[U-Boot] [GIT PULL] Xilinx changes for v2018.07-rc2
Hi Tom,
please pull these changes to your tree. Buildman and travis looks good https://travis-ci.org/michalsimek/u-boot/builds/392586380
Thanks, Michal
The following changes since commit 606fddd76c7a045c09d544357806b0b4de4845c7:
Merge branch 'master' of git://git.denx.de/u-boot-net (2018-06-14 07:20:41 -0400)
git://www.denx.de/git/u-boot-microblaze.git tags/xilinx-for-v2018.07-rc2
for you to fetch changes up to b729ed0d95415bd694a6b67c0761f03ef5a1e2bc:
serial: zynq: Make zynq_serial_setbrg static (2018-06-15 08:54:05 +0200)
---------------------------------------------------------------- Xilinx fixes for v2018.07-rc2
Zynq: - Fix missing watchdog header - DT fixes
ZynqMP: - emmc configuration split - Enable SPD - Fix PMUFW_INIT_FILE logic - Coverity fixes in SoC code
timer - Add timer_get_boot_us
mmc: - Fix MMC HS200 tuning command
serial: - Fix scrabled chars with OF_LIVE
---------------------------------------------------------------- Luca Ceresoli (1): arm64: zynqmp: accept an absolute path for PMUFW_INIT_FILE
Michal Simek (13): arm: zynq: Add missing watchdog header arm: zynq: Drop #address-cells and #size-cells from gpio-keys timer: cadence: Implement timer_get_boot_us arm64: zynqmp: Enable SPD ddr support for zcu102 targets gpio: zynq: Do not check unsigned type that is >= 0 mmc: zynq: Fix tuning_loop_counter type in arasan_sdhci_execute_tuning() arm64: zynqmp: Check return value from calloc arm64: zynqmp: Check return value in zynqmp_mmio_rawwrite() gpio: zynq_gpio: bank description should use unsigned type serial: zynq: Use BIT macros instead of shifts and full hex numbers serial: zynq: Write chars till output fifo is full serial: zynq: Initialize uart only before relocation serial: zynq: Make zynq_serial_setbrg static
Siva Durga Prasad Paladugu (2): arm64: zynqmp: Split emmc configuration into emmc0 and emmc1 mmc: sdhci: Fix MMC HS200 tuning command failures
arch/arm/cpu/armv8/zynqmp/cpu.c | 6 +++++- arch/arm/dts/Makefile | 3 ++- arch/arm/dts/zynq-zc702.dts | 2 -- arch/arm/dts/zynq-zturn.dts | 2 -- arch/arm/dts/{zynqmp-mini-emmc.dts => zynqmp-mini-emmc0.dts} | 20 ++++++-------------- arch/arm/dts/zynqmp-mini-emmc1.dts | 67 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/zynqmp-zcu100-revC.dts | 2 -- arch/arm/dts/zynqmp-zcu102-revA.dts | 2 -- arch/arm/dts/zynqmp-zcu106-revA.dts | 2 -- arch/arm/dts/zynqmp-zcu111-revA.dts | 2 -- board/xilinx/zynq/board.c | 1 + board/xilinx/zynqmp/zynqmp.c | 2 ++ configs/{xilinx_zynqmp_mini_emmc_defconfig => xilinx_zynqmp_mini_emmc0_defconfig} | 3 ++- configs/xilinx_zynqmp_mini_emmc1_defconfig | 49 +++++++++++++++++++++++++++++++++++++++++++++++++ configs/xilinx_zynqmp_r5_defconfig | 2 ++ configs/xilinx_zynqmp_zcu102_rev1_0_defconfig | 1 + configs/xilinx_zynqmp_zcu102_revA_defconfig | 1 + configs/xilinx_zynqmp_zcu102_revB_defconfig | 1 + drivers/gpio/zynq_gpio.c | 10 +++++----- drivers/mmc/sdhci.c | 8 ++++---- drivers/mmc/zynq_sdhci.c | 2 +- drivers/serial/serial_zynq.c | 24 +++++++++++++++--------- drivers/timer/cadence-ttc.c | 22 ++++++++++++++++++++++ include/configs/xilinx_zynqmp_zcu102.h | 3 +++ scripts/Makefile.spl | 8 +++++++- 25 files changed, 196 insertions(+), 49 deletions(-) rename arch/arm/dts/{zynqmp-mini-emmc.dts => zynqmp-mini-emmc0.dts} (77%) create mode 100644 arch/arm/dts/zynqmp-mini-emmc1.dts rename configs/{xilinx_zynqmp_mini_emmc_defconfig => xilinx_zynqmp_mini_emmc0_defconfig} (94%) create mode 100644 configs/xilinx_zynqmp_mini_emmc1_defconfig
On Fri, Jun 15, 2018 at 02:53:58PM +0200, Michal Simek wrote:
Hi Tom,
Thanks, Michal
Michal Simek
