Licensing discrepancies or ambiguities
I've been reviewing the copyright and license information for Das U-Boot in preparation for uploading to Debian, and found a few surprises.
tools/libfdt/fdt_rw.c: /* SPDX-License-Identifier: GPL-2.0+ BSD-2-Clause */
I *think* according to the SPDX spec this needs an OR or an AND. I also see no copyright declaration, although maybe there is a standard interpretation for this.
Similar issue with (though thankfully they include copyright declarations):
include/bloblist.h:/* SPDX-License-Identifier: GPL-2.0+ BSD-3-Clause */ common/bloblist.c:// SPDX-License-Identifier: GPL-2.0+ BSD-3-Clause doc/README.ubispl:# SPDX-License-Identifier: GPL 2.0+ BSD-3-Clause
This one has a non-existent license:
test/lib/strlcat.c: // SPDX-License-Identifier: GPL-2.1+
No such license exists, though thankfully it references the exact file in the original glibc sources it came from, which is listed as LGPL-2.1+.
There are certainly more ambiguous issues, but figured I would start with those!
live well, vagrant
This comes from the kernel and has been clarified there: // SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause)
Simon?
Should be an OR as well, yes, but it's also out of date and we could just delete if a problem.
Since you did the research would you mind sending the patch? Thanks.
That's much better! Thanks for looking into it! I suspect there are quite a few that get pulled in from linux or elsewhere that might have similar issues.
Simon?
Ok.
Will do eventually!
Also found some more ambiguous ones where the license text is in conflict with the SPDX identifiers:
arch/sandbox/cpu/u-boot-spl.lds-/* SPDX-License-Identifier: GPL-2.0+ */ arch/sandbox/cpu/u-boot-spl.lds-/* arch/sandbox/cpu/u-boot-spl.lds- * Copyright (c) 2011-2012 The Chromium OS Authors. arch/sandbox/cpu/u-boot-spl.lds: * Use of this source code is governed by a BSD-style license that can be arch/sandbox/cpu/u-boot-spl.lds- * found in the LICENSE file. arch/sandbox/cpu/u-boot-spl.lds- */
The referred to LICENSE file does not appear to exist in u-boot, and exactly what the text of this BSD-style license is ... a mystery.
And lib/zstd includes many entries in a similar situation:
lib/zstd/Makefile-# Copyright (c) Facebook, Inc. lib/zstd/Makefile-# All rights reserved. lib/zstd/Makefile-# lib/zstd/Makefile:# This source code is licensed under both the BSD-style license (found in the lib/zstd/Makefile-# LICENSE file in the root directory of this source tree) and the GPLv2 (found lib/zstd/Makefile-# in the COPYING file in the root directory of this source tree). lib/zstd/Makefile-# You may select, at your option, one of the above-listed licenses.
This seems like it would be "GPL-2.0 OR BSD-*something*", but it is unclear what BSD-style maps to, as the LICENSE file is not present where it claims.
Many similar discrepancies can be found with:
git grep -B4 -A3 'BSD-style'
I probably have mroe to dig up, but these are the ones that leapt out at me for now!
live well, vagrant
Simon?
Ok.
Will do eventually!
So, with my project maintainer hat on, U-Boot is essentially a GPLv2 project. We have a large amount of source code borrowed directly from the Linux Kernel and that is GPL-2.0 (and not or later), and today there's no feasible way to do not use that code. So everything in use must be something that is compatible with GPL-2.0, and anything with an incompatible license is worrisome and needs to be addressed.
In general, some of our inconsistencies should match the Linux Kernel (zstd is another one), and it might be best to file issues at https://source.denx.de/u-boot/u-boot/-/issues/ for these as you find them so that they can be tracked, if you aren't able to submit patches correcting them. There are a few cases, such as the sandbox one that are U-Boot specific and I assume can be fixed by the author once noted (and in that specific case I know Simon also likes issues to be filed).
Thanks again for looking in to these kind of issues, I appreciate it.
Vagrant Cascadian
