[PATCH v2 0/7] rockchip: Fix RK3328 USB support
This series support fixes for RK3328 USB.
Changes for v2: - collect Marek RB - update phy driver clockout_ctl for rk3328 - retest on Xavier patches.
Any inputs? Jagan.
Jagan Teki (7): arm64: dts: rockchip: Drop unused rk3328-xhci node configs: Drop unused XHCI_DWC3 for RK3328 boards usb: dwc3-generic: Restrict single ctrl node for RK3328 configs: Enable DWC3 USB 3.0 on RK3328 boards phy: rockchip-inno-usb2: Add USB2 PHY for RK3328 clk: rockchip: rk3328: Handle usb480m phy clock configs: rockchip: Enable USB2PHY for RK3328 boards
arch/arm/dts/rk3328-evb-u-boot.dtsi | 5 --- arch/arm/dts/rk3328-roc-cc-u-boot.dtsi | 14 -------- arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi | 5 --- arch/arm/dts/rk3328-rock64-u-boot.dtsi | 15 -------- arch/arm/dts/rk3328-u-boot.dtsi | 11 ------ configs/evb-rk3328_defconfig | 4 ++- configs/nanopi-r2c-rk3328_defconfig | 4 ++- configs/nanopi-r2s-rk3328_defconfig | 4 ++- configs/roc-cc-rk3328_defconfig | 4 ++- configs/rock-pi-e-rk3328_defconfig | 4 ++- configs/rock64-rk3328_defconfig | 4 ++- drivers/clk/rockchip/clk_rk3328.c | 2 ++ drivers/phy/rockchip/phy-rockchip-inno-usb2.c | 34 +++++++++++++++++++ drivers/usb/dwc3/dwc3-generic.c | 2 +- 14 files changed, 55 insertions(+), 57 deletions(-)
rk3328-xhci has been added due to the fact that the upstream dwc3 is unsupported. Moreover, the driver for rk3328-xhci is not added to the code tree.
By considering these facts and unsupported rk3328-xhci this patch is dropping all related code from DT. However, the DWC3 is fixed now in dwc3-generic and RK3328 USB 3.0 is functional in upcoming patches.
Let's drop it.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v2: - none
arch/arm/dts/rk3328-evb-u-boot.dtsi | 5 ----- arch/arm/dts/rk3328-roc-cc-u-boot.dtsi | 14 -------------- arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi | 5 ----- arch/arm/dts/rk3328-rock64-u-boot.dtsi | 15 --------------- arch/arm/dts/rk3328-u-boot.dtsi | 11 ----------- 5 files changed, 50 deletions(-)
diff --git a/arch/arm/dts/rk3328-evb-u-boot.dtsi b/arch/arm/dts/rk3328-evb-u-boot.dtsi index 4bfa0c2330..f9c729d3bd 100644 --- a/arch/arm/dts/rk3328-evb-u-boot.dtsi +++ b/arch/arm/dts/rk3328-evb-u-boot.dtsi @@ -44,8 +44,3 @@ /* Integrated PHY unsupported by U-boot */ status = "broken"; }; - -&usb_host0_xhci { - vbus-supply = <&vcc5v0_host_xhci>; - status = "okay"; -}; diff --git a/arch/arm/dts/rk3328-roc-cc-u-boot.dtsi b/arch/arm/dts/rk3328-roc-cc-u-boot.dtsi index 27a454f017..2062f34bf8 100644 --- a/arch/arm/dts/rk3328-roc-cc-u-boot.dtsi +++ b/arch/arm/dts/rk3328-roc-cc-u-boot.dtsi @@ -48,20 +48,6 @@ bootph-pre-ram; };
-&usb_host0_xhci { - vbus-supply = <&vcc_host1_5v>; - status = "okay"; -}; - -/* - * This makes XHCI responsible for toggling VBUS. This is needed to work - * around an issue where either XHCI only works with USB 2.0 or OTG doesn't - * work, depending on how VBUS is configured. Having USB 3.0 seems better. - */ -&vcc_host1_5v { - /delete-property/ regulator-always-on; -}; - /* Need this and all the pinctrl/gpio stuff above to set pinmux */ &vcc_sd { bootph-pre-ram; diff --git a/arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi b/arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi index 088e21c76a..1f220c6dcd 100644 --- a/arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi +++ b/arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi @@ -45,11 +45,6 @@ bootph-pre-ram; };
-&usb_host0_xhci { - vbus-supply = <&vcc_host_5v>; - status = "okay"; -}; - /* Need this and all the pinctrl/gpio stuff above to set pinmux */ &vcc_sd { bootph-pre-ram; diff --git a/arch/arm/dts/rk3328-rock64-u-boot.dtsi b/arch/arm/dts/rk3328-rock64-u-boot.dtsi index c20a99a620..849854302e 100644 --- a/arch/arm/dts/rk3328-rock64-u-boot.dtsi +++ b/arch/arm/dts/rk3328-rock64-u-boot.dtsi @@ -48,21 +48,6 @@ bootph-pre-ram; };
-&usb_host0_xhci { - vbus-supply = <&vcc_host_5v>; - status = "okay"; -}; - -/* - * This makes XHCI responsible for toggling VBUS. This is needed to work - * around an issue where either XHCI only works with USB 2.0 or OTG doesn't - * work, depending on how VBUS is configured. Having USB 3.0 seems better. - */ -&vcc_host_5v { - /delete-property/ regulator-always-on; - /delete-property/ regulator-boot-on; -}; - /* Need this and all the pinctrl/gpio stuff above to set pinmux */ &vcc_sd { bootph-pre-ram; diff --git a/arch/arm/dts/rk3328-u-boot.dtsi b/arch/arm/dts/rk3328-u-boot.dtsi index 668f8ca29d..ce96ce40a7 100644 --- a/arch/arm/dts/rk3328-u-boot.dtsi +++ b/arch/arm/dts/rk3328-u-boot.dtsi @@ -26,17 +26,6 @@ 0x0 0xff720000 0x0 0x1000 0x0 0xff798000 0x0 0x1000>; }; - - usb_host0_xhci: usb@ff600000 { - compatible = "rockchip,rk3328-xhci"; - reg = <0x0 0xff600000 0x0 0x100000>; - interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>; - snps,dis-enblslpm-quirk; - snps,phyif-utmi-bits = <16>; - snps,dis-u2-freeclk-exists-quirk; - snps,dis-u2-susphy-quirk; - status = "disabled"; - }; };
&cru {
Let's drop it.
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Changes for v2:
none
-&usb_host0_xhci {
- status = "okay";
-&usb_host0_xhci {
- status = "okay";
- This makes XHCI responsible for toggling VBUS. This is needed to work
- around an issue where either XHCI only works with USB 2.0 or OTG doesn't
- work, depending on how VBUS is configured. Having USB 3.0 seems better.
-&vcc_host1_5v {
-&usb_host0_xhci {
- status = "okay";
-&usb_host0_xhci {
- status = "okay";
-&vcc_host_5v {
&cru {
Driver support for rk3328 is not supported so drop this unused XHCI_DWC3.
Cc: Tianling Shen cnsztl@gmail.com Cc: David Bauer mail@david-bauer.net Cc: Loic Devulder ldevulder@suse.com Cc: Chen-Yu Tsai wens@csie.org Cc: Banglang Huang banglang.huang@foxmail.com Cc: Matwey V. Kornilov matwey.kornilov@gmail.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v2: - none
configs/evb-rk3328_defconfig | 1 - configs/nanopi-r2c-rk3328_defconfig | 1 - configs/nanopi-r2s-rk3328_defconfig | 1 - configs/roc-cc-rk3328_defconfig | 1 - configs/rock-pi-e-rk3328_defconfig | 1 - configs/rock64-rk3328_defconfig | 1 - 6 files changed, 6 deletions(-)
diff --git a/configs/evb-rk3328_defconfig b/configs/evb-rk3328_defconfig index 580ee502dc..5ab7abff9e 100644 --- a/configs/evb-rk3328_defconfig +++ b/configs/evb-rk3328_defconfig @@ -93,7 +93,6 @@ CONFIG_SYSRESET=y # CONFIG_TPL_SYSRESET is not set CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/nanopi-r2c-rk3328_defconfig b/configs/nanopi-r2c-rk3328_defconfig index 84710c185b..6af874ca2c 100644 --- a/configs/nanopi-r2c-rk3328_defconfig +++ b/configs/nanopi-r2c-rk3328_defconfig @@ -97,7 +97,6 @@ CONFIG_SYSRESET=y # CONFIG_TPL_SYSRESET is not set CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/nanopi-r2s-rk3328_defconfig b/configs/nanopi-r2s-rk3328_defconfig index 21d7a073e2..7b0fadbce9 100644 --- a/configs/nanopi-r2s-rk3328_defconfig +++ b/configs/nanopi-r2s-rk3328_defconfig @@ -97,7 +97,6 @@ CONFIG_SYSRESET=y # CONFIG_TPL_SYSRESET is not set CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/roc-cc-rk3328_defconfig b/configs/roc-cc-rk3328_defconfig index 6b3bc75ae9..477179e80e 100644 --- a/configs/roc-cc-rk3328_defconfig +++ b/configs/roc-cc-rk3328_defconfig @@ -102,7 +102,6 @@ CONFIG_SYSRESET=y # CONFIG_TPL_SYSRESET is not set CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/rock-pi-e-rk3328_defconfig b/configs/rock-pi-e-rk3328_defconfig index 9c67d0c5fe..633d5417a9 100644 --- a/configs/rock-pi-e-rk3328_defconfig +++ b/configs/rock-pi-e-rk3328_defconfig @@ -103,7 +103,6 @@ CONFIG_SYSRESET=y # CONFIG_TPL_SYSRESET is not set CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/rock64-rk3328_defconfig b/configs/rock64-rk3328_defconfig index 74a9cc0a7d..ae761d08a1 100644 --- a/configs/rock64-rk3328_defconfig +++ b/configs/rock64-rk3328_defconfig @@ -100,7 +100,6 @@ CONFIG_SYSRESET=y # CONFIG_TPL_SYSRESET is not set CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y
Thanks, - Kever
Changes for v2:
none
Like Rockchip RK3568, the RK3328 also have single node to represent the glue and ctrl for USB 3.0.
So, use the driver data to use single ctrl for RK3328 DWC3.
Reviewed-by: Marek Vasut marex@denx.de Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v2: - collect Marek RB
drivers/usb/dwc3/dwc3-generic.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/usb/dwc3/dwc3-generic.c b/drivers/usb/dwc3/dwc3-generic.c index 5f8c2613a4..dcf420bafd 100644 --- a/drivers/usb/dwc3/dwc3-generic.c +++ b/drivers/usb/dwc3/dwc3-generic.c @@ -621,7 +621,7 @@ static const struct udevice_id dwc3_glue_ids[] = { { .compatible = "ti,dwc3", .data = (ulong)&ti_ops }, { .compatible = "ti,am437x-dwc3", .data = (ulong)&ti_ops }, { .compatible = "ti,am654-dwc3" }, - { .compatible = "rockchip,rk3328-dwc3" }, + { .compatible = "rockchip,rk3328-dwc3", .data = (ulong)&rk_ops }, { .compatible = "rockchip,rk3399-dwc3" }, { .compatible = "rockchip,rk3568-dwc3", .data = (ulong)&rk_ops }, { .compatible = "qcom,dwc3" },
Changes for v2:
- collect Marek RB
This doesn't build for me against master due to rk_ops not being defined, is this against another branch or builds upon another patch set?
-- 2.25.1
Changes for v2:
- collect Marek RB
This, on top of https://patchwork.ozlabs.org/project/uboot/patch/20230530102617.3413183-5-jo...
Jagan.
Thanks, - Kever
Changes for v2:
collect Marek RB
- { .compatible = "rockchip,rk3328-dwc3", .data = (ulong)&rk_ops }, { .compatible = "rockchip,rk3399-dwc3" }, { .compatible = "rockchip,rk3568-dwc3", .data = (ulong)&rk_ops }, { .compatible = "qcom,dwc3" },
Enable USB 3.0 in all RK3328 boards.
=> usb start starting USB... Bus usb@ff5c0000: ehci_generic usb@ff5c0000: Failed to get clocks (ret=-19) Port not available. Bus usb@ff5d0000: USB OHCI 1.0 Bus usb@ff600000: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus usb@ff580000: 1 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found => usb tree USB device tree: 1 Hub (12 Mb/s, 0mA) U-Boot Root Hub
1 Hub (5 Gb/s, 0mA) | U-Boot XHCI Host Controller | +-2 Mass Storage (5 Gb/s, 224mA) SanDisk Dual Drive 040130e3ee554b7078843f4eb331646
1 Hub (480 Mb/s, 0mA) U-Boot Root Hub
configs/evb-rk3328_defconfig | 2 ++ configs/nanopi-r2c-rk3328_defconfig | 2 ++ configs/nanopi-r2s-rk3328_defconfig | 2 ++ configs/roc-cc-rk3328_defconfig | 2 ++ configs/rock-pi-e-rk3328_defconfig | 2 ++ configs/rock64-rk3328_defconfig | 2 ++ 6 files changed, 12 insertions(+)
diff --git a/configs/evb-rk3328_defconfig b/configs/evb-rk3328_defconfig index 5ab7abff9e..5183d65451 100644 --- a/configs/evb-rk3328_defconfig +++ b/configs/evb-rk3328_defconfig @@ -69,6 +69,7 @@ CONFIG_FASTBOOT_BUF_ADDR=0x800800 CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_ETH_DESIGNWARE=y @@ -100,6 +101,7 @@ CONFIG_USB_OHCI_GENERIC=y CONFIG_USB_DWC2=y CONFIG_USB_DWC3=y # CONFIG_USB_DWC3_GADGET is not set +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_SPL_TINY_MEMSET=y diff --git a/configs/nanopi-r2c-rk3328_defconfig b/configs/nanopi-r2c-rk3328_defconfig index 6af874ca2c..fb0b8719fb 100644 --- a/configs/nanopi-r2c-rk3328_defconfig +++ b/configs/nanopi-r2c-rk3328_defconfig @@ -71,6 +71,7 @@ CONFIG_FASTBOOT_BUF_ADDR=0x800800 CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_ETH_DESIGNWARE=y @@ -104,6 +105,7 @@ CONFIG_USB_OHCI_GENERIC=y CONFIG_USB_DWC2=y CONFIG_USB_DWC3=y # CONFIG_USB_DWC3_GADGET is not set +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_SPL_TINY_MEMSET=y diff --git a/configs/nanopi-r2s-rk3328_defconfig b/configs/nanopi-r2s-rk3328_defconfig index 7b0fadbce9..79cb17d751 100644 --- a/configs/nanopi-r2s-rk3328_defconfig +++ b/configs/nanopi-r2s-rk3328_defconfig @@ -71,6 +71,7 @@ CONFIG_FASTBOOT_BUF_ADDR=0x800800 CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_ETH_DESIGNWARE=y @@ -104,6 +105,7 @@ CONFIG_USB_OHCI_GENERIC=y CONFIG_USB_DWC2=y CONFIG_USB_DWC3=y # CONFIG_USB_DWC3_GADGET is not set +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_SPL_TINY_MEMSET=y diff --git a/configs/roc-cc-rk3328_defconfig b/configs/roc-cc-rk3328_defconfig index 477179e80e..f5912ceca9 100644 --- a/configs/roc-cc-rk3328_defconfig +++ b/configs/roc-cc-rk3328_defconfig @@ -72,6 +72,7 @@ CONFIG_FASTBOOT_BUF_ADDR=0x800800 CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_PHY_REALTEK=y @@ -109,6 +110,7 @@ CONFIG_USB_OHCI_GENERIC=y CONFIG_USB_DWC2=y CONFIG_USB_DWC3=y # CONFIG_USB_DWC3_GADGET is not set +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_SPL_TINY_MEMSET=y diff --git a/configs/rock-pi-e-rk3328_defconfig b/configs/rock-pi-e-rk3328_defconfig index 633d5417a9..e86a6f7b1a 100644 --- a/configs/rock-pi-e-rk3328_defconfig +++ b/configs/rock-pi-e-rk3328_defconfig @@ -73,6 +73,7 @@ CONFIG_FASTBOOT_BUF_ADDR=0x800800 CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_ETH_DESIGNWARE=y @@ -101,6 +102,7 @@ CONFIG_SYSINFO=y CONFIG_SYSINFO_SMBIOS=y CONFIG_SYSRESET=y # CONFIG_TPL_SYSRESET is not set +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/rock64-rk3328_defconfig b/configs/rock64-rk3328_defconfig index ae761d08a1..4acbca0140 100644 --- a/configs/rock64-rk3328_defconfig +++ b/configs/rock64-rk3328_defconfig @@ -71,6 +71,7 @@ CONFIG_FASTBOOT_BUF_ADDR=0x800800 CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH_GIGADEVICE=y @@ -107,6 +108,7 @@ CONFIG_USB_OHCI_GENERIC=y CONFIG_USB_DWC2=y CONFIG_USB_DWC3=y # CONFIG_USB_DWC3_GADGET is not set +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_SPL_TINY_MEMSET=y
Thanks, - Kever
Changes for v2:
none
USB2.0 Host and OTG controllers in RK3328 are using USB2PHY.
Add support for it.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v2: - add clkout_ctl
drivers/phy/rockchip/phy-rockchip-inno-usb2.c | 34 +++++++++++++++++++ 1 file changed, 34 insertions(+)
diff --git a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c index e43a5ba9b5..d8738f891d 100644 --- a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c +++ b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c @@ -345,6 +345,36 @@ bind_fail: return ret; }
+static const struct rockchip_usb2phy_cfg rk3328_usb2phy_cfgs[] = { + { + .reg = 0x100, + .clkout_ctl = { 0x108, 4, 4, 1, 0 }, + .port_cfgs = { + [USB2PHY_PORT_OTG] = { + .phy_sus = { 0x0100, 15, 0, 0, 0x1d1 }, + .bvalid_det_en = { 0x0110, 3, 2, 0, 3 }, + .bvalid_det_st = { 0x0114, 3, 2, 0, 3 }, + .bvalid_det_clr = { 0x0118, 3, 2, 0, 3 }, + .ls_det_en = { 0x0110, 0, 0, 0, 1 }, + .ls_det_st = { 0x0114, 0, 0, 0, 1 }, + .ls_det_clr = { 0x0118, 0, 0, 0, 1 }, + .utmi_avalid = { 0x0120, 10, 10, 0, 1 }, + .utmi_bvalid = { 0x0120, 9, 9, 0, 1 }, + .utmi_ls = { 0x0120, 5, 4, 0, 1 }, + }, + [USB2PHY_PORT_HOST] = { + .phy_sus = { 0x104, 15, 0, 0, 0x1d1 }, + .ls_det_en = { 0x110, 1, 1, 0, 1 }, + .ls_det_st = { 0x114, 1, 1, 0, 1 }, + .ls_det_clr = { 0x118, 1, 1, 0, 1 }, + .utmi_ls = { 0x120, 17, 16, 0, 1 }, + .utmi_hstdet = { 0x120, 19, 19, 0, 1 } + } + }, + }, + { /* sentinel */ } +}; + static const struct rockchip_usb2phy_cfg rk3399_usb2phy_cfgs[] = { { .reg = 0xe450, @@ -498,6 +528,10 @@ static const struct rockchip_usb2phy_cfg rk3588_phy_cfgs[] = { };
static const struct udevice_id rockchip_usb2phy_ids[] = { + { + .compatible = "rockchip,rk3328-usb2phy", + .data = (ulong)&rk3328_usb2phy_cfgs, + }, { .compatible = "rockchip,rk3399-usb2phy", .data = (ulong)&rk3399_usb2phy_cfgs,
El Tue, Jun 06, 2023 at 10:39:16PM +0530, Jagan Teki deia:
Add support for it.
Reviewed-by: Xavier Drudis Ferran xdrudis@tinet.cat
(fwiw, I just compared it with linux)
I just wanted to note this patch as written most likely depends on https://patchwork.ozlabs.org/project/uboot/patch/464111fca83008503022e8ada53...
which introduces the struct member clkout_ctl used here.
Changes for v2:
- add clkout_ctl
.reg = 0x100,
Add support for it.
Thanks, - Kever
Changes for v2:
add clkout_ctl
.reg = 0x100,
.port_cfgs = {
- { /* sentinel */ }
- static const struct rockchip_usb2phy_cfg rk3399_usb2phy_cfgs[] = { { .reg = 0xe450,
- }, { .compatible = "rockchip,rk3399-usb2phy", .data = (ulong)&rk3399_usb2phy_cfgs,
Handle USB480M clock ID in set_rate() and set_parent() to allow the dt assigned-clocks and assigned-clock-parents work on rk3328.dtsi
Cc: Lukasz Majewski lukma@denx.de Cc: Sean Anderson seanga2@gmail.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v2: - add USB480M to set_parent
drivers/clk/rockchip/clk_rk3328.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/clk/rockchip/clk_rk3328.c b/drivers/clk/rockchip/clk_rk3328.c index 969b7a8581..ef97381f0e 100644 --- a/drivers/clk/rockchip/clk_rk3328.c +++ b/drivers/clk/rockchip/clk_rk3328.c @@ -681,6 +681,7 @@ static ulong rk3328_clk_set_rate(struct clk *clk, ulong rate) case ACLK_GMAC: case PCLK_GMAC: case SCLK_USB3OTG_SUSPEND: + case USB480M: return 0; default: return -ENOENT; @@ -771,6 +772,7 @@ static int rk3328_clk_set_parent(struct clk *clk, struct clk *parent) case SCLK_MAC2IO_EXT: return rk3328_gmac2io_ext_set_parent(clk, parent); case DCLK_LCDC: + case USB480M: case SCLK_PDM: case SCLK_RTC32K: case SCLK_UART0:
Thanks, - Kever
Changes for v2:
- case USB480M: return 0; default: return -ENOENT;
- case USB480M: case SCLK_PDM: case SCLK_RTC32K: case SCLK_UART0:
Enable USB2PHY for all RK3328 boards.
=> usb start starting USB... Bus usb@ff5c0000: USB EHCI 1.00 Bus usb@ff5d0000: USB OHCI 1.0 Bus usb@ff600000: generic_phy_get_bulk : no phys property Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus usb@ff580000: USB DWC2 scanning bus usb@ff5c0000 for devices... 2 USB Device(s) found scanning bus usb@ff5d0000 for devices... 1 USB Device(s) found scanning bus usb@ff600000 for devices... 2 USB Device(s) found scanning bus usb@ff580000 for devices... 2 USB Device(s) found scanning usb for storage devices... 2 Storage Device(s) found => usb tree USB device tree: 1 Hub (480 Mb/s, 0mA) | u-boot EHCI Host Controller | +-2 Mass Storage (480 Mb/s, 500mA) TS-RDF5A Transcend 000000000009
1 Hub (480 Mb/s, 0mA) | U-Boot Root Hub | +-2 Human Interface (12 Mb/s, 98mA) Logitech USB Receiver
=> dm tree -s Class Index Probed Driver Name ----------------------------------------------------------- syscon 1 [ + ] syscon |-- syscon@ff450000 phy 0 [ + ] rockchip_usb2phy | `-- usb2phy@100 clk 2 [ + ] rockchip_usb2phy_clo | |-- usb480m_phy phy 1 [ + ] rockchip_usb2phy_por | |-- otg-port phy 2 [ + ] rockchip_usb2phy_por | `-- host-port sysinfo 0 [ + ] sysinfo_smbios |-- smbios usb 3 [ + ] dwc2_usb |-- usb@ff580000 usb_hub 3 [ + ] usb_hub | `-- usb_hub usb_dev_ge 0 [ + ] usb_dev_generic_drv | `-- generic_bus_3_dev_2 usb 0 [ + ] ehci_generic |-- usb@ff5c0000 usb_hub 0 [ + ] usb_hub | `-- usb_hub usb_mass_s 0 [ + ] usb_mass_storage | `-- usb_mass_storage blk 2 [ + ] usb_storage_blk | |-- usb_mass_storage.lun0 partition 4 [ + ] blk_partition | | |-- usb_mass_storage.lun0:1 partition 5 [ + ] blk_partition | | `-- usb_mass_storage.lun0:2 bootdev 3 [ ] usb_bootdev | `-- usb_mass_storage.lun0.bootdev usb 1 [ + ] ohci_generic `-- usb@ff5d0000 usb_hub 1 [ + ] usb_hub `-- usb_hub
Cc: Tianling Shen cnsztl@gmail.com Cc: David Bauer mail@david-bauer.net Cc: Loic Devulder ldevulder@suse.com Cc: Chen-Yu Tsai wens@csie.org Cc: Banglang Huang banglang.huang@foxmail.com Cc: Matwey V. Kornilov matwey.kornilov@gmail.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v2: - update commit message.
configs/evb-rk3328_defconfig | 1 + configs/nanopi-r2c-rk3328_defconfig | 1 + configs/nanopi-r2s-rk3328_defconfig | 1 + configs/roc-cc-rk3328_defconfig | 1 + configs/rock-pi-e-rk3328_defconfig | 1 + configs/rock64-rk3328_defconfig | 1 + 6 files changed, 6 insertions(+)
diff --git a/configs/evb-rk3328_defconfig b/configs/evb-rk3328_defconfig index 5183d65451..8f53aadbb6 100644 --- a/configs/evb-rk3328_defconfig +++ b/configs/evb-rk3328_defconfig @@ -74,6 +74,7 @@ CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_DM_PMIC=y diff --git a/configs/nanopi-r2c-rk3328_defconfig b/configs/nanopi-r2c-rk3328_defconfig index fb0b8719fb..583179d7c5 100644 --- a/configs/nanopi-r2c-rk3328_defconfig +++ b/configs/nanopi-r2c-rk3328_defconfig @@ -76,6 +76,7 @@ CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_DM_PMIC=y diff --git a/configs/nanopi-r2s-rk3328_defconfig b/configs/nanopi-r2s-rk3328_defconfig index 79cb17d751..f7ed71e412 100644 --- a/configs/nanopi-r2s-rk3328_defconfig +++ b/configs/nanopi-r2s-rk3328_defconfig @@ -76,6 +76,7 @@ CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_DM_PMIC=y diff --git a/configs/roc-cc-rk3328_defconfig b/configs/roc-cc-rk3328_defconfig index f5912ceca9..4ac3c9403b 100644 --- a/configs/roc-cc-rk3328_defconfig +++ b/configs/roc-cc-rk3328_defconfig @@ -79,6 +79,7 @@ CONFIG_PHY_REALTEK=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_DM_PMIC=y diff --git a/configs/rock-pi-e-rk3328_defconfig b/configs/rock-pi-e-rk3328_defconfig index e86a6f7b1a..277f691d4d 100644 --- a/configs/rock-pi-e-rk3328_defconfig +++ b/configs/rock-pi-e-rk3328_defconfig @@ -78,6 +78,7 @@ CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y CONFIG_PHY=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y diff --git a/configs/rock64-rk3328_defconfig b/configs/rock64-rk3328_defconfig index 4acbca0140..5e36612bb8 100644 --- a/configs/rock64-rk3328_defconfig +++ b/configs/rock64-rk3328_defconfig @@ -77,6 +77,7 @@ CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_DM_PMIC=y
Thanks, - Kever
Changes for v2:
Changes for v2:
- collect Marek RB
Any inputs?
I've done some basic testing of thing on a Rock64 and it looks good to me so for the series: Tested-by: Peter Robinson pbrobinson@gmail.com
Jagan.
-- 2.25.1
Hi Kever,
Changes for v2:
- collect Marek RB
Any inputs? Jagan.
Merge them in MW if you don't have any comments.
Thanks, Jagan.
Jagan Teki
Kever Yang
Peter Robinson
