[PATCH v4] board/lx2160aqds: Update the DSPI status fixup
The dts node of the DSPI controller in kernel is spi instead of dspi, it is not correct if use "/soc/dspi@" to fix up the status of the dts in kernel, so, modify it to "/soc/spi@".
The DSPI2 and I2C5 are muxed, and the status of DSPI2 node in kernel dts default value is okay, So set the status of DSPI2 node in kernel dts to disabled if it is muxed as I2C5.
Signed-off-by: Xiaowei Bao xiaowei.bao@nxp.com --- v2: - Modify the subject and commit message. v3: - Modify the Copyright. v4: - Modify the commit message.
board/freescale/lx2160a/lx2160a.c | 14 ++++++++------ 1 file changed, 8 insertions(+), 6 deletions(-)
diff --git a/board/freescale/lx2160a/lx2160a.c b/board/freescale/lx2160a/lx2160a.c index eff5d9f..184e111 100644 --- a/board/freescale/lx2160a/lx2160a.c +++ b/board/freescale/lx2160a/lx2160a.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2018-2019 NXP + * Copyright 2018-2020 NXP */
#include <common.h> @@ -210,9 +210,9 @@ void esdhc_dspi_status_fixup(void *blob) { const char esdhc0_path[] = "/soc/esdhc@2140000"; const char esdhc1_path[] = "/soc/esdhc@2150000"; - const char dspi0_path[] = "/soc/dspi@2100000"; - const char dspi1_path[] = "/soc/dspi@2110000"; - const char dspi2_path[] = "/soc/dspi@2120000"; + const char dspi0_path[] = "/soc/spi@2100000"; + const char dspi1_path[] = "/soc/spi@2110000"; + const char dspi2_path[] = "/soc/spi@2120000";
struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); u32 sdhc1_base_pmux; @@ -262,10 +262,12 @@ void esdhc_dspi_status_fixup(void *blob) & FSL_CHASSIS3_IIC5_PMUX_MASK; iic5_pmux >>= FSL_CHASSIS3_IIC5_PMUX_SHIFT;
- if (iic5_pmux == IIC5_PMUX_SPI3) { + if (iic5_pmux == IIC5_PMUX_SPI3) do_fixup_by_path(blob, dspi2_path, "status", "okay", sizeof("okay"), 1); - } + else + do_fixup_by_path(blob, dspi2_path, "status", "disabled", + sizeof("disabled"), 1); } #endif
-----Original Message----- From: Xiaowei Bao xiaowei.bao@nxp.com Sent: Wednesday, January 8, 2020 12:00 PM To: Priyanka Jain priyanka.jain@nxp.com; u-boot@lists.denx.de Cc: Xiaowei Bao xiaowei.bao@nxp.com Subject: [PATCH v4] board/lx2160aqds: Update the DSPI status fixup
patch applied in u-boot-fsl-qoriq/master -priyankajain
Priyanka Jain
Xiaowei Bao
