[U-Boot] [PATCH 1/3] tegra: add GMC/GMD funcmux entry for SFLASH
This is used on TrimSlice.
Signed-off-by: Stephen Warren swarren@nvidia.com --- arch/arm/cpu/armv7/tegra2/funcmux.c | 10 ++++++++++ arch/arm/include/asm/arch-tegra2/funcmux.h | 3 +++ 2 files changed, 13 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/tegra2/funcmux.c b/arch/arm/cpu/armv7/tegra2/funcmux.c index 455d010..4a31a4c 100644 --- a/arch/arm/cpu/armv7/tegra2/funcmux.c +++ b/arch/arm/cpu/armv7/tegra2/funcmux.c @@ -224,6 +224,16 @@ int funcmux_select(enum periph_id id, int config) } break;
+ case PERIPH_ID_SPI1: + if (config == FUNCMUX_SPI1_GMC_GMD) { + pinmux_set_func(PINGRP_GMC, PMUX_FUNC_SFLASH); + pinmux_set_func(PINGRP_GMD, PMUX_FUNC_SFLASH); + + pinmux_tristate_disable(PINGRP_GMC); + pinmux_tristate_disable(PINGRP_GMD); + } + break; + default: debug("%s: invalid periph_id %d", __func__, id); return -1; diff --git a/arch/arm/include/asm/arch-tegra2/funcmux.h b/arch/arm/include/asm/arch-tegra2/funcmux.h index 3cbc7d2..dcd512f 100644 --- a/arch/arm/include/asm/arch-tegra2/funcmux.h +++ b/arch/arm/include/asm/arch-tegra2/funcmux.h @@ -54,6 +54,9 @@ enum {
/* USB configs */ FUNCMUX_USB2_ULPI = 0, + + /* Serial Flash configs */ + FUNCMUX_SPI1_GMC_GMD = 0, };
Boards can override this to set up the pinmux correctly to access serial flash.
Signed-off-by: Stephen Warren swarren@nvidia.com --- board/nvidia/common/board.c | 7 +++++++ 1 files changed, 7 insertions(+), 0 deletions(-)
diff --git a/board/nvidia/common/board.c b/board/nvidia/common/board.c index fc8b928..e65fc9e 100644 --- a/board/nvidia/common/board.c +++ b/board/nvidia/common/board.c @@ -64,6 +64,12 @@ void __pin_mux_usb(void)
void pin_mux_usb(void) __attribute__((weak, alias("__pin_mux_usb")));
+void __pin_mux_spi(void) +{ +} + +void pin_mux_spi(void) __attribute__((weak, alias("__pin_mux_spi"))); + /* * Routine: power_det_init * Description: turn off power detects @@ -95,6 +101,7 @@ int board_init(void) gpio_config_uart(); #endif #ifdef CONFIG_TEGRA_SPI + pin_mux_spi(); spi_init(); #endif /* boot param addr */
When Trimslice is booted from serial flash, the boot ROM does this, so U-Boot doesn't need to. However, booting from the SD slot for recovery purposes, the boot ROM does not set up the pinmux for serial flash. Add code to U-Boot to set this up, so that an SD-based recovery U-Boot image can upgrade the U-Boot in serial flash.
Signed-off-by: Stephen Warren swarren@nvidia.com --- board/compulab/trimslice/trimslice.c | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/board/compulab/trimslice/trimslice.c b/board/compulab/trimslice/trimslice.c index f15fbd7..1ac15f8 100644 --- a/board/compulab/trimslice/trimslice.c +++ b/board/compulab/trimslice/trimslice.c @@ -42,6 +42,11 @@ void gpio_config_uart(void) { }
+void pin_mux_spi(void) +{ + funcmux_select(PERIPH_ID_SPI1, FUNCMUX_SPI1_GMC_GMD); +} + /* * Routine: pin_mux_mmc * Description: setup the pin muxes/tristate values for the SDMMC(s)
Stephen,
-----Original Message----- From: Stephen Warren [mailto:swarren@wwwdotorg.org] Sent: Tuesday, June 12, 2012 11:34 AM To: Tom Warren Cc: u-boot@lists.denx.de; Stephen Warren Subject: [PATCH 1/3] tegra: add GMC/GMD funcmux entry for SFLASH
This series (3 patches) has been applied to u-boot-tegra/master. Thanks!
Tom
- case PERIPH_ID_SPI1:
break;
- default: debug("%s: invalid periph_id %d", __func__, id); return -1;
- /* Serial Flash configs */
- FUNCMUX_SPI1_GMC_GMD = 0,
1.7.0.4
Stephen Warren
Tom Warren
