[U-Boot] [PATCH v1] ddr, fsl: add DM_I2C support
add DM_I2C support for this driver.
Signed-off-by: Heiko Schocher hs@denx.de
Did not fixed checkpatch warning:
CHECK: Prefer kernel type 'u8' over 'uint8_t' + uint8_t buf = 0;
Travis build, see: https://travis-ci.org/hsdenx/u-boot-test/builds/558858904
drivers/ddr/fsl/main.c | 88 ++++++++++++++++++++++++++++++++++++------ 1 file changed, 77 insertions(+), 11 deletions(-)
diff --git a/drivers/ddr/fsl/main.c b/drivers/ddr/fsl/main.c index e1f69a1d25..cb19d0f0ff 100644 --- a/drivers/ddr/fsl/main.c +++ b/drivers/ddr/fsl/main.c @@ -10,6 +10,7 @@ */
#include <common.h> +#include <dm.h> #include <i2c.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr.h> @@ -82,17 +83,82 @@ u8 spd_i2c_addr[CONFIG_SYS_NUM_DDR_CTLRS][CONFIG_DIMM_SLOTS_PER_CTLR] = {
#endif
+#if defined(CONFIG_DM_I2C) +#define DEV_TYPE struct udevice +#else +/* Local udevice */ +struct ludevice { + u8 chip; +}; + +#define DEV_TYPE struct ludevice + +#endif + #define SPD_SPA0_ADDRESS 0x36 #define SPD_SPA1_ADDRESS 0x37
-static void __get_spd(generic_spd_eeprom_t *spd, u8 i2c_address) +static int ddr_i2c_read(DEV_TYPE *dev, unsigned int addr, + int alen, uint8_t *buf, int len) { int ret; + +#ifdef CONFIG_DM_I2C + ret = dm_i2c_read(dev, 0, buf, len); +#else + ret = i2c_read(dev->chip, addr, alen, buf, len); +#endif + + return ret; +} + #ifdef CONFIG_SYS_FSL_DDR4 - uint8_t dummy = 0; +static int ddr_i2c_dummy_write(unsigned int chip_addr) +{ + uint8_t buf = 0; + +#ifdef CONFIG_DM_I2C + struct udevice *dev; + int ret; + + ret = i2c_get_chip_for_busnum(CONFIG_SYS_SPD_BUS_NUM, i2c_address, + 1, &dev); + if (ret) { + printf("%s: Cannot find udev for a bus %d\n", __func__, + CONFIG_SYS_SPD_BUS_NUM); + return ret; + } + + return dm_i2c_write(dev, 0, buf, 1); +#else + return i2c_write(chip_addr, 0, 1, &buf, 1); #endif
+ return 0; +} +#endif + +static void __get_spd(generic_spd_eeprom_t *spd, u8 i2c_address) +{ + int ret; + DEV_TYPE *dev; + +#if defined(CONFIG_DM_I2C) + ret = i2c_get_chip_for_busnum(CONFIG_SYS_SPD_BUS_NUM, i2c_address, + 1, &dev); + if (ret) { + printf("%s: Cannot find udev for a bus %d\n", __func__, + CONFIG_SYS_SPD_BUS_NUM); + return; + } +#else /* Non DM I2C support - will be removed */ + struct ludevice ldev = { + .chip = i2c_address, + }; + dev = &ldev; + i2c_set_bus_num(CONFIG_SYS_SPD_BUS_NUM); +#endif
#ifdef CONFIG_SYS_FSL_DDR4 /* @@ -101,18 +167,18 @@ static void __get_spd(generic_spd_eeprom_t *spd, u8 i2c_address) * To access the upper 256 bytes, we need to set EE page address to 1 * See Jedec standar No. 21-C for detail */ - i2c_write(SPD_SPA0_ADDRESS, 0, 1, &dummy, 1); - ret = i2c_read(i2c_address, 0, 1, (uchar *)spd, 256); + ddr_i2c_dummy_write(SPD_SPA0_ADDRESS); + ret = ddr_i2c_read(dev, 0, 1, (uchar *)spd, 256); if (!ret) { - i2c_write(SPD_SPA1_ADDRESS, 0, 1, &dummy, 1); - ret = i2c_read(i2c_address, 0, 1, - (uchar *)((ulong)spd + 256), - min(256, - (int)sizeof(generic_spd_eeprom_t) - 256)); + ddr_i2c_dummy_write(SPD_SPA1_ADDRESS); + ret = ddr_i2c_read(dev, 0, 1, (uchar *)((ulong)spd + 256), + min(256, + (int)sizeof(generic_spd_eeprom_t) + - 256)); } #else - ret = i2c_read(i2c_address, 0, 1, (uchar *)spd, - sizeof(generic_spd_eeprom_t)); + ret = ddr_i2c_read(dev, 0, 1, (uchar *)spd, + sizeof(generic_spd_eeprom_t)); #endif
if (ret) {
Dear Heiko,
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Heiko Schocher Sent: Tuesday, July 16, 2019 9:29 AM To: u-boot@lists.denx.de Cc: York Sun york.sun@nxp.com Subject: [U-Boot] [PATCH v1] ddr, fsl: add DM_I2C support
uint8_t buf = 0;
Travis build, see: https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Ftravis -ci.org%2Fhsdenx%2Fu-boot- test%2Fbuilds%2F558858904&data=02%7C01%7Cprabhakar.kushwaha% 40nxp.com%7C2c5f1ecc6ff9417a8ccb08d709a20297%7C686ea1d3bc2b4c6fa92 cd99c5c301635%7C0%7C0%7C636988463754459178&sdata=H%2FkQV%2 Bavu2EfajG3El5M%2FsKyuSPO6Nn0QRMVpzsvsUY%3D&reserved=0
How you tested both NXP's powerpc and ARM platforms as fsl i2c is yet to move to DM model? Or my understanding is wrong.
--pk
Hello Prabhakar,
Am 22.08.2019 um 13:33 schrieb Prabhakar Kushwaha:
Dear Heiko,
uint8_t buf = 0;
I only tested on powerpc (preciser socrates_defconfig) platform ...
But I see that now in current mainline there is applied a change in drivers/ddr/fsl/main.c from commit:
commit 0eba65d2013e5517e70cc9b3d467ba8183b54cd9 Author: Chuanhua Han chuanhua.han@nxp.com Date: Wed Jul 10 21:00:20 2019 +0800
boards: lx2160a: Add support of I2C driver model
DM_I2C_COMPAT is a compatibility layer that allows using the non-DM I2C API when DM_I2C is used. When DM_I2C_COMPAT is not enabled for compilation, a compilation error will be generated. This patch solves the problem that the i2c-related api of the lx2160a platform does not support dm.
Signed-off-by: Chuanhua Han chuanhua.han@nxp.com Reviewed-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com
Which does some similiar change ... but I think this already applied patch introduces more ifdefs and code ...
Hmm.. just tried to compile U-Boot for the socrates board (with DM changes) without my patch ... I get compilererror:
/home/hs/data/Entwicklung/abb/uboot-rework/u-boot/drivers/ddr/fsl/main.c: In function '__get_spd': /home/hs/data/Entwicklung/abb/uboot-rework/u-boot/drivers/ddr/fsl/main.c:144:52: error: 'dev' undeclared (first use in this function) ret = i2c_get_chip_for_busnum(0, i2c_address, 1, &dev); ^~~ /home/hs/data/Entwicklung/abb/uboot-rework/u-boot/drivers/ddr/fsl/main.c:144:52: note: each undeclared identifier is reported only once for each function it appears in make[2]: *** [/home/hs/data/Entwicklung/abb/uboot-rework/u-boot/scripts/Makefile.build:278: drivers/ddr/fsl/main.o] Fehler 1 make[1]: *** [/home/hs/data/Entwicklung/abb/uboot-rework/u-boot/Makefile:1588: drivers/ddr/fsl] Fehler 2 make[1]: *** Es wird auf noch nicht beendete Prozesse gewartet.... CC drivers/i2c/fsl_i2c.o CC cmd/elf.o
Ok, fixed this fast and dirty with:
diff --git a/drivers/ddr/fsl/main.c b/drivers/ddr/fsl/main.c index ac0783b428..5f05a2c863 100644 --- a/drivers/ddr/fsl/main.c +++ b/drivers/ddr/fsl/main.c @@ -91,6 +91,7 @@ static void __get_spd(generic_spd_eeprom_t *spd, u8 i2c_address) #ifdef CONFIG_SYS_FSL_DDR4 uint8_t dummy = 0; #endif + struct udevice *dev;
#ifndef CONFIG_DM_I2C i2c_set_bus_num(CONFIG_SYS_SPD_BUS_NUM);
and now code compiles and after flashing U-Boot I see:
U-Boot 2019.10-rc2-00151-ge4b57b4557-dirty (Aug 26 2019 - 07:17:47 +0200)
CPU: 8544, Version: 2.1, (0x80340121) Core: e500, Version: 2.3, (0x80210023) Clock Configuration: CPU0:666.667 MHz, CCB:333.333 MHz, DDR:166.667 MHz (333.333 MT/s data rate), LBC:333.333 MHz L1: D-cache 32 KiB enabled I-cache 32 KiB enabled Model: abb,socrates Board: Socrates, serial# 1001321865 PCI1: 32 bit, 33 MHz (PCI_CLK) DRAM: Detected UDIMM MSC2S512M667C1-H 512 MiB (DDR2, 64-bit, CL=3, ECC off) Flash: 32 MiB L2: 256 KiB enabled NAND: 1024 MiB Loading Environment from Flash... OK In: serial Out: serial Err: serial Net: TSEC0, TSEC1 Hit any key to stop autoboot: 0 =>
So this works also for me ...
Hmm... the change from commit 0eba65d2013e5517e70cc9b3d467ba8183b54cd9 doubles code for DM and none DM case ... I don;t like this.
May you can look through my rebased patch [1] and may test it ?
If this is OK, I can send it as a v2.
bye, Heiko
[1] rebased patch From 0180ade1202d806db7b577230b240605e5ccea7e Mon Sep 17 00:00:00 2001 From: Heiko Schocher hs@denx.de Date: Mon, 26 Aug 2019 07:09:27 +0200 Subject: [PATCH] ddr, fsl: add DM_I2C support
Signed-off-by: Heiko Schocher hs@denx.de Patch-cc: York Sun york.sun@nxp.com Patch-cc: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Patch-cc: Chuanhua Han chuanhua.han@nxp.com
Series-to: uboot Series-version: 2
Commit-notes:
Travis build, see: END
Signed-off-by: Heiko Schocher hs@denx.de --- drivers/ddr/fsl/main.c | 119 +++++++++++++++++++++++++++++++------------------ 1 file changed, 76 insertions(+), 43 deletions(-)
diff --git a/drivers/ddr/fsl/main.c b/drivers/ddr/fsl/main.c index ac0783b428..a19041d799 100644 --- a/drivers/ddr/fsl/main.c +++ b/drivers/ddr/fsl/main.c @@ -10,6 +10,7 @@ */
#include <common.h> +#include <dm.h> #include <i2c.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr.h> @@ -82,20 +83,82 @@ u8 spd_i2c_addr[CONFIG_SYS_NUM_DDR_CTLRS][CONFIG_DIMM_SLOTS_PER_CTLR] = {
#endif
-#ifndef CONFIG_DM_I2C - i2c_set_bus_num(CONFIG_SYS_SPD_BUS_NUM); + return 0; +} #endif
+static void __get_spd(generic_spd_eeprom_t *spd, u8 i2c_address) +{ + int ret; + DEV_TYPE *dev; + +#if defined(CONFIG_DM_I2C) + ret = i2c_get_chip_for_busnum(CONFIG_SYS_SPD_BUS_NUM, i2c_address, + 1, &dev); + if (ret) { + printf("%s: Cannot find udev for a bus %d\n", __func__, + CONFIG_SYS_SPD_BUS_NUM); + return; + } +#else /* Non DM I2C support - will be removed */ + struct ludevice ldev = { + .chip = i2c_address, + }; + dev = &ldev; + + i2c_set_bus_num(CONFIG_SYS_SPD_BUS_NUM); +#endif
#ifdef CONFIG_SYS_FSL_DDR4 /* @@ -104,49 +167,19 @@ static void __get_spd(generic_spd_eeprom_t *spd, u8 i2c_address) * To access the upper 256 bytes, we need to set EE page address to 1 * See Jedec standar No. 21-C for detail */ -#ifndef CONFIG_DM_I2C - i2c_write(SPD_SPA0_ADDRESS, 0, 1, &dummy, 1); - ret = i2c_read(i2c_address, 0, 1, (uchar *)spd, 256); + ddr_i2c_dummy_write(SPD_SPA0_ADDRESS); + ret = ddr_i2c_read(dev, 0, 1, (uchar *)spd, 256); if (!ret) { - i2c_write(SPD_SPA1_ADDRESS, 0, 1, &dummy, 1); - ret = i2c_read(i2c_address, 0, 1, - (uchar *)((ulong)spd + 256), - min(256, - (int)sizeof(generic_spd_eeprom_t) - 256)); + ddr_i2c_dummy_write(SPD_SPA1_ADDRESS); + ret = ddr_i2c_read(dev, 0, 1, (uchar *)((ulong)spd + 256), + min(256, + (int)sizeof(generic_spd_eeprom_t) + - 256)); } -#else - struct udevice *dev; - int read_len = min(256, (int)sizeof(generic_spd_eeprom_t) - 256);
- ret = i2c_get_chip_for_busnum(0, SPD_SPA0_ADDRESS, 1, &dev); - if (!ret) - dm_i2c_write(dev, 0, &dummy, 1); - ret = i2c_get_chip_for_busnum(0, i2c_address, 1, &dev); - if (!ret) { - if (!dm_i2c_read(dev, 0, (uchar *)spd, 256)) { - if (!i2c_get_chip_for_busnum(0, SPD_SPA1_ADDRESS, - 1, &dev)) - dm_i2c_write(dev, 0, &dummy, 1); - if (!i2c_get_chip_for_busnum(0, i2c_address, 1, &dev)) - ret = dm_i2c_read(dev, 0, - (uchar *)((ulong)spd + 256), - read_len); - } - } -#endif - -#else - -#ifndef CONFIG_DM_I2C - ret = i2c_read(i2c_address, 0, 1, (uchar *)spd, - sizeof(generic_spd_eeprom_t)); #else - ret = i2c_get_chip_for_busnum(0, i2c_address, 1, &dev); - if (!ret) - ret = dm_i2c_read(dev, 0, (uchar *)spd, - sizeof(generic_spd_eeprom_t)); -#endif - + ret = ddr_i2c_read(dev, 0, 1, (uchar *)spd, + sizeof(generic_spd_eeprom_t)); #endif
if (ret) {
Dear Heiko,
-----Original Message----- From: Heiko Schocher hs@denx.de Sent: Monday, August 26, 2019 11:08 AM To: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Cc: u-boot@lists.denx.de; York Sun york.sun@nxp.com; Chuanhua Han chuanhua.han@nxp.com Subject: Re: [U-Boot] [PATCH v1] ddr, fsl: add DM_I2C support
Hello Prabhakar,
Dear Heiko,
uint8_t buf = 0;
Travis build, see: https://travis -ci.org%2Fhsdenx%2Fu-boot-
move to DM model?
DM_I2C_COMPAT is a compatibility layer that allows using the non-DM I2C API when DM_I2C is used. When DM_I2C_COMPAT is not enabled for compilation, a compilation error will be generated. This patch solves the problem that the i2c-related api of the lx2160a platform does not support dm. Signed-off-by: Chuanhua Han <chuanhua.han@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
/home/hs/data/Entwicklung/abb/uboot-rework/u-boot/drivers/ddr/fsl/main.c: In function '__get_spd': /home/hs/data/Entwicklung/abb/uboot-rework/u- boot/drivers/ddr/fsl/main.c:144:52: error: 'dev' undeclared (first use in this function) ret = i2c_get_chip_for_busnum(0, i2c_address, 1, &dev); ^~~ /home/hs/data/Entwicklung/abb/uboot-rework/u- boot/drivers/ddr/fsl/main.c:144:52: note: each undeclared identifier is reported only once for each function it appears in make[2]: *** [/home/hs/data/Entwicklung/abb/uboot-rework/u- boot/scripts/Makefile.build:278: drivers/ddr/fsl/main.o] Fehler 1 make[1]: *** [/home/hs/data/Entwicklung/abb/uboot-rework/u- boot/Makefile:1588: drivers/ddr/fsl] Fehler 2 make[1]: *** Es wird auf noch nicht beendete Prozesse gewartet.... CC drivers/i2c/fsl_i2c.o CC cmd/elf.o
My bad. I only tested build/run on NXP's ARM platforms. As I am working on PowerPC pull request, I missed it.
bye, Heiko
Commit-notes:
uint8_t buf = 0;
Please send v2 version. I will test on both ARM and PowerPC platforms And also get reviewed from internal IP owners . .
--pk
Hello Prabhakar,
Am 26.08.2019 um 10:11 schrieb Prabhakar Kushwaha:
Dear Heiko,
Hello Prabhakar,
Dear Heiko,
uint8_t buf = 0;
move to DM model?
bye, Heiko
Commit-notes:
uint8_t buf = 0;
Ok, started travis build, if it is fine, I send the v2.
bye, Heiko
Heiko Schocher
Prabhakar Kushwaha
