[U-Boot] [PATCH] mips: fix DTC unit warnings
Fix following warnings for all mips based boards: mips: + pic32mzdask +Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name +Warning (unit_address_vs_reg): Node /cpus/cpu@0 has a unit name, but no reg property
Signed-off-by: Heiko Schocher hs@denx.de --- This warnings pop up with the DTC compiler: $ /tmp/dtc/dtc -v Version: DTC 1.4.1-gbeef80b8
This fixes the compile warnings for: https://travis-ci.org/hsdenx/u-boot/jobs/123254184
see: https://travis-ci.org/hsdenx/u-boot/jobs/123281033
arch/mips/dts/pic32mzda.dtsi | 2 +- arch/mips/dts/skeleton.dtsi | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/mips/dts/pic32mzda.dtsi b/arch/mips/dts/pic32mzda.dtsi index 8a554f9..791c364 100644 --- a/arch/mips/dts/pic32mzda.dtsi +++ b/arch/mips/dts/pic32mzda.dtsi @@ -27,7 +27,7 @@ };
cpus { - cpu@0 { + cpu { compatible = "mips,mips14kc"; }; }; diff --git a/arch/mips/dts/skeleton.dtsi b/arch/mips/dts/skeleton.dtsi index 24ee6c3..643996c 100644 --- a/arch/mips/dts/skeleton.dtsi +++ b/arch/mips/dts/skeleton.dtsi @@ -16,7 +16,7 @@ aliases { };
- memory { + memory@0 { device_type = "memory"; reg = <0 0>; };
cpus {
cpu@0 {
}; };cpu { compatible = "mips,mips14kc";
- memory {
- memory@0 { device_type = "memory"; reg = <0 0>; };
Reviewed-by: Purna Chandra Mandal purna.mandal@microchip.com
Am 15.04.2016 um 12:59 schrieb Heiko Schocher:
Acked-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
cpus {
cpu@0 {
- memory {
cpus {
cpu@0 {
- memory {
- memory@0 {
I have just been told on linux-rockchip mailing list that such a change should not be done as /memory is being special-cased in dtc warnings for the benefit of U-Boot. Supposedly U-Boot cannot handle updating memory size on /memory@0.
If that is untrue, please someone object on the Linux mailing lists.
Regards, Andreas
cpus {
cpu@0 {
- memory {
- memory@0 {
Uh, what? From dtc:
commit c9d9121683b35281239305e15adddfff2b462cf9 Author: Stephen Warren swarren@nvidia.com Date: Fri Feb 19 15:59:29 2016 +1100
Warn on node name unit-address presence/absence mismatch
ePAPR 1.1 section 2.2.1.1 "Node Name Requirements" specifies that any node that has a reg property must include a unit address in its name with value matching the first entry in its reg property. Conversely, if a node does not have a reg property, the node name must not include a unit address. Also allow ranges property as it is deemed valid, but ePAPR is not clear about it.
Implement a check for this. The code doesn't validate the format of the unit address; ePAPR implies this may vary from (containing bus) binding to binding, so doing so would be much more complex.
Signed-off-by: Stephen Warren swarren@nvidia.com [robh: also allow non-empty ranges] Signed-off-by: Rob Herring robh@kernel.org [moved new test in check_table] Signed-off-by: David Gibson david@gibson.dropbear.id.au
That's where that warning comes from.
But some real quick grepping makes it seem like the cpu@0 error is also a sign of a bigger problem in the dts file
But I would suggest that whomever is making special case warnings for U-Boot bring that up on the U-Boot mailing list or otherwise ask? We're not a black box...
Note that I am quite out-of-the-loop on these warning. I wrote the dtc patch that triggers them years ago, but it's only recently been applied due to Rob's efforts. I'm at most tangentially aware of the discussions surrounding applying it now.
cpus {
cpu@0 {
Surely the correct fix is to add a reg property? (Of course, this depends on the binding definition; for ARM my assertion would certainly be true). If not, what does MIPS do about SMP? Even if you write, say, 4 nodes with name "cpu" they'll all become the same single node in the DTB.
- memory {
- memory@0 {
Uh, what? From dtc:
I vaguely recall seeing discussion that /memory *would* be special-cased, but as you point out obviously isn't yet. I doubt it's anything to do with U-Boot itself, but rather the more general problem that if /memory@NNNN changes name based on what RAM is present, it's not possible for any bootloader to update it in a sane way (what node name do you search for to edit), or any OS to read it in a sane way (what node name do you search for to find out where memory is). As such, a special case is logically required.
Warn on node name unit-address presence/absence mismatch ePAPR 1.1 section 2.2.1.1 "Node Name Requirements" specifies that any node that has a reg property must include a unit address in its name with value matching the first entry in its reg property. Conversely, if a node does not have a reg property, the node name must not include a unit address. Also allow ranges property as it is deemed valid, but ePAPR is not clear about it. Implement a check for this. The code doesn't validate the format of the unit address; ePAPR implies this may vary from (containing bus) binding to binding, so doing so would be much more complex. Signed-off-by: Stephen Warren <swarren@nvidia.com> [robh: also allow non-empty ranges] Signed-off-by: Rob Herring <robh@kernel.org> [moved new test in check_table] Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Equally though, anyone working on DT in U-Boot should be hanging out on the device tree mailing list, and getting actively involved in discussions, rather than hiding here.
cpus {
cpu@0 {
So the likely answer here is that the dtsi is wrong and needs to be fixed rather than just dropping @0.
- memory {
- memory@0 {
Uh, what? From dtc:
Right, makes sense. But it'll also have to handle that today (nearly) everyone is /memory@NNNN.
True. And devicetree-spec is very quiet and devicetree is very very loud, and somewhere along the line for me at least vger kicked me off, sigh. Fixing that at least.
cpus {
cpu@0 {
- memory {
- memory@0 {
Uh, what? From dtc:
Nodes without a unit address are far more common currently, on ARM at least:
u-boot$ grep -HrnI 'memory@' arch/arm/dts|wc -l 3 u-boot$ grep -HrnI 'memory {' arch/arm/dts|wc -l 86
kernel.git$ grep -HrnI 'memory {' arch/arm/boot/dts|wc -l 528 kernel.git$ grep -HrnI memory@ arch/arm/boot/dts|wc -l 27 kernel.git$ cat arch/arm/boot/dts/skeleton.dtsi ... memory { device_type = "memory"; reg = <0 0>; };
(That last one is the base DT file that is typically included in all board files, and so should in theory set the correct example).
U-Boot's /memory updating code doesn't handle a unit address; see common/fdt_support.c fdt_fixup_memory_banks().
Linux's /memory parsing code doesn't handle a unit address, except for one PPC32 special case; see drivers/of/fdt.c early_init_dt_scan_memory().
(Which makes me wonder how any of the systems which do have /memory@nnn rather than plain /memory actual work...)
cpus {
cpu@0 {
- memory {
- memory@0 {
Uh, what? From dtc:
Brain fart, you are correct. I git grepped both memory and cpu and then got 'em backwards in my reply.
Hello Stephen,
Am 15.04.2016 um 18:56 schrieb Stephen Warren:
cpus {
cpu@0 {
Yes, everywhere I removed the @address I hope to get a response with the correct reg value. It is not possible for me to look through all the RMs ... nor test the new DTS on real boards ... and nobody has volunteered to fix the warnings, so I posted this "fixup" patch ...
So, lets discuss the correct fix ...
Hmm... is there a valid reg property for cpu ? Or can we add a dummy one?
Or may we do a "cpu@0" -> "cpu0"?
- memory {
- memory@0 {
Uh, what? From dtc:
Hmm.. dummy question ... why is:
memory: memory@address {
not possible?
Hmm... hidding is maybe the wrong definition ... instead I would call it "stack overflow" ... I try to follow device tree mailing list too, but also U-Boot, lkml, linux-mtd, ... and beside of this, I have also to work
so, yes I miss some(a lot currently) threads ... so, sorry for poping this thread up, but I want to get rid of this warnings ...
bye, Heiko
On Mon, Apr 18, 2016 at 07:38:36AM +0200, Heiko Schocher wrote:
Hello Stephen,
cpus {
cpu@0 {
Yes, we need to, but this isn't strictly a U-Boot problem, so this is by and large the wrong place to start with these patches.
No, in this case MIPS needs to update their skeleton to match the normal CPU binding.
[snip]
Well, sorry, but we're not going to address these warnings any time soon, by and large. The vast majority of these are in DT files that we inherit, almost entirely, from the kernel. The ones that we don't (ie most of x86) we should only update to fix this warning once everyone else agrees on the correct new style. Or if they already have, we need to do it that way.
You may wish to have travis-ci stuff pin down to an older DTC version for a while, to cut down on noise.
Am Freitag, 15. April 2016, 12:30:58 schrieb Tom Rini:
cpus {
cpu@0 {
aliases { };
- memory {
- memory@0 {
Uh, what? From dtc:
and that is supposed to get a special case for memory. On the kernel variant of dtc the change got deactivated again and will only trigger the warnings with a special command currently.
Also in another thread [0] on the arm-kernel-list Rob Herring explicitly stated:
This has come up before and been beaten to death. Bottom line is plain "memory" is allowed, and I plan to add that exception to dtc."
And as stated there as well, memory@0 is not correct in all cases, as it would need to be memory@baseaddress, so for example on Rockchip - memory@0 for the rk3288 - memory@60000000 for rk3188 and other A9s
So it's definitly not suitable for a general node in that skeleton,dtsi
Heiko
cpus {
cpu@0 {
- memory {
- memory@0 {
Interestingly MIPS arch does not update size on /memory node during bootm. Either we can fix that in arch/mips/ or all boards have to implement board specific ft_board_setup() to address this. Shortly you'll see a patch.
In PIC32 boards(may be in some other boards as well) embedded dts is used for U-Boot and for Linux full dts is downloaded from external media. And external version has updated memory reg=<> property so problem due to '/memory@0' fix is not seen.
Regards, Andreas
This just isn't right as-is (that cpu one is wrong, MIPS cannot make up a different binding from the right of the arches).
participants (7)
Andreas Färber
Daniel Schwierzeck
Heiko Schocher
Heiko Stübner
Stephen Warren
