[U-Boot] [PATCH 1/2] s3c64xx: upgrade s3c6400 to s3c64xx
From c56044d16f8ee5804d3048fe2c37028d5c963f1b Mon Sep 17 00:00:00 2001 From: Kavin Lau liujingwencn@gmail.com Date: Fri, 4 Mar 2011 12:58:47 +0800 Subject: [PATCH 1/2] s3c64xx: upgrade s3c6400 to s3c64xx
S3C6400, S3C6410 and S3C6430 are both pin and software compatible with each other, changed s3c6400 to s3c64xx to support those chips. --- arch/arm/cpu/arm1176/s3c64xx/Makefile | 2 +- arch/arm/cpu/arm1176/s3c64xx/cpu_init.S | 2 +- arch/arm/cpu/arm1176/s3c64xx/reset.S | 2 +- arch/arm/cpu/arm1176/s3c64xx/speed.c | 4 +- arch/arm/cpu/arm1176/s3c64xx/timer.c | 2 +- arch/arm/include/asm/arch-s3c64xx/s3c6400.h | 895 --------------------------- arch/arm/include/asm/arch-s3c64xx/s3c64x0.h | 8 +- arch/arm/include/asm/arch-s3c64xx/s3c64xx.h | 895 +++++++++++++++++++++++++++ board/samsung/smdk6400/lowlevel_init.S | 8 +- board/samsung/smdk6400/smdk6400.c | 2 +- drivers/mtd/nand/s3c64xx.c | 2 +- drivers/serial/s3c64xx.c | 4 +- drivers/usb/host/ohci-hcd.c | 2 +- drivers/usb/host/s3c64xx-hcd.c | 2 +- include/common.h | 2 +- 15 files changed, 916 insertions(+), 916 deletions(-) delete mode 100644 arch/arm/include/asm/arch-s3c64xx/s3c6400.h create mode 100644 arch/arm/include/asm/arch-s3c64xx/s3c64xx.h
Dear Kavin Lau,
In message 201103041704.04039.liujingwencn@gmail.com you wrote:
--Boundary-00=_DsKcNq+7G77Pv2N Content-Type: text/plain; charset="us-ascii" Content-Transfer-Encoding: quoted-printable
From c56044d16f8ee5804d3048fe2c37028d5c963f1b Mon Sep 17 00:00:00 2001 > From: Kavin Lau liujingwencn@gmail.com Date: Fri, 4 Mar 2011 12:58:47 +0800 Subject: [PATCH 1/2] s3c64xx: upgrade s3c6400 to s3c64xx
Why are you posting the same (?) patch within just 3 minutes?
Do not do that, please.
Kavin Lau
