[U-Boot] [PATCH] powerpc/esdhc: Map register for eSDHC host controller 3.0
eSDHC host controller has new register to support SD Spec 3.0. And the according host controller version was Freescale eSDHC Version 3.0. Add some new register and it simple description.
Signed-off-by: Haijun Zhang haijun.zhang@freescale.com --- drivers/mmc/fsl_esdhc.c | 62 +++++++++++++++++++++++++++++-------------------- 1 file changed, 37 insertions(+), 25 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 589288b..f3d4b90 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -40,31 +40,43 @@ DECLARE_GLOBAL_DATA_PTR;
struct fsl_esdhc { - uint dsaddr; - uint blkattr; - uint cmdarg; - uint xfertyp; - uint cmdrsp0; - uint cmdrsp1; - uint cmdrsp2; - uint cmdrsp3; - uint datport; - uint prsstat; - uint proctl; - uint sysctl; - uint irqstat; - uint irqstaten; - uint irqsigen; - uint autoc12err; - uint hostcapblt; - uint wml; - uint mixctrl; - char reserved1[4]; - uint fevt; - char reserved2[168]; - uint hostver; - char reserved3[780]; - uint scr; + uint dsaddr; /* SDMA system address register */ + uint blkattr; /* Block attributes register */ + uint cmdarg; /* Command argument register */ + uint xfertyp; /* Transfer type register */ + uint cmdrsp0; /* Command response 0 register */ + uint cmdrsp1; /* Command response 1 register */ + uint cmdrsp2; /* Command response 2 register */ + uint cmdrsp3; /* Command response 3 register */ + uint datport; /* Buffer data port register */ + uint prsstat; /* Present state register */ + uint proctl; /* Protocol control register */ + uint sysctl; /* System Control Register */ + uint irqstat; /* Interrupt status register */ + uint irqstaten; /* Interrupt status enable register */ + uint irqsigen; /* Interrupt signal enable register */ + uint autoc12err; /* Auto CMD error status register */ + uint hostcapblt; /* Host controller capabilities register */ + uint wml; /* Watermark level register */ + uint mixctrl; /* For USDHC */ + char reserved1[4]; /* reserved */ + uint fevt; /* Force event register */ + uint admaes; /* ADMA error status register */ + uint adsaddr; /* ADMA system address register */ + char reserved2[160]; /* reserved */ + uint hostver; /* Host controller version register */ + char reserved3[4]; /* reserved */ + uint dmaerraddr; /* DMA error address register */ + char reserved4[4]; /* reserved */ + uint dmaerrattr; /* DMA error attribute register */ + char reserved5[4]; /* reserved */ + uint hostcapblt2; /* Host controller capabilities register 2 */ + char reserved6[8]; /* reserved */ + uint tcr; /* Tuning control register */ + char reserved7[28]; /* reserved */ + uint sddirctl; /* SD direction control register */ + char reserved8[712]; /* reserved */ + uint scr; /* eSDHC control register */ };
/* Return the XFERTYP flags for a given command and data packet */
By adding a register in the same patch as you add descriptions, you make it hard to see what register you added.
-Scott
I'll split it to two patches.
Thanks.
δΊ 2013/10/30 1:54, Scott Wood ει:
-Scott
Haijun Zhang
Scott Wood
Zhang Haijun
