[PATCH v3] arm: xea: Modify board code to generate single binary u-boot
This change provides the possibility to build XEA (imx287 based) board U-Boot as a single binary (without support for CONFIG_SPL_FRAMEWORK).
The generated u-boot.sb can be used in the factory environment to for example perform initial setup or HW testing.
It can be used with 'uuu' utility (SDPS: boot -f /srv/tftp/xea/u-boot.sb)
In the configs/imx28_xea_defconfig one needs to disable following configs: # CONFIG_SPL_BLK is not set # CONFIG_SPL_FRAMEWORK is not set
The board_init_ll() is used in arch/arm/cpu/arm926ejs/mxs/start.S, which is utilized when CONFIG_SPL_FRAMEWORK is disabled.
However, when it is enabled - the arch/arm/cpu/arm926ejs/start.S is used, which requires the lowlevel_init() function.
Signed-off-by: Lukasz Majewski lukma@denx.de
Changes in v3: - Use just #ifdef for CONFIG_SPL_BUILD and CONFIG_SPL_FRAMEWORK as those two are some kind of a special defines for low level code
Changes in v2: - Use CONFIG_IS_ENABLED(FRAMEWORK) instead of #ifdef CONFIG_SPL_FRAMEWORK (previous version used CONFIG_IS_ENABLED(SPL_FRAMEWORK), which was wrong). - Restructure spl_xea.c code to be more readable
board/liebherr/xea/spl_xea.c | 7 +++++++ board/liebherr/xea/xea.c | 2 +- 2 files changed, 8 insertions(+), 1 deletion(-)
diff --git a/board/liebherr/xea/spl_xea.c b/board/liebherr/xea/spl_xea.c index 192f68fca5..df354cac64 100644 --- a/board/liebherr/xea/spl_xea.c +++ b/board/liebherr/xea/spl_xea.c @@ -290,6 +290,12 @@ u32 mxs_dram_vals[] = { 0x00000000, 0xffffffff };
+#ifndef CONFIG_SPL_FRAMEWORK +void board_init_ll(const u32 arg, const uint32_t *resptr) +{ + mxs_common_spl_init(arg, resptr, iomux_setup, ARRAY_SIZE(iomux_setup)); +} +#else void lowlevel_init(void) { struct mxs_pinctrl_regs *pinctrl_regs = @@ -301,3 +307,4 @@ void lowlevel_init(void)
mxs_common_spl_init(0, NULL, iomux_setup, ARRAY_SIZE(iomux_setup)); } +#endif diff --git a/board/liebherr/xea/xea.c b/board/liebherr/xea/xea.c index cd11b0ada7..38e841c5f6 100644 --- a/board/liebherr/xea/xea.c +++ b/board/liebherr/xea/xea.c @@ -58,7 +58,7 @@ static void init_clocks(void) mxs_set_sspclk(MXC_SSPCLK3, 96000, 0); }
-#ifdef CONFIG_SPL_BUILD +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_FRAMEWORK) void board_init_f(ulong arg) { init_clocks();
This change provides the possibility to build XEA (imx287 based) board U-Boot as a single binary (without support for CONFIG_SPL_FRAMEWORK). The generated u-boot.sb can be used in the factory environment to for example perform initial setup or HW testing. It can be used with 'uuu' utility (SDPS: boot -f /srv/tftp/xea/u-boot.sb) In the configs/imx28_xea_defconfig one needs to disable following configs: # CONFIG_SPL_BLK is not set # CONFIG_SPL_FRAMEWORK is not set The board_init_ll() is used in arch/arm/cpu/arm926ejs/mxs/start.S, which is utilized when CONFIG_SPL_FRAMEWORK is disabled. However, when it is enabled - the arch/arm/cpu/arm926ejs/start.S is used, which requires the lowlevel_init() function. Signed-off-by: Lukasz Majewski lukma@denx.de
Best regards, Stefano Babic
Lukasz Majewski
sbabic@denx.de
