[PATCH v7 0/7] Tegra: add ASUS/Google Nexus 7 (2012) support
This patchset adds support for native use of U-Boot on: - ASUS T30 Transformers (7 devices, all models); - ASUS/Google Nexus 7 (2012), both grouper and tilapia - LG Optimus 4X HD (P880) and Optimus Vu (P895) - HTC One X (endeavoru) as a replacement for the vendor bootloader.
Current commits are designed to work on re-crypted devices but can be used on clean unmodified devices with slight restrictions (like no booting/mounting emmc and no self updating feature).
All device setup commits fall under the same pattern. Alongside device bringup tegra requires few small patches: - add gpio keyboard as stdin device - make networking boot options optional - add a small tool to generate SoC UID
Commits passed ./tools/buildman/buildman tegra Building current source for 30 boards (12 threads, 1 job per thread) 30 0 0 /30 0:00:06 : apalis_t30 Completed: 30 total built, 30 newly), duration 0:05:33, rate 0.09
--- Changes from v6: - fixed typos - changed grouper base defconfig in doc - fixed references too microsd card for grouper, lg and htc - fixed name of p1801 - removed pwm from p1801 - added section about flashing uboot to tf600t - changed tf600t behavior (power off after update, not reboot)
Changes from v5: - fixed maintained files inclusion
Changes from v4: - fixed documentation - fixed CONFIG_* definitions
Changes from v3: - extended amount of devices supported
Changes from v2: - fuse build is excluded for T186 (it is not supported in it anyway)
Changes from v1: - fix fuse headers for newer Tegra generations - allow grouper_common_defconfig to pass without fragments ---
Jonas Schwöbel (1): configs: tegra-common-post: make PXE and DHCP boot targets optional
Svyatoslav Ryhel (6): configs: tegra-common-post: add GPIO keyboard as STDIN device ARM: tegra: add SoC UID calculation function board: asus: transformer: add ASUS Transformer T30 family support board: asus: grouper: add Google Nexus 7 (2012) support board: lg: x3: add Optimus 4X HD and Optimus Vu support board: htc: endeavoru: add One X support
arch/arm/dts/Makefile | 12 + arch/arm/dts/tegra30-asus-grouper-common.dtsi | 157 ++++++ .../dts/tegra30-asus-nexus7-grouper-E1565.dts | 43 ++ .../dts/tegra30-asus-nexus7-grouper-PM269.dts | 36 ++ .../dts/tegra30-asus-nexus7-tilapia-E1565.dts | 62 +++ arch/arm/dts/tegra30-asus-p1801-t.dts | 18 + arch/arm/dts/tegra30-asus-tf201.dts | 9 + arch/arm/dts/tegra30-asus-tf300t.dts | 18 + arch/arm/dts/tegra30-asus-tf300tg.dts | 9 + arch/arm/dts/tegra30-asus-tf300tl.dts | 9 + arch/arm/dts/tegra30-asus-tf600t.dts | 89 ++++ arch/arm/dts/tegra30-asus-tf700t.dts | 13 + arch/arm/dts/tegra30-asus-transformer.dtsi | 211 ++++++++ arch/arm/dts/tegra30-htc-endeavoru.dts | 166 +++++++ arch/arm/dts/tegra30-lg-p880.dts | 40 ++ arch/arm/dts/tegra30-lg-p895.dts | 50 ++ arch/arm/dts/tegra30-lg-x3.dtsi | 180 +++++++ arch/arm/include/asm/arch-tegra/fuse.h | 7 + arch/arm/mach-tegra/Makefile | 4 + arch/arm/mach-tegra/fuse.c | 151 ++++++ arch/arm/mach-tegra/tegra30/Kconfig | 20 + board/asus/grouper/Kconfig | 22 + board/asus/grouper/MAINTAINERS | 10 + board/asus/grouper/Makefile | 14 + board/asus/grouper/grouper-spl-max.c | 45 ++ board/asus/grouper/grouper-spl-ti.c | 41 ++ board/asus/grouper/grouper.c | 202 ++++++++ board/asus/grouper/pinmux-config-grouper.h | 362 ++++++++++++++ board/asus/transformer-t30/Kconfig | 23 + board/asus/transformer-t30/MAINTAINERS | 15 + board/asus/transformer-t30/Makefile | 11 + .../pinmux-config-transformer.h | 365 ++++++++++++++ .../transformer-t30/transformer-t30-spl.c | 41 ++ board/asus/transformer-t30/transformer-t30.c | 201 ++++++++ board/htc/endeavoru/Kconfig | 12 + board/htc/endeavoru/MAINTAINERS | 7 + board/htc/endeavoru/Makefile | 11 + board/htc/endeavoru/endeavoru-spl.c | 47 ++ board/htc/endeavoru/endeavoru.c | 116 +++++ board/htc/endeavoru/pinmux-config-endeavoru.h | 362 ++++++++++++++ board/lg/x3-t30/Kconfig | 26 + board/lg/x3-t30/MAINTAINERS | 9 + board/lg/x3-t30/Makefile | 11 + board/lg/x3-t30/pinmux-config-x3.h | 449 ++++++++++++++++++ board/lg/x3-t30/x3-t30-spl.c | 48 ++ board/lg/x3-t30/x3-t30.c | 176 +++++++ configs/endeavoru_defconfig | 84 ++++ configs/grouper_E1565.config | 2 + configs/grouper_PM269.config | 2 + configs/grouper_common_defconfig | 84 ++++ configs/p1801-t.config | 2 + configs/p880.config | 4 + configs/p895.config | 4 + configs/tf201.config | 2 + configs/tf300t.config | 2 + configs/tf300tg.config | 2 + configs/tf300tl.config | 2 + configs/tf600t.config | 4 + configs/tf700t.config | 2 + configs/tilapia.config | 3 + configs/transformer_t30_defconfig | 85 ++++ configs/x3_t30_defconfig | 88 ++++ doc/board/asus/grouper_common.rst | 94 ++++ doc/board/asus/index.rst | 10 + doc/board/asus/transformer_t30.rst | 116 +++++ doc/board/htc/endeavoru.rst | 89 ++++ doc/board/htc/index.rst | 9 + doc/board/index.rst | 3 + doc/board/lg/index.rst | 9 + doc/board/lg/x3_t30.rst | 93 ++++ include/configs/endeavoru.h | 65 +++ include/configs/grouper.h | 61 +++ include/configs/tegra-common-post.h | 28 +- include/configs/transformer-common.h | 94 ++++ include/configs/transformer-t30.h | 23 + include/configs/x3-t30.h | 77 +++ 76 files changed, 5068 insertions(+), 5 deletions(-) create mode 100644 arch/arm/dts/tegra30-asus-grouper-common.dtsi create mode 100644 arch/arm/dts/tegra30-asus-nexus7-grouper-E1565.dts create mode 100644 arch/arm/dts/tegra30-asus-nexus7-grouper-PM269.dts create mode 100644 arch/arm/dts/tegra30-asus-nexus7-tilapia-E1565.dts create mode 100644 arch/arm/dts/tegra30-asus-p1801-t.dts create mode 100644 arch/arm/dts/tegra30-asus-tf201.dts create mode 100644 arch/arm/dts/tegra30-asus-tf300t.dts create mode 100644 arch/arm/dts/tegra30-asus-tf300tg.dts create mode 100644 arch/arm/dts/tegra30-asus-tf300tl.dts create mode 100644 arch/arm/dts/tegra30-asus-tf600t.dts create mode 100644 arch/arm/dts/tegra30-asus-tf700t.dts create mode 100644 arch/arm/dts/tegra30-asus-transformer.dtsi create mode 100644 arch/arm/dts/tegra30-htc-endeavoru.dts create mode 100644 arch/arm/dts/tegra30-lg-p880.dts create mode 100644 arch/arm/dts/tegra30-lg-p895.dts create mode 100644 arch/arm/dts/tegra30-lg-x3.dtsi create mode 100644 arch/arm/mach-tegra/fuse.c create mode 100644 board/asus/grouper/Kconfig create mode 100644 board/asus/grouper/MAINTAINERS create mode 100644 board/asus/grouper/Makefile create mode 100644 board/asus/grouper/grouper-spl-max.c create mode 100644 board/asus/grouper/grouper-spl-ti.c create mode 100644 board/asus/grouper/grouper.c create mode 100644 board/asus/grouper/pinmux-config-grouper.h create mode 100644 board/asus/transformer-t30/Kconfig create mode 100644 board/asus/transformer-t30/MAINTAINERS create mode 100644 board/asus/transformer-t30/Makefile create mode 100644 board/asus/transformer-t30/pinmux-config-transformer.h create mode 100644 board/asus/transformer-t30/transformer-t30-spl.c create mode 100644 board/asus/transformer-t30/transformer-t30.c create mode 100644 board/htc/endeavoru/Kconfig create mode 100644 board/htc/endeavoru/MAINTAINERS create mode 100644 board/htc/endeavoru/Makefile create mode 100644 board/htc/endeavoru/endeavoru-spl.c create mode 100644 board/htc/endeavoru/endeavoru.c create mode 100644 board/htc/endeavoru/pinmux-config-endeavoru.h create mode 100644 board/lg/x3-t30/Kconfig create mode 100644 board/lg/x3-t30/MAINTAINERS create mode 100644 board/lg/x3-t30/Makefile create mode 100644 board/lg/x3-t30/pinmux-config-x3.h create mode 100644 board/lg/x3-t30/x3-t30-spl.c create mode 100644 board/lg/x3-t30/x3-t30.c create mode 100644 configs/endeavoru_defconfig create mode 100644 configs/grouper_E1565.config create mode 100644 configs/grouper_PM269.config create mode 100644 configs/grouper_common_defconfig create mode 100644 configs/p1801-t.config create mode 100644 configs/p880.config create mode 100644 configs/p895.config create mode 100644 configs/tf201.config create mode 100644 configs/tf300t.config create mode 100644 configs/tf300tg.config create mode 100644 configs/tf300tl.config create mode 100644 configs/tf600t.config create mode 100644 configs/tf700t.config create mode 100644 configs/tilapia.config create mode 100644 configs/transformer_t30_defconfig create mode 100644 configs/x3_t30_defconfig create mode 100644 doc/board/asus/grouper_common.rst create mode 100644 doc/board/asus/index.rst create mode 100644 doc/board/asus/transformer_t30.rst create mode 100644 doc/board/htc/endeavoru.rst create mode 100644 doc/board/htc/index.rst create mode 100644 doc/board/lg/index.rst create mode 100644 doc/board/lg/x3_t30.rst create mode 100644 include/configs/endeavoru.h create mode 100644 include/configs/grouper.h create mode 100644 include/configs/transformer-common.h create mode 100644 include/configs/transformer-t30.h create mode 100644 include/configs/x3-t30.h
GPIO keyboard is used on many newly upstreamed devices.
Tested-by: Andreas Westman Dorcsak hedmoo@yahoo.com # ASUS Grouper E1565 Tested-by: Svyatoslav Ryhel clamor95@gmail.com # LG P895 T30 Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- include/configs/tegra-common-post.h | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/include/configs/tegra-common-post.h b/include/configs/tegra-common-post.h index 991ffbb7df..2d5095639a 100644 --- a/include/configs/tegra-common-post.h +++ b/include/configs/tegra-common-post.h @@ -35,6 +35,12 @@ #define STDIN_KBD_USB "" #endif
+#ifdef CONFIG_BUTTON_KEYBOARD +#define STDIN_BTN_KBD ",button-kbd" +#else +#define STDIN_BTN_KBD "" +#endif + #ifdef CONFIG_VIDEO #define STDOUT_VIDEO ",vidconsole" #else @@ -48,7 +54,7 @@ #endif
#define TEGRA_DEVICE_SETTINGS \ - "stdin=serial" STDIN_KBD_KBC STDIN_KBD_USB STDOUT_CROS_EC "\0" \ + "stdin=serial" STDIN_KBD_KBC STDIN_KBD_USB STDOUT_CROS_EC STDIN_BTN_KBD "\0" \ "stdout=serial" STDOUT_VIDEO "\0" \ "stderr=serial" STDOUT_VIDEO "\0" \ ""
Disabling the network related features in defconfig causes build to fail so make them optional.
Tested-by: Andreas Westman Dorcsak hedmoo@yahoo.com # ASUS Grouper E1565 Tested-by: Svyatoslav Ryhel clamor95@gmail.com # LG P895 T30 Signed-off-by: Jonas Schwöbel jonasschwoebel@yahoo.de Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- include/configs/tegra-common-post.h | 20 ++++++++++++++++---- 1 file changed, 16 insertions(+), 4 deletions(-)
diff --git a/include/configs/tegra-common-post.h b/include/configs/tegra-common-post.h index 2d5095639a..0d0965ecce 100644 --- a/include/configs/tegra-common-post.h +++ b/include/configs/tegra-common-post.h @@ -8,9 +8,21 @@ #define __TEGRA_COMMON_POST_H
#if IS_ENABLED(CONFIG_CMD_USB) -# define BOOT_TARGET_USB(func) func(USB, usb, 0) +#define BOOT_TARGET_USB(func) func(USB, usb, 0) #else -# define BOOT_TARGET_USB(func) +#define BOOT_TARGET_USB(func) +#endif + +#if CONFIG_IS_ENABLED(CMD_DHCP) && CONFIG_IS_ENABLED(CMD_PXE) +#define BOOT_TARGET_PXE(func) func(PXE, pxe, na) +#else +#define BOOT_TARGET_PXE(func) +#endif + +#if CONFIG_IS_ENABLED(CMD_DHCP) +#define BOOT_TARGET_DHCP(func) func(DHCP, dhcp, na) +#else +#define BOOT_TARGET_DHCP(func) #endif
#ifndef BOOT_TARGET_DEVICES @@ -18,8 +30,8 @@ func(MMC, mmc, 1) \ func(MMC, mmc, 0) \ BOOT_TARGET_USB(func) \ - func(PXE, pxe, na) \ - func(DHCP, dhcp, na) + BOOT_TARGET_PXE(func) \ + BOOT_TARGET_DHCP(func) #endif #include <config_distro_bootcmd.h>
This is a small tool for calculation of SoC UID based on the same Linux function. It can be further used for generation of device unique data like mac address or exposing it as serial number.
Tested-by: Andreas Westman Dorcsak hedmoo@yahoo.com # ASUS Grouper E1565 Tested-by: Svyatoslav Ryhel clamor95@gmail.com # LG P895 T30 Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- arch/arm/include/asm/arch-tegra/fuse.h | 7 ++ arch/arm/mach-tegra/Makefile | 4 + arch/arm/mach-tegra/fuse.c | 151 +++++++++++++++++++++++++ 3 files changed, 162 insertions(+) create mode 100644 arch/arm/mach-tegra/fuse.c
diff --git a/arch/arm/include/asm/arch-tegra/fuse.h b/arch/arm/include/asm/arch-tegra/fuse.h index 5b8e0bd8d1..f3f2ad8e3f 100644 --- a/arch/arm/include/asm/arch-tegra/fuse.h +++ b/arch/arm/include/asm/arch-tegra/fuse.h @@ -19,4 +19,11 @@ struct fuse_regs { u32 security_mode; /* 0x1A0: FUSE_SECURITY_MODE */ };
+/** + * Calculate SoC UID + * + * Return: uid if ok, 0 on error + */ +unsigned long long tegra_chip_uid(void); + #endif /* ifndef _FUSE_H_ */ diff --git a/arch/arm/mach-tegra/Makefile b/arch/arm/mach-tegra/Makefile index 9147050b32..a5733b0bf6 100644 --- a/arch/arm/mach-tegra/Makefile +++ b/arch/arm/mach-tegra/Makefile @@ -32,6 +32,10 @@ endif obj-$(CONFIG_DISPLAY_CPUINFO) += sys_info.o obj-y += pmc.o
+ifndef CONFIG_TEGRA186 +obj-y += fuse.o +endif + obj-$(CONFIG_TEGRA20) += tegra20/ obj-$(CONFIG_TEGRA30) += tegra30/ obj-$(CONFIG_TEGRA114) += tegra114/ diff --git a/arch/arm/mach-tegra/fuse.c b/arch/arm/mach-tegra/fuse.c new file mode 100644 index 0000000000..83bd505538 --- /dev/null +++ b/arch/arm/mach-tegra/fuse.c @@ -0,0 +1,151 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2012-2013 + * NVIDIA Corporation <www.nvidia.com> + * + * (C) Copyright 2022 + * Svyatoslav Ryhel clamor95@gmail.com + */ + +#include <common.h> +#include <linux/delay.h> +#include <asm/io.h> + +#include <asm/arch/tegra.h> +#include <asm/arch/gp_padctrl.h> +#include <asm/arch/clock.h> +#include <asm/arch-tegra/fuse.h> + +#include "cpu.h" + +#define FUSE_UID_LOW 0x108 +#define FUSE_UID_HIGH 0x10c + +#define FUSE_VENDOR_CODE 0x200 +#define FUSE_FAB_CODE 0x204 +#define FUSE_LOT_CODE_0 0x208 +#define FUSE_LOT_CODE_1 0x20c +#define FUSE_WAFER_ID 0x210 +#define FUSE_X_COORDINATE 0x214 +#define FUSE_Y_COORDINATE 0x218 + +#define FUSE_VENDOR_CODE_MASK 0xf +#define FUSE_FAB_CODE_MASK 0x3f +#define FUSE_WAFER_ID_MASK 0x3f +#define FUSE_X_COORDINATE_MASK 0x1ff +#define FUSE_Y_COORDINATE_MASK 0x1ff + +static u32 tegra_fuse_readl(unsigned long offset) +{ + return readl(NV_PA_FUSE_BASE + offset); +} + +static void tegra_fuse_init(void) +{ + u32 reg; + + /* + * Performed by downstream and is not + * documented by TRM. Whithout setting + * this bit fuse region will not work. + */ + reg = readl_relaxed(NV_PA_CLK_RST_BASE + 0x48); + reg |= BIT(28); + writel(reg, NV_PA_CLK_RST_BASE + 0x48); + + clock_enable(PERIPH_ID_FUSE); + udelay(2); + reset_set_enable(PERIPH_ID_FUSE, 0); +} + +unsigned long long tegra_chip_uid(void) +{ + u64 uid = 0ull; + u32 reg; + u32 cid; + u32 vendor; + u32 fab; + u32 lot; + u32 wafer; + u32 x; + u32 y; + u32 i; + + tegra_fuse_init(); + + /* This used to be so much easier in prior chips. Unfortunately, there + is no one-stop shopping for the unique id anymore. It must be + constructed from various bits of information burned into the fuses + during the manufacturing process. The 64-bit unique id is formed + by concatenating several bit fields. The notation used for the + various fields is fieldname:size_in_bits with the UID composed + thusly: + CID:4VENDOR:4FAB:6LOT:26WAFER:6<X:9><Y:9> + Where: + Field Bits Position Data + ------- ---- -------- ---------------------------------------- + CID 4 60 Chip id + VENDOR 4 56 Vendor code + FAB 6 50 FAB code + LOT 26 24 Lot code (5-digit base-36-coded-decimal, + re-encoded to 26 bits binary) + WAFER 6 18 Wafer id + X 9 9 Wafer X-coordinate + Y 9 0 Wafer Y-coordinate + ------- ---- + Total 64 + */ + + switch (tegra_get_chip()) { + case CHIPID_TEGRA20: + /* T20 has simple calculation */ + return ((unsigned long long)tegra_fuse_readl(FUSE_UID_HIGH) << 32ull) | + (unsigned long long)tegra_fuse_readl(FUSE_UID_LOW); + case CHIPID_TEGRA30: + /* T30 chip id is 0 */ + cid = 0; + break; + case CHIPID_TEGRA114: + /* T11x chip id is 1 */ + cid = 1; + break; + case CHIPID_TEGRA124: + /* T12x chip id is 3 */ + cid = 3; + break; + case CHIPID_TEGRA210: + /* T210 chip id is 5 */ + cid = 5; + default: + return 0; + } + + vendor = tegra_fuse_readl(FUSE_VENDOR_CODE) & FUSE_VENDOR_CODE_MASK; + fab = tegra_fuse_readl(FUSE_FAB_CODE) & FUSE_FAB_CODE_MASK; + + /* Lot code must be re-encoded from a 5 digit base-36 'BCD' number + to a binary number. */ + lot = 0; + reg = tegra_fuse_readl(FUSE_LOT_CODE_0) << 2; + + for (i = 0; i < 5; ++i) { + u32 digit = (reg & 0xFC000000) >> 26; + lot *= 36; + lot += digit; + reg <<= 6; + } + + wafer = tegra_fuse_readl(FUSE_WAFER_ID) & FUSE_WAFER_ID_MASK; + x = tegra_fuse_readl(FUSE_X_COORDINATE) & FUSE_X_COORDINATE_MASK; + y = tegra_fuse_readl(FUSE_Y_COORDINATE) & FUSE_Y_COORDINATE_MASK; + + uid = ((unsigned long long)cid << 60ull) + | ((unsigned long long)vendor << 56ull) + | ((unsigned long long)fab << 50ull) + | ((unsigned long long)lot << 24ull) + | ((unsigned long long)wafer << 18ull) + | ((unsigned long long)x << 9ull) + | ((unsigned long long)y << 0ull); + + return uid; +}
It's a very bad idea to use the SoC UID as a MAC address. There are better ways (such as MAC address randomization) to generate one if for some reason you don't have a real MAC address or are concerned about privacy.
The SoC UID is also not very well suited as a serial number because it identifies only the SoC, but doesn't say anything about any of the other components of a device. Many devices have serial numbers in some EEPROM chip, so those would be more appropriate.
I suppose not all devices have such a system-wide serial number, so perhaps there are cases where this would be better than nothing.
Thierry
23 червня 2023 р. 14:24:37 GMT+03:00, Thierry Reding thierry.reding@gmail.com написав(-ла):
SoC UID is not used directly as MAC but it is used as a device specific base to generate device specific one. You can check LG board to see what I mean.
That is not the case of devices in patches and IIRC SoC UID is used as fastboot ID on transformers by vendor.
Vendors usually do not expose serial in any device hardware, or at least do not bother to inform, where to find it.
Thierry
Is this something that originates from the original vendor code? My primary concern is that this might end up reusing MAC addresses which were assigned to other devices.
That doesn't really make this a better idea, but I also understand that your options are limited given the information you have.
My experience differs. There's usually some serial number somewhere because vendors need some way of tracking these devices. But yeah, if you get an OEM device they typically don't tell you where to find it. One thing you might want to do is probe the various I2C busses to see if there's an EEPROM on any of them. They are often found at addresses 0x50-0x58 or so.
Again, I'm not strongly objecting to this, but I'd prefer some better way to identify system than by chip UID, because it's not meant for this purpose.
Thierry
23 червня 2023 р. 17:25:32 GMT+03:00, Thierry Reding thierry.reding@gmail.com написав(-ла):
No, but vendor code makes some magic inside the kernel, to avoid this in mainline linux, which is obviously not be accepted, I decided to generate mac in u-boot based on device specific data (soc id) and tweak linux dtb on load. It is not the ideal decision but so far it is the best I could make without messing stuff too much. If no bt mac is provided, bt will not work.
Well, why not? SoC ID is not smth secret. Even linux kernel can expose it and vendor firmwares often display it. As far as I can tell, this is the only 100% valid thing which can determine device unlikely and has stable way of calculation.
True, I have dug those extensively but nothing so far.
Well, maybe it is not meant for this purpose, but it is quite a nice fit.
Best regards, Svyatoslav R.
Thierry
The ASUS Transformer T30 family are 2-in-1 detachable tablets and AiO developed by ASUS that run the Android operating system (TF600T runs Windows RT and P1801-T runs Android and Windows). The T30 Transformers feature a 10.1-inch display (apart P1801-T), an Nvidia Tegra 3 quad-core chip, 1/2 GB of RAM, and 16/32 GB of storage. Transformers board derives from Nvidia Cardhu development board.
This patch brings support for 7 known Transformer devices: - ASUS Transformer Prime TF201 - ASUS Transformer Pad TF300T/TF300TG/TF300TL - ASUS VivoTab RT TF600T (Windows RT based) - ASUS Transformer Infinity TF700T - ASUS Portable AiO P1801-T
Tested-by: Andreas Westman Dorcsak hedmoo@yahoo.com # all devices Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- arch/arm/dts/Makefile | 7 + arch/arm/dts/tegra30-asus-p1801-t.dts | 18 + arch/arm/dts/tegra30-asus-tf201.dts | 9 + arch/arm/dts/tegra30-asus-tf300t.dts | 18 + arch/arm/dts/tegra30-asus-tf300tg.dts | 9 + arch/arm/dts/tegra30-asus-tf300tl.dts | 9 + arch/arm/dts/tegra30-asus-tf600t.dts | 89 +++++ arch/arm/dts/tegra30-asus-tf700t.dts | 13 + arch/arm/dts/tegra30-asus-transformer.dtsi | 211 ++++++++++ arch/arm/mach-tegra/tegra30/Kconfig | 5 + board/asus/transformer-t30/Kconfig | 23 ++ board/asus/transformer-t30/MAINTAINERS | 15 + board/asus/transformer-t30/Makefile | 11 + .../pinmux-config-transformer.h | 365 ++++++++++++++++++ .../transformer-t30/transformer-t30-spl.c | 41 ++ board/asus/transformer-t30/transformer-t30.c | 201 ++++++++++ configs/p1801-t.config | 2 + configs/tf201.config | 2 + configs/tf300t.config | 2 + configs/tf300tg.config | 2 + configs/tf300tl.config | 2 + configs/tf600t.config | 4 + configs/tf700t.config | 2 + configs/transformer_t30_defconfig | 85 ++++ doc/board/asus/index.rst | 9 + doc/board/asus/transformer_t30.rst | 116 ++++++ doc/board/index.rst | 1 + include/configs/transformer-common.h | 94 +++++ include/configs/transformer-t30.h | 23 ++ 29 files changed, 1388 insertions(+) create mode 100644 arch/arm/dts/tegra30-asus-p1801-t.dts create mode 100644 arch/arm/dts/tegra30-asus-tf201.dts create mode 100644 arch/arm/dts/tegra30-asus-tf300t.dts create mode 100644 arch/arm/dts/tegra30-asus-tf300tg.dts create mode 100644 arch/arm/dts/tegra30-asus-tf300tl.dts create mode 100644 arch/arm/dts/tegra30-asus-tf600t.dts create mode 100644 arch/arm/dts/tegra30-asus-tf700t.dts create mode 100644 arch/arm/dts/tegra30-asus-transformer.dtsi create mode 100644 board/asus/transformer-t30/Kconfig create mode 100644 board/asus/transformer-t30/MAINTAINERS create mode 100644 board/asus/transformer-t30/Makefile create mode 100644 board/asus/transformer-t30/pinmux-config-transformer.h create mode 100644 board/asus/transformer-t30/transformer-t30-spl.c create mode 100644 board/asus/transformer-t30/transformer-t30.c create mode 100644 configs/p1801-t.config create mode 100644 configs/tf201.config create mode 100644 configs/tf300t.config create mode 100644 configs/tf300tg.config create mode 100644 configs/tf300tl.config create mode 100644 configs/tf600t.config create mode 100644 configs/tf700t.config create mode 100644 configs/transformer_t30_defconfig create mode 100644 doc/board/asus/index.rst create mode 100644 doc/board/asus/transformer_t30.rst create mode 100644 include/configs/transformer-common.h create mode 100644 include/configs/transformer-t30.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 480269fa60..c87729d45e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -237,6 +237,13 @@ dtb-$(CONFIG_ARCH_TEGRA) += tegra20-harmony.dtb \ tegra20-ventana.dtb \ tegra20-colibri.dtb \ tegra30-apalis.dtb \ + tegra30-asus-p1801-t.dtb \ + tegra30-asus-tf201.dtb \ + tegra30-asus-tf300t.dtb \ + tegra30-asus-tf300tg.dtb \ + tegra30-asus-tf300tl.dtb \ + tegra30-asus-tf600t.dtb \ + tegra30-asus-tf700t.dtb \ tegra30-beaver.dtb \ tegra30-cardhu.dtb \ tegra30-colibri.dtb \ diff --git a/arch/arm/dts/tegra30-asus-p1801-t.dts b/arch/arm/dts/tegra30-asus-p1801-t.dts new file mode 100644 index 0000000000..4b2dc61713 --- /dev/null +++ b/arch/arm/dts/tegra30-asus-p1801-t.dts @@ -0,0 +1,18 @@ +// SPDX-License-Identifier: GPL-2.0 +/dts-v1/; + +#include "tegra30-asus-transformer.dtsi" + +/ { + model = "ASUS Portable AiO P1801-T"; + compatible = "asus,p1801-t", "nvidia,tegra30"; + + /delete-node/ host1x@50000000; + /delete-node/ pwm@7000a000; + + /delete-node/ backlight; + /delete-node/ panel; + + /delete-node/ regulator-pnl; + /delete-node/ regulator-bl; +}; diff --git a/arch/arm/dts/tegra30-asus-tf201.dts b/arch/arm/dts/tegra30-asus-tf201.dts new file mode 100644 index 0000000000..54f359ef96 --- /dev/null +++ b/arch/arm/dts/tegra30-asus-tf201.dts @@ -0,0 +1,9 @@ +// SPDX-License-Identifier: GPL-2.0 +/dts-v1/; + +#include "tegra30-asus-transformer.dtsi" + +/ { + model = "ASUS Transformer Prime TF201"; + compatible = "asus,tf201", "nvidia,tegra30"; +}; diff --git a/arch/arm/dts/tegra30-asus-tf300t.dts b/arch/arm/dts/tegra30-asus-tf300t.dts new file mode 100644 index 0000000000..db08488420 --- /dev/null +++ b/arch/arm/dts/tegra30-asus-tf300t.dts @@ -0,0 +1,18 @@ +// SPDX-License-Identifier: GPL-2.0 +/dts-v1/; + +#include "tegra30-asus-transformer.dtsi" + +/ { + model = "ASUS Transformer Pad TF300T"; + compatible = "asus,tf300t", "nvidia,tegra30"; + + gpio@6000d000 { + volume-buttons-hog { + gpio-hog; + gpios = <TEGRA_GPIO(R, 0) GPIO_ACTIVE_HIGH>, + <TEGRA_GPIO(K, 7) GPIO_ACTIVE_HIGH>; + output-low; + }; + }; +}; diff --git a/arch/arm/dts/tegra30-asus-tf300tg.dts b/arch/arm/dts/tegra30-asus-tf300tg.dts new file mode 100644 index 0000000000..6f42182c99 --- /dev/null +++ b/arch/arm/dts/tegra30-asus-tf300tg.dts @@ -0,0 +1,9 @@ +// SPDX-License-Identifier: GPL-2.0 +/dts-v1/; + +#include "tegra30-asus-transformer.dtsi" + +/ { + model = "ASUS Transformer Pad 3G TF300TG"; + compatible = "asus,tf300tg", "nvidia,tegra30"; +}; diff --git a/arch/arm/dts/tegra30-asus-tf300tl.dts b/arch/arm/dts/tegra30-asus-tf300tl.dts new file mode 100644 index 0000000000..242f79170c --- /dev/null +++ b/arch/arm/dts/tegra30-asus-tf300tl.dts @@ -0,0 +1,9 @@ +// SPDX-License-Identifier: GPL-2.0 +/dts-v1/; + +#include "tegra30-asus-transformer.dtsi" + +/ { + model = "ASUS Transformer Pad LTE TF300TL"; + compatible = "asus,tf300tl", "nvidia,tegra30"; +}; diff --git a/arch/arm/dts/tegra30-asus-tf600t.dts b/arch/arm/dts/tegra30-asus-tf600t.dts new file mode 100644 index 0000000000..c9b8f4fa14 --- /dev/null +++ b/arch/arm/dts/tegra30-asus-tf600t.dts @@ -0,0 +1,89 @@ +// SPDX-License-Identifier: GPL-2.0 +/dts-v1/; + +#include "tegra30-asus-transformer.dtsi" + +/ { + model = "ASUS VivoTab RT TF600T"; + compatible = "asus,tf600t", "nvidia,tegra30"; + + aliases { + spi0 = &spi4; + }; + + /delete-node/ host1x@50000000; + + pmic_i2c: i2c@7000d000 { + /* Texas Instruments TPS659110 PMIC */ + pmic: tps65911@2d { + regulators { + vdd_1v2_bl: vdd1 { + regulator-name = "vdd_1v2_backlight"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-always-on; + regulator-boot-on; + ti,regulator-ext-sleep-control = <8>; + }; + + /delete-node/ ldo2; + /delete-node/ ldo3; + + /* uSD slot VDDIO */ + vddio_usd: ldo5 { + regulator-name = "vddio_sdmmc"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + avdd_dsi_csi: ldo6 { + regulator-name = "avdd_dsi_csi"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + }; + }; + }; + }; + + spi4: spi@7000da00 { + status = "okay"; + spi-max-frequency = <25000000>; + + spi-flash@1 { + compatible = "winbond,w25q32", "jedec,spi-nor"; + reg = <1>; + spi-max-frequency = <20000000>; + }; + }; + + backlight { + power-supply = <&vdd_1v2_bl>; + }; + + gpio-keys { + key-volume-up { + label = "Volume Up"; + gpios = <&gpio TEGRA_GPIO(Q, 3) GPIO_ACTIVE_LOW>; + linux,code = <KEY_UP>; + }; + + key-volume-down { + label = "Volume Down"; + gpios = <&gpio TEGRA_GPIO(Q, 4) GPIO_ACTIVE_LOW>; + linux,code = <KEY_DOWN>; + }; + }; + + /delete-node/ panel; + + vdd_usd: regulator-usd { + compatible = "regulator-fixed"; + regulator-name = "vdd_usd"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + /delete-node/ regulator-pnl; + /delete-node/ regulator-bl; +}; diff --git a/arch/arm/dts/tegra30-asus-tf700t.dts b/arch/arm/dts/tegra30-asus-tf700t.dts new file mode 100644 index 0000000000..d530527c9f --- /dev/null +++ b/arch/arm/dts/tegra30-asus-tf700t.dts @@ -0,0 +1,13 @@ +// SPDX-License-Identifier: GPL-2.0 +/dts-v1/; + +#include "tegra30-asus-transformer.dtsi" + +/ { + model = "ASUS Transformer Infinity TF700T"; + compatible = "asus,tf700t", "nvidia,tegra30"; + + /delete-node/ host1x@50000000; + + /delete-node/ panel; +}; diff --git a/arch/arm/dts/tegra30-asus-transformer.dtsi b/arch/arm/dts/tegra30-asus-transformer.dtsi new file mode 100644 index 0000000000..4eee1df084 --- /dev/null +++ b/arch/arm/dts/tegra30-asus-transformer.dtsi @@ -0,0 +1,211 @@ +// SPDX-License-Identifier: GPL-2.0 + +#include <dt-bindings/input/input.h> + +#include "tegra30.dtsi" + +/ { + chosen { + stdout-path = &uarta; + }; + + aliases { + i2c0 = &pwr_i2c; + i2c1 = &gen1_i2c; + + mmc0 = &sdmmc4; /* eMMC */ + mmc1 = &sdmmc1; /* uSD slot */ + + rtc0 = &pmic; + rtc1 = "/rtc@7000e000"; + + usb0 = &usb1; + usb1 = &usb3; /* Dock USB */ + }; + + memory { + device_type = "memory"; + reg = <0x80000000 0x40000000>; + }; + + host1x@50000000 { + dc@54200000 { + rgb { + status = "okay"; + + nvidia,panel = <&panel>; + }; + }; + }; + + uarta: serial@70006000 { + status = "okay"; + }; + + pwm: pwm@7000a000 { + status = "okay"; + }; + + gen1_i2c: i2c@7000c000 { + status = "okay"; + clock-frequency = <100000>; + }; + + pwr_i2c: i2c@7000d000 { + status = "okay"; + clock-frequency = <400000>; + + /* Texas Instruments TPS659110 PMIC */ + pmic: tps65911@2d { + compatible = "ti,tps65911"; + reg = <0x2d>; + + interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; + #interrupt-cells = <2>; + interrupt-controller; + + ti,system-power-controller; + + #gpio-cells = <2>; + gpio-controller; + + regulators { + /* eMMC VDD */ + vcore_emmc: ldo1 { + regulator-name = "vdd_emmc_core"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + /* uSD slot VDD */ + vdd_usd: ldo2 { + regulator-name = "vdd_usd"; + regulator-min-microvolt = <3100000>; + regulator-max-microvolt = <3100000>; + }; + + /* uSD slot VDDIO */ + vddio_usd: ldo3 { + regulator-name = "vddio_usd"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3100000>; + }; + }; + }; + }; + + sdmmc1: sdhci@78000000 { + status = "okay"; + bus-width = <4>; + + cd-gpios = <&gpio TEGRA_GPIO(I, 5) GPIO_ACTIVE_LOW>; + power-gpios = <&gpio TEGRA_GPIO(D, 7) GPIO_ACTIVE_HIGH>; + + vmmc-supply = <&vdd_usd>; + vqmmc-supply = <&vddio_usd>; + }; + + sdmmc4: sdhci@78000600 { + status = "okay"; + bus-width = <8>; + non-removable; + }; + + /* USB via ASUS connector */ + usb1: usb@7d000000 { + status = "okay"; + dr_mode = "otg"; + }; + + /* Dock's USB port */ + usb3: usb@7d008000 { + status = "okay"; + }; + + backlight: backlight { + compatible = "pwm-backlight"; + + enable-gpios = <&gpio TEGRA_GPIO(H, 2) GPIO_ACTIVE_HIGH>; + power-supply = <&vdd_5v0_bl>; + pwms = <&pwm 0 4000000>; + + brightness-levels = <1 35 70 105 140 175 210 255>; + default-brightness-level = <5>; + }; + + /* PMIC has a built-in 32KHz oscillator which is used by PMC */ + clk32k_in: clock-32k { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + clock-output-names = "pmic-oscillator"; + }; + + gpio-keys { + compatible = "gpio-keys"; + + key-power { + label = "Power"; + gpios = <&gpio TEGRA_GPIO(V, 0) GPIO_ACTIVE_LOW>; + linux,code = <KEY_ENTER>; + }; + + key-volume-up { + label = "Volume Up"; + gpios = <&gpio TEGRA_GPIO(Q, 2) GPIO_ACTIVE_LOW>; + linux,code = <KEY_UP>; + }; + + key-volume-down { + label = "Volume Down"; + gpios = <&gpio TEGRA_GPIO(Q, 3) GPIO_ACTIVE_LOW>; + linux,code = <KEY_DOWN>; + }; + }; + + panel: panel { + compatible = "simple-panel"; + + power-supply = <&vdd_pnl_reg>; + enable-gpios = <&gpio TEGRA_GPIO(N, 6) GPIO_ACTIVE_HIGH>; + + backlight = <&backlight>; + + display-timings { + timing@0 { + /* 1280x800@60Hz */ + clock-frequency = <68000000>; + + hactive = <1280>; + hfront-porch = <48>; + hback-porch = <18>; + hsync-len = <30>; + + vactive = <800>; + vfront-porch = <3>; + vback-porch = <12>; + vsync-len = <5>; + }; + }; + }; + + vdd_pnl_reg: regulator-pnl { + compatible = "regulator-fixed"; + regulator-name = "vdd_panel"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio TEGRA_GPIO(W, 1) GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + vdd_5v0_bl: regulator-bl { + compatible = "regulator-fixed"; + regulator-name = "vdd_5v0_bl"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-boot-on; + gpio = <&gpio TEGRA_GPIO(H, 3) GPIO_ACTIVE_HIGH>; + enable-active-high; + }; +}; diff --git a/arch/arm/mach-tegra/tegra30/Kconfig b/arch/arm/mach-tegra/tegra30/Kconfig index 85b8ce294f..4f78d0ba97 100644 --- a/arch/arm/mach-tegra/tegra30/Kconfig +++ b/arch/arm/mach-tegra/tegra30/Kconfig @@ -24,6 +24,10 @@ config TARGET_TEC_NG bool "Avionic Design TEC-NG board" select BOARD_LATE_INIT
+config TARGET_TRANSFORMER_T30 + bool "Asus Tegra30 Transformer board" + select BOARD_LATE_INIT + endchoice
config SYS_SOC @@ -34,5 +38,6 @@ source "board/nvidia/beaver/Kconfig" source "board/nvidia/cardhu/Kconfig" source "board/toradex/colibri_t30/Kconfig" source "board/avionic-design/tec-ng/Kconfig" +source "board/asus/transformer-t30/Kconfig"
endif diff --git a/board/asus/transformer-t30/Kconfig b/board/asus/transformer-t30/Kconfig new file mode 100644 index 0000000000..3c36f4ada2 --- /dev/null +++ b/board/asus/transformer-t30/Kconfig @@ -0,0 +1,23 @@ +if TARGET_TRANSFORMER_T30 + +config SYS_BOARD + default "transformer-t30" + +config SYS_VENDOR + default "asus" + +config SYS_CONFIG_NAME + default "transformer-t30" + +config TRANSFORMER_SPI_BOOT + bool "Enable support for SPI based flash" + select TEGRA20_SLINK + select DM_SPI_FLASH + select SPI_FLASH_WINBOND + default n + help + Tegra 3 based Transformers with Windows RT have core + boot sequence (BCT and EBT) on separate SPI FLASH + memory with 4MB size. + +endif diff --git a/board/asus/transformer-t30/MAINTAINERS b/board/asus/transformer-t30/MAINTAINERS new file mode 100644 index 0000000000..c6c15323b2 --- /dev/null +++ b/board/asus/transformer-t30/MAINTAINERS @@ -0,0 +1,15 @@ +TRANSFORMER BOARD +M: Svyatoslav Ryhel clamor95@gmail.com +S: Maintained +F: board/asus/transformer-t30/ +F: configs/p1801-t.config +F: configs/tf201.config +F: configs/tf300t.config +F: configs/tf300tg.config +F: configs/tf300tl.config +F: configs/tf600t.config +F: configs/tf700t.config +F: configs/transformer_t30_defconfig +F: doc/board/asus/transformer_t30.rst +F: include/configs/transformer-common.h +F: include/configs/transformer-t30.h diff --git a/board/asus/transformer-t30/Makefile b/board/asus/transformer-t30/Makefile new file mode 100644 index 0000000000..c083f2289b --- /dev/null +++ b/board/asus/transformer-t30/Makefile @@ -0,0 +1,11 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2010-2012 +# NVIDIA Corporation <www.nvidia.com> +# +# (C) Copyright 2021 +# Svyatoslav Ryhel clamor95@gmail.com + +obj-$(CONFIG_SPL_BUILD) += transformer-t30-spl.o + +obj-y += transformer-t30.o diff --git a/board/asus/transformer-t30/pinmux-config-transformer.h b/board/asus/transformer-t30/pinmux-config-transformer.h new file mode 100644 index 0000000000..96ff45d375 --- /dev/null +++ b/board/asus/transformer-t30/pinmux-config-transformer.h @@ -0,0 +1,365 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. + * + * Copyright (c) 2021, Svyatoslav Ryhel. + */ + +#ifndef _PINMUX_CONFIG_TRANSFORMER_H_ +#define _PINMUX_CONFIG_TRANSFORMER_H_ + +#define DEFAULT_PINMUX(_pingrp, _mux, _pull, _tri, _io) \ + { \ + .pingrp = PMUX_PINGRP_##_pingrp, \ + .func = PMUX_FUNC_##_mux, \ + .pull = PMUX_PULL_##_pull, \ + .tristate = PMUX_TRI_##_tri, \ + .io = PMUX_PIN_##_io, \ + .lock = PMUX_PIN_LOCK_DEFAULT, \ + .od = PMUX_PIN_OD_DEFAULT, \ + .ioreset = PMUX_PIN_IO_RESET_DEFAULT, \ + } + +#define I2C_PINMUX(_pingrp, _mux, _pull, _tri, _io, _lock, _od) \ + { \ + .pingrp = PMUX_PINGRP_##_pingrp, \ + .func = PMUX_FUNC_##_mux, \ + .pull = PMUX_PULL_##_pull, \ + .tristate = PMUX_TRI_##_tri, \ + .io = PMUX_PIN_##_io, \ + .lock = PMUX_PIN_LOCK_##_lock, \ + .od = PMUX_PIN_OD_##_od, \ + .ioreset = PMUX_PIN_IO_RESET_DEFAULT, \ + } + +#define LV_PINMUX(_pingrp, _mux, _pull, _tri, _io, _lock, _ioreset) \ + { \ + .pingrp = PMUX_PINGRP_##_pingrp, \ + .func = PMUX_FUNC_##_mux, \ + .pull = PMUX_PULL_##_pull, \ + .tristate = PMUX_TRI_##_tri, \ + .io = PMUX_PIN_##_io, \ + .lock = PMUX_PIN_LOCK_##_lock, \ + .od = PMUX_PIN_OD_DEFAULT, \ + .ioreset = PMUX_PIN_IO_RESET_##_ioreset \ + } + +#define DEFAULT_PADCFG(_drvgrp, _slwf, _slwr, _drvup, _drvdn, _lpmd, _schmt, _hsm) \ + { \ + .drvgrp = PMUX_DRVGRP_##_drvgrp, \ + .slwf = _slwf, \ + .slwr = _slwr, \ + .drvup = _drvup, \ + .drvdn = _drvdn, \ + .lpmd = PMUX_LPMD_##_lpmd, \ + .schmt = PMUX_SCHMT_##_schmt, \ + .hsm = PMUX_HSM_##_hsm, \ + } + +static struct pmux_pingrp_config transformer_pinmux_common[] = { + /* SDMMC1 pinmux */ + DEFAULT_PINMUX(SDMMC1_CLK_PZ0, SDMMC1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_CMD_PZ1, SDMMC1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_DAT3_PY4, SDMMC1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_DAT2_PY5, SDMMC1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_DAT1_PY6, SDMMC1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_DAT0_PY7, SDMMC1, UP, NORMAL, INPUT), + + /* SDMMC3 pinmux */ + DEFAULT_PINMUX(SDMMC3_CLK_PA6, SDMMC3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_CMD_PA7, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT0_PB7, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT1_PB6, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT2_PB5, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT3_PB4, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT4_PD1, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT5_PD0, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT6_PD3, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT7_PD4, SDMMC3, UP, NORMAL, INPUT), + + /* SDMMC4 pinmux */ + LV_PINMUX(SDMMC4_CLK_PCC4, SDMMC4, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_CMD_PT7, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT0_PAA0, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT1_PAA1, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT2_PAA2, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT3_PAA3, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT4_PAA4, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT5_PAA5, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT6_PAA6, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT7_PAA7, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_RST_N_PCC3, RSVD1, DOWN, NORMAL, INPUT, DISABLE, DISABLE), + + /* I2C pinmux */ + I2C_PINMUX(GEN1_I2C_SCL_PC4, I2C1, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(GEN1_I2C_SDA_PC5, I2C1, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(GEN2_I2C_SCL_PT5, I2C2, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(GEN2_I2C_SDA_PT6, I2C2, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(CAM_I2C_SCL_PBB1, I2C3, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(CAM_I2C_SDA_PBB2, I2C3, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(DDC_SCL_PV4, I2C4, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(DDC_SDA_PV5, I2C4, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(PWR_I2C_SCL_PZ6, I2CPWR, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(PWR_I2C_SDA_PZ7, I2CPWR, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + + /* HDMI-CEC pinmux */ + DEFAULT_PINMUX(HDMI_CEC_PEE3, CEC, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(HDMI_INT_PN7, RSVD1, NORMAL, TRISTATE, INPUT), + + /* ULPI pinmux */ + DEFAULT_PINMUX(ULPI_DATA0_PO1, UARTA, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(ULPI_DATA1_PO2, UARTA, DOWN, TRISTATE, INPUT), + DEFAULT_PINMUX(ULPI_DATA2_PO3, UARTA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_DATA3_PO4, UARTA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_DATA4_PO5, UARTA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_DATA5_PO6, UARTA, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(ULPI_DATA6_PO7, UARTA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_DATA7_PO0, UARTA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_CLK_PY0, UARTD, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(ULPI_DIR_PY1, UARTD, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(ULPI_NXT_PY2, UARTD, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(ULPI_STP_PY3, UARTD, NORMAL, TRISTATE, OUTPUT), + + /* DAP3 pinmux */ + DEFAULT_PINMUX(DAP3_FS_PP0, I2S2, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(DAP3_DIN_PP1, I2S2, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(DAP3_DOUT_PP2, I2S2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP3_SCLK_PP3, I2S2, NORMAL, NORMAL, INPUT), + + DEFAULT_PINMUX(PV0, RSVD1, UP, TRISTATE, INPUT), + DEFAULT_PINMUX(PV2, RSVD1, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PV3, RSVD1, NORMAL, TRISTATE, OUTPUT), + + /* CLK2 pinmux */ + DEFAULT_PINMUX(CLK2_OUT_PW5, EXTPERIPH2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(CLK2_REQ_PCC5, DAP, NORMAL, NORMAL, INPUT), + + /* LCD pinmux */ + DEFAULT_PINMUX(LCD_PWR1_PC1, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_PWR2_PC6, DISPLAYA, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(LCD_SDIN_PZ2, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_SDOUT_PN5, DISPLAYA, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(LCD_WR_N_PZ3, DISPLAYA, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(LCD_CS0_N_PN4, DISPLAYA, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(LCD_DC0_PN6, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_SCK_PZ4, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_PWR0_PB2, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_PCLK_PB3, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_DE_PJ1, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_HSYNC_PJ3, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_VSYNC_PJ4, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D0_PE0, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D1_PE1, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D2_PE2, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D3_PE3, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D4_PE4, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D5_PE5, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D6_PE6, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D7_PE7, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D8_PF0, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D9_PF1, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D10_PF2, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D11_PF3, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D12_PF4, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D13_PF5, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D14_PF6, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D15_PF7, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D16_PM0, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D17_PM1, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D18_PM2, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D19_PM3, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D20_PM4, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D21_PM5, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D22_PM6, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D23_PM7, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_CS1_N_PW0, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_M1_PW1, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_DC1_PD2, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(CRT_HSYNC_PV6, CRT, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(CRT_VSYNC_PV7, CRT, NORMAL, TRISTATE, OUTPUT), + + /* VI-group pinmux */ + LV_PINMUX(VI_D0_PT4, RSVD1, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D1_PD5, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D2_PL0, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D3_PL1, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D4_PL2, VI, NORMAL, NORMAL, OUTPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D5_PL3, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D6_PL4, VI, NORMAL, NORMAL, OUTPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D7_PL5, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D8_PL6, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D9_PL7, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D10_PT2, RSVD1, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D11_PT3, RSVD1, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_PCLK_PT0, RSVD1, UP, TRISTATE, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_MCLK_PT1, VI, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_HSYNC_PD7, RSVD1, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_VSYNC_PD6, RSVD1, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + + /* UART-B pinmux */ + DEFAULT_PINMUX(UART2_RXD_PC3, UARTB, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART2_TXD_PC2, UARTB, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(UART2_RTS_N_PJ6, UARTB, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(UART2_CTS_N_PJ5, UARTB, NORMAL, NORMAL, INPUT), + + /* UART-C pinmux */ + DEFAULT_PINMUX(UART3_TXD_PW6, UARTC, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(UART3_RXD_PW7, UARTC, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART3_CTS_N_PA1, UARTC, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART3_RTS_N_PC0, UARTC, NORMAL, NORMAL, OUTPUT), + + /* U-gpio group pinmux */ + DEFAULT_PINMUX(PU0, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PU1, RSVD1, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PU2, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PU3, RSVD1, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PU4, RSVD1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(PU5, PWM2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PU6, RSVD1, DOWN, NORMAL, INPUT), + + /* DAP4 pinmux */ + DEFAULT_PINMUX(DAP4_FS_PP4, I2S3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP4_DIN_PP5, I2S3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP4_DOUT_PP6, I2S3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP4_SCLK_PP7, I2S3, NORMAL, NORMAL, INPUT), + + /* CLK3 pinmux */ + DEFAULT_PINMUX(CLK3_OUT_PEE0, EXTPERIPH3, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(CLK3_REQ_PEE1, DEV3, NORMAL, TRISTATE, INPUT), + + DEFAULT_PINMUX(CAM_MCLK_PCC0, VI_ALT3, UP, NORMAL, INPUT), + + DEFAULT_PINMUX(PCC1, RSVD1, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(PBB0, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PBB3, VGP3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PBB4, VGP4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PBB5, VGP5, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PBB6, VGP6, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PBB7, I2S4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PCC2, I2S4, NORMAL, NORMAL, INPUT), + + DEFAULT_PINMUX(JTAG_RTCK_PU7, RTCK, NORMAL, NORMAL, OUTPUT), + + /* KBC keys */ + DEFAULT_PINMUX(KB_ROW0_PR0, RSVD4, UP, NORMAL, OUTPUT), + DEFAULT_PINMUX(KB_ROW1_PR1, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW2_PR2, KBC, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_ROW3_PR3, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW4_PR4, KBC, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_ROW5_PR5, KBC, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_ROW6_PR6, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW7_PR7, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW8_PS0, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW9_PS1, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW10_PS2, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW11_PS3, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW12_PS4, KBC, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_ROW13_PS5, KBC, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_ROW14_PS6, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW15_PS7, KBC, UP, NORMAL, INPUT), + + DEFAULT_PINMUX(KB_COL0_PQ0, KBC, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(KB_COL1_PQ1, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL2_PQ2, RSVD4, UP, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_COL3_PQ3, RSVD4, UP, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_COL4_PQ4, RSVD4, UP, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_COL5_PQ5, KBC, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_COL6_PQ6, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL7_PQ7, KBC, NORMAL, TRISTATE, INPUT), + + /* CLK */ + DEFAULT_PINMUX(CLK_32K_OUT_PA0, BLINK, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(SYS_CLK_REQ_PZ5, SYSCLK, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(OWR, OWR, NORMAL, NORMAL, INPUT), + + /* DAP1 pinmux */ + DEFAULT_PINMUX(DAP1_FS_PN0, I2S0, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(DAP1_DIN_PN1, I2S0, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(DAP1_DOUT_PN2, I2S0, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(DAP1_SCLK_PN3, I2S0, NORMAL, TRISTATE, INPUT), + + /* CLK1 pinmux */ + DEFAULT_PINMUX(CLK1_REQ_PEE2, DAP, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(CLK1_OUT_PW4, EXTPERIPH1, NORMAL, NORMAL, INPUT), + + /* SPDIF pinmux */ + DEFAULT_PINMUX(SPDIF_IN_PK6, SPDIF, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(SPDIF_OUT_PK5, SPDIF, NORMAL, TRISTATE, OUTPUT), + + /* DAP2 pinmux */ + DEFAULT_PINMUX(DAP2_FS_PA2, I2S1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP2_DIN_PA4, I2S1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP2_DOUT_PA5, I2S1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP2_SCLK_PA3, I2S1, NORMAL, NORMAL, INPUT), + + /* SPI pinmux */ + DEFAULT_PINMUX(SPI1_MOSI_PX4, SPI1, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(SPI1_SCK_PX5, SPI1, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(SPI1_CS0_N_PX6, SPI1, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(SPI1_MISO_PX7, SPI1, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(SPI2_SCK_PX2, GMI, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPI2_CS1_N_PW2, SPI2, UP, NORMAL, INPUT), + + /* PEX pinmux */ + DEFAULT_PINMUX(PEX_L0_PRSNT_N_PDD0, PCIE, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PEX_L0_RST_N_PDD1, PCIE, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PEX_L0_CLKREQ_N_PDD2, PCIE, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PEX_WAKE_N_PDD3, PCIE, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PEX_L1_PRSNT_N_PDD4, PCIE, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PEX_L1_RST_N_PDD5, PCIE, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PEX_L1_CLKREQ_N_PDD6, PCIE, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PEX_L2_PRSNT_N_PDD7, PCIE, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PEX_L2_RST_N_PCC6, PCIE, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PEX_L2_CLKREQ_N_PCC7, PCIE, NORMAL, NORMAL, INPUT), + + /* GMI pinmux */ + DEFAULT_PINMUX(GMI_WP_N_PC7, RSVD1, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_IORDY_PI5, RSVD1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_WAIT_PI7, RSVD1, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_ADV_N_PK0, NAND, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_CLK_PK1, NAND, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_CS2_N_PK3, RSVD1, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_CS3_N_PK4, RSVD1, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_CS7_N_PI6, NAND, UP, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD0_PG0, NAND, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_AD1_PG1, NAND, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_AD2_PG2, NAND, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_AD3_PG3, NAND, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_AD4_PG4, NAND, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD5_PG5, NAND, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD6_PG6, NAND, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_AD7_PG7, NAND, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_AD8_PH0, PWM0, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_AD9_PH1, PWM1, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_AD10_PH2, NAND, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_AD11_PH3, NAND, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_AD12_PH4, NAND, UP, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD13_PH5, NAND, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD14_PH6, NAND, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_AD15_PH7, NAND, DOWN, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_A16_PJ7, SPI4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_A17_PB0, SPI4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_A18_PB1, SPI4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_A19_PK7, SPI4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_WR_N_PI0, NAND, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_OE_N_PI1, NAND, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_DQS_PI2, NAND, NORMAL, TRISTATE, OUTPUT), +}; + +static struct pmux_pingrp_config tf700t_mipi_pinmux[] = { + DEFAULT_PINMUX(LCD_PWR2_PC6, DISPLAYA, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(LCD_DC1_PD2, DISPLAYA, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PBB3, VGP3, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PBB7, I2S4, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(SPI2_MOSI_PX0, SPI2, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(KB_ROW7_PR7, KBC, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_CS4_N_PK2, GMI, UP, NORMAL, INPUT), + DEFAULT_PINMUX(CAM_MCLK_PCC0, VI_ALT3, UP, TRISTATE, INPUT), +}; + +static struct pmux_drvgrp_config transformer_padctrl[] = { + /* (_drvgrp, _slwf, _slwr, _drvup, _drvdn, _lpmd, _schmt, _hsm) */ + DEFAULT_PADCFG(SDIO1, SDIOCFG_DRVUP_SLWF, SDIOCFG_DRVDN_SLWR, \ + SDIOCFG_DRVUP, SDIOCFG_DRVDN, NONE, DISABLE, DISABLE), +}; +#endif /* _PINMUX_CONFIG_TRANSFORMER_H_ */ diff --git a/board/asus/transformer-t30/transformer-t30-spl.c b/board/asus/transformer-t30/transformer-t30-spl.c new file mode 100644 index 0000000000..89819b2b92 --- /dev/null +++ b/board/asus/transformer-t30/transformer-t30-spl.c @@ -0,0 +1,41 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * T30 Transformers SPL stage configuration + * + * (C) Copyright 2010-2013 + * NVIDIA Corporation <www.nvidia.com> + * + * (C) Copyright 2021 + * Svyatoslav Ryhel clamor95@gmail.com + */ + +#include <common.h> +#include <asm/arch-tegra/tegra_i2c.h> +#include <linux/delay.h> + +#define TPS65911_I2C_ADDR (0x2D << 1) +#define TPS65911_VDDCTRL_OP_REG 0x28 +#define TPS65911_VDDCTRL_SR_REG 0x27 +#define TPS65911_VDDCTRL_OP_DATA (0x2400 | TPS65911_VDDCTRL_OP_REG) +#define TPS65911_VDDCTRL_SR_DATA (0x0100 | TPS65911_VDDCTRL_SR_REG) + +#define TPS62361B_I2C_ADDR (0x60 << 1) +#define TPS62361B_SET3_REG 0x03 +#define TPS62361B_SET3_DATA (0x4600 | TPS62361B_SET3_REG) + +void pmic_enable_cpu_vdd(void) +{ + /* Set VDD_CORE to 1.200V. */ + tegra_i2c_ll_write(TPS62361B_I2C_ADDR, TPS62361B_SET3_DATA); + + udelay(1000); + + /* + * Bring up CPU VDD via the TPS65911x PMIC on the DVC I2C bus. + * First set VDD to 1.0125V, then enable the VDD regulator. + */ + tegra_i2c_ll_write(TPS65911_I2C_ADDR, TPS65911_VDDCTRL_OP_DATA); + udelay(1000); + tegra_i2c_ll_write(TPS65911_I2C_ADDR, TPS65911_VDDCTRL_SR_DATA); + udelay(10 * 1000); +} diff --git a/board/asus/transformer-t30/transformer-t30.c b/board/asus/transformer-t30/transformer-t30.c new file mode 100644 index 0000000000..b6fd19d28e --- /dev/null +++ b/board/asus/transformer-t30/transformer-t30.c @@ -0,0 +1,201 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2010-2013 + * NVIDIA Corporation <www.nvidia.com> + * + * (C) Copyright 2021 + * Svyatoslav Ryhel clamor95@gmail.com + */ + +/* T30 Transformers derive from Cardhu board */ + +#include <common.h> +#include <dm.h> +#include <env.h> +#include <fdt_support.h> +#include <i2c.h> +#include <log.h> +#include <asm/arch/pinmux.h> +#include <asm/arch/gp_padctrl.h> +#include <asm/arch/gpio.h> +#include <asm/arch-tegra/fuse.h> +#include <asm/gpio.h> +#include <linux/delay.h> +#include "pinmux-config-transformer.h" + +#define TPS65911_I2C_ADDRESS 0x2D + +#define TPS65911_VDD1 0x21 +#define TPS65911_VDD1_OP 0x22 +#define TPS65911_LDO1 0x30 +#define TPS65911_LDO2 0x31 +#define TPS65911_LDO3 0x37 +#define TPS65911_LDO5 0x32 +#define TPS65911_LDO6 0x35 + +#define TPS65911_GPIO0 0x60 +#define TPS65911_GPIO6 0x66 +#define TPS65911_GPIO7 0x67 +#define TPS65911_GPIO8 0x68 + +#define TPS65911_DEVCTRL 0x3F +#define DEVCTRL_PWR_OFF_MASK BIT(7) +#define DEVCTRL_DEV_ON_MASK BIT(2) +#define DEVCTRL_DEV_OFF_MASK BIT(0) + +#ifdef CONFIG_CMD_POWEROFF +int do_poweroff(struct cmd_tbl *cmdtp, int flag, + int argc, char *const argv[]) +{ + struct udevice *dev; + uchar data_buffer[1]; + int ret; + + ret = i2c_get_chip_for_busnum(0, TPS65911_I2C_ADDRESS, 1, &dev); + if (ret) { + log_debug("cannot find PMIC I2C chip\n"); + return 0; + } + + ret = dm_i2c_read(dev, TPS65911_DEVCTRL, data_buffer, 1); + if (ret) + return ret; + + data_buffer[0] |= DEVCTRL_PWR_OFF_MASK; + + ret = dm_i2c_write(dev, TPS65911_DEVCTRL, data_buffer, 1); + if (ret) + return ret; + + data_buffer[0] |= DEVCTRL_DEV_OFF_MASK; + data_buffer[0] &= ~DEVCTRL_DEV_ON_MASK; + + ret = dm_i2c_write(dev, TPS65911_DEVCTRL, data_buffer, 1); + if (ret) + return ret; + + // wait some time and then print error + mdelay(5000); + printf("Failed to power off!!!\n"); + return 1; +} +#endif + +/* + * Routine: pinmux_init + * Description: Do individual peripheral pinmux configs + */ +void pinmux_init(void) +{ + pinmux_config_pingrp_table(transformer_pinmux_common, + ARRAY_SIZE(transformer_pinmux_common)); + + pinmux_config_drvgrp_table(transformer_padctrl, + ARRAY_SIZE(transformer_padctrl)); + + if (of_machine_is_compatible("asus,tf700t")) { + pinmux_config_pingrp_table(tf700t_mipi_pinmux, + ARRAY_SIZE(tf700t_mipi_pinmux)); + } +} + +#ifdef CONFIG_MMC_SDHCI_TEGRA +static void tps65911_voltage_init(void) +{ + struct udevice *dev; + int ret; + + ret = i2c_get_chip_for_busnum(0, TPS65911_I2C_ADDRESS, 1, &dev); + if (ret) { + log_debug("cannot find PMIC I2C chip\n"); + return; + } + + /* TPS659110: LDO1_REG = 3.3v, ACTIVE to SDMMC4 */ + ret = dm_i2c_reg_write(dev, TPS65911_LDO1, 0xc9); + if (ret) + log_debug("vcore_emmc set failed: %d\n", ret); + + if (of_machine_is_compatible("asus,tf600t")) { + /* TPS659110: VDD1_REG = 1.2v, ACTIVE to backlight */ + ret = dm_i2c_reg_write(dev, TPS65911_VDD1_OP, 0x33); + if (ret) + log_debug("vdd_bl set failed: %d\n", ret); + + ret = dm_i2c_reg_write(dev, TPS65911_VDD1, 0x0d); + if (ret) + log_debug("vdd_bl enable failed: %d\n", ret); + + /* TPS659110: LDO5_REG = 3.3v, ACTIVE to SDMMC1 VIO */ + ret = dm_i2c_reg_write(dev, TPS65911_LDO5, 0x65); + if (ret) + log_debug("vdd_usd set failed: %d\n", ret); + + /* TPS659110: LDO6_REG = 1.2v, ACTIVE to MIPI */ + ret = dm_i2c_reg_write(dev, TPS65911_LDO6, 0x11); + if (ret) + log_debug("vdd_mipi set failed: %d\n", ret); + } else { + /* TPS659110: LDO2_REG = 3.1v, ACTIVE to SDMMC1 */ + ret = dm_i2c_reg_write(dev, TPS65911_LDO2, 0xb9); + if (ret) + log_debug("vdd_usd set failed: %d\n", ret); + + /* TPS659110: LDO3_REG = 3.1v, ACTIVE to SDMMC1 VIO */ + ret = dm_i2c_reg_write(dev, TPS65911_LDO3, 0x5d); + if (ret) + log_debug("vddio_usd set failed: %d\n", ret); + } + + /* TPS659110: GPIO0_REG output high to VDD_5V0_SBY */ + ret = dm_i2c_reg_write(dev, TPS65911_GPIO0, 0x07); + if (ret) + log_debug("vdd_5v0_sby set failed: %d\n", ret); + + /* TPS659110: GPIO6_REG output high to VDD_3V3_SYS */ + ret = dm_i2c_reg_write(dev, TPS65911_GPIO6, 0x07); + if (ret) + log_debug("vdd_3v3_sys set failed: %d\n", ret); + + /* TPS659110: GPIO7_REG output high to VDD_1V5_DDR */ + ret = dm_i2c_reg_write(dev, TPS65911_GPIO7, 0x07); + if (ret) + log_debug("vdd_1v5_ddr set failed: %d\n", ret); + + /* TPS659110: GPIO8_REG pull_down output high to VDD_5V0_SYS */ + ret = dm_i2c_reg_write(dev, TPS65911_GPIO8, 0x0f); + if (ret) + log_debug("vdd_5v0_sys set failed: %d\n", ret); +} + +/* + * Routine: pin_mux_mmc + * Description: setup the MMC muxes, power rails, etc. + */ +void pin_mux_mmc(void) +{ + /* Bring up uSD and eMMC power */ + tps65911_voltage_init(); +} +#endif /* MMC */ + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +int ft_board_setup(void *blob, struct bd_info *bd) +{ + /* Remove TrustZone nodes */ + fdt_del_node_and_alias(blob, "/firmware"); + fdt_del_node_and_alias(blob, "/reserved-memory/trustzone@bfe00000"); + + return 0; +} +#endif + +void nvidia_board_late_init(void) +{ + char serialno_str[17]; + + /* Set chip id as serialno */ + sprintf(serialno_str, "%016llx", tegra_chip_uid()); + env_set("serial#", serialno_str); + env_set("platform", "Tegra 3 T30"); +} diff --git a/configs/p1801-t.config b/configs/p1801-t.config new file mode 100644 index 0000000000..fab2912132 --- /dev/null +++ b/configs/p1801-t.config @@ -0,0 +1,2 @@ +CONFIG_DEFAULT_DEVICE_TREE="tegra30-asus-p1801-t" +CONFIG_USB_GADGET_PRODUCT_NUM=0x4cb0 diff --git a/configs/tf201.config b/configs/tf201.config new file mode 100644 index 0000000000..296743b774 --- /dev/null +++ b/configs/tf201.config @@ -0,0 +1,2 @@ +CONFIG_DEFAULT_DEVICE_TREE="tegra30-asus-tf201" +CONFIG_USB_GADGET_PRODUCT_NUM=0x4d00 diff --git a/configs/tf300t.config b/configs/tf300t.config new file mode 100644 index 0000000000..32a92fe76f --- /dev/null +++ b/configs/tf300t.config @@ -0,0 +1,2 @@ +CONFIG_DEFAULT_DEVICE_TREE="tegra30-asus-tf300t" +CONFIG_USB_GADGET_PRODUCT_NUM=0x4d00 diff --git a/configs/tf300tg.config b/configs/tf300tg.config new file mode 100644 index 0000000000..1396294f6d --- /dev/null +++ b/configs/tf300tg.config @@ -0,0 +1,2 @@ +CONFIG_DEFAULT_DEVICE_TREE="tegra30-asus-tf300tg" +CONFIG_USB_GADGET_PRODUCT_NUM=0x4c80 diff --git a/configs/tf300tl.config b/configs/tf300tl.config new file mode 100644 index 0000000000..3db033c8df --- /dev/null +++ b/configs/tf300tl.config @@ -0,0 +1,2 @@ +CONFIG_DEFAULT_DEVICE_TREE="tegra30-asus-tf300tl" +CONFIG_USB_GADGET_PRODUCT_NUM=0x4d00 diff --git a/configs/tf600t.config b/configs/tf600t.config new file mode 100644 index 0000000000..89d8db4eb1 --- /dev/null +++ b/configs/tf600t.config @@ -0,0 +1,4 @@ +CONFIG_DEFAULT_DEVICE_TREE="tegra30-asus-tf600t" +CONFIG_TRANSFORMER_SPI_BOOT=y +CONFIG_BOOTCOMMAND="setenv gpio_button 222; if run check_button; then poweroff; fi; setenv gpio_button 132; if run check_button; then echo Starting SPI flash update ...; run update_spi; fi; run bootcmd_mmc1; run bootcmd_mmc0; poweroff;" +CONFIG_USB_GADGET_PRODUCT_NUM=0x4d00 diff --git a/configs/tf700t.config b/configs/tf700t.config new file mode 100644 index 0000000000..066c884d08 --- /dev/null +++ b/configs/tf700t.config @@ -0,0 +1,2 @@ +CONFIG_DEFAULT_DEVICE_TREE="tegra30-asus-tf700t" +CONFIG_USB_GADGET_PRODUCT_NUM=0x4c90 diff --git a/configs/transformer_t30_defconfig b/configs/transformer_t30_defconfig new file mode 100644 index 0000000000..6fe6f2548d --- /dev/null +++ b/configs/transformer_t30_defconfig @@ -0,0 +1,85 @@ +CONFIG_ARM=y +CONFIG_SYS_L2CACHE_OFF=y +CONFIG_ARCH_TEGRA=y +CONFIG_SUPPORT_PASSING_ATAGS=y +CONFIG_CMDLINE_TAG=y +CONFIG_INITRD_TAG=y +CONFIG_TEXT_BASE=0x80110000 +CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SIZE=0x3000 +CONFIG_ENV_OFFSET=0xFFFFD000 +CONFIG_DEFAULT_DEVICE_TREE="tegra30-asus-tf201" +CONFIG_SPL_TEXT_BASE=0x80108000 +CONFIG_SYS_PROMPT="Tegra30 (Transformer) # " +CONFIG_SPL_STACK=0x800ffffc +CONFIG_TEGRA30=y +CONFIG_TARGET_TRANSFORMER_T30=y +CONFIG_CMD_EBTUPDATE=y +CONFIG_SYS_LOAD_ADDR=0x82000000 +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_BOOTDELAY=0 +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_KEYED_CTRLC=y +CONFIG_USE_BOOTCOMMAND=y +CONFIG_BOOTCOMMAND="setenv gpio_button 150; if run check_button; then poweroff; fi; setenv gpio_button 131; if run check_button; then bootmenu; fi; run bootcmd_mmc1; run bootcmd_mmc0; poweroff;" +CONFIG_SPL_FOOTPRINT_LIMIT=y +CONFIG_SPL_MAX_FOOTPRINT=0x8000 +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SYS_SPL_MALLOC=y +CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y +CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80090000 +CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SYS_MAXARGS=64 +CONFIG_SYS_PBSIZE=2084 +CONFIG_CMD_BOOTMENU=y +# CONFIG_CMD_IMI is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_GPT_RENAME=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_POWEROFF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_UMS_ABORT_KEYED=y +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_NFS is not set +CONFIG_CMD_PAUSE=y +CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_ENV_OVERWRITE=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_PART=2 +CONFIG_SPL_DM=y +CONFIG_BUTTON=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x91000000 +CONFIG_FASTBOOT_BUF_SIZE=0x10000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_FASTBOOT_CMD_OEM_FORMAT=y +CONFIG_GPIO_HOG=y +CONFIG_SYS_I2C_TEGRA=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_GPIO=y +CONFIG_BUTTON_KEYBOARD=y +CONFIG_DM_PMIC=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_PWM_TEGRA=y +CONFIG_SYS_NS16550=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_TEGRA=y +CONFIG_USB_KEYBOARD=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="ASUS" +CONFIG_USB_GADGET_VENDOR_NUM=0x0b05 +CONFIG_CI_UDC=y +CONFIG_VIDEO=y +# CONFIG_VIDEO_LOGO is not set +CONFIG_VIDEO_TEGRA20=y +# CONFIG_CMD_BOOTEFI_BOOTMGR is not set diff --git a/doc/board/asus/index.rst b/doc/board/asus/index.rst new file mode 100644 index 0000000000..c59571c8b3 --- /dev/null +++ b/doc/board/asus/index.rst @@ -0,0 +1,9 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +ASUS +==== + +.. toctree:: + :maxdepth: 2 + + transformer_t30 diff --git a/doc/board/asus/transformer_t30.rst b/doc/board/asus/transformer_t30.rst new file mode 100644 index 0000000000..b6b6101540 --- /dev/null +++ b/doc/board/asus/transformer_t30.rst @@ -0,0 +1,116 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +U-Boot for the ASUS Transformer device family +============================================= + +``DISCLAMER!`` Moving your ASUS Transformer to use U-Boot +assumes replacement of the vendor ASUS bootloader. Vendor +android firmwares will no longer be able to run on the device. +This replacement IS reversible. + +Quick Start +----------- + +- Build U-Boot +- Pack U-Boot into repart-block +- Flash repart-block into the eMMC +- Flash repart-block into TF600T SPI flash +- Boot +- Self Upgrading + +Build U-Boot +------------ + +Device support is implemented by applying config fragment +to a generic board defconfig. Valid fragments are ``tf201.config``, +``tf300t.config``, ``tf300tg.config``, ``tf300tl.config``, +``tf700t.config``, ``tf600t.config`` and ``p1801-t.config``. + +.. code-block:: bash + + $ export CROSS_COMPILE=arm-linux-gnueabi- + $ make transformer_t30_defconfig tf201.config # For TF201 + $ make + +After the build succeeds, you will obtain the final ``u-boot-dtb-tegra.bin`` +image, ready for flashing (but check the next section for additional +adjustments). + +Pack U-Boot into repar-block +---------------------------- + +``DISCLAMER!`` All questions related to re-crypt work should be asked +in re-crypt repo issues. NOT HERE! + +re-crypt is a small script which packs ``u-boot-dtb-tegra.bin`` in +form usable by device. This process is required only on the first +installation or to recover the device in case of a failed update. +You need to know your tablet's individual SBK to continue. + +.. code-block:: bash + + $ git clone https://github.com/clamor-s/re-crypt.git + $ cd re-crypt # place your u-boot-dtb-regra.bin here + $ ./re-crypt.sh -d tf201 -k deadbeefdeadc0dedeadd00dfee1dead + +Script will produce you a `repart-block.bin` ready to flash. + +Flash repart-block into the eMMC +-------------------------------- + +``DISCLAMER!`` All questions related to NvFlash should be asked +in the proper place. NOT HERE! Flashing repart-block will erase +all your eMMC, so make a backup before! + +``repart-block.bin`` contains BCT and bootloader in encrypted state +in form which can just be written RAW at the start of eMMC. + +.. code-block:: bash + + $ wheelie --blob blob.bin + $ nvflash --resume --rawdevicewrite 0 1024 repart-block.bin + +Flash repart-block into TF600T SPI flash +---------------------------------------- + +Unlike other transformers TF600T uses separate 4 MB SPI flash which +contains all data required for boot. It is flashed from within u-boot +itself preloaded into RAM using fusee gelee. After creating your +``repart-block.bin`` you have to place it on a 1st partition of microSD +card formated in fat. Then insert this microSD card into your tablet +and boot it using fusee gelee and u-boot which was included into +repart-block.bin, while booting you must hold volume down button. +Process should take less then a minute, if everything goes correct, +on microSD will appear ``spi-flash-backup.bin`` file, which is dump of +your spi flash content and can be used to restore UEFI, do not loose it, +tablet will power itself off. + +Self-updating of u-boot is performed by placing ``u-boot-dtb-tegra.bin`` +on 1st partition of microSD, inserting it into tablet and booting with +pressed volume down button. + +Boot +---- + +After flashing ``repart-block.bin`` the device should reboot and turn +itself off. This is normal behavior if no boot configuration is +found. + +To boot Linux, U-Boot will look for an ``extlinux.conf`` on MicroSD +and then on eMMC. Additionally if Volume Down button is pressed +while booting device will enter bootmenu. Bootmenu contains entries +to mount MicroSD and eMMC as mass storage, fastboot, reboot, reboot +RCM, poweroff, enter U-Boot console and update bootloader (check next +chapter). + +Flashing ``repart-block.bin`` eliminates vendor restriction on eMMC +and allows the user to use/partition it in any way the user desires. + +Self Upgrading +-------------- + +Place your ``u-boot-dtb-tegra.bin`` on the first partition of the +MicroSD card and insert it into the tablet. Enter bootmenu, choose +update bootloader option with Power button and U-Boot should update +itself. Once the process is completed, U-Boot will ask to press any +button to reboot. diff --git a/doc/board/index.rst b/doc/board/index.rst index 9ef25b1091..d28d8e1874 100644 --- a/doc/board/index.rst +++ b/doc/board/index.rst @@ -14,6 +14,7 @@ Board-specific doc anbernic/index apple/index armltd/index + asus/index atmel/index beacon/index broadcom/index diff --git a/include/configs/transformer-common.h b/include/configs/transformer-common.h new file mode 100644 index 0000000000..dcdda1ec5b --- /dev/null +++ b/include/configs/transformer-common.h @@ -0,0 +1,94 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2022, Svyatoslav Ryhel clamor95@gmail.com. + */ + +#ifndef __TRANSFORMER_COMMON_H +#define __TRANSFORMER_COMMON_H + +/* High-level configuration options */ +#define CFG_TEGRA_BOARD_STRING "ASUS Transformer" + +#define TRANSFORMER_FLASH_UBOOT \ + "flash_uboot=echo Preparing RAM;" \ + "mw ${kernel_addr_r} 0 ${boot_block_size_r};" \ + "mw ${ramdisk_addr_r} 0 ${boot_block_size_r};" \ + "echo Reading BCT;" \ + "mmc dev 0 1;" \ + "mmc read ${kernel_addr_r} 0 ${boot_block_size};" \ + "echo Reading bootloader;" \ + "if load mmc 1:1 ${ramdisk_addr_r} ${bootloader_file};" \ + "then echo Calculating bootloader size;" \ + "size mmc 1:1 ${bootloader_file};" \ + "ebtupdate ${kernel_addr_r} ${ramdisk_addr_r} ${filesize};" \ + "echo Writing bootloader to eMMC;" \ + "mmc dev 0 1;" \ + "mmc write ${kernel_addr_r} 0 ${boot_block_size};" \ + "mmc dev 0 2;" \ + "mmc write ${ramdisk_addr_r} 0 ${boot_block_size};" \ + "echo Bootloader written successfully;" \ + "pause 'Press ANY key to reboot device...'; reset;" \ + "else echo Reading bootloader failed;" \ + "pause 'Press ANY key to return to bootmenu...'; bootmenu; fi\0" + +#define TRANSFORMER_FLASH_SPI \ + "update_spi=sf probe 0:1;" \ + "echo Dumping current SPI flash content ...;" \ + "sf read ${kernel_addr_r} 0x0 ${spi_size};" \ + "if fatwrite mmc 1:1 ${kernel_addr_r} spi-flash-backup.bin ${spi_size};" \ + "then echo SPI flash content was successfully written into spi-flash-backup.bin;" \ + "echo Reading SPI flash binary;" \ + "if load mmc 1:1 ${kernel_addr_r} repart-block.bin;" \ + "then echo Writing bootloader into SPI flash;" \ + "sf probe 0:1;" \ + "sf update ${kernel_addr_r} 0x0 ${spi_size};" \ + "poweroff;" \ + "else echo Preparing RAM;" \ + "mw ${kernel_addr_r} 0 ${boot_block_size_r};" \ + "mw ${ramdisk_addr_r} 0 ${boot_block_size_r};" \ + "echo Reading BCT;" \ + "sf read ${kernel_addr_r} 0x0 ${boot_block_size_r};" \ + "echo Reading bootloader;" \ + "if load mmc 1:1 ${ramdisk_addr_r} ${bootloader_file};" \ + "then echo Calculating bootloader size;" \ + "size mmc 1:1 ${bootloader_file};" \ + "ebtupdate ${kernel_addr_r} ${ramdisk_addr_r} ${filesize};" \ + "echo Writing bootloader into SPI flash;" \ + "sf probe 0:1;" \ + "sf update ${kernel_addr_r} 0x0 ${boot_block_size_r};" \ + "sf update ${ramdisk_addr_r} ${boot_block_size_r} ${boot_block_size_r};" \ + "echo Bootloader written successfully; poweroff;" \ + "else echo Reading bootloader failed;" \ + "poweroff; fi;" \ + "fi;" \ + "else echo SPI flash backup FAILED! Aborting ...;" \ + "poweroff; fi\0" + +#define TRANSFORMER_REFRESH_USB \ + "refresh_usb=usb start; usb reset; usb tree; usb info;" \ + "pause 'Press ANY key to return to bootmenu...'; bootmenu\0" + +#define TRANSFORMER_BOOTMENU \ + TRANSFORMER_FLASH_UBOOT \ + TRANSFORMER_FLASH_SPI \ + TRANSFORMER_REFRESH_USB \ + "bootmenu_0=mount internal storage=usb start && ums 0 mmc 0; bootmenu\0" \ + "bootmenu_1=mount external storage=usb start && ums 0 mmc 1; bootmenu\0" \ + "bootmenu_2=fastboot=echo Starting Fastboot protocol ...; fastboot usb 0; bootmenu\0" \ + "bootmenu_3=update bootloader=run flash_uboot\0" \ + "bootmenu_4=refresh USB=run refresh_usb\0" \ + "bootmenu_5=reboot RCM=enterrcm\0" \ + "bootmenu_6=reboot=reset\0" \ + "bootmenu_7=power off=poweroff\0" \ + "bootmenu_delay=-1\0" + +#define BOARD_EXTRA_ENV_SETTINGS \ + "spi_size=0x400000\0" \ + "boot_block_size_r=0x200000\0" \ + "boot_block_size=0x1000\0" \ + "check_button=gpio input ${gpio_button}; test $? -eq 0;\0" \ + "bootloader_file=u-boot-dtb-tegra.bin\0" \ + "partitions=name=emmc,start=0,size=-,uuid=${uuid_gpt_rootfs}\0" \ + TRANSFORMER_BOOTMENU + +#endif /* __CONFIG_H */ diff --git a/include/configs/transformer-t30.h b/include/configs/transformer-t30.h new file mode 100644 index 0000000000..d2a16f12c1 --- /dev/null +++ b/include/configs/transformer-t30.h @@ -0,0 +1,23 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * (C) Copyright 2010,2012 + * NVIDIA Corporation <www.nvidia.com> + * + * (C) Copyright 2022 + * Svyatoslav Ryhel clamor95@gmail.com + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <linux/sizes.h> + +#include "tegra30-common.h" +#include "transformer-common.h" + +/* Board-specific serial config */ +#define CFG_SYS_NS16550_COM1 NV_PA_APB_UARTA_BASE + +#include "tegra-common-post.h" + +#endif /* __CONFIG_H */
On Fri, Jun 23, 2023 at 08:55:57AM +0300, Svyatoslav Ryhel wrote: [...]
- Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved.
- Copyright (c) 2021, Svyatoslav Ryhel.
I don't recall if we discussed this during upstreaming of the Linux device tree files, but shortly after the initial support for Tegra20 and Tegra30 was upstreamed (both in U-Boot and in Linux) we decided to move towards generating the pinmux configuration for the various consumers (i.e. U-Boot and Linux) from data tables using a set of scripts. This was done because we noticed that various inconsistencies kept creeping into the various drivers/tables.
You can find the scripts for this here:
https://github.com/NVIDIA/tegra-pinmux-scripts
I think there'd be some benefit if these new boards were also converted to use these scripts.
Thierry
23 червня 2023 р. 14:32:30 GMT+03:00, Thierry Reding thierry.reding@gmail.com написав(-ла):
True, but there is no driver for pinmux which can utilize device tree, instead u-boot relies on board header. I see the benefit of these pinmux nodes only if I can verify that they are correct and do not brake devices. Would be really bad if at some point devices brake cause nodes were not tested.
Additionally, shouldn't all supported boards be converted first?
Thierry
The above repository contains a script that will generate the board headers for U-Boot based on a more generic definition of the pinmux configuration. Many devices already have headers that were generated from those scripts, though it's mostly later boards (Tegra124 and onwards).
That said, for many of these boards a spreadsheet exists that contains these settings and the tables are generated from that spreadsheet. For many of these OEM devices I suspect no such spreadsheet exists, and it doesn't necessarily make sense to transcribe this into the tables and then convert into board header & DTS snippets. It might be nice to do for consistency, but I'll leave it up to you.
The repository has been in an archived state since there wasn't any activity on it for a long time and I guess we didn't expect any new boards to be added at this point. If needed we could revive this.
Thierry
23 червня 2023 р. 17:11:35 GMT+03:00, Thierry Reding thierry.reding@gmail.com написав(-ла):
Current tables are dumped from working vendor kernels. It is not that I like this approach, but I would rather leave an existing setup since it is well tested and confirmed to be stable enough. No one knows what htc and asus did with those pins, at least publicly.
That should not be necessary, though, thanks for proposition.
Thierry
Okay, fair enough.
Thierry
Nexus 7 is a mini tablet computer co-developed by Google and Asus that runs the Android operating system. The Nexus 7 features a 7" display, an Nvidia Tegra 3 quad-core chip, 1 GB of RAM and 8/16 GB of internal storage.
This patch brings support for all 3 known ASUS/Google devices: - Nexus 7 (2012) E1565 - Nexus 7 (2012) PM269 - Nexus 7 (2012) 3G - tilapia
Tested-by: Andreas Westman Dorcsak hedmoo@yahoo.com # ASUS Grouper E1565 Tested-by: Svyatoslav Ryhel clamor95@gmail.com # ASUS Grouper E1565 Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- arch/arm/dts/Makefile | 3 + arch/arm/dts/tegra30-asus-grouper-common.dtsi | 157 ++++++++ .../dts/tegra30-asus-nexus7-grouper-E1565.dts | 43 +++ .../dts/tegra30-asus-nexus7-grouper-PM269.dts | 36 ++ .../dts/tegra30-asus-nexus7-tilapia-E1565.dts | 62 +++ arch/arm/mach-tegra/tegra30/Kconfig | 5 + board/asus/grouper/Kconfig | 22 ++ board/asus/grouper/MAINTAINERS | 10 + board/asus/grouper/Makefile | 14 + board/asus/grouper/grouper-spl-max.c | 45 +++ board/asus/grouper/grouper-spl-ti.c | 41 ++ board/asus/grouper/grouper.c | 202 ++++++++++ board/asus/grouper/pinmux-config-grouper.h | 362 ++++++++++++++++++ configs/grouper_E1565.config | 2 + configs/grouper_PM269.config | 2 + configs/grouper_common_defconfig | 84 ++++ configs/tilapia.config | 3 + doc/board/asus/grouper_common.rst | 94 +++++ doc/board/asus/index.rst | 1 + include/configs/grouper.h | 61 +++ 20 files changed, 1249 insertions(+) create mode 100644 arch/arm/dts/tegra30-asus-grouper-common.dtsi create mode 100644 arch/arm/dts/tegra30-asus-nexus7-grouper-E1565.dts create mode 100644 arch/arm/dts/tegra30-asus-nexus7-grouper-PM269.dts create mode 100644 arch/arm/dts/tegra30-asus-nexus7-tilapia-E1565.dts create mode 100644 board/asus/grouper/Kconfig create mode 100644 board/asus/grouper/MAINTAINERS create mode 100644 board/asus/grouper/Makefile create mode 100644 board/asus/grouper/grouper-spl-max.c create mode 100644 board/asus/grouper/grouper-spl-ti.c create mode 100644 board/asus/grouper/grouper.c create mode 100644 board/asus/grouper/pinmux-config-grouper.h create mode 100644 configs/grouper_E1565.config create mode 100644 configs/grouper_PM269.config create mode 100644 configs/grouper_common_defconfig create mode 100644 configs/tilapia.config create mode 100644 doc/board/asus/grouper_common.rst create mode 100644 include/configs/grouper.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index c87729d45e..f2b4044a01 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -237,6 +237,9 @@ dtb-$(CONFIG_ARCH_TEGRA) += tegra20-harmony.dtb \ tegra20-ventana.dtb \ tegra20-colibri.dtb \ tegra30-apalis.dtb \ + tegra30-asus-nexus7-grouper-PM269.dtb \ + tegra30-asus-nexus7-grouper-E1565.dtb \ + tegra30-asus-nexus7-tilapia-E1565.dtb \ tegra30-asus-p1801-t.dtb \ tegra30-asus-tf201.dtb \ tegra30-asus-tf300t.dtb \ diff --git a/arch/arm/dts/tegra30-asus-grouper-common.dtsi b/arch/arm/dts/tegra30-asus-grouper-common.dtsi new file mode 100644 index 0000000000..4fa980f24f --- /dev/null +++ b/arch/arm/dts/tegra30-asus-grouper-common.dtsi @@ -0,0 +1,157 @@ +// SPDX-License-Identifier: GPL-2.0 + +#include <dt-bindings/input/input.h> + +#include "tegra30.dtsi" + +/ { + chosen { + stdout-path = &uarta; + }; + + aliases { + i2c0 = &pwr_i2c; + + mmc0 = &sdmmc4; /* eMMC */ + + rtc0 = &pmic; + rtc1 = "/rtc@7000e000"; + + usb0 = &usb1; + }; + + memory { + device_type = "memory"; + reg = <0x80000000 0x40000000>; + }; + + host1x@50000000 { + dc@54200000 { + nvidia,180-rotation; + rgb { + status = "okay"; + + nvidia,panel = <&panel>; + }; + }; + }; + + gpio@6000d000 { + volume-buttons-hog { + gpio-hog; + gpios = <TEGRA_GPIO(R, 0) GPIO_ACTIVE_HIGH>, + <TEGRA_GPIO(Q, 0) GPIO_ACTIVE_HIGH>; + output-low; + }; + }; + + uarta: serial@70006000 { + status = "okay"; + }; + + pwm: pwm@7000a000 { + status = "okay"; + }; + + pwr_i2c: i2c@7000d000 { + status = "okay"; + clock-frequency = <400000>; + }; + + sdmmc4: sdhci@78000600 { + status = "okay"; + bus-width = <8>; + non-removable; + }; + + usb1: usb@7d000000 { + status = "okay"; + dr_mode = "otg"; + }; + + backlight: backlight { + compatible = "pwm-backlight"; + + enable-gpios = <&gpio TEGRA_GPIO(H, 2) GPIO_ACTIVE_HIGH>; + power-supply = <&vdd_5v0_bl>; + pwms = <&pwm 0 50000>; + + brightness-levels = <1 35 70 105 140 175 210 255>; + default-brightness-level = <5>; + }; + + /* PMIC has a built-in 32KHz oscillator which is used by PMC */ + clk32k_in: clock-32k { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + clock-output-names = "pmic-oscillator"; + }; + + gpio-keys { + compatible = "gpio-keys"; + + key-power { + label = "Power"; + gpios = <&gpio TEGRA_GPIO(V, 0) GPIO_ACTIVE_LOW>; + linux,code = <KEY_ENTER>; + }; + + key-volume-up { + label = "Volume Up"; + gpios = <&gpio TEGRA_GPIO(Q, 2) GPIO_ACTIVE_LOW>; + linux,code = <KEY_UP>; + }; + + key-volume-down { + label = "Volume Down"; + gpios = <&gpio TEGRA_GPIO(Q, 3) GPIO_ACTIVE_LOW>; + linux,code = <KEY_DOWN>; + }; + }; + + panel: panel { + compatible = "simple-panel"; + + power-supply = <&vdd_pnl_reg>; + enable-gpios = <&gpio TEGRA_GPIO(N, 6) GPIO_ACTIVE_HIGH>; + + backlight = <&backlight>; + + display-timings { + timing@0 { + /* 1280x800@60Hz */ + clock-frequency = <68000000>; + + hactive = <800>; + hfront-porch = <24>; + hback-porch = <32>; + hsync-len = <24>; + + vactive = <1280>; + vfront-porch = <5>; + vback-porch = <32>; + vsync-len = <1>; + }; + }; + }; + + vdd_pnl_reg: regulator-pnl { + compatible = "regulator-fixed"; + regulator-name = "vdd_panel"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio TEGRA_GPIO(W, 1) GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + vdd_5v0_bl: regulator-bl { + compatible = "regulator-fixed"; + regulator-name = "vdd_5v0_bl"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-boot-on; + gpio = <&gpio TEGRA_GPIO(H, 3) GPIO_ACTIVE_HIGH>; + enable-active-high; + }; +}; diff --git a/arch/arm/dts/tegra30-asus-nexus7-grouper-E1565.dts b/arch/arm/dts/tegra30-asus-nexus7-grouper-E1565.dts new file mode 100644 index 0000000000..a98d3e2145 --- /dev/null +++ b/arch/arm/dts/tegra30-asus-nexus7-grouper-E1565.dts @@ -0,0 +1,43 @@ +// SPDX-License-Identifier: GPL-2.0 +/dts-v1/; + +#include "tegra30-asus-grouper-common.dtsi" + +/ { + model = "ASUS Google Nexus 7 (Project Nakasi / ME370T) E1565"; + compatible = "asus,grouper", "nvidia,tegra30"; + + i2c@7000d000 { + pmic: max77663@3c { + compatible = "maxim,max77663"; + reg = <0x3c>; + + interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; + #interrupt-cells = <2>; + interrupt-controller; + + system-power-controller; + + #gpio-cells = <2>; + gpio-controller; + + regulators { + vdd_1v8: sd2 { + regulator-name = "vdd_1v8_gen"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + }; + + /* eMMC VDD */ + vcore_emmc: ldo3 { + regulator-name = "vcore_emmc"; + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <3100000>; + regulator-always-on; + }; + }; + }; + }; +}; diff --git a/arch/arm/dts/tegra30-asus-nexus7-grouper-PM269.dts b/arch/arm/dts/tegra30-asus-nexus7-grouper-PM269.dts new file mode 100644 index 0000000000..44ea218a47 --- /dev/null +++ b/arch/arm/dts/tegra30-asus-nexus7-grouper-PM269.dts @@ -0,0 +1,36 @@ +// SPDX-License-Identifier: GPL-2.0 +/dts-v1/; + +#include "tegra30-asus-grouper-common.dtsi" + +/ { + model = "ASUS Google Nexus 7 (Project Nakasi / ME370T) PM269"; + compatible = "asus,grouper", "nvidia,tegra30"; + + i2c@7000d000 { + /* Texas Instruments TPS659110 PMIC */ + pmic: tps65911@2d { + compatible = "ti,tps65911"; + reg = <0x2d>; + + interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; + #interrupt-cells = <2>; + interrupt-controller; + + ti,system-power-controller; + + #gpio-cells = <2>; + gpio-controller; + + regulators { + /* eMMC VDD */ + vcore_emmc: ldo1 { + regulator-name = "vdd_emmc_core"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + }; + }; + }; +}; diff --git a/arch/arm/dts/tegra30-asus-nexus7-tilapia-E1565.dts b/arch/arm/dts/tegra30-asus-nexus7-tilapia-E1565.dts new file mode 100644 index 0000000000..812d5a1ba7 --- /dev/null +++ b/arch/arm/dts/tegra30-asus-nexus7-tilapia-E1565.dts @@ -0,0 +1,62 @@ +// SPDX-License-Identifier: GPL-2.0 +/dts-v1/; + +#include "tegra30-asus-grouper-common.dtsi" + +/ { + model = "ASUS Google Nexus 7 (Project Bach / ME370TG) E1565"; + compatible = "asus,tilapia", "nvidia,tegra30"; + + i2c@7000d000 { + pmic: max77663@3c { + compatible = "maxim,max77663"; + reg = <0x3c>; + + interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; + #interrupt-cells = <2>; + interrupt-controller; + + system-power-controller; + + #gpio-cells = <2>; + gpio-controller; + + regulators { + vdd_1v8: sd2 { + regulator-name = "vdd_1v8_gen"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + }; + + /* eMMC VDD */ + vcore_emmc: ldo3 { + regulator-name = "vcore_emmc"; + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <3100000>; + regulator-always-on; + }; + }; + }; + }; + + panel { + display-timings { + timing@0 { + /* 1280x800@60Hz */ + clock-frequency = <81750000>; + + hactive = <800>; + hfront-porch = <64>; + hback-porch = <128>; + hsync-len = <64>; + + vactive = <1280>; + vfront-porch = <5>; + vback-porch = <2>; + vsync-len = <1>; + }; + }; + }; +}; diff --git a/arch/arm/mach-tegra/tegra30/Kconfig b/arch/arm/mach-tegra/tegra30/Kconfig index 4f78d0ba97..6cbb73ebee 100644 --- a/arch/arm/mach-tegra/tegra30/Kconfig +++ b/arch/arm/mach-tegra/tegra30/Kconfig @@ -20,6 +20,10 @@ config TARGET_COLIBRI_T30 bool "Toradex Colibri T30 board" select BOARD_LATE_INIT
+config TARGET_GROUPER + bool "Asus and Google Grouper board" + select BOARD_LATE_INIT + config TARGET_TEC_NG bool "Avionic Design TEC-NG board" select BOARD_LATE_INIT @@ -37,6 +41,7 @@ source "board/toradex/apalis_t30/Kconfig" source "board/nvidia/beaver/Kconfig" source "board/nvidia/cardhu/Kconfig" source "board/toradex/colibri_t30/Kconfig" +source "board/asus/grouper/Kconfig" source "board/avionic-design/tec-ng/Kconfig" source "board/asus/transformer-t30/Kconfig"
diff --git a/board/asus/grouper/Kconfig b/board/asus/grouper/Kconfig new file mode 100644 index 0000000000..912c6c5fba --- /dev/null +++ b/board/asus/grouper/Kconfig @@ -0,0 +1,22 @@ +if TARGET_GROUPER + +config SYS_BOARD + default "grouper" + +config SYS_VENDOR + default "asus" + +config SYS_CONFIG_NAME + default "grouper" + +config GROUPER_TPS65911 + bool "Enable support TI TPS65911 PMIC" + select CMD_POWEROFF + default n + +config GROUPER_MAX77663 + bool "Enable support MAXIM MAX77663 PMIC" + select CMD_POWEROFF + default n + +endif diff --git a/board/asus/grouper/MAINTAINERS b/board/asus/grouper/MAINTAINERS new file mode 100644 index 0000000000..18b4f0641f --- /dev/null +++ b/board/asus/grouper/MAINTAINERS @@ -0,0 +1,10 @@ +GROUPER BOARD +M: Svyatoslav Ryhel clamor95@gmail.com +S: Maintained +F: board/asus/grouper/ +F: configs/grouper_E1565.config +F: configs/grouper_PM269.config +F: configs/tilapia.config +F: configs/grouper_common_defconfig +F: doc/board/asus/grouper_common.rst +F: include/configs/grouper.h diff --git a/board/asus/grouper/Makefile b/board/asus/grouper/Makefile new file mode 100644 index 0000000000..e4a477a366 --- /dev/null +++ b/board/asus/grouper/Makefile @@ -0,0 +1,14 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2010-2012 +# NVIDIA Corporation <www.nvidia.com> +# +# (C) Copyright 2021 +# Svyatoslav Ryhel clamor95@gmail.com + +ifdef CONFIG_SPL_BUILD +obj-$(CONFIG_GROUPER_MAX77663) += grouper-spl-max.o +obj-$(CONFIG_GROUPER_TPS65911) += grouper-spl-ti.o +endif + +obj-y += grouper.o diff --git a/board/asus/grouper/grouper-spl-max.c b/board/asus/grouper/grouper-spl-max.c new file mode 100644 index 0000000000..844383766a --- /dev/null +++ b/board/asus/grouper/grouper-spl-max.c @@ -0,0 +1,45 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * T30 Grouper MAX SPL stage configuration + * + * (C) Copyright 2010-2013 + * NVIDIA Corporation <www.nvidia.com> + * + * (C) Copyright 2022 + * Svyatoslav Ryhel clamor95@gmail.com + */ + +#include <common.h> +#include <asm/arch-tegra/tegra_i2c.h> +#include <linux/delay.h> + +#define MAX77663_I2C_ADDR (0x3C << 1) + +#define MAX77663_REG_SD0 0x16 +#define MAX77663_REG_SD0_DATA (0x2100 | MAX77663_REG_SD0) +#define MAX77663_REG_SD1 0x17 +#define MAX77663_REG_SD1_DATA (0x3000 | MAX77663_REG_SD1) +#define MAX77663_REG_LDO4 0x2B +#define MAX77663_REG_LDO4_DATA (0xE000 | MAX77663_REG_LDO4) + +#define MAX77663_REG_GPIO4 0x3A +#define MAX77663_REG_GPIO4_DATA (0x0100 | MAX77663_REG_GPIO4) + +void pmic_enable_cpu_vdd(void) +{ + /* Set VDD_CORE to 1.200V. */ + tegra_i2c_ll_write(MAX77663_I2C_ADDR, MAX77663_REG_SD1_DATA); + + udelay(1000); + + /* Bring up VDD_CPU to 1.0125V. */ + tegra_i2c_ll_write(MAX77663_I2C_ADDR, MAX77663_REG_SD0_DATA); + udelay(1000); + + /* Bring up VDD_RTC to 1.200V. */ + tegra_i2c_ll_write(MAX77663_I2C_ADDR, MAX77663_REG_LDO4_DATA); + udelay(10 * 1000); + + /* Set 32k-out gpio state */ + tegra_i2c_ll_write(MAX77663_I2C_ADDR, MAX77663_REG_GPIO4_DATA); +} diff --git a/board/asus/grouper/grouper-spl-ti.c b/board/asus/grouper/grouper-spl-ti.c new file mode 100644 index 0000000000..e5b78f0121 --- /dev/null +++ b/board/asus/grouper/grouper-spl-ti.c @@ -0,0 +1,41 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * T30 Grouper TI SPL stage configuration + * + * (C) Copyright 2010-2013 + * NVIDIA Corporation <www.nvidia.com> + * + * (C) Copyright 2022 + * Svyatoslav Ryhel clamor95@gmail.com + */ + +#include <common.h> +#include <asm/arch-tegra/tegra_i2c.h> +#include <linux/delay.h> + +#define TPS65911_I2C_ADDR (0x2D << 1) +#define TPS65911_VDDCTRL_OP_REG 0x28 +#define TPS65911_VDDCTRL_SR_REG 0x27 +#define TPS65911_VDDCTRL_OP_DATA (0x2400 | TPS65911_VDDCTRL_OP_REG) +#define TPS65911_VDDCTRL_SR_DATA (0x0100 | TPS65911_VDDCTRL_SR_REG) + +#define TPS62361B_I2C_ADDR (0x60 << 1) +#define TPS62361B_SET3_REG 0x03 +#define TPS62361B_SET3_DATA (0x4600 | TPS62361B_SET3_REG) + +void pmic_enable_cpu_vdd(void) +{ + /* Set VDD_CORE to 1.200V. */ + tegra_i2c_ll_write(TPS62361B_I2C_ADDR, TPS62361B_SET3_DATA); + + udelay(1000); + + /* + * Bring up CPU VDD via the TPS65911x PMIC on the DVC I2C bus. + * First set VDD to 1.0125V, then enable the VDD regulator. + */ + tegra_i2c_ll_write(TPS65911_I2C_ADDR, TPS65911_VDDCTRL_OP_DATA); + udelay(1000); + tegra_i2c_ll_write(TPS65911_I2C_ADDR, TPS65911_VDDCTRL_SR_DATA); + udelay(10 * 1000); +} diff --git a/board/asus/grouper/grouper.c b/board/asus/grouper/grouper.c new file mode 100644 index 0000000000..2769313e68 --- /dev/null +++ b/board/asus/grouper/grouper.c @@ -0,0 +1,202 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2010-2013 + * NVIDIA Corporation <www.nvidia.com> + * + * (C) Copyright 2021 + * Svyatoslav Ryhel clamor95@gmail.com + */ + +#include <common.h> +#include <dm.h> +#include <env.h> +#include <fdt_support.h> +#include <i2c.h> +#include <log.h> +#include <asm/arch/pinmux.h> +#include <asm/arch/gp_padctrl.h> +#include <asm/arch/gpio.h> +#include <asm/arch-tegra/fuse.h> +#include <asm/gpio.h> +#include <linux/delay.h> +#include "pinmux-config-grouper.h" + +#define TPS65911_I2C_ADDRESS 0x2D + +#define TPS65911_REG_LDO1 0x30 +#define TPS65911_REG_DEVCTRL 0x3F +#define DEVCTRL_PWR_OFF_MASK BIT(7) +#define DEVCTRL_DEV_ON_MASK BIT(2) +#define DEVCTRL_DEV_OFF_MASK BIT(0) + +#define MAX77663_I2C_ADDRESS 0x3C + +#define MAX77663_REG_SD2 0x18 +#define MAX77663_REG_LDO3 0x29 +#define MAX77663_REG_ONOFF_CFG1 0x41 +#define ONOFF_PWR_OFF BIT(1) + +#ifdef CONFIG_CMD_POWEROFF +#ifdef CONFIG_GROUPER_TPS65911 +int do_poweroff(struct cmd_tbl *cmdtp, + int flag, int argc, char *const argv[]) +{ + struct udevice *dev; + uchar data_buffer[1]; + int ret; + + ret = i2c_get_chip_for_busnum(0, TPS65911_I2C_ADDRESS, 1, &dev); + if (ret) { + log_debug("cannot find PMIC I2C chip\n"); + return 0; + } + + ret = dm_i2c_read(dev, TPS65911_REG_DEVCTRL, data_buffer, 1); + if (ret) + return ret; + + data_buffer[0] |= DEVCTRL_PWR_OFF_MASK; + + ret = dm_i2c_write(dev, TPS65911_REG_DEVCTRL, data_buffer, 1); + if (ret) + return ret; + + data_buffer[0] |= DEVCTRL_DEV_OFF_MASK; + data_buffer[0] &= ~DEVCTRL_DEV_ON_MASK; + + ret = dm_i2c_write(dev, TPS65911_REG_DEVCTRL, data_buffer, 1); + if (ret) + return ret; + + // wait some time and then print error + mdelay(5000); + + printf("Failed to power off!!!\n"); + return 1; +} +#endif /* CONFIG_GROUPER_TPS65911 */ + +#ifdef CONFIG_GROUPER_MAX77663 +int do_poweroff(struct cmd_tbl *cmdtp, + int flag, int argc, char *const argv[]) +{ + struct udevice *dev; + uchar data_buffer[1]; + int ret; + + ret = i2c_get_chip_for_busnum(0, MAX77663_I2C_ADDRESS, 1, &dev); + if (ret) { + log_debug("cannot find PMIC I2C chip\n"); + return 0; + } + + ret = dm_i2c_read(dev, MAX77663_REG_ONOFF_CFG1, data_buffer, 1); + if (ret) + return ret; + + data_buffer[0] |= ONOFF_PWR_OFF; + + ret = dm_i2c_write(dev, MAX77663_REG_ONOFF_CFG1, data_buffer, 1); + if (ret) + return ret; + + // wait some time and then print error + mdelay(5000); + + printf("Failed to power off!!!\n"); + return 1; +} +#endif /* CONFIG_GROUPER_MAX77663 */ +#endif /* CONFIG_CMD_POWEROFF */ + +/* + * Routine: pinmux_init + * Description: Do individual peripheral pinmux configs + */ +void pinmux_init(void) +{ + pinmux_config_pingrp_table(grouper_pinmux_common, + ARRAY_SIZE(grouper_pinmux_common)); + + pinmux_config_drvgrp_table(grouper_padctrl, + ARRAY_SIZE(grouper_padctrl)); +} + +#ifdef CONFIG_MMC_SDHCI_TEGRA +static void __maybe_unused tps65911_voltage_init(void) +{ + struct udevice *dev; + int ret; + + ret = i2c_get_chip_for_busnum(0, TPS65911_I2C_ADDRESS, 1, &dev); + if (ret) { + log_debug("cannot find PMIC I2C chip\n"); + return; + } + + /* TPS659110: LDO1_REG = 3.3v, ACTIVE to SDMMC4 */ + ret = dm_i2c_reg_write(dev, TPS65911_REG_LDO1, 0xC9); + if (ret) + log_debug("vcore_emmc set failed: %d\n", ret); +} + +static void __maybe_unused max77663_voltage_init(void) +{ + struct udevice *dev; + int ret; + + ret = i2c_get_chip_for_busnum(0, MAX77663_I2C_ADDRESS, 1, &dev); + if (ret) { + log_debug("cannot find PMIC I2C chip\n"); + return; + } + + /* 0x60 for 1.8v, bit7:0 = voltage */ + ret = dm_i2c_reg_write(dev, MAX77663_REG_SD2, 0x60); + if (ret) + log_debug("vdd_1v8_vio set failed: %d\n", ret); + + /* 0xEC for 3.00v, enabled: bit7:6 = 11 = enable, bit5:0 = voltage */ + ret = dm_i2c_reg_write(dev, MAX77663_REG_LDO3, 0xEC); + if (ret) + log_debug("vcore_emmc set failed: %d\n", ret); +} + +/* + * Routine: pin_mux_mmc + * Description: setup the MMC muxes, power rails, etc. + */ +void pin_mux_mmc(void) +{ +#ifdef CONFIG_GROUPER_MAX77663 + /* Bring up eMMC power on MAX PMIC */ + max77663_voltage_init(); +#endif + +#ifdef CONFIG_GROUPER_TPS65911 + /* Bring up eMMC power on TI PMIC */ + tps65911_voltage_init(); +#endif +} +#endif /* MMC */ + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +int ft_board_setup(void *blob, struct bd_info *bd) +{ + /* Remove TrustZone nodes */ + fdt_del_node_and_alias(blob, "/firmware"); + fdt_del_node_and_alias(blob, "/reserved-memory/trustzone@bfe00000"); + + return 0; +} +#endif + +void nvidia_board_late_init(void) +{ + char serialno_str[17]; + + /* Set chip id as serialno */ + sprintf(serialno_str, "%016llx", tegra_chip_uid()); + env_set("serial#", serialno_str); + env_set("platform", "Tegra 3 T30"); +} diff --git a/board/asus/grouper/pinmux-config-grouper.h b/board/asus/grouper/pinmux-config-grouper.h new file mode 100644 index 0000000000..98134f74f1 --- /dev/null +++ b/board/asus/grouper/pinmux-config-grouper.h @@ -0,0 +1,362 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. + */ + +#ifndef _PINMUX_CONFIG_GROUPER_H_ +#define _PINMUX_CONFIG_GROUPER_H_ + +#define DEFAULT_PINMUX(_pingrp, _mux, _pull, _tri, _io) \ + { \ + .pingrp = PMUX_PINGRP_##_pingrp, \ + .func = PMUX_FUNC_##_mux, \ + .pull = PMUX_PULL_##_pull, \ + .tristate = PMUX_TRI_##_tri, \ + .io = PMUX_PIN_##_io, \ + .lock = PMUX_PIN_LOCK_DEFAULT, \ + .od = PMUX_PIN_OD_DEFAULT, \ + .ioreset = PMUX_PIN_IO_RESET_DEFAULT, \ + } + +#define I2C_PINMUX(_pingrp, _mux, _pull, _tri, _io, _lock, _od) \ + { \ + .pingrp = PMUX_PINGRP_##_pingrp, \ + .func = PMUX_FUNC_##_mux, \ + .pull = PMUX_PULL_##_pull, \ + .tristate = PMUX_TRI_##_tri, \ + .io = PMUX_PIN_##_io, \ + .lock = PMUX_PIN_LOCK_##_lock, \ + .od = PMUX_PIN_OD_##_od, \ + .ioreset = PMUX_PIN_IO_RESET_DEFAULT, \ + } + +#define LV_PINMUX(_pingrp, _mux, _pull, _tri, _io, _lock, _ioreset) \ + { \ + .pingrp = PMUX_PINGRP_##_pingrp, \ + .func = PMUX_FUNC_##_mux, \ + .pull = PMUX_PULL_##_pull, \ + .tristate = PMUX_TRI_##_tri, \ + .io = PMUX_PIN_##_io, \ + .lock = PMUX_PIN_LOCK_##_lock, \ + .od = PMUX_PIN_OD_DEFAULT, \ + .ioreset = PMUX_PIN_IO_RESET_##_ioreset \ + } + +#define DEFAULT_PADCFG(_drvgrp, _slwf, _slwr, _drvup, _drvdn, _lpmd, _schmt, _hsm) \ + { \ + .drvgrp = PMUX_DRVGRP_##_drvgrp, \ + .slwf = _slwf, \ + .slwr = _slwr, \ + .drvup = _drvup, \ + .drvdn = _drvdn, \ + .lpmd = PMUX_LPMD_##_lpmd, \ + .schmt = PMUX_SCHMT_##_schmt, \ + .hsm = PMUX_HSM_##_hsm, \ + } + +static struct pmux_pingrp_config grouper_pinmux_common[] = { + /* SDMMC1 pinmux */ + DEFAULT_PINMUX(SDMMC1_CLK_PZ0, SDMMC1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_CMD_PZ1, SDMMC1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_DAT3_PY4, SDMMC1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_DAT2_PY5, SDMMC1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_DAT1_PY6, SDMMC1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_DAT0_PY7, SDMMC1, UP, NORMAL, INPUT), + + /* SDMMC3 pinmux */ + DEFAULT_PINMUX(SDMMC3_CLK_PA6, SDMMC3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_CMD_PA7, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT0_PB7, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT1_PB6, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT2_PB5, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT3_PB4, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT4_PD1, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT5_PD0, SDMMC3, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(SDMMC3_DAT6_PD3, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT7_PD4, SDMMC3, UP, NORMAL, INPUT), + + /* SDMMC4 pinmux */ + LV_PINMUX(SDMMC4_CLK_PCC4, SDMMC4, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_CMD_PT7, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT0_PAA0, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT1_PAA1, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT2_PAA2, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT3_PAA3, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT4_PAA4, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT5_PAA5, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT6_PAA6, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT7_PAA7, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_RST_N_PCC3, RSVD2, DOWN, NORMAL, INPUT, DISABLE, DISABLE), + + /* I2C pinmux */ + I2C_PINMUX(GEN1_I2C_SCL_PC4, I2C1, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(GEN1_I2C_SDA_PC5, I2C1, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(GEN2_I2C_SCL_PT5, I2C2, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(GEN2_I2C_SDA_PT6, I2C2, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(CAM_I2C_SCL_PBB1, I2C3, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(CAM_I2C_SDA_PBB2, I2C3, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(DDC_SCL_PV4, I2C4, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(DDC_SDA_PV5, I2C4, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(PWR_I2C_SCL_PZ6, I2CPWR, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(PWR_I2C_SDA_PZ7, I2CPWR, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + + /* HDMI-CEC pinmux */ + DEFAULT_PINMUX(HDMI_CEC_PEE3, CEC, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(HDMI_INT_PN7, RSVD1, NORMAL, TRISTATE, INPUT), + + /* ULPI pinmux */ + DEFAULT_PINMUX(ULPI_DATA0_PO1, UARTA, DOWN, TRISTATE, OUTPUT), + DEFAULT_PINMUX(ULPI_DATA1_PO2, UARTA, UP, TRISTATE, INPUT), + DEFAULT_PINMUX(ULPI_DATA2_PO3, UARTA, UP, TRISTATE, INPUT), + DEFAULT_PINMUX(ULPI_DATA3_PO4, ULPI, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_DATA4_PO5, UARTA, UP, TRISTATE, INPUT), + DEFAULT_PINMUX(ULPI_DATA5_PO6, UARTA, UP, TRISTATE, INPUT), + DEFAULT_PINMUX(ULPI_DATA6_PO7, UARTA, UP, TRISTATE, INPUT), + DEFAULT_PINMUX(ULPI_DATA7_PO0, UARTA, UP, TRISTATE, OUTPUT), + DEFAULT_PINMUX(ULPI_CLK_PY0, ULPI, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(ULPI_DIR_PY1, ULPI, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(ULPI_NXT_PY2, RSVD1, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(ULPI_STP_PY3, RSVD1, NORMAL, TRISTATE, OUTPUT), + + /* DAP3 pinmux */ + DEFAULT_PINMUX(DAP3_FS_PP0, I2S2, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(DAP3_DIN_PP1, I2S2, DOWN, NORMAL, INPUT), + DEFAULT_PINMUX(DAP3_DOUT_PP2, I2S2, DOWN, NORMAL, INPUT), + DEFAULT_PINMUX(DAP3_SCLK_PP3, I2S2, DOWN, TRISTATE, INPUT), + + DEFAULT_PINMUX(PV0, RSVD1, UP, TRISTATE, INPUT), + DEFAULT_PINMUX(PV1, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PV2, OWR, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(PV3, RSVD1, NORMAL, TRISTATE, INPUT), + + /* CLK2 pinmux */ + DEFAULT_PINMUX(CLK2_OUT_PW5, EXTPERIPH2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(CLK2_REQ_PCC5, DAP, NORMAL, NORMAL, INPUT), + + /* LCD pinmux */ + DEFAULT_PINMUX(LCD_PWR1_PC1, DISPLAYA, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(LCD_PWR2_PC6, DISPLAYA, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(LCD_SDIN_PZ2, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_SDOUT_PN5, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_WR_N_PZ3, DISPLAYA, UP, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_CS0_N_PN4, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_DC0_PN6, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_SCK_PZ4, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_PWR0_PB2, DISPLAYA, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(LCD_PCLK_PB3, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_DE_PJ1, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_HSYNC_PJ3, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_VSYNC_PJ4, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D0_PE0, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D1_PE1, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D2_PE2, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D3_PE3, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D4_PE4, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D5_PE5, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D6_PE6, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D7_PE7, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D8_PF0, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D9_PF1, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D10_PF2, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D11_PF3, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D12_PF4, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D13_PF5, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D14_PF6, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D15_PF7, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D16_PM0, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D17_PM1, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D18_PM2, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D19_PM3, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D20_PM4, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D21_PM5, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D22_PM6, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D23_PM7, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_CS1_N_PW0, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_M1_PW1, DISPLAYA, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(LCD_DC1_PD2, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(CRT_HSYNC_PV6, CRT, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(CRT_VSYNC_PV7, CRT, NORMAL, NORMAL, OUTPUT), + + /* VI-group pinmux */ + LV_PINMUX(VI_D0_PT4, RSVD1, DOWN, TRISTATE, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D1_PD5, SDMMC2, DOWN, TRISTATE, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D2_PL0, SDMMC2, DOWN, TRISTATE, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D3_PL1, SDMMC2, DOWN, TRISTATE, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D4_PL2, VI, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D5_PL3, SDMMC2, DOWN, TRISTATE, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D6_PL4, VI, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D7_PL5, SDMMC2, DOWN, TRISTATE, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D8_PL6, SDMMC2, DOWN, TRISTATE, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D9_PL7, SDMMC2, DOWN, TRISTATE, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D10_PT2, RSVD1, DOWN, TRISTATE, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D11_PT3, RSVD1, DOWN, TRISTATE, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_PCLK_PT0, SDMMC2, UP, TRISTATE, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_MCLK_PT1, RSVD1, DOWN, TRISTATE, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_HSYNC_PD7, RSVD1, DOWN, TRISTATE, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_VSYNC_PD6, RSVD1, DOWN, TRISTATE, INPUT, DISABLE, DISABLE), + + /* UART-B pinmux */ + DEFAULT_PINMUX(UART2_RXD_PC3, UARTB, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART2_TXD_PC2, UARTB, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(UART2_RTS_N_PJ6, UARTB, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(UART2_CTS_N_PJ5, UARTB, NORMAL, NORMAL, INPUT), + + /* UART-C pinmux */ + DEFAULT_PINMUX(UART3_TXD_PW6, UARTC, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(UART3_RXD_PW7, UARTC, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART3_CTS_N_PA1, UARTC, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART3_RTS_N_PC0, UARTC, NORMAL, NORMAL, OUTPUT), + + /* U-gpio group pinmux */ + DEFAULT_PINMUX(PU0, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PU1, RSVD1, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PU2, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PU3, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PU4, PWM1, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(PU5, PWM2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PU6, RSVD4, NORMAL, NORMAL, INPUT), + + /* DAP4 pinmux */ + DEFAULT_PINMUX(DAP4_FS_PP4, I2S3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP4_DIN_PP5, I2S3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP4_DOUT_PP6, I2S3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP4_SCLK_PP7, I2S3, NORMAL, NORMAL, INPUT), + + /* CLK3 pinmux */ + DEFAULT_PINMUX(CLK3_OUT_PEE0, EXTPERIPH3, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(CLK3_REQ_PEE1, DEV3, NORMAL, NORMAL, INPUT), + + DEFAULT_PINMUX(CAM_MCLK_PCC0, VI_ALT3, DOWN, NORMAL, INPUT), + + DEFAULT_PINMUX(PCC1, RSVD2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PBB0, RSVD2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PBB3, VGP3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PBB4, VGP4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PBB5, VGP5, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PBB6, VGP6, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PBB7, I2S4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PCC2, I2S4, NORMAL, NORMAL, INPUT), + + DEFAULT_PINMUX(JTAG_RTCK_PU7, RTCK, UP, NORMAL, INPUT), + + /* KBC keys */ + DEFAULT_PINMUX(KB_ROW0_PR0, RSVD4, UP, NORMAL, OUTPUT), + DEFAULT_PINMUX(KB_ROW1_PR1, KBC, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(KB_ROW2_PR2, KBC, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_ROW3_PR3, KBC, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(KB_ROW4_PR4, KBC, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_ROW5_PR5, KBC, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_ROW6_PR6, KBC, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(KB_ROW7_PR7, KBC, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(KB_ROW8_PS0, KBC, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(KB_ROW9_PS1, KBC, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(KB_ROW10_PS2, KBC, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(KB_ROW11_PS3, KBC, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW12_PS4, KBC, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW13_PS5, KBC, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(KB_ROW14_PS6, KBC, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_ROW15_PS7, KBC, NORMAL, NORMAL, OUTPUT), + + DEFAULT_PINMUX(KB_COL0_PQ0, KBC, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(KB_COL1_PQ1, KBC, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(KB_COL2_PQ2, RSVD4, UP, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_COL3_PQ3, RSVD4, UP, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_COL4_PQ4, KBC, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_COL5_PQ5, KBC, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_COL6_PQ6, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL7_PQ7, KBC, NORMAL, TRISTATE, INPUT), + + /* CLK */ + DEFAULT_PINMUX(CLK_32K_OUT_PA0, BLINK, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(SYS_CLK_REQ_PZ5, SYSCLK, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(OWR, OWR, NORMAL, NORMAL, INPUT), + + /* DAP1 pinmux */ + DEFAULT_PINMUX(DAP1_FS_PN0, I2S0, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP1_DIN_PN1, I2S0, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP1_DOUT_PN2, I2S0, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP1_SCLK_PN3, I2S0, NORMAL, NORMAL, INPUT), + + /* CLK1 pinmux */ + DEFAULT_PINMUX(CLK1_REQ_PEE2, DAP, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(CLK1_OUT_PW4, EXTPERIPH1, NORMAL, NORMAL, INPUT), + + /* SPDIF pinmux */ + DEFAULT_PINMUX(SPDIF_IN_PK6, SPDIF, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPDIF_OUT_PK5, SPDIF, NORMAL, NORMAL, OUTPUT), + + /* DAP2 pinmux */ + DEFAULT_PINMUX(DAP2_FS_PA2, I2S1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP2_DIN_PA4, I2S1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP2_DOUT_PA5, I2S1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP2_SCLK_PA3, I2S1, NORMAL, NORMAL, INPUT), + + /* SPI pinmux */ + DEFAULT_PINMUX(SPI1_MOSI_PX4, SPI1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPI1_SCK_PX5, SPI1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPI1_CS0_N_PX6, SPI1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPI1_MISO_PX7, SPI1, NORMAL, NORMAL, INPUT), + + DEFAULT_PINMUX(SPI2_MOSI_PX0, SPI2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPI2_MISO_PX1, SPI2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPI2_SCK_PX2, SPI2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPI2_CS1_N_PW2, SPI2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPI2_CS2_N_PW3, SPI2, NORMAL, NORMAL, INPUT), + + /* PEX pinmux */ + DEFAULT_PINMUX(PEX_L0_PRSNT_N_PDD0, PCIE, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(PEX_L0_RST_N_PDD1, PCIE, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(PEX_L0_CLKREQ_N_PDD2, PCIE, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(PEX_WAKE_N_PDD3, PCIE, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PEX_L1_PRSNT_N_PDD4, PCIE, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(PEX_L1_RST_N_PDD5, PCIE, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(PEX_L1_CLKREQ_N_PDD6, PCIE, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(PEX_L2_PRSNT_N_PDD7, PCIE, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PEX_L2_RST_N_PCC6, PCIE, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PEX_L2_CLKREQ_N_PCC7, PCIE, NORMAL, NORMAL, OUTPUT), + + /* GMI pinmux */ + DEFAULT_PINMUX(GMI_WP_N_PC7, RSVD1, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_IORDY_PI5, RSVD1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_WAIT_PI7, RSVD1, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_ADV_N_PK0, RSVD1, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_CLK_PK1, NAND, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_CS0_N_PJ0, RSVD1, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_CS1_N_PJ2, RSVD1, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_CS2_N_PK3, RSVD1, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_CS3_N_PK4, RSVD1, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_CS4_N_PK2, RSVD1, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_CS6_N_PI3, GMI, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_CS7_N_PI6, NAND, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_AD0_PG0, RSVD1, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_AD1_PG1, RSVD1, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_AD2_PG2, RSVD1, DOWN, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_AD3_PG3, RSVD1, DOWN, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_AD4_PG4, NAND, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD5_PG5, NAND, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD6_PG6, RSVD1, DOWN, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_AD7_PG7, RSVD1, DOWN, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_AD8_PH0, PWM0, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_AD9_PH1, RSVD4, DOWN, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_AD10_PH2, PWM2, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_AD11_PH3, PWM3, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_AD12_PH4, RSVD1, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_AD13_PH5, RSVD1, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_AD14_PH6, RSVD1, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_AD15_PH7, RSVD1, UP, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_A16_PJ7, UARTD, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_A17_PB0, UARTD, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_A18_PB1, UARTD, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_A19_PK7, UARTD, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_WR_N_PI0, RSVD1, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_OE_N_PI1, RSVD1, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_DQS_PI2, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_RST_N_PI4, NAND, UP, NORMAL, OUTPUT), +}; + +static struct pmux_drvgrp_config grouper_padctrl[] = { + /* (_drvgrp, _slwf, _slwr, _drvup, _drvdn, _lpmd, _schmt, _hsm) */ + DEFAULT_PADCFG(SDIO1, SDIOCFG_DRVUP_SLWF, SDIOCFG_DRVDN_SLWR, \ + SDIOCFG_DRVUP, SDIOCFG_DRVDN, NONE, DISABLE, DISABLE), +}; +#endif /* _PINMUX_CONFIG_GROUPER_H_ */ diff --git a/configs/grouper_E1565.config b/configs/grouper_E1565.config new file mode 100644 index 0000000000..4d8d5263fa --- /dev/null +++ b/configs/grouper_E1565.config @@ -0,0 +1,2 @@ +CONFIG_DEFAULT_DEVICE_TREE="tegra30-asus-nexus7-grouper-E1565" +CONFIG_GROUPER_MAX77663=y diff --git a/configs/grouper_PM269.config b/configs/grouper_PM269.config new file mode 100644 index 0000000000..fc768b2051 --- /dev/null +++ b/configs/grouper_PM269.config @@ -0,0 +1,2 @@ +CONFIG_DEFAULT_DEVICE_TREE="tegra30-asus-nexus7-grouper-PM269" +CONFIG_GROUPER_TPS65911=y diff --git a/configs/grouper_common_defconfig b/configs/grouper_common_defconfig new file mode 100644 index 0000000000..8dc88851f5 --- /dev/null +++ b/configs/grouper_common_defconfig @@ -0,0 +1,84 @@ +CONFIG_ARM=y +CONFIG_SYS_L2CACHE_OFF=y +CONFIG_ARCH_TEGRA=y +CONFIG_SUPPORT_PASSING_ATAGS=y +CONFIG_CMDLINE_TAG=y +CONFIG_INITRD_TAG=y +CONFIG_TEXT_BASE=0x80110000 +CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SIZE=0x3000 +CONFIG_ENV_OFFSET=0xFFFFD000 +CONFIG_DEFAULT_DEVICE_TREE="tegra30-asus-nexus7-grouper-E1565" +CONFIG_SPL_TEXT_BASE=0x80108000 +CONFIG_SYS_PROMPT="Tegra30 (Grouper) # " +CONFIG_SPL_STACK=0x800ffffc +CONFIG_TEGRA30=y +CONFIG_TARGET_GROUPER=y +CONFIG_CMD_EBTUPDATE=y +CONFIG_SYS_LOAD_ADDR=0x82000000 +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_BOOTDELAY=0 +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_KEYED_CTRLC=y +CONFIG_USE_BOOTCOMMAND=y +CONFIG_BOOTCOMMAND="if run check_button; then bootmenu; fi; run bootcmd_mmc0; poweroff;" +CONFIG_SPL_FOOTPRINT_LIMIT=y +CONFIG_SPL_MAX_FOOTPRINT=0x8000 +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SYS_SPL_MALLOC=y +CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y +CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80090000 +CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SYS_MAXARGS=64 +CONFIG_SYS_PBSIZE=2084 +CONFIG_CMD_BOOTMENU=y +# CONFIG_CMD_IMI is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_GPT_RENAME=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_UMS_ABORT_KEYED=y +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_NFS is not set +CONFIG_CMD_PAUSE=y +CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_ENV_OVERWRITE=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_PART=2 +CONFIG_SPL_DM=y +CONFIG_BUTTON=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x91000000 +CONFIG_FASTBOOT_BUF_SIZE=0x10000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_FASTBOOT_CMD_OEM_FORMAT=y +CONFIG_GPIO_HOG=y +CONFIG_SYS_I2C_TEGRA=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_GPIO=y +CONFIG_BUTTON_KEYBOARD=y +CONFIG_DM_PMIC=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_PWM_TEGRA=y +CONFIG_SYS_NS16550=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_TEGRA=y +CONFIG_USB_KEYBOARD=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="ASUS Google" +CONFIG_USB_GADGET_VENDOR_NUM=0x18d1 +CONFIG_USB_GADGET_PRODUCT_NUM=0x4e41 +CONFIG_CI_UDC=y +CONFIG_VIDEO=y +# CONFIG_VIDEO_LOGO is not set +CONFIG_VIDEO_TEGRA20=y +# CONFIG_CMD_BOOTEFI_BOOTMGR is not set diff --git a/configs/tilapia.config b/configs/tilapia.config new file mode 100644 index 0000000000..1fb0633e3a --- /dev/null +++ b/configs/tilapia.config @@ -0,0 +1,3 @@ +CONFIG_DEFAULT_DEVICE_TREE="tegra30-asus-nexus7-tilapia-E1565" +CONFIG_GROUPER_MAX77663=y +CONFIG_SYS_PROMPT="Tegra30 (Tilapia) # " diff --git a/doc/board/asus/grouper_common.rst b/doc/board/asus/grouper_common.rst new file mode 100644 index 0000000000..2e4450b40e --- /dev/null +++ b/doc/board/asus/grouper_common.rst @@ -0,0 +1,94 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +U-Boot for the ASUS/Google Nexus 7 (2012) +========================================= + +``DISCLAMER!`` Moving your ASUS/Google Nexus 7 (2012) to use +U-Boot assumes replacement of the vendor ASUS bootloader. Vendor +android firmwares will no longer be able to run on the device. +This replacement IS reversible. + +Quick Start +----------- + +- Build U-Boot +- Pack U-Boot into repart-block +- Flash repart-block into the eMMC +- Boot +- Self Upgrading + +Build U-Boot +------------ + +Device support is implemented by applying config fragment to a generic +board defconfig. Valid fragments are ``grouper_E1565.config``, +``grouper_PM269.config`` and ``tilapia.config``. + +.. code-block:: bash + + $ export CROSS_COMPILE=arm-linux-gnueabi- + $ make grouper_common_defconfig grouper_E1565.config # For maxim based grouper + $ make + +After the build succeeds, you will obtain the final ``u-boot-dtb-tegra.bin`` +image, ready for flashing (but check the next section for additional +adjustments). + +Pack U-Boot into repar-block +---------------------------- + +``DISCLAMER!`` All questions related to re-crypt work should be asked +in re-crypt repo issues. NOT HERE! + +re-crypt is a small script which packs ``u-boot-dtb-tegra.bin`` in +form usable by device. This process is required only on the first +installation or to recover the device in case of a failed update. +You need to know your tablet's individual SBK to continue. + +.. code-block:: bash + + $ git clone https://github.com/clamor-s/re-crypt.git + $ cd re-crypt # place your u-boot-dtb-regra.bin here + $ ./re-crypt.sh -d grouper -k deadbeefdeadc0dedeadd00dfee1dead + +Script will produce you a ``repart-block.bin`` ready to flash. + +Flash repart-block into the eMMC +-------------------------------- + +``DISCLAMER!`` All questions related to NvFlash should be asked +in the proper place. NOT HERE! Flashing repart-block will erase +all your eMMC, so make a backup before! + +``repart-block.bin`` contains BCT and bootloader in encrypted state +in form which can just be written RAW at the start of eMMC. + +.. code-block:: bash + + $ wheelie --blob blob.bin + $ nvflash --resume --rawdevicewrite 0 1024 repart-block.bin + +Boot +---- + +After flashing ``repart-block.bin`` the device should reboot and turn +itself off. This is normal behavior if no boot configuration is +found. + +To boot Linux, U-Boot will look for an ``extlinux.conf`` configuration +on eMMC. Additionally if Volume Down button is pressed while booting +device will enter bootmenu. Bootmenu contains entries to mount eMMC as +mass storage, fastboot, reboot, reboot RCM, poweroff, enter U-Boot +console and update bootloader (check next chapter). + +Flashing ``repart-block.bin`` eliminates vendor restriction on eMMC +and allows the user to use/partition it in any way the user desires. + +Self Upgrading +-------------- + +Place your ``u-boot-dtb-tegra.bin`` on the first partition of the +eMMC (using ability of u-boot to mount it). Enter bootmenu, choose +update bootloader option with Power button and U-Boot should update +itself. Once the process is completed, U-Boot will ask to press any +button to reboot. diff --git a/doc/board/asus/index.rst b/doc/board/asus/index.rst index c59571c8b3..87e535fe34 100644 --- a/doc/board/asus/index.rst +++ b/doc/board/asus/index.rst @@ -6,4 +6,5 @@ ASUS .. toctree:: :maxdepth: 2
+ grouper_common transformer_t30 diff --git a/include/configs/grouper.h b/include/configs/grouper.h new file mode 100644 index 0000000000..93304ddc6e --- /dev/null +++ b/include/configs/grouper.h @@ -0,0 +1,61 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2010-2012, NVIDIA CORPORATION. All rights reserved. + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <linux/sizes.h> + +#include "tegra30-common.h" + +/* High-level configuration options */ +#define CFG_TEGRA_BOARD_STRING "ASUS Google Nexus 7 (2012)" + +#define GROUPER_FLASH_UBOOT \ + "flash_uboot=echo Preparing RAM;" \ + "mw ${kernel_addr_r} 0 ${boot_block_size_r};" \ + "mw ${ramdisk_addr_r} 0 ${boot_block_size_r};" \ + "echo Reading BCT;" \ + "mmc dev 0 1;" \ + "mmc read ${kernel_addr_r} 0 ${boot_block_size};" \ + "echo Reading bootloader;" \ + "if load mmc 0:1 ${ramdisk_addr_r} ${bootloader_file};" \ + "then echo Calculating bootloader size;" \ + "size mmc 0:1 ${bootloader_file};" \ + "ebtupdate ${kernel_addr_r} ${ramdisk_addr_r} ${filesize};" \ + "echo Writing bootloader to eMMC;" \ + "mmc dev 0 1;" \ + "mmc write ${kernel_addr_r} 0 ${boot_block_size};" \ + "mmc dev 0 2;" \ + "mmc write ${ramdisk_addr_r} 0 ${boot_block_size};" \ + "echo Bootloader written successfully;" \ + "pause 'Press ANY key to reboot device...'; reset;" \ + "else echo Reading bootloader failed;" \ + "pause 'Press ANY key to return to bootmenu...'; bootmenu; fi\0" + +#define GROUPER_BOOTMENU \ + GROUPER_FLASH_UBOOT \ + "bootmenu_0=mount internal storage=usb start && ums 0 mmc 0; bootmenu\0" \ + "bootmenu_1=fastboot=echo Starting Fastboot protocol ...; fastboot usb 0; bootmenu\0" \ + "bootmenu_2=update bootloader=run flash_uboot\0" \ + "bootmenu_3=reboot RCM=enterrcm\0" \ + "bootmenu_4=reboot=reset\0" \ + "bootmenu_5=power off=poweroff\0" \ + "bootmenu_delay=-1\0" + +#define BOARD_EXTRA_ENV_SETTINGS \ + "boot_block_size_r=0x200000\0" \ + "boot_block_size=0x1000\0" \ + "bootloader_file=u-boot-dtb-tegra.bin\0" \ + "check_button=gpio input 131; test $? -eq 0;\0" \ + "partitions=name=emmc,start=0,size=-,uuid=${uuid_gpt_rootfs}\0" \ + GROUPER_BOOTMENU + +/* Board-specific serial config */ +#define CFG_SYS_NS16550_COM1 NV_PA_APB_UARTA_BASE + +#include "tegra-common-post.h" + +#endif /* __CONFIG_H */
LG X3 is a development board based on Nvidia Tegra 3 SoC on base of which Optimus 4X HD and Optimus Vu were created. Both smartphones feature a 4.7" and 5" panels respectively, an Nvidia Tegra 3 quad-core chip, 1 GB of RAM and 16/32 GB of internal storage. Optimux 4X HD additionally has a micro SD slot.
Tested-by: Andreas Westman Dorcsak hedmoo@yahoo.com # LG P880 T30 Tested-by: Svyatoslav Ryhel clamor95@gmail.com # LG P895 T30 Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- arch/arm/dts/Makefile | 2 + arch/arm/dts/tegra30-lg-p880.dts | 40 +++ arch/arm/dts/tegra30-lg-p895.dts | 50 ++++ arch/arm/dts/tegra30-lg-x3.dtsi | 180 +++++++++++ arch/arm/mach-tegra/tegra30/Kconfig | 5 + board/lg/x3-t30/Kconfig | 26 ++ board/lg/x3-t30/MAINTAINERS | 9 + board/lg/x3-t30/Makefile | 11 + board/lg/x3-t30/pinmux-config-x3.h | 449 ++++++++++++++++++++++++++++ board/lg/x3-t30/x3-t30-spl.c | 48 +++ board/lg/x3-t30/x3-t30.c | 176 +++++++++++ configs/p880.config | 4 + configs/p895.config | 4 + configs/x3_t30_defconfig | 88 ++++++ doc/board/index.rst | 1 + doc/board/lg/index.rst | 9 + doc/board/lg/x3_t30.rst | 93 ++++++ include/configs/x3-t30.h | 77 +++++ 18 files changed, 1272 insertions(+) create mode 100644 arch/arm/dts/tegra30-lg-p880.dts create mode 100644 arch/arm/dts/tegra30-lg-p895.dts create mode 100644 arch/arm/dts/tegra30-lg-x3.dtsi create mode 100644 board/lg/x3-t30/Kconfig create mode 100644 board/lg/x3-t30/MAINTAINERS create mode 100644 board/lg/x3-t30/Makefile create mode 100644 board/lg/x3-t30/pinmux-config-x3.h create mode 100644 board/lg/x3-t30/x3-t30-spl.c create mode 100644 board/lg/x3-t30/x3-t30.c create mode 100644 configs/p880.config create mode 100644 configs/p895.config create mode 100644 configs/x3_t30_defconfig create mode 100644 doc/board/lg/index.rst create mode 100644 doc/board/lg/x3_t30.rst create mode 100644 include/configs/x3-t30.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index f2b4044a01..f31cabc27b 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -250,6 +250,8 @@ dtb-$(CONFIG_ARCH_TEGRA) += tegra20-harmony.dtb \ tegra30-beaver.dtb \ tegra30-cardhu.dtb \ tegra30-colibri.dtb \ + tegra30-lg-p880.dtb \ + tegra30-lg-p895.dtb \ tegra30-tec-ng.dtb \ tegra114-dalmore.dtb \ tegra124-apalis.dtb \ diff --git a/arch/arm/dts/tegra30-lg-p880.dts b/arch/arm/dts/tegra30-lg-p880.dts new file mode 100644 index 0000000000..81d364310d --- /dev/null +++ b/arch/arm/dts/tegra30-lg-p880.dts @@ -0,0 +1,40 @@ +// SPDX-License-Identifier: GPL-2.0 +/dts-v1/; + +#include "tegra30-lg-x3.dtsi" + +/ { + model = "LG Optimus 4X HD"; + compatible = "lge,p880", "nvidia,tegra30"; + + aliases { + mmc1 = &sdmmc3; /* uSD slot */ + }; + + sdmmc3: sdhci@78000400 { + status = "okay"; + bus-width = <4>; + + cd-gpios = <&gpio TEGRA_GPIO(W, 5) GPIO_ACTIVE_LOW>; + + vmmc-supply = <&vdd_usd>; + vqmmc-supply = <&vdd_1v8_vio>; + }; + + gpio-keys { + key-volume-up { + label = "Volume Up"; + gpios = <&gpio TEGRA_GPIO(O, 7) GPIO_ACTIVE_LOW>; + linux,code = <KEY_UP>; + }; + }; + + panel: panel { + compatible = "jdi,dx12d100vm0eaa"; + + enable-gpios = <&gpio TEGRA_GPIO(Y, 0) GPIO_ACTIVE_HIGH>; + reset-gpios = <&gpio TEGRA_GPIO(W, 0) GPIO_ACTIVE_HIGH>; + + backlight = <&backlight>; + }; +}; diff --git a/arch/arm/dts/tegra30-lg-p895.dts b/arch/arm/dts/tegra30-lg-p895.dts new file mode 100644 index 0000000000..074205d5a9 --- /dev/null +++ b/arch/arm/dts/tegra30-lg-p895.dts @@ -0,0 +1,50 @@ +// SPDX-License-Identifier: GPL-2.0 +/dts-v1/; + +#include "tegra30-lg-x3.dtsi" + +/ { + model = "LG Optimus Vu"; + compatible = "lge,p895", "nvidia,tegra30"; + + gpio-keys { + key-volume-up { + label = "Volume Up"; + gpios = <&gpio TEGRA_GPIO(I, 6) GPIO_ACTIVE_LOW>; + linux,code = <KEY_UP>; + }; + }; + + panel: panel { + compatible = "hitachi,tx13d100vm0eaa"; + + reset-gpios = <&gpio TEGRA_GPIO(W, 0) GPIO_ACTIVE_HIGH>; + + renesas,gamma = <3>; + renesas,inversion; + renesas,contrast; + + vcc-supply = <&vcc_3v0_lcd>; + iovcc-supply = <&iovcc_1v8_lcd>; + + backlight = <&backlight>; + }; + + vcc_3v0_lcd: regulator-lcd { + compatible = "regulator-fixed"; + regulator-name = "vcc_3v0_lcd"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + gpio = <&gpio TEGRA_GPIO(BB, 0) GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + iovcc_1v8_lcd: regulator-lcdvio { + compatible = "regulator-fixed"; + regulator-name = "iovcc_1v8_lcd"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + gpio = <&gpio TEGRA_GPIO(Y, 0) GPIO_ACTIVE_HIGH>; + enable-active-high; + }; +}; diff --git a/arch/arm/dts/tegra30-lg-x3.dtsi b/arch/arm/dts/tegra30-lg-x3.dtsi new file mode 100644 index 0000000000..922e39915e --- /dev/null +++ b/arch/arm/dts/tegra30-lg-x3.dtsi @@ -0,0 +1,180 @@ +// SPDX-License-Identifier: GPL-2.0 + +#include <dt-bindings/input/input.h> + +#include "tegra30.dtsi" + +/ { + chosen { + stdout-path = &uartd; + }; + + aliases { + i2c0 = &pwr_i2c; + i2c1 = &gen2_i2c; + + mmc0 = &sdmmc4; /* eMMC */ + + rtc0 = &pmic; + rtc1 = "/rtc@7000e000"; + + spi0 = &dsi_spi; + + usb0 = µ_usb; + }; + + memory { + device_type = "memory"; + reg = <0x80000000 0x40000000>; + }; + + host1x@50000000 { + dc@54200000 { + rgb { + status = "okay"; + + nvidia,panel = <&bridge>; + }; + }; + }; + + uartd: serial@70006300 { + status = "okay"; + }; + + gen2_i2c: i2c@7000c400 { + status = "okay"; + clock-frequency = <400000>; + + backlight: lm3533@36 { + compatible = "ti,lm3533"; + reg = <0x36>; + + enable-gpios = <&gpio TEGRA_GPIO(N, 6) GPIO_ACTIVE_HIGH>; + default-brightness-level = <128>; + }; + + muic@44 { + compatible = "maxim,max14526-muic"; + reg = <0x44>; + + maxim,ap-usb; + + usif-gpios = <&gpio TEGRA_GPIO(Y, 3) GPIO_ACTIVE_HIGH>; + dp2t-gpios = <&gpio TEGRA_GPIO(CC, 2) GPIO_ACTIVE_HIGH>; + }; + }; + + pwr_i2c: i2c@7000d000 { + status = "okay"; + clock-frequency = <400000>; + + pmic: max77663@1c { + compatible = "maxim,max77663"; + reg = <0x1c>; + + interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; + #interrupt-cells = <2>; + interrupt-controller; + + #gpio-cells = <2>; + gpio-controller; + + system-power-controller; + + regulators { + vdd_1v8_vio: sd2 { + regulator-name = "vdd_1v8_gen"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + }; + + vdd_usd: ldo3 { + regulator-name = "vdd_sdmmc3"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-always-on; + regulator-boot-on; + }; + + vcore_emmc: ldo5 { + regulator-name = "vdd_ddr_rx"; + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <2850000>; + regulator-always-on; + regulator-boot-on; + }; + }; + }; + }; + + dsi_spi: spi@7000dc00 { + status = "okay"; + spi-max-frequency = <25000000>; + + bridge: bridge-spi@2 { + compatible = "solomon,ssd2825"; + reg = <2>; + + spi-cpol; + spi-cpha; + + spi-max-frequency = <1000000>; + + power-gpios = <&gpio TEGRA_GPIO(B, 1) GPIO_ACTIVE_HIGH>; + reset-gpios = <&gpio TEGRA_GPIO(O, 2) GPIO_ACTIVE_HIGH>; + + clocks = <&ssd2825_refclk>; + clock-names = "tx_clk"; + + panel = <&panel>; + }; + }; + + sdmmc4: sdhci@78000600 { + status = "okay"; + bus-width = <8>; + non-removable; + + vmmc-supply = <&vcore_emmc>; + vqmmc-supply = <&vdd_1v8_vio>; + }; + + micro_usb: usb@7d000000 { + status = "okay"; + dr_mode = "otg"; + }; + + /* PMIC has a built-in 32KHz oscillator which is used by PMC */ + clk32k_in: clock-32k { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + clock-output-names = "pmic-oscillator"; + }; + + ssd2825_refclk: clock-ssd2825 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <24000000>; + clock-output-names = "ssd2825-refclk"; + }; + + gpio-keys { + compatible = "gpio-keys"; + + key-power { + label = "Power"; + gpios = <&gpio TEGRA_GPIO(C, 7) GPIO_ACTIVE_LOW>; + linux,code = <KEY_ENTER>; + }; + + key-volume-down { + label = "Volume Down"; + gpios = <&gpio TEGRA_GPIO(O, 4) GPIO_ACTIVE_LOW>; + linux,code = <KEY_DOWN>; + }; + }; +}; diff --git a/arch/arm/mach-tegra/tegra30/Kconfig b/arch/arm/mach-tegra/tegra30/Kconfig index 6cbb73ebee..9b1df21d28 100644 --- a/arch/arm/mach-tegra/tegra30/Kconfig +++ b/arch/arm/mach-tegra/tegra30/Kconfig @@ -32,6 +32,10 @@ config TARGET_TRANSFORMER_T30 bool "Asus Tegra30 Transformer board" select BOARD_LATE_INIT
+config TARGET_X3_T30 + bool "LG X3 Tegra30 board" + select BOARD_LATE_INIT + endchoice
config SYS_SOC @@ -44,5 +48,6 @@ source "board/toradex/colibri_t30/Kconfig" source "board/asus/grouper/Kconfig" source "board/avionic-design/tec-ng/Kconfig" source "board/asus/transformer-t30/Kconfig" +source "board/lg/x3-t30/Kconfig"
endif diff --git a/board/lg/x3-t30/Kconfig b/board/lg/x3-t30/Kconfig new file mode 100644 index 0000000000..20ea4f5f32 --- /dev/null +++ b/board/lg/x3-t30/Kconfig @@ -0,0 +1,26 @@ +if TARGET_X3_T30 + +config SYS_BOARD + default "x3-t30" + +config SYS_VENDOR + default "lg" + +config SYS_CONFIG_NAME + default "x3-t30" + +config DEVICE_P880 + bool "Enable support for LG Optimus 4X HD" + default n + help + LG Optimus 4X HD derives from x3 board but has slight + differences. + +config DEVICE_P895 + bool "Enable support for LG Optimus Vu" + default n + help + LG Optimus Vu derives from x3 board but has slight + differences. + +endif diff --git a/board/lg/x3-t30/MAINTAINERS b/board/lg/x3-t30/MAINTAINERS new file mode 100644 index 0000000000..0ad29563e9 --- /dev/null +++ b/board/lg/x3-t30/MAINTAINERS @@ -0,0 +1,9 @@ +X3 BOARD +M: Svyatoslav Ryhel clamor95@gmail.com +S: Maintained +F: board/lg/x3-t30/ +F: configs/p880.config +F: configs/p895.config +F: configs/x3_t30_defconfig +F: doc/board/lg/x3_t30.rst +F: include/configs/x3-t30.h diff --git a/board/lg/x3-t30/Makefile b/board/lg/x3-t30/Makefile new file mode 100644 index 0000000000..3eeb132f3c --- /dev/null +++ b/board/lg/x3-t30/Makefile @@ -0,0 +1,11 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2010-2012 +# NVIDIA Corporation <www.nvidia.com> +# +# (C) Copyright 2021 +# Svyatoslav Ryhel clamor95@gmail.com + +obj-$(CONFIG_SPL_BUILD) += x3-t30-spl.o + +obj-y += x3-t30.o diff --git a/board/lg/x3-t30/pinmux-config-x3.h b/board/lg/x3-t30/pinmux-config-x3.h new file mode 100644 index 0000000000..cdb28095f3 --- /dev/null +++ b/board/lg/x3-t30/pinmux-config-x3.h @@ -0,0 +1,449 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. + * + * Copyright (c) 2021, Svyatoslav Ryhel. + */ + +#ifndef _PINMUX_CONFIG_X3_H_ +#define _PINMUX_CONFIG_X3_H_ + +#define DEFAULT_PINMUX(_pingrp, _mux, _pull, _tri, _io) \ + { \ + .pingrp = PMUX_PINGRP_##_pingrp, \ + .func = PMUX_FUNC_##_mux, \ + .pull = PMUX_PULL_##_pull, \ + .tristate = PMUX_TRI_##_tri, \ + .io = PMUX_PIN_##_io, \ + .lock = PMUX_PIN_LOCK_DEFAULT, \ + .od = PMUX_PIN_OD_DEFAULT, \ + .ioreset = PMUX_PIN_IO_RESET_DEFAULT, \ + } + +#define I2C_PINMUX(_pingrp, _mux, _pull, _tri, _io, _lock, _od) \ + { \ + .pingrp = PMUX_PINGRP_##_pingrp, \ + .func = PMUX_FUNC_##_mux, \ + .pull = PMUX_PULL_##_pull, \ + .tristate = PMUX_TRI_##_tri, \ + .io = PMUX_PIN_##_io, \ + .lock = PMUX_PIN_LOCK_##_lock, \ + .od = PMUX_PIN_OD_##_od, \ + .ioreset = PMUX_PIN_IO_RESET_DEFAULT, \ + } + +#define LV_PINMUX(_pingrp, _mux, _pull, _tri, _io, _lock, _ioreset) \ + { \ + .pingrp = PMUX_PINGRP_##_pingrp, \ + .func = PMUX_FUNC_##_mux, \ + .pull = PMUX_PULL_##_pull, \ + .tristate = PMUX_TRI_##_tri, \ + .io = PMUX_PIN_##_io, \ + .lock = PMUX_PIN_LOCK_##_lock, \ + .od = PMUX_PIN_OD_DEFAULT, \ + .ioreset = PMUX_PIN_IO_RESET_##_ioreset \ + } + +static struct pmux_pingrp_config tegra3_x3_pinmux_common[] = { + /* SDMMC1 pinmux */ + DEFAULT_PINMUX(SDMMC1_CLK_PZ0, SDMMC1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_CMD_PZ1, SDMMC1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_DAT3_PY4, SDMMC1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_DAT2_PY5, SDMMC1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_DAT1_PY6, SDMMC1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_DAT0_PY7, SDMMC1, UP, NORMAL, INPUT), + + /* SDMMC3 pinmux */ +// DEFAULT_PINMUX(SDMMC3_CLK_PA6, SDMMC3, NORMAL, TRISTATE, INPUT), // device specific +// DEFAULT_PINMUX(SDMMC3_CMD_PA7, SDMMC3, NORMAL, TRISTATE, INPUT), // device specific +// DEFAULT_PINMUX(SDMMC3_DAT0_PB7, RSVD1, NORMAL, TRISTATE, INPUT), // device specific +// DEFAULT_PINMUX(SDMMC3_DAT1_PB6, RSVD1, NORMAL, NORMAL, INPUT), // device specific +// DEFAULT_PINMUX(SDMMC3_DAT2_PB5, RSVD1, NORMAL, TRISTATE, INPUT), // device specific +// DEFAULT_PINMUX(SDMMC3_DAT3_PB4, RSVD1, NORMAL, TRISTATE, INPUT), // device specific +// DEFAULT_PINMUX(SDMMC3_DAT4_PD1, SDMMC3, NORMAL, TRISTATE, INPUT), // device specific +// DEFAULT_PINMUX(SDMMC3_DAT5_PD0, SDMMC3, NORMAL, TRISTATE, INPUT), // device specific +// DEFAULT_PINMUX(SDMMC3_DAT6_PD3, SDMMC3, NORMAL, TRISTATE, INPUT), // device specific +// DEFAULT_PINMUX(SDMMC3_DAT7_PD4, RSVD2, NORMAL, TRISTATE, INPUT), // device specific + + /* SDMMC4 pinmux */ + LV_PINMUX(SDMMC4_CLK_PCC4, SDMMC4, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), +// LV_PINMUX(SDMMC4_CMD_PT7, SDMMC4, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), // device specific + LV_PINMUX(SDMMC4_DAT0_PAA0, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT1_PAA1, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT2_PAA2, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT3_PAA3, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT4_PAA4, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT5_PAA5, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT6_PAA6, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT7_PAA7, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_RST_N_PCC3, RSVD2, DOWN, NORMAL, INPUT, DISABLE, DISABLE), + + /* I2C1 pinmux */ + I2C_PINMUX(GEN1_I2C_SCL_PC4, I2C1, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(GEN1_I2C_SDA_PC5, I2C1, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + + /* I2C2 pinmux */ + I2C_PINMUX(GEN2_I2C_SCL_PT5, I2C2, UP, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(GEN2_I2C_SDA_PT6, I2C2, UP, NORMAL, INPUT, DISABLE, ENABLE), + + /* I2C3 pinmux */ + I2C_PINMUX(CAM_I2C_SCL_PBB1, I2C3, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(CAM_I2C_SDA_PBB2, I2C3, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + + /* I2C4 pinmux */ + I2C_PINMUX(DDC_SCL_PV4, I2C4, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(DDC_SDA_PV5, I2C4, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + + /* Power I2C pinmux */ + I2C_PINMUX(PWR_I2C_SCL_PZ6, I2CPWR, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(PWR_I2C_SDA_PZ7, I2CPWR, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + + /* HDMI-CEC pinmux */ + DEFAULT_PINMUX(HDMI_CEC_PEE3, CEC, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(HDMI_INT_PN7, RSVD1, NORMAL, TRISTATE, INPUT), + + /* ULPI pinmux */ + DEFAULT_PINMUX(ULPI_DATA0_PO1, SPI3, UP, TRISTATE, OUTPUT), + DEFAULT_PINMUX(ULPI_DATA1_PO2, SPI3, UP, NORMAL, OUTPUT), // LCD_BRIDGE_RESET_N + DEFAULT_PINMUX(ULPI_DATA2_PO3, SPI3, UP, TRISTATE, INPUT), + DEFAULT_PINMUX(ULPI_DATA3_PO4, SPI3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_DATA4_PO5, ULPI, UP, NORMAL, INPUT), +// DEFAULT_PINMUX(ULPI_DATA5_PO6, SPI2, UP, TRISTATE, INPUT), // unconfigured +// DEFAULT_PINMUX(ULPI_DATA6_PO7, SPI2, UP, NORMAL, INPUT), // device specific +// DEFAULT_PINMUX(ULPI_DATA7_PO0, SPI2, UP, NORMAL, INPUT), // unconfigured + DEFAULT_PINMUX(ULPI_CLK_PY0, RSVD2, DOWN, NORMAL, OUTPUT), // LCD_EN + DEFAULT_PINMUX(ULPI_DIR_PY1, RSVD2, UP, NORMAL, OUTPUT), + DEFAULT_PINMUX(ULPI_NXT_PY2, RSVD2, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(ULPI_STP_PY3, SPI1, NORMAL, NORMAL, OUTPUT), + + /* DAP3 pinmux */ + DEFAULT_PINMUX(DAP3_FS_PP0, I2S2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP3_DIN_PP1, I2S2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP3_DOUT_PP2, I2S2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP3_SCLK_PP3, I2S2, NORMAL, NORMAL, INPUT), + + DEFAULT_PINMUX(PV0, RSVD1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(PV1, RSVD1, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PV2, OWR, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PV3, RSVD2, DOWN, NORMAL, INPUT), + + /* CLK2 pinmux */ + DEFAULT_PINMUX(CLK2_OUT_PW5, RSVD2, UP, NORMAL, INPUT), + DEFAULT_PINMUX(CLK2_REQ_PCC5, DAP, NORMAL, NORMAL, OUTPUT), + + /* LCD pinmux */ + DEFAULT_PINMUX(LCD_PWR1_PC1, DISPLAYA, NORMAL, NORMAL, OUTPUT), +// DEFAULT_PINMUX(LCD_PWR2_PC6, DISPLAYA, DOWN, TRISTATE, OUTPUT), // unconfigured + DEFAULT_PINMUX(LCD_SDIN_PZ2, SPI5, NORMAL, NORMAL, INPUT), // LCD_RGB_SDI + DEFAULT_PINMUX(LCD_SDOUT_PN5, SPI5, NORMAL, NORMAL, INPUT), // LCD_RGB_SDO + DEFAULT_PINMUX(LCD_WR_N_PZ3, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_CS0_N_PN4, SPI5, NORMAL, NORMAL, INPUT), // LCD_RGB_CS + DEFAULT_PINMUX(LCD_DC0_PN6, RSVD3, NORMAL, NORMAL, OUTPUT), // LCD_CP_EN / BL + DEFAULT_PINMUX(LCD_SCK_PZ4, SPI5, NORMAL, NORMAL, INPUT), // LCD_RGB_SCL + DEFAULT_PINMUX(LCD_PWR0_PB2, DISPLAYA, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(LCD_PCLK_PB3, DISPLAYA, NORMAL, NORMAL, INPUT), // LCD_RGB_PCLK + DEFAULT_PINMUX(LCD_DE_PJ1, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_HSYNC_PJ3, DISPLAYA, NORMAL, NORMAL, INPUT), // LCD_RGB_HSYNC + DEFAULT_PINMUX(LCD_VSYNC_PJ4, DISPLAYA, NORMAL, NORMAL, INPUT), // LCD_RGB_VSYNC + DEFAULT_PINMUX(LCD_D0_PE0, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D1_PE1, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D2_PE2, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D3_PE3, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D4_PE4, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D5_PE5, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D6_PE6, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D7_PE7, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D8_PF0, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D9_PF1, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D10_PF2, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D11_PF3, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D12_PF4, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D13_PF5, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D14_PF6, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D15_PF7, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D16_PM0, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D17_PM1, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D18_PM2, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D19_PM3, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D20_PM4, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D21_PM5, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D22_PM6, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D23_PM7, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_CS1_N_PW0, RSVD4, UP, NORMAL, OUTPUT), // LCD_RESET_N + DEFAULT_PINMUX(LCD_M1_PW1, DISPLAYA, NORMAL, TRISTATE, OUTPUT), // LCD_MAKER_ID + DEFAULT_PINMUX(LCD_DC1_PD2, RSVD3, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(CRT_HSYNC_PV6, RSVD2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(CRT_VSYNC_PV7, RSVD2, NORMAL, NORMAL, INPUT), + + /* VI-group pinmux */ + LV_PINMUX(VI_D0_PT4, RSVD2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D1_PD5, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D2_PL0, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D3_PL1, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D4_PL2, VI, NORMAL, NORMAL, OUTPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D5_PL3, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D6_PL4, VI, NORMAL, NORMAL, OUTPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D7_PL5, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D8_PL6, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D9_PL7, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D10_PT2, RSVD2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D11_PT3, RSVD2, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_PCLK_PT0, RSVD1, UP, TRISTATE, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_MCLK_PT1, VI, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_HSYNC_PD7, RSVD2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_VSYNC_PD6, RSVD2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + + /* UART-B pinmux */ +// DEFAULT_PINMUX(UART2_RXD_PC3, UARTB, NORMAL, NORMAL, INPUT), // device specific +// DEFAULT_PINMUX(UART2_TXD_PC2, UARTB, NORMAL, NORMAL, OUTPUT), // device specific + DEFAULT_PINMUX(UART2_RTS_N_PJ6, UARTB, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART2_CTS_N_PJ5, UARTB, NORMAL, NORMAL, INPUT), + + /* UART-C pinmux */ + DEFAULT_PINMUX(UART3_TXD_PW6, UARTC, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(UART3_RXD_PW7, UARTC, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART3_CTS_N_PA1, UARTC, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART3_RTS_N_PC0, UARTC, NORMAL, NORMAL, OUTPUT), + + /* PU-gpio group pinmux */ +// DEFAULT_PINMUX(PU0, UARTA, NORMAL, NORMAL, OUTPUT), // device specific +// DEFAULT_PINMUX(PU1, UARTA, NORMAL, NORMAL, INPUT), // device specific +// DEFAULT_PINMUX(PU2, RSVD1, NORMAL, TRISTATE, INPUT), // device specific +// DEFAULT_PINMUX(PU3, PWM0, NORMAL, TRISTATE, INPUT), // device specific +// DEFAULT_PINMUX(PU4, PWM1, NORMAL, TRISTATE, INPUT), // device specific + DEFAULT_PINMUX(PU5, RSVD4, DOWN, NORMAL, OUTPUT), + DEFAULT_PINMUX(PU6, PWM3, DOWN, NORMAL, INPUT), + + /* DAP4 pinmux */ + DEFAULT_PINMUX(DAP4_FS_PP4, I2S3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP4_DIN_PP5, I2S3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP4_DOUT_PP6, I2S3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP4_SCLK_PP7, I2S3, NORMAL, NORMAL, INPUT), + + /* CLK3 pinmux */ + DEFAULT_PINMUX(CLK3_OUT_PEE0, EXTPERIPH3, NORMAL, NORMAL, OUTPUT), // MIPI_BRIDGE_CLK + DEFAULT_PINMUX(CLK3_REQ_PEE1, DEV3, NORMAL, NORMAL, INPUT), + + DEFAULT_PINMUX(CAM_MCLK_PCC0, VI_ALT2, UP, NORMAL, INPUT), + + DEFAULT_PINMUX(PCC1, RSVD3, NORMAL, NORMAL, OUTPUT), +// DEFAULT_PINMUX(PBB0, RSVD2, NORMAL, NORMAL, OUTPUT), // device specific + DEFAULT_PINMUX(PBB3, VGP3, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PBB4, VGP4, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PBB5, VGP5, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PBB6, VGP6, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PBB7, I2S4, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(PCC2, RSVD3, NORMAL, NORMAL, OUTPUT), + + DEFAULT_PINMUX(JTAG_RTCK_PU7, RTCK, NORMAL, NORMAL, OUTPUT), + + /* KBC keys */ + DEFAULT_PINMUX(KB_ROW0_PR0, RSVD4, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(KB_ROW1_PR1, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW2_PR2, RSVD4, DOWN, NORMAL, OUTPUT), + DEFAULT_PINMUX(KB_ROW3_PR3, RSVD3, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(KB_ROW4_PR4, RSVD4, DOWN, NORMAL, OUTPUT), + DEFAULT_PINMUX(KB_ROW5_PR5, KBC, DOWN, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW6_PR6, KBC, DOWN, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW7_PR7, KBC, DOWN, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW8_PS0, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW9_PS1, KBC, DOWN, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW10_PS2, KBC, DOWN, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW11_PS3, KBC, DOWN, NORMAL, OUTPUT), + DEFAULT_PINMUX(KB_ROW12_PS4, KBC, DOWN, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW13_PS5, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW14_PS6, KBC, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW15_PS7, KBC, DOWN, NORMAL, INPUT), + + DEFAULT_PINMUX(KB_COL0_PQ0, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL1_PQ1, KBC, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(KB_COL2_PQ2, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL3_PQ3, KBC, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL4_PQ4, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL5_PQ5, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL6_PQ6, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL7_PQ7, KBC, UP, NORMAL, INPUT), + + /* CLK */ + DEFAULT_PINMUX(CLK_32K_OUT_PA0, BLINK, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SYS_CLK_REQ_PZ5, SYSCLK, NORMAL, NORMAL, INPUT), +// DEFAULT_PINMUX(CORE_PWR_REQ, RSVD1, NORMAL, NORMAL, INPUT), // unconfigured +// DEFAULT_PINMUX(CPU_PWR_REQ, RSVD1, NORMAL, NORMAL, INPUT), // unconfigured +// DEFAULT_PINMUX(PWR_INT_N, RSVD1, NORMAL, NORMAL, INPUT), // unconfigured +// DEFAULT_PINMUX(CLK_32K_IN, RSVD1, NORMAL, NORMAL, INPUT), // unconfigured + DEFAULT_PINMUX(OWR, OWR, NORMAL, NORMAL, INPUT), + + /* DAP1 pinmux */ + DEFAULT_PINMUX(DAP1_FS_PN0, I2S0, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP1_DIN_PN1, I2S0, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP1_DOUT_PN2, I2S0, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP1_SCLK_PN3, I2S0, NORMAL, NORMAL, INPUT), + + /* CLK1 pinmux */ + DEFAULT_PINMUX(CLK1_REQ_PEE2, DAP, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(CLK1_OUT_PW4, EXTPERIPH1, DOWN, NORMAL, INPUT), + + /* SPDIF pinmux */ + DEFAULT_PINMUX(SPDIF_IN_PK6, SPDIF, NORMAL, NORMAL, OUTPUT), +// DEFAULT_PINMUX(SPDIF_OUT_PK5, SPDIF, DOWN, NORMAL, OUTPUT), // device specific + + /* DAP2 pinmux */ + DEFAULT_PINMUX(DAP2_FS_PA2, HDA, DOWN, NORMAL, INPUT), + DEFAULT_PINMUX(DAP2_DIN_PA4, HDA, DOWN, NORMAL, INPUT), + DEFAULT_PINMUX(DAP2_DOUT_PA5, HDA, DOWN, NORMAL, INPUT), + DEFAULT_PINMUX(DAP2_SCLK_PA3, HDA, DOWN, NORMAL, INPUT), + + /* SPI pinmux */ + DEFAULT_PINMUX(SPI1_MOSI_PX4, SPI2, NORMAL, NORMAL, OUTPUT), +// DEFAULT_PINMUX(SPI1_SCK_PX5, SPI1, NORMAL, NORMAL, OUTPUT), // device specific +// DEFAULT_PINMUX(SPI1_CS0_N_PX6, GMI, NORMAL, NORMAL, INPUT), // device specific + DEFAULT_PINMUX(SPI1_MISO_PX7, RSVD4, NORMAL, NORMAL, OUTPUT), + + DEFAULT_PINMUX(SPI2_MOSI_PX0, SPI2, DOWN, NORMAL, OUTPUT), + DEFAULT_PINMUX(SPI2_MISO_PX1, GMI, NORMAL, NORMAL, OUTPUT), +// DEFAULT_PINMUX(SPI2_CS0_N_PX3, SPI6, UP, NORMAL, INPUT), // unconfigured +// DEFAULT_PINMUX(SPI2_SCK_PX2, SPI6, UP, NORMAL, INPUT), // unconfigured + DEFAULT_PINMUX(SPI2_CS1_N_PW2, SPI2, NORMAL, NORMAL, INPUT), +// DEFAULT_PINMUX(SPI2_CS2_N_PW3, SPI2, UP, TRISTATE, INPUT), // unconfigured + + /* PEX pinmux */ + DEFAULT_PINMUX(PEX_L0_PRSNT_N_PDD0, PCIE, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(PEX_L0_RST_N_PDD1, PCIE, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(PEX_L0_CLKREQ_N_PDD2, PCIE, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(PEX_WAKE_N_PDD3, PCIE, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(PEX_L1_PRSNT_N_PDD4, PCIE, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PEX_L1_RST_N_PDD5, PCIE, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PEX_L1_CLKREQ_N_PDD6, PCIE, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PEX_L2_PRSNT_N_PDD7, PCIE, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(PEX_L2_RST_N_PCC6, PCIE, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(PEX_L2_CLKREQ_N_PCC7, PCIE, NORMAL, TRISTATE, INPUT), + + /* GMI pinmux */ + DEFAULT_PINMUX(GMI_WP_N_PC7, GMI, UP, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_IORDY_PI5, RSVD1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_WAIT_PI7, GMI, UP, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_ADV_N_PK0, GMI, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_CLK_PK1, GMI, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_CS0_N_PJ0, GMI, UP, TRISTATE, INPUT), // LCD_RGB_DE + DEFAULT_PINMUX(GMI_CS1_N_PJ2, RSVD1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_CS2_N_PK3, RSVD1, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_CS3_N_PK4, RSVD1, NORMAL, NORMAL, OUTPUT), +// DEFAULT_PINMUX(GMI_CS4_N_PK2, RSVD4, UP, NORMAL, INPUT), // device specific + DEFAULT_PINMUX(GMI_CS6_N_PI3, GMI, UP, NORMAL, INPUT), +// DEFAULT_PINMUX(GMI_CS7_N_PI6, GMI, UP, NORMAL, INPUT), // device specific + DEFAULT_PINMUX(GMI_AD0_PG0, GMI, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_AD1_PG1, GMI, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_AD2_PG2, GMI, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_AD3_PG3, GMI, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_AD4_PG4, GMI, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_AD5_PG5, GMI, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_AD6_PG6, GMI, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_AD7_PG7, GMI, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_AD8_PH0, GMI, DOWN, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD9_PH1, GMI, DOWN, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD10_PH2, GMI, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_AD11_PH3, PWM3, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_AD12_PH4, RSVD4, UP, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD13_PH5, RSVD4, UP, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD14_PH6, GMI, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_AD15_PH7, GMI, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_A16_PJ7, UARTD, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_A17_PB0, UARTD, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_A18_PB1, UARTD, DOWN, NORMAL, OUTPUT), // RGB_IC_EN + DEFAULT_PINMUX(GMI_A19_PK7, UARTD, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_WR_N_PI0, GMI, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_OE_N_PI1, RSVD1, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_DQS_PI2, GMI, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_RST_N_PI4, GMI, UP, NORMAL, INPUT), +}; + +#ifdef CONFIG_DEVICE_P880 +static struct pmux_pingrp_config tegra3_p880_pinmux[] = { + /* SDMMC3 pinmux */ + DEFAULT_PINMUX(SDMMC3_CLK_PA6, SDMMC3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_CMD_PA7, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT0_PB7, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT1_PB6, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT2_PB5, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT3_PB4, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT4_PD1, SDMMC3, UP, TRISTATE, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT5_PD0, SDMMC3, UP, TRISTATE, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT6_PD3, SDMMC3, UP, TRISTATE, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT7_PD4, SDMMC3, UP, TRISTATE, INPUT), + + /* SDMMC4 pinmux */ + LV_PINMUX(SDMMC4_CMD_PT7, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + + /* ULPI pinmux */ + DEFAULT_PINMUX(ULPI_DATA6_PO7, SPI2, NORMAL, NORMAL, INPUT), + + /* UART-B pinmux */ + DEFAULT_PINMUX(UART2_RXD_PC3, UARTB, UP, NORMAL, INPUT), + DEFAULT_PINMUX(UART2_TXD_PC2, UARTB, UP, NORMAL, OUTPUT), + + /* GPIO group pinmux */ + DEFAULT_PINMUX(PU0, UARTA, UP, NORMAL, OUTPUT), + DEFAULT_PINMUX(PU1, UARTA, UP, NORMAL, INPUT), + DEFAULT_PINMUX(PU2, UARTA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PU3, UARTA, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PU4, PWM1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PBB0, I2S4, NORMAL, TRISTATE, INPUT), + + /* SPDIF pinmux */ + DEFAULT_PINMUX(SPDIF_OUT_PK5, SPDIF, UP, TRISTATE, OUTPUT), + + /* SPI pinmux */ + DEFAULT_PINMUX(SPI1_SCK_PX5, SPI2, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(SPI1_CS0_N_PX6, SPI1, NORMAL, NORMAL, INPUT), + + /* GMI pinmux */ + DEFAULT_PINMUX(GMI_CS4_N_PK2, RSVD1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_CS7_N_PI6, GMI, DOWN, NORMAL, OUTPUT), +}; +#endif /* CONFIG_DEVICE_P880 */ + +#ifdef CONFIG_DEVICE_P895 +static struct pmux_pingrp_config tegra3_p895_pinmux[] = { + /* SDMMC3 pinmux */ + DEFAULT_PINMUX(SDMMC3_CLK_PA6, SDMMC3, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(SDMMC3_CMD_PA7, SDMMC3, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT0_PB7, RSVD1, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT1_PB6, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT2_PB5, RSVD1, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT3_PB4, RSVD1, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT4_PD1, SDMMC3, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT5_PD0, SDMMC3, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT6_PD3, SDMMC3, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT7_PD4, RSVD2, NORMAL, TRISTATE, INPUT), + + /* SDMMC4 pinmux */ + LV_PINMUX(SDMMC4_CMD_PT7, SDMMC4, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + + /* ULPI pinmux */ + DEFAULT_PINMUX(ULPI_DATA6_PO7, SPI2, UP, NORMAL, INPUT), + + /* UART-B pinmux */ + DEFAULT_PINMUX(UART2_RXD_PC3, UARTB, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART2_TXD_PC2, UARTB, NORMAL, NORMAL, OUTPUT), + + /* Gpio group pinmux */ + DEFAULT_PINMUX(PU0, UARTA, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PU1, UARTA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PU2, RSVD1, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(PU3, PWM0, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(PU4, PWM1, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(PBB0, RSVD2, NORMAL, NORMAL, OUTPUT), // LCD_EN_3V0 + + /* SPDIF pinmux */ + DEFAULT_PINMUX(SPDIF_OUT_PK5, SPDIF, DOWN, NORMAL, OUTPUT), + + /* SPI pinmux */ + DEFAULT_PINMUX(SPI1_SCK_PX5, SPI1, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(SPI1_CS0_N_PX6, GMI, NORMAL, NORMAL, INPUT), + + /* GMI pinmux */ + DEFAULT_PINMUX(GMI_CS4_N_PK2, RSVD4, UP, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_CS7_N_PI6, GMI, UP, NORMAL, INPUT), +}; +#endif /* CONFIG_DEVICE_P895 */ +#endif /* _PINMUX_CONFIG_X3_H_ */ diff --git a/board/lg/x3-t30/x3-t30-spl.c b/board/lg/x3-t30/x3-t30-spl.c new file mode 100644 index 0000000000..864f2de45f --- /dev/null +++ b/board/lg/x3-t30/x3-t30-spl.c @@ -0,0 +1,48 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * T30 LGE X3 SPL stage configuration + * + * (C) Copyright 2010-2013 + * NVIDIA Corporation <www.nvidia.com> + * + * (C) Copyright 2022 + * Svyatoslav Ryhel clamor95@gmail.com + */ + +#include <common.h> +#include <asm/arch-tegra/tegra_i2c.h> +#include <linux/delay.h> + +#define MAX77663_I2C_ADDR (0x1C << 1) + +#define MAX77663_REG_SD0 0x16 +#define MAX77663_REG_SD0_DATA (0x2100 | MAX77663_REG_SD0) +#define MAX77663_REG_SD1 0x17 +#define MAX77663_REG_SD1_DATA (0x3000 | MAX77663_REG_SD1) +#define MAX77663_REG_LDO4 0x2B +#define MAX77663_REG_LDO4_DATA (0xE000 | MAX77663_REG_LDO4) + +#define MAX77663_REG_GPIO1 0x37 +#define MAX77663_REG_GPIO1_DATA (0x0800 | MAX77663_REG_GPIO1) +#define MAX77663_REG_GPIO4 0x3A +#define MAX77663_REG_GPIO4_DATA (0x0100 | MAX77663_REG_GPIO4) + +void pmic_enable_cpu_vdd(void) +{ + /* Set VDD_CORE to 1.200V. */ + tegra_i2c_ll_write(MAX77663_I2C_ADDR, MAX77663_REG_SD1_DATA); + + udelay(1000); + + /* Bring up VDD_CPU to 1.0125V. */ + tegra_i2c_ll_write(MAX77663_I2C_ADDR, MAX77663_REG_SD0_DATA); + udelay(1000); + + /* Bring up VDD_RTC to 1.200V. */ + tegra_i2c_ll_write(MAX77663_I2C_ADDR, MAX77663_REG_LDO4_DATA); + udelay(10 * 1000); + + /* Set GPIO4 and GPIO1 states */ + tegra_i2c_ll_write(MAX77663_I2C_ADDR, MAX77663_REG_GPIO4_DATA); + tegra_i2c_ll_write(MAX77663_I2C_ADDR, MAX77663_REG_GPIO1_DATA); +} diff --git a/board/lg/x3-t30/x3-t30.c b/board/lg/x3-t30/x3-t30.c new file mode 100644 index 0000000000..594563cf52 --- /dev/null +++ b/board/lg/x3-t30/x3-t30.c @@ -0,0 +1,176 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2010-2013 + * NVIDIA Corporation <www.nvidia.com> + * + * (C) Copyright 2022 + * Svyatoslav Ryhel clamor95@gmail.com + */ + +#include <common.h> +#include <dm.h> +#include <env.h> +#include <fdt_support.h> +#include <i2c.h> +#include <log.h> +#include <asm/arch/pinmux.h> +#include <asm/arch/clock.h> +#include <asm/arch/gpio.h> +#include <asm/arch/tegra.h> +#include <asm/arch-tegra/fuse.h> +#include <asm/gpio.h> +#include <linux/delay.h> +#include "pinmux-config-x3.h" + +#define MAX77663_I2C_ADDR 0x1C + +#define MAX77663_REG_SD2 0x18 +#define MAX77663_REG_LDO2 0x27 +#define MAX77663_REG_LDO3 0x29 +#define MAX77663_REG_LDO5 0x2D +#define MAX77663_REG_ONOFF_CFG1 0x41 +#define ONOFF_PWR_OFF BIT(1) + +#ifdef CONFIG_CMD_POWEROFF +int do_poweroff(struct cmd_tbl *cmdtp, int flag, + int argc, char *const argv[]) +{ + struct udevice *dev; + uchar data_buffer[1]; + int ret; + + ret = i2c_get_chip_for_busnum(0, MAX77663_I2C_ADDR, 1, &dev); + if (ret) { + log_debug("cannot find PMIC I2C chip\n"); + return 0; + } + + ret = dm_i2c_read(dev, MAX77663_REG_ONOFF_CFG1, data_buffer, 1); + if (ret) + return ret; + + data_buffer[0] |= ONOFF_PWR_OFF; + + ret = dm_i2c_write(dev, MAX77663_REG_ONOFF_CFG1, data_buffer, 1); + if (ret) + return ret; + + /* wait some time and then print error */ + mdelay(5000); + + printf("Failed to power off!!!\n"); + return 1; +} +#endif + +/* + * Routine: pinmux_init + * Description: Do individual peripheral pinmux configs + */ +void pinmux_init(void) +{ + pinmux_config_pingrp_table(tegra3_x3_pinmux_common, + ARRAY_SIZE(tegra3_x3_pinmux_common)); + +#ifdef CONFIG_DEVICE_P880 + pinmux_config_pingrp_table(tegra3_p880_pinmux, + ARRAY_SIZE(tegra3_p880_pinmux)); +#endif + +#ifdef CONFIG_DEVICE_P895 + pinmux_config_pingrp_table(tegra3_p895_pinmux, + ARRAY_SIZE(tegra3_p895_pinmux)); +#endif +} + +#ifdef CONFIG_MMC_SDHCI_TEGRA +static void max77663_voltage_init(void) +{ + struct udevice *dev; + int ret; + + ret = i2c_get_chip_for_busnum(0, MAX77663_I2C_ADDR, 1, &dev); + if (ret) { + log_debug("cannot find PMIC I2C chip\n"); + return; + } + + /* 0x60 for 1.8v, bit7:0 = voltage */ + ret = dm_i2c_reg_write(dev, MAX77663_REG_SD2, 0x60); + if (ret) + log_debug("vdd_1v8_vio set failed: %d\n", ret); + + /* 0xF2 for 3.30v, enabled: bit7:6 = 11 = enable, bit5:0 = voltage */ + ret = dm_i2c_reg_write(dev, MAX77663_REG_LDO2, 0xF2); + if (ret) + log_debug("avdd_usb set failed: %d\n", ret); + + /* 0xEC for 3.00v, enabled: bit7:6 = 11 = enable, bit5:0 = voltage */ + ret = dm_i2c_reg_write(dev, MAX77663_REG_LDO3, 0xEC); + if (ret) + log_debug("vdd_usd set failed: %d\n", ret); + + /* 0xE9 for 2.85v, enabled: bit7:6 = 11 = enable, bit5:0 = voltage */ + ret = dm_i2c_reg_write(dev, MAX77663_REG_LDO5, 0xE9); + if (ret) + log_debug("vcore_emmc set failed: %d\n", ret); +} + +/* + * Routine: pin_mux_mmc + * Description: setup the MMC muxes, power rails, etc. + */ +void pin_mux_mmc(void) +{ + /* Bring up uSD and eMMC power */ + max77663_voltage_init(); +} +#endif /* MMC */ + +int nvidia_board_init(void) +{ + /* Set up panel bridge clocks */ + clock_start_periph_pll(PERIPH_ID_EXTPERIPH3, CLOCK_ID_PERIPH, + 24 * 1000000); + clock_external_output(3); + + return 0; +} + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +int ft_board_setup(void *blob, struct bd_info *bd) +{ + /* First 3 bytes refer to LG vendor */ + u8 btmacaddr[6] = { 0x00, 0x00, 0x00, 0xD0, 0xC9, 0x88 }; + + /* Generate device 3 bytes based on chip sd */ + u64 bt_device = tegra_chip_uid() >> 24ull; + + btmacaddr[0] = (bt_device >> 1 & 0x0F) | + (bt_device >> 5 & 0xF0); + btmacaddr[1] = (bt_device >> 11 & 0x0F) | + (bt_device >> 17 & 0xF0); + btmacaddr[2] = (bt_device >> 23 & 0x0F) | + (bt_device >> 29 & 0xF0); + + /* Set BT MAC address */ + fdt_find_and_setprop(blob, "/serial@70006200/bluetooth", + "local-bd-address", btmacaddr, 6, 1); + + /* Remove TrustZone nodes */ + fdt_del_node_and_alias(blob, "/firmware"); + fdt_del_node_and_alias(blob, "/reserved-memory/trustzone@bfe00000"); + + return 0; +} +#endif + +void nvidia_board_late_init(void) +{ + char serialno_str[17]; + + /* Set chip id as serialno */ + sprintf(serialno_str, "%016llx", tegra_chip_uid()); + env_set("serial#", serialno_str); + env_set("platform", "Tegra 3 T30"); +} diff --git a/configs/p880.config b/configs/p880.config new file mode 100644 index 0000000000..1a47b5f769 --- /dev/null +++ b/configs/p880.config @@ -0,0 +1,4 @@ +CONFIG_DEFAULT_DEVICE_TREE="tegra30-lg-p880" +CONFIG_DEVICE_P880=y +CONFIG_SYS_PROMPT="Tegra30 (P880) # " +CONFIG_VIDEO_LCD_RENESAS_R69328=y diff --git a/configs/p895.config b/configs/p895.config new file mode 100644 index 0000000000..019a5662d6 --- /dev/null +++ b/configs/p895.config @@ -0,0 +1,4 @@ +CONFIG_DEFAULT_DEVICE_TREE="tegra30-lg-p895" +CONFIG_DEVICE_P895=y +CONFIG_SYS_PROMPT="Tegra30 (P895) # " +CONFIG_VIDEO_LCD_RENESAS_R61307=y diff --git a/configs/x3_t30_defconfig b/configs/x3_t30_defconfig new file mode 100644 index 0000000000..540c43096d --- /dev/null +++ b/configs/x3_t30_defconfig @@ -0,0 +1,88 @@ +CONFIG_ARM=y +CONFIG_SYS_L2CACHE_OFF=y +CONFIG_ARCH_TEGRA=y +CONFIG_SUPPORT_PASSING_ATAGS=y +CONFIG_CMDLINE_TAG=y +CONFIG_INITRD_TAG=y +CONFIG_TEXT_BASE=0x80110000 +CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SIZE=0x3000 +CONFIG_ENV_OFFSET=0xFFFFD000 +CONFIG_DEFAULT_DEVICE_TREE="tegra30-lg-p880" +CONFIG_SPL_TEXT_BASE=0x80108000 +CONFIG_SYS_PROMPT="Tegra30 (x3) # " +CONFIG_SPL_STACK=0x800ffffc +CONFIG_TEGRA30=y +CONFIG_TARGET_X3_T30=y +CONFIG_TEGRA_ENABLE_UARTD=y +CONFIG_CMD_EBTUPDATE=y +CONFIG_SYS_LOAD_ADDR=0x82000000 +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_BOOTDELAY=0 +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_KEYED_CTRLC=y +CONFIG_USE_BOOTCOMMAND=y +CONFIG_BOOTCOMMAND="if run check_button; then bootmenu; fi; run bootcmd_mmc1; run bootcmd_mmc0; poweroff;" +CONFIG_SPL_FOOTPRINT_LIMIT=y +CONFIG_SPL_MAX_FOOTPRINT=0x8000 +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SYS_SPL_MALLOC=y +CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y +CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80090000 +CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SYS_MAXARGS=64 +CONFIG_SYS_PBSIZE=2084 +CONFIG_CMD_BOOTMENU=y +# CONFIG_CMD_IMI is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_GPT_RENAME=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_POWEROFF=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_UMS_ABORT_KEYED=y +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_NFS is not set +CONFIG_CMD_PAUSE=y +CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_ENV_OVERWRITE=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_PART=2 +CONFIG_SPL_DM=y +CONFIG_BUTTON=y +CONFIG_EXTCON=y +CONFIG_EXTCON_MAX14526=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x91000000 +CONFIG_FASTBOOT_BUF_SIZE=0x10000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_FASTBOOT_CMD_OEM_FORMAT=y +CONFIG_SYS_I2C_TEGRA=y +CONFIG_BUTTON_KEYBOARD=y +CONFIG_DM_PMIC=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_PWM_TEGRA=y +CONFIG_SYS_NS16550=y +CONFIG_TEGRA20_SLINK=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_TEGRA=y +CONFIG_USB_KEYBOARD=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="LG" +CONFIG_USB_GADGET_VENDOR_NUM=0x1004 +CONFIG_USB_GADGET_PRODUCT_NUM=0x7100 +CONFIG_CI_UDC=y +CONFIG_VIDEO=y +# CONFIG_VIDEO_LOGO is not set +CONFIG_BACKLIGHT_LM3533=y +CONFIG_VIDEO_BRIDGE_SOLOMON_SSD2825=y +CONFIG_VIDEO_TEGRA20=y +# CONFIG_CMD_BOOTEFI_BOOTMGR is not set diff --git a/doc/board/index.rst b/doc/board/index.rst index d28d8e1874..3cfec7caec 100644 --- a/doc/board/index.rst +++ b/doc/board/index.rst @@ -28,6 +28,7 @@ Board-specific doc highbank/index intel/index kontron/index + lg/index mediatek/index microchip/index nokia/index diff --git a/doc/board/lg/index.rst b/doc/board/lg/index.rst new file mode 100644 index 0000000000..3af3681e0b --- /dev/null +++ b/doc/board/lg/index.rst @@ -0,0 +1,9 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +LG +== + +.. toctree:: + :maxdepth: 2 + + x3_t30 diff --git a/doc/board/lg/x3_t30.rst b/doc/board/lg/x3_t30.rst new file mode 100644 index 0000000000..5c564aabc6 --- /dev/null +++ b/doc/board/lg/x3_t30.rst @@ -0,0 +1,93 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +U-Boot for the LG X3 T30 device family +====================================== + +``DISCLAMER!`` Moving your LG P880 or P895 to use U-Boot +assumes replacement of the vendor LG bootloader. Vendor +android firmwares will no longer be able to run on the +device. This replacement IS reversible. + +Quick Start +----------- + +- Build U-Boot +- Pack U-Boot into repart-block +- Flash repart-block into the eMMC +- Boot +- Self Upgrading + +Build U-Boot +------------ + +Device support is implemented by applying config fragment to a generic +board defconfig. Valid fragments are ``p880.config`` and ``p895.config``. + +.. code-block:: bash + + $ export CROSS_COMPILE=arm-linux-gnueabi- + $ make x3_t30_defconfig p895.config # For LG Optimus Vu + $ make + +After the build succeeds, you will obtain the final ``u-boot-dtb-tegra.bin`` +image, ready for flashing (but check the next section for additional +adjustments). + +Pack U-Boot into repar-block +---------------------------- + +``DISCLAMER!`` All questions related to re-crypt work should be +asked in re-crypt repo issues. NOT HERE! + +re-crypt is a small script which packs ``u-boot-dtb-tegra.bin`` in +form usable by device. This process is required only on the first +installation or to recover the device in case of a failed update. + +.. code-block:: bash + + $ git clone https://github.com/clamor-s/re-crypt.git + $ cd re-crypt # place your u-boot-dtb-regra.bin here + $ ./re-crypt.sh -d p895 + +Script will produce you a ``repart-block.bin`` ready to flash. + +Flash repart-block into the eMMC +-------------------------------- + +``DISCLAMER!`` All questions related to NvFlash should be asked +in the proper place. NOT HERE! Flashing repart-block will erase +all your eMMC, so make a backup before! + +``repart-block.bin`` contains BCT and bootloader in encrypted state +in form which can just be written RAW at the start of eMMC. + +.. code-block:: bash + + $ wheelie --blob blob.bin + $ nvflash --resume --rawdevicewrite 0 1024 repart-block.bin + +Boot +---- + +After flashing ``repart-block.bin`` the device should reboot and turn +itself off. This is normal behavior if no boot configuration is +found. + +To boot Linux, U-Boot will look for an ``extlinux.conf`` on MicroSD +and then on eMMC. Additionally if Volume Down button is pressed +while booting device will enter bootmenu. Bootmenu contains entries +to mount MicroSD and eMMC as mass storage, fastboot, reboot, reboot +RCM, poweroff, enter U-Boot console and update bootloader (check next +chapter). + +Flashing ``repart-block.bin`` eliminates vendor restriction on eMMC +and allows the user to use/partition it in any way the user desires. + +Self Upgrading +-------------- + +Place your ``u-boot-dtb-tegra.bin`` on the first partition of the +eMMC (using ability of u-boot to mount it). Enter bootmenu, choose +update bootloader option with Power button and U-Boot should update +itself. Once the process is completed, U-Boot will ask to press any +button to reboot. diff --git a/include/configs/x3-t30.h b/include/configs/x3-t30.h new file mode 100644 index 0000000000..d29ea700b2 --- /dev/null +++ b/include/configs/x3-t30.h @@ -0,0 +1,77 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * (C) Copyright 2010,2012 + * NVIDIA Corporation <www.nvidia.com> + * + * (C) Copyright 2022 + * Svyatoslav Ryhel clamor95@gmail.com + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <linux/sizes.h> + +#include "tegra30-common.h" + +#define CFG_TEGRA_BOARD_STRING "LG X3 Board" + +#ifdef CONFIG_DEVICE_P880 +/* High-level configuration options */ +#undef CFG_TEGRA_BOARD_STRING +#define CFG_TEGRA_BOARD_STRING "LG Optimus 4X HD" +#endif + +#ifdef CONFIG_DEVICE_P895 +/* High-level configuration options */ +#undef CFG_TEGRA_BOARD_STRING +#define CFG_TEGRA_BOARD_STRING "LG Optimus Vu" +#endif + +#define X3_FLASH_UBOOT \ + "flash_uboot=echo Preparing RAM;" \ + "mw ${kernel_addr_r} 0 ${boot_block_size_r};" \ + "mw ${ramdisk_addr_r} 0 ${boot_block_size_r};" \ + "echo Reading BCT;" \ + "mmc dev 0 1;" \ + "mmc read ${kernel_addr_r} 0 ${boot_block_size};" \ + "echo Reading bootloader;" \ + "if load mmc 0:1 ${ramdisk_addr_r} ${bootloader_file};" \ + "then echo Calculating bootloader size;" \ + "size mmc 0:1 ${bootloader_file};" \ + "ebtupdate ${kernel_addr_r} ${ramdisk_addr_r} ${filesize};" \ + "echo Writing bootloader to eMMC;" \ + "mmc dev 0 1;" \ + "mmc write ${kernel_addr_r} 0 ${boot_block_size};" \ + "mmc dev 0 2;" \ + "mmc write ${ramdisk_addr_r} 0 ${boot_block_size};" \ + "echo Bootloader written successfully;" \ + "pause 'Press ANY key to reboot device...'; reset;" \ + "else echo Reading bootloader failed;" \ + "pause 'Press ANY key to return to bootmenu...'; bootmenu; fi\0" + +#define X3_BOOTMENU \ + X3_FLASH_UBOOT \ + "bootmenu_0=mount internal storage=usb start && ums 0 mmc 0; bootmenu\0" \ + "bootmenu_1=mount external storage=usb start && ums 0 mmc 1; bootmenu\0" \ + "bootmenu_2=fastboot=echo Starting Fastboot protocol ...; fastboot usb 0; bootmenu\0" \ + "bootmenu_3=update bootloader=run flash_uboot\0" \ + "bootmenu_4=reboot RCM=enterrcm\0" \ + "bootmenu_5=reboot=reset\0" \ + "bootmenu_6=power off=poweroff\0" \ + "bootmenu_delay=-1\0" + +#define BOARD_EXTRA_ENV_SETTINGS \ + "boot_block_size_r=0x200000\0" \ + "boot_block_size=0x1000\0" \ + "bootloader_file=u-boot-dtb-tegra.bin\0" \ + "check_button=gpio input 116; test $? -eq 0\0" \ + "partitions=name=emmc,start=0,size=-,uuid=${uuid_gpt_rootfs}\0" \ + X3_BOOTMENU + +/* Board-specific serial config */ +#define CFG_SYS_NS16550_COM1 NV_PA_APB_UARTD_BASE + +#include "tegra-common-post.h" + +#endif /* __CONFIG_H */
The HTC One X is a touchscreen-based, slate-sized smartphone designed and manufactured by HTC that runs the Android operating system. The One X features a 4.7" display, an Nvidia Tegra 3 quad-core chip, 1 GB of RAM and non-extendable 32 GB of internal storage. UART-A is default debug port.
Tested-by: Andreas Westman Dorcsak hedmoo@yahoo.com Tested-by: Ion Agorria ion@agorria.com Tested-by: Svyatoslav Ryhel clamor95@gmail.com Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- arch/arm/dts/tegra30-htc-endeavoru.dts | 166 ++++++++ arch/arm/mach-tegra/tegra30/Kconfig | 5 + board/htc/endeavoru/Kconfig | 12 + board/htc/endeavoru/MAINTAINERS | 7 + board/htc/endeavoru/Makefile | 11 + board/htc/endeavoru/endeavoru-spl.c | 47 +++ board/htc/endeavoru/endeavoru.c | 116 ++++++ board/htc/endeavoru/pinmux-config-endeavoru.h | 362 ++++++++++++++++++ configs/endeavoru_defconfig | 84 ++++ doc/board/htc/endeavoru.rst | 89 +++++ doc/board/htc/index.rst | 9 + doc/board/index.rst | 1 + include/configs/endeavoru.h | 65 ++++ 13 files changed, 974 insertions(+) create mode 100644 arch/arm/dts/tegra30-htc-endeavoru.dts create mode 100644 board/htc/endeavoru/Kconfig create mode 100644 board/htc/endeavoru/MAINTAINERS create mode 100644 board/htc/endeavoru/Makefile create mode 100644 board/htc/endeavoru/endeavoru-spl.c create mode 100644 board/htc/endeavoru/endeavoru.c create mode 100644 board/htc/endeavoru/pinmux-config-endeavoru.h create mode 100644 configs/endeavoru_defconfig create mode 100644 doc/board/htc/endeavoru.rst create mode 100644 doc/board/htc/index.rst create mode 100644 include/configs/endeavoru.h
diff --git a/arch/arm/dts/tegra30-htc-endeavoru.dts b/arch/arm/dts/tegra30-htc-endeavoru.dts new file mode 100644 index 0000000000..c55e193d1d --- /dev/null +++ b/arch/arm/dts/tegra30-htc-endeavoru.dts @@ -0,0 +1,166 @@ +// SPDX-License-Identifier: GPL-2.0 +/dts-v1/; + +/* This dts file describes the HTC One X smartphone */ +/* CPU Speedo ID 4, Soc Speedo ID 1, CPU Process: 1, Core Process: 0 */ + +#include <dt-bindings/input/input.h> + +#include "tegra30.dtsi" + +/ { + model = "HTC One X"; + compatible = "htc,endeavoru", "nvidia,tegra30"; + + chosen { + stdout-path = &uarta; + }; + + aliases { + i2c0 = &pwr_i2c; + + mmc0 = &sdmmc4; /* eMMC */ + + rtc0 = &pmic; + rtc1 = "/rtc@7000e000"; + + usb0 = µ_usb; + }; + + memory { + device_type = "memory"; + reg = <0x80000000 0x40000000>; + }; + + host1x@50000000 { + dc@54200000 { + clocks = <&tegra_car TEGRA30_CLK_DISP1>, + <&tegra_car TEGRA30_CLK_PLL_D_OUT0>; + + rgb { + status = "okay"; + + nvidia,panel = <&dsia>; + }; + }; + + dsia: dsi@54300000 { + status = "okay"; + + avdd-dsi-csi-supply = <&avdd_dsi_csi>; + + panel = <&panel>; + }; + }; + + uarta: serial@70006000 { + status = "okay"; + }; + + pwr_i2c: i2c@7000d000 { + status = "okay"; + clock-frequency = <100000>; + + /* Texas Instruments TPS80032 PMIC */ + pmic: tps80032@48 { + compatible = "ti,tps80032"; + reg = <0x48>; + + regulators { + /* DSI VDD */ + avdd_dsi_csi: ldo1 { + regulator-name = "avdd_dsi_csi"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-always-on; + }; + }; + }; + }; + + sdmmc4: sdhci@78000600 { + status = "okay"; + bus-width = <8>; + non-removable; + }; + + micro_usb: usb@7d000000 { + status = "okay"; + dr_mode = "otg"; + }; + + backlight: backlight { + compatible = "nvidia,tegra-pwm-backlight"; + + nvidia,pwm-source = <1>; + nvidia,default-brightness = <0x8E>; + }; + + /* PMIC has a built-in 32KHz oscillator which is used by PMC */ + clk32k_in: clock-32k { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + clock-output-names = "pmic-oscillator"; + }; + + gpio-keys { + compatible = "gpio-keys"; + + key-power { + label = "Power"; + gpios = <&gpio TEGRA_GPIO(U, 6) GPIO_ACTIVE_LOW>; + linux,code = <KEY_ENTER>; + }; + + key-volume-up { + label = "Volume Up"; + gpios = <&gpio TEGRA_GPIO(S, 0) GPIO_ACTIVE_LOW>; + linux,code = <KEY_UP>; + }; + + key-volume-down { + label = "Volume Down"; + gpios = <&gpio TEGRA_GPIO(W, 3) GPIO_ACTIVE_LOW>; + linux,code = <KEY_DOWN>; + }; + }; + + panel: panel { + compatible = "htc,edge-panel"; + + reset-gpios = <&gpio TEGRA_GPIO(N, 6) GPIO_ACTIVE_LOW>; + + vdd-supply = <&vdd_3v3_panel>; + vddio-supply = <&vdd_1v8_panel>; + + backlight = <&backlight>; + }; + + vcore_emmc: regulator-emmc { + compatible = "regulator-fixed"; + regulator-name = "vdd_2v85_sdmmc"; + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <2850000>; + gpio = <&gpio TEGRA_GPIO(M, 3) GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + vdd_3v3_panel: regulator-lcm { + compatible = "regulator-fixed"; + regulator-name = "v_lcm_3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio TEGRA_GPIO(E, 2) GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + vdd_1v8_panel: regulator-lcmio { + compatible = "regulator-fixed"; + regulator-name = "v_lcmio_1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + gpio = <&gpio TEGRA_GPIO(E, 5) GPIO_ACTIVE_HIGH>; + enable-active-high; + }; +}; diff --git a/arch/arm/mach-tegra/tegra30/Kconfig b/arch/arm/mach-tegra/tegra30/Kconfig index 9b1df21d28..3e478b3b7b 100644 --- a/arch/arm/mach-tegra/tegra30/Kconfig +++ b/arch/arm/mach-tegra/tegra30/Kconfig @@ -20,6 +20,10 @@ config TARGET_COLIBRI_T30 bool "Toradex Colibri T30 board" select BOARD_LATE_INIT
+config TARGET_ENDEAVORU + bool "HTC Endeavoru T30 board" + select BOARD_LATE_INIT + config TARGET_GROUPER bool "Asus and Google Grouper board" select BOARD_LATE_INIT @@ -45,6 +49,7 @@ source "board/toradex/apalis_t30/Kconfig" source "board/nvidia/beaver/Kconfig" source "board/nvidia/cardhu/Kconfig" source "board/toradex/colibri_t30/Kconfig" +source "board/htc/endeavoru/Kconfig" source "board/asus/grouper/Kconfig" source "board/avionic-design/tec-ng/Kconfig" source "board/asus/transformer-t30/Kconfig" diff --git a/board/htc/endeavoru/Kconfig b/board/htc/endeavoru/Kconfig new file mode 100644 index 0000000000..0b72c4a687 --- /dev/null +++ b/board/htc/endeavoru/Kconfig @@ -0,0 +1,12 @@ +if TARGET_ENDEAVORU + +config SYS_BOARD + default "endeavoru" + +config SYS_VENDOR + default "htc" + +config SYS_CONFIG_NAME + default "endeavoru" + +endif diff --git a/board/htc/endeavoru/MAINTAINERS b/board/htc/endeavoru/MAINTAINERS new file mode 100644 index 0000000000..85f439f467 --- /dev/null +++ b/board/htc/endeavoru/MAINTAINERS @@ -0,0 +1,7 @@ +ENDEAVORU BOARD +M: Svyatoslav Ryhel clamor95@gmail.com +S: Maintained +F: board/htc/endeavoru/ +F: configs/endeavoru_defconfig +F: doc/board/htc/endeavoru.rst +F: include/configs/endeavoru.h diff --git a/board/htc/endeavoru/Makefile b/board/htc/endeavoru/Makefile new file mode 100644 index 0000000000..0c6ba4af3b --- /dev/null +++ b/board/htc/endeavoru/Makefile @@ -0,0 +1,11 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2010-2012 +# NVIDIA Corporation <www.nvidia.com> +# +# (C) Copyright 2021 +# Svyatoslav Ryhel clamor95@gmail.com + +obj-$(CONFIG_SPL_BUILD) += endeavoru-spl.o + +obj-y += endeavoru.o diff --git a/board/htc/endeavoru/endeavoru-spl.c b/board/htc/endeavoru/endeavoru-spl.c new file mode 100644 index 0000000000..7921ff1a73 --- /dev/null +++ b/board/htc/endeavoru/endeavoru-spl.c @@ -0,0 +1,47 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * T30 HTC Endeavoru SPL stage configuration + * + * (C) Copyright 2010-2013 + * NVIDIA Corporation <www.nvidia.com> + * + * (C) Copyright 2022 + * Svyatoslav Ryhel clamor95@gmail.com + */ + +#include <common.h> +#include <asm/arch-tegra/tegra_i2c.h> +#include <linux/delay.h> + +/* + * Endeavoru uses TPS80032 PMIC with SMPS1 and SMPS2 in strandard + * mode with zero offset. + */ + +#define TPS80032_DVS_I2C_ADDR (0x12 << 1) +#define TPS80032_SMPS1_CFG_VOLTAGE_REG 0x56 +#define TPS80032_SMPS2_CFG_VOLTAGE_REG 0x5C +#define TPS80032_SMPS1_CFG_VOLTAGE_DATA (0x2100 | TPS80032_SMPS1_CFG_VOLTAGE_REG) +#define TPS80032_SMPS2_CFG_VOLTAGE_DATA (0x3000 | TPS80032_SMPS2_CFG_VOLTAGE_REG) + +#define TPS80032_CTL1_I2C_ADDR (0x48 << 1) +#define TPS80032_SMPS1_CFG_STATE_REG 0x54 +#define TPS80032_SMPS2_CFG_STATE_REG 0x5A +#define TPS80032_SMPS1_CFG_STATE_DATA (0x0100 | TPS80032_SMPS1_CFG_STATE_REG) +#define TPS80032_SMPS2_CFG_STATE_DATA (0x0100 | TPS80032_SMPS2_CFG_STATE_REG) + +void pmic_enable_cpu_vdd(void) +{ + /* Set VDD_CORE to 1.200V. */ + tegra_i2c_ll_write(TPS80032_DVS_I2C_ADDR, TPS80032_SMPS2_CFG_VOLTAGE_DATA); + udelay(1000); + tegra_i2c_ll_write(TPS80032_CTL1_I2C_ADDR, TPS80032_SMPS2_CFG_STATE_DATA); + + udelay(1000); + + /* Bring up VDD_CPU to 1.0125V. */ + tegra_i2c_ll_write(TPS80032_DVS_I2C_ADDR, TPS80032_SMPS1_CFG_VOLTAGE_DATA); + udelay(1000); + tegra_i2c_ll_write(TPS80032_CTL1_I2C_ADDR, TPS80032_SMPS1_CFG_STATE_DATA); + udelay(10 * 1000); +} diff --git a/board/htc/endeavoru/endeavoru.c b/board/htc/endeavoru/endeavoru.c new file mode 100644 index 0000000000..1d92870f91 --- /dev/null +++ b/board/htc/endeavoru/endeavoru.c @@ -0,0 +1,116 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2010-2013 + * NVIDIA Corporation <www.nvidia.com> + * + * (C) Copyright 2021 + * Svyatoslav Ryhel clamor95@gmail.com + */ + +#include <common.h> +#include <dm.h> +#include <env.h> +#include <fdt_support.h> +#include <i2c.h> +#include <log.h> +#include <asm/arch/pinmux.h> +#include <asm/arch/gp_padctrl.h> +#include <asm/arch/gpio.h> +#include <asm/arch-tegra/fuse.h> +#include <asm/gpio.h> +#include <linux/delay.h> +#include "pinmux-config-endeavoru.h" + +#define TPS80032_CTL1_I2C_ADDR 0x48 +#define TPS80032_PHOENIX_DEV_ON 0x25 +#define DEVOFF BIT(0) +#define TPS80032_LDO1_CFG_STATE 0x9E +#define TPS80032_LDO1_CFG_VOLTAGE 0x9F + +#ifdef CONFIG_CMD_POWEROFF +int do_poweroff(struct cmd_tbl *cmdtp, int flag, + int argc, char *const argv[]) +{ + struct udevice *dev; + int ret; + + ret = i2c_get_chip_for_busnum(0, TPS80032_CTL1_I2C_ADDR, 1, &dev); + if (ret) { + log_debug("cannot find PMIC I2C chip\n"); + return 0; + } + + ret = dm_i2c_reg_write(dev, TPS80032_PHOENIX_DEV_ON, DEVOFF); + if (ret) + return ret; + + // wait some time and then print error + mdelay(5000); + + printf("Failed to power off!!!\n"); + return 1; +} +#endif + +/* + * Routine: pinmux_init + * Description: Do individual peripheral pinmux configs + */ +void pinmux_init(void) +{ + pinmux_config_pingrp_table(endeavoru_pinmux_common, + ARRAY_SIZE(endeavoru_pinmux_common)); +} + +#ifdef CONFIG_MMC_SDHCI_TEGRA +static void tps80032_voltage_init(void) +{ + struct udevice *dev; + int ret; + + ret = i2c_get_chip_for_busnum(0, TPS80032_CTL1_I2C_ADDR, 1, &dev); + if (ret) + log_debug("cannot find PMIC I2C chip\n"); + + /* TPS80032: LDO1_REG = 1.2v to DSI */ + ret = dm_i2c_reg_write(dev, TPS80032_LDO1_CFG_VOLTAGE, 0x03); + if (ret) + log_debug("avdd_dsi_csi voltage set failed: %d\n", ret); + + /* TPS80032: LDO1_REG enable */ + ret = dm_i2c_reg_write(dev, TPS80032_LDO1_CFG_STATE, 0x01); + if (ret) + log_debug("avdd_dsi_csi enable failed: %d\n", ret); +} + +/* + * Routine: pin_mux_mmc + * Description: setup the MMC muxes, power rails, etc. + */ +void pin_mux_mmc(void) +{ + /* Bring up DSI power */ + tps80032_voltage_init(); +} +#endif /* MMC */ + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +int ft_board_setup(void *blob, struct bd_info *bd) +{ + /* Remove TrustZone nodes */ + fdt_del_node_and_alias(blob, "/firmware"); + fdt_del_node_and_alias(blob, "/reserved-memory/trustzone@bfe00000"); + + return 0; +} +#endif + +void nvidia_board_late_init(void) +{ + char serialno_str[17]; + + /* Set chip id as serialno */ + sprintf(serialno_str, "%016llx", tegra_chip_uid()); + env_set("serial#", serialno_str); + env_set("platform", "Tegra 3 T30"); +} diff --git a/board/htc/endeavoru/pinmux-config-endeavoru.h b/board/htc/endeavoru/pinmux-config-endeavoru.h new file mode 100644 index 0000000000..a00c5c988f --- /dev/null +++ b/board/htc/endeavoru/pinmux-config-endeavoru.h @@ -0,0 +1,362 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. + * + * Copyright (c) 2022, Svyatoslav Ryhel. + */ + +#ifndef _PINMUX_CONFIG_ENDEAVORU_H_ +#define _PINMUX_CONFIG_ENDEAVORU_H_ + +#define DEFAULT_PINMUX(_pingrp, _mux, _pull, _tri, _io) \ + { \ + .pingrp = PMUX_PINGRP_##_pingrp, \ + .func = PMUX_FUNC_##_mux, \ + .pull = PMUX_PULL_##_pull, \ + .tristate = PMUX_TRI_##_tri, \ + .io = PMUX_PIN_##_io, \ + .lock = PMUX_PIN_LOCK_DEFAULT, \ + .od = PMUX_PIN_OD_DEFAULT, \ + .ioreset = PMUX_PIN_IO_RESET_DEFAULT, \ + } + +#define I2C_PINMUX(_pingrp, _mux, _pull, _tri, _io, _lock, _od) \ + { \ + .pingrp = PMUX_PINGRP_##_pingrp, \ + .func = PMUX_FUNC_##_mux, \ + .pull = PMUX_PULL_##_pull, \ + .tristate = PMUX_TRI_##_tri, \ + .io = PMUX_PIN_##_io, \ + .lock = PMUX_PIN_LOCK_##_lock, \ + .od = PMUX_PIN_OD_##_od, \ + .ioreset = PMUX_PIN_IO_RESET_DEFAULT, \ + } + +#define LV_PINMUX(_pingrp, _mux, _pull, _tri, _io, _lock, _ioreset) \ + { \ + .pingrp = PMUX_PINGRP_##_pingrp, \ + .func = PMUX_FUNC_##_mux, \ + .pull = PMUX_PULL_##_pull, \ + .tristate = PMUX_TRI_##_tri, \ + .io = PMUX_PIN_##_io, \ + .lock = PMUX_PIN_LOCK_##_lock, \ + .od = PMUX_PIN_OD_DEFAULT, \ + .ioreset = PMUX_PIN_IO_RESET_##_ioreset \ + } + +#define DEFAULT_PADCFG(_drvgrp, _slwf, _slwr, _drvup, _drvdn, _lpmd, _schmt, _hsm) \ + { \ + .drvgrp = PMUX_DRVGRP_##_drvgrp, \ + .slwf = _slwf, \ + .slwr = _slwr, \ + .drvup = _drvup, \ + .drvdn = _drvdn, \ + .lpmd = PMUX_LPMD_##_lpmd, \ + .schmt = PMUX_SCHMT_##_schmt, \ + .hsm = PMUX_HSM_##_hsm, \ + } + +static struct pmux_pingrp_config endeavoru_pinmux_common[] = { + /* SDMMC1 pinmux */ + DEFAULT_PINMUX(SDMMC1_CLK_PZ0, SDMMC1, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(SDMMC1_CMD_PZ1, SDMMC1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_DAT3_PY4, UARTE, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(SDMMC1_DAT2_PY5, UARTE, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_DAT1_PY6, RSVD2, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(SDMMC1_DAT0_PY7, SDMMC1, UP, NORMAL, INPUT), + + /* SDMMC3 pinmux */ + DEFAULT_PINMUX(SDMMC3_CLK_PA6, SDMMC3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_CMD_PA7, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT0_PB7, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT1_PB6, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT2_PB5, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT3_PB4, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT4_PD1, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT5_PD0, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT6_PD3, INVALID, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT7_PD4, INVALID, NORMAL, NORMAL, INPUT), + + /* SDMMC4 pinmux */ + LV_PINMUX(SDMMC4_CLK_PCC4, SDMMC4, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_CMD_PT7, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT0_PAA0, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT1_PAA1, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT2_PAA2, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT3_PAA3, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT4_PAA4, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT5_PAA5, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT6_PAA6, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT7_PAA7, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_RST_N_PCC3, RSVD2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + + /* I2C pinmux */ + I2C_PINMUX(GEN1_I2C_SCL_PC4, I2C1, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(GEN1_I2C_SDA_PC5, I2C1, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(GEN2_I2C_SCL_PT5, I2C2, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(GEN2_I2C_SDA_PT6, I2C2, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(CAM_I2C_SCL_PBB1, I2C3, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(CAM_I2C_SDA_PBB2, I2C3, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(DDC_SCL_PV4, I2C4, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(DDC_SDA_PV5, I2C4, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(PWR_I2C_SCL_PZ6, I2CPWR, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(PWR_I2C_SDA_PZ7, I2CPWR, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + + /* HDMI pinmux */ + DEFAULT_PINMUX(HDMI_CEC_PEE3, CEC, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(HDMI_INT_PN7, RSVD1, NORMAL, TRISTATE, INPUT), + + /* ULPI pinmux */ + DEFAULT_PINMUX(ULPI_DATA0_PO1, UARTA, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(ULPI_DATA1_PO2, UARTA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_DATA2_PO3, SPI3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_DATA3_PO4, HSI, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_DATA4_PO5, SPI2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_DATA5_PO6, ULPI, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_DATA6_PO7, ULPI, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_DATA7_PO0, SPI2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_CLK_PY0, RSVD2, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(ULPI_DIR_PY1, RSVD2, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(ULPI_NXT_PY2, ULPI, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(ULPI_STP_PY3, ULPI, NORMAL, NORMAL, INPUT), + + /* DAP3 pinmux */ + DEFAULT_PINMUX(DAP3_FS_PP0, I2S2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP3_DIN_PP1, I2S2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP3_DOUT_PP2, I2S2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP3_SCLK_PP3, I2S2, NORMAL, NORMAL, INPUT), + + /* PV-gpio group pinmux */ + DEFAULT_PINMUX(PV0, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PV1, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PV2, RSVD2, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PV3, RSVD2, NORMAL, NORMAL, OUTPUT), + + /* CLK2 pinmux */ + DEFAULT_PINMUX(CLK2_OUT_PW5, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(CLK2_REQ_PCC5, RSVD4, NORMAL, NORMAL, OUTPUT), + + /* LCD pinmux */ + DEFAULT_PINMUX(LCD_PWR1_PC1, RSVD4, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(LCD_PWR2_PC6, DISPLAYA, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(LCD_SDIN_PZ2, DISPLAYA, UP, NORMAL, OUTPUT), + DEFAULT_PINMUX(LCD_SDOUT_PN5, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_WR_N_PZ3, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_CS0_N_PN4, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_DC0_PN6, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_SCK_PZ4, DISPLAYA, UP, TRISTATE, OUTPUT), + DEFAULT_PINMUX(LCD_PWR0_PB2, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_PCLK_PB3, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_DE_PJ1, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_HSYNC_PJ3, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_VSYNC_PJ4, DISPLAYA, DOWN, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D0_PE0, DISPLAYA, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(LCD_D1_PE1, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D2_PE2, RSVD3, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(LCD_D3_PE3, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D4_PE4, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D5_PE5, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D6_PE6, RSVD3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D7_PE7, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D8_PF0, RSVD4, DOWN, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D9_PF1, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D10_PF2, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D11_PF3, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D12_PF4, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D13_PF5, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D14_PF6, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D15_PF7, RSVD4, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(LCD_D16_PM0, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D17_PM1, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D18_PM2, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D19_PM3, RSVD4, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(LCD_D20_PM4, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D21_PM5, RSVD4, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(LCD_D22_PM6, RSVD4, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(LCD_D23_PM7, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_CS1_N_PW0, RSVD4, UP, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_M1_PW1, DISPLAYA, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(LCD_DC1_PD2, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(CRT_HSYNC_PV6, CRT, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(CRT_VSYNC_PV7, RSVD4, NORMAL, NORMAL, OUTPUT), + + /* VI-group pinmux */ + LV_PINMUX(VI_D0_PT4, INVALID, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D1_PD5, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D2_PL0, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D3_PL1, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D4_PL2, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D5_PL3, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D6_PL4, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D7_PL5, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D8_PL6, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D9_PL7, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D10_PT2, INVALID, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D11_PT3, INVALID, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_PCLK_PT0, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_MCLK_PT1, INVALID, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_VSYNC_PD6, INVALID, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_HSYNC_PD7, INVALID, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + + /* UART-2 pinmux */ + DEFAULT_PINMUX(UART2_RXD_PC3, SPI4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART2_TXD_PC2, SPI4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART2_RTS_N_PJ6, SPI4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART2_CTS_N_PJ5, SPI4, NORMAL, NORMAL, INPUT), + + /* UART-3 pinmux */ + DEFAULT_PINMUX(UART3_TXD_PW6, UARTC, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(UART3_RXD_PW7, UARTC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(UART3_CTS_N_PA1, UARTC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(UART3_RTS_N_PC0, UARTC, NORMAL, NORMAL, OUTPUT), + + /* PU-gpio group pinmux */ + DEFAULT_PINMUX(PU0, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PU1, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PU2, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PU3, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PU4, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PU5, RSVD4, UP, NORMAL, INPUT), + DEFAULT_PINMUX(PU6, PWM3, UP, TRISTATE, INPUT), + + /* DAP4 pinmux */ + DEFAULT_PINMUX(DAP4_FS_PP4, I2S3, DOWN, NORMAL, INPUT), + DEFAULT_PINMUX(DAP4_DIN_PP5, I2S3, DOWN, NORMAL, INPUT), + DEFAULT_PINMUX(DAP4_DOUT_PP6, RSVD4, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(DAP4_SCLK_PP7, RSVD4, NORMAL, NORMAL, OUTPUT), + + /* CLK3 pinmux */ + DEFAULT_PINMUX(CLK3_OUT_PEE0, EXTPERIPH3, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(CLK3_REQ_PEE1, RSVD4, NORMAL, TRISTATE, INPUT), + + /* GMI pinmux */ + DEFAULT_PINMUX(GMI_WP_N_PC7, RSVD1, UP, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_IORDY_PI5, RSVD1, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_WAIT_PI7, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_ADV_N_PK0, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_CLK_PK1, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_CS0_N_PJ0, GMI, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_CS1_N_PJ2, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_CS2_N_PK3, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_CS3_N_PK4, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_CS4_N_PK2, RSVD4, UP, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_CS6_N_PI3, NAND, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_CS7_N_PI6, NAND, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD0_PG0, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD1_PG1, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD2_PG2, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD3_PG3, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD4_PG4, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD5_PG5, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD6_PG6, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD7_PG7, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD8_PH0, PWM0, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_AD9_PH1, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD10_PH2, NAND, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_AD11_PH3, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD12_PH4, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD13_PH5, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD14_PH6, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD15_PH7, NAND, UP, TRISTATE, INPUT), + DEFAULT_PINMUX(GMI_A16_PJ7, UARTD, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_A17_PB0, UARTD, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_A18_PB1, UARTD, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_A19_PK7, UARTD, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_WR_N_PI0, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_OE_N_PI1, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_DQS_PI2, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_RST_N_PI4, RSVD4, UP, TRISTATE, INPUT), + + DEFAULT_PINMUX(CAM_MCLK_PCC0, VI_ALT3, NORMAL, NORMAL, INPUT), + + DEFAULT_PINMUX(PCC1, RSVD3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PBB0, RSVD3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PBB3, VGP3, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PBB4, VGP4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PBB5, VGP5, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PBB6, VGP6, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PBB7, RSVD3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PCC2, RSVD3, UP, NORMAL, INPUT), + + DEFAULT_PINMUX(JTAG_RTCK_PU7, RTCK, UP, NORMAL, INPUT), + + /* KBC keys */ + DEFAULT_PINMUX(KB_ROW0_PR0, RSVD4, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_ROW1_PR1, KBC, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(KB_ROW2_PR2, RSVD4, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(KB_ROW3_PR3, RSVD3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW4_PR4, RSVD4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW5_PR5, KBC, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(KB_ROW6_PR6, KBC, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_ROW7_PR7, KBC, UP, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_ROW8_PS0, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW9_PS1, KBC, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW10_PS2, KBC, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW11_PS3, KBC, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW12_PS4, KBC, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW13_PS5, KBC, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW14_PS6, KBC, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW15_PS7, KBC, NORMAL, NORMAL, INPUT), + + DEFAULT_PINMUX(KB_COL0_PQ0, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL1_PQ1, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL2_PQ2, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL3_PQ3, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL4_PQ4, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL5_PQ5, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL6_PQ6, KBC, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL7_PQ7, KBC, NORMAL, NORMAL, INPUT), + + /* CLK */ + DEFAULT_PINMUX(CLK_32K_OUT_PA0, BLINK, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(SYS_CLK_REQ_PZ5, SYSCLK, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(OWR, OWR, UP, NORMAL, INPUT), + + /* DAP1 pinmux */ + DEFAULT_PINMUX(DAP1_FS_PN0, I2S0, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(DAP1_DIN_PN1, I2S0, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(DAP1_DOUT_PN2, I2S0, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(DAP1_SCLK_PN3, I2S0, NORMAL, TRISTATE, OUTPUT), + + /* CLK1 pinmux */ + DEFAULT_PINMUX(CLK1_REQ_PEE2, DAP, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(CLK1_OUT_PW4, RSVD4, NORMAL, NORMAL, INPUT), + + /* SPDIF pinmux */ + DEFAULT_PINMUX(SPDIF_IN_PK6, SPDIF, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(SPDIF_OUT_PK5, SPDIF, NORMAL, TRISTATE, OUTPUT), + + /* DAP2 pinmux */ + DEFAULT_PINMUX(DAP2_FS_PA2, I2S1, DOWN, NORMAL, INPUT), + DEFAULT_PINMUX(DAP2_DIN_PA4, I2S1, DOWN, NORMAL, INPUT), + DEFAULT_PINMUX(DAP2_DOUT_PA5, I2S1, DOWN, NORMAL, INPUT), + DEFAULT_PINMUX(DAP2_SCLK_PA3, I2S1, DOWN, NORMAL, INPUT), + + /* SPI pinmux */ + DEFAULT_PINMUX(SPI2_MOSI_PX0, SPI2, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(SPI2_MISO_PX1, SPI2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPI2_CS0_N_PX3, SPI2, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(SPI2_SCK_PX2, SPI2, NORMAL, NORMAL, OUTPUT), + + DEFAULT_PINMUX(SPI2_CS1_N_PW2, SPI2, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SPI2_CS2_N_PW3, SPI2, UP, TRISTATE, INPUT), + + DEFAULT_PINMUX(SPI1_MOSI_PX4, SPI1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPI1_SCK_PX5, SPI2, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SPI1_CS0_N_PX6, SPI1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPI1_MISO_PX7, RSVD4, NORMAL, NORMAL, OUTPUT), + + /* PEX pinmux */ + DEFAULT_PINMUX(PEX_L0_PRSNT_N_PDD0, PCIE, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PEX_L0_RST_N_PDD1, PCIE, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PEX_L0_CLKREQ_N_PDD2, PCIE, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PEX_WAKE_N_PDD3, PCIE, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PEX_L1_PRSNT_N_PDD4, PCIE, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PEX_L1_RST_N_PDD5, PCIE, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PEX_L1_CLKREQ_N_PDD6, PCIE, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PEX_L2_PRSNT_N_PDD7, PCIE, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PEX_L2_RST_N_PCC6, PCIE, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PEX_L2_CLKREQ_N_PCC7, PCIE, NORMAL, NORMAL, INPUT), +}; + +#endif /* _PINMUX_CONFIG_TRANSFORMER_H_ */ diff --git a/configs/endeavoru_defconfig b/configs/endeavoru_defconfig new file mode 100644 index 0000000000..38f26f2dcc --- /dev/null +++ b/configs/endeavoru_defconfig @@ -0,0 +1,84 @@ +CONFIG_ARM=y +CONFIG_SYS_L2CACHE_OFF=y +CONFIG_ARCH_TEGRA=y +CONFIG_SUPPORT_PASSING_ATAGS=y +CONFIG_CMDLINE_TAG=y +CONFIG_INITRD_TAG=y +CONFIG_TEXT_BASE=0x80110000 +CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SIZE=0x3000 +CONFIG_ENV_OFFSET=0xFFFFD000 +CONFIG_DEFAULT_DEVICE_TREE="tegra30-htc-endeavoru" +CONFIG_SPL_TEXT_BASE=0x80108000 +CONFIG_SYS_PROMPT="Tegra30 (Endeavoru) # " +CONFIG_SPL_STACK=0x800ffffc +CONFIG_TEGRA30=y +CONFIG_TARGET_ENDEAVORU=y +CONFIG_CMD_EBTUPDATE=y +CONFIG_SYS_LOAD_ADDR=0x82000000 +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_BOOTDELAY=0 +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_KEYED_CTRLC=y +CONFIG_USE_BOOTCOMMAND=y +CONFIG_BOOTCOMMAND="if run check_button; then bootmenu; fi; run bootcmd_mmc0; poweroff;" +CONFIG_SPL_FOOTPRINT_LIMIT=y +CONFIG_SPL_MAX_FOOTPRINT=0x8000 +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SYS_SPL_MALLOC=y +CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y +CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80090000 +CONFIG_SYS_SPL_MALLOC_SIZE=0x10000 +CONFIG_SYS_MAXARGS=64 +CONFIG_SYS_PBSIZE=2084 +CONFIG_CMD_BOOTMENU=y +# CONFIG_CMD_IMI is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_GPT_RENAME=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_POWEROFF=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_UMS_ABORT_KEYED=y +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_NFS is not set +CONFIG_CMD_PAUSE=y +CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_ENV_OVERWRITE=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_PART=2 +CONFIG_SPL_DM=y +CONFIG_BUTTON=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x91000000 +CONFIG_FASTBOOT_BUF_SIZE=0x10000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_FASTBOOT_CMD_OEM_FORMAT=y +CONFIG_SYS_I2C_TEGRA=y +CONFIG_BUTTON_KEYBOARD=y +CONFIG_DM_PMIC=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_PWM_TEGRA=y +CONFIG_SYS_NS16550=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_TEGRA=y +CONFIG_USB_KEYBOARD=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="HTC" +CONFIG_USB_GADGET_VENDOR_NUM=0x0bb4 +CONFIG_USB_GADGET_PRODUCT_NUM=0x0c02 +CONFIG_CI_UDC=y +CONFIG_VIDEO=y +# CONFIG_VIDEO_LOGO is not set +CONFIG_VIDEO_LCD_ENDEAVORU=y +CONFIG_VIDEO_DSI_TEGRA30=y +CONFIG_TEGRA_BACKLIGHT_PWM=y +# CONFIG_CMD_BOOTEFI_BOOTMGR is not set diff --git a/doc/board/htc/endeavoru.rst b/doc/board/htc/endeavoru.rst new file mode 100644 index 0000000000..950c713f2f --- /dev/null +++ b/doc/board/htc/endeavoru.rst @@ -0,0 +1,89 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +U-Boot for the HTC One X (endeavoru) +==================================== + +``DISCLAMER!`` Moving your HTC ONe X to use U-Boot assumes +replacement of the vendor hboot. Vendor android firmwares +will no longer be able to run on the device. +This replacement IS reversible. + +Quick Start +----------- + +- Build U-Boot +- Pack U-Boot into repart-block +- Flash repart-block into the eMMC +- Boot +- Self Upgrading + +Build U-Boot +------------ + +.. code-block:: bash + + $ export CROSS_COMPILE=arm-linux-gnueabi- + $ make endeavoru_defconfig + $ make + +After the build succeeds, you will obtain the final ``u-boot-dtb-tegra.bin`` +image, ready for flashing (but check the next section for additional +adjustments). + +Pack U-Boot into repar-block +---------------------------- + +``DISCLAMER!`` All questions related to re-crypt work should be +asked in re-crypt repo issues. NOT HERE! + +re-crypt is a small script which packs ``u-boot-dtb-tegra.bin`` in +form usable by device. This process is required only on the first +installation or to recover the device in case of a failed update. + +.. code-block:: bash + + $ git clone https://github.com/clamor-s/re-crypt.git + $ cd re-crypt # place your u-boot-dtb-regra.bin here + $ ./re-crypt.sh -d endeavoru + +Script will produce you a ``repart-block.bin`` ready to flash. + +Flash repart-block into the eMMC +-------------------------------- + +``DISCLAMER!`` All questions related to NvFlash should be asked +in the proper place. NOT HERE! Flashing repart-block will erase +all your eMMC, so make a backup before! + +``repart-block.bin`` contains BCT and bootloader in encrypted state +in form which can just be written RAW at the start of eMMC. + +.. code-block:: bash + + $ wheelie --blob blob.bin + $ nvflash --resume --rawdevicewrite 0 1024 repart-block.bin + +Boot +---- + +After flashing ``repart-block.bin`` the device should reboot and turn +itself off. This is normal behavior if no boot configuration is +found. + +To boot Linux, U-Boot will look for an ``extlinux.conf`` configuration +on eMMC. Additionally if Volume Down button is pressed while booting +device will enter bootmenu. Bootmenu contains entries to mount eMMC as +mass storage, fastboot, reboot, reboot RCM, poweroff, enter U-Boot +console and update bootloader (check next chapter). + +Flashing ``repart-block.bin`` eliminates vendor restriction on eMMC +and allows the user to use/partition it in any way the user desires. + +Self Upgrading +-------------- + +Place your ``u-boot-dtb-tegra.bin`` on the first partition of the +eMMC (using ability of u-boot to mount it). Enter bootmenu, choose +update bootloader option with Power button and U-Boot should update +itself. Once the process is completed, U-Boot will ask to press any +button to reboot. diff --git a/doc/board/htc/index.rst b/doc/board/htc/index.rst new file mode 100644 index 0000000000..955c9b9e03 --- /dev/null +++ b/doc/board/htc/index.rst @@ -0,0 +1,9 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +HTC +=== + +.. toctree:: + :maxdepth: 2 + + endeavoru diff --git a/doc/board/index.rst b/doc/board/index.rst index 3cfec7caec..2e11dbb06f 100644 --- a/doc/board/index.rst +++ b/doc/board/index.rst @@ -26,6 +26,7 @@ Board-specific doc gateworks/index google/index highbank/index + htc/index intel/index kontron/index lg/index diff --git a/include/configs/endeavoru.h b/include/configs/endeavoru.h new file mode 100644 index 0000000000..46c582e963 --- /dev/null +++ b/include/configs/endeavoru.h @@ -0,0 +1,65 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * (C) Copyright 2010,2012 + * NVIDIA Corporation <www.nvidia.com> + * + * (C) Copyright 2022 + * Svyatoslav Ryhel clamor95@gmail.com + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <linux/sizes.h> + +#include "tegra30-common.h" + +/* High-level configuration options */ +#define CFG_TEGRA_BOARD_STRING "HTC One X" + +#define ENDEAVORU_FLASH_UBOOT \ + "flash_uboot=echo Preparing RAM;" \ + "mw ${kernel_addr_r} 0 ${boot_block_size_r};" \ + "mw ${ramdisk_addr_r} 0 ${boot_block_size_r};" \ + "echo Reading BCT;" \ + "mmc dev 0 1;" \ + "mmc read ${kernel_addr_r} 0 ${boot_block_size};" \ + "echo Reading bootloader;" \ + "if load mmc 0:1 ${ramdisk_addr_r} ${bootloader_file};" \ + "then echo Calculating bootloader size;" \ + "size mmc 0:1 ${bootloader_file};" \ + "ebtupdate ${kernel_addr_r} ${ramdisk_addr_r} ${filesize};" \ + "echo Writing bootloader to eMMC;" \ + "mmc dev 0 1;" \ + "mmc write ${kernel_addr_r} 0 ${boot_block_size};" \ + "mmc dev 0 2;" \ + "mmc write ${ramdisk_addr_r} 0 ${boot_block_size};" \ + "echo Bootloader written successfully;" \ + "pause 'Press ANY key to reboot device...'; reset;" \ + "else echo Reading bootloader failed;" \ + "pause 'Press ANY key to return to bootmenu...'; bootmenu; fi\0" + +#define ENDEAVORU_BOOTMENU \ + ENDEAVORU_FLASH_UBOOT \ + "bootmenu_0=mount internal storage=usb start && ums 0 mmc 0; bootmenu\0" \ + "bootmenu_1=fastboot=echo Starting Fastboot protocol ...; fastboot usb 0; bootmenu\0" \ + "bootmenu_2=update bootloader=run flash_uboot\0" \ + "bootmenu_3=reboot RCM=enterrcm\0" \ + "bootmenu_4=reboot=reset\0" \ + "bootmenu_5=power off=poweroff\0" \ + "bootmenu_delay=-1\0" + +#define BOARD_EXTRA_ENV_SETTINGS \ + "boot_block_size_r=0x200000\0" \ + "boot_block_size=0x1000\0" \ + "bootloader_file=u-boot-dtb-tegra.bin\0" \ + "check_button=gpio input 179; test $? -eq 0\0" \ + "partitions=name=emmc,start=0,size=-,uuid=${uuid_gpt_rootfs}\0" \ + ENDEAVORU_BOOTMENU + +/* Board-specific serial config */ +#define CFG_SYS_NS16550_COM1 NV_PA_APB_UARTA_BASE + +#include "tegra-common-post.h" + +#endif /* __CONFIG_H */
Thierry, Endeavoru device tree is not included into Makefile. Will you include it or should I send v8? It feels like these patches are hanging in here for ethernity.
23 червня 2023 р. 08:56:00 GMT+03:00, Svyatoslav Ryhel clamor95@gmail.com написав(-ла):
- model = "HTC One X";
- compatible = "htc,endeavoru", "nvidia,tegra30";
- chosen {
- aliases {
i2c0 = &pwr_i2c;
rtc0 = &pmic;
usb0 = µ_usb;
- memory {
- host1x@50000000 {
dc@54200000 {
rgb {
status = "okay";
status = "okay";
panel = <&panel>;
- uarta: serial@70006000 {
status = "okay";
- pwr_i2c: i2c@7000d000 {
status = "okay";
pmic: tps80032@48 {
reg = <0x48>;
regulators {
/* DSI VDD */
- sdmmc4: sdhci@78000600 {
status = "okay";
bus-width = <8>;
non-removable;
- micro_usb: usb@7d000000 {
status = "okay";
dr_mode = "otg";
- backlight: backlight {
- /* PMIC has a built-in 32KHz oscillator which is used by PMC */
- clk32k_in: clock-32k {
#clock-cells = <0>;
- gpio-keys {
key-power {
label = "Power";
key-volume-up {
key-volume-down {
- panel: panel {
- vcore_emmc: regulator-emmc {
enable-active-high;
- vdd_3v3_panel: regulator-lcm {
enable-active-high;
- vdd_1v8_panel: regulator-lcmio {
enable-active-high;
- bool "HTC Endeavoru T30 board"
- select BOARD_LATE_INIT
+config SYS_BOARD
- default "endeavoru"
+config SYS_VENDOR
- default "htc"
- T30 HTC Endeavoru SPL stage configuration
- (C) Copyright 2010-2013
- NVIDIA Corporation <www.nvidia.com>
- (C) Copyright 2022
- Svyatoslav Ryhel clamor95@gmail.com
- Endeavoru uses TPS80032 PMIC with SMPS1 and SMPS2 in strandard
- mode with zero offset.
- /* Set VDD_CORE to 1.200V. */
- tegra_i2c_ll_write(TPS80032_DVS_I2C_ADDR, TPS80032_SMPS2_CFG_VOLTAGE_DATA);
- udelay(1000);
- tegra_i2c_ll_write(TPS80032_CTL1_I2C_ADDR, TPS80032_SMPS2_CFG_STATE_DATA);
- udelay(1000);
- /* Bring up VDD_CPU to 1.0125V. */
- tegra_i2c_ll_write(TPS80032_DVS_I2C_ADDR, TPS80032_SMPS1_CFG_VOLTAGE_DATA);
- udelay(1000);
- tegra_i2c_ll_write(TPS80032_CTL1_I2C_ADDR, TPS80032_SMPS1_CFG_STATE_DATA);
- udelay(10 * 1000);
- (C) Copyright 2021
- struct udevice *dev;
- int ret;
- ret = i2c_get_chip_for_busnum(0, TPS80032_CTL1_I2C_ADDR, 1, &dev);
- if (ret) {
- ret = dm_i2c_reg_write(dev, TPS80032_PHOENIX_DEV_ON, DEVOFF);
- if (ret)
return ret;
- // wait some time and then print error
- mdelay(5000);
- printf("Failed to power off!!!\n");
- return 1;
+} +#endif
- Routine: pinmux_init
- Description: Do individual peripheral pinmux configs
- pinmux_config_pingrp_table(endeavoru_pinmux_common,
- int ret;
- if (ret)
- /* TPS80032: LDO1_REG = 1.2v to DSI */
- ret = dm_i2c_reg_write(dev, TPS80032_LDO1_CFG_VOLTAGE, 0x03);
- if (ret)
- /* TPS80032: LDO1_REG enable */
- ret = dm_i2c_reg_write(dev, TPS80032_LDO1_CFG_STATE, 0x01);
- if (ret)
- Routine: pin_mux_mmc
- Description: setup the MMC muxes, power rails, etc.
- /* Bring up DSI power */
- tps80032_voltage_init();
- /* Remove TrustZone nodes */
- fdt_del_node_and_alias(blob, "/firmware");
- fdt_del_node_and_alias(blob, "/reserved-memory/trustzone@bfe00000");
+} +#endif
- char serialno_str[17];
- /* Set chip id as serialno */
- sprintf(serialno_str, "%016llx", tegra_chip_uid());
- env_set("serial#", serialno_str);
- env_set("platform", "Tegra 3 T30");
- Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved.
- Copyright (c) 2022, Svyatoslav Ryhel.
.slwf = _slwf, \
.slwr = _slwr, \
.drvup = _drvup, \
.drvdn = _drvdn, \
- /* SDMMC1 pinmux */
- DEFAULT_PINMUX(SDMMC1_CLK_PZ0, SDMMC1, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(SDMMC1_CMD_PZ1, SDMMC1, UP, NORMAL, INPUT),
- DEFAULT_PINMUX(SDMMC1_DAT3_PY4, UARTE, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(SDMMC1_DAT2_PY5, UARTE, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(SDMMC1_DAT1_PY6, RSVD2, NORMAL, TRISTATE, INPUT),
- DEFAULT_PINMUX(SDMMC1_DAT0_PY7, SDMMC1, UP, NORMAL, INPUT),
- /* SDMMC3 pinmux */
- DEFAULT_PINMUX(SDMMC3_CLK_PA6, SDMMC3, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(SDMMC3_CMD_PA7, SDMMC3, UP, NORMAL, INPUT),
- DEFAULT_PINMUX(SDMMC3_DAT0_PB7, SDMMC3, UP, NORMAL, INPUT),
- DEFAULT_PINMUX(SDMMC3_DAT1_PB6, SDMMC3, UP, NORMAL, INPUT),
- DEFAULT_PINMUX(SDMMC3_DAT2_PB5, SDMMC3, UP, NORMAL, INPUT),
- DEFAULT_PINMUX(SDMMC3_DAT3_PB4, SDMMC3, UP, NORMAL, INPUT),
- DEFAULT_PINMUX(SDMMC3_DAT4_PD1, SDMMC3, UP, NORMAL, INPUT),
- DEFAULT_PINMUX(SDMMC3_DAT5_PD0, SDMMC3, UP, NORMAL, INPUT),
- DEFAULT_PINMUX(SDMMC3_DAT6_PD3, INVALID, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(SDMMC3_DAT7_PD4, INVALID, NORMAL, NORMAL, INPUT),
- /* SDMMC4 pinmux */
- LV_PINMUX(SDMMC4_CLK_PCC4, SDMMC4, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- LV_PINMUX(SDMMC4_CMD_PT7, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE),
- LV_PINMUX(SDMMC4_DAT0_PAA0, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE),
- LV_PINMUX(SDMMC4_DAT1_PAA1, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE),
- LV_PINMUX(SDMMC4_DAT2_PAA2, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE),
- LV_PINMUX(SDMMC4_DAT3_PAA3, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE),
- LV_PINMUX(SDMMC4_DAT4_PAA4, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE),
- LV_PINMUX(SDMMC4_DAT5_PAA5, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE),
- LV_PINMUX(SDMMC4_DAT6_PAA6, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE),
- LV_PINMUX(SDMMC4_DAT7_PAA7, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE),
- LV_PINMUX(SDMMC4_RST_N_PCC3, RSVD2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- /* I2C pinmux */
- I2C_PINMUX(GEN1_I2C_SCL_PC4, I2C1, NORMAL, NORMAL, INPUT, DISABLE, ENABLE),
- I2C_PINMUX(GEN1_I2C_SDA_PC5, I2C1, NORMAL, NORMAL, INPUT, DISABLE, ENABLE),
- I2C_PINMUX(GEN2_I2C_SCL_PT5, I2C2, NORMAL, NORMAL, INPUT, DISABLE, ENABLE),
- I2C_PINMUX(GEN2_I2C_SDA_PT6, I2C2, NORMAL, NORMAL, INPUT, DISABLE, ENABLE),
- I2C_PINMUX(CAM_I2C_SCL_PBB1, I2C3, NORMAL, NORMAL, INPUT, DISABLE, ENABLE),
- I2C_PINMUX(CAM_I2C_SDA_PBB2, I2C3, NORMAL, NORMAL, INPUT, DISABLE, ENABLE),
- I2C_PINMUX(DDC_SCL_PV4, I2C4, NORMAL, NORMAL, INPUT, DISABLE, ENABLE),
- I2C_PINMUX(DDC_SDA_PV5, I2C4, NORMAL, NORMAL, INPUT, DISABLE, ENABLE),
- I2C_PINMUX(PWR_I2C_SCL_PZ6, I2CPWR, NORMAL, NORMAL, INPUT, DISABLE, ENABLE),
- I2C_PINMUX(PWR_I2C_SDA_PZ7, I2CPWR, NORMAL, NORMAL, INPUT, DISABLE, ENABLE),
- /* HDMI pinmux */
- DEFAULT_PINMUX(HDMI_CEC_PEE3, CEC, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(HDMI_INT_PN7, RSVD1, NORMAL, TRISTATE, INPUT),
- /* ULPI pinmux */
- DEFAULT_PINMUX(ULPI_DATA0_PO1, UARTA, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(ULPI_DATA1_PO2, UARTA, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(ULPI_DATA2_PO3, SPI3, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(ULPI_DATA3_PO4, HSI, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(ULPI_DATA4_PO5, SPI2, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(ULPI_DATA5_PO6, ULPI, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(ULPI_DATA6_PO7, ULPI, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(ULPI_DATA7_PO0, SPI2, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(ULPI_CLK_PY0, RSVD2, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(ULPI_DIR_PY1, RSVD2, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(ULPI_NXT_PY2, ULPI, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(ULPI_STP_PY3, ULPI, NORMAL, NORMAL, INPUT),
- /* DAP3 pinmux */
- DEFAULT_PINMUX(DAP3_FS_PP0, I2S2, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(DAP3_DIN_PP1, I2S2, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(DAP3_DOUT_PP2, I2S2, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(DAP3_SCLK_PP3, I2S2, NORMAL, NORMAL, INPUT),
- /* PV-gpio group pinmux */
- DEFAULT_PINMUX(PV0, RSVD1, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(PV1, RSVD1, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(PV2, RSVD2, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(PV3, RSVD2, NORMAL, NORMAL, OUTPUT),
- /* CLK2 pinmux */
- DEFAULT_PINMUX(CLK2_OUT_PW5, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(CLK2_REQ_PCC5, RSVD4, NORMAL, NORMAL, OUTPUT),
- /* LCD pinmux */
- DEFAULT_PINMUX(LCD_PWR1_PC1, RSVD4, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(LCD_PWR2_PC6, DISPLAYA, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(LCD_SDIN_PZ2, DISPLAYA, UP, NORMAL, OUTPUT),
- DEFAULT_PINMUX(LCD_SDOUT_PN5, DISPLAYA, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_WR_N_PZ3, DISPLAYA, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_CS0_N_PN4, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_DC0_PN6, DISPLAYA, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_SCK_PZ4, DISPLAYA, UP, TRISTATE, OUTPUT),
- DEFAULT_PINMUX(LCD_PWR0_PB2, DISPLAYA, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_PCLK_PB3, DISPLAYA, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_DE_PJ1, DISPLAYA, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_HSYNC_PJ3, DISPLAYA, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_VSYNC_PJ4, DISPLAYA, DOWN, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_D0_PE0, DISPLAYA, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(LCD_D1_PE1, DISPLAYA, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_D2_PE2, RSVD3, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(LCD_D3_PE3, DISPLAYA, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_D4_PE4, DISPLAYA, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_D5_PE5, DISPLAYA, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_D6_PE6, RSVD3, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_D7_PE7, DISPLAYA, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_D8_PF0, RSVD4, DOWN, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_D9_PF1, DISPLAYA, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_D10_PF2, DISPLAYA, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_D11_PF3, DISPLAYA, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_D12_PF4, DISPLAYA, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_D13_PF5, DISPLAYA, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_D14_PF6, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_D15_PF7, RSVD4, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(LCD_D16_PM0, DISPLAYA, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_D17_PM1, DISPLAYA, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_D18_PM2, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_D19_PM3, RSVD4, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(LCD_D20_PM4, DISPLAYA, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_D21_PM5, RSVD4, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(LCD_D22_PM6, RSVD4, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(LCD_D23_PM7, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_CS1_N_PW0, RSVD4, UP, NORMAL, INPUT),
- DEFAULT_PINMUX(LCD_M1_PW1, DISPLAYA, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(LCD_DC1_PD2, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(CRT_HSYNC_PV6, CRT, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(CRT_VSYNC_PV7, RSVD4, NORMAL, NORMAL, OUTPUT),
- /* VI-group pinmux */
- LV_PINMUX(VI_D0_PT4, INVALID, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- LV_PINMUX(VI_D1_PD5, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- LV_PINMUX(VI_D2_PL0, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- LV_PINMUX(VI_D3_PL1, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- LV_PINMUX(VI_D4_PL2, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- LV_PINMUX(VI_D5_PL3, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- LV_PINMUX(VI_D6_PL4, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- LV_PINMUX(VI_D7_PL5, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- LV_PINMUX(VI_D8_PL6, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- LV_PINMUX(VI_D9_PL7, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- LV_PINMUX(VI_D10_PT2, INVALID, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- LV_PINMUX(VI_D11_PT3, INVALID, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- LV_PINMUX(VI_PCLK_PT0, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- LV_PINMUX(VI_MCLK_PT1, INVALID, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- LV_PINMUX(VI_VSYNC_PD6, INVALID, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- LV_PINMUX(VI_HSYNC_PD7, INVALID, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- /* UART-2 pinmux */
- DEFAULT_PINMUX(UART2_RXD_PC3, SPI4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(UART2_TXD_PC2, SPI4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(UART2_RTS_N_PJ6, SPI4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(UART2_CTS_N_PJ5, SPI4, NORMAL, NORMAL, INPUT),
- /* UART-3 pinmux */
- DEFAULT_PINMUX(UART3_TXD_PW6, UARTC, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(UART3_RXD_PW7, UARTC, UP, NORMAL, INPUT),
- DEFAULT_PINMUX(UART3_CTS_N_PA1, UARTC, UP, NORMAL, INPUT),
- DEFAULT_PINMUX(UART3_RTS_N_PC0, UARTC, NORMAL, NORMAL, OUTPUT),
- /* PU-gpio group pinmux */
- DEFAULT_PINMUX(PU0, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(PU1, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(PU2, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(PU3, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(PU4, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(PU5, RSVD4, UP, NORMAL, INPUT),
- DEFAULT_PINMUX(PU6, PWM3, UP, TRISTATE, INPUT),
- /* DAP4 pinmux */
- DEFAULT_PINMUX(DAP4_FS_PP4, I2S3, DOWN, NORMAL, INPUT),
- DEFAULT_PINMUX(DAP4_DIN_PP5, I2S3, DOWN, NORMAL, INPUT),
- DEFAULT_PINMUX(DAP4_DOUT_PP6, RSVD4, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(DAP4_SCLK_PP7, RSVD4, NORMAL, NORMAL, OUTPUT),
- /* CLK3 pinmux */
- DEFAULT_PINMUX(CLK3_OUT_PEE0, EXTPERIPH3, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(CLK3_REQ_PEE1, RSVD4, NORMAL, TRISTATE, INPUT),
- /* GMI pinmux */
- DEFAULT_PINMUX(GMI_WP_N_PC7, RSVD1, UP, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_IORDY_PI5, RSVD1, NORMAL, TRISTATE, INPUT),
- DEFAULT_PINMUX(GMI_WAIT_PI7, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_ADV_N_PK0, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_CLK_PK1, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_CS0_N_PJ0, GMI, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_CS1_N_PJ2, RSVD1, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_CS2_N_PK3, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_CS3_N_PK4, RSVD1, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_CS4_N_PK2, RSVD4, UP, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_CS6_N_PI3, NAND, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_CS7_N_PI6, NAND, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_AD0_PG0, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_AD1_PG1, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_AD2_PG2, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_AD3_PG3, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_AD4_PG4, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_AD5_PG5, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_AD6_PG6, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_AD7_PG7, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_AD8_PH0, PWM0, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(GMI_AD9_PH1, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_AD10_PH2, NAND, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(GMI_AD11_PH3, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_AD12_PH4, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_AD13_PH5, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_AD14_PH6, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_AD15_PH7, NAND, UP, TRISTATE, INPUT),
- DEFAULT_PINMUX(GMI_A16_PJ7, UARTD, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(GMI_A17_PB0, UARTD, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_A18_PB1, UARTD, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_A19_PK7, UARTD, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(GMI_WR_N_PI0, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_OE_N_PI1, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_DQS_PI2, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(GMI_RST_N_PI4, RSVD4, UP, TRISTATE, INPUT),
- DEFAULT_PINMUX(CAM_MCLK_PCC0, VI_ALT3, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(PCC1, RSVD3, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(PBB0, RSVD3, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(PBB3, VGP3, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(PBB4, VGP4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(PBB5, VGP5, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(PBB6, VGP6, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(PBB7, RSVD3, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(PCC2, RSVD3, UP, NORMAL, INPUT),
- DEFAULT_PINMUX(JTAG_RTCK_PU7, RTCK, UP, NORMAL, INPUT),
- /* KBC keys */
- DEFAULT_PINMUX(KB_ROW0_PR0, RSVD4, NORMAL, TRISTATE, INPUT),
- DEFAULT_PINMUX(KB_ROW1_PR1, KBC, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(KB_ROW2_PR2, RSVD4, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(KB_ROW3_PR3, RSVD3, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(KB_ROW4_PR4, RSVD4, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(KB_ROW5_PR5, KBC, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(KB_ROW6_PR6, KBC, NORMAL, TRISTATE, INPUT),
- DEFAULT_PINMUX(KB_ROW7_PR7, KBC, UP, TRISTATE, INPUT),
- DEFAULT_PINMUX(KB_ROW8_PS0, KBC, UP, NORMAL, INPUT),
- DEFAULT_PINMUX(KB_ROW9_PS1, KBC, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(KB_ROW10_PS2, KBC, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(KB_ROW11_PS3, KBC, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(KB_ROW12_PS4, KBC, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(KB_ROW13_PS5, KBC, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(KB_ROW14_PS6, KBC, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(KB_ROW15_PS7, KBC, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(KB_COL0_PQ0, KBC, UP, NORMAL, INPUT),
- DEFAULT_PINMUX(KB_COL1_PQ1, KBC, UP, NORMAL, INPUT),
- DEFAULT_PINMUX(KB_COL2_PQ2, KBC, UP, NORMAL, INPUT),
- DEFAULT_PINMUX(KB_COL3_PQ3, KBC, UP, NORMAL, INPUT),
- DEFAULT_PINMUX(KB_COL4_PQ4, KBC, UP, NORMAL, INPUT),
- DEFAULT_PINMUX(KB_COL5_PQ5, KBC, UP, NORMAL, INPUT),
- DEFAULT_PINMUX(KB_COL6_PQ6, KBC, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(KB_COL7_PQ7, KBC, NORMAL, NORMAL, INPUT),
- /* CLK */
- DEFAULT_PINMUX(CLK_32K_OUT_PA0, BLINK, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(SYS_CLK_REQ_PZ5, SYSCLK, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(OWR, OWR, UP, NORMAL, INPUT),
- /* DAP1 pinmux */
- DEFAULT_PINMUX(DAP1_FS_PN0, I2S0, NORMAL, TRISTATE, OUTPUT),
- DEFAULT_PINMUX(DAP1_DIN_PN1, I2S0, NORMAL, TRISTATE, OUTPUT),
- DEFAULT_PINMUX(DAP1_DOUT_PN2, I2S0, NORMAL, TRISTATE, INPUT),
- DEFAULT_PINMUX(DAP1_SCLK_PN3, I2S0, NORMAL, TRISTATE, OUTPUT),
- /* CLK1 pinmux */
- DEFAULT_PINMUX(CLK1_REQ_PEE2, DAP, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(CLK1_OUT_PW4, RSVD4, NORMAL, NORMAL, INPUT),
- /* SPDIF pinmux */
- DEFAULT_PINMUX(SPDIF_IN_PK6, SPDIF, NORMAL, TRISTATE, INPUT),
- DEFAULT_PINMUX(SPDIF_OUT_PK5, SPDIF, NORMAL, TRISTATE, OUTPUT),
- /* DAP2 pinmux */
- DEFAULT_PINMUX(DAP2_FS_PA2, I2S1, DOWN, NORMAL, INPUT),
- DEFAULT_PINMUX(DAP2_DIN_PA4, I2S1, DOWN, NORMAL, INPUT),
- DEFAULT_PINMUX(DAP2_DOUT_PA5, I2S1, DOWN, NORMAL, INPUT),
- DEFAULT_PINMUX(DAP2_SCLK_PA3, I2S1, DOWN, NORMAL, INPUT),
- /* SPI pinmux */
- DEFAULT_PINMUX(SPI2_MOSI_PX0, SPI2, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(SPI2_MISO_PX1, SPI2, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(SPI2_CS0_N_PX3, SPI2, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(SPI2_SCK_PX2, SPI2, NORMAL, NORMAL, OUTPUT),
- DEFAULT_PINMUX(SPI2_CS1_N_PW2, SPI2, UP, NORMAL, INPUT),
- DEFAULT_PINMUX(SPI2_CS2_N_PW3, SPI2, UP, TRISTATE, INPUT),
- DEFAULT_PINMUX(SPI1_MOSI_PX4, SPI1, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(SPI1_SCK_PX5, SPI2, UP, NORMAL, INPUT),
- DEFAULT_PINMUX(SPI1_CS0_N_PX6, SPI1, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(SPI1_MISO_PX7, RSVD4, NORMAL, NORMAL, OUTPUT),
- /* PEX pinmux */
- DEFAULT_PINMUX(PEX_L0_PRSNT_N_PDD0, PCIE, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(PEX_L0_RST_N_PDD1, PCIE, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(PEX_L0_CLKREQ_N_PDD2, PCIE, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(PEX_WAKE_N_PDD3, PCIE, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(PEX_L1_PRSNT_N_PDD4, PCIE, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(PEX_L1_RST_N_PDD5, PCIE, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(PEX_L1_CLKREQ_N_PDD6, PCIE, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(PEX_L2_PRSNT_N_PDD7, PCIE, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(PEX_L2_RST_N_PCC6, PCIE, NORMAL, NORMAL, INPUT),
- DEFAULT_PINMUX(PEX_L2_CLKREQ_N_PCC7, PCIE, NORMAL, NORMAL, INPUT),
Svyatoslav Ryhel
Thierry Reding
