[PATCH v4] imx8mp-evk: Add USB0 OTG support
Add USB0 OTG support.
Currently, the USB0 OTG nodes are not enabled in the Linux kernel devicetree.
For this reason, enable the USB0 OTG nodes inside imx8mp-evk-u-boot.dtsi for now.
Also select several useful options such as USB gadget and fastboot.
Tested by running "ums 0 mmc 2".
Signed-off-by: Fabio Estevam festevam@denx.de Reviewed-by: Marek Vasut marex@denx.de --- Changes since v3: - Fixed the alphabetical order once again.
arch/arm/dts/imx8mp-evk-u-boot.dtsi | 13 ++++++++++++ configs/imx8mp_evk_defconfig | 31 +++++++++++++++++++++++++++++ 2 files changed, 44 insertions(+)
diff --git a/arch/arm/dts/imx8mp-evk-u-boot.dtsi b/arch/arm/dts/imx8mp-evk-u-boot.dtsi index 6784ed2e7c92..f4fd2432ca8f 100644 --- a/arch/arm/dts/imx8mp-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-evk-u-boot.dtsi @@ -111,6 +111,19 @@ bootph-pre-ram; };
+&usb_dwc3_0 { + dr_mode = "peripheral"; + status = "okay"; +}; + +&usb3_0 { + status = "okay"; +}; + +&usb3_phy0 { + status = "okay"; +}; + &usdhc1 { bootph-pre-ram; }; diff --git a/configs/imx8mp_evk_defconfig b/configs/imx8mp_evk_defconfig index 14c749f44308..820dc36e9cdd 100644 --- a/configs/imx8mp_evk_defconfig +++ b/configs/imx8mp_evk_defconfig @@ -59,6 +59,9 @@ CONFIG_CMD_FUSE=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_SDP=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_CACHE=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y @@ -74,6 +77,14 @@ CONFIG_ETHPRIME="eth1" CONFIG_SPL_DM=y CONFIG_CLK_COMPOSITE_CCF=y CONFIG_CLK_IMX8MP=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x42800000 +CONFIG_FASTBOOT_BUF_SIZE=0x20000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_UUU_SUPPORT=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=2 +CONFIG_FASTBOOT_MMC_BOOT_SUPPORT=y +CONFIG_FASTBOOT_MMC_USER_SUPPORT=y CONFIG_MXC_GPIO=y CONFIG_DM_PCA953X=y CONFIG_DM_I2C=y @@ -94,10 +105,15 @@ CONFIG_DWC_ETH_QOS=y CONFIG_DWC_ETH_QOS_IMX=y CONFIG_FEC_MXC=y CONFIG_MII=y +CONFIG_PHY=y +CONFIG_PHY_IMX8MQ_USB=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_IMX8M=y CONFIG_SPL_POWER_LEGACY=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX8M_POWER_DOMAIN=y +CONFIG_IMX8MP_HSIOMIX_BLKCTRL=y CONFIG_POWER_PCA9450=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y @@ -109,4 +125,19 @@ CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y CONFIG_SYSRESET_PSCI=y CONFIG_SYSRESET_WATCHDOG=y +CONFIG_USB=y +# CONFIG_SPL_DM_USB is not set +CONFIG_DM_USB_GADGET=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_XHCI_DWC3_OF_SIMPLE=y +CONFIG_USB_EHCI_HCD=y +# CONFIG_USB_EHCI_MX7 is not set +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_SDP_LOADADDR=0x0 CONFIG_IMX_WATCHDOG=y
From: Fabio Estevam festevam@denx.de Add USB0 OTG support. Currently, the USB0 OTG nodes are not enabled in the Linux kernel devicetree. For this reason, enable the USB0 OTG nodes inside imx8mp-evk-u-boot.dtsi for now. Also select several useful options such as USB gadget and fastboot. Tested by running "ums 0 mmc 2". Signed-off-by: Fabio Estevam festevam@denx.de Reviewed-by: Marek Vasut marex@denx.de
Best regards, Stefano Babic
Reviewed-by: Peng Fan peng.fan@nxp.com
Changes since v3:
+&usb_dwc3_0 {
- dr_mode = "peripheral";
- status = "okay";
+&usb3_0 {
- status = "okay";
+&usb3_phy0 {
- status = "okay";
- &usdhc1 { bootph-pre-ram; };
Fabio Estevam
Peng Fan
sbabic@denx.de
