[U-Boot] [PATCH 1/2] dm: implement a Miscellaneous uclass
Implement a Miscellaneous uclass with generic read or write operations. This class is used only for those do not fit other more general classes.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- drivers/misc/Kconfig | 6 ++++++ drivers/misc/Makefile | 1 + drivers/misc/misc-uclass.c | 14 ++++++++++++++ include/dm/uclass-id.h | 1 + 4 files changed, 22 insertions(+) create mode 100644 drivers/misc/misc-uclass.c
diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index 8b38a84..51c2a08 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -4,6 +4,12 @@
menu "Multifunction device drivers"
+config DM_MISC + bool "Enable Driver Model for Misc drivers" + depends on DM + help + Enable driver model for miscellaneous devices. + config CMD_CROS_EC bool "Enable crosec command" depends on CROS_EC diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index 8d0fc3c..b285946 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -5,6 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
+obj-$(CONFIG_DM_MISC) += misc-uclass.o obj-$(CONFIG_ALI152X) += ali512x.o obj-$(CONFIG_DS4510) += ds4510.o obj-$(CONFIG_CBMEM_CONSOLE) += cbmem_console.o diff --git a/drivers/misc/misc-uclass.c b/drivers/misc/misc-uclass.c new file mode 100644 index 0000000..40fe947 --- /dev/null +++ b/drivers/misc/misc-uclass.c @@ -0,0 +1,14 @@ +/* + * Copyright (C) 2010 Thomas Chou thomas@wytron.com.tw + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <misc.h> + +UCLASS_DRIVER(misc) = { + .id = UCLASS_MISC, + .name = "misc", +}; diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index aff34a4..a6982ab 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -39,6 +39,7 @@ enum uclass_id { UCLASS_LED, /* Light-emitting diode (LED) */ UCLASS_LPC, /* x86 'low pin count' interface */ UCLASS_MASS_STORAGE, /* Mass storage device */ + UCLASS_MISC, /* Miscellaneous device */ UCLASS_MMC, /* SD / MMC card or chip */ UCLASS_MOD_EXP, /* RSA Mod Exp device */ UCLASS_PCH, /* x86 platform controller hub */
Convert altera sysid to driver model with misc uclass.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- arch/nios2/cpu/Makefile | 2 +- arch/nios2/cpu/cpu.c | 15 +---- arch/nios2/cpu/sysid.c | 46 -------------- arch/nios2/dts/3c120_devboard.dts | 8 +++ board/altera/nios2-generic/nios2-generic.c | 6 +- configs/nios2-generic_defconfig | 2 + drivers/misc/Kconfig | 7 +++ drivers/misc/Makefile | 1 + drivers/misc/altera_sysid.c | 99 ++++++++++++++++++++++++++++++ include/configs/nios2-generic.h | 3 +- 10 files changed, 126 insertions(+), 63 deletions(-) delete mode 100644 arch/nios2/cpu/sysid.c create mode 100644 drivers/misc/altera_sysid.c
diff --git a/arch/nios2/cpu/Makefile b/arch/nios2/cpu/Makefile index 3fe7847..185ca3c 100644 --- a/arch/nios2/cpu/Makefile +++ b/arch/nios2/cpu/Makefile @@ -7,5 +7,5 @@
extra-y = start.o obj-y = exceptions.o -obj-y += cpu.o interrupts.o sysid.o traps.o +obj-y += cpu.o interrupts.o traps.o obj-y += fdt.o diff --git a/arch/nios2/cpu/cpu.c b/arch/nios2/cpu/cpu.c index 88984e2..7b1717c 100644 --- a/arch/nios2/cpu/cpu.c +++ b/arch/nios2/cpu/cpu.c @@ -13,22 +13,11 @@
DECLARE_GLOBAL_DATA_PTR;
-#if defined (CONFIG_SYS_NIOS_SYSID_BASE) -extern void display_sysid (void); -#endif /* CONFIG_SYS_NIOS_SYSID_BASE */ - -#ifdef CONFIG_DISPLAY_CPUINFO int print_cpuinfo(void) { - printf ("CPU : Nios-II\n"); -#if !defined(CONFIG_SYS_NIOS_SYSID_BASE) - printf ("SYSID : <unknown>\n"); -#else - display_sysid (); -#endif - return (0); + printf("CPU: Nios-II\n"); + return 0; } -#endif /* CONFIG_DISPLAY_CPUINFO */
int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { diff --git a/arch/nios2/cpu/sysid.c b/arch/nios2/cpu/sysid.c deleted file mode 100644 index 50819b2..0000000 --- a/arch/nios2/cpu/sysid.c +++ /dev/null @@ -1,46 +0,0 @@ -/* - * (C) Copyright 2004, Psyent Corporation <www.psyent.com> - * Scott McNutt smcnutt@psyent.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> - -#if defined (CONFIG_SYS_NIOS_SYSID_BASE) - -#include <command.h> -#include <asm/io.h> -#include <linux/time.h> - -typedef volatile struct { - unsigned id; /* The system build id */ - unsigned timestamp; /* Timestamp */ -} nios_sysid_t; - -void display_sysid (void) -{ - nios_sysid_t *sysid = (nios_sysid_t *)CONFIG_SYS_NIOS_SYSID_BASE; - struct tm t; - char asc[32]; - time_t stamp; - - stamp = readl (&sysid->timestamp); - localtime_r (&stamp, &t); - asctime_r (&t, asc); - printf ("SYSID : %08lx, %s", readl (&sysid->id), asc); - -} - -int do_sysid (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - display_sysid (); - return (0); -} - -U_BOOT_CMD( - sysid, 1, 1, do_sysid, - "display Nios-II system id", - "" -); -#endif /* CONFIG_SYS_NIOS_SYSID_BASE */ diff --git a/arch/nios2/dts/3c120_devboard.dts b/arch/nios2/dts/3c120_devboard.dts index 2e2956f..2eb339c 100644 --- a/arch/nios2/dts/3c120_devboard.dts +++ b/arch/nios2/dts/3c120_devboard.dts @@ -72,6 +72,7 @@ <0x00004cc0 0x08004cc0 0x00000010>, <0x00004ce0 0x08004ce0 0x00000010>, <0x00004d00 0x08004d00 0x00000010>, + <0x00004d40 0x08004d40 0x00000008>, <0x00004d50 0x08004d50 0x00000008>, <0x00008000 0x08008000 0x00000020>, <0x00400000 0x08400000 0x00000020>; @@ -92,6 +93,13 @@ clock-frequency = < 125000000 >; };
+ sysid: sysid@0x4d40 { + compatible = "altr,sysid-1.0"; + reg = <0x00004d40 0x00000008>; + id = <0>; + timestamp = <1440939556>; + }; + jtag_uart: serial@0x4d50 { compatible = "altr,juart-1.0"; reg = <0x00004d50 0x00000008>; diff --git a/board/altera/nios2-generic/nios2-generic.c b/board/altera/nios2-generic/nios2-generic.c index 61d32c7..e08b8f7 100644 --- a/board/altera/nios2-generic/nios2-generic.c +++ b/board/altera/nios2-generic/nios2-generic.c @@ -42,7 +42,11 @@ int board_early_init_r(void)
int checkboard(void) { - printf("BOARD : %s\n", CONFIG_BOARD_NAME); +#ifdef CONFIG_ALTERA_SYSID + extern void display_sysid(void); + display_sysid(); +#endif + printf("BOARD: %s\n", CONFIG_BOARD_NAME); return 0; }
diff --git a/configs/nios2-generic_defconfig b/configs/nios2-generic_defconfig index 1aa2d9e..d8d26e5 100644 --- a/configs/nios2-generic_defconfig +++ b/configs/nios2-generic_defconfig @@ -15,6 +15,8 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_ALTERA_PIO=y +CONFIG_DM_MISC=y +CONFIG_ALTERA_SYSID=y CONFIG_ALTERA_JTAG_UART=y CONFIG_ALTERA_JTAG_UART_BYPASS=y CONFIG_DM_TIMER=y diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index 51c2a08..06a10d4 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -10,6 +10,13 @@ config DM_MISC help Enable driver model for miscellaneous devices.
+config ALTERA_SYSID + bool "Altera Sysid support" + depends on DM_MISC + help + Select this to enable a sysid for Altera devices. Please find + details on the "Embedded Peripherals IP User Guide" of Altera. + config CMD_CROS_EC bool "Enable crosec command" depends on CROS_EC diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index b285946..449425e 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -7,6 +7,7 @@
obj-$(CONFIG_DM_MISC) += misc-uclass.o obj-$(CONFIG_ALI152X) += ali512x.o +obj-$(CONFIG_ALTERA_SYSID) += altera_sysid.o obj-$(CONFIG_DS4510) += ds4510.o obj-$(CONFIG_CBMEM_CONSOLE) += cbmem_console.o obj-$(CONFIG_CROS_EC) += cros_ec.o diff --git a/drivers/misc/altera_sysid.c b/drivers/misc/altera_sysid.c new file mode 100644 index 0000000..648fdb1 --- /dev/null +++ b/drivers/misc/altera_sysid.c @@ -0,0 +1,99 @@ +/* + * (C) Copyright 2004, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <misc.h> +#include <errno.h> +#include <command.h> +#include <asm/io.h> +#include <linux/time.h> + +struct altera_sysid_regs { + u32 id; /* The system build id */ + u32 timestamp; /* Timestamp */ +}; + +struct altera_sysid_platdata { + struct altera_sysid_regs *regs; +}; + +void display_sysid (void) +{ + struct udevice *dev; + const struct dm_misc_ops *ops; + u32 sysid[2]; + struct tm t; + char asc[32]; + time_t stamp; + + uclass_first_device(UCLASS_MISC, &dev); + if (!dev) + return; + ops = device_get_ops(dev); + if (!ops->read) + return; + ops->read(dev, 0, &sysid, sizeof(sysid)); + + stamp = sysid[1]; + localtime_r(&stamp, &t); + asctime_r(&t, asc); + printf("SYSID: %08x, %s", sysid[0], asc); +} + +int do_sysid (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + display_sysid(); + return 0; +} + +U_BOOT_CMD( + sysid, 1, 1, do_sysid, + "display Nios-II system id", + "" +); + +static int altera_sysid_read(struct udevice *dev, + int offset, void *buf, int size) +{ + struct altera_sysid_platdata *plat = dev->platdata; + struct altera_sysid_regs *const regs = plat->regs; + u32 *sysid = buf; + + sysid[0] = readl(®s->id); + sysid[1] = readl(®s->timestamp); + + return 0; +} + +static int altera_sysid_ofdata_to_platdata(struct udevice *dev) +{ + struct altera_sysid_platdata *plat = dev_get_platdata(dev); + + plat->regs = ioremap(dev_get_addr(dev), + sizeof(struct altera_sysid_regs)); + + return 0; +} + +static const struct dm_misc_ops altera_sysid_ops = { + .read = altera_sysid_read, +}; + +static const struct udevice_id altera_sysid_ids[] = { + { .compatible = "altr,sysid-1.0", }, + { } +}; + +U_BOOT_DRIVER(altera_sysid) = { + .name = "altera_sysid", + .id = UCLASS_MISC, + .of_match = altera_sysid_ids, + .ofdata_to_platdata = altera_sysid_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct altera_sysid_platdata), + .ops = &altera_sysid_ops, +}; diff --git a/include/configs/nios2-generic.h b/include/configs/nios2-generic.h index ae19676..bd219e3 100644 --- a/include/configs/nios2-generic.h +++ b/include/configs/nios2-generic.h @@ -16,8 +16,7 @@ #define CONFIG_BOARD_NAME "nios2-generic" /* custom board name */ #define CONFIG_BOARD_EARLY_INIT_F /* enable early board-spec. init */ #define CONFIG_BOARD_EARLY_INIT_R -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_DISPLAY_BOARDINFO_LATE #define CONFIG_SYS_NIOS_SYSID_BASE CONFIG_SYS_SYSID_BASE
Hi Thomas,
Thanks for the patch.
-#else
- display_sysid ();
-#endif
- return (0);
- printf("CPU: Nios-II\n");
- (C) Copyright 2004, Psyent Corporation <www.psyent.com>
- Scott McNutt smcnutt@psyent.com
-} nios_sysid_t;
- struct tm t;
- char asc[32];
- time_t stamp;
- display_sysid ();
- return (0);
-U_BOOT_CMD(
id = <0>;
I believe we won't need the id and timestamp as these will be read from sysid register.
Thanks Chin Liang
p/s: Oh ya, let me know if you need my help to send new revision of those patches commented by me. I can share the load :)
- extern void display_sysid(void);
- display_sysid();
- printf("BOARD: %s\n", CONFIG_BOARD_NAME); return 0;
- bool "Altera Sysid support"
- depends on DM_MISC
- help
- u32 id; /* The system build id */
- u32 timestamp; /* Timestamp */
- struct altera_sysid_regs *regs;
- struct udevice *dev;
- const struct dm_misc_ops *ops;
- u32 sysid[2];
- struct tm t;
- char asc[32];
- time_t stamp;
- uclass_first_device(UCLASS_MISC, &dev);
- if (!dev)
return;
- ops = device_get_ops(dev);
- if (!ops->read)
return;
- ops->read(dev, 0, &sysid, sizeof(sysid));
- stamp = sysid[1];
- localtime_r(&stamp, &t);
- asctime_r(&t, asc);
- printf("SYSID: %08x, %s", sysid[0], asc);
- display_sysid();
+U_BOOT_CMD(
- struct altera_sysid_platdata *plat = dev->platdata;
- struct altera_sysid_regs *const regs = plat->regs;
- u32 *sysid = buf;
- sysid[0] = readl(®s->id);
- sysid[1] = readl(®s->timestamp);
- struct altera_sysid_platdata *plat = dev_get_platdata(dev);
- plat->regs = ioremap(dev_get_addr(dev),
- .read = altera_sysid_read,
- { .compatible = "altr,sysid-1.0", },
- .name = "altera_sysid",
- .id = UCLASS_MISC,
- .of_match = altera_sysid_ids,
- .ofdata_to_platdata = altera_sysid_ofdata_to_platdata,
- .platdata_auto_alloc_size = sizeof(struct altera_sysid_platdata),
- .ops = &altera_sysid_ops,
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- v2 add missing misc.h.
drivers/misc/Kconfig | 6 ++++++ drivers/misc/Makefile | 1 + drivers/misc/misc-uclass.c | 14 ++++++++++++++ include/dm/uclass-id.h | 1 + include/misc.h | 22 ++++++++++++++++++++++ 5 files changed, 44 insertions(+) create mode 100644 drivers/misc/misc-uclass.c create mode 100644 include/misc.h
+obj-$(CONFIG_DM_MISC) += misc-uclass.o obj-$(CONFIG_ALI152X) += ali512x.o obj-$(CONFIG_DS4510) += ds4510.o obj-$(CONFIG_CBMEM_CONSOLE) += cbmem_console.o diff --git a/drivers/misc/misc-uclass.c b/drivers/misc/misc-uclass.c new file mode 100644 index 0000000..40fe947 --- /dev/null +++ b/drivers/misc/misc-uclass.c @@ -0,0 +1,14 @@ +/* + * Copyright (C) 2010 Thomas Chou thomas@wytron.com.tw + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <misc.h> + +UCLASS_DRIVER(misc) = { + .id = UCLASS_MISC, + .name = "misc", +}; diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index aff34a4..a6982ab 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -39,6 +39,7 @@ enum uclass_id { UCLASS_LED, /* Light-emitting diode (LED) */ UCLASS_LPC, /* x86 'low pin count' interface */ UCLASS_MASS_STORAGE, /* Mass storage device */ + UCLASS_MISC, /* Miscellaneous device */ UCLASS_MMC, /* SD / MMC card or chip */ UCLASS_MOD_EXP, /* RSA Mod Exp device */ UCLASS_PCH, /* x86 platform controller hub */ diff --git a/include/misc.h b/include/misc.h new file mode 100644 index 0000000..dfca41f --- /dev/null +++ b/include/misc.h @@ -0,0 +1,22 @@ +/* + * Copyright (C) 2015 Thomas Chou thomas@wytron.com.tw + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _DM_MISC_H_ +#define _DM_MISC_H_ + +/* + * struct dm_misc_ops - Driver model Misc operations + * + * The uclass interface is implemented by all miscellaneous devices which + * use driver model. + */ +struct dm_misc_ops { + int (*read)(struct udevice *dev, int offset, void *buf, int size); + int (*write)(struct udevice *dev, int offset, const void *buf, + int size); +}; + +#endif /* _DM_MISC_H_ */
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- v2 remove trailing whitespace in altera_sysid.c.
obj-$(CONFIG_DM_MISC) += misc-uclass.o obj-$(CONFIG_ALI152X) += ali512x.o +obj-$(CONFIG_ALTERA_SYSID) += altera_sysid.o obj-$(CONFIG_DS4510) += ds4510.o obj-$(CONFIG_CBMEM_CONSOLE) += cbmem_console.o obj-$(CONFIG_CROS_EC) += cros_ec.o diff --git a/drivers/misc/altera_sysid.c b/drivers/misc/altera_sysid.c new file mode 100644 index 0000000..e200bf7 --- /dev/null +++ b/drivers/misc/altera_sysid.c @@ -0,0 +1,99 @@ +/* + * (C) Copyright 2004, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <misc.h> +#include <errno.h> +#include <command.h> +#include <asm/io.h> +#include <linux/time.h> + +struct altera_sysid_regs { + u32 id; /* The system build id */ + u32 timestamp; /* Timestamp */ +}; + +struct altera_sysid_platdata { + struct altera_sysid_regs *regs; +}; + +void display_sysid (void) +{ + struct udevice *dev; + const struct dm_misc_ops *ops; + u32 sysid[2]; + struct tm t; + char asc[32]; + time_t stamp; + + uclass_first_device(UCLASS_MISC, &dev); + if (!dev) + return; + ops = device_get_ops(dev); + if (!ops->read) + return; + ops->read(dev, 0, &sysid, sizeof(sysid)); + + stamp = sysid[1]; + localtime_r(&stamp, &t); + asctime_r(&t, asc); + printf("SYSID: %08x, %s", sysid[0], asc); +} + +int do_sysid (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + display_sysid(); + return 0; +} + +U_BOOT_CMD( + sysid, 1, 1, do_sysid, + "display Nios-II system id", + "" +); + +static int altera_sysid_read(struct udevice *dev, + int offset, void *buf, int size) +{ + struct altera_sysid_platdata *plat = dev->platdata; + struct altera_sysid_regs *const regs = plat->regs; + u32 *sysid = buf; + + sysid[0] = readl(®s->id); + sysid[1] = readl(®s->timestamp); + + return 0; +} + +static int altera_sysid_ofdata_to_platdata(struct udevice *dev) +{ + struct altera_sysid_platdata *plat = dev_get_platdata(dev); + + plat->regs = ioremap(dev_get_addr(dev), + sizeof(struct altera_sysid_regs)); + + return 0; +} + +static const struct dm_misc_ops altera_sysid_ops = { + .read = altera_sysid_read, +}; + +static const struct udevice_id altera_sysid_ids[] = { + { .compatible = "altr,sysid-1.0", }, + { } +}; + +U_BOOT_DRIVER(altera_sysid) = { + .name = "altera_sysid", + .id = UCLASS_MISC, + .of_match = altera_sysid_ids, + .ofdata_to_platdata = altera_sysid_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct altera_sysid_platdata), + .ops = &altera_sysid_ops, +}; diff --git a/include/configs/nios2-generic.h b/include/configs/nios2-generic.h index ae19676..bd219e3 100644 --- a/include/configs/nios2-generic.h +++ b/include/configs/nios2-generic.h @@ -16,8 +16,7 @@ #define CONFIG_BOARD_NAME "nios2-generic" /* custom board name */ #define CONFIG_BOARD_EARLY_INIT_F /* enable early board-spec. init */ #define CONFIG_BOARD_EARLY_INIT_R -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_DISPLAY_BOARDINFO_LATE #define CONFIG_SYS_NIOS_SYSID_BASE CONFIG_SYS_SYSID_BASE
Hi Thomas,
-#else
- display_sysid ();
-#endif
- return (0);
- return 0; }
-} nios_sysid_t;
- struct tm t;
- char asc[32];
- time_t stamp;
- display_sysid ();
- return (0);
-U_BOOT_CMD(
id = <0>;
- display_sysid();
- printf("BOARD: %s\n", CONFIG_BOARD_NAME); return 0; }
- help
- config CMD_CROS_EC bool "Enable crosec command" depends on CROS_EC
Even though you have copied this code, please fix the coding style above (space before "("). For all occurrences in this patch, so that it is checkpatch clean.
Thank, Stefan
Hi Stefan,
Thanks a lot for reminding.
Best regards, Thomas Chou
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- v2 add missing misc.h. v3 no change.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- v2 remove trailing whitespace in altera_sysid.c. v3 fix coding style as suggested by Stefan.
arch/nios2/cpu/Makefile | 2 +- arch/nios2/cpu/cpu.c | 13 +--- arch/nios2/cpu/sysid.c | 46 -------------- arch/nios2/dts/3c120_devboard.dts | 8 +++ board/altera/nios2-generic/nios2-generic.c | 6 +- configs/nios2-generic_defconfig | 2 + drivers/misc/Kconfig | 7 +++ drivers/misc/Makefile | 1 + drivers/misc/altera_sysid.c | 99 ++++++++++++++++++++++++++++++ include/configs/nios2-generic.h | 2 +- 10 files changed, 126 insertions(+), 60 deletions(-) delete mode 100644 arch/nios2/cpu/sysid.c create mode 100644 drivers/misc/altera_sysid.c
extra-y = start.o obj-y = exceptions.o -obj-y += cpu.o interrupts.o sysid.o traps.o +obj-y += cpu.o interrupts.o traps.o obj-y += fdt.o diff --git a/arch/nios2/cpu/cpu.c b/arch/nios2/cpu/cpu.c index 88984e2..1d497ab 100644 --- a/arch/nios2/cpu/cpu.c +++ b/arch/nios2/cpu/cpu.c @@ -13,20 +13,11 @@
-#if defined (CONFIG_SYS_NIOS_SYSID_BASE) -extern void display_sysid (void); -#endif /* CONFIG_SYS_NIOS_SYSID_BASE */ - #ifdef CONFIG_DISPLAY_CPUINFO int print_cpuinfo(void) { - printf ("CPU : Nios-II\n"); -#if !defined(CONFIG_SYS_NIOS_SYSID_BASE) - printf ("SYSID : <unknown>\n"); -#else - display_sysid (); -#endif - return (0); + printf("CPU: Nios-II\n"); + return 0; } #endif /* CONFIG_DISPLAY_CPUINFO */
obj-$(CONFIG_DM_MISC) += misc-uclass.o obj-$(CONFIG_ALI152X) += ali512x.o +obj-$(CONFIG_ALTERA_SYSID) += altera_sysid.o obj-$(CONFIG_DS4510) += ds4510.o obj-$(CONFIG_CBMEM_CONSOLE) += cbmem_console.o obj-$(CONFIG_CROS_EC) += cros_ec.o diff --git a/drivers/misc/altera_sysid.c b/drivers/misc/altera_sysid.c new file mode 100644 index 0000000..968f59c --- /dev/null +++ b/drivers/misc/altera_sysid.c @@ -0,0 +1,99 @@ +/* + * (C) Copyright 2004, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <misc.h> +#include <errno.h> +#include <command.h> +#include <asm/io.h> +#include <linux/time.h> + +struct altera_sysid_regs { + u32 id; /* The system build id */ + u32 timestamp; /* Timestamp */ +}; + +struct altera_sysid_platdata { + struct altera_sysid_regs *regs; +}; + +void display_sysid(void) +{ + struct udevice *dev; + const struct dm_misc_ops *ops; + u32 sysid[2]; + struct tm t; + char asc[32]; + time_t stamp; + + uclass_first_device(UCLASS_MISC, &dev); + if (!dev) + return; + ops = device_get_ops(dev); + if (!ops->read) + return; + ops->read(dev, 0, &sysid, sizeof(sysid)); + + stamp = sysid[1]; + localtime_r(&stamp, &t); + asctime_r(&t, asc); + printf("SYSID: %08x, %s", sysid[0], asc); +} + +int do_sysid(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + display_sysid(); + return 0; +} + +U_BOOT_CMD( + sysid, 1, 1, do_sysid, + "display Nios-II system id", + "" +); + +static int altera_sysid_read(struct udevice *dev, + int offset, void *buf, int size) +{ + struct altera_sysid_platdata *plat = dev->platdata; + struct altera_sysid_regs *const regs = plat->regs; + u32 *sysid = buf; + + sysid[0] = readl(®s->id); + sysid[1] = readl(®s->timestamp); + + return 0; +} + +static int altera_sysid_ofdata_to_platdata(struct udevice *dev) +{ + struct altera_sysid_platdata *plat = dev_get_platdata(dev); + + plat->regs = ioremap(dev_get_addr(dev), + sizeof(struct altera_sysid_regs)); + + return 0; +} + +static const struct dm_misc_ops altera_sysid_ops = { + .read = altera_sysid_read, +}; + +static const struct udevice_id altera_sysid_ids[] = { + { .compatible = "altr,sysid-1.0", }, + { } +}; + +U_BOOT_DRIVER(altera_sysid) = { + .name = "altera_sysid", + .id = UCLASS_MISC, + .of_match = altera_sysid_ids, + .ofdata_to_platdata = altera_sysid_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct altera_sysid_platdata), + .ops = &altera_sysid_ops, +}; diff --git a/include/configs/nios2-generic.h b/include/configs/nios2-generic.h index ae19676..16a16f3 100644 --- a/include/configs/nios2-generic.h +++ b/include/configs/nios2-generic.h @@ -17,7 +17,7 @@ #define CONFIG_BOARD_EARLY_INIT_F /* enable early board-spec. init */ #define CONFIG_BOARD_EARLY_INIT_R #define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_DISPLAY_BOARDINFO_LATE #define CONFIG_SYS_NIOS_SYSID_BASE CONFIG_SYS_SYSID_BASE
Hi Thomas,
+config DM_MISC
depends on DM
help
Need to explain this a bit more! When do I use it, mention that it has read and write.
I'm not sure about the name 'misc' but I suppose it makes sense. I wonder if you should add 'ioctl' also?
- Copyright (C) 2010 Thomas Chou thomas@wytron.com.tw
.id = UCLASS_MISC,
.name = "misc",
- Copyright (C) 2015 Thomas Chou thomas@wytron.com.tw
- struct dm_misc_ops - Driver model Misc operations
- The uclass interface is implemented by all miscellaneous devices which
- use driver model.
int size);
Method comments
Also don't you need to create misc_read() and misc_write() functions so people can use it?
2.1.4
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- v2 add missing misc.h. v3 no change. v4 add ioctl and comments as Simon suggested.
drivers/misc/Kconfig | 9 ++++++ drivers/misc/Makefile | 1 + drivers/misc/misc-uclass.c | 52 ++++++++++++++++++++++++++++++ include/dm/uclass-id.h | 1 + include/misc.h | 79 ++++++++++++++++++++++++++++++++++++++++++++++ 5 files changed, 142 insertions(+) create mode 100644 drivers/misc/misc-uclass.c create mode 100644 include/misc.h
diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index 8b38a84..2699329 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -4,6 +4,15 @@
+config DM_MISC + bool "Enable Driver Model for Misc drivers" + depends on DM + help + Enable driver model for miscellaneous devices. This class is + used only for those do not fit other more general classes. A + set of generic read, write and ioctl methods may be used to + access the device. + config CMD_CROS_EC bool "Enable crosec command" depends on CROS_EC diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index 8d0fc3c..b285946 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -5,6 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
+obj-$(CONFIG_DM_MISC) += misc-uclass.o obj-$(CONFIG_ALI152X) += ali512x.o obj-$(CONFIG_DS4510) += ds4510.o obj-$(CONFIG_CBMEM_CONSOLE) += cbmem_console.o diff --git a/drivers/misc/misc-uclass.c b/drivers/misc/misc-uclass.c new file mode 100644 index 0000000..7cfcd4c --- /dev/null +++ b/drivers/misc/misc-uclass.c @@ -0,0 +1,52 @@ +/* + * Copyright (C) 2010 Thomas Chou thomas@wytron.com.tw + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <misc.h> + +/* + * Implement a miscellaneous uclass for those do not fit other more + * general classes. A set of generic read, write and ioctl methods may + * be used to access the device. + */ + +int misc_read(struct udevice *dev, int offset, void *buf, int size) +{ + const struct dm_misc_ops *ops = device_get_ops(dev); + + if (!ops->read) + return -ENOSYS; + + return ops->read(dev, offset, buf, size); +} + +int misc_write(struct udevice *dev, int offset, void *buf, int size) +{ + const struct dm_misc_ops *ops = device_get_ops(dev); + + if (!ops->write) + return -ENOSYS; + + return ops->write(dev, offset, buf, size); +} + +int misc_ioctl(struct udevice *dev, unsigned long request, void *buf) +{ + const struct dm_misc_ops *ops = device_get_ops(dev); + + if (!ops->ioctl) + return -ENOSYS; + + return ops->ioctl(dev, request, buf); +} + + +UCLASS_DRIVER(misc) = { + .id = UCLASS_MISC, + .name = "misc", +}; diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index aff34a4..a6982ab 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -39,6 +39,7 @@ enum uclass_id { UCLASS_LED, /* Light-emitting diode (LED) */ UCLASS_LPC, /* x86 'low pin count' interface */ UCLASS_MASS_STORAGE, /* Mass storage device */ + UCLASS_MISC, /* Miscellaneous device */ UCLASS_MMC, /* SD / MMC card or chip */ UCLASS_MOD_EXP, /* RSA Mod Exp device */ UCLASS_PCH, /* x86 platform controller hub */ diff --git a/include/misc.h b/include/misc.h new file mode 100644 index 0000000..73de11b --- /dev/null +++ b/include/misc.h @@ -0,0 +1,79 @@ +/* + * Copyright (C) 2015 Thomas Chou thomas@wytron.com.tw + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _DM_MISC_H_ +#define _DM_MISC_H_ + +/* + * Read the device to buffer, optional. + * + * @dev: the device + * @offset: offset to read the device + * @buf: pointer to data buffer + * @size: data size in bytes to read the device + * @return: 0 if OK, -ve on error + */ +int misc_read(struct udevice *dev, int offset, void *buf, int size); +/* + * Write buffer to the device, optional. + * + * @dev: the device + * @offset: offset to write the device + * @buf: pointer to data buffer + * @size: data size in bytes to write the device + * @return: 0 if OK, -ve on error + */ +int misc_write(struct udevice *dev, int offset, void *buf, int size); +/* + * Assert command to the device, optional. + * + * @dev: the device + * @request: command to be sent to the device + * @buf: pointer to buffer related to the requset + * @return: 0 if OK, -ve on error + */ +int misc_ioctl(struct udevice *dev, unsigned long request, void *buf); + +/* + * struct dm_misc_ops - Driver model Misc operations + * + * The uclass interface is implemented by all miscellaneous devices which + * use driver model. + */ +struct dm_misc_ops { + /* + * Read the device to buffer, optional. + * + * @dev: the device + * @offset: offset to read the device + * @buf: pointer to data buffer + * @size: data size in bytes to read the device + * @return: 0 if OK, -ve on error + */ + int (*read)(struct udevice *dev, int offset, void *buf, int size); + /* + * Write buffer to the device, optional. + * + * @dev: the device + * @offset: offset to write the device + * @buf: pointer to data buffer + * @size: data size in bytes to write the device + * @return: 0 if OK, -ve on error + */ + int (*write)(struct udevice *dev, int offset, const void *buf, + int size); + /* + * Assert command to the device, optional. + * + * @dev: the device + * @request: command to be sent to the device + * @buf: pointer to buffer related to the requset + * @return: 0 if OK, -ve on error + */ + int (*ioctl)(struct udevice *dev, unsigned long request, void *buf); +}; + +#endif /* _DM_MISC_H_ */
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- v2 remove trailing whitespace in altera_sysid.c. v3 fix coding style as suggested by Stefan. v4 clean up sysid and timestamp in dts as Chin Liang suggested.
arch/nios2/cpu/Makefile | 2 +- arch/nios2/cpu/cpu.c | 13 +--- arch/nios2/cpu/sysid.c | 46 ------------- arch/nios2/dts/3c120_devboard.dts | 6 ++ board/altera/nios2-generic/nios2-generic.c | 6 +- configs/nios2-generic_defconfig | 2 + drivers/misc/Kconfig | 7 ++ drivers/misc/Makefile | 1 + drivers/misc/altera_sysid.c | 101 +++++++++++++++++++++++++++++ include/configs/nios2-generic.h | 2 +- 10 files changed, 126 insertions(+), 60 deletions(-) delete mode 100644 arch/nios2/cpu/sysid.c create mode 100644 drivers/misc/altera_sysid.c
extra-y = start.o obj-y = exceptions.o -obj-y += cpu.o interrupts.o sysid.o traps.o +obj-y += cpu.o interrupts.o traps.o obj-y += fdt.o diff --git a/arch/nios2/cpu/cpu.c b/arch/nios2/cpu/cpu.c index bd11abc..106f0bf 100644 --- a/arch/nios2/cpu/cpu.c +++ b/arch/nios2/cpu/cpu.c @@ -13,20 +13,11 @@
diff --git a/arch/nios2/cpu/sysid.c b/arch/nios2/cpu/sysid.c deleted file mode 100644 index 50819b2..0000000 --- a/arch/nios2/cpu/sysid.c +++ /dev/null @@ -1,46 +0,0 @@ -/* - * (C) Copyright 2004, Psyent Corporation <www.psyent.com> - * Scott McNutt smcnutt@psyent.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> - -#if defined (CONFIG_SYS_NIOS_SYSID_BASE) - -#include <command.h> -#include <asm/io.h> -#include <linux/time.h> - -typedef volatile struct { - unsigned id; /* The system build id */ - unsigned timestamp; /* Timestamp */ -} nios_sysid_t; - -void display_sysid (void) -{ - nios_sysid_t *sysid = (nios_sysid_t *)CONFIG_SYS_NIOS_SYSID_BASE; - struct tm t; - char asc[32]; - time_t stamp; - - stamp = readl (&sysid->timestamp); - localtime_r (&stamp, &t); - asctime_r (&t, asc); - printf ("SYSID : %08lx, %s", readl (&sysid->id), asc); - -} - -int do_sysid (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - display_sysid (); - return (0); -} - -U_BOOT_CMD( - sysid, 1, 1, do_sysid, - "display Nios-II system id", - "" -); -#endif /* CONFIG_SYS_NIOS_SYSID_BASE */ diff --git a/arch/nios2/dts/3c120_devboard.dts b/arch/nios2/dts/3c120_devboard.dts index 2e2956f..2455fff 100644 --- a/arch/nios2/dts/3c120_devboard.dts +++ b/arch/nios2/dts/3c120_devboard.dts @@ -72,6 +72,7 @@ <0x00004cc0 0x08004cc0 0x00000010>, <0x00004ce0 0x08004ce0 0x00000010>, <0x00004d00 0x08004d00 0x00000010>, + <0x00004d40 0x08004d40 0x00000008>, <0x00004d50 0x08004d50 0x00000008>, <0x00008000 0x08008000 0x00000020>, <0x00400000 0x08400000 0x00000020>; @@ -92,6 +93,11 @@ clock-frequency = < 125000000 >; };
+ sysid: sysid@0x4d40 { + compatible = "altr,sysid-1.0"; + reg = <0x00004d40 0x00000008>; + }; + jtag_uart: serial@0x4d50 { compatible = "altr,juart-1.0"; reg = <0x00004d50 0x00000008>; diff --git a/board/altera/nios2-generic/nios2-generic.c b/board/altera/nios2-generic/nios2-generic.c index 61d32c7..e08b8f7 100644 --- a/board/altera/nios2-generic/nios2-generic.c +++ b/board/altera/nios2-generic/nios2-generic.c @@ -42,7 +42,11 @@ int board_early_init_r(void)
diff --git a/configs/nios2-generic_defconfig b/configs/nios2-generic_defconfig index dac0b62..5576413 100644 --- a/configs/nios2-generic_defconfig +++ b/configs/nios2-generic_defconfig @@ -16,6 +16,8 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_ALTERA_PIO=y +CONFIG_DM_MISC=y +CONFIG_ALTERA_SYSID=y CONFIG_ALTERA_JTAG_UART=y CONFIG_ALTERA_JTAG_UART_BYPASS=y CONFIG_DM_TIMER=y diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index 2699329..a292289 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -13,6 +13,13 @@ config DM_MISC set of generic read, write and ioctl methods may be used to access the device.
obj-$(CONFIG_DM_MISC) += misc-uclass.o obj-$(CONFIG_ALI152X) += ali512x.o +obj-$(CONFIG_ALTERA_SYSID) += altera_sysid.o obj-$(CONFIG_DS4510) += ds4510.o obj-$(CONFIG_CBMEM_CONSOLE) += cbmem_console.o obj-$(CONFIG_CROS_EC) += cros_ec.o diff --git a/drivers/misc/altera_sysid.c b/drivers/misc/altera_sysid.c new file mode 100644 index 0000000..980f3b6 --- /dev/null +++ b/drivers/misc/altera_sysid.c @@ -0,0 +1,101 @@ +/* + * (C) Copyright 2004, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <misc.h> +#include <errno.h> +#include <command.h> +#include <asm/io.h> +#include <linux/time.h> + +struct altera_sysid_regs { + u32 id; /* The system build id */ + u32 timestamp; /* Timestamp */ +}; + +struct altera_sysid_platdata { + struct altera_sysid_regs *regs; +}; + +void display_sysid(void) +{ + struct udevice *dev; + u32 sysid[2]; + struct tm t; + char asc[32]; + time_t stamp; + int ret; + + /* the first misc device will be used */ + ret = uclass_first_device(UCLASS_MISC, &dev); + if (ret) + return; + if (!dev) + return; + ret = misc_read(dev, 0, &sysid, sizeof(sysid)); + if (ret) + return; + + stamp = sysid[1]; + localtime_r(&stamp, &t); + asctime_r(&t, asc); + printf("SYSID: %08x, %s", sysid[0], asc); +} + +int do_sysid(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + display_sysid(); + return 0; +} + +U_BOOT_CMD( + sysid, 1, 1, do_sysid, + "display Nios-II system id", + "" +); + +static int altera_sysid_read(struct udevice *dev, + int offset, void *buf, int size) +{ + struct altera_sysid_platdata *plat = dev->platdata; + struct altera_sysid_regs *const regs = plat->regs; + u32 *sysid = buf; + + sysid[0] = readl(®s->id); + sysid[1] = readl(®s->timestamp); + + return 0; +} + +static int altera_sysid_ofdata_to_platdata(struct udevice *dev) +{ + struct altera_sysid_platdata *plat = dev_get_platdata(dev); + + plat->regs = ioremap(dev_get_addr(dev), + sizeof(struct altera_sysid_regs)); + + return 0; +} + +static const struct dm_misc_ops altera_sysid_ops = { + .read = altera_sysid_read, +}; + +static const struct udevice_id altera_sysid_ids[] = { + { .compatible = "altr,sysid-1.0", }, + { } +}; + +U_BOOT_DRIVER(altera_sysid) = { + .name = "altera_sysid", + .id = UCLASS_MISC, + .of_match = altera_sysid_ids, + .ofdata_to_platdata = altera_sysid_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct altera_sysid_platdata), + .ops = &altera_sysid_ops, +}; diff --git a/include/configs/nios2-generic.h b/include/configs/nios2-generic.h index ae19676..16a16f3 100644 --- a/include/configs/nios2-generic.h +++ b/include/configs/nios2-generic.h @@ -17,7 +17,7 @@ #define CONFIG_BOARD_EARLY_INIT_F /* enable early board-spec. init */ #define CONFIG_BOARD_EARLY_INIT_R #define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_DISPLAY_BOARDINFO_LATE #define CONFIG_SYS_NIOS_SYSID_BASE CONFIG_SYS_SYSID_BASE
Hi Thomas,
-#else
display_sysid ();
-#endif
return (0);
-} nios_sysid_t;
struct tm t;
char asc[32];
time_t stamp;
display_sysid ();
return (0);
-U_BOOT_CMD(
Should that go in a system header file asm/system.h or similar?
display_sysid();
depends on DM_MISC
help
nit: Should sort these
common.h command.h dm.h errno.h misc.h
u32 sysid[2];
struct tm t;
char asc[32];
time_t stamp;
int ret;
if (ret)
return;
if (!dev)
return;
if (ret)
return;
stamp = sysid[1];
asctime_r(&t, asc);
display_sysid();
+U_BOOT_CMD(
u32 *sysid = buf;
.id = UCLASS_MISC,
2.1.4
Hi Thomas,
Acked-by: Chin Liang See clsee@altera.com
Thanks Chin Liang
Signed-off-by: Thomas Chou thomas@wytron.com.tw Acked-by: Simon Glass sjg@chromium.org --- v2 add missing misc.h. v3 no change. v4 add ioctl and comments as Simon suggested. v5 no change.
drivers/misc/Kconfig | 9 ++++++ drivers/misc/Makefile | 1 + drivers/misc/misc-uclass.c | 51 ++++++++++++++++++++++++++++++ include/dm/uclass-id.h | 1 + include/misc.h | 79 ++++++++++++++++++++++++++++++++++++++++++++++ 5 files changed, 141 insertions(+) create mode 100644 drivers/misc/misc-uclass.c create mode 100644 include/misc.h
+obj-$(CONFIG_DM_MISC) += misc-uclass.o obj-$(CONFIG_ALI152X) += ali512x.o obj-$(CONFIG_DS4510) += ds4510.o obj-$(CONFIG_CBMEM_CONSOLE) += cbmem_console.o diff --git a/drivers/misc/misc-uclass.c b/drivers/misc/misc-uclass.c new file mode 100644 index 0000000..a436ff5 --- /dev/null +++ b/drivers/misc/misc-uclass.c @@ -0,0 +1,51 @@ +/* + * Copyright (C) 2010 Thomas Chou thomas@wytron.com.tw + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <misc.h> + +/* + * Implement a miscellaneous uclass for those do not fit other more + * general classes. A set of generic read, write and ioctl methods may + * be used to access the device. + */ + +int misc_read(struct udevice *dev, int offset, void *buf, int size) +{ + const struct dm_misc_ops *ops = device_get_ops(dev); + + if (!ops->read) + return -ENOSYS; + + return ops->read(dev, offset, buf, size); +} + +int misc_write(struct udevice *dev, int offset, void *buf, int size) +{ + const struct dm_misc_ops *ops = device_get_ops(dev); + + if (!ops->write) + return -ENOSYS; + + return ops->write(dev, offset, buf, size); +} + +int misc_ioctl(struct udevice *dev, unsigned long request, void *buf) +{ + const struct dm_misc_ops *ops = device_get_ops(dev); + + if (!ops->ioctl) + return -ENOSYS; + + return ops->ioctl(dev, request, buf); +} + +UCLASS_DRIVER(misc) = { + .id = UCLASS_MISC, + .name = "misc", +}; diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index aff34a4..a6982ab 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -39,6 +39,7 @@ enum uclass_id { UCLASS_LED, /* Light-emitting diode (LED) */ UCLASS_LPC, /* x86 'low pin count' interface */ UCLASS_MASS_STORAGE, /* Mass storage device */ + UCLASS_MISC, /* Miscellaneous device */ UCLASS_MMC, /* SD / MMC card or chip */ UCLASS_MOD_EXP, /* RSA Mod Exp device */ UCLASS_PCH, /* x86 platform controller hub */ diff --git a/include/misc.h b/include/misc.h new file mode 100644 index 0000000..73de11b --- /dev/null +++ b/include/misc.h @@ -0,0 +1,79 @@ +/* + * Copyright (C) 2015 Thomas Chou thomas@wytron.com.tw + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _DM_MISC_H_ +#define _DM_MISC_H_ + +/* + * Read the device to buffer, optional. + * + * @dev: the device + * @offset: offset to read the device + * @buf: pointer to data buffer + * @size: data size in bytes to read the device + * @return: 0 if OK, -ve on error + */ +int misc_read(struct udevice *dev, int offset, void *buf, int size); +/* + * Write buffer to the device, optional. + * + * @dev: the device + * @offset: offset to write the device + * @buf: pointer to data buffer + * @size: data size in bytes to write the device + * @return: 0 if OK, -ve on error + */ +int misc_write(struct udevice *dev, int offset, void *buf, int size); +/* + * Assert command to the device, optional. + * + * @dev: the device + * @request: command to be sent to the device + * @buf: pointer to buffer related to the requset + * @return: 0 if OK, -ve on error + */ +int misc_ioctl(struct udevice *dev, unsigned long request, void *buf); + +/* + * struct dm_misc_ops - Driver model Misc operations + * + * The uclass interface is implemented by all miscellaneous devices which + * use driver model. + */ +struct dm_misc_ops { + /* + * Read the device to buffer, optional. + * + * @dev: the device + * @offset: offset to read the device + * @buf: pointer to data buffer + * @size: data size in bytes to read the device + * @return: 0 if OK, -ve on error + */ + int (*read)(struct udevice *dev, int offset, void *buf, int size); + /* + * Write buffer to the device, optional. + * + * @dev: the device + * @offset: offset to write the device + * @buf: pointer to data buffer + * @size: data size in bytes to write the device + * @return: 0 if OK, -ve on error + */ + int (*write)(struct udevice *dev, int offset, const void *buf, + int size); + /* + * Assert command to the device, optional. + * + * @dev: the device + * @request: command to be sent to the device + * @buf: pointer to buffer related to the requset + * @return: 0 if OK, -ve on error + */ + int (*ioctl)(struct udevice *dev, unsigned long request, void *buf); +}; + +#endif /* _DM_MISC_H_ */
Signed-off-by: Thomas Chou thomas@wytron.com.tw Acked-by: Chin Liang See clsee@altera.com --- v2 fix coding style. v3 doc dts binding. v4 no change. v5 sort headers inclusion as Simon suggested. add display_sysid() to asm/system.h.
arch/nios2/cpu/Makefile | 2 +- arch/nios2/cpu/cpu.c | 13 +--- arch/nios2/cpu/sysid.c | 46 ------------- arch/nios2/dts/3c120_devboard.dts | 6 ++ arch/nios2/include/asm/system.h | 2 + board/altera/nios2-generic/nios2-generic.c | 5 +- configs/nios2-generic_defconfig | 2 + drivers/misc/Kconfig | 7 ++ drivers/misc/Makefile | 1 + drivers/misc/altera_sysid.c | 101 +++++++++++++++++++++++++++++ include/configs/nios2-generic.h | 2 +- 11 files changed, 127 insertions(+), 60 deletions(-) delete mode 100644 arch/nios2/cpu/sysid.c create mode 100644 drivers/misc/altera_sysid.c
+ sysid: sysid@0x4d40 { + compatible = "altr,sysid-1.0"; + reg = <0x00004d40 0x00000008>; + }; + jtag_uart: serial@0x4d50 { compatible = "altr,juart-1.0"; reg = <0x00004d50 0x00000008>; diff --git a/arch/nios2/include/asm/system.h b/arch/nios2/include/asm/system.h index 6213a16..b158535 100644 --- a/arch/nios2/include/asm/system.h +++ b/arch/nios2/include/asm/system.h @@ -45,4 +45,6 @@ "callr %0" \ : : "r" (addr))
+void display_sysid(void); + #endif /* __ASM_NIOS2_SYSTEM_H */ diff --git a/board/altera/nios2-generic/nios2-generic.c b/board/altera/nios2-generic/nios2-generic.c index 61d32c7..be5c350 100644 --- a/board/altera/nios2-generic/nios2-generic.c +++ b/board/altera/nios2-generic/nios2-generic.c @@ -42,7 +42,10 @@ int board_early_init_r(void)
int checkboard(void) { - printf("BOARD : %s\n", CONFIG_BOARD_NAME); +#ifdef CONFIG_ALTERA_SYSID + display_sysid(); +#endif + printf("BOARD: %s\n", CONFIG_BOARD_NAME); return 0; }
obj-$(CONFIG_DM_MISC) += misc-uclass.o obj-$(CONFIG_ALI152X) += ali512x.o +obj-$(CONFIG_ALTERA_SYSID) += altera_sysid.o obj-$(CONFIG_DS4510) += ds4510.o obj-$(CONFIG_CBMEM_CONSOLE) += cbmem_console.o obj-$(CONFIG_CROS_EC) += cros_ec.o diff --git a/drivers/misc/altera_sysid.c b/drivers/misc/altera_sysid.c new file mode 100644 index 0000000..177e434 --- /dev/null +++ b/drivers/misc/altera_sysid.c @@ -0,0 +1,101 @@ +/* + * (C) Copyright 2004, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <command.h> +#include <dm.h> +#include <errno.h> +#include <misc.h> +#include <linux/time.h> +#include <asm/io.h> + +struct altera_sysid_regs { + u32 id; /* The system build id */ + u32 timestamp; /* Timestamp */ +}; + +struct altera_sysid_platdata { + struct altera_sysid_regs *regs; +}; + +void display_sysid(void) +{ + struct udevice *dev; + u32 sysid[2]; + struct tm t; + char asc[32]; + time_t stamp; + int ret; + + /* the first misc device will be used */ + ret = uclass_first_device(UCLASS_MISC, &dev); + if (ret) + return; + if (!dev) + return; + ret = misc_read(dev, 0, &sysid, sizeof(sysid)); + if (ret) + return; + + stamp = sysid[1]; + localtime_r(&stamp, &t); + asctime_r(&t, asc); + printf("SYSID: %08x, %s", sysid[0], asc); +} + +int do_sysid(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + display_sysid(); + return 0; +} + +U_BOOT_CMD( + sysid, 1, 1, do_sysid, + "display Nios-II system id", + "" +); + +static int altera_sysid_read(struct udevice *dev, + int offset, void *buf, int size) +{ + struct altera_sysid_platdata *plat = dev->platdata; + struct altera_sysid_regs *const regs = plat->regs; + u32 *sysid = buf; + + sysid[0] = readl(®s->id); + sysid[1] = readl(®s->timestamp); + + return 0; +} + +static int altera_sysid_ofdata_to_platdata(struct udevice *dev) +{ + struct altera_sysid_platdata *plat = dev_get_platdata(dev); + + plat->regs = ioremap(dev_get_addr(dev), + sizeof(struct altera_sysid_regs)); + + return 0; +} + +static const struct dm_misc_ops altera_sysid_ops = { + .read = altera_sysid_read, +}; + +static const struct udevice_id altera_sysid_ids[] = { + { .compatible = "altr,sysid-1.0", }, + { } +}; + +U_BOOT_DRIVER(altera_sysid) = { + .name = "altera_sysid", + .id = UCLASS_MISC, + .of_match = altera_sysid_ids, + .ofdata_to_platdata = altera_sysid_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct altera_sysid_platdata), + .ops = &altera_sysid_ops, +}; diff --git a/include/configs/nios2-generic.h b/include/configs/nios2-generic.h index ae19676..16a16f3 100644 --- a/include/configs/nios2-generic.h +++ b/include/configs/nios2-generic.h @@ -17,7 +17,7 @@ #define CONFIG_BOARD_EARLY_INIT_F /* enable early board-spec. init */ #define CONFIG_BOARD_EARLY_INIT_R #define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_DISPLAY_BOARDINFO_LATE #define CONFIG_SYS_NIOS_SYSID_BASE CONFIG_SYS_SYSID_BASE
Signed-off-by: Thomas Chou thomas@wytron.com.tw Acked-by: Simon Glass sjg@chromium.org --- v2 add missing misc.h. v3 no change. v4 add ioctl and comments as Simon suggested. v5 no change. v6 replace DM_MISC to MISC.
+config MISC + bool "Enable Driver Model for Misc drivers" + depends on DM + help + Enable driver model for miscellaneous devices. This class is + used only for those do not fit other more general classes. A + set of generic read, write and ioctl methods may be used to + access the device. + config CMD_CROS_EC bool "Enable crosec command" depends on CROS_EC diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index 8d0fc3c..b285946 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -5,6 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
+obj-$(CONFIG_MISC) += misc-uclass.o obj-$(CONFIG_ALI152X) += ali512x.o obj-$(CONFIG_DS4510) += ds4510.o obj-$(CONFIG_CBMEM_CONSOLE) += cbmem_console.o diff --git a/drivers/misc/misc-uclass.c b/drivers/misc/misc-uclass.c new file mode 100644 index 0000000..a436ff5 --- /dev/null +++ b/drivers/misc/misc-uclass.c @@ -0,0 +1,51 @@ +/* + * Copyright (C) 2010 Thomas Chou thomas@wytron.com.tw + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <misc.h> + +/* + * Implement a miscellaneous uclass for those do not fit other more + * general classes. A set of generic read, write and ioctl methods may + * be used to access the device. + */ + +int misc_read(struct udevice *dev, int offset, void *buf, int size) +{ + const struct misc_ops *ops = device_get_ops(dev); + + if (!ops->read) + return -ENOSYS; + + return ops->read(dev, offset, buf, size); +} + +int misc_write(struct udevice *dev, int offset, void *buf, int size) +{ + const struct misc_ops *ops = device_get_ops(dev); + + if (!ops->write) + return -ENOSYS; + + return ops->write(dev, offset, buf, size); +} + +int misc_ioctl(struct udevice *dev, unsigned long request, void *buf) +{ + const struct misc_ops *ops = device_get_ops(dev); + + if (!ops->ioctl) + return -ENOSYS; + + return ops->ioctl(dev, request, buf); +} + +UCLASS_DRIVER(misc) = { + .id = UCLASS_MISC, + .name = "misc", +}; diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index aff34a4..a6982ab 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -39,6 +39,7 @@ enum uclass_id { UCLASS_LED, /* Light-emitting diode (LED) */ UCLASS_LPC, /* x86 'low pin count' interface */ UCLASS_MASS_STORAGE, /* Mass storage device */ + UCLASS_MISC, /* Miscellaneous device */ UCLASS_MMC, /* SD / MMC card or chip */ UCLASS_MOD_EXP, /* RSA Mod Exp device */ UCLASS_PCH, /* x86 platform controller hub */ diff --git a/include/misc.h b/include/misc.h new file mode 100644 index 0000000..73de11b --- /dev/null +++ b/include/misc.h @@ -0,0 +1,79 @@ +/* + * Copyright (C) 2015 Thomas Chou thomas@wytron.com.tw + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _MISC_H_ +#define _MISC_H_ + +/* + * Read the device to buffer, optional. + * + * @dev: the device + * @offset: offset to read the device + * @buf: pointer to data buffer + * @size: data size in bytes to read the device + * @return: 0 if OK, -ve on error + */ +int misc_read(struct udevice *dev, int offset, void *buf, int size); +/* + * Write buffer to the device, optional. + * + * @dev: the device + * @offset: offset to write the device + * @buf: pointer to data buffer + * @size: data size in bytes to write the device + * @return: 0 if OK, -ve on error + */ +int misc_write(struct udevice *dev, int offset, void *buf, int size); +/* + * Assert command to the device, optional. + * + * @dev: the device + * @request: command to be sent to the device + * @buf: pointer to buffer related to the requset + * @return: 0 if OK, -ve on error + */ +int misc_ioctl(struct udevice *dev, unsigned long request, void *buf); + +/* + * struct misc_ops - Driver model Misc operations + * + * The uclass interface is implemented by all miscellaneous devices which + * use driver model. + */ +struct misc_ops { + /* + * Read the device to buffer, optional. + * + * @dev: the device + * @offset: offset to read the device + * @buf: pointer to data buffer + * @size: data size in bytes to read the device + * @return: 0 if OK, -ve on error + */ + int (*read)(struct udevice *dev, int offset, void *buf, int size); + /* + * Write buffer to the device, optional. + * + * @dev: the device + * @offset: offset to write the device + * @buf: pointer to data buffer + * @size: data size in bytes to write the device + * @return: 0 if OK, -ve on error + */ + int (*write)(struct udevice *dev, int offset, const void *buf, + int size); + /* + * Assert command to the device, optional. + * + * @dev: the device + * @request: command to be sent to the device + * @buf: pointer to buffer related to the requset + * @return: 0 if OK, -ve on error + */ + int (*ioctl)(struct udevice *dev, unsigned long request, void *buf); +}; + +#endif /* _MISC_H_ */
Signed-off-by: Thomas Chou thomas@wytron.com.tw Acked-by: Chin Liang See clsee@altera.com Reviewed-by: Simon Glass sjg@chromium.org --- v2 fix coding style. v3 doc dts binding. v4 no change. v5 sort headers inclusion as Simon suggested. add display_sysid() to asm/system.h. v6 replace DM_MISC to MISC.
+void display_sysid(void); + #endif /* __ASM_NIOS2_SYSTEM_H */ diff --git a/board/altera/nios2-generic/nios2-generic.c b/board/altera/nios2-generic/nios2-generic.c index cb98a08..1f10821 100644 --- a/board/altera/nios2-generic/nios2-generic.c +++ b/board/altera/nios2-generic/nios2-generic.c @@ -37,7 +37,10 @@ int board_early_init_f(void)
diff --git a/configs/nios2-generic_defconfig b/configs/nios2-generic_defconfig index 505a2cf..a9020ff 100644 --- a/configs/nios2-generic_defconfig +++ b/configs/nios2-generic_defconfig @@ -16,6 +16,8 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_ALTERA_PIO=y +CONFIG_MISC=y +CONFIG_ALTERA_SYSID=y CONFIG_ALTERA_JTAG_UART=y CONFIG_ALTERA_JTAG_UART_BYPASS=y CONFIG_TIMER=y diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index 2699329..a292289 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -13,6 +13,13 @@ config MISC set of generic read, write and ioctl methods may be used to access the device.
+config ALTERA_SYSID + bool "Altera Sysid support" + depends on MISC + help + Select this to enable a sysid for Altera devices. Please find + details on the "Embedded Peripherals IP User Guide" of Altera. + config CMD_CROS_EC bool "Enable crosec command" depends on CROS_EC diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index b285946..449425e 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -7,6 +7,7 @@
obj-$(CONFIG_MISC) += misc-uclass.o obj-$(CONFIG_ALI152X) += ali512x.o +obj-$(CONFIG_ALTERA_SYSID) += altera_sysid.o obj-$(CONFIG_DS4510) += ds4510.o obj-$(CONFIG_CBMEM_CONSOLE) += cbmem_console.o obj-$(CONFIG_CROS_EC) += cros_ec.o diff --git a/drivers/misc/altera_sysid.c b/drivers/misc/altera_sysid.c new file mode 100644 index 0000000..177e434 --- /dev/null +++ b/drivers/misc/altera_sysid.c @@ -0,0 +1,101 @@ +/* + * (C) Copyright 2004, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <command.h> +#include <dm.h> +#include <errno.h> +#include <misc.h> +#include <linux/time.h> +#include <asm/io.h> + +struct altera_sysid_regs { + u32 id; /* The system build id */ + u32 timestamp; /* Timestamp */ +}; + +struct altera_sysid_platdata { + struct altera_sysid_regs *regs; +}; + +void display_sysid(void) +{ + struct udevice *dev; + u32 sysid[2]; + struct tm t; + char asc[32]; + time_t stamp; + int ret; + + /* the first misc device will be used */ + ret = uclass_first_device(UCLASS_MISC, &dev); + if (ret) + return; + if (!dev) + return; + ret = misc_read(dev, 0, &sysid, sizeof(sysid)); + if (ret) + return; + + stamp = sysid[1]; + localtime_r(&stamp, &t); + asctime_r(&t, asc); + printf("SYSID: %08x, %s", sysid[0], asc); +} + +int do_sysid(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + display_sysid(); + return 0; +} + +U_BOOT_CMD( + sysid, 1, 1, do_sysid, + "display Nios-II system id", + "" +); + +static int altera_sysid_read(struct udevice *dev, + int offset, void *buf, int size) +{ + struct altera_sysid_platdata *plat = dev->platdata; + struct altera_sysid_regs *const regs = plat->regs; + u32 *sysid = buf; + + sysid[0] = readl(®s->id); + sysid[1] = readl(®s->timestamp); + + return 0; +} + +static int altera_sysid_ofdata_to_platdata(struct udevice *dev) +{ + struct altera_sysid_platdata *plat = dev_get_platdata(dev); + + plat->regs = ioremap(dev_get_addr(dev), + sizeof(struct altera_sysid_regs)); + + return 0; +} + +static const struct misc_ops altera_sysid_ops = { + .read = altera_sysid_read, +}; + +static const struct udevice_id altera_sysid_ids[] = { + { .compatible = "altr,sysid-1.0", }, + { } +}; + +U_BOOT_DRIVER(altera_sysid) = { + .name = "altera_sysid", + .id = UCLASS_MISC, + .of_match = altera_sysid_ids, + .ofdata_to_platdata = altera_sysid_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct altera_sysid_platdata), + .ops = &altera_sysid_ops, +}; diff --git a/include/configs/nios2-generic.h b/include/configs/nios2-generic.h index c65b3b3..e4b5abb 100644 --- a/include/configs/nios2-generic.h +++ b/include/configs/nios2-generic.h @@ -16,7 +16,7 @@ #define CONFIG_BOARD_NAME "nios2-generic" /* custom board name */ #define CONFIG_BOARD_EARLY_INIT_F /* enable early board-spec. init */ #define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_DISPLAY_BOARDINFO_LATE #define CONFIG_SYS_NIOS_SYSID_BASE CONFIG_SYS_SYSID_BASE
Applied to u-boot-nios.
Chin Liang See
Stefan Roese
Thomas Chou
