[U-Boot] [PATCH 1/2] imx:mx6sl_pins add pad settings for usb
Add pad settings for usb support.
This patch "imx:mx6slevk add usb support" missed to add pad definition.
Signed-off-by: Peng Fan Peng.Fan@freescale.com --- arch/arm/include/asm/arch-mx6/mx6sl_pins.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/include/asm/arch-mx6/mx6sl_pins.h b/arch/arm/include/asm/arch-mx6/mx6sl_pins.h index 045ccc4..17b4798 100644 --- a/arch/arm/include/asm/arch-mx6/mx6sl_pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6sl_pins.h @@ -34,5 +34,10 @@ enum { MX6_PAD_FEC_REF_CLK__FEC_REF_OUT = IOMUX_PAD(0x424, 0x134, 0x10, 0x000, 0, 0), MX6_PAD_FEC_RX_ER__GPIO_4_19 = IOMUX_PAD(0x0428, 0x0138, 5, 0x0000, 0, 0), MX6_PAD_FEC_TX_CLK__GPIO_4_21 = IOMUX_PAD(0x0434, 0x0144, 5, 0x0000, 0, 0), + + MX6_PAD_EPDC_PWRCOM__ANATOP_USBOTG1_ID = IOMUX_PAD(0x03D0, 0x00E0, 4, 0x05DC, 0, 0), + + MX6_PAD_KEY_COL4__USB_USBOTG1_PWR = IOMUX_PAD(0x0484, 0x017C, 6, 0x0000, 0, 0), + MX6_PAD_KEY_COL5__USB_USBOTG2_PWR = IOMUX_PAD(0x0488, 0x0180, 6, 0x0000, 0, 0), }; #endif /* __ASM_ARCH_MX6_MX6SL_PINS_H__ */
This patch "arm:imx-common introduce a new function to set gpr" missed to add the function prototype.
Signed-off-by: Peng Fan Peng.Fan@freescale.com --- arch/arm/include/asm/imx-common/iomux-v3.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/include/asm/imx-common/iomux-v3.h b/arch/arm/include/asm/imx-common/iomux-v3.h index a8ca49c..23421b5 100644 --- a/arch/arm/include/asm/imx-common/iomux-v3.h +++ b/arch/arm/include/asm/imx-common/iomux-v3.h @@ -182,6 +182,9 @@ typedef u64 iomux_v3_cfg_t; void imx_iomux_v3_setup_pad(iomux_v3_cfg_t pad); void imx_iomux_v3_setup_multiple_pads(iomux_v3_cfg_t const *pad_list, unsigned count); +/* Set bits for general purpose registers */ +void mxc_iomux_set_gpr_register(int group, int start_bit, int num_bits, + int value);
/* macros for declaring and using pinmux array */ #if defined(CONFIG_MX6QDL)
Hi Peng,
A fix of a previous patch makes sense when the patch was already merged. In that case, the fix should also have in the message the commit-id of the patch causing the issue.
Your patches are not yet merged: please send a new version of the patchset fixing the issues you have found.
Best regards, Stefano Babic
Then please resend the patch with the pad definition.
Thanks
Fabio Estevam
Peng Fan
Stefano Babic
