[PATCH v1] clk: rockchip: rk3568: update clks
fix up ppll init freq. support tclk_emmc. add freq (26M) for mmc device. fix up the sfc clk rate unit error.
Change-Id: I41daa2c1daf55ab07229c1513c6be51b90125cfd Signed-off-by: Elaine Zhang zhangqing@rock-chips.com --- arch/arm/include/asm/arch-rockchip/cru_rk3568.h | 2 +- drivers/clk/rockchip/clk_rk3568.c | 11 +++++++++-- 2 files changed, 10 insertions(+), 3 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/cru_rk3568.h b/arch/arm/include/asm/arch-rockchip/cru_rk3568.h index 6c59033f03a6..399f19ad21ec 100644 --- a/arch/arm/include/asm/arch-rockchip/cru_rk3568.h +++ b/arch/arm/include/asm/arch-rockchip/cru_rk3568.h @@ -14,7 +14,7 @@ #define APLL_HZ (816 * MHz) #define GPLL_HZ (1188 * MHz) #define CPLL_HZ (1000 * MHz) -#define PPLL_HZ (100 * MHz) +#define PPLL_HZ (200 * MHz)
/* RK3568 pll id */ enum rk3568_pll_id { diff --git a/drivers/clk/rockchip/clk_rk3568.c b/drivers/clk/rockchip/clk_rk3568.c index 553c6c0dafbd..d5e45e7602c7 100644 --- a/drivers/clk/rockchip/clk_rk3568.c +++ b/drivers/clk/rockchip/clk_rk3568.c @@ -1441,6 +1441,7 @@ static ulong rk3568_sdmmc_set_clk(struct rk3568_clk_priv *priv,
switch (rate) { case OSC_HZ: + case 26 * MHz: src_clk = CLK_SDMMC_SEL_24M; break; case 400 * MHz: @@ -1507,7 +1508,7 @@ static ulong rk3568_sfc_get_clk(struct rk3568_clk_priv *priv) case SCLK_SFC_SEL_125M: return 125 * MHz; case SCLK_SFC_SEL_150M: - return 150 * KHz; + return 150 * MHz; default: return -ENOENT; } @@ -1534,7 +1535,7 @@ static ulong rk3568_sfc_set_clk(struct rk3568_clk_priv *priv, ulong rate) case 125 * MHz: src_clk = SCLK_SFC_SEL_125M; break; - case 150 * KHz: + case 150 * MHz: src_clk = SCLK_SFC_SEL_150M; break; default: @@ -2406,6 +2407,9 @@ static ulong rk3568_clk_get_rate(struct clk *clk) case BCLK_EMMC: rate = rk3568_emmc_get_bclk(priv); break; + case TCLK_EMMC: + rate = OSC_HZ; + break; #ifndef CONFIG_SPL_BUILD case ACLK_VOP: rate = rk3568_aclk_vop_get_clk(priv); @@ -2582,6 +2586,9 @@ static ulong rk3568_clk_set_rate(struct clk *clk, ulong rate) case BCLK_EMMC: ret = rk3568_emmc_set_bclk(priv, rate); break; + case TCLK_EMMC: + ret = OSC_HZ; + break; #ifndef CONFIG_SPL_BUILD case ACLK_VOP: ret = rk3568_aclk_vop_set_clk(priv, rate);
Hi Elaine,
Please remove this change-id for upstream.
Thanks,
- Kever
- case 26 * MHz: src_clk = CLK_SDMMC_SEL_24M; break; case 400 * MHz:
return 150 * KHz;
default: return -ENOENT; }return 150 * MHz;
- case 150 * KHz:
- case 150 * MHz: src_clk = SCLK_SFC_SEL_150M; break; default:
- case TCLK_EMMC:
rate = OSC_HZ;
#ifndef CONFIG_SPL_BUILD case ACLK_VOP: rate = rk3568_aclk_vop_get_clk(priv);break;
- case TCLK_EMMC:
ret = OSC_HZ;
#ifndef CONFIG_SPL_BUILD case ACLK_VOP: ret = rk3568_aclk_vop_set_clk(priv, rate);break;
Elaine Zhang
Kever Yang
