[U-Boot] [PATCH 4/4] armv8: ls2085qds: Add support of X-QSGMII-16PORT riser card
The X-QSGMII-16PORT is a 4xQSGMII/8xSGMII riser card with eighth SerDes interfaces implemented in PCIe form factor board. It supports followings - Card can operate with up to 4 QSGMII lane simultaneously - Card can operate with up to 8 SGMII lane simultaneously
Add support of X-QSGMII-16PORT riser card. This patch also take care of back-ward compatiblity with old SGMII rise cards used on LS2085QDS Platform.
Signed-off-by: King Chung Lo@freescale.com KingChungLo@freescale.com Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- board/freescale/ls2085aqds/README | 81 +++++++ board/freescale/ls2085aqds/eth.c | 466 +++++++++++++++++++++++++++++++++++++- include/configs/ls2085aqds.h | 17 ++ 3 files changed, 553 insertions(+), 11 deletions(-)
diff --git a/board/freescale/ls2085aqds/README b/board/freescale/ls2085aqds/README index 11b2e79..e4a6f69 100644 --- a/board/freescale/ls2085aqds/README +++ b/board/freescale/ls2085aqds/README @@ -146,3 +146,84 @@ below: earlycon=uart8250,mmio,0x21c0600,115200 default_hugepagesz=2m hugepagesz=2m hugepages=16 mem=2048M'
+ +X-QSGMII-16PORT riser card +---------------------------- +The X-QSGMII-16PORT is a 4xQSGMII/8xSGMII riser card with eighth SerDes +interfaces implemented in PCIe form factor board. +It supports followings + - Card can operate with up to 4 QSGMII lane simultaneously + - Card can operate with up to 8 SGMII lane simultaneously + +Supported card configuration + - CSEL : ON ON ON ON + - MSEL1 : ON ON ON ON OFF OFF OFF OFF + - MSEL2 : OFF OFF OFF OFF ON ON ON ON + +To enable this card: modify hwconfig to add "xqsgmii" variable. + +Supported PHY addresses during SGMII: +#define XQSGMII_CARD_PHY1_PORT0_ADDR 0x0 +#define XQSGMII_CARD_PHY1_PORT2_ADDR 0x2 +#define XQSGMII_CARD_PHY2_PORT0_ADDR 0x4 +#define XQSGMII_CARD_PHY2_PORT2_ADDR 0x6 +#define XQSGMII_CARD_PHY3_PORT0_ADDR 0x8 +#define XQSGMII_CARD_PHY3_PORT2_ADDR 0xa +#define XQSGMII_CARD_PHY4_PORT0_ADDR 0xc +#define XQSGMII_CARD_PHY4_PORT2_ADDR 0xe + +Mapping DPMACx to PHY during QSGMII +DPMAC1 -> PHY1-P0 +DPMAC2 -> PHY2-P0 +DPMAC3 -> PHY3-P0 +DPMAC4 -> PHY4-P0 +DPMAC5 -> PHY3-P2 +DPMAC6 -> PHY1-P2 +DPMAC7 -> PHY4-P1 +DPMAC8 -> PHY2-P2 +DPMAC9 -> PHY1-P0 +DPMAC10 -> PHY2-P0 +DPMAC11 -> PHY3-P0 +DPMAC12 -> PHY4-P0 +DPMAC13 -> PHY3-P2 +DPMAC14 -> PHY1-P2 +DPMAC15 -> PHY4-P1 +DPMAC16 -> PHY2-P2 + + +Supported PHY address during QSGMII +#define XQSGMII_CARD_PHY1_PORT0_ADDR 0x0 +#define XQSGMII_CARD_PHY1_PORT1_ADDR 0x1 +#define XQSGMII_CARD_PHY1_PORT2_ADDR 0x2 +#define XQSGMII_CARD_PHY1_PORT3_ADDR 0x3 +#define XQSGMII_CARD_PHY2_PORT0_ADDR 0x4 +#define XQSGMII_CARD_PHY2_PORT1_ADDR 0x5 +#define XQSGMII_CARD_PHY2_PORT2_ADDR 0x6 +#define XQSGMII_CARD_PHY2_PORT3_ADDR 0x7 +#define XQSGMII_CARD_PHY3_PORT0_ADDR 0x8 +#define XQSGMII_CARD_PHY3_PORT1_ADDR 0x9 +#define XQSGMII_CARD_PHY3_PORT2_ADDR 0xa +#define XQSGMII_CARD_PHY3_PORT3_ADDR 0xb +#define XQSGMII_CARD_PHY4_PORT0_ADDR 0xc +#define XQSGMII_CARD_PHY4_PORT1_ADDR 0xd +#define XQSGMII_CARD_PHY4_PORT2_ADDR 0xe +#define XQSGMII_CARD_PHY4_PORT3_ADDR 0xf + +Mapping DPMACx to PHY during QSGMII +DPMAC1 -> PHY1-P3 +DPMAC2 -> PHY1-P2 +DPMAC3 -> PHY1-P1 +DPMAC4 -> PHY1-P0 +DPMAC5 -> PHY2-P3 +DPMAC6 -> PHY2-P2 +DPMAC7 -> PHY2-P1 +DPMAC8 -> PHY2-P0 +DPMAC9 -> PHY3-P0 +DPMAC10 -> PHY3-P1 +DPMAC11 -> PHY3-P2 +DPMAC12 -> PHY3-P3 +DPMAC13 -> PHY4-P0 +DPMAC14 -> PHY4-P1 +DPMAC15 -> PHY4-P2 +DPMAC16 -> PHY4-P3 + diff --git a/board/freescale/ls2085aqds/eth.c b/board/freescale/ls2085aqds/eth.c index 1f8a31f..007b433 100644 --- a/board/freescale/ls2085aqds/eth.c +++ b/board/freescale/ls2085aqds/eth.c @@ -9,9 +9,12 @@ #include <asm/io.h> #include <asm/arch/fsl_serdes.h> #include <asm/arch-fsl-lsch3/immap_lsch3.h> +#include <hwconfig.h> #include <fsl_mdio.h> #include <malloc.h> #include <fm_eth.h> +#include <i2c.h> +#include <miiphy.h> #include <fsl-mc/ldpaa_wriop.h>
#include "../common/qixis.h" @@ -30,6 +33,10 @@ * maps to something other than a board slot. */
+static u8 lane_to_slot_fsm1[] = { + 0, 0, 0, 0, 0, 0, 0, 0 +}; + static u8 lane_to_slot_fsm2[] = { 0, 0, 0, 0, 0, 0, 0, 0 }; @@ -37,7 +44,19 @@ static u8 lane_to_slot_fsm2[] = { /* On the Vitesse VSC8234XHG SGMII riser card there are 4 SGMII PHYs * housed. */ -static int riser_phy_addr[] = { + +static int xqsgii_riser_phy_addr[] = { + XQSGMII_CARD_PHY1_PORT0_ADDR, + XQSGMII_CARD_PHY2_PORT0_ADDR, + XQSGMII_CARD_PHY3_PORT0_ADDR, + XQSGMII_CARD_PHY4_PORT0_ADDR, + XQSGMII_CARD_PHY3_PORT2_ADDR, + XQSGMII_CARD_PHY1_PORT2_ADDR, + XQSGMII_CARD_PHY4_PORT2_ADDR, + XQSGMII_CARD_PHY2_PORT2_ADDR, +}; + +static int sgmii_riser_phy_addr[] = { SGMII_CARD_PORT1_PHY_ADDR, SGMII_CARD_PORT2_PHY_ADDR, SGMII_CARD_PORT3_PHY_ADDR, @@ -70,6 +89,236 @@ struct ls2085a_qds_mdio { struct mii_dev *realbus; };
+static void sgmii_configure_repeater(int serdes_port) +{ + struct mii_dev *bus; + uint8_t a = 0xf; + int i, j, ret; + int dpmac_id = 0, dpmac, mii_bus = 0; + unsigned short value; + char dev[2][20] = {"LS2085A_QDS_MDIO0", "LS2085A_QDS_MDIO3"}; + uint8_t i2c_addr[] = {0x58, 0x59, 0x5a, 0x5b, 0x5c, 0x5d, 0x5f, 0x60}; + + uint8_t ch_a_eq[] = {0x1, 0x2, 0x3, 0x7}; + uint8_t ch_a_ctl2[] = {0x81, 0x82, 0x83, 0x84}; + uint8_t ch_b_eq[] = {0x1, 0x2, 0x3, 0x7}; + uint8_t ch_b_ctl2[] = {0x81, 0x82, 0x83, 0x84}; + + int *riser_phy_addr = &xqsgii_riser_phy_addr[0]; + + /* Set I2c to Slot 1 */ + i2c_write(0x77, 0, 0, &a, 1); + + for (dpmac = 0; dpmac < 8; dpmac++) { + /* Check the PHY status */ + switch (serdes_port) { + case 1: + mii_bus = 0; + dpmac_id = dpmac + 1; + break; + case 2: + mii_bus = 1; + dpmac_id = dpmac + 9; + a = 0xb; + i2c_write(0x76, 0, 0, &a, 1); + break; + } + + ret = miiphy_set_current_dev(dev[mii_bus]); + if (ret > 0) + goto error; + + bus = mdio_get_current_dev(); + debug("Reading from bus %s\n", bus->name); + + ret = miiphy_write(dev[mii_bus], riser_phy_addr[dpmac], 0x1f, + 3); + if (ret > 0) + goto error; + + mdelay(10); + ret = miiphy_read(dev[mii_bus], riser_phy_addr[dpmac], 0x11, + &value); + if (ret > 0) + goto error; + + mdelay(10); + + if ((value & 0xfff) == 0x40f) { + printf("DPMAC %d:PHY is ..... Configured\n", dpmac_id); + continue; + } + + for (i = 0; i < 4; i++) { + for (j = 0; j < 4; j++) { + a = 0x18; + i2c_write(i2c_addr[dpmac], 6, 1, &a, 1); + a = 0x38; + i2c_write(i2c_addr[dpmac], 4, 1, &a, 1); + a = 0x4; + i2c_write(i2c_addr[dpmac], 8, 1, &a, 1); + + i2c_write(i2c_addr[dpmac], 0xf, 1, + &ch_a_eq[i], 1); + i2c_write(i2c_addr[dpmac], 0x11, 1, + &ch_a_ctl2[j], 1); + + i2c_write(i2c_addr[dpmac], 0x16, 1, + &ch_b_eq[i], 1); + i2c_write(i2c_addr[dpmac], 0x18, 1, + &ch_b_ctl2[j], 1); + + a = 0x14; + i2c_write(i2c_addr[dpmac], 0x23, 1, &a, 1); + a = 0xb5; + i2c_write(i2c_addr[dpmac], 0x2d, 1, &a, 1); + a = 0x20; + i2c_write(i2c_addr[dpmac], 4, 1, &a, 1); + mdelay(100); + ret = miiphy_read(dev[mii_bus], + riser_phy_addr[dpmac], + 0x11, &value); + if (ret > 0) + goto error; + + mdelay(1); + ret = miiphy_read(dev[mii_bus], + riser_phy_addr[dpmac], + 0x11, &value); + if (ret > 0) + goto error; + mdelay(10); + + if ((value & 0xfff) == 0x40f) { + printf("DPMAC %d :PHY is configured ", + dpmac_id); + printf("after setting repeater 0x%x\n", + value); + i = 5; + j = 5; + } else + printf("DPMAC %d :PHY is failed to ", + dpmac_id); + printf("configure the repeater 0x%x\n", + value); + } + } + } +error: + if (ret) + printf("DPMAC %d ..... FAILED to configure PHY\n", dpmac_id); + return; +} + +static void qsgmii_configure_repeater(int dpmac) +{ + uint8_t a = 0xf; + int i, j; + int i2c_phy_addr = 0; + int phy_addr = 0; + int i2c_addr[] = {0x58, 0x59, 0x5a, 0x5b}; + + uint8_t ch_a_eq[] = {0x1, 0x2, 0x3, 0x7}; + uint8_t ch_a_ctl2[] = {0x81, 0x82, 0x83, 0x84}; + uint8_t ch_b_eq[] = {0x1, 0x2, 0x3, 0x7}; + uint8_t ch_b_ctl2[] = {0x81, 0x82, 0x83, 0x84}; + + const char *dev = "LS2085A_QDS_MDIO0"; + int ret = 0; + unsigned short value; + + /* Set I2c to Slot 1 */ + i2c_write(0x77, 0, 0, &a, 1); + + switch (dpmac) { + case 1: + case 2: + case 3: + case 4: + i2c_phy_addr = i2c_addr[0]; + phy_addr = 0; + break; + + case 5: + case 6: + case 7: + case 8: + i2c_phy_addr = i2c_addr[1]; + phy_addr = 4; + break; + + case 9: + case 10: + case 11: + case 12: + i2c_phy_addr = i2c_addr[2]; + phy_addr = 8; + break; + + case 13: + case 14: + case 15: + case 16: + i2c_phy_addr = i2c_addr[3]; + phy_addr = 0xc; + break; + } + + /* Check the PHY status */ + ret = miiphy_set_current_dev(dev); + ret = miiphy_write(dev, phy_addr, 0x1f, 3); + mdelay(10); + ret = miiphy_read(dev, phy_addr, 0x11, &value); + mdelay(10); + ret = miiphy_read(dev, phy_addr, 0x11, &value); + mdelay(10); + if ((value & 0xf) == 0xf) { + printf("DPMAC %d :PHY is ..... Configured\n", dpmac); + return; + } + + for (i = 0; i < 4; i++) { + for (j = 0; j < 4; j++) { + a = 0x18; + i2c_write(i2c_phy_addr, 6, 1, &a, 1); + a = 0x38; + i2c_write(i2c_phy_addr, 4, 1, &a, 1); + a = 0x4; + i2c_write(i2c_phy_addr, 8, 1, &a, 1); + + i2c_write(i2c_phy_addr, 0xf, 1, &ch_a_eq[i], 1); + i2c_write(i2c_phy_addr, 0x11, 1, &ch_a_ctl2[j], 1); + + i2c_write(i2c_phy_addr, 0x16, 1, &ch_b_eq[i], 1); + i2c_write(i2c_phy_addr, 0x18, 1, &ch_b_ctl2[j], 1); + + a = 0x14; + i2c_write(i2c_phy_addr, 0x23, 1, &a, 1); + a = 0xb5; + i2c_write(i2c_phy_addr, 0x2d, 1, &a, 1); + a = 0x20; + i2c_write(i2c_phy_addr, 4, 1, &a, 1); + mdelay(100); + ret = miiphy_read(dev, phy_addr, 0x11, &value); + if (ret > 0) + goto error; + mdelay(1); + ret = miiphy_read(dev, phy_addr, 0x11, &value); + if (ret > 0) + goto error; + mdelay(10); + if ((value & 0xf) == 0xf) { + printf("DPMAC %d :PHY is ..... Configured\n", + dpmac); + return; + } + } + } +error: + printf("DPMAC %d :PHY ..... FAILED to configure PHY\n", dpmac); + return; +} + static const char *ls2085a_qds_mdio_name_for_muxval(u8 muxval) { return mdio_names[muxval]; @@ -195,14 +444,38 @@ static void initialize_dpmac_to_slot(void) FSL_CHASSIS3_RCWSR28_SRDS2_PRTCL_MASK) >> FSL_CHASSIS3_RCWSR28_SRDS2_PRTCL_SHIFT;
+ char *env_hwconfig; + env_hwconfig = getenv("hwconfig");
switch (serdes1_prtcl) { + case 0x07: + case 0x09: + case 0x33: + printf("qds: WRIOP: Supported SerDes1 Protocol 0x%02x\n", + serdes1_prtcl); + lane_to_slot_fsm1[0] = EMI1_SLOT1; + lane_to_slot_fsm1[1] = EMI1_SLOT1; + lane_to_slot_fsm1[2] = EMI1_SLOT1; + lane_to_slot_fsm1[3] = EMI1_SLOT1; + if (hwconfig_f("xqsgmii", env_hwconfig)) { + lane_to_slot_fsm1[4] = EMI1_SLOT1; + lane_to_slot_fsm1[5] = EMI1_SLOT1; + lane_to_slot_fsm1[6] = EMI1_SLOT1; + lane_to_slot_fsm1[7] = EMI1_SLOT1; + } else { + lane_to_slot_fsm1[4] = EMI1_SLOT2; + lane_to_slot_fsm1[5] = EMI1_SLOT2; + lane_to_slot_fsm1[6] = EMI1_SLOT2; + lane_to_slot_fsm1[7] = EMI1_SLOT2; + } + break; + case 0x2A: - printf("qds: WRIOP: Supported SerDes Protocol 0x%02x\n", + printf("qds: WRIOP: Supported SerDes1 Protocol 0x%02x\n", serdes1_prtcl); break; default: - printf("qds: WRIOP: Unsupported SerDes Protocol 0x%02x\n", + printf("qds: WRIOP: Unsupported SerDes1 Protocol 0x%02x\n", serdes1_prtcl); break; } @@ -210,21 +483,30 @@ static void initialize_dpmac_to_slot(void) switch (serdes2_prtcl) { case 0x07: case 0x08: + case 0x09: case 0x49: - printf("qds: WRIOP: Supported SerDes Protocol 0x%02x\n", + printf("qds: WRIOP: Supported SerDes2 Protocol 0x%02x\n", serdes2_prtcl); lane_to_slot_fsm2[0] = EMI1_SLOT4; lane_to_slot_fsm2[1] = EMI1_SLOT4; lane_to_slot_fsm2[2] = EMI1_SLOT4; lane_to_slot_fsm2[3] = EMI1_SLOT4; - /* No MDIO physical connection */ - lane_to_slot_fsm2[4] = EMI1_SLOT6; - lane_to_slot_fsm2[5] = EMI1_SLOT6; - lane_to_slot_fsm2[6] = EMI1_SLOT6; - lane_to_slot_fsm2[7] = EMI1_SLOT6; + + if (hwconfig_f("xqsgmii", env_hwconfig)) { + lane_to_slot_fsm2[4] = EMI1_SLOT4; + lane_to_slot_fsm2[5] = EMI1_SLOT4; + lane_to_slot_fsm2[6] = EMI1_SLOT4; + lane_to_slot_fsm2[7] = EMI1_SLOT4; + } else { + /* No MDIO physical connection */ + lane_to_slot_fsm2[4] = EMI1_SLOT6; + lane_to_slot_fsm2[5] = EMI1_SLOT6; + lane_to_slot_fsm2[6] = EMI1_SLOT6; + lane_to_slot_fsm2[7] = EMI1_SLOT6; + } break; default: - printf("qds: WRIOP: Unsupported SerDes Protocol 0x%02x\n", + printf("qds: WRIOP: Unsupported SerDes2 Protocol 0x%02x\n", serdes2_prtcl); break; } @@ -242,9 +524,69 @@ void ls2085a_handle_phy_interface_sgmii(int dpmac_id) FSL_CHASSIS3_RCWSR28_SRDS2_PRTCL_MASK) >> FSL_CHASSIS3_RCWSR28_SRDS2_PRTCL_SHIFT;
+ int *riser_phy_addr; + char *env_hwconfig = getenv("hwconfig"); + + if (hwconfig_f("xqsgmii", env_hwconfig)) + riser_phy_addr = &xqsgii_riser_phy_addr[0]; + else + riser_phy_addr = &sgmii_riser_phy_addr[0]; + + if (dpmac_id > WRIOP1_DPMAC9) + goto serdes2; + switch (serdes1_prtcl) { + case 0x07: + + lane = serdes_get_first_lane(FSL_SRDS_1, SGMII1 + dpmac_id); + slot = lane_to_slot_fsm1[lane]; + + switch (++slot) { + case 1: + /* Slot housing a SGMII riser card? */ + wriop_set_phy_address(dpmac_id, + riser_phy_addr[dpmac_id - 1]); + dpmac_info[dpmac_id].board_mux = EMI1_SLOT1; + bus = mii_dev_for_muxval(EMI1_SLOT1); + wriop_set_mdio(dpmac_id, bus); + dpmac_info[dpmac_id].phydev = phy_connect( + dpmac_info[dpmac_id].bus, + dpmac_info[dpmac_id].phy_addr, + NULL, + dpmac_info[dpmac_id].enet_if); + phy_config(dpmac_info[dpmac_id].phydev); + break; + case 2: + /* Slot housing a SGMII riser card? */ + wriop_set_phy_address(dpmac_id, + riser_phy_addr[dpmac_id - 1]); + dpmac_info[dpmac_id].board_mux = EMI1_SLOT2; + bus = mii_dev_for_muxval(EMI1_SLOT2); + wriop_set_mdio(dpmac_id, bus); + dpmac_info[dpmac_id].phydev = phy_connect( + dpmac_info[dpmac_id].bus, + dpmac_info[dpmac_id].phy_addr, + NULL, + dpmac_info[dpmac_id].enet_if); + phy_config(dpmac_info[dpmac_id].phydev); + break; + case 3: + break; + case 4: + break; + case 5: + break; + case 6: + break; + } + break; + default: + printf("qds: WRIOP: Unsupported SerDes1 Protocol 0x%02x\n", + serdes1_prtcl); + break; }
+serdes2: switch (serdes2_prtcl) { case 0x07: case 0x08: @@ -285,11 +627,86 @@ void ls2085a_handle_phy_interface_sgmii(int dpmac_id) } break; default: - printf("qds: WRIOP: Unsupported SerDes Protocol 0x%02x\n", + printf("qds: WRIOP: Unsupported SerDes2 Protocol 0x%02x\n", serdes2_prtcl); break; } } + +void ls2085a_handle_phy_interface_qsgmii(int dpmac_id) +{ + int lane = 0, slot; + struct mii_dev *bus; + struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; + int serdes1_prtcl = (in_le32(&gur->rcwsr[28]) & + FSL_CHASSIS3_RCWSR28_SRDS1_PRTCL_MASK) + >> FSL_CHASSIS3_RCWSR28_SRDS1_PRTCL_SHIFT; + + switch (serdes1_prtcl) { + case 0x33: + switch (dpmac_id) { + case 1: + case 2: + case 3: + case 4: + lane = serdes_get_first_lane(FSL_SRDS_1, QSGMII_A); + break; + case 5: + case 6: + case 7: + case 8: + lane = serdes_get_first_lane(FSL_SRDS_1, QSGMII_B); + break; + case 9: + case 10: + case 11: + case 12: + lane = serdes_get_first_lane(FSL_SRDS_1, QSGMII_C); + break; + case 13: + case 14: + case 15: + case 16: + lane = serdes_get_first_lane(FSL_SRDS_1, QSGMII_D); + break; + } + + slot = lane_to_slot_fsm1[lane]; + + switch (++slot) { + case 1: + /* Slot housing a QSGMII riser card? */ + wriop_set_phy_address(dpmac_id, dpmac_id - 1); + dpmac_info[dpmac_id].board_mux = EMI1_SLOT1; + bus = mii_dev_for_muxval(EMI1_SLOT1); + wriop_set_mdio(dpmac_id, bus); + dpmac_info[dpmac_id].phydev = phy_connect( + dpmac_info[dpmac_id].bus, + dpmac_info[dpmac_id].phy_addr, + NULL, + dpmac_info[dpmac_id].enet_if); + + phy_config(dpmac_info[dpmac_id].phydev); + break; + case 3: + break; + case 4: + break; + case 5: + break; + case 6: + break; + } + break; + default: + printf("qds: WRIOP: Unsupported SerDes Protocol 0x%02x\n", + serdes1_prtcl); + break; + } + + qsgmii_configure_repeater(dpmac_id); +} + void ls2085a_handle_phy_interface_xsgmii(int i) { struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; @@ -324,9 +741,20 @@ int board_eth_init(bd_t *bis) { int error; #ifdef CONFIG_FSL_MC_ENET + struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; + int serdes1_prtcl = (in_le32(&gur->rcwsr[28]) & + FSL_CHASSIS3_RCWSR28_SRDS1_PRTCL_MASK) + >> FSL_CHASSIS3_RCWSR28_SRDS1_PRTCL_SHIFT; + int serdes2_prtcl = (in_le32(&gur->rcwsr[28]) & + FSL_CHASSIS3_RCWSR28_SRDS2_PRTCL_MASK) + >> FSL_CHASSIS3_RCWSR28_SRDS2_PRTCL_SHIFT; + struct memac_mdio_info *memac_mdio0_info; struct memac_mdio_info *memac_mdio1_info; unsigned int i; + char *env_hwconfig; + + env_hwconfig = getenv("hwconfig");
initialize_dpmac_to_slot();
@@ -363,6 +791,7 @@ int board_eth_init(bd_t *bis) for (i = WRIOP1_DPMAC1; i < NUM_WRIOP_PORTS; i++) { switch (wriop_get_enet_if(i)) { case PHY_INTERFACE_MODE_QSGMII: + ls2085a_handle_phy_interface_qsgmii(i); break; case PHY_INTERFACE_MODE_SGMII: ls2085a_handle_phy_interface_sgmii(i); @@ -372,11 +801,26 @@ int board_eth_init(bd_t *bis) break; default: break; + + if (i == 16) + i = NUM_WRIOP_PORTS; } }
error = cpu_eth_init(bis); + + if (hwconfig_f("xqsgmii", env_hwconfig)) { + if (serdes1_prtcl == 0x7) + sgmii_configure_repeater(1); + if (serdes2_prtcl == 0x7 || serdes2_prtcl == 0x8 || + serdes2_prtcl == 0x49) + sgmii_configure_repeater(2); + } #endif error = pci_eth_init(bis); return error; } + +#ifdef CONFIG_FSL_MC_ENET + +#endif diff --git a/include/configs/ls2085aqds.h b/include/configs/ls2085aqds.h index f380ecc..5903aee 100644 --- a/include/configs/ls2085aqds.h +++ b/include/configs/ls2085aqds.h @@ -396,6 +396,23 @@ unsigned long get_board_ddr_clk(void); #define SGMII_CARD_PORT3_PHY_ADDR 0x1E #define SGMII_CARD_PORT4_PHY_ADDR 0x1F
+#define XQSGMII_CARD_PHY1_PORT0_ADDR 0x0 +#define XQSGMII_CARD_PHY1_PORT1_ADDR 0x1 +#define XQSGMII_CARD_PHY1_PORT2_ADDR 0x2 +#define XQSGMII_CARD_PHY1_PORT3_ADDR 0x3 +#define XQSGMII_CARD_PHY2_PORT0_ADDR 0x4 +#define XQSGMII_CARD_PHY2_PORT1_ADDR 0x5 +#define XQSGMII_CARD_PHY2_PORT2_ADDR 0x6 +#define XQSGMII_CARD_PHY2_PORT3_ADDR 0x7 +#define XQSGMII_CARD_PHY3_PORT0_ADDR 0x8 +#define XQSGMII_CARD_PHY3_PORT1_ADDR 0x9 +#define XQSGMII_CARD_PHY3_PORT2_ADDR 0xa +#define XQSGMII_CARD_PHY3_PORT3_ADDR 0xb +#define XQSGMII_CARD_PHY4_PORT0_ADDR 0xc +#define XQSGMII_CARD_PHY4_PORT1_ADDR 0xd +#define XQSGMII_CARD_PHY4_PORT2_ADDR 0xe +#define XQSGMII_CARD_PHY4_PORT3_ADDR 0xf + #define CONFIG_MII /* MII PHY management */ #define CONFIG_ETHPRIME "DPNI1" #define CONFIG_PHY_GIGE /* Include GbE speed/duplex detection */
Applied to fsl-qoriq master branch. Awaiting upstream.
York
Prabhakar Kushwaha
York Sun
