[U-Boot] [PATCH v3] ATMEL/PIO: Enable new feature of PIO on Atmel device
Enable new PIO feature supported by Atmel SoC. Using CPU_HAS_PIO3 micro to enable PIO new feature.
Signed-off-by: Bo Shen voice.shen@atmel.com --- Changes since v1: - remove the legacy interface. Changes since v2: - keep the legacy interface, don't touch it.
arch/arm/include/asm/arch-at91/at91_pio.h | 45 ++++++++++- drivers/gpio/at91_gpio.c | 125 ++++++++++++++++++++++++++++- 2 files changed, 167 insertions(+), 3 deletions(-)
diff --git a/arch/arm/include/asm/arch-at91/at91_pio.h b/arch/arm/include/asm/arch-at91/at91_pio.h index 416cabf..0483c98 100644 --- a/arch/arm/include/asm/arch-at91/at91_pio.h +++ b/arch/arm/include/asm/arch-at91/at91_pio.h @@ -66,14 +66,50 @@ typedef struct at91_port { u32 puer; /* 0x64 Pull-up Enable Register */ u32 pusr; /* 0x68 Pad Pull-up Status Register */ u32 reserved4; +#if defined(CPU_HAS_PIO3) + u32 abcdsr1; /* 0x70 Peripheral ABCD Select Register 1 */ + u32 abcdsr2; /* 0x74 Peripheral ABCD Select Register 2 */ + u32 reserved5[2]; + u32 ifscdr; /* 0x80 Input Filter SCLK Disable Register */ + u32 ifscer; /* 0x84 Input Filter SCLK Enable Register */ + u32 ifscsr; /* 0x88 Input Filter SCLK Status Register */ + u32 scdr; /* 0x8C SCLK Divider Debouncing Register */ + u32 ppddr; /* 0x90 Pad Pull-down Disable Register */ + u32 ppder; /* 0x94 Pad Pull-down Enable Register */ + u32 ppdsr; /* 0x98 Pad Pull-down Status Register */ + u32 reserved6; /* */ +#else u32 asr; /* 0x70 Select A Register */ u32 bsr; /* 0x74 Select B Register */ u32 absr; /* 0x78 AB Select Status Register */ u32 reserved5[9]; /* */ +#endif u32 ower; /* 0xA0 Output Write Enable Register */ u32 owdr; /* 0xA4 Output Write Disable Register */ - u32 owsr; /* OxA8 utput Write Status Register */ + u32 owsr; /* OxA8 Output Write Status Register */ +#if defined(CPU_HAS_PIO3) + u32 reserved7; /* */ + u32 aimer; /* 0xB0 Additional INT Modes Enable Register */ + u32 aimdr; /* 0xB4 Additional INT Modes Disable Register */ + u32 aimmr; /* 0xB8 Additional INT Modes Mask Register */ + u32 reserved8; /* */ + u32 esr; /* 0xC0 Edge Select Register */ + u32 lsr; /* 0xC4 Level Select Register */ + u32 elsr; /* 0xC8 Edge/Level Status Register */ + u32 reserved9; /* 0xCC */ + u32 fellsr; /* 0xD0 Falling /Low Level Select Register */ + u32 rehlsr; /* 0xD4 Rising /High Level Select Register */ + u32 frlhsr; /* 0xD8 Fall/Rise - Low/High Status Register */ + u32 reserved10; /* */ + u32 locksr; /* 0xE0 Lock Status */ + u32 wpmr; /* 0xE4 Write Protect Mode Register */ + u32 wpsr; /* 0xE8 Write Protect Status Register */ + u32 reserved11[5]; /* */ + u32 schmitt; /* 0x100 Schmitt Trigger Register */ + u32 reserved12[63]; +#else u32 reserved6[85]; +#endif } at91_port_t;
typedef union at91_pio { @@ -94,6 +130,13 @@ typedef union at91_pio { #ifdef CONFIG_AT91_GPIO int at91_set_a_periph(unsigned port, unsigned pin, int use_pullup); int at91_set_b_periph(unsigned port, unsigned pin, int use_pullup); +#if defined(CPU_HAS_PIO3) +int at91_set_c_periph(unsigned port, unsigned pin, int use_pullup); +int at91_set_d_periph(unsigned port, unsigned pin, int use_pullup); +int at91_set_pio_debounce(unsigned port, unsigned pin, int is_on, int div); +int at91_set_pio_pulldown(unsigned port, unsigned pin, int is_on); +int at91_set_pio_disable_schmitt_trig(unsigned port, unsigned pin); +#endif int at91_set_pio_input(unsigned port, unsigned pin, int use_pullup); int at91_set_pio_multi_drive(unsigned port, unsigned pin, int is_on); int at91_set_pio_output(unsigned port, unsigned pin, int value); diff --git a/drivers/gpio/at91_gpio.c b/drivers/gpio/at91_gpio.c index be2a026..ac3b322 100644 --- a/drivers/gpio/at91_gpio.c +++ b/drivers/gpio/at91_gpio.c @@ -86,7 +86,14 @@ int at91_set_a_periph(unsigned port, unsigned pin, int use_pullup) mask = 1 << pin; writel(mask, &pio->port[port].idr); at91_set_pio_pullup(port, pin, use_pullup); +#if defined(CPU_HAS_PIO3) + writel(readl(&pio->port[port].abcdsr1) & ~mask, + &pio->port[port].abcdsr1); + writel(readl(&pio->port[port].abcdsr2) & ~mask, + &pio->port[port].abcdsr2); +#else writel(mask, &pio->port[port].asr); +#endif writel(mask, &pio->port[port].pdr); } return 0; @@ -104,12 +111,63 @@ int at91_set_b_periph(unsigned port, unsigned pin, int use_pullup) mask = 1 << pin; writel(mask, &pio->port[port].idr); at91_set_pio_pullup(port, pin, use_pullup); +#if defined(CPU_HAS_PIO3) + writel(readl(&pio->port[port].abcdsr1) | mask, + &pio->port[port].abcdsr1); + writel(readl(&pio->port[port].abcdsr2) & ~mask, + &pio->port[port].abcdsr2); +#else writel(mask, &pio->port[port].bsr); +#endif writel(mask, &pio->port[port].pdr); } return 0; }
+#if defined(CPU_HAS_PIO3) +/* + * mux the pin to the "C" internal peripheral role. + */ +int at91_set_c_periph(unsigned port, unsigned pin, int use_pullup) +{ + at91_pio_t *pio = (at91_pio_t *) ATMEL_BASE_PIOA; + u32 mask; + + if ((port < ATMEL_PIO_PORTS) && (pin < 32)) { + mask = 1 << pin; + writel(mask, &pio->port[port].idr); + at91_set_pio_pullup(port, pin, use_pullup); + writel(readl(&pio->port[port].abcdsr1) & ~mask, + &pio->port[port].abcdsr1); + writel(readl(&pio->port[port].abcdsr2) | mask, + &pio->port[port].abcdsr2); + writel(mask, &pio->port[port].pdr); + } + return 0; +} + +/* + * mux the pin to the "D" internal peripheral role. + */ +int at91_set_d_periph(unsigned port, unsigned pin, int use_pullup) +{ + at91_pio_t *pio = (at91_pio_t *) ATMEL_BASE_PIOA; + u32 mask; + + if ((port < ATMEL_PIO_PORTS) && (pin < 32)) { + mask = 1 << pin; + writel(mask, &pio->port[port].idr); + at91_set_pio_pullup(port, pin, use_pullup); + writel(readl(&pio->port[port].abcdsr1) | mask, + &pio->port[port].abcdsr1); + writel(readl(&pio->port[port].abcdsr2) | mask, + &pio->port[port].abcdsr2); + writel(mask, &pio->port[port].pdr); + } + return 0; +} +#endif + /* * mux the pin to the gpio controller (instead of "A" or "B" peripheral), and * configure it for an input. @@ -162,13 +220,76 @@ int at91_set_pio_deglitch(unsigned port, unsigned pin, int is_on)
if ((port < ATMEL_PIO_PORTS) && (pin < 32)) { mask = 1 << pin; - if (is_on) + if (is_on) { +#if defined(CPU_HAS_PIO3) + writel(mask, &pio->port[port].ifscdr); +#endif writel(mask, &pio->port[port].ifer); - else + } else { writel(mask, &pio->port[port].ifdr); + } + } + return 0; +} + +#if defined(CPU_HAS_PIO3) +/* + * enable/disable the debounce filter. + */ +int at91_set_pio_debounce(unsigned port, unsigned pin, int is_on, int div) +{ + at91_pio_t *pio = (at91_pio_t *) ATMEL_BASE_PIOA; + u32 mask; + + if ((port < ATMEL_PIO_PORTS) && (pin < 32)) { + mask = 1 << pin; + if (is_on) { + writel(mask, &pio->port[port].ifscer); + writel(div & PIO_SCDR_DIV, &pio->port[port].scdr); + writel(mask, &pio->port[port].ifer); + } else { + writel(mask, &pio->port[port].ifdr); + } + } + return 0; +} + +/* + * enable/disable the pull-down. + * If pull-up already enabled while calling the function, we disable it. + */ +int at91_set_pio_pulldown(unsigned port, unsigned pin, int is_on) +{ + at91_pio_t *pio = (at91_pio_t *) ATMEL_BASE_PIOA; + u32 mask; + + if ((port < ATMEL_PIO_PORTS) && (pin < 32)) { + mask = 1 << pin; + writel(mask, &pio->port[port].pudr); + if (is_on) + writel(mask, &pio->port[port].ppder); + else + writel(mask, &pio->port[port].ppddr); + } + return 0; +} + +/* + * disable Schmitt trigger + */ +int at91_set_pio_disable_schmitt_trig(unsigned port, unsigned pin) +{ + at91_pio_t *pio = (at91_pio_t *) ATMEL_BASE_PIOA; + u32 mask; + + if ((port < ATMEL_PIO_PORTS) && (pin < 32)) { + mask = 1 << pin; + writel(readl(&pio->port[port].schmitt) | mask, + &pio->port[port].schmitt); } return 0; } +#endif
/* * enable/disable the multi-driver. This is only valid for output and
Hi All,
Signed-off-by: Bo Shenvoice.shen@atmel.com
Changes since v1:
Changes since v2:
Ping
Best Regards Bo Shen
Dear Bo Shen,
On 28.05.2012 09:43, Bo Shen wrote:
Hi All,
Changes since v1:
Changes since v2:
Ping
Acked-by: Andreas Bießmann andreas.devel@googlemail.com
thats all I can do since this is ARM related.
best regards
Andreas Bießmann
Hi All,
On 5/29/2012 16:06, Andreas Bießmann wrote:
Dear Bo Shen,
Hi All,
Changes since v1:
Changes since v2:
Ping
Acked-by: Andreas Bießmannandreas.devel@googlemail.com
Ping
best regards
Andreas Bießmann
On 6/1/2012 17:12, Bo Shen wrote:
Hi All,
Dear Bo Shen,
Hi All,
Changes since v1:
Changes since v2:
Ping
Ping
Ping again.
best regards
Andreas Bießmann
Dear Bo Shen,
Changes since v1:
Changes since v2:
applied to u-boot-atmel/master, thanks!
Best regards
Andreas Bießmann
Andreas Bießmann
Bo Shen
