[U-Boot] [PATCH v2 00/42] Kconfig: Convert remaining commands to Kconfig
This series converts the remaining commands (starting from M and ending at Z) to Kconfig. This completes the Kconfig conversion of commands.
Note that for v2 I dropped my CMD_REGINFO patch and picked up one from Christophe Leroy [1] since it was marked as accepted.
[1] http://patchwork.ozlabs.org/patch/787724/
Changes in v2: - Add a note about dropping CMD_UNIVERSE - Add new patch to resync with savedefconfig - Add new patch to sort the device-access commands - Add new patch to sort the memory commands - Drop include/sx151x.h also - Drop mention of this from several other places - Drop patch to convert CONFIG_CMD_MTDPARTS to Kconfig (already done) - Drop unwanted 'CONFIG_CMD_SPL_NAND_OFS=0x0' lines in defconfig - Fix indentation for CMD_PCI - Fix typos in help - Fix up microblaze-generic, gw_ventana, ipam390 - Fixed lots of merge conflicts with my series - Make X86 imply CMD_SF_TEST (except for efi-x86 which fails) - Make this 'default y' and drop defconfig file changes - Move CMD_PORTIO changes in from the CMD_READ patch - Move CMD_PORTIO changes to previous patch - Pull in this patch from http://patchwork.ozlabs.org/patch/787724/ instead - Put Kconfig change in alphabetical order - Remove some now-superfluous /* commands */ comments in header files - Rename the option to include 'zimageboot' - Sort Kconfig options in alphabetical order - Update commit message to explain Makefile change - Update edison also
Christophe Leroy (1): Convert CONFIG_CMD_REGINFO to Kconfig
Simon Glass (41): configs: Resync with savedefconfig Convert CONFIG_CMD_MAX6957 to Kconfig Kconfig: Drop CONFIG_CMD_MEM Kconfig: Sort the device-access commands Convert CONFIG_CMD_MMC_SPI to Kconfig Convert CONFIG_CMD_MTDPARTS_SPREAD to Kconfig Convert CONFIG_CMD_ONENAND to Kconfig Convert CONFIG_CMD_PCA953X to Kconfig Kconfig: Drop CONFIG_CMD_PCA953X_INFO Convert CONFIG_CMD_PCI to Kconfig Kconfig: Drop CONFIG_CMD_PCI_ENUM Kconfig; Drop CONFIG_IDE_TI_CARDBUS and associated driver Convert CONFIG_CMD_PCMCIA to Kconfig Kconfig: Drop CONFIG_CMD_PORTIO and associated command Kconfig: Convert CMD_READ to Kconfig Convert CONFIG_CMD_REISER to Kconfig Kconfig: sandbox: Drop CONFIG_CMD_SANDBOX option Convert CONFIG_CMD_SAVES to Kconfig Convert CONFIG_CMD_SCSI to Kconfig Convert CONFIG_CMD_SDRAM to Kconfig Convert CONFIG_CMD_SF_TEST to Kconfig Convert CONFIG_CMD_SH_ZIMAGEBOOT to Kconfig Convert CONFIG_CMD_SPL to Kconfig Convert CONFIG_CMD_SPL_NAND_OFS to Kconfig Convert CONFIG_CMD_SPL_WRITE_SIZE to Kconfig Kconfig: Sort the memory commands Convert CONFIG_CMD_STRINGS to Kconfig gpio: Drop sx151x driver Convert CONFIG_CMD_TCA642X to Kconfig Convert CONFIG_CMD_TERMINAL to Kconfig Kconfig: Drop CONFIG_CMD_TFTP Convert CONFIG_CMD_THOR_DOWNLOAD to Kconfig Convert CONFIG_CMD_YAFFS2 to Kconfig Convert CONFIG_CMD_TRACE to Kconfig Convert CONFIG_CMD_TSI148 to Kconfig Convert CONFIG_CMD_UNIVERSE to Kconfig Convert CONFIG_CMD_UUID to Kconfig Convert CONFIG_CMD_ZBOOT to Kconfig Convert CONFIG_CMD_ZFS to Kconfig Drop config_cmd_all.h README: Drop information about commands
README | 144 +---- arch/Kconfig | 3 + arch/arm/Kconfig | 10 + arch/arm/cpu/armv7/ls102xa/Kconfig | 1 + arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 1 + arch/arm/mach-imx/mx6/Kconfig | 1 + arch/arm/mach-omap2/am33xx/Kconfig | 1 + arch/powerpc/Kconfig | 3 + arch/powerpc/cpu/mpc83xx/Kconfig | 1 + arch/powerpc/cpu/mpc85xx/Kconfig | 6 + arch/sh/Kconfig | 2 + arch/sh/lib/Kconfig | 6 + board/work-microwave/work_92105/Kconfig | 7 + cmd/Kconfig | 501 ++++++++++++----- cmd/Makefile | 5 +- cmd/fastboot/Kconfig | 2 + cmd/pci.c | 4 +- cmd/portio.c | 145 ----- cmd/read.c | 2 +- configs/A10-OLinuXino-Lime_defconfig | 2 +- configs/A20-OLinuXino-Lime2_defconfig | 2 +- configs/A20-OLinuXino-Lime_defconfig | 2 +- configs/A20-OLinuXino_MICRO_defconfig | 2 +- configs/A20-Olimex-SOM-EVB_defconfig | 2 +- configs/Bananapi_M2_Ultra_defconfig | 2 +- configs/Bananapi_defconfig | 2 +- configs/Bananapro_defconfig | 2 +- configs/Cubieboard2_defconfig | 2 +- configs/Cubieboard_defconfig | 2 +- configs/Cubietruck_defconfig | 2 +- configs/Itead_Ibox_A20_defconfig | 2 +- configs/Lamobo_R1_defconfig | 2 +- configs/Linksprite_pcDuino3_Nano_defconfig | 2 +- configs/Linksprite_pcDuino3_defconfig | 3 - configs/M5235EVB_Flash32_defconfig | 1 + configs/M5235EVB_defconfig | 1 + configs/M5475AFE_defconfig | 1 + configs/M5475BFE_defconfig | 1 + configs/M5475CFE_defconfig | 1 + configs/M5475DFE_defconfig | 1 + configs/M5475EFE_defconfig | 1 + configs/M5475FFE_defconfig | 1 + configs/M5475GFE_defconfig | 1 + configs/M5485AFE_defconfig | 1 + configs/M5485BFE_defconfig | 1 + configs/M5485CFE_defconfig | 1 + configs/M5485DFE_defconfig | 1 + configs/M5485EFE_defconfig | 1 + configs/M5485FFE_defconfig | 1 + configs/M5485GFE_defconfig | 1 + configs/M5485HFE_defconfig | 1 + configs/MPC8308RDB_defconfig | 1 + configs/MPC8313ERDB_33_defconfig | 1 + configs/MPC8313ERDB_66_defconfig | 1 + configs/MPC8313ERDB_NAND_33_defconfig | 1 + configs/MPC8313ERDB_NAND_66_defconfig | 1 + configs/MPC8315ERDB_defconfig | 1 + configs/MPC8323ERDB_defconfig | 1 + configs/MPC832XEMDS_HOST_33_defconfig | 1 + configs/MPC832XEMDS_HOST_66_defconfig | 1 + configs/MPC832XEMDS_SLAVE_defconfig | 1 + configs/MPC8349ITXGP_defconfig | 2 + configs/MPC8349ITX_LOWBOOT_defconfig | 2 + configs/MPC8349ITX_defconfig | 2 + configs/MPC837XEMDS_HOST_defconfig | 1 + configs/MPC837XERDB_defconfig | 1 + configs/MPC8536DS_36BIT_defconfig | 1 + configs/MPC8536DS_SDCARD_defconfig | 1 + configs/MPC8536DS_SPIFLASH_defconfig | 1 + configs/MPC8536DS_defconfig | 1 + configs/MPC8541CDS_defconfig | 1 + configs/MPC8541CDS_legacy_defconfig | 1 + configs/MPC8544DS_defconfig | 3 +- configs/MPC8548CDS_36BIT_defconfig | 1 + configs/MPC8548CDS_defconfig | 1 + configs/MPC8548CDS_legacy_defconfig | 1 + configs/MPC8555CDS_defconfig | 1 + configs/MPC8555CDS_legacy_defconfig | 1 + configs/MPC8568MDS_defconfig | 1 + configs/MPC8569MDS_ATM_defconfig | 1 + configs/MPC8569MDS_defconfig | 1 + configs/MPC8572DS_36BIT_defconfig | 1 + configs/MPC8572DS_defconfig | 1 + configs/MPC8610HPCD_defconfig | 3 +- configs/MPC8641HPCN_36BIT_defconfig | 1 + configs/MPC8641HPCN_defconfig | 1 + configs/Marsboard_A10_defconfig | 2 +- configs/Mele_A1000_defconfig | 2 +- configs/Mele_M5_defconfig | 2 +- configs/MigoR_defconfig | 1 + configs/Orangepi_defconfig | 2 +- configs/Orangepi_mini_defconfig | 2 +- configs/P1021RDB-PC_36BIT_NAND_defconfig | 1 + configs/P1021RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1021RDB-PC_36BIT_defconfig | 1 + configs/P1021RDB-PC_NAND_defconfig | 1 + configs/P1021RDB-PC_SDCARD_defconfig | 1 + configs/P1021RDB-PC_SPIFLASH_defconfig | 1 + configs/P1021RDB-PC_defconfig | 1 + configs/P1022DS_36BIT_NAND_defconfig | 1 + configs/P1022DS_36BIT_SDCARD_defconfig | 1 + configs/P1022DS_36BIT_SPIFLASH_defconfig | 1 + configs/P1022DS_36BIT_defconfig | 1 + configs/P1022DS_NAND_defconfig | 1 + configs/P1022DS_SDCARD_defconfig | 1 + configs/P1022DS_SPIFLASH_defconfig | 1 + configs/P1022DS_defconfig | 1 + configs/P1023RDB_defconfig | 1 + configs/P1025RDB_36BIT_defconfig | 1 + configs/P1025RDB_NAND_defconfig | 1 + configs/P1025RDB_SDCARD_defconfig | 1 + configs/P1025RDB_SPIFLASH_defconfig | 1 + configs/P1025RDB_defconfig | 1 + configs/P2020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_36BIT_defconfig | 1 + configs/P2020RDB-PC_NAND_defconfig | 1 + configs/P2020RDB-PC_SDCARD_defconfig | 1 + configs/P2020RDB-PC_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_defconfig | 1 + configs/TQM834x_defconfig | 1 + configs/TWR-P1025_defconfig | 1 + configs/UCP1020_SPIFLASH_defconfig | 1 + configs/UCP1020_defconfig | 1 + configs/Wits_Pro_A20_DKT_defconfig | 2 +- configs/alt_defconfig | 1 + configs/am335x_boneblack_defconfig | 1 + configs/am335x_boneblack_vboot_defconfig | 1 + configs/am335x_evm_defconfig | 2 + configs/am335x_evm_nor_defconfig | 2 + configs/am335x_evm_usbspl_defconfig | 2 + configs/am335x_igep003x_defconfig | 1 + configs/am335x_sl50_defconfig | 1 + configs/am43xx_evm_defconfig | 3 + configs/am43xx_evm_ethboot_defconfig | 3 + configs/am43xx_evm_usbhost_boot_defconfig | 3 + configs/am57xx_evm_defconfig | 1 + configs/am57xx_evm_nodt_defconfig | 1 + configs/ap325rxa_defconfig | 1 + configs/ap_sh4a_4a_defconfig | 1 + configs/apalis-tk1_defconfig | 1 + configs/apalis_t30_defconfig | 1 + configs/armadillo-800eva_defconfig | 1 + configs/bayleybay_defconfig | 1 + configs/beaver_defconfig | 1 + configs/birdland_bav335a_defconfig | 1 + configs/birdland_bav335b_defconfig | 1 + configs/blanche_defconfig | 1 + configs/boston32r2_defconfig | 1 + configs/boston32r2el_defconfig | 1 + configs/boston64r2_defconfig | 1 + configs/boston64r2el_defconfig | 1 + configs/caddy2_defconfig | 2 + configs/cairo_defconfig | 2 + configs/cardhu_defconfig | 1 + configs/cei-tk1-som_defconfig | 1 + configs/chromebit_mickey_defconfig | 1 + configs/chromebook_jerry_defconfig | 1 + configs/chromebook_link64_defconfig | 1 + configs/chromebook_link_defconfig | 1 + configs/chromebook_minnie_defconfig | 1 + configs/chromebook_samus_defconfig | 1 + configs/chromebox_panther_defconfig | 1 + configs/cl-som-am57x_defconfig | 2 + configs/clearfog_defconfig | 1 + configs/cm_t335_defconfig | 1 + configs/cm_t54_defconfig | 2 +- ...conga-qeval20-qa3-e3845-internal-uart_defconfig | 1 + configs/conga-qeval20-qa3-e3845_defconfig | 1 + .../controlcenterd_36BIT_SDCARD_DEVELOP_defconfig | 1 + configs/controlcenterd_36BIT_SDCARD_defconfig | 1 + configs/controlcenterdc_defconfig | 4 +- configs/coreboot-x86_defconfig | 1 + configs/cougarcanyon2_defconfig | 1 + configs/crownbay_defconfig | 1 + configs/db-88f6820-amc_defconfig | 1 + configs/db-88f6820-gp_defconfig | 3 +- configs/db-mv784mp-gp_defconfig | 1 + configs/devkit8000_defconfig | 3 + configs/dfi-bt700-q7x-151_defconfig | 1 + configs/dra7xx_evm_defconfig | 3 +- configs/dra7xx_hs_evm_defconfig | 2 +- configs/ds414_defconfig | 1 + configs/ecovec_defconfig | 1 + configs/efi-x86_defconfig | 2 + configs/espt_defconfig | 1 + configs/ethernut5_defconfig | 2 + configs/galileo_defconfig | 1 + configs/gose_defconfig | 1 + configs/gwventana_emmc_defconfig | 3 + configs/gwventana_gw5904_defconfig | 3 + configs/gwventana_nand_defconfig | 3 + configs/highbank_defconfig | 2 +- configs/hrcon_defconfig | 1 + configs/hrcon_dh_defconfig | 1 + configs/igep0020_defconfig | 2 + configs/igep0030_defconfig | 2 + configs/igep0032_defconfig | 2 + configs/integratorap_cm720t_defconfig | 1 + configs/integratorap_cm920t_defconfig | 1 + configs/integratorap_cm926ejs_defconfig | 1 + configs/integratorap_cm946es_defconfig | 1 + configs/ipam390_defconfig | 3 + configs/jetson-tk1_defconfig | 1 + configs/koelsch_defconfig | 1 + configs/lager_defconfig | 1 + configs/ls1012aqds_qspi_defconfig | 4 +- configs/ls1012ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1012ardb_qspi_defconfig | 1 + configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 9 +- configs/ls1021atwr_nor_defconfig | 9 +- .../ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 11 +- configs/ls1021atwr_sdcard_ifc_defconfig | 9 +- configs/ls1021atwr_sdcard_qspi_defconfig | 9 +- configs/ls1043ardb_SECURE_BOOT_defconfig | 9 +- configs/ls1043ardb_defconfig | 9 +- configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig | 9 +- configs/ls1043ardb_sdcard_defconfig | 9 +- configs/ls1046aqds_SECURE_BOOT_defconfig | 5 +- configs/ls1046aqds_defconfig | 5 +- configs/ls1046aqds_lpuart_defconfig | 2 +- configs/ls1046aqds_nand_defconfig | 5 +- configs/ls1046aqds_qspi_defconfig | 5 +- configs/ls1046aqds_sdcard_ifc_defconfig | 5 +- configs/ls1046aqds_sdcard_qspi_defconfig | 5 +- configs/ls1046ardb_emmc_defconfig | 5 +- configs/ls1046ardb_qspi_SECURE_BOOT_defconfig | 13 +- configs/ls1046ardb_qspi_defconfig | 13 +- configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig | 13 +- configs/ls1046ardb_sdcard_defconfig | 13 +- configs/ls2080aqds_SECURE_BOOT_defconfig | 1 + configs/ls2080aqds_defconfig | 1 + configs/ls2080aqds_nand_defconfig | 1 + configs/ls2080aqds_qspi_defconfig | 1 + configs/ls2080aqds_sdcard_defconfig | 1 + configs/ls2080ardb_SECURE_BOOT_defconfig | 1 + configs/ls2080ardb_defconfig | 2 +- configs/ls2080ardb_nand_defconfig | 1 + configs/ls2081ardb_defconfig | 3 +- configs/ls2088ardb_qspi_defconfig | 2 +- configs/malta64_defconfig | 1 + configs/malta64el_defconfig | 1 + configs/malta_defconfig | 1 + configs/maltael_defconfig | 1 + configs/microblaze-generic_defconfig | 3 + configs/minnowmax_defconfig | 1 + configs/mpc8308_p1m_defconfig | 1 + configs/ms7720se_defconfig | 4 +- configs/ms7722se_defconfig | 1 + configs/mvebu_db_armada8k_defconfig | 1 + configs/mvebu_mcbin-88f8040_defconfig | 1 + configs/mx6sabresd_defconfig | 3 + configs/mx6sxsabresd_defconfig | 1 + configs/mx6sxsabresd_spl_defconfig | 1 + configs/novena_defconfig | 1 + configs/odroid-xu3_defconfig | 1 + configs/odroid_defconfig | 1 + configs/omap3_beagle_defconfig | 2 + configs/omap3_logic_defconfig | 2 + configs/omap3_overo_defconfig | 2 + configs/omap4_panda_defconfig | 1 + configs/omap5_uevm_defconfig | 4 +- configs/origen_defconfig | 1 + configs/ot1200_defconfig | 1 + configs/ot1200_spl_defconfig | 1 + configs/p2371-2180_defconfig | 1 + configs/p2771-0000-000_defconfig | 1 + configs/p2771-0000-500_defconfig | 1 + configs/pcm051_rev1_defconfig | 1 + configs/pcm051_rev3_defconfig | 1 + configs/pengwyn_defconfig | 2 + configs/porter_defconfig | 1 + configs/qemu-ppce500_defconfig | 1 + configs/qemu-x86_64_defconfig | 1 + configs/qemu-x86_defconfig | 1 + configs/qemu-x86_efi_payload32_defconfig | 1 + configs/qemu-x86_efi_payload64_defconfig | 1 + configs/r0p7734_defconfig | 1 + configs/r2dplus_defconfig | 1 + configs/r7780mp_defconfig | 2 + configs/r8a7795_salvator-x_defconfig | 5 +- configs/r8a7796_salvator-x_defconfig | 5 +- configs/rsk7203_defconfig | 1 + configs/s5p_goni_defconfig | 2 + configs/s5pc210_universal_defconfig | 1 + configs/sandbox_defconfig | 3 + configs/sandbox_flattree_defconfig | 1 + configs/sandbox_noblk_defconfig | 1 + configs/sandbox_spl_defconfig | 1 + configs/sbc8349_PCI_33_defconfig | 1 + configs/sbc8349_PCI_66_defconfig | 1 + configs/sbc8548_PCI_33_PCIE_defconfig | 1 + configs/sbc8548_PCI_33_defconfig | 1 + configs/sbc8548_PCI_66_PCIE_defconfig | 1 + configs/sbc8548_PCI_66_defconfig | 1 + configs/sbc8641d_defconfig | 1 + configs/sh7752evb_defconfig | 1 + configs/sh7753evb_defconfig | 1 + configs/sh7757lcr_defconfig | 1 + configs/sh7763rdp_defconfig | 1 + configs/sh7785lcr_32bit_defconfig | 2 + configs/sh7785lcr_defconfig | 2 + configs/shmin_defconfig | 1 + configs/silk_defconfig | 1 + configs/smdkc100_defconfig | 1 + configs/snapper9260_defconfig | 1 + configs/snapper9g20_defconfig | 1 + configs/socrates_defconfig | 2 + configs/som-db5800-som-6867_defconfig | 1 + configs/stout_defconfig | 1 + configs/strider_con_defconfig | 1 + configs/strider_con_dp_defconfig | 1 + configs/strider_cpu_defconfig | 1 + configs/strider_cpu_dp_defconfig | 1 + configs/tbs2910_defconfig | 1 + configs/theadorable-x86-dfi-bt700_defconfig | 1 + configs/theadorable_debug_defconfig | 1 + configs/topic_miami_defconfig | 1 + configs/topic_miamilite_defconfig | 1 + configs/topic_miamiplus_defconfig | 1 + configs/trats2_defconfig | 1 + configs/trats_defconfig | 1 + configs/trimslice_defconfig | 1 + configs/turris_omnia_defconfig | 1 + configs/twister_defconfig | 3 + configs/vct_platinum_onenand_defconfig | 1 + configs/vct_platinum_onenand_small_defconfig | 1 + configs/vct_platinumavc_onenand_defconfig | 1 + configs/vct_platinumavc_onenand_small_defconfig | 1 + configs/vct_premium_onenand_defconfig | 1 + configs/vct_premium_onenand_small_defconfig | 1 + configs/ve8313_defconfig | 1 + configs/vining_2000_defconfig | 1 + configs/vme8349_defconfig | 2 + configs/work_92105_defconfig | 1 + configs/x600_defconfig | 1 + configs/xilinx_zynqmp_ep_defconfig | 5 +- configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 1 + configs/xilinx_zynqmp_zcu102_revA_defconfig | 6 +- configs/xilinx_zynqmp_zcu102_revB_defconfig | 6 +- configs/xpedite517x_defconfig | 2 + configs/xpedite520x_defconfig | 2 + configs/xpedite537x_defconfig | 2 + configs/xpedite550x_defconfig | 2 + configs/xtfpga_defconfig | 1 + configs/zc5202_defconfig | 1 + configs/zynq_microzed_defconfig | 1 + configs/zynq_picozed_defconfig | 1 + configs/zynq_zc702_defconfig | 1 + configs/zynq_zc706_defconfig | 1 + configs/zynq_zed_defconfig | 1 + configs/zynq_zybo_defconfig | 1 + drivers/gpio/Kconfig | 18 + drivers/gpio/Makefile | 1 - drivers/gpio/pca953x.c | 8 - drivers/gpio/sx151x.c | 242 -------- drivers/pcmcia/Makefile | 1 - drivers/pcmcia/ti_pci1410a.c | 623 --------------------- fs/Kconfig | 2 + fs/yaffs2/Kconfig | 7 + include/command.h | 9 +- include/config_cmd_all.h | 31 - include/config_distro_bootcmd.h | 2 +- include/configs/B4860QDS.h | 9 - include/configs/BSC9131RDB.h | 5 - include/configs/BSC9132QDS.h | 7 - include/configs/C29XPCIE.h | 7 - include/configs/M5235EVB.h | 3 - include/configs/M54455EVB.h | 3 - include/configs/M5475EVB.h | 6 - include/configs/M5485EVB.h | 6 - include/configs/MCR3000.h | 3 - include/configs/MPC8308RDB.h | 1 - include/configs/MPC8313ERDB.h | 1 - include/configs/MPC8315ERDB.h | 1 - include/configs/MPC8323ERDB.h | 4 - include/configs/MPC832XEMDS.h | 4 - include/configs/MPC8349EMDS.h | 4 - include/configs/MPC8349ITX.h | 9 - include/configs/MPC837XEMDS.h | 4 - include/configs/MPC837XERDB.h | 4 - include/configs/MPC8536DS.h | 9 - include/configs/MPC8540ADS.h | 4 - include/configs/MPC8541CDS.h | 9 - include/configs/MPC8544DS.h | 9 - include/configs/MPC8548CDS.h | 9 - include/configs/MPC8555CDS.h | 9 - include/configs/MPC8560ADS.h | 12 - include/configs/MPC8568MDS.h | 9 - include/configs/MPC8569MDS.h | 9 - include/configs/MPC8572DS.h | 9 - include/configs/MPC8610HPCD.h | 6 - include/configs/MPC8641HPCN.h | 9 - include/configs/MigoR.h | 2 - include/configs/P1010RDB.h | 7 - include/configs/P1022DS.h | 9 - include/configs/P1023RDB.h | 9 - include/configs/P2041RDB.h | 4 - include/configs/T102xQDS.h | 9 - include/configs/T102xRDB.h | 9 - include/configs/T1040QDS.h | 9 - include/configs/T104xRDB.h | 9 - include/configs/T208xQDS.h | 9 - include/configs/T208xRDB.h | 9 - include/configs/T4240RDB.h | 6 - include/configs/TQM834x.h | 12 - include/configs/UCP1020.h | 8 - include/configs/advantech_dms-ba16.h | 1 - include/configs/am335x_evm.h | 2 - include/configs/am335x_shc.h | 1 - include/configs/am43xx_evm.h | 2 - include/configs/ap325rxa.h | 2 - include/configs/ap_sh4a_4a.h | 2 - include/configs/apalis-tk1.h | 1 - include/configs/apalis_t30.h | 1 - include/configs/armadillo-800eva.h | 2 - include/configs/baltos.h | 2 - include/configs/bav335x.h | 2 - include/configs/beaver.h | 1 - include/configs/boston.h | 1 - include/configs/brppt1.h | 2 - include/configs/calimain.h | 8 - include/configs/cardhu.h | 1 - include/configs/cei-tk1-som.h | 1 - include/configs/cl-som-am57x.h | 3 - include/configs/clearfog.h | 1 - include/configs/cm_t335.h | 4 - include/configs/controlcenterd.h | 4 - include/configs/controlcenterdc.h | 2 - include/configs/corenet_ds.h | 9 - include/configs/cyrus.h | 9 - include/configs/da850evm.h | 5 - include/configs/db-88f6820-amc.h | 1 - include/configs/db-88f6820-gp.h | 1 - include/configs/db-mv784mp-gp.h | 5 - include/configs/dbau1x00.h | 5 - include/configs/devkit8000.h | 3 - include/configs/dra7xx_evm.h | 2 - include/configs/dragonboard410c.h | 1 - include/configs/ds414.h | 2 - include/configs/ea20.h | 5 - include/configs/ecovec.h | 2 - include/configs/edison.h | 1 - include/configs/efi-x86.h | 2 - include/configs/espt.h | 5 - include/configs/ethernut5.h | 2 - include/configs/exynos4-common.h | 3 - include/configs/exynos5-common.h | 1 - include/configs/ge_bx50v3.h | 1 - include/configs/gw_ventana.h | 4 - include/configs/hrcon.h | 1 - include/configs/integratorap.h | 2 - include/configs/ipam390.h | 8 - include/configs/jetson-tk1.h | 1 - include/configs/km/km83xx-common.h | 4 - include/configs/km/kmp204x-common.h | 1 - include/configs/legoev3.h | 5 - include/configs/ls1012aqds.h | 2 - include/configs/ls1012ardb.h | 2 - include/configs/ls1021aiot.h | 2 - include/configs/ls1021aqds.h | 1 - include/configs/ls1021atwr.h | 1 - include/configs/ls1043a_common.h | 1 - include/configs/ls1043ardb.h | 1 - include/configs/ls1046a_common.h | 1 - include/configs/ls2080aqds.h | 1 - include/configs/ls2080ardb.h | 1 - include/configs/malta.h | 1 - include/configs/microblaze-generic.h | 20 - include/configs/mpc8308_p1m.h | 1 - include/configs/ms7720se.h | 3 - include/configs/ms7722se.h | 2 - include/configs/mvebu_armada-8k.h | 1 - include/configs/mx6sabreauto.h | 2 - include/configs/mx6sabresd.h | 3 - include/configs/mx6sxsabresd.h | 1 - include/configs/nokia_rx51.h | 6 - include/configs/novena.h | 1 - include/configs/odroid_xu3.h | 1 - include/configs/omap3_beagle.h | 2 - include/configs/omap3_cairo.h | 2 - include/configs/omap3_igep00x0.h | 2 - include/configs/omap3_logic.h | 2 - include/configs/omap3_overo.h | 2 - include/configs/omap3_zoom1.h | 2 - include/configs/omap5_uevm.h | 1 - include/configs/omapl138_lcdk.h | 4 - include/configs/ot1200.h | 2 - include/configs/p1_p2_rdb_pc.h | 7 - include/configs/p1_twr.h | 7 - include/configs/p2371-2180.h | 1 - include/configs/p2771-0000.h | 1 - include/configs/pengwyn.h | 2 - include/configs/qemu-ppce500.h | 6 - include/configs/r0p7734.h | 2 - include/configs/r2dplus.h | 6 - include/configs/r7780mp.h | 6 - include/configs/rcar-gen2-common.h | 2 - include/configs/rcar-gen3-common.h | 1 - include/configs/rsk7203.h | 2 - include/configs/s5p_goni.h | 3 - include/configs/sandbox.h | 6 - include/configs/sbc8349.h | 4 - include/configs/sbc8548.h | 9 - include/configs/sbc8641d.h | 6 - include/configs/sh7752evb.h | 2 - include/configs/sh7753evb.h | 2 - include/configs/sh7757lcr.h | 2 - include/configs/sh7763rdp.h | 5 - include/configs/sh7785lcr.h | 4 - include/configs/shmin.h | 2 - include/configs/smdkc100.h | 5 - include/configs/smdkv310.h | 1 - include/configs/snapper9260.h | 4 - include/configs/socrates.h | 10 - include/configs/spear-common.h | 5 - include/configs/stm32f429-discovery.h | 2 - include/configs/strider.h | 3 - include/configs/t4qds.h | 6 - include/configs/tbs2910.h | 1 - include/configs/theadorable.h | 3 - include/configs/ti_armv7_common.h | 4 - include/configs/ti_armv7_keystone2.h | 3 - include/configs/trats.h | 1 - include/configs/trimslice.h | 1 - include/configs/turris_omnia.h | 1 - include/configs/twister.h | 4 - include/configs/vct.h | 7 - include/configs/ve8313.h | 1 - include/configs/veyron.h | 2 - include/configs/vining_2000.h | 1 - include/configs/vme8349.h | 5 - include/configs/work_92105.h | 1 - include/configs/x600.h | 5 - include/configs/x86-common.h | 4 - include/configs/xilinx_zynqmp.h | 1 - include/configs/xilinx_zynqmp_zcu102.h | 2 - include/configs/xpedite517x.h | 9 - include/configs/xpedite520x.h | 9 - include/configs/xpedite537x.h | 9 - include/configs/xpedite550x.h | 9 - include/configs/xtfpga.h | 6 - include/configs/zc5202.h | 1 - include/configs/zynq-common.h | 2 - include/sx151x.h | 17 - scripts/config_whitelist.txt | 38 -- 549 files changed, 881 insertions(+), 2295 deletions(-) create mode 100644 arch/sh/lib/Kconfig delete mode 100644 cmd/portio.c delete mode 100644 drivers/gpio/sx151x.c delete mode 100644 drivers/pcmcia/ti_pci1410a.c create mode 100644 fs/yaffs2/Kconfig delete mode 100644 include/config_cmd_all.h delete mode 100644 include/sx151x.h
Rsync all defconfig files using moveconfig.py
Changes in v2: - Add new patch to resync with savedefconfig
configs/A10-OLinuXino-Lime_defconfig | 2 +- configs/A20-OLinuXino-Lime2_defconfig | 2 +- configs/A20-OLinuXino-Lime_defconfig | 2 +- configs/A20-OLinuXino_MICRO_defconfig | 2 +- configs/A20-Olimex-SOM-EVB_defconfig | 2 +- configs/Bananapi_M2_Ultra_defconfig | 2 +- configs/Bananapi_defconfig | 2 +- configs/Bananapro_defconfig | 2 +- configs/Cubieboard2_defconfig | 2 +- configs/Cubieboard_defconfig | 2 +- configs/Cubietruck_defconfig | 2 +- configs/Itead_Ibox_A20_defconfig | 2 +- configs/Lamobo_R1_defconfig | 2 +- configs/Linksprite_pcDuino3_Nano_defconfig | 2 +- configs/Linksprite_pcDuino3_defconfig | 3 --- configs/MPC8544DS_defconfig | 2 +- configs/MPC8610HPCD_defconfig | 2 +- configs/Marsboard_A10_defconfig | 2 +- configs/Mele_A1000_defconfig | 2 +- configs/Mele_M5_defconfig | 2 +- configs/Orangepi_defconfig | 2 +- configs/Orangepi_mini_defconfig | 2 +- configs/Wits_Pro_A20_DKT_defconfig | 2 +- configs/cm_t54_defconfig | 2 +- configs/controlcenterdc_defconfig | 2 +- configs/db-88f6820-gp_defconfig | 2 +- configs/dra7xx_evm_defconfig | 2 +- configs/dra7xx_hs_evm_defconfig | 2 +- configs/highbank_defconfig | 2 +- configs/ls1012aqds_qspi_defconfig | 2 +- configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 9 +-------- configs/ls1021atwr_nor_defconfig | 9 +-------- configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 9 +-------- configs/ls1021atwr_sdcard_ifc_defconfig | 9 +-------- configs/ls1021atwr_sdcard_qspi_defconfig | 9 +-------- configs/ls1043ardb_SECURE_BOOT_defconfig | 9 +-------- configs/ls1043ardb_defconfig | 9 +-------- configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig | 9 +-------- configs/ls1043ardb_sdcard_defconfig | 9 +-------- configs/ls1046aqds_SECURE_BOOT_defconfig | 2 +- configs/ls1046aqds_defconfig | 2 +- configs/ls1046aqds_lpuart_defconfig | 2 +- configs/ls1046aqds_nand_defconfig | 2 +- configs/ls1046aqds_qspi_defconfig | 2 +- configs/ls1046aqds_sdcard_ifc_defconfig | 2 +- configs/ls1046aqds_sdcard_qspi_defconfig | 2 +- configs/ls1046ardb_emmc_defconfig | 2 +- configs/ls1046ardb_qspi_SECURE_BOOT_defconfig | 10 ++-------- configs/ls1046ardb_qspi_defconfig | 10 ++-------- configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig | 10 ++-------- configs/ls1046ardb_sdcard_defconfig | 10 ++-------- configs/ls2080ardb_defconfig | 1 - configs/ls2081ardb_defconfig | 2 +- configs/ls2088ardb_qspi_defconfig | 1 - configs/ms7720se_defconfig | 2 +- configs/omap5_uevm_defconfig | 2 +- configs/r8a7795_salvator-x_defconfig | 4 ++-- configs/r8a7796_salvator-x_defconfig | 4 ++-- configs/xilinx_zynqmp_ep_defconfig | 4 ++-- configs/xilinx_zynqmp_zcu102_revA_defconfig | 4 ++-- configs/xilinx_zynqmp_zcu102_revB_defconfig | 4 ++-- 61 files changed, 67 insertions(+), 159 deletions(-)
diff --git a/configs/A10-OLinuXino-Lime_defconfig b/configs/A10-OLinuXino-Lime_defconfig index 914302276f..d76ddcf811 100644 --- a/configs/A10-OLinuXino-Lime_defconfig +++ b/configs/A10-OLinuXino-Lime_defconfig @@ -18,8 +18,8 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set -CONFIG_SCSI=y CONFIG_SUN4I_EMAC=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 +CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index f7b600be5b..e83ff82984 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -20,13 +20,13 @@ CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_PARTITION_UUIDS is not set -CONFIG_SCSI=y CONFIG_DFU_RAM=y CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 +CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y diff --git a/configs/A20-OLinuXino-Lime_defconfig b/configs/A20-OLinuXino-Lime_defconfig index 182a8f5f74..1bc0b7fbb9 100644 --- a/configs/A20-OLinuXino-Lime_defconfig +++ b/configs/A20-OLinuXino-Lime_defconfig @@ -16,9 +16,9 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set -CONFIG_SCSI=y CONFIG_ETH_DESIGNWARE=y CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 +CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/A20-OLinuXino_MICRO_defconfig b/configs/A20-OLinuXino_MICRO_defconfig index ae98e41685..009c4aa7e2 100644 --- a/configs/A20-OLinuXino_MICRO_defconfig +++ b/configs/A20-OLinuXino_MICRO_defconfig @@ -19,9 +19,9 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set -CONFIG_SCSI=y CONFIG_ETH_DESIGNWARE=y CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 +CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig index 61fe5e6390..c2fe2d234f 100644 --- a/configs/A20-Olimex-SOM-EVB_defconfig +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -20,10 +20,10 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set -CONFIG_SCSI=y CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 +CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Bananapi_M2_Ultra_defconfig b/configs/Bananapi_M2_Ultra_defconfig index 8c409faab8..a35d4bfd89 100644 --- a/configs/Bananapi_M2_Ultra_defconfig +++ b/configs/Bananapi_M2_Ultra_defconfig @@ -14,6 +14,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_SCSI=y CONFIG_AXP_DLDO4_VOLT=2500 CONFIG_AXP_ELDO3_VOLT=1200 +CONFIG_SCSI=y diff --git a/configs/Bananapi_defconfig b/configs/Bananapi_defconfig index 352a18ec8c..4e8e1e1a1f 100644 --- a/configs/Bananapi_defconfig +++ b/configs/Bananapi_defconfig @@ -17,8 +17,8 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_NETCONSOLE=y -CONFIG_SCSI=y CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y +CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Bananapro_defconfig b/configs/Bananapro_defconfig index 4218d5a97a..214c0d85f0 100644 --- a/configs/Bananapro_defconfig +++ b/configs/Bananapro_defconfig @@ -19,9 +19,9 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_NETCONSOLE=y -CONFIG_SCSI=y CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO4_VOLT=2500 +CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Cubieboard2_defconfig b/configs/Cubieboard2_defconfig index dc2722a9bf..0a0f95d6fb 100644 --- a/configs/Cubieboard2_defconfig +++ b/configs/Cubieboard2_defconfig @@ -15,7 +15,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set -CONFIG_SCSI=y CONFIG_ETH_DESIGNWARE=y CONFIG_SUN7I_GMAC=y +CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Cubieboard_defconfig b/configs/Cubieboard_defconfig index f83a691a26..a15c831a8a 100644 --- a/configs/Cubieboard_defconfig +++ b/configs/Cubieboard_defconfig @@ -15,6 +15,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set -CONFIG_SCSI=y CONFIG_SUN4I_EMAC=y +CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index cbd535c2bc..648eef1e72 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -22,11 +22,11 @@ CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_PARTITION_UUIDS is not set -CONFIG_SCSI=y CONFIG_DFU_RAM=y CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y +CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y diff --git a/configs/Itead_Ibox_A20_defconfig b/configs/Itead_Ibox_A20_defconfig index bab25b401c..6e6f5b2aaf 100644 --- a/configs/Itead_Ibox_A20_defconfig +++ b/configs/Itead_Ibox_A20_defconfig @@ -15,7 +15,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set -CONFIG_SCSI=y CONFIG_ETH_DESIGNWARE=y CONFIG_SUN7I_GMAC=y +CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Lamobo_R1_defconfig b/configs/Lamobo_R1_defconfig index 2ec0847e8a..65ccb6420c 100644 --- a/configs/Lamobo_R1_defconfig +++ b/configs/Lamobo_R1_defconfig @@ -17,8 +17,8 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set -CONFIG_SCSI=y CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y +CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Linksprite_pcDuino3_Nano_defconfig b/configs/Linksprite_pcDuino3_Nano_defconfig index 1e61cd20ba..c6682b8f79 100644 --- a/configs/Linksprite_pcDuino3_Nano_defconfig +++ b/configs/Linksprite_pcDuino3_Nano_defconfig @@ -17,8 +17,8 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set -CONFIG_SCSI=y CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y +CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Linksprite_pcDuino3_defconfig b/configs/Linksprite_pcDuino3_defconfig index f0d382c002..fb81bad00f 100644 --- a/configs/Linksprite_pcDuino3_defconfig +++ b/configs/Linksprite_pcDuino3_defconfig @@ -15,10 +15,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set -# CONFIG_SPL_BLK is not set CONFIG_DM_MMC=y -# CONFIG_SPL_DM_MMC is not set -# CONFIG_SPL_DM_MMC_OPS is not set CONFIG_ETH_DESIGNWARE=y CONFIG_SUN7I_GMAC=y CONFIG_SCSI=y diff --git a/configs/MPC8544DS_defconfig b/configs/MPC8544DS_defconfig index 8142cf267e..3e75be96b9 100644 --- a/configs/MPC8544DS_defconfig +++ b/configs/MPC8544DS_defconfig @@ -16,12 +16,12 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y -CONFIG_SCSI=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_RTL8139=y +CONFIG_SCSI=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/MPC8610HPCD_defconfig b/configs/MPC8610HPCD_defconfig index 6aef6d8434..57d8583fd1 100644 --- a/configs/MPC8610HPCD_defconfig +++ b/configs/MPC8610HPCD_defconfig @@ -15,9 +15,9 @@ CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y -CONFIG_SCSI=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y +CONFIG_SCSI=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_KEYBOARD=y diff --git a/configs/Marsboard_A10_defconfig b/configs/Marsboard_A10_defconfig index 516a16f73e..015b4d5814 100644 --- a/configs/Marsboard_A10_defconfig +++ b/configs/Marsboard_A10_defconfig @@ -11,7 +11,7 @@ CONFIG_SPL=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set -CONFIG_SCSI=y CONFIG_SUN4I_EMAC=y CONFIG_SUNXI_NO_PMIC=y +CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Mele_A1000_defconfig b/configs/Mele_A1000_defconfig index 0c9e8d1693..1ca92e0972 100644 --- a/configs/Mele_A1000_defconfig +++ b/configs/Mele_A1000_defconfig @@ -15,6 +15,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set -CONFIG_SCSI=y CONFIG_SUN4I_EMAC=y +CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Mele_M5_defconfig b/configs/Mele_M5_defconfig index 400a16505a..d316c75c83 100644 --- a/configs/Mele_M5_defconfig +++ b/configs/Mele_M5_defconfig @@ -16,7 +16,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set -CONFIG_SCSI=y CONFIG_ETH_DESIGNWARE=y CONFIG_SUN7I_GMAC=y +CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Orangepi_defconfig b/configs/Orangepi_defconfig index ed3e6786c6..5602d3c8e2 100644 --- a/configs/Orangepi_defconfig +++ b/configs/Orangepi_defconfig @@ -19,8 +19,8 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set -CONFIG_SCSI=y CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y +CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index 56f405ceed..5808d5df1b 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -21,8 +21,8 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set -CONFIG_SCSI=y CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y +CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Wits_Pro_A20_DKT_defconfig b/configs/Wits_Pro_A20_DKT_defconfig index 2a2f26d38f..5ee19bca1a 100644 --- a/configs/Wits_Pro_A20_DKT_defconfig +++ b/configs/Wits_Pro_A20_DKT_defconfig @@ -19,8 +19,8 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set -CONFIG_SCSI=y CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y +CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/cm_t54_defconfig b/configs/cm_t54_defconfig index ff811be04b..4aed572cf6 100644 --- a/configs/cm_t54_defconfig +++ b/configs/cm_t54_defconfig @@ -39,8 +39,8 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y -CONFIG_SCSI=y CONFIG_MMC_OMAP_HS=y +CONFIG_SCSI=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/controlcenterdc_defconfig b/configs/controlcenterdc_defconfig index 62c6546c20..af79b6c120 100644 --- a/configs/controlcenterdc_defconfig +++ b/configs/controlcenterdc_defconfig @@ -35,7 +35,6 @@ CONFIG_CMD_EXT4=y CONFIG_EFI_PARTITION=y CONFIG_OF_BOARD_FIXUP=y CONFIG_SPL_OF_TRANSLATE=y -CONFIG_SCSI=y CONFIG_DM_GPIO=y CONFIG_DM_PCA953X=y CONFIG_DM_I2C=y @@ -46,6 +45,7 @@ CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_MV=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SCSI=y CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_CLOCK=250000000 CONFIG_DEBUG_UART_SHIFT=2 diff --git a/configs/db-88f6820-gp_defconfig b/configs/db-88f6820-gp_defconfig index 5f072c5e67..6c6083d328 100644 --- a/configs/db-88f6820-gp_defconfig +++ b/configs/db-88f6820-gp_defconfig @@ -38,7 +38,6 @@ CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_SPL_OF_TRANSLATE=y -CONFIG_SCSI=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_MV=y @@ -46,6 +45,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PCI=y +CONFIG_SCSI=y CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_CLOCK=250000000 CONFIG_DEBUG_UART_SHIFT=2 diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 6987c35a4e..56effa08d0 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -46,7 +46,6 @@ CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y CONFIG_SPL_OF_TRANSLATE=y -CONFIG_DM_SCSI=y CONFIG_DWC_AHCI=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y @@ -70,6 +69,7 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_REGULATOR_PALMAS=y CONFIG_DM_REGULATOR_LP873X=y +CONFIG_DM_SCSI=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 72c43f8954..5b1d3fb658 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -49,7 +49,6 @@ CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y -CONFIG_DM_SCSI=y CONFIG_DWC_AHCI=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y @@ -73,6 +72,7 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_REGULATOR_PALMAS=y CONFIG_DM_REGULATOR_LP873X=y +CONFIG_DM_SCSI=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y diff --git a/configs/highbank_defconfig b/configs/highbank_defconfig index 3ed037ba11..d905b0f32b 100644 --- a/configs/highbank_defconfig +++ b/configs/highbank_defconfig @@ -24,6 +24,6 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set -CONFIG_SCSI=y # CONFIG_MMC is not set +CONFIG_SCSI=y CONFIG_OF_LIBFDT=y diff --git a/configs/ls1012aqds_qspi_defconfig b/configs/ls1012aqds_qspi_defconfig index d7ddd812a3..60000b376b 100644 --- a/configs/ls1012aqds_qspi_defconfig +++ b/configs/ls1012aqds_qspi_defconfig @@ -31,7 +31,6 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y -CONFIG_SCSI=y # CONFIG_BLK is not set CONFIG_DM_MMC=y # CONFIG_DM_MMC_OPS is not set @@ -43,6 +42,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_SCSI=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index c8cb2153bf..2d206e1947 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS1021ATWR=y CONFIG_SECURE_BOOT=y CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" +CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -12,8 +13,6 @@ CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y @@ -22,12 +21,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_BMP=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y @@ -46,4 +40,3 @@ CONFIG_VIDEO_FSL_DCU_FB=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_RSA=y CONFIG_SPL_RSA=y -CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index 29d6ea19a6..60f0830562 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021ATWR=y CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" +CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -11,8 +12,6 @@ CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y @@ -21,12 +20,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_BMP=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_FSL_CAAM=y @@ -45,4 +39,3 @@ CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_VIDEO_FSL_DCU_FB=y # CONFIG_VIDEO_SW_CURSOR is not set -CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index 8689fa7336..4722d36b3d 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" +CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -26,8 +27,6 @@ CONFIG_SPL_HASH_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y @@ -35,12 +34,7 @@ CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_BMP=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_DM=y @@ -61,4 +55,3 @@ CONFIG_VIDEO_FSL_DCU_FB=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_RSA=y CONFIG_SPL_RSA=y -CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index 8647365276..ba62b12741 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" +CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -24,8 +25,6 @@ CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y @@ -33,12 +32,7 @@ CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_BMP=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_DM=y @@ -57,4 +51,3 @@ CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_VIDEO_FSL_DCU_FB=y # CONFIG_VIDEO_SW_CURSOR is not set -CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index b254f3b909..08bd32a9c2 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" +CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -24,8 +25,6 @@ CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y @@ -35,12 +34,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_BMP=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_DM=y @@ -64,4 +58,3 @@ CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_VIDEO_FSL_DCU_FB=y # CONFIG_VIDEO_SW_CURSOR is not set -CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1043ardb_SECURE_BOOT_defconfig b/configs/ls1043ardb_SECURE_BOOT_defconfig index c7077fc809..fd37f5909b 100644 --- a/configs/ls1043ardb_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_SECURE_BOOT_defconfig @@ -3,23 +3,17 @@ CONFIG_TARGET_LS1043ARDB=y CONFIG_SECURE_BOOT=y CONFIG_FSL_LS_PPA=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-rdb" +CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=10 -CONFIG_HUSH_PARSER=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_PXE=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y @@ -40,4 +34,3 @@ CONFIG_USB_STORAGE=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_RSA_SOFTWARE_EXP=y -CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1043ardb_defconfig b/configs/ls1043ardb_defconfig index a551867ef2..7fe5a13a71 100644 --- a/configs/ls1043ardb_defconfig +++ b/configs/ls1043ardb_defconfig @@ -2,24 +2,18 @@ CONFIG_ARM=y CONFIG_TARGET_LS1043ARDB=y CONFIG_FSL_LS_PPA=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-rdb" +CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_BOOTDELAY=10 -CONFIG_HUSH_PARSER=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_PXE=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_FSL_CAAM=y @@ -38,4 +32,3 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig index a96cc56832..f939b859af 100644 --- a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-rdb" +CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT" @@ -21,20 +22,13 @@ CONFIG_SPL_CRYPTO_SUPPORT=y CONFIG_SPL_HASH_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y -CONFIG_HUSH_PARSER=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_PXE=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_DM=y @@ -56,4 +50,3 @@ CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_RSA=y CONFIG_SPL_RSA=y -CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig index 1b18179d43..0460fddd25 100644 --- a/configs/ls1043ardb_sdcard_defconfig +++ b/configs/ls1043ardb_sdcard_defconfig @@ -9,6 +9,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-rdb" +CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT" @@ -20,20 +21,13 @@ CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y -CONFIG_HUSH_PARSER=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_PXE=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_DM=y @@ -53,4 +47,3 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1046aqds_SECURE_BOOT_defconfig b/configs/ls1046aqds_SECURE_BOOT_defconfig index 08637e236f..8581fb99d0 100644 --- a/configs/ls1046aqds_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_SECURE_BOOT_defconfig @@ -16,13 +16,13 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y -CONFIG_CMD_USB=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/ls1046aqds_defconfig b/configs/ls1046aqds_defconfig index 94d0ea90ae..eaf35f2543 100644 --- a/configs/ls1046aqds_defconfig +++ b/configs/ls1046aqds_defconfig @@ -16,13 +16,13 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y -CONFIG_CMD_USB=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_FSL_CAAM=y diff --git a/configs/ls1046aqds_lpuart_defconfig b/configs/ls1046aqds_lpuart_defconfig index 6fc5d6edb8..7c7975355f 100644 --- a/configs/ls1046aqds_lpuart_defconfig +++ b/configs/ls1046aqds_lpuart_defconfig @@ -17,13 +17,13 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y -CONFIG_CMD_USB=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_FSL_CAAM=y diff --git a/configs/ls1046aqds_nand_defconfig b/configs/ls1046aqds_nand_defconfig index 802c69c0ad..7fa956b8bc 100644 --- a/configs/ls1046aqds_nand_defconfig +++ b/configs/ls1046aqds_nand_defconfig @@ -22,13 +22,13 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y -CONFIG_CMD_USB=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_FSL_CAAM=y diff --git a/configs/ls1046aqds_qspi_defconfig b/configs/ls1046aqds_qspi_defconfig index c47be08437..4244396f3d 100644 --- a/configs/ls1046aqds_qspi_defconfig +++ b/configs/ls1046aqds_qspi_defconfig @@ -17,13 +17,13 @@ CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y -CONFIG_CMD_USB=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_FSL_CAAM=y diff --git a/configs/ls1046aqds_sdcard_ifc_defconfig b/configs/ls1046aqds_sdcard_ifc_defconfig index f93854ac8f..3c4b6359fd 100644 --- a/configs/ls1046aqds_sdcard_ifc_defconfig +++ b/configs/ls1046aqds_sdcard_ifc_defconfig @@ -22,13 +22,13 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y -CONFIG_CMD_USB=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_DM=y diff --git a/configs/ls1046aqds_sdcard_qspi_defconfig b/configs/ls1046aqds_sdcard_qspi_defconfig index 62a9b2eaaf..8af81c0f85 100644 --- a/configs/ls1046aqds_sdcard_qspi_defconfig +++ b/configs/ls1046aqds_sdcard_qspi_defconfig @@ -22,13 +22,13 @@ CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y -CONFIG_CMD_USB=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_DM=y diff --git a/configs/ls1046ardb_emmc_defconfig b/configs/ls1046ardb_emmc_defconfig index a315ac1b24..29c55733d7 100644 --- a/configs/ls1046ardb_emmc_defconfig +++ b/configs/ls1046ardb_emmc_defconfig @@ -19,13 +19,13 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y -CONFIG_CMD_USB=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_DM=y diff --git a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig index 6d40587eee..2ed55547f3 100644 --- a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig @@ -4,24 +4,19 @@ CONFIG_SECURE_BOOT=y CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-rdb" +CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_QSPI_BOOT=y CONFIG_BOOTDELAY=10 -CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y CONFIG_CMD_USB=y +CONFIG_CMD_CACHE=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y @@ -37,4 +32,3 @@ CONFIG_FSL_QSPI=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_RSA=y -CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1046ardb_qspi_defconfig b/configs/ls1046ardb_qspi_defconfig index 1dc74debe7..bb5f3b007e 100644 --- a/configs/ls1046ardb_qspi_defconfig +++ b/configs/ls1046ardb_qspi_defconfig @@ -3,25 +3,20 @@ CONFIG_TARGET_LS1046ARDB=y CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-rdb" +CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_QSPI_BOOT=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_BOOTDELAY=10 -CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y CONFIG_CMD_USB=y +CONFIG_CMD_CACHE=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_FSL_CAAM=y @@ -37,4 +32,3 @@ CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y CONFIG_DM_USB=y -CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig index 9fdc4379cc..419c2289db 100644 --- a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS1046ARDB=y CONFIG_SECURE_BOOT=y CONFIG_FSL_LS_PPA=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-rdb" +CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL" @@ -13,20 +14,14 @@ CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 CONFIG_SPL_CRYPTO_SUPPORT=y CONFIG_SPL_HASH_SUPPORT=y -CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y CONFIG_CMD_USB=y +CONFIG_CMD_CACHE=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_DM=y @@ -45,4 +40,3 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_RSA=y CONFIG_SPL_RSA=y -CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1046ardb_sdcard_defconfig b/configs/ls1046ardb_sdcard_defconfig index 16cb8f1f00..48b0b43df5 100644 --- a/configs/ls1046ardb_sdcard_defconfig +++ b/configs/ls1046ardb_sdcard_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS1046ARDB=y CONFIG_FSL_LS_PPA=y CONFIG_SPL_FSL_LS_PPA=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-rdb" +CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL" @@ -13,20 +14,14 @@ CONFIG_SPL=y CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 -CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y CONFIG_CMD_USB=y +CONFIG_CMD_CACHE=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_DM=y @@ -43,4 +38,3 @@ CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y CONFIG_DM_USB=y -CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls2080ardb_defconfig b/configs/ls2080ardb_defconfig index fe4bb27992..da77d60f52 100644 --- a/configs/ls2080ardb_defconfig +++ b/configs/ls2080ardb_defconfig @@ -40,4 +40,3 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls2081ardb_defconfig b/configs/ls2081ardb_defconfig index 21fce98af7..7fcfdd4b6e 100644 --- a/configs/ls2081ardb_defconfig +++ b/configs/ls2081ardb_defconfig @@ -22,7 +22,6 @@ CONFIG_CMD_CACHE=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y -CONFIG_SCSI=y CONFIG_FSL_CAAM=y CONFIG_DM_SPI_FLASH=y CONFIG_NETDEVICES=y @@ -31,6 +30,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_SCSI=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y diff --git a/configs/ls2088ardb_qspi_defconfig b/configs/ls2088ardb_qspi_defconfig index 4addbaf7df..3a022330e2 100644 --- a/configs/ls2088ardb_qspi_defconfig +++ b/configs/ls2088ardb_qspi_defconfig @@ -40,4 +40,3 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ms7720se_defconfig b/configs/ms7720se_defconfig index 7f137fa911..dd95a236bb 100644 --- a/configs/ms7720se_defconfig +++ b/configs/ms7720se_defconfig @@ -26,5 +26,5 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y CONFIG_MTD_NOR_FLASH=y -CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_SCIF_CONSOLE=y +CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/omap5_uevm_defconfig b/configs/omap5_uevm_defconfig index d13d11c8b1..635bdf7e13 100644 --- a/configs/omap5_uevm_defconfig +++ b/configs/omap5_uevm_defconfig @@ -33,10 +33,10 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y -CONFIG_SCSI=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_MMC_OMAP_HS=y +CONFIG_SCSI=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/r8a7795_salvator-x_defconfig b/configs/r8a7795_salvator-x_defconfig index 1a11099e0c..98eca37710 100644 --- a/configs/r8a7795_salvator-x_defconfig +++ b/configs/r8a7795_salvator-x_defconfig @@ -3,9 +3,9 @@ CONFIG_ARCH_RMOBILE=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_RCAR_GEN3=y CONFIG_TARGET_SALVATOR_X=y -CONFIG_ENV_IS_IN_MMC=y CONFIG_DEFAULT_DEVICE_TREE="r8a7795-salvator-x" CONFIG_SMBIOS_PRODUCT_NAME="" +CONFIG_ENV_IS_IN_MMC=y CONFIG_DEFAULT_FDT_FILE="r8a7795-salvator-x.dtb" CONFIG_VERSION_VARIABLE=y CONFIG_CMD_BOOTZ=y @@ -15,8 +15,8 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y -CONFIG_OF_CONTROL=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y CONFIG_CLK=y CONFIG_CLK_RENESAS=y CONFIG_SH_SDHI=y diff --git a/configs/r8a7796_salvator-x_defconfig b/configs/r8a7796_salvator-x_defconfig index 2c8e7ddb99..9e0f9290bf 100644 --- a/configs/r8a7796_salvator-x_defconfig +++ b/configs/r8a7796_salvator-x_defconfig @@ -4,9 +4,9 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_RCAR_GEN3=y CONFIG_R8A7796=y CONFIG_TARGET_SALVATOR_X=y -CONFIG_ENV_IS_IN_MMC=y CONFIG_DEFAULT_DEVICE_TREE="r8a7796-salvator-x" CONFIG_SMBIOS_PRODUCT_NAME="" +CONFIG_ENV_IS_IN_MMC=y CONFIG_DEFAULT_FDT_FILE="r8a7796-salvator-x.dtb" CONFIG_VERSION_VARIABLE=y CONFIG_CMD_BOOTZ=y @@ -16,8 +16,8 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y -CONFIG_OF_CONTROL=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y CONFIG_CLK=y CONFIG_CLK_RENESAS=y CONFIG_SH_SDHI=y diff --git a/configs/xilinx_zynqmp_ep_defconfig b/configs/xilinx_zynqmp_ep_defconfig index d3ae3ec57a..b696c6272f 100644 --- a/configs/xilinx_zynqmp_ep_defconfig +++ b/configs/xilinx_zynqmp_ep_defconfig @@ -47,8 +47,6 @@ CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_SCSI=y -CONFIG_DM_SCSI=y CONFIG_SATA_CEVA=y CONFIG_DFU_RAM=y CONFIG_FPGA_XILINX=y @@ -64,6 +62,8 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_DM_ETH=y CONFIG_ZYNQ_GEM=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y CONFIG_DEBUG_UART_ZYNQ=y CONFIG_DEBUG_UART_BASE=0xff000000 CONFIG_DEBUG_UART_CLOCK=25000000 diff --git a/configs/xilinx_zynqmp_zcu102_revA_defconfig b/configs/xilinx_zynqmp_zcu102_revA_defconfig index fc14459d3c..0ef0ba5341 100644 --- a/configs/xilinx_zynqmp_zcu102_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revA_defconfig @@ -40,8 +40,6 @@ CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_SCSI=y -CONFIG_DM_SCSI=y CONFIG_SATA_CEVA=y CONFIG_DFU_RAM=y CONFIG_FPGA_XILINX=y @@ -57,6 +55,8 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_DM_ETH=y CONFIG_ZYNQ_GEM=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y CONFIG_DEBUG_UART_ZYNQ=y CONFIG_DEBUG_UART_BASE=0xff000000 CONFIG_DEBUG_UART_CLOCK=100000000 diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index bc9b14e2fb..87be093cc2 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -40,8 +40,6 @@ CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_SCSI=y -CONFIG_DM_SCSI=y CONFIG_SATA_CEVA=y CONFIG_DFU_RAM=y CONFIG_FPGA_XILINX=y @@ -57,6 +55,8 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_DM_ETH=y CONFIG_ZYNQ_GEM=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y CONFIG_DEBUG_UART_ZYNQ=y CONFIG_DEBUG_UART_BASE=0xff000000 CONFIG_DEBUG_UART_CLOCK=100000000
Changes in v2:
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
This converts the following to Kconfig: CONFIG_CMD_MAX6957
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com ---
Changes in v2: None
board/work-microwave/work_92105/Kconfig | 7 +++++++ configs/work_92105_defconfig | 1 + include/configs/work_92105.h | 1 - scripts/config_whitelist.txt | 1 - 4 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/board/work-microwave/work_92105/Kconfig b/board/work-microwave/work_92105/Kconfig index 1fde4b29aa..4bc34ed01f 100644 --- a/board/work-microwave/work_92105/Kconfig +++ b/board/work-microwave/work_92105/Kconfig @@ -17,4 +17,11 @@ config CMD_HD44760 help This controls the LCD driver.
+config CMD_MAX6957 + bool "Enable 'max6957aax' PMIC command" + help + DEPRECATED: Needs conversion to driver model. + + This allows PMIC registers to be read and written. + endif diff --git a/configs/work_92105_defconfig b/configs/work_92105_defconfig index ba2474c3a9..1765aa565a 100644 --- a/configs/work_92105_defconfig +++ b/configs/work_92105_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_CMD_HD44760=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_CMD_MAX6957=y CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/include/configs/work_92105.h b/include/configs/work_92105.h index 0ac7b85f4b..5c1af5f2a1 100644 --- a/include/configs/work_92105.h +++ b/include/configs/work_92105.h @@ -131,7 +131,6 @@
#define CONFIG_LPC32XX_SSP #define CONFIG_LPC32XX_SSP_TIMEOUT 100000 -#define CONFIG_CMD_MAX6957 /* * Environment */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 3b5c17a982..9bb398c240 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_MAX6957 CONFIG_CMD_MEM CONFIG_CMD_MFSL CONFIG_CMD_MMC_SPI
Changes in v2: None
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
This is not actually used in U-Boot. Most likely it means CONFIG_CMD_MEMORY so change all occurences to that.
Changes in v2: None
README | 4 ++-- include/configs/stm32f429-discovery.h | 2 -- scripts/config_whitelist.txt | 1 - 3 files changed, 2 insertions(+), 5 deletions(-)
diff --git a/README b/README index 1edf3dbbd8..ad83a81da9 100644 --- a/README +++ b/README @@ -3698,7 +3698,7 @@ Low Level (hardware related) configuration options:
- CONFIG_LOOPW Add the "loopw" memory command. This only takes effect if - the memory commands are activated globally (CONFIG_CMD_MEM). + the memory commands are activated globally (CONFIG_CMD_MEMORY).
- CONFIG_MX_CYCLIC Add the "mdc" and "mwc" memory commands. These are cyclic @@ -3712,7 +3712,7 @@ Low Level (hardware related) configuration options: This command will write 12345678 to address 100 all 10 ms.
This only takes effect if the memory commands are activated - globally (CONFIG_CMD_MEM). + globally (CONFIG_CMD_MEMORY).
- CONFIG_SKIP_LOWLEVEL_INIT [ARM, NDS32, MIPS only] If this variable is defined, then certain diff --git a/include/configs/stm32f429-discovery.h b/include/configs/stm32f429-discovery.h index c47be514d8..cd97c7cbad 100644 --- a/include/configs/stm32f429-discovery.h +++ b/include/configs/stm32f429-discovery.h @@ -82,6 +82,4 @@ #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING
-#define CONFIG_CMD_MEM - #endif /* __CONFIG_H */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 9bb398c240..b5662a9fd6 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_MEM CONFIG_CMD_MFSL CONFIG_CMD_MMC_SPI CONFIG_CMD_MTDPARTS_SPREAD
Changes in v2: None
These are currently not quite in alphabetical order. Before adding more, sort them.
Signed-off-by: Simon Glass sjg@chromium.org Suggested-by: Bin Meng bmeng.cn@gmail.com ---
Changes in v2: - Add new patch to sort the device-access commands
cmd/Kconfig | 244 ++++++++++++++++++++++++++++++------------------------------ 1 file changed, 122 insertions(+), 122 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index f18efc1e88..d9a35b81a7 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -483,6 +483,12 @@ endmenu
menu "Device access commands"
+config CMD_ARMFLASH + #depends on FLASH_CFI_DRIVER + bool "armflash" + help + ARM Ltd reference designs flash partition access + config CMD_CLK bool "clk - Show clock frequencies" help @@ -492,6 +498,25 @@ config CMD_CLK clock values from associated drivers. However currently no command exists for this.
+config CMD_DEMO + bool "demo - Demonstration commands for driver model" + depends on DM + help + Provides a 'demo' command which can be used to play around with + driver model. To use this properly you will need to enable one or + both of the demo devices (DM_DEMO_SHAPE and DM_DEMO_SIMPLE). + Otherwise you will always get an empty list of devices. The demo + devices are defined in the sandbox device tree, so the easiest + option is to use sandbox and pass the -d point to sandbox's + u-boot.dtb file. + +config CMD_DFU + bool "dfu" + select USB_FUNCTION_DFU + help + Enables the command "dfu" which is used to have U-Boot create a DFU + class device via USB. + config CMD_DM bool "dm - Access to driver model information" depends on DM @@ -503,17 +528,80 @@ config CMD_DM can be useful to see the state of driver model for debugging or interest.
-config CMD_DEMO - bool "demo - Demonstration commands for driver model" - depends on DM +config CMD_FDC + bool "fdcboot - Boot from floppy device" help - Provides a 'demo' command which can be used to play around with - driver model. To use this properly you will need to enable one or - both of the demo devices (DM_DEMO_SHAPE and DM_DEMO_SIMPLE). - Otherwise you will always get an empty list of devices. The demo - devices are defined in the sandbox device tree, so the easiest - option is to use sandbox and pass the -d point to sandbox's - u-boot.dtb file. + The 'fdtboot' command allows booting an image from a floppy disk. + +config CMD_FLASH + bool "flinfo, erase, protect" + default y + help + NOR flash support. + flinfo - print FLASH memory information + erase - FLASH memory + protect - enable or disable FLASH write protection + +config CMD_FPGA + bool "fpga" + default y + help + FPGA support. + +config CMD_FPGA_LOADBP + bool "fpga loadbp - load partial bitstream (Xilinx only)" + depends on CMD_FPGA + help + Supports loading an FPGA device from a bitstream buffer containing + a partial bitstream. + +config CMD_FPGA_LOADFS + bool "fpga loadfs - load bitstream from FAT filesystem (Xilinx only)" + depends on CMD_FPGA + help + Supports loading an FPGA device from a FAT filesystem. + +config CMD_FPGA_LOADMK + bool "fpga loadmk - load bitstream from image" + depends on CMD_FPGA + help + Supports loading an FPGA device from a image generated by mkimage. + +config CMD_FPGA_LOADP + bool "fpga loadp - load partial bitstream" + depends on CMD_FPGA + help + Supports loading an FPGA device from a bitstream buffer containing + a partial bitstream. + +config CMD_FPGAD + bool "fpgad - dump FPGA registers" + help + (legacy, needs conversion to driver model) + Provides a way to dump FPGA registers by calling the board-specific + fpga_get_reg() function. This functions similarly to the 'md' + command. + +config CMD_FUSE + bool "fuse - support for the fuse subssystem" + help + (deprecated - needs conversion to driver model) + This allows reading, sensing, programming or overriding fuses + which control the behaviour of the device. The command uses the + fuse_...() API. + +config CMD_GPIO + bool "gpio" + help + GPIO support. + +config CMD_GPT + bool "GPT (GUID Partition Table) command" + select PARTITION_UUIDS + select EFI_PARTITION + help + Enable the 'gpt' command to ready and write GPT style partition + tables.
config CMD_IDE bool "ide - Support for IDE drivers" @@ -566,6 +654,11 @@ config CMD_IOTRACE might be useful to enhance tracing to only checksum the accesses and not the data read/written.
+config CMD_I2C + bool "i2c" + help + I2C support. + config CMD_LOADB bool "loadb" default y @@ -578,29 +671,6 @@ config CMD_LOADS help Load an S-Record file over serial line
-config CMD_FLASH - bool "flinfo, erase, protect" - default y - help - NOR flash support. - flinfo - print FLASH memory information - erase - FLASH memory - protect - enable or disable FLASH write protection - -config CMD_GPT - bool "GPT (GUID Partition Table) command" - select PARTITION_UUIDS - select EFI_PARTITION - help - Enable the 'gpt' command to ready and write GPT style partition - tables. - -config CMD_ARMFLASH - #depends on FLASH_CFI_DRIVER - bool "armflash" - help - ARM Ltd reference designs flash partition access - config CMD_MMC bool "mmc" help @@ -638,6 +708,25 @@ config CMD_PART Read and display information about the partition table on various media.
+config CMD_REMOTEPROC + bool "remoteproc" + depends on REMOTEPROC + help + Support for Remote Processor control + +config CMD_SATA + bool "sata - Access SATA subsystem" + select SATA + help + SATA (Serial Advanced Technology Attachment) is a serial bus + standard for connecting to hard drives and other storage devices. + This command provides information about attached devices and allows + reading, writing and other operations. + + SATA replaces PATA (originally just ATA), which stands for Parallel AT + Attachment, where AT refers to an IBM AT (Advanced Technology) + computer released in 1984. + config CMD_SF bool "sf" help @@ -648,105 +737,16 @@ config CMD_SPI help SPI utility command.
-config CMD_I2C - bool "i2c" - help - I2C support. - config CMD_USB bool "usb" help USB support.
-config CMD_DFU - bool "dfu" - select USB_FUNCTION_DFU - help - Enables the command "dfu" which is used to have U-Boot create a DFU - class device via USB. - config CMD_USB_MASS_STORAGE bool "UMS usb mass storage" help USB mass storage support
-config CMD_FPGA - bool "fpga" - default y - help - FPGA support. - -config CMD_FPGA_LOADBP - bool "fpga loadbp - load partial bitstream (Xilinx only)" - depends on CMD_FPGA - help - Supports loading an FPGA device from a bitstream buffer containing - a partial bitstream. - -config CMD_FPGA_LOADFS - bool "fpga loadfs - load bitstream from FAT filesystem (Xilinx only)" - depends on CMD_FPGA - help - Supports loading an FPGA device from a FAT filesystem. - -config CMD_FPGA_LOADMK - bool "fpga loadmk - load bitstream from image" - depends on CMD_FPGA - help - Supports loading an FPGA device from a image generated by mkimage. - -config CMD_FPGA_LOADP - bool "fpga loadp - load partial bitstream" - depends on CMD_FPGA - help - Supports loading an FPGA device from a bitstream buffer containing - a partial bitstream. - -config CMD_FPGAD - bool "fpgad - dump FPGA registers" - help - (legacy, needs conversion to driver model) - Provides a way to dump FPGA registers by calling the board-specific - fpga_get_reg() function. This functions similarly to the 'md' - command. - -config CMD_FUSE - bool "fuse - support for the fuse subssystem" - help - (deprecated - needs conversion to driver model) - This allows reading, sensing, programming or overriding fuses - which control the behaviour of the device. The command uses the - fuse_...() API. - -config CMD_REMOTEPROC - bool "remoteproc" - depends on REMOTEPROC - help - Support for Remote Processor control - -config CMD_GPIO - bool "gpio" - help - GPIO support. - -config CMD_FDC - bool "fdcboot - Boot from floppy device" - help - The 'fdtboot' command allows booting an image from a floppy disk. - -config CMD_SATA - bool "sata - Access SATA subsystem" - select SATA - help - SATA (Serial Advanced Technology Attachment) is a serial bus - standard for connecting to hard drives and other storage devices. - This command provides information about attached devices and allows - reading, writing and other operations. - - SATA replaces PATA (originally just ATA), which stands for Parallel AT - Attachment, where AT refers to an IBM AT (Advanced Technology) - computer released in 1984. - endmenu
Changes in v2:
Signed-off-by: Simon Glass sjg@chromium.org Suggested-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Bin Meng bmeng.cn@gmail.com
Changes in v2:
Signed-off-by: Simon Glass sjg@chromium.org Suggested-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
This converts the following to Kconfig: CONFIG_CMD_MMC_SPI
Changes in v2: - Sort Kconfig options in alphabetical order
README | 1 - cmd/Kconfig | 9 +++++++++ configs/UCP1020_SPIFLASH_defconfig | 1 + configs/UCP1020_defconfig | 1 + configs/microblaze-generic_defconfig | 1 + include/config_cmd_all.h | 1 - include/configs/UCP1020.h | 1 - include/configs/am335x_shc.h | 1 - include/configs/microblaze-generic.h | 1 - scripts/config_whitelist.txt | 2 -- 10 files changed, 12 insertions(+), 7 deletions(-)
diff --git a/README b/README index ad83a81da9..8d635a1aaf 100644 --- a/README +++ b/README @@ -836,7 +836,6 @@ The following options need to be configured: CONFIG_CMD_TIMER * access to the system tick timer CONFIG_CMD_USB * USB support CONFIG_CMD_CDP * Cisco Discover Protocol support - CONFIG_CMD_MFSL * Microblaze FSL support CONFIG_CMD_XIMG Load part of Multi Image CONFIG_CMD_UUID * Generate random UUID or GUID string
diff --git a/cmd/Kconfig b/cmd/Kconfig index d9a35b81a7..4b63efe80c 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -701,6 +701,15 @@ config CMD_NAND_TORTURE
endif # CMD_NAND
+config CMD_MMC_SPI + bool "mmc_spi - Set up MMC SPI device" + help + Provides a way to set up an MMC (Multimedia Card) SPI (Serial + Peripheral Interface) device. The device provides a means of + accessing an MMC device via SPI using a single data line, limited + to 20MHz. It is useful since it reduces the amount of protocol code + required. + config CMD_PART bool "part" select PARTITION_UUIDS diff --git a/configs/UCP1020_SPIFLASH_defconfig b/configs/UCP1020_SPIFLASH_defconfig index 686137dc98..e871d6fdfc 100644 --- a/configs/UCP1020_SPIFLASH_defconfig +++ b/configs/UCP1020_SPIFLASH_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_MMC_SPI=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/UCP1020_defconfig b/configs/UCP1020_defconfig index be0029673b..13af8626e7 100644 --- a/configs/UCP1020_defconfig +++ b/configs/UCP1020_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_MMC_SPI=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/microblaze-generic_defconfig b/configs/microblaze-generic_defconfig index 3d84cf24aa..f97459e6a8 100644 --- a/configs/microblaze-generic_defconfig +++ b/configs/microblaze-generic_defconfig @@ -23,6 +23,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot-mONStR> " CONFIG_CMD_ASKENV=y CONFIG_CMD_GPIO=y +CONFIG_CMD_MFSL=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y diff --git a/include/config_cmd_all.h b/include/config_cmd_all.h index e6ebc2f57d..b3c0d0e71f 100644 --- a/include/config_cmd_all.h +++ b/include/config_cmd_all.h @@ -13,7 +13,6 @@ * Alphabetical list of all possible commands. */
-#define CONFIG_CMD_MFSL /* FSL support for Microblaze */ #define CONFIG_CMD_ONENAND /* OneNAND support */ #define CONFIG_CMD_PCI /* pciinfo */ #define CONFIG_CMD_PCMCIA /* PCMCIA support */ diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index 6fd3fa4712..eea518df21 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -437,7 +437,6 @@ #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_MMC_SPI -#define CONFIG_CMD_MMC_SPI #endif
/* Misc Extra Settings */ diff --git a/include/configs/am335x_shc.h b/include/configs/am335x_shc.h index f3b7767a97..d21240c23c 100644 --- a/include/configs/am335x_shc.h +++ b/include/configs/am335x_shc.h @@ -19,7 +19,6 @@ #undef CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC #undef CONFIG_CMD_EXT4 #undef CONFIG_CMD_EXT4_WRITE -#undef CONFIG_CMD_MMC_SPI #undef CONFIG_CMD_SPI
#define CONFIG_CMD_CACHE diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index aa007e2819..fb0575fa4d 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -163,7 +163,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_MFSL
#if defined(FLASH) # if !defined(RAMENV) diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index b5662a9fd6..60d13dfbba 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,8 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_MFSL -CONFIG_CMD_MMC_SPI CONFIG_CMD_MTDPARTS_SPREAD CONFIG_CMD_ONENAND CONFIG_CMD_PCA953X
Changes in v2:
This converts the following to Kconfig: CONFIG_CMD_MTDPARTS_SPREAD
Changes in v2: None
cmd/Kconfig | 10 ++++++++++ configs/sandbox_defconfig | 1 + scripts/config_whitelist.txt | 1 - 3 files changed, 11 insertions(+), 1 deletion(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 4b63efe80c..27b970975e 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1222,6 +1222,16 @@ config MTDPARTS_DEFAULT Defines a default MTD partitioning scheme in the Linux MTD command line partitions format
+config CMD_MTDPARTS_SPREAD + string "Padd partition size to take account of bad blocks" + depends on CMD_MTDPARTS + help + This enables the 'spread' sub-command of the mtdparts command. + This command will modify the existing mtdparts variable by increasing + the size of the partitions such that 1) each partition's net size is + at least as large as the size specified in the mtdparts variable and + 2) each partition starts on a good block. + endmenu
menu "Debug commands" diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index fd0b952e1d..698ced0256 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -61,6 +61,7 @@ CONFIG_CMD_TPM_TEST=y CONFIG_CMD_CBFS=y CONFIG_CMD_CRAMFS=y CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_MTDPARTS=y CONFIG_MAC_PARTITION=y CONFIG_AMIGA_PARTITION=y CONFIG_OF_CONTROL=y diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 60d13dfbba..b366dc0f39 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_MTDPARTS_SPREAD CONFIG_CMD_ONENAND CONFIG_CMD_PCA953X CONFIG_CMD_PCA953X_INFO
Changes in v2: None
This converts the following to Kconfig: CONFIG_CMD_ONENAND
Changes in v2: None
cmd/Kconfig | 8 ++++++++ configs/igep0020_defconfig | 1 + configs/igep0030_defconfig | 1 + configs/igep0032_defconfig | 1 + configs/s5p_goni_defconfig | 1 + configs/smdkc100_defconfig | 1 + configs/vct_platinum_onenand_defconfig | 1 + configs/vct_platinum_onenand_small_defconfig | 1 + configs/vct_platinumavc_onenand_defconfig | 1 + configs/vct_platinumavc_onenand_small_defconfig | 1 + configs/vct_premium_onenand_defconfig | 1 + configs/vct_premium_onenand_small_defconfig | 1 + include/config_cmd_all.h | 1 - include/configs/exynos4-common.h | 2 -- include/configs/nokia_rx51.h | 6 ------ include/configs/omap3_igep00x0.h | 2 -- include/configs/s5p_goni.h | 2 -- include/configs/smdkc100.h | 2 -- include/configs/vct.h | 4 ---- scripts/config_whitelist.txt | 1 - 20 files changed, 19 insertions(+), 20 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 27b970975e..cbe4744272 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -710,6 +710,14 @@ config CMD_MMC_SPI to 20MHz. It is useful since it reduces the amount of protocol code required.
+config CMD_ONENAND + bool "onenand - access to onenand device" + help + OneNAND is a brand of NAND ('Not AND' gate) flash which provides + various useful features. This command allows reading, writing, + and erasing blocks. It allso provides a way to show and change + bad blocks, and test the device. + config CMD_PART bool "part" select PARTITION_UUIDS diff --git a/configs/igep0020_defconfig b/configs/igep0020_defconfig index 8ca5a84ec5..2375f861f1 100644 --- a/configs/igep0020_defconfig +++ b/configs/igep0020_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y +CONFIG_CMD_ONENAND=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y diff --git a/configs/igep0030_defconfig b/configs/igep0030_defconfig index 8af6dd53d0..03da20162b 100644 --- a/configs/igep0030_defconfig +++ b/configs/igep0030_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y +CONFIG_CMD_ONENAND=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y diff --git a/configs/igep0032_defconfig b/configs/igep0032_defconfig index dd433309f9..fb8c925113 100644 --- a/configs/igep0032_defconfig +++ b/configs/igep0032_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y +CONFIG_CMD_ONENAND=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y diff --git a/configs/s5p_goni_defconfig b/configs/s5p_goni_defconfig index 9c66a1826d..0045f5e63e 100644 --- a/configs/s5p_goni_defconfig +++ b/configs/s5p_goni_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_PROMPT="Goni # " # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y +CONFIG_CMD_ONENAND=y CONFIG_CMD_DFU=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set diff --git a/configs/smdkc100_defconfig b/configs/smdkc100_defconfig index ef8510d47d..82ba51c00d 100644 --- a/configs/smdkc100_defconfig +++ b/configs/smdkc100_defconfig @@ -9,6 +9,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="SMDKC100 # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_ONENAND=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y diff --git a/configs/vct_platinum_onenand_defconfig b/configs/vct_platinum_onenand_defconfig index 4c1615c537..4c242e8786 100644 --- a/configs/vct_platinum_onenand_defconfig +++ b/configs/vct_platinum_onenand_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_PROMPT="$ " # CONFIG_CMD_IMLS is not set CONFIG_CMD_EEPROM=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_ONENAND=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/vct_platinum_onenand_small_defconfig b/configs/vct_platinum_onenand_small_defconfig index 20c0863b7b..845833c073 100644 --- a/configs/vct_platinum_onenand_small_defconfig +++ b/configs/vct_platinum_onenand_small_defconfig @@ -15,6 +15,7 @@ CONFIG_SYS_PROMPT="$ " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_ONENAND=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/vct_platinumavc_onenand_defconfig b/configs/vct_platinumavc_onenand_defconfig index dfb8f04ce7..2a726144e9 100644 --- a/configs/vct_platinumavc_onenand_defconfig +++ b/configs/vct_platinumavc_onenand_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_PROMPT="$ " # CONFIG_CMD_IMLS is not set CONFIG_CMD_EEPROM=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_ONENAND=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set diff --git a/configs/vct_platinumavc_onenand_small_defconfig b/configs/vct_platinumavc_onenand_small_defconfig index de7b500f80..e2f68eb1ea 100644 --- a/configs/vct_platinumavc_onenand_small_defconfig +++ b/configs/vct_platinumavc_onenand_small_defconfig @@ -15,6 +15,7 @@ CONFIG_SYS_PROMPT="$ " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_ONENAND=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/vct_premium_onenand_defconfig b/configs/vct_premium_onenand_defconfig index ba43e0e00a..39be742c5c 100644 --- a/configs/vct_premium_onenand_defconfig +++ b/configs/vct_premium_onenand_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_PROMPT="$ " # CONFIG_CMD_IMLS is not set CONFIG_CMD_EEPROM=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_ONENAND=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/vct_premium_onenand_small_defconfig b/configs/vct_premium_onenand_small_defconfig index cc9998f391..6e3a420a14 100644 --- a/configs/vct_premium_onenand_small_defconfig +++ b/configs/vct_premium_onenand_small_defconfig @@ -15,6 +15,7 @@ CONFIG_SYS_PROMPT="$ " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_ONENAND=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set diff --git a/include/config_cmd_all.h b/include/config_cmd_all.h index b3c0d0e71f..c61951bb22 100644 --- a/include/config_cmd_all.h +++ b/include/config_cmd_all.h @@ -13,7 +13,6 @@ * Alphabetical list of all possible commands. */
-#define CONFIG_CMD_ONENAND /* OneNAND support */ #define CONFIG_CMD_PCI /* pciinfo */ #define CONFIG_CMD_PCMCIA /* PCMCIA support */ #define CONFIG_CMD_PORTIO /* Port I/O */ diff --git a/include/configs/exynos4-common.h b/include/configs/exynos4-common.h index c995f35b73..9f0131a7ee 100644 --- a/include/configs/exynos4-common.h +++ b/include/configs/exynos4-common.h @@ -20,8 +20,6 @@ /* SD/MMC configuration */ #define CONFIG_MMC_DEFAULT_DEV 0
-#undef CONFIG_CMD_ONENAND - /* TIZEN THOR downloader support */ #define CONFIG_CMD_THOR_DOWNLOAD #define CONFIG_USB_FUNCTION_THOR diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index 982651462d..2767f882e4 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -102,12 +102,6 @@ #define CONFIG_CMDLINE_EDITING /* add command line history */ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */
-#ifdef ONENAND_SUPPORT - -#define CONFIG_CMD_ONENAND /* ONENAND support */ - -#endif - #define CONFIG_OMAP3_SPI #define CONFIG_SYS_I2C #define CONFIG_SYS_OMAP24_I2C_SPEED 100000 diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index 39f1e54544..35d46dc949 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -52,8 +52,6 @@ #define CONFIG_USBD_MANUFACTURER "Texas Instruments" #define CONFIG_USBD_PRODUCT_NAME "IGEP"
-#define CONFIG_CMD_ONENAND - #ifndef CONFIG_SPL_BUILD
/* Environment */ diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index 9c00138508..eb17580865 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -51,8 +51,6 @@ /* PWM */ #define CONFIG_PWM 1
-#define CONFIG_CMD_ONENAND - /* USB Composite download gadget - g_dnl */ #define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_32M #define DFU_DEFAULT_POLL_TIMEOUT 300 diff --git a/include/configs/smdkc100.h b/include/configs/smdkc100.h index 3e3575438a..58abac5eef 100644 --- a/include/configs/smdkc100.h +++ b/include/configs/smdkc100.h @@ -59,8 +59,6 @@ /*********************************************************** * Command definition ***********************************************************/ -#define CONFIG_CMD_ONENAND - #define CONFIG_MTD_DEVICE #define CONFIG_MTD_PARTITIONS
diff --git a/include/configs/vct.h b/include/configs/vct.h index 2cb4ab149c..e3c3b0e71f 100644 --- a/include/configs/vct.h +++ b/include/configs/vct.h @@ -105,10 +105,6 @@ #define CONFIG_EHCI_HCD_INIT_AFTER_RESET /* re-init HCD after CMD_RESET */ #endif /* CONFIG_CMD_USB */
-#if defined(CONFIG_VCT_ONENAND) -#define CONFIG_CMD_ONENAND -#endif - /* * BOOTP options */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index b366dc0f39..67ad3b846c 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_ONENAND CONFIG_CMD_PCA953X CONFIG_CMD_PCA953X_INFO CONFIG_CMD_PCI
Changes in v2: None
This converts the following to Kconfig: CONFIG_CMD_PCA953X
Changes in v2: None
README | 1 - arch/powerpc/cpu/mpc83xx/Kconfig | 1 + configs/cl-som-am57x_defconfig | 1 + configs/cm_t335_defconfig | 1 + configs/ot1200_defconfig | 1 + configs/ot1200_spl_defconfig | 1 + configs/snapper9260_defconfig | 1 + configs/snapper9g20_defconfig | 1 + configs/xilinx_zynqmp_zcu102_revA_defconfig | 1 + configs/xilinx_zynqmp_zcu102_revB_defconfig | 1 + configs/xpedite517x_defconfig | 1 + configs/xpedite520x_defconfig | 1 + configs/xpedite537x_defconfig | 1 + configs/xpedite550x_defconfig | 1 + drivers/gpio/Kconfig | 9 +++++++++ include/configs/cl-som-am57x.h | 1 - include/configs/cm_t335.h | 1 - include/configs/ot1200.h | 1 - include/configs/snapper9260.h | 1 - include/configs/strider.h | 1 - include/configs/xilinx_zynqmp_zcu102.h | 1 - include/configs/xpedite517x.h | 1 - include/configs/xpedite520x.h | 1 - include/configs/xpedite537x.h | 1 - include/configs/xpedite550x.h | 1 - scripts/config_whitelist.txt | 1 - 26 files changed, 22 insertions(+), 12 deletions(-)
diff --git a/README b/README index 8d635a1aaf..5f916c8d8e 100644 --- a/README +++ b/README @@ -812,7 +812,6 @@ The following options need to be configured: CONFIG_CMD_MII * MII utility commands CONFIG_CMD_NET bootp, tftpboot, rarpboot CONFIG_CMD_NFS NFS support - CONFIG_CMD_PCA953X * PCA953x I2C gpio commands CONFIG_CMD_PCA953X_INFO * PCA953x I2C gpio info command CONFIG_CMD_PCI * pciinfo CONFIG_CMD_PCMCIA * PCMCIA support diff --git a/arch/powerpc/cpu/mpc83xx/Kconfig b/arch/powerpc/cpu/mpc83xx/Kconfig index b5b26f9b3a..c66d6616a4 100644 --- a/arch/powerpc/cpu/mpc83xx/Kconfig +++ b/arch/powerpc/cpu/mpc83xx/Kconfig @@ -96,6 +96,7 @@ config TARGET_STRIDER bool "Support strider" select SYS_FSL_ERRATUM_ESDHC111 imply ENV_IS_IN_FLASH + imply CMD_PCA953X
endchoice
diff --git a/configs/cl-som-am57x_defconfig b/configs/cl-som-am57x_defconfig index 0d1f614163..e0b7565ac0 100644 --- a/configs/cl-som-am57x_defconfig +++ b/configs/cl-som-am57x_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y +CONFIG_CMD_PCA953X=y CONFIG_LED_STATUS=y CONFIG_LED_STATUS_GPIO=y CONFIG_LED_STATUS0=y diff --git a/configs/cm_t335_defconfig b/configs/cm_t335_defconfig index 7e411a961a..92a53278cc 100644 --- a/configs/cm_t335_defconfig +++ b/configs/cm_t335_defconfig @@ -45,6 +45,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_MTDPARTS=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y +CONFIG_CMD_PCA953X=y CONFIG_LED_STATUS=y CONFIG_LED_STATUS_GPIO=y CONFIG_LED_STATUS0=y diff --git a/configs/ot1200_defconfig b/configs/ot1200_defconfig index 3ae27da0d4..8605111ee1 100644 --- a/configs/ot1200_defconfig +++ b/configs/ot1200_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_DM=y +CONFIG_CMD_PCA953X=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/ot1200_spl_defconfig b/configs/ot1200_spl_defconfig index 50be46849e..707eea06c5 100644 --- a/configs/ot1200_spl_defconfig +++ b/configs/ot1200_spl_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_DM=y +CONFIG_CMD_PCA953X=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/snapper9260_defconfig b/configs/snapper9260_defconfig index 0c78b4717f..2e86f954c8 100644 --- a/configs/snapper9260_defconfig +++ b/configs/snapper9260_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_CMD_PCA953X=y # CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/snapper9g20_defconfig b/configs/snapper9g20_defconfig index f524a66fa3..e2b58419f2 100644 --- a/configs/snapper9g20_defconfig +++ b/configs/snapper9g20_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_CMD_PCA953X=y # CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/xilinx_zynqmp_zcu102_revA_defconfig b/configs/xilinx_zynqmp_zcu102_revA_defconfig index 0ef0ba5341..b58460ae3a 100644 --- a/configs/xilinx_zynqmp_zcu102_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revA_defconfig @@ -45,6 +45,7 @@ CONFIG_DFU_RAM=y CONFIG_FPGA_XILINX=y CONFIG_FPGA_ZYNQMPPL=y CONFIG_DM_GPIO=y +CONFIG_CMD_PCA953X=y CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index 87be093cc2..0e1c841ea5 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -45,6 +45,7 @@ CONFIG_DFU_RAM=y CONFIG_FPGA_XILINX=y CONFIG_FPGA_ZYNQMPPL=y CONFIG_DM_GPIO=y +CONFIG_CMD_PCA953X=y CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y diff --git a/configs/xpedite517x_defconfig b/configs/xpedite517x_defconfig index aff3bf0640..47fac0052e 100644 --- a/configs/xpedite517x_defconfig +++ b/configs/xpedite517x_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_SNTP=y CONFIG_CMD_DATE=y CONFIG_CMD_JFFS2=y CONFIG_CMD_IRQ=y +CONFIG_CMD_PCA953X=y CONFIG_DS4510=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/xpedite520x_defconfig b/configs/xpedite520x_defconfig index 0a705f80b7..4192269147 100644 --- a/configs/xpedite520x_defconfig +++ b/configs/xpedite520x_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_JFFS2=y # CONFIG_CMD_IRQ is not set +CONFIG_CMD_PCA953X=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y diff --git a/configs/xpedite537x_defconfig b/configs/xpedite537x_defconfig index 45fe128a55..90a00d9e17 100644 --- a/configs/xpedite537x_defconfig +++ b/configs/xpedite537x_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_DATE=y CONFIG_CMD_JFFS2=y # CONFIG_CMD_IRQ is not set CONFIG_SYS_FSL_DDR2=y +CONFIG_CMD_PCA953X=y CONFIG_DS4510=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/xpedite550x_defconfig b/configs/xpedite550x_defconfig index 63ce8b2393..796a805242 100644 --- a/configs/xpedite550x_defconfig +++ b/configs/xpedite550x_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_JFFS2=y # CONFIG_CMD_IRQ is not set +CONFIG_CMD_PCA953X=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index 63951e0dbe..d2e7c29e1d 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -109,6 +109,15 @@ config OMAP_GPIO Support GPIO controllers on the TI OMAP3/4/5 and related (such as AM335x/AM43xx/AM57xx/DRA7xx/etc) families of SoCs.
+config CMD_PCA953X + bool "Enable the pca953x command" + help + Deprecated: This should be converted to driver model. + + This command provides access to a pca953x GPIO device using the + legacy GPIO interface. Several subcommands are provided which mirror + the standard 'gpio' command. It should use that instead. + config PM8916_GPIO bool "Qualcomm PM8916 PMIC GPIO/keypad driver" depends on DM_GPIO && PMIC_PM8916 diff --git a/include/configs/cl-som-am57x.h b/include/configs/cl-som-am57x.h index 120ac02e06..8f3721cbfc 100644 --- a/include/configs/cl-som-am57x.h +++ b/include/configs/cl-som-am57x.h @@ -74,7 +74,6 @@ CONFIG_SYS_SCSI_MAX_LUN) /* PCA9555 GPIO expander support */ #define CONFIG_PCA953X -#define CONFIG_CMD_PCA953X #define CONFIG_CMD_PCA953X_INFO #define CONFIG_SYS_I2C_PCA953X_ADDR 0x20 #define CONFIG_SYS_I2C_PCA953X_WIDTH { {0x20, 16} } diff --git a/include/configs/cm_t335.h b/include/configs/cm_t335.h index ed7bb1d21c..7331d4fe1f 100644 --- a/include/configs/cm_t335.h +++ b/include/configs/cm_t335.h @@ -163,7 +163,6 @@ * First select the I2C0 bus with "i2c dev 0", then use "pca953x" command. */ #define CONFIG_PCA953X -#define CONFIG_CMD_PCA953X #define CONFIG_CMD_PCA953X_INFO #define CONFIG_SYS_I2C_PCA953X_ADDR 0x26 #define CONFIG_SYS_I2C_PCA953X_WIDTH { {0x26, 16} } diff --git a/include/configs/ot1200.h b/include/configs/ot1200.h index 373c2d5ca2..1287282270 100644 --- a/include/configs/ot1200.h +++ b/include/configs/ot1200.h @@ -31,7 +31,6 @@ #define CONFIG_PCA953X #define CONFIG_SYS_I2C_PCA953X_ADDR 0x20 #define CONFIG_SYS_I2C_PCA953X_WIDTH { {0x20, 16} } -#define CONFIG_CMD_PCA953X #define CONFIG_CMD_PCA953X_INFO
/* I2C Configs */ diff --git a/include/configs/snapper9260.h b/include/configs/snapper9260.h index 5ec8c1b695..8ff0fa3412 100644 --- a/include/configs/snapper9260.h +++ b/include/configs/snapper9260.h @@ -137,7 +137,6 @@ #define CONFIG_SYS_MALLOC_LEN (1 << 20)
/* Command line configuration */ -#define CONFIG_CMD_PCA953X #define CONFIG_CMD_PCA953X_INFO
#endif /* __CONFIG_H */ diff --git a/include/configs/strider.h b/include/configs/strider.h index a702ec71da..507a41462b 100644 --- a/include/configs/strider.h +++ b/include/configs/strider.h @@ -301,7 +301,6 @@ #define CONFIG_SYS_FSL_I2C_OFFSET 0x3000
#define CONFIG_PCA953X /* NXP PCA9554 */ -#define CONFIG_CMD_PCA953X #define CONFIG_CMD_PCA953X_INFO #define CONFIG_SYS_I2C_PCA953X_WIDTH { {0x24, 16}, {0x25, 16}, {0x26, 16}, \ {0x3c, 8}, {0x3d, 8}, {0x3e, 8} } diff --git a/include/configs/xilinx_zynqmp_zcu102.h b/include/configs/xilinx_zynqmp_zcu102.h index 4194b66c66..52278f1885 100644 --- a/include/configs/xilinx_zynqmp_zcu102.h +++ b/include/configs/xilinx_zynqmp_zcu102.h @@ -38,7 +38,6 @@
#define CONFIG_SYS_I2C_ZYNQ #define CONFIG_PCA953X -#define CONFIG_CMD_PCA953X #define CONFIG_CMD_PCA953X_INFO
#define CONFIG_ZYNQMP_XHCI_LIST {ZYNQMP_USB0_XHCI_BASEADDR} diff --git a/include/configs/xpedite517x.h b/include/configs/xpedite517x.h index c21c944b29..c27433787f 100644 --- a/include/configs/xpedite517x.h +++ b/include/configs/xpedite517x.h @@ -484,7 +484,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); /* * Command configuration. */ -#define CONFIG_CMD_PCA953X #define CONFIG_CMD_PCA953X_INFO #define CONFIG_CMD_PCI #define CONFIG_CMD_PCI_ENUM diff --git a/include/configs/xpedite520x.h b/include/configs/xpedite520x.h index eb801542eb..fa8f1d89f5 100644 --- a/include/configs/xpedite520x.h +++ b/include/configs/xpedite520x.h @@ -287,7 +287,6 @@ /* * Command configuration. */ -#define CONFIG_CMD_PCA953X #define CONFIG_CMD_PCA953X_INFO #define CONFIG_CMD_PCI #define CONFIG_CMD_PCI_ENUM diff --git a/include/configs/xpedite537x.h b/include/configs/xpedite537x.h index bc423136ba..2a35bf0972 100644 --- a/include/configs/xpedite537x.h +++ b/include/configs/xpedite537x.h @@ -337,7 +337,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); /* * Command configuration. */ -#define CONFIG_CMD_PCA953X #define CONFIG_CMD_PCA953X_INFO #define CONFIG_CMD_PCI #define CONFIG_CMD_PCI_ENUM diff --git a/include/configs/xpedite550x.h b/include/configs/xpedite550x.h index 13be539db3..c31f83d2e1 100644 --- a/include/configs/xpedite550x.h +++ b/include/configs/xpedite550x.h @@ -336,7 +336,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); /* * Command configuration. */ -#define CONFIG_CMD_PCA953X #define CONFIG_CMD_PCA953X_INFO #define CONFIG_CMD_PCI #define CONFIG_CMD_PCI_ENUM diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 67ad3b846c..8993ee89fb 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_PCA953X CONFIG_CMD_PCA953X_INFO CONFIG_CMD_PCI CONFIG_CMD_PCI_ENUM
Changes in v2: None
It does not seem worth having an option to enable another sub-command in this legacy driver. Drop this option so that the sub-command is always available.
Changes in v2: None
README | 1 - drivers/gpio/pca953x.c | 8 -------- include/configs/cl-som-am57x.h | 1 - include/configs/cm_t335.h | 1 - include/configs/ot1200.h | 1 - include/configs/snapper9260.h | 3 --- include/configs/strider.h | 1 - include/configs/xilinx_zynqmp_zcu102.h | 1 - include/configs/xpedite517x.h | 1 - include/configs/xpedite520x.h | 1 - include/configs/xpedite537x.h | 1 - include/configs/xpedite550x.h | 1 - scripts/config_whitelist.txt | 1 - 13 files changed, 22 deletions(-)
diff --git a/README b/README index 5f916c8d8e..addbf306f1 100644 --- a/README +++ b/README @@ -812,7 +812,6 @@ The following options need to be configured: CONFIG_CMD_MII * MII utility commands CONFIG_CMD_NET bootp, tftpboot, rarpboot CONFIG_CMD_NFS NFS support - CONFIG_CMD_PCA953X_INFO * PCA953x I2C gpio info command CONFIG_CMD_PCI * pciinfo CONFIG_CMD_PCMCIA * PCMCIA support CONFIG_CMD_PING * send ICMP ECHO_REQUEST to network diff --git a/drivers/gpio/pca953x.c b/drivers/gpio/pca953x.c index 238e02805c..d1c1ae1411 100644 --- a/drivers/gpio/pca953x.c +++ b/drivers/gpio/pca953x.c @@ -143,7 +143,6 @@ int pca953x_get_val(uint8_t chip) }
#ifdef CONFIG_CMD_PCA953X -#ifdef CONFIG_CMD_PCA953X_INFO /* * Display pca953x information */ @@ -193,16 +192,13 @@ static int pca953x_info(uint8_t chip)
return 0; } -#endif /* CONFIG_CMD_PCA953X_INFO */
cmd_tbl_t cmd_pca953x[] = { U_BOOT_CMD_MKENT(device, 3, 0, (void *)PCA953X_CMD_DEVICE, "", ""), U_BOOT_CMD_MKENT(output, 4, 0, (void *)PCA953X_CMD_OUTPUT, "", ""), U_BOOT_CMD_MKENT(input, 3, 0, (void *)PCA953X_CMD_INPUT, "", ""), U_BOOT_CMD_MKENT(invert, 4, 0, (void *)PCA953X_CMD_INVERT, "", ""), -#ifdef CONFIG_CMD_PCA953X_INFO U_BOOT_CMD_MKENT(info, 2, 0, (void *)PCA953X_CMD_INFO, "", ""), -#endif };
int do_pca953x(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) @@ -231,13 +227,11 @@ int do_pca953x(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) ul_arg3 = simple_strtoul(argv[3], NULL, 16) & 0x1;
switch ((long)c->cmd) { -#ifdef CONFIG_CMD_PCA953X_INFO case PCA953X_CMD_INFO: ret = pca953x_info(chip); if (ret) ret = CMD_RET_FAILURE; break; -#endif
case PCA953X_CMD_DEVICE: if (argc == 3) @@ -287,10 +281,8 @@ U_BOOT_CMD( "pca953x gpio access", "device [dev]\n" " - show or set current device address\n" -#ifdef CONFIG_CMD_PCA953X_INFO "pca953x info\n" " - display info for current chip\n" -#endif "pca953x output pin 0|1\n" " - set pin as output and drive low or high\n" "pca953x invert pin 0|1\n" diff --git a/include/configs/cl-som-am57x.h b/include/configs/cl-som-am57x.h index 8f3721cbfc..b9d6454887 100644 --- a/include/configs/cl-som-am57x.h +++ b/include/configs/cl-som-am57x.h @@ -74,7 +74,6 @@ CONFIG_SYS_SCSI_MAX_LUN) /* PCA9555 GPIO expander support */ #define CONFIG_PCA953X -#define CONFIG_CMD_PCA953X_INFO #define CONFIG_SYS_I2C_PCA953X_ADDR 0x20 #define CONFIG_SYS_I2C_PCA953X_WIDTH { {0x20, 16} }
diff --git a/include/configs/cm_t335.h b/include/configs/cm_t335.h index 7331d4fe1f..bc52aae251 100644 --- a/include/configs/cm_t335.h +++ b/include/configs/cm_t335.h @@ -163,7 +163,6 @@ * First select the I2C0 bus with "i2c dev 0", then use "pca953x" command. */ #define CONFIG_PCA953X -#define CONFIG_CMD_PCA953X_INFO #define CONFIG_SYS_I2C_PCA953X_ADDR 0x26 #define CONFIG_SYS_I2C_PCA953X_WIDTH { {0x26, 16} } #endif /* CONFIG_SPL_BUILD */ diff --git a/include/configs/ot1200.h b/include/configs/ot1200.h index 1287282270..8a1a49653c 100644 --- a/include/configs/ot1200.h +++ b/include/configs/ot1200.h @@ -31,7 +31,6 @@ #define CONFIG_PCA953X #define CONFIG_SYS_I2C_PCA953X_ADDR 0x20 #define CONFIG_SYS_I2C_PCA953X_WIDTH { {0x20, 16} } -#define CONFIG_CMD_PCA953X_INFO
/* I2C Configs */ #define CONFIG_SYS_I2C diff --git a/include/configs/snapper9260.h b/include/configs/snapper9260.h index 8ff0fa3412..e7828a5036 100644 --- a/include/configs/snapper9260.h +++ b/include/configs/snapper9260.h @@ -136,7 +136,4 @@ /* U-Boot memory settings */ #define CONFIG_SYS_MALLOC_LEN (1 << 20)
-/* Command line configuration */ -#define CONFIG_CMD_PCA953X_INFO - #endif /* __CONFIG_H */ diff --git a/include/configs/strider.h b/include/configs/strider.h index 507a41462b..aa7f15389c 100644 --- a/include/configs/strider.h +++ b/include/configs/strider.h @@ -301,7 +301,6 @@ #define CONFIG_SYS_FSL_I2C_OFFSET 0x3000
#define CONFIG_PCA953X /* NXP PCA9554 */ -#define CONFIG_CMD_PCA953X_INFO #define CONFIG_SYS_I2C_PCA953X_WIDTH { {0x24, 16}, {0x25, 16}, {0x26, 16}, \ {0x3c, 8}, {0x3d, 8}, {0x3e, 8} }
diff --git a/include/configs/xilinx_zynqmp_zcu102.h b/include/configs/xilinx_zynqmp_zcu102.h index 52278f1885..85f78ba43b 100644 --- a/include/configs/xilinx_zynqmp_zcu102.h +++ b/include/configs/xilinx_zynqmp_zcu102.h @@ -38,7 +38,6 @@
#define CONFIG_SYS_I2C_ZYNQ #define CONFIG_PCA953X -#define CONFIG_CMD_PCA953X_INFO
diff --git a/include/configs/xpedite517x.h b/include/configs/xpedite517x.h index c27433787f..fe1c14b7ee 100644 --- a/include/configs/xpedite517x.h +++ b/include/configs/xpedite517x.h @@ -484,7 +484,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); /* * Command configuration. */ -#define CONFIG_CMD_PCA953X_INFO #define CONFIG_CMD_PCI #define CONFIG_CMD_PCI_ENUM #define CONFIG_CMD_REGINFO diff --git a/include/configs/xpedite520x.h b/include/configs/xpedite520x.h index fa8f1d89f5..8a7cf7f711 100644 --- a/include/configs/xpedite520x.h +++ b/include/configs/xpedite520x.h @@ -287,7 +287,6 @@ /* * Command configuration. */ -#define CONFIG_CMD_PCA953X_INFO #define CONFIG_CMD_PCI #define CONFIG_CMD_PCI_ENUM #define CONFIG_CMD_REGINFO diff --git a/include/configs/xpedite537x.h b/include/configs/xpedite537x.h index 2a35bf0972..5d59bfe28b 100644 --- a/include/configs/xpedite537x.h +++ b/include/configs/xpedite537x.h @@ -337,7 +337,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); /* * Command configuration. */ -#define CONFIG_CMD_PCA953X_INFO #define CONFIG_CMD_PCI #define CONFIG_CMD_PCI_ENUM #define CONFIG_CMD_REGINFO diff --git a/include/configs/xpedite550x.h b/include/configs/xpedite550x.h index c31f83d2e1..6bf7dc3e67 100644 --- a/include/configs/xpedite550x.h +++ b/include/configs/xpedite550x.h @@ -336,7 +336,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); /* * Command configuration. */ -#define CONFIG_CMD_PCA953X_INFO #define CONFIG_CMD_PCI #define CONFIG_CMD_PCI_ENUM #define CONFIG_CMD_REGINFO diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 8993ee89fb..2f1d669114 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_PCA953X_INFO CONFIG_CMD_PCI CONFIG_CMD_PCI_ENUM CONFIG_CMD_PCMCIA
Changes in v2: None
This converts the following to Kconfig: CONFIG_CMD_PCI
Changes in v2: - Fix indentation for CMD_PCI - Sort Kconfig options in alphabetical order
README | 1 - arch/arm/cpu/armv7/ls102xa/Kconfig | 1 + arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 1 + arch/powerpc/cpu/mpc85xx/Kconfig | 6 ++++++ cmd/Kconfig | 8 ++++++++ configs/M5235EVB_Flash32_defconfig | 1 + configs/M5235EVB_defconfig | 1 + configs/M5475AFE_defconfig | 1 + configs/M5475BFE_defconfig | 1 + configs/M5475CFE_defconfig | 1 + configs/M5475DFE_defconfig | 1 + configs/M5475EFE_defconfig | 1 + configs/M5475FFE_defconfig | 1 + configs/M5475GFE_defconfig | 1 + configs/M5485AFE_defconfig | 1 + configs/M5485BFE_defconfig | 1 + configs/M5485CFE_defconfig | 1 + configs/M5485DFE_defconfig | 1 + configs/M5485EFE_defconfig | 1 + configs/M5485FFE_defconfig | 1 + configs/M5485GFE_defconfig | 1 + configs/M5485HFE_defconfig | 1 + configs/MPC8308RDB_defconfig | 1 + configs/MPC8313ERDB_33_defconfig | 1 + configs/MPC8313ERDB_66_defconfig | 1 + configs/MPC8313ERDB_NAND_33_defconfig | 1 + configs/MPC8313ERDB_NAND_66_defconfig | 1 + configs/MPC8315ERDB_defconfig | 1 + configs/MPC8323ERDB_defconfig | 1 + configs/MPC832XEMDS_HOST_33_defconfig | 1 + configs/MPC832XEMDS_HOST_66_defconfig | 1 + configs/MPC832XEMDS_SLAVE_defconfig | 1 + configs/MPC8349ITXGP_defconfig | 1 + configs/MPC8349ITX_LOWBOOT_defconfig | 1 + configs/MPC8349ITX_defconfig | 1 + configs/MPC837XEMDS_HOST_defconfig | 1 + configs/MPC837XERDB_defconfig | 1 + configs/MPC8536DS_36BIT_defconfig | 1 + configs/MPC8536DS_SDCARD_defconfig | 1 + configs/MPC8536DS_SPIFLASH_defconfig | 1 + configs/MPC8536DS_defconfig | 1 + configs/MPC8541CDS_defconfig | 1 + configs/MPC8541CDS_legacy_defconfig | 1 + configs/MPC8544DS_defconfig | 1 + configs/MPC8548CDS_36BIT_defconfig | 1 + configs/MPC8548CDS_defconfig | 1 + configs/MPC8548CDS_legacy_defconfig | 1 + configs/MPC8555CDS_defconfig | 1 + configs/MPC8555CDS_legacy_defconfig | 1 + configs/MPC8568MDS_defconfig | 1 + configs/MPC8569MDS_ATM_defconfig | 1 + configs/MPC8569MDS_defconfig | 1 + configs/MPC8572DS_36BIT_defconfig | 1 + configs/MPC8572DS_defconfig | 1 + configs/MPC8610HPCD_defconfig | 1 + configs/MPC8641HPCN_36BIT_defconfig | 1 + configs/MPC8641HPCN_defconfig | 1 + configs/P1021RDB-PC_36BIT_NAND_defconfig | 1 + configs/P1021RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1021RDB-PC_36BIT_defconfig | 1 + configs/P1021RDB-PC_NAND_defconfig | 1 + configs/P1021RDB-PC_SDCARD_defconfig | 1 + configs/P1021RDB-PC_SPIFLASH_defconfig | 1 + configs/P1021RDB-PC_defconfig | 1 + configs/P1022DS_36BIT_NAND_defconfig | 1 + configs/P1022DS_36BIT_SDCARD_defconfig | 1 + configs/P1022DS_36BIT_SPIFLASH_defconfig | 1 + configs/P1022DS_36BIT_defconfig | 1 + configs/P1022DS_NAND_defconfig | 1 + configs/P1022DS_SDCARD_defconfig | 1 + configs/P1022DS_SPIFLASH_defconfig | 1 + configs/P1022DS_defconfig | 1 + configs/P1023RDB_defconfig | 1 + configs/P1025RDB_36BIT_defconfig | 1 + configs/P1025RDB_NAND_defconfig | 1 + configs/P1025RDB_SDCARD_defconfig | 1 + configs/P1025RDB_SPIFLASH_defconfig | 1 + configs/P1025RDB_defconfig | 1 + configs/P2020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_36BIT_defconfig | 1 + configs/P2020RDB-PC_NAND_defconfig | 1 + configs/P2020RDB-PC_SDCARD_defconfig | 1 + configs/P2020RDB-PC_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_defconfig | 1 + configs/TQM834x_defconfig | 1 + configs/TWR-P1025_defconfig | 1 + configs/apalis-tk1_defconfig | 1 + configs/apalis_t30_defconfig | 1 + configs/bayleybay_defconfig | 1 + configs/beaver_defconfig | 1 + configs/boston32r2_defconfig | 1 + configs/boston32r2el_defconfig | 1 + configs/boston64r2_defconfig | 1 + configs/boston64r2el_defconfig | 1 + configs/caddy2_defconfig | 1 + configs/cardhu_defconfig | 1 + configs/cei-tk1-som_defconfig | 1 + configs/chromebook_link64_defconfig | 1 + configs/chromebook_link_defconfig | 1 + configs/chromebook_samus_defconfig | 1 + configs/chromebox_panther_defconfig | 1 + configs/clearfog_defconfig | 1 + configs/conga-qeval20-qa3-e3845-internal-uart_defconfig | 1 + configs/conga-qeval20-qa3-e3845_defconfig | 1 + configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig | 1 + configs/controlcenterd_36BIT_SDCARD_defconfig | 1 + configs/controlcenterdc_defconfig | 1 + configs/coreboot-x86_defconfig | 1 + configs/cougarcanyon2_defconfig | 1 + configs/crownbay_defconfig | 1 + configs/db-88f6820-amc_defconfig | 1 + configs/db-88f6820-gp_defconfig | 1 + configs/db-mv784mp-gp_defconfig | 1 + configs/dfi-bt700-q7x-151_defconfig | 1 + configs/ds414_defconfig | 1 + configs/efi-x86_defconfig | 1 + configs/galileo_defconfig | 1 + configs/gwventana_emmc_defconfig | 1 + configs/gwventana_gw5904_defconfig | 1 + configs/gwventana_nand_defconfig | 1 + configs/hrcon_defconfig | 1 + configs/hrcon_dh_defconfig | 1 + configs/integratorap_cm720t_defconfig | 1 + configs/integratorap_cm920t_defconfig | 1 + configs/integratorap_cm926ejs_defconfig | 1 + configs/integratorap_cm946es_defconfig | 1 + configs/jetson-tk1_defconfig | 1 + configs/ls1012aqds_qspi_defconfig | 1 + configs/ls1012ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1012ardb_qspi_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 2 +- configs/ls1046aqds_SECURE_BOOT_defconfig | 3 ++- configs/ls1046aqds_defconfig | 3 ++- configs/ls1046aqds_nand_defconfig | 3 ++- configs/ls1046aqds_qspi_defconfig | 3 ++- configs/ls1046aqds_sdcard_ifc_defconfig | 3 ++- configs/ls1046aqds_sdcard_qspi_defconfig | 3 ++- configs/ls1046ardb_emmc_defconfig | 3 ++- configs/ls1046ardb_qspi_SECURE_BOOT_defconfig | 3 ++- configs/ls1046ardb_qspi_defconfig | 3 ++- configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig | 3 ++- configs/ls1046ardb_sdcard_defconfig | 3 ++- configs/ls2080aqds_SECURE_BOOT_defconfig | 1 + configs/ls2080aqds_defconfig | 1 + configs/ls2080aqds_nand_defconfig | 1 + configs/ls2080aqds_qspi_defconfig | 1 + configs/ls2080aqds_sdcard_defconfig | 1 + configs/ls2080ardb_SECURE_BOOT_defconfig | 1 + configs/ls2080ardb_defconfig | 1 + configs/ls2080ardb_nand_defconfig | 1 + configs/ls2081ardb_defconfig | 1 + configs/ls2088ardb_qspi_defconfig | 1 + configs/malta64_defconfig | 1 + configs/malta64el_defconfig | 1 + configs/malta_defconfig | 1 + configs/maltael_defconfig | 1 + configs/minnowmax_defconfig | 1 + configs/mpc8308_p1m_defconfig | 1 + configs/mvebu_db_armada8k_defconfig | 1 + configs/mvebu_mcbin-88f8040_defconfig | 1 + configs/mx6sabresd_defconfig | 1 + configs/mx6sxsabresd_defconfig | 1 + configs/mx6sxsabresd_spl_defconfig | 1 + configs/novena_defconfig | 1 + configs/p2371-2180_defconfig | 1 + configs/p2771-0000-000_defconfig | 1 + configs/p2771-0000-500_defconfig | 1 + configs/qemu-ppce500_defconfig | 1 + configs/qemu-x86_64_defconfig | 1 + configs/qemu-x86_defconfig | 1 + configs/qemu-x86_efi_payload32_defconfig | 1 + configs/qemu-x86_efi_payload64_defconfig | 1 + configs/r2dplus_defconfig | 1 + configs/r7780mp_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/sandbox_flattree_defconfig | 1 + configs/sandbox_noblk_defconfig | 1 + configs/sandbox_spl_defconfig | 1 + configs/sbc8349_PCI_33_defconfig | 1 + configs/sbc8349_PCI_66_defconfig | 1 + configs/sbc8548_PCI_33_PCIE_defconfig | 1 + configs/sbc8548_PCI_33_defconfig | 1 + configs/sbc8548_PCI_66_PCIE_defconfig | 1 + configs/sbc8548_PCI_66_defconfig | 1 + configs/sbc8641d_defconfig | 1 + configs/sh7785lcr_32bit_defconfig | 1 + configs/sh7785lcr_defconfig | 1 + configs/socrates_defconfig | 1 + configs/som-db5800-som-6867_defconfig | 1 + configs/strider_con_defconfig | 1 + configs/strider_con_dp_defconfig | 1 + configs/strider_cpu_defconfig | 1 + configs/strider_cpu_dp_defconfig | 1 + configs/tbs2910_defconfig | 1 + configs/theadorable-x86-dfi-bt700_defconfig | 1 + configs/theadorable_debug_defconfig | 1 + configs/trimslice_defconfig | 1 + configs/turris_omnia_defconfig | 1 + configs/ve8313_defconfig | 1 + configs/vining_2000_defconfig | 1 + configs/vme8349_defconfig | 1 + configs/xpedite517x_defconfig | 1 + configs/xpedite520x_defconfig | 1 + configs/xpedite537x_defconfig | 1 + configs/xpedite550x_defconfig | 1 + configs/zc5202_defconfig | 1 + include/config_cmd_all.h | 1 - include/configs/B4860QDS.h | 4 ---- include/configs/BSC9132QDS.h | 2 -- include/configs/C29XPCIE.h | 2 -- include/configs/M5235EVB.h | 3 --- include/configs/M54455EVB.h | 3 --- include/configs/M5475EVB.h | 6 ------ include/configs/M5485EVB.h | 6 ------ include/configs/MPC8308RDB.h | 1 - include/configs/MPC8313ERDB.h | 1 - include/configs/MPC8315ERDB.h | 1 - include/configs/MPC8323ERDB.h | 4 ---- include/configs/MPC832XEMDS.h | 4 ---- include/configs/MPC8349EMDS.h | 4 ---- include/configs/MPC8349ITX.h | 4 ---- include/configs/MPC837XEMDS.h | 4 ---- include/configs/MPC837XERDB.h | 4 ---- include/configs/MPC8536DS.h | 4 ---- include/configs/MPC8540ADS.h | 4 ---- include/configs/MPC8541CDS.h | 4 ---- include/configs/MPC8544DS.h | 4 ---- include/configs/MPC8548CDS.h | 4 ---- include/configs/MPC8555CDS.h | 4 ---- include/configs/MPC8560ADS.h | 4 ---- include/configs/MPC8568MDS.h | 4 ---- include/configs/MPC8569MDS.h | 4 ---- include/configs/MPC8572DS.h | 4 ---- include/configs/MPC8610HPCD.h | 4 ---- include/configs/MPC8641HPCN.h | 4 ---- include/configs/P1010RDB.h | 2 -- include/configs/P1022DS.h | 4 ---- include/configs/P1023RDB.h | 4 ---- include/configs/P2041RDB.h | 4 ---- include/configs/T102xQDS.h | 4 ---- include/configs/T102xRDB.h | 4 ---- include/configs/T1040QDS.h | 4 ---- include/configs/T104xRDB.h | 4 ---- include/configs/T208xQDS.h | 4 ---- include/configs/T208xRDB.h | 4 ---- include/configs/T4240RDB.h | 4 ---- include/configs/TQM834x.h | 7 ------- include/configs/UCP1020.h | 2 -- include/configs/advantech_dms-ba16.h | 1 - include/configs/apalis-tk1.h | 1 - include/configs/apalis_t30.h | 1 - include/configs/beaver.h | 1 - include/configs/boston.h | 1 - include/configs/cardhu.h | 1 - include/configs/cei-tk1-som.h | 1 - include/configs/clearfog.h | 1 - include/configs/controlcenterd.h | 1 - include/configs/controlcenterdc.h | 1 - include/configs/corenet_ds.h | 4 ---- include/configs/cyrus.h | 4 ---- include/configs/db-88f6820-amc.h | 1 - include/configs/db-88f6820-gp.h | 1 - include/configs/db-mv784mp-gp.h | 5 ----- include/configs/ds414.h | 1 - include/configs/ge_bx50v3.h | 1 - include/configs/gw_ventana.h | 1 - include/configs/hrcon.h | 1 - include/configs/integratorap.h | 2 -- include/configs/jetson-tk1.h | 1 - include/configs/km/km83xx-common.h | 4 ---- include/configs/km/kmp204x-common.h | 1 - include/configs/ls1012aqds.h | 1 - include/configs/ls1012ardb.h | 1 - include/configs/ls1021aiot.h | 1 - include/configs/ls1021aqds.h | 1 - include/configs/ls1021atwr.h | 1 - include/configs/ls1043a_common.h | 1 - include/configs/ls1046a_common.h | 1 - include/configs/ls2080aqds.h | 1 - include/configs/ls2080ardb.h | 1 - include/configs/malta.h | 1 - include/configs/mpc8308_p1m.h | 1 - include/configs/mvebu_armada-8k.h | 1 - include/configs/mx6sabresd.h | 1 - include/configs/mx6sxsabresd.h | 1 - include/configs/novena.h | 1 - include/configs/p1_p2_rdb_pc.h | 2 -- include/configs/p1_twr.h | 2 -- include/configs/p2371-2180.h | 1 - include/configs/p2771-0000.h | 1 - include/configs/qemu-ppce500.h | 4 ---- include/configs/r2dplus.h | 1 - include/configs/r7780mp.h | 1 - include/configs/sandbox.h | 2 -- include/configs/sbc8349.h | 4 ---- include/configs/sbc8548.h | 4 ---- include/configs/sbc8641d.h | 4 ---- include/configs/sh7785lcr.h | 1 - include/configs/socrates.h | 4 ---- include/configs/strider.h | 1 - include/configs/t4qds.h | 4 ---- include/configs/tbs2910.h | 1 - include/configs/theadorable.h | 3 --- include/configs/trimslice.h | 1 - include/configs/turris_omnia.h | 1 - include/configs/ve8313.h | 1 - include/configs/vining_2000.h | 1 - include/configs/vme8349.h | 4 ---- include/configs/x86-common.h | 1 - include/configs/xpedite517x.h | 1 - include/configs/xpedite520x.h | 1 - include/configs/xpedite537x.h | 1 - include/configs/xpedite550x.h | 1 - include/configs/zc5202.h | 1 - scripts/config_whitelist.txt | 1 - 318 files changed, 231 insertions(+), 273 deletions(-)
diff --git a/README b/README index addbf306f1..63dd18ce10 100644 --- a/README +++ b/README @@ -812,7 +812,6 @@ The following options need to be configured: CONFIG_CMD_MII * MII utility commands CONFIG_CMD_NET bootp, tftpboot, rarpboot CONFIG_CMD_NFS NFS support - CONFIG_CMD_PCI * pciinfo CONFIG_CMD_PCMCIA * PCMCIA support CONFIG_CMD_PING * send ICMP ECHO_REQUEST to network host diff --git a/arch/arm/cpu/armv7/ls102xa/Kconfig b/arch/arm/cpu/armv7/ls102xa/Kconfig index 6a013b2183..fadfce4f05 100644 --- a/arch/arm/cpu/armv7/ls102xa/Kconfig +++ b/arch/arm/cpu/armv7/ls102xa/Kconfig @@ -15,6 +15,7 @@ config ARCH_LS1021A select SYS_FSL_SEC_COMPAT_5 select SYS_FSL_SEC_LE imply SCSI + imply CMD_PCI
menu "LS102xA architecture" depends on ARCH_LS1021A diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 5825f9b726..0ab138b707 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -27,6 +27,7 @@ config ARCH_LS1043A select ARCH_EARLY_INIT_R select BOARD_EARLY_INIT_F imply SCSI + imply CMD_PCI
config ARCH_LS1046A bool diff --git a/arch/powerpc/cpu/mpc85xx/Kconfig b/arch/powerpc/cpu/mpc85xx/Kconfig index 93a454cf1f..22fd306bfc 100644 --- a/arch/powerpc/cpu/mpc85xx/Kconfig +++ b/arch/powerpc/cpu/mpc85xx/Kconfig @@ -489,6 +489,7 @@ config ARCH_BSC9132 imply CMD_EEPROM imply CMD_MTDPARTS imply CMD_NAND + imply CMD_PCI
config ARCH_C29X bool @@ -503,6 +504,7 @@ config ARCH_C29X select SYS_PPC_E500_USE_DEBUG_TLB select FSL_IFC imply CMD_NAND + imply CMD_PCI
config ARCH_MPC8536 bool @@ -633,6 +635,7 @@ config ARCH_P1010 imply CMD_MTDPARTS imply CMD_NAND imply CMD_SATA + imply CMD_PCI
config ARCH_P1011 bool @@ -663,6 +666,7 @@ config ARCH_P1020 select FSL_ELBC imply CMD_NAND imply CMD_SATA + imply CMD_PCI
config ARCH_P1021 bool @@ -724,6 +728,7 @@ config ARCH_P1024 imply CMD_EEPROM imply CMD_NAND imply CMD_SATA + imply CMD_PCI
config ARCH_P1025 bool @@ -1076,6 +1081,7 @@ config E500
config E500MC bool + imply CMD_PCI help Enble PowerPC E500MC core
diff --git a/cmd/Kconfig b/cmd/Kconfig index cbe4744272..6654050574 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -725,6 +725,14 @@ config CMD_PART Read and display information about the partition table on various media.
+config CMD_PCI + bool "pci - Access PCI devices" + help + Provide access to PCI (Peripheral Interconnect Bus), a type of bus + used on some devices to allow the CPU to communicate with its + peripherals. Sub-commands allow bus enumeration, displaying and + changing configuration space and a few other features. + config CMD_REMOTEPROC bool "remoteproc" depends on REMOTEPROC diff --git a/configs/M5235EVB_Flash32_defconfig b/configs/M5235EVB_Flash32_defconfig index ee8ba643b2..8e4d2c837f 100644 --- a/configs/M5235EVB_Flash32_defconfig +++ b/configs/M5235EVB_Flash32_defconfig @@ -8,6 +8,7 @@ CONFIG_BOOTDELAY=1 # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/M5235EVB_defconfig b/configs/M5235EVB_defconfig index d3bbf21ff2..8cd8b112b8 100644 --- a/configs/M5235EVB_defconfig +++ b/configs/M5235EVB_defconfig @@ -8,6 +8,7 @@ CONFIG_SYS_PROMPT="-> " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/M5475AFE_defconfig b/configs/M5475AFE_defconfig index 07ec2a95f1..61a1b65049 100644 --- a/configs/M5475AFE_defconfig +++ b/configs/M5475AFE_defconfig @@ -6,6 +6,7 @@ CONFIG_BOOTDELAY=1 CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/M5475BFE_defconfig b/configs/M5475BFE_defconfig index 73338338ef..193939c675 100644 --- a/configs/M5475BFE_defconfig +++ b/configs/M5475BFE_defconfig @@ -6,6 +6,7 @@ CONFIG_BOOTDELAY=1 CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/M5475CFE_defconfig b/configs/M5475CFE_defconfig index deb3d6f81d..ada595ade4 100644 --- a/configs/M5475CFE_defconfig +++ b/configs/M5475CFE_defconfig @@ -6,6 +6,7 @@ CONFIG_BOOTDELAY=1 CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/M5475DFE_defconfig b/configs/M5475DFE_defconfig index 9a036cfd11..84c9e5c934 100644 --- a/configs/M5475DFE_defconfig +++ b/configs/M5475DFE_defconfig @@ -6,6 +6,7 @@ CONFIG_BOOTDELAY=1 CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/M5475EFE_defconfig b/configs/M5475EFE_defconfig index 0f6c3d6800..d86dd203fc 100644 --- a/configs/M5475EFE_defconfig +++ b/configs/M5475EFE_defconfig @@ -6,6 +6,7 @@ CONFIG_BOOTDELAY=1 CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/M5475FFE_defconfig b/configs/M5475FFE_defconfig index 4f8b4bb5bd..689cdd47b8 100644 --- a/configs/M5475FFE_defconfig +++ b/configs/M5475FFE_defconfig @@ -6,6 +6,7 @@ CONFIG_BOOTDELAY=1 CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/M5475GFE_defconfig b/configs/M5475GFE_defconfig index 90e919232a..75b8a1cc56 100644 --- a/configs/M5475GFE_defconfig +++ b/configs/M5475GFE_defconfig @@ -6,6 +6,7 @@ CONFIG_BOOTDELAY=1 CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/M5485AFE_defconfig b/configs/M5485AFE_defconfig index d49a6bedbb..7c0a3fd44a 100644 --- a/configs/M5485AFE_defconfig +++ b/configs/M5485AFE_defconfig @@ -6,6 +6,7 @@ CONFIG_BOOTDELAY=1 CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/M5485BFE_defconfig b/configs/M5485BFE_defconfig index e0d619ef6b..7de0b8546f 100644 --- a/configs/M5485BFE_defconfig +++ b/configs/M5485BFE_defconfig @@ -6,6 +6,7 @@ CONFIG_BOOTDELAY=1 CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/M5485CFE_defconfig b/configs/M5485CFE_defconfig index f0674e381f..c66d850c07 100644 --- a/configs/M5485CFE_defconfig +++ b/configs/M5485CFE_defconfig @@ -6,6 +6,7 @@ CONFIG_BOOTDELAY=1 CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/M5485DFE_defconfig b/configs/M5485DFE_defconfig index be8990a076..c43cc9db4b 100644 --- a/configs/M5485DFE_defconfig +++ b/configs/M5485DFE_defconfig @@ -6,6 +6,7 @@ CONFIG_BOOTDELAY=1 CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/M5485EFE_defconfig b/configs/M5485EFE_defconfig index 9961be4c18..26cfece58c 100644 --- a/configs/M5485EFE_defconfig +++ b/configs/M5485EFE_defconfig @@ -6,6 +6,7 @@ CONFIG_BOOTDELAY=1 CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/M5485FFE_defconfig b/configs/M5485FFE_defconfig index 8edd4b9ea0..4d2073275a 100644 --- a/configs/M5485FFE_defconfig +++ b/configs/M5485FFE_defconfig @@ -6,6 +6,7 @@ CONFIG_BOOTDELAY=1 CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/M5485GFE_defconfig b/configs/M5485GFE_defconfig index 8794f45558..90421dda3e 100644 --- a/configs/M5485GFE_defconfig +++ b/configs/M5485GFE_defconfig @@ -6,6 +6,7 @@ CONFIG_BOOTDELAY=1 CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/M5485HFE_defconfig b/configs/M5485HFE_defconfig index 9a4f23d0c9..914cdcdbc6 100644 --- a/configs/M5485HFE_defconfig +++ b/configs/M5485HFE_defconfig @@ -6,6 +6,7 @@ CONFIG_BOOTDELAY=1 CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/MPC8308RDB_defconfig b/configs/MPC8308RDB_defconfig index 10ff9cf7ca..8df1170332 100644 --- a/configs/MPC8308RDB_defconfig +++ b/configs/MPC8308RDB_defconfig @@ -10,6 +10,7 @@ CONFIG_BOOTDELAY=5 CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/MPC8313ERDB_33_defconfig b/configs/MPC8313ERDB_33_defconfig index 13a4fde917..dfc48b990c 100644 --- a/configs/MPC8313ERDB_33_defconfig +++ b/configs/MPC8313ERDB_33_defconfig @@ -10,6 +10,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_NAND=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/MPC8313ERDB_66_defconfig b/configs/MPC8313ERDB_66_defconfig index c1b5c85b5d..a7dfa1da3c 100644 --- a/configs/MPC8313ERDB_66_defconfig +++ b/configs/MPC8313ERDB_66_defconfig @@ -10,6 +10,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_NAND=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/MPC8313ERDB_NAND_33_defconfig b/configs/MPC8313ERDB_NAND_33_defconfig index e416ee36ce..f050d91623 100644 --- a/configs/MPC8313ERDB_NAND_33_defconfig +++ b/configs/MPC8313ERDB_NAND_33_defconfig @@ -13,6 +13,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_NAND=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/MPC8313ERDB_NAND_66_defconfig b/configs/MPC8313ERDB_NAND_66_defconfig index 787b23a788..e7afb2c4e9 100644 --- a/configs/MPC8313ERDB_NAND_66_defconfig +++ b/configs/MPC8313ERDB_NAND_66_defconfig @@ -13,6 +13,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_NAND=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/MPC8315ERDB_defconfig b/configs/MPC8315ERDB_defconfig index 74d886cd6e..530d802f29 100644 --- a/configs/MPC8315ERDB_defconfig +++ b/configs/MPC8315ERDB_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_SATA=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/MPC8323ERDB_defconfig b/configs/MPC8323ERDB_defconfig index 097fb09a44..6ac618b04d 100644 --- a/configs/MPC8323ERDB_defconfig +++ b/configs/MPC8323ERDB_defconfig @@ -9,6 +9,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_EEPROM=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y # CONFIG_MMC is not set diff --git a/configs/MPC832XEMDS_HOST_33_defconfig b/configs/MPC832XEMDS_HOST_33_defconfig index f48e6083fc..db36b078a9 100644 --- a/configs/MPC832XEMDS_HOST_33_defconfig +++ b/configs/MPC832XEMDS_HOST_33_defconfig @@ -8,6 +8,7 @@ CONFIG_BOOTDELAY=6 CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y # CONFIG_MMC is not set diff --git a/configs/MPC832XEMDS_HOST_66_defconfig b/configs/MPC832XEMDS_HOST_66_defconfig index 60431ad371..cf0fc32d47 100644 --- a/configs/MPC832XEMDS_HOST_66_defconfig +++ b/configs/MPC832XEMDS_HOST_66_defconfig @@ -8,6 +8,7 @@ CONFIG_BOOTDELAY=6 CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y # CONFIG_MMC is not set diff --git a/configs/MPC832XEMDS_SLAVE_defconfig b/configs/MPC832XEMDS_SLAVE_defconfig index 7379e9a48a..df5af99900 100644 --- a/configs/MPC832XEMDS_SLAVE_defconfig +++ b/configs/MPC832XEMDS_SLAVE_defconfig @@ -8,6 +8,7 @@ CONFIG_BOOTDELAY=6 CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y # CONFIG_MMC is not set diff --git a/configs/MPC8349ITXGP_defconfig b/configs/MPC8349ITXGP_defconfig index fc672be7e9..09af09d4c3 100644 --- a/configs/MPC8349ITXGP_defconfig +++ b/configs/MPC8349ITXGP_defconfig @@ -8,6 +8,7 @@ CONFIG_BOOTDELAY=6 CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="MPC8349E-mITX-GP> " CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y diff --git a/configs/MPC8349ITX_LOWBOOT_defconfig b/configs/MPC8349ITX_LOWBOOT_defconfig index c7f093eaa7..0650c7979a 100644 --- a/configs/MPC8349ITX_LOWBOOT_defconfig +++ b/configs/MPC8349ITX_LOWBOOT_defconfig @@ -11,6 +11,7 @@ CONFIG_CMD_IDE=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_SATA=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y diff --git a/configs/MPC8349ITX_defconfig b/configs/MPC8349ITX_defconfig index e508b3d388..3763f49ba6 100644 --- a/configs/MPC8349ITX_defconfig +++ b/configs/MPC8349ITX_defconfig @@ -11,6 +11,7 @@ CONFIG_CMD_IDE=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_SATA=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y diff --git a/configs/MPC837XEMDS_HOST_defconfig b/configs/MPC837XEMDS_HOST_defconfig index eb3b73596a..4b67fdecc3 100644 --- a/configs/MPC837XEMDS_HOST_defconfig +++ b/configs/MPC837XEMDS_HOST_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/MPC837XERDB_defconfig b/configs/MPC837XERDB_defconfig index 0373e0e433..2ac7e4dac7 100644 --- a/configs/MPC837XERDB_defconfig +++ b/configs/MPC837XERDB_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_SATA=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/MPC8536DS_36BIT_defconfig b/configs/MPC8536DS_36BIT_defconfig index 1d40e2fb1d..9a8a9588ea 100644 --- a/configs/MPC8536DS_36BIT_defconfig +++ b/configs/MPC8536DS_36BIT_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/MPC8536DS_SDCARD_defconfig b/configs/MPC8536DS_SDCARD_defconfig index 8fda7bc08c..7b01c6e74d 100644 --- a/configs/MPC8536DS_SDCARD_defconfig +++ b/configs/MPC8536DS_SDCARD_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set diff --git a/configs/MPC8536DS_SPIFLASH_defconfig b/configs/MPC8536DS_SPIFLASH_defconfig index bdbb8c059f..53675a4a9c 100644 --- a/configs/MPC8536DS_SPIFLASH_defconfig +++ b/configs/MPC8536DS_SPIFLASH_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set diff --git a/configs/MPC8536DS_defconfig b/configs/MPC8536DS_defconfig index 65a1f9e2c7..0fa0bb0827 100644 --- a/configs/MPC8536DS_defconfig +++ b/configs/MPC8536DS_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/MPC8541CDS_defconfig b/configs/MPC8541CDS_defconfig index 2d4647a6c9..928dd2ad00 100644 --- a/configs/MPC8541CDS_defconfig +++ b/configs/MPC8541CDS_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_BOOTDELAY=10 CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set diff --git a/configs/MPC8541CDS_legacy_defconfig b/configs/MPC8541CDS_legacy_defconfig index cbf9eff85d..6d3f805ee1 100644 --- a/configs/MPC8541CDS_legacy_defconfig +++ b/configs/MPC8541CDS_legacy_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_BOOTDELAY=10 CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set diff --git a/configs/MPC8544DS_defconfig b/configs/MPC8544DS_defconfig index 3e75be96b9..7ea19ea43e 100644 --- a/configs/MPC8544DS_defconfig +++ b/configs/MPC8544DS_defconfig @@ -11,6 +11,7 @@ CONFIG_BOOTDELAY=10 CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/MPC8548CDS_36BIT_defconfig b/configs/MPC8548CDS_36BIT_defconfig index fd3b8d6ad2..60ed3279e3 100644 --- a/configs/MPC8548CDS_36BIT_defconfig +++ b/configs/MPC8548CDS_36BIT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/MPC8548CDS_defconfig b/configs/MPC8548CDS_defconfig index e090a5b60f..9ec63c47a8 100644 --- a/configs/MPC8548CDS_defconfig +++ b/configs/MPC8548CDS_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/MPC8548CDS_legacy_defconfig b/configs/MPC8548CDS_legacy_defconfig index 4ea1b9da92..15b0d4ddaa 100644 --- a/configs/MPC8548CDS_legacy_defconfig +++ b/configs/MPC8548CDS_legacy_defconfig @@ -8,6 +8,7 @@ CONFIG_SYS_EXTRA_OPTIONS="LEGACY" CONFIG_BOOTDELAY=10 CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set diff --git a/configs/MPC8555CDS_defconfig b/configs/MPC8555CDS_defconfig index 8410fa4fb1..b21eee64c7 100644 --- a/configs/MPC8555CDS_defconfig +++ b/configs/MPC8555CDS_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_BOOTDELAY=10 CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set diff --git a/configs/MPC8555CDS_legacy_defconfig b/configs/MPC8555CDS_legacy_defconfig index 3ac6035e35..a18eedbd38 100644 --- a/configs/MPC8555CDS_legacy_defconfig +++ b/configs/MPC8555CDS_legacy_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_BOOTDELAY=10 CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set diff --git a/configs/MPC8568MDS_defconfig b/configs/MPC8568MDS_defconfig index b5fb4c282e..c58d8f3ced 100644 --- a/configs/MPC8568MDS_defconfig +++ b/configs/MPC8568MDS_defconfig @@ -9,6 +9,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/MPC8569MDS_ATM_defconfig b/configs/MPC8569MDS_ATM_defconfig index b713db43ad..d81c2df9b6 100644 --- a/configs/MPC8569MDS_ATM_defconfig +++ b/configs/MPC8569MDS_ATM_defconfig @@ -11,6 +11,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/MPC8569MDS_defconfig b/configs/MPC8569MDS_defconfig index 96f7755f5d..0c1f8f527e 100644 --- a/configs/MPC8569MDS_defconfig +++ b/configs/MPC8569MDS_defconfig @@ -10,6 +10,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/MPC8572DS_36BIT_defconfig b/configs/MPC8572DS_36BIT_defconfig index 521badc5ad..e705535ae3 100644 --- a/configs/MPC8572DS_36BIT_defconfig +++ b/configs/MPC8572DS_36BIT_defconfig @@ -12,6 +12,7 @@ CONFIG_BOOTDELAY=10 CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set diff --git a/configs/MPC8572DS_defconfig b/configs/MPC8572DS_defconfig index 2821c8c40b..8d362fc227 100644 --- a/configs/MPC8572DS_defconfig +++ b/configs/MPC8572DS_defconfig @@ -11,6 +11,7 @@ CONFIG_BOOTDELAY=10 CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set diff --git a/configs/MPC8610HPCD_defconfig b/configs/MPC8610HPCD_defconfig index 57d8583fd1..3d8b2b64c0 100644 --- a/configs/MPC8610HPCD_defconfig +++ b/configs/MPC8610HPCD_defconfig @@ -9,6 +9,7 @@ CONFIG_BOOTDELAY=10 CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/MPC8641HPCN_36BIT_defconfig b/configs/MPC8641HPCN_36BIT_defconfig index 074c3338cf..c3345aede8 100644 --- a/configs/MPC8641HPCN_36BIT_defconfig +++ b/configs/MPC8641HPCN_36BIT_defconfig @@ -10,6 +10,7 @@ CONFIG_BOOTDELAY=10 CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y diff --git a/configs/MPC8641HPCN_defconfig b/configs/MPC8641HPCN_defconfig index aa2a464547..8bc4ecc2b9 100644 --- a/configs/MPC8641HPCN_defconfig +++ b/configs/MPC8641HPCN_defconfig @@ -9,6 +9,7 @@ CONFIG_BOOTDELAY=10 CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y diff --git a/configs/P1021RDB-PC_36BIT_NAND_defconfig b/configs/P1021RDB-PC_36BIT_NAND_defconfig index c57949944c..0abbf6da7f 100644 --- a/configs/P1021RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1021RDB-PC_36BIT_NAND_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y diff --git a/configs/P1021RDB-PC_36BIT_SDCARD_defconfig b/configs/P1021RDB-PC_36BIT_SDCARD_defconfig index f5e620b6e4..e874b7d1fc 100644 --- a/configs/P1021RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1021RDB-PC_36BIT_SDCARD_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y diff --git a/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig index 581a46bde9..776fac77ad 100644 --- a/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y diff --git a/configs/P1021RDB-PC_36BIT_defconfig b/configs/P1021RDB-PC_36BIT_defconfig index d8138f2955..5c32ea75a6 100644 --- a/configs/P1021RDB-PC_36BIT_defconfig +++ b/configs/P1021RDB-PC_36BIT_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y diff --git a/configs/P1021RDB-PC_NAND_defconfig b/configs/P1021RDB-PC_NAND_defconfig index 378fd8e485..e1aeb53b68 100644 --- a/configs/P1021RDB-PC_NAND_defconfig +++ b/configs/P1021RDB-PC_NAND_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y diff --git a/configs/P1021RDB-PC_SDCARD_defconfig b/configs/P1021RDB-PC_SDCARD_defconfig index 9bd5df5bab..5e4c72f1e8 100644 --- a/configs/P1021RDB-PC_SDCARD_defconfig +++ b/configs/P1021RDB-PC_SDCARD_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y diff --git a/configs/P1021RDB-PC_SPIFLASH_defconfig b/configs/P1021RDB-PC_SPIFLASH_defconfig index 306d610de1..4626a0c33c 100644 --- a/configs/P1021RDB-PC_SPIFLASH_defconfig +++ b/configs/P1021RDB-PC_SPIFLASH_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y diff --git a/configs/P1021RDB-PC_defconfig b/configs/P1021RDB-PC_defconfig index 48565f1b96..dc3012f97e 100644 --- a/configs/P1021RDB-PC_defconfig +++ b/configs/P1021RDB-PC_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y diff --git a/configs/P1022DS_36BIT_NAND_defconfig b/configs/P1022DS_36BIT_NAND_defconfig index 964e5ae2bf..989c7709eb 100644 --- a/configs/P1022DS_36BIT_NAND_defconfig +++ b/configs/P1022DS_36BIT_NAND_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set diff --git a/configs/P1022DS_36BIT_SDCARD_defconfig b/configs/P1022DS_36BIT_SDCARD_defconfig index 8e8374ca67..f63a0f4c09 100644 --- a/configs/P1022DS_36BIT_SDCARD_defconfig +++ b/configs/P1022DS_36BIT_SDCARD_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set diff --git a/configs/P1022DS_36BIT_SPIFLASH_defconfig b/configs/P1022DS_36BIT_SPIFLASH_defconfig index 1773550e50..30b68f901d 100644 --- a/configs/P1022DS_36BIT_SPIFLASH_defconfig +++ b/configs/P1022DS_36BIT_SPIFLASH_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set diff --git a/configs/P1022DS_36BIT_defconfig b/configs/P1022DS_36BIT_defconfig index ce33485cfa..825ddfb333 100644 --- a/configs/P1022DS_36BIT_defconfig +++ b/configs/P1022DS_36BIT_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set diff --git a/configs/P1022DS_NAND_defconfig b/configs/P1022DS_NAND_defconfig index 9bf8db1408..999ae72a88 100644 --- a/configs/P1022DS_NAND_defconfig +++ b/configs/P1022DS_NAND_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set diff --git a/configs/P1022DS_SDCARD_defconfig b/configs/P1022DS_SDCARD_defconfig index 8bcdc73de4..a96bbb2656 100644 --- a/configs/P1022DS_SDCARD_defconfig +++ b/configs/P1022DS_SDCARD_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set diff --git a/configs/P1022DS_SPIFLASH_defconfig b/configs/P1022DS_SPIFLASH_defconfig index 5862c610a7..8afdd8286e 100644 --- a/configs/P1022DS_SPIFLASH_defconfig +++ b/configs/P1022DS_SPIFLASH_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set diff --git a/configs/P1022DS_defconfig b/configs/P1022DS_defconfig index 6c8fb0c9cb..5c44bbd879 100644 --- a/configs/P1022DS_defconfig +++ b/configs/P1022DS_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set diff --git a/configs/P1023RDB_defconfig b/configs/P1023RDB_defconfig index 4819a6912f..426de7afbb 100644 --- a/configs/P1023RDB_defconfig +++ b/configs/P1023RDB_defconfig @@ -14,6 +14,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_NAND=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set diff --git a/configs/P1025RDB_36BIT_defconfig b/configs/P1025RDB_36BIT_defconfig index 08b14fce0c..aebfc5d312 100644 --- a/configs/P1025RDB_36BIT_defconfig +++ b/configs/P1025RDB_36BIT_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y diff --git a/configs/P1025RDB_NAND_defconfig b/configs/P1025RDB_NAND_defconfig index 747a8be68b..8751026960 100644 --- a/configs/P1025RDB_NAND_defconfig +++ b/configs/P1025RDB_NAND_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y diff --git a/configs/P1025RDB_SDCARD_defconfig b/configs/P1025RDB_SDCARD_defconfig index e1af126a6d..75d0d2f1d1 100644 --- a/configs/P1025RDB_SDCARD_defconfig +++ b/configs/P1025RDB_SDCARD_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y diff --git a/configs/P1025RDB_SPIFLASH_defconfig b/configs/P1025RDB_SPIFLASH_defconfig index cd240c3fe2..4c02627f42 100644 --- a/configs/P1025RDB_SPIFLASH_defconfig +++ b/configs/P1025RDB_SPIFLASH_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y diff --git a/configs/P1025RDB_defconfig b/configs/P1025RDB_defconfig index 044e825c1c..68ffe811bd 100644 --- a/configs/P1025RDB_defconfig +++ b/configs/P1025RDB_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index c342fc45c8..ac20193c42 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index 8e52781497..45afe03cff 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index 032c836a28..675ec5ed79 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index a51b63100f..5a85cced02 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index 26a583aaae..0966fd9483 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index e446515204..e2575da3c1 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index c596b686da..ca06b962fc 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index 0430762acf..64a92ac4ea 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y diff --git a/configs/TQM834x_defconfig b/configs/TQM834x_defconfig index e31cacac7b..9f33156880 100644 --- a/configs/TQM834x_defconfig +++ b/configs/TQM834x_defconfig @@ -9,6 +9,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_EEPROM=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/TWR-P1025_defconfig b/configs/TWR-P1025_defconfig index e48b9bc3e9..26bfe3ef87 100644 --- a/configs/TWR-P1025_defconfig +++ b/configs/TWR-P1025_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_EEPROM=y CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set diff --git a/configs/apalis-tk1_defconfig b/configs/apalis-tk1_defconfig index ccff112392..0f4bd17b0b 100644 --- a/configs/apalis-tk1_defconfig +++ b/configs/apalis-tk1_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_DFU=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_DM=y diff --git a/configs/apalis_t30_defconfig b/configs/apalis_t30_defconfig index aaf1bfb7f0..c45699533a 100644 --- a/configs/apalis_t30_defconfig +++ b/configs/apalis_t30_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_DFU=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index f12503a334..60583a4767 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set diff --git a/configs/beaver_defconfig b/configs/beaver_defconfig index 10fd50d925..aaea936422 100644 --- a/configs/beaver_defconfig +++ b/configs/beaver_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_DFU=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y diff --git a/configs/boston32r2_defconfig b/configs/boston32r2_defconfig index 6d93edc358..dab3990e82 100644 --- a/configs/boston32r2_defconfig +++ b/configs/boston32r2_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_MEMTEST=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_PCI=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y CONFIG_CMD_LINK_LOCAL=y diff --git a/configs/boston32r2el_defconfig b/configs/boston32r2el_defconfig index 9e494eee10..e364af0b73 100644 --- a/configs/boston32r2el_defconfig +++ b/configs/boston32r2el_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_MEMTEST=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_PCI=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y CONFIG_CMD_LINK_LOCAL=y diff --git a/configs/boston64r2_defconfig b/configs/boston64r2_defconfig index 6913d2ba62..f6754606af 100644 --- a/configs/boston64r2_defconfig +++ b/configs/boston64r2_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_MEMTEST=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_PCI=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y CONFIG_CMD_LINK_LOCAL=y diff --git a/configs/boston64r2el_defconfig b/configs/boston64r2el_defconfig index 10ccc5427c..277d4e56d8 100644 --- a/configs/boston64r2el_defconfig +++ b/configs/boston64r2el_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MEMTEST=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_PCI=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y CONFIG_CMD_LINK_LOCAL=y diff --git a/configs/caddy2_defconfig b/configs/caddy2_defconfig index b062dcdd58..762a2c0a08 100644 --- a/configs/caddy2_defconfig +++ b/configs/caddy2_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_BOOTDELAY=6 CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/cardhu_defconfig b/configs/cardhu_defconfig index f771a057a3..79ed1600ae 100644 --- a/configs/cardhu_defconfig +++ b/configs/cardhu_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y diff --git a/configs/cei-tk1-som_defconfig b/configs/cei-tk1-som_defconfig index 5623bbfbc6..749461bfc6 100644 --- a/configs/cei-tk1-som_defconfig +++ b/configs/cei-tk1-som_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_DFU=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y diff --git a/configs/chromebook_link64_defconfig b/configs/chromebook_link64_defconfig index 3655a6449b..34b9a56ee6 100644 --- a/configs/chromebook_link64_defconfig +++ b/configs/chromebook_link64_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index e2bc9f7945..fb9b7a57dc 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set diff --git a/configs/chromebook_samus_defconfig b/configs/chromebook_samus_defconfig index 0a2cbb8ad2..e4bfba6c76 100644 --- a/configs/chromebook_samus_defconfig +++ b/configs/chromebook_samus_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index 34f57ad1eb..d3982c8f28 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set diff --git a/configs/clearfog_defconfig b/configs/clearfog_defconfig index 89c0976be2..b15ca83f4e 100644 --- a/configs/clearfog_defconfig +++ b/configs/clearfog_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_CACHE=y diff --git a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig index ff058f98c6..4b878b0a1a 100644 --- a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig +++ b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig index e4f97130fc..cc1f636500 100644 --- a/configs/conga-qeval20-qa3-e3845_defconfig +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set diff --git a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig index 87d212a323..58337a023e 100644 --- a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_SATA=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_BMP=y diff --git a/configs/controlcenterd_36BIT_SDCARD_defconfig b/configs/controlcenterd_36BIT_SDCARD_defconfig index ec98183391..65e80acd4f 100644 --- a/configs/controlcenterd_36BIT_SDCARD_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_SATA=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_BMP=y diff --git a/configs/controlcenterdc_defconfig b/configs/controlcenterdc_defconfig index af79b6c120..bb9c1b5d4f 100644 --- a/configs/controlcenterdc_defconfig +++ b/configs/controlcenterdc_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index a1379724ec..533f31dcc2 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -13,6 +13,7 @@ CONFIG_CMD_PART=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set diff --git a/configs/cougarcanyon2_defconfig b/configs/cougarcanyon2_defconfig index d347c0ae18..12f7f74c8b 100644 --- a/configs/cougarcanyon2_defconfig +++ b/configs/cougarcanyon2_defconfig @@ -12,6 +12,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index a17aa75e8f..d67a6c3f69 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set diff --git a/configs/db-88f6820-amc_defconfig b/configs/db-88f6820-amc_defconfig index 323871f68e..657573c02b 100644 --- a/configs/db-88f6820-amc_defconfig +++ b/configs/db-88f6820-amc_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y diff --git a/configs/db-88f6820-gp_defconfig b/configs/db-88f6820-gp_defconfig index 6c6083d328..41a4dac754 100644 --- a/configs/db-88f6820-gp_defconfig +++ b/configs/db-88f6820-gp_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y diff --git a/configs/db-mv784mp-gp_defconfig b/configs/db-mv784mp-gp_defconfig index 99533b9a8d..a46eb69c4e 100644 --- a/configs/db-mv784mp-gp_defconfig +++ b/configs/db-mv784mp-gp_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_SATA=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y diff --git a/configs/dfi-bt700-q7x-151_defconfig b/configs/dfi-bt700-q7x-151_defconfig index 13d911c78c..ffd81efdfa 100644 --- a/configs/dfi-bt700-q7x-151_defconfig +++ b/configs/dfi-bt700-q7x-151_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set diff --git a/configs/ds414_defconfig b/configs/ds414_defconfig index bde54b6bab..0b07dd7123 100644 --- a/configs/ds414_defconfig +++ b/configs/ds414_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y diff --git a/configs/efi-x86_defconfig b/configs/efi-x86_defconfig index d45932bcfc..789c5ce5bf 100644 --- a/configs/efi-x86_defconfig +++ b/configs/efi-x86_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_NET is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y diff --git a/configs/galileo_defconfig b/configs/galileo_defconfig index fb6e84fe52..879f0116d9 100644 --- a/configs/galileo_defconfig +++ b/configs/galileo_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index cdf3e92001..316df3e97f 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -38,6 +38,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig index c5b5232016..d04a92b83a 100644 --- a/configs/gwventana_gw5904_defconfig +++ b/configs/gwventana_gw5904_defconfig @@ -38,6 +38,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index f399c9796f..02b4d2bec3 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -41,6 +41,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/hrcon_defconfig b/configs/hrcon_defconfig index 10dbb7db82..bd0a2de085 100644 --- a/configs/hrcon_defconfig +++ b/configs/hrcon_defconfig @@ -18,6 +18,7 @@ CONFIG_AUTOBOOT_STOP_STR=" " CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_FPGAD=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/hrcon_dh_defconfig b/configs/hrcon_dh_defconfig index 48456b2974..bdb623203e 100644 --- a/configs/hrcon_dh_defconfig +++ b/configs/hrcon_dh_defconfig @@ -17,6 +17,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_FPGAD=y +CONFIG_CMD_PCI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y diff --git a/configs/integratorap_cm720t_defconfig b/configs/integratorap_cm720t_defconfig index 0685dca0de..349bdcd3f7 100644 --- a/configs/integratorap_cm720t_defconfig +++ b/configs/integratorap_cm720t_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_IS_NOWHERE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-AP # " CONFIG_CMD_ARMFLASH=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/integratorap_cm920t_defconfig b/configs/integratorap_cm920t_defconfig index 9c27bdb848..774f69274f 100644 --- a/configs/integratorap_cm920t_defconfig +++ b/configs/integratorap_cm920t_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_IS_NOWHERE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-AP # " CONFIG_CMD_ARMFLASH=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/integratorap_cm926ejs_defconfig b/configs/integratorap_cm926ejs_defconfig index 77aa6a8bd7..4e071d51d0 100644 --- a/configs/integratorap_cm926ejs_defconfig +++ b/configs/integratorap_cm926ejs_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_IS_NOWHERE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-AP # " CONFIG_CMD_ARMFLASH=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/integratorap_cm946es_defconfig b/configs/integratorap_cm946es_defconfig index 55bfe3a2a3..19de825c7b 100644 --- a/configs/integratorap_cm946es_defconfig +++ b/configs/integratorap_cm946es_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_IS_NOWHERE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-AP # " CONFIG_CMD_ARMFLASH=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/jetson-tk1_defconfig b/configs/jetson-tk1_defconfig index a533c6402f..14f6a8ef51 100644 --- a/configs/jetson-tk1_defconfig +++ b/configs/jetson-tk1_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_DFU=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y diff --git a/configs/ls1012aqds_qspi_defconfig b/configs/ls1012aqds_qspi_defconfig index 60000b376b..383fc1a95f 100644 --- a/configs/ls1012aqds_qspi_defconfig +++ b/configs/ls1012aqds_qspi_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig index ec6ed377d4..106e3d17a8 100644 --- a/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/ls1012ardb_qspi_defconfig b/configs/ls1012ardb_qspi_defconfig index 5eb35dfc4a..6b8dfd1b6b 100644 --- a/configs/ls1012ardb_qspi_defconfig +++ b/configs/ls1012ardb_qspi_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index 4722d36b3d..e1f736acb1 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -31,8 +31,8 @@ CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y CONFIG_CMD_GPT=y -CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_BMP=y # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/ls1046aqds_SECURE_BOOT_defconfig b/configs/ls1046aqds_SECURE_BOOT_defconfig index 8581fb99d0..fd9ea608ad 100644 --- a/configs/ls1046aqds_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_SECURE_BOOT_defconfig @@ -12,10 +12,11 @@ CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y +CONFIG_CMD_PCI=y CONFIG_CMD_SF=y -CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/ls1046aqds_defconfig b/configs/ls1046aqds_defconfig index eaf35f2543..d3248fb3eb 100644 --- a/configs/ls1046aqds_defconfig +++ b/configs/ls1046aqds_defconfig @@ -12,10 +12,11 @@ CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y +CONFIG_CMD_PCI=y CONFIG_CMD_SF=y -CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/ls1046aqds_nand_defconfig b/configs/ls1046aqds_nand_defconfig index 7fa956b8bc..481f60f4de 100644 --- a/configs/ls1046aqds_nand_defconfig +++ b/configs/ls1046aqds_nand_defconfig @@ -18,10 +18,11 @@ CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y +CONFIG_CMD_PCI=y CONFIG_CMD_SF=y -CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/ls1046aqds_qspi_defconfig b/configs/ls1046aqds_qspi_defconfig index 4244396f3d..e878c0148e 100644 --- a/configs/ls1046aqds_qspi_defconfig +++ b/configs/ls1046aqds_qspi_defconfig @@ -14,9 +14,10 @@ CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y CONFIG_CMD_SF=y -CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/ls1046aqds_sdcard_ifc_defconfig b/configs/ls1046aqds_sdcard_ifc_defconfig index 3c4b6359fd..0b7df8d776 100644 --- a/configs/ls1046aqds_sdcard_ifc_defconfig +++ b/configs/ls1046aqds_sdcard_ifc_defconfig @@ -18,10 +18,11 @@ CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y +CONFIG_CMD_PCI=y CONFIG_CMD_SF=y -CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/ls1046aqds_sdcard_qspi_defconfig b/configs/ls1046aqds_sdcard_qspi_defconfig index 8af81c0f85..07dfe64a70 100644 --- a/configs/ls1046aqds_sdcard_qspi_defconfig +++ b/configs/ls1046aqds_sdcard_qspi_defconfig @@ -19,9 +19,10 @@ CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y CONFIG_CMD_SF=y -CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/ls1046ardb_emmc_defconfig b/configs/ls1046ardb_emmc_defconfig index 29c55733d7..bb16df2636 100644 --- a/configs/ls1046ardb_emmc_defconfig +++ b/configs/ls1046ardb_emmc_defconfig @@ -15,10 +15,11 @@ CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y +CONFIG_CMD_PCI=y CONFIG_CMD_SF=y -CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig index 2ed55547f3..817cb51767 100644 --- a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig @@ -11,10 +11,11 @@ CONFIG_QSPI_BOOT=y CONFIG_BOOTDELAY=10 # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y +CONFIG_CMD_PCI=y CONFIG_CMD_SF=y -CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_CACHE=y CONFIG_OF_CONTROL=y diff --git a/configs/ls1046ardb_qspi_defconfig b/configs/ls1046ardb_qspi_defconfig index bb5f3b007e..a330cb95ec 100644 --- a/configs/ls1046ardb_qspi_defconfig +++ b/configs/ls1046ardb_qspi_defconfig @@ -11,10 +11,11 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_BOOTDELAY=10 # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y +CONFIG_CMD_PCI=y CONFIG_CMD_SF=y -CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_CACHE=y CONFIG_OF_CONTROL=y diff --git a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig index 419c2289db..e62fc72fb5 100644 --- a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig @@ -16,10 +16,11 @@ CONFIG_SPL_CRYPTO_SUPPORT=y CONFIG_SPL_HASH_SUPPORT=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y +CONFIG_CMD_PCI=y CONFIG_CMD_SF=y -CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_CACHE=y # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/ls1046ardb_sdcard_defconfig b/configs/ls1046ardb_sdcard_defconfig index 48b0b43df5..b8345e0418 100644 --- a/configs/ls1046ardb_sdcard_defconfig +++ b/configs/ls1046ardb_sdcard_defconfig @@ -16,10 +16,11 @@ CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y +CONFIG_CMD_PCI=y CONFIG_CMD_SF=y -CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_CACHE=y # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/ls2080aqds_SECURE_BOOT_defconfig b/configs/ls2080aqds_SECURE_BOOT_defconfig index a784d7aac1..61f8bbf5e7 100644 --- a/configs/ls2080aqds_SECURE_BOOT_defconfig +++ b/configs/ls2080aqds_SECURE_BOOT_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y diff --git a/configs/ls2080aqds_defconfig b/configs/ls2080aqds_defconfig index 0cb377adf7..37f3d3002b 100644 --- a/configs/ls2080aqds_defconfig +++ b/configs/ls2080aqds_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 1cae676adc..9c7c066d5b 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y diff --git a/configs/ls2080aqds_qspi_defconfig b/configs/ls2080aqds_qspi_defconfig index a4b22e4cad..ff77960b57 100644 --- a/configs/ls2080aqds_qspi_defconfig +++ b/configs/ls2080aqds_qspi_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y diff --git a/configs/ls2080aqds_sdcard_defconfig b/configs/ls2080aqds_sdcard_defconfig index 798f3bddac..b2f088b6fa 100644 --- a/configs/ls2080aqds_sdcard_defconfig +++ b/configs/ls2080aqds_sdcard_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y diff --git a/configs/ls2080ardb_SECURE_BOOT_defconfig b/configs/ls2080ardb_SECURE_BOOT_defconfig index a3d4322344..97170afa86 100644 --- a/configs/ls2080ardb_SECURE_BOOT_defconfig +++ b/configs/ls2080ardb_SECURE_BOOT_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y diff --git a/configs/ls2080ardb_defconfig b/configs/ls2080ardb_defconfig index da77d60f52..94e79fcc3e 100644 --- a/configs/ls2080ardb_defconfig +++ b/configs/ls2080ardb_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index 243fcc8dc5..8c72cb51e2 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y diff --git a/configs/ls2081ardb_defconfig b/configs/ls2081ardb_defconfig index 7fcfdd4b6e..bb8759e125 100644 --- a/configs/ls2081ardb_defconfig +++ b/configs/ls2081ardb_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y CONFIG_OF_CONTROL=y diff --git a/configs/ls2088ardb_qspi_defconfig b/configs/ls2088ardb_qspi_defconfig index 3a022330e2..c29ad3fcdd 100644 --- a/configs/ls2088ardb_qspi_defconfig +++ b/configs/ls2088ardb_qspi_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y CONFIG_OF_CONTROL=y diff --git a/configs/malta64_defconfig b/configs/malta64_defconfig index a342bec808..c97f6861e3 100644 --- a/configs/malta64_defconfig +++ b/configs/malta64_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_IDE=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set diff --git a/configs/malta64el_defconfig b/configs/malta64el_defconfig index ac560460eb..c443da1d30 100644 --- a/configs/malta64el_defconfig +++ b/configs/malta64el_defconfig @@ -11,6 +11,7 @@ CONFIG_CMD_IDE=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set diff --git a/configs/malta_defconfig b/configs/malta_defconfig index e4e21d0f0f..fd9fa8b7ce 100644 --- a/configs/malta_defconfig +++ b/configs/malta_defconfig @@ -9,6 +9,7 @@ CONFIG_CMD_IDE=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set diff --git a/configs/maltael_defconfig b/configs/maltael_defconfig index 0b9f665f10..9802627803 100644 --- a/configs/maltael_defconfig +++ b/configs/maltael_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_IDE=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index 0d58848e3c..6be7f55f7c 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set diff --git a/configs/mpc8308_p1m_defconfig b/configs/mpc8308_p1m_defconfig index 0dcdd3bcbe..a9d42c9f84 100644 --- a/configs/mpc8308_p1m_defconfig +++ b/configs/mpc8308_p1m_defconfig @@ -7,6 +7,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_BOOTDELAY=5 CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/mvebu_db_armada8k_defconfig b/configs/mvebu_db_armada8k_defconfig index 7f4ee052d3..239142d502 100644 --- a/configs/mvebu_db_armada8k_defconfig +++ b/configs/mvebu_db_armada8k_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y diff --git a/configs/mvebu_mcbin-88f8040_defconfig b/configs/mvebu_mcbin-88f8040_defconfig index b533f736c5..edcb4f9425 100644 --- a/configs/mvebu_mcbin-88f8040_defconfig +++ b/configs/mvebu_mcbin-88f8040_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index 627bf523d6..03bd57351b 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/mx6sxsabresd_defconfig b/configs/mx6sxsabresd_defconfig index 2522eb770b..9a1c67e833 100644 --- a/configs/mx6sxsabresd_defconfig +++ b/configs/mx6sxsabresd_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/mx6sxsabresd_spl_defconfig b/configs/mx6sxsabresd_spl_defconfig index 90daa96a36..370e7e6829 100644 --- a/configs/mx6sxsabresd_spl_defconfig +++ b/configs/mx6sxsabresd_spl_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 23c186b21a..36bab91e0d 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_SATA=y +CONFIG_CMD_PCI=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT4_WRITE=y diff --git a/configs/p2371-2180_defconfig b/configs/p2371-2180_defconfig index 4345fb070a..74d45ad96b 100644 --- a/configs/p2371-2180_defconfig +++ b/configs/p2371-2180_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_DFU=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y diff --git a/configs/p2771-0000-000_defconfig b/configs/p2771-0000-000_defconfig index edf6ce4a93..f33f992195 100644 --- a/configs/p2771-0000-000_defconfig +++ b/configs/p2771-0000-000_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y diff --git a/configs/p2771-0000-500_defconfig b/configs/p2771-0000-500_defconfig index c3870c38d6..655bba426e 100644 --- a/configs/p2771-0000-500_defconfig +++ b/configs/p2771-0000-500_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y diff --git a/configs/qemu-ppce500_defconfig b/configs/qemu-ppce500_defconfig index f905f35631..e7884d300b 100644 --- a/configs/qemu-ppce500_defconfig +++ b/configs/qemu-ppce500_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_PCI=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set diff --git a/configs/qemu-x86_64_defconfig b/configs/qemu-x86_64_defconfig index bda94ab460..0c40788e3f 100644 --- a/configs/qemu-x86_64_defconfig +++ b/configs/qemu-x86_64_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_IDE=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 068b1cd532..293309c994 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_PART=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set diff --git a/configs/qemu-x86_efi_payload32_defconfig b/configs/qemu-x86_efi_payload32_defconfig index 5f1045a128..21c5a09fb7 100644 --- a/configs/qemu-x86_efi_payload32_defconfig +++ b/configs/qemu-x86_efi_payload32_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_PART=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set diff --git a/configs/qemu-x86_efi_payload64_defconfig b/configs/qemu-x86_efi_payload64_defconfig index d76f7fd7eb..77489a8bcf 100644 --- a/configs/qemu-x86_efi_payload64_defconfig +++ b/configs/qemu-x86_efi_payload64_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_PART=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set diff --git a/configs/r2dplus_defconfig b/configs/r2dplus_defconfig index 31b9cc4f5b..197c4958eb 100644 --- a/configs/r2dplus_defconfig +++ b/configs/r2dplus_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_R2DPLUS=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_BOOTDELAY=-1 CONFIG_CMD_IDE=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y diff --git a/configs/r7780mp_defconfig b/configs/r7780mp_defconfig index a46954d3c3..58decc5b52 100644 --- a/configs/r7780mp_defconfig +++ b/configs/r7780mp_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_IDE=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_PCI=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 698ced0256..3fe2702d30 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -40,6 +40,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_REMOTEPROC=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TFTPSRV=y CONFIG_CMD_RARP=y diff --git a/configs/sandbox_flattree_defconfig b/configs/sandbox_flattree_defconfig index 3d21662599..8819e86093 100644 --- a/configs/sandbox_flattree_defconfig +++ b/configs/sandbox_flattree_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_REMOTEPROC=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TFTPSRV=y CONFIG_CMD_RARP=y diff --git a/configs/sandbox_noblk_defconfig b/configs/sandbox_noblk_defconfig index 0b82439d33..b6fcb31812 100644 --- a/configs/sandbox_noblk_defconfig +++ b/configs/sandbox_noblk_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_REMOTEPROC=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TFTPSRV=y CONFIG_CMD_RARP=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index 09e078ec51..e112c3200b 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -47,6 +47,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_REMOTEPROC=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TFTPSRV=y CONFIG_CMD_RARP=y diff --git a/configs/sbc8349_PCI_33_defconfig b/configs/sbc8349_PCI_33_defconfig index a79908ae01..c7d4b34ee0 100644 --- a/configs/sbc8349_PCI_33_defconfig +++ b/configs/sbc8349_PCI_33_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_EXTRA_OPTIONS="PCI_33M" CONFIG_BOOTDELAY=6 CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/sbc8349_PCI_66_defconfig b/configs/sbc8349_PCI_66_defconfig index 0d43ba425a..8990a01f87 100644 --- a/configs/sbc8349_PCI_66_defconfig +++ b/configs/sbc8349_PCI_66_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_EXTRA_OPTIONS="PCI_66M" CONFIG_BOOTDELAY=6 CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/sbc8548_PCI_33_PCIE_defconfig b/configs/sbc8548_PCI_33_PCIE_defconfig index 6348f7d2e4..5c2cca64c3 100644 --- a/configs/sbc8548_PCI_33_PCIE_defconfig +++ b/configs/sbc8548_PCI_33_PCIE_defconfig @@ -10,6 +10,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/sbc8548_PCI_33_defconfig b/configs/sbc8548_PCI_33_defconfig index acb3092b7c..4fb8b19efb 100644 --- a/configs/sbc8548_PCI_33_defconfig +++ b/configs/sbc8548_PCI_33_defconfig @@ -10,6 +10,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/sbc8548_PCI_66_PCIE_defconfig b/configs/sbc8548_PCI_66_PCIE_defconfig index 195d472e67..1230826eca 100644 --- a/configs/sbc8548_PCI_66_PCIE_defconfig +++ b/configs/sbc8548_PCI_66_PCIE_defconfig @@ -10,6 +10,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/sbc8548_PCI_66_defconfig b/configs/sbc8548_PCI_66_defconfig index c107213d8c..52ccb3979f 100644 --- a/configs/sbc8548_PCI_66_defconfig +++ b/configs/sbc8548_PCI_66_defconfig @@ -10,6 +10,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/sbc8641d_defconfig b/configs/sbc8641d_defconfig index 200500f2f6..ee4ec6fa1f 100644 --- a/configs/sbc8641d_defconfig +++ b/configs/sbc8641d_defconfig @@ -7,6 +7,7 @@ CONFIG_BOOTDELAY=10 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y CONFIG_DOS_PARTITION=y diff --git a/configs/sh7785lcr_32bit_defconfig b/configs/sh7785lcr_32bit_defconfig index 675c4eb678..d4ebd4b99d 100644 --- a/configs/sh7785lcr_32bit_defconfig +++ b/configs/sh7785lcr_32bit_defconfig @@ -16,6 +16,7 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_PCI=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set diff --git a/configs/sh7785lcr_defconfig b/configs/sh7785lcr_defconfig index d118fd4f5d..5aaca3f574 100644 --- a/configs/sh7785lcr_defconfig +++ b/configs/sh7785lcr_defconfig @@ -15,6 +15,7 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_PCI=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set diff --git a/configs/socrates_defconfig b/configs/socrates_defconfig index 4c55b8f33e..f0c1d72f5f 100644 --- a/configs/socrates_defconfig +++ b/configs/socrates_defconfig @@ -14,6 +14,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_NAND=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set diff --git a/configs/som-db5800-som-6867_defconfig b/configs/som-db5800-som-6867_defconfig index 4c60d03772..58bab22a3a 100644 --- a/configs/som-db5800-som-6867_defconfig +++ b/configs/som-db5800-som-6867_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set diff --git a/configs/strider_con_defconfig b/configs/strider_con_defconfig index d293d39d7b..1945d2db3c 100644 --- a/configs/strider_con_defconfig +++ b/configs/strider_con_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MEMTEST=y CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_FPGAD=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/strider_con_dp_defconfig b/configs/strider_con_dp_defconfig index e0040e9e38..66d8bed4d1 100644 --- a/configs/strider_con_dp_defconfig +++ b/configs/strider_con_dp_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MEMTEST=y CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_FPGAD=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/strider_cpu_defconfig b/configs/strider_cpu_defconfig index 7d372ffac7..8eafcd2b33 100644 --- a/configs/strider_cpu_defconfig +++ b/configs/strider_cpu_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MEMTEST=y CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_FPGAD=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/strider_cpu_dp_defconfig b/configs/strider_cpu_dp_defconfig index 5d304b3f8b..1100cafe60 100644 --- a/configs/strider_cpu_dp_defconfig +++ b/configs/strider_cpu_dp_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MEMTEST=y CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_FPGAD=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 15531e4ac3..c83a2e5932 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y CONFIG_CMD_SATA=y +CONFIG_CMD_PCI=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/theadorable-x86-dfi-bt700_defconfig b/configs/theadorable-x86-dfi-bt700_defconfig index 29d48b6c53..9de83c9329 100644 --- a/configs/theadorable-x86-dfi-bt700_defconfig +++ b/configs/theadorable-x86-dfi-bt700_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index 4d079292b3..23c4513dba 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y diff --git a/configs/trimslice_defconfig b/configs/trimslice_defconfig index a904e4b4dd..6be75eea97 100644 --- a/configs/trimslice_defconfig +++ b/configs/trimslice_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y diff --git a/configs/turris_omnia_defconfig b/configs/turris_omnia_defconfig index 2eb3d84972..fee26af937 100644 --- a/configs/turris_omnia_defconfig +++ b/configs/turris_omnia_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y diff --git a/configs/ve8313_defconfig b/configs/ve8313_defconfig index 5d601d950b..4a71356b60 100644 --- a/configs/ve8313_defconfig +++ b/configs/ve8313_defconfig @@ -8,6 +8,7 @@ CONFIG_BOOTDELAY=6 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_NAND=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/vining_2000_defconfig b/configs/vining_2000_defconfig index 0099cabc82..ade0e2db0d 100644 --- a/configs/vining_2000_defconfig +++ b/configs/vining_2000_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_PART=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/vme8349_defconfig b/configs/vme8349_defconfig index 244dc7e34f..27d6c6bee0 100644 --- a/configs/vme8349_defconfig +++ b/configs/vme8349_defconfig @@ -7,6 +7,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_BOOTDELAY=6 CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/xpedite517x_defconfig b/configs/xpedite517x_defconfig index 47fac0052e..a627146fca 100644 --- a/configs/xpedite517x_defconfig +++ b/configs/xpedite517x_defconfig @@ -11,6 +11,7 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_EEPROM=y CONFIG_CMD_NAND=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/xpedite520x_defconfig b/configs/xpedite520x_defconfig index 4192269147..d660d1c0e0 100644 --- a/configs/xpedite520x_defconfig +++ b/configs/xpedite520x_defconfig @@ -12,6 +12,7 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_EEPROM=y CONFIG_CMD_NAND=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/xpedite537x_defconfig b/configs/xpedite537x_defconfig index 90a00d9e17..63b0e40fc5 100644 --- a/configs/xpedite537x_defconfig +++ b/configs/xpedite537x_defconfig @@ -11,6 +11,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_EEPROM=y CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/xpedite550x_defconfig b/configs/xpedite550x_defconfig index 796a805242..0eb034805c 100644 --- a/configs/xpedite550x_defconfig +++ b/configs/xpedite550x_defconfig @@ -12,6 +12,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/zc5202_defconfig b/configs/zc5202_defconfig index d61ed777be..6e37265528 100644 --- a/configs/zc5202_defconfig +++ b/configs/zc5202_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y +CONFIG_CMD_PCI=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPI_FLASH=y diff --git a/include/config_cmd_all.h b/include/config_cmd_all.h index c61951bb22..b1f699080e 100644 --- a/include/config_cmd_all.h +++ b/include/config_cmd_all.h @@ -13,7 +13,6 @@ * Alphabetical list of all possible commands. */
-#define CONFIG_CMD_PCI /* pciinfo */ #define CONFIG_CMD_PCMCIA /* PCMCIA support */ #define CONFIG_CMD_PORTIO /* Port I/O */ #define CONFIG_CMD_REGINFO /* Register dump */ diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index 4ec65759b5..984803d440 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -695,10 +695,6 @@ unsigned long get_board_ddr_clk(void); */ #define CONFIG_CMD_REGINFO
-#ifdef CONFIG_PCI -#define CONFIG_CMD_PCI -#endif - /* * USB */ diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index b0a3cf8e47..b385cf4a97 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -77,8 +77,6 @@ #define CONFIG_FSL_PCIE_RESET /* need PCIe reset errata */ #define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */
-#define CONFIG_CMD_PCI - /* * PCI Windows * Memory space is mapped 1-1, but I/O space must start from 0. diff --git a/include/configs/C29XPCIE.h b/include/configs/C29XPCIE.h index 050847b4aa..a00d3872e3 100644 --- a/include/configs/C29XPCIE.h +++ b/include/configs/C29XPCIE.h @@ -77,8 +77,6 @@ #define CONFIG_FSL_PCIE_RESET /* need PCIe reset errata */ #define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */
-#define CONFIG_CMD_PCI - /* * PCI Windows * Memory space is mapped 1-1, but I/O space must start from 0. diff --git a/include/configs/M5235EVB.h b/include/configs/M5235EVB.h index 57328c6269..dac2a32383 100644 --- a/include/configs/M5235EVB.h +++ b/include/configs/M5235EVB.h @@ -33,9 +33,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
-/* Command line configuration */ -#define CONFIG_CMD_PCI - #define CONFIG_MCFFEC #ifdef CONFIG_MCFFEC # define CONFIG_MII 1 diff --git a/include/configs/M54455EVB.h b/include/configs/M54455EVB.h index 8702b89174..f83aa13ecf 100644 --- a/include/configs/M54455EVB.h +++ b/include/configs/M54455EVB.h @@ -35,9 +35,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
-/* Command line configuration */ -#undef CONFIG_CMD_PCI - /* Network configuration */ #define CONFIG_MCFFEC #ifdef CONFIG_MCFFEC diff --git a/include/configs/M5475EVB.h b/include/configs/M5475EVB.h index 9dca52e78a..b51d69568a 100644 --- a/include/configs/M5475EVB.h +++ b/include/configs/M5475EVB.h @@ -25,9 +25,6 @@ #undef CONFIG_HW_WATCHDOG #define CONFIG_WATCHDOG_TIMEOUT 5000 /* timeout in milliseconds, max timeout is 6.71sec */
-/* Command line configuration */ -#define CONFIG_CMD_PCI - #define CONFIG_SLTTMR
#define CONFIG_FSLDMAFEC @@ -68,9 +65,6 @@ #ifdef CONFIG_CMD_USB # define CONFIG_USB_OHCI_NEW
-# ifndef CONFIG_CMD_PCI -# define CONFIG_CMD_PCI -# endif # define CONFIG_PCI_OHCI
# undef CONFIG_SYS_USB_OHCI_BOARD_INIT diff --git a/include/configs/M5485EVB.h b/include/configs/M5485EVB.h index d95be2bd5e..56af0e3a5f 100644 --- a/include/configs/M5485EVB.h +++ b/include/configs/M5485EVB.h @@ -25,9 +25,6 @@ #undef CONFIG_HW_WATCHDOG #define CONFIG_WATCHDOG_TIMEOUT 5000 /* timeout in milliseconds, max timeout is 6.71sec */
#define CONFIG_FSLDMAFEC @@ -67,9 +64,6 @@
#ifdef CONFIG_CMD_USB # define CONFIG_USB_OHCI_NEW -# ifndef CONFIG_CMD_PCI -# define CONFIG_CMD_PCI -# endif /*# define CONFIG_PCI_OHCI*/ # define CONFIG_SYS_USB_OHCI_REGS_BASE 0x80041000 # define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 15 diff --git a/include/configs/MPC8308RDB.h b/include/configs/MPC8308RDB.h index 25d5cab959..8460b814ad 100644 --- a/include/configs/MPC8308RDB.h +++ b/include/configs/MPC8308RDB.h @@ -415,7 +415,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_PCI
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */
diff --git a/include/configs/MPC8313ERDB.h b/include/configs/MPC8313ERDB.h index d666f960b6..3a031a833a 100644 --- a/include/configs/MPC8313ERDB.h +++ b/include/configs/MPC8313ERDB.h @@ -463,7 +463,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_PCI
#define CONFIG_CMDLINE_EDITING 1 #define CONFIG_AUTO_COMPLETE /* add autocompletion support */ diff --git a/include/configs/MPC8315ERDB.h b/include/configs/MPC8315ERDB.h index 69107ca12d..28f7a289b7 100644 --- a/include/configs/MPC8315ERDB.h +++ b/include/configs/MPC8315ERDB.h @@ -442,7 +442,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_PCI
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */ diff --git a/include/configs/MPC8323ERDB.h b/include/configs/MPC8323ERDB.h index b8f8f493eb..7f99bd2888 100644 --- a/include/configs/MPC8323ERDB.h +++ b/include/configs/MPC8323ERDB.h @@ -319,10 +319,6 @@ * Command line configuration. */
-#if defined(CONFIG_PCI) - #define CONFIG_CMD_PCI -#endif - #undef CONFIG_WATCHDOG /* watchdog disabled */
/* diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index 428f3abf90..6ead1db0b3 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -403,10 +403,6 @@ * Command line configuration. */
/* diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index 18f7523692..0b965e2a6b 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -462,10 +462,6 @@ * Command line configuration. */
/* diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index 221c35cf51..7d8074b462 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -486,10 +486,6 @@ boards, we say we have two, but don't display a message if we find only one. */ #if defined(CONFIG_SATA_SIL3114) || defined(CONFIG_USB_STORAGE) #endif
-#ifdef CONFIG_PCI - #define CONFIG_CMD_PCI -#endif - /* Watchdog */ #undef CONFIG_WATCHDOG /* watchdog disabled */
diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index f6afa9dcc9..d29ff91032 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -465,10 +465,6 @@ extern int board_pci_host_broken(void); * Command line configuration. */
-#if defined(CONFIG_PCI) - #define CONFIG_CMD_PCI -#endif - #define CONFIG_CMDLINE_EDITING 1 /* add command line history */ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */
diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index d93f7a0074..11bd0c3f95 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -479,10 +479,6 @@ * Command line configuration. */
-#if defined(CONFIG_PCI) -#define CONFIG_CMD_PCI -#endif - #define CONFIG_CMDLINE_EDITING 1 /* add command line history */ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */
diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 38a2ca146c..277c9d00a7 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -585,10 +585,6 @@ */ #define CONFIG_CMD_REGINFO
-#if defined(CONFIG_PCI) -#define CONFIG_CMD_PCI -#endif - #undef CONFIG_WATCHDOG /* watchdog disabled */
#ifdef CONFIG_MMC diff --git a/include/configs/MPC8540ADS.h b/include/configs/MPC8540ADS.h index ca4ccd8ad3..6add793595 100644 --- a/include/configs/MPC8540ADS.h +++ b/include/configs/MPC8540ADS.h @@ -314,10 +314,6 @@ * Command line configuration. */
/* diff --git a/include/configs/MPC8541CDS.h b/include/configs/MPC8541CDS.h index 977454167d..3867b31e23 100644 --- a/include/configs/MPC8541CDS.h +++ b/include/configs/MPC8541CDS.h @@ -343,10 +343,6 @@ extern unsigned long get_clock_freq(void); */ #define CONFIG_CMD_REGINFO
/* diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index b4f4c4e32b..cea37f8ae4 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -349,10 +349,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); */ #define CONFIG_CMD_REGINFO
-#if defined(CONFIG_PCI) - #define CONFIG_CMD_PCI -#endif - /* * USB */ diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index b41543688b..7c98bcb035 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -462,10 +462,6 @@ extern unsigned long get_clock_freq(void); */ #define CONFIG_CMD_REGINFO
/* diff --git a/include/configs/MPC8555CDS.h b/include/configs/MPC8555CDS.h index d31395cf81..3dc24bd74e 100644 --- a/include/configs/MPC8555CDS.h +++ b/include/configs/MPC8555CDS.h @@ -341,10 +341,6 @@ extern unsigned long get_clock_freq(void); */ #define CONFIG_CMD_REGINFO
/* diff --git a/include/configs/MPC8560ADS.h b/include/configs/MPC8560ADS.h index 2e13fb52df..8b8be2da0e 100644 --- a/include/configs/MPC8560ADS.h +++ b/include/configs/MPC8560ADS.h @@ -354,10 +354,6 @@ */ #define CONFIG_CMD_REGINFO
-#if defined(CONFIG_PCI) - #define CONFIG_CMD_PCI -#endif - #if defined(CONFIG_ETHER_ON_FCC) #endif
diff --git a/include/configs/MPC8568MDS.h b/include/configs/MPC8568MDS.h index c0af7451b8..e6b1ea982f 100644 --- a/include/configs/MPC8568MDS.h +++ b/include/configs/MPC8568MDS.h @@ -356,10 +356,6 @@ extern unsigned long get_clock_freq(void); */ #define CONFIG_CMD_REGINFO
/* diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index 716bb069b3..6f2fa4939a 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -448,10 +448,6 @@ extern unsigned long get_clock_freq(void); */ #define CONFIG_CMD_REGINFO
#ifdef CONFIG_MMC diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index 906270222a..a75d30851b 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -547,10 +547,6 @@ */ #define CONFIG_CMD_REGINFO
-#if defined(CONFIG_PCI) -#define CONFIG_CMD_PCI -#endif - /* * USB */ diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index 5e8211609a..807624e2ce 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -426,10 +426,6 @@ * Command line configuration. */
-#if defined(CONFIG_PCI) -#define CONFIG_CMD_PCI -#endif - #define CONFIG_WATCHDOG /* watchdog enabled */ #define CONFIG_SYS_WATCHDOG_FREQ 5000 /* Feed interval, 5s */
diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index 7b9b2458b3..b74ef38513 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -587,10 +587,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); */ #define CONFIG_CMD_REGINFO
/* diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 08288ccf35..9f52a6fc48 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -140,8 +140,6 @@ #define CONFIG_FSL_PCIE_RESET /* need PCIe reset errata */ #define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */
-#define CONFIG_CMD_PCI - /* * PCI Windows * Memory space is mapped 1-1, but I/O space must start from 0. diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index a1035d6794..152f0d89f0 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -587,10 +587,6 @@ */ #define CONFIG_CMD_REGINFO
-#ifdef CONFIG_PCI -#define CONFIG_CMD_PCI -#endif - /* * USB */ diff --git a/include/configs/P1023RDB.h b/include/configs/P1023RDB.h index 75d1efd127..45dcb6b04b 100644 --- a/include/configs/P1023RDB.h +++ b/include/configs/P1023RDB.h @@ -241,10 +241,6 @@ extern unsigned long get_clock_freq(void); */ #define CONFIG_CMD_REGINFO
-#if defined(CONFIG_PCI) -#define CONFIG_CMD_PCI -#endif - /* * USB */ diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 7c139bbcd1..6c1df93458 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -571,10 +571,6 @@ unsigned long get_board_sys_clk(unsigned long dummy); * Command line configuration. */
-#ifdef CONFIG_PCI -#define CONFIG_CMD_PCI -#endif - /* * USB */ diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index 163ec10cfb..1adbf1ae90 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -773,10 +773,6 @@ unsigned long get_board_ddr_clk(void); */ #define CONFIG_CMD_REGINFO
-#ifdef CONFIG_PCI -#define CONFIG_CMD_PCI -#endif - /* * Miscellaneous configurable options */ diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index cdd459e197..7a33b8a19e 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -784,10 +784,6 @@ unsigned long get_board_ddr_clk(void); */ #define CONFIG_CMD_REGINFO
-#ifdef CONFIG_PCI -#define CONFIG_CMD_PCI -#endif - /* * Miscellaneous configurable options */ diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 0a848b6440..0f0e149572 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -652,10 +652,6 @@ unsigned long get_board_ddr_clk(void); */ #define CONFIG_CMD_REGINFO
-#ifdef CONFIG_PCI -#define CONFIG_CMD_PCI -#endif - /* * Miscellaneous configurable options */ diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 13efcb9e36..34578cc819 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -767,10 +767,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg */ #define CONFIG_CMD_REGINFO
-#ifdef CONFIG_PCI -#define CONFIG_CMD_PCI -#endif - /* * Miscellaneous configurable options */ diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 1e4a49e886..b45e634ddb 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -738,10 +738,6 @@ unsigned long get_board_ddr_clk(void); */ #define CONFIG_CMD_REGINFO
-#ifdef CONFIG_PCI -#define CONFIG_CMD_PCI -#endif - /* * Miscellaneous configurable options */ diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index ecce5163a1..b5b7a4a8fb 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -684,10 +684,6 @@ unsigned long get_board_ddr_clk(void); */ #define CONFIG_CMD_REGINFO
-#ifdef CONFIG_PCI -#define CONFIG_CMD_PCI -#endif - /* * Miscellaneous configurable options */ diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index f4f025a3be..1b56020c10 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -272,10 +272,6 @@ * Command line configuration. */
-#ifdef CONFIG_PCI -#define CONFIG_CMD_PCI -#endif - /* * Miscellaneous configurable options */ diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index c216ac2d47..aab8b5d9f2 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -269,13 +269,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
-/* - * Command line configuration. - */ -#if defined(CONFIG_PCI) - #define CONFIG_CMD_PCI -#endif - /* * Miscellaneous configurable options */ diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index eea518df21..6573301493 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -352,8 +352,6 @@ #define CONFIG_SYS_PCIE1_IO_PHYS 0xffc00000 #define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */
-#define CONFIG_CMD_PCI - #define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #endif /* CONFIG_PCI */
diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index 22a4e69be5..39d2df1804 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -269,7 +269,6 @@ #define CONFIG_PWM_IMX #define CONFIG_IMX6_PWM_PER_CLK 66000000
-#undef CONFIG_CMD_PCI #ifdef CONFIG_CMD_PCI #define CONFIG_PCI_SCAN_SHOW #define CONFIG_PCIE_IMX diff --git a/include/configs/apalis-tk1.h b/include/configs/apalis-tk1.h index d6b226c425..f750d5fbf9 100644 --- a/include/configs/apalis-tk1.h +++ b/include/configs/apalis-tk1.h @@ -39,7 +39,6 @@
/* PCI host support */ #undef CONFIG_PCI_SCAN_SHOW -#define CONFIG_CMD_PCI
/* PCI networking support */ #define CONFIG_E1000_NO_NVM diff --git a/include/configs/apalis_t30.h b/include/configs/apalis_t30.h index daa3be0999..c814c73b40 100644 --- a/include/configs/apalis_t30.h +++ b/include/configs/apalis_t30.h @@ -35,7 +35,6 @@ #define CONFIG_USB_EHCI_TEGRA
/* PCI host support */ -#define CONFIG_CMD_PCI
/* PCI networking support */ #define CONFIG_E1000_NO_NVM diff --git a/include/configs/beaver.h b/include/configs/beaver.h index 6afa1e8c04..2385173a6a 100644 --- a/include/configs/beaver.h +++ b/include/configs/beaver.h @@ -45,7 +45,6 @@ #define CONFIG_USB_ETHER_ASIX
/* General networking support */
diff --git a/include/configs/boston.h b/include/configs/boston.h index 2646cf09ed..86dd0433c8 100644 --- a/include/configs/boston.h +++ b/include/configs/boston.h @@ -20,7 +20,6 @@ /* * PCI */ -#define CONFIG_CMD_PCI
/* * Memory map diff --git a/include/configs/cardhu.h b/include/configs/cardhu.h index a490d06619..834bab073c 100644 --- a/include/configs/cardhu.h +++ b/include/configs/cardhu.h @@ -49,7 +49,6 @@ #define CONFIG_USB_ETHER_ASIX
diff --git a/include/configs/cei-tk1-som.h b/include/configs/cei-tk1-som.h index 768669ff12..4bb0f9e094 100644 --- a/include/configs/cei-tk1-som.h +++ b/include/configs/cei-tk1-som.h @@ -44,7 +44,6 @@ #define CONFIG_USB_ETHER_ASIX
diff --git a/include/configs/clearfog.h b/include/configs/clearfog.h index bd80222149..5061f6c6fd 100644 --- a/include/configs/clearfog.h +++ b/include/configs/clearfog.h @@ -24,7 +24,6 @@ /* * Commands configuration */ -#define CONFIG_CMD_PCI
/* I2C */ #define CONFIG_SYS_I2C diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index 1ac416260e..55d705c2fc 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -220,7 +220,6 @@ #define CONFIG_PCI_INDIRECT_BRIDGE #define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */ -#define CONFIG_CMD_PCI
#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ #define CONFIG_FSL_PCIE_RESET /* need PCIe reset errata */ diff --git a/include/configs/controlcenterdc.h b/include/configs/controlcenterdc.h index 021150ed61..979bb98850 100644 --- a/include/configs/controlcenterdc.h +++ b/include/configs/controlcenterdc.h @@ -33,7 +33,6 @@ * Commands configuration */ #define CONFIG_CMD_I2C -#define CONFIG_CMD_PCI #define CONFIG_CMD_SCSI #define CONFIG_CMD_SPI
diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 77a997b111..19f3a55e9a 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -585,10 +585,6 @@ */ #define CONFIG_CMD_REGINFO
-#ifdef CONFIG_PCI -#define CONFIG_CMD_PCI -#endif - /* * USB */ diff --git a/include/configs/cyrus.h b/include/configs/cyrus.h index ddbaf327d8..5ba393a7db 100644 --- a/include/configs/cyrus.h +++ b/include/configs/cyrus.h @@ -411,10 +411,6 @@ */ #define CONFIG_CMD_REGINFO
-#ifdef CONFIG_PCI -#define CONFIG_CMD_PCI -#endif - /* * USB */ diff --git a/include/configs/db-88f6820-amc.h b/include/configs/db-88f6820-amc.h index 864222955f..b0e988d234 100644 --- a/include/configs/db-88f6820-amc.h +++ b/include/configs/db-88f6820-amc.h @@ -24,7 +24,6 @@ /* * Commands configuration */ -#define CONFIG_CMD_PCI
/* SPI NOR flash default params, used by sf commands */ #define CONFIG_SF_DEFAULT_BUS 1 diff --git a/include/configs/db-88f6820-gp.h b/include/configs/db-88f6820-gp.h index 4a9d2f75bf..44fd968d3b 100644 --- a/include/configs/db-88f6820-gp.h +++ b/include/configs/db-88f6820-gp.h @@ -24,7 +24,6 @@ /* * Commands configuration */ -#define CONFIG_CMD_PCI
/* I2C */ #define CONFIG_SYS_I2C diff --git a/include/configs/db-mv784mp-gp.h b/include/configs/db-mv784mp-gp.h index 7174f6b40e..4a5be6188f 100644 --- a/include/configs/db-mv784mp-gp.h +++ b/include/configs/db-mv784mp-gp.h @@ -22,11 +22,6 @@ #define CONFIG_SYS_TEXT_BASE 0x00800000 #define CONFIG_SYS_TCLK 250000000 /* 250MHz */
-/* - * Commands configuration - */ -#define CONFIG_CMD_PCI - /* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MVTWSI diff --git a/include/configs/ds414.h b/include/configs/ds414.h index c1e9346290..f5998b4a52 100644 --- a/include/configs/ds414.h +++ b/include/configs/ds414.h @@ -48,7 +48,6 @@
/* PCIe support */ #ifndef CONFIG_SPL_BUILD -#define CONFIG_CMD_PCI #define CONFIG_CMD_PCI_ENUM #define CONFIG_PCI_MVEBU #define CONFIG_PCI_SCAN_SHOW diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index 5e04dd24f4..362c1de54f 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -299,7 +299,6 @@ #define CONFIG_PWM_IMX #define CONFIG_IMX6_PWM_PER_CLK 66000000
-#undef CONFIG_CMD_PCI #ifdef CONFIG_CMD_PCI #define CONFIG_PCI_SCAN_SHOW #define CONFIG_PCIE_IMX diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index bddebde042..18d1e7b1f5 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -116,7 +116,6 @@ /* * PCI express */ -#define CONFIG_CMD_PCI #ifdef CONFIG_CMD_PCI #define CONFIG_PCI_SCAN_SHOW #define CONFIG_PCI_FIXUP_DEV diff --git a/include/configs/hrcon.h b/include/configs/hrcon.h index c5b6fddee7..565a5aae93 100644 --- a/include/configs/hrcon.h +++ b/include/configs/hrcon.h @@ -509,7 +509,6 @@ void fpga_control_clear(unsigned int bus, int pin); /* * Command line configuration. */ -#define CONFIG_CMD_PCI
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */ diff --git a/include/configs/integratorap.h b/include/configs/integratorap.h index ae8399426f..0589b9288e 100644 --- a/include/configs/integratorap.h +++ b/include/configs/integratorap.h @@ -43,8 +43,6 @@ * PCI definitions */
-#define CONFIG_CMD_PCI - #define CONFIG_TULIP #define CONFIG_EEPRO100 #define CONFIG_SYS_RX_ETH_BUFFER 8 /* use 8 rx buffer on eepro100 */ diff --git a/include/configs/jetson-tk1.h b/include/configs/jetson-tk1.h index acc97268ba..b35f358ed2 100644 --- a/include/configs/jetson-tk1.h +++ b/include/configs/jetson-tk1.h @@ -40,7 +40,6 @@ #define CONFIG_USB_ETHER_ASIX
diff --git a/include/configs/km/km83xx-common.h b/include/configs/km/km83xx-common.h index 0bd42799f1..810b23e8fa 100644 --- a/include/configs/km/km83xx-common.h +++ b/include/configs/km/km83xx-common.h @@ -219,10 +219,6 @@ #define CONFIG_SYS_NAND_BASE CONFIG_SYS_KMBEC_FPGA_BASE #endif
-#if defined(CONFIG_PCI) -#define CONFIG_CMD_PCI -#endif - /* * For booting Linux, the board info and command line data * have to be in the first 8 MB of memory, since this is diff --git a/include/configs/km/kmp204x-common.h b/include/configs/km/kmp204x-common.h index 3c66f8a170..3c127f5f7d 100644 --- a/include/configs/km/kmp204x-common.h +++ b/include/configs/km/kmp204x-common.h @@ -367,7 +367,6 @@ int get_scl(void); /* * additionnal command line configuration. */ -#define CONFIG_CMD_PCI
/* we don't need flash support */ #undef CONFIG_FLASH_CFI_MTD diff --git a/include/configs/ls1012aqds.h b/include/configs/ls1012aqds.h index bebb0dfce8..99f5dd4119 100644 --- a/include/configs/ls1012aqds.h +++ b/include/configs/ls1012aqds.h @@ -149,7 +149,6 @@
#define CONFIG_NET_MULTI #define CONFIG_PCI_SCAN_SHOW -#define CONFIG_CMD_PCI
#define CONFIG_CMD_MEMINFO #define CONFIG_CMD_MEMTEST diff --git a/include/configs/ls1012ardb.h b/include/configs/ls1012ardb.h index 32c8cec072..f4ed0302a9 100644 --- a/include/configs/ls1012ardb.h +++ b/include/configs/ls1012ardb.h @@ -65,7 +65,6 @@
#define CONFIG_CMD_MEMINFO #define CONFIG_CMD_MEMTEST diff --git a/include/configs/ls1021aiot.h b/include/configs/ls1021aiot.h index 58f893f4fd..9896b0f04b 100644 --- a/include/configs/ls1021aiot.h +++ b/include/configs/ls1021aiot.h @@ -216,7 +216,6 @@
#ifdef CONFIG_PCI #define CONFIG_PCI_SCAN_SHOW -#define CONFIG_CMD_PCI #endif
#define CONFIG_CMD_PING diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index bd05b45f70..261eef1e2b 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -479,7 +479,6 @@ unsigned long get_board_ddr_clk(void);
#define CONFIG_CMDLINE_TAG diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 98e902e0c6..6d195903cb 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -350,7 +350,6 @@
#define CONFIG_CMDLINE_TAG diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 443a6657e6..f064d5c24a 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -169,7 +169,6 @@ #ifdef CONFIG_PCI #define CONFIG_NET_MULTI #define CONFIG_PCI_SCAN_SHOW -#define CONFIG_CMD_PCI #endif #endif
diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index 7d7da91a0d..e5159d8f1a 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -145,7 +145,6 @@
/* Command line configuration */ diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 6b943cdb32..e6384843f9 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -342,7 +342,6 @@ unsigned long get_board_ddr_clk(void);
/* MMC */ diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index b86726fc0e..0de535ac98 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -328,7 +328,6 @@ unsigned long get_board_sys_clk(void);
/* MMC */ diff --git a/include/configs/malta.h b/include/configs/malta.h index 8eb6d7a269..b0b9664f57 100644 --- a/include/configs/malta.h +++ b/include/configs/malta.h @@ -100,7 +100,6 @@ /* * Commands */ -#define CONFIG_CMD_PCI
#define CONFIG_SYS_LONGHELP /* verbose help, undef to save memory */
diff --git a/include/configs/mpc8308_p1m.h b/include/configs/mpc8308_p1m.h index cd5971d30c..755e05deda 100644 --- a/include/configs/mpc8308_p1m.h +++ b/include/configs/mpc8308_p1m.h @@ -382,7 +382,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_PCI
diff --git a/include/configs/mvebu_armada-8k.h b/include/configs/mvebu_armada-8k.h index 86ae19c9fb..05d41e66a2 100644 --- a/include/configs/mvebu_armada-8k.h +++ b/include/configs/mvebu_armada-8k.h @@ -127,7 +127,6 @@ */ #ifdef CONFIG_PCIE_DW_MVEBU #define CONFIG_E1000 -#define CONFIG_CMD_PCI #endif
#endif /* _CONFIG_MVEBU_ARMADA_8K_H */ diff --git a/include/configs/mx6sabresd.h b/include/configs/mx6sabresd.h index 27e767241f..0fa442985a 100644 --- a/include/configs/mx6sabresd.h +++ b/include/configs/mx6sabresd.h @@ -38,7 +38,6 @@ #define CONFIG_SYS_MMC_ENV_DEV 1 /* SDHC3 */ #endif
-#define CONFIG_CMD_PCI #ifdef CONFIG_CMD_PCI #define CONFIG_PCI_SCAN_SHOW #define CONFIG_PCIE_IMX diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index 319fed4ebc..c789d166fb 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -175,7 +175,6 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #endif
-#define CONFIG_CMD_PCI #ifdef CONFIG_CMD_PCI #define CONFIG_PCI_SCAN_SHOW #define CONFIG_PCIE_IMX diff --git a/include/configs/novena.h b/include/configs/novena.h index 2bba741ac3..c6d06559c1 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -17,7 +17,6 @@ #include "mx6_common.h"
/* U-Boot Commands */ -#define CONFIG_CMD_PCI
/* U-Boot general configurations */
diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 6eae41c7e5..d9829d6125 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -686,8 +686,6 @@ #endif #define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */
diff --git a/include/configs/p1_twr.h b/include/configs/p1_twr.h index d5f5769463..795d238b6d 100644 --- a/include/configs/p1_twr.h +++ b/include/configs/p1_twr.h @@ -266,8 +266,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_PCIE1_IO_PHYS 0xffc00000 #define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */
diff --git a/include/configs/p2371-2180.h b/include/configs/p2371-2180.h index 3fb62ded1e..afaeea83e8 100644 --- a/include/configs/p2371-2180.h +++ b/include/configs/p2371-2180.h @@ -39,7 +39,6 @@ #define CONFIG_USB_ETHER_ASIX
diff --git a/include/configs/p2771-0000.h b/include/configs/p2771-0000.h index 55230291c2..564069a665 100644 --- a/include/configs/p2771-0000.h +++ b/include/configs/p2771-0000.h @@ -23,7 +23,6 @@ #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE)
#include "tegra-common-post.h"
diff --git a/include/configs/qemu-ppce500.h b/include/configs/qemu-ppce500.h index 703d158b8b..2c9a3466f7 100644 --- a/include/configs/qemu-ppce500.h +++ b/include/configs/qemu-ppce500.h @@ -126,10 +126,6 @@ extern unsigned long long get_phys_ccsrbar_addr_early(void); * Command line configuration. */
-#ifdef CONFIG_PCI -#define CONFIG_CMD_PCI -#endif - /* * Miscellaneous configurable options */ diff --git a/include/configs/r2dplus.h b/include/configs/r2dplus.h index 7f1f115ff6..a604848073 100644 --- a/include/configs/r2dplus.h +++ b/include/configs/r2dplus.h @@ -11,7 +11,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_PCI #define CONFIG_CMD_SH_ZIMAGEBOOT
/* SCIF */ diff --git a/include/configs/r7780mp.h b/include/configs/r7780mp.h index 14390e81fb..21364ddd4a 100644 --- a/include/configs/r7780mp.h +++ b/include/configs/r7780mp.h @@ -21,7 +21,6 @@ * Command line configuration. */ #define CONFIG_CMD_SDRAM -#define CONFIG_CMD_PCI
#define CONFIG_CONS_SCIF0 1
diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index edb153f79e..28ad0a12e1 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -27,8 +27,6 @@ #define CONFIG_LMB #define CONFIG_ANDROID_BOOT_IMAGE
-#define CONFIG_CMD_PCI - #define CONFIG_FS_EXT4 #define CONFIG_EXT4_WRITE #define CONFIG_HOST_MAX_DEVICES 4 diff --git a/include/configs/sbc8349.h b/include/configs/sbc8349.h index c0faac3b79..ca4cde2f37 100644 --- a/include/configs/sbc8349.h +++ b/include/configs/sbc8349.h @@ -398,10 +398,6 @@ * Command line configuration. */
/* diff --git a/include/configs/sbc8548.h b/include/configs/sbc8548.h index cf9809df49..c2f533b0a1 100644 --- a/include/configs/sbc8548.h +++ b/include/configs/sbc8548.h @@ -512,10 +512,6 @@ */ #define CONFIG_CMD_REGINFO
/* diff --git a/include/configs/sbc8641d.h b/include/configs/sbc8641d.h index c5f9fcb918..de123fdd9c 100644 --- a/include/configs/sbc8641d.h +++ b/include/configs/sbc8641d.h @@ -452,10 +452,6 @@
/* diff --git a/include/configs/sh7785lcr.h b/include/configs/sh7785lcr.h index 48a77197fd..f249f4298d 100644 --- a/include/configs/sh7785lcr.h +++ b/include/configs/sh7785lcr.h @@ -12,7 +12,6 @@ #define CONFIG_CPU_SH7785 1 #define CONFIG_SH7785LCR 1
-#define CONFIG_CMD_PCI #define CONFIG_CMD_SDRAM #define CONFIG_CMD_SH_ZIMAGEBOOT
diff --git a/include/configs/socrates.h b/include/configs/socrates.h index 406a985b60..b6ea44e3c0 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -280,10 +280,6 @@ #define CONFIG_CMD_SDRAM #define CONFIG_CMD_REGINFO
/* diff --git a/include/configs/strider.h b/include/configs/strider.h index aa7f15389c..c6cb51c36b 100644 --- a/include/configs/strider.h +++ b/include/configs/strider.h @@ -543,7 +543,6 @@ void fpga_control_clear(unsigned int bus, int pin); /* * Command line configuration. */ -#define CONFIG_CMD_PCI
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */ diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h index 6d8c78f76b..23b6bf0361 100644 --- a/include/configs/t4qds.h +++ b/include/configs/t4qds.h @@ -241,10 +241,6 @@ * Command line configuration. */
-#ifdef CONFIG_PCI -#define CONFIG_CMD_PCI -#endif - /* * Miscellaneous configurable options */ diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 4baccdc1e9..0030e90ccd 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -72,7 +72,6 @@ #endif
/* PCI */ -#define CONFIG_CMD_PCI #ifdef CONFIG_CMD_PCI #define CONFIG_PCI_SCAN_SHOW #define CONFIG_PCIE_IMX diff --git a/include/configs/theadorable.h b/include/configs/theadorable.h index e5edd5e8fd..a7001e76aa 100644 --- a/include/configs/theadorable.h +++ b/include/configs/theadorable.h @@ -29,9 +29,6 @@ * This version should also enable all other non-production * interfaces / features. */ -#ifdef CONFIG_USB -#define CONFIG_CMD_PCI -#endif
/* I2C */ #define CONFIG_SYS_I2C diff --git a/include/configs/trimslice.h b/include/configs/trimslice.h index fd36634ae9..301065a831 100644 --- a/include/configs/trimslice.h +++ b/include/configs/trimslice.h @@ -42,7 +42,6 @@ #define CONFIG_USB_ETHER_ASIX
diff --git a/include/configs/turris_omnia.h b/include/configs/turris_omnia.h index 1020355ed5..d2c3e57570 100644 --- a/include/configs/turris_omnia.h +++ b/include/configs/turris_omnia.h @@ -26,7 +26,6 @@ /* * Commands configuration */ -#define CONFIG_CMD_PCI
/* I2C support */ #define CONFIG_DM_I2C diff --git a/include/configs/ve8313.h b/include/configs/ve8313.h index 291185fecd..38c67cd109 100644 --- a/include/configs/ve8313.h +++ b/include/configs/ve8313.h @@ -312,7 +312,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_PCI
#define CONFIG_CMDLINE_EDITING 1 #define CONFIG_AUTO_COMPLETE /* add autocompletion support */ diff --git a/include/configs/vining_2000.h b/include/configs/vining_2000.h index 0fed7f37ca..d859ba4a5e 100644 --- a/include/configs/vining_2000.h +++ b/include/configs/vining_2000.h @@ -84,7 +84,6 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #endif
-#define CONFIG_CMD_PCI #ifdef CONFIG_CMD_PCI #define CONFIG_PCI_SCAN_SHOW #define CONFIG_PCIE_IMX diff --git a/include/configs/vme8349.h b/include/configs/vme8349.h index 13ebafeac8..8e9abb264c 100644 --- a/include/configs/vme8349.h +++ b/include/configs/vme8349.h @@ -345,10 +345,6 @@ #define CONFIG_RTC_RX8025 #define CONFIG_CMD_TSI148
-#if defined(CONFIG_PCI) - #define CONFIG_CMD_PCI -#endif - /* Pass Ethernet MAC to VxWorks */ #define CONFIG_SYS_VXWORKS_MAC_PTR 0x000043f0
diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index a70fc9d4d9..f5f7a92b8b 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -66,7 +66,6 @@ /*----------------------------------------------------------------------- * Command line configuration. */ -#define CONFIG_CMD_PCI
#define CONFIG_CMD_ZBOOT
diff --git a/include/configs/xpedite517x.h b/include/configs/xpedite517x.h index fe1c14b7ee..58325f2ec8 100644 --- a/include/configs/xpedite517x.h +++ b/include/configs/xpedite517x.h @@ -484,7 +484,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); /* * Command configuration. */ -#define CONFIG_CMD_PCI #define CONFIG_CMD_PCI_ENUM #define CONFIG_CMD_REGINFO
diff --git a/include/configs/xpedite520x.h b/include/configs/xpedite520x.h index 8a7cf7f711..2bf12120b3 100644 --- a/include/configs/xpedite520x.h +++ b/include/configs/xpedite520x.h @@ -287,7 +287,6 @@ /* * Command configuration. */ -#define CONFIG_CMD_PCI #define CONFIG_CMD_PCI_ENUM #define CONFIG_CMD_REGINFO
diff --git a/include/configs/xpedite537x.h b/include/configs/xpedite537x.h index 5d59bfe28b..2a345d4ac6 100644 --- a/include/configs/xpedite537x.h +++ b/include/configs/xpedite537x.h @@ -337,7 +337,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); /* * Command configuration. */ -#define CONFIG_CMD_PCI #define CONFIG_CMD_PCI_ENUM #define CONFIG_CMD_REGINFO
diff --git a/include/configs/xpedite550x.h b/include/configs/xpedite550x.h index 6bf7dc3e67..0a09ded4d1 100644 --- a/include/configs/xpedite550x.h +++ b/include/configs/xpedite550x.h @@ -336,7 +336,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); /* * Command configuration. */ -#define CONFIG_CMD_PCI #define CONFIG_CMD_PCI_ENUM #define CONFIG_CMD_REGINFO
diff --git a/include/configs/zc5202.h b/include/configs/zc5202.h index a7988e06f5..b1afde9ba0 100644 --- a/include/configs/zc5202.h +++ b/include/configs/zc5202.h @@ -26,7 +26,6 @@ #define CONFIG_FEC_MXC_PHYADDR 0 #define CONFIG_MV88E6352_SWITCH
-#define CONFIG_CMD_PCI #define CONFIG_PCI_SCAN_SHOW #define CONFIG_PCIE_IMX
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 2f1d669114..ea59f44733 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_PCI CONFIG_CMD_PCI_ENUM CONFIG_CMD_PCMCIA CONFIG_CMD_PORTIO
On Sat, Aug 5, 2017 at 6:34 AM, Simon Glass sjg@chromium.org wrote:
This converts the following to Kconfig: CONFIG_CMD_PCI
Signed-off-by: Simon Glass sjg@chromium.org
Changes in v2:
- Fix indentation for CMD_PCI
- Sort Kconfig options in alphabetical order
README | 1 - arch/arm/cpu/armv7/ls102xa/Kconfig | 1 + arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 1 + arch/powerpc/cpu/mpc85xx/Kconfig | 6 ++++++ cmd/Kconfig | 8 ++++++++ configs/M5235EVB_Flash32_defconfig | 1 + configs/M5235EVB_defconfig | 1 + configs/M5475AFE_defconfig | 1 + configs/M5475BFE_defconfig | 1 + configs/M5475CFE_defconfig | 1 + configs/M5475DFE_defconfig | 1 + configs/M5475EFE_defconfig | 1 + configs/M5475FFE_defconfig | 1 + configs/M5475GFE_defconfig | 1 + configs/M5485AFE_defconfig | 1 + configs/M5485BFE_defconfig | 1 + configs/M5485CFE_defconfig | 1 + configs/M5485DFE_defconfig | 1 + configs/M5485EFE_defconfig | 1 + configs/M5485FFE_defconfig | 1 + configs/M5485GFE_defconfig | 1 + configs/M5485HFE_defconfig | 1 + configs/MPC8308RDB_defconfig | 1 + configs/MPC8313ERDB_33_defconfig | 1 + configs/MPC8313ERDB_66_defconfig | 1 + configs/MPC8313ERDB_NAND_33_defconfig | 1 + configs/MPC8313ERDB_NAND_66_defconfig | 1 + configs/MPC8315ERDB_defconfig | 1 + configs/MPC8323ERDB_defconfig | 1 + configs/MPC832XEMDS_HOST_33_defconfig | 1 + configs/MPC832XEMDS_HOST_66_defconfig | 1 + configs/MPC832XEMDS_SLAVE_defconfig | 1 + configs/MPC8349ITXGP_defconfig | 1 + configs/MPC8349ITX_LOWBOOT_defconfig | 1 + configs/MPC8349ITX_defconfig | 1 + configs/MPC837XEMDS_HOST_defconfig | 1 + configs/MPC837XERDB_defconfig | 1 + configs/MPC8536DS_36BIT_defconfig | 1 + configs/MPC8536DS_SDCARD_defconfig | 1 + configs/MPC8536DS_SPIFLASH_defconfig | 1 + configs/MPC8536DS_defconfig | 1 + configs/MPC8541CDS_defconfig | 1 + configs/MPC8541CDS_legacy_defconfig | 1 + configs/MPC8544DS_defconfig | 1 + configs/MPC8548CDS_36BIT_defconfig | 1 + configs/MPC8548CDS_defconfig | 1 + configs/MPC8548CDS_legacy_defconfig | 1 + configs/MPC8555CDS_defconfig | 1 + configs/MPC8555CDS_legacy_defconfig | 1 + configs/MPC8568MDS_defconfig | 1 + configs/MPC8569MDS_ATM_defconfig | 1 + configs/MPC8569MDS_defconfig | 1 + configs/MPC8572DS_36BIT_defconfig | 1 + configs/MPC8572DS_defconfig | 1 + configs/MPC8610HPCD_defconfig | 1 + configs/MPC8641HPCN_36BIT_defconfig | 1 + configs/MPC8641HPCN_defconfig | 1 + configs/P1021RDB-PC_36BIT_NAND_defconfig | 1 + configs/P1021RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1021RDB-PC_36BIT_defconfig | 1 + configs/P1021RDB-PC_NAND_defconfig | 1 + configs/P1021RDB-PC_SDCARD_defconfig | 1 + configs/P1021RDB-PC_SPIFLASH_defconfig | 1 + configs/P1021RDB-PC_defconfig | 1 + configs/P1022DS_36BIT_NAND_defconfig | 1 + configs/P1022DS_36BIT_SDCARD_defconfig | 1 + configs/P1022DS_36BIT_SPIFLASH_defconfig | 1 + configs/P1022DS_36BIT_defconfig | 1 + configs/P1022DS_NAND_defconfig | 1 + configs/P1022DS_SDCARD_defconfig | 1 + configs/P1022DS_SPIFLASH_defconfig | 1 + configs/P1022DS_defconfig | 1 + configs/P1023RDB_defconfig | 1 + configs/P1025RDB_36BIT_defconfig | 1 + configs/P1025RDB_NAND_defconfig | 1 + configs/P1025RDB_SDCARD_defconfig | 1 + configs/P1025RDB_SPIFLASH_defconfig | 1 + configs/P1025RDB_defconfig | 1 + configs/P2020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_36BIT_defconfig | 1 + configs/P2020RDB-PC_NAND_defconfig | 1 + configs/P2020RDB-PC_SDCARD_defconfig | 1 + configs/P2020RDB-PC_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_defconfig | 1 + configs/TQM834x_defconfig | 1 + configs/TWR-P1025_defconfig | 1 + configs/apalis-tk1_defconfig | 1 + configs/apalis_t30_defconfig | 1 + configs/bayleybay_defconfig | 1 + configs/beaver_defconfig | 1 + configs/boston32r2_defconfig | 1 + configs/boston32r2el_defconfig | 1 + configs/boston64r2_defconfig | 1 + configs/boston64r2el_defconfig | 1 + configs/caddy2_defconfig | 1 + configs/cardhu_defconfig | 1 + configs/cei-tk1-som_defconfig | 1 + configs/chromebook_link64_defconfig | 1 + configs/chromebook_link_defconfig | 1 + configs/chromebook_samus_defconfig | 1 + configs/chromebox_panther_defconfig | 1 + configs/clearfog_defconfig | 1 + configs/conga-qeval20-qa3-e3845-internal-uart_defconfig | 1 + configs/conga-qeval20-qa3-e3845_defconfig | 1 + configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig | 1 + configs/controlcenterd_36BIT_SDCARD_defconfig | 1 + configs/controlcenterdc_defconfig | 1 + configs/coreboot-x86_defconfig | 1 + configs/cougarcanyon2_defconfig | 1 + configs/crownbay_defconfig | 1 + configs/db-88f6820-amc_defconfig | 1 + configs/db-88f6820-gp_defconfig | 1 + configs/db-mv784mp-gp_defconfig | 1 + configs/dfi-bt700-q7x-151_defconfig | 1 + configs/ds414_defconfig | 1 + configs/efi-x86_defconfig | 1 + configs/galileo_defconfig | 1 + configs/gwventana_emmc_defconfig | 1 + configs/gwventana_gw5904_defconfig | 1 + configs/gwventana_nand_defconfig | 1 + configs/hrcon_defconfig | 1 + configs/hrcon_dh_defconfig | 1 + configs/integratorap_cm720t_defconfig | 1 + configs/integratorap_cm920t_defconfig | 1 + configs/integratorap_cm926ejs_defconfig | 1 + configs/integratorap_cm946es_defconfig | 1 + configs/jetson-tk1_defconfig | 1 + configs/ls1012aqds_qspi_defconfig | 1 + configs/ls1012ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1012ardb_qspi_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 2 +- configs/ls1046aqds_SECURE_BOOT_defconfig | 3 ++- configs/ls1046aqds_defconfig | 3 ++- configs/ls1046aqds_nand_defconfig | 3 ++- configs/ls1046aqds_qspi_defconfig | 3 ++- configs/ls1046aqds_sdcard_ifc_defconfig | 3 ++- configs/ls1046aqds_sdcard_qspi_defconfig | 3 ++- configs/ls1046ardb_emmc_defconfig | 3 ++- configs/ls1046ardb_qspi_SECURE_BOOT_defconfig | 3 ++- configs/ls1046ardb_qspi_defconfig | 3 ++- configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig | 3 ++- configs/ls1046ardb_sdcard_defconfig | 3 ++- configs/ls2080aqds_SECURE_BOOT_defconfig | 1 + configs/ls2080aqds_defconfig | 1 + configs/ls2080aqds_nand_defconfig | 1 + configs/ls2080aqds_qspi_defconfig | 1 + configs/ls2080aqds_sdcard_defconfig | 1 + configs/ls2080ardb_SECURE_BOOT_defconfig | 1 + configs/ls2080ardb_defconfig | 1 + configs/ls2080ardb_nand_defconfig | 1 + configs/ls2081ardb_defconfig | 1 + configs/ls2088ardb_qspi_defconfig | 1 + configs/malta64_defconfig | 1 + configs/malta64el_defconfig | 1 + configs/malta_defconfig | 1 + configs/maltael_defconfig | 1 + configs/minnowmax_defconfig | 1 + configs/mpc8308_p1m_defconfig | 1 + configs/mvebu_db_armada8k_defconfig | 1 + configs/mvebu_mcbin-88f8040_defconfig | 1 + configs/mx6sabresd_defconfig | 1 + configs/mx6sxsabresd_defconfig | 1 + configs/mx6sxsabresd_spl_defconfig | 1 + configs/novena_defconfig | 1 + configs/p2371-2180_defconfig | 1 + configs/p2771-0000-000_defconfig | 1 + configs/p2771-0000-500_defconfig | 1 + configs/qemu-ppce500_defconfig | 1 + configs/qemu-x86_64_defconfig | 1 + configs/qemu-x86_defconfig | 1 + configs/qemu-x86_efi_payload32_defconfig | 1 + configs/qemu-x86_efi_payload64_defconfig | 1 + configs/r2dplus_defconfig | 1 + configs/r7780mp_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/sandbox_flattree_defconfig | 1 + configs/sandbox_noblk_defconfig | 1 + configs/sandbox_spl_defconfig | 1 + configs/sbc8349_PCI_33_defconfig | 1 + configs/sbc8349_PCI_66_defconfig | 1 + configs/sbc8548_PCI_33_PCIE_defconfig | 1 + configs/sbc8548_PCI_33_defconfig | 1 + configs/sbc8548_PCI_66_PCIE_defconfig | 1 + configs/sbc8548_PCI_66_defconfig | 1 + configs/sbc8641d_defconfig | 1 + configs/sh7785lcr_32bit_defconfig | 1 + configs/sh7785lcr_defconfig | 1 + configs/socrates_defconfig | 1 + configs/som-db5800-som-6867_defconfig | 1 + configs/strider_con_defconfig | 1 + configs/strider_con_dp_defconfig | 1 + configs/strider_cpu_defconfig | 1 + configs/strider_cpu_dp_defconfig | 1 + configs/tbs2910_defconfig | 1 + configs/theadorable-x86-dfi-bt700_defconfig | 1 + configs/theadorable_debug_defconfig | 1 + configs/trimslice_defconfig | 1 + configs/turris_omnia_defconfig | 1 + configs/ve8313_defconfig | 1 + configs/vining_2000_defconfig | 1 + configs/vme8349_defconfig | 1 + configs/xpedite517x_defconfig | 1 + configs/xpedite520x_defconfig | 1 + configs/xpedite537x_defconfig | 1 + configs/xpedite550x_defconfig | 1 + configs/zc5202_defconfig | 1 + include/config_cmd_all.h | 1 - include/configs/B4860QDS.h | 4 ---- include/configs/BSC9132QDS.h | 2 -- include/configs/C29XPCIE.h | 2 -- include/configs/M5235EVB.h | 3 --- include/configs/M54455EVB.h | 3 --- include/configs/M5475EVB.h | 6 ------ include/configs/M5485EVB.h | 6 ------ include/configs/MPC8308RDB.h | 1 - include/configs/MPC8313ERDB.h | 1 - include/configs/MPC8315ERDB.h | 1 - include/configs/MPC8323ERDB.h | 4 ---- include/configs/MPC832XEMDS.h | 4 ---- include/configs/MPC8349EMDS.h | 4 ---- include/configs/MPC8349ITX.h | 4 ---- include/configs/MPC837XEMDS.h | 4 ---- include/configs/MPC837XERDB.h | 4 ---- include/configs/MPC8536DS.h | 4 ---- include/configs/MPC8540ADS.h | 4 ---- include/configs/MPC8541CDS.h | 4 ---- include/configs/MPC8544DS.h | 4 ---- include/configs/MPC8548CDS.h | 4 ---- include/configs/MPC8555CDS.h | 4 ---- include/configs/MPC8560ADS.h | 4 ---- include/configs/MPC8568MDS.h | 4 ---- include/configs/MPC8569MDS.h | 4 ---- include/configs/MPC8572DS.h | 4 ---- include/configs/MPC8610HPCD.h | 4 ---- include/configs/MPC8641HPCN.h | 4 ---- include/configs/P1010RDB.h | 2 -- include/configs/P1022DS.h | 4 ---- include/configs/P1023RDB.h | 4 ---- include/configs/P2041RDB.h | 4 ---- include/configs/T102xQDS.h | 4 ---- include/configs/T102xRDB.h | 4 ---- include/configs/T1040QDS.h | 4 ---- include/configs/T104xRDB.h | 4 ---- include/configs/T208xQDS.h | 4 ---- include/configs/T208xRDB.h | 4 ---- include/configs/T4240RDB.h | 4 ---- include/configs/TQM834x.h | 7 ------- include/configs/UCP1020.h | 2 -- include/configs/advantech_dms-ba16.h | 1 - include/configs/apalis-tk1.h | 1 - include/configs/apalis_t30.h | 1 - include/configs/beaver.h | 1 - include/configs/boston.h | 1 - include/configs/cardhu.h | 1 - include/configs/cei-tk1-som.h | 1 - include/configs/clearfog.h | 1 - include/configs/controlcenterd.h | 1 - include/configs/controlcenterdc.h | 1 - include/configs/corenet_ds.h | 4 ---- include/configs/cyrus.h | 4 ---- include/configs/db-88f6820-amc.h | 1 - include/configs/db-88f6820-gp.h | 1 - include/configs/db-mv784mp-gp.h | 5 ----- include/configs/ds414.h | 1 - include/configs/ge_bx50v3.h | 1 - include/configs/gw_ventana.h | 1 - include/configs/hrcon.h | 1 - include/configs/integratorap.h | 2 -- include/configs/jetson-tk1.h | 1 - include/configs/km/km83xx-common.h | 4 ---- include/configs/km/kmp204x-common.h | 1 - include/configs/ls1012aqds.h | 1 - include/configs/ls1012ardb.h | 1 - include/configs/ls1021aiot.h | 1 - include/configs/ls1021aqds.h | 1 - include/configs/ls1021atwr.h | 1 - include/configs/ls1043a_common.h | 1 - include/configs/ls1046a_common.h | 1 - include/configs/ls2080aqds.h | 1 - include/configs/ls2080ardb.h | 1 - include/configs/malta.h | 1 - include/configs/mpc8308_p1m.h | 1 - include/configs/mvebu_armada-8k.h | 1 - include/configs/mx6sabresd.h | 1 - include/configs/mx6sxsabresd.h | 1 - include/configs/novena.h | 1 - include/configs/p1_p2_rdb_pc.h | 2 -- include/configs/p1_twr.h | 2 -- include/configs/p2371-2180.h | 1 - include/configs/p2771-0000.h | 1 - include/configs/qemu-ppce500.h | 4 ---- include/configs/r2dplus.h | 1 - include/configs/r7780mp.h | 1 - include/configs/sandbox.h | 2 -- include/configs/sbc8349.h | 4 ---- include/configs/sbc8548.h | 4 ---- include/configs/sbc8641d.h | 4 ---- include/configs/sh7785lcr.h | 1 - include/configs/socrates.h | 4 ---- include/configs/strider.h | 1 - include/configs/t4qds.h | 4 ---- include/configs/tbs2910.h | 1 - include/configs/theadorable.h | 3 --- include/configs/trimslice.h | 1 - include/configs/turris_omnia.h | 1 - include/configs/ve8313.h | 1 - include/configs/vining_2000.h | 1 - include/configs/vme8349.h | 4 ---- include/configs/x86-common.h | 1 - include/configs/xpedite517x.h | 1 - include/configs/xpedite520x.h | 1 - include/configs/xpedite537x.h | 1 - include/configs/xpedite550x.h | 1 - include/configs/zc5202.h | 1 - scripts/config_whitelist.txt | 1 - 318 files changed, 231 insertions(+), 273 deletions(-)
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com
Changes in v2:
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
This option enables the 'pci enum' command. It is only enabled by a few board and these have not yet been converted to driver model, which always enables this command. It seems easiest to just remove this option.
The affected boards can be converted to use driver model for PCI if needed.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com ---
Changes in v2: None
cmd/pci.c | 4 ++-- include/config_distro_bootcmd.h | 2 +- include/configs/ds414.h | 1 - include/configs/xpedite517x.h | 1 - include/configs/xpedite520x.h | 1 - include/configs/xpedite537x.h | 1 - include/configs/xpedite550x.h | 1 - scripts/config_whitelist.txt | 1 - 8 files changed, 3 insertions(+), 9 deletions(-)
diff --git a/cmd/pci.c b/cmd/pci.c index fe27b4f761..b8c799f9bd 100644 --- a/cmd/pci.c +++ b/cmd/pci.c @@ -694,7 +694,7 @@ static int do_pci(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) if ((bdf = get_pci_dev(argv[2])) == -1) return 1; break; -#if defined(CONFIG_CMD_PCI_ENUM) || defined(CONFIG_DM_PCI) +#if defined(CONFIG_DM_PCI) case 'e': pci_init(); return 0; @@ -782,7 +782,7 @@ static int do_pci(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) static char pci_help_text[] = "[bus] [long]\n" " - short or long list of PCI devices on bus 'bus'\n" -#if defined(CONFIG_CMD_PCI_ENUM) || defined(CONFIG_DM_PCI) +#if defined(CONFIG_DM_PCI) "pci enum\n" " - Enumerate PCI buses\n" #endif diff --git a/include/config_distro_bootcmd.h b/include/config_distro_bootcmd.h index d8dab8e46a..9ed6b9892c 100644 --- a/include/config_distro_bootcmd.h +++ b/include/config_distro_bootcmd.h @@ -198,7 +198,7 @@ BOOT_TARGET_DEVICES_references_IDE_without_CONFIG_IDE #endif
-#if defined(CONFIG_CMD_PCI_ENUM) || defined(CONFIG_DM_PCI) +#if defined(CONFIG_DM_PCI) #define BOOTENV_RUN_NET_PCI_ENUM "run boot_net_pci_enum; " #define BOOTENV_SHARED_PCI \ "boot_net_pci_enum=pci enum\0" diff --git a/include/configs/ds414.h b/include/configs/ds414.h index f5998b4a52..0b84acdee8 100644 --- a/include/configs/ds414.h +++ b/include/configs/ds414.h @@ -48,7 +48,6 @@
/* PCIe support */ #ifndef CONFIG_SPL_BUILD -#define CONFIG_CMD_PCI_ENUM #define CONFIG_PCI_MVEBU #define CONFIG_PCI_SCAN_SHOW #endif diff --git a/include/configs/xpedite517x.h b/include/configs/xpedite517x.h index 58325f2ec8..57fc16812e 100644 --- a/include/configs/xpedite517x.h +++ b/include/configs/xpedite517x.h @@ -484,7 +484,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); /* * Command configuration. */ -#define CONFIG_CMD_PCI_ENUM #define CONFIG_CMD_REGINFO
/* diff --git a/include/configs/xpedite520x.h b/include/configs/xpedite520x.h index 2bf12120b3..628de82767 100644 --- a/include/configs/xpedite520x.h +++ b/include/configs/xpedite520x.h @@ -287,7 +287,6 @@ /* * Command configuration. */ -#define CONFIG_CMD_PCI_ENUM #define CONFIG_CMD_REGINFO
/* diff --git a/include/configs/xpedite537x.h b/include/configs/xpedite537x.h index 2a345d4ac6..c599b22bc8 100644 --- a/include/configs/xpedite537x.h +++ b/include/configs/xpedite537x.h @@ -337,7 +337,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); /* * Command configuration. */ -#define CONFIG_CMD_PCI_ENUM #define CONFIG_CMD_REGINFO
/* diff --git a/include/configs/xpedite550x.h b/include/configs/xpedite550x.h index 0a09ded4d1..c387d951c1 100644 --- a/include/configs/xpedite550x.h +++ b/include/configs/xpedite550x.h @@ -336,7 +336,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); /* * Command configuration. */ -#define CONFIG_CMD_PCI_ENUM #define CONFIG_CMD_REGINFO
/* diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index ea59f44733..9819f02985 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_PCI_ENUM CONFIG_CMD_PCMCIA CONFIG_CMD_PORTIO CONFIG_CMD_READ
Changes in v2: None
This driver is not used by any board. Drop it.
Changes in v2: None
drivers/pcmcia/Makefile | 1 - drivers/pcmcia/ti_pci1410a.c | 623 ------------------------------------------- 2 files changed, 624 deletions(-) delete mode 100644 drivers/pcmcia/ti_pci1410a.c
diff --git a/drivers/pcmcia/Makefile b/drivers/pcmcia/Makefile index b7e6188429..7d8cb5cb4c 100644 --- a/drivers/pcmcia/Makefile +++ b/drivers/pcmcia/Makefile @@ -5,5 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-$(CONFIG_IDE_TI_CARDBUS) += ti_pci1410a.o obj-$(CONFIG_MARUBUN_PCCARD) += marubun_pcmcia.o diff --git a/drivers/pcmcia/ti_pci1410a.c b/drivers/pcmcia/ti_pci1410a.c deleted file mode 100644 index d83db3f022..0000000000 --- a/drivers/pcmcia/ti_pci1410a.c +++ /dev/null @@ -1,623 +0,0 @@ -/* - * (C) Copyright 2000-2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB - * - * SPDX-License-Identifier: GPL-2.0+ - * - ******************************************************************** - * - * Lots of code copied from: - * - * m8xx_pcmcia.c - Linux PCMCIA socket driver for the mpc8xx series. - * (C) 1999-2000 Magnus Damm damm@bitsmart.com - * - * "The ExCA standard specifies that socket controllers should provide - * two IO and five memory windows per socket, which can be independently - * configured and positioned in the host address space and mapped to - * arbitrary segments of card address space. " - David A Hinds. 1999 - * - * This controller does _not_ meet the ExCA standard. - * - * m8xx pcmcia controller brief info: - * + 8 windows (attrib, mem, i/o) - * + up to two slots (SLOT_A and SLOT_B) - * + inputpins, outputpins, event and mask registers. - * - no offset register. sigh. - * - * Because of the lacking offset register we must map the whole card. - * We assign each memory window PCMCIA_MEM_WIN_SIZE address space. - * Make sure there is (PCMCIA_MEM_WIN_SIZE * PCMCIA_MEM_WIN_NO - * * PCMCIA_SOCKETS_NO) bytes at PCMCIA_MEM_WIN_BASE. - * The i/o windows are dynamically allocated at PCMCIA_IO_WIN_BASE. - * They are maximum 64KByte each... - */ - - -#undef DEBUG /**/ - -/* - * PCMCIA support - */ -#include <common.h> -#include <command.h> -#include <config.h> -#include <pci.h> -#include <asm/io.h> - -#include <pcmcia.h> - -#if defined(CONFIG_CMD_PCMCIA) - -int pcmcia_on(int ide_base_bus); - -static int hardware_disable(int slot); -static int hardware_enable(int slot); -static int voltage_set(int slot, int vcc, int vpp); -static void print_funcid(int func); -static void print_fixed(volatile char *p); -static int identify(volatile char *p); -static int check_ide_device(int slot, int ide_base_bus); - - -/* ------------------------------------------------------------------------- */ - - -const char *indent = "\t "; - -/* ------------------------------------------------------------------------- */ - - -static struct pci_device_id supported[] = { - { PCI_VENDOR_ID_TI, 0xac50 }, /* Ti PCI1410A */ - { PCI_VENDOR_ID_TI, 0xac56 }, /* Ti PCI1510 */ - { } -}; - -static pci_dev_t devbusfn; -static u32 socket_base; -static u32 pcmcia_cis_ptr; - -int pcmcia_on(int ide_base_bus) -{ - u16 dev_id; - u32 socket_status; - int slot = 0; - int cis_len; - u16 io_base; - u16 io_len; - - /* - * Find the CardBus PCI device(s). - */ - if ((devbusfn = pci_find_devices(supported, 0)) < 0) { - printf("Ti CardBus: not found\n"); - return 1; - } - - pci_read_config_word(devbusfn, PCI_DEVICE_ID, &dev_id); - - if (dev_id == 0xac56) { - debug("Enable PCMCIA Ti PCI1510\n"); - } else { - debug("Enable PCMCIA Ti PCI1410A\n"); - } - - pcmcia_cis_ptr = CONFIG_SYS_PCMCIA_CIS_WIN; - cis_len = CONFIG_SYS_PCMCIA_CIS_WIN_SIZE; - - io_base = CONFIG_SYS_PCMCIA_IO_WIN; - io_len = CONFIG_SYS_PCMCIA_IO_WIN_SIZE; - - /* - * Setup the PCI device. - */ - pci_read_config_dword(devbusfn, PCI_BASE_ADDRESS_0, &socket_base); - socket_base &= ~0xf; - - socket_status = readl(socket_base+8); - if ((socket_status & 6) == 0) { - printf("Card Present: "); - - switch (socket_status & 0x3c00) { - - case 0x400: - printf("5V "); - break; - case 0x800: - printf("3.3V "); - break; - case 0xc00: - printf("3.3/5V "); - break; - default: - printf("unsupported Vcc "); - break; - } - switch (socket_status & 0x30) { - case 0x10: - printf("16bit PC-Card\n"); - break; - case 0x20: - printf("32bit CardBus Card\n"); - break; - default: - printf("8bit PC-Card\n"); - break; - } - } - - - writeb(0x41, socket_base + 0x806); /* Enable I/O window 0 and memory window 0 */ - writeb(0x0e, socket_base + 0x807); /* Reset I/O window options */ - - /* Careful: the linux yenta driver do not seem to reset the offset - * in the i/o windows, so leaving them non-zero is a problem */ - - writeb(io_base & 0xff, socket_base + 0x808); /* I/O window 0 base address */ - writeb(io_base>>8, socket_base + 0x809); - writeb((io_base + io_len - 1) & 0xff, socket_base + 0x80a); /* I/O window 0 end address */ - writeb((io_base + io_len - 1)>>8, socket_base + 0x80b); - writeb(0x00, socket_base + 0x836); /* I/O window 0 offset address 0x000 */ - writeb(0x00, socket_base + 0x837); - - - writeb((pcmcia_cis_ptr&0x000ff000) >> 12, - socket_base + 0x810); /* Memory window 0 start address bits 19-12 */ - writeb((pcmcia_cis_ptr&0x00f00000) >> 20, - socket_base + 0x811); /* Memory window 0 start address bits 23-20 */ - writeb(((pcmcia_cis_ptr+cis_len-1) & 0x000ff000) >> 12, - socket_base + 0x812); /* Memory window 0 end address bits 19-12*/ - writeb(((pcmcia_cis_ptr+cis_len-1) & 0x00f00000) >> 20, - socket_base + 0x813); /* Memory window 0 end address bits 23-20*/ - writeb(0x00, socket_base + 0x814); /* Memory window 0 offset bits 19-12 */ - writeb(0x40, socket_base + 0x815); /* Memory window 0 offset bits 23-20 and - * options (read/write, attribute access) */ - writeb(0x00, socket_base + 0x816); /* ExCA card-detect and general control */ - writeb(0x00, socket_base + 0x81e); /* ExCA global control (interrupt modes) */ - - writeb((pcmcia_cis_ptr & 0xff000000) >> 24, - socket_base + 0x840); /* Memory window address bits 31-24 */ - - - /* turn off voltage */ - if (voltage_set(slot, 0, 0)) { - return 1; - } - - /* Enable external hardware */ - if (hardware_enable(slot)) { - return 1; - } - - if (check_ide_device(slot, ide_base_bus)) { - return 1; - } - - return 0; -} - -/* ------------------------------------------------------------------------- */ - - -#if defined(CONFIG_CMD_PCMCIA) -int pcmcia_off (void) -{ - int slot = 0; - - writeb(0x00, socket_base + 0x806); /* disable all I/O and memory windows */ - - writeb(0x00, socket_base + 0x808); /* I/O window 0 base address */ - writeb(0x00, socket_base + 0x809); - writeb(0x00, socket_base + 0x80a); /* I/O window 0 end address */ - writeb(0x00, socket_base + 0x80b); - writeb(0x00, socket_base + 0x836); /* I/O window 0 offset address */ - writeb(0x00, socket_base + 0x837); - - writeb(0x00, socket_base + 0x80c); /* I/O window 1 base address */ - writeb(0x00, socket_base + 0x80d); - writeb(0x00, socket_base + 0x80e); /* I/O window 1 end address */ - writeb(0x00, socket_base + 0x80f); - writeb(0x00, socket_base + 0x838); /* I/O window 1 offset address */ - writeb(0x00, socket_base + 0x839); - - writeb(0x00, socket_base + 0x810); /* Memory window 0 start address */ - writeb(0x00, socket_base + 0x811); - writeb(0x00, socket_base + 0x812); /* Memory window 0 end address */ - writeb(0x00, socket_base + 0x813); - writeb(0x00, socket_base + 0x814); /* Memory window 0 offset */ - writeb(0x00, socket_base + 0x815); - - writeb(0xc0, socket_base + 0x840); /* Memory window 0 page address */ - - - /* turn off voltage */ - voltage_set(slot, 0, 0); - - /* disable external hardware */ - printf ("Shutdown and Poweroff Ti PCI1410A\n"); - hardware_disable(slot); - - return 0; -} - -#endif - -/* ------------------------------------------------------------------------- */ - - -#define MAX_TUPEL_SZ 512 -#define MAX_FEATURES 4 -int ide_devices_found; -static int check_ide_device(int slot, int ide_base_bus) -{ - volatile char *ident = NULL; - volatile char *feature_p[MAX_FEATURES]; - volatile char *p, *start; - int n_features = 0; - uchar func_id = ~0; - uchar code, len; - ushort config_base = 0; - int found = 0; - int i; - u32 socket_status; - - debug ("PCMCIA MEM: %08X\n", pcmcia_cis_ptr); - - socket_status = readl(socket_base+8); - - if ((socket_status & 6) != 0 || (socket_status & 0x20) != 0) { - printf("no card or CardBus card\n"); - return 1; - } - - start = p = (volatile char *) pcmcia_cis_ptr; - - while ((p - start) < MAX_TUPEL_SZ) { - - code = *p; p += 2; - - if (code == 0xFF) { /* End of chain */ - break; - } - - len = *p; p += 2; -#if defined(DEBUG) && (DEBUG > 1) - { - volatile uchar *q = p; - printf ("\nTuple code %02x length %d\n\tData:", - code, len); - - for (i = 0; i < len; ++i) { - printf (" %02x", *q); - q+= 2; - } - } -#endif /* DEBUG */ - switch (code) { - case CISTPL_VERS_1: - ident = p + 4; - break; - case CISTPL_FUNCID: - /* Fix for broken SanDisk which may have 0x80 bit set */ - func_id = *p & 0x7F; - break; - case CISTPL_FUNCE: - if (n_features < MAX_FEATURES) - feature_p[n_features++] = p; - break; - case CISTPL_CONFIG: - config_base = (*(p+6) << 8) + (*(p+4)); - debug ("\n## Config_base = %04x ###\n", config_base); - default: - break; - } - p += 2 * len; - } - - found = identify(ident); - - if (func_id != ((uchar)~0)) { - print_funcid (func_id); - - if (func_id == CISTPL_FUNCID_FIXED) - found = 1; - else - return 1; /* no disk drive */ - } - - for (i=0; i<n_features; ++i) { - print_fixed(feature_p[i]); - } - - if (!found) { - printf("unknown card type\n"); - return 1; - } - - /* select config index 1 */ - writeb(1, pcmcia_cis_ptr + config_base); - -#if 0 - printf("Confiuration Option Register: %02x\n", readb(pcmcia_cis_ptr + config_base)); - printf("Card Confiuration and Status Register: %02x\n", readb(pcmcia_cis_ptr + config_base + 2)); - printf("Pin Replacement Register Register: %02x\n", readb(pcmcia_cis_ptr + config_base + 4)); - printf("Socket and Copy Register: %02x\n", readb(pcmcia_cis_ptr + config_base + 6)); -#endif - ide_devices_found |= (1 << (slot+ide_base_bus)); - - return 0; -} - - -static int voltage_set(int slot, int vcc, int vpp) -{ - u32 socket_control; - int reg=0; - - switch (slot) { - case 0: - reg = socket_base + 0x10; - break; - default: - return 1; - } - - socket_control = 0; - - - switch (vcc) { - case 50: - socket_control |= 0x20; - break; - case 33: - socket_control |= 0x30; - break; - case 0: - default: ; - } - - switch (vpp) { - case 120: - socket_control |= 0x1; - break; - case 50: - socket_control |= 0x2; - break; - case 33: - socket_control |= 0x3; - break; - case 0: - default: ; - } - - writel(socket_control, reg); - - debug ("voltage_set: Ti PCI1410A Slot %d, Vcc=%d.%d, Vpp=%d.%d\n", - slot, vcc/10, vcc%10, vpp/10, vpp%10); - - udelay(500); - return 0; -} - - -static int hardware_enable(int slot) -{ - u32 socket_status; - u16 brg_ctrl; - int is_82365sl; - - socket_status = readl(socket_base+8); - - if ((socket_status & 6) == 0) { - - switch (socket_status & 0x3c00) { - - case 0x400: - printf("5V "); - voltage_set(slot, 50, 0); - break; - case 0x800: - voltage_set(slot, 33, 0); - break; - case 0xc00: - voltage_set(slot, 33, 0); - break; - default: - voltage_set(slot, 0, 0); - break; - } - } else { - voltage_set(slot, 0, 0); - } - - pci_read_config_word(devbusfn, PCI_BRIDGE_CONTROL, &brg_ctrl); - brg_ctrl &= ~PCI_BRIDGE_CTL_BUS_RESET; - pci_write_config_word(devbusfn, PCI_BRIDGE_CONTROL, brg_ctrl); - is_82365sl = ((readb(socket_base+0x800) & 0x0f) == 2); - writeb(is_82365sl?0x90:0x98, socket_base+0x802); - writeb(0x67, socket_base+0x803); - udelay(100000); -#if 0 - printf("ExCA Id %02x, Card Status %02x, Power config %02x, Interrupt Config %02x, bridge control %04x %d\n", - readb(socket_base+0x800), readb(socket_base+0x801), - readb(socket_base+0x802), readb(socket_base+0x803), brg_ctrl, is_82365sl); -#endif - - return ((readb(socket_base+0x801)&0x6c)==0x6c)?0:1; -} - - -static int hardware_disable(int slot) -{ - voltage_set(slot, 0, 0); - return 0; -} - -static void print_funcid(int func) -{ - puts(indent); - switch (func) { - case CISTPL_FUNCID_MULTI: - puts(" Multi-Function"); - break; - case CISTPL_FUNCID_MEMORY: - puts(" Memory"); - break; - case CISTPL_FUNCID_SERIAL: - puts(" Serial Port"); - break; - case CISTPL_FUNCID_PARALLEL: - puts(" Parallel Port"); - break; - case CISTPL_FUNCID_FIXED: - puts(" Fixed Disk"); - break; - case CISTPL_FUNCID_VIDEO: - puts(" Video Adapter"); - break; - case CISTPL_FUNCID_NETWORK: - puts(" Network Adapter"); - break; - case CISTPL_FUNCID_AIMS: - puts(" AIMS Card"); - break; - case CISTPL_FUNCID_SCSI: - puts(" SCSI Adapter"); - break; - default: - puts(" Unknown"); - break; - } - puts(" Card\n"); -} - -/* ------------------------------------------------------------------------- */ - -static void print_fixed(volatile char *p) -{ - if (p == NULL) - return; - - puts(indent); - - switch (*p) { - case CISTPL_FUNCE_IDE_IFACE: - { uchar iface = *(p+2); - - puts ((iface == CISTPL_IDE_INTERFACE) ? " IDE" : " unknown"); - puts (" interface "); - break; - } - case CISTPL_FUNCE_IDE_MASTER: - case CISTPL_FUNCE_IDE_SLAVE: - { - uchar f1 = *(p+2); - uchar f2 = *(p+4); - - puts((f1 & CISTPL_IDE_SILICON) ? " [silicon]" : " [rotating]"); - - if (f1 & CISTPL_IDE_UNIQUE) { - puts(" [unique]"); - } - - puts((f1 & CISTPL_IDE_DUAL) ? " [dual]" : " [single]"); - - if (f2 & CISTPL_IDE_HAS_SLEEP) { - puts(" [sleep]"); - } - - if (f2 & CISTPL_IDE_HAS_STANDBY) { - puts(" [standby]"); - } - - if (f2 & CISTPL_IDE_HAS_IDLE) { - puts(" [idle]"); - } - - if (f2 & CISTPL_IDE_LOW_POWER) { - puts(" [low power]"); - } - - if (f2 & CISTPL_IDE_REG_INHIBIT) { - puts(" [reg inhibit]"); - } - - if (f2 & CISTPL_IDE_HAS_INDEX) { - puts(" [index]"); - } - - if (f2 & CISTPL_IDE_IOIS16) { - puts(" [IOis16]"); - } - - break; - } - } - putc('\n'); -} - -/* ------------------------------------------------------------------------- */ - -#define MAX_IDENT_CHARS 64 -#define MAX_IDENT_FIELDS 4 - -static char *known_cards[] = { - "ARGOSY PnPIDE D5", - NULL -}; - -static int identify(volatile char *p) -{ - char id_str[MAX_IDENT_CHARS]; - char data; - char *t; - char **card; - int i, done; - - if (p == NULL) - return (0); /* Don't know */ - - t = id_str; - done =0; - - for (i=0; i<=4 && !done; ++i, p+=2) { - while ((data = *p) != '\0') { - if (data == 0xFF) { - done = 1; - break; - } - *t++ = data; - if (t == &id_str[MAX_IDENT_CHARS-1]) { - done = 1; - break; - } - p += 2; - } - if (!done) - *t++ = ' '; - } - *t = '\0'; - while (--t > id_str) { - if (*t == ' ') { - *t = '\0'; - } else { - break; - } - } - puts(id_str); - putc('\n'); - - for (card=known_cards; *card; ++card) { - debug ("## Compare against "%s"\n", *card); - if (strcmp(*card, id_str) == 0) { /* found! */ - debug ("## CARD FOUND ##\n"); - return 1; - } - } - - return 0; /* don't know */ -} - -#endif /* CONFIG_CMD_PCMCIA */
Changes in v2: None
This converts the following to Kconfig: CONFIG_CMD_PCMCIA
Changes in v2: - Sort Kconfig options in alphabetical order
README | 1 - cmd/Kconfig | 8 ++++++++ configs/ms7720se_defconfig | 1 + include/config_cmd_all.h | 1 - include/configs/dbau1x00.h | 5 ----- include/configs/ms7720se.h | 1 - scripts/config_whitelist.txt | 1 - 7 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/README b/README index 63dd18ce10..186311bd88 100644 --- a/README +++ b/README @@ -812,7 +812,6 @@ The following options need to be configured: CONFIG_CMD_MII * MII utility commands CONFIG_CMD_NET bootp, tftpboot, rarpboot CONFIG_CMD_NFS NFS support - CONFIG_CMD_PCMCIA * PCMCIA support CONFIG_CMD_PING * send ICMP ECHO_REQUEST to network host CONFIG_CMD_PORTIO * Port I/O diff --git a/cmd/Kconfig b/cmd/Kconfig index 6654050574..7892b0b03f 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -733,6 +733,14 @@ config CMD_PCI peripherals. Sub-commands allow bus enumeration, displaying and changing configuration space and a few other features.
+config CMD_PCMCIA + bool "pinit - Set up PCMCIA device" + help + Provides a means to initialise a PCMCIA (Personal Computer Memory + Card International Association) device. This is an old standard from + about 1990. These devices are typically removable memory or network + cards using a standard 68-pin connector. + config CMD_REMOTEPROC bool "remoteproc" depends on REMOTEPROC diff --git a/configs/ms7720se_defconfig b/configs/ms7720se_defconfig index dd95a236bb..be5e82aeae 100644 --- a/configs/ms7720se_defconfig +++ b/configs/ms7720se_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_IDE=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_PCMCIA=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set diff --git a/include/config_cmd_all.h b/include/config_cmd_all.h index b1f699080e..a008bacdd9 100644 --- a/include/config_cmd_all.h +++ b/include/config_cmd_all.h @@ -13,7 +13,6 @@ * Alphabetical list of all possible commands. */
-#define CONFIG_CMD_PCMCIA /* PCMCIA support */ #define CONFIG_CMD_PORTIO /* Port I/O */ #define CONFIG_CMD_REGINFO /* Register dump */ #define CONFIG_CMD_REISER /* Reiserfs support */ diff --git a/include/configs/dbau1x00.h b/include/configs/dbau1x00.h index 970e214e07..cd65ceaee9 100644 --- a/include/configs/dbau1x00.h +++ b/include/configs/dbau1x00.h @@ -67,11 +67,6 @@ * Command line configuration. */
-#ifdef CONFIG_DBAU1550 - -#undef CONFIG_CMD_PCMCIA -#endif - /* * Miscellaneous configurable options */ diff --git a/include/configs/ms7720se.h b/include/configs/ms7720se.h index 86b93a39bb..112145ce77 100644 --- a/include/configs/ms7720se.h +++ b/include/configs/ms7720se.h @@ -13,7 +13,6 @@ #define CONFIG_MS7720SE 1
#define CONFIG_CMD_SDRAM -#define CONFIG_CMD_PCMCIA
#define CONFIG_BOOTARGS "console=ttySC0,115200" #define CONFIG_BOOTFILE "/boot/zImage" diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 9819f02985..6b7056d6ea 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_PCMCIA CONFIG_CMD_PORTIO CONFIG_CMD_READ CONFIG_CMD_REGINFO
Changes in v2:
This command is not used by any board. It also looks quite similar to the 'iod' and 'iow' commands which use the correct I/O macros.
Drop it.
Changes in v2: - Drop mention of this from several other places - Move CMD_PORTIO changes in from the CMD_READ patch
README | 1 - cmd/Makefile | 1 - cmd/portio.c | 145 ------------------------------------------- include/command.h | 9 ++- include/config_cmd_all.h | 1 - scripts/config_whitelist.txt | 1 - 6 files changed, 4 insertions(+), 154 deletions(-) delete mode 100644 cmd/portio.c
diff --git a/README b/README index 186311bd88..06a9b2eca9 100644 --- a/README +++ b/README @@ -814,7 +814,6 @@ The following options need to be configured: CONFIG_CMD_NFS NFS support CONFIG_CMD_PING * send ICMP ECHO_REQUEST to network host - CONFIG_CMD_PORTIO * Port I/O CONFIG_CMD_READ * Read raw data from partition CONFIG_CMD_REGINFO * Register dump CONFIG_CMD_RUN run command in env variable diff --git a/cmd/Makefile b/cmd/Makefile index bd231f24d8..eff6bd678f 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -97,7 +97,6 @@ ifdef CONFIG_PCI obj-$(CONFIG_CMD_PCI) += pci.o endif obj-y += pcmcia.o -obj-$(CONFIG_CMD_PORTIO) += portio.o obj-$(CONFIG_CMD_PXE) += pxe.o obj-$(CONFIG_CMD_QFW) += qfw.o obj-$(CONFIG_CMD_READ) += read.o diff --git a/cmd/portio.c b/cmd/portio.c deleted file mode 100644 index bf3a99791c..0000000000 --- a/cmd/portio.c +++ /dev/null @@ -1,145 +0,0 @@ -/* - * (C) Copyright 2003 - * Marc Singer, elf@buici.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * Port I/O Functions - * - * Copied from FADS ROM, Dan Malek (dmalek@jlc.net) - */ - -#include <common.h> -#include <command.h> - -/* Display values from last command. - * Memory modify remembered values are different from display memory. - */ -static uint in_last_addr, in_last_size; -static uint out_last_addr, out_last_size, out_last_value; - - -int do_portio_out (cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) -{ - uint addr = out_last_addr; - uint size = out_last_size; - uint value = out_last_value; - - if (argc != 3) - return CMD_RET_USAGE; - - if ((flag & CMD_FLAG_REPEAT) == 0) { - /* - * New command specified. Check for a size specification. - * Defaults to long if no or incorrect specification. - */ - size = cmd_get_data_size (argv[0], 1); - addr = simple_strtoul (argv[1], NULL, 16); - value = simple_strtoul (argv[2], NULL, 16); - } -#if defined (CONFIG_X86) - - { - unsigned short port = addr; - - switch (size) { - default: - case 1: - { - unsigned char ch = value; - __asm__ volatile ("out %0, %%dx"::"a" (ch), "d" (port)); - } - break; - case 2: - { - unsigned short w = value; - __asm__ volatile ("out %0, %%dx"::"a" (w), "d" (port)); - } - break; - case 4: - __asm__ volatile ("out %0, %%dx"::"a" (value), "d" (port)); - - break; - } - } - -#endif /* CONFIG_X86 */ - - out_last_addr = addr; - out_last_size = size; - out_last_value = value; - - return 0; -} - -U_BOOT_CMD( - out, 3, 1, do_portio_out, - "write datum to IO port", - "[.b, .w, .l] port value\n - output to IO port" -); - -int do_portio_in (cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) -{ - uint addr = in_last_addr; - uint size = in_last_size; - - if (argc != 2) - return CMD_RET_USAGE; - - if ((flag & CMD_FLAG_REPEAT) == 0) { - /* - * New command specified. Check for a size specification. - * Defaults to long if no or incorrect specification. - */ - size = cmd_get_data_size (argv[0], 1); - addr = simple_strtoul (argv[1], NULL, 16); - } -#if defined (CONFIG_X86) - - { - unsigned short port = addr; - - switch (size) { - default: - case 1: - { - unsigned char ch; - __asm__ volatile ("in %%dx, %0":"=a" (ch):"d" (port)); - - printf (" %02x\n", ch); - } - break; - case 2: - { - unsigned short w; - __asm__ volatile ("in %%dx, %0":"=a" (w):"d" (port)); - - printf (" %04x\n", w); - } - break; - case 4: - { - unsigned long l; - __asm__ volatile ("in %%dx, %0":"=a" (l):"d" (port)); - - printf (" %08lx\n", l); - } - break; - } - } -#endif /* CONFIG_X86 */ - - in_last_addr = addr; - in_last_size = size; - - return 0; -} - -U_BOOT_CMD( - in, 2, 1, do_portio_in, - "read data from an IO port", - "[.b, .w, .l] port\n" - " - read datum from IO port" -); diff --git a/include/command.h b/include/command.h index 08f04867dd..767cabb3df 100644 --- a/include/command.h +++ b/include/command.h @@ -80,11 +80,10 @@ int cmd_process_error(cmd_tbl_t *cmdtp, int err); * void function (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); */
-#if defined(CONFIG_CMD_MEMORY) \ - || defined(CONFIG_CMD_I2C) \ - || defined(CONFIG_CMD_ITEST) \ - || defined(CONFIG_CMD_PCI) \ - || defined(CONFIG_CMD_PORTIO) +#if defined(CONFIG_CMD_MEMORY) || \ + defined(CONFIG_CMD_I2C) || \ + defined(CONFIG_CMD_ITEST) || \ + defined(CONFIG_CMD_PCI) #define CMD_DATA_SIZE extern int cmd_get_data_size(char* arg, int default_size); #endif diff --git a/include/config_cmd_all.h b/include/config_cmd_all.h index a008bacdd9..35a6a529eb 100644 --- a/include/config_cmd_all.h +++ b/include/config_cmd_all.h @@ -13,7 +13,6 @@ * Alphabetical list of all possible commands. */
-#define CONFIG_CMD_PORTIO /* Port I/O */ #define CONFIG_CMD_REGINFO /* Register dump */ #define CONFIG_CMD_REISER /* Reiserfs support */ #define CONFIG_CMD_READ /* Read data from partition */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 6b7056d6ea..899fd501ad 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_PORTIO CONFIG_CMD_READ CONFIG_CMD_REGINFO CONFIG_CMD_REISER
Drop it.
Changes in v2:
Drop it.
Changes in v2:
Drop it.
Convert this option and enable it in sandbox. Also correct a bug which was introduced with the block-device driver model conversion.
Changes in v2: - Move CMD_PORTIO changes to previous patch - Sort Kconfig options in alphabetical order
README | 1 - cmd/Kconfig | 5 +++++ cmd/read.c | 2 +- configs/sandbox_defconfig | 3 +++ include/config_cmd_all.h | 1 - scripts/config_whitelist.txt | 1 - 6 files changed, 9 insertions(+), 4 deletions(-)
diff --git a/README b/README index 06a9b2eca9..2e813b7bcb 100644 --- a/README +++ b/README @@ -814,7 +814,6 @@ The following options need to be configured: CONFIG_CMD_NFS NFS support CONFIG_CMD_PING * send ICMP ECHO_REQUEST to network host - CONFIG_CMD_READ * Read raw data from partition CONFIG_CMD_REGINFO * Register dump CONFIG_CMD_RUN run command in env variable CONFIG_CMD_SANDBOX * sb command to access sandbox features diff --git a/cmd/Kconfig b/cmd/Kconfig index 7892b0b03f..15dcfbf1e9 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -741,6 +741,11 @@ config CMD_PCMCIA about 1990. These devices are typically removable memory or network cards using a standard 68-pin connector.
+config CMD_READ + bool "read - Read binary data from a partition" + help + Provides low-level access to the data in a partition. + config CMD_REMOTEPROC bool "remoteproc" depends on REMOTEPROC diff --git a/cmd/read.c b/cmd/read.c index 61d8ce73e4..ecf925426f 100644 --- a/cmd/read.c +++ b/cmd/read.c @@ -66,7 +66,7 @@ int do_read(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 1; }
- if (blk_read(dev_desc, offset + blk, cnt, addr) < 0) { + if (blk_dread(dev_desc, offset + blk, cnt, addr) < 0) { printf("Error reading blocks\n"); return 1; } diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 3fe2702d30..a1844d30a2 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -193,3 +193,6 @@ CONFIG_UNIT_TEST=y CONFIG_UT_TIME=y CONFIG_UT_DM=y CONFIG_UT_ENV=y +CONFIG_CMD_MTDPARTS=y +CONFIG_CMD_MTDPARTS_SPREAD=y +CONFIG_CMD_READ=y diff --git a/include/config_cmd_all.h b/include/config_cmd_all.h index 35a6a529eb..edfc91ff9b 100644 --- a/include/config_cmd_all.h +++ b/include/config_cmd_all.h @@ -15,7 +15,6 @@
#define CONFIG_CMD_REGINFO /* Register dump */ #define CONFIG_CMD_REISER /* Reiserfs support */ -#define CONFIG_CMD_READ /* Read data from partition */ #define CONFIG_CMD_SANDBOX /* sb command to access sandbox features */ #define CONFIG_CMD_SAVES /* save S record dump */ #define CONFIG_CMD_SDRAM /* SDRAM DIMM SPD info printout */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 899fd501ad..33a408891e 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_READ CONFIG_CMD_REGINFO CONFIG_CMD_REISER CONFIG_CMD_SANDBOX
Changes in v2:
Changes in v2:
This patch converts CONFIG_CMD_REGINFO to Kconfig
Signed-off-by: Christophe Leroy christophe.leroy@c-s.fr Signed-off-by: Simon Glass sjg@chromium.org ---
Changes in v2: - Fixed lots of merge conflicts with my series - Pull in this patch from http://patchwork.ozlabs.org/patch/787724/ instead
README | 1 - arch/powerpc/Kconfig | 3 +++ cmd/Kconfig | 5 +++++ include/config_cmd_all.h | 1 - include/configs/B4860QDS.h | 5 ----- include/configs/BSC9131RDB.h | 5 ----- include/configs/BSC9132QDS.h | 5 ----- include/configs/C29XPCIE.h | 5 ----- include/configs/MCR3000.h | 3 --- include/configs/MPC8536DS.h | 5 ----- include/configs/MPC8541CDS.h | 5 ----- include/configs/MPC8544DS.h | 5 ----- include/configs/MPC8548CDS.h | 5 ----- include/configs/MPC8555CDS.h | 5 ----- include/configs/MPC8560ADS.h | 8 -------- include/configs/MPC8568MDS.h | 5 ----- include/configs/MPC8569MDS.h | 5 ----- include/configs/MPC8572DS.h | 5 ----- include/configs/MPC8610HPCD.h | 2 -- include/configs/MPC8641HPCN.h | 5 ----- include/configs/P1010RDB.h | 5 ----- include/configs/P1022DS.h | 5 ----- include/configs/P1023RDB.h | 5 ----- include/configs/T102xQDS.h | 5 ----- include/configs/T102xRDB.h | 5 ----- include/configs/T1040QDS.h | 5 ----- include/configs/T104xRDB.h | 5 ----- include/configs/T208xQDS.h | 5 ----- include/configs/T208xRDB.h | 5 ----- include/configs/T4240RDB.h | 2 -- include/configs/TQM834x.h | 5 ----- include/configs/UCP1020.h | 5 ----- include/configs/controlcenterd.h | 3 --- include/configs/corenet_ds.h | 5 ----- include/configs/cyrus.h | 5 ----- include/configs/p1_p2_rdb_pc.h | 5 ----- include/configs/p1_twr.h | 5 ----- include/configs/qemu-ppce500.h | 2 -- include/configs/sbc8548.h | 5 ----- include/configs/sbc8641d.h | 2 -- include/configs/smdkc100.h | 3 --- include/configs/socrates.h | 1 - include/configs/t4qds.h | 2 -- include/configs/xpedite517x.h | 5 ----- include/configs/xpedite520x.h | 5 ----- include/configs/xpedite537x.h | 5 ----- include/configs/xpedite550x.h | 5 ----- scripts/config_whitelist.txt | 1 - 48 files changed, 8 insertions(+), 196 deletions(-)
diff --git a/README b/README index 2e813b7bcb..9b64ef06f4 100644 --- a/README +++ b/README @@ -814,7 +814,6 @@ The following options need to be configured: CONFIG_CMD_NFS NFS support CONFIG_CMD_PING * send ICMP ECHO_REQUEST to network host - CONFIG_CMD_REGINFO * Register dump CONFIG_CMD_RUN run command in env variable CONFIG_CMD_SANDBOX * sb command to access sandbox features CONFIG_CMD_SAVES * save S record dump diff --git a/arch/powerpc/Kconfig b/arch/powerpc/Kconfig index 8094416e4a..c79b247651 100644 --- a/arch/powerpc/Kconfig +++ b/arch/powerpc/Kconfig @@ -23,15 +23,18 @@ config MPC85xx imply USB_EHCI_HCD if USB imply CMD_HASH imply CMD_IRQ + imply CMD_REGINFO
config MPC86xx bool "MPC86xx" select SYS_FSL_DDR select SYS_FSL_DDR_BE imply ENV_IS_IN_FLASH + imply CMD_REGINFO
config 8xx bool "MPC8xx" + imply CMD_REGINFO
endchoice
diff --git a/cmd/Kconfig b/cmd/Kconfig index 15dcfbf1e9..070536ac23 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -158,6 +158,11 @@ config CMD_LICENSE help Print GPL license text
+config CMD_REGINFO + bool "reginfo" + help + Register dump + endmenu
menu "Boot commands" diff --git a/include/config_cmd_all.h b/include/config_cmd_all.h index edfc91ff9b..cb0ab6d61a 100644 --- a/include/config_cmd_all.h +++ b/include/config_cmd_all.h @@ -13,7 +13,6 @@ * Alphabetical list of all possible commands. */
-#define CONFIG_CMD_REGINFO /* Register dump */ #define CONFIG_CMD_REISER /* Reiserfs support */ #define CONFIG_CMD_SANDBOX /* sb command to access sandbox features */ #define CONFIG_CMD_SAVES /* save S record dump */ diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index 984803d440..ce9be95e7e 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -690,11 +690,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */
-/* - * Command line configuration. - */ -#define CONFIG_CMD_REGINFO - /* * USB */ diff --git a/include/configs/BSC9131RDB.h b/include/configs/BSC9131RDB.h index a7c97a3b79..38407af3c7 100644 --- a/include/configs/BSC9131RDB.h +++ b/include/configs/BSC9131RDB.h @@ -286,11 +286,6 @@ extern unsigned long get_sdram_size(void); #define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */
-/* - * Command line configuration. - */ -#define CONFIG_CMD_REGINFO - /* * Miscellaneous configurable options */ diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index b385cf4a97..8f2bccddb5 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -509,11 +509,6 @@ combinations. this should be removed later #define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */
-/* - * Command line configuration. - */ -#define CONFIG_CMD_REGINFO - /* * Miscellaneous configurable options */ diff --git a/include/configs/C29XPCIE.h b/include/configs/C29XPCIE.h index a00d3872e3..c88715f601 100644 --- a/include/configs/C29XPCIE.h +++ b/include/configs/C29XPCIE.h @@ -427,11 +427,6 @@ #define CONFIG_LOADS_ECHO #define CONFIG_SYS_LOADS_BAUD_CHANGE
-/* - * Command line configuration. - */ -#define CONFIG_CMD_REGINFO - /* * Miscellaneous configurable options */ diff --git a/include/configs/MCR3000.h b/include/configs/MCR3000.h index 17090da796..aabbab6e05 100644 --- a/include/configs/MCR3000.h +++ b/include/configs/MCR3000.h @@ -151,7 +151,4 @@ #define BOOTFLAG_COLD 0x01 #define BOOTFLAG_WARM 0x02
-/* Misc Settings */ -#define CONFIG_CMD_REGINFO - #endif /* __CONFIG_H */ diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 277c9d00a7..11a7950e4d 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -580,11 +580,6 @@ #define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
-/* - * Command line configuration. - */ -#define CONFIG_CMD_REGINFO - #undef CONFIG_WATCHDOG /* watchdog disabled */
#ifdef CONFIG_MMC diff --git a/include/configs/MPC8541CDS.h b/include/configs/MPC8541CDS.h index 3867b31e23..aa450fcaa4 100644 --- a/include/configs/MPC8541CDS.h +++ b/include/configs/MPC8541CDS.h @@ -338,11 +338,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
/* diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index cea37f8ae4..1c8e031a7e 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -344,11 +344,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
-/* - * Command line configuration. - */ -#define CONFIG_CMD_REGINFO - /* * USB */ diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index 7c98bcb035..58cd674a5f 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -457,11 +457,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
/* diff --git a/include/configs/MPC8555CDS.h b/include/configs/MPC8555CDS.h index 3dc24bd74e..b580c33070 100644 --- a/include/configs/MPC8555CDS.h +++ b/include/configs/MPC8555CDS.h @@ -336,11 +336,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
/* diff --git a/include/configs/MPC8560ADS.h b/include/configs/MPC8560ADS.h index 8b8be2da0e..672ae5007c 100644 --- a/include/configs/MPC8560ADS.h +++ b/include/configs/MPC8560ADS.h @@ -349,14 +349,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
-/* - * Command line configuration. - */ -#define CONFIG_CMD_REGINFO - -#if defined(CONFIG_ETHER_ON_FCC) -#endif - #undef CONFIG_WATCHDOG /* watchdog disabled */
/* diff --git a/include/configs/MPC8568MDS.h b/include/configs/MPC8568MDS.h index e6b1ea982f..29f3d09cfd 100644 --- a/include/configs/MPC8568MDS.h +++ b/include/configs/MPC8568MDS.h @@ -351,11 +351,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
/* diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index 6f2fa4939a..a0d48af908 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -443,11 +443,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
#ifdef CONFIG_MMC diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index a75d30851b..2d905e4732 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -542,11 +542,6 @@ #define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
-/* - * Command line configuration. - */ -#define CONFIG_CMD_REGINFO - /* * USB */ diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index 807624e2ce..e13fff0375 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -262,8 +262,6 @@
#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */
-#define CONFIG_CMD_REGINFO - #define CONFIG_ULI526X #ifdef CONFIG_ULI526X #endif diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index b74ef38513..607e8bd114 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -582,11 +582,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
/* diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 9f52a6fc48..a61c59f7fa 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -711,11 +711,6 @@ extern unsigned long get_sdram_size(void); #define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */
#if defined(CONFIG_MMC) || defined(CONFIG_USB_EHCI_HCD) \ diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index 152f0d89f0..fe7c677946 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -582,11 +582,6 @@ #define CONFIG_LOADS_ECHO #define CONFIG_SYS_LOADS_BAUD_CHANGE
-/* - * Command line configuration. - */ -#define CONFIG_CMD_REGINFO - /* * USB */ diff --git a/include/configs/P1023RDB.h b/include/configs/P1023RDB.h index 45dcb6b04b..3522c32a72 100644 --- a/include/configs/P1023RDB.h +++ b/include/configs/P1023RDB.h @@ -236,11 +236,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */
-/* - * Command line configuration. - */ -#define CONFIG_CMD_REGINFO - /* * USB */ diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index 1adbf1ae90..e4f8e7d980 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -768,11 +768,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */
-/* - * Command line configuration. - */ -#define CONFIG_CMD_REGINFO - /* * Miscellaneous configurable options */ diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 7a33b8a19e..7c81dc428e 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -779,11 +779,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */
-/* - * Command line configuration. - */ -#define CONFIG_CMD_REGINFO - /* * Miscellaneous configurable options */ diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 0f0e149572..de60b21e35 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -647,11 +647,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */
-/* - * Command line configuration. - */ -#define CONFIG_CMD_REGINFO - /* * Miscellaneous configurable options */ diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 34578cc819..84bcecbb05 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -762,11 +762,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg #define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */
-/* - * Command line configuration. - */ -#define CONFIG_CMD_REGINFO - /* * Miscellaneous configurable options */ diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index b45e634ddb..28e4bb01fb 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -733,11 +733,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */
-/* - * Command line configuration. - */ -#define CONFIG_CMD_REGINFO - /* * Miscellaneous configurable options */ diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index b5b7a4a8fb..a91d39e4eb 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -679,11 +679,6 @@ unsigned long get_board_ddr_clk(void); * Environment */
-/* - * Command line configuration. - */ -#define CONFIG_CMD_REGINFO - /* * Miscellaneous configurable options */ diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 1b56020c10..0717ae5a1e 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -56,8 +56,6 @@
#define CONFIG_DDR_ECC
-#define CONFIG_CMD_REGINFO - /* High Level Configuration Options */ #define CONFIG_SYS_BOOK3E_HV /* Category E.HV supported */ #define CONFIG_MP /* support multiple processors */ diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index aab8b5d9f2..b9923c316b 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -213,11 +213,6 @@
#endif /* CONFIG_TSEC_ENET */
-/* - * General PCI - * Addresses are mapped 1-1. - */ - #if defined(CONFIG_PCI)
#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index 6573301493..53d4bfa2f0 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -410,11 +410,6 @@ #define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */
-/* - * Command line configuration. - */ -#define CONFIG_CMD_REGINFO - /* * USB */ diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index 55d705c2fc..3b0290ccc4 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -335,9 +335,6 @@ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
#ifndef CONFIG_TRAILBLAZER - -#define CONFIG_CMD_REGINFO - /* * Board initialisation callbacks */ diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 19f3a55e9a..08c51e3434 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -580,11 +580,6 @@ #define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */
-/* - * Command line configuration. - */ -#define CONFIG_CMD_REGINFO - /* * USB */ diff --git a/include/configs/cyrus.h b/include/configs/cyrus.h index 5ba393a7db..aaa7a619ca 100644 --- a/include/configs/cyrus.h +++ b/include/configs/cyrus.h @@ -406,11 +406,6 @@ #define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */
-/* - * Command line configuration. - */ -#define CONFIG_CMD_REGINFO - /* * USB */ diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index d9829d6125..0a2c8611a1 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -798,11 +798,6 @@ #define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */
-/* - * Command line configuration. - */ -#define CONFIG_CMD_REGINFO - /* * USB */ diff --git a/include/configs/p1_twr.h b/include/configs/p1_twr.h index 795d238b6d..a992763d05 100644 --- a/include/configs/p1_twr.h +++ b/include/configs/p1_twr.h @@ -374,11 +374,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */
-/* - * Command line configuration. - */ -#define CONFIG_CMD_REGINFO - /* * USB */ diff --git a/include/configs/qemu-ppce500.h b/include/configs/qemu-ppce500.h index 2c9a3466f7..e0cc873e06 100644 --- a/include/configs/qemu-ppce500.h +++ b/include/configs/qemu-ppce500.h @@ -10,8 +10,6 @@ #ifndef __QEMU_PPCE500_H #define __QEMU_PPCE500_H
-#define CONFIG_CMD_REGINFO - #undef CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_TEXT_BASE 0xf01000 /* 15 MB */
diff --git a/include/configs/sbc8548.h b/include/configs/sbc8548.h index c2f533b0a1..28e53b1c2c 100644 --- a/include/configs/sbc8548.h +++ b/include/configs/sbc8548.h @@ -507,11 +507,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
/* diff --git a/include/configs/sbc8641d.h b/include/configs/sbc8641d.h index de123fdd9c..dcce2ba193 100644 --- a/include/configs/sbc8641d.h +++ b/include/configs/sbc8641d.h @@ -450,8 +450,6 @@ #define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
/* diff --git a/include/configs/smdkc100.h b/include/configs/smdkc100.h index 58abac5eef..f5d541d20b 100644 --- a/include/configs/smdkc100.h +++ b/include/configs/smdkc100.h @@ -56,9 +56,6 @@ /* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE
-/*********************************************************** - * Command definition - ***********************************************************/ #define CONFIG_MTD_DEVICE #define CONFIG_MTD_PARTITIONS
diff --git a/include/configs/socrates.h b/include/configs/socrates.h index b6ea44e3c0..cce7f901af 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -278,7 +278,6 @@ * Command line configuration. */ #define CONFIG_CMD_SDRAM -#define CONFIG_CMD_REGINFO
diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h index 23b6bf0361..ce138f843f 100644 --- a/include/configs/t4qds.h +++ b/include/configs/t4qds.h @@ -10,8 +10,6 @@ #ifndef __T4QDS_H #define __T4QDS_H
-#define CONFIG_CMD_REGINFO - /* High Level Configuration Options */ #define CONFIG_SYS_BOOK3E_HV /* Category E.HV supported */ #define CONFIG_MP /* support multiple processors */ diff --git a/include/configs/xpedite517x.h b/include/configs/xpedite517x.h index 57fc16812e..3753871343 100644 --- a/include/configs/xpedite517x.h +++ b/include/configs/xpedite517x.h @@ -481,11 +481,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); BATL_CACHEINHIBIT) #define CONFIG_SYS_IBAT7U CONFIG_SYS_DBAT7U
-/* - * Command configuration. - */ -#define CONFIG_CMD_REGINFO - /* * Miscellaneous configurable options */ diff --git a/include/configs/xpedite520x.h b/include/configs/xpedite520x.h index 628de82767..7a37b5cf7e 100644 --- a/include/configs/xpedite520x.h +++ b/include/configs/xpedite520x.h @@ -284,11 +284,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_GATEWAY
-/* - * Command configuration. - */ -#define CONFIG_CMD_REGINFO - /* * Miscellaneous configurable options */ diff --git a/include/configs/xpedite537x.h b/include/configs/xpedite537x.h index c599b22bc8..47affb5e74 100644 --- a/include/configs/xpedite537x.h +++ b/include/configs/xpedite537x.h @@ -334,11 +334,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define TSEC2_PHYIDX 0 #define CONFIG_HAS_ETH1
-/* - * Command configuration. - */ -#define CONFIG_CMD_REGINFO - /* * Miscellaneous configurable options */ diff --git a/include/configs/xpedite550x.h b/include/configs/xpedite550x.h index c387d951c1..60b9c00e26 100644 --- a/include/configs/xpedite550x.h +++ b/include/configs/xpedite550x.h @@ -333,11 +333,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_USB_EHCI_FSL #define CONFIG_EHCI_HCD_INIT_AFTER_RESET
-/* - * Command configuration. - */ -#define CONFIG_CMD_REGINFO - /* * Miscellaneous configurable options */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 33a408891e..01087839ee 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_REGINFO CONFIG_CMD_REISER CONFIG_CMD_SANDBOX CONFIG_CMD_SAVES
Changes in v2:
Signed-off-by: Christophe Leroy christophe.leroy@c-s.fr Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com
Changes in v2:
Signed-off-by: Christophe Leroy christophe.leroy@c-s.fr Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
With a few more changes to the imply logic to not add this on boards that didn't have it before, applied to u-boot/master, thanks!
This converts the following to Kconfig: CONFIG_CMD_REISER
Changes in v2: None
cmd/Kconfig | 9 +++++++++ configs/ethernut5_defconfig | 1 + include/config_cmd_all.h | 1 - include/configs/ethernut5.h | 1 - scripts/config_whitelist.txt | 1 - 5 files changed, 10 insertions(+), 3 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 070536ac23..6a39e26256 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1266,6 +1266,15 @@ config CMD_MTDPARTS_SPREAD at least as large as the size specified in the mtdparts variable and 2) each partition starts on a good block.
+config CMD_REISER + bool "reiser - Access to reiserfs filesystems" + help + This provides two commands which operate on a resierfs filesystem, + commonly used some years ago: + + reiserls - list files + reiserload - load a file + endmenu
menu "Debug commands" diff --git a/configs/ethernut5_defconfig b/configs/ethernut5_defconfig index 65a21732e7..6a34363f1e 100644 --- a/configs/ethernut5_defconfig +++ b/configs/ethernut5_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y +CONFIG_CMD_REISER=y CONFIG_CMD_UBI=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/include/config_cmd_all.h b/include/config_cmd_all.h index cb0ab6d61a..00bc6fc88a 100644 --- a/include/config_cmd_all.h +++ b/include/config_cmd_all.h @@ -13,7 +13,6 @@ * Alphabetical list of all possible commands. */
-#define CONFIG_CMD_REISER /* Reiserfs support */ #define CONFIG_CMD_SANDBOX /* sb command to access sandbox features */ #define CONFIG_CMD_SAVES /* save S record dump */ #define CONFIG_CMD_SDRAM /* SDRAM DIMM SPD info printout */ diff --git a/include/configs/ethernut5.h b/include/configs/ethernut5.h index 8bec154f43..cdad2e6d49 100644 --- a/include/configs/ethernut5.h +++ b/include/configs/ethernut5.h @@ -83,7 +83,6 @@ #define CONFIG_AT91_GPIO
#ifndef MINIMAL_LOADER -#define CONFIG_CMD_REISER #define CONFIG_CMD_SAVES #endif
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 01087839ee..64f18f0af1 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_REISER CONFIG_CMD_SANDBOX CONFIG_CMD_SAVES CONFIG_CMD_SCSI
Changes in v2: None
This is no-longer used. Drop it.
Changes in v2: None
README | 1 - include/config_cmd_all.h | 1 - include/configs/sandbox.h | 2 -- scripts/config_whitelist.txt | 1 - 4 files changed, 5 deletions(-)
diff --git a/README b/README index 9b64ef06f4..3a4e3a8f45 100644 --- a/README +++ b/README @@ -815,7 +815,6 @@ The following options need to be configured: CONFIG_CMD_PING * send ICMP ECHO_REQUEST to network host CONFIG_CMD_RUN run command in env variable - CONFIG_CMD_SANDBOX * sb command to access sandbox features CONFIG_CMD_SAVES * save S record dump CONFIG_CMD_SDRAM * print SDRAM configuration information (requires CONFIG_CMD_I2C) diff --git a/include/config_cmd_all.h b/include/config_cmd_all.h index 00bc6fc88a..87fba76cc9 100644 --- a/include/config_cmd_all.h +++ b/include/config_cmd_all.h @@ -13,7 +13,6 @@ * Alphabetical list of all possible commands. */
-#define CONFIG_CMD_SANDBOX /* sb command to access sandbox features */ #define CONFIG_CMD_SAVES /* save S record dump */ #define CONFIG_CMD_SDRAM /* SDRAM DIMM SPD info printout */ #define CONFIG_CMD_TERMINAL /* built-in Serial Terminal */ diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index 28ad0a12e1..beb5a124a2 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -94,8 +94,6 @@ #define CONFIG_BOOTP_SERVERIP #define CONFIG_IP_DEFRAG
-#define CONFIG_CMD_SANDBOX - #define CONFIG_BOOTARGS ""
#ifndef SANDBOX_NO_SDL diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 64f18f0af1..fd093f797d 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_SANDBOX CONFIG_CMD_SAVES CONFIG_CMD_SCSI CONFIG_CMD_SDRAM
Changes in v2: None
This converts the following to Kconfig: CONFIG_CMD_SAVES
Changes in v2: - Put Kconfig change in alphabetical order - Remove some now-superfluous /* commands */ comments in header files
README | 1 - arch/arm/Kconfig | 6 ++++++ cmd/Kconfig | 6 ++++++ configs/ethernut5_defconfig | 1 + configs/microblaze-generic_defconfig | 1 + configs/x600_defconfig | 1 + configs/xtfpga_defconfig | 1 + include/config_cmd_all.h | 1 - include/configs/calimain.h | 8 -------- include/configs/da850evm.h | 5 ----- include/configs/ea20.h | 5 ----- include/configs/ethernut5.h | 1 - include/configs/ipam390.h | 5 ----- include/configs/legoev3.h | 5 ----- include/configs/microblaze-generic.h | 18 ------------------ include/configs/omapl138_lcdk.h | 4 ---- include/configs/spear-common.h | 5 ----- include/configs/ti_armv7_keystone2.h | 3 --- include/configs/x600.h | 5 ----- include/configs/xtfpga.h | 6 ------ scripts/config_whitelist.txt | 1 - 21 files changed, 16 insertions(+), 73 deletions(-)
diff --git a/README b/README index 3a4e3a8f45..318a4aa25d 100644 --- a/README +++ b/README @@ -815,7 +815,6 @@ The following options need to be configured: CONFIG_CMD_PING * send ICMP ECHO_REQUEST to network host CONFIG_CMD_RUN run command in env variable - CONFIG_CMD_SAVES * save S record dump CONFIG_CMD_SDRAM * print SDRAM configuration information (requires CONFIG_CMD_I2C) CONFIG_CMD_SF * Read/write/erase SPI NOR flash diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 7f6ab4ac7e..5e42e7b030 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -308,6 +308,7 @@ config TARGET_GPLUGD config ARCH_DAVINCI bool "TI DaVinci" select CPU_ARM926EJS + imply CMD_SAVES help Support for TI's DaVinci platform.
@@ -409,21 +410,25 @@ config TARGET_SPEAR300 bool "Support spear300" select CPU_ARM926EJS select BOARD_EARLY_INIT_F + imply CMD_SAVES
config TARGET_SPEAR310 bool "Support spear310" select CPU_ARM926EJS select BOARD_EARLY_INIT_F + imply CMD_SAVES
config TARGET_SPEAR320 bool "Support spear320" select CPU_ARM926EJS select BOARD_EARLY_INIT_F + imply CMD_SAVES
config TARGET_SPEAR600 bool "Support spear600" select CPU_ARM926EJS select BOARD_EARLY_INIT_F + imply CMD_SAVES
config TARGET_STV0991 bool "Support stv0991" @@ -572,6 +577,7 @@ config ARCH_KEYSTONE select CMD_POWEROFF imply CMD_MTDPARTS imply FIT + imply CMD_SAVES
config ARCH_OMAP2PLUS bool "TI OMAP2+" diff --git a/cmd/Kconfig b/cmd/Kconfig index 6a39e26256..f90673f95b 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -770,6 +770,12 @@ config CMD_SATA Attachment, where AT refers to an IBM AT (Advanced Technology) computer released in 1984.
+config CMD_SAVES + bool "saves - Save a file over serial in S-Record format" + help + Provides a way to save a binary file using the Motorola S-Record + format over the serial line. + config CMD_SF bool "sf" help diff --git a/configs/ethernut5_defconfig b/configs/ethernut5_defconfig index 6a34363f1e..033e214a04 100644 --- a/configs/ethernut5_defconfig +++ b/configs/ethernut5_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_SAVES=y CONFIG_CMD_RARP=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/microblaze-generic_defconfig b/configs/microblaze-generic_defconfig index f97459e6a8..789488e735 100644 --- a/configs/microblaze-generic_defconfig +++ b/configs/microblaze-generic_defconfig @@ -24,6 +24,7 @@ CONFIG_SYS_PROMPT="U-Boot-mONStR> " CONFIG_CMD_ASKENV=y CONFIG_CMD_GPIO=y CONFIG_CMD_MFSL=y +CONFIG_CMD_SAVES=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y diff --git a/configs/x600_defconfig b/configs/x600_defconfig index d46289179f..cfc537a523 100644 --- a/configs/x600_defconfig +++ b/configs/x600_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_FPGA_LOADMK=y CONFIG_CMD_GPIO=y +CONFIG_CMD_SAVES=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/xtfpga_defconfig b/configs/xtfpga_defconfig index e52e62b201..f28c05f156 100644 --- a/configs/xtfpga_defconfig +++ b/configs/xtfpga_defconfig @@ -10,6 +10,7 @@ CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press <SPACE> to stop\n" CONFIG_AUTOBOOT_STOP_STR=" " CONFIG_CMD_ASKENV=y CONFIG_CRC32_VERIFY=y +CONFIG_CMD_SAVES=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_DIAG=y diff --git a/include/config_cmd_all.h b/include/config_cmd_all.h index 87fba76cc9..c72b24284b 100644 --- a/include/config_cmd_all.h +++ b/include/config_cmd_all.h @@ -13,7 +13,6 @@ * Alphabetical list of all possible commands. */
-#define CONFIG_CMD_SAVES /* save S record dump */ #define CONFIG_CMD_SDRAM /* SDRAM DIMM SPD info printout */ #define CONFIG_CMD_TERMINAL /* built-in Serial Terminal */ #define CONFIG_CMD_UNIVERSE /* Tundra Universe Support */ diff --git a/include/configs/calimain.h b/include/configs/calimain.h index b6c8035fb5..044aa69baf 100644 --- a/include/configs/calimain.h +++ b/include/configs/calimain.h @@ -294,14 +294,6 @@ "echo Product: $product; " \ "gpio c 1; gpio c 2;"
-/* - * U-Boot commands - */ -#define CONFIG_CMD_SAVES - -#ifndef CONFIG_DRIVER_TI_EMAC -#endif - /* additions for new relocation code, must added to all boards */ #define CONFIG_SYS_SDRAM_BASE 0xc0000000 /* initial stack pointer in internal SRAM */ diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 695f3f6874..675e7a649e 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -263,11 +263,6 @@ "mem=32M console=ttyS2,115200n8 root=/dev/mtdblock2 rw noinitrd ip=dhcp" #define CONFIG_EXTRA_ENV_SETTINGS "hwconfig=dsp:wake=yes"
-/* - * U-Boot commands - */ -#define CONFIG_CMD_SAVES - #ifdef CONFIG_CMD_BDI #define CONFIG_CLOCKS #endif diff --git a/include/configs/ea20.h b/include/configs/ea20.h index b1c4e3a750..158eea6018 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -121,11 +121,6 @@ #define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS
-/* - * U-Boot commands - */ -#define CONFIG_CMD_SAVES - #ifdef CONFIG_CMD_BDI #define CONFIG_CLOCKS #endif diff --git a/include/configs/ethernut5.h b/include/configs/ethernut5.h index cdad2e6d49..c1f04a92ff 100644 --- a/include/configs/ethernut5.h +++ b/include/configs/ethernut5.h @@ -83,7 +83,6 @@ #define CONFIG_AT91_GPIO
#ifndef MINIMAL_LOADER -#define CONFIG_CMD_SAVES #endif
/* NAND flash */ diff --git a/include/configs/ipam390.h b/include/configs/ipam390.h index a21261f4d5..083ccd8ef6 100644 --- a/include/configs/ipam390.h +++ b/include/configs/ipam390.h @@ -236,11 +236,6 @@ "nand write c0000100 180000 20000\0" \ "\0"
-/* - * U-Boot commands - */ -#define CONFIG_CMD_SAVES - #ifdef CONFIG_CMD_BDI #define CONFIG_CLOCKS #endif diff --git a/include/configs/legoev3.h b/include/configs/legoev3.h index 4ea61af920..2e6147d822 100644 --- a/include/configs/legoev3.h +++ b/include/configs/legoev3.h @@ -197,11 +197,6 @@ "loadbootscr=fatload mmc 0 ${bootscraddr} boot.scr\0" \ "bootscript=source ${bootscraddr}\0" \
-/* - * U-Boot commands - */ -#define CONFIG_CMD_SAVES - #ifdef CONFIG_CMD_BDI #define CONFIG_CLOCKS #endif diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index fb0575fa4d..8ddbf599e1 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -160,24 +160,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
-/* - * Command line configuration. - */ - -#if defined(FLASH) -# if !defined(RAMENV) -# define CONFIG_CMD_SAVES -# endif - -#else -#if defined(SPIFLASH) - -# if !defined(RAMENV) -# define CONFIG_CMD_SAVES -# endif -#endif -#endif - #if defined(CONFIG_CMD_JFFS2) # define CONFIG_MTD_PARTITIONS #endif diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index 08e7deb30f..6ea2b5e7f3 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -274,10 +274,6 @@ "boot_fit=0\0" \ "console=ttyS2,115200n8\0"
-/* - * U-Boot commands - */ -#define CONFIG_CMD_SAVES #ifdef CONFIG_CMD_BDI #define CONFIG_CLOCKS #endif diff --git a/include/configs/spear-common.h b/include/configs/spear-common.h index 83060e71a6..90ffa19b4b 100644 --- a/include/configs/spear-common.h +++ b/include/configs/spear-common.h @@ -93,11 +93,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_ONFI_DETECTION
-/* - * Command support defines - */ -#define CONFIG_CMD_SAVES - /* * Default Environment Varible definitions */ diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index 26290ef1b2..78c6726637 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -198,9 +198,6 @@ #define CONFIG_DEV_USB_PHY_BASE KS2_DEV_USB_PHY_BASE #define CONFIG_USB_PHY_CFG_BASE KS2_USB_PHY_CFG_BASE
-/* U-Boot command configuration */ -#define CONFIG_CMD_SAVES - /* U-Boot general configuration */ #define CONFIG_MISC_INIT_R #define CONFIG_MX_CYCLIC diff --git a/include/configs/x600.h b/include/configs/x600.h index a8435d8b01..7f19aec3ec 100644 --- a/include/configs/x600.h +++ b/include/configs/x600.h @@ -100,11 +100,6 @@ #define CONFIG_USB_EHCI_SPEAR #define CONFIG_USB_MAX_CONTROLLER_COUNT 2
-/* - * Command support defines - */ -#define CONFIG_CMD_SAVES - /* Filesystem support (for USB key) */ #define CONFIG_SUPPORT_VFAT
diff --git a/include/configs/xtfpga.h b/include/configs/xtfpga.h index 206ec344d9..df983d9f1e 100644 --- a/include/configs/xtfpga.h +++ b/include/configs/xtfpga.h @@ -123,12 +123,6 @@ /* Boot Argument Buffer Size */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
-/*=================*/ -/* U-Boot commands */ -/*=================*/ - -#define CONFIG_CMD_SAVES - /*==============================*/ /* U-Boot autoboot configuration */ /*==============================*/ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index fd093f797d..30b3451447 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_SAVES CONFIG_CMD_SCSI CONFIG_CMD_SDRAM CONFIG_CMD_SF_TEST
Changes in v2:
Changes in v2:
This converts the following to Kconfig: CONFIG_CMD_SCSI
Also update the Makefile to use CONFIG_CMD_SCSI instead of CONFIG_SCSI to enable the command, fixing an earlier error.
Changes in v2: - Update commit message to explain Makefile change
arch/arm/Kconfig | 3 +++ cmd/Kconfig | 9 +++++++++ cmd/Makefile | 2 +- configs/cl-som-am57x_defconfig | 1 + configs/controlcenterdc_defconfig | 1 + configs/ls1012aqds_qspi_defconfig | 1 + include/configs/cl-som-am57x.h | 1 - include/configs/controlcenterdc.h | 1 - include/configs/ls1012aqds.h | 1 - include/configs/ls1012ardb.h | 1 - include/configs/ls1021aiot.h | 1 - include/configs/ls1043ardb.h | 1 - scripts/config_whitelist.txt | 1 - 13 files changed, 16 insertions(+), 8 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 5e42e7b030..477e76be29 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -879,6 +879,7 @@ config TARGET_LS1012ARDB select ARM64 select BOARD_LATE_INIT imply SCSI + imply CMD_SCSI help Support for Freescale LS1012ARDB platform. The LS1012A Reference design board (RDB) is a high-performance @@ -932,6 +933,7 @@ config TARGET_LS1021AIOT select ARCH_LS1021A select ARCH_SUPPORT_PSCI imply SCSI + imply CMD_SCSI help Support for Freescale LS1021AIOT platform. The LS1021A Freescale board (IOT) is a high-performance @@ -959,6 +961,7 @@ config TARGET_LS1043ARDB select SUPPORT_SPL select BOARD_EARLY_INIT_F imply SCSI + imply CMD_SCSI help Support for Freescale LS1043ARDB platform.
diff --git a/cmd/Kconfig b/cmd/Kconfig index f90673f95b..c74acd535b 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1281,6 +1281,15 @@ config CMD_REISER reiserls - list files reiserload - load a file
+config CMD_SCSI + bool "scsi - Access to SCSI devices" + select SCSI + help + This provides a 'scsi' command which provides access to SCSI (Small + Computer System Interface) devices. The command provides a way to + scan the bus, reset the bus, read and write data and get information + about devices. + endmenu
menu "Debug commands" diff --git a/cmd/Makefile b/cmd/Makefile index eff6bd678f..a85fe25dda 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -106,7 +106,7 @@ obj-$(CONFIG_CMD_REMOTEPROC) += remoteproc.o obj-$(CONFIG_SANDBOX) += host.o obj-$(CONFIG_CMD_SATA) += sata.o obj-$(CONFIG_CMD_SF) += sf.o -obj-$(CONFIG_SCSI) += scsi.o disk.o +obj-$(CONFIG_CMD_SCSI) += scsi.o disk.o obj-$(CONFIG_CMD_SHA1SUM) += sha1sum.o obj-$(CONFIG_CMD_SETEXPR) += setexpr.o obj-$(CONFIG_CMD_SPI) += spi.o diff --git a/configs/cl-som-am57x_defconfig b/configs/cl-som-am57x_defconfig index e0b7565ac0..71ce02d616 100644 --- a/configs/cl-som-am57x_defconfig +++ b/configs/cl-som-am57x_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_SCSI=y CONFIG_ISO_PARTITION=y CONFIG_CMD_PCA953X=y CONFIG_LED_STATUS=y diff --git a/configs/controlcenterdc_defconfig b/configs/controlcenterdc_defconfig index bb9c1b5d4f..4affd31ebd 100644 --- a/configs/controlcenterdc_defconfig +++ b/configs/controlcenterdc_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_TIME=y CONFIG_CMD_TPM=y CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y +CONFIG_CMD_SCSI=y CONFIG_EFI_PARTITION=y CONFIG_OF_BOARD_FIXUP=y CONFIG_SPL_OF_TRANSLATE=y diff --git a/configs/ls1012aqds_qspi_defconfig b/configs/ls1012aqds_qspi_defconfig index 383fc1a95f..dfc378677d 100644 --- a/configs/ls1012aqds_qspi_defconfig +++ b/configs/ls1012aqds_qspi_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_CMD_SCSI=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y diff --git a/include/configs/cl-som-am57x.h b/include/configs/cl-som-am57x.h index b9d6454887..afab46caae 100644 --- a/include/configs/cl-som-am57x.h +++ b/include/configs/cl-som-am57x.h @@ -64,7 +64,6 @@
#ifndef CONFIG_SPL_BUILD /* SATA */ -#define CONFIG_CMD_SCSI #define CONFIG_LIBATA #define CONFIG_SCSI_AHCI #define CONFIG_SCSI_AHCI_PLAT diff --git a/include/configs/controlcenterdc.h b/include/configs/controlcenterdc.h index 979bb98850..715e9ed9c9 100644 --- a/include/configs/controlcenterdc.h +++ b/include/configs/controlcenterdc.h @@ -33,7 +33,6 @@ * Commands configuration */ #define CONFIG_CMD_I2C -#define CONFIG_CMD_SCSI #define CONFIG_CMD_SPI
/* SPI NOR flash default params, used by sf commands */ diff --git a/include/configs/ls1012aqds.h b/include/configs/ls1012aqds.h index 99f5dd4119..b3121d2c21 100644 --- a/include/configs/ls1012aqds.h +++ b/include/configs/ls1012aqds.h @@ -136,7 +136,6 @@ #define CONFIG_LIBATA #define CONFIG_SCSI_AHCI #define CONFIG_SCSI_AHCI_PLAT -#define CONFIG_CMD_SCSI
#define CONFIG_SYS_SATA AHCI_BASE_ADDR
diff --git a/include/configs/ls1012ardb.h b/include/configs/ls1012ardb.h index f4ed0302a9..e9edcd2bc9 100644 --- a/include/configs/ls1012ardb.h +++ b/include/configs/ls1012ardb.h @@ -52,7 +52,6 @@ #define CONFIG_LIBATA #define CONFIG_SCSI_AHCI #define CONFIG_SCSI_AHCI_PLAT -#define CONFIG_CMD_SCSI
diff --git a/include/configs/ls1021aiot.h b/include/configs/ls1021aiot.h index 9896b0f04b..0c4e98d28f 100644 --- a/include/configs/ls1021aiot.h +++ b/include/configs/ls1021aiot.h @@ -142,7 +142,6 @@ #define CONFIG_FSL_ESDHC
/* SATA */ -#define CONFIG_CMD_SCSI #define CONFIG_LIBATA #define CONFIG_SCSI_AHCI #define CONFIG_SCSI_AHCI_PLAT diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 937fd930ee..b95c2d87c0 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -294,7 +294,6 @@ #ifndef SPL_NO_SATA #define CONFIG_LIBATA #define CONFIG_SCSI_AHCI -#define CONFIG_CMD_SCSI #ifndef CONFIG_CMD_EXT2 #define CONFIG_CMD_EXT2 #endif diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 30b3451447..1ae87eb0b5 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_SCSI CONFIG_CMD_SDRAM CONFIG_CMD_SF_TEST CONFIG_CMD_SH_ZIMAGEBOOT
Changes in v2:
Changes in v2:
After making this default y if SCSI, and drop from cl-som-am57x as it wasn't using really, applied to u-boot/master, thanks!
This converts the following to Kconfig: CONFIG_CMD_SDRAM
README | 2 -- cmd/Kconfig | 7 +++++++ configs/MPC8349ITXGP_defconfig | 1 + configs/MPC8349ITX_LOWBOOT_defconfig | 1 + configs/MPC8349ITX_defconfig | 1 + configs/MigoR_defconfig | 1 + configs/alt_defconfig | 1 + configs/ap325rxa_defconfig | 1 + configs/ap_sh4a_4a_defconfig | 1 + configs/armadillo-800eva_defconfig | 1 + configs/blanche_defconfig | 1 + configs/ecovec_defconfig | 1 + configs/espt_defconfig | 1 + configs/gose_defconfig | 1 + configs/koelsch_defconfig | 1 + configs/lager_defconfig | 1 + configs/ms7720se_defconfig | 1 + configs/ms7722se_defconfig | 1 + configs/porter_defconfig | 1 + configs/r0p7734_defconfig | 1 + configs/r7780mp_defconfig | 1 + configs/r8a7795_salvator-x_defconfig | 1 + configs/r8a7796_salvator-x_defconfig | 1 + configs/rsk7203_defconfig | 1 + configs/sh7752evb_defconfig | 1 + configs/sh7753evb_defconfig | 1 + configs/sh7757lcr_defconfig | 1 + configs/sh7763rdp_defconfig | 1 + configs/sh7785lcr_32bit_defconfig | 1 + configs/sh7785lcr_defconfig | 1 + configs/shmin_defconfig | 1 + configs/silk_defconfig | 1 + configs/socrates_defconfig | 1 + configs/stout_defconfig | 1 + include/config_cmd_all.h | 1 - include/configs/MPC8349ITX.h | 5 ----- include/configs/MigoR.h | 2 -- include/configs/ap325rxa.h | 2 -- include/configs/ap_sh4a_4a.h | 2 -- include/configs/armadillo-800eva.h | 2 -- include/configs/ecovec.h | 2 -- include/configs/espt.h | 5 ----- include/configs/ms7720se.h | 2 -- include/configs/ms7722se.h | 2 -- include/configs/r0p7734.h | 2 -- include/configs/r7780mp.h | 5 ----- include/configs/rcar-gen2-common.h | 2 -- include/configs/rcar-gen3-common.h | 1 - include/configs/rsk7203.h | 2 -- include/configs/sh7752evb.h | 2 -- include/configs/sh7753evb.h | 2 -- include/configs/sh7757lcr.h | 2 -- include/configs/sh7763rdp.h | 5 ----- include/configs/sh7785lcr.h | 1 - include/configs/shmin.h | 2 -- include/configs/socrates.h | 5 ----- scripts/config_whitelist.txt | 1 - 57 files changed, 39 insertions(+), 59 deletions(-)
diff --git a/README b/README index 318a4aa25d..2371304279 100644 --- a/README +++ b/README @@ -815,8 +815,6 @@ The following options need to be configured: CONFIG_CMD_PING * send ICMP ECHO_REQUEST to network host CONFIG_CMD_RUN run command in env variable - CONFIG_CMD_SDRAM * print SDRAM configuration information - (requires CONFIG_CMD_I2C) CONFIG_CMD_SF * Read/write/erase SPI NOR flash CONFIG_CMD_SOFTSWITCH * Soft switch setting command for BF60x CONFIG_CMD_SOURCE "source" command Support diff --git a/cmd/Kconfig b/cmd/Kconfig index c74acd535b..6431d7c70f 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -776,6 +776,13 @@ config CMD_SAVES Provides a way to save a binary file using the Motorola S-Record format over the serial line.
+config CMD_SDRAM + bool "sdram - Print SDRAM configuration information" + help + Provides information about attached SDRAM. This assumed that the + SDRAM has an EEPROM with information that can be read using the + I2C bus. This is only available on some boards. + config CMD_SF bool "sf" help diff --git a/configs/MPC8349ITXGP_defconfig b/configs/MPC8349ITXGP_defconfig index 09af09d4c3..f1cfd3705c 100644 --- a/configs/MPC8349ITXGP_defconfig +++ b/configs/MPC8349ITXGP_defconfig @@ -9,6 +9,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="MPC8349E-mITX-GP> " CONFIG_CMD_I2C=y CONFIG_CMD_PCI=y +CONFIG_CMD_SDRAM=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y diff --git a/configs/MPC8349ITX_LOWBOOT_defconfig b/configs/MPC8349ITX_LOWBOOT_defconfig index 0650c7979a..4974dd1a9c 100644 --- a/configs/MPC8349ITX_LOWBOOT_defconfig +++ b/configs/MPC8349ITX_LOWBOOT_defconfig @@ -12,6 +12,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_SATA=y CONFIG_CMD_PCI=y +CONFIG_CMD_SDRAM=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y diff --git a/configs/MPC8349ITX_defconfig b/configs/MPC8349ITX_defconfig index 3763f49ba6..22805ae63e 100644 --- a/configs/MPC8349ITX_defconfig +++ b/configs/MPC8349ITX_defconfig @@ -12,6 +12,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_SATA=y CONFIG_CMD_PCI=y +CONFIG_CMD_SDRAM=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y diff --git a/configs/MigoR_defconfig b/configs/MigoR_defconfig index b8e2da2678..a62d3172d0 100644 --- a/configs/MigoR_defconfig +++ b/configs/MigoR_defconfig @@ -13,6 +13,7 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_SDRAM=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set diff --git a/configs/alt_defconfig b/configs/alt_defconfig index 109b1abfe7..4dc13d681c 100644 --- a/configs/alt_defconfig +++ b/configs/alt_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_SDRAM=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/ap325rxa_defconfig b/configs/ap325rxa_defconfig index 8c1aaf2c3c..fedaad9677 100644 --- a/configs/ap325rxa_defconfig +++ b/configs/ap325rxa_defconfig @@ -14,6 +14,7 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_ENV_EXISTS is not set CONFIG_CMD_IDE=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_SDRAM=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set diff --git a/configs/ap_sh4a_4a_defconfig b/configs/ap_sh4a_4a_defconfig index 400cfd10a7..c229cf725e 100644 --- a/configs/ap_sh4a_4a_defconfig +++ b/configs/ap_sh4a_4a_defconfig @@ -15,6 +15,7 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_SDRAM=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set diff --git a/configs/armadillo-800eva_defconfig b/configs/armadillo-800eva_defconfig index 8b2448b1fc..53d8ec1016 100644 --- a/configs/armadillo-800eva_defconfig +++ b/configs/armadillo-800eva_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_SDRAM=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set diff --git a/configs/blanche_defconfig b/configs/blanche_defconfig index c2a4c8092f..a4f02fe882 100644 --- a/configs/blanche_defconfig +++ b/configs/blanche_defconfig @@ -9,6 +9,7 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set CONFIG_CMD_MMC=y +CONFIG_CMD_SDRAM=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/ecovec_defconfig b/configs/ecovec_defconfig index 532b22d3be..4a5bed30c3 100644 --- a/configs/ecovec_defconfig +++ b/configs/ecovec_defconfig @@ -17,6 +17,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_SDRAM=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set diff --git a/configs/espt_defconfig b/configs/espt_defconfig index a41704ec96..a87edf1daf 100644 --- a/configs/espt_defconfig +++ b/configs/espt_defconfig @@ -15,6 +15,7 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_SDRAM=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set diff --git a/configs/gose_defconfig b/configs/gose_defconfig index 12b768ca39..885d3ca05b 100644 --- a/configs/gose_defconfig +++ b/configs/gose_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_SDRAM=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/koelsch_defconfig b/configs/koelsch_defconfig index e6eef3f731..a95f372f27 100644 --- a/configs/koelsch_defconfig +++ b/configs/koelsch_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_SDRAM=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/lager_defconfig b/configs/lager_defconfig index ca4f73d04f..7afd59f138 100644 --- a/configs/lager_defconfig +++ b/configs/lager_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_SDRAM=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/ms7720se_defconfig b/configs/ms7720se_defconfig index be5e82aeae..1f436589dd 100644 --- a/configs/ms7720se_defconfig +++ b/configs/ms7720se_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_IDE=y # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set CONFIG_CMD_PCMCIA=y +CONFIG_CMD_SDRAM=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set diff --git a/configs/ms7722se_defconfig b/configs/ms7722se_defconfig index 37cf8776c2..d3561da2f0 100644 --- a/configs/ms7722se_defconfig +++ b/configs/ms7722se_defconfig @@ -15,6 +15,7 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_SDRAM=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set diff --git a/configs/porter_defconfig b/configs/porter_defconfig index e90fbf1137..21f401aac6 100644 --- a/configs/porter_defconfig +++ b/configs/porter_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_SDRAM=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/r0p7734_defconfig b/configs/r0p7734_defconfig index 91b36058bc..994c156a73 100644 --- a/configs/r0p7734_defconfig +++ b/configs/r0p7734_defconfig @@ -15,6 +15,7 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_SDRAM=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set diff --git a/configs/r7780mp_defconfig b/configs/r7780mp_defconfig index 58decc5b52..b2596a4a7a 100644 --- a/configs/r7780mp_defconfig +++ b/configs/r7780mp_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_IDE=y # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set CONFIG_CMD_PCI=y +CONFIG_CMD_SDRAM=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set diff --git a/configs/r8a7795_salvator-x_defconfig b/configs/r8a7795_salvator-x_defconfig index 98eca37710..4203b9cd69 100644 --- a/configs/r8a7795_salvator-x_defconfig +++ b/configs/r8a7795_salvator-x_defconfig @@ -12,6 +12,7 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MMC=y CONFIG_CMD_USB=y +CONFIG_CMD_SDRAM=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/r8a7796_salvator-x_defconfig b/configs/r8a7796_salvator-x_defconfig index 9e0f9290bf..3c53e47bf1 100644 --- a/configs/r8a7796_salvator-x_defconfig +++ b/configs/r8a7796_salvator-x_defconfig @@ -13,6 +13,7 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MMC=y CONFIG_CMD_USB=y +CONFIG_CMD_SDRAM=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/rsk7203_defconfig b/configs/rsk7203_defconfig index f7b99f4842..8f642bf62f 100644 --- a/configs/rsk7203_defconfig +++ b/configs/rsk7203_defconfig @@ -14,6 +14,7 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_SDRAM=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set diff --git a/configs/sh7752evb_defconfig b/configs/sh7752evb_defconfig index 124757353b..d6ddbfed54 100644 --- a/configs/sh7752evb_defconfig +++ b/configs/sh7752evb_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_MD5SUM=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_SDRAM=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set diff --git a/configs/sh7753evb_defconfig b/configs/sh7753evb_defconfig index 68e0c5cdfb..023d2ee97d 100644 --- a/configs/sh7753evb_defconfig +++ b/configs/sh7753evb_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_MD5SUM=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_SDRAM=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set diff --git a/configs/sh7757lcr_defconfig b/configs/sh7757lcr_defconfig index d43c0184e4..ee9cbc1074 100644 --- a/configs/sh7757lcr_defconfig +++ b/configs/sh7757lcr_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_MD5SUM=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_SDRAM=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set diff --git a/configs/sh7763rdp_defconfig b/configs/sh7763rdp_defconfig index 32cc565b5e..858d9e250e 100644 --- a/configs/sh7763rdp_defconfig +++ b/configs/sh7763rdp_defconfig @@ -15,6 +15,7 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_SDRAM=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set diff --git a/configs/sh7785lcr_32bit_defconfig b/configs/sh7785lcr_32bit_defconfig index d4ebd4b99d..bd5db3edf1 100644 --- a/configs/sh7785lcr_32bit_defconfig +++ b/configs/sh7785lcr_32bit_defconfig @@ -17,6 +17,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_PCI=y +CONFIG_CMD_SDRAM=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set diff --git a/configs/sh7785lcr_defconfig b/configs/sh7785lcr_defconfig index 5aaca3f574..7547ae475b 100644 --- a/configs/sh7785lcr_defconfig +++ b/configs/sh7785lcr_defconfig @@ -16,6 +16,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_PCI=y +CONFIG_CMD_SDRAM=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set diff --git a/configs/shmin_defconfig b/configs/shmin_defconfig index 249582f495..8570bbc46a 100644 --- a/configs/shmin_defconfig +++ b/configs/shmin_defconfig @@ -14,6 +14,7 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_SDRAM=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set diff --git a/configs/silk_defconfig b/configs/silk_defconfig index d2d20b9b96..bd2832843d 100644 --- a/configs/silk_defconfig +++ b/configs/silk_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_SDRAM=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/socrates_defconfig b/configs/socrates_defconfig index f0c1d72f5f..1ab178a175 100644 --- a/configs/socrates_defconfig +++ b/configs/socrates_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_PCI=y +CONFIG_CMD_SDRAM=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set diff --git a/configs/stout_defconfig b/configs/stout_defconfig index bee7401d79..b1467764f7 100644 --- a/configs/stout_defconfig +++ b/configs/stout_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_SDRAM=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/include/config_cmd_all.h b/include/config_cmd_all.h index c72b24284b..25dd3c7355 100644 --- a/include/config_cmd_all.h +++ b/include/config_cmd_all.h @@ -13,7 +13,6 @@ * Alphabetical list of all possible commands. */
-#define CONFIG_CMD_SDRAM /* SDRAM DIMM SPD info printout */ #define CONFIG_CMD_TERMINAL /* built-in Serial Terminal */ #define CONFIG_CMD_UNIVERSE /* Tundra Universe Support */ #define CONFIG_CMD_ZFS /* ZFS Support */ diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index 7d8074b462..212c2e84cb 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -473,11 +473,6 @@ boards, we say we have two, but don't display a message if we find only one. */ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
-/* - * Command line configuration. - */ -#define CONFIG_CMD_SDRAM - #if defined(CONFIG_COMPACT_FLASH) || defined(CONFIG_SATA_SIL3114) \ || defined(CONFIG_USB_STORAGE) #define CONFIG_SUPPORT_VFAT diff --git a/include/configs/MigoR.h b/include/configs/MigoR.h index 73b0e6e05a..a311427435 100644 --- a/include/configs/MigoR.h +++ b/include/configs/MigoR.h @@ -12,8 +12,6 @@ #define CONFIG_CPU_SH7722 1 #define CONFIG_MIGO_R 1
-#define CONFIG_CMD_SDRAM - #define CONFIG_BOOTARGS "console=ttySC0,115200 root=1f01"
#define CONFIG_DISPLAY_BOARDINFO diff --git a/include/configs/ap325rxa.h b/include/configs/ap325rxa.h index 448c9279a9..0e0e5f9b43 100644 --- a/include/configs/ap325rxa.h +++ b/include/configs/ap325rxa.h @@ -13,8 +13,6 @@ #define CONFIG_CPU_SH7723 1 #define CONFIG_AP325RXA 1
-#define CONFIG_CMD_SDRAM - #define CONFIG_BOOTARGS "console=ttySC2,38400"
#define CONFIG_DISPLAY_BOARDINFO diff --git a/include/configs/ap_sh4a_4a.h b/include/configs/ap_sh4a_4a.h index adc7d1feba..2f2e4e83f7 100644 --- a/include/configs/ap_sh4a_4a.h +++ b/include/configs/ap_sh4a_4a.h @@ -16,8 +16,6 @@
#define CONFIG_SYS_TEXT_BASE 0x8BFC0000
-#define CONFIG_CMD_SDRAM - #define CONFIG_BOOTARGS "console=ttySC4,115200"
#define CONFIG_DISPLAY_BOARDINFO diff --git a/include/configs/armadillo-800eva.h b/include/configs/armadillo-800eva.h index 643b26b488..74eebd3aaf 100644 --- a/include/configs/armadillo-800eva.h +++ b/include/configs/armadillo-800eva.h @@ -16,8 +16,6 @@
#include <asm/arch/rmobile.h>
-#define CONFIG_CMD_SDRAM - #define BOARD_LATE_INIT
#define CONFIG_BOOTARGS "" diff --git a/include/configs/ecovec.h b/include/configs/ecovec.h index 2471277c68..7b67d992c0 100644 --- a/include/configs/ecovec.h +++ b/include/configs/ecovec.h @@ -28,8 +28,6 @@ #define CONFIG_ECOVEC_ROMIMAGE_ADDR 0xA0040000 #define CONFIG_SYS_TEXT_BASE 0x8FFC0000
-#define CONFIG_CMD_SDRAM - #define CONFIG_BOOTARGS "console=ttySC0,115200"
#define CONFIG_DISPLAY_BOARDINFO diff --git a/include/configs/espt.h b/include/configs/espt.h index 07f327532b..438580b51f 100644 --- a/include/configs/espt.h +++ b/include/configs/espt.h @@ -14,11 +14,6 @@ #define CONFIG_ESPT 1 #define __LITTLE_ENDIAN 1
-/* - * Command line configuration. - */ -#define CONFIG_CMD_SDRAM - #define CONFIG_BOOTARGS "console=ttySC0,115200 root=1f01" #define CONFIG_ENV_OVERWRITE 1
diff --git a/include/configs/ms7720se.h b/include/configs/ms7720se.h index 112145ce77..77e67aa183 100644 --- a/include/configs/ms7720se.h +++ b/include/configs/ms7720se.h @@ -12,8 +12,6 @@ #define CONFIG_CPU_SH7720 1 #define CONFIG_MS7720SE 1
-#define CONFIG_CMD_SDRAM - #define CONFIG_BOOTARGS "console=ttySC0,115200" #define CONFIG_BOOTFILE "/boot/zImage" #define CONFIG_LOADADDR 0x8E000000 diff --git a/include/configs/ms7722se.h b/include/configs/ms7722se.h index 49eadd10e9..af7453e71d 100644 --- a/include/configs/ms7722se.h +++ b/include/configs/ms7722se.h @@ -12,8 +12,6 @@ #define CONFIG_CPU_SH7722 1 #define CONFIG_MS7722SE 1
#define CONFIG_DISPLAY_BOARDINFO diff --git a/include/configs/r0p7734.h b/include/configs/r0p7734.h index d79aa21c9e..7c2badc3d5 100644 --- a/include/configs/r0p7734.h +++ b/include/configs/r0p7734.h @@ -16,8 +16,6 @@
-#define CONFIG_CMD_SDRAM - #define CONFIG_BOOTARGS "console=ttySC3,115200"
#define CONFIG_DISPLAY_BOARDINFO diff --git a/include/configs/r7780mp.h b/include/configs/r7780mp.h index 21364ddd4a..271ed53b81 100644 --- a/include/configs/r7780mp.h +++ b/include/configs/r7780mp.h @@ -17,11 +17,6 @@
-/* - * Command line configuration. - */ -#define CONFIG_CMD_SDRAM - #define CONFIG_CONS_SCIF0 1
#define CONFIG_BOOTARGS "console=ttySC0,115200" diff --git a/include/configs/rcar-gen2-common.h b/include/configs/rcar-gen2-common.h index 16f45f2bea..440984ce86 100644 --- a/include/configs/rcar-gen2-common.h +++ b/include/configs/rcar-gen2-common.h @@ -11,8 +11,6 @@
-#define CONFIG_CMD_SDRAM - /* Support File sytems */ #define CONFIG_SUPPORT_VFAT #define CONFIG_FS_EXT4 diff --git a/include/configs/rcar-gen3-common.h b/include/configs/rcar-gen3-common.h index 6c23249861..a79d0e60d0 100644 --- a/include/configs/rcar-gen3-common.h +++ b/include/configs/rcar-gen3-common.h @@ -12,7 +12,6 @@
-#define CONFIG_CMD_SDRAM #define CONFIG_CMD_EXT2 #define CONFIG_CMD_EXT4 #define CONFIG_CMD_EXT4_WRITE diff --git a/include/configs/rsk7203.h b/include/configs/rsk7203.h index 58aadbef01..ef054dad39 100644 --- a/include/configs/rsk7203.h +++ b/include/configs/rsk7203.h @@ -13,8 +13,6 @@ #define CONFIG_CPU_SH7203 1 #define CONFIG_RSK7203 1
-#define CONFIG_CMD_SDRAM - #define CONFIG_BOOTARGS "console=ttySC0,115200" #define CONFIG_LOADADDR 0x0C100000 /* RSK7203_SDRAM_BASE + 1MB */
diff --git a/include/configs/sh7752evb.h b/include/configs/sh7752evb.h index 39e8244b25..a7a2750c15 100644 --- a/include/configs/sh7752evb.h +++ b/include/configs/sh7752evb.h @@ -14,8 +14,6 @@
#define CONFIG_SYS_TEXT_BASE 0x5ff80000
-#define CONFIG_CMD_SDRAM - #define CONFIG_BOOTARGS "console=ttySC2,115200 root=/dev/nfs ip=dhcp"
#define CONFIG_DISPLAY_BOARDINFO diff --git a/include/configs/sh7753evb.h b/include/configs/sh7753evb.h index 24ec0768af..6feed0f7f1 100644 --- a/include/configs/sh7753evb.h +++ b/include/configs/sh7753evb.h @@ -14,8 +14,6 @@
#define CONFIG_DISPLAY_BOARDINFO diff --git a/include/configs/sh7757lcr.h b/include/configs/sh7757lcr.h index e5084adfcc..11992f5239 100644 --- a/include/configs/sh7757lcr.h +++ b/include/configs/sh7757lcr.h @@ -15,8 +15,6 @@
#define CONFIG_SYS_TEXT_BASE 0x8ef80000
#define CONFIG_DISPLAY_BOARDINFO diff --git a/include/configs/sh7763rdp.h b/include/configs/sh7763rdp.h index 74bd9fc29a..327bedb96a 100644 --- a/include/configs/sh7763rdp.h +++ b/include/configs/sh7763rdp.h @@ -14,11 +14,6 @@ #define CONFIG_SH7763RDP 1 #define __LITTLE_ENDIAN 1
-/* - * Command line configuration. - */ -#define CONFIG_CMD_SDRAM - #define CONFIG_BOOTARGS "console=ttySC2,115200 root=1f01" #define CONFIG_ENV_OVERWRITE 1
diff --git a/include/configs/sh7785lcr.h b/include/configs/sh7785lcr.h index f249f4298d..d4477c2794 100644 --- a/include/configs/sh7785lcr.h +++ b/include/configs/sh7785lcr.h @@ -12,7 +12,6 @@ #define CONFIG_CPU_SH7785 1 #define CONFIG_SH7785LCR 1
-#define CONFIG_CMD_SDRAM #define CONFIG_CMD_SH_ZIMAGEBOOT
#define CONFIG_BOOTARGS "console=ttySC1,115200 root=/dev/nfs ip=dhcp" diff --git a/include/configs/shmin.h b/include/configs/shmin.h index d31dc558b1..295607808a 100644 --- a/include/configs/shmin.h +++ b/include/configs/shmin.h @@ -15,8 +15,6 @@ /* T-SH7706LSR*/ /* #define CONFIG_T_SH7706LSR 1 */
/* diff --git a/include/configs/socrates.h b/include/configs/socrates.h index cce7f901af..27e33a7a78 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -274,11 +274,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
-/* - * Command line configuration. - */ -#define CONFIG_CMD_SDRAM - #undef CONFIG_WATCHDOG /* watchdog disabled */
/* diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 1ae87eb0b5..1d7244c5ee 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_SDRAM CONFIG_CMD_SF_TEST CONFIG_CMD_SH_ZIMAGEBOOT CONFIG_CMD_SPL
Changes in v2:
Changes in v2:
This converts the following to Kconfig: CONFIG_CMD_SF_TEST
Changes in v2: - Fix typos in help - Make X86 imply CMD_SF_TEST (except for efi-x86 which fails) - Put Kconfig change in alphabetical order
README | 6 ------ arch/Kconfig | 2 ++ cmd/Kconfig | 11 +++++++++++ configs/chromebit_mickey_defconfig | 1 + configs/chromebook_jerry_defconfig | 1 + configs/chromebook_minnie_defconfig | 1 + configs/efi-x86_defconfig | 1 + configs/sandbox_defconfig | 4 +--- include/configs/efi-x86.h | 2 -- include/configs/sandbox.h | 1 - include/configs/veyron.h | 2 -- include/configs/x86-common.h | 1 - scripts/config_whitelist.txt | 1 - 13 files changed, 18 insertions(+), 16 deletions(-)
diff --git a/README b/README index 2371304279..d5684ce5b5 100644 --- a/README +++ b/README @@ -2500,12 +2500,6 @@ The following options need to be configured: CONFIG_SF_DEFAULT_MODE (see include/spi.h) CONFIG_SF_DEFAULT_SPEED in Hz
- CONFIG_CMD_SF_TEST - - Define this option to include a destructive SPI flash - test ('sf test'). - -- SystemACE Support: CONFIG_SYSTEMACE
Adding this option adds support for Xilinx SystemACE diff --git a/arch/Kconfig b/arch/Kconfig index e063ee0d23..08f6e7f47d 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -78,6 +78,7 @@ config SANDBOX imply LZMA imply SCSI imply CMD_SATA + imply CMD_SF_TEST
config SH bool "SuperH architecture" @@ -111,6 +112,7 @@ config X86 imply CMD_GETTIME imply CMD_IO imply CMD_IRQ + imply CMD_SF_TEST
config XTENSA bool "Xtensa architecture" diff --git a/cmd/Kconfig b/cmd/Kconfig index 6431d7c70f..2a9c55f608 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -788,6 +788,17 @@ config CMD_SF help SPI Flash support
+config CMD_SF_TEST + bool "sf test - Allow testing of SPI flash" + help + Provides a way to test that SPI flash is working correctly. The + test is destructive, in that an area of SPI flash must be provided + for the test to use. Performance information is also provided, + measuring the performance of reading, writing and erasing in + Mbps (Million Bits Per Second). This value should approximately + equal the SPI bus speed for a single-bit-wide SPI bus, assuming + everything is working properly. + config CMD_SPI bool "sspi" help diff --git a/configs/chromebit_mickey_defconfig b/configs/chromebit_mickey_defconfig index 01032e7330..b4e727009c 100644 --- a/configs/chromebit_mickey_defconfig +++ b/configs/chromebit_mickey_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y +CONFIG_CMD_SF_TEST=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index b9d4fc9c12..8e91db4014 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y +CONFIG_CMD_SF_TEST=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y diff --git a/configs/chromebook_minnie_defconfig b/configs/chromebook_minnie_defconfig index fb955e46c6..e512ce1ef8 100644 --- a/configs/chromebook_minnie_defconfig +++ b/configs/chromebook_minnie_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y +CONFIG_CMD_SF_TEST=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y diff --git a/configs/efi-x86_defconfig b/configs/efi-x86_defconfig index 789c5ce5bf..a23d402dee 100644 --- a/configs/efi-x86_defconfig +++ b/configs/efi-x86_defconfig @@ -11,6 +11,7 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_PART=y CONFIG_CMD_SF=y +# CONFIG_CMD_SF_TEST is not set CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index a1844d30a2..349d3c7270 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -41,6 +41,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_REMOTEPROC=y CONFIG_CMD_GPIO=y CONFIG_CMD_PCI=y +CONFIG_CMD_READ=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TFTPSRV=y CONFIG_CMD_RARP=y @@ -193,6 +194,3 @@ CONFIG_UNIT_TEST=y CONFIG_UT_TIME=y CONFIG_UT_DM=y CONFIG_UT_ENV=y -CONFIG_CMD_MTDPARTS=y -CONFIG_CMD_MTDPARTS_SPREAD=y -CONFIG_CMD_READ=y diff --git a/include/configs/efi-x86.h b/include/configs/efi-x86.h index 4a6b66507f..fa263632a2 100644 --- a/include/configs/efi-x86.h +++ b/include/configs/efi-x86.h @@ -9,8 +9,6 @@
#include <configs/x86-common.h>
-#undef CONFIG_CMD_SF_TEST - #undef CONFIG_TPM_TIS_BASE_ADDRESS
#undef CONFIG_SCSI_AHCI diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index beb5a124a2..13777abb4c 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -52,7 +52,6 @@ #define CONFIG_ENV_SIZE 8192
/* SPI - enable all SPI flash types for testing purposes */ -#define CONFIG_CMD_SF_TEST
#define CONFIG_I2C_EDID
diff --git a/include/configs/veyron.h b/include/configs/veyron.h index 3f236aa13c..3a5fc065d8 100644 --- a/include/configs/veyron.h +++ b/include/configs/veyron.h @@ -17,8 +17,6 @@ #define CONFIG_SPL_SPI_LOAD #define CONFIG_SPI_FLASH_GIGADEVICE
-#define CONFIG_CMD_SF_TEST - #define CONFIG_KEYBOARD
#endif diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index f5f7a92b8b..43af193344 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -107,7 +107,6 @@ /*----------------------------------------------------------------------- * FLASH configuration */ -#define CONFIG_CMD_SF_TEST #define CONFIG_SPI
/*----------------------------------------------------------------------- diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 1d7244c5ee..3a81c7e3ad 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_SF_TEST CONFIG_CMD_SH_ZIMAGEBOOT CONFIG_CMD_SPL CONFIG_CMD_SPL_NAND_OFS
Changes in v2:
- Fix typos in help
Changes in v2:
- Fix typos in help
This converts the following to Kconfig: CONFIG_CMD_SH_ZIMAGEBOOT
Changes in v2: - Make this 'default y' and drop defconfig file changes - Remove some now-superfluous /* commands */ comments in header files - Rename the option to include 'zimageboot'
arch/sh/Kconfig | 2 ++ arch/sh/lib/Kconfig | 6 ++++++ include/configs/r2dplus.h | 5 ----- include/configs/sh7785lcr.h | 2 -- scripts/config_whitelist.txt | 1 - 5 files changed, 8 insertions(+), 8 deletions(-) create mode 100644 arch/sh/lib/Kconfig
diff --git a/arch/sh/Kconfig b/arch/sh/Kconfig index 1d40fe6845..fa32df02fc 100644 --- a/arch/sh/Kconfig +++ b/arch/sh/Kconfig @@ -128,6 +128,8 @@ config SYS_CPU default "sh3" if CPU_SH3 default "sh4" if CPU_SH4
+source "arch/sh/lib/Kconfig" + source "board/alphaproject/ap_sh4a_4a/Kconfig" source "board/espt/Kconfig" source "board/mpr2/Kconfig" diff --git a/arch/sh/lib/Kconfig b/arch/sh/lib/Kconfig new file mode 100644 index 0000000000..cec8d09cc3 --- /dev/null +++ b/arch/sh/lib/Kconfig @@ -0,0 +1,6 @@ +config CMD_SH_ZIMAGEBOOT + bool "zimageboot - Boot a zImage on SH" + default y + help + This is special SH-specific command to boot a zImage (compressed + Linux image) on SH-architecture boards. diff --git a/include/configs/r2dplus.h b/include/configs/r2dplus.h index a604848073..4feaa0509a 100644 --- a/include/configs/r2dplus.h +++ b/include/configs/r2dplus.h @@ -8,11 +8,6 @@
-/* - * Command line configuration. - */ -#define CONFIG_CMD_SH_ZIMAGEBOOT - /* SCIF */ #define CONFIG_CONS_SCIF1 1
diff --git a/include/configs/sh7785lcr.h b/include/configs/sh7785lcr.h index d4477c2794..da827aca87 100644 --- a/include/configs/sh7785lcr.h +++ b/include/configs/sh7785lcr.h @@ -12,8 +12,6 @@ #define CONFIG_CPU_SH7785 1 #define CONFIG_SH7785LCR 1
-#define CONFIG_CMD_SH_ZIMAGEBOOT - #define CONFIG_BOOTARGS "console=ttySC1,115200 root=/dev/nfs ip=dhcp"
#define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 3a81c7e3ad..08351b57e1 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_SH_ZIMAGEBOOT CONFIG_CMD_SPL CONFIG_CMD_SPL_NAND_OFS CONFIG_CMD_SPL_WRITE_SIZE
Changes in v2:
Changes in v2:
This converts the following to Kconfig: CONFIG_CMD_SPL
Note that trats does not actually use SPL, so this option can no-longer be set.
Changes in v2: - Fix up microblaze-generic, gw_ventana, ipam390 - Remove some now-superfluous /* commands */ comments in header files
arch/arm/Kconfig | 1 + arch/arm/mach-imx/mx6/Kconfig | 1 + arch/arm/mach-omap2/am33xx/Kconfig | 1 + cmd/Kconfig | 9 +++++++++ configs/am335x_boneblack_defconfig | 1 + configs/am335x_boneblack_vboot_defconfig | 1 + configs/am335x_evm_defconfig | 1 + configs/am335x_evm_nor_defconfig | 1 + configs/am335x_evm_usbspl_defconfig | 1 + configs/am335x_igep003x_defconfig | 1 + configs/am335x_sl50_defconfig | 1 + configs/am43xx_evm_defconfig | 1 + configs/am43xx_evm_ethboot_defconfig | 1 + configs/am43xx_evm_usbhost_boot_defconfig | 1 + configs/am57xx_evm_defconfig | 1 + configs/am57xx_evm_nodt_defconfig | 1 + configs/birdland_bav335a_defconfig | 1 + configs/birdland_bav335b_defconfig | 1 + configs/cairo_defconfig | 1 + configs/devkit8000_defconfig | 1 + configs/dra7xx_evm_defconfig | 1 + configs/ipam390_defconfig | 1 + configs/microblaze-generic_defconfig | 1 + configs/mx6sabresd_defconfig | 1 + configs/omap3_beagle_defconfig | 1 + configs/omap3_logic_defconfig | 1 + configs/omap3_overo_defconfig | 1 + configs/omap4_panda_defconfig | 1 + configs/omap5_uevm_defconfig | 1 + configs/pcm051_rev1_defconfig | 1 + configs/pcm051_rev3_defconfig | 1 + configs/pengwyn_defconfig | 1 + configs/twister_defconfig | 1 + include/configs/gw_ventana.h | 1 - include/configs/ipam390.h | 1 - include/configs/microblaze-generic.h | 1 - include/configs/mx6sabreauto.h | 1 - include/configs/mx6sabresd.h | 1 - include/configs/ti_armv7_common.h | 4 ---- include/configs/trats.h | 1 - include/configs/twister.h | 1 - include/configs/zynq-common.h | 1 - scripts/config_whitelist.txt | 1 - 43 files changed, 41 insertions(+), 13 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 477e76be29..c0f1c2802e 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -729,6 +729,7 @@ config ARCH_ZYNQ select CLK_ZYNQ imply CMD_CLK imply FAT_WRITE + imply CMD_SPL
config ARCH_ZYNQMP bool "Support Xilinx ZynqMP Platform" diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index bb2ce33132..9bae748c67 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -145,6 +145,7 @@ config TARGET_GW_VENTANA bool "gw_ventana" select SUPPORT_SPL imply CMD_SATA + imply CMD_SPL
config TARGET_KOSAGI_NOVENA bool "Kosagi Novena" diff --git a/arch/arm/mach-omap2/am33xx/Kconfig b/arch/arm/mach-omap2/am33xx/Kconfig index d8abba992a..7260d27877 100644 --- a/arch/arm/mach-omap2/am33xx/Kconfig +++ b/arch/arm/mach-omap2/am33xx/Kconfig @@ -81,6 +81,7 @@ config TARGET_AM335X_SHC select DM select DM_SERIAL select DM_GPIO + imply CMD_SPL
config TARGET_AM335X_SL50 bool "Support am335x_sl50" diff --git a/cmd/Kconfig b/cmd/Kconfig index 2a9c55f608..9157900a18 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -275,6 +275,15 @@ config CMD_POWEROFF help Poweroff/Shutdown the system
+config CMD_SPL + bool "spl export - Export boot information for Falcon boot" + depends on SPL + help + Falcon mode allows booting directly from SPL into an Operating + System such as Linux, thus skipping U-Boot proper. See + doc/README.falcon for full information about how to use this + command. + endmenu
menu "Environment commands" diff --git a/configs/am335x_boneblack_defconfig b/configs/am335x_boneblack_defconfig index ae2adb792a..0e30575287 100644 --- a/configs/am335x_boneblack_defconfig +++ b/configs/am335x_boneblack_defconfig @@ -24,6 +24,7 @@ CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x81000000 CONFIG_FASTBOOT_BUF_SIZE=0x07000000 # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_DFU_TFTP=y diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index 3ff6220dfc..2ea57ced8d 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -27,6 +27,7 @@ CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x81000000 CONFIG_FASTBOOT_BUF_SIZE=0x07000000 # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index b68857d7b7..07d70db9f2 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -20,6 +20,7 @@ CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x81000000 CONFIG_FASTBOOT_BUF_SIZE=0x07000000 # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/am335x_evm_nor_defconfig b/configs/am335x_evm_nor_defconfig index ebf155bfca..eb5a0d6abb 100644 --- a/configs/am335x_evm_nor_defconfig +++ b/configs/am335x_evm_nor_defconfig @@ -19,6 +19,7 @@ CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x81000000 CONFIG_FASTBOOT_BUF_SIZE=0x07000000 # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MTDPARTS=y diff --git a/configs/am335x_evm_usbspl_defconfig b/configs/am335x_evm_usbspl_defconfig index efc34ff2e8..7c7a5bd150 100644 --- a/configs/am335x_evm_usbspl_defconfig +++ b/configs/am335x_evm_usbspl_defconfig @@ -22,6 +22,7 @@ CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x81000000 CONFIG_FASTBOOT_BUF_SIZE=0x07000000 # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/am335x_igep003x_defconfig b/configs/am335x_igep003x_defconfig index 2c628870e0..480d94e38c 100644 --- a/configs/am335x_igep003x_defconfig +++ b/configs/am335x_igep003x_defconfig @@ -29,6 +29,7 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y diff --git a/configs/am335x_sl50_defconfig b/configs/am335x_sl50_defconfig index 5d5c68e0fa..6757473c90 100644 --- a/configs/am335x_sl50_defconfig +++ b/configs/am335x_sl50_defconfig @@ -29,6 +29,7 @@ CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_DELAY_STR="d" CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y CONFIG_CMD_ASKENV=y CONFIG_CMD_EEPROM=y # CONFIG_CMD_FLASH is not set diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index e99ee80cef..9cb1a6b2a3 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/am43xx_evm_ethboot_defconfig b/configs/am43xx_evm_ethboot_defconfig index 7a561fd746..75dbb38ebc 100644 --- a/configs/am43xx_evm_ethboot_defconfig +++ b/configs/am43xx_evm_ethboot_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y CONFIG_CMD_ASKENV=y CONFIG_CMD_EEPROM=y # CONFIG_CMD_FLASH is not set diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index 90c0c85988..b073b4fe55 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -19,6 +19,7 @@ CONFIG_SPL_USB_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y CONFIG_CMD_ASKENV=y CONFIG_CMD_EEPROM=y # CONFIG_CMD_FLASH is not set diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 9cae0cb9f7..ac6f8f43b6 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -33,6 +33,7 @@ CONFIG_FASTBOOT_USB_DEV=1 CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=1 # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_PMIC is not set diff --git a/configs/am57xx_evm_nodt_defconfig b/configs/am57xx_evm_nodt_defconfig index 0a898ded4b..c8d773ea10 100644 --- a/configs/am57xx_evm_nodt_defconfig +++ b/configs/am57xx_evm_nodt_defconfig @@ -24,6 +24,7 @@ CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=1 CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPT=y diff --git a/configs/birdland_bav335a_defconfig b/configs/birdland_bav335a_defconfig index c5d15c6296..b5d2518cd5 100644 --- a/configs/birdland_bav335a_defconfig +++ b/configs/birdland_bav335a_defconfig @@ -26,6 +26,7 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y CONFIG_CMD_ASKENV=y CONFIG_CMD_EEPROM=y # CONFIG_CMD_FLASH is not set diff --git a/configs/birdland_bav335b_defconfig b/configs/birdland_bav335b_defconfig index 31e077c395..b1cc9784a8 100644 --- a/configs/birdland_bav335b_defconfig +++ b/configs/birdland_bav335b_defconfig @@ -26,6 +26,7 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y CONFIG_CMD_ASKENV=y CONFIG_CMD_EEPROM=y # CONFIG_CMD_FLASH is not set diff --git a/configs/cairo_defconfig b/configs/cairo_defconfig index 4c881d207e..f4ad7267f8 100644 --- a/configs/cairo_defconfig +++ b/configs/cairo_defconfig @@ -13,6 +13,7 @@ CONFIG_SYS_PROMPT="Cairo # " CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index cd790fc675..8c0d1eed20 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -9,6 +9,7 @@ CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 56effa08d0..77f9bc3e34 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -32,6 +32,7 @@ CONFIG_FASTBOOT_BUF_SIZE=0x2f000000 CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=1 # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_ISO_PARTITION=y diff --git a/configs/ipam390_defconfig b/configs/ipam390_defconfig index 0337afa380..c97256d0ff 100644 --- a/configs/ipam390_defconfig +++ b/configs/ipam390_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot > " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y CONFIG_CMD_ASKENV=y CONFIG_CRC32_VERIFY=y # CONFIG_CMD_FLASH is not set diff --git a/configs/microblaze-generic_defconfig b/configs/microblaze-generic_defconfig index 789488e735..7c2d7f8362 100644 --- a/configs/microblaze-generic_defconfig +++ b/configs/microblaze-generic_defconfig @@ -21,6 +21,7 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SYS_OS_BASE=0x2c060000 CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot-mONStR> " +CONFIG_CMD_SPL=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GPIO=y CONFIG_CMD_MFSL=y diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index 03bd57351b..6c37df135e 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -22,6 +22,7 @@ CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_PART=y diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index b876be5831..f824f7c547 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_OS_BOOT=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index 1eb1ff8f12..d1eb9419fb 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -19,6 +19,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="OMAP Logic # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y # CONFIG_CMD_EEPROM is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y diff --git a/configs/omap3_overo_defconfig b/configs/omap3_overo_defconfig index 1a1dfcfafb..12dab49318 100644 --- a/configs/omap3_overo_defconfig +++ b/configs/omap3_overo_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_PROMPT="Overo # " CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y diff --git a/configs/omap4_panda_defconfig b/configs/omap4_panda_defconfig index b9503440d4..3e39e2f0df 100644 --- a/configs/omap4_panda_defconfig +++ b/configs/omap4_panda_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL=y # CONFIG_SPL_I2C_SUPPORT is not set CONFIG_SPL_OS_BOOT=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y diff --git a/configs/omap5_uevm_defconfig b/configs/omap5_uevm_defconfig index 635bdf7e13..c613433d12 100644 --- a/configs/omap5_uevm_defconfig +++ b/configs/omap5_uevm_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPT=y diff --git a/configs/pcm051_rev1_defconfig b/configs/pcm051_rev1_defconfig index 6571876f24..103391520b 100644 --- a/configs/pcm051_rev1_defconfig +++ b/configs/pcm051_rev1_defconfig @@ -28,6 +28,7 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y CONFIG_CMD_ASKENV=y CONFIG_CMD_EEPROM=y # CONFIG_CMD_FLASH is not set diff --git a/configs/pcm051_rev3_defconfig b/configs/pcm051_rev3_defconfig index a622359f24..4add43836b 100644 --- a/configs/pcm051_rev3_defconfig +++ b/configs/pcm051_rev3_defconfig @@ -28,6 +28,7 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y CONFIG_CMD_ASKENV=y CONFIG_CMD_EEPROM=y # CONFIG_CMD_FLASH is not set diff --git a/configs/pengwyn_defconfig b/configs/pengwyn_defconfig index 27b3b0b307..8354eba25a 100644 --- a/configs/pengwyn_defconfig +++ b/configs/pengwyn_defconfig @@ -29,6 +29,7 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y CONFIG_CMD_ASKENV=y CONFIG_CMD_EEPROM=y # CONFIG_CMD_FLASH is not set diff --git a/configs/twister_defconfig b/configs/twister_defconfig index b9e8cf9155..f99f781baf 100644 --- a/configs/twister_defconfig +++ b/configs/twister_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="twister => " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y CONFIG_CMD_EEPROM=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 18d1e7b1f5..0c395e5480 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -12,7 +12,6 @@ #define CONFIG_SYS_NAND_U_BOOT_OFFS (14 * SZ_1M)
/* Falcon Mode */ -#define CONFIG_CMD_SPL #define CONFIG_SYS_SPL_ARGS_ADDR 0x18000000 #define CONFIG_CMD_SPL_WRITE_SIZE (128 * SZ_1K)
diff --git a/include/configs/ipam390.h b/include/configs/ipam390.h index 083ccd8ef6..4824941dc3 100644 --- a/include/configs/ipam390.h +++ b/include/configs/ipam390.h @@ -274,7 +274,6 @@ GENERATED_GBL_DATA_SIZE)
/* add FALCON boot mode */ -#define CONFIG_CMD_SPL #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00200000 #define CONFIG_SYS_SPL_ARGS_ADDR LINUX_BOOT_PARAM_ADDR #define CONFIG_CMD_SPL_NAND_OFS 0x00180000 diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index 8ddbf599e1..3c8b640f1d 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -236,7 +236,6 @@ #endif
/* SPL part */ -#define CONFIG_CMD_SPL #define CONFIG_SPL_FRAMEWORK
#define CONFIG_SPL_LDSCRIPT "arch/microblaze/cpu/u-boot-spl.lds" diff --git a/include/configs/mx6sabreauto.h b/include/configs/mx6sabreauto.h index bd178a4a87..daebf5cba5 100644 --- a/include/configs/mx6sabreauto.h +++ b/include/configs/mx6sabreauto.h @@ -34,7 +34,6 @@ #ifdef CONFIG_SPL_OS_BOOT #define CONFIG_SPL_FS_LOAD_ARGS_NAME "args" #define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" -#define CONFIG_CMD_SPL #define CONFIG_SYS_SPL_ARGS_ADDR 0x18000000 #define CONFIG_CMD_SPL_WRITE_SIZE (128 * SZ_1K)
diff --git a/include/configs/mx6sabresd.h b/include/configs/mx6sabresd.h index 0fa442985a..9622394c8f 100644 --- a/include/configs/mx6sabresd.h +++ b/include/configs/mx6sabresd.h @@ -24,7 +24,6 @@ /* Falcon Mode */ #define CONFIG_SPL_FS_LOAD_ARGS_NAME "args" #define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" -#define CONFIG_CMD_SPL #define CONFIG_SYS_SPL_ARGS_ADDR 0x18000000 #define CONFIG_CMD_SPL_WRITE_SIZE (128 * SZ_1K)
diff --git a/include/configs/ti_armv7_common.h b/include/configs/ti_armv7_common.h index ccd7cd72d2..ac3eb5d729 100644 --- a/include/configs/ti_armv7_common.h +++ b/include/configs/ti_armv7_common.h @@ -201,10 +201,6 @@ #define CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR 0x1700 /* address 0x2E0000 */ #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0x1500 /* address 0x2A0000 */ #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS 0x200 /* 256KiB */ - - -/* spl export command */ -#define CONFIG_CMD_SPL #endif
/* General parts of the framework, required. */ diff --git a/include/configs/trats.h b/include/configs/trats.h index 3059d89ac9..861eb26305 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -166,7 +166,6 @@ "fdtaddr=40800000\0" \
/* Falcon mode definitions */ -#define CONFIG_CMD_SPL #define CONFIG_SYS_SPL_ARGS_ADDR CONFIG_SYS_SDRAM_BASE + 0x100
/* GPT */ diff --git a/include/configs/twister.h b/include/configs/twister.h index 94dde90e60..c45ae87a41 100644 --- a/include/configs/twister.h +++ b/include/configs/twister.h @@ -36,7 +36,6 @@ "bootcmd=run nandboot\0"
/* SPL OS boot options */ -#define CONFIG_CMD_SPL #define CONFIG_CMD_SPL_WRITE_SIZE 0x400 /* 1024 byte */ #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00200000 #define CONFIG_CMD_SPL_NAND_OFS (CONFIG_SYS_NAND_SPL_KERNEL_OFFS+\ diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 056eef7ce8..35e5c1e64f 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -318,7 +318,6 @@ /* Commands */
#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-zynq/u-boot-spl.lds" diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 08351b57e1..2bac9cf7a2 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_SPL CONFIG_CMD_SPL_NAND_OFS CONFIG_CMD_SPL_WRITE_SIZE CONFIG_CMD_STRINGS
Changes in v2:
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com
Changes in v2:
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
This converts the following to Kconfig: CONFIG_CMD_SPL_NAND_OFS
Changes in v2: - Drop unwanted 'CONFIG_CMD_SPL_NAND_OFS=0x0' lines in defconfig
cmd/Kconfig | 10 ++++++++++ configs/am335x_evm_defconfig | 1 + configs/am335x_evm_nor_defconfig | 1 + configs/am335x_evm_usbspl_defconfig | 1 + configs/am43xx_evm_defconfig | 1 + configs/am43xx_evm_ethboot_defconfig | 1 + configs/am43xx_evm_usbhost_boot_defconfig | 1 + configs/cairo_defconfig | 1 + configs/devkit8000_defconfig | 1 + configs/gwventana_emmc_defconfig | 1 + configs/gwventana_gw5904_defconfig | 1 + configs/gwventana_nand_defconfig | 1 + configs/igep0020_defconfig | 1 + configs/igep0030_defconfig | 1 + configs/igep0032_defconfig | 1 + configs/ipam390_defconfig | 1 + configs/omap3_beagle_defconfig | 1 + configs/omap3_logic_defconfig | 1 + configs/omap3_overo_defconfig | 1 + configs/pengwyn_defconfig | 1 + configs/twister_defconfig | 1 + include/configs/am335x_evm.h | 1 - include/configs/am43xx_evm.h | 1 - include/configs/baltos.h | 1 - include/configs/bav335x.h | 1 - include/configs/brppt1.h | 1 - include/configs/cm_t335.h | 1 - include/configs/devkit8000.h | 2 -- include/configs/dra7xx_evm.h | 1 - include/configs/gw_ventana.h | 1 - include/configs/ipam390.h | 1 - include/configs/omap3_beagle.h | 1 - include/configs/omap3_cairo.h | 1 - include/configs/omap3_logic.h | 1 - include/configs/omap3_overo.h | 1 - include/configs/omap3_zoom1.h | 1 - include/configs/pengwyn.h | 1 - include/configs/twister.h | 2 -- scripts/config_whitelist.txt | 1 - 39 files changed, 30 insertions(+), 20 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 9157900a18..065664db06 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -284,6 +284,16 @@ config CMD_SPL doc/README.falcon for full information about how to use this command.
+config CMD_SPL_NAND_OFS + hex "Offset of OS command line args for Falcon-mode NAND boot" + depends on CMD_SPL + default 0 + help + This provides the offset of the command line arguments for Linux + when booting from NAND in Falcon mode. See doc/README.falcon + for full information about how to use this option (and also see + board/gateworks/gw_ventana/README for an example). + endmenu
menu "Environment commands" diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 07d70db9f2..8ffb1d61a4 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -21,6 +21,7 @@ CONFIG_FASTBOOT_BUF_ADDR=0x81000000 CONFIG_FASTBOOT_BUF_SIZE=0x07000000 # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y +CONFIG_CMD_SPL_NAND_OFS=0x00080000 # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/am335x_evm_nor_defconfig b/configs/am335x_evm_nor_defconfig index eb5a0d6abb..5aac38f3c6 100644 --- a/configs/am335x_evm_nor_defconfig +++ b/configs/am335x_evm_nor_defconfig @@ -21,6 +21,7 @@ CONFIG_FASTBOOT_BUF_SIZE=0x07000000 # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y CONFIG_CMD_NAND=y +CONFIG_CMD_SPL_NAND_OFS=0x00080000 # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MTDPARTS=y CONFIG_DFU_MMC=y diff --git a/configs/am335x_evm_usbspl_defconfig b/configs/am335x_evm_usbspl_defconfig index 7c7a5bd150..83d6aba8e5 100644 --- a/configs/am335x_evm_usbspl_defconfig +++ b/configs/am335x_evm_usbspl_defconfig @@ -23,6 +23,7 @@ CONFIG_FASTBOOT_BUF_ADDR=0x81000000 CONFIG_FASTBOOT_BUF_SIZE=0x07000000 # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y +CONFIG_CMD_SPL_NAND_OFS=0x00080000 # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 9cb1a6b2a3..29f0be28e3 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y +CONFIG_CMD_SPL_NAND_OFS=0x00100000 # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/am43xx_evm_ethboot_defconfig b/configs/am43xx_evm_ethboot_defconfig index 75dbb38ebc..b5a2863328 100644 --- a/configs/am43xx_evm_ethboot_defconfig +++ b/configs/am43xx_evm_ethboot_defconfig @@ -16,6 +16,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y +CONFIG_CMD_SPL_NAND_OFS=0x00100000 CONFIG_CMD_ASKENV=y CONFIG_CMD_EEPROM=y # CONFIG_CMD_FLASH is not set diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index b073b4fe55..28302a4979 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -20,6 +20,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y +CONFIG_CMD_SPL_NAND_OFS=0x00100000 CONFIG_CMD_ASKENV=y CONFIG_CMD_EEPROM=y # CONFIG_CMD_FLASH is not set diff --git a/configs/cairo_defconfig b/configs/cairo_defconfig index f4ad7267f8..da2cf4cfe4 100644 --- a/configs/cairo_defconfig +++ b/configs/cairo_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y +CONFIG_CMD_SPL_NAND_OFS=0x240000 CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index 8c0d1eed20..dadc8b6ab3 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -10,6 +10,7 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y +CONFIG_CMD_SPL_NAND_OFS=0x680000 # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index 316df3e97f..3318faee0f 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -32,6 +32,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Ventana > " CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL_NAND_OFS=0x1100000 # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig index d04a92b83a..7830d90ca2 100644 --- a/configs/gwventana_gw5904_defconfig +++ b/configs/gwventana_gw5904_defconfig @@ -32,6 +32,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Ventana > " CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL_NAND_OFS=0x1100000 # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index 02b4d2bec3..3b0f42d377 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -33,6 +33,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Ventana > " CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL_NAND_OFS=0x1100000 # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y diff --git a/configs/igep0020_defconfig b/configs/igep0020_defconfig index 2375f861f1..576674cc33 100644 --- a/configs/igep0020_defconfig +++ b/configs/igep0020_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_ONENAND_SUPPORT=y CONFIG_SPL_OS_BOOT=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y diff --git a/configs/igep0030_defconfig b/configs/igep0030_defconfig index 03da20162b..b80db9a876 100644 --- a/configs/igep0030_defconfig +++ b/configs/igep0030_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_ONENAND_SUPPORT=y CONFIG_SPL_OS_BOOT=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y diff --git a/configs/igep0032_defconfig b/configs/igep0032_defconfig index fb8c925113..237bc43f5d 100644 --- a/configs/igep0032_defconfig +++ b/configs/igep0032_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_ONENAND_SUPPORT=y CONFIG_SPL_OS_BOOT=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPL=y CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y diff --git a/configs/ipam390_defconfig b/configs/ipam390_defconfig index c97256d0ff..702b311568 100644 --- a/configs/ipam390_defconfig +++ b/configs/ipam390_defconfig @@ -18,6 +18,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot > " # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y +CONFIG_CMD_SPL_NAND_OFS=0x00180000 CONFIG_CMD_ASKENV=y CONFIG_CRC32_VERIFY=y # CONFIG_CMD_FLASH is not set diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index f824f7c547..98e2be62db 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -11,6 +11,7 @@ CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_OS_BOOT=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y +CONFIG_CMD_SPL_NAND_OFS=0x240000 CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index d1eb9419fb..27c9e21bd5 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_PROMPT="OMAP Logic # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y +CONFIG_CMD_SPL_NAND_OFS=0x240000 # CONFIG_CMD_EEPROM is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y diff --git a/configs/omap3_overo_defconfig b/configs/omap3_overo_defconfig index 12dab49318..18bb6a124d 100644 --- a/configs/omap3_overo_defconfig +++ b/configs/omap3_overo_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y +CONFIG_CMD_SPL_NAND_OFS=0x240000 CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y diff --git a/configs/pengwyn_defconfig b/configs/pengwyn_defconfig index 8354eba25a..b4562b599c 100644 --- a/configs/pengwyn_defconfig +++ b/configs/pengwyn_defconfig @@ -30,6 +30,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y +CONFIG_CMD_SPL_NAND_OFS=0x240000 CONFIG_CMD_ASKENV=y CONFIG_CMD_EEPROM=y # CONFIG_CMD_FLASH is not set diff --git a/configs/twister_defconfig b/configs/twister_defconfig index f99f781baf..261d946f2b 100644 --- a/configs/twister_defconfig +++ b/configs/twister_defconfig @@ -11,6 +11,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="twister => " # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y +CONFIG_CMD_SPL_NAND_OFS=0x00800000 CONFIG_CMD_EEPROM=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 2a2e2ba0a9..1d8a07efff 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -238,7 +238,6 @@ #define CONFIG_SPL_NAND_AM33XX_BCH #endif #ifdef CONFIG_SPL_OS_BOOT -#define CONFIG_CMD_SPL_NAND_OFS 0x00080000 /* os parameters */ #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00200000 /* kernel offset */ #define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 #endif diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 44691676da..0d84a437d5 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -309,7 +309,6 @@ #endif /* NAND: SPL falcon mode configs */ #ifdef CONFIG_SPL_OS_BOOT -#define CONFIG_CMD_SPL_NAND_OFS 0x00100000 /* os parameters */ #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00300000 /* kernel offset */ #define CONFIG_CMD_SPL_WRITE_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #endif diff --git a/include/configs/baltos.h b/include/configs/baltos.h index aba7208c5a..1b932e24c7 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -45,7 +45,6 @@ #ifdef CONFIG_NAND #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x00080000 #ifdef CONFIG_SPL_OS_BOOT -#define CONFIG_CMD_SPL_NAND_OFS 0x00080000 /* os parameters */ #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00200000 /* kernel offset */ #define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 #endif diff --git a/include/configs/bav335x.h b/include/configs/bav335x.h index fafab8ea97..90188ea178 100644 --- a/include/configs/bav335x.h +++ b/include/configs/bav335x.h @@ -395,7 +395,6 @@ DEFAULT_LINUX_BOOT_ENV \ #define CONFIG_SPL_NAND_AM33XX_BCH #endif #ifdef CONFIG_SPL_OS_BOOT -#define CONFIG_CMD_SPL_NAND_OFS 0x00080000 /* os parameters */ #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00200000 /* kernel offset */ #define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 #endif diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index 9688c4a776..3dbbf67b5c 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -66,7 +66,6 @@
/* NAND */ #ifdef CONFIG_NAND -#define CONFIG_CMD_SPL_NAND_OFS 0x080000 /* end of u-boot */ #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x140000 #define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 #endif /* CONFIG_NAND */ diff --git a/include/configs/cm_t335.h b/include/configs/cm_t335.h index bc52aae251..a3c2942f79 100644 --- a/include/configs/cm_t335.h +++ b/include/configs/cm_t335.h @@ -139,7 +139,6 @@ #define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ #define CONFIG_SYS_NAND_ONFI_DETECTION #ifdef CONFIG_SPL_OS_BOOT -#define CONFIG_CMD_SPL_NAND_OFS 0x400000 /* un-assigned: (using dtb) */ #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x500000 #define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 #endif diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index fb9e4c6428..b4f46697e3 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -212,8 +212,6 @@
/* SPL OS boot options */ #define CONFIG_CMD_SPL_WRITE_SIZE 0x400 /* 1024 byte */ -#define CONFIG_CMD_SPL_NAND_OFS (CONFIG_SYS_NAND_SPL_KERNEL_OFFS+\ - 0x400000) #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000
#undef CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index b5091513f7..79a4488818 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -211,7 +211,6 @@ #endif /* NAND: SPL falcon mode configs */ #ifdef CONFIG_SPL_OS_BOOT -#define CONFIG_CMD_SPL_NAND_OFS 0x00080000 /* os-boot params*/ #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00200000 /* kernel offset */ #define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 #endif diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 0c395e5480..d389058573 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -16,7 +16,6 @@ #define CONFIG_CMD_SPL_WRITE_SIZE (128 * SZ_1K)
/* Falcon Mode - NAND support: args@17MB kernel@18MB */ -#define CONFIG_CMD_SPL_NAND_OFS (17 * SZ_1M) #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS (18 * SZ_1M)
/* Falcon Mode - MMC support: args@1MB kernel@2MB */ diff --git a/include/configs/ipam390.h b/include/configs/ipam390.h index 4824941dc3..6adbb8e778 100644 --- a/include/configs/ipam390.h +++ b/include/configs/ipam390.h @@ -276,7 +276,6 @@ /* add FALCON boot mode */ #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00200000 #define CONFIG_SYS_SPL_ARGS_ADDR LINUX_BOOT_PARAM_ADDR -#define CONFIG_CMD_SPL_NAND_OFS 0x00180000 #define CONFIG_CMD_SPL_WRITE_SIZE 0x400
/* GPIO support */ diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index a87a75e3cc..c6839013f2 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -276,7 +276,6 @@ #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 /* NAND: SPL falcon mode configs */ #ifdef CONFIG_SPL_OS_BOOT -#define CONFIG_CMD_SPL_NAND_OFS 0x240000 #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000 #define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 #endif diff --git a/include/configs/omap3_cairo.h b/include/configs/omap3_cairo.h index 4f8ce54144..5f9f8156fd 100644 --- a/include/configs/omap3_cairo.h +++ b/include/configs/omap3_cairo.h @@ -200,7 +200,6 @@ #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 /* NAND: SPL falcon mode configs */ #ifdef CONFIG_SPL_OS_BOOT -#define CONFIG_CMD_SPL_NAND_OFS 0x240000 #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000 #define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 #endif diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index 2ab74cb0e9..9143072814 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -264,7 +264,6 @@
/* NAND: SPL falcon mode configs */ #ifdef CONFIG_SPL_OS_BOOT -#define CONFIG_CMD_SPL_NAND_OFS 0x240000 #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000 #define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 #endif diff --git a/include/configs/omap3_overo.h b/include/configs/omap3_overo.h index 133069abbc..b123e62756 100644 --- a/include/configs/omap3_overo.h +++ b/include/configs/omap3_overo.h @@ -218,7 +218,6 @@ #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 /* NAND: SPL falcon mode configs */ #ifdef CONFIG_SPL_OS_BOOT -#define CONFIG_CMD_SPL_NAND_OFS 0x240000 #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000 #define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 #endif diff --git a/include/configs/omap3_zoom1.h b/include/configs/omap3_zoom1.h index b86292400a..81f8b799a0 100644 --- a/include/configs/omap3_zoom1.h +++ b/include/configs/omap3_zoom1.h @@ -57,7 +57,6 @@ #if defined(CONFIG_CMD_NAND) /* NAND: SPL falcon mode configs */ #ifdef CONFIG_SPL_OS_BOOT -#define CONFIG_CMD_SPL_NAND_OFS 0x240000 #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000 #define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 #endif diff --git a/include/configs/pengwyn.h b/include/configs/pengwyn.h index dbe0ddd785..1d962b100a 100644 --- a/include/configs/pengwyn.h +++ b/include/configs/pengwyn.h @@ -163,7 +163,6 @@ #define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ /* NAND: SPL falcon mode configs */ #ifdef CONFIG_SPL_OS_BOOT -#define CONFIG_CMD_SPL_NAND_OFS 0x240000 /* un-assigned */ #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000 #define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 #endif diff --git a/include/configs/twister.h b/include/configs/twister.h index c45ae87a41..80d480b103 100644 --- a/include/configs/twister.h +++ b/include/configs/twister.h @@ -38,8 +38,6 @@ /* SPL OS boot options */ #define CONFIG_CMD_SPL_WRITE_SIZE 0x400 /* 1024 byte */ #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00200000 -#define CONFIG_CMD_SPL_NAND_OFS (CONFIG_SYS_NAND_SPL_KERNEL_OFFS+\ - 0x600000)
#define CONFIG_SYS_SPL_ARGS_ADDR (PHYS_SDRAM_1 + 0x100)
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 2bac9cf7a2..d12eeec5cb 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_SPL_NAND_OFS CONFIG_CMD_SPL_WRITE_SIZE CONFIG_CMD_STRINGS CONFIG_CMD_SX151X
Changes in v2:
Changes in v2:
This converts the following to Kconfig: CONFIG_CMD_SPL_WRITE_SIZE
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com ---
Changes in v2: None
cmd/Kconfig | 9 +++++++++ configs/am43xx_evm_defconfig | 1 + configs/am43xx_evm_ethboot_defconfig | 1 + configs/am43xx_evm_usbhost_boot_defconfig | 1 + configs/devkit8000_defconfig | 1 + configs/gwventana_emmc_defconfig | 1 + configs/gwventana_gw5904_defconfig | 1 + configs/gwventana_nand_defconfig | 1 + configs/ipam390_defconfig | 1 + configs/mx6sabresd_defconfig | 1 + configs/twister_defconfig | 1 + include/configs/am335x_evm.h | 1 - include/configs/am43xx_evm.h | 1 - include/configs/baltos.h | 1 - include/configs/bav335x.h | 1 - include/configs/brppt1.h | 1 - include/configs/cm_t335.h | 1 - include/configs/devkit8000.h | 1 - include/configs/dra7xx_evm.h | 1 - include/configs/gw_ventana.h | 1 - include/configs/ipam390.h | 1 - include/configs/mx6sabreauto.h | 1 - include/configs/mx6sabresd.h | 1 - include/configs/omap3_beagle.h | 1 - include/configs/omap3_cairo.h | 1 - include/configs/omap3_logic.h | 1 - include/configs/omap3_overo.h | 1 - include/configs/omap3_zoom1.h | 1 - include/configs/pengwyn.h | 1 - include/configs/twister.h | 1 - scripts/config_whitelist.txt | 1 - 31 files changed, 19 insertions(+), 20 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 065664db06..df16508e47 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -294,6 +294,15 @@ config CMD_SPL_NAND_OFS for full information about how to use this option (and also see board/gateworks/gw_ventana/README for an example).
+config CMD_SPL_WRITE_SIZE + hex "Size of argument area" + depends on CMD_SPL + default 0x2000 + help + This provides the size of the command-line argument area in NAND + flash used by Falcon-mode boot. See the documentation until CMD_SPL + for detail. + endmenu
menu "Environment commands" diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 29f0be28e3..0c8b784cd6 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -17,6 +17,7 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y CONFIG_CMD_SPL_NAND_OFS=0x00100000 +CONFIG_CMD_SPL_WRITE_SIZE=0x40000 # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/am43xx_evm_ethboot_defconfig b/configs/am43xx_evm_ethboot_defconfig index b5a2863328..f6a51a24a7 100644 --- a/configs/am43xx_evm_ethboot_defconfig +++ b/configs/am43xx_evm_ethboot_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y CONFIG_CMD_SPL_NAND_OFS=0x00100000 +CONFIG_CMD_SPL_WRITE_SIZE=0x40000 CONFIG_CMD_ASKENV=y CONFIG_CMD_EEPROM=y # CONFIG_CMD_FLASH is not set diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index 28302a4979..08686d8d9d 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y CONFIG_CMD_SPL_NAND_OFS=0x00100000 +CONFIG_CMD_SPL_WRITE_SIZE=0x40000 CONFIG_CMD_ASKENV=y CONFIG_CMD_EEPROM=y # CONFIG_CMD_FLASH is not set diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index dadc8b6ab3..b3a602314a 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -11,6 +11,7 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y CONFIG_CMD_SPL_NAND_OFS=0x680000 +CONFIG_CMD_SPL_WRITE_SIZE=0x400 # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index 3318faee0f..944c0125e8 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -33,6 +33,7 @@ CONFIG_SYS_PROMPT="Ventana > " CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL_NAND_OFS=0x1100000 +CONFIG_CMD_SPL_WRITE_SIZE=0x20000 # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig index 7830d90ca2..5b2672c2bf 100644 --- a/configs/gwventana_gw5904_defconfig +++ b/configs/gwventana_gw5904_defconfig @@ -33,6 +33,7 @@ CONFIG_SYS_PROMPT="Ventana > " CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL_NAND_OFS=0x1100000 +CONFIG_CMD_SPL_WRITE_SIZE=0x20000 # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index 3b0f42d377..ecbe4e60a6 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -34,6 +34,7 @@ CONFIG_SYS_PROMPT="Ventana > " CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL_NAND_OFS=0x1100000 +CONFIG_CMD_SPL_WRITE_SIZE=0x20000 # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y diff --git a/configs/ipam390_defconfig b/configs/ipam390_defconfig index 702b311568..80d9f47a65 100644 --- a/configs/ipam390_defconfig +++ b/configs/ipam390_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_PROMPT="U-Boot > " # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y CONFIG_CMD_SPL_NAND_OFS=0x00180000 +CONFIG_CMD_SPL_WRITE_SIZE=0x400 CONFIG_CMD_ASKENV=y CONFIG_CRC32_VERIFY=y # CONFIG_CMD_FLASH is not set diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index 6c37df135e..99da859303 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -23,6 +23,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y +CONFIG_CMD_SPL_WRITE_SIZE=0x20000 # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_PART=y diff --git a/configs/twister_defconfig b/configs/twister_defconfig index 261d946f2b..82bcc8a2d8 100644 --- a/configs/twister_defconfig +++ b/configs/twister_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_PROMPT="twister => " # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPL=y CONFIG_CMD_SPL_NAND_OFS=0x00800000 +CONFIG_CMD_SPL_WRITE_SIZE=0x400 CONFIG_CMD_EEPROM=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 1d8a07efff..1c6189311c 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -239,7 +239,6 @@ #endif #ifdef CONFIG_SPL_OS_BOOT #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00200000 /* kernel offset */ -#define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 #endif #endif /* !CONFIG_NAND */
diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 0d84a437d5..d5d15e08fa 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -310,7 +310,6 @@ /* NAND: SPL falcon mode configs */ #ifdef CONFIG_SPL_OS_BOOT #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00300000 /* kernel offset */ -#define CONFIG_CMD_SPL_WRITE_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #endif #define NANDARGS \ "mtdids=" MTDIDS_DEFAULT "\0" \ diff --git a/include/configs/baltos.h b/include/configs/baltos.h index 1b932e24c7..4e352b0e29 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -46,7 +46,6 @@ #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x00080000 #ifdef CONFIG_SPL_OS_BOOT #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00200000 /* kernel offset */ -#define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 #endif #define NANDARGS \ "mtdids=" MTDIDS_DEFAULT "\0" \ diff --git a/include/configs/bav335x.h b/include/configs/bav335x.h index 90188ea178..0c93a2b1b6 100644 --- a/include/configs/bav335x.h +++ b/include/configs/bav335x.h @@ -396,7 +396,6 @@ DEFAULT_LINUX_BOOT_ENV \ #endif #ifdef CONFIG_SPL_OS_BOOT #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00200000 /* kernel offset */ -#define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 #endif #endif /* !CONFIG_NAND */
diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index 3dbbf67b5c..f965fc9a1d 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -67,7 +67,6 @@ /* NAND */ #ifdef CONFIG_NAND #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x140000 -#define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 #endif /* CONFIG_NAND */ #endif /* CONFIG_SPL_OS_BOOT */
diff --git a/include/configs/cm_t335.h b/include/configs/cm_t335.h index a3c2942f79..99bc4e08df 100644 --- a/include/configs/cm_t335.h +++ b/include/configs/cm_t335.h @@ -140,7 +140,6 @@ #define CONFIG_SYS_NAND_ONFI_DETECTION #ifdef CONFIG_SPL_OS_BOOT #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x500000 -#define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 #endif
/* GPIO pin + bank to pin ID mapping */ diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index b4f46697e3..f935334388 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -211,7 +211,6 @@ #define CONFIG_SYS_NAND_U_BOOT_SIZE 0x200000
/* SPL OS boot options */ -#define CONFIG_CMD_SPL_WRITE_SIZE 0x400 /* 1024 byte */ #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000
#undef CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 79a4488818..fce67b7cef 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -212,7 +212,6 @@ /* NAND: SPL falcon mode configs */ #ifdef CONFIG_SPL_OS_BOOT #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00200000 /* kernel offset */ -#define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 #endif #endif /* !CONFIG_NAND */
diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index d389058573..aeacd46f33 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -13,7 +13,6 @@
/* Falcon Mode */ #define CONFIG_SYS_SPL_ARGS_ADDR 0x18000000 -#define CONFIG_CMD_SPL_WRITE_SIZE (128 * SZ_1K)
/* Falcon Mode - NAND support: args@17MB kernel@18MB */ #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS (18 * SZ_1M) diff --git a/include/configs/ipam390.h b/include/configs/ipam390.h index 6adbb8e778..be91dc27cd 100644 --- a/include/configs/ipam390.h +++ b/include/configs/ipam390.h @@ -276,7 +276,6 @@ /* add FALCON boot mode */ #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00200000 #define CONFIG_SYS_SPL_ARGS_ADDR LINUX_BOOT_PARAM_ADDR -#define CONFIG_CMD_SPL_WRITE_SIZE 0x400
/* GPIO support */ #define CONFIG_DA8XX_GPIO diff --git a/include/configs/mx6sabreauto.h b/include/configs/mx6sabreauto.h index daebf5cba5..03ab812a32 100644 --- a/include/configs/mx6sabreauto.h +++ b/include/configs/mx6sabreauto.h @@ -35,7 +35,6 @@ #define CONFIG_SPL_FS_LOAD_ARGS_NAME "args" #define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" #define CONFIG_SYS_SPL_ARGS_ADDR 0x18000000 -#define CONFIG_CMD_SPL_WRITE_SIZE (128 * SZ_1K)
/* Falcon Mode - MMC support: args@1MB kernel@2MB */ #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0x800 /* 1MB */ diff --git a/include/configs/mx6sabresd.h b/include/configs/mx6sabresd.h index 9622394c8f..5410881fa1 100644 --- a/include/configs/mx6sabresd.h +++ b/include/configs/mx6sabresd.h @@ -25,7 +25,6 @@ #define CONFIG_SPL_FS_LOAD_ARGS_NAME "args" #define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" #define CONFIG_SYS_SPL_ARGS_ADDR 0x18000000 -#define CONFIG_CMD_SPL_WRITE_SIZE (128 * SZ_1K)
/* Falcon Mode - MMC support: args@1MB kernel@2MB */ #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0x800 /* 1MB */ diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index c6839013f2..fe83e71b61 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -277,7 +277,6 @@ /* NAND: SPL falcon mode configs */ #ifdef CONFIG_SPL_OS_BOOT #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000 -#define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 #endif
#endif /* __CONFIG_H */ diff --git a/include/configs/omap3_cairo.h b/include/configs/omap3_cairo.h index 5f9f8156fd..162fe0f2d3 100644 --- a/include/configs/omap3_cairo.h +++ b/include/configs/omap3_cairo.h @@ -201,7 +201,6 @@ /* NAND: SPL falcon mode configs */ #ifdef CONFIG_SPL_OS_BOOT #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000 -#define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 #endif
/* env defaults */ diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index 9143072814..e4527471f4 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -265,7 +265,6 @@ /* NAND: SPL falcon mode configs */ #ifdef CONFIG_SPL_OS_BOOT #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000 -#define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 #endif
#endif /* __CONFIG_H */ diff --git a/include/configs/omap3_overo.h b/include/configs/omap3_overo.h index b123e62756..d6c469b402 100644 --- a/include/configs/omap3_overo.h +++ b/include/configs/omap3_overo.h @@ -219,7 +219,6 @@ /* NAND: SPL falcon mode configs */ #ifdef CONFIG_SPL_OS_BOOT #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000 -#define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 #endif
#endif /* __CONFIG_H */ diff --git a/include/configs/omap3_zoom1.h b/include/configs/omap3_zoom1.h index 81f8b799a0..f58d621e2c 100644 --- a/include/configs/omap3_zoom1.h +++ b/include/configs/omap3_zoom1.h @@ -58,7 +58,6 @@ /* NAND: SPL falcon mode configs */ #ifdef CONFIG_SPL_OS_BOOT #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000 -#define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 #endif #endif
diff --git a/include/configs/pengwyn.h b/include/configs/pengwyn.h index 1d962b100a..55ce849081 100644 --- a/include/configs/pengwyn.h +++ b/include/configs/pengwyn.h @@ -164,7 +164,6 @@ /* NAND: SPL falcon mode configs */ #ifdef CONFIG_SPL_OS_BOOT #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000 -#define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 #endif
/* diff --git a/include/configs/twister.h b/include/configs/twister.h index 80d480b103..bec402ea9c 100644 --- a/include/configs/twister.h +++ b/include/configs/twister.h @@ -36,7 +36,6 @@ "bootcmd=run nandboot\0"
/* SPL OS boot options */ -#define CONFIG_CMD_SPL_WRITE_SIZE 0x400 /* 1024 byte */ #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00200000
#define CONFIG_SYS_SPL_ARGS_ADDR (PHYS_SDRAM_1 + 0x100) diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index d12eeec5cb..d2f839a7a2 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_SPL_WRITE_SIZE CONFIG_CMD_STRINGS CONFIG_CMD_SX151X CONFIG_CMD_TCA642X
Changes in v2: None
These are currently not quite in alphabetical order. Before adding more, sort them. Not all options have a CMD_ prefix, so ignore that when sorting.
Signed-off-by: Simon Glass sjg@chromium.org Suggested-by: Bin Meng bmeng.cn@gmail.com ---
Changes in v2: - Add new patch to sort the memory commands
cmd/Kconfig | 60 ++++++++++++++++++++++++++++++------------------------------ 1 file changed, 30 insertions(+), 30 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index df16508e47..bcf45fd119 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -369,20 +369,6 @@ endmenu
menu "Memory commands"
-config CMD_MEMORY - bool "md, mm, nm, mw, cp, cmp, base, loop" - default y - help - Memory commands. - md - memory display - mm - memory modify (auto-incrementing address) - nm - memory modify (constant address) - mw - memory write (fill) - cp - memory copy - cmp - memory compare - base - print or set address offset - loop - initialize loop on address range - config CMD_CRC32 bool "crc32" select HASH @@ -444,6 +430,11 @@ config EEPROM_LAYOUT_HELP_STRING Help printed with the LAYOUT VERSIONS part of the 'eeprom' command's help.
+config LOOPW + bool "loopw" + help + Infinite write loop on address range + config CMD_MD5SUM bool "md5sum" default n @@ -458,22 +449,24 @@ config MD5SUM_VERIFY help Add -v option to verify data against an MD5 checksum.
-config CMD_SHA1SUM - bool "sha1sum" - select SHA1 - help - Compute SHA1 checksum. - -config SHA1SUM_VERIFY - bool "sha1sum -v" - depends on CMD_SHA1SUM +config CMD_MEMINFO + bool "meminfo" help - Add -v option to verify data against a SHA1 checksum. + Display memory information.
-config LOOPW - bool "loopw" +config CMD_MEMORY + bool "md, mm, nm, mw, cp, cmp, base, loop" + default y help - Infinite write loop on address range + Memory commands. + md - memory display + mm - memory modify (auto-incrementing address) + nm - memory modify (constant address) + mw - memory write (fill) + cp - memory copy + cmp - memory compare + base - print or set address offset + loop - initialize loop on address range
config CMD_MEMTEST bool "memtest" @@ -486,10 +479,17 @@ config CMD_MX_CYCLIC mdc - memory display cyclic mwc - memory write cyclic
-config CMD_MEMINFO - bool "meminfo" +config CMD_SHA1SUM + bool "sha1sum" + select SHA1 help - Display memory information. + Compute SHA1 checksum. + +config SHA1SUM_VERIFY + bool "sha1sum -v" + depends on CMD_SHA1SUM + help + Add -v option to verify data against a SHA1 checksum.
endmenu
Changes in v2:
Signed-off-by: Simon Glass sjg@chromium.org Suggested-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Bin Meng bmeng.cn@gmail.com
Changes in v2:
Signed-off-by: Simon Glass sjg@chromium.org Suggested-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
This converts the following to Kconfig: CONFIG_CMD_STRINGS
Changes in v2: None
cmd/Kconfig | 8 ++++++++ include/configs/vct.h | 1 - scripts/config_whitelist.txt | 1 - 3 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index bcf45fd119..4c1cbe736f 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -491,6 +491,14 @@ config SHA1SUM_VERIFY help Add -v option to verify data against a SHA1 checksum.
+config CMD_STRINGS + bool "strings - display strings in memory" + help + This works similarly to the Unix 'strings' command except that it + works with a memory range. String of printable characters found + within the range are displayed. The minimum number of characters + for a sequence to be considered a string can be provided. + endmenu
menu "Compression commands" diff --git a/include/configs/vct.h b/include/configs/vct.h index e3c3b0e71f..a98dae8e24 100644 --- a/include/configs/vct.h +++ b/include/configs/vct.h @@ -239,7 +239,6 @@ int vct_gpio_get(int pin); * (NOR/OneNAND) usage and Linux kernel booting. */ #if defined(CONFIG_VCT_SMALL_IMAGE) -#undef CONFIG_CMD_STRINGS #undef CONFIG_CMD_TERMINAL
#undef CONFIG_SMC911X diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index d2f839a7a2..e89099472c 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_STRINGS CONFIG_CMD_SX151X CONFIG_CMD_TCA642X CONFIG_CMD_TERMINAL
Changes in v2: None
This driver is not used in U-Boot. Drop it and its associated CONFIG options.
Changes in v2: - Drop include/sx151x.h also
drivers/gpio/Makefile | 1 - drivers/gpio/sx151x.c | 242 ------------------------------------------- include/sx151x.h | 17 --- scripts/config_whitelist.txt | 3 - 4 files changed, 263 deletions(-) delete mode 100644 drivers/gpio/sx151x.c delete mode 100644 include/sx151x.h
diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index 8937e99b47..1396467ab6 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -45,7 +45,6 @@ obj-$(CONFIG_BCM2835_GPIO) += bcm2835_gpio.o obj-$(CONFIG_XILINX_GPIO) += xilinx_gpio.o obj-$(CONFIG_ADI_GPIO2) += adi_gpio2.o obj-$(CONFIG_TCA642X) += tca642x.o -oby-$(CONFIG_SX151X) += sx151x.o obj-$(CONFIG_SUNXI_GPIO) += sunxi_gpio.o obj-$(CONFIG_LPC32XX_GPIO) += lpc32xx_gpio.o obj-$(CONFIG_STM32_GPIO) += stm32_gpio.o diff --git a/drivers/gpio/sx151x.c b/drivers/gpio/sx151x.c deleted file mode 100644 index 167cf40c71..0000000000 --- a/drivers/gpio/sx151x.c +++ /dev/null @@ -1,242 +0,0 @@ -/* - * (C) Copyright 2013 - * Viktar Palstsiuk, Promwad, viktar.palstsiuk@promwad.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * Driver for Semtech SX151x SPI GPIO Expanders - */ - -#include <common.h> -#include <spi.h> -#include <sx151x.h> - -#ifndef CONFIG_SX151X_SPI_BUS -#define CONFIG_SX151X_SPI_BUS 0 -#endif - -/* - * The SX151x registers - */ - -#ifdef CONFIG_SX151X_GPIO_COUNT_8 -/* 8bit: SX1511 */ -#define SX151X_REG_DIR 0x07 -#define SX151X_REG_DATA 0x08 -#else -/* 16bit: SX1512 */ -#define SX151X_REG_DIR 0x0F -#define SX151X_REG_DATA 0x11 -#endif -#define SX151X_REG_RESET 0x7D - -static int sx151x_spi_write(int chip, unsigned char reg, unsigned char val) -{ - struct spi_slave *slave; - unsigned char buf[2]; - int ret; - - slave = spi_setup_slave(CONFIG_SX151X_SPI_BUS, chip, 1000000, - SPI_MODE_0); - if (!slave) - return 0; - - spi_claim_bus(slave); - - buf[0] = reg; - buf[1] = val; - - ret = spi_xfer(slave, 16, buf, NULL, SPI_XFER_BEGIN | SPI_XFER_END); - if (ret < 0) - printf("spi%d.%d write fail: can't write %02x to %02x: %d\n", - CONFIG_SX151X_SPI_BUS, chip, val, reg, ret); - else - printf("spi%d.%d write 0x%02x to register 0x%02x\n", - CONFIG_SX151X_SPI_BUS, chip, val, reg); - spi_release_bus(slave); - spi_free_slave(slave); - - return ret; -} - -static int sx151x_spi_read(int chip, unsigned char reg) -{ - struct spi_slave *slave; - int ret; - - slave = spi_setup_slave(CONFIG_SX151X_SPI_BUS, chip, 1000000, - SPI_MODE_0); - if (!slave) - return 0; - - spi_claim_bus(slave); - - ret = spi_w8r8(slave, reg | 0x80); - if (ret < 0) - printf("spi%d.%d read fail: can't read %02x: %d\n", - CONFIG_SX151X_SPI_BUS, chip, reg, ret); - else - printf("spi%d.%d read register 0x%02x: 0x%02x\n", - CONFIG_SX151X_SPI_BUS, chip, reg, ret); - - spi_release_bus(slave); - spi_free_slave(slave); - - return ret; -} - -static inline void sx151x_find_cfg(int gpio, unsigned char *reg, unsigned char *mask) -{ - *reg -= gpio / 8; - *mask = 1 << (gpio % 8); -} - -static int sx151x_write_cfg(int chip, unsigned char gpio, unsigned char reg, int val) -{ - unsigned char mask; - unsigned char data; - int ret; - - sx151x_find_cfg(gpio, ®, &mask); - ret = sx151x_spi_read(chip, reg); - if (ret < 0) - return ret; - else - data = ret; - data &= ~mask; - data |= (val << (gpio % 8)) & mask; - return sx151x_spi_write(chip, reg, data); -} - -int sx151x_get_value(int chip, int gpio) -{ - unsigned char reg = SX151X_REG_DATA; - unsigned char mask; - int ret; - - sx151x_find_cfg(gpio, ®, &mask); - ret = sx151x_spi_read(chip, reg); - if (ret >= 0) - ret = (ret & mask) != 0 ? 1 : 0; - - return ret; -} - -int sx151x_set_value(int chip, int gpio, int val) -{ - return sx151x_write_cfg(chip, gpio, SX151X_REG_DATA, (val ? 1 : 0)); -} - -int sx151x_direction_input(int chip, int gpio) -{ - return sx151x_write_cfg(chip, gpio, SX151X_REG_DIR, 1); -} - -int sx151x_direction_output(int chip, int gpio) -{ - return sx151x_write_cfg(chip, gpio, SX151X_REG_DIR, 0); -} - -int sx151x_reset(int chip) -{ - int err; - - err = sx151x_spi_write(chip, SX151X_REG_RESET, 0x12); - if (err < 0) - return err; - - err = sx151x_spi_write(chip, SX151X_REG_RESET, 0x34); - return err; -} - -#ifdef CONFIG_CMD_SX151X - -int do_sx151x(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - int ret = CMD_RET_USAGE, chip = 0, gpio = 0, val = 0; - - if (argc < 3) - return CMD_RET_USAGE; - - /* arg2 used as chip number */ - chip = simple_strtoul(argv[2], NULL, 10); - - if (strcmp(argv[1], "reset") == 0) { - ret = sx151x_reset(chip); - if (!ret) { - printf("Device at spi%d.%d was reset\n", - CONFIG_SX151X_SPI_BUS, chip); - } - return ret; - } - - if (argc < 4) - return CMD_RET_USAGE; - - /* arg3 used as gpio number */ - gpio = simple_strtoul(argv[3], NULL, 10); - - if (strcmp(argv[1], "get") == 0) { - ret = sx151x_get_value(chip, gpio); - if (ret < 0) - printf("Failed to get value at spi%d.%d gpio %d\n", - CONFIG_SX151X_SPI_BUS, chip, gpio); - else { - printf("Value at spi%d.%d gpio %d is %d\n", - CONFIG_SX151X_SPI_BUS, chip, gpio, ret); - ret = 0; - } - return ret; - } - - if (argc < 5) - return CMD_RET_USAGE; - - /* arg4 used as value or direction */ - val = simple_strtoul(argv[4], NULL, 10); - - if (strcmp(argv[1], "set") == 0) { - ret = sx151x_set_value(chip, gpio, val); - if (ret < 0) - printf("Failed to set value at spi%d.%d gpio %d\n", - CONFIG_SX151X_SPI_BUS, chip, gpio); - else - printf("New value at spi%d.%d gpio %d is %d\n", - CONFIG_SX151X_SPI_BUS, chip, gpio, val); - return ret; - } else if (strcmp(argv[1], "dir") == 0) { - if (val == 0) - ret = sx151x_direction_output(chip, gpio); - else - ret = sx151x_direction_input(chip, gpio); - - if (ret < 0) - printf("Failed to set direction of spi%d.%d gpio %d\n", - CONFIG_SX151X_SPI_BUS, chip, gpio); - else - printf("New direction of spi%d.%d gpio %d is %d\n", - CONFIG_SX151X_SPI_BUS, chip, gpio, val); - return ret; - } - - printf("Please see usage\n"); - - return ret; -} - -U_BOOT_CMD( - sx151x, 5, 1, do_sx151x, - "sx151x gpio access", - "dir chip gpio 0|1\n" - " - set gpio direction (0 for output, 1 for input)\n" - "sx151x get chip gpio\n" - " - get gpio value\n" - "sx151x set chip gpio 0|1\n" - " - set gpio value\n" - "sx151x reset chip\n" - " - reset chip" -); - -#endif /* CONFIG_CMD_SX151X */ diff --git a/include/sx151x.h b/include/sx151x.h deleted file mode 100644 index be42b0681b..0000000000 --- a/include/sx151x.h +++ /dev/null @@ -1,17 +0,0 @@ -/* - * (C) Copyright 2013 - * Viktar Palstsiuk, Promwad, viktar.palstsiuk@promwad.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __SX151X_H_ -#define __SX151X_H_ - -int sx151x_get_value(int chip, int gpio); -int sx151x_set_value(int chip, int gpio, int val); -int sx151x_direction_input(int chip, int gpio); -int sx151x_direction_output(int chip, int gpio); -int sx151x_reset(int chip); - -#endif /* __SX151X_H_ */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index e89099472c..f5ec487668 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_SX151X CONFIG_CMD_TCA642X CONFIG_CMD_TERMINAL CONFIG_CMD_TFTP @@ -2338,8 +2337,6 @@ CONFIG_SUPPORT_EMMC_RPMB CONFIG_SUPPORT_RAW_INITRD CONFIG_SUPPORT_VFAT CONFIG_SUVD3 -CONFIG_SX151X_GPIO_COUNT_8 -CONFIG_SX151X_SPI_BUS CONFIG_SXNI855T CONFIG_SYSCOUNTER_TIMER CONFIG_SYSFLAGS_ADDR
Changes in v2:
This converts the following to Kconfig: CONFIG_CMD_TCA642X
Changes in v2: None
configs/omap5_uevm_defconfig | 1 + drivers/gpio/Kconfig | 9 +++++++++ include/configs/omap5_uevm.h | 1 - scripts/config_whitelist.txt | 1 - 4 files changed, 10 insertions(+), 2 deletions(-)
diff --git a/configs/omap5_uevm_defconfig b/configs/omap5_uevm_defconfig index c613433d12..273be58114 100644 --- a/configs/omap5_uevm_defconfig +++ b/configs/omap5_uevm_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y +CONFIG_CMD_TCA642X=y CONFIG_MMC_OMAP_HS=y CONFIG_SCSI=y CONFIG_SYS_NS16550=y diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index d2e7c29e1d..ffeda9425a 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -165,6 +165,15 @@ config SANDBOX_GPIO_COUNT of 'anonymous' GPIOs that do not belong to any device or bank. Select a suitable value depending on your needs.
+config CMD_TCA642X + bool "tca642x - Command to access tca642x state" + help + DEPRECATED - This needs conversion to driver model + + This provides a way to looking at the pin state of this device. + This mirrors the 'gpio' command and that should be used in preference + to custom code. + config TEGRA_GPIO bool "Tegra20..210 GPIO driver" depends on DM_GPIO diff --git a/include/configs/omap5_uevm.h b/include/configs/omap5_uevm.h index 9b650090be..7e2a011843 100644 --- a/include/configs/omap5_uevm.h +++ b/include/configs/omap5_uevm.h @@ -46,7 +46,6 @@
/* Required support for the TCA642X GPIO we have on the uEVM */ #define CONFIG_TCA642X -#define CONFIG_CMD_TCA642X #define CONFIG_SYS_I2C_TCA642X_BUS_NUM 4 #define CONFIG_SYS_I2C_TCA642X_ADDR 0x22
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index f5ec487668..4ce1273bed 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_TCA642X CONFIG_CMD_TERMINAL CONFIG_CMD_TFTP CONFIG_CMD_THOR_DOWNLOAD
Changes in v2: None
This converts the following to Kconfig: CONFIG_CMD_TERMINAL
Changes in v2: None
cmd/Kconfig | 8 ++++++++ include/config_cmd_all.h | 1 - include/configs/vct.h | 2 -- scripts/config_whitelist.txt | 1 - 4 files changed, 8 insertions(+), 4 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 4c1cbe736f..a4c719d424 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1085,6 +1085,14 @@ config CMD_QFW
source "cmd/mvebu/Kconfig"
+config CMD_TERMINAL + bool "terminal - provides a way to attach a serial terminal" + help + Provides a 'cu'-like serial terminal command. This can be used to + access other serial ports from the system console. The terminal + is very simple with no special processing of characters. As with + cu, you can press ~. (tilde followed by period) to exit. + endmenu
config CMD_BOOTSTAGE diff --git a/include/config_cmd_all.h b/include/config_cmd_all.h index 25dd3c7355..f93d5508bb 100644 --- a/include/config_cmd_all.h +++ b/include/config_cmd_all.h @@ -13,7 +13,6 @@ * Alphabetical list of all possible commands. */
-#define CONFIG_CMD_TERMINAL /* built-in Serial Terminal */ #define CONFIG_CMD_UNIVERSE /* Tundra Universe Support */ #define CONFIG_CMD_ZFS /* ZFS Support */
diff --git a/include/configs/vct.h b/include/configs/vct.h index a98dae8e24..e7c3d4b589 100644 --- a/include/configs/vct.h +++ b/include/configs/vct.h @@ -239,8 +239,6 @@ int vct_gpio_get(int pin); * (NOR/OneNAND) usage and Linux kernel booting. */ #if defined(CONFIG_VCT_SMALL_IMAGE) -#undef CONFIG_CMD_TERMINAL - #undef CONFIG_SMC911X #undef CONFIG_SYS_I2C_SOFT #undef CONFIG_SOURCE diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 4ce1273bed..1753f4572f 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_TERMINAL CONFIG_CMD_TFTP CONFIG_CMD_THOR_DOWNLOAD CONFIG_CMD_TRACE
Changes in v2: None
This is not a valid CONFIG option. Drop it.
Changes in v2: None
include/configs/dragonboard410c.h | 1 - scripts/config_whitelist.txt | 1 - 2 files changed, 2 deletions(-)
diff --git a/include/configs/dragonboard410c.h b/include/configs/dragonboard410c.h index d9dc639aeb..5a0b60ff66 100644 --- a/include/configs/dragonboard410c.h +++ b/include/configs/dragonboard410c.h @@ -49,7 +49,6 @@ /* Enable that for switching of boot partitions */ /* Disabled by default as some sub-commands can brick eMMC */ /*#define CONFIG_SUPPORT_EMMC_BOOT */ -#define CONFIG_CMD_TFTP
/* Partition table support */ #define HAVE_BLOCK_DEVICE /* Needed for partition commands */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 1753f4572f..cd87bafbed 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_TFTP CONFIG_CMD_THOR_DOWNLOAD CONFIG_CMD_TRACE CONFIG_CMD_TSI148
Changes in v2: None
This converts the following to Kconfig: CONFIG_CMD_THOR_DOWNLOAD
Changes in v2: None
cmd/Kconfig | 8 ++++++++ configs/odroid-xu3_defconfig | 1 + configs/odroid_defconfig | 1 + configs/origen_defconfig | 1 + configs/s5p_goni_defconfig | 1 + configs/s5pc210_universal_defconfig | 1 + configs/topic_miami_defconfig | 1 + configs/topic_miamilite_defconfig | 1 + configs/topic_miamiplus_defconfig | 1 + configs/trats2_defconfig | 1 + configs/trats_defconfig | 1 + configs/xilinx_zynqmp_ep_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 1 + configs/xilinx_zynqmp_zcu102_revA_defconfig | 1 + configs/xilinx_zynqmp_zcu102_revB_defconfig | 1 + configs/zynq_microzed_defconfig | 1 + configs/zynq_picozed_defconfig | 1 + configs/zynq_zc702_defconfig | 1 + configs/zynq_zc706_defconfig | 1 + configs/zynq_zed_defconfig | 1 + configs/zynq_zybo_defconfig | 1 + include/configs/exynos4-common.h | 1 - include/configs/odroid_xu3.h | 1 - include/configs/s5p_goni.h | 1 - include/configs/smdkv310.h | 1 - include/configs/xilinx_zynqmp.h | 1 - include/configs/zynq-common.h | 1 - scripts/config_whitelist.txt | 1 - 29 files changed, 29 insertions(+), 7 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index a4c719d424..6a895bbac5 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -303,6 +303,14 @@ config CMD_SPL_WRITE_SIZE flash used by Falcon-mode boot. See the documentation until CMD_SPL for detail.
+config CMD_THOR_DOWNLOAD + bool "thor - TIZEN 'thor' download" + help + Implements the 'thor' download protocol. This is a way of + downloading a software update over USB from an attached host. + There is no documentation about this within the U-Boot source code + but you should be able to find something on the interwebs. + endmenu
menu "Environment commands" diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index ffcecd5fd2..2354a00ad4 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -12,6 +12,7 @@ CONFIG_SILENT_CONSOLE=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_PROMPT="ODROID-XU3 # " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/configs/odroid_defconfig b/configs/odroid_defconfig index 22e86e28c3..c9e55406eb 100644 --- a/configs/odroid_defconfig +++ b/configs/odroid_defconfig @@ -13,6 +13,7 @@ CONFIG_SYS_PROMPT="Odroid # " CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set +CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y diff --git a/configs/origen_defconfig b/configs/origen_defconfig index 573c9e29a7..0a27833f46 100644 --- a/configs/origen_defconfig +++ b/configs/origen_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_PROMPT="ORIGEN # " CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set +CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y diff --git a/configs/s5p_goni_defconfig b/configs/s5p_goni_defconfig index 0045f5e63e..8bfab751cb 100644 --- a/configs/s5p_goni_defconfig +++ b/configs/s5p_goni_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_PROMPT="Goni # " # CONFIG_AUTOBOOT is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set +CONFIG_CMD_THOR_DOWNLOAD=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y diff --git a/configs/s5pc210_universal_defconfig b/configs/s5pc210_universal_defconfig index 021e6c5102..cdbf12ceff 100644 --- a/configs/s5pc210_universal_defconfig +++ b/configs/s5pc210_universal_defconfig @@ -10,6 +10,7 @@ CONFIG_SYS_PROMPT="Universal # " CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set +CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y diff --git a/configs/topic_miami_defconfig b/configs/topic_miami_defconfig index 1873791e79..1bc9e3849e 100644 --- a/configs/topic_miami_defconfig +++ b/configs/topic_miami_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="zynq-uboot> " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_THOR_DOWNLOAD=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/topic_miamilite_defconfig b/configs/topic_miamilite_defconfig index db859a7b0b..df36b68ba7 100644 --- a/configs/topic_miamilite_defconfig +++ b/configs/topic_miamilite_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="zynq-uboot> " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_THOR_DOWNLOAD=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/topic_miamiplus_defconfig b/configs/topic_miamiplus_defconfig index 93e0292bd5..18df89ddd0 100644 --- a/configs/topic_miamiplus_defconfig +++ b/configs/topic_miamiplus_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="zynq-uboot> " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_THOR_DOWNLOAD=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/trats2_defconfig b/configs/trats2_defconfig index 16ac27fb95..f91ec1d3c3 100644 --- a/configs/trats2_defconfig +++ b/configs/trats2_defconfig @@ -13,6 +13,7 @@ CONFIG_SYS_PROMPT="Trats2 # " CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set +CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y diff --git a/configs/trats_defconfig b/configs/trats_defconfig index 0f2445bdf4..3a8f075d7b 100644 --- a/configs/trats_defconfig +++ b/configs/trats_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_PROMPT="Trats # " CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set +CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y diff --git a/configs/xilinx_zynqmp_ep_defconfig b/configs/xilinx_zynqmp_ep_defconfig index b696c6272f..f9b2d6e101 100644 --- a/configs/xilinx_zynqmp_ep_defconfig +++ b/configs/xilinx_zynqmp_ep_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_PROMPT="ZynqMP> " # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set +CONFIG_CMD_THOR_DOWNLOAD=y # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_ENV_EXISTS is not set CONFIG_CMD_UNZIP=y diff --git a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig index 8c4931f20d..8d648262cf 100644 --- a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig @@ -20,6 +20,7 @@ CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="ZynqMP> " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_UNZIP=y # CONFIG_CMD_FLASH is not set diff --git a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig index c4d8c97075..34d2843926 100644 --- a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig @@ -21,6 +21,7 @@ CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="ZynqMP> " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_UNZIP=y # CONFIG_CMD_FLASH is not set diff --git a/configs/xilinx_zynqmp_zcu102_revA_defconfig b/configs/xilinx_zynqmp_zcu102_revA_defconfig index b58460ae3a..112780b8d0 100644 --- a/configs/xilinx_zynqmp_zcu102_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revA_defconfig @@ -20,6 +20,7 @@ CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="ZynqMP> " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_EEPROM=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_UNZIP=y diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index 0e1c841ea5..7ca92053d4 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -20,6 +20,7 @@ CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="ZynqMP> " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_EEPROM=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_UNZIP=y diff --git a/configs/zynq_microzed_defconfig b/configs/zynq_microzed_defconfig index ec8eafb4db..1eb6575693 100644 --- a/configs/zynq_microzed_defconfig +++ b/configs/zynq_microzed_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_THOR_DOWNLOAD=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/zynq_picozed_defconfig b/configs/zynq_picozed_defconfig index f5155b2678..ad6bc0b5bc 100644 --- a/configs/zynq_picozed_defconfig +++ b/configs/zynq_picozed_defconfig @@ -9,6 +9,7 @@ CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_THOR_DOWNLOAD=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_USB=y diff --git a/configs/zynq_zc702_defconfig b/configs/zynq_zc702_defconfig index b850af923b..d6a32f93d7 100644 --- a/configs/zynq_zc702_defconfig +++ b/configs/zynq_zc702_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_EEPROM=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y diff --git a/configs/zynq_zc706_defconfig b/configs/zynq_zc706_defconfig index 35722e9952..5616549bc0 100644 --- a/configs/zynq_zc706_defconfig +++ b/configs/zynq_zc706_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_EEPROM=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y diff --git a/configs/zynq_zed_defconfig b/configs/zynq_zed_defconfig index 762d475de6..9ebcd4131f 100644 --- a/configs/zynq_zed_defconfig +++ b/configs/zynq_zed_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_THOR_DOWNLOAD=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/zynq_zybo_defconfig b/configs/zynq_zybo_defconfig index 439236139e..31499a1e92 100644 --- a/configs/zynq_zybo_defconfig +++ b/configs/zynq_zybo_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_EEPROM=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y diff --git a/include/configs/exynos4-common.h b/include/configs/exynos4-common.h index 9f0131a7ee..94fd3b36f6 100644 --- a/include/configs/exynos4-common.h +++ b/include/configs/exynos4-common.h @@ -21,7 +21,6 @@ #define CONFIG_MMC_DEFAULT_DEV 0
/* TIZEN THOR downloader support */ -#define CONFIG_CMD_THOR_DOWNLOAD #define CONFIG_USB_FUNCTION_THOR
#define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_32M diff --git a/include/configs/odroid_xu3.h b/include/configs/odroid_xu3.h index 697f8d2582..8bc7fbde9e 100644 --- a/include/configs/odroid_xu3.h +++ b/include/configs/odroid_xu3.h @@ -48,7 +48,6 @@ #define CONFIG_G_DNL_THOR_VENDOR_NUM CONFIG_G_DNL_VENDOR_NUM #define CONFIG_G_DNL_THOR_PRODUCT_NUM 0x685D #define CONFIG_USB_FUNCTION_THOR -#define CONFIG_CMD_THOR_DOWNLOAD
/* UMS */ #define CONFIG_G_DNL_UMS_VENDOR_NUM 0x0525 diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index eb17580865..01655ee1ed 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -56,7 +56,6 @@ #define DFU_DEFAULT_POLL_TIMEOUT 300
/* USB Samsung's IDs */ diff --git a/include/configs/smdkv310.h b/include/configs/smdkv310.h index 9986a3b707..96048f5d40 100644 --- a/include/configs/smdkv310.h +++ b/include/configs/smdkv310.h @@ -15,7 +15,6 @@ #undef CONFIG_USB_GADGET_DWC2_OTG #undef CONFIG_USB_GADGET_DWC2_OTG_PHY #undef CONFIG_REVISION_TAG -#undef CONFIG_CMD_THOR_DOWNLOAD
/* High Level Configuration Options */ #define CONFIG_EXYNOS4210 1 /* which is a EXYNOS4210 SoC */ diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 363c2924f0..55bd2836e6 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -89,7 +89,6 @@ #define CONFIG_SYS_DFU_DATA_BUF_SIZE 0x1800000 #define DFU_DEFAULT_POLL_TIMEOUT 300 #define CONFIG_USB_CABLE_CHECK -#define CONFIG_CMD_THOR_DOWNLOAD #define CONFIG_USB_FUNCTION_THOR #define CONFIG_THOR_RESET_OFF #define DFU_ALT_INFO_RAM \ diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 35e5c1e64f..66bc508b9d 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -91,7 +91,6 @@ # define CONFIG_SYS_DFU_DATA_BUF_SIZE 0x600000 # define DFU_DEFAULT_POLL_TIMEOUT 300 # define CONFIG_USB_CABLE_CHECK -# define CONFIG_CMD_THOR_DOWNLOAD # define CONFIG_THOR_RESET_OFF # define CONFIG_USB_FUNCTION_THOR # define DFU_ALT_INFO_RAM \ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index cd87bafbed..515ea8861d 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_THOR_DOWNLOAD CONFIG_CMD_TRACE CONFIG_CMD_TSI148 CONFIG_CMD_UNIVERSE
Changes in v2: None
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
This converts the following to Kconfig: CONFIG_CMD_YAFFS2
Changes in v2: None
cmd/Kconfig | 11 +++++++++++ cmd/Makefile | 2 +- fs/Kconfig | 2 ++ fs/yaffs2/Kconfig | 7 +++++++ 4 files changed, 21 insertions(+), 1 deletion(-) create mode 100644 fs/yaffs2/Kconfig
diff --git a/cmd/Kconfig b/cmd/Kconfig index 6a895bbac5..f8017f885a 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1360,6 +1360,17 @@ config CMD_SCSI scan the bus, reset the bus, read and write data and get information about devices.
+config CMD_YAFFS2 + bool "yaffs2 - Access of YAFFS2 filesystem" + depends on YAFFS2 + default y + help + This provides commands for accessing a YAFFS2 filesystem. Yet + Another Flash Filesystem 2 is a filesystem designed specifically + for NAND flash. It incorporates bad-block management and ensures + that device writes are sequential regardless of filesystem + activity. + endmenu
menu "Debug commands" diff --git a/cmd/Makefile b/cmd/Makefile index a85fe25dda..1bf6e3f711 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -132,7 +132,7 @@ obj-$(CONFIG_CMD_FS_UUID) += fs_uuid.o obj-$(CONFIG_CMD_USB_MASS_STORAGE) += usb_mass_storage.o obj-$(CONFIG_CMD_THOR_DOWNLOAD) += thordown.o obj-$(CONFIG_CMD_XIMG) += ximg.o -obj-$(CONFIG_YAFFS2) += yaffs2.o +obj-$(CONFIG_CMD_YAFFS2) += yaffs2.o obj-$(CONFIG_CMD_SPL) += spl.o obj-$(CONFIG_CMD_ZIP) += zip.o obj-$(CONFIG_CMD_ZFS) += zfs.o diff --git a/fs/Kconfig b/fs/Kconfig index e6438ad0ea..e6803ac8cb 100644 --- a/fs/Kconfig +++ b/fs/Kconfig @@ -18,4 +18,6 @@ source "fs/ubifs/Kconfig"
source "fs/cramfs/Kconfig"
+source "fs/yaffs2/Kconfig" + endmenu diff --git a/fs/yaffs2/Kconfig b/fs/yaffs2/Kconfig new file mode 100644 index 0000000000..45ffdf6c26 --- /dev/null +++ b/fs/yaffs2/Kconfig @@ -0,0 +1,7 @@ +config YAFFS2 + bool "YAFFS2 filesystem support" + help + This provides access to YAFFS2 filesystems. Yet Another Flash + Filesystem 2 is a filesystem designed specifically for NAND flash. + It incorporates bad-block management and ensures that device + writes are sequential regardless of filesystem activity.
Changes in v2: None
This converts the following to Kconfig: CONFIG_CMD_TRACE
Changes in v2: None
cmd/Kconfig | 9 +++++++++ include/configs/exynos5-common.h | 1 - include/configs/sandbox.h | 1 - scripts/config_whitelist.txt | 1 - 4 files changed, 9 insertions(+), 3 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index f8017f885a..425d1d1351 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1407,6 +1407,15 @@ config CMD_KGDB single-stepping, inspecting variables, etc. This is supported only on PowerPC at present.
+config CMD_TRACE + bool "trace - Support tracing of function calls and timing" + help + Enables a command to control using of function tracing within + U-Boot. This allows recording of call traces including timing + information. The command can write data to memory for exporting + for analsys (e.g. using bootchart). See doc/README.trace for full + details. + endmenu
config CMD_UBI diff --git a/include/configs/exynos5-common.h b/include/configs/exynos5-common.h index 3b73bbc525..9c9681e8ac 100644 --- a/include/configs/exynos5-common.h +++ b/include/configs/exynos5-common.h @@ -17,7 +17,6 @@
#ifdef FTRACE #define CONFIG_TRACE -#define CONFIG_CMD_TRACE #define CONFIG_TRACE_BUFFER_SIZE (16 << 20) #define CONFIG_TRACE_EARLY_SIZE (8 << 20) #define CONFIG_TRACE_EARLY diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index 13777abb4c..7567ccd905 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -8,7 +8,6 @@
#ifdef FTRACE #define CONFIG_TRACE -#define CONFIG_CMD_TRACE #define CONFIG_TRACE_BUFFER_SIZE (16 << 20) #define CONFIG_TRACE_EARLY_SIZE (8 << 20) #define CONFIG_TRACE_EARLY diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 515ea8861d..58f8bc4e87 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_TRACE CONFIG_CMD_TSI148 CONFIG_CMD_UNIVERSE CONFIG_CMD_UUID
Changes in v2: None
This converts the following to Kconfig: CONFIG_CMD_TSI148
Changes in v2: - Sort Kconfig options in alphabetical order
cmd/Kconfig | 6 ++++++ configs/caddy2_defconfig | 1 + configs/vme8349_defconfig | 1 + include/configs/vme8349.h | 1 - scripts/config_whitelist.txt | 1 - 5 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 425d1d1351..7934753232 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -848,6 +848,12 @@ config CMD_SPI help SPI utility command.
+config CMD_TSI148 + bool "tsi148 - Command to access tsi148 device" + help + This provides various sub-commands to initialise and configure the + Turndra tsi148 device. See the command help for full details. + config CMD_USB bool "usb" help diff --git a/configs/caddy2_defconfig b/configs/caddy2_defconfig index 762a2c0a08..3bdcb8d776 100644 --- a/configs/caddy2_defconfig +++ b/configs/caddy2_defconfig @@ -9,6 +9,7 @@ CONFIG_BOOTDELAY=6 CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_PCI=y +CONFIG_CMD_TSI148=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/vme8349_defconfig b/configs/vme8349_defconfig index 27d6c6bee0..e1e2f53a43 100644 --- a/configs/vme8349_defconfig +++ b/configs/vme8349_defconfig @@ -8,6 +8,7 @@ CONFIG_BOOTDELAY=6 CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_PCI=y +CONFIG_CMD_TSI148=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/include/configs/vme8349.h b/include/configs/vme8349.h index 8e9abb264c..0aafbe261f 100644 --- a/include/configs/vme8349.h +++ b/include/configs/vme8349.h @@ -343,7 +343,6 @@ #define CONFIG_SYS_RTC_BUS_NUM 0x01 #define CONFIG_SYS_I2C_RTC_ADDR 0x32 #define CONFIG_RTC_RX8025 -#define CONFIG_CMD_TSI148
/* Pass Ethernet MAC to VxWorks */ #define CONFIG_SYS_VXWORKS_MAC_PTR 0x000043f0 diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 58f8bc4e87..42eb367aa3 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_TSI148 CONFIG_CMD_UNIVERSE CONFIG_CMD_UUID CONFIG_CMD_ZBOOT
Changes in v2:
This converts the following to Kconfig: CONFIG_CMD_UNIVERSE
Since no board uses this, perhaps we should drop this command?
Changes in v2: - Add a note about dropping CMD_UNIVERSE - Sort Kconfig options in alphabetical order
cmd/Kconfig | 6 ++++++ include/config_cmd_all.h | 1 - scripts/config_whitelist.txt | 1 - 3 files changed, 6 insertions(+), 2 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 7934753232..4524370d23 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -854,6 +854,12 @@ config CMD_TSI148 This provides various sub-commands to initialise and configure the Turndra tsi148 device. See the command help for full details.
+config CMD_UNIVERSE + bool "universe - Command to set up the Turndra Universe controller" + help + This allows setting up the VMEbus provided by this controller. + See the command help for full details. + config CMD_USB bool "usb" help diff --git a/include/config_cmd_all.h b/include/config_cmd_all.h index f93d5508bb..faddca88cd 100644 --- a/include/config_cmd_all.h +++ b/include/config_cmd_all.h @@ -13,7 +13,6 @@ * Alphabetical list of all possible commands. */
-#define CONFIG_CMD_UNIVERSE /* Tundra Universe Support */ #define CONFIG_CMD_ZFS /* ZFS Support */
#endif /* _CONFIG_CMD_ALL_H */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 42eb367aa3..31aee890d7 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_UNIVERSE CONFIG_CMD_UUID CONFIG_CMD_ZBOOT CONFIG_CMD_ZFS
Changes in v2:
This converts the following to Kconfig: CONFIG_CMD_UUID
Changes in v2: None
README | 1 - cmd/Kconfig | 11 +++++++++++ scripts/config_whitelist.txt | 1 - 3 files changed, 11 insertions(+), 2 deletions(-)
diff --git a/README b/README index d5684ce5b5..1def10f235 100644 --- a/README +++ b/README @@ -826,7 +826,6 @@ The following options need to be configured: CONFIG_CMD_USB * USB support CONFIG_CMD_CDP * Cisco Discover Protocol support CONFIG_CMD_XIMG Load part of Multi Image - CONFIG_CMD_UUID * Generate random UUID or GUID string
EXAMPLE: If you want all functions except of network support you can write: diff --git a/cmd/Kconfig b/cmd/Kconfig index 4524370d23..de66c54ebc 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1113,6 +1113,17 @@ config CMD_TERMINAL is very simple with no special processing of characters. As with cu, you can press ~. (tilde followed by period) to exit.
+config CMD_UUID + bool "uuid, guid - generation of unique IDs" + help + This enables two commands: + + uuid - generate random Universally Unique Identifier + guid - generate Globally Unique Identifier based on random UUID + + The two commands are very similar except for the endianness of the + output. + endmenu
config CMD_BOOTSTAGE diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 31aee890d7..b2160567d6 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_UUID CONFIG_CMD_ZBOOT CONFIG_CMD_ZFS CONFIG_CM_INIT
Changes in v2: None
This converts the following to Kconfig: CONFIG_CMD_ZBOOT
Changes in v2: - Update edison also
arch/Kconfig | 1 + cmd/Kconfig | 12 ++++++++++++ include/configs/edison.h | 1 - include/configs/x86-common.h | 2 -- scripts/config_whitelist.txt | 1 - 5 files changed, 13 insertions(+), 4 deletions(-)
diff --git a/arch/Kconfig b/arch/Kconfig index 08f6e7f47d..78532f56ca 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -113,6 +113,7 @@ config X86 imply CMD_IO imply CMD_IRQ imply CMD_SF_TEST + imply CMD_ZBOOT
config XTENSA bool "Xtensa architecture" diff --git a/cmd/Kconfig b/cmd/Kconfig index de66c54ebc..c00353fff3 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -311,6 +311,18 @@ config CMD_THOR_DOWNLOAD There is no documentation about this within the U-Boot source code but you should be able to find something on the interwebs.
+config CMD_ZBOOT + bool "zboot - x86 boot command" + help + With x86 machines it is common to boot a bzImage file which + contains both a kernel and a setup.bin file. The latter includes + configuration information from the dark ages which x86 boards still + need to pick things out of. + + Consider using FIT in preference to this since it supports directly + booting both 32- and 64-bit kernels, as well as secure boot. + Documentation is available in doc/uImage.FIT/x86-fit-boot.txt + endmenu
menu "Environment commands" diff --git a/include/configs/edison.h b/include/configs/edison.h index 03aa702306..dfac340c2f 100644 --- a/include/configs/edison.h +++ b/include/configs/edison.h @@ -10,7 +10,6 @@ #include <asm/ibmpc.h>
/* Boot */ -#define CONFIG_CMD_ZBOOT #define CONFIG_BOOTCOMMAND "run bootcmd"
/* DISK Partition support */ diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index 43af193344..7ff354a4ad 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -67,8 +67,6 @@ * Command line configuration. */
-#define CONFIG_CMD_ZBOOT - #define CONFIG_BOOTARGS \ "root=/dev/sdb3 init=/sbin/init rootwait ro" #define CONFIG_BOOTCOMMAND \ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index b2160567d6..8c3d3e46f9 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_ZBOOT CONFIG_CMD_ZFS CONFIG_CM_INIT CONFIG_CM_MULTIPLE_SSRAM
Changes in v2:
This converts the following to Kconfig: CONFIG_CMD_ZFS
Changes in v2: None
cmd/Kconfig | 11 +++++++++++ include/config_cmd_all.h | 2 -- scripts/config_whitelist.txt | 1 - 3 files changed, 11 insertions(+), 3 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index c00353fff3..2c2669cdc3 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1406,6 +1406,17 @@ config CMD_YAFFS2 that device writes are sequential regardless of filesystem activity.
+config CMD_ZFS + bool "zfs - Access of ZFS filesystem" + help + This provides commands to accessing a ZFS filesystem, commonly used + on Solaris systems. Two sub-commands are provided: + + zfsls - list files in a directory + zfsload - load a file + + See doc/README.zfs for more details. + endmenu
menu "Debug commands" diff --git a/include/config_cmd_all.h b/include/config_cmd_all.h index faddca88cd..df88df42e1 100644 --- a/include/config_cmd_all.h +++ b/include/config_cmd_all.h @@ -13,6 +13,4 @@ * Alphabetical list of all possible commands. */
-#define CONFIG_CMD_ZFS /* ZFS Support */ - #endif /* _CONFIG_CMD_ALL_H */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 8c3d3e46f9..0b70937810 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -296,7 +296,6 @@ CONFIG_CM922T_XA10 CONFIG_CMDLINE_EDITING CONFIG_CMDLINE_PS_SUPPORT CONFIG_CMDLINE_TAG -CONFIG_CMD_ZFS CONFIG_CM_INIT CONFIG_CM_MULTIPLE_SSRAM CONFIG_CM_REMAP
Changes in v2: None
This file does not include all commands and has not for a while. Let's drop it.
Changes in v2: None
README | 5 ----- include/config_cmd_all.h | 16 ---------------- 2 files changed, 21 deletions(-) delete mode 100644 include/config_cmd_all.h
diff --git a/README b/README index 1def10f235..21639fdd3b 100644 --- a/README +++ b/README @@ -757,11 +757,6 @@ The following options need to be configured: CONFIG_SYS_BAUDRATE_TABLE, see below.
- Monitor Functions: - Monitor commands can be included or excluded - from the build by using the #include files - <config_cmd_all.h> and #undef'ing unwanted - commands, or adding #define's for wanted commands. - The default command configuration includes all commands except those marked below with a "*".
diff --git a/include/config_cmd_all.h b/include/config_cmd_all.h deleted file mode 100644 index df88df42e1..0000000000 --- a/include/config_cmd_all.h +++ /dev/null @@ -1,16 +0,0 @@ -/* - * Copyright 2007 Freescale Semiconductor, Inc. - * - * This file is licensed under the terms of the GNU General Public - * License Version 2. This file is licensed "as is" without any - * warranty of any kind, whether express or implied. - */ - -#ifndef _CONFIG_CMD_ALL_H -#define _CONFIG_CMD_ALL_H - -/* - * Alphabetical list of all possible commands. - */ - -#endif /* _CONFIG_CMD_ALL_H */
Changes in v2: None
Most of this is duplicated in Kconfig help. Add some of that which is not, and remove the help from the README.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com ---
Changes in v2: - Drop patch to convert CONFIG_CMD_MTDPARTS to Kconfig (already done)
README | 116 +-------------------------------------------------- cmd/Kconfig | 4 +- cmd/fastboot/Kconfig | 2 + 3 files changed, 6 insertions(+), 116 deletions(-)
diff --git a/README b/README index 21639fdd3b..99a0a41c47 100644 --- a/README +++ b/README @@ -756,93 +756,6 @@ The following options need to be configured: Select one of the baudrates listed in CONFIG_SYS_BAUDRATE_TABLE, see below.
-- Monitor Functions: - The default command configuration includes all commands - except those marked below with a "*". - - CONFIG_CMD_AES AES 128 CBC encrypt/decrypt - CONFIG_CMD_ASKENV * ask for env variable - CONFIG_CMD_BDI bdinfo - CONFIG_CMD_BOOTD bootd - CONFIG_CMD_BOOTI * ARM64 Linux kernel Image support - CONFIG_CMD_CACHE * icache, dcache - CONFIG_CMD_CONSOLE coninfo - CONFIG_CMD_DHCP * DHCP support - CONFIG_CMD_DIAG * Diagnostics - CONFIG_CMD_ECHO echo arguments - CONFIG_CMD_EDITENV edit env variable - CONFIG_CMD_ELF * bootelf, bootvx - CONFIG_CMD_ENV_EXISTS * check existence of env variable - CONFIG_CMD_EXPORTENV * export the environment - CONFIG_CMD_EXT2 * ext2 command support - CONFIG_CMD_EXT4 * ext4 command support - CONFIG_CMD_FS_GENERIC * filesystem commands (e.g. load, ls) - that work for multiple fs types - CONFIG_CMD_FS_UUID * Look up a filesystem UUID - CONFIG_CMD_SAVEENV saveenv - CONFIG_CMD_FLASH flinfo, erase, protect - CONFIG_CMD_FPGA FPGA device initialization support - CONFIG_CMD_GO * the 'go' command (exec code) - CONFIG_CMD_GREPENV * search environment - CONFIG_CMD_I2C * I2C serial bus support - CONFIG_CMD_IMI iminfo - CONFIG_CMD_IMLS List all images found in NOR flash - CONFIG_CMD_IMLS_NAND * List all images found in NAND flash - CONFIG_CMD_IMPORTENV * import an environment - CONFIG_CMD_INI * import data from an ini file into the env - CONFIG_CMD_ITEST Integer/string test of 2 values - CONFIG_CMD_LDRINFO * ldrinfo (display Blackfin loader) - CONFIG_CMD_LINK_LOCAL * link-local IP address auto-configuration - (169.254.*.*) - CONFIG_CMD_LOADB loadb - CONFIG_CMD_LOADS loads - CONFIG_CMD_MD5SUM * print md5 message digest - (requires CONFIG_CMD_MEMORY and CONFIG_MD5) - CONFIG_CMD_MEMINFO * Display detailed memory information - CONFIG_CMD_MEMORY md, mm, nm, mw, cp, cmp, crc, base, - loop, loopw - CONFIG_CMD_MEMTEST * mtest - CONFIG_CMD_MISC Misc functions like sleep etc - CONFIG_CMD_MMC * MMC memory mapped support - CONFIG_CMD_MII * MII utility commands - CONFIG_CMD_NET bootp, tftpboot, rarpboot - CONFIG_CMD_NFS NFS support - CONFIG_CMD_PING * send ICMP ECHO_REQUEST to network - host - CONFIG_CMD_RUN run command in env variable - CONFIG_CMD_SF * Read/write/erase SPI NOR flash - CONFIG_CMD_SOFTSWITCH * Soft switch setting command for BF60x - CONFIG_CMD_SOURCE "source" command Support - CONFIG_CMD_SPI * SPI serial bus support - CONFIG_CMD_TFTPSRV * TFTP transfer in server mode - CONFIG_CMD_TFTPPUT * TFTP put command (upload) - CONFIG_CMD_TIME * run command and report execution time (ARM specific) - CONFIG_CMD_TIMER * access to the system tick timer - CONFIG_CMD_USB * USB support - CONFIG_CMD_CDP * Cisco Discover Protocol support - CONFIG_CMD_XIMG Load part of Multi Image - - EXAMPLE: If you want all functions except of network - support you can write: - - #include "config_cmd_all.h" - #undef CONFIG_CMD_NET - - Other Commands: - fdt (flattened device tree) command: CONFIG_OF_LIBFDT - - Note: Don't enable the "icache" and "dcache" commands - (configuration option CONFIG_CMD_CACHE) unless you know - what you (and your U-Boot users) are doing. Data - cache cannot be enabled on systems like the - 8xx (where accesses to the IMMR region must be - uncached), and it cannot be disabled on all other - systems where we (mis-) use the data cache to hold an - initial stack and some data. - - - XXX - this list needs to get updated! - - Removal of commands If no commands are needed to boot, you can disable CONFIG_CMDLINE to remove them. In this case, the command line @@ -1044,10 +957,6 @@ The following options need to be configured: Allow generic access to the SPI bus on the Intel 8257x, for example with the "sspi" command.
- CONFIG_CMD_E1000 - Management command for E1000 devices. When used on devices - with SPI support you can reprogram the EEPROM from U-Boot. - CONFIG_EEPRO100 Support for Intel 82557/82559/82559ER chips. Optional CONFIG_EEPRO100_SROM_WRITE enables EEPROM @@ -1182,11 +1091,6 @@ The following options need to be configured: to. Contemporary x86 systems usually map it at 0xfed40000.
- CONFIG_CMD_TPM - Add tpm monitor functions. - Requires CONFIG_TPM. If CONFIG_TPM_AUTH_SESSIONS is set, also - provides monitor access to authorized functions. - CONFIG_TPM Define this to enable the TPM support library which provides functional interfaces to some TPM commands. @@ -1314,12 +1218,6 @@ The following options need to be configured: CONFIG_USB_FUNCTION_DFU This enables the USB portion of the DFU USB class
- CONFIG_CMD_DFU - This enables the command "dfu" which is used to have - U-Boot create a DFU class device via USB. This command - requires that the "dfu_alt_info" environment variable be - set and define the alt settings to expose to the host. - CONFIG_DFU_MMC This enables support for exposing (e)MMC devices via DFU.
@@ -1359,13 +1257,6 @@ The following options need to be configured: CONFIG_USB_FUNCTION_FASTBOOT This enables the USB part of the fastboot gadget
- CONFIG_CMD_FASTBOOT - This enables the command "fastboot" which enables the Android - fastboot mode for the platform's USB device. Fastboot is a USB - protocol for downloading images, flashing and device control - used on Android devices. - See doc/README.android-fastboot for more information. - CONFIG_ANDROID_BOOT_IMAGE This enables support for booting images which use the Android image format header. @@ -2476,12 +2367,7 @@ The following options need to be configured: commands cp, md...
- Serial Flash support - CONFIG_CMD_SF - - Defining this option enables SPI flash commands - 'sf probe/read/write/erase/update'. - - Usage requires an initial 'probe' to define the serial + Usage requires an initial 'sf probe' to define the serial flash parameters, followed by read/write/erase/update commands.
diff --git a/cmd/Kconfig b/cmd/Kconfig index 2c2669cdc3..c38a6b81f1 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -576,7 +576,9 @@ config CMD_DFU select USB_FUNCTION_DFU help Enables the command "dfu" which is used to have U-Boot create a DFU - class device via USB. + class device via USB. This command requires that the "dfu_alt_info" + environment variable be set and define the alt settings to expose to + the host.
config CMD_DM bool "dm - Access to driver model information" diff --git a/cmd/fastboot/Kconfig b/cmd/fastboot/Kconfig index 89b9e73440..b84529a374 100644 --- a/cmd/fastboot/Kconfig +++ b/cmd/fastboot/Kconfig @@ -18,6 +18,8 @@ config CMD_FASTBOOT protocol for downloading images, flashing and device control used on Android devices.
+ See doc/README.android-fastboot for more information. + config ANDROID_BOOT_IMAGE bool "Enable support for Android Boot Images" help
Changes in v2:
Bin Meng
Philipp Tomsich
