[PATCH v2] kontron-sl-mx8mm: Add CAAM support
Add CAAM support, which is required when enabling HAB secure boot.
Select CONFIG_SPL_DRIVERS_MISC so that CONFIG_IMX_HAB could build successfully, if selected.
Signed-off-by: Fabio Estevam festevam@denx.de --- Changes since v1: - Do not disable sec_jr0 node in -u-boot.dtsi. This will get disabled by the imx8mm.dtsi. Sent a patch upstream doing this. (Andrey)
arch/arm/dts/imx8mm-kontron-n801x-u-boot.dtsi | 16 ++++++++++++++++ arch/arm/mach-imx/imx8m/Kconfig | 3 +++ board/kontron/sl-mx8mm/spl.c | 9 +++++++++ configs/kontron-sl-mx8mm_defconfig | 1 + 4 files changed, 29 insertions(+)
diff --git a/arch/arm/dts/imx8mm-kontron-n801x-u-boot.dtsi b/arch/arm/dts/imx8mm-kontron-n801x-u-boot.dtsi index 22d18e6f1c..65ff3988d9 100644 --- a/arch/arm/dts/imx8mm-kontron-n801x-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-kontron-n801x-u-boot.dtsi @@ -25,6 +25,22 @@ }; };
+&crypto { + u-boot,dm-spl; +}; + +&sec_jr0 { + u-boot,dm-spl; +}; + +&sec_jr1 { + u-boot,dm-spl; +}; + +&sec_jr2 { + u-boot,dm-spl; +}; + &fec1 { phy-mode = "rgmii-rxid"; }; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 61397bf88d..5c59422ecb 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -106,6 +106,9 @@ config TARGET_KONTRON_MX8MM select IMX8MM select SUPPORT_SPL select IMX8M_LPDDR4 + select FSL_CAAM + select ARCH_MISC_INIT + select SPL_CRYPTO if SPL
config TARGET_IMX8MN_BSH_SMM_S2 bool "imx8mn-bsh-smm-s2" diff --git a/board/kontron/sl-mx8mm/spl.c b/board/kontron/sl-mx8mm/spl.c index 4ef03c8c17..5a513722c5 100644 --- a/board/kontron/sl-mx8mm/spl.c +++ b/board/kontron/sl-mx8mm/spl.c @@ -13,6 +13,9 @@ #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/iomux-v3.h> #include <dm/uclass.h> +#include <dm/device.h> +#include <dm/uclass-internal.h> +#include <dm/device-internal.h> #include <hang.h> #include <i2c.h> #include <init.h> @@ -213,6 +216,12 @@ void spl_board_init(void) struct udevice *dev; int ret;
+ if (IS_ENABLED(CONFIG_FSL_CAAM)) { + ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(caam_jr), &dev); + if (ret) + printf("Failed to initialize %s: %d\n", dev->name, ret); + } + puts("Normal Boot\n");
ret = uclass_get_device_by_name(UCLASS_CLK, diff --git a/configs/kontron-sl-mx8mm_defconfig b/configs/kontron-sl-mx8mm_defconfig index 2e9d52522b..eae9ac0dbe 100644 --- a/configs/kontron-sl-mx8mm_defconfig +++ b/configs/kontron-sl-mx8mm_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL_TEXT_BASE=0x7E1000 CONFIG_TARGET_KONTRON_MX8MM=y CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x42000000
Am 09.06.22 um 22:13 schrieb Fabio Estevam:
Build-tested on next and partly runtime-tested by verifying that "SEC0: RNG instantiated" is printed to the console in SPL and U-Boot proper.
Acked-by: Frieder Schrempf frieder.schrempf@kontron.de Tested-by: Frieder Schrempf frieder.schrempf@kontron.de
Changes since v1:
+&crypto {
- u-boot,dm-spl;
+&sec_jr0 {
- u-boot,dm-spl;
+&sec_jr1 {
- u-boot,dm-spl;
+&sec_jr2 {
- u-boot,dm-spl;
- select FSL_CAAM
- select ARCH_MISC_INIT
- select SPL_CRYPTO if SPL
if (ret)
Fabio Estevam
Frieder Schrempf
