[PATCH] sunxi: call fdt_fixup_ethernet again to set macaddr for more aliases
Sometimes some ethernet aliases do not exist in U-Boot DT but they exist in the DT used to boot the system (for example, modified via DT overlays). In this situation setup_environment is called again in ft_board_setup() to generate macaddr environment variable for them. However now the call to fdt_fixup_ethernet() is moved before the call of ft_board_setup().
Call fdt_fixup_ethernet() again to add MAC addresses for the extra ethernet aliases.
Signed-off-by: Icenowy Zheng icenowy@aosc.io [updated commit message] Signed-off-by: Jernej Skrabec jernej.skrabec@gmail.com ---
Hi all,
this is effectively resend of: https://patchwork.ozlabs.org/project/uboot/patch/20171027093439.12414-1-icen...
On at least one board, namely BananaPi M2 Zero, adding ethernet connector is pretty popular after market modification. Since this is not something that is already present on the board, ethernet node will never be part of upstream DT. Thus, the only sensible solution is to use DT overlay, which adds node to DT (maintaining patches is tedious). However, when overlays are used, U-Boot misses injecting MAC address, as described in commit message.
Please reconsider this patch for inclusion in upstream.
Best regards, Jernej
board/sunxi/board.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 1a46100e408d..97554d4642ed 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -997,10 +997,12 @@ int ft_board_setup(void *blob, struct bd_info *bd) int __maybe_unused r;
/* - * Call setup_environment again in case the boot fdt has - * ethernet aliases the u-boot copy does not have. + * Call setup_environment and fdt_fixup_ethernet again + * in case the boot fdt has ethernet aliases the u-boot + * copy does not have. */ setup_environment(blob); + fdt_fixup_ethernet(blob);
bluetooth_dt_fixup(blob);
On Sat, Sep 11, 2021 at 11:09 PM Jernej Skrabec jernej.skrabec@gmail.com wrote:
Hi all,
Reviewed-by: Jagan Teki jagan@amarulasolutions.com
On Sat, 11 Sep 2021 19:39:16 +0200 Jernej Skrabec jernej.skrabec@gmail.com wrote:
Hi all,
Applied to sunxi/master.
Thanks, Andre
Andre Przywara
Jagan Teki
Jernej Skrabec
