[PATCH 03/11] mtd: nand: Add manufacturer specific initialization/detection steps
Upstream commit abbe26d144ec22bb067fa414d717b9f7ca2e12bd
A lot of NANDs are implementing generic features in a non-generic way, or are providing advanced auto-detection logic where the NAND ID bytes meaning changes with the NAND generation.
Providing this vendor specific initialization step will allow us to get rid of full-id entries in the nand_ids table or all the vendor specific cases added over the time in the generic NAND ID decoding logic.
Signed-off-by: Boris Brezillon boris.brezillon@free-electrons.com Signed-off-by: Michael Trimarchi michael@amarulasolutions.com --- drivers/mtd/nand/raw/nand_base.c | 90 +++++++++++++++++++++++++------- include/linux/mtd/rawnand.h | 30 +++++++++++ 2 files changed, 102 insertions(+), 18 deletions(-)
diff --git a/drivers/mtd/nand/raw/nand_base.c b/drivers/mtd/nand/raw/nand_base.c index 4a78770a25..3b9c78cb24 100644 --- a/drivers/mtd/nand/raw/nand_base.c +++ b/drivers/mtd/nand/raw/nand_base.c @@ -4286,6 +4286,39 @@ static void nand_decode_ext_id(struct mtd_info *mtd, struct nand_chip *chip) } }
+/* + * Manufacturer detection. Only used when the NAND is not ONFI or JEDEC + * compliant and does not have a full-id or legacy-id entry in the nand_ids + * table. + */ +static void nand_manufacturer_detect(struct mtd_info *mtd, struct nand_chip *chip) +{ + /* + * Try manufacturer detection if available and use + * nand_decode_ext_id() otherwise. + */ + if (chip->manufacturer.desc && chip->manufacturer.desc->ops && + chip->manufacturer.desc->ops->detect) + chip->manufacturer.desc->ops->detect(chip); + else + nand_decode_ext_id(mtd, chip); +} + +/* + * Manufacturer initialization. This function is called for all NANDs including + * ONFI and JEDEC compliant ones. + * Manufacturer drivers should put all their specific initialization code in + * their ->init() hook. + */ +static int nand_manufacturer_init(struct nand_chip *chip) +{ + if (!chip->manufacturer.desc || !chip->manufacturer.desc->ops || + !chip->manufacturer.desc->ops->init) + return 0; + + return chip->manufacturer.desc->ops->init(chip); +} + /* * Old devices have chip data hardcoded in the device ID table. nand_decode_id * decodes a matching ID table entry and assigns the MTD size parameters for @@ -4383,6 +4416,26 @@ static bool find_full_id_nand(struct mtd_info *mtd, struct nand_chip *chip, return false; }
+/** + * nand_get_manufacturer_desc - Get manufacturer information from the + * manufacturer ID + * @id: manufacturer ID + * + * Returns a nand_manufacturer_desc object if the manufacturer is defined + * in the NAND manufacturers database, NULL otherwise. + */ +static const struct nand_manufacturers *nand_get_manufacturer_desc(u8 id) +{ + int i; + + for (i = 0; nand_manuf_ids[i].id != 0x0; i++) { + if (nand_manuf_ids[i].id == id) + return &nand_manuf_ids[i]; + } + + return NULL; +} + /* * Get the flash and manufacturer id and lookup if the type is supported. */ @@ -4391,8 +4444,8 @@ struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, int *maf_id, int *dev_id, struct nand_flash_dev *type) { + const struct nand_manufacturers *manufacturer_desc; int busw, ret; - int maf_idx; u8 *id_data = chip->id.data;
/* @@ -4433,6 +4486,12 @@ struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, return ERR_PTR(-ENODEV); }
+ chip->id.len = nand_id_len(id_data, ARRAY_SIZE(chip->id.data)); + + /* Try to identify manufacturer */ + manufacturer_desc = nand_get_manufacturer_desc(*maf_id); + chip->manufacturer.desc = manufacturer_desc; + if (!type) type = nand_flash_ids;
@@ -4451,8 +4510,6 @@ struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, */ chip->options &= ~NAND_BUSWIDTH_16;
- chip->id.len = nand_id_len(id_data, ARRAY_SIZE(chip->id.data)); - for (; type->name != NULL; type++) { if (is_full_id_nand(type)) { if (find_full_id_nand(mtd, chip, type)) @@ -4482,8 +4539,7 @@ struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, chip->chipsize = (uint64_t)type->chipsize << 20;
if (!type->pagesize) { - /* Decode parameters from extended ID */ - nand_decode_ext_id(mtd, chip); + nand_manufacturer_detect(mtd, chip); } else { nand_decode_id(mtd, chip, type); } @@ -4499,12 +4555,6 @@ struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, chip->options &= ~NAND_SAMSUNG_LP_OPTIONS; ident_done:
- /* Try to identify manufacturer */ - for (maf_idx = 0; nand_manuf_ids[maf_idx].id != 0x0; maf_idx++) { - if (nand_manuf_ids[maf_idx].id == *maf_id) - break; - } - if (chip->options & NAND_BUSWIDTH_AUTO) { WARN_ON(chip->options & NAND_BUSWIDTH_16); chip->options |= busw; @@ -4516,7 +4566,7 @@ ident_done: */ pr_info("device found, Manufacturer ID: 0x%02x, Chip ID: 0x%02x\n", *maf_id, *dev_id); - pr_info("%s %s\n", nand_manuf_ids[maf_idx].name, mtd->name); + pr_info("%s %s\n", manufacturer_desc->name, mtd->name); pr_warn("bus width %d instead %d bit\n", (chip->options & NAND_BUSWIDTH_16) ? 16 : 8, busw ? 16 : 8); @@ -4549,28 +4599,32 @@ ident_done: if (mtd->writesize > 512 && chip->cmdfunc == nand_command) chip->cmdfunc = nand_command_lp;
+ ret = nand_manufacturer_init(chip); + if (ret) + return ERR_PTR(ret); + pr_info("device found, Manufacturer ID: 0x%02x, Chip ID: 0x%02x\n", *maf_id, *dev_id);
#ifdef CONFIG_SYS_NAND_ONFI_DETECTION if (chip->onfi_version) - pr_info("%s %s\n", nand_manuf_ids[maf_idx].name, + pr_info("%s %s\n", manufacturer_desc->name, chip->onfi_params.model); else if (chip->jedec_version) - pr_info("%s %s\n", nand_manuf_ids[maf_idx].name, + pr_info("%s %s\n", manufacturer_desc->name, chip->jedec_params.model); else - pr_info("%s %s\n", nand_manuf_ids[maf_idx].name, + pr_info("%s %s\n", manufacturer_desc->name, type->name); #else if (chip->jedec_version) - pr_info("%s %s\n", nand_manuf_ids[maf_idx].name, + pr_info("%s %s\n", manufacturer_desc->name, chip->jedec_params.model); else - pr_info("%s %s\n", nand_manuf_ids[maf_idx].name, + pr_info("%s %s\n", manufacturer_desc->name, type->name);
- pr_info("%s %s\n", nand_manuf_ids[maf_idx].name, + pr_info("%s %s\n", manufacturer_desc->name, type->name); #endif
diff --git a/include/linux/mtd/rawnand.h b/include/linux/mtd/rawnand.h index f2c6a978cb..57fe7fb47b 100644 --- a/include/linux/mtd/rawnand.h +++ b/include/linux/mtd/rawnand.h @@ -796,6 +796,17 @@ nand_get_sdr_timings(const struct nand_data_interface *conf) return &conf->timings.sdr; }
+/** + * struct nand_manufacturer_ops - NAND Manufacturer operations + * @detect: detect the NAND memory organization and capabilities + * @init: initialize all vendor specific fields (like the ->read_retry() + * implementation) if any. + */ +struct nand_manufacturer_ops { + void (*detect)(struct nand_chip *chip); + int (*init)(struct nand_chip *chip); +}; + /** * struct nand_chip - NAND Private Flash Chip Data * @mtd: MTD device registered to the MTD framework @@ -897,6 +908,7 @@ nand_get_sdr_timings(const struct nand_data_interface *conf) * devices. * @priv: [OPTIONAL] pointer to private chip data * @write_page: [REPLACEABLE] High-level page write function + * @manufacturer: [INTERN] Contains manufacturer information */
struct nand_chip { @@ -983,6 +995,11 @@ struct nand_chip { struct nand_bbt_descr *badblock_pattern;
void *priv; + + struct { + const struct nand_manufacturers *desc; + void *priv; + } manufacturer; };
static inline void nand_set_flash_node(struct nand_chip *chip, @@ -1016,6 +1033,17 @@ static inline void nand_set_controller_data(struct nand_chip *chip, void *priv) chip->priv = priv; }
+static inline void nand_set_manufacturer_data(struct nand_chip *chip, + void *priv) +{ + chip->manufacturer.priv = priv; +} + +static inline void *nand_get_manufacturer_data(struct nand_chip *chip) +{ + return chip->manufacturer.priv; +} + /* * NAND Flash Manufacturer ID Codes */ @@ -1120,10 +1148,12 @@ struct nand_flash_dev { * struct nand_manufacturers - NAND Flash Manufacturer ID Structure * @name: Manufacturer name * @id: manufacturer ID code of device. + * @ops: manufacturer operations */ struct nand_manufacturers { int id; char *name; + const struct nand_manufacturer_ops *ops; };
extern struct nand_flash_dev nand_flash_ids[];
Michael Trimarchi
