[U-Boot] [PATCH] colibri_t30: fix usb ethernet functionality
Since commit aa7a648747d8c704a9a81c9e493d386930724e9d ("net: Stop including NFS overhead in defragment max") the following has been reproducibly observed while trying to transfer data over TFTP:
Load address: 0x80408000 Loading: EHCI timed out on TD - token=0x8008d80 T EHCI timed out on TD - token=0x88008d80 Rx: failed to receive: -5
This patch fixes this by upping our maximal de-fragmentation aka IP packet size again.
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
include/configs/colibri_t30.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/colibri_t30.h b/include/configs/colibri_t30.h index fbb235d..3431cde 100644 --- a/include/configs/colibri_t30.h +++ b/include/configs/colibri_t30.h @@ -48,6 +48,7 @@
/* General networking support */ #define CONFIG_IP_DEFRAG +#define CONFIG_NET_MAXDEFRAG (16384 + 4096 + 24) #define CONFIG_TFTP_BLOCKSIZE 16384 #define CONFIG_TFTP_TSIZE
Hi Marcel,
On Fri, Sep 9, 2016 at 9:20 PM, Marcel Ziswiler marcel.ziswiler@toradex.com wrote:
I suspect this is more than you need, right? You are using TFTP, not NFS. You probably only need an extra 34 bytes.
You could also just reduce this by 34 bytes.
-- 2.5.5
Applied, thanks . If you need to rectify this further based on Joe's feedback, please do, but I want this fixed before the release.
diff --git a/include/configs/colibri_t30.h b/include/configs/colibri_t30.h index fbb235d..3431cde 100644 --- a/include/configs/colibri_t30.h +++ b/include/configs/colibri_t30.h @@ -48,6 +48,7 @@ /* General networking support */ #define CONFIG_IP_DEFRAG +#define CONFIG_NET_MAXDEFRAG (16384 + 4096 + 24) #define CONFIG_TFTP_BLOCKSIZE 16384 #define CONFIG_TFTP_TSIZE
Unfortunately the release already happened. Nevertheless I will send an updated version 2 ASAP which fixes all of our boards currently exhibiting this issue the way Joe suggested.
Please base that on top of u-boot-usb/master , I already applied V1 . Me and Tom agreed this is not critical enough to wrap it into release.
Joe Hershberger
Marcel Ziswiler
