[U-Boot] NAND flash filesystems broken
I am working on a bootloader with NAND support but have been running into problems with the various flash filesystems on a board with a 4GB NAND device.
We are using Linux 2.6.32-27 with the latest YAFFS2 filesystem installed. Additionally I have the UBIFS tools version 1.1 (latest) installed.
While both UBIFS and YAFFS2 seem to work fine in Linux, both filesystems seem to have problems in U-Boot. We are currently using U-Boot 2011.03 but with all of the latest patches applied to the NAND support and all of the filesystems.
We are using the standard U-Boot software ECC support for the NAND flash. We have our own hardware ECC format but we only use this for our stage 1 NAND bootloader and for storing U-Boot at the beginning of the NAND device.
I have enabled CONFIG_MTD_NAND_ECC_YAFFS and CONFIG_MTD_NAND_ECC_JFFS2 since JFFS2, YAFFS2 and UBIFS are all enabled.
The YAFFS2 code in U-Boot seems to be rather broken. I had to disable all of the list support in devextras.h, for example, to get it to compile. It also looks to be incomplete since there is no command-line help for any of the commands. YAFFS2 also appears to not to support MTD partitioning since it looks like it only works with a bare NAND device.
UBIFS appears to be out of date and is incompatible with what is written by the Linux kernel. I am unable to mount any UBIFS volumes created by Linux.
JFFS2 also is problematic. First of all it does not scale, but additionally it seems to have other problems. For example, if in Linux a file is deleted and then re-added (i.e. updating a Linux kernel) then the file is displayed twice and U-Boot appears to read the first copy of the file.
I'm wondering if anyone else has experienced this problems or has any suggestions? At this point it looks like I will need to port a more recent version of UBIFS or YAFFS2 to U-Boot. With YAFFS2 I would also need to make it work with the MTD partitioning.
Any suggestions or comments are welcome.
-Aaron
Aaron Williams
