[U-Boot] [PATCH 1/6] am335x_evm: Drop useless CONFIG_ENV_IS_NOWHERE
We always set a CONFIG_ENV_IS_...somewhere... so drop the initial define of NOWHERE.
Signed-off-by: Tom Rini trini@ti.com --- include/configs/am335x_evm.h | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index ef00306..945ec09 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -298,8 +298,6 @@ #define CONFIG_ENV_OVERWRITE 1 #define CONFIG_SYS_CONSOLE_INFO_QUIET
-#define CONFIG_ENV_IS_NOWHERE - /* Defines for SPL */ #define CONFIG_SPL #define CONFIG_SPL_FRAMEWORK @@ -434,7 +432,6 @@ * 0x442000 - 0x800000 : Userland */ #if defined(CONFIG_SPI_BOOT) -# undef CONFIG_ENV_IS_NOWHERE # define CONFIG_ENV_IS_IN_SPI_FLASH # define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED # define CONFIG_ENV_OFFSET (892 << 10) /* 892 KiB in */ @@ -481,7 +478,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ #if !defined(CONFIG_SPI_BOOT) -#undef CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0x260000 /* environment starts here */ #define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */
Signed-off-by: Tom Rini trini@ti.com --- include/configs/am335x_evm.h | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 945ec09..004a06a 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -436,6 +436,13 @@ # define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED # define CONFIG_ENV_OFFSET (892 << 10) /* 892 KiB in */ # define CONFIG_ENV_SECT_SIZE (4 << 10) /* 4 KB sectors */ +#define CONFIG_CMD_MTDPARTS +#define MTDIDS_DEFAULT "nor0=physmap-flash.0" +#define MTDPARTS_DEFAULT "mtdparts=physmap-flash.0:128k(SPL)," \ + "128k(SPL.backup1)," \ + "128k(SPL.backup2)," \ + "128k(SPL.backup3),384k(u-boot)," \ + "4k(u-boot-env),3464k(kernel),-(rootfs)" #endif /* SPI support */
/* Unsupported features */
"Tom" == Tom Rini trini@ti.com writes:
Tom> Signed-off-by: Tom Rini trini@ti.com Tom> --- Tom> include/configs/am335x_evm.h | 7 +++++++ Tom> 1 file changed, 7 insertions(+)
Tom> diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h Tom> index 945ec09..004a06a 100644 Tom> --- a/include/configs/am335x_evm.h Tom> +++ b/include/configs/am335x_evm.h Tom> @@ -436,6 +436,13 @@ Tom> # define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED Tom> # define CONFIG_ENV_OFFSET (892 << 10) /* 892 KiB in */ Tom> # define CONFIG_ENV_SECT_SIZE (4 << 10) /* 4 KB sectors */ Tom> +#define CONFIG_CMD_MTDPARTS Tom> +#define MTDIDS_DEFAULT "nor0=physmap-flash.0" Tom> +#define MTDPARTS_DEFAULT "mtdparts=physmap-flash.0:128k(SPL)," \
physmap for a spi flash? I would have expected to see m25p80?
Tom> + "128k(SPL.backup1)," \ Tom> + "128k(SPL.backup2)," \ Tom> + "128k(SPL.backup3),384k(u-boot)," \ Tom> + "4k(u-boot-env),3464k(kernel),-(rootfs)" Tom> #endif /* SPI support */
Tom> /* Unsupported features */ Tom> -- Tom> 1.7.9.5
Tom> _______________________________________________ Tom> U-Boot mailing list Tom> U-Boot@lists.denx.de Tom> http://lists.denx.de/mailman/listinfo/u-boot
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
Yes, I'd swear it's physmap when I've tested it on the vendor kernel tree.
- -- Tom
Or I must be misrecalling things, changed.
Due to hardware design, we can't have NAND present (as we know of NAND today) when booting from SPI, so disable NAND then as that simplifies logic.
Signed-off-by: Tom Rini trini@ti.com --- include/configs/am335x_evm.h | 9 +++++++-- 1 file changed, 7 insertions(+), 2 deletions(-)
diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 004a06a..90cc1f5 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -230,7 +230,9 @@ /* USB Device Firmware Update support */ #define CONFIG_DFU_FUNCTION #define CONFIG_DFU_MMC +#ifdef CONFIG_NAND #define CONFIG_DFU_NAND +#endif #define CONFIG_CMD_DFU #define DFU_ALT_INFO_MMC \ "boot part 0 1;" \ @@ -335,6 +337,7 @@ #define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/am33xx/u-boot-spl.lds"
#define CONFIG_SPL_BOARD_INIT +#ifdef CONFIG_NAND #define CONFIG_SPL_NAND_AM33XX_BCH #define CONFIG_SPL_NAND_SUPPORT #define CONFIG_SPL_NAND_BASE @@ -365,6 +368,7 @@ #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE
#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 +#endif
/* * 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM @@ -466,7 +470,10 @@ #define CONFIG_PHY_ADDR 0 #define CONFIG_PHY_SMSC
+#if !defined(CONFIG_SPI_BOOT) #define CONFIG_NAND +#endif + /* NAND support */ #ifdef CONFIG_NAND #define CONFIG_CMD_NAND @@ -484,11 +491,9 @@ /* CS0 */ #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ -#if !defined(CONFIG_SPI_BOOT) #define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0x260000 /* environment starts here */ #define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ #endif -#endif
#endif /* ! __CONFIG_AM335X_EVM_H */
Tom> Due to hardware design, we can't have NAND present (as we know of NAND Tom> today) when booting from SPI, so disable NAND then as that simplifies Tom> logic.
Sorry, this description is not clear to me. I didn't check in detail, but as far as I remember the default pins for spi0 don't conflict with gmpc.
It's also not quite clear to me if you refer to SW support for NAND flash or the hardware component when you say 'NAND' above.
Tom> Signed-off-by: Tom Rini trini@ti.com Tom> --- Tom> include/configs/am335x_evm.h | 9 +++++++-- Tom> 1 file changed, 7 insertions(+), 2 deletions(-)
Tom> diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h Tom> index 004a06a..90cc1f5 100644 Tom> --- a/include/configs/am335x_evm.h Tom> +++ b/include/configs/am335x_evm.h Tom> @@ -230,7 +230,9 @@ Tom> /* USB Device Firmware Update support */ Tom> #define CONFIG_DFU_FUNCTION Tom> #define CONFIG_DFU_MMC Tom> +#ifdef CONFIG_NAND Tom> #define CONFIG_DFU_NAND Tom> +#endif Tom> #define CONFIG_CMD_DFU Tom> #define DFU_ALT_INFO_MMC \ Tom> "boot part 0 1;" \ Tom> @@ -335,6 +337,7 @@ Tom> #define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/am33xx/u-boot-spl.lds"
Tom> #define CONFIG_SPL_BOARD_INIT Tom> +#ifdef CONFIG_NAND Tom> #define CONFIG_SPL_NAND_AM33XX_BCH Tom> #define CONFIG_SPL_NAND_SUPPORT Tom> #define CONFIG_SPL_NAND_BASE Tom> @@ -365,6 +368,7 @@ Tom> #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE
Tom> #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 Tom> +#endif
Tom> /* Tom> * 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM Tom> @@ -466,7 +470,10 @@ Tom> #define CONFIG_PHY_ADDR 0 Tom> #define CONFIG_PHY_SMSC
Tom> +#if !defined(CONFIG_SPI_BOOT) Tom> #define CONFIG_NAND Tom> +#endif Tom> + Tom> /* NAND support */ Tom> #ifdef CONFIG_NAND Tom> #define CONFIG_CMD_NAND Tom> @@ -484,11 +491,9 @@ Tom> /* CS0 */ Tom> #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND Tom> devices */ Tom> -#if !defined(CONFIG_SPI_BOOT) Tom> #define CONFIG_ENV_IS_IN_NAND Tom> #define CONFIG_ENV_OFFSET 0x260000 /* environment starts here */ Tom> #define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ Tom> #endif Tom> -#endif
Tom> #endif /* ! __CONFIG_AM335X_EVM_H */ Tom> -- Tom> 1.7.9.5
It's also not quite clear to me if you refer to SW support fo NAND flash or the hardware component when you say 'NAND' above.
OK, good point. I'm talking about HW support, and it should be spelled put better. Note that we're talking about the TI GP EVM, EVM SK, BeagleBone White and BeagleBone Black here, and not custom hardware. The EVM SK does not allow for expansion such as adding NAND/NOR flash and probably not SPI. The GP EVM can have only one of NOR, NAND or SPI flash active based on the profile that is selected for the whole hardware stack. The BeagleBone White may have a "memory cape" installed which in turn can have a NAND, NOR or eMMC board plugged into it. It's not impossible someone could come up with a SPI flash cape and plug the memory cape into that, or come up with a complex breadboard solution. But lets see that happen and work before worrying about that particular permutation.
- -- Tom
We rework the various board_is_foo() checks to take a pointer to struct am335x_baseboard_id rather than using a local copy in board.c. This allows us to make use of the same checks in mux.c as well as fixing problems when this code could be running from read-only memory.
Signed-off-by: Tom Rini trini@ti.com --- board/ti/am335x/board.c | 78 ++++++++++++++++------------------------------- board/ti/am335x/board.h | 31 +++++++++++++++++++ board/ti/am335x/mux.c | 10 +++--- 3 files changed, 62 insertions(+), 57 deletions(-)
diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index b371376..6f6b5d0 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -51,43 +51,10 @@ static struct uart_sys *uart_base = (struct uart_sys *)DEFAULT_UART_BASE;
static struct ctrl_dev *cdev = (struct ctrl_dev *)CTRL_DEVICE_BASE;
-static struct am335x_baseboard_id __attribute__((section (".data"))) header; - -static inline int board_is_bone(void) -{ - return !strncmp(header.name, "A335BONE", HDR_NAME_LEN); -} - -static inline int board_is_bone_lt(void) -{ - return !strncmp(header.name, "A335BNLT", HDR_NAME_LEN); -} - -static inline int board_is_evm_sk(void) -{ - return !strncmp("A335X_SK", header.name, HDR_NAME_LEN); -} - -static inline int board_is_idk(void) -{ - return !strncmp(header.config, "SKU#02", 6); -} - -static int __maybe_unused board_is_gp_evm(void) -{ - return !strncmp("A33515BB", header.name, 8); -} - -int board_is_evm_15_or_later(void) -{ - return (!strncmp("A33515BB", header.name, 8) && - strncmp("1.5", header.version, 3) <= 0); -} - /* * Read header information from EEPROM into global structure. */ -static int read_eeprom(void) +static int read_eeprom(struct am335x_baseboard_id *header) { /* Check if baseboard eeprom is available */ if (i2c_probe(CONFIG_SYS_I2C_EEPROM_ADDR)) { @@ -97,28 +64,28 @@ static int read_eeprom(void) }
/* read the eeprom using i2c */ - if (i2c_read(CONFIG_SYS_I2C_EEPROM_ADDR, 0, 2, (uchar *)&header, - sizeof(header))) { + if (i2c_read(CONFIG_SYS_I2C_EEPROM_ADDR, 0, 2, (uchar *)header, + sizeof(struct am335x_baseboard_id))) { puts("Could not read the EEPROM; something fundamentally" " wrong on the I2C bus.\n"); return -EIO; }
- if (header.magic != 0xEE3355AA) { + if (header->magic != 0xEE3355AA) { /* * read the eeprom using i2c again, * but use only a 1 byte address */ - if (i2c_read(CONFIG_SYS_I2C_EEPROM_ADDR, 0, 1, - (uchar *)&header, sizeof(header))) { + if (i2c_read(CONFIG_SYS_I2C_EEPROM_ADDR, 0, 1, (uchar *)header, + sizeof(struct am335x_baseboard_id))) { puts("Could not read the EEPROM; something " "fundamentally wrong on the I2C bus.\n"); return -EIO; }
- if (header.magic != 0xEE3355AA) { + if (header->magic != 0xEE3355AA) { printf("Incorrect magic number (0x%x) in EEPROM\n", - header.magic); + header->magic); return -EINVAL; } } @@ -304,6 +271,8 @@ static struct emif_regs ddr3_evm_emif_reg_data = { */ void s_init(void) { + __maybe_unused struct am335x_baseboard_id header; + /* WDT1 is already running when the bootloader gets control * Disable it to avoid "random" resets */ @@ -362,11 +331,11 @@ void s_init(void) /* Initalize the board header */ enable_i2c0_pin_mux(); i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); - if (read_eeprom() < 0) + if (read_eeprom(&header) < 0) puts("Could not get board ID.\n");
enable_board_pin_mux(&header); - if (board_is_evm_sk()) { + if (board_is_evm_sk(&header)) { /* * EVM SK 1.2A and later use gpio0_7 to enable DDR3. * This is safe enough to do on older revs. @@ -375,15 +344,15 @@ void s_init(void) gpio_direction_output(GPIO_DDR_VTT_EN, 1); }
- if (board_is_evm_sk()) + if (board_is_evm_sk(&header)) config_ddr(303, MT41J128MJT125_IOCTRL_VALUE, &ddr3_data, &ddr3_cmd_ctrl_data, &ddr3_emif_reg_data, 0); - else if (board_is_bone_lt()) + else if (board_is_bone_lt(&header)) config_ddr(400, MT41K256M16HA125E_IOCTRL_VALUE, &ddr3_beagleblack_data, &ddr3_beagleblack_cmd_ctrl_data, &ddr3_beagleblack_emif_reg_data, 0); - else if (board_is_evm_15_or_later()) + else if (board_is_evm_15_or_later(&header)) config_ddr(303, MT41J512M8RH125_IOCTRL_VALUE, &ddr3_evm_data, &ddr3_evm_cmd_ctrl_data, &ddr3_evm_emif_reg_data, 0); else @@ -397,10 +366,6 @@ void s_init(void) */ int board_init(void) { - i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); - if (read_eeprom() < 0) - puts("Could not get board ID.\n"); - gd->bd->bi_boot_params = PHYS_DRAM_1 + 0x100;
gpmc_init(); @@ -413,6 +378,10 @@ int board_late_init(void) { #ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG char safe_string[HDR_NAME_LEN + 1]; + struct am335x_baseboard_id header; + + if (read_eeprom(&header) < 0) + puts("Could not get board ID.\n");
/* Now set variables based on the header. */ strncpy(safe_string, (char *)header.name, sizeof(header.name)); @@ -476,6 +445,7 @@ int board_eth_init(bd_t *bis) int rv, n = 0; uint8_t mac_addr[6]; uint32_t mac_hi, mac_lo; + __maybe_unused struct am335x_baseboard_id header;
/* try reading mac address from efuse */ mac_lo = readl(&cdev->macid0l); @@ -496,7 +466,11 @@ int board_eth_init(bd_t *bis) eth_setenv_enetaddr("ethaddr", mac_addr); }
- if (board_is_bone() || board_is_bone_lt() || board_is_idk()) { + if (read_eeprom(&header) < 0) + puts("Could not get board ID.\n"); + + if (board_is_bone(&header) || board_is_bone_lt(&header) || + board_is_idk(&header)) { writel(MII_MODE_ENABLE, &cdev->miisel); cpsw_slaves[0].phy_if = cpsw_slaves[1].phy_if = PHY_INTERFACE_MODE_MII; @@ -524,7 +498,7 @@ int board_eth_init(bd_t *bis) #define AR8051_DEBUG_RGMII_CLK_DLY_REG 0x5 #define AR8051_RGMII_TX_CLK_DLY 0x100
- if (board_is_evm_sk() || board_is_gp_evm()) { + if (board_is_evm_sk(&header) || board_is_gp_evm(&header)) { const char *devname; devname = miiphy_get_current_dev();
diff --git a/board/ti/am335x/board.h b/board/ti/am335x/board.h index 48e112e..36ccaec 100644 --- a/board/ti/am335x/board.h +++ b/board/ti/am335x/board.h @@ -37,6 +37,37 @@ struct am335x_baseboard_id { char mac_addr[HDR_NO_OF_MAC_ADDR][HDR_ETH_ALEN]; };
+static inline int board_is_bone(struct am335x_baseboard_id *header) +{ + return !strncmp(header->name, "A335BONE", HDR_NAME_LEN); +} + +static inline int board_is_bone_lt(struct am335x_baseboard_id *header) +{ + return !strncmp(header->name, "A335BNLT", HDR_NAME_LEN); +} + +static inline int board_is_evm_sk(struct am335x_baseboard_id *header) +{ + return !strncmp("A335X_SK", header->name, HDR_NAME_LEN); +} + +static inline int board_is_idk(struct am335x_baseboard_id *header) +{ + return !strncmp(header->config, "SKU#02", 6); +} + +static inline int board_is_gp_evm(struct am335x_baseboard_id *header) +{ + return !strncmp("A33515BB", header->name, HDR_NAME_LEN); +} + +static inline int board_is_evm_15_or_later(struct am335x_baseboard_id *header) +{ + return (board_is_gp_evm(header) && + strncmp("1.5", header->version, 3) <= 0); +} + /* * We have three pin mux functions that must exist. We must be able to enable * uart0, for initial output and i2c0 to read the main EEPROM. We then have a diff --git a/board/ti/am335x/mux.c b/board/ti/am335x/mux.c index 0283708..2e09d98 100644 --- a/board/ti/am335x/mux.c +++ b/board/ti/am335x/mux.c @@ -262,13 +262,13 @@ static unsigned short detect_daughter_board_profile(void) void enable_board_pin_mux(struct am335x_baseboard_id *header) { /* Do board-specific muxes. */ - if (!strncmp(header->name, "A335BONE", HDR_NAME_LEN)) { + if (board_is_bone(header)) { /* Beaglebone pinmux */ configure_module_pin_mux(i2c1_pin_mux); configure_module_pin_mux(mii1_pin_mux); configure_module_pin_mux(mmc0_pin_mux); configure_module_pin_mux(mmc1_pin_mux); - } else if (!strncmp(header->config, "SKU#01", 6)) { + } else if (board_is_gp_evm(header)) { /* General Purpose EVM */ unsigned short profile = detect_daughter_board_profile(); configure_module_pin_mux(rgmii1_pin_mux); @@ -283,7 +283,7 @@ void enable_board_pin_mux(struct am335x_baseboard_id *header) configure_module_pin_mux(mmc1_pin_mux); configure_module_pin_mux(spi0_pin_mux); } - } else if (!strncmp(header->config, "SKU#02", 6)) { + } else if (board_is_idk(header)) { /* * Industrial Motor Control (IDK) * note: IDK console is on UART3 by default. @@ -292,13 +292,13 @@ void enable_board_pin_mux(struct am335x_baseboard_id *header) */ configure_module_pin_mux(mii1_pin_mux); configure_module_pin_mux(mmc0_no_cd_pin_mux); - } else if (!strncmp(header->name, "A335X_SK", HDR_NAME_LEN)) { + } else if (board_is_evm_sk(header)) { /* Starter Kit EVM */ configure_module_pin_mux(i2c1_pin_mux); configure_module_pin_mux(gpio0_7_pin_mux); configure_module_pin_mux(rgmii1_pin_mux); configure_module_pin_mux(mmc0_pin_mux_sk_evm); - } else if (!strncmp(header->name, "A335BNLT", HDR_NAME_LEN)) { + } else if (board_is_bone_lt(header)) { /* Beaglebone LT pinmux */ configure_module_pin_mux(i2c1_pin_mux); configure_module_pin_mux(mii1_pin_mux);
This patch adds support for the NOR module that attaches to the memory cape for a Beaglebone board. This does not add booting support; only support so that you can boot from SD/MMC and see the NOR module so that it can be programmed.
Signed-off-by: Steve Kipisz s-kipisz2@ti.com [trini: Clean up config changes slightly] Signed-off-by: Tom Rini trini@ti.com --- arch/arm/cpu/armv7/am33xx/mem.c | 30 +++++++++++++++++- arch/arm/include/asm/arch-am33xx/mem.h | 9 ++++++ board/ti/am335x/mux.c | 53 ++++++++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/am335x_evm.h | 28 +++++++++++++++++ 5 files changed, 120 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/am33xx/mem.c b/arch/arm/cpu/armv7/am33xx/mem.c index b86b0de..e46201a 100644 --- a/arch/arm/cpu/armv7/am33xx/mem.c +++ b/arch/arm/cpu/armv7/am33xx/mem.c @@ -46,6 +46,19 @@ static const u32 gpmc_m_nand[GPMC_MAX_REG] = { }; #endif
+#if defined(CONFIG_CMD_FLASH) +static const u32 gpmc_nor[GPMC_MAX_REG] = { + STNOR_GPMC_CONFIG1, + STNOR_GPMC_CONFIG2, + STNOR_GPMC_CONFIG3, + STNOR_GPMC_CONFIG4, + STNOR_GPMC_CONFIG5, + STNOR_GPMC_CONFIG6, + STNOR_GPMC_CONFIG7 +}; + +#define GPMC_CS 0 +#endif
void enable_gpmc_cs_config(const u32 *gpmc_config, struct gpmc_cs *cs, u32 base, u32 size) @@ -75,16 +88,22 @@ void gpmc_init(void) /* putting a blanket check on GPMC based on ZeBu for now */ gpmc_cfg = (struct gpmc *)GPMC_BASE;
-#ifdef CONFIG_CMD_NAND +#if defined(CONFIG_CMD_NAND) || defined(CONFIG_NOR) const u32 *gpmc_config = NULL; u32 base = 0; u32 size = 0; #endif /* global settings */ writel(0x00000008, &gpmc_cfg->sysconfig); +#ifdef CONFIG_NOR + writel(0x00000000, &gpmc_cfg->irqstatus); + writel(0x00000000, &gpmc_cfg->irqenable); + writel(0x00000A00, &gpmc_cfg->config); +#else writel(0x00000100, &gpmc_cfg->irqstatus); writel(0x00000100, &gpmc_cfg->irqenable); writel(0x00000012, &gpmc_cfg->config); +#endif /* * Disable the GPMC0 config set by ROM code */ @@ -98,4 +117,13 @@ void gpmc_init(void) size = PISMO1_NAND_SIZE; enable_gpmc_cs_config(gpmc_config, &gpmc_cfg->cs[0], base, size); #endif + +#ifdef CONFIG_NOR + /* NOR - CS0 */ + gpmc_config = gpmc_nor; + base = CONFIG_SYS_FLASH_BASE; + size = GPMC_SIZE_16M; + enable_gpmc_cs_config(gpmc_config, &gpmc_cfg->cs[0], base, size); + writel(0x00000a00, 0x50000050); +#endif } diff --git a/arch/arm/include/asm/arch-am33xx/mem.h b/arch/arm/include/asm/arch-am33xx/mem.h index c3bf74e..ddcad62 100644 --- a/arch/arm/include/asm/arch-am33xx/mem.h +++ b/arch/arm/include/asm/arch-am33xx/mem.h @@ -61,6 +61,15 @@ #define M_NAND_GPMC_CONFIG6 0x16000f80 #define M_NAND_GPMC_CONFIG7 0x00000008
+/* NOR chip on NOR module for Beaglebone */ +#define STNOR_GPMC_CONFIG1 0x00001200 +#define STNOR_GPMC_CONFIG2 0x00101000 +#define STNOR_GPMC_CONFIG3 0x00030301 +#define STNOR_GPMC_CONFIG4 0x10041004 +#define STNOR_GPMC_CONFIG5 0x000C1010 +#define STNOR_GPMC_CONFIG6 0x08070280 +#define STNOR_GPMC_CONFIG7 0x00000F48 + /* max number of GPMC Chip Selects */ #define GPMC_MAX_CS 8 /* max number of GPMC regs */ diff --git a/board/ti/am335x/mux.c b/board/ti/am335x/mux.c index 2e09d98..187468e 100644 --- a/board/ti/am335x/mux.c +++ b/board/ti/am335x/mux.c @@ -190,6 +190,56 @@ static struct module_pin_mux nand_pin_mux[] = { {-1}, };
+#if defined(CONFIG_NOR) +static struct module_pin_mux bone_norcape_pin_mux[] = { + {OFFSET(lcd_data0), MODE(1) | PULLUDEN | RXACTIVE}, /* NOR_A0 */ + {OFFSET(lcd_data1), MODE(1) | PULLUDEN | RXACTIVE}, /* NOR_A1 */ + {OFFSET(lcd_data2), MODE(1) | PULLUDEN | RXACTIVE}, /* NOR_A2 */ + {OFFSET(lcd_data3), MODE(1) | PULLUDEN | RXACTIVE}, /* NOR_A3 */ + {OFFSET(lcd_data4), MODE(1) | PULLUDEN | RXACTIVE}, /* NOR_A4 */ + {OFFSET(lcd_data5), MODE(1) | PULLUDEN | RXACTIVE}, /* NOR_A5 */ + {OFFSET(lcd_data6), MODE(1) | PULLUDEN | RXACTIVE}, /* NOR_A6 */ + {OFFSET(lcd_data7), MODE(1) | PULLUDEN | RXACTIVE}, /* NOR_A7 */ + {OFFSET(lcd_vsync), MODE(1) | PULLUDEN | RXACTIVE}, /* NOR_A8 */ + {OFFSET(lcd_hsync), MODE(1) | PULLUDEN | RXACTIVE}, /* NOR_A9 */ + {OFFSET(lcd_pclk), MODE(1)| PULLUDEN | RXACTIVE}, /* NOR_A10 */ + {OFFSET(lcd_ac_bias_en), MODE(1)| PULLUDEN | RXACTIVE}, /* NOR_A11 */ + {OFFSET(lcd_data8), MODE(1) | PULLUDEN | RXACTIVE}, /* NOR_A12 */ + {OFFSET(lcd_data9), MODE(1) | PULLUDEN | RXACTIVE}, /* NOR_A13 */ + {OFFSET(lcd_data10), MODE(1) | PULLUDEN | RXACTIVE}, /* NOR_A14 */ + {OFFSET(lcd_data11), MODE(1) | PULLUDEN | RXACTIVE}, /* NOR_A15 */ + {OFFSET(lcd_data12), MODE(1) | PULLUDEN | RXACTIVE}, /* NOR_A16 */ + {OFFSET(lcd_data13), MODE(1) | PULLUDEN | RXACTIVE}, /* NOR_A17 */ + {OFFSET(lcd_data14), MODE(1) | PULLUDEN | RXACTIVE}, /* NOR_A18 */ + {OFFSET(lcd_data15), MODE(1) | PULLUDEN | RXACTIVE}, /* NOR_A19 */ + {OFFSET(gpmc_ad0), MODE(0) | PULLUDEN | RXACTIVE}, /* NOR_AD0 */ + {OFFSET(gpmc_ad1), MODE(0) | PULLUDEN | RXACTIVE}, /* NOR_AD1 */ + {OFFSET(gpmc_ad2), MODE(0) | PULLUDEN | RXACTIVE}, /* NOR_AD2 */ + {OFFSET(gpmc_ad3), MODE(0) | PULLUDEN | RXACTIVE}, /* NOR_AD3 */ + {OFFSET(gpmc_ad4), MODE(0) | PULLUDEN | RXACTIVE}, /* NOR_AD4 */ + {OFFSET(gpmc_ad5), MODE(0) | PULLUDEN | RXACTIVE}, /* NOR_AD5 */ + {OFFSET(gpmc_ad6), MODE(0) | PULLUDEN | RXACTIVE}, /* NOR_AD6 */ + {OFFSET(gpmc_ad7), MODE(0) | PULLUDEN | RXACTIVE}, /* NOR_AD7 */ + {OFFSET(gpmc_ad8), MODE(0) | PULLUDEN | RXACTIVE}, /* NOR_AD8 */ + {OFFSET(gpmc_ad9), MODE(0) | PULLUDEN | RXACTIVE}, /* NOR_AD9 */ + {OFFSET(gpmc_ad10), MODE(0) | PULLUDEN | RXACTIVE}, /* NOR_AD10 */ + {OFFSET(gpmc_ad11), MODE(0) | PULLUDEN | RXACTIVE}, /* NOR_AD11 */ + {OFFSET(gpmc_ad12), MODE(0) | PULLUDEN | RXACTIVE}, /* NOR_AD12 */ + {OFFSET(gpmc_ad13), MODE(0) | PULLUDEN | RXACTIVE}, /* NOR_AD13 */ + {OFFSET(gpmc_ad14), MODE(0) | PULLUDEN | RXACTIVE}, /* NOR_AD14 */ + {OFFSET(gpmc_ad15), MODE(0) | PULLUDEN | RXACTIVE}, /* NOR_AD15 */ + + {OFFSET(gpmc_csn0), (MODE(0) | PULLUDEN) | RXACTIVE}, /* NOR_CE */ + {OFFSET(gpmc_advn_ale), (MODE(0) | PULLUDEN) | RXACTIVE}, /* NOR_ADVN_ALE */ + {OFFSET(gpmc_oen_ren), (MODE(0) | PULLUDEN | RXACTIVE)},/* NOR_OE */ + {OFFSET(gpmc_be0n_cle), (MODE(0) | PULLUDEN | RXACTIVE)},/* NOR_BE0N_CLE */ + {OFFSET(gpmc_wen), (MODE(0) | PULLUDEN | RXACTIVE)}, /* NOR_WEN */ + {OFFSET(gpmc_wait0), (MODE(0) | RXACTIVE | PULLUDEN)}, /* NOR WAIT */ + {-1}, +}; +#endif + + void enable_uart0_pin_mux(void) { configure_module_pin_mux(uart0_pin_mux); @@ -268,6 +318,9 @@ void enable_board_pin_mux(struct am335x_baseboard_id *header) configure_module_pin_mux(mii1_pin_mux); configure_module_pin_mux(mmc0_pin_mux); configure_module_pin_mux(mmc1_pin_mux); +#if defined(CONFIG_NOR) + configure_module_pin_mux(bone_norcape_pin_mux); +#endif } else if (board_is_gp_evm(header)) { /* General Purpose EVM */ unsigned short profile = detect_daughter_board_profile(); diff --git a/boards.cfg b/boards.cfg index 5d78064..d74840d 100644 --- a/boards.cfg +++ b/boards.cfg @@ -236,6 +236,7 @@ integratorap_cm946es arm arm946es integrator armltd integratorcp_cm946es arm arm946es integrator armltd - integratorcp:CM946ES ca9x4_ct_vxp arm armv7 vexpress armltd am335x_evm arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1 +am335x_evm_nor arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,NOR am335x_evm_spiboot arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,SPI_BOOT am335x_evm_uart1 arm armv7 am335x ti am33xx am335x_evm:SERIAL2,CONS_INDEX=2 am335x_evm_uart2 arm armv7 am335x ti am33xx am335x_evm:SERIAL3,CONS_INDEX=3 diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 90cc1f5..343a4aa 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -496,4 +496,32 @@ #define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ #endif
+/* + * NOR Size = 16 MiB + * Number of Sectors/Blocks = 128 + * Sector Size = 128 KiB + * Word length = 16 bits + * Default layout: + * 0x000000 - 0x07FFFF : U-Boot (512 KiB) + * 0x080000 - 0x09FFFF : First copy of U-Boot Environment (128 KiB) + * 0x0A0000 - 0x0BFFFF : Second copy of U-Boot Environment (128 KiB) + * 0x0C0000 - 0x4BFFFF : Linux Kernel (4 MiB) + * 0x4C0000 - 0xFFFFFF : Userland (11 MiB + 256 KiB) + */ +#if defined(CONFIG_NOR) +#undef CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE +#define CONFIG_SYS_FLASH_PROTECTION +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_FLASH_CFI_MTD +#define CONFIG_SYS_MAX_FLASH_SECT 128 +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_FLASH_BASE (0x08000000) +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE +#define CONFIG_MTD_DEVICE +#define CONFIG_CMD_FLASH +#endif /* NOR support */ + #endif /* ! __CONFIG_AM335X_EVM_H */
Space missing after ':' in subject.
Tom> From: Steve Kipisz s-kipisz2@ti.com Tom> This patch adds support for the NOR module that attaches Tom> to the memory cape for a Beaglebone board. This does not Tom> add booting support; only support so that you can boot from Tom> SD/MMC and see the NOR module so that it can be programmed.
Tom> Signed-off-by: Steve Kipisz s-kipisz2@ti.com Tom> [trini: Clean up config changes slightly] Tom> Signed-off-by: Tom Rini trini@ti.com Tom> --- Tom> arch/arm/cpu/armv7/am33xx/mem.c | 30 +++++++++++++++++- Tom> arch/arm/include/asm/arch-am33xx/mem.h | 9 ++++++ Tom> board/ti/am335x/mux.c | 53 ++++++++++++++++++++++++++++++++ Tom> boards.cfg | 1 + Tom> include/configs/am335x_evm.h | 28 +++++++++++++++++ Tom> 5 files changed, 120 insertions(+), 1 deletion(-)
Tom> diff --git a/arch/arm/cpu/armv7/am33xx/mem.c b/arch/arm/cpu/armv7/am33xx/mem.c Tom> index b86b0de..e46201a 100644 Tom> --- a/arch/arm/cpu/armv7/am33xx/mem.c Tom> +++ b/arch/arm/cpu/armv7/am33xx/mem.c Tom> @@ -46,6 +46,19 @@ static const u32 gpmc_m_nand[GPMC_MAX_REG] = { Tom> }; Tom> #endif
Tom> +#if defined(CONFIG_CMD_FLASH) Tom> +static const u32 gpmc_nor[GPMC_MAX_REG] = { Tom> + STNOR_GPMC_CONFIG1, Tom> + STNOR_GPMC_CONFIG2, Tom> + STNOR_GPMC_CONFIG3, Tom> + STNOR_GPMC_CONFIG4, Tom> + STNOR_GPMC_CONFIG5, Tom> + STNOR_GPMC_CONFIG6, Tom> + STNOR_GPMC_CONFIG7 Tom> +};
These values (and the gmpc_m_nand ones) are platform specific, right? It would be nicer to have them in the board file than here, similar to how I did for the ddr settings some time ago.
Tom> + Tom> +#define GPMC_CS 0 Tom> +#endif
Tom> void enable_gpmc_cs_config(const u32 *gpmc_config, struct gpmc_cs *cs, u32 base, Tom> u32 size) Tom> @@ -75,16 +88,22 @@ void gpmc_init(void) Tom> /* putting a blanket check on GPMC based on ZeBu for now */ Tom> gpmc_cfg = (struct gpmc *)GPMC_BASE;
Tom> -#ifdef CONFIG_CMD_NAND Tom> +#if defined(CONFIG_CMD_NAND) || defined(CONFIG_NOR) Tom> const u32 *gpmc_config = NULL; Tom> u32 base = 0; Tom> u32 size = 0; Tom> #endif Tom> /* global settings */ Tom> writel(0x00000008, &gpmc_cfg->sysconfig); Tom> +#ifdef CONFIG_NOR Tom> + writel(0x00000000, &gpmc_cfg->irqstatus); Tom> + writel(0x00000000, &gpmc_cfg->irqenable); Tom> + writel(0x00000A00, &gpmc_cfg->config); Tom> +#else Tom> writel(0x00000100, &gpmc_cfg->irqstatus); Tom> writel(0x00000100, &gpmc_cfg->irqenable); Tom> writel(0x00000012, &gpmc_cfg->config); Tom> +#endif
So now you cannot E.G. have a single binary working on both the nand flash of the evm and beaglebone? That's not really nice.
Whoops.
The GPMC setup stuff has historically been, lets say less than optimal. We might be able to move this to board_init like omap3 does, however. I'll check.
It's worse than that. We don't have a NOR cape, we have a memory cape and NOR module. We could have a memory cape and NAND module. And there's not a nice way at run-time to determine if we've got one or the other.
- -- Tom
NOR requires that s_init be within the first 4KiB of the image so that we can perform the rest of the required pinmuxing to talk with the rest of NOR that we are found on. When NOR_BOOT is set we save our environment in NOR at 512KiB and a redundant copy at 768KiB.
Signed-off-by: Steve Kipisz s-kipisz2@ti.com Signed-off-by: Tom Rini trini@ti.com --- arch/arm/cpu/armv7/am33xx/emif4.c | 6 +- board/ti/am335x/Makefile | 2 +- board/ti/am335x/board.c | 31 ++++++++++- board/ti/am335x/mux.c | 6 +- board/ti/am335x/u-boot.lds | 110 +++++++++++++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/am335x_evm.h | 27 ++++++++- 7 files changed, 174 insertions(+), 9 deletions(-) create mode 100644 board/ti/am335x/u-boot.lds
diff --git a/arch/arm/cpu/armv7/am33xx/emif4.c b/arch/arm/cpu/armv7/am33xx/emif4.c index aa84e96..370230b 100644 --- a/arch/arm/cpu/armv7/am33xx/emif4.c +++ b/arch/arm/cpu/armv7/am33xx/emif4.c @@ -43,9 +43,11 @@ void dram_init_banksize(void) }
-#ifdef CONFIG_SPL_BUILD +#if defined(CONFIG_SPL_BUILD) || defined(CONFIG_NOR_BOOT) +#ifdef CONFIG_TI81XX static struct dmm_lisa_map_regs *hw_lisa_map_regs = (struct dmm_lisa_map_regs *)DMM_BASE; +#endif static struct vtp_reg *vtpreg[2] = { (struct vtp_reg *)VTP0_CTRL_ADDR, (struct vtp_reg *)VTP1_CTRL_ADDR}; @@ -53,6 +55,7 @@ static struct vtp_reg *vtpreg[2] = { static struct ddr_ctrl *ddrctrl = (struct ddr_ctrl *)DDR_CTRL_ADDR; #endif
+#ifdef CONFIG_TI81XX void config_dmm(const struct dmm_lisa_map_regs *regs) { enable_dmm_clocks(); @@ -67,6 +70,7 @@ void config_dmm(const struct dmm_lisa_map_regs *regs) writel(regs->dmm_lisa_map_1, &hw_lisa_map_regs->dmm_lisa_map_1); writel(regs->dmm_lisa_map_0, &hw_lisa_map_regs->dmm_lisa_map_0); } +#endif
static void config_vtp(int nr) { diff --git a/board/ti/am335x/Makefile b/board/ti/am335x/Makefile index 67a87a1..1795e3e 100644 --- a/board/ti/am335x/Makefile +++ b/board/ti/am335x/Makefile @@ -18,7 +18,7 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).o
-ifdef CONFIG_SPL_BUILD +ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_NOR_BOOT),y) COBJS := mux.o endif
diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index 6f6b5d0..a0ad4bc 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -38,7 +38,7 @@ DECLARE_GLOBAL_DATA_PTR;
static struct wd_timer *wdtimer = (struct wd_timer *)WDT_BASE; -#ifdef CONFIG_SPL_BUILD +#if defined(CONFIG_SPL_BUILD) || (CONFIG_NOR_BOOT) static struct uart_sys *uart_base = (struct uart_sys *)DEFAULT_UART_BASE; #endif
@@ -94,7 +94,7 @@ static int read_eeprom(struct am335x_baseboard_id *header) }
/* UART Defines */ -#ifdef CONFIG_SPL_BUILD +#if defined(CONFIG_SPL_BUILD) || defined(CONFIG_NOR_BOOT) #define UART_RESET (0x1 << 1) #define UART_CLK_RUNNING_MASK 0x1 #define UART_SMART_IDLE_EN (0x1 << 0x3) @@ -273,6 +273,24 @@ void s_init(void) { __maybe_unused struct am335x_baseboard_id header;
+ /* + * The ROM will only have set up sufficient pinmux to allow for the + * first 4KiB NOR to be read, we must finish doing what we know of + * the NOR mux in this space in order to continue. + */ +#ifdef CONFIG_NOR_BOOT + asm("stmfd sp!, {r2 - r4}"); + asm("movw r4, #0x8A4"); + asm("movw r3, #0x44E1"); + asm("orr r4, r4, r3, lsl #16"); + asm("mov r2, #9"); + asm("mov r3, #8"); + asm("gpmc_mux: str r2, [r4], #4"); + asm("subs r3, r3, #1"); + asm("bne gpmc_mux"); + asm("ldmfd sp!, {r2 - r4}"); +#endif + /* WDT1 is already running when the bootloader gets control * Disable it to avoid "random" resets */ @@ -283,7 +301,7 @@ void s_init(void) while (readl(&wdtimer->wdtwwps) != 0x0) ;
-#ifdef CONFIG_SPL_BUILD +#if defined(CONFIG_SPL_BUILD) || defined(CONFIG_NOR_BOOT) /* Setup the PLLs and the clocks for the peripherals */ pll_init();
@@ -324,9 +342,16 @@ void s_init(void) regVal |= UART_SMART_IDLE_EN; writel(regVal, &uart_base->uartsyscfg);
+#if defined(CONFIG_NOR_BOOT) + /* We want our console now. */ + gd->baudrate = CONFIG_BAUDRATE; + serial_init(); + gd->have_console = 1; +#else gd = &gdata;
preloader_console_init(); +#endif
/* Initalize the board header */ enable_i2c0_pin_mux(); diff --git a/board/ti/am335x/mux.c b/board/ti/am335x/mux.c index 187468e..5b7ed63 100644 --- a/board/ti/am335x/mux.c +++ b/board/ti/am335x/mux.c @@ -190,7 +190,7 @@ static struct module_pin_mux nand_pin_mux[] = { {-1}, };
-#if defined(CONFIG_NOR) +#if defined(CONFIG_NOR) && !defined(CONFIG_NOR_BOOT) static struct module_pin_mux bone_norcape_pin_mux[] = { {OFFSET(lcd_data0), MODE(1) | PULLUDEN | RXACTIVE}, /* NOR_A0 */ {OFFSET(lcd_data1), MODE(1) | PULLUDEN | RXACTIVE}, /* NOR_A1 */ @@ -317,8 +317,10 @@ void enable_board_pin_mux(struct am335x_baseboard_id *header) configure_module_pin_mux(i2c1_pin_mux); configure_module_pin_mux(mii1_pin_mux); configure_module_pin_mux(mmc0_pin_mux); +#ifndef CONFIG_NOR configure_module_pin_mux(mmc1_pin_mux); -#if defined(CONFIG_NOR) +#endif +#if defined(CONFIG_NOR) && !defined(CONFIG_NOR_BOOT) configure_module_pin_mux(bone_norcape_pin_mux); #endif } else if (board_is_gp_evm(header)) { diff --git a/board/ti/am335x/u-boot.lds b/board/ti/am335x/u-boot.lds new file mode 100644 index 0000000..d376743 --- /dev/null +++ b/board/ti/am335x/u-boot.lds @@ -0,0 +1,110 @@ +/* + * Copyright (c) 2004-2008 Texas Instruments + * + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, garyj@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + __image_copy_start = .; + CPUDIR/start.o (.text*) + board/ti/am335x/libam335x.o (.text*) + *(.text*) + } + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + + . = ALIGN(4); + .data : { + *(.data*) + } + + . = ALIGN(4); + + . = .; + + . = ALIGN(4); + .u_boot_list : { + KEEP(*(SORT(.u_boot_list*))); + } + + . = ALIGN(4); + + __image_copy_end = .; + + .rel.dyn : { + __rel_dyn_start = .; + *(.rel*) + __rel_dyn_end = .; + } + + .dynsym : { + __dynsym_start = .; + *(.dynsym) + } + + _end = .; + + /* + * Deprecated: this MMU section is used by pxa at present but + * should not be used by new boards/CPUs. + */ + . = ALIGN(4096); + .mmutable : { + *(.mmutable) + } + +/* + * Compiler-generated __bss_start and __bss_end, see arch/arm/lib/bss.c + * __bss_base and __bss_limit are for linker only (overlay ordering) + */ + + .bss_start __rel_dyn_start (OVERLAY) : { + KEEP(*(.__bss_start)); + __bss_base = .; + } + + .bss __bss_base (OVERLAY) : { + *(.bss*) + . = ALIGN(4); + __bss_limit = .; + } + + .bss_end __bss_limit (OVERLAY) : { + KEEP(*(.__bss_end)); + } + + /DISCARD/ : { *(.dynstr*) } + /DISCARD/ : { *(.dynamic*) } + /DISCARD/ : { *(.plt*) } + /DISCARD/ : { *(.interp*) } + /DISCARD/ : { *(.gnu*) } +} diff --git a/boards.cfg b/boards.cfg index d74840d..90e018f 100644 --- a/boards.cfg +++ b/boards.cfg @@ -237,6 +237,7 @@ integratorcp_cm946es arm arm946es integrator armltd ca9x4_ct_vxp arm armv7 vexpress armltd am335x_evm arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1 am335x_evm_nor arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,NOR +am335x_evm_norboot arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,NOR,NOR_BOOT am335x_evm_spiboot arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,SPI_BOOT am335x_evm_uart1 arm armv7 am335x ti am33xx am335x_evm:SERIAL2,CONS_INDEX=2 am335x_evm_uart2 arm armv7 am335x ti am33xx am335x_evm:SERIAL3,CONS_INDEX=3 diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 343a4aa..abc477b 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -39,6 +39,9 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG
+/* Custom script for NOR */ +#define CONFIG_SYS_LDSCRIPT "board/ti/am335x/u-boot.lds" + #define CONFIG_SYS_CACHELINE_SIZE 64
/* commands to include */ @@ -300,6 +303,7 @@ #define CONFIG_ENV_OVERWRITE 1 #define CONFIG_SYS_CONSOLE_INFO_QUIET
+#ifndef CONFIG_NOR_BOOT /* Defines for SPL */ #define CONFIG_SPL #define CONFIG_SPL_FRAMEWORK @@ -343,6 +347,8 @@ #define CONFIG_SPL_NAND_BASE #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_ECC +#endif + #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ CONFIG_SYS_NAND_PAGE_SIZE) @@ -376,14 +382,18 @@ * header. That is 0x800FFFC0--0x80100000 should not be used for any * other needs. */ +#ifdef CONFIG_NOR_BOOT +#define CONFIG_SYS_TEXT_BASE 0x08000000 +#else #define CONFIG_SYS_TEXT_BASE 0x80800000 +#endif #define CONFIG_SYS_SPL_MALLOC_START 0x80208000 #define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000
/* Since SPL did pll and ddr initialization for us, * we don't need to do it twice. */ -#ifndef CONFIG_SPL_BUILD +#if !defined(CONFIG_SPL_BUILD) && !defined(CONFIG_NOR_BOOT) #define CONFIG_SKIP_LOWLEVEL_INIT #endif
@@ -470,7 +480,7 @@ #define CONFIG_PHY_ADDR 0 #define CONFIG_PHY_SMSC
-#if !defined(CONFIG_SPI_BOOT) +#if !defined(CONFIG_SPI_BOOT) && !defined(CONFIG_NOR_BOOT) #define CONFIG_NAND #endif
@@ -520,6 +530,19 @@ #define CONFIG_SYS_FLASH_BASE (0x08000000) #define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE +#ifdef CONFIG_NOR_BOOT +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ +#define CONFIG_ENV_OFFSET (512 << 10) /* 512 KiB */ +#define CONFIG_ENV_OFFSET_REDUND (768 << 10) /* 768 KiB */ +#define CONFIG_CMD_MTDPARTS +#define MTDIDS_DEFAULT "nor0=physmap-flash.0" +#define MTDPARTS_DEFAULT "mtdparts=physmap-flash.0:" \ + "512k(u-boot)," \ + "128k(u-boot-env1)," \ + "128k(u-boot-env2)," \ + "4m(kernel),-(rootfs)" +#endif #define CONFIG_MTD_DEVICE #define CONFIG_CMD_FLASH #endif /* NOR support */
Tom> From: Steve Kipisz s-kipisz2@ti.com Tom> NOR requires that s_init be within the first 4KiB of the image so that Tom> we can perform the rest of the required pinmuxing to talk with the rest Tom> of NOR that we are found on. When NOR_BOOT is set we save our Tom> environment in NOR at 512KiB and a redundant copy at 768KiB.
Why not use SPL when booting from NOR as well? You still want to relocate into DDR.
Tom> Signed-off-by: Steve Kipisz s-kipisz2@ti.com Tom> Signed-off-by: Tom Rini trini@ti.com Tom> --- Tom> arch/arm/cpu/armv7/am33xx/emif4.c | 6 +- Tom> board/ti/am335x/Makefile | 2 +- Tom> board/ti/am335x/board.c | 31 ++++++++++- Tom> board/ti/am335x/mux.c | 6 +- Tom> board/ti/am335x/u-boot.lds | 110 +++++++++++++++++++++++++++++++++++++ Tom> boards.cfg | 1 + Tom> include/configs/am335x_evm.h | 27 ++++++++- Tom> 7 files changed, 174 insertions(+), 9 deletions(-) Tom> create mode 100644 board/ti/am335x/u-boot.lds
Tom> diff --git a/arch/arm/cpu/armv7/am33xx/emif4.c b/arch/arm/cpu/armv7/am33xx/emif4.c Tom> index aa84e96..370230b 100644 Tom> --- a/arch/arm/cpu/armv7/am33xx/emif4.c Tom> +++ b/arch/arm/cpu/armv7/am33xx/emif4.c Tom> @@ -43,9 +43,11 @@ void dram_init_banksize(void) Tom> }
Tom> -#ifdef CONFIG_SPL_BUILD Tom> +#if defined(CONFIG_SPL_BUILD) || defined(CONFIG_NOR_BOOT) Tom> +#ifdef CONFIG_TI81XX Tom> static struct dmm_lisa_map_regs *hw_lisa_map_regs = Tom> (struct dmm_lisa_map_regs *)DMM_BASE; Tom> +#endif Tom> static struct vtp_reg *vtpreg[2] = { Tom> (struct vtp_reg *)VTP0_CTRL_ADDR, Tom> (struct vtp_reg *)VTP1_CTRL_ADDR}; Tom> @@ -53,6 +55,7 @@ static struct vtp_reg *vtpreg[2] = { Tom> static struct ddr_ctrl *ddrctrl = (struct ddr_ctrl *)DDR_CTRL_ADDR; Tom> #endif
Tom> +#ifdef CONFIG_TI81XX Tom> void config_dmm(const struct dmm_lisa_map_regs *regs) Tom> { Tom> enable_dmm_clocks(); Tom> @@ -67,6 +70,7 @@ void config_dmm(const struct dmm_lisa_map_regs *regs) Tom> writel(regs->dmm_lisa_map_1, &hw_lisa_map_regs->dmm_lisa_map_1); Tom> writel(regs->dmm_lisa_map_0, &hw_lisa_map_regs->dmm_lisa_map_0); Tom> } Tom> +#endif
Tom> static void config_vtp(int nr) Tom> { Tom> diff --git a/board/ti/am335x/Makefile b/board/ti/am335x/Makefile Tom> index 67a87a1..1795e3e 100644 Tom> --- a/board/ti/am335x/Makefile Tom> +++ b/board/ti/am335x/Makefile Tom> @@ -18,7 +18,7 @@ include $(TOPDIR)/config.mk
Tom> LIB = $(obj)lib$(BOARD).o
Tom> -ifdef CONFIG_SPL_BUILD Tom> +ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_NOR_BOOT),y) Tom> COBJS := mux.o Tom> endif
Tom> diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c Tom> index 6f6b5d0..a0ad4bc 100644 Tom> --- a/board/ti/am335x/board.c Tom> +++ b/board/ti/am335x/board.c Tom> @@ -38,7 +38,7 @@ Tom> DECLARE_GLOBAL_DATA_PTR;
Tom> static struct wd_timer *wdtimer = (struct wd_timer *)WDT_BASE; Tom> -#ifdef CONFIG_SPL_BUILD Tom> +#if defined(CONFIG_SPL_BUILD) || (CONFIG_NOR_BOOT) Tom> static struct uart_sys *uart_base = (struct uart_sys *)DEFAULT_UART_BASE; Tom> #endif
Tom> @@ -94,7 +94,7 @@ static int read_eeprom(struct am335x_baseboard_id *header) Tom> }
Tom> /* UART Defines */ Tom> -#ifdef CONFIG_SPL_BUILD Tom> +#if defined(CONFIG_SPL_BUILD) || defined(CONFIG_NOR_BOOT) Tom> #define UART_RESET (0x1 << 1) Tom> #define UART_CLK_RUNNING_MASK 0x1 Tom> #define UART_SMART_IDLE_EN (0x1 << 0x3) Tom> @@ -273,6 +273,24 @@ void s_init(void) Tom> { Tom> __maybe_unused struct am335x_baseboard_id header;
Tom> + /* Tom> + * The ROM will only have set up sufficient pinmux to allow for the Tom> + * first 4KiB NOR to be read, we must finish doing what we know of Tom> + * the NOR mux in this space in order to continue. Tom> + */ Tom> +#ifdef CONFIG_NOR_BOOT Tom> + asm("stmfd sp!, {r2 - r4}"); Tom> + asm("movw r4, #0x8A4"); Tom> + asm("movw r3, #0x44E1"); Tom> + asm("orr r4, r4, r3, lsl #16"); Tom> + asm("mov r2, #9"); Tom> + asm("mov r3, #8"); Tom> + asm("gpmc_mux: str r2, [r4], #4"); Tom> + asm("subs r3, r3, #1"); Tom> + asm("bne gpmc_mux"); Tom> + asm("ldmfd sp!, {r2 - r4}"); Tom> +#endif Tom> + Tom> /* WDT1 is already running when the bootloader gets control Tom> * Disable it to avoid "random" resets Tom> */ Tom> @@ -283,7 +301,7 @@ void s_init(void) Tom> while (readl(&wdtimer->wdtwwps) != 0x0) Tom> ;
Tom> -#ifdef CONFIG_SPL_BUILD Tom> +#if defined(CONFIG_SPL_BUILD) || defined(CONFIG_NOR_BOOT) Tom> /* Setup the PLLs and the clocks for the peripherals */ Tom> pll_init();
Tom> @@ -324,9 +342,16 @@ void s_init(void) Tom> regVal |= UART_SMART_IDLE_EN; Tom> writel(regVal, &uart_base->uartsyscfg);
Tom> +#if defined(CONFIG_NOR_BOOT) Tom> + /* We want our console now. */ Tom> + gd->baudrate = CONFIG_BAUDRATE; Tom> + serial_init(); Tom> + gd->have_console = 1; Tom> +#else Tom> gd = &gdata;
Tom> preloader_console_init(); Tom> +#endif
Tom> /* Initalize the board header */ Tom> enable_i2c0_pin_mux(); Tom> diff --git a/board/ti/am335x/mux.c b/board/ti/am335x/mux.c Tom> index 187468e..5b7ed63 100644 Tom> --- a/board/ti/am335x/mux.c Tom> +++ b/board/ti/am335x/mux.c Tom> @@ -190,7 +190,7 @@ static struct module_pin_mux nand_pin_mux[] = { Tom> {-1}, Tom> };
Tom> -#if defined(CONFIG_NOR) Tom> +#if defined(CONFIG_NOR) && !defined(CONFIG_NOR_BOOT) Tom> static struct module_pin_mux bone_norcape_pin_mux[] = { Tom> {OFFSET(lcd_data0), MODE(1) | PULLUDEN | RXACTIVE}, /* NOR_A0 */ Tom> {OFFSET(lcd_data1), MODE(1) | PULLUDEN | RXACTIVE}, /* NOR_A1 */ Tom> @@ -317,8 +317,10 @@ void enable_board_pin_mux(struct am335x_baseboard_id *header) Tom> configure_module_pin_mux(i2c1_pin_mux); Tom> configure_module_pin_mux(mii1_pin_mux); Tom> configure_module_pin_mux(mmc0_pin_mux); Tom> +#ifndef CONFIG_NOR Tom> configure_module_pin_mux(mmc1_pin_mux); Tom> -#if defined(CONFIG_NOR) Tom> +#endif Tom> +#if defined(CONFIG_NOR) && !defined(CONFIG_NOR_BOOT) Tom> configure_module_pin_mux(bone_norcape_pin_mux); Tom> #endif Tom> } else if (board_is_gp_evm(header)) { Tom> diff --git a/board/ti/am335x/u-boot.lds b/board/ti/am335x/u-boot.lds Tom> new file mode 100644 Tom> index 0000000..d376743 Tom> --- /dev/null Tom> +++ b/board/ti/am335x/u-boot.lds Tom> @@ -0,0 +1,110 @@ Tom> +/* Tom> + * Copyright (c) 2004-2008 Texas Instruments Tom> + * Tom> + * (C) Copyright 2002 Tom> + * Gary Jennejohn, DENX Software Engineering, garyj@denx.de Tom> + * Tom> + * See file CREDITS for list of people who contributed to this Tom> + * project. Tom> + * Tom> + * This program is free software; you can redistribute it and/or Tom> + * modify it under the terms of the GNU General Public License as Tom> + * published by the Free Software Foundation; either version 2 of Tom> + * the License, or (at your option) any later version. Tom> + * Tom> + * This program is distributed in the hope that it will be useful, Tom> + * but WITHOUT ANY WARRANTY; without even the implied warranty of Tom> + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the Tom> + * GNU General Public License for more details. Tom> + * Tom> + * You should have received a copy of the GNU General Public License Tom> + * along with this program; if not, write to the Free Software Tom> + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, Tom> + * MA 02111-1307 USA Tom> + */ Tom> + Tom> +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") Tom> +OUTPUT_ARCH(arm) Tom> +ENTRY(_start) Tom> +SECTIONS Tom> +{ Tom> + . = 0x00000000; Tom> + Tom> + . = ALIGN(4); Tom> + .text : Tom> + { Tom> + __image_copy_start = .; Tom> + CPUDIR/start.o (.text*) Tom> + board/ti/am335x/libam335x.o (.text*) Tom> + *(.text*) Tom> + } Tom> + Tom> + . = ALIGN(4); Tom> + .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } Tom> + Tom> + . = ALIGN(4); Tom> + .data : { Tom> + *(.data*) Tom> + } Tom> + Tom> + . = ALIGN(4); Tom> + Tom> + . = .; Tom> + Tom> + . = ALIGN(4); Tom> + .u_boot_list : { Tom> + KEEP(*(SORT(.u_boot_list*))); Tom> + } Tom> + Tom> + . = ALIGN(4); Tom> + Tom> + __image_copy_end = .; Tom> + Tom> + .rel.dyn : { Tom> + __rel_dyn_start = .; Tom> + *(.rel*) Tom> + __rel_dyn_end = .; Tom> + } Tom> + Tom> + .dynsym : { Tom> + __dynsym_start = .; Tom> + *(.dynsym) Tom> + } Tom> + Tom> + _end = .; Tom> + Tom> + /* Tom> + * Deprecated: this MMU section is used by pxa at present but Tom> + * should not be used by new boards/CPUs. Tom> + */ Tom> + . = ALIGN(4096); Tom> + .mmutable : { Tom> + *(.mmutable) Tom> + } Tom> + Tom> +/* Tom> + * Compiler-generated __bss_start and __bss_end, see arch/arm/lib/bss.c Tom> + * __bss_base and __bss_limit are for linker only (overlay ordering) Tom> + */ Tom> + Tom> + .bss_start __rel_dyn_start (OVERLAY) : { Tom> + KEEP(*(.__bss_start)); Tom> + __bss_base = .; Tom> + } Tom> + Tom> + .bss __bss_base (OVERLAY) : { Tom> + *(.bss*) Tom> + . = ALIGN(4); Tom> + __bss_limit = .; Tom> + } Tom> + Tom> + .bss_end __bss_limit (OVERLAY) : { Tom> + KEEP(*(.__bss_end)); Tom> + } Tom> + Tom> + /DISCARD/ : { *(.dynstr*) } Tom> + /DISCARD/ : { *(.dynamic*) } Tom> + /DISCARD/ : { *(.plt*) } Tom> + /DISCARD/ : { *(.interp*) } Tom> + /DISCARD/ : { *(.gnu*) } Tom> +} Tom> diff --git a/boards.cfg b/boards.cfg Tom> index d74840d..90e018f 100644 Tom> --- a/boards.cfg Tom> +++ b/boards.cfg Tom> @@ -237,6 +237,7 @@ integratorcp_cm946es arm arm946es integrator armltd Tom> ca9x4_ct_vxp arm armv7 vexpress armltd Tom> am335x_evm arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1 Tom> am335x_evm_nor arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,NOR Tom> +am335x_evm_norboot arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,NOR,NOR_BOOT Tom> am335x_evm_spiboot arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,SPI_BOOT Tom> am335x_evm_uart1 arm armv7 am335x ti am33xx am335x_evm:SERIAL2,CONS_INDEX=2 Tom> am335x_evm_uart2 arm armv7 am335x ti am33xx am335x_evm:SERIAL3,CONS_INDEX=3 Tom> diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h Tom> index 343a4aa..abc477b 100644 Tom> --- a/include/configs/am335x_evm.h Tom> +++ b/include/configs/am335x_evm.h Tom> @@ -39,6 +39,9 @@ Tom> #define CONFIG_SETUP_MEMORY_TAGS Tom> #define CONFIG_INITRD_TAG
Tom> +/* Custom script for NOR */ Tom> +#define CONFIG_SYS_LDSCRIPT "board/ti/am335x/u-boot.lds" Tom> + Tom> #define CONFIG_SYS_CACHELINE_SIZE 64
Tom> /* commands to include */ Tom> @@ -300,6 +303,7 @@ Tom> #define CONFIG_ENV_OVERWRITE 1 Tom> #define CONFIG_SYS_CONSOLE_INFO_QUIET
Tom> +#ifndef CONFIG_NOR_BOOT Tom> /* Defines for SPL */ Tom> #define CONFIG_SPL Tom> #define CONFIG_SPL_FRAMEWORK Tom> @@ -343,6 +347,8 @@ Tom> #define CONFIG_SPL_NAND_BASE Tom> #define CONFIG_SPL_NAND_DRIVERS Tom> #define CONFIG_SPL_NAND_ECC Tom> +#endif Tom> + Tom> #define CONFIG_SYS_NAND_5_ADDR_CYCLE Tom> #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ Tom> CONFIG_SYS_NAND_PAGE_SIZE) Tom> @@ -376,14 +382,18 @@ Tom> * header. That is 0x800FFFC0--0x80100000 should not be used for any Tom> * other needs. Tom> */ Tom> +#ifdef CONFIG_NOR_BOOT Tom> +#define CONFIG_SYS_TEXT_BASE 0x08000000 Tom> +#else Tom> #define CONFIG_SYS_TEXT_BASE 0x80800000 Tom> +#endif Tom> #define CONFIG_SYS_SPL_MALLOC_START 0x80208000 Tom> #define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000
Tom> /* Since SPL did pll and ddr initialization for us, Tom> * we don't need to do it twice. Tom> */ Tom> -#ifndef CONFIG_SPL_BUILD Tom> +#if !defined(CONFIG_SPL_BUILD) && !defined(CONFIG_NOR_BOOT) Tom> #define CONFIG_SKIP_LOWLEVEL_INIT Tom> #endif
Tom> @@ -470,7 +480,7 @@ Tom> #define CONFIG_PHY_ADDR 0 Tom> #define CONFIG_PHY_SMSC
Tom> -#if !defined(CONFIG_SPI_BOOT) Tom> +#if !defined(CONFIG_SPI_BOOT) && !defined(CONFIG_NOR_BOOT) Tom> #define CONFIG_NAND Tom> #endif
Tom> @@ -520,6 +530,19 @@ Tom> #define CONFIG_SYS_FLASH_BASE (0x08000000) Tom> #define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT Tom> #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE Tom> +#ifdef CONFIG_NOR_BOOT Tom> +#define CONFIG_ENV_IS_IN_FLASH Tom> +#define CONFIG_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ Tom> +#define CONFIG_ENV_OFFSET (512 << 10) /* 512 KiB */ Tom> +#define CONFIG_ENV_OFFSET_REDUND (768 << 10) /* 768 KiB */ Tom> +#define CONFIG_CMD_MTDPARTS Tom> +#define MTDIDS_DEFAULT "nor0=physmap-flash.0" Tom> +#define MTDPARTS_DEFAULT "mtdparts=physmap-flash.0:" \ Tom> + "512k(u-boot)," \ Tom> + "128k(u-boot-env1)," \ Tom> + "128k(u-boot-env2)," \ Tom> + "4m(kernel),-(rootfs)" Tom> +#endif Tom> #define CONFIG_MTD_DEVICE Tom> #define CONFIG_CMD_FLASH Tom> #endif /* NOR support */ Tom> -- Tom> 1.7.9.5
Frankly, I'm allergic to SPL for NOR. It's the historical and well understood case, we're r/o until we move from flash to DDR. And it is fast enough here at least that it doesn't seem like we'd gain on falcon mode like we do on other medium.
- -- Tom
Tom> Frankly, I'm allergic to SPL for NOR. It's the historical and well Tom> understood case, we're r/o until we move from flash to DDR. And it is Tom> fast enough here at least that it doesn't seem like we'd gain on Tom> falcon mode like we do on other medium.
Ok. It would be good to mention this in the commit message.
I'll reword things slightly.
- -- Tom
Tom> We always set a CONFIG_ENV_IS_...somewhere... so drop the initial define Tom> of NOWHERE.
Reviewed-by: Peter Korsgaard jacmet@sunsite.dk
Peter Korsgaard
