[PATCH 1/2] dm: dump.c: Fix segfault when entry->of_match is NULL
Currently, dm drivers command produces a segfault: => dm drivers Driver Compatible -------------------------------- Segmentation fault (core dumped)
This is caused by a NULL pointer dereference of entry->of_match. Add a check to prevent this.
Signed-off-by: Ovidiu Panait ovpanait@gmail.com Cc: Sean Anderson seanga2@gmail.com Cc: Simon Glass sjg@chromium.org --- drivers/core/dump.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/core/dump.c b/drivers/core/dump.c index e73ebeabcc..b5046398d4 100644 --- a/drivers/core/dump.c +++ b/drivers/core/dump.c @@ -107,7 +107,8 @@ void dm_dump_drivers(void) puts("Driver Compatible\n"); puts("--------------------------------\n"); for (entry = d; entry < d + n_ents; entry++) { - for (match = entry->of_match; match->compatible; match++) + for (match = entry->of_match; + match && match->compatible; match++) printf("%-20.20s %s\n", match == entry->of_match ? entry->name : "", match->compatible);
Refactor the printing sequence in dm_dump_drivers to make it more clear.
Signed-off-by: Ovidiu Panait ovpanait@gmail.com Cc: Sean Anderson seanga2@gmail.com Cc: Simon Glass sjg@chromium.org --- drivers/core/dump.c | 18 +++++++++++------- 1 file changed, 11 insertions(+), 7 deletions(-)
diff --git a/drivers/core/dump.c b/drivers/core/dump.c index b5046398d4..cb8a25b9ad 100644 --- a/drivers/core/dump.c +++ b/drivers/core/dump.c @@ -107,12 +107,16 @@ void dm_dump_drivers(void) puts("Driver Compatible\n"); puts("--------------------------------\n"); for (entry = d; entry < d + n_ents; entry++) { - for (match = entry->of_match; - match && match->compatible; match++) - printf("%-20.20s %s\n", - match == entry->of_match ? entry->name : "", - match->compatible); - if (match == entry->of_match) - printf("%-20.20s\n", entry->name); + match = entry->of_match; + + printf("%-20.20s", entry->name); + if (match) { + printf(" %s", match->compatible); + match++; + } + printf("\n"); + + for (; match && match->compatible; match++) + printf("%-20.20s %s\n", "", match->compatible); } }
Applied to u-boot-dm, thanks!
This should have been fixed in version 3 of the original patch [1]. Did it not get merged properly? This is the second time I've been CC'd by someone who wants to fix this.
[1] https://patchwork.ozlabs.org/patch/1234460/
--Sean
Yes, it seems that an older version of the patch was merged:
https://github.com/u-boot/u-boot/commit/7b9d60fc1ff67b3959a7db394084b27268a7...
Ovidiu
--Sean
OK, so can someone do a fixup patch for this?
Ovidiu Panait
Sean Anderson
sjg@google.com
