[PATCH] api: Rework menu, and make it depend on CC_IS_GCC
We can only use the old U-Boot API for standalone applications when building U-Boot with GCC as it relies upon the "gd is a register" trick that only GCC supports. Further, rework the rest of the options so that they are in the API menu and only visible if API support is enabled.
Reported-by: Heinrich Schuchardt xypron.glpk@gmx.de Signed-off-by: Tom Rini trini@konsulko.com --- api/Kconfig | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/api/Kconfig b/api/Kconfig index 6072288f9bc2..b5a7399d7f3c 100644 --- a/api/Kconfig +++ b/api/Kconfig @@ -1,13 +1,14 @@ -menu "API" - config API bool "Enable U-Boot API" + depends on CC_IS_GCC help This option enables the U-Boot API. See api/README for more information.
+menu "API" + depends on API + config SYS_MMC_MAX_DEVICE int "Maximum number of MMC devices exposed via the API" - depends on API default 1
config EXAMPLES
Reported-by: Heinrich Schuchardt xypron.glpk@gmx.de Signed-off-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org
