[PATCH] ARM: dts: at91: sama7g5: fix signal name of pin PB2
The signal name of pin PB2 with function F is FLEXCOM11_IO1 as it is defined in the datasheet.
Fixes: 558378a4cd ("ARM: mach-at91: add support for new SoC sama7g5") Signed-off-by: Mihai Sain mihai.sain@microchip.com --- arch/arm/dts/sama7g5-pinfunc.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/sama7g5-pinfunc.h b/arch/arm/dts/sama7g5-pinfunc.h index 38d6962d00..b77185f8ed 100644 --- a/arch/arm/dts/sama7g5-pinfunc.h +++ b/arch/arm/dts/sama7g5-pinfunc.h @@ -261,7 +261,7 @@ #define PIN_PB2__FLEXCOM6_IO0 PINMUX_PIN(PIN_PB2, 2, 1) #define PIN_PB2__ADTRG PINMUX_PIN(PIN_PB2, 3, 1) #define PIN_PB2__A20 PINMUX_PIN(PIN_PB2, 4, 1) -#define PIN_PB2__FLEXCOM11_IO0 PINMUX_PIN(PIN_PB2, 6, 3) +#define PIN_PB2__FLEXCOM11_IO1 PINMUX_PIN(PIN_PB2, 6, 3) #define PIN_PB3 35 #define PIN_PB3__GPIO PINMUX_PIN(PIN_PB3, 0, 0) #define PIN_PB3__RF1 PINMUX_PIN(PIN_PB3, 1, 1)
Applied to u-boot-at91/master , thanks !
Eugen.Hristev@microchip.com
Mihai Sain
