[U-Boot] [PATCH 1/3] rockchip: rk3328: defconfig: remove SPL raw image support
RK3328 SPL only support FIT image for ATF bl31.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
configs/evb-rk3328_defconfig | 1 + configs/rock64-rk3328_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/evb-rk3328_defconfig b/configs/evb-rk3328_defconfig index 2868f0f133..37610774c1 100644 --- a/configs/evb-rk3328_defconfig +++ b/configs/evb-rk3328_defconfig @@ -20,6 +20,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_TPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_TPL_DRIVERS_MISC_SUPPORT=y diff --git a/configs/rock64-rk3328_defconfig b/configs/rock64-rk3328_defconfig index e8958590f4..3ab0af1158 100644 --- a/configs/rock64-rk3328_defconfig +++ b/configs/rock64-rk3328_defconfig @@ -21,6 +21,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-rock64.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_TPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_ATF=y
RK3368 SPL only support FIT image for ATF bl31.
configs/evb-px5_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/evb-px5_defconfig b/configs/evb-px5_defconfig index 46a42a7df6..5a06b2a99f 100644 --- a/configs/evb-px5_defconfig +++ b/configs/evb-px5_defconfig @@ -29,6 +29,7 @@ CONFIG_DEFAULT_FDT_FILE="rockchip/rk3368-px5-evb.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_ARCH_EARLY_INIT_R=y CONFIG_SPL_BOOTROM_SUPPORT=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_TPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_ATF=y
RK3399 SPL only support FIT image for ATF bl31.
configs/chromebook_bob_defconfig | 1 + configs/evb-rk3399_defconfig | 1 + configs/ficus-rk3399_defconfig | 1 + configs/firefly-rk3399_defconfig | 1 + configs/khadas-edge-captain-rk3399_defconfig | 1 + configs/khadas-edge-rk3399_defconfig | 1 + configs/khadas-edge-v-rk3399_defconfig | 1 + configs/nanopc-t4-rk3399_defconfig | 1 + configs/nanopi-m4-rk3399_defconfig | 1 + configs/nanopi-neo4-rk3399_defconfig | 1 + configs/orangepi-rk3399_defconfig | 1 + configs/roc-rk3399-pc_defconfig | 1 + configs/rock-pi-4-rk3399_defconfig | 1 + configs/rock960-rk3399_defconfig | 1 + configs/rockpro64-rk3399_defconfig | 1 + 15 files changed, 15 insertions(+)
diff --git a/configs/chromebook_bob_defconfig b/configs/chromebook_bob_defconfig index d6fc7e3b63..5126098b94 100644 --- a/configs/chromebook_bob_defconfig +++ b/configs/chromebook_bob_defconfig @@ -18,6 +18,7 @@ CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-gru-bob.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_TEXT_BASE=0xff8c2000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 CONFIG_SPL_SPI_LOAD=y diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index 14cca5bf2e..a0d215a5f1 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -11,6 +11,7 @@ CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 CONFIG_TPL=y diff --git a/configs/ficus-rk3399_defconfig b/configs/ficus-rk3399_defconfig index c3d8656d71..8b3692cdf0 100644 --- a/configs/ficus-rk3399_defconfig +++ b/configs/ficus-rk3399_defconfig @@ -11,6 +11,7 @@ CONFIG_DEBUG_UART=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_TEXT_BASE=0xff8c2000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 CONFIG_CMD_BOOTZ=y diff --git a/configs/firefly-rk3399_defconfig b/configs/firefly-rk3399_defconfig index 38ac8a32c3..d022631465 100644 --- a/configs/firefly-rk3399_defconfig +++ b/configs/firefly-rk3399_defconfig @@ -11,6 +11,7 @@ CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-firefly.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 CONFIG_TPL=y diff --git a/configs/khadas-edge-captain-rk3399_defconfig b/configs/khadas-edge-captain-rk3399_defconfig index 11ec2dab13..acfd91dbe7 100644 --- a/configs/khadas-edge-captain-rk3399_defconfig +++ b/configs/khadas-edge-captain-rk3399_defconfig @@ -11,6 +11,7 @@ CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-khadas-edge-captain.dtbi" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 CONFIG_TPL=y diff --git a/configs/khadas-edge-rk3399_defconfig b/configs/khadas-edge-rk3399_defconfig index c31360af86..b71fd3a286 100644 --- a/configs/khadas-edge-rk3399_defconfig +++ b/configs/khadas-edge-rk3399_defconfig @@ -11,6 +11,7 @@ CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-khadas-edge.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 CONFIG_TPL=y diff --git a/configs/khadas-edge-v-rk3399_defconfig b/configs/khadas-edge-v-rk3399_defconfig index 8c9e9fc7b9..0a789872dc 100644 --- a/configs/khadas-edge-v-rk3399_defconfig +++ b/configs/khadas-edge-v-rk3399_defconfig @@ -11,6 +11,7 @@ CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-khadas-edge-v.dtbi" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 CONFIG_TPL=y diff --git a/configs/nanopc-t4-rk3399_defconfig b/configs/nanopc-t4-rk3399_defconfig index 8afa5e1986..1d4c8f8a02 100644 --- a/configs/nanopc-t4-rk3399_defconfig +++ b/configs/nanopc-t4-rk3399_defconfig @@ -11,6 +11,7 @@ CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-nanopc-t4.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 CONFIG_TPL=y diff --git a/configs/nanopi-m4-rk3399_defconfig b/configs/nanopi-m4-rk3399_defconfig index e708a4fd8c..7375b758a2 100644 --- a/configs/nanopi-m4-rk3399_defconfig +++ b/configs/nanopi-m4-rk3399_defconfig @@ -11,6 +11,7 @@ CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-nanopi-m4.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 CONFIG_TPL=y diff --git a/configs/nanopi-neo4-rk3399_defconfig b/configs/nanopi-neo4-rk3399_defconfig index 62cdddde68..874ee5efb6 100644 --- a/configs/nanopi-neo4-rk3399_defconfig +++ b/configs/nanopi-neo4-rk3399_defconfig @@ -11,6 +11,7 @@ CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-nanopi-neo4.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 CONFIG_TPL=y diff --git a/configs/orangepi-rk3399_defconfig b/configs/orangepi-rk3399_defconfig index b1afeaeef8..7b02c59f08 100644 --- a/configs/orangepi-rk3399_defconfig +++ b/configs/orangepi-rk3399_defconfig @@ -11,6 +11,7 @@ CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-orangepi.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 CONFIG_TPL=y diff --git a/configs/roc-rk3399-pc_defconfig b/configs/roc-rk3399-pc_defconfig index 09e9b8a756..26ea2e615a 100644 --- a/configs/roc-rk3399-pc_defconfig +++ b/configs/roc-rk3399-pc_defconfig @@ -14,6 +14,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-roc-pc.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 CONFIG_CMD_BOOTZ=y diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4-rk3399_defconfig index d9d576c46f..14d115bab2 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -11,6 +11,7 @@ CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock-pi-4.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 CONFIG_TPL=y diff --git a/configs/rock960-rk3399_defconfig b/configs/rock960-rk3399_defconfig index 7413e4bf4c..abcc53fc8e 100644 --- a/configs/rock960-rk3399_defconfig +++ b/configs/rock960-rk3399_defconfig @@ -12,6 +12,7 @@ CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock960.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_TEXT_BASE=0xff8c2000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 CONFIG_SYS_PROMPT="rock960 => " diff --git a/configs/rockpro64-rk3399_defconfig b/configs/rockpro64-rk3399_defconfig index 5bc6d5d9c6..40ebad5abb 100644 --- a/configs/rockpro64-rk3399_defconfig +++ b/configs/rockpro64-rk3399_defconfig @@ -11,6 +11,7 @@ CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rockpro64.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 CONFIG_TPL=y
Kever Yang
