[U-Boot] [PATCH] MX5: efikamx: substitutes GPIO_NUMBER with IMX_GPIO_NR
The macro to get the gpio number id was renamed to IMX_GPIO_NR as in kernel. Fix the wrong name in efika.
Signed-off-by: Stefano Babic sbabic@denx.de CC: Matt Sealey matt@genesi-usa.com --- board/genesi/mx51_efikamx/efikamx.c | 48 +++++++++++++++++------------------ 1 file changed, 24 insertions(+), 24 deletions(-)
diff --git a/board/genesi/mx51_efikamx/efikamx.c b/board/genesi/mx51_efikamx/efikamx.c index 18ab8d9..3968040 100644 --- a/board/genesi/mx51_efikamx/efikamx.c +++ b/board/genesi/mx51_efikamx/efikamx.c @@ -81,14 +81,14 @@ static u32 get_mx_rev(void) */
/* set to 1 in order to get correct value on board rev 1.1 */ - gpio_direction_output(GPIO_NUMBER(3, 16), 1); - gpio_direction_input(GPIO_NUMBER(3, 11)); - gpio_direction_input(GPIO_NUMBER(3, 16)); - gpio_direction_input(GPIO_NUMBER(3, 17)); + gpio_direction_output(IMX_GPIO_NR(3, 16), 1); + gpio_direction_input(IMX_GPIO_NR(3, 11)); + gpio_direction_input(IMX_GPIO_NR(3, 16)); + gpio_direction_input(IMX_GPIO_NR(3, 17));
- rev |= (!!gpio_get_value(GPIO_NUMBER(3, 16))) << 0; - rev |= (!!gpio_get_value(GPIO_NUMBER(3, 17))) << 1; - rev |= (!!gpio_get_value(GPIO_NUMBER(3, 11))) << 2; + rev |= (!!gpio_get_value(IMX_GPIO_NR(3, 16))) << 0; + rev |= (!!gpio_get_value(IMX_GPIO_NR(3, 17))) << 1; + rev |= (!!gpio_get_value(IMX_GPIO_NR(3, 11))) << 2;
return (~rev & 0x7) + 1; } @@ -104,11 +104,11 @@ static inline u32 get_sb_rev(void)
imx_iomux_v3_setup_multiple_pads(efikasb_revision_pads, ARRAY_SIZE(efikasb_revision_pads)); - gpio_direction_input(GPIO_NUMBER(2, 28)); - gpio_direction_input(GPIO_NUMBER(2, 29)); + gpio_direction_input(IMX_GPIO_NR(2, 28)); + gpio_direction_input(IMX_GPIO_NR(2, 29));
- rev |= (!!gpio_get_value(GPIO_NUMBER(2, 28))) << 0; - rev |= (!!gpio_get_value(GPIO_NUMBER(2, 29))) << 1; + rev |= (!!gpio_get_value(IMX_GPIO_NR(2, 28))) << 0; + rev |= (!!gpio_get_value(IMX_GPIO_NR(2, 29))) << 1;
return rev; } @@ -159,9 +159,9 @@ static iomux_v3_cfg_t efikamx_spi_pads[] = { MX51_PAD_GPIO1_6__GPIO1_6, };
-#define EFIKAMX_SPI_SS0 GPIO_NUMBER(4, 24) -#define EFIKAMX_SPI_SS1 GPIO_NUMBER(4, 25) -#define EFIKAMX_PMIC_IRQ GPIO_NUMBER(1, 6) +#define EFIKAMX_SPI_SS0 IMX_GPIO_NR(4, 24) +#define EFIKAMX_SPI_SS1 IMX_GPIO_NR(4, 25) +#define EFIKAMX_PMIC_IRQ IMX_GPIO_NR(1, 6)
/* * PMIC configuration @@ -282,15 +282,15 @@ static iomux_v3_cfg_t efikamx_sdhc1_pads[] = { MX51_PAD_GPIO1_1__SD1_WP, };
-#define EFIKAMX_SDHC1_WP GPIO_NUMBER(1, 1) +#define EFIKAMX_SDHC1_WP IMX_GPIO_NR(1, 1)
static iomux_v3_cfg_t efikamx_sdhc1_cd_pads[] = { MX51_PAD_GPIO1_0__SD1_CD, MX51_PAD_EIM_CS2__SD1_CD, };
-#define EFIKAMX_SDHC1_CD GPIO_NUMBER(1, 0) -#define EFIKASB_SDHC1_CD GPIO_NUMBER(2, 27) +#define EFIKAMX_SDHC1_CD IMX_GPIO_NR(1, 0) +#define EFIKASB_SDHC1_CD IMX_GPIO_NR(2, 27)
static iomux_v3_cfg_t efikasb_sdhc2_pads[] = { MX51_PAD_SD2_CMD__SD2_CMD, @@ -303,8 +303,8 @@ static iomux_v3_cfg_t efikasb_sdhc2_pads[] = { MX51_PAD_GPIO1_8__SD2_CD, };
-#define EFIKASB_SDHC2_CD GPIO_NUMBER(1, 8) -#define EFIKASB_SDHC2_WP GPIO_NUMBER(1, 7) +#define EFIKASB_SDHC2_CD IMX_GPIO_NR(1, 8) +#define EFIKASB_SDHC2_WP IMX_GPIO_NR(1, 7)
static inline uint32_t efikamx_mmc_getcd(u32 base) { @@ -415,17 +415,17 @@ static inline void setup_iomux_usb(void) { } * Smarttop LED pad config is done in the DCD * */ -#define EFIKAMX_LED_BLUE GPIO_NUMBER(3, 13) -#define EFIKAMX_LED_GREEN GPIO_NUMBER(3, 14) -#define EFIKAMX_LED_RED GPIO_NUMBER(3, 15) +#define EFIKAMX_LED_BLUE IMX_GPIO_NR(3, 13) +#define EFIKAMX_LED_GREEN IMX_GPIO_NR(3, 14) +#define EFIKAMX_LED_RED IMX_GPIO_NR(3, 15)
static iomux_v3_cfg_t efikasb_led_pads[] = { MX51_PAD_GPIO1_3__GPIO1_3, MX51_PAD_EIM_CS0__GPIO2_25, };
-#define EFIKASB_CAPSLOCK_LED GPIO_NUMBER(2, 25) -#define EFIKASB_MESSAGE_LED GPIO_NUMBER(1, 3) /* Note: active low */ +#define EFIKASB_CAPSLOCK_LED IMX_GPIO_NR(2, 25) +#define EFIKASB_MESSAGE_LED IMX_GPIO_NR(1, 3) /* Note: active low */
/* * Board initialization
That's odd, I thought I fixed that.
+#define EFIKAMX_USB_HUB_RESET IMX_GPIO_NR(1, 5) +#define EFIKAMX_USB_PHY_RESET IMX_GPIO_NR(2, 9)
I copied the above two lines from my patch to the ML.. what happened here? :(
Matt Sealey
Stefano Babic
