Re: [U-Boot] [PATCH v7 01/10] nds32: add header files support for nds32
Hi Wolfgang,
This also triggers an erro-r from checkpatch, and indeed this is a strange define.
+#define R0 uregs[1] /* R0 */ +#define R1 uregs[2] +#define R2 uregs[3] +#define R3 uregs[4]
NAK. Please use a C struct instead.
After discussed with the colledgue responsor for GDB and ptrace utils, we will fix this in Linux kernel later. Ans, I'll fix it in the next patch v8.
diff --git a/arch/nds32/include/asm/u-boot.h
b/arch/nds32/include/asm/u-boot.h
new file mode 100644 index 0000000..fafe4e4 --- /dev/null +++ b/arch/nds32/include/asm/u-boot.h @@ -0,0 +1,63 @@ +/*
- (C) Copyright 2002
- Sysgo Real-Time Solutions, GmbH <www.elinos.com>
- Marius Groeger mgroeger@sysgo.de
- Copyright (C) 2011 Andes Technology Corporation
- Copyright (C) 2010 Shawn Lin (nobuhiro@andestech.com)
- Copyright (C) 2011 Macpaul Lin (macpaul@andestech.com)
+#ifndef _U_BOOT_H_ +#define _U_BOOT_H_ 1
+#include <environment.h>
+typedef struct bd_info {
- int bi_baudrate; /* serial console baudrate */
- unsigned long bi_ip_addr; /* IP Address */
- unsigned char bi_enetaddr[6]; /* Ethernet adress */
- env_t *bi_env;
- unsigned long bi_arch_number; /* unique id for this board */
- unsigned long bi_boot_params; /* where this board
expects params */
- unsigned long bi_memstart; /* start of DRAM memory */
- unsigned long bi_memsize; /* size of DRAM memory
in bytes */
- unsigned long bi_flashstart; /* start of FLASH memory */
- unsigned long bi_flashsize; /* size of FLASH memory */
- unsigned long bi_flashoffset; /* reserved area for
startup monitor */
- struct /* RAM configuration */
unsigned long start;
unsigned long size;
- } bi_dram[CONFIG_NR_DRAM_BANKS];
+} bd_t;
I wonder which part of this file would be (C) by any of the folks listed above?
The typedef struct bd_info comes from arch/i386/include/asm/u-boot.h and arch/arm/include/asm/u-boot.h.
If you grep the author "Marius Groeger mgroeger@sysgo.de" then you can find the the 2 files were in the grep result which was originally referenced. Hence we put (C) listed above because we have referenced those 2 files.
If you have any suggestion, please let me know.
Best regards, Macpaul Lin
