[PATCH] sunxi: power: axp809: Fix DCDC4 programming
When trying to set the DCDC4 regulator, the code was accidentally setting the voltage register for DCDC5 (VCC-DRAM). The higher voltage doesn't harm the DRAM chips, but upsets the Linux regulator driver: when it tried to correct that, it tripped over a separate DT bug. The DCDC5 DT limits are 1.425 and 1.575V, which cannot bet set with the rail's resolution of 50mV. The kernel driver gave up, and made in turn the system hang, as the PMIC powers essential devices.
Fix the copy&paste bug by using the correct PMIC voltage register.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- drivers/power/axp809.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/power/axp809.c b/drivers/power/axp809.c index 9e38e1a7450..ec3eca1ac4b 100644 --- a/drivers/power/axp809.c +++ b/drivers/power/axp809.c @@ -93,7 +93,7 @@ int axp_set_dcdc4(unsigned int mvolt) return pmic_bus_clrbits(AXP809_OUTPUT_CTRL1, AXP809_OUTPUT_CTRL1_DCDC4_EN);
- ret = pmic_bus_write(AXP809_DCDC5_CTRL, cfg); + ret = pmic_bus_write(AXP809_DCDC4_CTRL, cfg); if (ret) return ret;
Reviewed-by: Chen-Yu Tsai wens@csie.org
-- 2.46.2
-----Original Message----- From: Chen-Yu Tsai wens@csie.org Sent: Friday, October 25, 2024 11:43 PM To: Andre Przywara andre.przywara@arm.com Cc: Jaehoon Chung jh80.chung@samsung.com; Jagan Teki jagan@amarulasolutions.com; Tom Rini trini@konsulko.com; u-boot@lists.denx.de; linux-sunxi@lists.linux.dev Subject: Re: [PATCH] sunxi: power: axp809: Fix DCDC4 programming
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
-- 2.46.2
Andre Przywara
Chen-Yu Tsai
Jaehoon Chung
