[PATCH 1/1] dm: fix misleading messages
When no RNG device exists for a driver referenced via U_BOOT_DRVINFO() we get messages like:
No match for driver 'arm-rndr' Some drivers were not found
This is misleading as it is not the driver that was not found, it is the device that is not found. Correct the messages.
Reported-by: Andre Przywara andre.przywara@arm.com Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- drivers/core/lists.c | 2 +- drivers/core/root.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/core/lists.c b/drivers/core/lists.c index 8034a8f48d..e39d3acc97 100644 --- a/drivers/core/lists.c +++ b/drivers/core/lists.c @@ -97,7 +97,7 @@ static int bind_drivers_pass(struct udevice *parent, bool pre_reloc_only) if (CONFIG_IS_ENABLED(OF_PLATDATA)) drt->dev = dev; } else if (ret != -EPERM) { - dm_warn("No match for driver '%s'\n", entry->name); + dm_warn("No device for driver '%s'\n", entry->name); if (!result || ret != -ENOENT) result = ret; } diff --git a/drivers/core/root.c b/drivers/core/root.c index d4ae652bcf..29c918eb73 100644 --- a/drivers/core/root.c +++ b/drivers/core/root.c @@ -167,7 +167,7 @@ int dm_scan_plat(bool pre_reloc_only)
ret = lists_bind_drivers(DM_ROOT_NON_CONST, pre_reloc_only); if (ret == -ENOENT) { - dm_warn("Some drivers were not found\n"); + dm_warn("Some devices were not found\n"); ret = 0; }
Hi Heinrich,
On Sat, 4 Nov 2023 at 18:47, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
This should be "No match for driver_info"
It is not a device
Some driver_infos were not found
They are not devices
ret = 0; }
-- 2.40.1
Also please add a Fixes tag, I think for this:
20e442ab2df dm: Rename U_BOOT_DEVICE() to U_BOOT_DRVINFO()
On 11/4/23 21:45, Simon Glass wrote:
Hi Heinrich,
It is not a device
This suggestion does not match the case that Andre and I were discussing in
https://lore.kernel.org/u-boot/1ad4bd2c-e667-42b6-b637-8816a6c60d94@canonica...
U_BOOT_DRVINFO(cpu_arm_rndr) is triggering the arm-rndr driver's bind method. The bind method returns -ENOENT if there is no matching device.
Neither the driver U_BOOT_DRIVER(arm_rndr) nor the driver info U_BOOT_DRVINFO(cpu_arm_rndr) is missing. It is the non-existence of a matching device that triggers the messages.
Best regards
Heinrich
ret = 0; }
-- 2.40.1
Hi Heinrich,
On Sat, 4 Nov 2023 at 20:00, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Hi Heinrich,
It is not a device
There are various errors which can be returned.
Then perhaps for that specific -ENOENT code you could indicate that the device was matched but refused to bind? We just need to avoid confusing language, although of course what is there is confusing too.
As mentioned to Andrew, we should not be using DRVINFO records outside SPL.
Best regards
Heinrich
ret = 0; }
-- 2.40.1
