[U-Boot] [PATCH 0/4] ARM: uniphier updates for v2016.09-rc1
I want this series merged during this merge window.
Masahiro Yamada (4): ARM: uniphier: clear notification flag before L2 operation ARM: uniphier: rename outer-cache register macros ARM: uniphier: introduce flags to uniphier_board_data structure ARM: uniphier: add PH1-LD21 board data
arch/arm/mach-uniphier/arm32/Makefile | 2 +- arch/arm/mach-uniphier/arm32/cache-uniphier.c | 163 ++++++++++++++++++++++ arch/arm/mach-uniphier/arm32/cache_uniphier.c | 156 --------------------- arch/arm/mach-uniphier/arm32/late_lowlevel_init.S | 4 +- arch/arm/mach-uniphier/arm32/lowlevel_init.S | 14 +- arch/arm/mach-uniphier/arm32/ssc-regs.h | 100 ++++++------- arch/arm/mach-uniphier/boards.c | 21 ++- arch/arm/mach-uniphier/dram/umc-ld4.c | 2 +- arch/arm/mach-uniphier/dram/umc-pro4.c | 2 +- arch/arm/mach-uniphier/dram/umc-sld8.c | 2 +- arch/arm/mach-uniphier/init.h | 5 +- 11 files changed, 250 insertions(+), 221 deletions(-) create mode 100644 arch/arm/mach-uniphier/arm32/cache-uniphier.c delete mode 100644 arch/arm/mach-uniphier/arm32/cache_uniphier.c
Clear the flag immediately before cache operation to not depend on the previous state.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/mach-uniphier/arm32/cache_uniphier.c | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-uniphier/arm32/cache_uniphier.c b/arch/arm/mach-uniphier/arm32/cache_uniphier.c index 4398114..3d984a7 100644 --- a/arch/arm/mach-uniphier/arm32/cache_uniphier.c +++ b/arch/arm/mach-uniphier/arm32/cache_uniphier.c @@ -19,6 +19,9 @@ static void uniphier_cache_sync(void)
static void uniphier_cache_maint_all(u32 operation) { + /* clear the complete notification flag */ + writel(SSCOLPQS_EF, SSCOLPQS); + /* try until the command is successfully set */ do { writel(SSCOQM_S_ALL | SSCOQM_CE | operation, SSCOQM); @@ -28,9 +31,6 @@ static void uniphier_cache_maint_all(u32 operation) while (readl(SSCOLPQS) != SSCOLPQS_EF) ;
- /* clear the complete notification flag */ - writel(SSCOLPQS_EF, SSCOLPQS); - uniphier_cache_sync(); }
@@ -46,6 +46,9 @@ void v7_outer_cache_inval_all(void)
static void __uniphier_cache_maint_range(u32 start, u32 size, u32 operation) { + /* clear the complete notification flag */ + writel(SSCOLPQS_EF, SSCOLPQS); + /* try until the command is successfully set */ do { writel(SSCOQM_S_ADDRESS | SSCOQM_CE | operation, SSCOQM); @@ -57,9 +60,6 @@ static void __uniphier_cache_maint_range(u32 start, u32 size, u32 operation) /* wait until the operation is completed */ while (readl(SSCOLPQS) != SSCOLPQS_EF) ; - - /* clear the complete notification flag */ - writel(SSCOLPQS_EF, SSCOLPQS); }
static void uniphier_cache_maint_range(u32 start, u32 end, u32 operation)
Sync register macros with Linux code. This will be helpful to develop the counterpart of Linux.
arch/arm/mach-uniphier/arm32/Makefile | 2 +- arch/arm/mach-uniphier/arm32/cache-uniphier.c | 163 ++++++++++++++++++++++ arch/arm/mach-uniphier/arm32/cache_uniphier.c | 156 --------------------- arch/arm/mach-uniphier/arm32/late_lowlevel_init.S | 4 +- arch/arm/mach-uniphier/arm32/lowlevel_init.S | 14 +- arch/arm/mach-uniphier/arm32/ssc-regs.h | 100 ++++++------- 6 files changed, 224 insertions(+), 215 deletions(-) create mode 100644 arch/arm/mach-uniphier/arm32/cache-uniphier.c delete mode 100644 arch/arm/mach-uniphier/arm32/cache_uniphier.c
diff --git a/arch/arm/mach-uniphier/arm32/Makefile b/arch/arm/mach-uniphier/arm32/Makefile index 376c06b..5074ebd 100644 --- a/arch/arm/mach-uniphier/arm32/Makefile +++ b/arch/arm/mach-uniphier/arm32/Makefile @@ -7,7 +7,7 @@ obj-y += lowlevel_init.o obj-$(CONFIG_DEBUG_LL) += debug_ll.o else obj-y += late_lowlevel_init.o -obj-y += cache_uniphier.o +obj-y += cache-uniphier.o endif
obj-y += timer.o diff --git a/arch/arm/mach-uniphier/arm32/cache-uniphier.c b/arch/arm/mach-uniphier/arm32/cache-uniphier.c new file mode 100644 index 0000000..a58f008 --- /dev/null +++ b/arch/arm/mach-uniphier/arm32/cache-uniphier.c @@ -0,0 +1,163 @@ +/* + * Copyright (C) 2012-2015 Masahiro Yamada yamada.masahiro@socionext.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <linux/io.h> +#include <asm/armv7.h> + +#include "ssc-regs.h" + +#ifdef CONFIG_UNIPHIER_L2CACHE_ON +static void uniphier_cache_sync(void) +{ + /* drain internal buffers */ + writel(UNIPHIER_SSCOPE_CM_SYNC, UNIPHIER_SSCOPE); + /* need a read back to confirm */ + readl(UNIPHIER_SSCOPE); +} + +static void uniphier_cache_maint_all(u32 operation) +{ + /* clear the complete notification flag */ + writel(UNIPHIER_SSCOLPQS_EF, UNIPHIER_SSCOLPQS); + + /* try until the command is successfully set */ + do { + writel(UNIPHIER_SSCOQM_S_ALL | UNIPHIER_SSCOQM_CE | operation, + UNIPHIER_SSCOQM); + } while (readl(UNIPHIER_SSCOPPQSEF) & + (UNIPHIER_SSCOPPQSEF_FE | UNIPHIER_SSCOPPQSEF_OE)); + + /* wait until the operation is completed */ + while (readl(UNIPHIER_SSCOLPQS) != UNIPHIER_SSCOLPQS_EF) + ; + + uniphier_cache_sync(); +} + +void v7_outer_cache_flush_all(void) +{ + uniphier_cache_maint_all(UNIPHIER_SSCOQM_CM_FLUSH); +} + +void v7_outer_cache_inval_all(void) +{ + uniphier_cache_maint_all(UNIPHIER_SSCOQM_CM_INV); +} + +static void __uniphier_cache_maint_range(u32 start, u32 size, u32 operation) +{ + /* clear the complete notification flag */ + writel(UNIPHIER_SSCOLPQS_EF, UNIPHIER_SSCOLPQS); + + /* try until the command is successfully set */ + do { + writel(UNIPHIER_SSCOQM_S_RANGE | UNIPHIER_SSCOQM_CE | operation, + UNIPHIER_SSCOQM); + writel(start, UNIPHIER_SSCOQAD); + writel(size, UNIPHIER_SSCOQSZ); + + } while (readl(UNIPHIER_SSCOPPQSEF) & + (UNIPHIER_SSCOPPQSEF_FE | UNIPHIER_SSCOPPQSEF_OE)); + + /* wait until the operation is completed */ + while (readl(UNIPHIER_SSCOLPQS) != UNIPHIER_SSCOLPQS_EF) + ; +} + +static void uniphier_cache_maint_range(u32 start, u32 end, u32 operation) +{ + u32 size; + + /* + * If start address is not aligned to cache-line, + * do cache operation for the first cache-line + */ + start = start & ~(UNIPHIER_SSC_LINE_SIZE - 1); + + size = end - start; + + if (unlikely(size >= (u32)(-UNIPHIER_SSC_LINE_SIZE))) { + /* this means cache operation for all range */ + uniphier_cache_maint_all(operation); + return; + } + + /* + * If end address is not aligned to cache-line, + * do cache operation for the last cache-line + */ + size = ALIGN(size, UNIPHIER_SSC_LINE_SIZE); + + while (size) { + u32 chunk_size = size > UNIPHIER_SSC_RANGE_OP_MAX_SIZE ? + UNIPHIER_SSC_RANGE_OP_MAX_SIZE : size; + __uniphier_cache_maint_range(start, chunk_size, operation); + + start += chunk_size; + size -= chunk_size; + } + + uniphier_cache_sync(); +} + +void v7_outer_cache_flush_range(u32 start, u32 end) +{ + uniphier_cache_maint_range(start, end, UNIPHIER_SSCOQM_CM_FLUSH); +} + +void v7_outer_cache_inval_range(u32 start, u32 end) +{ + if (start & (UNIPHIER_SSC_LINE_SIZE - 1)) { + start &= ~(UNIPHIER_SSC_LINE_SIZE - 1); + __uniphier_cache_maint_range(start, UNIPHIER_SSC_LINE_SIZE, + UNIPHIER_SSCOQM_CM_FLUSH); + start += UNIPHIER_SSC_LINE_SIZE; + } + + if (start >= end) { + uniphier_cache_sync(); + return; + } + + if (end & (UNIPHIER_SSC_LINE_SIZE - 1)) { + end &= ~(UNIPHIER_SSC_LINE_SIZE - 1); + __uniphier_cache_maint_range(end, UNIPHIER_SSC_LINE_SIZE, + UNIPHIER_SSCOQM_CM_FLUSH); + } + + if (start >= end) { + uniphier_cache_sync(); + return; + } + + uniphier_cache_maint_range(start, end, UNIPHIER_SSCOQM_CM_INV); +} + +void v7_outer_cache_enable(void) +{ + u32 tmp; + + writel(U32_MAX, UNIPHIER_SSCLPDAWCR); /* activate all ways */ + tmp = readl(UNIPHIER_SSCC); + tmp |= UNIPHIER_SSCC_ON; + writel(tmp, UNIPHIER_SSCC); +} +#endif + +void v7_outer_cache_disable(void) +{ + u32 tmp; + + tmp = readl(UNIPHIER_SSCC); + tmp &= ~UNIPHIER_SSCC_ON; + writel(tmp, UNIPHIER_SSCC); +} + +void enable_caches(void) +{ + dcache_enable(); +} diff --git a/arch/arm/mach-uniphier/arm32/cache_uniphier.c b/arch/arm/mach-uniphier/arm32/cache_uniphier.c deleted file mode 100644 index 3d984a7..0000000 --- a/arch/arm/mach-uniphier/arm32/cache_uniphier.c +++ /dev/null @@ -1,156 +0,0 @@ -/* - * Copyright (C) 2012-2015 Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <linux/io.h> -#include <asm/armv7.h> - -#include "ssc-regs.h" - -#ifdef CONFIG_UNIPHIER_L2CACHE_ON -static void uniphier_cache_sync(void) -{ - writel(SSCOPE_CM_SYNC, SSCOPE); /* drain internal buffers */ - readl(SSCOPE); /* need a read back to confirm */ -} - -static void uniphier_cache_maint_all(u32 operation) -{ - /* clear the complete notification flag */ - writel(SSCOLPQS_EF, SSCOLPQS); - - /* try until the command is successfully set */ - do { - writel(SSCOQM_S_ALL | SSCOQM_CE | operation, SSCOQM); - } while (readl(SSCOPPQSEF) & (SSCOPPQSEF_FE | SSCOPPQSEF_OE)); - - /* wait until the operation is completed */ - while (readl(SSCOLPQS) != SSCOLPQS_EF) - ; - - uniphier_cache_sync(); -} - -void v7_outer_cache_flush_all(void) -{ - uniphier_cache_maint_all(SSCOQM_CM_WB_INV); -} - -void v7_outer_cache_inval_all(void) -{ - uniphier_cache_maint_all(SSCOQM_CM_INV); -} - -static void __uniphier_cache_maint_range(u32 start, u32 size, u32 operation) -{ - /* clear the complete notification flag */ - writel(SSCOLPQS_EF, SSCOLPQS); - - /* try until the command is successfully set */ - do { - writel(SSCOQM_S_ADDRESS | SSCOQM_CE | operation, SSCOQM); - writel(start, SSCOQAD); - writel(size, SSCOQSZ); - - } while (readl(SSCOPPQSEF) & (SSCOPPQSEF_FE | SSCOPPQSEF_OE)); - - /* wait until the operation is completed */ - while (readl(SSCOLPQS) != SSCOLPQS_EF) - ; -} - -static void uniphier_cache_maint_range(u32 start, u32 end, u32 operation) -{ - u32 size; - - /* - * If start address is not aligned to cache-line, - * do cache operation for the first cache-line - */ - start = start & ~(SSC_LINE_SIZE - 1); - - size = end - start; - - if (unlikely(size >= (u32)(-SSC_LINE_SIZE))) { - /* this means cache operation for all range */ - uniphier_cache_maint_all(operation); - return; - } - - /* - * If end address is not aligned to cache-line, - * do cache operation for the last cache-line - */ - size = ALIGN(size, SSC_LINE_SIZE); - - while (size) { - u32 chunk_size = size > SSC_RANGE_OP_MAX_SIZE ? - SSC_RANGE_OP_MAX_SIZE : size; - __uniphier_cache_maint_range(start, chunk_size, operation); - - start += chunk_size; - size -= chunk_size; - } - - uniphier_cache_sync(); -} - -void v7_outer_cache_flush_range(u32 start, u32 end) -{ - uniphier_cache_maint_range(start, end, SSCOQM_CM_WB_INV); -} - -void v7_outer_cache_inval_range(u32 start, u32 end) -{ - if (start & (SSC_LINE_SIZE - 1)) { - start &= ~(SSC_LINE_SIZE - 1); - __uniphier_cache_maint_range(start, SSC_LINE_SIZE, - SSCOQM_CM_WB_INV); - start += SSC_LINE_SIZE; - } - - if (start >= end) { - uniphier_cache_sync(); - return; - } - - if (end & (SSC_LINE_SIZE - 1)) { - end &= ~(SSC_LINE_SIZE - 1); - __uniphier_cache_maint_range(end, SSC_LINE_SIZE, - SSCOQM_CM_WB_INV); - } - - if (start >= end) { - uniphier_cache_sync(); - return; - } - - uniphier_cache_maint_range(start, end, SSCOQM_CM_INV); -} - -void v7_outer_cache_enable(void) -{ - u32 tmp; - - writel(U32_MAX, SSCLPDAWCR); /* activate all ways */ - tmp = readl(SSCC); - tmp |= SSCC_ON; - writel(tmp, SSCC); -} -#endif - -void v7_outer_cache_disable(void) -{ - u32 tmp; - tmp = readl(SSCC); - tmp &= ~SSCC_ON; - writel(tmp, SSCC); -} - -void enable_caches(void) -{ - dcache_enable(); -} diff --git a/arch/arm/mach-uniphier/arm32/late_lowlevel_init.S b/arch/arm/mach-uniphier/arm32/late_lowlevel_init.S index cce91df..001d732 100644 --- a/arch/arm/mach-uniphier/arm32/late_lowlevel_init.S +++ b/arch/arm/mach-uniphier/arm32/late_lowlevel_init.S @@ -10,9 +10,9 @@ #include "ssc-regs.h"
ENTRY(lowlevel_init) - ldr r1, = SSCC + ldr r1, = UNIPHIER_SSCC ldr r0, [r1] - bic r0, r0, #SSCC_ON @ L2 disable + bic r0, r0, #UNIPHIER_SSCC_ON @ L2 disable str r0, [r1] mov pc, lr ENDPROC(lowlevel_init) diff --git a/arch/arm/mach-uniphier/arm32/lowlevel_init.S b/arch/arm/mach-uniphier/arm32/lowlevel_init.S index cc34116..1b7e2d7 100644 --- a/arch/arm/mach-uniphier/arm32/lowlevel_init.S +++ b/arch/arm/mach-uniphier/arm32/lowlevel_init.S @@ -94,26 +94,26 @@ ENTRY(setup_init_ram) */ 0: /* - * set SSCOQM, SSCOQAD, SSCOQSZ, SSCOQWN in this order + * set UNIPHIER_SSCOQM, UNIPHIER_SSCOQAD, UNIPHIER_SSCOQSZ, UNIPHIER_SSCOQWN in this order */ ldr r0, = 0x00408006 @ touch to zero with address range - ldr r1, = SSCOQM + ldr r1, = UNIPHIER_SSCOQM str r0, [r1] ldr r0, = BOOT_RAM_BASE - ldr r1, = SSCOQAD + ldr r1, = UNIPHIER_SSCOQAD str r0, [r1] ldr r0, = BOOT_RAM_SIZE - ldr r1, = SSCOQSZ + ldr r1, = UNIPHIER_SSCOQSZ str r0, [r1] ldr r0, = BOOT_WAY_BITS - ldr r1, = SSCOQWN + ldr r1, = UNIPHIER_SSCOQWN str r0, [r1] - ldr r1, = SSCOPPQSEF + ldr r1, = UNIPHIER_SSCOPPQSEF ldr r0, [r1] cmp r0, #0 @ check if the command is successfully set bne 0b @ try again if an error occurs
- ldr r1, = SSCOLPQS + ldr r1, = UNIPHIER_SSCOLPQS 1: ldr r0, [r1] cmp r0, #0x4 diff --git a/arch/arm/mach-uniphier/arm32/ssc-regs.h b/arch/arm/mach-uniphier/arm32/ssc-regs.h index 02fca3b..e698f1e 100644 --- a/arch/arm/mach-uniphier/arm32/ssc-regs.h +++ b/arch/arm/mach-uniphier/arm32/ssc-regs.h @@ -9,57 +9,59 @@ #ifndef ARCH_SSC_REGS_H #define ARCH_SSC_REGS_H
-#define SSCC 0x500c0000 -#define SSCC_BST (0x1 << 20) -#define SSCC_ACT (0x1 << 19) -#define SSCC_WTG (0x1 << 18) -#define SSCC_PRD (0x1 << 17) -#define SSCC_WBWA (0x1 << 16) -#define SSCC_EX (0x1 << 13) -#define SSCC_ON (0x1 << 0) +/* control registers */ +#define UNIPHIER_SSCC 0x500c0000 /* Control Register */ +#define UNIPHIER_SSCC_BST (0x1 << 20) /* UCWG burst read */ +#define UNIPHIER_SSCC_ACT (0x1 << 19) /* Inst-Data separate */ +#define UNIPHIER_SSCC_WTG (0x1 << 18) /* WT gathering on */ +#define UNIPHIER_SSCC_PRD (0x1 << 17) /* enable pre-fetch */ +#define UNIPHIER_SSCC_ON (0x1 << 0) /* enable cache */ +#define UNIPHIER_SSCLPDAWCR 0x500c0030 /* Unified/Data Active Way Control */ +#define UNIPHIER_SSCLPIAWCR 0x500c0034 /* Instruction Active Way Control */
-#define SSCLPDAWCR 0x500c0030 +/* revision registers */ +#define UNIPHIER_SSCID 0x503c0100 /* ID Register */
-#define SSCOPE 0x506c0244 -#define SSCOPE_CM_SYNC 0x00000008 +/* operation registers */ +#define UNIPHIER_SSCOPE 0x506c0244 /* Cache Operation Primitive Entry */ +#define UNIPHIER_SSCOPE_CM_INV 0x0 /* invalidate */ +#define UNIPHIER_SSCOPE_CM_CLEAN 0x1 /* clean */ +#define UNIPHIER_SSCOPE_CM_FLUSH 0x2 /* flush */ +#define UNIPHIER_SSCOPE_CM_SYNC 0x8 /* sync (drain bufs) */ +#define UNIPHIER_SSCOPE_CM_FLUSH_PREFETCH 0x9 /* flush p-fetch buf */ +#define UNIPHIER_SSCOQM 0x506c0248 +#define UNIPHIER_SSCOQM_TID_MASK (0x3 << 21) +#define UNIPHIER_SSCOQM_TID_LRU_DATA (0x0 << 21) +#define UNIPHIER_SSCOQM_TID_LRU_INST (0x1 << 21) +#define UNIPHIER_SSCOQM_TID_WAY (0x2 << 21) +#define UNIPHIER_SSCOQM_S_MASK (0x3 << 17) +#define UNIPHIER_SSCOQM_S_RANGE (0x0 << 17) +#define UNIPHIER_SSCOQM_S_ALL (0x1 << 17) +#define UNIPHIER_SSCOQM_S_WAY (0x2 << 17) +#define UNIPHIER_SSCOQM_CE (0x1 << 15) /* notify completion */ +#define UNIPHIER_SSCOQM_CW (0x1 << 14) +#define UNIPHIER_SSCOQM_CM_MASK (0x7) +#define UNIPHIER_SSCOQM_CM_INV 0x0 /* invalidate */ +#define UNIPHIER_SSCOQM_CM_CLEAN 0x1 /* clean */ +#define UNIPHIER_SSCOQM_CM_FLUSH 0x2 /* flush */ +#define UNIPHIER_SSCOQM_CM_PREFETCH 0x3 /* prefetch to cache */ +#define UNIPHIER_SSCOQM_CM_PREFETCH_BUF 0x4 /* prefetch to pf-buf */ +#define UNIPHIER_SSCOQM_CM_TOUCH 0x5 /* touch */ +#define UNIPHIER_SSCOQM_CM_TOUCH_ZERO 0x6 /* touch to zero */ +#define UNIPHIER_SSCOQM_CM_TOUCH_DIRTY 0x7 /* touch with dirty */ +#define UNIPHIER_SSCOQAD 0x506c024c /* Cache Operation Queue Address */ +#define UNIPHIER_SSCOQSZ 0x506c0250 /* Cache Operation Queue Size */ +#define UNIPHIER_SSCOQMASK 0x506c0254 /* Cache Operation Queue Address Mask */ +#define UNIPHIER_SSCOQWN 0x506c0258 /* Cache Operation Queue Way Number */ +#define UNIPHIER_SSCOPPQSEF 0x506c025c /* Cache Operation Queue Set Complete */ +#define UNIPHIER_SSCOPPQSEF_FE (0x1 << 1) +#define UNIPHIER_SSCOPPQSEF_OE (0x1 << 0) +#define UNIPHIER_SSCOLPQS 0x506c0260 /* Cache Operation Queue Status */ +#define UNIPHIER_SSCOLPQS_EF (0x1 << 2) +#define UNIPHIER_SSCOLPQS_EST (0x1 << 1) +#define UNIPHIER_SSCOLPQS_QST (0x1 << 0)
-#define SSCOQM 0x506c0248 -#define SSCOQM_TID_MASK (0x3 << 21) -#define SSCOQM_TID_BY_WAY (0x2 << 21) -#define SSCOQM_TID_BY_INST_WAY (0x1 << 21) -#define SSCOQM_TID_BY_DATA_WAY (0x0 << 21) -#define SSCOQM_S_MASK (0x3 << 17) -#define SSCOQM_S_WAY (0x2 << 17) -#define SSCOQM_S_ALL (0x1 << 17) -#define SSCOQM_S_ADDRESS (0x0 << 17) -#define SSCOQM_CE (0x1 << 15) -#define SSCOQM_CW (0x1 << 14) -#define SSCOQM_CM_MASK (0x7) -#define SSCOQM_CM_DIRT_TOUCH (0x7) -#define SSCOQM_CM_ZERO_TOUCH (0x6) -#define SSCOQM_CM_NORM_TOUCH (0x5) -#define SSCOQM_CM_PREF_FETCH (0x4) -#define SSCOQM_CM_SSC_FETCH (0x3) -#define SSCOQM_CM_WB_INV (0x2) -#define SSCOQM_CM_WB (0x1) -#define SSCOQM_CM_INV (0x0) - -#define SSCOQAD 0x506c024c -#define SSCOQSZ 0x506c0250 -#define SSCOQWN 0x506c0258 - -#define SSCOPPQSEF 0x506c025c -#define SSCOPPQSEF_FE (0x1 << 1) -#define SSCOPPQSEF_OE (0x1 << 0) - -#define SSCOLPQS 0x506c0260 -#define SSCOLPQS_EF (0x1 << 2) -#define SSCOLPQS_EST (0x1 << 1) -#define SSCOLPQS_QST (0x1 << 0) - -#define SSCOQCE0 0x506c0270 - -#define SSC_LINE_SIZE 128 -#define SSC_RANGE_OP_MAX_SIZE (0x00400000 - (SSC_LINE_SIZE)) +#define UNIPHIER_SSC_LINE_SIZE 128 +#define UNIPHIER_SSC_RANGE_OP_MAX_SIZE (0x00400000 - (UNIPHIER_SSC_LINE_SIZE))
#endif /* ARCH_SSC_REGS_H */
I need to add more board attributes, so the "flags" member will be handier than separate boolean ones.
arch/arm/mach-uniphier/boards.c | 4 ++-- arch/arm/mach-uniphier/dram/umc-ld4.c | 2 +- arch/arm/mach-uniphier/dram/umc-pro4.c | 2 +- arch/arm/mach-uniphier/dram/umc-sld8.c | 2 +- arch/arm/mach-uniphier/init.h | 3 ++- 5 files changed, 7 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-uniphier/boards.c b/arch/arm/mach-uniphier/boards.c index ed308f3..f8db1ee 100644 --- a/arch/arm/mach-uniphier/boards.c +++ b/arch/arm/mach-uniphier/boards.c @@ -38,7 +38,6 @@ static const struct uniphier_board_data uniphier_sld3_data = { static const struct uniphier_board_data uniphier_ld4_data = { .dram_freq = 1600, .dram_nr_ch = 2, - .dram_ddr3plus = true, .dram_ch[0] = { .base = 0x80000000, .size = 0x10000000, @@ -49,6 +48,7 @@ static const struct uniphier_board_data uniphier_ld4_data = { .size = 0x10000000, .width = 16, }, + .flags = UNIPHIER_BD_DDR3PLUS, }; #endif
@@ -90,7 +90,6 @@ static const struct uniphier_board_data uniphier_pro4_2g_data = { static const struct uniphier_board_data uniphier_sld8_data = { .dram_freq = 1333, .dram_nr_ch = 2, - .dram_ddr3plus = true, .dram_ch[0] = { .base = 0x80000000, .size = 0x10000000, @@ -101,6 +100,7 @@ static const struct uniphier_board_data uniphier_sld8_data = { .size = 0x10000000, .width = 16, }, + .flags = UNIPHIER_BD_DDR3PLUS, }; #endif
diff --git a/arch/arm/mach-uniphier/dram/umc-ld4.c b/arch/arm/mach-uniphier/dram/umc-ld4.c index fc75864..7641a9f 100644 --- a/arch/arm/mach-uniphier/dram/umc-ld4.c +++ b/arch/arm/mach-uniphier/dram/umc-ld4.c @@ -175,7 +175,7 @@ int uniphier_ld4_umc_init(const struct uniphier_board_data *bd) for (ch = 0; ch < DRAM_CH_NR; ch++) { ret = umc_ch_init(dc_base, ca_base, bd->dram_freq, bd->dram_ch[ch].size, - bd->dram_ddr3plus, ch); + !!(bd->flags & UNIPHIER_BD_DDR3PLUS), ch); if (ret) { pr_err("failed to initialize UMC ch%d\n", ch); return ret; diff --git a/arch/arm/mach-uniphier/dram/umc-pro4.c b/arch/arm/mach-uniphier/dram/umc-pro4.c index 853f561..02ee4b6 100644 --- a/arch/arm/mach-uniphier/dram/umc-pro4.c +++ b/arch/arm/mach-uniphier/dram/umc-pro4.c @@ -170,7 +170,7 @@ int uniphier_pro4_umc_init(const struct uniphier_board_data *bd) ret = umc_ch_init(dc_base, ca_base, bd->dram_freq, bd->dram_ch[ch].size, bd->dram_ch[ch].width, - bd->dram_ddr3plus); + !!(bd->flags & UNIPHIER_BD_DDR3PLUS)); if (ret) { pr_err("failed to initialize UMC ch%d\n", ch); return ret; diff --git a/arch/arm/mach-uniphier/dram/umc-sld8.c b/arch/arm/mach-uniphier/dram/umc-sld8.c index e831766..89a7e8c 100644 --- a/arch/arm/mach-uniphier/dram/umc-sld8.c +++ b/arch/arm/mach-uniphier/dram/umc-sld8.c @@ -178,7 +178,7 @@ int uniphier_sld8_umc_init(const struct uniphier_board_data *bd) for (ch = 0; ch < DRAM_CH_NR; ch++) { ret = umc_ch_init(dc_base, ca_base, bd->dram_freq, bd->dram_ch[ch].size, - bd->dram_ddr3plus, ch); + !!(bd->flags & UNIPHIER_BD_DDR3PLUS), ch); if (ret) { pr_err("failed to initialize UMC ch%d\n", ch); return ret; diff --git a/arch/arm/mach-uniphier/init.h b/arch/arm/mach-uniphier/init.h index cba0bc9..4dbce17 100644 --- a/arch/arm/mach-uniphier/init.h +++ b/arch/arm/mach-uniphier/init.h @@ -20,8 +20,9 @@ struct uniphier_dram_ch { struct uniphier_board_data { unsigned int dram_freq; unsigned int dram_nr_ch; - bool dram_ddr3plus; struct uniphier_dram_ch dram_ch[UNIPHIER_MAX_NR_DRAM_CH]; + unsigned int flags; +#define UNIPHIER_BD_DDR3PLUS BIT(2) };
const struct uniphier_board_data *uniphier_get_board_param(void);
This has the same silicon die as PH1-LD20, but includes DRAM chips in its package.
arch/arm/mach-uniphier/boards.c | 17 +++++++++++++++++ arch/arm/mach-uniphier/init.h | 2 ++ 2 files changed, 19 insertions(+)
diff --git a/arch/arm/mach-uniphier/boards.c b/arch/arm/mach-uniphier/boards.c index f8db1ee..0022777 100644 --- a/arch/arm/mach-uniphier/boards.c +++ b/arch/arm/mach-uniphier/boards.c @@ -202,6 +202,22 @@ static const struct uniphier_board_data uniphier_ld20_data = { .width = 32, }, }; + +static const struct uniphier_board_data uniphier_ld21_data = { + .dram_freq = 1866, + .dram_nr_ch = 2, + .dram_ch[0] = { + .base = 0x80000000, + .size = 0x40000000, + .width = 32, + }, + .dram_ch[1] = { + .base = 0xc0000000, + .size = 0x40000000, + .width = 32, + }, + .flags = UNIPHIER_BD_PACKAGE_LD21, +}; #endif
struct uniphier_board_id { @@ -237,6 +253,7 @@ static const struct uniphier_board_id uniphier_boards[] = { { "socionext,ph1-ld11", &uniphier_ld11_data, }, #endif #if defined(CONFIG_ARCH_UNIPHIER_LD20) + { "socionext,ph1-ld21", &uniphier_ld21_data, }, { "socionext,ph1-ld20", &uniphier_ld20_data, }, #endif }; diff --git a/arch/arm/mach-uniphier/init.h b/arch/arm/mach-uniphier/init.h index 4dbce17..f6c278d 100644 --- a/arch/arm/mach-uniphier/init.h +++ b/arch/arm/mach-uniphier/init.h @@ -23,6 +23,8 @@ struct uniphier_board_data { struct uniphier_dram_ch dram_ch[UNIPHIER_MAX_NR_DRAM_CH]; unsigned int flags; #define UNIPHIER_BD_DDR3PLUS BIT(2) +#define UNIPHIER_BD_PACKAGE_LD21 1 +#define UNIPHIER_BD_PACKAGE_TYPE(f) ((f) & 0x3) };
2016-07-22 13:38 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Applied to u-boot-uniphier/master.
Masahiro Yamada
