[PATCH 1/4] stm32mp: stm32prog: Add Kconfig file for stm32prog command
Move CONFIG_CMD_STM32PROG in a specific Kconfig file for stm32prog command.
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
arch/arm/mach-stm32mp/Kconfig | 18 +----------------- arch/arm/mach-stm32mp/cmd_stm32prog/Kconfig | 18 ++++++++++++++++++ 2 files changed, 19 insertions(+), 17 deletions(-) create mode 100644 arch/arm/mach-stm32mp/cmd_stm32prog/Kconfig
diff --git a/arch/arm/mach-stm32mp/Kconfig b/arch/arm/mach-stm32mp/Kconfig index f538d7cb83..079d66a80c 100644 --- a/arch/arm/mach-stm32mp/Kconfig +++ b/arch/arm/mach-stm32mp/Kconfig @@ -121,23 +121,6 @@ config STM32_ETZPC help Say y to enable STM32 Extended TrustZone Protection
-config CMD_STM32PROG - bool "command stm32prog for STM32CudeProgrammer" - select DFU - select DFU_RAM - select DFU_VIRT - select PARTITION_TYPE_GUID - imply CMD_GPT if MMC - imply CMD_MTD if MTD - imply DFU_MMC if MMC - imply DFU_MTD if MTD - help - activate a specific command stm32prog for STM32MP soc family - witch update the device with the tools STM32CubeProgrammer, - using UART with STM32 protocol or USB with DFU protocol - NB: access to not volatile memory (NOR/NAND/SD/eMMC) is based - on U-Boot DFU framework - config CMD_STM32KEY bool "command stm32key to fuse public key hash" default y @@ -177,6 +160,7 @@ config DEBUG_UART_CLOCK default 64000000 endif
+source "arch/arm/mach-stm32mp/cmd_stm32prog/Kconfig" source "board/st/stm32mp1/Kconfig" source "board/dhelectronics/dh_stm32mp1/Kconfig"
diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/Kconfig b/arch/arm/mach-stm32mp/cmd_stm32prog/Kconfig new file mode 100644 index 0000000000..609a678793 --- /dev/null +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/Kconfig @@ -0,0 +1,18 @@ + +config CMD_STM32PROG + bool "command stm32prog for STM32CudeProgrammer" + select DFU + select DFU_RAM + select DFU_VIRT + select PARTITION_TYPE_GUID + imply CMD_GPT if MMC + imply CMD_MTD if MTD + imply DFU_MMC if MMC + imply DFU_MTD if MTD + help + activate a specific command stm32prog for STM32MP soc family + witch update the device with the tools STM32CubeProgrammer, + using UART with STM32 protocol or USB with DFU protocol + NB: access to not volatile memory (NOR/NAND/SD/eMMC) is based + on U-Boot DFU framework +
Add CONFIG_CMD_STM32PROG_SERIAL and CONFIG_CMD_STM32PROG_USB to independently select the support of UART or USB communication for STM32CubeProgrammer.
For serial boot over UART, user can deactivate CONFIG_CMD_STM32PROG_SERIAL to use U-Boot console of binary loaded by UART (for board bring-up for example).
arch/arm/mach-stm32mp/Makefile | 2 +- arch/arm/mach-stm32mp/cmd_stm32prog/Kconfig | 20 ++++++++++++++-- arch/arm/mach-stm32mp/cmd_stm32prog/Makefile | 8 +++---- .../cmd_stm32prog/cmd_stm32prog.c | 4 ++-- .../mach-stm32mp/cmd_stm32prog/stm32prog.h | 23 ++++++++++++++++++- arch/arm/mach-stm32mp/cpu.c | 5 ++-- board/st/common/stm32mp_dfu.c | 9 ++++---- 7 files changed, 55 insertions(+), 16 deletions(-)
diff --git a/arch/arm/mach-stm32mp/Makefile b/arch/arm/mach-stm32mp/Makefile index c8aa24d489..aa39867080 100644 --- a/arch/arm/mach-stm32mp/Makefile +++ b/arch/arm/mach-stm32mp/Makefile @@ -11,7 +11,7 @@ obj-y += bsec.o ifdef CONFIG_SPL_BUILD obj-y += spl.o else -obj-$(CONFIG_CMD_STM32PROG) += cmd_stm32prog/ +obj-y += cmd_stm32prog/ obj-$(CONFIG_CMD_STM32KEY) += cmd_stm32key.o obj-$(CONFIG_ARMV7_PSCI) += psci.o obj-$(CONFIG_TFABOOT) += boot_params.o diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/Kconfig b/arch/arm/mach-stm32mp/cmd_stm32prog/Kconfig index 609a678793..f4c0d18d4d 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/Kconfig +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/Kconfig @@ -11,8 +11,24 @@ config CMD_STM32PROG imply DFU_MTD if MTD help activate a specific command stm32prog for STM32MP soc family - witch update the device with the tools STM32CubeProgrammer, - using UART with STM32 protocol or USB with DFU protocol + witch update the device with the tools STM32CubeProgrammer NB: access to not volatile memory (NOR/NAND/SD/eMMC) is based on U-Boot DFU framework
+config CMD_STM32PROG_USB + bool "support stm32prog over USB" + depends on CMD_STM32PROG + default y + help + activate the command "stm32prog usb" for STM32MP soc family + witch update the device with the tools STM32CubeProgrammer, + using USB with DFU protocol + +config CMD_STM32PROG_SERIAL + bool "support stm32prog over UART" + depends on CMD_STM32PROG + default y + help + activate the command "stm32prog serial" for STM32MP soc family + with the tools STM32CubeProgrammer using U-Boot serial device + and UART protocol. \ No newline at end of file diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/Makefile b/arch/arm/mach-stm32mp/cmd_stm32prog/Makefile index 548a378921..b57e1bf870 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/Makefile +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/Makefile @@ -3,7 +3,7 @@ # Copyright (C) 2020, STMicroelectronics - All Rights Reserved #
-obj-y += cmd_stm32prog.o -obj-y += stm32prog.o -obj-y += stm32prog_serial.o -obj-y += stm32prog_usb.o +obj-$(CONFIG_CMD_STM32PROG) += cmd_stm32prog.o +obj-$(CONFIG_CMD_STM32PROG) += stm32prog.o +obj-$(CONFIG_CMD_STM32PROG_SERIAL) += stm32prog_serial.o +obj-$(CONFIG_CMD_STM32PROG_USB) += stm32prog_usb.o diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c b/arch/arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c index 34a6be66c3..a7e2861764 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c @@ -50,9 +50,9 @@ static int do_stm32prog(struct cmd_tbl *cmdtp, int flag, int argc, if (argc < 3 || argc > 5) return CMD_RET_USAGE;
- if (!strcmp(argv[1], "usb")) + if (IS_ENABLED(CONFIG_CMD_STM32PROG_USB) && !strcmp(argv[1], "usb")) link = LINK_USB; - else if (!strcmp(argv[1], "serial")) + else if (IS_ENABLED(CONFIG_CMD_STM32PROG_SERIAL) && !strcmp(argv[1], "serial")) link = LINK_SERIAL;
if (link == LINK_UNDEFINED) { diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h index be482c3402..18af99c78b 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h @@ -177,9 +177,30 @@ char *stm32prog_get_error(struct stm32prog_data *data);
/* Main function */ int stm32prog_init(struct stm32prog_data *data, ulong addr, ulong size); +void stm32prog_clean(struct stm32prog_data *data); + +#ifdef CONFIG_CMD_STM32PROG_SERIAL int stm32prog_serial_init(struct stm32prog_data *data, int link_dev); bool stm32prog_serial_loop(struct stm32prog_data *data); +#else +static inline int stm32prog_serial_init(struct stm32prog_data *data, int link_dev) +{ + return -ENOSYS; +} + +static inline bool stm32prog_serial_loop(struct stm32prog_data *data) +{ + return false; +} +#endif + +#ifdef CONFIG_CMD_STM32PROG_USB bool stm32prog_usb_loop(struct stm32prog_data *data, int dev); -void stm32prog_clean(struct stm32prog_data *data); +#else +static inline bool stm32prog_usb_loop(struct stm32prog_data *data, int dev) +{ + return false; +} +#endif
#endif diff --git a/arch/arm/mach-stm32mp/cpu.c b/arch/arm/mach-stm32mp/cpu.c index 3faa4ec18a..a453f89d02 100644 --- a/arch/arm/mach-stm32mp/cpu.c +++ b/arch/arm/mach-stm32mp/cpu.c @@ -265,7 +265,8 @@ int arch_cpu_init(void)
boot_mode = get_bootmode();
- if ((boot_mode & TAMP_BOOT_DEVICE_MASK) == BOOT_SERIAL_UART) + if (IS_ENABLED(CONFIG_CMD_STM32PROG_SERIAL) && + (boot_mode & TAMP_BOOT_DEVICE_MASK) == BOOT_SERIAL_UART) gd->flags |= GD_FLG_SILENT | GD_FLG_DISABLE_CONSOLE; #if defined(CONFIG_DEBUG_UART) && \ !defined(CONFIG_TFABOOT) && \ @@ -485,7 +486,7 @@ static void setup_boot_mode(void) env_set("boot_instance", cmd);
/* restore console on uart when not used */ - if (gd->cur_serial_dev != dev) { + if (IS_ENABLED(CONFIG_CMD_STM32PROG_SERIAL) && gd->cur_serial_dev != dev) { gd->flags &= ~(GD_FLG_SILENT | GD_FLG_DISABLE_CONSOLE); printf("serial boot with console enabled!\n"); diff --git a/board/st/common/stm32mp_dfu.c b/board/st/common/stm32mp_dfu.c index 5633a6cb95..00d1fb8f59 100644 --- a/board/st/common/stm32mp_dfu.c +++ b/board/st/common/stm32mp_dfu.c @@ -143,7 +143,8 @@ void set_dfu_alt_info(char *interface, char *devstr) board_get_alt_info_mtd(mtd, buf); }
- if (IS_ENABLED(CONFIG_DFU_VIRT)) { + if (IS_ENABLED(CONFIG_DFU_VIRT) && + IS_ENABLED(CMD_STM32PROG_USB)) { strncat(buf, "&virt 0=OTP", DFU_ALT_BUF_LEN);
if (IS_ENABLED(CONFIG_PMIC_STPMIC1)) @@ -217,7 +218,7 @@ int dfu_read_medium_virt(struct dfu_entity *dfu, u64 offset, return dfu_pmic_read(offset, buf, len); }
- if (CONFIG_IS_ENABLED(CMD_STM32PROG) && + if (IS_ENABLED(CONFIG_CMD_STM32PROG_USB) && dfu->data.virt.dev_num >= STM32PROG_VIRT_FIRST_DEV_NUM) return stm32prog_read_medium_virt(dfu, offset, buf, len);
@@ -228,7 +229,7 @@ int dfu_read_medium_virt(struct dfu_entity *dfu, u64 offset, int dfu_write_medium_virt(struct dfu_entity *dfu, u64 offset, void *buf, long *len) { - if (CONFIG_IS_ENABLED(CMD_STM32PROG) && + if (IS_ENABLED(CONFIG_CMD_STM32PROG_USB) && dfu->data.virt.dev_num >= STM32PROG_VIRT_FIRST_DEV_NUM) return stm32prog_write_medium_virt(dfu, offset, buf, len);
@@ -237,7 +238,7 @@ int dfu_write_medium_virt(struct dfu_entity *dfu, u64 offset,
int __weak dfu_get_medium_size_virt(struct dfu_entity *dfu, u64 *size) { - if (CONFIG_IS_ENABLED(CMD_STM32PROG) && + if (IS_ENABLED(CONFIG_CMD_STM32PROG_USB) && dfu->data.virt.dev_num >= STM32PROG_VIRT_FIRST_DEV_NUM) return stm32prog_get_medium_size_virt(dfu, size);
Hi Patrick
NB: access to not volatile memory (NOR/NAND/SD/eMMC) is based on U-Boot DFU frameworkwitch update the device with the tools STM32CubeProgrammer
- bool "support stm32prog over USB"
- depends on CMD_STM32PROG
- default y
- help
- bool "support stm32prog over UART"
- default y
- help
and UART protocol.
- if (IS_ENABLED(CONFIG_CMD_STM32PROG_USB) && !strcmp(argv[1], "usb")) link = LINK_USB;
- return -ENOSYS;
- return false;
+} +#endif
- return false;
+} +#endif
- if (IS_ENABLED(CONFIG_CMD_STM32PROG_SERIAL) &&
gd->flags |= GD_FLG_SILENT | GD_FLG_DISABLE_CONSOLE;(boot_mode & TAMP_BOOT_DEVICE_MASK) == BOOT_SERIAL_UART)
- if (IS_ENABLED(CONFIG_CMD_STM32PROG_USB) && dfu->data.virt.dev_num >= STM32PROG_VIRT_FIRST_DEV_NUM) return stm32prog_read_medium_virt(dfu, offset, buf, len);
- if (IS_ENABLED(CONFIG_CMD_STM32PROG_USB) && dfu->data.virt.dev_num >= STM32PROG_VIRT_FIRST_DEV_NUM) return stm32prog_write_medium_virt(dfu, offset, buf, len);
- if (IS_ENABLED(CONFIG_CMD_STM32PROG_USB) && dfu->data.virt.dev_num >= STM32PROG_VIRT_FIRST_DEV_NUM) return stm32prog_get_medium_size_virt(dfu, size);
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com
Thanks Patrice
Hi
On 3/9/21 2:08 PM, Patrice CHOTARD wrote:
Hi Patrick
- default y
- help
- default y
- help
and UART protocol.
- return -ENOSYS;
- return false;
+} +#endif
- return false;
+} +#endif
Thanks Patrice
Applied to u-boot-stm/next
Thanks
Patrice
When serial instance is not found in device tree, the console should be enabled and the error should be indicated.
arch/arm/mach-stm32mp/cpu.c | 14 ++++++++++---- 1 file changed, 10 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-stm32mp/cpu.c b/arch/arm/mach-stm32mp/cpu.c index a453f89d02..527b6290de 100644 --- a/arch/arm/mach-stm32mp/cpu.c +++ b/arch/arm/mach-stm32mp/cpu.c @@ -476,11 +476,17 @@ static void setup_boot_mode(void) break; /* serial : search associated alias in devicetree */ sprintf(cmd, "serial@%x", serial_addr[instance]); - if (uclass_get_device_by_name(UCLASS_SERIAL, cmd, &dev)) - break; - if (fdtdec_get_alias_seq(gd->fdt_blob, "serial", - dev_of_offset(dev), &alias)) + if (uclass_get_device_by_name(UCLASS_SERIAL, cmd, &dev) || + fdtdec_get_alias_seq(gd->fdt_blob, "serial", + dev_of_offset(dev), &alias)) { + /* restore console on error */ + if (IS_ENABLED(CONFIG_CMD_STM32PROG_SERIAL)) + gd->flags &= ~(GD_FLG_SILENT | + GD_FLG_DISABLE_CONSOLE); + printf("serial%d = %s not found in device tree!\n", + instance, cmd); break; + } sprintf(cmd, "%d", alias); env_set("boot_device", "serial"); env_set("boot_instance", cmd);
Hi Patrick
break;
sprintf(cmd, "%d", alias); env_set("boot_device", "serial"); env_set("boot_instance", cmd);}
Thanks Patrice
Hi
break;
Thanks
Patrice
The command "stm32prog serial <dev>" can directly use the device sequence number of serial uclass as this sequence number is egual to alias when it exist; this assumption simplify the code and avoid access to gd->fdt_blob and the device tree parsing.
.../cmd_stm32prog/stm32prog_serial.c | 29 ++++--------------- arch/arm/mach-stm32mp/cpu.c | 11 +++---- 2 files changed, 10 insertions(+), 30 deletions(-)
diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_serial.c b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_serial.c index 373ca20886..a51e5e3ec8 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_serial.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_serial.c @@ -187,36 +187,19 @@ static int stm32prog_read(struct stm32prog_data *data, u8 phase, u32 offset, int stm32prog_serial_init(struct stm32prog_data *data, int link_dev) { struct udevice *dev = NULL; - int node; - char alias[10]; - const char *path; struct dm_serial_ops *ops; /* no parity, 8 bits, 1 stop */ u32 serial_config = SERIAL_DEFAULT_CONFIG;
down_serial_dev = NULL;
- sprintf(alias, "serial%d", link_dev); - path = fdt_get_alias(gd->fdt_blob, alias); - if (!path) { - log_err("%s alias not found", alias); - return -ENODEV; - } - node = fdt_path_offset(gd->fdt_blob, path); - if (!uclass_get_device_by_of_offset(UCLASS_SERIAL, node, - &dev)) { - down_serial_dev = dev; - } else if (node > 0 && - !lists_bind_fdt(gd->dm_root, offset_to_ofnode(node), - &dev, false)) { - if (!device_probe(dev)) - down_serial_dev = dev; - } - if (!down_serial_dev) { - log_err("%s = %s device not found", alias, path); + if (uclass_get_device_by_seq(UCLASS_SERIAL, link_dev, &dev)) { + log_err("serial %d device not found\n", link_dev); return -ENODEV; }
+ down_serial_dev = dev; + /* force silent console on uart only when used */ if (gd->cur_serial_dev == down_serial_dev) gd->flags |= GD_FLG_DISABLE_CONSOLE | GD_FLG_SILENT; @@ -226,11 +209,11 @@ int stm32prog_serial_init(struct stm32prog_data *data, int link_dev) ops = serial_get_ops(down_serial_dev);
if (!ops) { - log_err("%s = %s missing ops", alias, path); + log_err("serial %d = %s missing ops\n", link_dev, dev->name); return -ENODEV; } if (!ops->setconfig) { - log_err("%s = %s missing setconfig", alias, path); + log_err("serial %d = %s missing setconfig\n", link_dev, dev->name); return -ENODEV; }
diff --git a/arch/arm/mach-stm32mp/cpu.c b/arch/arm/mach-stm32mp/cpu.c index 527b6290de..9a76b5633b 100644 --- a/arch/arm/mach-stm32mp/cpu.c +++ b/arch/arm/mach-stm32mp/cpu.c @@ -466,7 +466,6 @@ static void setup_boot_mode(void) unsigned int instance = (boot_mode & TAMP_BOOT_INSTANCE_MASK) - 1; u32 forced_mode = (boot_ctx & TAMP_BOOT_FORCED_MASK); struct udevice *dev; - int alias;
log_debug("%s: boot_ctx=0x%x => boot_mode=%x, instance=%d forced=%x\n", __func__, boot_ctx, boot_mode, instance, forced_mode); @@ -474,20 +473,18 @@ static void setup_boot_mode(void) case BOOT_SERIAL_UART: if (instance > ARRAY_SIZE(serial_addr)) break; - /* serial : search associated alias in devicetree */ + /* serial : search associated node in devicetree */ sprintf(cmd, "serial@%x", serial_addr[instance]); - if (uclass_get_device_by_name(UCLASS_SERIAL, cmd, &dev) || - fdtdec_get_alias_seq(gd->fdt_blob, "serial", - dev_of_offset(dev), &alias)) { + if (uclass_get_device_by_name(UCLASS_SERIAL, cmd, &dev)) { /* restore console on error */ if (IS_ENABLED(CONFIG_CMD_STM32PROG_SERIAL)) gd->flags &= ~(GD_FLG_SILENT | GD_FLG_DISABLE_CONSOLE); - printf("serial%d = %s not found in device tree!\n", + printf("uart%d = %s not found in device tree!\n", instance, cmd); break; } - sprintf(cmd, "%d", alias); + sprintf(cmd, "%d", dev_seq(dev)); env_set("boot_device", "serial"); env_set("boot_instance", cmd);
Hi Patrick
int node;
char alias[10];
if (!path) {
return -ENODEV;
&dev)) {
&dev, false)) {
return -ENODEV; }
if (!ops) {
return -ENODEV; } if (!ops->setconfig) {log_err("serial %d = %s missing ops\n", link_dev, dev->name);
return -ENODEV; }log_err("serial %d = %s missing setconfig\n", link_dev, dev->name);
int alias;
sprintf(cmd, "serial@%x", serial_addr[instance]);/* serial : search associated node in devicetree */
}printf("uart%d = %s not found in device tree!\n", instance, cmd); break;
env_set("boot_device", "serial"); env_set("boot_instance", cmd);sprintf(cmd, "%d", dev_seq(dev));
Thanks Patrice
Hi
On 3/9/21 2:14 PM, Patrice CHOTARD wrote:
Hi Patrick
int node;
char alias[10];
if (!path) {
return -ENODEV;
&dev)) {
&dev, false)) {
return -ENODEV; }
if (!ops) {
int alias;
Thanks Patrice
Thanks
Patrice
Hi Patrick
- select DFU
- select DFU_RAM
- select DFU_VIRT
- help
- select DFU
- select DFU_RAM
- select DFU_VIRT
- help
Thanks Patrice
Hi
On 3/9/21 2:07 PM, Patrice CHOTARD wrote:
Hi Patrick
- select DFU
- select DFU_RAM
- select DFU_VIRT
- help
- select DFU
- select DFU_RAM
- select DFU_VIRT
- help
Thanks Patrice _______________________________________________ Uboot-stm32 mailing list Uboot-stm32@st-md-mailman.stormreply.com https://st-md-mailman.stormreply.com/mailman/listinfo/uboot-stm32
Thanks
Patrice
Patrice CHOTARD
Patrick Delaunay
