[U-Boot-Users] change U-boot file stream to COM2
Hello, I have an PXA270 bord with U-boot version 1.1.2 (Dec 22 2005 - 09:10:28) I want to change the file stream stdin and stdout to the serial COM port 2, now its on COM1 I tried with
-setenv stdin serial1 -saveenv
also tried with
-setenv stdin=serial1 -saveenv
but no luck. The file stream is always COM1. Can you gibe me a hint? Best regards
also tried with
As a very first step you should try finding out which I/O devices are configured on your system. What does the "coninfo" command print?
Hi Wolfgang, the coninfo shows this:
List of available devices: serial 80000003 SIO stdin stdout stderr nulldev 80000003 SIO
I suppose this is why I can´t add the second serial, how do I add the COM2 ? Bets regards Javier
also tried with
Right - when there is no other device configured, you cannot switch to another device...
I don't know if this feature is supported for yoru architecture and/or your board. Check the configuration...
Hi Wolfgang, the hardware definetely supports the COM2 (I tested it with Windows CE 5.0), but how can I add/configure the COM2 with U-boot ? Is 80000003 a memory adress? Best regards Javier
In message op.twzubus0i2vpqq@localhost you wrote:
SGkgV29sZmdhbmcsCnRoZSBoYXJkd2FyZSBkZWZpbmV0ZWx5IHN1cHBvcnRzIHRoZSBDT00yIChJ IHRlc3RlZCBpdCB3aXRoIFdpbmRvd3MgQ0UgIAo1LjApLCBidXQgaG93IGNhbiBJIGFkZC9jb25m aWd1cmUgdGhlIENPTTIgd2l0aCBVLWJvb3QgPwpJcyA4MDAwMDAwMyBhIG1lbW9yeSBhZHJlc3M/ CkJlc3QgcmVnYXJkcwpKYXZpZXIKCk9uIE1vbiwgMTMgQXVnIDIwMDcgMTE6NDI6MzMgKzAyMDAs IFdvbGZnYW5nIERlbmsgPHdkQGRlbnguZGU+IHdyb3RlOgoKPiBJbiBtZXNzYWdlIDxvcC50d3ps N3dvY2kydnBxcUBsb2NhbGhvc3Q+IHlvdSB3cm90ZToKPj4KPj4gdGhlIGNvbmluZm8gc2hvd3Mg dGhpczoKPj4KPj4gTGlzdCBvZiBhdmFpbGFibGUgZGV2aWNlczoKPj4gc2VyaWFsICAgODAwMDAw MDMgU0lPIHN0ZGluIHN0ZG91dCBzdGRlcnIKPj4gbnVsbGRldiAgODAwMDAwMDMgU0lPCj4+Cj4+ IEkgc3VwcG9zZSB0aGlzIGlzIHdoeSBJIGNhbsOCwrR0IGFkZCB0aGUgc2Vjb25kIHNlcmlhbCwg aG93IGRvIEkgYWRkIHRoZSAgCj4+IENPTTIKPj4gPwo+Cj4gUmlnaHQgLSB3aGVuIHRoZXJlIGlz IG5vIG90aGVyIGRldmljZSBjb25maWd1cmVkLCB5b3UgY2Fubm90IHN3aXRjaCB0bwo+IGFub3Ro ZXIgZGV2aWNlLi4uCj4KPiBJIGRvbid0IGtub3cgaWYgdGhpcyBmZWF0dXJlIGlzIHN1cHBvcnRl ZCBmb3IgeW9ydSBhcmNoaXRlY3R1cmUgYW5kL29yCj4geW91ciBib2FyZC4gQ2hlY2sgdGhlIGNv bmZpZ3VyYXRpb24uLi4KPgo+IEJlc3QgcmVnYXJkcywKPgo+IFdvbGZnYW5nIERlbmsKPgoKCgot LSAKSmF2aWVyIEdyaWphbGJhCkphdmllciBkb3QgR3JpamFsYmEgYXQgZ21haWwgZG90IGNvbQoK LS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0t LS0tLS0tLS0tLS0tLS0tLQpUaGlzIFNGLm5ldCBlbWFpbCBpcyBzcG9uc29yZWQgYnk6IFNwbHVu ayBJbmMuClN0aWxsIGdyZXBwaW5nIHRocm91Z2ggbG9nIGZpbGVzIHRvIGZpbmQgcHJvYmxlbXM/ ICBTdG9wLgpOb3cgU2VhcmNoIGxvZyBldmVudHMgYW5kIGNvbmZpZ3VyYXRpb24gZmlsZXMgdXNp bmcgQUpBWCBhbmQgYSBicm93c2VyLgpEb3dubG9hZCB5b3VyIEZSRUUgY29weSBvZiBTcGx1bmsg bm93ID4+ICBodHRwOi8vZ2V0LnNwbHVuay5jb20vCl9fX19fX19fX19fX19fX19fX19fX19fX19f X19fX19fX19fX19fX19fX19fX19fClUtQm9vdC1Vc2VycyBtYWlsaW5nIGxpc3QKVS1Cb290LVVz ZXJzQGxpc3RzLnNvdXJjZWZvcmdlLm5ldApodHRwczovL2xpc3RzLnNvdXJjZWZvcmdlLm5ldC9s aXN0cy9saXN0aW5mby91LWJvb3QtdXNlcnMK
Please do not send base 64 encoded messages.
Please do not send HTML messages.
Please send plain text only.
Message unreadable, ignored. Sorry.
As mentioned before: I don't know if this feature is supported for your architecture and/or your board. Check the configuration...
No, its flag bits. Please RTFM and the code.
Hi Javier,
On the PXA270 you have three different UARTs, FFUART, BTUART and STDUART. I don't know what your configuration looks like, but I am pretty sure that what you dub as "COM1" is the FFUART and the other UARTs are not even supported let alone dynamically switchable in U-Boot.
Fortunately we are just working on something like this, Stefano (on CC), should be able to tell you when this will be finished.
Cheers Detlev
Test is finished. I will send the patch. Multiple serials are supported in the same way as they are on the PPC boards.
Javier, at the moment u-boot supports only one serial interface and consequently you cannot enable the other ones. You can use any of FFUART,BTUART or STUART, but u-boot cannot have more than one serial at the same time. The serial driver for PXA27xx does not support it.
After applying the patch I will send, you have to set CONFIG_SERIAL_MULTI in your config file and all serials you want to use:
#define CONFIG_SERIAL_MULTI #define CONFIG_FFUART 1 /* we use FFUART on Conxs */ #define CONFIG_BTUART 1 /* we use BTUART on Conxs */ #define CONFIG_STUART 1 /* we use STUART on Conxs */
You have to provide also a function in your board.c file to return the default serial device, such as:
struct serial_device *default_serial_console (void) { return &serial_ffuart_device; }
or whatever you prefer.
On my target (PXA270) I get: U-Boot 1.2.0-gc7d2ba2d-dirty (Aug 23 2007 - 15:47:09)
DRAM: 64 MB Flash: 32 MB In: serial Out: serial Err: serial Hit any key to stop autoboot: 0 $ coninfo List of available devices: serial 80000003 SIO stdin stdout stderr nulldev 80000003 SIO serial_stuart 00000003 .IO serial_btuart 00000003 .IO serial_ffuart 00000003 .IO
Then you will be able to switch among the serials setting the stdout, stdin and stderr variables. For example, to switch to the BTUART:
setenv stdout serial_btuart setenv stdin serial_btuart
Regards, stefano
Detlev Zundel
Javier Grijalba
stefano babic
