[U-Boot] [PATCH 2/2] ppc4xx: DDR/ECC: Use correct macros to clear error status
Use the correct macro instead of the hardcoded 0x4c to clear the ECC status in the 440/460 DDR(2) error status register after ECC initialization.
Also the non-440 parts (405EX(r) right now) and the IBM DDR PPC variants (440GX) use a different registers to clear this error status. Use the correct ones.
Signed-off-by: Stefan Roese sr@denx.de --- arch/powerpc/cpu/ppc4xx/ecc.c | 21 ++++++++++++++++++++- arch/powerpc/include/asm/ppc4xx-sdram.h | 2 ++ 2 files changed, 22 insertions(+), 1 deletions(-)
diff --git a/arch/powerpc/cpu/ppc4xx/ecc.c b/arch/powerpc/cpu/ppc4xx/ecc.c index f105605..49f28d9 100644 --- a/arch/powerpc/cpu/ppc4xx/ecc.c +++ b/arch/powerpc/cpu/ppc4xx/ecc.c @@ -130,7 +130,26 @@ static void program_ecc_addr(unsigned long start_address,
/* clear ECC error repoting registers */ mtsdram(SDRAM_ECCES, 0xffffffff); - mtdcr(0x4c, 0xffffffff); +#if defined(CONFIG_SDRAM_PPC4xx_IBM_DDR) + /* + * IBM DDR(1) core (440GX): + * Clear Mx bits in SDRAM0_BESR0/1 + */ + mtsdram(SDRAM0_BESR0, 0xffffffff); + mtsdram(SDRAM0_BESR1, 0xffffffff); +#elif defined(CONFIG_440) + /* + * 440/460 DDR2 core: + * Clear EMID (Error PLB Master ID) in MQ0_ESL + */ + mtdcr(SDRAM_ERRSTATLL, 0xfff00000); +#else + /* + * 405EX(r) DDR2 core: + * Clear M0ID (Error PLB Master ID) in SDRAM_BESR + */ + mtsdram(SDRAM_BESR, 0xf0000000); +#endif
mtsdram(SDRAM_MCOPT1, (mcopt1 & ~SDRAM_MCOPT1_MCHK_MASK) | SDRAM_MCOPT1_MCHK_CHK_REP); diff --git a/arch/powerpc/include/asm/ppc4xx-sdram.h b/arch/powerpc/include/asm/ppc4xx-sdram.h index 42eac45..4ec1ef8 100644 --- a/arch/powerpc/include/asm/ppc4xx-sdram.h +++ b/arch/powerpc/include/asm/ppc4xx-sdram.h @@ -63,6 +63,8 @@ #define SDRAM_CFG0 0x20 /* memory controller options 0 */ #define SDRAM_CFG1 0x21 /* memory controller options 1 */
+#define SDRAM0_BESR0 0x0000 /* bus error status reg 0 */ +#define SDRAM0_BESR1 0x0008 /* bus error status reg 1 */ #define SDRAM0_BEAR 0x0010 /* bus error address reg */ #define SDRAM0_SLIO 0x0018 /* ddr sdram slave interface options */ #define SDRAM0_CFG0 0x0020 /* ddr sdram options 0 */
Applied to u-boot-ppc4xx/master. Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Stefan Roese
