[U-Boot] [PATCH V4 1/3] imx-common/cmd_bmode.c: add imx bmode (bootmode) command
This is useful for forcing the ROM's usb downloader to activate upon a watchdog reset. Or, you can boot from either SD Card.
Currently, support added for MX53 and MX6Q Signed-off-by: Troy Kisky troy.kisky@boundarydevices.com
Note: MX53 support untested.
--- v4: replaced some occurrances of reset s/reset/boot/ or s/reset/b/ renamed files only bmode command now, added noreset argument. add static keywords --- arch/arm/cpu/armv7/imx-common/Makefile | 1 + arch/arm/cpu/armv7/imx-common/cmd_bmode.c | 119 +++++++++++++++++++++++++++ arch/arm/cpu/armv7/mx5/soc.c | 31 +++++++ arch/arm/cpu/armv7/mx6/soc.c | 36 ++++++++ arch/arm/include/asm/arch-mx5/imx-regs.h | 18 ++++ arch/arm/include/asm/arch-mx6/imx-regs.h | 21 +++++ arch/arm/include/asm/imx-common/boot_mode.h | 36 ++++++++ 7 files changed, 262 insertions(+) create mode 100644 arch/arm/cpu/armv7/imx-common/cmd_bmode.c create mode 100644 arch/arm/include/asm/imx-common/boot_mode.h
diff --git a/arch/arm/cpu/armv7/imx-common/Makefile b/arch/arm/cpu/armv7/imx-common/Makefile index bf36be5..16fba8d 100644 --- a/arch/arm/cpu/armv7/imx-common/Makefile +++ b/arch/arm/cpu/armv7/imx-common/Makefile @@ -29,6 +29,7 @@ LIB = $(obj)libimx-common.o
COBJS-y = iomux-v3.o timer.o cpu.o speed.o COBJS-$(CONFIG_I2C_MXC) += i2c.o +COBJS-$(CONFIG_CMD_BMODE) += cmd_bmode.o COBJS := $(sort $(COBJS-y))
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) diff --git a/arch/arm/cpu/armv7/imx-common/cmd_bmode.c b/arch/arm/cpu/armv7/imx-common/cmd_bmode.c new file mode 100644 index 0000000..02fe72e --- /dev/null +++ b/arch/arm/cpu/armv7/imx-common/cmd_bmode.c @@ -0,0 +1,119 @@ +/* + * Copyright (C) 2012 Boundary Devices Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <asm/errno.h> +#include <asm/io.h> +#include <asm/imx-common/boot_mode.h> +#include <malloc.h> + +static const struct boot_mode *modes[2]; + +static const struct boot_mode *search_modes(char *arg) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(modes); i++) { + const struct boot_mode *p = modes[i]; + if (p) { + while (p->name) { + if (!strcmp(p->name, arg)) + return p; + p++; + } + } + } + return NULL; +} + +static int create_usage(char *dest) +{ + int i; + int size = 0; + + for (i = 0; i < ARRAY_SIZE(modes); i++) { + const struct boot_mode *p = modes[i]; + if (p) { + while (p->name) { + int len = strlen(p->name); + if (dest) { + memcpy(dest, p->name, len); + dest += len; + *dest++ = '|'; + } + size += len + 1; + p++; + } + } + } + if (dest) + memcpy(dest - 1, " [noreset]", 11); /* include trailing 0 */ + size += 10; + return size; +} + +static int do_boot_mode(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + const struct boot_mode *p; + int reset_requested = 1; + + if (argc < 2) + return CMD_RET_USAGE; + p = search_modes(argv[1]); + if (!p) + return CMD_RET_USAGE; + if (argc == 3) { + if (strcmp(argv[2], "noreset")) + return CMD_RET_USAGE; + reset_requested = 0; + } + + boot_mode_apply(p->cfg_val); + if (reset_requested && p->cfg_val) + do_reset(NULL, 0, 0, NULL); + return 0; +} + +U_BOOT_CMD( + bmode, 3, 0, do_boot_mode, + NULL, + ""); + +void add_board_boot_modes(const struct boot_mode *p) +{ + int size; + char *dest; + + if (__u_boot_cmd_bmode.usage) { + free(__u_boot_cmd_bmode.usage); + __u_boot_cmd_bmode.usage = NULL; + } + + modes[0] = p; + modes[1] = soc_boot_modes; + size = create_usage(NULL); + dest = malloc(size); + if (dest) { + create_usage(dest); + __u_boot_cmd_bmode.usage = dest; + } +} diff --git a/arch/arm/cpu/armv7/mx5/soc.c b/arch/arm/cpu/armv7/mx5/soc.c index 3f5a4f7..d9ca88a 100644 --- a/arch/arm/cpu/armv7/mx5/soc.c +++ b/arch/arm/cpu/armv7/mx5/soc.c @@ -30,6 +30,7 @@
#include <asm/errno.h> #include <asm/io.h> +#include <asm/imx-common/boot_mode.h>
#if !(defined(CONFIG_MX51) || defined(CONFIG_MX53)) #error "CPU_TYPE not defined" @@ -115,3 +116,33 @@ void set_chipselect_size(int const cs_size)
writel(reg, &iomuxc_regs->gpr1); } + +#ifdef CONFIG_MX53 +void boot_mode_apply(unsigned cfg_val) +{ + writel(cfg_val, &((struct srtc_regs *)SRTC_BASE_ADDR)->lpgr); +} +/* + * cfg_val will be used for + * Boot_cfg3[7:0]:Boot_cfg2[7:0]:Boot_cfg1[7:0] + * + * If bit 28 of LPGR is set upon watchdog reset, + * bits[25:0] of LPGR will move to SBMR. + */ +const struct boot_mode soc_boot_modes[] = { + {"normal", MAKE_CFGVAL(0x00, 0x00, 0x00, 0x00)}, + /* usb or serial download */ + {"usb", MAKE_CFGVAL(0x00, 0x00, 0x00, 0x13)}, + {"sata", MAKE_CFGVAL(0x28, 0x00, 0x00, 0x12)}, + {"escpi1:0", MAKE_CFGVAL(0x38, 0x20, 0x00, 0x12)}, + {"escpi1:1", MAKE_CFGVAL(0x38, 0x20, 0x04, 0x12)}, + {"escpi1:2", MAKE_CFGVAL(0x38, 0x20, 0x08, 0x12)}, + {"escpi1:3", MAKE_CFGVAL(0x38, 0x20, 0x0c, 0x12)}, + /* 4 bit bus width */ + {"esdhc1", MAKE_CFGVAL(0x40, 0x20, 0x00, 0x12)}, + {"esdhc2", MAKE_CFGVAL(0x40, 0x20, 0x08, 0x12)}, + {"esdhc3", MAKE_CFGVAL(0x40, 0x20, 0x10, 0x12)}, + {"esdhc4", MAKE_CFGVAL(0x40, 0x20, 0x18, 0x12)}, + {NULL, 0}, +}; +#endif diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index 84b458c..7380ffe 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -29,6 +29,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> +#include <asm/imx-common/boot_mode.h>
u32 get_cpu_rev(void) { @@ -141,3 +142,38 @@ void imx_get_mac_from_fuse(int dev_id, unsigned char *mac)
} #endif + +void boot_mode_apply(unsigned cfg_val) +{ + unsigned reg; + struct src_regs *psrc = (struct src_regs *)SRC_BASE_ADDR; + writel(cfg_val, &psrc->gpr9); + reg = readl(&psrc->gpr10); + if (cfg_val) + reg |= 1 << 28; + else + reg &= ~(1 << 28); + writel(reg, &psrc->gpr10); +} +/* + * cfg_val will be used for + * Boot_cfg4[7:0]:Boot_cfg3[7:0]:Boot_cfg2[7:0]:Boot_cfg1[7:0] + * After reset, if GPR10[28] is 1, ROM will copy GPR9[25:0] + * to SBMR1, which will determine the boot device. + */ +const struct boot_mode soc_boot_modes[] = { + {"normal", MAKE_CFGVAL(0x00, 0x00, 0x00, 0x00)}, + /* reserved value should start rom usb */ + {"usb", MAKE_CFGVAL(0x01, 0x00, 0x00, 0x00)}, + {"sata", MAKE_CFGVAL(0x20, 0x00, 0x00, 0x00)}, + {"escpi1:0", MAKE_CFGVAL(0x30, 0x00, 0x00, 0x08)}, + {"escpi1:1", MAKE_CFGVAL(0x30, 0x00, 0x00, 0x18)}, + {"escpi1:2", MAKE_CFGVAL(0x30, 0x00, 0x00, 0x28)}, + {"escpi1:3", MAKE_CFGVAL(0x30, 0x00, 0x00, 0x38)}, + /* 4 bit bus width */ + {"esdhc1", MAKE_CFGVAL(0x40, 0x20, 0x00, 0x00)}, + {"esdhc2", MAKE_CFGVAL(0x40, 0x28, 0x00, 0x00)}, + {"esdhc3", MAKE_CFGVAL(0x40, 0x30, 0x00, 0x00)}, + {"esdhc4", MAKE_CFGVAL(0x40, 0x38, 0x00, 0x00)}, + {NULL, 0}, +}; diff --git a/arch/arm/include/asm/arch-mx5/imx-regs.h b/arch/arm/include/asm/arch-mx5/imx-regs.h index 7f66b61..c53465f 100644 --- a/arch/arm/include/asm/arch-mx5/imx-regs.h +++ b/arch/arm/include/asm/arch-mx5/imx-regs.h @@ -459,6 +459,24 @@ struct src { u32 simr; };
+struct srtc_regs { + u32 lpscmr; /* 0x00 */ + u32 lpsclr; /* 0x04 */ + u32 lpsar; /* 0x08 */ + u32 lpsmcr; /* 0x0c */ + u32 lpcr; /* 0x10 */ + u32 lpsr; /* 0x14 */ + u32 lppdr; /* 0x18 */ + u32 lpgr; /* 0x1c */ + u32 hpcmr; /* 0x20 */ + u32 hpclr; /* 0x24 */ + u32 hpamr; /* 0x28 */ + u32 hpalr; /* 0x2c */ + u32 hpcr; /* 0x30 */ + u32 hpisr; /* 0x34 */ + u32 hpienr; /* 0x38 */ +}; + /* CSPI registers */ struct cspi_regs { u32 rxdata; diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index 5d77603..dacb9ea 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -448,5 +448,26 @@ struct iomuxc_base_regs { u32 daisy[104]; /* 0x7b0..94c */ };
+struct src_regs { + u32 scr; /* 0x00 */ + u32 sbmr1; /* 0x04 */ + u32 srsr; /* 0x08 */ + u32 reserved1; /* 0x0c */ + u32 reserved2; /* 0x10 */ + u32 sisr; /* 0x14 */ + u32 simr; /* 0x18 */ + u32 sbmr2; /* 0x1c */ + u32 gpr1; /* 0x20 */ + u32 gpr2; /* 0x24 */ + u32 gpr3; /* 0x28 */ + u32 gpr4; /* 0x2c */ + u32 gpr5; /* 0x30 */ + u32 gpr6; /* 0x34 */ + u32 gpr7; /* 0x38 */ + u32 gpr8; /* 0x3c */ + u32 gpr9; /* 0x40 */ + u32 gpr10; /* 0x44 */ +}; + #endif /* __ASSEMBLER__*/ #endif /* __ASM_ARCH_MX6_IMX_REGS_H__ */ diff --git a/arch/arm/include/asm/imx-common/boot_mode.h b/arch/arm/include/asm/imx-common/boot_mode.h new file mode 100644 index 0000000..6d2df74 --- /dev/null +++ b/arch/arm/include/asm/imx-common/boot_mode.h @@ -0,0 +1,36 @@ +/* + * Copyright (C) 2012 Boundary Devices Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _ASM_BOOT_MODE_H +#define _ASM_BOOT_MODE_H +#define MAKE_CFGVAL(cfg1, cfg2, cfg3, cfg4) \ + ((cfg4) << 24) | ((cfg3) << 16) | ((cfg2) << 8) | (cfg1) + +struct boot_mode { + const char *name; + unsigned cfg_val; +}; + +void add_board_boot_modes(const struct boot_mode *p); +void boot_mode_apply(unsigned cfg_val); +extern const struct boot_mode soc_boot_modes[]; +#endif
This allows a watchdog reset to start the ROM's usb downloader, or boot from an sdcard.
Signed-off-by: Troy Kisky troy.kisky@boundarydevices.com --- board/freescale/mx6qsabrelite/mx6qsabrelite.c | 14 ++++++++++++++ include/configs/mx6qsabrelite.h | 3 +++ 2 files changed, 17 insertions(+)
diff --git a/board/freescale/mx6qsabrelite/mx6qsabrelite.c b/board/freescale/mx6qsabrelite/mx6qsabrelite.c index a1e3acc..cb85597 100644 --- a/board/freescale/mx6qsabrelite/mx6qsabrelite.c +++ b/board/freescale/mx6qsabrelite/mx6qsabrelite.c @@ -30,6 +30,7 @@ #include <asm/gpio.h> #include <asm/imx-common/iomux-v3.h> #include <asm/imx-common/mxc_i2c.h> +#include <asm/imx-common/boot_mode.h> #include <mmc.h> #include <fsl_esdhc.h> #include <micrel.h> @@ -488,10 +489,23 @@ static void preboot_keys(void) } #endif
+#ifdef CONFIG_CMD_BMODE +static const struct boot_mode board_boot_modes[] = { + /* 4 bit bus width */ + {"mmc0", MAKE_CFGVAL(0x40, 0x30, 0x00, 0x00)}, + {"mmc1", MAKE_CFGVAL(0x40, 0x38, 0x00, 0x00)}, + {NULL, 0}, +}; +#endif + int misc_init_r(void) { #ifdef CONFIG_PREBOOT preboot_keys(); #endif + +#ifdef CONFIG_CMD_BMODE + add_board_boot_modes(board_boot_modes); +#endif return 0; } diff --git a/include/configs/mx6qsabrelite.h b/include/configs/mx6qsabrelite.h index 0d376ba..782abc8 100644 --- a/include/configs/mx6qsabrelite.h +++ b/include/configs/mx6qsabrelite.h @@ -117,6 +117,9 @@ #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #define CONFIG_MXC_USB_FLAGS 0
+/* Miscellaneous commands */ +#define CONFIG_CMD_BMODE + /* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE #define CONFIG_CONS_INDEX 1
This allows a watchdog reset to start the ROM's usb/serial downloader, or boot from an sdcard.
--- Compile tested only, I don't have a mx53evk. --- board/freescale/mx53evk/mx53evk.c | 13 +++++++++++++ include/configs/mx53evk.h | 3 +++ 2 files changed, 16 insertions(+)
diff --git a/board/freescale/mx53evk/mx53evk.c b/board/freescale/mx53evk/mx53evk.c index 8a6e31d..7f50938 100644 --- a/board/freescale/mx53evk/mx53evk.c +++ b/board/freescale/mx53evk/mx53evk.c @@ -28,6 +28,7 @@ #include <asm/arch/crm_regs.h> #include <asm/arch/iomux.h> #include <asm/errno.h> +#include <asm/imx-common/boot_mode.h> #include <netdev.h> #include <i2c.h> #include <mmc.h> @@ -367,11 +368,23 @@ int board_init(void) return 0; }
+#ifdef CONFIG_CMD_BMODE +static const struct boot_mode board_boot_modes[] = { + /* 4 bit bus width */ + {"mmc0", MAKE_CFGVAL(0x40, 0x20, 0x00, 0x12)}, + {"mmc1", MAKE_CFGVAL(0x40, 0x20, 0x08, 0x12)}, + {NULL, 0}, +}; +#endif + int board_late_init(void) { setup_i2c(1); power_init();
diff --git a/include/configs/mx53evk.h b/include/configs/mx53evk.h index 67def93..bfb9706 100644 --- a/include/configs/mx53evk.h +++ b/include/configs/mx53evk.h @@ -89,6 +89,9 @@ #define CONFIG_CMD_NET #define CONFIG_CMD_DATE
On 15/08/2012 22:31, Troy Kisky wrote:
Hi Troy,
I will test it before merging.
- Copyright (C) 2012 Boundary Devices Inc.
- project.
- MA 02111-1307 USA
- int i;
- for (i = 0; i < ARRAY_SIZE(modes); i++) {
if (p) {
while (p->name) {
return p;
p++;
- return NULL;
- int i;
- int size = 0;
if (p) {
while (p->name) {
if (dest) {
dest += len;
*dest++ = '|';
size += len + 1;
p++;
- if (dest)
- size += 10;
- return size;
- const struct boot_mode *p;
- int reset_requested = 1;
- if (argc < 2)
- p = search_modes(argv[1]);
- if (!p)
- if (argc == 3) {
- boot_mode_apply(p->cfg_val);
- if (reset_requested && p->cfg_val)
+U_BOOT_CMD(
- bmode, 3, 0, do_boot_mode,
- NULL,
- int size;
- char *dest;
- if (__u_boot_cmd_bmode.usage) {
- modes[0] = p;
- modes[1] = soc_boot_modes;
- size = create_usage(NULL);
- dest = malloc(size);
- if (dest) {
create_usage(dest);
- writel(cfg_val, &((struct srtc_regs *)SRTC_BASE_ADDR)->lpgr);
- cfg_val will be used for
- Boot_cfg3[7:0]:Boot_cfg2[7:0]:Boot_cfg1[7:0]
- If bit 28 of LPGR is set upon watchdog reset,
- bits[25:0] of LPGR will move to SBMR.
- {"normal", MAKE_CFGVAL(0x00, 0x00, 0x00, 0x00)},
- /* usb or serial download */
- {"usb", MAKE_CFGVAL(0x00, 0x00, 0x00, 0x13)},
- {"sata", MAKE_CFGVAL(0x28, 0x00, 0x00, 0x12)},
- {"escpi1:0", MAKE_CFGVAL(0x38, 0x20, 0x00, 0x12)},
- {"escpi1:1", MAKE_CFGVAL(0x38, 0x20, 0x04, 0x12)},
- {"escpi1:2", MAKE_CFGVAL(0x38, 0x20, 0x08, 0x12)},
- {"escpi1:3", MAKE_CFGVAL(0x38, 0x20, 0x0c, 0x12)},
- /* 4 bit bus width */
- {"esdhc1", MAKE_CFGVAL(0x40, 0x20, 0x00, 0x12)},
- {"esdhc2", MAKE_CFGVAL(0x40, 0x20, 0x08, 0x12)},
- {"esdhc3", MAKE_CFGVAL(0x40, 0x20, 0x10, 0x12)},
- {"esdhc4", MAKE_CFGVAL(0x40, 0x20, 0x18, 0x12)},
- {NULL, 0},
} #endif
- unsigned reg;
- struct src_regs *psrc = (struct src_regs *)SRC_BASE_ADDR;
- writel(cfg_val, &psrc->gpr9);
- reg = readl(&psrc->gpr10);
- if (cfg_val)
reg |= 1 << 28;
- else
reg &= ~(1 << 28);
- writel(reg, &psrc->gpr10);
- Boot_cfg4[7:0]:Boot_cfg3[7:0]:Boot_cfg2[7:0]:Boot_cfg1[7:0]
- After reset, if GPR10[28] is 1, ROM will copy GPR9[25:0]
- to SBMR1, which will determine the boot device.
- /* reserved value should start rom usb */
- {"usb", MAKE_CFGVAL(0x01, 0x00, 0x00, 0x00)},
- {"sata", MAKE_CFGVAL(0x20, 0x00, 0x00, 0x00)},
- {"escpi1:0", MAKE_CFGVAL(0x30, 0x00, 0x00, 0x08)},
- {"escpi1:1", MAKE_CFGVAL(0x30, 0x00, 0x00, 0x18)},
- {"escpi1:2", MAKE_CFGVAL(0x30, 0x00, 0x00, 0x28)},
- {"escpi1:3", MAKE_CFGVAL(0x30, 0x00, 0x00, 0x38)},
- {"esdhc1", MAKE_CFGVAL(0x40, 0x20, 0x00, 0x00)},
- {"esdhc2", MAKE_CFGVAL(0x40, 0x28, 0x00, 0x00)},
- {"esdhc3", MAKE_CFGVAL(0x40, 0x30, 0x00, 0x00)},
- {"esdhc4", MAKE_CFGVAL(0x40, 0x38, 0x00, 0x00)},
- {NULL, 0},
+struct srtc_regs {
- u32 lpscmr; /* 0x00 */
- u32 lpsclr; /* 0x04 */
- u32 lpsar; /* 0x08 */
- u32 lpsmcr; /* 0x0c */
- u32 lpcr; /* 0x10 */
- u32 lpsr; /* 0x14 */
- u32 lppdr; /* 0x18 */
- u32 lpgr; /* 0x1c */
- u32 hpcmr; /* 0x20 */
- u32 hpclr; /* 0x24 */
- u32 hpamr; /* 0x28 */
- u32 hpalr; /* 0x2c */
- u32 hpcr; /* 0x30 */
- u32 hpisr; /* 0x34 */
- u32 hpienr; /* 0x38 */
+struct src_regs {
- u32 scr; /* 0x00 */
- u32 sbmr1; /* 0x04 */
- u32 srsr; /* 0x08 */
- u32 reserved1; /* 0x0c */
- u32 reserved2; /* 0x10 */
- u32 sisr; /* 0x14 */
- u32 simr; /* 0x18 */
- u32 sbmr2; /* 0x1c */
- u32 gpr1; /* 0x20 */
- u32 gpr2; /* 0x24 */
- u32 gpr3; /* 0x28 */
- u32 gpr4; /* 0x2c */
- u32 gpr5; /* 0x30 */
- u32 gpr6; /* 0x34 */
- u32 gpr7; /* 0x38 */
- u32 gpr8; /* 0x3c */
- u32 gpr9; /* 0x40 */
- u32 gpr10; /* 0x44 */
- project.
- MA 02111-1307 USA
- ((cfg4) << 24) | ((cfg3) << 16) | ((cfg2) << 8) | (cfg1)
+struct boot_mode {
- const char *name;
- unsigned cfg_val;
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
- project.
- MA 02111-1307 USA
- int i;
if (p) {
while (p->name) {
return p;
p++;
- return NULL;
- int i;
- int size = 0;
if (p) {
while (p->name) {
if (dest) {
dest += len;
*dest++ = '|';
size += len + 1;
p++;
- if (dest)
- size += 10;
- return size;
- if (argc < 2)
- if (!p)
- if (argc == 3) {
+U_BOOT_CMD(
- NULL,
- int size;
- char *dest;
- modes[0] = p;
- if (dest) {
create_usage(dest);
- {NULL, 0},
} #endif
- unsigned reg;
- if (cfg_val)
reg |= 1 << 28;
- else
reg &= ~(1 << 28);
- {NULL, 0},
+struct srtc_regs {
+struct src_regs {
- project.
- MA 02111-1307 USA
+struct boot_mode {
- const char *name;
- unsigned cfg_val;
Applied (whole series) to u-boot-imx, thanks.
Stefano Babic
Troy Kisky
