[U-Boot] [PATCH] powerpc/85xx: Move INIT_RAM_ADDR physical address to 36-bit space
If 36-bit physical address is used, move the INIT_RAM_ADDR to higher address. This frees the low 4GB address space for better use.
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/cpu/mpc85xx/start.S | 7 +++++++ 1 files changed, 7 insertions(+), 0 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/start.S b/arch/powerpc/cpu/mpc85xx/start.S index b3cb56a..aaf7838 100644 --- a/arch/powerpc/cpu/mpc85xx/start.S +++ b/arch/powerpc/cpu/mpc85xx/start.S @@ -330,8 +330,15 @@ _start_e500: lis r8,FSL_BOOKE_MAS2(CONFIG_SYS_INIT_RAM_ADDR, 0)@h ori r8,r8,FSL_BOOKE_MAS2(CONFIG_SYS_INIT_RAM_ADDR, 0)@l
+#if defined(CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW) && defined(CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH) + lis r9,FSL_BOOKE_MAS3(CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW, 0, (MAS3_SX|MAS3_SW|MAS3_SR))@h + ori r9,r9,FSL_BOOKE_MAS3(CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW, 0, (MAS3_SX|MAS3_SW|MAS3_SR))@l + li r10,CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH + mtspr MAS7,r10 +#else lis r9,FSL_BOOKE_MAS3(CONFIG_SYS_INIT_RAM_ADDR, 0, (MAS3_SX|MAS3_SW|MAS3_SR))@h ori r9,r9,FSL_BOOKE_MAS3(CONFIG_SYS_INIT_RAM_ADDR, 0, (MAS3_SX|MAS3_SW|MAS3_SR))@l +#endif
mtspr MAS0,r6 mtspr MAS1,r7
If 36-bit is enabled, move INIT_RAM_ADDR physical address higher to free lowest 4GB address space.
Signed-off-by: York Sun yorksun@freescale.com --- board/freescale/p2020ds/tlb.c | 8 ++++---- include/configs/P2020DS.h | 11 +++++++++++ 2 files changed, 15 insertions(+), 4 deletions(-)
diff --git a/board/freescale/p2020ds/tlb.c b/board/freescale/p2020ds/tlb.c index 36ad086..824b3b2 100644 --- a/board/freescale/p2020ds/tlb.c +++ b/board/freescale/p2020ds/tlb.c @@ -28,19 +28,19 @@
struct fsl_e_tlb_entry tlb_table[] = { /* TLB 0 - for temp stack in cache */ - SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR, CONFIG_SYS_INIT_RAM_ADDR, + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR, CONFIG_SYS_INIT_RAM_ADDR_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, 0, 0, 0, BOOKE_PAGESZ_4K, 0), SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, - CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + CONFIG_SYS_INIT_RAM_ADDR_PHYS + 4 * 1024, MAS3_SX|MAS3_SW|MAS3_SR, 0, 0, 0, BOOKE_PAGESZ_4K, 0), SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, - CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + CONFIG_SYS_INIT_RAM_ADDR_PHYS + 8 * 1024, MAS3_SX|MAS3_SW|MAS3_SR, 0, 0, 0, BOOKE_PAGESZ_4K, 0), SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, - CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + CONFIG_SYS_INIT_RAM_ADDR_PHYS + 12 * 1024, MAS3_SX|MAS3_SW|MAS3_SR, 0, 0, 0, BOOKE_PAGESZ_4K, 0),
diff --git a/include/configs/P2020DS.h b/include/configs/P2020DS.h index bf2acbf..e70c673 100644 --- a/include/configs/P2020DS.h +++ b/include/configs/P2020DS.h @@ -249,6 +249,17 @@
#define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xffd00000 /* Initial L1 address */ +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH 0xf +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW CONFIG_SYS_INIT_RAM_ADDR +/* The assembler doesn't like typecast */ +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS \ + (CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH * 0x100000000ull + CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW) +#else +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS CONFIG_SYS_INIT_RAM_ADDR /* Initial L1 address */ +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH 0 +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW CONFIG_SYS_INIT_RAM_ADDR_PHYS +#endif #define CONFIG_SYS_INIT_RAM_END 0x00004000 /* End of used area in RAM */
#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */
applied w/fix to 80 column issues in P2020DS.h
- k
applied but fixed 80 column formatting.
- k
Kumar Gala
