[U-Boot] [PATCH v2 1/2] omap_hsmmc: Check wp and cd GPIO for valid GPIO first
When we cannot check write protect or card change via GPIO (and have been passed -1 in omap_mmc_init), only even try the gpio_is_valid is true. This prevents invalid GPIO messages from being seen on the console when doing MMC operations
Signed-off-by: Tom Rini trini@ti.com
--- Changes in v2: - Use gpio_is_valid not just a check for >= 0 (Fabio Estevam) --- drivers/mmc/omap_hsmmc.c | 12 ++++++++++-- 1 file changed, 10 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/omap_hsmmc.c b/drivers/mmc/omap_hsmmc.c index 67cfcc2..8a5dce5 100644 --- a/drivers/mmc/omap_hsmmc.c +++ b/drivers/mmc/omap_hsmmc.c @@ -73,13 +73,21 @@ static int omap_mmc_setup_gpio_in(int gpio, const char *label) static int omap_mmc_getcd(struct mmc *mmc) { int cd_gpio = ((struct omap_hsmmc_data *)mmc->priv)->cd_gpio; - return gpio_get_value(cd_gpio); + + if (gpio_is_valid(cd_gpio)) + return gpio_get_value(cd_gpio); + else + return -1; }
static int omap_mmc_getwp(struct mmc *mmc) { int wp_gpio = ((struct omap_hsmmc_data *)mmc->priv)->wp_gpio; - return gpio_get_value(wp_gpio); + + if (gpio_is_valid(wp_gpio)) + return gpio_get_value(wp_gpio); + else + return -1; } #else static inline int omap_mmc_setup_gpio_in(int gpio, const char *label)
--- Changes in v2: - New patch, use -EINVAL in the driver --- drivers/mmc/omap_hsmmc.c | 14 +++++++------- 1 file changed, 7 insertions(+), 7 deletions(-)
diff --git a/drivers/mmc/omap_hsmmc.c b/drivers/mmc/omap_hsmmc.c index 8a5dce5..3055ac5 100644 --- a/drivers/mmc/omap_hsmmc.c +++ b/drivers/mmc/omap_hsmmc.c @@ -59,13 +59,13 @@ static struct omap_hsmmc_data hsmmc_dev_data[3]; static int omap_mmc_setup_gpio_in(int gpio, const char *label) { if (!gpio_is_valid(gpio)) - return -1; + return -EINVAL;
if (gpio_request(gpio, label) < 0) - return -1; + return -EINVAL;
if (gpio_direction_input(gpio) < 0) - return -1; + return -EINVAL;
return gpio; } @@ -77,7 +77,7 @@ static int omap_mmc_getcd(struct mmc *mmc) if (gpio_is_valid(cd_gpio)) return gpio_get_value(cd_gpio); else - return -1; + return -EINVAL; }
static int omap_mmc_getwp(struct mmc *mmc) @@ -87,12 +87,12 @@ static int omap_mmc_getwp(struct mmc *mmc) if (gpio_is_valid(wp_gpio)) return gpio_get_value(wp_gpio); else - return -1; + return -EINVAL; } #else static inline int omap_mmc_setup_gpio_in(int gpio, const char *label) { - return -1; + return -EINVAL; }
#define omap_mmc_getcd NULL @@ -401,7 +401,7 @@ static int mmc_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, mmc_reset_controller_fsm(mmc_base, SYSCTL_SRC); return TIMEOUT; } else if ((mmc_stat & ERRI_MASK) != 0) - return -1; + return -EINVAL;
if (mmc_stat & CC_MASK) { writel(CC_MASK, &mmc_base->stat);
Hi Tom, a few style comments:
That last part needs rephrasing: "only try if gpio_is_valid() is true".
- if (gpio_is_valid(cd_gpio))
- else
return -1;
Also, the "else" word is not necessary in both checks.
Aside from that, Acked-by: Nikita Kiryanov nikita@compulab.co.il
- else
return -1;
Also, the "else" word is not necessary (in both checks).
Nikita Kiryanov
