[U-Boot] [PATCH-OMAP3] OMAP3: Fix gpmc_cs_base pointer math in NAND
Subject: [PATCH-OMAP3] OMAP3: Fix gpmc_cs_base pointer math in NAND
gpmc_cs_base is an uint32_t pointer, correct pointer math. Missed after readl/writel conversion.
Signed-off-by: Dirk Behme dirk.behme@gmail.com
Jean-Christophe: Would be nice if you could handle this patch with priority as it prevents BeagleBoard from starting. Thanks!
drivers/mtd/nand/omap_gpmc.c | 10 +++++----- 1 files changed, 5 insertions(+), 5 deletions(-)
Index: u-boot-arm/drivers/mtd/nand/omap_gpmc.c =================================================================== --- u-boot-arm.orig/drivers/mtd/nand/omap_gpmc.c +++ u-boot-arm/drivers/mtd/nand/omap_gpmc.c @@ -48,13 +48,13 @@ static void omap_nand_hwcontrol(struct m */ switch (ctrl) { case NAND_CTRL_CHANGE | NAND_CTRL_CLE: - this->IO_ADDR_W = gpmc_cs_base + GPMC_NAND_CMD; + this->IO_ADDR_W = gpmc_cs_base + OFFS(GPMC_NAND_CMD); break; case NAND_CTRL_CHANGE | NAND_CTRL_ALE: - this->IO_ADDR_W = gpmc_cs_base + GPMC_NAND_ADR; + this->IO_ADDR_W = gpmc_cs_base + OFFS(GPMC_NAND_ADR); break; case NAND_CTRL_CHANGE | NAND_NCE: - this->IO_ADDR_W = gpmc_cs_base + GPMC_NAND_DAT; + this->IO_ADDR_W = gpmc_cs_base + OFFS(GPMC_NAND_DAT); break; }
@@ -321,8 +321,8 @@ int board_nand_init(struct nand_chip *na gpmc_config |= 0x10; writel(gpmc_config, gpmc_base + OFFS(GPMC_CONFIG));
- nand->IO_ADDR_R = gpmc_cs_base + GPMC_NAND_DAT; - nand->IO_ADDR_W = gpmc_cs_base + GPMC_NAND_CMD; + nand->IO_ADDR_R = gpmc_cs_base + OFFS(GPMC_NAND_DAT); + nand->IO_ADDR_W = gpmc_cs_base + OFFS(GPMC_NAND_CMD);
nand->cmd_ctrl = omap_nand_hwcontrol; nand->options = NAND_NO_PADDING | NAND_CACHEPRG | NAND_NO_AUTOINCR |
Dear dirk.behme@googlemail.com,
Delete that.
Line too long.
Ditto for the other postings vof this patch series.
dirk.behmeï¼ googlemail.com
