[U-Boot] [PATCH v2 0/3] Convert fdtdec_setup_memory_banksize() to use livetree
As requested while reviewing 452bc121027d ("fdt: fix fdtdec_setup_memory_banksize()") heres a patch set converting fdtdec_setup_memory_banksize() to use livetree.
v2: * Added test code for the new function ofnode_by_prop_value() * The patch "fdt: fdtdec_setup_memory_banksize() use livetree": Reviewed-by: Simon Glass sjg@chromium.org
Thanks, Jens
Jens Wiklander (3): ofnode: add ofnode_by_prop_value() fdt: fdtdec_setup_memory_banksize() use livetree test: ofnode: test ofnode_by_prop_value()
drivers/core/of_access.c | 27 +++++++++++++++++++++++ drivers/core/ofnode.c | 14 ++++++++++++ include/dm/of_access.h | 16 ++++++++++++++ include/dm/ofnode.h | 14 ++++++++++++ lib/fdtdec.c | 46 ++++++++++++++++++---------------------- test/dm/ofnode.c | 27 +++++++++++++++++++++++ 6 files changed, 119 insertions(+), 25 deletions(-)
Adds ofnode_by_prop_value() to search for nodes with a given property and value, an ofnode version of fdt_node_offset_by_prop_value().
Signed-off-by: Jens Wiklander jens.wiklander@linaro.org --- drivers/core/of_access.c | 27 +++++++++++++++++++++++++++ drivers/core/ofnode.c | 14 ++++++++++++++ include/dm/of_access.h | 16 ++++++++++++++++ include/dm/ofnode.h | 14 ++++++++++++++ 4 files changed, 71 insertions(+)
diff --git a/drivers/core/of_access.c b/drivers/core/of_access.c index 0729dfcdb3b8..14c020a687b7 100644 --- a/drivers/core/of_access.c +++ b/drivers/core/of_access.c @@ -376,6 +376,33 @@ struct device_node *of_find_compatible_node(struct device_node *from, return np; }
+static int of_device_has_prop_value(const struct device_node *device, + const char *propname, const void *propval, + int proplen) +{ + struct property *prop = of_find_property(device, propname, NULL); + + if (!prop || !prop->value || prop->length != proplen) + return 0; + return !memcmp(prop->value, propval, proplen); +} + +struct device_node *of_find_node_by_prop_value(struct device_node *from, + const char *propname, + const void *propval, int proplen) +{ + struct device_node *np; + + for_each_of_allnodes_from(from, np) { + if (of_device_has_prop_value(np, propname, propval, proplen) && + of_node_get(np)) + break; + } + of_node_put(from); + + return np; +} + struct device_node *of_find_node_by_phandle(phandle handle) { struct device_node *np; diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index 0cfb0fbabb00..a7e192772324 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -777,3 +777,17 @@ ofnode ofnode_by_compatible(ofnode from, const char *compat) gd->fdt_blob, ofnode_to_offset(from), compat)); } } + +ofnode ofnode_by_prop_value(ofnode from, const char *propname, + const void *propval, int proplen) +{ + if (of_live_active()) { + return np_to_ofnode(of_find_node_by_prop_value( + (struct device_node *)ofnode_to_np(from), propname, + propval, proplen)); + } else { + return offset_to_ofnode(fdt_node_offset_by_prop_value( + gd->fdt_blob, ofnode_to_offset(from), + propname, propval, proplen)); + } +} diff --git a/include/dm/of_access.h b/include/dm/of_access.h index dd1abb8e97b4..5ed1a0cdb427 100644 --- a/include/dm/of_access.h +++ b/include/dm/of_access.h @@ -193,6 +193,22 @@ static inline struct device_node *of_find_node_by_path(const char *path) struct device_node *of_find_compatible_node(struct device_node *from, const char *type, const char *compatible);
+/** + * of_find_node_by_prop_value() - find a node with a given property value + * + * Find a node based on a property value. + * @from: Node to start searching from or NULL. the node you pass will not be + * searched, only the next one will; typically, you pass what the previous + * call returned. + * @propname: property name to check + * @propval: property value to search for + * @proplen: length of the value in propval + * @return node pointer or NULL if not found + */ +struct device_node *of_find_node_by_prop_value(struct device_node *from, + const char *propname, + const void *propval, + int proplen); /** * of_find_node_by_phandle() - Find a node given a phandle * diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index ab36b74c4ca4..c06d77849c73 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -702,6 +702,20 @@ int ofnode_read_resource_byname(ofnode node, const char *name, */ ofnode ofnode_by_compatible(ofnode from, const char *compat);
+/** + * ofnode_by_prop_value() - Find the next node with given property value + * + * Find the next node after @from that has a @propname with a value + * @propval and a length @proplen. + * + * @from: ofnode to start from (use ofnode_null() to start at the + * beginning) @propname: property name to check @propval: property value to + * search for @proplen: length of the value in propval @return ofnode + * found, or ofnode_null() if none + */ +ofnode ofnode_by_prop_value(ofnode from, const char *propname, + const void *propval, int proplen); + /** * ofnode_for_each_subnode() - iterate over all subnodes of a parent *
Applied to u-boot-dm, and now in mainline, thanks!
Converts fdtdec_setup_memory_banksize() to use ofnode functions instead.
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Jens Wiklander jens.wiklander@linaro.org --- lib/fdtdec.c | 46 +++++++++++++++++++++------------------------- 1 file changed, 21 insertions(+), 25 deletions(-)
diff --git a/lib/fdtdec.c b/lib/fdtdec.c index a208589c48ae..fef2f88f9d10 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -16,6 +16,7 @@ #include <serial.h> #include <asm/sections.h> #include <linux/ctype.h> +#include <linux/ioport.h> #include <linux/lzo.h>
DECLARE_GLOBAL_DATA_PTR; @@ -1182,43 +1183,34 @@ int fdtdec_setup_mem_size_base(void)
#if defined(CONFIG_NR_DRAM_BANKS)
-static int get_next_memory_node(const void *blob, int startoffset) +static ofnode get_next_memory_node(ofnode mem) { - int mem = -1; - do { - mem = fdt_node_offset_by_prop_value(gd->fdt_blob, mem, - "device_type", "memory", 7); - } while (!fdtdec_get_is_enabled(blob, mem)); + mem = ofnode_by_prop_value(mem, "device_type", "memory", 7); + } while (ofnode_valid(mem) && !ofnode_is_available(mem));
return mem; }
int fdtdec_setup_memory_banksize(void) { - int bank, ret, mem, reg = 0; - struct fdt_resource res; + int bank, reg = 0; + struct resource res; + ofnode mem;
- mem = get_next_memory_node(gd->fdt_blob, -1); - if (mem < 0) { - debug("%s: Missing /memory node\n", __func__); - return -EINVAL; - } + mem = get_next_memory_node(ofnode_null()); + if (!ofnode_valid(mem)) + goto missing_node;
for (bank = 0; bank < CONFIG_NR_DRAM_BANKS; bank++) { - ret = fdt_get_resource(gd->fdt_blob, mem, "reg", reg++, &res); - if (ret == -FDT_ERR_NOTFOUND) { + while (ofnode_read_resource(mem, reg++, &res)) { reg = 0; - mem = get_next_memory_node(gd->fdt_blob, mem); - if (mem == -FDT_ERR_NOTFOUND) - break; - - ret = fdt_get_resource(gd->fdt_blob, mem, "reg", reg++, &res); - if (ret == -FDT_ERR_NOTFOUND) - break; - } - if (ret != 0) { - return -EINVAL; + mem = get_next_memory_node(mem); + if (!ofnode_valid(mem)) { + if (bank) + return 0; + goto missing_node; + } }
gd->bd->bi_dram[bank].start = (phys_addr_t)res.start; @@ -1232,6 +1224,10 @@ int fdtdec_setup_memory_banksize(void) }
return 0; + +missing_node: + debug("%s: Missing /memory node\n", __func__); + return -EINVAL; } #endif
Test ofnode_by_prop_value()
Signed-off-by: Jens Wiklander jens.wiklander@linaro.org --- test/dm/ofnode.c | 27 +++++++++++++++++++++++++++ 1 file changed, 27 insertions(+)
diff --git a/test/dm/ofnode.c b/test/dm/ofnode.c index 8db1f9857f7d..907d1ddbdb6f 100644 --- a/test/dm/ofnode.c +++ b/test/dm/ofnode.c @@ -15,3 +15,30 @@ static int dm_test_ofnode_compatible(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_ofnode_compatible, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +static int dm_test_ofnode_by_prop_value(struct unit_test_state *uts) +{ + const char propname[] = "compatible"; + const char propval[] = "denx,u-boot-fdt-test"; + const char *str; + ofnode node = ofnode_null(); + + /* Find first matching node, there should be at least one */ + node = ofnode_by_prop_value(node, propname, propval, sizeof(propval)); + ut_assert(ofnode_valid(node)); + str = ofnode_read_string(node, propname); + ut_assert(str && !strcmp(str, propval)); + + /* Find the rest of the matching nodes */ + while (true) { + node = ofnode_by_prop_value(node, propname, propval, + sizeof(propval)); + if (!ofnode_valid(node)) + break; + str = ofnode_read_string(node, propname); + ut_assert(str && !strcmp(str, propval)); + } + + return 0; +} +DM_TEST(dm_test_ofnode_by_prop_value, DM_TESTF_SCAN_FDT);
Thanks
Thanks
Jens Wiklander
