[RFC PATCH v1] arm: lib: add __gnu_thumb1_case_si
The assembly for __gnu_thumb1_case_si was taken from upstream gcc and adapted as width suffix was removed for the add instruction [1].
Signed-off-by: Francis Laniel francis.laniel@amarulasolutions.com Tested-by: Tony Dinh mibodhi@gmail.com [1] https://github.com/gcc-mirror/gcc/blob/4f181f9c7ee3efc509d185fdfda33be9018f1... --- arch/arm/lib/lib1funcs.S | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/arch/arm/lib/lib1funcs.S b/arch/arm/lib/lib1funcs.S index 7ff4446dd6..79cedc0aad 100644 --- a/arch/arm/lib/lib1funcs.S +++ b/arch/arm/lib/lib1funcs.S @@ -424,4 +424,21 @@ ENTRY(__gnu_thumb1_case_uhi) ret lr ENDPROC(__gnu_thumb1_case_uhi) .popsection + +/* Taken and adapted from: https://github.com/gcc-mirror/gcc/blob/4f181f9c7ee3efc509d185fdfda33be9018f1... */ +.pushsection .text.__gnu_thumb1_case_si, "ax" +ENTRY(__gnu_thumb1_case_si) + push {r0, r1} + mov r1, lr + adds r1, r1, #2 /* Align to word. */ + lsrs r1, r1, #2 + lsls r0, r0, #2 + lsls r1, r1, #2 + ldr r0, [r1, r0] + adds r0, r0, r1 + mov lr, r0 + pop {r0, r1} + mov pc, lr /* We know we were called from thumb code. */ +ENDPROC(__gnu_thumb1_case_si) +.popsection #endif -- 2.34.1
Hi Francis,
On Sat, Apr 1, 2023 at 2:55 PM Francis Laniel francis.laniel@amarulasolutions.com wrote:
Thanks for the patch! I've added Tom, Pali, and Stefan.
I think we need to do some more testing for other boards that have CONFIG_HAS_THUMB2 and CONFIG_SPL_SYS_THUMB_BUILD. My test target (Marvell Armada 385 SoC) is somewhat broken right now. So it will take some time for me to get that back running to run this test.
All the best, Tony
push {r0, r1}
mov r1, lr
lsrs r1, r1, #2
lsls r0, r0, #2
lsls r1, r1, #2
ldr r0, [r1, r0]
adds r0, r0, r1
mov lr, r0
pop {r0, r1}
#endif
2.34.1
On Saturday 01 April 2023 15:17:59 Tony Dinh wrote:
Hi Francis,
Looks good,
Acked-by: Pali Rohár pali@kernel.org
All the best, Tony
push {r0, r1}
mov r1, lr
lsrs r1, r1, #2
lsls r0, r0, #2
lsls r1, r1, #2
ldr r0, [r1, r0]
adds r0, r0, r1
mov lr, r0
pop {r0, r1}
#endif
2.34.1
Hi Francis,
Hi Francis,
Looks good,
I've done some more testing with other boards. I'm seeing some problems with LTO in gcc-12, but it is not related to this patch.
Acked-by: Tony Dinh mibodhi@gmail.com
Thanks, Tony
All the best, Tony
push {r0, r1}
mov r1, lr
lsrs r1, r1, #2
lsls r0, r0, #2
lsls r1, r1, #2
ldr r0, [r1, r0]
adds r0, r0, r1
mov lr, r0
pop {r0, r1}
#endif
2.34.1
Signed-off-by: Francis Laniel francis.laniel@amarulasolutions.com Tested-by: Tony Dinh mibodhi@gmail.com [1] https://github.com/gcc-mirror/gcc/blob/4f181f9c7ee3efc509d185fdfda33be9018f1... Acked-by: Pali Rohár pali@kernel.org Acked-by: Tony Dinh mibodhi@gmail.com
Signed-off-by: Francis Laniel francis.laniel@amarulasolutions.com Tested-by: Tony Dinh mibodhi@gmail.com [1] https://github.com/gcc-mirror/gcc/blob/4f181f9c7ee3efc509d185fdfda33be901 8f1611/libgcc/config/arm/lib1funcs.S#L2156 Acked-by: Pali Rohár pali@kernel.org Acked-by: Tony Dinh mibodhi@gmail.com
Thank you for the merge!
Francis Laniel
Pali Rohár
Tony Dinh
