[U-Boot] [PATCH] mpc83xx: boot time regression, move LCRR setup back to cpu_init_f
Commit c7190f02 (retain POR values of non-configured ACR, SPCR, SCCR, and LCRR bitfields) moved the LCRR assignment to after relocation to RAM because of the potential problem with changing the local bus clock while executing from flash.
This change unfortunately adversely affects the boot time, as running all code up to cpu_init_r can cause significant slowdown.
E.G. on a 8347 board a bootup time increase of ~600ms has been observed:
0.020 CPU: e300c1, MPC8347_PBGA_EA, Rev: 3.0 at 400 MHz, CSB: 266.667 MHz 0.168 RS: 232 0.172 I2C: ready 0.176 DRAM: 64 MB 1.236 FLASH: 32 MB
Versus:
0.016 CPU: e300c1, MPC8347_PBGA_EA, Rev: 3.0 at 400 MHz, CSB: 266.667 MHz 0.092 RS: 232 0.092 I2C: ready 0.096 DRAM: 64 MB 0.644 FLASH: 32 MB
So far no boards have needed the late LCRR setup, so simply revert it for now - If it is needed at a later time, those boards can either do their own final LCRR setup in board code (E.G. in board_early_init_r), or we can introduce a CONFIG_SYS_LCRR_LATE config option to only do the setup in cpu_init_r.
Signed-off-by: Peter Korsgaard jacmet@sunsite.dk --- cpu/mpc83xx/cpu_init.c | 61 ++++++++++++++++++++++------------------------- 1 files changed, 29 insertions(+), 32 deletions(-)
diff --git a/cpu/mpc83xx/cpu_init.c b/cpu/mpc83xx/cpu_init.c index 031e8d5..0d6a5fe 100644 --- a/cpu/mpc83xx/cpu_init.c +++ b/cpu/mpc83xx/cpu_init.c @@ -171,6 +171,28 @@ void cpu_init_f (volatile immap_t * im) (CONFIG_SYS_SCCR_SATACM << SCCR_SATACM_SHIFT) | #endif 0; + __be32 lcrr_mask = +#ifdef CONFIG_SYS_LCRR_DBYP /* PLL bypass */ + LCRR_DBYP | +#endif +#ifdef CONFIG_SYS_LCRR_EADC /* external address delay */ + LCRR_EADC | +#endif +#ifdef CONFIG_SYS_LCRR_CLKDIV /* system clock divider */ + LCRR_CLKDIV | +#endif + 0; + __be32 lcrr_val = +#ifdef CONFIG_SYS_LCRR_DBYP /* PLL bypass */ + CONFIG_SYS_LCRR_DBYP | +#endif +#ifdef CONFIG_SYS_LCRR_EADC + CONFIG_SYS_LCRR_EADC | +#endif +#ifdef CONFIG_SYS_LCRR_CLKDIV /* system clock divider */ + CONFIG_SYS_LCRR_CLKDIV | +#endif + 0;
/* Pointer is writable since we allocated a register for it */ gd = (gd_t *) (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_GBL_DATA_OFFSET); @@ -199,6 +221,13 @@ void cpu_init_f (volatile immap_t * im) */ __raw_writel(RMR_CSRE & (1<<RMR_CSRE_SHIFT), &im->reset.rmr);
+ /* LCRR - Clock Ratio Register (10.3.1.16) + * write, read, and isync per MPC8379ERM rev.1 CLKDEV field description + */ + clrsetbits_be32(&im->lbus.lcrr, lcrr_mask, lcrr_val); + __raw_readl(&im->lbus.lcrr); + isync(); + /* Enable Time Base & Decrementer ( so we will have udelay() )*/ setbits_be32(&im->sysconf.spcr, SPCR_TBEN);
@@ -331,41 +360,9 @@ void cpu_init_f (volatile immap_t * im)
int cpu_init_r (void) { - volatile immap_t *im = (volatile immap_t *)CONFIG_SYS_IMMR; #ifdef CONFIG_QE uint qe_base = CONFIG_SYS_IMMR + 0x00100000; /* QE immr base */ -#endif - __be32 lcrr_mask = -#ifdef CONFIG_SYS_LCRR_DBYP /* PLL bypass */ - LCRR_DBYP | -#endif -#ifdef CONFIG_SYS_LCRR_EADC /* external address delay */ - LCRR_EADC | -#endif -#ifdef CONFIG_SYS_LCRR_CLKDIV /* system clock divider */ - LCRR_CLKDIV | -#endif - 0; - __be32 lcrr_val = -#ifdef CONFIG_SYS_LCRR_DBYP /* PLL bypass */ - CONFIG_SYS_LCRR_DBYP | -#endif -#ifdef CONFIG_SYS_LCRR_EADC - CONFIG_SYS_LCRR_EADC | -#endif -#ifdef CONFIG_SYS_LCRR_CLKDIV /* system clock divider */ - CONFIG_SYS_LCRR_CLKDIV | -#endif - 0;
- /* LCRR - Clock Ratio Register (10.3.1.16) - * write, read, and isync per MPC8379ERM rev.1 CLKDEV field description - */ - clrsetbits_be32(&im->lbus.lcrr, lcrr_mask, lcrr_val); - __raw_readl(&im->lbus.lcrr); - isync(); - -#ifdef CONFIG_QE qe_init(qe_base); qe_reset(); #endif
Versus:
tested ok; applied to u-boot-mpc83xx master.
Thanks Peter!
Kim
Kim Phillips
Peter Korsgaard
