[PATCH 01/12] Convert CONFIG_83XX_PCICLK to Kconfig
This converts the following to Kconfig: CONFIG_83XX_PCICLK
Signed-off-by: Tom Rini trini@konsulko.com --- arch/powerpc/cpu/mpc83xx/Kconfig | 7 +++++++ configs/kmcoge5ne_defconfig | 1 + configs/kmopti2_defconfig | 1 + configs/kmsupx5_defconfig | 1 + configs/kmtegr1_defconfig | 1 + configs/kmtepr2_defconfig | 1 + configs/tuge1_defconfig | 1 + configs/tuxx1_defconfig | 1 + include/configs/km/km-mpc8309.h | 5 ----- include/configs/km/km-mpc832x.h | 5 ----- include/configs/kmcoge5ne.h | 5 ----- scripts/config_whitelist.txt | 1 - 12 files changed, 14 insertions(+), 16 deletions(-)
diff --git a/arch/powerpc/cpu/mpc83xx/Kconfig b/arch/powerpc/cpu/mpc83xx/Kconfig index d58d278c6da8..bcd837508789 100644 --- a/arch/powerpc/cpu/mpc83xx/Kconfig +++ b/arch/powerpc/cpu/mpc83xx/Kconfig @@ -188,6 +188,13 @@ source "arch/powerpc/cpu/mpc83xx/sysio/Kconfig" source "arch/powerpc/cpu/mpc83xx/arbiter/Kconfig" source "arch/powerpc/cpu/mpc83xx/initreg/Kconfig"
+config 83XX_PCICLK + hex "PCI clock frequency" + default 0xDEADBEEF + help + If required, the PCI clock frequency to use when configuring + the host bridge. + config FSL_ELBC bool
diff --git a/configs/kmcoge5ne_defconfig b/configs/kmcoge5ne_defconfig index 461f2e381224..53f7abc3fd09 100644 --- a/configs/kmcoge5ne_defconfig +++ b/configs/kmcoge5ne_defconfig @@ -156,6 +156,7 @@ CONFIG_ACR_PARKM_USB_I2C1_BOOT=y CONFIG_LCRR_DBYP_PLL_BYPASSED=y CONFIG_LCRR_EADC_2=y CONFIG_LCRR_CLKDIV_4=y +CONFIG_83XX_PCICLK=0x3ef1480 CONFIG_SYS_LOAD_ADDR=0x100000 CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y diff --git a/configs/kmopti2_defconfig b/configs/kmopti2_defconfig index 01709052c1a2..d230638548b8 100644 --- a/configs/kmopti2_defconfig +++ b/configs/kmopti2_defconfig @@ -139,6 +139,7 @@ CONFIG_ACR_APARK_MASTER=y CONFIG_ACR_PARKM_USB_I2C1_BOOT=y CONFIG_LCRR_EADC_1=y CONFIG_LCRR_CLKDIV_2=y +CONFIG_83XX_PCICLK=0x3ef1480 CONFIG_SYS_LOAD_ADDR=0x100000 CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y diff --git a/configs/kmsupx5_defconfig b/configs/kmsupx5_defconfig index 7802be8af4c8..b0b59262dec3 100644 --- a/configs/kmsupx5_defconfig +++ b/configs/kmsupx5_defconfig @@ -119,6 +119,7 @@ CONFIG_ACR_APARK_MASTER=y CONFIG_ACR_PARKM_USB_I2C1_BOOT=y CONFIG_LCRR_EADC_1=y CONFIG_LCRR_CLKDIV_2=y +CONFIG_83XX_PCICLK=0x3ef1480 CONFIG_SYS_LOAD_ADDR=0x100000 CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y diff --git a/configs/kmtegr1_defconfig b/configs/kmtegr1_defconfig index e2bf945bc3dc..53aaf6caa25c 100644 --- a/configs/kmtegr1_defconfig +++ b/configs/kmtegr1_defconfig @@ -118,6 +118,7 @@ CONFIG_ACR_APARK_MASTER=y CONFIG_ACR_PARKM_USB_I2C1_BOOT=y CONFIG_LCRR_EADC_1=y CONFIG_LCRR_CLKDIV_2=y +CONFIG_83XX_PCICLK=0x3ef1480 CONFIG_SYS_LOAD_ADDR=0x100000 CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y diff --git a/configs/kmtepr2_defconfig b/configs/kmtepr2_defconfig index 98f613ce16e3..b333769dc4f5 100644 --- a/configs/kmtepr2_defconfig +++ b/configs/kmtepr2_defconfig @@ -139,6 +139,7 @@ CONFIG_ACR_APARK_MASTER=y CONFIG_ACR_PARKM_USB_I2C1_BOOT=y CONFIG_LCRR_EADC_1=y CONFIG_LCRR_CLKDIV_2=y +CONFIG_83XX_PCICLK=0x3ef1480 CONFIG_SYS_LOAD_ADDR=0x100000 CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y diff --git a/configs/tuge1_defconfig b/configs/tuge1_defconfig index 9272a0cb4214..6078b46410af 100644 --- a/configs/tuge1_defconfig +++ b/configs/tuge1_defconfig @@ -119,6 +119,7 @@ CONFIG_ACR_APARK_MASTER=y CONFIG_ACR_PARKM_USB_I2C1_BOOT=y CONFIG_LCRR_EADC_1=y CONFIG_LCRR_CLKDIV_2=y +CONFIG_83XX_PCICLK=0x3ef1480 CONFIG_SYS_LOAD_ADDR=0x100000 CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y diff --git a/configs/tuxx1_defconfig b/configs/tuxx1_defconfig index 38875b39c12f..cc9bbab8c6bb 100644 --- a/configs/tuxx1_defconfig +++ b/configs/tuxx1_defconfig @@ -141,6 +141,7 @@ CONFIG_ACR_APARK_MASTER=y CONFIG_ACR_PARKM_USB_I2C1_BOOT=y CONFIG_LCRR_EADC_1=y CONFIG_LCRR_CLKDIV_2=y +CONFIG_83XX_PCICLK=0x3ef1480 CONFIG_SYS_LOAD_ADDR=0x100000 CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y diff --git a/include/configs/km/km-mpc8309.h b/include/configs/km/km-mpc8309.h index 47a335bcf8ff..98204bd3c692 100644 --- a/include/configs/km/km-mpc8309.h +++ b/include/configs/km/km-mpc8309.h @@ -5,11 +5,6 @@
#define CONFIG_KM_DEF_ARCH "arch=ppc_82xx\0"
-/* - * System Clock Setup - */ -#define CONFIG_83XX_PCICLK 66000000 - /* QE microcode/firmware address */ /* between the u-boot partition and env */
diff --git a/include/configs/km/km-mpc832x.h b/include/configs/km/km-mpc832x.h index d985ab7a65a9..54018daa68e6 100644 --- a/include/configs/km/km-mpc832x.h +++ b/include/configs/km/km-mpc832x.h @@ -3,11 +3,6 @@ */ #define CONFIG_KM8321 /* Keymile PBEC8321 board specific */
-/* - * System Clock Setup - */ -#define CONFIG_83XX_PCICLK 66000000 - /* * System IO Config */ diff --git a/include/configs/kmcoge5ne.h b/include/configs/kmcoge5ne.h index 9e1f802e4e57..8f4685c271c6 100644 --- a/include/configs/kmcoge5ne.h +++ b/include/configs/kmcoge5ne.h @@ -24,11 +24,6 @@ #include "km/km-mpc83xx.h" #include "km/km-mpc8360.h"
-/* - * System Clock Setup - */ -#define CONFIG_83XX_PCICLK 66000000 - /** * KMCOGE5NE has 512 MB RAM */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 7c0489595509..a9bbd5078a87 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1,6 +1,5 @@ CONFIG_64BIT_PHYS_ADDR CONFIG_83XX -CONFIG_83XX_PCICLK CONFIG_88F5182 CONFIG_A003399_NOR_WORKAROUND CONFIG_A008044_WORKAROUND
Neither of these symbols are referenced anywhere else, so remove them.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/powerpc/cpu/mpc83xx/start.S | 2 -- include/configs/km/km-mpc832x.h | 5 ----- 2 files changed, 7 deletions(-)
diff --git a/arch/powerpc/cpu/mpc83xx/start.S b/arch/powerpc/cpu/mpc83xx/start.S index 91c8778e5033..0944d1910573 100644 --- a/arch/powerpc/cpu/mpc83xx/start.S +++ b/arch/powerpc/cpu/mpc83xx/start.S @@ -14,8 +14,6 @@ #include <config.h> #include <mpc83xx.h>
-#define CONFIG_83XX 1 /* needed for Linux kernel header files*/ - #include <ppc_asm.tmpl> #include <ppc_defs.h>
diff --git a/include/configs/km/km-mpc832x.h b/include/configs/km/km-mpc832x.h index 54018daa68e6..aac1e999e40a 100644 --- a/include/configs/km/km-mpc832x.h +++ b/include/configs/km/km-mpc832x.h @@ -1,8 +1,3 @@ -/* - * High Level Configuration Options - */ -#define CONFIG_KM8321 /* Keymile PBEC8321 board specific */ - /* * System IO Config */
This converts the following to Kconfig: CONFIG_SYS_I2C_EEPROM_ADDR_LEN
Signed-off-by: Tom Rini trini@konsulko.com --- include/configs/km/km-mpc832x.h | 3 --- 1 file changed, 3 deletions(-)
diff --git a/include/configs/km/km-mpc832x.h b/include/configs/km/km-mpc832x.h index aac1e999e40a..888bb2981f7b 100644 --- a/include/configs/km/km-mpc832x.h +++ b/include/configs/km/km-mpc832x.h @@ -58,6 +58,3 @@
#define CONFIG_SYS_KMBEC_FPGA_BASE 0xE8000000 #define CONFIG_SYS_KMBEC_FPGA_SIZE 128 - -/* EEprom support */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1
The only place we use CONFIG_CPU_ARMV8 was in the arm_dcc serial driver. Switch this to CONFIG_ARM64 today, and if in the future we need finer granularity tuning here, a new CONFIG_SERIAL option needs to be introduced.
Signed-off-by: Tom Rini trini@konsulko.com --- drivers/serial/arm_dcc.c | 2 +- include/configs/meson64.h | 1 - include/configs/mt8183.h | 1 - include/configs/mt8512.h | 2 -- include/configs/mt8516.h | 1 - include/configs/mt8518.h | 2 -- include/configs/xilinx_versal.h | 2 -- include/configs/xilinx_zynqmp.h | 2 -- 8 files changed, 1 insertion(+), 12 deletions(-)
diff --git a/drivers/serial/arm_dcc.c b/drivers/serial/arm_dcc.c index dfcb6fd69812..a402a123b6d6 100644 --- a/drivers/serial/arm_dcc.c +++ b/drivers/serial/arm_dcc.c @@ -51,7 +51,7 @@ #define status_dcc(x) \ __asm__ volatile ("mrc p14, 0, %0, c14, c0, 0\n" : "=r" (x))
-#elif defined(CONFIG_CPU_ARMV8) +#elif defined(CONFIG_ARM64) /* * ARMV8 */ diff --git a/include/configs/meson64.h b/include/configs/meson64.h index cb202d555561..44f2967fc6b3 100644 --- a/include/configs/meson64.h +++ b/include/configs/meson64.h @@ -29,7 +29,6 @@ #define STDIN_CFG "serial" #endif
-#define CONFIG_CPU_ARMV8 #define CONFIG_REMAKE_ELF #define CONFIG_SYS_MAXARGS 32 #define CONFIG_SYS_CBSIZE 1024 diff --git a/include/configs/mt8183.h b/include/configs/mt8183.h index ebd2b326ade0..2b4e976aa1fe 100644 --- a/include/configs/mt8183.h +++ b/include/configs/mt8183.h @@ -11,7 +11,6 @@
#include <linux/sizes.h>
-#define CONFIG_CPU_ARMV8 #define COUNTER_FREQUENCY 13000000
#define CONFIG_SYS_NS16550_SERIAL diff --git a/include/configs/mt8512.h b/include/configs/mt8512.h index 8882a5a40970..9c443db9f52d 100644 --- a/include/configs/mt8512.h +++ b/include/configs/mt8512.h @@ -13,8 +13,6 @@
#define CONFIG_SYS_NONCACHED_MEMORY SZ_1M
-#define CONFIG_CPU_ARMV8 - #define COUNTER_FREQUENCY 13000000
#define CONFIG_SYS_BOOTM_LEN SZ_64M diff --git a/include/configs/mt8516.h b/include/configs/mt8516.h index 12840b883dec..47132c1db1d2 100644 --- a/include/configs/mt8516.h +++ b/include/configs/mt8516.h @@ -11,7 +11,6 @@
#define CONFIG_SYS_NS16550_SERIAL diff --git a/include/configs/mt8518.h b/include/configs/mt8518.h index 593c6a11d742..49ee926b0c94 100644 --- a/include/configs/mt8518.h +++ b/include/configs/mt8518.h @@ -13,8 +13,6 @@
/* DRAM definition */ diff --git a/include/configs/xilinx_versal.h b/include/configs/xilinx_versal.h index 43486457a45d..03539a41b49f 100644 --- a/include/configs/xilinx_versal.h +++ b/include/configs/xilinx_versal.h @@ -26,8 +26,6 @@ #endif
/* Serial setup */ -#define CONFIG_CPU_ARMV8 - #define CONFIG_SYS_BAUDRATE_TABLE \ { 4800, 9600, 19200, 38400, 57600, 115200 }
diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index d683d12e95b9..f4b7f305bf75 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -26,8 +26,6 @@ #endif
This converts the following to Kconfig: CONFIG_CPU_PXA27X
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/Kconfig | 6 +++++- include/configs/colibri_pxa270.h | 1 - scripts/config_whitelist.txt | 1 - 3 files changed, 5 insertions(+), 3 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 594aec2b92d7..4bfca750c27b 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -311,6 +311,10 @@ config CPU_PXA select SYS_CACHE_SHIFT_5 imply SYS_ARM_MMU
+config CPU_PXA27X + bool + select CPU_PXA + config CPU_SA1100 bool select SYS_CACHE_SHIFT_5 @@ -1765,7 +1769,7 @@ config TARGET_SL28
config TARGET_COLIBRI_PXA270 bool "Support colibri_pxa270" - select CPU_PXA + select CPU_PXA27X select GPIO_EXTRA_HEADER
config ARCH_UNIPHIER diff --git a/include/configs/colibri_pxa270.h b/include/configs/colibri_pxa270.h index 22eab7779b01..0be7f5a416d0 100644 --- a/include/configs/colibri_pxa270.h +++ b/include/configs/colibri_pxa270.h @@ -12,7 +12,6 @@ /* * High Level Board Configuration Options */ -#define CONFIG_CPU_PXA27X 1 /* Marvell PXA270 CPU */ /* Avoid overwriting factory configuration block */ #define CONFIG_BOARD_SIZE_LIMIT 0x40000
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index a9bbd5078a87..2bc2d5b146bd 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -162,7 +162,6 @@ CONFIG_CPU_MIPSR2 CONFIG_CPU_MONAHANS CONFIG_CPU_PXA25X CONFIG_CPU_PXA26X -CONFIG_CPU_PXA27X CONFIG_CPU_PXA300 CONFIG_CPU_SH7751 CONFIG_CPU_TYPE_R
This converts the following to Kconfig: CONFIG_CPU_SH7751
Signed-off-by: Tom Rini trini@konsulko.com --- arch/sh/Kconfig | 6 +++++- include/configs/r2dplus.h | 1 - scripts/config_whitelist.txt | 1 - 3 files changed, 5 insertions(+), 3 deletions(-)
diff --git a/arch/sh/Kconfig b/arch/sh/Kconfig index 7836869c55dc..7e6cb7015896 100644 --- a/arch/sh/Kconfig +++ b/arch/sh/Kconfig @@ -4,13 +4,17 @@ menu "SuperH architecture" config CPU_SH4 bool
+config CPU_SH7751 + bool + select CPU_SH4 + choice prompt "Target select" optional
config TARGET_R2DPLUS bool "Renesas R2D-PLUS" - select CPU_SH4 + select CPU_SH7751
endchoice
diff --git a/include/configs/r2dplus.h b/include/configs/r2dplus.h index 680d16d547c4..8e86830e61be 100644 --- a/include/configs/r2dplus.h +++ b/include/configs/r2dplus.h @@ -1,7 +1,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_CPU_SH7751 1 #define __LITTLE_ENDIAN__ 1
/* SCIF */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 2bc2d5b146bd..655eaab81812 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -163,7 +163,6 @@ CONFIG_CPU_MONAHANS CONFIG_CPU_PXA25X CONFIG_CPU_PXA26X CONFIG_CPU_PXA300 -CONFIG_CPU_SH7751 CONFIG_CPU_TYPE_R CONFIG_CPU_VR41XX CONFIG_CQSPI_REF_CLK
This converts the following to Kconfig: CONFIG_CPU_FREQ_HZ
Cc: Michal Simek monstr@monstr.eu Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/mach-zynqmp-r5/Kconfig | 6 ++++++ configs/xilinx_zynqmp_r5_defconfig | 1 + include/configs/xilinx_zynqmp_r5.h | 3 --- include/configs/zynq-common.h | 5 ----- 4 files changed, 7 insertions(+), 8 deletions(-)
diff --git a/arch/arm/mach-zynqmp-r5/Kconfig b/arch/arm/mach-zynqmp-r5/Kconfig index 5e0175413395..f14514b3c7c1 100644 --- a/arch/arm/mach-zynqmp-r5/Kconfig +++ b/arch/arm/mach-zynqmp-r5/Kconfig @@ -21,6 +21,12 @@ config SYS_CONFIG_NAME Based on this option include/configs/<CONFIG_SYS_CONFIG_NAME>.h header will be used for board configuration.
+config CPU_FREQ_HZ + int "CPU frequency" + default 800000000 + help + The value, in Hz, that the CPU clock is running at. + config SYS_MALLOC_F_LEN default 0x600
diff --git a/configs/xilinx_zynqmp_r5_defconfig b/configs/xilinx_zynqmp_r5_defconfig index a9c3c4a03e81..98f46cf0205a 100644 --- a/configs/xilinx_zynqmp_r5_defconfig +++ b/configs/xilinx_zynqmp_r5_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_SIZE=0x20000 CONFIG_DEFAULT_DEVICE_TREE="zynqmp-r5" CONFIG_DEBUG_UART_BASE=0xff010000 CONFIG_DEBUG_UART_CLOCK=100000000 +CONFIG_CPU_FREQ_HZ=500000000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x0 CONFIG_BOOTSTAGE=y diff --git a/include/configs/xilinx_zynqmp_r5.h b/include/configs/xilinx_zynqmp_r5.h index 6d5b81e05e16..3ec99e062df5 100644 --- a/include/configs/xilinx_zynqmp_r5.h +++ b/include/configs/xilinx_zynqmp_r5.h @@ -8,9 +8,6 @@
#define CONFIG_EXTRA_ENV_SETTINGS
-/* CPU clock */ -#define CONFIG_CPU_FREQ_HZ 500000000 - /* Serial drivers */ /* The following table includes the supported baudrates */ #define CONFIG_SYS_BAUDRATE_TABLE \ diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 8f8a9c7479c3..88c6490d81cd 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -9,11 +9,6 @@ #ifndef __CONFIG_ZYNQ_COMMON_H #define __CONFIG_ZYNQ_COMMON_H
-/* CPU clock */ -#ifndef CONFIG_CPU_FREQ_HZ -# define CONFIG_CPU_FREQ_HZ 800000000 -#endif - #define CONFIG_REMAKE_ELF
/* Cache options */
There are a number of symbols that are never defined, only referenced in code imported from the Linux kernel or similar. Drop them from the list.
Signed-off-by: Tom Rini trini@konsulko.com --- scripts/config_whitelist.txt | 897 ----------------------------------- 1 file changed, 897 deletions(-)
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 655eaab81812..9fae7ce8617c 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1,41 +1,24 @@ -CONFIG_64BIT_PHYS_ADDR -CONFIG_83XX CONFIG_88F5182 CONFIG_A003399_NOR_WORKAROUND CONFIG_A008044_WORKAROUND -CONFIG_AEABI CONFIG_AM335X_USB0 CONFIG_AM335X_USB0_MODE CONFIG_AM335X_USB1 CONFIG_AM335X_USB1_MODE -CONFIG_ANDES_PCU -CONFIG_ANDES_PCU_BASE -CONFIG_ARCH_ADPAG101P -CONFIG_ARCH_HAS_ILOG2_U32 -CONFIG_ARCH_HAS_ILOG2_U64 -CONFIG_ARCH_OMAP4 -CONFIG_ARCH_RMOBILE_EXTRAM_BOOT -CONFIG_ARCH_USE_BUILTIN_BSWAP -CONFIG_ARC_MMU_VER CONFIG_ARMV7_SECURE_BASE CONFIG_ARMV7_SECURE_MAX_SIZE CONFIG_ARMV7_SECURE_RESERVE_SIZE CONFIG_ARMV8_SWITCH_TO_EL1 CONFIG_ARM_GIC_BASE_ADDRESS CONFIG_ARP_TIMEOUT -CONFIG_AT91C_PQFP_UHPBUG -CONFIG_AT91RESET_EXTRST -CONFIG_AT91RM9200 CONFIG_AT91SAM9260EK CONFIG_AT91SAM9261EK CONFIG_AT91SAM9G10 CONFIG_AT91SAM9G10EK CONFIG_AT91SAM9G20EK CONFIG_AT91SAM9G20EK_2MMC -CONFIG_AT91SAM9G45EKES CONFIG_AT91SAM9G45_LCD_BASE CONFIG_AT91SAM9M10G45EK -CONFIG_AT91_CAN CONFIG_AT91_EFLASH CONFIG_AT91_GPIO_PULLUP CONFIG_AT91_LED @@ -45,13 +28,9 @@ CONFIG_ATMEL_LCD CONFIG_ATMEL_LCD_BGR555 CONFIG_ATMEL_LCD_RGB565 CONFIG_ATMEL_LEGACY -CONFIG_ATMEL_MCI_8BIT CONFIG_ATMEL_SPI0 CONFIG_AUTO_ZRELADDR CONFIG_BACKSIDE_L2_CACHE -CONFIG_BCH_CONST_M -CONFIG_BCH_CONST_PARAMS -CONFIG_BCH_CONST_T CONFIG_BCM2835_GPIO CONFIG_BIOSEMU CONFIG_BITBANGMII_MULTI @@ -72,11 +51,8 @@ CONFIG_BOARD_SIZE_LIMIT CONFIG_BOOTFILE CONFIG_BOOTMODE CONFIG_BOOTP_BOOTFILESIZE -CONFIG_BOOTP_DHCP_REQUEST_DELAY -CONFIG_BOOTP_ID_CACHE_SIZE CONFIG_BOOTP_MAY_FAIL CONFIG_BOOTP_NISDOMAIN -CONFIG_BOOTP_RANDOM_DELAY CONFIG_BOOTP_SERVERIP CONFIG_BOOTP_TIMEOFFSET CONFIG_BOOTP_VENDOREX @@ -84,7 +60,6 @@ CONFIG_BOOTROM_ERR_REG CONFIG_BOOTSCRIPT_ADDR CONFIG_BOOTSCRIPT_COPY_RAM CONFIG_BOOTSCRIPT_HDR_ADDR -CONFIG_BOOTSCRIPT_KEY_HASH CONFIG_BOOT_RETRY_MIN CONFIG_BOOT_RETRY_TIME CONFIG_BPTR_VIRT_ADDR @@ -97,35 +72,14 @@ CONFIG_BS_HDR_ADDR_RAM CONFIG_BS_HDR_SIZE CONFIG_BS_SIZE CONFIG_BTB -CONFIG_BUILD_ENVCRC -CONFIG_BUS_WIDTH -CONFIG_CDP_APPLIANCE_VLAN_TYPE -CONFIG_CDP_CAPABILITIES -CONFIG_CDP_DEVICE_ID -CONFIG_CDP_DEVICE_ID_PREFIX -CONFIG_CDP_PLATFORM -CONFIG_CDP_PORT_ID -CONFIG_CDP_POWER_CONSUMPTION -CONFIG_CDP_TRIGGER -CONFIG_CDP_VERSION -CONFIG_CFG_DATA_SECTOR CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS CONFIG_CF_DSPI CONFIG_CF_SBF -CONFIG_CF_V2 -CONFIG_CF_V3 -CONFIG_CF_V4 -CONFIG_CF_V4E CONFIG_CHAIN_BOOT_CMD CONFIG_CHIP_SELECTS_PER_CTRL -CONFIG_CHIP_SELECT_QUAD_CAPABLE CONFIG_CHROMEOS_EXTRA_ENV_SETTINGS CONFIG_CI_UDC_HAS_HOSTPC -CONFIG_CLK_1000_200_200 -CONFIG_CLK_1000_330_165 CONFIG_CLK_1000_400_200 -CONFIG_CLK_800_330_165 -CONFIG_CLK_DEBUG CONFIG_CLOCKS CONFIG_CLOCK_SYNTHESIZER CONFIG_CM922T_XA10 @@ -135,11 +89,7 @@ CONFIG_CM_MULTIPLE_SSRAM CONFIG_CM_REMAP CONFIG_CM_SPD_DETECT CONFIG_CM_TCRAM -CONFIG_COLDFIRE CONFIG_COMMON_BOOT -CONFIG_COMPAT -CONFIG_CONS_EXTC_PINSEL -CONFIG_CONS_EXTC_RATE CONFIG_CONS_ON_SCC CONFIG_CONS_SCIF0 CONFIG_CONS_SCIF1 @@ -151,39 +101,13 @@ CONFIG_CPLD_OR_PRELIM CONFIG_CPM2 CONFIG_CPU_ARMV8 CONFIG_CPU_FREQ_HZ -CONFIG_CPU_HAS_LLSC -CONFIG_CPU_HAS_PREFETCH -CONFIG_CPU_HAS_SMARTMIPS -CONFIG_CPU_HAS_SR_RB -CONFIG_CPU_HAS_WB -CONFIG_CPU_LITTLE_ENDIAN -CONFIG_CPU_MICROMIPS -CONFIG_CPU_MIPSR2 -CONFIG_CPU_MONAHANS -CONFIG_CPU_PXA25X -CONFIG_CPU_PXA26X -CONFIG_CPU_PXA300 -CONFIG_CPU_TYPE_R -CONFIG_CPU_VR41XX CONFIG_CQSPI_REF_CLK -CONFIG_CS8900_BUS16 -CONFIG_CS8900_BUS32 -CONFIG_CTL_JTAG -CONFIG_CTL_TBE CONFIG_CUSTOMER_BOARD_SUPPORT CONFIG_D2NET_V2 -CONFIG_DA850_EVM_MAX_CPU_CLK CONFIG_DB_784MP_GP CONFIG_DCACHE -CONFIG_DCACHE_OFF -CONFIG_DCFG_ADDR CONFIG_DEBUG -CONFIG_DEBUG_FS CONFIG_DEBUG_LED -CONFIG_DEBUG_LOCK_ALLOC -CONFIG_DEBUG_SEMIHOSTING -CONFIG_DEBUG_UART_LINFLEXUART -CONFIG_DEBUG_WRITECOUNT CONFIG_DEEP_SLEEP CONFIG_DEFAULT CONFIG_DEFAULT_IMMR @@ -194,12 +118,9 @@ CONFIG_DFU_ALT_BOOT_EMMC CONFIG_DFU_ALT_BOOT_SD CONFIG_DFU_ALT_SYSTEM CONFIG_DFU_ENV_SETTINGS -CONFIG_DHCP_MIN_EXT_LEN CONFIG_DIALOG_POWER CONFIG_DIMM_SLOTS_PER_CTLR -CONFIG_DISCONTIGMEM CONFIG_DISCOVER_PHY -CONFIG_DISPLAY_AER_xxxx CONFIG_DM9000_BASE CONFIG_DM9000_BYTE_SWAPPED CONFIG_DM9000_DEBUG @@ -207,33 +128,20 @@ CONFIG_DM9000_NO_SROM CONFIG_DM9000_USE_16BIT CONFIG_DMA_COHERENT CONFIG_DMA_COHERENT_SIZE -CONFIG_DMA_NONCOHERENT -CONFIG_DNET_AUTONEG_TIMEOUT CONFIG_DP_DDR_CTRL CONFIG_DP_DDR_DIMM_SLOTS_PER_CTLR CONFIG_DP_DDR_NUM_CTRLS CONFIG_DRIVER_DM9000 CONFIG_DSP_CLUSTER_START -CONFIG_DWCDDR21MCTL -CONFIG_DWCDDR21MCTL_BASE CONFIG_DWC_AHSATA_BASE_ADDR CONFIG_DWC_AHSATA_PORT_ID CONFIG_DW_ALTDESCRIPTOR -CONFIG_DW_AXI_BURST_LEN CONFIG_DW_GMAC_DEFAULT_DMA_PBL -CONFIG_DW_MAC_FORCE_THRESHOLD_MODE CONFIG_DW_WDT_BASE CONFIG_DW_WDT_CLOCK_KHZ CONFIG_E1000_NO_NVM CONFIG_E300 CONFIG_E5500 -CONFIG_ECC -CONFIG_EDB9301 -CONFIG_EDB93XX_INDUSTRIAL -CONFIG_EDB93XX_SDCS0 -CONFIG_EDB93XX_SDCS1 -CONFIG_EDB93XX_SDCS2 -CONFIG_EDB93XX_SDCS3 CONFIG_EFLASH_PROTSECTORS CONFIG_EHCI_DESC_BIG_ENDIAN CONFIG_EHCI_HCD_INIT_AFTER_RESET @@ -243,16 +151,10 @@ CONFIG_EHCI_MXS_PORT1 CONFIG_EMU CONFIG_ENABLE_36BIT_PHYS CONFIG_ENABLE_MMU -CONFIG_ENABLE_MUST_CHECK -CONFIG_ENV_ADDR_FLEX -CONFIG_ENV_CALLBACK_LIST_DEFAULT -CONFIG_ENV_CALLBACK_LIST_STATIC -CONFIG_ENV_FLAGS_LIST_DEFAULT CONFIG_ENV_FLAGS_LIST_STATIC CONFIG_ENV_IS_EMBEDDED CONFIG_ENV_MAX_ENTRIES CONFIG_ENV_MIN_ENTRIES -CONFIG_ENV_OFFSET_OOB CONFIG_ENV_RANGE CONFIG_ENV_REFLASH CONFIG_ENV_SETTINGS_BUTTONS_AND_LEDS @@ -260,34 +162,25 @@ CONFIG_ENV_SETTINGS_NAND_V1 CONFIG_ENV_SETTINGS_NAND_V2 CONFIG_ENV_SETTINGS_V1 CONFIG_ENV_SETTINGS_V2 -CONFIG_ENV_SIZE_FLEX CONFIG_ENV_SROM_BANK CONFIG_ENV_TOTAL_SIZE CONFIG_ENV_VERSION -CONFIG_EPH_POWER_EN -CONFIG_EPOLL CONFIG_ESBC_ADDR_64BIT CONFIG_ESBC_HDR_LS -CONFIG_ESDHC_DETECT_8_BIT_QUIRK CONFIG_ESDHC_DETECT_QUIRK CONFIG_ESDHC_HC_BLK_ADDR CONFIG_ESPRESSO7420 CONFIG_ET1100_BASE -CONFIG_ETHADDR CONFIG_ETHBASE CONFIG_ETHPRIME -CONFIG_ETH_BUFSIZE -CONFIG_ETH_RXSIZE CONFIG_EXTRA_CLOCK CONFIG_EXTRA_ENV CONFIG_EXTRA_ENV_SETTINGS CONFIG_EXTRA_ENV_SETTINGS_COMMON -CONFIG_EXT_AHB2AHB_BASE CONFIG_EXT_AHBAPBBRG_BASE CONFIG_EXT_AHBPCIBRG_BASE CONFIG_EXT_AHBSLAVE01_BASE CONFIG_EXT_AHBSLAVE02_BASE -CONFIG_EXT_PHY CONFIG_EXT_USB_HOST_BASE CONFIG_EXYNOS4 CONFIG_EXYNOS4210 @@ -304,27 +197,14 @@ CONFIG_EXYNOS_SPL CONFIG_EXYNOS_TMU CONFIG_FACTORYSET CONFIG_FB_ADDR -CONFIG_FB_BACKLIGHT -CONFIG_FB_DEFERRED_IO CONFIG_FDTADDR CONFIG_FDTFILE -CONFIG_FEATURE_CLEAN_UP -CONFIG_FEATURE_COMMAND_EDITING -CONFIG_FEATURE_SH_APPLETS_ALWAYS_WIN -CONFIG_FEATURE_SH_EXTRA_QUIET -CONFIG_FEATURE_SH_FANCY_PROMPT -CONFIG_FEATURE_SH_STANDALONE_SHELL CONFIG_FEC_ENET_DEV CONFIG_FEC_FIXED_SPEED -CONFIG_FEC_MXC_25M_REF_CLK CONFIG_FEC_MXC_PHYADDR -CONFIG_FEC_MXC_SWAP_PACKET CONFIG_FEC_XCV_TYPE CONFIG_FEROCEON CONFIG_FEROCEON_88FR131 -CONFIG_FILE -CONFIG_FIXED_PHY -CONFIG_FIXED_PHY_ADDR CONFIG_FIXED_SDHCI_ALIGNED_BUFFER CONFIG_FLASH_BR_PRELIM CONFIG_FLASH_CFI_LEGACY @@ -334,16 +214,13 @@ CONFIG_FLASH_SHOW_PROGRESS CONFIG_FLASH_SPANSION_S29WS_N CONFIG_FLASH_VERIFY CONFIG_FM_PLAT_CLK_DIV -CONFIG_FORCE_DDR_DATA_BUS_WIDTH_32 CONFIG_FORMIKE CONFIG_FPGA_COUNT -CONFIG_FPGA_DELAY CONFIG_FPGA_STRATIX_V CONFIG_FSL_CADMUS CONFIG_FSL_CORENET CONFIG_FSL_CPLD CONFIG_FSL_DCU_SII9022A -CONFIG_FSL_DEEP_SLEEP CONFIG_FSL_DEVICE_DISABLE CONFIG_FSL_DIU_CH7301 CONFIG_FSL_DIU_FB @@ -351,8 +228,6 @@ CONFIG_FSL_DSPI1 CONFIG_FSL_ESDHC_PIN_MUX CONFIG_FSL_FIXED_MMC_LOCATION CONFIG_FSL_FM_10GEC_REGULAR_NOTATION -CONFIG_FSL_I2C_CUSTOM_DFSR -CONFIG_FSL_I2C_CUSTOM_FDR CONFIG_FSL_IIM CONFIG_FSL_ISBC_KEY_EXT CONFIG_FSL_LBC @@ -364,35 +239,25 @@ CONFIG_FSL_PMIC_CLK CONFIG_FSL_PMIC_CS CONFIG_FSL_PMIC_MODE CONFIG_FSL_QIXIS -CONFIG_FSL_QIXIS_CLOCK_MEASUREMENT CONFIG_FSL_SATA_V2 CONFIG_FSL_SDHC_V2_3 -CONFIG_FSL_SDRAM_TYPE CONFIG_FSL_SERDES CONFIG_FSL_SERDES1 CONFIG_FSL_SERDES2 CONFIG_FSL_SGMII_RISER -CONFIG_FSL_TBCLK_EXTRA_DIV -CONFIG_FSL_TRUST_ARCH_v1 -CONFIG_FSNOTIFY -CONFIG_FS_POSIX_ACL CONFIG_FTAHBC020S CONFIG_FTAHBC020S_BASE CONFIG_FTAPBBRG020S_01_BASE CONFIG_FTCFC010_BASE CONFIG_FTDMAC020_BASE -CONFIG_FTGMAC100_BASE CONFIG_FTGPIO010_BASE -CONFIG_FTIDE020S_BASE CONFIG_FTIIC010_BASE CONFIG_FTINTC010_BASE CONFIG_FTLCDC100_BASE CONFIG_FTMAC100_BASE -CONFIG_FTMAC110_BASE CONFIG_FTPMU010 CONFIG_FTPMU010_BASE CONFIG_FTPMU010_POWER -CONFIG_FTPWM010_BASE CONFIG_FTRTC010_BASE CONFIG_FTRTC010_EXTCLK CONFIG_FTRTC010_PCLK @@ -403,22 +268,15 @@ CONFIG_FTSMC020_BASE CONFIG_FTSSP010_01_BASE CONFIG_FTSSP010_02_BASE CONFIG_FTTMR010_BASE -CONFIG_FTTMR010_EXT_CLK CONFIG_FTUART010_01_BASE CONFIG_FTUART010_02_BASE CONFIG_FTUART010_03_BASE CONFIG_FTWDT010_BASE CONFIG_FTWDT010_WATCHDOG -CONFIG_FZOTG266HD0A_BASE CONFIG_GATEWAYIP -CONFIG_GLOBAL_DATA_NOT_REG10 CONFIG_GLOBAL_TIMER CONFIG_GMII -CONFIG_GPCNTRL -CONFIG_GPIO_LED_INVERTED_TABLE -CONFIG_GPIO_LED_STUBS CONFIG_GREEN_LED -CONFIG_GURNARD_FPGA CONFIG_GURNARD_SPLASH CONFIG_G_DNL_THOR_PRODUCT_NUM CONFIG_G_DNL_THOR_VENDOR_NUM @@ -435,7 +293,6 @@ CONFIG_HDMI_ENCODER_I2C_ADDR CONFIG_HETROGENOUS_CLUSTERS CONFIG_HIDE_LOGO_VERSION CONFIG_HIKEY_GPIO -CONFIG_HITACHI_SX14 CONFIG_HOSTNAME CONFIG_HPS_ALTERAGRP_DBGATCLK CONFIG_HPS_ALTERAGRP_MAINCLK @@ -585,43 +442,27 @@ CONFIG_HWCONFIG CONFIG_HW_ENV_SETTINGS CONFIG_I2C_ENV_EEPROM_BUS CONFIG_I2C_GSC -CONFIG_I2C_MBB_TIMEOUT CONFIG_I2C_MULTI_BUS CONFIG_I2C_MVTWSI CONFIG_I2C_MVTWSI_BASE CONFIG_I2C_MVTWSI_BASE0 CONFIG_I2C_MVTWSI_BASE1 -CONFIG_I2C_MVTWSI_BASE2 -CONFIG_I2C_MVTWSI_BASE3 -CONFIG_I2C_MVTWSI_BASE4 -CONFIG_I2C_MVTWSI_BASE5 -CONFIG_I2C_REPEATED_START CONFIG_I2C_RTC_ADDR -CONFIG_I2C_TIMEOUT CONFIG_ICACHE CONFIG_ICS307_REFCLK_HZ CONFIG_IDE_PREINIT CONFIG_IDE_RESET -CONFIG_IMA CONFIG_IMX CONFIG_IMX6_PWM_PER_CLK CONFIG_IMX_HDMI CONFIG_IMX_VIDEO_SKIP CONFIG_INETSPACE_V2 -CONFIG_INI_ALLOW_MULTILINE -CONFIG_INI_CASE_INSENSITIVE -CONFIG_INI_MAX_LINE -CONFIG_INI_MAX_NAME -CONFIG_INI_MAX_SECTION -CONFIG_INTEGRITY CONFIG_INTERRUPTS CONFIG_IODELAY_RECALIBRATION CONFIG_IOMUX_LPSR CONFIG_IOMUX_SHARE_CONF_REG -CONFIG_IOS CONFIG_IO_TRACE CONFIG_IPADDR -CONFIG_IPROC CONFIG_IRAM_BASE CONFIG_IRAM_END CONFIG_IRAM_SIZE @@ -633,9 +474,7 @@ CONFIG_JFFS2_LZO CONFIG_JFFS2_NAND CONFIG_JFFS2_PART_OFFSET CONFIG_JFFS2_PART_SIZE -CONFIG_JFFS2_SUMMARY CONFIG_JRSTARTR_JR0 -CONFIG_JTAG_CONSOLE CONFIG_KEEP_SERVERADDR CONFIG_KEY_REVOCATION CONFIG_KIRKWOOD_EGIGA_INIT @@ -680,18 +519,14 @@ CONFIG_KSNET_NETCP_V1_5 CONFIG_KSNET_SERDES_LANES_PER_SGMII CONFIG_KSNET_SERDES_SGMII2_BASE CONFIG_KSNET_SERDES_SGMII_BASE -CONFIG_KVM_GUEST CONFIG_KW88F6192 CONFIG_KW88F6281 CONFIG_KW88F6702 CONFIG_L1_INIT_RAM CONFIG_L2_CACHE -CONFIG_LAN91C96_USE_32_BIT CONFIG_LAYERSCAPE_NS_ACCESS CONFIG_LBA48 -CONFIG_LBDAF CONFIG_LCD_ALIGNMENT -CONFIG_LCD_BMP_RLE8 CONFIG_LCD_INFO CONFIG_LCD_INFO_BELOW_LOGO CONFIG_LCD_IN_PSRAM @@ -700,14 +535,10 @@ CONFIG_LCD_MENU CONFIG_LD9040 CONFIG_LEGACY CONFIG_LEGACY_BOOTCMD_ENV -CONFIG_LITTLETON_LCD -CONFIG_LMS283GF05 CONFIG_LOADS_ECHO CONFIG_LOWPOWER_ADDR CONFIG_LOWPOWER_FLAG -CONFIG_LOW_MCFCLK CONFIG_LPC32XX_ETH -CONFIG_LPC32XX_ETH_BUFS_BASE CONFIG_LPC32XX_HSUART CONFIG_LPC32XX_NAND_MLC_BUSY_DELAY CONFIG_LPC32XX_NAND_MLC_NAND_TA @@ -724,90 +555,41 @@ CONFIG_LPC32XX_NAND_SLC_WDR_CLKS CONFIG_LPC32XX_NAND_SLC_WHOLD CONFIG_LPC32XX_NAND_SLC_WSETUP CONFIG_LPC32XX_NAND_SLC_WWIDTH -CONFIG_LPC_BASE -CONFIG_LPC_IO_BASE CONFIG_LPUART CONFIG_LPUART_32B_REG -CONFIG_LQ038J7DH53 CONFIG_LS102XA_STREAM_ID CONFIG_LSCHLV2 CONFIG_LSXHL -CONFIG_M41T94_SPI_CS -CONFIG_M520x -CONFIG_M5301x CONFIG_MACB_SEARCH_PHY -CONFIG_MACRESET_TIMEOUT CONFIG_MALLOC_F_ADDR CONFIG_MALTA -CONFIG_MARCO_MEMSET -CONFIG_MASK_AER_AO CONFIG_MAX_DSP_CPUS -CONFIG_MAX_FPGA_DEVICES CONFIG_MAX_MEM_MAPPED -CONFIG_MAX_PKT CONFIG_MAX_RAM_BANK_SIZE -CONFIG_MCF5249 -CONFIG_MCF5253 CONFIG_MCFRTC CONFIG_MCFTMR -CONFIG_MDIO_TIMEOUT CONFIG_MEMSIZE_IN_BYTES -CONFIG_MEM_HOLE_16M CONFIG_MEM_INIT_VALUE CONFIG_MEM_REMAP CONFIG_MFG_ENV_SETTINGS CONFIG_MII_DEFAULT_TSEC CONFIG_MII_INIT -CONFIG_MIPS_HUGE_TLB_SUPPORT -CONFIG_MIPS_MT_FPAFF CONFIG_MISC_COMMON -CONFIG_MIU_1BIT_INTERLEAVED CONFIG_MIU_2BIT_21_7_INTERLEAVED CONFIG_MIU_2BIT_INTERLEAVED -CONFIG_MIU_LINEAR CONFIG_MMCROOT CONFIG_MMC_DEFAULT_DEV -CONFIG_MMC_RPMB_TRACE CONFIG_MMC_SUNXI_SLOT -CONFIG_MMU CONFIG_MONITOR_IS_IN_RAM -CONFIG_MPC83XX_GPIO_0_INIT_DIRECTION -CONFIG_MPC83XX_GPIO_0_INIT_OPEN_DRAIN -CONFIG_MPC83XX_GPIO_0_INIT_VALUE -CONFIG_MPC83XX_GPIO_1_INIT_DIRECTION -CONFIG_MPC83XX_GPIO_1_INIT_OPEN_DRAIN -CONFIG_MPC83XX_GPIO_1_INIT_VALUE CONFIG_MPC85XX_FEC CONFIG_MPC85XX_FEC_NAME -CONFIG_MPC8xxx_DISABLE_BPTR CONFIG_MTD_CONCAT -CONFIG_MTD_NAND_MUSEUM_IDS CONFIG_MTD_NAND_VERIFY_WRITE -CONFIG_MTD_ONENAND_VERIFY_WRITE CONFIG_MTD_PARTITION -CONFIG_MTD_UBI_BEB_RESERVE -CONFIG_MTD_UBI_BLOCK -CONFIG_MTD_UBI_DEBUG -CONFIG_MTD_UBI_DEBUG_MSG -CONFIG_MTD_UBI_DEBUG_MSG_BLD -CONFIG_MTD_UBI_DEBUG_MSG_EBA -CONFIG_MTD_UBI_DEBUG_MSG_IO -CONFIG_MTD_UBI_DEBUG_MSG_WL -CONFIG_MTD_UBI_DEBUG_PARANOID -CONFIG_MTD_UBI_GLUEBI -CONFIG_MTD_UBI_MODULE -CONFIG_MULTI_CS CONFIG_MVGBE_PORTS -CONFIG_MVMFP_V2 CONFIG_MVS -CONFIG_MV_ETH_RXQ -CONFIG_MV_I2C_NUM -CONFIG_MV_I2C_REG CONFIG_MX27 CONFIG_MX27_CLK32 -CONFIG_MX27_TIMER_HIGH_PRECISION -CONFIG_MX28_FEC_MAC_IN_OCOTP -CONFIG_MXC_EPDC CONFIG_MXC_GPT_HCLK CONFIG_MXC_NAND_HWECC CONFIG_MXC_NAND_IP_REGS_BASE @@ -820,60 +602,36 @@ CONFIG_MXS CONFIG_MXS_AUART CONFIG_MXS_AUART_BASE CONFIG_MXS_OCOTP -CONFIG_MY_OPTION CONFIG_NANDFLASH_SIZE CONFIG_NAND_6BYTES_OOB_FREE_10BYTES_ECC CONFIG_NAND_CS_INIT -CONFIG_NAND_DATA_REG CONFIG_NAND_ECC_BCH -CONFIG_NAND_ENV_DST CONFIG_NAND_KIRKWOOD CONFIG_NAND_KMETER1 -CONFIG_NAND_MODE_REG CONFIG_NAND_OMAP_GPMC_WSCFG CONFIG_NAND_SECBOOT CONFIG_NAND_SPL -CONFIG_NAND_U_BOOT -CONFIG_NATSEMI -CONFIG_NCEL2C100_BASE -CONFIG_NCEMIC100_BASE -CONFIG_NDS_DLM1_BASE -CONFIG_NDS_DLM2_BASE -CONFIG_NEO CONFIG_NET2BIG_V2 -CONFIG_NETCONSOLE_BUFFER_SIZE CONFIG_NETDEV CONFIG_NETMASK CONFIG_NETSPACE_LITE_V2 CONFIG_NETSPACE_MAX_V2 CONFIG_NETSPACE_MINI_V2 CONFIG_NETSPACE_V2 -CONFIG_NET_MULTI CONFIG_NET_RETRY_COUNT CONFIG_NEVER_ASSERT_ODT_TO_CPU CONFIG_NFS_TIMEOUT CONFIG_NOBQFMAN -CONFIG_NON_SECURE CONFIG_NORBOOT CONFIG_NORFLASH_PS32BIT -CONFIG_NO_ETH -CONFIG_NO_WAIT CONFIG_NS16550_MIN_FUNCTIONS -CONFIG_NS8382X CONFIG_NUM_DSP_CPUS -CONFIG_NUM_PAMU CONFIG_ODROID_REV_AIN -CONFIG_OFF_PADCONF CONFIG_ORIGEN CONFIG_OTHBOOTARGS CONFIG_OVERWRITE_ETHADDR_ONCE -CONFIG_PALMAS_AUDPWR CONFIG_PALMAS_POWER -CONFIG_PALMAS_SMPS7_FPWM -CONFIG_PALMAS_USB_SS_PWR -CONFIG_PARAVIRT CONFIG_PCA953X -CONFIG_PCA9698 CONFIG_PCI1 CONFIG_PCI2 CONFIG_PCIE @@ -884,11 +642,8 @@ CONFIG_PCIE4 CONFIG_PCIE_IMX CONFIG_PCIE_IMX_PERST_GPIO CONFIG_PCIE_IMX_POWER_GPIO -CONFIG_PCI_BOOTDELAY CONFIG_PCI_CLK_FREQ CONFIG_PCI_CONFIG_HOST_BRIDGE -CONFIG_PCI_EHCI_DEVICE -CONFIG_PCI_EHCI_DEVNO CONFIG_PCI_GT64120 CONFIG_PCI_IO_BUS CONFIG_PCI_IO_PHYS @@ -899,14 +654,10 @@ CONFIG_PCI_MEM_SIZE CONFIG_PCI_MSC01 CONFIG_PCI_NOSCAN CONFIG_PCI_OHCI -CONFIG_PCI_OHCI_DEVNO CONFIG_PCI_PREF_BUS CONFIG_PCI_PREF_PHYS CONFIG_PCI_PREF_SIZE CONFIG_PCI_SCAN_SHOW -CONFIG_PCI_SYS_BUS -CONFIG_PCI_SYS_PHYS -CONFIG_PCI_SYS_SIZE CONFIG_PEN_ADDR_BIG_ENDIAN CONFIG_PHYSMEM CONFIG_PHY_BASE_ADR @@ -914,11 +665,8 @@ CONFIG_PHY_ET1011C_TX_CLK_FIX CONFIG_PHY_ID CONFIG_PHY_INTERFACE_MODE CONFIG_PHY_IRAM_BASE -CONFIG_PHY_MODE_NEED_CHANGE CONFIG_PHY_RESET_DELAY -CONFIG_PIXIS_SGMII_CMD CONFIG_PL011_CLOCK -CONFIG_PL011_SERIAL_RLCR CONFIG_PL01x_PORTS CONFIG_PM CONFIG_PMC_BR_PRELIM @@ -926,24 +674,15 @@ CONFIG_PMC_OR_PRELIM CONFIG_PME_PLAT_CLK_DIV CONFIG_PMU CONFIG_PMW_BASE -CONFIG_PM_SLEEP CONFIG_POST CONFIG_POSTBOOTMENU -CONFIG_POST_BSPEC1 -CONFIG_POST_BSPEC2 -CONFIG_POST_BSPEC3 -CONFIG_POST_BSPEC4 -CONFIG_POST_BSPEC5 CONFIG_POST_EXTERNAL_WORD_FUNCS CONFIG_POST_SKIP_ENV_FLAGS -CONFIG_POST_UART -CONFIG_POST_WATCHDOG CONFIG_POWER_FSL CONFIG_POWER_FSL_MC13892 CONFIG_POWER_HI6553 CONFIG_POWER_LTC3676 CONFIG_POWER_LTC3676_I2C_ADDR -CONFIG_POWER_MAX77696_I2C_ADDR CONFIG_POWER_PFUZE100 CONFIG_POWER_PFUZE100_I2C_ADDR CONFIG_POWER_PFUZE3000 @@ -954,25 +693,18 @@ CONFIG_POWER_TPS65090_EC CONFIG_POWER_TPS65217 CONFIG_POWER_TPS65218 CONFIG_POWER_TPS65910 -CONFIG_PPC64BRIDGE CONFIG_PPC_CLUSTER_START CONFIG_PPC_SPINTABLE_COMPATIBLE CONFIG_PRAM -CONFIG_PRINTK -CONFIG_PROC_FS -CONFIG_PROFILE_ALL_BRANCHES -CONFIG_PROFILING CONFIG_PSRAM_SCFG CONFIG_PWM CONFIG_PXA_LCD CONFIG_PXA_PWR_I2C CONFIG_PXA_STD_I2C CONFIG_PXA_VGA -CONFIG_PXA_VIDEO CONFIG_QBMAN_CLK_DIV CONFIG_QIXIS_I2C_ACCESS CONFIG_QSPI -CONFIG_QUOTA CONFIG_RAMBOOT_NAND CONFIG_RAMBOOT_SPIFLASH CONFIG_RAMBOOT_TEXT_BASE @@ -980,11 +712,8 @@ CONFIG_RAMDISKFILE CONFIG_RAMDISK_ADDR CONFIG_RAMDISK_BOOT CONFIG_RD_LVL -CONFIG_REALMODE_DEBUG CONFIG_RED_LED -CONFIG_REG CONFIG_REMAKE_ELF -CONFIG_REQ CONFIG_RESERVED_01_BASE CONFIG_RESERVED_02_BASE CONFIG_RESERVED_03_BASE @@ -995,50 +724,29 @@ CONFIG_RESET_VECTOR_ADDRESS CONFIG_RESTORE_FLASH CONFIG_RES_BLOCK_SIZE CONFIG_RMII -CONFIG_RMSTP0_ENA -CONFIG_RMSTP10_ENA -CONFIG_RMSTP11_ENA -CONFIG_RMSTP1_ENA -CONFIG_RMSTP2_ENA -CONFIG_RMSTP3_ENA -CONFIG_RMSTP4_ENA -CONFIG_RMSTP5_ENA -CONFIG_RMSTP6_ENA -CONFIG_RMSTP7_ENA -CONFIG_RMSTP8_ENA -CONFIG_RMSTP9_ENA CONFIG_ROCKCHIP_CHIP_TAG CONFIG_ROCKCHIP_MAX_INIT_SIZE CONFIG_ROCKCHIP_SDHCI_MAX_FREQ CONFIG_ROCKCHIP_STIMER_BASE -CONFIG_ROM_STUBS CONFIG_ROOTPATH CONFIG_RTC_DS1337 CONFIG_RTC_DS1337_NOOSC CONFIG_RTC_DS1338 -CONFIG_RTC_DS1339_TCR_VAL CONFIG_RTC_DS1374 -CONFIG_RTC_DS1388 -CONFIG_RTC_DS1388_TCR_VAL CONFIG_RTC_DS3231 CONFIG_RTC_FTRTC010 -CONFIG_RTC_M41T11 CONFIG_RTC_MC13XXX CONFIG_RTC_MCFRRTC -CONFIG_RTC_MCP79411 CONFIG_RTC_MXS CONFIG_RTC_PT7C4338 -CONFIG_RX_DESCR_NUM CONFIG_S5P CONFIG_S5PC100 CONFIG_S5PC110 CONFIG_S5P_PA_SYSRAM -CONFIG_S6E8AX0 CONFIG_SAMA5D3_LCD_BASE CONFIG_SAMSUNG CONFIG_SAMSUNG_ONENAND CONFIG_SANDBOX_ARCH -CONFIG_SANDBOX_BIG_ENDIAN CONFIG_SANDBOX_SDL CONFIG_SANDBOX_SPI_MAX_BUS CONFIG_SANDBOX_SPI_MAX_CS @@ -1046,10 +754,7 @@ CONFIG_SAR2_REG CONFIG_SAR_REG CONFIG_SATA1 CONFIG_SATA2 -CONFIG_SATA_ULI5288 -CONFIG_SCF0403_LCD CONFIG_SCIF_A -CONFIG_SCIF_USE_EXT_CLK CONFIG_SCSI_AHCI_PLAT CONFIG_SCSI_DEV_LIST CONFIG_SC_TIMER_CLK @@ -1057,25 +762,17 @@ CONFIG_SDCARD CONFIG_SDRAM_OFFSET_FOR_RT CONFIG_SECBOOT CONFIG_SECURE_BL1_ONLY -CONFIG_SECURE_RUNTIME_RESV_SRAM_SZ -CONFIG_SECURITY CONFIG_SEC_FW_SIZE CONFIG_SERIAL_BOOT CONFIG_SERIAL_FLASH -CONFIG_SERIAL_HW_FLOW_CONTROL CONFIG_SERIAL_SOFTWARE_FIFO -CONFIG_SERIRQ_CONTINUOUS_MODE CONFIG_SERVERIP CONFIG_SETUP_INITRD_TAG CONFIG_SET_BOOTARGS CONFIG_SET_DFU_ALT_BUF_LEN -CONFIG_SGI_IP28 CONFIG_SH73A0 CONFIG_SH7751_PCI -CONFIG_SHARP_LM8V31 CONFIG_SHEEVA_88SV131 -CONFIG_SH_CMT_CLK_FREQ -CONFIG_SH_DSP CONFIG_SH_ETHER_ALIGNE_SIZE CONFIG_SH_ETHER_BASE_ADDR CONFIG_SH_ETHER_CACHE_INVALIDATE @@ -1085,49 +782,28 @@ CONFIG_SH_ETHER_PHY_MODE CONFIG_SH_ETHER_SH7734_MII CONFIG_SH_ETHER_USE_PORT CONFIG_SH_GPIO_PFC -CONFIG_SH_MMCIF_CLK CONFIG_SH_QSPI_BASE CONFIG_SH_SCIF_CLK_FREQ -CONFIG_SH_SDHI_FREQ -CONFIG_SH_SDRAM_OFFSET CONFIG_SKIP_LOCAL_MAC_RANDOMIZATION CONFIG_SKIP_TRUNOFF_WATCHDOG CONFIG_SLIC -CONFIG_SLTTMR CONFIG_SMC91111 CONFIG_SMC91111_BASE CONFIG_SMC91111_EXT_PHY -CONFIG_SMC_AUTONEG_TIMEOUT CONFIG_SMC_USE_32_BIT -CONFIG_SMC_USE_IOFUNCS CONFIG_SMDK5420 CONFIG_SMP_PEN_ADDR CONFIG_SMSC_LPC47M CONFIG_SMSC_SIO1007 -CONFIG_SMSTP0_ENA -CONFIG_SMSTP10_ENA -CONFIG_SMSTP11_ENA -CONFIG_SMSTP1_ENA -CONFIG_SMSTP2_ENA -CONFIG_SMSTP3_ENA -CONFIG_SMSTP4_ENA -CONFIG_SMSTP5_ENA -CONFIG_SMSTP6_ENA -CONFIG_SMSTP7_ENA -CONFIG_SMSTP8_ENA -CONFIG_SMSTP9_ENA CONFIG_SOCRATES -CONFIG_SOC_OMAP3430 CONFIG_SOFT_I2C_READ_REPEATED_START CONFIG_SPD_EEPROM CONFIG_SPIFLASH CONFIG_SPI_ADDR CONFIG_SPI_BOOTING -CONFIG_SPI_DATAFLASH_WRITE_VERIFY CONFIG_SPI_FLASH_QUAD CONFIG_SPI_FLASH_SIZE CONFIG_SPI_HALF_DUPLEX -CONFIG_SPI_IDLE_VAL CONFIG_SPI_N25Q256A_RESET CONFIG_SPL_ATMEL_SIZE CONFIG_SPL_BOARD_LOAD_IMAGE @@ -1138,29 +814,21 @@ CONFIG_SPL_BSS_START_ADDR CONFIG_SPL_CMT CONFIG_SPL_CMT_DEBUG CONFIG_SPL_COMMON_INIT_DDR -CONFIG_SPL_CONSOLE -CONFIG_SPL_ETH_DEVICE CONFIG_SPL_FLUSH_IMAGE CONFIG_SPL_FS_LOAD_ARGS_NAME CONFIG_SPL_FS_LOAD_KERNEL_NAME CONFIG_SPL_FS_LOAD_PAYLOAD_NAME CONFIG_SPL_GD_ADDR CONFIG_SPL_INIT_MINIMAL -CONFIG_SPL_JR0_LIODN_NS -CONFIG_SPL_JR0_LIODN_S CONFIG_SPL_MAX_FOOTPRINT -CONFIG_SPL_MAX_PEB_SIZE CONFIG_SPL_MAX_SIZE -CONFIG_SPL_MXS_PSWITCH_WAIT CONFIG_SPL_NAND_INIT CONFIG_SPL_NAND_MINIMAL CONFIG_SPL_NAND_RAW_ONLY CONFIG_SPL_NAND_SOFTECC CONFIG_SPL_NAND_WORKSPACE CONFIG_SPL_PAD_TO -CONFIG_SPL_PANIC_ON_RAW_IMAGE CONFIG_SPL_PBL_PAD -CONFIG_SPL_PPAACT_ADDR CONFIG_SPL_RELOC_MALLOC_ADDR CONFIG_SPL_RELOC_MALLOC_SIZE CONFIG_SPL_RELOC_STACK @@ -1168,14 +836,12 @@ CONFIG_SPL_RELOC_TEXT_BASE CONFIG_SPL_SATA_BOOT_DEVICE CONFIG_SPL_SIZE CONFIG_SPL_SKIP_RELOCATE -CONFIG_SPL_SPAACT_ADDR CONFIG_SPL_SPI_FLASH_MINIMAL CONFIG_SPL_STACK CONFIG_SPL_STACK_ADDR CONFIG_SPL_STACK_SIZE CONFIG_SPL_START_S_PATH CONFIG_SPL_TARGET -CONFIG_SPL_UBOOT_KEY_HASH CONFIG_SRAM_BASE CONFIG_SRAM_SIZE CONFIG_SRIO1 @@ -1191,28 +857,19 @@ CONFIG_SRIO_PCIE_BOOT_SLAVE CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_BUS CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_PHYS CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_SIZE -CONFIG_SSE2 CONFIG_STACKBASE CONFIG_STANDALONE_LOAD_ADDR -CONFIG_STATIC_BOARD_REV CONFIG_STD_DEVICES_SETTINGS -CONFIG_SXNI855T -CONFIG_SYSFS -CONFIG_SYSMGR_ISWGRP_HANDOFF CONFIG_SYS_64BIT CONFIG_SYS_64BIT_LBA CONFIG_SYS_83XX_DDR_USES_CS0 -CONFIG_SYS_ADDRESS_MAP_A CONFIG_SYS_AMASK0 -CONFIG_SYS_AMASK0_FINAL CONFIG_SYS_AMASK1 CONFIG_SYS_AMASK1_FINAL CONFIG_SYS_AMASK2 CONFIG_SYS_AMASK2_FINAL CONFIG_SYS_AMASK3 -CONFIG_SYS_AMASK3_FINAL CONFIG_SYS_AMASK4 -CONFIG_SYS_AMASK5 CONFIG_SYS_AMASK6 CONFIG_SYS_AMASK7 CONFIG_SYS_AT91_MAIN_CLOCK @@ -1226,7 +883,6 @@ CONFIG_SYS_ATA_IDE0_OFFSET CONFIG_SYS_ATA_IDE1_OFFSET CONFIG_SYS_ATA_REG_OFFSET CONFIG_SYS_ATA_STRIDE -CONFIG_SYS_ATMEL_CPU_NAME CONFIG_SYS_AUTOLOAD CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION CONFIG_SYS_AUXCORE_BOOTDATA @@ -1235,8 +891,6 @@ CONFIG_SYS_BAUDRATE_TABLE CONFIG_SYS_BCSR CONFIG_SYS_BFTIC3_BASE CONFIG_SYS_BFTIC3_SIZE -CONFIG_SYS_BITBANG_PHY_PORT -CONFIG_SYS_BITBANG_PHY_PORTS CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_CENA_SIZE CONFIG_SYS_BMAN_CINH_BASE @@ -1248,11 +902,9 @@ CONFIG_SYS_BMAN_NUM_PORTALS CONFIG_SYS_BMAN_SP_CENA_SIZE CONFIG_SYS_BMAN_SP_CINH_SIZE CONFIG_SYS_BMAN_SWP_ISDR_REG -CONFIG_SYS_BOARD_NAME CONFIG_SYS_BOOK3E_HV CONFIG_SYS_BOOTCOUNT_BE CONFIG_SYS_BOOTCOUNT_LE -CONFIG_SYS_BOOTFILE_PREFIX CONFIG_SYS_BOOTMAPSZ CONFIG_SYS_BOOTM_LEN CONFIG_SYS_BOOTPARAMS_LEN @@ -1261,15 +913,9 @@ CONFIG_SYS_BOOT_RAMDISK_HIGH CONFIG_SYS_CACHE_ACR0 CONFIG_SYS_CACHE_ACR1 CONFIG_SYS_CACHE_ACR2 -CONFIG_SYS_CACHE_ACR3 -CONFIG_SYS_CACHE_ACR4 -CONFIG_SYS_CACHE_ACR5 -CONFIG_SYS_CACHE_ACR6 -CONFIG_SYS_CACHE_ACR7 CONFIG_SYS_CACHE_DCACR CONFIG_SYS_CACHE_ICACR CONFIG_SYS_CACHE_STASHING -CONFIG_SYS_CADMUS_BASE_REG CONFIG_SYS_CBSIZE CONFIG_SYS_CCCR CONFIG_SYS_CCSRBAR @@ -1277,20 +923,10 @@ CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR_PHYS_HIGH CONFIG_SYS_CCSRBAR_PHYS_LOW CONFIG_SYS_CCSR_DO_NOT_RELOCATE -CONFIG_SYS_CFI_FLASH_CONFIG_REGS CONFIG_SYS_CFI_FLASH_STATUS_POLL -CONFIG_SYS_CF_INTC_REG1 -CONFIG_SYS_CH7301_I2C CONFIG_SYS_CKEN CONFIG_SYS_CLK CONFIG_SYS_CLKTL_CBCDR -CONFIG_SYS_CLK_FREQ_C100 -CONFIG_SYS_CLK_FREQ_C110 -CONFIG_SYS_CMD_CONFIGURE -CONFIG_SYS_CMD_EL -CONFIG_SYS_CMD_IAS -CONFIG_SYS_CMD_INT -CONFIG_SYS_CMD_SUSPEND CONFIG_SYS_CORE_SRAM CONFIG_SYS_CORE_SRAM_SIZE CONFIG_SYS_CPC_REINIT_F @@ -1305,7 +941,6 @@ CONFIG_SYS_CPLD_FTIM1 CONFIG_SYS_CPLD_FTIM2 CONFIG_SYS_CPLD_FTIM3 CONFIG_SYS_CPLD_SIZE -CONFIG_SYS_CPM_INTERRUPT CONFIG_SYS_CPRI CONFIG_SYS_CPRI_CLK CONFIG_SYS_CPUSPEED @@ -1339,50 +974,25 @@ CONFIG_SYS_CS3_FTIM1 CONFIG_SYS_CS3_FTIM2 CONFIG_SYS_CS3_FTIM3 CONFIG_SYS_CS3_MASK -CONFIG_SYS_CS4_BASE -CONFIG_SYS_CS4_CTRL CONFIG_SYS_CS4_FTIM0 CONFIG_SYS_CS4_FTIM1 CONFIG_SYS_CS4_FTIM2 CONFIG_SYS_CS4_FTIM3 -CONFIG_SYS_CS4_MASK -CONFIG_SYS_CS5_BASE -CONFIG_SYS_CS5_CTRL -CONFIG_SYS_CS5_FTIM0 -CONFIG_SYS_CS5_FTIM1 -CONFIG_SYS_CS5_FTIM2 -CONFIG_SYS_CS5_FTIM3 -CONFIG_SYS_CS5_MASK -CONFIG_SYS_CS6_BASE -CONFIG_SYS_CS6_CTRL CONFIG_SYS_CS6_FTIM0 CONFIG_SYS_CS6_FTIM1 CONFIG_SYS_CS6_FTIM2 CONFIG_SYS_CS6_FTIM3 -CONFIG_SYS_CS6_MASK -CONFIG_SYS_CS7_BASE -CONFIG_SYS_CS7_CTRL CONFIG_SYS_CS7_FTIM0 CONFIG_SYS_CS7_FTIM1 CONFIG_SYS_CS7_FTIM2 CONFIG_SYS_CS7_FTIM3 -CONFIG_SYS_CS7_MASK CONFIG_SYS_CSOR0 -CONFIG_SYS_CSOR0_EXT CONFIG_SYS_CSOR1 -CONFIG_SYS_CSOR1_EXT CONFIG_SYS_CSOR2 -CONFIG_SYS_CSOR2_EXT CONFIG_SYS_CSOR3 -CONFIG_SYS_CSOR3_EXT CONFIG_SYS_CSOR4 -CONFIG_SYS_CSOR4_EXT -CONFIG_SYS_CSOR5 -CONFIG_SYS_CSOR5_EXT CONFIG_SYS_CSOR6 -CONFIG_SYS_CSOR6_EXT CONFIG_SYS_CSOR7 -CONFIG_SYS_CSOR7_EXT CONFIG_SYS_CSPR0 CONFIG_SYS_CSPR0_EXT CONFIG_SYS_CSPR0_FINAL @@ -1397,8 +1007,6 @@ CONFIG_SYS_CSPR3_EXT CONFIG_SYS_CSPR3_FINAL CONFIG_SYS_CSPR4 CONFIG_SYS_CSPR4_EXT -CONFIG_SYS_CSPR5 -CONFIG_SYS_CSPR5_EXT CONFIG_SYS_CSPR6 CONFIG_SYS_CSPR6_EXT CONFIG_SYS_CSPR7 @@ -1411,32 +1019,14 @@ CONFIG_SYS_DA850_DDR2_SDRCR CONFIG_SYS_DA850_DDR2_SDTIMR CONFIG_SYS_DA850_DDR2_SDTIMR2 CONFIG_SYS_DA850_PLL0_PLLM -CONFIG_SYS_DA850_PLL0_PREDIV CONFIG_SYS_DA850_PLL1_PLLM CONFIG_SYS_DA850_SYSCFG_SUSPSRC -CONFIG_SYS_DAVINCI_EMAC_PHY_COUNT CONFIG_SYS_DAVINCI_I2C_SLAVE CONFIG_SYS_DAVINCI_I2C_SLAVE1 CONFIG_SYS_DAVINCI_I2C_SLAVE2 CONFIG_SYS_DAVINCI_I2C_SPEED CONFIG_SYS_DAVINCI_I2C_SPEED1 CONFIG_SYS_DAVINCI_I2C_SPEED2 -CONFIG_SYS_DBAT0L -CONFIG_SYS_DBAT0U -CONFIG_SYS_DBAT1L -CONFIG_SYS_DBAT1U -CONFIG_SYS_DBAT2L -CONFIG_SYS_DBAT2U -CONFIG_SYS_DBAT3L -CONFIG_SYS_DBAT3U -CONFIG_SYS_DBAT4L -CONFIG_SYS_DBAT4U -CONFIG_SYS_DBAT5L -CONFIG_SYS_DBAT5U -CONFIG_SYS_DBAT6L -CONFIG_SYS_DBAT6U -CONFIG_SYS_DBAT7L -CONFIG_SYS_DBAT7U CONFIG_SYS_DCACHE_INV CONFIG_SYS_DCSRBAR CONFIG_SYS_DCSRBAR_PHYS @@ -1444,18 +1034,8 @@ CONFIG_SYS_DCSR_COP_CCP_ADDR CONFIG_SYS_DCSR_DCFG_ADDR CONFIG_SYS_DCSR_DCFG_OFFSET CONFIG_SYS_DCU_ADDR -CONFIG_SYS_DDR2_CS0_BNDS -CONFIG_SYS_DDR2_CS0_CONFIG -CONFIG_SYS_DDR2_CS1_BNDS -CONFIG_SYS_DDR2_CS1_CONFIG -CONFIG_SYS_DDR2_CS2_BNDS -CONFIG_SYS_DDR2_CS2_CONFIG -CONFIG_SYS_DDR2_CS3_BNDS -CONFIG_SYS_DDR2_CS3_CONFIG CONFIG_SYS_DDRCDR CONFIG_SYS_DDRCDR_VALUE -CONFIG_SYS_DDRD -CONFIG_SYS_DDRTC CONFIG_SYS_DDRUA CONFIG_SYS_DDR_BLOCK1_SIZE CONFIG_SYS_DDR_BLOCK2_BASE @@ -1463,52 +1043,34 @@ CONFIG_SYS_DDR_CLKSEL CONFIG_SYS_DDR_CLK_CNTL CONFIG_SYS_DDR_CLK_CONTROL CONFIG_SYS_DDR_CLK_CTRL -CONFIG_SYS_DDR_CLK_CTRL_1000 -CONFIG_SYS_DDR_CLK_CTRL_1200 CONFIG_SYS_DDR_CLK_CTRL_667 CONFIG_SYS_DDR_CLK_CTRL_800 -CONFIG_SYS_DDR_CLK_CTRL_900 CONFIG_SYS_DDR_CONFIG CONFIG_SYS_DDR_CONFIG_2 CONFIG_SYS_DDR_CONFIG_256 CONFIG_SYS_DDR_CONTROL CONFIG_SYS_DDR_CONTROL_2 -CONFIG_SYS_DDR_CPO CONFIG_SYS_DDR_CS0_BNDS CONFIG_SYS_DDR_CS0_CONFIG CONFIG_SYS_DDR_CS0_CONFIG_2 CONFIG_SYS_DDR_CS1_BNDS CONFIG_SYS_DDR_CS1_CONFIG CONFIG_SYS_DDR_CS1_CONFIG_2 -CONFIG_SYS_DDR_CS2_BNDS -CONFIG_SYS_DDR_CS2_CONFIG -CONFIG_SYS_DDR_CS3_BNDS -CONFIG_SYS_DDR_CS3_CONFIG CONFIG_SYS_DDR_DATA_INIT CONFIG_SYS_DDR_INIT_ADDR CONFIG_SYS_DDR_INIT_EXT_ADDR CONFIG_SYS_DDR_INTERVAL -CONFIG_SYS_DDR_INTERVAL_1000 -CONFIG_SYS_DDR_INTERVAL_1200 CONFIG_SYS_DDR_INTERVAL_667 CONFIG_SYS_DDR_INTERVAL_800 -CONFIG_SYS_DDR_INTERVAL_900 CONFIG_SYS_DDR_MODE CONFIG_SYS_DDR_MODE2 CONFIG_SYS_DDR_MODE_1 -CONFIG_SYS_DDR_MODE_1_1000 -CONFIG_SYS_DDR_MODE_1_1200 CONFIG_SYS_DDR_MODE_1_667 CONFIG_SYS_DDR_MODE_1_800 -CONFIG_SYS_DDR_MODE_1_900 CONFIG_SYS_DDR_MODE_2 -CONFIG_SYS_DDR_MODE_2_1000 -CONFIG_SYS_DDR_MODE_2_1200 CONFIG_SYS_DDR_MODE_2_667 CONFIG_SYS_DDR_MODE_2_800 -CONFIG_SYS_DDR_MODE_2_900 CONFIG_SYS_DDR_MODE_CONTROL -CONFIG_SYS_DDR_MODE_WEAK CONFIG_SYS_DDR_RAW_TIMING CONFIG_SYS_DDR_RCW_1 CONFIG_SYS_DDR_RCW_2 @@ -1519,53 +1081,31 @@ CONFIG_SYS_DDR_SDRAM_CLK_CNTL CONFIG_SYS_DDR_SIZE CONFIG_SYS_DDR_SR_CNTR CONFIG_SYS_DDR_TIMING_0 -CONFIG_SYS_DDR_TIMING_0_1000 -CONFIG_SYS_DDR_TIMING_0_1200 CONFIG_SYS_DDR_TIMING_0_667 CONFIG_SYS_DDR_TIMING_0_800 -CONFIG_SYS_DDR_TIMING_0_900 CONFIG_SYS_DDR_TIMING_1 -CONFIG_SYS_DDR_TIMING_1_1000 -CONFIG_SYS_DDR_TIMING_1_1200 CONFIG_SYS_DDR_TIMING_1_667 CONFIG_SYS_DDR_TIMING_1_800 -CONFIG_SYS_DDR_TIMING_1_900 CONFIG_SYS_DDR_TIMING_2 -CONFIG_SYS_DDR_TIMING_2_1000 -CONFIG_SYS_DDR_TIMING_2_1200 CONFIG_SYS_DDR_TIMING_2_667 CONFIG_SYS_DDR_TIMING_2_800 -CONFIG_SYS_DDR_TIMING_2_900 CONFIG_SYS_DDR_TIMING_3 -CONFIG_SYS_DDR_TIMING_3_1000 -CONFIG_SYS_DDR_TIMING_3_1200 CONFIG_SYS_DDR_TIMING_3_667 CONFIG_SYS_DDR_TIMING_3_800 -CONFIG_SYS_DDR_TIMING_3_900 CONFIG_SYS_DDR_TIMING_4 CONFIG_SYS_DDR_TIMING_5 -CONFIG_SYS_DDR_WRITE_DATA_DELAY -CONFIG_SYS_DDR_WRLVL_CNTL CONFIG_SYS_DDR_WRLVL_CONTROL CONFIG_SYS_DDR_WRLVL_CONTROL_667 CONFIG_SYS_DDR_WRLVL_CONTROL_800 -CONFIG_SYS_DDR_ZQ_CNTL CONFIG_SYS_DDR_ZQ_CONTROL CONFIG_SYS_DEBUG CONFIG_SYS_DEBUG_SERVER_FW_ADDR CONFIG_SYS_DEBUG_SERVER_FW_IN_NOR CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS -CONFIG_SYS_DEFAULT_VIDEO_MODE CONFIG_SYS_DIALOG_PMIC_I2C_ADDR -CONFIG_SYS_DIMM_SLOTS_PER_CTLR -CONFIG_SYS_DIRECT_FLASH_NFS CONFIG_SYS_DIRECT_FLASH_TFTP CONFIG_SYS_DISCOVER_PHY CONFIG_SYS_DIU_ADDR -CONFIG_SYS_DP501_BASE -CONFIG_SYS_DP501_DIFFERENTIAL -CONFIG_SYS_DP501_I2C -CONFIG_SYS_DP501_VCAPCTRL0 CONFIG_SYS_DPAA_DCE CONFIG_SYS_DPAA_FMAN CONFIG_SYS_DPAA_PME @@ -1575,21 +1115,15 @@ CONFIG_SYS_DP_DDR_BASE_PHY CONFIG_SYS_DRAM_BASE CONFIG_SYS_DRAM_SIZE CONFIG_SYS_DRAM_TEST -CONFIG_SYS_DSPI_CS0 -CONFIG_SYS_DSPI_CS2 CONFIG_SYS_DSPI_CTAR0 CONFIG_SYS_DSPI_CTAR1 CONFIG_SYS_DSPI_CTAR2 CONFIG_SYS_DSPI_CTAR3 CONFIG_SYS_DV_NOR_BOOT_CFG -CONFIG_SYS_EBI_CFGR_VAL -CONFIG_SYS_EBI_CSA_VAL CONFIG_SYS_EEPROM_BUS_NUM CONFIG_SYS_EEPROM_PAGE_WRITE_ENABLE CONFIG_SYS_EEPROM_WREN CONFIG_SYS_EHCI_USB1_ADDR -CONFIG_SYS_ELO3_DMA3 -CONFIG_SYS_EMAC_TI_CLKDIV CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS CONFIG_SYS_ENET_BD_BASE CONFIG_SYS_ENV_ADDR @@ -1600,22 +1134,14 @@ CONFIG_SYS_ETVPE_CLK CONFIG_SYS_EXCEPTION_VECTORS_HIGH CONFIG_SYS_FAST_CLK CONFIG_SYS_FAULT_ECHO_LINK_DOWN -CONFIG_SYS_FAULT_MII_ADDR CONFIG_SYS_FDT_BASE CONFIG_SYS_FDT_PAD -CONFIG_SYS_FEC0_IOBASE -CONFIG_SYS_FEC1_IOBASE CONFIG_SYS_FECI2C CONFIG_SYS_FEC_BUF_USE_SRAM -CONFIG_SYS_FIXED_PHY_ADDR -CONFIG_SYS_FIXED_PHY_PORT -CONFIG_SYS_FIXED_PHY_PORTS CONFIG_SYS_FLASH0 CONFIG_SYS_FLASH1 CONFIG_SYS_FLASH1_BASE_PHYS CONFIG_SYS_FLASH1_BASE_PHYS_EARLY -CONFIG_SYS_FLASHBOOT -CONFIG_SYS_FLASH_AUTOPROTECT_LIST CONFIG_SYS_FLASH_BANKS_LIST CONFIG_SYS_FLASH_BANKS_SIZES CONFIG_SYS_FLASH_BASE @@ -1624,16 +1150,11 @@ CONFIG_SYS_FLASH_BASE1 CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE_PHYS_EARLY CONFIG_SYS_FLASH_BR_PRELIM -CONFIG_SYS_FLASH_CFI_AMD_RESET CONFIG_SYS_FLASH_CFI_NONBLOCK CONFIG_SYS_FLASH_CFI_WIDTH CONFIG_SYS_FLASH_CHECKSUM -CONFIG_SYS_FLASH_CHECK_BLANK_BEFORE_ERASE CONFIG_SYS_FLASH_EMPTY_INFO CONFIG_SYS_FLASH_ERASE_TOUT -CONFIG_SYS_FLASH_LEGACY_256Kx8 -CONFIG_SYS_FLASH_LEGACY_512Kx16 -CONFIG_SYS_FLASH_LEGACY_512Kx8 CONFIG_SYS_FLASH_LOCK_TOUT CONFIG_SYS_FLASH_OR_PRELIM CONFIG_SYS_FLASH_PARMSECT_SZ @@ -1642,12 +1163,10 @@ CONFIG_SYS_FLASH_SECT_SIZE CONFIG_SYS_FLASH_SECT_SZ CONFIG_SYS_FLASH_SIZE CONFIG_SYS_FLASH_UNLOCK_TOUT -CONFIG_SYS_FLASH_VERIFY_AFTER_WRITE CONFIG_SYS_FLASH_WRITE_TOUT CONFIG_SYS_FLYCNFG_VAL CONFIG_SYS_FM1_10GEC1_PHY_ADDR CONFIG_SYS_FM1_CLK -CONFIG_SYS_FM1_DTSEC1_MDIO_ADDR CONFIG_SYS_FM1_DTSEC1_PHY_ADDR CONFIG_SYS_FM1_DTSEC1_RISER_PHY_ADDR CONFIG_SYS_FM1_DTSEC2_PHY_ADDR @@ -1657,34 +1176,16 @@ CONFIG_SYS_FM1_DTSEC3_RISER_PHY_ADDR CONFIG_SYS_FM1_DTSEC4_PHY_ADDR CONFIG_SYS_FM1_DTSEC4_RISER_PHY_ADDR CONFIG_SYS_FM1_DTSEC5_PHY_ADDR -CONFIG_SYS_FM1_DTSEC_MDIO_ADDR CONFIG_SYS_FM1_QSGMII11_PHY_ADDR CONFIG_SYS_FM1_QSGMII21_PHY_ADDR -CONFIG_SYS_FM1_TGEC_MDIO_ADDR CONFIG_SYS_FM2_10GEC1_PHY_ADDR CONFIG_SYS_FM2_CLK CONFIG_SYS_FM2_DTSEC1_PHY_ADDR CONFIG_SYS_FM2_DTSEC2_PHY_ADDR CONFIG_SYS_FM2_DTSEC3_PHY_ADDR CONFIG_SYS_FM2_DTSEC4_PHY_ADDR -CONFIG_SYS_FM2_DTSEC_MDIO_ADDR -CONFIG_SYS_FM2_TGEC_MDIO_ADDR CONFIG_SYS_FMAN_V3 CONFIG_SYS_FM_MURAM_SIZE -CONFIG_SYS_FORM_3U_CPCI -CONFIG_SYS_FORM_3U_VPX -CONFIG_SYS_FORM_6U_CPCI -CONFIG_SYS_FORM_6U_VPX -CONFIG_SYS_FORM_AMC -CONFIG_SYS_FORM_ATCA_AMC -CONFIG_SYS_FORM_ATCA_PMC -CONFIG_SYS_FORM_CUSTOM -CONFIG_SYS_FORM_PCI -CONFIG_SYS_FORM_PCI_EXPRESS -CONFIG_SYS_FORM_PMC -CONFIG_SYS_FORM_PMC_XMC -CONFIG_SYS_FORM_VME -CONFIG_SYS_FORM_XMC CONFIG_SYS_FPGAREG_DATE CONFIG_SYS_FPGAREG_DIPSW CONFIG_SYS_FPGAREG_FREQ @@ -1692,10 +1193,6 @@ CONFIG_SYS_FPGAREG_RESET CONFIG_SYS_FPGAREG_RESET_CODE CONFIG_SYS_FPGA_AMASK CONFIG_SYS_FPGA_BASE -CONFIG_SYS_FPGA_CHECK_BUSY -CONFIG_SYS_FPGA_CHECK_CTRLC -CONFIG_SYS_FPGA_CHECK_ERROR -CONFIG_SYS_FPGA_COUNT CONFIG_SYS_FPGA_CSOR CONFIG_SYS_FPGA_CSPR CONFIG_SYS_FPGA_CSPR_EXT @@ -1703,25 +1200,15 @@ CONFIG_SYS_FPGA_FTIM0 CONFIG_SYS_FPGA_FTIM1 CONFIG_SYS_FPGA_FTIM2 CONFIG_SYS_FPGA_FTIM3 -CONFIG_SYS_FPGA_NO_RFL_HI CONFIG_SYS_FPGA_PROG_FEEDBACK -CONFIG_SYS_FPGA_PROG_TIME CONFIG_SYS_FPGA_SIZE CONFIG_SYS_FPGA_WAIT -CONFIG_SYS_FPGA_WAIT_BUSY -CONFIG_SYS_FPGA_WAIT_CONFIG -CONFIG_SYS_FPGA_WAIT_INIT -CONFIG_SYS_FSL_AIOP1_BASE -CONFIG_SYS_FSL_AIOP1_SIZE -CONFIG_SYS_FSL_B4860QDS_XFI_ERR CONFIG_SYS_FSL_BMAN_ADDR CONFIG_SYS_FSL_BMAN_OFFSET -CONFIG_SYS_FSL_CCSR_BASE CONFIG_SYS_FSL_CCSR_GUR_BE CONFIG_SYS_FSL_CCSR_GUR_LE CONFIG_SYS_FSL_CCSR_SCFG_BE CONFIG_SYS_FSL_CCSR_SCFG_LE -CONFIG_SYS_FSL_CCSR_SIZE CONFIG_SYS_FSL_CH3_CLK_CTRL_ADDR CONFIG_SYS_FSL_CH3_CLK_GRPA_ADDR CONFIG_SYS_FSL_CH3_CLK_GRPB_ADDR @@ -1758,28 +1245,19 @@ CONFIG_SYS_FSL_CPC_ADDR CONFIG_SYS_FSL_CPC_OFFSET CONFIG_SYS_FSL_CSU_ADDR CONFIG_SYS_FSL_DCFG_ADDR -CONFIG_SYS_FSL_DCSR_BASE CONFIG_SYS_FSL_DCSR_DDR2_ADDR CONFIG_SYS_FSL_DCSR_DDR3_ADDR CONFIG_SYS_FSL_DCSR_DDR4_ADDR CONFIG_SYS_FSL_DCSR_DDR_ADDR -CONFIG_SYS_FSL_DCSR_SIZE CONFIG_SYS_FSL_DCU_BE CONFIG_SYS_FSL_DCU_LE CONFIG_SYS_FSL_DDR2_ADDR -CONFIG_SYS_FSL_DDR3L CONFIG_SYS_FSL_DDR3_ADDR CONFIG_SYS_FSL_DDR_ADDR CONFIG_SYS_FSL_DDR_EMU CONFIG_SYS_FSL_DDR_INTLV_256B CONFIG_SYS_FSL_DDR_MAIN_NUM_CTRLS CONFIG_SYS_FSL_DDR_SDRAM_BASE_PHY -CONFIG_SYS_FSL_DRAM_BASE1 -CONFIG_SYS_FSL_DRAM_BASE2 -CONFIG_SYS_FSL_DRAM_BASE3 -CONFIG_SYS_FSL_DRAM_SIZE1 -CONFIG_SYS_FSL_DRAM_SIZE2 -CONFIG_SYS_FSL_DRAM_SIZE3 CONFIG_SYS_FSL_DSPI_BE CONFIG_SYS_FSL_DSP_CCSRBAR_DEFAULT CONFIG_SYS_FSL_DSP_CCSR_DDR_ADDR @@ -1788,7 +1266,6 @@ CONFIG_SYS_FSL_DSP_DDR_ADDR CONFIG_SYS_FSL_DSP_M2_RAM_ADDR CONFIG_SYS_FSL_DSP_M3_RAM_ADDR CONFIG_SYS_FSL_ERRATUM_A008751 -CONFIG_SYS_FSL_ERRATUM_A_004934 CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_FSL_ESDHC_BE CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT @@ -1796,7 +1273,6 @@ CONFIG_SYS_FSL_ESDHC_HAS_DDR_MODE CONFIG_SYS_FSL_ESDHC_LE CONFIG_SYS_FSL_ESDHC_NUM CONFIG_SYS_FSL_ESDHC_P1010_BROKEN_SDCLK -CONFIG_SYS_FSL_ESDHC_USE_PIO CONFIG_SYS_FSL_FM CONFIG_SYS_FSL_FM1_ADDR CONFIG_SYS_FSL_FM1_DTSEC1_ADDR @@ -1822,28 +1298,14 @@ CONFIG_SYS_FSL_FM2_RX4_1G_OFFSET CONFIG_SYS_FSL_FM2_RX5_1G_OFFSET CONFIG_SYS_FSL_FMAN_ADDR CONFIG_SYS_FSL_GUTS_ADDR -CONFIG_SYS_FSL_I2C -CONFIG_SYS_FSL_IFC_BASE -CONFIG_SYS_FSL_IFC_BASE1 -CONFIG_SYS_FSL_IFC_BASE2 CONFIG_SYS_FSL_IFC_BE CONFIG_SYS_FSL_IFC_LE -CONFIG_SYS_FSL_IFC_SIZE -CONFIG_SYS_FSL_IFC_SIZE1 -CONFIG_SYS_FSL_IFC_SIZE1_1 -CONFIG_SYS_FSL_IFC_SIZE2 CONFIG_SYS_FSL_ISBC_VER CONFIG_SYS_FSL_JR0_ADDR CONFIG_SYS_FSL_JR0_OFFSET CONFIG_SYS_FSL_LS1_CLK_ADDR CONFIG_SYS_FSL_LSCH3_SERDES_ADDR CONFIG_SYS_FSL_MAX_NUM_OF_SEC -CONFIG_SYS_FSL_MC9SDZ60_I2C_ADDR -CONFIG_SYS_FSL_MC_BASE -CONFIG_SYS_FSL_MC_SIZE -CONFIG_SYS_FSL_NI_BASE -CONFIG_SYS_FSL_NI_SIZE -CONFIG_SYS_FSL_NO_SERDES CONFIG_SYS_FSL_NUM_CC_PLL CONFIG_SYS_FSL_NUM_CC_PLLS CONFIG_SYS_FSL_OCRAM_BASE @@ -1852,26 +1314,16 @@ CONFIG_SYS_FSL_OTHER_DDR_NUM_CTRLS CONFIG_SYS_FSL_PAMU_OFFSET CONFIG_SYS_FSL_PCIE_COMPAT CONFIG_SYS_FSL_PCI_VER_3_X -CONFIG_SYS_FSL_PEBUF_BASE -CONFIG_SYS_FSL_PEBUF_SIZE CONFIG_SYS_FSL_PEX_LUT_BE CONFIG_SYS_FSL_PEX_LUT_LE CONFIG_SYS_FSL_PMIC_I2C_ADDR CONFIG_SYS_FSL_PMU_ADDR CONFIG_SYS_FSL_PMU_CLTBENR -CONFIG_SYS_FSL_QBMAN_BASE -CONFIG_SYS_FSL_QBMAN_SIZE -CONFIG_SYS_FSL_QBMAN_SIZE_1 CONFIG_SYS_FSL_QMAN_ADDR CONFIG_SYS_FSL_QMAN_OFFSET CONFIG_SYS_FSL_QMAN_V3 CONFIG_SYS_FSL_QSPI_BASE -CONFIG_SYS_FSL_QSPI_BASE1 -CONFIG_SYS_FSL_QSPI_BASE2 CONFIG_SYS_FSL_QSPI_LE -CONFIG_SYS_FSL_QSPI_SIZE -CONFIG_SYS_FSL_QSPI_SIZE1 -CONFIG_SYS_FSL_QSPI_SIZE2 CONFIG_SYS_FSL_RAID_ENGINE CONFIG_SYS_FSL_RAID_ENGINE_ADDR CONFIG_SYS_FSL_RAID_ENGINE_OFFSET @@ -1910,49 +1362,15 @@ CONFIG_SYS_FSL_SRIO_OFFSET CONFIG_SYS_FSL_SRK_LE CONFIG_SYS_FSL_TBCLK_DIV CONFIG_SYS_FSL_TIMER_ADDR -CONFIG_SYS_FSL_USB1_ADDR CONFIG_SYS_FSL_USB1_PHY_ENABLE -CONFIG_SYS_FSL_USB2_ADDR CONFIG_SYS_FSL_USB2_PHY_ENABLE -CONFIG_SYS_FSL_USB_CTRL_PHY_EN -CONFIG_SYS_FSL_USB_DRVVBUS_CR_EN CONFIG_SYS_FSL_USB_DUAL_PHY_ENABLE -CONFIG_SYS_FSL_USB_ENABLE_OVERRIDE -CONFIG_SYS_FSL_USB_HS_DISCNCT_INC -CONFIG_SYS_FSL_USB_INTERNAL_SOC_CLK_EN CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY -CONFIG_SYS_FSL_USB_PLLPRG1_PHY_DIV -CONFIG_SYS_FSL_USB_PLLPRG2_FRAC_LPF_EN -CONFIG_SYS_FSL_USB_PLLPRG2_MFI -CONFIG_SYS_FSL_USB_PLLPRG2_MFI_INTERNAL_CLK -CONFIG_SYS_FSL_USB_PLLPRG2_PHY1_CLK_EN -CONFIG_SYS_FSL_USB_PLLPRG2_PHY2_CLK_EN -CONFIG_SYS_FSL_USB_PLLPRG2_PLL_EN -CONFIG_SYS_FSL_USB_PLLPRG2_REF_DIV -CONFIG_SYS_FSL_USB_PLLPRG2_REF_DIV_INTERNAL_CLK -CONFIG_SYS_FSL_USB_PWRFLT_CR_EN -CONFIG_SYS_FSL_USB_RX_AUTO_CAL_RD_WR_SEL -CONFIG_SYS_FSL_USB_SQUELCH_PROG_MASK -CONFIG_SYS_FSL_USB_SQUELCH_PROG_RD_0 -CONFIG_SYS_FSL_USB_SQUELCH_PROG_RD_3 -CONFIG_SYS_FSL_USB_SQUELCH_PROG_WR_0 -CONFIG_SYS_FSL_USB_SQUELCH_PROG_WR_3 -CONFIG_SYS_FSL_USB_SYS_CLK_VALID -CONFIG_SYS_FSL_USB_XCVRPRG_HS_DCNT_PROG_EN -CONFIG_SYS_FSL_USB_XCVRPRG_HS_DCNT_PROG_MASK CONFIG_SYS_FSL_USDHC_NUM CONFIG_SYS_FSL_WDOG_BE CONFIG_SYS_FSL_WRIOP1_ADDR -CONFIG_SYS_FSL_WRIOP1_BASE CONFIG_SYS_FSL_WRIOP1_MDIO1 CONFIG_SYS_FSL_WRIOP1_MDIO2 -CONFIG_SYS_FSL_WRIOP1_SIZE -CONFIG_SYS_FSL_XHCI_USB1_ADDR -CONFIG_SYS_FSL_XHCI_USB2_ADDR -CONFIG_SYS_FSL_XHCI_USB3_ADDR -CONFIG_SYS_FSMC_BASE -CONFIG_SYS_FSMC_NAND_16BIT -CONFIG_SYS_FSMC_NAND_8BIT CONFIG_SYS_FTAHBC020S_SLAVE_BSR_6 CONFIG_SYS_FTAHBC020S_SLAVE_BSR_BASE CONFIG_SYS_FTPMU010_PDLLCR0_HCLKOUTDIS @@ -1989,16 +1407,10 @@ CONFIG_SYS_GPDR0_VAL CONFIG_SYS_GPDR1_VAL CONFIG_SYS_GPDR2_VAL CONFIG_SYS_GPDR3_VAL -CONFIG_SYS_GPIO1_DAT -CONFIG_SYS_GPIO1_DIR CONFIG_SYS_GPIO1_EN CONFIG_SYS_GPIO1_FUNC CONFIG_SYS_GPIO1_LED CONFIG_SYS_GPIO1_OUT -CONFIG_SYS_GPIO1_PRELIM -CONFIG_SYS_GPIO2_DAT -CONFIG_SYS_GPIO2_DIR -CONFIG_SYS_GPIO2_PRELIM CONFIG_SYS_GPIO_EN CONFIG_SYS_GPIO_FUNC CONFIG_SYS_GPIO_OUT @@ -2008,29 +1420,9 @@ CONFIG_SYS_GPSR1_VAL CONFIG_SYS_GPSR2_VAL CONFIG_SYS_GPSR3_VAL CONFIG_SYS_HALT_BEFOR_RAM_JUMP -CONFIG_SYS_HELP_CMD_WIDTH -CONFIG_SYS_HIGH CONFIG_SYS_HMI_BASE -CONFIG_SYS_HRCW_HIGH -CONFIG_SYS_HRCW_LOW CONFIG_SYS_HZ_CLOCK -CONFIG_SYS_I2C2_FSL_OFFSET -CONFIG_SYS_I2C2_OFFSET -CONFIG_SYS_I2C2_PINMUX_CLR -CONFIG_SYS_I2C2_PINMUX_REG -CONFIG_SYS_I2C2_PINMUX_SET -CONFIG_SYS_I2C_0 -CONFIG_SYS_I2C_2 -CONFIG_SYS_I2C_5 -CONFIG_SYS_I2C_BASE0 -CONFIG_SYS_I2C_BASE1 -CONFIG_SYS_I2C_BASE2 -CONFIG_SYS_I2C_BASE3 -CONFIG_SYS_I2C_BASE4 -CONFIG_SYS_I2C_BASE5 CONFIG_SYS_I2C_BUSES -CONFIG_SYS_I2C_CLK_OFFSET -CONFIG_SYS_I2C_DIRECT_BUS CONFIG_SYS_I2C_DVI_ADDR CONFIG_SYS_I2C_DVI_BUS_NUM CONFIG_SYS_I2C_EEPROM_CCID @@ -2039,13 +1431,10 @@ CONFIG_SYS_I2C_EEPROM_PAGE_WRITE_BITS CONFIG_SYS_I2C_EEPROM_PAGE_WRITE_DELAY_MS CONFIG_SYS_I2C_EXPANDER_ADDR CONFIG_SYS_I2C_FPGA_ADDR -CONFIG_SYS_I2C_FRAM CONFIG_SYS_I2C_G762_ADDR CONFIG_SYS_I2C_IFDR_DIV CONFIG_SYS_I2C_INIT_BOARD CONFIG_SYS_I2C_LDI_ADDR -CONFIG_SYS_I2C_LPC32XX_SLAVE -CONFIG_SYS_I2C_LPC32XX_SPEED CONFIG_SYS_I2C_MAX_HOPS CONFIG_SYS_I2C_NOPROBES CONFIG_SYS_I2C_PCA953X_ADDR @@ -2059,24 +1448,7 @@ CONFIG_SYS_I2C_QIXIS_ADDR CONFIG_SYS_I2C_RTC_ADDR CONFIG_SYS_I2C_TCA642X_ADDR CONFIG_SYS_I2C_TCA642X_BUS_NUM -CONFIG_SYS_IBAT0L -CONFIG_SYS_IBAT0U -CONFIG_SYS_IBAT1L -CONFIG_SYS_IBAT1U -CONFIG_SYS_IBAT2L -CONFIG_SYS_IBAT2U -CONFIG_SYS_IBAT3L -CONFIG_SYS_IBAT3U -CONFIG_SYS_IBAT4L -CONFIG_SYS_IBAT4U -CONFIG_SYS_IBAT5L -CONFIG_SYS_IBAT5U -CONFIG_SYS_IBAT6L -CONFIG_SYS_IBAT6U -CONFIG_SYS_IBAT7L -CONFIG_SYS_IBAT7U CONFIG_SYS_ICACHE_INV -CONFIG_SYS_ICS8N3QV01_I2C CONFIG_SYS_IDE_MAXBUS CONFIG_SYS_IDE_MAXDEVICE CONFIG_SYS_IFC_ADDR @@ -2101,18 +1473,14 @@ CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_INPUT_CLKSRC CONFIG_SYS_INTERLAKEN -CONFIG_SYS_INTR_BASE CONFIG_SYS_INT_FLASH_BASE CONFIG_SYS_INT_FLASH_ENABLE CONFIG_SYS_IO_BASE -CONFIG_SYS_ISA_BASE CONFIG_SYS_ISA_IO CONFIG_SYS_ISA_IO_BASE_ADDRESS -CONFIG_SYS_ISA_MEM CONFIG_SYS_JFFS2_FIRST_BANK CONFIG_SYS_JFFS2_FIRST_SECTOR CONFIG_SYS_JFFS2_NUM_BANKS -CONFIG_SYS_JFFS2_SORT_FRAGMENTS CONFIG_SYS_KMBEC_FPGA_BASE CONFIG_SYS_KMBEC_FPGA_SIZE CONFIG_SYS_KWD_CONFIG @@ -2139,27 +1507,20 @@ CONFIG_SYS_LBC_SDRAM_SIZE CONFIG_SYS_LDB_CLOCK CONFIG_SYS_LIME_BASE CONFIG_SYS_LIME_SIZE -CONFIG_SYS_LINUX_LOWMEM_MAX_SIZE CONFIG_SYS_LOADS_BAUD_CHANGE CONFIG_SYS_LOW CONFIG_SYS_LOWMEM_BASE -CONFIG_SYS_LOW_RES_TIMER CONFIG_SYS_LPAE_SDRAM_BASE CONFIG_SYS_LS1_DDR_BLOCK1_SIZE CONFIG_SYS_LS_MC_AIOP_IMG_MAX_LENGTH CONFIG_SYS_LS_MC_BOOT_TIMEOUT_MS -CONFIG_SYS_LS_MC_DPC_IN_DDR CONFIG_SYS_LS_MC_DPC_MAX_LENGTH -CONFIG_SYS_LS_MC_DPL_IN_DDR CONFIG_SYS_LS_MC_DPL_MAX_LENGTH CONFIG_SYS_LS_MC_DRAM_AIOP_IMG_OFFSET CONFIG_SYS_LS_MC_DRAM_BLOCK_MIN_SIZE CONFIG_SYS_LS_MC_DRAM_DPC_OFFSET CONFIG_SYS_LS_MC_DRAM_DPL_OFFSET -CONFIG_SYS_LS_MC_FW_IN_DDR -CONFIG_SYS_LS_PPA_FW_IN_xxx CONFIG_SYS_M41T11_BASE_YEAR -CONFIG_SYS_M41T11_EXT_CENTURY_DATA CONFIG_SYS_MAIN_PWR_ON CONFIG_SYS_MALLOC_SIMPLE CONFIG_SYS_MAMR @@ -2168,7 +1529,6 @@ CONFIG_SYS_MAPPED_RAM_BASE CONFIG_SYS_MASTER_CLOCK CONFIG_SYS_MATRIX_EBI0CSA_VAL CONFIG_SYS_MATRIX_EBICSA_VAL -CONFIG_SYS_MATRIX_MCFG_REMAP CONFIG_SYS_MAXARGS CONFIG_SYS_MAX_FLASH_BANKS CONFIG_SYS_MAX_FLASH_BANKS_DETECT @@ -2176,39 +1536,32 @@ CONFIG_SYS_MAX_FLASH_SECT CONFIG_SYS_MAX_I2C_BUS CONFIG_SYS_MAX_NAND_CHIPS CONFIG_SYS_MAX_NAND_DEVICE -CONFIG_SYS_MAX_PCI_EPS CONFIG_SYS_MBAR CONFIG_SYS_MBAR2 CONFIG_SYS_MCATT0_VAL CONFIG_SYS_MCATT1_VAL CONFIG_SYS_MCFRRTC_BASE -CONFIG_SYS_MCFRTC_BASE -CONFIG_SYS_MCF_SYNCR CONFIG_SYS_MCIO0_VAL CONFIG_SYS_MCIO1_VAL CONFIG_SYS_MCKR CONFIG_SYS_MCKR1_VAL CONFIG_SYS_MCKR2_VAL CONFIG_SYS_MCKR_CSS -CONFIG_SYS_MCKR_VAL CONFIG_SYS_MCMEM0_VAL CONFIG_SYS_MCMEM1_VAL CONFIG_SYS_MDCNFG_VAL CONFIG_SYS_MDIO1_OFFSET -CONFIG_SYS_MDIO_BASE_ADDR CONFIG_SYS_MDMRS_VAL CONFIG_SYS_MDREFR_VAL CONFIG_SYS_MECR_VAL CONFIG_SYS_MEMAC_LITTLE_ENDIAN CONFIG_SYS_MEMORY_BASE CONFIG_SYS_MEMORY_SIZE -CONFIG_SYS_MEM_MAP CONFIG_SYS_MEM_RESERVE_SECURE CONFIG_SYS_MEM_SIZE CONFIG_SYS_MEM_TOP_HIDE CONFIG_SYS_MFD CONFIG_SYS_MHZ -CONFIG_SYS_MII_MODE CONFIG_SYS_MIPS_TIMER_FREQ CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS @@ -2231,8 +1584,6 @@ CONFIG_SYS_MPC83xx_ESDHC_ADDR CONFIG_SYS_MPC83xx_ESDHC_OFFSET CONFIG_SYS_MPC83xx_USB1_ADDR CONFIG_SYS_MPC83xx_USB1_OFFSET -CONFIG_SYS_MPC83xx_USB2_ADDR -CONFIG_SYS_MPC83xx_USB2_OFFSET CONFIG_SYS_MPC85XX_NO_RESETVEC CONFIG_SYS_MPC85xx_CPM_ADDR CONFIG_SYS_MPC85xx_CPM_OFFSET @@ -2293,42 +1644,24 @@ CONFIG_SYS_MPC85xx_USB2_PHY_OFFSET CONFIG_SYS_MPC8xxx_DDR2_OFFSET CONFIG_SYS_MPC8xxx_DDR3_OFFSET CONFIG_SYS_MPC8xxx_DDR_OFFSET -CONFIG_SYS_MPC8xxx_GUTS_ADDR CONFIG_SYS_MPC8xxx_PIC_ADDR -CONFIG_SYS_MPC92469AC CONFIG_SYS_MRAM_BASE CONFIG_SYS_MRAM_SIZE CONFIG_SYS_MSC0_VAL CONFIG_SYS_MSC1_VAL CONFIG_SYS_MSC2_VAL -CONFIG_SYS_MX5_CLK32 -CONFIG_SYS_MX5_HCLK -CONFIG_SYS_MX6_CLK32 -CONFIG_SYS_MX6_HCLK -CONFIG_SYS_MX7_CLK32 -CONFIG_SYS_MX7_HCLK -CONFIG_SYS_MXS_VDD5V_ONLY CONFIG_SYS_NAND_4BIT_HW_ECC_OOBFIRST -CONFIG_SYS_NAND_ACTL_ALE -CONFIG_SYS_NAND_ACTL_CLE -CONFIG_SYS_NAND_ACTL_DELAY -CONFIG_SYS_NAND_ACTL_NCE -CONFIG_SYS_NAND_ALE CONFIG_SYS_NAND_AMASK CONFIG_SYS_NAND_BASE CONFIG_SYS_NAND_BASE2 CONFIG_SYS_NAND_BASE_LIST CONFIG_SYS_NAND_BASE_PHYS -CONFIG_SYS_NAND_BOOT CONFIG_SYS_NAND_BR_PRELIM -CONFIG_SYS_NAND_BUSWIDTH_16 -CONFIG_SYS_NAND_CLE CONFIG_SYS_NAND_CS CONFIG_SYS_NAND_CSOR CONFIG_SYS_NAND_CSPR CONFIG_SYS_NAND_CSPR_EXT CONFIG_SYS_NAND_DATA_BASE -CONFIG_SYS_NAND_DBW_16 CONFIG_SYS_NAND_DBW_8 CONFIG_SYS_NAND_DDR_LAW CONFIG_SYS_NAND_ECCBYTES @@ -2346,8 +1679,6 @@ CONFIG_SYS_NAND_FTIM3 CONFIG_SYS_NAND_HW_ECC CONFIG_SYS_NAND_HW_ECC_OOBFIRST CONFIG_SYS_NAND_LARGEPAGE -CONFIG_SYS_NAND_LBLAWAR_PRELIM -CONFIG_SYS_NAND_LBLAWBAR_PRELIM CONFIG_SYS_NAND_MASK_ALE CONFIG_SYS_NAND_MASK_CLE CONFIG_SYS_NAND_MAX_ECCPOS @@ -2357,10 +1688,8 @@ CONFIG_SYS_NAND_NO_SUBPAGE_WRITE CONFIG_SYS_NAND_OR_PRELIM CONFIG_SYS_NAND_PAGE_2K CONFIG_SYS_NAND_PAGE_4K -CONFIG_SYS_NAND_QUIET CONFIG_SYS_NAND_READY_PIN CONFIG_SYS_NAND_REGS_BASE -CONFIG_SYS_NAND_SELECT_DEVICE CONFIG_SYS_NAND_SIZE CONFIG_SYS_NAND_SPL_KERNEL_OFFS CONFIG_SYS_NAND_U_BOOT_DST @@ -2384,14 +1713,12 @@ CONFIG_SYS_NOR_FTIM1 CONFIG_SYS_NOR_FTIM2 CONFIG_SYS_NOR_FTIM3 CONFIG_SYS_NS16550_CLK -CONFIG_SYS_NS16550_CLK_DIV CONFIG_SYS_NS16550_COM1 CONFIG_SYS_NS16550_COM2 CONFIG_SYS_NS16550_COM3 CONFIG_SYS_NS16550_COM4 CONFIG_SYS_NS16550_COM5 CONFIG_SYS_NS16550_COM6 -CONFIG_SYS_NS16550_IER CONFIG_SYS_NS16550_MEM32 CONFIG_SYS_NS16550_PORT_MAPPED CONFIG_SYS_NS16550_REG_SIZE @@ -2403,22 +1730,15 @@ CONFIG_SYS_NUM_FM2_10GEC CONFIG_SYS_NUM_FM2_DTSEC CONFIG_SYS_NUM_FMAN CONFIG_SYS_NUM_I2C_BUSES -CONFIG_SYS_NUM_IRQS -CONFIG_SYS_NVRAM_ACCESS_ROUTINE CONFIG_SYS_NVRAM_BASE_ADDR CONFIG_SYS_NVRAM_SIZE CONFIG_SYS_OBIR -CONFIG_SYS_OHCI_BE_CONTROLLER CONFIG_SYS_OHCI_SWAP_REG_ACCESS CONFIG_SYS_OMAP_ABE_SYSCK CONFIG_SYS_ONENAND_BASE CONFIG_SYS_ONENAND_BLOCK_SIZE -CONFIG_SYS_ONENAND_PAGE_SIZE -CONFIG_SYS_OR0_REMAP -CONFIG_SYS_OR1_REMAP CONFIG_SYS_OR_TIMING_MRAM CONFIG_SYS_OSCIN_FREQ -CONFIG_SYS_OSD_DH CONFIG_SYS_OSPR_OFFSET CONFIG_SYS_PACNT CONFIG_SYS_PADAT @@ -2434,7 +1754,6 @@ CONFIG_SYS_PBDDR CONFIG_SYS_PBI_FLASH_BASE CONFIG_SYS_PBI_FLASH_WINDOW CONFIG_SYS_PBSIZE -CONFIG_SYS_PCA953X_NVM_WP CONFIG_SYS_PCCNT CONFIG_SYS_PCDAT CONFIG_SYS_PCDDR @@ -2451,7 +1770,6 @@ CONFIG_SYS_PCI1_MEM_PHYS CONFIG_SYS_PCI1_MEM_SIZE CONFIG_SYS_PCI1_MEM_VIRT CONFIG_SYS_PCI2_ADDR -CONFIG_SYS_PCI64_MEMORY_BUS CONFIG_SYS_PCIE CONFIG_SYS_PCIE1_ADDR CONFIG_SYS_PCIE1_BASE @@ -2468,7 +1786,6 @@ CONFIG_SYS_PCIE1_MEM_VIRT CONFIG_SYS_PCIE1_NAME CONFIG_SYS_PCIE1_PHYS_ADDR CONFIG_SYS_PCIE1_PHYS_BASE -CONFIG_SYS_PCIE1_PHYS_SIZE CONFIG_SYS_PCIE1_VIRT_ADDR CONFIG_SYS_PCIE2_ADDR CONFIG_SYS_PCIE2_BASE @@ -2485,7 +1802,6 @@ CONFIG_SYS_PCIE2_MEM_VIRT CONFIG_SYS_PCIE2_NAME CONFIG_SYS_PCIE2_PHYS_ADDR CONFIG_SYS_PCIE2_PHYS_BASE -CONFIG_SYS_PCIE2_PHYS_SIZE CONFIG_SYS_PCIE2_VIRT_ADDR CONFIG_SYS_PCIE3_ADDR CONFIG_SYS_PCIE3_IO_PHYS @@ -2503,66 +1819,32 @@ CONFIG_SYS_PCIE4_MEM_PHYS CONFIG_SYS_PCIE4_MEM_VIRT CONFIG_SYS_PCIE4_NAME CONFIG_SYS_PCIE4_PHYS_ADDR -CONFIG_SYS_PCIE4_PHYS_SIZE CONFIG_SYS_PCIE_MMAP_SIZE -CONFIG_SYS_PCI_BAR0 -CONFIG_SYS_PCI_BAR1 -CONFIG_SYS_PCI_BAR2 -CONFIG_SYS_PCI_BAR3 -CONFIG_SYS_PCI_BAR4 -CONFIG_SYS_PCI_BAR5 -CONFIG_SYS_PCI_CACHE_LINE_SIZE -CONFIG_SYS_PCI_CFG_PHYS -CONFIG_SYS_PCI_EP_MEMORY_BASE CONFIG_SYS_PCI_IO_BASE -CONFIG_SYS_PCI_IO_BUS CONFIG_SYS_PCI_IO_PHYS CONFIG_SYS_PCI_IO_SIZE CONFIG_SYS_PCI_MAP_END CONFIG_SYS_PCI_MAP_START -CONFIG_SYS_PCI_MEMORY_BUS -CONFIG_SYS_PCI_MEMORY_PHYS -CONFIG_SYS_PCI_MEMORY_SIZE CONFIG_SYS_PCI_MEM_BASE -CONFIG_SYS_PCI_MEM_BUS CONFIG_SYS_PCI_MEM_PHYS CONFIG_SYS_PCI_MEM_SIZE CONFIG_SYS_PCI_MMIO_BASE CONFIG_SYS_PCI_MMIO_PHYS CONFIG_SYS_PCI_MMIO_SIZE -CONFIG_SYS_PCI_NR_INBOUND_WIN CONFIG_SYS_PCI_SLV_MEM_BUS CONFIG_SYS_PCI_SLV_MEM_LOCAL CONFIG_SYS_PCI_SLV_MEM_SIZE -CONFIG_SYS_PCI_SYS_MEM_BUS -CONFIG_SYS_PCI_SYS_MEM_PHYS -CONFIG_SYS_PCI_SYS_MEM_SIZE -CONFIG_SYS_PCI_TBATR0 -CONFIG_SYS_PCI_TBATR1 -CONFIG_SYS_PCI_TBATR2 -CONFIG_SYS_PCI_TBATR3 -CONFIG_SYS_PCI_TBATR4 -CONFIG_SYS_PCI_TBATR5 CONFIG_SYS_PDCNT CONFIG_SYS_PEHLPAR -CONFIG_SYS_PEPAR -CONFIG_SYS_PFPAR -CONFIG_SYS_PHY_UBOOT_BASE -CONFIG_SYS_PIOC_ASR_VAL -CONFIG_SYS_PIOC_BSR_VAL CONFIG_SYS_PIOC_PDR_VAL CONFIG_SYS_PIOC_PDR_VAL1 CONFIG_SYS_PIOC_PPUDR_VAL CONFIG_SYS_PIOD_PDR_VAL1 CONFIG_SYS_PIOD_PPUDR_VAL CONFIG_SYS_PIO_MODE -CONFIG_SYS_PIXIS_VBOOT_ENABLE -CONFIG_SYS_PIXIS_VBOOT_MASK -CONFIG_SYS_PIXIS_VCFGEN0_ENABLE CONFIG_SYS_PJPAR CONFIG_SYS_PL310_BASE CONFIG_SYS_PLLAR_VAL -CONFIG_SYS_PLLBR_VAL CONFIG_SYS_PLLCR CONFIG_SYS_PLL_BYPASS CONFIG_SYS_PLL_FDR @@ -2572,44 +1854,9 @@ CONFIG_SYS_PMAN CONFIG_SYS_PMC_BASE CONFIG_SYS_PMC_BASE_PHYS CONFIG_SYS_PME_CLK -CONFIG_SYS_PORTTC -CONFIG_SYS_POST_BSPEC1 -CONFIG_SYS_POST_BSPEC2 -CONFIG_SYS_POST_BSPEC3 -CONFIG_SYS_POST_BSPEC4 -CONFIG_SYS_POST_BSPEC5 -CONFIG_SYS_POST_CACHE -CONFIG_SYS_POST_CODEC -CONFIG_SYS_POST_COPROC -CONFIG_SYS_POST_CPU -CONFIG_SYS_POST_DSP -CONFIG_SYS_POST_ECC -CONFIG_SYS_POST_ETHER -CONFIG_SYS_POST_FLASH -CONFIG_SYS_POST_FLASH_END -CONFIG_SYS_POST_FLASH_NUM -CONFIG_SYS_POST_FLASH_START -CONFIG_SYS_POST_FPU -CONFIG_SYS_POST_HOTKEYS_GPIO -CONFIG_SYS_POST_I2C -CONFIG_SYS_POST_I2C_ADDRS -CONFIG_SYS_POST_I2C_IGNORES CONFIG_SYS_POST_MEMORY CONFIG_SYS_POST_MEM_REGIONS -CONFIG_SYS_POST_OCM -CONFIG_SYS_POST_RTC -CONFIG_SYS_POST_SPR -CONFIG_SYS_POST_SYSMON -CONFIG_SYS_POST_UART -CONFIG_SYS_POST_USB -CONFIG_SYS_POST_WATCHDOG -CONFIG_SYS_POST_WORD_ADDR -CONFIG_SYS_PPC_DDR_WIMGE -CONFIG_SYS_PQSPAR -CONFIG_SYS_PSDPAR CONFIG_SYS_PSSR_VAL -CONFIG_SYS_PTCPAR -CONFIG_SYS_PTDPAR CONFIG_SYS_PTV CONFIG_SYS_PUAPAR CONFIG_SYS_QMAN_CENA_BASE @@ -2630,10 +1877,8 @@ CONFIG_SYS_RCAR_I2C0_BASE CONFIG_SYS_RCAR_I2C1_BASE CONFIG_SYS_RCAR_I2C2_BASE CONFIG_SYS_RCAR_I2C3_BASE -CONFIG_SYS_READ_SPD CONFIG_SYS_RESET_ADDR CONFIG_SYS_RESET_ADDRESS -CONFIG_SYS_RESET_SCTRL CONFIG_SYS_RFD CONFIG_SYS_RGMII1_PHY_ADDR CONFIG_SYS_RGMII2_PHY_ADDR @@ -2645,8 +1890,6 @@ CONFIG_SYS_ROM_BASE CONFIG_SYS_RSTC_RMR_VAL CONFIG_SYS_RTC_BUS_NUM CONFIG_SYS_RTC_CNT -CONFIG_SYS_RTC_OSCILLATOR -CONFIG_SYS_RTC_REG_BASE_ADDR CONFIG_SYS_RTC_SETUP CONFIG_SYS_RX_ETH_BUFFER CONFIG_SYS_SATA @@ -2656,45 +1899,22 @@ CONFIG_SYS_SATA1_OFFSET CONFIG_SYS_SATA2 CONFIG_SYS_SATA2_FLAGS CONFIG_SYS_SATA2_OFFSET -CONFIG_SYS_SATA_ENV_DEV CONFIG_SYS_SATA_FAT_BOOT_PARTITION CONFIG_SYS_SATA_MAX_DEVICE CONFIG_SYS_SBFHDR_DATA_OFFSET CONFIG_SYS_SBFHDR_SIZE -CONFIG_SYS_SCCR_ENCCM -CONFIG_SYS_SCCR_PCICM -CONFIG_SYS_SCCR_PCIEXP1CM -CONFIG_SYS_SCCR_PCIEXP2CM CONFIG_SYS_SCCR_SATACM CONFIG_SYS_SCCR_TSEC1CM -CONFIG_SYS_SCCR_TSEC1ON CONFIG_SYS_SCCR_TSEC2CM -CONFIG_SYS_SCCR_TSEC2ON -CONFIG_SYS_SCCR_TSECCM CONFIG_SYS_SCCR_USBDRCM -CONFIG_SYS_SCCR_USBMPHCM CONFIG_SYS_SCR CONFIG_SYS_SCSI_MAX_DEVICE CONFIG_SYS_SCSI_MAX_LUN CONFIG_SYS_SCSI_MAX_SCSI_ID -CONFIG_SYS_SDIO0 -CONFIG_SYS_SDIO0_MAX_CLK -CONFIG_SYS_SDIO1 -CONFIG_SYS_SDIO1_MAX_CLK -CONFIG_SYS_SDIO2 -CONFIG_SYS_SDIO2_MAX_CLK -CONFIG_SYS_SDIO3 -CONFIG_SYS_SDIO3_MAX_CLK -CONFIG_SYS_SDIO_BASE0 -CONFIG_SYS_SDIO_BASE1 -CONFIG_SYS_SDIO_BASE2 -CONFIG_SYS_SDIO_BASE3 CONFIG_SYS_SDRAM -CONFIG_SYS_SDRAM1 CONFIG_SYS_SDRAM_BASE CONFIG_SYS_SDRAM_BASE0 CONFIG_SYS_SDRAM_BASE1 -CONFIG_SYS_SDRAM_BASE1xx CONFIG_SYS_SDRAM_BASE2 CONFIG_SYS_SDRAM_CFG CONFIG_SYS_SDRAM_CFG1 @@ -2704,7 +1924,6 @@ CONFIG_SYS_SDRAM_EMOD CONFIG_SYS_SDRAM_MODE CONFIG_SYS_SDRAM_SIZE CONFIG_SYS_SDRAM_SIZE0 -CONFIG_SYS_SDRAM_SIZE1 CONFIG_SYS_SDRAM_SIZE_LAW CONFIG_SYS_SDRAM_VAL CONFIG_SYS_SDRAM_VAL1 @@ -2753,13 +1972,10 @@ CONFIG_SYS_SH_SDHI3_BASE CONFIG_SYS_SH_SDHI_NR_CHANNEL CONFIG_SYS_SICRH CONFIG_SYS_SICRL -CONFIG_SYS_SIL1178_I2C CONFIG_SYS_SMC0_CYCLE0_VAL CONFIG_SYS_SMC0_MODE0_VAL CONFIG_SYS_SMC0_PULSE0_VAL CONFIG_SYS_SMC0_SETUP0_VAL -CONFIG_SYS_SMC_CSR0_VAL -CONFIG_SYS_SPCR_OPT CONFIG_SYS_SPD_BUS_NUM CONFIG_SYS_SPI_ARGS_OFFS CONFIG_SYS_SPI_ARGS_SIZE @@ -2770,8 +1986,6 @@ CONFIG_SYS_SPI_FLASH_U_BOOT_OFFS CONFIG_SYS_SPI_FLASH_U_BOOT_SIZE CONFIG_SYS_SPI_FLASH_U_BOOT_START CONFIG_SYS_SPI_KERNEL_OFFS -CONFIG_SYS_SPI_MXC_WAIT -CONFIG_SYS_SPI_RTC_DEVID CONFIG_SYS_SPI_ST_ENABLE_WP_PIN CONFIG_SYS_SPI_U_BOOT_SIZE CONFIG_SYS_SPL_ARGS_ADDR @@ -2793,8 +2007,6 @@ CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR_PHYS CONFIG_SYS_SST_SECT CONFIG_SYS_SST_SECTSZ CONFIG_SYS_STACK_SIZE -CONFIG_SYS_STATUS_C -CONFIG_SYS_STATUS_OK CONFIG_SYS_SXCNFG_VAL CONFIG_SYS_TBIPA_VALUE CONFIG_SYS_TCLK @@ -2802,30 +2014,17 @@ CONFIG_SYS_TIMERBASE CONFIG_SYS_TIMER_BASE CONFIG_SYS_TIMER_COUNTER CONFIG_SYS_TIMER_COUNTS_DOWN -CONFIG_SYS_TIMER_PRESCALER CONFIG_SYS_TIMER_RATE CONFIG_SYS_TMPVIRT -CONFIG_SYS_TMRINTR_MASK -CONFIG_SYS_TMRINTR_NO -CONFIG_SYS_TMRINTR_PEND -CONFIG_SYS_TMRINTR_PRI -CONFIG_SYS_TMRPND_REG -CONFIG_SYS_TMR_BASE CONFIG_SYS_TSEC1_OFFSET CONFIG_SYS_TSEC2_OFFSET CONFIG_SYS_TSEC3_OFFSET CONFIG_SYS_TX_ETH_BUFFER -CONFIG_SYS_UART1_ALT1_GPIO -CONFIG_SYS_UART2_ALT1_GPIO CONFIG_SYS_UART2_ALT3_GPIO -CONFIG_SYS_UART2_PRI_GPIO -CONFIG_SYS_UART_BASE CONFIG_SYS_UART_PORT CONFIG_SYS_UBOOT_BASE CONFIG_SYS_UBOOT_START -CONFIG_SYS_UDELAY_BASE CONFIG_SYS_UEC -CONFIG_SYS_UEC1_PHY_ADDR CONFIG_SYS_UEC2_ETH_TYPE CONFIG_SYS_UEC2_INTERFACE_SPEED CONFIG_SYS_UEC2_INTERFACE_TYPE @@ -2833,13 +2032,8 @@ CONFIG_SYS_UEC2_PHY_ADDR CONFIG_SYS_UEC2_RX_CLK CONFIG_SYS_UEC2_TX_CLK CONFIG_SYS_UEC2_UCC_NUM -CONFIG_SYS_UEC3_PHY_ADDR -CONFIG_SYS_UEC4_PHY_ADDR -CONFIG_SYS_UECx_PHY_ADDR CONFIG_SYS_ULB_CLK CONFIG_SYS_UNIFY_CACHE -CONFIG_SYS_UNSPEC_PHYID -CONFIG_SYS_UNSPEC_STRID CONFIG_SYS_USB_FAT_BOOT_PARTITION CONFIG_SYS_USB_OHCI_BOARD_INIT CONFIG_SYS_USB_OHCI_CPU_INIT @@ -2852,7 +2046,6 @@ CONFIG_SYS_USE_DATAFLASH_CS0 CONFIG_SYS_USE_DATAFLASH_CS1 CONFIG_SYS_USE_DATAFLASH_CS3 CONFIG_SYS_USE_FLASH -CONFIG_SYS_USE_MAIN_OSCILLATOR CONFIG_SYS_USE_MMC CONFIG_SYS_USE_NAND CONFIG_SYS_USE_NANDFLASH @@ -2861,7 +2054,6 @@ CONFIG_SYS_USR_EXCEP CONFIG_SYS_VCXK_ACKNOWLEDGE_DDR CONFIG_SYS_VCXK_ACKNOWLEDGE_PIN CONFIG_SYS_VCXK_ACKNOWLEDGE_PORT -CONFIG_SYS_VCXK_AUTODETECT CONFIG_SYS_VCXK_BASE CONFIG_SYS_VCXK_DEFAULT_LINEALIGN CONFIG_SYS_VCXK_DOUBLEBUFFERED @@ -2874,31 +2066,22 @@ CONFIG_SYS_VCXK_INVERT_PORT CONFIG_SYS_VCXK_REQUEST_DDR CONFIG_SYS_VCXK_REQUEST_PIN CONFIG_SYS_VCXK_REQUEST_PORT -CONFIG_SYS_VCXK_RESET_DDR -CONFIG_SYS_VCXK_RESET_PIN -CONFIG_SYS_VCXK_RESET_PORT CONFIG_SYS_VIDEO_LOGO_MAX_SIZE CONFIG_SYS_VSC7385_BASE CONFIG_SYS_VSC7385_BASE_PHYS CONFIG_SYS_VSC7385_BR_PRELIM CONFIG_SYS_VSC7385_OR_PRELIM -CONFIG_SYS_WATCHDOG_FREQ CONFIG_SYS_WATCHDOG_VALUE CONFIG_SYS_WDTC_WDMR_VAL CONFIG_SYS_WRITE_SWAPPED_DATA CONFIG_SYS_XHCI_USB1_ADDR CONFIG_SYS_XHCI_USB2_ADDR CONFIG_SYS_XHCI_USB3_ADDR -CONFIG_SYS_XIMG_LEN -CONFIG_TAM3517_SETTINGS CONFIG_TCA642X CONFIG_TEGRA_BOARD_STRING CONFIG_TEGRA_CLOCK_SCALING CONFIG_TEGRA_ENABLE_UARTA -CONFIG_TEGRA_ENABLE_UARTB -CONFIG_TEGRA_ENABLE_UARTC CONFIG_TEGRA_ENABLE_UARTD -CONFIG_TEGRA_ENABLE_UARTE CONFIG_TEGRA_GPU CONFIG_TEGRA_LP0 CONFIG_TEGRA_PMU @@ -2910,8 +2093,6 @@ CONFIG_TEGRA_VDD_CORE_TPS62361B_SET3 CONFIG_TEGRA_VDD_CORE_TPS62366A_SET1 CONFIG_TESTPIN_MASK CONFIG_TESTPIN_REG -CONFIG_TEST_LIST_SORT -CONFIG_TFTP_FILE_NAME_MAX_LEN CONFIG_TFTP_PORT CONFIG_THOR_RESET_OFF CONFIG_THUNDERX @@ -2935,7 +2116,6 @@ CONFIG_TSECV2 CONFIG_TSECV2_1 CONFIG_TSEC_TBICR_SETTINGS CONFIG_TWL6030_POWER -CONFIG_TX_DESCR_NUM CONFIG_TZSW_RESERVED_DRAM_SIZE CONFIG_UBIFS_VOLUME CONFIG_UBI_PART @@ -2945,130 +2125,53 @@ CONFIG_UBOOT_SECTOR_COUNT CONFIG_UBOOT_SECTOR_START CONFIG_UDP_CHECKSUM CONFIG_UEC_ETH -CONFIG_UEC_ETH1 CONFIG_UEC_ETH2 -CONFIG_UEC_ETH3 -CONFIG_UEC_ETH4 -CONFIG_UEC_ETH5 -CONFIG_UEC_ETH6 -CONFIG_UEC_ETH7 -CONFIG_UEC_ETH8 -CONFIG_UID16 -CONFIG_ULPI_REF_CLK CONFIG_UPDATEB -CONFIG_UPDATE_LOAD_ADDR CONFIG_USART_BASE CONFIG_USART_ID -CONFIG_USBD_CONFIGURATION_STR -CONFIG_USBD_CTRL_INTERFACE_STR -CONFIG_USBD_DATA_INTERFACE_STR CONFIG_USBD_HS CONFIG_USBD_MANUFACTURER CONFIG_USBD_PRODUCTID_CDCACM CONFIG_USBD_PRODUCTID_GSERIAL CONFIG_USBD_PRODUCT_NAME -CONFIG_USBD_SERIAL_BULK_HS_PKTSIZE -CONFIG_USBD_SERIAL_BULK_PKTSIZE -CONFIG_USBD_SERIAL_INT_ENDPOINT -CONFIG_USBD_SERIAL_INT_PKTSIZE -CONFIG_USBD_SERIAL_IN_ENDPOINT -CONFIG_USBD_SERIAL_IN_PKTSIZE -CONFIG_USBD_SERIAL_OUT_ENDPOINT -CONFIG_USBD_SERIAL_OUT_PKTSIZE CONFIG_USBD_VENDORID CONFIG_USBNET_DEV_ADDR CONFIG_USB_ATMEL CONFIG_USB_ATMEL_CLK_SEL_PLLB CONFIG_USB_ATMEL_CLK_SEL_UPLL -CONFIG_USB_BIN_FIXUP CONFIG_USB_BOOTING CONFIG_USB_DEVICE CONFIG_USB_DEV_BASE -CONFIG_USB_DEV_PULLUP_GPIO -CONFIG_USB_EHCI_BASE -CONFIG_USB_EHCI_BASE_LIST CONFIG_USB_EHCI_EXYNOS -CONFIG_USB_EHCI_FARADAY CONFIG_USB_EHCI_TXFIFO_THRESH -CONFIG_USB_ETH_QMULT -CONFIG_USB_ETH_SUBSET CONFIG_USB_EXT2_BOOT CONFIG_USB_FAT_BOOT -CONFIG_USB_GADGET_AMD5536UDC CONFIG_USB_GADGET_AT91 -CONFIG_USB_GADGET_DUMMY_HCD CONFIG_USB_GADGET_DWC2_OTG_PHY -CONFIG_USB_GADGET_FOTG210 -CONFIG_USB_GADGET_FSL_USB2 -CONFIG_USB_GADGET_GOKU -CONFIG_USB_GADGET_IMX -CONFIG_USB_GADGET_M66592 -CONFIG_USB_GADGET_MQ11XX -CONFIG_USB_GADGET_MUSBHSFC -CONFIG_USB_GADGET_N9604 -CONFIG_USB_GADGET_NET2280 -CONFIG_USB_GADGET_OMAP -CONFIG_USB_GADGET_PXA27X -CONFIG_USB_GADGET_PXA2XX -CONFIG_USB_GADGET_SA1100 -CONFIG_USB_INVENTRA_DMA CONFIG_USB_ISP1301_I2C_ADDR CONFIG_USB_MAX_CONTROLLER_COUNT -CONFIG_USB_MUSB_TIMEOUT -CONFIG_USB_MUSB_TUSB6010 CONFIG_USB_OHCI_LPC32XX CONFIG_USB_OHCI_NEW -CONFIG_USB_OTG -CONFIG_USB_OTG_BLACKLIST_HUB -CONFIG_USB_PXA25X_SMALL -CONFIG_USB_TI_CPPI_DMA CONFIG_USB_TTY -CONFIG_USB_TUSB_OMAP_DMA -CONFIG_USB_ULPI_TIMEOUT CONFIG_USB_XHCI_EXYNOS CONFIG_USE_INTERRUPT CONFIG_USE_ONENAND_BOARD_INIT -CONFIG_UTBIPAR_INIT_TBIPA -CONFIG_U_BOOT_HDR_ADDR CONFIG_U_BOOT_HDR_SIZE CONFIG_VAR_SIZE_SPL CONFIG_VERY_BIG_RAM CONFIG_VIDEO_BCM2835 CONFIG_VIDEO_BMP_LOGO CONFIG_VIDEO_DA8XX -CONFIG_VIDEO_FONT_4X6 CONFIG_VIDEO_LOGO -CONFIG_VIDEO_MXS_MODE_SYSTEM -CONFIG_VIDEO_STD_TIMINGS -CONFIG_VID_FLS_ENV -CONFIG_VM86 -CONFIG_VOIPAC_LCD -CONFIG_VOL_MONITOR_INA220 -CONFIG_VOL_MONITOR_IR36021_READ -CONFIG_VOL_MONITOR_IR36021_SET CONFIG_VSC7385_ENET CONFIG_VSC7385_IMAGE CONFIG_VSC7385_IMAGE_SIZE CONFIG_VSC9953 -CONFIG_WATCHDOG_NOWAYOUT CONFIG_WATCHDOG_PRESC CONFIG_WATCHDOG_RC CONFIG_WATCHDOG_TIMEOUT -CONFIG_WD_PERIOD -CONFIG_X86EMU_DEBUG CONFIG_X86EMU_RAW_IO CONFIG_X86_MRC_ADDR CONFIG_X86_REFCODE_ADDR CONFIG_X86_REFCODE_RUN_ADDR -CONFIG_XGI_XG22_BASE -CONFIG_XSENGINE CONFIG_XTFPGA -CONFIG_YAFFS_AUTO_UNICODE -CONFIG_YAFFS_CASE_INSENSITIVE -CONFIG_YAFFS_DEFINES_TYPES -CONFIG_YAFFS_UNICODE -CONFIG_YAFFS_UTIL -CONFIG_YAFFS_WINCE -CONFIG_YELLOW_LED -CONFIG_ZLT -CONFIG_eTSEC_MDIO_BUS
This converts the following to Kconfig: CONFIG_88F5182 CONFIG_BOARD_IS_OPENRD_BASE CONFIG_BOARD_IS_OPENRD_CLIENT CONFIG_BOARD_IS_OPENRD_ULTIMATE CONFIG_D2NET_V2 CONFIG_FEROCEON CONFIG_FEROCEON_88FR131 CONFIG_INETSPACE_V2 CONFIG_KW88F6192 CONFIG_KW88F6281 CONFIG_KW88F6702 CONFIG_NET2BIG_V2 CONFIG_NETSPACE_LITE_V2 CONFIG_NETSPACE_MAX_V2 CONFIG_NETSPACE_MINI_V2 CONFIG_NETSPACE_V2 CONFIG_SHEEVA_88SV131
At this point mv-plug-common.h is now only an include of mv-common.h so remove that indirection.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/mach-kirkwood/Kconfig | 49 ++++++++++++++++++++++++++++++ arch/arm/mach-orion5x/Kconfig | 8 +++++ board/LaCie/net2big_v2/Kconfig | 11 +++++++ board/LaCie/netspace_v2/Kconfig | 25 +++++++++++++++ board/Marvell/openrd/Kconfig | 14 +++++++++ configs/d2net_v2_defconfig | 1 - configs/inetspace_v2_defconfig | 1 - configs/net2big_v2_defconfig | 2 +- configs/netspace_lite_v2_defconfig | 2 +- configs/netspace_max_v2_defconfig | 2 +- configs/netspace_mini_v2_defconfig | 2 +- configs/netspace_v2_defconfig | 2 +- configs/openrd_base_defconfig | 1 - configs/openrd_client_defconfig | 2 +- configs/openrd_ultimate_defconfig | 2 +- include/configs/SBx81LIFKW.h | 2 -- include/configs/SBx81LIFXCAT.h | 2 -- include/configs/dns325.h | 6 ---- include/configs/dockstar.h | 6 ---- include/configs/dreamplug.h | 7 +---- include/configs/ds109.h | 7 +---- include/configs/edminiv2.h | 3 -- include/configs/goflexhome.h | 6 ---- include/configs/guruplug.h | 15 +-------- include/configs/ib62x0.h | 6 ---- include/configs/iconnect.h | 6 ---- include/configs/km/km_arm.h | 6 ---- include/configs/lacie_kw.h | 11 ------- include/configs/lsxl.h | 2 -- include/configs/mv-plug-common.h | 21 ------------- include/configs/nas220.h | 6 ---- include/configs/nsa310s.h | 5 --- include/configs/openrd.h | 6 ---- include/configs/pogo_e02.h | 6 ---- include/configs/sheevaplug.h | 7 +---- scripts/config_whitelist.txt | 17 ----------- 36 files changed, 118 insertions(+), 159 deletions(-) delete mode 100644 include/configs/mv-plug-common.h
diff --git a/arch/arm/mach-kirkwood/Kconfig b/arch/arm/mach-kirkwood/Kconfig index cb4e9f29ef6d..c060cc8546b6 100644 --- a/arch/arm/mach-kirkwood/Kconfig +++ b/arch/arm/mach-kirkwood/Kconfig @@ -1,66 +1,115 @@ if ARCH_KIRKWOOD
+config FEROCEON_88FR131 + bool + +config KW88F6192 + bool + +config KW88F6281 + bool + +config SHEEVA_88SV131 + bool + choice prompt "Marvell Kirkwood board select" optional
config TARGET_OPENRD bool "Marvell OpenRD Board" + select KW88F6281 + select SHEEVA_88SV131
config TARGET_DREAMPLUG bool "DreamPlug Board" + select KW88F6281 + select SHEEVA_88SV131
config TARGET_DS109 bool "Synology DS109" + select KW88F6281 + select SHEEVA_88SV131
config TARGET_GURUPLUG bool "GuruPlug Board" + select KW88F6281 + select SHEEVA_88SV131
config TARGET_SHEEVAPLUG bool "SheevaPlug Board" + select FEROCEON_88FR131 + select KW88F6281
config TARGET_LSXL bool "lsxl Board" + select FEROCEON_88FR131 + select KW88F6281
config TARGET_POGO_E02 bool "pogo_e02 Board" + select FEROCEON_88FR131 + select KW88F6281
config TARGET_DNS325 bool "dns325 Board" + select FEROCEON_88FR131 + select KW88F6281
config TARGET_ICONNECT bool "iconnect Board" + select FEROCEON_88FR131 + select KW88F6281
config TARGET_KM_KIRKWOOD bool "KM Kirkwood Board" + select FEROCEON_88FR131 + select KW88F6281 select VENDOR_KM
config TARGET_NET2BIG_V2 bool "LaCie 2Big Network v2 NAS Board" + select FEROCEON_88FR131 + select KW88F6281
config TARGET_NETSPACE_V2 bool "LaCie netspace_v2 Board" + select FEROCEON_88FR131
config TARGET_IB62X0 bool "ib62x0 Board" + select FEROCEON_88FR131 + select KW88F6281
config TARGET_DOCKSTAR bool "Dockstar Board" + select FEROCEON_88FR131 + select KW88F6281
config TARGET_GOFLEXHOME bool "GoFlex Home Board" + select FEROCEON_88FR131 + select KW88F6281
config TARGET_NAS220 bool "BlackArmor NAS220" + select FEROCEON_88FR131 + select KW88F6192
config TARGET_NSA310S bool "Zyxel NSA310S" + select FEROCEON_88FR131 + select KW88F6192
config TARGET_SBx81LIFKW bool "Allied Telesis SBx81GS24/SBx81GT40/SBx81XS6/SBx81XS16" + select FEROCEON_88FR131 + select KW88F6281
config TARGET_SBx81LIFXCAT bool "Allied Telesis SBx81GP24/SBx81GT24" + select FEROCEON_88FR131 + select KW88F6281
endchoice
diff --git a/arch/arm/mach-orion5x/Kconfig b/arch/arm/mach-orion5x/Kconfig index 5baa6fb935ae..b8b45a048ca3 100644 --- a/arch/arm/mach-orion5x/Kconfig +++ b/arch/arm/mach-orion5x/Kconfig @@ -1,11 +1,19 @@ if ARCH_ORION5X
+config 88F5182 + bool + +config FEROCEON + bool + choice prompt "Marvell Orion board select" optional
config TARGET_EDMINIV2 bool "LaCie Ethernet Disk mini V2" + select 88F5182 + select FEROCEON select SUPPORT_SPL
endchoice diff --git a/board/LaCie/net2big_v2/Kconfig b/board/LaCie/net2big_v2/Kconfig index ba460dba45ec..758d25e00714 100644 --- a/board/LaCie/net2big_v2/Kconfig +++ b/board/LaCie/net2big_v2/Kconfig @@ -1,5 +1,16 @@ if TARGET_NET2BIG_V2
+choice + prompt "Board variant" + +config D2NET_V2 + bool "D2NET v2" + +config NET2BIG_V2 + bool "NET2BIG v2" + +endchoice + config SYS_BOARD default "net2big_v2"
diff --git a/board/LaCie/netspace_v2/Kconfig b/board/LaCie/netspace_v2/Kconfig index 930b822dfbe7..4eca1d47de51 100644 --- a/board/LaCie/netspace_v2/Kconfig +++ b/board/LaCie/netspace_v2/Kconfig @@ -1,5 +1,30 @@ if TARGET_NETSPACE_V2
+choice + prompt "Board variant" + +config INETSPACE_V2 + bool "INETSPACE v2" + select KW88F6281 + +config NETSPACE_LITE_V2 + bool "NETSPACE LITE v2" + select KW88F6192 + +config NETSPACE_MAX_V2 + bool "NETSPACE MAX v2" + select KW88F6281 + +config NETSPACE_MINI_V2 + bool "NETSPACE MINI v2" + select KW88F6192 + +config NETSPACE_V2 + bool "NETSPACE v2" + select KW88F6281 + +endchoice + config SYS_BOARD default "netspace_v2"
diff --git a/board/Marvell/openrd/Kconfig b/board/Marvell/openrd/Kconfig index 124b66da0f13..dc26ed2f42f4 100644 --- a/board/Marvell/openrd/Kconfig +++ b/board/Marvell/openrd/Kconfig @@ -1,5 +1,19 @@ if TARGET_OPENRD
+choice + prompt "Board variant" + +config BOARD_IS_OPENRD_BASE + bool "Base" + +config BOARD_IS_OPENRD_CLIENT + bool "Client" + +config BOARD_IS_OPENRD_ULTIMATE + bool "Ultimate" + +endchoice + config SYS_BOARD default "openrd"
diff --git a/configs/d2net_v2_defconfig b/configs/d2net_v2_defconfig index 32fe1dcb4266..3f2763399b5e 100644 --- a/configs/d2net_v2_defconfig +++ b/configs/d2net_v2_defconfig @@ -13,7 +13,6 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-d2net" CONFIG_IDENT_STRING=" D2 v2" # CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_LOAD_ADDR=0x800000 -CONFIG_SYS_EXTRA_OPTIONS="D2NET_V2" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" diff --git a/configs/inetspace_v2_defconfig b/configs/inetspace_v2_defconfig index b6ebab0d183d..c3f9be8765fb 100644 --- a/configs/inetspace_v2_defconfig +++ b/configs/inetspace_v2_defconfig @@ -13,7 +13,6 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-is2" CONFIG_IDENT_STRING=" IS v2" # CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_LOAD_ADDR=0x800000 -CONFIG_SYS_EXTRA_OPTIONS="INETSPACE_V2" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" diff --git a/configs/net2big_v2_defconfig b/configs/net2big_v2_defconfig index cc1d81c7a1dd..083d3e6e0220 100644 --- a/configs/net2big_v2_defconfig +++ b/configs/net2big_v2_defconfig @@ -6,6 +6,7 @@ CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_NET2BIG_V2=y +CONFIG_NET2BIG_V2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 @@ -13,7 +14,6 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-net2big" CONFIG_IDENT_STRING=" 2Big v2" # CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_LOAD_ADDR=0x800000 -CONFIG_SYS_EXTRA_OPTIONS="NET2BIG_V2" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" diff --git a/configs/netspace_lite_v2_defconfig b/configs/netspace_lite_v2_defconfig index 249ffc6dad09..e671d994f765 100644 --- a/configs/netspace_lite_v2_defconfig +++ b/configs/netspace_lite_v2_defconfig @@ -6,6 +6,7 @@ CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_NETSPACE_V2=y +CONFIG_NETSPACE_LITE_V2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 @@ -13,7 +14,6 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2lite" CONFIG_IDENT_STRING=" NS v2 Lite" # CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_LOAD_ADDR=0x800000 -CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_LITE_V2" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" diff --git a/configs/netspace_max_v2_defconfig b/configs/netspace_max_v2_defconfig index e11a6b7cd46b..607cb5a3f9a5 100644 --- a/configs/netspace_max_v2_defconfig +++ b/configs/netspace_max_v2_defconfig @@ -6,6 +6,7 @@ CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_NETSPACE_V2=y +CONFIG_NETSPACE_MAX_V2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 @@ -13,7 +14,6 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2max" CONFIG_IDENT_STRING=" NS Max v2" # CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_LOAD_ADDR=0x800000 -CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_MAX_V2" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" diff --git a/configs/netspace_mini_v2_defconfig b/configs/netspace_mini_v2_defconfig index 7b9c29b9db98..203071d37775 100644 --- a/configs/netspace_mini_v2_defconfig +++ b/configs/netspace_mini_v2_defconfig @@ -6,6 +6,7 @@ CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_NETSPACE_V2=y +CONFIG_NETSPACE_MINI_V2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 @@ -13,7 +14,6 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2mini" CONFIG_IDENT_STRING=" NS v2 Mini" # CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_LOAD_ADDR=0x800000 -CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_MINI_V2" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" diff --git a/configs/netspace_v2_defconfig b/configs/netspace_v2_defconfig index ba0d0ffbab65..84a2389d1780 100644 --- a/configs/netspace_v2_defconfig +++ b/configs/netspace_v2_defconfig @@ -6,6 +6,7 @@ CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_NETSPACE_V2=y +CONFIG_NETSPACE_V2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 @@ -13,7 +14,6 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2" CONFIG_IDENT_STRING=" NS v2" # CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_LOAD_ADDR=0x800000 -CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_V2" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" diff --git a/configs/openrd_base_defconfig b/configs/openrd_base_defconfig index 9e048d475c18..e79649ee7ea3 100644 --- a/configs/openrd_base_defconfig +++ b/configs/openrd_base_defconfig @@ -13,7 +13,6 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-openrd-base" CONFIG_IDENT_STRING="\nOpenRD-Base" # CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_LOAD_ADDR=0x800000 -CONFIG_SYS_EXTRA_OPTIONS="BOARD_IS_OPENRD_BASE" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="${x_bootcmd_kernel}; setenv bootargs ${x_bootargs} ${x_bootargs_root}; ${x_bootcmd_usb}; bootm 0x6400000;" diff --git a/configs/openrd_client_defconfig b/configs/openrd_client_defconfig index 6f9f0a279dce..9d924f3cbc91 100644 --- a/configs/openrd_client_defconfig +++ b/configs/openrd_client_defconfig @@ -7,13 +7,13 @@ CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_OPENRD=y +CONFIG_BOARD_IS_OPENRD_CLIENT=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x80000 CONFIG_DEFAULT_DEVICE_TREE="kirkwood-openrd-client" CONFIG_IDENT_STRING="\nOpenRD-Client" # CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_LOAD_ADDR=0x800000 -CONFIG_SYS_EXTRA_OPTIONS="BOARD_IS_OPENRD_CLIENT" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="${x_bootcmd_kernel}; setenv bootargs ${x_bootargs} ${x_bootargs_root}; ${x_bootcmd_usb}; bootm 0x6400000;" diff --git a/configs/openrd_ultimate_defconfig b/configs/openrd_ultimate_defconfig index b5879638cd12..7c2e41e72e08 100644 --- a/configs/openrd_ultimate_defconfig +++ b/configs/openrd_ultimate_defconfig @@ -7,13 +7,13 @@ CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_OPENRD=y +CONFIG_BOARD_IS_OPENRD_ULTIMATE=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x80000 CONFIG_DEFAULT_DEVICE_TREE="kirkwood-openrd-ultimate" CONFIG_IDENT_STRING="\nOpenRD-Ultimate" # CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_LOAD_ADDR=0x800000 -CONFIG_SYS_EXTRA_OPTIONS="BOARD_IS_OPENRD_ULTIMATE" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="${x_bootcmd_kernel}; setenv bootargs ${x_bootargs} ${x_bootargs_root}; ${x_bootcmd_usb}; bootm 0x6400000;" diff --git a/include/configs/SBx81LIFKW.h b/include/configs/SBx81LIFKW.h index 782b16f30fa0..3ebeccc33bcd 100644 --- a/include/configs/SBx81LIFKW.h +++ b/include/configs/SBx81LIFKW.h @@ -9,8 +9,6 @@ /* * High Level Configuration Options (easy to change) */ -#define CONFIG_FEROCEON_88FR131 1 /* CPU Core subversion */ -#define CONFIG_KW88F6281 1 /* SOC Name */ #define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage.cfg
/* additions for new ARM relocation support */ diff --git a/include/configs/SBx81LIFXCAT.h b/include/configs/SBx81LIFXCAT.h index e4666e1e7e3c..53a6bdf0a302 100644 --- a/include/configs/SBx81LIFXCAT.h +++ b/include/configs/SBx81LIFXCAT.h @@ -9,8 +9,6 @@ /* * High Level Configuration Options (easy to change) */ -#define CONFIG_FEROCEON_88FR131 1 /* CPU Core subversion */ -#define CONFIG_KW88F6281 1 /* SOC Name */ #define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage.cfg
/* additions for new ARM relocation support */ diff --git a/include/configs/dns325.h b/include/configs/dns325.h index 8e298ddfa1a5..e35c16add4dd 100644 --- a/include/configs/dns325.h +++ b/include/configs/dns325.h @@ -12,12 +12,6 @@ #ifndef _CONFIG_DNS325_H #define _CONFIG_DNS325_H
-/* - * High Level Configuration Options (easy to change) - */ -#define CONFIG_FEROCEON_88FR131 /* CPU Core subversion */ -#define CONFIG_KW88F6281 /* SOC Name */ - #include "mv-common.h"
/* Remove or override few declarations from mv-common.h */ diff --git a/include/configs/dockstar.h b/include/configs/dockstar.h index 8a5daf48c0fe..0ad04eee1b74 100644 --- a/include/configs/dockstar.h +++ b/include/configs/dockstar.h @@ -11,12 +11,6 @@ #ifndef _CONFIG_DOCKSTAR_H #define _CONFIG_DOCKSTAR_H
-/* - * High Level Configuration Options (easy to change) - */ -#define CONFIG_FEROCEON_88FR131 1 /* CPU Core subversion */ -#define CONFIG_KW88F6281 1 /* SOC Name */ - /* * mv-common.h should be defined after CMD configs since it used them * to enable certain macros diff --git a/include/configs/dreamplug.h b/include/configs/dreamplug.h index 61b1e0fc1f34..beea234d8dc8 100644 --- a/include/configs/dreamplug.h +++ b/include/configs/dreamplug.h @@ -11,12 +11,7 @@ #ifndef _CONFIG_DREAMPLUG_H #define _CONFIG_DREAMPLUG_H
-/* - * High Level Configuration Options (easy to change) - */ -#define CONFIG_SHEEVA_88SV131 1 /* CPU Core subversion */ - -#include "mv-plug-common.h" +#include "mv-common.h"
/* * Environment variables configurations diff --git a/include/configs/ds109.h b/include/configs/ds109.h index c57461c7e6bf..8553ea0b95f2 100644 --- a/include/configs/ds109.h +++ b/include/configs/ds109.h @@ -11,12 +11,7 @@ #ifndef _CONFIG_DS109_H #define _CONFIG_DS109_H
/* * Environment variables configurations diff --git a/include/configs/edminiv2.h b/include/configs/edminiv2.h index 6b487b310cce..e20e058e0a32 100644 --- a/include/configs/edminiv2.h +++ b/include/configs/edminiv2.h @@ -28,9 +28,6 @@ * High Level Configuration Options (easy to change) */
-#define CONFIG_FEROCEON 1 /* CPU Core subversion */ -#define CONFIG_88F5182 1 /* SOC Name */ - #include <asm/arch/orion5x.h> /* * CLKs configurations diff --git a/include/configs/goflexhome.h b/include/configs/goflexhome.h index 269178c9c2be..90e37d985354 100644 --- a/include/configs/goflexhome.h +++ b/include/configs/goflexhome.h @@ -14,12 +14,6 @@ #ifndef _CONFIG_GOFLEXHOME_H #define _CONFIG_GOFLEXHOME_H
-/* - * High Level Configuration Options (easy to change) - */ -#define CONFIG_FEROCEON_88FR131 1 /* CPU Core subversion */ -#define CONFIG_KW88F6281 1 /* SOC Name */ - /* * Default GPIO configuration and LED status */ diff --git a/include/configs/guruplug.h b/include/configs/guruplug.h index e51f3f2483f1..25c5a97c69d7 100644 --- a/include/configs/guruplug.h +++ b/include/configs/guruplug.h @@ -9,20 +9,7 @@ #ifndef _CONFIG_GURUPLUG_H #define _CONFIG_GURUPLUG_H
-/* - * High Level Configuration Options (easy to change) - */ -#define CONFIG_SHEEVA_88SV131 1 /* CPU Core subversion */ - -/* - * Standard filesystems - */ - -/* - * mv-plug-common.h should be defined after CMD configs since it used them - * to enable certain macros - */ -#include "mv-plug-common.h" +#include "mv-common.h"
/* * Environment variables configurations diff --git a/include/configs/ib62x0.h b/include/configs/ib62x0.h index 75bb073d4d8d..9783fd89ec02 100644 --- a/include/configs/ib62x0.h +++ b/include/configs/ib62x0.h @@ -8,12 +8,6 @@ #ifndef _CONFIG_IB62x0_H #define _CONFIG_IB62x0_H
-/* - * High level configuration options - */ -#define CONFIG_FEROCEON_88FR131 /* CPU Core subversion */ -#define CONFIG_KW88F6281 /* SOC Name */ - #include "mv-common.h"
/* diff --git a/include/configs/iconnect.h b/include/configs/iconnect.h index 4903b92ca3af..f1aad1efde64 100644 --- a/include/configs/iconnect.h +++ b/include/configs/iconnect.h @@ -8,12 +8,6 @@ #ifndef _CONFIG_ICONNECT_H #define _CONFIG_ICONNECT_H
/* diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index cca624ea3e11..6501884d32ce 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -19,12 +19,6 @@ #ifndef _CONFIG_KM_ARM_H #define _CONFIG_KM_ARM_H
-/* - * High Level Configuration Options (easy to change) - */ -#define CONFIG_FEROCEON_88FR131 /* CPU Core subversion */ -#define CONFIG_KW88F6281 /* SOC Name */ - #define CONFIG_NAND_ECC_BCH
/* include common defines/options for all Keymile boards */ diff --git a/include/configs/lacie_kw.h b/include/configs/lacie_kw.h index 6180563ab767..d6c5425a9dd0 100644 --- a/include/configs/lacie_kw.h +++ b/include/configs/lacie_kw.h @@ -6,17 +6,6 @@ #ifndef _CONFIG_LACIE_KW_H #define _CONFIG_LACIE_KW_H
-/* - * High Level Configuration Options (easy to change) - */ -#define CONFIG_FEROCEON_88FR131 /* CPU Core subversion */ -/* SoC name */ -#if defined(CONFIG_NETSPACE_LITE_V2) || defined(CONFIG_NETSPACE_MINI_V2) -#define CONFIG_KW88F6192 -#else -#define CONFIG_KW88F6281 -#endif - /* * SDRAM configuration */ diff --git a/include/configs/lsxl.h b/include/configs/lsxl.h index 7294a3c20a5a..5891a1d8c594 100644 --- a/include/configs/lsxl.h +++ b/include/configs/lsxl.h @@ -21,8 +21,6 @@ /* * General configuration options */ -#define CONFIG_FEROCEON_88FR131 /* CPU Core subversion */ -#define CONFIG_KW88F6281 /* SOC Name */
#define CONFIG_KIRKWOOD_GPIO
diff --git a/include/configs/mv-plug-common.h b/include/configs/mv-plug-common.h deleted file mode 100644 index d38d9872c006..000000000000 --- a/include/configs/mv-plug-common.h +++ /dev/null @@ -1,21 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2009-2015 - * Marvell Semiconductor <www.marvell.com> - */ - -#ifndef _CONFIG_MARVELL_PLUG_H -#define _CONFIG_MARVELL_PLUG_H - -/* - * High Level Configuration Options (easy to change) - */ -#define CONFIG_KW88F6281 1 /* SOC Name */ - -/* - * mv-common.h should be defined after CMD configs since it used them - * to enable certain macros - */ -#include "mv-common.h" - -#endif /* _CONFIG_MARVELL_PLUG_H */ diff --git a/include/configs/nas220.h b/include/configs/nas220.h index 9f89cca0b017..12480d9d5525 100644 --- a/include/configs/nas220.h +++ b/include/configs/nas220.h @@ -11,12 +11,6 @@ #ifndef _CONFIG_NAS220_H #define _CONFIG_NAS220_H
-/* - * High Level Configuration Options (easy to change) - */ -#define CONFIG_FEROCEON_88FR131 /* #define CPU Core subversion */ -#define CONFIG_KW88F6192 /* SOC Name */ - /* power-on led, regulator, sata0, sata1 */ #define NAS220_GE_OE_VAL_LOW ((1 << 12)|(1 << 14)|(1 << 24)|(1 << 28)) #define NAS220_GE_OE_VAL_HIGH (0) diff --git a/include/configs/nsa310s.h b/include/configs/nsa310s.h index 54f496f6ce14..8cc9ca6a49d1 100644 --- a/include/configs/nsa310s.h +++ b/include/configs/nsa310s.h @@ -9,11 +9,6 @@ #ifndef _CONFIG_NSA310S_H #define _CONFIG_NSA310S_H
-/* high level configuration options */ -#define CONFIG_FEROCEON_88FR131 1 /* CPU Core subversion */ -#define CONFIG_KW88F6192 1 /* SOC Name */ -#define CONFIG_KW88F6702 1 /* SOC Name */ - #include "mv-common.h"
/* environment variables configuration */ diff --git a/include/configs/openrd.h b/include/configs/openrd.h index bd27e503cad1..43d089657b11 100644 --- a/include/configs/openrd.h +++ b/include/configs/openrd.h @@ -13,12 +13,6 @@ #ifndef _CONFIG_OPENRD_H #define _CONFIG_OPENRD_H
-/* - * High Level Configuration Options (easy to change) - */ -#define CONFIG_SHEEVA_88SV131 1 /* CPU Core subversion */ -#define CONFIG_KW88F6281 1 /* SOC Name */ - #include "mv-common.h"
/* diff --git a/include/configs/pogo_e02.h b/include/configs/pogo_e02.h index 196e362bd74f..3e94125cb35f 100644 --- a/include/configs/pogo_e02.h +++ b/include/configs/pogo_e02.h @@ -12,12 +12,6 @@ #ifndef _CONFIG_POGO_E02_H #define _CONFIG_POGO_E02_H
/* diff --git a/include/configs/sheevaplug.h b/include/configs/sheevaplug.h index bb7ce8d3edeb..8dba4fcb4f84 100644 --- a/include/configs/sheevaplug.h +++ b/include/configs/sheevaplug.h @@ -9,12 +9,7 @@ #ifndef _CONFIG_SHEEVAPLUG_H #define _CONFIG_SHEEVAPLUG_H
-/* - * High Level Configuration Options (easy to change) - */ -#define CONFIG_FEROCEON_88FR131 1 /* CPU Core subversion */ - -#include "mv-plug-common.h" +#include "mv-common.h"
/* * Environment variables configurations diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 9fae7ce8617c..43c53c764bbc 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1,4 +1,3 @@ -CONFIG_88F5182 CONFIG_A003399_NOR_WORKAROUND CONFIG_A008044_WORKAROUND CONFIG_AM335X_USB0 @@ -42,9 +41,6 @@ CONFIG_BOARDDIR CONFIG_BOARDNAME CONFIG_BOARD_COMMON CONFIG_BOARD_ECC_SUPPORT -CONFIG_BOARD_IS_OPENRD_BASE -CONFIG_BOARD_IS_OPENRD_CLIENT -CONFIG_BOARD_IS_OPENRD_ULTIMATE CONFIG_BOARD_NAME CONFIG_BOARD_POSTCLK_INIT CONFIG_BOARD_SIZE_LIMIT @@ -103,7 +99,6 @@ CONFIG_CPU_ARMV8 CONFIG_CPU_FREQ_HZ CONFIG_CQSPI_REF_CLK CONFIG_CUSTOMER_BOARD_SUPPORT -CONFIG_D2NET_V2 CONFIG_DB_784MP_GP CONFIG_DCACHE CONFIG_DEBUG @@ -203,8 +198,6 @@ CONFIG_FEC_ENET_DEV CONFIG_FEC_FIXED_SPEED CONFIG_FEC_MXC_PHYADDR CONFIG_FEC_XCV_TYPE -CONFIG_FEROCEON -CONFIG_FEROCEON_88FR131 CONFIG_FIXED_SDHCI_ALIGNED_BUFFER CONFIG_FLASH_BR_PRELIM CONFIG_FLASH_CFI_LEGACY @@ -456,7 +449,6 @@ CONFIG_IMX CONFIG_IMX6_PWM_PER_CLK CONFIG_IMX_HDMI CONFIG_IMX_VIDEO_SKIP -CONFIG_INETSPACE_V2 CONFIG_INTERRUPTS CONFIG_IODELAY_RECALIBRATION CONFIG_IOMUX_LPSR @@ -519,9 +511,6 @@ CONFIG_KSNET_NETCP_V1_5 CONFIG_KSNET_SERDES_LANES_PER_SGMII CONFIG_KSNET_SERDES_SGMII2_BASE CONFIG_KSNET_SERDES_SGMII_BASE -CONFIG_KW88F6192 -CONFIG_KW88F6281 -CONFIG_KW88F6702 CONFIG_L1_INIT_RAM CONFIG_L2_CACHE CONFIG_LAYERSCAPE_NS_ACCESS @@ -611,13 +600,8 @@ CONFIG_NAND_KMETER1 CONFIG_NAND_OMAP_GPMC_WSCFG CONFIG_NAND_SECBOOT CONFIG_NAND_SPL -CONFIG_NET2BIG_V2 CONFIG_NETDEV CONFIG_NETMASK -CONFIG_NETSPACE_LITE_V2 -CONFIG_NETSPACE_MAX_V2 -CONFIG_NETSPACE_MINI_V2 -CONFIG_NETSPACE_V2 CONFIG_NET_RETRY_COUNT CONFIG_NEVER_ASSERT_ODT_TO_CPU CONFIG_NFS_TIMEOUT @@ -772,7 +756,6 @@ CONFIG_SET_BOOTARGS CONFIG_SET_DFU_ALT_BUF_LEN CONFIG_SH73A0 CONFIG_SH7751_PCI -CONFIG_SHEEVA_88SV131 CONFIG_SH_ETHER_ALIGNE_SIZE CONFIG_SH_ETHER_BASE_ADDR CONFIG_SH_ETHER_CACHE_INVALIDATE
This converts the following to Kconfig: CONFIG_SYS_KWD_CONFIG
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/Kconfig | 8 ++++++++ arch/arm/mach-kirkwood/include/mach/config.h | 9 --------- arch/arm/mach-mvebu/include/mach/config.h | 9 --------- configs/SBx81LIFKW_defconfig | 1 + configs/SBx81LIFXCAT_defconfig | 1 + configs/crs305-1g-4s-bit_defconfig | 1 + configs/crs305-1g-4s_defconfig | 1 + configs/crs326-24g-2s-bit_defconfig | 1 + configs/crs326-24g-2s_defconfig | 1 + configs/crs328-4c-20s-4s-bit_defconfig | 1 + configs/crs328-4c-20s-4s_defconfig | 1 + configs/d2net_v2_defconfig | 1 + configs/db-xc3-24g4xg_defconfig | 1 + configs/dns325_defconfig | 1 + configs/dockstar_defconfig | 1 + configs/dreamplug_defconfig | 1 + configs/ds109_defconfig | 1 + configs/goflexhome_defconfig | 1 + configs/guruplug_defconfig | 1 + configs/ib62x0_defconfig | 1 + configs/iconnect_defconfig | 1 + configs/inetspace_v2_defconfig | 1 + configs/km_kirkwood_128m16_defconfig | 1 + configs/km_kirkwood_defconfig | 1 + configs/km_kirkwood_pci_defconfig | 1 + configs/kmcoge5un_defconfig | 1 + configs/kmnusa_defconfig | 1 + configs/kmsuse2_defconfig | 1 + configs/lschlv2_defconfig | 1 + configs/lsxhl_defconfig | 1 + configs/nas220_defconfig | 1 + configs/net2big_v2_defconfig | 1 + configs/netspace_lite_v2_defconfig | 1 + configs/netspace_max_v2_defconfig | 1 + configs/netspace_mini_v2_defconfig | 1 + configs/netspace_v2_defconfig | 1 + configs/nsa310s_defconfig | 1 + configs/openrd_base_defconfig | 1 + configs/openrd_client_defconfig | 1 + configs/openrd_ultimate_defconfig | 1 + configs/pogo_e02_defconfig | 1 + configs/sheevaplug_defconfig | 1 + include/configs/SBx81LIFKW.h | 5 ----- include/configs/SBx81LIFXCAT.h | 5 ----- include/configs/crs3xx-98dx3236.h | 1 - include/configs/db-xc3-24g4xg.h | 6 ------ include/configs/km_kirkwood.h | 9 --------- include/configs/lacie_kw.h | 18 ------------------ include/configs/lsxl.h | 11 ----------- scripts/config_whitelist.txt | 1 - 50 files changed, 47 insertions(+), 74 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 4bfca750c27b..08a06cd9e235 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -2046,6 +2046,14 @@ config ISW_ENTRY_ADDR image headers. endif
+config SYS_KWD_CONFIG + string "kwbimage config file path" + depends on ARCH_KIRKWOOD || ARCH_MVEBU + default "arch/arm/mach-mvebu/kwbimage.cfg" + help + Path within the source directory to the kwbimage.cfg file to use + when packaging the U-Boot image for use. + source "arch/arm/mach-apple/Kconfig"
source "arch/arm/mach-aspeed/Kconfig" diff --git a/arch/arm/mach-kirkwood/include/mach/config.h b/arch/arm/mach-kirkwood/include/mach/config.h index 9fd90611bd98..eb9502361eef 100644 --- a/arch/arm/mach-kirkwood/include/mach/config.h +++ b/arch/arm/mach-kirkwood/include/mach/config.h @@ -27,15 +27,6 @@ #define CONFIG_KIRKWOOD_RGMII_PAD_1V8 /* Set RGMII Pad voltage to 1.8V */ #define CONFIG_KIRKWOOD_PCIE_INIT /* Enable PCIE Port0 for kernel */
-/* - * By default kwbimage.cfg from board specific folder is used - * If for some board, different configuration file need to be used, - * CONFIG_SYS_KWD_CONFIG should be defined in board specific header file - */ -#ifndef CONFIG_SYS_KWD_CONFIG -#define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage.cfg -#endif /* CONFIG_SYS_KWD_CONFIG */ - /* Kirkwood has 2k of Security SRAM, use it for SP */ #define CONFIG_SYS_INIT_SP_ADDR 0xC8012000
diff --git a/arch/arm/mach-mvebu/include/mach/config.h b/arch/arm/mach-mvebu/include/mach/config.h index 6ecd394a533d..681f64961f0b 100644 --- a/arch/arm/mach-mvebu/include/mach/config.h +++ b/arch/arm/mach-mvebu/include/mach/config.h @@ -27,15 +27,6 @@
#define CONFIG_SYS_L2_PL310
-/* - * By default the generated mvebu kwbimage.cfg is used - * If for some board, different configuration file need to be used, - * CONFIG_SYS_KWD_CONFIG should be defined in board specific header file - */ -#ifndef CONFIG_SYS_KWD_CONFIG -#define CONFIG_SYS_KWD_CONFIG arch/arm/mach-mvebu/kwbimage.cfg -#endif /* CONFIG_SYS_KWD_CONFIG */ - /* end of 16M scrubbed by training in bootrom */ #define CONFIG_SYS_INIT_SP_ADDR 0x00FF0000
diff --git a/configs/SBx81LIFKW_defconfig b/configs/SBx81LIFKW_defconfig index 6001bccd6f9d..ec7c7eb29565 100644 --- a/configs/SBx81LIFKW_defconfig +++ b/configs/SBx81LIFKW_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/alliedtelesis/SBx81LIFKW/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x00600000 CONFIG_TARGET_SBx81LIFKW=y CONFIG_ENV_SIZE=0x2000 diff --git a/configs/SBx81LIFXCAT_defconfig b/configs/SBx81LIFXCAT_defconfig index 8835b75c732f..a3ddabd65758 100644 --- a/configs/SBx81LIFXCAT_defconfig +++ b/configs/SBx81LIFXCAT_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/alliedtelesis/SBx81LIFXCAT/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x00600000 CONFIG_TARGET_SBx81LIFXCAT=y CONFIG_ENV_SIZE=0x2000 diff --git a/configs/crs305-1g-4s-bit_defconfig b/configs/crs305-1g-4s-bit_defconfig index bf6186030cff..ff8f413810fd 100644 --- a/configs/crs305-1g-4s-bit_defconfig +++ b/configs/crs305-1g-4s-bit_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_MVEBU=y +CONFIG_SYS_KWD_CONFIG="board/mikrotik/crs3xx-98dx3236/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x00800000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_CRS3XX_98DX3236=y diff --git a/configs/crs305-1g-4s_defconfig b/configs/crs305-1g-4s_defconfig index 5fc805875bde..a71b6425ea5b 100644 --- a/configs/crs305-1g-4s_defconfig +++ b/configs/crs305-1g-4s_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_MVEBU=y +CONFIG_SYS_KWD_CONFIG="board/mikrotik/crs3xx-98dx3236/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x00800000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_CRS3XX_98DX3236=y diff --git a/configs/crs326-24g-2s-bit_defconfig b/configs/crs326-24g-2s-bit_defconfig index 3de29490e898..c0746be76427 100644 --- a/configs/crs326-24g-2s-bit_defconfig +++ b/configs/crs326-24g-2s-bit_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_MVEBU=y +CONFIG_SYS_KWD_CONFIG="board/mikrotik/crs3xx-98dx3236/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x00800000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_CRS3XX_98DX3236=y diff --git a/configs/crs326-24g-2s_defconfig b/configs/crs326-24g-2s_defconfig index 77296abfc9bf..344f1b082453 100644 --- a/configs/crs326-24g-2s_defconfig +++ b/configs/crs326-24g-2s_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_MVEBU=y +CONFIG_SYS_KWD_CONFIG="board/mikrotik/crs3xx-98dx3236/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x00800000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_CRS3XX_98DX3236=y diff --git a/configs/crs328-4c-20s-4s-bit_defconfig b/configs/crs328-4c-20s-4s-bit_defconfig index 513cc52562ed..edfd0a4faf93 100644 --- a/configs/crs328-4c-20s-4s-bit_defconfig +++ b/configs/crs328-4c-20s-4s-bit_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_MVEBU=y +CONFIG_SYS_KWD_CONFIG="board/mikrotik/crs3xx-98dx3236/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x00800000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_CRS3XX_98DX3236=y diff --git a/configs/crs328-4c-20s-4s_defconfig b/configs/crs328-4c-20s-4s_defconfig index dd0cd63b90c8..d6f93534dd9d 100644 --- a/configs/crs328-4c-20s-4s_defconfig +++ b/configs/crs328-4c-20s-4s_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_MVEBU=y +CONFIG_SYS_KWD_CONFIG="board/mikrotik/crs3xx-98dx3236/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x00800000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_CRS3XX_98DX3236=y diff --git a/configs/d2net_v2_defconfig b/configs/d2net_v2_defconfig index 3f2763399b5e..8e1bb2d4a01a 100644 --- a/configs/d2net_v2_defconfig +++ b/configs/d2net_v2_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/LaCie/net2big_v2/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_NET2BIG_V2=y diff --git a/configs/db-xc3-24g4xg_defconfig b/configs/db-xc3-24g4xg_defconfig index b2ee2c284313..3c0b045a21fa 100644 --- a/configs/db-xc3-24g4xg_defconfig +++ b/configs/db-xc3-24g4xg_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_MVEBU=y +CONFIG_SYS_KWD_CONFIG="board/Marvell/db-xc3-24g4xg/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x00800000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_SYS_MEMTEST_START=0x00800000 diff --git a/configs/dns325_defconfig b/configs/dns325_defconfig index a133402ff2f2..c1da0f545c63 100644 --- a/configs/dns325_defconfig +++ b/configs/dns325_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/d-link/dns325/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=1 CONFIG_TARGET_DNS325=y diff --git a/configs/dockstar_defconfig b/configs/dockstar_defconfig index ba934088e131..6c89a9a6fb21 100644 --- a/configs/dockstar_defconfig +++ b/configs/dockstar_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/Seagate/dockstar/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_DOCKSTAR=y diff --git a/configs/dreamplug_defconfig b/configs/dreamplug_defconfig index 3b4df5c0dbdb..557013dbacd1 100644 --- a/configs/dreamplug_defconfig +++ b/configs/dreamplug_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/Marvell/dreamplug/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_DREAMPLUG=y diff --git a/configs/ds109_defconfig b/configs/ds109_defconfig index ba74ece738de..8e2aea9ad624 100644 --- a/configs/ds109_defconfig +++ b/configs/ds109_defconfig @@ -8,6 +8,7 @@ CONFIG_CMDLINE_TAG=y CONFIG_INITRD_TAG=y CONFIG_STATIC_MACH_TYPE=y CONFIG_MACH_TYPE=527 +CONFIG_SYS_KWD_CONFIG="board/Synology/ds109/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_DS109=y diff --git a/configs/goflexhome_defconfig b/configs/goflexhome_defconfig index 70f703639c8c..ec8b7398d0a8 100644 --- a/configs/goflexhome_defconfig +++ b/configs/goflexhome_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/Seagate/goflexhome/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_GOFLEXHOME=y diff --git a/configs/guruplug_defconfig b/configs/guruplug_defconfig index 2e6b8e02825d..e7802afb0a0c 100644 --- a/configs/guruplug_defconfig +++ b/configs/guruplug_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/Marvell/guruplug/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_GURUPLUG=y diff --git a/configs/ib62x0_defconfig b/configs/ib62x0_defconfig index 913fb438cd15..23a211c39134 100644 --- a/configs/ib62x0_defconfig +++ b/configs/ib62x0_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/raidsonic/ib62x0/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_IB62X0=y diff --git a/configs/iconnect_defconfig b/configs/iconnect_defconfig index a6607faf7fa6..605b98b1642b 100644 --- a/configs/iconnect_defconfig +++ b/configs/iconnect_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/iomega/iconnect/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_ICONNECT=y diff --git a/configs/inetspace_v2_defconfig b/configs/inetspace_v2_defconfig index c3f9be8765fb..0af49d45f0c3 100644 --- a/configs/inetspace_v2_defconfig +++ b/configs/inetspace_v2_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/LaCie/netspace_v2/kwbimage-is2.cfg" CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_NETSPACE_V2=y diff --git a/configs/km_kirkwood_128m16_defconfig b/configs/km_kirkwood_128m16_defconfig index d6624dd9551d..c9832d3d51e4 100644 --- a/configs/km_kirkwood_128m16_defconfig +++ b/configs/km_kirkwood_128m16_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/keymile/km_arm/kwbimage_128M16_1.cfg" CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_ENV_SIZE=0x2000 diff --git a/configs/km_kirkwood_defconfig b/configs/km_kirkwood_defconfig index bf696cd2db28..b0a268e370d5 100644 --- a/configs/km_kirkwood_defconfig +++ b/configs/km_kirkwood_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/keymile/km_arm/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_ENV_SIZE=0x2000 diff --git a/configs/km_kirkwood_pci_defconfig b/configs/km_kirkwood_pci_defconfig index 0731bb557293..38c4c1e2e483 100644 --- a/configs/km_kirkwood_pci_defconfig +++ b/configs/km_kirkwood_pci_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/keymile/km_arm/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_KM_FPGA_CONFIG=y diff --git a/configs/kmcoge5un_defconfig b/configs/kmcoge5un_defconfig index 12aa23095cce..f46f45d64abf 100644 --- a/configs/kmcoge5un_defconfig +++ b/configs/kmcoge5un_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/keymile/km_arm/kwbimage_256M8_1.cfg" CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_PIGGY_MAC_ADDRESS_OFFSET=3 diff --git a/configs/kmnusa_defconfig b/configs/kmnusa_defconfig index 06b2d1fb571d..36965722cde3 100644 --- a/configs/kmnusa_defconfig +++ b/configs/kmnusa_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/keymile/km_arm/kwbimage_128M16_1.cfg" CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_KM_FPGA_CONFIG=y diff --git a/configs/kmsuse2_defconfig b/configs/kmsuse2_defconfig index a528bf5cfe90..a3079c04327e 100644 --- a/configs/kmsuse2_defconfig +++ b/configs/kmsuse2_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/keymile/km_arm/kwbimage_128M16_1.cfg" CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_KM_FPGA_CONFIG=y diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index 471b17e2efb3..dfcd39b4d5f4 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/buffalo/lsxl/kwbimage-lschl.cfg" CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_LSXL=y diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index 4188c3264f23..21e48949f9f0 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/buffalo/lsxl/kwbimage-lsxhl.cfg" CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_LSXL=y diff --git a/configs/nas220_defconfig b/configs/nas220_defconfig index 581d84518c17..d078714c2354 100644 --- a/configs/nas220_defconfig +++ b/configs/nas220_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/Seagate/nas220/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_NAS220=y diff --git a/configs/net2big_v2_defconfig b/configs/net2big_v2_defconfig index 083d3e6e0220..ed60c48a16bb 100644 --- a/configs/net2big_v2_defconfig +++ b/configs/net2big_v2_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/LaCie/net2big_v2/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_NET2BIG_V2=y diff --git a/configs/netspace_lite_v2_defconfig b/configs/netspace_lite_v2_defconfig index e671d994f765..51b413c99034 100644 --- a/configs/netspace_lite_v2_defconfig +++ b/configs/netspace_lite_v2_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/LaCie/netspace_v2/kwbimage-ns2l.cfg" CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_NETSPACE_V2=y diff --git a/configs/netspace_max_v2_defconfig b/configs/netspace_max_v2_defconfig index 607cb5a3f9a5..746854df77a5 100644 --- a/configs/netspace_max_v2_defconfig +++ b/configs/netspace_max_v2_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/LaCie/netspace_v2/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_NETSPACE_V2=y diff --git a/configs/netspace_mini_v2_defconfig b/configs/netspace_mini_v2_defconfig index 203071d37775..4cb5036fe96f 100644 --- a/configs/netspace_mini_v2_defconfig +++ b/configs/netspace_mini_v2_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/LaCie/netspace_v2/kwbimage-ns2l.cfg" CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_NETSPACE_V2=y diff --git a/configs/netspace_v2_defconfig b/configs/netspace_v2_defconfig index 84a2389d1780..51243a22a2dd 100644 --- a/configs/netspace_v2_defconfig +++ b/configs/netspace_v2_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/LaCie/netspace_v2/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_NETSPACE_V2=y diff --git a/configs/nsa310s_defconfig b/configs/nsa310s_defconfig index 501e82bcee2f..46ca3bac4797 100644 --- a/configs/nsa310s_defconfig +++ b/configs/nsa310s_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/zyxel/nsa310s/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_NSA310S=y diff --git a/configs/openrd_base_defconfig b/configs/openrd_base_defconfig index e79649ee7ea3..2c5a29cfe35f 100644 --- a/configs/openrd_base_defconfig +++ b/configs/openrd_base_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/Marvell/openrd/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_OPENRD=y diff --git a/configs/openrd_client_defconfig b/configs/openrd_client_defconfig index 9d924f3cbc91..b21d41b1ed4f 100644 --- a/configs/openrd_client_defconfig +++ b/configs/openrd_client_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/Marvell/openrd/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_OPENRD=y diff --git a/configs/openrd_ultimate_defconfig b/configs/openrd_ultimate_defconfig index 7c2e41e72e08..ceeb62109aa4 100644 --- a/configs/openrd_ultimate_defconfig +++ b/configs/openrd_ultimate_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/Marvell/openrd/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_OPENRD=y diff --git a/configs/pogo_e02_defconfig b/configs/pogo_e02_defconfig index 94885b888e90..10f08a515d96 100644 --- a/configs/pogo_e02_defconfig +++ b/configs/pogo_e02_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/cloudengines/pogo_e02/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_POGO_E02=y diff --git a/configs/sheevaplug_defconfig b/configs/sheevaplug_defconfig index 72304135cd40..6e39aa178a63 100644 --- a/configs/sheevaplug_defconfig +++ b/configs/sheevaplug_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/Marvell/sheevaplug/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_SHEEVAPLUG=y diff --git a/include/configs/SBx81LIFKW.h b/include/configs/SBx81LIFKW.h index 3ebeccc33bcd..6edc2b628ab4 100644 --- a/include/configs/SBx81LIFKW.h +++ b/include/configs/SBx81LIFKW.h @@ -6,11 +6,6 @@ #ifndef _CONFIG_SBX81LIFKW_H #define _CONFIG_SBX81LIFKW_H
-/* - * High Level Configuration Options (easy to change) - */ -#define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage.cfg - /* additions for new ARM relocation support */ #define CONFIG_SYS_SDRAM_BASE 0x00000000
diff --git a/include/configs/SBx81LIFXCAT.h b/include/configs/SBx81LIFXCAT.h index 53a6bdf0a302..50d02d3c1c97 100644 --- a/include/configs/SBx81LIFXCAT.h +++ b/include/configs/SBx81LIFXCAT.h @@ -6,11 +6,6 @@ #ifndef _CONFIG_SBX81LIFXCAT_H #define _CONFIG_SBX81LIFXCAT_H
diff --git a/include/configs/crs3xx-98dx3236.h b/include/configs/crs3xx-98dx3236.h index 27b45a7605d2..4dbc75826699 100644 --- a/include/configs/crs3xx-98dx3236.h +++ b/include/configs/crs3xx-98dx3236.h @@ -11,7 +11,6 @@ */
#define CONFIG_SYS_BOOTM_LEN (64 * 1024 * 1024) /* 64 MB */ -#define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage.cfg
/* Environment in SPI NOR flash */
diff --git a/include/configs/db-xc3-24g4xg.h b/include/configs/db-xc3-24g4xg.h index 6a4c5a7ab554..1d242bf4e650 100644 --- a/include/configs/db-xc3-24g4xg.h +++ b/include/configs/db-xc3-24g4xg.h @@ -6,12 +6,6 @@ #ifndef _CONFIG_DB_XC3_24G4G_H #define _CONFIG_DB_XC3_24G4G_H
-/* - * High Level Configuration Options (easy to change) - */ - -#define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage.cfg - /* Environment in SPI NOR flash */
/* NAND */ diff --git a/include/configs/km_kirkwood.h b/include/configs/km_kirkwood.h index 82c2a129223e..e58a69501b33 100644 --- a/include/configs/km_kirkwood.h +++ b/include/configs/km_kirkwood.h @@ -34,8 +34,6 @@ /* KM_KIRKWOOD_128M16 */ #elif defined(CONFIG_KM_KIRKWOOD_128M16) #define CONFIG_HOSTNAME "km_kirkwood_128m16" -#undef CONFIG_SYS_KWD_CONFIG -#define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage_128M16_1.cfg #define CONFIG_KM_DISABLE_PCIE
/* KM_NUSA */ @@ -43,21 +41,14 @@
#define CONFIG_HOSTNAME "kmnusa"
-#undef CONFIG_SYS_KWD_CONFIG -#define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage_128M16_1.cfg - /* KMCOGE5UN */ #elif defined(CONFIG_KM_COGE5UN) -#undef CONFIG_SYS_KWD_CONFIG -#define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage_256M8_1.cfg #define CONFIG_HOSTNAME "kmcoge5un" #define CONFIG_KM_DISABLE_PCIE
/* KM_SUSE2 */ #elif defined(CONFIG_KM_SUSE2) #define CONFIG_HOSTNAME "kmsuse2" -#undef CONFIG_SYS_KWD_CONFIG -#define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage_128M16_1.cfg #define CONFIG_KM_UBI_PART_BOOT_OPTS ",2048" #define CONFIG_SYS_NAND_NO_SUBPAGE_WRITE #else diff --git a/include/configs/lacie_kw.h b/include/configs/lacie_kw.h index d6c5425a9dd0..0d6dd30e0c4f 100644 --- a/include/configs/lacie_kw.h +++ b/include/configs/lacie_kw.h @@ -6,24 +6,6 @@ #ifndef _CONFIG_LACIE_KW_H #define _CONFIG_LACIE_KW_H
-/* - * SDRAM configuration - */ - -/* - * Different SDRAM configuration and size for some of the boards derived - * from the Network Space v2 - */ -#if defined(CONFIG_INETSPACE_V2) -#define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage-is2.cfg -#elif defined(CONFIG_NETSPACE_LITE_V2) || defined(CONFIG_NETSPACE_MINI_V2) -#define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage-ns2l.cfg -#endif - -/* - * mv-common.h should be defined after CMD configs since it used them - * to enable certain macros - */ #include "mv-common.h"
/* Remove or override few declarations from mv-common.h */ diff --git a/include/configs/lsxl.h b/include/configs/lsxl.h index 5891a1d8c594..fad69ab1f854 100644 --- a/include/configs/lsxl.h +++ b/include/configs/lsxl.h @@ -7,17 +7,6 @@ #ifndef _CONFIG_LSXL_H #define _CONFIG_LSXL_H
-/* - * Version number information - */ -#if defined(CONFIG_LSCHLV2) -#define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage-lschl.cfg -#elif defined(CONFIG_LSXHL) -#define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage-lsxhl.cfg -#else -#error "unknown board" -#endif - /* * General configuration options */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 43c53c764bbc..a248b5686fad 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1466,7 +1466,6 @@ CONFIG_SYS_JFFS2_FIRST_SECTOR CONFIG_SYS_JFFS2_NUM_BANKS CONFIG_SYS_KMBEC_FPGA_BASE CONFIG_SYS_KMBEC_FPGA_SIZE -CONFIG_SYS_KWD_CONFIG CONFIG_SYS_L2_PL310 CONFIG_SYS_L2_SIZE CONFIG_SYS_L3_SIZE
This converts the following to Kconfig: CONFIG_KIRKWOOD_GPIO
Signed-off-by: Tom Rini trini@konsulko.com --- configs/SBx81LIFKW_defconfig | 1 + configs/SBx81LIFXCAT_defconfig | 1 + configs/d2net_v2_defconfig | 1 + configs/dns325_defconfig | 1 + configs/inetspace_v2_defconfig | 1 + configs/km_kirkwood_128m16_defconfig | 1 + configs/km_kirkwood_defconfig | 1 + configs/km_kirkwood_pci_defconfig | 1 + configs/kmcoge5un_defconfig | 1 + configs/kmnusa_defconfig | 1 + configs/kmsuse2_defconfig | 1 + configs/lschlv2_defconfig | 1 + configs/lsxhl_defconfig | 1 + configs/nas220_defconfig | 1 + configs/net2big_v2_defconfig | 1 + configs/netspace_lite_v2_defconfig | 1 + configs/netspace_max_v2_defconfig | 1 + configs/netspace_mini_v2_defconfig | 1 + configs/netspace_v2_defconfig | 1 + drivers/gpio/Kconfig | 5 +++++ include/configs/SBx81LIFKW.h | 1 - include/configs/SBx81LIFXCAT.h | 1 - include/configs/dns325.h | 1 - include/configs/km/km_arm.h | 1 - include/configs/lacie_kw.h | 1 - include/configs/lsxl.h | 2 -- include/configs/nas220.h | 2 -- scripts/config_whitelist.txt | 1 - 28 files changed, 24 insertions(+), 10 deletions(-)
diff --git a/configs/SBx81LIFKW_defconfig b/configs/SBx81LIFKW_defconfig index ec7c7eb29565..77f44f6329ed 100644 --- a/configs/SBx81LIFKW_defconfig +++ b/configs/SBx81LIFKW_defconfig @@ -35,6 +35,7 @@ CONFIG_ENV_SPI_MAX_HZ=20000000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NETCONSOLE=y CONFIG_DM=y +CONFIG_KIRKWOOD_GPIO=y CONFIG_DM_PCA953X=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/SBx81LIFXCAT_defconfig b/configs/SBx81LIFXCAT_defconfig index a3ddabd65758..b84e3bd9d6ac 100644 --- a/configs/SBx81LIFXCAT_defconfig +++ b/configs/SBx81LIFXCAT_defconfig @@ -37,6 +37,7 @@ CONFIG_ENV_SPI_MAX_HZ=20000000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NETCONSOLE=y CONFIG_DM=y +CONFIG_KIRKWOOD_GPIO=y CONFIG_DM_PCA953X=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/d2net_v2_defconfig b/configs/d2net_v2_defconfig index 8e1bb2d4a01a..a856202d110e 100644 --- a/configs/d2net_v2_defconfig +++ b/configs/d2net_v2_defconfig @@ -47,6 +47,7 @@ CONFIG_ENV_ADDR=0x70000 CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SATA_MV=y +CONFIG_KIRKWOOD_GPIO=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x0 diff --git a/configs/dns325_defconfig b/configs/dns325_defconfig index c1da0f545c63..144fd30706b5 100644 --- a/configs/dns325_defconfig +++ b/configs/dns325_defconfig @@ -41,6 +41,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_NETCONSOLE=y CONFIG_DM=y +CONFIG_KIRKWOOD_GPIO=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/inetspace_v2_defconfig b/configs/inetspace_v2_defconfig index 0af49d45f0c3..8779e58b9322 100644 --- a/configs/inetspace_v2_defconfig +++ b/configs/inetspace_v2_defconfig @@ -47,6 +47,7 @@ CONFIG_ENV_ADDR=0x70000 CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SATA_MV=y +CONFIG_KIRKWOOD_GPIO=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x0 diff --git a/configs/km_kirkwood_128m16_defconfig b/configs/km_kirkwood_128m16_defconfig index c9832d3d51e4..f4b1abfd6a9d 100644 --- a/configs/km_kirkwood_128m16_defconfig +++ b/configs/km_kirkwood_128m16_defconfig @@ -49,6 +49,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_NETCONSOLE=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y +CONFIG_KIRKWOOD_GPIO=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_SOFT=y CONFIG_SYS_I2C_SOFT_SLAVE=0x0 diff --git a/configs/km_kirkwood_defconfig b/configs/km_kirkwood_defconfig index b0a268e370d5..eba4f097775d 100644 --- a/configs/km_kirkwood_defconfig +++ b/configs/km_kirkwood_defconfig @@ -49,6 +49,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_NETCONSOLE=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y +CONFIG_KIRKWOOD_GPIO=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_SOFT=y CONFIG_SYS_I2C_SOFT_SLAVE=0x0 diff --git a/configs/km_kirkwood_pci_defconfig b/configs/km_kirkwood_pci_defconfig index 38c4c1e2e483..5d19c5117602 100644 --- a/configs/km_kirkwood_pci_defconfig +++ b/configs/km_kirkwood_pci_defconfig @@ -50,6 +50,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_NETCONSOLE=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y +CONFIG_KIRKWOOD_GPIO=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_SOFT=y CONFIG_SYS_I2C_SOFT_SLAVE=0x0 diff --git a/configs/kmcoge5un_defconfig b/configs/kmcoge5un_defconfig index f46f45d64abf..9124504e3232 100644 --- a/configs/kmcoge5un_defconfig +++ b/configs/kmcoge5un_defconfig @@ -53,6 +53,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_NETCONSOLE=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y +CONFIG_KIRKWOOD_GPIO=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_SOFT=y CONFIG_SYS_I2C_SOFT_SLAVE=0x0 diff --git a/configs/kmnusa_defconfig b/configs/kmnusa_defconfig index 36965722cde3..d81c78761202 100644 --- a/configs/kmnusa_defconfig +++ b/configs/kmnusa_defconfig @@ -53,6 +53,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_NETCONSOLE=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y +CONFIG_KIRKWOOD_GPIO=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_SOFT=y CONFIG_SYS_I2C_SOFT_SLAVE=0x0 diff --git a/configs/kmsuse2_defconfig b/configs/kmsuse2_defconfig index a3079c04327e..d274c9576414 100644 --- a/configs/kmsuse2_defconfig +++ b/configs/kmsuse2_defconfig @@ -54,6 +54,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_NETCONSOLE=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y +CONFIG_KIRKWOOD_GPIO=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_SOFT=y CONFIG_SYS_I2C_SOFT_SLAVE=0x0 diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index dfcd39b4d5f4..497da09d4399 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -39,6 +39,7 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SATA_MV=y +CONFIG_KIRKWOOD_GPIO=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index 21e48949f9f0..cadeb9afd3cb 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -39,6 +39,7 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SATA_MV=y +CONFIG_KIRKWOOD_GPIO=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/nas220_defconfig b/configs/nas220_defconfig index d078714c2354..259eb2fa32ce 100644 --- a/configs/nas220_defconfig +++ b/configs/nas220_defconfig @@ -42,6 +42,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NETCONSOLE=y CONFIG_DM=y +CONFIG_KIRKWOOD_GPIO=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/net2big_v2_defconfig b/configs/net2big_v2_defconfig index ed60c48a16bb..985f530fb873 100644 --- a/configs/net2big_v2_defconfig +++ b/configs/net2big_v2_defconfig @@ -48,6 +48,7 @@ CONFIG_ENV_ADDR=0x70000 CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SATA_MV=y +CONFIG_KIRKWOOD_GPIO=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x0 diff --git a/configs/netspace_lite_v2_defconfig b/configs/netspace_lite_v2_defconfig index 51b413c99034..668f4ea291d4 100644 --- a/configs/netspace_lite_v2_defconfig +++ b/configs/netspace_lite_v2_defconfig @@ -48,6 +48,7 @@ CONFIG_ENV_ADDR=0x70000 CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SATA_MV=y +CONFIG_KIRKWOOD_GPIO=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x0 diff --git a/configs/netspace_max_v2_defconfig b/configs/netspace_max_v2_defconfig index 746854df77a5..25ce3c61a1f8 100644 --- a/configs/netspace_max_v2_defconfig +++ b/configs/netspace_max_v2_defconfig @@ -48,6 +48,7 @@ CONFIG_ENV_ADDR=0x70000 CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SATA_MV=y +CONFIG_KIRKWOOD_GPIO=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x0 diff --git a/configs/netspace_mini_v2_defconfig b/configs/netspace_mini_v2_defconfig index 4cb5036fe96f..0c9a3036eb13 100644 --- a/configs/netspace_mini_v2_defconfig +++ b/configs/netspace_mini_v2_defconfig @@ -47,6 +47,7 @@ CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SATA_MV=y CONFIG_BLK=y +CONFIG_KIRKWOOD_GPIO=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x0 diff --git a/configs/netspace_v2_defconfig b/configs/netspace_v2_defconfig index 51243a22a2dd..8f662edd1682 100644 --- a/configs/netspace_v2_defconfig +++ b/configs/netspace_v2_defconfig @@ -48,6 +48,7 @@ CONFIG_ENV_ADDR=0x70000 CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SATA_MV=y +CONFIG_KIRKWOOD_GPIO=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x0 diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index 40abc33772eb..b41a755fc758 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -177,6 +177,11 @@ config HSDK_CREG_GPIO help This driver supports CREG GPIOs on Synopsys HSDK SOC.
+config KIRKWOOD_GPIO + bool "Kirkwood GPIO driver" + help + This drdiver supports GPIOs on Kirkwood platforms + config LPC32XX_GPIO bool "LPC32XX GPIO driver" depends on DM diff --git a/include/configs/SBx81LIFKW.h b/include/configs/SBx81LIFKW.h index 6edc2b628ab4..dbaffc635d24 100644 --- a/include/configs/SBx81LIFKW.h +++ b/include/configs/SBx81LIFKW.h @@ -12,7 +12,6 @@ #define CONFIG_KIRKWOOD_EGIGA_INIT /* Enable GbePort0/1 for kernel */ #define CONFIG_KIRKWOOD_PCIE_INIT /* Enable PCIE Port0 */ #define CONFIG_KIRKWOOD_RGMII_PAD_1V8 /* Set RGMII Pad voltage to 1.8V */ -#define CONFIG_KIRKWOOD_GPIO 1
/* * NS16550 Configuration diff --git a/include/configs/SBx81LIFXCAT.h b/include/configs/SBx81LIFXCAT.h index 50d02d3c1c97..bbd3ccc6d9d2 100644 --- a/include/configs/SBx81LIFXCAT.h +++ b/include/configs/SBx81LIFXCAT.h @@ -12,7 +12,6 @@ #define CONFIG_KIRKWOOD_EGIGA_INIT /* Enable GbePort0/1 for kernel */ #define CONFIG_KIRKWOOD_PCIE_INIT /* Enable PCIE Port0 */ #define CONFIG_KIRKWOOD_RGMII_PAD_1V8 /* Set RGMII Pad voltage to 1.8V */ -#define CONFIG_KIRKWOOD_GPIO 1
/* * NS16550 Configuration diff --git a/include/configs/dns325.h b/include/configs/dns325.h index e35c16add4dd..0590704000ec 100644 --- a/include/configs/dns325.h +++ b/include/configs/dns325.h @@ -26,7 +26,6 @@ /* * Enable GPI0 support */ -#define CONFIG_KIRKWOOD_GPIO
/* * Environment variables configurations diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index 6501884d32ce..a485c3ac6d1d 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -68,7 +68,6 @@ #undef CONFIG_I2C_MVTWSI #define CONFIG_SYS_I2C_INIT_BOARD
-#define CONFIG_KIRKWOOD_GPIO /* Enable GPIO Support */ #define CONFIG_SYS_NUM_I2C_BUSES 6 #define CONFIG_SYS_I2C_MAX_HOPS 1 #define CONFIG_SYS_I2C_BUSES { {0, {I2C_NULL_HOP} }, \ diff --git a/include/configs/lacie_kw.h b/include/configs/lacie_kw.h index 0d6dd30e0c4f..046f1888cb18 100644 --- a/include/configs/lacie_kw.h +++ b/include/configs/lacie_kw.h @@ -41,7 +41,6 @@ /* * Enable GPI0 support */ -#define CONFIG_KIRKWOOD_GPIO
/* * Enable I2C support diff --git a/include/configs/lsxl.h b/include/configs/lsxl.h index fad69ab1f854..afa0206fb93a 100644 --- a/include/configs/lsxl.h +++ b/include/configs/lsxl.h @@ -11,8 +11,6 @@ * General configuration options */
-#define CONFIG_KIRKWOOD_GPIO - #include "mv-common.h"
/* loading initramfs images without uimage header */ diff --git a/include/configs/nas220.h b/include/configs/nas220.h index 12480d9d5525..a4347ae1aa15 100644 --- a/include/configs/nas220.h +++ b/include/configs/nas220.h @@ -63,6 +63,4 @@ * EFI partition */
-#define CONFIG_KIRKWOOD_GPIO - #endif /* _CONFIG_NAS220_H */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index a248b5686fad..69835e5e5b9d 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -470,7 +470,6 @@ CONFIG_JRSTARTR_JR0 CONFIG_KEEP_SERVERADDR CONFIG_KEY_REVOCATION CONFIG_KIRKWOOD_EGIGA_INIT -CONFIG_KIRKWOOD_GPIO CONFIG_KIRKWOOD_PCIE_INIT CONFIG_KIRKWOOD_RGMII_PAD_1V8 CONFIG_KM8321
This converts the following to Kconfig: CONFIG_JFFS2_DEV CONFIG_JFFS2_LZO CONFIG_JFFS2_NAND CONFIG_JFFS2_PART_OFFSET CONFIG_JFFS2_PART_SIZE
Signed-off-by: Tom Rini trini@konsulko.com --- README | 3 --- cmd/Kconfig | 21 +++++++++++++++++++++ cmd/jffs2.c | 12 ------------ configs/devkit8000_defconfig | 4 ++++ configs/ethernut5_defconfig | 1 + configs/ids8313_defconfig | 1 + configs/nas220_defconfig | 2 ++ configs/pm9263_defconfig | 3 +++ fs/jffs2/Kconfig | 12 ++++++++++++ include/configs/M5329EVB.h | 4 ---- include/configs/M5373EVB.h | 4 ---- include/configs/devkit8000.h | 9 --------- include/configs/ethernut5.h | 3 --- include/configs/ids8313.h | 3 --- include/configs/imx27lite-common.h | 1 - include/configs/nas220.h | 6 ------ include/configs/pm9263.h | 5 ----- include/configs/stmark2.h | 3 --- scripts/config_whitelist.txt | 4 ---- 19 files changed, 44 insertions(+), 57 deletions(-)
diff --git a/README b/README index 7d46c567a3f9..e1d74b3aa86e 100644 --- a/README +++ b/README @@ -1028,9 +1028,6 @@ The following options need to be configured: sending again an USB request to the device.
- Journaling Flash filesystem support: - CONFIG_JFFS2_NAND - Define these for a default partition on a NAND device - CONFIG_SYS_JFFS2_FIRST_SECTOR, CONFIG_SYS_JFFS2_FIRST_BANK, CONFIG_SYS_JFFS2_NUM_BANKS Define these for a default partition on a NOR device diff --git a/cmd/Kconfig b/cmd/Kconfig index 7747ab50a042..ef82f794b557 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -2219,6 +2219,27 @@ config CMD_JFFS2 provide the ability to load files, list directories and obtain filesystem information.
+config JFFS2_DEV + string "Default device for JFFS2" + depends on CMD_JFFS2 + default "nor0" + help + The default device to use with the jffs2 command. + +config JFFS2_PART_OFFSET + hex "Default offset within flash to locate the JFFS2 image" + depends on CMD_JFFS2 + default 0x0 + help + The default offset within flash to locate the JFFS2 image. + +config JFFS2_PART_SIZE + hex "Default size of JFFS2 partition" + depends on CMD_JFFS2 + default 0xFFFFFFFF + help + The default size of the JFFS2 partition + config CMD_MTDPARTS bool "MTD partition support" depends on MTD diff --git a/cmd/jffs2.c b/cmd/jffs2.c index 63bd55263a29..6f15b57b6a18 100644 --- a/cmd/jffs2.c +++ b/cmd/jffs2.c @@ -360,11 +360,7 @@ int mtdparts_init(void) /* id */ id->mtd_id = "single part";
-#if defined(CONFIG_JFFS2_DEV) dev_name = CONFIG_JFFS2_DEV; -#else - dev_name = "nor0"; -#endif
if ((mtd_id_parse(dev_name, NULL, &id->type, &id->num) != 0) || (mtd_device_validate(id->type, id->num, &size) != 0)) { @@ -382,17 +378,9 @@ int mtdparts_init(void) part->name = "static"; part->auto_name = 0;
-#if defined(CONFIG_JFFS2_PART_SIZE) part->size = CONFIG_JFFS2_PART_SIZE; -#else - part->size = SIZE_REMAINING; -#endif
-#if defined(CONFIG_JFFS2_PART_OFFSET) part->offset = CONFIG_JFFS2_PART_OFFSET; -#else - part->offset = 0x00000000; -#endif
part->dev = current_mtd_dev; INIT_LIST_HEAD(&part->link); diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index 4017eb69add8..4034f9ca7512 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -27,6 +27,9 @@ CONFIG_CMD_NAND_LOCK_UNLOCK=y CONFIG_BOOTP_DNS2=y CONFIG_BOOTP_NTPSERVER=y CONFIG_CMD_JFFS2=y +CONFIG_JFFS2_DEV="nand0" +CONFIG_JFFS2_PART_OFFSET=0x680000 +CONFIG_JFFS2_PART_SIZE=0xF980000 CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:512k(x-loader),1920k(u-boot),128k(u-boot-env),4m(kernel),-(fs)" @@ -50,4 +53,5 @@ CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_CONS_INDEX=3 +CONFIG_JFFS2_NAND=y CONFIG_OF_LIBFDT=y diff --git a/configs/ethernut5_defconfig b/configs/ethernut5_defconfig index e7ebfef38619..1821b23ed5f2 100644 --- a/configs/ethernut5_defconfig +++ b/configs/ethernut5_defconfig @@ -81,3 +81,4 @@ CONFIG_ATMEL_USART=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_USB=y +CONFIG_JFFS2_NAND=y diff --git a/configs/ids8313_defconfig b/configs/ids8313_defconfig index 4ee97ae55557..246cc3d045f8 100644 --- a/configs/ids8313_defconfig +++ b/configs/ids8313_defconfig @@ -199,4 +199,5 @@ CONFIG_TSEC_ENET=y CONFIG_RTC_PCF8563=y CONFIG_SYS_NS16550=y CONFIG_WATCHDOG=y +CONFIG_JFFS2_NAND=y CONFIG_OF_LIBFDT=y diff --git a/configs/nas220_defconfig b/configs/nas220_defconfig index 259eb2fa32ce..7e4e19a9f788 100644 --- a/configs/nas220_defconfig +++ b/configs/nas220_defconfig @@ -54,3 +54,5 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y +CONFIG_JFFS2_LZO=y +CONFIG_JFFS2_NAND=y diff --git a/configs/pm9263_defconfig b/configs/pm9263_defconfig index c755aaaae973..e8a5b4df9bdf 100644 --- a/configs/pm9263_defconfig +++ b/configs/pm9263_defconfig @@ -31,6 +31,8 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_JFFS2=y +CONFIG_JFFS2_DEV="nand0" +CONFIG_JFFS2_PART_SIZE=0x10000000 CONFIG_MTDIDS_DEFAULT="nor0=physmap-flash.0,nand0=nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=physmap-flash.0:256k(u-boot)ro,64k(u-boot-env)ro,1408k(kernel),-(rootfs);nand:-(nand)" CONFIG_OF_CONTROL=y @@ -63,3 +65,4 @@ CONFIG_USB=y CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP32 is not set CONFIG_LCD=y +CONFIG_JFFS2_NAND=y diff --git a/fs/jffs2/Kconfig b/fs/jffs2/Kconfig index 1b9ecdd8cca3..0e79c3409062 100644 --- a/fs/jffs2/Kconfig +++ b/fs/jffs2/Kconfig @@ -5,3 +5,15 @@ config FS_JFFS2 Flash File System version 2). JFFS2 is a log-structured file system for use with flash memory devices. It supports raw NAND devices, hard links and compression. + +config JFFS2_LZO + bool "Enable LZO compression in JFFS2" + depends on FS_JFFS2 + help + Enable LZO compression in the JFFS2 filesystem + +config JFFS2_NAND + bool "Enable JFFS2 support for NAND flash" + depends on FS_JFFS2 + help + Enable support for NAND flash as the backing store for JFFS2. diff --git a/include/configs/M5329EVB.h b/include/configs/M5329EVB.h index 16343b5d3864..f96f54ef65bc 100644 --- a/include/configs/M5329EVB.h +++ b/include/configs/M5329EVB.h @@ -135,10 +135,6 @@ # define CONFIG_SYS_NAND_SIZE 1 # define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } # define NAND_ALLOW_ERASE_ALL 1 -# define CONFIG_JFFS2_NAND 1 -# define CONFIG_JFFS2_DEV "nand0" -# define CONFIG_JFFS2_PART_SIZE (CONFIG_SYS_CS2_MASK & ~1) -# define CONFIG_JFFS2_PART_OFFSET 0x00000000 #endif
#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_CS0_BASE diff --git a/include/configs/M5373EVB.h b/include/configs/M5373EVB.h index ccc59ebed253..b7906013e09e 100644 --- a/include/configs/M5373EVB.h +++ b/include/configs/M5373EVB.h @@ -137,10 +137,6 @@ # define CONFIG_SYS_NAND_SIZE 1 # define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } # define NAND_ALLOW_ERASE_ALL 1 -# define CONFIG_JFFS2_NAND 1 -# define CONFIG_JFFS2_DEV "nand0" -# define CONFIG_JFFS2_PART_SIZE (CONFIG_SYS_CS2_MASK & ~1) -# define CONFIG_JFFS2_PART_OFFSET 0x00000000 #endif
#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_CS0_BASE diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index d813d924a689..9282f8372850 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -46,15 +46,6 @@
/* TWL4030 */
-/* Board NAND Info */ -#define CONFIG_JFFS2_NAND -/* nand device jffs2 lives on */ -#define CONFIG_JFFS2_DEV "nand0" -/* start of jffs2 partition */ -#define CONFIG_JFFS2_PART_OFFSET 0x680000 -#define CONFIG_JFFS2_PART_SIZE 0xf980000 /* size of jffs2 */ - /* partition */ - /* BOOTP/DHCP options */ #define CONFIG_BOOTP_NISDOMAIN #define CONFIG_BOOTP_BOOTFILESIZE diff --git a/include/configs/ethernut5.h b/include/configs/ethernut5.h index 75409a4eccac..ccf615efa3df 100644 --- a/include/configs/ethernut5.h +++ b/include/configs/ethernut5.h @@ -54,9 +54,6 @@ #endif
/* JFFS2 */ -#ifdef CONFIG_CMD_JFFS2 -#define CONFIG_JFFS2_NAND -#endif
/* Ethernet */ #define CONFIG_NET_RETRY_COUNT 20 diff --git a/include/configs/ids8313.h b/include/configs/ids8313.h index c88c72dfddab..206a57a65325 100644 --- a/include/configs/ids8313.h +++ b/include/configs/ids8313.h @@ -233,9 +233,6 @@ #define CONFIG_TIMESTAMP #undef CONFIG_SYS_LOADS_BAUD_CHANGE
-#define CONFIG_JFFS2_NAND -#define CONFIG_JFFS2_DEV "0" - /* mtdparts command line support */
#define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/imx27lite-common.h b/include/configs/imx27lite-common.h index c289d694e9b3..dffe175f50af 100644 --- a/include/configs/imx27lite-common.h +++ b/include/configs/imx27lite-common.h @@ -103,7 +103,6 @@ #define CONFIG_MXC_NAND_REGS_BASE 0xd8000000 #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BASE 0xd8000000 -#define CONFIG_JFFS2_NAND #define CONFIG_MXC_NAND_HWECC
/* diff --git a/include/configs/nas220.h b/include/configs/nas220.h index a4347ae1aa15..815f81f6493d 100644 --- a/include/configs/nas220.h +++ b/include/configs/nas220.h @@ -53,12 +53,6 @@ #define CONFIG_PHY_BASE_ADR 8 #endif /* CONFIG_CMD_NET */
-/* - * File system - */ -#define CONFIG_JFFS2_NAND -#define CONFIG_JFFS2_LZO - /* * EFI partition */ diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index d4f787029810..e9eb736ecb1a 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -179,11 +179,6 @@
#endif
-#define CONFIG_JFFS2_NAND 1 -#define CONFIG_JFFS2_DEV "nand0" /* NAND device jffs2 lives on */ -#define CONFIG_JFFS2_PART_OFFSET 0 /* start of jffs2 partition */ -#define CONFIG_JFFS2_PART_SIZE (256 * 1024 * 1024) /* partition size*/ - /* PSRAM */ #define PHYS_PSRAM 0x70000000 #define PHYS_PSRAM_SIZE 0x00400000 /* 4MB */ diff --git a/include/configs/stmark2.h b/include/configs/stmark2.h index 1a5cf6b78110..18a57f2231b6 100644 --- a/include/configs/stmark2.h +++ b/include/configs/stmark2.h @@ -41,9 +41,6 @@ #define CONFIG_RTC_MCFRRTC #define CONFIG_SYS_MCFRRTC_BASE 0xFC0A8000
-/* spi not partitions */ -#define CONFIG_JFFS2_DEV "nor0" - /* Timer */ #define CONFIG_MCFTMR
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 69835e5e5b9d..f57c389492c2 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -461,10 +461,6 @@ CONFIG_IRAM_SIZE CONFIG_IRAM_STACK CONFIG_IRAM_TOP CONFIG_IRDA_BASE -CONFIG_JFFS2_DEV -CONFIG_JFFS2_LZO -CONFIG_JFFS2_NAND -CONFIG_JFFS2_PART_OFFSET CONFIG_JFFS2_PART_SIZE CONFIG_JRSTARTR_JR0 CONFIG_KEEP_SERVERADDR
On Fri, Dec 17, 2021 at 06:08:36PM -0500, Tom Rini wrote:
This converts the following to Kconfig: CONFIG_83XX_PCICLK
