[PATCH v2] cmd: usb_mass_storage: Use part_get_info_by_dev_and_name_or_num
This allows specifying partitions using more extended syntax. This is particularly useful to access eMMC hardware partitions. For example, this allows something like
ums mmc 0.0,0.1,0.2,0.3
to expose four LUNs for each of the four default eMMC hardware partitions. Note that the comma syntax was already present.
Signed-off-by: Sean Anderson sean.anderson@seco.com ---
Changes in v2: - Reword commit message to include an example
cmd/usb_mass_storage.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/cmd/usb_mass_storage.c b/cmd/usb_mass_storage.c index 14fa7233c7..d4e619b842 100644 --- a/cmd/usb_mass_storage.c +++ b/cmd/usb_mass_storage.c @@ -74,8 +74,8 @@ static int ums_init(const char *devtype, const char *devnums_part_str) if (!devnum_part_str) break;
- partnum = blk_get_device_part_str(devtype, devnum_part_str, - &block_dev, &info, 1); + partnum = part_get_info_by_dev_and_name_or_num(devtype, devnum_part_str, + &block_dev, &info, 1);
if (partnum < 0) goto cleanup;
Shouldn't that be ums X mmc Y ?
That's all good, but is there some specification of the syntax somewhere instead of a random example ?
Is the current syntax still supported ?
Yes.
That's all good, but is there some specification of the syntax somewhere instead of a random example ?\
Yes, see https://u-boot.readthedocs.io/en/latest/usage/partitions.html
I suppose that https://u-boot.readthedocs.io/en/latest/usage/ums.html should be updated as well, especially since the comma syntax is undocumented.
Yes. This is completely backward-compatible.
--Sean
Yes.
Upon closer inspection, the partition syntax is actually already documented. This patch just brings the command in-line with what is documented.
--Sean
--Sean
Hi Marek,
Yes.
Does this patch need any additional modifications? As stated above, this new behavior is actually what is already documented.
--Sean
On 10/28/21 9:43 PM, Sean Anderson wrote:
Hi Marek,
Yes.
Update the commit message so the example isn't wrong (i.e. ums X mmc y).
Validate that "ums 0 mmc 0" still works for exporting the entire block device, if it does, then I can pick it.
Thanks
Sean Anderson
