[U-Boot] [PATCH 0/26] Start removing non-generic boards
As doc/README.generic-board says, the dead line has already expired and we are supposed to remove all the non-generic boards by the end of this year.
This series removes non-generic boards of mpc8xx, mpc8260, mpc824x platform.
Masahiro Yamada (26): mpc8xx: remove FPS{850,860}L, NSCU, SM850, TK885D, virtlab2 support powerpc: manroland: remove uc100, uc101, mucmc52, hmi1001 support mpc8xx: remove ELPT860 board support mpc8xx: remove KUP4X, KUP4K board support mpc8xx: remove SPD823TS board support mpc8xx: remove RRvision board support mpc8xx: remove R360MPI board support mpc8xx: remove NETVIA board support mpc8xx: remove lwmon board support mpc8xx: remove IVMS8, IVML24 board support mpc8xx: remove IP860 board support mpc8xx: remove ESTEEM192E board support powerpc: remove cogent_8xx, cogent_mpc8260 board support mpc8260: remove sacsng board support mpc8260: remove ppmc8260 board support mpc8260: remove ep8260 board support mpc8260: remove VoVPN-GW board support mpc8260: remove MPC8266ADS board support mpc8260: remove PM825, PM826, PM828 board support mpc8260: remove muas3001 board support mpc8260: remove IPHASE4539 board support mpc8260: remove gw8260 board support mpc8260: remove ep82xxm board support mpc8260: remove CPU86, CPU87 board support mpc8260: remove atc board support powerpc: mpc824x: remove MPC824X cpu support
MAKEALL | 6 - README | 5 - arch/powerpc/Kconfig | 4 - arch/powerpc/cpu/mpc5xxx/Kconfig | 12 - arch/powerpc/cpu/mpc5xxx/ide.c | 8 - arch/powerpc/cpu/mpc824x/Kconfig | 48 - arch/powerpc/cpu/mpc824x/Makefile | 11 - arch/powerpc/cpu/mpc824x/config.mk | 8 - arch/powerpc/cpu/mpc824x/cpu.c | 262 ----- arch/powerpc/cpu/mpc824x/cpu_init.c | 311 ------ arch/powerpc/cpu/mpc824x/drivers/epic.h | 1 - arch/powerpc/cpu/mpc824x/drivers/epic/README | 102 -- arch/powerpc/cpu/mpc824x/drivers/epic/epic.h | 163 ---- arch/powerpc/cpu/mpc824x/drivers/epic/epic1.c | 517 ---------- arch/powerpc/cpu/mpc824x/drivers/epic/epic2.S | 196 ---- arch/powerpc/cpu/mpc824x/drivers/epic/epicutil.S | 57 -- arch/powerpc/cpu/mpc824x/drivers/errors.h | 212 ---- arch/powerpc/cpu/mpc824x/drivers/i2c/i2c.c | 254 ----- arch/powerpc/cpu/mpc824x/interrupts.c | 77 -- arch/powerpc/cpu/mpc824x/pci.c | 75 -- arch/powerpc/cpu/mpc824x/speed.c | 102 -- arch/powerpc/cpu/mpc824x/start.S | 724 -------------- arch/powerpc/cpu/mpc824x/traps.c | 194 ---- arch/powerpc/cpu/mpc824x/u-boot.lds | 76 -- arch/powerpc/cpu/mpc8260/Kconfig | 60 -- arch/powerpc/cpu/mpc8260/cpu_init.c | 4 - arch/powerpc/cpu/mpc8260/pci.c | 64 -- arch/powerpc/cpu/mpc8260/start.S | 61 -- arch/powerpc/cpu/mpc8xx/Kconfig | 73 -- arch/powerpc/cpu/mpc8xx/cpu.c | 57 +- arch/powerpc/cpu/mpc8xx/cpu_init.c | 15 - arch/powerpc/cpu/mpc8xx/i2c.c | 7 - arch/powerpc/cpu/mpc8xx/scc.c | 24 - arch/powerpc/cpu/mpc8xx/serial.c | 23 +- arch/powerpc/cpu/mpc8xx/video.c | 148 --- arch/powerpc/include/asm/global_data.h | 2 +- arch/powerpc/include/asm/processor.h | 2 - board/LEOX/elpt860/Kconfig | 12 - board/LEOX/elpt860/MAINTAINERS | 6 - board/LEOX/elpt860/Makefile | 21 - board/LEOX/elpt860/README.LEOX | 423 -------- board/LEOX/elpt860/elpt860.c | 336 ------- board/LEOX/elpt860/flash.c | 602 ------------ board/LEOX/elpt860/u-boot.lds | 103 -- board/LEOX/elpt860/u-boot.lds.debug | 126 --- board/RRvision/Kconfig | 9 - board/RRvision/MAINTAINERS | 7 - board/RRvision/Makefile | 8 - board/RRvision/RRvision.c | 222 ----- board/RRvision/flash.c | 506 ---------- board/RRvision/u-boot.lds | 87 -- board/RRvision/video_ad7179.h | 52 - board/a3000/Kconfig | 9 - board/a3000/MAINTAINERS | 6 - board/a3000/Makefile | 8 - board/a3000/README | 17 - board/a3000/a3000.c | 101 -- board/a3000/flash.c | 438 --------- board/atc/Kconfig | 9 - board/atc/MAINTAINERS | 6 - board/atc/Makefile | 8 - board/atc/atc.c | 382 -------- board/atc/flash.c | 647 ------------- board/atc/ti113x.c | 620 ------------ board/cogent/Kconfig | 19 - board/cogent/MAINTAINERS | 8 - board/cogent/Makefile | 8 - board/cogent/README | 118 --- board/cogent/README.cma286 | 69 -- board/cogent/dipsw.c | 50 - board/cogent/dipsw.h | 3 - board/cogent/flash.c | 633 ------------ board/cogent/flash.h | 305 ------ board/cogent/kbm.c | 3 - board/cogent/lcd.c | 245 ----- board/cogent/lcd.h | 84 -- board/cogent/mb.c | 280 ------ board/cogent/mb.h | 513 ---------- board/cogent/par.c | 3 - board/cogent/par.h | 3 - board/cogent/pci.c | 3 - board/cogent/pci.h | 3 - board/cogent/rtc.c | 3 - board/cogent/rtc.h | 3 - board/cogent/serial.c | 189 ---- board/cogent/serial.h | 15 - board/cogent/u-boot.lds | 86 -- board/cogent/u-boot.lds.debug | 121 --- board/cpc45/Kconfig | 9 - board/cpc45/MAINTAINERS | 7 - board/cpc45/Makefile | 8 - board/cpc45/cpc45.c | 250 ----- board/cpc45/flash.c | 506 ---------- board/cpc45/ide.c | 128 --- board/cpc45/pd67290.c | 797 --------------- board/cpc45/plx9030.c | 156 --- board/cpu86/Kconfig | 9 - board/cpu86/MAINTAINERS | 7 - board/cpu86/Makefile | 8 - board/cpu86/cpu86.c | 304 ------ board/cpu86/cpu86.h | 27 - board/cpu86/flash.c | 599 ------------ board/cpu87/Kconfig | 9 - board/cpu87/MAINTAINERS | 7 - board/cpu87/Makefile | 8 - board/cpu87/cpu87.c | 330 ------- board/cpu87/cpu87.h | 27 - board/cpu87/flash.c | 608 ------------ board/cu824/Kconfig | 9 - board/cu824/MAINTAINERS | 6 - board/cu824/Makefile | 8 - board/cu824/README | 453 --------- board/cu824/cu824.c | 83 -- board/cu824/flash.c | 470 --------- board/eXalion/Kconfig | 9 - board/eXalion/MAINTAINERS | 6 - board/eXalion/Makefile | 8 - board/eXalion/eXalion.c | 283 ------ board/eXalion/eXalion.h | 36 - board/eXalion/piix_pci.h | 156 --- board/ep8260/Kconfig | 9 - board/ep8260/MAINTAINERS | 6 - board/ep8260/Makefile | 8 - board/ep8260/ep8260.c | 304 ------ board/ep8260/ep8260.h | 24 - board/ep8260/flash.c | 395 -------- board/ep8260/mii_phy.c | 107 --- board/ep82xxm/Kconfig | 9 - board/ep82xxm/MAINTAINERS | 6 - board/ep82xxm/Makefile | 8 - board/ep82xxm/ep82xxm.c | 274 ------ board/esteem192e/Kconfig | 9 - board/esteem192e/MAINTAINERS | 6 - board/esteem192e/Makefile | 8 - board/esteem192e/esteem192e.c | 225 ----- board/esteem192e/flash.c | 1119 ---------------------- board/esteem192e/u-boot.lds | 90 -- board/freescale/mpc8266ads/Kconfig | 12 - board/freescale/mpc8266ads/MAINTAINERS | 6 - board/freescale/mpc8266ads/Makefile | 8 - board/freescale/mpc8266ads/flash.c | 493 ---------- board/freescale/mpc8266ads/mpc8266ads.c | 582 ----------- board/funkwerk/vovpn-gw/Kconfig | 12 - board/funkwerk/vovpn-gw/MAINTAINERS | 6 - board/funkwerk/vovpn-gw/Makefile | 8 - board/funkwerk/vovpn-gw/flash.c | 436 --------- board/funkwerk/vovpn-gw/m88e6060.c | 249 ----- board/funkwerk/vovpn-gw/m88e6060.h | 75 -- board/funkwerk/vovpn-gw/vovpn-gw.c | 363 ------- board/gw8260/Kconfig | 9 - board/gw8260/MAINTAINERS | 6 - board/gw8260/Makefile | 8 - board/gw8260/flash.c | 502 ---------- board/gw8260/gw8260.c | 639 ------------ board/ip860/Kconfig | 9 - board/ip860/MAINTAINERS | 6 - board/ip860/Makefile | 8 - board/ip860/flash.c | 440 --------- board/ip860/ip860.c | 340 ------- board/ip860/u-boot.lds.debug | 122 --- board/iphase4539/Kconfig | 9 - board/iphase4539/MAINTAINERS | 6 - board/iphase4539/Makefile | 10 - board/iphase4539/README | 358 ------- board/iphase4539/flash.c | 474 --------- board/iphase4539/iphase4539.c | 408 -------- board/ivm/Kconfig | 19 - board/ivm/MAINTAINERS | 12 - board/ivm/Makefile | 8 - board/ivm/flash.c | 582 ----------- board/ivm/ivm.c | 382 -------- board/ivm/u-boot.lds.debug | 122 --- board/kup/common/flash.c | 499 ---------- board/kup/common/kup.c | 68 -- board/kup/common/kup.h | 40 - board/kup/common/load_sernum_ethaddr.c | 78 -- board/kup/common/pcmcia.c | 221 ----- board/kup/kup4k/Kconfig | 12 - board/kup/kup4k/MAINTAINERS | 6 - board/kup/kup4k/Makefile | 8 - board/kup/kup4k/kup4k.c | 289 ------ board/kup/kup4k/u-boot.lds.debug | 121 --- board/kup/kup4x/Kconfig | 12 - board/kup/kup4x/MAINTAINERS | 6 - board/kup/kup4x/Makefile | 8 - board/kup/kup4x/kup4x.c | 185 ---- board/kup/kup4x/u-boot.lds | 82 -- board/kup/kup4x/u-boot.lds.debug | 121 --- board/lwmon/Kconfig | 9 - board/lwmon/MAINTAINERS | 6 - board/lwmon/Makefile | 8 - board/lwmon/README.keybd | 126 --- board/lwmon/flash.c | 632 ------------ board/lwmon/lwmon.c | 1071 --------------------- board/lwmon/pcmcia.c | 234 ----- board/lwmon/u-boot.lds.debug | 122 --- board/manroland/hmi1001/Kconfig | 12 - board/manroland/hmi1001/MAINTAINERS | 6 - board/manroland/hmi1001/Makefile | 8 - board/manroland/hmi1001/hmi1001.c | 301 ------ board/manroland/mucmc52/Kconfig | 12 - board/manroland/mucmc52/MAINTAINERS | 6 - board/manroland/mucmc52/Makefile | 11 - board/manroland/mucmc52/mucmc52.c | 394 -------- board/manroland/uc100/Kconfig | 12 - board/manroland/uc100/MAINTAINERS | 6 - board/manroland/uc100/Makefile | 8 - board/manroland/uc100/pcmcia.c | 192 ---- board/manroland/uc100/uc100.c | 254 ----- board/manroland/uc101/Kconfig | 12 - board/manroland/uc101/MAINTAINERS | 6 - board/manroland/uc101/Makefile | 8 - board/manroland/uc101/uc101.c | 367 ------- board/muas3001/Kconfig | 9 - board/muas3001/MAINTAINERS | 7 - board/muas3001/Makefile | 8 - board/muas3001/muas3001.c | 335 ------- board/musenki/Kconfig | 9 - board/musenki/MAINTAINERS | 6 - board/musenki/Makefile | 8 - board/musenki/README | 298 ------ board/musenki/flash.c | 496 ---------- board/musenki/musenki.c | 94 -- board/mvblue/Kconfig | 9 - board/mvblue/MAINTAINERS | 6 - board/mvblue/Makefile | 8 - board/mvblue/flash.c | 570 ----------- board/mvblue/mvblue.c | 253 ----- board/mvblue/u-boot.lds | 86 -- board/netvia/Kconfig | 9 - board/netvia/MAINTAINERS | 7 - board/netvia/Makefile | 8 - board/netvia/flash.c | 495 ---------- board/netvia/netvia.c | 401 -------- board/netvia/u-boot.lds.debug | 121 --- board/pm826/Kconfig | 9 - board/pm826/MAINTAINERS | 13 - board/pm826/Makefile | 8 - board/pm826/flash.c | 370 ------- board/pm826/pm826.c | 319 ------ board/pm828/Kconfig | 9 - board/pm828/MAINTAINERS | 9 - board/pm828/Makefile | 8 - board/pm828/flash.c | 370 ------- board/pm828/pm828.c | 352 ------- board/ppmc8260/Kconfig | 9 - board/ppmc8260/MAINTAINERS | 6 - board/ppmc8260/Makefile | 8 - board/ppmc8260/ppmc8260.c | 291 ------ board/r360mpi/Kconfig | 9 - board/r360mpi/MAINTAINERS | 6 - board/r360mpi/Makefile | 8 - board/r360mpi/flash.c | 468 --------- board/r360mpi/pcmcia.c | 232 ----- board/r360mpi/r360mpi.c | 403 -------- board/r360mpi/u-boot.lds | 89 -- board/sacsng/Kconfig | 9 - board/sacsng/MAINTAINERS | 6 - board/sacsng/Makefile | 8 - board/sacsng/clkinit.c | 1009 ------------------- board/sacsng/clkinit.h | 103 -- board/sacsng/flash.c | 507 ---------- board/sacsng/ioconfig.h | 217 ----- board/sacsng/sacsng.c | 848 ---------------- board/sandpoint/Kconfig | 19 - board/sandpoint/MAINTAINERS | 12 - board/sandpoint/Makefile | 8 - board/sandpoint/README | 411 -------- board/sandpoint/dinkdl | 2 - board/sandpoint/flash.c | 748 --------------- board/sandpoint/sandpoint.c | 91 -- board/sandpoint/u-boot.lds | 84 -- board/spd8xx/Kconfig | 9 - board/spd8xx/MAINTAINERS | 6 - board/spd8xx/Makefile | 8 - board/spd8xx/flash.c | 41 - board/spd8xx/spd8xx.c | 278 ------ board/spd8xx/u-boot.lds | 91 -- board/spd8xx/u-boot.lds.debug | 122 --- board/tqc/tqm8xx/Kconfig | 78 -- board/tqc/tqm8xx/MAINTAINERS | 16 - board/tqc/tqm8xx/tqm8xx.c | 58 +- board/utx8245/Kconfig | 9 - board/utx8245/MAINTAINERS | 6 - board/utx8245/Makefile | 13 - board/utx8245/flash.c | 544 ----------- board/utx8245/utx8245.c | 119 --- common/cmd_pcmcia.c | 3 - common/flash.c | 6 - configs/A3000_defconfig | 3 - configs/CPC45_ROMBOOT_defconfig | 4 - configs/CPC45_defconfig | 3 - configs/CPU86_ROMBOOT_defconfig | 4 - configs/CPU86_defconfig | 3 - configs/CPU87_ROMBOOT_defconfig | 4 - configs/CPU87_defconfig | 3 - configs/CU824_defconfig | 3 - configs/ELPT860_defconfig | 3 - configs/ESTEEM192E_defconfig | 3 - configs/FPS850L_defconfig | 3 - configs/FPS860L_defconfig | 3 - configs/IP860_defconfig | 3 - configs/IPHASE4539_defconfig | 3 - configs/IVML24_128_defconfig | 4 - configs/IVML24_256_defconfig | 4 - configs/IVML24_defconfig | 4 - configs/IVMS8_128_defconfig | 4 - configs/IVMS8_256_defconfig | 4 - configs/IVMS8_defconfig | 4 - configs/KUP4K_defconfig | 3 - configs/KUP4X_defconfig | 3 - configs/MPC8266ADS_defconfig | 3 - configs/MUSENKI_defconfig | 3 - configs/MVBLUE_defconfig | 3 - configs/NETVIA_V2_defconfig | 4 - configs/NETVIA_defconfig | 4 - configs/NSCU_defconfig | 3 - configs/PM825_BIGFLASH_defconfig | 4 - configs/PM825_ROMBOOT_BIGFLASH_defconfig | 4 - configs/PM825_ROMBOOT_defconfig | 4 - configs/PM825_defconfig | 4 - configs/PM826_BIGFLASH_defconfig | 4 - configs/PM826_ROMBOOT_BIGFLASH_defconfig | 4 - configs/PM826_ROMBOOT_defconfig | 4 - configs/PM826_defconfig | 4 - configs/PM828_PCI_defconfig | 4 - configs/PM828_ROMBOOT_PCI_defconfig | 4 - configs/PM828_ROMBOOT_defconfig | 4 - configs/PM828_defconfig | 3 - configs/R360MPI_defconfig | 3 - configs/RRvision_LCD_defconfig | 4 - configs/RRvision_defconfig | 3 - configs/SM850_defconfig | 3 - configs/SPD823TS_defconfig | 3 - configs/Sandpoint8240_defconfig | 3 - configs/Sandpoint8245_defconfig | 3 - configs/TK885D_defconfig | 3 - configs/VoVPN-GW_66MHz_defconfig | 4 - configs/atc_defconfig | 3 - configs/cogent_mpc8260_defconfig | 3 - configs/cogent_mpc8xx_defconfig | 3 - configs/eXalion_defconfig | 3 - configs/ep8260_defconfig | 3 - configs/ep82xxm_defconfig | 3 - configs/gw8260_defconfig | 3 - configs/hmi1001_defconfig | 3 - configs/lwmon_defconfig | 3 - configs/muas3001_defconfig | 3 - configs/muas3001_dev_defconfig | 4 - configs/mucmc52_defconfig | 3 - configs/ppmc8260_defconfig | 3 - configs/sacsng_defconfig | 3 - configs/uc100_defconfig | 3 - configs/uc101_defconfig | 3 - configs/utx8245_defconfig | 3 - configs/virtlab2_defconfig | 3 - doc/README.scrapyard | 50 +- drivers/net/mpc5xxx_fec.c | 5 - drivers/pcmcia/Makefile | 1 - drivers/pcmcia/i82365.c | 989 ------------------- drivers/pcmcia/mpc8xx_pcmcia.c | 6 - drivers/pcmcia/tqm8xx_pcmcia.c | 51 +- drivers/rtc/Makefile | 1 - drivers/rtc/ds12887.c | 217 ----- drivers/video/mpc8xx_lcd.c | 53 - drivers/video/smiLynxEM.c | 3 - examples/standalone/test_burst.c | 19 - include/common.h | 4 - include/commproc.h | 293 +----- include/configs/A3000.h | 293 ------ include/configs/CPC45.h | 489 ---------- include/configs/CPU86.h | 629 ------------ include/configs/CPU87.h | 676 ------------- include/configs/CU824.h | 286 ------ include/configs/ELPT860.h | 374 -------- include/configs/ESTEEM192E.h | 292 ------ include/configs/FPS850L.h | 413 -------- include/configs/FPS860L.h | 415 -------- include/configs/IP860.h | 438 --------- include/configs/IPHASE4539.h | 328 ------- include/configs/IVML24.h | 458 --------- include/configs/IVMS8.h | 441 --------- include/configs/KUP4K.h | 488 ---------- include/configs/KUP4X.h | 440 --------- include/configs/MPC8266ADS.h | 563 ----------- include/configs/MUSENKI.h | 275 ------ include/configs/MVBLUE.h | 325 ------- include/configs/NETVIA.h | 435 --------- include/configs/NSCU.h | 463 --------- include/configs/PM826.h | 534 ----------- include/configs/PM828.h | 528 ---------- include/configs/R360MPI.h | 464 --------- include/configs/RRvision.h | 450 --------- include/configs/SM850.h | 351 ------- include/configs/SPD823TS.h | 402 -------- include/configs/Sandpoint8240.h | 398 -------- include/configs/Sandpoint8245.h | 376 -------- include/configs/TK885D.h | 490 ---------- include/configs/VoVPN-GW.h | 399 -------- include/configs/atc.h | 489 ---------- include/configs/cogent_common.h | 192 ---- include/configs/cogent_mpc8260.h | 392 -------- include/configs/cogent_mpc8xx.h | 349 ------- include/configs/eXalion.h | 433 --------- include/configs/ep8260.h | 744 -------------- include/configs/ep82xxm.h | 383 -------- include/configs/gw8260.h | 800 ---------------- include/configs/hmi1001.h | 339 ------- include/configs/lwmon.h | 587 ------------ include/configs/muas3001.h | 391 -------- include/configs/mucmc52.h | 126 --- include/configs/ppmc8260.h | 986 ------------------- include/configs/sacsng.h | 1038 -------------------- include/configs/uc100.h | 482 ---------- include/configs/uc101.h | 103 -- include/configs/utx8245.h | 408 -------- include/configs/virtlab2.h | 469 --------- include/mpc824x.h | 523 ---------- include/pci.h | 4 - include/pcmcia.h | 12 - include/pcmcia/cirrus.h | 180 ---- include/pcmcia/i82365.h | 154 --- include/pcmcia/ss.h | 133 --- include/pcmcia/ti113x.h | 234 ----- include/ppc_asm.tmpl | 4 +- include/status_led.h | 97 -- include/video_ad7176.h | 89 -- include/video_ad7177.h | 133 --- include/video_ad7179.h | 20 - post/drivers/memory.c | 2 +- 430 files changed, 59 insertions(+), 68545 deletions(-) delete mode 100644 arch/powerpc/cpu/mpc824x/Kconfig delete mode 100644 arch/powerpc/cpu/mpc824x/Makefile delete mode 100644 arch/powerpc/cpu/mpc824x/config.mk delete mode 100644 arch/powerpc/cpu/mpc824x/cpu.c delete mode 100644 arch/powerpc/cpu/mpc824x/cpu_init.c delete mode 100644 arch/powerpc/cpu/mpc824x/drivers/epic.h delete mode 100644 arch/powerpc/cpu/mpc824x/drivers/epic/README delete mode 100644 arch/powerpc/cpu/mpc824x/drivers/epic/epic.h delete mode 100644 arch/powerpc/cpu/mpc824x/drivers/epic/epic1.c delete mode 100644 arch/powerpc/cpu/mpc824x/drivers/epic/epic2.S delete mode 100644 arch/powerpc/cpu/mpc824x/drivers/epic/epicutil.S delete mode 100644 arch/powerpc/cpu/mpc824x/drivers/errors.h delete mode 100644 arch/powerpc/cpu/mpc824x/drivers/i2c/i2c.c delete mode 100644 arch/powerpc/cpu/mpc824x/interrupts.c delete mode 100644 arch/powerpc/cpu/mpc824x/pci.c delete mode 100644 arch/powerpc/cpu/mpc824x/speed.c delete mode 100644 arch/powerpc/cpu/mpc824x/start.S delete mode 100644 arch/powerpc/cpu/mpc824x/traps.c delete mode 100644 arch/powerpc/cpu/mpc824x/u-boot.lds delete mode 100644 board/LEOX/elpt860/Kconfig delete mode 100644 board/LEOX/elpt860/MAINTAINERS delete mode 100644 board/LEOX/elpt860/Makefile delete mode 100644 board/LEOX/elpt860/README.LEOX delete mode 100644 board/LEOX/elpt860/elpt860.c delete mode 100644 board/LEOX/elpt860/flash.c delete mode 100644 board/LEOX/elpt860/u-boot.lds delete mode 100644 board/LEOX/elpt860/u-boot.lds.debug delete mode 100644 board/RRvision/Kconfig delete mode 100644 board/RRvision/MAINTAINERS delete mode 100644 board/RRvision/Makefile delete mode 100644 board/RRvision/RRvision.c delete mode 100644 board/RRvision/flash.c delete mode 100644 board/RRvision/u-boot.lds delete mode 100644 board/RRvision/video_ad7179.h delete mode 100644 board/a3000/Kconfig delete mode 100644 board/a3000/MAINTAINERS delete mode 100644 board/a3000/Makefile delete mode 100644 board/a3000/README delete mode 100644 board/a3000/a3000.c delete mode 100644 board/a3000/flash.c delete mode 100644 board/atc/Kconfig delete mode 100644 board/atc/MAINTAINERS delete mode 100644 board/atc/Makefile delete mode 100644 board/atc/atc.c delete mode 100644 board/atc/flash.c delete mode 100644 board/atc/ti113x.c delete mode 100644 board/cogent/Kconfig delete mode 100644 board/cogent/MAINTAINERS delete mode 100644 board/cogent/Makefile delete mode 100644 board/cogent/README delete mode 100644 board/cogent/README.cma286 delete mode 100644 board/cogent/dipsw.c delete mode 100644 board/cogent/dipsw.h delete mode 100644 board/cogent/flash.c delete mode 100644 board/cogent/flash.h delete mode 100644 board/cogent/kbm.c delete mode 100644 board/cogent/lcd.c delete mode 100644 board/cogent/lcd.h delete mode 100644 board/cogent/mb.c delete mode 100644 board/cogent/mb.h delete mode 100644 board/cogent/par.c delete mode 100644 board/cogent/par.h delete mode 100644 board/cogent/pci.c delete mode 100644 board/cogent/pci.h delete mode 100644 board/cogent/rtc.c delete mode 100644 board/cogent/rtc.h delete mode 100644 board/cogent/serial.c delete mode 100644 board/cogent/serial.h delete mode 100644 board/cogent/u-boot.lds delete mode 100644 board/cogent/u-boot.lds.debug delete mode 100644 board/cpc45/Kconfig delete mode 100644 board/cpc45/MAINTAINERS delete mode 100644 board/cpc45/Makefile delete mode 100644 board/cpc45/cpc45.c delete mode 100644 board/cpc45/flash.c delete mode 100644 board/cpc45/ide.c delete mode 100644 board/cpc45/pd67290.c delete mode 100644 board/cpc45/plx9030.c delete mode 100644 board/cpu86/Kconfig delete mode 100644 board/cpu86/MAINTAINERS delete mode 100644 board/cpu86/Makefile delete mode 100644 board/cpu86/cpu86.c delete mode 100644 board/cpu86/cpu86.h delete mode 100644 board/cpu86/flash.c delete mode 100644 board/cpu87/Kconfig delete mode 100644 board/cpu87/MAINTAINERS delete mode 100644 board/cpu87/Makefile delete mode 100644 board/cpu87/cpu87.c delete mode 100644 board/cpu87/cpu87.h delete mode 100644 board/cpu87/flash.c delete mode 100644 board/cu824/Kconfig delete mode 100644 board/cu824/MAINTAINERS delete mode 100644 board/cu824/Makefile delete mode 100644 board/cu824/README delete mode 100644 board/cu824/cu824.c delete mode 100644 board/cu824/flash.c delete mode 100644 board/eXalion/Kconfig delete mode 100644 board/eXalion/MAINTAINERS delete mode 100644 board/eXalion/Makefile delete mode 100644 board/eXalion/eXalion.c delete mode 100644 board/eXalion/eXalion.h delete mode 100644 board/eXalion/piix_pci.h delete mode 100644 board/ep8260/Kconfig delete mode 100644 board/ep8260/MAINTAINERS delete mode 100644 board/ep8260/Makefile delete mode 100644 board/ep8260/ep8260.c delete mode 100644 board/ep8260/ep8260.h delete mode 100644 board/ep8260/flash.c delete mode 100644 board/ep8260/mii_phy.c delete mode 100644 board/ep82xxm/Kconfig delete mode 100644 board/ep82xxm/MAINTAINERS delete mode 100644 board/ep82xxm/Makefile delete mode 100644 board/ep82xxm/ep82xxm.c delete mode 100644 board/esteem192e/Kconfig delete mode 100644 board/esteem192e/MAINTAINERS delete mode 100644 board/esteem192e/Makefile delete mode 100644 board/esteem192e/esteem192e.c delete mode 100644 board/esteem192e/flash.c delete mode 100644 board/esteem192e/u-boot.lds delete mode 100644 board/freescale/mpc8266ads/Kconfig delete mode 100644 board/freescale/mpc8266ads/MAINTAINERS delete mode 100644 board/freescale/mpc8266ads/Makefile delete mode 100644 board/freescale/mpc8266ads/flash.c delete mode 100644 board/freescale/mpc8266ads/mpc8266ads.c delete mode 100644 board/funkwerk/vovpn-gw/Kconfig delete mode 100644 board/funkwerk/vovpn-gw/MAINTAINERS delete mode 100644 board/funkwerk/vovpn-gw/Makefile delete mode 100644 board/funkwerk/vovpn-gw/flash.c delete mode 100644 board/funkwerk/vovpn-gw/m88e6060.c delete mode 100644 board/funkwerk/vovpn-gw/m88e6060.h delete mode 100644 board/funkwerk/vovpn-gw/vovpn-gw.c delete mode 100644 board/gw8260/Kconfig delete mode 100644 board/gw8260/MAINTAINERS delete mode 100644 board/gw8260/Makefile delete mode 100644 board/gw8260/flash.c delete mode 100644 board/gw8260/gw8260.c delete mode 100644 board/ip860/Kconfig delete mode 100644 board/ip860/MAINTAINERS delete mode 100644 board/ip860/Makefile delete mode 100644 board/ip860/flash.c delete mode 100644 board/ip860/ip860.c delete mode 100644 board/ip860/u-boot.lds.debug delete mode 100644 board/iphase4539/Kconfig delete mode 100644 board/iphase4539/MAINTAINERS delete mode 100644 board/iphase4539/Makefile delete mode 100644 board/iphase4539/README delete mode 100644 board/iphase4539/flash.c delete mode 100644 board/iphase4539/iphase4539.c delete mode 100644 board/ivm/Kconfig delete mode 100644 board/ivm/MAINTAINERS delete mode 100644 board/ivm/Makefile delete mode 100644 board/ivm/flash.c delete mode 100644 board/ivm/ivm.c delete mode 100644 board/ivm/u-boot.lds.debug delete mode 100644 board/kup/common/flash.c delete mode 100644 board/kup/common/kup.c delete mode 100644 board/kup/common/kup.h delete mode 100644 board/kup/common/load_sernum_ethaddr.c delete mode 100644 board/kup/common/pcmcia.c delete mode 100644 board/kup/kup4k/Kconfig delete mode 100644 board/kup/kup4k/MAINTAINERS delete mode 100644 board/kup/kup4k/Makefile delete mode 100644 board/kup/kup4k/kup4k.c delete mode 100644 board/kup/kup4k/u-boot.lds.debug delete mode 100644 board/kup/kup4x/Kconfig delete mode 100644 board/kup/kup4x/MAINTAINERS delete mode 100644 board/kup/kup4x/Makefile delete mode 100644 board/kup/kup4x/kup4x.c delete mode 100644 board/kup/kup4x/u-boot.lds delete mode 100644 board/kup/kup4x/u-boot.lds.debug delete mode 100644 board/lwmon/Kconfig delete mode 100644 board/lwmon/MAINTAINERS delete mode 100644 board/lwmon/Makefile delete mode 100644 board/lwmon/README.keybd delete mode 100644 board/lwmon/flash.c delete mode 100644 board/lwmon/lwmon.c delete mode 100644 board/lwmon/pcmcia.c delete mode 100644 board/lwmon/u-boot.lds.debug delete mode 100644 board/manroland/hmi1001/Kconfig delete mode 100644 board/manroland/hmi1001/MAINTAINERS delete mode 100644 board/manroland/hmi1001/Makefile delete mode 100644 board/manroland/hmi1001/hmi1001.c delete mode 100644 board/manroland/mucmc52/Kconfig delete mode 100644 board/manroland/mucmc52/MAINTAINERS delete mode 100644 board/manroland/mucmc52/Makefile delete mode 100644 board/manroland/mucmc52/mucmc52.c delete mode 100644 board/manroland/uc100/Kconfig delete mode 100644 board/manroland/uc100/MAINTAINERS delete mode 100644 board/manroland/uc100/Makefile delete mode 100644 board/manroland/uc100/pcmcia.c delete mode 100644 board/manroland/uc100/uc100.c delete mode 100644 board/manroland/uc101/Kconfig delete mode 100644 board/manroland/uc101/MAINTAINERS delete mode 100644 board/manroland/uc101/Makefile delete mode 100644 board/manroland/uc101/uc101.c delete mode 100644 board/muas3001/Kconfig delete mode 100644 board/muas3001/MAINTAINERS delete mode 100644 board/muas3001/Makefile delete mode 100644 board/muas3001/muas3001.c delete mode 100644 board/musenki/Kconfig delete mode 100644 board/musenki/MAINTAINERS delete mode 100644 board/musenki/Makefile delete mode 100644 board/musenki/README delete mode 100644 board/musenki/flash.c delete mode 100644 board/musenki/musenki.c delete mode 100644 board/mvblue/Kconfig delete mode 100644 board/mvblue/MAINTAINERS delete mode 100644 board/mvblue/Makefile delete mode 100644 board/mvblue/flash.c delete mode 100644 board/mvblue/mvblue.c delete mode 100644 board/mvblue/u-boot.lds delete mode 100644 board/netvia/Kconfig delete mode 100644 board/netvia/MAINTAINERS delete mode 100644 board/netvia/Makefile delete mode 100644 board/netvia/flash.c delete mode 100644 board/netvia/netvia.c delete mode 100644 board/netvia/u-boot.lds.debug delete mode 100644 board/pm826/Kconfig delete mode 100644 board/pm826/MAINTAINERS delete mode 100644 board/pm826/Makefile delete mode 100644 board/pm826/flash.c delete mode 100644 board/pm826/pm826.c delete mode 100644 board/pm828/Kconfig delete mode 100644 board/pm828/MAINTAINERS delete mode 100644 board/pm828/Makefile delete mode 100644 board/pm828/flash.c delete mode 100644 board/pm828/pm828.c delete mode 100644 board/ppmc8260/Kconfig delete mode 100644 board/ppmc8260/MAINTAINERS delete mode 100644 board/ppmc8260/Makefile delete mode 100644 board/ppmc8260/ppmc8260.c delete mode 100644 board/r360mpi/Kconfig delete mode 100644 board/r360mpi/MAINTAINERS delete mode 100644 board/r360mpi/Makefile delete mode 100644 board/r360mpi/flash.c delete mode 100644 board/r360mpi/pcmcia.c delete mode 100644 board/r360mpi/r360mpi.c delete mode 100644 board/r360mpi/u-boot.lds delete mode 100644 board/sacsng/Kconfig delete mode 100644 board/sacsng/MAINTAINERS delete mode 100644 board/sacsng/Makefile delete mode 100644 board/sacsng/clkinit.c delete mode 100644 board/sacsng/clkinit.h delete mode 100644 board/sacsng/flash.c delete mode 100644 board/sacsng/ioconfig.h delete mode 100644 board/sacsng/sacsng.c delete mode 100644 board/sandpoint/Kconfig delete mode 100644 board/sandpoint/MAINTAINERS delete mode 100644 board/sandpoint/Makefile delete mode 100644 board/sandpoint/README delete mode 100644 board/sandpoint/dinkdl delete mode 100644 board/sandpoint/flash.c delete mode 100644 board/sandpoint/sandpoint.c delete mode 100644 board/sandpoint/u-boot.lds delete mode 100644 board/spd8xx/Kconfig delete mode 100644 board/spd8xx/MAINTAINERS delete mode 100644 board/spd8xx/Makefile delete mode 100644 board/spd8xx/flash.c delete mode 100644 board/spd8xx/spd8xx.c delete mode 100644 board/spd8xx/u-boot.lds delete mode 100644 board/spd8xx/u-boot.lds.debug delete mode 100644 board/utx8245/Kconfig delete mode 100644 board/utx8245/MAINTAINERS delete mode 100644 board/utx8245/Makefile delete mode 100644 board/utx8245/flash.c delete mode 100644 board/utx8245/utx8245.c delete mode 100644 configs/A3000_defconfig delete mode 100644 configs/CPC45_ROMBOOT_defconfig delete mode 100644 configs/CPC45_defconfig delete mode 100644 configs/CPU86_ROMBOOT_defconfig delete mode 100644 configs/CPU86_defconfig delete mode 100644 configs/CPU87_ROMBOOT_defconfig delete mode 100644 configs/CPU87_defconfig delete mode 100644 configs/CU824_defconfig delete mode 100644 configs/ELPT860_defconfig delete mode 100644 configs/ESTEEM192E_defconfig delete mode 100644 configs/FPS850L_defconfig delete mode 100644 configs/FPS860L_defconfig delete mode 100644 configs/IP860_defconfig delete mode 100644 configs/IPHASE4539_defconfig delete mode 100644 configs/IVML24_128_defconfig delete mode 100644 configs/IVML24_256_defconfig delete mode 100644 configs/IVML24_defconfig delete mode 100644 configs/IVMS8_128_defconfig delete mode 100644 configs/IVMS8_256_defconfig delete mode 100644 configs/IVMS8_defconfig delete mode 100644 configs/KUP4K_defconfig delete mode 100644 configs/KUP4X_defconfig delete mode 100644 configs/MPC8266ADS_defconfig delete mode 100644 configs/MUSENKI_defconfig delete mode 100644 configs/MVBLUE_defconfig delete mode 100644 configs/NETVIA_V2_defconfig delete mode 100644 configs/NETVIA_defconfig delete mode 100644 configs/NSCU_defconfig delete mode 100644 configs/PM825_BIGFLASH_defconfig delete mode 100644 configs/PM825_ROMBOOT_BIGFLASH_defconfig delete mode 100644 configs/PM825_ROMBOOT_defconfig delete mode 100644 configs/PM825_defconfig delete mode 100644 configs/PM826_BIGFLASH_defconfig delete mode 100644 configs/PM826_ROMBOOT_BIGFLASH_defconfig delete mode 100644 configs/PM826_ROMBOOT_defconfig delete mode 100644 configs/PM826_defconfig delete mode 100644 configs/PM828_PCI_defconfig delete mode 100644 configs/PM828_ROMBOOT_PCI_defconfig delete mode 100644 configs/PM828_ROMBOOT_defconfig delete mode 100644 configs/PM828_defconfig delete mode 100644 configs/R360MPI_defconfig delete mode 100644 configs/RRvision_LCD_defconfig delete mode 100644 configs/RRvision_defconfig delete mode 100644 configs/SM850_defconfig delete mode 100644 configs/SPD823TS_defconfig delete mode 100644 configs/Sandpoint8240_defconfig delete mode 100644 configs/Sandpoint8245_defconfig delete mode 100644 configs/TK885D_defconfig delete mode 100644 configs/VoVPN-GW_66MHz_defconfig delete mode 100644 configs/atc_defconfig delete mode 100644 configs/cogent_mpc8260_defconfig delete mode 100644 configs/cogent_mpc8xx_defconfig delete mode 100644 configs/eXalion_defconfig delete mode 100644 configs/ep8260_defconfig delete mode 100644 configs/ep82xxm_defconfig delete mode 100644 configs/gw8260_defconfig delete mode 100644 configs/hmi1001_defconfig delete mode 100644 configs/lwmon_defconfig delete mode 100644 configs/muas3001_defconfig delete mode 100644 configs/muas3001_dev_defconfig delete mode 100644 configs/mucmc52_defconfig delete mode 100644 configs/ppmc8260_defconfig delete mode 100644 configs/sacsng_defconfig delete mode 100644 configs/uc100_defconfig delete mode 100644 configs/uc101_defconfig delete mode 100644 configs/utx8245_defconfig delete mode 100644 configs/virtlab2_defconfig delete mode 100644 drivers/pcmcia/i82365.c delete mode 100644 drivers/rtc/ds12887.c delete mode 100644 include/configs/A3000.h delete mode 100644 include/configs/CPC45.h delete mode 100644 include/configs/CPU86.h delete mode 100644 include/configs/CPU87.h delete mode 100644 include/configs/CU824.h delete mode 100644 include/configs/ELPT860.h delete mode 100644 include/configs/ESTEEM192E.h delete mode 100644 include/configs/FPS850L.h delete mode 100644 include/configs/FPS860L.h delete mode 100644 include/configs/IP860.h delete mode 100644 include/configs/IPHASE4539.h delete mode 100644 include/configs/IVML24.h delete mode 100644 include/configs/IVMS8.h delete mode 100644 include/configs/KUP4K.h delete mode 100644 include/configs/KUP4X.h delete mode 100644 include/configs/MPC8266ADS.h delete mode 100644 include/configs/MUSENKI.h delete mode 100644 include/configs/MVBLUE.h delete mode 100644 include/configs/NETVIA.h delete mode 100644 include/configs/NSCU.h delete mode 100644 include/configs/PM826.h delete mode 100644 include/configs/PM828.h delete mode 100644 include/configs/R360MPI.h delete mode 100644 include/configs/RRvision.h delete mode 100644 include/configs/SM850.h delete mode 100644 include/configs/SPD823TS.h delete mode 100644 include/configs/Sandpoint8240.h delete mode 100644 include/configs/Sandpoint8245.h delete mode 100644 include/configs/TK885D.h delete mode 100644 include/configs/VoVPN-GW.h delete mode 100644 include/configs/atc.h delete mode 100644 include/configs/cogent_common.h delete mode 100644 include/configs/cogent_mpc8260.h delete mode 100644 include/configs/cogent_mpc8xx.h delete mode 100644 include/configs/eXalion.h delete mode 100644 include/configs/ep8260.h delete mode 100644 include/configs/ep82xxm.h delete mode 100644 include/configs/gw8260.h delete mode 100644 include/configs/hmi1001.h delete mode 100644 include/configs/lwmon.h delete mode 100644 include/configs/muas3001.h delete mode 100644 include/configs/mucmc52.h delete mode 100644 include/configs/ppmc8260.h delete mode 100644 include/configs/sacsng.h delete mode 100644 include/configs/uc100.h delete mode 100644 include/configs/uc101.h delete mode 100644 include/configs/utx8245.h delete mode 100644 include/configs/virtlab2.h delete mode 100644 include/mpc824x.h delete mode 100644 include/pcmcia/cirrus.h delete mode 100644 include/pcmcia/i82365.h delete mode 100644 include/pcmcia/ss.h delete mode 100644 include/pcmcia/ti113x.h delete mode 100644 include/video_ad7176.h delete mode 100644 include/video_ad7177.h delete mode 100644 include/video_ad7179.h
These boards are still non-generic boards.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Wolfgang Denk wd@denx.de ---
arch/powerpc/cpu/mpc8xx/Kconfig | 18 -- board/tqc/tqm8xx/Kconfig | 78 ------- board/tqc/tqm8xx/MAINTAINERS | 16 -- board/tqc/tqm8xx/tqm8xx.c | 58 +---- configs/FPS850L_defconfig | 3 - configs/FPS860L_defconfig | 3 - configs/NSCU_defconfig | 3 - configs/SM850_defconfig | 3 - configs/TK885D_defconfig | 3 - configs/virtlab2_defconfig | 3 - doc/README.scrapyard | 8 +- drivers/pcmcia/mpc8xx_pcmcia.c | 2 +- drivers/pcmcia/tqm8xx_pcmcia.c | 51 +---- include/commproc.h | 55 +---- include/configs/FPS850L.h | 413 --------------------------------- include/configs/FPS860L.h | 415 ---------------------------------- include/configs/NSCU.h | 463 ------------------------------------- include/configs/SM850.h | 351 ---------------------------- include/configs/TK885D.h | 490 ---------------------------------------- include/configs/virtlab2.h | 469 -------------------------------------- 20 files changed, 11 insertions(+), 2894 deletions(-) delete mode 100644 configs/FPS850L_defconfig delete mode 100644 configs/FPS860L_defconfig delete mode 100644 configs/NSCU_defconfig delete mode 100644 configs/SM850_defconfig delete mode 100644 configs/TK885D_defconfig delete mode 100644 configs/virtlab2_defconfig delete mode 100644 include/configs/FPS850L.h delete mode 100644 include/configs/FPS860L.h delete mode 100644 include/configs/NSCU.h delete mode 100644 include/configs/SM850.h delete mode 100644 include/configs/TK885D.h delete mode 100644 include/configs/virtlab2.h
diff --git a/arch/powerpc/cpu/mpc8xx/Kconfig b/arch/powerpc/cpu/mpc8xx/Kconfig index 99420ab..33fff0c 100644 --- a/arch/powerpc/cpu/mpc8xx/Kconfig +++ b/arch/powerpc/cpu/mpc8xx/Kconfig @@ -49,21 +49,6 @@ config TARGET_ELPT860 config TARGET_UC100 bool "Support uc100"
-config TARGET_FPS850L - bool "Support FPS850L" - -config TARGET_FPS860L - bool "Support FPS860L" - -config TARGET_NSCU - bool "Support NSCU" - -config TARGET_SM850 - bool "Support SM850" - -config TARGET_TK885D - bool "Support TK885D" - config TARGET_TQM823L bool "Support TQM823L"
@@ -100,9 +85,6 @@ config TARGET_TQM866M config TARGET_TQM885D bool "Support TQM885D"
-config TARGET_VIRTLAB2 - bool "Support virtlab2" - endchoice
source "board/LEOX/elpt860/Kconfig" diff --git a/board/tqc/tqm8xx/Kconfig b/board/tqc/tqm8xx/Kconfig index 926a37a..857fedb 100644 --- a/board/tqc/tqm8xx/Kconfig +++ b/board/tqc/tqm8xx/Kconfig @@ -1,68 +1,3 @@ -if TARGET_FPS850L - -config SYS_BOARD - default "tqm8xx" - -config SYS_VENDOR - default "tqc" - -config SYS_CONFIG_NAME - default "FPS850L" - -endif - -if TARGET_FPS860L - -config SYS_BOARD - default "tqm8xx" - -config SYS_VENDOR - default "tqc" - -config SYS_CONFIG_NAME - default "FPS860L" - -endif - -if TARGET_NSCU - -config SYS_BOARD - default "tqm8xx" - -config SYS_VENDOR - default "tqc" - -config SYS_CONFIG_NAME - default "NSCU" - -endif - -if TARGET_SM850 - -config SYS_BOARD - default "tqm8xx" - -config SYS_VENDOR - default "tqc" - -config SYS_CONFIG_NAME - default "SM850" - -endif - -if TARGET_TK885D - -config SYS_BOARD - default "tqm8xx" - -config SYS_VENDOR - default "tqc" - -config SYS_CONFIG_NAME - default "TK885D" - -endif - if TARGET_TQM823L
config SYS_BOARD @@ -218,16 +153,3 @@ config SYS_CONFIG_NAME default "TQM885D"
endif - -if TARGET_VIRTLAB2 - -config SYS_BOARD - default "tqm8xx" - -config SYS_VENDOR - default "tqc" - -config SYS_CONFIG_NAME - default "virtlab2" - -endif diff --git a/board/tqc/tqm8xx/MAINTAINERS b/board/tqc/tqm8xx/MAINTAINERS index fe4a212..f3ddc6a 100644 --- a/board/tqc/tqm8xx/MAINTAINERS +++ b/board/tqc/tqm8xx/MAINTAINERS @@ -2,12 +2,6 @@ TQM8XX BOARD M: Wolfgang Denk wd@denx.de S: Maintained F: board/tqc/tqm8xx/ -F: include/configs/FPS850L.h -F: configs/FPS850L_defconfig -F: include/configs/FPS860L.h -F: configs/FPS860L_defconfig -F: include/configs/SM850.h -F: configs/SM850_defconfig F: include/configs/TQM823L.h F: configs/TQM823L_defconfig F: configs/TQM823L_LCD_defconfig @@ -34,14 +28,4 @@ F: configs/TQM866M_defconfig F: include/configs/TQM885D.h F: configs/TQM885D_defconfig F: configs/TTTech_defconfig -F: include/configs/virtlab2.h -F: configs/virtlab2_defconfig F: configs/wtk_defconfig - -NSCU BOARD -#M: - -S: Maintained -F: include/configs/NSCU.h -F: configs/NSCU_defconfig -F: include/configs/TK885D.h -F: configs/TK885D_defconfig diff --git a/board/tqc/tqm8xx/tqm8xx.c b/board/tqc/tqm8xx/tqm8xx.c index 3b5230a..6d17830 100644 --- a/board/tqc/tqm8xx/tqm8xx.c +++ b/board/tqc/tqm8xx/tqm8xx.c @@ -118,9 +118,7 @@ int checkboard (void) break; putc (buf[i]); } -#ifdef CONFIG_VIRTLAB2 - puts (" (Virtlab2)"); -#endif + putc ('\n');
return (0); @@ -512,14 +510,6 @@ int misc_init_r (void) immap->im_ioport.iop_padat &= ~0x0001; /* turn it off */ # endif
-#ifdef CONFIG_NSCU - /* wake up ethernet module */ - immap->im_ioport.iop_pcpar &= ~0x0004; /* GPIO pin */ - immap->im_ioport.iop_pcdir |= 0x0004; /* output */ - immap->im_ioport.iop_pcso &= ~0x0004; /* for clarity */ - immap->im_ioport.iop_pcdat |= 0x0004; /* enable */ -#endif /* CONFIG_NSCU */ - return (0); } #endif /* CONFIG_MISC_INIT_R */ @@ -682,49 +672,3 @@ int ft_board_setup(void *blob, bd_t *bd) return 0; } #endif /* defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) */ - -/* ---------------------------------------------------------------------------- */ -/* TK885D specific initializaion */ -/* ---------------------------------------------------------------------------- */ -#ifdef CONFIG_TK885D -#include <miiphy.h> -int last_stage_init(void) -{ - const unsigned char phy[] = {CONFIG_FEC1_PHY, CONFIG_FEC2_PHY}; - unsigned short reg; - int ret, i = 100; - char *s; - - mii_init(); - /* Without this delay 0xff is read from the UART buffer later in - * abortboot() and autoboot is aborted */ - udelay(10000); - while (tstc() && i--) - (void)getc(); - - /* Check if auto-negotiation is prohibited */ - s = getenv("phy_auto_nego"); - - if (!s || !strcmp(s, "on")) - /* Nothing to do - autonegotiation by default */ - return 0; - - for (i = 0; i < 2; i++) { - ret = miiphy_read("FEC", phy[i], MII_BMCR, ®); - if (ret) { - printf("Cannot read BMCR on PHY %d\n", phy[i]); - return 0; - } - /* Auto-negotiation off, hard set full duplex, 100Mbps */ - ret = miiphy_write("FEC", phy[i], - MII_BMCR, (reg | BMCR_SPEED100 | - BMCR_FULLDPLX) & ~BMCR_ANENABLE); - if (ret) { - printf("Cannot write BMCR on PHY %d\n", phy[i]); - return 0; - } - } - - return 0; -} -#endif diff --git a/configs/FPS850L_defconfig b/configs/FPS850L_defconfig deleted file mode 100644 index e72ccdd..0000000 --- a/configs/FPS850L_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_FPS850L=y diff --git a/configs/FPS860L_defconfig b/configs/FPS860L_defconfig deleted file mode 100644 index 643da6a..0000000 --- a/configs/FPS860L_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_FPS860L=y diff --git a/configs/NSCU_defconfig b/configs/NSCU_defconfig deleted file mode 100644 index be96cbd..0000000 --- a/configs/NSCU_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_NSCU=y diff --git a/configs/SM850_defconfig b/configs/SM850_defconfig deleted file mode 100644 index 6a50316..0000000 --- a/configs/SM850_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_SM850=y diff --git a/configs/TK885D_defconfig b/configs/TK885D_defconfig deleted file mode 100644 index 01bc6dc..0000000 --- a/configs/TK885D_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_TK885D=y diff --git a/configs/virtlab2_defconfig b/configs/virtlab2_defconfig deleted file mode 100644 index 3eb3993..0000000 --- a/configs/virtlab2_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_VIRTLAB2=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index deb4af4..3cf32e7 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,7 +12,13 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= -hermes powerpc mpc8xx - - Wolfgang Denk wd@denx.de +FPS850L powerpc mpc8xx - - Wolfgang Denk wd@denx.de +FPS860L powerpc mpc8xx - - Wolfgang Denk wd@denx.de +NSCU powerpc mpc8xx - - +SM850 powerpc mpc8xx - - Wolfgang Denk wd@denx.de +TK885D powerpc mpc8xx - - +virtlab2 powerpc mpc8xx - - Wolfgang Denk wd@denx.de +hermes powerpc mpc8xx 36da51e 2014-12-08 Wolfgang Denk wd@denx.de PRS200 powerpc mpc5200 ecfdcee 2014-11-12 MCC200 powerpc mpc5200 ecfdcee 2014-11-12 TOP5200 powerpc mpc5200 d58a945 2014-10-28 Reinhard Meyer reinhard.meyer@emk-elektronik.de diff --git a/drivers/pcmcia/mpc8xx_pcmcia.c b/drivers/pcmcia/mpc8xx_pcmcia.c index af77426..ea88494 100644 --- a/drivers/pcmcia/mpc8xx_pcmcia.c +++ b/drivers/pcmcia/mpc8xx_pcmcia.c @@ -58,7 +58,7 @@ static const u_int m8xx_size_to_gray[M8XX_SIZES_NO] =
-#if defined(CONFIG_LWMON) || defined(CONFIG_NSCU) +#if defined(CONFIG_LWMON) #define CONFIG_SYS_PCMCIA_TIMING ( PCMCIA_SHT(9) \ | PCMCIA_SST(3) \ | PCMCIA_SL(12)) diff --git a/drivers/pcmcia/tqm8xx_pcmcia.c b/drivers/pcmcia/tqm8xx_pcmcia.c index 8b74478..45dcb54 100644 --- a/drivers/pcmcia/tqm8xx_pcmcia.c +++ b/drivers/pcmcia/tqm8xx_pcmcia.c @@ -22,51 +22,10 @@ #if defined(CONFIG_PCMCIA) \ && defined(CONFIG_TQM8xxL)
-#if defined(CONFIG_VIRTLAB2) -#define PCMCIA_BOARD_MSG "Virtlab2" -#elif defined(CONFIG_TQM8xxL) +#if defined(CONFIG_TQM8xxL) #define PCMCIA_BOARD_MSG "TQM8xxL" #endif
-#if defined(CONFIG_NSCU) - -static inline void power_config(int slot) {} -static inline void power_off(int slot) {} -static inline void power_on_5_0(int slot) {} -static inline void power_on_3_3(int slot) {} - -#elif defined(CONFIG_VIRTLAB2) - -static inline void power_config(int slot) {} - -static inline void power_off(int slot) -{ - volatile unsigned __iomem *addr; - addr = (volatile unsigned __iomem *)PCMCIA_CTRL; - - out_be32(addr, 0); -} - -static inline void power_on_5_0(int slot) -{ - volatile unsigned __iomem *addr; - addr = (volatile unsigned __iomem *)PCMCIA_CTRL; - - /* Enable 5V Vccout */ - out_be32(addr, 2); -} - -static inline void power_on_3_3(int slot) -{ - volatile unsigned __iomem *addr; - addr = (volatile unsigned __iomem *)PCMCIA_CTRL; - - /* Enable 3.3V Vccout */ - out_be32(addr, 1); -} - -#else - static inline void power_config(int slot) { immap_t *immap = (immap_t *)CONFIG_SYS_IMMR; @@ -98,8 +57,6 @@ static inline void power_on_3_3(int slot) setbits_be16(&immap->im_ioport.iop_pcdir, 0x0002 | 0x0004); }
-#endif - /* * Function to retrieve the PIPR register, used for debuging purposes. */ @@ -121,11 +78,7 @@ static inline int check_card_is_absent(int slot) return pipr & (0x18000000 >> (slot << 4)); }
-#ifdef NSCU_OE_INV -#define NSCU_GCRX_CXOE 0 -#else #define NSCU_GCRX_CXOE __MY_PCMCIA_GCRX_CXOE -#endif
int pcmcia_hardware_enable(int slot) { @@ -243,7 +196,6 @@ int pcmcia_hardware_disable(int slot)
int pcmcia_voltage_set(int slot, int vcc, int vpp) { -#ifndef CONFIG_NSCU u_long reg; uint32_t pipr = 0;
@@ -296,7 +248,6 @@ done: udelay(500);
debug("voltage_set: " PCMCIA_BOARD_MSG " Slot %c, DONE\n", slot+'A'); -#endif /* CONFIG_NSCU */ return 0; }
diff --git a/include/commproc.h b/include/commproc.h index 6875c4c..3e19603 100644 --- a/include/commproc.h +++ b/include/commproc.h @@ -510,31 +510,6 @@ typedef struct scc_enet {
#endif
-/*** FPS850L, FPS860L ************************************************/ - -#if defined(CONFIG_FPS850L) || defined(CONFIG_FPS860L) -/* Bits in parallel I/O port registers that have to be set/cleared - * to configure the pins for SCC2 use. - */ -#define PROFF_ENET PROFF_SCC2 -#define CPM_CR_ENET CPM_CR_CH_SCC2 -#define SCC_ENET 1 -#define PA_ENET_RXD ((ushort)0x0004) /* PA 13 */ -#define PA_ENET_TXD ((ushort)0x0008) /* PA 12 */ -#define PA_ENET_RCLK ((ushort)0x0100) /* PA 7 */ -#define PA_ENET_TCLK ((ushort)0x0400) /* PA 5 */ - -#define PC_ENET_TENA ((ushort)0x0002) /* PC 14 */ -#define PC_ENET_CLSN ((ushort)0x0040) /* PC 9 */ -#define PC_ENET_RENA ((ushort)0x0080) /* PC 8 */ - -/* Control bits in the SICR to route TCLK (CLK2) and RCLK (CLK4) to - * SCC2. Also, make sure GR2 (bit 16) and SC2 (bit 17) are zero. - */ -#define SICR_ENET_MASK ((uint)0x0000ff00) -#define SICR_ENET_CLKRT ((uint)0x00002600) -#endif /* CONFIG_FPS850L, CONFIG_FPS860L */ - /*** IP860 **********************************************************/
#if defined(CONFIG_IP860) @@ -708,32 +683,6 @@ typedef struct scc_enet {
#endif /* CONFIG_NETVIA */
-/*** SM850 *********************************************************/ - -/* The SM850 Service Module uses SCC2 for IrDA and SCC3 for Ethernet */ - -#ifdef CONFIG_SM850 -#define PROFF_ENET PROFF_SCC3 /* Ethernet on SCC3 */ -#define CPM_CR_ENET CPM_CR_CH_SCC3 -#define SCC_ENET 2 -#define PB_ENET_RXD ((uint)0x00000004) /* PB 29 */ -#define PB_ENET_TXD ((uint)0x00000002) /* PB 30 */ -#define PA_ENET_RCLK ((ushort)0x0100) /* PA 7 */ -#define PA_ENET_TCLK ((ushort)0x0400) /* PA 5 */ - -#define PC_ENET_LBK ((ushort)0x0008) /* PC 12 */ -#define PC_ENET_TENA ((ushort)0x0004) /* PC 13 */ - -#define PC_ENET_RENA ((ushort)0x0800) /* PC 4 */ -#define PC_ENET_CLSN ((ushort)0x0400) /* PC 5 */ - -/* Control bits in the SICR to route TCLK (CLK3) and RCLK (CLK1) to - * SCC3. Also, make sure GR3 (bit 8) and SC3 (bit 9) are zero. - */ -#define SICR_ENET_MASK ((uint)0x00FF0000) -#define SICR_ENET_CLKRT ((uint)0x00260000) -#endif /* CONFIG_SM850 */ - /*** SPD823TS ******************************************************/
#ifdef CONFIG_SPD823TS @@ -770,16 +719,14 @@ typedef struct scc_enet { defined(CONFIG_RRVISION)|| defined(CONFIG_TQM823L) || \ defined(CONFIG_TQM823M) || defined(CONFIG_TQM850L) || \ defined(CONFIG_TQM850M) || defined(CONFIG_TQM885D) || \ - defined(CONFIG_RRVISION)|| defined(CONFIG_VIRTLAB2) + defined(CONFIG_RRVISION)
/* Bits in parallel I/O port registers that have to be set/cleared * to configure the pins for SCC2 use. */ #define PROFF_ENET PROFF_SCC2 #define CPM_CR_ENET CPM_CR_CH_SCC2 -#if (!defined(CONFIG_TK885D)) /* TK885D does not use SCC Ethernet */ #define SCC_ENET 1 -#endif #define PA_ENET_RXD ((ushort)0x0004) /* PA 13 */ #define PA_ENET_TXD ((ushort)0x0008) /* PA 12 */ #define PA_ENET_RCLK ((ushort)0x0100) /* PA 7 */ diff --git a/include/configs/FPS850L.h b/include/configs/FPS850L.h deleted file mode 100644 index 4ea24a6..0000000 --- a/include/configs/FPS850L.h +++ /dev/null @@ -1,413 +0,0 @@ -/* - * (C) Copyright 2000-2008 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC850 1 /* This is a MPC850 CPU */ -#define CONFIG_FPS850L 1 /* ...on a FingerPrint Sensor */ - -#define CONFIG_SYS_TEXT_BASE 0x40000000 - -#define CONFIG_8xx_CONS_SMC2 1 /* Console is on SMC2 */ -#define CONFIG_SYS_SMC_RXBUFLEN 128 -#define CONFIG_SYS_MAXIDLE 10 -#define CONFIG_BAUDRATE 115200 - -#define CONFIG_BOOTCOUNT_LIMIT - -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ - -#define CONFIG_BOARD_TYPES 1 /* support board types */ - -#define CONFIG_PREBOOT "echo;echo Type \"run flash_nfs\" to mount root filesystem over NFS;echo" - -#undef CONFIG_BOOTARGS - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=eth0\0" \ - "nfsargs=setenv bootargs root=/dev/nfs rw " \ - "nfsroot=${serverip}:${rootpath}\0" \ - "ramargs=setenv bootargs root=/dev/ram rw\0" \ - "addip=setenv bootargs ${bootargs} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ - ":${hostname}:${netdev}:off panic=1\0" \ - "flash_nfs=run nfsargs addip;" \ - "bootm ${kernel_addr}\0" \ - "flash_self=run ramargs addip;" \ - "bootm ${kernel_addr} ${ramdisk_addr}\0" \ - "net_nfs=tftp 200000 ${bootfile};run nfsargs addip;bootm\0" \ - "rootpath=/opt/eldk/ppc_8xx\0" \ - "hostname=FPS850L\0" \ - "bootfile=FPS850L/uImage\0" \ - "fdt_addr=40040000\0" \ - "kernel_addr=40060000\0" \ - "ramdisk_addr=40200000\0" \ - "u-boot=FPS850L/u-image.bin\0" \ - "load=tftp 200000 ${u-boot}\0" \ - "update=prot off 40000000 +${filesize};" \ - "era 40000000 +${filesize};" \ - "cp.b 200000 40000000 ${filesize};" \ - "sete filesize;save\0" \ - "" -#define CONFIG_BOOTCOMMAND "run flash_self" - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_NISDOMAIN -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_DNS -#define CONFIG_BOOTP_DNS2 -#define CONFIG_BOOTP_SEND_HOSTNAME -#define CONFIG_BOOTP_NTPSERVER -#define CONFIG_BOOTP_TIMEOFFSET - -#define CONFIG_RTC_MPC8xx /* use internal RTC of MPC8xx */ - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_NFS -#define CONFIG_CMD_SNTP - - -#define CONFIG_NETCONSOLE - - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ - -#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ -#define CONFIG_SYS_HUSH_PARSER 1 /* Use the HUSH parser */ - -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xFFF00000 - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0x40000000 -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * FLASH organization - */ - -/* use CFI flash driver */ -#define CONFIG_SYS_FLASH_CFI 1 /* Flash is CFI conformant */ -#define CONFIG_FLASH_CFI_DRIVER 1 /* Use the common driver */ -#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE+flash_info[0].size } -#define CONFIG_SYS_FLASH_EMPTY_INFO -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 71 /* max number of sectors on one chip */ - -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_OFFSET 0x8000 /* Offset of Environment Sector */ -#define CONFIG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */ - -/* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET+CONFIG_ENV_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) - -#define CONFIG_SYS_USE_PPCENV /* Environment embedded in sect .ppcenv */ - -#define CONFIG_MISC_INIT_R /* Make sure to remap flashes correctly */ - -/*----------------------------------------------------------------------- - * Dynamic MTD partition support - */ -#define CONFIG_CMD_MTDPARTS -#define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ -#define CONFIG_FLASH_CFI_MTD -#define MTDIDS_DEFAULT "nor0=TQM8xxL-0" - -#define MTDPARTS_DEFAULT "mtdparts=TQM8xxL-0:256k(u-boot)," \ - "128k(dtb)," \ - "1664k(kernel)," \ - "2m(rootfs)," \ - "4m(data)" - -/*----------------------------------------------------------------------- - * Hardware Information Block - */ -#define CONFIG_SYS_HWINFO_OFFSET 0x0003FFC0 /* offset of HW Info block */ -#define CONFIG_SYS_HWINFO_SIZE 0x00000040 /* size of HW Info block */ -#define CONFIG_SYS_HWINFO_MAGIC 0x54514D38 /* 'TQM8' */ - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CACHELINE_SHIFT 4 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 11-9 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Software & Bus Monitor Timer max, Bus Monitor enable, SW Watchdog freeze - */ -#if defined(CONFIG_WATCHDOG) -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | \ - SYPCR_SWE | SYPCR_SWRI| SYPCR_SWP) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | SYPCR_SWP) -#endif - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 11-6 - *----------------------------------------------------------------------- - * PCMCIA config., multi-function pin tri-state - */ -#define CONFIG_SYS_SIUMCR (SIUMCR_DBGC00 | SIUMCR_DBPC00 | SIUMCR_MLRC01) - -/*----------------------------------------------------------------------- - * TBSCR - Time Base Status and Control 11-26 - *----------------------------------------------------------------------- - * Clear Reference Interrupt Status, Timebase freezing enabled - */ -#define CONFIG_SYS_TBSCR (TBSCR_REFA | TBSCR_REFB | TBSCR_TBF) - -/*----------------------------------------------------------------------- - * RTCSC - Real-Time Clock Status and Control Register 11-27 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RTCSC (RTCSC_SEC | RTCSC_ALR | RTCSC_RTF| RTCSC_RTE) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 11-31 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Interrupt Timer freezing enabled - */ -#define CONFIG_SYS_PISCR (PISCR_PS | PISCR_PITF) - -/*----------------------------------------------------------------------- - * PLPRCR - PLL, Low-Power, and Reset Control Register 15-30 - *----------------------------------------------------------------------- - * Reset PLL lock status sticky bit, timer expired status bit and timer - * interrupt status bit - leave PLL multiplication factor unchanged ! - */ -#define CONFIG_SYS_PLPRCR (PLPRCR_SPLSS | PLPRCR_TEXPS | PLPRCR_TMIST) - -/*----------------------------------------------------------------------- - * SCCR - System Clock and reset Control Register 15-27 - *----------------------------------------------------------------------- - * Set clock output, timebase and RTC source and divider, - * power management and some other internal clocks - */ -#define SCCR_MASK SCCR_EBDF11 -#define CONFIG_SYS_SCCR (SCCR_TBS | \ - SCCR_COM00 | SCCR_DFSYNC00 | SCCR_DFBRG00 | \ - SCCR_DFNL000 | SCCR_DFNH000 | SCCR_DFLCD000 | \ - SCCR_DFALCD00) - -/*----------------------------------------------------------------------- - * PCMCIA stuff - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_PCMCIA_MEM_ADDR (0xE0000000) -#define CONFIG_SYS_PCMCIA_MEM_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_DMA_ADDR (0xE4000000) -#define CONFIG_SYS_PCMCIA_DMA_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_ATTRB_ADDR (0xE8000000) -#define CONFIG_SYS_PCMCIA_ATTRB_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_IO_ADDR (0xEC000000) -#define CONFIG_SYS_PCMCIA_IO_SIZE ( 64 << 20 ) - -/*----------------------------------------------------------------------- - * - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_DER 0 - -/* - * Init Memory Controller: - * - * BR0/1 and OR0/1 (FLASH) - */ - -#define FLASH_BASE0_PRELIM 0x40000000 /* FLASH bank #0 */ -#define FLASH_BASE1_PRELIM 0x60000000 /* FLASH bank #0 */ - -/* used to re-map FLASH both when starting from SRAM or FLASH: - * restrict access enough to keep SRAM working (if any) - * but not too much to meddle with FLASH accesses - */ -#define CONFIG_SYS_REMAP_OR_AM 0x80000000 /* OR addr mask */ -#define CONFIG_SYS_PRELIM_OR_AM 0xE0000000 /* OR addr mask */ - -/* - * FLASH timing: - */ -#define CONFIG_SYS_OR_TIMING_FLASH (OR_ACS_DIV1 | OR_TRLX | OR_CSNT_SAM | \ - OR_SCY_3_CLK | OR_EHTR | OR_BI) - -#define CONFIG_SYS_OR0_REMAP (CONFIG_SYS_REMAP_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_BR0_PRELIM ((FLASH_BASE0_PRELIM & BR_BA_MSK) | BR_V ) - -#define CONFIG_SYS_OR1_REMAP CONFIG_SYS_OR0_REMAP -#define CONFIG_SYS_OR1_PRELIM CONFIG_SYS_OR0_PRELIM -#define CONFIG_SYS_BR1_PRELIM ((FLASH_BASE1_PRELIM & BR_BA_MSK) | BR_V ) - -/* - * BR2/3 and OR2/3 (SDRAM) - * - */ -#define SDRAM_BASE2_PRELIM 0x00000000 /* SDRAM bank #0 */ -#define SDRAM_BASE3_PRELIM 0x20000000 /* SDRAM bank #1 */ -#define SDRAM_MAX_SIZE 0x04000000 /* max 64 MB per bank */ - -/* SDRAM timing: Multiplexed addresses, GPL5 output to GPL5_A (don't care) */ -#define CONFIG_SYS_OR_TIMING_SDRAM 0x00000A00 - -#define CONFIG_SYS_OR2_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_SDRAM ) -#define CONFIG_SYS_BR2_PRELIM ((SDRAM_BASE2_PRELIM & BR_BA_MSK) | BR_MS_UPMA | BR_V ) - -#define CONFIG_SYS_OR3_PRELIM CONFIG_SYS_OR2_PRELIM -#define CONFIG_SYS_BR3_PRELIM ((SDRAM_BASE3_PRELIM & BR_BA_MSK) | BR_MS_UPMA | BR_V ) - -/* - * Memory Periodic Timer Prescaler - * - * The Divider for PTA (refresh timer) configuration is based on an - * example SDRAM configuration (64 MBit, one bank). The adjustment to - * the number of chip selects (NCS) and the actually needed refresh - * rate is done by setting MPTPR. - * - * PTA is calculated from - * PTA = (gclk * Trefresh) / ((2 ^ (2 * DFBRG)) * PTP * NCS) - * - * gclk CPU clock (not bus clock!) - * Trefresh Refresh cycle * 4 (four word bursts used) - * - * 4096 Rows from SDRAM example configuration - * 1000 factor s -> ms - * 32 PTP (pre-divider from MPTPR) from SDRAM example configuration - * 4 Number of refresh cycles per period - * 64 Refresh cycle in ms per number of rows - * -------------------------------------------- - * Divider = 4096 * 32 * 1000 / (4 * 64) = 512000 - * - * 50 MHz => 50.000.000 / Divider = 98 - * 66 Mhz => 66.000.000 / Divider = 129 - * 80 Mhz => 80.000.000 / Divider = 156 - */ - -#define CONFIG_SYS_PTA_PER_CLK ((4096 * 32 * 1000) / (4 * 64)) -#define CONFIG_SYS_MAMR_PTA 98 - -/* - * For 16 MBit, refresh rates could be 31.3 us - * (= 64 ms / 2K = 125 / quad bursts). - * For a simpler initialization, 15.6 us is used instead. - * - * #define CONFIG_SYS_MPTPR_2BK_2K MPTPR_PTP_DIV32 for 2 banks - * #define CONFIG_SYS_MPTPR_1BK_2K MPTPR_PTP_DIV64 for 1 bank - */ -#define CONFIG_SYS_MPTPR_2BK_4K MPTPR_PTP_DIV16 /* setting for 2 banks */ -#define CONFIG_SYS_MPTPR_1BK_4K MPTPR_PTP_DIV32 /* setting for 1 bank */ - -/* refresh rate 7.8 us (= 64 ms / 8K = 31.2 / quad bursts) for 256 MBit */ -#define CONFIG_SYS_MPTPR_2BK_8K MPTPR_PTP_DIV8 /* setting for 2 banks */ -#define CONFIG_SYS_MPTPR_1BK_8K MPTPR_PTP_DIV16 /* setting for 1 bank */ - -/* - * MAMR settings for SDRAM - */ - -/* 8 column SDRAM */ -#define CONFIG_SYS_MAMR_8COL ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_0 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A11 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) -/* 9 column SDRAM */ -#define CONFIG_SYS_MAMR_9COL ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_1 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A10 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) - -/* pass open firmware flat tree */ -#define CONFIG_OF_LIBFDT 1 -#define CONFIG_OF_BOARD_SETUP 1 -#define CONFIG_HWCONFIG 1 - -#endif /* __CONFIG_H */ diff --git a/include/configs/FPS860L.h b/include/configs/FPS860L.h deleted file mode 100644 index c368861..0000000 --- a/include/configs/FPS860L.h +++ /dev/null @@ -1,415 +0,0 @@ -/* - * (C) Copyright 2000-2008 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC860 1 /* This is a MPC860 CPU */ -#define CONFIG_FPS860L 1 /* ...on a FingerPrint Sensor */ - -#define CONFIG_SYS_TEXT_BASE 0x40000000 - -#define CONFIG_8xx_CONS_SMC2 1 /* Console is on SMC2 */ -#define CONFIG_SYS_SMC_RXBUFLEN 128 -#define CONFIG_SYS_MAXIDLE 10 -#define CONFIG_BAUDRATE 115200 - -#define CONFIG_BOOTCOUNT_LIMIT - -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ - -#define CONFIG_BOARD_TYPES 1 /* support board types */ - -#define CONFIG_PREBOOT "echo;echo Type \"run flash_nfs\" to mount root filesystem over NFS;echo" - -#undef CONFIG_BOOTARGS - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=eth0\0" \ - "nfsargs=setenv bootargs root=/dev/nfs rw " \ - "nfsroot=${serverip}:${rootpath}\0" \ - "ramargs=setenv bootargs root=/dev/ram rw\0" \ - "addip=setenv bootargs ${bootargs} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ - ":${hostname}:${netdev}:off panic=1\0" \ - "flash_nfs=run nfsargs addip;" \ - "bootm ${kernel_addr}\0" \ - "flash_self=run ramargs addip;" \ - "bootm ${kernel_addr} ${ramdisk_addr}\0" \ - "net_nfs=tftp 200000 ${bootfile};run nfsargs addip;bootm\0" \ - "rootpath=/opt/eldk/ppc_8xx\0" \ - "hostname=FPS860L\0" \ - "bootfile=FPS860L/uImage\0" \ - "fdt_addr=40040000\0" \ - "kernel_addr=40060000\0" \ - "ramdisk_addr=40200000\0" \ - "u-boot=FPS860L/u-image.bin\0" \ - "load=tftp 200000 ${u-boot}\0" \ - "update=prot off 40000000 +${filesize};" \ - "era 40000000 +${filesize};" \ - "cp.b 200000 40000000 ${filesize};" \ - "sete filesize;save\0" \ - "" -#define CONFIG_BOOTCOMMAND "run flash_self" - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_NISDOMAIN -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_DNS -#define CONFIG_BOOTP_DNS2 -#define CONFIG_BOOTP_SEND_HOSTNAME -#define CONFIG_BOOTP_NTPSERVER -#define CONFIG_BOOTP_TIMEOFFSET - -#define CONFIG_RTC_MPC8xx /* use internal RTC of MPC8xx */ - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_NFS -#define CONFIG_CMD_SNTP - - -#define CONFIG_NETCONSOLE - - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ - -#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ -#define CONFIG_SYS_HUSH_PARSER 1 /* Use the HUSH parser */ - -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xFFF00000 - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0x40000000 -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * FLASH organization - */ - -/* use CFI flash driver */ -#define CONFIG_SYS_FLASH_CFI 1 /* Flash is CFI conformant */ -#define CONFIG_FLASH_CFI_DRIVER 1 /* Use the common driver */ -#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE+flash_info[0].size } -#define CONFIG_SYS_FLASH_EMPTY_INFO -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 71 /* max number of sectors on one chip */ - -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_OFFSET 0x8000 /* Offset of Environment Sector */ -#define CONFIG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */ - -/* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET+CONFIG_ENV_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) - -#define CONFIG_SYS_USE_PPCENV /* Environment embedded in sect .ppcenv */ - -#define CONFIG_MISC_INIT_R /* Make sure to remap flashes correctly */ - -/*----------------------------------------------------------------------- - * Dynamic MTD partition support - */ -#define CONFIG_CMD_MTDPARTS -#define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ -#define CONFIG_FLASH_CFI_MTD -#define MTDIDS_DEFAULT "nor0=TQM8xxL-0" - -#define MTDPARTS_DEFAULT "mtdparts=TQM8xxL-0:256k(u-boot)," \ - "128k(dtb)," \ - "1664k(kernel)," \ - "2m(rootfs)," \ - "4m(data)" - -/*----------------------------------------------------------------------- - * Hardware Information Block - */ -#define CONFIG_SYS_HWINFO_OFFSET 0x0003FFC0 /* offset of HW Info block */ -#define CONFIG_SYS_HWINFO_SIZE 0x00000040 /* size of HW Info block */ -#define CONFIG_SYS_HWINFO_MAGIC 0x54514D38 /* 'TQM8' */ - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CACHELINE_SHIFT 4 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 11-9 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Software & Bus Monitor Timer max, Bus Monitor enable, SW Watchdog freeze - */ -#if defined(CONFIG_WATCHDOG) -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | \ - SYPCR_SWE | SYPCR_SWRI| SYPCR_SWP) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | SYPCR_SWP) -#endif - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 11-6 - *----------------------------------------------------------------------- - * PCMCIA config., multi-function pin tri-state - */ -#define CONFIG_SYS_SIUMCR (SIUMCR_DBGC00 | SIUMCR_DBPC00 | SIUMCR_MLRC01) - -/*----------------------------------------------------------------------- - * TBSCR - Time Base Status and Control 11-26 - *----------------------------------------------------------------------- - * Clear Reference Interrupt Status, Timebase freezing enabled - */ -#define CONFIG_SYS_TBSCR (TBSCR_REFA | TBSCR_REFB | TBSCR_TBF) - -/*----------------------------------------------------------------------- - * RTCSC - Real-Time Clock Status and Control Register 11-27 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RTCSC (RTCSC_SEC | RTCSC_ALR | RTCSC_RTF| RTCSC_RTE) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 11-31 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Interrupt Timer freezing enabled - */ -#define CONFIG_SYS_PISCR (PISCR_PS | PISCR_PITF) - -/*----------------------------------------------------------------------- - * PLPRCR - PLL, Low-Power, and Reset Control Register 15-30 - *----------------------------------------------------------------------- - * Reset PLL lock status sticky bit, timer expired status bit and timer - * interrupt status bit - leave PLL multiplication factor unchanged ! - */ -#define CONFIG_SYS_PLPRCR (PLPRCR_SPLSS | PLPRCR_TEXPS | PLPRCR_TMIST) - -/*----------------------------------------------------------------------- - * SCCR - System Clock and reset Control Register 15-27 - *----------------------------------------------------------------------- - * Set clock output, timebase and RTC source and divider, - * power management and some other internal clocks - */ -#define SCCR_MASK SCCR_EBDF11 -#define CONFIG_SYS_SCCR (SCCR_TBS | \ - SCCR_COM00 | SCCR_DFSYNC00 | SCCR_DFBRG00 | \ - SCCR_DFNL000 | SCCR_DFNH000 | SCCR_DFLCD000 | \ - SCCR_DFALCD00) - -/*----------------------------------------------------------------------- - * PCMCIA stuff - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_PCMCIA_MEM_ADDR (0xE0000000) -#define CONFIG_SYS_PCMCIA_MEM_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_DMA_ADDR (0xE4000000) -#define CONFIG_SYS_PCMCIA_DMA_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_ATTRB_ADDR (0xE8000000) -#define CONFIG_SYS_PCMCIA_ATTRB_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_IO_ADDR (0xEC000000) -#define CONFIG_SYS_PCMCIA_IO_SIZE ( 64 << 20 ) - -/*----------------------------------------------------------------------- - * - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_DER 0 - -/* - * Init Memory Controller: - * - * BR0/1 and OR0/1 (FLASH) - */ - -#define FLASH_BASE0_PRELIM 0x40000000 /* FLASH bank #0 */ -#define FLASH_BASE1_PRELIM 0x60000000 /* FLASH bank #0 */ - -/* used to re-map FLASH both when starting from SRAM or FLASH: - * restrict access enough to keep SRAM working (if any) - * but not too much to meddle with FLASH accesses - */ -#define CONFIG_SYS_REMAP_OR_AM 0x80000000 /* OR addr mask */ -#define CONFIG_SYS_PRELIM_OR_AM 0xE0000000 /* OR addr mask */ - -/* - * FLASH timing: - */ -#define CONFIG_SYS_OR_TIMING_FLASH (OR_ACS_DIV1 | OR_TRLX | OR_CSNT_SAM | \ - OR_SCY_3_CLK | OR_EHTR | OR_BI) - -#define CONFIG_SYS_OR0_REMAP (CONFIG_SYS_REMAP_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_BR0_PRELIM ((FLASH_BASE0_PRELIM & BR_BA_MSK) | BR_V ) - -#define CONFIG_SYS_OR1_REMAP CONFIG_SYS_OR0_REMAP -#define CONFIG_SYS_OR1_PRELIM CONFIG_SYS_OR0_PRELIM -#define CONFIG_SYS_BR1_PRELIM ((FLASH_BASE1_PRELIM & BR_BA_MSK) | BR_V ) - -/* - * BR2/3 and OR2/3 (SDRAM) - * - */ -#define SDRAM_BASE2_PRELIM 0x00000000 /* SDRAM bank #0 */ -#define SDRAM_BASE3_PRELIM 0x20000000 /* SDRAM bank #1 */ -#define SDRAM_MAX_SIZE 0x04000000 /* max 64 MB per bank */ - -/* SDRAM timing: Multiplexed addresses, GPL5 output to GPL5_A (don't care) */ -#define CONFIG_SYS_OR_TIMING_SDRAM 0x00000A00 - -#define CONFIG_SYS_OR2_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_SDRAM ) -#define CONFIG_SYS_BR2_PRELIM ((SDRAM_BASE2_PRELIM & BR_BA_MSK) | BR_MS_UPMA | BR_V ) - -#define CONFIG_SYS_OR3_PRELIM CONFIG_SYS_OR2_PRELIM -#define CONFIG_SYS_BR3_PRELIM ((SDRAM_BASE3_PRELIM & BR_BA_MSK) | BR_MS_UPMA | BR_V ) - -/* - * Memory Periodic Timer Prescaler - * - * The Divider for PTA (refresh timer) configuration is based on an - * example SDRAM configuration (64 MBit, one bank). The adjustment to - * the number of chip selects (NCS) and the actually needed refresh - * rate is done by setting MPTPR. - * - * PTA is calculated from - * PTA = (gclk * Trefresh) / ((2 ^ (2 * DFBRG)) * PTP * NCS) - * - * gclk CPU clock (not bus clock!) - * Trefresh Refresh cycle * 4 (four word bursts used) - * - * 4096 Rows from SDRAM example configuration - * 1000 factor s -> ms - * 32 PTP (pre-divider from MPTPR) from SDRAM example configuration - * 4 Number of refresh cycles per period - * 64 Refresh cycle in ms per number of rows - * -------------------------------------------- - * Divider = 4096 * 32 * 1000 / (4 * 64) = 512000 - * - * 50 MHz => 50.000.000 / Divider = 98 - * 66 Mhz => 66.000.000 / Divider = 129 - * 80 Mhz => 80.000.000 / Divider = 156 - */ - -#define CONFIG_SYS_PTA_PER_CLK ((4096 * 32 * 1000) / (4 * 64)) -#define CONFIG_SYS_MAMR_PTA 98 - -/* - * For 16 MBit, refresh rates could be 31.3 us - * (= 64 ms / 2K = 125 / quad bursts). - * For a simpler initialization, 15.6 us is used instead. - * - * #define CONFIG_SYS_MPTPR_2BK_2K MPTPR_PTP_DIV32 for 2 banks - * #define CONFIG_SYS_MPTPR_1BK_2K MPTPR_PTP_DIV64 for 1 bank - */ -#define CONFIG_SYS_MPTPR_2BK_4K MPTPR_PTP_DIV16 /* setting for 2 banks */ -#define CONFIG_SYS_MPTPR_1BK_4K MPTPR_PTP_DIV32 /* setting for 1 bank */ - -/* refresh rate 7.8 us (= 64 ms / 8K = 31.2 / quad bursts) for 256 MBit */ -#define CONFIG_SYS_MPTPR_2BK_8K MPTPR_PTP_DIV8 /* setting for 2 banks */ -#define CONFIG_SYS_MPTPR_1BK_8K MPTPR_PTP_DIV16 /* setting for 1 bank */ - -/* - * MAMR settings for SDRAM - */ - -/* 8 column SDRAM */ -#define CONFIG_SYS_MAMR_8COL ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_0 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A11 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) -/* 9 column SDRAM */ -#define CONFIG_SYS_MAMR_9COL ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_1 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A10 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) - -#define CONFIG_SCC1_ENET - -/* pass open firmware flat tree */ -#define CONFIG_OF_LIBFDT 1 -#define CONFIG_OF_BOARD_SETUP 1 -#define CONFIG_HWCONFIG 1 - -#endif /* __CONFIG_H */ diff --git a/include/configs/NSCU.h b/include/configs/NSCU.h deleted file mode 100644 index a9c649a..0000000 --- a/include/configs/NSCU.h +++ /dev/null @@ -1,463 +0,0 @@ -/* - * (C) Copyright 2000-2008 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC855 1 /* This is a MPC855 CPU */ -#define CONFIG_TQM855M 1 /* ...on a TQM8xxM module */ -#define CONFIG_NSCU 1 - -#define CONFIG_SYS_TEXT_BASE 0x40000000 - -#define CONFIG_8xx_CONS_SCC1 1 /* Console is on SMC1 */ -#define CONFIG_SYS_SMC_RXBUFLEN 128 -#define CONFIG_SYS_MAXIDLE 10 - -#define CONFIG_66MHz 1 /* running at 66 MHz, 1:1 clock */ - -#define CONFIG_BAUDRATE 115200 /* console baudrate = 115kbps */ - -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ - -#define CONFIG_BOARD_TYPES 1 /* support board types */ - -#define CONFIG_PREBOOT "echo;" \ - "echo Type \"run flash_nfs\" to mount root filesystem over NFS;" \ - "echo" - -#undef CONFIG_BOOTARGS - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=eth0\0" \ - "nfsargs=setenv bootargs root=/dev/nfs rw " \ - "nfsroot=${serverip}:${rootpath}\0" \ - "ramargs=setenv bootargs root=/dev/ram rw\0" \ - "addip=setenv bootargs ${bootargs} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ - ":${hostname}:${netdev}:off panic=1\0" \ - "flash_nfs=run nfsargs addip;" \ - "bootm ${kernel_addr}\0" \ - "flash_self=run ramargs addip;" \ - "bootm ${kernel_addr} ${ramdisk_addr}\0" \ - "net_nfs=tftp 200000 ${bootfile};run nfsargs addip;bootm\0" \ - "rootpath=/opt/eldk/ppc_8xx\0" \ - "hostname=NSCU\0" \ - "bootfile=${hostname}/uImage\0" \ - "kernel_addr=40080000\0" \ - "ramdisk_addr=40180000\0" \ - "u-boot=${hostname}/u-image.bin\0" \ - "load=tftp 200000 ${u-boot}\0" \ - "update=prot off 40000000 +${filesize};" \ - "era 40000000 +${filesize};" \ - "cp.b 200000 40000000 ${filesize};" \ - "sete filesize;save\0" \ - "" -#define CONFIG_BOOTCOMMAND "run flash_self" - -#define CONFIG_MISC_INIT_R 1 - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -#define CONFIG_STATUS_LED 1 /* Status LED enabled */ - -#undef CONFIG_CAN_DRIVER /* CAN Driver support disabled */ - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE - - -#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - -#define CONFIG_RTC_MPC8xx /* use internal RTC of MPC8xx */ - -#define CONFIG_ISP1362_USB /* ISP1362 USB OTG controller */ - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_ELF -#define CONFIG_CMD_IDE -#define CONFIG_CMD_NFS -#define CONFIG_CMD_SNTP - - -#define CONFIG_NETCONSOLE - - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ - -#define CONFIG_CMDLINE_EDITING 1 /* add command line history -*/ -#define CONFIG_SYS_HUSH_PARSER 1 /* use "hush" command parser */ - -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xFFF00000 - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0x40000000 -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * FLASH organization - */ - -/* use CFI flash driver */ -#define CONFIG_SYS_FLASH_CFI 1 /* Flash is CFI conformant */ -#define CONFIG_FLASH_CFI_DRIVER 1 /* Use the common driver */ -#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE+flash_info[0].size } -#define CONFIG_SYS_FLASH_EMPTY_INFO -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 71 /* max number of sectors on one chip */ - -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_OFFSET 0x8000 /* Offset of Environment Sector */ -#define CONFIG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */ - -/* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET+CONFIG_ENV_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) - -#define CONFIG_SYS_USE_PPCENV /* Environment embedded in sect .ppcenv */ - -/*----------------------------------------------------------------------- - * Hardware Information Block - */ -#define CONFIG_SYS_HWINFO_OFFSET 0x0003FFC0 /* offset of HW Info block */ -#define CONFIG_SYS_HWINFO_SIZE 0x00000040 /* size of HW Info block */ -#define CONFIG_SYS_HWINFO_MAGIC 0x54514D38 /* 'TQM8' */ - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CACHELINE_SHIFT 4 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 11-9 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Software & Bus Monitor Timer max, Bus Monitor enable, SW Watchdog freeze - */ -#if defined(CONFIG_WATCHDOG) -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | \ - SYPCR_SWE | SYPCR_SWRI| SYPCR_SWP) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | SYPCR_SWP) -#endif - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 11-6 - *----------------------------------------------------------------------- - * PCMCIA config., multi-function pin tri-state - */ -#ifndef CONFIG_CAN_DRIVER -#define CONFIG_SYS_SIUMCR (SIUMCR_DBGC00 | SIUMCR_DBPC00 | SIUMCR_MLRC01) -#else /* we must activate GPL5 in the SIUMCR for CAN */ -#define CONFIG_SYS_SIUMCR (SIUMCR_DBGC11 | SIUMCR_DBPC00 | SIUMCR_MLRC01) -#endif /* CONFIG_CAN_DRIVER */ - -/*----------------------------------------------------------------------- - * TBSCR - Time Base Status and Control 11-26 - *----------------------------------------------------------------------- - * Clear Reference Interrupt Status, Timebase freezing enabled - */ -#define CONFIG_SYS_TBSCR (TBSCR_REFA | TBSCR_REFB | TBSCR_TBF) - -/*----------------------------------------------------------------------- - * RTCSC - Real-Time Clock Status and Control Register 11-27 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RTCSC (RTCSC_SEC | RTCSC_ALR | RTCSC_RTF| RTCSC_RTE) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 11-31 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Interrupt Timer freezing enabled - */ -#define CONFIG_SYS_PISCR (PISCR_PS | PISCR_PITF) - -/*----------------------------------------------------------------------- - * PLPRCR - PLL, Low-Power, and Reset Control Register 15-30 - *----------------------------------------------------------------------- - * Reset PLL lock status sticky bit, timer expired status bit and timer - * interrupt status bit - */ -#define CONFIG_SYS_PLPRCR (PLPRCR_SPLSS | PLPRCR_TEXPS | PLPRCR_TMIST) - -/*----------------------------------------------------------------------- - * SCCR - System Clock and reset Control Register 15-27 - *----------------------------------------------------------------------- - * Set clock output, timebase and RTC source and divider, - * power management and some other internal clocks - */ -#define SCCR_MASK SCCR_EBDF11 -#define CONFIG_SYS_SCCR (SCCR_COM00 | SCCR_DFSYNC00 | SCCR_DFBRG00 | \ - SCCR_DFNL000 | SCCR_DFNH000 | SCCR_DFLCD000 | \ - SCCR_DFALCD00) - -/*----------------------------------------------------------------------- - * PCMCIA stuff - *----------------------------------------------------------------------- - * - */ -/* NSCU use both slots, SLOT_A as "primary". */ -#define CONFIG_PCMCIA_SLOT_A 1 - -#define CONFIG_SYS_PCMCIA_MEM_ADDR (0xE0000000) -#define CONFIG_SYS_PCMCIA_MEM_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_DMA_ADDR (0xE4000000) -#define CONFIG_SYS_PCMCIA_DMA_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_ATTRB_ADDR (0xE8000000) -#define CONFIG_SYS_PCMCIA_ATTRB_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_IO_ADDR (0xEC000000) -#define CONFIG_SYS_PCMCIA_IO_SIZE ( 64 << 20 ) -#define PCMCIA_MEM_WIN_NO 8 /* override default 4 in pcmcia.h */ -#define PCMCIA_SOCKETS_NO 2 /* we have two sockets */ -#undef NSCU_OE_INV /* PCMCIA_GCRX_CXOE was inverted on early boards */ - -/*----------------------------------------------------------------------- - * IDE/ATA stuff (Supports IDE harddisk on PCMCIA Adapter) - *----------------------------------------------------------------------- - */ - -#define CONFIG_IDE_PREINIT 1 /* Use preinit IDE hook */ -#define CONFIG_IDE_8xx_PCCARD 1 /* Use IDE with PC Card Adapter */ - -#undef CONFIG_IDE_8xx_DIRECT /* Direct IDE not supported */ -#undef CONFIG_IDE_LED /* LED for ide not supported */ -#undef CONFIG_IDE_RESET /* reset for ide not supported */ - -#define CONFIG_SYS_IDE_MAXBUS 2 /* max. 2 IDE buses */ -#define CONFIG_SYS_IDE_MAXDEVICE 4 /* max. 2 drives per IDE bus */ - -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 -#define CONFIG_SYS_ATA_IDE1_OFFSET (4 * CONFIG_SYS_PCMCIA_MEM_SIZE) /* starts @ 4th window */ - -#define CONFIG_SYS_ATA_BASE_ADDR CONFIG_SYS_PCMCIA_MEM_ADDR - -/* Offset for data I/O */ -#define CONFIG_SYS_ATA_DATA_OFFSET (CONFIG_SYS_PCMCIA_MEM_SIZE + 0x320) - -/* Offset for normal register accesses */ -#define CONFIG_SYS_ATA_REG_OFFSET (2 * CONFIG_SYS_PCMCIA_MEM_SIZE + 0x320) - -/* Offset for alternate registers */ -#define CONFIG_SYS_ATA_ALT_OFFSET 0x0100 - -/*----------------------------------------------------------------------- - * - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_DER 0 - -/* - * Init Memory Controller: - * - * BR0/1 and OR0/1 (FLASH) - */ - -#define FLASH_BASE0_PRELIM 0x40000000 /* FLASH bank #0 */ -#define FLASH_BASE1_PRELIM 0x60000000 /* FLASH bank #0 */ - -/* used to re-map FLASH both when starting from SRAM or FLASH: - * restrict access enough to keep SRAM working (if any) - * but not too much to meddle with FLASH accesses - */ -#define CONFIG_SYS_REMAP_OR_AM 0x80000000 /* OR addr mask */ -#define CONFIG_SYS_PRELIM_OR_AM 0xE0000000 /* OR addr mask */ - -/* - * FLASH timing: - */ -#define CONFIG_SYS_OR_TIMING_FLASH (OR_ACS_DIV1 | OR_TRLX | OR_CSNT_SAM | \ - OR_SCY_3_CLK | OR_EHTR | OR_BI) - -#define CONFIG_SYS_OR0_REMAP (CONFIG_SYS_REMAP_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_BR0_PRELIM ((FLASH_BASE0_PRELIM & BR_BA_MSK) | BR_V ) - -#define CONFIG_SYS_OR1_REMAP CONFIG_SYS_OR0_REMAP -#define CONFIG_SYS_OR1_PRELIM CONFIG_SYS_OR0_PRELIM -#define CONFIG_SYS_BR1_PRELIM ((FLASH_BASE1_PRELIM & BR_BA_MSK) | BR_V ) - -/* - * BR2/3 and OR2/3 (SDRAM) - * - */ -#define SDRAM_BASE2_PRELIM 0x00000000 /* SDRAM bank #0 */ -#define SDRAM_BASE3_PRELIM 0x20000000 /* SDRAM bank #1 */ -#define SDRAM_MAX_SIZE 0x04000000 /* max 64 MB per bank */ - -/* SDRAM timing: Multiplexed addresses, GPL5 output to GPL5_A (don't care) */ -#define CONFIG_SYS_OR_TIMING_SDRAM 0x00000A00 - -#define CONFIG_SYS_OR2_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_SDRAM ) -#define CONFIG_SYS_BR2_PRELIM ((SDRAM_BASE2_PRELIM & BR_BA_MSK) | BR_MS_UPMA | BR_V ) - -#ifndef CONFIG_CAN_DRIVER -#define CONFIG_SYS_OR3_PRELIM CONFIG_SYS_OR2_PRELIM -#define CONFIG_SYS_BR3_PRELIM ((SDRAM_BASE3_PRELIM & BR_BA_MSK) | BR_MS_UPMA | BR_V ) -#else /* CAN uses CS3#, so we can have only one SDRAM bank anyway */ -#define CONFIG_SYS_CAN_BASE 0xC0000000 /* CAN mapped at 0xC0000000 */ -#define CONFIG_SYS_CAN_OR_AM 0xFFFF8000 /* 32 kB address mask */ -#define CONFIG_SYS_OR3_CAN (CONFIG_SYS_CAN_OR_AM | OR_G5LA | OR_BI) -#define CONFIG_SYS_BR3_CAN ((CONFIG_SYS_CAN_BASE & BR_BA_MSK) | \ - BR_PS_8 | BR_MS_UPMB | BR_V ) -#endif /* CONFIG_CAN_DRIVER */ - -#ifdef CONFIG_ISP1362_USB -#define CONFIG_SYS_ISP1362_BASE 0xD0000000 /* ISP1362 mapped at 0xD0000000 */ -#define CONFIG_SYS_ISP1362_OR_AM 0xFFFF8000 /* 32 kB address mask */ -#define CONFIG_SYS_OR5_ISP1362 (CONFIG_SYS_ISP1362_OR_AM | OR_CSNT_SAM | \ - OR_ACS_DIV2 | OR_BI | OR_SCY_5_CLK) -#define CONFIG_SYS_BR5_ISP1362 ((CONFIG_SYS_ISP1362_BASE & BR_BA_MSK) | \ - BR_PS_16 | BR_MS_GPCM | BR_V ) -#endif /* CONFIG_ISP1362_USB */ - -/* - * Memory Periodic Timer Prescaler - * - * The Divider for PTA (refresh timer) configuration is based on an - * example SDRAM configuration (64 MBit, one bank). The adjustment to - * the number of chip selects (NCS) and the actually needed refresh - * rate is done by setting MPTPR. - * - * PTA is calculated from - * PTA = (gclk * Trefresh) / ((2 ^ (2 * DFBRG)) * PTP * NCS) - * - * gclk CPU clock (not bus clock!) - * Trefresh Refresh cycle * 4 (four word bursts used) - * - * 4096 Rows from SDRAM example configuration - * 1000 factor s -> ms - * 32 PTP (pre-divider from MPTPR) from SDRAM example configuration - * 4 Number of refresh cycles per period - * 64 Refresh cycle in ms per number of rows - * -------------------------------------------- - * Divider = 4096 * 32 * 1000 / (4 * 64) = 512000 - * - * 50 MHz => 50.000.000 / Divider = 98 - * 66 Mhz => 66.000.000 / Divider = 129 - * 80 Mhz => 80.000.000 / Divider = 156 - */ - -#define CONFIG_SYS_PTA_PER_CLK ((4096 * 32 * 1000) / (4 * 64)) -#define CONFIG_SYS_MAMR_PTA 98 - -/* - * For 16 MBit, refresh rates could be 31.3 us - * (= 64 ms / 2K = 125 / quad bursts). - * For a simpler initialization, 15.6 us is used instead. - * - * #define CONFIG_SYS_MPTPR_2BK_2K MPTPR_PTP_DIV32 for 2 banks - * #define CONFIG_SYS_MPTPR_1BK_2K MPTPR_PTP_DIV64 for 1 bank - */ -#define CONFIG_SYS_MPTPR_2BK_4K MPTPR_PTP_DIV16 /* setting for 2 banks */ -#define CONFIG_SYS_MPTPR_1BK_4K MPTPR_PTP_DIV32 /* setting for 1 bank */ - -/* refresh rate 7.8 us (= 64 ms / 8K = 31.2 / quad bursts) for 256 MBit */ -#define CONFIG_SYS_MPTPR_2BK_8K MPTPR_PTP_DIV8 /* setting for 2 banks */ -#define CONFIG_SYS_MPTPR_1BK_8K MPTPR_PTP_DIV16 /* setting for 1 bank */ - -/* - * MAMR settings for SDRAM - */ - -/* 8 column SDRAM */ -#define CONFIG_SYS_MAMR_8COL ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_0 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A11 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) -/* 9 column SDRAM */ -#define CONFIG_SYS_MAMR_9COL ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_1 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A10 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) - -#undef CONFIG_SCC1_ENET -#define CONFIG_FEC_ENET - -/* pass open firmware flat tree */ -#define CONFIG_OF_LIBFDT 1 -#define CONFIG_OF_BOARD_SETUP 1 -#define CONFIG_HWCONFIG 1 - -#endif /* __CONFIG_H */ diff --git a/include/configs/SM850.h b/include/configs/SM850.h deleted file mode 100644 index a7e4464..0000000 --- a/include/configs/SM850.h +++ /dev/null @@ -1,351 +0,0 @@ -/* - * (C) Copyright 2000-2008 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -#undef TQM8xxL_80MHz /* 1 / * define for 80 MHz CPU only */ - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC850 1 /* This is a MPC850 CPU */ -#define CONFIG_SM850 1 /*...on a MPC850 Service Module */ - -#define CONFIG_SYS_TEXT_BASE 0x40000000 - -#define CONFIG_8xx_CONS_SMC2 1 /* Console is on SMC2 */ -#define CONFIG_SYS_SMC_RXBUFLEN 128 -#define CONFIG_SYS_MAXIDLE 10 -#define CONFIG_BAUDRATE 115200 -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ - -#define CONFIG_CLOCKS_IN_MHZ 1 /* clocks passsed to Linux in MHz */ - -#define CONFIG_BOARD_TYPES 1 /* support board types */ - -#undef CONFIG_BOOTARGS -#define CONFIG_BOOTCOMMAND \ - "bootp; " \ - "setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off; " \ - "bootm" - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -#undef CONFIG_STATUS_LED /* Status LED not enabled */ - -#undef CONFIG_CAN_DRIVER /* CAN Driver support disabled */ - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE - - -#define CONFIG_RTC_MPC8xx /* use internal RTC of MPC8xx */ - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_DATE - - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#if defined(CONFIG_CMD_KGDB) && defined(KGDB_DEBUG) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xFFF00000 - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0x40000000 -#if defined(DEBUG) -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#else -#define CONFIG_SYS_MONITOR_LEN (192 << 10) /* Reserve 192 kB for Monitor */ -#endif -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * FLASH organization - */ -/* use CFI flash driver */ -#define CONFIG_SYS_FLASH_CFI 1 /* Flash is CFI conformant */ -#define CONFIG_FLASH_CFI_DRIVER 1 /* Use the common driver */ -#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE+flash_info[0].size } -#define CONFIG_SYS_FLASH_EMPTY_INFO -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 71 /* max number of sectors on one chip */ - -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_OFFSET 0x8000 /* Offset of Environment Sector */ -#define CONFIG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */ - -#define CONFIG_MISC_INIT_R /* Make sure to remap flashes correctly */ - -/*----------------------------------------------------------------------- - * Hardware Information Block - */ -#define CONFIG_SYS_HWINFO_OFFSET 0x0003FFC0 /* offset of HW Info block */ -#define CONFIG_SYS_HWINFO_SIZE 0x00000040 /* size of HW Info block */ -#define CONFIG_SYS_HWINFO_MAGIC 0x54514D38 /* 'TQM8' */ - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CACHELINE_SHIFT 4 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 11-9 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Software & Bus Monitor Timer max, Bus Monitor enable, SW Watchdog freeze - */ -#if defined(CONFIG_WATCHDOG) -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | \ - SYPCR_SWE | SYPCR_SWRI| SYPCR_SWP) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | SYPCR_SWP) -#endif - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 11-6 - *----------------------------------------------------------------------- - * PCMCIA config., multi-function pin tri-state - */ -#ifndef CONFIG_CAN_DRIVER -#define CONFIG_SYS_SIUMCR (SIUMCR_DBGC00 | SIUMCR_DBPC00 | SIUMCR_MLRC01) -#else /* we must activate GPL5 in the SIUMCR for CAN */ -#define CONFIG_SYS_SIUMCR (SIUMCR_DBGC11 | SIUMCR_DBPC00 | SIUMCR_MLRC01) -#endif /* CONFIG_CAN_DRIVER */ - -/*----------------------------------------------------------------------- - * TBSCR - Time Base Status and Control 11-26 - *----------------------------------------------------------------------- - * Clear Reference Interrupt Status, Timebase freezing enabled - */ -#define CONFIG_SYS_TBSCR (TBSCR_REFA | TBSCR_REFB | TBSCR_TBF) - -/*----------------------------------------------------------------------- - * RTCSC - Real-Time Clock Status and Control Register 11-27 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RTCSC (RTCSC_SEC | RTCSC_ALR | RTCSC_RTF| RTCSC_RTE) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 11-31 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Interrupt Timer freezing enabled - */ -#define CONFIG_SYS_PISCR (PISCR_PS | PISCR_PITF) - -/*----------------------------------------------------------------------- - * PLPRCR - PLL, Low-Power, and Reset Control Register 15-30 - *----------------------------------------------------------------------- - * Reset PLL lock status sticky bit, timer expired status bit and timer - * interrupt status bit - * - * If this is a 80 MHz CPU, set PLL multiplication factor to 5 (5*16=80)! - */ -#ifdef TQM8xxL_80MHz /* for 80 MHz, we use a 16 MHz clock * 5 */ -#define CONFIG_SYS_PLPRCR \ - ( (5-1)<<PLPRCR_MF_SHIFT | PLPRCR_TEXPS | PLPRCR_TMIST ) -#else -#define CONFIG_SYS_PLPRCR (PLPRCR_SPLSS | PLPRCR_TEXPS | PLPRCR_TMIST) -#endif /* TQM8xxL_80MHz */ - -/*----------------------------------------------------------------------- - * SCCR - System Clock and reset Control Register 15-27 - *----------------------------------------------------------------------- - * Set clock output, timebase and RTC source and divider, - * power management and some other internal clocks - */ -#define SCCR_MASK SCCR_EBDF11 -#ifdef TQM8xxL_80MHz /* for 80 MHz, we use a 16 MHz clock * 5 */ -#define CONFIG_SYS_SCCR (/* SCCR_TBS | */ \ - SCCR_COM00 | SCCR_DFSYNC00 | SCCR_DFBRG00 | \ - SCCR_DFNL000 | SCCR_DFNH000 | SCCR_DFLCD000 | \ - SCCR_DFALCD00) -#else /* up to 50 MHz we use a 1:1 clock */ -#define CONFIG_SYS_SCCR (SCCR_TBS | \ - SCCR_COM00 | SCCR_DFSYNC00 | SCCR_DFBRG00 | \ - SCCR_DFNL000 | SCCR_DFNH000 | SCCR_DFLCD000 | \ - SCCR_DFALCD00) -#endif /* TQM8xxL_80MHz */ - -/*----------------------------------------------------------------------- - * PCMCIA stuff - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_PCMCIA_MEM_ADDR (0xE0000000) -#define CONFIG_SYS_PCMCIA_MEM_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_DMA_ADDR (0xE4000000) -#define CONFIG_SYS_PCMCIA_DMA_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_ATTRB_ADDR (0xE8000000) -#define CONFIG_SYS_PCMCIA_ATTRB_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_IO_ADDR (0xEC000000) -#define CONFIG_SYS_PCMCIA_IO_SIZE ( 64 << 20 ) - -/*----------------------------------------------------------------------- - * - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_DER 0 - -/* - * Init Memory Controller: - * - * BR0/1 and OR0/1 (FLASH) - */ - -#define FLASH_BASE0_PRELIM 0x40000000 /* FLASH bank #0 */ -#define FLASH_BASE1_PRELIM 0x60000000 /* FLASH bank #0 */ - -/* used to re-map FLASH both when starting from SRAM or FLASH: - * restrict access enough to keep SRAM working (if any) - * but not too much to meddle with FLASH accesses - */ -#define CONFIG_SYS_REMAP_OR_AM 0x80000000 /* OR addr mask */ -#define CONFIG_SYS_PRELIM_OR_AM 0xE0000000 /* OR addr mask */ - -/* FLASH timing: ACS = 11, TRLX = 0, CSNT = 1, SCY = 5, EHTR = 1 */ -#define CONFIG_SYS_OR_TIMING_FLASH (OR_CSNT_SAM | OR_ACS_DIV2 | OR_BI | \ - OR_SCY_5_CLK | OR_EHTR) - -#define CONFIG_SYS_OR0_REMAP (CONFIG_SYS_REMAP_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_BR0_PRELIM ((FLASH_BASE0_PRELIM & BR_BA_MSK) | BR_V ) - -#define CONFIG_SYS_OR1_REMAP CONFIG_SYS_OR0_REMAP -#define CONFIG_SYS_OR1_PRELIM CONFIG_SYS_OR0_PRELIM -#define CONFIG_SYS_BR1_PRELIM ((FLASH_BASE1_PRELIM & BR_BA_MSK) | BR_V ) - -/* - * BR2/3 and OR2/3 (SDRAM) - * - */ -#define SDRAM_BASE2_PRELIM 0x00000000 /* SDRAM bank #0 */ -#define SDRAM_BASE3_PRELIM 0x20000000 /* SDRAM bank #1 */ -#define SDRAM_MAX_SIZE 0x04000000 /* max 64 MB per bank */ - -/* SDRAM timing: Multiplexed addresses, GPL5 output to GPL5_A (don't care) */ -#define CONFIG_SYS_OR_TIMING_SDRAM 0x00000A00 - -#define CONFIG_SYS_OR2_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_SDRAM ) -#define CONFIG_SYS_BR2_PRELIM ((SDRAM_BASE2_PRELIM & BR_BA_MSK) | BR_MS_UPMA | BR_V ) - -#ifndef CONFIG_CAN_DRIVER -#define CONFIG_SYS_OR3_PRELIM CONFIG_SYS_OR2_PRELIM -#define CONFIG_SYS_BR3_PRELIM ((SDRAM_BASE3_PRELIM & BR_BA_MSK) | BR_MS_UPMA | BR_V ) -#else /* CAN uses CS3#, so we can have only one SDRAM bank anyway */ -#define CONFIG_SYS_CAN_BASE 0xC0000000 /* CAN mapped at 0xC0000000 */ -#define CONFIG_SYS_CAN_OR_AM 0xFFFF8000 /* 32 kB address mask */ -#define CONFIG_SYS_OR3_CAN (CONFIG_SYS_CAN_OR_AM | OR_G5LA | OR_BI) -#define CONFIG_SYS_BR3_CAN ((CONFIG_SYS_CAN_BASE & BR_BA_MSK) | \ - BR_PS_8 | BR_MS_UPMB | BR_V ) -#endif /* CONFIG_CAN_DRIVER */ - -/* - * Memory Periodic Timer Prescaler - */ - -/* periodic timer for refresh */ -#define CONFIG_SYS_MAMR_PTA 97 /* start with divider for 100 MHz */ - -/* refresh rate 15.6 us (= 64 ms / 4K = 62.4 / quad bursts) for <= 128 MBit */ -#define CONFIG_SYS_MPTPR_2BK_4K MPTPR_PTP_DIV16 /* setting for 2 banks */ -#define CONFIG_SYS_MPTPR_1BK_4K MPTPR_PTP_DIV32 /* setting for 1 bank */ - -/* refresh rate 7.8 us (= 64 ms / 8K = 31.2 / quad bursts) for 256 MBit */ -#define CONFIG_SYS_MPTPR_2BK_8K MPTPR_PTP_DIV8 /* setting for 2 banks */ -#define CONFIG_SYS_MPTPR_1BK_8K MPTPR_PTP_DIV16 /* setting for 1 bank */ - -/* - * MAMR settings for SDRAM - */ - -/* 8 column SDRAM */ -#define CONFIG_SYS_MAMR_8COL ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_0 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A11 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) -/* 9 column SDRAM */ -#define CONFIG_SYS_MAMR_9COL ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_1 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A10 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) - -/* pass open firmware flat tree */ -#define CONFIG_OF_LIBFDT 1 -#define CONFIG_OF_BOARD_SETUP 1 -#define CONFIG_HWCONFIG 1 - -#endif /* __CONFIG_H */ diff --git a/include/configs/TK885D.h b/include/configs/TK885D.h deleted file mode 100644 index 5e1c52d..0000000 --- a/include/configs/TK885D.h +++ /dev/null @@ -1,490 +0,0 @@ -/* - * (C) Copyright 2000-2005 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * (C) Copyright 2006 - * Martin Krause, TQ-Systems GmBH, martin.krause@tqs.de - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC885 1 /* This is a MPC885 CPU */ -#define CONFIG_TQM885D 1 /* ...on a TQM88D module */ -#define CONFIG_TK885D 1 /* ...in a TK885D base board */ - -#define CONFIG_SYS_TEXT_BASE 0x40000000 - -#define CONFIG_8xx_OSCLK 10000000 /* 10 MHz - PLL input clock */ -#define CONFIG_SYS_8xx_CPUCLK_MIN 15000000 /* 15 MHz - CPU minimum clock */ -#define CONFIG_SYS_8xx_CPUCLK_MAX 133000000 /* 133 MHz - CPU maximum clock */ -#define CONFIG_8xx_CPUCLK_DEFAULT 66000000 /* 66 MHz - CPU default clock */ - /* (it will be used if there is no */ - /* 'cpuclk' variable with valid value) */ - -#define CONFIG_8xx_CONS_SMC1 1 /* Console is on SMC1 */ -#define CONFIG_SYS_SMC_RXBUFLEN 128 -#define CONFIG_SYS_MAXIDLE 10 -#define CONFIG_BAUDRATE 115200 /* console baudrate = 115kbps */ - -#define CONFIG_BOOTCOUNT_LIMIT - -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ - -#define CONFIG_BOARD_TYPES 1 /* support board types */ - -#define CONFIG_PREBOOT "echo;" \ - "echo Type \"run flash_nfs\" to mount root filesystem over NFS;" \ - "echo" - -#undef CONFIG_BOOTARGS - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "ethprime=FEC\0" \ - "ethact=FEC\0" \ - "netdev=eth0\0" \ - "nfsargs=setenv bootargs root=/dev/nfs rw " \ - "nfsroot=${serverip}:${rootpath}\0" \ - "ramargs=setenv bootargs root=/dev/ram rw\0" \ - "addip=setenv bootargs ${bootargs} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ - ":${hostname}:${netdev}:off panic=1\0" \ - "flash_nfs=run nfsargs addip;" \ - "bootm ${kernel_addr}\0" \ - "flash_self=run ramargs addip;" \ - "bootm ${kernel_addr} ${ramdisk_addr}\0" \ - "net_nfs=tftp 200000 ${bootfile};run nfsargs addip;bootm\0" \ - "rootpath=/opt/eldk/ppc_8xx\0" \ - "bootfile=/tftpboot/tk885d/uImage\0" \ - "u-boot=/tftpboot/tk885d/u-boot.bin\0" \ - "kernel_addr=40080000\0" \ - "ramdisk_addr=40180000\0" \ - "load=tftp 200000 ${u-boot}\0" \ - "update=protect off 40000000 +${filesize};" \ - "erase 40000000 +${filesize};" \ - "cp.b 200000 40000000 ${filesize};" \ - "protect on 40000000 +${filesize}\0" \ - "" -#define CONFIG_BOOTCOMMAND "run flash_self" - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -#define CONFIG_STATUS_LED 1 /* Status LED enabled */ - -#undef CONFIG_CAN_DRIVER /* CAN Driver support disabled */ - -/* enable I2C and select the hardware/software driver */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_SOFT /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SOFT_SPEED 93000 /* 93 kHz is supposed to work */ -#define CONFIG_SYS_I2C_SOFT_SLAVE 0xFE -/* - * Software (bit-bang) I2C driver configuration - */ -#define PB_SCL 0x00000020 /* PB 26 */ -#define PB_SDA 0x00000010 /* PB 27 */ - -#define I2C_INIT (immr->im_cpm.cp_pbdir |= PB_SCL) -#define I2C_ACTIVE (immr->im_cpm.cp_pbdir |= PB_SDA) -#define I2C_TRISTATE (immr->im_cpm.cp_pbdir &= ~PB_SDA) -#define I2C_READ ((immr->im_cpm.cp_pbdat & PB_SDA) != 0) -#define I2C_SDA(bit) if(bit) immr->im_cpm.cp_pbdat |= PB_SDA; \ - else immr->im_cpm.cp_pbdat &= ~PB_SDA -#define I2C_SCL(bit) if(bit) immr->im_cpm.cp_pbdat |= PB_SCL; \ - else immr->im_cpm.cp_pbdat &= ~PB_SCL -#define I2C_DELAY udelay(2) /* 1/4 I2C clock duration */ - -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* EEPROM AT24C?? */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 /* two byte address */ -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ - -# define CONFIG_RTC_DS1337 1 -# define CONFIG_SYS_I2C_RTC_ADDR 0x68 - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE - - -#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - -#undef CONFIG_RTC_MPC8xx /* MPC885 does not support RTC */ - -#define CONFIG_TIMESTAMP /* but print image timestmps */ - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C -#define CONFIG_CMD_IDE -#define CONFIG_CMD_MII -#define CONFIG_CMD_NFS -#define CONFIG_CMD_PING - - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ - -#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ -#define CONFIG_SYS_HUSH_PARSER 1 /* Use the HUSH parser */ - -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x0100000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0300000 /* 1 ... 3 MB in DRAM */ -#define CONFIG_SYS_ALT_MEMTEST /* alternate, more extensive - memory test.*/ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -/* - * Enable loopw command. - */ -#define CONFIG_LOOPW - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xFFF00000 - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0x40000000 -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MALLOC_LEN (256 << 10) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * FLASH organization - */ - -/* use CFI flash driver */ -#define CONFIG_SYS_FLASH_CFI 1 /* Flash is CFI conformant */ -#define CONFIG_FLASH_CFI_DRIVER 1 /* Use the common driver */ -#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } -#define CONFIG_SYS_FLASH_EMPTY_INFO -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 256 /* max number of sectors on one chip */ - -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_OFFSET 0x40000 /* Offset of Environment Sector */ -#define CONFIG_ENV_SIZE 0x08000 /* Total Size of Environment */ -#define CONFIG_ENV_SECT_SIZE 0x40000 /* Total Size of Environment Sector */ - -/* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET+CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) - -/*----------------------------------------------------------------------- - * Hardware Information Block - */ -#define CONFIG_SYS_HWINFO_OFFSET 0x0003FFC0 /* offset of HW Info block */ -#define CONFIG_SYS_HWINFO_SIZE 0x00000040 /* size of HW Info block */ -#define CONFIG_SYS_HWINFO_MAGIC 0x54514D38 /* 'TQM8' */ - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CACHELINE_SHIFT 4 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 11-9 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Software & Bus Monitor Timer max, Bus Monitor enable, SW Watchdog freeze - */ -#if defined(CONFIG_WATCHDOG) -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | \ - SYPCR_SWE | SYPCR_SWRI| SYPCR_SWP) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | SYPCR_SWP) -#endif - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 11-6 - *----------------------------------------------------------------------- - * PCMCIA config., multi-function pin tri-state - */ -#ifndef CONFIG_CAN_DRIVER -#define CONFIG_SYS_SIUMCR (SIUMCR_DBGC00 | SIUMCR_DBPC00 | SIUMCR_MLRC01) -#else /* we must activate GPL5 in the SIUMCR for CAN */ -#define CONFIG_SYS_SIUMCR (SIUMCR_DBGC11 | SIUMCR_DBPC00 | SIUMCR_MLRC01) -#endif /* CONFIG_CAN_DRIVER */ - -/*----------------------------------------------------------------------- - * TBSCR - Time Base Status and Control 11-26 - *----------------------------------------------------------------------- - * Clear Reference Interrupt Status, Timebase freezing enabled - */ -#define CONFIG_SYS_TBSCR (TBSCR_REFA | TBSCR_REFB | TBSCR_TBF) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 11-31 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Interrupt Timer freezing enabled - */ -#define CONFIG_SYS_PISCR (PISCR_PS | PISCR_PITF) - -/*----------------------------------------------------------------------- - * SCCR - System Clock and reset Control Register 15-27 - *----------------------------------------------------------------------- - * Set clock output, timebase and RTC source and divider, - * power management and some other internal clocks - */ -#define SCCR_MASK SCCR_EBDF11 -#define CONFIG_SYS_SCCR (SCCR_COM00 | SCCR_DFSYNC00 | SCCR_DFBRG00 | \ - SCCR_DFNL000 | SCCR_DFNH000 | SCCR_DFLCD000 | \ - SCCR_DFALCD00) - -/*----------------------------------------------------------------------- - * PCMCIA stuff - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_PCMCIA_MEM_ADDR (0xE0000000) -#define CONFIG_SYS_PCMCIA_MEM_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_DMA_ADDR (0xE4000000) -#define CONFIG_SYS_PCMCIA_DMA_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_ATTRB_ADDR (0xE8000000) -#define CONFIG_SYS_PCMCIA_ATTRB_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_IO_ADDR (0xEC000000) -#define CONFIG_SYS_PCMCIA_IO_SIZE ( 64 << 20 ) - -/*----------------------------------------------------------------------- - * IDE/ATA stuff (Supports IDE harddisk on PCMCIA Adapter) - *----------------------------------------------------------------------- - */ - -#define CONFIG_IDE_PREINIT 1 /* Use preinit IDE hook */ -#define CONFIG_IDE_8xx_PCCARD 1 /* Use IDE with PC Card Adapter */ - -#undef CONFIG_IDE_8xx_DIRECT /* Direct IDE not supported */ -#undef CONFIG_IDE_LED /* LED for ide not supported */ -#undef CONFIG_IDE_RESET /* reset for ide not supported */ - -#define CONFIG_SYS_IDE_MAXBUS 1 /* max. 1 IDE bus */ -#define CONFIG_SYS_IDE_MAXDEVICE 1 /* max. 1 drive per IDE bus */ - -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 - -#define CONFIG_SYS_ATA_BASE_ADDR CONFIG_SYS_PCMCIA_MEM_ADDR - -/* Offset for data I/O */ -#define CONFIG_SYS_ATA_DATA_OFFSET (CONFIG_SYS_PCMCIA_MEM_SIZE + 0x320) - -/* Offset for normal register accesses */ -#define CONFIG_SYS_ATA_REG_OFFSET (2 * CONFIG_SYS_PCMCIA_MEM_SIZE + 0x320) - -/* Offset for alternate registers */ -#define CONFIG_SYS_ATA_ALT_OFFSET 0x0100 - -/*----------------------------------------------------------------------- - * - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_DER 0 - -/* - * Init Memory Controller: - * - * BR0/1 and OR0/1 (FLASH) - */ - -#define FLASH_BASE0_PRELIM 0x40000000 /* FLASH bank #0 */ -#define FLASH_BASE1_PRELIM 0x60000000 /* FLASH bank #0 */ - -/* used to re-map FLASH both when starting from SRAM or FLASH: - * restrict access enough to keep SRAM working (if any) - * but not too much to meddle with FLASH accesses - */ -#define CONFIG_SYS_REMAP_OR_AM 0x80000000 /* OR addr mask */ -#define CONFIG_SYS_PRELIM_OR_AM 0xE0000000 /* OR addr mask */ - -/* - * FLASH timing: Default value of OR0 after reset - */ -#define CONFIG_SYS_OR_TIMING_FLASH (OR_CSNT_SAM | OR_ACS_MSK | OR_BI | \ - OR_SCY_6_CLK | OR_TRLX) - -#define CONFIG_SYS_OR0_REMAP (CONFIG_SYS_REMAP_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_BR0_PRELIM ((FLASH_BASE0_PRELIM & BR_BA_MSK) | BR_V ) - -#define CONFIG_SYS_OR1_REMAP CONFIG_SYS_OR0_REMAP -#define CONFIG_SYS_OR1_PRELIM CONFIG_SYS_OR0_PRELIM -#define CONFIG_SYS_BR1_PRELIM ((FLASH_BASE1_PRELIM & BR_BA_MSK) | BR_V ) - -/* - * BR2/3 and OR2/3 (SDRAM) - * - */ -#define SDRAM_BASE2_PRELIM 0x00000000 /* SDRAM bank #0 */ -#define SDRAM_BASE3_PRELIM 0x20000000 /* SDRAM bank #1 */ -#define SDRAM_MAX_SIZE (256 << 20) /* max 256 MB per bank */ - -/* SDRAM timing: Multiplexed addresses, GPL5 output to GPL5_A (don't care) */ -#define CONFIG_SYS_OR_TIMING_SDRAM 0x00000A00 - -#define CONFIG_SYS_OR2_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_SDRAM ) -#define CONFIG_SYS_BR2_PRELIM ((SDRAM_BASE2_PRELIM & BR_BA_MSK) | BR_MS_UPMA | BR_V ) - -#ifndef CONFIG_CAN_DRIVER -#define CONFIG_SYS_OR3_PRELIM CONFIG_SYS_OR2_PRELIM -#define CONFIG_SYS_BR3_PRELIM ((SDRAM_BASE3_PRELIM & BR_BA_MSK) | BR_MS_UPMA | BR_V ) -#else /* CAN uses CS3#, so we can have only one SDRAM bank anyway */ -#define CONFIG_SYS_CAN_BASE 0xC0000000 /* CAN mapped at 0xC0000000 */ -#define CONFIG_SYS_CAN_OR_AM 0xFFFF8000 /* 32 kB address mask */ -#define CONFIG_SYS_OR3_CAN (CONFIG_SYS_CAN_OR_AM | OR_G5LA | OR_BI) -#define CONFIG_SYS_BR3_CAN ((CONFIG_SYS_CAN_BASE & BR_BA_MSK) | \ - BR_PS_8 | BR_MS_UPMB | BR_V ) -#endif /* CONFIG_CAN_DRIVER */ - -/* - * 4096 Rows from SDRAM example configuration - * 1000 factor s -> ms - * 64 PTP (pre-divider from MPTPR) from SDRAM example configuration - * 4 Number of refresh cycles per period - * 64 Refresh cycle in ms per number of rows - */ -#define CONFIG_SYS_PTA_PER_CLK ((4096 * 64 * 1000) / (4 * 64)) - -/* - * Periodic timer (MAMR[PTx]) for 4 * 7.8 us refresh (= 31.2 us per quad) - * - * CPUclock(MHz) * 31.2 - * CONFIG_SYS_MAMR_PTA = ----------------------------------- with DFBRG = 0 - * 2^(2*SCCR[DFBRG]) * MPTPR_PTP_DIV16 - * - * CPU clock = 15 MHz: CONFIG_SYS_MAMR_PTA = 29 -> 4 * 7.73 us - * CPU clock = 50 MHz: CONFIG_SYS_MAMR_PTA = 97 -> 4 * 7.76 us - * CPU clock = 66 MHz: CONFIG_SYS_MAMR_PTA = 128 -> 4 * 7.75 us - * CPU clock = 133 MHz: CONFIG_SYS_MAMR_PTA = 255 -> 4 * 7.67 us - * - * Value 97 is for 4 * 7.8 us at 50 MHz. So the refresh cycle requirement will - * be met also in the default configuration, i.e. if environment variable - * 'cpuclk' is not set. - */ -#define CONFIG_SYS_MAMR_PTA 128 - -/* - * Memory Periodic Timer Prescaler Register (MPTPR) values. - */ -/* 4 * 7.8 us refresh (= 31.2 us per quad) at 50 MHz and PTA = 97 */ -#define CONFIG_SYS_MPTPR_2BK_4K MPTPR_PTP_DIV16 -/* 4 * 3.9 us refresh (= 15.6 us per quad) at 50 MHz and PTA = 97 */ -#define CONFIG_SYS_MPTPR_2BK_8K MPTPR_PTP_DIV8 - -/* - * MAMR settings for SDRAM - */ - -/* 8 column SDRAM */ -#define CONFIG_SYS_MAMR_8COL ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_0 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A11 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) -/* 9 column SDRAM */ -#define CONFIG_SYS_MAMR_9COL ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_1 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A10 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) -/* 10 column SDRAM */ -#define CONFIG_SYS_MAMR_10COL ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_2 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A9 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) - -/* - * Network configuration - */ -#define CONFIG_FEC_ENET /* enable ethernet on FEC */ -#define CONFIG_ETHER_ON_FEC1 /* ... for FEC1 */ -#define CONFIG_ETHER_ON_FEC2 /* ... for FEC2 */ - -#define CONFIG_LAST_STAGE_INIT 1 /* Have to configure PHYs for Linux */ - -/* CONFIG_SYS_DISCOVER_PHY only works with FEC if only one interface is enabled */ -#if (!defined(CONFIG_ETHER_ON_FEC1) || !defined(CONFIG_ETHER_ON_FEC2)) -#define CONFIG_SYS_DISCOVER_PHY -#endif - -#ifndef CONFIG_SYS_DISCOVER_PHY -/* PHY addresses - hard wired in hardware */ -#define CONFIG_FEC1_PHY 1 -#define CONFIG_FEC2_PHY 2 -#endif - -#define CONFIG_MII_INIT 1 - -#define CONFIG_NET_RETRY_COUNT 3 -#define CONFIG_ETHPRIME "FEC" - -/* pass open firmware flat tree */ -#define CONFIG_OF_LIBFDT 1 -#define CONFIG_OF_BOARD_SETUP 1 -#define CONFIG_HWCONFIG 1 - -#endif /* __CONFIG_H */ diff --git a/include/configs/virtlab2.h b/include/configs/virtlab2.h deleted file mode 100644 index 0457cdf..0000000 --- a/include/configs/virtlab2.h +++ /dev/null @@ -1,469 +0,0 @@ -/* - * (C) Copyright 2006-2008 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC823 1 /* This is a MPC823 CPU */ -#define CONFIG_VIRTLAB2 1 /* ...on a virtlab2 module */ -#define CONFIG_TQM8xxL 1 - -#define CONFIG_SYS_TEXT_BASE 0x40000000 - -#define CONFIG_8xx_CONS_SMC1 1 /* Console is on SMC1 */ -#define CONFIG_SYS_SMC_RXBUFLEN 128 -#define CONFIG_SYS_MAXIDLE 10 -#define CONFIG_BAUDRATE 115200 /* console baudrate = 115kbps */ - -#define CONFIG_BOOTCOUNT_LIMIT - -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ - -#define CONFIG_BOARD_TYPES 1 /* support board types */ - -#define CONFIG_PREBOOT "echo;echo Type \"run flash_nfs\" to mount root filesystem over NFS;echo" - -#undef CONFIG_BOOTARGS - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=eth0\0" \ - "nfsargs=setenv bootargs root=/dev/nfs rw " \ - "nfsroot=${serverip}:${rootpath}\0" \ - "ramargs=setenv bootargs root=/dev/ram rw\0" \ - "addip=setenv bootargs ${bootargs} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ - ":${hostname}:${netdev}:off panic=1\0" \ - "flash_nfs=run nfsargs addip;" \ - "bootm ${kernel_addr}\0" \ - "flash_self=run ramargs addip;" \ - "bootm ${kernel_addr} ${ramdisk_addr}\0" \ - "net_nfs=tftp 200000 ${bootfile};run nfsargs addip;bootm\0" \ - "rootpath=/opt/eldk/ppc_8xx\0" \ - "hostname=virtlab2\0" \ - "bootfile=virtlab2/uImage\0" \ - "fdt_addr=40040000\0" \ - "kernel_addr=40060000\0" \ - "ramdisk_addr=40200000\0" \ - "u-boot=virtlab2/u-image.bin\0" \ - "load=tftp 200000 ${u-boot}\0" \ - "update=prot off 40000000 +${filesize};" \ - "era 40000000 +${filesize};" \ - "cp.b 200000 40000000 ${filesize};" \ - "sete filesize;save\0" \ - "" -#define CONFIG_BOOTCOMMAND "run flash_self" - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -#if defined(CONFIG_LCD) -# undef CONFIG_STATUS_LED /* disturbs display */ -#else -# define CONFIG_STATUS_LED 1 /* Status LED enabled */ -#endif /* CONFIG_LCD */ - -#undef CONFIG_CAN_DRIVER /* CAN Driver support disabled */ - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE - - -#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - -#define CONFIG_RTC_MPC8xx /* use internal RTC of MPC8xx */ - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_IDE -#define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_NFS -#define CONFIG_CMD_SNTP - -#if defined(CONFIG_SPLASH_SCREEN) - #define CONFIG_CMD_BMP -#endif - - -#define CONFIG_NETCONSOLE - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ - -#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ -#define CONFIG_SYS_HUSH_PARSER 1 /* use "hush" command parser */ - -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xFFF00000 - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0x40000000 -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * FLASH organization - */ - -/* use CFI flash driver */ -#define CONFIG_SYS_FLASH_CFI 1 /* Flash is CFI conformant */ -#define CONFIG_FLASH_CFI_DRIVER 1 /* Use the common driver */ -#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE+flash_info[0].size } -#define CONFIG_SYS_FLASH_EMPTY_INFO -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 71 /* max number of sectors on one chip */ - -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_OFFSET 0x8000 /* Offset of Environment Sector */ -#define CONFIG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */ - -/* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET+CONFIG_ENV_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) - -#define CONFIG_SYS_USE_PPCENV /* Environment embedded in sect .ppcenv */ - -#define CONFIG_MISC_INIT_R /* Make sure to remap flashes correctly */ - -/*----------------------------------------------------------------------- - * Dynamic MTD partition support - */ -#define CONFIG_CMD_MTDPARTS -#define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ -#define CONFIG_FLASH_CFI_MTD -#define MTDIDS_DEFAULT "nor0=TQM8xxL-0" - -#define MTDPARTS_DEFAULT "mtdparts=TQM8xxL-0:256k(u-boot)," \ - "128k(dtb)," \ - "1664k(kernel)," \ - "2m(rootfs)," \ - "4m(data)" - -/*----------------------------------------------------------------------- - * Hardware Information Block - */ -#define CONFIG_SYS_HWINFO_OFFSET 0x0003FFC0 /* offset of HW Info block */ -#define CONFIG_SYS_HWINFO_SIZE 0x00000040 /* size of HW Info block */ -#define CONFIG_SYS_HWINFO_MAGIC 0x54514D38 /* 'TQM8' */ - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CACHELINE_SHIFT 4 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 11-9 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Software & Bus Monitor Timer max, Bus Monitor enable, SW Watchdog freeze - */ -#if defined(CONFIG_WATCHDOG) -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | \ - SYPCR_SWE | SYPCR_SWRI| SYPCR_SWP) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | SYPCR_SWP) -#endif - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 11-6 - *----------------------------------------------------------------------- - * PCMCIA config., multi-function pin tri-state - */ -#ifndef CONFIG_CAN_DRIVER -#define CONFIG_SYS_SIUMCR (SIUMCR_DBGC00 | SIUMCR_DBPC00 | SIUMCR_MLRC01) -#else /* we must activate GPL5 in the SIUMCR for CAN */ -#define CONFIG_SYS_SIUMCR (SIUMCR_DBGC11 | SIUMCR_DBPC00 | SIUMCR_MLRC01) -#endif /* CONFIG_CAN_DRIVER */ - -/*----------------------------------------------------------------------- - * TBSCR - Time Base Status and Control 11-26 - *----------------------------------------------------------------------- - * Clear Reference Interrupt Status, Timebase freezing enabled - */ -#define CONFIG_SYS_TBSCR (TBSCR_REFA | TBSCR_REFB | TBSCR_TBF) - -/*----------------------------------------------------------------------- - * RTCSC - Real-Time Clock Status and Control Register 11-27 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RTCSC (RTCSC_SEC | RTCSC_ALR | RTCSC_RTF| RTCSC_RTE) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 11-31 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Interrupt Timer freezing enabled - */ -#define CONFIG_SYS_PISCR (PISCR_PS | PISCR_PITF) - -/*----------------------------------------------------------------------- - * PLPRCR - PLL, Low-Power, and Reset Control Register 15-30 - *----------------------------------------------------------------------- - * Reset PLL lock status sticky bit, timer expired status bit and timer - * interrupt status bit - */ -#define CONFIG_SYS_PLPRCR (PLPRCR_SPLSS | PLPRCR_TEXPS | PLPRCR_TMIST) - -/*----------------------------------------------------------------------- - * SCCR - System Clock and reset Control Register 15-27 - *----------------------------------------------------------------------- - * Set clock output, timebase and RTC source and divider, - * power management and some other internal clocks - */ -#define SCCR_MASK SCCR_EBDF11 -#define CONFIG_SYS_SCCR (SCCR_COM00 | SCCR_DFSYNC00 | SCCR_DFBRG00 | \ - SCCR_DFNL000 | SCCR_DFNH000 | SCCR_DFLCD000 | \ - SCCR_DFALCD00) - -/*----------------------------------------------------------------------- - * PCMCIA stuff - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_PCMCIA_MEM_ADDR (0xE0000000) -#define CONFIG_SYS_PCMCIA_MEM_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_DMA_ADDR (0xE4000000) -#define CONFIG_SYS_PCMCIA_DMA_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_ATTRB_ADDR (0xE8000000) -#define CONFIG_SYS_PCMCIA_ATTRB_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_IO_ADDR (0xEC000000) -#define CONFIG_SYS_PCMCIA_IO_SIZE ( 64 << 20 ) - -/*----------------------------------------------------------------------- - * IDE/ATA stuff (Supports IDE harddisk on PCMCIA Adapter) - *----------------------------------------------------------------------- - */ - -#define CONFIG_IDE_PREINIT 1 /* Use preinit IDE hook */ -#define CONFIG_IDE_8xx_PCCARD 1 /* Use IDE with PC Card Adapter */ - -#undef CONFIG_IDE_8xx_DIRECT /* Direct IDE not supported */ -#undef CONFIG_IDE_LED /* LED for ide not supported */ -#undef CONFIG_IDE_RESET /* reset for ide not supported */ - -#define CONFIG_SYS_IDE_MAXBUS 1 /* max. 1 IDE bus */ -#define CONFIG_SYS_IDE_MAXDEVICE 1 /* max. 1 drive per IDE bus */ - -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 - -#define CONFIG_SYS_ATA_BASE_ADDR CONFIG_SYS_PCMCIA_MEM_ADDR - -/* Offset for data I/O */ -#define CONFIG_SYS_ATA_DATA_OFFSET (CONFIG_SYS_PCMCIA_MEM_SIZE + 0x320) - -/* Offset for normal register accesses */ -#define CONFIG_SYS_ATA_REG_OFFSET (2 * CONFIG_SYS_PCMCIA_MEM_SIZE + 0x320) - -/* Offset for alternate registers */ -#define CONFIG_SYS_ATA_ALT_OFFSET 0x0100 - -/*----------------------------------------------------------------------- - * - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_DER 0 - -/* - * Init Memory Controller: - * - * BR0/1 and OR0/1 (FLASH) - */ - -#define FLASH_BASE0_PRELIM 0x40000000 /* FLASH bank #0 */ -#define FLASH_BASE1_PRELIM 0x60000000 /* FLASH bank #0 */ - -/* used to re-map FLASH both when starting from SRAM or FLASH: - * restrict access enough to keep SRAM working (if any) - * but not too much to meddle with FLASH accesses - */ -#define CONFIG_SYS_REMAP_OR_AM 0x80000000 /* OR addr mask */ -#define CONFIG_SYS_PRELIM_OR_AM 0xE0000000 /* OR addr mask */ - -/* - * FLASH timing: - */ -#define CONFIG_SYS_OR_TIMING_FLASH (OR_ACS_DIV1 | OR_TRLX | OR_CSNT_SAM | \ - OR_SCY_3_CLK | OR_EHTR | OR_BI) - -#define CONFIG_SYS_OR0_REMAP (CONFIG_SYS_REMAP_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_BR0_PRELIM ((FLASH_BASE0_PRELIM & BR_BA_MSK) | BR_V ) - -#define CONFIG_SYS_OR1_REMAP CONFIG_SYS_OR0_REMAP -#define CONFIG_SYS_OR1_PRELIM CONFIG_SYS_OR0_PRELIM -#define CONFIG_SYS_BR1_PRELIM ((FLASH_BASE1_PRELIM & BR_BA_MSK) | BR_V ) - -/* - * BR2/3 and OR2/3 (SDRAM) - * - */ -#define SDRAM_BASE2_PRELIM 0x00000000 /* SDRAM bank #0 */ -#define SDRAM_BASE3_PRELIM 0x20000000 /* SDRAM bank #1 */ -#define SDRAM_MAX_SIZE 0x04000000 /* max 64 MB per bank */ - -/* SDRAM timing: Multiplexed addresses, GPL5 output to GPL5_A (don't care) */ -#define CONFIG_SYS_OR_TIMING_SDRAM 0x00000A00 - -#define CONFIG_SYS_OR2_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_SDRAM ) -#define CONFIG_SYS_BR2_PRELIM ((SDRAM_BASE2_PRELIM & BR_BA_MSK) | BR_MS_UPMA | BR_V ) - -#ifndef CONFIG_CAN_DRIVER -#define CONFIG_SYS_OR3_PRELIM CONFIG_SYS_OR2_PRELIM -#define CONFIG_SYS_BR3_PRELIM ((SDRAM_BASE3_PRELIM & BR_BA_MSK) | BR_MS_UPMA | BR_V ) -#else /* CAN uses CS3#, so we can have only one SDRAM bank anyway */ -#define CONFIG_SYS_CAN_BASE 0xC0000000 /* CAN mapped at 0xC0000000 */ -#define CONFIG_SYS_CAN_OR_AM 0xFFFF8000 /* 32 kB address mask */ -#define CONFIG_SYS_OR3_CAN (CONFIG_SYS_CAN_OR_AM | OR_G5LA | OR_BI) -#define CONFIG_SYS_BR3_CAN ((CONFIG_SYS_CAN_BASE & BR_BA_MSK) | \ - BR_PS_8 | BR_MS_UPMB | BR_V ) -#endif /* CONFIG_CAN_DRIVER */ - -/* - * Memory Periodic Timer Prescaler - * - * The Divider for PTA (refresh timer) configuration is based on an - * example SDRAM configuration (64 MBit, one bank). The adjustment to - * the number of chip selects (NCS) and the actually needed refresh - * rate is done by setting MPTPR. - * - * PTA is calculated from - * PTA = (gclk * Trefresh) / ((2 ^ (2 * DFBRG)) * PTP * NCS) - * - * gclk CPU clock (not bus clock!) - * Trefresh Refresh cycle * 4 (four word bursts used) - * - * 4096 Rows from SDRAM example configuration - * 1000 factor s -> ms - * 32 PTP (pre-divider from MPTPR) from SDRAM example configuration - * 4 Number of refresh cycles per period - * 64 Refresh cycle in ms per number of rows - * -------------------------------------------- - * Divider = 4096 * 32 * 1000 / (4 * 64) = 512000 - * - * 50 MHz => 50.000.000 / Divider = 98 - * 66 Mhz => 66.000.000 / Divider = 129 - * 80 Mhz => 80.000.000 / Divider = 156 - */ - -#define CONFIG_SYS_PTA_PER_CLK ((4096 * 32 * 1000) / (4 * 64)) -#define CONFIG_SYS_MAMR_PTA 98 - -/* - * For 16 MBit, refresh rates could be 31.3 us - * (= 64 ms / 2K = 125 / quad bursts). - * For a simpler initialization, 15.6 us is used instead. - * - * #define CONFIG_SYS_MPTPR_2BK_2K MPTPR_PTP_DIV32 for 2 banks - * #define CONFIG_SYS_MPTPR_1BK_2K MPTPR_PTP_DIV64 for 1 bank - */ -#define CONFIG_SYS_MPTPR_2BK_4K MPTPR_PTP_DIV16 /* setting for 2 banks */ -#define CONFIG_SYS_MPTPR_1BK_4K MPTPR_PTP_DIV32 /* setting for 1 bank */ - -/* refresh rate 7.8 us (= 64 ms / 8K = 31.2 / quad bursts) for 256 MBit */ -#define CONFIG_SYS_MPTPR_2BK_8K MPTPR_PTP_DIV8 /* setting for 2 banks */ -#define CONFIG_SYS_MPTPR_1BK_8K MPTPR_PTP_DIV16 /* setting for 1 bank */ - -/* - * MAMR settings for SDRAM - */ - -/* 8 column SDRAM */ -#define CONFIG_SYS_MAMR_8COL ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_0 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A11 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) -/* 9 column SDRAM */ -#define CONFIG_SYS_MAMR_9COL ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_1 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A10 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) - -/* Map peripheral control registers on CS4 */ -#define CONFIG_SYS_PERIPHERAL_BASE 0xA0000000 -#define CONFIG_SYS_PERIPHERAL_OR_AM 0xFFFF8000 /* 32 kB address mask */ -#define CONFIG_SYS_OR4_PRELIM (CONFIG_SYS_PERIPHERAL_OR_AM | OR_TRLX | OR_CSNT_SAM | \ - OR_SCY_2_CLK) -#define CONFIG_SYS_BR4_PRELIM ((CONFIG_SYS_PERIPHERAL_BASE & BR_BA_MSK) | BR_PS_8 | BR_V) -#define PCMCIA_CTRL (CONFIG_SYS_PERIPHERAL_BASE + 0xB00) - -/* pass open firmware flat tree */ -#define CONFIG_OF_LIBFDT 1 -#define CONFIG_OF_BOARD_SETUP 1 -#define CONFIG_HWCONFIG 1 - -#endif /* __CONFIG_H */
On Mon, Dec 15, 2014 at 11:26:06PM +0900, Masahiro Yamada wrote:
These boards are still non-generic boards.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Wolfgang Denk wd@denx.de
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Heiko Schocher hs@denx.de Cc: Stefan Roese sr@denx.de ---
arch/powerpc/cpu/mpc5xxx/Kconfig | 12 - arch/powerpc/cpu/mpc5xxx/ide.c | 8 - arch/powerpc/cpu/mpc8xx/Kconfig | 4 - board/manroland/hmi1001/Kconfig | 12 - board/manroland/hmi1001/MAINTAINERS | 6 - board/manroland/hmi1001/Makefile | 8 - board/manroland/hmi1001/hmi1001.c | 301 ---------------------- board/manroland/mucmc52/Kconfig | 12 - board/manroland/mucmc52/MAINTAINERS | 6 - board/manroland/mucmc52/Makefile | 11 - board/manroland/mucmc52/mucmc52.c | 394 ----------------------------- board/manroland/uc100/Kconfig | 12 - board/manroland/uc100/MAINTAINERS | 6 - board/manroland/uc100/Makefile | 8 - board/manroland/uc100/pcmcia.c | 192 -------------- board/manroland/uc100/uc100.c | 254 ------------------- board/manroland/uc101/Kconfig | 12 - board/manroland/uc101/MAINTAINERS | 6 - board/manroland/uc101/Makefile | 8 - board/manroland/uc101/uc101.c | 367 --------------------------- configs/hmi1001_defconfig | 3 - configs/mucmc52_defconfig | 3 - configs/uc100_defconfig | 3 - configs/uc101_defconfig | 3 - doc/README.scrapyard | 4 + drivers/net/mpc5xxx_fec.c | 5 - drivers/video/smiLynxEM.c | 3 - include/configs/hmi1001.h | 339 ------------------------- include/configs/mucmc52.h | 126 ---------- include/configs/uc100.h | 482 ------------------------------------ include/configs/uc101.h | 103 -------- include/pcmcia.h | 2 - 32 files changed, 4 insertions(+), 2711 deletions(-) delete mode 100644 board/manroland/hmi1001/Kconfig delete mode 100644 board/manroland/hmi1001/MAINTAINERS delete mode 100644 board/manroland/hmi1001/Makefile delete mode 100644 board/manroland/hmi1001/hmi1001.c delete mode 100644 board/manroland/mucmc52/Kconfig delete mode 100644 board/manroland/mucmc52/MAINTAINERS delete mode 100644 board/manroland/mucmc52/Makefile delete mode 100644 board/manroland/mucmc52/mucmc52.c delete mode 100644 board/manroland/uc100/Kconfig delete mode 100644 board/manroland/uc100/MAINTAINERS delete mode 100644 board/manroland/uc100/Makefile delete mode 100644 board/manroland/uc100/pcmcia.c delete mode 100644 board/manroland/uc100/uc100.c delete mode 100644 board/manroland/uc101/Kconfig delete mode 100644 board/manroland/uc101/MAINTAINERS delete mode 100644 board/manroland/uc101/Makefile delete mode 100644 board/manroland/uc101/uc101.c delete mode 100644 configs/hmi1001_defconfig delete mode 100644 configs/mucmc52_defconfig delete mode 100644 configs/uc100_defconfig delete mode 100644 configs/uc101_defconfig delete mode 100644 include/configs/hmi1001.h delete mode 100644 include/configs/mucmc52.h delete mode 100644 include/configs/uc100.h delete mode 100644 include/configs/uc101.h
diff --git a/arch/powerpc/cpu/mpc5xxx/Kconfig b/arch/powerpc/cpu/mpc5xxx/Kconfig index bd64ea6..e2e9cb7 100644 --- a/arch/powerpc/cpu/mpc5xxx/Kconfig +++ b/arch/powerpc/cpu/mpc5xxx/Kconfig @@ -83,15 +83,6 @@ config TARGET_O3DNT config TARGET_DIGSY_MTC bool "Support digsy_mtc"
-config TARGET_HMI1001 - bool "Support hmi1001" - -config TARGET_MUCMC52 - bool "Support mucmc52" - -config TARGET_UC101 - bool "Support uc101" - config TARGET_PCM030 bool "Support pcm030"
@@ -124,9 +115,6 @@ source "board/inka4x0/Kconfig" source "board/intercontrol/digsy_mtc/Kconfig" source "board/ipek01/Kconfig" source "board/jupiter/Kconfig" -source "board/manroland/hmi1001/Kconfig" -source "board/manroland/mucmc52/Kconfig" -source "board/manroland/uc101/Kconfig" source "board/motionpro/Kconfig" source "board/munices/Kconfig" source "board/phytec/pcm030/Kconfig" diff --git a/arch/powerpc/cpu/mpc5xxx/ide.c b/arch/powerpc/cpu/mpc5xxx/ide.c index 03cd7fd..9003b77 100644 --- a/arch/powerpc/cpu/mpc5xxx/ide.c +++ b/arch/powerpc/cpu/mpc5xxx/ide.c @@ -41,19 +41,11 @@ int ide_preinit (void) /* All sample codes do that... */ *(vu_long *) MPC5XXX_ATA_SHARE_COUNT = 0;
-#if defined(CONFIG_UC101) - /* Configure and reset host */ - *(vu_long *) MPC5XXX_ATA_HOST_CONFIG = - MPC5xxx_ATA_HOSTCONF_SMR | MPC5xxx_ATA_HOSTCONF_FR; - udelay (10); - *(vu_long *) MPC5XXX_ATA_HOST_CONFIG = 0; -#else /* Configure and reset host */ *(vu_long *) MPC5XXX_ATA_HOST_CONFIG = MPC5xxx_ATA_HOSTCONF_IORDY | MPC5xxx_ATA_HOSTCONF_SMR | MPC5xxx_ATA_HOSTCONF_FR; udelay (10); *(vu_long *) MPC5XXX_ATA_HOST_CONFIG = MPC5xxx_ATA_HOSTCONF_IORDY; -#endif
/* Disable prefetch on Commbus */ psdma->PtdCntrl |= 1; diff --git a/arch/powerpc/cpu/mpc8xx/Kconfig b/arch/powerpc/cpu/mpc8xx/Kconfig index 33fff0c..9eb7e17 100644 --- a/arch/powerpc/cpu/mpc8xx/Kconfig +++ b/arch/powerpc/cpu/mpc8xx/Kconfig @@ -46,9 +46,6 @@ config TARGET_KUP4X config TARGET_ELPT860 bool "Support ELPT860"
-config TARGET_UC100 - bool "Support uc100" - config TARGET_TQM823L bool "Support TQM823L"
@@ -96,7 +93,6 @@ source "board/ivm/Kconfig" source "board/kup/kup4k/Kconfig" source "board/kup/kup4x/Kconfig" source "board/lwmon/Kconfig" -source "board/manroland/uc100/Kconfig" source "board/netvia/Kconfig" source "board/r360mpi/Kconfig" source "board/spd8xx/Kconfig" diff --git a/board/manroland/hmi1001/Kconfig b/board/manroland/hmi1001/Kconfig deleted file mode 100644 index 996a87f..0000000 --- a/board/manroland/hmi1001/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_HMI1001 - -config SYS_BOARD - default "hmi1001" - -config SYS_VENDOR - default "manroland" - -config SYS_CONFIG_NAME - default "hmi1001" - -endif diff --git a/board/manroland/hmi1001/MAINTAINERS b/board/manroland/hmi1001/MAINTAINERS deleted file mode 100644 index a66a981..0000000 --- a/board/manroland/hmi1001/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -HMI1001 BOARD -#M: - -S: Maintained -F: board/manroland/hmi1001/ -F: include/configs/hmi1001.h -F: configs/hmi1001_defconfig diff --git a/board/manroland/hmi1001/Makefile b/board/manroland/hmi1001/Makefile deleted file mode 100644 index c29a665..0000000 --- a/board/manroland/hmi1001/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2003-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y := hmi1001.o diff --git a/board/manroland/hmi1001/hmi1001.c b/board/manroland/hmi1001/hmi1001.c deleted file mode 100644 index 64bdd8f..0000000 --- a/board/manroland/hmi1001/hmi1001.c +++ /dev/null @@ -1,301 +0,0 @@ -/* - * (C) Copyright 2003-2008 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * (C) Copyright 2004 - * Mark Jonas, Freescale Semiconductor, mark.jonas@motorola.com. - * - * (C) Copyright 2004 - * Martin Krause, TQ-Systems GmbH, martin.krause@tqs.de - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc5xxx.h> -#include <pci.h> -#include <asm/processor.h> -#include <malloc.h> - -#ifndef CONFIG_SYS_RAMBOOT -static void sdram_start (int hi_addr) -{ - long hi_addr_bit = hi_addr ? 0x01000000 : 0; - - /* unlock mode register */ - *(vu_long *)MPC5XXX_SDRAM_CTRL = SDRAM_CONTROL | 0x80000000 | hi_addr_bit; - __asm__ volatile ("sync"); - - /* precharge all banks */ - *(vu_long *)MPC5XXX_SDRAM_CTRL = SDRAM_CONTROL | 0x80000002 | hi_addr_bit; - __asm__ volatile ("sync"); - -#if SDRAM_DDR - /* set mode register: extended mode */ - *(vu_long *)MPC5XXX_SDRAM_MODE = SDRAM_EMODE; - __asm__ volatile ("sync"); - - /* set mode register: reset DLL */ - *(vu_long *)MPC5XXX_SDRAM_MODE = SDRAM_MODE | 0x04000000; - __asm__ volatile ("sync"); -#endif - - /* precharge all banks */ - *(vu_long *)MPC5XXX_SDRAM_CTRL = SDRAM_CONTROL | 0x80000002 | hi_addr_bit; - __asm__ volatile ("sync"); - - /* auto refresh */ - *(vu_long *)MPC5XXX_SDRAM_CTRL = SDRAM_CONTROL | 0x80000004 | hi_addr_bit; - __asm__ volatile ("sync"); - - /* set mode register */ - *(vu_long *)MPC5XXX_SDRAM_MODE = SDRAM_MODE; - __asm__ volatile ("sync"); - - /* normal operation */ - *(vu_long *)MPC5XXX_SDRAM_CTRL = SDRAM_CONTROL | hi_addr_bit; - __asm__ volatile ("sync"); -} -#endif - -/* - * ATTENTION: Although partially referenced initdram does NOT make real use - * use of CONFIG_SYS_SDRAM_BASE. The code does not work if CONFIG_SYS_SDRAM_BASE - * is something else than 0x00000000. - */ - -phys_size_t initdram (int board_type) -{ - ulong dramsize = 0; -#ifndef CONFIG_SYS_RAMBOOT - ulong test1, test2; - uint svr, pvr; - - /* setup SDRAM chip selects */ - *(vu_long *)MPC5XXX_SDRAM_CS0CFG = 0x0000001c; /* 512MB at 0x0 */ - *(vu_long *)MPC5XXX_SDRAM_CS1CFG = 0x40000000; /* disabled */ - __asm__ volatile ("sync"); - - /* setup config registers */ - *(vu_long *)MPC5XXX_SDRAM_CONFIG1 = SDRAM_CONFIG1; - *(vu_long *)MPC5XXX_SDRAM_CONFIG2 = SDRAM_CONFIG2; - __asm__ volatile ("sync"); - -#if SDRAM_DDR - /* set tap delay */ - *(vu_long *)MPC5XXX_CDM_PORCFG = SDRAM_TAPDELAY; - __asm__ volatile ("sync"); -#endif - - /* find RAM size using SDRAM CS0 only */ - sdram_start(0); - test1 = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, 0x20000000); - sdram_start(1); - test2 = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, 0x20000000); - if (test1 > test2) { - sdram_start(0); - dramsize = test1; - } else { - dramsize = test2; - } - - /* memory smaller than 1MB is impossible */ - if (dramsize < (1 << 20)) { - dramsize = 0; - } - - /* set SDRAM CS0 size according to the amount of RAM found */ - if (dramsize > 0) { - *(vu_long *)MPC5XXX_SDRAM_CS0CFG = 0x13 + - __builtin_ffs(dramsize >> 20) - 1; - } else { - *(vu_long *)MPC5XXX_SDRAM_CS0CFG = 0; /* disabled */ - } - - *(vu_long *)MPC5XXX_SDRAM_CS1CFG = dramsize; /* disabled */ -#else /* CONFIG_SYS_RAMBOOT */ - - /* retrieve size of memory connected to SDRAM CS0 */ - dramsize = *(vu_long *)MPC5XXX_SDRAM_CS0CFG & 0xFF; - if (dramsize >= 0x13) { - dramsize = (1 << (dramsize - 0x13)) << 20; - } else { - dramsize = 0; - } - - /* retrieve size of memory connected to SDRAM CS1 */ - dramsize2 = *(vu_long *)MPC5XXX_SDRAM_CS1CFG & 0xFF; - if (dramsize2 >= 0x13) { - dramsize2 = (1 << (dramsize2 - 0x13)) << 20; - } else { - dramsize2 = 0; - } - -#endif /* CONFIG_SYS_RAMBOOT */ - - /* - * On MPC5200B we need to set the special configuration delay in the - * DDR controller. Please refer to Freescale's AN3221 "MPC5200B SDRAM - * Initialization and Configuration", 3.3.1 SDelay--MBAR + 0x0190: - * - * "The SDelay should be written to a value of 0x00000004. It is - * required to account for changes caused by normal wafer processing - * parameters." - */ - svr = get_svr(); - pvr = get_pvr(); - if ((SVR_MJREV(svr) >= 2) && - (PVR_MAJ(pvr) == 1) && (PVR_MIN(pvr) == 4)) { - - *(vu_long *)MPC5XXX_SDRAM_SDELAY = 0x04; - __asm__ volatile ("sync"); - } - -/* return dramsize + dramsize2; */ - return dramsize; -} - -int checkboard (void) -{ - puts ("Board: HMI1001\n"); - return 0; -} - -#ifdef CONFIG_PREBOOT - -static uchar kbd_magic_prefix[] = "key_magic"; -static uchar kbd_command_prefix[] = "key_cmd"; - -#define S1_ROT 0xf0 -#define S2_Q 0x40 -#define S2_M 0x20 - -struct kbd_data_t { - char s1; - char s2; -}; - -struct kbd_data_t* get_keys (struct kbd_data_t *kbd_data) -{ - kbd_data->s1 = *((volatile uchar*)(CONFIG_SYS_STATUS1_BASE)); - kbd_data->s2 = *((volatile uchar*)(CONFIG_SYS_STATUS2_BASE)); - - return kbd_data; -} - -static int compare_magic (const struct kbd_data_t *kbd_data, char *str) -{ - char s1 = str[0]; - char s2; - - if (s1 >= '0' && s1 <= '9') - s1 -= '0'; - else if (s1 >= 'a' && s1 <= 'f') - s1 = s1 - 'a' + 10; - else if (s1 >= 'A' && s1 <= 'F') - s1 = s1 - 'A' + 10; - else - return -1; - - if (((S1_ROT & kbd_data->s1) >> 4) != s1) - return -1; - - s2 = (S2_Q | S2_M) & kbd_data->s2; - - switch (str[1]) { - case 'q': - case 'Q': - if (s2 == S2_Q) - return -1; - break; - case 'm': - case 'M': - if (s2 == S2_M) - return -1; - break; - case '\0': - if (s2 == (S2_Q | S2_M)) - return 0; - default: - return -1; - } - - if (str[2]) - return -1; - - return 0; -} - -static char *key_match (const struct kbd_data_t *kbd_data) -{ - char magic[sizeof (kbd_magic_prefix) + 1]; - char *suffix; - char *kbd_magic_keys; - - /* - * The following string defines the characters that can be appended - * to "key_magic" to form the names of environment variables that - * hold "magic" key codes, i. e. such key codes that can cause - * pre-boot actions. If the string is empty (""), then only - * "key_magic" is checked (old behaviour); the string "125" causes - * checks for "key_magic1", "key_magic2" and "key_magic5", etc. - */ - if ((kbd_magic_keys = getenv ("magic_keys")) == NULL) - kbd_magic_keys = ""; - - /* loop over all magic keys; - * use '\0' suffix in case of empty string - */ - for (suffix = kbd_magic_keys; *suffix || - suffix == kbd_magic_keys; ++suffix) { - sprintf (magic, "%s%c", kbd_magic_prefix, *suffix); - - if (compare_magic(kbd_data, getenv(magic)) == 0) { - char cmd_name[sizeof (kbd_command_prefix) + 1]; - char *cmd; - - sprintf (cmd_name, "%s%c", kbd_command_prefix, *suffix); - cmd = getenv (cmd_name); - - return (cmd); - } - } - - return (NULL); -} - -#endif /* CONFIG_PREBOOT */ - -int misc_init_r (void) -{ -#ifdef CONFIG_PREBOOT - struct kbd_data_t kbd_data; - /* Decode keys */ - char *str = strdup (key_match (get_keys (&kbd_data))); - /* Set or delete definition */ - setenv ("preboot", str); - free (str); -#endif /* CONFIG_PREBOOT */ - - return 0; -} - -int board_early_init_r (void) -{ - *(vu_long *)MPC5XXX_BOOTCS_CFG &= ~0x1; /* clear RO */ - *(vu_long *)MPC5XXX_BOOTCS_START = - *(vu_long *)MPC5XXX_CS0_START = START_REG(CONFIG_SYS_FLASH_BASE); - *(vu_long *)MPC5XXX_BOOTCS_STOP = - *(vu_long *)MPC5XXX_CS0_STOP = STOP_REG(CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_SIZE); - return 0; -} -#ifdef CONFIG_PCI -static struct pci_controller hose; - -extern void pci_mpc5xxx_init(struct pci_controller *); - -void pci_init_board(void) -{ - pci_mpc5xxx_init(&hose); -} -#endif diff --git a/board/manroland/mucmc52/Kconfig b/board/manroland/mucmc52/Kconfig deleted file mode 100644 index a033610..0000000 --- a/board/manroland/mucmc52/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_MUCMC52 - -config SYS_BOARD - default "mucmc52" - -config SYS_VENDOR - default "manroland" - -config SYS_CONFIG_NAME - default "mucmc52" - -endif diff --git a/board/manroland/mucmc52/MAINTAINERS b/board/manroland/mucmc52/MAINTAINERS deleted file mode 100644 index 45a2764..0000000 --- a/board/manroland/mucmc52/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -MUCMC52 BOARD -M: Heiko Schocher hs@denx.de -S: Maintained -F: board/manroland/mucmc52/ -F: include/configs/mucmc52.h -F: configs/mucmc52_defconfig diff --git a/board/manroland/mucmc52/Makefile b/board/manroland/mucmc52/Makefile deleted file mode 100644 index 927fc32..0000000 --- a/board/manroland/mucmc52/Makefile +++ /dev/null @@ -1,11 +0,0 @@ -# -# (C) Copyright 2008 -# Heiko Schocher, DENX Software Engineering, hs@denx.de. -# -# (C) Copyright 2003-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y := mucmc52.o diff --git a/board/manroland/mucmc52/mucmc52.c b/board/manroland/mucmc52/mucmc52.c deleted file mode 100644 index c8ed5b7..0000000 --- a/board/manroland/mucmc52/mucmc52.c +++ /dev/null @@ -1,394 +0,0 @@ -/* - * (C) Copyright 2003-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * (C) Copyright 2004 - * Mark Jonas, Freescale Semiconductor, mark.jonas@motorola.com. - * - * (C) Copyright 2004 - * Martin Krause, TQ-Systems GmbH, martin.krause@tqs.de - * - * (C) Copyright 2008 - * Heiko Schocher, DENX Software Engineering, hs@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <fdt_support.h> -#include <mpc5xxx.h> -#include <pci.h> -#include <malloc.h> -#include <asm/processor.h> -#include <asm/io.h> - -#ifndef CONFIG_SYS_RAMBOOT -static void sdram_start (int hi_addr) -{ - long hi_addr_bit = hi_addr ? 0x01000000 : 0; - - /* unlock mode register */ - out_be32 ((unsigned __iomem *)MPC5XXX_SDRAM_CTRL, - (SDRAM_CONTROL | 0x80000000 | hi_addr_bit)); - __asm__ volatile ("sync"); - - /* precharge all banks */ - out_be32 ((unsigned __iomem *)MPC5XXX_SDRAM_CTRL, - (SDRAM_CONTROL | 0x80000002 | hi_addr_bit)); - __asm__ volatile ("sync"); - -#if SDRAM_DDR - /* set mode register: extended mode */ - out_be32 ((unsigned __iomem *)MPC5XXX_SDRAM_MODE, (SDRAM_EMODE)); - __asm__ volatile ("sync"); - - /* set mode register: reset DLL */ - out_be32 ((unsigned __iomem *)MPC5XXX_SDRAM_MODE, - (SDRAM_MODE | 0x04000000)); - __asm__ volatile ("sync"); -#endif - - /* precharge all banks */ - out_be32 ((unsigned __iomem *)MPC5XXX_SDRAM_CTRL, - (SDRAM_CONTROL | 0x80000002 | hi_addr_bit)); - __asm__ volatile ("sync"); - - /* auto refresh */ - out_be32 ((unsigned __iomem *)MPC5XXX_SDRAM_CTRL, - (SDRAM_CONTROL | 0x80000004 | hi_addr_bit)); - __asm__ volatile ("sync"); - - /* set mode register */ - out_be32 ((unsigned __iomem *)MPC5XXX_SDRAM_MODE, (SDRAM_MODE)); - __asm__ volatile ("sync"); - - /* normal operation */ - out_be32 ((unsigned __iomem *)MPC5XXX_SDRAM_CTRL, - (SDRAM_CONTROL | hi_addr_bit)); - __asm__ volatile ("sync"); -} -#endif - -/* - * ATTENTION: Although partially referenced initdram does NOT make real use - * use of CONFIG_SYS_SDRAM_BASE. The code does not work if CONFIG_SYS_SDRAM_BASE - * is something else than 0x00000000. - */ - -phys_size_t initdram (int board_type) -{ - ulong dramsize = 0; - ulong dramsize2 = 0; - uint svr, pvr; - -#ifndef CONFIG_SYS_RAMBOOT - ulong test1, test2; - - /* setup SDRAM chip selects */ - out_be32 ((unsigned __iomem *)MPC5XXX_SDRAM_CS0CFG, 0x0000001c); /* 512MB at 0x0 */ - out_be32 ((unsigned __iomem *)MPC5XXX_SDRAM_CS1CFG, 0x80000000);/* disabled */ - __asm__ volatile ("sync"); - - /* setup config registers */ - out_be32 ((unsigned __iomem *)MPC5XXX_SDRAM_CONFIG1, SDRAM_CONFIG1); - out_be32 ((unsigned __iomem *)MPC5XXX_SDRAM_CONFIG2, SDRAM_CONFIG2); - __asm__ volatile ("sync"); - -#if SDRAM_DDR - /* set tap delay */ - out_be32 ((unsigned __iomem *)MPC5XXX_CDM_PORCFG, SDRAM_TAPDELAY); - __asm__ volatile ("sync"); -#endif - - /* find RAM size using SDRAM CS0 only */ - sdram_start (0); - test1 = get_ram_size ((long *)CONFIG_SYS_SDRAM_BASE, 0x20000000); - sdram_start(1); - test2 = get_ram_size ((long *)CONFIG_SYS_SDRAM_BASE, 0x20000000); - if (test1 > test2) { - sdram_start (0); - dramsize = test1; - } else { - dramsize = test2; - } - - /* memory smaller than 1MB is impossible */ - if (dramsize < (1 << 20)) { - dramsize = 0; - } - - /* set SDRAM CS0 size according to the amount of RAM found */ - if (dramsize > 0) { - out_be32 ((unsigned __iomem *)MPC5XXX_SDRAM_CS0CFG, - (0x13 + __builtin_ffs(dramsize >> 20) - 1)); - } else { - out_be32 ((unsigned __iomem *)MPC5XXX_SDRAM_CS0CFG, 0); /* disabled */ - } - - /* let SDRAM CS1 start right after CS0 */ - out_be32 ((unsigned __iomem *)MPC5XXX_SDRAM_CS1CFG, (dramsize + 0x0000001c));/*512MB*/ - - /* find RAM size using SDRAM CS1 only */ - if (!dramsize) - sdram_start (0); - test2 = test1 = get_ram_size ((long *)(CONFIG_SYS_SDRAM_BASE + dramsize), 0x20000000); - if (!dramsize) { - sdram_start (1); - test2 = get_ram_size ((long *)(CONFIG_SYS_SDRAM_BASE + dramsize), 0x20000000); - } - if (test1 > test2) { - sdram_start (0); - dramsize2 = test1; - } else { - dramsize2 = test2; - } - - /* memory smaller than 1MB is impossible */ - if (dramsize2 < (1 << 20)) { - dramsize2 = 0; - } - - /* set SDRAM CS1 size according to the amount of RAM found */ - if (dramsize2 > 0) { - out_be32 ((unsigned __iomem *)MPC5XXX_SDRAM_CS1CFG, - (dramsize | (0x13 + __builtin_ffs(dramsize2 >> 20) - 1))); - } else { - out_be32 ((unsigned __iomem *)MPC5XXX_SDRAM_CS1CFG, dramsize); /* disabled */ - } - -#else /* CONFIG_SYS_RAMBOOT */ - - /* retrieve size of memory connected to SDRAM CS0 */ - dramsize = in_be32 ((unsigned __iomem *)MPC5XXX_SDRAM_CS0CFG) & 0xFF; - if (dramsize >= 0x13) { - dramsize = (1 << (dramsize - 0x13)) << 20; - } else { - dramsize = 0; - } - - /* retrieve size of memory connected to SDRAM CS1 */ - dramsize2 = in_be32 ((unsigned __iomem *)MPC5XXX_SDRAM_CS1CFG) & 0xFF; - if (dramsize2 >= 0x13) { - dramsize2 = (1 << (dramsize2 - 0x13)) << 20; - } else { - dramsize2 = 0; - } - -#endif /* CONFIG_SYS_RAMBOOT */ - - /* - * On MPC5200B we need to set the special configuration delay in the - * DDR controller. Please refer to Freescale's AN3221 "MPC5200B SDRAM - * Initialization and Configuration", 3.3.1 SDelay--MBAR + 0x0190: - * - * "The SDelay should be written to a value of 0x00000004. It is - * required to account for changes caused by normal wafer processing - * parameters." - */ - svr = get_svr(); - pvr = get_pvr(); - if ((SVR_MJREV(svr) >= 2) && - (PVR_MAJ(pvr) == 1) && (PVR_MIN(pvr) == 4)) { - - out_be32 ((unsigned __iomem *)MPC5XXX_SDRAM_SDELAY, 0x04); - __asm__ volatile ("sync"); - } - - return dramsize + dramsize2; -} - -int checkboard (void) -{ - puts ("Board: MUC.MC-52 HW WDT "); -#if defined(CONFIG_HW_WATCHDOG) - puts ("enabled\n"); -#else - puts ("disabled\n"); -#endif - return 0; -} - -#ifdef CONFIG_PREBOOT - -static uchar kbd_magic_prefix[] = "key_magic"; -static uchar kbd_command_prefix[] = "key_cmd"; - -#define S1_ROT 0xf0 -#define S2_Q 0x40 -#define S2_M 0x20 - -struct kbd_data_t { - char s1; - char s2; -}; - -struct kbd_data_t* get_keys (struct kbd_data_t *kbd_data) -{ - kbd_data->s1 = in_8 ((volatile uchar*)CONFIG_SYS_STATUS1_BASE); - kbd_data->s2 = in_8 ((volatile uchar*)CONFIG_SYS_STATUS2_BASE); - - return kbd_data; -} - -static int compare_magic (const struct kbd_data_t *kbd_data, char *str) -{ - char s1 = str[0]; - char s2; - - if (s1 >= '0' && s1 <= '9') - s1 -= '0'; - else if (s1 >= 'a' && s1 <= 'f') - s1 = s1 - 'a' + 10; - else if (s1 >= 'A' && s1 <= 'F') - s1 = s1 - 'A' + 10; - else - return -1; - - if (((S1_ROT & kbd_data->s1) >> 4) != s1) - return -1; - - s2 = (S2_Q | S2_M) & kbd_data->s2; - - switch (str[1]) { - case 'q': - case 'Q': - if (s2 == S2_Q) - return -1; - break; - case 'm': - case 'M': - if (s2 == S2_M) - return -1; - break; - case '\0': - if (s2 == (S2_Q | S2_M)) - return 0; - default: - return -1; - } - - if (str[2]) - return -1; - - return 0; -} - -static char *key_match (const struct kbd_data_t *kbd_data) -{ - char magic[sizeof (kbd_magic_prefix) + 1]; - char *suffix; - char *kbd_magic_keys; - - /* - * The following string defines the characters that can be appended - * to "key_magic" to form the names of environment variables that - * hold "magic" key codes, i. e. such key codes that can cause - * pre-boot actions. If the string is empty (""), then only - * "key_magic" is checked (old behaviour); the string "125" causes - * checks for "key_magic1", "key_magic2" and "key_magic5", etc. - */ - if ((kbd_magic_keys = getenv ("magic_keys")) == NULL) - kbd_magic_keys = ""; - - /* loop over all magic keys; - * use '\0' suffix in case of empty string - */ - for (suffix = kbd_magic_keys; *suffix || - suffix == kbd_magic_keys; ++suffix) { - sprintf (magic, "%s%c", kbd_magic_prefix, *suffix); - - if (compare_magic(kbd_data, getenv(magic)) == 0) { - char cmd_name[sizeof (kbd_command_prefix) + 1]; - char *cmd; - - sprintf (cmd_name, "%s%c", kbd_command_prefix, *suffix); - cmd = getenv (cmd_name); - - return (cmd); - } - } - - return (NULL); -} - -#endif /* CONFIG_PREBOOT */ - -int misc_init_r (void) -{ -#ifdef CONFIG_PREBOOT - struct kbd_data_t kbd_data; - /* Decode keys */ - char *str = strdup (key_match (get_keys (&kbd_data))); - /* Set or delete definition */ - setenv ("preboot", str); - free (str); -#endif /* CONFIG_PREBOOT */ - - out_8 ((volatile uchar *)(CONFIG_SYS_DISPLAY_BASE + 0x38), ' '); - out_8 ((volatile uchar *)(CONFIG_SYS_DISPLAY_BASE + 0x39), ' '); - out_8 ((volatile uchar *)(CONFIG_SYS_DISPLAY_BASE + 0x3A), ' '); - out_8 ((volatile uchar *)(CONFIG_SYS_DISPLAY_BASE + 0x3B), ' '); - out_8 ((volatile uchar *)(CONFIG_SYS_DISPLAY_BASE + 0x3C), ' '); - out_8 ((volatile uchar *)(CONFIG_SYS_DISPLAY_BASE + 0x3D), ' '); - out_8 ((volatile uchar *)(CONFIG_SYS_DISPLAY_BASE + 0x3E), ' '); - out_8 ((volatile uchar *)(CONFIG_SYS_DISPLAY_BASE + 0x3F), ' '); - - return 0; -} - -int board_early_init_r (void) -{ - out_be32 ((unsigned __iomem *)MPC5XXX_BOOTCS_CFG, in_be32 ((unsigned __iomem *)MPC5XXX_BOOTCS_CFG) & ~0x1); - out_be32 ((unsigned __iomem *)MPC5XXX_BOOTCS_START, START_REG(CONFIG_SYS_FLASH_BASE)); - out_be32 ((unsigned __iomem *)MPC5XXX_CS0_START, START_REG(CONFIG_SYS_FLASH_BASE)); - out_be32 ((unsigned __iomem *)MPC5XXX_BOOTCS_STOP, - STOP_REG(CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_SIZE)); - out_be32 ((unsigned __iomem *)MPC5XXX_CS0_STOP, - STOP_REG(CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_SIZE)); - return 0; -} - -int last_stage_init (void) -{ - out_8 ((volatile uchar *)(CONFIG_SYS_DISPLAY_BASE + 0x38), 'M'); - out_8 ((volatile uchar *)(CONFIG_SYS_DISPLAY_BASE + 0x39), 'U'); - out_8 ((volatile uchar *)(CONFIG_SYS_DISPLAY_BASE + 0x3A), 'C'); - out_8 ((volatile uchar *)(CONFIG_SYS_DISPLAY_BASE + 0x3B), '.'); - out_8 ((volatile uchar *)(CONFIG_SYS_DISPLAY_BASE + 0x3C), 'M'); - out_8 ((volatile uchar *)(CONFIG_SYS_DISPLAY_BASE + 0x3D), 'C'); - out_8 ((volatile uchar *)(CONFIG_SYS_DISPLAY_BASE + 0x3E), '5'); - out_8 ((volatile uchar *)(CONFIG_SYS_DISPLAY_BASE + 0x3F), '2'); - - return 0; -} - -#if defined(CONFIG_HW_WATCHDOG) -#define GPT_OUT_0 0x00000027 -#define GPT_OUT_1 0x00000037 -void hw_watchdog_reset (void) -{ - /* Trigger HW Watchdog with TIMER_0 */ - out_be32 ((unsigned __iomem *)MPC5XXX_GPT0_ENABLE, GPT_OUT_1); - out_be32 ((unsigned __iomem *)MPC5XXX_GPT0_ENABLE, GPT_OUT_0); -} -#endif - -#ifdef CONFIG_PCI -static struct pci_controller hose; - -extern void pci_mpc5xxx_init (struct pci_controller *); - -void pci_init_board (void) -{ - pci_mpc5xxx_init (&hose); -} -#endif - -#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) -int ft_board_setup(void *blob, bd_t *bd) -{ - ft_cpu_setup(blob, bd); - - return 0; -} -#endif /* defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) */ diff --git a/board/manroland/uc100/Kconfig b/board/manroland/uc100/Kconfig deleted file mode 100644 index 08f681b..0000000 --- a/board/manroland/uc100/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_UC100 - -config SYS_BOARD - default "uc100" - -config SYS_VENDOR - default "manroland" - -config SYS_CONFIG_NAME - default "uc100" - -endif diff --git a/board/manroland/uc100/MAINTAINERS b/board/manroland/uc100/MAINTAINERS deleted file mode 100644 index 260471c..0000000 --- a/board/manroland/uc100/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -UC100 BOARD -M: Stefan Roese sr@denx.de -S: Maintained -F: board/manroland/uc100/ -F: include/configs/uc100.h -F: configs/uc100_defconfig diff --git a/board/manroland/uc100/Makefile b/board/manroland/uc100/Makefile deleted file mode 100644 index 8e69c52..0000000 --- a/board/manroland/uc100/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = uc100.o pcmcia.o diff --git a/board/manroland/uc100/pcmcia.c b/board/manroland/uc100/pcmcia.c deleted file mode 100644 index db3821a..0000000 --- a/board/manroland/uc100/pcmcia.c +++ /dev/null @@ -1,192 +0,0 @@ -#include <common.h> -#include <mpc8xx.h> -#include <pcmcia.h> - -#undef CONFIG_PCMCIA - -#if defined(CONFIG_CMD_PCMCIA) -#define CONFIG_PCMCIA -#endif - -#if (defined(CONFIG_CMD_IDE)) && defined(CONFIG_IDE_8xx_PCCARD) -#define CONFIG_PCMCIA -#endif - -#ifdef CONFIG_PCMCIA - -#define PCMCIA_BOARD_MSG "UC100" - -/* - * Remark: don't turn off OE "__MY_PCMCIA_GCRX_CXOE" on UC100 board. - * This leads to board-hangup! (sr, 8 Dez. 2004) - */ -static void cfg_ports (void) -{ - volatile immap_t *immap; - - immap = (immap_t *)CONFIG_SYS_IMMR; - - /* - * Configure Port A for MAX1602 PC-Card Power-Interface Switch - */ - immap->im_ioport.iop_padat &= ~0x8000; /* set port x output to low */ - immap->im_ioport.iop_padir |= 0x8000; /* enable port x as output */ - - debug ("Set Port A: PAR: %08x DIR: %08x DAT: %08x\n", - immap->im_ioport.iop_papar, immap->im_ioport.iop_padir, - immap->im_ioport.iop_padat); -} - -int pcmcia_hardware_enable(int slot) -{ - volatile immap_t *immap; - volatile pcmconf8xx_t *pcmp; - volatile sysconf8xx_t *sysp; - uint reg, mask; - - debug ("hardware_enable: " PCMCIA_BOARD_MSG " Slot %c\n", 'A'+slot); - - udelay(10000); - - immap = (immap_t *)CONFIG_SYS_IMMR; - sysp = (sysconf8xx_t *)(&(((immap_t *)CONFIG_SYS_IMMR)->im_siu_conf)); - pcmp = (pcmconf8xx_t *)(&(((immap_t *)CONFIG_SYS_IMMR)->im_pcmcia)); - - /* Configure Ports for TPS2211A PC-Card Power-Interface Switch */ - cfg_ports (); - - /* - * Configure SIUMCR to enable PCMCIA port B - * (VFLS[0:1] are not used for debugging, we connect FRZ# instead) - */ - sysp->sc_siumcr &= ~SIUMCR_DBGC11; /* set DBGC to 00 */ - - /* clear interrupt state, and disable interrupts */ - pcmp->pcmc_pscr = PCMCIA_MASK(_slot_); - pcmp->pcmc_per &= ~PCMCIA_MASK(_slot_); - - /* - * Disable interrupts, DMA, and PCMCIA buffers - * (isolate the interface) and assert RESET signal - */ - debug ("Disable PCMCIA buffers and assert RESET\n"); - reg = 0; - reg |= __MY_PCMCIA_GCRX_CXRESET; /* active high */ - PCMCIA_PGCRX(_slot_) = reg; - udelay(500); - - /* - * Make sure there is a card in the slot, then configure the interface. - */ - udelay(10000); - debug ("[%d] %s: PIPR(%p)=0x%x\n", - __LINE__,__FUNCTION__, - &(pcmp->pcmc_pipr),pcmp->pcmc_pipr); - if (pcmp->pcmc_pipr & (0x18000000 >> (slot << 4))) { - printf (" No Card found\n"); - return (1); - } - - /* - * Power On. - */ - mask = PCMCIA_VS1(slot) | PCMCIA_VS2(slot); - reg = pcmp->pcmc_pipr; - debug ("PIPR: 0x%x ==> VS1=o%s, VS2=o%s\n", - reg, - (reg&PCMCIA_VS1(slot))?"n":"ff", - (reg&PCMCIA_VS2(slot))?"n":"ff"); - - if ((reg & mask) == mask) - puts (" 5.0V card found: "); - else - puts (" 3.3V card found: "); - - /* switch VCC on */ - immap->im_ioport.iop_padat |= 0x8000; /* power enable 3.3V */ - - udelay(10000); - - debug ("Enable PCMCIA buffers and stop RESET\n"); - reg = PCMCIA_PGCRX(_slot_); - reg &= ~__MY_PCMCIA_GCRX_CXRESET; /* active high */ - reg &= ~__MY_PCMCIA_GCRX_CXOE; /* active low */ - PCMCIA_PGCRX(_slot_) = reg; - - udelay(250000); /* some cards need >150 ms to come up :-( */ - - debug ("# hardware_enable done\n"); - - return (0); -} - - -#if defined(CONFIG_CMD_PCMCIA) -int pcmcia_hardware_disable(int slot) -{ - volatile immap_t *immap; - volatile cpm8xx_t *cp; - volatile pcmconf8xx_t *pcmp; - u_long reg; - - debug ("hardware_disable: " PCMCIA_BOARD_MSG " Slot %c\n", 'A'+slot); - - immap = (immap_t *)CONFIG_SYS_IMMR; - pcmp = (pcmconf8xx_t *)(&(((immap_t *)CONFIG_SYS_IMMR)->im_pcmcia)); - - /* switch VCC off */ - immap->im_ioport.iop_padat &= ~0x8000; /* power disable 3.3V */ - - /* Configure PCMCIA General Control Register */ - debug ("Disable PCMCIA buffers and assert RESET\n"); - reg = 0; - reg |= __MY_PCMCIA_GCRX_CXRESET; /* active high */ - PCMCIA_PGCRX(_slot_) = reg; - - udelay(10000); - - return (0); -} -#endif - - -int pcmcia_voltage_set(int slot, int vcc, int vpp) -{ - u_long reg; - - debug ("voltage_set: " - PCMCIA_BOARD_MSG - " Slot %c, Vcc=%d.%d, Vpp=%d.%d\n", - 'A'+slot, vcc/10, vcc%10, vpp/10, vcc%10); - - /* - * Disable PCMCIA buffers (isolate the interface) - * and assert RESET signal - */ - debug ("Disable PCMCIA buffers and assert RESET\n"); - reg = PCMCIA_PGCRX(_slot_); - reg |= __MY_PCMCIA_GCRX_CXRESET; /* active high */ - PCMCIA_PGCRX(_slot_) = reg; - udelay(500); - - /* - * Configure Port C pins for - * 5 Volts Enable and 3 Volts enable, - * Turn all power pins to Hi-Z - */ - debug ("PCMCIA power OFF\n"); - cfg_ports (); /* Enables switch, but all in Hi-Z */ - - debug ("Enable PCMCIA buffers and stop RESET\n"); - reg = PCMCIA_PGCRX(_slot_); - reg &= ~__MY_PCMCIA_GCRX_CXRESET; /* active high */ - reg &= ~__MY_PCMCIA_GCRX_CXOE; /* active low */ - PCMCIA_PGCRX(_slot_) = reg; - udelay(500); - - debug ("voltage_set: " PCMCIA_BOARD_MSG " Slot %c, DONE\n", - slot+'A'); - return (0); -} - -#endif /* CONFIG_PCMCIA */ diff --git a/board/manroland/uc100/uc100.c b/board/manroland/uc100/uc100.c deleted file mode 100644 index 31f08dd..0000000 --- a/board/manroland/uc100/uc100.c +++ /dev/null @@ -1,254 +0,0 @@ -/* - * (C) Copyright 2000-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#if 0 -#define DEBUG -#endif - -#include <common.h> -#include <mpc8xx.h> -#include <i2c.h> -#include <miiphy.h> - -int fec8xx_miiphy_write(char *devname, unsigned char addr, - unsigned char reg, unsigned short value); - -/*********************************************************************/ -/* UPMA Pre Initilization Table by WV (Miron MT48LC16M16A2-7E B) */ -/*********************************************************************/ -const uint sdram_init_upm_table[] = { - /* SDRAM Initialisation Sequence (offset 0 in UPMA RAM) WV */ - /* NOP - Precharge - AutoRefr - NOP - NOP */ - /* NOP - AutoRefr - NOP */ - /* NOP - NOP - LoadModeR - NOP - Active */ - /* Position of Single Read */ - 0x0ffffc04, 0x0ff77c04, 0x0ff5fc04, 0x0ffffc04, 0x0ffffc04, - 0x0ffffc04, 0x0ff5fc04, 0x0ffffc04, - - /* Burst Read. (offset 8 in UPMA RAM) */ - /* Cycle lent for Initialisation WV */ - 0x0ffffc04, 0x0ffffc34, 0x0f057c34, 0x0ffffc30, 0x1ff7fc05, - 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, - 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, - - /* Single Write. (offset 18 in UPMA RAM) */ - 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, - 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, - - /* Burst Write. (offset 20 in UPMA RAM) */ - 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, - 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, - 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, - - /* Refresh (offset 30 in UPMA RAM) */ - 0x0FF77C04, 0x0FFFFC04, 0x0FF5FC84, 0x0FFFFC04, 0x0FFFFC04, - 0x0FFFFC84, 0x1FFFFC05, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, - 0xFFFFFFFF, 0xFFFFFFFF, - - /* Exception. (offset 3c in UPMA RAM) */ - 0x7FFFFC05, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, -}; - -/*********************************************************************/ -/* UPMA initilization table. */ -/*********************************************************************/ -const uint sdram_upm_table[] = { - /* single read. (offset 0 in UPMA RAM) */ - 0x0F07FC04, 0x0FFFFC04, 0x00BDFC04, 0x0FF77C00, 0x1FFFFC05, - 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, /* 0x05-0x07 new WV */ - - /* Burst Read. (offset 8 in UPMA RAM) */ - 0x0F07FC04, 0x0FFFFC04, 0x00BDFC04, 0x00FFFC00, 0x00FFFC00, - 0x00FFFC00, 0x0FF77C00, 0x1FFFFC05, 0xFFFFFFFF, 0xFFFFFFFF, - 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, - - /* Single Write. (offset 18 in UPMA RAM) */ - 0x0F07FC04, 0x0FFFFC00, 0x00BD7C04, 0x0FFFFC04, 0x0FF77C04, - 0x1FFFFC05, 0xFFFFFFFF, 0xFFFFFFFF, - - /* Burst Write. (offset 20 in UPMA RAM) */ - 0x0F07FC04, 0x0FFFFC00, 0x00BD7C00, 0x00FFFC00, 0x00FFFC00, - 0x00FFFC04, 0x0FFFFC04, 0x0FF77C04, 0x1FFFFC05, 0xFFFFFFFF, - 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, - - /* Refresh (offset 30 in UPMA RAM) */ - 0x0FF77C04, 0x0FFFFC04, 0x0FF5FC84, 0x0FFFFC04, 0x0FFFFC04, - 0x0FFFFC84, 0x1FFFFC05, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, - 0xFFFFFFFF, 0xFFFFFFFF, - - /* Exception. (offset 3c in UPMA RAM) */ - 0x7FFFFC05, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, /* 0x3C new WV */ -}; - -/*********************************************************************/ -/* UPMB initilization table. */ -/*********************************************************************/ -const uint mpm_upm_table[] = { - /* single read. (offset 0 in upm RAM) */ - 0x8FF00004, 0x0FF00004, 0x0FF81004, 0x1FF00001, - 0x1FF00001, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, - - /* burst read. (Offset 8 in upm RAM) */ - 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, - 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, - 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, - 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, - - /* single write. (Offset 0x18 in upm RAM) */ - 0x8FF00004, 0x0FF00004, 0x0FF81004, 0x0FF00004, - 0x0FF00004, 0x1FF00001, 0xFFFFFFFF, 0xFFFFFFFF, - - /* burst write. (Offset 0x20 in upm RAM) */ - 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, - 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, - 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, - 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, - - /* Refresh cycle, offset 0x30 */ - 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, - 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, - 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, - - /* Exception, 0ffset 0x3C */ - 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, -}; - - -int board_switch(void) -{ - volatile pcmconf8xx_t *pcmp; - - pcmp = (pcmconf8xx_t *)(&(((immap_t *)CONFIG_SYS_IMMR)->im_pcmcia)); - - return ((pcmp->pcmc_pipr >> 24) & 0xf); -} - - -/* - * Check Board Identity: - */ -int checkboard (void) -{ - char str[64]; - int i = getenv_f("serial#", str, sizeof(str)); - - puts ("Board: "); - - if (i == -1) { - puts ("### No HW ID - assuming UC100"); - } else { - puts(str); - } - - printf (" (SWITCH=%1X)\n", board_switch()); - - return 0; -} - - -/* - * Initialize SDRAM - */ -phys_size_t initdram (int board_type) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - - /*---------------------------------------------------------------------*/ - /* Initialize the UPMA/UPMB registers with the appropriate table. */ - /*---------------------------------------------------------------------*/ - upmconfig (UPMA, (uint *) sdram_init_upm_table, - sizeof (sdram_init_upm_table) / sizeof (uint)); - upmconfig (UPMB, (uint *) mpm_upm_table, - sizeof (mpm_upm_table) / sizeof (uint)); - - /*---------------------------------------------------------------------*/ - /* Memory Periodic Timer Prescaler: divide by 16 */ - /*---------------------------------------------------------------------*/ - memctl->memc_mptpr = 0x0200; /* Divide by 32 WV */ - - memctl->memc_mamr = CONFIG_SYS_MAMR_VAL & 0xFF7FFFFF; /* Bit 8 := "0" Kein Refresh WV */ - memctl->memc_mbmr = CONFIG_SYS_MBMR_VAL; - - /*---------------------------------------------------------------------*/ - /* Initialize the Memory Controller registers, MPTPR, Chip Select 1 */ - /* for SDRAM */ - /* */ - /* NOTE: The refresh rate in MAMR reg is set according to the lowest */ - /* clock rate (16.67MHz) to allow proper operation for all ADS */ - /* clock frequencies. */ - /*---------------------------------------------------------------------*/ - memctl->memc_or1 = CONFIG_SYS_OR1_PRELIM; - memctl->memc_br1 = CONFIG_SYS_BR1_PRELIM; - - /*-------------------------------------------------------------------*/ - /* Wait at least 200 usec for DRAM to stabilize, this magic number */ - /* obtained from the init code. */ - /*-------------------------------------------------------------------*/ - udelay(200); - - memctl->memc_mamr = (memctl->memc_mamr | 0x04) & ~0x08; - - memctl->memc_br1 = CONFIG_SYS_BR1_PRELIM; - memctl->memc_or1 = CONFIG_SYS_OR1_PRELIM; - - /*---------------------------------------------------------------------*/ - /* run MRS command in location 5-8 of UPMB. */ - /*---------------------------------------------------------------------*/ - memctl->memc_mar = 0x88; - /* RUN UPMA on CS1 1-time from UPMA addr 0x05 */ - - memctl->memc_mcr = 0x80002100; - /* RUN UPMA on CS1 1-time from UPMA addr 0x00 WV */ - - udelay(200); - - /*---------------------------------------------------------------------*/ - /* Initialisation for normal access WV */ - /*---------------------------------------------------------------------*/ - - /*---------------------------------------------------------------------*/ - /* Initialize the UPMA register with the appropriate table. */ - /*---------------------------------------------------------------------*/ - upmconfig (UPMA, (uint *) sdram_upm_table, - sizeof (sdram_upm_table) / sizeof (uint)); - - /*---------------------------------------------------------------------*/ - /* rerstore MBMR value (4-beat refresh burst.) */ - /*---------------------------------------------------------------------*/ - memctl->memc_mamr = CONFIG_SYS_MAMR_VAL | 0x00800000; /* Bit 8 := "1" Refresh Enable WV */ - - udelay(200); - - return (64 * 1024 * 1024); /* fixed setup for 64MBytes! */ -} - - -int misc_init_r (void) -{ - uchar val; - - /* - * Make sure that RTC has clock output enabled (triggers watchdog!) - */ - val = i2c_reg_read (CONFIG_SYS_I2C_RTC_ADDR, 0x0D); - val |= 0x80; - i2c_reg_write (CONFIG_SYS_I2C_RTC_ADDR, 0x0D, val); - - /* - * Configure PHY to setup LED's correctly and use 100MBit, FD - */ - mii_init(); - - /* disable auto-negotiation, 100mbit, full-duplex */ - fec8xx_miiphy_write(NULL, 0, MII_BMCR, 0x2100); - - /* set LED's to Link, Transmit, Receive */ - fec8xx_miiphy_write(NULL, 0, MII_NWAYTEST, 0x4122); - - return 0; -} diff --git a/board/manroland/uc101/Kconfig b/board/manroland/uc101/Kconfig deleted file mode 100644 index c285b22..0000000 --- a/board/manroland/uc101/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_UC101 - -config SYS_BOARD - default "uc101" - -config SYS_VENDOR - default "manroland" - -config SYS_CONFIG_NAME - default "uc101" - -endif diff --git a/board/manroland/uc101/MAINTAINERS b/board/manroland/uc101/MAINTAINERS deleted file mode 100644 index 0fc7b85..0000000 --- a/board/manroland/uc101/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -UC101 BOARD -M: Heiko Schocher hs@denx.de -S: Maintained -F: board/manroland/uc101/ -F: include/configs/uc101.h -F: configs/uc101_defconfig diff --git a/board/manroland/uc101/Makefile b/board/manroland/uc101/Makefile deleted file mode 100644 index 9289d91..0000000 --- a/board/manroland/uc101/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2003-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y := uc101.o diff --git a/board/manroland/uc101/uc101.c b/board/manroland/uc101/uc101.c deleted file mode 100644 index e794c46..0000000 --- a/board/manroland/uc101/uc101.c +++ /dev/null @@ -1,367 +0,0 @@ -/* - * (C) Copyright 2006 - * Heiko Schocher, DENX Software Engineering, hs@denx.de. - * - * (C) Copyright 2003-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * (C) Copyright 2004 - * Mark Jonas, Freescale Semiconductor, mark.jonas@motorola.com. - * - * (C) Copyright 2004 - * Martin Krause, TQ-Systems GmbH, martin.krause@tqs.de - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <fdt_support.h> -#include <mpc5xxx.h> -#include <pci.h> -#include <malloc.h> - -/* some SIMPLE GPIO Pins */ -#define GPIO_USB_8 (31-12) -#define GPIO_USB_7 (31-13) -#define GPIO_USB_6 (31-14) -#define GPIO_USB_0 (31-15) -#define GPIO_PSC3_7 (31-18) -#define GPIO_PSC3_6 (31-19) -#define GPIO_PSC3_1 (31-22) -#define GPIO_PSC3_0 (31-23) - -/* some simple Interrupt GPIO Pins */ -#define GPIO_PSC3_8 2 -#define GPIO_USB1_9 3 - -#define GPT_OUT_0 0x00000027 -#define GPT_OUT_1 0x00000037 -#define GPT_DISABLE 0x00000000 /* GPT pin disabled */ - -#define GP_SIMP_ENABLE_O(n, v) {pgpio->simple_dvo |= (v << n); \ - pgpio->simple_ddr |= (1 << n); \ - pgpio->simple_gpioe |= (1 << n); \ - } - -#define GP_SIMP_ENABLE_I(n) { pgpio->simple_ddr |= ~(1 << n); \ - pgpio->simple_gpioe |= (1 << n); \ - } - -#define GP_SIMP_SET_O(n, v) (pgpio->simple_dvo = v ? \ - (pgpio->simple_dvo | (1 << n)) : \ - (pgpio->simple_dvo & ~(1 << n)) ) - -#define GP_SIMP_GET_O(n) ((pgpio->simple_dvo >> n) & 1) -#define GP_SIMP_GET_I(n) ((pgpio->simple_ival >> n) & 1) - -#define GP_SINT_SET_O(n, v) (pgpio->sint_dvo = v ? \ - (pgpio->sint_dvo | (1 << n)) : \ - (pgpio->sint_dvo & ~(1 << n)) ) - -#define GP_SINT_ENABLE_O(n, v) {pgpio->sint_ode &= ~(1 << n); \ - pgpio->sint_ddr |= (1 << n); \ - GP_SINT_SET_O(n, v); \ - pgpio->sint_gpioe |= (1 << n); \ - } - -#define GP_SINT_ENABLE_I(n) { pgpio->sint_ddr |= ~(1 << n); \ - pgpio->sint_gpioe |= (1 << n); \ - } - -#define GP_SINT_GET_O(n) ((pgpio->sint_ival >> n) & 1) -#define GP_SINT_GET_I(n) ((pgpio-ntt_ival >> n) & 1) - -#define GP_TIMER_ENABLE_O(n, v) ( \ - ((volatile struct mpc5xxx_gpt *)(MPC5XXX_GPT + n))->emsr = v ? \ - GPT_OUT_1 : \ - GPT_OUT_0 ) - -#define GP_TIMER_SET_O(n, v) GP_TIMER_ENABLE_O(n, v) - -#define GP_TIMER_GET_O(n, v) ( \ - (((volatile struct mpc5xxx_gpt *)(MPC5XXX_GPT + n))->emsr & 0x10) >> 4) - -#define GP_TIMER_GET_I(n, v) ( \ - (((volatile struct mpc5xxx_gpt *)(MPC5XXX_GPT + n))->sr & 0x100) >> 8) - -#ifndef CONFIG_SYS_RAMBOOT -static void sdram_start (int hi_addr) -{ - long hi_addr_bit = hi_addr ? 0x01000000 : 0; - - /* unlock mode register */ - *(vu_long *)MPC5XXX_SDRAM_CTRL = SDRAM_CONTROL | 0x80000000 | hi_addr_bit; - __asm__ volatile ("sync"); - - /* precharge all banks */ - *(vu_long *)MPC5XXX_SDRAM_CTRL = SDRAM_CONTROL | 0x80000002 | hi_addr_bit; - __asm__ volatile ("sync"); - -#if SDRAM_DDR - /* set mode register: extended mode */ - *(vu_long *)MPC5XXX_SDRAM_MODE = SDRAM_EMODE; - __asm__ volatile ("sync"); - - /* set mode register: reset DLL */ - *(vu_long *)MPC5XXX_SDRAM_MODE = SDRAM_MODE | 0x04000000; - __asm__ volatile ("sync"); -#endif - - /* precharge all banks */ - *(vu_long *)MPC5XXX_SDRAM_CTRL = SDRAM_CONTROL | 0x80000002 | hi_addr_bit; - __asm__ volatile ("sync"); - - /* auto refresh */ - *(vu_long *)MPC5XXX_SDRAM_CTRL = SDRAM_CONTROL | 0x80000004 | hi_addr_bit; - __asm__ volatile ("sync"); - - /* set mode register */ - *(vu_long *)MPC5XXX_SDRAM_MODE = SDRAM_MODE; - __asm__ volatile ("sync"); - - /* normal operation */ - *(vu_long *)MPC5XXX_SDRAM_CTRL = SDRAM_CONTROL | hi_addr_bit; - __asm__ volatile ("sync"); -} -#endif - -/* - * ATTENTION: Although partially referenced initdram does NOT make real use - * use of CONFIG_SYS_SDRAM_BASE. The code does not work if CONFIG_SYS_SDRAM_BASE - * is something else than 0x00000000. - */ - -phys_size_t initdram (int board_type) -{ - ulong dramsize = 0; -#ifndef CONFIG_SYS_RAMBOOT - ulong test1, test2; - - /* setup SDRAM chip selects */ - *(vu_long *)MPC5XXX_SDRAM_CS0CFG = 0x0000001c; /* 512MB at 0x0 */ - *(vu_long *)MPC5XXX_SDRAM_CS1CFG = 0x40000000; /* disabled */ - __asm__ volatile ("sync"); - - /* setup config registers */ - *(vu_long *)MPC5XXX_SDRAM_CONFIG1 = SDRAM_CONFIG1; - *(vu_long *)MPC5XXX_SDRAM_CONFIG2 = SDRAM_CONFIG2; - __asm__ volatile ("sync"); - -#if SDRAM_DDR - /* set tap delay */ - *(vu_long *)MPC5XXX_CDM_PORCFG = SDRAM_TAPDELAY; - __asm__ volatile ("sync"); -#endif - - /* find RAM size using SDRAM CS0 only */ - sdram_start(0); - test1 = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, 0x20000000); - sdram_start(1); - test2 = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, 0x20000000); - if (test1 > test2) { - sdram_start(0); - dramsize = test1; - } else { - dramsize = test2; - } - - /* memory smaller than 1MB is impossible */ - if (dramsize < (1 << 20)) { - dramsize = 0; - } - - /* set SDRAM CS0 size according to the amount of RAM found */ - if (dramsize > 0) { - *(vu_long *)MPC5XXX_SDRAM_CS0CFG = 0x13 + - __builtin_ffs(dramsize >> 20) - 1; - } else { - *(vu_long *)MPC5XXX_SDRAM_CS0CFG = 0; /* disabled */ - } - - *(vu_long *)MPC5XXX_SDRAM_CS1CFG = dramsize; /* disabled */ -#else /* CONFIG_SYS_RAMBOOT */ - - /* retrieve size of memory connected to SDRAM CS0 */ - dramsize = *(vu_long *)MPC5XXX_SDRAM_CS0CFG & 0xFF; - if (dramsize >= 0x13) { - dramsize = (1 << (dramsize - 0x13)) << 20; - } else { - dramsize = 0; - } - - /* retrieve size of memory connected to SDRAM CS1 */ - dramsize2 = *(vu_long *)MPC5XXX_SDRAM_CS1CFG & 0xFF; - if (dramsize2 >= 0x13) { - dramsize2 = (1 << (dramsize2 - 0x13)) << 20; - } else { - dramsize2 = 0; - } - -#endif /* CONFIG_SYS_RAMBOOT */ - -/* return dramsize + dramsize2; */ - return dramsize; -} - -int checkboard (void) -{ - puts ("Board: MAN UC101\n"); - /* clear the Display */ - *(char *)(CONFIG_SYS_DISP_CWORD) = 0x80; - return 0; -} - -static void init_ports (void) -{ - volatile struct mpc5xxx_gpio *pgpio = - (struct mpc5xxx_gpio *)MPC5XXX_GPIO; - - GP_SIMP_ENABLE_I(GPIO_USB_8); /* HEX Bit 3 */ - GP_SIMP_ENABLE_I(GPIO_USB_7); /* HEX Bit 2 */ - GP_SIMP_ENABLE_I(GPIO_USB_6); /* HEX Bit 1 */ - GP_SIMP_ENABLE_I(GPIO_USB_0); /* HEX Bit 0 */ - GP_SIMP_ENABLE_I(GPIO_PSC3_0); /* Switch Menue A */ - GP_SIMP_ENABLE_I(GPIO_PSC3_1); /* Switch Menue B */ - GP_SIMP_ENABLE_I(GPIO_PSC3_6); /* Switch Cold_Warm */ - GP_SIMP_ENABLE_I(GPIO_PSC3_7); /* Switch Restart */ - GP_SINT_ENABLE_O(GPIO_PSC3_8, 0); /* LED H2 */ - GP_SINT_ENABLE_O(GPIO_USB1_9, 0); /* LED H3 */ - GP_TIMER_ENABLE_O(4, 0); /* LED H4 */ - GP_TIMER_ENABLE_O(5, 0); /* LED H5 */ - GP_TIMER_ENABLE_O(3, 0); /* LED HB */ - GP_TIMER_ENABLE_O(1, 0); /* RES_COLDSTART */ -} - -#ifdef CONFIG_PREBOOT - -static uchar kbd_magic_prefix[] = "key_magic"; -static uchar kbd_command_prefix[] = "key_cmd"; - -struct kbd_data_t { - char s1; -}; - -struct kbd_data_t* get_keys (struct kbd_data_t *kbd_data) -{ - volatile struct mpc5xxx_gpio *pgpio = - (struct mpc5xxx_gpio *)MPC5XXX_GPIO; - - kbd_data->s1 = GP_SIMP_GET_I(GPIO_USB_8) << 3 | \ - GP_SIMP_GET_I(GPIO_USB_7) << 2 | \ - GP_SIMP_GET_I(GPIO_USB_6) << 1 | \ - GP_SIMP_GET_I(GPIO_USB_0) << 0; - return kbd_data; -} - -static int compare_magic (const struct kbd_data_t *kbd_data, char *str) -{ - char s1 = str[0]; - - if (s1 >= '0' && s1 <= '9') - s1 -= '0'; - else if (s1 >= 'a' && s1 <= 'f') - s1 = s1 - 'a' + 10; - else if (s1 >= 'A' && s1 <= 'F') - s1 = s1 - 'A' + 10; - else - return -1; - - if (s1 != kbd_data->s1) return -1; - return 0; -} - -static char *key_match (const struct kbd_data_t *kbd_data) -{ - char magic[sizeof (kbd_magic_prefix) + 1]; - char *suffix; - char *kbd_magic_keys; - - /* - * The following string defines the characters that can be appended - * to "key_magic" to form the names of environment variables that - * hold "magic" key codes, i. e. such key codes that can cause - * pre-boot actions. If the string is empty (""), then only - * "key_magic" is checked (old behaviour); the string "125" causes - * checks for "key_magic1", "key_magic2" and "key_magic5", etc. - */ - if ((kbd_magic_keys = getenv ("magic_keys")) == NULL) - kbd_magic_keys = ""; - - /* loop over all magic keys; - * use '\0' suffix in case of empty string - */ - for (suffix = kbd_magic_keys; *suffix || - suffix == kbd_magic_keys; ++suffix) { - sprintf (magic, "%s%c", kbd_magic_prefix, *suffix); - - if (compare_magic(kbd_data, getenv(magic)) == 0) { - char cmd_name[sizeof (kbd_command_prefix) + 1]; - char *cmd; - - sprintf (cmd_name, "%s%c", kbd_command_prefix, *suffix); - cmd = getenv (cmd_name); - - return (cmd); - } - } - - return (NULL); -} - -#endif /* CONFIG_PREBOOT */ - -int misc_init_r (void) -{ - /* Init the I/O ports */ - init_ports (); - -#ifdef CONFIG_PREBOOT - struct kbd_data_t kbd_data; - /* Decode keys */ - char *str = strdup (key_match (get_keys (&kbd_data))); - /* Set or delete definition */ - setenv ("preboot", str); - free (str); -#endif /* CONFIG_PREBOOT */ - return 0; -} - -int board_early_init_r (void) -{ - *(vu_long *)MPC5XXX_BOOTCS_CFG &= ~0x1; /* clear RO */ - *(vu_long *)MPC5XXX_BOOTCS_START = - *(vu_long *)MPC5XXX_CS0_START = START_REG(CONFIG_SYS_FLASH_BASE); - *(vu_long *)MPC5XXX_BOOTCS_STOP = - *(vu_long *)MPC5XXX_CS0_STOP = STOP_REG(CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_SIZE); - /* Interbus enable it here ?? */ - *(vu_long *)MPC5XXX_GPT6_ENABLE = GPT_OUT_1; - return 0; -} -#ifdef CONFIG_PCI -static struct pci_controller hose; - -extern void pci_mpc5xxx_init(struct pci_controller *); - -void pci_init_board(void) -{ - pci_mpc5xxx_init(&hose); -} -#endif - -#if defined(CONFIG_HW_WATCHDOG) -void hw_watchdog_reset(void) -{ - /* Trigger HW Watchdog with TIMER_0 */ - *(vu_long *)MPC5XXX_GPT0_ENABLE = GPT_OUT_1; - *(vu_long *)MPC5XXX_GPT0_ENABLE = GPT_OUT_0; -} -#endif - -#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) -int ft_board_setup(void *blob, bd_t *bd) -{ - ft_cpu_setup(blob, bd); - - return 0; -} -#endif /* defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) */ diff --git a/configs/hmi1001_defconfig b/configs/hmi1001_defconfig deleted file mode 100644 index a351dbe..0000000 --- a/configs/hmi1001_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_MPC5xxx=y -CONFIG_TARGET_HMI1001=y diff --git a/configs/mucmc52_defconfig b/configs/mucmc52_defconfig deleted file mode 100644 index 1e49695..0000000 --- a/configs/mucmc52_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_MPC5xxx=y -CONFIG_TARGET_MUCMC52=y diff --git a/configs/uc100_defconfig b/configs/uc100_defconfig deleted file mode 100644 index 76eeb11..0000000 --- a/configs/uc100_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_UC100=y diff --git a/configs/uc101_defconfig b/configs/uc101_defconfig deleted file mode 100644 index b365bff..0000000 --- a/configs/uc101_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_MPC5xxx=y -CONFIG_TARGET_UC101=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 3cf32e7..8bd7056 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,10 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +hmi1001 powerpc mpc5xxx - - +mucmc52 powerpc mpc5xxx - - Heiko Schocher hs@denx.de +uc101 powerpc mpc5xxx - - Heiko Schocher hs@denx.de +uc100 powerpc mpc8xx - - Stefan Roese sr@denx.de FPS850L powerpc mpc8xx - - Wolfgang Denk wd@denx.de FPS860L powerpc mpc8xx - - Wolfgang Denk wd@denx.de NSCU powerpc mpc8xx - - diff --git a/drivers/net/mpc5xxx_fec.c b/drivers/net/mpc5xxx_fec.c index 1093ba5..d9d6f4f 100644 --- a/drivers/net/mpc5xxx_fec.c +++ b/drivers/net/mpc5xxx_fec.c @@ -476,11 +476,6 @@ static int mpc5xxx_fec_init_phy(struct eth_device *dev, bd_t * bis) miiphy_write(dev->name, phyAddr, 0x0, 0x8000); udelay(1000);
-#if defined(CONFIG_UC101) || defined(CONFIG_MUCMC52) - /* Set the LED configuration Register for the UC101 - and MUCMC52 Board */ - miiphy_write(dev->name, phyAddr, 0x14, 0x4122); -#endif if (fec->xcv_type == MII10) { /* * Force 10Base-T, FDX operation diff --git a/drivers/video/smiLynxEM.c b/drivers/video/smiLynxEM.c index 614bcb3..1880ccc 100644 --- a/drivers/video/smiLynxEM.c +++ b/drivers/video/smiLynxEM.c @@ -131,9 +131,6 @@ static char SMI_PCR [] = { }; static char SMI_MCR[] = { 0x60, 0x01, 0x61, 0x00, -#ifdef CONFIG_HMI1001 - 0x62, 0x74, /* Memory type is not configured by pins on HMI1001 */ -#endif };
static char SMI_HCR[] = { diff --git a/include/configs/hmi1001.h b/include/configs/hmi1001.h deleted file mode 100644 index a1a88b5..0000000 --- a/include/configs/hmi1001.h +++ /dev/null @@ -1,339 +0,0 @@ -/* - * (C) Copyright 2003-2005 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC5200 1 /* This is an MPC5200 CPU */ -#define CONFIG_HMI1001 1 /* HMI1001 board */ - -#ifndef CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_TEXT_BASE 0xFFF00000 -#endif - -#define CONFIG_SYS_MPC5XXX_CLKIN 33000000 /* ... running at 33.000000MHz */ - -#define CONFIG_BOARD_EARLY_INIT_R - -#define CONFIG_HIGH_BATS 1 /* High BATs supported */ - -/* - * Serial console configuration - */ -#define CONFIG_PSC_CONSOLE 1 /* console is on PSC1 */ -#define CONFIG_BAUDRATE 115200 /* ... at 115200 bps */ -#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 } - -/* Partitions */ -#define CONFIG_DOS_PARTITION - - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_DATE -#define CONFIG_CMD_DISPLAY -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C -#define CONFIG_CMD_IDE -#define CONFIG_CMD_NFS -#define CONFIG_CMD_PCI -#define CONFIG_CMD_SNTP - - -#define CONFIG_TIMESTAMP 1 /* Print image info with timestamp */ - -#if (CONFIG_SYS_TEXT_BASE == 0xFFF00000) /* Boot low */ -# define CONFIG_SYS_LOWBOOT 1 -#endif - -/* - * Autobooting - */ -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ - -#define CONFIG_PREBOOT "echo;" \ - "echo Type \"run flash_nfs\" to mount root filesystem over NFS;" \ - "echo" - -#undef CONFIG_BOOTARGS - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=eth0\0" \ - "nfsargs=setenv bootargs root=/dev/nfs rw " \ - "nfsroot=${serverip}:${rootpath}\0" \ - "ramargs=setenv bootargs root=/dev/ram rw\0" \ - "addip=setenv bootargs ${bootargs} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ - ":${hostname}:${netdev}:off panic=1\0" \ - "flash_nfs=run nfsargs addip;" \ - "bootm ${kernel_addr}\0" \ - "net_nfs=tftp 200000 ${bootfile};run nfsargs addip;bootm\0" \ - "rootpath=/opt/eldk/ppc_82xx\0" \ - "" - -#define CONFIG_BOOTCOMMAND "run net_nfs" - -#define CONFIG_MISC_INIT_R 1 - -/* - * IPB Bus clocking configuration. - */ -#undef CONFIG_SYS_IPBCLK_EQUALS_XLBCLK /* define for 133MHz speed */ - -/* - * I2C configuration - */ -#define CONFIG_HARD_I2C 1 /* I2C with hardware support */ -#define CONFIG_SYS_I2C_MODULE 2 /* Select I2C module #1 or #2 */ - -#define CONFIG_SYS_I2C_SPEED 100000 /* 100 kHz */ -#define CONFIG_SYS_I2C_SLAVE 0x7F - -/* - * EEPROM configuration - */ -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x58 -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 - -/* - * RTC configuration - */ -#define CONFIG_RTC_PCF8563 -#define CONFIG_SYS_I2C_RTC_ADDR 0x51 - -/* - * Flash configuration - */ -#define CONFIG_SYS_FLASH_BASE 0xFF800000 - -#define CONFIG_SYS_FLASH_SIZE 0x00800000 /* 8 MByte */ -#define CONFIG_SYS_MAX_FLASH_SECT 67 /* max num of sects on one chip */ - -#define CONFIG_ENV_ADDR (CONFIG_SYS_TEXT_BASE+0x40000) /* second sector */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max num of flash banks - (= chip selects) */ -#define CONFIG_SYS_FLASH_ERASE_TOUT 240000 /* Flash Erase Timeout (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (in ms) */ - -#define CONFIG_FLASH_CFI_DRIVER -#define CONFIG_SYS_FLASH_CFI -#define CONFIG_SYS_FLASH_EMPTY_INFO -#define CONFIG_SYS_FLASH_CFI_AMD_RESET - -/* - * Environment settings - */ -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_SIZE 0x4000 -#define CONFIG_ENV_SECT_SIZE 0x20000 -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET+CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) - -/* - * Memory map - */ -#define CONFIG_SYS_MBAR 0xF0000000 -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_DEFAULT_MBAR 0x80000000 -#define CONFIG_SYS_DISPLAY_BASE 0x80600000 -#define CONFIG_SYS_STATUS1_BASE 0x80600200 -#define CONFIG_SYS_STATUS2_BASE 0x80600300 - -/* Settings for XLB = 132 MHz */ -#define SDRAM_DDR 1 -#define SDRAM_MODE 0x018D0000 -#define SDRAM_EMODE 0x40090000 -#define SDRAM_CONTROL 0x714f0f00 -#define SDRAM_CONFIG1 0x73722930 -#define SDRAM_CONFIG2 0x47770000 -#define SDRAM_TAPDELAY 0x10000000 - -/* Use ON-Chip SRAM until RAM will be available */ -#define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM - -/* preserve space for the post_word at end of on-chip SRAM */ -#define MPC5XXX_SRAM_POST_SIZE (MPC5XXX_SRAM_SIZE - 4) - -#ifdef CONFIG_POST -#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_POST_SIZE -#else -#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE -#endif - -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE -#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) -# define CONFIG_SYS_RAMBOOT 1 -#endif - -#define CONFIG_SYS_MONITOR_LEN (192 << 10) /* Reserve 192 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (512 << 10) /* Reserve 128 kB for malloc() */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/* - * Ethernet configuration - */ -#define CONFIG_MPC5xxx_FEC 1 -#define CONFIG_MPC5xxx_FEC_MII100 -#define CONFIG_PHY_ADDR 0x00 -#define CONFIG_MII 1 /* MII PHY management */ - -/* - * GPIO configuration - */ -#define CONFIG_SYS_GPS_PORT_CONFIG 0x01051004 - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ -#if defined(CONFIG_CMD_KGDB) -# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - -/* Enable an alternate, more extensive memory test */ -#define CONFIG_SYS_ALT_MEMTEST - -#define CONFIG_SYS_MEMTEST_START 0x00100000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x00f00000 /* 1 ... 15 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -/* - * Enable loopw command. - */ -#define CONFIG_LOOPW - -/* - * Various low-level settings - */ -#define CONFIG_SYS_HID0_INIT HID0_ICE | HID0_ICFI -#define CONFIG_SYS_HID0_FINAL HID0_ICE - -#define CONFIG_SYS_BOOTCS_START CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_BOOTCS_SIZE CONFIG_SYS_FLASH_SIZE -#define CONFIG_SYS_BOOTCS_CFG 0x0004FB00 -#define CONFIG_SYS_CS0_START CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_CS0_SIZE CONFIG_SYS_FLASH_SIZE - -/* 8Mbit SRAM @0x80100000 */ -#define CONFIG_SYS_CS1_START 0x80100000 -#define CONFIG_SYS_CS1_SIZE 0x00100000 -#define CONFIG_SYS_CS1_CFG 0x19B00 - -/* FRAM 32Kbyte @0x80700000 */ -#define CONFIG_SYS_CS2_START 0x80700000 -#define CONFIG_SYS_CS2_SIZE 0x00008000 -#define CONFIG_SYS_CS2_CFG 0x19800 - -/* Display H1, Status Inputs, EPLD @0x80600000 */ -#define CONFIG_SYS_CS3_START 0x80600000 -#define CONFIG_SYS_CS3_SIZE 0x00100000 -#define CONFIG_SYS_CS3_CFG 0x00019800 - -#define CONFIG_SYS_CS_BURST 0x00000000 -#define CONFIG_SYS_CS_DEADCYCLE 0x33333333 - -/*----------------------------------------------------------------------- - * IDE/ATA stuff Supports IDE harddisk - *----------------------------------------------------------------------- - */ - -#undef CONFIG_IDE_8xx_PCCARD /* Use IDE with PC Card Adapter */ - -#undef CONFIG_IDE_8xx_DIRECT /* Direct IDE not supported */ -#undef CONFIG_IDE_LED /* LED for ide not supported */ - -#define CONFIG_SYS_IDE_MAXBUS 1 /* max. 1 IDE bus */ -#define CONFIG_SYS_IDE_MAXDEVICE 2 /* max. 2 drives per IDE bus */ - -#define CONFIG_IDE_PREINIT 1 - -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 - -#define CONFIG_SYS_ATA_BASE_ADDR MPC5XXX_ATA - -/* Offset for data I/O */ -#define CONFIG_SYS_ATA_DATA_OFFSET (0x0060) - -/* Offset for normal register accesses */ -#define CONFIG_SYS_ATA_REG_OFFSET (CONFIG_SYS_ATA_DATA_OFFSET) - -/* Offset for alternate registers */ -#define CONFIG_SYS_ATA_ALT_OFFSET (0x005C) - -/* Interval between registers */ -#define CONFIG_SYS_ATA_STRIDE 4 - -#define CONFIG_ATAPI 1 - -#define CONFIG_VIDEO_SMI_LYNXEM -#define CONFIG_CFB_CONSOLE -#define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_VIDEO_LOGO - -/* - * PCI Mapping: - * 0x40000000 - 0x4fffffff - PCI Memory - * 0x50000000 - 0x50ffffff - PCI IO Space - */ -#define CONFIG_PCI 1 -#define CONFIG_PCI_PNP 1 -#define CONFIG_PCI_SCAN_SHOW 1 -#define CONFIG_PCIAUTO_SKIP_HOST_BRIDGE 1 - -#define CONFIG_PCI_MEM_BUS 0x40000000 -#define CONFIG_PCI_MEM_PHYS CONFIG_PCI_MEM_BUS -#define CONFIG_PCI_MEM_SIZE 0x10000000 - -#define CONFIG_PCI_IO_BUS 0x50000000 -#define CONFIG_PCI_IO_PHYS CONFIG_PCI_IO_BUS -#define CONFIG_PCI_IO_SIZE 0x01000000 - -#define CONFIG_SYS_ISA_IO CONFIG_PCI_IO_BUS - -/*---------------------------------------------------------------------*/ -/* Display addresses */ -/*---------------------------------------------------------------------*/ - -#define CONFIG_PDSP188x -#define CONFIG_SYS_DISP_CHR_RAM (CONFIG_SYS_DISPLAY_BASE + 0x38) -#define CONFIG_SYS_DISP_CWORD (CONFIG_SYS_DISPLAY_BASE + 0x30) - -#endif /* __CONFIG_H */ diff --git a/include/configs/mucmc52.h b/include/configs/mucmc52.h deleted file mode 100644 index ff75ead..0000000 --- a/include/configs/mucmc52.h +++ /dev/null @@ -1,126 +0,0 @@ -/* - * (C) Copyright 2008-2009 - * Heiko Schocher, DENX Software Engineering, hs@denx.de. - * - * (C) Copyright 2003-2005 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MUCMC52 1 /* MUCMC52 board */ -#define CONFIG_HOSTNAME mucmc52 - -#ifndef CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_TEXT_BASE 0xFFF00000 -#endif - -#include "manroland/common.h" -#include "manroland/mpc5200-common.h" - -#define CONFIG_LAST_STAGE_INIT -/* - * Serial console configuration - */ -#define CONFIG_BAUDRATE 38400 /* ... at 38400 bps */ - -#define CONFIG_CMD_PCI - -/* - * Flash configuration - */ -#define CONFIG_SYS_MAX_FLASH_SECT 67 - -/* - * Environment settings - */ -#define CONFIG_ENV_SECT_SIZE 0x20000 - -/* - * Memory map - */ -#define CONFIG_SYS_STATUS1_BASE 0x80600200 -#define CONFIG_SYS_STATUS2_BASE 0x80600300 -#define CONFIG_SYS_PMI_UNI_BASE 0x80800000 -#define CONFIG_SYS_PMI_BROAD_BASE 0x80810000 - -/* - * GPIO configuration - */ -#define CONFIG_SYS_GPS_PORT_CONFIG 0x8D550644 - -#define CONFIG_SYS_MEMTEST_START 0x00100000 -#define CONFIG_SYS_MEMTEST_END 0x00f00000 - -#define CONFIG_SYS_LOAD_ADDR 0x100000 - -#define CONFIG_SYS_BOOTCS_CFG 0x0004FB00 - -/* 8Mbit SRAM @0x80100000 */ -#define CONFIG_SYS_CS1_SIZE 0x00100000 -#define CONFIG_SYS_CS1_CFG 0x00019B00 - -#define CONFIG_SYS_SRAM_SIZE CONFIG_SYS_CS1_SIZE - -/* FRAM 32Kbyte @0x80700000 */ -#define CONFIG_SYS_CS2_START 0x80700000 -#define CONFIG_SYS_CS2_SIZE 0x00008000 -#define CONFIG_SYS_CS2_CFG 0x00019800 - -/* Display H1, Status Inputs, EPLD @0x80600000 */ -#define CONFIG_SYS_CS3_START 0x80600000 -#define CONFIG_SYS_CS3_SIZE 0x00100000 -#define CONFIG_SYS_CS3_CFG 0x00019800 - -/* PMI Unicast 32Kbyte @0x80800000 */ -#define CONFIG_SYS_CS6_START CONFIG_SYS_PMI_UNI_BASE -#define CONFIG_SYS_CS6_SIZE 0x00008000 -#define CONFIG_SYS_CS6_CFG 0xFFFFF930 - -/* PMI Broadcast 32Kbyte @0x80810000 */ -#define CONFIG_SYS_CS7_START CONFIG_SYS_PMI_BROAD_BASE -#define CONFIG_SYS_CS7_SIZE 0x00008000 -#define CONFIG_SYS_CS7_CFG 0xFF00F930 - -/*----------------------------------------------------------------------- - * IDE/ATA stuff Supports IDE harddisk - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_IDE_MAXDEVICE 1 /* max. 2 drives per IDE bus */ - -/* - * PCI Mapping: - * 0x40000000 - 0x4fffffff - PCI Memory - * 0x50000000 - 0x50ffffff - PCI IO Space - */ -#define CONFIG_PCI 1 -#define CONFIG_PCI_PNP 1 -#define CONFIG_PCI_SCAN_SHOW 1 -#define CONFIG_PCIAUTO_SKIP_HOST_BRIDGE 1 - -#define CONFIG_PCI_MEM_BUS 0x40000000 -#define CONFIG_PCI_MEM_PHYS CONFIG_PCI_MEM_BUS -#define CONFIG_PCI_MEM_SIZE 0x10000000 - -#define CONFIG_PCI_IO_BUS 0x50000000 -#define CONFIG_PCI_IO_PHYS CONFIG_PCI_IO_BUS -#define CONFIG_PCI_IO_SIZE 0x01000000 - -#define CONFIG_SYS_ISA_IO CONFIG_PCI_IO_BUS - -/*---------------------------------------------------------------------*/ -/* Display addresses */ -/*---------------------------------------------------------------------*/ - -#define CONFIG_SYS_DISP_CHR_RAM (CONFIG_SYS_DISPLAY_BASE + 0x38) -#define CONFIG_SYS_DISP_CWORD (CONFIG_SYS_DISPLAY_BASE + 0x30) - -#endif /* __CONFIG_H */ diff --git a/include/configs/uc100.h b/include/configs/uc100.h deleted file mode 100644 index cad897f..0000000 --- a/include/configs/uc100.h +++ /dev/null @@ -1,482 +0,0 @@ -/* - * (C) Copyright 2000-2005 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC860 1 -#define CONFIG_MPC860T 1 -#define CONFIG_MPC862 1 /* enable 862 since the */ -#define CONFIG_MPC857 1 /* 857 is a variant of the 862 */ - -#define CONFIG_UC100 1 /* ...on a UC100 module */ - -#define CONFIG_SYS_TEXT_BASE 0x40700000 - -#define MPC8XX_FACT 4 /* Multiply by 4 */ -#define MPC8XX_XIN 25000000 /* 25.0 MHz in */ -#define CONFIG_8xx_GCLK_FREQ (MPC8XX_FACT * MPC8XX_XIN) - /* define if cant' use get_gclk_freq */ - -#define CONFIG_8xx_CONS_SMC1 1 /* Console is on SMC1 */ -#undef CONFIG_8xx_CONS_SMC2 -#undef CONFIG_8xx_CONS_NONE - -#define CONFIG_MISC_INIT_R 1 /* call misc_init_r() */ - -#define CONFIG_BAUDRATE 115200 /* console baudrate = 115kbps */ - -#define CONFIG_BOOTCOUNT_LIMIT - -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ - -#define CONFIG_BOARD_TYPES 1 /* support board types */ - -#define CONFIG_PREBOOT "echo;" \ - "echo Type \"run flash_nfs\" to mount root filesystem over NFS;" \ - "echo" - -#undef CONFIG_BOOTARGS - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=eth0\0" \ - "nfsargs=setenv bootargs root=/dev/nfs rw " \ - "nfsroot=${serverip}:${rootpath}\0" \ - "ramargs=setenv bootargs root=/dev/ram rw\0" \ - "addip=setenv bootargs ${bootargs} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ - ":${hostname}:${netdev}:off panic=1\0" \ - "addtty=setenv bootargs ${bootargs} console=ttyS0,${baudrate}\0"\ - "flash_nfs=run nfsargs addip addtty;" \ - "bootm ${kernel_addr}\0" \ - "flash_self=run ramargs addip addtty;" \ - "bootm ${kernel_addr} ${ramdisk_addr}\0" \ - "net_nfs=tftp 200000 ${bootfile};run nfsargs addip addtty;" \ - "bootm\0" \ - "rootpath=/opt/eldk/ppc_8xx\0" \ - "bootfile=/tftpboot/uc100/uImage\0" \ - "kernel_addr=40000000\0" \ - "ramdisk_addr=40100000\0" \ - "load=tftp 100000 /tftpboot/uc100/u-boot.bin\0" \ - "update=protect off 40700000 4073ffff;era 40700000 4073ffff;" \ - "cp.b 100000 40700000 ${filesize};" \ - "setenv filesize;saveenv\0" \ - "" -#define CONFIG_BOOTCOMMAND "run flash_self" - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -#undef CONFIG_STATUS_LED /* no status-led */ - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE - - -#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - -#undef CONFIG_RTC_MPC8xx -#define CONFIG_SYS_I2C_RTC_ADDR 0x51 /* PCF8563 RTC */ -#define CONFIG_RTC_PCF8563 /* use Philips PCF8563 RTC */ - -/* - * Power On Self Test support - */ -#define CONFIG_POST ( CONFIG_SYS_POST_CACHE | \ - CONFIG_SYS_POST_MEMORY | \ - CONFIG_SYS_POST_CPU | \ - CONFIG_SYS_POST_UART | \ - CONFIG_SYS_POST_SPR ) -#undef CONFIG_POST - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_EEPROM -#define CONFIG_CMD_ELF -#define CONFIG_CMD_FAT -#define CONFIG_CMD_I2C -#define CONFIG_CMD_IDE -#define CONFIG_CMD_MII -#define CONFIG_CMD_NFS -#define CONFIG_CMD_PING -#define CONFIG_CMD_SNTP - -#ifdef CONFIG_POST -#define CONFIG_CMD_DIAG -#endif - - -#define CONFIG_NETCONSOLE - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ - -#if 0 -#define CONFIG_SYS_HUSH_PARSER 1 /* use "hush" command parser */ -#endif - -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -#define CONFIG_AUTO_COMPLETE 1 /* add autocompletion support */ - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xF0000000 - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0x40000000 -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_FLASH_BASE+0x00700000) /* resetvec fff00100*/ -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -/*----------------------------------------------------------------------- - * Address accessed to reset the board - must not be mapped/assigned - */ -#define CONFIG_SYS_RESET_ADDRESS 0x90000000 - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_FLASH_CFI /* The flash is CFI compatible */ -#define CONFIG_FLASH_CFI_DRIVER /* Use common CFI driver */ -#define CONFIG_SYS_FLASH_CFI_AMD_RESET 1 /* AMD RESET for STM 29W320DB! */ - -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 256 /* max number of sectors on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ - -#define CONFIG_SYS_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */ - -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE+CONFIG_SYS_MONITOR_LEN) -#define CONFIG_ENV_SECT_SIZE 0x20000 /* size of one complete sector */ -#define CONFIG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */ - -/* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR+CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CACHELINE_SHIFT 4 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 11-9 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Software & Bus Monitor Timer max, Bus Monitor enable, SW Watchdog freeze - */ -#if defined(CONFIG_WATCHDOG) -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | \ - SYPCR_SWE | SYPCR_SWRI| SYPCR_SWP) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | SYPCR_SWP) -#endif - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 11-6 - *----------------------------------------------------------------------- - * PCMCIA config., multi-function pin tri-state - */ -#define CONFIG_SYS_SIUMCR (SIUMCR_FRC | SIUMCR_DBGC00 | SIUMCR_DBPC00 | SIUMCR_MLRC01) - -/*----------------------------------------------------------------------- - * TBSCR - Time Base Status and Control 11-26 - *----------------------------------------------------------------------- - * Clear Reference Interrupt Status, Timebase freezing enabled - */ -#define CONFIG_SYS_TBSCR (TBSCR_REFA | TBSCR_REFB | TBSCR_TBF) - -/*----------------------------------------------------------------------- - * RTCSC - Real-Time Clock Status and Control Register 11-27 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RTCSC (RTCSC_SEC | RTCSC_ALR | RTCSC_RTF| RTCSC_RTE) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 11-31 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Interrupt Timer freezing enabled - */ -#define CONFIG_SYS_PISCR (PISCR_PS | PISCR_PITF) - -/*----------------------------------------------------------------------- - * PLPRCR - PLL, Low-Power, and Reset Control Register 15-30 - *----------------------------------------------------------------------- - * Reset PLL lock status sticky bit, timer expired status bit and timer - * interrupt status bit - */ -#define CONFIG_SYS_PLPRCR (((MPC8XX_FACT-1) << PLPRCR_MF_SHIFT) | \ - PLPRCR_SPLSS | PLPRCR_TEXPS | PLPRCR_TMIST) - -/*----------------------------------------------------------------------- - * SCCR - System Clock and reset Control Register 15-27 - *----------------------------------------------------------------------- - * Set clock output, timebase and RTC source and divider, - * power management and some other internal clocks - */ -#define SCCR_MASK 0x00000000 -#define CONFIG_SYS_SCCR (SCCR_EBDF11) - -/*----------------------------------------------------------------------- - * PCMCIA stuff - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_PCMCIA_MEM_ADDR (0xE0000000) -#define CONFIG_SYS_PCMCIA_MEM_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_DMA_ADDR (0xE4000000) -#define CONFIG_SYS_PCMCIA_DMA_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_ATTRB_ADDR (0xE8000000) -#define CONFIG_SYS_PCMCIA_ATTRB_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_IO_ADDR (0xEC000000) -#define CONFIG_SYS_PCMCIA_IO_SIZE ( 64 << 20 ) - -/*----------------------------------------------------------------------- - * IDE/ATA stuff (Supports IDE harddisk on PCMCIA Adapter) - *----------------------------------------------------------------------- - */ - -#define CONFIG_IDE_PREINIT 1 /* Use preinit IDE hook */ -#define CONFIG_IDE_8xx_PCCARD 1 /* Use IDE with PC Card Adapter */ - -#undef CONFIG_IDE_8xx_DIRECT /* Direct IDE not supported */ -#undef CONFIG_IDE_LED /* LED for ide not supported */ -#undef CONFIG_IDE_RESET /* reset for ide not supported */ - -#define CONFIG_SYS_IDE_MAXBUS 1 /* max. 1 IDE bus */ -#define CONFIG_SYS_IDE_MAXDEVICE 1 /* max. 1 drive per IDE bus */ - -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 - -#define CONFIG_SYS_ATA_BASE_ADDR CONFIG_SYS_PCMCIA_MEM_ADDR - -/* Offset for data I/O */ -#define CONFIG_SYS_ATA_DATA_OFFSET (CONFIG_SYS_PCMCIA_MEM_SIZE + 0x320) - -/* Offset for normal register accesses */ -#define CONFIG_SYS_ATA_REG_OFFSET (2 * CONFIG_SYS_PCMCIA_MEM_SIZE + 0x320) - -/* Offset for alternate registers */ -#define CONFIG_SYS_ATA_ALT_OFFSET 0x0100 - -/*----------------------------------------------------------------------- - * - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_DER 0 - -/* - * Init Memory Controller: - * - * BR0/1 and OR0/1 (FLASH) - */ - -#define FLASH_BASE0_PRELIM 0x40000000 /* FLASH bank #0 */ -#define FLASH_BASE1_PRELIM 0x60000000 /* FLASH bank #0 */ - -/* used to re-map FLASH both when starting from SRAM or FLASH: - * restrict access enough to keep SRAM working (if any) - * but not too much to meddle with FLASH accesses - */ -#define CONFIG_SYS_REMAP_OR_AM 0x80000000 /* OR addr mask */ -#define CONFIG_SYS_PRELIM_OR_AM 0xFF800000 /* OR addr mask */ - -/* - * FLASH timing: - */ -#define CONFIG_SYS_OR_TIMING_FLASH (0x00000d24) - -#define CONFIG_SYS_OR0_REMAP (CONFIG_SYS_REMAP_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_BR0_PRELIM ((FLASH_BASE0_PRELIM & BR_BA_MSK) | BR_V ) - -#define CONFIG_SYS_BR1_PRELIM 0x00000081 /* Chip select for SDRAM (32 Bit, UPMA) */ -#define CONFIG_SYS_OR1_PRELIM 0xfc000a00 -#define CONFIG_SYS_BR2_PRELIM 0x80000001 /* Chip select for SRAM (32 Bit, GPCM) */ -#define CONFIG_SYS_OR2_PRELIM 0xfff00d24 -#define CONFIG_SYS_BR3_PRELIM 0x80600401 /* Chip select for Display (8 Bit, GPCM) */ -#define CONFIG_SYS_OR3_PRELIM 0xffff8f44 -#define CONFIG_SYS_BR4_PRELIM 0xc05108c1 /* Chip select for Interbus MPM (16 Bit, UPMB) */ -#define CONFIG_SYS_OR4_PRELIM 0xffff0300 -#define CONFIG_SYS_BR5_PRELIM 0xc0500401 /* Chip select for Interbus Status (8 Bit, GPCM) */ -#define CONFIG_SYS_OR5_PRELIM 0xffff8db0 - -/* - * Memory Periodic Timer Prescaler - * - * The Divider for PTA (refresh timer) configuration is based on an - * example SDRAM configuration (64 MBit, one bank). The adjustment to - * the number of chip selects (NCS) and the actually needed refresh - * rate is done by setting MPTPR. - * - * PTA is calculated from - * PTA = (gclk * Trefresh) / ((2 ^ (2 * DFBRG)) * PTP * NCS) - * - * gclk CPU clock (not bus clock!) - * Trefresh Refresh cycle * 4 (four word bursts used) - * - * 4096 Rows from SDRAM example configuration - * 1000 factor s -> ms - * 32 PTP (pre-divider from MPTPR) from SDRAM example configuration - * 4 Number of refresh cycles per period - * 64 Refresh cycle in ms per number of rows - * -------------------------------------------- - * Divider = 4096 * 32 * 1000 / (4 * 64) = 512000 - * - * 50 MHz => 50.000.000 / Divider = 98 - * 66 Mhz => 66.000.000 / Divider = 129 - * 80 Mhz => 80.000.000 / Divider = 156 - * 100 Mhz => 100.000.000 / Divider = 195 - */ - -#define CONFIG_SYS_PTA_PER_CLK ((4096 * 32 * 1000) / (4 * 64)) -#define CONFIG_SYS_MAMR_PTA 98 - -/* - * For 16 MBit, refresh rates could be 31.3 us - * (= 64 ms / 2K = 125 / quad bursts). - * For a simpler initialization, 15.6 us is used instead. - * - * #define CONFIG_SYS_MPTPR_2BK_2K MPTPR_PTP_DIV32 for 2 banks - * #define CONFIG_SYS_MPTPR_1BK_2K MPTPR_PTP_DIV64 for 1 bank - */ -#define CONFIG_SYS_MPTPR_2BK_4K MPTPR_PTP_DIV16 /* setting for 2 banks */ -#define CONFIG_SYS_MPTPR_1BK_4K MPTPR_PTP_DIV32 /* setting for 1 bank */ - -/* refresh rate 7.8 us (= 64 ms / 8K = 31.2 / quad bursts) for 256 MBit */ -#define CONFIG_SYS_MPTPR_2BK_8K MPTPR_PTP_DIV8 /* setting for 2 banks */ -#define CONFIG_SYS_MPTPR_1BK_8K MPTPR_PTP_DIV16 /* setting for 1 bank */ - -/* - * MAMR settings for SDRAM - */ - -/* 8 column SDRAM */ -#define CONFIG_SYS_MAMR_8COL ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_0 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A11 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) -/* 9 column SDRAM */ -#define CONFIG_SYS_MAMR_9COL ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_1 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A10 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) - -#define CONFIG_SYS_MAMR_VAL 0x30904114 /* for SDRAM */ -#define CONFIG_SYS_MBMR_VAL 0xff001111 /* for Interbus-MPM */ - -/*----------------------------------------------------------------------- - * I2C stuff - */ - -/* enable I2C and select the hardware/software driver */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_SOFT /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SOFT_SPEED 93000 /* 93 kHz is supposed to work */ -#define CONFIG_SYS_I2C_SOFT_SLAVE 0xFE -/* - * Software (bit-bang) I2C driver configuration - */ -#define PB_SCL 0x00000020 /* PB 26 */ -#define PB_SDA 0x00000010 /* PB 27 */ - -#define I2C_INIT (immr->im_cpm.cp_pbdir |= PB_SCL) -#define I2C_ACTIVE (immr->im_cpm.cp_pbdir |= PB_SDA) -#define I2C_TRISTATE (immr->im_cpm.cp_pbdir &= ~PB_SDA) -#define I2C_READ ((immr->im_cpm.cp_pbdat & PB_SDA) != 0) -#define I2C_SDA(bit) if(bit) immr->im_cpm.cp_pbdat |= PB_SDA; \ - else immr->im_cpm.cp_pbdat &= ~PB_SDA -#define I2C_SCL(bit) if(bit) immr->im_cpm.cp_pbdat |= PB_SCL; \ - else immr->im_cpm.cp_pbdat &= ~PB_SCL -#define I2C_DELAY udelay(2) /* 1/4 I2C clock duration */ - -/*----------------------------------------------------------------------- - * I2C EEPROM (24C164) - */ -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x58 /* EEPROM AT24C164 */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* takes up to 10 msec */ -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 - -#define CONFIG_FEC_ENET 1 /* use FEC ethernet */ -#define FEC_ENET -#define CONFIG_MII -#define CONFIG_MII_INIT 1 -#define CONFIG_SYS_DISCOVER_PHY 1 - -#endif /* __CONFIG_H */ diff --git a/include/configs/uc101.h b/include/configs/uc101.h deleted file mode 100644 index f93dea7..0000000 --- a/include/configs/uc101.h +++ /dev/null @@ -1,103 +0,0 @@ -/* - * (C) Copyright 2003-2009 - * Heiko Schocher, DENX Software Engineering, hs@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_UC101 1 /* UC101 board */ -#define CONFIG_HOSTNAME uc101 - -#ifndef CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_TEXT_BASE 0xFFF00000 -#endif -#define CONFIG_SYS_LDSCRIPT "arch/powerpc/cpu/mpc5xxx/u-boot-customlayout.lds" - -#include "manroland/common.h" -#include "manroland/mpc5200-common.h" - -/* - * Serial console configuration - */ -#define CONFIG_BAUDRATE 115200 /* ... at 115200 bps */ - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME - -/* - * Flash configuration - */ -#define CONFIG_SYS_MAX_FLASH_SECT 140 - -/* - * Environment settings - */ -#define CONFIG_ENV_SECT_SIZE 0x10000 - -/* - * Memory map - */ -#define CONFIG_SYS_IB_MASTER 0xc0510000 /* CS 6 */ -#define CONFIG_SYS_IB_EPLD 0xc0500000 /* CS 7 */ - -/* SRAM */ -#define CONFIG_SYS_SRAM_SIZE 0x200000 - -/* - * GPIO configuration - */ -#define CONFIG_SYS_GPS_PORT_CONFIG 0x4d558044 - -#define CONFIG_SYS_MEMTEST_START 0x00300000 -#define CONFIG_SYS_MEMTEST_END 0x00f00000 - -#define CONFIG_SYS_LOAD_ADDR 0x300000 - -#define CONFIG_SYS_BOOTCS_CFG 0x00045D00 - -/* 8Mbit SRAM @0x80100000 */ -#define CONFIG_SYS_CS1_SIZE 0x00200000 -#define CONFIG_SYS_CS1_CFG 0x21D00 - -/* Display H1, Status Inputs, EPLD @0x80600000 8 Bit */ -#define CONFIG_SYS_CS3_START CONFIG_SYS_DISPLAY_BASE -#define CONFIG_SYS_CS3_SIZE 0x00000100 -#define CONFIG_SYS_CS3_CFG 0x00081802 - -/* Interbus Master 16 Bit */ -#define CONFIG_SYS_CS6_START CONFIG_SYS_IB_MASTER -#define CONFIG_SYS_CS6_SIZE 0x00010000 -#define CONFIG_SYS_CS6_CFG 0x00FF3500 - -/* Interbus EPLD 8 Bit */ -#define CONFIG_SYS_CS7_START CONFIG_SYS_IB_EPLD -#define CONFIG_SYS_CS7_SIZE 0x00010000 -#define CONFIG_SYS_CS7_CFG 0x00081800 - -/*----------------------------------------------------------------------- - * IDE/ATA stuff Supports IDE harddisk - *----------------------------------------------------------------------- - */ - -#define CONFIG_SYS_IDE_MAXDEVICE 1 /* max. 2 drives per IDE bus*/ - -/*---------------------------------------------------------------------*/ -/* Display addresses */ -/*---------------------------------------------------------------------*/ -#define CONFIG_SYS_DISP_CHR_RAM (CONFIG_SYS_DISPLAY_BASE + 0x38) -#define CONFIG_SYS_DISP_CWORD (CONFIG_SYS_DISPLAY_BASE + 0x30) - -#endif /* __CONFIG_H */ diff --git a/include/pcmcia.h b/include/pcmcia.h index 00065b2..2ff399b 100644 --- a/include/pcmcia.h +++ b/include/pcmcia.h @@ -33,8 +33,6 @@ # define CONFIG_PCMCIA_SLOT_B #elif defined(CONFIG_ATC) /* The ATC use SLOT_A */ # define CONFIG_PCMCIA_SLOT_A -#elif defined(CONFIG_UC100) /* The UC100 use SLOT_B */ -# define CONFIG_PCMCIA_SLOT_B #else # error "PCMCIA Slot not configured" #endif
On Mon, Dec 15, 2014 at 11:26:07PM +0900, Masahiro Yamada wrote:
These boards are still non-generic boards.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Heiko Schocher hs@denx.de Cc: Stefan Roese sr@denx.de
This board is still a non-generic board.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: The LEOX team team@leox.org ---
arch/powerpc/cpu/mpc8xx/Kconfig | 4 - board/LEOX/elpt860/Kconfig | 12 - board/LEOX/elpt860/MAINTAINERS | 6 - board/LEOX/elpt860/Makefile | 21 -- board/LEOX/elpt860/README.LEOX | 423 ------------------------- board/LEOX/elpt860/elpt860.c | 336 -------------------- board/LEOX/elpt860/flash.c | 602 ------------------------------------ board/LEOX/elpt860/u-boot.lds | 103 ------ board/LEOX/elpt860/u-boot.lds.debug | 126 -------- configs/ELPT860_defconfig | 3 - doc/README.scrapyard | 1 + include/commproc.h | 26 -- include/configs/ELPT860.h | 374 ---------------------- 13 files changed, 1 insertion(+), 2036 deletions(-) delete mode 100644 board/LEOX/elpt860/Kconfig delete mode 100644 board/LEOX/elpt860/MAINTAINERS delete mode 100644 board/LEOX/elpt860/Makefile delete mode 100644 board/LEOX/elpt860/README.LEOX delete mode 100644 board/LEOX/elpt860/elpt860.c delete mode 100644 board/LEOX/elpt860/flash.c delete mode 100644 board/LEOX/elpt860/u-boot.lds delete mode 100644 board/LEOX/elpt860/u-boot.lds.debug delete mode 100644 configs/ELPT860_defconfig delete mode 100644 include/configs/ELPT860.h
diff --git a/arch/powerpc/cpu/mpc8xx/Kconfig b/arch/powerpc/cpu/mpc8xx/Kconfig index 9eb7e17..30f8533 100644 --- a/arch/powerpc/cpu/mpc8xx/Kconfig +++ b/arch/powerpc/cpu/mpc8xx/Kconfig @@ -43,9 +43,6 @@ config TARGET_KUP4K config TARGET_KUP4X bool "Support KUP4X"
-config TARGET_ELPT860 - bool "Support ELPT860" - config TARGET_TQM823L bool "Support TQM823L"
@@ -84,7 +81,6 @@ config TARGET_TQM885D
endchoice
-source "board/LEOX/elpt860/Kconfig" source "board/RRvision/Kconfig" source "board/cogent/Kconfig" source "board/esteem192e/Kconfig" diff --git a/board/LEOX/elpt860/Kconfig b/board/LEOX/elpt860/Kconfig deleted file mode 100644 index ed74956..0000000 --- a/board/LEOX/elpt860/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_ELPT860 - -config SYS_BOARD - default "elpt860" - -config SYS_VENDOR - default "LEOX" - -config SYS_CONFIG_NAME - default "ELPT860" - -endif diff --git a/board/LEOX/elpt860/MAINTAINERS b/board/LEOX/elpt860/MAINTAINERS deleted file mode 100644 index 8f8a199..0000000 --- a/board/LEOX/elpt860/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -ELPT860 BOARD -M: The LEOX team team@leox.org -S: Maintained -F: board/LEOX/elpt860/ -F: include/configs/ELPT860.h -F: configs/ELPT860_defconfig diff --git a/board/LEOX/elpt860/Makefile b/board/LEOX/elpt860/Makefile deleted file mode 100644 index b811adb..0000000 --- a/board/LEOX/elpt860/Makefile +++ /dev/null @@ -1,21 +0,0 @@ -####################################################################### -# -# Copyright (C) 2000, 2001, 2002, 2003 -# The LEOX team team@leox.org, http://www.leox.org -# -# (C) Copyright 2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# LEOX.org is about the development of free hardware and software resources -# for system on chip. -# -# Description: U-Boot port on the LEOX's ELPT860 CPU board -# ~~~~~~~~~~~ -# -####################################################################### -# -# SPDX-License-Identifier: GPL-2.0+ -# -####################################################################### - -obj-y = elpt860.o flash.o diff --git a/board/LEOX/elpt860/README.LEOX b/board/LEOX/elpt860/README.LEOX deleted file mode 100644 index aa41ff8..0000000 --- a/board/LEOX/elpt860/README.LEOX +++ /dev/null @@ -1,423 +0,0 @@ -============================================================================= - - U-Boot port on the LEOX's ELPT860 CPU board - ------------------------------------------- - -LEOX.org is about the development of free hardware and software resources - for system on chip. - -For more information, contact The LEOX team team@leox.org - -References: -~~~~~~~~~~ - 1) Get the last stable release from denx.de: - o ftp://ftp.denx.de/pub/u-boot/u-boot-0.2.0.tar.bz2 - 2) Get the current CVS snapshot: - o cvs -d:pserver:anonymous@cvs.u-boot.sourceforge.net:/cvsroot/u-boot login - o cvs -z6 -d:pserver:anonymous@cvs.u-boot.sourceforge.net:/cvsroot/u-boot co -P u-boot - -============================================================================= - -The ELPT860 CPU board has the following features: - -Processor: - MPC860T @ 50MHz - - PowerPC Core - - 65 MIPS - - Caches: D->4KB, I->4KB - - CPM: 4 SCCs, 2 SMCs - - Ethernet 10/100 - - SPI, I2C, PCMCIA, Parallel - -CPU board: - DRAM: 16 MB - - FLASH: 512 KB + (2 * 4 MB) - - NVRAM: 128 KB - - 1 Serial link - - 2 Ethernet 10 BaseT Channels - -On power-up the processor jumps to the address of 0x02000100 - -Thus, U-Boot is configured to reside in flash starting at the address of -0x02001000. The environment space is located in NVRAM separately from -U-Boot, at the address of 0x03000000. - -============================================================================= - - U-Boot test results - -============================================================================= - -################################################## -# Operation on the serial console (SMC1) -############################## - -U-Boot 0.2.2 (Jan 19 2003 - 11:08:39) - -CPU: XPC860xxZPnnB at 50 MHz: 4 kB I-Cache 4 kB D-Cache FEC present - *** Warning: CPU Core has Silicon Bugs -- Check the Errata *** -Board: ### No HW ID - assuming ELPT860 -DRAM: 16 MB -FLASH: 512 kB -In: serial -Out: serial -Err: serial -Net: SCC ETHERNET - -Type "run nfsboot" to mount root filesystem over NFS - -Hit any key to stop autoboot: 0 -LEOX_elpt860: help -askenv - get environment variables from stdin -base - print or set address offset -bdinfo - print Board Info structure -bootm - boot application image from memory -bootp - boot image via network using BootP/TFTP protocol -bootd - boot default, i.e., run 'bootcmd' -cmp - memory compare -coninfo - print console devices and informations -cp - memory copy -crc32 - checksum calculation -echo - echo args to console -erase - erase FLASH memory -flinfo - print FLASH memory information -go - start application at address 'addr' -help - print online help -iminfo - print header information for application image -loadb - load binary file over serial line (kermit mode) -loads - load S-Record file over serial line -loop - infinite loop on address range -md - memory display -mm - memory modify (auto-incrementing) -mtest - simple RAM test -mw - memory write (fill) -nm - memory modify (constant address) -printenv- print environment variables -protect - enable or disable FLASH write protection -rarpboot- boot image via network using RARP/TFTP protocol -reset - Perform RESET of the CPU -run - run commands in an environment variable -saveenv - save environment variables to persistent storage -setenv - set environment variables -sleep - delay execution for some time -source - run script from memory -tftpboot- boot image via network using TFTP protocol - and env variables ipaddr and serverip -version - print monitor version -? - alias for 'help' - -################################################## -# Environment Variables (CONFIG_ENV_IS_IN_NVRAM) -############################## - -LEOX_elpt860: printenv -bootdelay=5 -loads_echo=1 -baudrate=9600 -stdin=serial -stdout=serial -stderr=serial -ethaddr=00:03:ca:00:64:df -ipaddr=192.168.0.30 -netmask=255.255.255.0 -serverip=192.168.0.1 -nfsserverip=192.168.0.1 -preboot=echo;echo Type "run nfsboot" to mount root filesystem over NFS;echo -gatewayip=192.168.0.1 -ramargs=setenv bootargs root=/dev/ram rw -rootargs=setenv rootpath /tftp/${ipaddr} -nfsargs=setenv bootargs root=/dev/nfs rw nfsroot=${nfsserverip}:${rootpath} -addip=setenv bootargs ${bootargs} ip=${ipaddr}:${nfsserverip}:${gatewayip}:${netmask}:${hostname}:eth0: -ramboot=tftp 400000 /home/leox/pMulti;run ramargs;bootm -nfsboot=tftp 400000 /home/leox/uImage;run rootargs;run nfsargs;run addip;bootm -bootcmd=run ramboot -clocks_in_mhz=1 - -Environment size: 730/16380 bytes - -################################################## -# Flash Memory Information -############################## - -LEOX_elpt860: flinfo - -Bank # 1: AMD AM29F040 (4 Mbits) - Size: 512 KB in 8 Sectors - Sector Start Addresses: - 02000000 (RO) 02010000 (RO) 02020000 (RO) 02030000 (RO) 02040000 - 02050000 02060000 02070000 - -################################################## -# Board Information Structure -############################## - -LEOX_elpt860: bdinfo -memstart = 0x00000000 -memsize = 0x01000000 -flashstart = 0x02000000 -flashsize = 0x00080000 -flashoffset = 0x00030000 -sramstart = 0x00000000 -sramsize = 0x00000000 -immr_base = 0xFF000000 -bootflags = 0x00000001 -intfreq = 50 MHz -busfreq = 50 MHz -ethaddr = 00:03:ca:00:64:df -IP addr = 192.168.0.30 -baudrate = 9600 bps - -################################################## -# Image Download and run over serial port -# hello_world (S-Record image) -# ===> 1) Enter "loads" command into U-Boot monitor -# ===> 2) From TeraTerm's bar menu, Select 'File/Send file...' -# Then select 'hello_world.srec' with the file browser -############################## - -U-Boot 0.2.2 (Jan 19 2003 - 11:08:39) - -CPU: XPC860xxZPnnB at 50 MHz: 4 kB I-Cache 4 kB D-Cache FEC present - *** Warning: CPU Core has Silicon Bugs -- Check the Errata *** -Board: ### No HW ID - assuming ELPT860 -DRAM: 16 MB -FLASH: 512 kB -In: serial -Out: serial -Err: serial -Net: SCC ETHERNET - -Type "run nfsboot" to mount root filesystem over NFS - -Hit any key to stop autoboot: 0 -LEOX_elpt860: loads -## Ready for S-Record download ... -S804040004F3050154000501709905014C000501388D -## First Load Addr = 0x00040000 -## Last Load Addr = 0x0005018B -## Total Size = 0x0001018C = 65932 Bytes -## Start Addr = 0x00040004 -LEOX_elpt860: go 40004 This is a test !!! -## Starting application at 0x00040004 ... -Hello World -argc = 6 -argv[0] = "40004" -argv[1] = "This" -argv[2] = "is" -argv[3] = "a" -argv[4] = "test" -argv[5] = "!!!" -argv[6] = "<NULL>" -Hit any key to exit ... - -## Application terminated, rc = 0x0 - -################################################## -# Image download and run over ethernet interface -# Linux-2.4.4 (uImage) + Root filesystem mounted over NFS -############################## - -U-Boot 0.2.2 (Jan 19 2003 - 11:08:39) - -CPU: XPC860xxZPnnB at 50 MHz: 4 kB I-Cache 4 kB D-Cache FEC present - *** Warning: CPU Core has Silicon Bugs -- Check the Errata *** -Board: ### No HW ID - assuming ELPT860 -DRAM: 16 MB -FLASH: 512 kB -In: serial -Out: serial -Err: serial -Net: SCC ETHERNET - -Type "run nfsboot" to mount root filesystem over NFS - -Hit any key to stop autoboot: 0 -LEOX_elpt860: run nfsboot -ARP broadcast 1 -TFTP from server 192.168.0.1; our IP address is 192.168.0.30 -Filename '/home/leox/uImage'. -Load address: 0x400000 -Loading: ################################################################# - ############################# -done -Bytes transferred = 477294 (7486e hex) -## Booting image at 00400000 ... - Image Name: Linux-2.4.4 - Image Type: PowerPC Linux Kernel Image (gzip compressed) - Data Size: 477230 Bytes = 466 kB = 0 MB - Load Address: 00000000 - Entry Point: 00000000 - Verifying Checksum ... OK - Uncompressing Kernel Image ... OK -Linux version 2.4.4-rthal5 (leox@p5ak6650) (gcc version 2.95.3 20010315 (release/MontaVista)) #1 Wed Jul 3 10:23:53 CEST 2002 -On node 0 totalpages: 4096 -zone(0): 4096 pages. -zone(1): 0 pages. -zone(2): 0 pages. -Kernel command line: root=/dev/nfs rw nfsroot=192.168.0.1:/tftp/192.168.0.30 ip=192.168.0.30:192.168.0.1:192.168.0.1:255.255.255.0::eth0: -rtsched version <20010618.1050.24> -Decrementer Frequency: 3125000 -Warning: real time clock seems stuck! -Calibrating delay loop... 49.76 BogoMIPS -Memory: 14720k available (928k kernel code, 384k data, 44k init, 0k highmem) -Dentry-cache hash table entries: 2048 (order: 2, 16384 bytes) -Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes) -Page-cache hash table entries: 4096 (order: 2, 16384 bytes) -Inode-cache hash table entries: 1024 (order: 1, 8192 bytes) -POSIX conformance testing by UNIFIX -Linux NET4.0 for Linux 2.4 -Based upon Swansea University Computer Society NET3.039 -Starting kswapd v1.8 -CPM UART driver version 0.03 -ttyS0 on SMC1 at 0x0280, BRG1 -block: queued sectors max/low 9701kB/3233kB, 64 slots per queue -RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize -eth0: CPM ENET Version 0.2 on SCC1, 00:03:ca:00:64:df -NET4: Linux TCP/IP 1.0 for NET4.0 -IP Protocols: ICMP, UDP, TCP -IP: routing cache hash table of 512 buckets, 4Kbytes -TCP: Hash tables configured (established 1024 bind 1024) -NET4: Unix domain sockets 1.0/SMP for Linux NET4.0. -Looking up port of RPC 100003/2 on 192.168.0.1 -Looking up port of RPC 100005/2 on 192.168.0.1 -VFS: Mounted root (nfs filesystem). -Freeing unused kernel memory: 44k init -INIT: version 2.78 booting - Welcome to DENX Embedded Linux Environment - Press 'I' to enter interactive startup. -Mounting proc filesystem: [ OK ] -Configuring kernel parameters: [ OK ] -Cannot access the Hardware Clock via any known method. -Use the --debug option to see the details of our search for an access method. -Setting clock : Wed Dec 31 19:00:11 EST 1969 [ OK ] -Activating swap partitions: [ OK ] -Setting hostname 192.168.0.30: [ OK ] -Finding module dependencies: -[ OK ] -Checking filesystems -Checking all file systems. -[ OK ] -Mounting local filesystems: [ OK ] -Enabling swap space: [ OK ] -INIT: Entering runlevel: 3 -Entering non-interactive startup -Starting system logger: [ OK ] -Starting kernel logger: [ OK ] -Starting xinetd: [ OK ] - -192 login: root -Last login: Wed Dec 31 19:00:41 on ttyS0 -bash-2.04# - -################################################## -# Image download and run over ethernet interface -# Linux-2.4.4 + Root filesystem mounted from RAM (pMulti) -############################## - -U-Boot 0.2.2 (Jan 19 2003 - 11:08:39) - -CPU: XPC860xxZPnnB at 50 MHz: 4 kB I-Cache 4 kB D-Cache FEC present - *** Warning: CPU Core has Silicon Bugs -- Check the Errata *** -Board: ### No HW ID - assuming ELPT860 -DRAM: 16 MB -FLASH: 512 kB -In: serial -Out: serial -Err: serial -Net: SCC ETHERNET - -Type "run nfsboot" to mount root filesystem over NFS - -Hit any key to stop autoboot: 0 -LEOX_elpt860: run ramboot -ARP broadcast 1 -TFTP from server 192.168.0.1; our IP address is 192.168.0.30 -Filename '/home/leox/pMulti'. -Load address: 0x400000 -Loading: ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ######################################################## -done -Bytes transferred = 1947816 (1db8a8 hex) -## Booting image at 00400000 ... - Image Name: linux-2.4.4-2002-03-21 Multiboot - Image Type: PowerPC Linux Multi-File Image (gzip compressed) - Data Size: 1947752 Bytes = 1902 kB = 1 MB - Load Address: 00000000 - Entry Point: 00000000 - Contents: - Image 0: 477230 Bytes = 466 kB = 0 MB - Image 1: 1470508 Bytes = 1436 kB = 1 MB - Verifying Checksum ... OK - Uncompressing Multi-File Image ... OK - Loading Ramdisk to 00e44000, end 00fab02c ... OK -Linux version 2.4.4-rthal5 (leox@p5ak6650) (gcc version 2.95.3 20010315 (release/MontaVista)) #1 Wed Jul 3 10:23:53 CEST 2002 -On node 0 totalpages: 4096 -zone(0): 4096 pages. -zone(1): 0 pages. -zone(2): 0 pages. -Kernel command line: root=/dev/ram rw -rtsched version <20010618.1050.24> -Decrementer Frequency: 3125000 -Warning: real time clock seems stuck! -Calibrating delay loop... 49.76 BogoMIPS -Memory: 13280k available (928k kernel code, 384k data, 44k init, 0k highmem) -Dentry-cache hash table entries: 2048 (order: 2, 16384 bytes) -Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes) -Page-cache hash table entries: 4096 (order: 2, 16384 bytes) -Inode-cache hash table entries: 1024 (order: 1, 8192 bytes) -POSIX conformance testing by UNIFIX -Linux NET4.0 for Linux 2.4 -Based upon Swansea University Computer Society NET3.039 -Starting kswapd v1.8 -CPM UART driver version 0.03 -ttyS0 on SMC1 at 0x0280, BRG1 -block: queued sectors max/low 8741kB/2913kB, 64 slots per queue -RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize -eth0: CPM ENET Version 0.2 on SCC1, 00:03:ca:00:64:df -RAMDISK: Compressed image found at block 0 -Freeing initrd memory: 1436k freed -NET4: Linux TCP/IP 1.0 for NET4.0 -IP Protocols: ICMP, UDP, TCP -IP: routing cache hash table of 512 buckets, 4Kbytes -TCP: Hash tables configured (established 1024 bind 1024) -IP-Config: Incomplete network configuration information. -NET4: Unix domain sockets 1.0/SMP for Linux NET4.0. -VFS: Mounted root (ext2 filesystem). -Freeing unused kernel memory: 44k init -init started: BusyBox v0.60.2 (2002.07.01-12:06+0000) multi-call Configuring hostname -Configuring lo... -Configuring eth0... -Configuring Gateway... - -Please press Enter to activate this console. - -ELPT860 login: root -Password: -Welcome to Linux-2.4.4 for ELPT CPU board (MPC860T @ 50MHz) - - a8888b. - d888888b. - 8P"YP"Y88 - _ _ 8|o||o|88 - | | |_| 8' .88 - | | _ ____ _ _ _ _ 8`._.' Y8. - | | | | _ | | | |\ / / d/ `8b. - | |___ | | | | | |_| |/ \ .dP . Y8b. - |_____||_|_| |_|____|_/_/ d8:' " `::88b. - d8" `Y88b - :8P ' :888 - 8a. : _a88P - ._/"Yaa_ : .| 88P| - \ YP" `| 8P `. - / ._____.d| .' - `--..__)888888P`._.' -login[21]: root login on `ttyS0' - - - -BusyBox v0.60.3 (2002.07.20-10:39+0000) Built-in shell (ash) -Enter 'help' for a list of built-in commands. - -root@ELPT860:~ # diff --git a/board/LEOX/elpt860/elpt860.c b/board/LEOX/elpt860/elpt860.c deleted file mode 100644 index 81820cb..0000000 --- a/board/LEOX/elpt860/elpt860.c +++ /dev/null @@ -1,336 +0,0 @@ -/* -**===================================================================== -** -** Copyright (C) 2000, 2001, 2002, 2003 -** The LEOX team team@leox.org, http://www.leox.org -** -** LEOX.org is about the development of free hardware and software resources -** for system on chip. -** -** Description: U-Boot port on the LEOX's ELPT860 CPU board -** ~~~~~~~~~~~ -** -**===================================================================== -** - * SPDX-License-Identifier: GPL-2.0+ -** -**===================================================================== -*/ - -/* -** Note 1: In this file, you have to provide the following functions: -** ------ -** int board_early_init_f(void) -** int checkboard(void) -** phys_size_t initdram(int board_type) -** called from 'board_init_f()' into 'common/board.c' -** -** void reset_phy(void) -** called from 'board_init_r()' into 'common/board.c' -*/ - -#include <common.h> -#include <mpc8xx.h> - -/* ------------------------------------------------------------------------- */ - -static long int dram_size (long int, long int *, long int); - -/* ------------------------------------------------------------------------- */ - -#define _NOT_USED_ 0xFFFFFFFF - -const uint init_sdram_table[] = { - /* - * Single Read. (Offset 0 in UPMA RAM) - */ - 0x0FFCCC04, 0xFFFFFC04, 0x0FFC3C04, 0xFFFFFC04, - 0xFFFFFC04, /* last */ - /* - * SDRAM Initialization (offset 5 in UPMA RAM) - * - * This is no UPM entry point. The following definition uses - * the remaining space to establish an initialization - * sequence, which is executed by a RUN command. - * - */ - 0xFFFFFC04, 0xFFFFFC04, 0x0FFC3C04, /* last */ - /* - * Burst Read. (Offset 8 in UPMA RAM) - */ - 0xFFFFFC04, 0xFFFFFC04, 0xFFFFFC04, 0xFFFFFC04, - 0x0FFC3C04, 0xFFFFFC04, 0xFFFFFC04, 0xFFFFFC04, - 0xFFFFFC04, 0x0FFC3C04, 0xFFFFFC04, 0xFFFFFC04, - 0xFFFFFC04, 0xFFFFFC04, 0x0FFC3C04, 0xFFFFFC04, /* last */ - /* - * Single Write. (Offset 18 in UPMA RAM) - */ - 0xFFFFFC04, 0xFFFFFC04, 0xFFFFFC04, 0x0FFC3C04, - 0xFFFFFC04, 0xFFFFFC04, 0x0FFFFC04, 0xFFFFFC04, /* last */ - /* - * Burst Write. (Offset 20 in UPMA RAM) - */ - 0x0FFC3C04, 0xFFFFFC04, 0xFFFFFC04, 0xFFFFFC04, - 0xFFFFFC04, 0x0FFC3C04, 0xFFFFFC04, 0xFFFFFC04, - 0xFFFFFC04, 0xFFFFFC04, 0xFFFFFC34, 0x0FAC0C34, - 0xFFFFFC05, 0xFFFFFC04, 0x0FFCFC04, 0xFFFFFC05, /* last */ -}; - -const uint sdram_table[] = { - /* - * Single Read. (Offset 0 in UPMA RAM) - */ - 0x0F0FFC24, 0x0F0CFC04, 0xFF0FFC04, 0x00AF3C04, - 0xFF0FFC00, /* last */ - /* - * SDRAM Initialization (offset 5 in UPMA RAM) - * - * This is no UPM entry point. The following definition uses - * the remaining space to establish an initialization - * sequence, which is executed by a RUN command. - * - */ - 0x0FFCCC04, 0xFFAFFC05, 0xFFAFFC05, /* last */ - /* - * Burst Read. (Offset 8 in UPMA RAM) - */ - 0x0F0FFC24, 0x0F0CFC04, 0xFF0FFC04, 0x00AF3C04, - 0xF00FFC00, 0xF00FFC00, 0xF00FFC00, 0xFF0FFC00, - 0x0FFCCC04, 0xFFAFFC05, 0xFFAFFC04, 0xFFAFFC04, - 0xFFAFFC04, 0xFFAFFC04, 0xFFAFFC04, 0xFFAFFC04, /* last */ - /* - * Single Write. (Offset 18 in UPMA RAM) - */ - 0x0F0FFC24, 0x0F0CFC04, 0xFF0FFC04, 0x00AF0C00, - 0xFF0FFC04, 0x0FFCCC04, 0xFFAFFC05, /* last */ - _NOT_USED_, - /* - * Burst Write. (Offset 20 in UPMA RAM) - */ - 0x0F0FFC24, 0x0F0CFC04, 0xFF0FFC00, 0x00AF0C00, - 0xF00FFC00, 0xF00FFC00, 0xF00FFC04, 0x0FFCCC04, - 0xFFAFFC04, 0xFFAFFC05, 0xFFAFFC04, 0xFFAFFC04, - 0xFFAFFC04, 0xFFAFFC04, 0xFFAFFC04, 0xFFAFFC04, /* last */ - /* - * Refresh (Offset 30 in UPMA RAM) - */ - 0x0FFC3C04, 0xFFFFFC04, 0xFFFFFC04, 0xFFFFFC04, - 0xFFFFFC05, 0xFFFFFC04, 0xFFFFFC05, _NOT_USED_, - 0xFFAFFC04, 0xFFAFFC04, 0xFFAFFC04, 0xFFAFFC04, /* last */ - /* - * Exception. (Offset 3c in UPMA RAM) - */ - 0x0FFFFC34, 0x0FAC0C34, 0xFFFFFC05, 0xFFAFFC04, /* last */ -}; - -/* ------------------------------------------------------------------------- */ - -#define CONFIG_SYS_PC4 0x0800 - -#define CONFIG_SYS_DS1 CONFIG_SYS_PC4 - -/* - * Very early board init code (fpga boot, etc.) - */ -int board_early_init_f (void) -{ - volatile immap_t *immr = (immap_t *) CONFIG_SYS_IMMR; - - /* - * Light up the red led on ELPT860 pcb (DS1) (PCDAT) - */ - immr->im_ioport.iop_pcdat &= ~CONFIG_SYS_DS1; /* PCDAT (DS1 = 0) */ - immr->im_ioport.iop_pcpar &= ~CONFIG_SYS_DS1; /* PCPAR (0=general purpose I/O) */ - immr->im_ioport.iop_pcdir |= CONFIG_SYS_DS1; /* PCDIR (I/O: 0=input, 1=output) */ - - return (0); /* success */ -} - -/* - * Check Board Identity: - * - * Test ELPT860 ID string - * - * Return 1 if no second DRAM bank, otherwise returns 0 - */ - -int checkboard (void) -{ - char buf[64]; - int i = getenv_f("serial#", buf, sizeof(buf)); - - if ((i < 0) || strncmp(buf, "ELPT860", 7)) - printf ("### No HW ID - assuming ELPT860\n"); - - return (0); /* success */ -} - -/* ------------------------------------------------------------------------- */ - -phys_size_t initdram (int board_type) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - long int size8, size9; - long int size_b0 = 0; - - /* - * This sequence initializes SDRAM chips on ELPT860 board - */ - upmconfig (UPMA, (uint *) init_sdram_table, - sizeof (init_sdram_table) / sizeof (uint)); - - memctl->memc_mptpr = 0x0200; - memctl->memc_mamr = 0x18002111; - - memctl->memc_mar = 0x00000088; - memctl->memc_mcr = 0x80002000; /* CS1: SDRAM bank 0 */ - - upmconfig (UPMA, (uint *) sdram_table, - sizeof (sdram_table) / sizeof (uint)); - - /* - * Preliminary prescaler for refresh (depends on number of - * banks): This value is selected for four cycles every 62.4 us - * with two SDRAM banks or four cycles every 31.2 us with one - * bank. It will be adjusted after memory sizing. - */ - memctl->memc_mptpr = CONFIG_SYS_MPTPR_2BK_8K; - - /* - * The following value is used as an address (i.e. opcode) for - * the LOAD MODE REGISTER COMMAND during SDRAM initialisation. If - * the port size is 32bit the SDRAM does NOT "see" the lower two - * address lines, i.e. mar=0x00000088 -> opcode=0x00000022 for - * MICRON SDRAMs: - * -> 0 00 010 0 010 - * | | | | +- Burst Length = 4 - * | | | +----- Burst Type = Sequential - * | | +------- CAS Latency = 2 - * | +----------- Operating Mode = Standard - * +-------------- Write Burst Mode = Programmed Burst Length - */ - memctl->memc_mar = 0x00000088; - - /* - * Map controller banks 2 and 3 to the SDRAM banks 2 and 3 at - * preliminary addresses - these have to be modified after the - * SDRAM size has been determined. - */ - memctl->memc_or1 = CONFIG_SYS_OR1_PRELIM; - memctl->memc_br1 = CONFIG_SYS_BR1_PRELIM; - - memctl->memc_mamr = CONFIG_SYS_MAMR_8COL & (~(MAMR_PTAE)); /* no refresh yet */ - - udelay (200); - - /* perform SDRAM initializsation sequence */ - - memctl->memc_mcr = 0x80002105; /* CS1: SDRAM bank 0 */ - udelay (1); - memctl->memc_mcr = 0x80002230; /* CS1: SDRAM bank 0 - execute twice */ - udelay (1); - - memctl->memc_mamr |= MAMR_PTAE; /* enable refresh */ - - udelay (1000); - - /* - * Check Bank 0 Memory Size for re-configuration - * - * try 8 column mode - */ - size8 = dram_size (CONFIG_SYS_MAMR_8COL, - SDRAM_BASE1_PRELIM, SDRAM_MAX_SIZE); - - udelay (1000); - - /* - * try 9 column mode - */ - size9 = dram_size (CONFIG_SYS_MAMR_9COL, - SDRAM_BASE1_PRELIM, SDRAM_MAX_SIZE); - - if (size8 < size9) { /* leave configuration at 9 columns */ - size_b0 = size9; - /* debug ("SDRAM Bank 0 in 9 column mode: %ld MB\n", size >> 20); */ - } else { /* back to 8 columns */ - - size_b0 = size8; - memctl->memc_mamr = CONFIG_SYS_MAMR_8COL; - udelay (500); - /* debug ("SDRAM Bank 0 in 8 column mode: %ld MB\n", size >> 20); */ - } - - udelay (1000); - - /* - * Adjust refresh rate depending on SDRAM type, both banks - * For types > 128 MBit leave it at the current (fast) rate - */ - if (size_b0 < 0x02000000) { - /* reduce to 15.6 us (62.4 us / quad) */ - memctl->memc_mptpr = CONFIG_SYS_MPTPR_2BK_4K; - udelay (1000); - } - - /* - * Final mapping: map bigger bank first - */ - memctl->memc_or1 = ((-size_b0) & 0xFFFF0000) | CONFIG_SYS_OR_TIMING_SDRAM; - memctl->memc_br1 = (CONFIG_SYS_SDRAM_BASE & BR_BA_MSK) | BR_MS_UPMA | BR_V; - - { - unsigned long reg; - - /* adjust refresh rate depending on SDRAM type, one bank */ - reg = memctl->memc_mptpr; - reg >>= 1; /* reduce to CONFIG_SYS_MPTPR_1BK_8K / _4K */ - memctl->memc_mptpr = reg; - } - - udelay (10000); - - return (size_b0); -} - -/* ------------------------------------------------------------------------- */ - -/* - * Check memory range for valid RAM. A simple memory test determines - * the actually available RAM size between addresses `base' and - * `base + maxsize'. Some (not all) hardware errors are detected: - * - short between address lines - * - short between data lines - */ - -static long int -dram_size (long int mamr_value, long int *base, long int maxsize) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - - memctl->memc_mamr = mamr_value; - - return (get_ram_size (base, maxsize)); -} - -/* ------------------------------------------------------------------------- */ - -#define CONFIG_SYS_PA1 0x4000 -#define CONFIG_SYS_PA2 0x2000 - -#define CONFIG_SYS_LBKs (CONFIG_SYS_PA2 | CONFIG_SYS_PA1) - -void reset_phy (void) -{ - volatile immap_t *immr = (immap_t *) CONFIG_SYS_IMMR; - - /* - * Ensure LBK LXT901 ethernet 1 & 2 = 0 ... for normal loopback in effect - * and no AUI loopback - */ - immr->im_ioport.iop_padat &= ~CONFIG_SYS_LBKs; /* PADAT (LBK eth 1&2 = 0) */ - immr->im_ioport.iop_papar &= ~CONFIG_SYS_LBKs; /* PAPAR (0=general purpose I/O) */ - immr->im_ioport.iop_padir |= CONFIG_SYS_LBKs; /* PADIR (I/O: 0=input, 1=output) */ -} diff --git a/board/LEOX/elpt860/flash.c b/board/LEOX/elpt860/flash.c deleted file mode 100644 index 0377c89..0000000 --- a/board/LEOX/elpt860/flash.c +++ /dev/null @@ -1,602 +0,0 @@ -/* -**===================================================================== -** -** Copyright (C) 2000, 2001, 2002, 2003 -** The LEOX team team@leox.org, http://www.leox.org -** -** LEOX.org is about the development of free hardware and software resources -** for system on chip. -** -** Description: U-Boot port on the LEOX's ELPT860 CPU board -** ~~~~~~~~~~~ -** -**===================================================================== -** - * SPDX-License-Identifier: GPL-2.0+ -** -**===================================================================== -*/ - -/* -** Note 1: In this file, you have to provide the following variable: -** ------ -** flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS] -** 'flash_info_t' structure is defined into 'include/flash.h' -** and defined as extern into 'common/cmd_flash.c' -** -** Note 2: In this file, you have to provide the following functions: -** ------ -** unsigned long flash_init(void) -** called from 'board_init_r()' into 'common/board.c' -** -** void flash_print_info(flash_info_t *info) -** called from 'do_flinfo()' into 'common/cmd_flash.c' -** -** int flash_erase(flash_info_t *info, -** int s_first, -** int s_last) -** called from 'do_flerase()' & 'flash_sect_erase()' into 'common/cmd_flash.c' -** -** int write_buff (flash_info_t *info, -** uchar *src, -** ulong addr, -** ulong cnt) -** called from 'flash_write()' into 'common/cmd_flash.c' -*/ - -#include <common.h> -#include <mpc8xx.h> - - -#ifndef CONFIG_ENV_ADDR -# define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET) -#endif - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH chips */ - -/*----------------------------------------------------------------------- - * Internal Functions - */ -static void flash_get_offsets (ulong base, flash_info_t *info); -static ulong flash_get_size (volatile unsigned char *addr, flash_info_t *info); - -static int write_word (flash_info_t *info, ulong dest, ulong data); -static int write_byte (flash_info_t *info, ulong dest, uchar data); - -/*----------------------------------------------------------------------- - */ - -unsigned long -flash_init (void) -{ - volatile immap_t *immap = (immap_t *)CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - unsigned long size_b0; - int i; - - /* Init: no FLASHes known */ - for (i=0; i<CONFIG_SYS_MAX_FLASH_BANKS; ++i) - { - flash_info[i].flash_id = FLASH_UNKNOWN; - } - - /* Static FLASH Bank configuration here - FIXME XXX */ - - size_b0 = flash_get_size ((volatile unsigned char *)FLASH_BASE0_PRELIM, - &flash_info[0]); - - if ( flash_info[0].flash_id == FLASH_UNKNOWN ) - { - printf ("## Unknown FLASH on Bank 0 - Size = 0x%08lx = %ld MB\n", - size_b0, size_b0<<20); - } - - /* Remap FLASH according to real size */ - memctl->memc_or0 = CONFIG_SYS_OR_TIMING_FLASH | (-size_b0 & OR_AM_MSK); - memctl->memc_br0 = (CONFIG_SYS_FLASH_BASE & BR_BA_MSK) | BR_MS_GPCM | BR_PS_8 | BR_V; - - /* Re-do sizing to get full correct info */ - size_b0 = flash_get_size ((volatile unsigned char *)CONFIG_SYS_FLASH_BASE, - &flash_info[0]); - - flash_get_offsets (CONFIG_SYS_FLASH_BASE, &flash_info[0]); - -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE - /* monitor protection ON by default */ - flash_protect (FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE + monitor_flash_len-1, - &flash_info[0]); -#endif - -#ifdef CONFIG_ENV_IS_IN_FLASH - /* ENV protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR + CONFIG_ENV_SIZE-1, - &flash_info[0]); -#endif - - flash_info[0].size = size_b0; - - return (size_b0); -} - -/*----------------------------------------------------------------------- - */ -static void -flash_get_offsets (ulong base, - flash_info_t *info) -{ - int i; - -#define SECTOR_64KB 0x00010000 - - /* set up sector start adress table */ - for (i = 0; i < info->sector_count; i++) - { - info->start[i] = base + (i * SECTOR_64KB); - } -} - -/*----------------------------------------------------------------------- - */ -void -flash_print_info (flash_info_t *info) -{ - int i; - - if ( info->flash_id == FLASH_UNKNOWN ) - { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch ( info->flash_id & FLASH_VENDMASK ) - { - case FLASH_MAN_AMD: printf ("AMD "); break; - case FLASH_MAN_FUJ: printf ("FUJITSU "); break; - case FLASH_MAN_STM: printf ("STM (Thomson) "); break; - default: printf ("Unknown Vendor "); break; - } - - switch ( info->flash_id & FLASH_TYPEMASK ) - { - case FLASH_AM040: printf ("AM29F040 (4 Mbits)\n"); - break; - default: printf ("Unknown Chip Type\n"); - break; - } - - printf (" Size: %ld KB in %d Sectors\n", - info->size >> 10, info->sector_count); - - printf (" Sector Start Addresses:"); - for (i=0; i<info->sector_count; ++i) - { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", - info->start[i], - info->protect[i] ? " (RO)" : " " - ); - } - printf ("\n"); - - return; -} - -/*----------------------------------------------------------------------- - */ - - -/*----------------------------------------------------------------------- - */ - -/* - * The following code cannot be run from FLASH! - */ - -static ulong -flash_get_size (volatile unsigned char *addr, - flash_info_t *info) -{ - short i; - uchar value; - ulong base = (ulong)addr; - - /* Write auto select command: read Manufacturer ID */ - addr[0x0555] = 0xAA; - addr[0x02AA] = 0x55; - addr[0x0555] = 0x90; - - value = addr[0]; - - switch ( value ) - { - /* case AMD_MANUFACT: */ - case 0x01: - info->flash_id = FLASH_MAN_AMD; - break; - /* case FUJ_MANUFACT: */ - case 0x04: - info->flash_id = FLASH_MAN_FUJ; - break; - /* case STM_MANUFACT: */ - case 0x20: - info->flash_id = FLASH_MAN_STM; - break; - - default: - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - return (0); /* no or unknown flash */ - } - - value = addr[1]; /* device ID */ - - switch ( value ) - { - case STM_ID_F040B: - case AMD_ID_F040B: - info->flash_id += FLASH_AM040; /* 4 Mbits = 512k * 8 */ - info->sector_count = 8; - info->size = 0x00080000; - break; - - default: - info->flash_id = FLASH_UNKNOWN; - return (0); /* => no or unknown flash */ - } - - /* set up sector start adress table */ - for (i = 0; i < info->sector_count; i++) - { - info->start[i] = base + (i * 0x00010000); - } - - /* check for protected sectors */ - for (i = 0; i < info->sector_count; i++) - { - /* read sector protection at sector address, (A7 .. A0) = 0x02 */ - /* D0 = 1 if protected */ - addr = (volatile unsigned char *)(info->start[i]); - info->protect[i] = addr[2] & 1; - } - - /* - * Prevent writes to uninitialized FLASH. - */ - if ( info->flash_id != FLASH_UNKNOWN ) - { - addr = (volatile unsigned char *)info->start[0]; - - *addr = 0xF0; /* reset bank */ - } - - return (info->size); -} - - -/*----------------------------------------------------------------------- - */ - -int -flash_erase (flash_info_t *info, - int s_first, - int s_last) -{ - volatile unsigned char *addr = (volatile unsigned char *)(info->start[0]); - int flag, prot, sect, l_sect; - ulong start, now, last; - - if ( (s_first < 0) || (s_first > s_last) ) - { - if ( info->flash_id == FLASH_UNKNOWN ) - { - printf ("- missing\n"); - } - else - { - printf ("- no sectors to erase\n"); - } - return ( 1 ); - } - - if ( (info->flash_id == FLASH_UNKNOWN) || - (info->flash_id > FLASH_AMD_COMP) ) - { - printf ("Can't erase unknown flash type %08lx - aborted\n", - info->flash_id); - return ( 1 ); - } - - prot = 0; - for (sect=s_first; sect<=s_last; ++sect) - { - if ( info->protect[sect] ) - { - prot++; - } - } - - if ( prot ) - { - printf ("- Warning: %d protected sectors will not be erased!\n", prot); - } - else - { - printf ("\n"); - } - - l_sect = -1; - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - addr[0x0555] = 0xAA; - addr[0x02AA] = 0x55; - addr[0x0555] = 0x80; - addr[0x0555] = 0xAA; - addr[0x02AA] = 0x55; - - /* Start erase on unprotected sectors */ - for (sect = s_first; sect<=s_last; sect++) - { - if (info->protect[sect] == 0) /* not protected */ - { - addr = (volatile unsigned char *)(info->start[sect]); - addr[0] = 0x30; - l_sect = sect; - } - } - - /* re-enable interrupts if necessary */ - if ( flag ) - enable_interrupts(); - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - - /* - * We wait for the last triggered sector - */ - if ( l_sect < 0 ) - goto DONE; - - start = get_timer (0); - last = start; - addr = (volatile unsigned char *)(info->start[l_sect]); - while ( (addr[0] & 0x80) != 0x80 ) - { - if ( (now = get_timer(start)) > CONFIG_SYS_FLASH_ERASE_TOUT ) - { - printf ("Timeout\n"); - return ( 1 ); - } - /* show that we're waiting */ - if ( (now - last) > 1000 ) /* every second */ - { - putc ('.'); - last = now; - } - } - -DONE: - /* reset to read mode */ - addr = (volatile unsigned char *)info->start[0]; - addr[0] = 0xF0; /* reset bank */ - - printf (" done\n"); - - return ( 0 ); -} - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ - -int -write_buff (flash_info_t *info, - uchar *src, - ulong addr, - ulong cnt) -{ - ulong cp, wp, data; - uchar bdata; - int i, l, rc; - - if ( (info->flash_id & FLASH_TYPEMASK) == FLASH_AM040 ) - { - /* Width of the data bus: 8 bits */ - - wp = addr; - - while ( cnt ) - { - bdata = *src++; - - if ( (rc = write_byte(info, wp, bdata)) != 0 ) - { - return (rc); - } - - ++wp; - --cnt; - } - - return ( 0 ); - } - else - { - /* Width of the data bus: 32 bits */ - - wp = (addr & ~3); /* get lower word aligned address */ - - /* - * handle unaligned start bytes - */ - if ( (l = addr - wp) != 0 ) - { - data = 0; - for (i=0, cp=wp; i<l; ++i, ++cp) - { - data = (data << 8) | (*(uchar *)cp); - } - for (; i<4 && cnt>0; ++i) - { - data = (data << 8) | *src++; - --cnt; - ++cp; - } - for (; cnt==0 && i<4; ++i, ++cp) - { - data = (data << 8) | (*(uchar *)cp); - } - - if ( (rc = write_word(info, wp, data)) != 0 ) - { - return (rc); - } - wp += 4; - } - - /* - * handle word aligned part - */ - while ( cnt >= 4 ) - { - data = 0; - for (i=0; i<4; ++i) - { - data = (data << 8) | *src++; - } - if ( (rc = write_word(info, wp, data)) != 0 ) - { - return (rc); - } - wp += 4; - cnt -= 4; - } - - if ( cnt == 0 ) - { - return (0); - } - - /* - * handle unaligned tail bytes - */ - data = 0; - for (i=0, cp=wp; i<4 && cnt>0; ++i, ++cp) - { - data = (data << 8) | *src++; - --cnt; - } - for (; i<4; ++i, ++cp) - { - data = (data << 8) | (*(uchar *)cp); - } - - return (write_word(info, wp, data)); - } -} - -/*----------------------------------------------------------------------- - * Write a word to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int -write_word (flash_info_t *info, - ulong dest, - ulong data) -{ - vu_long *addr = (vu_long*)(info->start[0]); - ulong start; - int flag; - - /* Check if Flash is (sufficiently) erased */ - if ( (*((vu_long *)dest) & data) != data ) - { - return (2); - } - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - addr[0x0555] = 0x00AA00AA; - addr[0x02AA] = 0x00550055; - addr[0x0555] = 0x00A000A0; - - *((vu_long *)dest) = data; - - /* re-enable interrupts if necessary */ - if ( flag ) - enable_interrupts(); - - /* data polling for D7 */ - start = get_timer (0); - while ( (*((vu_long *)dest) & 0x00800080) != (data & 0x00800080) ) - { - if ( get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT ) - { - return (1); - } - } - - return (0); -} - -/*----------------------------------------------------------------------- - * Write a byte to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int -write_byte (flash_info_t *info, - ulong dest, - uchar data) -{ - volatile unsigned char *addr = (volatile unsigned char *)(info->start[0]); - ulong start; - int flag; - - /* Check if Flash is (sufficiently) erased */ - if ( (*((volatile unsigned char *)dest) & data) != data ) - { - return (2); - } - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - addr[0x0555] = 0xAA; - addr[0x02AA] = 0x55; - addr[0x0555] = 0xA0; - - *((volatile unsigned char *)dest) = data; - - /* re-enable interrupts if necessary */ - if ( flag ) - enable_interrupts(); - - /* data polling for D7 */ - start = get_timer (0); - while ( (*((volatile unsigned char *)dest) & 0x80) != (data & 0x80) ) - { - if ( get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT ) - { - return (1); - } - } - - return (0); -} - -/*----------------------------------------------------------------------- - */ diff --git a/board/LEOX/elpt860/u-boot.lds b/board/LEOX/elpt860/u-boot.lds deleted file mode 100644 index c5e57ec..0000000 --- a/board/LEOX/elpt860/u-boot.lds +++ /dev/null @@ -1,103 +0,0 @@ -/* -**===================================================================== -** -** Copyright (C) 2000, 2001, 2002, 2003 -** The LEOX team team@leox.org, http://www.leox.org -** -** LEOX.org is about the development of free hardware and software resources -** for system on chip. -** -** Description: U-Boot port on the LEOX's ELPT860 CPU board -** ~~~~~~~~~~~ -** -**===================================================================== -** - * SPDX-License-Identifier: GPL-2.0+ -** -**===================================================================== -*/ - -OUTPUT_ARCH(powerpc) - -SECTIONS -{ - /* Read-only sections, merged into text segment: */ - . = + SIZEOF_HEADERS; - .text : - { - /* WARNING - the following is hand-optimized to fit within */ - /* the sector layout of our flash chips! XXX FIXME XXX */ - - arch/powerpc/cpu/mpc8xx/start.o (.text*) - arch/powerpc/cpu/mpc8xx/traps.o (.text*) - common/built-in.o (.text*) - arch/powerpc/cpu/mpc8xx/built-in.o (.text*) - board/LEOX/elpt860/built-in.o (.text*) - arch/powerpc/lib/built-in.o (.text*) - - . = env_offset; - common/env_embedded.o (.text*) - - *(.text*) - } - _etext = .; - PROVIDE (etext = .); - .rodata : - { - *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) - } - - /* Read-write section, merged into data segment: */ - . = (. + 0x00FF) & 0xFFFFFF00; - _erotext = .; - PROVIDE (erotext = .); - .reloc : - { - _GOT2_TABLE_ = .; - KEEP(*(.got2)) - KEEP(*(.got)) - PROVIDE(_GLOBAL_OFFSET_TABLE_ = . + 4); - _FIXUP_TABLE_ = .; - KEEP(*(.fixup)) - } - __got2_entries = ((_GLOBAL_OFFSET_TABLE_ - _GOT2_TABLE_) >> 2) - 1; - __fixup_entries = (. - _FIXUP_TABLE_)>>2; - - .data : - { - *(.data*) - *(.sdata*) - } - _edata = .; - PROVIDE (edata = .); - - . = .; - - . = ALIGN(4); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); - } - - . = .; - __start___ex_table = .; - __ex_table : { *(__ex_table) } - __stop___ex_table = .; - - . = ALIGN(256); - __init_begin = .; - .text.init : { *(.text.init) } - .data.init : { *(.data.init) } - . = ALIGN(256); - __init_end = .; - - __bss_start = .; - .bss (NOLOAD) : - { - *(.bss*) - *(.sbss*) - *(COMMON) - . = ALIGN(4); - } - __bss_end = . ; - PROVIDE (end = .); -} diff --git a/board/LEOX/elpt860/u-boot.lds.debug b/board/LEOX/elpt860/u-boot.lds.debug deleted file mode 100644 index ce81046..0000000 --- a/board/LEOX/elpt860/u-boot.lds.debug +++ /dev/null @@ -1,126 +0,0 @@ -/* -**===================================================================== -** -** Copyright (C) 2000, 2001, 2002, 2003 -** The LEOX team team@leox.org, http://www.leox.org -** -** LEOX.org is about the development of free hardware and software resources -** for system on chip. -** -** Description: U-Boot port on the LEOX's ELPT860 CPU board -** ~~~~~~~~~~~ -** -**===================================================================== -** - * SPDX-License-Identifier: GPL-2.0+ -** -**===================================================================== -*/ - -OUTPUT_ARCH(powerpc) -/* Do we need any of these for elf? - __DYNAMIC = 0; */ -SECTIONS -{ - /* Read-only sections, merged into text segment: */ - . = + SIZEOF_HEADERS; - .interp : { *(.interp) } - .hash : { *(.hash) } - .dynsym : { *(.dynsym) } - .dynstr : { *(.dynstr) } - .rel.text : { *(.rel.text) } - .rela.text : { *(.rela.text) } - .rel.data : { *(.rel.data) } - .rela.data : { *(.rela.data) } - .rel.rodata : { *(.rel.rodata) } - .rela.rodata : { *(.rela.rodata) } - .rel.got : { *(.rel.got) } - .rela.got : { *(.rela.got) } - .rel.ctors : { *(.rel.ctors) } - .rela.ctors : { *(.rela.ctors) } - .rel.dtors : { *(.rel.dtors) } - .rela.dtors : { *(.rela.dtors) } - .rel.bss : { *(.rel.bss) } - .rela.bss : { *(.rela.bss) } - .rel.plt : { *(.rel.plt) } - .rela.plt : { *(.rela.plt) } - .init : { *(.init) } - .plt : { *(.plt) } - .text : - { - /* WARNING - the following is hand-optimized to fit within */ - /* the sector layout of our flash chips! XXX FIXME XXX */ - - arch/powerpc/cpu/mpc8xx/start.o (.text) - common/dlmalloc.o (.text) - lib/vsprintf.o (.text) - lib/crc32.o (.text) - - . = env_offset; - common/env_embedded.o (.text) - - *(.text) - *(.got1) - } - _etext = .; - PROVIDE (etext = .); - .rodata : - { - *(.rodata) - *(.rodata1) - *(.rodata.str1.4) - *(.eh_frame) - } - .fini : { *(.fini) } =0 - .ctors : { *(.ctors) } - .dtors : { *(.dtors) } - - /* Read-write section, merged into data segment: */ - . = (. + 0x0FFF) & 0xFFFFF000; - _erotext = .; - PROVIDE (erotext = .); - .reloc : - { - *(.got) - _GOT2_TABLE_ = .; - *(.got2) - _FIXUP_TABLE_ = .; - *(.fixup) - } - __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; - __fixup_entries = (. - _FIXUP_TABLE_)>>2; - - .data : - { - *(.data) - *(.data1) - *(.sdata) - *(.sdata2) - *(.dynamic) - CONSTRUCTORS - } - _edata = .; - PROVIDE (edata = .); - - __start___ex_table = .; - __ex_table : { *(__ex_table) } - __stop___ex_table = .; - - . = ALIGN(4096); - __init_begin = .; - .text.init : { *(.text.init) } - .data.init : { *(.data.init) } - . = ALIGN(4096); - __init_end = .; - - __bss_start = .; - .bss : - { - *(.sbss) *(.scommon) - *(.dynbss) - *(.bss) - *(COMMON) - } - __bss_end = . ; - PROVIDE (end = .); -} diff --git a/configs/ELPT860_defconfig b/configs/ELPT860_defconfig deleted file mode 100644 index d02b313..0000000 --- a/configs/ELPT860_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_ELPT860=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 8bd7056..426cadc 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,7 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +ELPT860 powerpc mpc8xx - - The LEOX team team@leox.org hmi1001 powerpc mpc5xxx - - mucmc52 powerpc mpc5xxx - - Heiko Schocher hs@denx.de uc101 powerpc mpc5xxx - - Heiko Schocher hs@denx.de diff --git a/include/commproc.h b/include/commproc.h index 3e19603..af67878 100644 --- a/include/commproc.h +++ b/include/commproc.h @@ -456,32 +456,6 @@ typedef struct scc_enet { #define SICR_ENET_CLKRT ((uint)0x00002c00) #endif /* CONFIG_BSEIP */
-/*** ELPT860 *********************************************************/ - -#ifdef CONFIG_ELPT860 -/* Bits in parallel I/O port registers that have to be set/cleared - * to configure the pins for SCC1 use. - */ -# define PROFF_ENET PROFF_SCC1 -# define CPM_CR_ENET CPM_CR_CH_SCC1 -# define SCC_ENET 0 - -# define PA_ENET_RXD ((ushort)0x0001) /* PA 15 */ -# define PA_ENET_TXD ((ushort)0x0002) /* PA 14 */ -# define PA_ENET_RCLK ((ushort)0x0100) /* PA 7 */ -# define PA_ENET_TCLK ((ushort)0x0200) /* PA 6 */ - -# define PC_ENET_TENA ((ushort)0x0001) /* PC 15 */ -# define PC_ENET_CLSN ((ushort)0x0010) /* PC 11 */ -# define PC_ENET_RENA ((ushort)0x0020) /* PC 10 */ - -/* Control bits in the SICR to route TCLK (CLK2) and RCLK (CLK1) to - * SCC1. Also, make sure GR1 (bit 24) and SC1 (bit 25) are zero. - */ -# define SICR_ENET_MASK ((uint)0x000000FF) -# define SICR_ENET_CLKRT ((uint)0x00000025) -#endif /* CONFIG_ELPT860 */ - /*** ESTEEM 192E **************************************************/ #ifdef CONFIG_ESTEEM192E /* ESTEEM192E diff --git a/include/configs/ELPT860.h b/include/configs/ELPT860.h deleted file mode 100644 index a9d62c8..0000000 --- a/include/configs/ELPT860.h +++ /dev/null @@ -1,374 +0,0 @@ -/* -**===================================================================== -** -** Copyright (C) 2000, 2001, 2002, 2003 -** The LEOX team team@leox.org, http://www.leox.org -** -** LEOX.org is about the development of free hardware and software resources -** for system on chip. -** -** Description: U-Boot port on the LEOX's ELPT860 CPU board -** ~~~~~~~~~~~ -** -**===================================================================== -** - * SPDX-License-Identifier: GPL-2.0+ -** -**===================================================================== -*/ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC860 1 /* It's a MPC860, in fact a 860T CPU */ -#define CONFIG_MPC860T 1 -#define CONFIG_ELPT860 1 /* ...on a LEOX's ELPT860 CPU board */ - -#define CONFIG_SYS_TEXT_BASE 0x02000000 - -#define CONFIG_8xx_CONS_SMC1 1 /* Console is on SMC1 */ -#undef CONFIG_8xx_CONS_SMC2 -#undef CONFIG_8xx_CONS_NONE - -#define CONFIG_CLOCKS_IN_MHZ 1 /* Clock passed to Linux (<2.4.5) in MHz */ -#define CONFIG_8xx_GCLK_FREQ 50000000 /* MPC860T runs at 50MHz */ - -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ - -#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ -#define CONFIG_RESET_PHY_R 1 /* Call reset_phy() */ - -/* BOOT arguments */ -#define CONFIG_PREBOOT \ - "echo;" \ - "echo Type "run nfsboot" to mount root filesystem over NFS;" \ - "echo" - -#undef CONFIG_BOOTARGS - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "ramargs=setenv bootargs root=/dev/ram rw\0" \ - "rootargs=setenv rootpath /tftp/${ipaddr}\0" \ - "nfsargs=setenv bootargs root=/dev/nfs rw " \ - "nfsroot=${serverip}:${rootpath}\0" \ - "addip=setenv bootargs ${bootargs} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ - ":${hostname}:eth0:off panic=1\0" \ - "ramboot=tftp 400000 /home/paugaml/pMulti;" \ - "run ramargs;bootm\0" \ - "nfsboot=tftp 400000 /home/paugaml/uImage;" \ - "run rootargs;run nfsargs;run addip;bootm\0" \ - "" -#define CONFIG_BOOTCOMMAND "run ramboot" - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE - - -#undef CONFIG_WATCHDOG /* watchdog disabled */ -#undef CONFIG_CAN_DRIVER /* CAN Driver support disabled */ -#undef CONFIG_RTC_MPC8xx /* internal RTC MPC8xx unused */ -#define CONFIG_RTC_DS164x 1 /* RTC is a Dallas DS1646 */ - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_DATE - - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "LEOX_elpt860: " /* Monitor Command Prompt */ - -#if defined(CONFIG_CMD_KGDB) -# define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -# define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif - -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x00400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x00C00000 /* 4 ... 12 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x00100000 /* default load address */ - -/* - * Environment Variables and Storages - */ -#define CONFIG_ENV_OVERWRITE 1 /* Allow Overwrite of serial# & ethaddr */ - -#undef CONFIG_ENV_IS_IN_NVRAM /* Environment is in NVRAM */ -#undef CONFIG_ENV_IS_IN_EEPROM /* Environment is in I2C EEPROM */ -#define CONFIG_ENV_IS_IN_FLASH 1 /* Environment is in FLASH */ - -#define CONFIG_BAUDRATE 9600 /* console baudrate = 9600 bps */ - -#define CONFIG_ETHADDR 00:01:77:00:60:40 -#define CONFIG_IPADDR 192.168.0.30 -#define CONFIG_NETMASK 255.255.255.0 - -#define CONFIG_SERVERIP 192.168.0.1 -#define CONFIG_GATEWAYIP 192.168.0.1 - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ - -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xFF000000 - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0x02000000 -#define CONFIG_SYS_NVRAM_BASE 0x03000000 - -#if defined(CONFIG_ENV_IS_IN_FLASH) -# if defined(DEBUG) -# define CONFIG_SYS_MONITOR_LEN (320 << 10) /* Reserve 320 kB for Monitor */ -# else -# define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -# endif -#else -# if defined(DEBUG) -# define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -# else -# define CONFIG_SYS_MONITOR_LEN (192 << 10) /* Reserve 192 kB for Monitor */ -# endif -#endif - -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 8 /* max number of sectors on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ - -#if defined(CONFIG_ENV_IS_IN_FLASH) -# define CONFIG_ENV_OFFSET 0x10000 /* Offset of Environment Sector */ -# define CONFIG_ENV_SIZE 0x10000 /* Total Size of Environment Sector */ -#endif - -/*----------------------------------------------------------------------- - * NVRAM organization - */ -#define CONFIG_SYS_NVRAM_BASE_ADDR CONFIG_SYS_NVRAM_BASE /* Base address of NVRAM area */ -#define CONFIG_SYS_NVRAM_SIZE ((128*1024)-8) /* clock regs resident in the */ - /* 8 top NVRAM locations */ - -#if defined(CONFIG_ENV_IS_IN_NVRAM) -# define CONFIG_ENV_ADDR CONFIG_SYS_NVRAM_BASE /* Base address of NVRAM area */ -# define CONFIG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */ -#endif - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ - -#if defined(CONFIG_CMD_KGDB) -# define CONFIG_SYS_CACHELINE_SHIFT 4 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 11-9 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Software & Bus Monitor Timer max, Bus Monitor enable, SW Watchdog freeze - */ -#if defined(CONFIG_WATCHDOG) -# define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | \ - SYPCR_SWE | SYPCR_SWRI | SYPCR_SWP) -#else -# define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | \ - SYPCR_SWP) -#endif - -/*----------------------------------------------------------------------- - * SUMCR - SIU Module Configuration 11-6 - *----------------------------------------------------------------------- - * PCMCIA config., multi-function pin tri-state - */ -#define CONFIG_SYS_SIUMCR (SIUMCR_DBGC11) - -/*----------------------------------------------------------------------- - * TBSCR - Time Base Status and Control 11-26 - *----------------------------------------------------------------------- - * Clear Reference Interrupt Status, Timebase freezing enabled - */ -#define CONFIG_SYS_TBSCR (TBSCR_REFA | TBSCR_REFB | TBSCR_TBF) - -/*----------------------------------------------------------------------- - * RTCSC - Real-Time Clock Status and Control Register 11-27 - *----------------------------------------------------------------------- - * Once-per-Second Interrupt, Alarm Interrupt, RTC freezing enabled, RTC - * enabled - */ -#define CONFIG_SYS_RTCSC (RTCSC_SEC | RTCSC_ALR | RTCSC_RTF| RTCSC_RTE) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 11-31 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Interrupt Timer freezing enabled - */ -#define CONFIG_SYS_PISCR (PISCR_PS | PISCR_PITF) - -/*----------------------------------------------------------------------- - * PLPRCR - PLL, Low-Power, and Reset Control Register 15-30 - *----------------------------------------------------------------------- - * Reset PLL lock status sticky bit, timer expired status bit and timer - * interrupt status bit - leave PLL multiplication factor unchanged ! - */ -#define CONFIG_SYS_PLPRCR (PLPRCR_SPLSS | PLPRCR_TEXPS | PLPRCR_TMIST) - -/*----------------------------------------------------------------------- - * SCCR - System Clock and reset Control Register 15-27 - *----------------------------------------------------------------------- - * Set clock output, timebase and RTC source and divider, - * power management and some other internal clocks - */ -#define SCCR_MASK SCCR_EBDF11 -#define CONFIG_SYS_SCCR (SCCR_TBS | \ - SCCR_COM00 | SCCR_DFSYNC00 | SCCR_DFBRG00 | \ - SCCR_DFNL000 | SCCR_DFNH000 | SCCR_DFLCD000 | \ - SCCR_DFALCD00) - -/*----------------------------------------------------------------------- - * Chip Selects + SDRAM timings + Memory Periodic Timer Prescaler - *----------------------------------------------------------------------- - * - */ -#ifdef DEBUG -# define CONFIG_SYS_DER 0xFFE7400F /* Debug Enable Register */ -#else -# define CONFIG_SYS_DER 0 -#endif - -/* - * Init Memory Controller: - * ~~~~~~~~~~~~~~~~~~~~~~ - * - * BR0 and OR0 (FLASH) - */ - -#define FLASH_BASE0_PRELIM CONFIG_SYS_FLASH_BASE /* FLASH bank #0 */ - -/* used to re-map FLASH both when starting from SRAM or FLASH: - * restrict access enough to keep SRAM working (if any) - * but not too much to meddle with FLASH accesses - */ -#define CONFIG_SYS_PRELIM_OR_AM 0xFF000000 /* 16 MB between each CSx */ - -/* FLASH timing: ACS = 11, TRLX = 0, CSNT = 0, SCY = 8, EHTR = 0 */ -#define CONFIG_SYS_OR_TIMING_FLASH (OR_ACS_DIV2 | OR_BI | OR_SCY_8_CLK) - -#define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_BR0_PRELIM ((FLASH_BASE0_PRELIM & BR_BA_MSK) | BR_PS_8 | BR_V ) - -/* - * BR1 and OR1 (SDRAM) - * - */ -#define SDRAM_BASE1_PRELIM CONFIG_SYS_SDRAM_BASE /* SDRAM bank #0 */ -#define SDRAM_MAX_SIZE 0x02000000 /* 32 MB MAX for CS1 */ - -/* SDRAM timing: */ -#define CONFIG_SYS_OR_TIMING_SDRAM 0x00000000 - -#define CONFIG_SYS_OR1_PRELIM ((2 * CONFIG_SYS_PRELIM_OR_AM) | CONFIG_SYS_OR_TIMING_SDRAM ) -#define CONFIG_SYS_BR1_PRELIM ((SDRAM_BASE1_PRELIM & BR_BA_MSK) | BR_MS_UPMA | BR_V ) - -/* - * BR2 and OR2 (NVRAM) - * - */ -#define NVRAM_BASE1_PRELIM CONFIG_SYS_NVRAM_BASE /* NVRAM bank #0 */ -#define NVRAM_MAX_SIZE 0x00020000 /* 128 KB MAX for CS2 */ - -#define CONFIG_SYS_OR2_PRELIM 0xFFF80160 -#define CONFIG_SYS_BR2_PRELIM ((NVRAM_BASE1_PRELIM & BR_BA_MSK) | BR_PS_8 | BR_V ) - -/* - * Memory Periodic Timer Prescaler - */ - -/* periodic timer for refresh */ -#define CONFIG_SYS_MAMR_PTA 97 /* start with divider for 100 MHz */ - -/* refresh rate 15.6 us (= 64 ms / 4K = 62.4 / quad bursts) for <= 128 MBit */ -#define CONFIG_SYS_MPTPR_2BK_4K MPTPR_PTP_DIV16 /* setting for 2 banks */ -#define CONFIG_SYS_MPTPR_1BK_4K MPTPR_PTP_DIV32 /* setting for 1 bank */ - -/* refresh rate 7.8 us (= 64 ms / 8K = 31.2 / quad bursts) for 256 MBit */ -#define CONFIG_SYS_MPTPR_2BK_8K MPTPR_PTP_DIV8 /* setting for 2 banks */ -#define CONFIG_SYS_MPTPR_1BK_8K MPTPR_PTP_DIV16 /* setting for 1 bank */ - -/* - * MAMR settings for SDRAM - */ - -/* 8 column SDRAM */ -#define CONFIG_SYS_MAMR_8COL ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_0 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A11 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) -/* 9 column SDRAM */ -#define CONFIG_SYS_MAMR_9COL ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_1 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A10 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) - -#endif /* __CONFIG_H */
On Mon, Dec 15, 2014 at 11:26:08PM +0900, Masahiro Yamada wrote:
This board is still a non-generic board.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: The LEOX team team@leox.org
These boards are still non-generic boards.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Klaus Heydeck heydeck@kieback-peter.de ---
arch/powerpc/cpu/mpc8xx/Kconfig | 8 - arch/powerpc/cpu/mpc8xx/cpu.c | 11 - board/kup/common/flash.c | 499 --------------------------------- board/kup/common/kup.c | 68 ----- board/kup/common/kup.h | 40 --- board/kup/common/load_sernum_ethaddr.c | 78 ------ board/kup/common/pcmcia.c | 221 --------------- board/kup/kup4k/Kconfig | 12 - board/kup/kup4k/MAINTAINERS | 6 - board/kup/kup4k/Makefile | 8 - board/kup/kup4k/kup4k.c | 289 ------------------- board/kup/kup4k/u-boot.lds.debug | 121 -------- board/kup/kup4x/Kconfig | 12 - board/kup/kup4x/MAINTAINERS | 6 - board/kup/kup4x/Makefile | 8 - board/kup/kup4x/kup4x.c | 185 ------------ board/kup/kup4x/u-boot.lds | 82 ------ board/kup/kup4x/u-boot.lds.debug | 121 -------- configs/KUP4K_defconfig | 3 - configs/KUP4X_defconfig | 3 - doc/README.scrapyard | 2 + include/commproc.h | 30 -- include/configs/KUP4K.h | 488 -------------------------------- include/configs/KUP4X.h | 440 ----------------------------- include/status_led.h | 16 -- 25 files changed, 2 insertions(+), 2755 deletions(-) delete mode 100644 board/kup/common/flash.c delete mode 100644 board/kup/common/kup.c delete mode 100644 board/kup/common/kup.h delete mode 100644 board/kup/common/load_sernum_ethaddr.c delete mode 100644 board/kup/common/pcmcia.c delete mode 100644 board/kup/kup4k/Kconfig delete mode 100644 board/kup/kup4k/MAINTAINERS delete mode 100644 board/kup/kup4k/Makefile delete mode 100644 board/kup/kup4k/kup4k.c delete mode 100644 board/kup/kup4k/u-boot.lds.debug delete mode 100644 board/kup/kup4x/Kconfig delete mode 100644 board/kup/kup4x/MAINTAINERS delete mode 100644 board/kup/kup4x/Makefile delete mode 100644 board/kup/kup4x/kup4x.c delete mode 100644 board/kup/kup4x/u-boot.lds delete mode 100644 board/kup/kup4x/u-boot.lds.debug delete mode 100644 configs/KUP4K_defconfig delete mode 100644 configs/KUP4X_defconfig delete mode 100644 include/configs/KUP4K.h delete mode 100644 include/configs/KUP4X.h
diff --git a/arch/powerpc/cpu/mpc8xx/Kconfig b/arch/powerpc/cpu/mpc8xx/Kconfig index 30f8533..7fa5b0b 100644 --- a/arch/powerpc/cpu/mpc8xx/Kconfig +++ b/arch/powerpc/cpu/mpc8xx/Kconfig @@ -37,12 +37,6 @@ config TARGET_RRVISION config TARGET_SPD823TS bool "Support SPD823TS"
-config TARGET_KUP4K - bool "Support KUP4K" - -config TARGET_KUP4X - bool "Support KUP4X" - config TARGET_TQM823L bool "Support TQM823L"
@@ -86,8 +80,6 @@ source "board/cogent/Kconfig" source "board/esteem192e/Kconfig" source "board/ip860/Kconfig" source "board/ivm/Kconfig" -source "board/kup/kup4k/Kconfig" -source "board/kup/kup4x/Kconfig" source "board/lwmon/Kconfig" source "board/netvia/Kconfig" source "board/r360mpi/Kconfig" diff --git a/arch/powerpc/cpu/mpc8xx/cpu.c b/arch/powerpc/cpu/mpc8xx/cpu.c index eb4432f..9967664 100644 --- a/arch/powerpc/cpu/mpc8xx/cpu.c +++ b/arch/powerpc/cpu/mpc8xx/cpu.c @@ -598,17 +598,6 @@ void reset_8xx_watchdog (volatile immap_t * immr) immr->im_ioport.iop_paodr &= ~(WATCHDOG_BIT); /* active output */
immr->im_ioport.iop_padat ^= WATCHDOG_BIT; /* Toggle WDI */ -# elif defined(CONFIG_KUP4K) || defined(CONFIG_KUP4X) - /* - * The KUP4 boards uses a TPS3705 Watchdog - * with the trigger pin connected to port PA.5 - */ -# define WATCHDOG_BIT 0x0400 - immr->im_ioport.iop_papar &= ~(WATCHDOG_BIT); /* GPIO */ - immr->im_ioport.iop_padir |= WATCHDOG_BIT; /* Output */ - immr->im_ioport.iop_paodr &= ~(WATCHDOG_BIT); /* active output */ - - immr->im_ioport.iop_padat ^= WATCHDOG_BIT; /* Toggle WDI */ # else /* * All other boards use the MPC8xx Internal Watchdog diff --git a/board/kup/common/flash.c b/board/kup/common/flash.c deleted file mode 100644 index 77c7b6c..0000000 --- a/board/kup/common/flash.c +++ /dev/null @@ -1,499 +0,0 @@ -/* - * (C) Copyright 2000-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc8xx.h> - -#ifndef CONFIG_ENV_ADDR -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET) -#endif - -#define CONFIG_FLASH_16BIT - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH chips */ - -/*----------------------------------------------------------------------- - * Functions - */ -static ulong flash_get_size (vu_long *addr, flash_info_t *info); -static int write_word (flash_info_t *info, ulong dest, ulong data); - -/*----------------------------------------------------------------------- - */ - -unsigned long flash_init (void) -{ - volatile immap_t *immap = (immap_t *)CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - unsigned long size_b0; - int i; - - /* Init: no FLASHes known */ - for (i=0; i<CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - } - - /* Static FLASH Bank configuration here - FIXME XXX */ - - size_b0 = flash_get_size((vu_long *)FLASH_BASE0_PRELIM, &flash_info[0]); - - if (flash_info[0].flash_id == FLASH_UNKNOWN) { - printf ("## Unknown FLASH on Bank 0 - Size = 0x%08lx = %ld MB\n", - size_b0, size_b0<<20); - } - - - /* Remap FLASH according to real size */ - memctl->memc_or0 = CONFIG_SYS_OR_TIMING_FLASH | (-size_b0 & OR_AM_MSK); - memctl->memc_br0 = (CONFIG_SYS_FLASH_BASE & BR_BA_MSK) | BR_MS_GPCM | BR_V | BR_PS_16; - - /* Re-do sizing to get full correct info */ - size_b0 = flash_get_size((vu_long *)CONFIG_SYS_FLASH_BASE, &flash_info[0]); - -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE - /* monitor protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE+monitor_flash_len-1, - &flash_info[0]); -#endif - -#ifdef CONFIG_ENV_IS_IN_FLASH - /* ENV protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR+CONFIG_ENV_SIZE-1, - &flash_info[0]); -#endif - - flash_info[0].size = size_b0; - - return (size_b0); -} - -/*----------------------------------------------------------------------- - */ -void flash_print_info (flash_info_t *info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_AMD: printf ("AMD "); break; - case FLASH_MAN_FUJ: printf ("FUJITSU "); break; - default: printf ("Unknown Vendor "); break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_AM400B: printf ("AM29LV400B (4 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM400T: printf ("AM29LV400T (4 Mbit, top boot sector)\n"); - break; - case FLASH_AM800B: printf ("AM29LV800B (8 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM800T: printf ("AM29LV800T (8 Mbit, top boot sector)\n"); - break; - case FLASH_AM160B: printf ("AM29LV160B (16 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM160T: printf ("AM29LV160T (16 Mbit, top boot sector)\n"); - break; - case FLASH_AM320B: printf ("AM29LV320B (32 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM320T: printf ("AM29LV320T (32 Mbit, top boot sector)\n"); - break; - default: printf ("Unknown Chip Type\n"); - break; - } - - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); - - printf (" Sector Start Addresses:"); - for (i=0; i<info->sector_count; ++i) { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", - info->start[i], - info->protect[i] ? " (RO)" : " " - ); - } - printf ("\n"); - return; -} - -/*----------------------------------------------------------------------- - */ - - -/*----------------------------------------------------------------------- - */ - -/* - * The following code cannot be run from FLASH! - */ - -static ulong flash_get_size (vu_long *addr, flash_info_t *info) -{ - short i; - ulong value; - ulong base = (ulong)addr; - - /* Write auto select command: read Manufacturer ID */ - vu_short *s_addr=(vu_short*)addr; - s_addr[0x5555] = 0x00AA; - s_addr[0x2AAA] = 0x0055; - s_addr[0x5555] = 0x0090; - - value = s_addr[0]; - value = value|(value<<16); - - switch (value) { - case AMD_MANUFACT: - info->flash_id = FLASH_MAN_AMD; - break; - case FUJ_MANUFACT: - info->flash_id = FLASH_MAN_FUJ; - break; - default: - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - return (0); /* no or unknown flash */ - } - - value = s_addr[1]; - value = value|(value<<16); - - switch (value) { - case FUJI_ID_29F800BA: - info->flash_id += FLASH_AM400T; - info->sector_count = 19; - info->size = 0x00100000; - break; /* => 1 MB */ - case AMD_ID_LV800T: - info->flash_id += FLASH_AM800T; - info->sector_count = 19; - info->size = 0x00100000; - break; /* => 1 MB */ - case AMD_ID_LV800B: - info->flash_id += FLASH_AM800B; - info->sector_count = 19; - info->size = 0x00100000; - break; /* => 1 MB */ - default: - info->flash_id = FLASH_UNKNOWN; - return (0); /* => no or unknown flash */ - } - - /* set up sector start address table */ - /* set sector offsets for bottom boot block type */ - info->start[0] = base + 0x00000000; - info->start[1] = base + 0x00004000; - info->start[2] = base + 0x00006000; - info->start[3] = base + 0x00008000; - for (i = 4; i < info->sector_count; i++) { - info->start[i] = base + (i * 0x00010000) - 0x00030000; - } - - - /* check for protected sectors */ - for (i = 0; i < info->sector_count; i++) { - /* read sector protection at sector address, (A7 .. A0) = 0x02 */ - /* D0 = 1 if protected */ - s_addr = (volatile unsigned short *)(info->start[i]); - info->protect[i] = s_addr[2] & 1; - } - - /* - * Prevent writes to uninitialized FLASH. - */ - if (info->flash_id != FLASH_UNKNOWN) { - s_addr = (volatile unsigned short *)info->start[0]; - *s_addr = 0x00F0; /* reset bank */ - } - return (info->size); -} - - -/*----------------------------------------------------------------------- - */ - - -int flash_erase (flash_info_t *info, int s_first, int s_last) -{ - vu_long *addr = (vu_long*)(info->start[0]); - int flag, prot, sect; - ulong start, now, last; -#ifdef CONFIG_FLASH_16BIT - vu_short *s_addr = (vu_short*)addr; -#endif - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } -/*#ifndef CONFIG_FLASH_16BIT - ulong type; - type = (info->flash_id & FLASH_VENDMASK); - if ((type != FLASH_MAN_SST) && (type != FLASH_MAN_STM)) { - printf ("Can't erase unknown flash type %08lx - aborted\n", - info->flash_id); - return; - } -#endif*/ - prot = 0; - for (sect=s_first; sect<=s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - printf ("\n"); - } - - start = get_timer (0); - last = start; - /* Start erase on unprotected sectors */ - for (sect = s_first; sect<=s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ -#ifdef CONFIG_FLASH_16BIT - vu_short *s_sect_addr = (vu_short*)(info->start[sect]); -#else - vu_long *sect_addr = (vu_long*)(info->start[sect]); -#endif - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - -#ifdef CONFIG_FLASH_16BIT - - /*printf("\ns_sect_addr=%x",s_sect_addr);*/ - s_addr[0x5555] = 0x00AA; - s_addr[0x2AAA] = 0x0055; - s_addr[0x5555] = 0x0080; - s_addr[0x5555] = 0x00AA; - s_addr[0x2AAA] = 0x0055; - s_sect_addr[0] = 0x0030; -#else - addr[0x5555] = 0x00AA00AA; - addr[0x2AAA] = 0x00550055; - addr[0x5555] = 0x00800080; - addr[0x5555] = 0x00AA00AA; - addr[0x2AAA] = 0x00550055; - sect_addr[0] = 0x00300030; -#endif - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - -#ifdef CONFIG_FLASH_16BIT - while ((s_sect_addr[0] & 0x0080) != 0x0080) { -#else - while ((sect_addr[0] & 0x00800080) != 0x00800080) { -#endif - if ((now = get_timer(start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - return 1; - } - /* show that we're waiting */ - if ((now - last) > 1000) { /* every second */ - putc ('.'); - last = now; - } - } - } - } - - /* reset to read mode */ - addr = (volatile unsigned long *)info->start[0]; -#ifdef CONFIG_FLASH_16BIT - s_addr[0] = 0x00F0; /* reset bank */ -#else - addr[0] = 0x00F000F0; /* reset bank */ -#endif - - printf (" done\n"); - return 0; -} - - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ - -int write_buff (flash_info_t *info, uchar *src, ulong addr, ulong cnt) -{ - ulong cp, wp, data; - int i, l, rc; - - wp = (addr & ~3); /* get lower word aligned address */ - - /* - * handle unaligned start bytes - */ - if ((l = addr - wp) != 0) { - data = 0; - for (i=0, cp=wp; i<l; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - for (; i<4 && cnt>0; ++i) { - data = (data << 8) | *src++; - --cnt; - ++cp; - } - for (; cnt==0 && i<4; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - - if ((rc = write_word(info, wp, data)) != 0) { - return (rc); - } - wp += 4; - } - - /* - * handle word aligned part - */ - while (cnt >= 4) { - data = 0; - for (i=0; i<4; ++i) { - data = (data << 8) | *src++; - } - if ((rc = write_word(info, wp, data)) != 0) { - return (rc); - } - wp += 4; - cnt -= 4; - } - - if (cnt == 0) { - return (0); - } - - /* - * handle unaligned tail bytes - */ - data = 0; - for (i=0, cp=wp; i<4 && cnt>0; ++i, ++cp) { - data = (data << 8) | *src++; - --cnt; - } - for (; i<4; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - - return (write_word(info, wp, data)); -} - - -/*----------------------------------------------------------------------- - * Write a word to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_word (flash_info_t *info, ulong dest, ulong data) -{ - vu_long *addr = (vu_long*)(info->start[0]); - -#ifdef CONFIG_FLASH_16BIT - vu_short high_data; - vu_short low_data; - vu_short *s_addr = (vu_short*)addr; -#endif - ulong start; - int flag; - - /* Check if Flash is (sufficiently) erased */ - if ((*((vu_long *)dest) & data) != data) { - return (2); - } - -#ifdef CONFIG_FLASH_16BIT - /* Write the 16 higher-bits */ - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - high_data = ((data>>16) & 0x0000ffff); - - s_addr[0x5555] = 0x00AA; - s_addr[0x2AAA] = 0x0055; - s_addr[0x5555] = 0x00A0; - - *((vu_short *)dest) = high_data; - - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* data polling for D7 */ - start = get_timer (0); - while ((*((vu_short *)dest) & 0x0080) != (high_data & 0x0080)) { - if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - return (1); - } - } - - - /* Write the 16 lower-bits */ -#endif - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); -#ifdef CONFIG_FLASH_16BIT - dest += 0x2; - low_data = (data & 0x0000ffff); - - s_addr[0x5555] = 0x00AA; - s_addr[0x2AAA] = 0x0055; - s_addr[0x5555] = 0x00A0; - *((vu_short *)dest) = low_data; - -#else - addr[0x5555] = 0x00AA00AA; - addr[0x2AAA] = 0x00550055; - addr[0x5555] = 0x00A000A0; - *((vu_long *)dest) = data; -#endif - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* data polling for D7 */ - start = get_timer (0); - -#ifdef CONFIG_FLASH_16BIT - while ((*((vu_short *)dest) & 0x0080) != (low_data & 0x0080)) { -#else - while ((*((vu_long *)dest) & 0x00800080) != (data & 0x00800080)) { -#endif - - if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - return (1); - } - } - return (0); -} diff --git a/board/kup/common/kup.c b/board/kup/common/kup.c deleted file mode 100644 index 03ab018..0000000 --- a/board/kup/common/kup.c +++ /dev/null @@ -1,68 +0,0 @@ -/* - * (C) Copyright 2004 - * Klaus Heydeck, Kieback & Peter GmbH & Co KG, heydeck@kieback-peter.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc8xx.h> -#include "kup.h" -#include <asm/io.h> - - -int misc_init_f(void) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile sysconf8xx_t *siu = &immap->im_siu_conf; - - while (in_be32(&siu->sc_sipend) & 0x20000000) { - debug("waiting for 5V VCC\n"); - } - - /* RS232 / RS485 default is RS232 */ - clrbits_be16(&immap->im_ioport.iop_padat, PA_RS485); - clrbits_be16(&immap->im_ioport.iop_papar, PA_RS485); - clrbits_be16(&immap->im_ioport.iop_paodr, PA_RS485); - setbits_be16(&immap->im_ioport.iop_padir, PA_RS485); - - /* IO Reset min 1 msec */ - setbits_be16(&immap->im_ioport.iop_padat, - (PA_RESET_IO_01 | PA_RESET_IO_02)); - clrbits_be16(&immap->im_ioport.iop_papar, - (PA_RESET_IO_01 | PA_RESET_IO_02)); - clrbits_be16(&immap->im_ioport.iop_paodr, - (PA_RESET_IO_01 | PA_RESET_IO_02)); - setbits_be16(&immap->im_ioport.iop_padir, - (PA_RESET_IO_01 | PA_RESET_IO_02)); - udelay(1000); - clrbits_be16(&immap->im_ioport.iop_padat, - (PA_RESET_IO_01 | PA_RESET_IO_02)); - return (0); -} - -#ifdef CONFIG_IDE_LED -void ide_led(uchar led, uchar status) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - - /* We have one led for both pcmcia slots */ - if (status) - clrbits_be16(&immap->im_ioport.iop_padat, PA_LED_YELLOW); - else - setbits_be16(&immap->im_ioport.iop_padat, PA_LED_YELLOW); -} -#endif - -void poweron_key(void) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - - clrbits_be16(&immap->im_ioport.iop_pcpar, PC_SWITCH1); - clrbits_be16(&immap->im_ioport.iop_pcdir, PC_SWITCH1); - - if (in_be16(&immap->im_ioport.iop_pcdat) & (PC_SWITCH1)) - setenv("key1", "off"); - else - setenv("key1", "on"); -} diff --git a/board/kup/common/kup.h b/board/kup/common/kup.h deleted file mode 100644 index a1369ae..0000000 --- a/board/kup/common/kup.h +++ /dev/null @@ -1,40 +0,0 @@ -/* - * (C) Copyright 2004 - * Klaus Heydeck, Kieback & Peter GmbH & Co KG, heydeck@kieback-peter.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __KUP_H -#define __KUP_H - -#define PA_8 0x0080 -#define PA_9 0x0040 -#define PA_10 0x0020 -#define PA_11 0x0010 -#define PA_12 0x0008 - -#define PB_14 0x00020000 -#define PB_15 0x00010000 -#define PB_16 0x00008000 -#define PB_17 0x00004000 - -#define PC_4 0x0800 -#define PC_5 0x0400 -#define PC_9 0x0040 - -#define PA_RS485 PA_11 /* SCC1: 0=RS232 1=RS485 */ -#define PA_LED_YELLOW PA_8 -#define PA_RESET_IO_01 PA_9 /* Reset left IO */ -#define PA_RESET_IO_02 PA_10 /* Reset right IO */ -#define PB_PROG_IO_01 PB_15 /* Program left IO */ -#define PB_PROG_IO_02 PB_16 /* Program right IO */ -#define BP_USB_VCC PB_14 /* VCC for USB devices 0=vcc on, 1=vcc off */ -#define PB_LCD_PWM PB_17 /* PB 17 */ -#define PC_SWITCH1 PC_9 /* Reboot switch */ - - -extern void poweron_key(void); -extern void load_sernum_ethaddr(void); - -#endif /* __KUP_H */ diff --git a/board/kup/common/load_sernum_ethaddr.c b/board/kup/common/load_sernum_ethaddr.c deleted file mode 100644 index 20fe799..0000000 --- a/board/kup/common/load_sernum_ethaddr.c +++ /dev/null @@ -1,78 +0,0 @@ -/* - * (C) Copyright 2000-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc8xx.h> - -/*----------------------------------------------------------------------- - * Process Hardware Information Block: - * - * If we boot on a system fresh from factory, check if the Hardware - * Information Block exists and save the information it contains. - * - * The KUP Hardware Information Block is defined as - * follows: - * - located in first flash bank - * - starts at offset CONFIG_SYS_HWINFO_OFFSET - * - size CONFIG_SYS_HWINFO_SIZE - * - * Internal structure: - * - sequence of ASCII character lines - * - fields separated by <CR><LF> - * - last field terminated by NUL character (0x00) - * - * Fields in Hardware Information Block: - * 1) Module Type - * 2) MAC Address - * 3) .... - */ - - -#define ETHADDR_TOKEN "ethaddr=" -#define LCD_TOKEN "lcd=" - -void load_sernum_ethaddr (void) -{ - unsigned char *hwi; - char *var; - unsigned char hwi_stack[CONFIG_SYS_HWINFO_SIZE]; - char *p; - - hwi = (unsigned char *) (CONFIG_SYS_FLASH_BASE + CONFIG_SYS_HWINFO_OFFSET); - if (*((unsigned long *) hwi) != (unsigned long) CONFIG_SYS_HWINFO_MAGIC) { - printf ("HardwareInfo not found!\n"); - return; - } - memcpy (hwi_stack, hwi, CONFIG_SYS_HWINFO_SIZE); - - /* - ** ethaddr - */ - var = strstr ((char *)hwi_stack, ETHADDR_TOKEN); - if (var) { - var += sizeof (ETHADDR_TOKEN) - 1; - p = strchr (var, '\r'); - if ((unsigned char *)p < hwi + CONFIG_SYS_HWINFO_SIZE) { - *p = '\0'; - setenv ("ethaddr", var); - *p = '\r'; - } - } - /* - ** lcd - */ - var = strstr ((char *)hwi_stack, LCD_TOKEN); - if (var) { - var += sizeof (LCD_TOKEN) - 1; - p = strchr (var, '\r'); - if ((unsigned char *)p < hwi + CONFIG_SYS_HWINFO_SIZE) { - *p = '\0'; - setenv ("lcd", var); - *p = '\r'; - } - } -} diff --git a/board/kup/common/pcmcia.c b/board/kup/common/pcmcia.c deleted file mode 100644 index 61ba586..0000000 --- a/board/kup/common/pcmcia.c +++ /dev/null @@ -1,221 +0,0 @@ -#include <common.h> -#include <mpc8xx.h> -#include <pcmcia.h> - -#undef CONFIG_PCMCIA - -#if defined(CONFIG_CMD_PCMCIA) -#define CONFIG_PCMCIA -#endif - -#if defined(CONFIG_CMD_IDE) && defined(CONFIG_IDE_8xx_PCCARD) -#define CONFIG_PCMCIA -#endif - -#ifdef CONFIG_PCMCIA - -#define PCMCIA_BOARD_MSG "KUP" - -#define KUP4K_PCMCIA_B_3V3 (0x00020000) - -int pcmcia_hardware_enable(int slot) -{ - volatile cpm8xx_t *cp; - volatile pcmconf8xx_t *pcmp; - volatile sysconf8xx_t *sysp; - uint reg, mask; - - debug ("hardware_enable: " PCMCIA_BOARD_MSG " Slot %c\n", 'A'+slot); - - udelay(10000); - - sysp = (sysconf8xx_t *)(&(((immap_t *)CONFIG_SYS_IMMR)->im_siu_conf)); - pcmp = (pcmconf8xx_t *)(&(((immap_t *)CONFIG_SYS_IMMR)->im_pcmcia)); - cp = (cpm8xx_t *)(&(((immap_t *)CONFIG_SYS_IMMR)->im_cpm)); - - /* - * Configure SIUMCR to enable PCMCIA port B - * (VFLS[0:1] are not used for debugging, we connect FRZ# instead) - */ - sysp->sc_siumcr &= ~SIUMCR_DBGC11; /* set DBGC to 00 */ - - /* clear interrupt state, and disable interrupts */ - pcmp->pcmc_pscr = PCMCIA_MASK(slot); - pcmp->pcmc_per &= ~PCMCIA_MASK(slot); - - /* - * Disable interrupts, DMA, and PCMCIA buffers - * (isolate the interface) and assert RESET signal - */ - debug ("Disable PCMCIA buffers and assert RESET\n"); - reg = 0; - reg |= __MY_PCMCIA_GCRX_CXRESET; /* active high */ - reg |= __MY_PCMCIA_GCRX_CXOE; /* active low */ - PCMCIA_PGCRX(slot) = reg; - udelay(2500); - - /* - * Configure Port B pins for - * 3 Volts enable - */ - if (slot) { /* Slot A is built-in */ - cp->cp_pbdir |= KUP4K_PCMCIA_B_3V3; - cp->cp_pbpar &= ~KUP4K_PCMCIA_B_3V3; - /* remove all power */ - cp->cp_pbdat |= KUP4K_PCMCIA_B_3V3; /* active low */ - } - /* - * Make sure there is a card in the slot, then configure the interface. - */ - udelay(10000); - debug ("[%d] %s: PIPR(%p)=0x%x\n", - __LINE__,__FUNCTION__, - &(pcmp->pcmc_pipr),pcmp->pcmc_pipr); - if (pcmp->pcmc_pipr & (0x18000000 >> (slot << 4))) { - printf (" No Card found\n"); - return (1); - } - - /* - * Power On. - */ - printf("%s Slot %c:", slot ? "" : "\n", 'A' + slot); - mask = PCMCIA_VS1(slot) | PCMCIA_VS2(slot); - reg = pcmp->pcmc_pipr; - debug ("PIPR: 0x%x ==> VS1=o%s, VS2=o%s\n", - reg, - (reg&PCMCIA_VS1(slot))?"n":"ff", - (reg&PCMCIA_VS2(slot))?"n":"ff"); - if ((reg & mask) == mask) { - puts (" 5.0V card found: NOT SUPPORTED !!!\n"); - } else { - if(slot) - cp->cp_pbdat &= ~KUP4K_PCMCIA_B_3V3; - puts (" 3.3V card found: "); - } -#if 0 - /* VCC switch error flag, PCMCIA slot INPACK_ pin */ - cp->cp_pbdir &= ~(0x0020 | 0x0010); - cp->cp_pbpar &= ~(0x0020 | 0x0010); - udelay(500000); -#endif - debug ("Enable PCMCIA buffers and stop RESET\n"); - reg = PCMCIA_PGCRX(slot); - reg &= ~__MY_PCMCIA_GCRX_CXRESET; /* active high */ - reg &= ~__MY_PCMCIA_GCRX_CXOE; /* active low */ - PCMCIA_PGCRX(slot) = reg; - - udelay(250000); /* some cards need >150 ms to come up :-( */ - - debug ("# hardware_enable done\n"); - - return (0); -} - - -#if defined(CONFIG_CMD_PCMCIA) -int pcmcia_hardware_disable(int slot) -{ - volatile immap_t *immap; - volatile cpm8xx_t *cp; - volatile pcmconf8xx_t *pcmp; - u_long reg; - - debug ("hardware_disable: " PCMCIA_BOARD_MSG " Slot %c\n", 'A'+slot); - - immap = (immap_t *)CONFIG_SYS_IMMR; - pcmp = (pcmconf8xx_t *)(&(((immap_t *)CONFIG_SYS_IMMR)->im_pcmcia)); - cp = (cpm8xx_t *)(&(((immap_t *)CONFIG_SYS_IMMR)->im_cpm)); - - /* remove all power */ - if (slot) - cp->cp_pbdat |= KUP4K_PCMCIA_B_3V3; - - /* Configure PCMCIA General Control Register */ - debug ("Disable PCMCIA buffers and assert RESET\n"); - reg = 0; - reg |= __MY_PCMCIA_GCRX_CXRESET; /* active high */ - reg |= __MY_PCMCIA_GCRX_CXOE; /* active low */ - PCMCIA_PGCRX(slot) = reg; - - udelay(10000); - - return (0); -} -#endif - - -int pcmcia_voltage_set(int slot, int vcc, int vpp) -{ - volatile cpm8xx_t *cp; - volatile pcmconf8xx_t *pcmp; - u_long reg; - - debug ("voltage_set: " \ - PCMCIA_BOARD_MSG \ - " Slot %c, Vcc=%d.%d, Vpp=%d.%d\n", - 'A'+slot, vcc/10, vcc%10, vpp/10, vcc%10); - - if (!slot) /* Slot A is not configurable */ - return 0; - - pcmp = (pcmconf8xx_t *)(&(((immap_t *)CONFIG_SYS_IMMR)->im_pcmcia)); - cp = (cpm8xx_t *)(&(((immap_t *)CONFIG_SYS_IMMR)->im_cpm)); - - /* - * Disable PCMCIA buffers (isolate the interface) - * and assert RESET signal - */ - debug ("Disable PCMCIA buffers and assert RESET\n"); - reg = PCMCIA_PGCRX(slot); - reg |= __MY_PCMCIA_GCRX_CXRESET; /* active high */ - reg |= __MY_PCMCIA_GCRX_CXOE; /* active low */ - PCMCIA_PGCRX(slot) = reg; - udelay(500); - - debug ("PCMCIA power OFF\n"); - /* - * Configure Port B pins for - * 3 Volts enable - */ - cp->cp_pbdir |= KUP4K_PCMCIA_B_3V3; - cp->cp_pbpar &= ~KUP4K_PCMCIA_B_3V3; - /* remove all power */ - cp->cp_pbdat |= KUP4K_PCMCIA_B_3V3; /* active low */ - - switch(vcc) { - case 0: break; - case 33: - cp->cp_pbdat &= ~KUP4K_PCMCIA_B_3V3; - debug ("PCMCIA powered at 3.3V\n"); - break; - case 50: - debug ("PCMCIA: 5Volt vcc not supported\n"); - break; - default: - puts("PCMCIA: vcc not supported"); - break; - } - udelay(10000); - /* Checking supported voltages */ - - debug ("PIPR: 0x%x --> %s\n", - pcmp->pcmc_pipr, - (pcmp->pcmc_pipr & (0x80000000 >> (slot << 4))) - ? "only 5 V --> NOT SUPPORTED" - : "can do 3.3V"); - - - debug ("Enable PCMCIA buffers and stop RESET\n"); - reg = PCMCIA_PGCRX(slot); - reg &= ~__MY_PCMCIA_GCRX_CXRESET; /* active high */ - reg &= ~__MY_PCMCIA_GCRX_CXOE; /* active low */ - PCMCIA_PGCRX(slot) = reg; - udelay(500); - - debug ("voltage_set: " PCMCIA_BOARD_MSG " Slot %c, DONE\n", - slot+'A'); - return (0); -} - -#endif /* CONFIG_PCMCIA */ diff --git a/board/kup/kup4k/Kconfig b/board/kup/kup4k/Kconfig deleted file mode 100644 index 903c341..0000000 --- a/board/kup/kup4k/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_KUP4K - -config SYS_BOARD - default "kup4k" - -config SYS_VENDOR - default "kup" - -config SYS_CONFIG_NAME - default "KUP4K" - -endif diff --git a/board/kup/kup4k/MAINTAINERS b/board/kup/kup4k/MAINTAINERS deleted file mode 100644 index 25d90cf..0000000 --- a/board/kup/kup4k/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -KUP4K BOARD -M: Klaus Heydeck heydeck@kieback-peter.de -S: Maintained -F: board/kup/kup4k/ -F: include/configs/KUP4K.h -F: configs/KUP4K_defconfig diff --git a/board/kup/kup4k/Makefile b/board/kup/kup4k/Makefile deleted file mode 100644 index c896fcd..0000000 --- a/board/kup/kup4k/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = kup4k.o ../common/flash.o ../common/kup.o ../common/load_sernum_ethaddr.o ../common/pcmcia.o diff --git a/board/kup/kup4k/kup4k.c b/board/kup/kup4k/kup4k.c deleted file mode 100644 index 71c6a79..0000000 --- a/board/kup/kup4k/kup4k.c +++ /dev/null @@ -1,289 +0,0 @@ -/* - * (C) Copyright 2000-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * Klaus Heydeck, Kieback & Peter GmbH & Co KG, heydeck@kieback-peter.de - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <command.h> -#include <libfdt.h> -#include <mpc8xx.h> -#include <hwconfig.h> -#include <i2c.h> -#include "../common/kup.h" -#include <asm/io.h> - -static unsigned char swapbyte(unsigned char c); -static int read_diag(void); - -DECLARE_GLOBAL_DATA_PTR; - -/* ----------------------------------------------------------------------- */ - -#define _NOT_USED_ 0xFFFFFFFF - -const uint sdram_table[] = { - /* - * Single Read. (Offset 0 in UPMA RAM) - */ - 0x1F07FC04, 0xEEAEFC04, 0x11ADFC04, 0xEFBBBC00, - 0x1FF77C47, /* last */ - - /* - * SDRAM Initialization (offset 5 in UPMA RAM) - * - * This is no UPM entry point. The following definition uses - * the remaining space to establish an initialization - * sequence, which is executed by a RUN command. - * - */ - 0x1FF77C35, 0xEFEABC34, 0x1FB57C35, /* last */ - - /* - * Burst Read. (Offset 8 in UPMA RAM) - */ - 0x1F07FC04, 0xEEAEFC04, 0x10ADFC04, 0xF0AFFC00, - 0xF0AFFC00, 0xF1AFFC00, 0xEFBBBC00, 0x1FF77C47, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - - /* - * Single Write. (Offset 18 in UPMA RAM) - */ - 0x1F27FC04, 0xEEAEBC00, 0x01B93C04, 0x1FF77C47, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - - /* - * Burst Write. (Offset 20 in UPMA RAM) - */ - 0x1F07FC04, 0xEEAEBC00, 0x10AD7C00, 0xF0AFFC00, - 0xF0AFFC00, 0xE1BBBC04, 0x1FF77C47, /* last */ - _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - - /* - * Refresh (Offset 30 in UPMA RAM) - */ - 0x1FF5FC84, 0xFFFFFC04, 0xFFFFFC04, 0xFFFFFC04, - 0xFFFFFC84, 0xFFFFFC07, /* last */ - _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - - /* - * Exception. (Offset 3c in UPMA RAM) - */ - 0x7FFFFC07, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, -}; - -/* ----------------------------------------------------------------------- */ - -/* - * Check Board Identity: - */ - -int checkboard(void) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - uchar rev,mod,tmp,pcf,ak_rev,ak_mod; - - /* - * Init ChipSelect #4 (CAN + HW-Latch) - */ - out_be32(&immap->im_memctl.memc_or4, CONFIG_SYS_OR4); - out_be32(&immap->im_memctl.memc_br4, CONFIG_SYS_BR4); - - /* - * Init ChipSelect #5 (S1D13768) - */ - out_be32(&immap->im_memctl.memc_or5, CONFIG_SYS_OR5); - out_be32(&immap->im_memctl.memc_br5, CONFIG_SYS_BR5); - - tmp = swapbyte(in_8((unsigned char*) LATCH_ADDR)); - rev = (tmp & 0xF8) >> 3; - mod = (tmp & 0x07); - - i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); - - if (read_diag()) - gd->flags &= ~GD_FLG_SILENT; - - printf("Board: KUP4K Rev %d.%d AK:",rev,mod); - /* - * TI Application report: Before using the IO as an input, - * a high must be written to the IO first - */ - pcf = 0xFF; - i2c_write(0x21, 0, 0 , &pcf, 1); - if (i2c_read(0x21, 0, 0, &pcf, 1)) { - puts("n/a\n"); - } else { - ak_rev = (pcf & 0xF8) >> 3; - ak_mod = (pcf & 0x07); - printf("%d.%d\n", ak_rev, ak_mod); - } - return 0; -} - -/* ----------------------------------------------------------------------- */ - - -phys_size_t initdram(int board_type) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - long int size = 0; - uchar *latch, rev, tmp; - - /* - * Init ChipSelect #4 (CAN + HW-Latch) to determine Hardware Revision - * Rev 1..6 -> 48 MB RAM; Rev >= 7 -> 96 MB - */ - out_be32(&immap->im_memctl.memc_or4, CONFIG_SYS_OR4); - out_be32(&immap->im_memctl.memc_br4, CONFIG_SYS_BR4); - - latch = (uchar *)0x90000200; - tmp = swapbyte(*latch); - rev = (tmp & 0xF8) >> 3; - - upmconfig(UPMA, (uint *) sdram_table, - sizeof (sdram_table) / sizeof (uint)); - - out_be16(&memctl->memc_mptpr, CONFIG_SYS_MPTPR); - - out_be32(&memctl->memc_mar, 0x00000088); - /* no refresh yet */ - if(rev >= 7) { - out_be32(&memctl->memc_mamr, - CONFIG_SYS_MAMR_9COL & (~(MAMR_PTAE))); - } else { - out_be32(&memctl->memc_mamr, - CONFIG_SYS_MAMR_8COL & (~(MAMR_PTAE))); - } - - udelay(200); - - /* perform SDRAM initializsation sequence */ - - /* SDRAM bank 0 */ - out_be32(&memctl->memc_mcr, 0x80002105); - udelay(1); - out_be32(&memctl->memc_mcr, 0x80002830); /* execute twice */ - udelay(1); - out_be32(&memctl->memc_mcr, 0x80002106); /* RUN MRS Pattern from loc 6 */ - udelay(1); - - /* SDRAM bank 1 */ - out_be32(&memctl->memc_mcr, 0x80004105); - udelay(1); - out_be32(&memctl->memc_mcr, 0x80004830); /* execute twice */ - udelay(1); - out_be32(&memctl->memc_mcr, 0x80004106); /* RUN MRS Pattern from loc 6 */ - udelay(1); - - /* SDRAM bank 2 */ - out_be32(&memctl->memc_mcr, 0x80006105); - udelay(1); - out_be32(&memctl->memc_mcr, 0x80006830); /* execute twice */ - udelay(1); - out_be32(&memctl->memc_mcr, 0x80006106); /* RUN MRS Pattern from loc 6 */ - udelay(1); - - setbits_be32(&memctl->memc_mamr, MAMR_PTAE); /* enable refresh */ - udelay(1000); - - out_be16(&memctl->memc_mptpr, CONFIG_SYS_MPTPR); - udelay(1000); - if(rev >= 7) { - size = 32 * 3 * 1024 * 1024; - out_be32(&memctl->memc_or1, CONFIG_SYS_OR1_9COL); - out_be32(&memctl->memc_br1, CONFIG_SYS_BR1_9COL); - out_be32(&memctl->memc_or2, CONFIG_SYS_OR2_9COL); - out_be32(&memctl->memc_br2, CONFIG_SYS_BR2_9COL); - out_be32(&memctl->memc_or3, CONFIG_SYS_OR3_9COL); - out_be32(&memctl->memc_br3, CONFIG_SYS_BR3_9COL); - } else { - size = 16 * 3 * 1024 * 1024; - out_be32(&memctl->memc_or1, CONFIG_SYS_OR1_8COL); - out_be32(&memctl->memc_br1, CONFIG_SYS_BR1_8COL); - out_be32(&memctl->memc_or2, CONFIG_SYS_OR2_8COL); - out_be32(&memctl->memc_br2, CONFIG_SYS_BR2_8COL); - out_be32(&memctl->memc_or3, CONFIG_SYS_OR3_8COL); - out_be32(&memctl->memc_br3, CONFIG_SYS_BR3_8COL); - } - return (size); -} - -/* ----------------------------------------------------------------------- */ - - -int misc_init_r(void) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - -#ifdef CONFIG_IDE_LED - /* Configure PA8 as output port */ - setbits_be16(&immap->im_ioport.iop_padir, PA_8); - setbits_be16(&immap->im_ioport.iop_paodr, PA_8); - clrbits_be16(&immap->im_ioport.iop_papar, PA_8); - setbits_be16(&immap->im_ioport.iop_padat, PA_8); /* turn it off */ -#endif - load_sernum_ethaddr(); - setenv("hw","4k"); - poweron_key(); - return (0); -} - - -static int read_diag(void) -{ - int diag; - immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; - - clrbits_be16(&immr->im_ioport.iop_pcdir, PC_4); /* input */ - clrbits_be16(&immr->im_ioport.iop_pcpar, PC_4); /* gpio */ - setbits_be16(&immr->im_ioport.iop_pcdir, PC_5); /* output */ - clrbits_be16(&immr->im_ioport.iop_pcpar, PC_4); /* gpio */ - setbits_be16(&immr->im_ioport.iop_pcdat, PC_5); /* 1 */ - udelay(500); - if (in_be16(&immr->im_ioport.iop_pcdat) & PC_4) { - clrbits_be16(&immr->im_ioport.iop_pcdat, PC_5);/* 0 */ - udelay(500); - if(in_be16(&immr->im_ioport.iop_pcdat) & PC_4) - diag = 0; - else - diag = 1; - } else { - diag = 0; - } - clrbits_be16(&immr->im_ioport.iop_pcdir, PC_5); /* input */ - return (diag); -} - -static unsigned char swapbyte(unsigned char c) -{ - unsigned char result = 0; - int i = 0; - - for(i = 0; i < 8; ++i) { - result = result << 1; - result |= (c & 1); - c = c >> 1; - } - return result; -} - -/* - * Device Tree Support - */ -#if defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) -int ft_board_setup(void *blob, bd_t *bd) -{ - ft_cpu_setup(blob, bd); - - return 0; -} -#endif /* defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) */ diff --git a/board/kup/kup4k/u-boot.lds.debug b/board/kup/kup4k/u-boot.lds.debug deleted file mode 100644 index 0ea27e8..0000000 --- a/board/kup/kup4k/u-boot.lds.debug +++ /dev/null @@ -1,121 +0,0 @@ -/* - * (C) Copyright 2000-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -OUTPUT_ARCH(powerpc) -/* Do we need any of these for elf? - __DYNAMIC = 0; */ -SECTIONS -{ - /* Read-only sections, merged into text segment: */ - . = + SIZEOF_HEADERS; - .interp : { *(.interp) } - .hash : { *(.hash) } - .dynsym : { *(.dynsym) } - .dynstr : { *(.dynstr) } - .rel.text : { *(.rel.text) } - .rela.text : { *(.rela.text) } - .rel.data : { *(.rel.data) } - .rela.data : { *(.rela.data) } - .rel.rodata : { *(.rel.rodata) } - .rela.rodata : { *(.rela.rodata) } - .rel.got : { *(.rel.got) } - .rela.got : { *(.rela.got) } - .rel.ctors : { *(.rel.ctors) } - .rela.ctors : { *(.rela.ctors) } - .rel.dtors : { *(.rel.dtors) } - .rela.dtors : { *(.rela.dtors) } - .rel.bss : { *(.rel.bss) } - .rela.bss : { *(.rela.bss) } - .rel.plt : { *(.rel.plt) } - .rela.plt : { *(.rela.plt) } - .init : { *(.init) } - .plt : { *(.plt) } - .text : - { - /* WARNING - the following is hand-optimized to fit within */ - /* the sector layout of our flash chips! XXX FIXME XXX */ - - arch/powerpc/cpu/mpc8xx/start.o (.text) - common/dlmalloc.o (.text) - lib/vsprintf.o (.text) - lib/crc32.o (.text) - - . = env_offset; - common/env_embedded.o(.text) - - *(.text) - *(.got1) - } - _etext = .; - PROVIDE (etext = .); - .rodata : - { - *(.rodata) - *(.rodata1) - *(.rodata.str1.4) - *(.eh_frame) - } - .fini : { *(.fini) } =0 - .ctors : { *(.ctors) } - .dtors : { *(.dtors) } - - /* Read-write section, merged into data segment: */ - . = (. + 0x0FFF) & 0xFFFFF000; - _erotext = .; - PROVIDE (erotext = .); - .reloc : - { - *(.got) - _GOT2_TABLE_ = .; - *(.got2) - _FIXUP_TABLE_ = .; - *(.fixup) - } - __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; - __fixup_entries = (. - _FIXUP_TABLE_)>>2; - - .data : - { - *(.data) - *(.data1) - *(.sdata) - *(.sdata2) - *(.dynamic) - CONSTRUCTORS - } - _edata = .; - PROVIDE (edata = .); - - - . = ALIGN(4); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); - } - - - __start___ex_table = .; - __ex_table : { *(__ex_table) } - __stop___ex_table = .; - - . = ALIGN(4096); - __init_begin = .; - .text.init : { *(.text.init) } - .data.init : { *(.data.init) } - . = ALIGN(4096); - __init_end = .; - - __bss_start = .; - .bss : - { - *(.sbss) *(.scommon) - *(.dynbss) - *(.bss) - *(COMMON) - } - __bss_end = . ; - PROVIDE (end = .); -} diff --git a/board/kup/kup4x/Kconfig b/board/kup/kup4x/Kconfig deleted file mode 100644 index eeb5d83..0000000 --- a/board/kup/kup4x/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_KUP4X - -config SYS_BOARD - default "kup4x" - -config SYS_VENDOR - default "kup" - -config SYS_CONFIG_NAME - default "KUP4X" - -endif diff --git a/board/kup/kup4x/MAINTAINERS b/board/kup/kup4x/MAINTAINERS deleted file mode 100644 index 85159e4..0000000 --- a/board/kup/kup4x/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -KUP4X BOARD -M: Klaus Heydeck heydeck@kieback-peter.de -S: Maintained -F: board/kup/kup4x/ -F: include/configs/KUP4X.h -F: configs/KUP4X_defconfig diff --git a/board/kup/kup4x/Makefile b/board/kup/kup4x/Makefile deleted file mode 100644 index 6945943..0000000 --- a/board/kup/kup4x/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = kup4x.o ../common/flash.o ../common/kup.o ../common/load_sernum_ethaddr.o ../common/pcmcia.o diff --git a/board/kup/kup4x/kup4x.c b/board/kup/kup4x/kup4x.c deleted file mode 100644 index 0e51bd1..0000000 --- a/board/kup/kup4x/kup4x.c +++ /dev/null @@ -1,185 +0,0 @@ -/* - * (C) Copyright 2000-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * Klaus Heydeck, Kieback & Peter GmbH & Co KG, heydeck@kieback-peter.de - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc8xx.h> -#include <post.h> -#include "../common/kup.h" -#include <asm/io.h> - - -#define _NOT_USED_ 0xFFFFFFFF - -const uint sdram_table[] = { - /* - * Single Read. (Offset 0 in UPMA RAM) - */ - 0x1F07FC04, 0xEEAEFC04, 0x11ADFC04, 0xEFBBBC00, - 0x1FF77C47, /* last */ - - /* - * SDRAM Initialization (offset 5 in UPMA RAM) - * - * This is no UPM entry point. The following definition uses - * the remaining space to establish an initialization - * sequence, which is executed by a RUN command. - * - */ - 0x1FF77C35, 0xEFEABC34, 0x1FB57C35, /* last */ - - /* - * Burst Read. (Offset 8 in UPMA RAM) - */ - 0x1F07FC04, 0xEEAEFC04, 0x10ADFC04, 0xF0AFFC00, - 0xF0AFFC00, 0xF1AFFC00, 0xEFBBBC00, 0x1FF77C47, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - - /* - * Single Write. (Offset 18 in UPMA RAM) - */ - 0x1F27FC04, 0xEEAEBC00, 0x01B93C04, 0x1FF77C47, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - - /* - * Burst Write. (Offset 20 in UPMA RAM) - */ - 0x1F07FC04, 0xEEAEBC00, 0x10AD7C00, 0xF0AFFC00, - 0xF0AFFC00, 0xE1BBBC04, 0x1FF77C47, /* last */ - _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - - /* - * Refresh (Offset 30 in UPMA RAM) - */ - 0x1FF5FC84, 0xFFFFFC04, 0xFFFFFC04, 0xFFFFFC04, - 0xFFFFFC84, 0xFFFFFC07, /* last */ - _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - - /* - * Exception. (Offset 3c in UPMA RAM) - */ - 0x7FFFFC07, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, -}; - - -/* - * Check Board Identity: - */ - -int checkboard(void) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - uchar latch, rev, mod; - - /* - * Init ChipSelect #4 (CAN + HW-Latch) - */ - out_be32(&memctl->memc_or4, 0xFFFF8926); - out_be32(&memctl->memc_br4, 0x90000401); - - latch = in_8( (unsigned char *) LATCH_ADDR); - rev = (latch & 0xF8) >> 3; - mod = (latch & 0x03); - - printf("Board: KUP4X Rev %d.%d\n", rev, mod); - - return 0; -} - - -phys_size_t initdram(int board_type) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - - upmconfig(UPMA, (uint *) sdram_table, - sizeof (sdram_table) / sizeof (uint)); - - out_be16(&memctl->memc_mptpr, CONFIG_SYS_MPTPR); - - out_be32(&memctl->memc_mar, 0x00000088); - - out_be32(&memctl->memc_mamr, - CONFIG_SYS_MAMR & (~(MAMR_PTAE))); /* no refresh yet */ - - udelay(200); - - /* perform SDRAM initializsation sequence */ - - /* SDRAM bank 0 */ - out_be32(&memctl->memc_mcr, 0x80002105); - udelay(1); - out_be32(&memctl->memc_mcr, 0x80002830); /* execute twice */ - udelay(1); - out_be32(&memctl->memc_mcr, 0x80002106); /* RUN MRS Pattern from loc 6 */ - udelay(1); - - /* SDRAM bank 1 */ - out_be32(&memctl->memc_mcr, 0x80004105); - udelay(1); - out_be32(&memctl->memc_mcr, 0x80004830); /* execute twice */ - udelay(1); - out_be32(&memctl->memc_mcr, 0x80004106); /* RUN MRS Pattern from loc 6 */ - udelay(1); - - /* SDRAM bank 2 */ - out_be32(&memctl->memc_mcr, 0x80006105); - udelay(1); - out_be32(&memctl->memc_mcr, 0x80006830); /* execute twice */ - udelay(1); - out_be32(&memctl->memc_mcr, 0x80006106); /* RUN MRS Pattern from loc 6 */ - udelay(1); - - /* SDRAM bank 3 */ - out_be32(&memctl->memc_mcr, 0x8000C105); - udelay(1); - out_be32(&memctl->memc_mcr, 0x8000C830); /* execute twice */ - udelay(1); - out_be32(&memctl->memc_mcr, 0x8000C106); /* RUN MRS Pattern from loc 6 */ - udelay(1); - - setbits_be32(&memctl->memc_mamr, MAMR_PTAE); /* enable refresh */ - - udelay(1000); - /* 4 x 16 MB */ - out_be16(&memctl->memc_mptpr, CONFIG_SYS_MPTPR); - udelay(1000); - out_be32(&memctl->memc_or1, 0xFF000A00); - out_be32(&memctl->memc_br1, 0x00000081); - out_be32(&memctl->memc_or2, 0xFE000A00); - out_be32(&memctl->memc_br2, 0x01000081); - out_be32(&memctl->memc_or3, 0xFD000A00); - out_be32(&memctl->memc_br3, 0x02000081); - out_be32(&memctl->memc_or6, 0xFC000A00); - out_be32(&memctl->memc_br6, 0x03000081); - udelay(10000); - - return (4 * 16 * 1024 * 1024); -} - -int misc_init_r(void) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - -#ifdef CONFIG_IDE_LED - /* Configure PA8 as output port */ - setbits_be16(&immap->im_ioport.iop_padir, PA_8); - setbits_be16(&immap->im_ioport.iop_paodr, PA_8); - clrbits_be16(&immap->im_ioport.iop_papar, PA_8); - setbits_be16(&immap->im_ioport.iop_padat, PA_8); /* turn it off */ -#endif - load_sernum_ethaddr(); - setenv("hw", "4x"); - poweron_key(); - return 0; -} diff --git a/board/kup/kup4x/u-boot.lds b/board/kup/kup4x/u-boot.lds deleted file mode 100644 index 0eb2fba..0000000 --- a/board/kup/kup4x/u-boot.lds +++ /dev/null @@ -1,82 +0,0 @@ -/* - * (C) Copyright 2000-2010 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -OUTPUT_ARCH(powerpc) - -SECTIONS -{ - /* Read-only sections, merged into text segment: */ - . = + SIZEOF_HEADERS; - .text : - { - arch/powerpc/cpu/mpc8xx/start.o (.text*) - arch/powerpc/cpu/mpc8xx/traps.o (.text*) - - *(.text*) - } - _etext = .; - PROVIDE (etext = .); - .rodata : - { - *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) - } - - /* Read-write section, merged into data segment: */ - . = (. + 0x00FF) & 0xFFFFFF00; - _erotext = .; - PROVIDE (erotext = .); - .reloc : - { - _GOT2_TABLE_ = .; - KEEP(*(.got2)) - KEEP(*(.got)) - PROVIDE(_GLOBAL_OFFSET_TABLE_ = . + 4); - _FIXUP_TABLE_ = .; - KEEP(*(.fixup)) - } - __got2_entries = ((_GLOBAL_OFFSET_TABLE_ - _GOT2_TABLE_) >> 2) - 1; - __fixup_entries = (. - _FIXUP_TABLE_)>>2; - - .data : - { - *(.data*) - *(.sdata*) - } - _edata = .; - PROVIDE (edata = .); - - . = .; - - . = ALIGN(4); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); - } - - - . = .; - __start___ex_table = .; - __ex_table : { *(__ex_table) } - __stop___ex_table = .; - - . = ALIGN(256); - __init_begin = .; - .text.init : { *(.text.init) } - .data.init : { *(.data.init) } - . = ALIGN(256); - __init_end = .; - - __bss_start = .; - .bss (NOLOAD) : - { - *(.bss*) - *(.sbss*) - *(COMMON) - . = ALIGN(4); - } - __bss_end = . ; - PROVIDE (end = .); -} diff --git a/board/kup/kup4x/u-boot.lds.debug b/board/kup/kup4x/u-boot.lds.debug deleted file mode 100644 index 0ea27e8..0000000 --- a/board/kup/kup4x/u-boot.lds.debug +++ /dev/null @@ -1,121 +0,0 @@ -/* - * (C) Copyright 2000-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -OUTPUT_ARCH(powerpc) -/* Do we need any of these for elf? - __DYNAMIC = 0; */ -SECTIONS -{ - /* Read-only sections, merged into text segment: */ - . = + SIZEOF_HEADERS; - .interp : { *(.interp) } - .hash : { *(.hash) } - .dynsym : { *(.dynsym) } - .dynstr : { *(.dynstr) } - .rel.text : { *(.rel.text) } - .rela.text : { *(.rela.text) } - .rel.data : { *(.rel.data) } - .rela.data : { *(.rela.data) } - .rel.rodata : { *(.rel.rodata) } - .rela.rodata : { *(.rela.rodata) } - .rel.got : { *(.rel.got) } - .rela.got : { *(.rela.got) } - .rel.ctors : { *(.rel.ctors) } - .rela.ctors : { *(.rela.ctors) } - .rel.dtors : { *(.rel.dtors) } - .rela.dtors : { *(.rela.dtors) } - .rel.bss : { *(.rel.bss) } - .rela.bss : { *(.rela.bss) } - .rel.plt : { *(.rel.plt) } - .rela.plt : { *(.rela.plt) } - .init : { *(.init) } - .plt : { *(.plt) } - .text : - { - /* WARNING - the following is hand-optimized to fit within */ - /* the sector layout of our flash chips! XXX FIXME XXX */ - - arch/powerpc/cpu/mpc8xx/start.o (.text) - common/dlmalloc.o (.text) - lib/vsprintf.o (.text) - lib/crc32.o (.text) - - . = env_offset; - common/env_embedded.o(.text) - - *(.text) - *(.got1) - } - _etext = .; - PROVIDE (etext = .); - .rodata : - { - *(.rodata) - *(.rodata1) - *(.rodata.str1.4) - *(.eh_frame) - } - .fini : { *(.fini) } =0 - .ctors : { *(.ctors) } - .dtors : { *(.dtors) } - - /* Read-write section, merged into data segment: */ - . = (. + 0x0FFF) & 0xFFFFF000; - _erotext = .; - PROVIDE (erotext = .); - .reloc : - { - *(.got) - _GOT2_TABLE_ = .; - *(.got2) - _FIXUP_TABLE_ = .; - *(.fixup) - } - __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; - __fixup_entries = (. - _FIXUP_TABLE_)>>2; - - .data : - { - *(.data) - *(.data1) - *(.sdata) - *(.sdata2) - *(.dynamic) - CONSTRUCTORS - } - _edata = .; - PROVIDE (edata = .); - - - . = ALIGN(4); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); - } - - - __start___ex_table = .; - __ex_table : { *(__ex_table) } - __stop___ex_table = .; - - . = ALIGN(4096); - __init_begin = .; - .text.init : { *(.text.init) } - .data.init : { *(.data.init) } - . = ALIGN(4096); - __init_end = .; - - __bss_start = .; - .bss : - { - *(.sbss) *(.scommon) - *(.dynbss) - *(.bss) - *(COMMON) - } - __bss_end = . ; - PROVIDE (end = .); -} diff --git a/configs/KUP4K_defconfig b/configs/KUP4K_defconfig deleted file mode 100644 index 8e9e26d..0000000 --- a/configs/KUP4K_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_KUP4K=y diff --git a/configs/KUP4X_defconfig b/configs/KUP4X_defconfig deleted file mode 100644 index 29520c9..0000000 --- a/configs/KUP4X_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_KUP4X=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 426cadc..3a27d4c 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,8 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +KUP4K powerpc mpc8xx - - Klaus Heydeck heydeck@kieback-peter.de +KUP4X powerpc mpc8xx - - Klaus Heydeck heydeck@kieback-peter.de ELPT860 powerpc mpc8xx - - The LEOX team team@leox.org hmi1001 powerpc mpc5xxx - - mucmc52 powerpc mpc5xxx - - Heiko Schocher hs@denx.de diff --git a/include/commproc.h b/include/commproc.h index af67878..311745e 100644 --- a/include/commproc.h +++ b/include/commproc.h @@ -543,36 +543,6 @@ typedef struct scc_enet {
#endif /* CONFIG_IVMS8, CONFIG_IVML24 */
-/*** KUP4K, KUP4X ****************************************************/ -/* The KUP4 boards uses the FEC on a MPC8xx for Ethernet */ - -#if defined(CONFIG_KUP4K) || defined(CONFIG_KUP4X) - -#define FEC_ENET /* use FEC for EThernet */ -#undef SCC_ENET - -#define PB_ENET_POWER ((uint)0x00010000) /* PB 15 */ - -#define PC_ENET_RESET ((ushort)0x0010) /* PC 11 */ - -#define PD_MII_TXD1 ((ushort)0x1000) /* PD 3 */ -#define PD_MII_TXD2 ((ushort)0x0800) /* PD 4 */ -#define PD_MII_TXD3 ((ushort)0x0400) /* PD 5 */ -#define PD_MII_RX_DV ((ushort)0x0200) /* PD 6 */ -#define PD_MII_RX_ERR ((ushort)0x0100) /* PD 7 */ -#define PD_MII_RX_CLK ((ushort)0x0080) /* PD 8 */ -#define PD_MII_TXD0 ((ushort)0x0040) /* PD 9 */ -#define PD_MII_RXD0 ((ushort)0x0020) /* PD 10 */ -#define PD_MII_TX_ERR ((ushort)0x0010) /* PD 11 */ -#define PD_MII_MDC ((ushort)0x0008) /* PD 12 */ -#define PD_MII_RXD1 ((ushort)0x0004) /* PD 13 */ -#define PD_MII_RXD2 ((ushort)0x0002) /* PD 14 */ -#define PD_MII_RXD3 ((ushort)0x0001) /* PD 15 */ - -#define PD_MII_MASK ((ushort)0x1FFF) /* PD 3...15 */ - -#endif /* CONFIG_KUP4K */ - /*** LWMON **********************************************************/
#if defined(CONFIG_LWMON) diff --git a/include/configs/KUP4K.h b/include/configs/KUP4K.h deleted file mode 100644 index 7cf09d0..0000000 --- a/include/configs/KUP4K.h +++ /dev/null @@ -1,488 +0,0 @@ -/* - * (C) Copyright 2000-2010 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * Klaus Heydeck, Kieback & Peter GmbH & Co KG, heydeck@kieback-peter.de - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - * Derived from ../tqm8xx/tqm8xx.c - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC855 1 /* This is a MPC855 CPU */ -#define CONFIG_KUP4K 1 /* ...on a KUP4K module */ - -#define CONFIG_SYS_TEXT_BASE 0x40000000 - -#define CONFIG_8xx_CONS_SMC1 1 /* Console is on SMC1 */ -#undef CONFIG_8xx_CONS_SMC2 -#undef CONFIG_8xx_CONS_NONE -#define CONFIG_BAUDRATE 115200 /* console baudrate */ -#define CONFIG_BOOTDELAY 1 /* autoboot after 1 second */ - -#define CONFIG_BOARD_TYPES 1 /* support board types */ - -#undef CONFIG_BOOTARGS - -#define CONFIG_EXTRA_ENV_SETTINGS \ -"slot_a_boot=setenv bootargs root=/dev/sda2 ip=off;" \ - "run addhw; mw.b 400000 00 80; diskboot 400000 0:1; bootm 400000\0" \ -"slot_b_boot=setenv bootargs root=/dev/sda2 ip=off;" \ - "run addhw; mw.b 400000 00 80; diskboot 400000 2:1; bootm 400000\0" \ -"nfs_boot=mw.b 400000 00 80; dhcp; run nfsargs addip addhw; bootm 400000\0" \ -"fat_boot=mw.b 400000 00 80; fatload ide 2:1 400000 st.bin; run addhw; \ - bootm 400000 \0" \ -"panic_boot=echo No Bootdevice !!! reset\0" \ -"nfsargs=setenv bootargs root=/dev/nfs rw nfsroot=${rootpath}\0" \ -"ramargs=setenv bootargs root=/dev/ram rw\0" \ -"addip=setenv bootargs ${bootargs} ip=${ipaddr}::${gatewayip}" \ - ":${netmask}:${hostname}:${netdev}:off\0" \ -"addhw=setenv bootargs ${bootargs} ${mtdparts} console=${console} ${debug} \ - hw=${hw} key1=${key1} panic=1 mem=${mem}\0" \ -"console=ttyCPM0,115200\0" \ -"netdev=eth0\0" \ -"contrast=20\0" \ -"silent=1\0" \ -"mtdparts=" MTDPARTS_DEFAULT "\0" \ -"load=tftp 200000 bootloader-4k.bitmap;tftp 100000 bootloader-4k.bin\0" \ -"update=protect off 1:0-9;era 1:0-9;cp.b 100000 40000000 ${filesize};" \ - "cp.b 200000 40050000 14000\0" - -#define CONFIG_BOOTCOMMAND \ - "run fat_boot;run slot_b_boot;run slot_a_boot;run nfs_boot;run panic_boot" - -#define CONFIG_PREBOOT "setenv preboot; saveenv" - -#define CONFIG_MISC_INIT_R 1 -#define CONFIG_MISC_INIT_F 1 - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ - -#define CONFIG_WATCHDOG 1 /* watchdog enabled */ - -#define CONFIG_STATUS_LED 1 /* Status LED enabled */ - -#undef CONFIG_CAN_DRIVER /* CAN Driver support disabled */ - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE - -#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - -/* - * enable I2C and select the hardware/software driver - */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_SOFT /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SOFT_SPEED 93000 /* 93 kHz is supposed to work */ -#define CONFIG_SYS_I2C_SOFT_SLAVE 0xFE - -/* - * Software (bit-bang) I2C driver configuration - */ -#define PB_SCL 0x00000020 /* PB 26 */ -#define PB_SDA 0x00000010 /* PB 27 */ - -#define I2C_INIT (immr->im_cpm.cp_pbdir |= PB_SCL) -#define I2C_ACTIVE (immr->im_cpm.cp_pbdir |= PB_SDA) -#define I2C_TRISTATE (immr->im_cpm.cp_pbdir &= ~PB_SDA) -#define I2C_READ ((immr->im_cpm.cp_pbdat & PB_SDA) != 0) -#define I2C_SDA(bit) if(bit) immr->im_cpm.cp_pbdat |= PB_SDA; \ - else immr->im_cpm.cp_pbdat &= ~PB_SDA -#define I2C_SCL(bit) if(bit) immr->im_cpm.cp_pbdat |= PB_SCL; \ - else immr->im_cpm.cp_pbdat &= ~PB_SCL -#define I2C_DELAY udelay(2) /* 1/4 I2C clock duration */ - -/*----------------------------------------------------------------------- - * I2C Configuration - */ - -#define CONFIG_SYS_I2C_PICIO_ADDR 0x21 /* PCF8574 IO Expander */ -#define CONFIG_SYS_I2C_RTC_ADDR 0x51 /* PCF8563 RTC */ - -/* List of I2C addresses to be verified by POST */ - -#define CONFIG_SYS_POST_I2C_ADDRS {CONFIG_SYS_I2C_PICIO_ADDR, \ - CONFIG_SYS_I2C_RTC_ADDR, \ - } - -#define CONFIG_RTC_PCF8563 /* use Philips PCF8563 RTC */ - -#define CONFIG_SYS_DISCOVER_PHY -#define CONFIG_MII - -/* Define to allow the user to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_I2C -#define CONFIG_CMD_IDE -#define CONFIG_CMD_MII -#define CONFIG_CMD_NFS -#define CONFIG_CMD_FAT -#define CONFIG_CMD_SNTP - -#ifdef CONFIG_POST - #define CONFIG_CMD_DIAG -#endif - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ -#endif -/* Print Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x000400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x005C00000 /* 4 ... 92 MB in DRAM */ -#define CONFIG_SYS_ALT_MEMTEST 1 -#define CONFIG_SYS_MEMTEST_SCRATCH 0x90000200 /* using latch as scratch register */ - -#define CONFIG_SYS_LOAD_ADDR 0x400000 /* default load address */ - -#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 115200 } - -#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xFFF00000 - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0x40000000 -#define CONFIG_SYS_MONITOR_LEN (192 << 10) /* Reserve 192 kB for Monitor */ -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 19 /* max number of sectors on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ - -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_OFFSET 0x40000 /* Offset of Environment Sector */ -#define CONFIG_ENV_SIZE 0x1000 /* Total Size of Environment Sector */ -#define CONFIG_ENV_SECT_SIZE 0x10000 - -/*----------------------------------------------------------------------- - * Dynamic MTD partition support - */ -#define MTDPARTS_DEFAULT "mtdparts=40000000.flash:256k(u-boot)," \ - "64k(env)," \ - "128k(splash)," \ - "512k(etc)," \ - "64k(hw-info)" - -/*----------------------------------------------------------------------- - * Hardware Information Block - */ -#define CONFIG_SYS_HWINFO_OFFSET 0x000F0000 /* offset of HW Info block */ -#define CONFIG_SYS_HWINFO_SIZE 0x00000100 /* size of HW Info block */ -#define CONFIG_SYS_HWINFO_MAGIC 0x4B26500D /* 'K&P<CR>' */ - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CACHELINE_SHIFT 4 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 11-9 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Software & Bus Monitor Timer max, Bus Monitor enable, SW Watchdog freeze - */ -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | SYPCR_SWP) - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 11-6 - *----------------------------------------------------------------------- - * PCMCIA config., multi-function pin tri-state - */ -#define CONFIG_SYS_SIUMCR (SIUMCR_DBGC00 | SIUMCR_DBPC00 | SIUMCR_MLRC00) - -/*----------------------------------------------------------------------- - * TBSCR - Time Base Status and Control 11-26 - *----------------------------------------------------------------------- - * Clear Reference Interrupt Status, Timebase freezing enabled - */ -#define CONFIG_SYS_TBSCR (TBSCR_REFA | TBSCR_REFB | TBSCR_TBF) - -/*----------------------------------------------------------------------- - * RTCSC - Real-Time Clock Status and Control Register 11-27 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RTCSC (RTCSC_SEC | RTCSC_ALR | RTCSC_RTF| RTCSC_RTE) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 11-31 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Interrupt Timer freezing enabled - */ -#define CONFIG_SYS_PISCR (PISCR_PS | PISCR_PITF) - -/*----------------------------------------------------------------------- - * PLPRCR - PLL, Low-Power, and Reset Control Register 15-30 - *----------------------------------------------------------------------- - * Reset PLL lock status sticky bit, timer expired status bit and timer - * interrupt status bit - * - * If this is a 80 MHz CPU, set PLL multiplication factor to 5 (5*16=80)! - */ -#define CONFIG_SYS_PLPRCR ( (5-1)<<PLPRCR_MF_SHIFT | PLPRCR_TEXPS | PLPRCR_TMIST ) - -/*----------------------------------------------------------------------- - * SCCR - System Clock and reset Control Register 15-27 - *----------------------------------------------------------------------- - * Set clock output, timebase and RTC source and divider, - * power management and some other internal clocks - */ -#define SCCR_MASK SCCR_EBDF00 -#define CONFIG_SYS_SCCR (SCCR_TBS | SCCR_EBDF01 | \ - SCCR_COM00 | SCCR_DFSYNC00 | SCCR_DFBRG00 | \ - SCCR_DFNL000 | SCCR_DFNH000 | SCCR_DFLCD000 | \ - SCCR_DFALCD00) - -/*----------------------------------------------------------------------- - * PCMCIA stuff - *----------------------------------------------------------------------- - * - */ - -/* KUP4K use both slots, SLOT_A as "primary". */ -#define CONFIG_PCMCIA_SLOT_A 1 - -#define CONFIG_SYS_PCMCIA_MEM_ADDR (0xE0000000) -#define CONFIG_SYS_PCMCIA_MEM_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_DMA_ADDR (0xE4000000) -#define CONFIG_SYS_PCMCIA_DMA_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_ATTRB_ADDR (0xE8000000) -#define CONFIG_SYS_PCMCIA_ATTRB_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_IO_ADDR (0xEC000000) -#define CONFIG_SYS_PCMCIA_IO_SIZE ( 64 << 20 ) - -#define PCMCIA_SOCKETS_NO 2 -#define PCMCIA_MEM_WIN_NO 8 -/*----------------------------------------------------------------------- - * IDE/ATA stuff (Supports IDE harddisk on PCMCIA Adapter) - *----------------------------------------------------------------------- - */ - -#define CONFIG_IDE_PREINIT 1 /* Use preinit IDE hook */ -#define CONFIG_IDE_8xx_PCCARD 1 /* Use IDE with PC Card Adapter */ - -#undef CONFIG_IDE_8xx_DIRECT /* Direct IDE not supported */ -#define CONFIG_IDE_LED 1 /* LED for ide supported */ -#undef CONFIG_IDE_RESET /* reset for ide not supported */ - -#define CONFIG_SYS_IDE_MAXBUS 2 -#define CONFIG_SYS_IDE_MAXDEVICE 4 - -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 - -#define CONFIG_SYS_ATA_IDE1_OFFSET (4 * CONFIG_SYS_PCMCIA_MEM_SIZE) - -#define CONFIG_SYS_ATA_BASE_ADDR CONFIG_SYS_PCMCIA_MEM_ADDR - -/* Offset for data I/O */ -#define CONFIG_SYS_ATA_DATA_OFFSET (CONFIG_SYS_PCMCIA_MEM_SIZE + 0x320) - -/* Offset for normal register accesses */ -#define CONFIG_SYS_ATA_REG_OFFSET (2 * CONFIG_SYS_PCMCIA_MEM_SIZE + 0x320) - -/* Offset for alternate registers */ -#define CONFIG_SYS_ATA_ALT_OFFSET 0x0100 - -/*----------------------------------------------------------------------- - * - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_DER 0 - -/* - * Init Memory Controller: - * - * BR0/1 and OR0/1 (FLASH) - */ -#define FLASH_BASE0_PRELIM 0x40000000 /* FLASH bank #0 */ - -/* used to re-map FLASH both when starting from SRAM or FLASH: - * restrict access enough to keep SRAM working (if any) - * but not too much to meddle with FLASH accesses - */ -#define CONFIG_SYS_REMAP_OR_AM 0x80000000 /* OR addr mask */ -#define CONFIG_SYS_PRELIM_OR_AM 0xE0000000 /* OR addr mask */ - -/* - * FLASH timing: - */ -#define CONFIG_SYS_OR_TIMING_FLASH (OR_ACS_DIV2 | OR_CSNT_SAM | \ - OR_SCY_5_CLK | OR_EHTR | OR_BI) - -#define CONFIG_SYS_OR0_REMAP \ - (CONFIG_SYS_REMAP_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_OR0_PRELIM \ - (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_BR0_PRELIM \ - ((FLASH_BASE0_PRELIM & BR_BA_MSK) | BR_PS_16 | BR_V ) - - -/* SDRAM timing: Multiplexed addresses, GPL5 output to GPL5_A (don't care) */ -#define CONFIG_SYS_OR_TIMING_SDRAM 0x00000A00 - -/* - * Memory Periodic Timer Prescaler - * - * The Divider for PTA (refresh timer) configuration is based on an - * example SDRAM configuration (64 MBit, one bank). The adjustment to - * the number of chip selects (NCS) and the actually needed refresh - * rate is done by setting MPTPR. - * - * PTA is calculated from - * PTA = (gclk * Trefresh) / ((2 ^ (2 * DFBRG)) * PTP * NCS) - * - * gclk CPU clock (not bus clock!) - * Trefresh Refresh cycle * 4 (four word bursts used) - * - * 4096 Rows from SDRAM example configuration - * 1000 factor s -> ms - * 32 PTP (pre-divider from MPTPR) from SDRAM example configuration - * 4 Number of refresh cycles per period - * 64 Refresh cycle in ms per number of rows - * -------------------------------------------- - * Divider = 4096 * 32 * 1000 / (4 * 64) = 512000 - * - * 50 MHz => 50.000.000 / Divider = 98 - * 66 Mhz => 66.000.000 / Divider = 129 - * 80 Mhz => 80.000.000 / Divider = 156 - */ -#if defined(CONFIG_80MHz) -#define CONFIG_SYS_MAMR_PTA 156 -#elif defined(CONFIG_66MHz) -#define CONFIG_SYS_MAMR_PTA 129 -#else /* 50 MHz */ -#define CONFIG_SYS_MAMR_PTA 98 -#endif /*CONFIG_??MHz */ - -/* - * For 16 MBit, refresh rates could be 31.3 us - * (= 64 ms / 2K = 125 / quad bursts). - * For a simpler initialization, 15.6 us is used instead. - * - * #define CONFIG_SYS_MPTPR_2BK_2K MPTPR_PTP_DIV32 for 2 banks - * #define CONFIG_SYS_MPTPR_1BK_2K MPTPR_PTP_DIV64 for 1 bank - */ -#define CONFIG_SYS_MPTPR 0x400 - -/* - * MAMR settings for SDRAM - */ - -/* 8 column SDRAM */ -#define CONFIG_SYS_MAMR_8COL 0x68802114 -/* 9 column SDRAM */ -#define CONFIG_SYS_MAMR_9COL 0x68904114 - -/* - * Chip Selects - */ -#define CONFIG_SYS_OR0 -#define CONFIG_SYS_BR0 - -#define CONFIG_SYS_OR1_8COL 0xFF000A00 -#define CONFIG_SYS_BR1_8COL 0x00000081 -#define CONFIG_SYS_OR2_8COL 0xFE000A00 -#define CONFIG_SYS_BR2_8COL 0x01000081 -#define CONFIG_SYS_OR3_8COL 0xFC000A00 -#define CONFIG_SYS_BR3_8COL 0x02000081 - -#define CONFIG_SYS_OR1_9COL 0xFE000A00 -#define CONFIG_SYS_BR1_9COL 0x00000081 -#define CONFIG_SYS_OR2_9COL 0xFE000A00 -#define CONFIG_SYS_BR2_9COL 0x02000081 -#define CONFIG_SYS_OR3_9COL 0xFE000A00 -#define CONFIG_SYS_BR3_9COL 0x04000081 - -#define CONFIG_SYS_OR4 0xFFFF8926 -#define CONFIG_SYS_BR4 0x90000401 - -#define CONFIG_SYS_OR5 0xFFC007F0 /* EPSON: 4 MB 17 WS or externel TA */ -#define CONFIG_SYS_BR5 0x80080801 /* Start at 0x80080000 */ - -#define LATCH_ADDR 0x90000200 - -#define CONFIG_AUTOBOOT_KEYED /* use key strings to stop autoboot */ -#define CONFIG_AUTOBOOT_STOP_STR "." -#define CONFIG_SILENT_CONSOLE 1 -#define CONFIG_SYS_DEVICE_NULLDEV 1 /* enble null device */ -#define CONFIG_VERSION_VARIABLE 1 - -/* pass open firmware flat tree */ -#define CONFIG_OF_LIBFDT 1 -#define CONFIG_OF_BOARD_SETUP 1 - -#endif /* __CONFIG_H */ diff --git a/include/configs/KUP4X.h b/include/configs/KUP4X.h deleted file mode 100644 index 47d1623..0000000 --- a/include/configs/KUP4X.h +++ /dev/null @@ -1,440 +0,0 @@ -/* - * (C) Copyright 2000-2005 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * Klaus Heydeck, Kieback & Peter GmbH & Co KG, heydeck@kieback-peter.de - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - * Derived from ../tqm8xx/tqm8xx.c - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC859T 1 /* This is a MPC859T CPU */ -#define CONFIG_KUP4X 1 /* ...on a KUP4X module */ - -#define CONFIG_SYS_TEXT_BASE 0x40000000 - -#define CONFIG_8xx_CONS_SMC1 1 /* Console is on SMC1 */ -#undef CONFIG_8xx_CONS_SMC2 -#undef CONFIG_8xx_CONS_NONE -#define CONFIG_BAUDRATE 115200 /* console baudrate */ - -#define CONFIG_BOOTDELAY 1 /* autoboot after 1 second */ - -#define CONFIG_BOARD_TYPES 1 /* support board types */ - -#define CONFIG_SYS_8XX_FACT 8 /* Multiply by 8 */ -#define CONFIG_SYS_8XX_XIN 16000000 /* 16 MHz in */ - - -#define MPC8XX_HZ ((CONFIG_SYS_8XX_XIN) * (CONFIG_SYS_8XX_FACT)) - -/* should ALWAYS define this, measure_gclk in speed.c is unreliable */ -/* in general, we always know this for FADS+new ADS anyway */ -#define CONFIG_8xx_GCLK_FREQ MPC8XX_HZ - - -#undef CONFIG_BOOTARGS - - -#define CONFIG_EXTRA_ENV_SETTINGS \ -"slot_a_boot=setenv bootargs root=/dev/hda2 ip=off;" \ - "run addhw;diskboot 200000 0:1;bootm 200000\0" \ -"usb_boot=setenv bootargs root=/dev/sda2 ip=off; \ - run addhw; sleep 2; usb reset; usb scan; usbboot 200000 0:1; \ - usb stop; bootm 200000\0" \ -"nfs_boot=dhcp;run nfsargs addip addhw;bootm 200000\0" \ -"panic_boot=echo No Bootdevice !!! reset\0" \ -"nfsargs=setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath}\0" \ -"ramargs=setenv bootargs root=/dev/ram rw\0" \ -"addip=setenv bootargs ${bootargs} ip=${ipaddr}:${serverip}:${gatewayip}" \ - ":${netmask}:${hostname}:${netdev}:off\0" \ -"addhw=setenv bootargs ${bootargs} hw=${hw} key1=${key1} panic=1\0" \ -"netdev=eth0\0" \ -"silent=1\0" \ -"load=tftp 200000 bootloader-4x.bitmap;tftp 100000 bootloader-4x.bin\0" \ -"update=protect off 1:0-5;era 1:0-5;cp.b 100000 40000000 ${filesize};" \ - "cp.b 200000 40040000 14000\0" - -#define CONFIG_BOOTCOMMAND \ - "run usb_boot;run slot_a_boot;run nfs_boot;run panic_boot" - - -#define CONFIG_MISC_INIT_R 1 -#define CONFIG_MISC_INIT_F 1 - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ - -#define CONFIG_WATCHDOG 1 /* watchdog enabled */ - -#define CONFIG_STATUS_LED 1 /* Status LED enabled */ - -#undef CONFIG_CAN_DRIVER /* CAN Driver support disabled */ - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE - - -#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - -/* - * enable I2C and select the hardware/software driver - */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_SOFT /* I2C bit-banged */ - -#ifdef CONFIG_SYS_I2C_SOFT -#define CONFIG_SYS_I2C_SOFT_SPEED 93000 /* 93 kHz is supposed to work */ -#define CONFIG_SYS_I2C_SOFT_SLAVE 0xFE - -/* - * Software (bit-bang) I2C driver configuration - */ -#define PB_SCL 0x00000020 /* PB 26 */ -#define PB_SDA 0x00000010 /* PB 27 */ - -#define I2C_INIT (immr->im_cpm.cp_pbdir |= PB_SCL) -#define I2C_ACTIVE (immr->im_cpm.cp_pbdir |= PB_SDA) -#define I2C_TRISTATE (immr->im_cpm.cp_pbdir &= ~PB_SDA) -#define I2C_READ ((immr->im_cpm.cp_pbdat & PB_SDA) != 0) -#define I2C_SDA(bit) if(bit) immr->im_cpm.cp_pbdat |= PB_SDA; \ - else immr->im_cpm.cp_pbdat &= ~PB_SDA -#define I2C_SCL(bit) if(bit) immr->im_cpm.cp_pbdat |= PB_SCL; \ - else immr->im_cpm.cp_pbdat &= ~PB_SCL -#define I2C_DELAY udelay(2) /* 1/4 I2C clock duration */ -#endif /* CONFIG_SYS_I2C_SOFT */ - - -/*----------------------------------------------------------------------- - * I2C Configuration - */ - -#define CONFIG_SYS_I2C_PICIO_ADDR 0x21 /* PCF8574 IO Expander */ -#define CONFIG_SYS_I2C_RTC_ADDR 0x51 /* PCF8563 RTC */ - - -/* List of I2C addresses to be verified by POST */ - -#define CONFIG_SYS_POST_I2C_ADDRS {CONFIG_SYS_I2C_PICIO_ADDR, \ - CONFIG_SYS_I2C_RTC_ADDR, \ - } - - -#define CONFIG_RTC_PCF8563 /* use Philips PCF8563 RTC */ - -#define CONFIG_SYS_DISCOVER_PHY -#define CONFIG_MII - -#undef CONFIG_KUP4K_LOGO - -/* Define to allow the user to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE - - -/* POST support */ -#define CONFIG_POST (CONFIG_SYS_POST_CPU | \ - CONFIG_SYS_POST_RTC | \ - CONFIG_SYS_POST_I2C) - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_FAT -#define CONFIG_CMD_I2C -#define CONFIG_CMD_IDE -#define CONFIG_CMD_NFS -#define CONFIG_CMD_SNTP -#define CONFIG_CMD_USB - -#ifdef CONFIG_POST - #define CONFIG_CMD_DIAG -#endif - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x000400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x003C00000 /* 4 ... 60 MB in DRAM */ -#define CONFIG_SYS_LOAD_ADDR 0x200000 /* default load address */ - -#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 115200 } - -#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xFFF00000 - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0x40000000 -#define CONFIG_SYS_MONITOR_LEN (192 << 10) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 19 /* max number of sectors on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ - -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_OFFSET 0x40000 /* Offset of Environment Sector */ -#define CONFIG_ENV_SIZE 0x1000 /* Total Size of Environment Sector */ -#define CONFIG_ENV_SECT_SIZE 0x10000 - -/* Address and size of Redundant Environment Sector */ -#if 0 -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET+CONFIG_ENV_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) -#endif -/*----------------------------------------------------------------------- - * Hardware Information Block - */ -#if 1 -#define CONFIG_SYS_HWINFO_OFFSET 0x000F0000 /* offset of HW Info block */ -#define CONFIG_SYS_HWINFO_SIZE 0x00000100 /* size of HW Info block */ -#define CONFIG_SYS_HWINFO_MAGIC 0x4B26500D /* 'K&P<CR>' */ -#endif -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CACHELINE_SHIFT 4 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 11-9 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Software & Bus Monitor Timer max, Bus Monitor enable, SW Watchdog freeze - */ -#if 0 && defined(CONFIG_WATCHDOG) /* KUP uses external TPS3705 WD */ -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | \ - SYPCR_SWE | SYPCR_SWRI| SYPCR_SWP) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | SYPCR_SWP) -#endif - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 11-6 - *----------------------------------------------------------------------- - * PCMCIA config., multi-function pin tri-state - */ -#define CONFIG_SYS_SIUMCR (SIUMCR_DBGC00 | SIUMCR_DBPC00 | SIUMCR_MLRC00) - -/*----------------------------------------------------------------------- - * TBSCR - Time Base Status and Control 11-26 - *----------------------------------------------------------------------- - * Clear Reference Interrupt Status, Timebase freezing enabled - */ -#define CONFIG_SYS_TBSCR (TBSCR_REFA | TBSCR_REFB | TBSCR_TBF) - - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 11-31 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Interrupt Timer freezing enabled - */ -#define CONFIG_SYS_PISCR (PISCR_PS | PISCR_PITF) - - -/*----------------------------------------------------------------------- - * PLPRCR - PLL, Low-Power, and Reset Control Register 15-30 - *----------------------------------------------------------------------- - * set the PLL, the low-power modes and the reset control (15-29) - */ -#define CONFIG_SYS_PLPRCR ((CONFIG_SYS_8XX_FACT << PLPRCR_MFI_SHIFT) | \ - PLPRCR_SPLSS | PLPRCR_TEXPS) - - -/*----------------------------------------------------------------------- - * SCCR - System Clock and reset Control Register 15-27 - *----------------------------------------------------------------------- - * Set clock output, timebase and RTC source and divider, - * power management and some other internal clocks - */ -#define SCCR_MASK SCCR_EBDF00 -#define CONFIG_SYS_SCCR (SCCR_TBS | SCCR_EBDF01 | \ - SCCR_COM00 | SCCR_DFSYNC00 | SCCR_DFBRG00 | \ - SCCR_DFNL000 | SCCR_DFNH000 | SCCR_DFLCD000 | \ - SCCR_DFALCD00) - -/*----------------------------------------------------------------------- - * PCMCIA stuff - *----------------------------------------------------------------------- - * - */ - -/* KUP4K use both slots, SLOT_A as "primary". */ -#define CONFIG_PCMCIA_SLOT_A 1 - -#define CONFIG_SYS_PCMCIA_MEM_ADDR (0xE0000000) -#define CONFIG_SYS_PCMCIA_MEM_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_DMA_ADDR (0xE4000000) -#define CONFIG_SYS_PCMCIA_DMA_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_ATTRB_ADDR (0xE8000000) -#define CONFIG_SYS_PCMCIA_ATTRB_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_IO_ADDR (0xEC000000) -#define CONFIG_SYS_PCMCIA_IO_SIZE ( 64 << 20 ) - -#define PCMCIA_SOCKETS_NO 1 -#define PCMCIA_MEM_WIN_NO 8 -/*----------------------------------------------------------------------- - * IDE/ATA stuff (Supports IDE harddisk on PCMCIA Adapter) - *----------------------------------------------------------------------- - */ - -#define CONFIG_IDE_PREINIT 1 /* Use preinit IDE hook */ -#define CONFIG_IDE_8xx_PCCARD 1 /* Use IDE with PC Card Adapter */ - -#undef CONFIG_IDE_8xx_DIRECT /* Direct IDE not supported */ -#define CONFIG_IDE_LED 1 /* LED for ide supported */ -#undef CONFIG_IDE_RESET /* reset for ide not supported */ - -#define CONFIG_SYS_IDE_MAXBUS 1 -#define CONFIG_SYS_IDE_MAXDEVICE 2 - -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 - -#define CONFIG_SYS_ATA_IDE1_OFFSET (4 * CONFIG_SYS_PCMCIA_MEM_SIZE) - -#define CONFIG_SYS_ATA_BASE_ADDR CONFIG_SYS_PCMCIA_MEM_ADDR - -/* Offset for data I/O */ -#define CONFIG_SYS_ATA_DATA_OFFSET (CONFIG_SYS_PCMCIA_MEM_SIZE + 0x320) - -/* Offset for normal register accesses */ -#define CONFIG_SYS_ATA_REG_OFFSET (2 * CONFIG_SYS_PCMCIA_MEM_SIZE + 0x320) - -/* Offset for alternate registers */ -#define CONFIG_SYS_ATA_ALT_OFFSET 0x0100 - - -/*----------------------------------------------------------------------- - * - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_DER 0 - -/* - * Init Memory Controller: - * - * BR0/1 and OR0/1 (FLASH) - */ -#define FLASH_BASE0_PRELIM 0x40000000 /* FLASH bank #0 */ - -/* used to re-map FLASH both when starting from SRAM or FLASH: - * restrict access enough to keep SRAM working (if any) - * but not too much to meddle with FLASH accesses - */ -#define CONFIG_SYS_REMAP_OR_AM 0x80000000 /* OR addr mask */ -#define CONFIG_SYS_PRELIM_OR_AM 0xE0000000 /* OR addr mask */ - -/* - * FLASH timing: - */ -#define CONFIG_SYS_OR_TIMING_FLASH (OR_ACS_DIV1 | OR_TRLX | OR_CSNT_SAM | \ - OR_SCY_2_CLK | OR_EHTR | OR_BI) - -#define CONFIG_SYS_OR0_REMAP \ - (CONFIG_SYS_REMAP_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_OR0_PRELIM \ - (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_BR0_PRELIM \ - ((FLASH_BASE0_PRELIM & BR_BA_MSK) | BR_PS_16 | BR_V ) - - -/* SDRAM timing: Multiplexed addresses, GPL5 output to GPL5_A (don't care) */ -#define CONFIG_SYS_OR_TIMING_SDRAM 0x00000A00 - - -#define CONFIG_SYS_MPTPR 0x400 - -/* - * MAMR settings for SDRAM - */ -#define CONFIG_SYS_MAMR 0x80802114 - - -/* - * Chip Selects - */ - -#define CONFIG_SYS_OR4 0xFFFF8926 -#define CONFIG_SYS_BR4 0x90000401 - -#define LATCH_ADDR 0x90000200 - -#define CONFIG_AUTOBOOT_KEYED /* use key strings to stop autoboot */ - -#define CONFIG_AUTOBOOT_STOP_STR "." /* easy to stop for now */ -#define CONFIG_SILENT_CONSOLE 1 - -#define CONFIG_USB_STORAGE 1 -#define CONFIG_USB_SL811HS 1 - -#endif /* __CONFIG_H */ diff --git a/include/status_led.h b/include/status_led.h index c5de894..1feeff5 100644 --- a/include/status_led.h +++ b/include/status_led.h @@ -158,22 +158,6 @@ void status_led_set (int led, int state); # define STATUS_LED_ACTIVE 1 /* LED on for bit == 0 */ # define STATUS_LED_BOOT 0 /* LED 0 used for boot status */
-/***** KUP4K, KUP4X ****************************************************/ -#elif defined(CONFIG_KUP4K) || defined(CONFIG_KUP4X) - -# define STATUS_LED_PAR im_ioport.iop_papar -# define STATUS_LED_DIR im_ioport.iop_padir -# define STATUS_LED_ODR im_ioport.iop_paodr -# define STATUS_LED_DAT im_ioport.iop_padat - -# define STATUS_LED_BIT 0x00000300 /* green + red PA[8]=yellow, PA[7]=red, PA[6]=green */ -# define STATUS_LED_PERIOD (CONFIG_SYS_HZ / 2) -# define STATUS_LED_STATE STATUS_LED_BLINKING - -# define STATUS_LED_ACTIVE 1 /* LED on for bit == 1 */ - -# define STATUS_LED_BOOT 0 /* LED 0 used for boot status */ - #elif defined(CONFIG_V38B)
# define STATUS_LED_BIT 0x0010 /* Timer7 GPIO */
On Mon, Dec 15, 2014 at 11:26:09PM +0900, Masahiro Yamada wrote:
These boards are still non-generic boards.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Klaus Heydeck heydeck@kieback-peter.de
This board is still a non-generic board.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Wolfgang Denk wd@denx.de ---
arch/powerpc/cpu/mpc8xx/Kconfig | 4 - arch/powerpc/cpu/mpc8xx/cpu_init.c | 3 +- board/spd8xx/Kconfig | 9 - board/spd8xx/MAINTAINERS | 6 - board/spd8xx/Makefile | 8 - board/spd8xx/flash.c | 41 ---- board/spd8xx/spd8xx.c | 278 ------------------------- board/spd8xx/u-boot.lds | 91 --------- board/spd8xx/u-boot.lds.debug | 122 ----------- common/flash.c | 6 - configs/SPD823TS_defconfig | 3 - doc/README.scrapyard | 1 + include/commproc.h | 29 --- include/configs/SPD823TS.h | 402 ------------------------------------- include/pcmcia.h | 2 - 15 files changed, 2 insertions(+), 1003 deletions(-) delete mode 100644 board/spd8xx/Kconfig delete mode 100644 board/spd8xx/MAINTAINERS delete mode 100644 board/spd8xx/Makefile delete mode 100644 board/spd8xx/flash.c delete mode 100644 board/spd8xx/spd8xx.c delete mode 100644 board/spd8xx/u-boot.lds delete mode 100644 board/spd8xx/u-boot.lds.debug delete mode 100644 configs/SPD823TS_defconfig delete mode 100644 include/configs/SPD823TS.h
diff --git a/arch/powerpc/cpu/mpc8xx/Kconfig b/arch/powerpc/cpu/mpc8xx/Kconfig index 7fa5b0b..8bda42e 100644 --- a/arch/powerpc/cpu/mpc8xx/Kconfig +++ b/arch/powerpc/cpu/mpc8xx/Kconfig @@ -34,9 +34,6 @@ config TARGET_R360MPI config TARGET_RRVISION bool "Support RRvision"
-config TARGET_SPD823TS - bool "Support SPD823TS" - config TARGET_TQM823L bool "Support TQM823L"
@@ -83,7 +80,6 @@ source "board/ivm/Kconfig" source "board/lwmon/Kconfig" source "board/netvia/Kconfig" source "board/r360mpi/Kconfig" -source "board/spd8xx/Kconfig" source "board/tqc/tqm8xx/Kconfig"
endmenu diff --git a/arch/powerpc/cpu/mpc8xx/cpu_init.c b/arch/powerpc/cpu/mpc8xx/cpu_init.c index 6a1cd46..f772787 100644 --- a/arch/powerpc/cpu/mpc8xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc8xx/cpu_init.c @@ -130,8 +130,7 @@ void cpu_init_f (volatile immap_t * immr) defined(CONFIG_IVMS8) || \ defined(CONFIG_LWMON) || \ defined(CONFIG_R360MPI) || \ - defined(CONFIG_RMU) || \ - defined(CONFIG_SPD823TS) + defined(CONFIG_RMU)
memctl->memc_br0 = CONFIG_SYS_BR0_PRELIM; #endif diff --git a/board/spd8xx/Kconfig b/board/spd8xx/Kconfig deleted file mode 100644 index 2430616..0000000 --- a/board/spd8xx/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_SPD823TS - -config SYS_BOARD - default "spd8xx" - -config SYS_CONFIG_NAME - default "SPD823TS" - -endif diff --git a/board/spd8xx/MAINTAINERS b/board/spd8xx/MAINTAINERS deleted file mode 100644 index 7ed9423..0000000 --- a/board/spd8xx/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -SPD8XX BOARD -M: Wolfgang Denk wd@denx.de -S: Maintained -F: board/spd8xx/ -F: include/configs/SPD823TS.h -F: configs/SPD823TS_defconfig diff --git a/board/spd8xx/Makefile b/board/spd8xx/Makefile deleted file mode 100644 index c393f06..0000000 --- a/board/spd8xx/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = spd8xx.o flash.o diff --git a/board/spd8xx/flash.c b/board/spd8xx/flash.c deleted file mode 100644 index 4a332e0..0000000 --- a/board/spd8xx/flash.c +++ /dev/null @@ -1,41 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc8xx.h> - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; - -/*----------------------------------------------------------------------- - */ - -unsigned long flash_init (void) -{ - /* All Speech Design board memory (DRAM and EPROM) initialisation is - done in dram_init(). - The caller of ths function here expects the total size and will hang, - if we give here back 0. So we return the EPROM size. */ - - return (1024 * 1024); /* 1 MB */ -} - -/*----------------------------------------------------------------------- - */ - -void flash_print_info (flash_info_t *info) -{ - printf("no FLASH memory in MPC823TS board\n"); - return; -} - -int flash_erase (flash_info_t *info, int s_first, int s_last) -{ - return 1; -} - -/*----------------------------------------------------------------------- - */ diff --git a/board/spd8xx/spd8xx.c b/board/spd8xx/spd8xx.c deleted file mode 100644 index d3320bb..0000000 --- a/board/spd8xx/spd8xx.c +++ /dev/null @@ -1,278 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * Ulrich Lutz, Speech Design GmbH, ulutz@datalab.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc8xx.h> -#include <commproc.h> - -/* ------------------------------------------------------------------------- */ - -static long int dram_size (long int, long int *, long int); - -/* ------------------------------------------------------------------------- */ - -#define _NOT_USED_ 0xFFFFFFFF - -const uint sharc_table[] = { - /* - * Single Read. (Offset 0 in UPM RAM) - */ - 0x0FF3FC04, 0x0FF3EC00, 0x7FFFEC04, 0xFFFFEC04, - 0xFFFFEC05, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Burst Read. (Offset 8 in UPM RAM) - */ - /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Single Write. (Offset 18 in UPM RAM) - */ - 0x0FAFFC04, 0x0FAFEC00, 0x7FFFEC04, 0xFFFFEC04, - 0xFFFFEC05, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Burst Write. (Offset 20 in UPM RAM) - */ - /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Refresh (Offset 30 in UPM RAM) - */ - /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Exception. (Offset 3c in UPM RAM) - */ - 0x7FFFFC07, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, -}; - - -const uint sdram_table[] = { - /* - * Single Read. (Offset 0 in UPM RAM) - */ - 0x1F07FC04, 0xEEAEFC04, 0x11ADFC04, 0xEFBBBC00, - 0x1FF77C47, /* last */ - /* - * SDRAM Initialization (offset 5 in UPM RAM) - * - * This is no UPM entry point. The following definition uses - * the remaining space to establish an initialization - * sequence, which is executed by a RUN command. - * - */ - 0x1FF77C35, 0xEFEABC34, 0x1FB57C35, /* last */ - /* - * Burst Read. (Offset 8 in UPM RAM) - */ - 0x1F07FC04, 0xEEAEFC04, 0x10ADFC04, 0xF0AFFC00, - 0xF0AFFC00, 0xF1AFFC00, 0xEFBBBC00, 0x1FF77C47, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Single Write. (Offset 18 in UPM RAM) - */ - 0x1F27FC04, 0xEEAEBC00, 0x01B93C04, 0x1FF77C47, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Burst Write. (Offset 20 in UPM RAM) - */ - 0x1F07FC04, 0xEEAEBC00, 0x10AD7C00, 0xF0AFFC00, - 0xF0AFFC00, 0xE1BBBC04, 0x1FF77C47, /* last */ - _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Refresh (Offset 30 in UPM RAM) - */ - 0x1FF5FC84, 0xFFFFFC04, 0xFFFFFC04, 0xFFFFFC04, - 0xFFFFFC84, 0xFFFFFC07, /* last */ - _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Exception. (Offset 3c in UPM RAM) - */ - 0x7FFFFC07, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, -}; - -/* ------------------------------------------------------------------------- */ - - -/* - * Check Board Identity: - * - */ - -int checkboard (void) -{ - puts ("Board: SPD823TS\n"); - return (0); -} - -/* ------------------------------------------------------------------------- */ - -phys_size_t initdram (int board_type) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - long int size_b0; - -#if 0 - /* - * Map controller bank 2 to the SRAM bank at preliminary address. - */ - memctl->memc_or2 = CONFIG_SYS_OR2; - memctl->memc_br2 = CONFIG_SYS_BR2; -#endif - - /* - * Map controller bank 4 to the PER8 bank. - */ - memctl->memc_or4 = CONFIG_SYS_OR4; - memctl->memc_br4 = CONFIG_SYS_BR4; - -#if 0 - /* Configure SHARC at UMA */ - upmconfig (UPMA, (uint *) sharc_table, - sizeof (sharc_table) / sizeof (uint)); - /* Map controller bank 5 to the SHARC */ - memctl->memc_or5 = CONFIG_SYS_OR5; - memctl->memc_br5 = CONFIG_SYS_BR5; -#endif - - memctl->memc_mamr = 0x00001000; - - /* Configure SDRAM at UMB */ - upmconfig (UPMB, (uint *) sdram_table, - sizeof (sdram_table) / sizeof (uint)); - - memctl->memc_mptpr = CONFIG_SYS_MPTPR_1BK_8K; - - memctl->memc_mar = 0x00000088; - - /* - * Map controller bank 3 to the SDRAM bank at preliminary address. - */ - memctl->memc_or3 = CONFIG_SYS_OR3_PRELIM; - memctl->memc_br3 = CONFIG_SYS_BR3_PRELIM; - - memctl->memc_mbmr = CONFIG_SYS_MBMR_8COL; /* refresh not enabled yet */ - - udelay (200); - memctl->memc_mcr = 0x80806105; - udelay (1); - memctl->memc_mcr = 0x80806130; - udelay (1); - memctl->memc_mcr = 0x80806130; - udelay (1); - memctl->memc_mcr = 0x80806106; - - memctl->memc_mbmr |= MBMR_PTBE; /* refresh enabled */ - - /* - * Check Bank 0 Memory Size for re-configuration - */ - size_b0 = - dram_size (CONFIG_SYS_MBMR_8COL, SDRAM_BASE3_PRELIM, - SDRAM_MAX_SIZE); - - memctl->memc_mbmr = CONFIG_SYS_MBMR_8COL | MBMR_PTBE; - - return (size_b0); -} - -/* ------------------------------------------------------------------------- */ - -/* - * Check memory range for valid RAM. A simple memory test determines - * the actually available RAM size between addresses `base' and - * `base + maxsize'. Some (not all) hardware errors are detected: - * - short between address lines - * - short between data lines - */ - -static long int dram_size (long int mamr_value, long int *base, - long int maxsize) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - - memctl->memc_mbmr = mamr_value; - - return (get_ram_size (base, maxsize)); -} - -/* ------------------------------------------------------------------------- */ - -void reset_phy (void) -{ - immap_t *immr = (immap_t *) CONFIG_SYS_IMMR; - ushort sreg; - - /* Configure extra port pins for NS DP83843 PHY */ - immr->im_ioport.iop_papar &= ~(PA_ENET_MDC | PA_ENET_MDIO); - - sreg = immr->im_ioport.iop_padir; - sreg |= PA_ENET_MDC; /* Mgmt. Data Clock is Output */ - sreg &= ~(PA_ENET_MDIO); /* Mgmt. Data I/O is bidirect. => Input */ - immr->im_ioport.iop_padir = sreg; - - immr->im_ioport.iop_padat &= ~(PA_ENET_MDC); /* set MDC = 0 */ - - /* - * RESET in implemented by a positive pulse of at least 1 us - * at the reset pin. - * - * Configure RESET pins for NS DP83843 PHY, and RESET chip. - * - * Note: The RESET pin is high active, but there is an - * inverter on the SPD823TS board... - */ - immr->im_ioport.iop_pcpar &= ~(PC_ENET_RESET); - immr->im_ioport.iop_pcdir |= PC_ENET_RESET; - /* assert RESET signal of PHY */ - immr->im_ioport.iop_pcdat &= ~(PC_ENET_RESET); - udelay (10); - /* de-assert RESET signal of PHY */ - immr->im_ioport.iop_pcdat |= PC_ENET_RESET; - udelay (10); -} - -/* ------------------------------------------------------------------------- */ - -void ide_set_reset (int on) -{ - volatile immap_t *immr = (immap_t *) CONFIG_SYS_IMMR; - - /* - * Configure PC for IDE Reset Pin - */ - if (on) { /* assert RESET */ - immr->im_ioport.iop_pcdat &= ~(CONFIG_SYS_PC_IDE_RESET); - } else { /* release RESET */ - immr->im_ioport.iop_pcdat |= CONFIG_SYS_PC_IDE_RESET; - } - - /* program port pin as GPIO output */ - immr->im_ioport.iop_pcpar &= ~(CONFIG_SYS_PC_IDE_RESET); - immr->im_ioport.iop_pcso &= ~(CONFIG_SYS_PC_IDE_RESET); - immr->im_ioport.iop_pcdir |= CONFIG_SYS_PC_IDE_RESET; -} - -/* ------------------------------------------------------------------------- */ diff --git a/board/spd8xx/u-boot.lds b/board/spd8xx/u-boot.lds deleted file mode 100644 index 463af7e..0000000 --- a/board/spd8xx/u-boot.lds +++ /dev/null @@ -1,91 +0,0 @@ -/* - * (C) Copyright 2000-2010 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -OUTPUT_ARCH(powerpc) - -SECTIONS -{ - /* Read-only sections, merged into text segment: */ - . = + SIZEOF_HEADERS; - .text : - { - /* WARNING - the following is hand-optimized to fit within */ - /* the sector layout of our flash chips! XXX FIXME XXX */ - - arch/powerpc/cpu/mpc8xx/start.o (.text*) - arch/powerpc/cpu/mpc8xx/traps.o (.text*) - net/built-in.o (.text*) - arch/powerpc/cpu/mpc8xx/built-in.o (.text*) - *(.text.v*printf) - - . = DEFINED(env_offset) ? env_offset : .; - common/env_embedded.o (.ppcenv*) - - *(.text*) - } - _etext = .; - PROVIDE (etext = .); - .rodata : - { - *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) - } - - /* Read-write section, merged into data segment: */ - . = (. + 0x0FF) & 0xFFFFFF00; - _erotext = .; - PROVIDE (erotext = .); - .reloc : - { - _GOT2_TABLE_ = .; - KEEP(*(.got2)) - KEEP(*(.got)) - PROVIDE(_GLOBAL_OFFSET_TABLE_ = . + 4); - _FIXUP_TABLE_ = .; - KEEP(*(.fixup)) - } - __got2_entries = ((_GLOBAL_OFFSET_TABLE_ - _GOT2_TABLE_) >> 2) - 1; - __fixup_entries = (. - _FIXUP_TABLE_)>>2; - - .data : - { - *(.data*) - *(.sdata*) - } - _edata = .; - PROVIDE (edata = .); - - . = .; - - . = ALIGN(4); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); - } - - - . = .; - __start___ex_table = .; - __ex_table : { *(__ex_table) } - __stop___ex_table = .; - - . = ALIGN(256); - __init_begin = .; - .text.init : { *(.text.init) } - .data.init : { *(.data.init) } - . = ALIGN(256); - __init_end = .; - - __bss_start = .; - .bss (NOLOAD) : - { - *(.bss*) - *(.sbss*) - *(COMMON) - . = ALIGN(4); - } - __bss_end = . ; - PROVIDE (end = .); -} diff --git a/board/spd8xx/u-boot.lds.debug b/board/spd8xx/u-boot.lds.debug deleted file mode 100644 index 7cfed1f..0000000 --- a/board/spd8xx/u-boot.lds.debug +++ /dev/null @@ -1,122 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -OUTPUT_ARCH(powerpc) -/* Do we need any of these for elf? - __DYNAMIC = 0; */ -SECTIONS -{ - /* Read-only sections, merged into text segment: */ - . = + SIZEOF_HEADERS; - .interp : { *(.interp) } - .hash : { *(.hash) } - .dynsym : { *(.dynsym) } - .dynstr : { *(.dynstr) } - .rel.text : { *(.rel.text) } - .rela.text : { *(.rela.text) } - .rel.data : { *(.rel.data) } - .rela.data : { *(.rela.data) } - .rel.rodata : { *(.rel.rodata) } - .rela.rodata : { *(.rela.rodata) } - .rel.got : { *(.rel.got) } - .rela.got : { *(.rela.got) } - .rel.ctors : { *(.rel.ctors) } - .rela.ctors : { *(.rela.ctors) } - .rel.dtors : { *(.rel.dtors) } - .rela.dtors : { *(.rela.dtors) } - .rel.bss : { *(.rel.bss) } - .rela.bss : { *(.rela.bss) } - .rel.plt : { *(.rel.plt) } - .rela.plt : { *(.rela.plt) } - .init : { *(.init) } - .plt : { *(.plt) } - .text : - { - /* WARNING - the following is hand-optimized to fit within */ - /* the sector layout of our flash chips! XXX FIXME XXX */ - - arch/powerpc/cpu/mpc8xx/start.o (.text) - common/dlmalloc.o (.text) - lib/vsprintf.o (.text) - lib/crc32.o (.text) - arch/powerpc/lib/extable.o (.text) - - . = env_offset; - common/env_embedded.o(.text) - - *(.text) - *(.got1) - } - _etext = .; - PROVIDE (etext = .); - .rodata : - { - *(.rodata) - *(.rodata1) - *(.rodata.str1.4) - *(.eh_frame) - } - .fini : { *(.fini) } =0 - .ctors : { *(.ctors) } - .dtors : { *(.dtors) } - - /* Read-write section, merged into data segment: */ - . = (. + 0x0FFF) & 0xFFFFF000; - _erotext = .; - PROVIDE (erotext = .); - .reloc : - { - *(.got) - _GOT2_TABLE_ = .; - *(.got2) - _FIXUP_TABLE_ = .; - *(.fixup) - } - __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; - __fixup_entries = (. - _FIXUP_TABLE_)>>2; - - .data : - { - *(.data) - *(.data1) - *(.sdata) - *(.sdata2) - *(.dynamic) - CONSTRUCTORS - } - _edata = .; - PROVIDE (edata = .); - - - . = ALIGN(4); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); - } - - - __start___ex_table = .; - __ex_table : { *(__ex_table) } - __stop___ex_table = .; - - . = ALIGN(4096); - __init_begin = .; - .text.init : { *(.text.init) } - .data.init : { *(.data.init) } - . = ALIGN(4096); - __init_end = .; - - __bss_start = .; - .bss : - { - *(.sbss) *(.scommon) - *(.dynbss) - *(.bss) - *(COMMON) - } - __bss_end = . ; - PROVIDE (end = .); -} diff --git a/common/flash.c b/common/flash.c index f1440c2..fa33f03 100644 --- a/common/flash.c +++ b/common/flash.c @@ -88,7 +88,6 @@ flash_protect (int flag, ulong from, ulong to, flash_info_t *info) flash_info_t * addr2info (ulong addr) { -#ifndef CONFIG_SPD823TS flash_info_t *info; int i;
@@ -104,7 +103,6 @@ addr2info (ulong addr) return (info); } } -#endif /* CONFIG_SPD823TS */
return (NULL); } @@ -125,9 +123,6 @@ addr2info (ulong addr) int flash_write (char *src, ulong addr, ulong cnt) { -#ifdef CONFIG_SPD823TS - return (ERR_TIMOUT); /* any other error codes are possible as well */ -#else int i; ulong end = addr + cnt - 1; flash_info_t *info_first = addr2info (addr); @@ -181,7 +176,6 @@ flash_write (char *src, ulong addr, ulong cnt) #endif /* CONFIG_SYS_FLASH_VERIFY_AFTER_WRITE */
return (ERR_OK); -#endif /* CONFIG_SPD823TS */ }
/*----------------------------------------------------------------------- diff --git a/configs/SPD823TS_defconfig b/configs/SPD823TS_defconfig deleted file mode 100644 index 1b218c6..0000000 --- a/configs/SPD823TS_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_SPD823TS=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 3a27d4c..623a30e 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,7 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +SPD823TS powerpc mpc8xx - - Wolfgang Denk wd@denx.de KUP4K powerpc mpc8xx - - Klaus Heydeck heydeck@kieback-peter.de KUP4X powerpc mpc8xx - - Klaus Heydeck heydeck@kieback-peter.de ELPT860 powerpc mpc8xx - - The LEOX team team@leox.org diff --git a/include/commproc.h b/include/commproc.h index 311745e..4c39934 100644 --- a/include/commproc.h +++ b/include/commproc.h @@ -627,35 +627,6 @@ typedef struct scc_enet {
#endif /* CONFIG_NETVIA */
-/*** SPD823TS ******************************************************/ - -#ifdef CONFIG_SPD823TS -/* Bits in parallel I/O port registers that have to be set/cleared - * to configure the pins for SCC2 use. - */ -#define PROFF_ENET PROFF_SCC2 /* Ethernet on SCC2 */ -#define CPM_CR_ENET CPM_CR_CH_SCC2 -#define SCC_ENET 1 -#define PA_ENET_MDC ((ushort)0x0001) /* PA 15 !!! */ -#define PA_ENET_MDIO ((ushort)0x0002) /* PA 14 !!! */ -#define PA_ENET_RXD ((ushort)0x0004) /* PA 13 */ -#define PA_ENET_TXD ((ushort)0x0008) /* PA 12 */ -#define PA_ENET_RCLK ((ushort)0x0200) /* PA 6 */ -#define PA_ENET_TCLK ((ushort)0x0400) /* PA 5 */ - -#define PB_ENET_TENA ((uint)0x00002000) /* PB 18 */ - -#define PC_ENET_CLSN ((ushort)0x0040) /* PC 9 */ -#define PC_ENET_RENA ((ushort)0x0080) /* PC 8 */ -#define PC_ENET_RESET ((ushort)0x0100) /* PC 7 !!! */ - -/* Control bits in the SICR to route TCLK (CLK3) and RCLK (CLK2) to - * SCC2. Also, make sure GR2 (bit 16) and SC2 (bit 17) are zero. - */ -#define SICR_ENET_MASK ((uint)0x0000ff00) -#define SICR_ENET_CLKRT ((uint)0x00002E00) -#endif /* CONFIG_SPD823TS */ - /*** MVS1, TQM823L/M, TQM850L/M, TQM885D, R360MPI **********/
#if (defined(CONFIG_MVS) && CONFIG_MVS < 2) || \ diff --git a/include/configs/SPD823TS.h b/include/configs/SPD823TS.h deleted file mode 100644 index a8b4fbb..0000000 --- a/include/configs/SPD823TS.h +++ /dev/null @@ -1,402 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC823 1 /* This is a MPC823 CPU */ -#define CONFIG_SPD823TS 1 /* ...on a SPD823TS board */ - -#define CONFIG_SYS_TEXT_BASE 0xFF000000 - -#define CONFIG_RESET_PHY_R 1 /* Call reset_phy() */ - -#define CONFIG_8xx_CONS_SMC1 1 /* Console is on SMC1 */ -#undef CONFIG_8xx_CONS_SMC2 -#undef CONFIG_8xx_CONS_NONE -#define CONFIG_BAUDRATE 115200 -#if 0 -#define CONFIG_BOOTDELAY -1 /* autoboot disabled */ -#else -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ -#endif - -#define CONFIG_CLOCKS_IN_MHZ 1 /* clocks passsed to Linux in MHz */ - -#define CONFIG_BOOTCOMMAND "bootp" /* autoboot command */ - -#define CONFIG_BOOTARGS "root=/dev/nfs rw " \ - "nfsroot=10.0.0.2:/opt/eldk/ppc_8xx " \ - "nfsaddrs=10.0.0.99:10.0.0.2" - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_IDE - -#undef CONFIG_CMD_SAVEENV -#undef CONFIG_CMD_FLASH - - -#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE - - -/*----------------------------------------------------------------------*/ -#define CONFIG_ETHADDR 00:D0:93:00:01:CB -#define CONFIG_IPADDR 10.0.0.98 -#define CONFIG_SERVERIP 10.0.0.1 -#undef CONFIG_BOOTCOMMAND -#define CONFIG_BOOTCOMMAND "tftp 200000 uImage;bootm 200000" -/*----------------------------------------------------------------------*/ - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x00100000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x00F00000 /* 1 ... 15MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x00100000 /* default load address */ - -#define CONFIG_SYS_PIO_MODE 0 /* IDE interface in PIO Mode 0 */ - -#define CONFIG_SYS_PC_IDE_RESET ((ushort)0x0008) /* PC 12 */ - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xFFF00000 /* was: 0xFF000000 */ - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0xFF000000 -#ifdef DEBUG -#define CONFIG_SYS_MONITOR_LEN (512 << 10) /* Reserve 512 kB for Monitor */ -#else -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#endif -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 0 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 0 /* max number of sectors on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 0 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 0 /* Timeout for Flash Write (in ms) */ - -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_OFFSET 0x8000 /* Offset of Environment Sector */ -#define CONFIG_ENV_SIZE 0x0800 /* Total Size of Environment Sector */ -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CACHELINE_SHIFT 4 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 11-9 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Software & Bus Monitor Timer max, Bus Monitor enable, SW Watchdog freeze - */ -#if defined(CONFIG_WATCHDOG) -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | \ - SYPCR_SWE | SYPCR_SWRI| SYPCR_SWP) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | SYPCR_SWP) -#endif - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 11-6 - *----------------------------------------------------------------------- - * PCMCIA config., multi-function pin tri-state - */ -/* 0x00000040 */ -#define CONFIG_SYS_SIUMCR (SIUMCR_DBGC00 | SIUMCR_DBPC00 | SIUMCR_MLRC00 | SIUMCR_GB5E) - -/*----------------------------------------------------------------------- - * TBSCR - Time Base Status and Control 11-26 - *----------------------------------------------------------------------- - * Clear Reference Interrupt Status, Timebase freezing enabled - */ -#define CONFIG_SYS_TBSCR (TBSCR_REFA | TBSCR_REFB | TBSCR_TBF) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 11-31 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Interrupt Timer freezing enabled - */ -#define CONFIG_SYS_PISCR (PISCR_PS | PISCR_PITF) - -/*----------------------------------------------------------------------- - * PLPRCR - PLL, Low-Power, and Reset Control Register 15-30 - *----------------------------------------------------------------------- - * Reset PLL lock status sticky bit, timer expired status bit and timer - * interrupt status bit, set PLL multiplication factor ! - */ -/* 0x00b0c0c0 */ -#define CONFIG_SYS_PLPRCR \ - ( (11 << PLPRCR_MF_SHIFT) | \ - PLPRCR_SPLSS | PLPRCR_TEXPS | /*PLPRCR_TMIST|*/ \ - /*PLPRCR_CSRC|*/ PLPRCR_LPM_NORMAL | \ - PLPRCR_CSR | PLPRCR_LOLRE /*|PLPRCR_FIOPD*/ \ - ) - -/*----------------------------------------------------------------------- - * SCCR - System Clock and reset Control Register 15-27 - *----------------------------------------------------------------------- - * Set clock output, timebase and RTC source and divider, - * power management and some other internal clocks - */ -#define SCCR_MASK SCCR_EBDF11 -/* 0x01800014 */ -#define CONFIG_SYS_SCCR (SCCR_COM00 | /*SCCR_TBS|*/ \ - SCCR_RTDIV | SCCR_RTSEL | \ - /*SCCR_CRQEN|*/ /*SCCR_PRQEN|*/ \ - SCCR_EBDF00 | SCCR_DFSYNC00 | \ - SCCR_DFBRG00 | SCCR_DFNL000 | \ - SCCR_DFNH000 | SCCR_DFLCD101 | \ - SCCR_DFALCD00) - -/*----------------------------------------------------------------------- - * RTCSC - Real-Time Clock Status and Control Register - *----------------------------------------------------------------------- - */ -/* 0x00C3 */ -#define CONFIG_SYS_RTCSC (RTCSC_SEC | RTCSC_ALR | RTCSC_RTF| RTCSC_RTE) - - -/*----------------------------------------------------------------------- - * RCCR - RISC Controller Configuration Register - *----------------------------------------------------------------------- - */ -/* TIMEP=2 */ -#define CONFIG_SYS_RCCR 0x0200 - -/*----------------------------------------------------------------------- - * RMDS - RISC Microcode Development Support Control Register - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RMDS 0 - -/*----------------------------------------------------------------------- - * SDSR - SDMA Status Register - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_SDSR ((u_char)0x83) - -/*----------------------------------------------------------------------- - * SDMR - SDMA Mask Register - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_SDMR ((u_char)0x00) - -/*----------------------------------------------------------------------- - * - * Interrupt Levels - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_CPM_INTERRUPT 13 /* SIU_LEVEL6 */ - -/*----------------------------------------------------------------------- - * PCMCIA stuff - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_PCMCIA_MEM_ADDR (0xE0000000) -#define CONFIG_SYS_PCMCIA_MEM_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_DMA_ADDR (0xE4000000) -#define CONFIG_SYS_PCMCIA_DMA_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_ATTRB_ADDR (0xE8000000) -#define CONFIG_SYS_PCMCIA_ATTRB_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_IO_ADDR (0xEC000000) -#define CONFIG_SYS_PCMCIA_IO_SIZE ( 64 << 20 ) - -/*----------------------------------------------------------------------- - * IDE/ATA stuff - *----------------------------------------------------------------------- - */ -#define CONFIG_IDE_PREINIT 1 /* Use preinit IDE hook */ -#define CONFIG_IDE_INIT_POSTRESET 1 /* Use postreset IDE hook */ -#define CONFIG_IDE_8xx_DIRECT 1 /* PCMCIA interface required */ -#define CONFIG_IDE_LED 1 /* LED for ide supported */ -#define CONFIG_IDE_RESET 1 /* reset for ide supported */ - -#define CONFIG_SYS_IDE_MAXBUS 2 /* max. 2 IDE busses */ -#define CONFIG_SYS_IDE_MAXDEVICE (CONFIG_SYS_IDE_MAXBUS*2) /* max. 2 drives per IDE bus */ - -#define CONFIG_SYS_ATA_BASE_ADDR 0xFE100000 -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 -#define CONFIG_SYS_ATA_IDE1_OFFSET 0x0C00 - -#define CONFIG_SYS_ATA_DATA_OFFSET 0x0000 /* Offset for data I/O */ -#define CONFIG_SYS_ATA_REG_OFFSET 0x0080 /* Offset for normal register accesses */ -#define CONFIG_SYS_ATA_ALT_OFFSET 0x0100 /* Offset for alternate registers */ - -/*----------------------------------------------------------------------- - * - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_DER 0 - -/* - * Init Memory Controller: - * - * BR0/1 and OR0/1 (FLASH) - */ - -#define FLASH_BASE0_PRELIM 0xFF000000 /* FLASH bank #0 */ -#define FLASH_BASE1_PRELIM 0xFF080000 /* FLASH bank #1 */ - -/* used to re-map FLASH both when starting from SRAM or FLASH: - * restrict access enough to keep SRAM working (if any) - * but not too much to meddle with FLASH accesses - */ -/* EPROMs are 512kb */ -#define CONFIG_SYS_REMAP_OR_AM 0xFFF80000 /* OR addr mask */ -#define CONFIG_SYS_PRELIM_OR_AM 0xFFF80000 /* OR addr mask */ - -/* FLASH timing: ACS = 11, TRLX = 0, CSNT = 1, SCY = 5, EHTR = 1 */ -#define CONFIG_SYS_OR_TIMING_FLASH (/* OR_CSNT_SAM | */ OR_ACS_DIV4 | OR_BI | \ - OR_SCY_5_CLK | OR_EHTR) - -#define CONFIG_SYS_OR0_REMAP (CONFIG_SYS_REMAP_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -/* 16 bit, bank valid */ -#define CONFIG_SYS_BR0_PRELIM ((FLASH_BASE0_PRELIM & BR_BA_MSK) | BR_PS_16 | BR_V ) - -#define CONFIG_SYS_OR1_REMAP CONFIG_SYS_OR0_REMAP -#define CONFIG_SYS_OR1_PRELIM CONFIG_SYS_OR0_PRELIM -/* 16 bit, bank valid */ -#define CONFIG_SYS_BR1_PRELIM ((FLASH_BASE1_PRELIM & BR_BA_MSK) | BR_PS_16 | BR_V ) - -/* - * BR2-5 and OR2-5 (SRAM/SDRAM/PER8/SHARC) - * - */ -#define SRAM_BASE 0xFE200000 /* SRAM bank */ -#define SRAM_OR_AM 0xFFE00000 /* SRAM is 2 MB */ - -#define SDRAM_BASE3_PRELIM 0x00000000 /* SDRAM bank */ -#define SDRAM_PRELIM_OR_AM 0xF8000000 /* map max. 128 MB */ -#define SDRAM_MAX_SIZE 0x04000000 /* max 64 MB SDRAM */ - -#define PER8_BASE 0xFE000000 /* PER8 bank */ -#define PER8_OR_AM 0xFFF00000 /* PER8 is 1 MB */ - -#define SHARC_BASE 0xFE400000 /* SHARC bank */ -#define SHARC_OR_AM 0xFFC00000 /* SHARC is 4 MB */ - -/* SRAM timing: Multiplexed addresses, GPL5 output to GPL5_A (don't care) */ - -#define CONFIG_SYS_OR_TIMING_SRAM 0x00000D42 /* SRAM-Timing */ -#define CONFIG_SYS_OR2 (SRAM_OR_AM | CONFIG_SYS_OR_TIMING_SRAM ) -#define CONFIG_SYS_BR2 ((SRAM_BASE & BR_BA_MSK) | BR_PS_16 | BR_V ) - -/* SDRAM timing: Multiplexed addresses, GPL5 output to GPL5_A (don't care) */ - -#define CONFIG_SYS_OR_TIMING_SDRAM 0x00000A00 /* SDRAM-Timing */ -#define CONFIG_SYS_OR3_PRELIM (SDRAM_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_SDRAM ) -#define CONFIG_SYS_BR3_PRELIM ((SDRAM_BASE3_PRELIM & BR_BA_MSK) | BR_MS_UPMB | BR_V ) - -#define CONFIG_SYS_OR_TIMING_PER8 0x00000F32 /* PER8-Timing */ -#define CONFIG_SYS_OR4 (PER8_OR_AM | CONFIG_SYS_OR_TIMING_PER8 ) -#define CONFIG_SYS_BR4 ((PER8_BASE & BR_BA_MSK) | BR_PS_8 | BR_V ) - -#define CONFIG_SYS_OR_TIMING_SHARC 0x00000700 /* SHARC-Timing */ -#define CONFIG_SYS_OR5 (SHARC_OR_AM | CONFIG_SYS_OR_TIMING_SHARC ) -#define CONFIG_SYS_BR5 ((SHARC_BASE & BR_BA_MSK) | BR_PS_32 | BR_MS_UPMA | BR_V ) -/* - * Memory Periodic Timer Prescaler - */ - -/* periodic timer for refresh */ -#define CONFIG_SYS_MBMR_PTB 204 - -/* refresh rate 15.6 us (= 64 ms / 4K = 62.4 / quad bursts) for <= 128 MBit */ -#define CONFIG_SYS_MPTPR_2BK_4K MPTPR_PTP_DIV16 /* setting for 2 banks */ -#define CONFIG_SYS_MPTPR_1BK_4K MPTPR_PTP_DIV32 /* setting for 1 bank */ - -/* refresh rate 7.8 us (= 64 ms / 8K = 31.2 / quad bursts) for 256 MBit */ -#define CONFIG_SYS_MPTPR_2BK_8K MPTPR_PTP_DIV8 /* setting for 2 banks */ -#define CONFIG_SYS_MPTPR_1BK_8K MPTPR_PTP_DIV16 /* setting for 1 bank */ - -/* - * MBMR settings for SDRAM - */ - -/* 8 column SDRAM */ -#define CONFIG_SYS_MBMR_8COL ((CONFIG_SYS_MBMR_PTB << MBMR_PTB_SHIFT) | \ - MBMR_AMB_TYPE_0 | MBMR_DSB_1_CYCL | MBMR_G0CLB_A11 | \ - MBMR_RLFB_1X | MBMR_WLFB_1X | MBMR_TLFB_4X) - -#endif /* __CONFIG_H */ diff --git a/include/pcmcia.h b/include/pcmcia.h index 2ff399b..371c9a4 100644 --- a/include/pcmcia.h +++ b/include/pcmcia.h @@ -23,8 +23,6 @@
#if defined(CONFIG_TQM8xxL) # define CONFIG_PCMCIA_SLOT_B /* The TQM8xxL use SLOT_B */ -#elif defined(CONFIG_SPD823TS) /* The SPD8xx use SLOT_B */ -# define CONFIG_PCMCIA_SLOT_B #elif defined(CONFIG_IVMS8) || defined(CONFIG_IVML24) /* The IVM* use SLOT_A */ # define CONFIG_PCMCIA_SLOT_A #elif defined(CONFIG_LWMON) /* The LWMON use SLOT_B */
Unused code in arch/powerpc/cpu/mpc8xx/video.c should be also deleted because CONFIG_VIDEO_ENCODER_AD7176, CONFIG_VIDEO_ENCODER_AD7177, CONFIG_VIDEO_ENCODER_AD7179 are not defined any more.
arch/powerpc/cpu/mpc8xx/Kconfig | 4 - arch/powerpc/cpu/mpc8xx/video.c | 148 ------------ board/RRvision/Kconfig | 9 - board/RRvision/MAINTAINERS | 7 - board/RRvision/Makefile | 8 - board/RRvision/RRvision.c | 222 ------------------ board/RRvision/flash.c | 506 ---------------------------------------- board/RRvision/u-boot.lds | 87 ------- board/RRvision/video_ad7179.h | 52 ----- configs/RRvision_LCD_defconfig | 4 - configs/RRvision_defconfig | 3 - doc/README.scrapyard | 1 + drivers/video/mpc8xx_lcd.c | 17 -- include/commproc.h | 5 +- include/configs/RRvision.h | 450 ----------------------------------- include/video_ad7176.h | 89 ------- include/video_ad7177.h | 133 ----------- include/video_ad7179.h | 20 -- 18 files changed, 3 insertions(+), 1762 deletions(-) delete mode 100644 board/RRvision/Kconfig delete mode 100644 board/RRvision/MAINTAINERS delete mode 100644 board/RRvision/Makefile delete mode 100644 board/RRvision/RRvision.c delete mode 100644 board/RRvision/flash.c delete mode 100644 board/RRvision/u-boot.lds delete mode 100644 board/RRvision/video_ad7179.h delete mode 100644 configs/RRvision_LCD_defconfig delete mode 100644 configs/RRvision_defconfig delete mode 100644 include/configs/RRvision.h delete mode 100644 include/video_ad7176.h delete mode 100644 include/video_ad7177.h delete mode 100644 include/video_ad7179.h
diff --git a/arch/powerpc/cpu/mpc8xx/Kconfig b/arch/powerpc/cpu/mpc8xx/Kconfig index 8bda42e..37ee5f6 100644 --- a/arch/powerpc/cpu/mpc8xx/Kconfig +++ b/arch/powerpc/cpu/mpc8xx/Kconfig @@ -31,9 +31,6 @@ config TARGET_NETVIA config TARGET_R360MPI bool "Support R360MPI"
-config TARGET_RRVISION - bool "Support RRvision" - config TARGET_TQM823L bool "Support TQM823L"
@@ -72,7 +69,6 @@ config TARGET_TQM885D
endchoice
-source "board/RRvision/Kconfig" source "board/cogent/Kconfig" source "board/esteem192e/Kconfig" source "board/ip860/Kconfig" diff --git a/arch/powerpc/cpu/mpc8xx/video.c b/arch/powerpc/cpu/mpc8xx/video.c index 9590bfd..659e688 100644 --- a/arch/powerpc/cpu/mpc8xx/video.c +++ b/arch/powerpc/cpu/mpc8xx/video.c @@ -53,34 +53,6 @@ DECLARE_GLOBAL_DATA_PTR; #define VIDEO_INFO_Y 16
/************************************************************************/ -/* ** VIDEO ENCODER CONSTANTS */ -/************************************************************************/ - -#ifdef CONFIG_VIDEO_ENCODER_AD7176 - -#include <video_ad7176.h> /* Sets encoder data, mode, and visible and active area */ - -#define VIDEO_I2C 1 -#define VIDEO_I2C_ADDR CONFIG_VIDEO_ENCODER_AD7176_ADDR -#endif - -#ifdef CONFIG_VIDEO_ENCODER_AD7177 - -#include <video_ad7177.h> /* Sets encoder data, mode, and visible and active area */ - -#define VIDEO_I2C 1 -#define VIDEO_I2C_ADDR CONFIG_VIDEO_ENCODER_AD7177_ADDR -#endif - -#ifdef CONFIG_VIDEO_ENCODER_AD7179 - -#include <video_ad7179.h> /* Sets encoder data, mode, and visible and active area */ - -#define VIDEO_I2C 1 -#define VIDEO_I2C_ADDR CONFIG_VIDEO_ENCODER_AD7179_ADDR -#endif - -/************************************************************************/ /* ** VIDEO MODE CONSTANTS */ /************************************************************************/
@@ -467,7 +439,6 @@ static inline void video_putstring (int xx, int yy, unsigned char *s) /* ** VIDEO CONTROLLER LOW-LEVEL FUNCTIONS */ /************************************************************************/
-#if !defined(CONFIG_RRVISION) static void video_mode_dupefield (VRAM * source, VRAM * dest, int entries) { int i; @@ -480,7 +451,6 @@ static void video_mode_dupefield (VRAM * source, VRAM * dest, int entries) dest[0].lcyc++; /* Add a cycle to the first entry */ dest[entries - 1].lst = 1; /* Set end of ram entries */ } -#endif
static void inline video_mode_addentry (VRAM * vr, int Hx, int Vx, int Fx, int Bx, @@ -641,72 +611,6 @@ static int video_mode_generate (void)
#ifdef VIDEO_MODE_PAL
-#if defined(CONFIG_RRVISION) - -#define HPW 160 /* horizontal pulse width (was 139) */ -#define VPW 2 /* vertical pulse width */ -#define HBP 104 /* horizontal back porch (was 112) */ -#define VBP 19 /* vertical back porch (was 19) */ -#define VID_R 240 /* number of rows */ - - debug ("[VIDEO CTRL] Starting to add controller entries..."); -/* - * Even field - */ - ADDENTRY (0, 3, 0, 3, 1, 0, 2, 0, 0); - ADDENTRY (0, 0, 0, 3, 1, 0, HPW, 0, 0); - ADDENTRY (3, 0, 0, 3, 1, 0, HBP + (VIDEO_COLS * 2) + 72, 0, 0); - - ADDENTRY (0, 0, 0, 3, 1, 0, VPW, 1, 0); - ADDENTRY (0, 0, 0, 3, 1, 0, HPW-1, 0, 0); - ADDENTRY (3, 0, 0, 3, 1, 0, HBP + (VIDEO_COLS * 2) + 72, 1, 0); - - ADDENTRY (0, 3, 0, 3, 1, 0, VBP, 1, 0); - ADDENTRY (0, 3, 0, 3, 1, 0, HPW-1, 0, 0); - ADDENTRY (3, 3, 0, 3, 1, 0, HBP + (VIDEO_COLS * 2) + 72, 1, 0); -/* - * Active area - */ - ADDENTRY (0, 3, 0, 3, 1, 0, VID_R , 1, 0); - ADDENTRY (0, 3, 0, 3, 1, 0, HPW-1, 0, 0); - ADDENTRY (3, 3, 0, 3, 1, 0, HBP, 0, 0); - ADDENTRY (3, 3, 0, 3, 0, 0, VIDEO_COLS*2, 0, 0); - ADDENTRY (3, 3, 0, 3, 1, 0, 72, 1, 1); - - ADDENTRY (0, 3, 0, 3, 1, 0, 51, 1, 0); - ADDENTRY (0, 3, 0, 3, 1, 0, HPW-1, 0, 0); - ADDENTRY (3, 3, 0, 3, 1, 0, HBP +(VIDEO_COLS * 2) + 72 , 1, 0); -/* - * Odd field - */ - ADDENTRY (0, 3, 0, 3, 1, 0, 2, 0, 0); - ADDENTRY (0, 0, 0, 3, 1, 0, HPW, 0, 0); - ADDENTRY (3, 0, 0, 3, 1, 0, HBP + (VIDEO_COLS * 2) + 72, 0, 0); - - ADDENTRY (0, 0, 0, 3, 1, 0, VPW+1, 1, 0); - ADDENTRY (0, 0, 0, 3, 1, 0, HPW-1, 0, 0); - ADDENTRY (3, 0, 0, 3, 1, 0, HBP + (VIDEO_COLS * 2) + 72, 1, 0); - - ADDENTRY (0, 3, 0, 3, 1, 0, VBP, 1, 0); - ADDENTRY (0, 3, 0, 3, 1, 0, HPW-1, 0, 0); - ADDENTRY (3, 3, 0, 3, 1, 0, HBP + (VIDEO_COLS * 2) + 72, 1, 0); -/* - * Active area - */ - ADDENTRY (0, 3, 0, 3, 1, 0, VID_R , 1, 0); - ADDENTRY (0, 3, 0, 3, 1, 0, HPW-1, 0, 0); - ADDENTRY (3, 3, 0, 3, 1, 0, HBP, 0, 0); - ADDENTRY (3, 3, 0, 3, 0, 0, VIDEO_COLS*2, 0, 0); - ADDENTRY (3, 3, 0, 3, 1, 0, 72, 1, 1); - - ADDENTRY (0, 3, 0, 3, 1, 0, 51, 1, 0); - ADDENTRY (0, 3, 0, 3, 1, 0, HPW-1, 0, 0); - ADDENTRY (3, 3, 0, 3, 1, 0, HBP +(VIDEO_COLS * 2) + 72 , 1, 0); - - debug ("done\n"); - -#else /* !CONFIG_RRVISION */ - /* * Hx Vx Fx Bx VDS INT LCYC LP LST * @@ -758,7 +662,6 @@ static int video_mode_generate (void) * one more cycle loop and a last identifier) */ video_mode_dupefield (vr, &vr[entry], entry); -#endif /* CONFIG_RRVISION */
#endif /* VIDEO_MODE_PAL */
@@ -787,42 +690,6 @@ static int video_mode_generate (void)
static void video_encoder_init (void) { -#ifdef VIDEO_I2C - int rc; - - /* Initialize the I2C */ - debug ("[VIDEO ENCODER] Initializing I2C bus...\n"); -#ifdef CONFIG_SYS_I2C - i2c_init_all(); -#else - i2c_init (CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); -#endif - - /* Send configuration */ -#ifdef DEBUG - { - int i; - - puts ("[VIDEO ENCODER] Configuring the encoder...\n"); - - printf ("Sending %zu bytes (@ %08lX) to I2C 0x%lX:\n ", - sizeof(video_encoder_data), - (ulong)video_encoder_data, - (ulong)VIDEO_I2C_ADDR); - for (i=0; i<sizeof(video_encoder_data); ++i) { - printf(" %02X", video_encoder_data[i]); - } - putc ('\n'); - } -#endif /* DEBUG */ - - if ((rc = i2c_write (VIDEO_I2C_ADDR, 0, 1, - video_encoder_data, - sizeof(video_encoder_data))) != 0) { - printf ("i2c_send error: rc=%d\n", rc); - return; - } -#endif /* VIDEO_I2C */ return; }
@@ -866,21 +733,6 @@ static void video_ctrl_init (void *memptr) immap->im_ioport.iop_pdpar = 0x1fff; immap->im_ioport.iop_pddir = 0x0000;
-#ifdef CONFIG_RRVISION - debug ("PC5->Output(1): enable PAL clock"); - immap->im_ioport.iop_pcpar &= ~(0x0400); - immap->im_ioport.iop_pcdir |= 0x0400 ; - immap->im_ioport.iop_pcdat |= 0x0400 ; - debug ("PDPAR=0x%04X PDDIR=0x%04X PDDAT=0x%04X\n", - immap->im_ioport.iop_pdpar, - immap->im_ioport.iop_pddir, - immap->im_ioport.iop_pddat); - debug ("PCPAR=0x%04X PCDIR=0x%04X PCDAT=0x%04X\n", - immap->im_ioport.iop_pcpar, - immap->im_ioport.iop_pcdir, - immap->im_ioport.iop_pcdat); -#endif /* CONFIG_RRVISION */ - /* Blanking the screen. */ debug ("[VIDEO CTRL] Blanking the screen...\n"); video_fill (VIDEO_BG_COL); diff --git a/board/RRvision/Kconfig b/board/RRvision/Kconfig deleted file mode 100644 index 7c8a6f6..0000000 --- a/board/RRvision/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_RRVISION - -config SYS_BOARD - default "RRvision" - -config SYS_CONFIG_NAME - default "RRvision" - -endif diff --git a/board/RRvision/MAINTAINERS b/board/RRvision/MAINTAINERS deleted file mode 100644 index 59b5c5f..0000000 --- a/board/RRvision/MAINTAINERS +++ /dev/null @@ -1,7 +0,0 @@ -RRVISION BOARD -M: Wolfgang Denk wd@denx.de -S: Maintained -F: board/RRvision/ -F: include/configs/RRvision.h -F: configs/RRvision_defconfig -F: configs/RRvision_LCD_defconfig diff --git a/board/RRvision/Makefile b/board/RRvision/Makefile deleted file mode 100644 index 908e8f8..0000000 --- a/board/RRvision/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = RRvision.o flash.o diff --git a/board/RRvision/RRvision.c b/board/RRvision/RRvision.c deleted file mode 100644 index d94e238..0000000 --- a/board/RRvision/RRvision.c +++ /dev/null @@ -1,222 +0,0 @@ -/* - * (C) Copyright 2001-2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc8xx.h> - -/* ------------------------------------------------------------------------- */ - -static long int dram_size (long int, long int *, long int); - -/* ------------------------------------------------------------------------- */ - -#define _NOT_USED_ 0xFFFFFFFF - -const uint sdram_table[] = -{ - /* - * Single Read. (Offset 0 in UPMA RAM) - */ - 0x1F07FC04, 0xEEAEFC04, 0x11ADFC04, 0xEFBBBC00, - 0x1FF77C47, /* last */ - /* - * SDRAM Initialization (offset 5 in UPMA RAM) - * - * This is no UPM entry point. The following definition uses - * the remaining space to establish an initialization - * sequence, which is executed by a RUN command. - * - */ - 0x1FF77C34, 0xEFEABC34, 0x1FB57C35, /* last */ - /* - * Burst Read. (Offset 8 in UPMA RAM) - */ - 0x1F07FC04, 0xEEAEFC04, 0x10ADFC04, 0xF0AFFC00, - 0xF0AFFC00, 0xF1AFFC00, 0xEFBBBC00, 0x1FF77C47, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Single Write. (Offset 18 in UPMA RAM) - */ - 0x1F07FC04, 0xEEAEBC00, 0x01B93C04, 0x1FF77C47, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Burst Write. (Offset 20 in UPMA RAM) - */ - 0x1F07FC04, 0xEEAEBC00, 0x10AD7C00, 0xF0AFFC00, - 0xF0AFFC00, 0xE1BBBC04, 0x1FF77C47, /* last */ - _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Refresh (Offset 30 in UPMA RAM) - */ - 0x1FF5FC84, 0xFFFFFC04, 0xFFFFFC04, 0xFFFFFC04, - 0xFFFFFC84, 0xFFFFFC07, /* last */ - _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Exception. (Offset 3c in UPMA RAM) - */ - 0x7FFFFC07, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, -}; - -/* ------------------------------------------------------------------------- */ - - -/* - * Check Board Identity: - * - * Always return 1 (no second DRAM bank). - */ - -int checkboard (void) -{ - char buf[64]; - int i; - int l = getenv_f("serial#", buf, sizeof(buf)); - - puts ("Board: RRvision "); - - for (i=0; i < l; ++i) { - if (buf[i] == ' ') - break; - putc (buf[i]); - } - - putc ('\n'); - - return (0); -} - -/* ------------------------------------------------------------------------- */ - -phys_size_t initdram (int board_type) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - unsigned long reg; - long int size8, size9; - long int size = 0; - - upmconfig (UPMA, (uint *)sdram_table, sizeof(sdram_table) / sizeof(uint)); - - /* - * Preliminary prescaler for refresh (depends on number of - * banks): This value is selected for four cycles every 62.4 us - * with two SDRAM banks or four cycles every 31.2 us with one - * bank. It will be adjusted after memory sizing. - */ - memctl->memc_mptpr = CONFIG_SYS_MPTPR_2BK_8K; - - memctl->memc_mar = 0x00000088; - - /* - * Map controller bank 1 the SDRAM bank 2 at physical address 0. - */ - memctl->memc_or1 = CONFIG_SYS_OR2_PRELIM; - memctl->memc_br1 = CONFIG_SYS_BR2_PRELIM; - - memctl->memc_mamr = CONFIG_SYS_MAMR_8COL & (~(MAMR_PTAE)); /* no refresh yet */ - - udelay (200); - - /* perform SDRAM initializsation sequence */ - - memctl->memc_mcr = 0x80002105; /* SDRAM bank 0 */ - udelay (1); - memctl->memc_mcr = 0x80002230; /* SDRAM bank 0 - execute twice */ - udelay (1); - - memctl->memc_mamr |= MAMR_PTAE; /* enable refresh */ - - udelay (1000); - - /* - * Check Bank 0 Memory Size - * - * try 8 column mode - */ - size8 = dram_size (CONFIG_SYS_MAMR_8COL, - SDRAM_BASE2_PRELIM, - SDRAM_MAX_SIZE); - - udelay (1000); - - /* - * try 9 column mode - */ - size9 = dram_size (CONFIG_SYS_MAMR_9COL, - SDRAM_BASE2_PRELIM, - SDRAM_MAX_SIZE); - - if (size8 < size9) { /* leave configuration at 9 columns */ - size = size9; -/* debug ("SDRAM Bank 0 in 9 column mode: %ld MB\n", size >> 20); */ - } else { /* back to 8 columns */ - size = size8; - memctl->memc_mamr = CONFIG_SYS_MAMR_8COL; - udelay (500); -/* debug ("SDRAM Bank 0 in 8 column mode: %ld MB\n", size >> 20); */ - } - - udelay (1000); - - /* - * Adjust refresh rate depending on SDRAM type - * For types > 128 MBit leave it at the current (fast) rate - */ - if (size < 0x02000000) { - /* reduce to 15.6 us (62.4 us / quad) */ - memctl->memc_mptpr = CONFIG_SYS_MPTPR_2BK_4K; - udelay (1000); - } - - /* - * Final mapping - */ - memctl->memc_or1 = ((-size) & 0xFFFF0000) | CONFIG_SYS_OR_TIMING_SDRAM; - memctl->memc_br1 = (CONFIG_SYS_SDRAM_BASE & BR_BA_MSK) | BR_MS_UPMA | BR_V; - - /* - * No bank 1 - * - * invalidate bank - */ - memctl->memc_br3 = 0; - - /* adjust refresh rate depending on SDRAM type, one bank */ - reg = memctl->memc_mptpr; - reg >>= 1; /* reduce to CONFIG_SYS_MPTPR_1BK_8K / _4K */ - memctl->memc_mptpr = reg; - - udelay (10000); - - return (size); -} - -/* ------------------------------------------------------------------------- */ - -/* - * Check memory range for valid RAM. A simple memory test determines - * the actually available RAM size between addresses `base' and - * `base + maxsize'. Some (not all) hardware errors are detected: - * - short between address lines - * - short between data lines - */ - -static long int dram_size (long int mamr_value, long int *base, - long int maxsize) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - - memctl->memc_mamr = mamr_value; - - return (get_ram_size(base, maxsize)); -} diff --git a/board/RRvision/flash.c b/board/RRvision/flash.c deleted file mode 100644 index 146a923..0000000 --- a/board/RRvision/flash.c +++ /dev/null @@ -1,506 +0,0 @@ -/* - * (C) Copyright 2000-2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#define DEBUG - -#include <common.h> -#include <mpc8xx.h> - -#ifndef CONFIG_ENV_ADDR -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET) -#endif - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH chips */ - -/*----------------------------------------------------------------------- - * Functions - */ -static ulong flash_get_size (vu_long *addr, flash_info_t *info); -static int write_word (flash_info_t *info, ulong dest, ulong data); - -/*----------------------------------------------------------------------- - */ - -unsigned long flash_init (void) -{ - volatile immap_t *immap = (immap_t *)CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - unsigned long size; - int i; - - /* Init: no FLASHes known */ - for (i=0; i<CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - } - - /* Static FLASH Bank configuration here - FIXME XXX */ - - size = flash_get_size((vu_long *)FLASH_BASE0_PRELIM, &flash_info[0]); - - if (flash_info[0].flash_id == FLASH_UNKNOWN) { - printf ("## Unknown FLASH on Bank 0 - Size = 0x%08lx = %ld MB\n", - size, size<<20); - } - - /* Remap FLASH according to real size */ - memctl->memc_or0 = CONFIG_SYS_OR_TIMING_FLASH | (-size & OR_AM_MSK); - memctl->memc_br0 = (CONFIG_SYS_FLASH_BASE & BR_BA_MSK) | BR_MS_GPCM | BR_V; - - /* Re-do sizing to get full correct info */ - size = flash_get_size((vu_long *)CONFIG_SYS_FLASH_BASE, &flash_info[0]); - -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE - /* monitor protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE+monitor_flash_len-1, - &flash_info[0]); -#endif - -#ifdef CONFIG_ENV_IS_IN_FLASH - /* ENV protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR+CONFIG_ENV_SIZE-1, - &flash_info[0]); -#endif - - flash_info[0].size = size; - - return (size); -} - -/*----------------------------------------------------------------------- - */ -void flash_print_info (flash_info_t *info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - puts ("missing or unknown FLASH type\n"); - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_AMD: puts ("AMD "); break; - case FLASH_MAN_FUJ: puts ("FUJITSU "); break; - default: puts ("Unknown Vendor "); break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_AM400B: puts ("AM29LV400B (4 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM400T: puts ("AM29LV400T (4 Mbit, top boot sector)\n"); - break; - case FLASH_AM800B: puts ("AM29LV800B (8 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM800T: puts ("AM29LV800T (8 Mbit, top boot sector)\n"); - break; - case FLASH_AM160B: puts ("AM29LV160B (16 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM160T: puts ("AM29LV160T (16 Mbit, top boot sector)\n"); - break; - case FLASH_AM320B: puts ("AM29LV320B (32 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM320T: puts ("AM29LV320T (32 Mbit, top boot sector)\n"); - break; - default: puts ("Unknown Chip Type\n"); - break; - } - - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); - - puts (" Sector Start Addresses:"); - for (i=0; i<info->sector_count; ++i) { - if ((i % 5) == 0) - puts ("\n "); - printf (" %08lX%s", - info->start[i], - info->protect[i] ? " (RO)" : " " - ); - } - puts ("\n"); - return; -} - -/*----------------------------------------------------------------------- - */ - - -/*----------------------------------------------------------------------- - */ - -/* - * The following code cannot be run from FLASH! - */ - -static ulong flash_get_size (vu_long *addr, flash_info_t *info) -{ - short i; - ulong value; - ulong base = (ulong)addr; - - /* Write auto select command: read Manufacturer ID */ - addr[0x0555] = 0x00AA00AA; - addr[0x02AA] = 0x00550055; - addr[0x0555] = 0x00900090; - - value = addr[0]; - - switch (value) { - case AMD_MANUFACT: - info->flash_id = FLASH_MAN_AMD; - break; - case FUJ_MANUFACT: - info->flash_id = FLASH_MAN_FUJ; - break; - default: - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - return (0); /* no or unknown flash */ - } - - value = addr[1]; /* device ID */ - - switch (value) { - case AMD_ID_LV400T: - info->flash_id += FLASH_AM400T; - info->sector_count = 11; - info->size = 0x00100000; - break; /* => 1 MB */ - - case AMD_ID_LV400B: - info->flash_id += FLASH_AM400B; - info->sector_count = 11; - info->size = 0x00100000; - break; /* => 1 MB */ - - case AMD_ID_LV800T: - info->flash_id += FLASH_AM800T; - info->sector_count = 19; - info->size = 0x00200000; - break; /* => 2 MB */ - - case AMD_ID_LV800B: - info->flash_id += FLASH_AM800B; - info->sector_count = 19; - info->size = 0x00200000; - break; /* => 2 MB */ - - case AMD_ID_LV160T: - info->flash_id += FLASH_AM160T; - info->sector_count = 35; - info->size = 0x00400000; - break; /* => 4 MB */ - - case AMD_ID_LV160B: - info->flash_id += FLASH_AM160B; - info->sector_count = 35; - info->size = 0x00400000; - break; /* => 4 MB */ - case AMD_ID_LV320T: - info->flash_id += FLASH_AM320T; - info->sector_count = 71; - info->size = 0x00800000; - break; /* => 8 MB */ - - case AMD_ID_LV320B: - info->flash_id += FLASH_AM320B; - info->sector_count = 71; - info->size = 0x00800000; - break; /* => 8 MB */ - default: - info->flash_id = FLASH_UNKNOWN; - return (0); /* => no or unknown flash */ - } - - /* set up sector start address table */ - switch (value) { - case AMD_ID_LV400B: - case AMD_ID_LV800B: - case AMD_ID_LV160B: - /* set sector offsets for bottom boot block type */ - info->start[0] = base + 0x00000000; - info->start[1] = base + 0x00008000; - info->start[2] = base + 0x0000C000; - info->start[3] = base + 0x00010000; - for (i = 4; i < info->sector_count; i++) { - info->start[i] = base + (i * 0x00020000) - 0x00060000; - } - break; - case AMD_ID_LV400T: - case AMD_ID_LV800T: - case AMD_ID_LV160T: - /* set sector offsets for top boot block type */ - i = info->sector_count - 1; - info->start[i--] = base + info->size - 0x00008000; - info->start[i--] = base + info->size - 0x0000C000; - info->start[i--] = base + info->size - 0x00010000; - for (; i >= 0; i--) { - info->start[i] = base + i * 0x00020000; - } - break; - case AMD_ID_LV320B: - for (i = 0; i < info->sector_count; i++) { - info->start[i] = base; - /* - * The first 8 sectors are 8 kB, - * all the other ones are 64 kB - */ - base += (i < 8) - ? 2 * ( 8 << 10) - : 2 * (64 << 10); - } - break; - case AMD_ID_LV320T: - for (i = 0; i < info->sector_count; i++) { - info->start[i] = base; - /* - * The last 8 sectors are 8 kB, - * all the other ones are 64 kB - */ - base += (i < (info->sector_count - 8)) - ? 2 * (64 << 10) - : 2 * ( 8 << 10); - } - break; - default: - return (0); - break; - } - - /* check for protected sectors */ - for (i = 0; i < info->sector_count; i++) { - /* read sector protection at sector address, (A7 .. A0) = 0x02 */ - /* D0 = 1 if protected */ - addr = (volatile unsigned long *)(info->start[i]); - info->protect[i] = addr[2] & 1; - } - - /* - * Prevent writes to uninitialized FLASH. - */ - if (info->flash_id != FLASH_UNKNOWN) { - addr = (volatile unsigned long *)info->start[0]; - - *addr = 0x00F000F0; /* reset bank */ - } - - return (info->size); -} - - -/*----------------------------------------------------------------------- - */ - -int flash_erase (flash_info_t *info, int s_first, int s_last) -{ - vu_long *addr = (vu_long*)(info->start[0]); - int flag, prot, sect, l_sect; - ulong start, now, last; - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - puts ("- missing\n"); - } else { - puts ("- no sectors to erase\n"); - } - return 1; - } - - if ((info->flash_id == FLASH_UNKNOWN) || - (info->flash_id > FLASH_AMD_COMP)) { - printf ("Can't erase unknown flash type %08lx - aborted\n", - info->flash_id); - return 1; - } - - prot = 0; - for (sect=s_first; sect<=s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - puts ("\n"); - } - - l_sect = -1; - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - addr[0x0555] = 0x00AA00AA; - addr[0x02AA] = 0x00550055; - addr[0x0555] = 0x00800080; - addr[0x0555] = 0x00AA00AA; - addr[0x02AA] = 0x00550055; - - /* Start erase on unprotected sectors */ - for (sect = s_first; sect<=s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - addr = (vu_long*)(info->start[sect]); - addr[0] = 0x00300030; - l_sect = sect; - } - } - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - - /* - * We wait for the last triggered sector - */ - if (l_sect < 0) - goto DONE; - - start = get_timer (0); - last = start; - addr = (vu_long*)(info->start[l_sect]); - while ((addr[0] & 0x00800080) != 0x00800080) { - if ((now = get_timer(start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - puts ("Timeout\n"); - return 1; - } - /* show that we're waiting */ - if ((now - last) > 1000) { /* every second */ - putc ('.'); - last = now; - } - } - -DONE: - /* reset to read mode */ - addr = (volatile unsigned long *)info->start[0]; - addr[0] = 0x00F000F0; /* reset bank */ - - puts (" done\n"); - return 0; -} - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ - -int write_buff (flash_info_t *info, uchar *src, ulong addr, ulong cnt) -{ - ulong cp, wp, data; - int i, l, rc; - - wp = (addr & ~3); /* get lower word aligned address */ - - /* - * handle unaligned start bytes - */ - if ((l = addr - wp) != 0) { - data = 0; - for (i=0, cp=wp; i<l; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - for (; i<4 && cnt>0; ++i) { - data = (data << 8) | *src++; - --cnt; - ++cp; - } - for (; cnt==0 && i<4; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - - if ((rc = write_word(info, wp, data)) != 0) { - return (rc); - } - wp += 4; - } - - /* - * handle word aligned part - */ - while (cnt >= 4) { - data = 0; - for (i=0; i<4; ++i) { - data = (data << 8) | *src++; - } - if ((rc = write_word(info, wp, data)) != 0) { - return (rc); - } - wp += 4; - cnt -= 4; - } - - if (cnt == 0) { - return (0); - } - - /* - * handle unaligned tail bytes - */ - data = 0; - for (i=0, cp=wp; i<4 && cnt>0; ++i, ++cp) { - data = (data << 8) | *src++; - --cnt; - } - for (; i<4; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - - return (write_word(info, wp, data)); -} - -/*----------------------------------------------------------------------- - * Write a word to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_word (flash_info_t *info, ulong dest, ulong data) -{ - vu_long *addr = (vu_long*)(info->start[0]); - ulong start; - int flag; - - /* Check if Flash is (sufficiently) erased */ - if ((*((vu_long *)dest) & data) != data) { - return (2); - } - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - addr[0x0555] = 0x00AA00AA; - addr[0x02AA] = 0x00550055; - addr[0x0555] = 0x00A000A0; - - *((vu_long *)dest) = data; - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* data polling for D7 */ - start = get_timer (0); - while ((*((vu_long *)dest) & 0x00800080) != (data & 0x00800080)) { - if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - return (1); - } - } - return (0); -} - -/*----------------------------------------------------------------------- - */ diff --git a/board/RRvision/u-boot.lds b/board/RRvision/u-boot.lds deleted file mode 100644 index 9470a24..0000000 --- a/board/RRvision/u-boot.lds +++ /dev/null @@ -1,87 +0,0 @@ -/* - * (C) Copyright 2000-2010 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -OUTPUT_ARCH(powerpc) - -SECTIONS -{ - /* Read-only sections, merged into text segment: */ - . = + SIZEOF_HEADERS; - .text : - { - /* WARNING - the following is hand-optimized to fit within */ - /* the sector layout of our flash chips! XXX FIXME XXX */ - arch/powerpc/cpu/mpc8xx/start.o (.text*) - arch/powerpc/cpu/mpc8xx/traps.o (.text*) - - . = env_offset; - common/env_embedded.o (.ppcenv) - - *(.text*) - } - _etext = .; - PROVIDE (etext = .); - .rodata : - { - *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) - } - - /* Read-write section, merged into data segment: */ - . = (. + 0x00FF) & 0xFFFFFF00; - _erotext = .; - PROVIDE (erotext = .); - .reloc : - { - _GOT2_TABLE_ = .; - KEEP(*(.got2)) - KEEP(*(.got)) - PROVIDE(_GLOBAL_OFFSET_TABLE_ = . + 4); - _FIXUP_TABLE_ = .; - KEEP(*(.fixup)) - } - __got2_entries = ((_GLOBAL_OFFSET_TABLE_ - _GOT2_TABLE_) >> 2) - 1; - __fixup_entries = (. - _FIXUP_TABLE_)>>2; - - .data : - { - *(.data*) - *(.sdata*) - } - _edata = .; - PROVIDE (edata = .); - - . = .; - - . = ALIGN(4); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); - } - - - . = .; - __start___ex_table = .; - __ex_table : { *(__ex_table) } - __stop___ex_table = .; - - . = ALIGN(256); - __init_begin = .; - .text.init : { *(.text.init) } - .data.init : { *(.data.init) } - . = ALIGN(256); - __init_end = .; - - __bss_start = .; - .bss (NOLOAD) : - { - *(.bss*) - *(.sbss*) - *(COMMON) - . = ALIGN(4); - } - __bss_end = . ; - PROVIDE (end = .); -} diff --git a/board/RRvision/video_ad7179.h b/board/RRvision/video_ad7179.h deleted file mode 100644 index 1fc1ef4..0000000 --- a/board/RRvision/video_ad7179.h +++ /dev/null @@ -1,52 +0,0 @@ -/* - * (C) Copyright 2003 Wolfgang Grandegger wg@denx.de - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#define VIDEO_ENCODER_NAME "Analog Devices AD7179" - -#define VIDEO_ENCODER_I2C_RATE 100000 /* Max rate is 100Khz */ -#define VIDEO_ENCODER_CB_Y_CR_Y /* Use CB Y CR Y format... */ - -#define VIDEO_MODE_YUYV /* The only mode supported by this encoder */ -#undef VIDEO_MODE_RGB -#define VIDEO_MODE_BPP 16 - -#ifdef VIDEO_MODE_PAL -#define VIDEO_ACTIVE_COLS 720 -#define VIDEO_ACTIVE_ROWS 576 -#define VIDEO_VISIBLE_COLS 640 -#define VIDEO_VISIBLE_ROWS 480 -#else -#error "NTSC mode is not supported" -#endif - -static unsigned char video_encoder_data[] = { - 0x05, /* Mode Register 0 */ - 0x11, /* Mode Register 1 */ - 0x20, /* Mode Register 2 */ - 0x0C, /* Mode Register 3 */ - 0x01, /* Mode Register 4 */ - 0x00, /* Reserved */ - 0x00, /* Reserved */ - 0x04, /* Timing Register 0 */ - 0x00, /* Timing Register 1 */ - 0xCB, /* Subcarrier Frequency Register 0 */ - 0x0A, /* Subcarrier Frequency Register 1 */ - 0x09, /* Subcarrier Frequency Register 2 */ - 0x2A, /* Subcarrier Frequency Register 3 */ - 0x00, /* Subcarrier Phase */ - 0x00, /* Closed Captioning Ext Reg 0 */ - 0x00, /* Closed Captioning Ext Reg 1 */ - 0x00, /* Closed Captioning Reg 0 */ - 0x00, /* Closed Captioning Reg 1 */ - 0x00, /* Pedestal Control Reg 0 */ - 0x00, /* Pedestal Control Reg 1 */ - 0x00, /* Pedestal Control Reg 2 */ - 0x00, /* Pedestal Control Reg 3 */ - 0x00, /* CGMS_WSS Reg 0 */ - 0x00, /* CGMS_WSS Reg 0 */ - 0x00, /* CGMS_WSS Reg 0 */ - 0x00 /* Teletext Req. Control Reg */ -} ; diff --git a/configs/RRvision_LCD_defconfig b/configs/RRvision_LCD_defconfig deleted file mode 100644 index 4d61187..0000000 --- a/configs/RRvision_LCD_defconfig +++ /dev/null @@ -1,4 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="LCD,SHARP_LQ104V7DS01" -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_RRVISION=y diff --git a/configs/RRvision_defconfig b/configs/RRvision_defconfig deleted file mode 100644 index bdb4d7a..0000000 --- a/configs/RRvision_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_RRVISION=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 623a30e..00a5447 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,7 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +RRvision powerpc mpc8xx - - Wolfgang Denk wd@denx.de SPD823TS powerpc mpc8xx - - Wolfgang Denk wd@denx.de KUP4K powerpc mpc8xx - - Klaus Heydeck heydeck@kieback-peter.de KUP4X powerpc mpc8xx - - Klaus Heydeck heydeck@kieback-peter.de diff --git a/drivers/video/mpc8xx_lcd.c b/drivers/video/mpc8xx_lcd.c index 2bc3ceb..a5c1e19 100644 --- a/drivers/video/mpc8xx_lcd.c +++ b/drivers/video/mpc8xx_lcd.c @@ -448,23 +448,6 @@ void lcd_enable (void) r360_i2c_lcd_write(0x40 | ((ctr>>8) & 0xF), ctr & 0xFF); } #endif /* CONFIG_R360MPI */ -#ifdef CONFIG_RRVISION - debug ("PC4->Output(1): enable LVDS\n"); - debug ("PC5->Output(0): disable PAL clock\n"); - immr->im_ioport.iop_pddir |= 0x1000; - immr->im_ioport.iop_pcpar &= ~(0x0C00); - immr->im_ioport.iop_pcdir |= 0x0C00 ; - immr->im_ioport.iop_pcdat |= 0x0800 ; - immr->im_ioport.iop_pcdat &= ~(0x0400); - debug ("PDPAR=0x%04X PDDIR=0x%04X PDDAT=0x%04X\n", - immr->im_ioport.iop_pdpar, - immr->im_ioport.iop_pddir, - immr->im_ioport.iop_pddat); - debug ("PCPAR=0x%04X PCDIR=0x%04X PCDAT=0x%04X\n", - immr->im_ioport.iop_pcpar, - immr->im_ioport.iop_pcdir, - immr->im_ioport.iop_pcdat); -#endif }
/************************************************************************/ diff --git a/include/commproc.h b/include/commproc.h index 4c39934..7d62861 100644 --- a/include/commproc.h +++ b/include/commproc.h @@ -631,10 +631,9 @@ typedef struct scc_enet {
#if (defined(CONFIG_MVS) && CONFIG_MVS < 2) || \ defined(CONFIG_R360MPI) || \ - defined(CONFIG_RRVISION)|| defined(CONFIG_TQM823L) || \ + defined(CONFIG_TQM823L) || \ defined(CONFIG_TQM823M) || defined(CONFIG_TQM850L) || \ - defined(CONFIG_TQM850M) || defined(CONFIG_TQM885D) || \ - defined(CONFIG_RRVISION) + defined(CONFIG_TQM850M) || defined(CONFIG_TQM885D)
/* Bits in parallel I/O port registers that have to be set/cleared * to configure the pins for SCC2 use. diff --git a/include/configs/RRvision.h b/include/configs/RRvision.h deleted file mode 100644 index 97f7798..0000000 --- a/include/configs/RRvision.h +++ /dev/null @@ -1,450 +0,0 @@ -/* - * (C) Copyright 2000, 2001, 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC823 1 /* This is a MPC823 CPU */ -#define CONFIG_RRVISION 1 /* ...on a RRvision board */ - -#define CONFIG_SYS_TEXT_BASE 0x40000000 - -#define CONFIG_8xx_GCLK_FREQ 64000000 - -#define CONFIG_8xx_CONS_SMC1 1 /* Console is on SMC1 */ -#undef CONFIG_8xx_CONS_SMC2 -#undef CONFIG_8xx_CONS_NONE -#define CONFIG_BAUDRATE 115200 /* console baudrate = 115kbps */ -#if 0 -#define CONFIG_BOOTDELAY -1 /* autoboot disabled */ -#else -#define CONFIG_BOOTDELAY 3 /* autoboot after 5 seconds */ -#endif - -#define CONFIG_CLOCKS_IN_MHZ 1 /* clocks passsed to Linux in MHz */ - -#define CONFIG_PREBOOT "setenv stdout serial" - -#undef CONFIG_BOOTARGS -#define CONFIG_ETHADDR 00:50:C2:00:E0:70 -#define CONFIG_OVERWRITE_ETHADDR_ONCE 1 -#define CONFIG_IPADDR 10.0.0.5 -#define CONFIG_SERVERIP 10.0.0.2 -#define CONFIG_NETMASK 255.0.0.0 -#define CONFIG_ROOTPATH "/opt/eldk/ppc_8xx" -#define CONFIG_BOOTCOMMAND "run flash_self" - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=eth0\0" \ - "ramargs=setenv bootargs root=/dev/ram rw\0" \ - "nfsargs=setenv bootargs root=/dev/nfs rw " \ - "nfsroot=${serverip}:${rootpath}\0" \ - "addip=setenv bootargs ${bootargs} ip=${ipaddr}:${serverip}" \ - ":${gatewayip}:${netmask}:${hostname}:${netdev}:off\0" \ - "addtty=setenv bootargs ${bootargs} console=ttyS0,${baudrate}\0"\ - "load=tftp 100000 /tftpboot/u-boot.bin\0" \ - "update=protect off 1:0-8;era 1:0-8;" \ - "cp.b 100000 40000000 ${filesize};" \ - "setenv filesize;saveenv\0" \ - "kernel_addr=40040000\0" \ - "ramdisk_addr=40100000\0" \ - "kernel_img=/tftpboot/uImage\0" \ - "kernel_load=tftp 200000 ${kernel_img}\0" \ - "net_nfs=run kernel_load nfsargs addip addtty;bootm\0" \ - "flash_nfs=run nfsargs addip addtty;bootm ${kernel_addr}\0" \ - "flash_self=run ramargs addip addtty;" \ - "bootm ${kernel_addr} ${ramdisk_addr}\0" - - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -#undef CONFIG_STATUS_LED /* disturbs display */ - -#undef CONFIG_CAN_DRIVER /* CAN Driver support disabled */ - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE - - -#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - -#define CONFIG_RTC_MPC8xx /* use internal RTC of MPC8xx */ - - -#ifdef CONFIG_LCD -#define CONFIG_MPC8XX_LCD -#else -#define CONFIG_VIDEO 1 /* To enable the video initialization */ - -/* Video related */ -#define CONFIG_VIDEO_LOGO 1 /* Show the logo */ -#define CONFIG_VIDEO_ENCODER_AD7179 1 /* Enable this encoder */ -#define CONFIG_VIDEO_ENCODER_AD7179_ADDR 0x2A /* ALSB to ground */ -#endif - -/* enable I2C and select the hardware/software driver */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_SOFT /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SOFT_SPEED 50000 -#define CONFIG_SYS_I2C_SOFT_SLAVE 0xFE -/* - * Software (bit-bang) I2C driver configuration - */ -#define PB_SCL 0x00000020 /* PB 26 */ -#define PB_SDA 0x00000010 /* PB 27 */ - -#define I2C_INIT (immr->im_cpm.cp_pbdir |= PB_SCL) -#define I2C_ACTIVE (immr->im_cpm.cp_pbdir |= PB_SDA) -#define I2C_TRISTATE (immr->im_cpm.cp_pbdir &= ~PB_SDA) -#define I2C_READ ((immr->im_cpm.cp_pbdat & PB_SDA) != 0) -#define I2C_SDA(bit) if(bit) immr->im_cpm.cp_pbdat |= PB_SDA; \ - else immr->im_cpm.cp_pbdat &= ~PB_SDA -#define I2C_SCL(bit) if(bit) immr->im_cpm.cp_pbdat |= PB_SCL; \ - else immr->im_cpm.cp_pbdat &= ~PB_SCL -#define I2C_DELAY udelay(1) /* 1/4 I2C clock duration */ - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_I2C -#define CONFIG_CMD_IDE -#define CONFIG_CMD_DATE - -#undef CONFIG_CMD_PCMCIA -#undef CONFIG_CMD_IDE - - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xFFF00000 - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0x40000000 -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 71 /* max number of sectors on one chip */ - -/* timeout values are in ticks = ms */ -#define CONFIG_SYS_FLASH_ERASE_TOUT (120*CONFIG_SYS_HZ) /* Timeout for Flash Erase */ -#define CONFIG_SYS_FLASH_WRITE_TOUT (1 * CONFIG_SYS_HZ) /* Timeout for Flash Write */ - -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_OFFSET 0x8000 /* Offset of Environment Sector */ -#define CONFIG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */ - -/* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET+CONFIG_ENV_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) - -#define CONFIG_SYS_USE_PPCENV /* Environment embedded in sect .ppcenv */ - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CACHELINE_SHIFT 4 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 11-9 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Software & Bus Monitor Timer max, Bus Monitor enable, SW Watchdog freeze - */ -#if defined(CONFIG_WATCHDOG) -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | \ - SYPCR_SWE | SYPCR_SWRI| SYPCR_SWP) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | SYPCR_SWP) -#endif - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 11-6 - *----------------------------------------------------------------------- - * PCMCIA config., multi-function pin tri-state - */ -#ifndef CONFIG_CAN_DRIVER -#define CONFIG_SYS_SIUMCR (SIUMCR_DBGC00 | SIUMCR_DBPC00 | SIUMCR_MLRC01) -#else /* we must activate GPL5 in the SIUMCR for CAN */ -#define CONFIG_SYS_SIUMCR (SIUMCR_DBGC11 | SIUMCR_DBPC00 | SIUMCR_MLRC01) -#endif /* CONFIG_CAN_DRIVER */ - -/*----------------------------------------------------------------------- - * TBSCR - Time Base Status and Control 11-26 - *----------------------------------------------------------------------- - * Clear Reference Interrupt Status, Timebase freezing enabled - */ -#define CONFIG_SYS_TBSCR (TBSCR_REFA | TBSCR_REFB | TBSCR_TBF) - -/*----------------------------------------------------------------------- - * RTCSC - Real-Time Clock Status and Control Register 11-27 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RTCSC (RTCSC_SEC | RTCSC_ALR | RTCSC_RTF| RTCSC_RTE) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 11-31 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Interrupt Timer freezing enabled - */ -#define CONFIG_SYS_PISCR (PISCR_PS | PISCR_PITF | PISCR_PTE) - -/*----------------------------------------------------------------------- - * PLPRCR - PLL, Low-Power, and Reset Control Register 15-30 - *----------------------------------------------------------------------- - * Reset PLL lock status sticky bit, timer expired status bit and timer - * interrupt status bit - */ - -/* for 64 MHz, we use a 16 MHz clock * 4 */ -#define CONFIG_SYS_PLPRCR ( (4-1)<<PLPRCR_MF_SHIFT | PLPRCR_TEXPS | PLPRCR_TMIST ) - -/*----------------------------------------------------------------------- - * SCCR - System Clock and reset Control Register 15-27 - *----------------------------------------------------------------------- - * Set clock output, timebase and RTC source and divider, - * power management and some other internal clocks - */ -#define SCCR_MASK SCCR_EBDF11 -#define CONFIG_SYS_SCCR (/* SCCR_TBS | */ SCCR_RTSEL | SCCR_RTDIV | \ - SCCR_COM00 | SCCR_DFSYNC00 | SCCR_DFBRG00 | \ - SCCR_DFNL000 | SCCR_DFNH000 | SCCR_DFLCD000 | \ - SCCR_DFALCD00) - -/*----------------------------------------------------------------------- - * PCMCIA stuff - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_PCMCIA_MEM_ADDR (0xE0000000) -#define CONFIG_SYS_PCMCIA_MEM_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_DMA_ADDR (0xE4000000) -#define CONFIG_SYS_PCMCIA_DMA_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_ATTRB_ADDR (0xE8000000) -#define CONFIG_SYS_PCMCIA_ATTRB_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_IO_ADDR (0xEC000000) -#define CONFIG_SYS_PCMCIA_IO_SIZE ( 64 << 20 ) - -/*----------------------------------------------------------------------- - * IDE/ATA stuff (Supports IDE harddisk on PCMCIA Adapter) - *----------------------------------------------------------------------- - */ - -#define CONFIG_IDE_PREINIT 1 /* Use preinit IDE hook */ -#define CONFIG_IDE_8xx_PCCARD 1 /* Use IDE with PC Card Adapter */ - -#undef CONFIG_IDE_8xx_DIRECT /* Direct IDE not supported */ -#undef CONFIG_IDE_LED /* LED for ide not supported */ -#undef CONFIG_IDE_RESET /* reset for ide not supported */ - -#define CONFIG_SYS_IDE_MAXBUS 1 /* max. 1 IDE bus */ -#define CONFIG_SYS_IDE_MAXDEVICE 1 /* max. 1 drive per IDE bus */ - -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 - -#define CONFIG_SYS_ATA_BASE_ADDR CONFIG_SYS_PCMCIA_MEM_ADDR - -/* Offset for data I/O */ -#define CONFIG_SYS_ATA_DATA_OFFSET (CONFIG_SYS_PCMCIA_MEM_SIZE + 0x320) - -/* Offset for normal register accesses */ -#define CONFIG_SYS_ATA_REG_OFFSET (2 * CONFIG_SYS_PCMCIA_MEM_SIZE + 0x320) - -/* Offset for alternate registers */ -#define CONFIG_SYS_ATA_ALT_OFFSET 0x0100 - -/*----------------------------------------------------------------------- - * - *----------------------------------------------------------------------- - * - */ -/*#define CONFIG_SYS_DER 0x2002000F*/ -#define CONFIG_SYS_DER 0 - -/* - * Init Memory Controller: - * - * BR0/1 (FLASH) - */ - -#define FLASH_BASE0_PRELIM 0x40000000 /* FLASH bank #0 */ - -/* used to re-map FLASH both when starting from SRAM or FLASH: - * restrict access enough to keep SRAM working (if any) - * but not too much to meddle with FLASH accesses - */ -#define CONFIG_SYS_REMAP_OR_AM 0x80000000 /* OR addr mask */ -#define CONFIG_SYS_PRELIM_OR_AM 0xE0000000 /* OR addr mask */ - -/* - * FLASH timing: - */ -/* 66 MHz CPU - 66 MHz bus: ACS = 00, TRLX = 1, CSNT = 1, SCY = 3, EHTR = 1 */ -#define CONFIG_SYS_OR_TIMING_FLASH (OR_ACS_DIV1 | OR_TRLX | OR_CSNT_SAM | \ - OR_SCY_3_CLK | OR_EHTR | OR_BI) - -#define CONFIG_SYS_OR0_REMAP (CONFIG_SYS_REMAP_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_BR0_PRELIM ((FLASH_BASE0_PRELIM & BR_BA_MSK) | BR_V ) - -/* - * BR2/3 and OR2/3 (SDRAM) - * - */ -#define SDRAM_BASE2_PRELIM 0x00000000 /* SDRAM bank #0 */ -#define SDRAM_BASE3_PRELIM 0x20000000 /* SDRAM bank #1 */ -#define SDRAM_MAX_SIZE 0x04000000 /* max 64 MB per bank */ - -/* SDRAM timing: Multiplexed addresses, GPL5 output to GPL5_A (don't care) */ -#define CONFIG_SYS_OR_TIMING_SDRAM 0x00000A00 - -#define CONFIG_SYS_OR2_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_SDRAM ) -#define CONFIG_SYS_BR2_PRELIM ((SDRAM_BASE2_PRELIM & BR_BA_MSK) | BR_MS_UPMA | BR_V ) - -#ifndef CONFIG_CAN_DRIVER -#define CONFIG_SYS_OR3_PRELIM CONFIG_SYS_OR2_PRELIM -#define CONFIG_SYS_BR3_PRELIM ((SDRAM_BASE3_PRELIM & BR_BA_MSK) | BR_MS_UPMA | BR_V ) -#else /* CAN uses CS3#, so we can have only one SDRAM bank anyway */ -#define CONFIG_SYS_CAN_BASE 0xC0000000 /* CAN mapped at 0xC0000000 */ -#define CONFIG_SYS_CAN_OR_AM 0xFFFF8000 /* 32 kB address mask */ -#define CONFIG_SYS_OR3_CAN (CONFIG_SYS_CAN_OR_AM | OR_G5LA | OR_BI) -#define CONFIG_SYS_BR3_CAN ((CONFIG_SYS_CAN_BASE & BR_BA_MSK) | \ - BR_PS_8 | BR_MS_UPMB | BR_V ) -#endif /* CONFIG_CAN_DRIVER */ - -/* - * Memory Periodic Timer Prescaler - * - * The Divider for PTA (refresh timer) configuration is based on an - * example SDRAM configuration (64 MBit, one bank). The adjustment to - * the number of chip selects (NCS) and the actually needed refresh - * rate is done by setting MPTPR. - * - * PTA is calculated from - * PTA = (gclk * Trefresh) / ((2 ^ (2 * DFBRG)) * PTP * NCS) - * - * gclk CPU clock (not bus clock!) - * Trefresh Refresh cycle * 4 (four word bursts used) - * - * 4096 Rows from SDRAM example configuration - * 1000 factor s -> ms - * 32 PTP (pre-divider from MPTPR) from SDRAM example configuration - * 4 Number of refresh cycles per period - * 64 Refresh cycle in ms per number of rows - * -------------------------------------------- - * Divider = 4096 * 32 * 1000 / (4 * 64) = 512000 - * - * 50 MHz => 50.000.000 / Divider = 98 - * 66 Mhz => 66.000.000 / Divider = 129 - * 80 Mhz => 80.000.000 / Divider = 156 - */ -#define CONFIG_SYS_MAMR_PTA 129 - -/* - * For 16 MBit, refresh rates could be 31.3 us - * (= 64 ms / 2K = 125 / quad bursts). - * For a simpler initialization, 15.6 us is used instead. - * - * #define CONFIG_SYS_MPTPR_2BK_2K MPTPR_PTP_DIV32 for 2 banks - * #define CONFIG_SYS_MPTPR_1BK_2K MPTPR_PTP_DIV64 for 1 bank - */ -#define CONFIG_SYS_MPTPR_2BK_4K MPTPR_PTP_DIV16 /* setting for 2 banks */ -#define CONFIG_SYS_MPTPR_1BK_4K MPTPR_PTP_DIV32 /* setting for 1 bank */ - -/* refresh rate 7.8 us (= 64 ms / 8K = 31.2 / quad bursts) for 256 MBit */ -#define CONFIG_SYS_MPTPR_2BK_8K MPTPR_PTP_DIV8 /* setting for 2 banks */ -#define CONFIG_SYS_MPTPR_1BK_8K MPTPR_PTP_DIV16 /* setting for 1 bank */ - -/* - * MAMR settings for SDRAM - */ - -/* 8 column SDRAM */ -#define CONFIG_SYS_MAMR_8COL ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_0 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A11 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) -/* 9 column SDRAM */ -#define CONFIG_SYS_MAMR_9COL ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_1 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A10 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) - - -#endif /* __CONFIG_H */ diff --git a/include/video_ad7176.h b/include/video_ad7176.h deleted file mode 100644 index 6a0230e..0000000 --- a/include/video_ad7176.h +++ /dev/null @@ -1,89 +0,0 @@ -/* - * (C) Copyright 2000 - * Paolo Scaffardi, AIRVENT SAM s.p.a - RIMINI(ITALY), arsenio@tin.it - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef _VIDEO_AD7176_H_ -#define _VIDEO_AD7176_H_ - -#define VIDEO_ENCODER_NAME "Analog Devices AD7176" - -#define VIDEO_ENCODER_I2C_RATE 100000 /* Max rate is 100 kHz */ -#define VIDEO_ENCODER_CB_Y_CR_Y /* Use CB Y CR Y format... */ - -#define VIDEO_MODE_YUYV /* The only mode supported by this encoder */ -#undef VIDEO_MODE_RGB -#define VIDEO_MODE_BPP 16 - -#ifdef VIDEO_MODE_PAL -#define VIDEO_ACTIVE_COLS 720 -#define VIDEO_ACTIVE_ROWS 576 -#define VIDEO_VISIBLE_COLS 640 -#define VIDEO_VISIBLE_ROWS 480 -#endif - -#ifdef VIDEO_MODE_NTSC -#define VIDEO_ACTIVE_COLS 720 -#define VIDEO_ACTIVE_ROWS 525 -#define VIDEO_VISIBLE_COLS 640 -#define VIDEO_VISIBLE_ROWS 400 -#endif - -static unsigned char video_encoder_data[] = { -#ifdef VIDEO_MODE_NTSC - 0x04, /* Mode Register 0 */ -#ifdef VIDEO_DEBUG_COLORBARS - 0x82, -#else - 0x02, /* Mode Register 1 */ -#endif /* VIDEO_DEBUG_COLORBARS */ - 0x16, /* Subcarrier Freq 0 */ - 0x7c, /* Subcarrier Freq 1 */ - 0xf0, /* Subcarrier Freq 2 */ - 0x21, /* Subcarrier Freq 3 */ - 0x00, /* Subcarrier phase */ - 0x02, /* Timing Register 0 */ - 0x00, /* Extended Captioning 0 */ - 0x00, /* Extended Captioning 1 */ - 0x00, /* Closed Captioning 0 */ - 0x00, /* Closed Captioning 1 */ - 0x00, /* Timing Register 1 */ - 0x08, /* Mode Register 2 */ - 0x00, /* Pedestal Register 0 */ - 0x00, /* Pedestal Register 1 */ - 0x00, /* Pedestal Register 2 */ - 0x00, /* Pedestal Register 3 */ - 0x00 /* Mode Register 3 */ - -#endif /* VIDEO_MODE_NTSC */ - -#ifdef VIDEO_MODE_PAL - 0x05, /* Mode Register 0 */ -#ifdef VIDEO_DEBUG_COLORBARS - 0x82, -#else - 0x02, /* Mode Register 1 (2) */ -#endif /* VIDEO_DEBUG_COLORBARS */ - 0xcb, /* Subcarrier Freq 0 */ - 0x8a, /* Subcarrier Freq 1 */ - 0x09, /* Subcarrier Freq 2 */ - 0x2a, /* Subcarrier Freq 3 */ - 0x00, /* Subcarrier phase */ - 0x0a, /* Timing Register 0 (a) */ - 0x00, /* Extended Captioning 0 */ - 0x00, /* Extended Captioning 1 */ - 0x00, /* Closed Captioning 0 */ - 0x00, /* Closed Captioning 1 */ - 0x00, /* Timing Register 1 */ - 0x08, /* Mode Register 2 (8) */ - 0x00, /* Pedestal Register 0 */ - 0x00, /* Pedestal Register 1 */ - 0x00, /* Pedestal Register 2 */ - 0x00, /* Pedestal Register 3 */ - 0x00 /* Mode Register 3 */ -#endif /* VIDEO_MODE_PAL */ -} ; - -#endif /* _VIDEO_AD7176_H_ */ diff --git a/include/video_ad7177.h b/include/video_ad7177.h deleted file mode 100644 index 38436d6..0000000 --- a/include/video_ad7177.h +++ /dev/null @@ -1,133 +0,0 @@ -/* - * (C) Copyright 2000 - * Paolo Scaffardi, AIRVENT SAM s.p.a - RIMINI(ITALY), arsenio@tin.it - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef _VIDEO_AD7177_H_ -#define _VIDEO_AD7177_H_ - -/* #define VIDEO_DEBUG_DISABLE_COLORS 0 */ - -#define VIDEO_ENCODER_NAME "Analog Devices AD7177" - -#define VIDEO_ENCODER_I2C_RATE 100000 /* Max rate is 100 kHz */ -#define VIDEO_ENCODER_CB_Y_CR_Y /* Use CB Y CR Y format... */ - -#define VIDEO_MODE_YUYV /* The only mode supported by this encoder */ -#undef VIDEO_MODE_RGB -#define VIDEO_MODE_BPP 16 - -#ifdef VIDEO_MODE_PAL -#define VIDEO_ACTIVE_COLS 720 -#define VIDEO_ACTIVE_ROWS 576 -#define VIDEO_VISIBLE_COLS 640 -#define VIDEO_VISIBLE_ROWS 480 -#endif - -#ifdef VIDEO_MODE_NTSC -#define VIDEO_ACTIVE_COLS 720 -#define VIDEO_ACTIVE_ROWS 525 -#define VIDEO_VISIBLE_COLS 640 -#define VIDEO_VISIBLE_ROWS 400 -#endif - -static unsigned char - video_encoder_data[] = { -#ifdef VIDEO_MODE_NTSC - 0x04, /* Mode Register 0 */ -#ifdef VIDEO_DEBUG_COLORBARS - 0xc2, -#else - 0x42, /* Mode Register 1 */ -#endif /* VIDEO_DEBUG_COLORBARS */ - 0x16, /* Subcarrier Freq 0 */ - 0x7c, /* Subcarrier Freq 1 */ - 0xf0, /* Subcarrier Freq 2 */ - 0x21, /* Subcarrier Freq 3 */ - 0x00, /* Subcarrier phase */ - 0x02, /* Timing Register 0 */ - 0x00, /* Extended Captioning 0 */ - 0x00, /* Extended Captioning 1 */ - 0x00, /* Closed Captioning 0 */ - 0x00, /* Closed Captioning 1 */ - 0x00, /* Timing Register 1 */ - 0x08, /* Mode Register 2 */ - 0x00, /* Pedestal Register 0 */ - 0x00, /* Pedestal Register 1 */ - 0x00, /* Pedestal Register 2 */ - 0x00, /* Pedestal Register 3 */ - 0x08, /* Mode Register 3 */ - -#endif /* VIDEO_MODE_NTSC */ - -#ifdef VIDEO_MODE_PAL -#ifdef VIDEO_MODE_RGB_OUT - - 0x69, /* Mode Register 0 */ -#ifdef VIDEO_DEBUG_COLORBARS - 0xc0, /* Mode Register 1 (c0) */ -#else - 0x40, /* Mode Register 1 (c0) */ -#endif /* VIDEO_DEBUG_COLORBARS */ - 0xcb, /* Subcarrier Freq 0 */ - 0x8a, /* Subcarrier Freq 1 */ - 0x09, /* Subcarrier Freq 2 */ - 0x2a, /* Subcarrier Freq 3 */ - 0x00, /* Subcarrier phase */ - 0x02, /* Timing Register 0 */ - 0x00, /* Extended Captioning 0 */ - 0x00, /* Extended Captioning 1 */ - 0x00, /* Closed Captioning 0 */ - 0x00, /* Closed Captioning 1 */ - 0x00, /* Timing Register 1 */ - 0x28, /* Mode Register 2 */ - 0x00, /* Pedestal Register 0 */ - 0x00, /* Pedestal Register 1 */ - 0x00, /* Pedestal Register 2 */ - 0x00, /* Pedestal Register 3 */ - 0x08, /* Mode Register 3 */ - -#else /* ! VIDEO_MODE_RGB_OUT */ - - 0x09, /* Mode Register 0 (was 01) */ -#ifdef VIDEO_DEBUG_COLORBARS - 0xd8, /* */ -#else - 0x59, /* Mode Register 1 (was 58) */ -#endif /* VIDEO_DEBUG_COLORBARS */ - 0xcb, /* Subcarrier Freq 0 */ - 0x8a, /* Subcarrier Freq 1 */ - 0x09, /* Subcarrier Freq 2 */ - 0x2a, /* Subcarrier Freq 3 */ - 0x00, /* Subcarrier phase */ - 0x02, /* Timing Register 0 (was a) */ - 0x00, /* Extended Captioning 0 */ - 0x00, /* Extended Captioning 1 */ - 0x00, /* Closed Captioning 0 */ - 0x00, /* Closed Captioning 1 */ - 0x00, /* Timing Register 1 */ -#ifdef VIDEO_DEBUG_LOWPOWER -#ifdef VIDEO_DEBUG_DISABLE_COLORS - 0x98, /* Mode Register 2 */ -#else - 0x88, /* Mode Register 2 */ -#endif /* VIDEO_DEBUG_DISABLE_COLORS */ -#else /* ! VIDEO_DEBUG_LOWPOWER */ -#ifdef VIDEO_DEBUG_DISABLE_COLORS - 0x18, /* Mode Register 2 */ -#else - 0x08, /* Mode Register 2 */ -#endif /* VIDEO_DEBUG_DISABLE_COLORS */ -#endif /* VIDEO_DEBUG_LOWPOWER */ - 0x00, /* Pedestal Register 0 */ - 0x00, /* Pedestal Register 1 */ - 0x00, /* Pedestal Register 2 */ - 0x00, /* Pedestal Register 3 */ - 0x08 /* Mode Register 3 */ -#endif /* VIDEO_MODE_RGB_OUT */ -#endif /* VIDEO_MODE_PAL */ - } ; - -#endif /* _VIDEO_AD7177_H_ */ diff --git a/include/video_ad7179.h b/include/video_ad7179.h deleted file mode 100644 index 67c1ec0..0000000 --- a/include/video_ad7179.h +++ /dev/null @@ -1,20 +0,0 @@ -/* - * (C) Copyright 2003 Wolfgang Grandegger wg@denx.de - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef _VIDEO_AD7179_H_ -#define _VIDEO_AD7179_H_ - -/* - * The video encoder data are board specific now! - */ - -#if defined(CONFIG_RRVISION) -#include "../board/RRvision/video_ad7179.h" -#else -#error "Please provide a board-specific video_ad7179.h" -#endif - -#endif /* _VIDEO_AD7179_H_ */
On Mon, Dec 15, 2014 at 11:26:11PM +0900, Masahiro Yamada wrote:
This board is still a non-generic board.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Wolfgang Denk wd@denx.de
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Wolfgang Denk wd@denx.de ---
arch/powerpc/cpu/mpc8xx/Kconfig | 4 - arch/powerpc/cpu/mpc8xx/cpu_init.c | 1 - board/r360mpi/Kconfig | 9 - board/r360mpi/MAINTAINERS | 6 - board/r360mpi/Makefile | 8 - board/r360mpi/flash.c | 468 ------------------------------------- board/r360mpi/pcmcia.c | 232 ------------------ board/r360mpi/r360mpi.c | 403 -------------------------------- board/r360mpi/u-boot.lds | 89 ------- configs/R360MPI_defconfig | 3 - doc/README.scrapyard | 1 + drivers/video/mpc8xx_lcd.c | 25 -- include/commproc.h | 4 - include/configs/R360MPI.h | 464 ------------------------------------ include/pcmcia.h | 2 - 15 files changed, 1 insertion(+), 1718 deletions(-) delete mode 100644 board/r360mpi/Kconfig delete mode 100644 board/r360mpi/MAINTAINERS delete mode 100644 board/r360mpi/Makefile delete mode 100644 board/r360mpi/flash.c delete mode 100644 board/r360mpi/pcmcia.c delete mode 100644 board/r360mpi/r360mpi.c delete mode 100644 board/r360mpi/u-boot.lds delete mode 100644 configs/R360MPI_defconfig delete mode 100644 include/configs/R360MPI.h
diff --git a/arch/powerpc/cpu/mpc8xx/Kconfig b/arch/powerpc/cpu/mpc8xx/Kconfig index 37ee5f6..4e67ff2 100644 --- a/arch/powerpc/cpu/mpc8xx/Kconfig +++ b/arch/powerpc/cpu/mpc8xx/Kconfig @@ -28,9 +28,6 @@ config TARGET_LWMON config TARGET_NETVIA bool "Support NETVIA"
-config TARGET_R360MPI - bool "Support R360MPI" - config TARGET_TQM823L bool "Support TQM823L"
@@ -75,7 +72,6 @@ source "board/ip860/Kconfig" source "board/ivm/Kconfig" source "board/lwmon/Kconfig" source "board/netvia/Kconfig" -source "board/r360mpi/Kconfig" source "board/tqc/tqm8xx/Kconfig"
endmenu diff --git a/arch/powerpc/cpu/mpc8xx/cpu_init.c b/arch/powerpc/cpu/mpc8xx/cpu_init.c index f772787..9350fdd 100644 --- a/arch/powerpc/cpu/mpc8xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc8xx/cpu_init.c @@ -129,7 +129,6 @@ void cpu_init_f (volatile immap_t * immr) defined(CONFIG_IVML24) || \ defined(CONFIG_IVMS8) || \ defined(CONFIG_LWMON) || \ - defined(CONFIG_R360MPI) || \ defined(CONFIG_RMU)
memctl->memc_br0 = CONFIG_SYS_BR0_PRELIM; diff --git a/board/r360mpi/Kconfig b/board/r360mpi/Kconfig deleted file mode 100644 index fe8484f..0000000 --- a/board/r360mpi/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_R360MPI - -config SYS_BOARD - default "r360mpi" - -config SYS_CONFIG_NAME - default "R360MPI" - -endif diff --git a/board/r360mpi/MAINTAINERS b/board/r360mpi/MAINTAINERS deleted file mode 100644 index a67ab0c..0000000 --- a/board/r360mpi/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -R360MPI BOARD -M: Wolfgang Denk wd@denx.de -S: Maintained -F: board/r360mpi/ -F: include/configs/R360MPI.h -F: configs/R360MPI_defconfig diff --git a/board/r360mpi/Makefile b/board/r360mpi/Makefile deleted file mode 100644 index f8f7fe7..0000000 --- a/board/r360mpi/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = r360mpi.o flash.o pcmcia.o diff --git a/board/r360mpi/flash.c b/board/r360mpi/flash.c deleted file mode 100644 index 996a22e..0000000 --- a/board/r360mpi/flash.c +++ /dev/null @@ -1,468 +0,0 @@ -/* - * (C) Copyright 2001 - * Kyle Harris, Nexus Technologies, Inc. kharris@nexus-tech.net - * - * (C) Copyright 2001 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* #define DEBUG */ - -#include <common.h> -#include <mpc8xx.h> - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH chips */ - -#if defined(CONFIG_ENV_IS_IN_FLASH) -# ifndef CONFIG_ENV_ADDR -# define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET) -# endif -# ifndef CONFIG_ENV_SIZE -# define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -# endif -# ifndef CONFIG_ENV_SECT_SIZE -# define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE -# endif -#endif - -/*----------------------------------------------------------------------- - * Protection Flags: - */ -#define FLAG_PROTECT_SET 0x01 -#define FLAG_PROTECT_CLEAR 0x02 - -/* Board support for 1 or 2 flash devices */ -#undef FLASH_PORT_WIDTH32 -#define FLASH_PORT_WIDTH16 - -#ifdef FLASH_PORT_WIDTH16 -#define FLASH_PORT_WIDTH ushort -#define FLASH_PORT_WIDTHV vu_short -#else -#define FLASH_PORT_WIDTH ulong -#define FLASH_PORT_WIDTHV vu_long -#endif - -#define FPW FLASH_PORT_WIDTH -#define FPWV FLASH_PORT_WIDTHV - -/*----------------------------------------------------------------------- - * Functions - */ -static ulong flash_get_size (FPW * addr, flash_info_t * info); -static int write_data (flash_info_t * info, ulong dest, FPW data); -static void flash_get_offsets (ulong base, flash_info_t * info); - -/*----------------------------------------------------------------------- - */ - -unsigned long flash_init (void) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - unsigned long size_b0; - int i; - - /* Init: no FLASHes known */ - for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - } - - /* Static FLASH Bank configuration here - FIXME XXX */ - size_b0 = flash_get_size ((FPW *) FLASH_BASE0_PRELIM, &flash_info[0]); - - if (flash_info[0].flash_id == FLASH_UNKNOWN) { - printf ("## Unknown FLASH on Bank 0 - Size = 0x%08lx = %ld MB\n", - size_b0, size_b0 << 20); - } - - /* Remap FLASH according to real size */ - memctl->memc_or0 = CONFIG_SYS_OR_TIMING_FLASH | (-size_b0 & 0xFFFF8000); - memctl->memc_br0 = (CONFIG_SYS_FLASH_BASE & BR_BA_MSK) | BR_PS_16 | BR_MS_GPCM | BR_V; - - /* Re-do sizing to get full correct info */ - size_b0 = flash_get_size ((FPW *) CONFIG_SYS_FLASH_BASE, &flash_info[0]); - - flash_get_offsets (CONFIG_SYS_FLASH_BASE, &flash_info[0]); - -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE - /* monitor protection ON by default */ - (void) flash_protect (FLAG_PROTECT_SET, - CONFIG_SYS_FLASH_BASE, - CONFIG_SYS_FLASH_BASE + monitor_flash_len - 1, - &flash_info[0]); -#endif - -#ifdef CONFIG_ENV_IS_IN_FLASH - /* ENV protection ON by default */ - flash_protect (FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR + CONFIG_ENV_SIZE - 1, - &flash_info[0]); -#endif - - flash_info[0].size = size_b0; - - return (size_b0); -} - -/*----------------------------------------------------------------------- - */ -static void flash_get_offsets (ulong base, flash_info_t * info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - return; - } - - if ((info->flash_id & FLASH_VENDMASK) == FLASH_MAN_INTEL) { - for (i = 0; i < info->sector_count; i++) { - info->start[i] = base + (i * 0x00020000); - } - } -} - -/*----------------------------------------------------------------------- - */ -void flash_print_info (flash_info_t * info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_INTEL: - printf ("INTEL "); - break; - default: - printf ("Unknown Vendor "); - break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_28F320J3A: - printf ("28F320J3A\n"); - break; - case FLASH_28F640J3A: - printf ("28F640J3A\n"); - break; - case FLASH_28F128J3A: - printf ("28F128J3A\n"); - break; - default: - printf ("Unknown Chip Type\n"); - break; - } - - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); - - printf (" Sector Start Addresses:"); - for (i = 0; i < info->sector_count; ++i) { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", - info->start[i], - info->protect[i] ? " (RO)" : " "); - } - printf ("\n"); - return; -} - -/*----------------------------------------------------------------------- - */ - - -/*----------------------------------------------------------------------- - */ - -/* - * The following code cannot be run from FLASH! - */ - -static ulong flash_get_size (FPW * addr, flash_info_t * info) -{ - FPW value; - - /* Make sure Block Lock Bits get cleared */ - addr[0] = (FPW) 0x00FF00FF; - addr[0] = (FPW) 0x00600060; - addr[0] = (FPW) 0x00D000D0; - addr[0] = (FPW) 0x00FF00FF; - - /* Write auto select command: read Manufacturer ID */ - addr[0x5555] = (FPW) 0x00AA00AA; - addr[0x2AAA] = (FPW) 0x00550055; - addr[0x5555] = (FPW) 0x00900090; - - value = addr[0]; - - debug("Manuf. ID @ 0x%08lx: 0x%08x\n", (ulong)addr, value); - - switch (value) { - case (FPW) INTEL_MANUFACT: - info->flash_id = FLASH_MAN_INTEL; - break; - default: - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - addr[0] = (FPW) 0x00FF00FF; /* restore read mode */ - return (0); /* no or unknown flash */ - } - - value = addr[1]; /* device ID */ - - debug("Device ID @ 0x%08lx: 0x%08x\n", (ulong)(&addr[1]), value); - - switch (value) { - case (FPW) INTEL_ID_28F320J3A: - info->flash_id += FLASH_28F320J3A; - info->sector_count = 32; - info->size = 0x00400000; - break; /* => 4 MB */ - - case (FPW) INTEL_ID_28F640J3A: - info->flash_id += FLASH_28F640J3A; - info->sector_count = 64; - info->size = 0x00800000; - break; /* => 8 MB */ - - case (FPW) INTEL_ID_28F128J3A: - info->flash_id += FLASH_28F128J3A; - info->sector_count = 128; - info->size = 0x01000000; - break; /* => 16 MB */ - - default: - info->flash_id = FLASH_UNKNOWN; - break; - } - - if (info->sector_count > CONFIG_SYS_MAX_FLASH_SECT) { - printf ("** ERROR: sector count %d > max (%d) **\n", - info->sector_count, CONFIG_SYS_MAX_FLASH_SECT); - info->sector_count = CONFIG_SYS_MAX_FLASH_SECT; - } - - addr[0] = (FPW) 0x00FF00FF; /* restore read mode */ - - return (info->size); -} - - -/*----------------------------------------------------------------------- - */ - -int flash_erase (flash_info_t * info, int s_first, int s_last) -{ - int flag, prot, sect; - ulong type, start, now, last; - int rcode = 0; - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - type = (info->flash_id & FLASH_VENDMASK); - if ((type != FLASH_MAN_INTEL)) { - printf ("Can't erase unknown flash type %08lx - aborted\n", - info->flash_id); - return 1; - } - - prot = 0; - for (sect = s_first; sect <= s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - printf ("\n"); - } - - start = get_timer (0); - last = start; - /* Start erase on unprotected sectors */ - for (sect = s_first; sect <= s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - FPWV *addr = (FPWV *) (info->start[sect]); - FPW status; - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts (); - - *addr = (FPW) 0x00500050; /* clear status register */ - *addr = (FPW) 0x00200020; /* erase setup */ - *addr = (FPW) 0x00D000D0; /* erase confirm */ - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts (); - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - - while (((status = *addr) & (FPW) 0x00800080) != (FPW) 0x00800080) { - if ((now = get_timer (start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - *addr = (FPW) 0x00B000B0; /* suspend erase */ - *addr = (FPW) 0x00FF00FF; /* reset to read mode */ - rcode = 1; - break; - } - - /* show that we're waiting */ - if ((now - last) > 1000) { /* every second */ - putc ('.'); - last = now; - } - } - - *addr = (FPW) 0x00FF00FF; /* reset to read mode */ - } - } - printf (" done\n"); - return rcode; -} - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - * 4 - Flash not identified - */ - -int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) -{ - ulong cp, wp; - FPW data; - - int i, l, rc, port_width; - - if (info->flash_id == FLASH_UNKNOWN) { - return 4; - } -/* get lower word aligned address */ -#ifdef FLASH_PORT_WIDTH16 - wp = (addr & ~1); - port_width = 2; -#else - wp = (addr & ~3); - port_width = 4; -#endif - - /* - * handle unaligned start bytes - */ - if ((l = addr - wp) != 0) { - data = 0; - for (i = 0, cp = wp; i < l; ++i, ++cp) { - data = (data << 8) | (*(uchar *) cp); - } - for (; i < port_width && cnt > 0; ++i) { - data = (data << 8) | *src++; - --cnt; - ++cp; - } - for (; cnt == 0 && i < port_width; ++i, ++cp) { - data = (data << 8) | (*(uchar *) cp); - } - - if ((rc = write_data (info, wp, data)) != 0) { - return (rc); - } - wp += port_width; - } - - /* - * handle word aligned part - */ - while (cnt >= port_width) { - data = 0; - for (i = 0; i < port_width; ++i) { - data = (data << 8) | *src++; - } - if ((rc = write_data (info, wp, data)) != 0) { - return (rc); - } - wp += port_width; - cnt -= port_width; - } - - if (cnt == 0) { - return (0); - } - - /* - * handle unaligned tail bytes - */ - data = 0; - for (i = 0, cp = wp; i < port_width && cnt > 0; ++i, ++cp) { - data = (data << 8) | *src++; - --cnt; - } - for (; i < port_width; ++i, ++cp) { - data = (data << 8) | (*(uchar *) cp); - } - - return (write_data (info, wp, data)); -} - -/*----------------------------------------------------------------------- - * Write a word or halfword to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_data (flash_info_t * info, ulong dest, FPW data) -{ - FPWV *addr = (FPWV *) dest; - ulong status; - ulong start; - int flag; - - /* Check if Flash is (sufficiently) erased */ - if ((*addr & data) != data) { - printf ("not erased at %08lx (%x)\n", (ulong) addr, *addr); - return (2); - } - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts (); - - *addr = (FPW) 0x00400040; /* write setup */ - *addr = data; - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts (); - - start = get_timer (0); - - while (((status = *addr) & (FPW) 0x00800080) != (FPW) 0x00800080) { - if (get_timer (start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - *addr = (FPW) 0x00FF00FF; /* restore read mode */ - return (1); - } - } - - *addr = (FPW) 0x00FF00FF; /* restore read mode */ - - return (0); -} diff --git a/board/r360mpi/pcmcia.c b/board/r360mpi/pcmcia.c deleted file mode 100644 index a939b31..0000000 --- a/board/r360mpi/pcmcia.c +++ /dev/null @@ -1,232 +0,0 @@ -#include <common.h> -#include <mpc8xx.h> -#include <pcmcia.h> - -#undef CONFIG_PCMCIA - -#if defined(CONFIG_CMD_PCMCIA) -#define CONFIG_PCMCIA -#endif - -#if defined(CONFIG_CMD_IDE) && defined(CONFIG_IDE_8xx_PCCARD) -#define CONFIG_PCMCIA -#endif - -#ifdef CONFIG_PCMCIA - -#define PCMCIA_BOARD_MSG "R360MPI" - -int pcmcia_hardware_enable(int slot) -{ - volatile immap_t *immap; - volatile pcmconf8xx_t *pcmp; - volatile sysconf8xx_t *sysp; - uint reg, mask; - - debug ("hardware_enable: " PCMCIA_BOARD_MSG " Slot %c\n", 'A'+slot); - - udelay(10000); - - immap = (immap_t *)CONFIG_SYS_IMMR; - sysp = (sysconf8xx_t *)(&(((immap_t *)CONFIG_SYS_IMMR)->im_siu_conf)); - pcmp = (pcmconf8xx_t *)(&(((immap_t *)CONFIG_SYS_IMMR)->im_pcmcia)); - - /* - * Configure SIUMCR to enable PCMCIA port B - * (VFLS[0:1] are not used for debugging, we connect FRZ# instead) - */ - sysp->sc_siumcr &= ~SIUMCR_DBGC11; /* set DBGC to 00 */ - - /* clear interrupt state, and disable interrupts */ - pcmp->pcmc_pscr = PCMCIA_MASK(_slot_); - pcmp->pcmc_per &= ~PCMCIA_MASK(_slot_); - - /* - * Disable interrupts, DMA, and PCMCIA buffers - * (isolate the interface) and assert RESET signal - */ - debug ("Disable PCMCIA buffers and assert RESET\n"); - reg = 0; - reg |= __MY_PCMCIA_GCRX_CXRESET; /* active high */ - reg |= __MY_PCMCIA_GCRX_CXOE; /* active low */ - PCMCIA_PGCRX(_slot_) = reg; - udelay(500); - - /* - * Configure Ports A, B & C pins for - * 5 Volts Enable and 3 Volts enable - */ - immap->im_ioport.iop_pcpar &= ~(0x0400); - immap->im_ioport.iop_pcso &= ~(0x0400);/* - immap->im_ioport.iop_pcdir |= 0x0400;*/ - - immap->im_ioport.iop_papar &= ~(0x0200);/* - immap->im_ioport.iop_padir |= 0x0200;*/ -#if 0 - immap->im_ioport.iop_pbpar &= ~(0xC000); - immap->im_ioport.iop_pbdir &= ~(0xC000); -#endif - /* remove all power */ - - immap->im_ioport.iop_pcdat |= 0x0400; - immap->im_ioport.iop_padat |= 0x0200; - - /* - * Make sure there is a card in the slot, then configure the interface. - */ - udelay(10000); - debug ("[%d] %s: PIPR(%p)=0x%x\n", - __LINE__,__FUNCTION__, - &(pcmp->pcmc_pipr),pcmp->pcmc_pipr); - if (pcmp->pcmc_pipr & (0x18000000 >> (slot << 4))) { - printf (" No Card found\n"); - return (1); - } - - /* - * Power On. - */ - mask = PCMCIA_VS1(slot) | PCMCIA_VS2(slot); - reg = pcmp->pcmc_pipr; - debug ("PIPR: 0x%x ==> VS1=o%s, VS2=o%s\n", - reg, - (reg&PCMCIA_VS1(slot))?"n":"ff", - (reg&PCMCIA_VS2(slot))?"n":"ff"); - if ((reg & mask) == mask) { - immap->im_ioport.iop_pcdat &= ~(0x4000); - puts (" 5.0V card found: "); - } else { - immap->im_ioport.iop_padat &= ~(0x0002); - puts (" 3.3V card found: "); - } - immap->im_ioport.iop_pcdir |= 0x0400; - immap->im_ioport.iop_padir |= 0x0200; -#if 0 - /* VCC switch error flag, PCMCIA slot INPACK_ pin */ - cp->cp_pbdir &= ~(0x0020 | 0x0010); - cp->cp_pbpar &= ~(0x0020 | 0x0010); - udelay(500000); -#endif - debug ("Enable PCMCIA buffers and stop RESET\n"); - reg = PCMCIA_PGCRX(_slot_); - reg &= ~__MY_PCMCIA_GCRX_CXRESET; /* active high */ - reg &= ~__MY_PCMCIA_GCRX_CXOE; /* active low */ - PCMCIA_PGCRX(_slot_) = reg; - - udelay(250000); /* some cards need >150 ms to come up :-( */ - - debug ("# hardware_enable done\n"); - - return (0); -} - - -#if defined(CONFIG_CMD_PCMCIA) -int pcmcia_hardware_disable(int slot) -{ - volatile immap_t *immap; - u_long reg; - - debug ("hardware_disable: " PCMCIA_BOARD_MSG " Slot %c\n", 'A'+slot); - - immap = (immap_t *)CONFIG_SYS_IMMR; - - /* remove all power */ - immap->im_ioport.iop_pcdat |= 0x0400; - immap->im_ioport.iop_padat |= 0x0200; - - /* Configure PCMCIA General Control Register */ - debug ("Disable PCMCIA buffers and assert RESET\n"); - reg = 0; - reg |= __MY_PCMCIA_GCRX_CXRESET; /* active high */ - reg |= __MY_PCMCIA_GCRX_CXOE; /* active low */ - PCMCIA_PGCRX(_slot_) = reg; - - udelay(10000); - - return (0); -} -#endif - - -int pcmcia_voltage_set(int slot, int vcc, int vpp) -{ - volatile immap_t *immap; - volatile pcmconf8xx_t *pcmp; - u_long reg; - - debug ("voltage_set: " - PCMCIA_BOARD_MSG - " Slot %c, Vcc=%d.%d, Vpp=%d.%d\n", - 'A'+slot, vcc/10, vcc%10, vpp/10, vcc%10); - - immap = (immap_t *)CONFIG_SYS_IMMR; - pcmp = (pcmconf8xx_t *)(&(((immap_t *)CONFIG_SYS_IMMR)->im_pcmcia)); - /* - * Disable PCMCIA buffers (isolate the interface) - * and assert RESET signal - */ - debug ("Disable PCMCIA buffers and assert RESET\n"); - reg = PCMCIA_PGCRX(_slot_); - reg |= __MY_PCMCIA_GCRX_CXRESET; /* active high */ - reg |= __MY_PCMCIA_GCRX_CXOE; /* active low */ - PCMCIA_PGCRX(_slot_) = reg; - udelay(500); - - /* - * Configure Ports A & C pins for - * 5 Volts Enable and 3 Volts enable, - * Turn off all power - */ - debug ("PCMCIA power OFF\n"); - immap->im_ioport.iop_pcpar &= ~(0x0400); - immap->im_ioport.iop_pcso &= ~(0x0400);/* - immap->im_ioport.iop_pcdir |= 0x0400;*/ - - immap->im_ioport.iop_papar &= ~(0x0200);/* - immap->im_ioport.iop_padir |= 0x0200;*/ - - immap->im_ioport.iop_pcdat |= 0x0400; - immap->im_ioport.iop_padat |= 0x0200; - - reg = 0; - switch(vcc) { - case 0: break; - case 33: reg |= 0x0200; break; - case 50: reg |= 0x0400; break; - default: goto done; - } - - /* Checking supported voltages */ - - debug ("PIPR: 0x%x --> %s\n", - pcmp->pcmc_pipr, - (pcmp->pcmc_pipr & 0x00008000) ? "only 5 V" : "can do 3.3V"); - - if (reg & 0x0200) - immap->im_ioport.iop_pcdat &= !reg; - if (reg & 0x0400) - immap->im_ioport.iop_padat &= !reg; - immap->im_ioport.iop_pcdir |= 0x0200; - immap->im_ioport.iop_padir |= 0x0400; - if (reg) { - debug ("PCMCIA powered at %sV\n", - (reg&0x0400) ? "5.0" : "3.3"); - } else { - debug ("PCMCIA powered down\n"); - } - -done: - debug ("Enable PCMCIA buffers and stop RESET\n"); - reg = PCMCIA_PGCRX(_slot_); - reg &= ~__MY_PCMCIA_GCRX_CXRESET; /* active high */ - reg &= ~__MY_PCMCIA_GCRX_CXOE; /* active low */ - PCMCIA_PGCRX(_slot_) = reg; - udelay(500); - - debug ("voltage_set: " PCMCIA_BOARD_MSG " Slot %c, DONE\n", - slot+'A'); - return (0); -} - -#endif /* CCONFIG_PCMCIA */ diff --git a/board/r360mpi/r360mpi.c b/board/r360mpi/r360mpi.c deleted file mode 100644 index d06aea7..0000000 --- a/board/r360mpi/r360mpi.c +++ /dev/null @@ -1,403 +0,0 @@ -/* - * (C) Copyright 2001-2003 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <config.h> -#include <mpc8xx.h> -#include <i2c.h> - -#include <commproc.h> -#include <command.h> -#include <malloc.h> - -#include <linux/types.h> -#include <linux/string.h> /* for strdup */ - - -/* - * Memory Controller Using - * - * CS0 - Flash memory (0x40000000) - * CS1 - FLASH memory (0x????????) - * CS2 - SDRAM (0x00000000) - * CS3 - - * CS4 - - * CS5 - - * CS6 - PCMCIA device - * CS7 - PCMCIA device - */ - -/* ------------------------------------------------------------------------- */ - -#define _not_used_ 0xffffffff - -const uint sdram_table[]= -{ - /* single read. (offset 0 in upm RAM) */ - 0x1f07fc04, 0xeeaefc04, 0x11adfc04, 0xefbbbc00, - 0x1ff77c47, - - /* MRS initialization (offset 5) */ - - 0x1ff77c34, 0xefeabc34, 0x1fb57c35, - - /* burst read. (offset 8 in upm RAM) */ - 0x1f07fc04, 0xeeaefc04, 0x10adfc04, 0xf0affc00, - 0xf0affc00, 0xf1affc00, 0xefbbbc00, 0x1ff77c47, - _not_used_, _not_used_, _not_used_, _not_used_, - _not_used_, _not_used_, _not_used_, _not_used_, - - /* single write. (offset 18 in upm RAM) */ - 0x1f27fc04, 0xeeaebc00, 0x01b93c04, 0x1ff77c47, - _not_used_, _not_used_, _not_used_, _not_used_, - - /* burst write. (offset 20 in upm RAM) */ - 0x1f07fc04, 0xeeaebc00, 0x10ad7c00, 0xf0affc00, - 0xf0affc00, 0xe1bbbc04, 0x1ff77c47, _not_used_, - _not_used_, _not_used_, _not_used_, _not_used_, - _not_used_, _not_used_, _not_used_, _not_used_, - - /* refresh. (offset 30 in upm RAM) */ - 0x1ff5fc84, 0xfffffc04, 0xfffffc04, 0xfffffc04, - 0xfffffc84, 0xfffffc07, _not_used_, _not_used_, - _not_used_, _not_used_, _not_used_, _not_used_, - - /* exception. (offset 3c in upm RAM) */ - 0x7ffffc07, _not_used_, _not_used_, _not_used_ }; - -/* ------------------------------------------------------------------------- */ - -/* - * Check Board Identity: - */ - -int checkboard (void) -{ - puts ("Board: R360 MPI Board\n"); - return 0; -} - -/* ------------------------------------------------------------------------- */ - -static long int dram_size (long int, long int *, long int); - -/* ------------------------------------------------------------------------- */ - -phys_size_t initdram (int board_type) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - long int size8, size9; - long int size_b0 = 0; - unsigned long reg; - - upmconfig (UPMA, (uint *) sdram_table, - sizeof (sdram_table) / sizeof (uint)); - - /* - * Preliminary prescaler for refresh (depends on number of - * banks): This value is selected for four cycles every 62.4 us - * with two SDRAM banks or four cycles every 31.2 us with one - * bank. It will be adjusted after memory sizing. - */ - memctl->memc_mptpr = CONFIG_SYS_MPTPR_2BK_8K; - - memctl->memc_mar = 0x00000088; - - /* - * Map controller bank 2 to the SDRAM bank at - * preliminary address - these have to be modified after the - * SDRAM size has been determined. - */ - memctl->memc_or2 = CONFIG_SYS_OR2_PRELIM; - memctl->memc_br2 = CONFIG_SYS_BR2_PRELIM; - - memctl->memc_mamr = CONFIG_SYS_MAMR_8COL & (~(MAMR_PTAE)); /* no refresh yet */ - - udelay (200); - - /* perform SDRAM initializsation sequence */ - - memctl->memc_mcr = 0x80004105; /* SDRAM bank 0 */ - udelay (200); - memctl->memc_mcr = 0x80004230; /* SDRAM bank 0 - execute twice */ - udelay (200); - - memctl->memc_mamr |= MAMR_PTAE; /* enable refresh */ - - udelay (1000); - - /* - * Check Bank 2 Memory Size for re-configuration - * - * try 8 column mode - */ - size8 = dram_size (CONFIG_SYS_MAMR_8COL, (long *) SDRAM_BASE2_PRELIM, - SDRAM_MAX_SIZE); - - udelay (1000); - - /* - * try 9 column mode - */ - size9 = dram_size (CONFIG_SYS_MAMR_9COL, (long *) SDRAM_BASE2_PRELIM, - SDRAM_MAX_SIZE); - - if (size8 < size9) { /* leave configuration at 9 columns */ - size_b0 = size9; -/* debug ("SDRAM Bank 0 in 9 column mode: %ld MB\n", size >> 20); */ - } else { /* back to 8 columns */ - size_b0 = size8; - memctl->memc_mamr = CONFIG_SYS_MAMR_8COL; - udelay (500); -/* debug ("SDRAM Bank 0 in 8 column mode: %ld MB\n", size >> 20); */ - } - - udelay (1000); - - /* - * Adjust refresh rate depending on SDRAM type, both banks - * For types > 128 MBit leave it at the current (fast) rate - */ - if ((size_b0 < 0x02000000)) { - /* reduce to 15.6 us (62.4 us / quad) */ - memctl->memc_mptpr = CONFIG_SYS_MPTPR_2BK_4K; - udelay (1000); - } - - /* - * Final mapping - */ - - memctl->memc_or1 = ((-size_b0) & 0xFFFF0000) | CONFIG_SYS_OR_TIMING_SDRAM; - memctl->memc_br1 = (CONFIG_SYS_SDRAM_BASE & BR_BA_MSK) | BR_MS_UPMA | BR_V; - - /* adjust refresh rate depending on SDRAM type, one bank */ - reg = memctl->memc_mptpr; - reg >>= 1; /* reduce to CONFIG_SYS_MPTPR_1BK_8K / _4K */ - memctl->memc_mptpr = reg; - - udelay (10000); - -#ifdef CONFIG_CAN_DRIVER - /* Initialize OR3 / BR3 */ - memctl->memc_or3 = CONFIG_SYS_OR3_CAN; /* switch GPLB_5 to GPLA_5 */ - memctl->memc_br3 = CONFIG_SYS_BR3_CAN; - - /* Initialize MBMR */ - memctl->memc_mbmr = MBMR_GPL_B4DIS; /* GPL_B4 works as UPWAITB */ - - /* Initialize UPMB for CAN: single read */ - memctl->memc_mdr = 0xFFFFC004; - memctl->memc_mcr = 0x0100 | UPMB; - - memctl->memc_mdr = 0x0FFFD004; - memctl->memc_mcr = 0x0101 | UPMB; - - memctl->memc_mdr = 0x0FFFC000; - memctl->memc_mcr = 0x0102 | UPMB; - - memctl->memc_mdr = 0x3FFFC004; - memctl->memc_mcr = 0x0103 | UPMB; - - memctl->memc_mdr = 0xFFFFDC05; - memctl->memc_mcr = 0x0104 | UPMB; - - /* Initialize UPMB for CAN: single write */ - memctl->memc_mdr = 0xFFFCC004; - memctl->memc_mcr = 0x0118 | UPMB; - - memctl->memc_mdr = 0xCFFCD004; - memctl->memc_mcr = 0x0119 | UPMB; - - memctl->memc_mdr = 0x0FFCC000; - memctl->memc_mcr = 0x011A | UPMB; - - memctl->memc_mdr = 0x7FFCC004; - memctl->memc_mcr = 0x011B | UPMB; - - memctl->memc_mdr = 0xFFFDCC05; - memctl->memc_mcr = 0x011C | UPMB; -#endif - - return (size_b0); -} - -/* ------------------------------------------------------------------------- */ - -/* - * Check memory range for valid RAM. A simple memory test determines - * the actually available RAM size between addresses `base' and - * `base + maxsize'. Some (not all) hardware errors are detected: - * - short between address lines - * - short between data lines - */ - -static long int dram_size (long int mamr_value, - long int *base, long int maxsize) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - - memctl->memc_mamr = mamr_value; - - return (get_ram_size(base, maxsize)); -} - -/* ------------------------------------------------------------------------- */ - -void r360_i2c_lcd_write (uchar data0, uchar data1) -{ - if (i2c_write (CONFIG_SYS_I2C_LCD_ADDR, data0, 1, &data1, 1)) { - printf("Can't write lcd data 0x%02X 0x%02X.\n", data0, data1); - } -} - -/* ------------------------------------------------------------------------- */ - -/*----------------------------------------------------------------------- - * Keyboard Controller - */ - -/* Number of bytes returned from Keyboard Controller */ -#define KEYBD_KEY_MAX 16 /* maximum key number */ -#define KEYBD_DATALEN ((KEYBD_KEY_MAX + 7) / 8) /* normal key scan data */ - -static uchar *key_match (uchar *); - -int misc_init_r (void) -{ - char kbd_data[KEYBD_DATALEN]; - char keybd_env[2 * KEYBD_DATALEN + 1]; - char *str; - int i; - - i2c_init (CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); - - i2c_read (CONFIG_SYS_I2C_KEY_ADDR, 0, 0, (uchar *)kbd_data, KEYBD_DATALEN); - - for (i = 0; i < KEYBD_DATALEN; ++i) { - sprintf (keybd_env + i + i, "%02X", kbd_data[i]); - } - setenv ("keybd", keybd_env); - - str = strdup ((char *)key_match ((uchar *)keybd_env)); /* decode keys */ - -#ifdef CONFIG_PREBOOT /* automatically configure "preboot" command on key match */ - setenv ("preboot", str); /* set or delete definition */ -#endif /* CONFIG_PREBOOT */ - if (str != NULL) { - free (str); - } - - return (0); -} - -/*----------------------------------------------------------------------- - * Check if pressed key(s) match magic sequence, - * and return the command string associated with that key(s). - * - * If no key press was decoded, NULL is returned. - * - * Note: the first character of the argument will be overwritten with - * the "magic charcter code" of the decoded key(s), or '\0'. - * - * - * Note: the string points to static environment data and must be - * saved before you call any function that modifies the environment. - */ -#ifdef CONFIG_PREBOOT - -static uchar kbd_magic_prefix[] = "key_magic"; -static uchar kbd_command_prefix[] = "key_cmd"; - -static uchar *key_match (uchar * kbd_str) -{ - uchar magic[sizeof (kbd_magic_prefix) + 1]; - uchar cmd_name[sizeof (kbd_command_prefix) + 1]; - uchar *str, *suffix; - uchar *kbd_magic_keys; - char *cmd; - - /* - * The following string defines the characters that can pe appended - * to "key_magic" to form the names of environment variables that - * hold "magic" key codes, i. e. such key codes that can cause - * pre-boot actions. If the string is empty (""), then only - * "key_magic" is checked (old behaviour); the string "125" causes - * checks for "key_magic1", "key_magic2" and "key_magic5", etc. - */ - if ((kbd_magic_keys = (uchar *)getenv ("magic_keys")) != NULL) { - /* loop over all magic keys; - * use '\0' suffix in case of empty string - */ - for (suffix = kbd_magic_keys; - *suffix || suffix == kbd_magic_keys; - ++suffix) { - sprintf ((char *)magic, "%s%c", kbd_magic_prefix, *suffix); - -#if 0 - printf ("### Check magic "%s"\n", magic); -#endif - - if ((str = (uchar *)getenv ((char *)magic)) != 0) { - -#if 0 - printf ("### Compare "%s" "%s"\n", - kbd_str, str); -#endif - if (strcmp ((char *)kbd_str, (char *)str) == 0) { - sprintf ((char *)cmd_name, "%s%c", - kbd_command_prefix, - *suffix); - - if ((cmd = getenv ((char *)cmd_name)) != 0) { -#if 0 - printf ("### Set PREBOOT to $(%s): "%s"\n", - cmd_name, cmd); -#endif - return ((uchar *)cmd); - } - } - } - } - } -#if 0 - printf ("### Delete PREBOOT\n"); -#endif - *kbd_str = '\0'; - return (NULL); -} -#endif /* CONFIG_PREBOOT */ - -/* Read Keyboard status */ -int do_kbd (cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) -{ - uchar kbd_data[KEYBD_DATALEN]; - uchar keybd_env[2 * KEYBD_DATALEN + 1]; - int i; - - i2c_init (CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); - - /* Read keys */ - i2c_read (CONFIG_SYS_I2C_KEY_ADDR, 0, 0, kbd_data, KEYBD_DATALEN); - - puts ("Keys:"); - for (i = 0; i < KEYBD_DATALEN; ++i) { - sprintf ((char *)(keybd_env + i + i), "%02X", kbd_data[i]); - printf (" %02x", kbd_data[i]); - } - putc ('\n'); - setenv ("keybd", (char *)keybd_env); - return 0; -} - -U_BOOT_CMD( - kbd, 1, 1, do_kbd, - "read keyboard status", - "" -); diff --git a/board/r360mpi/u-boot.lds b/board/r360mpi/u-boot.lds deleted file mode 100644 index 5f69bc4..0000000 --- a/board/r360mpi/u-boot.lds +++ /dev/null @@ -1,89 +0,0 @@ -/* - * (C) Copyright 2000-2010 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -OUTPUT_ARCH(powerpc) - -SECTIONS -{ - /* Read-only sections, merged into text segment: */ - . = + SIZEOF_HEADERS; - .text : - { - /* WARNING - the following is hand-optimized to fit within */ - /* the sector layout of our flash chips! XXX FIXME XXX */ - arch/powerpc/cpu/mpc8xx/start.o (.text*) - arch/powerpc/cpu/mpc8xx/traps.o (.text*) - - *(.text*) - } - _etext = .; - PROVIDE (etext = .); - .rodata : - { - *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) - } - - /* Read-write section, merged into data segment: */ - . = (. + 0x00FF) & 0xFFFFFF00; - _erotext = .; - PROVIDE (erotext = .); - .reloc : - { - _GOT2_TABLE_ = .; - KEEP(*(.got2)) - KEEP(*(.got)) - PROVIDE(_GLOBAL_OFFSET_TABLE_ = . + 4); - _FIXUP_TABLE_ = .; - KEEP(*(.fixup)) - } - __got2_entries = ((_GLOBAL_OFFSET_TABLE_ - _GOT2_TABLE_) >> 2) - 1; - __fixup_entries = (. - _FIXUP_TABLE_)>>2; - - .data : - { - *(.data*) - *(.sdata*) - } - _edata = .; - PROVIDE (edata = .); - - . = .; - - . = ALIGN(4); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); - } - - - . = .; - __start___ex_table = .; - __ex_table : { *(__ex_table) } - __stop___ex_table = .; - - . = ALIGN(256); - __init_begin = .; - .text.init : { *(.text.init) } - .data.init : { *(.data.init) } - . = ALIGN(256); - __init_end = .; - - __bss_start = .; - .bss (NOLOAD) : - { - *(.bss*) - *(.sbss*) - *(COMMON) - . = ALIGN(4); - } - __bss_end = . ; - PROVIDE (end = .); - . = ALIGN(128 * 1024); - .ppcenv : - { - common/env_embedded.o (.ppcenv) - } -} diff --git a/configs/R360MPI_defconfig b/configs/R360MPI_defconfig deleted file mode 100644 index 290f694..0000000 --- a/configs/R360MPI_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_R360MPI=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 00a5447..1e475af 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,7 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +R360MPI powerpc mpc8xx - - Wolfgang Denk wd@denx.de RRvision powerpc mpc8xx - - Wolfgang Denk wd@denx.de SPD823TS powerpc mpc8xx - - Wolfgang Denk wd@denx.de KUP4K powerpc mpc8xx - - Klaus Heydeck heydeck@kieback-peter.de diff --git a/drivers/video/mpc8xx_lcd.c b/drivers/video/mpc8xx_lcd.c index a5c1e19..336788f 100644 --- a/drivers/video/mpc8xx_lcd.c +++ b/drivers/video/mpc8xx_lcd.c @@ -423,31 +423,6 @@ void lcd_enable (void) pic_write (0x60, c); } #endif /* CONFIG_LWMON */ - -#if defined(CONFIG_R360MPI) - { - extern void r360_i2c_lcd_write (uchar data0, uchar data1); - unsigned long bgi, ctr; - char *p; - - if ((p = getenv("lcdbgi")) != NULL) { - bgi = simple_strtoul (p, 0, 10) & 0xFFF; - } else { - bgi = 0xFFF; - } - - if ((p = getenv("lcdctr")) != NULL) { - ctr = simple_strtoul (p, 0, 10) & 0xFFF; - } else { - ctr=0x7FF; - } - - r360_i2c_lcd_write(0x10, 0x01); - r360_i2c_lcd_write(0x20, 0x01); - r360_i2c_lcd_write(0x30 | ((bgi>>8) & 0xF), bgi & 0xFF); - r360_i2c_lcd_write(0x40 | ((ctr>>8) & 0xF), ctr & 0xFF); - } -#endif /* CONFIG_R360MPI */ }
/************************************************************************/ diff --git a/include/commproc.h b/include/commproc.h index 7d62861..38e4e7d 100644 --- a/include/commproc.h +++ b/include/commproc.h @@ -630,7 +630,6 @@ typedef struct scc_enet { /*** MVS1, TQM823L/M, TQM850L/M, TQM885D, R360MPI **********/
#if (defined(CONFIG_MVS) && CONFIG_MVS < 2) || \ - defined(CONFIG_R360MPI) || \ defined(CONFIG_TQM823L) || \ defined(CONFIG_TQM823M) || defined(CONFIG_TQM850L) || \ defined(CONFIG_TQM850M) || defined(CONFIG_TQM885D) @@ -650,9 +649,6 @@ typedef struct scc_enet {
#define PC_ENET_CLSN ((ushort)0x0040) /* PC 9 */ #define PC_ENET_RENA ((ushort)0x0080) /* PC 8 */ -#if defined(CONFIG_R360MPI) -#define PC_ENET_LBK ((ushort)0x0008) /* PC 12 */ -#endif /* CONFIG_R360MPI */
/* Control bits in the SICR to route TCLK (CLK3) and RCLK (CLK1) to * SCC2. Also, make sure GR2 (bit 16) and SC2 (bit 17) are zero. diff --git a/include/configs/R360MPI.h b/include/configs/R360MPI.h deleted file mode 100644 index 009d1cf..0000000 --- a/include/configs/R360MPI.h +++ /dev/null @@ -1,464 +0,0 @@ -/* - * (C) Copyright 2000-2005 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC823 1 /* This is a MPC823 CPU */ -#define CONFIG_R360MPI 1 - -#define CONFIG_SYS_TEXT_BASE 0x40000000 - -#define CONFIG_LCD -#define CONFIG_MPC8XX_LCD -#undef CONFIG_EDT32F10 -#define CONFIG_SHARP_LQ057Q3DC02 - -#define CONFIG_SPLASH_SCREEN - -#define MPC8XX_FACT 1 /* Multiply by 1 */ -#define MPC8XX_XIN 50000000 /* 50 MHz in */ -#define CONFIG_8xx_GCLK_FREQ 50000000 /* define if can't use get_gclk_freq */ - -#define CONFIG_8xx_CONS_SMC1 1 /* Console is on SMC1 */ -#undef CONFIG_8xx_CONS_SMC2 -#undef CONFIG_8xx_CONS_NONE -#define CONFIG_BAUDRATE 115200 /* console baudrate in bps */ -#if 0 -#define CONFIG_BOOTDELAY 0 /* immediate boot */ -#else -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ -#endif - -#define CONFIG_CLOCKS_IN_MHZ 1 /* clocks passsed to Linux in MHz */ - -#define CONFIG_PREBOOT "echo;echo Type \"run flash_nfs\" to mount root filesystem over NFS;echo" - -#undef CONFIG_BOOTARGS -#define CONFIG_BOOTCOMMAND \ - "bootp; " \ - "setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off; " \ - "bootm" - -#undef CONFIG_SCC1_ENET -#define CONFIG_SCC2_ENET - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ - -#define CONFIG_MISC_INIT_R /* have misc_init_r() function */ - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -#define CONFIG_CAN_DRIVER /* CAN Driver support enabled */ - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE - -#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - -#define CONFIG_RTC_MPC8xx /* use internal RTC of MPC8xx */ - -#define CONFIG_HARD_I2C 1 /* To I2C with hardware support */ -#undef CONFIG_SYS_I2C_SOFT /* To I2C with software support */ -#define CONFIG_SYS_I2C_SPEED 4700 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_SLAVE 0x7F - -#if defined(CONFIG_SYS_I2C_SOFT) -#define CONFIG_SYS_SYS_I2C_SOFT_SPEED 4700 /* I2C speed and slave address */ -#define CONFIG_SYS_SYS_I2C_SOFT_SLAVE 0x7F -/* - * Software (bit-bang) I2C driver configuration - */ -#define PB_SCL 0x00000020 /* PB 26 */ -#define PB_SDA 0x00000010 /* PB 27 */ - -#define I2C_INIT (immr->im_cpm.cp_pbdir |= PB_SCL) -#define I2C_ACTIVE (immr->im_cpm.cp_pbdir |= PB_SDA) -#define I2C_TRISTATE (immr->im_cpm.cp_pbdir &= ~PB_SDA) -#define I2C_READ ((immr->im_cpm.cp_pbdat & PB_SDA) != 0) -#define I2C_SDA(bit) if(bit) immr->im_cpm.cp_pbdat |= PB_SDA; \ - else immr->im_cpm.cp_pbdat &= ~PB_SDA -#define I2C_SCL(bit) if(bit) immr->im_cpm.cp_pbdat |= PB_SCL; \ - else immr->im_cpm.cp_pbdat &= ~PB_SCL -#define I2C_DELAY udelay(50) -#endif /* #define(CONFIG_SYS_I2C_SOFT) */ - -#define CONFIG_SYS_I2C_LCD_ADDR 0x8 /* LCD Control */ -#define CONFIG_SYS_I2C_KEY_ADDR 0x9 /* Keyboard coprocessor */ -#define CONFIG_SYS_I2C_TEM_ADDR 0x49 /* Temperature Sensors */ - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_BMP -#define CONFIG_CMD_BSP -#define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_I2C -#define CONFIG_CMD_IDE -#define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_NFS -#define CONFIG_CMD_PCMCIA -#define CONFIG_CMD_SNTP - - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_DEVICE_NULLDEV 1 /* we need the null device */ -#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 /* must set console from env */ - -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -/* - * JFFS2 partitions - */ -/* No command line, one static partition - * use all the space starting at offset 3MB*/ -#undef CONFIG_CMD_MTDPARTS -#define CONFIG_JFFS2_DEV "nor0" -#define CONFIG_JFFS2_PART_SIZE 0xFFFFFFFF -#define CONFIG_JFFS2_PART_OFFSET 0x00300000 - -/* mtdparts command line support */ -/* -#define CONFIG_CMD_MTDPARTS -#define MTDIDS_DEFAULT "nor0=r360-0" -#define MTDPARTS_DEFAULT "mtdparts=r360-0:-@3m(user)" -*/ - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xFF000000 - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0x40000000 -#if defined(DEBUG) -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#else -#define CONFIG_SYS_MONITOR_LEN (192 << 10) /* Reserve 192 kB for Monitor */ -#endif -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 128 /* max number of sectors on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ - -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_OFFSET 0x40000 /* Offset of Environment */ -#define CONFIG_ENV_SECT_SIZE 0x20000 /* Total Size of Environment sector */ -#define CONFIG_ENV_SIZE 0x4000 /* Used Size of Environment sector */ -#define CONFIG_SYS_USE_PPCENV /* Environment embedded in sect .ppcenv */ - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CACHELINE_SHIFT 4 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 11-9 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Software & Bus Monitor Timer max, Bus Monitor enable, SW Watchdog freeze - */ -#if defined(CONFIG_WATCHDOG) -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | \ - SYPCR_SWE | SYPCR_SWRI| SYPCR_SWP) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | SYPCR_SWP) -#endif - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 11-6 - *----------------------------------------------------------------------- - * PCMCIA config., multi-function pin tri-state - */ -#define CONFIG_SYS_SIUMCR (SIUMCR_DBGC00 | SIUMCR_DBPC00 | SIUMCR_MLRC01) - -/*----------------------------------------------------------------------- - * TBSCR - Time Base Status and Control 11-26 - *----------------------------------------------------------------------- - * Clear Reference Interrupt Status, Timebase freezing enabled - */ -#define CONFIG_SYS_TBSCR (TBSCR_REFA | TBSCR_REFB | TBSCR_TBE) - -/*----------------------------------------------------------------------- - * RTCSC - Real-Time Clock Status and Control Register 11-27 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RTCSC (RTCSC_SEC | RTCSC_ALR | RTCSC_RTF| RTCSC_RTE) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 11-31 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Interrupt Timer freezing enabled - */ -#define CONFIG_SYS_PISCR (PISCR_PS | PISCR_PITF) - -/*----------------------------------------------------------------------- - * PLPRCR - PLL, Low-Power, and Reset Control Register 15-30 - *----------------------------------------------------------------------- - * Reset PLL lock status sticky bit, timer expired status bit and timer - * interrupt status bit - * - * If this is a 80 MHz CPU, set PLL multiplication factor to 5 (5*16=80)! - */ -#ifdef CONFIG_80MHz /* for 80 MHz, we use a 16 MHz clock * 5 */ -#define CONFIG_SYS_PLPRCR \ - ( (5-1)<<PLPRCR_MF_SHIFT | PLPRCR_TEXPS | PLPRCR_TMIST ) -#else /* up to 50 MHz we use a 1:1 clock */ -#define CONFIG_SYS_PLPRCR (PLPRCR_SPLSS | PLPRCR_TEXPS | PLPRCR_TMIST) -#endif /* CONFIG_80MHz */ - -/*----------------------------------------------------------------------- - * SCCR - System Clock and reset Control Register 15-27 - *----------------------------------------------------------------------- - * Set clock output, timebase and RTC source and divider, - * power management and some other internal clocks - */ -#define SCCR_MASK SCCR_EBDF11 -#define CONFIG_SYS_SCCR (SCCR_TBS | \ - SCCR_COM00 | SCCR_DFSYNC00 | SCCR_DFBRG00 | \ - SCCR_DFNL000 | SCCR_DFNH000 | SCCR_DFLCD000 | \ - SCCR_DFALCD00) - -/*----------------------------------------------------------------------- - * PCMCIA stuff - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_PCMCIA_MEM_ADDR (0xE0000000) -#define CONFIG_SYS_PCMCIA_MEM_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_DMA_ADDR (0xE4000000) -#define CONFIG_SYS_PCMCIA_DMA_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_ATTRB_ADDR (0xE8000000) -#define CONFIG_SYS_PCMCIA_ATTRB_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_IO_ADDR (0xEC000000) -#define CONFIG_SYS_PCMCIA_IO_SIZE ( 64 << 20 ) - -/*----------------------------------------------------------------------- - * IDE/ATA stuff (Supports IDE harddisk on PCMCIA Adapter) - *----------------------------------------------------------------------- - */ - -#if 1 -#define CONFIG_IDE_PREINIT 1 /* Use preinit IDE hook */ -#define CONFIG_IDE_8xx_PCCARD 1 /* Use IDE with PC Card Adapter */ - -#undef CONFIG_IDE_8xx_DIRECT /* Direct IDE not supported */ -#undef CONFIG_IDE_LED /* LED for ide not supported */ -#undef CONFIG_IDE_RESET /* reset for ide not supported */ - -#define CONFIG_SYS_IDE_MAXBUS 1 /* max. 1 IDE bus */ -#define CONFIG_SYS_IDE_MAXDEVICE 1 /* max. 1 drive per IDE bus */ - -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 - -#define CONFIG_SYS_ATA_BASE_ADDR CONFIG_SYS_PCMCIA_MEM_ADDR - -/* Offset for data I/O */ -#define CONFIG_SYS_ATA_DATA_OFFSET (CONFIG_SYS_PCMCIA_MEM_SIZE + 0x320) - -/* Offset for normal register accesses */ -#define CONFIG_SYS_ATA_REG_OFFSET (2 * CONFIG_SYS_PCMCIA_MEM_SIZE + 0x320) - -/* Offset for alternate registers */ -#define CONFIG_SYS_ATA_ALT_OFFSET 0x0100 -#endif - -/*----------------------------------------------------------------------- - * - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_DER 0 - -/* - * Init Memory Controller: - * - * BR0/1 and OR0/1 (FLASH) - */ - -#define FLASH_BASE0_PRELIM 0x40000000 /* FLASH bank #0 */ - -/* used to re-map FLASH both when starting from SRAM or FLASH: - * restrict access enough to keep SRAM working (if any) - * but not too much to meddle with FLASH accesses - */ -#define CONFIG_SYS_REMAP_OR_AM 0x80000000 /* OR addr mask */ -#define CONFIG_SYS_PRELIM_OR_AM 0xFF000000 /* OR addr mask */ - -/* - * FLASH timing: - */ -#define CONFIG_SYS_OR_TIMING_FLASH (OR_ACS_DIV1 | OR_SCY_7_CLK | OR_BI) - -#define CONFIG_SYS_OR0_REMAP (CONFIG_SYS_REMAP_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_BR0_PRELIM ((FLASH_BASE0_PRELIM & BR_BA_MSK) | BR_PS_16 | BR_V ) - - -/* - * BR2 and OR2 (SDRAM) - * - */ -#define SDRAM_BASE2_PRELIM 0x00000000 /* SDRAM bank #0 */ -#define SDRAM_MAX_SIZE 0x04000000 /* max 64 MB per bank */ - -#define CONFIG_SYS_PRELIM_OR2_AM 0xF8000000 /* OR addr mask */ - -/* SDRAM timing: Multiplexed addresses, GPL5 output to GPL5_A (don't care) */ -#define CONFIG_SYS_OR_TIMING_SDRAM (OR_ACS_DIV1 | OR_CSNT_SAM | \ - OR_SCY_0_CLK | OR_G5LS) - -#define CONFIG_SYS_OR2_PRELIM (CONFIG_SYS_PRELIM_OR2_AM | CONFIG_SYS_OR_TIMING_SDRAM ) -#define CONFIG_SYS_BR2_PRELIM ((SDRAM_BASE2_PRELIM & BR_BA_MSK) | BR_MS_UPMA | BR_V ) - -/* - * BR3 and OR3 (CAN Controller) - */ -#ifdef CONFIG_CAN_DRIVER -#define CONFIG_SYS_CAN_BASE 0xC0000000 /* CAN base address */ -#define CONFIG_SYS_CAN_OR_AM 0xFFFF8000 /* 32 kB address mask */ -#define CONFIG_SYS_OR3_CAN (CONFIG_SYS_CAN_OR_AM | OR_G5LA |OR_BI) -#define CONFIG_SYS_BR3_CAN ((CONFIG_SYS_CAN_BASE & BR_BA_MSK) | \ - BR_PS_8 | BR_MS_UPMB | BR_V) -#endif /* CONFIG_CAN_DRIVER */ - - -/* - * Memory Periodic Timer Prescaler - * - * The Divider for PTA (refresh timer) configuration is based on an - * example SDRAM configuration (64 MBit, one bank). The adjustment to - * the number of chip selects (NCS) and the actually needed refresh - * rate is done by setting MPTPR. - * - * PTA is calculated from - * PTA = (gclk * Trefresh) / ((2 ^ (2 * DFBRG)) * PTP * NCS) - * - * gclk CPU clock (not bus clock!) - * Trefresh Refresh cycle * 4 (four word bursts used) - * - * 4096 Rows from SDRAM example configuration - * 1000 factor s -> ms - * 32 PTP (pre-divider from MPTPR) from SDRAM example configuration - * 4 Number of refresh cycles per period - * 64 Refresh cycle in ms per number of rows - * -------------------------------------------- - * Divider = 4096 * 32 * 1000 / (4 * 64) = 512000 - * - * 50 MHz => 50.000.000 / Divider = 98 - * 66 Mhz => 66.000.000 / Divider = 129 - * 80 Mhz => 80.000.000 / Divider = 156 - */ -#if defined(CONFIG_80MHz) -#define CONFIG_SYS_MAMR_PTA 156 -#elif defined(CONFIG_66MHz) -#define CONFIG_SYS_MAMR_PTA 129 -#else /* 50 MHz */ -#define CONFIG_SYS_MAMR_PTA 98 -#endif /*CONFIG_??MHz */ - -/* - * For 16 MBit, refresh rates could be 31.3 us - * (= 64 ms / 2K = 125 / quad bursts). - * For a simpler initialization, 15.6 us is used instead. - * - * #define CONFIG_SYS_MPTPR_2BK_2K MPTPR_PTP_DIV32 for 2 banks - * #define CONFIG_SYS_MPTPR_1BK_2K MPTPR_PTP_DIV64 for 1 bank - */ -#define CONFIG_SYS_MPTPR_2BK_4K MPTPR_PTP_DIV16 /* setting for 2 banks */ -#define CONFIG_SYS_MPTPR_1BK_4K MPTPR_PTP_DIV32 /* setting for 1 bank */ - -/* refresh rate 7.8 us (= 64 ms / 8K = 31.2 / quad bursts) for 256 MBit */ -#define CONFIG_SYS_MPTPR_2BK_8K MPTPR_PTP_DIV8 /* setting for 2 banks */ -#define CONFIG_SYS_MPTPR_1BK_8K MPTPR_PTP_DIV16 /* setting for 1 bank */ - -/* - * MAMR settings for SDRAM - */ - -/* 8 column SDRAM */ -#define CONFIG_SYS_MAMR_8COL ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_0 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A11 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) -/* 9 column SDRAM */ -#define CONFIG_SYS_MAMR_9COL ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_1 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A10 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) - -#endif /* __CONFIG_H */ diff --git a/include/pcmcia.h b/include/pcmcia.h index 371c9a4..7e495bc 100644 --- a/include/pcmcia.h +++ b/include/pcmcia.h @@ -27,8 +27,6 @@ # define CONFIG_PCMCIA_SLOT_A #elif defined(CONFIG_LWMON) /* The LWMON use SLOT_B */ # define CONFIG_PCMCIA_SLOT_B -#elif defined(CONFIG_R360MPI) /* The R360MPI use SLOT_B */ -# define CONFIG_PCMCIA_SLOT_B #elif defined(CONFIG_ATC) /* The ATC use SLOT_A */ # define CONFIG_PCMCIA_SLOT_A #else
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Pantelis Antoniou panto@intracom.gr ---
arch/powerpc/cpu/mpc8xx/Kconfig | 4 - arch/powerpc/cpu/mpc8xx/scc.c | 20 -- board/netvia/Kconfig | 9 - board/netvia/MAINTAINERS | 7 - board/netvia/Makefile | 8 - board/netvia/flash.c | 495 ---------------------------------------- board/netvia/netvia.c | 401 -------------------------------- board/netvia/u-boot.lds.debug | 121 ---------- configs/NETVIA_V2_defconfig | 4 - configs/NETVIA_defconfig | 4 - doc/README.scrapyard | 1 + include/commproc.h | 33 --- include/configs/NETVIA.h | 435 ----------------------------------- include/status_led.h | 23 -- 14 files changed, 1 insertion(+), 1564 deletions(-) delete mode 100644 board/netvia/Kconfig delete mode 100644 board/netvia/MAINTAINERS delete mode 100644 board/netvia/Makefile delete mode 100644 board/netvia/flash.c delete mode 100644 board/netvia/netvia.c delete mode 100644 board/netvia/u-boot.lds.debug delete mode 100644 configs/NETVIA_V2_defconfig delete mode 100644 configs/NETVIA_defconfig delete mode 100644 include/configs/NETVIA.h
diff --git a/arch/powerpc/cpu/mpc8xx/Kconfig b/arch/powerpc/cpu/mpc8xx/Kconfig index 4e67ff2..b510e1f 100644 --- a/arch/powerpc/cpu/mpc8xx/Kconfig +++ b/arch/powerpc/cpu/mpc8xx/Kconfig @@ -25,9 +25,6 @@ config TARGET_IVMS8 config TARGET_LWMON bool "Support lwmon"
-config TARGET_NETVIA - bool "Support NETVIA" - config TARGET_TQM823L bool "Support TQM823L"
@@ -71,7 +68,6 @@ source "board/esteem192e/Kconfig" source "board/ip860/Kconfig" source "board/ivm/Kconfig" source "board/lwmon/Kconfig" -source "board/netvia/Kconfig" source "board/tqc/tqm8xx/Kconfig"
endmenu diff --git a/arch/powerpc/cpu/mpc8xx/scc.c b/arch/powerpc/cpu/mpc8xx/scc.c index 01029ff..610fd78 100644 --- a/arch/powerpc/cpu/mpc8xx/scc.c +++ b/arch/powerpc/cpu/mpc8xx/scc.c @@ -448,26 +448,6 @@ static int scc_init (struct eth_device *dev, bd_t * bis) #error Configuration Error: exactly ONE of PB_ENET_TENA, PC_ENET_TENA must be defined #endif
-#if defined(CONFIG_NETVIA) -#if defined(PA_ENET_PDN) - immr->im_ioport.iop_papar &= ~PA_ENET_PDN; - immr->im_ioport.iop_padir |= PA_ENET_PDN; - immr->im_ioport.iop_padat |= PA_ENET_PDN; -#elif defined(PB_ENET_PDN) - immr->im_cpm.cp_pbpar &= ~PB_ENET_PDN; - immr->im_cpm.cp_pbdir |= PB_ENET_PDN; - immr->im_cpm.cp_pbdat |= PB_ENET_PDN; -#elif defined(PC_ENET_PDN) - immr->im_ioport.iop_pcpar &= ~PC_ENET_PDN; - immr->im_ioport.iop_pcdir |= PC_ENET_PDN; - immr->im_ioport.iop_pcdat |= PC_ENET_PDN; -#elif defined(PD_ENET_PDN) - immr->im_ioport.iop_pdpar &= ~PD_ENET_PDN; - immr->im_ioport.iop_pddir |= PD_ENET_PDN; - immr->im_ioport.iop_pddat |= PD_ENET_PDN; -#endif -#endif - /* * Set the ENT/ENR bits in the GSMR Low -- Enable Transmit/Receive */ diff --git a/board/netvia/Kconfig b/board/netvia/Kconfig deleted file mode 100644 index 3e740e5..0000000 --- a/board/netvia/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_NETVIA - -config SYS_BOARD - default "netvia" - -config SYS_CONFIG_NAME - default "NETVIA" - -endif diff --git a/board/netvia/MAINTAINERS b/board/netvia/MAINTAINERS deleted file mode 100644 index 0313058..0000000 --- a/board/netvia/MAINTAINERS +++ /dev/null @@ -1,7 +0,0 @@ -NETVIA BOARD -M: Pantelis Antoniou panto@intracom.gr -S: Maintained -F: board/netvia/ -F: include/configs/NETVIA.h -F: configs/NETVIA_defconfig -F: configs/NETVIA_V2_defconfig diff --git a/board/netvia/Makefile b/board/netvia/Makefile deleted file mode 100644 index b667bc9..0000000 --- a/board/netvia/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = netvia.o flash.o diff --git a/board/netvia/flash.c b/board/netvia/flash.c deleted file mode 100644 index 14888f8..0000000 --- a/board/netvia/flash.c +++ /dev/null @@ -1,495 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc8xx.h> - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH chips */ - -/*----------------------------------------------------------------------- - * Functions - */ -static ulong flash_get_size(vu_long * addr, flash_info_t * info); -static int write_byte(flash_info_t * info, ulong dest, uchar data); -static void flash_get_offsets(ulong base, flash_info_t * info); - -/*----------------------------------------------------------------------- - */ - -unsigned long flash_init(void) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - unsigned long size; - int i; - - /* Init: no FLASHes known */ - for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; ++i) - flash_info[i].flash_id = FLASH_UNKNOWN; - - size = flash_get_size((vu_long *) FLASH_BASE0_PRELIM, &flash_info[0]); - - if (flash_info[0].flash_id == FLASH_UNKNOWN) { - printf("## Unknown FLASH on Bank 0 - Size = 0x%08lx = %ld MB\n", size, size << 20); - } - - /* Remap FLASH according to real size */ - memctl->memc_or0 = CONFIG_SYS_OR_TIMING_FLASH | (-size & 0xFFFF8000); - memctl->memc_br0 = (CONFIG_SYS_FLASH_BASE & BR_BA_MSK) | (memctl->memc_br0 & ~(BR_BA_MSK)); - - /* Re-do sizing to get full correct info */ - size = flash_get_size((vu_long *) CONFIG_SYS_FLASH_BASE, &flash_info[0]); - - flash_get_offsets(CONFIG_SYS_FLASH_BASE, &flash_info[0]); - - /* monitor protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE + monitor_flash_len - 1, - &flash_info[0]); - - flash_protect ( FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE - 1, - &flash_info[0]); - -#ifdef CONFIG_ENV_ADDR_REDUND - flash_protect ( FLAG_PROTECT_SET, - CONFIG_ENV_ADDR_REDUND, - CONFIG_ENV_ADDR_REDUND + CONFIG_ENV_SECT_SIZE - 1, - &flash_info[0]); -#endif - - - flash_info[0].size = size; - - return (size); -} - -/*----------------------------------------------------------------------- - */ -static void flash_get_offsets(ulong base, flash_info_t * info) -{ - int i; - - /* set up sector start address table */ - if ((info->flash_id & FLASH_TYPEMASK) == FLASH_AM040) { - for (i = 0; i < info->sector_count; i++) { - info->start[i] = base + (i * 0x00010000); - } - } else if (info->flash_id & FLASH_BTYPE) { - /* set sector offsets for bottom boot block type */ - info->start[0] = base + 0x00000000; - info->start[1] = base + 0x00004000; - info->start[2] = base + 0x00006000; - info->start[3] = base + 0x00008000; - for (i = 4; i < info->sector_count; i++) { - info->start[i] = base + (i * 0x00010000) - 0x00030000; - } - } else { - /* set sector offsets for top boot block type */ - i = info->sector_count - 1; - info->start[i--] = base + info->size - 0x00004000; - info->start[i--] = base + info->size - 0x00006000; - info->start[i--] = base + info->size - 0x00008000; - for (; i >= 0; i--) { - info->start[i] = base + i * 0x00010000; - } - } - -} - -/*----------------------------------------------------------------------- - */ -void flash_print_info(flash_info_t * info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf("missing or unknown FLASH type\n"); - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_AMD: - printf("AMD "); - break; - case FLASH_MAN_FUJ: - printf("FUJITSU "); - break; - case FLASH_MAN_MX: - printf("MXIC "); - break; - default: - printf("Unknown Vendor "); - break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_AM040: - printf("AM29LV040B (4 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM400B: - printf("AM29LV400B (4 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM400T: - printf("AM29LV400T (4 Mbit, top boot sector)\n"); - break; - case FLASH_AM800B: - printf("AM29LV800B (8 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM800T: - printf("AM29LV800T (8 Mbit, top boot sector)\n"); - break; - case FLASH_AM160B: - printf("AM29LV160B (16 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM160T: - printf("AM29LV160T (16 Mbit, top boot sector)\n"); - break; - case FLASH_AM320B: - printf("AM29LV320B (32 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM320T: - printf("AM29LV320T (32 Mbit, top boot sector)\n"); - break; - default: - printf("Unknown Chip Type\n"); - break; - } - - printf(" Size: %ld MB in %d Sectors\n", info->size >> 20, info->sector_count); - - printf(" Sector Start Addresses:"); - for (i = 0; i < info->sector_count; ++i) { - if ((i % 5) == 0) - printf("\n "); - printf(" %08lX%s", info->start[i], info->protect[i] ? " (RO)" : " "); - } - printf("\n"); -} - -/*----------------------------------------------------------------------- - */ - - -/*----------------------------------------------------------------------- - */ - -/* - * The following code cannot be run from FLASH! - */ - -static ulong flash_get_size(vu_long * addr, flash_info_t * info) -{ - short i; - uchar mid; - uchar pid; - vu_char *caddr = (vu_char *) addr; - ulong base = (ulong) addr; - - - /* Write auto select command: read Manufacturer ID */ - caddr[0x0555] = 0xAA; - caddr[0x02AA] = 0x55; - caddr[0x0555] = 0x90; - - mid = caddr[0]; - switch (mid) { - case (AMD_MANUFACT & 0xFF): - info->flash_id = FLASH_MAN_AMD; - break; - case (FUJ_MANUFACT & 0xFF): - info->flash_id = FLASH_MAN_FUJ; - break; - case (MX_MANUFACT & 0xFF): - info->flash_id = FLASH_MAN_MX; - break; - case (STM_MANUFACT & 0xFF): - info->flash_id = FLASH_MAN_STM; - break; - default: - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - return (0); /* no or unknown flash */ - } - - pid = caddr[1]; /* device ID */ - switch (pid) { - case (AMD_ID_LV400T & 0xFF): - info->flash_id += FLASH_AM400T; - info->sector_count = 11; - info->size = 0x00080000; - break; /* => 512 kB */ - - case (AMD_ID_LV400B & 0xFF): - info->flash_id += FLASH_AM400B; - info->sector_count = 11; - info->size = 0x00080000; - break; /* => 512 kB */ - - case (AMD_ID_LV800T & 0xFF): - info->flash_id += FLASH_AM800T; - info->sector_count = 19; - info->size = 0x00100000; - break; /* => 1 MB */ - - case (AMD_ID_LV800B & 0xFF): - info->flash_id += FLASH_AM800B; - info->sector_count = 19; - info->size = 0x00100000; - break; /* => 1 MB */ - - case (AMD_ID_LV160T & 0xFF): - info->flash_id += FLASH_AM160T; - info->sector_count = 35; - info->size = 0x00200000; - break; /* => 2 MB */ - - case (AMD_ID_LV160B & 0xFF): - info->flash_id += FLASH_AM160B; - info->sector_count = 35; - info->size = 0x00200000; - break; /* => 2 MB */ - - case (AMD_ID_LV040B & 0xFF): - info->flash_id += FLASH_AM040; - info->sector_count = 8; - info->size = 0x00080000; - break; - - case (STM_ID_M29W040B & 0xFF): - info->flash_id += FLASH_AM040; - info->sector_count = 8; - info->size = 0x00080000; - break; - -#if 0 /* enable when device IDs are available */ - case (AMD_ID_LV320T & 0xFF): - info->flash_id += FLASH_AM320T; - info->sector_count = 67; - info->size = 0x00400000; - break; /* => 4 MB */ - - case (AMD_ID_LV320B & 0xFF): - info->flash_id += FLASH_AM320B; - info->sector_count = 67; - info->size = 0x00400000; - break; /* => 4 MB */ -#endif - default: - info->flash_id = FLASH_UNKNOWN; - return (0); /* => no or unknown flash */ - - } - - printf(" "); - /* set up sector start address table */ - if ((info->flash_id & FLASH_TYPEMASK) == FLASH_AM040) { - for (i = 0; i < info->sector_count; i++) { - info->start[i] = base + (i * 0x00010000); - } - } else if (info->flash_id & FLASH_BTYPE) { - /* set sector offsets for bottom boot block type */ - info->start[0] = base + 0x00000000; - info->start[1] = base + 0x00004000; - info->start[2] = base + 0x00006000; - info->start[3] = base + 0x00008000; - for (i = 4; i < info->sector_count; i++) { - info->start[i] = base + (i * 0x00010000) - 0x00030000; - } - } else { - /* set sector offsets for top boot block type */ - i = info->sector_count - 1; - info->start[i--] = base + info->size - 0x00004000; - info->start[i--] = base + info->size - 0x00006000; - info->start[i--] = base + info->size - 0x00008000; - for (; i >= 0; i--) { - info->start[i] = base + i * 0x00010000; - } - } - - /* check for protected sectors */ - for (i = 0; i < info->sector_count; i++) { - /* read sector protection: D0 = 1 if protected */ - caddr = (volatile unsigned char *)(info->start[i]); - info->protect[i] = caddr[2] & 1; - } - - /* - * Prevent writes to uninitialized FLASH. - */ - if (info->flash_id != FLASH_UNKNOWN) { - caddr = (vu_char *) info->start[0]; - - caddr[0x0555] = 0xAA; - caddr[0x02AA] = 0x55; - caddr[0x0555] = 0xF0; - - udelay(20000); - } - - return (info->size); -} - - -/*----------------------------------------------------------------------- - */ - -int flash_erase(flash_info_t * info, int s_first, int s_last) -{ - vu_char *addr = (vu_char *) (info->start[0]); - int flag, prot, sect, l_sect; - ulong start, now, last; - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf("- missing\n"); - } else { - printf("- no sectors to erase\n"); - } - return 1; - } - - if ((info->flash_id == FLASH_UNKNOWN) || - (info->flash_id > FLASH_AMD_COMP)) { - printf("Can't erase unknown flash type %08lx - aborted\n", info->flash_id); - return 1; - } - - prot = 0; - for (sect = s_first; sect <= s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf("- Warning: %d protected sectors will not be erased!\n", prot); - } else { - printf("\n"); - } - - l_sect = -1; - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - addr[0x0555] = 0xAA; - addr[0x02AA] = 0x55; - addr[0x0555] = 0x80; - addr[0x0555] = 0xAA; - addr[0x02AA] = 0x55; - - /* Start erase on unprotected sectors */ - for (sect = s_first; sect <= s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - addr = (vu_char *) (info->start[sect]); - addr[0] = 0x30; - l_sect = sect; - } - } - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* wait at least 80us - let's wait 1 ms */ - udelay(1000); - - /* - * We wait for the last triggered sector - */ - if (l_sect < 0) - goto DONE; - - start = get_timer(0); - last = start; - addr = (vu_char *) (info->start[l_sect]); - while ((addr[0] & 0x80) != 0x80) { - if ((now = get_timer(start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf("Timeout\n"); - return 1; - } - /* show that we're waiting */ - if ((now - last) > 1000) { /* every second */ - putc('.'); - last = now; - } - } - - DONE: - /* reset to read mode */ - addr = (vu_char *) info->start[0]; - addr[0] = 0xF0; /* reset bank */ - - printf(" done\n"); - return 0; -} - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ - -int write_buff(flash_info_t * info, uchar * src, ulong addr, ulong cnt) -{ - int rc; - - while (cnt > 0) { - if ((rc = write_byte(info, addr++, *src++)) != 0) { - return (rc); - } - --cnt; - } - - return (0); -} - -/*----------------------------------------------------------------------- - * Write a word to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_byte(flash_info_t * info, ulong dest, uchar data) -{ - vu_char *addr = (vu_char *) (info->start[0]); - ulong start; - int flag; - - /* Check if Flash is (sufficiently) erased */ - if ((*((vu_char *) dest) & data) != data) { - return (2); - } - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - addr[0x0555] = 0xAA; - addr[0x02AA] = 0x55; - addr[0x0555] = 0xA0; - - *((vu_char *) dest) = data; - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* data polling for D7 */ - start = get_timer(0); - while ((*((vu_char *) dest) & 0x80) != (data & 0x80)) { - if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - return (1); - } - } - return (0); -} - -/*----------------------------------------------------------------------- - */ diff --git a/board/netvia/netvia.c b/board/netvia/netvia.c deleted file mode 100644 index b3bbf47..0000000 --- a/board/netvia/netvia.c +++ /dev/null @@ -1,401 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * Pantelis Antoniou, Intracom S.A., panto@intracom.gr - * U-Boot port on NetVia board - */ - -#include <common.h> -#include "mpc8xx.h" - -/****************************************************************/ - -#if defined(CONFIG_NETVIA_VERSION) && CONFIG_NETVIA_VERSION >= 2 -/* last value written to the external register; we cannot read back */ -unsigned int last_er_val; -#endif - -/****************************************************************/ - -/****************************************************************/ - -/* some sane bit macros */ -#define _BD(_b) (1U << (31-(_b))) -#define _BDR(_l, _h) (((((1U << (31-(_l))) - 1) << 1) | 1) & ~((1U << (31-(_h))) - 1)) - -#define _BW(_b) (1U << (15-(_b))) -#define _BWR(_l, _h) (((((1U << (15-(_l))) - 1) << 1) | 1) & ~((1U << (15-(_h))) - 1)) - -#define _BB(_b) (1U << (7-(_b))) -#define _BBR(_l, _h) (((((1U << (7-(_l))) - 1) << 1) | 1) & ~((1U << (7-(_h))) - 1)) - -#define _B(_b) _BD(_b) -#define _BR(_l, _h) _BDR(_l, _h) - -/****************************************************************/ - -#define _NOT_USED_ 0xFFFFFFFF - -/****************************************************************/ - -#define CS_0000 0x00000000 -#define CS_0001 0x10000000 -#define CS_0010 0x20000000 -#define CS_0011 0x30000000 -#define CS_0100 0x40000000 -#define CS_0101 0x50000000 -#define CS_0110 0x60000000 -#define CS_0111 0x70000000 -#define CS_1000 0x80000000 -#define CS_1001 0x90000000 -#define CS_1010 0xA0000000 -#define CS_1011 0xB0000000 -#define CS_1100 0xC0000000 -#define CS_1101 0xD0000000 -#define CS_1110 0xE0000000 -#define CS_1111 0xF0000000 - -#define BS_0000 0x00000000 -#define BS_0001 0x01000000 -#define BS_0010 0x02000000 -#define BS_0011 0x03000000 -#define BS_0100 0x04000000 -#define BS_0101 0x05000000 -#define BS_0110 0x06000000 -#define BS_0111 0x07000000 -#define BS_1000 0x08000000 -#define BS_1001 0x09000000 -#define BS_1010 0x0A000000 -#define BS_1011 0x0B000000 -#define BS_1100 0x0C000000 -#define BS_1101 0x0D000000 -#define BS_1110 0x0E000000 -#define BS_1111 0x0F000000 - -#define A10_AAAA 0x00000000 -#define A10_AAA0 0x00200000 -#define A10_AAA1 0x00300000 -#define A10_000A 0x00800000 -#define A10_0000 0x00A00000 -#define A10_0001 0x00B00000 -#define A10_111A 0x00C00000 -#define A10_1110 0x00E00000 -#define A10_1111 0x00F00000 - -#define RAS_0000 0x00000000 -#define RAS_0001 0x00040000 -#define RAS_1110 0x00080000 -#define RAS_1111 0x000C0000 - -#define CAS_0000 0x00000000 -#define CAS_0001 0x00010000 -#define CAS_1110 0x00020000 -#define CAS_1111 0x00030000 - -#define WE_0000 0x00000000 -#define WE_0001 0x00004000 -#define WE_1110 0x00008000 -#define WE_1111 0x0000C000 - -#define GPL4_0000 0x00000000 -#define GPL4_0001 0x00001000 -#define GPL4_1110 0x00002000 -#define GPL4_1111 0x00003000 - -#define GPL5_0000 0x00000000 -#define GPL5_0001 0x00000400 -#define GPL5_1110 0x00000800 -#define GPL5_1111 0x00000C00 -#define LOOP 0x00000080 - -#define EXEN 0x00000040 - -#define AMX_COL 0x00000000 -#define AMX_ROW 0x00000020 -#define AMX_MAR 0x00000030 - -#define NA 0x00000008 - -#define UTA 0x00000004 - -#define TODT 0x00000002 - -#define LAST 0x00000001 - -const uint sdram_table[0x40] = { - /* RSS */ - CS_0001 | BS_1111 | A10_AAAA | RAS_0001 | CAS_1111 | WE_1111 | AMX_COL | UTA, /* ACT */ - CS_1111 | BS_1111 | A10_0000 | RAS_1111 | CAS_1111 | WE_1111 | AMX_COL | UTA, /* NOP */ - CS_0000 | BS_1111 | A10_0001 | RAS_1111 | CAS_0001 | WE_1111 | AMX_COL | UTA, /* READ */ - CS_0001 | BS_0001 | A10_1111 | RAS_0001 | CAS_1111 | WE_0001 | AMX_COL | UTA, /* PALL */ - CS_1111 | BS_1111 | A10_1111 | RAS_1111 | CAS_1111 | WE_1111 | AMX_COL, /* NOP */ - CS_1111 | BS_1111 | A10_1111 | RAS_1111 | CAS_1111 | WE_1111 | AMX_COL | UTA | TODT | LAST, /* NOP */ - _NOT_USED_, _NOT_USED_, - - /* RBS */ - CS_0001 | BS_1111 | A10_AAAA | RAS_0001 | CAS_1111 | WE_1111 | AMX_COL | UTA, /* ACT */ - CS_1111 | BS_1111 | A10_0000 | RAS_1111 | CAS_1111 | WE_1111 | AMX_COL | UTA, /* NOP */ - CS_0001 | BS_1111 | A10_0001 | RAS_1111 | CAS_0001 | WE_1111 | AMX_COL | UTA, /* READ */ - CS_1111 | BS_0000 | A10_1111 | RAS_1111 | CAS_1111 | WE_1111 | AMX_COL | UTA, /* NOP */ - CS_1111 | BS_0000 | A10_1111 | RAS_1111 | CAS_1111 | WE_1111 | AMX_COL, /* NOP */ - CS_1111 | BS_0000 | A10_1111 | RAS_1111 | CAS_1111 | WE_1111 | AMX_COL, /* NOP */ - CS_0001 | BS_0001 | A10_1111 | RAS_0001 | CAS_1111 | WE_0001 | AMX_COL, /* PALL */ - CS_1111 | BS_1111 | A10_1111 | RAS_1111 | CAS_1111 | WE_1111 | AMX_COL | TODT | LAST, /* NOP */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - - /* WSS */ - CS_0001 | BS_1111 | A10_AAAA | RAS_0001 | CAS_1111 | WE_1111 | AMX_COL | UTA, - CS_1111 | BS_1111 | A10_0000 | RAS_1111 | CAS_1111 | WE_1111 | AMX_COL, - CS_0000 | BS_0001 | A10_0000 | RAS_1111 | CAS_0001 | WE_0000 | AMX_COL | UTA, - CS_0001 | BS_1111 | A10_1111 | RAS_0001 | CAS_1111 | WE_0001 | AMX_COL | UTA | TODT | LAST, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - - /* WBS */ - CS_0001 | BS_1111 | A10_AAAA | RAS_0001 | CAS_1111 | WE_1111 | AMX_COL | UTA, /* ACT */ - CS_1111 | BS_1111 | A10_0000 | RAS_1111 | CAS_1111 | WE_1111 | AMX_COL, /* NOP */ - CS_0001 | BS_0000 | A10_0000 | RAS_1111 | CAS_0001 | WE_0000 | AMX_COL, /* WRITE */ - CS_1111 | BS_0000 | A10_1111 | RAS_1111 | CAS_1111 | WE_1111 | AMX_COL, /* NOP */ - CS_1111 | BS_0000 | A10_1111 | RAS_1111 | CAS_1111 | WE_1111 | AMX_COL, /* NOP */ - CS_1111 | BS_0001 | A10_1111 | RAS_1111 | CAS_1111 | WE_1111 | AMX_COL | UTA, /* NOP */ - CS_1111 | BS_1111 | A10_1111 | RAS_1111 | CAS_1111 | WE_1111 | AMX_COL | UTA, /* NOP */ - CS_0001 | BS_1111 | A10_1111 | RAS_0001 | CAS_1111 | WE_0001 | AMX_COL | UTA, /* PALL */ - CS_1111 | BS_1111 | A10_1111 | RAS_1111 | CAS_1111 | WE_1111 | AMX_COL | UTA | TODT | LAST, /* NOP */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, - - /* UPT */ - CS_1111 | BS_1111 | A10_1111 | RAS_1111 | CAS_1111 | WE_1111 | AMX_COL, /* NOP */ - CS_0001 | BS_1111 | A10_1111 | RAS_0001 | CAS_0001 | WE_1111 | AMX_COL | LOOP, - CS_1111 | BS_1111 | A10_1111 | RAS_1111 | CAS_1111 | WE_1111 | AMX_COL, - CS_1111 | BS_1111 | A10_1111 | RAS_1111 | CAS_1111 | WE_1111 | AMX_COL, - CS_1111 | BS_1111 | A10_1111 | RAS_1111 | CAS_1111 | WE_1111 | AMX_COL | LOOP, - CS_1111 | BS_1111 | A10_1111 | RAS_1111 | CAS_1111 | WE_1111 | AMX_COL | LAST, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, - - /* EXC */ - CS_0001 | BS_1111 | A10_1111 | RAS_0001 | CAS_1111 | WE_0001 | AMX_COL, - CS_1111 | BS_1111 | A10_1111 | RAS_1111 | CAS_1111 | WE_1111 | AMX_COL | TODT | LAST, - - /* REG */ - CS_1111 | BS_1111 | A10_1111 | RAS_1111 | CAS_1111 | WE_1110 | AMX_MAR, - CS_0001 | BS_1111 | A10_0001 | RAS_0001 | CAS_0001 | WE_0001 | AMX_MAR | TODT | LAST, -}; - -/* ------------------------------------------------------------------------- */ - - -/* - * Check Board Identity: - * - * Test ETX ID string (ETX_xxx...) - * - * Return 1 always. - */ - -int checkboard(void) -{ -#if !defined(CONFIG_NETVIA_VERSION) || CONFIG_NETVIA_VERSION == 1 - printf ("NETVIA v1\n"); -#else - printf ("NETVIA v2+\n"); -#endif - return (0); -} - -/* ------------------------------------------------------------------------- */ - -/* 0xC8 = 0b11001000 , CAS3, >> 2 = 0b00 11 0 010 */ -#define MAR_SDRAM_INIT 0x000000C8LU - -#define MCR_OP(x) ((unsigned long)((x) & 3) << (31-1)) -#define MCR_OP_MASK MCR_OP(3) - -#define MCR_UM(x) ((unsigned long)((x) & 1) << (31 - 8)) -#define MCR_UM_MASK MCR_UM(1) -#define MCR_UM_UPMA MCR_UM(0) -#define MCR_UM_UPMB MCR_UM(1) - -#define MCR_MB(x) ((unsigned long)((x) & 7) << (31 - 18)) -#define MCR_MB_MASK MCR_MB(7) -#define MCR_MB_CS(x) MCR_MB(x) - -#define MCR_MCLF(x) ((unsigned long)((x) & 15) << (31 - 23)) -#define MCR_MCLF_MASK MCR_MCLF(15) - -phys_size_t initdram(int board_type) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - long int size; - - upmconfig(UPMA, (uint *) sdram_table, sizeof(sdram_table) / sizeof(uint)); - - /* - * Preliminary prescaler for refresh - */ - memctl->memc_mptpr = CONFIG_SYS_MPTPR_1BK_8K; - - memctl->memc_mar = MAR_SDRAM_INIT; /* 32-bit address to be output on the address bus if AMX = 0b11 */ - - /* - * Map controller bank 3 to the SDRAM bank at preliminary address. - */ - memctl->memc_or3 = CONFIG_SYS_OR3_PRELIM; - memctl->memc_br3 = CONFIG_SYS_BR3_PRELIM; - - memctl->memc_mamr = CONFIG_SYS_MAMR_9COL & ~MAMR_PTAE; /* no refresh yet */ - - udelay(200); - - /* perform SDRAM initialisation sequence */ - memctl->memc_mcr = MCR_OP_RUN | MCR_UM_UPMA | MCR_MB_CS3 | MCR_MCLF(1) | MCR_MAD(0x3C); /* precharge all */ - udelay(1); - memctl->memc_mcr = MCR_OP_RUN | MCR_UM_UPMA | MCR_MB_CS3 | MCR_MCLF(0) | MCR_MAD(0x30); /* refresh 16 times(0) */ - udelay(1); - memctl->memc_mcr = MCR_OP_RUN | MCR_UM_UPMA | MCR_MB_CS3 | MCR_MCLF(1) | MCR_MAD(0x3E); /* exception program (write mar) */ - udelay(1); - - memctl->memc_mamr |= MAMR_PTAE; /* enable refresh */ - - udelay(1000); - - memctl->memc_mamr = CONFIG_SYS_MAMR_9COL; - - size = SDRAM_MAX_SIZE; - - udelay(10000); - - return (size); -} - -/* ------------------------------------------------------------------------- */ - -int misc_init_r(void) -{ -#if defined(CONFIG_NETVIA_VERSION) && CONFIG_NETVIA_VERSION >= 2 - last_er_val = 0xffffffff; -#endif - return(0); -} - -/* ------------------------------------------------------------------------- */ - -/* GP = general purpose, SP = special purpose (on chip peripheral) */ - -/* bits that can have a special purpose or can be configured as inputs/outputs */ -#define PA_GP_INMASK 0 -#define PA_GP_OUTMASK (_BW(5) | _BWR(14, 15)) -#define PA_SP_MASK (_BW(4) | _BWR(6, 13)) -#define PA_ODR_VAL 0 -#define PA_GP_OUTVAL _BW(5) -#define PA_SP_DIRVAL 0 - -#define PB_GP_INMASK _B(28) -#define PB_GP_OUTMASK (_BR(16, 19) | _BR(26, 27) | _BR(29, 31)) -#define PB_SP_MASK _BR(22, 25) -#define PB_ODR_VAL 0 -#define PB_GP_OUTVAL (_BR(16, 19) | _BR(26, 27) | _BR(29, 31)) -#define PB_SP_DIRVAL 0 - -#if !defined(CONFIG_NETVIA_VERSION) || CONFIG_NETVIA_VERSION == 1 - -#define PC_GP_INMASK (_BWR(5, 7) | _BWR(9, 10) | _BW(13)) -#define PC_GP_OUTMASK _BW(12) -#define PC_SP_MASK (_BW(4) | _BW(8)) -#define PC_SOVAL 0 -#define PC_INTVAL 0 -#define PC_GP_OUTVAL 0 -#define PC_SP_DIRVAL 0 - -#define PD_GP_INMASK 0 -#define PD_GP_OUTMASK _BWR(3, 15) -#define PD_SP_MASK 0 -#define PD_GP_OUTVAL (_BW(3) | _BW(5) | _BW(7) | _BWR(8, 15)) -#define PD_SP_DIRVAL 0 - -#elif CONFIG_NETVIA_VERSION >= 2 - -#define PC_GP_INMASK (_BW(5) | _BW(7) | _BWR(9, 11) | _BWR(13, 15)) -#define PC_GP_OUTMASK (_BW(6) | _BW(12)) -#define PC_SP_MASK (_BW(4) | _BW(8)) -#define PC_SOVAL 0 -#define PC_INTVAL _BW(7) -#define PC_GP_OUTVAL (_BW(6) | _BW(12)) -#define PC_SP_DIRVAL 0 - -#define PD_GP_INMASK 0 -#define PD_GP_OUTMASK _BWR(3, 15) -#define PD_SP_MASK 0 -#define PD_GP_OUTVAL (_BW(3) | _BW(5) | _BW(9) | _BW(11)) -#define PD_SP_DIRVAL 0 - -#else -#error Unknown NETVIA board version. -#endif - -int board_early_init_f(void) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile iop8xx_t *ioport = &immap->im_ioport; - volatile cpm8xx_t *cpm = &immap->im_cpm; - volatile memctl8xx_t *memctl = &immap->im_memctl; - - /* DSP0 chip select */ - memctl->memc_or4 = ((0xFFFFFFFFLU & ~(DSP_SIZE - 1)) | OR_CSNT_SAM | OR_BI | OR_ACS_DIV2 | OR_SETA | OR_TRLX); - memctl->memc_br4 = ((DSP0_BASE & BR_BA_MSK) | BR_PS_16 | BR_V); - - /* DSP1 chip select */ - memctl->memc_or5 = ((0xFFFFFFFFLU & ~(DSP_SIZE - 1)) | OR_CSNT_SAM | OR_BI | OR_ACS_DIV2 | OR_SETA | OR_TRLX); - memctl->memc_br5 = ((DSP1_BASE & BR_BA_MSK) | BR_PS_16 | BR_V); - - /* FPGA chip select */ - memctl->memc_or6 = ((0xFFFFFFFFLU & ~(FPGA_SIZE - 1)) | OR_BI | OR_SCY_1_CLK); - memctl->memc_br6 = ((FPGA_BASE & BR_BA_MSK) | BR_PS_8 | BR_V); - -#if defined(CONFIG_NETVIA_VERSION) && CONFIG_NETVIA_VERSION >= 2 - /* NAND chip select */ - memctl->memc_or1 = ((0xFFFFFFFFLU & ~(NAND_SIZE - 1)) | OR_CSNT_SAM | OR_BI | OR_SCY_8_CLK | OR_EHTR | OR_TRLX); - memctl->memc_br1 = ((NAND_BASE & BR_BA_MSK) | BR_PS_8 | BR_V); - - /* kill this chip select */ - memctl->memc_br2 &= ~BR_V; /* invalid */ - - /* external reg chip select */ - memctl->memc_or7 = ((0xFFFFFFFFLU & ~(ER_SIZE - 1)) | OR_BI | OR_SCY_4_CLK); - memctl->memc_br7 = ((ER_BASE & BR_BA_MSK) | BR_PS_32 | BR_V); -#endif - - ioport->iop_padat = PA_GP_OUTVAL; - ioport->iop_paodr = PA_ODR_VAL; - ioport->iop_padir = PA_GP_OUTMASK | PA_SP_DIRVAL; - ioport->iop_papar = PA_SP_MASK; - - cpm->cp_pbdat = PB_GP_OUTVAL; - cpm->cp_pbodr = PB_ODR_VAL; - cpm->cp_pbdir = PB_GP_OUTMASK | PB_SP_DIRVAL; - cpm->cp_pbpar = PB_SP_MASK; - - ioport->iop_pcdat = PC_GP_OUTVAL; - ioport->iop_pcdir = PC_GP_OUTMASK | PC_SP_DIRVAL; - ioport->iop_pcso = PC_SOVAL; - ioport->iop_pcint = PC_INTVAL; - ioport->iop_pcpar = PC_SP_MASK; - - ioport->iop_pddat = PD_GP_OUTVAL; - ioport->iop_pddir = PD_GP_OUTMASK | PD_SP_DIRVAL; - ioport->iop_pdpar = PD_SP_MASK; - -#if defined(CONFIG_NETVIA_VERSION) && CONFIG_NETVIA_VERSION >= 2 - /* external register init */ - *(volatile uint *)ER_BASE = 0xFFFFFFFF; -#endif - - return 0; -} diff --git a/board/netvia/u-boot.lds.debug b/board/netvia/u-boot.lds.debug deleted file mode 100644 index 5bbf1c5..0000000 --- a/board/netvia/u-boot.lds.debug +++ /dev/null @@ -1,121 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -OUTPUT_ARCH(powerpc) -/* Do we need any of these for elf? - __DYNAMIC = 0; */ -SECTIONS -{ - /* Read-only sections, merged into text segment: */ - . = + SIZEOF_HEADERS; - .interp : { *(.interp) } - .hash : { *(.hash) } - .dynsym : { *(.dynsym) } - .dynstr : { *(.dynstr) } - .rel.text : { *(.rel.text) } - .rela.text : { *(.rela.text) } - .rel.data : { *(.rel.data) } - .rela.data : { *(.rela.data) } - .rel.rodata : { *(.rel.rodata) } - .rela.rodata : { *(.rela.rodata) } - .rel.got : { *(.rel.got) } - .rela.got : { *(.rela.got) } - .rel.ctors : { *(.rel.ctors) } - .rela.ctors : { *(.rela.ctors) } - .rel.dtors : { *(.rel.dtors) } - .rela.dtors : { *(.rela.dtors) } - .rel.bss : { *(.rel.bss) } - .rela.bss : { *(.rela.bss) } - .rel.plt : { *(.rel.plt) } - .rela.plt : { *(.rela.plt) } - .init : { *(.init) } - .plt : { *(.plt) } - .text : - { - /* WARNING - the following is hand-optimized to fit within */ - /* the sector layout of our flash chips! XXX FIXME XXX */ - - arch/powerpc/cpu/mpc8xx/start.o (.text) - common/dlmalloc.o (.text) - lib/vsprintf.o (.text) - lib/crc32.o (.text) - - . = env_offset; - common/env_embedded.o(.text) - - *(.text) - *(.got1) - } - _etext = .; - PROVIDE (etext = .); - .rodata : - { - *(.rodata) - *(.rodata1) - *(.rodata.str1.4) - *(.eh_frame) - } - .fini : { *(.fini) } =0 - .ctors : { *(.ctors) } - .dtors : { *(.dtors) } - - /* Read-write section, merged into data segment: */ - . = (. + 0x0FFF) & 0xFFFFF000; - _erotext = .; - PROVIDE (erotext = .); - .reloc : - { - *(.got) - _GOT2_TABLE_ = .; - *(.got2) - _FIXUP_TABLE_ = .; - *(.fixup) - } - __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; - __fixup_entries = (. - _FIXUP_TABLE_)>>2; - - .data : - { - *(.data) - *(.data1) - *(.sdata) - *(.sdata2) - *(.dynamic) - CONSTRUCTORS - } - _edata = .; - PROVIDE (edata = .); - - - . = ALIGN(4); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); - } - - - __start___ex_table = .; - __ex_table : { *(__ex_table) } - __stop___ex_table = .; - - . = ALIGN(4096); - __init_begin = .; - .text.init : { *(.text.init) } - .data.init : { *(.data.init) } - . = ALIGN(4096); - __init_end = .; - - __bss_start = .; - .bss : - { - *(.sbss) *(.scommon) - *(.dynbss) - *(.bss) - *(COMMON) - } - __bss_end = . ; - PROVIDE (end = .); -} diff --git a/configs/NETVIA_V2_defconfig b/configs/NETVIA_V2_defconfig deleted file mode 100644 index 2715910..0000000 --- a/configs/NETVIA_V2_defconfig +++ /dev/null @@ -1,4 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="NETVIA_VERSION=2" -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_NETVIA=y diff --git a/configs/NETVIA_defconfig b/configs/NETVIA_defconfig deleted file mode 100644 index 27c8f2b..0000000 --- a/configs/NETVIA_defconfig +++ /dev/null @@ -1,4 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="NETVIA_VERSION=1" -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_NETVIA=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 1e475af..6b391df 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,7 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +NETVIA powerpc mpc8xx - - Pantelis Antoniou panto@intracom.gr R360MPI powerpc mpc8xx - - Wolfgang Denk wd@denx.de RRvision powerpc mpc8xx - - Wolfgang Denk wd@denx.de SPD823TS powerpc mpc8xx - - Wolfgang Denk wd@denx.de diff --git a/include/commproc.h b/include/commproc.h index 38e4e7d..8de0d15 100644 --- a/include/commproc.h +++ b/include/commproc.h @@ -594,39 +594,6 @@ typedef struct scc_enet { #define SICR_ENET_CLKRT ((uint)0x00250000) #endif /* CONFIG_KM8XX */
-/*** NETVIA *******************************************************/ - -#if defined(CONFIG_NETVIA) -/* Bits in parallel I/O port registers that have to be set/cleared - * to configure the pins for SCC2 use. - */ -#define PROFF_ENET PROFF_SCC2 -#define CPM_CR_ENET CPM_CR_CH_SCC2 -#define SCC_ENET 1 -#define PA_ENET_RXD ((ushort)0x0004) /* PA 13 */ -#define PA_ENET_TXD ((ushort)0x0008) /* PA 12 */ -#define PA_ENET_RCLK ((ushort)0x0200) /* PA 6 */ -#define PA_ENET_TCLK ((ushort)0x0800) /* PA 4 */ - -#if !defined(CONFIG_NETVIA_VERSION) || CONFIG_NETVIA_VERSION == 1 -# define PB_ENET_PDN ((ushort)0x4000) /* PB 17 */ -#elif CONFIG_NETVIA_VERSION >= 2 -# define PC_ENET_PDN ((ushort)0x0008) /* PC 12 */ -#endif - -#define PB_ENET_TENA ((ushort)0x2000) /* PB 18 */ - -#define PC_ENET_CLSN ((ushort)0x0040) /* PC 9 */ -#define PC_ENET_RENA ((ushort)0x0080) /* PC 8 */ - -/* Control bits in the SICR to route TCLK (CLK3) and RCLK (CLK1) to - * SCC2. Also, make sure GR2 (bit 16) and SC2 (bit 17) are zero. - */ -#define SICR_ENET_MASK ((uint)0x0000ff00) -#define SICR_ENET_CLKRT ((uint)0x00002f00) - -#endif /* CONFIG_NETVIA */ - /*** MVS1, TQM823L/M, TQM850L/M, TQM885D, R360MPI **********/
#if (defined(CONFIG_MVS) && CONFIG_MVS < 2) || \ diff --git a/include/configs/NETVIA.h b/include/configs/NETVIA.h deleted file mode 100644 index 4a0fa9e..0000000 --- a/include/configs/NETVIA.h +++ /dev/null @@ -1,435 +0,0 @@ -/* - * (C) Copyright 2000-2010 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * Pantelis Antoniou, Intracom S.A., panto@intracom.gr - * U-Boot port on NetVia board - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC850 1 /* This is a MPC850 CPU */ -#define CONFIG_NETVIA 1 /* ...on a NetVia board */ - -#define CONFIG_SYS_TEXT_BASE 0x40000000 - -#if !defined(CONFIG_NETVIA_VERSION) || CONFIG_NETVIA_VERSION == 1 -#define CONFIG_8xx_CONS_SMC1 1 /* Console is on SMC1 */ -#undef CONFIG_8xx_CONS_SMC2 -#undef CONFIG_8xx_CONS_NONE -#else -#define CONFIG_8xx_CONS_NONE -#define CONFIG_MAX3100_SERIAL -#endif - -#define CONFIG_BAUDRATE 115200 /* console baudrate = 115kbps */ - -#define CONFIG_XIN 10000000 -#define CONFIG_8xx_GCLK_FREQ 80000000 - -#if 0 -#define CONFIG_BOOTDELAY -1 /* autoboot disabled */ -#else -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ -#endif - -#undef CONFIG_CLOCKS_IN_MHZ /* clocks NOT passsed to Linux in MHz */ - -#define CONFIG_PREBOOT "echo;echo Type \"run flash_nfs\" to mount root filesystem over NFS;echo" - -#undef CONFIG_BOOTARGS -#define CONFIG_BOOTCOMMAND \ - "tftpboot; " \ - "setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off; " \ - "bootm" - -#define CONFIG_LOADS_ECHO 0 /* echo off for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -#define CONFIG_STATUS_LED 1 /* Status LED enabled */ - -#if defined(CONFIG_NETVIA_VERSION) && CONFIG_NETVIA_VERSION >= 2 -#define CONFIG_BOARD_SPECIFIC_LED /* version has board specific leds */ -#endif - -#undef CONFIG_CAN_DRIVER /* CAN Driver support disabled */ - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_NISDOMAIN - - -#undef CONFIG_MAC_PARTITION -#undef CONFIG_DOS_PARTITION - -#define CONFIG_RTC_MPC8xx /* use internal RTC of MPC8xx */ - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_PING - -#if defined(CONFIG_NETVIA_VERSION) && CONFIG_NETVIA_VERSION >= 2 -/* #define CONFIG_CMD_NAND */ /* disabled */ -#endif - - -#define CONFIG_BOARD_EARLY_INIT_F 1 -#define CONFIG_MISC_INIT_R - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x0300000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0700000 /* 3 ... 7 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xFF000000 - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x3000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0x40000000 -#if defined(DEBUG) -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#else -#define CONFIG_SYS_MONITOR_LEN (192 << 10) /* Reserve 192 kB for Monitor */ -#endif -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 8 /* max number of sectors on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ - -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_SECT_SIZE 0x10000 - -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x60000) -#define CONFIG_ENV_SIZE 0x4000 - -#define CONFIG_ENV_ADDR_REDUND (CONFIG_SYS_FLASH_BASE + 0x70000) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CACHELINE_SHIFT 4 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 11-9 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Software & Bus Monitor Timer max, Bus Monitor enable, SW Watchdog freeze - */ -#if defined(CONFIG_WATCHDOG) -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | \ - SYPCR_SWE | SYPCR_SWRI| SYPCR_SWP) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | SYPCR_SWP) -#endif - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 11-6 - *----------------------------------------------------------------------- - * PCMCIA config., multi-function pin tri-state - */ -#ifndef CONFIG_CAN_DRIVER -#define CONFIG_SYS_SIUMCR (SIUMCR_DBGC00 | SIUMCR_DBPC00 | SIUMCR_MLRC01 | SIUMCR_FRC) -#else /* we must activate GPL5 in the SIUMCR for CAN */ -#define CONFIG_SYS_SIUMCR (SIUMCR_DBGC11 | SIUMCR_DBPC00 | SIUMCR_MLRC01 | SIUMCR_FRC) -#endif /* CONFIG_CAN_DRIVER */ - -/*----------------------------------------------------------------------- - * TBSCR - Time Base Status and Control 11-26 - *----------------------------------------------------------------------- - * Clear Reference Interrupt Status, Timebase freezing enabled - */ -#define CONFIG_SYS_TBSCR (TBSCR_REFA | TBSCR_REFB | TBSCR_TBF) - -/*----------------------------------------------------------------------- - * RTCSC - Real-Time Clock Status and Control Register 11-27 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RTCSC (RTCSC_SEC | RTCSC_ALR | RTCSC_RTF| RTCSC_RTE) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 11-31 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Interrupt Timer freezing enabled - */ -#define CONFIG_SYS_PISCR (PISCR_PS | PISCR_PITF) - -/*----------------------------------------------------------------------- - * PLPRCR - PLL, Low-Power, and Reset Control Register 15-30 - *----------------------------------------------------------------------- - * Reset PLL lock status sticky bit, timer expired status bit and timer - * interrupt status bit - * - * - *----------------------------------------------------------------------- - * SCCR - System Clock and reset Control Register 15-27 - *----------------------------------------------------------------------- - * Set clock output, timebase and RTC source and divider, - * power management and some other internal clocks - */ - -#define SCCR_MASK SCCR_EBDF11 - -#if CONFIG_8xx_GCLK_FREQ == 50000000 - -#define CONFIG_SYS_PLPRCR ( ((5 - 1) << PLPRCR_MF_SHIFT) | PLPRCR_SPLSS | PLPRCR_TEXPS | PLPRCR_TMIST) -#define CONFIG_SYS_SCCR (SCCR_TBS | \ - SCCR_COM00 | SCCR_DFSYNC00 | SCCR_DFBRG00 | \ - SCCR_DFNL000 | SCCR_DFNH000 | SCCR_DFLCD000 | \ - SCCR_DFALCD00) - -#elif CONFIG_8xx_GCLK_FREQ == 80000000 - -#define CONFIG_SYS_PLPRCR ( ((8 - 1) << PLPRCR_MF_SHIFT) | PLPRCR_SPLSS | PLPRCR_TEXPS | PLPRCR_TMIST) -#define CONFIG_SYS_SCCR (SCCR_TBS | \ - SCCR_COM00 | SCCR_DFSYNC00 | SCCR_DFBRG00 | \ - SCCR_DFNL000 | SCCR_DFNH000 | SCCR_DFLCD000 | \ - SCCR_DFALCD00 | SCCR_EBDF01) - -#endif - -/*----------------------------------------------------------------------- - * - *----------------------------------------------------------------------- - * - */ -/*#define CONFIG_SYS_DER 0x2002000F*/ -#define CONFIG_SYS_DER 0 - -/* - * Init Memory Controller: - * - * BR0/1 and OR0/1 (FLASH) - */ - -#define FLASH_BASE0_PRELIM 0x40000000 /* FLASH bank #0 */ - -/* used to re-map FLASH both when starting from SRAM or FLASH: - * restrict access enough to keep SRAM working (if any) - * but not too much to meddle with FLASH accesses - */ -#define CONFIG_SYS_REMAP_OR_AM 0x80000000 /* OR addr mask */ -#define CONFIG_SYS_PRELIM_OR_AM 0xE0000000 /* OR addr mask */ - -/* FLASH timing: ACS = 11, TRLX = 0, CSNT = 1, SCY = 5, EHTR = 1 */ -#define CONFIG_SYS_OR_TIMING_FLASH (OR_CSNT_SAM | OR_BI | OR_SCY_5_CLK | OR_TRLX) - -#define CONFIG_SYS_OR0_REMAP (CONFIG_SYS_REMAP_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_BR0_PRELIM ((FLASH_BASE0_PRELIM & BR_BA_MSK) | BR_PS_8 | BR_V ) - -/* - * BR3 and OR3 (SDRAM) - * - */ -#define SDRAM_BASE3_PRELIM 0x00000000 /* SDRAM bank #0 */ -#define SDRAM_MAX_SIZE 0x04000000 /* max 64 MB per bank */ - -/* SDRAM timing: Multiplexed addresses, GPL5 output to GPL5_A (don't care) */ -#define CONFIG_SYS_OR_TIMING_SDRAM (OR_CSNT_SAM | OR_G5LS) - -#define CONFIG_SYS_OR3_PRELIM ((0xFFFFFFFFLU & ~(SDRAM_MAX_SIZE - 1)) | CONFIG_SYS_OR_TIMING_SDRAM) -#define CONFIG_SYS_BR3_PRELIM ((SDRAM_BASE3_PRELIM & BR_BA_MSK) | BR_MS_UPMA | BR_PS_32 | BR_V) - -/* - * Memory Periodic Timer Prescaler - */ - -/* periodic timer for refresh */ -#define CONFIG_SYS_MAMR_PTA 208 - -/* refresh rate 7.8 us (= 64 ms / 8K = 31.2 / quad bursts) for 256 MBit */ -#define CONFIG_SYS_MPTPR_1BK_8K MPTPR_PTP_DIV16 /* setting for 1 bank */ - -/* - * MAMR settings for SDRAM - */ - -/* 9 column SDRAM */ -#define CONFIG_SYS_MAMR_9COL ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_1 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A10 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) - -/* Ethernet at SCC2 */ -#define CONFIG_SCC2_ENET - -/****************************************************************/ - -#define DSP_SIZE 0x00010000 /* 64K */ -#define FPGA_SIZE 0x00010000 /* 64K */ - -#define DSP0_BASE 0xF1000000 -#define DSP1_BASE (DSP0_BASE + DSP_SIZE) -#define FPGA_BASE (DSP1_BASE + DSP_SIZE) - -#if defined(CONFIG_NETVIA_VERSION) && CONFIG_NETVIA_VERSION >= 2 - -#define ER_SIZE 0x00010000 /* 64K */ -#define ER_BASE (FPGA_BASE + FPGA_SIZE) - -#define NAND_SIZE 0x00010000 /* 64K */ -#define NAND_BASE (ER_BASE + ER_SIZE) - -#endif - -/****************************************************************/ - -#if defined(CONFIG_NETVIA_VERSION) && CONFIG_NETVIA_VERSION >= 2 - -#define STATUS_LED_BIT 0x00000001 /* bit 31 */ -#define STATUS_LED_PERIOD (CONFIG_SYS_HZ / 2) -#define STATUS_LED_STATE STATUS_LED_BLINKING - -#define STATUS_LED_BIT1 0x00000002 /* bit 30 */ -#define STATUS_LED_PERIOD1 (CONFIG_SYS_HZ / 2) -#define STATUS_LED_STATE1 STATUS_LED_OFF - -#define STATUS_LED_ACTIVE 0 /* LED on for bit == 0 */ -#define STATUS_LED_BOOT 0 /* LED 0 used for boot status */ - -#endif - - -/*****************************************************************************/ - -#ifndef __ASSEMBLY__ - -#if defined(CONFIG_NETVIA_VERSION) && CONFIG_NETVIA_VERSION >= 2 - -/* LEDs */ - -/* last value written to the external register; we cannot read back */ -extern unsigned int last_er_val; - -/* led_id_t is unsigned long mask */ -typedef unsigned int led_id_t; - -static inline void __led_init(led_id_t mask, int state) -{ - unsigned int new_er_val; - - if (state) - new_er_val = last_er_val & ~mask; - else - new_er_val = last_er_val | mask; - - *(volatile unsigned int *)ER_BASE = new_er_val; - last_er_val = new_er_val; -} - -static inline void __led_toggle(led_id_t mask) -{ - unsigned int new_er_val; - - new_er_val = last_er_val ^ mask; - *(volatile unsigned int *)ER_BASE = new_er_val; - last_er_val = new_er_val; -} - -static inline void __led_set(led_id_t mask, int state) -{ - unsigned int new_er_val; - - if (state) - new_er_val = last_er_val & ~mask; - else - new_er_val = last_er_val | mask; - - *(volatile unsigned int *)ER_BASE = new_er_val; - last_er_val = new_er_val; -} - -/* MAX3100 console */ -#define MAX3100_SPI_RXD_PORT (((volatile immap_t *)CONFIG_SYS_IMMR)->im_cpm.cp_pbdat) -#define MAX3100_SPI_RXD_BIT 0x00000008 - -#define MAX3100_SPI_TXD_PORT (((volatile immap_t *)CONFIG_SYS_IMMR)->im_cpm.cp_pbdat) -#define MAX3100_SPI_TXD_BIT 0x00000004 - -#define MAX3100_SPI_CLK_PORT (((volatile immap_t *)CONFIG_SYS_IMMR)->im_cpm.cp_pbdat) -#define MAX3100_SPI_CLK_BIT 0x00000002 - -#define MAX3100_CS_PORT (((volatile immap_t *)CONFIG_SYS_IMMR)->im_ioport.iop_pddat) -#define MAX3100_CS_BIT 0x0010 - -#endif - -#endif - -/*************************************************************************************************/ - -#endif /* __CONFIG_H */ diff --git a/include/status_led.h b/include/status_led.h index 1feeff5..919e3ae 100644 --- a/include/status_led.h +++ b/include/status_led.h @@ -122,29 +122,6 @@ void status_led_set (int led, int state); * filling this file up with lots of custom board stuff. */
-/***** NetVia ********************************************************/ -#elif defined(CONFIG_NETVIA) - -#if !defined(CONFIG_NETVIA_VERSION) || CONFIG_NETVIA_VERSION == 1 - -#define STATUS_LED_PAR im_ioport.iop_pdpar -#define STATUS_LED_DIR im_ioport.iop_pddir -#undef STATUS_LED_ODR -#define STATUS_LED_DAT im_ioport.iop_pddat - -# define STATUS_LED_BIT 0x0080 /* PD.8 */ -# define STATUS_LED_PERIOD (CONFIG_SYS_HZ / 2) -# define STATUS_LED_STATE STATUS_LED_BLINKING - -# define STATUS_LED_BIT1 0x0040 /* PD.9 */ -# define STATUS_LED_PERIOD1 (CONFIG_SYS_HZ / 2) -# define STATUS_LED_STATE1 STATUS_LED_OFF - -# define STATUS_LED_ACTIVE 0 /* LED on for bit == 0 */ -# define STATUS_LED_BOOT 0 /* LED 0 used for boot status */ - -#endif - /***** CMI ********************************************************/ #elif defined(CONFIG_CMI) # define STATUS_LED_DIR im_mios.mios_mpiosm32ddr
On Mon, Dec 15, 2014 at 11:26:13PM +0900, Masahiro Yamada wrote:
This board is still a non-generic board.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Wolfgang Denk wd@denx.de ---
arch/powerpc/cpu/mpc8xx/Kconfig | 4 - arch/powerpc/cpu/mpc8xx/cpu.c | 46 +- arch/powerpc/cpu/mpc8xx/cpu_init.c | 1 - arch/powerpc/cpu/mpc8xx/i2c.c | 7 - arch/powerpc/cpu/mpc8xx/scc.c | 4 - arch/powerpc/cpu/mpc8xx/serial.c | 16 - arch/powerpc/include/asm/global_data.h | 2 +- board/lwmon/Kconfig | 9 - board/lwmon/MAINTAINERS | 6 - board/lwmon/Makefile | 8 - board/lwmon/README.keybd | 126 ---- board/lwmon/flash.c | 632 ------------------- board/lwmon/lwmon.c | 1071 -------------------------------- board/lwmon/pcmcia.c | 234 ------- board/lwmon/u-boot.lds.debug | 122 ---- configs/lwmon_defconfig | 3 - doc/README.scrapyard | 1 + drivers/pcmcia/mpc8xx_pcmcia.c | 6 - drivers/video/mpc8xx_lcd.c | 11 - examples/standalone/test_burst.c | 19 - include/common.h | 4 - include/commproc.h | 26 - include/configs/lwmon.h | 587 ----------------- include/pcmcia.h | 2 - 24 files changed, 3 insertions(+), 2944 deletions(-) delete mode 100644 board/lwmon/Kconfig delete mode 100644 board/lwmon/MAINTAINERS delete mode 100644 board/lwmon/Makefile delete mode 100644 board/lwmon/README.keybd delete mode 100644 board/lwmon/flash.c delete mode 100644 board/lwmon/lwmon.c delete mode 100644 board/lwmon/pcmcia.c delete mode 100644 board/lwmon/u-boot.lds.debug delete mode 100644 configs/lwmon_defconfig delete mode 100644 include/configs/lwmon.h
diff --git a/arch/powerpc/cpu/mpc8xx/Kconfig b/arch/powerpc/cpu/mpc8xx/Kconfig index b510e1f..4d47d05 100644 --- a/arch/powerpc/cpu/mpc8xx/Kconfig +++ b/arch/powerpc/cpu/mpc8xx/Kconfig @@ -22,9 +22,6 @@ config TARGET_IVML24 config TARGET_IVMS8 bool "Support IVMS8"
-config TARGET_LWMON - bool "Support lwmon" - config TARGET_TQM823L bool "Support TQM823L"
@@ -67,7 +64,6 @@ source "board/cogent/Kconfig" source "board/esteem192e/Kconfig" source "board/ip860/Kconfig" source "board/ivm/Kconfig" -source "board/lwmon/Kconfig" source "board/tqc/tqm8xx/Kconfig"
endmenu diff --git a/arch/powerpc/cpu/mpc8xx/cpu.c b/arch/powerpc/cpu/mpc8xx/cpu.c index 9967664..105be9c 100644 --- a/arch/powerpc/cpu/mpc8xx/cpu.c +++ b/arch/powerpc/cpu/mpc8xx/cpu.c @@ -457,8 +457,6 @@ void upmconfig (uint upm, uint * table, uint size)
-#ifndef CONFIG_LWMON - int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { ulong msr, addr; @@ -493,32 +491,6 @@ int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 1; }
-#else /* CONFIG_LWMON */ - -/* - * On the LWMON board, the MCLR reset input of the PIC's on the board - * uses a 47K/1n RC combination which has a 47us time constant. The - * low signal on the HRESET pin of the CPU is only 512 clocks = 8 us - * and thus too short to reset the external hardware. So we use the - * watchdog to reset the board. - */ -int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - /* prevent triggering the watchdog */ - disable_interrupts (); - - /* make sure the watchdog is running */ - reset_8xx_watchdog ((immap_t *) CONFIG_SYS_IMMR); - - /* wait for watchdog reset */ - while (1) {}; - - /* NOTREACHED */ - return 1; -} - -#endif /* CONFIG_LWMON */ - /* ------------------------------------------------------------------------- */
/* @@ -580,31 +552,15 @@ void watchdog_reset (void) } #endif /* CONFIG_WATCHDOG */
-#if defined(CONFIG_WATCHDOG) || defined(CONFIG_LWMON) +#if defined(CONFIG_WATCHDOG)
void reset_8xx_watchdog (volatile immap_t * immr) { -# if defined(CONFIG_LWMON) - /* - * The LWMON board uses a MAX6301 Watchdog - * with the trigger pin connected to port PA.7 - * - * (The old board version used a MAX706TESA Watchdog, which - * had to be handled exactly the same.) - */ -# define WATCHDOG_BIT 0x0100 - immr->im_ioport.iop_papar &= ~(WATCHDOG_BIT); /* GPIO */ - immr->im_ioport.iop_padir |= WATCHDOG_BIT; /* Output */ - immr->im_ioport.iop_paodr &= ~(WATCHDOG_BIT); /* active output */ - - immr->im_ioport.iop_padat ^= WATCHDOG_BIT; /* Toggle WDI */ -# else /* * All other boards use the MPC8xx Internal Watchdog */ immr->im_siu_conf.sc_swsr = 0x556c; /* write magic1 */ immr->im_siu_conf.sc_swsr = 0xaa39; /* write magic2 */ -# endif /* CONFIG_LWMON */ } #endif /* CONFIG_WATCHDOG */
diff --git a/arch/powerpc/cpu/mpc8xx/cpu_init.c b/arch/powerpc/cpu/mpc8xx/cpu_init.c index 9350fdd..d41fa88 100644 --- a/arch/powerpc/cpu/mpc8xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc8xx/cpu_init.c @@ -128,7 +128,6 @@ void cpu_init_f (volatile immap_t * immr) #if defined(CONFIG_IP860) || \ defined(CONFIG_IVML24) || \ defined(CONFIG_IVMS8) || \ - defined(CONFIG_LWMON) || \ defined(CONFIG_RMU)
memctl->memc_br0 = CONFIG_SYS_BR0_PRELIM; diff --git a/arch/powerpc/cpu/mpc8xx/i2c.c b/arch/powerpc/cpu/mpc8xx/i2c.c index 2f8b139..6146de3 100644 --- a/arch/powerpc/cpu/mpc8xx/i2c.c +++ b/arch/powerpc/cpu/mpc8xx/i2c.c @@ -17,9 +17,6 @@
#include <commproc.h> #include <i2c.h> -#ifdef CONFIG_LWMON -#include <watchdog.h> -#endif
DECLARE_GLOBAL_DATA_PTR;
@@ -591,10 +588,6 @@ int i2c_read(uchar chip, uint addr, int alen, uchar *buffer, int len) uchar xaddr[4]; int rc;
-#ifdef CONFIG_LWMON - WATCHDOG_RESET(); -#endif - xaddr[0] = (addr >> 24) & 0xFF; xaddr[1] = (addr >> 16) & 0xFF; xaddr[2] = (addr >> 8) & 0xFF; diff --git a/arch/powerpc/cpu/mpc8xx/scc.c b/arch/powerpc/cpu/mpc8xx/scc.c index 610fd78..251966b 100644 --- a/arch/powerpc/cpu/mpc8xx/scc.c +++ b/arch/powerpc/cpu/mpc8xx/scc.c @@ -193,10 +193,6 @@ static int scc_init (struct eth_device *dev, bd_t * bis)
volatile immap_t *immr = (immap_t *) CONFIG_SYS_IMMR;
-#if defined(CONFIG_LWMON) - reset_phy(); -#endif - pram_ptr = (scc_enet_t *) & (immr->im_cpm.cp_dparam[PROFF_ENET]);
rxIdx = 0; diff --git a/arch/powerpc/cpu/mpc8xx/serial.c b/arch/powerpc/cpu/mpc8xx/serial.c index b1625fb..bb16b17 100644 --- a/arch/powerpc/cpu/mpc8xx/serial.c +++ b/arch/powerpc/cpu/mpc8xx/serial.c @@ -405,22 +405,6 @@ static int scc_init (void) sp = (scc_t *) &(cp->cp_scc[SCC_INDEX]); up = (scc_uart_t *) &cp->cp_dparam[PROFF_SCC];
-#if defined(CONFIG_LWMON) && defined(CONFIG_8xx_CONS_SCC2) - { /* Disable Ethernet, enable Serial */ - uchar c; - - c = pic_read (0x61); - c &= ~0x40; /* enable COM3 */ - c |= 0x80; /* disable Ethernet */ - pic_write (0x61, c); - - /* enable RTS2 */ - cp->cp_pbpar |= 0x2000; - cp->cp_pbdat |= 0x2000; - cp->cp_pbdir |= 0x2000; - } -#endif /* CONFIG_LWMON */ - /* Disable transmitter/receiver. */ sp->scc_gsmrl &= ~(SCC_GSMRL_ENR | SCC_GSMRL_ENT);
diff --git a/arch/powerpc/include/asm/global_data.h b/arch/powerpc/include/asm/global_data.h index 8e59e8b..4430477 100644 --- a/arch/powerpc/include/asm/global_data.h +++ b/arch/powerpc/include/asm/global_data.h @@ -109,7 +109,7 @@ struct arch_global_data { #if defined(CONFIG_WD_MAX_RATE) unsigned long long wdt_last; /* trace watch-dog triggering rate */ #endif -#if defined(CONFIG_LWMON) || defined(CONFIG_LWMON5) +#if defined(CONFIG_LWMON5) unsigned long kbd_status; #endif }; diff --git a/board/lwmon/Kconfig b/board/lwmon/Kconfig deleted file mode 100644 index e98c794..0000000 --- a/board/lwmon/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_LWMON - -config SYS_BOARD - default "lwmon" - -config SYS_CONFIG_NAME - default "lwmon" - -endif diff --git a/board/lwmon/MAINTAINERS b/board/lwmon/MAINTAINERS deleted file mode 100644 index 763ce22..0000000 --- a/board/lwmon/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -LWMON BOARD -M: Wolfgang Denk wd@denx.de -S: Maintained -F: board/lwmon/ -F: include/configs/lwmon.h -F: configs/lwmon_defconfig diff --git a/board/lwmon/Makefile b/board/lwmon/Makefile deleted file mode 100644 index 599a613..0000000 --- a/board/lwmon/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2001-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = lwmon.o flash.o pcmcia.o diff --git a/board/lwmon/README.keybd b/board/lwmon/README.keybd deleted file mode 100644 index 5e5144e..0000000 --- a/board/lwmon/README.keybd +++ /dev/null @@ -1,126 +0,0 @@ - -Tastaturabfrage: - -Die Implementierung / Decodierung beruht auf den Angaben aus dem Do- -kument "PIC LWE-Tastatur" in der Fassung vom 9. 3. 2001, insbesonde- -re Tabelle 3 im Kapitel 4.3 Tastencodes. In U-Boot werden die vom -Keyboard-Controller gelesenen Daten hexadezimal codiert in der auto- -matisch angelegten Environment-Variablen "keybd" übergeben. Ist kei- -ne Taste gedrückt worden, steht dort: - - keybd=000000000000000000 - -Der decodierte Tastencode ("keybd") kann mit den "bootargs" an den -Linux-Kernel übergeben und dort z. B. in einem Device-Treiber oder -einer Applikation ausgewertet werden. - - -Sonderfunktionen beim Booten: - -Es lassen sich eine oder mehrere (beliebig viele) Tasten oder Tasten- -kombinationen definieren, die Sonderfunktionen auslösen, wenn diese -Tasten beim Booten (Reset) gedrückt sind. - -Wird eine eingestellte Taste bzw. Tastenkombination erkannt, so wird -in U-Boot noch vor dem Start des "Countdown" und somit vor jedem an- -deren Kommando der Inhalt einer dieser Taste bzw. Tastenkombination -zugeordneten Environment-Variablen ausführen. - - -Die Environment-Variable "magic_keys" wird als Liste von Zeichen ver- -standen, die als Suffix an den Namen "key_magic" angefügt werden und -so die Namen der Environment-Variablen definieren, mit denen die -Tasten (-kombinationen) festgelegt werden: - -Ist "magic_keys" NICHT definiert, so wird nur die in der Environment- -Variablen "key_magic" codierte Tasten (-kombination) geprüft, und -ggf. der Inhalt der Environment-Variablen "key_cmd" ausgeführt (ge- -nauer: der Inhalt von "key_cmd" wird der Variablen "preboot" zugewie- -sen, die ausgeführt wird, unmittelbar bevor die interaktive Kommando- -interpretation beginnt). - -Enthält "magic_keys" z. B. die Zeichenkette "0123CB*", so werden -nacheinander folgende Aktionen ausgeführt: - - prüfe Tastencode ggf. führe aus Kommando - in Variable in Variable - ----------------------------------- - key_magic0 ==> key_cmd0 - key_magic1 ==> key_cmd1 - key_magic2 ==> key_cmd2 - key_magic3 ==> key_cmd3 - key_magicC ==> key_cmdC - key_magicB ==> key_cmdB - key_magicA ==> key_cmdA - key_magic* ==> key_cmd* - -Hinweis: sobald ein aktivierter Tastencode erkannt wurde, wird die -Bearbeitung abgebrochen; es wird daher höchstens eines der definier- -ten Kommandos ausgeführt, wobei die Priorität durch die Suchreihen- -folge festgelegt wird, also durch die Reihenfolge der Zeichen in der -Varuiablen "magic_keys". - - -Die Codierung der Tasten, die beim Booten gedrückt werden müssen, um -eine Funktion auszulösen, erfolgt nach der Tastaturtabelle. - -Die Definitionen - - => setenv key_magic0 3a+3b - => setenv key_cmd0 setenv bootdelay 30 - -bedeuten dementsprechend, daß die Tasten mit den Codes 0x3A (Taste -"F1") und 0x3B (Taste "F2") gleichzeitig gedrückt werden müssen. Sie -können dort eine beliebige Tastenkombination eintragen (jeweils 2 -Zeichen für die Hex-Codes der Tasten, und '+' als Trennzeichen). - -Wird die eingestellte Tastenkombination erkannt, so wird in U-Boot -noch vor dem Start des "Countdown" und somit vor jedem anderen Kom- -mando das angebene Kommando ausgeführt und somit ein langes Boot- -Delay eingetragen. - -Praktisch könnten Sie also in U-Boot "bootdelay" auf 0 setzen und -somit stets ohne jede User-Interaktion automatisch booten, außer, -wenn die beiden Tasten "F1" und "F2" beim Booten gedrückt werden: -dann würde ein Boot-Delay von 30 Sekunden eingefügt. - - -Hinweis: dem Zeichen '#' kommt innerhalb von "magic_keys" eine beson- -dere Bedeutung zu: die dadurch definierte Key-Sequenz schaltet den -Monitor in den "Debug-Modus" - das bedeutet zunächst, daß alle weite- -ren Meldungen von U-Boot über das LCD-Display ausgegeben werden; -außerdem kann man durch das mit dieser Tastenkombination verknüpfte -Kommando z. B. die Linux-Bootmeldungen ebenfalls auf das LCD-Display -legen, so daß der Boot-Vorgang direkt und ohne weitere Hilfsmittel -analysiert werden kann. - -Beispiel: - -In U-Boot werden folgende Environment-Variablen gesetzt und abgespei- -chert: - -(1) => setenv magic_keys 01234#X -(2) => setenv key_cmd# setenv addfb setenv bootargs \${bootargs} console=tty0 console=ttyS1,\${baudrate} -(3) => setenv nfsargs setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath} -(4) => setenv addip setenv bootargs ${bootargs} ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off panic=1 -(5) => setenv addfb setenv bootargs ${bootargs} console=ttyS1,${baudrate} -(6) => setenv bootcmd bootp;run nfsargs;run addip;run addfb;bootm - -Hierbei wird die Linux Commandline (in der Variablen "bootargs") im -Boot-Kommando "bootcmd" (6) schrittweise zusammengesetzt: zunächst -werden die für Root-Filesystem über NFS erforderlichen Optionen ge- -setzt ("run nfsargs", vgl. (3)), dann die Netzwerkkonfiguration an- -gefügt ("run addip", vgl. (4)), und schließlich die Systemconsole -definiert ("run addfb"). - -Dabei wird im Normalfall die Definition (5) verwendt; wurde aller- -dings beim Reset die entsprechende Taste gedrückt gehalten, so wird -diese Definition bei der Ausführung des in (2) definierten Kommandos -überschrieben, so daß Linux die Bootmeldungen auch über das Frame- -buffer-Device (=LCD-Display) ausgibt. - -Beachten Sie die Verdoppelung der ''-Escapes in der Definition von -"key_cmd#" - diese ist erforderlich, weil der String _zweimal_ inter- -pretiert wird: das erste Mal bei der Eingabe von "key_cmd#", das -zweite Mal, wenn der String (als Inhalt von "preboot") ausgeführt -wird. diff --git a/board/lwmon/flash.c b/board/lwmon/flash.c deleted file mode 100644 index cb60c41..0000000 --- a/board/lwmon/flash.c +++ /dev/null @@ -1,632 +0,0 @@ -/* - * (C) Copyright 2001 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* #define DEBUG */ - -#include <common.h> -#include <mpc8xx.h> - -#if defined(CONFIG_ENV_IS_IN_FLASH) -# ifndef CONFIG_ENV_ADDR -# define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET) -# endif -# ifndef CONFIG_ENV_SIZE -# define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -# endif -# ifndef CONFIG_ENV_SECT_SIZE -# define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE -# endif -#endif - -/*---------------------------------------------------------------------*/ - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH chips */ - -/*----------------------------------------------------------------------- - * Functions - */ -static ulong flash_get_size (vu_long *addr, flash_info_t *info); -static int write_data (flash_info_t *info, ulong dest, ulong data); -#ifdef CONFIG_SYS_FLASH_USE_BUFFER_WRITE -static int write_data_buf (flash_info_t * info, ulong dest, uchar * cp, int len); -#endif -static void flash_get_offsets (ulong base, flash_info_t *info); - -/*----------------------------------------------------------------------- - */ - -unsigned long flash_init (void) -{ - volatile immap_t *immap = (immap_t *)CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - unsigned long size_b0, size_b1; - int i; - - /* Init: no FLASHes known */ - for (i=0; i<CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - } - - /* Static FLASH Bank configuration here - FIXME XXX */ - - debug ("\n## Get flash bank 1 size @ 0x%08x\n",FLASH_BASE0_PRELIM); - - size_b0 = flash_get_size((vu_long *)FLASH_BASE0_PRELIM, &flash_info[0]); - - if (flash_info[0].flash_id == FLASH_UNKNOWN) { - printf ("## Unknown FLASH on Bank 0: " - "ID 0x%lx, Size = 0x%08lx = %ld MB\n", - flash_info[0].flash_id, - size_b0, size_b0<<20); - } - - debug ("## Get flash bank 2 size @ 0x%08x\n",FLASH_BASE1_PRELIM); - - size_b1 = flash_get_size((vu_long *)FLASH_BASE1_PRELIM, &flash_info[1]); - - debug ("## Prelim. Flash bank sizes: %08lx + 0x%08lx\n",size_b0,size_b1); - - if (size_b1 > size_b0) { - printf ("## ERROR: " - "Bank 1 (0x%08lx = %ld MB) > Bank 0 (0x%08lx = %ld MB)\n", - size_b1, size_b1<<20, - size_b0, size_b0<<20 - ); - flash_info[0].flash_id = FLASH_UNKNOWN; - flash_info[1].flash_id = FLASH_UNKNOWN; - flash_info[0].sector_count = -1; - flash_info[1].sector_count = -1; - flash_info[0].size = 0; - flash_info[1].size = 0; - return (0); - } - - debug ("## Before remap: " - "BR0: 0x%08x OR0: 0x%08x " - "BR1: 0x%08x OR1: 0x%08x\n", - memctl->memc_br0, memctl->memc_or0, - memctl->memc_br1, memctl->memc_or1); - - /* Remap FLASH according to real size */ - memctl->memc_or0 = (-size_b0 & 0xFFFF8000) | CONFIG_SYS_OR_TIMING_FLASH | - OR_CSNT_SAM | OR_ACS_DIV1; - memctl->memc_br0 = (CONFIG_SYS_FLASH_BASE & BR_BA_MSK) | BR_PS_32 | BR_V; - - debug ("## BR0: 0x%08x OR0: 0x%08x\n", - memctl->memc_br0, memctl->memc_or0); - - /* Re-do sizing to get full correct info */ - size_b0 = flash_get_size((vu_long *)CONFIG_SYS_FLASH_BASE, &flash_info[0]); - - flash_get_offsets (CONFIG_SYS_FLASH_BASE, &flash_info[0]); - - flash_info[0].size = size_b0; - -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE - /* monitor protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE+monitor_flash_len-1, - &flash_info[0]); -#endif - -#ifdef CONFIG_ENV_IS_IN_FLASH - /* ENV protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR+CONFIG_ENV_SECT_SIZE-1, - &flash_info[0]); -#endif - - if (size_b1) { - memctl->memc_or1 = (-size_b1 & 0xFFFF8000) | CONFIG_SYS_OR_TIMING_FLASH | - OR_CSNT_SAM | OR_ACS_DIV1; - memctl->memc_br1 = ((CONFIG_SYS_FLASH_BASE + size_b0) & BR_BA_MSK) | - BR_PS_32 | BR_V; - - debug ("## BR1: 0x%08x OR1: 0x%08x\n", - memctl->memc_br1, memctl->memc_or1); - - /* Re-do sizing to get full correct info */ - size_b1 = flash_get_size((vu_long *)(CONFIG_SYS_FLASH_BASE + size_b0), - &flash_info[1]); - - flash_info[1].size = size_b1; - - flash_get_offsets (CONFIG_SYS_FLASH_BASE + size_b0, &flash_info[1]); - -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE - /* monitor protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE+monitor_flash_len-1, - &flash_info[1]); -#endif - -#ifdef CONFIG_ENV_IS_IN_FLASH - /* ENV protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR+CONFIG_ENV_SECT_SIZE-1, - &flash_info[1]); -#endif - } else { - memctl->memc_br1 = 0; /* invalidate bank */ - memctl->memc_or1 = 0; /* invalidate bank */ - - debug ("## DISABLE BR1: 0x%08x OR1: 0x%08x\n", - memctl->memc_br1, memctl->memc_or1); - - flash_info[1].flash_id = FLASH_UNKNOWN; - flash_info[1].sector_count = -1; - flash_info[1].size = 0; - } - - debug ("## Final Flash bank sizes: %08lx + 0x%08lx\n",size_b0,size_b1); - - return (size_b0 + size_b1); -} - -/*----------------------------------------------------------------------- - */ -static void flash_get_offsets (ulong base, flash_info_t *info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_INTEL: - for (i = 0; i < info->sector_count; i++) { - info->start[i] = base; - base += 0x00020000 * 2; /* 128k * 2 chips per bank */ - } - return; - - default: - printf ("Don't know sector ofsets for flash type 0x%lx\n", - info->flash_id); - return; - } -} - -/*----------------------------------------------------------------------- - */ -void flash_print_info (flash_info_t *info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_AMD: printf ("AMD "); break; - case FLASH_MAN_FUJ: printf ("Fujitsu "); break; - case FLASH_MAN_SST: printf ("SST "); break; - case FLASH_MAN_STM: printf ("STM "); break; - case FLASH_MAN_INTEL: printf ("Intel "); break; - case FLASH_MAN_MT: printf ("MT "); break; - default: printf ("Unknown Vendor "); break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_28F320J3A: printf ("28F320J3A (32Mbit = 128K x 32)\n"); - break; - case FLASH_28F640J3A: printf ("28F640J3A (64Mbit = 128K x 64)\n"); - break; - case FLASH_28F128J3A: printf ("28F128J3A (128Mbit = 128K x 128)\n"); - break; - default: printf ("Unknown Chip Type\n"); - break; - } - - if (info->size >= (1 << 20)) { - i = 20; - } else { - i = 10; - } - printf (" Size: %ld %cB in %d Sectors\n", - info->size >> i, - (i == 20) ? 'M' : 'k', - info->sector_count); - - printf (" Sector Start Addresses:"); - for (i=0; i<info->sector_count; ++i) { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", - info->start[i], - info->protect[i] ? " (RO)" : " " - ); - } - printf ("\n"); - return; -} - -/*----------------------------------------------------------------------- - */ - - -/*----------------------------------------------------------------------- - */ - -/* - * The following code cannot be run from FLASH! - */ - -static ulong flash_get_size (vu_long *addr, flash_info_t *info) -{ - ulong value; - - /* Read Manufacturer ID */ - addr[0] = 0x00900090; - value = addr[0]; - - debug ("Manuf. ID @ 0x%08lx: 0x%08lx\n", (ulong)addr, value); - - switch (value) { - case AMD_MANUFACT: - info->flash_id = FLASH_MAN_AMD; - break; - case FUJ_MANUFACT: - info->flash_id = FLASH_MAN_FUJ; - break; - case SST_MANUFACT: - info->flash_id = FLASH_MAN_SST; - break; - case STM_MANUFACT: - info->flash_id = FLASH_MAN_STM; - break; - case INTEL_MANUFACT: - info->flash_id = FLASH_MAN_INTEL; - break; - default: - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - addr[0] = 0x00FF00FF; /* restore read mode */ - return (0); /* no or unknown flash */ - } - - value = addr[1]; /* device ID */ - - debug ("Device ID @ 0x%08lx: 0x%08lx\n", (ulong)(&addr[1]), value); - - switch (value) { - case INTEL_ID_28F320J3A: - info->flash_id += FLASH_28F320J3A; - info->sector_count = 32; - info->size = 0x00400000 * 2; - break; /* => 8 MB */ - - case INTEL_ID_28F640J3A: - info->flash_id += FLASH_28F640J3A; - info->sector_count = 64; - info->size = 0x00800000 * 2; - break; /* => 16 MB */ - - case INTEL_ID_28F128J3A: - info->flash_id += FLASH_28F128J3A; - info->sector_count = 128; - info->size = 0x01000000 * 2; - break; /* => 32 MB */ - - default: - info->flash_id = FLASH_UNKNOWN; - addr[0] = 0x00FF00FF; /* restore read mode */ - return (0); /* => no or unknown flash */ - - } - - if (info->sector_count > CONFIG_SYS_MAX_FLASH_SECT) { - printf ("** ERROR: sector count %d > max (%d) **\n", - info->sector_count, CONFIG_SYS_MAX_FLASH_SECT); - info->sector_count = CONFIG_SYS_MAX_FLASH_SECT; - } - - addr[0] = 0x00FF00FF; /* restore read mode */ - - return (info->size); -} - - -/*----------------------------------------------------------------------- - */ - -int flash_erase (flash_info_t *info, int s_first, int s_last) -{ - int flag, prot, sect; - ulong start, now, last; - - debug ("flash_erase: first: %d last: %d\n", s_first, s_last); - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - if ((info->flash_id & FLASH_VENDMASK) != FLASH_MAN_INTEL) { - printf ("Can erase only Intel flash types - aborted\n"); - return 1; - } - - prot = 0; - for (sect=s_first; sect<=s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - printf ("\n"); - } - - start = get_timer (0); - last = start; - /* Start erase on unprotected sectors */ - for (sect = s_first; sect<=s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - vu_long *addr = (vu_long *)(info->start[sect]); - unsigned long status; - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - *addr = 0x00600060; /* clear lock bit setup */ - *addr = 0x00D000D0; /* clear lock bit confirm */ - - udelay (1000); - /* This takes awfully long - up to 50 ms and more */ - while (((status = *addr) & 0x00800080) != 0x00800080) { - if ((now=get_timer(start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - *addr = 0x00FF00FF; /* reset to read mode */ - return 1; - } - - /* show that we're waiting */ - if ((now - last) > 1000) { /* every second */ - putc ('.'); - last = now; - } - udelay (1000); /* to trigger the watchdog */ - } - - *addr = 0x00500050; /* clear status register */ - *addr = 0x00200020; /* erase setup */ - *addr = 0x00D000D0; /* erase confirm */ - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - - while (((status = *addr) & 0x00800080) != 0x00800080) { - if ((now=get_timer(start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - *addr = 0x00B000B0; /* suspend erase */ - *addr = 0x00FF00FF; /* reset to read mode */ - return 1; - } - - /* show that we're waiting */ - if ((now - last) > 1000) { /* every second */ - putc ('.'); - last = now; - } - udelay (1000); /* to trigger the watchdog */ - } - - *addr = 0x00FF00FF; /* reset to read mode */ - } - } - printf (" done\n"); - return 0; -} - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - * 4 - Flash not identified - */ - -#define FLASH_WIDTH 4 /* flash bus width in bytes */ - -int write_buff (flash_info_t *info, uchar *src, ulong addr, ulong cnt) -{ - ulong cp, wp, data; - int i, l, rc; - - if (info->flash_id == FLASH_UNKNOWN) { - return 4; - } - - wp = (addr & ~(FLASH_WIDTH-1)); /* get lower FLASH_WIDTH aligned address */ - - /* - * handle unaligned start bytes - */ - if ((l = addr - wp) != 0) { - data = 0; - for (i=0, cp=wp; i<l; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - for (; i<FLASH_WIDTH && cnt>0; ++i) { - data = (data << 8) | *src++; - --cnt; - ++cp; - } - for (; cnt==0 && i<FLASH_WIDTH; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - - if ((rc = write_data(info, wp, data)) != 0) { - return (rc); - } - wp += FLASH_WIDTH; - } - - /* - * handle FLASH_WIDTH aligned part - */ -#ifdef CONFIG_SYS_FLASH_USE_BUFFER_WRITE - while(cnt >= FLASH_WIDTH) { - i = CONFIG_SYS_FLASH_BUFFER_SIZE > cnt ? - (cnt & ~(FLASH_WIDTH - 1)) : CONFIG_SYS_FLASH_BUFFER_SIZE; - if((rc = write_data_buf(info, wp, src,i)) != 0) - return rc; - wp += i; - src += i; - cnt -=i; - } -#else - while (cnt >= FLASH_WIDTH) { - data = 0; - for (i=0; i<FLASH_WIDTH; ++i) { - data = (data << 8) | *src++; - } - if ((rc = write_data(info, wp, data)) != 0) { - return (rc); - } - wp += FLASH_WIDTH; - cnt -= FLASH_WIDTH; - } -#endif /* CONFIG_SYS_FLASH_USE_BUFFER_WRITE */ - - if (cnt == 0) { - return (0); - } - - /* - * handle unaligned tail bytes - */ - data = 0; - for (i=0, cp=wp; i<FLASH_WIDTH && cnt>0; ++i, ++cp) { - data = (data << 8) | *src++; - --cnt; - } - for (; i<FLASH_WIDTH; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - - return (write_data(info, wp, data)); -} - -/*----------------------------------------------------------------------- - * Check flash status, returns: - * 0 - OK - * 1 - timeout - */ -static int flash_status_check(vu_long *addr, ulong tout, char * prompt) -{ - ulong status; - ulong start; - - /* Wait for command completion */ - start = get_timer (0); - while(((status = *addr) & 0x00800080) != 0x00800080) { - if (get_timer(start) > tout) { - printf("Flash %s timeout at address %p\n", prompt, addr); - *addr = 0x00FF00FF; /* restore read mode */ - return (1); - } - } - return 0; -} - -/*----------------------------------------------------------------------- - * Write a word to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_data (flash_info_t *info, ulong dest, ulong data) -{ - vu_long *addr = (vu_long *)dest; - int flag; - - /* Check if Flash is (sufficiently) erased */ - if ((*addr & data) != data) { - return (2); - } - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - *addr = 0x00400040; /* write setup */ - *addr = data; - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - if (flash_status_check(addr, CONFIG_SYS_FLASH_WRITE_TOUT, "write") != 0) { - return (1); - } - - *addr = 0x00FF00FF; /* restore read mode */ - - return (0); -} - -#ifdef CONFIG_SYS_FLASH_USE_BUFFER_WRITE -/*----------------------------------------------------------------------- - * Write a buffer to Flash, returns: - * 0 - OK - * 1 - write timeout - */ -static int write_data_buf(flash_info_t * info, ulong dest, uchar * cp, int len) -{ - vu_long *addr = (vu_long *)dest; - int sector; - int cnt; - int retcode; - vu_long * src = (vu_long *)cp; - vu_long * dst = (vu_long *)dest; - - /* find sector */ - for(sector = info->sector_count - 1; sector >= 0; sector--) { - if(dest >= info->start[sector]) - break; - } - - *addr = 0x00500050; /* clear status */ - *addr = 0x00e800e8; /* write buffer */ - - if((retcode = flash_status_check(addr, CONFIG_SYS_FLASH_BUFFER_WRITE_TOUT, - "write to buffer")) == 0) { - cnt = len / FLASH_WIDTH; - *addr = (cnt-1) | ((cnt-1) << 16); - while(cnt-- > 0) { - *dst++ = *src++; - } - *addr = 0x00d000d0; /* write buffer confirm */ - retcode = flash_status_check(addr, CONFIG_SYS_FLASH_BUFFER_WRITE_TOUT, - "buffer write"); - } - *addr = 0x00FF00FF; /* restore read mode */ - *addr = 0x00500050; /* clear status */ - return retcode; -} -#endif /* CONFIG_SYS_USE_FLASH_BUFFER_WRITE */ - -/*----------------------------------------------------------------------- - */ diff --git a/board/lwmon/lwmon.c b/board/lwmon/lwmon.c deleted file mode 100644 index 225b1ef..0000000 --- a/board/lwmon/lwmon.c +++ /dev/null @@ -1,1071 +0,0 @@ -/*********************************************************************** - * -M* Modul: lwmon.c -M* -M* Content: LWMON specific U-Boot commands. - * - * (C) Copyright 2001, 2002 - * DENX Software Engineering - * Wolfgang Denk, wd@denx.de - * -D* Design: wd@denx.de -C* Coding: wd@denx.de -V* Verification: dzu@denx.de - * - * SPDX-License-Identifier: GPL-2.0+ - ***********************************************************************/ - -/*---------------------------- Headerfiles ----------------------------*/ -#include <common.h> -#include <mpc8xx.h> -#include <commproc.h> -#include <i2c.h> -#include <command.h> -#include <malloc.h> -#include <post.h> -#include <serial.h> - -#include <linux/types.h> -#include <linux/string.h> /* for strdup */ - -DECLARE_GLOBAL_DATA_PTR; - -/*------------------------ Local prototypes ---------------------------*/ -static long int dram_size (long int, long int *, long int); -static void kbd_init (void); -static int compare_magic (uchar *kbd_data, uchar *str); - - -/*--------------------- Local macros and constants --------------------*/ -#define _NOT_USED_ 0xFFFFFFFF - -#ifdef CONFIG_MODEM_SUPPORT -static int key_pressed(void); -extern void disable_putc(void); -#endif /* CONFIG_MODEM_SUPPORT */ - -/* - * 66 MHz SDRAM access using UPM A - */ -const uint sdram_table[] = -{ -#if defined(CONFIG_SYS_MEMORY_75) || defined(CONFIG_SYS_MEMORY_8E) - /* - * Single Read. (Offset 0 in UPM RAM) - */ - 0x1F0DFC04, 0xEEAFBC04, 0x11AF7C04, 0xEFBAFC00, - 0x1FF5FC47, /* last */ - /* - * SDRAM Initialization (offset 5 in UPM RAM) - * - * This is no UPM entry point. The following definition uses - * the remaining space to establish an initialization - * sequence, which is executed by a RUN command. - * - */ - 0x1FF5FC34, 0xEFEABC34, 0x1FB57C35, /* last */ - /* - * Burst Read. (Offset 8 in UPM RAM) - */ - 0x1F0DFC04, 0xEEAFBC04, 0x10AF7C04, 0xF0AFFC00, - 0xF0AFFC00, 0xF1AFFC00, 0xEFBAFC00, 0x1FF5FC47, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Single Write. (Offset 18 in UPM RAM) - */ - 0x1F2DFC04, 0xEEABBC00, 0x01B27C04, 0x1FF5FC47, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Burst Write. (Offset 20 in UPM RAM) - */ - 0x1F0DFC04, 0xEEABBC00, 0x10A77C00, 0xF0AFFC00, - 0xF0AFFC00, 0xE1BAFC04, 0x01FF5FC47, /* last */ - _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Refresh (Offset 30 in UPM RAM) - */ - 0x1FFD7C84, 0xFFFFFC04, 0xFFFFFC04, 0xFFFFFC04, - 0xFFFFFC84, 0xFFFFFC07, /* last */ - _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Exception. (Offset 3c in UPM RAM) - */ - 0x7FFFFC07, /* last */ - 0xFFFFFCFF, 0xFFFFFCFF, 0xFFFFFCFF, -#endif -#ifdef CONFIG_SYS_MEMORY_7E - /* - * Single Read. (Offset 0 in UPM RAM) - */ - 0x0E2DBC04, 0x11AF7C04, 0xEFBAFC00, 0x1FF5FC47, /* last */ - _NOT_USED_, - /* - * SDRAM Initialization (offset 5 in UPM RAM) - * - * This is no UPM entry point. The following definition uses - * the remaining space to establish an initialization - * sequence, which is executed by a RUN command. - * - */ - 0x1FF5FC34, 0xEFEABC34, 0x1FB57C35, /* last */ - /* - * Burst Read. (Offset 8 in UPM RAM) - */ - 0x0E2DBC04, 0x10AF7C04, 0xF0AFFC00, 0xF0AFFC00, - 0xF1AFFC00, 0xEFBAFC00, 0x1FF5FC47, /* last */ - _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Single Write. (Offset 18 in UPM RAM) - */ - 0x0E29BC04, 0x01B27C04, 0x1FF5FC47, /* last */ - _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Burst Write. (Offset 20 in UPM RAM) - */ - 0x0E29BC04, 0x10A77C00, 0xF0AFFC00, 0xF0AFFC00, - 0xE1BAFC04, 0x1FF5FC47, /* last */ - _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Refresh (Offset 30 in UPM RAM) - */ - 0x1FFD7C84, 0xFFFFFC04, 0xFFFFFC04, 0xFFFFFC04, - 0xFFFFFC84, 0xFFFFFC07, /* last */ - _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Exception. (Offset 3c in UPM RAM) - */ - 0x7FFFFC07, /* last */ - 0xFFFFFCFF, 0xFFFFFCFF, 0xFFFFFCFF, -#endif -}; - -/* - * Check Board Identity: - * - */ - -/*********************************************************************** -F* Function: int checkboard (void) P*A*Z* - * -P* Parameters: none -P* -P* Returnvalue: int - 0 is always returned - * -Z* Intention: This function is the checkboard() method implementation -Z* for the lwmon board. Only a standard message is printed. - * -D* Design: wd@denx.de -C* Coding: wd@denx.de -V* Verification: dzu@denx.de - ***********************************************************************/ -int checkboard (void) -{ - puts ("Board: LICCON Konsole LCD3\n"); - return (0); -} - -/*********************************************************************** -F* Function: phys_size_t initdram (int board_type) P*A*Z* - * -P* Parameters: int board_type -P* - Usually type of the board - ignored here. -P* -P* Returnvalue: long int -P* - Size of initialized memory - * -Z* Intention: This function is the initdram() method implementation -Z* for the lwmon board. -Z* The memory controller is initialized to access the -Z* DRAM. - * -D* Design: wd@denx.de -C* Coding: wd@denx.de -V* Verification: dzu@denx.de - ***********************************************************************/ -phys_size_t initdram (int board_type) -{ - volatile immap_t *immr = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immr->im_memctl; - long int size_b0; - long int size8, size9; - int i; - - /* - * Configure UPMA for SDRAM - */ - upmconfig (UPMA, (uint *)sdram_table, sizeof(sdram_table)/sizeof(uint)); - - memctl->memc_mptpr = CONFIG_SYS_MPTPR; - - /* burst length=4, burst type=sequential, CAS latency=2 */ - memctl->memc_mar = CONFIG_SYS_MAR; - - /* - * Map controller bank 3 to the SDRAM bank at preliminary address. - */ - memctl->memc_or3 = CONFIG_SYS_OR3_PRELIM; - memctl->memc_br3 = CONFIG_SYS_BR3_PRELIM; - - /* initialize memory address register */ - memctl->memc_mamr = CONFIG_SYS_MAMR_8COL; /* refresh not enabled yet */ - - /* mode initialization (offset 5) */ - udelay (200); /* 0x80006105 */ - memctl->memc_mcr = MCR_OP_RUN | MCR_MB_CS3 | MCR_MLCF (1) | MCR_MAD (0x05); - - /* run 2 refresh sequence with 4-beat refresh burst (offset 0x30) */ - udelay (1); /* 0x80006130 */ - memctl->memc_mcr = MCR_OP_RUN | MCR_MB_CS3 | MCR_MLCF (1) | MCR_MAD (0x30); - udelay (1); /* 0x80006130 */ - memctl->memc_mcr = MCR_OP_RUN | MCR_MB_CS3 | MCR_MLCF (1) | MCR_MAD (0x30); - - udelay (1); /* 0x80006106 */ - memctl->memc_mcr = MCR_OP_RUN | MCR_MB_CS3 | MCR_MLCF (1) | MCR_MAD (0x06); - - memctl->memc_mamr |= MAMR_PTAE; /* refresh enabled */ - - udelay (200); - - /* Need at least 10 DRAM accesses to stabilize */ - for (i = 0; i < 10; ++i) { - volatile unsigned long *addr = - (volatile unsigned long *) SDRAM_BASE3_PRELIM; - unsigned long val; - - val = *(addr + i); - *(addr + i) = val; - } - - /* - * Check Bank 0 Memory Size for re-configuration - * - * try 8 column mode - */ - size8 = dram_size (CONFIG_SYS_MAMR_8COL, (long *)SDRAM_BASE3_PRELIM, SDRAM_MAX_SIZE); - - udelay (1000); - - /* - * try 9 column mode - */ - size9 = dram_size (CONFIG_SYS_MAMR_9COL, (long *)SDRAM_BASE3_PRELIM, SDRAM_MAX_SIZE); - - if (size8 < size9) { /* leave configuration at 9 columns */ - size_b0 = size9; - memctl->memc_mamr = CONFIG_SYS_MAMR_9COL | MAMR_PTAE; - udelay (500); - } else { /* back to 8 columns */ - size_b0 = size8; - memctl->memc_mamr = CONFIG_SYS_MAMR_8COL | MAMR_PTAE; - udelay (500); - } - - /* - * Final mapping: - */ - - memctl->memc_or3 = ((-size_b0) & 0xFFFF0000) | - OR_CSNT_SAM | OR_G5LS | SDRAM_TIMING; - memctl->memc_br3 = (CONFIG_SYS_SDRAM_BASE & BR_BA_MSK) | BR_MS_UPMA | BR_V; - udelay (1000); - - return (size_b0); -} - -/*********************************************************************** -F* Function: static long int dram_size (long int mamr_value, -F* long int *base, -F* long int maxsize) P*A*Z* - * -P* Parameters: long int mamr_value -P* - Value for MAMR for the test -P* long int *base -P* - Base address for the test -P* long int maxsize -P* - Maximum size to test for -P* -P* Returnvalue: long int -P* - Size of probed memory - * -Z* Intention: Check memory range for valid RAM. A simple memory test -Z* determines the actually available RAM size between -Z* addresses `base' and `base + maxsize'. Some (not all) -Z* hardware errors are detected: -Z* - short between address lines -Z* - short between data lines - * -D* Design: wd@denx.de -C* Coding: wd@denx.de -V* Verification: dzu@denx.de - ***********************************************************************/ -static long int dram_size (long int mamr_value, long int *base, long int maxsize) -{ - volatile immap_t *immr = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immr->im_memctl; - - memctl->memc_mamr = mamr_value; - - return (get_ram_size(base, maxsize)); -} - -/* ------------------------------------------------------------------------- */ - -#ifndef PB_ENET_TENA -# define PB_ENET_TENA ((uint)0x00002000) /* PB 18 */ -#endif - -/*********************************************************************** -F* Function: int board_early_init_f (void) P*A*Z* - * -P* Parameters: none -P* -P* Returnvalue: int -P* - 0 is always returned. - * -Z* Intention: This function is the board_early_init_f() method implementation -Z* for the lwmon board. -Z* Disable Ethernet TENA on Port B. - * -D* Design: wd@denx.de -C* Coding: wd@denx.de -V* Verification: dzu@denx.de - ***********************************************************************/ -int board_early_init_f (void) -{ - volatile immap_t *immr = (immap_t *) CONFIG_SYS_IMMR; - - /* Disable Ethernet TENA on Port B - * Necessary because of pull up in COM3 port. - * - * This is just a preliminary fix, intended to turn off TENA - * as soon as possible to avoid noise on the network. Once - * I2C is running we will make sure the interface is - * correctly initialized. - */ - immr->im_cpm.cp_pbpar &= ~PB_ENET_TENA; - immr->im_cpm.cp_pbodr &= ~PB_ENET_TENA; - immr->im_cpm.cp_pbdat &= ~PB_ENET_TENA; /* set to 0 = disabled */ - immr->im_cpm.cp_pbdir |= PB_ENET_TENA; - - return (0); -} - -/* ------------------------------------------------------------------------- */ - -/*********************************************************************** -F* Function: void reset_phy (void) P*A*Z* - * -P* Parameters: none -P* -P* Returnvalue: none - * -Z* Intention: Reset the PHY. In the lwmon case we do this by the -Z* signaling the PIC I/O expander. - * -D* Design: wd@denx.de -C* Coding: wd@denx.de -V* Verification: dzu@denx.de - ***********************************************************************/ -void reset_phy (void) -{ - uchar c; - -#ifdef DEBUG - printf ("### Switch on Ethernet for SCC2 ###\n"); -#endif - c = pic_read (0x61); -#ifdef DEBUG - printf ("Old PIC read: reg_61 = 0x%02x\n", c); -#endif - c |= 0x40; /* disable COM3 */ - c &= ~0x80; /* enable Ethernet */ - pic_write (0x61, c); -#ifdef DEBUG - c = pic_read (0x61); - printf ("New PIC read: reg_61 = 0x%02x\n", c); -#endif - udelay (1000); -} - - -/*------------------------- Keyboard controller -----------------------*/ -/* command codes */ -#define KEYBD_CMD_READ_KEYS 0x01 -#define KEYBD_CMD_READ_VERSION 0x02 -#define KEYBD_CMD_READ_STATUS 0x03 -#define KEYBD_CMD_RESET_ERRORS 0x10 - -/* status codes */ -#define KEYBD_STATUS_MASK 0x3F -#define KEYBD_STATUS_H_RESET 0x20 -#define KEYBD_STATUS_BROWNOUT 0x10 -#define KEYBD_STATUS_WD_RESET 0x08 -#define KEYBD_STATUS_OVERLOAD 0x04 -#define KEYBD_STATUS_ILLEGAL_WR 0x02 -#define KEYBD_STATUS_ILLEGAL_RD 0x01 - -/* Number of bytes returned from Keyboard Controller */ -#define KEYBD_VERSIONLEN 2 /* version information */ -#define KEYBD_DATALEN 9 /* normal key scan data */ - -/* maximum number of "magic" key codes that can be assigned */ - -static uchar kbd_addr = CONFIG_SYS_I2C_KEYBD_ADDR; - -static uchar *key_match (uchar *); - -#define KEYBD_SET_DEBUGMODE '#' /* Magic key to enable debug output */ - -/*********************************************************************** -F* Function: int board_postclk_init (void) P*A*Z* - * -P* Parameters: none -P* -P* Returnvalue: int -P* - 0 is always returned. - * -Z* Intention: This function is the board_postclk_init() method implementation -Z* for the lwmon board. - * - ***********************************************************************/ -int board_postclk_init (void) -{ - kbd_init(); - -#ifdef CONFIG_MODEM_SUPPORT - if (key_pressed()) { - disable_putc(); /* modem doesn't understand banner etc */ - gd->do_mdm_init = 1; - } -#endif - - return (0); -} - -struct serial_device * default_serial_console (void) -{ - return gd->do_mdm_init ? &serial_scc_device : &serial_smc_device; -} - -static void kbd_init (void) -{ - uchar kbd_data[KEYBD_DATALEN]; - uchar tmp_data[KEYBD_DATALEN]; - uchar val, errcd; - int i; - - i2c_set_bus_num(0); - - gd->arch.kbd_status = 0; - - /* Forced by PIC. Delays <= 175us loose */ - udelay(1000); - - /* Read initial keyboard error code */ - val = KEYBD_CMD_READ_STATUS; - i2c_write (kbd_addr, 0, 0, &val, 1); - i2c_read (kbd_addr, 0, 0, &errcd, 1); - /* clear unused bits */ - errcd &= KEYBD_STATUS_MASK; - /* clear "irrelevant" bits. Recommended by Martin Rajek, LWN */ - errcd &= ~(KEYBD_STATUS_H_RESET|KEYBD_STATUS_BROWNOUT); - if (errcd) { - gd->arch.kbd_status |= errcd << 8; - } - /* Reset error code and verify */ - val = KEYBD_CMD_RESET_ERRORS; - i2c_write (kbd_addr, 0, 0, &val, 1); - udelay(1000); /* delay NEEDED by keyboard PIC !!! */ - - val = KEYBD_CMD_READ_STATUS; - i2c_write (kbd_addr, 0, 0, &val, 1); - i2c_read (kbd_addr, 0, 0, &val, 1); - - val &= KEYBD_STATUS_MASK; /* clear unused bits */ - if (val) { /* permanent error, report it */ - gd->arch.kbd_status |= val; - return; - } - - /* - * Read current keyboard state. - * - * After the error reset it may take some time before the - * keyboard PIC picks up a valid keyboard scan - the total - * scan time is approx. 1.6 ms (information by Martin Rajek, - * 28 Sep 2002). We read a couple of times for the keyboard - * to stabilize, using a big enough delay. - * 10 times should be enough. If the data is still changing, - * we use what we get :-( - */ - - memset (tmp_data, 0xFF, KEYBD_DATALEN); /* impossible value */ - for (i=0; i<10; ++i) { - val = KEYBD_CMD_READ_KEYS; - i2c_write (kbd_addr, 0, 0, &val, 1); - i2c_read (kbd_addr, 0, 0, kbd_data, KEYBD_DATALEN); - - if (memcmp(kbd_data, tmp_data, KEYBD_DATALEN) == 0) { - /* consistent state, done */ - break; - } - /* remeber last state, delay, and retry */ - memcpy (tmp_data, kbd_data, KEYBD_DATALEN); - udelay (5000); - } -} - -/*********************************************************************** -F* Function: int misc_init_r (void) P*A*Z* - * -P* Parameters: none -P* -P* Returnvalue: int -P* - 0 is always returned, even in the case of a keyboard -P* error. - * -Z* Intention: This function is the misc_init_r() method implementation -Z* for the lwmon board. -Z* The keyboard controller is initialized and the result -Z* of a read copied to the environment variable "keybd". -Z* If KEYBD_SET_DEBUGMODE is defined, a check is made for -Z* this key, and if found display to the LCD will be enabled. -Z* The keys in "keybd" are checked against the magic -Z* keycommands defined in the environment. -Z* See also key_match(). - * -D* Design: wd@denx.de -C* Coding: wd@denx.de -V* Verification: dzu@denx.de - ***********************************************************************/ -int misc_init_r (void) -{ - uchar kbd_data[KEYBD_DATALEN]; - char keybd_env[2 * KEYBD_DATALEN + 1]; - uchar kbd_init_status = gd->arch.kbd_status >> 8; - uchar kbd_status = gd->arch.kbd_status; - uchar val; - char *str; - int i; - - if (kbd_init_status) { - printf ("KEYBD: Error %02X\n", kbd_init_status); - } - if (kbd_status) { /* permanent error, report it */ - printf ("*** Keyboard error code %02X ***\n", kbd_status); - sprintf (keybd_env, "%02X", kbd_status); - setenv ("keybd", keybd_env); - return 0; - } - - /* - * Now we know that we have a working keyboard, so disable - * all output to the LCD except when a key press is detected. - */ - - if ((console_assign (stdout, "serial") < 0) || - (console_assign (stderr, "serial") < 0)) { - printf ("Can't assign serial port as output device\n"); - } - - /* Read Version */ - val = KEYBD_CMD_READ_VERSION; - i2c_write (kbd_addr, 0, 0, &val, 1); - i2c_read (kbd_addr, 0, 0, kbd_data, KEYBD_VERSIONLEN); - printf ("KEYBD: Version %d.%d\n", kbd_data[0], kbd_data[1]); - - /* Read current keyboard state */ - val = KEYBD_CMD_READ_KEYS; - i2c_write (kbd_addr, 0, 0, &val, 1); - i2c_read (kbd_addr, 0, 0, kbd_data, KEYBD_DATALEN); - - for (i = 0; i < KEYBD_DATALEN; ++i) { - sprintf (keybd_env + i + i, "%02X", kbd_data[i]); - } - setenv ("keybd", keybd_env); - - str = strdup ((char *)key_match (kbd_data)); /* decode keys */ -#ifdef KEYBD_SET_DEBUGMODE - if (kbd_data[0] == KEYBD_SET_DEBUGMODE) { /* set debug mode */ - if ((console_assign (stdout, "lcd") < 0) || - (console_assign (stderr, "lcd") < 0)) { - printf ("Can't assign LCD display as output device\n"); - } - } -#endif /* KEYBD_SET_DEBUGMODE */ -#ifdef CONFIG_PREBOOT /* automatically configure "preboot" command on key match */ - setenv ("preboot", str); /* set or delete definition */ -#endif /* CONFIG_PREBOOT */ - if (str != NULL) { - free (str); - } - return (0); -} - -#ifdef CONFIG_PREBOOT - -static uchar kbd_magic_prefix[] = "key_magic"; -static uchar kbd_command_prefix[] = "key_cmd"; - -static int compare_magic (uchar *kbd_data, uchar *str) -{ - uchar compare[KEYBD_DATALEN-1]; - char *nxt; - int i; - - /* Don't include modifier byte */ - memcpy (compare, kbd_data+1, KEYBD_DATALEN-1); - - for (; str != NULL; str = (*nxt) ? (uchar *)(nxt+1) : (uchar *)nxt) { - uchar c; - int k; - - c = (uchar) simple_strtoul ((char *)str, (char **) (&nxt), 16); - - if (str == (uchar *)nxt) { /* invalid character */ - break; - } - - /* - * Check if this key matches the input. - * Set matches to zero, so they match only once - * and we can find duplicates or extra keys - */ - for (k = 0; k < sizeof(compare); ++k) { - if (compare[k] == '\0') /* only non-zero entries */ - continue; - if (c == compare[k]) { /* found matching key */ - compare[k] = '\0'; - break; - } - } - if (k == sizeof(compare)) { - return -1; /* unmatched key */ - } - } - - /* - * A full match leaves no keys in the `compare' array, - */ - for (i = 0; i < sizeof(compare); ++i) { - if (compare[i]) - { - return -1; - } - } - - return 0; -} - -/*********************************************************************** -F* Function: static uchar *key_match (uchar *kbd_data) P*A*Z* - * -P* Parameters: uchar *kbd_data -P* - The keys to match against our magic definitions -P* -P* Returnvalue: uchar * -P* - != NULL: Pointer to the corresponding command(s) -P* NULL: No magic is about to happen - * -Z* Intention: Check if pressed key(s) match magic sequence, -Z* and return the command string associated with that key(s). -Z* -Z* If no key press was decoded, NULL is returned. -Z* -Z* Note: the first character of the argument will be -Z* overwritten with the "magic charcter code" of the -Z* decoded key(s), or '\0'. -Z* -Z* Note: the string points to static environment data -Z* and must be saved before you call any function that -Z* modifies the environment. - * -D* Design: wd@denx.de -C* Coding: wd@denx.de -V* Verification: dzu@denx.de - ***********************************************************************/ -static uchar *key_match (uchar *kbd_data) -{ - char magic[sizeof (kbd_magic_prefix) + 1]; - uchar *suffix; - char *kbd_magic_keys; - - /* - * The following string defines the characters that can pe appended - * to "key_magic" to form the names of environment variables that - * hold "magic" key codes, i. e. such key codes that can cause - * pre-boot actions. If the string is empty (""), then only - * "key_magic" is checked (old behaviour); the string "125" causes - * checks for "key_magic1", "key_magic2" and "key_magic5", etc. - */ - if ((kbd_magic_keys = getenv ("magic_keys")) == NULL) - kbd_magic_keys = ""; - - /* loop over all magic keys; - * use '\0' suffix in case of empty string - */ - for (suffix=(uchar *)kbd_magic_keys; *suffix || suffix==(uchar *)kbd_magic_keys; ++suffix) { - sprintf (magic, "%s%c", kbd_magic_prefix, *suffix); -#if 0 - printf ("### Check magic "%s"\n", magic); -#endif - if (compare_magic(kbd_data, (uchar *)getenv(magic)) == 0) { - char cmd_name[sizeof (kbd_command_prefix) + 1]; - char *cmd; - - sprintf (cmd_name, "%s%c", kbd_command_prefix, *suffix); - - cmd = getenv (cmd_name); -#if 0 - printf ("### Set PREBOOT to $(%s): "%s"\n", - cmd_name, cmd ? cmd : "<<NULL>>"); -#endif - *kbd_data = *suffix; - return ((uchar *)cmd); - } - } -#if 0 - printf ("### Delete PREBOOT\n"); -#endif - *kbd_data = '\0'; - return (NULL); -} -#endif /* CONFIG_PREBOOT */ - -#ifdef CONFIG_LCD_INFO -#include <lcd.h> -#include <version.h> -#include <timestamp.h> - -void lcd_show_board_info(void) -{ - char temp[32]; - - lcd_printf ("%s (%s - %s)\n", U_BOOT_VERSION, U_BOOT_DATE, U_BOOT_TIME); - lcd_printf ("(C) 2008 DENX Software Engineering GmbH\n"); - lcd_printf (" Wolfgang DENK, wd@denx.de\n"); -#ifdef CONFIG_LCD_INFO_BELOW_LOGO - lcd_printf ("MPC823 CPU at %s MHz\n", - strmhz(temp, gd->cpu_clk)); - lcd_printf (" %ld MB RAM, %ld MB Flash\n", - gd->ram_size >> 20, - gd->bd->bi_flashsize >> 20 ); -#else - /* leave one blank line */ - lcd_printf ("\nMPC823 CPU at %s MHz, %ld MB RAM, %ld MB Flash\n", - strmhz(temp, gd->cpu_clk), - gd->ram_size >> 20, - gd->bd->bi_flashsize >> 20 ); -#endif /* CONFIG_LCD_INFO_BELOW_LOGO */ -} -#endif /* CONFIG_LCD_INFO */ - -/*---------------Board Special Commands: PIC read/write ---------------*/ - -#if defined(CONFIG_CMD_BSP) -/*********************************************************************** -F* Function: int do_pic (cmd_tbl_t *cmdtp, int flag, -F* int argc, char * const argv[]) P*A*Z* - * -P* Parameters: cmd_tbl_t *cmdtp -P* - Pointer to our command table entry -P* int flag -P* - If the CMD_FLAG_REPEAT bit is set, then this call is -P* a repetition -P* int argc -P* - Argument count -P* char * const argv[] -P* - Array of the actual arguments -P* -P* Returnvalue: int -P* - 0 The command was handled successfully -P* 1 An error occurred - * -Z* Intention: Implement the "pic [read|write]" commands. -Z* The read subcommand takes one argument, the register, -Z* whereas the write command takes two, the register and -Z* the new value. - * -D* Design: wd@denx.de -C* Coding: wd@denx.de -V* Verification: dzu@denx.de - ***********************************************************************/ -int do_pic (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - uchar reg, val; - - switch (argc) { - case 3: /* PIC read reg */ - if (strcmp (argv[1], "read") != 0) - break; - - reg = simple_strtoul (argv[2], NULL, 16); - - printf ("PIC read: reg %02x: %02x\n\n", reg, pic_read (reg)); - - return 0; - case 4: /* PIC write reg val */ - if (strcmp (argv[1], "write") != 0) - break; - - reg = simple_strtoul (argv[2], NULL, 16); - val = simple_strtoul (argv[3], NULL, 16); - - printf ("PIC write: reg %02x val 0x%02x: %02x => ", - reg, val, pic_read (reg)); - pic_write (reg, val); - printf ("%02x\n\n", pic_read (reg)); - return 0; - default: - break; - } - return cmd_usage(cmdtp); -} -U_BOOT_CMD( - pic, 4, 1, do_pic, - "read and write PIC registers", - "read reg - read PIC register `reg'\n" - "pic write reg val - write value `val' to PIC register `reg'" -); - -/*********************************************************************** -F* Function: int do_kbd (cmd_tbl_t *cmdtp, int flag, -F* int argc, char * const argv[]) P*A*Z* - * -P* Parameters: cmd_tbl_t *cmdtp -P* - Pointer to our command table entry -P* int flag -P* - If the CMD_FLAG_REPEAT bit is set, then this call is -P* a repetition -P* int argc -P* - Argument count -P* char * const argv[] -P* - Array of the actual arguments -P* -P* Returnvalue: int -P* - 0 is always returned. - * -Z* Intention: Implement the "kbd" command. -Z* The keyboard status is read. The result is printed on -Z* the console and written into the "keybd" environment -Z* variable. - * -D* Design: wd@denx.de -C* Coding: wd@denx.de -V* Verification: dzu@denx.de - ***********************************************************************/ -int do_kbd (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - uchar kbd_data[KEYBD_DATALEN]; - char keybd_env[2 * KEYBD_DATALEN + 1]; - uchar val; - int i; - -#if 0 /* Done in kbd_init */ - i2c_init (CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); -#endif - - /* Read keys */ - val = KEYBD_CMD_READ_KEYS; - i2c_write (kbd_addr, 0, 0, &val, 1); - i2c_read (kbd_addr, 0, 0, kbd_data, KEYBD_DATALEN); - - puts ("Keys:"); - for (i = 0; i < KEYBD_DATALEN; ++i) { - sprintf (keybd_env + i + i, "%02X", kbd_data[i]); - printf (" %02x", kbd_data[i]); - } - putc ('\n'); - setenv ("keybd", keybd_env); - return 0; -} - -U_BOOT_CMD( - kbd, 1, 1, do_kbd, - "read keyboard status", - "" -); - -/* Read and set LSB switch */ -#define CONFIG_SYS_PC_TXD1_ENA 0x0008 /* PC.12 */ - -/*********************************************************************** -F* Function: int do_lsb (cmd_tbl_t *cmdtp, int flag, -F* int argc, char * const argv[]) P*A*Z* - * -P* Parameters: cmd_tbl_t *cmdtp -P* - Pointer to our command table entry -P* int flag -P* - If the CMD_FLAG_REPEAT bit is set, then this call is -P* a repetition -P* int argc -P* - Argument count -P* char * const argv[] -P* - Array of the actual arguments -P* -P* Returnvalue: int -P* - 0 The command was handled successfully -P* 1 An error occurred - * -Z* Intention: Implement the "lsb [on|off]" commands. -Z* The lsb is switched according to the first parameter by -Z* by signaling the PIC I/O expander. -Z* Called with no arguments, the current setting is -Z* printed. - * -D* Design: wd@denx.de -C* Coding: wd@denx.de -V* Verification: dzu@denx.de - ***********************************************************************/ -int do_lsb (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - uchar val; - immap_t *immr = (immap_t *) CONFIG_SYS_IMMR; - - switch (argc) { - case 1: /* lsb - print setting */ - val = pic_read (0x60); - printf ("LSB is o%s\n", (val & 0x20) ? "n" : "ff"); - return 0; - case 2: /* lsb on or lsb off - set switch */ - val = pic_read (0x60); - - if (strcmp (argv[1], "on") == 0) { - val |= 0x20; - immr->im_ioport.iop_pcpar &= ~(CONFIG_SYS_PC_TXD1_ENA); - immr->im_ioport.iop_pcdat |= CONFIG_SYS_PC_TXD1_ENA; - immr->im_ioport.iop_pcdir |= CONFIG_SYS_PC_TXD1_ENA; - } else if (strcmp (argv[1], "off") == 0) { - val &= ~0x20; - immr->im_ioport.iop_pcpar &= ~(CONFIG_SYS_PC_TXD1_ENA); - immr->im_ioport.iop_pcdat &= ~(CONFIG_SYS_PC_TXD1_ENA); - immr->im_ioport.iop_pcdir |= CONFIG_SYS_PC_TXD1_ENA; - } else { - break; - } - pic_write (0x60, val); - return 0; - default: - break; - } - return cmd_usage(cmdtp); -} - -U_BOOT_CMD( - lsb, 2, 1, do_lsb, - "check and set LSB switch", - "on - switch LSB on\n" - "lsb off - switch LSB off\n" - "lsb - print current setting" -); - -#endif - -/*----------------------------- Utilities -----------------------------*/ -/*********************************************************************** -F* Function: uchar pic_read (uchar reg) P*A*Z* - * -P* Parameters: uchar reg -P* - Register to read -P* -P* Returnvalue: uchar -P* - Value read from register - * -Z* Intention: Read a register from the PIC I/O expander. - * -D* Design: wd@denx.de -C* Coding: wd@denx.de -V* Verification: dzu@denx.de - ***********************************************************************/ -uchar pic_read (uchar reg) -{ - return (i2c_reg_read (CONFIG_SYS_I2C_PICIO_ADDR, reg)); -} - -/*********************************************************************** -F* Function: void pic_write (uchar reg, uchar val) P*A*Z* - * -P* Parameters: uchar reg -P* - Register to read -P* uchar val -P* - Value to write -P* -P* Returnvalue: none - * -Z* Intention: Write to a register on the PIC I/O expander. - * -D* Design: wd@denx.de -C* Coding: wd@denx.de -V* Verification: dzu@denx.de - ***********************************************************************/ -void pic_write (uchar reg, uchar val) -{ - i2c_reg_write (CONFIG_SYS_I2C_PICIO_ADDR, reg, val); -} - -/*---------------------- Board Control Functions ----------------------*/ -/*********************************************************************** -F* Function: void board_poweroff (void) P*A*Z* - * -P* Parameters: none -P* -P* Returnvalue: none - * -Z* Intention: Turn off the battery power and loop endless, so this -Z* should better be the last function you call... - * -D* Design: wd@denx.de -C* Coding: wd@denx.de -V* Verification: dzu@denx.de - ***********************************************************************/ -void board_poweroff (void) -{ - /* Turn battery off */ - ((volatile immap_t *)CONFIG_SYS_IMMR)->im_ioport.iop_pcdat &= ~(1 << (31 - 13)); - - while (1); -} - -#ifdef CONFIG_MODEM_SUPPORT -static int key_pressed(void) -{ - uchar kbd_data[KEYBD_DATALEN]; - uchar val; - - /* Read keys */ - val = KEYBD_CMD_READ_KEYS; - i2c_write (kbd_addr, 0, 0, &val, 1); - i2c_read (kbd_addr, 0, 0, kbd_data, KEYBD_DATALEN); - - return (compare_magic(kbd_data, (uchar *)CONFIG_MODEM_KEY_MAGIC) == 0); -} -#endif /* CONFIG_MODEM_SUPPORT */ - -#ifdef CONFIG_POST -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - uchar kbd_data[KEYBD_DATALEN]; - uchar val; - - /* Read keys */ - val = KEYBD_CMD_READ_KEYS; - i2c_write (kbd_addr, 0, 0, &val, 1); - i2c_read (kbd_addr, 0, 0, kbd_data, KEYBD_DATALEN); - - return (compare_magic(kbd_data, (uchar *)CONFIG_POST_KEY_MAGIC) == 0); -} -#endif diff --git a/board/lwmon/pcmcia.c b/board/lwmon/pcmcia.c deleted file mode 100644 index b9894cf..0000000 --- a/board/lwmon/pcmcia.c +++ /dev/null @@ -1,234 +0,0 @@ -#include <common.h> -#include <mpc8xx.h> -#include <pcmcia.h> -#include <i2c.h> - -#undef CONFIG_PCMCIA - -#if defined(CONFIG_CMD_PCMCIA) -#define CONFIG_PCMCIA -#endif - -#if defined(CONFIG_CMD_IDE) && defined(CONFIG_IDE_8xx_PCCARD) -#define CONFIG_PCMCIA -#endif - -#ifdef CONFIG_PCMCIA - -#define PCMCIA_BOARD_MSG "LWMON" - -/* #define's for MAX1604 Power Switch */ -#define MAX1604_OP_SUS 0x80 -#define MAX1604_VCCBON 0x40 -#define MAX1604_VCC_35 0x20 -#define MAX1604_VCCBHIZ 0x10 -#define MAX1604_VPPBON 0x08 -#define MAX1604_VPPBPBPGM 0x04 -#define MAX1604_VPPBHIZ 0x02 -/* reserved 0x01 */ - -int pcmcia_hardware_enable(int slot) -{ - volatile pcmconf8xx_t *pcmp; - volatile sysconf8xx_t *sysp; - uint reg, mask; - uchar val; - - - debug ("hardware_enable: " PCMCIA_BOARD_MSG " Slot %c\n", 'A'+slot); - - /* Switch on PCMCIA port in PIC register 0x60 */ - reg = pic_read (0x60); - debug ("[%d] PIC read: reg_60 = 0x%02x\n", __LINE__, reg); - reg &= ~0x10; - /* reg |= 0x08; Vpp not needed */ - pic_write (0x60, reg); -#ifdef DEBUG - reg = pic_read (0x60); - printf ("[%d] PIC read: reg_60 = 0x%02x\n", __LINE__, reg); -#endif - udelay(10000); - - sysp = (sysconf8xx_t *)(&(((immap_t *)CONFIG_SYS_IMMR)->im_siu_conf)); - pcmp = (pcmconf8xx_t *)(&(((immap_t *)CONFIG_SYS_IMMR)->im_pcmcia)); - - /* - * Configure SIUMCR to enable PCMCIA port B - * (VFLS[0:1] are not used for debugging, we connect FRZ# instead) - */ - sysp->sc_siumcr &= ~SIUMCR_DBGC11; /* set DBGC to 00 */ - - /* clear interrupt state, and disable interrupts */ - pcmp->pcmc_pscr = PCMCIA_MASK(_slot_); - pcmp->pcmc_per &= ~PCMCIA_MASK(_slot_); - - /* - * Disable interrupts, DMA, and PCMCIA buffers - * (isolate the interface) and assert RESET signal - */ - debug ("Disable PCMCIA buffers and assert RESET\n"); - reg = 0; - reg |= __MY_PCMCIA_GCRX_CXRESET; /* active high */ - reg |= __MY_PCMCIA_GCRX_CXOE; /* active low */ - PCMCIA_PGCRX(_slot_) = reg; - udelay(500); - - /* - * Make sure there is a card in the slot, then configure the interface. - */ - udelay(10000); - debug ("[%d] %s: PIPR(%p)=0x%x\n", - __LINE__,__FUNCTION__, - &(pcmp->pcmc_pipr),pcmp->pcmc_pipr); - if (pcmp->pcmc_pipr & (0x18000000 >> (slot << 4))) { - printf (" No Card found\n"); - return (1); - } - - /* - * Power On. - */ - mask = PCMCIA_VS1(slot) | PCMCIA_VS2(slot); - reg = pcmp->pcmc_pipr; - debug ("PIPR: 0x%x ==> VS1=o%s, VS2=o%s\n", - reg, - (reg&PCMCIA_VS1(slot))?"n":"ff", - (reg&PCMCIA_VS2(slot))?"n":"ff"); - if ((reg & mask) == mask) { - val = 0; /* VCCB3/5 = 0 ==> use Vx = 5.0 V */ - puts (" 5.0V card found: "); - } else { - val = MAX1604_VCC_35; /* VCCB3/5 = 1 ==> use Vy = 3.3 V */ - puts (" 3.3V card found: "); - } - - /* switch VCC on */ - val |= MAX1604_OP_SUS | MAX1604_VCCBON; - i2c_set_bus_num(0); - i2c_write (CONFIG_SYS_I2C_POWER_A_ADDR, 0, 0, &val, 1); - - udelay(500000); - - debug ("Enable PCMCIA buffers and stop RESET\n"); - reg = PCMCIA_PGCRX(_slot_); - reg &= ~__MY_PCMCIA_GCRX_CXRESET; /* active high */ - reg &= ~__MY_PCMCIA_GCRX_CXOE; /* active low */ - PCMCIA_PGCRX(_slot_) = reg; - - udelay(250000); /* some cards need >150 ms to come up :-( */ - - debug ("# hardware_enable done\n"); - - return (0); -} - - -#if defined(CONFIG_CMD_PCMCIA) -int pcmcia_hardware_disable(int slot) -{ - volatile immap_t *immap; - volatile pcmconf8xx_t *pcmp; - u_long reg; - uchar val; - - debug ("hardware_disable: " PCMCIA_BOARD_MSG " Slot %c\n", 'A'+slot); - - immap = (immap_t *)CONFIG_SYS_IMMR; - pcmp = (pcmconf8xx_t *)(&(((immap_t *)CONFIG_SYS_IMMR)->im_pcmcia)); - - /* remove all power, put output in high impedance state */ - val = MAX1604_VCCBHIZ | MAX1604_VPPBHIZ; - i2c_init (CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); - i2c_write (CONFIG_SYS_I2C_POWER_A_ADDR, 0, 0, &val, 1); - - /* Configure PCMCIA General Control Register */ - debug ("Disable PCMCIA buffers and assert RESET\n"); - reg = 0; - reg |= __MY_PCMCIA_GCRX_CXRESET; /* active high */ - reg |= __MY_PCMCIA_GCRX_CXOE; /* active low */ - PCMCIA_PGCRX(_slot_) = reg; - - /* Switch off PCMCIA port in PIC register 0x60 */ - reg = pic_read (0x60); - debug ("[%d] PIC read: reg_60 = 0x%02x\n", __LINE__, reg); - reg |= 0x10; - reg &= ~0x08; - pic_write (0x60, reg); -#ifdef DEBUG - reg = pic_read (0x60); - printf ("[%d] PIC read: reg_60 = 0x%02x\n", __LINE__, reg); -#endif - udelay(10000); - - return (0); -} -#endif - - -int pcmcia_voltage_set(int slot, int vcc, int vpp) -{ - volatile pcmconf8xx_t *pcmp; - u_long reg; - uchar val; - - debug ("voltage_set: " - PCMCIA_BOARD_MSG - " Slot %c, Vcc=%d.%d, Vpp=%d.%d\n", - 'A'+slot, vcc/10, vcc%10, vpp/10, vcc%10); - - pcmp = (pcmconf8xx_t *)(&(((immap_t *)CONFIG_SYS_IMMR)->im_pcmcia)); - /* - * Disable PCMCIA buffers (isolate the interface) - * and assert RESET signal - */ - debug ("Disable PCMCIA buffers and assert RESET\n"); - reg = PCMCIA_PGCRX(_slot_); - reg |= __MY_PCMCIA_GCRX_CXRESET; /* active high */ - reg |= __MY_PCMCIA_GCRX_CXOE; /* active low */ - PCMCIA_PGCRX(_slot_) = reg; - udelay(500); - - /* - * Turn off all power (switch to high impedance) - */ - debug ("PCMCIA power OFF\n"); - val = MAX1604_VCCBHIZ | MAX1604_VPPBHIZ; - i2c_set_bus_num(0); - i2c_write (CONFIG_SYS_I2C_POWER_A_ADDR, 0, 0, &val, 1); - - val = 0; - switch(vcc) { - case 0: break; - case 33: val = MAX1604_VCC_35; break; - case 50: break; - default: goto done; - } - - /* Checking supported voltages */ - - debug ("PIPR: 0x%x --> %s\n", - pcmp->pcmc_pipr, - (pcmp->pcmc_pipr & 0x00008000) ? "only 5 V" : "can do 3.3V"); - - i2c_write (CONFIG_SYS_I2C_POWER_A_ADDR, 0, 0, &val, 1); - if (val) { - debug ("PCMCIA powered at %sV\n", - (val & MAX1604_VCC_35) ? "3.3" : "5.0"); - } else { - debug ("PCMCIA powered down\n"); - } - -done: - debug ("Enable PCMCIA buffers and stop RESET\n"); - reg = PCMCIA_PGCRX(_slot_); - reg &= ~__MY_PCMCIA_GCRX_CXRESET; /* active high */ - reg &= ~__MY_PCMCIA_GCRX_CXOE; /* active low */ - PCMCIA_PGCRX(_slot_) = reg; - udelay(500); - - debug ("voltage_set: " PCMCIA_BOARD_MSG " Slot %c, DONE\n", - slot+'A'); - return (0); -} - -#endif /* CONFIG_PCMCIA */ diff --git a/board/lwmon/u-boot.lds.debug b/board/lwmon/u-boot.lds.debug deleted file mode 100644 index 75a1337..0000000 --- a/board/lwmon/u-boot.lds.debug +++ /dev/null @@ -1,122 +0,0 @@ -/* - * (C) Copyright 2001 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -OUTPUT_ARCH(powerpc) -/* Do we need any of these for elf? - __DYNAMIC = 0; */ -SECTIONS -{ - /* Read-only sections, merged into text segment: */ - . = + SIZEOF_HEADERS; - .interp : { *(.interp) } - .hash : { *(.hash) } - .dynsym : { *(.dynsym) } - .dynstr : { *(.dynstr) } - .rel.text : { *(.rel.text) } - .rela.text : { *(.rela.text) } - .rel.data : { *(.rel.data) } - .rela.data : { *(.rela.data) } - .rel.rodata : { *(.rel.rodata) } - .rela.rodata : { *(.rela.rodata) } - .rel.got : { *(.rel.got) } - .rela.got : { *(.rela.got) } - .rel.ctors : { *(.rel.ctors) } - .rela.ctors : { *(.rela.ctors) } - .rel.dtors : { *(.rel.dtors) } - .rela.dtors : { *(.rela.dtors) } - .rel.bss : { *(.rel.bss) } - .rela.bss : { *(.rela.bss) } - .rel.plt : { *(.rel.plt) } - .rela.plt : { *(.rela.plt) } - .init : { *(.init) } - .plt : { *(.plt) } - .text : - { - /* WARNING - the following is hand-optimized to fit within */ - /* the sector layout of our flash chips! XXX FIXME XXX */ - - arch/powerpc/cpu/mpc8xx/start.o (.text) - common/dlmalloc.o (.text) - lib/vsprintf.o (.text) - lib/crc32.o (.text) - arch/powerpc/lib/extable.o (.text) - - . = env_offset; - common/env_embedded.o(.text) - - *(.text) - *(.got1) - } - _etext = .; - PROVIDE (etext = .); - .rodata : - { - *(.rodata) - *(.rodata1) - *(.rodata.str1.4) - *(.eh_frame) - } - .fini : { *(.fini) } =0 - .ctors : { *(.ctors) } - .dtors : { *(.dtors) } - - /* Read-write section, merged into data segment: */ - . = (. + 0x0FFF) & 0xFFFFF000; - _erotext = .; - PROVIDE (erotext = .); - .reloc : - { - *(.got) - _GOT2_TABLE_ = .; - *(.got2) - _FIXUP_TABLE_ = .; - *(.fixup) - } - __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; - __fixup_entries = (. - _FIXUP_TABLE_)>>2; - - .data : - { - *(.data) - *(.data1) - *(.sdata) - *(.sdata2) - *(.dynamic) - CONSTRUCTORS - } - _edata = .; - PROVIDE (edata = .); - - - . = ALIGN(4); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); - } - - - __start___ex_table = .; - __ex_table : { *(__ex_table) } - __stop___ex_table = .; - - . = ALIGN(4096); - __init_begin = .; - .text.init : { *(.text.init) } - .data.init : { *(.data.init) } - . = ALIGN(4096); - __init_end = .; - - __bss_start = .; - .bss : - { - *(.sbss) *(.scommon) - *(.dynbss) - *(.bss) - *(COMMON) - } - __bss_end = . ; - PROVIDE (end = .); -} diff --git a/configs/lwmon_defconfig b/configs/lwmon_defconfig deleted file mode 100644 index 128ff5f..0000000 --- a/configs/lwmon_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_LWMON=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 6b391df..1f5ff8f 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,7 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +lwmon powerpc mpc8xx - - Wolfgang Denk wd@denx.de NETVIA powerpc mpc8xx - - Pantelis Antoniou panto@intracom.gr R360MPI powerpc mpc8xx - - Wolfgang Denk wd@denx.de RRvision powerpc mpc8xx - - Wolfgang Denk wd@denx.de diff --git a/drivers/pcmcia/mpc8xx_pcmcia.c b/drivers/pcmcia/mpc8xx_pcmcia.c index ea88494..1b41e39 100644 --- a/drivers/pcmcia/mpc8xx_pcmcia.c +++ b/drivers/pcmcia/mpc8xx_pcmcia.c @@ -58,15 +58,9 @@ static const u_int m8xx_size_to_gray[M8XX_SIZES_NO] =
-#if defined(CONFIG_LWMON) -#define CONFIG_SYS_PCMCIA_TIMING ( PCMCIA_SHT(9) \ - | PCMCIA_SST(3) \ - | PCMCIA_SL(12)) -#else #define CONFIG_SYS_PCMCIA_TIMING ( PCMCIA_SHT(2) \ | PCMCIA_SST(4) \ | PCMCIA_SL(9)) -#endif
diff --git a/drivers/video/mpc8xx_lcd.c b/drivers/video/mpc8xx_lcd.c index 336788f..50eed89 100644 --- a/drivers/video/mpc8xx_lcd.c +++ b/drivers/video/mpc8xx_lcd.c @@ -412,17 +412,6 @@ void lcd_enable (void) /* Enable the LCD panel */ immr->im_siu_conf.sc_sdcr |= (1 << (31 - 25)); /* LAM = 1 */ lcdp->lcd_lccr |= LCCR_PON; - -#if defined(CONFIG_LWMON) - { uchar c = pic_read (0x60); -#if defined(CONFIG_LCD) && defined(CONFIG_LWMON) && (CONFIG_POST & CONFIG_SYS_POST_SYSMON) - /* Enable LCD later in sysmon test, only if temperature is OK */ -#else - c |= 0x07; /* Power on CCFL, Enable CCFL, Chip Enable LCD */ -#endif - pic_write (0x60, c); - } -#endif /* CONFIG_LWMON */ }
/************************************************************************/ diff --git a/examples/standalone/test_burst.c b/examples/standalone/test_burst.c index 4a16ffb..f2fdbf1 100644 --- a/examples/standalone/test_burst.c +++ b/examples/standalone/test_burst.c @@ -31,25 +31,6 @@ */ #define TEST_FLASH_ADDR 0x40100000
-/* Define GPIO ports to signal start of burst transfers and errors */ -#ifdef CONFIG_LWMON -/* Use PD.8 to signal start of burst transfers */ -#define GPIO1_DAT (((volatile immap_t *)CONFIG_SYS_IMMR)->im_ioport.iop_pddat) -#define GPIO1_BIT 0x0080 -/* Configure PD.8 as general purpose output */ -#define GPIO1_INIT \ - ((volatile immap_t *)CONFIG_SYS_IMMR)->im_ioport.iop_pdpar &= ~GPIO1_BIT; \ - ((volatile immap_t *)CONFIG_SYS_IMMR)->im_ioport.iop_pddir |= GPIO1_BIT; -/* Use PD.9 to signal error */ -#define GPIO2_DAT (((volatile immap_t *)CONFIG_SYS_IMMR)->im_ioport.iop_pddat) -#define GPIO2_BIT 0x0040 -/* Configure PD.9 as general purpose output */ -#define GPIO2_INIT \ - ((volatile immap_t *)CONFIG_SYS_IMMR)->im_ioport.iop_pdpar &= ~GPIO2_BIT; \ - ((volatile immap_t *)CONFIG_SYS_IMMR)->im_ioport.iop_pddir |= GPIO2_BIT; -#endif /* CONFIG_LWMON */ - - static void test_prepare (void); static int test_burst_start (unsigned long size, unsigned long pattern); static void test_map_8M (unsigned long paddr, unsigned long vaddr, int cached); diff --git a/include/common.h b/include/common.h index 46f07fe..bab77e6 100644 --- a/include/common.h +++ b/include/common.h @@ -421,10 +421,6 @@ int eeprom_probe (unsigned dev_addr, unsigned offset); #endif int eeprom_read (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt); int eeprom_write (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt); -#ifdef CONFIG_LWMON -extern uchar pic_read (uchar reg); -extern void pic_write (uchar reg, uchar val); -#endif
/* * Set this up regardless of board diff --git a/include/commproc.h b/include/commproc.h index 8de0d15..509d6e4 100644 --- a/include/commproc.h +++ b/include/commproc.h @@ -543,32 +543,6 @@ typedef struct scc_enet {
#endif /* CONFIG_IVMS8, CONFIG_IVML24 */
-/*** LWMON **********************************************************/ - -#if defined(CONFIG_LWMON) -/* Bits in parallel I/O port registers that have to be set/cleared - * to configure the pins for SCC2 use. - */ -#define PROFF_ENET PROFF_SCC2 -#define CPM_CR_ENET CPM_CR_CH_SCC2 -#define SCC_ENET 1 -#define PA_ENET_RXD ((ushort)0x0004) /* PA 13 */ -#define PA_ENET_TXD ((ushort)0x0008) /* PA 12 */ -#define PA_ENET_RCLK ((ushort)0x0800) /* PA 4 */ -#define PA_ENET_TCLK ((ushort)0x0400) /* PA 5 */ - -#define PB_ENET_TENA ((uint)0x00002000) /* PB 18 */ - -#define PC_ENET_CLSN ((ushort)0x0040) /* PC 9 */ -#define PC_ENET_RENA ((ushort)0x0080) /* PC 8 */ - -/* Control bits in the SICR to route TCLK (CLK3) and RCLK (CLK4) to - * SCC2. Also, make sure GR2 (bit 16) and SC2 (bit 17) are zero. - */ -#define SICR_ENET_MASK ((uint)0x0000ff00) -#define SICR_ENET_CLKRT ((uint)0x00003E00) -#endif /* CONFIG_LWMON */ - /*** KM8XX *********************************************************/
/* The KM8XX Service Module uses SCC3 for Ethernet */ diff --git a/include/configs/lwmon.h b/include/configs/lwmon.h deleted file mode 100644 index f204587..0000000 --- a/include/configs/lwmon.h +++ /dev/null @@ -1,587 +0,0 @@ -/* - * (C) Copyright 2001-2005 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* External logbuffer support */ -#define CONFIG_LOGBUFFER - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC823 1 /* This is a MPC823E CPU */ -#define CONFIG_LWMON 1 /* ...on a LWMON board */ - -#define CONFIG_SYS_TEXT_BASE 0x40000000 - -/* Default Ethernet MAC address */ -#define CONFIG_ETHADDR 00:11:B0:00:00:00 - -/* The default Ethernet MAC address can be overwritten just once */ -#ifdef CONFIG_ETHADDR -#define CONFIG_OVERWRITE_ETHADDR_ONCE 1 -#endif - -#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f() */ -#define CONFIG_BOARD_POSTCLK_INIT 1 /* Call board_postclk_init() */ -#define CONFIG_MISC_INIT_R 1 /* Call misc_init_r() */ - -#define CONFIG_LCD 1 /* use LCD controller ... */ -#define CONFIG_MPC8XX_LCD -#define CONFIG_HLD1045 1 /* ... with a HLD1045 display */ - -#define CONFIG_LCD_LOGO 1 /* print our logo on the LCD */ -#define CONFIG_LCD_INFO 1 /* ... and some board info */ -#define CONFIG_SPLASH_SCREEN /* ... with splashscreen support*/ - -#define CONFIG_8xx_CONS_SMC2 1 /* Console is on SMC2 */ -#define CONFIG_8xx_CONS_SCC2 1 /* Console is on SCC2 */ - -#define CONFIG_BAUDRATE 115200 /* with watchdog >= 38400 needed */ - -#define CONFIG_BOOTDELAY 1 /* autoboot after 1 second */ - -#define CONFIG_CLOCKS_IN_MHZ 1 /* clocks passsed to Linux in MHz */ - -/* pre-boot commands */ -#define CONFIG_PREBOOT "setenv bootdelay 15" - -#undef CONFIG_BOOTARGS - -/* POST support */ -#define CONFIG_POST (CONFIG_SYS_POST_CACHE | \ - CONFIG_SYS_POST_WATCHDOG | \ - CONFIG_SYS_POST_RTC | \ - CONFIG_SYS_POST_MEMORY | \ - CONFIG_SYS_POST_CPU | \ - CONFIG_SYS_POST_UART | \ - CONFIG_SYS_POST_ETHER | \ - CONFIG_SYS_POST_I2C | \ - CONFIG_SYS_POST_SPI | \ - CONFIG_SYS_POST_USB | \ - CONFIG_SYS_POST_SPR | \ - CONFIG_SYS_POST_SYSMON) - -/* - * Keyboard commands: - * # = 0x28 = ENTER : enable bootmessages on LCD - * 2 = 0x3A+0x3C = F1 + F3 : enable update mode - * 3 = 0x3C+0x3F = F3 + F6 : enable test mode - */ - -#define CONFIG_BOOTCOMMAND "source 40040000;saveenv" - -/* "gatewayip=10.8.211.250\0" \ */ -#define CONFIG_EXTRA_ENV_SETTINGS \ - "kernel_addr=40080000\0" \ - "ramdisk_addr=40280000\0" \ - "netmask=255.255.192.0\0" \ - "serverip=10.8.2.101\0" \ - "ipaddr=10.8.57.0\0" \ - "magic_keys=#23\0" \ - "key_magic#=28\0" \ - "key_cmd#=setenv addfb setenv 'bootargs $bootargs console=tty0'\0" \ - "key_magic2=3A+3C\0" \ - "key_cmd2=echo *** Entering Update Mode ***;" \ - "if fatload ide 0:3 10000 update.scr;" \ - "then source 10000;" \ - "else echo *** UPDATE FAILED ***;" \ - "fi\0" \ - "key_magic3=3C+3F\0" \ - "key_cmd3=echo *** Entering Test Mode ***;" \ - "setenv add_misc 'setenv bootargs $bootargs testmode'\0" \ - "nfsargs=setenv bootargs root=/dev/nfs rw nfsroot=$serverip:$rootpath\0" \ - "ramargs=setenv bootargs root=/dev/ram rw\0" \ - "addfb=setenv bootargs $bootargs console=ttyS1,$baudrate\0" \ - "addip=setenv bootargs $bootargs " \ - "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname::off " \ - "panic=1\0" \ - "add_wdt=setenv bootargs $bootargs $wdt_args\0" \ - "add_misc=setenv bootargs $bootargs runmode\0" \ - "flash_nfs=run nfsargs addip add_wdt addfb add_misc;" \ - "bootm $kernel_addr\0" \ - "flash_self=run ramargs addip add_wdt addfb add_misc;" \ - "bootm $kernel_addr $ramdisk_addr\0" \ - "net_nfs=tftp 100000 /tftpboot/uImage.lwmon;" \ - "run nfsargs addip add_wdt addfb;bootm\0" \ - "rootpath=/opt/eldk/ppc_8xx\0" \ - "load=tftp 100000 /tftpboot/u-boot.bin\0" \ - "update=protect off 1:0;era 1:0;cp.b 100000 40000000 $filesize\0" \ - "wdt_args=wdt_8xx=off\0" \ - "verify=no" - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ - -#define CONFIG_WATCHDOG 1 /* watchdog enabled */ -#define CONFIG_SYS_WATCHDOG_FREQ (CONFIG_SYS_HZ / 20) - -#undef CONFIG_STATUS_LED /* Status LED disabled */ - -/* enable I2C and select the hardware/software driver */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_SOFT /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SOFT_SPEED 93000 /* 93 kHz is supposed to work */ -#define CONFIG_SYS_I2C_SOFT_SLAVE 0xFE -/* - * Software (bit-bang) I2C driver configuration - */ -#define PB_SCL 0x00000020 /* PB 26 */ -#define PB_SDA 0x00000010 /* PB 27 */ - -#define I2C_INIT (immr->im_cpm.cp_pbdir |= PB_SCL) -#define I2C_ACTIVE (immr->im_cpm.cp_pbdir |= PB_SDA) -#define I2C_TRISTATE (immr->im_cpm.cp_pbdir &= ~PB_SDA) -#define I2C_READ ((immr->im_cpm.cp_pbdat & PB_SDA) != 0) -#define I2C_SDA(bit) if(bit) immr->im_cpm.cp_pbdat |= PB_SDA; \ - else immr->im_cpm.cp_pbdat &= ~PB_SDA -#define I2C_SCL(bit) if(bit) immr->im_cpm.cp_pbdat |= PB_SCL; \ - else immr->im_cpm.cp_pbdat &= ~PB_SCL -#define I2C_DELAY udelay(2) /* 1/4 I2C clock duration */ - - -#define CONFIG_RTC_PCF8563 /* use Philips PCF8563 RTC */ - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_BMP -#define CONFIG_CMD_BSP -#define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_EEPROM -#define CONFIG_CMD_FAT -#define CONFIG_CMD_I2C -#define CONFIG_CMD_IDE -#define CONFIG_CMD_NFS -#define CONFIG_CMD_SNTP - -#ifdef CONFIG_POST -#define CONFIG_CMD_DIAG -#endif - - -#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE - - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ - -#define CONFIG_SYS_HUSH_PARSER 1 /* use "hush" command parser */ - -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x00100000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x00F00000 /* 1 ... 15MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x00100000 /* default load address */ - -#define CONFIG_SYS_PIO_MODE 0 /* IDE interface in PIO Mode 0 */ - -/* - * When the watchdog is enabled, output must be fast enough in Linux. - */ -#ifdef CONFIG_WATCHDOG -#define CONFIG_SYS_BAUDRATE_TABLE { 38400, 57600, 115200 } -#endif - -/*----------------------------------------------------------------------*/ -#define CONFIG_MODEM_SUPPORT 1 /* enable modem initialization stuff */ -#undef CONFIG_MODEM_SUPPORT_DEBUG - -#define CONFIG_MODEM_KEY_MAGIC "3C+3D" /* press F3 + F4 keys to enable modem */ -#define CONFIG_POST_KEY_MAGIC "3C+3E" /* press F3 + F5 keys to force POST */ -#if 0 -#define CONFIG_AUTOBOOT_KEYED /* Enable "password" protection */ -#define CONFIG_AUTOBOOT_PROMPT \ - "\nEnter password - autoboot in %d sec...\n", bootdelay -#define CONFIG_AUTOBOOT_DELAY_STR " " /* "password" */ -#endif -/*----------------------------------------------------------------------*/ - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xFFF00000 - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0x40000000 -#if defined(DEBUG) || defined(CONFIG_CMD_IDE) -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#else -#define CONFIG_SYS_MONITOR_LEN (128 << 10) /* Reserve 128 kB for Monitor */ -#endif -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 128 /* max number of sectors on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 180000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 600 /* Timeout for Flash Write (in ms) */ -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE -#define CONFIG_SYS_FLASH_BUFFER_WRITE_TOUT 2048 /* Timeout for Flash Buffer Write (in ms) */ -/* Buffer size. - We have two flash devices connected in parallel. - Each device incorporates a Write Buffer of 32 bytes. - */ -#define CONFIG_SYS_FLASH_BUFFER_SIZE (2*32) - -/* Put environment in flash which is much faster to boot than using the EEPROM */ -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_ADDR 0x40040000 /* Address of Environment Sector */ -#define CONFIG_ENV_SIZE 0x2000 /* Total Size of Environment */ -#define CONFIG_ENV_SECT_SIZE 0x40000 /* we have BIG sectors only :-( */ - -/*----------------------------------------------------------------------- - * I2C/EEPROM Configuration - */ - -#define CONFIG_SYS_I2C_AUDIO_ADDR 0x28 /* Audio volume control */ -#define CONFIG_SYS_I2C_SYSMON_ADDR 0x2E /* LM87 System Monitor */ -#define CONFIG_SYS_I2C_RTC_ADDR 0x51 /* PCF8563 RTC */ -#define CONFIG_SYS_I2C_POWER_A_ADDR 0x52 /* PCMCIA/USB power switch, channel A */ -#define CONFIG_SYS_I2C_POWER_B_ADDR 0x53 /* PCMCIA/USB power switch, channel B */ -#define CONFIG_SYS_I2C_KEYBD_ADDR 0x56 /* PIC LWE keyboard */ -#define CONFIG_SYS_I2C_PICIO_ADDR 0x57 /* PIC IO Expander */ - -#undef CONFIG_USE_FRAM /* Use FRAM instead of EEPROM */ - -#ifdef CONFIG_USE_FRAM /* use FRAM */ -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x55 /* FRAM FM24CL64 */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 -#else /* use EEPROM */ -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x58 /* EEPROM AT24C164 */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* takes up to 10 msec */ -#endif /* CONFIG_USE_FRAM */ -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 - -/* List of I2C addresses to be verified by POST */ -#ifdef CONFIG_USE_FRAM -#define CONFIG_SYS_POST_I2C_ADDRS {/* CONFIG_SYS_I2C_AUDIO_ADDR, */ \ - CONFIG_SYS_I2C_SYSMON_ADDR, \ - CONFIG_SYS_I2C_RTC_ADDR, \ - CONFIG_SYS_I2C_POWER_A_ADDR, \ - CONFIG_SYS_I2C_POWER_B_ADDR, \ - CONFIG_SYS_I2C_KEYBD_ADDR, \ - CONFIG_SYS_I2C_PICIO_ADDR, \ - CONFIG_SYS_I2C_EEPROM_ADDR, \ - } -#else /* Use EEPROM - which show up on 8 consequtive addresses */ -#define CONFIG_SYS_POST_I2C_ADDRS {/* CONFIG_SYS_I2C_AUDIO_ADDR, */ \ - CONFIG_SYS_I2C_SYSMON_ADDR, \ - CONFIG_SYS_I2C_RTC_ADDR, \ - CONFIG_SYS_I2C_POWER_A_ADDR, \ - CONFIG_SYS_I2C_POWER_B_ADDR, \ - CONFIG_SYS_I2C_KEYBD_ADDR, \ - CONFIG_SYS_I2C_PICIO_ADDR, \ - CONFIG_SYS_I2C_EEPROM_ADDR+0, \ - CONFIG_SYS_I2C_EEPROM_ADDR+1, \ - CONFIG_SYS_I2C_EEPROM_ADDR+2, \ - CONFIG_SYS_I2C_EEPROM_ADDR+3, \ - CONFIG_SYS_I2C_EEPROM_ADDR+4, \ - CONFIG_SYS_I2C_EEPROM_ADDR+5, \ - CONFIG_SYS_I2C_EEPROM_ADDR+6, \ - CONFIG_SYS_I2C_EEPROM_ADDR+7, \ - } -#endif /* CONFIG_USE_FRAM */ - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CACHELINE_SHIFT 4 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 11-9 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Software & Bus Monitor Timer max, Bus Monitor enable, SW Watchdog freeze - */ -#if 0 && defined(CONFIG_WATCHDOG) /* LWMON uses external MAX706TESA WD */ -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | \ - SYPCR_SWE | SYPCR_SWRI| SYPCR_SWP) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | SYPCR_SWP) -#endif - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 11-6 - *----------------------------------------------------------------------- - * PCMCIA config., multi-function pin tri-state - */ -/* EARB, DBGC and DBPC are initialised by the HCW */ -/* => 0x000000C0 */ -#define CONFIG_SYS_SIUMCR (SIUMCR_GB5E) -/*#define CONFIG_SYS_SIUMCR (SIUMCR_DBGC00 | SIUMCR_DBPC00 | SIUMCR_MLRC01) */ - -/*----------------------------------------------------------------------- - * TBSCR - Time Base Status and Control 11-26 - *----------------------------------------------------------------------- - * Clear Reference Interrupt Status, Timebase freezing enabled - */ -#define CONFIG_SYS_TBSCR (TBSCR_REFA | TBSCR_REFB | TBSCR_TBF) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 11-31 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Interrupt Timer freezing enabled - */ -#define CONFIG_SYS_PISCR (PISCR_PS | PISCR_PITF) - -/*----------------------------------------------------------------------- - * PLPRCR - PLL, Low-Power, and Reset Control Register 15-30 - *----------------------------------------------------------------------- - * Reset PLL lock status sticky bit, timer expired status bit and timer - * interrupt status bit, set PLL multiplication factor ! - */ -/* 0x00405000 */ -#define CONFIG_SYS_PLPRCR_MF 4 /* (4+1) * 13.2 = 66 MHz Clock */ -#define CONFIG_SYS_PLPRCR \ - ( (CONFIG_SYS_PLPRCR_MF << PLPRCR_MF_SHIFT) | \ - PLPRCR_SPLSS | PLPRCR_TEXPS | PLPRCR_TMIST | \ - /*PLPRCR_CSRC|*/ PLPRCR_LPM_NORMAL | \ - PLPRCR_CSR /*| PLPRCR_LOLRE|PLPRCR_FIOPD*/ \ - ) - -#define CONFIG_8xx_GCLK_FREQ ((CONFIG_SYS_PLPRCR_MF+1)*13200000) - -/*----------------------------------------------------------------------- - * SCCR - System Clock and reset Control Register 15-27 - *----------------------------------------------------------------------- - * Set clock output, timebase and RTC source and divider, - * power management and some other internal clocks - */ -#define SCCR_MASK SCCR_EBDF11 -/* 0x01800000 */ -#define CONFIG_SYS_SCCR (SCCR_COM00 | /*SCCR_TBS|*/ \ - SCCR_RTDIV | SCCR_RTSEL | \ - /*SCCR_CRQEN|*/ /*SCCR_PRQEN|*/ \ - SCCR_EBDF00 | SCCR_DFSYNC00 | \ - SCCR_DFBRG00 | SCCR_DFNL000 | \ - SCCR_DFNH000 | SCCR_DFLCD100 | \ - SCCR_DFALCD01) - -/*----------------------------------------------------------------------- - * RTCSC - Real-Time Clock Status and Control Register 11-27 - *----------------------------------------------------------------------- - */ -/* 0x00C3 => 0x0003 */ -#define CONFIG_SYS_RTCSC (RTCSC_SEC | RTCSC_ALR | RTCSC_RTF| RTCSC_RTE) - - -/*----------------------------------------------------------------------- - * RCCR - RISC Controller Configuration Register 19-4 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RCCR 0x0000 - -/*----------------------------------------------------------------------- - * RMDS - RISC Microcode Development Support Control Register - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RMDS 0 - -/*----------------------------------------------------------------------- - * - * Interrupt Levels - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_CPM_INTERRUPT 13 /* SIU_LEVEL6 */ - -/*----------------------------------------------------------------------- - * PCMCIA stuff - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_PCMCIA_MEM_ADDR (0x50000000) -#define CONFIG_SYS_PCMCIA_MEM_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_DMA_ADDR (0x54000000) -#define CONFIG_SYS_PCMCIA_DMA_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_ATTRB_ADDR (0x58000000) -#define CONFIG_SYS_PCMCIA_ATTRB_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_IO_ADDR (0x5C000000) -#define CONFIG_SYS_PCMCIA_IO_SIZE ( 64 << 20 ) - -/*----------------------------------------------------------------------- - * IDE/ATA stuff (Supports IDE harddisk on PCMCIA Adapter) - *----------------------------------------------------------------------- - */ - -#define CONFIG_IDE_PREINIT 1 /* Use preinit IDE hook */ -#define CONFIG_IDE_8xx_PCCARD 1 /* Use IDE with PC Card Adapter */ - -#undef CONFIG_IDE_8xx_DIRECT /* Direct IDE not supported */ -#undef CONFIG_IDE_LED /* LED for ide not supported */ -#undef CONFIG_IDE_RESET /* reset for ide not supported */ - -#define CONFIG_SYS_IDE_MAXBUS 1 /* max. 1 IDE bus */ -#define CONFIG_SYS_IDE_MAXDEVICE 1 /* max. 1 drive per IDE bus */ - -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 - -#define CONFIG_SYS_ATA_BASE_ADDR CONFIG_SYS_PCMCIA_MEM_ADDR - -/* Offset for data I/O */ -#define CONFIG_SYS_ATA_DATA_OFFSET (CONFIG_SYS_PCMCIA_MEM_SIZE + 0x320) - -/* Offset for normal register accesses */ -#define CONFIG_SYS_ATA_REG_OFFSET (2 * CONFIG_SYS_PCMCIA_MEM_SIZE + 0x320) - -/* Offset for alternate registers */ -#define CONFIG_SYS_ATA_ALT_OFFSET 0x0100 - -#define CONFIG_SUPPORT_VFAT /* enable VFAT support */ - -/*----------------------------------------------------------------------- - * - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_DER 0 - -/* - * Init Memory Controller: - * - * BR0/1 and OR0/1 (FLASH) - second Flash bank optional - */ - -#define FLASH_BASE0_PRELIM 0x40000000 /* FLASH bank #0 */ -#define FLASH_BASE1_PRELIM 0x41000000 /* FLASH bank #1 */ - -/* used to re-map FLASH: - * restrict access enough to keep SRAM working (if any) - * but not too much to meddle with FLASH accesses - */ -#define CONFIG_SYS_REMAP_OR_AM 0xFF000000 /* OR addr mask */ -#define CONFIG_SYS_PRELIM_OR_AM 0xFF000000 /* OR addr mask */ - -/* FLASH timing: ACS = 00, TRLX = 0, CSNT = 1, SCY = 8, EHTR = 0 */ -#define CONFIG_SYS_OR_TIMING_FLASH (OR_SCY_8_CLK) - -#define CONFIG_SYS_OR0_REMAP ( CONFIG_SYS_REMAP_OR_AM | OR_CSNT_SAM | OR_ACS_DIV1 | OR_BI | \ - CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_PRELIM_OR_AM | OR_ACS_DIV1 | OR_BI | \ - CONFIG_SYS_OR_TIMING_FLASH) -/* 16 bit, bank valid */ -#define CONFIG_SYS_BR0_PRELIM ((FLASH_BASE0_PRELIM & BR_BA_MSK) | BR_PS_32 | BR_V ) - -#define CONFIG_SYS_OR1_REMAP CONFIG_SYS_OR0_REMAP -#define CONFIG_SYS_OR1_PRELIM CONFIG_SYS_OR0_PRELIM -#define CONFIG_SYS_BR1_PRELIM ((FLASH_BASE1_PRELIM & BR_BA_MSK) | BR_PS_32 | BR_V ) - -/* - * BR3/OR3: SDRAM - * - * Multiplexed addresses, GPL5 output to GPL5_A (don't care) - */ -#define SDRAM_BASE3_PRELIM 0x00000000 /* SDRAM bank */ -#define SDRAM_PRELIM_OR_AM 0xF0000000 /* map 256 MB (>SDRAM_MAX_SIZE!) */ -#define SDRAM_TIMING OR_SCY_0_CLK /* SDRAM-Timing */ - -#define SDRAM_MAX_SIZE 0x08000000 /* max 128 MB SDRAM */ - -#define CONFIG_SYS_OR3_PRELIM (SDRAM_PRELIM_OR_AM | OR_CSNT_SAM | OR_G5LS | SDRAM_TIMING ) -#define CONFIG_SYS_BR3_PRELIM ((SDRAM_BASE3_PRELIM & BR_BA_MSK) | BR_MS_UPMA | BR_V ) - -/* - * BR5/OR5: Touch Panel - * - * AM=0xFFC00 ATM=0 CSNT/SAM=0 ACS/G5LA/G5LS=3 BIH=1 SCY=0 SETA=0 TRLX=0 EHTR=0 - */ -#define TOUCHPNL_BASE 0x20000000 -#define TOUCHPNL_OR_AM 0xFFFF8000 -#define TOUCHPNL_TIMING OR_SCY_0_CLK - -#define CONFIG_SYS_OR5_PRELIM (TOUCHPNL_OR_AM | OR_CSNT_SAM | OR_ACS_DIV1 | OR_BI | \ - TOUCHPNL_TIMING ) -#define CONFIG_SYS_BR5_PRELIM ((TOUCHPNL_BASE & BR_BA_MSK) | BR_PS_32 | BR_V ) - -#define CONFIG_SYS_MEMORY_75 -#undef CONFIG_SYS_MEMORY_7E -#undef CONFIG_SYS_MEMORY_8E - -/* - * Memory Periodic Timer Prescaler - */ - -/* periodic timer for refresh */ -#define CONFIG_SYS_MPTPR 0x200 - -/* - * MAMR settings for SDRAM - */ - -#define CONFIG_SYS_MAMR_8COL 0x80802114 -#define CONFIG_SYS_MAMR_9COL 0x80904114 - -/* - * MAR setting for SDRAM - */ -#define CONFIG_SYS_MAR 0x00000088 - -#endif /* __CONFIG_H */ diff --git a/include/pcmcia.h b/include/pcmcia.h index 7e495bc..54ab2ac 100644 --- a/include/pcmcia.h +++ b/include/pcmcia.h @@ -25,8 +25,6 @@ # define CONFIG_PCMCIA_SLOT_B /* The TQM8xxL use SLOT_B */ #elif defined(CONFIG_IVMS8) || defined(CONFIG_IVML24) /* The IVM* use SLOT_A */ # define CONFIG_PCMCIA_SLOT_A -#elif defined(CONFIG_LWMON) /* The LWMON use SLOT_B */ -# define CONFIG_PCMCIA_SLOT_B #elif defined(CONFIG_ATC) /* The ATC use SLOT_A */ # define CONFIG_PCMCIA_SLOT_A #else
On Mon, Dec 15, 2014 at 11:26:14PM +0900, Masahiro Yamada wrote:
This board is still a non-generic board.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Wolfgang Denk wd@denx.de
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Wolfgang Denk wd@denx.de ---
arch/powerpc/cpu/mpc8xx/Kconfig | 7 - arch/powerpc/cpu/mpc8xx/cpu_init.c | 2 - board/ivm/Kconfig | 19 -- board/ivm/MAINTAINERS | 12 - board/ivm/Makefile | 8 - board/ivm/flash.c | 582 ------------------------------------- board/ivm/ivm.c | 382 ------------------------ board/ivm/u-boot.lds.debug | 122 -------- configs/IVML24_128_defconfig | 4 - configs/IVML24_256_defconfig | 4 - configs/IVML24_defconfig | 4 - configs/IVMS8_128_defconfig | 4 - configs/IVMS8_256_defconfig | 4 - configs/IVMS8_defconfig | 4 - doc/README.scrapyard | 2 + include/commproc.h | 31 -- include/configs/IVML24.h | 458 ----------------------------- include/configs/IVMS8.h | 441 ---------------------------- include/pcmcia.h | 2 - include/status_led.h | 58 ---- 20 files changed, 2 insertions(+), 2148 deletions(-) delete mode 100644 board/ivm/Kconfig delete mode 100644 board/ivm/MAINTAINERS delete mode 100644 board/ivm/Makefile delete mode 100644 board/ivm/flash.c delete mode 100644 board/ivm/ivm.c delete mode 100644 board/ivm/u-boot.lds.debug delete mode 100644 configs/IVML24_128_defconfig delete mode 100644 configs/IVML24_256_defconfig delete mode 100644 configs/IVML24_defconfig delete mode 100644 configs/IVMS8_128_defconfig delete mode 100644 configs/IVMS8_256_defconfig delete mode 100644 configs/IVMS8_defconfig delete mode 100644 include/configs/IVML24.h delete mode 100644 include/configs/IVMS8.h
diff --git a/arch/powerpc/cpu/mpc8xx/Kconfig b/arch/powerpc/cpu/mpc8xx/Kconfig index 4d47d05..ef5c511 100644 --- a/arch/powerpc/cpu/mpc8xx/Kconfig +++ b/arch/powerpc/cpu/mpc8xx/Kconfig @@ -16,12 +16,6 @@ config TARGET_ESTEEM192E config TARGET_IP860 bool "Support IP860"
-config TARGET_IVML24 - bool "Support IVML24" - -config TARGET_IVMS8 - bool "Support IVMS8" - config TARGET_TQM823L bool "Support TQM823L"
@@ -63,7 +57,6 @@ endchoice source "board/cogent/Kconfig" source "board/esteem192e/Kconfig" source "board/ip860/Kconfig" -source "board/ivm/Kconfig" source "board/tqc/tqm8xx/Kconfig"
endmenu diff --git a/arch/powerpc/cpu/mpc8xx/cpu_init.c b/arch/powerpc/cpu/mpc8xx/cpu_init.c index d41fa88..753d25d 100644 --- a/arch/powerpc/cpu/mpc8xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc8xx/cpu_init.c @@ -126,8 +126,6 @@ void cpu_init_f (volatile immap_t * immr) */
#if defined(CONFIG_IP860) || \ - defined(CONFIG_IVML24) || \ - defined(CONFIG_IVMS8) || \ defined(CONFIG_RMU)
memctl->memc_br0 = CONFIG_SYS_BR0_PRELIM; diff --git a/board/ivm/Kconfig b/board/ivm/Kconfig deleted file mode 100644 index 6ff3025..0000000 --- a/board/ivm/Kconfig +++ /dev/null @@ -1,19 +0,0 @@ -if TARGET_IVML24 - -config SYS_BOARD - default "ivm" - -config SYS_CONFIG_NAME - default "IVML24" - -endif - -if TARGET_IVMS8 - -config SYS_BOARD - default "ivm" - -config SYS_CONFIG_NAME - default "IVMS8" - -endif diff --git a/board/ivm/MAINTAINERS b/board/ivm/MAINTAINERS deleted file mode 100644 index 6a9082c..0000000 --- a/board/ivm/MAINTAINERS +++ /dev/null @@ -1,12 +0,0 @@ -IVM BOARD -M: Wolfgang Denk wd@denx.de -S: Maintained -F: board/ivm/ -F: include/configs/IVML24.h -F: configs/IVML24_defconfig -F: configs/IVML24_128_defconfig -F: configs/IVML24_256_defconfig -F: include/configs/IVMS8.h -F: configs/IVMS8_defconfig -F: configs/IVMS8_128_defconfig -F: configs/IVMS8_256_defconfig diff --git a/board/ivm/Makefile b/board/ivm/Makefile deleted file mode 100644 index e53a276..0000000 --- a/board/ivm/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = ivm.o flash.o diff --git a/board/ivm/flash.c b/board/ivm/flash.c deleted file mode 100644 index 14d3aee..0000000 --- a/board/ivm/flash.c +++ /dev/null @@ -1,582 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc8xx.h> - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH chips */ - -#if defined(CONFIG_ENV_IS_IN_FLASH) -# ifndef CONFIG_ENV_ADDR -# define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET) -# endif -# ifndef CONFIG_ENV_SIZE -# define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -# endif -# ifndef CONFIG_ENV_SECT_SIZE -# define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE -# endif -#endif - -/*----------------------------------------------------------------------- - * Functions - */ -static ulong flash_get_size (vu_long *addr, flash_info_t *info); -static int write_data (flash_info_t *info, ulong dest, ulong data); -static void flash_get_offsets (ulong base, flash_info_t *info); - -/*----------------------------------------------------------------------- - */ - -unsigned long flash_init (void) -{ - volatile immap_t *immap = (immap_t *)CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - unsigned long size_b0; - int i; - - /* Init: no FLASHes known */ - for (i=0; i<CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - } - - /* Static FLASH Bank configuration here - FIXME XXX */ - - size_b0 = flash_get_size((vu_long *)FLASH_BASE0_PRELIM, &flash_info[0]); - - if (flash_info[0].flash_id == FLASH_UNKNOWN) { - printf ("## Unknown FLASH on Bank 0: " - "ID 0x%lx, Size = 0x%08lx = %ld MB\n", - flash_info[0].flash_id, - size_b0, size_b0<<20); - } - - /* Remap FLASH according to real size */ - memctl->memc_or0 = CONFIG_SYS_OR_TIMING_FLASH | (-size_b0 & 0xFFFF8000); - memctl->memc_br0 = (CONFIG_SYS_FLASH_BASE & BR_BA_MSK) | \ - BR_MS_GPCM | BR_PS_16 | BR_V; - - /* Re-do sizing to get full correct info */ - size_b0 = flash_get_size((vu_long *)CONFIG_SYS_FLASH_BASE, &flash_info[0]); - - flash_get_offsets (CONFIG_SYS_FLASH_BASE, &flash_info[0]); - - flash_info[0].size = size_b0; - -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE - /* monitor protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE+monitor_flash_len-1, - &flash_info[0]); -#endif - -#ifdef CONFIG_ENV_IS_IN_FLASH - /* ENV protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR+CONFIG_ENV_SECT_SIZE-1, - &flash_info[0]); -#endif - - return (size_b0); -} - -/*----------------------------------------------------------------------- - */ -static void flash_get_offsets (ulong base, flash_info_t *info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_MT: - if (info->flash_id & FLASH_BTYPE) { - /* set sector offsets for bottom boot block type */ - info->start[0] = base + 0x00000000; - info->start[1] = base + 0x00004000; - info->start[2] = base + 0x00006000; - info->start[3] = base + 0x00008000; - for (i = 4; i < info->sector_count; i++) { - info->start[i] = base + ((i-3) * 0x00020000); - } - } else { - /* set sector offsets for top boot block type */ - i = info->sector_count - 1; - info->start[i--] = base + info->size - 0x00004000; - info->start[i--] = base + info->size - 0x00006000; - info->start[i--] = base + info->size - 0x00008000; - for (; i >= 0; i--) { - info->start[i] = base + i * 0x00020000; - } - } - return; - - case FLASH_MAN_SST: - for (i = 0; i < info->sector_count; i++) { - info->start[i] = base + (i * 0x00002000); - } - return; - - case FLASH_MAN_AMD: - case FLASH_MAN_FUJ: - - /* set up sector start address table */ - if (info->flash_id & FLASH_BTYPE) { - /* set sector offsets for bottom boot block type */ - info->start[0] = base + 0x00000000; - info->start[1] = base + 0x00008000; - info->start[2] = base + 0x0000C000; - info->start[3] = base + 0x00010000; - for (i = 4; i < info->sector_count; i++) { - info->start[i] = base + (i * 0x00020000) - 0x00060000; - } - } else { - /* set sector offsets for top boot block type */ - i = info->sector_count - 1; - info->start[i--] = base + info->size - 0x00008000; - info->start[i--] = base + info->size - 0x0000C000; - info->start[i--] = base + info->size - 0x00010000; - for (; i >= 0; i--) { - info->start[i] = base + i * 0x00020000; - } - } - return; - default: - printf ("Don't know sector ofsets for flash type 0x%lx\n", - info->flash_id); - return; - } -} - -/*----------------------------------------------------------------------- - */ -void flash_print_info (flash_info_t *info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_AMD: printf ("AMD "); break; - case FLASH_MAN_FUJ: printf ("Fujitsu "); break; - case FLASH_MAN_SST: printf ("SST "); break; - case FLASH_MAN_STM: printf ("STM "); break; - case FLASH_MAN_MT: printf ("MT "); break; - case FLASH_MAN_INTEL: printf ("Intel "); break; - default: printf ("Unknown Vendor "); break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_AM400B: printf ("AM29LV400B (4 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM400T: printf ("AM29LV400T (4 Mbit, top boot sector)\n"); - break; - case FLASH_AM800B: printf ("AM29LV800B (8 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM800T: printf ("AM29LV800T (8 Mbit, top boot sector)\n"); - break; - case FLASH_AM160B: printf ("AM29LV160B (16 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM160T: printf ("AM29LV160T (16 Mbit, top boot sector)\n"); - break; - case FLASH_AM320B: printf ("AM29LV320B (32 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM320T: printf ("AM29LV320T (32 Mbit, top boot sector)\n"); - break; - case FLASH_SST200A: printf ("39xF200A (2M = 128K x 16)\n"); - break; - case FLASH_SST400A: printf ("39xF400A (4M = 256K x 16)\n"); - break; - case FLASH_SST800A: printf ("39xF800A (8M = 512K x 16)\n"); - break; - case FLASH_STM800AB: printf ("M29W800AB (8M = 512K x 16)\n"); - break; - case FLASH_28F008S5: printf ("28F008S5 (1M = 64K x 16)\n"); - break; - case FLASH_28F400_T: printf ("28F400B3 (4Mbit, top boot sector)\n"); - break; - case FLASH_28F400_B: printf ("28F400B3 (4Mbit, bottom boot sector)\n"); - break; - default: printf ("Unknown Chip Type\n"); - break; - } - - if (info->size >= (1 << 20)) { - i = 20; - } else { - i = 10; - } - printf (" Size: %ld %cB in %d Sectors\n", - info->size >> i, - (i == 20) ? 'M' : 'k', - info->sector_count); - - printf (" Sector Start Addresses:"); - for (i=0; i<info->sector_count; ++i) { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", - info->start[i], - info->protect[i] ? " (RO)" : " " - ); - } - printf ("\n"); - return; -} - -/*----------------------------------------------------------------------- - */ - - -/*----------------------------------------------------------------------- - */ - -/* - * The following code cannot be run from FLASH! - */ - -static ulong flash_get_size (vu_long *addr, flash_info_t *info) -{ - ushort value; - vu_short *saddr = (vu_short *)addr; - - /* Read Manufacturer ID */ - saddr[0] = 0x0090; - value = saddr[0]; - - switch (value) { - case (AMD_MANUFACT & 0xFFFF): - info->flash_id = FLASH_MAN_AMD; - break; - case (FUJ_MANUFACT & 0xFFFF): - info->flash_id = FLASH_MAN_FUJ; - break; - case (SST_MANUFACT & 0xFFFF): - info->flash_id = FLASH_MAN_SST; - break; - case (STM_MANUFACT & 0xFFFF): - info->flash_id = FLASH_MAN_STM; - break; - case (MT_MANUFACT & 0xFFFF): - info->flash_id = FLASH_MAN_MT; - break; - default: - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - saddr[0] = 0x00FF; /* restore read mode */ - return (0); /* no or unknown flash */ - } - - value = saddr[1]; /* device ID */ - - switch (value) { - case (AMD_ID_LV400T & 0xFFFF): - info->flash_id += FLASH_AM400T; - info->sector_count = 11; - info->size = 0x00100000; - break; /* => 1 MB */ - - case (AMD_ID_LV400B & 0xFFFF): - info->flash_id += FLASH_AM400B; - info->sector_count = 11; - info->size = 0x00100000; - break; /* => 1 MB */ - - case (AMD_ID_LV800T & 0xFFFF): - info->flash_id += FLASH_AM800T; - info->sector_count = 19; - info->size = 0x00200000; - break; /* => 2 MB */ - - case (AMD_ID_LV800B & 0xFFFF): - info->flash_id += FLASH_AM800B; - info->sector_count = 19; - info->size = 0x00200000; - break; /* => 2 MB */ - - case (AMD_ID_LV160T & 0xFFFF): - info->flash_id += FLASH_AM160T; - info->sector_count = 35; - info->size = 0x00400000; - break; /* => 4 MB */ - - case (AMD_ID_LV160B & 0xFFFF): - info->flash_id += FLASH_AM160B; - info->sector_count = 35; - info->size = 0x00400000; - break; /* => 4 MB */ -#if 0 /* enable when device IDs are available */ - case (AMD_ID_LV320T & 0xFFFF): - info->flash_id += FLASH_AM320T; - info->sector_count = 67; - info->size = 0x00800000; - break; /* => 8 MB */ - - case (AMD_ID_LV320B & 0xFFFF): - info->flash_id += FLASH_AM320B; - info->sector_count = 67; - info->size = 0x00800000; - break; /* => 8 MB */ -#endif - case (SST_ID_xF200A & 0xFFFF): - info->flash_id += FLASH_SST200A; - info->sector_count = 64; /* 39xF200A ID ( 2M = 128K x 16 ) */ - info->size = 0x00080000; - break; - case (SST_ID_xF400A & 0xFFFF): - info->flash_id += FLASH_SST400A; - info->sector_count = 128; /* 39xF400A ID ( 4M = 256K x 16 ) */ - info->size = 0x00100000; - break; - case (SST_ID_xF800A & 0xFFFF): - info->flash_id += FLASH_SST800A; - info->sector_count = 256; /* 39xF800A ID ( 8M = 512K x 16 ) */ - info->size = 0x00200000; - break; /* => 2 MB */ - case (STM_ID_x800AB & 0xFFFF): - info->flash_id += FLASH_STM800AB; - info->sector_count = 19; - info->size = 0x00200000; - break; /* => 2 MB */ - case (MT_ID_28F400_T & 0xFFFF): - info->flash_id += FLASH_28F400_T; - info->sector_count = 7; - info->size = 0x00080000; - break; /* => 512 kB */ - case (MT_ID_28F400_B & 0xFFFF): - info->flash_id += FLASH_28F400_B; - info->sector_count = 7; - info->size = 0x00080000; - break; /* => 512 kB */ - default: - info->flash_id = FLASH_UNKNOWN; - saddr[0] = 0x00FF; /* restore read mode */ - return (0); /* => no or unknown flash */ - - } - - if (info->sector_count > CONFIG_SYS_MAX_FLASH_SECT) { - printf ("** ERROR: sector count %d > max (%d) **\n", - info->sector_count, CONFIG_SYS_MAX_FLASH_SECT); - info->sector_count = CONFIG_SYS_MAX_FLASH_SECT; - } - - saddr[0] = 0x00FF; /* restore read mode */ - - return (info->size); -} - - -/*----------------------------------------------------------------------- - */ - -int flash_erase (flash_info_t *info, int s_first, int s_last) -{ - int flag, prot, sect; - ulong start, now, last; - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - if ((info->flash_id & FLASH_VENDMASK) != FLASH_MAN_MT) { - printf ("Can erase only MT flash types - aborted\n"); - return 1; - } - - prot = 0; - for (sect=s_first; sect<=s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - printf ("\n"); - } - - start = get_timer (0); - last = start; - /* Start erase on unprotected sectors */ - for (sect = s_first; sect<=s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - vu_short *addr = (vu_short *)(info->start[sect]); - unsigned short status; - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - *addr = 0x0050; /* clear status register */ - *addr = 0x0020; /* erase setup */ - *addr = 0x00D0; /* erase confirm */ - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - - while (((status = *addr) & 0x0080) != 0x0080) { - if ((now=get_timer(start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - *addr = 0x00FF; /* reset to read mode */ - return 1; - } - - /* show that we're waiting */ - if ((now - last) > 1000) { /* every second */ - putc ('.'); - last = now; - } - } - - *addr = 0x00FF; /* reset to read mode */ - } - } - printf (" done\n"); - return 0; -} - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - * 4 - Flash not identified - */ - -#define FLASH_WIDTH 2 /* flash bus width in bytes */ - -int write_buff (flash_info_t *info, uchar *src, ulong addr, ulong cnt) -{ - ulong cp, wp, data; - int i, l, rc; - - if (info->flash_id == FLASH_UNKNOWN) { - return 4; - } - - wp = (addr & ~(FLASH_WIDTH-1)); /* get lower FLASH_WIDTH aligned address */ - - /* - * handle unaligned start bytes - */ - if ((l = addr - wp) != 0) { - data = 0; - for (i=0, cp=wp; i<l; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - for (; i<FLASH_WIDTH && cnt>0; ++i) { - data = (data << 8) | *src++; - --cnt; - ++cp; - } - for (; cnt==0 && i<FLASH_WIDTH; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - - if ((rc = write_data(info, wp, data)) != 0) { - return (rc); - } - wp += FLASH_WIDTH; - } - - /* - * handle FLASH_WIDTH aligned part - */ - while (cnt >= FLASH_WIDTH) { - data = 0; - for (i=0; i<FLASH_WIDTH; ++i) { - data = (data << 8) | *src++; - } - if ((rc = write_data(info, wp, data)) != 0) { - return (rc); - } - wp += FLASH_WIDTH; - cnt -= FLASH_WIDTH; - } - - if (cnt == 0) { - return (0); - } - - /* - * handle unaligned tail bytes - */ - data = 0; - for (i=0, cp=wp; i<FLASH_WIDTH && cnt>0; ++i, ++cp) { - data = (data << 8) | *src++; - --cnt; - } - for (; i<FLASH_WIDTH; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - - return (write_data(info, wp, data)); -} - -/*----------------------------------------------------------------------- - * Write a word to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_data (flash_info_t *info, ulong dest, ulong data) -{ - vu_short *addr = (vu_short *)dest; - ushort sdata = (ushort)data; - ushort status; - ulong start; - int flag; - - /* Check if Flash is (sufficiently) erased */ - if ((*addr & sdata) != sdata) { - return (2); - } - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - *addr = 0x0040; /* write setup */ - *addr = sdata; - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - start = get_timer (0); - - while (((status = *addr) & 0x0080) != 0x0080) { - if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - *addr = 0x00FF; /* restore read mode */ - return (1); - } - } - - *addr = 0x00FF; /* restore read mode */ - - return (0); -} - -/*----------------------------------------------------------------------- - */ diff --git a/board/ivm/ivm.c b/board/ivm/ivm.c deleted file mode 100644 index 3bdbdd1..0000000 --- a/board/ivm/ivm.c +++ /dev/null @@ -1,382 +0,0 @@ -/* - * (C) Copyright 2000, 2001 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * Ulrich Lutz, Speech Design GmbH, ulutz@datalab.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc8xx.h> -#include <commproc.h> - -#ifdef CONFIG_STATUS_LED -# include <status_led.h> -#endif - -/* ------------------------------------------------------------------------- */ - -static long int dram_size (long int, long int *, long int); - -/* ------------------------------------------------------------------------- */ - -#define _NOT_USED_ 0xFFFFFFFF - -/* - * 50 MHz SHARC access using UPM A - */ -const uint sharc_table[] = { - /* - * Single Read. (Offset 0 in UPM RAM) - */ - 0x0FF3FC04, 0x0FF3EC00, 0x7FFFEC04, 0xFFFFEC04, - 0xFFFFEC05, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Burst Read. (Offset 8 in UPM RAM) - */ - /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Single Write. (Offset 18 in UPM RAM) - */ - 0x0FAFFC04, 0x0FAFEC00, 0x7FFFEC04, 0xFFFFEC04, - 0xFFFFEC05, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Burst Write. (Offset 20 in UPM RAM) - */ - /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Refresh (Offset 30 in UPM RAM) - */ - /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Exception. (Offset 3c in UPM RAM) - */ - 0x7FFFFC07, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, -}; - - -/* - * 50 MHz SDRAM access using UPM B - */ -const uint sdram_table[] = { - /* - * Single Read. (Offset 0 in UPM RAM) - */ - 0x0E26FC04, 0x11ADFC04, 0xEFBBBC00, 0x1FF77C45, /* last */ - _NOT_USED_, - /* - * SDRAM Initialization (offset 5 in UPM RAM) - * - * This is no UPM entry point. The following definition uses - * the remaining space to establish an initialization - * sequence, which is executed by a RUN command. - * - */ - 0x1FF77C35, 0xEFEABC34, 0x1FB57C35, /* last */ - /* - * Burst Read. (Offset 8 in UPM RAM) - */ - 0x0E26FC04, 0x10ADFC04, 0xF0AFFC00, 0xF0AFFC00, - 0xF1AFFC00, 0xEFBBBC00, 0x1FF77C45, /* last */ - _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Single Write. (Offset 18 in UPM RAM) - */ - 0x1F27FC04, 0xEEAEBC04, 0x01B93C00, 0x1FF77C45, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Burst Write. (Offset 20 in UPM RAM) - */ - 0x0E26BC00, 0x10AD7C00, 0xF0AFFC00, 0xF0AFFC00, - 0xE1BBBC04, 0x1FF77C45, /* last */ - _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Refresh (Offset 30 in UPM RAM) - */ - 0x1FF5FC84, 0xFFFFFC04, 0xFFFFFC04, 0xFFFFFC84, - 0xFFFFFC05, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Exception. (Offset 3c in UPM RAM) - */ - 0x7FFFFC07, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, -}; - -/* ------------------------------------------------------------------------- */ - - -/* - * Check Board Identity: - * - */ - -int checkboard (void) -{ -#ifdef CONFIG_IVMS8 - puts ("Board: IVMS8\n"); -#endif -#ifdef CONFIG_IVML24 - puts ("Board: IVM-L8/24\n"); -#endif - return (0); -} - -/* ------------------------------------------------------------------------- */ - -phys_size_t initdram (int board_type) -{ - volatile immap_t *immr = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immr->im_memctl; - long int size_b0; - - /* enable SDRAM clock ("switch on" SDRAM) */ - immr->im_cpm.cp_pbpar &= ~(CONFIG_SYS_PB_SDRAM_CLKE); /* GPIO */ - immr->im_cpm.cp_pbodr &= ~(CONFIG_SYS_PB_SDRAM_CLKE); /* active output */ - immr->im_cpm.cp_pbdir |= CONFIG_SYS_PB_SDRAM_CLKE; /* output */ - immr->im_cpm.cp_pbdat |= CONFIG_SYS_PB_SDRAM_CLKE; /* assert SDRAM CLKE */ - udelay (1); - - /* - * Map controller bank 1 for ELIC SACCO - */ - memctl->memc_or1 = CONFIG_SYS_OR1; - memctl->memc_br1 = CONFIG_SYS_BR1; - - /* - * Map controller bank 2 for ELIC EPIC - */ - memctl->memc_or2 = CONFIG_SYS_OR2; - memctl->memc_br2 = CONFIG_SYS_BR2; - - /* - * Configure UPMA for SHARC - */ - upmconfig (UPMA, (uint *) sharc_table, - sizeof (sharc_table) / sizeof (uint)); - -#if defined(CONFIG_IVML24) - /* - * Map controller bank 4 for HDLC Address space - */ - memctl->memc_or4 = CONFIG_SYS_OR4; - memctl->memc_br4 = CONFIG_SYS_BR4; -#endif - - /* - * Map controller bank 5 for SHARC - */ - memctl->memc_or5 = CONFIG_SYS_OR5; - memctl->memc_br5 = CONFIG_SYS_BR5; - - memctl->memc_mamr = 0x00001000; - - /* - * Configure UPMB for SDRAM - */ - upmconfig (UPMB, (uint *) sdram_table, - sizeof (sdram_table) / sizeof (uint)); - - memctl->memc_mptpr = CONFIG_SYS_MPTPR_1BK_8K; - - memctl->memc_mar = 0x00000088; - - /* - * Map controller bank 3 to the SDRAM bank at preliminary address. - */ - memctl->memc_or3 = CONFIG_SYS_OR3_PRELIM; - memctl->memc_br3 = CONFIG_SYS_BR3_PRELIM; - - memctl->memc_mbmr = CONFIG_SYS_MBMR_8COL; /* refresh not enabled yet */ - - udelay (200); - memctl->memc_mcr = 0x80806105; /* precharge */ - udelay (1); - memctl->memc_mcr = 0x80806106; /* load mode register */ - udelay (1); - memctl->memc_mcr = 0x80806130; /* autorefresh */ - udelay (1); - memctl->memc_mcr = 0x80806130; /* autorefresh */ - udelay (1); - memctl->memc_mcr = 0x80806130; /* autorefresh */ - udelay (1); - memctl->memc_mcr = 0x80806130; /* autorefresh */ - udelay (1); - memctl->memc_mcr = 0x80806130; /* autorefresh */ - udelay (1); - memctl->memc_mcr = 0x80806130; /* autorefresh */ - udelay (1); - memctl->memc_mcr = 0x80806130; /* autorefresh */ - udelay (1); - memctl->memc_mcr = 0x80806130; /* autorefresh */ - - memctl->memc_mbmr |= MBMR_PTBE; /* refresh enabled */ - - /* - * Check Bank 0 Memory Size for re-configuration - */ - size_b0 = - dram_size (CONFIG_SYS_MBMR_8COL, (long *) SDRAM_BASE3_PRELIM, - SDRAM_MAX_SIZE); - - memctl->memc_mbmr = CONFIG_SYS_MBMR_8COL | MBMR_PTBE; - - return (size_b0); -} - -/* ------------------------------------------------------------------------- */ - -/* - * Check memory range for valid RAM. A simple memory test determines - * the actually available RAM size between addresses `base' and - * `base + maxsize'. Some (not all) hardware errors are detected: - * - short between address lines - * - short between data lines - */ - -static long int dram_size (long int mamr_value, long int *base, - long int maxsize) -{ - volatile immap_t *immr = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immr->im_memctl; - - memctl->memc_mbmr = mamr_value; - - return (get_ram_size (base, maxsize)); -} - -/* ------------------------------------------------------------------------- */ - -void reset_phy (void) -{ - immap_t *immr = (immap_t *) CONFIG_SYS_IMMR; - - /* De-assert Ethernet Powerdown */ - immr->im_cpm.cp_pbpar &= ~(CONFIG_SYS_PB_ETH_POWERDOWN); /* GPIO */ - immr->im_cpm.cp_pbodr &= ~(CONFIG_SYS_PB_ETH_POWERDOWN); /* active output */ - immr->im_cpm.cp_pbdir |= CONFIG_SYS_PB_ETH_POWERDOWN; /* output */ - immr->im_cpm.cp_pbdat &= ~(CONFIG_SYS_PB_ETH_POWERDOWN); /* Enable PHY power */ - udelay (1000); - - /* - * RESET is implemented by a positive pulse of at least 1 us - * at the reset pin. - * - * Configure RESET pins for NS DP83843 PHY, and RESET chip. - * - * Note: The RESET pin is high active, but there is an - * inverter on the SPD823TS board... - */ - immr->im_ioport.iop_pcpar &= ~(CONFIG_SYS_PC_ETH_RESET); - immr->im_ioport.iop_pcdir |= CONFIG_SYS_PC_ETH_RESET; - /* assert RESET signal of PHY */ - immr->im_ioport.iop_pcdat &= ~(CONFIG_SYS_PC_ETH_RESET); - udelay (10); - /* de-assert RESET signal of PHY */ - immr->im_ioport.iop_pcdat |= CONFIG_SYS_PC_ETH_RESET; - udelay (10); -} - -/* ------------------------------------------------------------------------- */ - -void show_boot_progress (int status) -{ -#if defined(CONFIG_STATUS_LED) -# if defined(STATUS_LED_YELLOW) - status_led_set (STATUS_LED_YELLOW, - (status < 0) ? STATUS_LED_ON : STATUS_LED_OFF); -# endif /* STATUS_LED_YELLOW */ -# if defined(STATUS_LED_BOOT) - if (status == BOOTSTAGE_ID_DECOMP_IMAGE) - status_led_set (STATUS_LED_BOOT, STATUS_LED_OFF); -# endif /* STATUS_LED_BOOT */ -#endif /* CONFIG_STATUS_LED */ -} - -/* ------------------------------------------------------------------------- */ - -void ide_set_reset (int on) -{ - volatile immap_t *immr = (immap_t *) CONFIG_SYS_IMMR; - int i; - - /* - * Configure PC for IDE Reset Pin - */ - if (on) { /* assert RESET */ - immr->im_ioport.iop_pcdat &= ~(CONFIG_SYS_PC_IDE_RESET); - -#ifdef CONFIG_SYS_PB_12V_ENABLE - /* 12V Enable output OFF */ - immr->im_cpm.cp_pbdat &= ~(CONFIG_SYS_PB_12V_ENABLE); - - immr->im_cpm.cp_pbpar &= ~(CONFIG_SYS_PB_12V_ENABLE); - immr->im_cpm.cp_pbodr &= ~(CONFIG_SYS_PB_12V_ENABLE); - immr->im_cpm.cp_pbdir |= CONFIG_SYS_PB_12V_ENABLE; - - /* wait 500 ms for the voltage to stabilize */ - for (i = 0; i < 500; ++i) - udelay(1000); -#endif /* CONFIG_SYS_PB_12V_ENABLE */ - } else { /* release RESET */ -#ifdef CONFIG_SYS_PB_12V_ENABLE - /* 12V Enable output ON */ - immr->im_cpm.cp_pbdat |= CONFIG_SYS_PB_12V_ENABLE; -#endif /* CONFIG_SYS_PB_12V_ENABLE */ - -#ifdef CONFIG_SYS_PB_IDE_MOTOR - /* configure IDE Motor voltage monitor pin as input */ - immr->im_cpm.cp_pbpar &= ~(CONFIG_SYS_PB_IDE_MOTOR); - immr->im_cpm.cp_pbodr &= ~(CONFIG_SYS_PB_IDE_MOTOR); - immr->im_cpm.cp_pbdir &= ~(CONFIG_SYS_PB_IDE_MOTOR); - -/* wait up to 1 s for the motor voltage to stabilize */ - for (i = 0; i < 1000; ++i) { - if ((immr->im_cpm.cp_pbdat - & CONFIG_SYS_PB_IDE_MOTOR) != 0) - break; - udelay(1000); - } - - if (i == 1000) { /* Timeout */ - printf("\nWarning: 5V for IDE Motor missing\n"); -#ifdef CONFIG_STATUS_LED -#ifdef STATUS_LED_YELLOW - status_led_set(STATUS_LED_YELLOW, STATUS_LED_ON); -#endif -#ifdef STATUS_LED_GREEN - status_led_set(STATUS_LED_GREEN, STATUS_LED_OFF); -#endif -#endif /* CONFIG_STATUS_LED */ - } -#endif /* CONFIG_SYS_PB_IDE_MOTOR */ - - immr->im_ioport.iop_pcdat |= CONFIG_SYS_PC_IDE_RESET; - } - - /* program port pin as GPIO output */ - immr->im_ioport.iop_pcpar &= ~(CONFIG_SYS_PC_IDE_RESET); - immr->im_ioport.iop_pcso &= ~(CONFIG_SYS_PC_IDE_RESET); - immr->im_ioport.iop_pcdir |= CONFIG_SYS_PC_IDE_RESET; -} - -/* ------------------------------------------------------------------------- */ diff --git a/board/ivm/u-boot.lds.debug b/board/ivm/u-boot.lds.debug deleted file mode 100644 index 1dd207b..0000000 --- a/board/ivm/u-boot.lds.debug +++ /dev/null @@ -1,122 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -OUTPUT_ARCH(powerpc) -/* Do we need any of these for elf? - __DYNAMIC = 0; */ -SECTIONS -{ - /* Read-only sections, merged into text segment: */ - . = + SIZEOF_HEADERS; - .interp : { *(.interp) } - .hash : { *(.hash) } - .dynsym : { *(.dynsym) } - .dynstr : { *(.dynstr) } - .rel.text : { *(.rel.text) } - .rela.text : { *(.rela.text) } - .rel.data : { *(.rel.data) } - .rela.data : { *(.rela.data) } - .rel.rodata : { *(.rel.rodata) } - .rela.rodata : { *(.rela.rodata) } - .rel.got : { *(.rel.got) } - .rela.got : { *(.rela.got) } - .rel.ctors : { *(.rel.ctors) } - .rela.ctors : { *(.rela.ctors) } - .rel.dtors : { *(.rel.dtors) } - .rela.dtors : { *(.rela.dtors) } - .rel.bss : { *(.rel.bss) } - .rela.bss : { *(.rela.bss) } - .rel.plt : { *(.rel.plt) } - .rela.plt : { *(.rela.plt) } - .init : { *(.init) } - .plt : { *(.plt) } - .text : - { - /* WARNING - the following is hand-optimized to fit within */ - /* the sector layout of our flash chips! XXX FIXME XXX */ - - arch/powerpc/cpu/mpc8xx/start.o (.text) - common/dlmalloc.o (.text) - lib/vsprintf.o (.text) - lib/crc32.o (.text) - arch/powerpc/lib/extable.o (.text) - - . = env_offset; - common/env_embedded.o(.text) - - *(.text) - *(.got1) - } - _etext = .; - PROVIDE (etext = .); - .rodata : - { - *(.rodata) - *(.rodata1) - *(.rodata.str1.4) - *(.eh_frame) - } - .fini : { *(.fini) } =0 - .ctors : { *(.ctors) } - .dtors : { *(.dtors) } - - /* Read-write section, merged into data segment: */ - . = (. + 0x0FFF) & 0xFFFFF000; - _erotext = .; - PROVIDE (erotext = .); - .reloc : - { - *(.got) - _GOT2_TABLE_ = .; - *(.got2) - _FIXUP_TABLE_ = .; - *(.fixup) - } - __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; - __fixup_entries = (. - _FIXUP_TABLE_)>>2; - - .data : - { - *(.data) - *(.data1) - *(.sdata) - *(.sdata2) - *(.dynamic) - CONSTRUCTORS - } - _edata = .; - PROVIDE (edata = .); - - - . = ALIGN(4); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); - } - - - __start___ex_table = .; - __ex_table : { *(__ex_table) } - __stop___ex_table = .; - - . = ALIGN(4096); - __init_begin = .; - .text.init : { *(.text.init) } - .data.init : { *(.data.init) } - . = ALIGN(4096); - __init_end = .; - - __bss_start = .; - .bss : - { - *(.sbss) *(.scommon) - *(.dynbss) - *(.bss) - *(COMMON) - } - __bss_end = . ; - PROVIDE (end = .); -} diff --git a/configs/IVML24_128_defconfig b/configs/IVML24_128_defconfig deleted file mode 100644 index f0850f6..0000000 --- a/configs/IVML24_128_defconfig +++ /dev/null @@ -1,4 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="IVML24_32M" -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_IVML24=y diff --git a/configs/IVML24_256_defconfig b/configs/IVML24_256_defconfig deleted file mode 100644 index 9c241c2..0000000 --- a/configs/IVML24_256_defconfig +++ /dev/null @@ -1,4 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="IVML24_64M" -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_IVML24=y diff --git a/configs/IVML24_defconfig b/configs/IVML24_defconfig deleted file mode 100644 index 0f85d43..0000000 --- a/configs/IVML24_defconfig +++ /dev/null @@ -1,4 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="IVML24_16M" -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_IVML24=y diff --git a/configs/IVMS8_128_defconfig b/configs/IVMS8_128_defconfig deleted file mode 100644 index 685d76f..0000000 --- a/configs/IVMS8_128_defconfig +++ /dev/null @@ -1,4 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="IVMS8_32M" -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_IVMS8=y diff --git a/configs/IVMS8_256_defconfig b/configs/IVMS8_256_defconfig deleted file mode 100644 index 63435d2..0000000 --- a/configs/IVMS8_256_defconfig +++ /dev/null @@ -1,4 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="IVMS8_64M" -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_IVMS8=y diff --git a/configs/IVMS8_defconfig b/configs/IVMS8_defconfig deleted file mode 100644 index 3f4087b..0000000 --- a/configs/IVMS8_defconfig +++ /dev/null @@ -1,4 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="IVMS8_16M" -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_IVMS8=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 1f5ff8f..252b607 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,8 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +IVML24 powerpc mpc8xx - - Wolfgang Denk wd@denx.de +IVMS8 powerpc mpc8xx - - Wolfgang Denk wd@denx.de lwmon powerpc mpc8xx - - Wolfgang Denk wd@denx.de NETVIA powerpc mpc8xx - - Pantelis Antoniou panto@intracom.gr R360MPI powerpc mpc8xx - - Wolfgang Denk wd@denx.de diff --git a/include/commproc.h b/include/commproc.h index 509d6e4..6e0a233 100644 --- a/include/commproc.h +++ b/include/commproc.h @@ -512,37 +512,6 @@ typedef struct scc_enet { #define SICR_ENET_CLKRT ((uint)0x0000002C) #endif /* CONFIG_IP860 */
-/*** IVMS8 **********************************************************/ - -/* The IVMS8 uses the FEC on a MPC860T for Ethernet */ - -#if defined(CONFIG_IVMS8) || defined(CONFIG_IVML24) - -#define FEC_ENET /* use FEC for EThernet */ -#undef SCC_ENET - -#define PB_ENET_POWER ((uint)0x00010000) /* PB 15 */ - -#define PC_ENET_RESET ((ushort)0x0010) /* PC 11 */ - -#define PD_MII_TXD1 ((ushort)0x1000) /* PD 3 */ -#define PD_MII_TXD2 ((ushort)0x0800) /* PD 4 */ -#define PD_MII_TXD3 ((ushort)0x0400) /* PD 5 */ -#define PD_MII_RX_DV ((ushort)0x0200) /* PD 6 */ -#define PD_MII_RX_ERR ((ushort)0x0100) /* PD 7 */ -#define PD_MII_RX_CLK ((ushort)0x0080) /* PD 8 */ -#define PD_MII_TXD0 ((ushort)0x0040) /* PD 9 */ -#define PD_MII_RXD0 ((ushort)0x0020) /* PD 10 */ -#define PD_MII_TX_ERR ((ushort)0x0010) /* PD 11 */ -#define PD_MII_MDC ((ushort)0x0008) /* PD 12 */ -#define PD_MII_RXD1 ((ushort)0x0004) /* PD 13 */ -#define PD_MII_RXD2 ((ushort)0x0002) /* PD 14 */ -#define PD_MII_RXD3 ((ushort)0x0001) /* PD 15 */ - -#define PD_MII_MASK ((ushort)0x1FFF) /* PD 3...15 */ - -#endif /* CONFIG_IVMS8, CONFIG_IVML24 */ - /*** KM8XX *********************************************************/
/* The KM8XX Service Module uses SCC3 for Ethernet */ diff --git a/include/configs/IVML24.h b/include/configs/IVML24.h deleted file mode 100644 index 8aa4ac2..0000000 --- a/include/configs/IVML24.h +++ /dev/null @@ -1,458 +0,0 @@ -/* - * (C) Copyright 2001 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC860 1 /* This is a MPC860 CPU */ -#define CONFIG_IVML24 1 /* ...on a IVML24 board */ - -#define CONFIG_SYS_TEXT_BASE 0xFF000000 - -#if defined (CONFIG_IVML24_16M) -# define CONFIG_IDENT_STRING " IVML24" -#elif defined (CONFIG_IVML24_32M) -# define CONFIG_IDENT_STRING " IVML24_128" -#elif defined (CONFIG_IVML24_64M) -# define CONFIG_IDENT_STRING " IVML24_256" -#endif - -#define CONFIG_8xx_CONS_SMC1 1 /* Console is on SMC1 */ -#undef CONFIG_8xx_CONS_SMC2 -#undef CONFIG_8xx_CONS_NONE -#define CONFIG_BAUDRATE 115200 - -#define CONFIG_CLOCKS_IN_MHZ 1 /* clocks passsed to Linux in MHz */ -#define CONFIG_8xx_GCLK_FREQ 50331648 - -#define CONFIG_RESET_PHY_R 1 /* Call reset_phy() */ - -#define CONFIG_SHOW_BOOT_PROGRESS 1 /* Show boot progress on LEDs */ - -#if 0 -#define CONFIG_BOOTDELAY -1 /* autoboot disabled */ -#else -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ -#endif -#define CONFIG_BOOTCOMMAND "bootp" /* autoboot command */ - -#define CONFIG_BOOTARGS "root=/dev/nfs rw " \ - "nfsroot=10.0.0.2:/opt/eldk/ppc_8xx " \ - "nfsaddrs=10.0.0.99:10.0.0.2" - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -#define CONFIG_STATUS_LED 1 /* Status LED enabled */ - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_IDE - - -#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE - - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x00100000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x00F00000 /* 1 ... 15MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x00100000 /* default load address */ - -#define CONFIG_SYS_PIO_MODE 0 /* IDE interface in PIO Mode 0 */ - -#define CONFIG_SYS_PB_12V_ENABLE 0x00002000 /* PB 18 */ -#define CONFIG_SYS_PB_ILOCK_SWITCH 0x00004000 /* PB 17 */ -#define CONFIG_SYS_PB_SDRAM_CLKE 0x00008000 /* PB 16 */ -#define CONFIG_SYS_PB_ETH_POWERDOWN 0x00010000 /* PB 15 */ -#define CONFIG_SYS_PB_IDE_MOTOR 0x00020000 /* PB 14 */ - -#define CONFIG_SYS_PC_ETH_RESET ((ushort)0x0010) /* PC 11 */ -#define CONFIG_SYS_PC_IDE_RESET ((ushort)0x0020) /* PC 10 */ - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xFFF00000 /* was: 0xFF000000 */ - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR - -#if defined (CONFIG_IVML24_16M) -# define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#elif defined (CONFIG_IVML24_32M) -# define CONFIG_SYS_INIT_RAM_SIZE 0x3000 /* Size of used area in DPRAM */ -#elif defined (CONFIG_IVML24_64M) -# define CONFIG_SYS_INIT_RAM_SIZE 0x3000 /* Size of used area in DPRAM */ -#endif - -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0xFF000000 -#ifdef DEBUG -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#else -#define CONFIG_SYS_MONITOR_LEN (192 << 10) /* Reserve 192 kB for Monitor */ -#endif -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 256 /* max number of sectors on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ - -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_OFFSET 0x7A000 /* Offset of Environment Sector */ -#define CONFIG_ENV_SIZE 0x2000 /* Total Size of Environment Sector */ -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CACHELINE_SHIFT 4 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 11-9 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Software & Bus Monitor Timer max, Bus Monitor enable, SW Watchdog freeze - */ -#if defined(CONFIG_WATCHDOG) - -# if defined (CONFIG_IVML24_16M) -# define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | \ - SYPCR_SWE | SYPCR_SWRI| SYPCR_SWP) -# elif defined (CONFIG_IVML24_32M) -# define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | \ - SYPCR_SWE | SYPCR_SWP) -# elif defined (CONFIG_IVML24_64M) -# define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | \ - SYPCR_SWE | SYPCR_SWP) -# endif - -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | SYPCR_SWP) -#endif - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 11-6 - *----------------------------------------------------------------------- - * PCMCIA config., multi-function pin tri-state - */ -/* EARB, DBGC and DBPC are initialised by the HCW */ -/* => 0x000000C0 */ -#define CONFIG_SYS_SIUMCR (SIUMCR_BSC | SIUMCR_GB5E) - -/*----------------------------------------------------------------------- - * TBSCR - Time Base Status and Control 11-26 - *----------------------------------------------------------------------- - * Clear Reference Interrupt Status, Timebase freezing enabled - */ -#define CONFIG_SYS_TBSCR (TBSCR_REFA | TBSCR_REFB | TBSCR_TBF) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 11-31 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Interrupt Timer freezing enabled - */ -#define CONFIG_SYS_PISCR (PISCR_PS | PISCR_PITF) - -/*----------------------------------------------------------------------- - * PLPRCR - PLL, Low-Power, and Reset Control Register 15-30 - *----------------------------------------------------------------------- - * Reset PLL lock status sticky bit, timer expired status bit and timer - * interrupt status bit, set PLL multiplication factor ! - */ -/* 0x00B0C0C0 */ -#define CONFIG_SYS_PLPRCR \ - ( (11 << PLPRCR_MF_SHIFT) | \ - PLPRCR_SPLSS | PLPRCR_TEXPS | /*PLPRCR_TMIST|*/ \ - /*PLPRCR_CSRC|*/ PLPRCR_LPM_NORMAL | \ - PLPRCR_CSR | PLPRCR_LOLRE /*|PLPRCR_FIOPD*/ \ - ) - -/*----------------------------------------------------------------------- - * SCCR - System Clock and reset Control Register 15-27 - *----------------------------------------------------------------------- - * Set clock output, timebase and RTC source and divider, - * power management and some other internal clocks - */ -#define SCCR_MASK SCCR_EBDF11 -/* 0x01800014 */ -#define CONFIG_SYS_SCCR (SCCR_COM01 | /*SCCR_TBS|*/ \ - SCCR_RTDIV | SCCR_RTSEL | \ - /*SCCR_CRQEN|*/ /*SCCR_PRQEN|*/ \ - SCCR_EBDF00 | SCCR_DFSYNC00 | \ - SCCR_DFBRG00 | SCCR_DFNL000 | \ - SCCR_DFNH000 | SCCR_DFLCD101 | \ - SCCR_DFALCD00) - -/*----------------------------------------------------------------------- - * RTCSC - Real-Time Clock Status and Control Register 11-27 - *----------------------------------------------------------------------- - */ -/* 0x00C3 */ -#define CONFIG_SYS_RTCSC (RTCSC_SEC | RTCSC_ALR | RTCSC_RTF| RTCSC_RTE) - - -/*----------------------------------------------------------------------- - * RCCR - RISC Controller Configuration Register 19-4 - *----------------------------------------------------------------------- - */ -/* TIMEP=2 */ -#define CONFIG_SYS_RCCR 0x0200 - -/*----------------------------------------------------------------------- - * RMDS - RISC Microcode Development Support Control Register - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RMDS 0 - -/*----------------------------------------------------------------------- - * - * Interrupt Levels - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_CPM_INTERRUPT 13 /* SIU_LEVEL6 */ - -/*----------------------------------------------------------------------- - * PCMCIA stuff - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_PCMCIA_MEM_ADDR (0xE0000000) -#define CONFIG_SYS_PCMCIA_MEM_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_DMA_ADDR (0xE4000000) -#define CONFIG_SYS_PCMCIA_DMA_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_ATTRB_ADDR (0xE8000000) -#define CONFIG_SYS_PCMCIA_ATTRB_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_IO_ADDR (0xEC000000) -#define CONFIG_SYS_PCMCIA_IO_SIZE ( 64 << 20 ) - -/*----------------------------------------------------------------------- - * IDE/ATA stuff - *----------------------------------------------------------------------- - */ -#define CONFIG_IDE_PREINIT 1 /* Use preinit IDE hook */ -#define CONFIG_IDE_INIT_POSTRESET 1 /* Use postreset IDE hook */ -#define CONFIG_IDE_8xx_DIRECT 1 /* PCMCIA interface required */ -#define CONFIG_IDE_RESET 1 /* reset for ide supported */ - -#define CONFIG_SYS_IDE_MAXBUS 1 /* The IVML24 has only 1 IDE bus*/ -#define CONFIG_SYS_IDE_MAXDEVICE 1 /* ... and only 1 IDE device */ - -#define CONFIG_SYS_ATA_BASE_ADDR 0xFE100000 -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 -#undef CONFIG_SYS_ATA_IDE1_OFFSET /* only one IDE bus available */ - -#define CONFIG_SYS_ATA_DATA_OFFSET 0x0000 /* Offset for data I/O */ -#define CONFIG_SYS_ATA_REG_OFFSET 0x0080 /* Offset for normal register accesses */ -#define CONFIG_SYS_ATA_ALT_OFFSET 0x0100 /* Offset for alternate registers */ - -/*----------------------------------------------------------------------- - * - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_DER 0 - -/* - * Init Memory Controller: - * - * BR0 and OR0 (FLASH) - */ - -#define FLASH_BASE0_PRELIM 0xFF000000 /* FLASH bank #0 */ - -/* used to re-map FLASH both when starting from SRAM or FLASH: - * restrict access enough to keep SRAM working (if any) - * but not too much to meddle with FLASH accesses - */ -/* EPROMs are 512kb */ -#define CONFIG_SYS_REMAP_OR_AM 0xFFF80000 /* OR addr mask */ -#define CONFIG_SYS_PRELIM_OR_AM 0xFFF80000 /* OR addr mask */ - -/* FLASH timing: ACS = 11, TRLX = 0, CSNT = 1, SCY = 5, EHTR = 1 */ -#define CONFIG_SYS_OR_TIMING_FLASH (OR_SCY_5_CLK | OR_EHTR) - -#define CONFIG_SYS_OR0_REMAP ( CONFIG_SYS_REMAP_OR_AM | OR_ACS_DIV4 | OR_BI | \ - CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_PRELIM_OR_AM | OR_ACS_DIV4 | OR_BI | \ - CONFIG_SYS_OR_TIMING_FLASH) -/* 16 bit, bank valid */ -#define CONFIG_SYS_BR0_PRELIM ((FLASH_BASE0_PRELIM & BR_BA_MSK) | BR_PS_16 | BR_V ) - -/* - * BR1/OR1 - ELIC SACCO bank @ 0xFE000000 - * - * AM=0xFFFF8 ATM=0 CSNT/SAM=1 ACS/G5LA/G5LS=3 BIH=1 SCY=2 SETA=0 TRLX=1 EHTR=1 - */ -#define ELIC_SACCO_BASE 0xFE000000 -#define ELIC_SACCO_OR_AM 0xFFFF8000 -#define ELIC_SACCO_TIMING (OR_SCY_2_CLK | OR_TRLX | OR_EHTR) - -#define CONFIG_SYS_OR1 (ELIC_SACCO_OR_AM | OR_CSNT_SAM | OR_ACS_DIV2 | OR_BI | \ - ELIC_SACCO_TIMING) -#define CONFIG_SYS_BR1 ((ELIC_SACCO_BASE & BR_BA_MSK) | BR_PS_8 | BR_V ) - -/* - * BR2/OR2 - ELIC EPIC bank @ 0xFE008000 - * - * AM=0xFFFF8 ATM=0 CSNT/SAM=1 ACS/G5LA/G5LS=3 BIH=1 SCY=2 SETA=0 TRLX=1 EHTR=1 - */ -#define ELIC_EPIC_BASE 0xFE008000 -#define ELIC_EPIC_OR_AM 0xFFFF8000 -#define ELIC_EPIC_TIMING (OR_SCY_2_CLK | OR_TRLX | OR_EHTR) - -#define CONFIG_SYS_OR2 (ELIC_EPIC_OR_AM | OR_CSNT_SAM | OR_ACS_DIV2 | OR_BI | \ - ELIC_EPIC_TIMING) -#define CONFIG_SYS_BR2 ((ELIC_EPIC_BASE & BR_BA_MSK) | BR_PS_8 | BR_V ) - -/* - * BR3/OR3: SDRAM - * - * Multiplexed addresses, GPL5 output to GPL5_A (don't care) - */ -#define SDRAM_BASE3_PRELIM 0x00000000 /* SDRAM bank */ -#define SDRAM_PRELIM_OR_AM 0xF8000000 /* map max. 128 MB */ -#define SDRAM_TIMING OR_SCY_0_CLK /* SDRAM-Timing */ - -#define SDRAM_MAX_SIZE 0x04000000 /* max 64 MB SDRAM */ - -#define CONFIG_SYS_OR3_PRELIM (SDRAM_PRELIM_OR_AM | OR_CSNT_SAM | OR_G5LS | SDRAM_TIMING ) -#define CONFIG_SYS_BR3_PRELIM ((SDRAM_BASE3_PRELIM & BR_BA_MSK) | BR_MS_UPMB | BR_V ) - -/* - * BR4/OR4 - HDLC Address - * - * AM=0xFFFF8 ATM=0 CSNT/SAM=0 ACS/G5LA/G5LS=0 BIH=1 SCY=1 SETA=0 TRLX=0 EHTR=0 - */ -#define HDLC_ADDR_BASE 0xFE108000 /* HDLC Address area */ -#define HDLC_ADDR_OR_AM 0xFFFF8000 -#define HDLC_ADDR_TIMING OR_SCY_1_CLK - -#define CONFIG_SYS_OR4 (HDLC_ADDR_OR_AM | OR_BI | HDLC_ADDR_TIMING) -#define CONFIG_SYS_BR4 ((HDLC_ADDR_BASE & BR_BA_MSK) | BR_PS_8 | BR_WP | BR_V ) - -/* - * BR5/OR5: SHARC ADSP-2165L - * - * AM=0xFFC00 ATM=0 CSNT/SAM=0 ACS/G5LA/G5LS=3 BIH=1 SCY=0 SETA=0 TRLX=0 EHTR=0 - */ -#define SHARC_BASE 0xFE400000 -#define SHARC_OR_AM 0xFFC00000 -#define SHARC_TIMING OR_SCY_0_CLK - -#define CONFIG_SYS_OR5 (SHARC_OR_AM | OR_ACS_DIV2 | OR_BI | SHARC_TIMING ) -#define CONFIG_SYS_BR5 ((SHARC_BASE & BR_BA_MSK) | BR_PS_32 | BR_MS_UPMA | BR_V ) - -/* - * Memory Periodic Timer Prescaler - */ - -/* periodic timer for refresh */ -#define CONFIG_SYS_MBMR_PTB 204 - -/* refresh rate 15.6 us (= 64 ms / 4K = 62.4 / quad bursts) for <= 128 MBit */ -#define CONFIG_SYS_MPTPR_2BK_4K MPTPR_PTP_DIV16 /* setting for 2 banks */ -#define CONFIG_SYS_MPTPR_1BK_4K MPTPR_PTP_DIV32 /* setting for 1 bank */ - -/* refresh rate 7.8 us (= 64 ms / 8K = 31.2 / quad bursts) for 256 MBit */ -#define CONFIG_SYS_MPTPR_2BK_8K MPTPR_PTP_DIV8 /* setting for 2 banks */ - -#if defined (CONFIG_IVML24_16M) -# define CONFIG_SYS_MPTPR_1BK_8K MPTPR_PTP_DIV16 /* setting for 1 bank */ -#elif defined (CONFIG_IVML24_32M) -# define CONFIG_SYS_MPTPR_1BK_8K MPTPR_PTP_DIV16 /* setting for 1 bank */ -#elif defined (CONFIG_IVML24_64M) -# define CONFIG_SYS_MPTPR_1BK_8K MPTPR_PTP_DIV8 /* setting for 1 bank */ -#endif - - -/* - * MBMR settings for SDRAM - */ - -#if defined (CONFIG_IVML24_16M) - /* 8 column SDRAM */ -# define CONFIG_SYS_MBMR_8COL ((CONFIG_SYS_MBMR_PTB << MBMR_PTB_SHIFT) | \ - MBMR_AMB_TYPE_0 | MBMR_DSB_1_CYCL | MBMR_G0CLB_A11 | \ - MBMR_RLFB_1X | MBMR_WLFB_1X | MBMR_TLFB_4X) -#elif defined (CONFIG_IVML24_32M) -/* 128 MBit SDRAM */ -# define CONFIG_SYS_MBMR_8COL ((CONFIG_SYS_MBMR_PTB << MBMR_PTB_SHIFT) | \ - MBMR_AMB_TYPE_1 | MBMR_DSB_1_CYCL | MBMR_G0CLB_A10 | \ - MBMR_RLFB_1X | MBMR_WLFB_1X | MBMR_TLFB_4X) -#elif defined (CONFIG_IVML24_64M) -/* 128 MBit SDRAM */ -# define CONFIG_SYS_MBMR_8COL ((CONFIG_SYS_MBMR_PTB << MBMR_PTB_SHIFT) | \ - MBMR_AMB_TYPE_1 | MBMR_DSB_1_CYCL | MBMR_G0CLB_A10 | \ - MBMR_RLFB_1X | MBMR_WLFB_1X | MBMR_TLFB_4X) -#endif -#endif /* __CONFIG_H */ diff --git a/include/configs/IVMS8.h b/include/configs/IVMS8.h deleted file mode 100644 index 0b54af5..0000000 --- a/include/configs/IVMS8.h +++ /dev/null @@ -1,441 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC860 1 /* This is a MPC860 CPU */ -#define CONFIG_IVMS8 1 /* ...on a IVMS8 board */ - -#define CONFIG_SYS_TEXT_BASE 0xFF000000 - -#if defined (CONFIG_IVMS8_16M) -# define CONFIG_IDENT_STRING " IVMS8" -#elif defined (CONFIG_IVMS8_32M) -# define CONFIG_IDENT_STRING " IVMS8_128" -#elif defined (CONFIG_IVMS8_64M) -# define CONFIG_IDENT_STRING " IVMS8_256" -#endif - -#define CONFIG_8xx_CONS_SMC1 1 /* Console is on SMC1 */ -#undef CONFIG_8xx_CONS_SMC2 -#undef CONFIG_8xx_CONS_NONE -#define CONFIG_BAUDRATE 115200 - -#define CONFIG_RESET_PHY_R 1 /* Call reset_phy() */ - -#define CONFIG_CLOCKS_IN_MHZ 1 /* clocks passsed to Linux in MHz */ -#define CONFIG_8xx_GCLK_FREQ 50331648 - -#define CONFIG_SHOW_BOOT_PROGRESS 1 /* Show boot progress on LEDs */ - -#if 0 -#define CONFIG_BOOTDELAY -1 /* autoboot disabled */ -#else -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ -#endif -#define CONFIG_BOOTCOMMAND "bootp" /* autoboot command */ - -#define CONFIG_BOOTARGS "root=/dev/nfs rw " \ - "nfsroot=10.0.0.2:/opt/eldk/ppc_8xx " \ - "nfsaddrs=10.0.0.99:10.0.0.2" - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -#define CONFIG_STATUS_LED 1 /* Status LED enabled */ - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_IDE - - -#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE - - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x00100000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x00F00000 /* 1 ... 15MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x00100000 /* default load address */ - -#define CONFIG_SYS_PIO_MODE 0 /* IDE interface in PIO Mode 0 */ - -#define CONFIG_SYS_PB_SDRAM_CLKE 0x00008000 /* PB 16 */ -#define CONFIG_SYS_PB_ETH_POWERDOWN 0x00010000 /* PB 15 */ -#define CONFIG_SYS_PB_IDE_MOTOR 0x00020000 /* PB 14 */ - -#define CONFIG_SYS_PC_ETH_RESET ((ushort)0x0010) /* PC 11 */ -#define CONFIG_SYS_PC_IDE_RESET ((ushort)0x0020) /* PC 10 */ - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xFFF00000 /* was: 0xFF000000 */ - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#if defined (CONFIG_IVMS8_16M) -# define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#elif defined (CONFIG_IVMS8_32M) -# define CONFIG_SYS_INIT_RAM_SIZE 0x3000 /* Size of used area in DPRAM */ -#elif defined (CONFIG_IVMS8_64M) -# define CONFIG_SYS_INIT_RAM_SIZE 0x3000 /* Size of used area in DPRAM */ -#endif - -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0xFF000000 -#ifdef DEBUG -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#else -#define CONFIG_SYS_MONITOR_LEN (192 << 10) /* Reserve 192 kB for Monitor */ -#endif -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 256 /* max number of sectors on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ - -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_OFFSET 0x7A000 /* Offset of Environment Sector */ -#define CONFIG_ENV_SIZE 0x2000 /* Total Size of Environment Sector */ -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CACHELINE_SHIFT 4 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 11-9 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Software & Bus Monitor Timer max, Bus Monitor enable, SW Watchdog freeze - */ -#if defined(CONFIG_WATCHDOG) -# if defined (CONFIG_IVMS8_16M) -# define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | \ - SYPCR_SWE | SYPCR_SWRI| SYPCR_SWP) -# elif defined (CONFIG_IVMS8_32M) -# define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | \ - SYPCR_SWE | SYPCR_SWP) -# elif defined (CONFIG_IVMS8_64M) -# define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | \ - SYPCR_SWE | SYPCR_SWP) -# endif -#else -# define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | SYPCR_SWP) -#endif - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 11-6 - *----------------------------------------------------------------------- - * PCMCIA config., multi-function pin tri-state - */ -/* EARB, DBGC and DBPC are initialised by the HCW */ -/* => 0x000000C0 */ -#define CONFIG_SYS_SIUMCR (SIUMCR_BSC | SIUMCR_GB5E) - -/*----------------------------------------------------------------------- - * TBSCR - Time Base Status and Control 11-26 - *----------------------------------------------------------------------- - * Clear Reference Interrupt Status, Timebase freezing enabled - */ -#define CONFIG_SYS_TBSCR (TBSCR_REFA | TBSCR_REFB | TBSCR_TBF) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 11-31 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Interrupt Timer freezing enabled - */ -#define CONFIG_SYS_PISCR (PISCR_PS | PISCR_PITF) - -/*----------------------------------------------------------------------- - * PLPRCR - PLL, Low-Power, and Reset Control Register 15-30 - *----------------------------------------------------------------------- - * Reset PLL lock status sticky bit, timer expired status bit and timer - * interrupt status bit, set PLL multiplication factor ! - */ -/* 0x00B0C0C0 */ -#define CONFIG_SYS_PLPRCR \ - ( (11 << PLPRCR_MF_SHIFT) | \ - PLPRCR_SPLSS | PLPRCR_TEXPS | /*PLPRCR_TMIST|*/ \ - /*PLPRCR_CSRC|*/ PLPRCR_LPM_NORMAL | \ - PLPRCR_CSR | PLPRCR_LOLRE /*|PLPRCR_FIOPD*/ \ - ) - -/*----------------------------------------------------------------------- - * SCCR - System Clock and reset Control Register 15-27 - *----------------------------------------------------------------------- - * Set clock output, timebase and RTC source and divider, - * power management and some other internal clocks - */ -#define SCCR_MASK SCCR_EBDF11 -/* 0x01800014 */ -#define CONFIG_SYS_SCCR (SCCR_COM01 | /*SCCR_TBS|*/ \ - SCCR_RTDIV | SCCR_RTSEL | \ - /*SCCR_CRQEN|*/ /*SCCR_PRQEN|*/ \ - SCCR_EBDF00 | SCCR_DFSYNC00 | \ - SCCR_DFBRG00 | SCCR_DFNL000 | \ - SCCR_DFNH000 | SCCR_DFLCD101 | \ - SCCR_DFALCD00) - -/*----------------------------------------------------------------------- - * RTCSC - Real-Time Clock Status and Control Register 11-27 - *----------------------------------------------------------------------- - */ -/* 0x00C3 */ -#define CONFIG_SYS_RTCSC (RTCSC_SEC | RTCSC_ALR | RTCSC_RTF| RTCSC_RTE) - - -/*----------------------------------------------------------------------- - * RCCR - RISC Controller Configuration Register 19-4 - *----------------------------------------------------------------------- - */ -/* TIMEP=2 */ -#define CONFIG_SYS_RCCR 0x0200 - -/*----------------------------------------------------------------------- - * RMDS - RISC Microcode Development Support Control Register - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RMDS 0 - -/*----------------------------------------------------------------------- - * - * Interrupt Levels - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_CPM_INTERRUPT 13 /* SIU_LEVEL6 */ - -/*----------------------------------------------------------------------- - * PCMCIA stuff - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_PCMCIA_MEM_ADDR (0xE0000000) -#define CONFIG_SYS_PCMCIA_MEM_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_DMA_ADDR (0xE4000000) -#define CONFIG_SYS_PCMCIA_DMA_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_ATTRB_ADDR (0xE8000000) -#define CONFIG_SYS_PCMCIA_ATTRB_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_IO_ADDR (0xEC000000) -#define CONFIG_SYS_PCMCIA_IO_SIZE ( 64 << 20 ) - -/*----------------------------------------------------------------------- - * IDE/ATA stuff - *----------------------------------------------------------------------- - */ -#define CONFIG_IDE_PREINIT 1 /* Use preinit IDE hook */ -#define CONFIG_IDE_INIT_POSTRESET 1 /* Use postreset IDE hook */ -#define CONFIG_IDE_8xx_DIRECT 1 /* PCMCIA interface required */ -#define CONFIG_IDE_RESET 1 /* reset for ide supported */ - -#define CONFIG_SYS_IDE_MAXBUS 1 /* The IVMS8 has only 1 IDE bus */ -#define CONFIG_SYS_IDE_MAXDEVICE 1 /* ... and only 1 IDE device */ - -#define CONFIG_SYS_ATA_BASE_ADDR 0xFE100000 -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 -#undef CONFIG_SYS_ATA_IDE1_OFFSET /* only one IDE bus available */ - -#define CONFIG_SYS_ATA_DATA_OFFSET 0x0000 /* Offset for data I/O */ -#define CONFIG_SYS_ATA_REG_OFFSET 0x0080 /* Offset for normal register accesses */ -#define CONFIG_SYS_ATA_ALT_OFFSET 0x0100 /* Offset for alternate registers */ - -/*----------------------------------------------------------------------- - * - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_DER 0 - -/* - * Init Memory Controller: - * - * BR0 and OR0 (FLASH) - */ - -#define FLASH_BASE0_PRELIM 0xFF000000 /* FLASH bank #0 */ - -/* used to re-map FLASH both when starting from SRAM or FLASH: - * restrict access enough to keep SRAM working (if any) - * but not too much to meddle with FLASH accesses - */ -/* EPROMs are 512kb */ -#define CONFIG_SYS_REMAP_OR_AM 0xFFF80000 /* OR addr mask */ -#define CONFIG_SYS_PRELIM_OR_AM 0xFFF80000 /* OR addr mask */ - -/* FLASH timing: ACS = 11, TRLX = 0, CSNT = 1, SCY = 5, EHTR = 1 */ -#define CONFIG_SYS_OR_TIMING_FLASH (/* OR_CSNT_SAM | */ OR_ACS_DIV4 | OR_BI | \ - OR_SCY_5_CLK | OR_EHTR) - -#define CONFIG_SYS_OR0_REMAP (CONFIG_SYS_REMAP_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -/* 16 bit, bank valid */ -#define CONFIG_SYS_BR0_PRELIM ((FLASH_BASE0_PRELIM & BR_BA_MSK) | BR_PS_16 | BR_V ) - -/* - * BR1/OR1 - ELIC SACCO bank @ 0xFE000000 - * - * AM=0xFFFF8 ATM=0 CSNT/SAM=1 ACS/G5LA/G5LS=3 BIH=1 SCY=2 SETA=0 TRLX=1 EHTR=1 - */ -#define ELIC_SACCO_BASE 0xFE000000 -#define ELIC_SACCO_OR_AM 0xFFFF8000 -#define ELIC_SACCO_TIMING 0x00000F26 - -#define CONFIG_SYS_OR1 (ELIC_SACCO_OR_AM | ELIC_SACCO_TIMING) -#define CONFIG_SYS_BR1 ((ELIC_SACCO_BASE & BR_BA_MSK) | BR_PS_8 | BR_V ) - -/* - * BR2/OR2 - ELIC EPIC bank @ 0xFE008000 - * - * AM=0xFFFF8 ATM=0 CSNT/SAM=1 ACS/G5LA/G5LS=3 BIH=1 SCY=2 SETA=0 TRLX=1 EHTR=1 - */ -#define ELIC_EPIC_BASE 0xFE008000 -#define ELIC_EPIC_OR_AM 0xFFFF8000 -#define ELIC_EPIC_TIMING 0x00000F26 - -#define CONFIG_SYS_OR2 (ELIC_EPIC_OR_AM | ELIC_EPIC_TIMING) -#define CONFIG_SYS_BR2 ((ELIC_EPIC_BASE & BR_BA_MSK) | BR_PS_8 | BR_V ) - -/* - * BR3/OR3: SDRAM - * - * Multiplexed addresses, GPL5 output to GPL5_A (don't care) - */ -#define SDRAM_BASE3_PRELIM 0x00000000 /* SDRAM bank */ -#define SDRAM_PRELIM_OR_AM 0xF8000000 /* map max. 128 MB */ -#define SDRAM_TIMING 0x00000A00 /* SDRAM-Timing */ - -#define SDRAM_MAX_SIZE 0x04000000 /* max 64 MB SDRAM */ - -#define CONFIG_SYS_OR3_PRELIM (SDRAM_PRELIM_OR_AM | SDRAM_TIMING ) -#define CONFIG_SYS_BR3_PRELIM ((SDRAM_BASE3_PRELIM & BR_BA_MSK) | BR_MS_UPMB | BR_V ) - -/* - * BR4/OR4: not used - */ - -/* - * BR5/OR5: SHARC ADSP-2165L - * - * AM=0xFFC00 ATM=0 CSNT/SAM=0 ACS/G5LA/G5LS=3 BIH=1 SCY=0 SETA=0 TRLX=0 EHTR=0 - */ -#define SHARC_BASE 0xFE400000 -#define SHARC_OR_AM 0xFFC00000 -#define SHARC_TIMING 0x00000700 - -#define CONFIG_SYS_OR5 (SHARC_OR_AM | SHARC_TIMING ) -#define CONFIG_SYS_BR5 ((SHARC_BASE & BR_BA_MSK) | BR_PS_32 | BR_MS_UPMA | BR_V ) - -/* - * Memory Periodic Timer Prescaler - */ - -/* periodic timer for refresh */ -#define CONFIG_SYS_MBMR_PTB 204 - -/* refresh rate 15.6 us (= 64 ms / 4K = 62.4 / quad bursts) for <= 128 MBit */ -#define CONFIG_SYS_MPTPR_2BK_4K MPTPR_PTP_DIV16 /* setting for 2 banks */ -#define CONFIG_SYS_MPTPR_1BK_4K MPTPR_PTP_DIV32 /* setting for 1 bank */ - -/* refresh rate 7.8 us (= 64 ms / 8K = 31.2 / quad bursts) for 256 MBit */ -#define CONFIG_SYS_MPTPR_2BK_8K MPTPR_PTP_DIV8 /* setting for 2 banks */ -#if defined (CONFIG_IVMS8_16M) - #define CONFIG_SYS_MPTPR_1BK_8K MPTPR_PTP_DIV16 /* setting for 1 bank */ -#elif defined (CONFIG_IVMS8_32M) -#define CONFIG_SYS_MPTPR_1BK_8K MPTPR_PTP_DIV16 /* setting for 1 bank */ -#elif defined (CONFIG_IVMS8_64M) -#define CONFIG_SYS_MPTPR_1BK_8K MPTPR_PTP_DIV8 /* setting for 1 bank */ -#endif - - -/* - * MBMR settings for SDRAM - */ - -#if defined (CONFIG_IVMS8_16M) - /* 8 column SDRAM */ -# define CONFIG_SYS_MBMR_8COL ((CONFIG_SYS_MBMR_PTB << MBMR_PTB_SHIFT) | \ - MBMR_AMB_TYPE_0 | MBMR_DSB_1_CYCL | MBMR_G0CLB_A11 | \ - MBMR_RLFB_1X | MBMR_WLFB_1X | MBMR_TLFB_4X) -#elif defined (CONFIG_IVMS8_32M) -/* 128 MBit SDRAM */ -#define CONFIG_SYS_MBMR_8COL ((CONFIG_SYS_MBMR_PTB << MBMR_PTB_SHIFT) | \ - MBMR_AMB_TYPE_1 | MBMR_DSB_1_CYCL | MBMR_G0CLB_A10 | \ - MBMR_RLFB_1X | MBMR_WLFB_1X | MBMR_TLFB_4X) -#elif defined (CONFIG_IVMS8_64M) -/* 128 MBit SDRAM */ -#define CONFIG_SYS_MBMR_8COL ((CONFIG_SYS_MBMR_PTB << MBMR_PTB_SHIFT) | \ - MBMR_AMB_TYPE_1 | MBMR_DSB_1_CYCL | MBMR_G0CLB_A10 | \ - MBMR_RLFB_1X | MBMR_WLFB_1X | MBMR_TLFB_4X) - -#endif -#endif /* __CONFIG_H */ diff --git a/include/pcmcia.h b/include/pcmcia.h index 54ab2ac..8e8831f 100644 --- a/include/pcmcia.h +++ b/include/pcmcia.h @@ -23,8 +23,6 @@
#if defined(CONFIG_TQM8xxL) # define CONFIG_PCMCIA_SLOT_B /* The TQM8xxL use SLOT_B */ -#elif defined(CONFIG_IVMS8) || defined(CONFIG_IVML24) /* The IVM* use SLOT_A */ -# define CONFIG_PCMCIA_SLOT_A #elif defined(CONFIG_ATC) /* The ATC use SLOT_A */ # define CONFIG_PCMCIA_SLOT_A #else diff --git a/include/status_led.h b/include/status_led.h index 919e3ae..27f4bdf 100644 --- a/include/status_led.h +++ b/include/status_led.h @@ -56,64 +56,6 @@ void status_led_set (int led, int state);
# define STATUS_LED_BOOT 0 /* LED 0 used for boot status */
-/***** IVMS8 **********************************************************/ -#elif defined(CONFIG_IVMS8) - -# define STATUS_LED_PAR im_cpm.cp_pbpar -# define STATUS_LED_DIR im_cpm.cp_pbdir -# define STATUS_LED_ODR im_cpm.cp_pbodr -# define STATUS_LED_DAT im_cpm.cp_pbdat - -# define STATUS_LED_BIT 0x00000010 /* LED 0 is on PB.27 */ -# define STATUS_LED_PERIOD (1 * CONFIG_SYS_HZ) -# define STATUS_LED_STATE STATUS_LED_OFF -# define STATUS_LED_BIT1 0x00000020 /* LED 1 is on PB.26 */ -# define STATUS_LED_PERIOD1 (1 * CONFIG_SYS_HZ) -# define STATUS_LED_STATE1 STATUS_LED_OFF -/* IDE LED usable for other purposes, too */ -# define STATUS_LED_BIT2 0x00000008 /* LED 2 is on PB.28 */ -# define STATUS_LED_PERIOD2 (1 * CONFIG_SYS_HZ) -# define STATUS_LED_STATE2 STATUS_LED_OFF - -# define STATUS_LED_ACTIVE 1 /* LED on for bit == 1 */ - -# define STATUS_ILOCK_SWITCH 0x00800000 /* ILOCK switch in IRQ4 */ - -# define STATUS_ILOCK_PERIOD (CONFIG_SYS_HZ / 10) /* about every 100 ms */ - -# define STATUS_LED_YELLOW 0 -# define STATUS_LED_GREEN 1 -# define STATUS_LED_BOOT 2 /* IDE LED used for boot status */ - -/***** IVML24 *********************************************************/ -#elif defined(CONFIG_IVML24) - -# define STATUS_LED_PAR im_cpm.cp_pbpar -# define STATUS_LED_DIR im_cpm.cp_pbdir -# define STATUS_LED_ODR im_cpm.cp_pbodr -# define STATUS_LED_DAT im_cpm.cp_pbdat - -# define STATUS_LED_BIT 0x00000010 /* LED 0 is on PB.27 */ -# define STATUS_LED_PERIOD (1 * CONFIG_SYS_HZ) -# define STATUS_LED_STATE STATUS_LED_OFF -# define STATUS_LED_BIT1 0x00000020 /* LED 1 is on PB.26 */ -# define STATUS_LED_PERIOD1 (1 * CONFIG_SYS_HZ) -# define STATUS_LED_STATE1 STATUS_LED_OFF -/* IDE LED usable for other purposes, too */ -# define STATUS_LED_BIT2 0x00000008 /* LED 2 is on PB.28 */ -# define STATUS_LED_PERIOD2 (1 * CONFIG_SYS_HZ) -# define STATUS_LED_STATE2 STATUS_LED_OFF - -# define STATUS_LED_ACTIVE 1 /* LED on for bit == 1 */ - -# define STATUS_ILOCK_SWITCH 0x00004000 /* ILOCK is on PB.17 */ - -# define STATUS_ILOCK_PERIOD (CONFIG_SYS_HZ / 10) /* about every 100 ms */ - -# define STATUS_LED_YELLOW 0 -# define STATUS_LED_GREEN 1 -# define STATUS_LED_BOOT 2 /* IDE LED used for boot status */ - /***** Someone else defines these *************************************/ #elif defined(STATUS_LED_PAR)
On Mon, Dec 15, 2014 at 11:26:15PM +0900, Masahiro Yamada wrote:
This board is still a non-generic board.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Wolfgang Denk wd@denx.de
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Wolfgang Denk wd@denx.de ---
arch/powerpc/cpu/mpc8xx/Kconfig | 4 - arch/powerpc/cpu/mpc8xx/cpu_init.c | 10 - arch/powerpc/cpu/mpc8xx/serial.c | 7 +- board/ip860/Kconfig | 9 - board/ip860/MAINTAINERS | 6 - board/ip860/Makefile | 8 - board/ip860/flash.c | 440 ------------------------------------- board/ip860/ip860.c | 340 ---------------------------- board/ip860/u-boot.lds.debug | 122 ---------- configs/IP860_defconfig | 3 - doc/README.scrapyard | 1 + include/commproc.h | 28 --- include/configs/IP860.h | 438 ------------------------------------ 13 files changed, 2 insertions(+), 1414 deletions(-) delete mode 100644 board/ip860/Kconfig delete mode 100644 board/ip860/MAINTAINERS delete mode 100644 board/ip860/Makefile delete mode 100644 board/ip860/flash.c delete mode 100644 board/ip860/ip860.c delete mode 100644 board/ip860/u-boot.lds.debug delete mode 100644 configs/IP860_defconfig delete mode 100644 include/configs/IP860.h
diff --git a/arch/powerpc/cpu/mpc8xx/Kconfig b/arch/powerpc/cpu/mpc8xx/Kconfig index ef5c511..45e7d7e 100644 --- a/arch/powerpc/cpu/mpc8xx/Kconfig +++ b/arch/powerpc/cpu/mpc8xx/Kconfig @@ -13,9 +13,6 @@ config TARGET_COGENT_MPC8XX config TARGET_ESTEEM192E bool "Support ESTEEM192E"
-config TARGET_IP860 - bool "Support IP860" - config TARGET_TQM823L bool "Support TQM823L"
@@ -56,7 +53,6 @@ endchoice
source "board/cogent/Kconfig" source "board/esteem192e/Kconfig" -source "board/ip860/Kconfig" source "board/tqc/tqm8xx/Kconfig"
endmenu diff --git a/arch/powerpc/cpu/mpc8xx/cpu_init.c b/arch/powerpc/cpu/mpc8xx/cpu_init.c index 753d25d..f621d62 100644 --- a/arch/powerpc/cpu/mpc8xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc8xx/cpu_init.c @@ -125,12 +125,6 @@ void cpu_init_f (volatile immap_t * immr) * I owe him a free beer. - wd] */
-#if defined(CONFIG_IP860) || \ - defined(CONFIG_RMU) - - memctl->memc_br0 = CONFIG_SYS_BR0_PRELIM; -#endif - #if defined(CONFIG_SYS_OR0_REMAP) memctl->memc_or0 = CONFIG_SYS_OR0_REMAP; #endif @@ -150,10 +144,6 @@ void cpu_init_f (volatile immap_t * immr) memctl->memc_br1 = CONFIG_SYS_BR1_PRELIM; #endif
-#if defined(CONFIG_IP860) /* disable CS0 now that Flash is mapped on CS1 */ - memctl->memc_br0 = 0; -#endif - #if defined(CONFIG_SYS_OR2_PRELIM) && defined(CONFIG_SYS_BR2_PRELIM) memctl->memc_or2 = CONFIG_SYS_OR2_PRELIM; memctl->memc_br2 = CONFIG_SYS_BR2_PRELIM; diff --git a/arch/powerpc/cpu/mpc8xx/serial.c b/arch/powerpc/cpu/mpc8xx/serial.c index bb16b17..af65c96 100644 --- a/arch/powerpc/cpu/mpc8xx/serial.c +++ b/arch/powerpc/cpu/mpc8xx/serial.c @@ -416,18 +416,13 @@ static int scc_init (void) cp->cp_pbdir &= ~0x06; cp->cp_pbodr &= ~0x06;
-#elif (SCC_INDEX < 2) || !defined(CONFIG_IP860) +#elif (SCC_INDEX < 2) /* * Standard configuration for SCC's is on Part A */ ip->iop_papar |= ((3 << (2 * SCC_INDEX))); ip->iop_padir &= ~((3 << (2 * SCC_INDEX))); ip->iop_paodr &= ~((3 << (2 * SCC_INDEX))); -#else - /* - * The IP860 has SCC3 and SCC4 on Port D - */ - ip->iop_pdpar |= ((3 << (2 * SCC_INDEX))); #endif
/* Allocate space for two buffer descriptors in the DP ram. */ diff --git a/board/ip860/Kconfig b/board/ip860/Kconfig deleted file mode 100644 index 955c9db..0000000 --- a/board/ip860/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_IP860 - -config SYS_BOARD - default "ip860" - -config SYS_CONFIG_NAME - default "IP860" - -endif diff --git a/board/ip860/MAINTAINERS b/board/ip860/MAINTAINERS deleted file mode 100644 index 36d5690..0000000 --- a/board/ip860/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -IP860 BOARD -M: Wolfgang Denk wd@denx.de -S: Maintained -F: board/ip860/ -F: include/configs/IP860.h -F: configs/IP860_defconfig diff --git a/board/ip860/Makefile b/board/ip860/Makefile deleted file mode 100644 index 3c60006..0000000 --- a/board/ip860/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = ip860.o flash.o diff --git a/board/ip860/flash.c b/board/ip860/flash.c deleted file mode 100644 index 542b0c8..0000000 --- a/board/ip860/flash.c +++ /dev/null @@ -1,440 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc8xx.h> - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH chips */ - -#if defined(CONFIG_ENV_IS_IN_FLASH) -# ifndef CONFIG_ENV_ADDR -# define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET) -# endif -# ifndef CONFIG_ENV_SIZE -# define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -# endif -# ifndef CONFIG_ENV_SECT_SIZE -# define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE -# endif -#endif - -/*----------------------------------------------------------------------- - * Functions - */ -static ulong flash_get_size (vu_long *addr, flash_info_t *info); -static int write_word (flash_info_t *info, ulong dest, ulong data); -static void flash_get_offsets (ulong base, flash_info_t *info); - -/*----------------------------------------------------------------------- - */ - -unsigned long flash_init (void) -{ - volatile immap_t *immap = (immap_t *)CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - volatile ip860_bcsr_t *bcsr = (ip860_bcsr_t *)BCSR_BASE; - unsigned long size; - int i; - - /* Init: enable write, - * or we cannot even write flash commands - */ - bcsr->bd_ctrl |= BD_CTRL_FLWE; - - for (i=0; i<CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - } - - /* Static FLASH Bank configuration here - FIXME XXX */ - - size = flash_get_size((vu_long *)FLASH_BASE, &flash_info[0]); - - if (flash_info[0].flash_id == FLASH_UNKNOWN) { - printf ("## Unknown FLASH on Bank 0 - Size = 0x%08lx = %ld MB\n", - size, size<<20); - } - - /* Remap FLASH according to real size */ - memctl->memc_or1 = CONFIG_SYS_OR_TIMING_FLASH | (-size & 0xFFFF8000); - memctl->memc_br1 = (CONFIG_SYS_FLASH_BASE & BR_BA_MSK) | - (memctl->memc_br1 & ~(BR_BA_MSK)); - - /* Re-do sizing to get full correct info */ - size = flash_get_size((vu_long *)CONFIG_SYS_FLASH_BASE, &flash_info[0]); - - flash_get_offsets (CONFIG_SYS_FLASH_BASE, &flash_info[0]); - - flash_info[0].size = size; - -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE - /* monitor protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE+monitor_flash_len-1, - &flash_info[0]); -#endif - -#ifdef CONFIG_ENV_IS_IN_FLASH - /* ENV protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR+CONFIG_ENV_SECT_SIZE-1, - &flash_info[0]); -#endif - return (size); -} - -/*----------------------------------------------------------------------- - */ -static void flash_get_offsets (ulong base, flash_info_t *info) -{ - int i; - - /* all possible flash types - * (28F016SV, 28F160S3, 28F320S3) - * have the same erase block size: 64 kB per chip, - * of 128 kB per bank - */ - - /* set up sector start address table */ - for (i = 0; i < info->sector_count; i++) { - info->start[i] = base; - base += 0x00020000; - } -} - -/*----------------------------------------------------------------------- - */ -void flash_print_info (flash_info_t *info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_INTEL: printf ("Intel "); break; - default: printf ("Unknown Vendor "); break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_28F016SV: printf ("28F016SV (16 Mbit, 32 x 64k)\n"); - break; - case FLASH_28F160S3: printf ("28F160S3 (16 Mbit, 32 x 512K)\n"); - break; - case FLASH_28F320S3: printf ("28F320S3 (32 Mbit, 64 x 512K)\n"); - break; - default: printf ("Unknown Chip Type\n"); - break; - } - - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); - - printf (" Sector Start Addresses:"); - for (i=0; i<info->sector_count; ++i) { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", - info->start[i], - info->protect[i] ? " (RO)" : " " - ); - } - printf ("\n"); - return; -} - -/*----------------------------------------------------------------------- - */ - - -/*----------------------------------------------------------------------- - */ - -/* - * The following code cannot be run from FLASH! - */ - -static ulong flash_get_size (vu_long *addr, flash_info_t *info) -{ - short i; - ulong value; - ulong base = (ulong)addr; - - /* Write "Intelligent Identifier" command: read Manufacturer ID */ - *addr = 0x90909090; - - value = addr[0]; - switch (value) { - case (MT_MANUFACT & 0x00FF00FF): /* MT or => Intel */ - case (INTEL_ALT_MANU & 0x00FF00FF): - info->flash_id = FLASH_MAN_INTEL; - break; - default: - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - return (0); /* no or unknown flash */ - } - - value = addr[1]; /* device ID */ - - switch (value) { - case (INTEL_ID_28F016S): - info->flash_id += FLASH_28F016SV; - info->sector_count = 32; - info->size = 0x00400000; - break; /* => 2x2 MB */ - - case (INTEL_ID_28F160S3): - info->flash_id += FLASH_28F160S3; - info->sector_count = 32; - info->size = 0x00400000; - break; /* => 2x2 MB */ - - case (INTEL_ID_28F320S3): - info->flash_id += FLASH_28F320S3; - info->sector_count = 64; - info->size = 0x00800000; - break; /* => 2x4 MB */ - - default: - info->flash_id = FLASH_UNKNOWN; - return (0); /* => no or unknown flash */ - - } - - /* set up sector start address table */ - for (i = 0; i < info->sector_count; i++) { - info->start[i] = base + (i * 0x00020000); - /* don't know how to check sector protection */ - info->protect[i] = 0; - } - - /* - * Prevent writes to uninitialized FLASH. - */ - if (info->flash_id != FLASH_UNKNOWN) { - addr = (vu_long *)info->start[0]; - - *addr = 0xFFFFFF; /* reset bank to read array mode */ - } - - return (info->size); -} - - -/*----------------------------------------------------------------------- - */ - -int flash_erase (flash_info_t *info, int s_first, int s_last) -{ - int flag, prot, sect; - ulong start, now, last; - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - if ((info->flash_id & FLASH_VENDMASK) != FLASH_MAN_INTEL) { - printf ("Can't erase unknown flash type %08lx - aborted\n", - info->flash_id); - return 1; - } - - prot = 0; - for (sect=s_first; sect<=s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - printf ("\n"); - } - - start = get_timer (0); - last = start; - - /* Start erase on unprotected sectors */ - for (sect = s_first; sect<=s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - vu_long *addr = (vu_long *)(info->start[sect]); - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - /* Single Block Erase Command */ - *addr = 0x20202020; - /* Confirm */ - *addr = 0xD0D0D0D0; - /* Resume Command, as per errata update */ - *addr = 0xD0D0D0D0; - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - - while ((*addr & 0x00800080) != 0x00800080) { - if ((now=get_timer(start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - *addr = 0xFFFFFFFF; /* reset bank */ - return 1; - } - /* show that we're waiting */ - if ((now - last) > 1000) { /* every second */ - putc ('.'); - last = now; - } - } - - /* reset to read mode */ - *addr = 0xFFFFFFFF; - } - } - - printf (" done\n"); - return 0; -} - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ - -int write_buff (flash_info_t *info, uchar *src, ulong addr, ulong cnt) -{ - ulong cp, wp, data; - int i, l, rc; - - wp = (addr & ~3); /* get lower word aligned address */ - - /* - * handle unaligned start bytes - */ - if ((l = addr - wp) != 0) { - data = 0; - for (i=0, cp=wp; i<l; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - for (; i<4 && cnt>0; ++i) { - data = (data << 8) | *src++; - --cnt; - ++cp; - } - for (; cnt==0 && i<4; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - - if ((rc = write_word(info, wp, data)) != 0) { - return (rc); - } - wp += 4; - } - - /* - * handle word aligned part - */ - while (cnt >= 4) { - data = 0; - for (i=0; i<4; ++i) { - data = (data << 8) | *src++; - } - if ((rc = write_word(info, wp, data)) != 0) { - return (rc); - } - wp += 4; - cnt -= 4; - } - - if (cnt == 0) { - return (0); - } - - /* - * handle unaligned tail bytes - */ - data = 0; - for (i=0, cp=wp; i<4 && cnt>0; ++i, ++cp) { - data = (data << 8) | *src++; - --cnt; - } - for (; i<4; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - - return (write_word(info, wp, data)); -} - -/*----------------------------------------------------------------------- - * Write a word to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_word (flash_info_t *info, ulong dest, ulong data) -{ - vu_long *addr = (vu_long *)dest; - ulong start, csr; - int flag; - - /* Check if Flash is (sufficiently) erased */ - if ((*addr & data) != data) { - return (2); - } - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - /* Write Command */ - *addr = 0x10101010; - - /* Write Data */ - *addr = data; - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* data polling for D7 */ - start = get_timer (0); - flag = 0; - while (((csr = *addr) & 0x00800080) != 0x00800080) { - if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - flag = 1; - break; - } - } - if (csr & 0x00400040) { -printf ("CSR indicates write error (%08lx) at %08lx\n", csr, (ulong)addr); - flag = 1; - } - - /* Clear Status Registers Command */ - *addr = 0x50505050; - /* Reset to read array mode */ - *addr = 0xFFFFFFFF; - - return (flag); -} - -/*----------------------------------------------------------------------- - */ diff --git a/board/ip860/ip860.c b/board/ip860/ip860.c deleted file mode 100644 index 4e3b1b5..0000000 --- a/board/ip860/ip860.c +++ /dev/null @@ -1,340 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <commproc.h> -#include <mpc8xx.h> - -/* ------------------------------------------------------------------------- */ - -static long int dram_size (long int, long int *, long int); -unsigned long ip860_get_dram_size(void); -unsigned long ip860_get_clk_freq (void); -/* ------------------------------------------------------------------------- */ - -#define _NOT_USED_ 0xFFFFFFFF - -const uint sdram_table[] = { - /* - * Single Read. (Offset 0 in UPMA RAM) - */ - 0x1f07fc04, 0xeeaefc04, 0x11adfc04, 0xefbbbc00, - 0x1ff77c47, /* last */ - /* - * SDRAM Initialization (offset 5 in UPMA RAM) - * - * This is no UPM entry point. The following definition uses - * the remaining space to establish an initialization - * sequence, which is executed by a RUN command. - * - */ - 0x1ff77c34, 0xefeabc34, 0x1fb57c35, /* last */ - /* - * Burst Read. (Offset 8 in UPMA RAM) - */ - 0x1f07fc04, 0xeeaefc04, 0x10adfc04, 0xf0affc00, - 0xf0affc00, 0xf1affc00, 0xefbbbc00, 0x1ff77c47, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Single Write. (Offset 18 in UPMA RAM) - */ - 0x1f27fc04, 0xeeaebc00, 0x01b93c04, 0x1ff77c47, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Burst Write. (Offset 20 in UPMA RAM) - */ - 0x1f07fc04, 0xeeaebc00, 0x10ad7c00, 0xf0affc00, - 0xf0affc00, 0xe1bbbc04, 0x1ff77c47, /* last */ - _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Refresh (Offset 30 in UPMA RAM) - */ - 0x1ff5fc84, 0xfffffc04, 0xfffffc04, 0xfffffc04, - 0xfffffc84, 0xfffffc07, /* last */ - _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Exception. (Offset 3c in UPMA RAM) - */ - 0x7ffffc07, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, -}; - - -/* ------------------------------------------------------------------------- */ -int board_early_init_f(void) -{ - volatile immap_t *immap = (immap_t *)CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - -/* init BCSR chipselect line for ip860_get_clk_freq() and ip860_get_dram_size() */ - memctl->memc_or4 = CONFIG_SYS_OR4; - memctl->memc_br4 = CONFIG_SYS_BR4; - - return 0; -} - - -/* ------------------------------------------------------------------------- */ - -/* - * Check Board Identity: - * - * Test ID string (IP860...) - */ - -int checkboard (void) -{ - unsigned char *s, *e; - unsigned char buf[64]; - int i; - - puts ("Board: "); - - i = getenv_f("serial#", (char *)buf, sizeof (buf)); - s = (i > 0) ? buf : NULL; - - if (!s || strncmp ((char *)s, "IP860", 5)) { - puts ("### No HW ID - assuming IP860"); - } else { - for (e = s; *e; ++e) { - if (*e == ' ') - break; - } - - for (; s < e; ++s) { - putc (*s); - } - } - - putc ('\n'); - - return (0); -} - -/* ------------------------------------------------------------------------- */ - -phys_size_t initdram (int board_type) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - long int size; - ulong refresh_val; - - upmconfig (UPMA, (uint *) sdram_table, - sizeof (sdram_table) / sizeof (uint)); - - /* - * Preliminary prescaler for refresh - */ - if (ip860_get_clk_freq() == 50000000) - { - memctl->memc_mptpr = 0x0400; - refresh_val = 0xC3000000; - } - else - { - memctl->memc_mptpr = 0x0200; - refresh_val = 0x9C000000; - } - - - memctl->memc_mar = 0x00000088; - - /* - * Map controller banks 2 to the SDRAM address - */ - memctl->memc_or2 = CONFIG_SYS_OR2; - memctl->memc_br2 = CONFIG_SYS_BR2; - - /* IP860 boards have only one bank SDRAM */ - - - udelay (200); - - /* perform SDRAM initializsation sequence */ - - memctl->memc_mamr = 0x00804114 | refresh_val; - memctl->memc_mcr = 0x80004105; /* run precharge pattern from loc 5 */ - udelay(1); - memctl->memc_mamr = 0x00804118 | refresh_val; - memctl->memc_mcr = 0x80004130; /* run refresh pattern 8 times */ - - - udelay (1000); - - /* - * Check SDRAM Memory Size - */ - if (ip860_get_dram_size() == 16) - size = dram_size (refresh_val | 0x00804114, SDRAM_BASE, SDRAM_MAX_SIZE); - else - size = dram_size (refresh_val | 0x00906114, SDRAM_BASE, SDRAM_MAX_SIZE); - - udelay (1000); - - memctl->memc_or2 = ((-size) & 0xFFFF0000) | SDRAM_TIMING; - memctl->memc_br2 = (CONFIG_SYS_SDRAM_BASE & BR_BA_MSK) | BR_MS_UPMA | BR_V; - - udelay (10000); - - /* - * Also, map other memory to correct position - */ - -#if (defined(CONFIG_SYS_OR1) && defined(CONFIG_SYS_BR1_PRELIM)) - memctl->memc_or1 = CONFIG_SYS_OR1; - memctl->memc_br1 = CONFIG_SYS_BR1; -#endif - -#if defined(CONFIG_SYS_OR3) && defined(CONFIG_SYS_BR3) - memctl->memc_or3 = CONFIG_SYS_OR3; - memctl->memc_br3 = CONFIG_SYS_BR3; -#endif - -#if defined(CONFIG_SYS_OR4) && defined(CONFIG_SYS_BR4) - memctl->memc_or4 = CONFIG_SYS_OR4; - memctl->memc_br4 = CONFIG_SYS_BR4; -#endif - -#if defined(CONFIG_SYS_OR5) && defined(CONFIG_SYS_BR5) - memctl->memc_or5 = CONFIG_SYS_OR5; - memctl->memc_br5 = CONFIG_SYS_BR5; -#endif - -#if defined(CONFIG_SYS_OR6) && defined(CONFIG_SYS_BR6) - memctl->memc_or6 = CONFIG_SYS_OR6; - memctl->memc_br6 = CONFIG_SYS_BR6; -#endif - -#if defined(CONFIG_SYS_OR7) && defined(CONFIG_SYS_BR7) - memctl->memc_or7 = CONFIG_SYS_OR7; - memctl->memc_br7 = CONFIG_SYS_BR7; -#endif - - return (size); -} - -/* ------------------------------------------------------------------------- */ - -/* - * Check memory range for valid RAM. A simple memory test determines - * the actually available RAM size between addresses `base' and - * `base + maxsize'. Some (not all) hardware errors are detected: - * - short between address lines - * - short between data lines - */ - -static long int dram_size (long int mamr_value, long int *base, - long int maxsize) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - - memctl->memc_mamr = mamr_value; - - return (get_ram_size(base, maxsize)); -} - -/* ------------------------------------------------------------------------- */ - -void reset_phy (void) -{ - volatile immap_t *immr = (immap_t *) CONFIG_SYS_IMMR; - ulong mask = PB_ENET_RESET | PB_ENET_JABD; - ulong reg; - - /* Make sure PHY is not in low-power mode */ - immr->im_cpm.cp_pbpar &= ~(mask); /* GPIO */ - immr->im_cpm.cp_pbodr &= ~(mask); /* active output */ - - /* Set JABD low (no JABber Disable), - * and RESET high (Reset PHY) - */ - reg = immr->im_cpm.cp_pbdat; - reg = (reg & ~PB_ENET_JABD) | PB_ENET_RESET; - immr->im_cpm.cp_pbdat = reg; - - /* now drive outputs */ - immr->im_cpm.cp_pbdir |= mask; /* output */ - udelay (1000); - /* - * Release RESET signal - */ - immr->im_cpm.cp_pbdat &= ~(PB_ENET_RESET); - udelay (1000); -} - -/* ------------------------------------------------------------------------- */ - -unsigned long ip860_get_clk_freq(void) -{ - volatile ip860_bcsr_t *bcsr = (ip860_bcsr_t *)BCSR_BASE; - ulong temp; - uchar sysclk; - - if ((bcsr->bd_status & 0x80) == 0x80) /* bd_rev valid ? */ - sysclk = (bcsr->bd_rev & 0x18) >> 3; - else - sysclk = 0x00; - - switch (sysclk) - { - case 0x00: - temp = 50000000; - break; - - case 0x01: - temp = 80000000; - break; - - default: - temp = 50000000; - break; - } - - return (temp); - -} - - -/* ------------------------------------------------------------------------- */ - -unsigned long ip860_get_dram_size(void) -{ - volatile ip860_bcsr_t *bcsr = (ip860_bcsr_t *)BCSR_BASE; - ulong temp; - uchar dram_size; - - if ((bcsr->bd_status & 0x80) == 0x80) /* bd_rev valid ? */ - dram_size = (bcsr->bd_rev & 0xE0) >> 5; - else - dram_size = 0x00; /* default is 16 MB */ - - switch (dram_size) - { - case 0x00: - temp = 16; - break; - - case 0x01: - temp = 32; - break; - - default: - temp = 16; - break; - } - - return (temp); - -} - -/* ------------------------------------------------------------------------- */ diff --git a/board/ip860/u-boot.lds.debug b/board/ip860/u-boot.lds.debug deleted file mode 100644 index e561bb4..0000000 --- a/board/ip860/u-boot.lds.debug +++ /dev/null @@ -1,122 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -OUTPUT_ARCH(powerpc) -/* Do we need any of these for elf? - __DYNAMIC = 0; */ -SECTIONS -{ - /* Read-only sections, merged into text segment: */ - . = + SIZEOF_HEADERS; - .interp : { *(.interp) } - .hash : { *(.hash) } - .dynsym : { *(.dynsym) } - .dynstr : { *(.dynstr) } - .rel.text : { *(.rel.text) } - .rela.text : { *(.rela.text) } - .rel.data : { *(.rel.data) } - .rela.data : { *(.rela.data) } - .rel.rodata : { *(.rel.rodata) } - .rela.rodata : { *(.rela.rodata) } - .rel.got : { *(.rel.got) } - .rela.got : { *(.rela.got) } - .rel.ctors : { *(.rel.ctors) } - .rela.ctors : { *(.rela.ctors) } - .rel.dtors : { *(.rel.dtors) } - .rela.dtors : { *(.rela.dtors) } - .rel.bss : { *(.rel.bss) } - .rela.bss : { *(.rela.bss) } - .rel.plt : { *(.rel.plt) } - .rela.plt : { *(.rela.plt) } - .init : { *(.init) } - .plt : { *(.plt) } - .text : - { - /* WARNING - the following is hand-optimized to fit within */ - /* the sector layout of our flash chips! XXX FIXME XXX */ - - arch/powerpc/cpu/mpc8xx/start.o (.text) - arch/powerpc/lib/ppcstring.o (.text) - arch/powerpc/cpu/mpc8xx/interrupts.o (.text) - arch/powerpc/lib/time.o (.text) - arch/powerpc/lib/ticks.o (.text) -/** - . = env_offset; - common/env_embedded.o(.text) -**/ - *(.text) - *(.got1) - } - _etext = .; - PROVIDE (etext = .); - .rodata : - { - *(.rodata) - *(.rodata1) - *(.rodata.str1.4) - *(.eh_frame) - } - .fini : { *(.fini) } =0 - .ctors : { *(.ctors) } - .dtors : { *(.dtors) } - - /* Read-write section, merged into data segment: */ - . = (. + 0x0FFF) & 0xFFFFF000; - _erotext = .; - PROVIDE (erotext = .); - .reloc : - { - *(.got) - _GOT2_TABLE_ = .; - *(.got2) - _FIXUP_TABLE_ = .; - *(.fixup) - } - __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; - __fixup_entries = (. - _FIXUP_TABLE_)>>2; - - .data : - { - *(.data) - *(.data1) - *(.sdata) - *(.sdata2) - *(.dynamic) - CONSTRUCTORS - } - _edata = .; - PROVIDE (edata = .); - - - . = ALIGN(4); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); - } - - - __start___ex_table = .; - __ex_table : { *(__ex_table) } - __stop___ex_table = .; - - . = ALIGN(4096); - __init_begin = .; - .text.init : { *(.text.init) } - .data.init : { *(.data.init) } - . = ALIGN(4096); - __init_end = .; - - __bss_start = .; - .bss : - { - *(.sbss) *(.scommon) - *(.dynbss) - *(.bss) - *(COMMON) - } - __bss_end = . ; - PROVIDE (end = .); -} diff --git a/configs/IP860_defconfig b/configs/IP860_defconfig deleted file mode 100644 index feb243d..0000000 --- a/configs/IP860_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_IP860=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 252b607..0e39857 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,7 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +IP860 powerpc mpc8xx - - Wolfgang Denk wd@denx.de IVML24 powerpc mpc8xx - - Wolfgang Denk wd@denx.de IVMS8 powerpc mpc8xx - - Wolfgang Denk wd@denx.de lwmon powerpc mpc8xx - - Wolfgang Denk wd@denx.de diff --git a/include/commproc.h b/include/commproc.h index 6e0a233..c53482c 100644 --- a/include/commproc.h +++ b/include/commproc.h @@ -484,34 +484,6 @@ typedef struct scc_enet {
#endif
-/*** IP860 **********************************************************/ - -#if defined(CONFIG_IP860) -/* Bits in parallel I/O port registers that have to be set/cleared - * to configure the pins for SCC1 use. - */ -#define PROFF_ENET PROFF_SCC1 -#define CPM_CR_ENET CPM_CR_CH_SCC1 -#define SCC_ENET 0 -#define PA_ENET_RXD ((ushort)0x0001) /* PA 15 */ -#define PA_ENET_TXD ((ushort)0x0002) /* PA 14 */ -#define PA_ENET_RCLK ((ushort)0x0200) /* PA 6 */ -#define PA_ENET_TCLK ((ushort)0x0100) /* PA 7 */ - -#define PC_ENET_TENA ((ushort)0x0001) /* PC 15 */ -#define PC_ENET_CLSN ((ushort)0x0010) /* PC 11 */ -#define PC_ENET_RENA ((ushort)0x0020) /* PC 10 */ - -#define PB_ENET_RESET (uint)0x00000008 /* PB 28 */ -#define PB_ENET_JABD (uint)0x00000004 /* PB 29 */ - -/* Control bits in the SICR to route TCLK (CLK1) and RCLK (CLK2) to - * SCC1. Also, make sure GR1 (bit 24) and SC1 (bit 25) are zero. - */ -#define SICR_ENET_MASK ((uint)0x000000ff) -#define SICR_ENET_CLKRT ((uint)0x0000002C) -#endif /* CONFIG_IP860 */ - /*** KM8XX *********************************************************/
/* The KM8XX Service Module uses SCC3 for Ethernet */ diff --git a/include/configs/IP860.h b/include/configs/IP860.h deleted file mode 100644 index 97eda58..0000000 --- a/include/configs/IP860.h +++ /dev/null @@ -1,438 +0,0 @@ -/* - * (C) Copyright 2000-2005 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC860 1 /* This is a MPC860 CPU */ -#define CONFIG_IP860 1 /* ...on a IP860 board */ - -#define CONFIG_SYS_TEXT_BASE 0x10000000 - -#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ -#define CONFIG_RESET_PHY_R 1 /* Call reset_phy() */ - -#define CONFIG_8xx_CONS_SMC1 1 /* Console is on SMC1 */ -#define CONFIG_BAUDRATE 9600 -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ - -#define CONFIG_PREBOOT "echo;echo Type \"run flash_nfs\" to mount root filesystem over NFS;echo" \ -"\0load=tftp "/tftpboot/u-boot.bin"\0update=protect off 1:0;era 1:0;cp.b 100000 10000000 ${filesize}\0" - -#undef CONFIG_BOOTARGS -#define CONFIG_BOOTCOMMAND \ - "bootp; " \ - "setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off; " \ - "bootm" - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - - -/* enable I2C and select the hardware/software driver */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_SOFT /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SOFT_SPEED 50000 -#define CONFIG_SYS_I2C_SOFT_SLAVE 0xFE -/* - * Software (bit-bang) I2C driver configuration - */ -#define PB_SCL 0x00000020 /* PB 26 */ -#define PB_SDA 0x00000010 /* PB 27 */ - -#define I2C_INIT (immr->im_cpm.cp_pbdir |= PB_SCL) -#define I2C_ACTIVE (immr->im_cpm.cp_pbdir |= PB_SDA) -#define I2C_TRISTATE (immr->im_cpm.cp_pbdir &= ~PB_SDA) -#define I2C_READ ((immr->im_cpm.cp_pbdat & PB_SDA) != 0) -#define I2C_SDA(bit) if(bit) immr->im_cpm.cp_pbdat |= PB_SDA; \ - else immr->im_cpm.cp_pbdat &= ~PB_SDA -#define I2C_SCL(bit) if(bit) immr->im_cpm.cp_pbdat |= PB_SCL; \ - else immr->im_cpm.cp_pbdat &= ~PB_SCL -#define I2C_DELAY udelay(5) /* 1/4 I2C clock duration */ - -# define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* EEPROM X24C16 */ -# define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 /* bytes of address */ -/* mask of address bits that overflow into the "EEPROM chip address" */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW 0x07 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* takes up to 10 msec */ - -#define CONFIG_TIMESTAMP /* Print image info with timestamp */ - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_BEDBUG -#define CONFIG_CMD_I2C -#define CONFIG_CMD_EEPROM -#define CONFIG_CMD_NFS -#define CONFIG_CMD_SNTP - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x00100000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x00F00000 /* 1 ... 15MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x00100000 /* default load address */ - -#define CONFIG_SYS_PIO_MODE 0 /* IDE interface in PIO Mode 0 */ - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xF1000000 /* Non-standard value!! */ - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0x10000000 -#ifdef DEBUG -#define CONFIG_SYS_MONITOR_LEN (512 << 10) /* Reserve 512 kB for Monitor */ -#else -#if 0 /* need more space for I2C tests */ -#define CONFIG_SYS_MONITOR_LEN (128 << 10) /* Reserve 128 kB for Monitor */ -#else -#define CONFIG_SYS_MONITOR_LEN (256 << 10) -#endif -#endif -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 124 /* max number of sectors on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ - -#undef CONFIG_ENV_IS_IN_FLASH -#undef CONFIG_ENV_IS_IN_NVRAM -#undef CONFIG_ENV_IS_IN_NVRAM -#undef DEBUG_I2C -#define CONFIG_ENV_IS_IN_EEPROM - -#ifdef CONFIG_ENV_IS_IN_NVRAM -#define CONFIG_ENV_ADDR 0x20000000 /* use SRAM */ -#define CONFIG_ENV_SIZE (16<<10) /* use 16 kB */ -#endif /* CONFIG_ENV_IS_IN_NVRAM */ - -#ifdef CONFIG_ENV_IS_IN_EEPROM -#define CONFIG_ENV_OFFSET 512 /* Leave 512 bytes free for other data */ -#define CONFIG_ENV_SIZE 1536 /* Use remaining space */ -#endif /* CONFIG_ENV_IS_IN_EEPROM */ - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CACHELINE_SHIFT 4 /* log base 2 of the above value */ -#endif -#define CONFIG_SYS_DELAYED_ICACHE 1 /* enable ICache not before - * running in RAM. - */ - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 11-9 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Software & Bus Monitor Timer max, Bus Monitor enable, SW Watchdog freeze - * +0x0004 - */ -#if defined(CONFIG_WATCHDOG) -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | \ - SYPCR_SWE | SYPCR_SWRI| SYPCR_SWP) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | SYPCR_SWP) -#endif - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 11-6 - *----------------------------------------------------------------------- - * +0x0000 => 0x80600800 - */ -#define CONFIG_SYS_SIUMCR (SIUMCR_EARB | SIUMCR_EARP0 | \ - SIUMCR_DBGC11 | SIUMCR_MLRC10) - -/*----------------------------------------------------------------------- - * Clock Setting - get clock frequency from Board Revision Register - *----------------------------------------------------------------------- - */ -#ifndef __ASSEMBLY__ -extern unsigned long ip860_get_clk_freq (void); -#endif -#define CONFIG_8xx_GCLK_FREQ ip860_get_clk_freq() - -/*----------------------------------------------------------------------- - * TBSCR - Time Base Status and Control 11-26 - *----------------------------------------------------------------------- - * Clear Reference Interrupt Status, Timebase freezing enabled - * +0x0200 => 0x00C2 - */ -#define CONFIG_SYS_TBSCR (TBSCR_REFA | TBSCR_REFB | TBSCR_TBF) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 11-31 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Interrupt Timer freezing enabled - * +0x0240 => 0x0082 - */ -#define CONFIG_SYS_PISCR (PISCR_PS | PISCR_PITF) - -/*----------------------------------------------------------------------- - * PLPRCR - PLL, Low-Power, and Reset Control Register 15-30 - *----------------------------------------------------------------------- - * Reset PLL lock status sticky bit, timer expired status bit and timer - * interrupt status bit, set PLL multiplication factor ! - */ -/* +0x0286 => was: 0x0000D000 */ -#define CONFIG_SYS_PLPRCR \ - ( PLPRCR_SPLSS | PLPRCR_TEXPS | PLPRCR_TMIST | \ - /*PLPRCR_CSRC|*/ PLPRCR_LPM_NORMAL | \ - PLPRCR_CSR | PLPRCR_LOLRE /*|PLPRCR_FIOPD*/ \ - ) - -/*----------------------------------------------------------------------- - * SCCR - System Clock and reset Control Register 15-27 - *----------------------------------------------------------------------- - * Set clock output, timebase and RTC source and divider, - * power management and some other internal clocks - */ -#define SCCR_MASK SCCR_EBDF11 -#define CONFIG_SYS_SCCR (SCCR_COM00 | SCCR_TBS | \ - SCCR_RTDIV | SCCR_RTSEL | \ - /*SCCR_CRQEN|*/ /*SCCR_PRQEN|*/ \ - SCCR_EBDF00 | SCCR_DFSYNC00 | \ - SCCR_DFBRG00 | SCCR_DFNL000 | \ - SCCR_DFNH000) - -/*----------------------------------------------------------------------- - * RTCSC - Real-Time Clock Status and Control Register 11-27 - *----------------------------------------------------------------------- - */ -/* +0x0220 => 0x00C3 */ -#define CONFIG_SYS_RTCSC (RTCSC_SEC | RTCSC_ALR | RTCSC_RTF| RTCSC_RTE) - - -/*----------------------------------------------------------------------- - * RCCR - RISC Controller Configuration Register 19-4 - *----------------------------------------------------------------------- - */ -/* +0x09C4 => TIMEP=1 */ -#define CONFIG_SYS_RCCR 0x0100 - -/*----------------------------------------------------------------------- - * RMDS - RISC Microcode Development Support Control Register - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RMDS 0 - -/*----------------------------------------------------------------------- - * DER - Debug Event Register - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_DER 0 - -/* - * Init Memory Controller: - */ - -/* - * MAMR settings for SDRAM - 16-14 - * => 0xC3804114 - */ - -/* periodic timer for refresh */ -#define CONFIG_SYS_MAMR_PTA 0xC3 - -#define CONFIG_SYS_MAMR ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_0 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A10 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) -/* - * BR1 and OR1 (FLASH) - */ -#define FLASH_BASE 0x10000000 /* FLASH bank #0 */ - -/* used to re-map FLASH - * restrict access enough to keep SRAM working (if any) - * but not too much to meddle with FLASH accesses - */ -/* allow for max 8 MB of Flash */ -#define CONFIG_SYS_REMAP_OR_AM 0xFF800000 /* OR addr mask */ -#define CONFIG_SYS_PRELIM_OR_AM 0xFF800000 /* OR addr mask */ - -#define CONFIG_SYS_OR_TIMING_FLASH (OR_CSNT_SAM | OR_ACS_DIV2 | OR_BI | OR_SCY_6_CLK) - -#define CONFIG_SYS_OR0_REMAP (CONFIG_SYS_REMAP_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -/* 16 bit, bank valid */ -#define CONFIG_SYS_BR0_PRELIM ((FLASH_BASE & BR_BA_MSK) | BR_PS_32 | BR_V ) - -#define CONFIG_SYS_OR1_PRELIM CONFIG_SYS_OR0_PRELIM -#define CONFIG_SYS_BR1_PRELIM CONFIG_SYS_BR0_PRELIM - -/* - * BR2/OR2 - SDRAM - */ -#define SDRAM_BASE 0x00000000 /* SDRAM bank */ -#define SDRAM_PRELIM_OR_AM 0xF8000000 /* map max. 128 MB */ -#define SDRAM_TIMING 0x00000A00 /* SDRAM-Timing */ - -#define SDRAM_MAX_SIZE 0x04000000 /* max 64 MB SDRAM */ - -#define CONFIG_SYS_OR2 (SDRAM_PRELIM_OR_AM | SDRAM_TIMING ) -#define CONFIG_SYS_BR2 ((SDRAM_BASE & BR_BA_MSK) | BR_MS_UPMA | BR_V ) - -/* - * BR3/OR3 - SRAM (16 bit) - */ -#define SRAM_BASE 0x20000000 -#define CONFIG_SYS_OR3 0xFFF00130 /* BI/SCY = 5/TRLX (internal) */ -#define CONFIG_SYS_BR3 ((SRAM_BASE & BR_BA_MSK) | BR_PS_16 | BR_V) -#define SRAM_SIZE (1 + (~(CONFIG_SYS_OR3 & BR_BA_MSK))) -#define CONFIG_SYS_OR3_PRELIM CONFIG_SYS_OR3 /* Make sure to map early */ -#define CONFIG_SYS_BR3_PRELIM CONFIG_SYS_BR3 /* in case it's used for ENV */ -#define CONFIG_SYS_SRAM_BASE SRAM_BASE -#define CONFIG_SYS_SRAM_SIZE SRAM_SIZE - -/* - * BR4/OR4 - Board Control & Status (8 bit) - */ -#define BCSR_BASE 0xFC000000 -#define CONFIG_SYS_OR4 0xFFFF0120 /* BI (internal) */ -#define CONFIG_SYS_BR4 ((BCSR_BASE & BR_BA_MSK) | BR_PS_8 | BR_V) - -/* - * BR5/OR5 - IP Slot A/B (16 bit) - */ -#define IP_SLOT_BASE 0x40000000 -#define CONFIG_SYS_OR5 0xFE00010C /* SETA/TRLX/BI/ SCY=0 (external) */ -#define CONFIG_SYS_BR5 ((IP_SLOT_BASE & BR_BA_MSK) | BR_PS_16 | BR_V) - -/* - * BR6/OR6 - VME STD (16 bit) - */ -#define VME_STD_BASE 0xFE000000 -#define CONFIG_SYS_OR6 0xFF00010C /* SETA/TRLX/BI/SCY=0 (external) */ -#define CONFIG_SYS_BR6 ((VME_STD_BASE & BR_BA_MSK) | BR_PS_16 | BR_V) - -/* - * BR7/OR7 - SHORT I/O + RTC + IACK (16 bit) - */ -#define VME_SHORT_BASE 0xFF000000 -#define CONFIG_SYS_OR7 0xFF00010C /* SETA/TRLX/BI/ SCY=0 (external) */ -#define CONFIG_SYS_BR7 ((VME_SHORT_BASE & BR_BA_MSK) | BR_PS_16 | BR_V) - -/*----------------------------------------------------------------------- - * Board Control and Status Region: - *----------------------------------------------------------------------- - */ -#ifndef __ASSEMBLY__ -typedef struct ip860_bcsr_s { - unsigned char shmem_addr; /* +00 shared memory address register */ - unsigned char reserved0; - unsigned char mbox_addr; /* +02 mailbox address register */ - unsigned char reserved1; - unsigned char vme_int_mask; /* +04 VME Bus interrupt mask register */ - unsigned char reserved2; - unsigned char vme_int_pend; /* +06 VME interrupt pending register */ - unsigned char reserved3; - unsigned char bd_int_mask; /* +08 board interrupt mask register */ - unsigned char reserved4; - unsigned char bd_int_pend; /* +0A board interrupt pending register */ - unsigned char reserved5; - unsigned char bd_ctrl; /* +0C board control register */ - unsigned char reserved6; - unsigned char bd_status; /* +0E board status register */ - unsigned char reserved7; - unsigned char vme_irq; /* +10 VME interrupt request register */ - unsigned char reserved8; - unsigned char vme_ivec; /* +12 VME interrupt vector register */ - unsigned char reserved9; - unsigned char cli_mbox; /* +14 clear mailbox irq */ - unsigned char reservedA; - unsigned char rtc; /* +16 RTC control register */ - unsigned char reservedB; - unsigned char mbox_data; /* +18 mailbox read/write register */ - unsigned char reservedC; - unsigned char wd_trigger; /* +1A Watchdog trigger register */ - unsigned char reservedD; - unsigned char rmw_req; /* +1C RMW request register */ - unsigned char reservedE; - unsigned char bd_rev; /* +1E Board Revision register */ -} ip860_bcsr_t; -#endif /* __ASSEMBLY__ */ - -/*----------------------------------------------------------------------- - * Board Control Register: bd_ctrl (Offset 0x0C) - *----------------------------------------------------------------------- - */ -#define BD_CTRL_IPLSE 0x80 /* IP Slot Long Select Enable */ -#define BD_CTRL_WDOGE 0x40 /* Watchdog Enable */ -#define BD_CTRL_FLWE 0x20 /* Flash Write Enable */ -#define BD_CTRL_RWDN 0x10 /* VMEBus Requester Release When Done Enable */ - -#endif /* __CONFIG_H */
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Conn Clark clark@esteem.com ---
arch/powerpc/cpu/mpc8xx/Kconfig | 4 - board/esteem192e/Kconfig | 9 - board/esteem192e/MAINTAINERS | 6 - board/esteem192e/Makefile | 8 - board/esteem192e/esteem192e.c | 225 -------- board/esteem192e/flash.c | 1119 --------------------------------------- board/esteem192e/u-boot.lds | 90 ---- configs/ESTEEM192E_defconfig | 3 - doc/README.scrapyard | 1 + include/commproc.h | 28 - include/configs/ESTEEM192E.h | 292 ---------- 11 files changed, 1 insertion(+), 1784 deletions(-) delete mode 100644 board/esteem192e/Kconfig delete mode 100644 board/esteem192e/MAINTAINERS delete mode 100644 board/esteem192e/Makefile delete mode 100644 board/esteem192e/esteem192e.c delete mode 100644 board/esteem192e/flash.c delete mode 100644 board/esteem192e/u-boot.lds delete mode 100644 configs/ESTEEM192E_defconfig delete mode 100644 include/configs/ESTEEM192E.h
diff --git a/arch/powerpc/cpu/mpc8xx/Kconfig b/arch/powerpc/cpu/mpc8xx/Kconfig index 45e7d7e..428a129 100644 --- a/arch/powerpc/cpu/mpc8xx/Kconfig +++ b/arch/powerpc/cpu/mpc8xx/Kconfig @@ -10,9 +10,6 @@ choice config TARGET_COGENT_MPC8XX bool "Support cogent_mpc8xx"
-config TARGET_ESTEEM192E - bool "Support ESTEEM192E" - config TARGET_TQM823L bool "Support TQM823L"
@@ -52,7 +49,6 @@ config TARGET_TQM885D endchoice
source "board/cogent/Kconfig" -source "board/esteem192e/Kconfig" source "board/tqc/tqm8xx/Kconfig"
endmenu diff --git a/board/esteem192e/Kconfig b/board/esteem192e/Kconfig deleted file mode 100644 index f895bc4..0000000 --- a/board/esteem192e/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_ESTEEM192E - -config SYS_BOARD - default "esteem192e" - -config SYS_CONFIG_NAME - default "ESTEEM192E" - -endif diff --git a/board/esteem192e/MAINTAINERS b/board/esteem192e/MAINTAINERS deleted file mode 100644 index 8d6634c..0000000 --- a/board/esteem192e/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -ESTEEM192E BOARD -M: Conn Clark clark@esteem.com -S: Maintained -F: board/esteem192e/ -F: include/configs/ESTEEM192E.h -F: configs/ESTEEM192E_defconfig diff --git a/board/esteem192e/Makefile b/board/esteem192e/Makefile deleted file mode 100644 index 55d80b6..0000000 --- a/board/esteem192e/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = esteem192e.o flash.o diff --git a/board/esteem192e/esteem192e.c b/board/esteem192e/esteem192e.c deleted file mode 100644 index b54c614..0000000 --- a/board/esteem192e/esteem192e.c +++ /dev/null @@ -1,225 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - * - * Modified By Conn Clark to work with Esteem 192E 7/31/00 - */ - -#include <common.h> -#include <mpc8xx.h> - -/* ------------------------------------------------------------------------- */ - -#define _NOT_USED_ 0xFFFFFFFF - -const uint sdram_table[] = { - /* - * Single Read. (Offset 0 in UPMA RAM) - * - * active, NOP, read, precharge, NOP */ - 0x0F27CC04, 0x0EAECC04, 0x00B98C04, 0x00F74C00, - 0x11FFCC05, /* last */ - /* - * SDRAM Initialization (offset 5 in UPMA RAM) - * - * This is no UPM entry point. The following definition uses - * the remaining space to establish an initialization - * sequence, which is executed by a RUN command. - * NOP, Program - */ - 0x0F0A8C34, 0x1F354C37, /* last */ - - _NOT_USED_, /* Not used */ - - /* - * Burst Read. (Offset 8 in UPMA RAM) - * active, NOP, read, NOP, NOP, NOP, NOP, NOP */ - 0x0F37CC04, 0x0EFECC04, 0x00FDCC04, 0x00FFCC00, - 0x00FFCC00, 0x01FFCC00, 0x0FFFCC00, 0x1FFFCC05, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Single Write. (Offset 18 in UPMA RAM) - * active, NOP, write, NOP, precharge, NOP */ - 0x0F27CC04, 0x0EAE8C00, 0x01BD4C04, 0x0FFB8C04, - 0x0FF74C04, 0x1FFFCC05, /* last */ - _NOT_USED_, _NOT_USED_, - /* - * Burst Write. (Offset 20 in UPMA RAM) - * active, NOP, write, NOP, NOP, NOP, NOP, NOP */ - 0x0F37CC04, 0x0EFE8C00, 0x00FD4C00, 0x00FFCC00, - 0x00FFCC00, 0x01FFCC04, 0x0FFFCC04, 0x1FFFCC05, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Refresh (Offset 30 in UPMA RAM) - * precharge, NOP, auto_ref, NOP, NOP, NOP */ - 0x0FF74C34, 0x0FFACCB4, 0x0FF5CC34, 0x0FFFCC34, - 0x0FFFCCB4, 0x1FFFCC35, /* last */ - _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Exception. (Offset 3c in UPMA RAM) - */ - 0x0FFB8C00, 0x1FF74C03, /* last */ - _NOT_USED_, _NOT_USED_ -}; - -/* ------------------------------------------------------------------------- */ - - -/* - * Check Board Identity: - */ - -int checkboard (void) -{ - puts ("Board: Esteem 192E\n"); - return (0); -} - -/* ------------------------------------------------------------------------- */ - - -phys_size_t initdram (int board_type) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - long int size_b0, size_b1; - - /* - * Explain frequency of refresh here - */ - - memctl->memc_mptpr = 0x0200; /* divide by 32 */ - - memctl->memc_mamr = 0x18003112; /*CONFIG_SYS_MAMR_8COL; */ /* 0x18005112 TODO: explain here */ - - upmconfig (UPMA, (uint *) sdram_table, - sizeof (sdram_table) / sizeof (uint)); - - /* - * Map cs 2 and 3 to the SDRAM banks 0 and 1 at - * preliminary addresses - these have to be modified after the - * SDRAM size has been determined. - */ - - memctl->memc_or2 = CONFIG_SYS_OR2_PRELIM; /* not defined yet */ - memctl->memc_br2 = CONFIG_SYS_BR2_PRELIM; - - memctl->memc_or3 = CONFIG_SYS_OR3_PRELIM; - memctl->memc_br3 = CONFIG_SYS_BR3_PRELIM; - - - /* perform SDRAM initializsation sequence */ - memctl->memc_mar = 0x00000088; - memctl->memc_mcr = 0x80004830; /* SDRAM bank 0 execute 8 refresh */ - memctl->memc_mcr = 0x80004105; /* SDRAM bank 0 */ - - memctl->memc_mcr = 0x80006830; /* SDRAM bank 1 execute 8 refresh */ - memctl->memc_mcr = 0x80006105; /* SDRAM bank 1 */ - - memctl->memc_mamr = CONFIG_SYS_MAMR_8COL; /* 0x18803112 start refresh timer TODO: explain here */ - -/* printf ("banks 0 and 1 are programed\n"); */ - - /* - * Check Bank 0 Memory Size for re-configuration - * - */ - size_b0 = get_ram_size ( (long *)SDRAM_BASE2_PRELIM, SDRAM_MAX_SIZE); - size_b1 = get_ram_size ( (long *)SDRAM_BASE3_PRELIM, SDRAM_MAX_SIZE); - - printf ("\nbank 0 size %lu\nbank 1 size %lu\n", size_b0, size_b1); - -/* printf ("bank 1 size %u\n",size_b1); */ - - if (size_b1 == 0) { - /* - * Adjust refresh rate if bank 0 isn't stuffed - */ - memctl->memc_mptpr = 0x0400; /* divide by 64 */ - memctl->memc_br3 &= 0x0FFFFFFFE; - - /* - * Adjust OR2 for size of bank 0 - */ - memctl->memc_or2 |= 7 * size_b0; - } else { - if (size_b0 < size_b1) { - memctl->memc_br2 &= 0x00007FFE; - memctl->memc_br3 &= 0x00007FFF; - - /* - * Adjust OR3 for size of bank 1 - */ - memctl->memc_or3 |= 15 * size_b1; - - /* - * Adjust OR2 for size of bank 0 - */ - memctl->memc_or2 |= 15 * size_b0; - memctl->memc_br2 += (size_b1 + 1); - } else { - memctl->memc_br3 &= 0x00007FFE; - - /* - * Adjust OR2 for size of bank 0 - */ - memctl->memc_or2 |= 15 * size_b0; - - /* - * Adjust OR3 for size of bank 1 - */ - memctl->memc_or3 |= 15 * size_b1; - memctl->memc_br3 += (size_b0 + 1); - } - } - - /* before leaving set all unused i/o pins to outputs */ - - /* - * --*Unused Pin List*-- - * - * group/port bit number - * IP_B 0,1,3,4,5 Taken care of in pcmcia-cs-x.x.xx - * PA 5,7,8,9,14,15 - * PB 22,23,31 - * PC 4,5,6,7,10,11,12,13,14,15 - * PD 5,6,7 - * - */ - - /* - * --*Pin Used for I/O List*-- - * - * port input bit number output bit number either - * PB 18,26,27 - * PD 3,4 8,9,10,11,12,13,14,15 - * - */ - - immap->im_ioport.iop_papar &= ~0x05C3; /* set pins as io */ - immap->im_ioport.iop_padir |= 0x05C3; /* set pins as output */ - immap->im_ioport.iop_paodr &= 0x0008; /* config pins 9 & 14 as normal outputs */ - immap->im_ioport.iop_padat |= 0x05C3; /* set unused pins as high */ - - immap->im_cpm.cp_pbpar &= ~0x00001331; /* set unused port b pins as io */ - immap->im_cpm.cp_pbdir |= 0x00001331; /* set unused port b pins as output */ - immap->im_cpm.cp_pbodr &= ~0x00001331; /* config bits 18,22,23,26,27 & 31 as normal outputs */ - immap->im_cpm.cp_pbdat |= 0x00001331; /* set T/E LED, /NV_CS, & /POWER_ADJ_CS and the rest to a high */ - - immap->im_ioport.iop_pcpar &= ~0x0F3F; /* set unused port c pins as io */ - immap->im_ioport.iop_pcdir |= 0x0F3F; /* set unused port c pins as output */ - immap->im_ioport.iop_pcso &= ~0x0F3F; /* clear special purpose bit for unused port c pins for clarity */ - immap->im_ioport.iop_pcdat |= 0x0F3F; /* set unused port c pins high */ - - immap->im_ioport.iop_pdpar &= 0xE000; /* set pins as io */ - immap->im_ioport.iop_pddir &= 0xE000; /* set bit 3 & 4 as inputs */ - immap->im_ioport.iop_pddir |= 0x07FF; /* set bits 5 - 15 as outputs */ - immap->im_ioport.iop_pddat = 0x0055; /* set alternating pattern on test port */ - - return (size_b0 + size_b1); -} diff --git a/board/esteem192e/flash.c b/board/esteem192e/flash.c deleted file mode 100644 index a121104..0000000 --- a/board/esteem192e/flash.c +++ /dev/null @@ -1,1119 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc8xx.h> - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH chips */ - -#ifdef CONFIG_FLASH_16BIT -#define FLASH_WORD_SIZE unsigned short -#define FLASH_ID_MASK 0xFFFF -#else -#define FLASH_WORD_SIZE unsigned long -#define FLASH_ID_MASK 0xFFFFFFFF -#endif - -/*----------------------------------------------------------------------- - * Functions - */ - -ulong flash_get_size (volatile FLASH_WORD_SIZE * addr, flash_info_t * info); - -#ifndef CONFIG_FLASH_16BIT -static int write_word (flash_info_t * info, ulong dest, ulong data); -#else -static int write_short (flash_info_t * info, ulong dest, ushort data); -#endif -/*int flash_write (uchar *, ulong, ulong); */ -/*flash_info_t *addr2info (ulong); */ - -static void flash_get_offsets (ulong base, flash_info_t * info); - -/*----------------------------------------------------------------------- - */ -unsigned long flash_init (void) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - unsigned long size_b0, size_b1; - int i; - - /* Init: no FLASHes known */ - for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - } - - /* Static FLASH Bank configuration here - FIXME XXX */ - - size_b0 = - flash_get_size ((volatile FLASH_WORD_SIZE *) - FLASH_BASE0_PRELIM, &flash_info[0]); - if (flash_info[0].flash_id == FLASH_UNKNOWN) { - printf ("## Unknown FLASH on Bank 0 - Size = 0x%08lx = %ld MB\n", size_b0, size_b0 << 20); - } - - size_b1 = - flash_get_size ((volatile FLASH_WORD_SIZE *) - FLASH_BASE1_PRELIM, &flash_info[1]); - - if (size_b1 > size_b0) { - printf ("## ERROR: " - "Bank 1 (0x%08lx = %ld MB) > Bank 0 (0x%08lx = %ld MB)\n", - size_b1, size_b1 << 20, size_b0, size_b0 << 20); - flash_info[0].flash_id = FLASH_UNKNOWN; - flash_info[1].flash_id = FLASH_UNKNOWN; - flash_info[0].sector_count = -1; - flash_info[1].sector_count = -1; - flash_info[0].size = 0; - flash_info[1].size = 0; - return (0); - } - - /* Remap FLASH according to real size */ - memctl->memc_or0 = CONFIG_SYS_OR_TIMING_FLASH | (-size_b0 & 0xFFFF8000); - memctl->memc_br0 = CONFIG_SYS_FLASH_BASE | 0x00000801; /* (CONFIG_SYS_FLASH_BASE & BR_BA_MSK) | BR_MS_GPCM | BR_V; */ - - /* Re-do sizing to get full correct info */ - - size_b0 = flash_get_size ((volatile FLASH_WORD_SIZE *) CONFIG_SYS_FLASH_BASE, - &flash_info[0]); - flash_get_offsets (CONFIG_SYS_FLASH_BASE, &flash_info[0]); - -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE - /* monitor protection ON by default */ - (void) flash_protect (FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE + monitor_flash_len - 1, - &flash_info[0]); -#endif - - if (size_b1) { - memctl->memc_or1 = - CONFIG_SYS_OR_TIMING_FLASH | (-size_b1 & 0xFFFF8000); - memctl->memc_br1 = - (CONFIG_SYS_FLASH_BASE | 0x00000801) + (size_b0 & BR_BA_MSK); - /*((CONFIG_SYS_FLASH_BASE + size_b0) & BR_BA_MSK) | - BR_MS_GPCM | BR_V; */ - - /* Re-do sizing to get full correct info */ - size_b1 = - flash_get_size ((volatile FLASH_WORD_SIZE - *) (CONFIG_SYS_FLASH_BASE + size_b0), - &flash_info[1]); - - flash_get_offsets (CONFIG_SYS_FLASH_BASE + size_b0, &flash_info[1]); - -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE - /* monitor protection ON by default */ - (void) flash_protect (FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE + monitor_flash_len - - 1, &flash_info[1]); -#endif - } else { - memctl->memc_br1 = 0; /* invalidate bank */ - - flash_info[1].flash_id = FLASH_UNKNOWN; - flash_info[1].sector_count = -1; - } - - flash_info[0].size = size_b0; - flash_info[1].size = size_b1; - - return (size_b0 + size_b1); -} - -/*----------------------------------------------------------------------- - */ -static void flash_get_offsets (ulong base, flash_info_t * info) -{ - int i; - - /* set up sector start adress table */ - if (info->flash_id & FLASH_BTYPE) { - if ((info->flash_id & FLASH_VENDMASK) == FLASH_MAN_INTEL) { - -#ifndef CONFIG_FLASH_16BIT - /* set sector offsets for bottom boot block type */ - info->start[0] = base + 0x00000000; - info->start[1] = base + 0x00004000; - info->start[2] = base + 0x00008000; - info->start[3] = base + 0x0000C000; - info->start[4] = base + 0x00010000; - info->start[5] = base + 0x00014000; - info->start[6] = base + 0x00018000; - info->start[7] = base + 0x0001C000; - for (i = 8; i < info->sector_count; i++) { - info->start[i] = - base + (i * 0x00020000) - 0x000E0000; - } - } else { - /* set sector offsets for bottom boot block type */ - info->start[0] = base + 0x00000000; - info->start[1] = base + 0x00008000; - info->start[2] = base + 0x0000C000; - info->start[3] = base + 0x00010000; - for (i = 4; i < info->sector_count; i++) { - info->start[i] = - base + (i * 0x00020000) - 0x00060000; - } - } -#else - /* set sector offsets for bottom boot block type */ - info->start[0] = base + 0x00000000; - info->start[1] = base + 0x00002000; - info->start[2] = base + 0x00004000; - info->start[3] = base + 0x00006000; - info->start[4] = base + 0x00008000; - info->start[5] = base + 0x0000A000; - info->start[6] = base + 0x0000C000; - info->start[7] = base + 0x0000E000; - for (i = 8; i < info->sector_count; i++) { - info->start[i] = - base + (i * 0x00010000) - 0x00070000; - } - } else { - /* set sector offsets for bottom boot block type */ - info->start[0] = base + 0x00000000; - info->start[1] = base + 0x00004000; - info->start[2] = base + 0x00006000; - info->start[3] = base + 0x00008000; - for (i = 4; i < info->sector_count; i++) { - info->start[i] = - base + (i * 0x00010000) - 0x00030000; - } - } -#endif - } else { - /* set sector offsets for top boot block type */ - i = info->sector_count - 1; - if ((info->flash_id & FLASH_VENDMASK) == FLASH_MAN_INTEL) { - -#ifndef CONFIG_FLASH_16BIT - info->start[i--] = base + info->size - 0x00004000; - info->start[i--] = base + info->size - 0x00008000; - info->start[i--] = base + info->size - 0x0000C000; - info->start[i--] = base + info->size - 0x00010000; - info->start[i--] = base + info->size - 0x00014000; - info->start[i--] = base + info->size - 0x00018000; - info->start[i--] = base + info->size - 0x0001C000; - for (; i >= 0; i--) { - info->start[i] = base + i * 0x00020000; - } - - } else { - - info->start[i--] = base + info->size - 0x00008000; - info->start[i--] = base + info->size - 0x0000C000; - info->start[i--] = base + info->size - 0x00010000; - for (; i >= 0; i--) { - info->start[i] = base + i * 0x00020000; - } - } -#else - info->start[i--] = base + info->size - 0x00002000; - info->start[i--] = base + info->size - 0x00004000; - info->start[i--] = base + info->size - 0x00006000; - info->start[i--] = base + info->size - 0x00008000; - info->start[i--] = base + info->size - 0x0000A000; - info->start[i--] = base + info->size - 0x0000C000; - info->start[i--] = base + info->size - 0x0000E000; - for (; i >= 0; i--) { - info->start[i] = base + i * 0x00010000; - } - - } else { - - info->start[i--] = base + info->size - 0x00004000; - info->start[i--] = base + info->size - 0x00006000; - info->start[i--] = base + info->size - 0x00008000; - for (; i >= 0; i--) { - info->start[i] = base + i * 0x00010000; - } - } -#endif - } - - -} - -/*----------------------------------------------------------------------- - */ -void flash_print_info (flash_info_t * info) -{ - int i; - uchar *boottype; - uchar botboot[] = ", bottom boot sect)\n"; - uchar topboot[] = ", top boot sector)\n"; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_AMD: - printf ("AMD "); - break; - case FLASH_MAN_FUJ: - printf ("FUJITSU "); - break; - case FLASH_MAN_SST: - printf ("SST "); - break; - case FLASH_MAN_STM: - printf ("STM "); - break; - case FLASH_MAN_INTEL: - printf ("INTEL "); - break; - default: - printf ("Unknown Vendor "); - break; - } - - if (info->flash_id & 0x0001) { - boottype = botboot; - } else { - boottype = topboot; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_AM400B: - printf ("AM29LV400B (4 Mbit%s", boottype); - break; - case FLASH_AM400T: - printf ("AM29LV400T (4 Mbit%s", boottype); - break; - case FLASH_AM800B: - printf ("AM29LV800B (8 Mbit%s", boottype); - break; - case FLASH_AM800T: - printf ("AM29LV800T (8 Mbit%s", boottype); - break; - case FLASH_AM160B: - printf ("AM29LV160B (16 Mbit%s", boottype); - break; - case FLASH_AM160T: - printf ("AM29LV160T (16 Mbit%s", boottype); - break; - case FLASH_AM320B: - printf ("AM29LV320B (32 Mbit%s", boottype); - break; - case FLASH_AM320T: - printf ("AM29LV320T (32 Mbit%s", boottype); - break; - case FLASH_INTEL800B: - printf ("INTEL28F800B (8 Mbit%s", boottype); - break; - case FLASH_INTEL800T: - printf ("INTEL28F800T (8 Mbit%s", boottype); - break; - case FLASH_INTEL160B: - printf ("INTEL28F160B (16 Mbit%s", boottype); - break; - case FLASH_INTEL160T: - printf ("INTEL28F160T (16 Mbit%s", boottype); - break; - case FLASH_INTEL320B: - printf ("INTEL28F320B (32 Mbit%s", boottype); - break; - case FLASH_INTEL320T: - printf ("INTEL28F320T (32 Mbit%s", boottype); - break; - -#if 0 /* enable when devices are available */ - - case FLASH_INTEL640B: - printf ("INTEL28F640B (64 Mbit%s", boottype); - break; - case FLASH_INTEL640T: - printf ("INTEL28F640T (64 Mbit%s", boottype); - break; -#endif - - default: - printf ("Unknown Chip Type\n"); - break; - } - - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); - - printf (" Sector Start Addresses:"); - for (i = 0; i < info->sector_count; ++i) { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", - info->start[i], info->protect[i] ? " (RO)" : " "); - } - printf ("\n"); - return; -} - -/*----------------------------------------------------------------------- - */ - - -/*----------------------------------------------------------------------- - */ - -/* - * The following code cannot be run from FLASH! - */ -ulong flash_get_size (volatile FLASH_WORD_SIZE * addr, flash_info_t * info) -{ - short i; - ulong base = (ulong) addr; - FLASH_WORD_SIZE value; - - /* Write auto select command: read Manufacturer ID */ - - -#ifndef CONFIG_FLASH_16BIT - - /* - * Note: if it is an AMD flash and the word at addr[0000] - * is 0x00890089 this routine will think it is an Intel - * flash device and may(most likely) cause trouble. - */ - - addr[0x0000] = 0x00900090; - if (addr[0x0000] != 0x00890089) { - addr[0x0555] = 0x00AA00AA; - addr[0x02AA] = 0x00550055; - addr[0x0555] = 0x00900090; -#else - - /* - * Note: if it is an AMD flash and the word at addr[0000] - * is 0x0089 this routine will think it is an Intel - * flash device and may(most likely) cause trouble. - */ - - addr[0x0000] = 0x0090; - - if (addr[0x0000] != 0x0089) { - addr[0x0555] = 0x00AA; - addr[0x02AA] = 0x0055; - addr[0x0555] = 0x0090; -#endif - } - value = addr[0]; - - switch (value) { - case (AMD_MANUFACT & FLASH_ID_MASK): - info->flash_id = FLASH_MAN_AMD; - break; - case (FUJ_MANUFACT & FLASH_ID_MASK): - info->flash_id = FLASH_MAN_FUJ; - break; - case (STM_MANUFACT & FLASH_ID_MASK): - info->flash_id = FLASH_MAN_STM; - break; - case (SST_MANUFACT & FLASH_ID_MASK): - info->flash_id = FLASH_MAN_SST; - break; - case (INTEL_MANUFACT & FLASH_ID_MASK): - info->flash_id = FLASH_MAN_INTEL; - break; - default: - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - return (0); /* no or unknown flash */ - - } - - value = addr[1]; /* device ID */ - - switch (value) { - - case (AMD_ID_LV400T & FLASH_ID_MASK): - info->flash_id += FLASH_AM400T; - info->sector_count = 11; - info->size = 0x00100000; - break; /* => 1 MB */ - - case (AMD_ID_LV400B & FLASH_ID_MASK): - info->flash_id += FLASH_AM400B; - info->sector_count = 11; - info->size = 0x00100000; - break; /* => 1 MB */ - - case (AMD_ID_LV800T & FLASH_ID_MASK): - info->flash_id += FLASH_AM800T; - info->sector_count = 19; - info->size = 0x00200000; - break; /* => 2 MB */ - - case (AMD_ID_LV800B & FLASH_ID_MASK): - info->flash_id += FLASH_AM800B; - info->sector_count = 19; - info->size = 0x00200000; - break; /* => 2 MB */ - - case (AMD_ID_LV160T & FLASH_ID_MASK): - info->flash_id += FLASH_AM160T; - info->sector_count = 35; - info->size = 0x00400000; - break; /* => 4 MB */ - - case (AMD_ID_LV160B & FLASH_ID_MASK): - info->flash_id += FLASH_AM160B; - info->sector_count = 35; - info->size = 0x00400000; - break; /* => 4 MB */ -#if 0 /* enable when device IDs are available */ - case (AMD_ID_LV320T & FLASH_ID_MASK): - info->flash_id += FLASH_AM320T; - info->sector_count = 67; - info->size = 0x00800000; - break; /* => 8 MB */ - - case (AMD_ID_LV320B & FLASH_ID_MASK): - info->flash_id += FLASH_AM320B; - info->sector_count = 67; - info->size = 0x00800000; - break; /* => 8 MB */ -#endif - - case (INTEL_ID_28F800B3T & FLASH_ID_MASK): - info->flash_id += FLASH_INTEL800T; - info->sector_count = 23; - info->size = 0x00200000; - break; /* => 2 MB */ - - case (INTEL_ID_28F800B3B & FLASH_ID_MASK): - info->flash_id += FLASH_INTEL800B; - info->sector_count = 23; - info->size = 0x00200000; - break; /* => 2 MB */ - - case (INTEL_ID_28F160B3T & FLASH_ID_MASK): - info->flash_id += FLASH_INTEL160T; - info->sector_count = 39; - info->size = 0x00400000; - break; /* => 4 MB */ - - case (INTEL_ID_28F160B3B & FLASH_ID_MASK): - info->flash_id += FLASH_INTEL160B; - info->sector_count = 39; - info->size = 0x00400000; - break; /* => 4 MB */ - - case (INTEL_ID_28F320B3T & FLASH_ID_MASK): - info->flash_id += FLASH_INTEL320T; - info->sector_count = 71; - info->size = 0x00800000; - break; /* => 8 MB */ - - case (INTEL_ID_28F320B3B & FLASH_ID_MASK): - info->flash_id += FLASH_AM320B; - info->sector_count = 71; - info->size = 0x00800000; - break; /* => 8 MB */ - -#if 0 /* enable when devices are available */ - case (INTEL_ID_28F320B3T & FLASH_ID_MASK): - info->flash_id += FLASH_INTEL320T; - info->sector_count = 135; - info->size = 0x01000000; - break; /* => 16 MB */ - - case (INTEL_ID_28F320B3B & FLASH_ID_MASK): - info->flash_id += FLASH_AM320B; - info->sector_count = 135; - info->size = 0x01000000; - break; /* => 16 MB */ -#endif - default: - info->flash_id = FLASH_UNKNOWN; - return (0); /* => no or unknown flash */ - - } - - /* set up sector start adress table */ - if (info->flash_id & FLASH_BTYPE) { - if ((info->flash_id & FLASH_VENDMASK) == FLASH_MAN_INTEL) { - -#ifndef CONFIG_FLASH_16BIT - /* set sector offsets for bottom boot block type */ - info->start[0] = base + 0x00000000; - info->start[1] = base + 0x00004000; - info->start[2] = base + 0x00008000; - info->start[3] = base + 0x0000C000; - info->start[4] = base + 0x00010000; - info->start[5] = base + 0x00014000; - info->start[6] = base + 0x00018000; - info->start[7] = base + 0x0001C000; - for (i = 8; i < info->sector_count; i++) { - info->start[i] = - base + (i * 0x00020000) - 0x000E0000; - } - } else { - /* set sector offsets for bottom boot block type */ - info->start[0] = base + 0x00000000; - info->start[1] = base + 0x00008000; - info->start[2] = base + 0x0000C000; - info->start[3] = base + 0x00010000; - for (i = 4; i < info->sector_count; i++) { - info->start[i] = - base + (i * 0x00020000) - 0x00060000; - } - } -#else - /* set sector offsets for bottom boot block type */ - info->start[0] = base + 0x00000000; - info->start[1] = base + 0x00002000; - info->start[2] = base + 0x00004000; - info->start[3] = base + 0x00006000; - info->start[4] = base + 0x00008000; - info->start[5] = base + 0x0000A000; - info->start[6] = base + 0x0000C000; - info->start[7] = base + 0x0000E000; - for (i = 8; i < info->sector_count; i++) { - info->start[i] = - base + (i * 0x00010000) - 0x00070000; - } - } else { - /* set sector offsets for bottom boot block type */ - info->start[0] = base + 0x00000000; - info->start[1] = base + 0x00004000; - info->start[2] = base + 0x00006000; - info->start[3] = base + 0x00008000; - for (i = 4; i < info->sector_count; i++) { - info->start[i] = - base + (i * 0x00010000) - 0x00030000; - } - } -#endif - } else { - /* set sector offsets for top boot block type */ - i = info->sector_count - 1; - if ((info->flash_id & FLASH_VENDMASK) == FLASH_MAN_INTEL) { - -#ifndef CONFIG_FLASH_16BIT - info->start[i--] = base + info->size - 0x00004000; - info->start[i--] = base + info->size - 0x00008000; - info->start[i--] = base + info->size - 0x0000C000; - info->start[i--] = base + info->size - 0x00010000; - info->start[i--] = base + info->size - 0x00014000; - info->start[i--] = base + info->size - 0x00018000; - info->start[i--] = base + info->size - 0x0001C000; - for (; i >= 0; i--) { - info->start[i] = base + i * 0x00020000; - } - - } else { - - info->start[i--] = base + info->size - 0x00008000; - info->start[i--] = base + info->size - 0x0000C000; - info->start[i--] = base + info->size - 0x00010000; - for (; i >= 0; i--) { - info->start[i] = base + i * 0x00020000; - } - } -#else - info->start[i--] = base + info->size - 0x00002000; - info->start[i--] = base + info->size - 0x00004000; - info->start[i--] = base + info->size - 0x00006000; - info->start[i--] = base + info->size - 0x00008000; - info->start[i--] = base + info->size - 0x0000A000; - info->start[i--] = base + info->size - 0x0000C000; - info->start[i--] = base + info->size - 0x0000E000; - for (; i >= 0; i--) { - info->start[i] = base + i * 0x00010000; - } - - } else { - - info->start[i--] = base + info->size - 0x00004000; - info->start[i--] = base + info->size - 0x00006000; - info->start[i--] = base + info->size - 0x00008000; - for (; i >= 0; i--) { - info->start[i] = base + i * 0x00010000; - } - } -#endif - } - - /* check for protected sectors */ - for (i = 0; i < info->sector_count; i++) { - /* read sector protection at sector address, (A7 .. A0) = 0x02 */ - /* D0 = 1 if protected */ - addr = (volatile FLASH_WORD_SIZE *) (info->start[i]); - info->protect[i] = addr[2] & 1; - } - - /* - * Prevent writes to uninitialized FLASH. - */ - if (info->flash_id != FLASH_UNKNOWN) { - addr = (volatile FLASH_WORD_SIZE *) info->start[0]; - if ((info->flash_id & 0xFF00) == FLASH_MAN_INTEL) { - *addr = (0x00F000F0 & FLASH_ID_MASK); /* reset bank */ - } else { - *addr = (0x00FF00FF & FLASH_ID_MASK); /* reset bank */ - } - } - - return (info->size); -} - - -/*----------------------------------------------------------------------- - */ - -int flash_erase (flash_info_t * info, int s_first, int s_last) -{ - - volatile FLASH_WORD_SIZE *addr = - (volatile FLASH_WORD_SIZE *) (info->start[0]); - int flag, prot, sect, l_sect, barf; - ulong start, now, last; - int rcode = 0; - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - if ((info->flash_id == FLASH_UNKNOWN) || - ((info->flash_id > FLASH_AMD_COMP) && - ((info->flash_id & FLASH_VENDMASK) != FLASH_MAN_INTEL))) { - printf ("Can't erase unknown flash type - aborted\n"); - return 1; - } - - prot = 0; - for (sect = s_first; sect <= s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", prot); - } else { - printf ("\n"); - } - - l_sect = -1; - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts (); - if (info->flash_id < FLASH_AMD_COMP) { -#ifndef CONFIG_FLASH_16BIT - addr[0x0555] = 0x00AA00AA; - addr[0x02AA] = 0x00550055; - addr[0x0555] = 0x00800080; - addr[0x0555] = 0x00AA00AA; - addr[0x02AA] = 0x00550055; -#else - addr[0x0555] = 0x00AA; - addr[0x02AA] = 0x0055; - addr[0x0555] = 0x0080; - addr[0x0555] = 0x00AA; - addr[0x02AA] = 0x0055; -#endif - /* Start erase on unprotected sectors */ - for (sect = s_first; sect <= s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - addr = (volatile FLASH_WORD_SIZE *) (info->start[sect]); - addr[0] = (0x00300030 & FLASH_ID_MASK); - l_sect = sect; - } - } - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts (); - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - - /* - * We wait for the last triggered sector - */ - if (l_sect < 0) - goto DONE; - - start = get_timer (0); - last = start; - addr = (volatile FLASH_WORD_SIZE *) (info->start[l_sect]); - while ((addr[0] & (0x00800080 & FLASH_ID_MASK)) != - (0x00800080 & FLASH_ID_MASK)) { - if ((now = get_timer (start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - return 1; - } - /* show that we're waiting */ - if ((now - last) > 1000) { /* every second */ - serial_putc ('.'); - last = now; - } - } - - DONE: - /* reset to read mode */ - addr = (volatile FLASH_WORD_SIZE *) info->start[0]; - addr[0] = (0x00F000F0 & FLASH_ID_MASK); /* reset bank */ - } else { - - - for (sect = s_first; sect <= s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - barf = 0; -#ifndef CONFIG_FLASH_16BIT - addr = (vu_long *) (info->start[sect]); - addr[0] = 0x00200020; - addr[0] = 0x00D000D0; - while (!(addr[0] & 0x00800080)); /* wait for error or finish */ - if (addr[0] & 0x003A003A) { /* check for error */ - barf = addr[0] & 0x003A0000; - if (barf) { - barf >>= 16; - } else { - barf = addr[0] & 0x0000003A; - } - } -#else - addr = (vu_short *) (info->start[sect]); - addr[0] = 0x0020; - addr[0] = 0x00D0; - while (!(addr[0] & 0x0080)); /* wait for error or finish */ - if (addr[0] & 0x003A) /* check for error */ - barf = addr[0] & 0x003A; -#endif - if (barf) { - printf ("\nFlash error in sector at %lx\n", (unsigned long) addr); - if (barf & 0x0002) - printf ("Block locked, not erased.\n"); - if ((barf & 0x0030) == 0x0030) - printf ("Command Sequence error.\n"); - if ((barf & 0x0030) == 0x0020) - printf ("Block Erase error.\n"); - if (barf & 0x0008) - printf ("Vpp Low error.\n"); - rcode = 1; - } else - printf ("."); - l_sect = sect; - } - addr = (volatile FLASH_WORD_SIZE *) info->start[0]; - addr[0] = (0x00FF00FF & FLASH_ID_MASK); /* reset bank */ - - } - - } - printf (" done\n"); - return rcode; -} - -/*----------------------------------------------------------------------- - */ - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ - -int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) -{ -#ifndef CONFIG_FLASH_16BIT - ulong cp, wp, data; - int l; -#else - ulong cp, wp; - ushort data; -#endif - int i, rc; - -#ifndef CONFIG_FLASH_16BIT - - - wp = (addr & ~3); /* get lower word aligned address */ - - /* - * handle unaligned start bytes - */ - if ((l = addr - wp) != 0) { - data = 0; - for (i = 0, cp = wp; i < l; ++i, ++cp) { - data = (data << 8) | (*(uchar *) cp); - } - for (; i < 4 && cnt > 0; ++i) { - data = (data << 8) | *src++; - --cnt; - ++cp; - } - for (; cnt == 0 && i < 4; ++i, ++cp) { - data = (data << 8) | (*(uchar *) cp); - } - - if ((rc = write_word (info, wp, data)) != 0) { - return (rc); - } - wp += 4; - } - - /* - * handle word aligned part - */ - while (cnt >= 4) { - data = 0; - for (i = 0; i < 4; ++i) { - data = (data << 8) | *src++; - } - if ((rc = write_word (info, wp, data)) != 0) { - return (rc); - } - wp += 4; - cnt -= 4; - } - - if (cnt == 0) { - return (0); - } - - /* - * handle unaligned tail bytes - */ - data = 0; - for (i = 0, cp = wp; i < 4 && cnt > 0; ++i, ++cp) { - data = (data << 8) | *src++; - --cnt; - } - for (; i < 4; ++i, ++cp) { - data = (data << 8) | (*(uchar *) cp); - } - - return (write_word (info, wp, data)); - -#else - wp = (addr & ~1); /* get lower word aligned address */ - - /* - * handle unaligned start byte - */ - if (addr - wp) { - data = 0; - data = (data << 8) | *src++; - --cnt; - if ((rc = write_short (info, wp, data)) != 0) { - return (rc); - } - wp += 2; - } - - /* - * handle word aligned part - */ -/* l = 0; used for debuging */ - while (cnt >= 2) { - data = 0; - for (i = 0; i < 2; ++i) { - data = (data << 8) | *src++; - } - -/* if(!l){ - printf("%x",data); - l = 1; - } used for debuging */ - - if ((rc = write_short (info, wp, data)) != 0) { - return (rc); - } - wp += 2; - cnt -= 2; - } - - if (cnt == 0) { - return (0); - } - - /* - * handle unaligned tail bytes - */ - data = 0; - for (i = 0, cp = wp; i < 2 && cnt > 0; ++i, ++cp) { - data = (data << 8) | *src++; - --cnt; - } - for (; i < 2; ++i, ++cp) { - data = (data << 8) | (*(uchar *) cp); - } - - return (write_short (info, wp, data)); - - -#endif -} - -/*----------------------------------------------------------------------- - * Write a word to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -#ifndef CONFIG_FLASH_16BIT -static int write_word (flash_info_t * info, ulong dest, ulong data) -{ - vu_long *addr = (vu_long *) (info->start[0]); - ulong start, barf; - int flag; - - - /* Check if Flash is (sufficiently) erased */ - if ((*((vu_long *) dest) & data) != data) { - return (2); - } - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts (); - - if (info->flash_id > FLASH_AMD_COMP) { - /* AMD stuff */ - addr[0x0555] = 0x00AA00AA; - addr[0x02AA] = 0x00550055; - addr[0x0555] = 0x00A000A0; - } else { - /* intel stuff */ - *addr = 0x00400040; - } - *((vu_long *) dest) = data; - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts (); - - /* data polling for D7 */ - start = get_timer (0); - - if (info->flash_id > FLASH_AMD_COMP) { - - while ((*((vu_long *) dest) & 0x00800080) != - (data & 0x00800080)) { - if (get_timer (start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - return (1); - } - } - - } else { - - while (!(addr[0] & 0x00800080)) { /* wait for error or finish */ - if (get_timer (start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - return (1); - } - - if (addr[0] & 0x003A003A) { /* check for error */ - barf = addr[0] & 0x003A0000; - if (barf) { - barf >>= 16; - } else { - barf = addr[0] & 0x0000003A; - } - printf ("\nFlash write error at address %lx\n", (unsigned long) dest); - if (barf & 0x0002) - printf ("Block locked, not erased.\n"); - if (barf & 0x0010) - printf ("Programming error.\n"); - if (barf & 0x0008) - printf ("Vpp Low error.\n"); - return (2); - } - - - } - - return (0); - - } - -#else - -static int write_short (flash_info_t * info, ulong dest, ushort data) -{ - vu_short *addr = (vu_short *) (info->start[0]); - ulong start, barf; - int flag; - - /* Check if Flash is (sufficiently) erased */ - if ((*((vu_short *) dest) & data) != data) { - return (2); - } - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts (); - - if (info->flash_id < FLASH_AMD_COMP) { - /* AMD stuff */ - addr[0x0555] = 0x00AA; - addr[0x02AA] = 0x0055; - addr[0x0555] = 0x00A0; - } else { - /* intel stuff */ - *addr = 0x00D0; - *addr = 0x0040; - } - *((vu_short *) dest) = data; - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts (); - - /* data polling for D7 */ - start = get_timer (0); - - if (info->flash_id < FLASH_AMD_COMP) { - /* AMD stuff */ - while ((*((vu_short *) dest) & 0x0080) != (data & 0x0080)) { - if (get_timer (start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - return (1); - } - } - - } else { - /* intel stuff */ - while (!(addr[0] & 0x0080)) { /* wait for error or finish */ - if (get_timer (start) > CONFIG_SYS_FLASH_WRITE_TOUT) - return (1); - } - - if (addr[0] & 0x003A) { /* check for error */ - barf = addr[0] & 0x003A; - printf ("\nFlash write error at address %lx\n", - (unsigned long) dest); - if (barf & 0x0002) - printf ("Block locked, not erased.\n"); - if (barf & 0x0010) - printf ("Programming error.\n"); - if (barf & 0x0008) - printf ("Vpp Low error.\n"); - return (2); - } - *addr = 0x00B0; - *addr = 0x0070; - while (!(addr[0] & 0x0080)) { /* wait for error or finish */ - if (get_timer (start) > CONFIG_SYS_FLASH_WRITE_TOUT) - return (1); - } - *addr = 0x00FF; - } - return (0); -} - -#endif -/*-----------------------------------------------------------------------*/ diff --git a/board/esteem192e/u-boot.lds b/board/esteem192e/u-boot.lds deleted file mode 100644 index 59a86bf..0000000 --- a/board/esteem192e/u-boot.lds +++ /dev/null @@ -1,90 +0,0 @@ -/* - * (C) Copyright 2000-2010 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -OUTPUT_ARCH(powerpc) - -SECTIONS -{ - /* Read-only sections, merged into text segment: */ - . = + SIZEOF_HEADERS; - .text : - { - /* WARNING - the following is hand-optimized to fit within */ - /* the sector layout of our flash chips! XXX FIXME XXX */ - - arch/powerpc/cpu/mpc8xx/start.o (.text*) - arch/powerpc/cpu/mpc8xx/traps.o (.text*) - net/built-in.o (.text*) - board/esteem192e/built-in.o (.text*) - - . = env_offset; - common/env_embedded.o (.text*) - - *(.text*) - } - _etext = .; - PROVIDE (etext = .); - .rodata : - { - *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) - } - - /* Read-write section, merged into data segment: */ - . = (. + 0x00FF) & 0xFFFFFF00; - _erotext = .; - PROVIDE (erotext = .); - .reloc : - { - _GOT2_TABLE_ = .; - KEEP(*(.got2)) - KEEP(*(.got)) - PROVIDE(_GLOBAL_OFFSET_TABLE_ = . + 4); - _FIXUP_TABLE_ = .; - KEEP(*(.fixup)) - } - __got2_entries = ((_GLOBAL_OFFSET_TABLE_ - _GOT2_TABLE_) >> 2) - 1; - __fixup_entries = (. - _FIXUP_TABLE_)>>2; - - .data : - { - *(.data*) - *(.sdata*) - } - _edata = .; - PROVIDE (edata = .); - - . = .; - - . = ALIGN(4); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); - } - - - . = .; - __start___ex_table = .; - __ex_table : { *(__ex_table) } - __stop___ex_table = .; - - . = ALIGN(256); - __init_begin = .; - .text.init : { *(.text.init) } - .data.init : { *(.data.init) } - . = ALIGN(256); - __init_end = .; - - __bss_start = .; - .bss (NOLOAD) : - { - *(.bss*) - *(.sbss*) - *(COMMON) - . = ALIGN(4); - } - __bss_end = . ; - PROVIDE (end = .); -} diff --git a/configs/ESTEEM192E_defconfig b/configs/ESTEEM192E_defconfig deleted file mode 100644 index e6279b8..0000000 --- a/configs/ESTEEM192E_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_ESTEEM192E=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 0e39857..9d6a6b6 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,7 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +ESTEEM192E powerpc mpc8xx - - Conn Clark clark@esteem.com IP860 powerpc mpc8xx - - Wolfgang Denk wd@denx.de IVML24 powerpc mpc8xx - - Wolfgang Denk wd@denx.de IVMS8 powerpc mpc8xx - - Wolfgang Denk wd@denx.de diff --git a/include/commproc.h b/include/commproc.h index c53482c..9582746 100644 --- a/include/commproc.h +++ b/include/commproc.h @@ -456,34 +456,6 @@ typedef struct scc_enet { #define SICR_ENET_CLKRT ((uint)0x00002c00) #endif /* CONFIG_BSEIP */
-/*** ESTEEM 192E **************************************************/ -#ifdef CONFIG_ESTEEM192E -/* ESTEEM192E - * This ENET stuff is for the MPC850 with ethernet on SCC2. This - * is very similar to the RPX-Lite configuration. - * Note TENA , LOOPBACK , FDPLEX_DIS on Port B. - */ - -#define PROFF_ENET PROFF_SCC2 -#define CPM_CR_ENET CPM_CR_CH_SCC2 -#define SCC_ENET 1 - -#define PA_ENET_RXD ((ushort)0x0004) -#define PA_ENET_TXD ((ushort)0x0008) -#define PA_ENET_TCLK ((ushort)0x0200) -#define PA_ENET_RCLK ((ushort)0x0800) -#define PB_ENET_TENA ((uint)0x00002000) -#define PC_ENET_CLSN ((ushort)0x0040) -#define PC_ENET_RENA ((ushort)0x0080) - -#define SICR_ENET_MASK ((uint)0x0000ff00) -#define SICR_ENET_CLKRT ((uint)0x00003d00) - -#define PB_ENET_LOOPBACK ((uint)0x00004000) -#define PB_ENET_FDPLEX_DIS ((uint)0x00008000) - -#endif - /*** KM8XX *********************************************************/
/* The KM8XX Service Module uses SCC3 for Ethernet */ diff --git a/include/configs/ESTEEM192E.h b/include/configs/ESTEEM192E.h deleted file mode 100644 index 347f8b6..0000000 --- a/include/configs/ESTEEM192E.h +++ /dev/null @@ -1,292 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC850 1 /* This is a MPC850 CPU */ -#define CONFIG_ESTEEM192E 1 /* ...on a EST ESTEEM192E */ - -#define CONFIG_SYS_TEXT_BASE 0x40000000 - -#define CONFIG_FLASH_16BIT 1 /* Rom 16 bit data bus */ - -#define CONFIG_8xx_CONS_SMC1 1 /* Console is on SMC1 */ -#undef CONFIG_8xx_CONS_SMC2 -#undef CONFIG_8xx_CONS_NONE - -#define MPC8XX_FACT 10 /* Multiply by 10 */ -#define MPC8XX_XIN 4915200 /* 4.915200 MHz in - ??? - XXX */ -#define CONFIG_SYS_PLPRCR_MF ((MPC8XX_FACT-1) << 20) -#define MPC8XX_HZ ((MPC8XX_XIN) * (MPC8XX_FACT)) /* 49,152,000 Hz */ - -#define CONFIG_8xx_GCLK_FREQ MPC8XX_HZ /* Force it - dont measure it */ - -#define CONFIG_CLOCKS_IN_MHZ 1 /* clocks passsed to Linux in MHz */ - -#define CONFIG_BAUDRATE 9600 -#if 0 -#define CONFIG_BOOTDELAY -1 /* autoboot disabled */ -#else -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ -#endif -#define CONFIG_BOOTCOMMAND "bootm 40030000" /* autoboot command */ - -#define CONFIG_BOOTARGS "root=/dev/ram rw ramdisk=8192 " \ - "ip=100.100.100.21:100.100.100.14:100.100.100.1:255.0.0.0 " -/* - * Miscellaneous configurable options - */ - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - - -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "BOOT: " /* Monitor Command Prompt */ -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 8 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xFF000000 - - /*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0x40000000 -#ifdef DEBUG -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#else -#define CONFIG_SYS_MONITOR_LEN (128 << 10) /* Reserve 128 kB for Monitor */ -#endif -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 71 /* max number of sectors on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ - -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_OFFSET 0x8000 /* Offset of Environment Sector */ -#define CONFIG_ENV_SIZE 0x2000 /* Total Size of Environment Sector */ -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 11-9 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Software & Bus Monitor Timer max, Bus Monitor enable, SW Watchdog freeze - */ -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | SYPCR_SWP) - -/*----------------------------------------------------------------------- - * SUMCR - SIU Module Configuration 11-6 - *----------------------------------------------------------------------- - * PCMCIA config., multi-function pin tri-state - */ -#define CONFIG_SYS_SIUMCR (SIUMCR_DBGC00 | SIUMCR_DBPC00 | SIUMCR_MLRC01) /* DBGC00 */ - -/*----------------------------------------------------------------------- - * TBSCR - Time Base Status and Control 11-26 - *----------------------------------------------------------------------- - * Clear Reference Interrupt Status, Timebase freezing enabled - */ -#define CONFIG_SYS_TBSCR (TBSCR_REFA | TBSCR_REFB | TBSCR_TBF | TBSCR_TBE) - -/* (TBSCR_REFA | TBSCR_REFB | TBSCR_TBF) */ - - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 11-31 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Interrupt Timer freezing enabled - */ -#define CONFIG_SYS_PISCR (PISCR_PS | PISCR_PITF) - -/*----------------------------------------------------------------------- - * PLPRCR - PLL, Low-Power, and Reset Control Register 15-30 - *----------------------------------------------------------------------- - * Reset PLL lock status sticky bit, timer expired status bit and timer - * interrupt status bit - leave PLL multiplication factor unchanged ! - */ -#define CONFIG_SYS_PLPRCR (CONFIG_SYS_PLPRCR_MF | PLPRCR_SPLSS | PLPRCR_TEXPS | PLPRCR_TMIST) - -/*----------------------------------------------------------------------- - * SCCR - System Clock and reset Control Register 15-27 - *----------------------------------------------------------------------- - * Set clock output, timebase and RTC source and divider, - * power management and some other internal clocks - */ -#define SCCR_MASK SCCR_EBDF11 -#define CONFIG_SYS_SCCR (SCCR_TBS | \ - SCCR_COM00 | SCCR_DFSYNC00 | SCCR_DFBRG00 | \ - SCCR_DFNL000 | SCCR_DFNH000 | SCCR_DFLCD000 | \ - SCCR_DFALCD00) - -/*----------------------------------------------------------------------- - * PCMCIA stuff - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_PCMCIA_MEM_ADDR (0xE0000000) -#define CONFIG_SYS_PCMCIA_MEM_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_DMA_ADDR (0xE4000000) -#define CONFIG_SYS_PCMCIA_DMA_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_ATTRB_ADDR (0xE8000000) -#define CONFIG_SYS_PCMCIA_ATTRB_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_IO_ADDR (0xEC000000) -#define CONFIG_SYS_PCMCIA_IO_SIZE ( 64 << 20 ) - -#define CONFIG_SYS_PCMCIA_INTERRUPT SIU_LEVEL6 - -/*----------------------------------------------------------------------- - * - *----------------------------------------------------------------------- - * - */ -/*#define CONFIG_SYS_DER 0x2002000F*/ -#define CONFIG_SYS_DER 0 -/*#define CONFIG_SYS_DER 0x02002000 */ - - -/* - * Init Memory Controller: - * - * BR0/1 and OR0/1 (FLASH) - */ - -#define FLASH_BASE0_PRELIM 0x40000000 /* FLASH bank #0 */ -#define FLASH_BASE1_PRELIM 0x60000000 /* FLASH bank #0 */ - -/* used to re-map FLASH both when starting from SRAM or FLASH: - * restrict access enough to keep SRAM working (if any) - * but not too much to meddle with FLASH accesses - */ -#define CONFIG_SYS_REMAP_OR_AM 0x80000000 /* OR addr mask */ -#define CONFIG_SYS_PRELIM_OR_AM 0xE0000000 /* OR addr mask */ - -/* FLASH timing: ACS = 11, TRLX = 0, CSNT = 1, SCY = 5, EHTR = 1 */ -#define CONFIG_SYS_OR_TIMING_FLASH 0x00000160 - /*(OR_CSNT_SAM | OR_ACS_DIV2 | OR_BI | \ - OR_SCY_5_CLK | OR_EHTR) */ - -#define CONFIG_SYS_OR0_REMAP 0x80000160 /*(CONFIG_SYS_REMAP_OR_AM | CONFIG_SYS_OR_TIMING_FLASH)*/ -#define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_BR0_PRELIM ( FLASH_BASE0_PRELIM | 0x00000801 ) - -#define CONFIG_SYS_OR1_REMAP CONFIG_SYS_OR0_REMAP -#define CONFIG_SYS_OR1_PRELIM CONFIG_SYS_OR0_PRELIM -#define CONFIG_SYS_BR1_PRELIM ( FLASH_BASE1_PRELIM | 0x00000801 ) - -/* - * BR2/3 and OR2/3 (SDRAM) - * - */ -#define SDRAM_BASE2_PRELIM 0x00000000 /* SDRAM bank #0 */ -#define SDRAM_BASE3_PRELIM 0x04000000 /* SDRAM bank #1 */ -#define SDRAM_MAX_SIZE 0x02000000 /* max 32 MB per bank */ - -/* SDRAM timing: Multiplexed addresses, GPL5 output to GPL5_A (don't care) */ -#define CONFIG_SYS_OR_TIMING_SDRAM 0x00000A00 - -#define CONFIG_SYS_OR2_PRELIM 0xFC000E00 -#define CONFIG_SYS_BR2_PRELIM (SDRAM_BASE2_PRELIM | 0x00000081) - -#define CONFIG_SYS_OR3_PRELIM CONFIG_SYS_OR2_PRELIM -#define CONFIG_SYS_BR3_PRELIM (SDRAM_BASE3_PRELIM | 0x00000081) - - -/* - * Memory Periodic Timer Prescaler - */ - -/* periodic timer for refresh */ -#define CONFIG_SYS_MAMR_PTA 97 /* start with divider for 100 MHz */ - -/* refresh rate 15.6 us (= 64 ms / 4K = 62.4 / quad bursts) for <= 128 MBit */ -#define CONFIG_SYS_MPTPR_2BK_4K MPTPR_PTP_DIV16 /* setting for 2 banks */ -#define CONFIG_SYS_MPTPR_1BK_4K MPTPR_PTP_DIV32 /* setting for 1 bank */ - -/* refresh rate 7.8 us (= 64 ms / 8K = 31.2 / quad bursts) for 256 MBit */ -#define CONFIG_SYS_MPTPR_2BK_8K MPTPR_PTP_DIV8 /* setting for 2 banks */ -#define CONFIG_SYS_MPTPR_1BK_8K MPTPR_PTP_DIV16 /* setting for 1 bank */ - -/* - * MAMR settings for SDRAM - */ - -/* 8 column SDRAM */ -#define CONFIG_SYS_MAMR_8COL 0x18803112 -#define CONFIG_SYS_MAMR_9COL 0x18803112 /* same as 8 column because its just easier to port with*/ - -#endif /* __CONFIG_H */
On Mon, Dec 15, 2014 at 11:26:17PM +0900, Masahiro Yamada wrote:
This board is still a non-generic board.
These boards are still non-generic boards.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Murray Jensen Murray.Jensen@csiro.au ---
arch/powerpc/cpu/mpc8260/Kconfig | 4 - arch/powerpc/cpu/mpc8260/cpu_init.c | 4 - arch/powerpc/cpu/mpc8260/start.S | 61 ---- arch/powerpc/cpu/mpc8xx/Kconfig | 4 - board/cogent/Kconfig | 19 -- board/cogent/MAINTAINERS | 8 - board/cogent/Makefile | 8 - board/cogent/README | 118 ------- board/cogent/README.cma286 | 69 ---- board/cogent/dipsw.c | 50 --- board/cogent/dipsw.h | 3 - board/cogent/flash.c | 633 ------------------------------------ board/cogent/flash.h | 305 ----------------- board/cogent/kbm.c | 3 - board/cogent/lcd.c | 245 -------------- board/cogent/lcd.h | 84 ----- board/cogent/mb.c | 280 ---------------- board/cogent/mb.h | 513 ----------------------------- board/cogent/par.c | 3 - board/cogent/par.h | 3 - board/cogent/pci.c | 3 - board/cogent/pci.h | 3 - board/cogent/rtc.c | 3 - board/cogent/rtc.h | 3 - board/cogent/serial.c | 189 ----------- board/cogent/serial.h | 15 - board/cogent/u-boot.lds | 86 ----- board/cogent/u-boot.lds.debug | 121 ------- configs/cogent_mpc8260_defconfig | 3 - configs/cogent_mpc8xx_defconfig | 3 - doc/README.scrapyard | 2 + include/configs/cogent_common.h | 192 ----------- include/configs/cogent_mpc8260.h | 392 ---------------------- include/configs/cogent_mpc8xx.h | 349 -------------------- 34 files changed, 2 insertions(+), 3779 deletions(-) delete mode 100644 board/cogent/Kconfig delete mode 100644 board/cogent/MAINTAINERS delete mode 100644 board/cogent/Makefile delete mode 100644 board/cogent/README delete mode 100644 board/cogent/README.cma286 delete mode 100644 board/cogent/dipsw.c delete mode 100644 board/cogent/dipsw.h delete mode 100644 board/cogent/flash.c delete mode 100644 board/cogent/flash.h delete mode 100644 board/cogent/kbm.c delete mode 100644 board/cogent/lcd.c delete mode 100644 board/cogent/lcd.h delete mode 100644 board/cogent/mb.c delete mode 100644 board/cogent/mb.h delete mode 100644 board/cogent/par.c delete mode 100644 board/cogent/par.h delete mode 100644 board/cogent/pci.c delete mode 100644 board/cogent/pci.h delete mode 100644 board/cogent/rtc.c delete mode 100644 board/cogent/rtc.h delete mode 100644 board/cogent/serial.c delete mode 100644 board/cogent/serial.h delete mode 100644 board/cogent/u-boot.lds delete mode 100644 board/cogent/u-boot.lds.debug delete mode 100644 configs/cogent_mpc8260_defconfig delete mode 100644 configs/cogent_mpc8xx_defconfig delete mode 100644 include/configs/cogent_common.h delete mode 100644 include/configs/cogent_mpc8260.h delete mode 100644 include/configs/cogent_mpc8xx.h
diff --git a/arch/powerpc/cpu/mpc8260/Kconfig b/arch/powerpc/cpu/mpc8260/Kconfig index 2541400..17e303d 100644 --- a/arch/powerpc/cpu/mpc8260/Kconfig +++ b/arch/powerpc/cpu/mpc8260/Kconfig @@ -10,9 +10,6 @@ choice config TARGET_ATC bool "Support atc"
-config TARGET_COGENT_MPC8260 - bool "Support cogent_mpc8260" - config TARGET_CPU86 bool "Support CPU86"
@@ -58,7 +55,6 @@ config TARGET_KM82XX endchoice
source "board/atc/Kconfig" -source "board/cogent/Kconfig" source "board/cpu86/Kconfig" source "board/cpu87/Kconfig" source "board/ep8260/Kconfig" diff --git a/arch/powerpc/cpu/mpc8260/cpu_init.c b/arch/powerpc/cpu/mpc8260/cpu_init.c index f46a9c0..a9bb5ad 100644 --- a/arch/powerpc/cpu/mpc8260/cpu_init.c +++ b/arch/powerpc/cpu/mpc8260/cpu_init.c @@ -88,9 +88,7 @@ static void config_8260_ioports (volatile immap_t * immr) */ void cpu_init_f (volatile immap_t * immr) { -#if !defined(CONFIG_COGENT) /* done in start.S for the cogent */ uint sccr; -#endif #if defined(CONFIG_BOARD_GET_CPU_CLK_F) unsigned long cpu_clk; #endif @@ -141,13 +139,11 @@ void cpu_init_f (volatile immap_t * immr) /* initialize the PIT (4-42) */ immr->im_sit.sit_piscr = CONFIG_SYS_PISCR;
-#if !defined(CONFIG_COGENT) /* done in start.S for the cogent */ /* System clock control register (9-8) */ sccr = immr->im_clkrst.car_sccr & (SCCR_PCI_MODE | SCCR_PCI_MODCK | SCCR_PCIDF_MSK); immr->im_clkrst.car_sccr = sccr | (CONFIG_SYS_SCCR & ~(SCCR_PCI_MODE | SCCR_PCI_MODCK | SCCR_PCIDF_MSK) ); -#endif /* !CONFIG_COGENT */
/* * Memory Controller: diff --git a/arch/powerpc/cpu/mpc8260/start.S b/arch/powerpc/cpu/mpc8260/start.S index 5f1e174..d255bde 100644 --- a/arch/powerpc/cpu/mpc8260/start.S +++ b/arch/powerpc/cpu/mpc8260/start.S @@ -136,14 +136,6 @@ _hrcw_table: _start: mfmsr r5 /* save msr contents */
-#if defined(CONFIG_COGENT) - /* this is what the cogent EPROM does */ - li r0, 0 - mtmsr r0 - isync - bl cogent_init_8260 -#endif /* CONFIG_COGENT */ - #if defined(CONFIG_SYS_DEFAULT_IMMR) lis r3, CONFIG_SYS_IMMR@h ori r3, r3, CONFIG_SYS_IMMR@l @@ -379,57 +371,6 @@ int_return: SYNC rfi
-#if defined(CONFIG_COGENT) - -/* - * This code initialises the MPC8260 processor core - * (conforms to PowerPC 603e spec) - */ - - .globl cogent_init_8260 -cogent_init_8260: - - /* Taken from page 14 of CMA282 manual */ - /*--------------------------------------------------------------*/ - - lis r4, (CONFIG_SYS_IMMR+IM_REGBASE)@h - lis r3, CONFIG_SYS_IMMR@h - stw r3, IM_IMMR@l(r4) - lwz r3, IM_IMMR@l(r4) - stw r3, 0(r0) - lis r3, CONFIG_SYS_SYPCR@h - ori r3, r3, CONFIG_SYS_SYPCR@l - stw r3, IM_SYPCR@l(r4) - lwz r3, IM_SYPCR@l(r4) - stw r3, 4(r0) - lis r3, CONFIG_SYS_SCCR@h - ori r3, r3, CONFIG_SYS_SCCR@l - stw r3, IM_SCCR@l(r4) - lwz r3, IM_SCCR@l(r4) - stw r3, 8(r0) - - /* the rest of this was disassembled from the */ - /* EPROM code that came with my CMA282 CPU module */ - /*--------------------------------------------------------------*/ - - lis r1, 0x1234 - ori r1, r1, 0x5678 - stw r1, 0x20(r0) - lwz r1, 0x20(r0) - stw r1, 0x24(r0) - lwz r1, 0x24(r0) - lis r3, 0x0e80 - ori r3, r3, 0 - stw r1, 4(r3) - lwz r1, 4(r3) - - /* Done! */ - /*--------------------------------------------------------------*/ - - blr - -#endif /* CONFIG_COGENT */ - /* * This code initialises the MPC8260 processor core * (conforms to PowerPC 603e spec) @@ -456,11 +397,9 @@ init_8260_core: /*--------------------------------------------------------------*/
lis r3, (CONFIG_SYS_IMMR+IM_REGBASE)@h -#if !defined(CONFIG_COGENT) lis r4, CONFIG_SYS_SYPCR@h ori r4, r4, CONFIG_SYS_SYPCR@l stw r4, IM_SYPCR@l(r3) -#endif /* !CONFIG_COGENT */ #if defined(CONFIG_WATCHDOG) li r4, 21868 /* = 0x556c */ sth r4, IM_SWSR@l(r3) diff --git a/arch/powerpc/cpu/mpc8xx/Kconfig b/arch/powerpc/cpu/mpc8xx/Kconfig index 428a129..e8bcbe9 100644 --- a/arch/powerpc/cpu/mpc8xx/Kconfig +++ b/arch/powerpc/cpu/mpc8xx/Kconfig @@ -7,9 +7,6 @@ config SYS_CPU choice prompt "Target select"
-config TARGET_COGENT_MPC8XX - bool "Support cogent_mpc8xx" - config TARGET_TQM823L bool "Support TQM823L"
@@ -48,7 +45,6 @@ config TARGET_TQM885D
endchoice
-source "board/cogent/Kconfig" source "board/tqc/tqm8xx/Kconfig"
endmenu diff --git a/board/cogent/Kconfig b/board/cogent/Kconfig deleted file mode 100644 index 7f34a14..0000000 --- a/board/cogent/Kconfig +++ /dev/null @@ -1,19 +0,0 @@ -if TARGET_COGENT_MPC8260 - -config SYS_BOARD - default "cogent" - -config SYS_CONFIG_NAME - default "cogent_mpc8260" - -endif - -if TARGET_COGENT_MPC8XX - -config SYS_BOARD - default "cogent" - -config SYS_CONFIG_NAME - default "cogent_mpc8xx" - -endif diff --git a/board/cogent/MAINTAINERS b/board/cogent/MAINTAINERS deleted file mode 100644 index 7126015..0000000 --- a/board/cogent/MAINTAINERS +++ /dev/null @@ -1,8 +0,0 @@ -COGENT BOARD -M: Murray Jensen Murray.Jensen@csiro.au -S: Maintained -F: board/cogent/ -F: include/configs/cogent_mpc8260.h -F: configs/cogent_mpc8260_defconfig -F: include/configs/cogent_mpc8xx.h -F: configs/cogent_mpc8xx_defconfig diff --git a/board/cogent/Makefile b/board/cogent/Makefile deleted file mode 100644 index 30fe98d..0000000 --- a/board/cogent/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y := mb.o flash.o dipsw.o lcd.o serial.o # pci.o rtc.o par.o kbm.o diff --git a/board/cogent/README b/board/cogent/README deleted file mode 100644 index 4343f73..0000000 --- a/board/cogent/README +++ /dev/null @@ -1,118 +0,0 @@ -Cogent Modular Architecture configuration ------------------------------------------ - -As the name suggests, the Cogent platform is a modular system where -you have a motherboard into which plugs a cpu module and one or more -i/o modules. This provides very nice flexibility, but makes the -configuration task somewhat harder. - -The possible Cogent motherboards are: - -Code Config Variable Description ----- --------------- ----------- - -CMA101 CONFIG_CMA101 32MB ram, 2 ser, 1 par, rtc, dipsw, - 2x16 lcd, eth(?) -CMA102 CONFIG_CMA102 32MB ram, 2 ser, 1 par, rtc, dipsw, - 2x16 lcd -CMA111 CONFIG_CMA111 32MB ram, 1MB flash, 4 ser, 1 par, - rtc, ps/2 kbd/mse, 2x16 lcd, 2xPCI, - 10/100TP eth -CMA120 CONFIG_CMA120 32MB ram, 1MB flash, 4 ser, 1 par, - rtc, ps/2 kbd/mse, 2x16 lcd, 2xPCI, - 10/100TP eth, 2xPCMCIA, video/lcd-panel -CMA150 CONFIG_CMA150 8MB ram, 1MB flash, 2 ser, 1 par, rtc, - ps/2 kbd/mse, 2x16 lcd - -The possible Cogent PowerPC CPU modules are: - -Code Config Variable Description ----- --------------- ----------- - -CMA278-603EV CONFIG_CMA278_603EV PPC603ev CPU, 66MHz clock, 512K EPROM, - JTAG/COP -CMA278-603ER CONFIG_CMA278_603ER PPC603er CPU, 66MHz clock, 512K EPROM, - JTAG/COP -CMA278-740 CONFIG_CMA278_740 PPC740 CPU, 66MHz clock, 512K EPROM, - JTAG/COP -CMA280-509 CONFIG_CMA280_509 MPC505/509 CPU, 50MHz clock, - 512K EPROM, BDM -CMA282 CONFIG_CMA282 MPC8260 CPU, 66MHz clock, 512K EPROM, - JTAG, 16M RAM, 1 x ser (SMC2), - 1 x 10baseT PHY (SCC4), 1 x 10/100 TP - PHY (FCC1), 2 x 48pin DIN (FCC2 + TDM1) -CMA285 CONFIG_CMA285 MPC801 CPU, 33MHz clock, 512K EPROM, - BDM -CMA286-21 CONFIG_CMA286_21 MPC821 CPU, 66MHz clock, 512K EPROM, - BDM, 16M RAM, 2 x ser (SMC1 + SMC2), - 1 x 10baseT PHY (SCC2) -CMA286-60-OLD CONFIG_CMA286_60_OLD MPC860 CPU, 33MHz clock, 128K EPROM, - BDM -CMA286-60 CONFIG_CMA286_60 MPC860 CPU, 66MHz clock, 512K EPROM, - BDM, 16M RAM, 2 x ser (SMC1 + SMC2), - 1 x 10baseT PHY (SCC2) -CMA286-60P CONFIG_CMA286_60P MPC860P CPU, 66MHz clock, 512K EPROM, - BDM, 16M RAM, 2 x ser (SMC1 + SMC2), - 1 x 10baseT PHY (SCC2) -CMA287-23 CONFIG_CMA287_23 MPC823 CPU, 33MHz clock, 512K EPROM, - BDM -CMA287-50 CONFIG_CMA287_50 MPC850 CPU, 33MHz clock, 512K EPROM, - BDM - -(there are a lot of other cpu modules with ARM, MIPS and M-CORE CPUs, -but we'll worry about those later). - -The possible Cogent CMA I/O Modules are: - -Code Config Variable Description ----- --------------- ----------- - -CMA302 CONFIG_CMA302 up to 16M flash, ps/2 keyboard/mouse -CMA352 CONFIG_CMA352 CMAbus <=> PCI - -Currently supported: - - Motherboards: CMA102 - CPU Modules: CMA286-60-OLD - I/O Modules: CMA302 I/O module - -To configure, perform the usual U-Boot configuration task of editing -"include/config_cogent_mpc8xx.h" and reviewing all the options and -settings in there. In particular, check the chip select values -installed into the memory controller's various option and base -registers - these are set by the defines CONFIG_SYS_CMA_CSn_{BASE,SIZE} and -CONFIG_SYS_{B,O}Rn_PRELIM. Also be careful of the clock settings installed -into the SCCR - via the define CONFIG_SYS_SCCR. Finally, decide whether you -want the serial console on motherboard serial port A or on one of the -8xx SMC ports, and set CONFIG_8xx_CONS_{SMC1,SMC2,NONE} accordingly -(NONE means use Cogent motherboard serial port A). - -Then edit the file "cogent/config.mk". Firstly, set CONFIG_SYS_TEXT_BASE to be -the base address of the EPROM for the CPU module. This should be the -same as the value selected for CONFIG_SYS_MONITOR_BASE in -"include/config_cogent_*.h" (in fact, I have made this automatic via -the -CONFIG_SYS_TEXT_BASE=... option in CPPFLAGS). - -Finally, set the values of the make variables $(CMA_MB) and $(CMA_IOMS). - -$(CMA_MB) is the name of the directory that contains support for your -motherboard. At this stage, only "cma10x" exists, which supports the -CMA101 and CMA102 motherboards - but only selected devices, namely -serial, lcd and dipsw. - -$(CMA_IOMS) is a list of zero or more directories that contain -support for the i/o modules you have installed. At this stage, only -"cma302" exists, which supports the CMA302 flash i/o module - but -only the flash part, not the ps/2 keyboard and mouse interfaces. - -There should be a make variable for each of the above directories, -which is the directory name with "_O" appended. This make variable is -a list of object files to compile from that directory and include in -the library. - - e.g. cma10x_O = serial.o ... - -That's it. Good Luck. - -Murray.Jensen@cmst.csiro.au -August 31, 2000. diff --git a/board/cogent/README.cma286 b/board/cogent/README.cma286 deleted file mode 100644 index 0345fea..0000000 --- a/board/cogent/README.cma286 +++ /dev/null @@ -1,69 +0,0 @@ -CPU module revisions --------------------- - -My cpu module has the model number "CMA286-60-990526-01". My motherboard -has the model number "CMA102-32M-990526-01". These are both fairly old, -and may not reflect current design. In particular, I can see from the -Cogent web site that the CMA286 has been significantly redesigned - it -now has on board RAM (4M), ethernet 10baseT PHY (on SCC2), 2 serial ports -(SMC1 and SMC2), and 48pin DIN for the FEC (if present i.e. MPC860T), and -also the EPROM is 512K. - -My CMA286-60 has none of this, and only 128K EPROM. In addition, the CPU -clock is listed as 66MHz, whereas mine is 33.333MHz. - -Clocks ------- - -Quote from my "CMA286 MPC860/821 User's Manual": - -"When setting up the Periodic Interrupt Timer (PIT), be aware that the -CMA286 places the MPC860/821 in PLL X1 Mode. This means that we feed -a 25MHz clock directly into the MPC860/821. This mode sets the divisor -for the PIT to be 512. In addition, the Time Base Register (TMB) -divisor is set to 16." - -I interpreted this information to mean that EXTCLK is 25MHz and that at -power on reset, MODCK1=1 and MODCK2=0, which selects EXTCLK as the -source for OSCCLK and PITRTCLK, sets RTDIV to 512 and sets MF (the -multiplication factor) to 1 (I assume this is what they mean by X1 -mode above). MF=1 means the cpus internal clock runs at the same -rate as EXTCLK i.e. 25MHz. - -Furthermore, since SCCR[TBS] (the Time Base Source selector bit in the -System Clock and Reset Control register) is set in the cpu initialisation -code, the TMBCLK source is forced to be GCLK2 and the TMBCLK prescale is -forced to be 16. This results in TMBCLK=1562500. - -One problem - since PITRTCLK source is EXTCLK (25Mhz) and RTDIV is 512, -PITRTCLK will be 48828.125 (huh?). Another quote from the MPC860 Users -Manual: - -"When used by the real-time clock (RTC), the PITRTCLK source is first -divided as determined by RTDIV, and then divided in the RTC circuits by -either 8192 or 9600. Therefore, in order for the RTC to count in -seconds, the clock source must satisfy: - - (EXTCLK or OSCM) / [(4 or 512) x (8192 or 9600)] = 1 - -The RTC will operate with other frequencies, but it will not count in -units of seconds." - -Therefore, the internal RTC of the MPC860 is not going to count in -seconds, so we must use the motherboard RTC (if we need a RTC). - -I presume this means that they do not provide a fixed oscillator for -OSCM. The code in get_gclk_freq() assumes PITRTCLK source is OSCM, -RTDIV is 4, and that OSCM/4 is 8192 (i.e. a ~32KHz oscillator). Since -the CMA286-60 doesn't have this (at least mine doesn't) we can't use -the code in get_gclk_freq(). - -Finally, it appears that the internal clock in my CMA286-60 is actually -33.333MHz. Which makes TMBCLK=2083312.5 (another huh?) and -PITRTCLK=65103.515625 (bloody hell!). - -If anyone finds anything wrong with the stuff above, I would appreciate -an email about it. - -Murray Jensen Murray.Jensen@csiro.au -21-Aug-00 diff --git a/board/cogent/dipsw.c b/board/cogent/dipsw.c deleted file mode 100644 index ecfbc25..0000000 --- a/board/cogent/dipsw.c +++ /dev/null @@ -1,50 +0,0 @@ -#include <common.h> -#include "dipsw.h" - -unsigned char -dipsw_raw(void) -{ - return cma_mb_reg_read(&((cma_mb_dipsw *)CMA_MB_DIPSW_BASE)->dip_val); -} - -unsigned char -dipsw_cooked(void) -{ - unsigned char val1, val2, mask1, mask2; - - val1 = dipsw_raw(); - - /* - * we want to mirror the bits because the low bit is switch 1 and high - * bit is switch 8 and also invert them because 1=off and 0=on, according - * to manual. - * - * this makes the value more intuitive i.e. - * - left most, or high, or top, bit is left most switch (1); - * - right most, or low, or bottom, bit is right most switch (8) - * - a set bit means "on" and a clear bit means "off" - */ - - val2 = 0; - for (mask1 = 1 << 7, mask2 = 1; mask1 > 0; mask1 >>= 1, mask2 <<= 1) - if ((val1 & mask1) == 0) - val2 |= mask2; - - return (val2); -} - -void -dipsw_init(void) -{ - unsigned char val, mask; - - val = dipsw_cooked(); - - printf("|"); - for (mask = 1 << 7; mask > 0; mask >>= 1) - if (val & mask) - printf("on |"); - else - printf("off|"); - printf("\n"); -} diff --git a/board/cogent/dipsw.h b/board/cogent/dipsw.h deleted file mode 100644 index 4f52fd4..0000000 --- a/board/cogent/dipsw.h +++ /dev/null @@ -1,3 +0,0 @@ -extern unsigned char dipsw_raw(void); -extern unsigned char dipsw_cooked(void); -extern void dipsw_init(void); diff --git a/board/cogent/flash.c b/board/cogent/flash.c deleted file mode 100644 index 1da8f10..0000000 --- a/board/cogent/flash.c +++ /dev/null @@ -1,633 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include "flash.h" -#include <linux/compiler.h> - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH chips */ - -#if defined(CONFIG_ENV_IS_IN_FLASH) -# ifndef CONFIG_ENV_ADDR -# define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET) -# endif -# ifndef CONFIG_ENV_SIZE -# define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -# endif -# ifndef CONFIG_ENV_SECT_SIZE -# define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE -# endif -#endif - -/*----------------------------------------------------------------------- - * Functions - */ -static int write_word (flash_info_t *info, ulong dest, ulong data); - -/*----------------------------------------------------------------------- - */ - - -#if defined(CONFIG_CMA302) - -/* - * probe for the existence of flash at address "addr" - * 0 = yes, 1 = bad Manufacturer's Id, 2 = bad Device Id - */ -static int -c302f_probe_word(c302f_addr_t addr) -{ - /* reset the flash */ - *addr = C302F_BNK_CMD_RST; - - /* check the manufacturer id */ - *addr = C302F_BNK_CMD_RD_ID; - if (*C302F_BNK_ADDR_MAN(addr) != C302F_BNK_RD_ID_MAN) - return 1; - - /* check the device id */ - *addr = C302F_BNK_CMD_RD_ID; - if (*C302F_BNK_ADDR_DEV(addr) != C302F_BNK_RD_ID_DEV) - return 2; - -#ifdef FLASH_DEBUG - { - int i; - - printf("\nMaster Lock Config = 0x%08lx\n", - *C302F_BNK_ADDR_CFGM(addr)); - for (i = 0; i < C302F_BNK_NBLOCKS; i++) - printf("Block %2d Lock Config = 0x%08lx\n", - i, *C302F_BNK_ADDR_CFG(i, addr)); - } -#endif - - /* reset the flash again */ - *addr = C302F_BNK_CMD_RST; - - return 0; -} - -/* - * probe for Cogent CMA302 flash module at address "base" and store - * info for any found into flash_info entry "fip". Must find at least - * one bank. - */ -static void -c302f_probe(flash_info_t *fip, c302f_addr_t base) -{ - c302f_addr_t addr, eaddr; - int nbanks; - - fip->size = 0L; - fip->sector_count = 0; - - addr = base; - eaddr = C302F_BNK_ADDR_BASE(addr, C302F_MAX_BANKS); - nbanks = 0; - - while (addr < eaddr) { - c302f_addr_t addrw, eaddrw, addrb; - int i, osc, nsc; - - addrw = addr; - eaddrw = C302F_BNK_ADDR_NEXT_WORD(addrw); - - while (addrw < eaddrw) - if (c302f_probe_word(addrw++) != 0) - goto out; - - /* bank exists - append info for this bank to *fip */ - fip->flash_id = FLASH_MAN_INTEL|FLASH_28F008S5; - fip->size += C302F_BNK_SIZE; - osc = fip->sector_count; - fip->sector_count += C302F_BNK_NBLOCKS; - if ((nsc = fip->sector_count) >= CONFIG_SYS_MAX_FLASH_SECT) - panic("Too many sectors in flash at address 0x%08lx\n", - (unsigned long)base); - - addrb = addr; - for (i = osc; i < nsc; i++) { - fip->start[i] = (ulong)addrb; - fip->protect[i] = 0; - addrb = C302F_BNK_ADDR_NEXT_BLK(addrb); - } - - addr = C302F_BNK_ADDR_NEXT_BNK(addr); - nbanks++; - } - -out: - if (nbanks == 0) - panic("ERROR: no flash found at address 0x%08lx\n", - (unsigned long)base); -} - -static void -c302f_reset(flash_info_t *info, int sect) -{ - c302f_addr_t addrw, eaddrw; - - addrw = (c302f_addr_t)info->start[sect]; - eaddrw = C302F_BNK_ADDR_NEXT_WORD(addrw); - - while (addrw < eaddrw) { -#ifdef FLASH_DEBUG - printf(" writing reset cmd to addr 0x%08lx\n", - (unsigned long)addrw); -#endif - *addrw = C302F_BNK_CMD_RST; - addrw++; - } -} - -static void -c302f_erase_init(flash_info_t *info, int sect) -{ - c302f_addr_t addrw, saddrw, eaddrw; - int flag; - -#ifdef FLASH_DEBUG - printf("0x%08lx C302F_BNK_CMD_PROG\n", C302F_BNK_CMD_PROG); - printf("0x%08lx C302F_BNK_CMD_ERASE1\n", C302F_BNK_CMD_ERASE1); - printf("0x%08lx C302F_BNK_CMD_ERASE2\n", C302F_BNK_CMD_ERASE2); - printf("0x%08lx C302F_BNK_CMD_CLR_STAT\n", C302F_BNK_CMD_CLR_STAT); - printf("0x%08lx C302F_BNK_CMD_RST\n", C302F_BNK_CMD_RST); - printf("0x%08lx C302F_BNK_STAT_RDY\n", C302F_BNK_STAT_RDY); - printf("0x%08lx C302F_BNK_STAT_ERR\n", C302F_BNK_STAT_ERR); -#endif - - saddrw = (c302f_addr_t)info->start[sect]; - eaddrw = C302F_BNK_ADDR_NEXT_WORD(saddrw); - -#ifdef FLASH_DEBUG - printf("erasing sector %d, start addr = 0x%08lx " - "(bank next word addr = 0x%08lx)\n", sect, - (unsigned long)saddrw, (unsigned long)eaddrw); -#endif - - /* Disable intrs which might cause a timeout here */ - flag = disable_interrupts(); - - for (addrw = saddrw; addrw < eaddrw; addrw++) { -#ifdef FLASH_DEBUG - printf(" writing erase cmd to addr 0x%08lx\n", - (unsigned long)addrw); -#endif - *addrw = C302F_BNK_CMD_ERASE1; - *addrw = C302F_BNK_CMD_ERASE2; - } - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); -} - -static int -c302f_erase_poll(flash_info_t *info, int sect) -{ - c302f_addr_t addrw, saddrw, eaddrw; - int sectdone, haderr; - - saddrw = (c302f_addr_t)info->start[sect]; - eaddrw = C302F_BNK_ADDR_NEXT_WORD(saddrw); - - sectdone = 1; - haderr = 0; - - for (addrw = saddrw; addrw < eaddrw; addrw++) { - c302f_word_t stat = *addrw; - -#ifdef FLASH_DEBUG - printf(" checking status at addr " - "0x%08lx [0x%08lx]\n", - (unsigned long)addrw, stat); -#endif - if ((stat & C302F_BNK_STAT_RDY) != C302F_BNK_STAT_RDY) - sectdone = 0; - else if ((stat & C302F_BNK_STAT_ERR) != 0) { - printf(" failed on sector %d " - "(stat = 0x%08lx) at " - "address 0x%08lx\n", - sect, stat, - (unsigned long)addrw); - *addrw = C302F_BNK_CMD_CLR_STAT; - haderr = 1; - } - } - - if (haderr) - return (-1); - else - return (sectdone); -} - -static int -c302f_write_word(c302f_addr_t addr, c302f_word_t value) -{ - c302f_word_t stat; - ulong start; - int flag, retval; - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - *addr = C302F_BNK_CMD_PROG; - - *addr = value; - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - retval = 0; - - /* data polling for D7 */ - start = get_timer (0); - do { - if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - retval = 1; - goto done; - } - stat = *addr; - } while ((stat & C302F_BNK_STAT_RDY) != C302F_BNK_STAT_RDY); - - if ((stat & C302F_BNK_STAT_ERR) != 0) { - printf("flash program failed (stat = 0x%08lx) " - "at address 0x%08lx\n", (ulong)stat, (ulong)addr); - *addr = C302F_BNK_CMD_CLR_STAT; - retval = 3; - } - -done: - /* reset to read mode */ - *addr = C302F_BNK_CMD_RST; - - return (retval); -} - -#endif /* CONFIG_CMA302 */ - -unsigned long -flash_init(void) -{ - unsigned long total; - int i; - __maybe_unused flash_info_t *fip; - - /* Init: no FLASHes known */ - for (i=0; i<CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - } - - fip = &flash_info[0]; - total = 0L; - -#if defined(CONFIG_CMA302) - c302f_probe(fip, (c302f_addr_t)CONFIG_SYS_FLASH_BASE); - total += fip->size; - fip++; -#endif - -#if (CMA_MB_CAPS & CMA_MB_CAP_FLASH) - /* not yet ... - cmbf_probe(fip, (cmbf_addr_t)CMA_MB_FLASH_BASE); - total += fip->size; - fip++; - */ -#endif - - /* - * protect monitor and environment sectors - */ - -#if CONFIG_SYS_MONITOR_BASE == CONFIG_SYS_FLASH_BASE - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE+monitor_flash_len-1, - &flash_info[0]); -#endif - -#ifdef CONFIG_ENV_IS_IN_FLASH - /* ENV protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR+CONFIG_ENV_SECT_SIZE-1, - &flash_info[0]); -#endif - return total; -} - -/*----------------------------------------------------------------------- - */ -void -flash_print_info(flash_info_t *info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_INTEL: printf ("INTEL "); break; - default: printf ("Unknown Vendor "); break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_28F008S5: printf ("28F008S5\n"); - break; - default: printf ("Unknown Chip Type\n"); - break; - } - - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); - - printf (" Sector Start Addresses:"); - for (i=0; i<info->sector_count; ++i) { - if ((i % 4) == 0) - printf ("\n "); - printf (" %2d - %08lX%s", i, - info->start[i], - info->protect[i] ? " (RO)" : " " - ); - } - printf ("\n"); - return; -} - -/*----------------------------------------------------------------------- - */ - - -/*----------------------------------------------------------------------- - */ - -/* - * The following code cannot be run from FLASH! - */ - -int -flash_erase(flash_info_t *info, int s_first, int s_last) -{ - int prot, sect, haderr; - ulong start, now, last; - void (*erase_init)(flash_info_t *, int); - int (*erase_poll)(flash_info_t *, int); - void (*reset)(flash_info_t *, int); - int rcode = 0; - -#ifdef FLASH_DEBUG - printf("\nflash_erase: erase %d sectors (%d to %d incl.) from\n" - " Bank # %d: ", s_last - s_first + 1, s_first, s_last, - (info - flash_info) + 1); - flash_print_info(info); -#endif - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - switch (info->flash_id) { - -#if defined(CONFIG_CMA302) - case FLASH_MAN_INTEL|FLASH_28F008S5: - erase_init = c302f_erase_init; - erase_poll = c302f_erase_poll; - reset = c302f_reset; - break; -#endif - -#if (CMA_MB_CAPS & CMA_MB_CAP_FLASH) - case FLASH_MAN_INTEL|FLASH_28F800_B: - case FLASH_MAN_AMD|FLASH_AM29F800B: - /* not yet ... - erase_init = cmbf_erase_init; - erase_poll = cmbf_erase_poll; - reset = cmbf_reset; - break; - */ -#endif - - default: - printf ("Flash type %08lx not supported - aborted\n", - info->flash_id); - return 1; - } - - prot = 0; - for (sect=s_first; sect<=s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf("- Warning: %d protected sector%s will not be erased!\n", - prot, (prot > 1 ? "s" : "")); - } - - start = get_timer (0); - last = 0; - haderr = 0; - - for (sect = s_first; sect <= s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - ulong estart; - int sectdone; - - (*erase_init)(info, sect); - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - - estart = get_timer(start); - - do { - now = get_timer(start); - - if (now - estart > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout (sect %d)\n", sect); - haderr = 1; - break; - } - -#ifndef FLASH_DEBUG - /* show that we're waiting */ - if ((now - last) > 1000) { /* every second */ - putc ('.'); - last = now; - } -#endif - - sectdone = (*erase_poll)(info, sect); - - if (sectdone < 0) { - haderr = 1; - break; - } - - } while (!sectdone); - - if (haderr) - break; - } - } - - if (haderr > 0) { - printf (" failed\n"); - rcode = 1; - } - else - printf (" done\n"); - - /* reset to read mode */ - for (sect = s_first; sect <= s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - (*reset)(info, sect); - } - } - return rcode; -} - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - * 3 - write error - */ - -int -write_buff(flash_info_t *info, uchar *src, ulong addr, ulong cnt) -{ - ulong cp, wp, data; - int i, l, rc; - ulong start, now, last; - - wp = (addr & ~3); /* get lower word aligned address */ - - /* - * handle unaligned start bytes - */ - if ((l = addr - wp) != 0) { - data = 0; - for (i=0, cp=wp; i<l; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - for (; i<4 && cnt>0; ++i) { - data = (data << 8) | *src++; - --cnt; - ++cp; - } - for (; cnt==0 && i<4; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - - if ((rc = write_word(info, wp, data)) != 0) { - return (rc); - } - wp += 4; - } - - /* - * handle word aligned part - */ - start = get_timer (0); - last = 0; - while (cnt >= 4) { - data = 0; - for (i=0; i<4; ++i) { - data = (data << 8) | *src++; - } - if ((rc = write_word(info, wp, data)) != 0) { - return (rc); - } - wp += 4; - cnt -= 4; - - /* show that we're waiting */ - now = get_timer(start); - if ((now - last) > 1000) { /* every second */ - putc ('.'); - last = now; - } - } - - if (cnt == 0) { - return (0); - } - - /* - * handle unaligned tail bytes - */ - data = 0; - for (i=0, cp=wp; i<4 && cnt>0; ++i, ++cp) { - data = (data << 8) | *src++; - --cnt; - } - for (; i<4; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - - return (write_word(info, wp, data)); -} - -/*----------------------------------------------------------------------- - * Write a word to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - * 3 - write error - */ -static int -write_word(flash_info_t *info, ulong dest, ulong data) -{ - int retval; - - /* Check if Flash is (sufficiently) erased */ - if ((*(ulong *)dest & data) != data) { - return (2); - } - - switch (info->flash_id) { - -#if defined(CONFIG_CMA302) - case FLASH_MAN_INTEL|FLASH_28F008S5: - retval = c302f_write_word((c302f_addr_t)dest, (c302f_word_t)data); - break; -#endif - -#if (CMA_MB_CAPS & CMA_MB_CAP_FLASH) - case FLASH_MAN_INTEL|FLASH_28F800_B: - case FLASH_MAN_AMD|FLASH_AM29F800B: - /* not yet ... - retval = cmbf_write_word((cmbf_addr_t)dest, (cmbf_word_t)data); - */ - retval = 3; - break; -#endif - - default: - printf ("Flash type %08lx not supported - aborted\n", - info->flash_id); - retval = 3; - break; - } - - return (retval); -} - -/*----------------------------------------------------------------------- - */ diff --git a/board/cogent/flash.h b/board/cogent/flash.h deleted file mode 100644 index 0b8d6aa..0000000 --- a/board/cogent/flash.h +++ /dev/null @@ -1,305 +0,0 @@ -/**************** DEFINES for Intel 28F008S5 FLASH chip **********************/ - -/* register addresses, valid only following a I8S5_CMD_RD_ID command */ -#define I8S5_ADDR_MAN 0x00000 /* manufacturer's id */ -#define I8S5_ADDR_DEV 0x00001 /* device id */ -#define I8S5_ADDR_CFGM 0x00003 /* master lock configuration */ -#define I8S5_ADDR_CFG(b) (((b)<<16)|2) /* block lock configuration */ - -/* Commands */ -#define I8S5_CMD_RST 0xFF /* reset flash */ -#define I8S5_CMD_RD_ID 0x90 /* read the id and lock bits */ -#define I8S5_CMD_RD_STAT 0x70 /* read the status register */ -#define I8S5_CMD_CLR_STAT 0x50 /* clear the staus register */ -#define I8S5_CMD_ERASE1 0x20 /* first word for block erase */ -#define I8S5_CMD_ERASE2 0xD0 /* second word for block erase */ -#define I8S5_CMD_PROG 0x40 /* program word command */ -#define I8S5_CMD_LOCK 0x60 /* first word for all lock commands */ -#define I8S5_CMD_SET_LOCK_BLK 0x01 /* 2nd word for set block lock bit */ -#define I8S5_CMD_SET_LOCK_MSTR 0xF1 /* 2nd word for set master lock bit */ -#define I8S5_CMD_CLR_LOCK_BLK 0xD0 /* 2nd word for clear block lock bit */ - -/* status register bits */ -#define I8S5_STAT_DPS 0x02 /* Device Protect Status */ -#define I8S5_STAT_PSS 0x04 /* Program Suspend Status */ -#define I8S5_STAT_VPPS 0x08 /* VPP Status */ -#define I8S5_STAT_PSLBS 0x10 /* Program and Set Lock Bit Status */ -#define I8S5_STAT_ECLBS 0x20 /* Erase and Clear Lock Bit Status */ -#define I8S5_STAT_ESS 0x40 /* Erase Suspend Status */ -#define I8S5_STAT_RDY 0x80 /* Write State Machine Status, 1=rdy */ - -#define I8S5_STAT_ERR (I8S5_STAT_VPPS | I8S5_STAT_DPS | \ - I8S5_STAT_ECLBS | I8S5_STAT_PSLBS) - -/* ID and Lock Configuration */ -#define I8S5_RD_ID_LOCK 0x01 /* Bit 0 of each byte */ -#define I8S5_RD_ID_MAN 0x89 /* Manufacturer code = 0x89 */ -#define I8S5_RD_ID_DEV 0xA6 /* Device code = 0xA6, 28F008S5 */ - -/* dimensions */ -#define I8S5_NBLOCKS 16 /* a 28F008S5 consists of 16 blocks */ -#define I8S5_BLKSZ (64*1024) /* of 64Kbyte each */ -#define I8S5_SIZE (I8S5_BLKSZ * I8S5_NBLOCKS) - -/**************** DEFINES for Intel 28F800B5 FLASH chip **********************/ - -/* register addresses, valid only following a I8S5_CMD_RD_ID command */ -#define I8B5_ADDR_MAN 0x00000 /* manufacturer's id */ -#define I8B5_ADDR_DEV 0x00001 /* device id */ - -/* Commands */ -#define I8B5_CMD_RST 0xFF /* reset flash */ -#define I8B5_CMD_RD_ID 0x90 /* read the id and lock bits */ -#define I8B5_CMD_RD_STAT 0x70 /* read the status register */ -#define I8B5_CMD_CLR_STAT 0x50 /* clear the staus register */ -#define I8B5_CMD_ERASE1 0x20 /* first word for block erase */ -#define I8B5_CMD_ERASE2 0xD0 /* second word for block erase */ -#define I8B5_CMD_PROG 0x40 /* program word command */ - -/* status register bits */ -#define I8B5_STAT_VPPS 0x08 /* VPP Status */ -#define I8B5_STAT_DWS 0x10 /* Program and Set Lock Bit Status */ -#define I8B5_STAT_ES 0x20 /* Erase and Clear Lock Bit Status */ -#define I8B5_STAT_ESS 0x40 /* Erase Suspend Status */ -#define I8B5_STAT_RDY 0x80 /* Write State Machine Status, 1=rdy */ - -#define I8B5_STAT_ERR (I8B5_STAT_VPPS | I8B5_STAT_DWS | I8B5_STAT_ES) - -/* ID Configuration */ -#define I8B5_RD_ID_MAN 0x89 /* Manufacturer code = 0x89 */ -#define I8B5_RD_ID_DEV1 0x889D /* Device code = 0x889D, 28F800B5 */ - -/* dimensions */ -#define I8B5_NBLOCKS 8 /* a 28F008S5 consists of 16 blocks */ -#define I8B5_BLKSZ (128*1024) /* of 64Kbyte each */ -#define I8B5_SIZE (I8B5_BLKSZ * I8B5_NBLOCKS) - -/****************** DEFINES for Cogent CMA302 Flash **************************/ - -/* - * Quoted from the CMA302 manual: - * - * Although the CMA302 supports 64-bit reads, all writes must be done with - * word size only. When programming the CMA302, the FLASH devices appear as 2 - * banks of interleaved, 32-bit wide FLASH. Each 32-bit word consists of four - * 28F008S5 devices. The first bank is accessed when the word address is even, - * while the second bank is accessed when the word address is odd. This must - * be taken into account when programming the desired word. Also, when locking - * blocks, software must lock both banks. The CMA302 does not directly support - * byte writing. Programming and/or erasing individual bytes is done with - * selective use of the Write Command. By not placing the Write Command value - * on a particular byte lane, that byte will not be written with the following - * Write Data. Also, remember that within a byte lane (i.e. D0-7), there are - * two 28F008S5 devices, one for each bank or every other word. - * - * End quote. - * - * Each 28F008S5 is 8Mbit, with 8 bit wide data. i.e. each is 1Mbyte. The - * chips are arranged on the CMA302 in multiples of two banks, each bank having - * 4 chips. Each bank must be accessed as a single 32 bit wide device (i.e. - * aligned on a 32 bit boundary), with each byte lane within the 32 bits (0-3) - * going to each of the 4 chips and the word address selecting the bank, even - * being the low bank and odd the high bank. For 64bit reads, both banks are - * read simultaneously with the second bank on byte lanes 4-7. Each 28F008S5 - * consists of 16 64Kbyte "block"s. Before programming a byte, the block that - * the byte resides within must be erased. So if you want to program contiguous - * memory locations, you must erase all 8 chips at the same time. i.e. the - * flash on the CMA302 can be viewed as a number of 512Kbyte blocks. - * - * Note: I am going to treat banks as 8 Mbytes (1Meg of 64bit words), whereas - * the example code treats them as a pair of interleaved 1 Mbyte x 32bit banks. - */ - -typedef unsigned long c302f_word_t; /* 32 or 64 bit unsigned integer */ -typedef volatile c302f_word_t *c302f_addr_t; -typedef unsigned long c302f_size_t; /* want this big - at least 32 bit */ - -/* layout of banks on cma302 board */ -#define C302F_BNK_WIDTH 8 /* each bank is 8 chips wide */ -#define C302F_BNK_WSHIFT 3 /* log base 2 of C302F_BNK_WIDTH */ -#define C302F_BNK_NBLOCKS I8S5_NBLOCKS -#define C302F_BNK_BLKSZ (I8S5_BLKSZ * C302F_BNK_WIDTH) -#define C302F_BNK_SIZE (I8S5_SIZE * C302F_BNK_WIDTH) - -#define C302F_MAX_BANKS 2 /* up to 2 banks (8M each) on CMA302 */ - -/* align addresses and sizes to bank boundaries */ -#define C302F_BNK_ADDR_ALIGN(a) ((c302f_addr_t)((c302f_size_t)(a) \ - & ~(C302F_BNK_WIDTH - 1))) -#define C302F_BNK_SIZE_ALIGN(s) ((c302f_size_t)C302F_BNK_ADDR_ALIGN( \ - (c302f_size_t)(s) + (C302F_BNK_WIDTH - 1))) - -/* align addresses and sizes to block boundaries */ -#define C302F_BLK_ADDR_ALIGN(a) ((c302f_addr_t)((c302f_size_t)(a) \ - & ~(C302F_BNK_BLKSZ - 1))) -#define C302F_BLK_SIZE_ALIGN(s) ((c302f_size_t)C302F_BLK_ADDR_ALIGN( \ - (c302f_size_t)(s) + (C302F_BNK_BLKSZ - 1))) - -/* add a byte offset to a flash address */ -#define C302F_ADDR_ADD_BYTEOFF(a,o) \ - (c302f_addr_t)((c302f_size_t)(a) + (o)) - -/* get base address of bank b, given flash base address a */ -#define C302F_BNK_ADDR_BASE(a,b) \ - C302F_ADDR_ADD_BYTEOFF((a), \ - (c302f_size_t)(b) * C302F_BNK_SIZE) - -/* adjust an address a (within a bank) to next word, block or bank */ -#define C302F_BNK_ADDR_NEXT_WORD(a) \ - C302F_ADDR_ADD_BYTEOFF((a), C302F_BNK_WIDTH) -#define C302F_BNK_ADDR_NEXT_BLK(a) \ - C302F_ADDR_ADD_BYTEOFF((a), C302F_BNK_BLKSZ) -#define C302F_BNK_ADDR_NEXT_BNK(a) \ - C302F_ADDR_ADD_BYTEOFF((a), C302F_BNK_SIZE) - -/* get bank address of chip register r given a bank base address a */ -#define C302F_BNK_ADDR_I8S5REG(a,r) \ - C302F_ADDR_ADD_BYTEOFF((a), \ - (r) << C302F_BNK_WSHIFT) - -/* make a bank representation for each chip address */ - -#define C302F_BNK_ADDR_MAN(a) C302F_BNK_ADDR_I8S5REG((a), I8S5_ADDR_MAN) -#define C302F_BNK_ADDR_DEV(a) C302F_BNK_ADDR_I8S5REG((a), I8S5_ADDR_DEV) -#define C302F_BNK_ADDR_CFGM(a) C302F_BNK_ADDR_I8S5REG((a), I8S5_ADDR_CFGM) -#define C302F_BNK_ADDR_CFG(b,a) C302F_BNK_ADDR_I8S5REG((a), I8S5_ADDR_CFG(b)) - -/* - * replicate a chip cmd/stat/rd value into each byte position within a word - * so that multiple chips are accessed in a single word i/o operation - * - * this must be as wide as the c302f_word_t type - */ -#define C302F_FILL_WORD(o) (((unsigned long)(o) << 24) | \ - ((unsigned long)(o) << 16) | \ - ((unsigned long)(o) << 8) | \ - (unsigned long)(o)) - -/* make a bank representation for each chip cmd/stat/rd value */ - -/* Commands */ -#define C302F_BNK_CMD_RST C302F_FILL_WORD(I8S5_CMD_RST) -#define C302F_BNK_CMD_RD_ID C302F_FILL_WORD(I8S5_CMD_RD_ID) -#define C302F_BNK_CMD_RD_STAT C302F_FILL_WORD(I8S5_CMD_RD_STAT) -#define C302F_BNK_CMD_CLR_STAT C302F_FILL_WORD(I8S5_CMD_CLR_STAT) -#define C302F_BNK_CMD_ERASE1 C302F_FILL_WORD(I8S5_CMD_ERASE1) -#define C302F_BNK_CMD_ERASE2 C302F_FILL_WORD(I8S5_CMD_ERASE2) -#define C302F_BNK_CMD_PROG C302F_FILL_WORD(I8S5_CMD_PROG) -#define C302F_BNK_CMD_LOCK C302F_FILL_WORD(I8S5_CMD_LOCK) -#define C302F_BNK_CMD_SET_LOCK_BLK C302F_FILL_WORD(I8S5_CMD_SET_LOCK_BLK) -#define C302F_BNK_CMD_SET_LOCK_MSTR C302F_FILL_WORD(I8S5_CMD_SET_LOCK_MSTR) -#define C302F_BNK_CMD_CLR_LOCK_BLK C302F_FILL_WORD(I8S5_CMD_CLR_LOCK_BLK) - -/* status register bits */ -#define C302F_BNK_STAT_DPS C302F_FILL_WORD(I8S5_STAT_DPS) -#define C302F_BNK_STAT_PSS C302F_FILL_WORD(I8S5_STAT_PSS) -#define C302F_BNK_STAT_VPPS C302F_FILL_WORD(I8S5_STAT_VPPS) -#define C302F_BNK_STAT_PSLBS C302F_FILL_WORD(I8S5_STAT_PSLBS) -#define C302F_BNK_STAT_ECLBS C302F_FILL_WORD(I8S5_STAT_ECLBS) -#define C302F_BNK_STAT_ESS C302F_FILL_WORD(I8S5_STAT_ESS) -#define C302F_BNK_STAT_RDY C302F_FILL_WORD(I8S5_STAT_RDY) - -#define C302F_BNK_STAT_ERR C302F_FILL_WORD(I8S5_STAT_ERR) - -/* ID and Lock Configuration */ -#define C302F_BNK_RD_ID_LOCK C302F_FILL_WORD(I8S5_RD_ID_LOCK) -#define C302F_BNK_RD_ID_MAN C302F_FILL_WORD(I8S5_RD_ID_MAN) -#define C302F_BNK_RD_ID_DEV C302F_FILL_WORD(I8S5_RD_ID_DEV) - -/*************** DEFINES for Cogent Motherboard Flash ************************/ - -typedef unsigned short cmbf_word_t; /* 16 bit unsigned integer */ -typedef volatile cmbf_word_t *cmbf_addr_t; -typedef unsigned long cmbf_size_t; /* want this big - at least 32 bit */ - -/* layout of banks on cogent motherboard - only 1 bank, 16 bit wide */ -#define CMBF_BNK_WIDTH 1 /* each bank is one chip wide */ -#define CMBF_BNK_WSHIFT 0 /* log base 2 of CMBF_BNK_WIDTH */ -#define CMBF_BNK_NBLOCKS I8B5_NBLOCKS -#define CMBF_BNK_BLKSZ (I8B5_BLKSZ * CMBF_BNK_WIDTH) -#define CMBF_BNK_SIZE (I8B5_SIZE * CMBF_BNK_WIDTH) - -#define CMBF_MAX_BANKS 1 /* only 1 x 1Mbyte bank on cogent m/b */ - -/* align addresses and sizes to bank boundaries */ -#define CMBF_BNK_ADDR_ALIGN(a) ((c302f_addr_t)((c302f_size_t)(a) \ - & ~(CMBF_BNK_WIDTH - 1))) -#define CMBF_BNK_SIZE_ALIGN(s) ((c302f_size_t)CMBF_BNK_ADDR_ALIGN( \ - (c302f_size_t)(s) + (CMBF_BNK_WIDTH - 1))) - -/* align addresses and sizes to block boundaries */ -#define CMBF_BLK_ADDR_ALIGN(a) ((c302f_addr_t)((c302f_size_t)(a) \ - & ~(CMBF_BNK_BLKSZ - 1))) -#define CMBF_BLK_SIZE_ALIGN(s) ((c302f_size_t)CMBF_BLK_ADDR_ALIGN( \ - (c302f_size_t)(s) + (CMBF_BNK_BLKSZ - 1))) - -/* add a byte offset to a flash address */ -#define CMBF_ADDR_ADD_BYTEOFF(a,o) \ - (c302f_addr_t)((c302f_size_t)(a) + (o)) - -/* get base address of bank b, given flash base address a */ -#define CMBF_BNK_ADDR_BASE(a,b) \ - CMBF_ADDR_ADD_BYTEOFF((a), \ - (c302f_size_t)(b) * CMBF_BNK_SIZE) - -/* adjust an address a (within a bank) to next word, block or bank */ -#define CMBF_BNK_ADDR_NEXT_WORD(a) \ - CMBF_ADDR_ADD_BYTEOFF((a), CMBF_BNK_WIDTH) -#define CMBF_BNK_ADDR_NEXT_BLK(a) \ - CMBF_ADDR_ADD_BYTEOFF((a), CMBF_BNK_BLKSZ) -#define CMBF_BNK_ADDR_NEXT_BNK(a) \ - CMBF_ADDR_ADD_BYTEOFF((a), CMBF_BNK_SIZE) - -/* get bank address of chip register r given a bank base address a */ -#define CMBF_BNK_ADDR_I8B5REG(a,r) \ - CMBF_ADDR_ADD_BYTEOFF((a), \ - (r) << CMBF_BNK_WSHIFT) - -/* make a bank representation for each chip address */ - -#define CMBF_BNK_ADDR_MAN(a) CMBF_BNK_ADDR_I8B5REG((a), I8B5_ADDR_MAN) -#define CMBF_BNK_ADDR_DEV(a) CMBF_BNK_ADDR_I8B5REG((a), I8B5_ADDR_DEV) -#define CMBF_BNK_ADDR_CFGM(a) CMBF_BNK_ADDR_I8B5REG((a), I8B5_ADDR_CFGM) -#define CMBF_BNK_ADDR_CFG(b,a) CMBF_BNK_ADDR_I8B5REG((a), I8B5_ADDR_CFG(b)) - -/* - * replicate a chip cmd/stat/rd value into each byte position within a word - * so that multiple chips are accessed in a single word i/o operation - * - * this must be as wide as the c302f_word_t type - */ -#define CMBF_FILL_WORD(o) (((unsigned long)(o) << 24) | \ - ((unsigned long)(o) << 16) | \ - ((unsigned long)(o) << 8) | \ - (unsigned long)(o)) - -/* make a bank representation for each chip cmd/stat/rd value */ - -/* Commands */ -#define CMBF_BNK_CMD_RST CMBF_FILL_WORD(I8B5_CMD_RST) -#define CMBF_BNK_CMD_RD_ID CMBF_FILL_WORD(I8B5_CMD_RD_ID) -#define CMBF_BNK_CMD_RD_STAT CMBF_FILL_WORD(I8B5_CMD_RD_STAT) -#define CMBF_BNK_CMD_CLR_STAT CMBF_FILL_WORD(I8B5_CMD_CLR_STAT) -#define CMBF_BNK_CMD_ERASE1 CMBF_FILL_WORD(I8B5_CMD_ERASE1) -#define CMBF_BNK_CMD_ERASE2 CMBF_FILL_WORD(I8B5_CMD_ERASE2) -#define CMBF_BNK_CMD_PROG CMBF_FILL_WORD(I8B5_CMD_PROG) -#define CMBF_BNK_CMD_LOCK CMBF_FILL_WORD(I8B5_CMD_LOCK) -#define CMBF_BNK_CMD_SET_LOCK_BLK CMBF_FILL_WORD(I8B5_CMD_SET_LOCK_BLK) -#define CMBF_BNK_CMD_SET_LOCK_MSTR CMBF_FILL_WORD(I8B5_CMD_SET_LOCK_MSTR) -#define CMBF_BNK_CMD_CLR_LOCK_BLK CMBF_FILL_WORD(I8B5_CMD_CLR_LOCK_BLK) - -/* status register bits */ -#define CMBF_BNK_STAT_DPS CMBF_FILL_WORD(I8B5_STAT_DPS) -#define CMBF_BNK_STAT_PSS CMBF_FILL_WORD(I8B5_STAT_PSS) -#define CMBF_BNK_STAT_VPPS CMBF_FILL_WORD(I8B5_STAT_VPPS) -#define CMBF_BNK_STAT_PSLBS CMBF_FILL_WORD(I8B5_STAT_PSLBS) -#define CMBF_BNK_STAT_ECLBS CMBF_FILL_WORD(I8B5_STAT_ECLBS) -#define CMBF_BNK_STAT_ESS CMBF_FILL_WORD(I8B5_STAT_ESS) -#define CMBF_BNK_STAT_RDY CMBF_FILL_WORD(I8B5_STAT_RDY) - -#define CMBF_BNK_STAT_ERR CMBF_FILL_WORD(I8B5_STAT_ERR) - -/* ID and Lock Configuration */ -#define CMBF_BNK_RD_ID_LOCK CMBF_FILL_WORD(I8B5_RD_ID_LOCK) -#define CMBF_BNK_RD_ID_MAN CMBF_FILL_WORD(I8B5_RD_ID_MAN) -#define CMBF_BNK_RD_ID_DEV CMBF_FILL_WORD(I8B5_RD_ID_DEV) diff --git a/board/cogent/kbm.c b/board/cogent/kbm.c deleted file mode 100644 index 8496402..0000000 --- a/board/cogent/kbm.c +++ /dev/null @@ -1,3 +0,0 @@ -/* keyboard/mouse not implemented yet */ - -int cma_kbm_not_implemented = 1; diff --git a/board/cogent/lcd.c b/board/cogent/lcd.c deleted file mode 100644 index 05ffc4d..0000000 --- a/board/cogent/lcd.c +++ /dev/null @@ -1,245 +0,0 @@ -/* most of this is taken from the file */ -/* hal/powerpc/cogent/current/src/hal_diag.c in the */ -/* Cygnus eCos source. Here is the copyright notice: */ -/* */ -/*============================================================================= */ -/* */ -/* hal_diag.c */ -/* */ -/* HAL diagnostic output code */ -/* */ -/*============================================================================= */ -/*####COPYRIGHTBEGIN#### */ -/* */ -/* ------------------------------------------- */ -/* The contents of this file are subject to the Cygnus eCos Public License */ -/* Version 1.0 (the "License"); you may not use this file except in */ -/* compliance with the License. You may obtain a copy of the License at */ -/* http://sourceware.cygnus.com/ecos */ -/* */ -/* Software distributed under the License is distributed on an "AS IS" */ -/* basis, WITHOUT WARRANTY OF ANY KIND, either express or implied. See the */ -/* License for the specific language governing rights and limitations under */ -/* the License. */ -/* */ -/* The Original Code is eCos - Embedded Cygnus Operating System, released */ -/* September 30, 1998. */ -/* */ -/* The Initial Developer of the Original Code is Cygnus. Portions created */ -/* by Cygnus are Copyright (C) 1998,1999 Cygnus Solutions. All Rights Reserved. */ -/* ------------------------------------------- */ -/* */ -/*####COPYRIGHTEND#### */ -/*============================================================================= */ -/*#####DESCRIPTIONBEGIN#### */ -/* */ -/* Author(s): nickg, jskov */ -/* Contributors: nickg, jskov */ -/* Date: 1999-03-23 */ -/* Purpose: HAL diagnostic output */ -/* Description: Implementations of HAL diagnostic output support. */ -/* */ -/*####DESCRIPTIONEND#### */ -/* */ -/*============================================================================= */ - -/*----------------------------------------------------------------------------- */ -/* Cogent board specific LCD code */ - -#include <common.h> -#include <stdarg.h> -#include "lcd.h" - -static char lines[2][LCD_LINE_LENGTH+1]; -static int curline; -static int linepos; -static int heartbeat_active; -/* make the next two strings exactly LCD_LINE_LENGTH (16) chars long */ -/* pad to the right with spaces if necessary */ -static char init_line0[LCD_LINE_LENGTH+1] = "U-Boot Cogent "; -static char init_line1[LCD_LINE_LENGTH+1] = "mjj, 11 Aug 2000"; - -static inline unsigned char -lcd_read_status(cma_mb_lcd *clp) -{ - /* read the Busy Status Register */ - return (cma_mb_reg_read(&clp->lcd_bsr)); -} - -static inline void -lcd_wait_not_busy(cma_mb_lcd *clp) -{ - /* - * wait for not busy - * Note: It seems that the LCD isn't quite ready to process commands - * when it clears the BUSY flag. Reading the status address an extra - * time seems to give it enough breathing room. - */ - - while (lcd_read_status(clp) & LCD_STAT_BUSY) - ; - - (void)lcd_read_status(clp); -} - -static inline void -lcd_write_command(cma_mb_lcd *clp, unsigned char cmd) -{ - lcd_wait_not_busy(clp); - - /* write the Command Register */ - cma_mb_reg_write(&clp->lcd_cmd, cmd); -} - -static inline void -lcd_write_data(cma_mb_lcd *clp, unsigned char data) -{ - lcd_wait_not_busy(clp); - - /* write the Current Character Register */ - cma_mb_reg_write(&clp->lcd_ccr, data); -} - -static inline void -lcd_dis(int addr, char *string) -{ - cma_mb_lcd *clp = (cma_mb_lcd *)CMA_MB_LCD_BASE; - int pos, linelen; - - linelen = LCD_LINE_LENGTH; - if (heartbeat_active && addr == LCD_LINE0) - linelen--; - - lcd_write_command(clp, LCD_CMD_ADD + addr); - for (pos = 0; *string != '\0' && pos < linelen; pos++) - lcd_write_data(clp, *string++); -} - -void -lcd_init(void) -{ - cma_mb_lcd *clp = (cma_mb_lcd *)CMA_MB_LCD_BASE; - int i; - - /* configure the lcd for 8 bits/char, 2 lines and 5x7 dot matrix */ - lcd_write_command(clp, LCD_CMD_MODE); - - /* turn the LCD display on */ - lcd_write_command(clp, LCD_CMD_DON); - - curline = 0; - linepos = 0; - - for (i = 0; i < LCD_LINE_LENGTH; i++) { - lines[0][i] = init_line0[i]; - lines[1][i] = init_line1[i]; - } - - lines[0][LCD_LINE_LENGTH] = lines[1][LCD_LINE_LENGTH] = 0; - - lcd_dis(LCD_LINE0, lines[0]); - lcd_dis(LCD_LINE1, lines[1]); - - printf("HD44780 2 line x %d char display\n", LCD_LINE_LENGTH); -} - -void -lcd_write_char(const char c) -{ - int i, linelen; - - /* ignore CR */ - if (c == '\r') - return; - - linelen = LCD_LINE_LENGTH; - if (heartbeat_active && curline == 0) - linelen--; - - if (c == '\n') { - lcd_dis(LCD_LINE0, &lines[curline^1][0]); - lcd_dis(LCD_LINE1, &lines[curline][0]); - - /* Do a line feed */ - curline ^= 1; - linelen = LCD_LINE_LENGTH; - if (heartbeat_active && curline == 0) - linelen--; - linepos = 0; - - for (i = 0; i < linelen; i++) - lines[curline][i] = ' '; - - return; - } - - /* Only allow to be output if there is room on the LCD line */ - if (linepos < linelen) - lines[curline][linepos++] = c; -} - -void -lcd_flush(void) -{ - lcd_dis(LCD_LINE1, &lines[curline][0]); -} - -void -lcd_write_string(const char *s) -{ - char *p; - - for (p = (char *)s; *p != '\0'; p++) - lcd_write_char(*p); -} - -void -lcd_printf(const char *fmt, ...) -{ - va_list args; - char buf[CONFIG_SYS_PBSIZE]; - - va_start(args, fmt); - (void)vsprintf(buf, fmt, args); - va_end(args); - - lcd_write_string(buf); -} - -void -lcd_heartbeat(void) -{ - cma_mb_lcd *clp = (cma_mb_lcd *)CMA_MB_LCD_BASE; -#if 0 - static char rotchars[] = { '|', '/', '-', '\' }; -#else - /* HD44780 Rom Code A00 has no backslash */ - static char rotchars[] = { '|', '/', '-', '\315' }; -#endif - static int rotator_index = 0; - - heartbeat_active = 1; - - /* write the address */ - lcd_write_command(clp, LCD_CMD_ADD + LCD_LINE0 + (LCD_LINE_LENGTH - 1)); - - /* write the next char in the sequence */ - lcd_write_data(clp, rotchars[rotator_index]); - - if (++rotator_index >= (sizeof rotchars / sizeof rotchars[0])) - rotator_index = 0; -} - -#ifdef CONFIG_SHOW_ACTIVITY -void board_show_activity (ulong timestamp) -{ -#ifdef CONFIG_STATUS_LED - if ((timestamp % (CONFIG_SYS_HZ / 2)) == 0) - lcd_heartbeat (); -#endif -} - -void show_activity(int arg) -{ -} -#endif diff --git a/board/cogent/lcd.h b/board/cogent/lcd.h deleted file mode 100644 index 9e6157e..0000000 --- a/board/cogent/lcd.h +++ /dev/null @@ -1,84 +0,0 @@ -/* most of this is taken from the file */ -/* hal/powerpc/cogent/current/src/hal_diag.c in the */ -/* Cygnus eCos source. Here is the copyright notice: */ -/* */ -/*============================================================================= */ -/* */ -/* hal_diag.c */ -/* */ -/* HAL diagnostic output code */ -/* */ -/*============================================================================= */ -/*####COPYRIGHTBEGIN#### */ -/* */ -/* ------------------------------------------- */ -/* The contents of this file are subject to the Cygnus eCos Public License */ -/* Version 1.0 (the "License"); you may not use this file except in */ -/* compliance with the License. You may obtain a copy of the License at */ -/* http://sourceware.cygnus.com/ecos */ -/* */ -/* Software distributed under the License is distributed on an "AS IS" */ -/* basis, WITHOUT WARRANTY OF ANY KIND, either express or implied. See the */ -/* License for the specific language governing rights and limitations under */ -/* the License. */ -/* */ -/* The Original Code is eCos - Embedded Cygnus Operating System, released */ -/* September 30, 1998. */ -/* */ -/* The Initial Developer of the Original Code is Cygnus. Portions created */ -/* by Cygnus are Copyright (C) 1998,1999 Cygnus Solutions. All Rights Reserved. */ -/* ------------------------------------------- */ -/* */ -/*####COPYRIGHTEND#### */ -/*============================================================================= */ -/*#####DESCRIPTIONBEGIN#### */ -/* */ -/* Author(s): nickg, jskov */ -/* Contributors: nickg, jskov */ -/* Date: 1999-03-23 */ -/* Purpose: HAL diagnostic output */ -/* Description: Implementations of HAL diagnostic output support. */ -/* */ -/*####DESCRIPTIONEND#### */ -/* */ -/*============================================================================= */ - -/* FEMA 162B 16 character x 2 line LCD */ - -/* status register bit definitions */ -#define LCD_STAT_BUSY 0x80 /* 1 = display busy */ -#define LCD_STAT_ADD 0x7F /* bits 0-6 return current display address */ - -/* command register definitions */ -#define LCD_CMD_RST 0x01 /* clear entire display and reset display addr */ -#define LCD_CMD_HOME 0x02 /* reset display address and reset any shifting */ -#define LCD_CMD_ECL 0x04 /* move cursor left one pos on next data write */ -#define LCD_CMD_ESL 0x05 /* shift display left one pos on next data write */ -#define LCD_CMD_ECR 0x06 /* move cursor right one pos on next data write */ -#define LCD_CMD_ESR 0x07 /* shift disp right one pos on next data write */ -#define LCD_CMD_DOFF 0x08 /* display off, cursor off, blinking off */ -#define LCD_CMD_BL 0x09 /* blink character at current cursor position */ -#define LCD_CMD_CUR 0x0A /* enable cursor on */ -#define LCD_CMD_DON 0x0C /* turn display on */ -#define LCD_CMD_CL 0x10 /* move cursor left one position */ -#define LCD_CMD_SL 0x14 /* shift display left one position */ -#define LCD_CMD_CR 0x18 /* move cursor right one position */ -#define LCD_CMD_SR 0x1C /* shift display right one position */ -#define LCD_CMD_MODE 0x38 /* sets 8 bits, 2 lines, 5x7 characters */ -#define LCD_CMD_ACG 0x40 /* bits 0-5 sets character generator address */ -#define LCD_CMD_ADD 0x80 /* bits 0-6 sets display data addr to line 1 + */ - -/* LCD status values */ -#define LCD_OK 0x00 -#define LCD_ERR 0x01 - -#define LCD_LINE0 0x00 -#define LCD_LINE1 0x40 - -#define LCD_LINE_LENGTH 16 - -extern void lcd_init(void); -extern void lcd_write_char(const char); -extern void lcd_flush(void); -extern void lcd_write_string(const char *); -extern void lcd_printf(const char *, ...); diff --git a/board/cogent/mb.c b/board/cogent/mb.c deleted file mode 100644 index c025643..0000000 --- a/board/cogent/mb.c +++ /dev/null @@ -1,280 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include "dipsw.h" -#include "lcd.h" -#include "rtc.h" -#include "par.h" -#include "pci.h" - -/* ------------------------------------------------------------------------- */ - -#if defined(CONFIG_MPC8260) - -#include <ioports.h> - -/* - * I/O Port configuration table - * - * if conf is 1, then that port pin will be configured at boot time - * according to the five values podr/pdir/ppar/psor/pdat for that entry - */ - -const iop_conf_t iop_conf_tab[4][32] = { - - /* Port A configuration */ - { /* conf ppar psor pdir podr pdat */ - /* PA31 */ {0, 0, 0, 0, 0, 0}, - /* PA30 */ {0, 0, 0, 0, 0, 0}, - /* PA29 */ {0, 0, 0, 0, 0, 0}, - /* PA28 */ {0, 0, 0, 0, 0, 0}, - /* PA27 */ {0, 0, 0, 0, 0, 0}, - /* PA26 */ {0, 0, 0, 0, 0, 0}, - /* PA25 */ {0, 0, 0, 0, 0, 0}, - /* PA24 */ {0, 0, 0, 0, 0, 0}, - /* PA23 */ {0, 0, 0, 0, 0, 0}, - /* PA22 */ {0, 0, 0, 0, 0, 0}, - /* PA21 */ {0, 0, 0, 0, 0, 0}, - /* PA20 */ {0, 0, 0, 0, 0, 0}, - /* PA19 */ {0, 0, 0, 0, 0, 0}, - /* PA18 */ {0, 0, 0, 0, 0, 0}, - /* PA17 */ {0, 0, 0, 0, 0, 0}, - /* PA16 */ {0, 0, 0, 0, 0, 0}, - /* PA15 */ {0, 0, 0, 0, 0, 0}, - /* PA14 */ {0, 0, 0, 0, 0, 0}, - /* PA13 */ {0, 0, 0, 0, 0, 0}, - /* PA12 */ {0, 0, 0, 0, 0, 0}, - /* PA11 */ {0, 0, 0, 0, 0, 0}, - /* PA10 */ {0, 0, 0, 0, 0, 0}, - /* PA9 */ {1, 1, 0, 1, 0, 0}, - /* SMC2 TXD */ - /* PA8 */ {1, 1, 0, 0, 0, 0}, - /* SMC2 RXD */ - /* PA7 */ {0, 0, 0, 0, 0, 0}, - /* PA6 */ {0, 0, 0, 0, 0, 0}, - /* PA5 */ {0, 0, 0, 0, 0, 0}, - /* PA4 */ {0, 0, 0, 0, 0, 0}, - /* PA3 */ {0, 0, 0, 0, 0, 0}, - /* PA2 */ {0, 0, 0, 0, 0, 0}, - /* PA1 */ {0, 0, 0, 0, 0, 0}, - /* PA0 */ {0, 0, 0, 0, 0, 0} - }, - - - { /* conf ppar psor pdir podr pdat */ - /* PB31 */ {0, 0, 0, 0, 0, 0}, - /* PB30 */ {0, 0, 0, 0, 0, 0}, - /* PB29 */ {0, 0, 0, 0, 0, 0}, - /* PB28 */ {0, 0, 0, 0, 0, 0}, - /* PB27 */ {0, 0, 0, 0, 0, 0}, - /* PB26 */ {0, 0, 0, 0, 0, 0}, - /* PB25 */ {0, 0, 0, 0, 0, 0}, - /* PB24 */ {0, 0, 0, 0, 0, 0}, - /* PB23 */ {0, 0, 0, 0, 0, 0}, - /* PB22 */ {0, 0, 0, 0, 0, 0}, - /* PB21 */ {0, 0, 0, 0, 0, 0}, - /* PB20 */ {0, 0, 0, 0, 0, 0}, - /* PB19 */ {0, 0, 0, 0, 0, 0}, - /* PB18 */ {0, 0, 0, 0, 0, 0}, - /* PB17 */ {0, 0, 0, 0, 0, 0}, - /* PB16 */ {0, 0, 0, 0, 0, 0}, - /* PB15 */ {0, 0, 0, 0, 0, 0}, - /* PB14 */ {0, 0, 0, 0, 0, 0}, - /* PB13 */ {0, 0, 0, 0, 0, 0}, - /* PB12 */ {0, 0, 0, 0, 0, 0}, - /* PB11 */ {0, 0, 0, 0, 0, 0}, - /* PB10 */ {0, 0, 0, 0, 0, 0}, - /* PB9 */ {0, 0, 0, 0, 0, 0}, - /* PB8 */ {0, 0, 0, 0, 0, 0}, - /* PB7 */ {0, 0, 0, 0, 0, 0}, - /* PB6 */ {0, 0, 0, 0, 0, 0}, - /* PB5 */ {0, 0, 0, 0, 0, 0}, - /* PB4 */ {0, 0, 0, 0, 0, 0}, - /* PB3 */ {0, 0, 0, 0, 0, 0}, - /* pin doesn't exist */ - /* PB2 */ {0, 0, 0, 0, 0, 0}, - /* pin doesn't exist */ - /* PB1 */ {0, 0, 0, 0, 0, 0}, - /* pin doesn't exist */ - /* PB0 */ {0, 0, 0, 0, 0, 0} - /* pin doesn't exist */ - }, - - - { /* conf ppar psor pdir podr pdat */ - /* PC31 */ {0, 0, 0, 0, 0, 0}, - /* PC30 */ {0, 0, 0, 0, 0, 0}, - /* PC29 */ {0, 0, 0, 0, 0, 0}, - /* PC28 */ {0, 0, 0, 0, 0, 0}, - /* PC27 */ {0, 0, 0, 0, 0, 0}, - /* PC26 */ {0, 0, 0, 0, 0, 0}, - /* PC25 */ {0, 0, 0, 0, 0, 0}, - /* PC24 */ {0, 0, 0, 0, 0, 0}, - /* PC23 */ {0, 0, 0, 0, 0, 0}, - /* PC22 */ {0, 0, 0, 0, 0, 0}, - /* PC21 */ {0, 0, 0, 0, 0, 0}, - /* PC20 */ {0, 0, 0, 0, 0, 0}, - /* PC19 */ {0, 0, 0, 0, 0, 0}, - /* PC18 */ {0, 0, 0, 0, 0, 0}, - /* PC17 */ {0, 0, 0, 0, 0, 0}, - /* PC16 */ {0, 0, 0, 0, 0, 0}, - /* PC15 */ {0, 0, 0, 0, 0, 0}, - /* PC14 */ {0, 0, 0, 0, 0, 0}, - /* PC13 */ {0, 0, 0, 0, 0, 0}, - /* PC12 */ {0, 0, 0, 0, 0, 0}, - /* PC11 */ {0, 0, 0, 0, 0, 0}, - /* PC10 */ {0, 0, 0, 0, 0, 0}, - /* PC9 */ {0, 0, 0, 0, 0, 0}, - /* PC8 */ {0, 0, 0, 0, 0, 0}, - /* PC7 */ {0, 0, 0, 0, 0, 0}, - /* PC6 */ {0, 0, 0, 0, 0, 0}, - /* PC5 */ {0, 0, 0, 0, 0, 0}, - /* PC4 */ {0, 0, 0, 0, 0, 0}, - /* PC3 */ {0, 0, 0, 0, 0, 0}, - /* PC2 */ {0, 0, 0, 0, 0, 0}, - /* PC1 */ {0, 0, 0, 0, 0, 0}, - /* PC0 */ {0, 0, 0, 0, 0, 0} - }, - - - { /* conf ppar psor pdir podr pdat */ - /* PD31 */ {0, 0, 0, 0, 0, 0}, - /* PD30 */ {0, 0, 0, 0, 0, 0}, - /* PD29 */ {0, 0, 0, 0, 0, 0}, - /* PD28 */ {0, 0, 0, 0, 0, 0}, - /* PD27 */ {0, 0, 0, 0, 0, 0}, - /* PD26 */ {0, 0, 0, 0, 0, 0}, - /* PD25 */ {0, 0, 0, 0, 0, 0}, - /* PD24 */ {0, 0, 0, 0, 0, 0}, - /* PD23 */ {0, 0, 0, 0, 0, 0}, - /* PD22 */ {0, 0, 0, 0, 0, 0}, - /* PD21 */ {0, 0, 0, 0, 0, 0}, - /* PD20 */ {0, 0, 0, 0, 0, 0}, - /* PD19 */ {0, 0, 0, 0, 0, 0}, - /* PD18 */ {0, 0, 0, 0, 0, 0}, - /* PD17 */ {0, 0, 0, 0, 0, 0}, - /* PD16 */ {0, 0, 0, 0, 0, 0}, - /* PD15 */ {1, 1, 1, 0, 0, 0}, - /* I2C SDA */ - /* PD14 */ {1, 1, 1, 0, 0, 0}, - /* I2C SCL */ - /* PD13 */ {0, 0, 0, 0, 0, 0}, - /* PD12 */ {0, 0, 0, 0, 0, 0}, - /* PD11 */ {0, 0, 0, 0, 0, 0}, - /* PD10 */ {0, 0, 0, 0, 0, 0}, - /* PD9 */ {1, 1, 0, 1, 0, 0}, - /* SMC1 TXD */ - /* PD8 */ {1, 1, 0, 0, 0, 0}, - /* SMC1 RXD */ - /* PD7 */ {0, 0, 0, 0, 0, 0}, - /* PD6 */ {0, 0, 0, 0, 0, 0}, - /* PD5 */ {0, 0, 0, 0, 0, 0}, - /* PD4 */ {0, 0, 0, 0, 0, 0}, - /* PD3 */ {0, 0, 0, 0, 0, 0}, - /* pin doesn't exist */ - /* PD2 */ {0, 0, 0, 0, 0, 0}, - /* pin doesn't exist */ - /* PD1 */ {0, 0, 0, 0, 0, 0}, - /* pin doesn't exist */ - /* PD0 */ {0, 0, 0, 0, 0, 0} - /* pin doesn't exist */ - } -}; - -#endif /* CONFIG_MPC8260 */ - -/* ------------------------------------------------------------------------- */ - -/* - * Check Board Identity: - */ - -int checkboard (void) -{ - puts ("Board: Cogent " COGENT_MOTHERBOARD " motherboard with a " - COGENT_CPU_MODULE " CPU Module\n"); - return (0); -} - -/* ------------------------------------------------------------------------- */ - -/* - * Miscelaneous platform dependent initialisations while still - * running in flash - */ - -int misc_init_f (void) -{ - printf ("DIPSW: "); - dipsw_init (); - return (0); -} - -/* ------------------------------------------------------------------------- */ - -phys_size_t initdram (int board_type) -{ -#ifdef CONFIG_CMA111 - return (32L * 1024L * 1024L); -#else - unsigned char dipsw_val; - int dual, size0, size1; - long int memsize; - - dipsw_val = dipsw_cooked (); - - dual = dipsw_val & 0x01; - size0 = (dipsw_val & 0x08) >> 3; - size1 = (dipsw_val & 0x04) >> 2; - - if (size0) - if (size1) - memsize = 16L * 1024L * 1024L; - else - memsize = 1L * 1024L * 1024L; - else if (size1) - memsize = 4L * 1024L * 1024L; - else { - printf ("[Illegal dip switch settings - assuming 16Mbyte SIMMs] "); - memsize = 16L * 1024L * 1024L; /* shouldn't happen - guess 16M */ - } - - if (dual) - memsize *= 2L; - - return (memsize); -#endif -} - -/* ------------------------------------------------------------------------- */ - -/* - * Miscelaneous platform dependent initialisations after monitor - * has been relocated into ram - */ - -int misc_init_r (void) -{ - printf ("LCD: "); - lcd_init (); - -#if 0 - printf ("RTC: "); - rtc_init (); - - printf ("PAR: "); - par_init (); - - printf ("KBM: "); - kbm_init (); - - printf ("PCI: "); - pci_init (); -#endif - return (0); -} diff --git a/board/cogent/mb.h b/board/cogent/mb.h deleted file mode 100644 index 1db516f..0000000 --- a/board/cogent/mb.h +++ /dev/null @@ -1,513 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * defines for Cogent Motherboards - */ - -#ifndef _COGENT_MB_H -#define _COGENT_MB_H - -/* - * Cogent Motherboard Address Map - * - * The size of a Cogent motherboard address space is 256 Mbytes (i.e. 28 bits). - * - * The first 32 Mbyte (0x0000000-0x1FFFFFF) is usually RAM. The following - * 3 x 32 Mbyte areas (0x2000000-0x3FFFFFF, 0x4000000-0x5FFFFFF and - * 0x6000000-0x7FFFFFF) are general I/O "slots" (slots 1, 2 and 3). - * Most other motherboard devices have registers mapped into the area - * 0xE000000-0xFFFFFFF (Motherboard I/O slot?). The area 0x8000000-0xDFFFFFF - * is free for whatever. - * - * The location of the motherboard address space in the physical address space - * of the cpu is given by CMA_MB_BASE. This value is determined by the cpu - * module plugged into the motherboard and is configured above. - * - * Motherboard I/O devices mapped into the area (0xE000000-0xFFFFFFF) - * generally only use byte lane 0 (D0-7) for their transfers, i.e. only - * 8 bit, or 1 byte, transfers can take place, so all the registers are - * only 8 bits wide. The exceptions are the motherboard flash, which uses - * byte lanes 0 and 1 (i.e. 16 bits), and the mapped PCI address space. - * - * I/O registers within the mapped motherboard devices are 64 bit aligned - * i.e. they are 8 bytes apart. For big endian addressing, the 8 bit register - * will be at byte 7 (the address + 7). For little endian addressing, the - * register will be at byte 0 (the address + 0). To learn the endianess - * we must include <endian.h> - * - * Take the CMA102 and CMA111 motherboards as examples... - * - * The CMA102 has three CMABus I/O Expansion slots and no PCI bridge. The 3 - * CMABus slots are each mapped directly onto the three general I/O slots. - * - * The CMA111 has only one CMABus I/O Expansion slot, but has a V360EPC PCI - * bridge. The CMABus slot is mapped onto general I/O slot 1. The standard - * PCI Bus space is mapped onto general I/O slot 2, with a small area at the - * top reserved for access to the V360EPC registers (0x5FF0000-0x5FFFFFF). - * I/O slot 3 is unused. The extended PCI Bus space is mapped onto the area - * 0xA000000-0xDFFFFFF. - */ - -#define CMA_MB_RAM_BASE (CONFIG_SYS_CMA_MB_BASE+0x0000000) -#define CMA_MB_RAM_SIZE 0x2000000 /* dip sws set actual size */ - -#if (CMA_MB_CAPS & CMA_MB_CAP_SLOT1) -#define CMA_MB_SLOT1_BASE (CONFIG_SYS_CMA_MB_BASE+0x2000000) -#define CMA_MB_SLOT1_SIZE 0x2000000 -#endif - -#if (CMA_MB_CAPS & CMA_MB_CAP_SLOT2) -#define CMA_MB_SLOT2_BASE (CONFIG_SYS_CMA_MB_BASE+0x4000000) -#define CMA_MB_SLOT2_SIZE 0x2000000 -#endif -#if (CMA_MB_CAPS & CMA_MB_CAP_PCI) -#define CMA_MB_STDPCI_BASE (CONFIG_SYS_CMA_MB_BASE+0x4000000) -#define CMA_MB_STDPCI_SIZE 0x1ff0000 -#define CMA_MB_V360EPC_BASE (CONFIG_SYS_CMA_MB_BASE+0x5ff0000) -#define CMA_MB_V360EPC_SIZE 0x10000 -#endif - -#if (CMA_MB_CAPS & CMA_MB_CAP_SLOT3) -#define CMA_MB_SLOT3_BASE (CONFIG_SYS_CMA_MB_BASE+0x6000000) -#define CMA_MB_SLOT3_SIZE 0x2000000 -#endif - -#if (CMA_MB_CAPS & CMA_MB_CAP_PCI_EXT) -#define CMA_MB_EXTPCI_BASE (CONFIG_SYS_CMA_MB_BASE+0xa000000) -#define CMA_MB_EXTPCI_SIZE 0x4000000 -#endif - -#define CMA_MB_ROMLOW_BASE (CONFIG_SYS_CMA_MB_BASE+0xe000000) -#define CMA_MB_ROMLOW_SIZE 0x800000 -#if (CMA_MB_CAPS & CMA_MB_CAP_FLASH) -#define CMA_MB_FLLOW_EXEC_BASE (CONFIG_SYS_CMA_MB_BASE+0xe000000) -#define CMA_MB_FLLOW_EXEC_SIZE 0x100000 -#define CMA_MB_FLLOW_RDWR_BASE (CONFIG_SYS_CMA_MB_BASE+0xe400000) -#define CMA_MB_FLLOW_RDWR_SIZE 0x400000 -#endif - -#if (CMA_MB_CAPS & CMA_MB_CAP_RTC) -#define CMA_MB_RTC_BASE (CONFIG_SYS_CMA_MB_BASE+0xe800000) -#define CMA_MB_RTC_SIZE 0x4000 -#endif - -#if (CMA_MB_CAPS & CMA_MB_CAP_SERPAR) -#define CMA_MB_SERPAR_BASE (CONFIG_SYS_CMA_MB_BASE+0xe900000) -#define CMA_MB_SERIALB_BASE (CMA_MB_SERPAR_BASE+0x00) -#define CMA_MB_SERIALA_BASE (CMA_MB_SERPAR_BASE+0x40) -#define CMA_MB_PARALLEL_BASE (CMA_MB_SERPAR_BASE+0x80) -#define CMA_MB_SERPAR_SIZE 0xa0 -#endif - -#if (CMA_MB_CAPS & CMA_MB_CAP_KBM) -#define CMA_MB_PKBM_BASE (CONFIG_SYS_CMA_MB_BASE+0xe900100) -#define CMA_MB_PKBM_SIZE 0x10 -#endif - -#if (CMA_MB_CAPS & CMA_MB_CAP_LCD) -#define CMA_MB_LCD_BASE (CONFIG_SYS_CMA_MB_BASE+0xeb00000) -#define CMA_MB_LCD_SIZE 0x10 -#endif - -#define CMA_MB_DIPSW_BASE (CONFIG_SYS_CMA_MB_BASE+0xec00000) -#define CMA_MB_DIPSW_SIZE 0x10 - -#if (CMA_MB_CAPS & (CMA_MB_CAP_SLOT1|CMA_MB_CAP_SER2|CMA_MB_CAP_KBM)) -#define CMA_MB_SLOT1CFG_BASE (CONFIG_SYS_CMA_MB_BASE+0xf100000) -#if (CMA_MB_CAPS & CMA_MB_CAP_SER2) -#define CMA_MB_SER2_BASE (CMA_MB_SLOT1CFG_BASE+0x80) -#define CMA_MB_SER2B_BASE (CMA_MB_SER2_BASE+0x00) -#define CMA_MB_SER2A_BASE (CMA_MB_SER2_BASE+0x40) -#endif -#if defined(CONFIG_CMA302) && defined(CONFIG_CMA302_SLOT1) -#define CMA_MB_S1KBM_BASE (CMA_MB_SLOT1CFG_BASE+0x200) -#endif -#if (CMA_MB_CAPS & CMA_MB_CAP_KBM) && !defined(COGENT_CMA150) -#define CMA_MB_IREQ1STAT_BASE (CMA_MB_SLOT1CFG_BASE+0x100) -#define CMA_MB_AKBM_BASE (CMA_MB_SLOT1CFG_BASE+0x200) -#define CMA_MB_IREQ1MASK_BASE (CMA_MB_SLOT1CFG_BASE+0x300) -#endif -#define CMA_MB_SLOT1CFG_SIZE 0x400 -#endif - -#if (CMA_MB_CAPS & CMA_MB_CAP_SLOT2) -#define CMA_MB_SLOT2CFG_BASE (CONFIG_SYS_CMA_MB_BASE+0xf200000) -#if defined(CONFIG_CMA302) && defined(CONFIG_CMA302_SLOT2) -#define CMA_MB_S2KBM_BASE (CMA_MB_SLOT2CFG_BASE+0x200) -#endif -#define CMA_MB_SLOT2CFG_SIZE 0x400 -#endif - -#if (CMA_MB_CAPS & CMA_MB_CAP_PCI) -#define CMA_MB_PCICTL_BASE (CONFIG_SYS_CMA_MB_BASE+0xf200000) -#define CMA_MB_PCI_V3CTL_BASE (CMA_MB_PCICTL_BASE+0x100) -#define CMA_MB_PCI_IDSEL_BASE (CMA_MB_PCICTL_BASE+0x200) -#define CMA_MB_PCI_IMASK_BASE (CMA_MB_PCICTL_BASE+0x300) -#define CMA_MB_PCI_ISTAT_BASE (CMA_MB_PCICTL_BASE+0x400) -#define CMA_MB_PCI_MBID_BASE (CMA_MB_PCICTL_BASE+0x500) -#define CMA_MB_PCI_MBREV_BASE (CMA_MB_PCICTL_BASE+0x600) -#define CMA_MB_PCICTL_SIZE 0x700 -#endif - -#if (CMA_MB_CAPS & CMA_MB_CAP_SLOT3) -#define CMA_MB_SLOT3CFG_BASE (CONFIG_SYS_CMA_MB_BASE+0xf300000) -#if defined(CONFIG_CMA302) && defined(CONFIG_CMA302_SLOT3) -#define CMA_MB_S3KBM_BASE (CMA_MB_SLOT3CFG_BASE+0x200) -#endif -#define CMA_MB_SLOT3CFG_SIZE 0x400 -#endif - -#define CMA_MB_ROMHIGH_BASE (CONFIG_SYS_CMA_MB_BASE+0xf800000) -#define CMA_MB_ROMHIGH_SIZE 0x800000 -#if (CMA_MB_CAPS & CMA_MB_CAP_FLASH) -#define CMA_MB_FLHIGH_EXEC_BASE (CONFIG_SYS_CMA_MB_BASE+0xf800000) -#define CMA_MB_FLHIGH_EXEC_SIZE 0x100000 -#define CMA_MB_FLHIGH_RDWR_BASE (CONFIG_SYS_CMA_MB_BASE+0xfc00000) -#define CMA_MB_FLHIGH_RDWR_SIZE 0x400000 -#endif - -#if (CMA_MB_CAPS & CMA_MB_CAP_PCI) - -/* PCI Control Register bits */ - -/* V360EPC Control register bits */ -#define CMA_MB_PCI_V3CTL_RESET 0x01 -#define CMA_MB_PCI_V3CTL_EXTADD 0x08 - -/* PCI ID Select register bits */ -#define CMA_MB_PCI_IDSEL_SLOTA 0x01 -#define CMA_MB_PCI_IDSEL_SLOTB 0x02 -#define CMA_MB_PCI_IDSEL_GD82559 0x04 -#define CMA_MB_PCI_IDSEL_B69000 0x08 -#define CMA_MB_PCI_IDSEL_PD6832 0x10 - -/* PCI Interrupt Mask/Status register bits */ -#define CMA_MB_PCI_IMS_INTA 0x01 -#define CMA_MB_PCI_IMS_INTB 0x02 -#define CMA_MB_PCI_IMS_INTC 0x04 -#define CMA_MB_PCI_IMS_INTD 0x08 -#define CMA_MB_PCI_IMS_CBINT 0x10 -#define CMA_MB_PCI_IMS_V3LINT 0x80 - -#endif - -#if (CMA_MB_CAPS & (CMA_MB_CAP_KBM|CMA_MB_CAP_SER2)) && !defined(COGENT_CMA150) - -/* - * IREQ1 Interrupt Mask/Status register bits - * (Note: not available on CMA150 - must poll HT6542B interrupt register) - */ - -#define IREQ1_MINT 0x01 -#define IREQ1_KINT 0x02 -#if (CMA_MB_CAPS & CMA_MB_CAP_SER2) -#define IREQ1_SINT2 0x04 -#define IREQ1_SINT3 0x08 -#endif - -#endif - -#ifndef __ASSEMBLY__ - -#ifdef USE_HOSTCC -#include <endian.h> /* avoid using private kernel header files */ -#else -#include <asm/byteorder.h> /* use U-Boot provided headers */ -#endif - -/* a single CMA10x motherboard i/o register */ -typedef - struct { -#if __BYTE_ORDER == __LITTLE_ENDIAN - unsigned char value; -#endif - unsigned char filler[7]; -#if __BYTE_ORDER == __BIG_ENDIAN - unsigned char value; -#endif - } -cma_mb_reg; - -extern __inline__ unsigned char -cma_mb_reg_read(volatile cma_mb_reg *reg) -{ - unsigned char data = reg->value; - __asm__ __volatile__ ("eieio" : : : "memory"); - return data; -} - -extern __inline__ void -cma_mb_reg_write(volatile cma_mb_reg *reg, unsigned char data) -{ - reg->value = data; - __asm__ __volatile__ ("eieio" : : : "memory"); -} - -#if (CMA_MB_CAPS & CMA_MB_CAP_RTC) - -/* MK48T02 RTC registers */ -typedef - struct { - cma_mb_reg sram[2040];/* Battery-Backed SRAM */ - cma_mb_reg clk_ctl; /* Clock Control Register */ - cma_mb_reg clk_sec; /* Clock Seconds Register */ - cma_mb_reg clk_min; /* Clock Minutes Register */ - cma_mb_reg clk_hour; /* Clock Hour Register */ - cma_mb_reg clk_day; /* Clock Day Register */ - cma_mb_reg clk_date; /* Clock Date Register */ - cma_mb_reg clk_month; /* Clock Month Register */ - cma_mb_reg clk_year; /* Clock Year Register */ - } -cma_mb_rtc; - -#endif - -#if (CMA_MB_CAPS & CMA_MB_CAP_SERPAR) - -/* ST16C522 Serial I/O */ -typedef - struct { - cma_mb_reg ser_rhr; /* Receive Holding Register (R, DLAB=0) */ - cma_mb_reg ser_ier; /* Interrupt Enable Register (R/W, DLAB=0) */ - cma_mb_reg ser_isr; /* Interrupt Status Register (R) */ - cma_mb_reg ser_lcr; /* Line Control Register (R/W) */ - cma_mb_reg ser_mcr; /* Modem Control Register (R/W) */ - cma_mb_reg ser_lsr; /* Line Status Register (R) */ - cma_mb_reg ser_msr; /* Modem Status Register (R/W) */ - cma_mb_reg ser_spr; /* Scratch Pad Register (R/W) */ - } -cma_mb_serial; - -#define ser_thr ser_rhr /* Transmit Holding Register (W, DLAB=0) */ -#define ser_brl ser_rhr /* Baud Rate Divisor Low Byte (R/W, DLAB=1) */ -#define ser_brh ser_ier /* Baud Rate Divisor High Byte (R/W, DLAB=1) */ -#define ser_fcr ser_isr /* FIFO Control Register (W) */ -#define ser_nop ser_lsr /* No Operation (W) */ - -/* ST16C522 Parallel I/O */ -typedef - struct { - cma_mb_reg par_rdr; /* Port Read Data Register (R) */ - cma_mb_reg par_sr; /* Status Register (R) */ - cma_mb_reg par_cmd; /* Command Register (R) */ - } -cma_mb_parallel; - -#define par_wdr par_rdr /* Port Write Data Register (W) */ -#define par_ios par_sr /* I/O Select Register (W) */ -#define par_ctl par_cmd /* Control Register (W) */ - -#endif - -#if (CMA_MB_CAPS & CMA_MB_CAP_KBM) || defined(CONFIG_CMA302) - -/* HT6542B PS/2 Keyboard/Mouse Controller */ -typedef - struct { - cma_mb_reg kbm_rdr; /* Read Data Register (R) */ - cma_mb_reg kbm_sr; /* Status Register (R) */ - } -cma_mb_kbm; - -#define kbm_wdr kbm_rdr /* Write Data Register (W) */ -#define kbm_cmd kbm_sr /* Command Register (W) */ - -#endif - -#if (CMA_MB_CAPS & CMA_MB_CAP_LCD) - -/* HD44780 LCD Display */ -typedef - struct { - cma_mb_reg lcd_ccr; /* Current Character Register (R/W) */ - cma_mb_reg lcd_bsr; /* Busy Status Register (R) */ - } -cma_mb_lcd; - -#define lcd_cmd lcd_bsr /* Command Register (W) */ - -#endif - -/* 8-Position Configuration Switch */ -typedef - struct { - cma_mb_reg dip_val; /* Dip Switch value (R) */ - } -cma_mb_dipsw; - -#if (CMA_MB_CAPS & CMA_MB_CAP_PCI) - -/* V360EPC PCI Bridge */ -typedef - struct { -#if __BYTE_ORDER == __LITTLE_ENDIAN - unsigned short v3_pci_vendor; /* 0x00 */ - unsigned short v3_pci_device; - unsigned short v3_pci_cmd; /* 0x04 */ - unsigned short v3_pci_stat; - unsigned long v3_pci_cc_rev; /* 0x08 */ - unsigned long v3_pci_hdr_cfg; /* 0x0c */ - unsigned long v3_pci_io_base; /* 0x10 */ - unsigned long v3_pci_base0; /* 0x14 */ - unsigned long v3_pci_base1; /* 0x18 */ - unsigned long reserved1[4]; /* 0x1c */ - unsigned short v3_pci_sub_vendor; /* 0x2c */ - unsigned short v3_pci_sub_id; - unsigned long v3_pci_rom; /* 0x30 */ - unsigned long reserved2[2]; /* 0x34 */ - unsigned long v3_pci_bparam; /* 0x3c */ - unsigned long v3_pci_map0; /* 0x40 */ - unsigned long v3_pci_map1; /* 0x44 */ - unsigned long v3_pci_int_stat; /* 0x48 */ - unsigned long v3_pci_int_cfg; /* 0x4c */ - unsigned long reserved3[1]; /* 0x50 */ - unsigned long v3_lb_base0; /* 0x54 */ - unsigned long v3_lb_base1; /* 0x58 */ - unsigned short reserved4; /* 0x5c */ - unsigned short v3_lb_map0; - unsigned short reserved5; /* 0x60 */ - unsigned short v3_lb_map1; - unsigned short v3_lb_base2; /* 0x64 */ - unsigned short v3_lb_map2; - unsigned long v3_lb_size; /* 0x68 */ - unsigned short reserved6; /* 0x6c */ - unsigned short v3_lb_io_base; - unsigned short v3_fifo_cfg; /* 0x70 */ - unsigned short v3_fifo_priority; - unsigned short v3_fifo_stat; /* 0x74 */ - unsigned char v3_lb_istat; - unsigned char v3_lb_imask; - unsigned short v3_system; /* 0x78 */ - unsigned short v3_lb_cfg; - unsigned short v3_pci_cfg; /* 0x7c */ - unsigned short reserved7; - unsigned long v3_dma_pci_addr0; /* 0x80 */ - unsigned long v3_dma_local_addr0; /* 0x84 */ - unsigned long v3_dma_length0:24; /* 0x88 */ - unsigned long v3_dma_csr0:8; - unsigned long v3_dma_ctlb_adr0; /* 0x8c */ - unsigned long v3_dma_pci_addr1; /* 0x90 */ - unsigned long v3_dma_local_addr1; /* 0x94 */ - unsigned long v3_dma_length1:24; /* 0x98 */ - unsigned long v3_dma_csr1:8; - unsigned long v3_dma_ctlb_adr1; /* 0x9c */ - unsigned long v3_i20_mups[8]; /* 0xa0 */ - unsigned char v3_mail_data0; /* 0xc0 */ - unsigned char v3_mail_data1; - unsigned char v3_mail_data2; - unsigned char v3_mail_data3; - unsigned char v3_mail_data4; /* 0xc4 */ - unsigned char v3_mail_data5; - unsigned char v3_mail_data6; - unsigned char v3_mail_data7; - unsigned char v3_mail_data8; /* 0xc8 */ - unsigned char v3_mail_data9; - unsigned char v3_mail_data10; - unsigned char v3_mail_data11; - unsigned char v3_mail_data12; /* 0xcc */ - unsigned char v3_mail_data13; - unsigned char v3_mail_data14; - unsigned char v3_mail_data15; - unsigned short v3_pci_mail_iewr; /* 0xd0 */ - unsigned short v3_pci_mail_ierd; - unsigned short v3_lb_mail_iewr; /* 0xd4 */ - unsigned short v3_lb_mail_ierd; - unsigned short v3_mail_wr_stat; /* 0xd8 */ - unsigned short v3_mail_rd_stat; - unsigned long v3_qba_map; /* 0xdc */ - unsigned long v3_dma_delay:8; /* 0xe0 */ - unsigned long reserved8:24; - unsigned long reserved9[7]; /* 0xe4 */ -#endif -#if __BYTE_ORDER == __BIG_ENDIAN - unsigned short v3_pci_device; /* 0x00 */ - unsigned short v3_pci_vendor; - unsigned short v3_pci_stat; /* 0x04 */ - unsigned short v3_pci_cmd; - unsigned long v3_pci_cc_rev; /* 0x08 */ - unsigned long v3_pci_hdr_cfg; /* 0x0c */ - unsigned long v3_pci_io_base; /* 0x10 */ - unsigned long v3_pci_base0; /* 0x14 */ - unsigned long v3_pci_base1; /* 0x18 */ - unsigned long reserved1[4]; /* 0x1c */ - unsigned short v3_pci_sub_id; /* 0x2c */ - unsigned short v3_pci_sub_vendor; - unsigned long v3_pci_rom; /* 0x30 */ - unsigned long reserved2[2]; /* 0x34 */ - unsigned long v3_pci_bparam; /* 0x3c */ - unsigned long v3_pci_map0; /* 0x40 */ - unsigned long v3_pci_map1; /* 0x44 */ - unsigned long v3_pci_int_stat; /* 0x48 */ - unsigned long v3_pci_int_cfg; /* 0x4c */ - unsigned long reserved3; /* 0x50 */ - unsigned long v3_lb_base0; /* 0x54 */ - unsigned long v3_lb_base1; /* 0x58 */ - unsigned short v3_lb_map0; /* 0x5c */ - unsigned short reserved4; - unsigned short v3_lb_map1; /* 0x60 */ - unsigned short reserved5; - unsigned short v3_lb_map2; /* 0x64 */ - unsigned short v3_lb_base2; - unsigned long v3_lb_size; /* 0x68 */ - unsigned short v3_lb_io_base; /* 0x6c */ - unsigned short reserved6; - unsigned short v3_fifo_priority; /* 0x70 */ - unsigned short v3_fifo_cfg; - unsigned char v3_lb_imask; /* 0x74 */ - unsigned char v3_lb_istat; - unsigned short v3_fifo_stat; - unsigned short v3_lb_cfg; /* 0x78 */ - unsigned short v3_system; - unsigned short reserved7; /* 0x7c */ - unsigned short v3_pci_cfg; - unsigned long v3_dma_pci_addr0; /* 0x80 */ - unsigned long v3_dma_local_addr0; /* 0x84 */ - unsigned long v3_dma_csr0:8; /* 0x88 */ - unsigned long v3_dma_length0:24; - unsigned long v3_dma_ctlb_adr0; /* 0x8c */ - unsigned long v3_dma_pci_addr1; /* 0x90 */ - unsigned long v3_dma_local_addr1; /* 0x94 */ - unsigned long v3_dma_csr1:8; /* 0x98 */ - unsigned long v3_dma_length1:24; - unsigned long v3_dma_ctlb_adr1; /* 0x9c */ - unsigned long v3_i20_mups[8]; /* 0xa0 */ - unsigned char v3_mail_data3; /* 0xc0 */ - unsigned char v3_mail_data2; - unsigned char v3_mail_data1; - unsigned char v3_mail_data0; - unsigned char v3_mail_data7; /* 0xc4 */ - unsigned char v3_mail_data6; - unsigned char v3_mail_data5; - unsigned char v3_mail_data4; - unsigned char v3_mail_data11; /* 0xc8 */ - unsigned char v3_mail_data10; - unsigned char v3_mail_data9; - unsigned char v3_mail_data8; - unsigned char v3_mail_data15; /* 0xcc */ - unsigned char v3_mail_data14; - unsigned char v3_mail_data13; - unsigned char v3_mail_data12; - unsigned short v3_pci_mail_ierd; /* 0xd0 */ - unsigned short v3_pci_mail_iewr; - unsigned short v3_lb_mail_ierd; /* 0xd4 */ - unsigned short v3_lb_mail_iewr; - unsigned short v3_mail_rd_stat; /* 0xd8 */ - unsigned short v3_mail_wr_stat; - unsigned long v3_qba_map; /* 0xdc */ - unsigned long reserved8:24; /* 0xe0 */ - unsigned long v3_dma_delay:8; - unsigned long reserved9[7]; /* 0xe4 */ -#endif - } /* 0x100 */ -cma_mb_v360epc; - -#endif - -#endif /* __ASSEMBLY__ */ - -#endif /* _COGENT_MB_H */ diff --git a/board/cogent/par.c b/board/cogent/par.c deleted file mode 100644 index a03c0f1..0000000 --- a/board/cogent/par.c +++ /dev/null @@ -1,3 +0,0 @@ -/* parallel not implemented yet */ - -int cma_parallel_not_implemented = 1; diff --git a/board/cogent/par.h b/board/cogent/par.h deleted file mode 100644 index 664ae4a..0000000 --- a/board/cogent/par.h +++ /dev/null @@ -1,3 +0,0 @@ -/* parallel not implemented yet */ - -extern int cma_parallel_not_implemented; diff --git a/board/cogent/pci.c b/board/cogent/pci.c deleted file mode 100644 index 0a57c0c..0000000 --- a/board/cogent/pci.c +++ /dev/null @@ -1,3 +0,0 @@ -/* pci not implemented yet */ - -int cma_pci_not_implemented = 1; diff --git a/board/cogent/pci.h b/board/cogent/pci.h deleted file mode 100644 index 35aa354..0000000 --- a/board/cogent/pci.h +++ /dev/null @@ -1,3 +0,0 @@ -/* pci not implemented yet */ - -extern int cma_pci_not_implemented; diff --git a/board/cogent/rtc.c b/board/cogent/rtc.c deleted file mode 100644 index ace9193..0000000 --- a/board/cogent/rtc.c +++ /dev/null @@ -1,3 +0,0 @@ -/* rtc not implemented yet */ - -int cma_rtc_not_implemented = 1; diff --git a/board/cogent/rtc.h b/board/cogent/rtc.h deleted file mode 100644 index 4b55bd2..0000000 --- a/board/cogent/rtc.h +++ /dev/null @@ -1,3 +0,0 @@ -/* rtc not implemented yet */ - -extern int cma_rtc_not_implemented; diff --git a/board/cogent/serial.c b/board/cogent/serial.c deleted file mode 100644 index 95c8120..0000000 --- a/board/cogent/serial.c +++ /dev/null @@ -1,189 +0,0 @@ -/* - * Simple serial driver for Cogent motherboard serial ports - * for use during boot - */ - -#include <common.h> -#include "serial.h" -#include <serial.h> -#include <linux/compiler.h> - -DECLARE_GLOBAL_DATA_PTR; - -#if (CMA_MB_CAPS & CMA_MB_CAP_SERPAR) - -#if (defined(CONFIG_8xx) && defined(CONFIG_8xx_CONS_NONE)) || \ - (defined(CONFIG_MPC8260) && defined(CONFIG_CONS_NONE)) - -#if CONFIG_CONS_INDEX == 1 -#define CMA_MB_SERIAL_BASE CMA_MB_SERIALA_BASE -#elif CONFIG_CONS_INDEX == 2 -#define CMA_MB_SERIAL_BASE CMA_MB_SERIALB_BASE -#elif CONFIG_CONS_INDEX == 3 && (CMA_MB_CAPS & CMA_MB_CAP_SER2) -#define CMA_MB_SERIAL_BASE CMA_MB_SER2A_BASE -#elif CONFIG_CONS_INDEX == 4 && (CMA_MB_CAPS & CMA_MB_CAP_SER2) -#define CMA_MB_SERIAL_BASE CMA_MB_SER2B_BASE -#else -#error CONFIG_CONS_INDEX must be configured for Cogent motherboard serial -#endif - -static int cogent_serial_init(void) -{ - cma_mb_serial *mbsp = (cma_mb_serial *) CMA_MB_SERIAL_BASE; - - cma_mb_reg_write (&mbsp->ser_ier, 0x00); /* turn off interrupts */ - serial_setbrg (); - cma_mb_reg_write (&mbsp->ser_lcr, 0x03); /* 8 data, 1 stop, no parity */ - cma_mb_reg_write (&mbsp->ser_mcr, 0x03); /* RTS/DTR */ - cma_mb_reg_write (&mbsp->ser_fcr, 0x07); /* Clear & enable FIFOs */ - - return (0); -} - -static void cogent_serial_setbrg(void) -{ - cma_mb_serial *mbsp = (cma_mb_serial *) CMA_MB_SERIAL_BASE; - unsigned int divisor; - unsigned char lcr; - - if ((divisor = br_to_div (gd->baudrate)) == 0) - divisor = DEFDIV; - - lcr = cma_mb_reg_read (&mbsp->ser_lcr); - cma_mb_reg_write (&mbsp->ser_lcr, lcr | 0x80); /* Access baud rate(set DLAB) */ - cma_mb_reg_write (&mbsp->ser_brl, divisor & 0xff); - cma_mb_reg_write (&mbsp->ser_brh, (divisor >> 8) & 0xff); - cma_mb_reg_write (&mbsp->ser_lcr, lcr); /* unset DLAB */ -} - -static void cogent_serial_putc(const char c) -{ - cma_mb_serial *mbsp = (cma_mb_serial *) CMA_MB_SERIAL_BASE; - - if (c == '\n') - serial_putc ('\r'); - - while ((cma_mb_reg_read (&mbsp->ser_lsr) & LSR_THRE) == 0); - - cma_mb_reg_write (&mbsp->ser_thr, c); -} - -static int cogent_serial_getc(void) -{ - cma_mb_serial *mbsp = (cma_mb_serial *) CMA_MB_SERIAL_BASE; - - while ((cma_mb_reg_read (&mbsp->ser_lsr) & LSR_DR) == 0); - - return ((int) cma_mb_reg_read (&mbsp->ser_rhr) & 0x7f); -} - -static int cogent_serial_tstc(void) -{ - cma_mb_serial *mbsp = (cma_mb_serial *) CMA_MB_SERIAL_BASE; - - return ((cma_mb_reg_read (&mbsp->ser_lsr) & LSR_DR) != 0); -} - -static struct serial_device cogent_serial_drv = { - .name = "cogent_serial", - .start = cogent_serial_init, - .stop = NULL, - .setbrg = cogent_serial_setbrg, - .putc = cogent_serial_putc, - .puts = default_serial_puts, - .getc = cogent_serial_getc, - .tstc = cogent_serial_tstc, -}; - -void cogent_serial_initialize(void) -{ - serial_register(&cogent_serial_drv); -} - -__weak struct serial_device *default_serial_console(void) -{ - return &cogent_serial_drv; -} -#endif /* CONS_NONE */ - -#if defined(CONFIG_CMD_KGDB) && \ - defined(CONFIG_KGDB_NONE) - -#if CONFIG_KGDB_INDEX == CONFIG_CONS_INDEX -#error Console and kgdb are on the same serial port - this is not supported -#endif - -#if CONFIG_KGDB_INDEX == 1 -#define CMA_MB_KGDB_SER_BASE CMA_MB_SERIALA_BASE -#elif CONFIG_KGDB_INDEX == 2 -#define CMA_MB_KGDB_SER_BASE CMA_MB_SERIALB_BASE -#elif CONFIG_KGDB_INDEX == 3 && (CMA_MB_CAPS & CMA_MB_CAP_SER2) -#define CMA_MB_KGDB_SER_BASE CMA_MB_SER2A_BASE -#elif CONFIG_KGDB_INDEX == 4 && (CMA_MB_CAPS & CMA_MB_CAP_SER2) -#define CMA_MB_KGDB_SER_BASE CMA_MB_SER2B_BASE -#else -#error CONFIG_KGDB_INDEX must be configured for Cogent motherboard serial -#endif - -void kgdb_serial_init (void) -{ - cma_mb_serial *mbsp = (cma_mb_serial *) CMA_MB_KGDB_SER_BASE; - unsigned int divisor; - - if ((divisor = br_to_div (CONFIG_KGDB_BAUDRATE)) == 0) - divisor = DEFDIV; - - cma_mb_reg_write (&mbsp->ser_ier, 0x00); /* turn off interrupts */ - cma_mb_reg_write (&mbsp->ser_lcr, 0x80); /* Access baud rate(set DLAB) */ - cma_mb_reg_write (&mbsp->ser_brl, divisor & 0xff); - cma_mb_reg_write (&mbsp->ser_brh, (divisor >> 8) & 0xff); - cma_mb_reg_write (&mbsp->ser_lcr, 0x03); /* 8 data, 1 stop, no parity */ - cma_mb_reg_write (&mbsp->ser_mcr, 0x03); /* RTS/DTR */ - cma_mb_reg_write (&mbsp->ser_fcr, 0x07); /* Clear & enable FIFOs */ - - printf ("[on cma10x serial port B] "); -} - -void putDebugChar (int c) -{ - cma_mb_serial *mbsp = (cma_mb_serial *) CMA_MB_KGDB_SER_BASE; - - while ((cma_mb_reg_read (&mbsp->ser_lsr) & LSR_THRE) == 0); - - cma_mb_reg_write (&mbsp->ser_thr, c & 0xff); -} - -void putDebugStr (const char *str) -{ - while (*str != '\0') { - if (*str == '\n') - putDebugChar ('\r'); - putDebugChar (*str++); - } -} - -int getDebugChar (void) -{ - cma_mb_serial *mbsp = (cma_mb_serial *) CMA_MB_KGDB_SER_BASE; - - while ((cma_mb_reg_read (&mbsp->ser_lsr) & LSR_DR) == 0); - - return ((int) cma_mb_reg_read (&mbsp->ser_rhr) & 0x7f); -} - -void kgdb_interruptible (int yes) -{ - cma_mb_serial *mbsp = (cma_mb_serial *) CMA_MB_KGDB_SER_BASE; - - if (yes == 1) { - printf ("kgdb: turning serial ints on\n"); - cma_mb_reg_write (&mbsp->ser_ier, 0xf); - } else { - printf ("kgdb: turning serial ints off\n"); - cma_mb_reg_write (&mbsp->ser_ier, 0x0); - } -} - -#endif /* KGDB && KGDB_NONE */ - -#endif /* CAPS & SERPAR */ diff --git a/board/cogent/serial.h b/board/cogent/serial.h deleted file mode 100644 index 89962d8..0000000 --- a/board/cogent/serial.h +++ /dev/null @@ -1,15 +0,0 @@ -/* Line Status Register bits */ -#define LSR_DR 0x01 /* Data ready */ -#define LSR_OE 0x02 /* Overrun */ -#define LSR_PE 0x04 /* Parity error */ -#define LSR_FE 0x08 /* Framing error */ -#define LSR_BI 0x10 /* Break */ -#define LSR_THRE 0x20 /* Xmit holding register empty */ -#define LSR_TEMT 0x40 /* Xmitter empty */ -#define LSR_ERR 0x80 /* Error */ - -#define CLKRATE 3686400 /* cogent motherboard serial clk = 3.6864MHz */ -#define DEFDIV 1 /* default to 230400 bps */ - -#define br_to_div(br) (CLKRATE / (16 * (br))) -#define div_to_br(div) (CLKRATE / (16 * (div))) diff --git a/board/cogent/u-boot.lds b/board/cogent/u-boot.lds deleted file mode 100644 index 4c63ff2..0000000 --- a/board/cogent/u-boot.lds +++ /dev/null @@ -1,86 +0,0 @@ -/* - * (C) Copyright 2000-2010 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <config.h> -OUTPUT_ARCH(powerpc) - -SECTIONS -{ - /* Read-only sections, merged into text segment: */ - . = + SIZEOF_HEADERS; - .text : - { -#ifdef CONFIG_MPC8260 - arch/powerpc/cpu/mpc8260/start.o (.text*) -#else - arch/powerpc/cpu/mpc8xx/start.o (.text*) - arch/powerpc/cpu/mpc8xx/traps.o (.text*) -#endif - *(.text*) - } - _etext = .; - PROVIDE (etext = .); - .rodata : - { - *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) - } - - /* Read-write section, merged into data segment: */ - . = (. + 0x0FFF) & 0xFFFFF000; - _erotext = .; - PROVIDE (erotext = .); - .reloc : - { - _GOT2_TABLE_ = .; - KEEP(*(.got2)) - KEEP(*(.got)) - PROVIDE(_GLOBAL_OFFSET_TABLE_ = . + 4); - _FIXUP_TABLE_ = .; - KEEP(*(.fixup)) - } - __got2_entries = ((_GLOBAL_OFFSET_TABLE_ - _GOT2_TABLE_) >> 2) - 1; - __fixup_entries = (. - _FIXUP_TABLE_)>>2; - - .data : - { - *(.data*) - *(.sdata*) - } - _edata = .; - PROVIDE (edata = .); - - . = .; - - . = ALIGN(4); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); - } - - - . = .; - __start___ex_table = .; - __ex_table : { *(__ex_table) } - __stop___ex_table = .; - - . = ALIGN(4096); - __init_begin = .; - .text.init : { *(.text.init) } - .data.init : { *(.data.init) } - . = ALIGN(4096); - __init_end = .; - - __bss_start = .; - .bss (NOLOAD) : - { - *(.bss*) - *(.sbss*) - *(COMMON) - . = ALIGN(4); - } - __bss_end = . ; - PROVIDE (end = .); -} diff --git a/board/cogent/u-boot.lds.debug b/board/cogent/u-boot.lds.debug deleted file mode 100644 index b9c84c7..0000000 --- a/board/cogent/u-boot.lds.debug +++ /dev/null @@ -1,121 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -OUTPUT_ARCH(powerpc) -/* Do we need any of these for elf? - __DYNAMIC = 0; */ -SECTIONS -{ - /* Read-only sections, merged into text segment: */ - . = + SIZEOF_HEADERS; - .interp : { *(.interp) } - .hash : { *(.hash) } - .dynsym : { *(.dynsym) } - .dynstr : { *(.dynstr) } - .rel.text : { *(.rel.text) } - .rela.text : { *(.rela.text) } - .rel.data : { *(.rel.data) } - .rela.data : { *(.rela.data) } - .rel.rodata : { *(.rel.rodata) } - .rela.rodata : { *(.rela.rodata) } - .rel.got : { *(.rel.got) } - .rela.got : { *(.rela.got) } - .rel.ctors : { *(.rel.ctors) } - .rela.ctors : { *(.rela.ctors) } - .rel.dtors : { *(.rel.dtors) } - .rela.dtors : { *(.rela.dtors) } - .rel.bss : { *(.rel.bss) } - .rela.bss : { *(.rela.bss) } - .rel.plt : { *(.rel.plt) } - .rela.plt : { *(.rela.plt) } - .init : { *(.init) } - .plt : { *(.plt) } - .text : - { - /* WARNING - the following is hand-optimized to fit within */ - /* the sector layout of our flash chips! XXX FIXME XXX */ - - arch/powerpc/cpu/mpc8xx/start.o (.text) - common/dlmalloc.o (.text) - lib/vsprintf.o (.text) - lib/crc32.o (.text) - - . = env_offset; - common/env_embedded.o(.text) - - *(.text) - *(.got1) - } - _etext = .; - PROVIDE (etext = .); - .rodata : - { - *(.rodata) - *(.rodata1) - *(.rodata.str1.4) - *(.eh_frame) - } - .fini : { *(.fini) } =0 - .ctors : { *(.ctors) } - .dtors : { *(.dtors) } - - /* Read-write section, merged into data segment: */ - . = (. + 0x0FFF) & 0xFFFFF000; - _erotext = .; - PROVIDE (erotext = .); - .reloc : - { - *(.got) - _GOT2_TABLE_ = .; - *(.got2) - _FIXUP_TABLE_ = .; - *(.fixup) - } - __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; - __fixup_entries = (. - _FIXUP_TABLE_)>>2; - - .data : - { - *(.data) - *(.data1) - *(.sdata) - *(.sdata2) - *(.dynamic) - CONSTRUCTORS - } - _edata = .; - PROVIDE (edata = .); - - - . = ALIGN(4); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); - } - - - __start___ex_table = .; - __ex_table : { *(__ex_table) } - __stop___ex_table = .; - - . = ALIGN(4096); - __init_begin = .; - .text.init : { *(.text.init) } - .data.init : { *(.data.init) } - . = ALIGN(4096); - __init_end = .; - - __bss_start = .; - .bss : - { - *(.sbss) *(.scommon) - *(.dynbss) - *(.bss) - *(COMMON) - } - __bss_end = . ; - PROVIDE (end = .); -} diff --git a/configs/cogent_mpc8260_defconfig b/configs/cogent_mpc8260_defconfig deleted file mode 100644 index dc297f1..0000000 --- a/configs/cogent_mpc8260_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_COGENT_MPC8260=y diff --git a/configs/cogent_mpc8xx_defconfig b/configs/cogent_mpc8xx_defconfig deleted file mode 100644 index 2fe7a5a..0000000 --- a/configs/cogent_mpc8xx_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_COGENT_MPC8XX=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 9d6a6b6..c9b4b17 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,8 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +cogent_mpc8260 powerpc mpc8260 - - Murray Jensen Murray.Jensen@csiro.au +cogent_8xx powerpc mpc8xx - - Murray Jensen Murray.Jensen@csiro.au ESTEEM192E powerpc mpc8xx - - Conn Clark clark@esteem.com IP860 powerpc mpc8xx - - Wolfgang Denk wd@denx.de IVML24 powerpc mpc8xx - - Wolfgang Denk wd@denx.de diff --git a/include/configs/cogent_common.h b/include/configs/cogent_common.h deleted file mode 100644 index 1b5d6a5..0000000 --- a/include/configs/cogent_common.h +++ /dev/null @@ -1,192 +0,0 @@ -/* - * (C) Copyright 2000 - * Murray Jensen, CSIRO-MST - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef _CONFIG_COGENT_COMMON_H -#define _CONFIG_COGENT_COMMON_H - -/* - * Cogent Motherboard Capabilities - */ -#define CMA_MB_CAP_SERPAR 0x0001 /* has dual serial+parallel (16C552) */ -#define CMA_MB_CAP_LCD 0x0002 /* has LCD display (HD44780) */ -#define CMA_MB_CAP_FLASH 0x0004 /* has flash (E28F800B or AM29F800BB) */ -#define CMA_MB_CAP_RTC 0x0008 /* has RTC+NVRAM (MK48T02) */ -#define CMA_MB_CAP_ETHER 0x0010 /* has Ethernet (MB86964) */ -#define CMA_MB_CAP_SLOT1 0x0020 /* has CMABus slot 1 */ -#define CMA_MB_CAP_SLOT2 0x0040 /* has CMABus slot 2 */ -#define CMA_MB_CAP_SLOT3 0x0080 /* has CMABus slot 3 */ -#define CMA_MB_CAP_KBM 0x0100 /* has PS/2 keyboard+mouse (HT6542B) */ -#define CMA_MB_CAP_SER2 0x0200 /* has 2nd dual serial (16C2552) */ -#define CMA_MB_CAP_PCI 0x0400 /* has pci bridge (V360EPC) */ -#define CMA_MB_CAP_PCI_EXT 0x0800 /* can access extended pci space */ -#define CMA_MB_CAP_PCI_ETHER 0x1000 /* has 10/100 ether on PCI (GD82559) */ -#define CMA_MB_CAP_PCI_VIDEO 0x2000 /* has video int'face on PCI (B69000) */ -#define CMA_MB_CAP_PCI_CARDBUS 0x4000 /* has Cardbus Ctlr on PCI (PD6832) */ - -/* - * Cogent option sanity checking - */ - -#if defined(CONFIG_MPC821) || defined(CONFIG_MPC823) || \ - defined(CONFIG_MPC850) || defined(CONFIG_MPC860) - -/* - * check a PowerPC 8xx cpu module has been selected - */ - -# if defined(CONFIG_CMA286_21) - -# define COGENT_CPU_MODULE "CMA286-21" - -# elif defined(CONFIG_CMA286_60_OLD) - -# define COGENT_CPU_MODULE "CMA286-60 (old)" - -# elif defined(CONFIG_CMA286_60) - -# define COGENT_CPU_MODULE "CMA286-60" - -# elif defined(CONFIG_CMA286_60P) - -# define COGENT_CPU_MODULE "CMA286-60P" - -# elif defined(CONFIG_CMA287_21) - -# define COGENT_CPU_MODULE "CMA287-21" - -# elif defined(CONFIG_CMA287_50) - -# define COGENT_CPU_MODULE "CMA287-50" - -# else - -# error Cogent CPU Module must be a PowerPC MPC8xx module - -# endif - -#elif defined(CONFIG_MPC8260) - -/* - * check a PowerPC 8260 cpu module has been selected - */ - -# if defined(CONFIG_CMA282) - -# define COGENT_CPU_MODULE "CMA282" - -# else - -# error Cogent CPU Module must be a PowerPC MPC8260 module - -# endif - -#else - -# error CPU type must be PowerPC 8xx or 8260 - -#endif - -/* - * check a motherboard has been selected - * define the motherboard capabilities while we're at it - */ - -#if defined(CONFIG_CMA101) - -# define COGENT_MOTHERBOARD "CMA101" -# define CMA_MB_CAPS (CMA_MB_CAP_SERPAR | CMA_MB_CAP_LCD | \ - CMA_MB_CAP_RTC | CMA_MB_CAP_ETHER | \ - CMA_MB_CAP_SLOT1 | CMA_MB_CAP_SLOT2 | \ - CMA_MB_CAP_SLOT3) -# define CMA_MB_NSLOTS 3 - -#elif defined(CONFIG_CMA102) - -# define COGENT_MOTHERBOARD "CMA102" -# define CMA_MB_CAPS (CMA_MB_CAP_SERPAR | CMA_MB_CAP_LCD | \ - CMA_MB_CAP_RTC | CMA_MB_CAP_SLOT1 | \ - CMA_MB_CAP_SLOT2 | CMA_MB_CAP_SLOT3) -# define CMA_MB_NSLOTS 3 - -#elif defined(CONFIG_CMA110) - -# define COGENT_MOTHERBOARD "CMA110" -# define CMA_MB_CAPS (CMA_MB_CAP_SERPAR | CMA_MB_CAP_LCD | \ - CMA_MB_CAP_FLASH | CMA_MB_CAP_RTC | \ - CMA_MB_CAP_KBM | CMA_MB_CAP_PCI) -# define CMA_MB_NSLOTS 0 - -#elif defined(CONFIG_CMA111) - -# define COGENT_MOTHERBOARD "CMA111" -# define CMA_MB_CAPS (CMA_MB_CAP_SERPAR | CMA_MB_CAP_LCD | \ - CMA_MB_CAP_FLASH | CMA_MB_CAP_RTC | \ - CMA_MB_CAP_SLOT1 | CMA_MB_CAP_KBM | \ - CMA_MB_CAP_PCI | CMA_MB_CAP_PCI_EXT | \ - CMA_MB_CAP_PCI_ETHER) -# define CMA_MB_NSLOTS 1 - -#elif defined(CONFIG_CMA120) - -# define COGENT_MOTHERBOARD "CMA120" -# define CMA_MB_CAPS (CMA_MB_CAP_SERPAR | CMA_MB_CAP_LCD | \ - CMA_MB_CAP_FLASH | CMA_MB_CAP_RTC | \ - CMA_MB_CAP_SLOT1 | CMA_MB_CAP_KBM | \ - CMA_MB_CAP_SER2 | CMA_MB_CAP_PCI | \ - CMA_MB_CAP_PCI_EXT | CMA_MB_CAP_PCI_ETHER | \ - CMA_MB_CAP_PCI_VIDEO | CMA_MB_CAP_PCI_CARDBUS) -# define CMA_MB_NSLOTS 1 - -#elif defined(CONFIG_CMA150) - -# define COGENT_MOTHERBOARD "CMA150" -# define CMA_MB_CAPS (CMA_MB_CAP_SERPAR | CMA_MB_CAP_LCD | \ - CMA_MB_CAP_FLASH | CMA_MB_CAP_RTC | \ - CMA_MB_CAP_KBM) -# define CMA_MB_NSLOTS 0 - -#else - -# error Cogent Motherboard either unsupported or undefined - -#endif - -/* - * check a flash i/o module has been selected if no flash on m/b - */ - -#if defined(CONFIG_CMA302) - -# define COGENT_FLASH_MODULE "CMA302" - -#elif (CMA_MB_CAPS & CMA_MB_CAP_FLASH) == 0 - -# error Cogent Flash I/O module (e.g. CMA302) is required with this Motherboard - -#endif - -/* - * some further sanity checks - */ - -#if (CMA_MB_CAPS & CMA_MB_CAP_PCI) && (CMA_MB_CAPS & CMA_MB_CAP_SLOT2) -#error Cogent Sanity Check: Both Slot2 and PCI are defined -#endif - -#if (CMA_MB_CAPS & CMA_MB_CAP_PCI_EXT) && !(CMA_MB_CAPS & CMA_MB_CAP_PCI) -#error Extended PCI capability defined without PCI capability -#endif - -#if (CMA_MB_CAPS & CMA_MB_CAP_PCI_ETHER) && !(CMA_MB_CAPS & CMA_MB_CAP_PCI) -#error Motherboard ethernet capability defined without PCI capability -#endif - -#if (CMA_MB_CAPS & CMA_MB_CAP_SER2) && !(CMA_MB_CAPS & CMA_MB_CAP_SERPAR) -#error 2nd dual serial capability defined without serial/parallel capability -#endif -#include "../board/cogent/mb.h" -#endif /* _CONFIG_COGENT_COMMON_H */ diff --git a/include/configs/cogent_mpc8260.h b/include/configs/cogent_mpc8260.h deleted file mode 100644 index 02b25c6..0000000 --- a/include/configs/cogent_mpc8260.h +++ /dev/null @@ -1,392 +0,0 @@ -/* - * (C) Copyright 2000 - * Murray Jensen Murray.Jensen@cmst.csiro.au - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * Config header file for Cogent platform using an MPC8xx CPU module - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC8260 1 /* This is an MPC8260 CPU */ -#define CONFIG_COGENT 1 /* using Cogent Modular Architecture */ -#define CONFIG_CPM2 1 /* Has a CPM2 */ - -#define CONFIG_SYS_TEXT_BASE 0xfff00000 - -#define CONFIG_MISC_INIT_F 1 /* Use misc_init_f() */ -#define CONFIG_MISC_INIT_R /* Use misc_init_r() */ - -/* Cogent Modular Architecture options */ -#define CONFIG_CMA282 1 /* ...on a CMA282 CPU module */ -#define CONFIG_CMA111 1 /* ...on a CMA111 motherboard */ - -/* - * select serial console configuration - * - * if either CONFIG_CONS_ON_SMC or CONFIG_CONS_ON_SCC is selected, then - * CONFIG_CONS_INDEX must be set to the channel number (1-2 for SMC, 1-4 - * for SCC). - * - * if CONFIG_CONS_NONE is defined, then the serial console routines must - * defined elsewhere (for example, on the cogent platform, there are serial - * ports on the motherboard which are used for the serial console - see - * cogent/cma101/serial.[ch]). - */ -#define CONFIG_CONS_ON_SMC /* define if console on SMC */ -#undef CONFIG_CONS_ON_SCC /* define if console on SCC */ -#undef CONFIG_CONS_NONE /* define if console on something else*/ -#define CONFIG_CONS_INDEX 1 /* which serial channel for console */ -#undef CONFIG_CONS_USE_EXTC /* SMC/SCC use ext clock not brg_clk */ -#define CONFIG_CONS_EXTC_RATE 3686400 /* SMC/SCC ext clk rate in Hz */ -#define CONFIG_CONS_EXTC_PINSEL 0 /* pin select 0=CLK3/CLK9,1=CLK5/CLK15*/ - -/* - * select ethernet configuration - * - * if either CONFIG_ETHER_ON_SCC or CONFIG_ETHER_ON_FCC is selected, then - * CONFIG_ETHER_INDEX must be set to the channel number (1-4 for SCC, 1-3 - * for FCC) - * - * if CONFIG_ETHER_NONE is defined, then either the ethernet routines must be - * defined elsewhere (as for the console), or CONFIG_CMD_NET must be unset. - */ -#undef CONFIG_ETHER_ON_SCC /* define if ether on SCC */ -#undef CONFIG_ETHER_ON_FCC /* define if ether on FCC */ -#define CONFIG_ETHER_NONE /* define if ether on something else */ -#define CONFIG_ETHER_INDEX 1 /* which channel for ether */ - -/* system clock rate (CLKIN) - equal to the 60x and local bus speed */ -#define CONFIG_8260_CLKIN 66666666 /* in Hz */ - -#if defined(CONFIG_CONS_NONE) || defined(CONFIG_CONS_USE_EXTC) -#define CONFIG_BAUDRATE 230400 -#else -#define CONFIG_BAUDRATE 9600 -#endif - - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_KGDB - -#undef CONFIG_CMD_NET -#undef CONFIG_CMD_NFS - -#ifdef DEBUG -#define CONFIG_BOOTDELAY -1 /* autoboot disabled */ -#else -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ -#endif -#define CONFIG_BOOTCOMMAND "bootm 04080000 04200000" /* autoboot command*/ - -#define CONFIG_BOOTARGS "root=/dev/ram rw" - -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_KGDB_ON_SMC /* define if kgdb on SMC */ -#undef CONFIG_KGDB_ON_SCC /* define if kgdb on SCC */ -#undef CONFIG_KGDB_NONE /* define if kgdb on something else */ -#define CONFIG_KGDB_INDEX 2 /* which serial channel for kgdb */ -#define CONFIG_KGDB_USE_EXTC /* SMC/SCC use ext clock not brg_clk */ -#define CONFIG_KGDB_EXTC_RATE 3686400 /* serial ext clk rate in Hz */ -#define CONFIG_KGDB_EXTC_PINSEL 0 /* pin select 0=CLK3/CLK9,1=CLK5/CLK15*/ -# if defined(CONFIG_KGDB_NONE) || defined(CONFIG_KGDB_USE_EXTC) -#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port at */ -# else -#define CONFIG_KGDB_BAUDRATE 9600 /* speed to run kgdb serial port at */ -# endif -#endif - -#undef CONFIG_WATCHDOG /* disable platform specific watchdog */ - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x00400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x01c00000 /* 4 ... 28 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 } - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ - -/*----------------------------------------------------------------------- - * Low Level Cogent settings - * if CONFIG_SYS_CMA_CONS_SERIAL is defined, make sure the 8260 CPM serial is not. - * also, make sure CONFIG_CONS_INDEX is still defined - the index will be - * 1 for serialA, 2 for serialB, 3 for ser2A, 4 for ser2B - * (second 2 for CMA120 only) - */ -#define CONFIG_SYS_CMA_MB_BASE 0x00000000 /* base of m/b address space */ - -#include <configs/cogent_common.h> - -#ifdef CONFIG_CONS_NONE -#define CONFIG_SYS_CMA_CONS_SERIAL /* use Cogent motherboard serial for console */ -#endif -#define CONFIG_SYS_CMA_LCD_HEARTBEAT /* define for sec rotator in lcd corner */ -#define CONFIG_SHOW_ACTIVITY - -#if (CMA_MB_CAPS & CMA_MB_CAP_FLASH) -/* - * flash exists on the motherboard - * set these four according to TOP dipsw: - * TOP on => ..._FLLOW_... (boot EPROM space is high so FLASH is low ) - * TOP off => ..._FLHIGH_... (boot EPROM space is low so FLASH is high) - */ -#define CMA_MB_FLASH_EXEC_BASE CMA_MB_FLLOW_EXEC_BASE -#define CMA_MB_FLASH_EXEC_SIZE CMA_MB_FLLOW_EXEC_SIZE -#define CMA_MB_FLASH_RDWR_BASE CMA_MB_FLLOW_RDWR_BASE -#define CMA_MB_FLASH_RDWR_SIZE CMA_MB_FLLOW_RDWR_SIZE -#endif -#define CMA_MB_FLASH_BASE CMA_MB_FLASH_EXEC_BASE -#define CMA_MB_FLASH_SIZE CMA_MB_FLASH_EXEC_SIZE - -/*----------------------------------------------------------------------- - * Hard Reset Configuration Words - * - * if you change bits in the HRCW, you must also change the CONFIG_SYS_* - * defines for the various registers affected by the HRCW e.g. changing - * HRCW_DPPCxx requires you to also change CONFIG_SYS_SIUMCR. - */ -#define CONFIG_SYS_HRCW_MASTER (HRCW_EBM|HRCW_BPS10|HRCW_L2CPC10|HRCW_DPPC11|\ - HRCW_ISB100|HRCW_MMR11|HRCW_MODCK_H0101) -/* no slaves so just duplicate the master hrcw */ -#define CONFIG_SYS_HRCW_SLAVE1 CONFIG_SYS_HRCW_MASTER -#define CONFIG_SYS_HRCW_SLAVE2 CONFIG_SYS_HRCW_MASTER -#define CONFIG_SYS_HRCW_SLAVE3 CONFIG_SYS_HRCW_MASTER -#define CONFIG_SYS_HRCW_SLAVE4 CONFIG_SYS_HRCW_MASTER -#define CONFIG_SYS_HRCW_SLAVE5 CONFIG_SYS_HRCW_MASTER -#define CONFIG_SYS_HRCW_SLAVE6 CONFIG_SYS_HRCW_MASTER -#define CONFIG_SYS_HRCW_SLAVE7 CONFIG_SYS_HRCW_MASTER - -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xF0000000 - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE CMA_MB_RAM_BASE -#ifdef CONFIG_CMA302 -#define CONFIG_SYS_FLASH_BASE CMA_MB_SLOT2_BASE /* cma302 in slot 2 */ -#else -#define CONFIG_SYS_FLASH_BASE CMA_MB_FLASH_BASE /* flash on m/b */ -#endif -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc()*/ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Mem map for Linux*/ - -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max num of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 67 /* max num of sects on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Flash Erase Timeout (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (in ms) */ - -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_ADDR CONFIG_SYS_FLASH_BASE /* Addr of Environment Sector */ -#ifdef CONFIG_CMA302 -#define CONFIG_ENV_SIZE 0x1000 /* Total Size of Environment Sector */ -#define CONFIG_ENV_SECT_SIZE (512*1024) /* see README - env sect real size */ -#else -#define CONFIG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */ -#endif - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC8260 CPU */ -#if defined(CONFIG_CMD_KGDB) -# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value*/ -#endif - -/*----------------------------------------------------------------------- - * HIDx - Hardware Implementation-dependent Registers 2-11 - *----------------------------------------------------------------------- - * HID0 also contains cache control - initially enable both caches and - * invalidate contents, then the final state leaves only the instruction - * cache enabled. Note that Power-On and Hard reset invalidate the caches, - * but Soft reset does not. - * - * HID1 has only read-only information - nothing to set. - */ -#define CONFIG_SYS_HID0_INIT (HID0_ICE|HID0_DCE|HID0_ICFI|HID0_DCI|\ - HID0_IFEM|HID0_ABE) -#define CONFIG_SYS_HID0_FINAL (HID0_ICE|HID0_IFEM|HID0_ABE) -#define CONFIG_SYS_HID2 0 - -/*----------------------------------------------------------------------- - * RMR - Reset Mode Register 5-5 - *----------------------------------------------------------------------- - * turn on Checkstop Reset Enable - */ -#define CONFIG_SYS_RMR RMR_CSRE - -/*----------------------------------------------------------------------- - * BCR - Bus Configuration 4-25 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_BCR BCR_EBM - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 4-31 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_SIUMCR (SIUMCR_DPPC11|SIUMCR_L2CPC10|SIUMCR_MMR11) - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 4-35 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Watchdog & Bus Monitor Timer max, 60x Bus Monitor enable - */ -#if defined(CONFIG_WATCHDOG) -#define CONFIG_SYS_SYPCR (SYPCR_SWTC|SYPCR_BMT|SYPCR_PBME|SYPCR_LBME|\ - SYPCR_SWRI|SYPCR_SWP|SYPCR_SWE) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC|SYPCR_BMT|SYPCR_PBME|SYPCR_LBME|\ - SYPCR_SWRI|SYPCR_SWP) -#endif /* CONFIG_WATCHDOG */ - -/*----------------------------------------------------------------------- - * TMCNTSC - Time Counter Status and Control 4-40 - *----------------------------------------------------------------------- - * Clear once per Second and Alarm Interrupt Status, Set 32KHz timersclk, - * and enable Time Counter - */ -#define CONFIG_SYS_TMCNTSC (TMCNTSC_SEC|TMCNTSC_ALR|TMCNTSC_TCF|TMCNTSC_TCE) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 4-42 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Set 32KHz timersclk, and enable - * Periodic timer - */ -#define CONFIG_SYS_PISCR (PISCR_PS|PISCR_PTF|PISCR_PTE) - -/*----------------------------------------------------------------------- - * SCCR - System Clock Control 9-8 - *----------------------------------------------------------------------- - * Ensure DFBRG is Divide by 16 - */ -#define CONFIG_SYS_SCCR (SCCR_DFBRG01) - -/*----------------------------------------------------------------------- - * RCCR - RISC Controller Configuration 13-7 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RCCR 0 - -#if defined(CONFIG_CMA282) - -/* - * Init Memory Controller: - * - * According to the Cogent manual, only CS0 and CS2 are used - CS0 for EPROM - * and CS2 for (optional) local bus RAM on the CPU module. - * - * Note the motherboard address space (256 Mbyte in size) is connected - * to the 60x Bus and is located starting at address 0. The Hard Reset - * Configuration Word should put the 60x Bus into External Bus Mode, since - * we dont set up any memory controller maps for it (see BCR[EBM], 4-26). - * - * (the *_SIZE vars must be a power of 2) - */ - -#define CONFIG_SYS_CMA_CS0_BASE CONFIG_SYS_TEXT_BASE /* EPROM */ -#define CONFIG_SYS_CMA_CS0_SIZE (1 << 20) -#if 0 -#define CONFIG_SYS_CMA_CS2_BASE 0x10000000 /* Local Bus SDRAM */ -#define CONFIG_SYS_CMA_CS2_SIZE (16 << 20) -#endif - -/* - * CS0 maps the EPROM on the cpu module - * Set it for 10 wait states, address CONFIG_SYS_MONITOR_BASE and size 1M - * - * Note: We must have already transferred control to the final location - * of the EPROM before these are used, because when BR0/OR0 are set, the - * mirror of the eprom at any other addresses will disappear. - */ - -/* base address = CONFIG_SYS_CMA_CS0_BASE, 16-bit, no parity, r/o, gpcm (60x bus) */ -#define CONFIG_SYS_BR0_PRELIM ((CONFIG_SYS_CMA_CS0_BASE&BRx_BA_MSK)|BRx_PS_16|BRx_WP|BRx_V) -/* mask size CONFIG_SYS_CMA_CS0_SIZE, csneg 1/4 early, adr-to-cs 1/2, 10-wait states */ -#define CONFIG_SYS_OR0_PRELIM (P2SZ_TO_AM(CONFIG_SYS_CMA_CS0_SIZE)|\ - ORxG_CSNT|ORxG_ACS_DIV2|ORxG_SCY_10_CLK) - -/* - * CS2 enables the Local Bus SDRAM on the CPU Module - * - * Will leave this unset for the moment, because a) my CPU module has no - * SDRAM installed (it is optional); and b) it will require programming - * one of the UPMs in SDRAM mode - not a trivial job, and hard to get right - * if you can't test it. - */ - -#if 0 -/* base address = CONFIG_SYS_CMA_CS2_BASE, 32-bit, no parity, ??? */ -#define CONFIG_SYS_BR0_PRELIM ((CONFIG_SYS_CMA_CS2_BASE&BRx_BA_MSK)|BRx_PS_32|/*???*/|BRx_V) -/* mask size CONFIG_SYS_CMA_CS2_SIZE, CS time normal, ??? */ -#define CONFIG_SYS_OR2_PRELIM ((~(CONFIG_SYS_CMA_CS2_SIZE-1)&ORx_AM_MSK)|/*???*/) -#endif - -#endif -#endif /* __CONFIG_H */ diff --git a/include/configs/cogent_mpc8xx.h b/include/configs/cogent_mpc8xx.h deleted file mode 100644 index c98b687..0000000 --- a/include/configs/cogent_mpc8xx.h +++ /dev/null @@ -1,349 +0,0 @@ -/* - * (C) Copyright 2000-2010 - * Murray Jensen Murray.Jensen@cmst.csiro.au - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * Config header file for Cogent platform using an MPC8xx CPU module - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC860 1 /* This is an MPC860 CPU */ -#define CONFIG_COGENT 1 /* using Cogent Modular Architecture */ - -#define CONFIG_SYS_TEXT_BASE 0xfff00000 - -#define CONFIG_MISC_INIT_F 1 /* Use misc_init_f() */ -#define CONFIG_MISC_INIT_R /* Use misc_init_r() */ - -/* Cogent Modular Architecture options */ -#define CONFIG_CMA286_60_OLD 1 /* ...on an old CMA286-60 CPU module */ -#define CONFIG_CMA102 1 /* ...on a CMA102 motherboard */ -#define CONFIG_CMA302 1 /* ...with a CMA302 flash I/O module */ - -/* serial console configuration */ -#undef CONFIG_8xx_CONS_SMC1 -#undef CONFIG_8xx_CONS_SMC2 -#define CONFIG_8xx_CONS_NONE /* not on 8xx serial ports (eg on cogent m/b) */ - -#if defined(CONFIG_CMA286_60_OLD) -#define CONFIG_8xx_GCLK_FREQ 33333000 /* define if cant use get_gclk_freq */ -#endif - -#define CONFIG_BAUDRATE 230400 - -#define CONFIG_HARD_I2C /* I2C with hardware support */ -#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_SLAVE 0x7F - - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_KGDB -#define CONFIG_CMD_I2C - -#undef CONFIG_CMD_NET -#undef CONFIG_CMD_NFS - -#if 0 -#define CONFIG_BOOTDELAY -1 /* autoboot disabled */ -#else -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ -#endif -#define CONFIG_BOOTCOMMAND "bootm 04080000 04200000" /* autoboot command*/ - -#define CONFIG_BOOTARGS "root=/dev/ram rw" - -#if defined(CONFIG_CMD_KGDB) -#undef CONFIG_KGDB_ON_SMC /* define if kgdb on SMC */ -#undef CONFIG_KGDB_ON_SCC /* define if kgdb on SCC */ -#define CONFIG_KGDB_NONE /* define if kgdb on something else */ -#define CONFIG_KGDB_INDEX 2 /* which SMC/SCC channel for kgdb */ -#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ -#endif - -#define CONFIG_WATCHDOG /* turn on platform specific watchdog */ - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x00400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x01c00000 /* 4 ... 28 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 } - -#define CONFIG_SYS_ALLOC_DPRAM - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ - -/*----------------------------------------------------------------------- - * Low Level Cogent settings - * if CONFIG_SYS_CMA_CONS_SERIAL is defined, make sure the 8xx CPM serial is not. - * also, make sure CONFIG_CONS_INDEX is still defined - the index will be - * 1 for serialA, 2 for serialB, 3 for ser2A, 4 for ser2B - * (second 2 for CMA120 only) - */ -#define CONFIG_SYS_CMA_MB_BASE 0x00000000 /* base of m/b address space */ - -#include <configs/cogent_common.h> - -#define CONFIG_SYS_CMA_CONS_SERIAL /* use Cogent motherboard serial for console */ -#define CONFIG_CONS_INDEX 1 -#define CONFIG_SYS_CMA_LCD_HEARTBEAT /* define for sec rotator in lcd corner */ -#define CONFIG_SHOW_ACTIVITY -#if (CMA_MB_CAPS & CMA_MB_CAP_FLASH) -/* - * flash exists on the motherboard - * set these four according to TOP dipsw: - * TOP on => ..._FLLOW_... (boot EPROM space is high so FLASH is low ) - * TOP off => ..._FLHIGH_... (boot EPROM space is low so FLASH is high) - */ -#define CMA_MB_FLASH_EXEC_BASE CMA_MB_FLLOW_EXEC_BASE -#define CMA_MB_FLASH_EXEC_SIZE CMA_MB_FLLOW_EXEC_SIZE -#define CMA_MB_FLASH_RDWR_BASE CMA_MB_FLLOW_RDWR_BASE -#define CMA_MB_FLASH_RDWR_SIZE CMA_MB_FLLOW_RDWR_SIZE -#endif -#define CMA_MB_FLASH_BASE CMA_MB_FLASH_EXEC_BASE -#define CMA_MB_FLASH_SIZE CMA_MB_FLASH_EXEC_SIZE - -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xFF000000 - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE CMA_MB_RAM_BASE -#ifdef CONFIG_CMA302 -#define CONFIG_SYS_FLASH_BASE CMA_MB_SLOT2_BASE /* cma302 in slot 2 */ -#else -#define CONFIG_SYS_FLASH_BASE CMA_MB_FLASH_BASE /* flash on m/b */ -#endif -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_MONITOR_LEN (128 << 10) /* Reserve 128 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 67 /* max number of sectors on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ - -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_ADDR CONFIG_SYS_FLASH_BASE /* Addr of Environment Sector */ -#ifdef CONFIG_CMA302 -#define CONFIG_ENV_SIZE 0x1000 /* Total Size of Environment Sector */ -#define CONFIG_ENV_SECT_SIZE (512*1024) /* see README - env sect real size */ -#else -#define CONFIG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */ -#endif -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CACHELINE_SHIFT 4 /* log base 2 of the above value */ -#endif - - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 11-9 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Software & Bus Monitor Timer max, Bus Monitor enable, SW Watchdog freeze - */ -#if defined(CONFIG_WATCHDOG) -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | \ - SYPCR_SWE | SYPCR_SWRI| SYPCR_SWP) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | SYPCR_SWP) -#endif /* CONFIG_WATCHDOG */ - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 11-6 - *----------------------------------------------------------------------- - * PCMCIA config., multi-function pin tri-state - */ -#define CONFIG_SYS_SIUMCR (SIUMCR_DBGC00 | SIUMCR_DBPC00 | SIUMCR_MLRC01) - -/*----------------------------------------------------------------------- - * TBSCR - Time Base Status and Control 11-26 - *----------------------------------------------------------------------- - * Clear Reference Interrupt Status, Timebase freezing enabled - */ -#define CONFIG_SYS_TBSCR (TBSCR_REFA | TBSCR_REFB | TBSCR_TBF) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 11-31 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Interrupt Timer freezing enabled - */ -#define CONFIG_SYS_PISCR (PISCR_PS | PISCR_PITF) - -/*----------------------------------------------------------------------- - * PLPRCR - PLL, Low-Power, and Reset Control Register 15-30 - *----------------------------------------------------------------------- - * Reset PLL lock status sticky bit, timer expired status bit and timer - * interrupt status bit - leave PLL multiplication factor unchanged ! - */ -#define CONFIG_SYS_PLPRCR (PLPRCR_SPLSS | PLPRCR_TEXPS | PLPRCR_TMIST) - -/*----------------------------------------------------------------------- - * SCCR - System Clock and reset Control Register 15-27 - *----------------------------------------------------------------------- - * Set clock output, timebase and RTC source and divider, - * power management and some other internal clocks - */ -#define SCCR_MASK SCCR_EBDF11 -#define CONFIG_SYS_SCCR (SCCR_TBS | SCCR_RTDIV | SCCR_RTSEL | \ - SCCR_COM00 | SCCR_DFSYNC00 | SCCR_DFBRG00 | \ - SCCR_DFNL000 | SCCR_DFNH000 | SCCR_DFLCD000 | \ - SCCR_DFALCD00) - -/*----------------------------------------------------------------------- - * PCMCIA stuff - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_PCMCIA_MEM_ADDR (0xE0000000) -#define CONFIG_SYS_PCMCIA_MEM_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_DMA_ADDR (0xE4000000) -#define CONFIG_SYS_PCMCIA_DMA_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_ATTRB_ADDR (0xE8000000) -#define CONFIG_SYS_PCMCIA_ATTRB_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_IO_ADDR (0xEC000000) -#define CONFIG_SYS_PCMCIA_IO_SIZE ( 64 << 20 ) - -/*----------------------------------------------------------------------- - * - *----------------------------------------------------------------------- - * - */ -/*#define CONFIG_SYS_DER 0x2002000F*/ -#define CONFIG_SYS_DER 0 - -#if defined(CONFIG_CMA286_60_OLD) - -/* - * Init Memory Controller: - * - * NOTE: although the names (CONFIG_SYS_xRn_PRELIM) suggest preliminary settings, - * they are actually the final settings for this cpu/board, because the - * flash and RAM are on the motherboard, accessed via the CMAbus, and the - * mappings are pretty much fixed. - * - * (the *_SIZE vars must be a power of 2) - */ - -#define CONFIG_SYS_CMA_CS0_BASE CONFIG_SYS_TEXT_BASE /* EPROM */ -#define CONFIG_SYS_CMA_CS0_SIZE (1 << 20) -#define CONFIG_SYS_CMA_CS1_BASE CMA_MB_RAM_BASE /* RAM + I/O SLOT 1 */ -#define CONFIG_SYS_CMA_CS1_SIZE (64 << 20) -#define CONFIG_SYS_CMA_CS2_BASE CMA_MB_SLOT2_BASE /* I/O SLOTS 2 + 3 */ -#define CONFIG_SYS_CMA_CS2_SIZE (64 << 20) -#define CONFIG_SYS_CMA_CS3_BASE CMA_MB_ROMLOW_BASE /* M/B I/O */ -#define CONFIG_SYS_CMA_CS3_SIZE (32 << 20) - -/* - * CS0 maps the EPROM on the cpu module - * Set it for 4 wait states, address CONFIG_SYS_MONITOR_BASE and size 1M - * - * Note: We must have already transferred control to the final location - * of the EPROM before these are used, because when BR0/OR0 are set, the - * mirror of the eprom at any other addresses will disappear. - */ - -/* base address = CONFIG_SYS_CMA_CS0_BASE, 16-bit, no parity, r/o, gpcm */ -#define CONFIG_SYS_BR0_PRELIM ((CONFIG_SYS_CMA_CS0_BASE&BR_BA_MSK)|BR_PS_16|BR_WP|BR_V) -/* mask size CONFIG_SYS_CMA_CS0_SIZE, CS time normal, burst inhibit, 4-wait states */ -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_CMA_CS0_SIZE-1)&OR_AM_MSK)|OR_BI|OR_SCY_4_CLK) - -/* - * CS1 maps motherboard DRAM and motherboard I/O slot 1 - * (each 32Mbyte in size) - */ - -/* base address = CONFIG_SYS_CMA_CS1_BASE, 32-bit, no parity, r/w, gpcm */ -#define CONFIG_SYS_BR1_PRELIM ((CONFIG_SYS_CMA_CS1_BASE&BR_BA_MSK)|BR_V) -/* mask size CONFIG_SYS_CMA_CS1_SIZE, CS time normal, burst ok, ext xfer ack */ -#define CONFIG_SYS_OR1_PRELIM ((~(CONFIG_SYS_CMA_CS1_SIZE-1)&OR_AM_MSK)|OR_SETA) - -/* - * CS2 maps motherboard I/O slots 2 and 3 - * (each 32Mbyte in size) - */ - -/* base address = CONFIG_SYS_CMA_CS2_BASE, 32-bit, no parity, r/w, gpcm */ -#define CONFIG_SYS_BR2_PRELIM ((CONFIG_SYS_CMA_CS2_BASE&BR_BA_MSK)|BR_V) -/* mask size CONFIG_SYS_CMA_CS2_SIZE, CS time normal, burst ok, ext xfer ack */ -#define CONFIG_SYS_OR2_PRELIM ((~(CONFIG_SYS_CMA_CS2_SIZE-1)&OR_AM_MSK)|OR_SETA) - -/* - * CS3 maps motherboard I/O - * (32Mbyte in size) - */ - -/* base address = CONFIG_SYS_CMA_CS3_BASE, 32-bit, no parity, r/w, gpcm */ -#define CONFIG_SYS_BR3_PRELIM ((CONFIG_SYS_CMA_CS3_BASE&BR_BA_MSK)|BR_V) -/* mask size CONFIG_SYS_CMA_CS3_SIZE, CS time normal, burst inhibit, ext xfer ack */ -#define CONFIG_SYS_OR3_PRELIM ((~(CONFIG_SYS_CMA_CS3_SIZE-1)&OR_AM_MSK)|OR_BI|OR_SETA) - -#endif -#endif /* __CONFIG_H */
On Mon, Dec 15, 2014 at 11:26:18PM +0900, Masahiro Yamada wrote:
These boards are still non-generic boards.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Murray Jensen Murray.Jensen@csiro.au
This board is still a non-generic board.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Jerry Van Baren gerald.vanbaren@smiths-aerospace.com ---
arch/powerpc/cpu/mpc8260/Kconfig | 4 - board/sacsng/Kconfig | 9 - board/sacsng/MAINTAINERS | 6 - board/sacsng/Makefile | 8 - board/sacsng/clkinit.c | 1009 ------------------------------------ board/sacsng/clkinit.h | 103 ---- board/sacsng/flash.c | 507 ------------------- board/sacsng/ioconfig.h | 217 -------- board/sacsng/sacsng.c | 848 ------------------------------- configs/sacsng_defconfig | 3 - doc/README.scrapyard | 1 + include/configs/sacsng.h | 1038 -------------------------------------- 12 files changed, 1 insertion(+), 3752 deletions(-) delete mode 100644 board/sacsng/Kconfig delete mode 100644 board/sacsng/MAINTAINERS delete mode 100644 board/sacsng/Makefile delete mode 100644 board/sacsng/clkinit.c delete mode 100644 board/sacsng/clkinit.h delete mode 100644 board/sacsng/flash.c delete mode 100644 board/sacsng/ioconfig.h delete mode 100644 board/sacsng/sacsng.c delete mode 100644 configs/sacsng_defconfig delete mode 100644 include/configs/sacsng.h
diff --git a/arch/powerpc/cpu/mpc8260/Kconfig b/arch/powerpc/cpu/mpc8260/Kconfig index 17e303d..bdaf126 100644 --- a/arch/powerpc/cpu/mpc8260/Kconfig +++ b/arch/powerpc/cpu/mpc8260/Kconfig @@ -40,9 +40,6 @@ config TARGET_PM828 config TARGET_PPMC8260 bool "Support ppmc8260"
-config TARGET_SACSNG - bool "Support sacsng" - config TARGET_MPC8266ADS bool "Support MPC8266ADS"
@@ -68,6 +65,5 @@ source "board/muas3001/Kconfig" source "board/pm826/Kconfig" source "board/pm828/Kconfig" source "board/ppmc8260/Kconfig" -source "board/sacsng/Kconfig"
endmenu diff --git a/board/sacsng/Kconfig b/board/sacsng/Kconfig deleted file mode 100644 index 1646425..0000000 --- a/board/sacsng/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_SACSNG - -config SYS_BOARD - default "sacsng" - -config SYS_CONFIG_NAME - default "sacsng" - -endif diff --git a/board/sacsng/MAINTAINERS b/board/sacsng/MAINTAINERS deleted file mode 100644 index b76e462..0000000 --- a/board/sacsng/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -SACSNG BOARD -#M: Jerry Van Baren gerald.vanbaren@smiths-aerospace.com -S: Orphan (since 2014-06) -F: board/sacsng/ -F: include/configs/sacsng.h -F: configs/sacsng_defconfig diff --git a/board/sacsng/Makefile b/board/sacsng/Makefile deleted file mode 100644 index 95e6b8d..0000000 --- a/board/sacsng/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y := sacsng.o flash.o clkinit.o diff --git a/board/sacsng/clkinit.c b/board/sacsng/clkinit.c deleted file mode 100644 index 2a28037..0000000 --- a/board/sacsng/clkinit.c +++ /dev/null @@ -1,1009 +0,0 @@ -/* - * (C) Copyright 2002 - * Custom IDEAS, Inc. <www.cideas.com> - * Jon Diekema diekema@cideas.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <ioports.h> -#include <mpc8260.h> -#include <asm/cpm_8260.h> -#include <configs/sacsng.h> - -#include "clkinit.h" - -DECLARE_GLOBAL_DATA_PTR; - -int Daq64xSampling = 0; - - -void Daq_BRG_Reset(uint brg) -{ - volatile immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; - volatile uint *brg_ptr; - - brg_ptr = (uint *)&immr->im_brgc1; - - if (brg >= 5) { - brg_ptr = (uint *)&immr->im_brgc5; - brg -= 4; - } - brg_ptr += brg; - *brg_ptr |= CPM_BRG_RST; - *brg_ptr &= ~CPM_BRG_RST; -} - -void Daq_BRG_Disable(uint brg) -{ - volatile immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; - volatile uint *brg_ptr; - - brg_ptr = (uint *)&immr->im_brgc1; - - if (brg >= 5) { - brg_ptr = (uint *)&immr->im_brgc5; - brg -= 4; - } - brg_ptr += brg; - *brg_ptr &= ~CPM_BRG_EN; -} - -void Daq_BRG_Enable(uint brg) -{ - volatile immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; - volatile uint *brg_ptr; - - brg_ptr = (uint *)&immr->im_brgc1; - if (brg >= 5) { - brg_ptr = (uint *)&immr->im_brgc5; - brg -= 4; - } - brg_ptr += brg; - *brg_ptr |= CPM_BRG_EN; -} - -uint Daq_BRG_Get_Div16(uint brg) -{ - volatile immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; - uint *brg_ptr; - - brg_ptr = (uint *)&immr->im_brgc1; - if (brg >= 5) { - brg_ptr = (uint *)&immr->im_brgc5; - brg -= 4; - } - brg_ptr += brg; - - if (*brg_ptr & CPM_BRG_DIV16) { - /* DIV16 active */ - return true; - } - else { - /* DIV16 inactive */ - return false; - } -} - -void Daq_BRG_Set_Div16(uint brg, uint div16) -{ - volatile immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; - uint *brg_ptr; - - brg_ptr = (uint *)&immr->im_brgc1; - if (brg >= 5) { - brg_ptr = (uint *)&immr->im_brgc5; - brg -= 4; - } - brg_ptr += brg; - - if (div16) { - /* DIV16 active */ - *brg_ptr |= CPM_BRG_DIV16; - } - else { - /* DIV16 inactive */ - *brg_ptr &= ~CPM_BRG_DIV16; - } -} - -uint Daq_BRG_Get_Count(uint brg) -{ - volatile immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; - uint *brg_ptr; - uint brg_cnt; - - brg_ptr = (uint *)&immr->im_brgc1; - if (brg >= 5) { - brg_ptr = (uint *)&immr->im_brgc5; - brg -= 4; - } - brg_ptr += brg; - - /* Get the clock divider - * - * Note: A clock divider of 0 means divide by 1, - * therefore we need to add 1 to the count. - */ - brg_cnt = (*brg_ptr & CPM_BRG_CD_MASK) >> CPM_BRG_DIV16_SHIFT; - brg_cnt++; - if (*brg_ptr & CPM_BRG_DIV16) { - brg_cnt *= 16; - } - - return (brg_cnt); -} - -void Daq_BRG_Set_Count(uint brg, uint brg_cnt) -{ - volatile immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; - uint *brg_ptr; - - brg_ptr = (uint *)&immr->im_brgc1; - if (brg >= 5) { - brg_ptr = (uint *)&immr->im_brgc5; - brg -= 4; - } - brg_ptr += brg; - - /* - * Note: A clock divider of 0 means divide by 1, - * therefore we need to subtract 1 from the count. - */ - if (brg_cnt > 4096) { - /* Prescale = Divide by 16 */ - *brg_ptr = (*brg_ptr & ~CPM_BRG_CD_MASK) | - (((brg_cnt / 16) - 1) << CPM_BRG_DIV16_SHIFT); - *brg_ptr |= CPM_BRG_DIV16; - } - else { - /* Prescale = Divide by 1 */ - *brg_ptr = (*brg_ptr & ~CPM_BRG_CD_MASK) | - ((brg_cnt - 1) << CPM_BRG_DIV16_SHIFT); - *brg_ptr &= ~CPM_BRG_DIV16; - } -} - -uint Daq_BRG_Get_ExtClk(uint brg) -{ - volatile immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; - uint *brg_ptr; - - brg_ptr = (uint *)&immr->im_brgc1; - if (brg >= 5) { - brg_ptr = (uint *)&immr->im_brgc5; - brg -= 4; - } - brg_ptr += brg; - - return ((*brg_ptr & CPM_BRG_EXTC_MASK) >> CPM_BRG_EXTC_SHIFT); -} - -char* Daq_BRG_Get_ExtClk_Description(uint brg) -{ - uint extc; - - extc = Daq_BRG_Get_ExtClk(brg); - - switch (brg + 1) { - case 1: - case 2: - case 5: - case 6: { - switch (extc) { - case 0: { - return ("BRG_INT"); - } - case 1: { - return ("CLK3"); - } - case 2: { - return ("CLK5"); - } - } - return ("??1245??"); - } - case 3: - case 4: - case 7: - case 8: { - switch (extc) { - case 0: { - return ("BRG_INT"); - } - case 1: { - return ("CLK9"); - } - case 2: { - return ("CLK15"); - } - } - return ("??3478??"); - } - } - return ("??9876??"); -} - -void Daq_BRG_Set_ExtClk(uint brg, uint extc) -{ - volatile immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; - uint *brg_ptr; - - brg_ptr = (uint *)&immr->im_brgc1; - if (brg >= 5) { - brg_ptr = (uint *)&immr->im_brgc5; - brg -= 4; - } - brg_ptr += brg; - - *brg_ptr = (*brg_ptr & ~CPM_BRG_EXTC_MASK) | - ((extc << CPM_BRG_EXTC_SHIFT) & CPM_BRG_EXTC_MASK); -} - -uint Daq_BRG_Rate(uint brg) -{ - volatile immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; - uint *brg_ptr; - uint brg_cnt; - uint brg_freq = 0; - - brg_ptr = (uint *)&immr->im_brgc1; - brg_ptr += brg; - if (brg >= 5) { - brg_ptr = (uint *)&immr->im_brgc5; - brg_ptr += (brg - 4); - } - - brg_cnt = Daq_BRG_Get_Count(brg); - - switch (Daq_BRG_Get_ExtClk(brg)) { - case CPM_BRG_EXTC_CLK3: - case CPM_BRG_EXTC_CLK5: { - brg_freq = brg_cnt; - break; - } - default: { - brg_freq = (uint)BRG_INT_CLK / brg_cnt; - } - } - return (brg_freq); -} - -uint Daq_Get_SampleRate(void) -{ - /* - * Read the BRG's to return the actual sample rate. - */ - return (Daq_BRG_Rate(MCLK_BRG) / (MCLK_DIVISOR * SCLK_DIVISOR)); -} - -void Daq_Init_Clocks(int sample_rate, int sample_64x) -{ - volatile ioport_t *iopa = ioport_addr((immap_t *)CONFIG_SYS_IMMR, 0 /* port A */); - uint mclk_divisor; /* MCLK divisor */ - int flag; /* Interrupt state */ - - /* Save off the clocking data */ - Daq64xSampling = sample_64x; - - /* - * Limit the sample rate to some sensible values. - */ - if (sample_rate > MAX_64x_SAMPLE_RATE) { - sample_rate = MAX_64x_SAMPLE_RATE; - } - if (sample_rate < MIN_SAMPLE_RATE) { - sample_rate = MIN_SAMPLE_RATE; - } - - /* - * Initialize the MCLK/SCLK/LRCLK baud rate generators. - */ - - /* Setup MCLK */ - Daq_BRG_Set_ExtClk(MCLK_BRG, CPM_BRG_EXTC_BRGCLK); - - /* Setup SCLK */ -# ifdef RUN_SCLK_ON_BRG_INT - Daq_BRG_Set_ExtClk(SCLK_BRG, CPM_BRG_EXTC_BRGCLK); -# else - Daq_BRG_Set_ExtClk(SCLK_BRG, CPM_BRG_EXTC_CLK9); -# endif - - /* Setup LRCLK */ -# ifdef RUN_LRCLK_ON_BRG_INT - Daq_BRG_Set_ExtClk(LRCLK_BRG, CPM_BRG_EXTC_BRGCLK); -# else - Daq_BRG_Set_ExtClk(LRCLK_BRG, CPM_BRG_EXTC_CLK5); -# endif - - /* - * Dynamically adjust MCLK based on the new sample rate. - */ - - /* Compute the divisors */ - mclk_divisor = BRG_INT_CLK / (sample_rate * MCLK_DIVISOR * SCLK_DIVISOR); - - /* - * Disable interrupt and save the current state - */ - flag = disable_interrupts(); - - /* Setup MCLK */ - Daq_BRG_Set_Count(MCLK_BRG, mclk_divisor); - - /* Setup SCLK */ -# ifdef RUN_SCLK_ON_BRG_INT - Daq_BRG_Set_Count(SCLK_BRG, mclk_divisor * MCLK_DIVISOR); -# else - Daq_BRG_Set_Count(SCLK_BRG, MCLK_DIVISOR); -# endif - -# ifdef RUN_LRCLK_ON_BRG_INT - Daq_BRG_Set_Count(LRCLK_BRG, - mclk_divisor * MCLK_DIVISOR * SCLK_DIVISOR); -# else - Daq_BRG_Set_Count(LRCLK_BRG, SCLK_DIVISOR); -# endif - - /* - * Restore the Interrupt state - */ - if (flag) { - enable_interrupts(); - } - - /* Enable the clock drivers */ - iopa->pdat &= ~SLRCLK_EN_MASK; -} - -void Daq_Stop_Clocks(void) - -{ -#ifdef TIGHTEN_UP_BRG_TIMING - volatile immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; - register uint mclk_brg; /* MCLK BRG value */ - register uint sclk_brg; /* SCLK BRG value */ - register uint lrclk_brg; /* LRCLK BRG value */ - unsigned long flag; /* Interrupt flags */ -#endif - -# ifdef TIGHTEN_UP_BRG_TIMING - /* - * Obtain MCLK BRG reset/disabled value - */ -# if (MCLK_BRG == 0) - mclk_brg = (*IM_BRGC1 | CPM_BRG_RST) & ~CPM_BRG_EN; -# endif -# if (MCLK_BRG == 1) - mclk_brg = (*IM_BRGC2 | CPM_BRG_RST) & ~CPM_BRG_EN; -# endif -# if (MCLK_BRG == 2) - mclk_brg = (*IM_BRGC3 | CPM_BRG_RST) & ~CPM_BRG_EN; -# endif -# if (MCLK_BRG == 3) - mclk_brg = (*IM_BRGC4 | CPM_BRG_RST) & ~CPM_BRG_EN; -# endif -# if (MCLK_BRG == 4) - mclk_brg = (*IM_BRGC5 | CPM_BRG_RST) & ~CPM_BRG_EN; -# endif -# if (MCLK_BRG == 5) - mclk_brg = (*IM_BRGC6 | CPM_BRG_RST) & ~CPM_BRG_EN; -# endif -# if (MCLK_BRG == 6) - mclk_brg = (*IM_BRGC7 | CPM_BRG_RST) & ~CPM_BRG_EN; -# endif -# if (MCLK_BRG == 7) - mclk_brg = (*IM_BRGC8 | CPM_BRG_RST) & ~CPM_BRG_EN; -# endif - - /* - * Obtain SCLK BRG reset/disabled value - */ -# if (SCLK_BRG == 0) - sclk_brg = (*IM_BRGC1 | CPM_BRG_RST) & ~CPM_BRG_EN; -# endif -# if (SCLK_BRG == 1) - sclk_brg = (*IM_BRGC2 | CPM_BRG_RST) & ~CPM_BRG_EN; -# endif -# if (SCLK_BRG == 2) - sclk_brg = (*IM_BRGC3 | CPM_BRG_RST) & ~CPM_BRG_EN; -# endif -# if (SCLK_BRG == 3) - sclk_brg = (*IM_BRGC4 | CPM_BRG_RST) & ~CPM_BRG_EN; -# endif -# if (SCLK_BRG == 4) - sclk_brg = (*IM_BRGC5 | CPM_BRG_RST) & ~CPM_BRG_EN; -# endif -# if (SCLK_BRG == 5) - sclk_brg = (*IM_BRGC6 | CPM_BRG_RST) & ~CPM_BRG_EN; -# endif -# if (SCLK_BRG == 6) - sclk_brg = (*IM_BRGC7 | CPM_BRG_RST) & ~CPM_BRG_EN; -# endif -# if (SCLK_BRG == 7) - sclk_brg = (*IM_BRGC8 | CPM_BRG_RST) & ~CPM_BRG_EN; -# endif - - /* - * Obtain LRCLK BRG reset/disabled value - */ -# if (LRCLK_BRG == 0) - lrclk_brg = (*IM_BRGC1 | CPM_BRG_RST) & ~CPM_BRG_EN; -# endif -# if (LRCLK_BRG == 1) - lrclk_brg = (*IM_BRGC2 | CPM_BRG_RST) & ~CPM_BRG_EN; -# endif -# if (LRCLK_BRG == 2) - lrclk_brg = (*IM_BRGC3 | CPM_BRG_RST) & ~CPM_BRG_EN; -# endif -# if (LRCLK_BRG == 3) - lrclk_brg = (*IM_BRGC4 | CPM_BRG_RST) & ~CPM_BRG_EN; -# endif -# if (LRCLK_BRG == 4) - lrclk_brg = (*IM_BRGC5 | CPM_BRG_RST) & ~CPM_BRG_EN; -# endif -# if (LRCLK_BRG == 5) - lrclk_brg = (*IM_BRGC6 | CPM_BRG_RST) & ~CPM_BRG_EN; -# endif -# if (LRCLK_BRG == 6) - lrclk_brg = (*IM_BRGC7 | CPM_BRG_RST) & ~CPM_BRG_EN; -# endif -# if (LRCLK_BRG == 7) - lrclk_brg = (*IM_BRGC8 | CPM_BRG_RST) & ~CPM_BRG_EN; -# endif - - /* - * Disable interrupt and save the current state - */ - flag = disable_interrupts(); - - /* - * Set reset on MCLK BRG - */ -# if (MCLK_BRG == 0) - *IM_BRGC1 = mclk_brg; -# endif -# if (MCLK_BRG == 1) - *IM_BRGC2 = mclk_brg; -# endif -# if (MCLK_BRG == 2) - *IM_BRGC3 = mclk_brg; -# endif -# if (MCLK_BRG == 3) - *IM_BRGC4 = mclk_brg; -# endif -# if (MCLK_BRG == 4) - *IM_BRGC5 = mclk_brg; -# endif -# if (MCLK_BRG == 5) - *IM_BRGC6 = mclk_brg; -# endif -# if (MCLK_BRG == 6) - *IM_BRGC7 = mclk_brg; -# endif -# if (MCLK_BRG == 7) - *IM_BRGC8 = mclk_brg; -# endif - - /* - * Set reset on SCLK BRG - */ -# if (SCLK_BRG == 0) - *IM_BRGC1 = sclk_brg; -# endif -# if (SCLK_BRG == 1) - *IM_BRGC2 = sclk_brg; -# endif -# if (SCLK_BRG == 2) - *IM_BRGC3 = sclk_brg; -# endif -# if (SCLK_BRG == 3) - *IM_BRGC4 = sclk_brg; -# endif -# if (SCLK_BRG == 4) - *IM_BRGC5 = sclk_brg; -# endif -# if (SCLK_BRG == 5) - *IM_BRGC6 = sclk_brg; -# endif -# if (SCLK_BRG == 6) - *IM_BRGC7 = sclk_brg; -# endif -# if (SCLK_BRG == 7) - *IM_BRGC8 = sclk_brg; -# endif - - /* - * Set reset on LRCLK BRG - */ -# if (LRCLK_BRG == 0) - *IM_BRGC1 = lrclk_brg; -# endif -# if (LRCLK_BRG == 1) - *IM_BRGC2 = lrclk_brg; -# endif -# if (LRCLK_BRG == 2) - *IM_BRGC3 = lrclk_brg; -# endif -# if (LRCLK_BRG == 3) - *IM_BRGC4 = lrclk_brg; -# endif -# if (LRCLK_BRG == 4) - *IM_BRGC5 = lrclk_brg; -# endif -# if (LRCLK_BRG == 5) - *IM_BRGC6 = lrclk_brg; -# endif -# if (LRCLK_BRG == 6) - *IM_BRGC7 = lrclk_brg; -# endif -# if (LRCLK_BRG == 7) - *IM_BRGC8 = lrclk_brg; -# endif - - /* - * Clear reset on MCLK BRG - */ -# if (MCLK_BRG == 0) - *IM_BRGC1 = mclk_brg & ~CPM_BRG_RST; -# endif -# if (MCLK_BRG == 1) - *IM_BRGC2 = mclk_brg & ~CPM_BRG_RST; -# endif -# if (MCLK_BRG == 2) - *IM_BRGC3 = mclk_brg & ~CPM_BRG_RST; -# endif -# if (MCLK_BRG == 3) - *IM_BRGC4 = mclk_brg & ~CPM_BRG_RST; -# endif -# if (MCLK_BRG == 4) - *IM_BRGC5 = mclk_brg & ~CPM_BRG_RST; -# endif -# if (MCLK_BRG == 5) - *IM_BRGC6 = mclk_brg & ~CPM_BRG_RST; -# endif -# if (MCLK_BRG == 6) - *IM_BRGC7 = mclk_brg & ~CPM_BRG_RST; -# endif -# if (MCLK_BRG == 7) - *IM_BRGC8 = mclk_brg & ~CPM_BRG_RST; -# endif - - /* - * Clear reset on SCLK BRG - */ -# if (SCLK_BRG == 0) - *IM_BRGC1 = sclk_brg & ~CPM_BRG_RST; -# endif -# if (SCLK_BRG == 1) - *IM_BRGC2 = sclk_brg & ~CPM_BRG_RST; -# endif -# if (SCLK_BRG == 2) - *IM_BRGC3 = sclk_brg & ~CPM_BRG_RST; -# endif -# if (SCLK_BRG == 3) - *IM_BRGC4 = sclk_brg & ~CPM_BRG_RST; -# endif -# if (SCLK_BRG == 4) - *IM_BRGC5 = sclk_brg & ~CPM_BRG_RST; -# endif -# if (SCLK_BRG == 5) - *IM_BRGC6 = sclk_brg & ~CPM_BRG_RST; -# endif -# if (SCLK_BRG == 6) - *IM_BRGC7 = sclk_brg & ~CPM_BRG_RST; -# endif -# if (SCLK_BRG == 7) - *IM_BRGC8 = sclk_brg & ~CPM_BRG_RST; -# endif - - /* - * Clear reset on LRCLK BRG - */ -# if (LRCLK_BRG == 0) - *IM_BRGC1 = lrclk_brg & ~CPM_BRG_RST; -# endif -# if (LRCLK_BRG == 1) - *IM_BRGC2 = lrclk_brg & ~CPM_BRG_RST; -# endif -# if (LRCLK_BRG == 2) - *IM_BRGC3 = lrclk_brg & ~CPM_BRG_RST; -# endif -# if (LRCLK_BRG == 3) - *IM_BRGC4 = lrclk_brg & ~CPM_BRG_RST; -# endif -# if (LRCLK_BRG == 4) - *IM_BRGC5 = lrclk_brg & ~CPM_BRG_RST; -# endif -# if (LRCLK_BRG == 5) - *IM_BRGC6 = lrclk_brg & ~CPM_BRG_RST; -# endif -# if (LRCLK_BRG == 6) - *IM_BRGC7 = lrclk_brg & ~CPM_BRG_RST; -# endif -# if (LRCLK_BRG == 7) - *IM_BRGC8 = lrclk_brg & ~CPM_BRG_RST; -# endif - - /* - * Restore the Interrupt state - */ - if (flag) { - enable_interrupts(); - } -# else - /* - * Reset the clocks - */ - Daq_BRG_Reset(MCLK_BRG); - Daq_BRG_Reset(SCLK_BRG); - Daq_BRG_Reset(LRCLK_BRG); -# endif -} - -void Daq_Start_Clocks(int sample_rate) - -{ -#ifdef TIGHTEN_UP_BRG_TIMING - volatile immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; - - register uint mclk_brg; /* MCLK BRG value */ - register uint sclk_brg; /* SCLK BRG value */ - register uint temp_lrclk_brg; /* Temporary LRCLK BRG value */ - register uint real_lrclk_brg; /* Permanent LRCLK BRG value */ - uint lrclk_brg; /* LRCLK BRG value */ - unsigned long flags; /* Interrupt flags */ - uint sclk_cnt; /* SCLK count */ - uint delay_cnt; /* Delay count */ -#endif - -# ifdef TIGHTEN_UP_BRG_TIMING - /* - * Obtain the enabled MCLK BRG value - */ -# if (MCLK_BRG == 0) - mclk_brg = (*IM_BRGC1 & ~CPM_BRG_RST) | CPM_BRG_EN; -# endif -# if (MCLK_BRG == 1) - mclk_brg = (*IM_BRGC2 & ~CPM_BRG_RST) | CPM_BRG_EN; -# endif -# if (MCLK_BRG == 2) - mclk_brg = (*IM_BRGC3 & ~CPM_BRG_RST) | CPM_BRG_EN; -# endif -# if (MCLK_BRG == 3) - mclk_brg = (*IM_BRGC4 & ~CPM_BRG_RST) | CPM_BRG_EN; -# endif -# if (MCLK_BRG == 4) - mclk_brg = (*IM_BRGC5 & ~CPM_BRG_RST) | CPM_BRG_EN; -# endif -# if (MCLK_BRG == 5) - mclk_brg = (*IM_BRGC6 & ~CPM_BRG_RST) | CPM_BRG_EN; -# endif -# if (MCLK_BRG == 6) - mclk_brg = (*IM_BRGC7 & ~CPM_BRG_RST) | CPM_BRG_EN; -# endif -# if (MCLK_BRG == 7) - mclk_brg = (*IM_BRGC8 & ~CPM_BRG_RST) | CPM_BRG_EN; -# endif - - /* - * Obtain the enabled SCLK BRG value - */ -# if (SCLK_BRG == 0) - sclk_brg = (*IM_BRGC1 & ~CPM_BRG_RST) | CPM_BRG_EN; -# endif -# if (SCLK_BRG == 1) - sclk_brg = (*IM_BRGC2 & ~CPM_BRG_RST) | CPM_BRG_EN; -# endif -# if (SCLK_BRG == 2) - sclk_brg = (*IM_BRGC3 & ~CPM_BRG_RST) | CPM_BRG_EN; -# endif -# if (SCLK_BRG == 3) - sclk_brg = (*IM_BRGC4 & ~CPM_BRG_RST) | CPM_BRG_EN; -# endif -# if (SCLK_BRG == 4) - sclk_brg = (*IM_BRGC5 & ~CPM_BRG_RST) | CPM_BRG_EN; -# endif -# if (SCLK_BRG == 5) - sclk_brg = (*IM_BRGC6 & ~CPM_BRG_RST) | CPM_BRG_EN; -# endif -# if (SCLK_BRG == 6) - sclk_brg = (*IM_BRGC7 & ~CPM_BRG_RST) | CPM_BRG_EN; -# endif -# if (SCLK_BRG == 7) - sclk_brg = (*IM_BRGC8 & ~CPM_BRG_RST) | CPM_BRG_EN; -# endif - - /* - * Obtain the enabled LRCLK BRG value - */ -# if (LRCLK_BRG == 0) - lrclk_brg = (*IM_BRGC1 & ~CPM_BRG_RST) | CPM_BRG_EN; -# endif -# if (LRCLK_BRG == 1) - lrclk_brg = (*IM_BRGC2 & ~CPM_BRG_RST) | CPM_BRG_EN; -# endif -# if (LRCLK_BRG == 2) - lrclk_brg = (*IM_BRGC3 & ~CPM_BRG_RST) | CPM_BRG_EN; -# endif -# if (LRCLK_BRG == 3) - lrclk_brg = (*IM_BRGC4 & ~CPM_BRG_RST) | CPM_BRG_EN; -# endif -# if (LRCLK_BRG == 4) - lrclk_brg = (*IM_BRGC5 & ~CPM_BRG_RST) | CPM_BRG_EN; -# endif -# if (LRCLK_BRG == 5) - lrclk_brg = (*IM_BRGC6 & ~CPM_BRG_RST) | CPM_BRG_EN; -# endif -# if (LRCLK_BRG == 6) - lrclk_brg = (*IM_BRGC7 & ~CPM_BRG_RST) | CPM_BRG_EN; -# endif -# if (LRCLK_BRG == 7) - lrclk_brg = (*IM_BRGC8 & ~CPM_BRG_RST) | CPM_BRG_EN; -# endif - - /* Save off the real LRCLK value */ - real_lrclk_brg = lrclk_brg; - - /* Obtain the current SCLK count */ - sclk_cnt = ((sclk_brg & 0x00001FFE) >> 1) + 1; - - /* Compute the delay as a function of SCLK count */ - delay_cnt = ((sclk_cnt / 4) - 2) * 10 + 6; - if (DaqSampleRate == 43402) { - delay_cnt++; - } - - /* Clear out the count */ - temp_lrclk_brg = sclk_brg & ~0x00001FFE; - - /* Insert the count */ - temp_lrclk_brg |= ((delay_cnt + (sclk_cnt / 2) - 1) << 1) & 0x00001FFE; - - /* - * Disable interrupt and save the current state - */ - flag = disable_interrupts(); - - /* - * Enable MCLK BRG - */ -# if (MCLK_BRG == 0) - *IM_BRGC1 = mclk_brg; -# endif -# if (MCLK_BRG == 1) - *IM_BRGC2 = mclk_brg; -# endif -# if (MCLK_BRG == 2) - *IM_BRGC3 = mclk_brg; -# endif -# if (MCLK_BRG == 3) - *IM_BRGC4 = mclk_brg; -# endif -# if (MCLK_BRG == 4) - *IM_BRGC5 = mclk_brg; -# endif -# if (MCLK_BRG == 5) - *IM_BRGC6 = mclk_brg; -# endif -# if (MCLK_BRG == 6) - *IM_BRGC7 = mclk_brg; -# endif -# if (MCLK_BRG == 7) - *IM_BRGC8 = mclk_brg; -# endif - - /* - * Enable SCLK BRG - */ -# if (SCLK_BRG == 0) - *IM_BRGC1 = sclk_brg; -# endif -# if (SCLK_BRG == 1) - *IM_BRGC2 = sclk_brg; -# endif -# if (SCLK_BRG == 2) - *IM_BRGC3 = sclk_brg; -# endif -# if (SCLK_BRG == 3) - *IM_BRGC4 = sclk_brg; -# endif -# if (SCLK_BRG == 4) - *IM_BRGC5 = sclk_brg; -# endif -# if (SCLK_BRG == 5) - *IM_BRGC6 = sclk_brg; -# endif -# if (SCLK_BRG == 6) - *IM_BRGC7 = sclk_brg; -# endif -# if (SCLK_BRG == 7) - *IM_BRGC8 = sclk_brg; -# endif - - /* - * Enable LRCLK BRG (1st time - temporary) - */ -# if (LRCLK_BRG == 0) - *IM_BRGC1 = temp_lrclk_brg; -# endif -# if (LRCLK_BRG == 1) - *IM_BRGC2 = temp_lrclk_brg; -# endif -# if (LRCLK_BRG == 2) - *IM_BRGC3 = temp_lrclk_brg; -# endif -# if (LRCLK_BRG == 3) - *IM_BRGC4 = temp_lrclk_brg; -# endif -# if (LRCLK_BRG == 4) - *IM_BRGC5 = temp_lrclk_brg; -# endif -# if (LRCLK_BRG == 5) - *IM_BRGC6 = temp_lrclk_brg; -# endif -# if (LRCLK_BRG == 6) - *IM_BRGC7 = temp_lrclk_brg; -# endif -# if (LRCLK_BRG == 7) - *IM_BRGC8 = temp_lrclk_brg; -# endif - - /* - * Enable LRCLK BRG (2nd time - permanent) - */ -# if (LRCLK_BRG == 0) - *IM_BRGC1 = real_lrclk_brg; -# endif -# if (LRCLK_BRG == 1) - *IM_BRGC2 = real_lrclk_brg; -# endif -# if (LRCLK_BRG == 2) - *IM_BRGC3 = real_lrclk_brg; -# endif -# if (LRCLK_BRG == 3) - *IM_BRGC4 = real_lrclk_brg; -# endif -# if (LRCLK_BRG == 4) - *IM_BRGC5 = real_lrclk_brg; -# endif -# if (LRCLK_BRG == 5) - *IM_BRGC6 = real_lrclk_brg; -# endif -# if (LRCLK_BRG == 6) - *IM_BRGC7 = real_lrclk_brg; -# endif -# if (LRCLK_BRG == 7) - *IM_BRGC8 = real_lrclk_brg; -# endif - - /* - * Restore the Interrupt state - */ - if (flag) { - enable_interrupts(); - } -# else - /* - * Enable the clocks - */ - Daq_BRG_Enable(LRCLK_BRG); - Daq_BRG_Enable(SCLK_BRG); - Daq_BRG_Enable(MCLK_BRG); -# endif -} - -void Daq_Display_Clocks(void) - -{ - volatile immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; - uint mclk_divisor; /* Detected MCLK divisor */ - uint sclk_divisor; /* Detected SCLK divisor */ - - printf("\nBRG:\n"); - if (immr->im_brgc4 != 0) { - printf("\tbrgc4\t0x%08x @ 0x%08x, %5d count, %d extc, %8s, MCLK\n", - immr->im_brgc4, - (uint)&(immr->im_brgc4), - Daq_BRG_Get_Count(3), - Daq_BRG_Get_ExtClk(3), - Daq_BRG_Get_ExtClk_Description(3)); - } - if (immr->im_brgc8 != 0) { - printf("\tbrgc8\t0x%08x @ 0x%08x, %5d count, %d extc, %8s, SCLK\n", - immr->im_brgc8, - (uint)&(immr->im_brgc8), - Daq_BRG_Get_Count(7), - Daq_BRG_Get_ExtClk(7), - Daq_BRG_Get_ExtClk_Description(7)); - } - if (immr->im_brgc6 != 0) { - printf("\tbrgc6\t0x%08x @ 0x%08x, %5d count, %d extc, %8s, LRCLK\n", - immr->im_brgc6, - (uint)&(immr->im_brgc6), - Daq_BRG_Get_Count(5), - Daq_BRG_Get_ExtClk(5), - Daq_BRG_Get_ExtClk_Description(5)); - } - if (immr->im_brgc1 != 0) { - printf("\tbrgc1\t0x%08x @ 0x%08x, %5d count, %d extc, %8s, SMC1\n", - immr->im_brgc1, - (uint)&(immr->im_brgc1), - Daq_BRG_Get_Count(0), - Daq_BRG_Get_ExtClk(0), - Daq_BRG_Get_ExtClk_Description(0)); - } - if (immr->im_brgc2 != 0) { - printf("\tbrgc2\t0x%08x @ 0x%08x, %5d count, %d extc, %8s, SMC2\n", - immr->im_brgc2, - (uint)&(immr->im_brgc2), - Daq_BRG_Get_Count(1), - Daq_BRG_Get_ExtClk(1), - Daq_BRG_Get_ExtClk_Description(1)); - } - if (immr->im_brgc3 != 0) { - printf("\tbrgc3\t0x%08x @ 0x%08x, %5d count, %d extc, %8s, SCC1\n", - immr->im_brgc3, - (uint)&(immr->im_brgc3), - Daq_BRG_Get_Count(2), - Daq_BRG_Get_ExtClk(2), - Daq_BRG_Get_ExtClk_Description(2)); - } - if (immr->im_brgc5 != 0) { - printf("\tbrgc5\t0x%08x @ 0x%08x, %5d count, %d extc, %8s\n", - immr->im_brgc5, - (uint)&(immr->im_brgc5), - Daq_BRG_Get_Count(4), - Daq_BRG_Get_ExtClk(4), - Daq_BRG_Get_ExtClk_Description(4)); - } - if (immr->im_brgc7 != 0) { - printf("\tbrgc7\t0x%08x @ 0x%08x, %5d count, %d extc, %8s\n", - immr->im_brgc7, - (uint)&(immr->im_brgc7), - Daq_BRG_Get_Count(6), - Daq_BRG_Get_ExtClk(6), - Daq_BRG_Get_ExtClk_Description(6)); - } - -# ifdef RUN_SCLK_ON_BRG_INT - mclk_divisor = Daq_BRG_Rate(MCLK_BRG) / Daq_BRG_Rate(SCLK_BRG); -# else - mclk_divisor = Daq_BRG_Get_Count(SCLK_BRG); -# endif -# ifdef RUN_LRCLK_ON_BRG_INT - sclk_divisor = Daq_BRG_Rate(SCLK_BRG) / Daq_BRG_Rate(LRCLK_BRG); -# else - sclk_divisor = Daq_BRG_Get_Count(LRCLK_BRG); -# endif - - printf("\nADC/DAC Clocking (%d/%d):\n", sclk_divisor, mclk_divisor); - printf("\tMCLK %8d Hz, or %3dx SCLK, or %3dx LRCLK\n", - Daq_BRG_Rate(MCLK_BRG), - mclk_divisor, - mclk_divisor * sclk_divisor); -# ifdef RUN_SCLK_ON_BRG_INT - printf("\tSCLK %8d Hz, or %3dx LRCLK\n", - Daq_BRG_Rate(SCLK_BRG), - sclk_divisor); -# else - printf("\tSCLK %8d Hz, or %3dx LRCLK\n", - Daq_BRG_Rate(MCLK_BRG) / mclk_divisor, - sclk_divisor); -# endif -# ifdef RUN_LRCLK_ON_BRG_INT - printf("\tLRCLK %8d Hz\n", - Daq_BRG_Rate(LRCLK_BRG)); -# else -# ifdef RUN_SCLK_ON_BRG_INT - printf("\tLRCLK %8d Hz\n", - Daq_BRG_Rate(SCLK_BRG) / sclk_divisor); -# else - printf("\tLRCLK %8d Hz\n", - Daq_BRG_Rate(MCLK_BRG) / (mclk_divisor * sclk_divisor)); -# endif -# endif - printf("\n"); -} diff --git a/board/sacsng/clkinit.h b/board/sacsng/clkinit.h deleted file mode 100644 index 3f759dd..0000000 --- a/board/sacsng/clkinit.h +++ /dev/null @@ -1,103 +0,0 @@ -/* - * (C) Copyright 2002 - * Custom IDEAS, Inc. <www.cideas.com> - * Jon Diekema diekema@cideas.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#define SLRCLK_EN_MASK 0x00040000 /* PA13 - SLRCLK_EN* */ - -#define MIN_SAMPLE_RATE 4000 /* Minimum sample rate */ -#define MAX_128x_SAMPLE_RATE 43402 /* Maximum 128x sample rate */ -#define MAX_64x_SAMPLE_RATE 86805 /* Maximum 64x sample rate */ - -#define KHZ ((uint)1000) -#define MHZ ((uint)(1000 * KHZ)) - -#define MCLK_BRG 3 /* MCLK, Master CLocK for the A/D & D/A */ -#define SCLK_BRG 7 /* SCLK, Sample CLocK for the A/D & D/A */ -#define LRCLK_BRG 5 /* LRCLK, L/R CLocK for the A/D & D/A */ - /* 0 == BRG1 (used for SMC1) */ - /* 1 == BRG2 (used for SMC2) */ - /* 2 == BRG3 (used for SCC1) */ - /* 3 == BRG4 (MCLK) */ - /* 4 == BRG5 */ - /* 5 == BRG6 (LRCLK) */ - /* 6 == BRG7 */ - /* 7 == BRG8 (SCLK) */ - -#define MCLK_DIVISOR 4 /* SCLK = MCLK / MCLK_DIVISOR */ -#define SCLK_DIVISOR (Daq64xSampling ? 64 : 128) - /* LRCLK = SCLK / SCLK_DIVISOR */ - -#define TIGHTEN_UP_BRG_EN_TIMING /* Tighten up the BRG enable timing */ -#define RUN_SCLK_ON_BRG_INT /* Run SCLK on BRG_INT instead of MCLK */ - /* The 8260 (Mask B.3) seems to have */ - /* problems generating SCLK from MCLK */ - /* via CLK9. */ -#define RUN_LRCLK_ON_BRG_INT /* Run LRCLK on BRG_INT instead of SCLK */ - /* The 8260 (Mask B.3) seems to have */ - /* problems generating LRCLK from SCLK */ - -#define NUM_LRCLKS_TO_STABILIZE 1 /* Number of LRCLK period (sample) */ - /* to wait for the clock to stabilize */ - -#define CPM_CLK (gd->bd->bi_cpmfreq) -#define DFBRG 4 -#define BRG_INT_CLK (CPM_CLK * 2 / DFBRG) - /* BRG = CPM * 2 / DFBRG (Sect 9.8) */ - /* BRG = CPM * 2 / 4 */ - /* BRG = CPM / 2 */ - -#define CPM_BRG_EXTC_MASK ((uint)0x0000C000) -#define CPM_BRG_EXTC_SHIFT 14 - -#define CPM_BRG_DIV16_MASK ((uint)0x00000001) -#define CPM_BRG_DIV16_SHIFT 1 - -#define CPM_BRG_EXTC_BRGCLK 0 -#define CPM_BRG_EXTC_CLK3 1 -#define CPM_BRG_EXTC_CLK9 CPM_BRG_EXTC_CLK3 -#define CPM_BRG_EXTC_CLK5 2 -#define CPM_BRG_EXTC_CLK15 CPM_BRG_EXTC_CLK5 - -#define IM_BRGC1 ((uint *)0xf00119f0) -#define IM_BRGC2 ((uint *)0xf00119f4) -#define IM_BRGC3 ((uint *)0xf00119f8) -#define IM_BRGC4 ((uint *)0xf00119fc) -#define IM_BRGC5 ((uint *)0xf00115f0) -#define IM_BRGC6 ((uint *)0xf00115f4) -#define IM_BRGC7 ((uint *)0xf00115f8) -#define IM_BRGC8 ((uint *)0xf00115fc) - -/* - * External declarations - */ - -extern int Daq64xSampling; - -extern void Daq_BRG_Reset(uint brg); -extern void Daq_BRG_Run(uint brg); - -extern void Daq_BRG_Disable(uint brg); -extern void Daq_BRG_Enable(uint brg); - -extern uint Daq_BRG_Get_Div16(uint brg); -extern void Daq_BRG_Set_Div16(uint brg, uint div16); - -extern uint Daq_BRG_Get_Count(uint brg); -extern void Daq_BRG_Set_Count(uint brg, uint brg_cnt); - -extern uint Daq_BRG_Get_ExtClk(uint brg); -extern char* Daq_BRG_Get_ExtClk_Description(uint brg); -extern void Daq_BRG_Set_ExtClk(uint brg, uint extc); - -extern uint Daq_BRG_Rate(uint brg); - -extern uint Daq_Get_SampleRate(void); - -extern void Daq_Init_Clocks(int sample_rate, int sample_64x); -extern void Daq_Stop_Clocks(void); -extern void Daq_Start_Clocks(int sample_rate); -extern void Daq_Display_Clocks(void); diff --git a/board/sacsng/flash.c b/board/sacsng/flash.c deleted file mode 100644 index 686fb22..0000000 --- a/board/sacsng/flash.c +++ /dev/null @@ -1,507 +0,0 @@ -/* - * (C) Copyright 2001 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <configs/sacsng.h> - - -#undef DEBUG - -#ifndef CONFIG_ENV_ADDR -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET) -#endif -#ifndef CONFIG_ENV_SIZE -#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -#endif - - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH chips */ - -/*----------------------------------------------------------------------- - * Functions - */ -static ulong flash_get_size (vu_short *addr, flash_info_t *info); -static int write_word (flash_info_t *info, ulong dest, ulong data); - -/*----------------------------------------------------------------------- - */ - -unsigned long flash_init (void) -{ - unsigned long size_b0, size_b1; - int i; - - /* Init: no FLASHes known */ - for (i=0; i<CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - } - - size_b0 = flash_get_size((vu_short *)CONFIG_SYS_FLASH0_BASE, &flash_info[0]); - - if (flash_info[0].flash_id == FLASH_UNKNOWN) { - printf ("## Unknown FLASH on Bank 0 - Size = 0x%08lx = %ld MB\n", - size_b0, size_b0<<20); - } - - size_b1 = flash_get_size((vu_short *)CONFIG_SYS_FLASH1_BASE, &flash_info[1]); - -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE - /* monitor protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE+monitor_flash_len-1, - &flash_info[0]); -#endif - -#ifdef CONFIG_ENV_IS_IN_FLASH - /* ENV protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR+CONFIG_ENV_SIZE-1, - &flash_info[0]); -#endif - - if (size_b1) { -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE - /* monitor protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE+monitor_flash_len-1, - &flash_info[1]); -#endif - -#ifdef CONFIG_ENV_IS_IN_FLASH - /* ENV protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR+CONFIG_ENV_SIZE-1, - &flash_info[1]); -#endif - } else { - flash_info[1].flash_id = FLASH_UNKNOWN; - flash_info[1].sector_count = -1; - } - - flash_info[0].size = size_b0; - flash_info[1].size = size_b1; - - /* - * We only report the primary flash for U-Boot's use. - */ - return (size_b0); -} - -/*----------------------------------------------------------------------- - */ -void flash_print_info (flash_info_t *info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_AMD: printf ("AMD "); break; - case FLASH_MAN_FUJ: printf ("FUJITSU "); break; - default: printf ("Unknown Vendor "); break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_AM400B: printf ("AM29LV400B (4 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM400T: printf ("AM29LV400T (4 Mbit, top boot sector)\n"); - break; - case FLASH_AM800B: printf ("AM29LV800B (8 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM800T: printf ("AM29LV800T (8 Mbit, top boot sector)\n"); - break; - case FLASH_AM160B: printf ("AM29LV160B (16 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM160T: printf ("AM29LV160T (16 Mbit, top boot sector)\n"); - break; - case FLASH_AM320B: printf ("AM29LV320B (32 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM320T: printf ("AM29LV320T (32 Mbit, top boot sector)\n"); - break; - default: printf ("Unknown Chip Type\n"); - break; - } - - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); - - printf (" Sector Start Addresses:"); - for (i=0; i<info->sector_count; ++i) { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", - info->start[i], - info->protect[i] ? " (RO)" : " " - ); - } - printf ("\n"); - return; -} - -/*----------------------------------------------------------------------- - */ - - -/*----------------------------------------------------------------------- - */ - -/* - * The following code cannot be run from FLASH! - */ - -static ulong flash_get_size (vu_short *addr, flash_info_t *info) -{ - short i; - ushort value; - ulong base = (ulong)addr; - - /* Write auto select command: read Manufacturer ID */ - addr[0x0555] = 0xAAAA; - addr[0x02AA] = 0x5555; - addr[0x0555] = 0x9090; - __asm__ __volatile__(" sync\n "); - - value = addr[0]; -#ifdef DEBUG - printf("Flash manufacturer 0x%04X\n", value); -#endif - - if(value == (ushort)AMD_MANUFACT) { - info->flash_id = FLASH_MAN_AMD; - } else if (value == (ushort)FUJ_MANUFACT) { - info->flash_id = FLASH_MAN_FUJ; - } else { -#ifdef DEBUG - printf("Unknown flash manufacturer 0x%04X\n", value); -#endif - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - return (0); /* no or unknown flash */ - } - - value = addr[1]; /* device ID */ -#ifdef DEBUG - printf("Flash type 0x%04X\n", value); -#endif - - if(value == (ushort)AMD_ID_LV400T) { - info->flash_id += FLASH_AM400T; - info->sector_count = 11; - info->size = 0x00080000; /* => 0.5 MB */ - } else if(value == (ushort)AMD_ID_LV400B) { - info->flash_id += FLASH_AM400B; - info->sector_count = 11; - info->size = 0x00080000; /* => 0.5 MB */ - } else if(value == (ushort)AMD_ID_LV800T) { - info->flash_id += FLASH_AM800T; - info->sector_count = 19; - info->size = 0x00100000; /* => 1 MB */ - } else if(value == (ushort)AMD_ID_LV800B) { - info->flash_id += FLASH_AM800B; - info->sector_count = 19; - info->size = 0x00100000; /* => 1 MB */ - } else if(value == (ushort)AMD_ID_LV160T) { - info->flash_id += FLASH_AM160T; - info->sector_count = 35; - info->size = 0x00200000; /* => 2 MB */ - } else if(value == (ushort)AMD_ID_LV160B) { - info->flash_id += FLASH_AM160B; - info->sector_count = 35; - info->size = 0x00200000; /* => 2 MB */ - } else if(value == (ushort)AMD_ID_LV320T) { - info->flash_id += FLASH_AM320T; - info->sector_count = 67; - info->size = 0x00400000; /* => 4 MB */ - } else if(value == (ushort)AMD_ID_LV320B) { - info->flash_id += FLASH_AM320B; - info->sector_count = 67; - info->size = 0x00400000; /* => 4 MB */ - } else { -#ifdef DEBUG - printf("Unknown flash type 0x%04X\n", value); - info->size = CONFIG_SYS_FLASH_SIZE; -#else - info->flash_id = FLASH_UNKNOWN; - return (0); /* => no or unknown flash */ -#endif - } - - /* set up sector start address table */ - if (info->flash_id & FLASH_BTYPE) { - /* set sector offsets for bottom boot block type */ - info->start[0] = base + 0x00000000; - info->start[1] = base + 0x00004000; - info->start[2] = base + 0x00006000; - info->start[3] = base + 0x00008000; - for (i = 4; i < info->sector_count; i++) { - info->start[i] = base + ((i - 3) * 0x00010000); - } - } else { - /* set sector offsets for top boot block type */ - i = info->sector_count - 1; - info->start[i--] = base + info->size - 0x00004000; - info->start[i--] = base + info->size - 0x00006000; - info->start[i--] = base + info->size - 0x00008000; - for (; i >= 0; i--) { - info->start[i] = base + (i * 0x00010000); - } - } - - /* check for protected sectors */ - for (i = 0; i < info->sector_count; i++) { - /* read sector protection at sector address, (A7 .. A0) = 0x02 */ - /* D0 = 1 if protected */ - addr = (volatile unsigned short *)(info->start[i]); - info->protect[i] = addr[2] & 1; - } - - /* - * Prevent writes to uninitialized FLASH. - */ - if (info->flash_id != FLASH_UNKNOWN) { - addr = (volatile unsigned short *)info->start[0]; - - } - - addr[0] = 0xF0F0; /* reset bank */ - __asm__ __volatile__(" sync\n "); - return (info->size); -} - - -/*----------------------------------------------------------------------- - */ - -int flash_erase (flash_info_t *info, int s_first, int s_last) -{ - vu_short *addr = (vu_short*)(info->start[0]); - int flag, prot, sect, l_sect; - ulong start, now, last; - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - if ((info->flash_id == FLASH_UNKNOWN) || - (info->flash_id > FLASH_AMD_COMP)) { - printf ("Can't erase unknown flash type %08lx - aborted\n", - info->flash_id); - return 1; - } - - prot = 0; - for (sect=s_first; sect<=s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - printf ("\n"); - } - - l_sect = -1; - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - addr[0x0555] = 0xAAAA; - addr[0x02AA] = 0x5555; - addr[0x0555] = 0x8080; - addr[0x0555] = 0xAAAA; - addr[0x02AA] = 0x5555; - __asm__ __volatile__(" sync\n "); - - /* Start erase on unprotected sectors */ - for (sect = s_first; sect<=s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - addr = (vu_short*)(info->start[sect]); - addr[0] = 0x3030; - l_sect = sect; - } - } - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - - /* - * We wait for the last triggered sector - */ - if (l_sect < 0) - goto DONE; - - start = get_timer (0); - last = start; - addr = (vu_short*)(info->start[l_sect]); - while ((addr[0] & 0x0080) != 0x0080) { - if ((now = get_timer(start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - addr[0] = 0xF0F0; /* reset bank */ - __asm__ __volatile__(" sync\n "); - return 1; - } - /* show that we're waiting */ - if ((now - last) > 1000) { /* every second */ - putc ('.'); - last = now; - } - } - -DONE: - /* reset to read mode */ - addr = (vu_short*)info->start[0]; - addr[0] = 0xF0F0; /* reset bank */ - __asm__ __volatile__(" sync\n "); - - printf (" done\n"); - return 0; -} - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ - -int write_buff (flash_info_t *info, uchar *src, ulong addr, ulong cnt) -{ - ulong cp, wp, data; - int i, l, rc; - - wp = (addr & ~3); /* get lower word aligned address */ - - /* - * handle unaligned start bytes - */ - if ((l = addr - wp) != 0) { - data = 0; - for (i=0, cp=wp; i<l; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - for (; i<4 && cnt>0; ++i) { - data = (data << 8) | *src++; - --cnt; - ++cp; - } - for (; cnt==0 && i<4; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - - if ((rc = write_word(info, wp, data)) != 0) { - return (rc); - } - wp += 4; - } - - /* - * handle word aligned part - */ - while (cnt >= 4) { - data = 0; - for (i=0; i<4; ++i) { - data = (data << 8) | *src++; - } - if ((rc = write_word(info, wp, data)) != 0) { - return (rc); - } - wp += 4; - cnt -= 4; - } - - if (cnt == 0) { - return (0); - } - - /* - * handle unaligned tail bytes - */ - data = 0; - for (i=0, cp=wp; i<4 && cnt>0; ++i, ++cp) { - data = (data << 8) | *src++; - --cnt; - } - for (; i<4; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - - return (write_word(info, wp, data)); -} - -/*----------------------------------------------------------------------- - * Write a word to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_word (flash_info_t *info, ulong dest, ulong data) -{ - vu_short *addr = (vu_short*)(info->start[0]); - ulong start; - int flag; - int j; - - /* Check if Flash is (sufficiently) erased */ - if (((*(vu_long *)dest) & data) != data) { - return (2); - } - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - /* The original routine was designed to write 32 bit words to - * 32 bit wide memory. We have 16 bit wide memory so we do - * two writes. We write the LSB first at dest+2 and then the - * MSB at dest (lousy big endian). - */ - dest += 2; - for(j = 0; j < 2; j++) { - addr[0x0555] = 0xAAAA; - addr[0x02AA] = 0x5555; - addr[0x0555] = 0xA0A0; - __asm__ __volatile__(" sync\n "); - - *((vu_short *)dest) = (ushort)data; - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* data polling for D7 */ - start = get_timer (0); - while (*(vu_short *)dest != (ushort)data) { - if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - return (1); - } - } - dest -= 2; - data >>= 16; - } - return (0); -} - -/*----------------------------------------------------------------------- - */ diff --git a/board/sacsng/ioconfig.h b/board/sacsng/ioconfig.h deleted file mode 100644 index ac8f152..0000000 --- a/board/sacsng/ioconfig.h +++ /dev/null @@ -1,217 +0,0 @@ -/* - * I/O Port configuration table - * - * If conf is 1, then that port pin will be configured at boot time - * according to the five values podr/pdir/ppar/psor/pdat for that entry - */ - -#ifdef SKIP -#undef SKIP -#endif - -#ifdef CONF -#undef CONF -#endif - -#ifdef DIN -#undef DIN -#endif - -#ifdef DOUT -#undef DOUT -#endif - -#ifdef GPIO -#undef GPIO -#endif - -#ifdef SPEC -#undef SPEC -#endif - -#ifdef ACTV -#undef ACTV -#endif - -#ifdef OPEN -#undef OPEN -#endif - -#define SKIP 0 /* SKIP over this port */ -#define CONF 1 /* CONFiguration the port */ - -#define DIN 0 /* PDIRx 0: Direction IN */ -#define DOUT 1 /* PDIRx 1: Direction OUT */ - -#define GPIO 0 /* PPARx 0: General Purpose I/O */ -#define SPEC 1 /* PPARx 1: dedicated to a peripheral function, */ - /* i.e. the port has a SPECial use. */ - -#define ACTV 0 /* PODRx 0: ACTiVely driven as an output */ -#define OPEN 1 /* PODRx 1: OPEN-drain driver */ - -const iop_conf_t iop_conf_tab[4][32] = { - - /* Port A configuration */ - { /* conf ppar psor pdir podr pdat */ - /* PA31 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* RODIS8* */ - /* PA30 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* RODIS7* */ - /* PA29 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* RODIS6* */ - /* PA28 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* RODIS5* */ - /* PA27 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* RODIS4* */ - /* PA26 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* RODIS3* */ - /* PA25 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* RODIS2* */ - /* PA24 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* RODIS1* */ - /* PA23 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* ODIS_EN* */ - /* PA22 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* STLED2_EN* */ - /* PA21 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* STLED1_EN* */ - /* PA20 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* PLED3_EN* */ - /* PA19 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* PLED2_EN* */ - /* PA18 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* PLED1_EN* */ - /* PA17 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PA16 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* DAC_RST* */ - /* PA15 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* CH34SDATA_PU */ - /* PA14 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* CH12SDATA_PU */ - /* PA13 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* SLRCLK_EN* */ - /* PA12 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* MTRX_4ACDC* */ - /* PA11 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* MTRX_4TEDS* */ - /* PA10 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* MTRX_4XTDS* */ - /* PA9 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* MTRX_3ACDC* */ - /* PA8 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* MTRX_3TEDS* */ - /* PA7 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* MTRX_3XTDS* */ - /* PA6 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* MTRX_2ACDC* */ - /* PA5 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* MTRX_2TEDS* */ - /* PA4 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* MTRX_2XTDS* */ - /* PA3 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PA2 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* MTRX_1ACDC* */ - /* PA1 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* MTRX_1TEDS* */ - /* PA0 */ { CONF, GPIO, 0, DOUT, ACTV, 1 } /* MTRX_1XTDS* */ - }, - - /* Port B configuration */ - { /* conf ppar psor pdir podr pdat */ - /* PB31 */ { CONF, SPEC, 0, DOUT, ACTV, 0 }, /* FCC2 MII_TX_ER */ - /* PB30 */ { CONF, SPEC, 0, DIN, ACTV, 0 }, /* FCC2 MII_RX_DV */ - /* PB29 */ { CONF, SPEC, 1, DOUT, ACTV, 0 }, /* FCC2 MII_TX_EN */ - /* PB28 */ { CONF, SPEC, 0, DIN, ACTV, 0 }, /* FCC2 MII_RX_ER */ - /* PB27 */ { CONF, SPEC, 0, DIN, ACTV, 0 }, /* FCC2 MII_COL */ - /* PB26 */ { CONF, SPEC, 0, DIN, ACTV, 0 }, /* FCC2 MII_CRS */ - /* PB25 */ { CONF, SPEC, 0, DOUT, ACTV, 0 }, /* FCC2 MII_TXD3 */ - /* PB24 */ { CONF, SPEC, 0, DOUT, ACTV, 0 }, /* FCC2 MII_TXD2 */ - /* PB23 */ { CONF, SPEC, 0, DOUT, ACTV, 0 }, /* FCC2 MII_TXD1 */ - /* PB22 */ { CONF, SPEC, 0, DOUT, ACTV, 0 }, /* FCC2 MII_TXD0 */ - /* PB21 */ { CONF, SPEC, 0, DIN, ACTV, 0 }, /* FCC2 MII_RXD0 */ - /* PB20 */ { CONF, SPEC, 0, DIN, ACTV, 0 }, /* FCC2 MII_RXD1 */ - /* PB19 */ { CONF, SPEC, 0, DIN, ACTV, 0 }, /* FCC2 MII_RXD2 */ - /* PB18 */ { CONF, SPEC, 0, DIN, ACTV, 0 }, /* FCC2 MII_RXD3 */ - /* PB17 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PB16 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PB15 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PB14 */ { CONF, SPEC, 1, DIN, ACTV, 0 }, /* L1RXDC1, BSDATA_ADC12 */ - /* PB13 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PB12 */ { CONF, SPEC, 1, DIN, ACTV, 0 }, /* L1RSYNCC1, LRCLK */ - /* PB11 */ { CONF, SPEC, 1, DIN, ACTV, 0 }, /* L1TXDD1, RSDATA_DAC12 */ - /* PB10 */ { CONF, SPEC, 1, DIN, ACTV, 0 }, /* L1RXDD1, BSDATA_ADC34 */ - /* PB9 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PB8 */ { CONF, SPEC, 1, DIN, ACTV, 0 }, /* L1RSYNCD1, LRCLK */ - /* PB7 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PB6 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* XCITE_SHDN */ - /* PB5 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* TRIGGER */ - /* PB4 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* ARM */ - /* PB3 */ { SKIP, GPIO, 0, DIN, ACTV, 0 }, /* pin doesn't exist */ - /* PB2 */ { SKIP, GPIO, 0, DIN, ACTV, 0 }, /* pin doesn't exist */ - /* PB1 */ { SKIP, GPIO, 0, DIN, ACTV, 0 }, /* pin doesn't exist */ - /* PB0 */ { SKIP, GPIO, 0, DIN, ACTV, 0 } /* pin doesn't exist */ - }, - - /* Port C */ - { /* conf ppar psor pdir podr pdat */ - /* PC31 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PC30 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PC29 */ { CONF, SPEC, 0, DIN, ACTV, 0 }, /* CLK3, MCLK */ - /* PC28 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* TOUT2* */ -#ifdef QQQ - /* PC28 */ { CONF, SPEC, 0, DOUT, ACTV, 0 }, /* TOUT2* */ -#endif - /* PC27 */ { CONF, SPEC, 0, DIN, ACTV, 0 }, /* CLK5, SCLK */ - /* PC26 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PC25 */ { CONF, SPEC, 0, DIN, ACTV, 0 }, /* CLK7, SCLK */ - /* PC24 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PC23 */ { CONF, SPEC, 0, DIN, ACTV, 0 }, /* CLK9, MCLK */ - /* PC22 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PC21 */ { CONF, SPEC, 0, DOUT, ACTV, 0 }, /* BRGO6 (LRCLK) */ - /* PC20 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PC19 */ { CONF, SPEC, 0, DIN, ACTV, 0 }, /* CLK13, MII_RXCLK */ - /* PC18 */ { CONF, SPEC, 0, DIN, ACTV, 0 }, /* CLK14, MII_TXCLK */ - /* PC17 */ { CONF, SPEC, 0, DOUT, ACTV, 0 }, /* BRGO8 (SCLK) */ - /* PC16 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PC15 */ { CONF, SPEC, 0, DOUT, ACTV, 0 }, /* SMC2_TX */ - /* PC14 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PC13 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PC12 */ { CONF, SPEC, 0, DOUT, ACTV, 0 }, /* TDM_STRB3 */ - /* PC11 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PC10 */ { CONF, SPEC, 1, DOUT, ACTV, 0 }, /* TDM_STRB4 */ - /* PC9 */ { CONF, GPIO, 0, DIN, ACTV, 0 }, /* BPDIS_IN3 */ - /* PC8 */ { CONF, GPIO, 0, DIN, ACTV, 0 }, /* BPDIS_IN2 */ - /* PC7 */ { CONF, GPIO, 0, DIN, ACTV, 0 }, /* BPDIS_IN1 */ - /* PC6 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PC5 */ { CONF, GPIO, 0, DIN, ACTV, 0 }, /* BTST_IN2* */ - /* PC4 */ { CONF, GPIO, 0, DIN, ACTV, 0 }, /* BTST_IN1* */ - /* PC3 */ { CONF, GPIO, 0, DIN, ACTV, 0 }, /* MUSH_STAT */ - /* PC2 */ { CONF, GPIO, 0, DIN, ACTV, 0 }, /* OUTDRV_STAT */ - /* PC1 */ { CONF, GPIO, 0, DOUT, OPEN, 1 }, /* PHY_MDIO */ - /* PC0 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* PHY_MDC */ - }, - - /* Port D */ - { /* conf ppar psor pdir podr pdat */ - /* PD31 */ { CONF, SPEC, 0, DIN, ACTV, 0 }, /* SCC1_RX */ - /* PD30 */ { CONF, SPEC, 1, DOUT, ACTV, 0 }, /* SCC1_TX */ - /* PD29 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PD28 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PD27 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PD26 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PD25 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PD24 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PD23 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PD22 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PD21 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PD20 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* SPI_ADC_CS* */ - /* PD19 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* SPI_DAC_CS* */ -#if defined(CONFIG_SOFT_SPI) - /* PD18 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* SPI_CLK */ - /* PD17 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* SPI_MOSI */ - /* PD16 */ { CONF, GPIO, 0, DIN, ACTV, 0 }, /* SPI_MISO */ -#else - /* PD18 */ { CONF, SPEC, 1, DOUT, ACTV, 0 }, /* SPI_CLK */ - /* PD17 */ { CONF, SPEC, 1, DOUT, ACTV, 0 }, /* SPI_MOSI */ - /* PD16 */ { CONF, SPEC, 1, DIN, ACTV, 0 }, /* SPI_MISO */ -#endif -#if defined(CONFIG_SYS_I2C_SOFT) - /* PD15 */ { CONF, GPIO, 0, DOUT, OPEN, 1 }, /* I2C_SDA */ - /* PD14 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* I2C_SCL */ -#else -#if defined(CONFIG_HARD_I2C) - /* PD15 */ { CONF, SPEC, 1, DIN, OPEN, 0 }, /* I2C_SDA */ - /* PD14 */ { CONF, SPEC, 1, DIN, OPEN, 0 }, /* I2C_SCL */ -#else /* normal I/O port pins */ - /* PD15 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* I2C_SDA */ - /* PD14 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* I2C_SCL */ -#endif -#endif - /* PD13 */ { CONF, SPEC, 0, DOUT, ACTV, 0 }, /* TDM_STRB1 */ - /* PD12 */ { CONF, SPEC, 0, DOUT, ACTV, 0 }, /* TDM_STRB2 */ - /* PD11 */ { CONF, GPIO, 0, DOUT, ACTV, 0 }, /* N/C */ - /* PD10 */ { CONF, SPEC, 1, DOUT, ACTV, 0 }, /* BRGO4 (MCLK) */ - /* PD9 */ { CONF, SPEC, 0, DOUT, ACTV, 0 }, /* SMC1_TX */ - /* PD8 */ { CONF, SPEC, 0, DIN, ACTV, 0 }, /* SMC1_RX */ - /* PD7 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* N/C */ - /* PD6 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* N/C */ - /* PD5 */ { CONF, GPIO, 0, DOUT, ACTV, 1 }, /* N/C */ - /* PD4 */ { CONF, SPEC, 1, DOUT, ACTV, 1 }, /* SMC2_RX */ - /* PD3 */ { SKIP, GPIO, 0, DIN, ACTV, 0 }, /* pin doesn't exist */ - /* PD2 */ { SKIP, GPIO, 0, DIN, ACTV, 0 }, /* pin doesn't exist */ - /* PD1 */ { SKIP, GPIO, 0, DIN, ACTV, 0 }, /* pin doesn't exist */ - /* PD0 */ { SKIP, GPIO, 0, DIN, ACTV, 0 } /* pin doesn't exist */ - } -}; diff --git a/board/sacsng/sacsng.c b/board/sacsng/sacsng.c deleted file mode 100644 index 91c4987..0000000 --- a/board/sacsng/sacsng.c +++ /dev/null @@ -1,848 +0,0 @@ -/* - * (C) Copyright 2002 - * Custom IDEAS, Inc. <www.cideas.com> - * Gerald Van Baren vanbaren@cideas.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/u-boot.h> -#include <ioports.h> -#include <mpc8260.h> -#include <i2c.h> -#include <spi.h> -#include <command.h> - -#ifdef CONFIG_SHOW_BOOT_PROGRESS -#include <status_led.h> -#endif - -#ifdef CONFIG_ETHER_LOOPBACK_TEST -extern void eth_loopback_test(void); -#endif /* CONFIG_ETHER_LOOPBACK_TEST */ - -#include "clkinit.h" -#include "ioconfig.h" /* I/O configuration table */ - -/* - * PBI Page Based Interleaving - * PSDMR_PBI page based interleaving - * 0 bank based interleaving - * External Address Multiplexing (EAMUX) adds a clock to address cycles - * (this can help with marginal board layouts) - * PSDMR_EAMUX adds a clock - * 0 no extra clock - * Buffer Command (BUFCMD) adds a clock to command cycles. - * PSDMR_BUFCMD adds a clock - * 0 no extra clock - */ -#define CONFIG_PBI PSDMR_PBI -#define PESSIMISTIC_SDRAM 0 -#define EAMUX 0 /* EST requires EAMUX */ -#define BUFCMD 0 - -/* - * ADC/DAC Defines: - */ -#define INITIAL_SAMPLE_RATE 10016 /* Initial Daq sample rate */ -#define INITIAL_RIGHT_JUST 0 /* Initial DAC right justification */ -#define INITIAL_MCLK_DIVIDE 0 /* Initial MCLK Divide */ -#define INITIAL_SAMPLE_64X 1 /* Initial 64x clocking mode */ -#define INITIAL_SAMPLE_128X 0 /* Initial 128x clocking mode */ - -/* - * ADC Defines: - */ -#define I2C_ADC_1_ADDR 0x0E /* I2C Address of the ADC #1 */ -#define I2C_ADC_2_ADDR 0x0F /* I2C Address of the ADC #2 */ - -#define ADC_SDATA1_MASK 0x00020000 /* PA14 - CH12SDATA_PU */ -#define ADC_SDATA2_MASK 0x00010000 /* PA15 - CH34SDATA_PU */ - -#define ADC_VREF_CAP 100 /* VREF capacitor in uF */ -#define ADC_INITIAL_DELAY (10 * ADC_VREF_CAP) /* 10 usec per uF, in usec */ -#define ADC_SDATA_DELAY 100 /* ADC SDATA release delay in usec */ -#define ADC_CAL_DELAY (1000000 / INITIAL_SAMPLE_RATE * 4500) - /* Wait at least 4100 LRCLK's */ - -#define ADC_REG1_FRAME_START 0x80 /* Frame start */ -#define ADC_REG1_GROUND_CAL 0x40 /* Ground calibration enable */ -#define ADC_REG1_ANA_MOD_PDOWN 0x20 /* Analog modulator section in power down */ -#define ADC_REG1_DIG_MOD_PDOWN 0x10 /* Digital modulator section in power down */ - -#define ADC_REG2_128x 0x80 /* Oversample at 128x */ -#define ADC_REG2_CAL 0x40 /* System calibration enable */ -#define ADC_REG2_CHANGE_SIGN 0x20 /* Change sign enable */ -#define ADC_REG2_LR_DISABLE 0x10 /* Left/Right output disable */ -#define ADC_REG2_HIGH_PASS_DIS 0x08 /* High pass filter disable */ -#define ADC_REG2_SLAVE_MODE 0x04 /* Slave mode */ -#define ADC_REG2_DFS 0x02 /* Digital format select */ -#define ADC_REG2_MUTE 0x01 /* Mute */ - -#define ADC_REG7_ADDR_ENABLE 0x80 /* Address enable */ -#define ADC_REG7_PEAK_ENABLE 0x40 /* Peak enable */ -#define ADC_REG7_PEAK_UPDATE 0x20 /* Peak update */ -#define ADC_REG7_PEAK_FORMAT 0x10 /* Peak display format */ -#define ADC_REG7_DIG_FILT_PDOWN 0x04 /* Digital filter power down enable */ -#define ADC_REG7_FIR2_IN_EN 0x02 /* External FIR2 input enable */ -#define ADC_REG7_PSYCHO_EN 0x01 /* External pyscho filter input enable */ - -/* - * DAC Defines: - */ - -#define I2C_DAC_ADDR 0x11 /* I2C Address of the DAC */ - -#define DAC_RST_MASK 0x00008000 /* PA16 - DAC_RST* */ -#define DAC_RESET_DELAY 100 /* DAC reset delay in usec */ -#define DAC_INITIAL_DELAY 5000 /* DAC initialization delay in usec */ - -#define DAC_REG1_AMUTE 0x80 /* Auto-mute */ - -#define DAC_REG1_LEFT_JUST_24_BIT (0 << 4) /* Fmt 0: Left justified 24 bit */ -#define DAC_REG1_I2S_24_BIT (1 << 4) /* Fmt 1: I2S up to 24 bit */ -#define DAC_REG1_RIGHT_JUST_16BIT (2 << 4) /* Fmt 2: Right justified 16 bit */ -#define DAC_REG1_RIGHT_JUST_24BIT (3 << 4) /* Fmt 3: Right justified 24 bit */ -#define DAC_REG1_RIGHT_JUST_20BIT (4 << 4) /* Fmt 4: Right justified 20 bit */ -#define DAC_REG1_RIGHT_JUST_18BIT (5 << 4) /* Fmt 5: Right justified 18 bit */ - -#define DAC_REG1_DEM_NO (0 << 2) /* No De-emphasis */ -#define DAC_REG1_DEM_44KHZ (1 << 2) /* 44.1KHz De-emphasis */ -#define DAC_REG1_DEM_48KHZ (2 << 2) /* 48KHz De-emphasis */ -#define DAC_REG1_DEM_32KHZ (3 << 2) /* 32KHz De-emphasis */ - -#define DAC_REG1_SINGLE 0 /* 4- 50KHz sample rate */ -#define DAC_REG1_DOUBLE 1 /* 50-100KHz sample rate */ -#define DAC_REG1_QUAD 2 /* 100-200KHz sample rate */ -#define DAC_REG1_DSD 3 /* Direct Stream Data, DSD */ - -#define DAC_REG5_INVERT_A 0x80 /* Invert channel A */ -#define DAC_REG5_INVERT_B 0x40 /* Invert channel B */ -#define DAC_REG5_I2C_MODE 0x20 /* Control port (I2C) mode */ -#define DAC_REG5_POWER_DOWN 0x10 /* Power down mode */ -#define DAC_REG5_MUTEC_A_B 0x08 /* Mutec A=B */ -#define DAC_REG5_FREEZE 0x04 /* Freeze */ -#define DAC_REG5_MCLK_DIV 0x02 /* MCLK divide by 2 */ -#define DAC_REG5_RESERVED 0x01 /* Reserved */ - -/* - * Check Board Identity: - */ - -int checkboard(void) -{ - printf("SACSng\n"); - - return 0; -} - -phys_size_t initdram(int board_type) -{ - volatile immap_t *immap = (immap_t *)CONFIG_SYS_IMMR; - volatile memctl8260_t *memctl = &immap->im_memctl; - volatile uchar c = 0; - volatile uchar *ramaddr = (uchar *)(CONFIG_SYS_SDRAM_BASE + 0x8); - uint psdmr = CONFIG_SYS_PSDMR; - int i; - uint psrt = 14; /* for no SPD */ - uint chipselects = 1; /* for no SPD */ - uint sdram_size = CONFIG_SYS_SDRAM0_SIZE * 1024 * 1024; /* for no SPD */ - uint or = CONFIG_SYS_OR2_PRELIM; /* for no SPD */ - -#ifdef SDRAM_SPD_ADDR - uint data_width; - uint rows; - uint banks; - uint cols; - uint caslatency; - uint width; - uint rowst; - uint sdam; - uint bsma; - uint sda10; - u_char data; - u_char cksum; - int j; -#endif - -#ifdef SDRAM_SPD_ADDR - /* Keep the compiler from complaining about potentially uninitialized vars */ - data_width = chipselects = rows = banks = cols = caslatency = psrt = - 0; - - /* - * Read the SDRAM SPD EEPROM via I2C. - */ - i2c_read(SDRAM_SPD_ADDR, 0, 1, &data, 1); - cksum = data; - for (j = 1; j < 64; j++) { /* read only the checksummed bytes */ - /* note: the I2C address autoincrements when alen == 0 */ - i2c_read(SDRAM_SPD_ADDR, 0, 0, &data, 1); - if (j == 5) - chipselects = data & 0x0F; - else if (j == 6) - data_width = data; - else if (j == 7) - data_width |= data << 8; - else if (j == 3) - rows = data & 0x0F; - else if (j == 4) - cols = data & 0x0F; - else if (j == 12) { - /* - * Refresh rate: this assumes the prescaler is set to - * approximately 1uSec per tick. - */ - switch (data & 0x7F) { - default: - case 0: - psrt = 14; /* 15.625uS */ - break; - case 1: - psrt = 2; /* 3.9uS */ - break; - case 2: - psrt = 6; /* 7.8uS */ - break; - case 3: - psrt = 29; /* 31.3uS */ - break; - case 4: - psrt = 60; /* 62.5uS */ - break; - case 5: - psrt = 120; /* 125uS */ - break; - } - } else if (j == 17) - banks = data; - else if (j == 18) { - caslatency = 3; /* default CL */ -#if(PESSIMISTIC_SDRAM) - if ((data & 0x04) != 0) - caslatency = 3; - else if ((data & 0x02) != 0) - caslatency = 2; - else if ((data & 0x01) != 0) - caslatency = 1; -#else - if ((data & 0x01) != 0) - caslatency = 1; - else if ((data & 0x02) != 0) - caslatency = 2; - else if ((data & 0x04) != 0) - caslatency = 3; -#endif - else { - printf("WARNING: Unknown CAS latency 0x%02X, using 3\n", data); - } - } else if (j == 63) { - if (data != cksum) { - printf("WARNING: Configuration data checksum failure:" " is 0x%02x, calculated 0x%02x\n", data, cksum); - } - } - cksum += data; - } - - /* We don't trust CL less than 2 (only saw it on an old 16MByte DIMM) */ - if (caslatency < 2) { - printf("WARNING: CL was %d, forcing to 2\n", caslatency); - caslatency = 2; - } - if (rows > 14) { - printf("WARNING: This doesn't look good, rows = %d, should be <= 14\n", - rows); - rows = 14; - } - if (cols > 11) { - printf("WARNING: This doesn't look good, columns = %d, should be <= 11\n", - cols); - cols = 11; - } - - if ((data_width != 64) && (data_width != 72)) { - printf("WARNING: SDRAM width unsupported, is %d, expected 64 or 72.\n", - data_width); - } - width = 3; /* 2^3 = 8 bytes = 64 bits wide */ - /* - * Convert banks into log2(banks) - */ - if (banks == 2) - banks = 1; - else if (banks == 4) - banks = 2; - else if (banks == 8) - banks = 3; - - sdram_size = 1 << (rows + cols + banks + width); - -#if(CONFIG_PBI == 0) /* bank-based interleaving */ - rowst = ((32 - 6) - (rows + cols + width)) * 2; -#else - rowst = 32 - (rows + banks + cols + width); -#endif - - or = ~(sdram_size - 1) | /* SDAM address mask */ - ((banks - 1) << 13) | /* banks per device */ - (rowst << 9) | /* rowst */ - ((rows - 9) << 6); /* numr */ - - memctl->memc_or2 = or; - - /* - * SDAM specifies the number of columns that are multiplexed - * (reference AN2165/D), defined to be (columns - 6) for page - * interleave, (columns - 8) for bank interleave. - * - * BSMA is 14 - max(rows, cols). The bank select lines come - * into play above the highest "address" line going into the - * the SDRAM. - */ -#if(CONFIG_PBI == 0) /* bank-based interleaving */ - sdam = cols - 8; - bsma = ((31 - width) - 14) - ((rows > cols) ? rows : cols); - sda10 = sdam + 2; -#else - sdam = cols - 6; - bsma = ((31 - width) - 14) - ((rows > cols) ? rows : cols); - sda10 = sdam; -#endif -#if(PESSIMISTIC_SDRAM) - psdmr = (CONFIG_PBI | PSDMR_RFEN | PSDMR_RFRC_16_CLK | - PSDMR_PRETOACT_8W | PSDMR_ACTTORW_8W | PSDMR_WRC_4C | - PSDMR_EAMUX | PSDMR_BUFCMD) | caslatency | - ((caslatency - 1) << 6) | /* LDOTOPRE is CL - 1 */ - (sdam << 24) | (bsma << 21) | (sda10 << 18); -#else - psdmr = (CONFIG_PBI | PSDMR_RFEN | PSDMR_RFRC_7_CLK | - PSDMR_PRETOACT_3W | /* 1 for 7E parts (fast PC-133) */ - PSDMR_ACTTORW_2W | /* 1 for 7E parts (fast PC-133) */ - PSDMR_WRC_1C | /* 1 clock + 7nSec */ - EAMUX | BUFCMD) | - caslatency | ((caslatency - 1) << 6) | /* LDOTOPRE is CL - 1 */ - (sdam << 24) | (bsma << 21) | (sda10 << 18); -#endif -#endif - - /* - * Quote from 8260 UM (10.4.2 SDRAM Power-On Initialization, 10-35): - * - * "At system reset, initialization software must set up the - * programmable parameters in the memory controller banks registers - * (ORx, BRx, P/LSDMR). After all memory parameters are configured, - * system software should execute the following initialization sequence - * for each SDRAM device. - * - * 1. Issue a PRECHARGE-ALL-BANKS command - * 2. Issue eight CBR REFRESH commands - * 3. Issue a MODE-SET command to initialize the mode register - * - * Quote from Micron MT48LC8M16A2 data sheet: - * - * "...the SDRAM requires a 100uS delay prior to issuing any - * command other than a COMMAND INHIBIT or NOP. Starting at some - * point during this 100uS period and continuing at least through - * the end of this period, COMMAND INHIBIT or NOP commands should - * be applied." - * - * "Once the 100uS delay has been satisfied with at least one COMMAND - * INHIBIT or NOP command having been applied, a /PRECHARGE command/ - * should be applied. All banks must then be precharged, thereby - * placing the device in the all banks idle state." - * - * "Once in the idle state, /two/ AUTO REFRESH cycles must be - * performed. After the AUTO REFRESH cycles are complete, the - * SDRAM is ready for mode register programming." - * - * (/emphasis/ mine, gvb) - * - * The way I interpret this, Micron start up sequence is: - * 1. Issue a PRECHARGE-BANK command (initial precharge) - * 2. Issue a PRECHARGE-ALL-BANKS command ("all banks ... precharged") - * 3. Issue two (presumably, doing eight is OK) CBR REFRESH commands - * 4. Issue a MODE-SET command to initialize the mode register - * - * -------- - * - * The initial commands are executed by setting P/LSDMR[OP] and - * accessing the SDRAM with a single-byte transaction." - * - * The appropriate BRx/ORx registers have already been set when we - * get here. The SDRAM can be accessed at the address CONFIG_SYS_SDRAM_BASE. - */ - - memctl->memc_mptpr = CONFIG_SYS_MPTPR; - memctl->memc_psrt = psrt; - - memctl->memc_psdmr = psdmr | PSDMR_OP_PREA; - *ramaddr = c; - - memctl->memc_psdmr = psdmr | PSDMR_OP_CBRR; - for (i = 0; i < 8; i++) - *ramaddr = c; - - memctl->memc_psdmr = psdmr | PSDMR_OP_MRW; - *ramaddr = c; - - memctl->memc_psdmr = psdmr | PSDMR_OP_NORM | PSDMR_RFEN; - *ramaddr = c; - - /* - * Do it a second time for the second set of chips if the DIMM has - * two chip selects (double sided). - */ - if (chipselects > 1) { - ramaddr += sdram_size; - - memctl->memc_br3 = CONFIG_SYS_BR3_PRELIM + sdram_size; - memctl->memc_or3 = or; - - memctl->memc_psdmr = psdmr | PSDMR_OP_PREA; - *ramaddr = c; - - memctl->memc_psdmr = psdmr | PSDMR_OP_CBRR; - for (i = 0; i < 8; i++) - *ramaddr = c; - - memctl->memc_psdmr = psdmr | PSDMR_OP_MRW; - *ramaddr = c; - - memctl->memc_psdmr = psdmr | PSDMR_OP_NORM | PSDMR_RFEN; - *ramaddr = c; - } - - /* return total ram size */ - return (sdram_size * chipselects); -} - -/*----------------------------------------------------------------------- - * Board Control Functions - */ -void board_poweroff(void) -{ - while (1); /* hang forever */ -} - - -#ifdef CONFIG_MISC_INIT_R -/* ------------------------------------------------------------------------- */ -int misc_init_r(void) -{ - /* - * Note: iop is used by the I2C macros, and iopa by the ADC/DAC initialization. - */ - volatile ioport_t *iopa = - ioport_addr((immap_t *)CONFIG_SYS_IMMR, 0 /* port A */ ); - volatile ioport_t *iop = - ioport_addr((immap_t *)CONFIG_SYS_IMMR, I2C_PORT); - - int reg; /* I2C register value */ - char *ep; /* Environment pointer */ - char str_buf[12]; /* sprintf output buffer */ - int sample_rate; /* ADC/DAC sample rate */ - int sample_64x; /* Use 64/4 clocking for the ADC/DAC */ - int sample_128x; /* Use 128/4 clocking for the ADC/DAC */ - int right_just; /* Is the data to the DAC right justified? */ - int mclk_divide; /* MCLK Divide */ - int quiet; /* Quiet or minimal output mode */ - - quiet = 0; - - if ((ep = getenv("quiet")) != NULL) - quiet = simple_strtol(ep, NULL, 10); - else - setenv("quiet", "0"); - - /* - * SACSng custom initialization: - * Start the ADC and DAC clocks, since the Crystal parts do not - * work on the I2C bus until the clocks are running. - */ - - sample_rate = INITIAL_SAMPLE_RATE; - if ((ep = getenv("DaqSampleRate")) != NULL) - sample_rate = simple_strtol(ep, NULL, 10); - - sample_64x = INITIAL_SAMPLE_64X; - sample_128x = INITIAL_SAMPLE_128X; - if ((ep = getenv("Daq64xSampling")) != NULL) { - sample_64x = simple_strtol(ep, NULL, 10); - if (sample_64x) - sample_128x = 0; - else - sample_128x = 1; - } else { - if ((ep = getenv("Daq128xSampling")) != NULL) { - sample_128x = simple_strtol(ep, NULL, 10); - if (sample_128x) - sample_64x = 0; - else - sample_64x = 1; - } - } - - /* - * Stop the clocks and wait for at least 1 LRCLK period - * to make sure the clocking has really stopped. - */ - Daq_Stop_Clocks(); - udelay((1000000 / sample_rate) * NUM_LRCLKS_TO_STABILIZE); - - /* - * Initialize the clocks with the new rates - */ - Daq_Init_Clocks(sample_rate, sample_64x); - sample_rate = Daq_Get_SampleRate(); - - /* - * Start the clocks and wait for at least 1 LRCLK period - * to make sure the clocking has become stable. - */ - Daq_Start_Clocks(sample_rate); - udelay((1000000 / sample_rate) * NUM_LRCLKS_TO_STABILIZE); - - sprintf(str_buf, "%d", sample_rate); - setenv("DaqSampleRate", str_buf); - - if (sample_64x) { - setenv("Daq64xSampling", "1"); - setenv("Daq128xSampling", NULL); - } else { - setenv("Daq64xSampling", NULL); - setenv("Daq128xSampling", "1"); - } - - /* - * Display the ADC/DAC clocking information - */ - if (!quiet) - Daq_Display_Clocks(); - - /* - * Determine the DAC data justification - */ - - right_just = INITIAL_RIGHT_JUST; - if ((ep = getenv("DaqDACRightJustified")) != NULL) - right_just = simple_strtol(ep, NULL, 10); - - sprintf(str_buf, "%d", right_just); - setenv("DaqDACRightJustified", str_buf); - - /* - * Determine the DAC MCLK Divide - */ - - mclk_divide = INITIAL_MCLK_DIVIDE; - if ((ep = getenv("DaqDACMClockDivide")) != NULL) - mclk_divide = simple_strtol(ep, NULL, 10); - - sprintf(str_buf, "%d", mclk_divide); - setenv("DaqDACMClockDivide", str_buf); - - /* - * Initializing the I2C address in the Crystal A/Ds: - * - * 1) Wait for VREF cap to settle (10uSec per uF) - * 2) Release pullup on SDATA - * 3) Write the I2C address to register 6 - * 4) Enable address matching by setting the MSB in register 7 - */ - - if (!quiet) - printf("Initializing the ADC...\n"); - - udelay(ADC_INITIAL_DELAY); /* 10uSec per uF of VREF cap */ - - iopa->pdat &= ~ADC_SDATA1_MASK; /* release SDATA1 */ - udelay(ADC_SDATA_DELAY); /* arbitrary settling time */ - - i2c_reg_write(0x00, 0x06, I2C_ADC_1_ADDR); /* set address */ - i2c_reg_write(I2C_ADC_1_ADDR, 0x07, /* turn on ADDREN */ - ADC_REG7_ADDR_ENABLE); - - i2c_reg_write(I2C_ADC_1_ADDR, 0x02, /* 128x, slave mode, !HPEN */ - (sample_64x ? 0 : ADC_REG2_128x) | - ADC_REG2_HIGH_PASS_DIS | ADC_REG2_SLAVE_MODE); - - reg = i2c_reg_read(I2C_ADC_1_ADDR, 0x06) & 0x7F; - if (reg != I2C_ADC_1_ADDR) { - printf("Init of ADC U10 failed: address is 0x%02X should be 0x%02X\n", - reg, I2C_ADC_1_ADDR); - } - - iopa->pdat &= ~ADC_SDATA2_MASK; /* release SDATA2 */ - udelay(ADC_SDATA_DELAY); /* arbitrary settling time */ - - /* set address (do not set ADDREN yet) */ - i2c_reg_write(0x00, 0x06, I2C_ADC_2_ADDR); - - i2c_reg_write(I2C_ADC_2_ADDR, 0x02, /* 64x, slave mode, !HPEN */ - (sample_64x ? 0 : ADC_REG2_128x) | - ADC_REG2_HIGH_PASS_DIS | ADC_REG2_SLAVE_MODE); - - reg = i2c_reg_read(I2C_ADC_2_ADDR, 0x06) & 0x7F; - if (reg != I2C_ADC_2_ADDR) { - printf("Init of ADC U15 failed: address is 0x%02X should be 0x%02X\n", - reg, I2C_ADC_2_ADDR); - } - - i2c_reg_write(I2C_ADC_1_ADDR, 0x01, /* set FSTART and GNDCAL */ - ADC_REG1_FRAME_START | ADC_REG1_GROUND_CAL); - - i2c_reg_write(I2C_ADC_1_ADDR, 0x02, /* Start calibration */ - (sample_64x ? 0 : ADC_REG2_128x) | - ADC_REG2_CAL | - ADC_REG2_HIGH_PASS_DIS | ADC_REG2_SLAVE_MODE); - - udelay(ADC_CAL_DELAY); /* a minimum of 4100 LRCLKs */ - i2c_reg_write(I2C_ADC_1_ADDR, 0x01, 0x00); /* remove GNDCAL */ - - /* - * Now that we have synchronized the ADC's, enable address - * selection on the second ADC as well as the first. - */ - i2c_reg_write(I2C_ADC_2_ADDR, 0x07, ADC_REG7_ADDR_ENABLE); - - /* - * Initialize the Crystal DAC - * - * Two of the config lines are used for I2C so we have to set them - * to the proper initialization state without inadvertantly - * sending an I2C "start" sequence. When we bring the I2C back to - * the normal state, we send an I2C "stop" sequence. - */ - if (!quiet) - printf("Initializing the DAC...\n"); - - /* - * Bring the I2C clock and data lines low for initialization - */ - I2C_SCL(0); - I2C_DELAY; - I2C_SDA(0); - I2C_ACTIVE; - I2C_DELAY; - - /* Reset the DAC */ - iopa->pdat &= ~DAC_RST_MASK; - udelay(DAC_RESET_DELAY); - - /* Release the DAC reset */ - iopa->pdat |= DAC_RST_MASK; - udelay(DAC_INITIAL_DELAY); - - /* - * Cause the DAC to: - * Enable control port (I2C mode) - * Going into power down - */ - i2c_reg_write(I2C_DAC_ADDR, 0x05, - DAC_REG5_I2C_MODE | DAC_REG5_POWER_DOWN); - - /* - * Cause the DAC to: - * Enable control port (I2C mode) - * Going into power down - * . MCLK divide by 1 - * . MCLK divide by 2 - */ - i2c_reg_write(I2C_DAC_ADDR, 0x05, - DAC_REG5_I2C_MODE | - DAC_REG5_POWER_DOWN | - (mclk_divide ? DAC_REG5_MCLK_DIV : 0)); - - /* - * Cause the DAC to: - * Auto-mute disabled - * . Format 0, left justified 24 bits - * . Format 3, right justified 24 bits - * No de-emphasis - * . Single speed mode - * . Double speed mode - */ - i2c_reg_write(I2C_DAC_ADDR, 0x01, - (right_just ? DAC_REG1_RIGHT_JUST_24BIT : - DAC_REG1_LEFT_JUST_24_BIT) | - DAC_REG1_DEM_NO | - (sample_rate >= - 50000 ? DAC_REG1_DOUBLE : DAC_REG1_SINGLE)); - - sprintf(str_buf, "%d", - sample_rate >= 50000 ? DAC_REG1_DOUBLE : DAC_REG1_SINGLE); - setenv("DaqDACFunctionalMode", str_buf); - - /* - * Cause the DAC to: - * Enable control port (I2C mode) - * Remove power down - * . MCLK divide by 1 - * . MCLK divide by 2 - */ - i2c_reg_write(I2C_DAC_ADDR, 0x05, - DAC_REG5_I2C_MODE | - (mclk_divide ? DAC_REG5_MCLK_DIV : 0)); - - /* - * Create a I2C stop condition: - * low->high on data while clock is high. - */ - I2C_SCL(1); - I2C_DELAY; - I2C_SDA(1); - I2C_DELAY; - I2C_TRISTATE; - - if (!quiet) - printf("\n"); -#ifdef CONFIG_ETHER_LOOPBACK_TEST - /* - * Run the Ethernet loopback test - */ - eth_loopback_test(); -#endif /* CONFIG_ETHER_LOOPBACK_TEST */ - -#ifdef CONFIG_SHOW_BOOT_PROGRESS - /* - * Turn off the RED fail LED now that we are up and running. - */ - status_led_set(STATUS_LED_RED, STATUS_LED_OFF); -#endif - - return 0; -} - -#ifdef CONFIG_SHOW_BOOT_PROGRESS -/* - * Show boot status: flash the LED if something goes wrong, indicating - * that last thing that worked and thus, by implication, what is broken. - * - * This stores the last OK value in RAM so this will not work properly - * before RAM is initialized. Since it is being used for indicating - * boot status (i.e. after RAM is initialized), that is OK. - */ -static void flash_code(uchar number, uchar modulo, uchar digits) -{ - int j; - - /* - * Recursively do upper digits. - */ - if (digits > 1) - flash_code(number / modulo, modulo, digits - 1); - - number = number % modulo; - - /* - * Zero is indicated by one long flash (dash). - */ - if (number == 0) { - status_led_set(STATUS_LED_BOOT, STATUS_LED_ON); - udelay(1000000); - status_led_set(STATUS_LED_BOOT, STATUS_LED_OFF); - udelay(200000); - } else { - /* - * Non-zero is indicated by short flashes, one per count. - */ - for (j = 0; j < number; j++) { - status_led_set(STATUS_LED_BOOT, STATUS_LED_ON); - udelay(100000); - status_led_set(STATUS_LED_BOOT, STATUS_LED_OFF); - udelay(200000); - } - } - /* - * Inter-digit pause: we've already waited 200 mSec, wait 1 sec total - */ - udelay(700000); -} - -static int last_boot_progress; - -void show_boot_progress(int status) -{ - int i, j; - - if (status > 0) { - last_boot_progress = status; - } else { - /* - * If a specific failure code is given, flash this code - * else just use the last success code we've seen - */ - if (status < -1) - last_boot_progress = -status; - - /* - * Flash this code 5 times - */ - for (j = 0; j < 5; j++) { - /* - * Houston, we have a problem. - * Blink the last OK status which indicates where things failed. - */ - status_led_set(STATUS_LED_RED, STATUS_LED_ON); - flash_code(last_boot_progress, 5, 3); - - /* - * Delay 5 seconds between repetitions, - * with the fault LED blinking - */ - for (i = 0; i < 5; i++) { - status_led_set(STATUS_LED_RED, - STATUS_LED_OFF); - udelay(500000); - status_led_set(STATUS_LED_RED, STATUS_LED_ON); - udelay(500000); - } - } - - /* - * Reset the board to retry initialization. - */ - do_reset(NULL, 0, 0, NULL); - } -} -#endif /* CONFIG_SHOW_BOOT_PROGRESS */ - - -/* - * The following are used to control the SPI chip selects for the SPI command. - */ -#if defined(CONFIG_CMD_SPI) - -#define SPI_ADC_CS_MASK 0x00000800 -#define SPI_DAC_CS_MASK 0x00001000 - -static const u32 cs_mask[] = { - SPI_ADC_CS_MASK, - SPI_DAC_CS_MASK, -}; - -int spi_cs_is_valid(unsigned int bus, unsigned int cs) -{ - return bus == 0 && cs < sizeof(cs_mask) / sizeof(cs_mask[0]); -} - -void spi_cs_activate(struct spi_slave *slave) -{ - volatile ioport_t *iopd = - ioport_addr((immap_t *) CONFIG_SYS_IMMR, 3 /* port D */ ); - - iopd->pdat &= ~cs_mask[slave->cs]; -} - -void spi_cs_deactivate(struct spi_slave *slave) -{ - volatile ioport_t *iopd = - ioport_addr((immap_t *) CONFIG_SYS_IMMR, 3 /* port D */ ); - - iopd->pdat |= cs_mask[slave->cs]; -} - -#endif - -#endif /* CONFIG_MISC_INIT_R */ diff --git a/configs/sacsng_defconfig b/configs/sacsng_defconfig deleted file mode 100644 index 91cca23..0000000 --- a/configs/sacsng_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_SACSNG=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index c9b4b17..5b71bc9 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,7 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +sacsng powerpc mpc8260 - - Jerry Van Baren gerald.vanbaren@smiths-aerospace.com cogent_mpc8260 powerpc mpc8260 - - Murray Jensen Murray.Jensen@csiro.au cogent_8xx powerpc mpc8xx - - Murray Jensen Murray.Jensen@csiro.au ESTEEM192E powerpc mpc8xx - - Conn Clark clark@esteem.com diff --git a/include/configs/sacsng.h b/include/configs/sacsng.h deleted file mode 100644 index 2dee315..0000000 --- a/include/configs/sacsng.h +++ /dev/null @@ -1,1038 +0,0 @@ -/* - * (C) Copyright 2000 - * Murray Jensen Murray.Jensen@cmst.csiro.au - * - * (C) Copyright 2000 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * - * (C) Copyright 2001 - * Advent Networks, Inc. http://www.adventnetworks.com - * Jay Monkman jtm@smoothsmoothie.com - * - * Configuration settings for the SACSng 8260 board. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -#define CONFIG_SYS_TEXT_BASE 0x40000000 - -#undef DEBUG_BOOTP_EXT /* Debug received vendor fields */ - -#undef CONFIG_LOGBUFFER /* External logbuffer support */ - -/***************************************************************************** - * - * These settings must match the way _your_ board is set up - * - *****************************************************************************/ - -/* What is the oscillator's (UX2) frequency in Hz? */ -#define CONFIG_8260_CLKIN 66666600 - -/*----------------------------------------------------------------------- - * MODCK_H & MODCLK[1-3] - Ref: Section 9.2 in MPC8206 User Manual - *----------------------------------------------------------------------- - * What should MODCK_H be? It is dependent on the oscillator - * frequency, MODCK[1-3], and desired CPM and core frequencies. - * Here are some example values (all frequencies are in MHz): - * - * MODCK_H MODCK[1-3] Osc CPM Core S2-6 S2-7 S2-8 - * ------- ---------- --- --- ---- ----- ----- ----- - * 0x1 0x5 33 100 133 Open Close Open - * 0x1 0x6 33 100 166 Open Open Close - * 0x1 0x7 33 100 200 Open Open Open - * - * 0x2 0x2 33 133 133 Close Open Close - * 0x2 0x3 33 133 166 Close Open Open - * 0x2 0x4 33 133 200 Open Close Close - * 0x2 0x5 33 133 233 Open Close Open - * 0x2 0x6 33 133 266 Open Open Close - * - * 0x5 0x5 66 133 133 Open Close Open - * 0x5 0x6 66 133 166 Open Open Close - * 0x5 0x7 66 133 200 Open Open Open - * 0x6 0x0 66 133 233 Close Close Close - * 0x6 0x1 66 133 266 Close Close Open - * 0x6 0x2 66 133 300 Close Open Close - */ -#define CONFIG_SYS_SBC_MODCK_H 0x05 - -/* Define this if you want to boot from 0x00000100. If you don't define - * this, you will need to program the bootloader to 0xfff00000, and - * get the hardware reset config words at 0xfe000000. The simplest - * way to do that is to program the bootloader at both addresses. - * It is suggested that you just let U-Boot live at 0x00000000. - */ -#define CONFIG_SYS_SBC_BOOT_LOW 1 - -/* What should the base address of the main FLASH be and how big is - * it (in MBytes)? This must contain CONFIG_SYS_TEXT_BASE from board/sacsng/config.mk - * The main FLASH is whichever is connected to *CS0. - */ -#define CONFIG_SYS_FLASH0_BASE 0x40000000 -#define CONFIG_SYS_FLASH0_SIZE 2 - -/* What should the base address of the secondary FLASH be and how big - * is it (in Mbytes)? The secondary FLASH is whichever is connected - * to *CS6. - */ -#define CONFIG_SYS_FLASH1_BASE 0x60000000 -#define CONFIG_SYS_FLASH1_SIZE 2 - -/* Define CONFIG_VERY_BIG_RAM to allow use of SDRAMs larger than 256MBytes - */ -#define CONFIG_VERY_BIG_RAM 1 - -/* What should be the base address of SDRAM DIMM and how big is - * it (in Mbytes)? This will normally auto-configure via the SPD. -*/ -#define CONFIG_SYS_SDRAM0_BASE 0x00000000 -#define CONFIG_SYS_SDRAM0_SIZE 64 - -/* - * Memory map example with 64 MB DIMM: - * - * 0x0000 0000 Exception Vector code, 8k - * : - * 0x0000 1FFF - * 0x0000 2000 Free for Application Use - * : - * : - * - * : - * : - * 0x03F5 FF30 Monitor Stack (Growing downward) - * Monitor Stack Buffer (0x80) - * 0x03F5 FFB0 Board Info Data - * 0x03F6 0000 Malloc Arena - * : CONFIG_ENV_SECT_SIZE, 16k - * : CONFIG_SYS_MALLOC_LEN, 128k - * 0x03FC 0000 RAM Copy of Monitor Code - * : CONFIG_SYS_MONITOR_LEN, 256k - * 0x03FF FFFF [End of RAM], CONFIG_SYS_SDRAM_SIZE - 1 - */ - -#define CONFIG_POST (CONFIG_SYS_POST_MEMORY | \ - CONFIG_SYS_POST_CPU) - - -/* - * select serial console configuration - * - * if either CONFIG_CONS_ON_SMC or CONFIG_CONS_ON_SCC is selected, then - * CONFIG_CONS_INDEX must be set to the channel number (1-2 for SMC, 1-4 - * for SCC). - * - * if CONFIG_CONS_NONE is defined, then the serial console routines must - * defined elsewhere. - */ -#define CONFIG_CONS_ON_SMC 1 /* define if console on SMC */ -#undef CONFIG_CONS_ON_SCC /* define if console on SCC */ -#undef CONFIG_CONS_NONE /* define if console on neither */ -#define CONFIG_CONS_INDEX 1 /* which SMC/SCC channel for console */ - -/* - * select ethernet configuration - * - * if either CONFIG_ETHER_ON_SCC or CONFIG_ETHER_ON_FCC is selected, then - * CONFIG_ETHER_INDEX must be set to the channel number (1-4 for SCC, 1-3 - * for FCC) - * - * if CONFIG_ETHER_NONE is defined, then either the ethernet routines must be - * defined elsewhere (as for the console), or CONFIG_CMD_NET must be unset. - */ - -#undef CONFIG_ETHER_ON_SCC -#define CONFIG_ETHER_ON_FCC -#undef CONFIG_ETHER_NONE /* define if ethernet on neither */ - -#ifdef CONFIG_ETHER_ON_SCC -#define CONFIG_ETHER_INDEX 1 /* which SCC/FCC channel for ethernet */ -#endif /* CONFIG_ETHER_ON_SCC */ - -#ifdef CONFIG_ETHER_ON_FCC -#define CONFIG_ETHER_INDEX 2 /* which SCC/FCC channel for ethernet */ -#undef CONFIG_ETHER_LOOPBACK_TEST /* Ethernet external loopback test */ -#define CONFIG_MII /* MII PHY management */ -#define CONFIG_BITBANGMII /* bit-bang MII PHY management */ -/* - * Port pins used for bit-banged MII communictions (if applicable). - */ - -#define MDIO_PORT 2 /* Port A=0, B=1, C=2, D=3 */ -#define MDIO_DECLARE volatile ioport_t *iop = ioport_addr ( \ - (immap_t *) CONFIG_SYS_IMMR, MDIO_PORT ) -#define MDC_DECLARE MDIO_DECLARE - -#define MDIO_ACTIVE (iop->pdir |= 0x40000000) -#define MDIO_TRISTATE (iop->pdir &= ~0x40000000) -#define MDIO_READ ((iop->pdat & 0x40000000) != 0) - -#define MDIO(bit) if(bit) iop->pdat |= 0x40000000; \ - else iop->pdat &= ~0x40000000 - -#define MDC(bit) if(bit) iop->pdat |= 0x80000000; \ - else iop->pdat &= ~0x80000000 - -#define MIIDELAY udelay(50) -#endif /* CONFIG_ETHER_ON_FCC */ - -#if defined(CONFIG_ETHER_ON_SCC) && (CONFIG_ETHER_INDEX == 1) - -/* - * - RX clk is CLK11 - * - TX clk is CLK12 - */ -# define CONFIG_SYS_CMXSCR_VALUE1 (CMXSCR_RS1CS_CLK11 | CMXSCR_TS1CS_CLK12) - -#elif defined(CONFIG_ETHER_ON_FCC) && (CONFIG_ETHER_INDEX == 2) - -/* - * - Rx-CLK is CLK13 - * - Tx-CLK is CLK14 - * - Select bus for bd/buffers (see 28-13) - * - Enable Full Duplex in FSMR - */ -# define CONFIG_SYS_CMXFCR_MASK2 (CMXFCR_FC2|CMXFCR_RF2CS_MSK|CMXFCR_TF2CS_MSK) -# define CONFIG_SYS_CMXFCR_VALUE2 (CMXFCR_RF2CS_CLK13|CMXFCR_TF2CS_CLK14) -# define CONFIG_SYS_CPMFCR_RAMTYPE 0 -# define CONFIG_SYS_FCC_PSMR (FCC_PSMR_FDE | FCC_PSMR_LPB) - -#endif /* CONFIG_ETHER_ON_FCC, CONFIG_ETHER_INDEX */ - -#define CONFIG_SHOW_BOOT_PROGRESS 1 /* boot progress enabled */ - -/* - * Configure for RAM tests. - */ -#undef CONFIG_SYS_DRAM_TEST /* calls other tests in board.c */ - - -/* - * Status LED for power up status feedback. - */ -#define CONFIG_STATUS_LED 1 /* Status LED enabled */ - -#define STATUS_LED_PAR im_ioport.iop_ppara -#define STATUS_LED_DIR im_ioport.iop_pdira -#define STATUS_LED_ODR im_ioport.iop_podra -#define STATUS_LED_DAT im_ioport.iop_pdata - -#define STATUS_LED_BIT 0x00000800 /* LED 0 is on PA.20 */ -#define STATUS_LED_PERIOD (CONFIG_SYS_HZ) -#define STATUS_LED_STATE STATUS_LED_OFF -#define STATUS_LED_BIT1 0x00001000 /* LED 1 is on PA.19 */ -#define STATUS_LED_PERIOD1 (CONFIG_SYS_HZ) -#define STATUS_LED_STATE1 STATUS_LED_OFF -#define STATUS_LED_BIT2 0x00002000 /* LED 2 is on PA.18 */ -#define STATUS_LED_PERIOD2 (CONFIG_SYS_HZ/2) -#define STATUS_LED_STATE2 STATUS_LED_ON - -#define STATUS_LED_ACTIVE 0 /* LED on for bit == 0 */ - -#define STATUS_LED_YELLOW 0 -#define STATUS_LED_GREEN 1 -#define STATUS_LED_RED 2 -#define STATUS_LED_BOOT 1 - - -/* - * Select SPI support configuration - */ -#define CONFIG_SOFT_SPI /* Enable SPI driver */ -#define MAX_SPI_BYTES 4 /* Maximum number of bytes we can handle */ -#undef DEBUG_SPI /* Disable SPI debugging */ - -/* - * Software (bit-bang) SPI driver configuration - */ -#ifdef CONFIG_SOFT_SPI - -/* - * Software (bit-bang) SPI driver configuration - */ -#define I2C_SCLK 0x00002000 /* PD 18: Shift clock */ -#define I2C_MOSI 0x00004000 /* PD 17: Master Out, Slave In */ -#define I2C_MISO 0x00008000 /* PD 16: Master In, Slave Out */ - -#define SPI_READ ((immr->im_ioport.iop_pdatd & I2C_MISO) != 0) -#define SPI_SDA(bit) do { \ - if(bit) immr->im_ioport.iop_pdatd |= I2C_MOSI; \ - else immr->im_ioport.iop_pdatd &= ~I2C_MOSI; \ - } while (0) -#define SPI_SCL(bit) do { \ - if(bit) immr->im_ioport.iop_pdatd |= I2C_SCLK; \ - else immr->im_ioport.iop_pdatd &= ~I2C_SCLK; \ - } while (0) -#define SPI_DELAY /* No delay is needed */ -#endif /* CONFIG_SOFT_SPI */ - - -/* - * select I2C support configuration - * - * Supported configurations are {none, software, hardware} drivers. - * If the software driver is chosen, there are some additional - * configuration items that the driver uses to drive the port pins. - */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_SOFT /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SOFT_SPEED 400000 -#define CONFIG_SYS_I2C_SOFT_SLAVE 0x7F -/* - * Software (bit-bang) I2C driver configuration - */ -#define I2C_PORT 3 /* Port A=0, B=1, C=2, D=3 */ -#define I2C_ACTIVE (iop->pdir |= 0x00010000) -#define I2C_TRISTATE (iop->pdir &= ~0x00010000) -#define I2C_READ ((iop->pdat & 0x00010000) != 0) -#define I2C_SDA(bit) if(bit) iop->pdat |= 0x00010000; \ - else iop->pdat &= ~0x00010000 -#define I2C_SCL(bit) if(bit) iop->pdat |= 0x00020000; \ - else iop->pdat &= ~0x00020000 -#define I2C_DELAY udelay(20) /* 1/4 I2C clock duration */ - -/* Define this to reserve an entire FLASH sector for - * environment variables. Otherwise, the environment will be - * put in the same sector as U-Boot, and changing variables - * will erase U-Boot temporarily - */ -#define CONFIG_ENV_IN_OWN_SECT 1 - -/* Define this to contain any number of null terminated strings that - * will be part of the default environment compiled into the boot image. - */ -#define CONFIG_EXTRA_ENV_SETTINGS \ -"quiet=0\0" \ -"serverip=192.168.123.205\0" \ -"ipaddr=192.168.123.203\0" \ -"checkhostname=VR8500\0" \ -"reprog="\ - "bootp; " \ - "tftpboot 0x140000 /bdi2000/u-boot.bin; " \ - "protect off 60000000 6003FFFF; " \ - "erase 60000000 6003FFFF; " \ - "cp.b 140000 60000000 ${filesize}; " \ - "protect on 60000000 6003FFFF\0" \ -"copyenv="\ - "protect off 60040000 6004FFFF; " \ - "erase 60040000 6004FFFF; " \ - "cp.b 40040000 60040000 10000; " \ - "protect on 60040000 6004FFFF\0" \ -"copyprog="\ - "protect off 60000000 6003FFFF; " \ - "erase 60000000 6003FFFF; " \ - "cp.b 40000000 60000000 40000; " \ - "protect on 60000000 6003FFFF\0" \ -"zapenv="\ - "protect off 40040000 4004FFFF; " \ - "erase 40040000 4004FFFF; " \ - "protect on 40040000 4004FFFF\0" \ -"zapotherenv="\ - "protect off 60040000 6004FFFF; " \ - "erase 60040000 6004FFFF; " \ - "protect on 60040000 6004FFFF\0" \ -"root-on-initrd="\ - "setenv bootcmd "\ - "version\;" \ - "echo\;" \ - "bootp\;" \ - "setenv bootargs root=/dev/ram0 rw quiet " \ - "ip=\${ipaddr}:\${serverip}:\${gatewayip}:\${netmask}:\${hostname}::off\;" \ - "run boot-hook\;" \ - "bootm\0" \ -"root-on-initrd-debug="\ - "setenv bootcmd "\ - "version\;" \ - "echo\;" \ - "bootp\;" \ - "setenv bootargs root=/dev/ram0 rw debug " \ - "ip=\${ipaddr}:\${serverip}:\${gatewayip}:\${netmask}:\${hostname}::off\;" \ - "run debug-hook\;" \ - "run boot-hook\;" \ - "bootm\0" \ -"root-on-nfs="\ - "setenv bootcmd "\ - "version\;" \ - "echo\;" \ - "bootp\;" \ - "setenv bootargs root=/dev/nfs rw quiet " \ - "nfsroot=\${serverip}:\${rootpath} " \ - "ip=\${ipaddr}:\${serverip}:\${gatewayip}:\${netmask}:\${hostname}::off\;" \ - "run boot-hook\;" \ - "bootm\0" \ -"root-on-nfs-debug="\ - "setenv bootcmd "\ - "version\;" \ - "echo\;" \ - "bootp\;" \ - "setenv bootargs root=/dev/nfs rw debug " \ - "nfsroot=\${serverip}:\${rootpath} " \ - "ip=\${ipaddr}:\${serverip}:\${gatewayip}:\${netmask}:\${hostname}::off\;" \ - "run debug-hook\;" \ - "run boot-hook\;" \ - "bootm\0" \ -"debug-checkout="\ - "setenv checkhostname;" \ - "setenv ethaddr 00:09:70:00:00:01;" \ - "bootp;" \ - "setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath} debug " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off;" \ - "run debug-hook;" \ - "run boot-hook;" \ - "bootm\0" \ -"debug-hook="\ - "echo ipaddr ${ipaddr};" \ - "echo serverip ${serverip};" \ - "echo gatewayip ${gatewayip};" \ - "echo netmask ${netmask};" \ - "echo hostname ${hostname}\0" \ -"ana=run adc ; run dac\0" \ -"adc=run adc-12 ; run adc-34\0" \ -"adc-12=echo ### ADC-12 ; i2c md e 81 e\0" \ -"adc-34=echo ### ADC-34 ; i2c md f 81 e\0" \ -"dac=echo ### DAC ; i2c md 11 81 5\0" \ -"boot-hook=echo\0" - -/* What should the console's baud rate be? */ -#define CONFIG_BAUDRATE 9600 - -/* Ethernet MAC address */ -#define CONFIG_ETHADDR 00:09:70:00:00:00 - -/* The default Ethernet MAC address can be overwritten just once */ -#ifdef CONFIG_ETHADDR -#define CONFIG_OVERWRITE_ETHADDR_ONCE 1 -#endif - -/* - * Define this to do some miscellaneous board-specific initialization. - */ -#define CONFIG_MISC_INIT_R - -/* Set to a positive value to delay for running BOOTCOMMAND */ -#define CONFIG_BOOTDELAY 1 /* autoboot after 1 second */ - -/* Be selective on what keys can delay or stop the autoboot process - * To stop use: " " - */ -#define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_PROMPT "Autobooting...\n" -#define CONFIG_AUTOBOOT_STOP_STR " " -#undef CONFIG_AUTOBOOT_DELAY_STR -#define CONFIG_ZERO_BOOTDELAY_CHECK -#define DEBUG_BOOTKEYS 0 - -/* Define a command string that is automatically executed when no character - * is read on the console interface withing "Boot Delay" after reset. - */ -#undef CONFIG_BOOT_ROOT_INITRD /* Use ram disk for the root file system */ -#define CONFIG_BOOT_ROOT_NFS /* Use a NFS mounted root file system */ - -#ifdef CONFIG_BOOT_ROOT_INITRD -#define CONFIG_BOOTCOMMAND \ - "version;" \ - "echo;" \ - "bootp;" \ - "setenv bootargs root=/dev/ram0 rw quiet " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off;" \ - "run boot-hook;" \ - "bootm" -#endif /* CONFIG_BOOT_ROOT_INITRD */ - -#ifdef CONFIG_BOOT_ROOT_NFS -#define CONFIG_BOOTCOMMAND \ - "version;" \ - "echo;" \ - "bootp;" \ - "setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath} quiet " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off;" \ - "run boot-hook;" \ - "bootm" -#endif /* CONFIG_BOOT_ROOT_NFS */ - -#define CONFIG_BOOTP_RANDOM_DELAY /* Randomize the BOOTP retry delay */ -#define CONFIG_LIB_RAND - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_DNS -#define CONFIG_BOOTP_DNS2 -#define CONFIG_BOOTP_SEND_HOSTNAME - - -/* undef this to save memory */ -#define CONFIG_SYS_LONGHELP - -/* Monitor Command Prompt */ - -#undef CONFIG_SYS_HUSH_PARSER -#ifdef CONFIG_SYS_HUSH_PARSER -#endif - -/* When CONFIG_TIMESTAMP is selected, the timestamp (date and time) - * of an image is printed by image commands like bootm or iminfo. - */ -#define CONFIG_TIMESTAMP - -/* If this variable is defined, an environment variable named "ver" - * is created by U-Boot showing the U-Boot version. - */ -#define CONFIG_VERSION_VARIABLE - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_ELF -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_I2C -#define CONFIG_CMD_SPI -#define CONFIG_CMD_SDRAM -#define CONFIG_CMD_REGINFO -#define CONFIG_CMD_IMMAP -#define CONFIG_CMD_IRQ -#define CONFIG_CMD_PING - -#undef CONFIG_CMD_KGDB - -#ifdef CONFIG_ETHER_ON_FCC -#define CONFIG_CMD_MII -#endif - - -/* Where do the internal registers live? */ -#define CONFIG_SYS_IMMR 0xF0000000 - -#undef CONFIG_WATCHDOG /* disable the watchdog */ - -/***************************************************************************** - * - * You should not have to modify any of the following settings - * - *****************************************************************************/ - -#define CONFIG_SACSng 1 /* munged for the SACSng */ -#define CONFIG_CPM2 1 /* Has a CPM2 */ - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_BOOTM_HEADER_QUIET 1 /* Suppress the image header dump */ - /* in the bootm command. */ -#define CONFIG_SYS_BOOTM_PROGESS_QUIET 1 /* Suppress the progress displays, */ - /* "## <message>" from the bootm cmd */ -#define CONFIG_SYS_BOOTP_CHECK_HOSTNAME 1 /* If checkhostname environment is */ - /* defined, then the hostname param */ - /* validated against checkhostname. */ -#define CONFIG_SYS_BOOTP_RETRY_COUNT 0x40000000 /* # of timeouts before giving up */ -#define CONFIG_SYS_BOOTP_SHORT_RANDOM_DELAY 1 /* Use a short random delay value */ - /* (limited to maximum of 1024 msec) */ -#define CONFIG_SYS_CHK_FOR_ABORT_AT_LEAST_ONCE 1 - /* Check for abort key presses */ - /* at least once in dependent of the */ - /* CONFIG_BOOTDELAY value. */ -#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* Don't print console @ startup */ -#define CONFIG_SYS_FAULT_ECHO_LINK_DOWN 1 /* Echo the inverted Ethernet link */ - /* state to the fault LED. */ -#define CONFIG_SYS_FAULT_MII_ADDR 0x02 /* MII addr of the PHY to check for */ - /* the Ethernet link state. */ -#define CONFIG_SYS_STATUS_FLASH_UNTIL_TFTP_OK 1 /* Keeping the status LED flashing */ - /* until the TFTP is successful. */ -#define CONFIG_SYS_STATUS_OFF_AFTER_NETBOOT 1 /* After a successful netboot, */ - /* turn off the STATUS LEDs. */ -#define CONFIG_SYS_TFTP_BLINK_STATUS_ON_DATA_IN 1 /* Blink status LED based on */ - /* incoming data. */ -#define CONFIG_SYS_TFTP_BLOCKS_PER_HASH 100 /* For every XX blocks, output a '#' */ - /* to signify that tftp is moving. */ -#define CONFIG_SYS_TFTP_HASHES_PER_FLASH 200 /* For every '#' hashes, */ - /* flash the status LED. */ -#define CONFIG_SYS_TFTP_HASHES_PER_LINE 65 /* Only output XX '#'s per line */ - /* during the tftp file transfer. */ -#define CONFIG_SYS_TFTP_PROGESS_QUIET 1 /* Suppress the progress displays */ - /* '#'s from the tftp command. */ -#define CONFIG_SYS_TFTP_STATUS_QUIET 1 /* Suppress the status displays */ - /* issued during the tftp command. */ -#define CONFIG_SYS_TFTP_TIMEOUT_COUNT 5 /* How many timeouts TFTP will allow */ - /* before it gives up. */ - -#if defined(CONFIG_CMD_KGDB) -# define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -# define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif - -/* Print Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT)+16) - -#define CONFIG_SYS_MAXARGS 32 /* max number of command args */ - -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_LOAD_ADDR 0x400000 /* default load address */ - -#define CONFIG_SYS_ALT_MEMTEST /* Select full-featured memory test */ -#define CONFIG_SYS_MEMTEST_START 0x2000 /* memtest works from the end of */ - /* the exception vector table */ - /* to the end of the DRAM */ - /* less monitor and malloc area */ -#define CONFIG_SYS_STACK_USAGE 0x10000 /* Reserve 64k for the stack usage */ -#define CONFIG_SYS_MEM_END_USAGE ( CONFIG_SYS_MONITOR_LEN \ - + CONFIG_SYS_MALLOC_LEN \ - + CONFIG_ENV_SECT_SIZE \ - + CONFIG_SYS_STACK_USAGE ) - -#define CONFIG_SYS_MEMTEST_END ( CONFIG_SYS_SDRAM_SIZE * 1024 * 1024 \ - - CONFIG_SYS_MEM_END_USAGE ) - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ - -#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_FLASH0_BASE -#define CONFIG_SYS_FLASH_SIZE CONFIG_SYS_FLASH0_SIZE -#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_SDRAM0_BASE -#define CONFIG_SYS_SDRAM_SIZE CONFIG_SYS_SDRAM0_SIZE - -/*----------------------------------------------------------------------- - * Hard Reset Configuration Words - */ -#if defined(CONFIG_SYS_SBC_BOOT_LOW) -# define CONFIG_SYS_SBC_HRCW_BOOT_FLAGS (HRCW_CIP | HRCW_BMS) -#else -# define CONFIG_SYS_SBC_HRCW_BOOT_FLAGS (0) -#endif /* defined(CONFIG_SYS_SBC_BOOT_LOW) */ - -/* get the HRCW ISB field from CONFIG_SYS_IMMR */ -#define CONFIG_SYS_SBC_HRCW_IMMR ( ((CONFIG_SYS_IMMR & 0x10000000) >> 10) | \ - ((CONFIG_SYS_IMMR & 0x01000000) >> 7) | \ - ((CONFIG_SYS_IMMR & 0x00100000) >> 4) ) - -#define CONFIG_SYS_HRCW_MASTER ( HRCW_BPS10 | \ - HRCW_DPPC11 | \ - CONFIG_SYS_SBC_HRCW_IMMR | \ - HRCW_MMR00 | \ - HRCW_LBPC11 | \ - HRCW_APPC10 | \ - HRCW_CS10PC00 | \ - (CONFIG_SYS_SBC_MODCK_H & HRCW_MODCK_H1111) | \ - CONFIG_SYS_SBC_HRCW_BOOT_FLAGS ) - -/* no slaves */ -#define CONFIG_SYS_HRCW_SLAVE1 0 -#define CONFIG_SYS_HRCW_SLAVE2 0 -#define CONFIG_SYS_HRCW_SLAVE3 0 -#define CONFIG_SYS_HRCW_SLAVE4 0 -#define CONFIG_SYS_HRCW_SLAVE5 0 -#define CONFIG_SYS_HRCW_SLAVE6 0 -#define CONFIG_SYS_HRCW_SLAVE7 0 - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - * Note also that the logic that sets CONFIG_SYS_RAMBOOT is platform dependent. - */ -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH0_BASE - -#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) -# define CONFIG_SYS_RAMBOOT -#endif - -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * FLASH and environment organization - */ - -#define CONFIG_SYS_FLASH_CFI 1 /* Flash is CFI conformant */ -#undef CONFIG_SYS_FLASH_PROTECTION /* use hardware protection */ -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT (64+4) /* max number of sectors on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 8000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 1 /* Timeout for Flash Write (in ms) */ - -#ifndef CONFIG_SYS_RAMBOOT -# define CONFIG_ENV_IS_IN_FLASH 1 - -# ifdef CONFIG_ENV_IN_OWN_SECT -# define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) -# define CONFIG_ENV_SECT_SIZE 0x10000 -# else -# define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_SYS_MONITOR_LEN - CONFIG_ENV_SECT_SIZE) -# define CONFIG_ENV_SIZE 0x1000 /* Total Size of Environment Sector */ -# define CONFIG_ENV_SECT_SIZE 0x10000 /* see README - env sect real size */ -# endif /* CONFIG_ENV_IN_OWN_SECT */ - -#else -# define CONFIG_ENV_IS_IN_NVRAM 1 -# define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) -# define CONFIG_ENV_SIZE 0x200 -#endif /* CONFIG_SYS_RAMBOOT */ - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC8260 CPU */ - -#if defined(CONFIG_CMD_KGDB) -# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * HIDx - Hardware Implementation-dependent Registers 2-11 - *----------------------------------------------------------------------- - * HID0 also contains cache control - initially enable both caches and - * invalidate contents, then the final state leaves only the instruction - * cache enabled. Note that Power-On and Hard reset invalidate the caches, - * but Soft reset does not. - * - * HID1 has only read-only information - nothing to set. - */ -#define CONFIG_SYS_HID0_INIT (HID0_ICE |\ - HID0_DCE |\ - HID0_ICFI |\ - HID0_DCI |\ - HID0_IFEM |\ - HID0_ABE) - -#define CONFIG_SYS_HID0_FINAL (HID0_ICE |\ - HID0_IFEM |\ - HID0_ABE |\ - HID0_EMCP) -#define CONFIG_SYS_HID2 0 - -/*----------------------------------------------------------------------- - * RMR - Reset Mode Register - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RMR 0 - -/*----------------------------------------------------------------------- - * BCR - Bus Configuration 4-25 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_BCR (BCR_ETM) - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 4-31 - *----------------------------------------------------------------------- - */ - -#define CONFIG_SYS_SIUMCR (SIUMCR_DPPC11 |\ - SIUMCR_L2CPC00 |\ - SIUMCR_APPC10 |\ - SIUMCR_MMR00) - - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 11-9 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Watchdog & Bus Monitor Timer max, 60x Bus Monitor enable - */ -#if defined(CONFIG_WATCHDOG) -#define CONFIG_SYS_SYPCR (SYPCR_SWTC |\ - SYPCR_BMT |\ - SYPCR_PBME |\ - SYPCR_LBME |\ - SYPCR_SWRI |\ - SYPCR_SWP |\ - SYPCR_SWE) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC |\ - SYPCR_BMT |\ - SYPCR_PBME |\ - SYPCR_LBME |\ - SYPCR_SWRI |\ - SYPCR_SWP) -#endif /* CONFIG_WATCHDOG */ - -/*----------------------------------------------------------------------- - * TMCNTSC - Time Counter Status and Control 4-40 - *----------------------------------------------------------------------- - * Clear once per Second and Alarm Interrupt Status, Set 32KHz timersclk, - * and enable Time Counter - */ -#define CONFIG_SYS_TMCNTSC (TMCNTSC_SEC |\ - TMCNTSC_ALR |\ - TMCNTSC_TCF |\ - TMCNTSC_TCE) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 4-42 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Set 32KHz timersclk, and enable - * Periodic timer - */ -#define CONFIG_SYS_PISCR (PISCR_PS |\ - PISCR_PTF |\ - PISCR_PTE) - -/*----------------------------------------------------------------------- - * SCCR - System Clock Control 9-8 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_SCCR 0 - -/*----------------------------------------------------------------------- - * RCCR - RISC Controller Configuration 13-7 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RCCR 0 - -/* - * Initialize Memory Controller: - * - * Bank Bus Machine PortSz Device - * ---- --- ------- ------ ------ - * 0 60x GPCM 16 bit FLASH (primary flash - 2MB) - * 1 60x GPCM -- bit (Unused) - * 2 60x SDRAM 64 bit SDRAM (DIMM) - * 3 60x SDRAM 64 bit SDRAM (DIMM) - * 4 60x GPCM -- bit (Unused) - * 5 60x GPCM -- bit (Unused) - * 6 60x GPCM 16 bit FLASH (secondary flash - 2MB) - */ - -/*----------------------------------------------------------------------- - * BR0,BR1 - Base Register - * Ref: Section 10.3.1 on page 10-14 - * OR0,OR1 - Option Register - * Ref: Section 10.3.2 on page 10-18 - *----------------------------------------------------------------------- - */ - -/* Bank 0 - Primary FLASH - */ - -/* BR0 is configured as follows: - * - * - Base address of 0x40000000 - * - 16 bit port size - * - Data errors checking is disabled - * - Read and write access - * - GPCM 60x bus - * - Access are handled by the memory controller according to MSEL - * - Not used for atomic operations - * - No data pipelining is done - * - Valid - */ -#define CONFIG_SYS_BR0_PRELIM ((CONFIG_SYS_FLASH0_BASE & BRx_BA_MSK) |\ - BRx_PS_16 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -/* OR0 is configured as follows: - * - * - 4 MB - * - *BCTL0 is asserted upon access to the current memory bank - * - *CW / *WE are negated a quarter of a clock earlier - * - *CS is output at the same time as the address lines - * - Uses a clock cycle length of 5 - * - *PSDVAL is generated internally by the memory controller - * unless *GTA is asserted earlier externally. - * - Relaxed timing is generated by the GPCM for accesses - * initiated to this memory region. - * - One idle clock is inserted between a read access from the - * current bank and the next access. - */ -#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH0_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_5_CLK |\ - ORxG_TRLX |\ - ORxG_EHTR) - -/*----------------------------------------------------------------------- - * BR2,BR3 - Base Register - * Ref: Section 10.3.1 on page 10-14 - * OR2,OR3 - Option Register - * Ref: Section 10.3.2 on page 10-16 - *----------------------------------------------------------------------- - */ - -/* Bank 2,3 - SDRAM DIMM - */ - -/* The BR2 is configured as follows: - * - * - Base address of 0x00000000 - * - 64 bit port size (60x bus only) - * - Data errors checking is disabled - * - Read and write access - * - SDRAM 60x bus - * - Access are handled by the memory controller according to MSEL - * - Not used for atomic operations - * - No data pipelining is done - * - Valid - */ -#define CONFIG_SYS_BR2_PRELIM ((CONFIG_SYS_SDRAM0_BASE & BRx_BA_MSK) |\ - BRx_PS_64 |\ - BRx_MS_SDRAM_P |\ - BRx_V) - -#define CONFIG_SYS_BR3_PRELIM ((CONFIG_SYS_SDRAM0_BASE & BRx_BA_MSK) |\ - BRx_PS_64 |\ - BRx_MS_SDRAM_P |\ - BRx_V) - -/* With a 64 MB DIMM, the OR2 is configured as follows: - * - * - 64 MB - * - 4 internal banks per device - * - Row start address bit is A8 with PSDMR[PBI] = 0 - * - 12 row address lines - * - Back-to-back page mode - * - Internal bank interleaving within save device enabled - */ -#if (CONFIG_SYS_SDRAM0_SIZE == 64) -#define CONFIG_SYS_OR2_PRELIM (MEG_TO_AM(CONFIG_SYS_SDRAM0_SIZE) |\ - ORxS_BPD_4 |\ - ORxS_ROWST_PBI0_A8 |\ - ORxS_NUMR_12) -#else -#error "INVALID SDRAM CONFIGURATION" -#endif - -/*----------------------------------------------------------------------- - * PSDMR - 60x Bus SDRAM Mode Register - * Ref: Section 10.3.3 on page 10-21 - *----------------------------------------------------------------------- - */ - -/* Address that the DIMM SPD memory lives at. - */ -#define SDRAM_SPD_ADDR 0x50 - -#if (CONFIG_SYS_SDRAM0_SIZE == 64) -/* With a 64 MB DIMM, the PSDMR is configured as follows: - * - * - Bank Based Interleaving, - * - Refresh Enable, - * - Address Multiplexing where A5 is output on A14 pin - * (A6 on A15, and so on), - * - use address pins A14-A16 as bank select, - * - A9 is output on SDA10 during an ACTIVATE command, - * - earliest timing for ACTIVATE command after REFRESH command is 7 clocks, - * - earliest timing for ACTIVATE or REFRESH command after PRECHARGE command - * is 3 clocks, - * - earliest timing for READ/WRITE command after ACTIVATE command is - * 2 clocks, - * - earliest timing for PRECHARGE after last data was read is 1 clock, - * - earliest timing for PRECHARGE after last data was written is 1 clock, - * - CAS Latency is 2. - */ -#define CONFIG_SYS_PSDMR (PSDMR_RFEN |\ - PSDMR_SDAM_A14_IS_A5 |\ - PSDMR_BSMA_A14_A16 |\ - PSDMR_SDA10_PBI0_A9 |\ - PSDMR_RFRC_7_CLK |\ - PSDMR_PRETOACT_3W |\ - PSDMR_ACTTORW_2W |\ - PSDMR_LDOTOPRE_1C |\ - PSDMR_WRC_1C |\ - PSDMR_CL_2) -#else -#error "INVALID SDRAM CONFIGURATION" -#endif - -/* - * Shoot for approximately 1MHz on the prescaler. - */ -#if (CONFIG_8260_CLKIN >= (60 * 1000 * 1000)) -#define CONFIG_SYS_MPTPR MPTPR_PTP_DIV64 -#elif (CONFIG_8260_CLKIN >= (30 * 1000 * 1000)) -#define CONFIG_SYS_MPTPR MPTPR_PTP_DIV32 -#else -#warning "Unconfigured bus clock freq: check CONFIG_SYS_MPTPR and CONFIG_SYS_PSRT are OK" -#define CONFIG_SYS_MPTPR MPTPR_PTP_DIV32 -#endif -#define CONFIG_SYS_PSRT 14 - - -/*----------------------------------------------------------------------- - * BR6 - Base Register - * Ref: Section 10.3.1 on page 10-14 - * OR6 - Option Register - * Ref: Section 10.3.2 on page 10-18 - *----------------------------------------------------------------------- - */ - -/* Bank 6 - Secondary FLASH - * - * The secondary FLASH is connected to *CS6 - */ -#if (defined(CONFIG_SYS_FLASH1_BASE) && defined(CONFIG_SYS_FLASH1_SIZE)) - -/* BR6 is configured as follows: - * - * - Base address of 0x60000000 - * - 16 bit port size - * - Data errors checking is disabled - * - Read and write access - * - GPCM 60x bus - * - Access are handled by the memory controller according to MSEL - * - Not used for atomic operations - * - No data pipelining is done - * - Valid - */ -# define CONFIG_SYS_BR6_PRELIM ((CONFIG_SYS_FLASH1_BASE & BRx_BA_MSK) |\ - BRx_PS_16 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -/* OR6 is configured as follows: - * - * - 2 MB - * - *BCTL0 is asserted upon access to the current memory bank - * - *CW / *WE are negated a quarter of a clock earlier - * - *CS is output at the same time as the address lines - * - Uses a clock cycle length of 5 - * - *PSDVAL is generated internally by the memory controller - * unless *GTA is asserted earlier externally. - * - Relaxed timing is generated by the GPCM for accesses - * initiated to this memory region. - * - One idle clock is inserted between a read access from the - * current bank and the next access. - */ -# define CONFIG_SYS_OR6_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH1_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_5_CLK |\ - ORxG_TRLX |\ - ORxG_EHTR) -#endif /* (defined(CONFIG_SYS_FLASH1_BASE) && defined(CONFIG_SYS_FLASH1_SIZE)) */ - -#endif /* __CONFIG_H */
On Mon, Dec 15, 2014 at 11:26:19PM +0900, Masahiro Yamada wrote:
This board is still a non-generic board.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Jerry Van Baren gerald.vanbaren@smiths-aerospace.com
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Brad Kemp Brad.Kemp@seranoa.com ---
arch/powerpc/cpu/mpc8260/Kconfig | 4 - board/ppmc8260/Kconfig | 9 - board/ppmc8260/MAINTAINERS | 6 - board/ppmc8260/Makefile | 8 - board/ppmc8260/ppmc8260.c | 291 ------------ configs/ppmc8260_defconfig | 3 - doc/README.scrapyard | 1 + include/configs/ppmc8260.h | 986 --------------------------------------- 8 files changed, 1 insertion(+), 1307 deletions(-) delete mode 100644 board/ppmc8260/Kconfig delete mode 100644 board/ppmc8260/MAINTAINERS delete mode 100644 board/ppmc8260/Makefile delete mode 100644 board/ppmc8260/ppmc8260.c delete mode 100644 configs/ppmc8260_defconfig delete mode 100644 include/configs/ppmc8260.h
diff --git a/arch/powerpc/cpu/mpc8260/Kconfig b/arch/powerpc/cpu/mpc8260/Kconfig index bdaf126..d4132a0 100644 --- a/arch/powerpc/cpu/mpc8260/Kconfig +++ b/arch/powerpc/cpu/mpc8260/Kconfig @@ -37,9 +37,6 @@ config TARGET_PM826 config TARGET_PM828 bool "Support PM828"
-config TARGET_PPMC8260 - bool "Support ppmc8260" - config TARGET_MPC8266ADS bool "Support MPC8266ADS"
@@ -64,6 +61,5 @@ source "board/keymile/km82xx/Kconfig" source "board/muas3001/Kconfig" source "board/pm826/Kconfig" source "board/pm828/Kconfig" -source "board/ppmc8260/Kconfig"
endmenu diff --git a/board/ppmc8260/Kconfig b/board/ppmc8260/Kconfig deleted file mode 100644 index 1a6dcd3..0000000 --- a/board/ppmc8260/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_PPMC8260 - -config SYS_BOARD - default "ppmc8260" - -config SYS_CONFIG_NAME - default "ppmc8260" - -endif diff --git a/board/ppmc8260/MAINTAINERS b/board/ppmc8260/MAINTAINERS deleted file mode 100644 index 8b896af..0000000 --- a/board/ppmc8260/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -PPMC8260 BOARD -#M: Brad Kemp Brad.Kemp@seranoa.com -S: Orphan (since 2014-04) -F: board/ppmc8260/ -F: include/configs/ppmc8260.h -F: configs/ppmc8260_defconfig diff --git a/board/ppmc8260/Makefile b/board/ppmc8260/Makefile deleted file mode 100644 index 3072fb4..0000000 --- a/board/ppmc8260/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y := ppmc8260.o diff --git a/board/ppmc8260/ppmc8260.c b/board/ppmc8260/ppmc8260.c deleted file mode 100644 index f0f29b2..0000000 --- a/board/ppmc8260/ppmc8260.c +++ /dev/null @@ -1,291 +0,0 @@ -/* - * (C) Copyright 2000 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * - * (C) Copyright 2001 - * Advent Networks, Inc. http://www.adventnetworks.com - * Jay Monkman jtm@smoothsmoothie.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <ioports.h> -#include <mpc8260.h> - -/* - * I/O Port configuration table - * - * if conf is 1, then that port pin will be configured at boot time - * according to the five values podr/pdir/ppar/psor/pdat for that entry - */ - -const iop_conf_t iop_conf_tab[4][32] = { - - - /* Port A configuration */ - { /* conf ppar psor pdir podr pdat */ - /* PA31 */ { 0, 0, 0, 0, 0, 0 }, /* FCC1 *ATMTXEN */ - /* PA30 */ { 0, 0, 0, 0, 0, 0 }, /* FCC1 ATMTCA */ - /* PA29 */ { 0, 0, 0, 0, 0, 0 }, /* FCC1 ATMTSOC */ - /* PA28 */ { 0, 0, 0, 0, 0, 0 }, /* FCC1 *ATMRXEN */ - /* PA27 */ { 0, 0, 0, 0, 0, 0 }, /* FCC1 ATMRSOC */ - /* PA26 */ { 0, 0, 0, 0, 0, 0 }, /* FCC1 ATMRCA */ - /* PA25 */ { 0, 0, 0, 0, 0, 0 }, /* FCC1 ATMTXD[0] */ - /* PA24 */ { 0, 0, 0, 0, 0, 0 }, /* FCC1 ATMTXD[1] */ - /* PA23 */ { 0, 0, 0, 0, 0, 0 }, /* FCC1 ATMTXD[2] */ - /* PA22 */ { 0, 0, 0, 0, 0, 0 }, /* FCC1 ATMTXD[3] */ - /* PA21 */ { 0, 0, 0, 0, 0, 0 }, /* FCC1 ATMTXD[4] */ - /* PA20 */ { 0, 0, 0, 0, 0, 0 }, /* FCC1 ATMTXD[5] */ - /* PA19 */ { 0, 0, 0, 0, 0, 0 }, /* FCC1 ATMTXD[6] */ - /* PA18 */ { 0, 0, 0, 0, 0, 0 }, /* FCC1 ATMTXD[7] */ - /* PA17 */ { 0, 0, 0, 0, 0, 0 }, /* FCC1 ATMRXD[7] */ - /* PA16 */ { 0, 0, 0, 0, 0, 0 }, /* FCC1 ATMRXD[6] */ - /* PA15 */ { 0, 0, 0, 0, 0, 0 }, /* FCC1 ATMRXD[5] */ - /* PA14 */ { 0, 0, 0, 0, 0, 0 }, /* FCC1 ATMRXD[4] */ - /* PA13 */ { 0, 0, 0, 0, 0, 0 }, /* FCC1 ATMRXD[3] */ - /* PA12 */ { 0, 0, 0, 0, 0, 0 }, /* FCC1 ATMRXD[2] */ - /* PA11 */ { 0, 0, 0, 0, 0, 0 }, /* FCC1 ATMRXD[1] */ - /* PA10 */ { 0, 0, 0, 0, 0, 0 }, /* FCC1 ATMRXD[0] */ - /* PA9 */ { 1, 1, 0, 1, 0, 0 }, /* SMC2 TXD */ - /* PA8 */ { 1, 1, 0, 0, 0, 0 }, /* SMC2 RXD */ - /* PA7 */ { 1, 0, 0, 1, 0, 0 }, /* TDM_A1:L1TSYNC */ - /* PA6 */ { 1, 0, 0, 1, 0, 0 }, /* TDN_A1:L1RSYNC */ - /* PA5 */ { 0, 0, 0, 0, 0, 0 }, /* PA5 */ - /* PA4 */ { 0, 0, 0, 0, 0, 0 }, /* PA4 */ - /* PA3 */ { 0, 0, 0, 0, 0, 0 }, /* PA3 */ - /* PA2 */ { 0, 0, 0, 0, 0, 0 }, /* PA2 */ - /* PA1 */ { 0, 0, 0, 0, 0, 0 }, /* PA1 */ - /* PA0 */ { 0, 0, 0, 0, 0, 0 } /* PA0 */ - }, - - /* Port B configuration */ - { /* conf ppar psor pdir podr pdat */ - /* PB31 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TX_ER */ - /* PB30 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_DV */ - /* PB29 */ { 1, 1, 1, 1, 0, 0 }, /* FCC2 MII TX_EN */ - /* PB28 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_ER */ - /* PB27 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII COL */ - /* PB26 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII CRS */ - /* PB25 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[3] */ - /* PB24 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[2] */ - /* PB23 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[1] */ - /* PB22 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[0] */ - /* PB21 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[0] */ - /* PB20 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[1] */ - /* PB19 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[2] */ - /* PB18 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[3] */ - /* PB17 */ { 0, 0, 0, 0, 0, 0 }, /* PB17 */ - /* PB16 */ { 1, 0, 0, 0, 0, 0 }, /* TDM_A1:L1CLK0 */ - /* PB15 */ { 1, 0, 0, 1, 0, 1 }, /* /FETHRST */ - /* PB14 */ { 1, 0, 0, 1, 0, 0 }, /* FETHDIS */ - /* PB13 */ { 0, 0, 0, 0, 0, 0 }, /* PB13 */ - /* PB12 */ { 1, 0, 0, 1, 0, 0 }, /* TDM_B1:L1CLK0 */ - /* PB11 */ { 1, 0, 0, 1, 0, 0 }, /* TDM_D1:L1TXD */ - /* PB10 */ { 1, 0, 0, 1, 0, 0 }, /* TDM_D1:L1RXD */ - /* PB9 */ { 1, 0, 0, 1, 0, 0 }, /* TDM_D1:L1TSYNC */ - /* PB8 */ { 1, 0, 0, 1, 0, 0 }, /* TDM_D1:L1RSYNC */ - /* PB7 */ { 0, 0, 0, 0, 0, 0 }, /* PB7 */ - /* PB6 */ { 0, 0, 0, 0, 0, 0 }, /* PB6 */ - /* PB5 */ { 0, 0, 0, 0, 0, 0 }, /* PB5 */ - /* PB4 */ { 0, 0, 0, 0, 0, 0 }, /* PB4 */ - /* PB3 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PB2 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PB1 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PB0 */ { 0, 0, 0, 0, 0, 0 } /* pin doesn't exist */ - }, - - /* Port C */ - { /* conf ppar psor pdir podr pdat */ - /* PC31 */ { 0, 0, 0, 0, 0, 0 }, /* PC31 */ - /* PC30 */ { 0, 0, 0, 0, 0, 0 }, /* PC30 */ - /* PC29 */ { 0, 0, 0, 0, 0, 0 }, /* PC28 */ - /* PC28 */ { 1, 1, 0, 0, 0, 0 }, /* CLK4 */ - /* PC27 */ { 0, 0, 0, 0, 0, 0 }, /* PC27 */ - /* PC26 */ { 0, 0, 0, 0, 0, 0 }, /* PC26 */ - /* PC25 */ { 1, 1, 0, 0, 0, 0 }, /* CLK7 */ - /* PC24 */ { 0, 0, 0, 0, 0, 0 }, /* PC24 */ - /* PC23 */ { 1, 0, 0, 1, 0, 0 }, /* ATMTFCLK */ - /* PC22 */ { 0, 0, 0, 0, 0, 0 }, /* PC22 */ - /* PC21 */ { 0, 0, 0, 0, 0, 0 }, /* PC23 */ - /* PC20 */ { 0, 0, 0, 0, 0, 0 }, /* PC24 */ - /* PC19 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_CLK */ - /* PC18 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII TX_CLK */ - /* PC17 */ { 0, 0, 0, 0, 0, 0 }, /* PC17 */ - /* PC16 */ { 0, 0, 0, 0, 0, 0 }, /* PC16 */ - /* PC15 */ { 1, 0, 0, 1, 0, 0 }, /* FCC1:TxAddr[0] */ - /* PC14 */ { 1, 0, 0, 1, 0, 0 }, /* FCC1:RxAddr[0] */ - /* PC13 */ { 1, 0, 0, 1, 0, 0 }, /* FCC1:TxAddr[1] */ - /* PC12 */ { 1, 0, 0, 1, 0, 0 }, /* FCC1:RxAddr[1] */ - /* PC11 */ { 1, 1, 0, 1, 0, 0 }, /* TDM_D1:L1CLK0 */ - /* PC10 */ { 1, 0, 0, 1, 0, 0 }, /* FCC2 MDC */ - /* PC9 */ { 1, 0, 0, 1, 0, 0 }, /* FCC2 MDIO */ - /* PC8 */ { 0, 0, 0, 0, 0, 0 }, /* PC8 */ - /* PC7 */ { 1, 0, 0, 1, 0, 0 }, /* FCC1:TxAddr[2]*/ - /* PC6 */ { 1, 0, 0, 1, 0, 0 }, /* FCC1:RxAddr[2] */ - /* PC5 */ { 0, 0, 0, 0, 0, 0 }, /* PC5 */ - /* PC4 */ { 0, 0, 0, 0, 0, 0 }, /* PC4 */ - /* PC3 */ { 1, 0, 0, 1, 0, 0 }, /* IDMA2:DACK */ - /* PC2 */ { 1, 0, 0, 1, 0, 0 }, /* IDMA2:DONE */ - /* PC1 */ { 1, 0, 0, 1, 0, 0 }, /* IDMA2:DREQ */ - /* PC0 */ { 1, 0, 0, 1, 0, 0 }, /* IDMA1:DREQ */ - }, - - /* Port D */ - { /* conf ppar psor pdir podr pdat */ - /* PD31 */ { 0, 0, 0, 0, 0, 0 }, /* PD31 */ - /* PD30 */ { 0, 0, 0, 0, 0, 0 }, /* PD30 */ - /* PD29 */ { 1, 0, 0, 1, 0, 0 }, /* FCC1:RxAddr[3] */ - /* PD28 */ { 0, 0, 0, 0, 0, 0 }, /* PD28 */ - /* PD27 */ { 0, 0, 0, 0, 0, 0 }, /* PD27 */ - /* PD26 */ { 1, 0, 0, 1, 0, 0 }, /* TDM_C1:L1RSYNC */ - /* PD25 */ { 0, 0, 0, 0, 0, 0 }, /* PD25 */ - /* PD24 */ { 0, 0, 0, 0, 0, 0 }, /* PD24 */ - /* PD23 */ { 0, 0, 0, 0, 0, 0 }, /* PD23 */ - /* PD22 */ { 0, 0, 0, 0, 0, 0 }, /* PD22 */ - /* PD21 */ { 0, 0, 0, 0, 0, 0 }, /* PD21 */ - /* PD20 */ { 0, 0, 0, 0, 0, 0 }, /* PD20 */ - /* PD19 */ { 0, 0, 0, 0, 0, 0 }, /* PD19 */ - /* PD18 */ { 0, 0, 0, 0, 0, 0 }, /* PD19 */ - /* PD17 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 ATMRXPRTY */ - /* PD16 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 ATMTXPRTY */ - /* PD15 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SDA */ - /* PD14 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SCL */ - /* PD13 */ { 1, 0, 0, 0, 0, 0 }, /* TDM_B1:L1TXD */ - /* PD12 */ { 1, 0, 0, 0, 0, 0 }, /* TDM_B1:L1RXD */ - /* PD11 */ { 1, 0, 0, 0, 0, 0 }, /* TDM_B1:L1TSYNC */ - /* PD10 */ { 1, 0, 0, 0, 0, 0 }, /* TDM_B1:L1RSYNC*/ - /* PD9 */ { 1, 1, 0, 1, 0, 0 }, /* SMC1:TXD */ - /* PD8 */ { 1, 1, 0, 0, 0, 0 }, /* SMC1:RXD */ - /* PD7 */ { 1, 1, 0, 0, 0, 0 }, /* SMC1:SMSYN */ - /* PD6 */ { 1, 0, 0, 1, 0, 0 }, /* IDMA1:DACK */ - /* PD5 */ { 1, 0, 0, 1, 0, 0 }, /* IDMA1:DONE */ - /* PD4 */ { 0, 0, 0, 0, 0, 0 }, /* PD4 */ - /* PD3 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PD2 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PD1 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PD0 */ { 0, 0, 0, 0, 0, 0 } /* pin doesn't exist */ - } -}; - -/* ------------------------------------------------------------------------- */ - -/* - * Check Board Identity: - */ - -int checkboard (void) -{ - puts ("Board: Wind River PPMC8260\n"); - return 0; -} - -/* ------------------------------------------------------------------------- */ - -phys_size_t initdram (int board_type) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8260_t *memctl = &immap->im_memctl; - volatile uchar c = 0xff; - volatile uchar *ramaddr0 = (uchar *) (CONFIG_SYS_SDRAM0_BASE); - volatile uchar *ramaddr1 = (uchar *) (CONFIG_SYS_SDRAM1_BASE); - ulong psdmr = CONFIG_SYS_PSDMR; - volatile uchar *ramaddr2 = (uchar *) (CONFIG_SYS_SDRAM2_BASE); - ulong lsdmr = CONFIG_SYS_LSDMR; - int i; - - /* - * Quote from 8260 UM (10.4.2 SDRAM Power-On Initialization, 10-35): - * - * "At system reset, initialization software must set up the - * programmable parameters in the memory controller banks registers - * (ORx, BRx, P/LSDMR). After all memory parameters are configured, - * system software should execute the following initialization sequence - * for each SDRAM device. - * - * 1. Issue a PRECHARGE-ALL-BANKS command - * 2. Issue eight CBR REFRESH commands - * 3. Issue a MODE-SET command to initialize the mode register - * - * The initial commands are executed by setting P/LSDMR[OP] and - * accessing the SDRAM with a single-byte transaction." - * - * The appropriate BRx/ORx registers have already been set when we - * get here. The SDRAM can be accessed at the address CONFIG_SYS_SDRAM_BASE. - */ - - memctl->memc_psrt = CONFIG_SYS_PSRT; - memctl->memc_mptpr = CONFIG_SYS_MPTPR; - -#ifndef CONFIG_SYS_RAMBOOT - memctl->memc_psdmr = psdmr | PSDMR_OP_PREA; - *ramaddr0++ = c; - *ramaddr1++ = c; - - memctl->memc_psdmr = psdmr | PSDMR_OP_CBRR; - for (i = 0; i < 8; i++) { - *ramaddr0++ = c; - *ramaddr1++ = c; - } - - memctl->memc_psdmr = psdmr | PSDMR_OP_MRW; - ramaddr0 = (uchar *) (CONFIG_SYS_SDRAM0_BASE + 0x110); - ramaddr1 = (uchar *) (CONFIG_SYS_SDRAM1_BASE + 0x110); - *ramaddr0 = c; - *ramaddr1 = c; - - memctl->memc_psdmr = psdmr | PSDMR_OP_NORM | PSDMR_RFEN; - *ramaddr0 = c; - *ramaddr1 = c; - - memctl->memc_lsdmr = lsdmr | PSDMR_OP_PREA; - *ramaddr2++ = c; - - memctl->memc_lsdmr = lsdmr | PSDMR_OP_CBRR; - for (i = 0; i < 8; i++) { - *ramaddr2++ = c; - } - - memctl->memc_lsdmr = lsdmr | PSDMR_OP_MRW; - *ramaddr2++ = c; - - memctl->memc_lsdmr = lsdmr | PSDMR_OP_NORM | PSDMR_RFEN; - *ramaddr2 = c; -#endif - - /* return total ram size */ - return ((CONFIG_SYS_SDRAM0_SIZE + CONFIG_SYS_SDRAM1_SIZE) * 1024 * 1024); -} - -#ifdef CONFIG_MISC_INIT_R -/* ------------------------------------------------------------------------- */ -int misc_init_r (void) -{ -#ifdef CONFIG_SYS_LED_BASE - uchar ds = *(unsigned char *) (CONFIG_SYS_LED_BASE + 1); - uchar ss; - uchar tmp[64]; - int res; - - if ((ds != 0) && (ds != 0xff)) { - res = getenv_f("ethaddr", (char *)tmp, sizeof (tmp)); - if (res > 0) { - ss = ((ds >> 4) & 0x0f); - ss += ss < 0x0a ? '0' : ('a' - 10); - tmp[15] = ss; - - ss = (ds & 0x0f); - ss += ss < 0x0a ? '0' : ('a' - 10); - tmp[16] = ss; - - tmp[17] = '\0'; - setenv ("ethaddr", (char *)tmp); - /* set the led to show the address */ - *((unsigned char *) (CONFIG_SYS_LED_BASE + 1)) = ds; - } - } -#endif /* CONFIG_SYS_LED_BASE */ - return (0); -} -#endif /* CONFIG_MISC_INIT_R */ diff --git a/configs/ppmc8260_defconfig b/configs/ppmc8260_defconfig deleted file mode 100644 index e8eb4f7..0000000 --- a/configs/ppmc8260_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_PPMC8260=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 5b71bc9..0845651 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,7 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +ppmc8260 powerpc mpc8260 - - Brad Kemp Brad.Kemp@seranoa.com sacsng powerpc mpc8260 - - Jerry Van Baren gerald.vanbaren@smiths-aerospace.com cogent_mpc8260 powerpc mpc8260 - - Murray Jensen Murray.Jensen@csiro.au cogent_8xx powerpc mpc8xx - - Murray Jensen Murray.Jensen@csiro.au diff --git a/include/configs/ppmc8260.h b/include/configs/ppmc8260.h deleted file mode 100644 index 5dcd9cc..0000000 --- a/include/configs/ppmc8260.h +++ /dev/null @@ -1,986 +0,0 @@ -/* - * (C) Copyright 2000 - * Murray Jensen Murray.Jensen@cmst.csiro.au - * - * (C) Copyright 2000 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * - * (C) Copyright 2001 - * Advent Networks, Inc. http://www.adventnetworks.com - * Jay Monkman jtm@smoothsmoothie.com - * - * Configuation settings for the WindRiver PPMC8260 board. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -#define CONFIG_SYS_TEXT_BASE 0xfe000000 - -/***************************************************************************** - * - * These settings must match the way _your_ board is set up - * - *****************************************************************************/ - -/* What is the oscillator's (UX2) frequency in Hz? */ -#define CONFIG_8260_CLKIN (66 * 1000 * 1000) - -/*----------------------------------------------------------------------- - * MODCK_H & MODCLK[1-3] - Ref: Section 9.2 in MPC8206 User Manual - *----------------------------------------------------------------------- - * What should MODCK_H be? It is dependent on the oscillator - * frequency, MODCK[1-3], and desired CPM and core frequencies. - * Here are some example values (all frequencies are in MHz): - * - * MODCK_H MODCK[1-3] Osc CPM Core S2-6 S2-7 S2-8 - * ------- ---------- --- --- ---- ----- ----- ----- - * 0x2 0x2 33 133 133 Close Open Close - * 0x2 0x3 33 133 166 Close Open Open - * 0x2 0x4 33 133 200 Open Close Close - * 0x2 0x5 33 133 233 Open Close Open - * 0x2 0x6 33 133 266 Open Open Close - * - * 0x5 0x5 66 133 133 Open Close Open - * 0x5 0x6 66 133 166 Open Open Close - * 0x5 0x7 66 133 200 Open Open Open - * 0x6 0x0 66 133 233 Close Close Close - * 0x6 0x1 66 133 266 Close Close Open - * 0x6 0x2 66 133 300 Close Open Close - */ -#define CONFIG_SYS_PPMC_MODCK_H 0x05 - -/* Define this if you want to boot from 0x00000100. If you don't define - * this, you will need to program the bootloader to 0xfff00000, and - * get the hardware reset config words at 0xfe000000. The simplest - * way to do that is to program the bootloader at both addresses. - * It is suggested that you just let U-Boot live at 0x00000000. - */ -#define CONFIG_SYS_PPMC_BOOT_LOW 1 - -/* What should the base address of the main FLASH be and how big is - * it (in MBytes)? This must contain CONFIG_SYS_TEXT_BASE from board/ppmc8260/config.mk - * The main FLASH is whichever is connected to *CS0. U-Boot expects - * this to be the SIMM. - */ -#define CONFIG_SYS_FLASH0_BASE 0xFE000000 -#define CONFIG_SYS_FLASH0_SIZE 16 - -/* What should be the base address of the first SDRAM DIMM and how big is - * it (in Mbytes)? -*/ -#define CONFIG_SYS_SDRAM0_BASE 0x00000000 -#define CONFIG_SYS_SDRAM0_SIZE 128 - -/* What should be the base address of the second SDRAM DIMM and how big is - * it (in Mbytes)? -*/ -#define CONFIG_SYS_SDRAM1_BASE 0x08000000 -#define CONFIG_SYS_SDRAM1_SIZE 128 - -/* What should be the base address of the on board SDRAM and how big is - * it (in Mbytes)? -*/ -#define CONFIG_SYS_SDRAM2_BASE 0x38000000 -#define CONFIG_SYS_SDRAM2_SIZE 16 - -/* What should be the base address of the MAILBOX and how big is it - * (in Bytes) - * The eeprom lives at CONFIG_SYS_MAILBOX_BASE + 0x80000000 - */ -#define CONFIG_SYS_MAILBOX_BASE 0x32000000 -#define CONFIG_SYS_MAILBOX_SIZE 8192 - -/* What is the base address of the I/O select lines and how big is it - * (In Mbytes)? - */ - -#define CONFIG_SYS_IOSELECT_BASE 0xE0000000 -#define CONFIG_SYS_IOSELECT_SIZE 32 - - -/* What should be the base address of the LEDs and switch S0? - * If you don't want them enabled, don't define this. - */ -#define CONFIG_SYS_LED_BASE 0xF1000000 - -/* - * PPMC8260 with 256 16 MB DIMM: - * - * 0x0000 0000 Exception Vector code, 8k - * : - * 0x0000 1FFF - * 0x0000 2000 Free for Application Use - * : - * : - * - * : - * : - * 0x0FF5 FF30 Monitor Stack (Growing downward) - * Monitor Stack Buffer (0x80) - * 0x0FF5 FFB0 Board Info Data - * 0x0FF6 0000 Malloc Arena - * : CONFIG_ENV_SECT_SIZE, 256k - * : CONFIG_SYS_MALLOC_LEN, 128k - * 0x0FFC 0000 RAM Copy of Monitor Code - * : CONFIG_SYS_MONITOR_LEN, 256k - * 0x0FFF FFFF [End of RAM], CONFIG_SYS_SDRAM_SIZE - 1 - */ - - -/* - * select serial console configuration - * - * if either CONFIG_CONS_ON_SMC or CONFIG_CONS_ON_SCC is selected, then - * CONFIG_CONS_INDEX must be set to the channel number (1-2 for SMC, 1-4 - * for SCC). - * - * if CONFIG_CONS_NONE is defined, then the serial console routines must - * defined elsewhere. - * The console can be on SMC1 or SMC2 - */ -#define CONFIG_CONS_ON_SMC 1 /* define if console on SMC */ -#undef CONFIG_CONS_ON_SCC /* define if console on SCC */ -#undef CONFIG_CONS_NONE /* define if console on neither */ -#define CONFIG_CONS_INDEX 1 /* which SMC/SCC channel for console */ - -/* - * select ethernet configuration - * - * if either CONFIG_ETHER_ON_SCC or CONFIG_ETHER_ON_FCC is selected, then - * CONFIG_ETHER_INDEX must be set to the channel number (1-4 for SCC, 1-3 - * for FCC) - * - * if CONFIG_ETHER_NONE is defined, then either the ethernet routines must be - * defined elsewhere (as for the console), or CONFIG_CMD_NET must be unset. - */ - -#undef CONFIG_ETHER_ON_SCC /* define if ethernet on SCC */ -#define CONFIG_ETHER_ON_FCC /* define if ethernet on FCC */ -#undef CONFIG_ETHER_NONE /* define if ethernet on neither */ -#define CONFIG_ETHER_INDEX 2 /* which SCC/FCC channel for ethernet */ -#define CONFIG_MII /* MII PHY management */ -#define CONFIG_BITBANGMII /* bit-bang MII PHY management */ -/* - * Port pins used for bit-banged MII communictions (if applicable). - */ -#define MDIO_PORT 2 /* Port C */ -#define MDIO_DECLARE volatile ioport_t *iop = ioport_addr ( \ - (immap_t *) CONFIG_SYS_IMMR, MDIO_PORT ) -#define MDC_DECLARE MDIO_DECLARE - -#define MDIO_ACTIVE (iop->pdir |= 0x00400000) -#define MDIO_TRISTATE (iop->pdir &= ~0x00400000) -#define MDIO_READ ((iop->pdat & 0x00400000) != 0) - -#define MDIO(bit) if(bit) iop->pdat |= 0x00400000; \ - else iop->pdat &= ~0x00400000 - -#define MDC(bit) if(bit) iop->pdat |= 0x00200000; \ - else iop->pdat &= ~0x00200000 - -#define MIIDELAY udelay(1) - - -/* Define this to reserve an entire FLASH sector (256 KB) for - * environment variables. Otherwise, the environment will be - * put in the same sector as U-Boot, and changing variables - * will erase U-Boot temporarily - */ -#define CONFIG_ENV_IN_OWN_SECT 1 - -/* Define to allow the user to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE - -/* What should the console's baud rate be? */ -#define CONFIG_BAUDRATE 9600 - -/* Ethernet MAC address */ - -#define CONFIG_ETHADDR 00:a0:1e:90:2b:00 - -/* Define this to set the last octet of the ethernet address - * from the DS0-DS7 switch and light the leds with the result - * The DS0-DS7 switch and the leds are backwards with respect - * to each other. DS7 is on the board edge side of both the - * led strip and the DS0-DS7 switch. - */ -#define CONFIG_MISC_INIT_R - -/* Set to a positive value to delay for running BOOTCOMMAND */ -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ - -#if 0 -/* Be selective on what keys can delay or stop the autoboot process - * To stop use: " " - */ -# define CONFIG_AUTOBOOT_KEYED -# define CONFIG_AUTOBOOT_PROMPT \ - "Autobooting in %d seconds, press " " to stop\n", bootdelay -# define CONFIG_AUTOBOOT_STOP_STR " " -# undef CONFIG_AUTOBOOT_DELAY_STR -# define DEBUG_BOOTKEYS 0 -#endif - -/* Define a command string that is automatically executed when no character - * is read on the console interface withing "Boot Delay" after reset. - */ -#undef CONFIG_BOOT_ROOT_INITRD /* Use ram disk for the root file system */ -#define CONFIG_BOOT_ROOT_NFS /* Use a NFS mounted root file system */ - -#ifdef CONFIG_BOOT_ROOT_INITRD -#define CONFIG_BOOTCOMMAND \ - "version;" \ - "echo;" \ - "bootp;" \ - "setenv bootargs root=/dev/ram0 rw " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off;" \ - "bootm" -#endif /* CONFIG_BOOT_ROOT_INITRD */ - -#ifdef CONFIG_BOOT_ROOT_NFS -#define CONFIG_BOOTCOMMAND \ - "version;" \ - "echo;" \ - "bootp;" \ - "setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off;" \ - "bootm" -#endif /* CONFIG_BOOT_ROOT_NFS */ - - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_DNS - - -/* undef this to save memory */ -#define CONFIG_SYS_LONGHELP - -/* Monitor Command Prompt */ - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_ELF -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_REGINFO -#define CONFIG_CMD_MEMTEST -#define CONFIG_CMD_MII -#define CONFIG_CMD_IMMAP - -#undef CONFIG_CMD_KGDB - - -/* Where do the internal registers live? */ -#define CONFIG_SYS_IMMR 0xf0000000 - -/***************************************************************************** - * - * You should not have to modify any of the following settings - * - *****************************************************************************/ - -#define CONFIG_PPMC8260 1 /* on an Wind River PPMC8260 Board */ -#define CONFIG_CPM2 1 /* Has a CPM2 */ - -/* - * Miscellaneous configurable options - */ -#if defined(CONFIG_CMD_KGDB) -# define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -# define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif - -/* Print Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT)+16) - -#define CONFIG_SYS_MAXARGS 32 /* max number of command args */ - -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_LOAD_ADDR 0x140000 /* default load address */ - -#define CONFIG_SYS_MEMTEST_START 0x2000 /* memtest works from the end of */ - /* the exception vector table */ - /* to the end of the DRAM */ - /* less monitor and malloc area */ -#define CONFIG_SYS_STACK_USAGE 0x10000 /* Reserve 64k for the stack usage */ -#define CONFIG_SYS_MEM_END_USAGE ( CONFIG_SYS_MONITOR_LEN \ - + CONFIG_SYS_MALLOC_LEN \ - + CONFIG_ENV_SECT_SIZE \ - + CONFIG_SYS_STACK_USAGE ) - -#define CONFIG_SYS_MEMTEST_END ( CONFIG_SYS_SDRAM_SIZE * 1024 * 1024 \ - - CONFIG_SYS_MEM_END_USAGE ) - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ - -#if defined(CONFIG_ETHER_ON_SCC) && (CONFIG_ETHER_INDEX == 1) -/* - * Attention: This is board specific - * - RX clk is CLK11 - * - TX clk is CLK12 - */ -#define CONFIG_SYS_CMXSCR_VALUE (CMXSCR_RS1CS_CLK11 |\ - CMXSCR_TS1CS_CLK12) - -#elif defined(CONFIG_ETHER_ON_FCC) && (CONFIG_ETHER_INDEX == 2) -/* - * Attention: this is board-specific - * - Rx-CLK is CLK13 - * - Tx-CLK is CLK14 - * - Select bus for bd/buffers (see 28-13) - * - Enable Full Duplex in FSMR - */ -#define CONFIG_SYS_CMXFCR_MASK2 (CMXFCR_FC2|CMXFCR_RF2CS_MSK|CMXFCR_TF2CS_MSK) -#define CONFIG_SYS_CMXFCR_VALUE2 (CMXFCR_RF2CS_CLK13|CMXFCR_TF2CS_CLK14) -#define CONFIG_SYS_CPMFCR_RAMTYPE 0 -#define CONFIG_SYS_FCC_PSMR (FCC_PSMR_FDE | FCC_PSMR_LPB) -#endif /* CONFIG_ETHER_INDEX */ - -#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_FLASH0_BASE -#define CONFIG_SYS_FLASH_SIZE CONFIG_SYS_FLASH0_SIZE -#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_SDRAM0_BASE -#define CONFIG_SYS_SDRAM_SIZE (CONFIG_SYS_SDRAM0_SIZE + CONFIG_SYS_SDRAM1_SIZE) - -/*----------------------------------------------------------------------- - * Hard Reset Configuration Words - */ -#if defined(CONFIG_SYS_PPMC_BOOT_LOW) -# define CONFIG_SYS_PPMC_HRCW_BOOT_FLAGS (HRCW_CIP | HRCW_BMS) -#else -# define CONFIG_SYS_PPMC_HRCW_BOOT_FLAGS (0) -#endif /* defined(CONFIG_SYS_PPMC_BOOT_LOW) */ - -/* get the HRCW ISB field from CONFIG_SYS_IMMR */ -#define CONFIG_SYS_PPMC_HRCW_IMMR ( ((CONFIG_SYS_IMMR & 0x10000000) >> 10) | \ - ((CONFIG_SYS_IMMR & 0x01000000) >> 7) | \ - ((CONFIG_SYS_IMMR & 0x00100000) >> 4) ) - -#define CONFIG_SYS_HRCW_MASTER ( HRCW_EBM | \ - HRCW_BPS11 | \ - HRCW_L2CPC10 | \ - HRCW_DPPC00 | \ - CONFIG_SYS_PPMC_HRCW_IMMR | \ - HRCW_MMR00 | \ - HRCW_LBPC00 | \ - HRCW_APPC10 | \ - HRCW_CS10PC00 | \ - (CONFIG_SYS_PPMC_MODCK_H & HRCW_MODCK_H1111) | \ - CONFIG_SYS_PPMC_HRCW_BOOT_FLAGS ) - -/* no slaves */ -#define CONFIG_SYS_HRCW_SLAVE1 0 -#define CONFIG_SYS_HRCW_SLAVE2 0 -#define CONFIG_SYS_HRCW_SLAVE3 0 -#define CONFIG_SYS_HRCW_SLAVE4 0 -#define CONFIG_SYS_HRCW_SLAVE5 0 -#define CONFIG_SYS_HRCW_SLAVE6 0 -#define CONFIG_SYS_HRCW_SLAVE7 0 - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - * Note also that the logic that sets CONFIG_SYS_RAMBOOT is platform dependent. - */ -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH0_BASE - -#ifndef CONFIG_SYS_MONITOR_BASE -#define CONFIG_SYS_MONITOR_BASE 0x0ff80000 -#endif - -#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) -# define CONFIG_SYS_RAMBOOT -#endif - -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 374 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * FLASH and environment organization - */ - -#define CONFIG_SYS_FLASH_CFI 1 /* Flash is CFI conformant */ -#define CONFIG_FLASH_CFI_DRIVER 1 /* Use the common driver */ -#define CONFIG_SYS_MAX_FLASH_SECT 128 /* max number of sectors on one chip */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CONFIG_SYS_FLASH_INCREMENT 0 /* there is only one bank */ -#define CONFIG_SYS_FLASH_PROTECTION 1 /* use hardware protection */ -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 /* use buffered writes (20x faster) */ - - -#ifndef CONFIG_SYS_RAMBOOT - -# define CONFIG_ENV_IS_IN_FLASH 1 -# ifdef CONFIG_ENV_IN_OWN_SECT -# define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + 0x40000) -# define CONFIG_ENV_SECT_SIZE 0x40000 -# else -# define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_SYS_MONITOR_LEN - CONFIG_ENV_SECT_SIZE) -# define CONFIG_ENV_SIZE 0x1000 /* Total Size of Environment Sector */ -# define CONFIG_ENV_SECT_SIZE 0x40000 /* see README - env sect real size */ -# endif /* CONFIG_ENV_IN_OWN_SECT */ - -#else -# define CONFIG_ENV_IS_IN_FLASH 1 -# define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x40000) -#define CONFIG_ENV_SIZE 0x1000 -# define CONFIG_ENV_SECT_SIZE 0x40000 -#endif /* CONFIG_SYS_RAMBOOT */ - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC8260 CPU */ - -#if defined(CONFIG_CMD_KGDB) -# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * HIDx - Hardware Implementation-dependent Registers 2-11 - *----------------------------------------------------------------------- - * HID0 also contains cache control - initially enable both caches and - * invalidate contents, then the final state leaves only the instruction - * cache enabled. Note that Power-On and Hard reset invalidate the caches, - * but Soft reset does not. - * - * HID1 has only read-only information - nothing to set. - */ -#define CONFIG_SYS_HID0_INIT (HID0_ICE |\ - HID0_DCE |\ - HID0_ICFI |\ - HID0_DCI |\ - HID0_IFEM |\ - HID0_ABE) - -#define CONFIG_SYS_HID0_FINAL (HID0_ICE |\ - HID0_IFEM |\ - HID0_ABE |\ - HID0_EMCP) -#define CONFIG_SYS_HID2 0 - -/*----------------------------------------------------------------------- - * RMR - Reset Mode Register - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RMR 0 - -/*----------------------------------------------------------------------- - * BCR - Bus Configuration 4-25 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_BCR (BCR_EBM |\ - 0x30000000) - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 4-31 - * Ref Section 4.3.2.6 page 4-31 - *----------------------------------------------------------------------- - */ - -#define CONFIG_SYS_SIUMCR (SIUMCR_ESE |\ - SIUMCR_DPPC00 |\ - SIUMCR_L2CPC10 |\ - SIUMCR_LBPC00 |\ - SIUMCR_APPC10 |\ - SIUMCR_CS10PC00 |\ - SIUMCR_BCTLC00 |\ - SIUMCR_MMR00) - - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 11-9 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Watchdog & Bus Monitor Timer max, 60x Bus Monitor enable - */ -#define CONFIG_SYS_SYPCR (SYPCR_SWTC |\ - SYPCR_BMT |\ - SYPCR_PBME |\ - SYPCR_LBME |\ - SYPCR_SWRI |\ - SYPCR_SWP) - -/*----------------------------------------------------------------------- - * TMCNTSC - Time Counter Status and Control 4-40 - *----------------------------------------------------------------------- - * Clear once per Second and Alarm Interrupt Status, Set 32KHz timersclk, - * and enable Time Counter - */ -#define CONFIG_SYS_TMCNTSC (TMCNTSC_SEC |\ - TMCNTSC_ALR |\ - TMCNTSC_TCF |\ - TMCNTSC_TCE) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 4-42 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Set 32KHz timersclk, and enable - * Periodic timer - */ -#define CONFIG_SYS_PISCR (PISCR_PS |\ - PISCR_PTF |\ - PISCR_PTE) - -/*----------------------------------------------------------------------- - * SCCR - System Clock Control 9-8 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_SCCR 0 - -/*----------------------------------------------------------------------- - * RCCR - RISC Controller Configuration 13-7 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RCCR 0 - -/* - * Initialize Memory Controller: - * - * Bank Bus Machine PortSz Device - * ---- --- ------- ------ ------ - * 0 60x GPCM 32 bit FLASH (SIMM - 32MB) * - * 1 unused - * 2 60x SDRAM 64 bit SDRAM (DIMM - 128MB) - * 3 60x SDRAM 64 bit SDRAM (DIMM - 128MB) - * 4 Local SDRAM 32 bit SDRAM (on board - 16MB) - * 5 60x GPCM 8 bit Mailbox/EEPROM (8KB) - * 6 60x GPCM 8 bit FLASH (on board - 2MB) * - * 7 60x GPCM 8 bit LEDs, switches - * - * (*) This configuration requires the PPMC8260 be configured - * so that *CS0 goes to the FLASH SIMM, and *CS6 goes to - * the on board FLASH. In other words, JP24 should have - * pins 1 and 2 jumpered and pins 3 and 4 jumpered. - * - */ - -/*----------------------------------------------------------------------- - * BR0,BR1 - Base Register - * Ref: Section 10.3.1 on page 10-14 - * OR0,OR1 - Option Register - * Ref: Section 10.3.2 on page 10-18 - *----------------------------------------------------------------------- - */ - -/* Bank 0,1 - FLASH SIMM - * - * This expects the FLASH SIMM to be connected to *CS0 - * It consists of 4 AM29F080B parts. - * - * Note: For the 4 MB SIMM, *CS1 is unused. - */ - -/* BR0 is configured as follows: - * - * - Base address of 0xFE000000 - * - 32 bit port size - * - Data errors checking is disabled - * - Read and write access - * - GPCM 60x bus - * - Access are handled by the memory controller according to MSEL - * - Not used for atomic operations - * - No data pipelining is done - * - Valid - */ -#define CONFIG_SYS_BR0_PRELIM ((CONFIG_SYS_FLASH0_BASE & BRx_BA_MSK) |\ - BRx_PS_32 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -/* OR0 is configured as follows: - * - * - 32 MB - * - *BCTL0 is asserted upon access to the current memory bank - * - *CW / *WE are negated a quarter of a clock earlier - * - *CS is output at the same time as the address lines - * - Uses a clock cycle length of 5 - * - *PSDVAL is generated internally by the memory controller - * unless *GTA is asserted earlier externally. - * - Relaxed timing is generated by the GPCM for accesses - * initiated to this memory region. - * - One idle clock is inserted between a read access from the - * current bank and the next access. - */ -#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH0_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_5_CLK |\ - ORxG_TRLX |\ - ORxG_EHTR) - -/*----------------------------------------------------------------------- - * BR2,BR3 - Base Register - * Ref: Section 10.3.1 on page 10-14 - * OR2,OR3 - Option Register - * Ref: Section 10.3.2 on page 10-16 - *----------------------------------------------------------------------- - */ - -/* - * Bank 2,3 - 128 MB SDRAM DIMM - */ - -/* With a 128 MB DIMM, the BR2 is configured as follows: - * - * - Base address of 0x00000000/0x08000000 - * - 64 bit port size (60x bus only) - * - Data errors checking is disabled - * - Read and write access - * - SDRAM 60x bus - * - Access are handled by the memory controller according to MSEL - * - Not used for atomic operations - * - No data pipelining is done - * - Valid - */ -#define CONFIG_SYS_BR2_PRELIM ((CONFIG_SYS_SDRAM0_BASE & BRx_BA_MSK) |\ - BRx_PS_64 |\ - BRx_MS_SDRAM_P |\ - BRx_V) - -#define CONFIG_SYS_BR3_PRELIM ((CONFIG_SYS_SDRAM1_BASE & BRx_BA_MSK) |\ - BRx_PS_64 |\ - BRx_MS_SDRAM_P |\ - BRx_V) - -/* With a 128 MB DIMM, the OR2 is configured as follows: - * - * - 128 MB - * - 4 internal banks per device - * - Row start address bit is A8 with PSDMR[PBI] = 0 - * - 13 row address lines - * - Back-to-back page mode - * - Internal bank interleaving within save device enabled - */ - -#define CONFIG_SYS_OR2_PRELIM (MEG_TO_AM(CONFIG_SYS_SDRAM0_SIZE) |\ - ORxS_BPD_4 |\ - ORxS_ROWST_PBI0_A7 |\ - ORxS_NUMR_13) - -#define CONFIG_SYS_OR3_PRELIM (MEG_TO_AM(CONFIG_SYS_SDRAM1_SIZE) |\ - ORxS_BPD_4 |\ - ORxS_ROWST_PBI0_A7 |\ - ORxS_NUMR_13) - - -/*----------------------------------------------------------------------- - * PSDMR - 60x Bus SDRAM Mode Register - * Ref: Section 10.3.3 on page 10-21 - *----------------------------------------------------------------------- - */ - -/* With a 128 MB DIMM, the PSDMR is configured as follows: - * - * - Page Based Interleaving, - * - Refresh Enable, - * - Normal Operation - * - Address Multiplexing where A5 is output on A14 pin - * (A6 on A15, and so on), - * - use address pins A13-A15 as bank select, - * - A9 is output on SDA10 during an ACTIVATE command, - * - earliest timing for ACTIVATE command after REFRESH command is 7 clocks, - * - earliest timing for ACTIVATE or REFRESH command after PRECHARGE command - * is 3 clocks, - * - earliest timing for READ/WRITE command after ACTIVATE command is - * 2 clocks, - * - earliest timing for PRECHARGE after last data was read is 1 clock, - * - earliest timing for PRECHARGE after last data was written is 1 clock, - * - External Address Multiplexing enabled - * - CAS Latency is 2. - */ -#define CONFIG_SYS_PSDMR (PSDMR_RFEN |\ - PSDMR_SDAM_A14_IS_A5 |\ - PSDMR_BSMA_A13_A15 |\ - PSDMR_SDA10_PBI0_A9 |\ - PSDMR_RFRC_7_CLK |\ - PSDMR_PRETOACT_3W |\ - PSDMR_ACTTORW_2W |\ - PSDMR_LDOTOPRE_1C |\ - PSDMR_WRC_1C |\ - PSDMR_EAMUX |\ - PSDMR_CL_2) - - -#define CONFIG_SYS_PSRT 0x0e -#define CONFIG_SYS_MPTPR MPTPR_PTP_DIV32 - - -/*----------------------------------------------------------------------- - * BR4 - Base Register - * Ref: Section 10.3.1 on page 10-14 - * OR4 - Option Register - * Ref: Section 10.3.2 on page 10-16 - *----------------------------------------------------------------------- - */ - -/* - * Bank 4 - On board SDRAM - * - */ -/* With 16 MB of onboard SDRAM BR4 is configured as follows - * - * - Base address 0x38000000 - * - 32 bit port size - * - Data error checking disabled - * - Read/Write access - * - SDRAM local bus - * - Not used for atomic operations - * - No data pipelining is done - * - Valid - * - */ - -#define CONFIG_SYS_BR4_PRELIM ((CONFIG_SYS_SDRAM2_BASE & BRx_BA_MSK) |\ - BRx_PS_32 |\ - BRx_DECC_NONE |\ - BRx_MS_SDRAM_L |\ - BRx_V) - -/* - * With 16MB SDRAM, OR4 is configured as follows - * - 4 internal banks per device - * - Row start address bit is A10 with LSDMR[PBI] = 0 - * - 12 row address lines - * - Back-to-back page mode - * - Internal bank interleaving within save device enabled - */ - -#define CONFIG_SYS_OR4_PRELIM (MEG_TO_AM(CONFIG_SYS_SDRAM2_SIZE) |\ - ORxS_BPD_4 |\ - ORxS_ROWST_PBI0_A10 |\ - ORxS_NUMR_12) - - -/*----------------------------------------------------------------------- - * LSDMR - Local Bus SDRAM Mode Register - * Ref: Section 10.3.4 on page 10-24 - *----------------------------------------------------------------------- - */ - -/* With a 16 MB onboard SDRAM, the LSDMR is configured as follows: - * - * - Page Based Interleaving, - * - Refresh Enable, - * - Normal Operation - * - Address Multiplexing where A5 is output on A13 pin - * (A6 on A15, and so on), - * - use address pins A15-A17 as bank select, - * - A11 is output on SDA10 during an ACTIVATE command, - * - earliest timing for ACTIVATE command after REFRESH command is 7 clocks, - * - earliest timing for ACTIVATE or REFRESH command after PRECHARGE command - * is 2 clocks, - * - earliest timing for READ/WRITE command after ACTIVATE command is - * 2 clocks, - * - SDRAM burst length is 8 - * - earliest timing for PRECHARGE after last data was read is 1 clock, - * - earliest timing for PRECHARGE after last data was written is 1 clock, - * - External Address Multiplexing disabled - * - CAS Latency is 2. - */ -#define CONFIG_SYS_LSDMR (PSDMR_RFEN |\ - PSDMR_SDAM_A13_IS_A5 |\ - PSDMR_BSMA_A15_A17 |\ - PSDMR_SDA10_PBI0_A11 |\ - PSDMR_RFRC_7_CLK |\ - PSDMR_PRETOACT_2W |\ - PSDMR_ACTTORW_2W |\ - PSDMR_BL |\ - PSDMR_LDOTOPRE_1C |\ - PSDMR_WRC_1C |\ - PSDMR_CL_2) - -#define CONFIG_SYS_LSRT 0x0e - -/*----------------------------------------------------------------------- - * BR5 - Base Register - * Ref: Section 10.3.1 on page 10-14 - * OR5 - Option Register - * Ref: Section 10.3.2 on page 10-16 - *----------------------------------------------------------------------- - */ - -/* - * Bank 5 EEProm and Mailbox - * - * The EEPROM and mailbox live on the same chip select. - * the eeprom is selected if the MSb of the address is set and the mailbox is - * selected if the MSb of the address is clear. - * - */ - -/* BR5 is configured as follows: - * - * - Base address of 0x32000000/0xF2000000 - * - 8 bit - * - Data error checking disabled - * - Read/Write access - * - GPCM 60x Bus - * - SDRAM local bus - * - No data pipelining is done - * - Valid - */ - -#define CONFIG_SYS_BR5_PRELIM ((CONFIG_SYS_MAILBOX_BASE & BRx_BA_MSK) |\ - BRx_PS_8 |\ - BRx_DECC_NONE |\ - BRx_MS_GPCM_P |\ - BRx_V) -/* OR5 is configured as follows - * - buffer control enabled - * - chip select negated normally - * - CS output 1/2 clock after address - * - 15 wait states - * - *PSDVAL is generated internally by the memory controller - * unless *GTA is asserted earlier externally. - * - Relaxed timing is generated by the GPCM for accesses - * initiated to this memory region. - * - One idle clock is inserted between a read access from the - * current bank and the next access. - */ - -#define CONFIG_SYS_OR5_PRELIM ((P2SZ_TO_AM(CONFIG_SYS_MAILBOX_SIZE) & ~0x80000000) |\ - ORxG_ACS_DIV2 |\ - ORxG_SCY_15_CLK |\ - ORxG_TRLX |\ - ORxG_EHTR) - -/*----------------------------------------------------------------------- - * BR6 - Base Register - * Ref: Section 10.3.1 on page 10-14 - * OR6 - Option Register - * Ref: Section 10.3.2 on page 10-18 - *----------------------------------------------------------------------- - */ - -/* Bank 6 - I/O select - * - */ - -/* BR6 is configured as follows: - * - * - Base address of 0xE0000000 - * - 16 bit port size - * - Data errors checking is disabled - * - Read and write access - * - GPCM 60x bus - * - Access are handled by the memory controller according to MSEL - * - Not used for atomic operations - * - No data pipelining is done - * - Valid - */ -#define CONFIG_SYS_BR6_PRELIM ((CONFIG_SYS_IOSELECT_BASE & BRx_BA_MSK) |\ - BRx_PS_16 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -/* OR6 is configured as follows - * - buffer control enabled - * - chip select negated normally - * - CS output 1/2 clock after address - * - 15 wait states - * - *PSDVAL is generated internally by the memory controller - * unless *GTA is asserted earlier externally. - * - Relaxed timing is generated by the GPCM for accesses - * initiated to this memory region. - * - One idle clock is inserted between a read access from the - * current bank and the next access. - */ - -#define CONFIG_SYS_OR6_PRELIM (MEG_TO_AM(CONFIG_SYS_IOSELECT_SIZE) |\ - ORxG_ACS_DIV2 |\ - ORxG_SCY_15_CLK |\ - ORxG_TRLX |\ - ORxG_EHTR) - - -/*----------------------------------------------------------------------- - * BR7 - Base Register - * Ref: Section 10.3.1 on page 10-14 - * OR7 - Option Register - * Ref: Section 10.3.2 on page 10-18 - *----------------------------------------------------------------------- - */ - -/* Bank 7 - LEDs and switches - * - * LEDs are at 0x00001 (write only) - * switches are at 0x00001 (read only) - */ -#ifdef CONFIG_SYS_LED_BASE - -/* BR7 is configured as follows: - * - * - Base address of 0xA0000000 - * - 8 bit port size - * - Data errors checking is disabled - * - Read and write access - * - GPCM 60x bus - * - Access are handled by the memory controller according to MSEL - * - Not used for atomic operations - * - No data pipelining is done - * - Valid - */ -#define CONFIG_SYS_BR7_PRELIM ((CONFIG_SYS_LED_BASE & BRx_BA_MSK) |\ - BRx_PS_8 |\ - BRx_DECC_NONE |\ - BRx_MS_GPCM_P |\ - BRx_V) - -/* OR7 is configured as follows: - * - * - 1 byte - * - *BCTL0 is asserted upon access to the current memory bank - * - *CW / *WE are negated a quarter of a clock earlier - * - *CS is output at the same time as the address lines - * - Uses a clock cycle length of 15 - * - *PSDVAL is generated internally by the memory controller - * unless *GTA is asserted earlier externally. - * - Relaxed timing is generated by the GPCM for accesses - * initiated to this memory region. - * - One idle clock is inserted between a read access from the - * current bank and the next access. - */ -#define CONFIG_SYS_OR7_PRELIM (ORxG_AM_MSK |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_15_CLK |\ - ORxG_TRLX |\ - ORxG_EHTR) -#endif /* CONFIG_SYS_LED_BASE */ -#endif /* __CONFIG_H */
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Frank Panno fpanno@delphintech.com ---
arch/powerpc/cpu/mpc8260/Kconfig | 4 - board/ep8260/Kconfig | 9 - board/ep8260/MAINTAINERS | 6 - board/ep8260/Makefile | 8 - board/ep8260/ep8260.c | 304 ---------------- board/ep8260/ep8260.h | 24 -- board/ep8260/flash.c | 395 --------------------- board/ep8260/mii_phy.c | 107 ------ configs/ep8260_defconfig | 3 - doc/README.scrapyard | 1 + include/configs/ep8260.h | 744 --------------------------------------- 11 files changed, 1 insertion(+), 1604 deletions(-) delete mode 100644 board/ep8260/Kconfig delete mode 100644 board/ep8260/MAINTAINERS delete mode 100644 board/ep8260/Makefile delete mode 100644 board/ep8260/ep8260.c delete mode 100644 board/ep8260/ep8260.h delete mode 100644 board/ep8260/flash.c delete mode 100644 board/ep8260/mii_phy.c delete mode 100644 configs/ep8260_defconfig delete mode 100644 include/configs/ep8260.h
diff --git a/arch/powerpc/cpu/mpc8260/Kconfig b/arch/powerpc/cpu/mpc8260/Kconfig index d4132a0..1032712 100644 --- a/arch/powerpc/cpu/mpc8260/Kconfig +++ b/arch/powerpc/cpu/mpc8260/Kconfig @@ -16,9 +16,6 @@ config TARGET_CPU86 config TARGET_CPU87 bool "Support CPU87"
-config TARGET_EP8260 - bool "Support ep8260" - config TARGET_EP82XXM bool "Support ep82xxm"
@@ -51,7 +48,6 @@ endchoice source "board/atc/Kconfig" source "board/cpu86/Kconfig" source "board/cpu87/Kconfig" -source "board/ep8260/Kconfig" source "board/ep82xxm/Kconfig" source "board/freescale/mpc8266ads/Kconfig" source "board/funkwerk/vovpn-gw/Kconfig" diff --git a/board/ep8260/Kconfig b/board/ep8260/Kconfig deleted file mode 100644 index 5d876f4..0000000 --- a/board/ep8260/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_EP8260 - -config SYS_BOARD - default "ep8260" - -config SYS_CONFIG_NAME - default "ep8260" - -endif diff --git a/board/ep8260/MAINTAINERS b/board/ep8260/MAINTAINERS deleted file mode 100644 index bfa923c..0000000 --- a/board/ep8260/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -EP8260 BOARD -#M: Frank Panno fpanno@delphintech.com -S: Orphan (since 2014-06) -F: board/ep8260/ -F: include/configs/ep8260.h -F: configs/ep8260_defconfig diff --git a/board/ep8260/Makefile b/board/ep8260/Makefile deleted file mode 100644 index dd08b74..0000000 --- a/board/ep8260/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2002-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = ep8260.o flash.o mii_phy.o diff --git a/board/ep8260/ep8260.c b/board/ep8260/ep8260.c deleted file mode 100644 index 3697d24..0000000 --- a/board/ep8260/ep8260.c +++ /dev/null @@ -1,304 +0,0 @@ -/* - * (C) Copyright 2001, 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * (C) Copyright 2002 - * Frank Panno fpanno@delphintech.com, Delphin Technology AG - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <ioports.h> -#include <mpc8260.h> -#include "ep8260.h" -/* - * I/O Port configuration table - * - * if conf is 1, then that port pin will be configured at boot time - * according to the five values podr/pdir/ppar/psor/pdat for that entry - */ - -const iop_conf_t iop_conf_tab[4][32] = { - - /* Port A configuration */ - { /* conf ppar psor pdir podr pdat */ - /* PA31 */ { 0, 0, 0, 1, 0, 0 }, /* */ - /* PA30 */ { 0, 0, 0, 1, 0, 0 }, /* */ - /* PA29 */ { 0, 0, 0, 1, 0, 0 }, /* */ - /* PA28 */ { 0, 0, 0, 1, 0, 0 }, /* */ - /* PA27 */ { 0, 0, 0, 1, 0, 0 }, /* */ - /* PA26 */ { 0, 0, 0, 1, 0, 0 }, /* */ - /* PA25 */ { 0, 0, 0, 1, 0, 0 }, /* */ - /* PA24 */ { 0, 0, 0, 1, 0, 0 }, /* */ - /* PA23 */ { 0, 0, 0, 1, 0, 0 }, /* */ - /* PA22 */ { 0, 0, 0, 1, 0, 0 }, /* */ - /* PA21 */ { 0, 0, 0, 1, 0, 0 }, /* */ - /* PA20 */ { 0, 0, 0, 1, 0, 0 }, /* */ - /* PA19 */ { 0, 0, 0, 1, 0, 0 }, /* */ - /* PA18 */ { 0, 0, 0, 1, 0, 0 }, /* */ - /* PA17 */ { 0, 0, 0, 1, 0, 0 }, /* */ - /* PA16 */ { 0, 0, 0, 1, 0, 0 }, /* */ - /* PA15 */ { 0, 0, 0, 1, 0, 0 }, /* */ - /* PA14 */ { 0, 0, 0, 1, 0, 0 }, /* */ - /* PA13 */ { 0, 0, 0, 1, 0, 0 }, /* */ - /* PA12 */ { 0, 0, 0, 1, 0, 0 }, /* */ - /* PA11 */ { 0, 0, 0, 1, 0, 0 }, /* */ - /* PA10 */ { 0, 0, 0, 1, 0, 0 }, /* */ - /* PA9 */ { 0, 1, 0, 1, 0, 0 }, /* */ - /* PA8 */ { 0, 1, 0, 0, 0, 0 }, /* */ - /* PA7 */ { 0, 0, 0, 1, 0, 0 }, /* PA7 */ - /* PA6 */ { 0, 0, 0, 1, 0, 0 }, /* PA6 */ - /* PA5 */ { 0, 0, 0, 1, 0, 0 }, /* PA5 */ - /* PA4 */ { 0, 0, 0, 1, 0, 0 }, /* PA4 */ - /* PA3 */ { 0, 0, 0, 1, 0, 0 }, /* PA3 */ - /* PA2 */ { 0, 0, 0, 1, 0, 0 }, /* PA2 */ - /* PA1 */ { 0, 0, 0, 1, 0, 0 }, /* PA1 */ - /* PA0 */ { 0, 0, 0, 1, 0, 0 } /* PA0 */ - }, - - /* Port B configuration */ - { /* conf ppar psor pdir podr pdat */ - /* PB31 */ { 0, 1, 0, 1, 0, 0 }, /* */ - /* PB30 */ { 0, 1, 0, 0, 0, 0 }, /* */ - /* PB29 */ { 0, 1, 1, 1, 0, 0 }, /* */ - /* PB28 */ { 0, 1, 0, 0, 0, 0 }, /* */ - /* PB27 */ { 0, 1, 0, 0, 0, 0 }, /* */ - /* PB26 */ { 0, 1, 0, 0, 0, 0 }, /* */ - /* PB25 */ { 0, 1, 0, 1, 0, 0 }, /* */ - /* PB24 */ { 0, 1, 0, 1, 0, 0 }, /* */ - /* PB23 */ { 0, 1, 0, 1, 0, 0 }, /* */ - /* PB22 */ { 0, 1, 0, 1, 0, 0 }, /* */ - /* PB21 */ { 0, 1, 0, 0, 0, 0 }, /* */ - /* PB20 */ { 0, 1, 0, 0, 0, 0 }, /* */ - /* PB19 */ { 0, 1, 0, 0, 0, 0 }, /* */ - /* PB18 */ { 0, 1, 0, 0, 0, 0 }, /* */ - /* PB17 */ { 1, 1, 0, 0, 0, 0 }, /* FCC3 MII RX_DV */ - /* PB16 */ { 1, 1, 0, 0, 0, 0 }, /* FCC3 MII RX_ER */ - /* PB15 */ { 1, 1, 0, 1, 0, 0 }, /* FCC3 MII TX_ER */ - /* PB14 */ { 1, 1, 0, 1, 0, 0 }, /* FCC3 MII TX_EN */ - /* PB13 */ { 1, 1, 0, 0, 0, 0 }, /* FCC3 MII COL */ - /* PB12 */ { 1, 1, 0, 0, 0, 0 }, /* FCC3 MII CRS */ - /* PB11 */ { 1, 1, 0, 0, 0, 0 }, /* FCC3 MII RxD[3] */ - /* PB10 */ { 1, 1, 0, 0, 0, 0 }, /* FCC3 MII RxD[2] */ - /* PB9 */ { 1, 1, 0, 0, 0, 0 }, /* FCC3 MII RxD[1] */ - /* PB8 */ { 1, 1, 0, 0, 0, 0 }, /* FCC3 MII RxD[0] */ - /* PB7 */ { 0, 0, 0, 0, 0, 0 }, /* PB7 */ - /* PB6 */ { 1, 1, 0, 1, 0, 0 }, /* FCC3 MII TxD[1] */ - /* PB5 */ { 1, 1, 0, 1, 0, 0 }, /* FCC3 MII TxD[2] */ - /* PB4 */ { 1, 1, 0, 1, 0, 0 }, /* FCC3 MII TxD[3] */ - /* PB3 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PB2 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PB1 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PB0 */ { 0, 0, 0, 0, 0, 0 } /* pin doesn't exist */ - }, - - /* Port C */ - { /* conf ppar psor pdir podr pdat */ - /* PC31 */ { 0, 0, 0, 1, 0, 0 }, /* PC31 */ - /* PC30 */ { 0, 0, 0, 1, 0, 0 }, /* PC30 */ - /* PC29 */ { 0, 1, 1, 0, 0, 0 }, /* */ - /* PC28 */ { 0, 0, 0, 1, 0, 0 }, /* PC28 */ - /* PC27 */ { 1, 1, 0, 1, 0, 0 }, /* FCC3 MII TxD[0] */ - /* PC26 */ { 0, 0, 0, 1, 0, 0 }, /* PC26 */ - /* PC25 */ { 0, 0, 0, 1, 0, 0 }, /* PC25 */ - /* PC24 */ { 0, 0, 0, 1, 0, 0 }, /* PC24 */ - /* PC23 */ { 0, 1, 0, 1, 0, 0 }, /* */ - /* PC22 */ { 0, 1, 0, 0, 0, 0 }, /* */ - /* PC21 */ { 0, 1, 0, 0, 0, 0 }, /* */ - /* PC20 */ { 0, 1, 0, 0, 0, 0 }, /* */ - /* PC19 */ { 0, 1, 0, 0, 0, 0 }, /* */ - /* PC18 */ { 0, 1, 0, 0, 0, 0 }, /* */ - /* PC17 */ { 1, 1, 0, 0, 0, 0 }, /* FCC3 MII CLK15 */ - /* PC16 */ { 1, 1, 0, 0, 0, 0 }, /* FCC3 MII CLK16 */ - /* PC15 */ { 0, 0, 0, 1, 0, 0 }, /* PC15 */ - /* PC14 */ { 0, 1, 0, 0, 0, 0 }, /* */ - /* PC13 */ { 0, 0, 0, 1, 0, 0 }, /* PC13 */ - /* PC12 */ { 0, 0, 0, 1, 0, 0 }, /* PC12 */ - /* PC11 */ { 0, 0, 0, 1, 0, 0 }, /* PC11 */ - /* PC10 */ { 0, 0, 0, 1, 0, 0 }, /* */ - /* PC9 */ { 0, 0, 0, 1, 0, 0 }, /* */ - /* PC8 */ { 0, 0, 0, 1, 0, 0 }, /* PC8 */ - /* PC7 */ { 0, 0, 0, 1, 0, 0 }, /* PC7 */ - /* PC6 */ { 0, 0, 0, 1, 0, 0 }, /* PC6 */ - /* PC5 */ { 0, 0, 0, 1, 0, 0 }, /* PC5 */ - /* PC4 */ { 0, 0, 0, 1, 0, 0 }, /* PC4 */ - /* PC3 */ { 0, 0, 0, 1, 0, 0 }, /* PC3 */ - /* PC2 */ { 0, 0, 0, 1, 0, 1 }, /* */ - /* PC1 */ { 0, 0, 0, 1, 0, 0 }, /* */ - /* PC0 */ { 0, 0, 0, 1, 0, 0 }, /* */ - }, - - /* Port D */ - { /* conf ppar psor pdir podr pdat */ - /* PD31 */ { 0, 1, 0, 0, 0, 0 }, /* */ - /* PD30 */ { 0, 1, 1, 1, 0, 0 }, /* */ - /* PD29 */ { 0, 1, 0, 1, 0, 0 }, /* */ - /* PD28 */ { 0, 0, 0, 1, 0, 0 }, /* PD28 */ - /* PD27 */ { 0, 0, 0, 1, 0, 0 }, /* PD27 */ - /* PD26 */ { 0, 0, 0, 1, 0, 0 }, /* PD26 */ - /* PD25 */ { 0, 0, 0, 1, 0, 0 }, /* PD25 */ - /* PD24 */ { 0, 0, 0, 1, 0, 0 }, /* PD24 */ - /* PD23 */ { 0, 0, 0, 1, 0, 0 }, /* PD23 */ - /* PD22 */ { 0, 0, 0, 1, 0, 0 }, /* PD22 */ - /* PD21 */ { 0, 0, 0, 1, 0, 0 }, /* PD21 */ - /* PD20 */ { 0, 0, 0, 1, 0, 0 }, /* PD20 */ - /* PD19 */ { 0, 0, 0, 1, 0, 0 }, /* PD19 */ - /* PD18 */ { 0, 0, 0, 1, 0, 0 }, /* PD19 */ - /* PD17 */ { 0, 1, 0, 0, 0, 0 }, /* */ - /* PD16 */ { 0, 1, 0, 1, 0, 0 }, /* */ - /* PD15 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SDA */ - /* PD14 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SCL */ - /* PD13 */ { 0, 0, 0, 0, 0, 0 }, /* PD13 */ - /* PD12 */ { 0, 0, 0, 0, 0, 0 }, /* PD12 */ - /* PD11 */ { 0, 0, 0, 0, 0, 0 }, /* PD11 */ - /* PD10 */ { 0, 0, 0, 0, 0, 0 }, /* PD10 */ - /* PD9 */ { 1, 1, 0, 1, 0, 0 }, /* SMC1 TXD */ - /* PD8 */ { 1, 1, 0, 0, 0, 0 }, /* SMC1 RXD */ - /* PD7 */ { 0, 0, 0, 1, 0, 1 }, /* PD7 */ - /* PD6 */ { 0, 0, 0, 1, 0, 1 }, /* PD6 */ - /* PD5 */ { 0, 0, 0, 1, 0, 1 }, /* PD5 */ - /* PD4 */ { 0, 0, 0, 1, 0, 1 }, /* PD4 */ - /* PD3 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PD2 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PD1 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PD0 */ { 0, 0, 0, 0, 0, 0 } /* pin doesn't exist */ - } -}; - -/* ------------------------------------------------------------------------- */ - -/* - * Setup CS4 to enable the Board Control/Status registers. - * Otherwise the smcs won't work. -*/ -int board_early_init_f (void) -{ - volatile t_ep_regs *regs = (t_ep_regs *) CONFIG_SYS_REGS_BASE; - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8260_t *memctl = &immap->im_memctl; - - memctl->memc_br4 = CONFIG_SYS_BR4_PRELIM; - memctl->memc_or4 = CONFIG_SYS_OR4_PRELIM; - regs->bcsr1 = 0x62; /* to enable terminal on SMC1 */ - regs->bcsr2 = 0x30; /* enable NVRAM and writing FLASH */ - return 0; -} - -void reset_phy (void) -{ - volatile t_ep_regs *regs = (t_ep_regs *) CONFIG_SYS_REGS_BASE; - - regs->bcsr4 = 0xC0; -} - -/* - * Check Board Identity: - * I don' know, how the next board revisions will be coded. - * Thats why its a static interpretation ... -*/ - -int checkboard (void) -{ - volatile t_ep_regs *regs = (t_ep_regs *) CONFIG_SYS_REGS_BASE; - uint major = 0, minor = 0; - - switch (regs->bcsr0) { - case 0x02: - major = 1; - break; - case 0x03: - major = 1; - minor = 1; - break; - case 0x06: - major = 1; - minor = 3; - break; - default: - break; - } - printf ("Board: Embedded Planet EP8260, Revision %d.%d\n", - major, minor); - return 0; -} - - -/* ------------------------------------------------------------------------- */ - - -phys_size_t initdram (int board_type) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8260_t *memctl = &immap->im_memctl; - volatile uchar c = 0; - volatile uchar *ramaddr = (uchar *) (CONFIG_SYS_SDRAM_BASE) + 0x110; - -/* - ulong psdmr = CONFIG_SYS_PSDMR; -#ifdef CONFIG_SYS_LSDRAM - ulong lsdmr = CONFIG_SYS_LSDMR; -#endif -*/ - long size = CONFIG_SYS_SDRAM0_SIZE; - int i; - - -/* -* Quote from 8260 UM (10.4.2 SDRAM Power-On Initialization, 10-35): -* -* "At system reset, initialization software must set up the -* programmable parameters in the memory controller banks registers -* (ORx, BRx, P/LSDMR). After all memory parameters are configured, -* system software should execute the following initialization sequence -* for each SDRAM device. -* -* 1. Issue a PRECHARGE-ALL-BANKS command -* 2. Issue eight CBR REFRESH commands -* 3. Issue a MODE-SET command to initialize the mode register -* -* The initial commands are executed by setting P/LSDMR[OP] and -* accessing the SDRAM with a single-byte transaction." -* -* The appropriate BRx/ORx registers have already been set when we -* get here. The SDRAM can be accessed at the address CONFIG_SYS_SDRAM_BASE. -*/ - - memctl->memc_psrt = CONFIG_SYS_PSRT; - memctl->memc_mptpr = CONFIG_SYS_MPTPR; - - memctl->memc_psdmr = (ulong) CONFIG_SYS_PSDMR | PSDMR_OP_PREA; - *ramaddr = c; - - memctl->memc_psdmr = (ulong) CONFIG_SYS_PSDMR | PSDMR_OP_CBRR; - for (i = 0; i < 8; i++) - *ramaddr = c; - - memctl->memc_psdmr = (ulong) CONFIG_SYS_PSDMR | PSDMR_OP_MRW; - *ramaddr = c; - - memctl->memc_psdmr = (ulong) CONFIG_SYS_PSDMR | PSDMR_OP_NORM | PSDMR_RFEN; - *ramaddr = c; - -#ifndef CONFIG_SYS_RAMBOOT -#ifdef CONFIG_SYS_LSDRAM - size += CONFIG_SYS_SDRAM1_SIZE; - ramaddr = (uchar *) (CONFIG_SYS_SDRAM1_BASE) + 0x8c; - memctl->memc_lsrt = CONFIG_SYS_LSRT; - - memctl->memc_lsdmr = (ulong) CONFIG_SYS_LSDMR | PSDMR_OP_PREA; - *ramaddr = c; - - memctl->memc_lsdmr = (ulong) CONFIG_SYS_LSDMR | PSDMR_OP_CBRR; - for (i = 0; i < 8; i++) - *ramaddr = c; - - memctl->memc_lsdmr = (ulong) CONFIG_SYS_LSDMR | PSDMR_OP_MRW; - *ramaddr = c; - - memctl->memc_lsdmr = (ulong) CONFIG_SYS_LSDMR | PSDMR_OP_NORM | PSDMR_RFEN; - *ramaddr = c; -#endif /* CONFIG_SYS_LSDRAM */ -#endif /* CONFIG_SYS_RAMBOOT */ - return (size * 1024 * 1024); -} diff --git a/board/ep8260/ep8260.h b/board/ep8260/ep8260.h deleted file mode 100644 index 3032b14..0000000 --- a/board/ep8260/ep8260.h +++ /dev/null @@ -1,24 +0,0 @@ -#ifndef __EP8260_H__ -#define __EP8260_H__ - -typedef struct tt_ep_regs { - volatile unsigned char bcsr0; - volatile unsigned char bcsr1; - volatile unsigned char bcsr2; - volatile unsigned char bcsr3; - volatile unsigned char bcsr4; - volatile unsigned char bcsr5; - volatile unsigned char bcsr6; - volatile unsigned char bcsr7; - volatile unsigned char bcsr8; - volatile unsigned char bcsr9; - volatile unsigned char bcsr10; - volatile unsigned char bcsr11; - volatile unsigned char bcsr12; - volatile unsigned char bcsr13; - volatile unsigned char bcsr14; - volatile unsigned char bcsr15; -} t_ep_regs; -typedef t_ep_regs *tp_ep_regs; - -#endif diff --git a/board/ep8260/flash.c b/board/ep8260/flash.c deleted file mode 100644 index 44f63ee..0000000 --- a/board/ep8260/flash.c +++ /dev/null @@ -1,395 +0,0 @@ -/* - * (C) Copyright 2001, 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * (C) Copyright 2002 - * Frank Panno fpanno@delphintech.com, Delphin Technology AG - * - * Flash Routines for AMD device AM29DL323DB on the EP8260 board. - * - * This file is based on board/tqm8260/flash.c. - *-------------------------------------------------------------------- - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc8xx.h> - -#define V_ULONG(a) (*(volatile unsigned long *)( a )) -#define V_BYTE(a) (*(volatile unsigned char *)( a )) - - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; - - -/*----------------------------------------------------------------------- - */ -void flash_reset(void) -{ - if( flash_info[0].flash_id != FLASH_UNKNOWN ) { - V_ULONG( flash_info[0].start[0] ) = 0x00F000F0; - V_ULONG( flash_info[0].start[0] + 4 ) = 0x00F000F0; - } -} - -/*----------------------------------------------------------------------- - */ -ulong flash_get_size( ulong baseaddr, flash_info_t *info ) -{ - short i; - unsigned long flashtest_h, flashtest_l; - - /* Write auto select command sequence and test FLASH answer */ - V_ULONG(baseaddr + ((ulong)0x0555 << 3)) = 0x00AA00AA; - V_ULONG(baseaddr + ((ulong)0x02AA << 3)) = 0x00550055; - V_ULONG(baseaddr + ((ulong)0x0555 << 3)) = 0x00900090; - V_ULONG(baseaddr + 4 + ((ulong)0x0555 << 3)) = 0x00AA00AA; - V_ULONG(baseaddr + 4 + ((ulong)0x02AA << 3)) = 0x00550055; - V_ULONG(baseaddr + 4 + ((ulong)0x0555 << 3)) = 0x00900090; - - flashtest_h = V_ULONG(baseaddr); /* manufacturer ID */ - flashtest_l = V_ULONG(baseaddr + 4); - - if ((int)flashtest_h == AMD_MANUFACT) { - info->flash_id = FLASH_MAN_AMD; - } else { - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - return (0); /* no or unknown flash */ - } - - flashtest_h = V_ULONG(baseaddr + 8); /* device ID */ - flashtest_l = V_ULONG(baseaddr + 12); - if (flashtest_h != flashtest_l) { - info->flash_id = FLASH_UNKNOWN; - return(0); - } - - switch((int)flashtest_h) { - case AMD_ID_DL323B: - info->flash_id += FLASH_AMDL323B; - info->sector_count = 71; - info->size = 0x01000000; /* 4 * 4 MB = 16 MB */ - break; - case AMD_ID_LV640U: /* AMDLV640 and AMDLV641 have same ID */ - info->flash_id += FLASH_AMLV640U; - info->sector_count = 128; - info->size = 0x02000000; /* 4 * 8 MB = 32 MB */ - break; - default: - info->flash_id = FLASH_UNKNOWN; - return(0); /* no or unknown flash */ - } - - if(flashtest_h == AMD_ID_LV640U) { - /* set up sector start adress table (uniform sector type) */ - for (i = 0; i < info->sector_count; i++) - info->start[i] = baseaddr + (i * 0x00040000); - } else { - /* set up sector start adress table (bottom sector type) */ - for (i = 0; i < 8; i++) { - info->start[i] = baseaddr + (i * 0x00008000); - } - for (i = 8; i < info->sector_count; i++) { - info->start[i] = baseaddr + (i * 0x00040000) - 0x001C0000; - } - } - /* check for protected sectors */ - for (i = 0; i < info->sector_count; i++) { - /* read sector protection at sector address, (A7 .. A0) = 0x02 */ - if ((V_ULONG( info->start[i] + 16 ) & 0x00010001) || - (V_ULONG( info->start[i] + 20 ) & 0x00010001)) { - info->protect[i] = 1; /* D0 = 1 if protected */ - } else { - info->protect[i] = 0; - } - } - - flash_reset(); - return(info->size); -} - -/*----------------------------------------------------------------------- - */ -unsigned long flash_init (void) -{ - unsigned long size_b0 = 0; - int i; - - /* Init: no FLASHes known */ - for (i=0; i<CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - } - - /* Static FLASH Bank configuration here (only one bank) */ - - size_b0 = flash_get_size(CONFIG_SYS_FLASH0_BASE, &flash_info[0]); - if (flash_info[0].flash_id == FLASH_UNKNOWN || size_b0 == 0) { - printf ("## Unknown FLASH on Bank 0 - Size = 0x%08lx = %ld MB\n", - size_b0, size_b0>>20); - } - - /* - * protect monitor and environment sectors - */ - -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH0_BASE - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE+monitor_flash_len-1, - &flash_info[0]); -#endif - -#if defined(CONFIG_ENV_IS_IN_FLASH) && defined(CONFIG_ENV_ADDR) -# ifndef CONFIG_ENV_SIZE -# define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -# endif - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR + CONFIG_ENV_SIZE - 1, - &flash_info[0]); -#endif - - return (size_b0); -} - -/*----------------------------------------------------------------------- - */ -void flash_print_info (flash_info_t *info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch ((info->flash_id >> 16) & 0xff) { - case FLASH_MAN_AMD: printf ("AMD "); break; - default: printf ("Unknown Vendor "); break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_AMDL323B: printf ("29DL323B (32 M, bottom sector)\n"); - break; - case FLASH_AMLV640U: printf ("29LV640U (64 M, uniform sector)\n"); - break; - default: printf ("Unknown Chip Type\n"); - break; - } - - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); - - printf (" Sector Start Addresses:"); - for (i=0; i<info->sector_count; ++i) { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", - info->start[i], - info->protect[i] ? " (RO)" : " " - ); - } - printf ("\n"); - return; -} - -/*----------------------------------------------------------------------- - */ -int flash_erase (flash_info_t *info, int s_first, int s_last) -{ - int flag, prot, sect, l_sect; - ulong start, now, last; - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - prot = 0; - for (sect = s_first; sect <= s_last; sect++) { - if (info->protect[sect]) - prot++; - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - printf ("\n"); - } - - l_sect = -1; - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - V_ULONG( info->start[0] + (0x0555 << 3) ) = 0x00AA00AA; - V_ULONG( info->start[0] + (0x02AA << 3) ) = 0x00550055; - V_ULONG( info->start[0] + (0x0555 << 3) ) = 0x00800080; - V_ULONG( info->start[0] + (0x0555 << 3) ) = 0x00AA00AA; - V_ULONG( info->start[0] + (0x02AA << 3) ) = 0x00550055; - V_ULONG( info->start[0] + 4 + (0x0555 << 3) ) = 0x00AA00AA; - V_ULONG( info->start[0] + 4 + (0x02AA << 3) ) = 0x00550055; - V_ULONG( info->start[0] + 4 + (0x0555 << 3) ) = 0x00800080; - V_ULONG( info->start[0] + 4 + (0x0555 << 3) ) = 0x00AA00AA; - V_ULONG( info->start[0] + 4 + (0x02AA << 3) ) = 0x00550055; - udelay (1000); - - /* Start erase on unprotected sectors */ - for (sect = s_first; sect<=s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - V_ULONG( info->start[sect] ) = 0x00300030; - V_ULONG( info->start[sect] + 4 ) = 0x00300030; - l_sect = sect; - } - } - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - - /* - * We wait for the last triggered sector - */ - if (l_sect < 0) - goto DONE; - - start = get_timer (0); - last = start; - while ((V_ULONG( info->start[l_sect] ) & 0x00800080) != 0x00800080 || - (V_ULONG( info->start[l_sect] + 4 ) & 0x00800080) != 0x00800080) - { - if ((now = get_timer(start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - return 1; - } - /* show that we're waiting */ - if ((now - last) > 1000) { /* every second */ - serial_putc ('.'); - last = now; - } - } - - DONE: - /* reset to read mode */ - flash_reset (); - - printf (" done\n"); - return 0; -} - -static int write_dword (flash_info_t *, ulong, unsigned char *); - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ - -int write_buff (flash_info_t *info, uchar *src, ulong addr, ulong cnt) -{ - ulong dp; - static unsigned char bb[8]; - int i, l, rc, cc = cnt; - - dp = (addr & ~7); /* get lower dword aligned address */ - - /* - * handle unaligned start bytes - */ - if ((l = addr - dp) != 0) { - for (i = 0; i < 8; i++) - bb[i] = (i < l || (i-l) >= cc) ? V_BYTE(dp+i) : *src++; - if ((rc = write_dword(info, dp, bb)) != 0) - { - return (rc); - } - dp += 8; - cc -= 8 - l; - } - - /* - * handle word aligned part - */ - while (cc >= 8) { - if ((rc = write_dword(info, dp, src)) != 0) { - return (rc); - } - dp += 8; - src += 8; - cc -= 8; - } - - if (cc <= 0) { - return (0); - } - - /* - * handle unaligned tail bytes - */ - for (i = 0; i < 8; i++) { - bb[i] = (i < cc) ? *src++ : V_BYTE(dp+i); - } - return (write_dword(info, dp, bb)); -} - -/*----------------------------------------------------------------------- - * Write a dword to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_dword (flash_info_t *info, ulong dest, unsigned char * pdata) -{ - ulong start; - ulong cl = 0, ch =0; - int flag, i; - - for (ch=0, i=0; i < 4; i++) - ch = (ch << 8) + *pdata++; /* high word */ - for (cl=0, i=0; i < 4; i++) - cl = (cl << 8) + *pdata++; /* low word */ - - /* Check if Flash is (sufficiently) erased */ - if ((*((vu_long *)dest) & ch) != ch - ||(*((vu_long *)(dest + 4)) & cl) != cl) - { - return (2); - } - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - V_ULONG( info->start[0] + (0x0555 << 3) ) = 0x00AA00AA; - V_ULONG( info->start[0] + (0x02AA << 3) ) = 0x00550055; - V_ULONG( info->start[0] + (0x0555 << 3) ) = 0x00A000A0; - V_ULONG( dest ) = ch; - V_ULONG( info->start[0] + 4 + (0x0555 << 3) ) = 0x00AA00AA; - V_ULONG( info->start[0] + 4 + (0x02AA << 3) ) = 0x00550055; - V_ULONG( info->start[0] + 4 + (0x0555 << 3) ) = 0x00A000A0; - V_ULONG( dest + 4 ) = cl; - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* data polling for D7 */ - start = get_timer (0); - while (((V_ULONG( dest ) & 0x00800080) != (ch & 0x00800080)) || - ((V_ULONG( dest + 4 ) & 0x00800080) != (cl & 0x00800080))) { - if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - return (1); - } - } - return (0); -} diff --git a/board/ep8260/mii_phy.c b/board/ep8260/mii_phy.c deleted file mode 100644 index c7aa275..0000000 --- a/board/ep8260/mii_phy.c +++ /dev/null @@ -1,107 +0,0 @@ -#include <common.h> -#include <mii_phy.h> -#include "ep8260.h" - -#define MII_MDIO 0x01 -#define MII_MDCK 0x02 -#define MII_MDIR 0x04 - -void -mii_discover_phy(void) -{ - int known; - unsigned short phy_reg; - unsigned long phy_id; - - known = 0; - printf("Discovering phy @ 0: "); - phy_id = mii_phy_read(2) << 16; - phy_id |= mii_phy_read(3); - if ((phy_id & 0xFFFFFC00) == 0x00137800) { - printf("Level One "); - if ((phy_id & 0x000003F0) == 0xE0) { - printf("LXT971A Revision %d\n", (int)(phy_id & 0xF)); - known = 1; - } - else printf("unknown type\n"); - } - else printf("unknown OUI = 0x%08lX\n", phy_id); - - phy_reg = mii_phy_read(1); - if (!(phy_reg & 0x0004)) printf("Link is down\n"); - if (!(phy_reg & 0x0020)) printf("Auto-negotiation not complete\n"); - if (phy_reg & 0x0002) printf("Jabber condition detected\n"); - if (phy_reg & 0x0010) printf("Remote fault condition detected \n"); - - if (known) { - phy_reg = mii_phy_read(17); - if (phy_reg & 0x0400) - printf("Phy operating at %d MBit/s in %s-duplex mode\n", - phy_reg & 0x4000 ? 100 : 10, - phy_reg & 0x0200 ? "full" : "half"); - else - printf("bad link!!\n"); -/* -left off: no link, green 100MBit, yellow 10MBit -right off: no activity, green full-duplex, yellow half-duplex -*/ - mii_phy_write(20, 0x0452); - } -} - -unsigned short -mii_phy_read(unsigned short reg) -{ - int i; - unsigned short tmp, val = 0, adr = 0; - t_ep_regs *regs = (t_ep_regs*)CONFIG_SYS_REGS_BASE; - - tmp = 0x6002 | (adr << 7) | (reg << 2); - regs->bcsr4 = 0xC3; - for (i = 0; i < 64; i++) { - regs->bcsr4 ^= MII_MDCK; - } - for (i = 0; i < 16; i++) { - regs->bcsr4 &= ~MII_MDCK; - if (tmp & 0x8000) regs->bcsr4 |= MII_MDIO; - else regs->bcsr4 &= ~MII_MDIO; - regs->bcsr4 |= MII_MDCK; - tmp <<= 1; - } - regs->bcsr4 |= MII_MDIR; - for (i = 0; i < 16; i++) { - val <<= 1; - regs->bcsr4 = MII_MDIO | (regs->bcsr4 | MII_MDCK); - if (regs->bcsr4 & MII_MDIO) val |= 1; - regs->bcsr4 = MII_MDIO | (regs->bcsr4 &= ~MII_MDCK); - } - return val; -} - -void -mii_phy_write(unsigned short reg, unsigned short val) -{ - int i; - unsigned short tmp, adr = 0; - t_ep_regs *regs = (t_ep_regs*)CONFIG_SYS_REGS_BASE; - - tmp = 0x5002 | (adr << 7) | (reg << 2); - regs->bcsr4 = 0xC3; - for (i = 0; i < 64; i++) { - regs->bcsr4 ^= MII_MDCK; - } - for (i = 0; i < 16; i++) { - regs->bcsr4 &= ~MII_MDCK; - if (tmp & 0x8000) regs->bcsr4 |= MII_MDIO; - else regs->bcsr4 &= ~MII_MDIO; - regs->bcsr4 |= MII_MDCK; - tmp <<= 1; - } - for (i = 0; i < 16; i++) { - regs->bcsr4 &= ~MII_MDCK; - if (val & 0x8000) regs->bcsr4 |= MII_MDIO; - else regs->bcsr4 &= ~MII_MDIO; - regs->bcsr4 |= MII_MDCK; - val <<= 1; - } -} diff --git a/configs/ep8260_defconfig b/configs/ep8260_defconfig deleted file mode 100644 index 1cce900..0000000 --- a/configs/ep8260_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_EP8260=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 0845651..46b6dbe 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,7 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +ep8260 powerpc mpc8260 - - Frank Panno fpanno@delphintech.com ppmc8260 powerpc mpc8260 - - Brad Kemp Brad.Kemp@seranoa.com sacsng powerpc mpc8260 - - Jerry Van Baren gerald.vanbaren@smiths-aerospace.com cogent_mpc8260 powerpc mpc8260 - - Murray Jensen Murray.Jensen@csiro.au diff --git a/include/configs/ep8260.h b/include/configs/ep8260.h deleted file mode 100644 index 9cd3054..0000000 --- a/include/configs/ep8260.h +++ /dev/null @@ -1,744 +0,0 @@ -/* - * (C) Copyright 2002 - * Frank Panno fpanno@delphintech.com, Delphin Technology AG - * - * This file is based on similar values for other boards found in other - * U-Boot config files, and some that I found in the EP8260 manual. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - * - * "EP8260 H, V.1.1" - * - 64M 60x Bus SDRAM - * - 32M Local Bus SDRAM - * - 16M Flash (4 x AM29DL323DB90WDI) - * - 128k NVRAM with RTC - * - * "EP8260 H2, V.1.3" (CONFIG_SYS_EP8260_H2) - * - 300MHz/133MHz/66MHz - * - 64M 60x Bus SDRAM - * - 32M Local Bus SDRAM - * - 32M Flash - * - 128k NVRAM with RTC - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* Define this to enable support the EP8260 H2 version */ -#define CONFIG_SYS_EP8260_H2 1 -/* #undef CONFIG_SYS_EP8260_H2 */ - -#define CONFIG_SYS_TEXT_BASE 0xFFF00000 - -#define CONFIG_CPM2 1 /* Has a CPM2 */ - -/* What is the oscillator's (UX2) frequency in Hz? */ -#define CONFIG_8260_CLKIN (66 * 1000 * 1000) - -/*----------------------------------------------------------------------- - * MODCK_H & MODCLK[1-3] - Ref: Section 9.2 in MPC8206 User Manual - *----------------------------------------------------------------------- - * What should MODCK_H be? It is dependent on the oscillator - * frequency, MODCK[1-3], and desired CPM and core frequencies. - * Here are some example values (all frequencies are in MHz): - * - * MODCK_H MODCK[1-3] Osc CPM Core - * ------- ---------- --- --- ---- - * 0x2 0x2 33 133 133 - * 0x2 0x3 33 133 166 - * 0x2 0x4 33 133 200 - * 0x2 0x5 33 133 233 - * 0x2 0x6 33 133 266 - * - * 0x5 0x5 66 133 133 - * 0x5 0x6 66 133 166 - * 0x5 0x7 66 133 200 * - * 0x6 0x0 66 133 233 - * 0x6 0x1 66 133 266 - * 0x6 0x2 66 133 300 - */ -#ifdef CONFIG_SYS_EP8260_H2 -#define CONFIG_SYS_SBC_MODCK_H (HRCW_MODCK_H0110) -#else -#define CONFIG_SYS_SBC_MODCK_H (HRCW_MODCK_H0110) -#endif - -/* Define this if you want to boot from 0x00000100. If you don't define - * this, you will need to program the bootloader to 0xfff00000, and - * get the hardware reset config words at 0xfe000000. The simplest - * way to do that is to program the bootloader at both addresses. - * It is suggested that you just let U-Boot live at 0x00000000. - */ -/* #define CONFIG_SYS_SBC_BOOT_LOW 1 */ /* only for HRCW */ -/* #undef CONFIG_SYS_SBC_BOOT_LOW */ - -/* The reset command will not work as expected if the reset address does - * not point to the correct address. - */ - -#define CONFIG_SYS_RESET_ADDRESS 0xFFF00100 - -/* What should the base address of the main FLASH be and how big is - * it (in MBytes)? This must contain CONFIG_SYS_TEXT_BASE from board/ep8260/config.mk - * The main FLASH is whichever is connected to *CS0. U-Boot expects - * this to be the SIMM. - */ -#ifdef CONFIG_SYS_EP8260_H2 -#define CONFIG_SYS_FLASH0_BASE 0xFE000000 -#define CONFIG_SYS_FLASH0_SIZE 32 -#else -#define CONFIG_SYS_FLASH0_BASE 0xFF000000 -#define CONFIG_SYS_FLASH0_SIZE 16 -#endif - -/* What should the base address of the secondary FLASH be and how big - * is it (in Mbytes)? The secondary FLASH is whichever is connected - * to *CS6. U-Boot expects this to be the on board FLASH. If you don't - * want it enabled, don't define these constants. - */ -#define CONFIG_SYS_FLASH1_BASE 0 -#define CONFIG_SYS_FLASH1_SIZE 0 -#undef CONFIG_SYS_FLASH1_BASE -#undef CONFIG_SYS_FLASH1_SIZE - -/* What should be the base address of SDRAM DIMM (60x bus) and how big is - * it (in Mbytes)? -*/ -#define CONFIG_SYS_SDRAM0_BASE 0x00000000 -#define CONFIG_SYS_SDRAM0_SIZE 64 - -/* define CONFIG_SYS_LSDRAM if you want to enable the 32M SDRAM on the - * local bus (8260 local bus is NOT cacheable!) -*/ -/* #define CONFIG_SYS_LSDRAM */ -#undef CONFIG_SYS_LSDRAM - -#ifdef CONFIG_SYS_LSDRAM -/* What should be the base address of SDRAM DIMM (local bus) and how big is - * it (in Mbytes)? -*/ - #define CONFIG_SYS_SDRAM1_BASE 0x04000000 - #define CONFIG_SYS_SDRAM1_SIZE 32 -#else - #define CONFIG_SYS_SDRAM1_BASE 0 - #define CONFIG_SYS_SDRAM1_SIZE 0 - #undef CONFIG_SYS_SDRAM1_BASE - #undef CONFIG_SYS_SDRAM1_SIZE -#endif /* CONFIG_SYS_LSDRAM */ - -/* What should be the base address of NVRAM and how big is - * it (in Bytes) - */ -#define CONFIG_SYS_NVRAM_BASE_ADDR 0xFA080000 -#define CONFIG_SYS_NVRAM_SIZE (128*1024)-16 - -/* The RTC is a Dallas DS1556 - */ -#define CONFIG_RTC_DS1556 - -/* What should be the base address of the LEDs and switch S0? - * If you don't want them enabled, don't define this. - */ -#define CONFIG_SYS_LED_BASE 0x00000000 -#undef CONFIG_SYS_LED_BASE - -/* - * select serial console configuration - * - * if either CONFIG_CONS_ON_SMC or CONFIG_CONS_ON_SCC is selected, then - * CONFIG_CONS_INDEX must be set to the channel number (1-2 for SMC, 1-4 - * for SCC). - * - * if CONFIG_CONS_NONE is defined, then the serial console routines must - * defined elsewhere. - */ -#define CONFIG_CONS_ON_SMC /* define if console on SMC */ -#undef CONFIG_CONS_ON_SCC /* define if console on SCC */ -#undef CONFIG_CONS_NONE /* define if console on neither */ -#define CONFIG_CONS_INDEX 1 /* which SMC/SCC channel for console */ - -/* - * select ethernet configuration - * - * if either CONFIG_ETHER_ON_SCC or CONFIG_ETHER_ON_FCC is selected, then - * CONFIG_ETHER_INDEX must be set to the channel number (1-4 for SCC, 1-3 - * for FCC) - * - * if CONFIG_ETHER_NONE is defined, then either the ethernet routines must be - * defined elsewhere (as for the console), or CONFIG_CMD_NET must be unset. - */ -#undef CONFIG_ETHER_ON_SCC /* define if ethernet on SCC */ -#define CONFIG_ETHER_ON_FCC /* define if ethernet on FCC */ -#undef CONFIG_ETHER_NONE /* define if ethernet on neither */ -#define CONFIG_ETHER_INDEX 3 /* which SCC/FCC channel for ethernet */ - -#if ( CONFIG_ETHER_INDEX == 3 ) - -/* - * - Rx-CLK is CLK15 - * - Tx-CLK is CLK16 - * - RAM for BD/Buffers is on the local Bus (see 28-13) - * - Enable Half Duplex in FSMR - */ -# define CONFIG_SYS_CMXFCR_MASK3 (CMXFCR_FC3|CMXFCR_RF3CS_MSK|CMXFCR_TF3CS_MSK) -# define CONFIG_SYS_CMXFCR_VALUE3 (CMXFCR_RF3CS_CLK15|CMXFCR_TF3CS_CLK16) - -/* - * - RAM for BD/Buffers is on the local Bus (see 28-13) - */ -#ifdef CONFIG_SYS_LSDRAM - #define CONFIG_SYS_CPMFCR_RAMTYPE 3 -#else /* CONFIG_SYS_LSDRAM */ - #define CONFIG_SYS_CPMFCR_RAMTYPE 0 -#endif /* CONFIG_SYS_LSDRAM */ - -/* - Enable Half Duplex in FSMR */ -/* # define CONFIG_SYS_FCC_PSMR (FCC_PSMR_FDE|FCC_PSMR_LPB) */ -# define CONFIG_SYS_FCC_PSMR 0 - -#else /* CONFIG_ETHER_INDEX */ -# error "on EP8260 ethernet must be FCC3" -#endif /* CONFIG_ETHER_INDEX */ - -/* - * select i2c support configuration - * - * Supported configurations are {none, software, hardware} drivers. - * If the software driver is chosen, there are some additional - * configuration items that the driver uses to drive the port pins. - */ -#define CONFIG_SYS_I2C_SOFT /* I2C bit-banged */ - -#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_SLAVE 0x7F /* This is for HARD, must go */ - -/* - * Software (bit-bang) I2C driver configuration - */ -#ifdef CONFIG_SYS_I2C_SOFT -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_SOFT_SPEED 50000 -#define CONFIG_SYS_I2C_SOFT_SLAVE 0xFE -#define I2C_PORT 3 /* Port A=0, B=1, C=2, D=3 */ -#define I2C_ACTIVE (iop->pdir |= 0x00010000) -#define I2C_TRISTATE (iop->pdir &= ~0x00010000) -#define I2C_READ ((iop->pdat & 0x00010000) != 0) -#define I2C_SDA(bit) if(bit) iop->pdat |= 0x00010000; \ - else iop->pdat &= ~0x00010000 -#define I2C_SCL(bit) if(bit) iop->pdat |= 0x00020000; \ - else iop->pdat &= ~0x00020000 -#define I2C_DELAY udelay(5) /* 1/4 I2C clock duration */ -#endif /* CONFIG_SYS_I2C_SOFT */ - -/* #define CONFIG_RTC_DS174x */ - -/* Define this to reserve an entire FLASH sector (256 KB) for - * environment variables. Otherwise, the environment will be - * put in the same sector as U-Boot, and changing variables - * will erase U-Boot temporarily - */ -#define CONFIG_ENV_IN_OWN_SECT - -/* Define to allow the user to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE - -/* What should the console's baud rate be? */ -#ifdef CONFIG_SYS_EP8260_H2 -#define CONFIG_BAUDRATE 9600 -#else -#define CONFIG_BAUDRATE 115200 -#endif - -/* Ethernet MAC address */ -#define CONFIG_ETHADDR 00:10:EC:00:30:8C - -#define CONFIG_IPADDR 192.168.254.130 -#define CONFIG_SERVERIP 192.168.254.49 - -/* Set to a positive value to delay for running BOOTCOMMAND */ -#define CONFIG_BOOTDELAY -1 - -/* undef this to save memory */ -#define CONFIG_SYS_LONGHELP - -/* Monitor Command Prompt */ - -/* Define this variable to enable the "hush" shell (from - Busybox) as command line interpreter, thus enabling - powerful command line syntax like - if...then...else...fi conditionals or `&&' and '||' - constructs ("shell scripts"). - If undefined, you get the old, much simpler behaviour - with a somewhat smapper memory footprint. -*/ -#define CONFIG_SYS_HUSH_PARSER - - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_BEDBUG -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_CDP -#define CONFIG_CMD_DATE -#define CONFIG_CMD_DIAG -#define CONFIG_CMD_ELF -#define CONFIG_CMD_FAT -#define CONFIG_CMD_I2C -#define CONFIG_CMD_IMMAP -#define CONFIG_CMD_IRQ -#define CONFIG_CMD_PING -#define CONFIG_CMD_PORTIO -#define CONFIG_CMD_REGINFO -#define CONFIG_CMD_SAVES -#define CONFIG_CMD_SDRAM -#define CONFIG_CMD_SNTP - -#undef CONFIG_CMD_XIMG - -/* Where do the internal registers live? */ -#define CONFIG_SYS_IMMR 0xF0000000 -#define CONFIG_SYS_DEFAULT_IMMR 0x00010000 - -/* Where do the on board registers (CS4) live? */ -#define CONFIG_SYS_REGS_BASE 0xFA000000 - -/***************************************************************************** - * - * You should not have to modify any of the following settings - * - *****************************************************************************/ - -#define CONFIG_EP8260 11 /* on an Embedded Planet EP8260 Board, Rev. 11 */ - -#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ - -/* - * Miscellaneous configurable options - */ -#if defined(CONFIG_CMD_KGDB) -# define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -# define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif - -/* Print Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT)+16) - -#define CONFIG_SYS_MAXARGS 8 /* max number of command args */ - -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#ifdef CONFIG_SYS_LSDRAM - #define CONFIG_SYS_MEMTEST_START 0x04000000 /* memtest works on */ - #define CONFIG_SYS_MEMTEST_END 0x06000000 /* 64-96 MB in SDRAM */ -#else - #define CONFIG_SYS_MEMTEST_START 0x00000000 /* memtest works on */ - #define CONFIG_SYS_MEMTEST_END 0x02000000 /* 0-32 MB in SDRAM */ -#endif /* CONFIG_SYS_LSDRAM */ - -#define CONFIG_CLOCKS_IN_MHZ 1 /* clocks passsed to Linux in MHz */ - -#define CONFIG_SYS_LOAD_ADDR 0x00100000 /* default load address */ - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ - -#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_FLASH0_BASE -#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_SDRAM0_BASE - -/*----------------------------------------------------------------------- - * Hard Reset Configuration Words - */ - -#if defined(CONFIG_SYS_SBC_BOOT_LOW) -# define CONFIG_SYS_SBC_HRCW_BOOT_FLAGS (HRCW_CIP | HRCW_BMS) -#else -# define CONFIG_SYS_SBC_HRCW_BOOT_FLAGS (0x00000000) -#endif /* defined(CONFIG_SYS_SBC_BOOT_LOW) */ - -#ifdef CONFIG_SYS_EP8260_H2 -/* get the HRCW ISB field from CONFIG_SYS_DEFAULT_IMMR */ -#define CONFIG_SYS_SBC_HRCW_IMMR ( ((CONFIG_SYS_DEFAULT_IMMR & 0x10000000) >> 10) |\ - ((CONFIG_SYS_DEFAULT_IMMR & 0x01000000) >> 7) |\ - ((CONFIG_SYS_DEFAULT_IMMR & 0x00100000) >> 4) ) - -#define CONFIG_SYS_HRCW_MASTER (HRCW_EBM |\ - HRCW_L2CPC01 |\ - CONFIG_SYS_SBC_HRCW_IMMR |\ - HRCW_APPC10 |\ - HRCW_CS10PC01 |\ - CONFIG_SYS_SBC_MODCK_H |\ - CONFIG_SYS_SBC_HRCW_BOOT_FLAGS) -#else -#define CONFIG_SYS_HRCW_MASTER 0x10400245 -#endif - -/* no slaves */ -#define CONFIG_SYS_HRCW_SLAVE1 0 -#define CONFIG_SYS_HRCW_SLAVE2 0 -#define CONFIG_SYS_HRCW_SLAVE3 0 -#define CONFIG_SYS_HRCW_SLAVE4 0 -#define CONFIG_SYS_HRCW_SLAVE5 0 -#define CONFIG_SYS_HRCW_SLAVE6 0 -#define CONFIG_SYS_HRCW_SLAVE7 0 - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - * Note also that the logic that sets CONFIG_SYS_RAMBOOT is platform dependent. - */ -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE - - -#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) -# define CONFIG_SYS_RAMBOOT -#endif - -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * FLASH and environment organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#ifdef CONFIG_SYS_EP8260_H2 -#define CONFIG_SYS_MAX_FLASH_SECT 128 /* max number of sectors on one chip */ -#else -#define CONFIG_SYS_MAX_FLASH_SECT 71 /* max number of sectors on one chip */ -#endif - -#ifdef CONFIG_SYS_EP8260_H2 -#define CONFIG_SYS_FLASH_ERASE_TOUT 240000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ -#else -#define CONFIG_SYS_FLASH_ERASE_TOUT 8000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 1 /* Timeout for Flash Write (in ms) */ -#endif - -#ifndef CONFIG_SYS_RAMBOOT -# define CONFIG_ENV_IS_IN_FLASH 1 - -# ifdef CONFIG_ENV_IN_OWN_SECT -# define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + 0x40000) -# define CONFIG_ENV_SECT_SIZE 0x40000 -# else -# define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_SYS_MONITOR_LEN - CONFIG_ENV_SECT_SIZE) -# define CONFIG_ENV_SIZE 0x1000 /* Total Size of Environment Sector */ -# define CONFIG_ENV_SECT_SIZE 0x10000 /* see README - env sect real size */ -# endif /* CONFIG_ENV_IN_OWN_SECT */ -#else -# define CONFIG_ENV_IS_IN_NVRAM 1 -# define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) -# define CONFIG_ENV_SIZE 0x200 -#endif /* CONFIG_SYS_RAMBOOT */ - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC8260 CPU */ - -#if defined(CONFIG_CMD_KGDB) -# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * HIDx - Hardware Implementation-dependent Registers 2-11 - *----------------------------------------------------------------------- - * HID0 also contains cache control - initially enable both caches and - * invalidate contents, then the final state leaves only the instruction - * cache enabled. Note that Power-On and Hard reset invalidate the caches, - * but Soft reset does not. - * - * HID1 has only read-only information - nothing to set. - */ -#define CONFIG_SYS_HID0_INIT (HID0_ICE |\ - HID0_DCE |\ - HID0_ICFI |\ - HID0_DCI |\ - HID0_IFEM |\ - HID0_ABE) -#ifdef CONFIG_SYS_LSDRAM -/* 8260 local bus is NOT cacheable */ -#define CONFIG_SYS_HID0_FINAL (/*HID0_ICE |*/\ - HID0_IFEM |\ - HID0_ABE |\ - HID0_EMCP) -#else /* !CONFIG_SYS_LSDRAM */ -#define CONFIG_SYS_HID0_FINAL (HID0_ICE |\ - HID0_IFEM |\ - HID0_ABE |\ - HID0_EMCP) -#endif /* CONFIG_SYS_LSDRAM */ - -#define CONFIG_SYS_HID2 0 - -/*----------------------------------------------------------------------- - * RMR - Reset Mode Register - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RMR 0 - -/*----------------------------------------------------------------------- - * BCR - Bus Configuration 4-25 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_BCR (BCR_EBM |\ - BCR_PLDP |\ - BCR_EAV |\ - BCR_NPQM0) - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 4-31 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_SIUMCR (SIUMCR_L2CPC01 |\ - SIUMCR_APPC10 |\ - SIUMCR_CS10PC01) - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 11-9 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Watchdog & Bus Monitor Timer max, 60x Bus Monitor enable - */ -#ifdef CONFIG_SYS_EP8260_H2 -/* TBD: Find out why setting the BMT to 0xff causes the FCC to - * generate TX buffer underrun errors for large packets under - * Linux - */ -#define CONFIG_SYS_SYPCR_BMT 0x00000600 -#else -#define CONFIG_SYS_SYPCR_BMT SYPCR_BMT -#endif - -#ifdef CONFIG_SYS_LSDRAM -#define CONFIG_SYS_SYPCR (SYPCR_SWTC |\ - CONFIG_SYS_SYPCR_BMT |\ - SYPCR_PBME |\ - SYPCR_LBME |\ - SYPCR_SWP) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC |\ - CONFIG_SYS_SYPCR_BMT |\ - SYPCR_PBME |\ - SYPCR_SWP) -#endif - -/*----------------------------------------------------------------------- - * TMCNTSC - Time Counter Status and Control 4-40 - *----------------------------------------------------------------------- - * Clear once per Second and Alarm Interrupt Status, Set 32KHz timersclk, - * and enable Time Counter - */ -#define CONFIG_SYS_TMCNTSC (TMCNTSC_SEC |\ - TMCNTSC_ALR |\ - TMCNTSC_TCF |\ - TMCNTSC_TCE) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 4-42 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Set 32KHz timersclk, and enable - * Periodic timer - */ -#ifdef CONFIG_SYS_EP8260_H2 -#define CONFIG_SYS_PISCR (PISCR_PS |\ - PISCR_PTF |\ - PISCR_PTE) -#else -#define CONFIG_SYS_PISCR 0 -#endif - -/*----------------------------------------------------------------------- - * SCCR - System Clock Control 9-8 - *----------------------------------------------------------------------- - */ -#ifdef CONFIG_SYS_EP8260_H2 -#define CONFIG_SYS_SCCR (SCCR_DFBRG00) -#else -#define CONFIG_SYS_SCCR (SCCR_DFBRG01) -#endif - -/*----------------------------------------------------------------------- - * RCCR - RISC Controller Configuration 13-7 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RCCR 0 - -/*----------------------------------------------------------------------- - * MPTPR - Memory Refresh Timer Prescale Register 10-32 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_MPTPR (0x0A00 & MPTPR_PTP_MSK) - -/* - * Init Memory Controller: - * - * Bank Bus Machine PortSz Device - * ---- --- ------- ------ ------ - * 0 60x GPCM 64 bit FLASH (BGA - 16MB AMD AM29DL323DB90WDI) - * 1 60x SDRAM 64 bit SDRAM (BGA - 64MB Micron 48LC8M16A2TG) - * 2 Local SDRAM 32 bit SDRAM (BGA - 32MB Micron 48LC8M16A2TG) - * 3 unused - * 4 60x GPCM 8 bit Board Regs, NVRTC - * 5 unused - * 6 unused - * 7 unused - * 8 PCMCIA - * 9 unused - * 10 unused - * 11 unused -*/ - -/*----------------------------------------------------------------------- - * BRx - Base Register - * Ref: Section 10.3.1 on page 10-14 - * ORx - Option Register - * Ref: Section 10.3.2 on page 10-18 - *----------------------------------------------------------------------- - */ - -/* Bank 0 - FLASH - * - */ -#define CONFIG_SYS_BR0_PRELIM ((CONFIG_SYS_FLASH0_BASE & BRx_BA_MSK) |\ - BRx_PS_64 |\ - BRx_DECC_NONE |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH0_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_8_CLK |\ - ORxG_EHTR) - -/* Bank 1 - SDRAM - * PSDRAM - */ -#define CONFIG_SYS_BR1_PRELIM ((CONFIG_SYS_SDRAM0_BASE & BRx_BA_MSK) |\ - BRx_PS_64 |\ - BRx_MS_SDRAM_P |\ - BRx_V) - -#define CONFIG_SYS_OR1_PRELIM (MEG_TO_AM(CONFIG_SYS_SDRAM0_SIZE) |\ - ORxS_BPD_4 |\ - ORxS_ROWST_PBI1_A6 |\ - ORxS_NUMR_12) - -#ifdef CONFIG_SYS_EP8260_H2 -#define CONFIG_SYS_PSDMR 0xC34E246E -#else -#define CONFIG_SYS_PSDMR 0xC34E2462 -#endif - -#define CONFIG_SYS_PSRT 0x64 - -#ifdef CONFIG_SYS_LSDRAM -/* Bank 2 - SDRAM - * LSDRAM - */ - - #define CONFIG_SYS_BR2_PRELIM ((CONFIG_SYS_SDRAM1_BASE & BRx_BA_MSK) |\ - BRx_PS_32 |\ - BRx_MS_SDRAM_L |\ - BRx_V) - - #define CONFIG_SYS_OR2_PRELIM (MEG_TO_AM(CONFIG_SYS_SDRAM1_SIZE) |\ - ORxS_BPD_4 |\ - ORxS_ROWST_PBI0_A9 |\ - ORxS_NUMR_12) - - #define CONFIG_SYS_LSDMR 0x416A2562 - #define CONFIG_SYS_LSRT 0x64 -#else - #define CONFIG_SYS_LSRT 0x0 -#endif /* CONFIG_SYS_LSDRAM */ - -/* Bank 4 - On board registers - * NVRTC and BCSR - */ -#define CONFIG_SYS_BR4_PRELIM ((CONFIG_SYS_REGS_BASE & BRx_BA_MSK) |\ - BRx_PS_8 |\ - BRx_MS_GPCM_P |\ - BRx_V) -/* -#define CONFIG_SYS_OR4_PRELIM (ORxG_AM_MSK |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_10_CLK |\ - ORxG_TRLX) -*/ -#define CONFIG_SYS_OR4_PRELIM 0xfff00854 - -#ifdef _NOT_USED_SINCE_NOT_WORKING_ -/* Bank 8 - On board registers - * PCMCIA (currently not working!) - */ -#define CONFIG_SYS_BR8_PRELIM ((CONFIG_SYS_REGS_BASE & BRx_BA_MSK) |\ - BRx_PS_16 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR8_PRELIM (ORxG_AM_MSK |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SETA |\ - ORxG_SCY_10_CLK) -#endif - -/* - * JFFS2 partitions - * - */ -/* No command line, one static partition, whole device */ -#undef CONFIG_CMD_MTDPARTS -#define CONFIG_JFFS2_DEV "nor0" -#define CONFIG_JFFS2_PART_SIZE 0xFFFFFFFF -#define CONFIG_JFFS2_PART_OFFSET 0x00000000 - -/* mtdparts command line support */ -/* Note: fake mtd_id used, no linux mtd map file */ -/* -#define CONFIG_CMD_MTDPARTS -#define MTDIDS_DEFAULT "" -#define MTDPARTS_DEFAULT "" -*/ - -#endif /* __CONFIG_H */
On Mon, Dec 15, 2014 at 11:26:21PM +0900, Masahiro Yamada wrote:
This board is still a non-generic board.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
arch/powerpc/cpu/mpc8260/Kconfig | 4 - board/funkwerk/vovpn-gw/Kconfig | 12 - board/funkwerk/vovpn-gw/MAINTAINERS | 6 - board/funkwerk/vovpn-gw/Makefile | 8 - board/funkwerk/vovpn-gw/flash.c | 436 ------------------------------------ board/funkwerk/vovpn-gw/m88e6060.c | 249 -------------------- board/funkwerk/vovpn-gw/m88e6060.h | 75 ------- board/funkwerk/vovpn-gw/vovpn-gw.c | 363 ------------------------------ configs/VoVPN-GW_66MHz_defconfig | 4 - doc/README.scrapyard | 1 + include/configs/VoVPN-GW.h | 399 --------------------------------- 11 files changed, 1 insertion(+), 1556 deletions(-) delete mode 100644 board/funkwerk/vovpn-gw/Kconfig delete mode 100644 board/funkwerk/vovpn-gw/MAINTAINERS delete mode 100644 board/funkwerk/vovpn-gw/Makefile delete mode 100644 board/funkwerk/vovpn-gw/flash.c delete mode 100644 board/funkwerk/vovpn-gw/m88e6060.c delete mode 100644 board/funkwerk/vovpn-gw/m88e6060.h delete mode 100644 board/funkwerk/vovpn-gw/vovpn-gw.c delete mode 100644 configs/VoVPN-GW_66MHz_defconfig delete mode 100644 include/configs/VoVPN-GW.h
diff --git a/arch/powerpc/cpu/mpc8260/Kconfig b/arch/powerpc/cpu/mpc8260/Kconfig index 1032712..15742d9 100644 --- a/arch/powerpc/cpu/mpc8260/Kconfig +++ b/arch/powerpc/cpu/mpc8260/Kconfig @@ -37,9 +37,6 @@ config TARGET_PM828 config TARGET_MPC8266ADS bool "Support MPC8266ADS"
-config TARGET_VOVPN_GW - bool "Support VoVPN-GW" - config TARGET_KM82XX bool "Support km82xx"
@@ -50,7 +47,6 @@ source "board/cpu86/Kconfig" source "board/cpu87/Kconfig" source "board/ep82xxm/Kconfig" source "board/freescale/mpc8266ads/Kconfig" -source "board/funkwerk/vovpn-gw/Kconfig" source "board/gw8260/Kconfig" source "board/iphase4539/Kconfig" source "board/keymile/km82xx/Kconfig" diff --git a/board/funkwerk/vovpn-gw/Kconfig b/board/funkwerk/vovpn-gw/Kconfig deleted file mode 100644 index 6b6c328..0000000 --- a/board/funkwerk/vovpn-gw/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_VOVPN_GW - -config SYS_BOARD - default "vovpn-gw" - -config SYS_VENDOR - default "funkwerk" - -config SYS_CONFIG_NAME - default "VoVPN-GW" - -endif diff --git a/board/funkwerk/vovpn-gw/MAINTAINERS b/board/funkwerk/vovpn-gw/MAINTAINERS deleted file mode 100644 index 34d1cc1..0000000 --- a/board/funkwerk/vovpn-gw/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -VOVPN-GW BOARD -#M: - -S: Maintained -F: board/funkwerk/vovpn-gw/ -F: include/configs/VoVPN-GW.h -F: configs/VoVPN-GW_66MHz_defconfig diff --git a/board/funkwerk/vovpn-gw/Makefile b/board/funkwerk/vovpn-gw/Makefile deleted file mode 100644 index 3253247..0000000 --- a/board/funkwerk/vovpn-gw/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2001-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y := vovpn-gw.o flash.o m88e6060.o diff --git a/board/funkwerk/vovpn-gw/flash.c b/board/funkwerk/vovpn-gw/flash.c deleted file mode 100644 index 829514c..0000000 --- a/board/funkwerk/vovpn-gw/flash.c +++ /dev/null @@ -1,436 +0,0 @@ -/* - * (C) Copyright 2004 - * Elmeg Communications Systems GmbH, Juergen Selent (j.selent@elmeg.de) - * - * Support for the Elmeg VoVPN Gateway Module - * ------------------------------------------ - * This is a signle bank flashdriver for INTEL 28F320J3, 28F640J3 - * and 28F128J3A flashs working in 8 Bit mode. - * - * Most of this code is taken from existing u-boot source code. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; - -#define FLASH_CMD_READ_ID 0x90 -#define FLASH_CMD_READ_STATUS 0x70 -#define FLASH_CMD_RESET 0xff -#define FLASH_CMD_BLOCK_ERASE 0x20 -#define FLASH_CMD_ERASE_CONFIRM 0xd0 -#define FLASH_CMD_CLEAR_STATUS 0x50 -#define FLASH_CMD_SUSPEND_ERASE 0xb0 -#define FLASH_CMD_WRITE 0x40 -#define FLASH_CMD_WRITE_BUFF 0xe8 -#define FLASH_CMD_PROG_RESUME 0xd0 -#define FLASH_CMD_PROTECT 0x60 -#define FLASH_CMD_PROTECT_SET 0x01 -#define FLASH_CMD_PROTECT_CLEAR 0xd0 -#define FLASH_STATUS_DONE 0x80 - -#define FLASH_WRITE_BUFFER_SIZE 32 - -#ifdef CONFIG_SYS_FLASH_16BIT -#define FLASH_WORD_SIZE unsigned short -#define FLASH_ID_MASK 0xffff -#define FLASH_CMD_ADDR_SHIFT 0 -#else -#define FLASH_WORD_SIZE unsigned char -#define FLASH_ID_MASK 0xff -/* A0 is not used in either 8x or 16x for READ ID */ -#define FLASH_CMD_ADDR_SHIFT 1 -#endif - - -static unsigned long -flash_get(volatile FLASH_WORD_SIZE *addr, flash_info_t *info) -{ - volatile FLASH_WORD_SIZE *p; - FLASH_WORD_SIZE value; - int i; - - addr[0] = FLASH_CMD_READ_ID; - - /* manufactor */ - value = addr[0 << FLASH_CMD_ADDR_SHIFT]; - switch (value) { - case (INTEL_MANUFACT & FLASH_ID_MASK): - info->flash_id = FLASH_MAN_INTEL; - break; - default: - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - *addr = FLASH_CMD_RESET; - return (0); - - } - - /* device */ - value = addr[1 << FLASH_CMD_ADDR_SHIFT]; - switch (value) { - case (INTEL_ID_28F320J3A & FLASH_ID_MASK): - info->flash_id += FLASH_28F320J3A; - info->sector_count = 32; - info->size = 0x00400000; - break; - case (INTEL_ID_28F640J3A & FLASH_ID_MASK): - info->flash_id += FLASH_28F640J3A; - info->sector_count = 64; - info->size = 0x00800000; - break; - case (INTEL_ID_28F128J3A & FLASH_ID_MASK): - info->flash_id += FLASH_28F128J3A; - info->sector_count = 128; - info->size = 0x01000000; - break; - default: - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - *addr = FLASH_CMD_RESET; - return (0); - } - - /* setup sectors */ - for (i = 0; i < info->sector_count; i++) { - info->start[i] = (unsigned long)addr + (i * info->size/info->sector_count); - } - - /* check protected sectors */ - for (i = 0; i < info->sector_count; i++) { - p = (volatile FLASH_WORD_SIZE *)(info->start[i]); - info->protect[i] = p[2 << FLASH_CMD_ADDR_SHIFT] & 1; - } - - /* reset bank */ - *addr = FLASH_CMD_RESET; - return (info->size); -} - -unsigned long -flash_init(void) -{ - unsigned long size; - int i; - - for (i=0; i<CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - } - size = flash_get((volatile FLASH_WORD_SIZE *)CONFIG_SYS_FLASH_BASE, &flash_info[0]); - if (flash_info[0].flash_id == FLASH_UNKNOWN) { - printf ("## Unknown FLASH Size=0x%08lx\n", size); - return (0); - } - - /* always protect 1 sector containing the HRCW */ - flash_protect(FLAG_PROTECT_SET, - flash_info[0].start[0], - flash_info[0].start[1] - 1, - &flash_info[0]); - -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_FLASH, - CONFIG_SYS_MONITOR_FLASH+CONFIG_SYS_MONITOR_LEN-1, - &flash_info[0]); -#endif -#ifdef CONFIG_ENV_IS_IN_FLASH - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR+CONFIG_ENV_SECT_SIZE-1, - &flash_info[0]); -#endif - return (size); -} - -void -flash_print_info(flash_info_t *info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_INTEL: printf ("INTEL "); break; - default: printf ("Unknown Vendor "); break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_28F320J3A: printf ("28F320JA3 (32 Mbit)\n"); - break; - case FLASH_28F640J3A: printf ("28F640JA3 (64 Mbit)\n"); - break; - case FLASH_28F128J3A: printf ("28F128JA3 (128 Mbit)\n"); - break; - default: printf ("Unknown Chip Type"); - break; - } - - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); - - printf (" Sector Start Addresses:"); - for (i=0; i<info->sector_count; ++i) { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", - info->start[i], - info->protect[i] ? " (RO)" : " " - ); - } - printf ("\n"); -} - -int -flash_erase(flash_info_t *info, int s_first, int s_last) -{ - unsigned long start, now, last; - int flag, prot, sect; - volatile FLASH_WORD_SIZE *addr; - FLASH_WORD_SIZE status; - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return (1); - } - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("Cannot erase unknown flash - aborted\n"); - return (1); - } - - prot = 0; - for (sect=s_first; sect<=s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", prot); - } else { - printf ("\n"); - } - - start = get_timer (0); - last = start; - - for (sect = s_first; sect<=s_last; sect++) { - if (info->protect[sect]) { - continue; - } - - addr = (volatile FLASH_WORD_SIZE *)(info->start[sect]); - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - -#ifdef DEBUG - printf("Erase sector %d at start addr 0x%08X", sect, (unsigned int)info->start[sect]); -#endif - - *addr = FLASH_CMD_CLEAR_STATUS; - *addr = FLASH_CMD_BLOCK_ERASE; - *addr = FLASH_CMD_ERASE_CONFIRM; - - /* re-enable interrupts if necessary */ - if (flag) { - enable_interrupts(); - } - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - - while (((status = *addr) & FLASH_STATUS_DONE) != FLASH_STATUS_DONE) { - if ((now=get_timer(start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf("Flash erase timeout at address %lx\n", info->start[sect]); - *addr = FLASH_CMD_SUSPEND_ERASE; - *addr = FLASH_CMD_RESET; - return (1); - } - - /* show that we're waiting */ - if ((now - last) > 1000) { /* every second */ - putc ('.'); - last = now; - } - } - *addr = FLASH_CMD_RESET; - } - printf (" done\n"); - return (0); -} - -static int -write_buff2( volatile FLASH_WORD_SIZE *dst, - volatile FLASH_WORD_SIZE *src, - unsigned long cnt ) -{ - unsigned long start; - FLASH_WORD_SIZE status; - int flag, i; - - start = get_timer (0); - while (1) { - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - dst[0] = FLASH_CMD_WRITE_BUFF; - if ((status = *dst) & FLASH_STATUS_DONE) { - break; - } - - /* re-enable interrupts if necessary */ - if (flag) { - enable_interrupts(); - } - - if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - return (-1); - } - } - dst[0] = (FLASH_WORD_SIZE)(cnt - 1); - for (i=0; i<cnt; i++) { - dst[i] = src[i]; - } - dst[0] = FLASH_CMD_PROG_RESUME; - - if (flag) { - enable_interrupts(); - } - - return( 0 ); -} - -static int -poll_status( volatile FLASH_WORD_SIZE *addr ) -{ - unsigned long start; - - start = get_timer (0); - /* wait for error or finish */ - while (1) { - if (*addr == FLASH_STATUS_DONE) { - if (*addr == FLASH_STATUS_DONE) { - break; - } - } - if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - *addr = FLASH_CMD_RESET; - return (-1); - } - } - *addr = FLASH_CMD_RESET; - return (0); -} - -/* - * write_buff return values: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - * 4 - Flash not identified - */ -int -write_buff(flash_info_t *info, uchar *src, ulong udst, ulong cnt) -{ - volatile FLASH_WORD_SIZE *addr, *dst; - unsigned long bcnt; - int flag, i; - - if (info->flash_id == FLASH_UNKNOWN) { - return (4); - } - - addr = (volatile FLASH_WORD_SIZE *)(info->start[0]); - dst = (volatile FLASH_WORD_SIZE *) udst; - -#ifdef CONFIG_SYS_FLASH_16BIT -#error NYI -#else - while (cnt > 0) { - /* Check if buffer write is possible */ - if (cnt > 1 && (((unsigned long)dst & (FLASH_WRITE_BUFFER_SIZE - 1)) == 0)) { - bcnt = cnt > FLASH_WRITE_BUFFER_SIZE ? FLASH_WRITE_BUFFER_SIZE : cnt; - /* Check if Flash is (sufficiently) erased */ - for (i=0; i<bcnt; i++) { - if ((dst[i] & src[i]) != src[i]) { - return (2); - } - } - if (write_buff2( dst,src,bcnt ) != 0) { - addr[0] = FLASH_CMD_READ_STATUS; - } - if (poll_status( dst ) != 0) { - return (1); - } - cnt -= bcnt; - dst += bcnt; - src += bcnt; - continue; - } - - /* Check if Flash is (sufficiently) erased */ - if ((*dst & *src) != *src) { - return (2); - } - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - addr[0] = FLASH_CMD_ERASE_CONFIRM; - addr[0] = FLASH_CMD_WRITE; - *dst++ = *src++; - /* re-enable interrupts if necessary */ - if (flag) { - enable_interrupts(); - } - - if (poll_status( dst ) != 0) { - return (1); - } - cnt --; - } -#endif - return (0); -} - -int -flash_real_protect(flash_info_t *info, long sector, int prot) -{ - volatile FLASH_WORD_SIZE *addr; - unsigned long start; - - addr = (volatile FLASH_WORD_SIZE *)(info->start[sector]); - *addr = FLASH_CMD_CLEAR_STATUS; - *addr = FLASH_CMD_PROTECT; - - if(prot) { - *addr = FLASH_CMD_PROTECT_SET; - } else { - *addr = FLASH_CMD_PROTECT_CLEAR; - } - - /* wait for error or finish */ - start = get_timer (0); - while(!(addr[0] & FLASH_STATUS_DONE)){ - if (get_timer(start) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf("Flash protect timeout at address %lx\n", info->start[sector]); - addr[0] = FLASH_CMD_RESET; - return (1); - } - } - - /* Set software protect flag */ - info->protect[sector] = prot; - *addr = FLASH_CMD_RESET; - return (0); -} diff --git a/board/funkwerk/vovpn-gw/m88e6060.c b/board/funkwerk/vovpn-gw/m88e6060.c deleted file mode 100644 index 7aa9593..0000000 --- a/board/funkwerk/vovpn-gw/m88e6060.c +++ /dev/null @@ -1,249 +0,0 @@ -/* - * (C) Copyright 2004 - * Elmeg Communications Systems GmbH, Juergen Selent (j.selent@elmeg.de) - * - * Support for the Elmeg VoVPN Gateway Module - * ------------------------------------------ - * Initialize Marvell M88E6060 Switch - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <ioports.h> -#include <mpc8260.h> -#include <asm/m8260_pci.h> -#include <net.h> -#include <miiphy.h> - -#include "m88e6060.h" - -#if defined(CONFIG_CMD_NET) -static int prtTab[M88X_PRT_CNT] = { 8, 9, 10, 11, 12, 13 }; -static int phyTab[M88X_PHY_CNT] = { 0, 1, 2, 3, 4 }; - -static m88x_regCfg_t prtCfg0[] = { - { 4, 0x3e7c, 0x8000 }, - { 4, 0x3e7c, 0x8003 }, - { 6, 0x0fc0, 0x001e }, - { -1, 0xffff, 0x0000 } -}; - -static m88x_regCfg_t prtCfg1[] = { - { 4, 0x3e7c, 0x8000 }, - { 4, 0x3e7c, 0x8003 }, - { 6, 0x0fc0, 0x001d }, - { -1, 0xffff, 0x0000 } -}; - -static m88x_regCfg_t prtCfg2[] = { - { 4, 0x3e7c, 0x8000 }, - { 4, 0x3e7c, 0x8003 }, - { 6, 0x0fc0, 0x001b }, - { -1, 0xffff, 0x0000 } -}; - -static m88x_regCfg_t prtCfg3[] = { - { 4, 0x3e7c, 0x8000 }, - { 4, 0x3e7c, 0x8003 }, - { 6, 0x0fc0, 0x0017 }, - { -1, 0xffff, 0x0000 } -}; - -static m88x_regCfg_t prtCfg4[] = { - { 4, 0x3e7c, 0x8000 }, - { 4, 0x3e7c, 0x8003 }, - { 6, 0x0fc0, 0x000f }, - { -1, 0xffff, 0x0000 } -}; - -static m88x_regCfg_t *prtCfg[M88X_PRT_CNT] = { - prtCfg0,prtCfg1,prtCfg2,prtCfg3,prtCfg4,NULL -}; - -static m88x_regCfg_t phyCfgX[] = { - { 4, 0xfa1f, 0x01e0 }, - { 0, 0x213f, 0x1200 }, - { 24, 0x81ff, 0x1200 }, - { -1, 0xffff, 0x0000 } -}; - -static m88x_regCfg_t *phyCfg[M88X_PHY_CNT] = { - phyCfgX,phyCfgX,phyCfgX,phyCfgX,NULL -}; - -#if 0 -static void -m88e6060_dump( int devAddr ) -{ - int i, j; - unsigned short val[6]; - - printf( "M88E6060 Register Dump\n" ); - printf( "====================================\n" ); - printf( "PortNo 0 1 2 3 4 5\n" ); - for (i=0; i<6; i++) - miiphy_read( devAddr+prtTab[i],M88X_PRT_STAT,&val[i] ); - printf( "STAT %04hx %04hx %04hx %04hx %04hx %04hx\n", - val[0],val[1],val[2],val[3],val[4],val[5] ); - - for (i=0; i<6; i++) - miiphy_read( devAddr+prtTab[i],M88X_PRT_ID,&val[i] ); - printf( "ID %04hx %04hx %04hx %04hx %04hx %04hx\n", - val[0],val[1],val[2],val[3],val[4],val[5] ); - - for (i=0; i<6; i++) - miiphy_read( devAddr+prtTab[i],M88X_PRT_CNTL,&val[i] ); - printf( "CNTL %04hx %04hx %04hx %04hx %04hx %04hx\n", - val[0],val[1],val[2],val[3],val[4],val[5] ); - - for (i=0; i<6; i++) - miiphy_read( devAddr+prtTab[i],M88X_PRT_VLAN,&val[i] ); - printf( "VLAN %04hx %04hx %04hx %04hx %04hx %04hx\n", - val[0],val[1],val[2],val[3],val[4],val[5] ); - - for (i=0; i<6; i++) - miiphy_read( devAddr+prtTab[i],M88X_PRT_PAV,&val[i] ); - printf( "PAV %04hx %04hx %04hx %04hx %04hx %04hx\n", - val[0],val[1],val[2],val[3],val[4],val[5] ); - - for (i=0; i<6; i++) - miiphy_read( devAddr+prtTab[i],M88X_PRT_RX,&val[i] ); - printf( "RX %04hx %04hx %04hx %04hx %04hx %04hx\n", - val[0],val[1],val[2],val[3],val[4],val[5] ); - - for (i=0; i<6; i++) - miiphy_read( devAddr+prtTab[i],M88X_PRT_TX,&val[i] ); - printf( "TX %04hx %04hx %04hx %04hx %04hx %04hx\n", - val[0],val[1],val[2],val[3],val[4],val[5] ); - - printf( "------------------------------------\n" ); - printf( "PhyNo 0 1 2 3 4\n" ); - for (i=0; i<9; i++) { - for (j=0; j<5; j++) { - miiphy_read( devAddr+phyTab[j],i,&val[j] ); - } - printf( "0x%02x %04hx %04hx %04hx %04hx %04hx\n", - i,val[0],val[1],val[2],val[3],val[4] ); - } - for (i=0x10; i<0x1d; i++) { - for (j=0; j<5; j++) { - miiphy_read( devAddr+phyTab[j],i,&val[j] ); - } - printf( "0x%02x %04hx %04hx %04hx %04hx %04hx\n", - i,val[0],val[1],val[2],val[3],val[4] ); - } -} -#endif - -int -m88e6060_initialize( int devAddr ) -{ - static char *_f = "m88e6060_initialize:"; - m88x_regCfg_t *p; - int err; - int i; - unsigned short val; - - /*** reset all phys into powerdown ************************************/ - for (i=0, err=0; i<M88X_PHY_CNT; i++) { - err += bb_miiphy_read(NULL, devAddr+phyTab[i],M88X_PHY_CNTL,&val ); - /* keep SpeedLSB, Duplex */ - val &= 0x2100; - /* set SWReset, AnegEn, PwrDwn, RestartAneg */ - val |= 0x9a00; - err += bb_miiphy_write(NULL, devAddr+phyTab[i],M88X_PHY_CNTL,val ); - } - if (err) { - printf( "%s [ERR] reset phys\n",_f ); - return( -1 ); - } - - /*** disable all ports ************************************************/ - for (i=0, err=0; i<M88X_PRT_CNT; i++) { - err += bb_miiphy_read(NULL, devAddr+prtTab[i],M88X_PRT_CNTL,&val ); - val &= 0xfffc; - err += bb_miiphy_write(NULL, devAddr+prtTab[i],M88X_PRT_CNTL,val ); - } - if (err) { - printf( "%s [ERR] disable ports\n",_f ); - return( -1 ); - } - - /*** initialize switch ************************************************/ - /* set switch mac addr */ -#define ea eth_get_dev()->enetaddr - val = (ea[4] << 8) | ea[5]; - err = bb_miiphy_write(NULL, devAddr+15,M88X_GLB_MAC45,val ); - val = (ea[2] << 8) | ea[3]; - err += bb_miiphy_write(NULL, devAddr+15,M88X_GLB_MAC23,val ); - val = (ea[0] << 8) | ea[1]; -#undef ea - val &= 0xfeff; /* clear DiffAddr */ - err += bb_miiphy_write(NULL, devAddr+15,M88X_GLB_MAC01,val ); - if (err) { - printf( "%s [ERR] switch mac address register\n",_f ); - return( -1 ); - } - - /* !DiscardExcessive, MaxFrameSize, CtrMode */ - err = bb_miiphy_read(NULL, devAddr+15,M88X_GLB_CNTL,&val ); - val &= 0xd870; - val |= 0x0500; - err += bb_miiphy_write(NULL, devAddr+15,M88X_GLB_CNTL,val ); - if (err) { - printf( "%s [ERR] switch global control register\n",_f ); - return( -1 ); - } - - /* LernDis off, ATUSize 1024, AgeTime 5min */ - err = bb_miiphy_read(NULL, devAddr+15,M88X_ATU_CNTL,&val ); - val &= 0x000f; - val |= 0x2130; - err += bb_miiphy_write(NULL, devAddr+15,M88X_ATU_CNTL,val ); - if (err) { - printf( "%s [ERR] atu control register\n",_f ); - return( -1 ); - } - - /*** initialize ports *************************************************/ - for (i=0; i<M88X_PRT_CNT; i++) { - if ((p = prtCfg[i]) == NULL) { - continue; - } - while (p->reg != -1) { - err = 0; - err += bb_miiphy_read(NULL, devAddr+prtTab[i],p->reg,&val ); - val &= p->msk; - val |= p->val; - err += bb_miiphy_write(NULL, devAddr+prtTab[i],p->reg,val ); - if (err) { - printf( "%s [ERR] config port %d register %d\n",_f,i,p->reg ); - /* XXX what todo */ - } - p++; - } - } - - /*** initialize phys **************************************************/ - for (i=0; i<M88X_PHY_CNT; i++) { - if ((p = phyCfg[i]) == NULL) { - continue; - } - while (p->reg != -1) { - err = 0; - err += bb_miiphy_read(NULL, devAddr+phyTab[i],p->reg,&val ); - val &= p->msk; - val |= p->val; - err += bb_miiphy_write(NULL, devAddr+phyTab[i],p->reg,val ); - if (err) { - printf( "%s [ERR] config phy %d register %d\n",_f,i,p->reg ); - /* XXX what todo */ - } - p++; - } - } - udelay(100000); - return( 0 ); -} -#endif diff --git a/board/funkwerk/vovpn-gw/m88e6060.h b/board/funkwerk/vovpn-gw/m88e6060.h deleted file mode 100644 index 5f7f6d1..0000000 --- a/board/funkwerk/vovpn-gw/m88e6060.h +++ /dev/null @@ -1,75 +0,0 @@ -/* - * (C) Copyright 2004 - * Elmeg Communications Systems GmbH, Juergen Selent (j.selent@elmeg.de) - * - * Support for the Elmeg VoVPN Gateway Module - * ------------------------------------------ - * Initialize Marvell M88E6060 Switch - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef _INC_m88e6060_h_ -#define _INC_m88e6060_h_ - -/* ************************************************************************** */ -/* *** DEFINES ************************************************************** */ - -/* switch hw */ -#define M88X_PRT_CNT 6 -#define M88X_PHY_CNT 5 - -/* phy register offsets */ -#define M88X_PHY_CNTL 0x00 -#define M88X_PHY_STAT 0x00 -#define M88X_PHY_ID0 0x02 -#define M88X_PHY_ID1 0x03 -#define M88X_PHY_ANEG_ADV 0x04 -#define M88X_PHY_LPA 0x05 -#define M88X_PHY_ANEG_EXP 0x06 -#define M88X_PHY_NPT 0x07 -#define M88X_PHY_LPNP 0x08 - -/* port register offsets */ -#define M88X_PRT_STAT 0x00 -#define M88X_PRT_ID 0x03 -#define M88X_PRT_CNTL 0x04 -#define M88X_PRT_VLAN 0x06 -#define M88X_PRT_PAV 0x0b -#define M88X_PRT_RX 0x10 -#define M88X_PRT_TX 0x11 - -/* global/atu register offsets */ -#define M88X_GLB_STAT 0x00 -#define M88X_GLB_MAC01 0x01 -#define M88X_GLB_MAC23 0x02 -#define M88X_GLB_MAC45 0x03 -#define M88X_GLB_CNTL 0x04 -#define M88X_ATU_CNTL 0x0a -#define M88X_ATU_OP 0x0b - -/* id0 register - 0x02 */ -#define M88X_PHY_ID0_VALUE 0x0141 - -/* id1 register - 0x03 */ -#define M88X_PHY_ID1_VALUE 0x0c80 /* without revision ! */ - - -/* misc */ -#define M88E6060_ID ((M88X_PHY_ID0_VALUE<<16) | M88X_PHY_ID1_VALUE) - -/* ************************************************************************** */ -/* *** TYPEDEFS ************************************************************* */ - -typedef struct { - int reg; - unsigned short msk; - unsigned short val; -} m88x_regCfg_t; - -/* ************************************************************************** */ -/* *** PROTOTYPES *********************************************************** */ - -extern int m88e6060_initialize( int ); - -#endif /* _INC_m88e6060_h_ */ diff --git a/board/funkwerk/vovpn-gw/vovpn-gw.c b/board/funkwerk/vovpn-gw/vovpn-gw.c deleted file mode 100644 index c2aad6e..0000000 --- a/board/funkwerk/vovpn-gw/vovpn-gw.c +++ /dev/null @@ -1,363 +0,0 @@ -/* - * (C) Copyright 2004 - * Elmeg Communications Systems GmbH, Juergen Selent (j.selent@elmeg.de) - * - * Support for the Elmeg VoVPN Gateway Module - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <ioports.h> -#include <mpc8260.h> -#include <asm/m8260_pci.h> -#include <miiphy.h> -#include <linux/compiler.h> - -#include "m88e6060.h" - -/* - * I/O Port configuration table - * - * if conf is 1, then that port pin will be configured at boot time - * according to the five values podr/pdir/ppar/psor/pdat for that entry - */ - -const iop_conf_t iop_conf_tab[4][32] = { - /* Port A configuration */ - { /* conf ppar psor pdir podr pdat */ - /* PA31 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1252 */ - /* PA30 */ { 1, 0, 0, 0, 0, 0 }, /* GPI BP_RES */ - /* PA29 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1253 */ - /* PA28 */ { 1, 1, 1, 1, 0, 0 }, /* FCC1 RMII TX_EN */ - /* PA27 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 RMII CRS_DV */ - /* PA26 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 RMII RX_ERR */ - /* PA25 */ { 1, 0, 0, 0, 0, 0 }, /* GPI HWID */ - /* PA24 */ { 1, 0, 0, 0, 0, 0 }, /* GPI HWID */ - /* PA23 */ { 1, 0, 0, 0, 0, 0 }, /* GPI HWID */ - /* PA22 */ { 1, 0, 0, 0, 0, 0 }, /* GPI HWID */ - /* PA21 */ { 1, 0, 0, 0, 0, 0 }, /* GPI HWID */ - /* PA20 */ { 1, 0, 0, 1, 0, 1 }, /* GPO LED STATUS */ - /* PA19 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 RMII TxD[1] */ - /* PA18 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 RMII TxD[0] */ - /* PA17 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 RMII RxD[0] */ - /* PA16 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 RMII RxD[1] */ - /* PA15 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1255 */ - /* PA14 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP???? */ - /* PA13 */ { 1, 0, 0, 1, 0, 1 }, /* GPO EN_BCTL1 XXX jse */ - /* PA12 */ { 1, 0, 0, 1, 0, 0 }, /* GPO SWITCH RESET */ - /* PA11 */ { 1, 0, 0, 1, 0, 0 }, /* GPO DSP SL1 RESET */ - /* PA10 */ { 1, 0, 0, 1, 0, 0 }, /* GPO DSP SL2 RESET */ - /* PA9 */ { 1, 1, 0, 1, 0, 0 }, /* SMC2 TXD */ - /* PA8 */ { 1, 1, 0, 0, 0, 0 }, /* SMC2 RXD */ - /* PA7 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exit */ - /* PA6 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exit */ - /* PA5 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exit */ - /* PA4 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exit */ - /* PA3 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exit */ - /* PA2 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exit */ - /* PA1 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exit */ - /* PA0 */ { 0, 0, 0, 0, 0, 0 } /* pin does not exit */ - }, - - /* Port B configuration */ - { /* conf ppar psor pdir podr pdat */ - /* PB31 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1257 */ - /* PB30 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 RMII CRS_DV */ - /* PB29 */ { 1, 1, 1, 1, 0, 0 }, /* FCC2 RMII TX_EN */ - /* PB28 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 RMII RX_ERR */ - /* PB27 */ { 1, 1, 1, 0, 1, 0 }, /* TDM_B2 L1TXD XXX val=0 */ - /* PB26 */ { 1, 1, 1, 0, 1, 0 }, /* TDM_B2 L1RXD XXX val,dr */ - /* PB25 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1259 */ - /* PB24 */ { 1, 1, 1, 0, 0, 0 }, /* TDM_B2 L1RSYNC */ - /* PB23 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 RMII TxD[1] */ - /* PB22 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 RMII TxD[0] */ - /* PB21 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 RMII RxD[0] */ - /* PB20 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 RMII RxD[1] */ - /* PB19 */ { 1, 0, 0, 1, 0, 1 }, /* GPO PHY MDC */ - /* PB18 */ { 1, 0, 0, 0, 0, 0 }, /* GPIO PHY MDIO */ - /* PB17 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PB16 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PB15 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PB14 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PB13 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PB12 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PB11 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PB10 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PB9 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PB8 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PB7 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PB6 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PB5 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PB4 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PB3 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PB2 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PB1 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PB0 */ { 0, 0, 0, 0, 0, 0 } /* pin does not exist */ - }, - - /* Port C */ - { /* conf ppar psor pdir podr pdat */ - /* PC31 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PC30 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PC29 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1183 */ - /* PC28 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1184 */ - /* PC27 */ { 1, 1, 0, 0, 0, 0 }, /* CLK5 TDM_A1 RX */ - /* PC26 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1185 */ - /* PC25 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1178 */ - /* PC24 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1186 */ - /* PC23 */ { 1, 1, 0, 0, 0, 0 }, /* CLK9 TDM_B2 RX */ - /* PC22 */ { 1, 1, 0, 0, 0, 0 }, /* CLK10 FCC1 RMII REFCLK */ - /* PC21 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1187 */ - /* PC20 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1182 */ - /* PC19 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1188 */ - /* PC18 */ { 1, 0, 0, 1, 0, 0 }, /* GPO HW RESET */ - /* PC17 */ { 1, 1, 0, 1, 0, 0 }, /* BRG8 SWITCH CLKIN */ - /* PC16 */ { 1, 1, 0, 0, 0, 0 }, /* CLK16 FCC2 RMII REFCLK */ - /* PC15 */ { 1, 0, 0, 0, 0, 0 }, /* GPI SL1_MTYPE_3 */ - /* PC14 */ { 1, 0, 0, 0, 0, 0 }, /* GPI SL1_MTYPE_2 */ - /* PC13 */ { 1, 0, 0, 0, 0, 0 }, /* GPI SL1_MTYPE_1 */ - /* PC12 */ { 1, 0, 0, 0, 0, 0 }, /* GPI SL1_MTYPE_0 */ - /* PC11 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1176 */ - /* PC10 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1177 */ - /* PC9 */ { 1, 0, 0, 0, 0, 0 }, /* GPI SL2_MTYPE_3 */ - /* PC8 */ { 1, 0, 0, 0, 0, 0 }, /* GPI SL2_MTYPE_2 */ - /* PC7 */ { 1, 0, 0, 0, 0, 0 }, /* GPI SL2_MTYPE_1 */ - /* PC6 */ { 1, 0, 0, 0, 0, 0 }, /* GPI SL2_MTYPE_0 */ - /* PC5 */ { 1, 1, 0, 1, 0, 0 }, /* SMC1 TXD */ - /* PC4 */ { 1, 1, 0, 0, 0, 0 }, /* SMC1 RXD */ - /* PC3 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PC2 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PC1 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1192 */ - /* PC0 */ { 1, 0, 0, 0, 0, 0 }, /* GPI RACK */ - }, - - /* Port D */ - { /* conf ppar psor pdir podr pdat */ - /* PD31 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1193 */ - /* PD30 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1194 */ - /* PD29 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1195 */ - /* PD28 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PD27 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PD26 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PD25 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1179 */ - /* PD24 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1180 */ - /* PD23 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1181 */ - /* PD22 */ { 1, 1, 1, 0, 1, 0 }, /* TDM_A2 L1TXD */ - /* PD21 */ { 1, 1, 1, 0, 1, 0 }, /* TDM_A2 L1RXD */ - /* PD20 */ { 1, 1, 1, 0, 0, 0 }, /* TDM_A2 L1RSYNC */ - /* PD19 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1196 */ - /* PD18 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1197 */ - /* PD17 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1198 */ - /* PD16 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1199 */ - /* PD15 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1250 */ - /* PD14 */ { 1, 0, 0, 1, 0, 0 }, /* GPO TP1251 */ - /* PD13 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PD12 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PD11 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PD10 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PD9 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PD8 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PD7 */ { 0, 0, 0, 1, 0, 0 }, /* GPO FL_BYTE */ - /* PD6 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PD5 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PD4 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PD3 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PD2 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PD1 */ { 0, 0, 0, 0, 0, 0 }, /* pin does not exist */ - /* PD0 */ { 0, 0, 0, 0, 0, 0 } /* pin does not exist */ - } -}; - -void reset_phy (void) -{ - volatile ioport_t *iop; -#if defined(CONFIG_CMD_NET) - int i; - unsigned short val; -#endif - - iop = ioport_addr((immap_t *)CONFIG_SYS_IMMR, 0); - - /* Reset the PHY */ - iop->pdat &= 0xfff7ffff; /* PA12 = |SWITCH_RESET */ -#if defined(CONFIG_CMD_NET) - udelay(20000); - iop->pdat |= 0x00080000; - for (i=0; i<100; i++) { - udelay(20000); - if (bb_miiphy_read("FCC1", CONFIG_SYS_PHY_ADDR,2,&val ) == 0) { - break; - } - } - /* initialize switch */ - m88e6060_initialize( CONFIG_SYS_PHY_ADDR ); -#endif -} - -static unsigned long UPMATable[] = { - 0x8fffec00, 0x0ffcfc00, 0x0ffcfc00, 0x0ffcfc00, /* Words 0 to 3 */ - 0x0ffcfc04, 0x3ffdfc00, 0xfffffc01, 0xfffffc01, /* Words 4 to 7 */ - 0xfffffc00, 0xfffffc04, 0xfffffc01, 0xfffffc00, /* Words 8 to 11 */ - 0xfffffc00, 0xfffffc00, 0xfffffc00, 0xfffffc00, /* Words 12 to 15 */ - 0xfffffc00, 0xfffffc00, 0xfffffc00, 0xfffffc00, /* Words 16 to 19 */ - 0xfffffc00, 0xfffffc00, 0xfffffc00, 0xfffffc01, /* Words 20 to 23 */ - 0x8fffec00, 0x00fffc00, 0x00fffc00, 0x00fffc00, /* Words 24 to 27 */ - 0x0ffffc04, 0xfffffc01, 0xfffffc01, 0xfffffc01, /* Words 28 to 31 */ - 0xfffffc00, 0xfffffc01, 0xfffffc01, 0xfffffc00, /* Words 32 to 35 */ - 0xfffffc00, 0xfffffc00, 0xfffffc00, 0xfffffc00, /* Words 36 to 39 */ - 0xfffffc00, 0xfffffc00, 0xfffffc00, 0xfffffc00, /* Words 40 to 43 */ - 0xfffffc00, 0xfffffc00, 0xfffffc00, 0xfffffc01, /* Words 44 to 47 */ - 0xfffffc00, 0xfffffc04, 0xfffffc01, 0xfffffc00, /* Words 48 to 51 */ - 0xfffffc00, 0xfffffc00, 0xfffffc00, 0xfffffc00, /* Words 52 to 55 */ - 0xfffffc00, 0xfffffc00, 0xfffffc00, 0xfffffc01, /* Words 56 to 59 */ - 0xffffec00, 0xffffec04, 0xffffec00, 0xfffffc01 /* Words 60 to 63 */ -}; - -int board_early_init_f (void) -{ - volatile immap_t *immap; - volatile memctl8260_t *memctl; - volatile unsigned char *dummy; - int i; - - immap = (immap_t *) CONFIG_SYS_IMMR; - memctl = &immap->im_memctl; - -#if 0 - /* CS2-5 - DSP via UPMA */ - dummy = (volatile unsigned char *) (memctl->memc_br2 & BRx_BA_MSK); - memctl->memc_mar = 0; - memctl->memc_mamr = MxMR_OP_WARR; - for (i = 0; i < 64; i++) { - memctl->memc_mdr = UPMATable[i]; - *dummy = 0; - } - memctl->memc_mamr = 0x00044440; -#else - /* CS7 - DPRAM via UPMA */ - dummy = (volatile unsigned char *) (memctl->memc_br7 & BRx_BA_MSK); - memctl->memc_mar = 0; - memctl->memc_mamr = MxMR_OP_WARR; - for (i = 0; i < 64; i++) { - memctl->memc_mdr = UPMATable[i]; - *dummy = 0; - } - memctl->memc_mamr = 0x00044440; -#endif - return 0; -} - -int misc_init_r (void) -{ - volatile ioport_t *iop; - __maybe_unused unsigned char temp; -#if 0 - /* DUMP UPMA RAM */ - volatile immap_t *immap; - volatile memctl8260_t *memctl; - volatile unsigned char *dummy; - unsigned char c; - int i; - - immap = (immap_t *) CONFIG_SYS_IMMR; - memctl = &immap->im_memctl; - - - dummy = (volatile unsigned char *) (memctl->memc_br7 & BRx_BA_MSK); - memctl->memc_mar = 0; - memctl->memc_mamr = MxMR_OP_RARR; - for (i = 0; i < 64; i++) { - c = *dummy; - printf( "UPMA[%02d]: 0x%08lx,0x%08lx: 0x%08lx\n",i, - memctl->memc_mamr, - memctl->memc_mar, - memctl->memc_mdr ); - } - memctl->memc_mamr = 0x00044440; -#endif - /* enable buffers (DSP, DPRAM) */ - iop = ioport_addr((immap_t *)CONFIG_SYS_IMMR, 0); - iop->pdat &= 0xfffbffff; /* PA13 = |EN_M_BCTL1 */ - - /* destroy DPRAM magic */ - *(volatile unsigned char *)0xf0500000 = 0x00; - - /* clear any pending DPRAM irq */ - temp = *(volatile unsigned char *)0xf05003ff; - - /* write module-id into DPRAM */ - *(volatile unsigned char *)0xf0500201 = 0x50; - - return 0; -} - -#if defined(CONFIG_HAVE_OWN_RESET) -int -do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - volatile ioport_t *iop; - - iop = ioport_addr((immap_t *)CONFIG_SYS_IMMR, 2); - iop->pdat |= 0x00002000; /* PC18 = HW_RESET */ - return 1; -} -#endif /* CONFIG_HAVE_OWN_RESET */ - -#define ns2clk(ns) (ns / (1000000000 / CONFIG_8260_CLKIN) + 1) - -phys_size_t initdram (int board_type) -{ -#ifndef CONFIG_SYS_RAMBOOT - volatile immap_t *immap; - volatile memctl8260_t *memctl; - volatile uchar *ramaddr; - int i; - uchar c; - - immap = (immap_t *) CONFIG_SYS_IMMR; - memctl = &immap->im_memctl; - ramaddr = (uchar *) CONFIG_SYS_SDRAM_BASE; - c = 0xff; - - immap->im_siu_conf.sc_ppc_acr = 0x02; - immap->im_siu_conf.sc_ppc_alrh = 0x01267893; - immap->im_siu_conf.sc_ppc_alrl = 0x89abcdef; - immap->im_siu_conf.sc_tescr1 = 0x00000000; - immap->im_siu_conf.sc_tescr2 = 0x00000000; - - memctl->memc_mptpr = CONFIG_SYS_MPTPR; - memctl->memc_psrt = CONFIG_SYS_PSRT; - memctl->memc_or1 = CONFIG_SYS_OR1_PRELIM; - memctl->memc_br1 = CONFIG_SYS_SDRAM_BASE | CONFIG_SYS_BR1_PRELIM; - - /* Precharge all banks */ - memctl->memc_psdmr = CONFIG_SYS_PSDMR | 0x28000000; - *ramaddr = c; - - /* CBR refresh */ - memctl->memc_psdmr = CONFIG_SYS_PSDMR | 0x08000000; - for (i = 0; i < 8; i++) - *ramaddr = c; - - /* Mode Register write */ - memctl->memc_psdmr = CONFIG_SYS_PSDMR | 0x18000000; - *ramaddr = c; - - /* Refresh enable */ - memctl->memc_psdmr = CONFIG_SYS_PSDMR | 0x40000000; - *ramaddr = c; -#endif /* CONFIG_SYS_RAMBOOT */ - - return (CONFIG_SYS_SDRAM_SIZE); -} - -int checkboard (void) -{ -#ifdef CONFIG_CLKIN_66MHz - puts ("Board: Elmeg VoVPN Gateway Module (66MHz)\n"); -#else - puts ("Board: Elmeg VoVPN Gateway Module (100MHz)\n"); -#endif - return 0; -} diff --git a/configs/VoVPN-GW_66MHz_defconfig b/configs/VoVPN-GW_66MHz_defconfig deleted file mode 100644 index 4eb931e..0000000 --- a/configs/VoVPN-GW_66MHz_defconfig +++ /dev/null @@ -1,4 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="CLKIN_66MHz" -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_VOVPN_GW=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 46b6dbe..7e4eaef 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,7 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +VoVPN-GW powerpc mpc8260 - - ep8260 powerpc mpc8260 - - Frank Panno fpanno@delphintech.com ppmc8260 powerpc mpc8260 - - Brad Kemp Brad.Kemp@seranoa.com sacsng powerpc mpc8260 - - Jerry Van Baren gerald.vanbaren@smiths-aerospace.com diff --git a/include/configs/VoVPN-GW.h b/include/configs/VoVPN-GW.h deleted file mode 100644 index 1ceef11..0000000 --- a/include/configs/VoVPN-GW.h +++ /dev/null @@ -1,399 +0,0 @@ -/* - * (C) Copyright 2004 - * Elmeg Communications Systems GmbH, Juergen Selent (j.selent@elmeg.de) - * - * Support for the Elmeg VoVPN Gateway Module - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* define cpu used */ -#define CONFIG_MPC8272 1 - -/* define busmode: 8260 */ -#undef CONFIG_BUSMODE_60x - -#define CONFIG_SYS_TEXT_BASE 0xfff00000 - -/* system clock rate (CLKIN) - equal to the 60x and local bus speed */ -#ifdef CONFIG_CLKIN_66MHz -#define CONFIG_8260_CLKIN 66666666 /* in Hz */ -#else -#define CONFIG_8260_CLKIN 100000000 /* in Hz */ -#endif - -/* call board_early_init_f */ -#define CONFIG_BOARD_EARLY_INIT_F 1 - -/* have misc_init_r() function */ -#define CONFIG_MISC_INIT_R 1 - -/* have reset_phy_r() function */ -#define CONFIG_RESET_PHY_R 1 - -/* have special reset function */ -#define CONFIG_HAVE_OWN_RESET 1 - -/* allow serial and ethaddr to be overwritten */ -#define CONFIG_ENV_OVERWRITE - -/* watchdog disabled */ -#undef CONFIG_WATCHDOG - -/* include support for bzip2 compressed images */ -#undef CONFIG_BZIP2 - -/* status led */ -#undef CONFIG_STATUS_LED /* XXX jse */ - -/* vendor parameter protection */ -#define CONFIG_ENV_OVERWRITE - -/* - * select serial console configuration - * - * if either CONFIG_CONS_ON_SMC or CONFIG_CONS_ON_SCC is selected, then - * CONFIG_CONS_INDEX must be set to the channel number (1-2 for SMC, 1-4 - * for SCC). - */ -#define CONFIG_CONS_ON_SMC -#undef CONFIG_CONS_ON_SCC -#undef CONFIG_CONS_NONE -#define CONFIG_CONS_INDEX 1 - -/* serial port default baudrate */ -#define CONFIG_BAUDRATE 115200 - -/* echo on for serial download */ -#define CONFIG_LOADS_ECHO 1 - -/* don't allow baudrate change */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE - -/* - * select ethernet configuration - * - * if either CONFIG_ETHER_ON_SCC or CONFIG_ETHER_ON_FCC is selected, then - * CONFIG_ETHER_INDEX must be set to the channel number (1-4 for SCC, 1-3 - * for FCC) - * - * if CONFIG_ETHER_NONE is defined, then either the ethernet routines must be - * defined elsewhere (as for the console), or CONFIG_CMD_NET must be unset. - */ -#undef CONFIG_ETHER_ON_SCC -#define CONFIG_ETHER_ON_FCC -#undef CONFIG_ETHER_NONE - -#ifdef CONFIG_ETHER_ON_FCC - -/* which SCC/FCC channel for ethernet */ -#define CONFIG_ETHER_INDEX 1 - -/* Marvell Switch SMI base addr */ -#define CONFIG_SYS_PHY_ADDR 0x10 - -/* FCC1 RMII REFCLK is CLK10 */ -#define CONFIG_SYS_CMXFCR_VALUE CMXFCR_TF1CS_CLK10 -#define CONFIG_SYS_CMXFCR_MASK (CMXFCR_FC1|CMXFCR_TF1CS_MSK) - -/* BDs and buffers on 60x bus */ -#define CONFIG_SYS_CPMFCR_RAMTYPE 0 - -/* Local Protect, Full duplex, Flowcontrol, RMII */ -#define CONFIG_SYS_FCC_PSMR (FCC_PSMR_LPB|FCC_PSMR_FDE|\ - FCC_PSMR_FCE|FCC_PSMR_RMII) - -/* bit-bang MII PHY management */ -#define CONFIG_BITBANGMII - -#define MDIO_PORT 1 /* Port B */ - -#define MDIO_DECLARE volatile ioport_t *iop = ioport_addr ( \ - (immap_t *) CONFIG_SYS_IMMR, MDIO_PORT ) -#define MDC_DECLARE MDIO_DECLARE - -#define CONFIG_SYS_MDIO_PIN 0x00002000 /* PB18 */ -#define CONFIG_SYS_MDC_PIN 0x00001000 /* PB19 */ -#define MDIO_ACTIVE (iop->pdir |= CONFIG_SYS_MDIO_PIN) -#define MDIO_TRISTATE (iop->pdir &= ~CONFIG_SYS_MDIO_PIN) -#define MDIO_READ ((iop->pdat & CONFIG_SYS_MDIO_PIN) != 0) -#define MDIO(bit) if(bit) iop->pdat |= CONFIG_SYS_MDIO_PIN; \ - else iop->pdat &= ~CONFIG_SYS_MDIO_PIN -#define MDC(bit) if(bit) iop->pdat |= CONFIG_SYS_MDC_PIN; \ - else iop->pdat &= ~CONFIG_SYS_MDC_PIN -#define MIIDELAY udelay(1) - -#endif - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME - - -/* - * Command line configuration. - */ - -#define CONFIG_CMD_BDI -#define CONFIG_CMD_CONSOLE -#define CONFIG_CMD_ECHO -#define CONFIG_CMD_FLASH -#define CONFIG_CMD_IMI -#define CONFIG_CMD_IMLS -#define CONFIG_CMD_LOADB -#define CONFIG_CMD_MEMORY -#define CONFIG_CMD_MISC -#define CONFIG_CMD_NET -#define CONFIG_CMD_PING -#define CONFIG_CMD_RUN -#define CONFIG_CMD_SAVEENV -#define CONFIG_CMD_SOURCE - - -/* - * boot options & environment - */ -#define CONFIG_BOOTDELAY 3 -#define CONFIG_BOOTCOMMAND "run flash_self" -#undef CONFIG_BOOTARGS -#define CONFIG_EXTRA_ENV_SETTINGS \ -"clean_nv=erase fff20000 ffffffff\0" \ -"update_boss=tftp 100000 PPC/logic157.bin; protect off fff00000 ffffffff; erase fff00000 ffffffff; cp.b 100000 fff00000 ${filesize}; tftp 100000 PPC/bootmon157.bin; cp.b 100000 fff20000 ${filesize}\0" \ -"update_lx=tftp 100000 ${kernel}; erase ${kernel_addr} ffefffff; cp.b 100000 ${kernel_addr} ${filesize}\0" \ -"update_fs=tftp 100000 ${fs}.${fstype}; erase ff840000 ffdfffff; cp.b 100000 ff840000 ${filesize}\0" \ -"update_ub=tftp 100000 ${uboot}; protect off fff00000 fff1ffff; erase fff00000 fff1ffff; cp.b 100000 fff00000 ${filesize}; protect off ff820000 ff83ffff; erase ff820000 ff83ffff\0" \ -"flashargs=setenv bootargs root=${rootdev} rw rootfstype=${fstype}\0" \ -"nfsargs=setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath}\0" \ -"addip=setenv bootargs ${bootargs} ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}:${netdev}:off\0" \ -"addmisc=setenv bootargs ${bootargs} console=${console},${baudrate} ethaddr=${ethaddr} panic=1\0" \ -"net_nfs=tftpboot 400000 ${kernel}; run nfsargs addip addmisc; bootm\0" \ -"net_self=tftpboot 400000 ${kernel}; run flashargs addmisc; bootm\0" \ -"flash_self=run flashargs addmisc; bootm ${kernel_addr}\0" \ -"flash_nfs=run nfsargs addip addmisc; bootm ${kernel_addr}\0" \ -"fstype=cramfs\0" \ -"rootpath=/root_fs\0" \ -"uboot=PPC/u-boot.bin\0" \ -"kernel=PPC/uImage\0" \ -"kernel_addr=ffe00000\0" \ -"fs=PPC/root_fs\0" \ -"console=ttyS0\0" \ -"netdev=eth0\0" \ -"rootdev=31:3\0" \ -"ethaddr=00:09:4f:01:02:03\0" \ -"ipaddr=10.0.0.201\0" \ -"netmask=255.255.255.0\0" \ -"serverip=10.0.0.136\0" \ -"gatewayip=10.0.0.10\0" \ -"hostname=bastard\0" \ -"" - - -/* - * miscellaneous configurable options - */ - -/* undef to save memory */ -#define CONFIG_SYS_LONGHELP - -/* monitor command prompt */ - -/* console i/o buffer size */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 -#else -#define CONFIG_SYS_CBSIZE 256 -#endif - -/* print buffer size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) - -/* max number of command args */ -#define CONFIG_SYS_MAXARGS 16 - -/* boot argument buffer size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE - -/* memtest works on */ -#define CONFIG_SYS_MEMTEST_START 0x00100000 -/* 1 ... 15 MB in DRAM */ -#define CONFIG_SYS_MEMTEST_END 0x00f00000 -/* full featured memtest */ -#define CONFIG_SYS_ALT_MEMTEST - -/* default load address */ -#define CONFIG_SYS_LOAD_ADDR 0x00100000 - -/* decrementer freq: 1 ms ticks */ - -/* configure flash */ -#define CONFIG_SYS_FLASH_BASE 0xff800000 -#define CONFIG_SYS_MAX_FLASH_BANKS 1 -#define CONFIG_SYS_MAX_FLASH_SECT 64 -#define CONFIG_SYS_FLASH_SIZE 8 -#undef CONFIG_SYS_FLASH_16BIT -#define CONFIG_SYS_FLASH_ERASE_TOUT 240000 -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 -#define CONFIG_SYS_FLASH_LOCK_TOUT 500 -#define CONFIG_SYS_FLASH_UNLOCK_TOUT 10000 -#define CONFIG_SYS_FLASH_PROTECTION - -/* monitor in flash */ -#define CONFIG_SYS_MONITOR_OFFSET 0x00700000 - -/* environment in flash */ -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x00020000) -#define CONFIG_ENV_SIZE 0x00020000 -#define CONFIG_ENV_SECT_SIZE 0x00020000 - -/* - * Initial memory map for linux - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) - -/* hard reset configuration words */ -#ifdef CONFIG_CLKIN_66MHz -#define CONFIG_SYS_HRCW_MASTER 0x04643050 -#else -#error NO HRCW FOR 100MHZ SPECIFIED !!! -#endif -#define CONFIG_SYS_HRCW_SLAVE1 0x00000000 -#define CONFIG_SYS_HRCW_SLAVE2 0x00000000 -#define CONFIG_SYS_HRCW_SLAVE3 0x00000000 -#define CONFIG_SYS_HRCW_SLAVE4 0x00000000 -#define CONFIG_SYS_HRCW_SLAVE5 0x00000000 -#define CONFIG_SYS_HRCW_SLAVE6 0x00000000 -#define CONFIG_SYS_HRCW_SLAVE7 0x00000000 - -/* internal memory mapped register */ -#define CONFIG_SYS_IMMR 0xF0000000 - -/* definitions for initial stack pointer and data area (in DPRAM) */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/* - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_SDRAM_SIZE (32*1024*1024) -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_MONITOR_FLASH (CONFIG_SYS_FLASH_BASE + CONFIG_SYS_MONITOR_OFFSET) -#define CONFIG_SYS_MONITOR_LEN 0x00020000 -#define CONFIG_SYS_MALLOC_LEN 0x00020000 - -/* cache configuration */ -#define CONFIG_SYS_CACHELINE_SIZE 32 /* for MPC8260 */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of above */ -#endif - -/* - * HIDx - Hardware Implementation-dependent Registers - *----------------------------------------------------------------------- - * HID0 also contains cache control - initially enable both caches and - * invalidate contents, then the final state leaves only the instruction - * cache enabled. Note that Power-On and Hard reset invalidate the caches, - * but Soft reset does not. - * - * HID1 has only read-only information - nothing to set. - */ -#define CONFIG_SYS_HID0_INIT (HID0_ICE|HID0_DCE|\ - HID0_ICFI|HID0_DCI|HID0_IFEM|HID0_ABE) -#define CONFIG_SYS_HID0_FINAL (HID0_IFEM|HID0_ABE) -#define CONFIG_SYS_HID2 0 - -/* RMR - reset mode register - turn on checkstop reset enable */ -#define CONFIG_SYS_RMR RMR_CSRE - -/* BCR - bus configuration */ -#define CONFIG_SYS_BCR 0x00000000 - -/* SIUMCR - siu module configuration */ -#define CONFIG_SYS_SIUMCR 0x4905c000 - -/* SYPCR - system protection control */ -#if defined(CONFIG_WATCHDOG) -#define CONFIG_SYS_SYPCR 0xffffff87 -#else -#define CONFIG_SYS_SYPCR 0xffffff83 -#endif - -/* TMCNTSC - time counter status and control */ -/* clear interrupts XXX jse */ -/*#define CONFIG_SYS_TMCNTSC (TMCNTSC_SEC|TMCNTSC_ALR) */ -#define CONFIG_SYS_TMCNTSC (TMCNTSC_SEC|TMCNTSC_ALR|\ - TMCNTSC_TCF|TMCNTSC_TCE) - -/* PISCR - periodic interrupt status and control */ -/* clear interrupts XXX jse */ -/*#define CONFIG_SYS_PISCR (PISCR_PS) */ -#define CONFIG_SYS_PISCR (PISCR_PS|PISCR_PTF|PISCR_PTE) - -/* SCCR - system clock control */ -#define CONFIG_SYS_SCCR 0x000001a9 - -/* RCCR - risc controller configuration */ -#define CONFIG_SYS_RCCR 0 - -/* - * MEMORY MAP - * ---------- - * CS0 - FLASH 8MB/8Bit base=0xff800000 (boot: 0xfe000000, 8x mirrored) - * CS1 - SDRAM 32MB/64Bit base=0x00000000 - * CS2 - DSP/SL1 1MB/16Bit base=0xf0100000 - * CS3 - DSP/SL2 1MB/16Bit base=0xf0200000 - * CS4 - DSP/SL3 1MB/16Bit base=0xf0300000 - * CS5 - DSP/SL4 1MB/16Bit base=0xf0400000 - * CS7 - DPRAM 1KB/8Bit base=0xf0500000, size=32KB (32x mirrored) - * x - IMMR 384KB base=0xf0000000 - */ -/* XXX jse 100MHz TODO */ -#define CONFIG_SYS_BR0_PRELIM 0xff800801 -#define CONFIG_SYS_OR0_PRELIM 0xff801e44 -#define CONFIG_SYS_BR1_PRELIM 0x00000041 -#define CONFIG_SYS_OR1_PRELIM 0xfe002ec0 -#if 1 -#define CONFIG_SYS_BR2_PRELIM 0xf0101001 -#define CONFIG_SYS_OR2_PRELIM 0xfff00ef4 -#define CONFIG_SYS_BR3_PRELIM 0xf0201001 -#define CONFIG_SYS_OR3_PRELIM 0xfff00ef4 -#define CONFIG_SYS_BR4_PRELIM 0xf0301001 -#define CONFIG_SYS_OR4_PRELIM 0xfff00ef4 -#define CONFIG_SYS_BR5_PRELIM 0xf0401001 -#define CONFIG_SYS_OR5_PRELIM 0xfff00ef4 -#else -#define CONFIG_SYS_BR2_PRELIM 0xf0101081 -#define CONFIG_SYS_OR2_PRELIM 0xfff00104 -#define CONFIG_SYS_BR3_PRELIM 0xf0201081 -#define CONFIG_SYS_OR3_PRELIM 0xfff00104 -#define CONFIG_SYS_BR4_PRELIM 0xf0301081 -#define CONFIG_SYS_OR4_PRELIM 0xfff00104 -#define CONFIG_SYS_BR5_PRELIM 0xf0401081 -#define CONFIG_SYS_OR5_PRELIM 0xfff00104 -#endif -#define CONFIG_SYS_BR7_PRELIM 0xf0500881 -#define CONFIG_SYS_OR7_PRELIM 0xffff8104 -#define CONFIG_SYS_MPTPR 0x2700 -#define CONFIG_SYS_PSDMR 0x822a2452 /* optimal */ -/*#define CONFIG_SYS_PSDMR 0x822a48a3 */ /* relaxed */ -#define CONFIG_SYS_PSRT 0x1a - -/* "bad" address */ -#define CONFIG_SYS_RESET_ADDRESS 0x40000000 - -#endif /* __CONFIG_H */
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Rune Torgersen runet@innovsys.com ---
arch/powerpc/cpu/mpc8260/Kconfig | 4 - arch/powerpc/cpu/mpc8260/pci.c | 57 +--- board/freescale/mpc8266ads/Kconfig | 12 - board/freescale/mpc8266ads/MAINTAINERS | 6 - board/freescale/mpc8266ads/Makefile | 8 - board/freescale/mpc8266ads/flash.c | 493 --------------------------- board/freescale/mpc8266ads/mpc8266ads.c | 582 -------------------------------- configs/MPC8266ADS_defconfig | 3 - doc/README.scrapyard | 1 + include/configs/MPC8266ADS.h | 563 ------------------------------ 10 files changed, 3 insertions(+), 1726 deletions(-) delete mode 100644 board/freescale/mpc8266ads/Kconfig delete mode 100644 board/freescale/mpc8266ads/MAINTAINERS delete mode 100644 board/freescale/mpc8266ads/Makefile delete mode 100644 board/freescale/mpc8266ads/flash.c delete mode 100644 board/freescale/mpc8266ads/mpc8266ads.c delete mode 100644 configs/MPC8266ADS_defconfig delete mode 100644 include/configs/MPC8266ADS.h
diff --git a/arch/powerpc/cpu/mpc8260/Kconfig b/arch/powerpc/cpu/mpc8260/Kconfig index 15742d9..d9dba83 100644 --- a/arch/powerpc/cpu/mpc8260/Kconfig +++ b/arch/powerpc/cpu/mpc8260/Kconfig @@ -34,9 +34,6 @@ config TARGET_PM826 config TARGET_PM828 bool "Support PM828"
-config TARGET_MPC8266ADS - bool "Support MPC8266ADS" - config TARGET_KM82XX bool "Support km82xx"
@@ -46,7 +43,6 @@ source "board/atc/Kconfig" source "board/cpu86/Kconfig" source "board/cpu87/Kconfig" source "board/ep82xxm/Kconfig" -source "board/freescale/mpc8266ads/Kconfig" source "board/gw8260/Kconfig" source "board/iphase4539/Kconfig" source "board/keymile/km82xx/Kconfig" diff --git a/arch/powerpc/cpu/mpc8260/pci.c b/arch/powerpc/cpu/mpc8260/pci.c index f7bb05d..079b6e6 100644 --- a/arch/powerpc/cpu/mpc8260/pci.c +++ b/arch/powerpc/cpu/mpc8260/pci.c @@ -22,7 +22,7 @@ #include <fdt_support.h> #endif
-#if defined CONFIG_MPC8266ADS || defined CONFIG_MPC8272 || defined CONFIG_PM826 +#if defined CONFIG_PM826 DECLARE_GLOBAL_DATA_PTR; #endif
@@ -236,34 +236,6 @@ void pci_mpc8250_init (struct pci_controller *hose) CONFIG_SYS_IMMR + PCI_CFG_DATA_REG);
/* - * Setting required to enable local bus for PCI (SIUMCR [LBPC]). - */ -#ifdef CONFIG_MPC8266ADS - immap->im_siu_conf.sc_siumcr = - (immap->im_siu_conf.sc_siumcr & ~SIUMCR_LBPC11) - | SIUMCR_LBPC01; -#elif defined CONFIG_MPC8272 - immap->im_siu_conf.sc_siumcr = (immap->im_siu_conf.sc_siumcr & - ~SIUMCR_BBD & - ~SIUMCR_ESE & - ~SIUMCR_PBSE & - ~SIUMCR_CDIS & - ~SIUMCR_DPPC11 & - ~SIUMCR_L2CPC11 & - ~SIUMCR_LBPC11 & - ~SIUMCR_APPC11 & - ~SIUMCR_CS10PC11 & - ~SIUMCR_BCTLC11 & - ~SIUMCR_MMR11) - | SIUMCR_DPPC11 - | SIUMCR_L2CPC01 - | SIUMCR_LBPC00 - | SIUMCR_APPC10 - | SIUMCR_CS10PC00 - | SIUMCR_BCTLC00 - | SIUMCR_MMR11; -#else - /* * Setting required to enable IRQ1-IRQ7 (SIUMCR [DPPC]), * and local bus for PCI (SIUMCR [LBPC]). */ @@ -274,7 +246,6 @@ void pci_mpc8250_init (struct pci_controller *hose) SIUMCR_LBPC01 | SIUMCR_CS10PC01 | SIUMCR_APPC10; -#endif
/* Make PCI lowest priority */ /* Each 4 bits is a device bus request and the MS 4bits @@ -304,24 +275,11 @@ void pci_mpc8250_init (struct pci_controller *hose) immap->im_memctl.memc_pcimsk0 = PCIMSK0_MASK; immap->im_memctl.memc_pcibr0 = PCI_MSTR0_LOCAL | PCIBR_ENABLE;
-#if defined CONFIG_MPC8266ADS || defined CONFIG_MPC8272 - immap->im_memctl.memc_pcimsk1 = PCIMSK1_MASK; - immap->im_memctl.memc_pcibr1 = PCI_MSTR1_LOCAL | PCIBR_ENABLE; -#endif - /* Release PCI RST (by default the PCI RST signal is held low) */ immap->im_pci.pci_gcr = cpu_to_le32 (PCIGCR_PCI_BUS_EN);
/* give it some time */ { -#if defined CONFIG_MPC8266ADS || defined CONFIG_MPC8272 - /* Give the PCI cards more time to initialize before query - This might be good for other boards also - */ - int i; - - for (i = 0; i < 1000; ++i) -#endif udelay (1000); }
@@ -358,11 +316,7 @@ void pci_mpc8250_init (struct pci_controller *hose) immap->im_pci.pci_picmr0 = cpu_to_le32 (PICMR0_MASK_ATTRIB); /* Size & attribute */
/* See above for description - puts PCI request as highest priority */ -#ifdef CONFIG_MPC8272 - immap->im_siu_conf.sc_ppc_alrh = 0x01236745; -#else immap->im_siu_conf.sc_ppc_alrh = 0x03124567; -#endif
/* Park the bus on the PCI */ immap->im_siu_conf.sc_ppc_acr = PPC_ACR_BUS_PARK_PCI; @@ -388,7 +342,7 @@ void pci_mpc8250_init (struct pci_controller *hose) hose->last_busno = 0xff;
/* System memory space */ -#if defined CONFIG_MPC8266ADS || defined CONFIG_MPC8272 || defined CONFIG_PM826 +#if defined CONFIG_PM826 pci_set_region (hose->regions + 0, PCI_SLV_MEM_BUS, PCI_SLV_MEM_LOCAL, @@ -401,17 +355,10 @@ void pci_mpc8250_init (struct pci_controller *hose) #endif
/* PCI memory space */ -#if defined CONFIG_MPC8266ADS || defined CONFIG_MPC8272 - pci_set_region (hose->regions + 1, - PCI_MSTR_MEMIO_BUS, - PCI_MSTR_MEMIO_LOCAL, - PCI_MSTR_MEMIO_SIZE, PCI_REGION_MEM); -#else pci_set_region (hose->regions + 1, PCI_MSTR_MEM_BUS, PCI_MSTR_MEM_LOCAL, PCI_MSTR_MEM_SIZE, PCI_REGION_MEM); -#endif
/* PCI I/O space */ pci_set_region (hose->regions + 2, diff --git a/board/freescale/mpc8266ads/Kconfig b/board/freescale/mpc8266ads/Kconfig deleted file mode 100644 index 78963b9..0000000 --- a/board/freescale/mpc8266ads/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_MPC8266ADS - -config SYS_BOARD - default "mpc8266ads" - -config SYS_VENDOR - default "freescale" - -config SYS_CONFIG_NAME - default "MPC8266ADS" - -endif diff --git a/board/freescale/mpc8266ads/MAINTAINERS b/board/freescale/mpc8266ads/MAINTAINERS deleted file mode 100644 index bdea02d..0000000 --- a/board/freescale/mpc8266ads/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -MPC8266ADS BOARD -M: Rune Torgersen runet@innovsys.com -S: Maintained -F: board/freescale/mpc8266ads/ -F: include/configs/MPC8266ADS.h -F: configs/MPC8266ADS_defconfig diff --git a/board/freescale/mpc8266ads/Makefile b/board/freescale/mpc8266ads/Makefile deleted file mode 100644 index ee63dc0..0000000 --- a/board/freescale/mpc8266ads/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2001-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y := mpc8266ads.o flash.o diff --git a/board/freescale/mpc8266ads/flash.c b/board/freescale/mpc8266ads/flash.c deleted file mode 100644 index ef28194..0000000 --- a/board/freescale/mpc8266ads/flash.c +++ /dev/null @@ -1,493 +0,0 @@ -/* - * (C) Copyright 2000, 2001 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * (C) Copyright 2001, Stuart Hughes, Lineo Inc, stuarth@lineo.com - * Add support the Sharp chips on the mpc8260ads. - * I started with board/ip860/flash.c and made changes I found in - * the MTD project by David Schleef. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> - - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH chips */ - -#if defined(CONFIG_ENV_IS_IN_FLASH) -# ifndef CONFIG_ENV_ADDR -# define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET) -# endif -# ifndef CONFIG_ENV_SIZE -# define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -# endif -# ifndef CONFIG_ENV_SECT_SIZE -# define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE -# endif -#endif - -/*----------------------------------------------------------------------- - * Functions - */ -static ulong flash_get_size (vu_long *addr, flash_info_t *info); -static int write_word (flash_info_t *info, ulong dest, ulong data); -static int clear_block_lock_bit(vu_long * addr); - -/*----------------------------------------------------------------------- - */ - -unsigned long flash_init (void) -{ -#ifndef CONFIG_MPC8266ADS - volatile immap_t *immap = (immap_t *)CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - volatile ip860_bcsr_t *bcsr = (ip860_bcsr_t *)BCSR_BASE; -#endif - unsigned long size; - int i; - - /* Init: enable write, - * or we cannot even write flash commands - */ -#ifndef CONFIG_MPC8266ADS - bcsr->bd_ctrl |= BD_CTRL_FLWE; -#endif - - - for (i=0; i<CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - - /* set the default sector offset */ - } - - /* Static FLASH Bank configuration here - FIXME XXX */ - - size = flash_get_size((vu_long *)FLASH_BASE, &flash_info[0]); - - if (flash_info[0].flash_id == FLASH_UNKNOWN) { - printf ("## Unknown FLASH on Bank 0 - Size = 0x%08lx = %ld MB\n", - size, size<<20); - } - -#ifndef CONFIG_MPC8266ADS - /* Remap FLASH according to real size */ - memctl->memc_or1 = CONFIG_SYS_OR_TIMING_FLASH | (-size & 0xFFFF8000); - memctl->memc_br1 = (CONFIG_SYS_FLASH_BASE & BR_BA_MSK) | - (memctl->memc_br1 & ~(BR_BA_MSK)); -#endif - /* Re-do sizing to get full correct info */ - size = flash_get_size((vu_long *)CONFIG_SYS_FLASH_BASE, &flash_info[0]); - - flash_info[0].size = size; - -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE - /* monitor protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE+monitor_flash_len-1, - &flash_info[0]); -#endif - -#ifdef CONFIG_ENV_IS_IN_FLASH - /* ENV protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR+CONFIG_ENV_SECT_SIZE-1, - &flash_info[0]); -#endif - return (size); -} - -/*----------------------------------------------------------------------- - */ -void flash_print_info (flash_info_t *info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_INTEL: printf ("Intel "); break; - case FLASH_MAN_SHARP: printf ("Sharp "); break; - default: printf ("Unknown Vendor "); break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_28F016SV: printf ("28F016SV (16 Mbit, 32 x 64k)\n"); - break; - case FLASH_28F160S3: printf ("28F160S3 (16 Mbit, 32 x 512K)\n"); - break; - case FLASH_28F320S3: printf ("28F320S3 (32 Mbit, 64 x 512K)\n"); - break; - case FLASH_LH28F016SCT: printf ("28F016SC (16 Mbit, 32 x 64K)\n"); - break; - default: printf ("Unknown Chip Type\n"); - break; - } - - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); - - printf (" Sector Start Addresses:"); - for (i=0; i<info->sector_count; ++i) { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", - info->start[i], - info->protect[i] ? " (RO)" : " " - ); - } - printf ("\n"); -} - -/*----------------------------------------------------------------------- - */ - - -/*----------------------------------------------------------------------- - */ - -/* - * The following code cannot be run from FLASH! - */ - -static ulong flash_get_size (vu_long *addr, flash_info_t *info) -{ - short i; - ulong value; - ulong base = (ulong)addr; - ulong sector_offset; - - /* Write "Intelligent Identifier" command: read Manufacturer ID */ - *addr = 0x90909090; - - value = addr[0] & 0x00FF00FF; - switch (value) { - case MT_MANUFACT: /* SHARP, MT or => Intel */ - case INTEL_ALT_MANU: - info->flash_id = FLASH_MAN_INTEL; - break; - default: - printf("unknown manufacturer: %x\n", (unsigned int)value); - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - return (0); /* no or unknown flash */ - } - - value = addr[1]; /* device ID */ - - switch (value) { - case (INTEL_ID_28F016S): - info->flash_id += FLASH_28F016SV; - info->sector_count = 32; - info->size = 0x00400000; - sector_offset = 0x20000; - break; /* => 2x2 MB */ - - case (INTEL_ID_28F160S3): - info->flash_id += FLASH_28F160S3; - info->sector_count = 32; - info->size = 0x00400000; - sector_offset = 0x20000; - break; /* => 2x2 MB */ - - case (INTEL_ID_28F320S3): - info->flash_id += FLASH_28F320S3; - info->sector_count = 64; - info->size = 0x00800000; - sector_offset = 0x20000; - break; /* => 2x4 MB */ - - case SHARP_ID_28F016SCL: - case SHARP_ID_28F016SCZ: - info->flash_id = FLASH_MAN_SHARP | FLASH_LH28F016SCT; - info->sector_count = 32; - info->size = 0x00800000; - sector_offset = 0x40000; - break; /* => 4x2 MB */ - - - default: - info->flash_id = FLASH_UNKNOWN; - return (0); /* => no or unknown flash */ - - } - - /* set up sector start address table */ - for (i = 0; i < info->sector_count; i++) { - info->start[i] = base; - base += sector_offset; - /* don't know how to check sector protection */ - info->protect[i] = 0; - } - - /* - * Prevent writes to uninitialized FLASH. - */ - if (info->flash_id != FLASH_UNKNOWN) { - addr = (vu_long *)info->start[0]; - - *addr = 0xFFFFFF; /* reset bank to read array mode */ - } - - return (info->size); -} - - -/*----------------------------------------------------------------------- - */ - -int flash_erase (flash_info_t *info, int s_first, int s_last) -{ - int flag, prot, sect; - ulong start, now, last; - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - if ( ((info->flash_id & FLASH_VENDMASK) != FLASH_MAN_INTEL) - && ((info->flash_id & FLASH_VENDMASK) != FLASH_MAN_SHARP) ) { - printf ("Can't erase unknown flash type %08lx - aborted\n", - info->flash_id); - return 1; - } - - prot = 0; - for (sect=s_first; sect<=s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - printf ("\n"); - } - - /* Make Sure Block Lock Bit is not set. */ - if(clear_block_lock_bit((vu_long *)(info->start[s_first]))){ - return 1; - } - - - /* Start erase on unprotected sectors */ - for (sect = s_first; sect<=s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - vu_long *addr = (vu_long *)(info->start[sect]); - - last = start = get_timer (0); - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - /* Reset Array */ - *addr = 0xffffffff; - /* Clear Status Register */ - *addr = 0x50505050; - /* Single Block Erase Command */ - *addr = 0x20202020; - /* Confirm */ - *addr = 0xD0D0D0D0; - - if((info->flash_id & FLASH_TYPEMASK) != FLASH_LH28F016SCT) { - /* Resume Command, as per errata update */ - *addr = 0xD0D0D0D0; - } - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - while ((*addr & 0x80808080) != 0x80808080) { - if(*addr & 0x20202020){ - printf("Error in Block Erase - Lock Bit may be set!\n"); - printf("Status Register = 0x%X\n", (uint)*addr); - *addr = 0xFFFFFFFF; /* reset bank */ - return 1; - } - if ((now=get_timer(start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - *addr = 0xFFFFFFFF; /* reset bank */ - return 1; - } - /* show that we're waiting */ - if ((now - last) > 1000) { /* every second */ - putc ('.'); - last = now; - } - } - - /* reset to read mode */ - *addr = 0xFFFFFFFF; - } - } - - printf (" done\n"); - return 0; -} - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ - -int write_buff (flash_info_t *info, uchar *src, ulong addr, ulong cnt) -{ - ulong cp, wp, data; - int i, l, rc; - - wp = (addr & ~3); /* get lower word aligned address */ - - /* - * handle unaligned start bytes - */ - if ((l = addr - wp) != 0) { - data = 0; - for (i=0, cp=wp; i<l; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - for (; i<4 && cnt>0; ++i) { - data = (data << 8) | *src++; - --cnt; - ++cp; - } - for (; cnt==0 && i<4; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - - if ((rc = write_word(info, wp, data)) != 0) { - return (rc); - } - wp += 4; - } - - /* - * handle word aligned part - */ - while (cnt >= 4) { - data = 0; - for (i=0; i<4; ++i) { - data = (data << 8) | *src++; - } - if ((rc = write_word(info, wp, data)) != 0) { - return (rc); - } - wp += 4; - cnt -= 4; - } - - if (cnt == 0) { - return (0); - } - - /* - * handle unaligned tail bytes - */ - data = 0; - for (i=0, cp=wp; i<4 && cnt>0; ++i, ++cp) { - data = (data << 8) | *src++; - --cnt; - } - for (; i<4; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - - return (write_word(info, wp, data)); -} - -/*----------------------------------------------------------------------- - * Write a word to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_word (flash_info_t *info, ulong dest, ulong data) -{ - vu_long *addr = (vu_long *)dest; - ulong start, csr; - int flag; - - /* Check if Flash is (sufficiently) erased */ - if ((*addr & data) != data) { - return (2); - } - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - /* Write Command */ - *addr = 0x10101010; - - /* Write Data */ - *addr = data; - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* data polling for D7 */ - start = get_timer (0); - flag = 0; - while (((csr = *addr) & 0x80808080) != 0x80808080) { - if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - flag = 1; - break; - } - } - if (csr & 0x40404040) { - printf ("CSR indicates write error (%08lx) at %08lx\n", csr, (ulong)addr); - flag = 1; - } - - /* Clear Status Registers Command */ - *addr = 0x50505050; - /* Reset to read array mode */ - *addr = 0xFFFFFFFF; - - return (flag); -} - -/*----------------------------------------------------------------------- - * Clear Block Lock Bit, returns: - * 0 - OK - * 1 - Timeout - */ - -static int clear_block_lock_bit(vu_long * addr) -{ - ulong start, now; - - /* Reset Array */ - *addr = 0xffffffff; - /* Clear Status Register */ - *addr = 0x50505050; - - *addr = 0x60606060; - *addr = 0xd0d0d0d0; - - start = get_timer (0); - while(*addr != 0x80808080){ - if ((now=get_timer(start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout on clearing Block Lock Bit\n"); - *addr = 0xFFFFFFFF; /* reset bank */ - return 1; - } - } - return 0; -} diff --git a/board/freescale/mpc8266ads/mpc8266ads.c b/board/freescale/mpc8266ads/mpc8266ads.c deleted file mode 100644 index 1eeec3f..0000000 --- a/board/freescale/mpc8266ads/mpc8266ads.c +++ /dev/null @@ -1,582 +0,0 @@ -/* - * (C) Copyright 2001-2011 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * Modified during 2001 by - * Advanced Communications Technologies (Australia) Pty. Ltd. - * Howard Walker, Tuong Vu-Dinh - * - * (C) Copyright 2001, Stuart Hughes, Lineo Inc, stuarth@lineo.com - * Added support for the 16M dram simm on the 8260ads boards - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <ioports.h> -#include <i2c.h> -#include <mpc8260.h> -#include <pci.h> - -/* - * PBI Page Based Interleaving - * PSDMR_PBI page based interleaving - * 0 bank based interleaving - * External Address Multiplexing (EAMUX) adds a clock to address cycles - * (this can help with marginal board layouts) - * PSDMR_EAMUX adds a clock - * 0 no extra clock - * Buffer Command (BUFCMD) adds a clock to command cycles. - * PSDMR_BUFCMD adds a clock - * 0 no extra clock - */ -#define CONFIG_PBI 0 -#define PESSIMISTIC_SDRAM 0 -#define EAMUX 0 /* EST requires EAMUX */ -#define BUFCMD 0 - - -/* - * I/O Port configuration table - * - * if conf is 1, then that port pin will be configured at boot time - * according to the five values podr/pdir/ppar/psor/pdat for that entry - */ - -const iop_conf_t iop_conf_tab[4][32] = { - - /* Port A configuration */ - { /* conf ppar psor pdir podr pdat */ - /* PA31 */ { 0, 1, 0, 1, 0, 0 }, /* FCC1 TxENB */ - /* PA30 */ { 0, 1, 0, 0, 0, 0 }, /* FCC1 TxClav */ - /* PA29 */ { 0, 1, 0, 1, 0, 0 }, /* FCC1 TxSOC */ - /* PA28 */ { 0, 1, 0, 1, 0, 0 }, /* FCC1 RxENB */ - /* PA27 */ { 0, 1, 0, 0, 0, 0 }, /* FCC1 RxSOC */ - /* PA26 */ { 0, 1, 0, 0, 0, 0 }, /* FCC1 RxClav */ - /* PA25 */ { 0, 1, 0, 1, 0, 0 }, /* FCC1 ATMTXD[0] */ - /* PA24 */ { 0, 1, 0, 1, 0, 0 }, /* FCC1 ATMTXD[1] */ - /* PA23 */ { 0, 1, 0, 1, 0, 0 }, /* FCC1 ATMTXD[2] */ - /* PA22 */ { 0, 1, 0, 1, 0, 0 }, /* FCC1 ATMTXD[3] */ - /* PA21 */ { 0, 1, 0, 1, 0, 0 }, /* FCC1 ATMTXD[4] */ - /* PA20 */ { 0, 1, 0, 1, 0, 0 }, /* FCC1 ATMTXD[5] */ - /* PA19 */ { 0, 1, 0, 1, 0, 0 }, /* FCC1 ATMTXD[6] */ - /* PA18 */ { 0, 1, 0, 1, 0, 0 }, /* FCC1 ATMTXD[7] */ - /* PA17 */ { 0, 1, 0, 0, 0, 0 }, /* FCC1 ATMRXD[7] */ - /* PA16 */ { 0, 1, 0, 0, 0, 0 }, /* FCC1 ATMRXD[6] */ - /* PA15 */ { 0, 1, 0, 0, 0, 0 }, /* FCC1 ATMRXD[5] */ - /* PA14 */ { 0, 1, 0, 0, 0, 0 }, /* FCC1 ATMRXD[4] */ - /* PA13 */ { 0, 1, 0, 0, 0, 0 }, /* FCC1 ATMRXD[3] */ - /* PA12 */ { 0, 1, 0, 0, 0, 0 }, /* FCC1 ATMRXD[2] */ - /* PA11 */ { 0, 1, 0, 0, 0, 0 }, /* FCC1 ATMRXD[1] */ - /* PA10 */ { 0, 1, 0, 0, 0, 0 }, /* FCC1 ATMRXD[0] */ - /* PA9 */ { 0, 1, 1, 1, 0, 0 }, /* FCC1 L1TXD */ - /* PA8 */ { 0, 1, 1, 0, 0, 0 }, /* FCC1 L1RXD */ - /* PA7 */ { 0, 0, 0, 1, 0, 0 }, /* PA7 */ - /* PA6 */ { 1, 1, 1, 1, 0, 0 }, /* TDM A1 L1RSYNC */ - /* PA5 */ { 0, 0, 0, 1, 0, 0 }, /* PA5 */ - /* PA4 */ { 0, 0, 0, 1, 0, 0 }, /* PA4 */ - /* PA3 */ { 0, 0, 0, 1, 0, 0 }, /* PA3 */ - /* PA2 */ { 0, 0, 0, 1, 0, 0 }, /* PA2 */ - /* PA1 */ { 1, 0, 0, 0, 0, 0 }, /* FREERUN */ - /* PA0 */ { 0, 0, 0, 1, 0, 0 } /* PA0 */ - }, - - /* Port B configuration */ - { /* conf ppar psor pdir podr pdat */ - /* PB31 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TX_ER */ - /* PB30 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_DV */ - /* PB29 */ { 1, 1, 1, 1, 0, 0 }, /* FCC2 MII TX_EN */ - /* PB28 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_ER */ - /* PB27 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII COL */ - /* PB26 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII CRS */ - /* PB25 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[3] */ - /* PB24 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[2] */ - /* PB23 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[1] */ - /* PB22 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[0] */ - /* PB21 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[0] */ - /* PB20 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[1] */ - /* PB19 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[2] */ - /* PB18 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[3] */ - /* PB17 */ { 0, 1, 0, 0, 0, 0 }, /* FCC3:RX_DIV */ - /* PB16 */ { 0, 1, 0, 0, 0, 0 }, /* FCC3:RX_ERR */ - /* PB15 */ { 0, 1, 0, 1, 0, 0 }, /* FCC3:TX_ERR */ - /* PB14 */ { 0, 1, 0, 1, 0, 0 }, /* FCC3:TX_EN */ - /* PB13 */ { 0, 1, 0, 0, 0, 0 }, /* FCC3:COL */ - /* PB12 */ { 0, 1, 0, 0, 0, 0 }, /* FCC3:CRS */ - /* PB11 */ { 0, 1, 0, 0, 0, 0 }, /* FCC3:RXD */ - /* PB10 */ { 0, 1, 0, 0, 0, 0 }, /* FCC3:RXD */ - /* PB9 */ { 0, 1, 0, 0, 0, 0 }, /* FCC3:RXD */ - /* PB8 */ { 0, 1, 0, 0, 0, 0 }, /* FCC3:RXD */ - /* PB7 */ { 0, 1, 0, 1, 0, 0 }, /* FCC3:TXD */ - /* PB6 */ { 0, 1, 0, 1, 0, 0 }, /* FCC3:TXD */ - /* PB5 */ { 0, 1, 0, 1, 0, 0 }, /* FCC3:TXD */ - /* PB4 */ { 0, 1, 0, 1, 0, 0 }, /* FCC3:TXD */ - /* PB3 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PB2 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PB1 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PB0 */ { 0, 0, 0, 0, 0, 0 } /* pin doesn't exist */ - }, - - /* Port C */ - { /* conf ppar psor pdir podr pdat */ - /* PC31 */ { 0, 0, 0, 1, 0, 0 }, /* PC31 */ - /* PC30 */ { 0, 0, 0, 1, 0, 0 }, /* PC30 */ - /* PC29 */ { 0, 1, 1, 0, 0, 0 }, /* SCC1 EN *CLSN */ - /* PC28 */ { 0, 0, 0, 1, 0, 0 }, /* PC28 */ - /* PC27 */ { 0, 0, 0, 1, 0, 0 }, /* UART Clock in */ - /* PC26 */ { 0, 0, 0, 1, 0, 0 }, /* PC26 */ - /* PC25 */ { 0, 0, 0, 1, 0, 0 }, /* PC25 */ - /* PC24 */ { 0, 0, 0, 1, 0, 0 }, /* PC24 */ - /* PC23 */ { 0, 1, 0, 1, 0, 0 }, /* ATMTFCLK */ - /* PC22 */ { 0, 1, 0, 0, 0, 0 }, /* ATMRFCLK */ - /* PC21 */ { 0, 1, 0, 0, 0, 0 }, /* SCC1 EN RXCLK */ - /* PC20 */ { 0, 1, 0, 0, 0, 0 }, /* SCC1 EN TXCLK */ - /* PC19 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_CLK CLK13 */ - /* PC18 */ { 1, 1, 0, 0, 0, 0 }, /* FCC Tx Clock (CLK14) */ - /* PC17 */ { 0, 0, 0, 1, 0, 0 }, /* PC17 */ - /* PC16 */ { 0, 1, 0, 0, 0, 0 }, /* FCC Tx Clock (CLK16) */ - /* PC15 */ { 0, 0, 0, 1, 0, 0 }, /* PC15 */ - /* PC14 */ { 0, 1, 0, 0, 0, 0 }, /* SCC1 EN *CD */ - /* PC13 */ { 0, 0, 0, 1, 0, 0 }, /* PC13 */ - /* PC12 */ { 0, 1, 0, 1, 0, 0 }, /* PC12 */ - /* PC11 */ { 0, 0, 0, 1, 0, 0 }, /* LXT971 transmit control */ - /* PC10 */ { 1, 0, 0, 1, 0, 0 }, /* LXT970 FETHMDC */ - /* PC9 */ { 1, 0, 0, 0, 0, 0 }, /* LXT970 FETHMDIO */ - /* PC8 */ { 0, 0, 0, 1, 0, 0 }, /* PC8 */ - /* PC7 */ { 0, 0, 0, 1, 0, 0 }, /* PC7 */ - /* PC6 */ { 0, 0, 0, 1, 0, 0 }, /* PC6 */ - /* PC5 */ { 0, 0, 0, 1, 0, 0 }, /* PC5 */ - /* PC4 */ { 0, 0, 0, 1, 0, 0 }, /* PC4 */ - /* PC3 */ { 0, 0, 0, 1, 0, 0 }, /* PC3 */ - /* PC2 */ { 0, 0, 0, 1, 0, 1 }, /* ENET FDE */ - /* PC1 */ { 0, 0, 0, 1, 0, 0 }, /* ENET DSQE */ - /* PC0 */ { 0, 0, 0, 1, 0, 0 }, /* ENET LBK */ - }, - - /* Port D */ - { /* conf ppar psor pdir podr pdat */ - /* PD31 */ { 1, 1, 0, 0, 0, 0 }, /* SCC1 EN RxD */ - /* PD30 */ { 1, 1, 1, 1, 0, 0 }, /* SCC1 EN TxD */ - /* PD29 */ { 0, 1, 0, 1, 0, 0 }, /* SCC1 EN TENA */ - /* PD28 */ { 0, 1, 0, 0, 0, 0 }, /* PD28 */ - /* PD27 */ { 0, 1, 1, 1, 0, 0 }, /* PD27 */ - /* PD26 */ { 0, 0, 0, 1, 0, 0 }, /* PD26 */ - /* PD25 */ { 0, 0, 0, 1, 0, 0 }, /* PD25 */ - /* PD24 */ { 0, 0, 0, 1, 0, 0 }, /* PD24 */ - /* PD23 */ { 0, 0, 0, 1, 0, 0 }, /* PD23 */ - /* PD22 */ { 0, 0, 0, 1, 0, 0 }, /* PD22 */ - /* PD21 */ { 0, 0, 0, 1, 0, 0 }, /* PD21 */ - /* PD20 */ { 0, 0, 0, 1, 0, 0 }, /* PD20 */ - /* PD19 */ { 0, 0, 0, 1, 0, 0 }, /* PD19 */ - /* PD18 */ { 0, 0, 0, 1, 0, 0 }, /* PD18 */ - /* PD17 */ { 0, 1, 0, 0, 0, 0 }, /* FCC1 ATMRXPRTY */ - /* PD16 */ { 0, 1, 0, 1, 0, 0 }, /* FCC1 ATMTXPRTY */ - /* PD15 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SDA */ - /* PD14 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SCL */ - /* PD13 */ { 0, 0, 0, 0, 0, 0 }, /* PD13 */ - /* PD12 */ { 0, 0, 0, 0, 0, 0 }, /* PD12 */ - /* PD11 */ { 0, 0, 0, 0, 0, 0 }, /* PD11 */ - /* PD10 */ { 0, 0, 0, 0, 0, 0 }, /* PD10 */ - /* PD9 */ { 1, 1, 0, 1, 0, 0 }, /* SMC1 TXD */ - /* PD8 */ { 1, 1, 0, 0, 0, 0 }, /* SMC1 RXD */ - /* PD7 */ { 0, 0, 0, 1, 0, 1 }, /* PD7 */ - /* PD6 */ { 0, 0, 0, 1, 0, 1 }, /* PD6 */ - /* PD5 */ { 0, 0, 0, 1, 0, 1 }, /* PD5 */ - /* PD4 */ { 0, 0, 0, 1, 0, 1 }, /* PD4 */ - /* PD3 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PD2 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PD1 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PD0 */ { 0, 0, 0, 0, 0, 0 } /* pin doesn't exist */ - } -}; - -typedef struct bscr_ { - unsigned long bcsr0; - unsigned long bcsr1; - unsigned long bcsr2; - unsigned long bcsr3; - unsigned long bcsr4; - unsigned long bcsr5; - unsigned long bcsr6; - unsigned long bcsr7; -} bcsr_t; - -typedef struct pci_ic_s { - unsigned long pci_int_stat; - unsigned long pci_int_mask; -} pci_ic_t; - -void reset_phy(void) -{ - volatile bcsr_t *bcsr = (bcsr_t *)CONFIG_SYS_BCSR; - - /* reset the FEC port */ - bcsr->bcsr1 &= ~FETH_RST; - bcsr->bcsr1 |= FETH_RST; -} - - -int board_early_init_f(void) -{ - volatile bcsr_t *bcsr = (bcsr_t *)CONFIG_SYS_BCSR; - volatile pci_ic_t *pci_ic = (pci_ic_t *)CONFIG_SYS_PCI_INT; - - bcsr->bcsr1 = ~FETHIEN & ~RS232EN_1 & ~RS232EN_2; - - /* mask all PCI interrupts */ - pci_ic->pci_int_mask |= 0xfff00000; - - return 0; -} - -int checkboard(void) -{ - puts("Board: Motorola MPC8266ADS\n"); - return 0; -} - -phys_size_t initdram(int board_type) -{ - /* Autoinit part stolen from board/sacsng/sacsng.c */ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8260_t *memctl = &immap->im_memctl; - volatile uchar c = 0xff; - volatile uchar *ramaddr = (uchar *) (CONFIG_SYS_SDRAM_BASE + 0x8); - uint psdmr = CONFIG_SYS_PSDMR; - int i; - - uint psrt = 0x21; /* for no SPD */ - uint chipselects = 1; /* for no SPD */ - uint sdram_size = CONFIG_SYS_SDRAM_SIZE * 1024 * 1024; /* for no SPD */ - uint or = CONFIG_SYS_OR2_PRELIM; /* for no SPD */ - uint data_width; - uint rows; - uint banks; - uint cols; - uint caslatency; - uint width; - uint rowst; - uint sdam; - uint bsma; - uint sda10; - u_char data; - u_char cksum; - int j; - - /* - * Keep the compiler from complaining about - * potentially uninitialized vars - */ - data_width = rows = banks = cols = caslatency = 0; - - /* - * Read the SDRAM SPD EEPROM via I2C. - */ - i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); - - i2c_read(SDRAM_SPD_ADDR, 0, 1, &data, 1); - cksum = data; - for (j = 1; j < 64; j++) { /* read only the checksummed bytes */ - /* note: the I2C address autoincrements when alen == 0 */ - i2c_read(SDRAM_SPD_ADDR, 0, 0, &data, 1); - /*printf("addr %d = 0x%02x\n", j, data); */ - if (j == 5) - chipselects = data & 0x0F; - else if (j == 6) - data_width = data; - else if (j == 7) - data_width |= data << 8; - else if (j == 3) - rows = data & 0x0F; - else if (j == 4) - cols = data & 0x0F; - else if (j == 12) { - /* - * Refresh rate: this assumes the prescaler is set to - * approximately 0.39uSec per tick and the target - * refresh period is about 85% of maximum. - */ - switch (data & 0x7F) { - default: - case 0: - psrt = 0x21; /* 15.625uS */ - break; - case 1: - psrt = 0x07; /* 3.9uS */ - break; - case 2: - psrt = 0x0F; /* 7.8uS */ - break; - case 3: - psrt = 0x43; /* 31.3uS */ - break; - case 4: - psrt = 0x87; /* 62.5uS */ - break; - case 5: - psrt = 0xFF; /* 125uS */ - break; - } - } else if (j == 17) - banks = data; - else if (j == 18) { - caslatency = 3; /* default CL */ -#if (PESSIMISTIC_SDRAM) - if ((data & 0x04) != 0) - caslatency = 3; - else if ((data & 0x02) != 0) - caslatency = 2; - else if ((data & 0x01) != 0) - caslatency = 1; -#else - if ((data & 0x01) != 0) - caslatency = 1; - else if ((data & 0x02) != 0) - caslatency = 2; - else if ((data & 0x04) != 0) - caslatency = 3; -#endif - else { - printf("WARNING: Unknown CAS latency 0x%02X, using 3\n", - data); - } - } else if (j == 63) { - if (data != cksum) { - printf("WARNING: Configuration data checksum failure:" - " is 0x%02x, calculated 0x%02x\n", - data, cksum); - } - } - cksum += data; - } - - /* We don't trust CL less than 2 (only saw it on an old 16MByte DIMM) */ - if (caslatency < 2) { - printf("CL was %d, forcing to 2\n", caslatency); - caslatency = 2; - } - if (rows > 14) { - printf("This doesn't look good, rows = %d, should be <= 14\n", - rows); - rows = 14; - } - if (cols > 11) { - printf("This doesn't look good, columns = %d, should be <= 11\n", - cols); - cols = 11; - } - - if ((data_width != 64) && (data_width != 72)) { - printf("WARNING: SDRAM width unsupported, is %d, expected 64 or 72.\n", - data_width); - } - width = 3; /* 2^3 = 8 bytes = 64 bits wide */ - /* - * Convert banks into log2(banks) - */ - if (banks == 2) - banks = 1; - else if (banks == 4) - banks = 2; - else if (banks == 8) - banks = 3; - - - sdram_size = 1 << (rows + cols + banks + width); - /* hack for high density memory (512MB per CS) */ - /* !!!!! Will ONLY work with Page Based Interleave !!!!! - ( PSDMR[PBI] = 1 ) - */ - /* - * memory actually has 11 column addresses, but the memory - * controller doesn't really care. - * - * the calculations that follow will however move the rows so - * that they are muxed one bit off if you use 11 bit columns. - * - * The solution is to tell the memory controller the correct - * size of the memory but change the number of columns to 10 - * afterwards. - * - * The 11th column addre will still be mucxed correctly onto - * the bus. - * - * Also be aware that the MPC8266ADS board Rev B has not - * connected Row address 13 to anything. - * - * The fix is to connect ADD16 (from U37-47) to SADDR12 (U28-126) - */ - if (cols > 10) - cols = 10; - -#if (CONFIG_PBI == 0) /* bank-based interleaving */ - rowst = ((32 - 6) - (rows + cols + width)) * 2; -#else - rowst = 32 - (rows + banks + cols + width); -#endif - - or = ~(sdram_size - 1) | /* SDAM address mask */ - ((banks - 1) << 13) | /* banks per device */ - (rowst << 9) | /* rowst */ - ((rows - 9) << 6); /* numr */ - - - /*printf("memctl->memc_or2 = 0x%08x\n", or); */ - - /* - * SDAM specifies the number of columns that are multiplexed - * (reference AN2165/D), defined to be (columns - 6) for page - * interleave, (columns - 8) for bank interleave. - * - * BSMA is 14 - max(rows, cols). The bank select lines come - * into play above the highest "address" line going into the - * the SDRAM. - */ -#if (CONFIG_PBI == 0) /* bank-based interleaving */ - sdam = cols - 8; - bsma = ((31 - width) - 14) - ((rows > cols) ? rows : cols); - sda10 = sdam + 2; -#else - sdam = cols + banks - 8; - bsma = ((31 - width) - 14) - ((rows > cols) ? rows : cols); - sda10 = sdam; -#endif -#if (PESSIMISTIC_SDRAM) - psdmr = (CONFIG_PBI | PSDMR_RFEN | PSDMR_RFRC_16_CLK | - PSDMR_PRETOACT_8W | PSDMR_ACTTORW_8W | PSDMR_WRC_4C | - PSDMR_EAMUX | PSDMR_BUFCMD) | caslatency | - ((caslatency - 1) << 6) | /* LDOTOPRE is CL - 1 */ - (sdam << 24) | (bsma << 21) | (sda10 << 18); -#else - psdmr = (CONFIG_PBI | PSDMR_RFEN | PSDMR_RFRC_7_CLK | - PSDMR_PRETOACT_3W | /* 1 for 7E parts (fast PC-133) */ - PSDMR_ACTTORW_2W | /* 1 for 7E parts (fast PC-133) */ - PSDMR_WRC_1C | /* 1 clock + 7nSec */ - EAMUX | BUFCMD) | caslatency | - ((caslatency - 1) << 6) | /* LDOTOPRE is CL - 1 */ - (sdam << 24) | (bsma << 21) | (sda10 << 18); -#endif - /*printf("psdmr = 0x%08x\n", psdmr); */ - - /* - * Quote from 8260 UM (10.4.2 SDRAM Power-On Initialization, 10-35): - * - * "At system reset, initialization software must set up the - * programmable parameters in the memory controller banks registers - * (ORx, BRx, P/LSDMR). After all memory parameters are configured, - * system software should execute the following initialization sequence - * for each SDRAM device. - * - * 1. Issue a PRECHARGE-ALL-BANKS command - * 2. Issue eight CBR REFRESH commands - * 3. Issue a MODE-SET command to initialize the mode register - * - * Quote from Micron MT48LC8M16A2 data sheet: - * - * "...the SDRAM requires a 100uS delay prior to issuing any - * command other than a COMMAND INHIBIT or NOP. Starting at some - * point during this 100uS period and continuing at least through - * the end of this period, COMMAND INHIBIT or NOP commands should - * be applied." - * - * "Once the 100uS delay has been satisfied with at least one COMMAND - * INHIBIT or NOP command having been applied, a /PRECHARGE command/ - * should be applied. All banks must then be precharged, thereby - * placing the device in the all banks idle state." - * - * "Once in the idle state, /two/ AUTO REFRESH cycles must be - * performed. After the AUTO REFRESH cycles are complete, the - * SDRAM is ready for mode register programming." - * - * (/emphasis/ mine, gvb) - * - * The way I interpret this, Micron start up sequence is: - * 1. Issue a PRECHARGE-BANK command (initial precharge) - * 2. Issue a PRECHARGE-ALL-BANKS command ("all banks ... precharged") - * 3. Issue two (presumably, doing eight is OK) CBR REFRESH commands - * 4. Issue a MODE-SET command to initialize the mode register - * - * -------- - * - * The initial commands are executed by setting P/LSDMR[OP] and - * accessing the SDRAM with a single-byte transaction." - * - * The appropriate BRx/ORx registers have already been set - * when we get here. The SDRAM can be accessed at the address - * CONFIG_SYS_SDRAM_BASE. - */ - - memctl->memc_mptpr = CONFIG_SYS_MPTPR; - memctl->memc_psrt = psrt; - - memctl->memc_br2 = CONFIG_SYS_BR2_PRELIM; - memctl->memc_or2 = or; - - memctl->memc_psdmr = psdmr | PSDMR_OP_PREA; - *ramaddr = c; - - memctl->memc_psdmr = psdmr | PSDMR_OP_CBRR; - for (i = 0; i < 8; i++) - *ramaddr = c; - - memctl->memc_psdmr = psdmr | PSDMR_OP_MRW; - *ramaddr = c; - - memctl->memc_psdmr = psdmr | PSDMR_OP_NORM | PSDMR_RFEN; - *ramaddr = c; - - /* - * Do it a second time for the second set of chips if the DIMM has - * two chip selects (double sided). - */ - if (chipselects > 1) { - ramaddr += sdram_size; - - memctl->memc_br3 = CONFIG_SYS_BR3_PRELIM + sdram_size; - memctl->memc_or3 = or; - - memctl->memc_psdmr = psdmr | PSDMR_OP_PREA; - *ramaddr = c; - - memctl->memc_psdmr = psdmr | PSDMR_OP_CBRR; - for (i = 0; i < 8; i++) - *ramaddr = c; - - memctl->memc_psdmr = psdmr | PSDMR_OP_MRW; - *ramaddr = c; - - memctl->memc_psdmr = psdmr | PSDMR_OP_NORM | PSDMR_RFEN; - *ramaddr = c; - } - - /* print info */ - printf("SDRAM configuration read from SPD\n"); - printf("\tSize per side = %dMB\n", sdram_size >> 20); - printf("\tOrganization: %d sides, %d banks, %d Columns, %d Rows, Data width = %d bits\n", - chipselects, 1 << (banks), cols, rows, data_width); - printf("\tRefresh rate = %d, CAS latency = %d", psrt, caslatency); -#if (CONFIG_PBI == 0) /* bank-based interleaving */ - printf(", Using Bank Based Interleave\n"); -#else - printf(", Using Page Based Interleave\n"); -#endif - printf("\tTotal size: "); - - /* this delay only needed for original 16MB DIMM... - * Not needed for any other memory configuration */ - if ((sdram_size * chipselects) == (16 * 1024 * 1024)) - udelay(250000); - - return sdram_size * chipselects; -} - -#ifdef CONFIG_PCI -struct pci_controller hose; - -extern void pci_mpc8250_init(struct pci_controller *); - -void pci_init_board(void) -{ - pci_mpc8250_init(&hose); -} -#endif diff --git a/configs/MPC8266ADS_defconfig b/configs/MPC8266ADS_defconfig deleted file mode 100644 index 485c842..0000000 --- a/configs/MPC8266ADS_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_MPC8266ADS=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 7e4eaef..d358d62 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,7 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +MPC8266ADS powerpc mpc8260 - - Rune Torgersen runet@innovsys.com VoVPN-GW powerpc mpc8260 - - ep8260 powerpc mpc8260 - - Frank Panno fpanno@delphintech.com ppmc8260 powerpc mpc8260 - - Brad Kemp Brad.Kemp@seranoa.com diff --git a/include/configs/MPC8266ADS.h b/include/configs/MPC8266ADS.h deleted file mode 100644 index 8d9c8fb..0000000 --- a/include/configs/MPC8266ADS.h +++ /dev/null @@ -1,563 +0,0 @@ -/* - * (C) Copyright 2001 - * Stuart Hughes stuarth@lineo.com - * This file is based on similar values for other boards found in other - * U-Boot config files, and some that I found in the mpc8260ads manual. - * - * Note: my board is a PILOT rev. - * Note: the mpc8260ads doesn't come with a proper Ethernet MAC address. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * Config header file for a MPC8266ADS Pilot 16M Ram Simm, 8Mbytes Flash Simm - */ - -/* !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! - !! !! - !! This configuration requires JP3 to be in position 1-2 to work !! - !! To make it work for the default, the CONFIG_SYS_TEXT_BASE define in !! - !! board/mpc8266ads/config.mk must be changed from 0xfe000000 to !! - !! 0xfff00000 !! - !! The CONFIG_SYS_HRCW_MASTER define below must also be changed to match !! - !! !! - !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC8266ADS 1 /* ...on motorola ADS board */ -#define CONFIG_CPM2 1 /* Has a CPM2 */ - -#define CONFIG_SYS_TEXT_BASE 0xfe000000 - -#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ -#define CONFIG_RESET_PHY_R 1 /* Call reset_phy() */ - -/* allow serial and ethaddr to be overwritten */ -#define CONFIG_ENV_OVERWRITE - -/* - * select serial console configuration - * - * if either CONFIG_CONS_ON_SMC or CONFIG_CONS_ON_SCC is selected, then - * CONFIG_CONS_INDEX must be set to the channel number (1-2 for SMC, 1-4 - * for SCC). - * - * if CONFIG_CONS_NONE is defined, then the serial console routines must - * defined elsewhere (for example, on the cogent platform, there are serial - * ports on the motherboard which are used for the serial console - see - * cogent/cma101/serial.[ch]). - */ -#undef CONFIG_CONS_ON_SMC /* define if console on SMC */ -#define CONFIG_CONS_ON_SCC /* define if console on SCC */ -#undef CONFIG_CONS_NONE /* define if console on something else */ -#define CONFIG_CONS_INDEX 1 /* which serial channel for console */ - -/* - * select ethernet configuration - * - * if either CONFIG_ETHER_ON_SCC or CONFIG_ETHER_ON_FCC is selected, then - * CONFIG_ETHER_INDEX must be set to the channel number (1-4 for SCC, 1-3 - * for FCC) - * - * if CONFIG_ETHER_NONE is defined, then either the ethernet routines must be - * defined elsewhere (as for the console), or CONFIG_CMD_NET must be unset. - */ -#undef CONFIG_ETHER_ON_SCC /* define if ether on SCC */ -#define CONFIG_ETHER_ON_FCC /* define if ether on FCC */ -#undef CONFIG_ETHER_NONE /* define if ether on something else */ -#define CONFIG_ETHER_INDEX 2 /* which channel for ether */ -#define CONFIG_MII /* MII PHY management */ -#define CONFIG_BITBANGMII /* bit-bang MII PHY management */ -/* - * Port pins used for bit-banged MII communictions (if applicable). - */ -#define MDIO_PORT 2 /* Port C */ -#define MDIO_DECLARE volatile ioport_t *iop = ioport_addr ( \ - (immap_t *) CONFIG_SYS_IMMR, MDIO_PORT ) -#define MDC_DECLARE MDIO_DECLARE - -#define MDIO_ACTIVE (iop->pdir |= 0x00400000) -#define MDIO_TRISTATE (iop->pdir &= ~0x00400000) -#define MDIO_READ ((iop->pdat & 0x00400000) != 0) - -#define MDIO(bit) if(bit) iop->pdat |= 0x00400000; \ - else iop->pdat &= ~0x00400000 - -#define MDC(bit) if(bit) iop->pdat |= 0x00200000; \ - else iop->pdat &= ~0x00200000 - -#define MIIDELAY udelay(1) - -#if (CONFIG_ETHER_INDEX == 2) - -/* - * - Rx-CLK is CLK13 - * - Tx-CLK is CLK14 - * - Select bus for bd/buffers (see 28-13) - * - Half duplex - */ -# define CONFIG_SYS_CMXFCR_MASK2 (CMXFCR_FC2 | CMXFCR_RF2CS_MSK | CMXFCR_TF2CS_MSK) -# define CONFIG_SYS_CMXFCR_VALUE2 (CMXFCR_RF2CS_CLK13 | CMXFCR_TF2CS_CLK14) -# define CONFIG_SYS_CPMFCR_RAMTYPE 0 -# define CONFIG_SYS_FCC_PSMR (FCC_PSMR_FDE | FCC_PSMR_LPB) - -#endif /* CONFIG_ETHER_INDEX */ - -/* other options */ -#define CONFIG_HARD_I2C 1 /* To enable I2C support */ -#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 - -/* PCI */ -#define CONFIG_PCI -#define CONFIG_PCI_INDIRECT_BRIDGE -#define CONFIG_PCI_PNP -#define CONFIG_PCI_BOOTDELAY 0 -#undef CONFIG_PCI_SCAN_SHOW - -/*----------------------------------------------------------------------- - * Definitions for Serial Presence Detect EEPROM address - * (to get SDRAM settings) - */ -#define SPD_EEPROM_ADDRESS 0x50 - -#define CONFIG_8260_CLKIN 66000000 /* in Hz */ -#define CONFIG_BAUDRATE 115200 - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -/* Commands we want, that are not part of default set */ -#define CONFIG_CMD_ASKENV /* ask for env variable */ -#define CONFIG_CMD_CACHE /* icache, dcache */ -#define CONFIG_CMD_DHCP /* DHCP Support */ -#define CONFIG_CMD_DIAG /* Diagnostics */ -#define CONFIG_CMD_IMMAP /* IMMR dump support */ -#define CONFIG_CMD_IRQ /* irqinfo */ -#define CONFIG_CMD_MII /* MII support */ -#define CONFIG_CMD_PCI /* pciinfo */ -#define CONFIG_CMD_PING /* ping support */ -#define CONFIG_CMD_PORTIO /* Port I/O */ -#define CONFIG_CMD_REGINFO /* Register dump */ -#define CONFIG_CMD_SAVES /* save S record dump */ -#define CONFIG_CMD_SDRAM /* SDRAM DIMM SPD info printout */ - -/* Commands from default set we don't need */ -#undef CONFIG_CMD_FPGA /* FPGA configuration Support */ -#undef CONFIG_CMD_SETGETDCR /* DCR support on 4xx */ - -/* Define a command string that is automatically executed when no character - * is read on the console interface withing "Boot Delay" after reset. - */ -#undef CONFIG_BOOT_ROOT_INITRD /* Use ram disk for the root file system */ -#define CONFIG_BOOT_ROOT_NFS /* Use a NFS mounted root file system */ - -#ifdef CONFIG_BOOT_ROOT_INITRD -#define CONFIG_BOOTCOMMAND \ - "version;" \ - "echo;" \ - "bootp;" \ - "setenv bootargs root=/dev/ram0 rw " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off;" \ - "bootm" -#endif /* CONFIG_BOOT_ROOT_INITRD */ - -#ifdef CONFIG_BOOT_ROOT_NFS -#define CONFIG_BOOTCOMMAND \ - "version;" \ - "echo;" \ - "bootp;" \ - "setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off;" \ - "bootm" -#endif /* CONFIG_BOOT_ROOT_NFS */ - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_DNS - -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ - -#if defined(CONFIG_CMD_KGDB) -#undef CONFIG_KGDB_ON_SMC /* define if kgdb on SMC */ -#define CONFIG_KGDB_ON_SCC /* define if kgdb on SCC */ -#undef CONFIG_KGDB_NONE /* define if kgdb on something else */ -#define CONFIG_KGDB_INDEX 2 /* which serial channel for kgdb */ -#define CONFIG_KGDB_BAUDRATE 115200 /* speed to run kgdb serial port at */ -#endif - -#undef CONFIG_WATCHDOG /* disable platform specific watchdog */ - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x00100000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x00f00000 /* 1 ... 15 MB in DRAM */ - -#undef CONFIG_CLOCKS_IN_MHZ /* clocks passsed to Linux in MHz */ - /* for versions < 2.4.5-pre5 */ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 } - -#define CONFIG_SYS_FLASH_BASE 0xFE000000 -#define FLASH_BASE 0xFE000000 -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max num of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 32 /* max num of sects on one chip */ -#define CONFIG_SYS_FLASH_SIZE 8 -#define CONFIG_SYS_FLASH_ERASE_TOUT 8000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 5 /* Timeout for Flash Write (in ms) */ - -#undef CONFIG_SYS_FLASH_CHECKSUM - -/* this is stuff came out of the Motorola docs */ -/* Only change this if you also change the Hardware configuration Word */ -#define CONFIG_SYS_DEFAULT_IMMR 0x0F010000 - -/* Set IMMR to 0xF0000000 or above to boot Linux */ -#define CONFIG_SYS_IMMR 0xF0000000 -#define CONFIG_SYS_BCSR 0xF8000000 -#define CONFIG_SYS_PCI_INT 0xF8200000 /* PCI interrupt controller */ - -/* Define CONFIG_VERY_BIG_RAM to allow use of SDRAMs larger than 256MBytes - */ -/*#define CONFIG_VERY_BIG_RAM 1*/ - -/* What should be the base address of SDRAM DIMM and how big is - * it (in Mbytes)? This will normally auto-configure via the SPD. -*/ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_SDRAM_SIZE 16 - -#define SDRAM_SPD_ADDR 0x50 - -/*----------------------------------------------------------------------- - * BR2,BR3 - Base Register - * Ref: Section 10.3.1 on page 10-14 - * OR2,OR3 - Option Register - * Ref: Section 10.3.2 on page 10-16 - *----------------------------------------------------------------------- - */ - -/* Bank 2,3 - SDRAM DIMM - */ - -/* The BR2 is configured as follows: - * - * - Base address of 0x00000000 - * - 64 bit port size (60x bus only) - * - Data errors checking is disabled - * - Read and write access - * - SDRAM 60x bus - * - Access are handled by the memory controller according to MSEL - * - Not used for atomic operations - * - No data pipelining is done - * - Valid - */ -#define CONFIG_SYS_BR2_PRELIM ((CONFIG_SYS_SDRAM_BASE & BRx_BA_MSK) |\ - BRx_PS_64 |\ - BRx_MS_SDRAM_P |\ - BRx_V) - -#define CONFIG_SYS_BR3_PRELIM ((CONFIG_SYS_SDRAM_BASE & BRx_BA_MSK) |\ - BRx_PS_64 |\ - BRx_MS_SDRAM_P |\ - BRx_V) - -/* With a 64 MB DIMM, the OR2 is configured as follows: - * - * - 64 MB - * - 4 internal banks per device - * - Row start address bit is A8 with PSDMR[PBI] = 0 - * - 12 row address lines - * - Back-to-back page mode - * - Internal bank interleaving within save device enabled - */ -#if (CONFIG_SYS_SDRAM_SIZE == 64) -#define CONFIG_SYS_OR2_PRELIM (MEG_TO_AM(CONFIG_SYS_SDRAM_SIZE) |\ - ORxS_BPD_4 |\ - ORxS_ROWST_PBI0_A8 |\ - ORxS_NUMR_12) -#elif (CONFIG_SYS_SDRAM_SIZE == 16) -#define CONFIG_SYS_OR2_PRELIM (0xFF000C80) -#else -#error "INVALID SDRAM CONFIGURATION" -#endif - -/*----------------------------------------------------------------------- - * PSDMR - 60x Bus SDRAM Mode Register - * Ref: Section 10.3.3 on page 10-21 - *----------------------------------------------------------------------- - */ - -#if (CONFIG_SYS_SDRAM_SIZE == 64) -/* With a 64 MB DIMM, the PSDMR is configured as follows: - * - * - Bank Based Interleaving, - * - Refresh Enable, - * - Address Multiplexing where A5 is output on A14 pin - * (A6 on A15, and so on), - * - use address pins A14-A16 as bank select, - * - A9 is output on SDA10 during an ACTIVATE command, - * - earliest timing for ACTIVATE command after REFRESH command is 7 clocks, - * - earliest timing for ACTIVATE or REFRESH command after PRECHARGE command - * is 3 clocks, - * - earliest timing for READ/WRITE command after ACTIVATE command is - * 2 clocks, - * - earliest timing for PRECHARGE after last data was read is 1 clock, - * - earliest timing for PRECHARGE after last data was written is 1 clock, - * - CAS Latency is 2. - */ -#define CONFIG_SYS_PSDMR (PSDMR_RFEN |\ - PSDMR_SDAM_A14_IS_A5 |\ - PSDMR_BSMA_A14_A16 |\ - PSDMR_SDA10_PBI0_A9 |\ - PSDMR_RFRC_7_CLK |\ - PSDMR_PRETOACT_3W |\ - PSDMR_ACTTORW_2W |\ - PSDMR_LDOTOPRE_1C |\ - PSDMR_WRC_1C |\ - PSDMR_CL_2) -#elif (CONFIG_SYS_SDRAM_SIZE == 16) -/* With a 16 MB DIMM, the PSDMR is configured as follows: - * - * configuration parameters found in Motorola documentation - */ -#define CONFIG_SYS_PSDMR (0x016EB452) -#else -#error "INVALID SDRAM CONFIGURATION" -#endif - -#define RS232EN_1 0x02000002 -#define RS232EN_2 0x01000001 -#define FETHIEN 0x08000008 -#define FETH_RST 0x04000004 - -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/* Use this HRCW for booting from address 0xfe00000 (JP3 in setting 1-2) */ -/* 0x0EB2B645 */ -#define CONFIG_SYS_HRCW_MASTER (( HRCW_BPS11 | HRCW_CIP ) |\ - ( HRCW_L2CPC10 | HRCW_DPPC11 | HRCW_ISB010 ) |\ - ( HRCW_BMS | HRCW_MMR11 | HRCW_LBPC01 | HRCW_APPC10 ) |\ - ( HRCW_CS10PC01 | HRCW_MODCK_H0101 ) \ - ) - -/* Use this HRCW for booting from address 0xfff0000 (JP3 in setting 2-3) */ -/* #define CONFIG_SYS_HRCW_MASTER 0x0cb23645 */ - -/* This value should actually be situated in the first 256 bytes of the FLASH - which on the standard MPC8266ADS board is at address 0xFF800000 - The linker script places it at 0xFFF00000 instead. - - It still works, however, as long as the ADS board jumper JP3 is set to - position 2-3 so the board is using the BCSR as Hardware Configuration Word - - If you want to use the one defined here instead, ust copy the first 256 bytes from - 0xfff00000 to 0xff800000 (for 8MB flash) - - - Rune - -*/ - -/* no slaves */ -#define CONFIG_SYS_HRCW_SLAVE1 0 -#define CONFIG_SYS_HRCW_SLAVE2 0 -#define CONFIG_SYS_HRCW_SLAVE3 0 -#define CONFIG_SYS_HRCW_SLAVE4 0 -#define CONFIG_SYS_HRCW_SLAVE5 0 -#define CONFIG_SYS_HRCW_SLAVE6 0 -#define CONFIG_SYS_HRCW_SLAVE7 0 - -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE - -#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) -# define CONFIG_SYS_RAMBOOT -#endif - -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -#ifndef CONFIG_SYS_RAMBOOT -# define CONFIG_ENV_IS_IN_FLASH 1 -# define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + 0x40000) -# define CONFIG_ENV_SECT_SIZE 0x40000 -#else -# define CONFIG_ENV_IS_IN_NVRAM 1 -# define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) -# define CONFIG_ENV_SIZE 0x200 -#endif /* CONFIG_SYS_RAMBOOT */ - -#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC8260 CPU */ -#if defined(CONFIG_CMD_KGDB) -# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * HIDx - Hardware Implementation-dependent Registers 2-11 - *----------------------------------------------------------------------- - * HID0 also contains cache control - initially enable both caches and - * invalidate contents, then the final state leaves only the instruction - * cache enabled. Note that Power-On and Hard reset invalidate the caches, - * but Soft reset does not. - * - * HID1 has only read-only information - nothing to set. - */ -/*#define CONFIG_SYS_HID0_INIT 0 */ -#define CONFIG_SYS_HID0_INIT (HID0_ICE |\ - HID0_DCE |\ - HID0_ICFI |\ - HID0_DCI |\ - HID0_IFEM |\ - HID0_ABE) - -#define CONFIG_SYS_HID0_FINAL (HID0_ICE | HID0_IFEM | HID0_ABE ) - -#define CONFIG_SYS_HID2 0 - -#define CONFIG_SYS_SYPCR 0xFFFFFFC3 -#define CONFIG_SYS_BCR 0x004C0000 -#define CONFIG_SYS_SIUMCR 0x4E64C000 -#define CONFIG_SYS_SCCR 0x00000000 - -/* local bus memory map - * - * 0x00000000-0x03FFFFFF 64MB SDRAM - * 0x80000000-0x9FFFFFFF 512MB outbound prefetchable PCI memory window - * 0xA0000000-0xBFFFFFFF 512MB outbound non-prefetchable PCI memory window - * 0xF0000000-0xF001FFFF 128KB MPC8266 internal memory - * 0xF4000000-0xF7FFFFFF 64MB outbound PCI I/O window - * 0xF8000000-0xF8007FFF 32KB BCSR - * 0xF8100000-0xF8107FFF 32KB ATM UNI - * 0xF8200000-0xF8207FFF 32KB PCI interrupt controller - * 0xF8300000-0xF8307FFF 32KB EEPROM - * 0xFE000000-0xFFFFFFFF 32MB flash - */ -#define CONFIG_SYS_BR0_PRELIM 0xFE001801 /* flash */ -#define CONFIG_SYS_OR0_PRELIM 0xFE000836 -#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR | 0x1801) /* BCSR */ -#define CONFIG_SYS_OR1_PRELIM 0xFFFF8010 -#define CONFIG_SYS_BR4_PRELIM 0xF8300801 /* EEPROM */ -#define CONFIG_SYS_OR4_PRELIM 0xFFFF8846 -#define CONFIG_SYS_BR5_PRELIM 0xF8100801 /* PM5350 ATM UNI */ -#define CONFIG_SYS_OR5_PRELIM 0xFFFF8E36 -#define CONFIG_SYS_BR8_PRELIM (CONFIG_SYS_PCI_INT | 0x1801) /* PCI interrupt controller */ -#define CONFIG_SYS_OR8_PRELIM 0xFFFF8010 - -#define CONFIG_SYS_RMR 0x0001 -#define CONFIG_SYS_TMCNTSC (TMCNTSC_SEC|TMCNTSC_ALR|TMCNTSC_TCF|TMCNTSC_TCE) -#define CONFIG_SYS_PISCR (PISCR_PS|PISCR_PTF|PISCR_PTE) -#define CONFIG_SYS_RCCR 0 -#define CONFIG_SYS_MPTPR 0x00001900 -#define CONFIG_SYS_PSRT 0x00000021 - -/* This address must not exist */ -#define CONFIG_SYS_RESET_ADDRESS 0xFCFFFF00 - -/* PCI Memory map (if different from default map */ -#define CONFIG_SYS_PCI_SLV_MEM_LOCAL CONFIG_SYS_SDRAM_BASE /* Local base */ -#define CONFIG_SYS_PCI_SLV_MEM_BUS 0x00000000 /* PCI base */ -#define CONFIG_SYS_PICMR0_MASK_ATTRIB (PICMR_MASK_512MB | PICMR_ENABLE | \ - PICMR_PREFETCH_EN) - -/* - * These are the windows that allow the CPU to access PCI address space. - * All three PCI master windows, which allow the CPU to access PCI - * prefetch, non prefetch, and IO space (see below), must all fit within - * these windows. - */ - -/* PCIBR0 */ -#define CONFIG_SYS_PCI_MSTR0_LOCAL 0x80000000 /* Local base */ -#define CONFIG_SYS_PCIMSK0_MASK PCIMSK_1GB /* Size of window */ -/* PCIBR1 */ -#define CONFIG_SYS_PCI_MSTR1_LOCAL 0xF4000000 /* Local base */ -#define CONFIG_SYS_PCIMSK1_MASK PCIMSK_64MB /* Size of window */ - -/* - * Master window that allows the CPU to access PCI Memory (prefetch). - * This window will be setup with the first set of Outbound ATU registers - * in the bridge. - */ - -#define CONFIG_SYS_PCI_MSTR_MEM_LOCAL 0x80000000 /* Local base */ -#define CONFIG_SYS_PCI_MSTR_MEM_BUS 0x80000000 /* PCI base */ -#define CONFIG_SYS_CPU_PCI_MEM_START PCI_MSTR_MEM_LOCAL -#define CONFIG_SYS_PCI_MSTR_MEM_SIZE 0x20000000 /* 512MB */ -#define CONFIG_SYS_POCMR0_MASK_ATTRIB (POCMR_MASK_512MB | POCMR_ENABLE | POCMR_PREFETCH_EN) - -/* - * Master window that allows the CPU to access PCI Memory (non-prefetch). - * This window will be setup with the second set of Outbound ATU registers - * in the bridge. - */ - -#define CONFIG_SYS_PCI_MSTR_MEMIO_LOCAL 0xA0000000 /* Local base */ -#define CONFIG_SYS_PCI_MSTR_MEMIO_BUS 0xA0000000 /* PCI base */ -#define CONFIG_SYS_CPU_PCI_MEMIO_START PCI_MSTR_MEMIO_LOCAL -#define CONFIG_SYS_PCI_MSTR_MEMIO_SIZE 0x20000000 /* 512MB */ -#define CONFIG_SYS_POCMR1_MASK_ATTRIB (POCMR_MASK_512MB | POCMR_ENABLE) - -/* - * Master window that allows the CPU to access PCI IO space. - * This window will be setup with the third set of Outbound ATU registers - * in the bridge. - */ - -#define CONFIG_SYS_PCI_MSTR_IO_LOCAL 0xF4000000 /* Local base */ -#define CONFIG_SYS_PCI_MSTR_IO_BUS 0xF4000000 /* PCI base */ -#define CONFIG_SYS_CPU_PCI_IO_START PCI_MSTR_IO_LOCAL -#define CONFIG_SYS_PCI_MSTR_IO_SIZE 0x04000000 /* 64MB */ -#define CONFIG_SYS_POCMR2_MASK_ATTRIB (POCMR_MASK_64MB | POCMR_ENABLE | POCMR_PCI_IO) - -/* - * JFFS2 partitions - * - */ -/* No command line, one static partition, whole device */ -#undef CONFIG_CMD_MTDPARTS -#define CONFIG_JFFS2_DEV "nor0" -#define CONFIG_JFFS2_PART_SIZE 0xFFFFFFFF -#define CONFIG_JFFS2_PART_OFFSET 0x00000000 - -/* mtdparts command line support */ -/* -#define CONFIG_CMD_MTDPARTS -#define MTDIDS_DEFAULT "" -#define MTDPARTS_DEFAULT "" -*/ - -#endif /* __CONFIG_H */
On Mon, Dec 15, 2014 at 11:26:23PM +0900, Masahiro Yamada wrote:
This board is still a non-generic board.
These boards are still non-generic boards.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Wolfgang Denk wd@denx.de ---
arch/powerpc/cpu/mpc8260/Kconfig | 8 - arch/powerpc/cpu/mpc8260/pci.c | 11 - board/pm826/Kconfig | 9 - board/pm826/MAINTAINERS | 13 - board/pm826/Makefile | 8 - board/pm826/flash.c | 370 --------------------- board/pm826/pm826.c | 319 ------------------ board/pm828/Kconfig | 9 - board/pm828/MAINTAINERS | 9 - board/pm828/Makefile | 8 - board/pm828/flash.c | 370 --------------------- board/pm828/pm828.c | 352 -------------------- configs/PM825_BIGFLASH_defconfig | 4 - configs/PM825_ROMBOOT_BIGFLASH_defconfig | 4 - configs/PM825_ROMBOOT_defconfig | 4 - configs/PM825_defconfig | 4 - configs/PM826_BIGFLASH_defconfig | 4 - configs/PM826_ROMBOOT_BIGFLASH_defconfig | 4 - configs/PM826_ROMBOOT_defconfig | 4 - configs/PM826_defconfig | 4 - configs/PM828_PCI_defconfig | 4 - configs/PM828_ROMBOOT_PCI_defconfig | 4 - configs/PM828_ROMBOOT_defconfig | 4 - configs/PM828_defconfig | 3 - doc/README.scrapyard | 3 + include/configs/PM826.h | 534 ------------------------------- include/configs/PM828.h | 528 ------------------------------ 27 files changed, 3 insertions(+), 2595 deletions(-) delete mode 100644 board/pm826/Kconfig delete mode 100644 board/pm826/MAINTAINERS delete mode 100644 board/pm826/Makefile delete mode 100644 board/pm826/flash.c delete mode 100644 board/pm826/pm826.c delete mode 100644 board/pm828/Kconfig delete mode 100644 board/pm828/MAINTAINERS delete mode 100644 board/pm828/Makefile delete mode 100644 board/pm828/flash.c delete mode 100644 board/pm828/pm828.c delete mode 100644 configs/PM825_BIGFLASH_defconfig delete mode 100644 configs/PM825_ROMBOOT_BIGFLASH_defconfig delete mode 100644 configs/PM825_ROMBOOT_defconfig delete mode 100644 configs/PM825_defconfig delete mode 100644 configs/PM826_BIGFLASH_defconfig delete mode 100644 configs/PM826_ROMBOOT_BIGFLASH_defconfig delete mode 100644 configs/PM826_ROMBOOT_defconfig delete mode 100644 configs/PM826_defconfig delete mode 100644 configs/PM828_PCI_defconfig delete mode 100644 configs/PM828_ROMBOOT_PCI_defconfig delete mode 100644 configs/PM828_ROMBOOT_defconfig delete mode 100644 configs/PM828_defconfig delete mode 100644 include/configs/PM826.h delete mode 100644 include/configs/PM828.h
diff --git a/arch/powerpc/cpu/mpc8260/Kconfig b/arch/powerpc/cpu/mpc8260/Kconfig index d9dba83..cb81cdc 100644 --- a/arch/powerpc/cpu/mpc8260/Kconfig +++ b/arch/powerpc/cpu/mpc8260/Kconfig @@ -28,12 +28,6 @@ config TARGET_IPHASE4539 config TARGET_MUAS3001 bool "Support muas3001"
-config TARGET_PM826 - bool "Support PM826" - -config TARGET_PM828 - bool "Support PM828" - config TARGET_KM82XX bool "Support km82xx"
@@ -47,7 +41,5 @@ source "board/gw8260/Kconfig" source "board/iphase4539/Kconfig" source "board/keymile/km82xx/Kconfig" source "board/muas3001/Kconfig" -source "board/pm826/Kconfig" -source "board/pm828/Kconfig"
endmenu diff --git a/arch/powerpc/cpu/mpc8260/pci.c b/arch/powerpc/cpu/mpc8260/pci.c index 079b6e6..56f290c 100644 --- a/arch/powerpc/cpu/mpc8260/pci.c +++ b/arch/powerpc/cpu/mpc8260/pci.c @@ -22,10 +22,6 @@ #include <fdt_support.h> #endif
-#if defined CONFIG_PM826 -DECLARE_GLOBAL_DATA_PTR; -#endif - /* * Local->PCI map (from CPU) controlled by * MPC826x master window @@ -342,17 +338,10 @@ void pci_mpc8250_init (struct pci_controller *hose) hose->last_busno = 0xff;
/* System memory space */ -#if defined CONFIG_PM826 - pci_set_region (hose->regions + 0, - PCI_SLV_MEM_BUS, - PCI_SLV_MEM_LOCAL, - gd->ram_size, PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); -#else pci_set_region (hose->regions + 0, CONFIG_SYS_SDRAM_BASE, CONFIG_SYS_SDRAM_BASE, 0x4000000, PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); -#endif
/* PCI memory space */ pci_set_region (hose->regions + 1, diff --git a/board/pm826/Kconfig b/board/pm826/Kconfig deleted file mode 100644 index dd11b7a..0000000 --- a/board/pm826/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_PM826 - -config SYS_BOARD - default "pm826" - -config SYS_CONFIG_NAME - default "PM826" - -endif diff --git a/board/pm826/MAINTAINERS b/board/pm826/MAINTAINERS deleted file mode 100644 index 41df4c9..0000000 --- a/board/pm826/MAINTAINERS +++ /dev/null @@ -1,13 +0,0 @@ -PM826 BOARD -M: Wolfgang Denk wd@denx.de -S: Maintained -F: board/pm826/ -F: include/configs/PM826.h -F: configs/PM825_defconfig -F: configs/PM825_BIGFLASH_defconfig -F: configs/PM825_ROMBOOT_defconfig -F: configs/PM825_ROMBOOT_BIGFLASH_defconfig -F: configs/PM826_defconfig -F: configs/PM826_BIGFLASH_defconfig -F: configs/PM826_ROMBOOT_defconfig -F: configs/PM826_ROMBOOT_BIGFLASH_defconfig diff --git a/board/pm826/Makefile b/board/pm826/Makefile deleted file mode 100644 index c515f81..0000000 --- a/board/pm826/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2001-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = pm826.o flash.o diff --git a/board/pm826/flash.c b/board/pm826/flash.c deleted file mode 100644 index 786a29b..0000000 --- a/board/pm826/flash.c +++ /dev/null @@ -1,370 +0,0 @@ -/* - * (C) Copyright 2001, 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * Flash Routines for Intel devices - * - *-------------------------------------------------------------------- - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc8xx.h> - - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; - -/*----------------------------------------------------------------------- - */ -ulong flash_get_size (volatile unsigned long *baseaddr, - flash_info_t * info) -{ - short i; - unsigned long flashtest_h, flashtest_l; - - info->sector_count = info->size = 0; - info->flash_id = FLASH_UNKNOWN; - - /* Write query command sequence and test FLASH answer - */ - baseaddr[0] = 0x00980098; - baseaddr[1] = 0x00980098; - - flashtest_h = baseaddr[0]; /* manufacturer ID */ - flashtest_l = baseaddr[1]; - - if (flashtest_h != INTEL_MANUFACT || flashtest_l != INTEL_MANUFACT) - return (0); /* no or unknown flash */ - - flashtest_h = baseaddr[2]; /* device ID */ - flashtest_l = baseaddr[3]; - - if (flashtest_h != flashtest_l) - return (0); - - switch (flashtest_h) { - case INTEL_ID_28F160C3B: - info->flash_id = FLASH_28F160C3B; - info->sector_count = 39; - info->size = 0x00800000; /* 4 * 2 MB = 8 MB */ - break; - case INTEL_ID_28F160F3B: - info->flash_id = FLASH_28F160F3B; - info->sector_count = 39; - info->size = 0x00800000; /* 4 * 2 MB = 8 MB */ - break; - case INTEL_ID_28F640C3B: - info->flash_id = FLASH_28F640C3B; - info->sector_count = 135; - info->size = 0x02000000; /* 16 * 2 MB = 32 MB */ - break; - default: - return (0); /* no or unknown flash */ - } - - info->flash_id |= INTEL_MANUFACT << 16; /* set manufacturer offset */ - - if (info->flash_id & FLASH_BTYPE) { - volatile unsigned long *tmp = baseaddr; - - /* set up sector start adress table (bottom sector type) - * AND unlock the sectors (if our chip is 160C3 or 640C3) - */ - for (i = 0; i < info->sector_count; i++) { - if (((info->flash_id & FLASH_TYPEMASK) == FLASH_28F160C3B) || - ((info->flash_id & FLASH_TYPEMASK) == FLASH_28F640C3B)) { - tmp[0] = 0x00600060; - tmp[1] = 0x00600060; - tmp[0] = 0x00D000D0; - tmp[1] = 0x00D000D0; - } - info->start[i] = (uint) tmp; - tmp += i < 8 ? 0x2000 : 0x10000; /* pointer arith */ - } - } - - memset (info->protect, 0, info->sector_count); - - baseaddr[0] = 0x00FF00FF; - baseaddr[1] = 0x00FF00FF; - - return (info->size); -} - -/*----------------------------------------------------------------------- - */ -unsigned long flash_init (void) -{ - unsigned long size_b0 = 0; - int i; - - /* Init: no FLASHes known - */ - for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - } - - /* Static FLASH Bank configuration here (only one bank) */ - - size_b0 = flash_get_size ((ulong *) CONFIG_SYS_FLASH0_BASE, &flash_info[0]); - if (flash_info[0].flash_id == FLASH_UNKNOWN || size_b0 == 0) { - printf ("## Unknown FLASH on Bank 0 - Size = 0x%08lx = %ld MB\n", - size_b0, size_b0 >> 20); - } - - /* protect monitor and environment sectors - */ - -#ifndef CONFIG_BOOT_ROM - /* If U-Boot is booted from ROM the CONFIG_SYS_MONITOR_BASE > CONFIG_SYS_FLASH0_BASE - * but we shouldn't protect it. - */ - -# if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH0_BASE - flash_protect (FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE + monitor_flash_len - 1, &flash_info[0] - ); -# endif -#endif /* CONFIG_BOOT_ROM */ - -#if defined(CONFIG_ENV_IS_IN_FLASH) && defined(CONFIG_ENV_ADDR) -# ifndef CONFIG_ENV_SIZE -# define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -# endif - flash_protect (FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR + CONFIG_ENV_SIZE - 1, &flash_info[0]); -#endif - - return (size_b0); -} - -/*----------------------------------------------------------------------- - */ -void flash_print_info (flash_info_t * info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch ((info->flash_id >> 16) & 0xff) { - case 0x89: - printf ("INTEL "); - break; - default: - printf ("Unknown Vendor "); - break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_28F160C3B: - printf ("28F160C3B (16 M, bottom sector)\n"); - break; - case FLASH_28F160F3B: - printf ("28F160F3B (16 M, bottom sector)\n"); - break; - case FLASH_28F640C3B: - printf ("28F640C3B (64 M, bottom sector)\n"); - break; - default: - printf ("Unknown Chip Type\n"); - break; - } - - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); - - printf (" Sector Start Addresses:"); - for (i = 0; i < info->sector_count; ++i) { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", - info->start[i], - info->protect[i] ? " (RO)" : " " - ); - } - printf ("\n"); -} - -/*----------------------------------------------------------------------- - */ -int flash_erase (flash_info_t * info, int s_first, int s_last) -{ - int flag, prot, sect; - ulong start, now, last; - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - prot = 0; - for (sect = s_first; sect <= s_last; sect++) { - if (info->protect[sect]) - prot++; - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - printf ("\n"); - } - - /* Start erase on unprotected sectors - */ - for (sect = s_first; sect <= s_last; sect++) { - volatile ulong *addr = - (volatile unsigned long *) info->start[sect]; - - start = get_timer (0); - last = start; - if (info->protect[sect] == 0) { - /* Disable interrupts which might cause a timeout here - */ - flag = disable_interrupts (); - - /* Erase the block - */ - addr[0] = 0x00200020; - addr[1] = 0x00200020; - addr[0] = 0x00D000D0; - addr[1] = 0x00D000D0; - - /* re-enable interrupts if necessary - */ - if (flag) - enable_interrupts (); - - /* wait at least 80us - let's wait 1 ms - */ - udelay (1000); - - last = start; - while ((addr[0] & 0x00800080) != 0x00800080 || - (addr[1] & 0x00800080) != 0x00800080) { - if ((now = get_timer (start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout (erase suspended!)\n"); - /* Suspend erase - */ - addr[0] = 0x00B000B0; - addr[1] = 0x00B000B0; - goto DONE; - } - /* show that we're waiting - */ - if ((now - last) > 1000) { /* every second */ - serial_putc ('.'); - last = now; - } - } - if (addr[0] & 0x00220022 || addr[1] & 0x00220022) { - printf ("*** ERROR: erase failed!\n"); - goto DONE; - } - } - /* Clear status register and reset to read mode - */ - addr[0] = 0x00500050; - addr[1] = 0x00500050; - addr[0] = 0x00FF00FF; - addr[1] = 0x00FF00FF; - } - - printf (" done\n"); - -DONE: - return 0; -} - -static int write_word (flash_info_t *, volatile unsigned long *, ulong); - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) -{ - ulong v; - int i, l, cc = cnt, res = 0; - - - for (v=0; cc > 0; addr += 4, cc -= 4 - l) { - l = (addr & 3); - addr &= ~3; - - for (i = 0; i < 4; i++) { - v = (v << 8) + (i < l || i - l >= cc ? - *((unsigned char *) addr + i) : *src++); - } - - if ((res = write_word (info, (volatile unsigned long *) addr, v)) != 0) - break; - } - - return (res); -} - -/*----------------------------------------------------------------------- - * Write a word to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_word (flash_info_t * info, volatile unsigned long *addr, - ulong data) -{ - int flag, res = 0; - ulong start; - - /* Check if Flash is (sufficiently) erased - */ - if ((*addr & data) != data) - return (2); - - /* Disable interrupts which might cause a timeout here - */ - flag = disable_interrupts (); - - *addr = 0x00400040; - *addr = data; - - /* re-enable interrupts if necessary - */ - if (flag) - enable_interrupts (); - - start = get_timer (0); - while ((*addr & 0x00800080) != 0x00800080) { - if (get_timer (start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - /* Suspend program - */ - *addr = 0x00B000B0; - res = 1; - goto OUT; - } - } - - if (*addr & 0x00220022) { - printf ("*** ERROR: program failed!\n"); - res = 1; - } - -OUT: - /* Clear status register and reset to read mode - */ - *addr = 0x00500050; - *addr = 0x00FF00FF; - - return (res); -} diff --git a/board/pm826/pm826.c b/board/pm826/pm826.c deleted file mode 100644 index 93bb1b4..0000000 --- a/board/pm826/pm826.c +++ /dev/null @@ -1,319 +0,0 @@ -/* - * (C) Copyright 2001 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <ioports.h> -#include <mpc8260.h> -#include <pci.h> -#include <netdev.h> - -/* - * I/O Port configuration table - * - * if conf is 1, then that port pin will be configured at boot time - * according to the five values podr/pdir/ppar/psor/pdat for that entry - */ - -const iop_conf_t iop_conf_tab[4][32] = { - - /* Port A configuration */ - { /* conf ppar psor pdir podr pdat */ - /* PA31 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 COL */ - /* PA30 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 CRS */ - /* PA29 */ { 1, 1, 1, 1, 0, 0 }, /* FCC1 TXER */ - /* PA28 */ { 1, 1, 1, 1, 0, 0 }, /* FCC1 TXEN */ - /* PA27 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 RXDV */ - /* PA26 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 RXER */ - /* PA25 */ { 0, 0, 0, 1, 0, 0 }, /* PA25 */ - /* PA24 */ { 0, 0, 0, 1, 0, 0 }, /* PA24 */ - /* PA23 */ { 0, 0, 0, 1, 0, 0 }, /* PA23 */ - /* PA22 */ { 0, 0, 0, 1, 0, 0 }, /* PA22 */ - /* PA21 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 TXD3 */ - /* PA20 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 TXD2 */ - /* PA19 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 TXD1 */ - /* PA18 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 TXD0 */ - /* PA17 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 RXD0 */ - /* PA16 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 RXD1*/ - /* PA15 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 RXD2 */ - /* PA14 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 RXD3 */ - /* PA13 */ { 0, 0, 0, 1, 0, 0 }, /* PA13 */ - /* PA12 */ { 0, 0, 0, 1, 0, 0 }, /* PA12 */ - /* PA11 */ { 0, 0, 0, 1, 0, 0 }, /* PA11 */ - /* PA10 */ { 0, 0, 0, 1, 0, 0 }, /* PA10 */ - /* PA9 */ { 0, 1, 0, 1, 0, 0 }, /* PA9 */ - /* PA8 */ { 0, 1, 0, 0, 0, 0 }, /* PA8 */ - /* PA7 */ { 0, 0, 0, 1, 0, 0 }, /* PA7 */ - /* PA6 */ { 0, 0, 0, 1, 0, 0 }, /* PA6 */ - /* PA5 */ { 0, 0, 0, 1, 0, 0 }, /* PA5 */ - /* PA4 */ { 0, 0, 0, 1, 0, 0 }, /* PA4 */ - /* PA3 */ { 0, 0, 0, 1, 0, 0 }, /* PA3 */ - /* PA2 */ { 0, 0, 0, 1, 0, 0 }, /* PA2 */ - /* PA1 */ { 0, 0, 0, 1, 0, 0 }, /* PA1 */ - /* PA0 */ { 0, 0, 0, 1, 0, 0 } /* PA0 */ - }, - - /* Port B configuration */ - { /* conf ppar psor pdir podr pdat */ - /* PB31 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 TX_ER */ - /* PB30 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 RX_DV */ - /* PB29 */ { 1, 1, 1, 1, 0, 0 }, /* FCC2 TX_EN */ -#if defined(CONFIG_ETHER_ON_SCC) && (CONFIG_ETHER_INDEX == 1) -#ifdef CONFIG_ETHER_ON_FCC2 -#error "SCC1 conflicts with FCC2" -#endif - /* PB28 */ { 1, 1, 1, 1, 0, 0 }, /* SCC1 TXD */ -#else - /* PB28 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 RX_ER */ -#endif - /* PB27 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 COL */ - /* PB26 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 CRS */ - /* PB25 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 TxD[3] */ - /* PB24 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 TxD[2] */ - /* PB23 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 TxD[1] */ - /* PB22 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 TxD[0] */ - /* PB21 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 RxD[0] */ - /* PB20 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 RxD[1] */ - /* PB19 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 RxD[2] */ - /* PB18 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 RxD[3] */ - /* PB17 */ { 0, 0, 0, 0, 0, 0 }, /* PB17 */ - /* PB16 */ { 0, 0, 0, 0, 0, 0 }, /* PB16 */ - /* PB15 */ { 1, 1, 0, 0, 0, 0 }, /* SCC2 RXD */ - /* PB14 */ { 1, 1, 0, 0, 0, 0 }, /* SCC3 RXD */ - /* PB13 */ { 0, 0, 0, 0, 0, 0 }, /* PB13 */ - /* PB12 */ { 0, 0, 0, 0, 0, 0 }, /* PB12 */ - /* PB11 */ { 0, 0, 0, 0, 0, 0 }, /* PB11 */ - /* PB10 */ { 0, 0, 0, 0, 0, 0 }, /* PB10 */ - /* PB9 */ { 0, 0, 0, 0, 0, 0 }, /* PB9 */ - /* PB8 */ { 1, 1, 1, 1, 0, 0 }, /* SCC3 TXD */ - /* PB7 */ { 0, 0, 0, 0, 0, 0 }, /* PB7 */ - /* PB6 */ { 0, 0, 0, 0, 0, 0 }, /* PB6 */ - /* PB5 */ { 0, 0, 0, 0, 0, 0 }, /* PB5 */ - /* PB4 */ { 0, 0, 0, 0, 0, 0 }, /* PB4 */ - /* PB3 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PB2 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PB1 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PB0 */ { 0, 0, 0, 0, 0, 0 } /* pin doesn't exist */ - }, - - /* Port C */ - { /* conf ppar psor pdir podr pdat */ - /* PC31 */ { 0, 0, 0, 1, 0, 0 }, /* PC31 */ - /* PC30 */ { 0, 0, 0, 1, 0, 0 }, /* PC30 */ - /* PC29 */ { 0, 1, 1, 0, 0, 0 }, /* SCC1 CTS */ - /* PC28 */ { 0, 0, 0, 1, 0, 0 }, /* SCC2 CTS */ - /* PC27 */ { 0, 0, 0, 1, 0, 0 }, /* PC27 */ - /* PC26 */ { 0, 0, 0, 1, 0, 0 }, /* PC26 */ - /* PC25 */ { 0, 0, 0, 1, 0, 0 }, /* PC25 */ - /* PC24 */ { 0, 0, 0, 1, 0, 0 }, /* PC24 */ - /* PC23 */ { 0, 1, 0, 1, 0, 0 }, /* PC23 */ - /* PC22 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 TXCK */ - /* PC21 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 RXCK */ - /* PC20 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 TXCK(2) */ - /* PC19 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 RXCK */ - /* PC18 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 TXCK */ - /* PC17 */ { 0, 0, 0, 1, 0, 0 }, /* PC17 */ - /* PC16 */ { 0, 0, 0, 1, 0, 0 }, /* PC16 */ - /* PC15 */ { 1, 1, 0, 1, 0, 0 }, /* SMC2 TXD */ - /* PC14 */ { 0, 1, 0, 0, 0, 0 }, /* SCC1 DCD */ - /* PC13 */ { 0, 0, 0, 1, 0, 0 }, /* PC13 */ - /* PC12 */ { 0, 0, 0, 1, 0, 0 }, /* SCC2 DCD */ - /* PC11 */ { 0, 0, 0, 1, 0, 0 }, /* SCC3 CTS */ - /* PC10 */ { 0, 0, 0, 1, 0, 0 }, /* SCC3 DCD */ - /* PC9 */ { 0, 0, 0, 1, 0, 0 }, /* SCC4 CTS */ - /* PC8 */ { 0, 0, 0, 1, 0, 0 }, /* SCC4 DCD */ - /* PC7 */ { 0, 0, 0, 1, 0, 0 }, /* PC7 */ - /* PC6 */ { 0, 0, 0, 1, 0, 0 }, /* PC6 */ - /* PC5 */ { 0, 0, 0, 1, 0, 0 }, /* PC5 */ - /* PC4 */ { 0, 0, 0, 1, 0, 0 }, /* PC4 */ - /* PC3 */ { 0, 0, 0, 1, 0, 0 }, /* PC3 */ - /* PC2 */ { 0, 0, 0, 1, 0, 1 }, /* PC2 */ - /* PC1 */ { 0, 0, 0, 1, 0, 0 }, /* PC1 */ - /* PC0 */ { 0, 0, 0, 1, 0, 0 }, /* PC0 */ - }, - - /* Port D */ - { /* conf ppar psor pdir podr pdat */ - /* PD31 */ { 1, 1, 0, 0, 0, 0 }, /* SCC1 RXD */ - /* PD30 */ { 0, 1, 1, 1, 0, 0 }, /* PD30 */ - /* PD29 */ { 0, 1, 0, 1, 0, 0 }, /* SCC1 RTS */ - /* PD28 */ { 0, 0, 0, 1, 0, 0 }, /* PD28 */ - /* PD27 */ { 0, 1, 0, 1, 0, 0 }, /* SCC2 RTS */ - /* PD26 */ { 0, 0, 0, 1, 0, 0 }, /* PD26 */ - /* PD25 */ { 0, 0, 0, 1, 0, 0 }, /* PD25 */ - /* PD24 */ { 0, 0, 0, 1, 0, 0 }, /* PD24 */ - /* PD23 */ { 0, 0, 0, 1, 0, 0 }, /* SCC3 RTS */ - /* PD22 */ { 1, 1, 0, 0, 0, 0 }, /* SCC4 RXD */ - /* PD21 */ { 1, 1, 0, 1, 0, 0 }, /* SCC4 TXD */ - /* PD20 */ { 0, 0, 1, 1, 0, 0 }, /* SCC4 RTS */ - /* PD19 */ { 0, 0, 0, 1, 0, 0 }, /* PD19 */ - /* PD18 */ { 0, 0, 0, 1, 0, 0 }, /* PD18 */ - /* PD17 */ { 0, 1, 0, 0, 0, 0 }, /* PD17 */ - /* PD16 */ { 0, 1, 0, 1, 0, 0 }, /* PD16 */ -#if defined(CONFIG_SYS_I2C_SOFT) - /* PD15 */ { 1, 0, 0, 1, 1, 1 }, /* I2C SDA */ - /* PD14 */ { 1, 0, 0, 1, 1, 1 }, /* I2C SCL */ -#else -#if defined(CONFIG_HARD_I2C) - /* PD15 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SDA */ - /* PD14 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SCL */ -#else /* normal I/O port pins */ - /* PD15 */ { 0, 1, 1, 0, 1, 0 }, /* I2C SDA */ - /* PD14 */ { 0, 1, 1, 0, 1, 0 }, /* I2C SCL */ -#endif -#endif - /* PD13 */ { 0, 0, 0, 0, 0, 0 }, /* PD13 */ - /* PD12 */ { 0, 0, 0, 0, 0, 0 }, /* PD12 */ - /* PD11 */ { 0, 0, 0, 0, 0, 0 }, /* PD11 */ - /* PD10 */ { 0, 0, 0, 0, 0, 0 }, /* PD10 */ - /* PD9 */ { 0, 1, 0, 1, 0, 0 }, /* PD9 */ - /* PD8 */ { 0, 1, 0, 0, 0, 0 }, /* PD8 */ - /* PD7 */ { 0, 0, 0, 1, 0, 1 }, /* PD7 */ - /* PD6 */ { 0, 0, 0, 1, 0, 1 }, /* PD6 */ - /* PD5 */ { 0, 0, 0, 1, 0, 1 }, /* PD5 */ - /* PD4 */ { 1, 1, 1, 0, 0, 0 }, /* SMC2 RXD */ - /* PD3 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PD2 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PD1 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PD0 */ { 0, 0, 0, 0, 0, 0 } /* pin doesn't exist */ - } -}; - -/* ------------------------------------------------------------------------- */ - -/* Check Board Identity: - */ -int checkboard (void) -{ - puts ("Board: PM826\n"); - return 0; -} - -/* ------------------------------------------------------------------------- */ - - -/* Try SDRAM initialization with P/LSDMR=sdmr and ORx=orx - * - * This routine performs standard 8260 initialization sequence - * and calculates the available memory size. It may be called - * several times to try different SDRAM configurations on both - * 60x and local buses. - */ -static long int try_init (volatile memctl8260_t * memctl, ulong sdmr, - ulong orx, volatile uchar * base) -{ - volatile uchar c = 0xff; - volatile uint *sdmr_ptr; - volatile uint *orx_ptr; - ulong maxsize, size; - int i; - - /* We must be able to test a location outsize the maximum legal size - * to find out THAT we are outside; but this address still has to be - * mapped by the controller. That means, that the initial mapping has - * to be (at least) twice as large as the maximum expected size. - */ - maxsize = (1 + (~orx | 0x7fff)) / 2; - - sdmr_ptr = &memctl->memc_psdmr; - orx_ptr = &memctl->memc_or2; - - *orx_ptr = orx; - - /* - * Quote from 8260 UM (10.4.2 SDRAM Power-On Initialization, 10-35): - * - * "At system reset, initialization software must set up the - * programmable parameters in the memory controller banks registers - * (ORx, BRx, P/LSDMR). After all memory parameters are configured, - * system software should execute the following initialization sequence - * for each SDRAM device. - * - * 1. Issue a PRECHARGE-ALL-BANKS command - * 2. Issue eight CBR REFRESH commands - * 3. Issue a MODE-SET command to initialize the mode register - * - * The initial commands are executed by setting P/LSDMR[OP] and - * accessing the SDRAM with a single-byte transaction." - * - * The appropriate BRx/ORx registers have already been set when we - * get here. The SDRAM can be accessed at the address CONFIG_SYS_SDRAM_BASE. - */ - - *sdmr_ptr = sdmr | PSDMR_OP_PREA; - *base = c; - - *sdmr_ptr = sdmr | PSDMR_OP_CBRR; - for (i = 0; i < 8; i++) - *base = c; - - *sdmr_ptr = sdmr | PSDMR_OP_MRW; - *(base + CONFIG_SYS_MRS_OFFS) = c; /* setting MR on address lines */ - - *sdmr_ptr = sdmr | PSDMR_OP_NORM | PSDMR_RFEN; - *base = c; - - size = get_ram_size((long *)base, maxsize); - - *orx_ptr = orx | ~(size - 1); - - return (size); -} - - -phys_size_t initdram (int board_type) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8260_t *memctl = &immap->im_memctl; - -#ifndef CONFIG_SYS_RAMBOOT - ulong size8, size9; -#endif - ulong psize = 32 * 1024 * 1024; - - memctl->memc_psrt = CONFIG_SYS_PSRT; - memctl->memc_mptpr = CONFIG_SYS_MPTPR; - -#ifndef CONFIG_SYS_RAMBOOT - size8 = try_init (memctl, CONFIG_SYS_PSDMR_8COL, CONFIG_SYS_OR2_8COL, - (uchar *) CONFIG_SYS_SDRAM_BASE); - size9 = try_init (memctl, CONFIG_SYS_PSDMR_9COL, CONFIG_SYS_OR2_9COL, - (uchar *) CONFIG_SYS_SDRAM_BASE); - - if (size8 < size9) { - psize = size9; - printf ("(60x:9COL) "); - } else { - psize = try_init (memctl, CONFIG_SYS_PSDMR_8COL, CONFIG_SYS_OR2_8COL, - (uchar *) CONFIG_SYS_SDRAM_BASE); - printf ("(60x:8COL) "); - } -#endif - return (psize); -} - -#if defined(CONFIG_CMD_DOC) -void doc_init (void) -{ - doc_probe (CONFIG_SYS_DOC_BASE); -} -#endif - -#ifdef CONFIG_PCI -struct pci_controller hose; - -extern void pci_mpc8250_init(struct pci_controller *); - -void pci_init_board(void) -{ - pci_mpc8250_init(&hose); -} -#endif - -int board_eth_init(bd_t *bis) -{ - return pci_eth_init(bis); -} diff --git a/board/pm828/Kconfig b/board/pm828/Kconfig deleted file mode 100644 index e7970a3..0000000 --- a/board/pm828/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_PM828 - -config SYS_BOARD - default "pm828" - -config SYS_CONFIG_NAME - default "PM828" - -endif diff --git a/board/pm828/MAINTAINERS b/board/pm828/MAINTAINERS deleted file mode 100644 index 97c1ccc..0000000 --- a/board/pm828/MAINTAINERS +++ /dev/null @@ -1,9 +0,0 @@ -PM828 BOARD -#M: - -S: Maintained -F: board/pm828/ -F: include/configs/PM828.h -F: configs/PM828_defconfig -F: configs/PM828_PCI_defconfig -F: configs/PM828_ROMBOOT_defconfig -F: configs/PM828_ROMBOOT_PCI_defconfig diff --git a/board/pm828/Makefile b/board/pm828/Makefile deleted file mode 100644 index 0afffb7..0000000 --- a/board/pm828/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2001-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = pm828.o flash.o diff --git a/board/pm828/flash.c b/board/pm828/flash.c deleted file mode 100644 index 8888560..0000000 --- a/board/pm828/flash.c +++ /dev/null @@ -1,370 +0,0 @@ -/* - * (C) Copyright 2001-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * Flash Routines for Intel devices - * - *-------------------------------------------------------------------- - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc8xx.h> - - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; - -/*----------------------------------------------------------------------- - */ -ulong flash_get_size (volatile unsigned long *baseaddr, - flash_info_t * info) -{ - short i; - unsigned long flashtest_h, flashtest_l; - - info->sector_count = info->size = 0; - info->flash_id = FLASH_UNKNOWN; - - /* Write query command sequence and test FLASH answer - */ - baseaddr[0] = 0x00980098; - baseaddr[1] = 0x00980098; - - flashtest_h = baseaddr[0]; /* manufacturer ID */ - flashtest_l = baseaddr[1]; - - if (flashtest_h != INTEL_MANUFACT || flashtest_l != INTEL_MANUFACT) - return (0); /* no or unknown flash */ - - flashtest_h = baseaddr[2]; /* device ID */ - flashtest_l = baseaddr[3]; - - if (flashtest_h != flashtest_l) - return (0); - - switch (flashtest_h) { - case INTEL_ID_28F160C3B: - info->flash_id = FLASH_28F160C3B; - info->sector_count = 39; - info->size = 0x00800000; /* 4 * 2 MB = 8 MB */ - break; - case INTEL_ID_28F160F3B: - info->flash_id = FLASH_28F160F3B; - info->sector_count = 39; - info->size = 0x00800000; /* 4 * 2 MB = 8 MB */ - break; - case INTEL_ID_28F640C3B: - info->flash_id = FLASH_28F640C3B; - info->sector_count = 135; - info->size = 0x02000000; /* 16 * 2 MB = 32 MB */ - break; - default: - return (0); /* no or unknown flash */ - } - - info->flash_id |= INTEL_MANUFACT << 16; /* set manufacturer offset */ - - if (info->flash_id & FLASH_BTYPE) { - volatile unsigned long *tmp = baseaddr; - - /* set up sector start adress table (bottom sector type) - * AND unlock the sectors (if our chip is 160C3 or 640c3) - */ - for (i = 0; i < info->sector_count; i++) { - if (((info->flash_id & FLASH_TYPEMASK) == FLASH_28F160C3B) || - ((info->flash_id & FLASH_TYPEMASK) == FLASH_28F640C3B)) { - tmp[0] = 0x00600060; - tmp[1] = 0x00600060; - tmp[0] = 0x00D000D0; - tmp[1] = 0x00D000D0; - } - info->start[i] = (uint) tmp; - tmp += i < 8 ? 0x2000 : 0x10000; /* pointer arith */ - } - } - - memset (info->protect, 0, info->sector_count); - - baseaddr[0] = 0x00FF00FF; - baseaddr[1] = 0x00FF00FF; - - return (info->size); -} - -/*----------------------------------------------------------------------- - */ -unsigned long flash_init (void) -{ - unsigned long size_b0 = 0; - int i; - - /* Init: no FLASHes known - */ - for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - } - - /* Static FLASH Bank configuration here (only one bank) */ - - size_b0 = flash_get_size ((ulong *) CONFIG_SYS_FLASH0_BASE, &flash_info[0]); - if (flash_info[0].flash_id == FLASH_UNKNOWN || size_b0 == 0) { - printf ("## Unknown FLASH on Bank 0 - Size = 0x%08lx = %ld MB\n", - size_b0, size_b0 >> 20); - } - - /* protect monitor and environment sectors - */ - -#ifndef CONFIG_BOOT_ROM - /* If U-Boot is booted from ROM the CONFIG_SYS_MONITOR_BASE > CONFIG_SYS_FLASH0_BASE - * but we shouldn't protect it. - */ - -# if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH0_BASE - flash_protect (FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE + monitor_flash_len - 1, &flash_info[0] - ); -# endif -#endif /* CONFIG_BOOT_ROM */ - -#if defined(CONFIG_ENV_IS_IN_FLASH) && defined(CONFIG_ENV_ADDR) -# ifndef CONFIG_ENV_SIZE -# define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -# endif - flash_protect (FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR + CONFIG_ENV_SIZE - 1, &flash_info[0]); -#endif - - return (size_b0); -} - -/*----------------------------------------------------------------------- - */ -void flash_print_info (flash_info_t * info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch ((info->flash_id >> 16) & 0xff) { - case 0x89: - printf ("INTEL "); - break; - default: - printf ("Unknown Vendor "); - break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_28F160C3B: - printf ("28F160C3B (16 M, bottom sector)\n"); - break; - case FLASH_28F160F3B: - printf ("28F160F3B (16 M, bottom sector)\n"); - break; - case FLASH_28F640C3B: - printf ("28F640C3B (64 M, bottom sector)\n"); - break; - default: - printf ("Unknown Chip Type\n"); - break; - } - - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); - - printf (" Sector Start Addresses:"); - for (i = 0; i < info->sector_count; ++i) { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", - info->start[i], - info->protect[i] ? " (RO)" : " " - ); - } - printf ("\n"); -} - -/*----------------------------------------------------------------------- - */ -int flash_erase (flash_info_t * info, int s_first, int s_last) -{ - int flag, prot, sect; - ulong start, now, last; - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - prot = 0; - for (sect = s_first; sect <= s_last; sect++) { - if (info->protect[sect]) - prot++; - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - printf ("\n"); - } - - /* Start erase on unprotected sectors - */ - for (sect = s_first; sect <= s_last; sect++) { - volatile ulong *addr = - (volatile unsigned long *) info->start[sect]; - - start = get_timer (0); - last = start; - if (info->protect[sect] == 0) { - /* Disable interrupts which might cause a timeout here - */ - flag = disable_interrupts (); - - /* Erase the block - */ - addr[0] = 0x00200020; - addr[1] = 0x00200020; - addr[0] = 0x00D000D0; - addr[1] = 0x00D000D0; - - /* re-enable interrupts if necessary - */ - if (flag) - enable_interrupts (); - - /* wait at least 80us - let's wait 1 ms - */ - udelay (1000); - - last = start; - while ((addr[0] & 0x00800080) != 0x00800080 || - (addr[1] & 0x00800080) != 0x00800080) { - if ((now = get_timer (start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout (erase suspended!)\n"); - /* Suspend erase - */ - addr[0] = 0x00B000B0; - addr[1] = 0x00B000B0; - goto DONE; - } - /* show that we're waiting - */ - if ((now - last) > 1000) { /* every second */ - serial_putc ('.'); - last = now; - } - } - if (addr[0] & 0x00220022 || addr[1] & 0x00220022) { - printf ("*** ERROR: erase failed!\n"); - goto DONE; - } - } - /* Clear status register and reset to read mode - */ - addr[0] = 0x00500050; - addr[1] = 0x00500050; - addr[0] = 0x00FF00FF; - addr[1] = 0x00FF00FF; - } - - printf (" done\n"); - -DONE: - return 0; -} - -static int write_word (flash_info_t *, volatile unsigned long *, ulong); - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) -{ - ulong v; - int i, l, cc = cnt, res = 0; - - - for (v=0; cc > 0; addr += 4, cc -= 4 - l) { - l = (addr & 3); - addr &= ~3; - - for (i = 0; i < 4; i++) { - v = (v << 8) + (i < l || i - l >= cc ? - *((unsigned char *) addr + i) : *src++); - } - - if ((res = write_word (info, (volatile unsigned long *) addr, v)) != 0) - break; - } - - return (res); -} - -/*----------------------------------------------------------------------- - * Write a word to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_word (flash_info_t * info, volatile unsigned long *addr, - ulong data) -{ - int flag, res = 0; - ulong start; - - /* Check if Flash is (sufficiently) erased - */ - if ((*addr & data) != data) - return (2); - - /* Disable interrupts which might cause a timeout here - */ - flag = disable_interrupts (); - - *addr = 0x00400040; - *addr = data; - - /* re-enable interrupts if necessary - */ - if (flag) - enable_interrupts (); - - start = get_timer (0); - while ((*addr & 0x00800080) != 0x00800080) { - if (get_timer (start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - /* Suspend program - */ - *addr = 0x00B000B0; - res = 1; - goto OUT; - } - } - - if (*addr & 0x00220022) { - printf ("*** ERROR: program failed!\n"); - res = 1; - } - -OUT: - /* Clear status register and reset to read mode - */ - *addr = 0x00500050; - *addr = 0x00FF00FF; - - return (res); -} diff --git a/board/pm828/pm828.c b/board/pm828/pm828.c deleted file mode 100644 index f446543..0000000 --- a/board/pm828/pm828.c +++ /dev/null @@ -1,352 +0,0 @@ -/* - * (C) Copyright 2001-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <ioports.h> -#include <mpc8260.h> -#include <pci.h> -#include <netdev.h> - -/* - * I/O Port configuration table - * - * if conf is 1, then that port pin will be configured at boot time - * according to the five values podr/pdir/ppar/psor/pdat for that entry - */ - -const iop_conf_t iop_conf_tab[4][32] = { - - /* Port A configuration */ - { /* conf ppar psor pdir podr pdat */ - /* PA31 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 COL */ - /* PA30 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 CRS */ - /* PA29 */ { 1, 1, 1, 1, 0, 0 }, /* FCC1 TXER */ - /* PA28 */ { 1, 1, 1, 1, 0, 0 }, /* FCC1 TXEN */ - /* PA27 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 RXDV */ - /* PA26 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 RXER */ - /* PA25 */ { 0, 0, 0, 1, 0, 0 }, /* PA25 */ - /* PA24 */ { 0, 0, 0, 1, 0, 0 }, /* PA24 */ - /* PA23 */ { 0, 0, 0, 1, 0, 0 }, /* PA23 */ - /* PA22 */ { 0, 0, 0, 1, 0, 0 }, /* PA22 */ - /* PA21 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 TXD3 */ - /* PA20 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 TXD2 */ - /* PA19 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 TXD1 */ - /* PA18 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 TXD0 */ - /* PA17 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 RXD0 */ - /* PA16 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 RXD1*/ - /* PA15 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 RXD2 */ - /* PA14 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 RXD3 */ - /* PA13 */ { 0, 0, 0, 1, 0, 0 }, /* PA13 */ - /* PA12 */ { 0, 0, 0, 1, 0, 0 }, /* PA12 */ - /* PA11 */ { 0, 0, 0, 1, 0, 0 }, /* PA11 */ - /* PA10 */ { 0, 0, 0, 1, 0, 0 }, /* PA10 */ - /* PA9 */ { 0, 1, 0, 1, 0, 0 }, /* PA9 */ - /* PA8 */ { 0, 1, 0, 0, 0, 0 }, /* PA8 */ - /* PA7 */ { 0, 0, 0, 1, 0, 0 }, /* PA7 */ - /* PA6 */ { 0, 0, 0, 1, 0, 0 }, /* PA6 */ - /* PA5 */ { 0, 0, 0, 1, 0, 0 }, /* PA5 */ - /* PA4 */ { 0, 0, 0, 1, 0, 0 }, /* PA4 */ - /* PA3 */ { 0, 0, 0, 1, 0, 0 }, /* PA3 */ - /* PA2 */ { 0, 0, 0, 1, 0, 0 }, /* PA2 */ - /* PA1 */ { 0, 0, 0, 1, 0, 0 }, /* PA1 */ - /* PA0 */ { 0, 0, 0, 1, 0, 0 } /* PA0 */ - }, - - /* Port B configuration */ - { /* conf ppar psor pdir podr pdat */ - /* PB31 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 TX_ER */ - /* PB30 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 RX_DV */ - /* PB29 */ { 1, 1, 1, 1, 0, 0 }, /* FCC2 TX_EN */ -#if defined(CONFIG_ETHER_ON_SCC) && (CONFIG_ETHER_INDEX == 1) -#ifdef CONFIG_ETHER_ON_FCC2 -#error "SCC1 conflicts with FCC2" -#endif - /* PB28 */ { 1, 1, 1, 1, 0, 0 }, /* SCC1 TXD */ -#else - /* PB28 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 RX_ER */ -#endif - /* PB27 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 COL */ - /* PB26 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 CRS */ - /* PB25 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 TxD[3] */ - /* PB24 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 TxD[2] */ - /* PB23 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 TxD[1] */ - /* PB22 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 TxD[0] */ - /* PB21 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 RxD[0] */ - /* PB20 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 RxD[1] */ - /* PB19 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 RxD[2] */ - /* PB18 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 RxD[3] */ - /* PB17 */ { 0, 0, 0, 0, 0, 0 }, /* PB17 */ - /* PB16 */ { 0, 0, 0, 0, 0, 0 }, /* PB16 */ - /* PB15 */ { 1, 1, 0, 0, 0, 0 }, /* SCC2 RXD */ - /* PB14 */ { 1, 1, 0, 0, 0, 0 }, /* SCC3 RXD */ - /* PB13 */ { 0, 0, 0, 0, 0, 0 }, /* PB13 */ - /* PB12 */ { 0, 0, 0, 0, 0, 0 }, /* PB12 */ - /* PB11 */ { 0, 0, 0, 0, 0, 0 }, /* PB11 */ - /* PB10 */ { 0, 0, 0, 0, 0, 0 }, /* PB10 */ - /* PB9 */ { 0, 0, 0, 0, 0, 0 }, /* PB9 */ - /* PB8 */ { 1, 1, 1, 1, 0, 0 }, /* SCC3 TXD */ - /* PB7 */ { 0, 0, 0, 0, 0, 0 }, /* PB7 */ - /* PB6 */ { 0, 0, 0, 0, 0, 0 }, /* PB6 */ - /* PB5 */ { 0, 0, 0, 0, 0, 0 }, /* PB5 */ - /* PB4 */ { 0, 0, 0, 0, 0, 0 }, /* PB4 */ - /* PB3 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PB2 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PB1 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PB0 */ { 0, 0, 0, 0, 0, 0 } /* pin doesn't exist */ - }, - - /* Port C */ - { /* conf ppar psor pdir podr pdat */ - /* PC31 */ { 0, 0, 0, 1, 0, 0 }, /* PC31 */ - /* PC30 */ { 0, 0, 0, 1, 0, 0 }, /* PC30 */ - /* PC29 */ { 0, 1, 1, 0, 0, 0 }, /* SCC1 CTS */ - /* PC28 */ { 0, 0, 0, 1, 0, 0 }, /* SCC2 CTS */ - /* PC27 */ { 0, 0, 0, 1, 0, 0 }, /* PC27 */ - /* PC26 */ { 0, 0, 0, 1, 0, 0 }, /* PC26 */ - /* PC25 */ { 0, 0, 0, 1, 0, 0 }, /* PC25 */ - /* PC24 */ { 0, 0, 0, 1, 0, 0 }, /* PC24 */ - /* PC23 */ { 0, 1, 0, 1, 0, 0 }, /* PC23 */ - /* PC22 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 TXCK */ - /* PC21 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 RXCK */ - /* PC20 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 TXCK(2) */ - /* PC19 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 RXCK */ - /* PC18 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 TXCK */ - /* PC17 */ { 0, 0, 0, 1, 0, 0 }, /* PC17 */ - /* PC16 */ { 0, 0, 0, 1, 0, 0 }, /* PC16 */ - /* PC15 */ { 1, 1, 0, 1, 0, 0 }, /* SMC2 TXD */ - /* PC14 */ { 0, 1, 0, 0, 0, 0 }, /* SCC1 DCD */ - /* PC13 */ { 0, 0, 0, 1, 0, 0 }, /* PC13 */ - /* PC12 */ { 0, 0, 0, 1, 0, 0 }, /* SCC2 DCD */ - /* PC11 */ { 0, 0, 0, 1, 0, 0 }, /* SCC3 CTS */ - /* PC10 */ { 0, 0, 0, 1, 0, 0 }, /* SCC3 DCD */ - /* PC9 */ { 0, 0, 0, 1, 0, 0 }, /* SCC4 CTS */ - /* PC8 */ { 0, 0, 0, 1, 0, 0 }, /* SCC4 DCD */ - /* PC7 */ { 0, 0, 0, 1, 0, 0 }, /* PC7 */ - /* PC6 */ { 0, 0, 0, 1, 0, 0 }, /* PC6 */ - /* PC5 */ { 0, 0, 0, 1, 0, 0 }, /* PC5 */ - /* PC4 */ { 0, 0, 0, 1, 0, 0 }, /* PC4 */ - /* PC3 */ { 0, 0, 0, 1, 0, 0 }, /* PC3 */ - /* PC2 */ { 0, 0, 0, 1, 0, 1 }, /* PC2 */ - /* PC1 */ { 0, 0, 0, 1, 0, 0 }, /* PC1 */ - /* PC0 */ { 0, 0, 0, 1, 0, 0 }, /* PC0 */ - }, - - /* Port D */ - { /* conf ppar psor pdir podr pdat */ - /* PD31 */ { 1, 1, 0, 0, 0, 0 }, /* SCC1 RXD */ - /* PD30 */ { 0, 1, 1, 1, 0, 0 }, /* PD30 */ - /* PD29 */ { 0, 1, 0, 1, 0, 0 }, /* SCC1 RTS */ - /* PD28 */ { 0, 0, 0, 1, 0, 0 }, /* PD28 */ - /* PD27 */ { 0, 1, 0, 1, 0, 0 }, /* SCC2 RTS */ - /* PD26 */ { 0, 0, 0, 1, 0, 0 }, /* PD26 */ - /* PD25 */ { 0, 0, 0, 1, 0, 0 }, /* PD25 */ - /* PD24 */ { 0, 0, 0, 1, 0, 0 }, /* PD24 */ - /* PD23 */ { 0, 0, 0, 1, 0, 0 }, /* SCC3 RTS */ - /* PD22 */ { 1, 1, 0, 0, 0, 0 }, /* SCC4 RXD */ - /* PD21 */ { 1, 1, 0, 1, 0, 0 }, /* SCC4 TXD */ - /* PD20 */ { 0, 0, 1, 1, 0, 0 }, /* SCC4 RTS */ - /* PD19 */ { 0, 0, 0, 1, 0, 0 }, /* PD19 */ - /* PD18 */ { 0, 0, 0, 1, 0, 0 }, /* PD18 */ - /* PD17 */ { 0, 1, 0, 0, 0, 0 }, /* PD17 */ - /* PD16 */ { 0, 1, 0, 1, 0, 0 }, /* PD16 */ -#if defined(CONFIG_SYS_I2C_SOFT) - /* PD15 */ { 1, 0, 0, 1, 1, 1 }, /* I2C SDA */ - /* PD14 */ { 1, 0, 0, 1, 1, 1 }, /* I2C SCL */ -#else -#if defined(CONFIG_HARD_I2C) - /* PD15 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SDA */ - /* PD14 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SCL */ -#else /* normal I/O port pins */ - /* PD15 */ { 0, 1, 1, 0, 1, 0 }, /* I2C SDA */ - /* PD14 */ { 0, 1, 1, 0, 1, 0 }, /* I2C SCL */ -#endif -#endif - /* PD13 */ { 0, 0, 0, 0, 0, 0 }, /* PD13 */ - /* PD12 */ { 0, 0, 0, 0, 0, 0 }, /* PD12 */ - /* PD11 */ { 0, 0, 0, 0, 0, 0 }, /* PD11 */ - /* PD10 */ { 0, 0, 0, 0, 0, 0 }, /* PD10 */ - /* PD9 */ { 0, 1, 0, 1, 0, 0 }, /* PD9 */ - /* PD8 */ { 0, 1, 0, 0, 0, 0 }, /* PD8 */ - /* PD7 */ { 0, 0, 0, 1, 0, 1 }, /* PD7 */ - /* PD6 */ { 0, 0, 0, 1, 0, 1 }, /* PD6 */ - /* PD5 */ { 0, 0, 0, 1, 0, 1 }, /* PD5 */ - /* PD4 */ { 1, 1, 1, 0, 0, 0 }, /* SMC2 RXD */ - /* PD3 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PD2 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PD1 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PD0 */ { 0, 0, 0, 0, 0, 0 } /* pin doesn't exist */ - } -}; - -/* ------------------------------------------------------------------------- */ - -/* Check Board Identity: - */ -int checkboard (void) -{ - puts ("Board: PM828\n"); - return 0; -} - -/* ------------------------------------------------------------------------- */ - - -/* Try SDRAM initialization with P/LSDMR=sdmr and ORx=orx - * - * This routine performs standard 8260 initialization sequence - * and calculates the available memory size. It may be called - * several times to try different SDRAM configurations on both - * 60x and local buses. - */ -static long int try_init (volatile memctl8260_t * memctl, ulong sdmr, - ulong orx, volatile uchar * base) -{ - volatile uchar c = 0xff; - volatile ulong cnt, val; - volatile ulong *addr; - volatile uint *sdmr_ptr; - volatile uint *orx_ptr; - int i; - ulong save[32]; /* to make test non-destructive */ - ulong maxsize; - - /* We must be able to test a location outsize the maximum legal size - * to find out THAT we are outside; but this address still has to be - * mapped by the controller. That means, that the initial mapping has - * to be (at least) twice as large as the maximum expected size. - */ - maxsize = (1 + (~orx | 0x7fff)) / 2; - - sdmr_ptr = &memctl->memc_psdmr; - orx_ptr = &memctl->memc_or2; - - *orx_ptr = orx; - - /* - * Quote from 8260 UM (10.4.2 SDRAM Power-On Initialization, 10-35): - * - * "At system reset, initialization software must set up the - * programmable parameters in the memory controller banks registers - * (ORx, BRx, P/LSDMR). After all memory parameters are configured, - * system software should execute the following initialization sequence - * for each SDRAM device. - * - * 1. Issue a PRECHARGE-ALL-BANKS command - * 2. Issue eight CBR REFRESH commands - * 3. Issue a MODE-SET command to initialize the mode register - * - * The initial commands are executed by setting P/LSDMR[OP] and - * accessing the SDRAM with a single-byte transaction." - * - * The appropriate BRx/ORx registers have already been set when we - * get here. The SDRAM can be accessed at the address CONFIG_SYS_SDRAM_BASE. - */ - - *sdmr_ptr = sdmr | PSDMR_OP_PREA; - *base = c; - - *sdmr_ptr = sdmr | PSDMR_OP_CBRR; - for (i = 0; i < 8; i++) - *base = c; - - *sdmr_ptr = sdmr | PSDMR_OP_MRW; - *(base + CONFIG_SYS_MRS_OFFS) = c; /* setting MR on address lines */ - - *sdmr_ptr = sdmr | PSDMR_OP_NORM | PSDMR_RFEN; - *base = c; - - /* - * Check memory range for valid RAM. A simple memory test determines - * the actually available RAM size between addresses `base' and - * `base + maxsize'. Some (not all) hardware errors are detected: - * - short between address lines - * - short between data lines - */ - i = 0; - for (cnt = maxsize / sizeof (long); cnt > 0; cnt >>= 1) { - addr = (volatile ulong *) base + cnt; /* pointer arith! */ - save[i++] = *addr; - *addr = ~cnt; - } - - addr = (volatile ulong *) base; - save[i] = *addr; - *addr = 0; - - if ((val = *addr) != 0) { - *addr = save[i]; - return (0); - } - - for (cnt = 1; cnt <= maxsize / sizeof (long); cnt <<= 1) { - addr = (volatile ulong *) base + cnt; /* pointer arith! */ - val = *addr; - *addr = save[--i]; - if (val != ~cnt) { - /* Write the actual size to ORx - */ - *orx_ptr = orx | ~(cnt * sizeof (long) - 1); - return (cnt * sizeof (long)); - } - } - return (maxsize); -} - - -phys_size_t initdram (int board_type) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8260_t *memctl = &immap->im_memctl; - -#ifndef CONFIG_SYS_RAMBOOT - ulong size8, size9; -#endif - ulong psize = 32 * 1024 * 1024; - - memctl->memc_psrt = CONFIG_SYS_PSRT; - memctl->memc_mptpr = CONFIG_SYS_MPTPR; - -#ifndef CONFIG_SYS_RAMBOOT - size8 = try_init (memctl, CONFIG_SYS_PSDMR_8COL, CONFIG_SYS_OR2_8COL, - (uchar *) CONFIG_SYS_SDRAM_BASE); - size9 = try_init (memctl, CONFIG_SYS_PSDMR_9COL, CONFIG_SYS_OR2_9COL, - (uchar *) CONFIG_SYS_SDRAM_BASE); - - if (size8 < size9) { - psize = size9; - printf ("(60x:9COL) "); - } else { - psize = try_init (memctl, CONFIG_SYS_PSDMR_8COL, CONFIG_SYS_OR2_8COL, - (uchar *) CONFIG_SYS_SDRAM_BASE); - printf ("(60x:8COL) "); - } -#endif - return (psize); -} - -#if defined(CONFIG_CMD_DOC) -void doc_init (void) -{ - doc_probe (CONFIG_SYS_DOC_BASE); -} -#endif - -#ifdef CONFIG_PCI -struct pci_controller hose; - -extern void pci_mpc8250_init(struct pci_controller *); - -void pci_init_board(void) -{ - pci_mpc8250_init(&hose); -} -#endif - -int board_eth_init(bd_t *bis) -{ - return pci_eth_init(bis); -} diff --git a/configs/PM825_BIGFLASH_defconfig b/configs/PM825_BIGFLASH_defconfig deleted file mode 100644 index 75efcdd..0000000 --- a/configs/PM825_BIGFLASH_defconfig +++ /dev/null @@ -1,4 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="PCI,FLASH_32MB,SYS_TEXT_BASE=0x40000000" -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_PM826=y diff --git a/configs/PM825_ROMBOOT_BIGFLASH_defconfig b/configs/PM825_ROMBOOT_BIGFLASH_defconfig deleted file mode 100644 index 28ff17f..0000000 --- a/configs/PM825_ROMBOOT_BIGFLASH_defconfig +++ /dev/null @@ -1,4 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="PCI,BOOT_ROM,FLASH_32MB,SYS_TEXT_BASE=0xFF800000" -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_PM826=y diff --git a/configs/PM825_ROMBOOT_defconfig b/configs/PM825_ROMBOOT_defconfig deleted file mode 100644 index f5233fa..0000000 --- a/configs/PM825_ROMBOOT_defconfig +++ /dev/null @@ -1,4 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="PCI,BOOT_ROM,SYS_TEXT_BASE=0xFF800000" -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_PM826=y diff --git a/configs/PM825_defconfig b/configs/PM825_defconfig deleted file mode 100644 index 459cdba..0000000 --- a/configs/PM825_defconfig +++ /dev/null @@ -1,4 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="PCI,SYS_TEXT_BASE=0xFF000000" -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_PM826=y diff --git a/configs/PM826_BIGFLASH_defconfig b/configs/PM826_BIGFLASH_defconfig deleted file mode 100644 index 0acf9d2..0000000 --- a/configs/PM826_BIGFLASH_defconfig +++ /dev/null @@ -1,4 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="FLASH_32MB,SYS_TEXT_BASE=0x40000000" -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_PM826=y diff --git a/configs/PM826_ROMBOOT_BIGFLASH_defconfig b/configs/PM826_ROMBOOT_BIGFLASH_defconfig deleted file mode 100644 index af8d4c9..0000000 --- a/configs/PM826_ROMBOOT_BIGFLASH_defconfig +++ /dev/null @@ -1,4 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="BOOT_ROM,FLASH_32MB,SYS_TEXT_BASE=0xFF800000" -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_PM826=y diff --git a/configs/PM826_ROMBOOT_defconfig b/configs/PM826_ROMBOOT_defconfig deleted file mode 100644 index 7d3e1c3..0000000 --- a/configs/PM826_ROMBOOT_defconfig +++ /dev/null @@ -1,4 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="BOOT_ROM,SYS_TEXT_BASE=0xFF800000" -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_PM826=y diff --git a/configs/PM826_defconfig b/configs/PM826_defconfig deleted file mode 100644 index b2f9d34..0000000 --- a/configs/PM826_defconfig +++ /dev/null @@ -1,4 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0xFF000000" -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_PM826=y diff --git a/configs/PM828_PCI_defconfig b/configs/PM828_PCI_defconfig deleted file mode 100644 index 9b68562..0000000 --- a/configs/PM828_PCI_defconfig +++ /dev/null @@ -1,4 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="PCI" -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_PM828=y diff --git a/configs/PM828_ROMBOOT_PCI_defconfig b/configs/PM828_ROMBOOT_PCI_defconfig deleted file mode 100644 index 8120058..0000000 --- a/configs/PM828_ROMBOOT_PCI_defconfig +++ /dev/null @@ -1,4 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="PCI,BOOT_ROM,SYS_TEXT_BASE=0xFF800000" -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_PM828=y diff --git a/configs/PM828_ROMBOOT_defconfig b/configs/PM828_ROMBOOT_defconfig deleted file mode 100644 index 7c8980e..0000000 --- a/configs/PM828_ROMBOOT_defconfig +++ /dev/null @@ -1,4 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="BOOT_ROM,SYS_TEXT_BASE=0xFF800000" -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_PM828=y diff --git a/configs/PM828_defconfig b/configs/PM828_defconfig deleted file mode 100644 index 15887ca..0000000 --- a/configs/PM828_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_PM828=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index d358d62..f1c2f8b 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,9 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +PM825 powerpc mpc8260 - - Wolfgang Denk wd@denx.de +PM826 powerpc mpc8260 - - Wolfgang Denk wd@denx.de +PM828 powerpc mpc8260 - - MPC8266ADS powerpc mpc8260 - - Rune Torgersen runet@innovsys.com VoVPN-GW powerpc mpc8260 - - ep8260 powerpc mpc8260 - - Frank Panno fpanno@delphintech.com diff --git a/include/configs/PM826.h b/include/configs/PM826.h deleted file mode 100644 index 6416ad5..0000000 --- a/include/configs/PM826.h +++ /dev/null @@ -1,534 +0,0 @@ -/* - * (C) Copyright 2001-2005 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -#undef CONFIG_SYS_RAMBOOT - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_PM826 1 /* ...on a PM8260 module */ -#define CONFIG_CPM2 1 /* Has a CPM2 */ - -#ifndef CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_TEXT_BASE 0xFF000000 /* Standard: boot 64-bit flash */ -#endif - -#undef CONFIG_DB_CR826_J30x_ON /* J30x jumpers on D.B. carrier */ - -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ - -#define CONFIG_PREBOOT "echo;echo Type \"run flash_nfs\" to mount root filesystem over NFS;echo" - -#undef CONFIG_BOOTARGS -#define CONFIG_BOOTCOMMAND \ - "bootp; " \ - "setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off; " \ - "bootm" - -/* enable I2C and select the hardware/software driver */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_SOFT /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SOFT_SPEED 50000 -#define CONFIG_SYS_I2C_SOFT_SLAVE 0xFE -/* - * Software (bit-bang) I2C driver configuration - */ -#define I2C_PORT 3 /* Port A=0, B=1, C=2, D=3 */ -#define I2C_ACTIVE (iop->pdir |= 0x00010000) -#define I2C_TRISTATE (iop->pdir &= ~0x00010000) -#define I2C_READ ((iop->pdat & 0x00010000) != 0) -#define I2C_SDA(bit) if(bit) iop->pdat |= 0x00010000; \ - else iop->pdat &= ~0x00010000 -#define I2C_SCL(bit) if(bit) iop->pdat |= 0x00020000; \ - else iop->pdat &= ~0x00020000 -#define I2C_DELAY udelay(5) /* 1/4 I2C clock duration */ - - -#define CONFIG_RTC_PCF8563 -#define CONFIG_SYS_I2C_RTC_ADDR 0x51 - -/* - * select serial console configuration - * - * if either CONFIG_CONS_ON_SMC or CONFIG_CONS_ON_SCC is selected, then - * CONFIG_CONS_INDEX must be set to the channel number (1-2 for SMC, 1-4 - * for SCC). - * - * if CONFIG_CONS_NONE is defined, then the serial console routines must - * defined elsewhere (for example, on the cogent platform, there are serial - * ports on the motherboard which are used for the serial console - see - * cogent/cma101/serial.[ch]). - */ -#define CONFIG_CONS_ON_SMC /* define if console on SMC */ -#undef CONFIG_CONS_ON_SCC /* define if console on SCC */ -#undef CONFIG_CONS_NONE /* define if console on something else*/ -#define CONFIG_CONS_INDEX 2 /* which serial channel for console */ - -/* - * select ethernet configuration - * - * if CONFIG_ETHER_ON_SCC is selected, then - * - CONFIG_ETHER_INDEX must be set to the channel number (1-4) - * - * if CONFIG_ETHER_ON_FCC is selected, then - * - one or more CONFIG_ETHER_ON_FCCx (x=1,2,3) must also be selected - * - * if CONFIG_ETHER_NONE is defined, then either the ethernet routines must be - * defined elsewhere (as for the console), or CONFIG_CMD_NET must be unset. - */ -#undef CONFIG_ETHER_NONE /* define if ether on something else */ - -#undef CONFIG_ETHER_ON_SCC /* define if ether on SCC */ -#define CONFIG_ETHER_INDEX 1 /* which SCC channel for ethernet */ - -#define CONFIG_ETHER_ON_FCC /* define if ether on FCC */ -/* - * - Rx-CLK is CLK11 - * - Tx-CLK is CLK10 - */ -#define CONFIG_ETHER_ON_FCC1 -# define CONFIG_SYS_CMXFCR_MASK1 (CMXFCR_FC1|CMXFCR_RF1CS_MSK|CMXFCR_TF1CS_MSK) -#ifndef CONFIG_DB_CR826_J30x_ON -# define CONFIG_SYS_CMXFCR_VALUE1 (CMXFCR_RF1CS_CLK11|CMXFCR_TF1CS_CLK10) -#else -# define CONFIG_SYS_CMXFCR_VALUE1 (CMXFCR_RF1CS_CLK11|CMXFCR_TF1CS_CLK12) -#endif -/* - * - Rx-CLK is CLK15 - * - Tx-CLK is CLK14 - */ -#define CONFIG_ETHER_ON_FCC2 -# define CONFIG_SYS_CMXFCR_MASK2 (CMXFCR_FC2|CMXFCR_RF2CS_MSK|CMXFCR_TF2CS_MSK) -# define CONFIG_SYS_CMXFCR_VALUE2 (CMXFCR_RF2CS_CLK13|CMXFCR_TF2CS_CLK14) -/* - * - RAM for BD/Buffers is on the 60x Bus (see 28-13) - * - Enable Full Duplex in FSMR - */ -# define CONFIG_SYS_CPMFCR_RAMTYPE 0 -# define CONFIG_SYS_FCC_PSMR (FCC_PSMR_FDE|FCC_PSMR_LPB) - -/* system clock rate (CLKIN) - equal to the 60x and local bus speed */ -#define CONFIG_8260_CLKIN 64000000 /* in Hz */ - -#if defined(CONFIG_CONS_NONE) || defined(CONFIG_CONS_USE_EXTC) -#define CONFIG_BAUDRATE 230400 -#else -#define CONFIG_BAUDRATE 9600 -#endif - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_BEDBUG -#define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C -#define CONFIG_CMD_NFS -#define CONFIG_CMD_SNTP - -#ifdef CONFIG_PCI -#define CONFIG_PCI_INDIRECT_BRIDGE -#define CONFIG_CMD_PCI -#endif - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -#define CONFIG_SYS_RESET_ADDRESS 0xFDFFFFFC /* "bad" address */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * Flash and Boot ROM mapping - */ -#ifdef CONFIG_FLASH_32MB -#define CONFIG_SYS_FLASH0_BASE 0x40000000 -#define CONFIG_SYS_FLASH0_SIZE 0x02000000 -#else -#define CONFIG_SYS_FLASH0_BASE 0xFF000000 -#define CONFIG_SYS_FLASH0_SIZE 0x00800000 -#endif -#define CONFIG_SYS_BOOTROM_BASE 0xFF800000 -#define CONFIG_SYS_BOOTROM_SIZE 0x00080000 -#define CONFIG_SYS_DOC_BASE 0xFF800000 -#define CONFIG_SYS_DOC_SIZE 0x00100000 - -/* Flash bank size (for preliminary settings) - */ -#define CONFIG_SYS_FLASH_SIZE CONFIG_SYS_FLASH0_SIZE - -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max num of memory banks */ -#ifdef CONFIG_FLASH_32MB -#define CONFIG_SYS_MAX_FLASH_SECT 135 /* max num of sects on one chip */ -#else -#define CONFIG_SYS_MAX_FLASH_SECT 128 /* max num of sects on one chip */ -#endif -#define CONFIG_SYS_FLASH_ERASE_TOUT 240000 /* Flash Erase Timeout (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (in ms) */ - -#if 0 -/* Start port with environment in flash; switch to EEPROM later */ -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE+0x40000) -#define CONFIG_ENV_SIZE 0x40000 -#define CONFIG_ENV_SECT_SIZE 0x40000 -#else -/* Final version: environment in EEPROM */ -#define CONFIG_ENV_IS_IN_EEPROM 1 -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x58 -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CONFIG_ENV_OFFSET 512 -#define CONFIG_ENV_SIZE (2048 - 512) -#endif - -/*----------------------------------------------------------------------- - * Hard Reset Configuration Words - * - * if you change bits in the HRCW, you must also change the CONFIG_SYS_* - * defines for the various registers affected by the HRCW e.g. changing - * HRCW_DPPCxx requires you to also change CONFIG_SYS_SIUMCR. - */ -#if defined(CONFIG_BOOT_ROM) -#define CONFIG_SYS_HRCW_MASTER (HRCW_BPS01 | HRCW_CIP | HRCW_ISB100 | HRCW_BMS) -#else -#define CONFIG_SYS_HRCW_MASTER (HRCW_CIP | HRCW_ISB100 | HRCW_BMS) -#endif - -/* no slaves so just fill with zeros */ -#define CONFIG_SYS_HRCW_SLAVE1 0 -#define CONFIG_SYS_HRCW_SLAVE2 0 -#define CONFIG_SYS_HRCW_SLAVE3 0 -#define CONFIG_SYS_HRCW_SLAVE4 0 -#define CONFIG_SYS_HRCW_SLAVE5 0 -#define CONFIG_SYS_HRCW_SLAVE6 0 -#define CONFIG_SYS_HRCW_SLAVE7 0 - -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xF0000000 - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - * - * 60x SDRAM is mapped at CONFIG_SYS_SDRAM_BASE, local SDRAM - * is mapped at SDRAM_BASE2_PRELIM. - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_FLASH0_BASE -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc()*/ - -#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) -# define CONFIG_SYS_RAMBOOT -#endif - -#ifdef CONFIG_PCI -#define CONFIG_PCI_PNP -#define CONFIG_EEPRO100 -#define CONFIG_SYS_RX_ETH_BUFFER 8 /* use 8 rx buffer on eepro100 */ -#endif - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC8260 CPU */ -#if defined(CONFIG_CMD_KGDB) -# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * HIDx - Hardware Implementation-dependent Registers 2-11 - *----------------------------------------------------------------------- - * HID0 also contains cache control - initially enable both caches and - * invalidate contents, then the final state leaves only the instruction - * cache enabled. Note that Power-On and Hard reset invalidate the caches, - * but Soft reset does not. - * - * HID1 has only read-only information - nothing to set. - */ -#define CONFIG_SYS_HID0_INIT (HID0_ICE|HID0_DCE|HID0_ICFI|HID0_DCI|\ - HID0_IFEM|HID0_ABE) -#define CONFIG_SYS_HID0_FINAL (HID0_ICE|HID0_IFEM|HID0_ABE) -#define CONFIG_SYS_HID2 0 - -/*----------------------------------------------------------------------- - * RMR - Reset Mode Register 5-5 - *----------------------------------------------------------------------- - * turn on Checkstop Reset Enable - */ -#define CONFIG_SYS_RMR RMR_CSRE - -/*----------------------------------------------------------------------- - * BCR - Bus Configuration 4-25 - *----------------------------------------------------------------------- - */ - -#define BCR_APD01 0x10000000 -#define CONFIG_SYS_BCR (BCR_APD01|BCR_ETM|BCR_LETM) /* 8260 mode */ - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 4-31 - *----------------------------------------------------------------------- - */ -#if 0 -#define CONFIG_SYS_SIUMCR (SIUMCR_DPPC00|SIUMCR_APPC10|SIUMCR_CS10PC01) -#else -#define CONFIG_SYS_SIUMCR (SIUMCR_DPPC10|SIUMCR_APPC10) -#endif - - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 4-35 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Watchdog & Bus Monitor Timer max, 60x Bus Monitor enable - */ -#if defined(CONFIG_WATCHDOG) -#define CONFIG_SYS_SYPCR (SYPCR_SWTC|SYPCR_BMT|SYPCR_PBME|SYPCR_LBME|\ - SYPCR_SWRI|SYPCR_SWP|SYPCR_SWE) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC|SYPCR_BMT|SYPCR_PBME|SYPCR_LBME|\ - SYPCR_SWRI|SYPCR_SWP) -#endif /* CONFIG_WATCHDOG */ - -/*----------------------------------------------------------------------- - * TMCNTSC - Time Counter Status and Control 4-40 - *----------------------------------------------------------------------- - * Clear once per Second and Alarm Interrupt Status, Set 32KHz timersclk, - * and enable Time Counter - */ -#define CONFIG_SYS_TMCNTSC (TMCNTSC_SEC|TMCNTSC_ALR|TMCNTSC_TCF|TMCNTSC_TCE) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 4-42 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Set 32KHz timersclk, and enable - * Periodic timer - */ -#define CONFIG_SYS_PISCR (PISCR_PS|PISCR_PTF|PISCR_PTE) - -/*----------------------------------------------------------------------- - * SCCR - System Clock Control 9-8 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_SCCR (SCCR_DFBRG00) - -/*----------------------------------------------------------------------- - * RCCR - RISC Controller Configuration 13-7 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RCCR 0 - -/* - * Init Memory Controller: - * - * Bank Bus Machine PortSz Device - * ---- --- ------- ------ ------ - * 0 60x GPCM 64 bit FLASH - * 1 60x SDRAM 64 bit SDRAM - * - */ - - /* Initialize SDRAM on local bus - */ -#define CONFIG_SYS_INIT_LOCAL_SDRAM - - -/* Minimum mask to separate preliminary - * address ranges for CS[0:2] - */ -#define CONFIG_SYS_MIN_AM_MASK 0xC0000000 - -/* - * we use the same values for 32 MB and 128 MB SDRAM - * refresh rate = 7.73 uS (64 MHz Bus Clock) - */ -#define CONFIG_SYS_MPTPR 0x2000 -#define CONFIG_SYS_PSRT 0x0E - -#define CONFIG_SYS_MRS_OFFS 0x00000000 - - -#if defined(CONFIG_BOOT_ROM) -/* - * Bank 0 - Boot ROM (8 bit wide) - */ -#define CONFIG_SYS_BR0_PRELIM ((CONFIG_SYS_BOOTROM_BASE & BRx_BA_MSK)|\ - BRx_PS_8 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR0_PRELIM (P2SZ_TO_AM(CONFIG_SYS_BOOTROM_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_3_CLK |\ - ORxG_EHTR |\ - ORxG_TRLX) - -/* - * Bank 1 - Flash (64 bit wide) - */ -#define CONFIG_SYS_BR1_PRELIM ((CONFIG_SYS_FLASH_BASE & BRx_BA_MSK) |\ - BRx_PS_64 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR1_PRELIM (P2SZ_TO_AM(CONFIG_SYS_FLASH_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_3_CLK |\ - ORxG_EHTR |\ - ORxG_TRLX) - -#else /* ! CONFIG_BOOT_ROM */ - -/* - * Bank 0 - Flash (64 bit wide) - */ -#define CONFIG_SYS_BR0_PRELIM ((CONFIG_SYS_FLASH_BASE & BRx_BA_MSK) |\ - BRx_PS_64 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR0_PRELIM (P2SZ_TO_AM(CONFIG_SYS_FLASH_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_3_CLK |\ - ORxG_EHTR |\ - ORxG_TRLX) - -/* - * Bank 1 - Disk-On-Chip - */ -#define CONFIG_SYS_BR1_PRELIM ((CONFIG_SYS_DOC_BASE & BRx_BA_MSK) |\ - BRx_PS_8 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR1_PRELIM (P2SZ_TO_AM(CONFIG_SYS_DOC_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_3_CLK |\ - ORxG_EHTR |\ - ORxG_TRLX) - -#endif /* CONFIG_BOOT_ROM */ - -/* Bank 2 - SDRAM - */ - -#ifndef CONFIG_SYS_RAMBOOT -#define CONFIG_SYS_BR2_PRELIM ((CONFIG_SYS_SDRAM_BASE & BRx_BA_MSK) |\ - BRx_PS_64 |\ - BRx_MS_SDRAM_P |\ - BRx_V) - - /* SDRAM initialization values for 8-column chips - */ -#define CONFIG_SYS_OR2_8COL (CONFIG_SYS_MIN_AM_MASK |\ - ORxS_BPD_4 |\ - ORxS_ROWST_PBI0_A9 |\ - ORxS_NUMR_12) - -#define CONFIG_SYS_PSDMR_8COL (PSDMR_SDAM_A13_IS_A5 |\ - PSDMR_BSMA_A14_A16 |\ - PSDMR_SDA10_PBI0_A10 |\ - PSDMR_RFRC_7_CLK |\ - PSDMR_PRETOACT_2W |\ - PSDMR_ACTTORW_1W |\ - PSDMR_LDOTOPRE_1C |\ - PSDMR_WRC_1C |\ - PSDMR_CL_2) - - /* SDRAM initialization values for 9-column chips - */ -#define CONFIG_SYS_OR2_9COL (CONFIG_SYS_MIN_AM_MASK |\ - ORxS_BPD_4 |\ - ORxS_ROWST_PBI0_A7 |\ - ORxS_NUMR_13) - -#define CONFIG_SYS_PSDMR_9COL (PSDMR_SDAM_A14_IS_A5 |\ - PSDMR_BSMA_A13_A15 |\ - PSDMR_SDA10_PBI0_A9 |\ - PSDMR_RFRC_7_CLK |\ - PSDMR_PRETOACT_2W |\ - PSDMR_ACTTORW_1W |\ - PSDMR_LDOTOPRE_1C |\ - PSDMR_WRC_1C |\ - PSDMR_CL_2) - -#define CONFIG_SYS_OR2_PRELIM CONFIG_SYS_OR2_9COL -#define CONFIG_SYS_PSDMR CONFIG_SYS_PSDMR_9COL - -#endif /* CONFIG_SYS_RAMBOOT */ - -#endif /* __CONFIG_H */ diff --git a/include/configs/PM828.h b/include/configs/PM828.h deleted file mode 100644 index e17fbfb..0000000 --- a/include/configs/PM828.h +++ /dev/null @@ -1,528 +0,0 @@ -/* - * (C) Copyright 2001-2005 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -#undef CONFIG_SYS_RAMBOOT - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_PM828 1 /* ...on a PM828 module */ -#define CONFIG_CPM2 1 /* Has a CPM2 */ - -#ifndef CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_TEXT_BASE 0x40000000 /* Standard: boot 64-bit flash */ -#endif - -#undef CONFIG_DB_CR826_J30x_ON /* J30x jumpers on D.B. carrier */ - -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ - -#define CONFIG_PREBOOT "echo;echo Type \"run flash_nfs\" to mount root filesystem over NFS;echo" - -#undef CONFIG_BOOTARGS -#define CONFIG_BOOTCOMMAND \ - "bootp;" \ - "setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off;" \ - "bootm" - -/* enable I2C and select the hardware/software driver */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_SOFT /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SOFT_SPEED 50000 -#define CONFIG_SYS_I2C_SOFT_SLAVE 0xFE -/* - * Software (bit-bang) I2C driver configuration - */ -#define I2C_PORT 3 /* Port A=0, B=1, C=2, D=3 */ -#define I2C_ACTIVE (iop->pdir |= 0x00010000) -#define I2C_TRISTATE (iop->pdir &= ~0x00010000) -#define I2C_READ ((iop->pdat & 0x00010000) != 0) -#define I2C_SDA(bit) if(bit) iop->pdat |= 0x00010000; \ - else iop->pdat &= ~0x00010000 -#define I2C_SCL(bit) if(bit) iop->pdat |= 0x00020000; \ - else iop->pdat &= ~0x00020000 -#define I2C_DELAY udelay(5) /* 1/4 I2C clock duration */ - - -#define CONFIG_RTC_PCF8563 -#define CONFIG_SYS_I2C_RTC_ADDR 0x51 - -/* - * select serial console configuration - * - * if either CONFIG_CONS_ON_SMC or CONFIG_CONS_ON_SCC is selected, then - * CONFIG_CONS_INDEX must be set to the channel number (1-2 for SMC, 1-4 - * for SCC). - * - * if CONFIG_CONS_NONE is defined, then the serial console routines must - * defined elsewhere (for example, on the cogent platform, there are serial - * ports on the motherboard which are used for the serial console - see - * cogent/cma101/serial.[ch]). - */ -#define CONFIG_CONS_ON_SMC /* define if console on SMC */ -#undef CONFIG_CONS_ON_SCC /* define if console on SCC */ -#undef CONFIG_CONS_NONE /* define if console on something else*/ -#define CONFIG_CONS_INDEX 2 /* which serial channel for console */ - -/* - * select ethernet configuration - * - * if CONFIG_ETHER_ON_SCC is selected, then - * - CONFIG_ETHER_INDEX must be set to the channel number (1-4) - * - * if CONFIG_ETHER_ON_FCC is selected, then - * - one or more CONFIG_ETHER_ON_FCCx (x=1,2,3) must also be selected - * - * if CONFIG_ETHER_NONE is defined, then either the ethernet routines must be - * defined elsewhere (as for the console), or CONFIG_CMD_NET must be unset. - */ -#undef CONFIG_ETHER_NONE /* define if ether on something else */ - -#undef CONFIG_ETHER_ON_SCC /* define if ether on SCC */ -#define CONFIG_ETHER_INDEX 1 /* which SCC channel for ethernet */ - -#define CONFIG_ETHER_ON_FCC /* define if ether on FCC */ -/* - * - Rx-CLK is CLK11 - * - Tx-CLK is CLK10 - */ -#define CONFIG_ETHER_ON_FCC1 -# define CONFIG_SYS_CMXFCR_MASK1 (CMXFCR_FC1|CMXFCR_RF1CS_MSK|CMXFCR_TF1CS_MSK) -#ifndef CONFIG_DB_CR826_J30x_ON -# define CONFIG_SYS_CMXFCR_VALUE1 (CMXFCR_RF1CS_CLK11|CMXFCR_TF1CS_CLK10) -#else -# define CONFIG_SYS_CMXFCR_VALUE1 (CMXFCR_RF1CS_CLK11|CMXFCR_TF1CS_CLK12) -#endif -/* - * - Rx-CLK is CLK15 - * - Tx-CLK is CLK14 - */ -#define CONFIG_ETHER_ON_FCC2 -# define CONFIG_SYS_CMXFCR_MASK2 (CMXFCR_FC2|CMXFCR_RF2CS_MSK|CMXFCR_TF2CS_MSK) -# define CONFIG_SYS_CMXFCR_VALUE2 (CMXFCR_RF2CS_CLK13|CMXFCR_TF2CS_CLK14) -/* - * - RAM for BD/Buffers is on the 60x Bus (see 28-13) - * - Enable Full Duplex in FSMR - */ -# define CONFIG_SYS_CPMFCR_RAMTYPE 0 -# define CONFIG_SYS_FCC_PSMR (FCC_PSMR_FDE|FCC_PSMR_LPB) - -/* system clock rate (CLKIN) - equal to the 60x and local bus speed */ -#define CONFIG_8260_CLKIN 100000000 /* in Hz */ - -#if defined(CONFIG_CONS_NONE) || defined(CONFIG_CONS_USE_EXTC) -#define CONFIG_BAUDRATE 230400 -#else -#define CONFIG_BAUDRATE 9600 -#endif - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_BEDBUG -#define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C -#define CONFIG_CMD_NFS -#define CONFIG_CMD_SNTP - -#ifdef CONFIG_PCI -#define CONFIG_PCI_INDIRECT_BRIDGE -#define CONFIG_CMD_PCI -#endif - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -#define CONFIG_SYS_RESET_ADDRESS 0xFDFFFFFC /* "bad" address */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * Flash and Boot ROM mapping - */ - -#define CONFIG_SYS_BOOTROM_BASE 0xFF800000 -#define CONFIG_SYS_BOOTROM_SIZE 0x00080000 -#define CONFIG_SYS_FLASH0_BASE 0x40000000 -#define CONFIG_SYS_FLASH0_SIZE 0x02000000 -#define CONFIG_SYS_DOC_BASE 0xFF800000 -#define CONFIG_SYS_DOC_SIZE 0x00100000 - - -/* Flash bank size (for preliminary settings) - */ -#define CONFIG_SYS_FLASH_SIZE CONFIG_SYS_FLASH0_SIZE - -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max num of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 135 /* max num of sects on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 240000 /* Flash Erase Timeout (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (in ms) */ - -#if 0 -/* Start port with environment in flash; switch to EEPROM later */ -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE+0x40000) -#define CONFIG_ENV_SIZE 0x40000 -#define CONFIG_ENV_SECT_SIZE 0x40000 -#else -/* Final version: environment in EEPROM */ -#define CONFIG_ENV_IS_IN_EEPROM 1 -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x58 -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CONFIG_ENV_OFFSET 512 -#define CONFIG_ENV_SIZE (2048 - 512) -#endif - -/*----------------------------------------------------------------------- - * Hard Reset Configuration Words - * - * if you change bits in the HRCW, you must also change the CONFIG_SYS_* - * defines for the various registers affected by the HRCW e.g. changing - * HRCW_DPPCxx requires you to also change CONFIG_SYS_SIUMCR. - */ -#if defined(CONFIG_BOOT_ROM) -#define CONFIG_SYS_HRCW_MASTER (HRCW_BPS01 | HRCW_CIP | HRCW_ISB100 | HRCW_BMS) -#else -#define CONFIG_SYS_HRCW_MASTER (HRCW_CIP | HRCW_ISB100 | HRCW_BMS) -#endif - -/* no slaves so just fill with zeros */ -#define CONFIG_SYS_HRCW_SLAVE1 0 -#define CONFIG_SYS_HRCW_SLAVE2 0 -#define CONFIG_SYS_HRCW_SLAVE3 0 -#define CONFIG_SYS_HRCW_SLAVE4 0 -#define CONFIG_SYS_HRCW_SLAVE5 0 -#define CONFIG_SYS_HRCW_SLAVE6 0 -#define CONFIG_SYS_HRCW_SLAVE7 0 - -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xF0000000 - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - * - * 60x SDRAM is mapped at CONFIG_SYS_SDRAM_BASE, local SDRAM - * is mapped at SDRAM_BASE2_PRELIM. - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_FLASH0_BASE -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc()*/ - -#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) -# define CONFIG_SYS_RAMBOOT -#endif - -#ifdef CONFIG_PCI -#define CONFIG_PCI_PNP -#define CONFIG_EEPRO100 -#define CONFIG_SYS_RX_ETH_BUFFER 8 /* use 8 rx buffer on eepro100 */ -#endif - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC8260 CPU */ -#if defined(CONFIG_CMD_KGDB) -# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * HIDx - Hardware Implementation-dependent Registers 2-11 - *----------------------------------------------------------------------- - * HID0 also contains cache control - initially enable both caches and - * invalidate contents, then the final state leaves only the instruction - * cache enabled. Note that Power-On and Hard reset invalidate the caches, - * but Soft reset does not. - * - * HID1 has only read-only information - nothing to set. - */ -#define CONFIG_SYS_HID0_INIT (HID0_ICE|HID0_DCE|HID0_ICFI|HID0_DCI|\ - HID0_IFEM|HID0_ABE) -#define CONFIG_SYS_HID0_FINAL (HID0_ICE|HID0_IFEM|HID0_ABE) -#define CONFIG_SYS_HID2 0 - -/*----------------------------------------------------------------------- - * RMR - Reset Mode Register 5-5 - *----------------------------------------------------------------------- - * turn on Checkstop Reset Enable - */ -#define CONFIG_SYS_RMR RMR_CSRE - -/*----------------------------------------------------------------------- - * BCR - Bus Configuration 4-25 - *----------------------------------------------------------------------- - */ - -#define BCR_APD01 0x10000000 -#define CONFIG_SYS_BCR (BCR_APD01|BCR_ETM|BCR_LETM) /* 8260 mode */ - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 4-31 - *----------------------------------------------------------------------- - */ -#if 0 -#define CONFIG_SYS_SIUMCR (SIUMCR_DPPC00|SIUMCR_APPC10|SIUMCR_CS10PC01) -#else -#define CONFIG_SYS_SIUMCR (SIUMCR_DPPC10|SIUMCR_APPC10) -#endif - - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 4-35 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Watchdog & Bus Monitor Timer max, 60x Bus Monitor enable - */ -#if defined(CONFIG_WATCHDOG) -#define CONFIG_SYS_SYPCR (SYPCR_SWTC|SYPCR_BMT|SYPCR_PBME|SYPCR_LBME|\ - SYPCR_SWRI|SYPCR_SWP|SYPCR_SWE) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC|SYPCR_BMT|SYPCR_PBME|SYPCR_LBME|\ - SYPCR_SWRI|SYPCR_SWP) -#endif /* CONFIG_WATCHDOG */ - -/*----------------------------------------------------------------------- - * TMCNTSC - Time Counter Status and Control 4-40 - *----------------------------------------------------------------------- - * Clear once per Second and Alarm Interrupt Status, Set 32KHz timersclk, - * and enable Time Counter - */ -#define CONFIG_SYS_TMCNTSC (TMCNTSC_SEC|TMCNTSC_ALR|TMCNTSC_TCF|TMCNTSC_TCE) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 4-42 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Set 32KHz timersclk, and enable - * Periodic timer - */ -#define CONFIG_SYS_PISCR (PISCR_PS|PISCR_PTF|PISCR_PTE) - -/*----------------------------------------------------------------------- - * SCCR - System Clock Control 9-8 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_SCCR (SCCR_DFBRG00) - -/*----------------------------------------------------------------------- - * RCCR - RISC Controller Configuration 13-7 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RCCR 0 - -/* - * Init Memory Controller: - * - * Bank Bus Machine PortSz Device - * ---- --- ------- ------ ------ - * 0 60x GPCM 64 bit FLASH - * 1 60x SDRAM 64 bit SDRAM - * - */ - - /* Initialize SDRAM on local bus - */ -#define CONFIG_SYS_INIT_LOCAL_SDRAM - - -/* Minimum mask to separate preliminary - * address ranges for CS[0:2] - */ -#define CONFIG_SYS_MIN_AM_MASK 0xC0000000 - -/* - * we use the same values for 32 MB and 128 MB SDRAM - * refresh rate = 7.68 uS (100 MHz Bus Clock) - */ -#define CONFIG_SYS_MPTPR 0x2000 -#define CONFIG_SYS_PSRT 0x16 - -#define CONFIG_SYS_MRS_OFFS 0x00000000 - - -#if defined(CONFIG_BOOT_ROM) -/* - * Bank 0 - Boot ROM (8 bit wide) - */ -#define CONFIG_SYS_BR0_PRELIM ((CONFIG_SYS_BOOTROM_BASE & BRx_BA_MSK)|\ - BRx_PS_8 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR0_PRELIM (P2SZ_TO_AM(CONFIG_SYS_BOOTROM_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_5_CLK |\ - ORxG_EHTR |\ - ORxG_TRLX) - -/* - * Bank 1 - Flash (64 bit wide) - */ -#define CONFIG_SYS_BR1_PRELIM ((CONFIG_SYS_FLASH_BASE & BRx_BA_MSK) |\ - BRx_PS_64 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR1_PRELIM (P2SZ_TO_AM(CONFIG_SYS_FLASH_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_5_CLK |\ - ORxG_EHTR |\ - ORxG_TRLX) - -#else /* ! CONFIG_BOOT_ROM */ - -/* - * Bank 0 - Flash (64 bit wide) - */ -#define CONFIG_SYS_BR0_PRELIM ((CONFIG_SYS_FLASH_BASE & BRx_BA_MSK) |\ - BRx_PS_64 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR0_PRELIM (P2SZ_TO_AM(CONFIG_SYS_FLASH_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_5_CLK |\ - ORxG_EHTR |\ - ORxG_TRLX) - -/* - * Bank 1 - Disk-On-Chip - */ -#define CONFIG_SYS_BR1_PRELIM ((CONFIG_SYS_DOC_BASE & BRx_BA_MSK) |\ - BRx_PS_8 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR1_PRELIM (P2SZ_TO_AM(CONFIG_SYS_DOC_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_5_CLK |\ - ORxG_EHTR |\ - ORxG_TRLX) - -#endif /* CONFIG_BOOT_ROM */ - -/* Bank 2 - SDRAM - */ - -#ifndef CONFIG_SYS_RAMBOOT -#define CONFIG_SYS_BR2_PRELIM ((CONFIG_SYS_SDRAM_BASE & BRx_BA_MSK) |\ - BRx_PS_64 |\ - BRx_MS_SDRAM_P |\ - BRx_V) - - /* SDRAM initialization values for 8-column chips - */ -#define CONFIG_SYS_OR2_8COL (CONFIG_SYS_MIN_AM_MASK |\ - ORxS_BPD_4 |\ - ORxS_ROWST_PBI0_A9 |\ - ORxS_NUMR_12) - -#define CONFIG_SYS_PSDMR_8COL (PSDMR_SDAM_A13_IS_A5 |\ - PSDMR_BSMA_A14_A16 |\ - PSDMR_SDA10_PBI0_A10 |\ - PSDMR_RFRC_7_CLK |\ - PSDMR_PRETOACT_2W |\ - PSDMR_ACTTORW_2W |\ - PSDMR_LDOTOPRE_1C |\ - PSDMR_WRC_1C |\ - PSDMR_CL_2) - - /* SDRAM initialization values for 9-column chips - */ -#define CONFIG_SYS_OR2_9COL (CONFIG_SYS_MIN_AM_MASK |\ - ORxS_BPD_4 |\ - ORxS_ROWST_PBI0_A7 |\ - ORxS_NUMR_13) - -#define CONFIG_SYS_PSDMR_9COL (PSDMR_SDAM_A14_IS_A5 |\ - PSDMR_BSMA_A13_A15 |\ - PSDMR_SDA10_PBI0_A9 |\ - PSDMR_RFRC_7_CLK |\ - PSDMR_PRETOACT_2W |\ - PSDMR_ACTTORW_2W |\ - PSDMR_LDOTOPRE_1C |\ - PSDMR_WRC_1C |\ - PSDMR_CL_2) - -#define CONFIG_SYS_OR2_PRELIM CONFIG_SYS_OR2_9COL -#define CONFIG_SYS_PSDMR CONFIG_SYS_PSDMR_9COL - -#endif /* CONFIG_SYS_RAMBOOT */ - -#endif /* __CONFIG_H */
On Mon, Dec 15, 2014 at 11:26:24PM +0900, Masahiro Yamada wrote:
These boards are still non-generic boards.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Wolfgang Denk wd@denx.de
This board is still a non-generic board.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Heiko Schocher hs@denx.de ---
arch/powerpc/cpu/mpc8260/Kconfig | 4 - board/muas3001/Kconfig | 9 - board/muas3001/MAINTAINERS | 7 - board/muas3001/Makefile | 8 - board/muas3001/muas3001.c | 335 --------------------------------- configs/muas3001_defconfig | 3 - configs/muas3001_dev_defconfig | 4 - doc/README.scrapyard | 1 + include/configs/muas3001.h | 391 --------------------------------------- 9 files changed, 1 insertion(+), 761 deletions(-) delete mode 100644 board/muas3001/Kconfig delete mode 100644 board/muas3001/MAINTAINERS delete mode 100644 board/muas3001/Makefile delete mode 100644 board/muas3001/muas3001.c delete mode 100644 configs/muas3001_defconfig delete mode 100644 configs/muas3001_dev_defconfig delete mode 100644 include/configs/muas3001.h
diff --git a/arch/powerpc/cpu/mpc8260/Kconfig b/arch/powerpc/cpu/mpc8260/Kconfig index cb81cdc..2b3c9c2 100644 --- a/arch/powerpc/cpu/mpc8260/Kconfig +++ b/arch/powerpc/cpu/mpc8260/Kconfig @@ -25,9 +25,6 @@ config TARGET_GW8260 config TARGET_IPHASE4539 bool "Support IPHASE4539"
-config TARGET_MUAS3001 - bool "Support muas3001" - config TARGET_KM82XX bool "Support km82xx"
@@ -40,6 +37,5 @@ source "board/ep82xxm/Kconfig" source "board/gw8260/Kconfig" source "board/iphase4539/Kconfig" source "board/keymile/km82xx/Kconfig" -source "board/muas3001/Kconfig"
endmenu diff --git a/board/muas3001/Kconfig b/board/muas3001/Kconfig deleted file mode 100644 index 94a00b3..0000000 --- a/board/muas3001/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_MUAS3001 - -config SYS_BOARD - default "muas3001" - -config SYS_CONFIG_NAME - default "muas3001" - -endif diff --git a/board/muas3001/MAINTAINERS b/board/muas3001/MAINTAINERS deleted file mode 100644 index cfb5983..0000000 --- a/board/muas3001/MAINTAINERS +++ /dev/null @@ -1,7 +0,0 @@ -MUAS3001 BOARD -M: Heiko Schocher hs@denx.de -S: Maintained -F: board/muas3001/ -F: include/configs/muas3001.h -F: configs/muas3001_defconfig -F: configs/muas3001_dev_defconfig diff --git a/board/muas3001/Makefile b/board/muas3001/Makefile deleted file mode 100644 index ef04960..0000000 --- a/board/muas3001/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2001-2008 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y := muas3001.o diff --git a/board/muas3001/muas3001.c b/board/muas3001/muas3001.c deleted file mode 100644 index e0c4dba..0000000 --- a/board/muas3001/muas3001.c +++ /dev/null @@ -1,335 +0,0 @@ -/* - * (C) Copyright 2008 - * Heiko Schocher, DENX Software Engineering, hs@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc8260.h> -#include <ioports.h> - -#if defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) -#include <libfdt.h> -#endif - -/* - * I/O Port configuration table - * - * if conf is 1, then that port pin will be configured at boot time - * according to the five values podr/pdir/ppar/psor/pdat for that entry - */ -const iop_conf_t iop_conf_tab[4][32] = { - - /* Port A */ - { /* conf ppar psor pdir podr pdat */ - /* PA31 */ { 0, 0, 0, 0, 0, 0 }, /* PA31 */ - /* PA30 */ { 0, 0, 0, 0, 0, 0 }, /* PA30 */ - /* PA29 */ { 1, 1, 1, 1, 0, 0 }, /* FCC1 TXER */ - /* PA28 */ { 1, 1, 1, 1, 0, 0 }, /* FCC1 TXEN */ - /* PA27 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 RXDV */ - /* PA26 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 RXER */ - /* PA25 */ { 1, 0, 0, 1, 0, 0 }, /* ETH_PWRDWN */ - /* PA24 */ { 1, 0, 0, 1, 0, 1 }, /* ETH_RESET */ - /* PA23 */ { 0, 0, 0, 0, 0, 0 }, /* PA23 */ - /* PA22 */ { 0, 0, 0, 0, 0, 0 }, /* PA22 */ - /* PA21 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 TXD3 */ - /* PA20 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 TXD2 */ - /* PA19 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 TXD1 */ - /* PA18 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 TXD0 */ - /* PA17 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 RXD0 */ - /* PA16 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 RXD1 */ - /* PA15 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 RXD2 */ - /* PA14 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 RXD3 */ - /* PA13 */ { 0, 0, 0, 0, 0, 0 }, /* PA13 */ - /* PA12 */ { 1, 0, 0, 1, 0, 0 }, /* ETH_SLEEP */ - /* PA11 */ { 0, 0, 0, 0, 0, 0 }, /* PA11 */ - /* PA10 */ { 1, 0, 0, 1, 0, 0 }, /* MDIO */ - /* PA9 */ { 1, 0, 0, 1, 0, 0 }, /* MDC */ - /* PA8 */ { 1, 1, 0, 0, 0, 0 }, /* SMC2 RxD */ - /* PA7 */ { 0, 0, 0, 0, 0, 0 }, /* PA7 */ - /* PA6 */ { 0, 0, 0, 0, 0, 0 }, /* PA6 */ - /* PA5 */ { 0, 0, 0, 0, 0, 0 }, /* PA5 */ - /* PA4 */ { 0, 0, 0, 0, 0, 0 }, /* PA4 */ - /* PA3 */ { 0, 0, 0, 0, 0, 0 }, /* PA3 */ - /* PA2 */ { 0, 0, 0, 0, 0, 0 }, /* PA2 */ - /* PA1 */ { 0, 0, 0, 0, 0, 0 }, /* PA1 */ - /* PA0 */ { 0, 0, 0, 0, 0, 0 } /* PA0 */ - }, - - /* Port B */ - { /* conf ppar psor pdir podr pdat */ - /* PB31 */ { 0, 0, 0, 0, 0, 0 }, /* PB31 */ - /* PB30 */ { 0, 0, 0, 0, 0, 0 }, /* PB30 */ - /* PB29 */ { 0, 0, 0, 0, 0, 0 }, /* PB29 */ - /* PB28 */ { 1, 1, 1, 1, 0, 0 }, /* SCC1 TxD */ - /* PB27 */ { 0, 0, 0, 0, 0, 0 }, /* PB27 */ - /* PB26 */ { 0, 0, 0, 0, 0, 0 }, /* PB26 */ - /* PB25 */ { 0, 0, 0, 0, 0, 0 }, /* PB25 */ - /* PB24 */ { 0, 0, 0, 0, 0, 0 }, /* PB24 */ - /* PB23 */ { 0, 0, 0, 0, 0, 0 }, /* PB23 */ - /* PB22 */ { 0, 0, 0, 0, 0, 0 }, /* PB22 */ - /* PB21 */ { 0, 0, 0, 0, 0, 0 }, /* PB21 */ - /* PB20 */ { 0, 0, 0, 0, 0, 0 }, /* PB20 */ - /* PB19 */ { 0, 0, 0, 0, 0, 0 }, /* PB19 */ - /* PB18 */ { 0, 0, 0, 0, 0, 0 }, /* PB18 */ - /* PB17 */ { 0, 0, 0, 0, 0, 0 }, /* non-existent */ - /* PB16 */ { 0, 0, 0, 0, 0, 0 }, /* non-existent */ - /* PB15 */ { 1, 1, 0, 0, 0, 0 }, /* SCC2 RxD */ - /* PB14 */ { 1, 1, 0, 0, 0, 0 }, /* SCC3 RxD */ - /* PB13 */ { 0, 0, 0, 0, 0, 0 }, /* non-existent */ - /* PB12 */ { 1, 1, 1, 1, 0, 0 }, /* SCC2 TxD */ - /* PB11 */ { 0, 0, 0, 0, 0, 0 }, /* non-existent */ - /* PB10 */ { 0, 0, 0, 0, 0, 0 }, /* non-existent */ - /* PB9 */ { 0, 0, 0, 0, 0, 0 }, /* non-existent */ - /* PB8 */ { 1, 1, 1, 1, 0, 0 }, /* SCC3 TxD */ - /* PB7 */ { 0, 0, 0, 0, 0, 0 }, /* non-existent */ - /* PB6 */ { 0, 0, 0, 0, 0, 0 }, /* non-existent */ - /* PB5 */ { 0, 0, 0, 0, 0, 0 }, /* non-existent */ - /* PB4 */ { 0, 0, 0, 0, 0, 0 }, /* non-existent */ - /* PB3 */ { 0, 0, 0, 0, 0, 0 }, /* non-existent */ - /* PB2 */ { 0, 0, 0, 0, 0, 0 }, /* non-existent */ - /* PB1 */ { 0, 0, 0, 0, 0, 0 }, /* non-existent */ - /* PB0 */ { 0, 0, 0, 0, 0, 0 } /* non-existent */ - }, - - /* Port C */ - { /* conf ppar psor pdir podr pdat */ - /* PC31 */ { 0, 0, 0, 0, 0, 0 }, /* PC31 */ - /* PC30 */ { 1, 1, 1, 1, 0, 0 }, /* Timer1 OUT */ - /* PC29 */ { 0, 0, 0, 0, 0, 0 }, /* PC29 */ - /* PC28 */ { 0, 0, 0, 0, 0, 0 }, /* PC28 */ - /* PC27 */ { 0, 0, 0, 0, 0, 0 }, /* PC27 */ - /* PC26 */ { 0, 0, 0, 0, 0, 0 }, /* PC26 */ - /* PC25 */ { 0, 0, 0, 0, 0, 0 }, /* PC25 */ - /* PC24 */ { 0, 0, 0, 0, 0, 0 }, /* PC24 */ - /* PC23 */ { 0, 0, 0, 0, 0, 0 }, /* PC23 */ - /* PC22 */ { 0, 0, 0, 0, 0, 0 }, /* PC22 */ - /* PC21 */ { 1, 1, 0, 0, 0, 0 }, /* FCC RxCLK 11 */ - /* PC20 */ { 1, 1, 0, 0, 0, 0 }, /* FCC TxCLK 12 */ - /* PC19 */ { 0, 0, 0, 0, 0, 0 }, /* PC19 */ - /* PC18 */ { 0, 0, 0, 0, 0, 0 }, /* PC18 */ - /* PC17 */ { 0, 0, 0, 0, 0, 0 }, /* PC17 */ - /* PC16 */ { 0, 0, 0, 0, 0, 0 }, /* PC16 */ - /* PC15 */ { 1, 1, 0, 1, 0, 0 }, /* SMC2 TxD */ - /* PC14 */ { 0, 0, 0, 0, 0, 0 }, /* PC14 */ - /* PC13 */ { 0, 0, 0, 0, 0, 0 }, /* PC13 */ - /* PC12 */ { 1, 0, 0, 1, 0, 0 }, /* TX OUTPUT SLEW1 */ - /* PC11 */ { 1, 0, 0, 1, 0, 0 }, /* TX OUTPUT SLEW0 */ - /* PC10 */ { 0, 0, 0, 0, 0, 0 }, /* PC10 */ - /* PC9 */ { 1, 0, 0, 1, 0, 1 }, /* SPA_TX_EN */ - /* PC8 */ { 0, 0, 0, 0, 0, 0 }, /* PC8 */ - /* PC7 */ { 0, 0, 0, 0, 0, 0 }, /* PC7 */ - /* PC6 */ { 0, 0, 0, 0, 0, 0 }, /* PC6 */ - /* PC5 */ { 0, 0, 0, 0, 0, 0 }, /* PC5 */ - /* PC4 */ { 0, 0, 0, 0, 0, 0 }, /* PC4 */ - /* PC3 */ { 0, 0, 0, 0, 0, 0 }, /* PC3 */ - /* PC2 */ { 0, 0, 0, 0, 0, 0 }, /* PC2 */ - /* PC1 */ { 0, 0, 0, 0, 0, 0 }, /* PC1 */ - /* PC0 */ { 0, 0, 0, 0, 0, 0 }, /* PC0 */ - }, - - /* Port D */ - { /* conf ppar psor pdir podr pdat */ - /* PD31 */ { 1, 1, 0, 0, 0, 0 }, /* SCC1 RxD */ - /* PD30 */ { 0, 0, 0, 0, 0, 0 }, /* PD30 */ - /* PD29 */ { 0, 0, 0, 0, 0, 0 }, /* PD29 */ - /* PD28 */ { 0, 0, 0, 0, 0, 0 }, /* PD28 */ - /* PD27 */ { 0, 0, 0, 0, 0, 0 }, /* PD27 */ - /* PD26 */ { 0, 0, 0, 0, 0, 0 }, /* PD26 */ - /* PD25 */ { 0, 0, 0, 0, 0, 0 }, /* PD25 */ - /* PD24 */ { 0, 0, 0, 0, 0, 0 }, /* PD24 */ - /* PD23 */ { 0, 0, 0, 0, 0, 0 }, /* PD23 */ - /* PD22 */ { 1, 1, 0, 0, 0, 0 }, /* SCC4: RXD */ - /* PD21 */ { 1, 1, 0, 1, 0, 0 }, /* SCC4: TXD */ - /* PD20 */ { 0, 0, 0, 0, 0, 0 }, /* PD18 */ - /* PD19 */ { 0, 0, 0, 0, 0, 0 }, /* PD19 */ - /* PD18 */ { 0, 0, 0, 0, 0, 0 }, /* PD18 */ - /* PD17 */ { 0, 0, 0, 0, 0, 0 }, /* PD17 */ - /* PD16 */ { 0, 0, 0, 0, 0, 0 }, /* PD16 */ -#if defined(CONFIG_HARD_I2C) - /* PD15 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SDA */ - /* PD14 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SCL */ -#else - /* PD15 */ { 1, 0, 0, 0, 1, 1 }, /* PD15 */ - /* PD14 */ { 1, 0, 0, 1, 1, 1 }, /* PD14 */ -#endif - /* PD13 */ { 0, 0, 0, 0, 0, 0 }, /* PD13 */ - /* PD12 */ { 0, 0, 0, 0, 0, 0 }, /* PD12 */ - /* PD11 */ { 0, 0, 0, 0, 0, 0 }, /* PD11 */ - /* PD10 */ { 0, 0, 0, 0, 0, 0 }, /* PD10 */ - /* PD9 */ { 1, 1, 0, 1, 0, 0 }, /* SMC1 TxD */ - /* PD8 */ { 1, 1, 0, 0, 0, 0 }, /* SMC1 RxD */ - /* PD7 */ { 0, 0, 0, 0, 0, 0 }, /* PD7 */ - /* PD6 */ { 0, 0, 0, 0, 0, 0 }, /* PD6 */ - /* PD5 */ { 0, 0, 0, 0, 0, 0 }, /* PD5 */ - /* PD4 */ { 0, 0, 0, 0, 0, 0 }, /* PD4 */ - /* PD3 */ { 0, 0, 0, 0, 0, 0 }, /* non-existent */ - /* PD2 */ { 0, 0, 0, 0, 0, 0 }, /* non-existent */ - /* PD1 */ { 0, 0, 0, 0, 0, 0 }, /* non-existent */ - /* PD0 */ { 0, 0, 0, 0, 0, 0 } /* non-existent */ - } -}; - -/* Try SDRAM initialization with P/LSDMR=sdmr and ORx=orx - * - * This routine performs standard 8260 initialization sequence - * and calculates the available memory size. It may be called - * several times to try different SDRAM configurations on both - * 60x and local buses. - */ -static long int try_init (volatile memctl8260_t * memctl, ulong sdmr, - ulong orx, volatile uchar * base) -{ - volatile uchar c = 0xff; - volatile uint *sdmr_ptr; - volatile uint *orx_ptr; - ulong maxsize, size; - int i; - - /* We must be able to test a location outsize the maximum legal size - * to find out THAT we are outside; but this address still has to be - * mapped by the controller. That means, that the initial mapping has - * to be (at least) twice as large as the maximum expected size. - */ - maxsize = (1 + (~orx | 0x7fff))/* / 2*/; - - sdmr_ptr = &memctl->memc_psdmr; - orx_ptr = &memctl->memc_or1; - - *orx_ptr = orx; - - /* - * Quote from 8260 UM (10.4.2 SDRAM Power-On Initialization, 10-35): - * - * "At system reset, initialization software must set up the - * programmable parameters in the memory controller banks registers - * (ORx, BRx, P/LSDMR). After all memory parameters are configured, - * system software should execute the following initialization sequence - * for each SDRAM device. - * - * 1. Issue a PRECHARGE-ALL-BANKS command - * 2. Issue eight CBR REFRESH commands - * 3. Issue a MODE-SET command to initialize the mode register - * - * The initial commands are executed by setting P/LSDMR[OP] and - * accessing the SDRAM with a single-byte transaction." - * - * The appropriate BRx/ORx registers have already been set when we - * get here. The SDRAM can be accessed at the address CONFIG_SYS_SDRAM_BASE. - */ - - *sdmr_ptr = sdmr | PSDMR_OP_PREA; - *base = c; - - *sdmr_ptr = sdmr | PSDMR_OP_CBRR; - for (i = 0; i < 8; i++) - *base = c; - - *sdmr_ptr = sdmr | PSDMR_OP_MRW; - *(base + CONFIG_SYS_MRS_OFFS) = c; /* setting MR on address lines */ - - *sdmr_ptr = sdmr | PSDMR_OP_NORM | PSDMR_RFEN; - *base = c; - - size = get_ram_size ((long *)base, maxsize); - *orx_ptr = orx | ~(size - 1); - - return (size); -} - -phys_size_t initdram (int board_type) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8260_t *memctl = &immap->im_memctl; - long psize; - long sizelittle, sizebig; - - memctl->memc_psrt = CONFIG_SYS_PSRT; - memctl->memc_mptpr = CONFIG_SYS_MPTPR; - - /* 60x SDRAM setup: - */ - sizelittle = try_init (memctl, CONFIG_SYS_PSDMR_LITTLE, CONFIG_SYS_OR1_LITTLE, - (uchar *) CONFIG_SYS_SDRAM_BASE); - sizebig = try_init (memctl, CONFIG_SYS_PSDMR_BIG, CONFIG_SYS_OR1_BIG, - (uchar *) CONFIG_SYS_SDRAM_BASE); - if (sizelittle < sizebig) { - psize = sizebig; - } else { - psize = try_init (memctl, CONFIG_SYS_PSDMR_LITTLE, CONFIG_SYS_OR1_LITTLE, - (uchar *) CONFIG_SYS_SDRAM_BASE); - } - - icache_enable (); - - return (psize); -} - -int checkboard (void) -{ - puts ("Board: MUAS3001\n"); - - return 0; -} - -/* - * Early board initalization. - */ -int board_early_init_r (void) -{ - return 0; -} - -#if defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) -DECLARE_GLOBAL_DATA_PTR; - -/* - * update "memory" property in the blob - */ -void ft_blob_update (void *blob, bd_t *bd) -{ - int ret, nodeoffset = 0; - ulong flash_data[4] = {0}; - ulong speed = 0; - - /* update Flash addr, size */ - flash_data[2] = cpu_to_be32 (CONFIG_SYS_FLASH_BASE); - flash_data[3] = cpu_to_be32 (CONFIG_SYS_FLASH_SIZE); - nodeoffset = fdt_path_offset (blob, "/localbus"); - if (nodeoffset >= 0) { - ret = fdt_setprop (blob, nodeoffset, "ranges", flash_data, - sizeof (flash_data)); - if (ret < 0) - printf ("ft_blob_update): cannot set /localbus/ranges " - "property err:%s\n", fdt_strerror(ret)); - } else { - /* memory node is required in dts */ - printf ("ft_blob_update(): cannot find /localbus node " - "err:%s\n", fdt_strerror (nodeoffset)); - } - - /* baudrate */ - nodeoffset = fdt_path_offset (blob, "/soc/cpm/serial"); - if (nodeoffset >= 0) { - speed = cpu_to_be32 (gd->baudrate); - ret = fdt_setprop (blob, nodeoffset, "current-speed", &speed, - sizeof (unsigned long)); - if (ret < 0) - printf ("ft_blob_update): cannot set /soc/cpm/serial/current-speed " - "property err:%s\n", fdt_strerror (ret)); - } else { - /* baudrate is required in dts */ - printf ("ft_blob_update(): cannot find /soc/cpm/smc2/current-speed node " - "err:%s\n", fdt_strerror (nodeoffset)); - } -} - -int ft_board_setup(void *blob, bd_t *bd) -{ - ft_cpu_setup (blob, bd); - ft_blob_update (blob, bd); - - return 0; -} -#endif /* defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) */ diff --git a/configs/muas3001_defconfig b/configs/muas3001_defconfig deleted file mode 100644 index e1056bd..0000000 --- a/configs/muas3001_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_MUAS3001=y diff --git a/configs/muas3001_dev_defconfig b/configs/muas3001_dev_defconfig deleted file mode 100644 index a62019c..0000000 --- a/configs/muas3001_dev_defconfig +++ /dev/null @@ -1,4 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="MUAS_DEV_BOARD" -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_MUAS3001=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index f1c2f8b..7f76aae 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,7 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +muas3001 powerpc mpc8260 - - Heiko Schocher hs@denx.de PM825 powerpc mpc8260 - - Wolfgang Denk wd@denx.de PM826 powerpc mpc8260 - - Wolfgang Denk wd@denx.de PM828 powerpc mpc8260 - - diff --git a/include/configs/muas3001.h b/include/configs/muas3001.h deleted file mode 100644 index df2ecc1..0000000 --- a/include/configs/muas3001.h +++ /dev/null @@ -1,391 +0,0 @@ -/* - * (C) Copyright 2008 - * Heiko Schocher, DENX Software Engineering, hs@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MUAS3001 1 - -#define CONFIG_SYS_TEXT_BASE 0xFF000000 - -#define CONFIG_CPM2 1 /* Has a CPM2 */ - -/* Do boardspecific init */ -#define CONFIG_BOARD_EARLY_INIT_R 1 - -/* enable Watchdog */ -#define CONFIG_WATCHDOG 1 - -/* - * Select serial console configuration - * - * If either CONFIG_CONS_ON_SMC or CONFIG_CONS_ON_SCC is selected, then - * CONFIG_CONS_INDEX must be set to the channel number (1-2 for SMC, 1-4 - * for SCC). - */ -#define CONFIG_CONS_ON_SMC /* Console is on SMC */ -#undef CONFIG_CONS_ON_SCC /* It's not on SCC */ -#undef CONFIG_CONS_NONE /* It's not on external UART */ -#if defined(CONFIG_MUAS_DEV_BOARD) -#define CONFIG_CONS_INDEX 2 /* SMC2 is used for console */ -#else -#define CONFIG_CONS_INDEX 1 /* SMC1 is used for console */ -#endif - -/* - * Select ethernet configuration - * - * If either CONFIG_ETHER_ON_SCC or CONFIG_ETHER_ON_FCC is selected, - * then CONFIG_ETHER_INDEX must be set to the channel number (1-4 for - * SCC, 1-3 for FCC) - * - * If CONFIG_ETHER_NONE is defined, then either the ethernet routines - * must be defined elsewhere (as for the console), or CONFIG_CMD_NET - * must be unset. - */ -#undef CONFIG_ETHER_ON_SCC /* Ethernet is not on SCC */ -#define CONFIG_ETHER_ON_FCC /* Ethernet is on FCC */ -#undef CONFIG_ETHER_NONE /* No external Ethernet */ - -#define CONFIG_ETHER_INDEX 1 -#define CONFIG_ETHER_ON_FCC1 -#define CONFIG_HAS_ETH0 -#define FCC_ENET - -/* - * - Rx-CLK is CLK11 - * - Tx-CLK is CLK12 - */ -# define CONFIG_SYS_CMXFCR_VALUE1 (CMXFCR_RF1CS_CLK11 | CMXFCR_TF1CS_CLK12) -# define CONFIG_SYS_CMXFCR_MASK1 (CMXFCR_FC1 | CMXFCR_RF1CS_MSK | CMXFCR_TF1CS_MSK) -/* - * - RAM for BD/Buffers is on the 60x Bus (see 28-13) - */ -# define CONFIG_SYS_CPMFCR_RAMTYPE (0) -/* know on local Bus */ -/* define CONFIG_SYS_CPMFCR_RAMTYPE (CPMFCR_DTB | CPMFCR_BDB) */ -/* - * - Enable Full Duplex in FSMR - */ -# define CONFIG_SYS_FCC_PSMR (FCC_PSMR_FDE|FCC_PSMR_LPB) - -#define CONFIG_MII /* MII PHY management */ -#define CONFIG_BITBANGMII /* bit-bang MII PHY management */ -# define CONFIG_SYS_PHY_ADDR 1 -/* - * GPIO pins used for bit-banged MII communications - */ -#define MDIO_PORT 0 /* Port A */ -#define MDIO_DECLARE volatile ioport_t *iop = ioport_addr ( \ - (immap_t *) CONFIG_SYS_IMMR, MDIO_PORT ) -#define MDC_DECLARE MDIO_DECLARE - - -#define CONFIG_SYS_MDIO_PIN 0x00200000 /* PA10 */ -#define CONFIG_SYS_MDC_PIN 0x00400000 /* PA9 */ - -#define MDIO_ACTIVE (iop->pdir |= CONFIG_SYS_MDIO_PIN) -#define MDIO_TRISTATE (iop->pdir &= ~CONFIG_SYS_MDIO_PIN) -#define MDIO_READ ((iop->pdat & CONFIG_SYS_MDIO_PIN) != 0) - -#define MDIO(bit) if(bit) iop->pdat |= CONFIG_SYS_MDIO_PIN; \ - else iop->pdat &= ~CONFIG_SYS_MDIO_PIN - -#define MDC(bit) if(bit) iop->pdat |= CONFIG_SYS_MDC_PIN; \ - else iop->pdat &= ~CONFIG_SYS_MDC_PIN - -#define MIIDELAY udelay(1) - -#ifndef CONFIG_8260_CLKIN -#define CONFIG_8260_CLKIN 66000000 /* in Hz */ -#endif - -#define CONFIG_BAUDRATE 115200 - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_DTT -#define CONFIG_CMD_ECHO -#define CONFIG_CMD_IMMAP -#define CONFIG_CMD_MII -#define CONFIG_CMD_PING -#define CONFIG_CMD_I2C - -/* - * Default environment settings - */ -#define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=eth0\0" \ - "u-boot_addr_r=100000\0" \ - "kernel_addr_r=200000\0" \ - "fdt_addr_r=400000\0" \ - "rootpath=/opt/eldk/ppc_6xx\0" \ - "u-boot=muas3001/u-boot.bin\0" \ - "bootfile=muas3001/uImage\0" \ - "fdt_file=muas3001/muas3001.dtb\0" \ - "ramdisk_file=uRamdisk\0" \ - "load=tftp ${u-boot_addr_r} ${u-boot}\0" \ - "update=prot off ff000000 ff03ffff; era ff000000 ff03ffff; " \ - "cp.b ${u-boot_addr_r} ff000000 ${filesize};" \ - "prot on ff000000 ff03ffff\0" \ - "ramargs=setenv bootargs root=/dev/ram rw\0" \ - "nfsargs=setenv bootargs root=/dev/nfs rw " \ - "nfsroot=${serverip}:${rootpath}\0" \ - "addcons=setenv bootargs ${bootargs} console=ttyCPM0,${baudrate}\0" \ - "addmtd=setenv bootargs ${bootargs} ${mtdparts}\0" \ - "addip=setenv bootargs ${bootargs} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:" \ - "${netmask}:${hostname}:${netdev}:off panic=1\0" \ - "net_nfs=tftp ${kernel_addr_r} ${bootfile}; " \ - "tftp ${fdt_addr_r} ${fdt_file}; run nfsargs addip addcons;" \ - "bootm ${kernel_addr_r} - ${fdt_addr_r}\0" \ - "net_self=tftp ${kernel_addr_r} ${bootfile}; " \ - "tftp ${fdt_addr_r} ${fdt_file}; " \ - "tftp ${ramdisk_addr} ${ramdisk_file}; " \ - "run ramargs addip; " \ - "bootm ${kernel_addr_r} ${ramdisk_addr} ${fdt_addr_r}\0" \ - "ramdisk_addr=ff210000\0" \ - "kernel_addr=ff050000\0" \ - "fdt_addr=ff200000\0" \ - "flash_self=run ramargs addip addcons;bootm ${kernel_addr}" \ - " ${ramdisk_addr} ${fdt_addr}\0" \ - "updateramdisk=era ${ramdisk_addr} +1f0000;tftpb ${kernel_addr_r}" \ - " ${ramdisk_file};" \ - "cp.b ${kernel_addr_r} ${ramdisk_addr} ${filesize}\0" \ - "updatekernel=era ${kernel_addr} +1b0000;tftpb ${kernel_addr_r}" \ - " ${bootfile};" \ - "cp.b ${kernel_addr_r} ${kernel_addr} ${filesize}\0" \ - "updatefdt=era ${fdt_addr} +10000;tftpb ${fdt_addr_r} ${fdt_file};" \ - "cp.b ${fdt_addr_r} ${fdt_addr} ${filesize}\0" \ - "" - -#define CONFIG_BOOTCOMMAND "run net_nfs" -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x00100000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x00f00000 /* 1 ... 15 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 } - -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0xFF000000 -#define CONFIG_SYS_FLASH_SIZE 32 -#define CONFIG_SYS_FLASH_CFI -#define CONFIG_FLASH_CFI_DRIVER -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max num of flash banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 512 /* max num of sects on one chip */ - -#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } - -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256KB for Monitor */ - -#define CONFIG_ENV_IS_IN_FLASH - -#ifdef CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_SECT_SIZE 0x10000 -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) -#endif /* CONFIG_ENV_IS_IN_FLASH */ - -/* - * I2C Bus - */ -#define CONFIG_HARD_I2C 1 /* To enable I2C support */ -#define CONFIG_SYS_I2C_SPEED 100000 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_SLAVE 0x7F - -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 -/* I2C SYSMON (LM75, AD7414 is almost compatible) */ -#define CONFIG_DTT_LM75 1 /* ON Semi's LM75 */ -#define CONFIG_DTT_SENSORS {0} /* Sensor addresses */ -#define CONFIG_SYS_DTT_MAX_TEMP 70 -#define CONFIG_SYS_DTT_LOW_TEMP -30 -#define CONFIG_SYS_DTT_HYSTERESIS 3 - -#define CONFIG_SYS_IMMR 0xF0000000 -#define CONFIG_SYS_DEFAULT_IMMR 0x0F010000 - -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/* Hard reset configuration word */ -#define CONFIG_SYS_HRCW_MASTER 0x0E028200 /* BPS=11 CIP=1 ISB=010 BMS=1 */ - -/* No slaves */ -#define CONFIG_SYS_HRCW_SLAVE1 0 -#define CONFIG_SYS_HRCW_SLAVE2 0 -#define CONFIG_SYS_HRCW_SLAVE3 0 -#define CONFIG_SYS_HRCW_SLAVE4 0 -#define CONFIG_SYS_HRCW_SLAVE5 0 -#define CONFIG_SYS_HRCW_SLAVE6 0 -#define CONFIG_SYS_HRCW_SLAVE7 0 - -#define CONFIG_SYS_MALLOC_LEN (4096 << 10) /* Reserve 4 MB for malloc() */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC8260 CPUs */ -#if defined(CONFIG_CMD_KGDB) -# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - -#define CONFIG_SYS_HID0_INIT 0 -#define CONFIG_SYS_HID0_FINAL (HID0_ICE | HID0_IFEM | HID0_ABE) - -#define CONFIG_SYS_HID2 0 - -#define CONFIG_SYS_SIUMCR 0x00200000 -#define CONFIG_SYS_BCR 0x004c0000 -#define CONFIG_SYS_SCCR 0x0 - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 4-35 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Watchdog & Bus Monitor Timer max, 60x Bus Monitor enable - */ -#if defined(CONFIG_WATCHDOG) -#define CONFIG_SYS_SYPCR (SYPCR_SWTC|SYPCR_BMT|SYPCR_PBME|SYPCR_LBME|\ - SYPCR_SWRI|SYPCR_SWP|SYPCR_SWE) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC|SYPCR_BMT|SYPCR_PBME|SYPCR_LBME|\ - SYPCR_SWRI|SYPCR_SWP) -#endif /* CONFIG_WATCHDOG */ - -/*----------------------------------------------------------------------- - * RMR - Reset Mode Register 5-5 - *----------------------------------------------------------------------- - * turn on Checkstop Reset Enable - */ -#define CONFIG_SYS_RMR 0 - -/*----------------------------------------------------------------------- - * TMCNTSC - Time Counter Status and Control 4-40 - *----------------------------------------------------------------------- - * Clear once per Second and Alarm Interrupt Status, Set 32KHz timersclk, - * and enable Time Counter - */ -#define CONFIG_SYS_TMCNTSC (TMCNTSC_SEC|TMCNTSC_ALR|TMCNTSC_TCF|TMCNTSC_TCE) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 4-42 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Set 32KHz timersclk, and enable - * Periodic timer - */ -#define CONFIG_SYS_PISCR (PISCR_PS|PISCR_PTF|PISCR_PTE) - -/*----------------------------------------------------------------------- - * RCCR - RISC Controller Configuration 13-7 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RCCR 0 - -/* - * Init Memory Controller: - * - * Bank Bus Machine PortSz Device - * ---- --- ------- ------ ------ - * 0 60x GPCM 32 bit FLASH - * 1 60x SDRAM 64 bit SDRAM - * 4 60x GPCM 16 bit I/O Ctrl - * - */ -/* Bank 0 - FLASH - */ -#define CONFIG_SYS_BR0_PRELIM ((CONFIG_SYS_FLASH_BASE & BRx_BA_MSK) |\ - BRx_PS_32 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR0_PRELIM (0xff000020) - -/* Bank 1 - 60x bus SDRAM - */ -#define CONFIG_SYS_GLOBAL_SDRAM_LIMIT (256 << 20) /* less than 256 MB */ - -#define CONFIG_SYS_MPTPR 0x2800 - -/*----------------------------------------------------------------------------- - * Address for Mode Register Set (MRS) command - *----------------------------------------------------------------------------- - */ -#define CONFIG_SYS_MRS_OFFS 0x00000110 -#define CONFIG_SYS_PSRT 0x13 - -#define CONFIG_SYS_BR1_PRELIM ((CONFIG_SYS_SDRAM_BASE & BRx_BA_MSK) |\ - BRx_PS_64 |\ - BRx_MS_SDRAM_P |\ - BRx_V) - -#define CONFIG_SYS_OR1_PRELIM CONFIG_SYS_OR1_LITTLE - -/* SDRAM initialization values -*/ -#define CONFIG_SYS_OR1_LITTLE ((~(CONFIG_SYS_GLOBAL_SDRAM_LIMIT-1) & ORxS_SDAM_MSK) |\ - ORxS_BPD_4 |\ - ORxS_ROWST_PBI1_A7 |\ - ORxS_NUMR_12) - -#define CONFIG_SYS_PSDMR_LITTLE 0x004b36a3 - -#define CONFIG_SYS_OR1_BIG ((~(CONFIG_SYS_GLOBAL_SDRAM_LIMIT-1) & ORxS_SDAM_MSK) |\ - ORxS_BPD_4 |\ - ORxS_ROWST_PBI1_A4 |\ - ORxS_NUMR_12) - -#define CONFIG_SYS_PSDMR_BIG 0x014f36a3 - -/* IO on CS4 initialization values -*/ -#define CONFIG_SYS_IO_BASE 0xc0000000 -#define CONFIG_SYS_IO_SIZE 1 - -#define CONFIG_SYS_BR4_PRELIM ((CONFIG_SYS_IO_BASE & BRx_BA_MSK) |\ - BRx_PS_16 | BRx_MS_GPCM_L | BRx_V) - -#define CONFIG_SYS_OR4_PRELIM (0xfff80020) - -#define CONFIG_SYS_RESET_ADDRESS 0xFDFFFFFC /* "bad" address */ - -/* pass open firmware flat tree */ -#define CONFIG_OF_LIBFDT 1 -#define CONFIG_OF_BOARD_SETUP 1 - -#define OF_TBCLK (bd->bi_busfreq / 4) -#if defined(CONFIG_MUAS_DEV_BOARD) -#define OF_STDOUT_PATH "/soc/cpm/serial@11a90" -#else -#define OF_STDOUT_PATH "/soc/cpm/serial@11a80" -#endif - -#endif /* __CONFIG_H */
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Wolfgang Grandegger wg@denx.de ---
arch/powerpc/cpu/mpc8260/Kconfig | 4 - board/iphase4539/Kconfig | 9 - board/iphase4539/MAINTAINERS | 6 - board/iphase4539/Makefile | 10 - board/iphase4539/README | 358 ----------------------------- board/iphase4539/flash.c | 474 --------------------------------------- board/iphase4539/iphase4539.c | 408 --------------------------------- configs/IPHASE4539_defconfig | 3 - doc/README.scrapyard | 1 + include/configs/IPHASE4539.h | 328 --------------------------- 10 files changed, 1 insertion(+), 1600 deletions(-) delete mode 100644 board/iphase4539/Kconfig delete mode 100644 board/iphase4539/MAINTAINERS delete mode 100644 board/iphase4539/Makefile delete mode 100644 board/iphase4539/README delete mode 100644 board/iphase4539/flash.c delete mode 100644 board/iphase4539/iphase4539.c delete mode 100644 configs/IPHASE4539_defconfig delete mode 100644 include/configs/IPHASE4539.h
diff --git a/arch/powerpc/cpu/mpc8260/Kconfig b/arch/powerpc/cpu/mpc8260/Kconfig index 2b3c9c2..56b79ac 100644 --- a/arch/powerpc/cpu/mpc8260/Kconfig +++ b/arch/powerpc/cpu/mpc8260/Kconfig @@ -22,9 +22,6 @@ config TARGET_EP82XXM config TARGET_GW8260 bool "Support gw8260"
-config TARGET_IPHASE4539 - bool "Support IPHASE4539" - config TARGET_KM82XX bool "Support km82xx"
@@ -35,7 +32,6 @@ source "board/cpu86/Kconfig" source "board/cpu87/Kconfig" source "board/ep82xxm/Kconfig" source "board/gw8260/Kconfig" -source "board/iphase4539/Kconfig" source "board/keymile/km82xx/Kconfig"
endmenu diff --git a/board/iphase4539/Kconfig b/board/iphase4539/Kconfig deleted file mode 100644 index 74594d2..0000000 --- a/board/iphase4539/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_IPHASE4539 - -config SYS_BOARD - default "iphase4539" - -config SYS_CONFIG_NAME - default "IPHASE4539" - -endif diff --git a/board/iphase4539/MAINTAINERS b/board/iphase4539/MAINTAINERS deleted file mode 100644 index ddf6814..0000000 --- a/board/iphase4539/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -IPHASE4539 BOARD -M: Wolfgang Grandegger wg@denx.de -S: Maintained -F: board/iphase4539/ -F: include/configs/IPHASE4539.h -F: configs/IPHASE4539_defconfig diff --git a/board/iphase4539/Makefile b/board/iphase4539/Makefile deleted file mode 100644 index 9197b84..0000000 --- a/board/iphase4539/Makefile +++ /dev/null @@ -1,10 +0,0 @@ -# -# (C) Copyright 2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# (C) Copyright 2002 Wolfgang Grandegger wg@denx.de -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y := iphase4539.o flash.o diff --git a/board/iphase4539/README b/board/iphase4539/README deleted file mode 100644 index c5146d9..0000000 --- a/board/iphase4539/README +++ /dev/null @@ -1,358 +0,0 @@ - -This file contains basic information on the port of U-Boot to IPHASE4539 -(Interphase 4539 T1/E1/J1 PMC Communications Controller). -All the changes fit in the common U-Boot infrastructure, providing a new -IPHASE4539-specific entry in makefiles. To build U-Boot for IPHASE4539, -type "make IPHASE4539_config", edit the "include/config_IPHASE4539.h" -file if necessary, then type "make". - - -Common file modifications: --------------------------- - -The following common files have been modified by this project: -(starting from the ppcboot-1.1.5/ directory) - -MAKEALL - IPHASE4539 entry added -Makefile - IPHASE4539_config entry added - - -New files: ----------- - -The following new files have been added by this project: -(starting from the ppcboot-1.1.5/ directory) - -board/iphase4539/ - board-specific directory -board/iphase4539/Makefile - board-specific makefile -board/iphase4539/config.mk - config file -board/iphase4539/flash.c - flash driver (for AM29LV033C) -board/iphase4539/ppcboot.lds - linker script -board/iphase4539/iphase4539.c - ioport and memory initialization -include/config_IPHASE4539.h - main configuration file - - -New configuration options: --------------------------- - -CONFIG_IPHASE4539 - - Main board-specific option (should be defined for IPHASE4539). - - -Acceptance criteria tests: --------------------------- - -The following tests have been conducted to validate the port of U-Boot -to IPHASE4539: - -1. Operation on serial console: - -With SMC1 defined as console in the main configuration file, the U-Boot -output appeared on the serial terminal connected to the 2.5mm stereo jack -connector as follows: - ------------------------------------------------------------------------------- -=> help -base - print or set address offset -bdinfo - print Board Info structure -bootm - boot application image from memory -bootp - boot image via network using BootP/TFTP protocol -bootd - boot default, i.e., run 'bootcmd' -cmp - memory compare -coninfo - print console devices and informations -cp - memory copy -crc32 - checksum calculation -dcache - enable or disable data cache -echo - echo args to console -erase - erase FLASH memory -flinfo - print FLASH memory information -go - start application at address 'addr' -help - print online help -icache - enable or disable instruction cache -iminfo - print header information for application image -loadb - load binary file over serial line (kermit mode) -loads - load S-Record file over serial line -loop - infinite loop on address range -md - memory display -mm - memory modify (auto-incrementing) -mtest - simple RAM test -mw - memory write (fill) -nm - memory modify (constant address) -printenv- print environment variables -protect - enable or disable FLASH write protection -rarpboot- boot image via network using RARP/TFTP protocol -reset - Perform RESET of the CPU -run - run commands in an environment variable -saveenv - save environment variables to persistent storage -setenv - set environment variables -sleep - delay execution for some time -source - run script from memory -tftpboot- boot image via network using TFTP protocol - and env variables ipaddr and serverip -version - print monitor version -? - alias for 'help' -=> ------------------------------------------------------------------------------- - - -2. Flash driver operation - -The following sequence was performed to test the "flinfo" command: - ------------------------------------------------------------------------------- -=> flinfo - -Bank # 1: AMD AM29LV033C (32 Mbit, uniform sectors) - Size: 4 MB in 64 Sectors - Sector Start Addresses: - FF800000 (RO) FF810000 (RO) FF820000 FF830000 FF840000 - FF850000 FF860000 FF870000 FF880000 FF890000 - FF8A0000 FF8B0000 FF8C0000 FF8D0000 FF8E0000 - FF8F0000 FF900000 FF910000 FF920000 FF930000 - FF940000 FF950000 FF960000 FF970000 FF980000 - FF990000 FF9A0000 FF9B0000 FF9C0000 FF9D0000 - FF9E0000 FF9F0000 FFA00000 FFA10000 FFA20000 - FFA30000 FFA40000 FFA50000 FFA60000 FFA70000 - FFA80000 FFA90000 FFAA0000 FFAB0000 FFAC0000 - FFAD0000 FFAE0000 FFAF0000 FFB00000 (RO) FFB10000 (RO) - FFB20000 (RO) FFB30000 (RO) FFB40000 FFB50000 FFB60000 - FFB70000 FFB80000 FFB90000 FFBA0000 FFBB0000 - FFBC0000 FFBD0000 FFBE0000 FFBF0000 ------------------------------------------------------------------------------- - -Note: the Hardware Configuration Word (HWC) of the 8260 is on the -first sector of the flash and should not be touched. The U-Boot -environment variables are stored on second sector and U-Boot -starts at the address 0xFFB00000. - - -The following sequence was performed to test the erase command: - ------------------------------------------------------------------------------- -=> cp 0 ff880000 10 -Copy to Flash... done -=> md ff880000 20 -ff880000: ff000000 60000000 60000000 7c7f1b78 ....`...`...|..x -ff880010: 7c9e2378 7cbd2b78 7cdc3378 7cfb3b78 |.#x|.+x|.3x|.;x -ff880020: 3b000000 4811e0f5 48003719 480036a5 ;...H...H.7.H.6. -ff880030: 480036f9 48003731 48005c5d 7c7a1b78 H.6.H.71H.]|z.x -ff880040: ffffffff ffffffff ffffffff ffffffff ................ -ff880050: ffffffff ffffffff ffffffff ffffffff ................ -ff880060: ffffffff ffffffff ffffffff ffffffff ................ -ff880070: ffffffff ffffffff ffffffff ffffffff ................ -=> erase ff880000 ff88ffff -Erase Flash from 0xff880000 to 0xff88ffff -.. done -Erased 1 sectors -=> md ff880000 -ff880000: ffffffff ffffffff ffffffff ffffffff ................ -ff880010: ffffffff ffffffff ffffffff ffffffff ................ -ff880020: ffffffff ffffffff ffffffff ffffffff ................ -ff880030: ffffffff ffffffff ffffffff ffffffff ................ -ff880040: ffffffff ffffffff ffffffff ffffffff ................ -ff880050: ffffffff ffffffff ffffffff ffffffff ................ -ff880060: ffffffff ffffffff ffffffff ffffffff ................ -ff880070: ffffffff ffffffff ffffffff ffffffff ................ -=> cp 0 ff880000 10 -Copy to Flash... done -=> md ff880000 20 -ff880000: ff000000 60000000 60000000 7c7f1b78 ....`...`...|..x -ff880010: 7c9e2378 7cbd2b78 7cdc3378 7cfb3b78 |.#x|.+x|.3x|.;x -ff880020: 3b000000 4811e0f5 48003719 480036a5 ;...H...H.7.H.6. -ff880030: 480036f9 48003731 48005c5d 7c7a1b78 H.6.H.71H.]|z.x -ff880040: ffffffff ffffffff ffffffff ffffffff ................ -ff880050: ffffffff ffffffff ffffffff ffffffff ................ -ff880060: ffffffff ffffffff ffffffff ffffffff ................ -ff880070: ffffffff ffffffff ffffffff ffffffff ................ -=> erase 1:8 -Erase Flash Sectors 8-8 in Bank # 1 -.. done -=> md ff880000 20 -ff880000: ffffffff ffffffff ffffffff ffffffff ................ -ff880010: ffffffff ffffffff ffffffff ffffffff ................ -ff880020: ffffffff ffffffff ffffffff ffffffff ................ -ff880030: ffffffff ffffffff ffffffff ffffffff ................ -ff880040: ffffffff ffffffff ffffffff ffffffff ................ -ff880050: ffffffff ffffffff ffffffff ffffffff ................ -ff880060: ffffffff ffffffff ffffffff ffffffff ................ -ff880070: ffffffff ffffffff ffffffff ffffffff ................ -=> cp 0 ff880000 10 -Copy to Flash... done -=> cp 0 ff890000 10 -=> md ff880000 20 -ff880000: ff000000 60000000 60000000 7c7f1b78 ....`...`...|..x -ff880010: 7c9e2378 7cbd2b78 7cdc3378 7cfb3b78 |.#x|.+x|.3x|.;x -ff880020: 3b000000 4811e0f5 48003719 480036a5 ;...H...H.7.H.6. -ff880030: 480036f9 48003731 48005c5d 7c7a1b78 H.6.H.71H.]|z.x -ff880040: ffffffff ffffffff ffffffff ffffffff ................ -ff880050: ffffffff ffffffff ffffffff ffffffff ................ -ff880060: ffffffff ffffffff ffffffff ffffffff ................ -ff880070: ffffffff ffffffff ffffffff ffffffff ................ -=> md ff890000 -ff890000: ff000000 60000000 60000000 7c7f1b78 ....`...`...|..x -ff890010: 7c9e2378 7cbd2b78 7cdc3378 7cfb3b78 |.#x|.+x|.3x|.;x -ff890020: 3b000000 4811e0f5 48003719 480036a5 ;...H...H.7.H.6. -ff890030: 480036f9 48003731 48005c5d 7c7a1b78 H.6.H.71H.]|z.x -ff890040: ffffffff ffffffff ffffffff ffffffff ................ -ff890050: ffffffff ffffffff ffffffff ffffffff ................ -ff890060: ffffffff ffffffff ffffffff ffffffff ................ -ff890070: ffffffff ffffffff ffffffff ffffffff ................ -=> erase 1:8-9 -Erase Flash Sectors 8-9 in Bank # 1 -.... done -=> md ff880000 20 -ff880000: ffffffff ffffffff ffffffff ffffffff ................ -ff880010: ffffffff ffffffff ffffffff ffffffff ................ -ff880020: ffffffff ffffffff ffffffff ffffffff ................ -ff880030: ffffffff ffffffff ffffffff ffffffff ................ -ff880040: ffffffff ffffffff ffffffff ffffffff ................ -ff880050: ffffffff ffffffff ffffffff ffffffff ................ -ff880060: ffffffff ffffffff ffffffff ffffffff ................ -ff880070: ffffffff ffffffff ffffffff ffffffff ................ -=> md ff890000 -ff890000: ffffffff ffffffff ffffffff ffffffff ................ -ff890010: ffffffff ffffffff ffffffff ffffffff ................ -ff890020: ffffffff ffffffff ffffffff ffffffff ................ -ff890030: ffffffff ffffffff ffffffff ffffffff ................ -ff890040: ffffffff ffffffff ffffffff ffffffff ................ -ff890050: ffffffff ffffffff ffffffff ffffffff ................ -ff890060: ffffffff ffffffff ffffffff ffffffff ................ -ff890070: ffffffff ffffffff ffffffff ffffffff ................ -=> ------------------------------------------------------------------------------- - - -The following sequence was performed to test the Flash programming commands: - ------------------------------------------------------------------------------- -=> erase ff880000 ff88ffff -Erase Flash from 0xff880000 to 0xff88ffff -.. done -Erased 1 sectors -=> cp 0 ff880000 10 -Copy to Flash... done -=> md 0 20 -00000000: ff000000 60000000 60000000 7c7f1b78 ....`...`...|..x -00000010: 7c9e2378 7cbd2b78 7cdc3378 7cfb3b78 |.#x|.+x|.3x|.;x -00000020: 3b000000 4811e0f5 48003719 480036a5 ;...H...H.7.H.6. -00000030: 480036f9 48003731 48005c5d 7c7a1b78 H.6.H.71H.]|z.x -00000040: 3c83c000 2c040000 40823378 7c0000a6 <...,...@.3x|... -00000050: 60000030 7c1b03a6 3c00c000 600035ec `..0|...<...`.5. -00000060: 7c1a03a6 4c000064 00000000 00000000 |...L..d........ -00000070: 00000000 00000000 00000000 00000000 ................ -=> md ff880000 20 -ff880000: ff000000 60000000 60000000 7c7f1b78 ....`...`...|..x -ff880010: 7c9e2378 7cbd2b78 7cdc3378 7cfb3b78 |.#x|.+x|.3x|.;x -ff880020: 3b000000 4811e0f5 48003719 480036a5 ;...H...H.7.H.6. -ff880030: 480036f9 48003731 48005c5d 7c7a1b78 H.6.H.71H.]|z.x -ff880040: ffffffff ffffffff ffffffff ffffffff ................ -ff880050: ffffffff ffffffff ffffffff ffffffff ................ -ff880060: ffffffff ffffffff ffffffff ffffffff ................ -ff880070: ffffffff ffffffff ffffffff ffffffff ................ -=> ------------------------------------------------------------------------------- - - -The following sequence was performed to test storage of the environment -variables in Flash: - ------------------------------------------------------------------------------- -=> setenv foo bar -=> saveenv -Un-Protected 1 sectors -Erasing Flash... -.. done -Erased 1 sectors -Saving Environment to Flash... -Protected 1 sectors -=> reset -... -=> printenv -... -foo=bar -... -Environment size: 339/65532 bytes -=> ------------------------------------------------------------------------------- - - -The following sequence was performed to test image download and run over -Ethernet interface (both interfaces were tested): - ------------------------------------------------------------------------------- -=> tftpboot 40000 hello_world.bin -ARP broadcast 1 -TFTP from server 10.0.0.1; our IP address is 10.0.0.8 -Filename 'hello_world.bin'. -Load address: 0x40000 -Loading: ############# -done -Bytes transferred = 65932 (1018c hex) -=> go 40004 -## Starting application at 0x00040004 ... -Hello World -argc = 1 -argv[0] = "40004" -argv[1] = "<NULL>" -Hit any key to exit ... - -## Application terminated, rc = 0x0 -=> ------------------------------------------------------------------------------- - - -3. Known Problems - -None for the moment. - - ----------------------------------------------------------------------------- -U-Boot and Linux for Interphase 4539 T1/E1/J1 PMC Communications Controller ----------------------------------------------------------------------------- - -U-Boot: - - Configure and make U-Boot: - - $ cd <path>/u-boot - $ make IPHASE4539_config - $ make dep - $ make - $ cp -p u-boot.bin /tftpboot - - Load u-boot.bin into the Flash memory at 0xffb00000. - - -Linux: - - Configure and make Linux: - - $ cd <patch>/linux-2.4 - $ make IPHASE4539_config - $ make oldconfig - $ make dep - $ make uImage - $ cp -p arch/powerpc/mbxboot/uImage /tftpboot - - Load uImage via tftp and boot it. - - -Flash organisation: - - The following preliminary layout of the Flash memory - is defined: - - 0xff800000 ( 0 - 64 kB): Hardware Configuration Word. - 0xff810000 ( 64 kB - 128 kB): U-Boot Environment. - 0xff820000 ( 128 kB - 3 MB): RAMdisk. - 0xffb00000 ( 3 MB - 3328 kB): U-Boot. - 0xffb40000 (3328 KB - 4 MB): Linux Kernel. - - -For further information concerning U-Boot and Linux please consult -the "DENX U-Boot and Linux Guide". - - -(C) 2002 Wolfgang Grandegger, DENX Software Engineering, wg@denx.de -=================================================================== diff --git a/board/iphase4539/flash.c b/board/iphase4539/flash.c deleted file mode 100644 index 3c2dad6..0000000 --- a/board/iphase4539/flash.c +++ /dev/null @@ -1,474 +0,0 @@ -/* - * (C) Copyright 2001 - * Josh Huber huber@mclx.com, Mission Critical Linux, Inc. - * - * (C) Copyright 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * Adapted for Interphase 4539 by Wolfgang Grandegger wg@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <config.h> -#include <common.h> -#include <flash.h> -#include <asm/io.h> - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; - -extern int hwc_flash_size(void); -static ulong flash_get_size (u32 addr, flash_info_t *info); -static int flash_get_offsets (u32 base, flash_info_t *info); -static int write_word (flash_info_t *info, ulong dest, ulong data); -static void flash_reset (u32 addr); - -#define out8(a,v) *(volatile unsigned char*)(a) = v -#define in8(a) *(volatile unsigned char*)(a) -#define in32(a) *(volatile unsigned long*)(a) -#define iobarrier_rw() eieio() - -unsigned long flash_init (void) -{ - unsigned int i; - unsigned long flash_size = 0; - unsigned long bank_size; - unsigned int bank = 0; - - /* Init: no FLASHes known */ - for (i=0; i < CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - flash_info[i].sector_count = 0; - flash_info[i].size = 0; - } - - /* Initialise the BOOT Flash */ - if (bank == CONFIG_SYS_MAX_FLASH_BANKS) { - puts ("Warning: not all Flashes are initialised !"); - return flash_size; - } - - bank_size = flash_get_size (CONFIG_SYS_FLASH_BASE, flash_info + bank); - if (bank_size) { -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE && \ - CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE + CONFIG_SYS_MAX_FLASH_SIZE - /* monitor protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE + monitor_flash_len - 1, - flash_info + bank); -#endif - -#ifdef CONFIG_ENV_IS_IN_FLASH - /* ENV protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE - 1, - flash_info + bank); -#endif - - /* HWC protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_FLASH_BASE, - CONFIG_SYS_FLASH_BASE + 0x10000 - 1, - flash_info + bank); - - flash_size += bank_size; - bank++; - } else { - puts ("Warning: the BOOT Flash is not initialised !"); - } - - return flash_size; -} - -/* - * The following code cannot be run from FLASH! - */ -static ulong flash_get_size (u32 addr, flash_info_t *info) -{ - volatile uchar value; -#if 0 - int i; -#endif - - /* Write auto select command: read Manufacturer ID */ - out8(addr + 0x0555, 0xAA); - iobarrier_rw(); - udelay(10); - out8(addr + 0x02AA, 0x55); - iobarrier_rw(); - udelay(10); - out8(addr + 0x0555, 0x90); - iobarrier_rw(); - udelay(10); - - value = in8(addr); - iobarrier_rw(); - udelay(10); - switch (value | (value << 16)) { - case AMD_MANUFACT: - info->flash_id = FLASH_MAN_AMD; - break; - - case FUJ_MANUFACT: - info->flash_id = FLASH_MAN_FUJ; - break; - - default: - info->flash_id = FLASH_UNKNOWN; - flash_reset (addr); - return 0; - } - - value = in8(addr + 1); /* device ID */ - iobarrier_rw(); - - switch (value) { - case AMD_ID_LV033C: - info->flash_id += FLASH_AM033C; - info->size = hwc_flash_size(); - if (info->size > CONFIG_SYS_MAX_FLASH_SIZE) { - printf("U-Boot supports only %d MB\n", - CONFIG_SYS_MAX_FLASH_SIZE); - info->size = CONFIG_SYS_MAX_FLASH_SIZE; - } - info->sector_count = info->size / 0x10000; - break; /* => 4 MB */ - - default: - info->flash_id = FLASH_UNKNOWN; - flash_reset (addr); - return (0); /* => no or unknown flash */ - - } - - if (!flash_get_offsets (addr, info)) { - flash_reset (addr); - return 0; - } - -#if 0 - /* check for protected sectors */ - for (i = 0; i < info->sector_count; i++) { - /* read sector protection at sector address, (A7 .. A0) = 0x02 */ - /* D0 = 1 if protected */ - value = in8(info->start[i] + 2); - iobarrier_rw(); - info->protect[i] = (value & 1) != 0; - } -#endif - - /* - * Reset bank to read mode - */ - flash_reset (addr); - - return (info->size); -} - -static int flash_get_offsets (u32 base, flash_info_t *info) -{ - unsigned int i, size; - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_AM033C: - /* set sector offsets for uniform sector type */ - size = info->size / info->sector_count; - for (i = 0; i < info->sector_count; i++) { - info->start[i] = base + i * size; - } - break; - default: - return 0; - } - - return 1; -} - -int flash_erase (flash_info_t *info, int s_first, int s_last) -{ - volatile u32 addr = info->start[0]; - int flag, prot, sect, l_sect; - ulong start, now, last; - - if (s_first < 0 || s_first > s_last) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - if (info->flash_id == FLASH_UNKNOWN || - info->flash_id > FLASH_AMD_COMP) { - printf ("Can't erase unknown flash type %08lx - aborted\n", - info->flash_id); - return 1; - } - - prot = 0; - for (sect=s_first; sect<=s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - printf ("\n"); - } - - l_sect = -1; - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - out8(addr + 0x555, 0xAA); - iobarrier_rw(); - out8(addr + 0x2AA, 0x55); - iobarrier_rw(); - out8(addr + 0x555, 0x80); - iobarrier_rw(); - out8(addr + 0x555, 0xAA); - iobarrier_rw(); - out8(addr + 0x2AA, 0x55); - iobarrier_rw(); - - /* Start erase on unprotected sectors */ - for (sect = s_first; sect<=s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - addr = info->start[sect]; - out8(addr, 0x30); - iobarrier_rw(); - l_sect = sect; - } - } - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - - /* - * We wait for the last triggered sector - */ - if (l_sect < 0) - goto DONE; - - start = get_timer (0); - last = start; - addr = info->start[l_sect]; - while ((in8(addr) & 0x80) != 0x80) { - if ((now = get_timer(start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - return 1; - } - /* show that we're waiting */ - if ((now - last) > 1000) { /* every second */ - putc ('.'); - last = now; - } - iobarrier_rw(); - } - -DONE: - /* reset to read mode */ - flash_reset (info->start[0]); - - printf (" done\n"); - return 0; -} - -/* - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -int write_buff (flash_info_t *info, uchar *src, ulong addr, ulong cnt) -{ - ulong cp, wp, data; - int i, l, rc; - - wp = (addr & ~3); /* get lower word aligned address */ - - /* - * handle unaligned start bytes - */ - if ((l = addr - wp) != 0) { - data = 0; - for (i=0, cp=wp; i<l; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - for (; i<4 && cnt>0; ++i) { - data = (data << 8) | *src++; - --cnt; - ++cp; - } - for (; cnt==0 && i<4; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - - if ((rc = write_word(info, wp, data)) != 0) { - return (rc); - } - wp += 4; - } - - /* - * handle word aligned part - */ - while (cnt >= 4) { - data = 0; - for (i=0; i<4; ++i) { - data = (data << 8) | *src++; - } - if ((rc = write_word(info, wp, data)) != 0) { - return (rc); - } - wp += 4; - cnt -= 4; - } - - if (cnt == 0) { - return (0); - } - - /* - * handle unaligned tail bytes - */ - data = 0; - for (i=0, cp=wp; i<4 && cnt>0; ++i, ++cp) { - data = (data << 8) | *src++; - --cnt; - } - for (; i<4; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - - return (write_word(info, wp, data)); -} - -/* - * Write a word to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_word (flash_info_t *info, ulong dest, ulong data) -{ - volatile u32 addr = info->start[0]; - ulong start; - int flag, i; - - /* Check if Flash is (sufficiently) erased */ - if ((in32(dest) & data) != data) { - return (2); - } - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - /* first, perform an unlock bypass command to speed up flash writes */ - out8(addr + 0x555, 0xAA); - iobarrier_rw(); - out8(addr + 0x2AA, 0x55); - iobarrier_rw(); - out8(addr + 0x555, 0x20); - iobarrier_rw(); - - /* write each byte out */ - for (i = 0; i < 4; i++) { - char *data_ch = (char *)&data; - out8(addr, 0xA0); - iobarrier_rw(); - out8(dest+i, data_ch[i]); - iobarrier_rw(); - udelay(10); /* XXX */ - } - - /* we're done, now do an unlock bypass reset */ - out8(addr, 0x90); - iobarrier_rw(); - out8(addr, 0x00); - iobarrier_rw(); - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* data polling for D7 */ - start = get_timer (0); - while ((in32(dest) & 0x80808080) != (data & 0x80808080)) { - if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - return (1); - } - iobarrier_rw(); - } - - flash_reset (addr); - - return (0); -} - -/* - * Reset bank to read mode - */ -static void flash_reset (u32 addr) -{ - out8(addr, 0xF0); /* reset bank */ - iobarrier_rw(); -} - -void flash_print_info (flash_info_t *info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_AMD: printf ("AMD "); break; - case FLASH_MAN_FUJ: printf ("FUJITSU "); break; - case FLASH_MAN_BM: printf ("BRIGHT MICRO "); break; - default: printf ("Unknown Vendor "); break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_AM033C: printf ("AM29LV033C (32 Mbit, uniform sectors)\n"); - break; - default: printf ("Unknown Chip Type\n"); - break; - } - - if (info->size % 0x100000 == 0) { - printf (" Size: %ld MB in %d Sectors\n", - info->size / 0x100000, info->sector_count); - } - else if (info->size % 0x400 == 0) { - printf (" Size: %ld KB in %d Sectors\n", - info->size / 0x400, info->sector_count); - } - else { - printf (" Size: %ld B in %d Sectors\n", - info->size, info->sector_count); - } - - printf (" Sector Start Addresses:"); - for (i=0; i<info->sector_count; ++i) { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", - info->start[i], - info->protect[i] ? " (RO)" : " " - ); - } - printf ("\n"); -} diff --git a/board/iphase4539/iphase4539.c b/board/iphase4539/iphase4539.c deleted file mode 100644 index d40d2b6..0000000 --- a/board/iphase4539/iphase4539.c +++ /dev/null @@ -1,408 +0,0 @@ -/* - * (C) Copyright 2002 Wolfgang Grandegger wg@denx.de - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <ioports.h> -#include <mpc8260.h> -#include <asm/io.h> -#include <asm/immap_8260.h> - -int hwc_flash_size (void); -int hwc_local_sdram_size (void); -int hwc_main_sdram_size (void); -int hwc_serial_number (void); -int hwc_mac_address (char *str); -int hwc_manufact_date (char *str); -int seeprom_read (int addr, uchar * data, int size); - -/* - * I/O Port configuration table - * - * if conf is 1, then that port pin will be configured at boot time - * according to the five values podr/pdir/ppar/psor/pdat for that entry - * - * The port definitions are taken from the old firmware (see - * also SYS/H/4539.H): - * - * ppar psor pdir podr pdat - * PA: 0x02ffffff 0x02c00000 0xfc403fe6 0x00000000 0x02403fc0 - * PB: 0x0fffdeb0 0x000000b0 0x0f032347 0x00000000 0x0f000290 - * PC: 0x030ffa55 0x030f0040 0xbcf005ea 0x00000000 0xc0c0ba7d - * PD: 0x09c04e3c 0x01000e3c 0x0a7ff1c3 0x00000000 0x00ce0ae9 - */ -const iop_conf_t iop_conf_tab[4][32] = { - - /* Port A configuration */ - { /* conf ppar psor pdir podr pdat */ - {0, 1, 0, 0, 0, 0}, /* PA31 FCC1_TXENB SLAVE */ - {0, 1, 0, 1, 0, 0}, /* PA30 FCC1_TXCLAV SLAVE */ - {0, 1, 0, 1, 0, 0}, /* PA29 FCC1_TXSOC */ - {0, 1, 0, 0, 0, 0}, /* PA28 FCC1_RXENB SLAVE */ - {0, 1, 0, 0, 0, 0}, /* PA27 FCC1_RXSOC */ - {0, 1, 0, 1, 0, 0}, /* PA26 FCC1_RXCLAV SLAVE */ - {0, 1, 0, 1, 0, 1}, /* PA25 FCC1_TXD0 */ - {0, 1, 0, 1, 0, 1}, /* PA24 FCC1_TXD1 */ - {0, 1, 0, 1, 0, 1}, /* PA23 FCC1_TXD2 */ - {0, 1, 0, 1, 0, 1}, /* PA22 FCC1_TXD3 */ - {0, 1, 0, 1, 0, 1}, /* PA21 FCC1_TXD4 */ - {0, 1, 0, 1, 0, 1}, /* PA20 FCC1_TXD5 */ - {0, 1, 0, 1, 0, 1}, /* PA19 FCC1_TXD6 */ - {0, 1, 0, 1, 0, 1}, /* PA18 FCC1_TXD7 */ - {0, 1, 0, 0, 0, 0}, /* PA17 FCC1_RXD7 */ - {0, 1, 0, 0, 0, 0}, /* PA16 FCC1_RXD6 */ - {0, 1, 0, 0, 0, 0}, /* PA15 FCC1_RXD5 */ - {0, 1, 0, 0, 0, 0}, /* PA14 FCC1_RXD4 */ - {0, 1, 0, 0, 0, 0}, /* PA13 FCC1_RXD3 */ - {0, 1, 0, 0, 0, 0}, /* PA12 FCC1_RXD2 */ - {0, 1, 0, 0, 0, 0}, /* PA11 FCC1_RXD1 */ - {0, 1, 0, 0, 0, 0}, /* PA10 FCC1_RXD0 */ - {0, 1, 1, 1, 0, 1}, /* PA9 TDMA1_L1TXD */ - {0, 1, 1, 0, 0, 0}, /* PA8 TDMA1_L1RXD */ - {0, 0, 0, 0, 0, 0}, /* PA7 CONFIG0 */ - {0, 1, 1, 0, 0, 1}, /* PA6 TDMA1_L1RSYNC */ - {0, 0, 0, 1, 0, 0}, /* PA5 FCC2:RxAddr[2] */ - {0, 0, 0, 1, 0, 0}, /* PA4 FCC2:RxAddr[1] */ - {0, 0, 0, 1, 0, 0}, /* PA3 FCC2:RxAddr[0] */ - {0, 0, 0, 1, 0, 0}, /* PA2 FCC2:TxAddr[0] */ - {0, 0, 0, 1, 0, 0}, /* PA1 FCC2:TxAddr[1] */ - {0, 0, 0, 1, 0, 0} /* PA0 FCC2:TxAddr[2] */ - }, - /* Port B configuration */ - { /* conf ppar psor pdir podr pdat */ - {0, 0, 0, 1, 0, 0}, /* PB31 FCC2_RXSOC */ - {0, 0, 0, 1, 0, 0}, /* PB30 FCC2_TXSOC */ - {0, 0, 0, 1, 0, 0}, /* PB29 FCC2_RXCLAV */ - {0, 0, 0, 0, 0, 0}, /* PB28 CONFIG2 */ - {0, 1, 1, 0, 0, 1}, /* PB27 FCC2_TXD0 */ - {0, 1, 1, 0, 0, 0}, /* PB26 FCC2_TXD1 */ - {0, 0, 0, 1, 0, 0}, /* PB25 FCC2_TXD4 */ - {0, 1, 1, 0, 0, 1}, /* PB24 FCC2_TXD5 */ - {0, 0, 0, 1, 0, 0}, /* PB23 FCC2_TXD6 */ - {0, 1, 0, 1, 0, 1}, /* PB22 FCC2_TXD7 */ - {0, 1, 0, 0, 0, 0}, /* PB21 FCC2_RXD7 */ - {0, 1, 0, 0, 0, 0}, /* PB20 FCC2_RXD6 */ - {0, 1, 0, 0, 0, 0}, /* PB19 FCC2_RXD5 */ - {0, 0, 0, 1, 0, 0}, /* PB18 FCC2_RXD4 */ - {1, 1, 0, 0, 0, 0}, /* PB17 FCC3_RX_DV */ - {1, 1, 0, 0, 0, 0}, /* PB16 FCC3_RX_ER */ - {1, 1, 0, 1, 0, 0}, /* PB15 FCC3_TX_ER */ - {1, 1, 0, 1, 0, 0}, /* PB14 FCC3_TX_EN */ - {1, 1, 0, 0, 0, 0}, /* PB13 FCC3_COL */ - {1, 1, 0, 0, 0, 0}, /* PB12 FCC3_CRS */ - {1, 1, 0, 0, 0, 0}, /* PB11 FCC3_RXD3 */ - {1, 1, 0, 0, 0, 0}, /* PB10 FCC3_RXD2 */ - {1, 1, 0, 0, 0, 0}, /* PB9 FCC3_RXD1 */ - {1, 1, 0, 0, 0, 0}, /* PB8 FCC3_RXD0 */ - {1, 1, 0, 1, 0, 1}, /* PB7 FCC3_TXD0 */ - {1, 1, 0, 1, 0, 1}, /* PB6 FCC3_TXD1 */ - {1, 1, 0, 1, 0, 1}, /* PB5 FCC3_TXD2 */ - {1, 1, 0, 1, 0, 1}, /* PB4 FCC3_TXD3 */ - {0, 0, 0, 0, 0, 0}, /* PB3 */ - {0, 0, 0, 0, 0, 0}, /* PB2 */ - {0, 0, 0, 0, 0, 0}, /* PB1 */ - {0, 0, 0, 0, 0, 0}, /* PB0 */ - }, - /* Port C configuration */ - { /* conf ppar psor pdir podr pdat */ - {0, 1, 0, 0, 0, 1}, /* PC31 CLK1 */ - {0, 0, 0, 1, 0, 0}, /* PC30 U1MASTER_N */ - {0, 1, 0, 0, 0, 1}, /* PC29 CLK3 */ - {0, 0, 0, 1, 0, 1}, /* PC28 -MT90220_RST */ - {0, 1, 0, 0, 0, 1}, /* PC27 CLK5 */ - {0, 0, 0, 1, 0, 1}, /* PC26 -QUADFALC_RST */ - {0, 1, 1, 1, 0, 1}, /* PC25 BRG4 */ - {1, 0, 0, 1, 0, 0}, /* PC24 MDIO */ - {1, 0, 0, 1, 0, 0}, /* PC23 MDC */ - {0, 1, 0, 0, 0, 1}, /* PC22 CLK10 */ - {0, 0, 0, 1, 0, 0}, /* PC21 */ - {0, 1, 0, 0, 0, 1}, /* PC20 CLK12 */ - {0, 1, 0, 0, 0, 1}, /* PC19 CLK13 */ - {1, 1, 0, 0, 0, 1}, /* PC18 CLK14 */ - {0, 1, 0, 0, 0, 0}, /* PC17 CLK15 */ - {1, 1, 0, 0, 0, 1}, /* PC16 CLK16 */ - {0, 1, 1, 0, 0, 0}, /* PC15 FCC1_TXADDR0 SLAVE */ - {0, 1, 1, 0, 0, 0}, /* PC14 FCC1_RXADDR0 SLAVE */ - {0, 1, 1, 0, 0, 0}, /* PC13 FCC1_TXADDR1 SLAVE */ - {0, 1, 1, 0, 0, 0}, /* PC12 FCC1_RXADDR1 SLAVE */ - {0, 0, 0, 1, 0, 0}, /* PC11 FCC2_RXD2 */ - {0, 0, 0, 1, 0, 0}, /* PC10 FCC2_RXD3 */ - {0, 0, 0, 1, 0, 1}, /* PC9 LTMODE */ - {0, 0, 0, 1, 0, 1}, /* PC8 SELSYNC */ - {0, 1, 1, 0, 0, 0}, /* PC7 FCC1_TXADDR2 SLAVE */ - {0, 1, 1, 0, 0, 0}, /* PC6 FCC1_RXADDR2 SLAVE */ - {0, 0, 0, 1, 0, 0}, /* PC5 FCC2_TXCLAV MASTER */ - {0, 0, 0, 1, 0, 0}, /* PC4 FCC2_RXENB MASTER */ - {0, 0, 0, 1, 0, 0}, /* PC3 FCC2_TXD2 */ - {0, 0, 0, 1, 0, 0}, /* PC2 FCC2_TXD3 */ - {0, 0, 0, 0, 0, 1}, /* PC1 PTMC -PTEENB */ - {0, 0, 0, 1, 0, 1}, /* PC0 COMCLK_N */ - }, - /* Port D configuration */ - { /* conf ppar psor pdir podr pdat */ - {0, 0, 0, 1, 0, 1}, /* PD31 -CAM_RST */ - {0, 0, 0, 1, 0, 0}, /* PD30 FCC2_TXENB */ - {0, 1, 1, 0, 0, 0}, /* PD29 FCC1_RXADDR3 SLAVE */ - {0, 1, 1, 0, 0, 1}, /* PD28 TDMC1_L1TXD */ - {0, 1, 1, 0, 0, 0}, /* PD27 TDMC1_L1RXD */ - {0, 1, 1, 0, 0, 1}, /* PD26 TDMC1_L1RSYNC */ - {0, 0, 0, 1, 0, 1}, /* PD25 LED0 -OFF */ - {0, 0, 0, 1, 0, 1}, /* PD24 LED5 -OFF */ - {1, 0, 0, 1, 0, 1}, /* PD23 -LXT971_RST */ - {0, 1, 1, 0, 0, 1}, /* PD22 TDMA2_L1TXD */ - {0, 1, 1, 0, 0, 0}, /* PD21 TDMA2_L1RXD */ - {0, 1, 1, 0, 0, 1}, /* PD20 TDMA2_L1RSYNC */ - {0, 0, 0, 1, 0, 0}, /* PD19 FCC2_TXADDR3 */ - {0, 0, 0, 1, 0, 0}, /* PD18 FCC2_RXADDR3 */ - {0, 1, 0, 1, 0, 0}, /* PD17 BRG2 */ - {0, 0, 0, 1, 0, 0}, /* PD16 */ - {0, 0, 0, 1, 0, 0}, /* PD15 PT2TO1 */ - {0, 0, 0, 1, 0, 1}, /* PD14 PT4TO3 */ - {0, 0, 0, 1, 0, 1}, /* PD13 -SWMODE */ - {0, 0, 0, 1, 0, 1}, /* PD12 -PTMODE */ - {0, 0, 0, 1, 0, 0}, /* PD11 FCC2_RXD0 */ - {0, 0, 0, 1, 0, 0}, /* PD10 FCC2_RXD1 */ - {1, 1, 0, 1, 0, 1}, /* PD9 SMC1_SMTXD */ - {1, 1, 0, 0, 0, 1}, /* PD8 SMC1_SMRXD */ - {0, 1, 1, 0, 0, 0}, /* PD7 FCC1_TXADDR3 SLAVE */ - {0, 0, 0, 1, 0, 0}, /* PD6 IMAMODE */ - {0, 0, 0, 0, 0, 0}, /* PD5 CONFIG2 */ - {0, 1, 0, 1, 0, 0}, /* PD4 BRG8 */ - {0, 0, 0, 0, 0, 0}, /* PD3 */ - {0, 0, 0, 0, 0, 0}, /* PD2 */ - {0, 0, 0, 0, 0, 0}, /* PD1 */ - {0, 0, 0, 0, 0, 0}, /* PD0 */ - } -}; - -phys_size_t initdram (int board_type) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8260_t *memctl = &immap->im_memctl; - volatile uchar *base; - ulong maxsize; - int i; - - memctl->memc_psrt = CONFIG_SYS_PSRT; - memctl->memc_mptpr = CONFIG_SYS_MPTPR; - -#ifndef CONFIG_SYS_RAMBOOT - immap->im_siu_conf.sc_ppc_acr = 0x00000026; - immap->im_siu_conf.sc_ppc_alrh = 0x01276345; - immap->im_siu_conf.sc_ppc_alrl = 0x89ABCDEF; - immap->im_siu_conf.sc_lcl_acr = 0x00000000; - immap->im_siu_conf.sc_lcl_alrh = 0x01234567; - immap->im_siu_conf.sc_lcl_alrl = 0x89ABCDEF; - immap->im_siu_conf.sc_tescr1 = 0x00004000; - immap->im_siu_conf.sc_ltescr1 = 0x00004000; - - /* Init Main SDRAM */ -#define OP_VALUE 0x404A241A -#define OP_VALUE_M (OP_VALUE & 0x87FFFFFF); - base = (uchar *) CONFIG_SYS_SDRAM_BASE; - memctl->memc_psdmr = 0x28000000 | OP_VALUE_M; - *base = 0xFF; - memctl->memc_psdmr = 0x08000000 | OP_VALUE_M; - for (i = 0; i < 8; i++) - *base = 0xFF; - memctl->memc_psdmr = 0x18000000 | OP_VALUE_M; - *(base + 0x110) = 0xFF; - memctl->memc_psdmr = OP_VALUE; - memctl->memc_lsdmr = 0x4086A522; - *base = 0xFF; - - /* We must be able to test a location outsize the maximum legal size - * to find out THAT we are outside; but this address still has to be - * mapped by the controller. That means, that the initial mapping has - * to be (at least) twice as large as the maximum expected size. - */ - maxsize = (1 + (~memctl->memc_or1 | 0x7fff)) / 2; - - maxsize = get_ram_size((long *)base, maxsize); - - memctl->memc_or1 |= ~(maxsize - 1); - - if (maxsize != hwc_main_sdram_size ()) - printf ("Oops: memory test has not found all memory!\n"); -#endif - - icache_enable (); - /* return total ram size of SDRAM */ - return (maxsize); -} - -int checkboard (void) -{ - char string[32]; - - hwc_manufact_date (string); - - printf ("Board: Interphase 4539 (#%d %s)\n", - hwc_serial_number (), - string); - -#ifdef DEBUG - printf ("Manufacturing date: %s\n", string); - printf ("Serial number : %d\n", hwc_serial_number ()); - printf ("FLASH size : %d MB\n", hwc_flash_size () >> 20); - printf ("Main SDRAM size : %d MB\n", hwc_main_sdram_size () >> 20); - printf ("Local SDRAM size : %d MB\n", hwc_local_sdram_size () >> 20); - hwc_mac_address (string); - printf ("MAC address : %s\n", string); -#endif - - return 0; -} - -int misc_init_r (void) -{ - char *s, str[32]; - int num; - - if ((s = getenv ("serial#")) == NULL && - (num = hwc_serial_number ()) != -1) { - sprintf (str, "%06d", num); - setenv ("serial#", str); - } - if ((s = getenv ("ethaddr")) == NULL && hwc_mac_address (str) == 0) { - setenv ("ethaddr", str); - } - return (0); -} - -/*************************************************************** - * We take some basic Hardware Configuration Parameter from the - * Serial EEPROM conected to the PSpan bridge. We keep it as - * simple as possible. - */ -int hwc_flash_size (void) -{ - uchar byte; - - if (!seeprom_read (0x40, &byte, sizeof (byte))) { - switch ((byte >> 2) & 0x3) { - case 0x1: - return 0x0400000; - break; - case 0x2: - return 0x0800000; - break; - case 0x3: - return 0x1000000; - default: - return 0x0100000; - } - } - return -1; -} -int hwc_local_sdram_size (void) -{ - uchar byte; - - if (!seeprom_read (0x40, &byte, sizeof (byte))) { - switch ((byte & 0x03)) { - case 0x1: - return 0x0800000; - case 0x2: - return 0x1000000; - default: - return 0; /* not present */ - } - } - return -1; -} -int hwc_main_sdram_size (void) -{ - uchar byte; - - if (!seeprom_read (0x41, &byte, sizeof (byte))) { - return 0x1000000 << ((byte >> 5) & 0x7); - } - return -1; -} -int hwc_serial_number (void) -{ - int sn = -1; - - if (!seeprom_read (0xa0, (uchar *) &sn, sizeof (sn))) { - sn = cpu_to_le32 (sn); - } - return sn; -} -int hwc_mac_address (char *str) -{ - char mac[6]; - - if (!seeprom_read (0xb0, (uchar *)mac, sizeof (mac))) { - sprintf (str, "%02x:%02x:%02x:%02x:%02x:%02x\n", - mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]); - } else { - strcpy (str, "ERROR"); - return -1; - } - return 0; -} -int hwc_manufact_date (char *str) -{ - uchar byte; - int value; - - if (seeprom_read (0x92, &byte, sizeof (byte))) - goto out; - value = byte; - if (seeprom_read (0x93, &byte, sizeof (byte))) - goto out; - value += byte << 8; - sprintf (str, "%02d/%02d/%04d", - value & 0x1F, (value >> 5) & 0xF, - 1980 + ((value >> 9) & 0x1FF)); - return 0; - - out: - strcpy (str, "ERROR"); - return -1; -} - -#define PSPAN_ADDR 0xF0020000 -#define EEPROM_REG 0x408 -#define EEPROM_READ_CMD 0xA000 -#define PSPAN_WRITE(a,v) \ - *((volatile unsigned long *)(PSPAN_ADDR+(a))) = v; eieio() -#define PSPAN_READ(a) \ - *((volatile unsigned long *)(PSPAN_ADDR+(a))) - -int seeprom_read (int addr, uchar * data, int size) -{ - ulong val, cmd; - int i; - - for (i = 0; i < size; i++) { - - cmd = EEPROM_READ_CMD; - cmd |= ((addr + i) << 24) & 0xff000000; - - /* Wait for ACT to authorize write */ - while ((val = PSPAN_READ (EEPROM_REG)) & 0x80) - eieio (); - - /* Write command */ - PSPAN_WRITE (EEPROM_REG, cmd); - - /* Wait for data to be valid */ - while ((val = PSPAN_READ (EEPROM_REG)) & 0x80) - eieio (); - /* Do it twice, first read might be erratic */ - while ((val = PSPAN_READ (EEPROM_REG)) & 0x80) - eieio (); - - /* Read error */ - if (val & 0x00000040) { - return -1; - } else { - data[i] = (val >> 16) & 0xff; - } - } - return 0; -} diff --git a/configs/IPHASE4539_defconfig b/configs/IPHASE4539_defconfig deleted file mode 100644 index d49ea52..0000000 --- a/configs/IPHASE4539_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_IPHASE4539=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 7f76aae..af4b00c 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,7 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +IPHASE4539 powerpc mpc8260 - - Wolfgang Grandegger wg@denx.de muas3001 powerpc mpc8260 - - Heiko Schocher hs@denx.de PM825 powerpc mpc8260 - - Wolfgang Denk wd@denx.de PM826 powerpc mpc8260 - - Wolfgang Denk wd@denx.de diff --git a/include/configs/IPHASE4539.h b/include/configs/IPHASE4539.h deleted file mode 100644 index e402075..0000000 --- a/include/configs/IPHASE4539.h +++ /dev/null @@ -1,328 +0,0 @@ -/* - * (C) Copyright 2002 Wolfgang Grandegger wg@denx.de - * - * This file is based on similar values for other boards found in - * other U-Boot config files, mainly tqm8260.h and mpc8260ads.h. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * Config header file for a Interphase 4539 PMC, 64 MB SDRAM, 4MB Flash. - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/*----------------------------------------------------------------------- - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_IPHASE4539 1 /* ...on a Interphase 4539 PMC */ - -#define CONFIG_SYS_TEXT_BASE 0xffb00000 - -#define CONFIG_CPM2 1 /* Has a CPM2 */ - -/*----------------------------------------------------------------------- - * select serial console configuration - * - * if either CONFIG_CONS_ON_SMC or CONFIG_CONS_ON_SCC is selected, then - * CONFIG_CONS_INDEX must be set to the channel number (1-2 for SMC, 1-4 - * for SCC). - * - * if CONFIG_CONS_NONE is defined, then the serial console routines must - * defined elsewhere (for example, on the cogent platform, there are serial - * ports on the motherboard which are used for the serial console - see - * cogent/cma101/serial.[ch]). - */ -#define CONFIG_CONS_ON_SMC /* define if console on SMC */ -#undef CONFIG_CONS_ON_SCC /* define if console on SCC */ -#undef CONFIG_CONS_NONE /* define if console on something else */ -#define CONFIG_CONS_INDEX 1 /* which serial channel for console */ - -/*----------------------------------------------------------------------- - * select ethernet configuration - * - * if either CONFIG_ETHER_ON_SCC or CONFIG_ETHER_ON_FCC is selected, then - * CONFIG_ETHER_INDEX must be set to the channel number (1-4 for SCC, 1-3 - * for FCC) - * - * if CONFIG_ETHER_NONE is defined, then either the ethernet routines must be - * defined elsewhere (as for the console), or CONFIG_CMD_NET must be unset. - */ -#undef CONFIG_ETHER_ON_SCC /* define if ether on SCC */ -#define CONFIG_ETHER_ON_FCC /* define if ether on FCC */ -#undef CONFIG_ETHER_NONE /* define if ether on something else */ -#define CONFIG_ETHER_INDEX 3 /* which channel for ether */ - -#if defined(CONFIG_ETHER_ON_FCC) && (CONFIG_ETHER_INDEX == 3) - -/*----------------------------------------------------------------------- - * - Rx-CLK is CLK14 - * - Tx-CLK is CLK16 - * - Select bus for bd/buffers (see 28-13) - * - Half duplex - */ -# define CONFIG_SYS_CMXFCR_MASK3 (CMXFCR_FC3 | CMXFCR_RF3CS_MSK | CMXFCR_TF3CS_MSK) -# define CONFIG_SYS_CMXFCR_VALUE3 (CMXFCR_RF3CS_CLK14 | CMXFCR_TF3CS_CLK16) -# define CONFIG_SYS_CPMFCR_RAMTYPE 0 -# define CONFIG_SYS_FCC_PSMR (FCC_PSMR_FDE|FCC_PSMR_LPB) - -#endif /* CONFIG_ETHER_ON_FCC, CONFIG_ETHER_INDEX */ - -/* other options */ - -#define CONFIG_8260_CLKIN 66666666 /* in Hz */ -#define CONFIG_BAUDRATE 19200 - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE - -/* - * select i2c support configuration - * - * Supported configurations are {none, software, hardware} drivers. - * If the software driver is chosen, there are some additional - * configuration items that the driver uses to drive the port pins. - */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_SOFT /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SOFT_SPEED 400000 -#define CONFIG_SYS_I2C_SOFT_SLAVE 0x7F -/* - * Software (bit-bang) I2C driver configuration - */ -#define I2C_PORT 3 /* Port A=0, B=1, C=2, D=3 */ -#define I2C_ACTIVE (iop->pdir |= 0x00010000) -#define I2C_TRISTATE (iop->pdir &= ~0x00010000) -#define I2C_READ ((iop->pdat & 0x00010000) != 0) -#define I2C_SDA(bit) if(bit) iop->pdat |= 0x00010000; \ - else iop->pdat &= ~0x00010000 -#define I2C_SCL(bit) if(bit) iop->pdat |= 0x00020000; \ - else iop->pdat &= ~0x00020000 -#define I2C_DELAY udelay(5) /* 1/4 I2C clock duration */ - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - - -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ -#define CONFIG_BOOTCOMMAND "bootm 100000" /* autoboot command */ -#define CONFIG_BOOTARGS "root=/dev/ram rw" - -#if defined(CONFIG_CMD_KGDB) -#undef CONFIG_KGDB_ON_SMC /* define if kgdb on SMC */ -#define CONFIG_KGDB_ON_SCC /* define if kgdb on SCC */ -#undef CONFIG_KGDB_NONE /* define if kgdb on something else */ -#define CONFIG_KGDB_INDEX 2 /* which serial channel for kgdb */ -#define CONFIG_KGDB_BAUDRATE 115200 /* speed to run kgdb serial port at */ -#endif - -#undef CONFIG_WATCHDOG /* disable platform specific watchdog */ - -/*----------------------------------------------------------------------- - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x00100000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x00F00000 /* 1 ... 15 MB in DRAM */ - -#define CONFIG_CLOCKS_IN_MHZ 1 /* clocks passed to Linux in MHz */ - /* for versions < 2.4.5-pre5 */ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -#define CONFIG_SYS_RESET_ADDRESS 0x04400000 - -#define CONFIG_MISC_INIT_R 1 /* We need misc_init_r() */ - -/*----------------------------------------------------------------------- - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration (Setup by the - * startup code). Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0. - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0xFF800000 - -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max num of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 64 /* max num of sects on one chip */ -#define CONFIG_SYS_MAX_FLASH_SIZE (CONFIG_SYS_MAX_FLASH_SECT * 0x10000) /* 4 MB */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 2400000 /* Flash Erase Timeout (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (in ms) */ - -/* Environment in FLASH, there is little space left in Serial EEPROM */ -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_SECT_SIZE 0x10000 /* We use one complete sector */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x10000) /* 2. sector */ - - -/*----------------------------------------------------------------------- - * Hard Reset Configuration Words - * - * if you change bits in the HRCW, you must also change the CONFIG_SYS_* - * defines for the various registers affected by the HRCW e.g. changing - * HRCW_DPPCxx requires you to also change CONFIG_SYS_SIUMCR. - */ -#define CONFIG_SYS_HRCW_MASTER ( ( HRCW_BPS01 | HRCW_EBM ) |\ - ( HRCW_L2CPC10 | HRCW_ISB110 ) |\ - ( HRCW_MMR11 | HRCW_APPC10 ) |\ - ( HRCW_CS10PC01 | HRCW_MODCK_H0101 ) \ - ) /* 0x14863245 */ - -/* no slaves */ -#define CONFIG_SYS_HRCW_SLAVE1 0 -#define CONFIG_SYS_HRCW_SLAVE2 0 -#define CONFIG_SYS_HRCW_SLAVE3 0 -#define CONFIG_SYS_HRCW_SLAVE4 0 -#define CONFIG_SYS_HRCW_SLAVE5 0 -#define CONFIG_SYS_HRCW_SLAVE6 0 -#define CONFIG_SYS_HRCW_SLAVE7 0 - -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xFF000000 /* We keep original value */ - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC8260 CPU */ -#if defined(CONFIG_CMD_KGDB) -# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * HIDx - Hardware Implementation-dependent Registers 2-11 - *----------------------------------------------------------------------- - * HID0 also contains cache control. - * - * HID1 has only read-only information - nothing to set. - */ -#define CONFIG_SYS_HID0_INIT (HID0_ICE|HID0_DCE|HID0_ICFI|HID0_DCI|\ - HID0_IFEM|HID0_ABE) -#define CONFIG_SYS_HID0_FINAL (HID0_IFEM|HID0_ABE) -#define CONFIG_SYS_HID2 0 - -/*----------------------------------------------------------------------- - * RMR - Reset Mode Register 5-5 - *----------------------------------------------------------------------- - * turn on Checkstop Reset Enable - */ -#define CONFIG_SYS_RMR RMR_CSRE - -/*----------------------------------------------------------------------- - * BCR - Bus Configuration 4-25 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_BCR 0xA01C0000 - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 4-31 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_SIUMCR 0X4205C000 - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 4-35 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Watchdog & Bus Monitor Timer max, 60x Bus Monitor enable - */ -#if defined (CONFIG_WATCHDOG) -#define CONFIG_SYS_SYPCR (SYPCR_SWTC|SYPCR_BMT|SYPCR_PBME|SYPCR_LBME|\ - SYPCR_SWRI|SYPCR_SWP|SYPCR_SWE) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC|SYPCR_BMT|SYPCR_PBME|SYPCR_LBME|\ - SYPCR_SWRI|SYPCR_SWP) -#endif /* CONFIG_WATCHDOG */ - -/*----------------------------------------------------------------------- - * TMCNTSC - Time Counter Status and Control 4-40 - * Clear once per Second and Alarm Interrupt Status, Set 32KHz timersclk, - * and enable Time Counter - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_TMCNTSC (TMCNTSC_SEC|TMCNTSC_ALR|TMCNTSC_TCF|TMCNTSC_TCE) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 4-42 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Set 32KHz timersclk, and enable - * Periodic timer - */ -#define CONFIG_SYS_PISCR (PISCR_PS|PISCR_PTF|PISCR_PTE) - -/*----------------------------------------------------------------------- - * SCCR - System Clock Control 9-8 - *----------------------------------------------------------------------- - * Ensure DFBRG is Divide by 16 - */ -#define CONFIG_SYS_SCCR 0 - -/*----------------------------------------------------------------------- - * RCCR - RISC Controller Configuration 13-7 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RCCR 0 - -/*----------------------------------------------------------------------- - * Init Memory Controller: - * - * Bank Bus Machine PortSz Device - * ---- --- ------- ------ ------ - * 0 60x GPCM 64 bit FLASH - * 1 60x SDRAM 64 bit SDRAM - */ - -#define CONFIG_SYS_BR0_PRELIM ((CONFIG_SYS_FLASH_BASE & BRx_BA_MSK) | 0x0801) -#define CONFIG_SYS_OR0_PRELIM 0xFF800882 -#define CONFIG_SYS_BR1_PRELIM ((CONFIG_SYS_SDRAM_BASE & BRx_BA_MSK) | 0x0041) -#define CONFIG_SYS_OR1_PRELIM 0xF8002CD0 - -#define CONFIG_SYS_PSDMR 0x404A241A -#define CONFIG_SYS_MPTPR 0x00007400 -#define CONFIG_SYS_PSRT 0x00000007 - -#endif /* __CONFIG_H */
On Mon, Dec 15, 2014 at 11:26:26PM +0900, Masahiro Yamada wrote:
This board is still a non-generic board.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Oliver Brown obrown@adventnetworks.com ---
arch/powerpc/cpu/mpc8260/Kconfig | 4 - board/gw8260/Kconfig | 9 - board/gw8260/MAINTAINERS | 6 - board/gw8260/Makefile | 8 - board/gw8260/flash.c | 502 ------------------------ board/gw8260/gw8260.c | 639 ------------------------------- configs/gw8260_defconfig | 3 - doc/README.scrapyard | 1 + include/configs/gw8260.h | 800 --------------------------------------- 9 files changed, 1 insertion(+), 1971 deletions(-) delete mode 100644 board/gw8260/Kconfig delete mode 100644 board/gw8260/MAINTAINERS delete mode 100644 board/gw8260/Makefile delete mode 100644 board/gw8260/flash.c delete mode 100644 board/gw8260/gw8260.c delete mode 100644 configs/gw8260_defconfig delete mode 100644 include/configs/gw8260.h
diff --git a/arch/powerpc/cpu/mpc8260/Kconfig b/arch/powerpc/cpu/mpc8260/Kconfig index 56b79ac..59e2bed 100644 --- a/arch/powerpc/cpu/mpc8260/Kconfig +++ b/arch/powerpc/cpu/mpc8260/Kconfig @@ -19,9 +19,6 @@ config TARGET_CPU87 config TARGET_EP82XXM bool "Support ep82xxm"
-config TARGET_GW8260 - bool "Support gw8260" - config TARGET_KM82XX bool "Support km82xx"
@@ -31,7 +28,6 @@ source "board/atc/Kconfig" source "board/cpu86/Kconfig" source "board/cpu87/Kconfig" source "board/ep82xxm/Kconfig" -source "board/gw8260/Kconfig" source "board/keymile/km82xx/Kconfig"
endmenu diff --git a/board/gw8260/Kconfig b/board/gw8260/Kconfig deleted file mode 100644 index 1d6aa80..0000000 --- a/board/gw8260/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_GW8260 - -config SYS_BOARD - default "gw8260" - -config SYS_CONFIG_NAME - default "gw8260" - -endif diff --git a/board/gw8260/MAINTAINERS b/board/gw8260/MAINTAINERS deleted file mode 100644 index 5268d19..0000000 --- a/board/gw8260/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -GW8260 BOARD -M: Oliver Brown obrown@adventnetworks.com -S: Maintained -F: board/gw8260/ -F: include/configs/gw8260.h -F: configs/gw8260_defconfig diff --git a/board/gw8260/Makefile b/board/gw8260/Makefile deleted file mode 100644 index 2e23f39..0000000 --- a/board/gw8260/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y := gw8260.o flash.o diff --git a/board/gw8260/flash.c b/board/gw8260/flash.c deleted file mode 100644 index 0c4a943..0000000 --- a/board/gw8260/flash.c +++ /dev/null @@ -1,502 +0,0 @@ -/* - * (C) Copyright 2000 - * Marius Groeger mgroeger@sysgo.de - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * - * (C) Copyright 2000, 2001 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * (C) Copyright 2001 - * Advent Networks, Inc. http://www.adventnetworks.com - * Oliver Brown oliverb@alumni.utexas.net - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/*********************************************************************/ -/* DESCRIPTION: - * This file contains the flash routines for the GW8260 board. - * - * - * - * MODULE DEPENDENCY: - * None - * - * - * RESTRICTIONS/LIMITATIONS: - * - * Only supports the following flash devices: - * AMD 29F080B - * AMD 29F016D - * - * Copyright (c) 2001, Advent Networks, Inc. - * - */ -/*********************************************************************/ - -#include <common.h> -#include <mpc8260.h> - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; - -static ulong flash_get_size (vu_long *addr, flash_info_t *info); -static int write_word (flash_info_t *info, ulong dest, ulong data); - -/*********************************************************************/ -/* functions */ -/*********************************************************************/ - -/* - * NAME: flash_init() - initializes flash banks - * - * DESCRIPTION: - * This function initializes the flash bank(s). - * - * RETURNS: - * The size in bytes of the flash - * - * RESTRICTIONS/LIMITATIONS: - * - * - */ -unsigned long flash_init(void) -{ - int i; - - /* Init: no FLASHes known */ - for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; ++i) - flash_info[i].flash_id = FLASH_UNKNOWN; - - /* for now, only support the 4 MB Flash SIMM */ - (void)flash_get_size((vu_long *) CONFIG_SYS_FLASH0_BASE, - &flash_info[0]); - /* - * protect monitor and environment sectors - */ -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH0_BASE - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE + monitor_flash_len - 1, - &flash_info[0]); -#endif - -#if defined(CONFIG_ENV_IS_IN_FLASH) && defined(CONFIG_ENV_ADDR) -#ifndef CONFIG_ENV_SIZE -#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -#endif - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR + CONFIG_ENV_SIZE - 1, &flash_info[0]); -#endif - - return CONFIG_SYS_FLASH0_SIZE * 1024 * 1024; /*size */ -} - -/*********************************************************************/ -/* NAME: flash_print_info() - prints flash imformation */ -/* */ -/* DESCRIPTION: */ -/* This function prints the flash information. */ -/* */ -/* INPUTS: */ -/* flash_info_t *info - flash information structure */ -/* */ -/* OUTPUTS: */ -/* Displays flash information to console */ -/* */ -/* RETURNS: */ -/* None */ -/* */ -/* RESTRICTIONS/LIMITATIONS: */ -/* */ -/* */ -/*********************************************************************/ -void flash_print_info (flash_info_t *info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch ((info->flash_id >> 16) & 0xff) { - case 0x1: - printf ("AMD "); - break; - default: - printf ("Unknown Vendor "); - break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case AMD_ID_F040B: - printf ("AM29F040B (4 Mbit)\n"); - break; - case AMD_ID_F080B: - printf ("AM29F080B (8 Mbit)\n"); - break; - case AMD_ID_F016D: - printf ("AM29F016D (16 Mbit)\n"); - break; - default: - printf ("Unknown Chip Type\n"); - break; - } - - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); - - printf (" Sector Start Addresses:"); - for (i=0; i<info->sector_count; ++i) { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", - info->start[i], - info->protect[i] ? " (RO)" : " " - ); - } - printf ("\n"); - return; -} - -/*********************************************************************/ -/* The following code cannot be run from FLASH! */ -/*********************************************************************/ - -/*********************************************************************/ -/* NAME: flash_get_size() - detects the flash size */ -/* */ -/* DESCRIPTION: */ -/* 1) Reads vendor ID and devices ID from the flash devices. */ -/* 2) Initializes flash info struct. */ -/* 3) Return the flash size */ -/* */ -/* INPUTS: */ -/* vu_long *addr - pointer to start of flash */ -/* flash_info_t *info - flash information structure */ -/* */ -/* OUTPUTS: */ -/* None */ -/* */ -/* RETURNS: */ -/* Size of the flash in bytes, or 0 if device id is unknown. */ -/* */ -/* RESTRICTIONS/LIMITATIONS: */ -/* Only supports the following devices: */ -/* AM29F080D */ -/* AM29F016D */ -/* */ -/*********************************************************************/ -static ulong flash_get_size (vu_long *addr, flash_info_t *info) -{ - short i; - vu_long vendor, devid; - ulong base = (ulong)addr; - - /*printf("addr = %08lx\n", (unsigned long)addr); */ - - /* Reset and Write auto select command: read Manufacturer ID */ - addr[0x0000] = 0xf0f0f0f0; - addr[0x0555] = 0xAAAAAAAA; - addr[0x02AA] = 0x55555555; - addr[0x0555] = 0x90909090; - udelay (1000); - - vendor = addr[0]; - /*printf("vendor = %08lx\n", vendor); */ - if (vendor != 0x01010101) { - info->size = 0; - goto out; - } - - devid = addr[1]; - /*printf("devid = %08lx\n", devid); */ - - if ((devid & 0xff) == AMD_ID_F080B) { - info->flash_id = (vendor & 0xff) << 16 | AMD_ID_F080B; - /* we have 16 sectors with 64KB each x 4 */ - info->sector_count = 16; - info->size = 4 * info->sector_count * 64*1024; - } else if ((devid & 0xff) == AMD_ID_F016D){ - info->flash_id = (vendor & 0xff) << 16 | AMD_ID_F016D; - /* we have 32 sectors with 64KB each x 4 */ - info->sector_count = 32; - info->size = 4 * info->sector_count * 64*1024; - } else { - info->size = 0; - goto out; - } - /*printf("sector count = %08x\n", info->sector_count); */ - /* check for protected sectors */ - for (i = 0; i < info->sector_count; i++) { - /* sector base address */ - info->start[i] = base + i * (info->size / info->sector_count); - /* read sector protection at sector address, (A7 .. A0) = 0x02 */ - /* D0 = 1 if protected */ - addr = (volatile unsigned long *)(info->start[i]); - info->protect[i] = addr[2] & 1; - } - - /* reset command */ - addr = (vu_long *)info->start[0]; - - out: - addr[0] = 0xf0f0f0f0; - - /*printf("size = %08x\n", info->size); */ - return info->size; -} - -/*********************************************************************/ -/* NAME: flash_erase() - erases flash by sector */ -/* */ -/* DESCRIPTION: */ -/* This function erases flash sectors starting for s_first to */ -/* s_last. */ -/* */ -/* INPUTS: */ -/* flash_info_t *info - flash information structure */ -/* int s_first - first sector to erase */ -/* int s_last - last sector to erase */ -/* */ -/* OUTPUTS: */ -/* None */ -/* */ -/* RETURNS: */ -/* Returns 0 for success, 1 for failure. */ -/* */ -/* RESTRICTIONS/LIMITATIONS: */ -/* */ -/*********************************************************************/ -int flash_erase (flash_info_t *info, int s_first, int s_last) -{ - vu_long *addr = (vu_long*)(info->start[0]); - int flag, prot, sect, l_sect; - ulong start, now, last; - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - prot = 0; - for (sect = s_first; sect <= s_last; sect++) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - printf ("\n"); - } - - l_sect = -1; - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - addr[0x0555] = 0xAAAAAAAA; - addr[0x02AA] = 0x55555555; - addr[0x0555] = 0x80808080; - addr[0x0555] = 0xAAAAAAAA; - addr[0x02AA] = 0x55555555; - udelay (100); - - /* Start erase on unprotected sectors */ - for (sect = s_first; sect <= s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - addr = (vu_long*)(info->start[sect]); - addr[0] = 0x30303030; - l_sect = sect; - } - } - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - - /* - * We wait for the last triggered sector - */ - if (l_sect < 0) - goto DONE; - - start = get_timer (0); - last = start; - addr = (vu_long*)(info->start[l_sect]); - while ((addr[0] & 0x80808080) != 0x80808080) { - if ((now = get_timer(start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - return 1; - } - /* show that we're waiting */ - if ((now - last) > 1000) { /* every second */ - serial_putc ('.'); - last = now; - } - } - - DONE: - /* reset to read mode */ - addr = (volatile unsigned long *)info->start[0]; - addr[0] = 0xF0F0F0F0; /* reset bank */ - - printf (" done\n"); - return 0; -} - -/*********************************************************************/ -/* NAME: write_buff() - writes a buffer to flash */ -/* */ -/* DESCRIPTION: */ -/* This function copies a buffer, *src, to flash. */ -/* */ -/* INPUTS: */ -/* flash_info_t *info - flash information structure */ -/* uchar *src - pointer to buffer to write to flash */ -/* ulong addr - address to start write at */ -/* ulong cnt - number of bytes to write to flash */ -/* */ -/* OUTPUTS: */ -/* None */ -/* */ -/* RETURNS: */ -/* 0 - OK */ -/* 1 - write timeout */ -/* 2 - Flash not erased */ -/* */ -/* RESTRICTIONS/LIMITATIONS: */ -/* */ -/*********************************************************************/ -int write_buff (flash_info_t *info, uchar *src, ulong addr, ulong cnt) -{ - ulong cp, wp, data; - int i, l, rc; - - wp = (addr & ~3); /* get lower word aligned address */ - - /* - * handle unaligned start bytes - */ - if ((l = addr - wp) != 0) { - data = 0; - for (i = 0, cp = wp; i < l; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - for (; (i < 4) && (cnt > 0); ++i) { - data = (data << 8) | *src++; - --cnt; - ++cp; - } - for (; (cnt == 0) && (i < 4); ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - - if ((rc = write_word(info, wp, data)) != 0) { - return (rc); - } - wp += 4; - } - - /* - * handle word aligned part - */ - while (cnt >= 4) { - data = 0; - for (i = 0; i < 4; ++i) { - data = (data << 8) | *src++; - } - if ((rc = write_word(info, wp, data)) != 0) { - return (rc); - } - wp += 4; - cnt -= 4; - } - - if (cnt == 0) { - return (0); - } - - /* - * handle unaligned tail bytes - */ - data = 0; - for (i = 0, cp = wp; (i < 4) && (cnt > 0); ++i, ++cp) { - data = (data << 8) | *src++; - --cnt; - } - for (; (i < 4); ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - - return (write_word(info, wp, data)); -} - -/*********************************************************************/ -/* NAME: write_word() - writes a word to flash */ -/* */ -/* DESCRIPTION: */ -/* This writes a single word to flash. */ -/* */ -/* INPUTS: */ -/* flash_info_t *info - flash information structure */ -/* ulong dest - address to write */ -/* ulong data - data to write */ -/* */ -/* OUTPUTS: */ -/* None */ -/* */ -/* RETURNS: */ -/* 0 - OK */ -/* 1 - write timeout */ -/* 2 - Flash not erased */ -/* */ -/* RESTRICTIONS/LIMITATIONS: */ -/* */ -/*********************************************************************/ -static int write_word (flash_info_t *info, ulong dest, ulong data) -{ - vu_long *addr = (vu_long*)(info->start[0]); - ulong start; - int flag; - - /* Check if Flash is (sufficiently) erased */ - if ((*((vu_long *)dest) & data) != data) { - return (2); - } - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - addr[0x0555] = 0xAAAAAAAA; - addr[0x02AA] = 0x55555555; - addr[0x0555] = 0xA0A0A0A0; - - *((vu_long *)dest) = data; - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* data polling for D7 */ - start = get_timer (0); - while ((*((vu_long *)dest) & 0x80808080) != (data & 0x80808080)) { - if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - return (1); - } - } - return (0); -} -/*********************************************************************/ -/* End of flash.c */ -/*********************************************************************/ diff --git a/board/gw8260/gw8260.c b/board/gw8260/gw8260.c deleted file mode 100644 index bbae0a8..0000000 --- a/board/gw8260/gw8260.c +++ /dev/null @@ -1,639 +0,0 @@ -/* - * (C) Copyright 2000 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * - * (C) Copyright 2001 - * Advent Networks, Inc. http://www.adventnetworks.com - * Jay Monkman jtm@smoothsmoothie.com - * - * (C) Copyright 2001 - * Advent Networks, Inc. http://www.adventnetworks.com - * Oliver Brown oliverb@alumni.utexas.net - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/*********************************************************************/ -/* DESCRIPTION: - * This file contains the board routines for the GW8260 board. - * - * MODULE DEPENDENCY: - * None - * - * RESTRICTIONS/LIMITATIONS: - * None - * - * Copyright (c) 2001, Advent Networks, Inc. - */ -/*********************************************************************/ - -#include <common.h> -#include <ioports.h> -#include <mpc8260.h> - -/* - * I/O Port configuration table - * - */ -const iop_conf_t iop_conf_tab[4][32] = { - - /* Port A configuration */ - { /* conf ppar psor pdir podr pdat */ - /* PA31 */ { 1, 0, 0, 1, 0, 0 }, /* TP14 */ - /* PA30 */ { 1, 1, 1, 1, 0, 0 }, /* US_RTS */ - /* PA29 */ { 1, 0, 0, 1, 0, 1 }, /* LSSI_DATA */ - /* PA28 */ { 1, 0, 0, 1, 0, 1 }, /* LSSI_CLK */ - /* PA27 */ { 1, 0, 0, 1, 0, 0 }, /* TP12 */ - /* PA26 */ { 1, 0, 0, 0, 0, 0 }, /* IO_STATUS */ - /* PA25 */ { 1, 0, 0, 0, 0, 0 }, /* IO_CLOCK */ - /* PA24 */ { 1, 0, 0, 0, 0, 0 }, /* IO_CONFIG */ - /* PA23 */ { 1, 0, 0, 0, 0, 0 }, /* IO_DONE */ - /* PA22 */ { 1, 0, 0, 0, 0, 0 }, /* IO_DATA */ - /* PA21 */ { 1, 1, 0, 1, 0, 0 }, /* US_TXD3 */ - /* PA20 */ { 1, 1, 0, 1, 0, 0 }, /* US_TXD2 */ - /* PA19 */ { 1, 1, 0, 1, 0, 0 }, /* US_TXD1 */ - /* PA18 */ { 1, 1, 0, 1, 0, 0 }, /* US_TXD0 */ - /* PA17 */ { 1, 1, 0, 0, 0, 0 }, /* DS_RXD0 */ - /* PA16 */ { 1, 1, 0, 0, 0, 0 }, /* DS_RXD1 */ - /* PA15 */ { 1, 1, 0, 0, 0, 0 }, /* DS_RXD2 */ - /* PA14 */ { 1, 1, 0, 0, 0, 0 }, /* DS_RXD3 */ - /* PA13 */ { 1, 0, 0, 1, 0, 0 }, /* SPARE7 */ - /* PA12 */ { 1, 0, 0, 1, 0, 0 }, /* SPARE6 */ - /* PA11 */ { 1, 0, 0, 1, 0, 0 }, /* SPARE5 */ - /* PA10 */ { 1, 0, 0, 1, 0, 0 }, /* SPARE4 */ - /* PA9 */ { 1, 0, 0, 1, 0, 0 }, /* SPARE3 */ - /* PA8 */ { 1, 0, 0, 1, 0, 0 }, /* SPARE2 */ - /* PA7 */ { 1, 0, 0, 0, 0, 0 }, /* LSSI_IN */ - /* PA6 */ { 1, 0, 0, 1, 0, 0 }, /* SPARE0 */ - /* PA5 */ { 1, 0, 0, 1, 0, 0 }, /* DEMOD_RESET_ */ - /* PA4 */ { 1, 0, 0, 1, 0, 0 }, /* MOD_RESET_ */ - /* PA3 */ { 1, 0, 0, 1, 0, 0 }, /* IO_RESET */ - /* PA2 */ { 1, 0, 0, 1, 0, 0 }, /* TX_ENABLE */ - /* PA1 */ { 1, 0, 0, 0, 0, 0 }, /* RX_LOCK */ - /* PA0 */ { 1, 0, 0, 1, 0, 1 } /* MPC_RESET_ */ - }, - - /* Port B configuration */ - { /* conf ppar psor pdir podr pdat */ - /* PB31 */ { 1, 1, 0, 1, 0, 0 }, /* FETH0_TX_ER */ - /* PB30 */ { 1, 1, 0, 0, 0, 0 }, /* FETH0_RX_DV */ - /* PB29 */ { 1, 1, 1, 1, 0, 0 }, /* FETH0_TX_EN */ - /* PB28 */ { 1, 1, 0, 0, 0, 0 }, /* FETH0_RX_ER */ - /* PB27 */ { 1, 1, 0, 0, 0, 0 }, /* FETH0_COL */ - /* PB26 */ { 1, 1, 0, 0, 0, 0 }, /* FETH0_CRS */ - /* PB25 */ { 1, 1, 0, 1, 0, 0 }, /* FETH0_TXD3 */ - /* PB24 */ { 1, 1, 0, 1, 0, 0 }, /* FETH0_TXD2 */ - /* PB23 */ { 1, 1, 0, 1, 0, 0 }, /* FETH0_TXD1 */ - /* PB22 */ { 1, 1, 0, 1, 0, 0 }, /* FETH0_TXD0 */ - /* PB21 */ { 1, 1, 0, 0, 0, 0 }, /* FETH0_RXD0 */ - /* PB20 */ { 1, 1, 0, 0, 0, 0 }, /* FETH0_RXD1 */ - /* PB19 */ { 1, 1, 0, 0, 0, 0 }, /* FETH0_RXD2 */ - /* PB18 */ { 1, 1, 0, 0, 0, 0 }, /* FETH0_RXD3 */ - /* PB17 */ { 1, 1, 0, 0, 0, 0 }, /* FETH1_RX_DV */ - /* PB16 */ { 1, 1, 0, 0, 0, 0 }, /* FETH1_RX_ER */ - /* PB15 */ { 1, 1, 0, 1, 0, 0 }, /* FETH1_TX_ER */ - /* PB14 */ { 1, 1, 0, 1, 0, 0 }, /* FETH1_TX_EN */ - /* PB13 */ { 1, 1, 0, 0, 0, 0 }, /* FETH1_COL */ - /* PB12 */ { 1, 1, 0, 0, 0, 0 }, /* FETH1_CRS */ - /* PB11 */ { 1, 1, 0, 0, 0, 0 }, /* FETH1_RXD3 */ - /* PB10 */ { 1, 1, 0, 0, 0, 0 }, /* FETH1_RXD2 */ - /* PB9 */ { 1, 1, 0, 0, 0, 0 }, /* FETH1_RXD1 */ - /* PB8 */ { 1, 1, 0, 0, 0, 0 }, /* FETH1_RXD0 */ - /* PB7 */ { 1, 1, 0, 1, 0, 0 }, /* FETH1_TXD0 */ - /* PB6 */ { 1, 1, 0, 1, 0, 0 }, /* FETH1_TXD1 */ - /* PB5 */ { 1, 1, 0, 1, 0, 0 }, /* FETH1_TXD2 */ - /* PB4 */ { 1, 1, 0, 1, 0, 0 }, /* FETH1_TXD3 */ - /* PB3 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PB2 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PB1 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PB0 */ { 0, 0, 0, 0, 0, 0 } /* pin doesn't exist */ - }, - - /* Port C */ - { /* conf ppar psor pdir podr pdat */ - /* PC31 */ { 1, 0, 0, 1, 0, 1 }, /* FAST_RESET_ */ - /* PC30 */ { 1, 0, 0, 1, 0, 1 }, /* FAST_PAUSE_ */ - /* PC29 */ { 1, 0, 0, 1, 0, 0 }, /* FAST_SLEW1 */ - /* PC28 */ { 1, 0, 0, 1, 0, 0 }, /* FAST_SLEW0 */ - /* PC27 */ { 1, 0, 0, 1, 0, 0 }, /* TP13 */ - /* PC26 */ { 1, 0, 0, 0, 0, 0 }, /* RXDECDFLG */ - /* PC25 */ { 1, 0, 0, 0, 0, 0 }, /* RXACQFAIL */ - /* PC24 */ { 1, 0, 0, 0, 0, 0 }, /* RXACQFLG */ - /* PC23 */ { 1, 0, 0, 1, 0, 0 }, /* WD_TCL */ - /* PC22 */ { 1, 0, 0, 1, 0, 0 }, /* WD_EN */ - /* PC21 */ { 1, 0, 0, 1, 0, 0 }, /* US_TXCLK */ - /* PC20 */ { 1, 0, 0, 0, 0, 0 }, /* DS_RXCLK */ - /* PC19 */ { 1, 1, 0, 0, 0, 0 }, /* FETH0_RX_CLK */ - /* PC18 */ { 1, 1, 0, 0, 0, 0 }, /* FETH0_TX_CLK */ - /* PC17 */ { 1, 1, 0, 0, 0, 0 }, /* FETH1_RX_CLK */ - /* PC16 */ { 1, 1, 0, 0, 0, 0 }, /* FETH1_TX_CLK */ - /* PC15 */ { 1, 0, 0, 1, 0, 0 }, /* TX_SHUTDOWN_ */ - /* PC14 */ { 1, 0, 0, 0, 0, 0 }, /* RS_232_DTR_ */ - /* PC13 */ { 1, 0, 0, 0, 0, 0 }, /* TXERR */ - /* PC12 */ { 1, 0, 0, 1, 0, 1 }, /* FETH1_MDDIS */ - /* PC11 */ { 1, 0, 0, 1, 0, 1 }, /* FETH0_MDDIS */ - /* PC10 */ { 1, 0, 0, 1, 0, 0 }, /* MDC */ - /* PC9 */ { 1, 0, 0, 1, 1, 1 }, /* MDIO */ - /* PC8 */ { 1, 0, 0, 1, 1, 1 }, /* SER_NUM */ - /* PC7 */ { 1, 1, 0, 0, 0, 0 }, /* US_CTS */ - /* PC6 */ { 1, 1, 0, 0, 0, 0 }, /* DS_CD_ */ - /* PC5 */ { 1, 0, 0, 1, 0, 0 }, /* FETH1_PWRDWN */ - /* PC4 */ { 1, 0, 0, 1, 0, 0 }, /* FETH0_PWRDWN */ - /* PC3 */ { 1, 0, 0, 1, 0, 0 }, /* MPULED3 */ - /* PC2 */ { 1, 0, 0, 1, 0, 0 }, /* MPULED2 */ - /* PC1 */ { 1, 0, 0, 1, 0, 0 }, /* MPULED1 */ - /* PC0 */ { 1, 0, 0, 1, 0, 1 }, /* MPULED0 */ - }, - - /* Port D */ - { /* conf ppar psor pdir podr pdat */ - /* PD31 */ { 1, 0, 0, 0, 0, 0 }, /* not used */ - /* PD30 */ { 1, 0, 0, 0, 0, 0 }, /* not used */ - /* PD29 */ { 1, 0, 0, 0, 0, 0 }, /* not used */ - /* PD28 */ { 1, 0, 0, 0, 0, 0 }, /* not used */ - /* PD27 */ { 1, 0, 0, 0, 0, 0 }, /* not used */ - /* PD26 */ { 1, 0, 0, 0, 0, 0 }, /* not used */ - /* PD25 */ { 1, 0, 0, 0, 0, 0 }, /* not used */ - /* PD24 */ { 1, 0, 0, 0, 0, 0 }, /* not used */ - /* PD23 */ { 1, 0, 0, 0, 0, 0 }, /* not used */ - /* PD22 */ { 1, 0, 0, 0, 0, 0 }, /* not used */ - /* PD21 */ { 1, 0, 0, 0, 0, 0 }, /* not used */ - /* PD20 */ { 1, 0, 0, 0, 0, 0 }, /* not used */ - /* PD19 */ { 1, 1, 1, 0, 0, 0 }, /* not used */ - /* PD18 */ { 1, 1, 1, 0, 0, 0 }, /* not used */ - /* PD17 */ { 1, 1, 1, 0, 0, 0 }, /* not used */ - /* PD16 */ { 1, 1, 1, 0, 0, 0 }, /* not used */ - /* PD15 */ { 1, 1, 1, 0, 1, 1 }, /* SDRAM_SDA */ - /* PD14 */ { 1, 1, 1, 0, 1, 1 }, /* SDRAM_SCL */ - /* PD13 */ { 1, 0, 0, 1, 0, 0 }, /* MPULED7 */ - /* PD12 */ { 1, 0, 0, 1, 0, 0 }, /* MPULED6 */ - /* PD11 */ { 1, 0, 0, 1, 0, 0 }, /* MPULED5 */ - /* PD10 */ { 1, 0, 0, 1, 0, 0 }, /* MPULED4 */ - /* PD9 */ { 1, 1, 0, 1, 0, 0 }, /* RS232_TXD */ - /* PD8 */ { 1, 1, 0, 0, 0, 0 }, /* RD232_RXD */ - /* PD7 */ { 1, 0, 0, 0, 0, 0 }, /* not used */ - /* PD6 */ { 1, 0, 0, 0, 0, 0 }, /* not used */ - /* PD5 */ { 1, 0, 0, 0, 0, 0 }, /* not used */ - /* PD4 */ { 1, 0, 0, 0, 0, 0 }, /* not used */ - /* PD3 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PD2 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PD1 */ { 0, 0, 0, 0, 0, 0 }, /* pin doesn't exist */ - /* PD0 */ { 0, 0, 0, 0, 0, 0 } /* pin doesn't exist */ - } -}; - -/*********************************************************************/ -/* NAME: checkboard() - Displays the board type and serial number */ -/* */ -/* OUTPUTS: */ -/* Displays the board type and serial number */ -/* */ -/* RETURNS: */ -/* Always returns 1 */ -/* */ -/* RESTRICTIONS/LIMITATIONS: */ -/* */ -/* */ -/*********************************************************************/ -int checkboard (void) -{ - char buf[64]; - int i = getenv_f("serial#", buf, sizeof(buf)); - - puts ("Board: Advent Networks gw8260\n"); - - if (i > 0) { - printf("SN: %s\n", buf); - } - return 0; -} - - -#if defined (CONFIG_SYS_DRAM_TEST) -/*********************************************************************/ -/* NAME: move64() - moves a double word (64-bit) */ -/* */ -/* DESCRIPTION: */ -/* this function performs a double word move from the data at */ -/* the source pointer to the location at the destination pointer. */ -/* */ -/* INPUTS: */ -/* unsigned long long *src - pointer to data to move */ -/* */ -/* OUTPUTS: */ -/* unsigned long long *dest - pointer to locate to move data */ -/* */ -/* RETURNS: */ -/* None */ -/* */ -/* RESTRICTIONS/LIMITATIONS: */ -/* May cloober fr0. */ -/* */ -/*********************************************************************/ -static void move64 (unsigned long long *src, unsigned long long *dest) -{ - asm ("lfd 0, 0(3)\n\t" /* fpr0 = *scr */ - "stfd 0, 0(4)" /* *dest = fpr0 */ - : : : "fr0"); /* Clobbers fr0 */ - return; -} - - -#if defined (CONFIG_SYS_DRAM_TEST_DATA) - -unsigned long long pattern[] = { - 0xaaaaaaaaaaaaaaaaULL, - 0xccccccccccccccccULL, - 0xf0f0f0f0f0f0f0f0ULL, - 0xff00ff00ff00ff00ULL, - 0xffff0000ffff0000ULL, - 0xffffffff00000000ULL, - 0x00000000ffffffffULL, - 0x0000ffff0000ffffULL, - 0x00ff00ff00ff00ffULL, - 0x0f0f0f0f0f0f0f0fULL, - 0x3333333333333333ULL, - 0x5555555555555555ULL, -}; - -/*********************************************************************/ -/* NAME: mem_test_data() - test data lines for shorts and opens */ -/* */ -/* DESCRIPTION: */ -/* Tests data lines for shorts and opens by forcing adjacent data */ -/* to opposite states. Because the data lines could be routed in */ -/* an arbitrary manner the must ensure test patterns ensure that */ -/* every case is tested. By using the following series of binary */ -/* patterns every combination of adjacent bits is test regardless */ -/* of routing. */ -/* */ -/* ...101010101010101010101010 */ -/* ...110011001100110011001100 */ -/* ...111100001111000011110000 */ -/* ...111111110000000011111111 */ -/* */ -/* Carrying this out, gives us six hex patterns as follows: */ -/* */ -/* 0xaaaaaaaaaaaaaaaa */ -/* 0xcccccccccccccccc */ -/* 0xf0f0f0f0f0f0f0f0 */ -/* 0xff00ff00ff00ff00 */ -/* 0xffff0000ffff0000 */ -/* 0xffffffff00000000 */ -/* */ -/* The number test patterns will always be given by: */ -/* */ -/* log(base 2)(number data bits) = log2 (64) = 6 */ -/* */ -/* To test for short and opens to other signals on our boards. we */ -/* simply */ -/* test with the 1's complemnt of the paterns as well. */ -/* */ -/* OUTPUTS: */ -/* Displays failing test pattern */ -/* */ -/* RETURNS: */ -/* 0 - Passed test */ -/* 1 - Failed test */ -/* */ -/* RESTRICTIONS/LIMITATIONS: */ -/* Assumes only one one SDRAM bank */ -/* */ -/*********************************************************************/ -int mem_test_data (void) -{ - unsigned long long *pmem = (unsigned long long *) CONFIG_SYS_SDRAM_BASE; - unsigned long long temp64 = 0; - int num_patterns = sizeof (pattern) / sizeof (pattern[0]); - int i; - unsigned int hi, lo; - - for (i = 0; i < num_patterns; i++) { - move64 (&(pattern[i]), pmem); - move64 (pmem, &temp64); - - /* hi = (temp64>>32) & 0xffffffff; */ - /* lo = temp64 & 0xffffffff; */ - /* printf("\ntemp64 = 0x%08x%08x", hi, lo); */ - - hi = (pattern[i] >> 32) & 0xffffffff; - lo = pattern[i] & 0xffffffff; - /* printf("\npattern[%d] = 0x%08x%08x", i, hi, lo); */ - - if (temp64 != pattern[i]) { - printf ("\n Data Test Failed, pattern 0x%08x%08x", - hi, lo); - return 1; - } - } - - return 0; -} -#endif /* CONFIG_SYS_DRAM_TEST_DATA */ - -#if defined (CONFIG_SYS_DRAM_TEST_ADDRESS) -/*********************************************************************/ -/* NAME: mem_test_address() - test address lines */ -/* */ -/* DESCRIPTION: */ -/* This function performs a test to verify that each word im */ -/* memory is uniquly addressable. The test sequence is as follows: */ -/* */ -/* 1) write the address of each word to each word. */ -/* 2) verify that each location equals its address */ -/* */ -/* OUTPUTS: */ -/* Displays failing test pattern and address */ -/* */ -/* RETURNS: */ -/* 0 - Passed test */ -/* 1 - Failed test */ -/* */ -/* RESTRICTIONS/LIMITATIONS: */ -/* */ -/* */ -/*********************************************************************/ -int mem_test_address (void) -{ - volatile unsigned int *pmem = - (volatile unsigned int *) CONFIG_SYS_SDRAM_BASE; - const unsigned int size = (CONFIG_SYS_SDRAM_SIZE * 1024 * 1024) / 4; - unsigned int i; - - /* write address to each location */ - for (i = 0; i < size; i++) { - pmem[i] = i; - } - - /* verify each loaction */ - for (i = 0; i < size; i++) { - if (pmem[i] != i) { - printf ("\n Address Test Failed at 0x%x", i); - return 1; - } - } - return 0; -} -#endif /* CONFIG_SYS_DRAM_TEST_ADDRESS */ - -#if defined (CONFIG_SYS_DRAM_TEST_WALK) -/*********************************************************************/ -/* NAME: mem_march() - memory march */ -/* */ -/* DESCRIPTION: */ -/* Marches up through memory. At each location verifies rmask if */ -/* read = 1. At each location write wmask if write = 1. Displays */ -/* failing address and pattern. */ -/* */ -/* INPUTS: */ -/* volatile unsigned long long * base - start address of test */ -/* unsigned int size - number of dwords(64-bit) to test */ -/* unsigned long long rmask - read verify mask */ -/* unsigned long long wmask - wrtie verify mask */ -/* short read - verifies rmask if read = 1 */ -/* short write - writes wmask if write = 1 */ -/* */ -/* OUTPUTS: */ -/* Displays failing test pattern and address */ -/* */ -/* RETURNS: */ -/* 0 - Passed test */ -/* 1 - Failed test */ -/* */ -/* RESTRICTIONS/LIMITATIONS: */ -/* */ -/* */ -/*********************************************************************/ -int mem_march (volatile unsigned long long *base, - unsigned int size, - unsigned long long rmask, - unsigned long long wmask, short read, short write) -{ - unsigned int i; - unsigned long long temp = 0; - unsigned int hitemp, lotemp, himask, lomask; - - for (i = 0; i < size; i++) { - if (read != 0) { - /* temp = base[i]; */ - move64 ((unsigned long long *) &(base[i]), &temp); - if (rmask != temp) { - hitemp = (temp >> 32) & 0xffffffff; - lotemp = temp & 0xffffffff; - himask = (rmask >> 32) & 0xffffffff; - lomask = rmask & 0xffffffff; - - printf ("\n Walking one's test failed: address = 0x%08x," "\n\texpected 0x%08x%08x, found 0x%08x%08x", i << 3, himask, lomask, hitemp, lotemp); - return 1; - } - } - if (write != 0) { - /* base[i] = wmask; */ - move64 (&wmask, (unsigned long long *) &(base[i])); - } - } - return 0; -} -#endif /* CONFIG_SYS_DRAM_TEST_WALK */ - -/*********************************************************************/ -/* NAME: mem_test_walk() - a simple walking ones test */ -/* */ -/* DESCRIPTION: */ -/* Performs a walking ones through entire physical memory. The */ -/* test uses as series of memory marches, mem_march(), to verify */ -/* and write the test patterns to memory. The test sequence is as */ -/* follows: */ -/* 1) march writing 0000...0001 */ -/* 2) march verifying 0000...0001 , writing 0000...0010 */ -/* 3) repeat step 2 shifting masks left 1 bit each time unitl */ -/* the write mask equals 1000...0000 */ -/* 4) march verifying 1000...0000 */ -/* The test fails if any of the memory marches return a failure. */ -/* */ -/* OUTPUTS: */ -/* Displays which pass on the memory test is executing */ -/* */ -/* RETURNS: */ -/* 0 - Passed test */ -/* 1 - Failed test */ -/* */ -/* RESTRICTIONS/LIMITATIONS: */ -/* */ -/* */ -/*********************************************************************/ -int mem_test_walk (void) -{ - unsigned long long mask; - volatile unsigned long long *pmem = - (volatile unsigned long long *) CONFIG_SYS_SDRAM_BASE; - const unsigned long size = (CONFIG_SYS_SDRAM_SIZE * 1024 * 1024) / 8; - - unsigned int i; - - mask = 0x01; - - printf ("Initial Pass"); - mem_march (pmem, size, 0x0, 0x1, 0, 1); - - printf ("\b\b\b\b\b\b\b\b\b\b\b\b"); - printf (" "); - printf ("\b\b\b\b\b\b\b\b\b\b\b\b"); - - for (i = 0; i < 63; i++) { - printf ("Pass %2d", i + 2); - if (mem_march (pmem, size, mask, mask << 1, 1, 1) != 0) { - /*printf("mask: 0x%x, pass: %d, ", mask, i); */ - return 1; - } - mask = mask << 1; - printf ("\b\b\b\b\b\b\b"); - } - - printf ("Last Pass"); - if (mem_march (pmem, size, 0, mask, 0, 1) != 0) { - /* printf("mask: 0x%x", mask); */ - return 1; - } - printf ("\b\b\b\b\b\b\b\b\b"); - printf (" "); - printf ("\b\b\b\b\b\b\b\b\b"); - - return 0; -} - -/*********************************************************************/ -/* NAME: testdram() - calls any enabled memory tests */ -/* */ -/* DESCRIPTION: */ -/* Runs memory tests if the environment test variables are set to */ -/* 'y'. */ -/* */ -/* INPUTS: */ -/* testdramdata - If set to 'y', data test is run. */ -/* testdramaddress - If set to 'y', address test is run. */ -/* testdramwalk - If set to 'y', walking ones test is run */ -/* */ -/* OUTPUTS: */ -/* None */ -/* */ -/* RETURNS: */ -/* 0 - Passed test */ -/* 1 - Failed test */ -/* */ -/* RESTRICTIONS/LIMITATIONS: */ -/* */ -/* */ -/*********************************************************************/ -int testdram (void) -{ - int rundata, runaddress, runwalk; - - rundata = getenv_yesno("testdramdata") == 1; - runaddress = getenv_yesno("testdramaddress") == 1; - runwalk = getenv_yesno("testdramwalk") == 1; - - if ((rundata == 1) || (runaddress == 1) || (runwalk == 1)) { - printf ("Testing RAM ... "); - } -#ifdef CONFIG_SYS_DRAM_TEST_DATA - if (rundata == 1) { - if (mem_test_data () == 1) { - return 1; - } - } -#endif -#ifdef CONFIG_SYS_DRAM_TEST_ADDRESS - if (runaddress == 1) { - if (mem_test_address () == 1) { - return 1; - } - } -#endif -#ifdef CONFIG_SYS_DRAM_TEST_WALK - if (runwalk == 1) { - if (mem_test_walk () == 1) { - return 1; - } - } -#endif - if ((rundata == 1) || (runaddress == 1) || (runwalk == 1)) { - printf ("passed"); - } - return 0; - -} -#endif /* CONFIG_SYS_DRAM_TEST */ - -/*********************************************************************/ -/* NAME: initdram() - initializes SDRAM controller */ -/* */ -/* DESCRIPTION: */ -/* Initializes the MPC8260's SDRAM controller. */ -/* */ -/* INPUTS: */ -/* CONFIG_SYS_IMMR - MPC8260 Internal memory map */ -/* CONFIG_SYS_SDRAM_BASE - Physical start address of SDRAM */ -/* CONFIG_SYS_PSDMR - SDRAM mode register */ -/* CONFIG_SYS_MPTPR - Memory refresh timer prescaler register */ -/* CONFIG_SYS_SDRAM0_SIZE - SDRAM size */ -/* */ -/* RETURNS: */ -/* SDRAM size in bytes */ -/* */ -/* RESTRICTIONS/LIMITATIONS: */ -/* */ -/* */ -/*********************************************************************/ -phys_size_t initdram (int board_type) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8260_t *memctl = &immap->im_memctl; - volatile uchar c = 0, *ramaddr = (uchar *) (CONFIG_SYS_SDRAM_BASE + 0x8); - ulong psdmr = CONFIG_SYS_PSDMR; - int i; - - /* - * Quote from 8260 UM (10.4.2 SDRAM Power-On Initialization, 10-35): - * - * "At system reset, initialization software must set up the - * programmable parameters in the memory controller banks registers - * (ORx, BRx, P/LSDMR). After all memory parameters are configured, - * system software should execute the following initialization sequence - * for each SDRAM device. - * - * 1. Issue a PRECHARGE-ALL-BANKS command - * 2. Issue eight CBR REFRESH commands - * 3. Issue a MODE-SET command to initialize the mode register - * - * The initial commands are executed by setting P/LSDMR[OP] and - * accessing the SDRAM with a single-byte transaction." - * - * The appropriate BRx/ORx registers have already been set when we - * get here. The SDRAM can be accessed at the address CONFIG_SYS_SDRAM_BASE. - */ - - memctl->memc_psrt = CONFIG_SYS_PSRT; - memctl->memc_mptpr = CONFIG_SYS_MPTPR; - - memctl->memc_psdmr = psdmr | PSDMR_OP_PREA; - *ramaddr = c; - - memctl->memc_psdmr = psdmr | PSDMR_OP_CBRR; - for (i = 0; i < 8; i++) { - *ramaddr = c; - } - memctl->memc_psdmr = psdmr | PSDMR_OP_MRW; - *ramaddr = c; - - memctl->memc_psdmr = psdmr | PSDMR_OP_NORM | PSDMR_RFEN; - *ramaddr = c; - - /* return total ram size */ - return (CONFIG_SYS_SDRAM0_SIZE * 1024 * 1024); -} - -/*********************************************************************/ -/* End of gw8260.c */ -/*********************************************************************/ diff --git a/configs/gw8260_defconfig b/configs/gw8260_defconfig deleted file mode 100644 index a59ec3a..0000000 --- a/configs/gw8260_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_GW8260=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index af4b00c..0c47ebd 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,7 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +gw8260 powerpc mpc8260 - - Oliver Brown obrown@adventnetworks.com IPHASE4539 powerpc mpc8260 - - Wolfgang Grandegger wg@denx.de muas3001 powerpc mpc8260 - - Heiko Schocher hs@denx.de PM825 powerpc mpc8260 - - Wolfgang Denk wd@denx.de diff --git a/include/configs/gw8260.h b/include/configs/gw8260.h deleted file mode 100644 index 262c9e9..0000000 --- a/include/configs/gw8260.h +++ /dev/null @@ -1,800 +0,0 @@ -/* - * (C) Copyright 2000 - * Murray Jensen Murray.Jensen@cmst.csiro.au - * - * (C) Copyright 2000 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * - * (C) Copyright 2001 - * Advent Networks, Inc. http://www.adventnetworks.com - * Jay Monkman jmonkman@adventnetworks.com - * - * (C) Copyright 2001 - * Advent Networks, Inc. http://www.adventnetworks.com - * Oliver Brown obrown@adventnetworks.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/*********************************************************************/ -/* DESCRIPTION: - * This file contains the board configuartion for the GW8260 board. - * - * MODULE DEPENDENCY: - * None - * - * RESTRICTIONS/LIMITATIONS: - * None - * - * Copyright (c) 2001, Advent Networks, Inc. - */ -/*********************************************************************/ - -#ifndef __CONFIG_H -#define __CONFIG_H - -#define CONFIG_SYS_TEXT_BASE 0x40000000 - -/* Enable debug prints */ -#undef DEBUG_BOOTP_EXT /* Debug received vendor fields */ - -/* What is the oscillator's (UX2) frequency in Hz? */ -#define CONFIG_8260_CLKIN (66 * 1000 * 1000) - -/*----------------------------------------------------------------------- - * MODCK_H & MODCLK[1-3] - Ref: Section 9.2 in MPC8206 User Manual - *----------------------------------------------------------------------- - * What should MODCK_H be? It is dependent on the oscillator - * frequency, MODCK[1-3], and desired CPM and core frequencies. - * Here are some example values (all frequencies are in MHz): - * - * MODCK_H MODCK[1-3] Osc CPM Core S2-6 S2-7 S2-8 - * ------- ---------- --- --- ---- ----- ----- ----- - * 0x5 0x5 66 133 133 Open Close Open - * 0x5 0x6 66 133 166 Open Open Close - * 0x5 0x7 66 133 200 Open Open Open - * 0x6 0x0 66 133 233 Close Close Close - * 0x6 0x1 66 133 266 Close Close Open - * 0x6 0x2 66 133 300 Close Open Close - */ -#define CONFIG_SYS_SBC_MODCK_H 0x05 - -/* Define this if you want to boot from 0x00000100. If you don't define - * this, you will need to program the bootloader to 0xfff00000, and - * get the hardware reset config words at 0xfe000000. The simplest - * way to do that is to program the bootloader at both addresses. - * It is suggested that you just let U-Boot live at 0x00000000. - */ -#define CONFIG_SYS_SBC_BOOT_LOW 1 - -/* What should the base address of the main FLASH be and how big is - * it (in MBytes)? This must contain CONFIG_SYS_TEXT_BASE. - * The main FLASH is whichever is connected to *CS0. U-Boot expects - * this to be the SIMM. - */ -#define CONFIG_SYS_FLASH0_BASE 0x40000000 -#define CONFIG_SYS_FLASH0_SIZE 8 - -/* Define CONFIG_SYS_FLASH_CHECKSUM to enable flash checksum during boot. - * Note: the 'flashchecksum' environment variable must also be set to 'y'. - */ -#define CONFIG_SYS_FLASH_CHECKSUM - -/* What should be the base address of SDRAM DIMM and how big is - * it (in Mbytes)? - */ -#define CONFIG_SYS_SDRAM0_BASE 0x00000000 -#define CONFIG_SYS_SDRAM0_SIZE 64 - -/* - * DRAM tests - * CONFIG_SYS_DRAM_TEST - enables the following tests. - * - * CONFIG_SYS_DRAM_TEST_DATA - Enables test for shorted or open data lines - * Environment variable 'test_dram_data' must be - * set to 'y'. - * CONFIG_SYS_DRAM_TEST_DATA - Enables test to verify that each word is uniquely - * addressable. Environment variable - * 'test_dram_address' must be set to 'y'. - * CONFIG_SYS_DRAM_TEST_WALK - Enables test a 64-bit walking ones pattern test. - * This test takes about 6 minutes to test 64 MB. - * Environment variable 'test_dram_walk' must be - * set to 'y'. - */ -#define CONFIG_SYS_DRAM_TEST -#if defined(CONFIG_SYS_DRAM_TEST) -#define CONFIG_SYS_DRAM_TEST_DATA -#define CONFIG_SYS_DRAM_TEST_ADDRESS -#define CONFIG_SYS_DRAM_TEST_WALK -#endif /* CONFIG_SYS_DRAM_TEST */ - -/* - * GW8260 with 16 MB DIMM: - * - * 0x0000 0000 Exception Vector code, 8k - * : - * 0x0000 1FFF - * 0x0000 2000 Free for Application Use - * : - * : - * - * : - * : - * 0x00F5 FF30 Monitor Stack (Growing downward) - * Monitor Stack Buffer (0x80) - * 0x00F5 FFB0 Board Info Data - * 0x00F6 0000 Malloc Arena - * : CONFIG_ENV_SECT_SIZE, 256k - * : CONFIG_SYS_MALLOC_LEN, 128k - * 0x00FC 0000 RAM Copy of Monitor Code - * : CONFIG_SYS_MONITOR_LEN, 256k - * 0x00FF FFFF [End of RAM], CONFIG_SYS_SDRAM_SIZE - 1 - */ - -/* - * GW8260 with 64 MB DIMM: - * - * 0x0000 0000 Exception Vector code, 8k - * : - * 0x0000 1FFF - * 0x0000 2000 Free for Application Use - * : - * : - * - * : - * : - * 0x03F5 FF30 Monitor Stack (Growing downward) - * Monitor Stack Buffer (0x80) - * 0x03F5 FFB0 Board Info Data - * 0x03F6 0000 Malloc Arena - * : CONFIG_ENV_SECT_SIZE, 256k - * : CONFIG_SYS_MALLOC_LEN, 128k - * 0x03FC 0000 RAM Copy of Monitor Code - * : CONFIG_SYS_MONITOR_LEN, 256k - * 0x03FF FFFF [End of RAM], CONFIG_SYS_SDRAM_SIZE - 1 - */ - - -/* - * select serial console configuration - * - * if either CONFIG_CONS_ON_SMC or CONFIG_CONS_ON_SCC is selected, then - * CONFIG_CONS_INDEX must be set to the channel number (1-2 for SMC, 1-4 - * for SCC). - * - * if CONFIG_CONS_NONE is defined, then the serial console routines must - * defined elsewhere. - */ -#define CONFIG_CONS_ON_SMC 1 /* define if console on SMC */ -#undef CONFIG_CONS_ON_SCC /* define if console on SCC */ -#undef CONFIG_CONS_NONE /* define if console on neither */ -#define CONFIG_CONS_INDEX 1 /* which SMC/SCC channel for console */ - -/* - * select ethernet configuration - * - * if either CONFIG_ETHER_ON_SCC or CONFIG_ETHER_ON_FCC is selected, then - * CONFIG_ETHER_INDEX must be set to the channel number (1-4 for SCC, 1-3 - * for FCC) - * - * if CONFIG_ETHER_NONE is defined, then either the ethernet routines must be - * defined elsewhere (as for the console), or CONFIG_CMD_NET must be unset. - */ - -#undef CONFIG_ETHER_ON_SCC -#define CONFIG_ETHER_ON_FCC -#undef CONFIG_ETHER_NONE /* define if ethernet on neither */ - -#ifdef CONFIG_ETHER_ON_SCC -#define CONFIG_ETHER_INDEX 1 /* which SCC/FCC channel for ethernet */ -#endif /* CONFIG_ETHER_ON_SCC */ - -#ifdef CONFIG_ETHER_ON_FCC -#define CONFIG_ETHER_INDEX 2 /* which SCC/FCC channel for ethernet */ -#define CONFIG_MII /* MII PHY management */ -#define CONFIG_BITBANGMII /* bit-bang MII PHY management */ -/* - * Port pins used for bit-banged MII communictions (if applicable). - */ -#define MDIO_PORT 2 /* Port C */ - -#define MDIO_DECLARE volatile ioport_t *iop = ioport_addr ( \ - (immap_t *) CONFIG_SYS_IMMR, MDIO_PORT ) -#define MDC_DECLARE MDIO_DECLARE - -#define MDIO_ACTIVE (iop->pdir |= 0x00400000) -#define MDIO_TRISTATE (iop->pdir &= ~0x00400000) -#define MDIO_READ ((iop->pdat & 0x00400000) != 0) - -#define MDIO(bit) if(bit) iop->pdat |= 0x00400000; \ - else iop->pdat &= ~0x00400000 - -#define MDC(bit) if(bit) iop->pdat |= 0x00200000; \ - else iop->pdat &= ~0x00200000 - -#define MIIDELAY udelay(1) -#endif /* CONFIG_ETHER_ON_FCC */ - -#if defined(CONFIG_ETHER_ON_FCC) && (CONFIG_ETHER_INDEX == 2) - -/* - * - Rx-CLK is CLK13 - * - Tx-CLK is CLK14 - * - Select bus for bd/buffers (see 28-13) - * - Enable Full Duplex in FSMR - */ -# define CONFIG_SYS_CMXFCR_MASK2 (CMXFCR_FC2|CMXFCR_RF2CS_MSK|CMXFCR_TF2CS_MSK) -# define CONFIG_SYS_CMXFCR_VALUE2 (CMXFCR_RF2CS_CLK13|CMXFCR_TF2CS_CLK14) -# define CONFIG_SYS_CPMFCR_RAMTYPE 0 -# define CONFIG_SYS_FCC_PSMR (FCC_PSMR_FDE | FCC_PSMR_LPB) - -#elif defined(CONFIG_ETHER_ON_FCC) && (CONFIG_ETHER_INDEX == 3) - -/* - * - Rx-CLK is CLK15 - * - Tx-CLK is CLK16 - * - Select bus for bd/buffers (see 28-13) - * - Enable Full Duplex in FSMR - */ -# define CONFIG_SYS_CMXFCR_MASK3 (CMXFCR_FC3|CMXFCR_RF3CS_MSK|CMXFCR_TF3CS_MSK) -# define CONFIG_SYS_CMXFCR_VALUE3 (CMXFCR_RF3CS_CLK15|CMXFCR_TF3CS_CLK16) -# define CONFIG_SYS_CPMFCR_RAMTYPE 0 -# define CONFIG_SYS_FCC_PSMR (FCC_PSMR_FDE | FCC_PSMR_LPB) - -#endif /* CONFIG_ETHER_ON_FCC, CONFIG_ETHER_INDEX */ - -/* Define this to reserve an entire FLASH sector (256 KB) for - * environment variables. Otherwise, the environment will be - * put in the same sector as U-Boot, and changing variables - * will erase U-Boot temporarily - */ -#define CONFIG_ENV_IN_OWN_SECT - -/* Define to allow the user to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE - -/* What should the console's baud rate be? */ -#define CONFIG_BAUDRATE 115200 - -/* Ethernet MAC address - This is set to all zeros to force an - * an error if we use BOOTP without setting - * the MAC address - */ -#define CONFIG_ETHADDR 00:00:00:00:00:00 - -/* Set to a positive value to delay for running BOOTCOMMAND */ -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ - -/* Be selective on what keys can delay or stop the autoboot process - * To stop use: " " - */ -#define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_PROMPT \ - "Autobooting in %d seconds, press " " to stop\n", bootdelay -#define CONFIG_AUTOBOOT_STOP_STR " " -#undef CONFIG_AUTOBOOT_DELAY_STR -#define DEBUG_BOOTKEYS 0 - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH - -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_DNS - -/* undef this to save memory */ -#define CONFIG_SYS_LONGHELP - -/* Monitor Command Prompt */ - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_BEDBUG -#define CONFIG_CMD_ELF -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_REGINFO -#define CONFIG_CMD_IMMAP -#define CONFIG_CMD_MII - -#undef CONFIG_CMD_KGDB - - -/* Where do the internal registers live? */ -#define CONFIG_SYS_IMMR 0xf0000000 - -/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER -#ifdef CONFIG_SYS_HUSH_PARSER -#endif - -/* What is the address of IO controller */ -#define CONFIG_SYS_IO_BASE 0xe0000000 - -/***************************************************************************** - * - * You should not have to modify any of the following settings - * - *****************************************************************************/ - -#define CONFIG_GW8260 1 /* on an GW8260 Board */ -#define CONFIG_CPM2 1 /* Has a CPM2 */ - -/* - * Miscellaneous configurable options - */ -#if defined(CONFIG_CMD_KGDB) -# define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -# define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif - -/* Print Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT)+16) - -#define CONFIG_SYS_MAXARGS 8 /* max number of command args */ - -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -/* Convert clocks to MHZ when passing board info to kernel. - * This must be defined for eariler 2.4 kernels (~2.4.4). - */ -#define CONFIG_CLOCKS_IN_MHZ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - - -/* memtest works from the end of the exception vector table - * to the end of the DRAM less monitor and malloc area - */ -#define CONFIG_SYS_MEMTEST_START 0x2000 - -#define CONFIG_SYS_STACK_USAGE 0x10000 /* Reserve 64k for the stack usage */ - -#define CONFIG_SYS_MEM_END_USAGE ( CONFIG_SYS_MONITOR_LEN \ - + CONFIG_SYS_MALLOC_LEN \ - + CONFIG_ENV_SECT_SIZE \ - + CONFIG_SYS_STACK_USAGE ) - -#define CONFIG_SYS_MEMTEST_END ( CONFIG_SYS_SDRAM_SIZE * 1024 * 1024 \ - - CONFIG_SYS_MEM_END_USAGE ) - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ - -#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_FLASH0_BASE -#define CONFIG_SYS_FLASH_SIZE CONFIG_SYS_FLASH0_SIZE -#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_SDRAM0_BASE -#define CONFIG_SYS_SDRAM_SIZE CONFIG_SYS_SDRAM0_SIZE - -/*----------------------------------------------------------------------- - * Hard Reset Configuration Words - */ -#if defined(CONFIG_SYS_SBC_BOOT_LOW) -# define CONFIG_SYS_SBC_HRCW_BOOT_FLAGS (HRCW_CIP | HRCW_BMS) -#else -# define CONFIG_SYS_SBC_HRCW_BOOT_FLAGS (0) -#endif /* defined(CONFIG_SYS_SBC_BOOT_LOW) */ - -/* get the HRCW ISB field from CONFIG_SYS_IMMR */ -#define CONFIG_SYS_SBC_HRCW_IMMR ( ((CONFIG_SYS_IMMR & 0x10000000) >> 10) | \ - ((CONFIG_SYS_IMMR & 0x01000000) >> 7) | \ - ((CONFIG_SYS_IMMR & 0x00100000) >> 4) ) - -#define CONFIG_SYS_HRCW_MASTER ( HRCW_BPS11 | \ - HRCW_DPPC11 | \ - CONFIG_SYS_SBC_HRCW_IMMR | \ - HRCW_MMR00 | \ - HRCW_LBPC11 | \ - HRCW_APPC10 | \ - HRCW_CS10PC00 | \ - (CONFIG_SYS_SBC_MODCK_H & HRCW_MODCK_H1111) | \ - CONFIG_SYS_SBC_HRCW_BOOT_FLAGS ) - -/* no slaves */ -#define CONFIG_SYS_HRCW_SLAVE1 0 -#define CONFIG_SYS_HRCW_SLAVE2 0 -#define CONFIG_SYS_HRCW_SLAVE3 0 -#define CONFIG_SYS_HRCW_SLAVE4 0 -#define CONFIG_SYS_HRCW_SLAVE5 0 -#define CONFIG_SYS_HRCW_SLAVE6 0 -#define CONFIG_SYS_HRCW_SLAVE7 0 - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - * Note also that the logic that sets CONFIG_SYS_RAMBOOT is platform dependent. - */ -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH0_BASE - -#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (128 * 1024) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * FLASH and environment organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 32 /* max number of sectors on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 8000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 1 /* Timeout for Flash Write (in ms) */ - -#define CONFIG_ENV_IS_IN_FLASH 1 - -#ifdef CONFIG_ENV_IN_OWN_SECT -# define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + (256 * 1024)) -# define CONFIG_ENV_SECT_SIZE (256 * 1024) -#else -# define CONFIG_ENV_SIZE (16 * 1024)/* Size of Environment Sector */ -# define CONFIG_ENV_ADD ((CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) - CONFIG_ENV_SIZE) -# define CONFIG_ENV_SECT_SIZE (256 * 1024)/* see README - env sect real size */ -#endif /* CONFIG_ENV_IN_OWN_SECT */ - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC8260 CPU */ - -#if defined(CONFIG_CMD_KGDB) -# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * HIDx - Hardware Implementation-dependent Registers 2-11 - *----------------------------------------------------------------------- - * HID0 also contains cache control - initially enable both caches and - * invalidate contents, then the final state leaves only the instruction - * cache enabled. Note that Power-On and Hard reset invalidate the caches, - * but Soft reset does not. - * - * HID1 has only read-only information - nothing to set. - */ -#define CONFIG_SYS_HID0_INIT (HID0_ICE |\ - HID0_DCE |\ - HID0_ICFI |\ - HID0_DCI |\ - HID0_IFEM |\ - HID0_ABE) - -#define CONFIG_SYS_HID0_FINAL (HID0_ICE |\ - HID0_IFEM |\ - HID0_ABE |\ - HID0_EMCP) -#define CONFIG_SYS_HID2 0 - -/*----------------------------------------------------------------------- - * RMR - Reset Mode Register - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RMR 0 - -/*----------------------------------------------------------------------- - * BCR - Bus Configuration 4-25 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_BCR (BCR_ETM) - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 4-31 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_SIUMCR (SIUMCR_DPPC11 |\ - SIUMCR_L2CPC00 |\ - SIUMCR_APPC10 |\ - SIUMCR_MMR00) - - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 11-9 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Watchdog & Bus Monitor Timer max, 60x Bus Monitor enable - */ -#define CONFIG_SYS_SYPCR (SYPCR_SWTC |\ - SYPCR_BMT |\ - SYPCR_PBME |\ - SYPCR_LBME |\ - SYPCR_SWRI |\ - SYPCR_SWP) - -/*----------------------------------------------------------------------- - * TMCNTSC - Time Counter Status and Control 4-40 - *----------------------------------------------------------------------- - * Clear once per Second and Alarm Interrupt Status, Set 32KHz timersclk, - * and enable Time Counter - */ -#define CONFIG_SYS_TMCNTSC (TMCNTSC_SEC |\ - TMCNTSC_ALR |\ - TMCNTSC_TCF |\ - TMCNTSC_TCE) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 4-42 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Set 32KHz timersclk, and enable - * Periodic timer - */ -#define CONFIG_SYS_PISCR (PISCR_PS |\ - PISCR_PTF |\ - PISCR_PTE) - -/*----------------------------------------------------------------------- - * SCCR - System Clock Control 9-8 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_SCCR 0 - -/*----------------------------------------------------------------------- - * RCCR - RISC Controller Configuration 13-7 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RCCR 0 - -/* - * Initialize Memory Controller: - * - * Bank Bus Machine PortSz Device - * ---- --- ------- ------ ------ - * 0 60x GPCM 32 bit FLASH (SIMM - 4MB) - * 1 60x GPCM 32 bit unused - * 2 60x SDRAM 64 bit SDRAM (DIMM - 16MB or 64MB) - * 3 60x SDRAM 64 bit unused - * 4 Local GPCM 8 bit IO (on board - 64k) - * 5 60x GPCM 8 bit unused - * 6 60x GPCM 8 bit unused - * 7 60x GPCM 8 bit unused - * - */ - -/*----------------------------------------------------------------------- - * BR0 - Base Register - * Ref: Section 10.3.1 on page 10-14 - * OR0 - Option Register - * Ref: Section 10.3.2 on page 10-18 - *----------------------------------------------------------------------- - */ - -/* Bank 0,1 - FLASH SIMM - * - * This expects the FLASH SIMM to be connected to *CS0 - * It consists of 4 AM29F016D parts. - * - * Note: For the 8 MB SIMM, *CS1 is unused. - */ - -/* BR0 is configured as follows: - * - * - Base address of 0x40000000 - * - 32 bit port size - * - Data errors checking is disabled - * - Read and write access - * - GPCM 60x bus - * - Access are handled by the memory controller according to MSEL - * - Not used for atomic operations - * - No data pipelining is done - * - Valid - */ -#define CONFIG_SYS_BR0_PRELIM ((CONFIG_SYS_FLASH0_BASE & BRx_BA_MSK) |\ - BRx_PS_32 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -/* OR0 is configured as follows: - * - * - 8 MB - * - *BCTL0 is asserted upon access to the current memory bank - * - *CW / *WE are negated a quarter of a clock earlier - * - *CS is output at the same time as the address lines - * - Uses a clock cycle length of 5 - * - *PSDVAL is generated internally by the memory controller - * unless *GTA is asserted earlier externally. - * - Relaxed timing is generated by the GPCM for accesses - * initiated to this memory region. - * - One idle clock is inserted between a read access from the - * current bank and the next access. - */ -#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH0_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_5_CLK |\ - ORxG_TRLX |\ - ORxG_EHTR) - -/*----------------------------------------------------------------------- - * BR2 - Base Register - * Ref: Section 10.3.1 on page 10-14 - * OR2 - Option Register - * Ref: Section 10.3.2 on page 10-16 - *----------------------------------------------------------------------- - */ - -/* Bank 2 - SDRAM DIMM - * - * 16MB DIMM: P/N - * 64MB DIMM: P/N 1W-8864X8-4-P1-EST or - * MT4LSDT864AG-10EB1 (Micron) - * - * Note: *CS3 is unused for this DIMM - */ - -/* With a 16 MB or 64 MB DIMM, the BR2 is configured as follows: - * - * - Base address of 0x00000000 - * - 64 bit port size (60x bus only) - * - Data errors checking is disabled - * - Read and write access - * - SDRAM 60x bus - * - Access are handled by the memory controller according to MSEL - * - Not used for atomic operations - * - No data pipelining is done - * - Valid - */ -#define CONFIG_SYS_BR2_PRELIM ((CONFIG_SYS_SDRAM0_BASE & BRx_BA_MSK) |\ - BRx_PS_64 |\ - BRx_MS_SDRAM_P |\ - BRx_V) - -/* With a 16 MB DIMM, the OR2 is configured as follows: - * - * - 16 MB - * - 2 internal banks per device - * - Row start address bit is A9 with PSDMR[PBI] = 0 - * - 11 row address lines - * - Back-to-back page mode - * - Internal bank interleaving within save device enabled - */ -#if (CONFIG_SYS_SDRAM0_SIZE == 16) -#define CONFIG_SYS_OR2_PRELIM (MEG_TO_AM(CONFIG_SYS_SDRAM0_SIZE) |\ - ORxS_BPD_2 |\ - ORxS_ROWST_PBI0_A9 |\ - ORxS_NUMR_11) - -/* With a 16 MB DIMM, the PSDMR is configured as follows: - * - * - Page Based Interleaving, - * - Refresh Enable, - * - Address Multiplexing where A5 is output on A14 pin - * (A6 on A15, and so on), - * - use address pins A16-A18 as bank select, - * - A9 is output on SDA10 during an ACTIVATE command, - * - earliest timing for ACTIVATE command after REFRESH command is 7 clocks, - * - earliest timing for ACTIVATE or REFRESH command after PRECHARGE command - * is 3 clocks, - * - earliest timing for READ/WRITE command after ACTIVATE command is - * 2 clocks, - * - earliest timing for PRECHARGE after last data was read is 1 clock, - * - earliest timing for PRECHARGE after last data was written is 1 clock, - * - CAS Latency is 2. - */ - -/*----------------------------------------------------------------------- - * PSDMR - 60x Bus SDRAM Mode Register - * Ref: Section 10.3.3 on page 10-21 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_PSDMR (PSDMR_RFEN |\ - PSDMR_SDAM_A14_IS_A5 |\ - PSDMR_BSMA_A16_A18 |\ - PSDMR_SDA10_PBI0_A9 |\ - PSDMR_RFRC_7_CLK |\ - PSDMR_PRETOACT_3W |\ - PSDMR_ACTTORW_2W |\ - PSDMR_LDOTOPRE_1C |\ - PSDMR_WRC_1C |\ - PSDMR_CL_2) -#endif /* (CONFIG_SYS_SDRAM0_SIZE == 16) */ - -/* With a 64 MB DIMM, the OR2 is configured as follows: - * - * - 64 MB - * - 4 internal banks per device - * - Row start address bit is A8 with PSDMR[PBI] = 0 - * - 12 row address lines - * - Back-to-back page mode - * - Internal bank interleaving within save device enabled - */ -#if (CONFIG_SYS_SDRAM0_SIZE == 64) -#define CONFIG_SYS_OR2_PRELIM (MEG_TO_AM(CONFIG_SYS_SDRAM0_SIZE) |\ - ORxS_BPD_4 |\ - ORxS_ROWST_PBI0_A8 |\ - ORxS_NUMR_12) - -/* With a 64 MB DIMM, the PSDMR is configured as follows: - * - * - Page Based Interleaving, - * - Refresh Enable, - * - Address Multiplexing where A5 is output on A14 pin - * (A6 on A15, and so on), - * - use address pins A14-A16 as bank select, - * - A9 is output on SDA10 during an ACTIVATE command, - * - earliest timing for ACTIVATE command after REFRESH command is 7 clocks, - * - earliest timing for ACTIVATE or REFRESH command after PRECHARGE command - * is 3 clocks, - * - earliest timing for READ/WRITE command after ACTIVATE command is - * 2 clocks, - * - earliest timing for PRECHARGE after last data was read is 1 clock, - * - earliest timing for PRECHARGE after last data was written is 1 clock, - * - CAS Latency is 2. - */ - -/*----------------------------------------------------------------------- - * PSDMR - 60x Bus SDRAM Mode Register - * Ref: Section 10.3.3 on page 10-21 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_PSDMR (PSDMR_RFEN |\ - PSDMR_SDAM_A14_IS_A5 |\ - PSDMR_BSMA_A14_A16 |\ - PSDMR_SDA10_PBI0_A9 |\ - PSDMR_RFRC_7_CLK |\ - PSDMR_PRETOACT_3W |\ - PSDMR_ACTTORW_2W |\ - PSDMR_LDOTOPRE_1C |\ - PSDMR_WRC_1C |\ - PSDMR_CL_2) -#endif /* (CONFIG_SYS_SDRAM0_SIZE == 64) */ - -#define CONFIG_SYS_PSRT 0x0e -#define CONFIG_SYS_MPTPR MPTPR_PTP_DIV32 - - -/*----------------------------------------------------------------------- - * BR4 - Base Register - * Ref: Section 10.3.1 on page 10-14 - * OR4 - Option Register - * Ref: Section 10.3.2 on page 10-18 - *----------------------------------------------------------------------- - */ -/* Bank 4 - Onboard Memory Mapped IO controller - * - * This expects the onboard IO controller to connected to *CS4 and - * the local bus. - * - Base address of 0xe0000000 - * - 8 bit port size (local bus only) - * - Read and write access - * - GPCM local bus - * - Not used for atomic operations - * - No data pipelining is done - * - Valid - * - extended hold time - * - 11 wait states - */ - -#ifdef CONFIG_SYS_IO_BASE -# define CONFIG_SYS_BR4_PRELIM ((CONFIG_SYS_IO_BASE & BRx_BA_MSK) |\ - BRx_PS_8 |\ - BRx_MS_GPCM_L |\ - BRx_V) - -# define CONFIG_SYS_OR4_PRELIM (ORxG_AM_MSK |\ - ORxG_SCY_11_CLK |\ - ORxG_EHTR) -#endif /* CONFIG_SYS_IO_BASE */ -#endif /* __CONFIG_H */
On Mon, Dec 15, 2014 at 11:26:27PM +0900, Masahiro Yamada wrote:
This board is still a non-generic board.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Oliver Brown obrown@adventnetworks.com
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
arch/powerpc/cpu/mpc8260/Kconfig | 4 - board/ep82xxm/Kconfig | 9 - board/ep82xxm/MAINTAINERS | 6 - board/ep82xxm/Makefile | 8 - board/ep82xxm/ep82xxm.c | 274 ---------------------------- configs/ep82xxm_defconfig | 3 - doc/README.scrapyard | 1 + include/configs/ep82xxm.h | 383 --------------------------------------- 8 files changed, 1 insertion(+), 687 deletions(-) delete mode 100644 board/ep82xxm/Kconfig delete mode 100644 board/ep82xxm/MAINTAINERS delete mode 100644 board/ep82xxm/Makefile delete mode 100644 board/ep82xxm/ep82xxm.c delete mode 100644 configs/ep82xxm_defconfig delete mode 100644 include/configs/ep82xxm.h
diff --git a/arch/powerpc/cpu/mpc8260/Kconfig b/arch/powerpc/cpu/mpc8260/Kconfig index 59e2bed..599b021 100644 --- a/arch/powerpc/cpu/mpc8260/Kconfig +++ b/arch/powerpc/cpu/mpc8260/Kconfig @@ -16,9 +16,6 @@ config TARGET_CPU86 config TARGET_CPU87 bool "Support CPU87"
-config TARGET_EP82XXM - bool "Support ep82xxm" - config TARGET_KM82XX bool "Support km82xx"
@@ -27,7 +24,6 @@ endchoice source "board/atc/Kconfig" source "board/cpu86/Kconfig" source "board/cpu87/Kconfig" -source "board/ep82xxm/Kconfig" source "board/keymile/km82xx/Kconfig"
endmenu diff --git a/board/ep82xxm/Kconfig b/board/ep82xxm/Kconfig deleted file mode 100644 index d842091..0000000 --- a/board/ep82xxm/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_EP82XXM - -config SYS_BOARD - default "ep82xxm" - -config SYS_CONFIG_NAME - default "ep82xxm" - -endif diff --git a/board/ep82xxm/MAINTAINERS b/board/ep82xxm/MAINTAINERS deleted file mode 100644 index c053df9..0000000 --- a/board/ep82xxm/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -EP82XXM BOARD -#M: - -S: Maintained -F: board/ep82xxm/ -F: include/configs/ep82xxm.h -F: configs/ep82xxm_defconfig diff --git a/board/ep82xxm/Makefile b/board/ep82xxm/Makefile deleted file mode 100644 index f9d3891..0000000 --- a/board/ep82xxm/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2001-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y := ep82xxm.o diff --git a/board/ep82xxm/ep82xxm.c b/board/ep82xxm/ep82xxm.c deleted file mode 100644 index fdde535..0000000 --- a/board/ep82xxm/ep82xxm.c +++ /dev/null @@ -1,274 +0,0 @@ -/* - * Copyright (C) 2006 Embedded Planet, LLC. - * - * Support for Embedded Planet EP82xxM boards. - * Tested on EP82xxM (MPC8270). - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc8260.h> -#include <ioports.h> -#include <asm/m8260_pci.h> -#ifdef CONFIG_PCI -#include <pci.h> -#endif -#include <miiphy.h> -#include <linux/compiler.h> - -/* - * I/O Port configuration table - * - * if conf is 1, then that port pin will be configured at boot time - * according to the five values podr/pdir/ppar/psor/pdat for that entry - */ - -#define CONFIG_SYS_FCC2 1 -#define CONFIG_SYS_FCC3 1 - -const iop_conf_t iop_conf_tab[4][32] = { - - /* Port A */ - { /* conf ppar psor pdir podr pdat */ - /* PA31 */ { 0, 0, 0, 0, 0, 1 }, /* PA31 */ - /* PA30 */ { 0, 0, 0, 0, 0, 1 }, /* PA30 */ - /* PA29 */ { 0, 0, 0, 0, 0, 1 }, /* PA29 */ - /* PA28 */ { 0, 0, 0, 0, 0, 1 }, /* PA28 */ - /* PA27 */ { 0, 0, 0, 0, 0, 1 }, /* PA27 */ - /* PA26 */ { 0, 0, 0, 0, 0, 1 }, /* PA26 */ - /* PA25 */ { 0, 0, 0, 0, 0, 1 }, /* PA25 */ - /* PA24 */ { 0, 0, 0, 0, 0, 1 }, /* PA24 */ - /* PA23 */ { 0, 0, 0, 0, 0, 1 }, /* PA23 */ - /* PA22 */ { 0, 0, 0, 0, 0, 0 }, /* PA22 */ - /* PA21 */ { 0, 0, 0, 0, 0, 1 }, /* PA21 */ - /* PA20 */ { 0, 0, 0, 0, 0, 1 }, /* PA20 */ - /* PA19 */ { 0, 0, 0, 0, 0, 1 }, /* PA19 */ - /* PA18 */ { 0, 0, 0, 0, 0, 1 }, /* PA18 */ - /* PA17 */ { 0, 0, 0, 0, 0, 1 }, /* PA17 */ - /* PA16 */ { 0, 0, 0, 0, 0, 1 }, /* PA16 */ - /* PA15 */ { 0, 0, 0, 0, 0, 1 }, /* PA15 */ - /* PA14 */ { 0, 0, 0, 0, 0, 1 }, /* PA14 */ - /* PA13 */ { 0, 0, 0, 0, 0, 1 }, /* PA13 */ - /* PA12 */ { 0, 0, 0, 0, 0, 1 }, /* PA12 */ - /* PA11 */ { 0, 0, 0, 0, 0, 1 }, /* PA11 */ - /* PA10 */ { 0, 0, 0, 0, 0, 1 }, /* PA10 */ - /* PA9 */ { 1, 1, 0, 1, 0, 1 }, /* SMC2 TxD */ - /* PA8 */ { 1, 1, 0, 0, 0, 1 }, /* SMC2 RxD */ - /* PA7 */ { 0, 0, 0, 0, 0, 1 }, /* PA7 */ - /* PA6 */ { 0, 0, 0, 0, 0, 1 }, /* PA6 */ - /* PA5 */ { 0, 0, 0, 0, 0, 1 }, /* PA5 */ - /* PA4 */ { 0, 0, 0, 0, 0, 1 }, /* PA4 */ - /* PA3 */ { 0, 0, 0, 0, 0, 1 }, /* PA3 */ - /* PA2 */ { 0, 0, 0, 0, 0, 1 }, /* PA2 */ - /* PA1 */ { 0, 0, 0, 0, 0, 1 }, /* PA1 */ - /* PA0 */ { 0, 0, 0, 0, 0, 1 } /* PA0 */ - }, - - /* Port B */ - { /* conf ppar psor pdir podr pdat */ - /* PB31 */ { CONFIG_SYS_FCC2, 1, 0, 1, 0, 0 }, /* FCC2 MII TX_ER */ - /* PB30 */ { CONFIG_SYS_FCC2, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_DV */ - /* PB29 */ { CONFIG_SYS_FCC2, 1, 1, 1, 0, 0 }, /* FCC2 MII TX_EN */ - /* PB28 */ { CONFIG_SYS_FCC2, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_ER */ - /* PB27 */ { CONFIG_SYS_FCC2, 1, 0, 0, 0, 0 }, /* FCC2 MII COL */ - /* PB26 */ { CONFIG_SYS_FCC2, 1, 0, 0, 0, 0 }, /* FCC2 MII CRS */ - /* PB25 */ { CONFIG_SYS_FCC2, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[3] */ - /* PB24 */ { CONFIG_SYS_FCC2, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[2] */ - /* PB23 */ { CONFIG_SYS_FCC2, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[1] */ - /* PB22 */ { CONFIG_SYS_FCC2, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[0] */ - /* PB21 */ { CONFIG_SYS_FCC2, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[0] */ - /* PB20 */ { CONFIG_SYS_FCC2, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[1] */ - /* PB19 */ { CONFIG_SYS_FCC2, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[2] */ - /* PB18 */ { CONFIG_SYS_FCC2, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[3] */ - /* PB17 */ { CONFIG_SYS_FCC3, 1, 0, 0, 0, 0 }, /* FCC3:RX_DIV */ - /* PB16 */ { CONFIG_SYS_FCC3, 1, 0, 0, 0, 0 }, /* FCC3:RX_ERR */ - /* PB15 */ { CONFIG_SYS_FCC3, 1, 0, 1, 0, 0 }, /* FCC3:TX_ERR */ - /* PB14 */ { CONFIG_SYS_FCC3, 1, 0, 1, 0, 0 }, /* FCC3:TX_EN */ - /* PB13 */ { CONFIG_SYS_FCC3, 1, 0, 0, 0, 0 }, /* FCC3:COL */ - /* PB12 */ { CONFIG_SYS_FCC3, 1, 0, 0, 0, 0 }, /* FCC3:CRS */ - /* PB11 */ { CONFIG_SYS_FCC3, 1, 0, 0, 0, 0 }, /* FCC3:RXD */ - /* PB10 */ { CONFIG_SYS_FCC3, 1, 0, 0, 0, 0 }, /* FCC3:RXD */ - /* PB9 */ { CONFIG_SYS_FCC3, 1, 0, 0, 0, 0 }, /* FCC3:RXD */ - /* PB8 */ { CONFIG_SYS_FCC3, 1, 0, 0, 0, 0 }, /* FCC3:RXD */ - /* PB7 */ { 0, 0, 0, 0, 0, 0 }, /* PB7 */ - /* PB6 */ { CONFIG_SYS_FCC3, 1, 0, 1, 0, 0 }, /* FCC3:TXD */ - /* PB5 */ { CONFIG_SYS_FCC3, 1, 0, 1, 0, 0 }, /* FCC3:TXD */ - /* PB4 */ { CONFIG_SYS_FCC3, 1, 0, 1, 0, 0 }, /* FCC3:TXD */ - /* PB3 */ { 0, 0, 0, 0, 0, 0 }, /* non-existent */ - /* PB2 */ { 0, 0, 0, 0, 0, 0 }, /* non-existent */ - /* PB1 */ { 0, 0, 0, 0, 0, 0 }, /* non-existent */ - /* PB0 */ { 0, 0, 0, 0, 0, 0 } /* non-existent */ - }, - - /* Port C */ - { /* conf ppar psor pdir podr pdat */ - /* PC31 */ { 0, 0, 0, 0, 0, 0 }, /* PC31 */ - /* PC30 */ { 0, 0, 0, 0, 0, 0 }, /* PC30 */ - /* PC29 */ { 1, 1, 1, 0, 0, 0 }, /* SCC1 CTS# */ - /* PC28 */ { 0, 0, 0, 0, 0, 0 }, /* PC28 */ - /* PC27 */ { CONFIG_SYS_FCC3, 1, 0, 1, 0, 0 }, /* FCC3: TXD[0] */ - /* PC26 */ { 0, 0, 0, 0, 0, 0 }, /* PC26 */ - /* PC25 */ { 0, 0, 0, 0, 0, 0 }, /* PC25 */ - /* PC24 */ { 0, 0, 0, 0, 0, 0 }, /* PC24 */ - /* PC23 */ { 0, 0, 0, 0, 0, 0 }, /* PC23 */ - /* PC22 */ { 0, 0, 0, 0, 0, 0 }, /* PC22 */ - /* PC21 */ { 0, 0, 0, 0, 0, 0 }, /* PC21 */ - /* PC20 */ { 0, 0, 0, 0, 0, 0 }, /* PC20 */ - /* PC19 */ { CONFIG_SYS_FCC2, 1, 0, 0, 0, 0 }, /* RxClk (CLK13) */ - /* PC18 */ { CONFIG_SYS_FCC2, 1, 0, 0, 0, 0 }, /* TxClk (CLK14) */ - /* PC17 */ { CONFIG_SYS_FCC3, 1, 0, 0, 0, 0 }, /* RxClk (CLK15) */ - /* PC16 */ { CONFIG_SYS_FCC3, 1, 0, 0, 0, 0 }, /* TxClk (CLK16) */ - /* PC15 */ { 0, 0, 0, 0, 0, 0 }, /* PC15 */ - /* PC14 */ { 1, 1, 0, 0, 0, 0 }, /* SCC1 CD# */ - /* PC13 */ { 1, 1, 0, 0, 0, 0 }, /* SCC2 CTS# */ - /* PC12 */ { 1, 1, 0, 0, 0, 0 }, /* SCC2 CD# */ - /* PC11 */ { 0, 0, 0, 0, 0, 0 }, /* PC11 */ - /* PC10 */ { 1, 1, 0, 0, 0, 0 }, /* SCC3 CD# */ - /* PC9 */ { 0, 0, 0, 0, 0, 0 }, /* PC9 */ - /* PC8 */ { 1, 1, 1, 0, 0, 0 }, /* SCC3 CTS# */ - /* PC7 */ { 0, 0, 0, 0, 0, 0 }, /* PC7 */ - /* PC6 */ { 0, 0, 0, 0, 0, 0 }, /* PC6 */ - /* PC5 */ { 0, 0, 0, 0, 0, 0 }, /* PC5 */ - /* PC4 */ { 0, 0, 0, 0, 0, 0 }, /* PC4 */ - /* PC3 */ { 0, 0, 0, 0, 0, 0 }, /* PC3 */ - /* PC2 */ { 0, 0, 0, 0, 0, 0 }, /* PC2 */ - /* PC1 */ { 0, 0, 0, 0, 0, 0 }, /* PC1 */ - /* PC0 */ { 0, 0, 0, 0, 0, 0 }, /* PC0 */ - }, - - /* Port D */ - { /* conf ppar psor pdir podr pdat */ - /* PD31 */ { 1, 1, 0, 0, 0, 0 }, /* SCC1 RXD */ - /* PD30 */ { 1, 1, 1, 1, 0, 1 }, /* SCC1 TXD */ - /* PD29 */ { 1, 1, 0, 1, 0, 0 }, /* SCC1 RTS# */ - /* PD28 */ { 1, 1, 0, 0, 0, 0 }, /* SCC2 RXD */ - /* PD27 */ { 1, 1, 0, 1, 0, 0 }, /* SCC2 TXD */ - /* PD26 */ { 1, 1, 0, 1, 0, 0 }, /* SCC2 RTS# */ - /* PD25 */ { 1, 1, 0, 0, 0, 0 }, /* SCC3 RXD */ - /* PD24 */ { 1, 1, 0, 1, 0, 0 }, /* SCC3 TXD */ - /* PD23 */ { 1, 1, 0, 1, 0, 0 }, /* SCC3 RTS# */ - /* PD22 */ { 0, 0, 0, 0, 0, 1 }, /* PD22 */ - /* PD21 */ { 0, 0, 0, 0, 0, 1 }, /* PD21 */ - /* PD20 */ { 0, 0, 0, 0, 0, 1 }, /* PD20 */ - /* PD19 */ { 0, 0, 0, 0, 0, 1 }, /* PD19 */ - /* PD18 */ { 0, 0, 0, 0, 0, 1 }, /* PD18 */ - /* PD17 */ { 0, 0, 0, 0, 0, 1 }, /* PD17 */ - /* PD16 */ { 0, 0, 0, 0, 0, 1 }, /* PD16 */ - /* PD15 */ { 1, 1, 1, 0, 1, 1 }, /* I2C SDA */ - /* PD14 */ { 1, 1, 1, 0, 1, 1 }, /* I2C SCL */ - /* PD13 */ { 0, 0, 0, 0, 0, 1 }, /* PD13 */ - /* PD12 */ { 0, 0, 0, 0, 0, 1 }, /* PD12 */ - /* PD11 */ { 0, 0, 0, 0, 0, 1 }, /* PD11 */ - /* PD10 */ { 0, 0, 0, 0, 0, 1 }, /* PD10 */ - /* PD9 */ { 1, 1, 0, 1, 0, 1 }, /* SMC1 TxD */ - /* PD8 */ { 1, 1, 0, 0, 0, 1 }, /* SMC1 RxD */ - /* PD7 */ { 1, 1, 0, 0, 0, 1 }, /* SMC1 SMSYN */ - /* PD6 */ { 0, 0, 0, 0, 0, 1 }, /* PD6 */ - /* PD5 */ { 0, 0, 0, 0, 0, 1 }, /* PD5 */ - /* PD4 */ { 0, 0, 0, 0, 0, 1 }, /* PD4 */ - /* PD3 */ { 0, 0, 0, 0, 0, 0 }, /* non-existent */ - /* PD2 */ { 0, 0, 0, 0, 0, 0 }, /* non-existent */ - /* PD1 */ { 0, 0, 0, 0, 0, 0 }, /* non-existent */ - /* PD0 */ { 0, 0, 0, 0, 0, 0 } /* non-existent */ - } -}; - -#ifdef CONFIG_PCI -typedef struct pci_ic_s { - unsigned long pci_int_stat; - unsigned long pci_int_mask; -}pci_ic_t; -#endif - -int board_early_init_f (void) -{ - vu_char *bcsr = (vu_char *)CONFIG_SYS_BCSR; - - bcsr[4] |= 0x30; /* Turn the LEDs off */ - -#if defined(CONFIG_CONS_ON_SMC) || defined(CONFIG_KGDB_ON_SMC) - bcsr[6] |= 0x10; -#endif -#if defined(CONFIG_CONS_ON_SCC) || defined(CONFIG_KGDB_ON_SCC) - bcsr[7] |= 0x10; -#endif - -#if CONFIG_SYS_FCC3 - bcsr[8] |= 0xC0; -#endif /* CONFIG_SYS_FCC3 */ -#if CONFIG_SYS_FCC2 - bcsr[8] |= 0x30; -#endif /* CONFIG_SYS_FCC2 */ - - return 0; -} - -phys_size_t initdram(int board_type) -{ - /* Size in MB of SDRAM populated on board*/ - long int msize = 256; - -#ifndef CONFIG_SYS_RAMBOOT - volatile immap_t *immap = (immap_t *)CONFIG_SYS_IMMR; - volatile memctl8260_t *memctl = &immap->im_memctl; - uint psdmr = CONFIG_SYS_PSDMR; - int i; - - unsigned char *ramptr1 = (unsigned char *)0x00000110; - __maybe_unused unsigned char ramtmp; - - memctl->memc_mptpr = CONFIG_SYS_MPTPR; - -udelay(400); - - /* Initialise 60x bus SDRAM */ - memctl->memc_psrt = CONFIG_SYS_PSRT; - memctl->memc_or1 = CONFIG_SYS_SDRAM_OR; - memctl->memc_br1 = CONFIG_SYS_SDRAM_BR; - memctl->memc_psdmr = psdmr; - -udelay(400); - - memctl->memc_psdmr = psdmr | PSDMR_OP_PREA; /* Precharge all banks */ - ramtmp = *ramptr1; - memctl->memc_psdmr = psdmr | PSDMR_OP_CBRR; /* CBR refresh */ - for (i = 0; i < 8; i++) { - memctl->memc_psdmr = psdmr | PSDMR_OP_CBRR; /* CBR refresh */ - } - ramtmp = *ramptr1; - memctl->memc_psdmr = psdmr | PSDMR_OP_MRW; /* Mode Register write */ - *ramptr1 = 0xFF; - memctl->memc_psdmr = psdmr | PSDMR_RFEN; /* Refresh enable */ -#endif /* !CONFIG_SYS_RAMBOOT */ - - /* Return total 60x bus SDRAM size */ - return msize * 1024 * 1024; -} - -int checkboard(void) -{ - vu_char *bcsr = (vu_char *)CONFIG_SYS_BCSR; - - puts("Board: "); - switch (bcsr[0]) { - case 0x0A: - printf("EP82xxM 1.0 CPLD revision %d\n", bcsr[1]); - break; - default: - printf("unknown: ID=%02X\n", bcsr[0]); - } - - return 0; -} - -#ifdef CONFIG_PCI -struct pci_controller hose; - -extern void pci_mpc8250_init(struct pci_controller *); - -void pci_init_board(void) -{ - pci_mpc8250_init(&hose); -} -#endif diff --git a/configs/ep82xxm_defconfig b/configs/ep82xxm_defconfig deleted file mode 100644 index 0842d2d..0000000 --- a/configs/ep82xxm_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_EP82XXM=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 0c47ebd..400eea1 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,7 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +ep82xxm powerpc mpc8260 - - gw8260 powerpc mpc8260 - - Oliver Brown obrown@adventnetworks.com IPHASE4539 powerpc mpc8260 - - Wolfgang Grandegger wg@denx.de muas3001 powerpc mpc8260 - - Heiko Schocher hs@denx.de diff --git a/include/configs/ep82xxm.h b/include/configs/ep82xxm.h deleted file mode 100644 index cf31f0f..0000000 --- a/include/configs/ep82xxm.h +++ /dev/null @@ -1,383 +0,0 @@ -/* - * Copyright (C) 2006 Embedded Planet, LLC. - * - * U-Boot configuration for Embedded Planet EP82xxM boards. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -#define CPU_ID_STR "MPC8270" - -#define CONFIG_EP82XXM /* Embedded Planet EP82xxM H 1.0 board */ - /* 256MB SDRAM / 64MB FLASH */ - -#define CONFIG_SYS_TEXT_BASE 0xFFF00000 - -#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ - -/* Allow serial number (serial#) and MAC address (ethaddr) to be overwritten */ -#define CONFIG_ENV_OVERWRITE - -/* - * Select serial console configuration - * - * If either CONFIG_CONS_ON_SMC or CONFIG_CONS_ON_SCC is selected, then - * CONFIG_CONS_INDEX must be set to the channel number (1-2 for SMC, 1-4 - * for SCC). - */ -#define CONFIG_CONS_ON_SMC /* Console is on SMC */ -#undef CONFIG_CONS_ON_SCC /* It's not on SCC */ -#undef CONFIG_CONS_NONE /* It's not on external UART */ -#define CONFIG_CONS_INDEX 1 /* SMC1 is used for console */ - -#define CONFIG_SYS_BCSR 0xFA000000 - -/* - * Select ethernet configuration - * - * If either CONFIG_ETHER_ON_SCC or CONFIG_ETHER_ON_FCC is selected, - * then CONFIG_ETHER_INDEX must be set to the channel number (1-4 for - * SCC, 1-3 for FCC) - * - * If CONFIG_ETHER_NONE is defined, then either the ethernet routines - * must be defined elsewhere (as for the console), or CONFIG_CMD_NET - * must be unset. - */ -#undef CONFIG_ETHER_ON_SCC /* Ethernet is not on SCC */ -#define CONFIG_ETHER_ON_FCC /* Ethernet is on FCC */ -#undef CONFIG_ETHER_NONE /* No external Ethernet */ - - -#define CONFIG_ETHER_ON_FCC2 -#define CONFIG_ETHER_ON_FCC3 - -#define CONFIG_SYS_CMXFCR_MASK3 (CMXFCR_FC3 | CMXFCR_RF3CS_MSK | CMXFCR_TF3CS_MSK) -#define CONFIG_SYS_CMXFCR_VALUE3 (CMXFCR_RF3CS_CLK15 | CMXFCR_TF3CS_CLK16) -#define CONFIG_SYS_CMXFCR_MASK2 (CMXFCR_FC2 | CMXFCR_RF2CS_MSK | CMXFCR_TF2CS_MSK) -#define CONFIG_SYS_CMXFCR_VALUE2 (CMXFCR_RF2CS_CLK13 | CMXFCR_TF2CS_CLK14) - -#define CONFIG_SYS_CPMFCR_RAMTYPE 0 -#define CONFIG_SYS_FCC_PSMR (FCC_PSMR_FDE | FCC_PSMR_LPB) - -#define CONFIG_MII /* MII PHY management */ -#define CONFIG_BITBANGMII /* Bit-banged MDIO interface */ - -/* - * GPIO pins used for bit-banged MII communications - */ -#define MDIO_PORT 0 /* Not used - implemented in BCSR */ - -#define MDIO_ACTIVE (*(vu_char *)(CONFIG_SYS_BCSR + 8) &= 0xFB) -#define MDIO_TRISTATE (*(vu_char *)(CONFIG_SYS_BCSR + 8) |= 0x04) -#define MDIO_READ (*(vu_char *)(CONFIG_SYS_BCSR + 8) & 1) - -#define MDIO(bit) if(bit) *(vu_char *)(CONFIG_SYS_BCSR + 8) |= 0x01; \ - else *(vu_char *)(CONFIG_SYS_BCSR + 8) &= 0xFE - -#define MDC(bit) if(bit) *(vu_char *)(CONFIG_SYS_BCSR + 8) |= 0x02; \ - else *(vu_char *)(CONFIG_SYS_BCSR + 8) &= 0xFD - -#define MIIDELAY udelay(1) - - -#ifndef CONFIG_8260_CLKIN -#define CONFIG_8260_CLKIN 66000000 /* in Hz */ -#endif - -#define CONFIG_BAUDRATE 115200 - -#define CONFIG_SYS_VXWORKS_MAC_PTR 0x4300 /* Pass Ethernet MAC to VxWorks */ - - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - - -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_ECHO -#define CONFIG_CMD_I2C -#define CONFIG_CMD_IMMAP -#define CONFIG_CMD_MII -#define CONFIG_CMD_PING -#define CONFIG_CMD_DATE -#define CONFIG_CMD_DTT -#define CONFIG_CMD_EEPROM -#define CONFIG_CMD_PCI -#define CONFIG_CMD_DIAG - - -#define CONFIG_ETHADDR 00:10:EC:00:88:65 -#define CONFIG_HAS_ETH1 -#define CONFIG_ETH1ADDR 00:10:EC:80:88:65 -#define CONFIG_IPADDR 10.0.0.245 -#define CONFIG_HOSTNAME EP82xxM -#define CONFIG_SERVERIP 10.0.0.26 -#define CONFIG_GATEWAYIP 10.0.0.1 -#define CONFIG_NETMASK 255.255.255.0 -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ -#define CONFIG_ENV_IN_OWN_SECT 1 -#define CONFIG_AUTO_COMPLETE 1 -#define CONFIG_EXTRA_ENV_SETTINGS "ethprime=FCC3" - -#if defined(CONFIG_CMD_KGDB) -#undef CONFIG_KGDB_ON_SMC /* define if kgdb on SMC */ -#define CONFIG_KGDB_ON_SCC /* define if kgdb on SCC */ -#undef CONFIG_KGDB_NONE /* define if kgdb on something else */ -#define CONFIG_KGDB_INDEX 1 /* which serial channel for kgdb */ -#define CONFIG_KGDB_BAUDRATE 115200 /* speed to run kgdb serial port at */ -#endif - -#define CONFIG_BZIP2 /* include support for bzip2 compressed images */ -#undef CONFIG_WATCHDOG /* disable platform specific watchdog */ - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "ep82xxm=> " /* Monitor Command Prompt */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x00100000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x00f00000 /* 1 ... 15 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 } - -/*----------------------------------------------------------------------- - * Environment - *----------------------------------------------------------------------*/ -/* - * Define here the location of the environment variables (FLASH or EEPROM). - * Note: DENX encourages to use redundant environment in FLASH. - */ -#if 1 -#define CONFIG_ENV_IS_IN_FLASH 1 /* use FLASH for environment vars */ -#else -#define CONFIG_ENV_IS_IN_EEPROM 1 /* use EEPROM for environment vars */ -#endif - -/*----------------------------------------------------------------------- - * FLASH related - *----------------------------------------------------------------------*/ -#define CONFIG_SYS_FLASH_BASE 0xFC000000 -#define CONFIG_SYS_FLASH_CFI -#define CONFIG_FLASH_CFI_DRIVER -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max num of flash banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 512 /* max num of sects on one chip */ -#define CONFIG_SYS_FLASH_EMPTY_INFO /* print 'E' for empty sector in flinfo */ - -#ifdef CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_SECT_SIZE 0x20000 -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) -#endif /* CONFIG_ENV_IS_IN_FLASH */ - -/*----------------------------------------------------------------------- - * I2C - *----------------------------------------------------------------------*/ -/* EEPROM Configuration */ -#define CONFIG_SYS_EEPROM_SIZE 0x1000 -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x54 -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 - -#ifdef CONFIG_ENV_IS_IN_EEPROM -#define CONFIG_ENV_SIZE 0x200 /* Size of Environment vars */ -#define CONFIG_ENV_OFFSET 0x0 -#endif /* CONFIG_ENV_IS_IN_EEPROM */ - -/* RTC Configuration */ -#define CONFIG_RTC_M41T11 1 /* uses a M41T81 */ -#define CONFIG_SYS_I2C_RTC_ADDR 0x68 -#define CONFIG_M41T11_BASE_YEAR 1900 - -/* I2C SYSMON (LM75) */ -#define CONFIG_DTT_LM75 1 -#define CONFIG_DTT_SENSORS {0} -#define CONFIG_SYS_DTT_MAX_TEMP 70 -#define CONFIG_SYS_DTT_LOW_TEMP -30 -#define CONFIG_SYS_DTT_HYSTERESIS 3 - -/*----------------------------------------------------------------------- - * NVRAM Configuration - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_NVRAM_BASE_ADDR 0xFA080000 -#define CONFIG_SYS_NVRAM_SIZE (128*1024)-16 - - -/*----------------------------------------------------------------------- - * PCI stuff - *----------------------------------------------------------------------- - */ -/* General PCI */ -#define CONFIG_PCI /* include pci support */ -#define CONFIG_PCI_INDIRECT_BRIDGE /* indirect PCI bridge support */ -#define CONFIG_PCI_PNP /* do pci plug-and-play */ -#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#define CONFIG_PCI_BOOTDELAY 0 - -/* PCI Memory map (if different from default map */ -#define CONFIG_SYS_PCI_SLV_MEM_LOCAL CONFIG_SYS_SDRAM_BASE /* Local base */ -#define CONFIG_SYS_PCI_SLV_MEM_BUS 0x00000000 /* PCI base */ -#define CONFIG_SYS_PICMR0_MASK_ATTRIB (PICMR_MASK_512MB | PICMR_ENABLE | \ - PICMR_PREFETCH_EN) - -/* - * These are the windows that allow the CPU to access PCI address space. - * All three PCI master windows, which allow the CPU to access PCI - * prefetch, non prefetch, and IO space (see below), must all fit within - * these windows. - */ - -/* - * Master window that allows the CPU to access PCI Memory (prefetch). - * This window will be setup with the second set of Outbound ATU registers - * in the bridge. - */ - -#define CONFIG_SYS_PCI_MSTR_MEM_LOCAL 0x80000000 /* Local base */ -#define CONFIG_SYS_PCI_MSTR_MEM_BUS 0x80000000 /* PCI base */ -#define CONFIG_SYS_CPU_PCI_MEM_START PCI_MSTR_MEM_LOCAL -#define CONFIG_SYS_PCI_MSTR_MEM_SIZE 0x20000000 /* 512MB */ -#define CONFIG_SYS_POCMR0_MASK_ATTRIB (POCMR_MASK_512MB | POCMR_ENABLE | POCMR_PREFETCH_EN) - -/* - * Master window that allows the CPU to access PCI Memory (non-prefetch). - * This window will be setup with the second set of Outbound ATU registers - * in the bridge. - */ - -#define CONFIG_SYS_PCI_MSTR_MEMIO_LOCAL 0xA0000000 /* Local base */ -#define CONFIG_SYS_PCI_MSTR_MEMIO_BUS 0xA0000000 /* PCI base */ -#define CONFIG_SYS_CPU_PCI_MEMIO_START PCI_MSTR_MEMIO_LOCAL -#define CONFIG_SYS_PCI_MSTR_MEMIO_SIZE 0x20000000 /* 512MB */ -#define CONFIG_SYS_POCMR1_MASK_ATTRIB (POCMR_MASK_512MB | POCMR_ENABLE) - -/* - * Master window that allows the CPU to access PCI IO space. - * This window will be setup with the first set of Outbound ATU registers - * in the bridge. - */ - -#define CONFIG_SYS_PCI_MSTR_IO_LOCAL 0xF6000000 /* Local base */ -#define CONFIG_SYS_PCI_MSTR_IO_BUS 0x00000000 /* PCI base */ -#define CONFIG_SYS_CPU_PCI_IO_START PCI_MSTR_IO_LOCAL -#define CONFIG_SYS_PCI_MSTR_IO_SIZE 0x02000000 /* 64MB */ -#define CONFIG_SYS_POCMR2_MASK_ATTRIB (POCMR_MASK_32MB | POCMR_ENABLE | POCMR_PCI_IO) - - -/* PCIBR0 - for PCI IO*/ -#define CONFIG_SYS_PCI_MSTR0_LOCAL CONFIG_SYS_PCI_MSTR_IO_LOCAL /* Local base */ -#define CONFIG_SYS_PCIMSK0_MASK ~(CONFIG_SYS_PCI_MSTR_IO_SIZE - 1U) /* Size of window */ -/* PCIBR1 - prefetch and non-prefetch regions joined together */ -#define CONFIG_SYS_PCI_MSTR1_LOCAL CONFIG_SYS_PCI_MSTR_MEM_LOCAL -#define CONFIG_SYS_PCIMSK1_MASK ~(CONFIG_SYS_PCI_MSTR_MEM_SIZE + CONFIG_SYS_PCI_MSTR_MEMIO_SIZE - 1U) - - -#define CONFIG_SYS_DIRECT_FLASH_TFTP - -#if defined(CONFIG_CMD_JFFS2) -#define CONFIG_SYS_JFFS2_FIRST_BANK 0 -#define CONFIG_SYS_JFFS2_NUM_BANKS CONFIG_SYS_MAX_FLASH_BANKS -#define CONFIG_SYS_JFFS2_FIRST_SECTOR 0 -#define CONFIG_SYS_JFFS2_LAST_SECTOR 62 -#define CONFIG_SYS_JFFS2_SORT_FRAGMENTS -#define CONFIG_SYS_JFFS_CUSTOM_PART -#endif - -#if defined(CONFIG_CMD_I2C) -#define CONFIG_HARD_I2C 1 /* To enable I2C support */ -#define CONFIG_SYS_I2C_SPEED 100000 /* I2C speed */ -#define CONFIG_SYS_I2C_SLAVE 0x7F /* I2C slave address */ -#endif - -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE -#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) -#define CONFIG_SYS_RAMBOOT -#endif - -#define CONFIG_SYS_MONITOR_LEN (512 << 10) /* Reserve 256KB for Monitor */ - -#define CONFIG_SYS_DEFAULT_IMMR 0x00010000 -#define CONFIG_SYS_IMMR 0xF0000000 - -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - - -/* Hard reset configuration word */ -#define CONFIG_SYS_HRCW_MASTER 0 /*0x1C800641*/ /* Not used - provided by CPLD */ -/* No slaves */ -#define CONFIG_SYS_HRCW_SLAVE1 0 -#define CONFIG_SYS_HRCW_SLAVE2 0 -#define CONFIG_SYS_HRCW_SLAVE3 0 -#define CONFIG_SYS_HRCW_SLAVE4 0 -#define CONFIG_SYS_HRCW_SLAVE5 0 -#define CONFIG_SYS_HRCW_SLAVE6 0 -#define CONFIG_SYS_HRCW_SLAVE7 0 - -#define CONFIG_SYS_MALLOC_LEN (4096 << 10) /* Reserve 4 MB for malloc() */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC8260 CPUs */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - -#define CONFIG_SYS_HID0_INIT 0 -#define CONFIG_SYS_HID0_FINAL 0 - -#define CONFIG_SYS_HID2 0 - -#define CONFIG_SYS_SIUMCR 0x02610000 -#define CONFIG_SYS_SYPCR 0xFFFF0689 -#define CONFIG_SYS_BCR 0x8080E000 -#define CONFIG_SYS_SCCR 0x00000001 - -#define CONFIG_SYS_RMR 0 -#define CONFIG_SYS_TMCNTSC 0x000000C3 -#define CONFIG_SYS_PISCR 0x00000083 -#define CONFIG_SYS_RCCR 0 - -#define CONFIG_SYS_MPTPR 0x0A00 -#define CONFIG_SYS_PSDMR 0xC432246E -#define CONFIG_SYS_PSRT 0x32 - -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_SDRAM_BR (CONFIG_SYS_SDRAM_BASE | 0x00000041) -#define CONFIG_SYS_SDRAM_OR 0xF0002900 - -#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | 0x00001801) -#define CONFIG_SYS_OR0_PRELIM 0xFC000882 -#define CONFIG_SYS_BR4_PRELIM (CONFIG_SYS_BCSR | 0x00001001) -#define CONFIG_SYS_OR4_PRELIM 0xFFF00050 - -#define CONFIG_SYS_RESET_ADDRESS 0xFFF00100 - -#endif /* __CONFIG_H */
These boards are still non-generic boards.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Wolfgang Denk wd@denx.de ---
arch/powerpc/cpu/mpc8260/Kconfig | 8 - board/cpu86/Kconfig | 9 - board/cpu86/MAINTAINERS | 7 - board/cpu86/Makefile | 8 - board/cpu86/cpu86.c | 304 ------------------ board/cpu86/cpu86.h | 27 -- board/cpu86/flash.c | 599 ---------------------------------- board/cpu87/Kconfig | 9 - board/cpu87/MAINTAINERS | 7 - board/cpu87/Makefile | 8 - board/cpu87/cpu87.c | 330 ------------------- board/cpu87/cpu87.h | 27 -- board/cpu87/flash.c | 608 ----------------------------------- configs/CPU86_ROMBOOT_defconfig | 4 - configs/CPU86_defconfig | 3 - configs/CPU87_ROMBOOT_defconfig | 4 - configs/CPU87_defconfig | 3 - doc/README.scrapyard | 2 + include/configs/CPU86.h | 629 ------------------------------------ include/configs/CPU87.h | 676 --------------------------------------- 20 files changed, 2 insertions(+), 3270 deletions(-) delete mode 100644 board/cpu86/Kconfig delete mode 100644 board/cpu86/MAINTAINERS delete mode 100644 board/cpu86/Makefile delete mode 100644 board/cpu86/cpu86.c delete mode 100644 board/cpu86/cpu86.h delete mode 100644 board/cpu86/flash.c delete mode 100644 board/cpu87/Kconfig delete mode 100644 board/cpu87/MAINTAINERS delete mode 100644 board/cpu87/Makefile delete mode 100644 board/cpu87/cpu87.c delete mode 100644 board/cpu87/cpu87.h delete mode 100644 board/cpu87/flash.c delete mode 100644 configs/CPU86_ROMBOOT_defconfig delete mode 100644 configs/CPU86_defconfig delete mode 100644 configs/CPU87_ROMBOOT_defconfig delete mode 100644 configs/CPU87_defconfig delete mode 100644 include/configs/CPU86.h delete mode 100644 include/configs/CPU87.h
diff --git a/arch/powerpc/cpu/mpc8260/Kconfig b/arch/powerpc/cpu/mpc8260/Kconfig index 599b021..eab4514 100644 --- a/arch/powerpc/cpu/mpc8260/Kconfig +++ b/arch/powerpc/cpu/mpc8260/Kconfig @@ -10,20 +10,12 @@ choice config TARGET_ATC bool "Support atc"
-config TARGET_CPU86 - bool "Support CPU86" - -config TARGET_CPU87 - bool "Support CPU87" - config TARGET_KM82XX bool "Support km82xx"
endchoice
source "board/atc/Kconfig" -source "board/cpu86/Kconfig" -source "board/cpu87/Kconfig" source "board/keymile/km82xx/Kconfig"
endmenu diff --git a/board/cpu86/Kconfig b/board/cpu86/Kconfig deleted file mode 100644 index ac3ae98..0000000 --- a/board/cpu86/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_CPU86 - -config SYS_BOARD - default "cpu86" - -config SYS_CONFIG_NAME - default "CPU86" - -endif diff --git a/board/cpu86/MAINTAINERS b/board/cpu86/MAINTAINERS deleted file mode 100644 index 06bdd0d..0000000 --- a/board/cpu86/MAINTAINERS +++ /dev/null @@ -1,7 +0,0 @@ -CPU86 BOARD -M: Wolfgang Denk wd@denx.de -S: Maintained -F: board/cpu86/ -F: include/configs/CPU86.h -F: configs/CPU86_defconfig -F: configs/CPU86_ROMBOOT_defconfig diff --git a/board/cpu86/Makefile b/board/cpu86/Makefile deleted file mode 100644 index da83afd..0000000 --- a/board/cpu86/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2001-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = cpu86.o flash.o diff --git a/board/cpu86/cpu86.c b/board/cpu86/cpu86.c deleted file mode 100644 index 9292910..0000000 --- a/board/cpu86/cpu86.c +++ /dev/null @@ -1,304 +0,0 @@ -/* - * (C) Copyright 2001 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <ioports.h> -#include <mpc8260.h> -#include "cpu86.h" - -/* - * I/O Port configuration table - * - * if conf is 1, then that port pin will be configured at boot time - * according to the five values podr/pdir/ppar/psor/pdat for that entry - */ - -const iop_conf_t iop_conf_tab[4][32] = { - - /* Port A configuration */ - { /* conf ppar psor pdir podr pdat */ - /* PA31 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 MII COL */ - /* PA30 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 MII CRS */ - /* PA29 */ { 1, 1, 1, 1, 0, 0 }, /* FCC1 MII TX_ER */ - /* PA28 */ { 1, 1, 1, 1, 0, 0 }, /* FCC1 MII TX_EN */ - /* PA27 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 MII RX_DV */ - /* PA26 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 MII RX_ER */ - /* PA25 */ { 1, 0, 0, 1, 0, 0 }, /* FCC2 MII MDIO */ - /* PA24 */ { 1, 0, 0, 1, 0, 0 }, /* FCC2 MII MDC */ - /* PA23 */ { 1, 0, 0, 1, 0, 0 }, /* FCC1 MII MDIO */ - /* PA22 */ { 1, 0, 0, 1, 0, 0 }, /* FCC1 MII MDC */ - /* PA21 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 MII TxD[3] */ - /* PA20 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 MII TxD[2] */ - /* PA19 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 MII TxD[1] */ - /* PA18 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 MII TxD[0] */ - /* PA17 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 MII RxD[0] */ - /* PA16 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 MII RxD[1] */ - /* PA15 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 MII RxD[2] */ - /* PA14 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 MII RxD[3] */ - /* PA13 */ { 1, 0, 0, 1, 0, 0 }, /* FCC2 MII TXSL1 */ - /* PA12 */ { 1, 0, 0, 1, 0, 1 }, /* FCC2 MII TXSL0 */ - /* PA11 */ { 1, 0, 0, 1, 0, 0 }, /* FCC1 MII TXSL1 */ - /* PA10 */ { 1, 0, 0, 1, 0, 1 }, /* FCC1 MII TXSL0 */ - /* PA9 */ { 0, 1, 0, 1, 0, 0 }, /* SMC2 TXD */ - /* PA8 */ { 0, 1, 0, 0, 0, 0 }, /* SMC2 RXD */ - /* PA7 */ { 0, 0, 0, 0, 0, 0 }, /* PA7 */ - /* PA6 */ { 1, 0, 0, 1, 0, 1 }, /* FCC2 MII PAUSE */ - /* PA5 */ { 1, 0, 0, 1, 0, 1 }, /* FCC1 MII PAUSE */ - /* PA4 */ { 1, 0, 0, 1, 0, 0 }, /* FCC2 MII PWRDN */ - /* PA3 */ { 1, 0, 0, 1, 0, 0 }, /* FCC1 MII PWRDN */ - /* PA2 */ { 0, 0, 0, 0, 0, 0 }, /* PA2 */ - /* PA1 */ { 1, 0, 0, 0, 0, 0 }, /* FCC2 MII MDINT */ - /* PA0 */ { 1, 0, 0, 1, 0, 0 } /* FCC1 MII MDINT */ - }, - - /* Port B configuration */ - { /* conf ppar psor pdir podr pdat */ - /* PB31 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TX_ER */ - /* PB30 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_DV */ - /* PB29 */ { 1, 1, 1, 1, 0, 0 }, /* FCC2 MII TX_EN */ - /* PB28 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_ER */ - /* PB27 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII COL */ - /* PB26 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII CRS */ - /* PB25 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[3] */ - /* PB24 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[2] */ - /* PB23 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[1] */ - /* PB22 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[0] */ - /* PB21 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[0] */ - /* PB20 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[1] */ - /* PB19 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[2] */ - /* PB18 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[3] */ - /* PB17 */ { 0, 0, 0, 0, 0, 0 }, /* PB17 */ - /* PB16 */ { 0, 0, 0, 0, 0, 0 }, /* PB16 */ - /* PB15 */ { 0, 0, 0, 0, 0, 0 }, /* PB15 */ - /* PB14 */ { 0, 0, 0, 0, 0, 0 }, /* PB14 */ - /* PB13 */ { 0, 0, 0, 0, 0, 0 }, /* PB13 */ - /* PB12 */ { 0, 0, 0, 0, 0, 0 }, /* PB12 */ - /* PB11 */ { 0, 0, 0, 0, 0, 0 }, /* PB11 */ - /* PB10 */ { 0, 0, 0, 0, 0, 0 }, /* PB10 */ - /* PB9 */ { 0, 0, 0, 0, 0, 0 }, /* PB9 */ - /* PB8 */ { 0, 0, 0, 0, 0, 0 }, /* PB8 */ - /* PB7 */ { 0, 0, 0, 0, 0, 0 }, /* PB7 */ - /* PB6 */ { 0, 0, 0, 0, 0, 0 }, /* PB6 */ - /* PB5 */ { 0, 0, 0, 0, 0, 0 }, /* PB5 */ - /* PB4 */ { 0, 0, 0, 0, 0, 0 }, /* PB4 */ - /* PB3 */ { 0, 0, 0, 0, 0, 0 }, /* PB3 */ - /* PB2 */ { 0, 0, 0, 0, 0, 0 }, /* PB2 */ - /* PB1 */ { 0, 0, 0, 0, 0, 0 }, /* PB1 */ - /* PB0 */ { 0, 0, 0, 0, 0, 0 } /* PB0 */ - }, - - /* Port C */ - { /* conf ppar psor pdir podr pdat */ - /* PC31 */ { 0, 0, 0, 0, 0, 0 }, /* PC31 */ - /* PC30 */ { 0, 0, 0, 0, 0, 0 }, /* PC30 */ - /* PC29 */ { 1, 0, 0, 0, 0, 0 }, /* SCC1 CTS */ - /* PC28 */ { 1, 0, 0, 0, 0, 0 }, /* SCC2 CTS */ - /* PC27 */ { 0, 0, 0, 0, 0, 0 }, /* PC27 */ - /* PC26 */ { 0, 0, 0, 0, 0, 0 }, /* PC26 */ - /* PC25 */ { 0, 0, 0, 0, 0, 0 }, /* PC25 */ - /* PC24 */ { 0, 0, 0, 0, 0, 0 }, /* PC24 */ - /* PC23 */ { 0, 0, 0, 0, 0, 0 }, /* FDC37C78 DACFD */ - /* PC22 */ { 0, 0, 0, 0, 0, 0 }, /* FDC37C78 DNFD */ - /* PC21 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 MII RX_CLK */ - /* PC20 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 MII TX_CLK */ - /* PC19 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_CLK */ - /* PC18 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII TX_CLK */ - /* PC17 */ { 0, 0, 0, 0, 0, 0 }, /* PC17 */ - /* PC16 */ { 0, 0, 0, 0, 0, 0 }, /* PC16 */ - /* PC15 */ { 0, 0, 0, 0, 0, 0 }, /* PC15 */ - /* PC14 */ { 0, 0, 0, 0, 0, 0 }, /* PC14 */ - /* PC13 */ { 0, 0, 0, 0, 0, 0 }, /* PC13 */ - /* PC12 */ { 0, 0, 0, 0, 0, 0 }, /* PC12 */ - /* PC11 */ { 0, 0, 0, 0, 0, 0 }, /* PC11 */ - /* PC10 */ { 0, 0, 0, 0, 0, 0 }, /* PC10 */ - /* PC9 */ { 0, 0, 0, 0, 0, 0 }, /* FC9 */ - /* PC8 */ { 0, 0, 0, 0, 0, 0 }, /* PC8 */ - /* PC7 */ { 0, 0, 0, 0, 0, 0 }, /* PC7 */ - /* PC6 */ { 0, 0, 0, 0, 0, 0 }, /* PC6 */ - /* PC5 */ { 0, 0, 0, 0, 0, 0 }, /* PC5 */ - /* PC4 */ { 0, 0, 0, 0, 0, 0 }, /* PC4 */ - /* PC3 */ { 0, 0, 0, 0, 0, 0 }, /* PC3 */ - /* PC2 */ { 0, 0, 0, 0, 0, 0 }, /* PC2 */ - /* PC1 */ { 0, 0, 0, 0, 0, 0 }, /* PC1 */ - /* PC0 */ { 0, 0, 0, 0, 0, 0 }, /* FDC37C78 DRQFD */ - }, - - /* Port D */ - { /* conf ppar psor pdir podr pdat */ - /* PD31 */ { 1, 1, 0, 0, 0, 0 }, /* SCC1 RXD */ - /* PD30 */ { 1, 1, 1, 1, 0, 0 }, /* SCC1 TXD */ - /* PD29 */ { 1, 0, 0, 1, 0, 0 }, /* SCC1 RTS */ - /* PD28 */ { 1, 1, 0, 0, 0, 0 }, /* SCC2 RXD */ - /* PD27 */ { 1, 1, 0, 1, 0, 0 }, /* SCC2 TXD */ - /* PD26 */ { 1, 0, 0, 1, 0, 0 }, /* SCC2 RTS */ - /* PD25 */ { 0, 0, 0, 0, 0, 0 }, /* PD25 */ - /* PD24 */ { 0, 0, 0, 0, 0, 0 }, /* PD24 */ - /* PD23 */ { 0, 0, 0, 0, 0, 0 }, /* PD23 */ - /* PD22 */ { 0, 0, 0, 0, 0, 0 }, /* PD22 */ - /* PD21 */ { 0, 0, 0, 0, 0, 0 }, /* PD21 */ - /* PD20 */ { 0, 0, 0, 0, 0, 0 }, /* PD20 */ - /* PD19 */ { 0, 0, 0, 0, 0, 0 }, /* PD19 */ - /* PD18 */ { 0, 0, 0, 0, 0, 0 }, /* PD18 */ - /* PD17 */ { 0, 0, 0, 0, 0, 0 }, /* PD17 */ - /* PD16 */ { 0, 0, 0, 0, 0, 0 }, /* PD16 */ -#if defined(CONFIG_SYS_I2C_SOFT) - /* PD15 */ { 1, 0, 0, 1, 1, 1 }, /* I2C SDA */ - /* PD14 */ { 1, 0, 0, 1, 1, 1 }, /* I2C SCL */ -#else -#if defined(CONFIG_HARD_I2C) - /* PD15 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SDA */ - /* PD14 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SCL */ -#else /* normal I/O port pins */ - /* PD15 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SDA */ - /* PD14 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SCL */ -#endif -#endif - /* PD13 */ { 0, 0, 0, 0, 0, 0 }, /* PD13 */ - /* PD12 */ { 0, 0, 0, 0, 0, 0 }, /* PD12 */ - /* PD11 */ { 0, 0, 0, 0, 0, 0 }, /* PD11 */ - /* PD10 */ { 0, 0, 0, 0, 0, 0 }, /* PD10 */ - /* PD9 */ { 1, 1, 0, 1, 0, 0 }, /* SMC1 TXD */ - /* PD8 */ { 1, 1, 0, 0, 0, 0 }, /* SMC1 RXD */ - /* PD7 */ { 0, 0, 0, 0, 0, 0 }, /* PD7 */ - /* PD6 */ { 0, 0, 0, 0, 0, 0 }, /* PD6 */ - /* PD5 */ { 0, 0, 0, 0, 0, 0 }, /* PD5 */ - /* PD4 */ { 0, 0, 0, 0, 0, 0 }, /* PD4 */ - /* PD3 */ { 0, 0, 0, 0, 0, 0 }, /* PD3 */ - /* PD2 */ { 0, 0, 0, 0, 0, 0 }, /* PD2 */ - /* PD1 */ { 0, 0, 0, 0, 0, 0 }, /* PD1 */ - /* PD0 */ { 0, 0, 0, 0, 0, 0 } /* PD0 */ - } -}; - -/* ------------------------------------------------------------------------- */ - -/* Check Board Identity: - */ -int checkboard (void) -{ - printf ("Board: CPU86 (Rev %02x)\n", CPU86_REV); - return 0; -} - -/* ------------------------------------------------------------------------- */ - -/* Try SDRAM initialization with P/LSDMR=sdmr and ORx=orx - * - * This routine performs standard 8260 initialization sequence - * and calculates the available memory size. It may be called - * several times to try different SDRAM configurations on both - * 60x and local buses. - */ -static long int try_init (volatile memctl8260_t * memctl, ulong sdmr, - ulong orx, volatile uchar * base) -{ - volatile uchar c = 0xff; - volatile uint *sdmr_ptr; - volatile uint *orx_ptr; - ulong maxsize, size; - int i; - - /* We must be able to test a location outsize the maximum legal size - * to find out THAT we are outside; but this address still has to be - * mapped by the controller. That means, that the initial mapping has - * to be (at least) twice as large as the maximum expected size. - */ - maxsize = (1 + (~orx | 0x7fff)) / 2; - - /* Since CONFIG_SYS_SDRAM_BASE is always 0 (??), we assume that - * we are configuring CS1 if base != 0 - */ - sdmr_ptr = &memctl->memc_psdmr; - orx_ptr = &memctl->memc_or2; - - *orx_ptr = orx; - - /* - * Quote from 8260 UM (10.4.2 SDRAM Power-On Initialization, 10-35): - * - * "At system reset, initialization software must set up the - * programmable parameters in the memory controller banks registers - * (ORx, BRx, P/LSDMR). After all memory parameters are configured, - * system software should execute the following initialization sequence - * for each SDRAM device. - * - * 1. Issue a PRECHARGE-ALL-BANKS command - * 2. Issue eight CBR REFRESH commands - * 3. Issue a MODE-SET command to initialize the mode register - * - * The initial commands are executed by setting P/LSDMR[OP] and - * accessing the SDRAM with a single-byte transaction." - * - * The appropriate BRx/ORx registers have already been set when we - * get here. The SDRAM can be accessed at the address CONFIG_SYS_SDRAM_BASE. - */ - - *sdmr_ptr = sdmr | PSDMR_OP_PREA; - *base = c; - - *sdmr_ptr = sdmr | PSDMR_OP_CBRR; - for (i = 0; i < 8; i++) - *base = c; - - *sdmr_ptr = sdmr | PSDMR_OP_MRW; - *(base + CONFIG_SYS_MRS_OFFS) = c; /* setting MR on address lines */ - - *sdmr_ptr = sdmr | PSDMR_OP_NORM | PSDMR_RFEN; - *base = c; - - size = get_ram_size((long *)base, maxsize); - - *orx_ptr = orx | ~(size - 1); - - return (size); -} - -phys_size_t initdram (int board_type) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8260_t *memctl = &immap->im_memctl; - -#ifndef CONFIG_SYS_RAMBOOT - ulong size8, size9; -#endif - long psize; - - psize = 32 * 1024 * 1024; - - memctl->memc_mptpr = CONFIG_SYS_MPTPR; - memctl->memc_psrt = CONFIG_SYS_PSRT; - -#ifndef CONFIG_SYS_RAMBOOT - /* 60x SDRAM setup: - */ - size8 = try_init (memctl, CONFIG_SYS_PSDMR_8COL, CONFIG_SYS_OR2_8COL, - (uchar *) CONFIG_SYS_SDRAM_BASE); - size9 = try_init (memctl, CONFIG_SYS_PSDMR_9COL, CONFIG_SYS_OR2_9COL, - (uchar *) CONFIG_SYS_SDRAM_BASE); - - if (size8 < size9) { - psize = size9; - printf ("(60x:9COL) "); - } else { - psize = try_init (memctl, CONFIG_SYS_PSDMR_8COL, CONFIG_SYS_OR2_8COL, - (uchar *) CONFIG_SYS_SDRAM_BASE); - printf ("(60x:8COL) "); - } - -#endif /* CONFIG_SYS_RAMBOOT */ - - icache_enable (); - - return (psize); -} - -#if defined(CONFIG_CMD_DOC) -void doc_init (void) -{ - doc_probe (CONFIG_SYS_DOC_BASE); -} -#endif diff --git a/board/cpu86/cpu86.h b/board/cpu86/cpu86.h deleted file mode 100644 index ca0c39f..0000000 --- a/board/cpu86/cpu86.h +++ /dev/null @@ -1,27 +0,0 @@ -#ifndef __BOARD_CPU86__ -#define __BOARD_CPU86__ - -#include <config.h> - -#define REG8(x) (*(volatile unsigned char *)(x)) - -/* CPU86 register definitions */ -#define CPU86_VME_EAC REG8(CONFIG_SYS_BCRS_BASE + 0x00) -#define CPU86_VME_SAC REG8(CONFIG_SYS_BCRS_BASE + 0x01) -#define CPU86_VME_MAC REG8(CONFIG_SYS_BCRS_BASE + 0x02) -#define CPU86_BCR REG8(CONFIG_SYS_BCRS_BASE + 0x03) -#define CPU86_BSR REG8(CONFIG_SYS_BCRS_BASE + 0x04) -#define CPU86_WDOG_RPORT REG8(CONFIG_SYS_BCRS_BASE + 0x05) -#define CPU86_MBOX_IRQ REG8(CONFIG_SYS_BCRS_BASE + 0x04) -#define CPU86_REV REG8(CONFIG_SYS_BCRS_BASE + 0x07) -#define CPU86_VME_IRQMASK REG8(CONFIG_SYS_BCRS_BASE + 0x80) -#define CPU86_VME_IRQSTATUS REG8(CONFIG_SYS_BCRS_BASE + 0x81) -#define CPU86_LOCAL_IRQMASK REG8(CONFIG_SYS_BCRS_BASE + 0x82) -#define CPU86_LOCAL_IRQSTATUS REG8(CONFIG_SYS_BCRS_BASE + 0x83) -#define CPU86_PMCL_IRQSTATUS REG8(CONFIG_SYS_BCRS_BASE + 0x84) - -/* Board Control Register bits */ -#define CPU86_BCR_FWPT 0x01 -#define CPU86_BCR_FWRE 0x02 - -#endif /* __BOARD_CPU86__ */ diff --git a/board/cpu86/flash.c b/board/cpu86/flash.c deleted file mode 100644 index b99a9a0..0000000 --- a/board/cpu86/flash.c +++ /dev/null @@ -1,599 +0,0 @@ -/* - * (C) Copyright 2001, 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * Flash Routines for Intel devices - * - *-------------------------------------------------------------------- - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc8xx.h> -#include "cpu86.h" - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; - -/*----------------------------------------------------------------------- - */ -ulong flash_int_get_size (volatile unsigned long *baseaddr, - flash_info_t * info) -{ - short i; - unsigned long flashtest_h, flashtest_l; - - info->sector_count = info->size = 0; - info->flash_id = FLASH_UNKNOWN; - - /* Write identify command sequence and test FLASH answer - */ - baseaddr[0] = 0x00900090; - baseaddr[1] = 0x00900090; - - flashtest_h = baseaddr[0]; /* manufacturer ID */ - flashtest_l = baseaddr[1]; - - if (flashtest_h != INTEL_MANUFACT || flashtest_l != INTEL_MANUFACT) - return (0); /* no or unknown flash */ - - flashtest_h = baseaddr[2]; /* device ID */ - flashtest_l = baseaddr[3]; - - if (flashtest_h != flashtest_l) - return (0); - - switch (flashtest_h) { - case INTEL_ID_28F160C3B: - info->flash_id = FLASH_28F160C3B; - info->sector_count = 39; - info->size = 0x00800000; /* 4 * 2 MB = 8 MB */ - break; - case INTEL_ID_28F160F3B: - info->flash_id = FLASH_28F160F3B; - info->sector_count = 39; - info->size = 0x00800000; /* 4 * 2 MB = 8 MB */ - break; - default: - return (0); /* no or unknown flash */ - } - - info->flash_id |= INTEL_MANUFACT << 16; /* set manufacturer offset */ - - if (info->flash_id & FLASH_BTYPE) { - volatile unsigned long *tmp = baseaddr; - - /* set up sector start adress table (bottom sector type) - * AND unlock the sectors (if our chip is 160C3) - */ - for (i = 0; i < info->sector_count; i++) { - if ((info->flash_id & FLASH_TYPEMASK) == FLASH_28F160C3B) { - tmp[0] = 0x00600060; - tmp[1] = 0x00600060; - tmp[0] = 0x00D000D0; - tmp[1] = 0x00D000D0; - } - info->start[i] = (uint) tmp; - tmp += i < 8 ? 0x2000 : 0x10000; /* pointer arith */ - } - } - - memset (info->protect, 0, info->sector_count); - - baseaddr[0] = 0x00FF00FF; - baseaddr[1] = 0x00FF00FF; - - return (info->size); -} - -static ulong flash_amd_get_size (vu_char *addr, flash_info_t *info) -{ - short i; - uchar vendor, devid; - ulong base = (ulong)addr; - - /* Write auto select command: read Manufacturer ID */ - addr[0x0555] = 0xAA; - addr[0x02AA] = 0x55; - addr[0x0555] = 0x90; - - udelay(1000); - - vendor = addr[0]; - devid = addr[1] & 0xff; - - /* only support AMD */ - if (vendor != 0x01) { - return 0; - } - - vendor &= 0xf; - devid &= 0xff; - - if (devid == AMD_ID_F040B) { - info->flash_id = vendor << 16 | devid; - info->sector_count = 8; - info->size = info->sector_count * 0x10000; - } - else if (devid == AMD_ID_F080B) { - info->flash_id = vendor << 16 | devid; - info->sector_count = 16; - info->size = 4 * info->sector_count * 0x10000; - } - else if (devid == AMD_ID_F016D) { - info->flash_id = vendor << 16 | devid; - info->sector_count = 32; - info->size = 4 * info->sector_count * 0x10000; - } - else { - printf ("## Unknown Flash Type: %02x\n", devid); - return 0; - } - - /* check for protected sectors */ - for (i = 0; i < info->sector_count; i++) { - /* sector base address */ - info->start[i] = base + i * (info->size / info->sector_count); - /* read sector protection at sector address, (A7 .. A0) = 0x02 */ - /* D0 = 1 if protected */ - addr = (volatile unsigned char *)(info->start[i]); - info->protect[i] = addr[2] & 1; - } - - /* - * Prevent writes to uninitialized FLASH. - */ - if (info->flash_id != FLASH_UNKNOWN) { - addr = (vu_char *)info->start[0]; - addr[0] = 0xF0; /* reset bank */ - } - - return (info->size); -} - - -/*----------------------------------------------------------------------- - */ -unsigned long flash_init (void) -{ - unsigned long size_b0 = 0; - unsigned long size_b1 = 0; - int i; - - /* Init: no FLASHes known - */ - for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - } - - /* Disable flash protection */ - CPU86_BCR |= (CPU86_BCR_FWPT | CPU86_BCR_FWRE); - - /* Static FLASH Bank configuration here (only one bank) */ - - size_b0 = flash_int_get_size ((ulong *) CONFIG_SYS_FLASH_BASE, &flash_info[0]); - size_b1 = flash_amd_get_size ((uchar *) CONFIG_SYS_BOOTROM_BASE, &flash_info[1]); - - if (size_b0 > 0 || size_b1 > 0) { - - printf("("); - - if (size_b0 > 0) { - puts ("Bank#1 - "); - print_size (size_b0, (size_b1 > 0) ? ", " : ") "); - } - - if (size_b1 > 0) { - puts ("Bank#2 - "); - print_size (size_b1, ") "); - } - } - else { - printf ("## No FLASH found.\n"); - return 0; - } - /* protect monitor and environment sectors - */ - -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_BOOTROM_BASE - if (size_b1) { - /* If U-Boot is booted from ROM the CONFIG_SYS_MONITOR_BASE > CONFIG_SYS_FLASH_BASE - * but we shouldn't protect it. - */ - - flash_protect (FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE + monitor_flash_len - 1, &flash_info[1] - ); - } -#else -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE - flash_protect (FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE + monitor_flash_len - 1, &flash_info[0] - ); -#endif -#endif - -#if defined(CONFIG_ENV_IS_IN_FLASH) && defined(CONFIG_ENV_ADDR) -# ifndef CONFIG_ENV_SIZE -# define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -# endif -# if CONFIG_ENV_ADDR >= CONFIG_SYS_BOOTROM_BASE - if (size_b1) { - flash_protect (FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR + CONFIG_ENV_SIZE - 1, &flash_info[1]); - } -# else - flash_protect (FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR + CONFIG_ENV_SIZE - 1, &flash_info[0]); -# endif -#endif - - return (size_b0 + size_b1); -} - -/*----------------------------------------------------------------------- - */ -void flash_print_info (flash_info_t * info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch ((info->flash_id >> 16) & 0xff) { - case 0x89: - printf ("INTEL "); - break; - case 0x1: - printf ("AMD "); - break; - default: - printf ("Unknown Vendor "); - break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_28F160C3B: - printf ("28F160C3B (16 Mbit, bottom sector)\n"); - break; - case FLASH_28F160F3B: - printf ("28F160F3B (16 Mbit, bottom sector)\n"); - break; - case AMD_ID_F040B: - printf ("AM29F040B (4 Mbit)\n"); - break; - default: - printf ("Unknown Chip Type\n"); - break; - } - - if (info->size < 0x100000) - printf (" Size: %ld KB in %d Sectors\n", - info->size >> 10, info->sector_count); - else - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); - - printf (" Sector Start Addresses:"); - for (i = 0; i < info->sector_count; ++i) { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", - info->start[i], - info->protect[i] ? " (RO)" : " " - ); - } - printf ("\n"); -} - -/*----------------------------------------------------------------------- - */ -int flash_erase (flash_info_t * info, int s_first, int s_last) -{ - vu_char *addr = (vu_char *)(info->start[0]); - int flag, prot, sect, l_sect; - ulong start, now, last; - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - prot = 0; - for (sect = s_first; sect <= s_last; sect++) { - if (info->protect[sect]) - prot++; - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - printf ("\n"); - } - - /* Check the type of erased flash - */ - if (info->flash_id >> 16 == 0x1) { - /* Erase AMD flash - */ - l_sect = -1; - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - addr[0x0555] = 0xAA; - addr[0x02AA] = 0x55; - addr[0x0555] = 0x80; - addr[0x0555] = 0xAA; - addr[0x02AA] = 0x55; - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - - /* Start erase on unprotected sectors */ - for (sect = s_first; sect<=s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - addr = (vu_char *)(info->start[sect]); - addr[0] = 0x30; - l_sect = sect; - } - } - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - - /* - * We wait for the last triggered sector - */ - if (l_sect < 0) - goto AMD_DONE; - - start = get_timer (0); - last = start; - addr = (vu_char *)(info->start[l_sect]); - while ((addr[0] & 0x80) != 0x80) { - if ((now = get_timer(start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - return 1; - } - /* show that we're waiting */ - if ((now - last) > 1000) { /* every second */ - serial_putc ('.'); - last = now; - } - } - -AMD_DONE: - /* reset to read mode */ - addr = (volatile unsigned char *)info->start[0]; - addr[0] = 0xF0; /* reset bank */ - - } else { - /* Erase Intel flash - */ - - /* Start erase on unprotected sectors - */ - for (sect = s_first; sect <= s_last; sect++) { - volatile ulong *addr = - (volatile unsigned long *) info->start[sect]; - - start = get_timer (0); - last = start; - if (info->protect[sect] == 0) { - /* Disable interrupts which might cause a timeout here - */ - flag = disable_interrupts (); - - /* Erase the block - */ - addr[0] = 0x00200020; - addr[1] = 0x00200020; - addr[0] = 0x00D000D0; - addr[1] = 0x00D000D0; - - /* re-enable interrupts if necessary - */ - if (flag) - enable_interrupts (); - - /* wait at least 80us - let's wait 1 ms - */ - udelay (1000); - - last = start; - while ((addr[0] & 0x00800080) != 0x00800080 || - (addr[1] & 0x00800080) != 0x00800080) { - if ((now = get_timer (start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout (erase suspended!)\n"); - /* Suspend erase - */ - addr[0] = 0x00B000B0; - addr[1] = 0x00B000B0; - goto DONE; - } - /* show that we're waiting - */ - if ((now - last) > 1000) { /* every second */ - serial_putc ('.'); - last = now; - } - } - if (addr[0] & 0x00220022 || addr[1] & 0x00220022) { - printf ("*** ERROR: erase failed!\n"); - goto DONE; - } - } - /* Clear status register and reset to read mode - */ - addr[0] = 0x00500050; - addr[1] = 0x00500050; - addr[0] = 0x00FF00FF; - addr[1] = 0x00FF00FF; - } - } - - printf (" done\n"); - -DONE: - return 0; -} - -static int write_word (flash_info_t *, volatile unsigned long *, ulong); -static int write_byte (flash_info_t *info, ulong dest, uchar data); - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) -{ - ulong v; - int i, l, rc, cc = cnt, res = 0; - - if (info->flash_id >> 16 == 0x1) { - - /* Write to AMD 8-bit flash - */ - while (cnt > 0) { - if ((rc = write_byte(info, addr, *src)) != 0) { - return (rc); - } - addr++; - src++; - cnt--; - } - - return (0); - } else { - - /* Write to Intel 64-bit flash - */ - for (v=0; cc > 0; addr += 4, cc -= 4 - l) { - l = (addr & 3); - addr &= ~3; - - for (i = 0; i < 4; i++) { - v = (v << 8) + (i < l || i - l >= cc ? - *((unsigned char *) addr + i) : *src++); - } - - if ((res = write_word (info, (volatile unsigned long *) addr, v)) != 0) - break; - } - } - - return (res); -} - -/*----------------------------------------------------------------------- - * Write a word to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_word (flash_info_t * info, volatile unsigned long *addr, - ulong data) -{ - int flag, res = 0; - ulong start; - - /* Check if Flash is (sufficiently) erased - */ - if ((*addr & data) != data) - return (2); - - /* Disable interrupts which might cause a timeout here - */ - flag = disable_interrupts (); - - *addr = 0x00400040; - *addr = data; - - /* re-enable interrupts if necessary - */ - if (flag) - enable_interrupts (); - - start = get_timer (0); - while ((*addr & 0x00800080) != 0x00800080) { - if (get_timer (start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - /* Suspend program - */ - *addr = 0x00B000B0; - res = 1; - goto OUT; - } - } - - if (*addr & 0x00220022) { - printf ("*** ERROR: program failed!\n"); - res = 1; - } - -OUT: - /* Clear status register and reset to read mode - */ - *addr = 0x00500050; - *addr = 0x00FF00FF; - - return (res); -} - -/*----------------------------------------------------------------------- - * Write a byte to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_byte (flash_info_t *info, ulong dest, uchar data) -{ - vu_char *addr = (vu_char *)(info->start[0]); - ulong start; - int flag; - - /* Check if Flash is (sufficiently) erased */ - if ((*((vu_char *)dest) & data) != data) { - return (2); - } - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - addr[0x0555] = 0xAA; - addr[0x02AA] = 0x55; - addr[0x0555] = 0xA0; - - *((vu_char *)dest) = data; - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* data polling for D7 */ - start = get_timer (0); - while ((*((vu_char *)dest) & 0x80) != (data & 0x80)) { - if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - return (1); - } - } - return (0); -} - -/*----------------------------------------------------------------------- - */ diff --git a/board/cpu87/Kconfig b/board/cpu87/Kconfig deleted file mode 100644 index a4f2768..0000000 --- a/board/cpu87/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_CPU87 - -config SYS_BOARD - default "cpu87" - -config SYS_CONFIG_NAME - default "CPU87" - -endif diff --git a/board/cpu87/MAINTAINERS b/board/cpu87/MAINTAINERS deleted file mode 100644 index 32804ea..0000000 --- a/board/cpu87/MAINTAINERS +++ /dev/null @@ -1,7 +0,0 @@ -CPU87 BOARD -#M: - -S: Maintained -F: board/cpu87/ -F: include/configs/CPU87.h -F: configs/CPU87_defconfig -F: configs/CPU87_ROMBOOT_defconfig diff --git a/board/cpu87/Makefile b/board/cpu87/Makefile deleted file mode 100644 index 0d59bbb..0000000 --- a/board/cpu87/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2001-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = cpu87.o flash.o diff --git a/board/cpu87/cpu87.c b/board/cpu87/cpu87.c deleted file mode 100644 index 01f90d2..0000000 --- a/board/cpu87/cpu87.c +++ /dev/null @@ -1,330 +0,0 @@ -/* - * (C) Copyright 2001-2005 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <ioports.h> -#include <mpc8260.h> -#include "cpu87.h" -#include <pci.h> -#include <netdev.h> - -/* - * I/O Port configuration table - * - * if conf is 1, then that port pin will be configured at boot time - * according to the five values podr/pdir/ppar/psor/pdat for that entry - */ - -const iop_conf_t iop_conf_tab[4][32] = { - - /* Port A configuration */ - { /* conf ppar psor pdir podr pdat */ - /* PA31 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 MII COL */ - /* PA30 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 MII CRS */ - /* PA29 */ { 1, 1, 1, 1, 0, 0 }, /* FCC1 MII TX_ER */ - /* PA28 */ { 1, 1, 1, 1, 0, 0 }, /* FCC1 MII TX_EN */ - /* PA27 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 MII RX_DV */ - /* PA26 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 MII RX_ER */ - /* PA25 */ { 1, 0, 0, 1, 0, 0 }, /* FCC2 MII MDIO */ - /* PA24 */ { 1, 0, 0, 1, 0, 0 }, /* FCC2 MII MDC */ - /* PA23 */ { 1, 0, 0, 1, 0, 0 }, /* FCC1 MII MDIO */ - /* PA22 */ { 1, 0, 0, 1, 0, 0 }, /* FCC1 MII MDC */ - /* PA21 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 MII TxD[3] */ - /* PA20 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 MII TxD[2] */ - /* PA19 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 MII TxD[1] */ - /* PA18 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 MII TxD[0] */ - /* PA17 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 MII RxD[0] */ - /* PA16 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 MII RxD[1] */ - /* PA15 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 MII RxD[2] */ - /* PA14 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 MII RxD[3] */ - /* PA13 */ { 1, 0, 0, 1, 0, 0 }, /* FCC2 MII TXSL1 */ - /* PA12 */ { 1, 0, 0, 1, 0, 1 }, /* FCC2 MII TXSL0 */ - /* PA11 */ { 1, 0, 0, 1, 0, 0 }, /* FCC1 MII TXSL1 */ - /* PA10 */ { 1, 0, 0, 1, 0, 1 }, /* FCC1 MII TXSL0 */ - /* PA9 */ { 0, 1, 0, 1, 0, 0 }, /* SMC2 TXD */ - /* PA8 */ { 0, 1, 0, 0, 0, 0 }, /* SMC2 RXD */ - /* PA7 */ { 0, 0, 0, 0, 0, 0 }, /* PA7 */ - /* PA6 */ { 1, 0, 0, 1, 0, 1 }, /* FCC2 MII PAUSE */ - /* PA5 */ { 1, 0, 0, 1, 0, 1 }, /* FCC1 MII PAUSE */ - /* PA4 */ { 1, 0, 0, 1, 0, 0 }, /* FCC2 MII PWRDN */ - /* PA3 */ { 1, 0, 0, 1, 0, 0 }, /* FCC1 MII PWRDN */ - /* PA2 */ { 0, 0, 0, 0, 0, 0 }, /* PA2 */ - /* PA1 */ { 1, 0, 0, 0, 0, 0 }, /* FCC2 MII MDINT */ - /* PA0 */ { 1, 0, 0, 1, 0, 0 } /* FCC1 MII MDINT */ - }, - - /* Port B configuration */ - { /* conf ppar psor pdir podr pdat */ - /* PB31 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TX_ER */ - /* PB30 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_DV */ - /* PB29 */ { 1, 1, 1, 1, 0, 0 }, /* FCC2 MII TX_EN */ - /* PB28 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_ER */ - /* PB27 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII COL */ - /* PB26 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII CRS */ - /* PB25 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[3] */ - /* PB24 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[2] */ - /* PB23 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[1] */ - /* PB22 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[0] */ - /* PB21 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[0] */ - /* PB20 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[1] */ - /* PB19 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[2] */ - /* PB18 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[3] */ - /* PB17 */ { 0, 0, 0, 0, 0, 0 }, /* PB17 */ - /* PB16 */ { 0, 0, 0, 0, 0, 0 }, /* PB16 */ - /* PB15 */ { 0, 0, 0, 0, 0, 0 }, /* PB15 */ - /* PB14 */ { 0, 0, 0, 0, 0, 0 }, /* PB14 */ - /* PB13 */ { 0, 0, 0, 0, 0, 0 }, /* PB13 */ - /* PB12 */ { 0, 0, 0, 0, 0, 0 }, /* PB12 */ - /* PB11 */ { 0, 0, 0, 0, 0, 0 }, /* PB11 */ - /* PB10 */ { 0, 0, 0, 0, 0, 0 }, /* PB10 */ - /* PB9 */ { 0, 0, 0, 0, 0, 0 }, /* PB9 */ - /* PB8 */ { 0, 0, 0, 0, 0, 0 }, /* PB8 */ - /* PB7 */ { 0, 0, 0, 0, 0, 0 }, /* PB7 */ - /* PB6 */ { 0, 0, 0, 0, 0, 0 }, /* PB6 */ - /* PB5 */ { 0, 0, 0, 0, 0, 0 }, /* PB5 */ - /* PB4 */ { 0, 0, 0, 0, 0, 0 }, /* PB4 */ - /* PB3 */ { 0, 0, 0, 0, 0, 0 }, /* PB3 */ - /* PB2 */ { 0, 0, 0, 0, 0, 0 }, /* PB2 */ - /* PB1 */ { 0, 0, 0, 0, 0, 0 }, /* PB1 */ - /* PB0 */ { 0, 0, 0, 0, 0, 0 } /* PB0 */ - }, - - /* Port C */ - { /* conf ppar psor pdir podr pdat */ - /* PC31 */ { 0, 0, 0, 0, 0, 0 }, /* PC31 */ - /* PC30 */ { 0, 0, 0, 0, 0, 0 }, /* PC30 */ - /* PC29 */ { 1, 0, 0, 0, 0, 0 }, /* SCC1 CTS */ - /* PC28 */ { 1, 0, 0, 0, 0, 0 }, /* SCC2 CTS */ - /* PC27 */ { 0, 0, 0, 0, 0, 0 }, /* PC27 */ - /* PC26 */ { 0, 0, 0, 0, 0, 0 }, /* PC26 */ - /* PC25 */ { 0, 0, 0, 0, 0, 0 }, /* PC25 */ - /* PC24 */ { 0, 0, 0, 0, 0, 0 }, /* PC24 */ - /* PC23 */ { 0, 0, 0, 0, 0, 0 }, /* FDC37C78 DACFD */ - /* PC22 */ { 0, 0, 0, 0, 0, 0 }, /* FDC37C78 DNFD */ - /* PC21 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 MII RX_CLK */ - /* PC20 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 MII TX_CLK */ - /* PC19 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_CLK */ - /* PC18 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII TX_CLK */ - /* PC17 */ { 0, 0, 0, 0, 0, 0 }, /* PC17 */ - /* PC16 */ { 0, 0, 0, 0, 0, 0 }, /* PC16 */ - /* PC15 */ { 0, 0, 0, 0, 0, 0 }, /* PC15 */ - /* PC14 */ { 0, 0, 0, 0, 0, 0 }, /* PC14 */ - /* PC13 */ { 0, 0, 0, 0, 0, 0 }, /* PC13 */ - /* PC12 */ { 0, 0, 0, 0, 0, 0 }, /* PC12 */ - /* PC11 */ { 0, 0, 0, 0, 0, 0 }, /* PC11 */ - /* PC10 */ { 0, 0, 0, 0, 0, 0 }, /* PC10 */ - /* PC9 */ { 0, 0, 0, 0, 0, 0 }, /* FC9 */ - /* PC8 */ { 0, 0, 0, 0, 0, 0 }, /* PC8 */ - /* PC7 */ { 0, 0, 0, 0, 0, 0 }, /* PC7 */ - /* PC6 */ { 0, 0, 0, 0, 0, 0 }, /* PC6 */ - /* PC5 */ { 0, 0, 0, 0, 0, 0 }, /* PC5 */ - /* PC4 */ { 0, 0, 0, 0, 0, 0 }, /* PC4 */ - /* PC3 */ { 0, 0, 0, 0, 0, 0 }, /* PC3 */ - /* PC2 */ { 0, 0, 0, 0, 0, 0 }, /* PC2 */ - /* PC1 */ { 0, 0, 0, 0, 0, 0 }, /* PC1 */ - /* PC0 */ { 0, 0, 0, 0, 0, 0 }, /* FDC37C78 DRQFD */ - }, - - /* Port D */ - { /* conf ppar psor pdir podr pdat */ - /* PD31 */ { 1, 1, 0, 0, 0, 0 }, /* SCC1 RXD */ - /* PD30 */ { 1, 1, 1, 1, 0, 0 }, /* SCC1 TXD */ - /* PD29 */ { 1, 0, 0, 1, 0, 0 }, /* SCC1 RTS */ - /* PD28 */ { 1, 1, 0, 0, 0, 0 }, /* SCC2 RXD */ - /* PD27 */ { 1, 1, 0, 1, 0, 0 }, /* SCC2 TXD */ - /* PD26 */ { 1, 0, 0, 1, 0, 0 }, /* SCC2 RTS */ - /* PD25 */ { 0, 0, 0, 0, 0, 0 }, /* PD25 */ - /* PD24 */ { 0, 0, 0, 0, 0, 0 }, /* PD24 */ - /* PD23 */ { 0, 0, 0, 0, 0, 0 }, /* PD23 */ - /* PD22 */ { 0, 0, 0, 0, 0, 0 }, /* PD22 */ - /* PD21 */ { 0, 0, 0, 0, 0, 0 }, /* PD21 */ - /* PD20 */ { 0, 0, 0, 0, 0, 0 }, /* PD20 */ - /* PD19 */ { 0, 0, 0, 0, 0, 0 }, /* PD19 */ - /* PD18 */ { 0, 0, 0, 0, 0, 0 }, /* PD18 */ - /* PD17 */ { 0, 0, 0, 0, 0, 0 }, /* PD17 */ - /* PD16 */ { 0, 0, 0, 0, 0, 0 }, /* PD16 */ -#if defined(CONFIG_SYS_I2C_SOFT) - /* PD15 */ { 1, 0, 0, 1, 1, 1 }, /* I2C SDA */ - /* PD14 */ { 1, 0, 0, 1, 1, 1 }, /* I2C SCL */ -#else -#if defined(CONFIG_HARD_I2C) - /* PD15 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SDA */ - /* PD14 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SCL */ -#else /* normal I/O port pins */ - /* PD15 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SDA */ - /* PD14 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SCL */ -#endif -#endif - /* PD13 */ { 0, 0, 0, 0, 0, 0 }, /* PD13 */ - /* PD12 */ { 0, 0, 0, 0, 0, 0 }, /* PD12 */ - /* PD11 */ { 0, 0, 0, 0, 0, 0 }, /* PD11 */ - /* PD10 */ { 0, 0, 0, 0, 0, 0 }, /* PD10 */ - /* PD9 */ { 1, 1, 0, 1, 0, 0 }, /* SMC1 TXD */ - /* PD8 */ { 1, 1, 0, 0, 0, 0 }, /* SMC1 RXD */ - /* PD7 */ { 0, 0, 0, 0, 0, 0 }, /* PD7 */ - /* PD6 */ { 0, 0, 0, 0, 0, 0 }, /* PD6 */ - /* PD5 */ { 0, 0, 0, 0, 0, 0 }, /* PD5 */ - /* PD4 */ { 0, 0, 0, 0, 0, 0 }, /* PD4 */ - /* PD3 */ { 0, 0, 0, 0, 0, 0 }, /* PD3 */ - /* PD2 */ { 0, 0, 0, 0, 0, 0 }, /* PD2 */ - /* PD1 */ { 0, 0, 0, 0, 0, 0 }, /* PD1 */ - /* PD0 */ { 0, 0, 0, 0, 0, 0 } /* PD0 */ - } -}; - -/* ------------------------------------------------------------------------- */ - -/* Check Board Identity: - */ -int checkboard (void) -{ - printf ("Board: CPU87 (Rev %02x)\n", CPU86_REV & 0x7f); - return 0; -} - -/* ------------------------------------------------------------------------- */ - -/* Try SDRAM initialization with P/LSDMR=sdmr and ORx=orx - * - * This routine performs standard 8260 initialization sequence - * and calculates the available memory size. It may be called - * several times to try different SDRAM configurations on both - * 60x and local buses. - */ -static long int try_init (volatile memctl8260_t * memctl, ulong sdmr, - ulong orx, volatile uchar * base) -{ - volatile uchar c = 0xff; - volatile uint *sdmr_ptr; - volatile uint *orx_ptr; - ulong maxsize, size; - int i; - - /* We must be able to test a location outsize the maximum legal size - * to find out THAT we are outside; but this address still has to be - * mapped by the controller. That means, that the initial mapping has - * to be (at least) twice as large as the maximum expected size. - */ - maxsize = (1 + (~orx | 0x7fff)) / 2; - - /* Since CONFIG_SYS_SDRAM_BASE is always 0 (??), we assume that - * we are configuring CS1 if base != 0 - */ - sdmr_ptr = &memctl->memc_psdmr; - orx_ptr = &memctl->memc_or2; - - *orx_ptr = orx; - - /* - * Quote from 8260 UM (10.4.2 SDRAM Power-On Initialization, 10-35): - * - * "At system reset, initialization software must set up the - * programmable parameters in the memory controller banks registers - * (ORx, BRx, P/LSDMR). After all memory parameters are configured, - * system software should execute the following initialization sequence - * for each SDRAM device. - * - * 1. Issue a PRECHARGE-ALL-BANKS command - * 2. Issue eight CBR REFRESH commands - * 3. Issue a MODE-SET command to initialize the mode register - * - * The initial commands are executed by setting P/LSDMR[OP] and - * accessing the SDRAM with a single-byte transaction." - * - * The appropriate BRx/ORx registers have already been set when we - * get here. The SDRAM can be accessed at the address CONFIG_SYS_SDRAM_BASE. - */ - - *sdmr_ptr = sdmr | PSDMR_OP_PREA; - *base = c; - - *sdmr_ptr = sdmr | PSDMR_OP_CBRR; - for (i = 0; i < 8; i++) - *base = c; - - *sdmr_ptr = sdmr | PSDMR_OP_MRW; - *(base + CONFIG_SYS_MRS_OFFS) = c; /* setting MR on address lines */ - - *sdmr_ptr = sdmr | PSDMR_OP_NORM | PSDMR_RFEN; - *base = c; - - size = get_ram_size((long *)base, maxsize); - - *orx_ptr = orx | ~(size - 1); - - return (size); -} - -phys_size_t initdram (int board_type) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8260_t *memctl = &immap->im_memctl; - -#ifndef CONFIG_SYS_RAMBOOT - ulong size8, size9, size10; -#endif - long psize; - - psize = 32 * 1024 * 1024; - - memctl->memc_mptpr = CONFIG_SYS_MPTPR; - memctl->memc_psrt = CONFIG_SYS_PSRT; - -#ifndef CONFIG_SYS_RAMBOOT - /* 60x SDRAM setup: - */ - size8 = try_init (memctl, CONFIG_SYS_PSDMR_8COL, CONFIG_SYS_OR2_8COL, - (uchar *) CONFIG_SYS_SDRAM_BASE); - - size9 = try_init (memctl, CONFIG_SYS_PSDMR_9COL, CONFIG_SYS_OR2_9COL, - (uchar *) CONFIG_SYS_SDRAM_BASE); - - size10 = try_init (memctl, CONFIG_SYS_PSDMR_10COL, CONFIG_SYS_OR2_10COL, - (uchar *) CONFIG_SYS_SDRAM_BASE); - - psize = max(size8,max(size9,size10)); - - if (psize == size8) { - psize = try_init (memctl, CONFIG_SYS_PSDMR_8COL, CONFIG_SYS_OR2_8COL, - (uchar *) CONFIG_SYS_SDRAM_BASE); - printf ("(60x:8COL) "); - } else if (psize == size9){ - psize = try_init (memctl, CONFIG_SYS_PSDMR_9COL, CONFIG_SYS_OR2_9COL, - (uchar *) CONFIG_SYS_SDRAM_BASE); - printf ("(60x:9COL) "); - } else - printf ("(60x:10COL) "); - -#endif /* CONFIG_SYS_RAMBOOT */ - - icache_enable (); - - return (psize); -} - -#if defined(CONFIG_CMD_DOC) -void doc_init (void) -{ - doc_probe (CONFIG_SYS_DOC_BASE); -} -#endif - -#ifdef CONFIG_PCI -struct pci_controller hose; - -extern void pci_mpc8250_init(struct pci_controller *); - -void pci_init_board(void) -{ - pci_mpc8250_init(&hose); -} -#endif - -int board_eth_init(bd_t *bis) -{ - return pci_eth_init(bis); -} diff --git a/board/cpu87/cpu87.h b/board/cpu87/cpu87.h deleted file mode 100644 index 45cb853..0000000 --- a/board/cpu87/cpu87.h +++ /dev/null @@ -1,27 +0,0 @@ -#ifndef __BOARD_CPU87__ -#define __BOARD_CPU87__ - -#include <config.h> - -#define REG8(x) (*(volatile unsigned char *)(x)) - -/* CPU86 register definitions */ -#define CPU86_VME_EAC REG8(CONFIG_SYS_BCRS_BASE + 0x00) -#define CPU86_VME_SAC REG8(CONFIG_SYS_BCRS_BASE + 0x01) -#define CPU86_VME_MAC REG8(CONFIG_SYS_BCRS_BASE + 0x02) -#define CPU86_BCR REG8(CONFIG_SYS_BCRS_BASE + 0x03) -#define CPU86_BSR REG8(CONFIG_SYS_BCRS_BASE + 0x04) -#define CPU86_WDOG_RPORT REG8(CONFIG_SYS_BCRS_BASE + 0x05) -#define CPU86_MBOX_IRQ REG8(CONFIG_SYS_BCRS_BASE + 0x04) -#define CPU86_REV REG8(CONFIG_SYS_BCRS_BASE + 0x07) -#define CPU86_VME_IRQMASK REG8(CONFIG_SYS_BCRS_BASE + 0x80) -#define CPU86_VME_IRQSTATUS REG8(CONFIG_SYS_BCRS_BASE + 0x81) -#define CPU86_LOCAL_IRQMASK REG8(CONFIG_SYS_BCRS_BASE + 0x82) -#define CPU86_LOCAL_IRQSTATUS REG8(CONFIG_SYS_BCRS_BASE + 0x83) -#define CPU86_PMCL_IRQSTATUS REG8(CONFIG_SYS_BCRS_BASE + 0x84) - -/* Board Control Register bits */ -#define CPU86_BCR_FWPT 0x01 -#define CPU86_BCR_FWRE 0x02 - -#endif /* __BOARD_CPU87__ */ diff --git a/board/cpu87/flash.c b/board/cpu87/flash.c deleted file mode 100644 index 96ba7d9..0000000 --- a/board/cpu87/flash.c +++ /dev/null @@ -1,608 +0,0 @@ -/* - * (C) Copyright 2001-2005 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * Flash Routines for Intel devices - * - *-------------------------------------------------------------------- - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc8xx.h> -#include "cpu87.h" - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; - -/*----------------------------------------------------------------------- - */ -ulong flash_int_get_size (volatile unsigned long *baseaddr, - flash_info_t * info) -{ - short i; - unsigned long flashtest_h, flashtest_l; - - info->sector_count = info->size = 0; - info->flash_id = FLASH_UNKNOWN; - - /* Write identify command sequence and test FLASH answer - */ - baseaddr[0] = 0x00900090; - baseaddr[1] = 0x00900090; - - flashtest_h = baseaddr[0]; /* manufacturer ID */ - flashtest_l = baseaddr[1]; - - if (flashtest_h != INTEL_MANUFACT || flashtest_l != INTEL_MANUFACT) - return (0); /* no or unknown flash */ - - flashtest_h = baseaddr[2]; /* device ID */ - flashtest_l = baseaddr[3]; - - if (flashtest_h != flashtest_l) - return (0); - - switch (flashtest_h) { - case INTEL_ID_28F160C3B: - info->flash_id = FLASH_28F160C3B; - info->sector_count = 39; - info->size = 0x00800000; /* 4 * 2 MB = 8 MB */ - break; - case INTEL_ID_28F160F3B: - info->flash_id = FLASH_28F160F3B; - info->sector_count = 39; - info->size = 0x00800000; /* 4 * 2 MB = 8 MB */ - break; - case INTEL_ID_28F640C3B: - info->flash_id = FLASH_28F640C3B; - info->sector_count = 135; - info->size = 0x02000000; /* 16 * 2 MB = 32 MB */ - break; - default: - return (0); /* no or unknown flash */ - } - - info->flash_id |= INTEL_MANUFACT << 16; /* set manufacturer offset */ - - if (info->flash_id & FLASH_BTYPE) { - volatile unsigned long *tmp = baseaddr; - - /* set up sector start adress table (bottom sector type) - * AND unlock the sectors (if our chip is 160C3) - */ - for (i = 0; i < info->sector_count; i++) { - if (((info->flash_id & FLASH_TYPEMASK) == FLASH_28F160C3B) || - ((info->flash_id & FLASH_TYPEMASK) == FLASH_28F640C3B)) { - tmp[0] = 0x00600060; - tmp[1] = 0x00600060; - tmp[0] = 0x00D000D0; - tmp[1] = 0x00D000D0; - } - info->start[i] = (uint) tmp; - tmp += i < 8 ? 0x2000 : 0x10000; /* pointer arith */ - } - } - - memset (info->protect, 0, info->sector_count); - - baseaddr[0] = 0x00FF00FF; - baseaddr[1] = 0x00FF00FF; - - return (info->size); -} - -static ulong flash_amd_get_size (vu_char *addr, flash_info_t *info) -{ - short i; - uchar vendor, devid; - ulong base = (ulong)addr; - - /* Write auto select command: read Manufacturer ID */ - addr[0x0555] = 0xAA; - addr[0x02AA] = 0x55; - addr[0x0555] = 0x90; - - udelay(1000); - - vendor = addr[0]; - devid = addr[1] & 0xff; - - /* only support AMD */ - if (vendor != 0x01) { - return 0; - } - - vendor &= 0xf; - devid &= 0xff; - - if (devid == AMD_ID_F040B) { - info->flash_id = vendor << 16 | devid; - info->sector_count = 8; - info->size = info->sector_count * 0x10000; - } - else if (devid == AMD_ID_F080B) { - info->flash_id = vendor << 16 | devid; - info->sector_count = 16; - info->size = 4 * info->sector_count * 0x10000; - } - else if (devid == AMD_ID_F016D) { - info->flash_id = vendor << 16 | devid; - info->sector_count = 32; - info->size = 4 * info->sector_count * 0x10000; - } - else { - printf ("## Unknown Flash Type: %02x\n", devid); - return 0; - } - - /* check for protected sectors */ - for (i = 0; i < info->sector_count; i++) { - /* sector base address */ - info->start[i] = base + i * (info->size / info->sector_count); - /* read sector protection at sector address, (A7 .. A0) = 0x02 */ - /* D0 = 1 if protected */ - addr = (volatile unsigned char *)(info->start[i]); - info->protect[i] = addr[2] & 1; - } - - /* - * Prevent writes to uninitialized FLASH. - */ - if (info->flash_id != FLASH_UNKNOWN) { - addr = (vu_char *)info->start[0]; - addr[0] = 0xF0; /* reset bank */ - } - - return (info->size); -} - - -/*----------------------------------------------------------------------- - */ -unsigned long flash_init (void) -{ - unsigned long size_b0 = 0; - unsigned long size_b1 = 0; - int i; - - /* Init: no FLASHes known - */ - for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - } - - /* Disable flash protection */ - CPU86_BCR |= (CPU86_BCR_FWPT | CPU86_BCR_FWRE); - - /* Static FLASH Bank configuration here (only one bank) */ - - size_b0 = flash_int_get_size ((ulong *) CONFIG_SYS_FLASH_BASE, &flash_info[0]); - size_b1 = flash_amd_get_size ((uchar *) CONFIG_SYS_BOOTROM_BASE, &flash_info[1]); - - if (size_b0 > 0 || size_b1 > 0) { - - printf("("); - - if (size_b0 > 0) { - puts ("Bank#1 - "); - print_size (size_b0, (size_b1 > 0) ? ", " : ") "); - } - - if (size_b1 > 0) { - puts ("Bank#2 - "); - print_size (size_b1, ") "); - } - } - else { - printf ("## No FLASH found.\n"); - return 0; - } - /* protect monitor and environment sectors - */ - -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_BOOTROM_BASE - if (size_b1) { - /* If U-Boot is booted from ROM the CONFIG_SYS_MONITOR_BASE > CONFIG_SYS_FLASH_BASE - * but we shouldn't protect it. - */ - - flash_protect (FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE + monitor_flash_len - 1, &flash_info[1] - ); - } -#else -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE - flash_protect (FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE + monitor_flash_len - 1, &flash_info[0] - ); -#endif -#endif - -#if defined(CONFIG_ENV_IS_IN_FLASH) && defined(CONFIG_ENV_ADDR) -# ifndef CONFIG_ENV_SIZE -# define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -# endif -# if CONFIG_ENV_ADDR >= CONFIG_SYS_BOOTROM_BASE - if (size_b1) { - flash_protect (FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR + CONFIG_ENV_SIZE - 1, &flash_info[1]); - } -# else - flash_protect (FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR + CONFIG_ENV_SIZE - 1, &flash_info[0]); -# endif -#endif - - return (size_b0 + size_b1); -} - -/*----------------------------------------------------------------------- - */ -void flash_print_info (flash_info_t * info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch ((info->flash_id >> 16) & 0xff) { - case 0x89: - printf ("INTEL "); - break; - case 0x1: - printf ("AMD "); - break; - default: - printf ("Unknown Vendor "); - break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_28F160C3B: - printf ("28F160C3B (16 Mbit, bottom sector)\n"); - break; - case FLASH_28F160F3B: - printf ("28F160F3B (16 Mbit, bottom sector)\n"); - break; - case FLASH_28F640C3B: - printf ("28F640C3B (64 M, bottom sector)\n"); - break; - case AMD_ID_F040B: - printf ("AM29F040B (4 Mbit)\n"); - break; - default: - printf ("Unknown Chip Type\n"); - break; - } - - if (info->size < 0x100000) - printf (" Size: %ld KB in %d Sectors\n", - info->size >> 10, info->sector_count); - else - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); - - printf (" Sector Start Addresses:"); - for (i = 0; i < info->sector_count; ++i) { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", - info->start[i], - info->protect[i] ? " (RO)" : " " - ); - } - printf ("\n"); -} - -/*----------------------------------------------------------------------- - */ -int flash_erase (flash_info_t * info, int s_first, int s_last) -{ - vu_char *addr = (vu_char *)(info->start[0]); - int flag, prot, sect, l_sect; - ulong start, now, last; - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - prot = 0; - for (sect = s_first; sect <= s_last; sect++) { - if (info->protect[sect]) - prot++; - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - printf ("\n"); - } - - /* Check the type of erased flash - */ - if (info->flash_id >> 16 == 0x1) { - /* Erase AMD flash - */ - l_sect = -1; - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - addr[0x0555] = 0xAA; - addr[0x02AA] = 0x55; - addr[0x0555] = 0x80; - addr[0x0555] = 0xAA; - addr[0x02AA] = 0x55; - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - - /* Start erase on unprotected sectors */ - for (sect = s_first; sect<=s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - addr = (vu_char *)(info->start[sect]); - addr[0] = 0x30; - l_sect = sect; - } - } - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - - /* - * We wait for the last triggered sector - */ - if (l_sect < 0) - goto AMD_DONE; - - start = get_timer (0); - last = start; - addr = (vu_char *)(info->start[l_sect]); - while ((addr[0] & 0x80) != 0x80) { - if ((now = get_timer(start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - return 1; - } - /* show that we're waiting */ - if ((now - last) > 1000) { /* every second */ - serial_putc ('.'); - last = now; - } - } - -AMD_DONE: - /* reset to read mode */ - addr = (volatile unsigned char *)info->start[0]; - addr[0] = 0xF0; /* reset bank */ - - } else { - /* Erase Intel flash - */ - - /* Start erase on unprotected sectors - */ - for (sect = s_first; sect <= s_last; sect++) { - volatile ulong *addr = - (volatile unsigned long *) info->start[sect]; - - start = get_timer (0); - last = start; - if (info->protect[sect] == 0) { - /* Disable interrupts which might cause a timeout here - */ - flag = disable_interrupts (); - - /* Erase the block - */ - addr[0] = 0x00200020; - addr[1] = 0x00200020; - addr[0] = 0x00D000D0; - addr[1] = 0x00D000D0; - - /* re-enable interrupts if necessary - */ - if (flag) - enable_interrupts (); - - /* wait at least 80us - let's wait 1 ms - */ - udelay (1000); - - last = start; - while ((addr[0] & 0x00800080) != 0x00800080 || - (addr[1] & 0x00800080) != 0x00800080) { - if ((now = get_timer (start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout (erase suspended!)\n"); - /* Suspend erase - */ - addr[0] = 0x00B000B0; - addr[1] = 0x00B000B0; - goto DONE; - } - /* show that we're waiting - */ - if ((now - last) > 1000) { /* every second */ - serial_putc ('.'); - last = now; - } - } - if (addr[0] & 0x00220022 || addr[1] & 0x00220022) { - printf ("*** ERROR: erase failed!\n"); - goto DONE; - } - } - /* Clear status register and reset to read mode - */ - addr[0] = 0x00500050; - addr[1] = 0x00500050; - addr[0] = 0x00FF00FF; - addr[1] = 0x00FF00FF; - } - } - - printf (" done\n"); - -DONE: - return 0; -} - -static int write_word (flash_info_t *, volatile unsigned long *, ulong); -static int write_byte (flash_info_t *info, ulong dest, uchar data); - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) -{ - ulong v; - int i, l, rc, cc = cnt, res = 0; - - if (info->flash_id >> 16 == 0x1) { - - /* Write to AMD 8-bit flash - */ - while (cnt > 0) { - if ((rc = write_byte(info, addr, *src)) != 0) { - return (rc); - } - addr++; - src++; - cnt--; - } - - return (0); - } else { - - /* Write to Intel 64-bit flash - */ - for (v=0; cc > 0; addr += 4, cc -= 4 - l) { - l = (addr & 3); - addr &= ~3; - - for (i = 0; i < 4; i++) { - v = (v << 8) + (i < l || i - l >= cc ? - *((unsigned char *) addr + i) : *src++); - } - - if ((res = write_word (info, (volatile unsigned long *) addr, v)) != 0) - break; - } - } - - return (res); -} - -/*----------------------------------------------------------------------- - * Write a word to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_word (flash_info_t * info, volatile unsigned long *addr, - ulong data) -{ - int flag, res = 0; - ulong start; - - /* Check if Flash is (sufficiently) erased - */ - if ((*addr & data) != data) - return (2); - - /* Disable interrupts which might cause a timeout here - */ - flag = disable_interrupts (); - - *addr = 0x00400040; - *addr = data; - - /* re-enable interrupts if necessary - */ - if (flag) - enable_interrupts (); - - start = get_timer (0); - while ((*addr & 0x00800080) != 0x00800080) { - if (get_timer (start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - /* Suspend program - */ - *addr = 0x00B000B0; - res = 1; - goto OUT; - } - } - - if (*addr & 0x00220022) { - printf ("*** ERROR: program failed!\n"); - res = 1; - } - -OUT: - /* Clear status register and reset to read mode - */ - *addr = 0x00500050; - *addr = 0x00FF00FF; - - return (res); -} - -/*----------------------------------------------------------------------- - * Write a byte to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_byte (flash_info_t *info, ulong dest, uchar data) -{ - vu_char *addr = (vu_char *)(info->start[0]); - ulong start; - int flag; - - /* Check if Flash is (sufficiently) erased */ - if ((*((vu_char *)dest) & data) != data) { - return (2); - } - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - addr[0x0555] = 0xAA; - addr[0x02AA] = 0x55; - addr[0x0555] = 0xA0; - - *((vu_char *)dest) = data; - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* data polling for D7 */ - start = get_timer (0); - while ((*((vu_char *)dest) & 0x80) != (data & 0x80)) { - if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - return (1); - } - } - return (0); -} - -/*----------------------------------------------------------------------- - */ diff --git a/configs/CPU86_ROMBOOT_defconfig b/configs/CPU86_ROMBOOT_defconfig deleted file mode 100644 index 41aa7df..0000000 --- a/configs/CPU86_ROMBOOT_defconfig +++ /dev/null @@ -1,4 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="BOOT_ROM" -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_CPU86=y diff --git a/configs/CPU86_defconfig b/configs/CPU86_defconfig deleted file mode 100644 index f0a4049..0000000 --- a/configs/CPU86_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_CPU86=y diff --git a/configs/CPU87_ROMBOOT_defconfig b/configs/CPU87_ROMBOOT_defconfig deleted file mode 100644 index ba13b40..0000000 --- a/configs/CPU87_ROMBOOT_defconfig +++ /dev/null @@ -1,4 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="BOOT_ROM" -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_CPU87=y diff --git a/configs/CPU87_defconfig b/configs/CPU87_defconfig deleted file mode 100644 index 86a5737..0000000 --- a/configs/CPU87_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_CPU87=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 400eea1..c0d0cd9 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,8 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +CPU86 powerpc mpc8260 - - Wolfgang Denk wd@denx.de +CPU87 powerpc mpc8260 - - ep82xxm powerpc mpc8260 - - gw8260 powerpc mpc8260 - - Oliver Brown obrown@adventnetworks.com IPHASE4539 powerpc mpc8260 - - Wolfgang Grandegger wg@denx.de diff --git a/include/configs/CPU86.h b/include/configs/CPU86.h deleted file mode 100644 index 7be83b0..0000000 --- a/include/configs/CPU86.h +++ /dev/null @@ -1,629 +0,0 @@ -/* - * (C) Copyright 2001-2005 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_CPU86 1 /* ...on a CPU86 board */ -#define CONFIG_CPM2 1 /* Has a CPM2 */ - -#ifdef CONFIG_BOOT_ROM -#define CONFIG_SYS_TEXT_BASE 0xFF800000 -#else -#define CONFIG_SYS_TEXT_BASE 0xFF000000 -#endif - -/* - * select serial console configuration - * - * if either CONFIG_CONS_ON_SMC or CONFIG_CONS_ON_SCC is selected, then - * CONFIG_CONS_INDEX must be set to the channel number (1-2 for SMC, 1-4 - * for SCC). - * - * if CONFIG_CONS_NONE is defined, then the serial console routines must - * defined elsewhere (for example, on the cogent platform, there are serial - * ports on the motherboard which are used for the serial console - see - * cogent/cma101/serial.[ch]). - */ -#undef CONFIG_CONS_ON_SMC /* define if console on SMC */ -#define CONFIG_CONS_ON_SCC /* define if console on SCC */ -#undef CONFIG_CONS_NONE /* define if console on something else*/ -#define CONFIG_CONS_INDEX 1 /* which serial channel for console */ - -#if defined(CONFIG_CONS_NONE) || defined(CONFIG_CONS_USE_EXTC) -#define CONFIG_BAUDRATE 230400 -#else -#define CONFIG_BAUDRATE 9600 -#endif - -/* - * select ethernet configuration - * - * if either CONFIG_ETHER_ON_SCC or CONFIG_ETHER_ON_FCC is selected, then - * CONFIG_ETHER_INDEX must be set to the channel number (1-4 for SCC, 1-3 - * for FCC) - * - * if CONFIG_ETHER_NONE is defined, then either the ethernet routines must be - * defined elsewhere (as for the console), or CONFIG_CMD_NET must be unset. - */ -#undef CONFIG_ETHER_ON_SCC /* define if ether on SCC */ -#define CONFIG_ETHER_ON_FCC /* define if ether on FCC */ -#undef CONFIG_ETHER_NONE /* define if ether on something else */ -#define CONFIG_ETHER_INDEX 1 /* which SCC/FCC channel for ethernet */ - -#if defined(CONFIG_ETHER_ON_FCC) && (CONFIG_ETHER_INDEX == 1) - -/* - * - Rx-CLK is CLK11 - * - Tx-CLK is CLK12 - * - RAM for BD/Buffers is on the 60x Bus (see 28-13) - * - Enable Full Duplex in FSMR - */ -# define CONFIG_SYS_CMXFCR_MASK1 (CMXFCR_FC1|CMXFCR_RF1CS_MSK|CMXFCR_TF1CS_MSK) -# define CONFIG_SYS_CMXFCR_VALUE1 (CMXFCR_RF1CS_CLK11|CMXFCR_TF1CS_CLK12) -# define CONFIG_SYS_CPMFCR_RAMTYPE 0 -# define CONFIG_SYS_FCC_PSMR (FCC_PSMR_FDE|FCC_PSMR_LPB) - -#elif defined(CONFIG_ETHER_ON_FCC) && (CONFIG_ETHER_INDEX == 2) - -/* - * - Rx-CLK is CLK13 - * - Tx-CLK is CLK14 - * - RAM for BD/Buffers is on the 60x Bus (see 28-13) - * - Enable Full Duplex in FSMR - */ -# define CONFIG_SYS_CMXFCR_MASK2 (CMXFCR_FC2|CMXFCR_RF2CS_MSK|CMXFCR_TF2CS_MSK) -# define CONFIG_SYS_CMXFCR_VALUE2 (CMXFCR_RF2CS_CLK13|CMXFCR_TF2CS_CLK14) -# define CONFIG_SYS_CPMFCR_RAMTYPE 0 -# define CONFIG_SYS_FCC_PSMR (FCC_PSMR_FDE|FCC_PSMR_LPB) - -#endif /* CONFIG_ETHER_ON_FCC, CONFIG_ETHER_INDEX */ - -/* system clock rate (CLKIN) - equal to the 60x and local bus speed */ -#define CONFIG_8260_CLKIN 64000000 /* in Hz */ - -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ - -#define CONFIG_PREBOOT \ - "echo; " \ - "echo Type \"run flash_nfs\" to mount root filesystem over NFS; " \ - "echo" - -#undef CONFIG_BOOTARGS -#define CONFIG_BOOTCOMMAND \ - "bootp; " \ - "setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off; " \ - "bootm" - -/*----------------------------------------------------------------------- - * I2C/EEPROM/RTC configuration - */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_SOFT /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SOFT_SPEED 50000 -#define CONFIG_SYS_I2C_SOFT_SLAVE 0xFE - -/* - * Software (bit-bang) I2C driver configuration - */ -#define I2C_PORT 3 /* Port A=0, B=1, C=2, D=3 */ -#define I2C_ACTIVE (iop->pdir |= 0x00010000) -#define I2C_TRISTATE (iop->pdir &= ~0x00010000) -#define I2C_READ ((iop->pdat & 0x00010000) != 0) -#define I2C_SDA(bit) if(bit) iop->pdat |= 0x00010000; \ - else iop->pdat &= ~0x00010000 -#define I2C_SCL(bit) if(bit) iop->pdat |= 0x00020000; \ - else iop->pdat &= ~0x00020000 -#define I2C_DELAY udelay(5) /* 1/4 I2C clock duration */ - -#define CONFIG_RTC_PCF8563 -#define CONFIG_SYS_I2C_RTC_ADDR 0x51 - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -/*----------------------------------------------------------------------- - * Miscellaneous configuration options - */ - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_BEDBUG -#define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C -#define CONFIG_CMD_NFS -#define CONFIG_CMD_SNTP - - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -#define CONFIG_SYS_RESET_ADDRESS 0xFFF00100 /* "bad" address */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * Flash configuration - */ - -#define CONFIG_SYS_BOOTROM_BASE 0xFF800000 -#define CONFIG_SYS_BOOTROM_SIZE 0x00080000 -#define CONFIG_SYS_FLASH_BASE 0xFF000000 -#define CONFIG_SYS_FLASH_SIZE 0x00800000 - -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max num of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 128 /* max num of sects on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 240000 /* Flash Erase Timeout (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (in ms) */ - -/*----------------------------------------------------------------------- - * Other areas to be mapped - */ - -/* CS3: Dual ported SRAM */ -#define CONFIG_SYS_DPSRAM_BASE 0x40000000 -#define CONFIG_SYS_DPSRAM_SIZE 0x00020000 - -/* CS4: DiskOnChip */ -#define CONFIG_SYS_DOC_BASE 0xF4000000 -#define CONFIG_SYS_DOC_SIZE 0x00100000 - -/* CS5: FDC37C78 controller */ -#define CONFIG_SYS_FDC37C78_BASE 0xF1000000 -#define CONFIG_SYS_FDC37C78_SIZE 0x00100000 - -/* CS6: Board configuration registers */ -#define CONFIG_SYS_BCRS_BASE 0xF2000000 -#define CONFIG_SYS_BCRS_SIZE 0x00010000 - -/* CS7: VME Extended Access Range */ -#define CONFIG_SYS_VMEEAR_BASE 0x80000000 -#define CONFIG_SYS_VMEEAR_SIZE 0x01000000 - -/* CS8: VME Standard Access Range */ -#define CONFIG_SYS_VMESAR_BASE 0xFE000000 -#define CONFIG_SYS_VMESAR_SIZE 0x01000000 - -/* CS9: VME Short I/O Access Range */ -#define CONFIG_SYS_VMESIOAR_BASE 0xFD000000 -#define CONFIG_SYS_VMESIOAR_SIZE 0x01000000 - -/*----------------------------------------------------------------------- - * Hard Reset Configuration Words - * - * if you change bits in the HRCW, you must also change the CONFIG_SYS_* - * defines for the various registers affected by the HRCW e.g. changing - * HRCW_DPPCxx requires you to also change CONFIG_SYS_SIUMCR. - */ -#if defined(CONFIG_BOOT_ROM) -#define CONFIG_SYS_HRCW_MASTER (HRCW_CIP | HRCW_ISB100 | HRCW_BMS | \ - HRCW_BPS01 | HRCW_CS10PC01) -#else -#define CONFIG_SYS_HRCW_MASTER (HRCW_CIP | HRCW_ISB100 | HRCW_BMS | HRCW_CS10PC01) -#endif - -/* no slaves so just fill with zeros */ -#define CONFIG_SYS_HRCW_SLAVE1 0 -#define CONFIG_SYS_HRCW_SLAVE2 0 -#define CONFIG_SYS_HRCW_SLAVE3 0 -#define CONFIG_SYS_HRCW_SLAVE4 0 -#define CONFIG_SYS_HRCW_SLAVE5 0 -#define CONFIG_SYS_HRCW_SLAVE6 0 -#define CONFIG_SYS_HRCW_SLAVE7 0 - -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xF0000000 - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - * - * 60x SDRAM is mapped at CONFIG_SYS_SDRAM_BASE. - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_SDRAM_MAX_SIZE 0x08000000 /* max. 128 MB */ -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc()*/ - -#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) -# define CONFIG_SYS_RAMBOOT -#endif - -#if 0 -/* environment is in Flash */ -#define CONFIG_ENV_IS_IN_FLASH 1 -#ifdef CONFIG_BOOT_ROM -# define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE+0x70000) -# define CONFIG_ENV_SIZE 0x10000 -# define CONFIG_ENV_SECT_SIZE 0x10000 -#endif -#else -/* environment is in EEPROM */ -#define CONFIG_ENV_IS_IN_EEPROM 1 -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x58 /* EEPROM X24C16 */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 -/* mask of address bits that overflow into the "EEPROM chip address" */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW 0x07 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CONFIG_ENV_OFFSET 512 -#define CONFIG_ENV_SIZE (2048 - 512) -#endif - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC8260 CPU */ -#if defined(CONFIG_CMD_KGDB) -# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * HIDx - Hardware Implementation-dependent Registers 2-11 - *----------------------------------------------------------------------- - * HID0 also contains cache control - initially enable both caches and - * invalidate contents, then the final state leaves only the instruction - * cache enabled. Note that Power-On and Hard reset invalidate the caches, - * but Soft reset does not. - * - * HID1 has only read-only information - nothing to set. - */ -#define CONFIG_SYS_HID0_INIT (HID0_ICE|HID0_DCE|HID0_ICFI|\ - HID0_DCI|HID0_IFEM|HID0_ABE) -#define CONFIG_SYS_HID0_FINAL (HID0_IFEM|HID0_ABE) -#define CONFIG_SYS_HID2 0 - -/*----------------------------------------------------------------------- - * RMR - Reset Mode Register 5-5 - *----------------------------------------------------------------------- - * turn on Checkstop Reset Enable - */ -#define CONFIG_SYS_RMR RMR_CSRE - -/*----------------------------------------------------------------------- - * BCR - Bus Configuration 4-25 - *----------------------------------------------------------------------- - */ -#define BCR_APD01 0x10000000 -#define CONFIG_SYS_BCR (BCR_APD01|BCR_ETM|BCR_LETM) /* 8260 mode */ - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 4-31 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_SIUMCR (SIUMCR_BBD|SIUMCR_DPPC00|SIUMCR_APPC10|\ - SIUMCR_CS10PC01|SIUMCR_BCTLC10) - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 4-35 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Watchdog & Bus Monitor Timer max, 60x Bus Monitor enable - */ -#if defined(CONFIG_WATCHDOG) -#define CONFIG_SYS_SYPCR (SYPCR_SWTC|SYPCR_BMT|SYPCR_PBME|SYPCR_LBME|\ - SYPCR_SWRI|SYPCR_SWP|SYPCR_SWE) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC|SYPCR_BMT|SYPCR_PBME|SYPCR_LBME|\ - SYPCR_SWRI|SYPCR_SWP) -#endif /* CONFIG_WATCHDOG */ - -/*----------------------------------------------------------------------- - * TMCNTSC - Time Counter Status and Control 4-40 - *----------------------------------------------------------------------- - * Clear once per Second and Alarm Interrupt Status, Set 32KHz timersclk, - * and enable Time Counter - */ -#define CONFIG_SYS_TMCNTSC (TMCNTSC_SEC|TMCNTSC_ALR|TMCNTSC_TCF|TMCNTSC_TCE) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 4-42 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Set 32KHz timersclk, and enable - * Periodic timer - */ -#define CONFIG_SYS_PISCR (PISCR_PS|PISCR_PTF|PISCR_PTE) - -/*----------------------------------------------------------------------- - * SCCR - System Clock Control 9-8 - *----------------------------------------------------------------------- - * Ensure DFBRG is Divide by 16 - */ -#define CONFIG_SYS_SCCR SCCR_DFBRG01 - -/*----------------------------------------------------------------------- - * RCCR - RISC Controller Configuration 13-7 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RCCR 0 - -#define CONFIG_SYS_MIN_AM_MASK 0xC0000000 -/*----------------------------------------------------------------------- - * MPTPR - Memory Refresh Timer Prescaler Register 10-18 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_MPTPR 0x1F00 - -/*----------------------------------------------------------------------- - * PSRT - Refresh Timer Register 10-16 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_PSRT 0x0f - -/*----------------------------------------------------------------------- - * PSRT - SDRAM Mode Register 10-10 - *----------------------------------------------------------------------- - */ - - /* SDRAM initialization values for 8-column chips - */ -#define CONFIG_SYS_OR2_8COL (CONFIG_SYS_MIN_AM_MASK |\ - ORxS_BPD_4 |\ - ORxS_ROWST_PBI0_A9 |\ - ORxS_NUMR_12) - -#define CONFIG_SYS_PSDMR_8COL (PSDMR_SDAM_A13_IS_A5 |\ - PSDMR_BSMA_A14_A16 |\ - PSDMR_SDA10_PBI0_A10 |\ - PSDMR_RFRC_7_CLK |\ - PSDMR_PRETOACT_2W |\ - PSDMR_ACTTORW_1W |\ - PSDMR_LDOTOPRE_1C |\ - PSDMR_WRC_1C |\ - PSDMR_CL_2) - - /* SDRAM initialization values for 9-column chips - */ -#define CONFIG_SYS_OR2_9COL (CONFIG_SYS_MIN_AM_MASK |\ - ORxS_BPD_4 |\ - ORxS_ROWST_PBI0_A7 |\ - ORxS_NUMR_13) - -#define CONFIG_SYS_PSDMR_9COL (PSDMR_SDAM_A14_IS_A5 |\ - PSDMR_BSMA_A13_A15 |\ - PSDMR_SDA10_PBI0_A9 |\ - PSDMR_RFRC_7_CLK |\ - PSDMR_PRETOACT_2W |\ - PSDMR_ACTTORW_1W |\ - PSDMR_LDOTOPRE_1C |\ - PSDMR_WRC_1C |\ - PSDMR_CL_2) - -/* - * Init Memory Controller: - * - * Bank Bus Machine PortSz Device - * ---- --- ------- ------ ------ - * 0 60x GPCM 8 bit Boot ROM - * 1 60x GPCM 64 bit FLASH - * 2 60x SDRAM 64 bit SDRAM - * - */ - -#define CONFIG_SYS_MRS_OFFS 0x00000000 - -#ifdef CONFIG_BOOT_ROM -/* Bank 0 - Boot ROM - */ -#define CONFIG_SYS_BR0_PRELIM ((CONFIG_SYS_BOOTROM_BASE & BRx_BA_MSK)|\ - BRx_PS_8 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR0_PRELIM (P2SZ_TO_AM(CONFIG_SYS_BOOTROM_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_3_CLK |\ - ORxU_EHTR_8IDLE) - -/* Bank 1 - FLASH - */ -#define CONFIG_SYS_BR1_PRELIM ((CONFIG_SYS_FLASH_BASE & BRx_BA_MSK) |\ - BRx_PS_64 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR1_PRELIM (P2SZ_TO_AM(CONFIG_SYS_FLASH_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_3_CLK |\ - ORxU_EHTR_8IDLE) - -#else /* CONFIG_BOOT_ROM */ -/* Bank 0 - FLASH - */ -#define CONFIG_SYS_BR0_PRELIM ((CONFIG_SYS_FLASH_BASE & BRx_BA_MSK) |\ - BRx_PS_64 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR0_PRELIM (P2SZ_TO_AM(CONFIG_SYS_FLASH_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_3_CLK |\ - ORxU_EHTR_8IDLE) - -/* Bank 1 - Boot ROM - */ -#define CONFIG_SYS_BR1_PRELIM ((CONFIG_SYS_BOOTROM_BASE & BRx_BA_MSK)|\ - BRx_PS_8 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR1_PRELIM (P2SZ_TO_AM(CONFIG_SYS_BOOTROM_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_3_CLK |\ - ORxU_EHTR_8IDLE) - -#endif /* CONFIG_BOOT_ROM */ - - -/* Bank 2 - 60x bus SDRAM - */ -#ifndef CONFIG_SYS_RAMBOOT -#define CONFIG_SYS_BR2_PRELIM ((CONFIG_SYS_SDRAM_BASE & BRx_BA_MSK) |\ - BRx_PS_64 |\ - BRx_MS_SDRAM_P |\ - BRx_V) - -#define CONFIG_SYS_OR2_PRELIM CONFIG_SYS_OR2_9COL - -#define CONFIG_SYS_PSDMR CONFIG_SYS_PSDMR_9COL -#endif /* CONFIG_SYS_RAMBOOT */ - -/* Bank 3 - Dual Ported SRAM - */ -#define CONFIG_SYS_BR3_PRELIM ((CONFIG_SYS_DPSRAM_BASE & BRx_BA_MSK) |\ - BRx_PS_16 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR3_PRELIM (P2SZ_TO_AM(CONFIG_SYS_DPSRAM_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_5_CLK |\ - ORxG_SETA) - -/* Bank 4 - DiskOnChip - */ -#define CONFIG_SYS_BR4_PRELIM ((CONFIG_SYS_DOC_BASE & BRx_BA_MSK) |\ - BRx_PS_8 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR4_PRELIM (P2SZ_TO_AM(CONFIG_SYS_DOC_SIZE) |\ - ORxG_ACS_DIV2 |\ - ORxG_SCY_5_CLK |\ - ORxU_EHTR_8IDLE) - -/* Bank 5 - FDC37C78 controller - */ -#define CONFIG_SYS_BR5_PRELIM ((CONFIG_SYS_FDC37C78_BASE & BRx_BA_MSK) |\ - BRx_PS_8 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR5_PRELIM (P2SZ_TO_AM(CONFIG_SYS_FDC37C78_SIZE) |\ - ORxG_ACS_DIV2 |\ - ORxG_SCY_8_CLK |\ - ORxU_EHTR_8IDLE) - -/* Bank 6 - Board control registers - */ -#define CONFIG_SYS_BR6_PRELIM ((CONFIG_SYS_BCRS_BASE & BRx_BA_MSK) |\ - BRx_PS_8 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR6_PRELIM (P2SZ_TO_AM(CONFIG_SYS_BCRS_SIZE) |\ - ORxG_CSNT |\ - ORxG_SCY_5_CLK) - -/* Bank 7 - VME Extended Access Range - */ -#define CONFIG_SYS_BR7_PRELIM ((CONFIG_SYS_VMEEAR_BASE & BRx_BA_MSK) |\ - BRx_PS_32 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR7_PRELIM (P2SZ_TO_AM(CONFIG_SYS_VMEEAR_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_5_CLK |\ - ORxG_SETA) - -/* Bank 8 - VME Standard Access Range - */ -#define CONFIG_SYS_BR8_PRELIM ((CONFIG_SYS_VMESAR_BASE & BRx_BA_MSK) |\ - BRx_PS_16 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR8_PRELIM (P2SZ_TO_AM(CONFIG_SYS_VMESAR_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_5_CLK |\ - ORxG_SETA) - -/* Bank 9 - VME Short I/O Access Range - */ -#define CONFIG_SYS_BR9_PRELIM ((CONFIG_SYS_VMESIOAR_BASE & BRx_BA_MSK) |\ - BRx_PS_16 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR9_PRELIM (P2SZ_TO_AM(CONFIG_SYS_VMESIOAR_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_5_CLK |\ - ORxG_SETA) - -#endif /* __CONFIG_H */ diff --git a/include/configs/CPU87.h b/include/configs/CPU87.h deleted file mode 100644 index d3a59e8..0000000 --- a/include/configs/CPU87.h +++ /dev/null @@ -1,676 +0,0 @@ -/* - * (C) Copyright 2001-2005 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_CPU87 1 /* ...on a CPU87 board */ -#define CONFIG_PCI -#define CONFIG_CPM2 1 /* Has a CPM2 */ - -#ifdef CONFIG_BOOT_ROM -#define CONFIG_SYS_TEXT_BASE 0xFF800000 -#else -#define CONFIG_SYS_TEXT_BASE 0xFF000000 -#endif - -/* - * select serial console configuration - * - * if either CONFIG_CONS_ON_SMC or CONFIG_CONS_ON_SCC is selected, then - * CONFIG_CONS_INDEX must be set to the channel number (1-2 for SMC, 1-4 - * for SCC). - * - * if CONFIG_CONS_NONE is defined, then the serial console routines must - * defined elsewhere (for example, on the cogent platform, there are serial - * ports on the motherboard which are used for the serial console - see - * cogent/cma101/serial.[ch]). - */ -#undef CONFIG_CONS_ON_SMC /* define if console on SMC */ -#define CONFIG_CONS_ON_SCC /* define if console on SCC */ -#undef CONFIG_CONS_NONE /* define if console on something else*/ -#define CONFIG_CONS_INDEX 1 /* which serial channel for console */ - -#if defined(CONFIG_CONS_NONE) || defined(CONFIG_CONS_USE_EXTC) -#define CONFIG_BAUDRATE 230400 -#else -#define CONFIG_BAUDRATE 9600 -#endif - -/* - * select ethernet configuration - * - * if either CONFIG_ETHER_ON_SCC or CONFIG_ETHER_ON_FCC is selected, then - * CONFIG_ETHER_INDEX must be set to the channel number (1-4 for SCC, 1-3 - * for FCC) - * - * if CONFIG_ETHER_NONE is defined, then either the ethernet routines must be - * defined elsewhere (as for the console), or CONFIG_CMD_NET must be unset. - */ -#undef CONFIG_ETHER_ON_SCC /* define if ether on SCC */ -#define CONFIG_ETHER_ON_FCC /* define if ether on FCC */ -#undef CONFIG_ETHER_NONE /* define if ether on something else */ -#define CONFIG_ETHER_INDEX 1 /* which SCC/FCC channel for ethernet */ - -#define CONFIG_HAS_ETH1 1 -#define CONFIG_HAS_ETH2 1 - -#if defined(CONFIG_ETHER_ON_FCC) && (CONFIG_ETHER_INDEX == 1) - -/* - * - Rx-CLK is CLK11 - * - Tx-CLK is CLK12 - * - RAM for BD/Buffers is on the 60x Bus (see 28-13) - * - Enable Full Duplex in FSMR - */ -# define CONFIG_SYS_CMXFCR_MASK1 (CMXFCR_FC1|CMXFCR_RF1CS_MSK|CMXFCR_TF1CS_MSK) -# define CONFIG_SYS_CMXFCR_VALUE1 (CMXFCR_RF1CS_CLK11|CMXFCR_TF1CS_CLK12) -# define CONFIG_SYS_CPMFCR_RAMTYPE 0 -# define CONFIG_SYS_FCC_PSMR (FCC_PSMR_FDE|FCC_PSMR_LPB) - -#elif defined(CONFIG_ETHER_ON_FCC) && (CONFIG_ETHER_INDEX == 2) - -/* - * - Rx-CLK is CLK13 - * - Tx-CLK is CLK14 - * - RAM for BD/Buffers is on the 60x Bus (see 28-13) - * - Enable Full Duplex in FSMR - */ -# define CONFIG_SYS_CMXFCR_MASK2 (CMXFCR_FC2|CMXFCR_RF2CS_MSK|CMXFCR_TF2CS_MSK) -# define CONFIG_SYS_CMXFCR_VALUE2 (CMXFCR_RF2CS_CLK13|CMXFCR_TF2CS_CLK14) -# define CONFIG_SYS_CPMFCR_RAMTYPE 0 -# define CONFIG_SYS_FCC_PSMR (FCC_PSMR_FDE|FCC_PSMR_LPB) - -#endif /* CONFIG_ETHER_ON_FCC, CONFIG_ETHER_INDEX */ - -/* system clock rate (CLKIN) - equal to the 60x and local bus speed */ -#define CONFIG_8260_CLKIN 100000000 /* in Hz */ - -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ - -#define CONFIG_PREBOOT \ - "echo; " \ - "echo Type \"run flash_nfs\" to mount root filesystem over NFS; " \ - "echo" - -#undef CONFIG_BOOTARGS -#define CONFIG_BOOTCOMMAND \ - "bootp; " \ - "setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off; " \ - "bootm" - -/*----------------------------------------------------------------------- - * I2C/EEPROM/RTC configuration - */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_SOFT /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SOFT_SPEED 50000 -#define CONFIG_SYS_I2C_SOFT_SLAVE 0xFE - -/* - * Software (bit-bang) I2C driver configuration - */ -#define I2C_PORT 3 /* Port A=0, B=1, C=2, D=3 */ -#define I2C_ACTIVE (iop->pdir |= 0x00010000) -#define I2C_TRISTATE (iop->pdir &= ~0x00010000) -#define I2C_READ ((iop->pdat & 0x00010000) != 0) -#define I2C_SDA(bit) if(bit) iop->pdat |= 0x00010000; \ - else iop->pdat &= ~0x00010000 -#define I2C_SCL(bit) if(bit) iop->pdat |= 0x00020000; \ - else iop->pdat &= ~0x00020000 -#define I2C_DELAY udelay(5) /* 1/4 I2C clock duration */ - -#define CONFIG_RTC_PCF8563 -#define CONFIG_SYS_I2C_RTC_ADDR 0x51 - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -/*----------------------------------------------------------------------- - * Disk-On-Chip configuration - */ - -#define CONFIG_SYS_MAX_DOC_DEVICE 1 /* Max number of DOC devices */ - -#define CONFIG_SYS_DOC_SUPPORT_2000 -#define CONFIG_SYS_DOC_SUPPORT_MILLENNIUM - -/*----------------------------------------------------------------------- - * Miscellaneous configuration options - */ - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_BEDBUG -#define CONFIG_CMD_DATE -#define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C - -#ifdef CONFIG_PCI -#define CONFIG_PCI_INDIRECT_BRIDGE - #define CONFIG_CMD_PCI -#endif - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -#define CONFIG_SYS_RESET_ADDRESS 0xFFF00100 /* "bad" address */ - -#define CONFIG_LOOPW - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * Flash configuration - */ - -#define CONFIG_SYS_BOOTROM_BASE 0xFF800000 -#define CONFIG_SYS_BOOTROM_SIZE 0x00080000 -#define CONFIG_SYS_FLASH_BASE 0xFF000000 -#define CONFIG_SYS_FLASH_SIZE 0x00800000 - -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max num of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 135 /* max num of sects on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 240000 /* Flash Erase Timeout (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (in ms) */ - -/*----------------------------------------------------------------------- - * Other areas to be mapped - */ - -/* CS3: Dual ported SRAM */ -#define CONFIG_SYS_DPSRAM_BASE 0x40000000 -#define CONFIG_SYS_DPSRAM_SIZE 0x00100000 - -/* CS4: DiskOnChip */ -#define CONFIG_SYS_DOC_BASE 0xF4000000 -#define CONFIG_SYS_DOC_SIZE 0x00100000 - -/* CS5: FDC37C78 controller */ -#define CONFIG_SYS_FDC37C78_BASE 0xF1000000 -#define CONFIG_SYS_FDC37C78_SIZE 0x00100000 - -/* CS6: Board configuration registers */ -#define CONFIG_SYS_BCRS_BASE 0xF2000000 -#define CONFIG_SYS_BCRS_SIZE 0x00010000 - -/* CS7: VME Extended Access Range */ -#define CONFIG_SYS_VMEEAR_BASE 0x60000000 -#define CONFIG_SYS_VMEEAR_SIZE 0x01000000 - -/* CS8: VME Standard Access Range */ -#define CONFIG_SYS_VMESAR_BASE 0xFE000000 -#define CONFIG_SYS_VMESAR_SIZE 0x01000000 - -/* CS9: VME Short I/O Access Range */ -#define CONFIG_SYS_VMESIOAR_BASE 0xFD000000 -#define CONFIG_SYS_VMESIOAR_SIZE 0x01000000 - -/*----------------------------------------------------------------------- - * Hard Reset Configuration Words - * - * if you change bits in the HRCW, you must also change the CONFIG_SYS_* - * defines for the various registers affected by the HRCW e.g. changing - * HRCW_DPPCxx requires you to also change CONFIG_SYS_SIUMCR. - */ -#if defined(CONFIG_BOOT_ROM) -#define CONFIG_SYS_HRCW_MASTER (HRCW_CIP | HRCW_ISB100 | HRCW_BMS | \ - HRCW_BPS01 | HRCW_CS10PC01) -#else -#define CONFIG_SYS_HRCW_MASTER (HRCW_CIP | HRCW_ISB100 | HRCW_BMS | HRCW_CS10PC01) -#endif - -/* no slaves so just fill with zeros */ -#define CONFIG_SYS_HRCW_SLAVE1 0 -#define CONFIG_SYS_HRCW_SLAVE2 0 -#define CONFIG_SYS_HRCW_SLAVE3 0 -#define CONFIG_SYS_HRCW_SLAVE4 0 -#define CONFIG_SYS_HRCW_SLAVE5 0 -#define CONFIG_SYS_HRCW_SLAVE6 0 -#define CONFIG_SYS_HRCW_SLAVE7 0 - -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xF0000000 - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - * - * 60x SDRAM is mapped at CONFIG_SYS_SDRAM_BASE. - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_SDRAM_MAX_SIZE 0x08000000 /* max. 128 MB */ -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc()*/ - -#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) -# define CONFIG_SYS_RAMBOOT -#endif - -#ifdef CONFIG_PCI -#define CONFIG_PCI_PNP -#define CONFIG_EEPRO100 -#define CONFIG_SYS_RX_ETH_BUFFER 8 /* use 8 rx buffer on eepro100 */ -#endif - -#if 0 -/* environment is in Flash */ -#define CONFIG_ENV_IS_IN_FLASH 1 -#ifdef CONFIG_BOOT_ROM -# define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE+0x70000) -# define CONFIG_ENV_SIZE 0x10000 -# define CONFIG_ENV_SECT_SIZE 0x10000 -#endif -#else -/* environment is in EEPROM */ -#define CONFIG_ENV_IS_IN_EEPROM 1 -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x58 /* EEPROM X24C16 */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 -/* mask of address bits that overflow into the "EEPROM chip address" */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW 0x07 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CONFIG_ENV_OFFSET 512 -#define CONFIG_ENV_SIZE (2048 - 512) -#endif - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC8260 CPU */ -#if defined(CONFIG_CMD_KGDB) -# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * HIDx - Hardware Implementation-dependent Registers 2-11 - *----------------------------------------------------------------------- - * HID0 also contains cache control - initially enable both caches and - * invalidate contents, then the final state leaves only the instruction - * cache enabled. Note that Power-On and Hard reset invalidate the caches, - * but Soft reset does not. - * - * HID1 has only read-only information - nothing to set. - */ -#define CONFIG_SYS_HID0_INIT (HID0_ICE|HID0_DCE|HID0_ICFI|\ - HID0_DCI|HID0_IFEM|HID0_ABE) -#define CONFIG_SYS_HID0_FINAL (HID0_IFEM|HID0_ABE) -#define CONFIG_SYS_HID2 0 - -/*----------------------------------------------------------------------- - * RMR - Reset Mode Register 5-5 - *----------------------------------------------------------------------- - * turn on Checkstop Reset Enable - */ -#define CONFIG_SYS_RMR RMR_CSRE - -/*----------------------------------------------------------------------- - * BCR - Bus Configuration 4-25 - *----------------------------------------------------------------------- - */ -#define BCR_APD01 0x10000000 -#define CONFIG_SYS_BCR (BCR_APD01|BCR_ETM|BCR_LETM) /* 8260 mode */ - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 4-31 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_SIUMCR (SIUMCR_BBD|SIUMCR_DPPC00|SIUMCR_APPC10|\ - SIUMCR_CS10PC01|SIUMCR_BCTLC10) - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 4-35 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Watchdog & Bus Monitor Timer max, 60x Bus Monitor enable - */ -#if defined(CONFIG_WATCHDOG) -#define CONFIG_SYS_SYPCR (SYPCR_SWTC|SYPCR_BMT|SYPCR_PBME|SYPCR_LBME|\ - SYPCR_SWRI|SYPCR_SWP|SYPCR_SWE) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC|SYPCR_BMT|SYPCR_PBME|SYPCR_LBME|\ - SYPCR_SWRI|SYPCR_SWP) -#endif /* CONFIG_WATCHDOG */ - -/*----------------------------------------------------------------------- - * TMCNTSC - Time Counter Status and Control 4-40 - *----------------------------------------------------------------------- - * Clear once per Second and Alarm Interrupt Status, Set 32KHz timersclk, - * and enable Time Counter - */ -#define CONFIG_SYS_TMCNTSC (TMCNTSC_SEC|TMCNTSC_ALR|TMCNTSC_TCF|TMCNTSC_TCE) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 4-42 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Set 32KHz timersclk, and enable - * Periodic timer - */ -#define CONFIG_SYS_PISCR (PISCR_PS|PISCR_PTF|PISCR_PTE) - -/*----------------------------------------------------------------------- - * SCCR - System Clock Control 9-8 - *----------------------------------------------------------------------- - * Ensure DFBRG is Divide by 16 - */ -#define CONFIG_SYS_SCCR SCCR_DFBRG01 - -/*----------------------------------------------------------------------- - * RCCR - RISC Controller Configuration 13-7 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RCCR 0 - -#define CONFIG_SYS_MIN_AM_MASK 0xC0000000 - -/* - * we use the same values for 32 MB, 128 MB and 256 MB SDRAM - * refresh rate = 7.68 uS (100 MHz Bus Clock) - */ - -/*----------------------------------------------------------------------- - * MPTPR - Memory Refresh Timer Prescaler Register 10-18 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_MPTPR 0x2000 - -/*----------------------------------------------------------------------- - * PSRT - Refresh Timer Register 10-16 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_PSRT 0x16 - -/*----------------------------------------------------------------------- - * PSRT - SDRAM Mode Register 10-10 - *----------------------------------------------------------------------- - */ - - /* SDRAM initialization values for 8-column chips - */ -#define CONFIG_SYS_OR2_8COL (CONFIG_SYS_MIN_AM_MASK |\ - ORxS_BPD_4 |\ - ORxS_ROWST_PBI0_A9 |\ - ORxS_NUMR_12) - -#define CONFIG_SYS_PSDMR_8COL (PSDMR_SDAM_A13_IS_A5 |\ - PSDMR_BSMA_A14_A16 |\ - PSDMR_SDA10_PBI0_A10 |\ - PSDMR_RFRC_7_CLK |\ - PSDMR_PRETOACT_2W |\ - PSDMR_ACTTORW_2W |\ - PSDMR_LDOTOPRE_1C |\ - PSDMR_WRC_1C |\ - PSDMR_CL_2) - - /* SDRAM initialization values for 9-column chips - */ -#define CONFIG_SYS_OR2_9COL (CONFIG_SYS_MIN_AM_MASK |\ - ORxS_BPD_4 |\ - ORxS_ROWST_PBI0_A7 |\ - ORxS_NUMR_13) - -#define CONFIG_SYS_PSDMR_9COL (PSDMR_SDAM_A14_IS_A5 |\ - PSDMR_BSMA_A13_A15 |\ - PSDMR_SDA10_PBI0_A9 |\ - PSDMR_RFRC_7_CLK |\ - PSDMR_PRETOACT_2W |\ - PSDMR_ACTTORW_2W |\ - PSDMR_LDOTOPRE_1C |\ - PSDMR_WRC_1C |\ - PSDMR_CL_2) - - /* SDRAM initialization values for 10-column chips - */ -#define CONFIG_SYS_OR2_10COL (CONFIG_SYS_MIN_AM_MASK |\ - ORxS_BPD_4 |\ - ORxS_ROWST_PBI1_A4 |\ - ORxS_NUMR_13) - -#define CONFIG_SYS_PSDMR_10COL (PSDMR_PBI |\ - PSDMR_SDAM_A17_IS_A5 |\ - PSDMR_BSMA_A13_A15 |\ - PSDMR_SDA10_PBI1_A6 |\ - PSDMR_RFRC_7_CLK |\ - PSDMR_PRETOACT_2W |\ - PSDMR_ACTTORW_2W |\ - PSDMR_LDOTOPRE_1C |\ - PSDMR_WRC_1C |\ - PSDMR_CL_2) - -/* - * Init Memory Controller: - * - * Bank Bus Machine PortSz Device - * ---- --- ------- ------ ------ - * 0 60x GPCM 8 bit Boot ROM - * 1 60x GPCM 64 bit FLASH - * 2 60x SDRAM 64 bit SDRAM - * - */ - -#define CONFIG_SYS_MRS_OFFS 0x00000000 - -#ifdef CONFIG_BOOT_ROM -/* Bank 0 - Boot ROM - */ -#define CONFIG_SYS_BR0_PRELIM ((CONFIG_SYS_BOOTROM_BASE & BRx_BA_MSK)|\ - BRx_PS_8 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR0_PRELIM (P2SZ_TO_AM(CONFIG_SYS_BOOTROM_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_5_CLK |\ - ORxU_EHTR_8IDLE) - -/* Bank 1 - FLASH - */ -#define CONFIG_SYS_BR1_PRELIM ((CONFIG_SYS_FLASH_BASE & BRx_BA_MSK) |\ - BRx_PS_64 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR1_PRELIM (P2SZ_TO_AM(CONFIG_SYS_FLASH_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_5_CLK |\ - ORxU_EHTR_8IDLE) - -#else /* CONFIG_BOOT_ROM */ -/* Bank 0 - FLASH - */ -#define CONFIG_SYS_BR0_PRELIM ((CONFIG_SYS_FLASH_BASE & BRx_BA_MSK) |\ - BRx_PS_64 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR0_PRELIM (P2SZ_TO_AM(CONFIG_SYS_FLASH_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_5_CLK |\ - ORxU_EHTR_8IDLE) - -/* Bank 1 - Boot ROM - */ -#define CONFIG_SYS_BR1_PRELIM ((CONFIG_SYS_BOOTROM_BASE & BRx_BA_MSK)|\ - BRx_PS_8 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR1_PRELIM (P2SZ_TO_AM(CONFIG_SYS_BOOTROM_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_5_CLK |\ - ORxU_EHTR_8IDLE) - -#endif /* CONFIG_BOOT_ROM */ - - -/* Bank 2 - 60x bus SDRAM - */ -#ifndef CONFIG_SYS_RAMBOOT -#define CONFIG_SYS_BR2_PRELIM ((CONFIG_SYS_SDRAM_BASE & BRx_BA_MSK) |\ - BRx_PS_64 |\ - BRx_MS_SDRAM_P |\ - BRx_V) - -#define CONFIG_SYS_OR2_PRELIM CONFIG_SYS_OR2_8COL - -#define CONFIG_SYS_PSDMR CONFIG_SYS_PSDMR_8COL -#endif /* CONFIG_SYS_RAMBOOT */ - -/* Bank 3 - Dual Ported SRAM - */ -#define CONFIG_SYS_BR3_PRELIM ((CONFIG_SYS_DPSRAM_BASE & BRx_BA_MSK) |\ - BRx_PS_16 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR3_PRELIM (P2SZ_TO_AM(CONFIG_SYS_DPSRAM_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_7_CLK |\ - ORxG_SETA) - -/* Bank 4 - DiskOnChip - */ -#define CONFIG_SYS_BR4_PRELIM ((CONFIG_SYS_DOC_BASE & BRx_BA_MSK) |\ - BRx_PS_8 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR4_PRELIM (P2SZ_TO_AM(CONFIG_SYS_DOC_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV2 |\ - ORxG_SCY_9_CLK |\ - ORxU_EHTR_8IDLE) - -/* Bank 5 - FDC37C78 controller - */ -#define CONFIG_SYS_BR5_PRELIM ((CONFIG_SYS_FDC37C78_BASE & BRx_BA_MSK) |\ - BRx_PS_8 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR5_PRELIM (P2SZ_TO_AM(CONFIG_SYS_FDC37C78_SIZE) |\ - ORxG_ACS_DIV2 |\ - ORxG_SCY_10_CLK |\ - ORxU_EHTR_8IDLE) - -/* Bank 6 - Board control registers - */ -#define CONFIG_SYS_BR6_PRELIM ((CONFIG_SYS_BCRS_BASE & BRx_BA_MSK) |\ - BRx_PS_8 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR6_PRELIM (P2SZ_TO_AM(CONFIG_SYS_BCRS_SIZE) |\ - ORxG_CSNT |\ - ORxG_SCY_7_CLK) - -/* Bank 7 - VME Extended Access Range - */ -#define CONFIG_SYS_BR7_PRELIM ((CONFIG_SYS_VMEEAR_BASE & BRx_BA_MSK) |\ - BRx_PS_32 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR7_PRELIM (P2SZ_TO_AM(CONFIG_SYS_VMEEAR_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_7_CLK |\ - ORxG_SETA) - -/* Bank 8 - VME Standard Access Range - */ -#define CONFIG_SYS_BR8_PRELIM ((CONFIG_SYS_VMESAR_BASE & BRx_BA_MSK) |\ - BRx_PS_16 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR8_PRELIM (P2SZ_TO_AM(CONFIG_SYS_VMESAR_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_7_CLK |\ - ORxG_SETA) - -/* Bank 9 - VME Short I/O Access Range - */ -#define CONFIG_SYS_BR9_PRELIM ((CONFIG_SYS_VMESIOAR_BASE & BRx_BA_MSK) |\ - BRx_PS_16 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR9_PRELIM (P2SZ_TO_AM(CONFIG_SYS_VMESIOAR_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_7_CLK |\ - ORxG_SETA) - -#endif /* __CONFIG_H */
On Mon, Dec 15, 2014 at 11:26:29PM +0900, Masahiro Yamada wrote:
These boards are still non-generic boards.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Wolfgang Denk wd@denx.de
drivers/rtc/ds12887.c should also be removed because it can not be built without CONFIG_ATC.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Wolfgang Denk wd@denx.de ---
arch/powerpc/cpu/mpc8260/Kconfig | 4 - board/atc/Kconfig | 9 - board/atc/MAINTAINERS | 6 - board/atc/Makefile | 8 - board/atc/atc.c | 382 ----------------------- board/atc/flash.c | 647 --------------------------------------- board/atc/ti113x.c | 620 ------------------------------------- configs/atc_defconfig | 3 - doc/README.scrapyard | 1 + drivers/rtc/Makefile | 1 - drivers/rtc/ds12887.c | 217 ------------- include/configs/atc.h | 489 ----------------------------- include/pcmcia.h | 2 - 13 files changed, 1 insertion(+), 2388 deletions(-) delete mode 100644 board/atc/Kconfig delete mode 100644 board/atc/MAINTAINERS delete mode 100644 board/atc/Makefile delete mode 100644 board/atc/atc.c delete mode 100644 board/atc/flash.c delete mode 100644 board/atc/ti113x.c delete mode 100644 configs/atc_defconfig delete mode 100644 drivers/rtc/ds12887.c delete mode 100644 include/configs/atc.h
diff --git a/arch/powerpc/cpu/mpc8260/Kconfig b/arch/powerpc/cpu/mpc8260/Kconfig index eab4514..55941c8 100644 --- a/arch/powerpc/cpu/mpc8260/Kconfig +++ b/arch/powerpc/cpu/mpc8260/Kconfig @@ -7,15 +7,11 @@ config SYS_CPU choice prompt "Target select"
-config TARGET_ATC - bool "Support atc" - config TARGET_KM82XX bool "Support km82xx"
endchoice
-source "board/atc/Kconfig" source "board/keymile/km82xx/Kconfig"
endmenu diff --git a/board/atc/Kconfig b/board/atc/Kconfig deleted file mode 100644 index 9b336ca..0000000 --- a/board/atc/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_ATC - -config SYS_BOARD - default "atc" - -config SYS_CONFIG_NAME - default "atc" - -endif diff --git a/board/atc/MAINTAINERS b/board/atc/MAINTAINERS deleted file mode 100644 index 1c5d61e..0000000 --- a/board/atc/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -ATC BOARD -M: Wolfgang Denk wd@denx.de -S: Maintained -F: board/atc/ -F: include/configs/atc.h -F: configs/atc_defconfig diff --git a/board/atc/Makefile b/board/atc/Makefile deleted file mode 100644 index 3a163c4..0000000 --- a/board/atc/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2001-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = atc.o flash.o ti113x.o diff --git a/board/atc/atc.c b/board/atc/atc.c deleted file mode 100644 index 0038561..0000000 --- a/board/atc/atc.c +++ /dev/null @@ -1,382 +0,0 @@ -/* - * (C) Copyright 2001 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <ioports.h> -#include <mpc8260.h> -#include <pci.h> - -/* - * I/O Port configuration table - * - * if conf is 1, then that port pin will be configured at boot time - * according to the five values podr/pdir/ppar/psor/pdat for that entry - */ - -const iop_conf_t iop_conf_tab[4][32] = { - - /* Port A configuration */ - { /* conf ppar psor pdir podr pdat */ - /* PA31 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 MII COL */ - /* PA30 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 MII CRS */ - /* PA29 */ { 1, 1, 1, 1, 0, 0 }, /* FCC1 MII TX_ER */ - /* PA28 */ { 1, 1, 1, 1, 0, 0 }, /* FCC1 MII TX_EN */ - /* PA27 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 MII RX_DV */ - /* PA26 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 MII RX_ER */ - /* PA25 */ { 1, 0, 0, 1, 0, 0 }, /* FCC2 MII MDIO */ - /* PA24 */ { 1, 0, 0, 1, 0, 0 }, /* FCC2 MII MDC */ - /* PA23 */ { 1, 0, 0, 1, 0, 0 }, /* FCC1 MII MDIO */ - /* PA22 */ { 1, 0, 0, 1, 0, 0 }, /* FCC1 MII MDC */ - /* PA21 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 MII TxD[3] */ - /* PA20 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 MII TxD[2] */ - /* PA19 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 MII TxD[1] */ - /* PA18 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 MII TxD[0] */ - /* PA17 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 MII RxD[0] */ - /* PA16 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 MII RxD[1] */ - /* PA15 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 MII RxD[2] */ - /* PA14 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 MII RxD[3] */ - /* PA13 */ { 1, 0, 0, 1, 0, 0 }, /* FCC2 MII TXSL1 */ - /* PA12 */ { 1, 0, 0, 1, 0, 1 }, /* FCC2 MII TXSL0 */ - /* PA11 */ { 1, 0, 0, 1, 0, 0 }, /* FCC1 MII TXSL1 */ - /* PA10 */ { 1, 0, 0, 1, 0, 1 }, /* FCC1 MII TXSL0 */ -#if 1 - /* PA9 */ { 0, 1, 0, 1, 0, 0 }, /* SMC2 TXD */ - /* PA8 */ { 0, 1, 0, 0, 0, 0 }, /* SMC2 RXD */ -#else - /* PA9 */ { 1, 1, 0, 1, 0, 0 }, /* SMC2 TXD */ - /* PA8 */ { 1, 1, 0, 0, 0, 0 }, /* SMC2 RXD */ -#endif - /* PA7 */ { 0, 0, 0, 0, 0, 0 }, /* PA7 */ - /* PA6 */ { 1, 0, 0, 1, 0, 1 }, /* FCC2 MII PAUSE */ - /* PA5 */ { 1, 0, 0, 1, 0, 1 }, /* FCC1 MII PAUSE */ - /* PA4 */ { 1, 0, 0, 1, 0, 0 }, /* FCC2 MII PWRDN */ - /* PA3 */ { 1, 0, 0, 1, 0, 0 }, /* FCC1 MII PWRDN */ - /* PA2 */ { 0, 0, 0, 0, 0, 0 }, /* PA2 */ - /* PA1 */ { 1, 0, 0, 0, 0, 0 }, /* FCC2 MII MDINT */ - /* PA0 */ { 1, 0, 0, 1, 0, 0 } /* FCC1 MII MDINT */ - }, - - /* Port B configuration */ - { /* conf ppar psor pdir podr pdat */ - /* PB31 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TX_ER */ - /* PB30 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_DV */ - /* PB29 */ { 1, 1, 1, 1, 0, 0 }, /* FCC2 MII TX_EN */ - /* PB28 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_ER */ - /* PB27 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII COL */ - /* PB26 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII CRS */ - /* PB25 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[3] */ - /* PB24 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[2] */ - /* PB23 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[1] */ - /* PB22 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[0] */ - /* PB21 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[0] */ - /* PB20 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[1] */ - /* PB19 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[2] */ - /* PB18 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[3] */ - /* PB17 */ { 1, 1, 0, 0, 0, 0 }, /* FCC3 MII RX_DV */ - /* PB16 */ { 1, 1, 0, 0, 0, 0 }, /* FCC3 MII RX_ER */ - /* PB15 */ { 1, 1, 0, 1, 0, 0 }, /* FCC3 MII TX_ER */ - /* PB14 */ { 1, 1, 0, 1, 0, 0 }, /* FCC3 MII TX_EN */ - /* PB13 */ { 1, 1, 0, 0, 0, 0 }, /* FCC3 MII COL */ - /* PB12 */ { 1, 1, 0, 0, 0, 0 }, /* FCC3 MII CRS */ - /* PB11 */ { 1, 1, 0, 0, 0, 0 }, /* FCC3 MII RxD */ - /* PB10 */ { 1, 1, 0, 0, 0, 0 }, /* FCC3 MII RxD */ - /* PB9 */ { 1, 1, 0, 0, 0, 0 }, /* FCC3 MII RxD */ - /* PB8 */ { 1, 1, 0, 0, 0, 0 }, /* FCC3 MII RxD */ - /* PB7 */ { 1, 1, 0, 1, 0, 0 }, /* FCC3 MII TxD */ - /* PB6 */ { 1, 1, 0, 1, 0, 0 }, /* FCC3 MII TxD */ - /* PB5 */ { 1, 1, 0, 1, 0, 0 }, /* FCC3 MII TxD */ - /* PB4 */ { 1, 1, 0, 1, 0, 0 }, /* FCC3 MII TxD */ - /* PB3 */ { 0, 0, 0, 0, 0, 0 }, /* PB3 */ - /* PB2 */ { 0, 0, 0, 0, 0, 0 }, /* PB2 */ - /* PB1 */ { 0, 0, 0, 0, 0, 0 }, /* PB1 */ - /* PB0 */ { 0, 0, 0, 0, 0, 0 } /* PB0 */ - }, - - /* Port C */ - { /* conf ppar psor pdir podr pdat */ - /* PC31 */ { 0, 0, 0, 0, 0, 0 }, /* PC31 */ - /* PC30 */ { 0, 0, 0, 0, 0, 0 }, /* PC30 */ - /* PC29 */ { 1, 0, 0, 0, 0, 0 }, /* SCC1 CTS */ - /* PC28 */ { 1, 0, 0, 0, 0, 0 }, /* SCC2 CTS */ - /* PC27 */ { 0, 0, 0, 0, 0, 0 }, /* PC27 */ - /* PC26 */ { 0, 0, 0, 0, 0, 0 }, /* PC26 */ - /* PC25 */ { 0, 0, 0, 0, 0, 0 }, /* PC25 */ - /* PC24 */ { 0, 0, 0, 0, 0, 0 }, /* PC24 */ - /* PC23 */ { 0, 0, 0, 0, 0, 0 }, /* FDC37C78 DACFD */ - /* PC22 */ { 0, 0, 0, 0, 0, 0 }, /* FDC37C78 DNFD */ - /* PC21 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 MII RX_CLK */ - /* PC20 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 MII TX_CLK */ - /* PC19 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_CLK */ - /* PC18 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII TX_CLK */ - /* PC17 */ { 1, 1, 0, 0, 0, 0 }, /* FCC3 MII RX_CLK */ - /* PC16 */ { 1, 1, 0, 0, 0, 0 }, /* FCC3 MII TX_CLK */ -#if 0 - /* PC15 */ { 0, 0, 0, 0, 0, 0 }, /* PC15 */ -#else - /* PC15 */ { 1, 1, 0, 1, 0, 0 }, /* PC15 */ -#endif - /* PC14 */ { 0, 0, 0, 0, 0, 0 }, /* PC14 */ - /* PC13 */ { 0, 0, 0, 0, 0, 0 }, /* PC13 */ - /* PC12 */ { 0, 0, 0, 0, 0, 0 }, /* PC12 */ - /* PC11 */ { 0, 0, 0, 0, 0, 0 }, /* PC11 */ - /* PC10 */ { 0, 0, 0, 0, 0, 0 }, /* PC10 */ - /* PC9 */ { 0, 0, 0, 0, 0, 0 }, /* FC9 */ - /* PC8 */ { 0, 0, 0, 0, 0, 0 }, /* PC8 */ - /* PC7 */ { 0, 0, 0, 0, 0, 0 }, /* PC7 */ - /* PC6 */ { 0, 0, 0, 0, 0, 0 }, /* PC6 */ - /* PC5 */ { 0, 0, 0, 0, 0, 0 }, /* PC5 */ - /* PC4 */ { 0, 0, 0, 0, 0, 0 }, /* PC4 */ - /* PC3 */ { 0, 0, 0, 0, 0, 0 }, /* PC3 */ - /* PC2 */ { 0, 0, 0, 0, 0, 0 }, /* PC2 */ - /* PC1 */ { 0, 0, 0, 0, 0, 0 }, /* PC1 */ - /* PC0 */ { 0, 0, 0, 0, 0, 0 }, /* FDC37C78 DRQFD */ - }, - - /* Port D */ - { /* conf ppar psor pdir podr pdat */ - /* PD31 */ { 1, 1, 0, 0, 0, 0 }, /* SCC1 RXD */ - /* PD30 */ { 1, 1, 1, 1, 0, 0 }, /* SCC1 TXD */ - /* PD29 */ { 1, 0, 0, 1, 0, 0 }, /* SCC1 RTS */ - /* PD28 */ { 1, 1, 0, 0, 0, 0 }, /* SCC2 RXD */ - /* PD27 */ { 1, 1, 0, 1, 0, 0 }, /* SCC2 TXD */ - /* PD26 */ { 1, 0, 0, 1, 0, 0 }, /* SCC2 RTS */ - /* PD25 */ { 0, 0, 0, 0, 0, 0 }, /* PD25 */ - /* PD24 */ { 0, 0, 0, 0, 0, 0 }, /* PD24 */ - /* PD23 */ { 0, 0, 0, 0, 0, 0 }, /* PD23 */ - /* PD22 */ { 0, 0, 0, 0, 0, 0 }, /* PD22 */ - /* PD21 */ { 0, 0, 0, 0, 0, 0 }, /* PD21 */ - /* PD20 */ { 0, 0, 0, 0, 0, 0 }, /* PD20 */ - /* PD19 */ { 0, 0, 0, 0, 0, 0 }, /* PD19 */ - /* PD18 */ { 0, 0, 0, 0, 0, 0 }, /* PD18 */ - /* PD17 */ { 0, 0, 0, 0, 0, 0 }, /* PD17 */ - /* PD16 */ { 0, 0, 0, 0, 0, 0 }, /* PD16 */ -#if defined(CONFIG_SYS_I2C_SOFT) - /* PD15 */ { 1, 0, 0, 1, 1, 1 }, /* I2C SDA */ - /* PD14 */ { 1, 0, 0, 1, 1, 1 }, /* I2C SCL */ -#else -#if defined(CONFIG_HARD_I2C) - /* PD15 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SDA */ - /* PD14 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SCL */ -#else /* normal I/O port pins */ - /* PD15 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SDA */ - /* PD14 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SCL */ -#endif -#endif - /* PD13 */ { 0, 0, 0, 0, 0, 0 }, /* PD13 */ - /* PD12 */ { 0, 0, 0, 0, 0, 0 }, /* PD12 */ - /* PD11 */ { 0, 0, 0, 0, 0, 0 }, /* PD11 */ - /* PD10 */ { 0, 0, 0, 0, 0, 0 }, /* PD10 */ - /* PD9 */ { 1, 1, 0, 1, 0, 0 }, /* SMC1 TXD */ - /* PD8 */ { 1, 1, 0, 0, 0, 0 }, /* SMC1 RXD */ - /* PD7 */ { 0, 0, 0, 0, 0, 0 }, /* PD7 */ - /* PD6 */ { 0, 0, 0, 0, 0, 0 }, /* PD6 */ - /* PD5 */ { 0, 0, 0, 0, 0, 0 }, /* PD5 */ -#if 0 - /* PD4 */ { 0, 0, 0, 0, 0, 0 }, /* PD4 */ -#else - /* PD4 */ { 1, 1, 1, 0, 0, 0 }, /* PD4 */ -#endif - /* PD3 */ { 0, 0, 0, 0, 0, 0 }, /* PD3 */ - /* PD2 */ { 0, 0, 0, 0, 0, 0 }, /* PD2 */ - /* PD1 */ { 0, 0, 0, 0, 0, 0 }, /* PD1 */ - /* PD0 */ { 0, 0, 0, 0, 0, 0 } /* PD0 */ - } -}; - -/* - * UPMB initialization table - */ -#define _NOT_USED_ 0xFFFFFFFF - -static const uint rtc_table[] = -{ - /* - * Single Read. (Offset 0 in UPMA RAM) - */ - 0xfffec00, 0xfffac00, 0xfff2d00, 0xfef2800, - 0xfaf2080, 0xfaf2080, 0xfff2400, 0x1fff6c05, /* last */ - /* - * Burst Read. (Offset 8 in UPMA RAM) - */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Single Write. (Offset 18 in UPMA RAM) - */ - 0xfffec00, 0xfffac00, 0xfff2d00, 0xfef2800, - 0xfaf2080, 0xfaf2080, 0xfaf2400, 0x1fbf6c05, /* last */ - /* - * Burst Write. (Offset 20 in UPMA RAM) - */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Refresh (Offset 30 in UPMA RAM) - */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Exception. (Offset 3c in UPMA RAM) - */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, -}; - -/* ------------------------------------------------------------------------- */ - -/* Check Board Identity: - */ -int checkboard (void) -{ - printf ("Board: ATC\n"); - return 0; -} - -/* ------------------------------------------------------------------------- */ - -/* Try SDRAM initialization with P/LSDMR=sdmr and ORx=orx - * - * This routine performs standard 8260 initialization sequence - * and calculates the available memory size. It may be called - * several times to try different SDRAM configurations on both - * 60x and local buses. - */ -static long int try_init (volatile memctl8260_t * memctl, ulong sdmr, - ulong orx, volatile uchar * base) -{ - volatile uchar c = 0xff; - volatile uint *sdmr_ptr; - volatile uint *orx_ptr; - ulong maxsize, size; - int i; - - /* We must be able to test a location outsize the maximum legal size - * to find out THAT we are outside; but this address still has to be - * mapped by the controller. That means, that the initial mapping has - * to be (at least) twice as large as the maximum expected size. - */ - maxsize = (1 + (~orx | 0x7fff)) / 2; - - /* Since CONFIG_SYS_SDRAM_BASE is always 0 (??), we assume that - * we are configuring CS1 if base != 0 - */ - sdmr_ptr = &memctl->memc_psdmr; - orx_ptr = &memctl->memc_or2; - - *orx_ptr = orx; - - /* - * Quote from 8260 UM (10.4.2 SDRAM Power-On Initialization, 10-35): - * - * "At system reset, initialization software must set up the - * programmable parameters in the memory controller banks registers - * (ORx, BRx, P/LSDMR). After all memory parameters are configured, - * system software should execute the following initialization sequence - * for each SDRAM device. - * - * 1. Issue a PRECHARGE-ALL-BANKS command - * 2. Issue eight CBR REFRESH commands - * 3. Issue a MODE-SET command to initialize the mode register - * - * The initial commands are executed by setting P/LSDMR[OP] and - * accessing the SDRAM with a single-byte transaction." - * - * The appropriate BRx/ORx registers have already been set when we - * get here. The SDRAM can be accessed at the address CONFIG_SYS_SDRAM_BASE. - */ - - *sdmr_ptr = sdmr | PSDMR_OP_PREA; - *base = c; - - *sdmr_ptr = sdmr | PSDMR_OP_CBRR; - for (i = 0; i < 8; i++) - *base = c; - - *sdmr_ptr = sdmr | PSDMR_OP_MRW; - *(base + CONFIG_SYS_MRS_OFFS) = c; /* setting MR on address lines */ - - *sdmr_ptr = sdmr | PSDMR_OP_NORM | PSDMR_RFEN; - *base = c; - - size = get_ram_size((long *)base, maxsize); - - *orx_ptr = orx | ~(size - 1); - - return (size); -} - -int misc_init_r(void) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8260_t *memctl = &immap->im_memctl; - - upmconfig(UPMA, (uint *)rtc_table, sizeof(rtc_table) / sizeof(uint)); - memctl->memc_mamr = MxMR_RLFx_6X | MxMR_WLFx_6X | MxMR_OP_NORM; - - return (0); -} - -phys_size_t initdram (int board_type) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8260_t *memctl = &immap->im_memctl; - -#ifndef CONFIG_SYS_RAMBOOT - ulong size8, size9; -#endif - long psize; - - psize = 8 * 1024 * 1024; - - memctl->memc_mptpr = CONFIG_SYS_MPTPR; - memctl->memc_psrt = CONFIG_SYS_PSRT; - -#ifndef CONFIG_SYS_RAMBOOT - /* 60x SDRAM setup: - */ - size8 = try_init (memctl, CONFIG_SYS_PSDMR_8COL, CONFIG_SYS_OR2_8COL, - (uchar *) CONFIG_SYS_SDRAM_BASE); - size9 = try_init (memctl, CONFIG_SYS_PSDMR_9COL, CONFIG_SYS_OR2_9COL, - (uchar *) CONFIG_SYS_SDRAM_BASE); - - if (size8 < size9) { - psize = size9; - printf ("(60x:9COL) "); - } else { - psize = try_init (memctl, CONFIG_SYS_PSDMR_8COL, CONFIG_SYS_OR2_8COL, - (uchar *) CONFIG_SYS_SDRAM_BASE); - printf ("(60x:8COL) "); - } - -#endif /* CONFIG_SYS_RAMBOOT */ - - icache_enable (); - - return (psize); -} - -#if defined(CONFIG_CMD_DOC) -void doc_init (void) -{ - doc_probe (CONFIG_SYS_DOC_BASE); -} -#endif - -#ifdef CONFIG_PCI -struct pci_controller hose; - -extern void pci_mpc8250_init(struct pci_controller *); - -void pci_init_board(void) -{ - pci_mpc8250_init(&hose); -} -#endif diff --git a/board/atc/flash.c b/board/atc/flash.c deleted file mode 100644 index 5a9c510..0000000 --- a/board/atc/flash.c +++ /dev/null @@ -1,647 +0,0 @@ -/* - * (C) Copyright 2003 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH chips */ - -/* NOTE - CONFIG_FLASH_16BIT means the CPU interface is 16-bit, it - * has nothing to do with the flash chip being 8-bit or 16-bit. - */ -#ifdef CONFIG_FLASH_16BIT -typedef unsigned short FLASH_PORT_WIDTH; -typedef volatile unsigned short FLASH_PORT_WIDTHV; -#define FLASH_ID_MASK 0xFFFF -#else -typedef unsigned long FLASH_PORT_WIDTH; -typedef volatile unsigned long FLASH_PORT_WIDTHV; -#define FLASH_ID_MASK 0xFFFFFFFF -#endif - -#define FPW FLASH_PORT_WIDTH -#define FPWV FLASH_PORT_WIDTHV - -#define ORMASK(size) ((-size) & OR_AM_MSK) - -#define FLASH_CYCLE1 0x0555 -#define FLASH_CYCLE2 0x02aa - -/*----------------------------------------------------------------------- - * Functions - */ -static ulong flash_get_size(FPWV *addr, flash_info_t *info); -static void flash_reset(flash_info_t *info); -static int write_word_intel(flash_info_t *info, FPWV *dest, FPW data); -static int write_word_amd(flash_info_t *info, FPWV *dest, FPW data); -static void flash_get_offsets(ulong base, flash_info_t *info); -static flash_info_t *flash_get_info(ulong base); - -/*----------------------------------------------------------------------- - * flash_init() - * - * sets up flash_info and returns size of FLASH (bytes) - */ -unsigned long flash_init (void) -{ - unsigned long size = 0; - int i; - - /* Init: no FLASHes known */ - for (i=0; i < CONFIG_SYS_MAX_FLASH_BANKS; ++i) { -#if 0 - ulong flashbase = (i == 0) ? PHYS_FLASH_1 : PHYS_FLASH_2; -#else - ulong flashbase = CONFIG_SYS_FLASH_BASE; -#endif - - memset(&flash_info[i], 0, sizeof(flash_info_t)); - - flash_info[i].size = - flash_get_size((FPW *)flashbase, &flash_info[i]); - - if (flash_info[i].flash_id == FLASH_UNKNOWN) { - printf ("## Unknown FLASH on Bank %d - Size = 0x%08lx\n", - i, flash_info[i].size); - } - - size += flash_info[i].size; - } - -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE - /* monitor protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE+monitor_flash_len-1, - flash_get_info(CONFIG_SYS_MONITOR_BASE)); -#endif - -#ifdef CONFIG_ENV_IS_IN_FLASH - /* ENV protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR+CONFIG_ENV_SIZE-1, - flash_get_info(CONFIG_ENV_ADDR)); -#endif - - - return size ? size : 1; -} - -/*----------------------------------------------------------------------- - */ -static void flash_reset(flash_info_t *info) -{ - FPWV *base = (FPWV *)(info->start[0]); - - /* Put FLASH back in read mode */ - if ((info->flash_id & FLASH_VENDMASK) == FLASH_MAN_INTEL) - *base = (FPW)0x00FF00FF; /* Intel Read Mode */ - else if ((info->flash_id & FLASH_VENDMASK) == FLASH_MAN_AMD) - *base = (FPW)0x00F000F0; /* AMD Read Mode */ -} - -/*----------------------------------------------------------------------- - */ -static void flash_get_offsets (ulong base, flash_info_t *info) -{ - int i; - - /* set up sector start address table */ - if ((info->flash_id & FLASH_VENDMASK) == FLASH_MAN_INTEL - && (info->flash_id & FLASH_BTYPE)) { - int bootsect_size; /* number of bytes/boot sector */ - int sect_size; /* number of bytes/regular sector */ - - bootsect_size = 0x00002000 * (sizeof(FPW)/2); - sect_size = 0x00010000 * (sizeof(FPW)/2); - - /* set sector offsets for bottom boot block type */ - for (i = 0; i < 8; ++i) { - info->start[i] = base + (i * bootsect_size); - } - for (i = 8; i < info->sector_count; i++) { - info->start[i] = base + ((i - 7) * sect_size); - } - } - else if ((info->flash_id & FLASH_VENDMASK) == FLASH_MAN_AMD - && (info->flash_id & FLASH_TYPEMASK) == FLASH_AM640U) { - - int sect_size; /* number of bytes/sector */ - - sect_size = 0x00010000 * (sizeof(FPW)/2); - - /* set up sector start address table (uniform sector type) */ - for( i = 0; i < info->sector_count; i++ ) - info->start[i] = base + (i * sect_size); - } -} - -/*----------------------------------------------------------------------- - */ - -static flash_info_t *flash_get_info(ulong base) -{ - int i; - flash_info_t * info; - - for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; i ++) { - info = & flash_info[i]; - if (info->start[0] <= base && base < info->start[0] + info->size) - break; - } - - return i == CONFIG_SYS_MAX_FLASH_BANKS ? 0 : info; -} - -/*----------------------------------------------------------------------- - */ - -void flash_print_info (flash_info_t *info) -{ - int i; - uchar *boottype; - uchar *bootletter; - char *fmt; - uchar botbootletter[] = "B"; - uchar topbootletter[] = "T"; - uchar botboottype[] = "bottom boot sector"; - uchar topboottype[] = "top boot sector"; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_AMD: printf ("AMD "); break; - case FLASH_MAN_BM: printf ("BRIGHT MICRO "); break; - case FLASH_MAN_FUJ: printf ("FUJITSU "); break; - case FLASH_MAN_SST: printf ("SST "); break; - case FLASH_MAN_STM: printf ("STM "); break; - case FLASH_MAN_INTEL: printf ("INTEL "); break; - default: printf ("Unknown Vendor "); break; - } - - /* check for top or bottom boot, if it applies */ - if (info->flash_id & FLASH_BTYPE) { - boottype = botboottype; - bootletter = botbootletter; - } - else { - boottype = topboottype; - bootletter = topbootletter; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_AM640U: - fmt = "29LV641D (64 Mbit, uniform sectors)\n"; - break; - case FLASH_28F800C3B: - case FLASH_28F800C3T: - fmt = "28F800C3%s (8 Mbit, %s)\n"; - break; - case FLASH_INTEL800B: - case FLASH_INTEL800T: - fmt = "28F800B3%s (8 Mbit, %s)\n"; - break; - case FLASH_28F160C3B: - case FLASH_28F160C3T: - fmt = "28F160C3%s (16 Mbit, %s)\n"; - break; - case FLASH_INTEL160B: - case FLASH_INTEL160T: - fmt = "28F160B3%s (16 Mbit, %s)\n"; - break; - case FLASH_28F320C3B: - case FLASH_28F320C3T: - fmt = "28F320C3%s (32 Mbit, %s)\n"; - break; - case FLASH_INTEL320B: - case FLASH_INTEL320T: - fmt = "28F320B3%s (32 Mbit, %s)\n"; - break; - case FLASH_28F640C3B: - case FLASH_28F640C3T: - fmt = "28F640C3%s (64 Mbit, %s)\n"; - break; - case FLASH_INTEL640B: - case FLASH_INTEL640T: - fmt = "28F640B3%s (64 Mbit, %s)\n"; - break; - default: - fmt = "Unknown Chip Type\n"; - break; - } - - printf (fmt, bootletter, boottype); - - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, - info->sector_count); - - printf (" Sector Start Addresses:"); - - for (i=0; i<info->sector_count; ++i) { - if ((i % 5) == 0) { - printf ("\n "); - } - - printf (" %08lX%s", info->start[i], - info->protect[i] ? " (RO)" : " "); - } - - printf ("\n"); -} - -/*----------------------------------------------------------------------- - */ - -/* - * The following code cannot be run from FLASH! - */ - -ulong flash_get_size (FPWV *addr, flash_info_t *info) -{ - /* Write auto select command: read Manufacturer ID */ - - /* Write auto select command sequence and test FLASH answer */ - addr[FLASH_CYCLE1] = (FPW)0x00AA00AA; /* for AMD, Intel ignores this */ - addr[FLASH_CYCLE2] = (FPW)0x00550055; /* for AMD, Intel ignores this */ - addr[FLASH_CYCLE1] = (FPW)0x00900090; /* selects Intel or AMD */ - - /* The manufacturer codes are only 1 byte, so just use 1 byte. - * This works for any bus width and any FLASH device width. - */ - udelay(100); - switch (addr[0] & 0xff) { - - case (uchar)AMD_MANUFACT: - info->flash_id = FLASH_MAN_AMD; - break; - - case (uchar)INTEL_MANUFACT: - info->flash_id = FLASH_MAN_INTEL; - break; - - default: - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - break; - } - - /* Check 16 bits or 32 bits of ID so work on 32 or 16 bit bus. */ - if (info->flash_id != FLASH_UNKNOWN) switch (addr[1]) { - - case (FPW)AMD_ID_LV640U: /* 29LV640 and 29LV641 have same ID */ - info->flash_id += FLASH_AM640U; - info->sector_count = 128; - info->size = 0x00800000 * (sizeof(FPW)/2); - break; /* => 8 or 16 MB */ - - case (FPW)INTEL_ID_28F800C3B: - info->flash_id += FLASH_28F800C3B; - info->sector_count = 23; - info->size = 0x00100000 * (sizeof(FPW)/2); - break; /* => 1 or 2 MB */ - - case (FPW)INTEL_ID_28F800B3B: - info->flash_id += FLASH_INTEL800B; - info->sector_count = 23; - info->size = 0x00100000 * (sizeof(FPW)/2); - break; /* => 1 or 2 MB */ - - case (FPW)INTEL_ID_28F160C3B: - info->flash_id += FLASH_28F160C3B; - info->sector_count = 39; - info->size = 0x00200000 * (sizeof(FPW)/2); - break; /* => 2 or 4 MB */ - - case (FPW)INTEL_ID_28F160B3B: - info->flash_id += FLASH_INTEL160B; - info->sector_count = 39; - info->size = 0x00200000 * (sizeof(FPW)/2); - break; /* => 2 or 4 MB */ - - case (FPW)INTEL_ID_28F320C3B: - info->flash_id += FLASH_28F320C3B; - info->sector_count = 71; - info->size = 0x00400000 * (sizeof(FPW)/2); - break; /* => 4 or 8 MB */ - - case (FPW)INTEL_ID_28F320B3B: - info->flash_id += FLASH_INTEL320B; - info->sector_count = 71; - info->size = 0x00400000 * (sizeof(FPW)/2); - break; /* => 4 or 8 MB */ - - case (FPW)INTEL_ID_28F640C3B: - info->flash_id += FLASH_28F640C3B; - info->sector_count = 135; - info->size = 0x00800000 * (sizeof(FPW)/2); - break; /* => 8 or 16 MB */ - - case (FPW)INTEL_ID_28F640B3B: - info->flash_id += FLASH_INTEL640B; - info->sector_count = 135; - info->size = 0x00800000 * (sizeof(FPW)/2); - break; /* => 8 or 16 MB */ - - default: - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - return (0); /* => no or unknown flash */ - } - - flash_get_offsets((ulong)addr, info); - - /* Put FLASH back in read mode */ - flash_reset(info); - - return (info->size); -} - -/*----------------------------------------------------------------------- - */ - -int flash_erase (flash_info_t *info, int s_first, int s_last) -{ - FPWV *addr; - int flag, prot, sect; - int intel = (info->flash_id & FLASH_VENDMASK) == FLASH_MAN_INTEL; - ulong start, now, last; - int rcode = 0; - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_INTEL800B: - case FLASH_INTEL160B: - case FLASH_INTEL320B: - case FLASH_INTEL640B: - case FLASH_28F800C3B: - case FLASH_28F160C3B: - case FLASH_28F320C3B: - case FLASH_28F640C3B: - case FLASH_AM640U: - break; - case FLASH_UNKNOWN: - default: - printf ("Can't erase unknown flash type %08lx - aborted\n", - info->flash_id); - return 1; - } - - prot = 0; - for (sect=s_first; sect<=s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - printf ("\n"); - } - - last = get_timer(0); - - /* Start erase on unprotected sectors */ - for (sect = s_first; sect<=s_last && rcode == 0; sect++) { - - if (info->protect[sect] != 0) /* protected, skip it */ - continue; - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - addr = (FPWV *)(info->start[sect]); - if (intel) { - *addr = (FPW)0x00500050; /* clear status register */ - *addr = (FPW)0x00200020; /* erase setup */ - *addr = (FPW)0x00D000D0; /* erase confirm */ - } - else { - /* must be AMD style if not Intel */ - FPWV *base; /* first address in bank */ - - base = (FPWV *)(info->start[0]); - base[FLASH_CYCLE1] = (FPW)0x00AA00AA; /* unlock */ - base[FLASH_CYCLE2] = (FPW)0x00550055; /* unlock */ - base[FLASH_CYCLE1] = (FPW)0x00800080; /* erase mode */ - base[FLASH_CYCLE1] = (FPW)0x00AA00AA; /* unlock */ - base[FLASH_CYCLE2] = (FPW)0x00550055; /* unlock */ - *addr = (FPW)0x00300030; /* erase sector */ - } - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - start = get_timer(0); - - /* wait at least 50us for AMD, 80us for Intel. - * Let's wait 1 ms. - */ - udelay (1000); - - while ((*addr & (FPW)0x00800080) != (FPW)0x00800080) { - if ((now = get_timer(start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - - if (intel) { - /* suspend erase */ - *addr = (FPW)0x00B000B0; - } - - flash_reset(info); /* reset to read mode */ - rcode = 1; /* failed */ - break; - } - - /* show that we're waiting */ - if ((get_timer(last)) > CONFIG_SYS_HZ) {/* every second */ - putc ('.'); - last = get_timer(0); - } - } - - /* show that we're waiting */ - if ((get_timer(last)) > CONFIG_SYS_HZ) { /* every second */ - putc ('.'); - last = get_timer(0); - } - - flash_reset(info); /* reset to read mode */ - } - - printf (" done\n"); - return rcode; -} - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -int write_buff (flash_info_t *info, uchar *src, ulong addr, ulong cnt) -{ - FPW data = 0; /* 16 or 32 bit word, matches flash bus width on MPC8XX */ - int bytes; /* number of bytes to program in current word */ - int left; /* number of bytes left to program */ - int i, res; - - for (left = cnt, res = 0; - left > 0 && res == 0; - addr += sizeof(data), left -= sizeof(data) - bytes) { - - bytes = addr & (sizeof(data) - 1); - addr &= ~(sizeof(data) - 1); - - /* combine source and destination data so can program - * an entire word of 16 or 32 bits - */ - for (i = 0; i < sizeof(data); i++) { - data <<= 8; - if (i < bytes || i - bytes >= left ) - data += *((uchar *)addr + i); - else - data += *src++; - } - - /* write one word to the flash */ - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_AMD: - res = write_word_amd(info, (FPWV *)addr, data); - break; - case FLASH_MAN_INTEL: - res = write_word_intel(info, (FPWV *)addr, data); - break; - default: - /* unknown flash type, error! */ - printf ("missing or unknown FLASH type\n"); - res = 1; /* not really a timeout, but gives error */ - break; - } - } - - return (res); -} - -/*----------------------------------------------------------------------- - * Write a word to Flash for AMD FLASH - * A word is 16 or 32 bits, whichever the bus width of the flash bank - * (not an individual chip) is. - * - * returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_word_amd (flash_info_t *info, FPWV *dest, FPW data) -{ - ulong start; - int flag; - int res = 0; /* result, assume success */ - FPWV *base; /* first address in flash bank */ - - /* Check if Flash is (sufficiently) erased */ - if ((*dest & data) != data) { - return (2); - } - - - base = (FPWV *)(info->start[0]); - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - base[FLASH_CYCLE1] = (FPW)0x00AA00AA; /* unlock */ - base[FLASH_CYCLE2] = (FPW)0x00550055; /* unlock */ - base[FLASH_CYCLE1] = (FPW)0x00A000A0; /* selects program mode */ - - *dest = data; /* start programming the data */ - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - start = get_timer (0); - - /* data polling for D7 */ - while (res == 0 && (*dest & (FPW)0x00800080) != (data & (FPW)0x00800080)) { - if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - *dest = (FPW)0x00F000F0; /* reset bank */ - res = 1; - } - } - - return (res); -} - -/*----------------------------------------------------------------------- - * Write a word to Flash for Intel FLASH - * A word is 16 or 32 bits, whichever the bus width of the flash bank - * (not an individual chip) is. - * - * returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_word_intel (flash_info_t *info, FPWV *dest, FPW data) -{ - ulong start; - int flag; - int res = 0; /* result, assume success */ - - /* Check if Flash is (sufficiently) erased */ - if ((*dest & data) != data) { - return (2); - } - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - *dest = (FPW)0x00500050; /* clear status register */ - *dest = (FPW)0x00FF00FF; /* make sure in read mode */ - *dest = (FPW)0x00400040; /* program setup */ - - *dest = data; /* start programming the data */ - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - start = get_timer (0); - - while (res == 0 && (*dest & (FPW)0x00800080) != (FPW)0x00800080) { - if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - *dest = (FPW)0x00B000B0; /* Suspend program */ - res = 1; - } - } - - if (res == 0 && (*dest & (FPW)0x00100010)) - res = 1; /* write failed, time out error is close enough */ - - *dest = (FPW)0x00500050; /* clear status register */ - *dest = (FPW)0x00FF00FF; /* make sure in read mode */ - - return (res); -} diff --git a/board/atc/ti113x.c b/board/atc/ti113x.c deleted file mode 100644 index c7c502c..0000000 --- a/board/atc/ti113x.c +++ /dev/null @@ -1,620 +0,0 @@ -/* - * (C) Copyright 2003-2005 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - ******************************************************************** - * - * Lots of code copied from: - * - * i82365.c 1.352 - Linux driver for Intel 82365 and compatible - * PC Card controllers, and Yenta-compatible PCI-to-CardBus controllers. - * (C) 1999 David A. Hinds dahinds@users.sourceforge.net - */ - -#include <common.h> - -#ifdef CONFIG_I82365 - -#include <command.h> -#include <pci.h> -#include <pcmcia.h> -#include <asm/io.h> - -#include <pcmcia/ss.h> -#include <pcmcia/i82365.h> -#include <pcmcia/yenta.h> -#include <pcmcia/ti113x.h> - -static struct pci_device_id supported[] = { - {PCI_VENDOR_ID_TI, PCI_DEVICE_ID_TI_1510}, - {0, 0} -}; - -#define CYCLE_TIME 120 - -#ifdef DEBUG -static void i82365_dump_regions (pci_dev_t dev); -#endif - -typedef struct socket_info_t { - pci_dev_t dev; - u_short bcr; - u_char pci_lat, cb_lat, sub_bus, cache; - u_int cb_phys; - - socket_cap_t cap; - u_short type; - u_int flags; - ti113x_state_t state; -} socket_info_t; - -static socket_info_t socket; -static socket_state_t state; -static struct pccard_mem_map mem; -static struct pccard_io_map io; - -/*====================================================================*/ - -/* Some PCI shortcuts */ - -static int pci_readb (socket_info_t * s, int r, u_char * v) -{ - return pci_read_config_byte (s->dev, r, v); -} -static int pci_writeb (socket_info_t * s, int r, u_char v) -{ - return pci_write_config_byte (s->dev, r, v); -} -static int pci_readw (socket_info_t * s, int r, u_short * v) -{ - return pci_read_config_word (s->dev, r, v); -} -static int pci_writew (socket_info_t * s, int r, u_short v) -{ - return pci_write_config_word (s->dev, r, v); -} -static int pci_readl (socket_info_t * s, int r, u_int * v) -{ - return pci_read_config_dword (s->dev, r, v); -} -static int pci_writel (socket_info_t * s, int r, u_int v) -{ - return pci_write_config_dword (s->dev, r, v); -} - -/*====================================================================*/ - -#define cb_readb(s, r) readb((s)->cb_phys + (r)) -#define cb_readl(s, r) readl((s)->cb_phys + (r)) -#define cb_writeb(s, r, v) writeb(v, (s)->cb_phys + (r)) -#define cb_writel(s, r, v) writel(v, (s)->cb_phys + (r)) - -static u_char i365_get (socket_info_t * s, u_short reg) -{ - return cb_readb (s, 0x0800 + reg); -} - -static void i365_set (socket_info_t * s, u_short reg, u_char data) -{ - cb_writeb (s, 0x0800 + reg, data); -} - -static void i365_bset (socket_info_t * s, u_short reg, u_char mask) -{ - i365_set (s, reg, i365_get (s, reg) | mask); -} - -static void i365_bclr (socket_info_t * s, u_short reg, u_char mask) -{ - i365_set (s, reg, i365_get (s, reg) & ~mask); -} - -#if 0 /* not used */ -static void i365_bflip (socket_info_t * s, u_short reg, u_char mask, int b) -{ - u_char d = i365_get (s, reg); - - i365_set (s, reg, (b) ? (d | mask) : (d & ~mask)); -} - -static u_short i365_get_pair (socket_info_t * s, u_short reg) -{ - return (i365_get (s, reg) + (i365_get (s, reg + 1) << 8)); -} -#endif /* not used */ - -static void i365_set_pair (socket_info_t * s, u_short reg, u_short data) -{ - i365_set (s, reg, data & 0xff); - i365_set (s, reg + 1, data >> 8); -} - -/*====================================================================== - - Code to save and restore global state information for TI 1130 and - TI 1131 controllers, and to set and report global configuration - options. - -======================================================================*/ - -static void ti113x_get_state (socket_info_t * s) -{ - ti113x_state_t *p = &s->state; - - pci_readl (s, TI113X_SYSTEM_CONTROL, &p->sysctl); - pci_readb (s, TI113X_CARD_CONTROL, &p->cardctl); - pci_readb (s, TI113X_DEVICE_CONTROL, &p->devctl); - pci_readb (s, TI1250_DIAGNOSTIC, &p->diag); - pci_readl (s, TI12XX_IRQMUX, &p->irqmux); -} - -static void ti113x_set_state (socket_info_t * s) -{ - ti113x_state_t *p = &s->state; - - pci_writel (s, TI113X_SYSTEM_CONTROL, p->sysctl); - pci_writeb (s, TI113X_CARD_CONTROL, p->cardctl); - pci_writeb (s, TI113X_DEVICE_CONTROL, p->devctl); - pci_writeb (s, TI1250_MULTIMEDIA_CTL, 0); - pci_writeb (s, TI1250_DIAGNOSTIC, p->diag); - pci_writel (s, TI12XX_IRQMUX, p->irqmux); - i365_set_pair (s, TI113X_IO_OFFSET (0), 0); - i365_set_pair (s, TI113X_IO_OFFSET (1), 0); -} - -static u_int ti113x_set_opts (socket_info_t * s) -{ - ti113x_state_t *p = &s->state; - u_int mask = 0xffff; - - p->cardctl &= ~TI113X_CCR_ZVENABLE; - p->cardctl |= TI113X_CCR_SPKROUTEN; - - return mask; -} - -/*====================================================================== - - Routines to handle common CardBus options - -======================================================================*/ - -/* Default settings for PCI command configuration register */ -#define CMD_DFLT (PCI_COMMAND_IO|PCI_COMMAND_MEMORY| \ - PCI_COMMAND_MASTER|PCI_COMMAND_WAIT) - -static void cb_get_state (socket_info_t * s) -{ - pci_readb (s, PCI_CACHE_LINE_SIZE, &s->cache); - pci_readb (s, PCI_LATENCY_TIMER, &s->pci_lat); - pci_readb (s, CB_LATENCY_TIMER, &s->cb_lat); - pci_readb (s, CB_CARDBUS_BUS, &s->cap.cardbus); - pci_readb (s, CB_SUBORD_BUS, &s->sub_bus); - pci_readw (s, CB_BRIDGE_CONTROL, &s->bcr); -} - -static void cb_set_state (socket_info_t * s) -{ - pci_writel (s, CB_LEGACY_MODE_BASE, 0); - pci_writel (s, PCI_BASE_ADDRESS_0, s->cb_phys); - pci_writew (s, PCI_COMMAND, CMD_DFLT); - pci_writeb (s, PCI_CACHE_LINE_SIZE, s->cache); - pci_writeb (s, PCI_LATENCY_TIMER, s->pci_lat); - pci_writeb (s, CB_LATENCY_TIMER, s->cb_lat); - pci_writeb (s, CB_CARDBUS_BUS, s->cap.cardbus); - pci_writeb (s, CB_SUBORD_BUS, s->sub_bus); - pci_writew (s, CB_BRIDGE_CONTROL, s->bcr); -} - -static void cb_set_opts (socket_info_t * s) -{ - if (s->cache == 0) - s->cache = 8; - if (s->pci_lat == 0) - s->pci_lat = 0xa8; - if (s->cb_lat == 0) - s->cb_lat = 0xb0; -} - -/*====================================================================== - - Power control for Cardbus controllers: used both for 16-bit and - Cardbus cards. - -======================================================================*/ - -static int cb_set_power (socket_info_t * s, socket_state_t * state) -{ - u_int reg = 0; - - /* restart card voltage detection if it seems appropriate */ - if ((state->Vcc == 0) && (state->Vpp == 0) && - !(cb_readl (s, CB_SOCKET_STATE) & CB_SS_VSENSE)) - cb_writel (s, CB_SOCKET_FORCE, CB_SF_CVSTEST); - switch (state->Vcc) { - case 0: - reg = 0; - break; - case 33: - reg = CB_SC_VCC_3V; - break; - case 50: - reg = CB_SC_VCC_5V; - break; - default: - return -1; - } - switch (state->Vpp) { - case 0: - break; - case 33: - reg |= CB_SC_VPP_3V; - break; - case 50: - reg |= CB_SC_VPP_5V; - break; - case 120: - reg |= CB_SC_VPP_12V; - break; - default: - return -1; - } - if (reg != cb_readl (s, CB_SOCKET_CONTROL)) - cb_writel (s, CB_SOCKET_CONTROL, reg); - - return 0; -} - -/*====================================================================== - - Generic routines to get and set controller options - -======================================================================*/ - -static void get_bridge_state (socket_info_t * s) -{ - ti113x_get_state (s); - cb_get_state (s); -} - -static void set_bridge_state (socket_info_t * s) -{ - cb_set_state (s); - i365_set (s, I365_GBLCTL, 0x00); - i365_set (s, I365_GENCTL, 0x00); - ti113x_set_state (s); -} - -static void set_bridge_opts (socket_info_t * s) -{ - ti113x_set_opts (s); - cb_set_opts (s); -} - -/*====================================================================*/ -#define PD67_EXT_INDEX 0x2e /* Extension index */ -#define PD67_EXT_DATA 0x2f /* Extension data */ -#define PD67_EXD_VS1(s) (0x01 << ((s)<<1)) - -#define pd67_ext_get(s, r) \ - (i365_set(s, PD67_EXT_INDEX, r), i365_get(s, PD67_EXT_DATA)) - -static int i365_get_status (socket_info_t * s, u_int * value) -{ - u_int status; - - status = i365_get (s, I365_IDENT); - status = i365_get (s, I365_STATUS); - *value = ((status & I365_CS_DETECT) == I365_CS_DETECT) ? SS_DETECT : 0; - if (i365_get (s, I365_INTCTL) & I365_PC_IOCARD) { - *value |= (status & I365_CS_STSCHG) ? 0 : SS_STSCHG; - } else { - *value |= (status & I365_CS_BVD1) ? 0 : SS_BATDEAD; - *value |= (status & I365_CS_BVD2) ? 0 : SS_BATWARN; - } - *value |= (status & I365_CS_WRPROT) ? SS_WRPROT : 0; - *value |= (status & I365_CS_READY) ? SS_READY : 0; - *value |= (status & I365_CS_POWERON) ? SS_POWERON : 0; - - status = cb_readl (s, CB_SOCKET_STATE); - *value |= (status & CB_SS_32BIT) ? SS_CARDBUS : 0; - *value |= (status & CB_SS_3VCARD) ? SS_3VCARD : 0; - *value |= (status & CB_SS_XVCARD) ? SS_XVCARD : 0; - *value |= (status & CB_SS_VSENSE) ? 0 : SS_PENDING; - /* For now, ignore cards with unsupported voltage keys */ - if (*value & SS_XVCARD) - *value &= ~(SS_DETECT | SS_3VCARD | SS_XVCARD); - - return 0; -} /* i365_get_status */ - -static int i365_set_socket (socket_info_t * s, socket_state_t * state) -{ - u_char reg; - - set_bridge_state (s); - - /* IO card, RESET flag */ - reg = 0; - reg |= (state->flags & SS_RESET) ? 0 : I365_PC_RESET; - reg |= (state->flags & SS_IOCARD) ? I365_PC_IOCARD : 0; - i365_set (s, I365_INTCTL, reg); - - reg = I365_PWR_NORESET; - if (state->flags & SS_PWR_AUTO) - reg |= I365_PWR_AUTO; - if (state->flags & SS_OUTPUT_ENA) - reg |= I365_PWR_OUT; - - cb_set_power (s, state); - reg |= i365_get (s, I365_POWER) & (I365_VCC_MASK | I365_VPP1_MASK); - - if (reg != i365_get (s, I365_POWER)) - i365_set (s, I365_POWER, reg); - - return 0; -} /* i365_set_socket */ - -/*====================================================================*/ - -static int i365_set_mem_map (socket_info_t * s, struct pccard_mem_map *mem) -{ - u_short base, i; - u_char map; - - debug ("i82365: SetMemMap(%d, %#2.2x, %d ns, %#5.5lx-%#5.5lx, %#5.5x)\n", - mem->map, mem->flags, mem->speed, - mem->sys_start, mem->sys_stop, mem->card_start); - - map = mem->map; - if ((map > 4) || - (mem->card_start > 0x3ffffff) || - (mem->sys_start > mem->sys_stop) || - (mem->speed > 1000)) { - return -1; - } - - /* Turn off the window before changing anything */ - if (i365_get (s, I365_ADDRWIN) & I365_ENA_MEM (map)) - i365_bclr (s, I365_ADDRWIN, I365_ENA_MEM (map)); - - /* Take care of high byte, for PCI controllers */ - i365_set (s, CB_MEM_PAGE (map), mem->sys_start >> 24); - - base = I365_MEM (map); - i = (mem->sys_start >> 12) & 0x0fff; - if (mem->flags & MAP_16BIT) - i |= I365_MEM_16BIT; - if (mem->flags & MAP_0WS) - i |= I365_MEM_0WS; - i365_set_pair (s, base + I365_W_START, i); - - i = (mem->sys_stop >> 12) & 0x0fff; - switch (mem->speed / CYCLE_TIME) { - case 0: - break; - case 1: - i |= I365_MEM_WS0; - break; - case 2: - i |= I365_MEM_WS1; - break; - default: - i |= I365_MEM_WS1 | I365_MEM_WS0; - break; - } - i365_set_pair (s, base + I365_W_STOP, i); - - i = ((mem->card_start - mem->sys_start) >> 12) & 0x3fff; - if (mem->flags & MAP_WRPROT) - i |= I365_MEM_WRPROT; - if (mem->flags & MAP_ATTRIB) - i |= I365_MEM_REG; - i365_set_pair (s, base + I365_W_OFF, i); - - /* Turn on the window if necessary */ - if (mem->flags & MAP_ACTIVE) - i365_bset (s, I365_ADDRWIN, I365_ENA_MEM (map)); - return 0; -} /* i365_set_mem_map */ - -static int i365_set_io_map (socket_info_t * s, struct pccard_io_map *io) -{ - u_char map, ioctl; - - map = io->map; - /* comment out: comparison is always false due to limited range of data type */ - if ((map > 1) || /* (io->start > 0xffff) || (io->stop > 0xffff) || */ - (io->stop < io->start)) - return -1; - /* Turn off the window before changing anything */ - if (i365_get (s, I365_ADDRWIN) & I365_ENA_IO (map)) - i365_bclr (s, I365_ADDRWIN, I365_ENA_IO (map)); - i365_set_pair (s, I365_IO (map) + I365_W_START, io->start); - i365_set_pair (s, I365_IO (map) + I365_W_STOP, io->stop); - ioctl = i365_get (s, I365_IOCTL) & ~I365_IOCTL_MASK (map); - if (io->speed) - ioctl |= I365_IOCTL_WAIT (map); - if (io->flags & MAP_0WS) - ioctl |= I365_IOCTL_0WS (map); - if (io->flags & MAP_16BIT) - ioctl |= I365_IOCTL_16BIT (map); - if (io->flags & MAP_AUTOSZ) - ioctl |= I365_IOCTL_IOCS16 (map); - i365_set (s, I365_IOCTL, ioctl); - /* Turn on the window if necessary */ - if (io->flags & MAP_ACTIVE) - i365_bset (s, I365_ADDRWIN, I365_ENA_IO (map)); - return 0; -} /* i365_set_io_map */ - -/*====================================================================*/ - -static int i82365_init (void) -{ - u_int val; - int i; - - if ((socket.dev = pci_find_devices (supported, 0)) < 0) { - /* Controller not found */ - return 1; - } - debug ("i82365 Device Found!\n"); - - pci_read_config_dword (socket.dev, PCI_BASE_ADDRESS_0, &socket.cb_phys); - socket.cb_phys &= ~0xf; - - get_bridge_state (&socket); - set_bridge_opts (&socket); - - i = i365_get_status (&socket, &val); - - if (val & SS_DETECT) { - if (val & SS_3VCARD) { - state.Vcc = state.Vpp = 33; - puts (" 3.3V card found: "); - } else if (!(val & SS_XVCARD)) { - state.Vcc = state.Vpp = 50; - puts (" 5.0V card found: "); - } else { - puts ("i82365: unsupported voltage key\n"); - state.Vcc = state.Vpp = 0; - } - } else { - /* No card inserted */ - puts ("No card\n"); - return 1; - } - - state.flags = SS_IOCARD | SS_OUTPUT_ENA; - state.csc_mask = 0; - state.io_irq = 0; - - i365_set_socket (&socket, &state); - - for (i = 500; i; i--) { - if ((i365_get (&socket, I365_STATUS) & I365_CS_READY)) - break; - udelay (1000); - } - - if (i == 0) { - /* PC Card not ready for data transfer */ - puts ("i82365 PC Card not ready for data transfer\n"); - return 1; - } - debug (" PC Card ready for data transfer: "); - - mem.map = 0; - mem.flags = MAP_ATTRIB | MAP_ACTIVE; - mem.speed = 300; - mem.sys_start = CONFIG_SYS_PCMCIA_MEM_ADDR; - mem.sys_stop = CONFIG_SYS_PCMCIA_MEM_ADDR + CONFIG_SYS_PCMCIA_MEM_SIZE - 1; - mem.card_start = 0; - i365_set_mem_map (&socket, &mem); - - io.map = 0; - io.flags = MAP_AUTOSZ | MAP_ACTIVE; - io.speed = 0; - io.start = 0x0100; - io.stop = 0x010F; - i365_set_io_map (&socket, &io); - -#ifdef DEBUG - i82365_dump_regions (socket.dev); -#endif - - return 0; -} - -static void i82365_exit (void) -{ - io.map = 0; - io.flags = 0; - io.speed = 0; - io.start = 0; - io.stop = 0x1; - - i365_set_io_map (&socket, &io); - - mem.map = 0; - mem.flags = 0; - mem.speed = 0; - mem.sys_start = 0; - mem.sys_stop = 0x1000; - mem.card_start = 0; - - i365_set_mem_map (&socket, &mem); - - socket.state.sysctl &= 0xFFFF00FF; - - state.Vcc = state.Vpp = 0; - - i365_set_socket (&socket, &state); -} - -int pcmcia_on (void) -{ - u_int rc; - - debug ("Enable PCMCIA " PCMCIA_SLOT_MSG "\n"); - - rc = i82365_init(); - if (rc) - goto exit; - - rc = check_ide_device(0); - if (rc == 0) - goto exit; - - i82365_exit(); - -exit: - return rc; -} - -#if defined(CONFIG_CMD_PCMCIA) -int pcmcia_off (void) -{ - printf ("Disable PCMCIA " PCMCIA_SLOT_MSG "\n"); - - i82365_exit(); - - return 0; -} -#endif - -/*====================================================================== - - Debug stuff - -======================================================================*/ - -#ifdef DEBUG -static void i82365_dump_regions (pci_dev_t dev) -{ - u_int tmp[2]; - u_int *mem = (void *) socket.cb_phys; - u_char *cis = (void *) CONFIG_SYS_PCMCIA_MEM_ADDR; - u_char *ide = (void *) (CONFIG_SYS_ATA_BASE_ADDR + CONFIG_SYS_ATA_REG_OFFSET); - - pci_read_config_dword (dev, 0x00, tmp + 0); - pci_read_config_dword (dev, 0x80, tmp + 1); - - printf ("PCI CONF: %08X ... %08X\n", - tmp[0], tmp[1]); - printf ("PCI MEM: ... %08X ... %08X\n", - mem[0x8 / 4], mem[0x800 / 4]); - printf ("CIS: ...%c%c%c%c%c%c%c%c...\n", - cis[0x38], cis[0x3a], cis[0x3c], cis[0x3e], - cis[0x40], cis[0x42], cis[0x44], cis[0x48]); - printf ("CIS CONF: %02X %02X %02X ...\n", - cis[0x200], cis[0x202], cis[0x204]); - printf ("IDE: %02X %02X %02X %02X %02X %02X %02X %02X\n", - ide[0], ide[1], ide[2], ide[3], - ide[4], ide[5], ide[6], ide[7]); -} -#endif /* DEBUG */ - -#endif /* CONFIG_I82365 */ diff --git a/configs/atc_defconfig b/configs/atc_defconfig deleted file mode 100644 index 967be47..0000000 --- a/configs/atc_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_MPC8260=y -CONFIG_TARGET_ATC=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index c0d0cd9..5df0664 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,7 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +atc powerpc mpc8260 - - Wolfgang Denk wd@denx.de CPU86 powerpc mpc8260 - - Wolfgang Denk wd@denx.de CPU87 powerpc mpc8260 - - ep82xxm powerpc mpc8260 - - diff --git a/drivers/rtc/Makefile b/drivers/rtc/Makefile index 43f8546..fdcbc00 100644 --- a/drivers/rtc/Makefile +++ b/drivers/rtc/Makefile @@ -11,7 +11,6 @@ obj-$(CONFIG_RTC_AT91SAM9_RTT) += at91sam9_rtt.o obj-$(CONFIG_RTC_BFIN) += bfin_rtc.o obj-y += date.o obj-$(CONFIG_RTC_DAVINCI) += davinci.o -obj-$(CONFIG_RTC_DS12887) += ds12887.o obj-$(CONFIG_RTC_DS1302) += ds1302.o obj-$(CONFIG_RTC_DS1306) += ds1306.o obj-$(CONFIG_RTC_DS1307) += ds1307.o diff --git a/drivers/rtc/ds12887.c b/drivers/rtc/ds12887.c deleted file mode 100644 index d8a519b..0000000 --- a/drivers/rtc/ds12887.c +++ /dev/null @@ -1,217 +0,0 @@ -/* - * (C) Copyright 2003 - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * Date & Time support for the DS12887 RTC - */ - -#undef RTC_DEBUG - -#include <common.h> -#include <command.h> -#include <config.h> -#include <rtc.h> - -#if defined(CONFIG_CMD_DATE) - -#define RTC_SECONDS 0x00 -#define RTC_SECONDS_ALARM 0x01 -#define RTC_MINUTES 0x02 -#define RTC_MINUTES_ALARM 0x03 -#define RTC_HOURS 0x04 -#define RTC_HOURS_ALARM 0x05 -#define RTC_DAY_OF_WEEK 0x06 -#define RTC_DATE_OF_MONTH 0x07 -#define RTC_MONTH 0x08 -#define RTC_YEAR 0x09 -#define RTC_CONTROL_A 0x0A -#define RTC_CONTROL_B 0x0B -#define RTC_CONTROL_C 0x0C -#define RTC_CONTROL_D 0x0D - -#define RTC_CA_UIP 0x80 -#define RTC_CB_DM 0x04 -#define RTC_CB_24_12 0x02 -#define RTC_CB_SET 0x80 - -#if defined(CONFIG_ATC) - -static uchar rtc_read (uchar reg) -{ - uchar val; - - *(volatile unsigned char*)(RTC_PORT_ADDR) = reg; - __asm__ __volatile__ ("sync"); - - val = *(volatile unsigned char*)(RTC_PORT_DATA); - return (val); -} - -static void rtc_write (uchar reg, uchar val) -{ - *(volatile unsigned char*)(RTC_PORT_ADDR) = reg; - __asm__ __volatile__ ("sync"); - - *(volatile unsigned char*)(RTC_PORT_DATA) = val; - __asm__ __volatile__ ("sync"); -} - -#else -# error Board specific rtc access functions should be supplied -#endif - -int rtc_get (struct rtc_time *tmp) -{ - uchar sec, min, hour, mday, wday, mon, year; - - /* check if rtc is available for access */ - while( rtc_read(RTC_CONTROL_A) & RTC_CA_UIP) - ; - - sec = rtc_read(RTC_SECONDS); - min = rtc_read(RTC_MINUTES); - hour = rtc_read(RTC_HOURS); - mday = rtc_read(RTC_DATE_OF_MONTH); - wday = rtc_read(RTC_DAY_OF_WEEK); - mon = rtc_read(RTC_MONTH); - year = rtc_read(RTC_YEAR); - -#ifdef RTC_DEBUG - printf( "Get RTC year: %d; mon: %d; mday: %d; wday: %d; " - "hr: %d; min: %d; sec: %d\n", - year, mon, mday, wday, hour, min, sec ); - - printf ( "Alarms: hour: %02x min: %02x sec: %02x\n", - rtc_read (RTC_HOURS_ALARM), - rtc_read (RTC_MINUTES_ALARM), - rtc_read (RTC_SECONDS_ALARM) ); -#endif - - if( !(rtc_read(RTC_CONTROL_B) & RTC_CB_DM)) - { /* Information is in BCD format */ -printf(" Get: Convert BSD to BIN\n"); - tmp->tm_sec = bcd2bin (sec & 0x7F); - tmp->tm_min = bcd2bin (min & 0x7F); - tmp->tm_hour = bcd2bin (hour & 0x3F); - tmp->tm_mday = bcd2bin (mday & 0x3F); - tmp->tm_mon = bcd2bin (mon & 0x1F); - tmp->tm_year = bcd2bin (year); - tmp->tm_wday = bcd2bin (wday & 0x07); - } -else - { - tmp->tm_sec = sec & 0x7F; - tmp->tm_min = min & 0x7F; - tmp->tm_hour = hour & 0x3F; - tmp->tm_mday = mday & 0x3F; - tmp->tm_mon = mon & 0x1F; - tmp->tm_year = year; - tmp->tm_wday = wday & 0x07; - } - - - if(tmp->tm_year<70) - tmp->tm_year+=2000; - else - tmp->tm_year+=1900; - - tmp->tm_yday = 0; - tmp->tm_isdst= 0; -#ifdef RTC_DEBUG - printf ( "Get DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n", - tmp->tm_year, tmp->tm_mon, tmp->tm_mday, tmp->tm_wday, - tmp->tm_hour, tmp->tm_min, tmp->tm_sec); -#endif - - return 0; -} - -int rtc_set (struct rtc_time *tmp) -{ - uchar save_ctrl_b; - uchar sec, min, hour, mday, wday, mon, year; - -#ifdef RTC_DEBUG - printf ( "Set DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n", - tmp->tm_year, tmp->tm_mon, tmp->tm_mday, tmp->tm_wday, - tmp->tm_hour, tmp->tm_min, tmp->tm_sec); -#endif - - if( !(rtc_read(RTC_CONTROL_B) & RTC_CB_DM)) - { /* Information is in BCD format */ - year = bin2bcd(tmp->tm_year % 100); - mon = bin2bcd(tmp->tm_mon); - wday = bin2bcd(tmp->tm_wday); - mday = bin2bcd(tmp->tm_mday); - hour = bin2bcd(tmp->tm_hour); - min = bin2bcd(tmp->tm_min); - sec = bin2bcd(tmp->tm_sec); - } - else - { - year = tmp->tm_year % 100; - mon = tmp->tm_mon; - wday = tmp->tm_wday; - mday = tmp->tm_mday; - hour = tmp->tm_hour; - min = tmp->tm_min; - sec = tmp->tm_sec; - } - - /* disables the RTC to update the regs */ - save_ctrl_b = rtc_read(RTC_CONTROL_B); - save_ctrl_b |= RTC_CB_SET; - rtc_write(RTC_CONTROL_B, save_ctrl_b); - - rtc_write (RTC_YEAR, year); - rtc_write (RTC_MONTH, mon); - rtc_write (RTC_DAY_OF_WEEK, wday); - rtc_write (RTC_DATE_OF_MONTH, mday); - rtc_write (RTC_HOURS, hour); - rtc_write (RTC_MINUTES, min); - rtc_write (RTC_SECONDS, sec); - - /* enables the RTC to update the regs */ - save_ctrl_b &= ~RTC_CB_SET; - rtc_write(RTC_CONTROL_B, save_ctrl_b); - - return 0; -} - -void rtc_reset (void) -{ - struct rtc_time tmp; - uchar ctrl_rg; - - ctrl_rg = RTC_CB_SET; - rtc_write(RTC_CONTROL_B,ctrl_rg); - - tmp.tm_year = 1970 % 100; - tmp.tm_mon = 1; - tmp.tm_mday= 1; - tmp.tm_hour = 0; - tmp.tm_min = 0; - tmp.tm_sec = 0; - -#ifdef RTC_DEBUG - printf ( "RTC: %4d-%02d-%02d %2d:%02d:%02d UTC\n", - tmp.tm_year, tmp.tm_mon, tmp.tm_mday, - tmp.tm_hour, tmp.tm_min, tmp.tm_sec); -#endif - - ctrl_rg = RTC_CB_SET | RTC_CB_24_12 | RTC_CB_DM; - rtc_write(RTC_CONTROL_B,ctrl_rg); - rtc_set(&tmp); - - rtc_write(RTC_HOURS_ALARM, 0), - rtc_write(RTC_MINUTES_ALARM, 0), - rtc_write(RTC_SECONDS_ALARM, 0); - - ctrl_rg = RTC_CB_24_12 | RTC_CB_DM; - rtc_write(RTC_CONTROL_B,ctrl_rg); -} - -#endif diff --git a/include/configs/atc.h b/include/configs/atc.h deleted file mode 100644 index 77fa79a..0000000 --- a/include/configs/atc.h +++ /dev/null @@ -1,489 +0,0 @@ -/* - * (C) Copyright 2001 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_ATC 1 /* ...on a ATC board */ -#define CONFIG_CPM2 1 /* Has a CPM2 */ - -#define CONFIG_SYS_TEXT_BASE 0xFF000000 - -/* - * select serial console configuration - * - * if either CONFIG_CONS_ON_SMC or CONFIG_CONS_ON_SCC is selected, then - * CONFIG_CONS_INDEX must be set to the channel number (1-2 for SMC, 1-4 - * for SCC). - * - * if CONFIG_CONS_NONE is defined, then the serial console routines must - * defined elsewhere (for example, on the cogent platform, there are serial - * ports on the motherboard which are used for the serial console - see - * cogent/cma101/serial.[ch]). - */ -#define CONFIG_CONS_ON_SMC /* define if console on SMC */ -#undef CONFIG_CONS_ON_SCC /* define if console on SCC */ -#undef CONFIG_CONS_NONE /* define if console on something else*/ -#define CONFIG_CONS_INDEX 2 /* which serial channel for console */ - -#define CONFIG_BAUDRATE 115200 - -/* - * select ethernet configuration - * - * if either CONFIG_ETHER_ON_SCC or CONFIG_ETHER_ON_FCC is selected, then - * CONFIG_ETHER_INDEX must be set to the channel number (1-4 for SCC, 1-3 - * for FCC) - * - * if CONFIG_ETHER_NONE is defined, then either the ethernet routines must be - * defined elsewhere (as for the console), or CONFIG_CMD_NET must be unset. - */ -#undef CONFIG_ETHER_ON_SCC /* define if ether on SCC */ -#undef CONFIG_ETHER_NONE /* define if ether on something else */ -#define CONFIG_ETHER_ON_FCC - -#define CONFIG_ETHER_ON_FCC2 - -/* - * - Rx-CLK is CLK13 - * - Tx-CLK is CLK14 - * - RAM for BD/Buffers is on the 60x Bus (see 28-13) - * - Enable Full Duplex in FSMR - */ -# define CONFIG_SYS_CMXFCR_MASK2 (CMXFCR_FC2|CMXFCR_RF2CS_MSK|CMXFCR_TF2CS_MSK) -# define CONFIG_SYS_CMXFCR_VALUE2 (CMXFCR_RF2CS_CLK13|CMXFCR_TF2CS_CLK14) -# define CONFIG_SYS_CPMFCR_RAMTYPE 0 -# define CONFIG_SYS_FCC_PSMR (FCC_PSMR_FDE|FCC_PSMR_LPB) - -#define CONFIG_ETHER_ON_FCC3 - -/* - * - Rx-CLK is CLK15 - * - Tx-CLK is CLK16 - * - RAM for BD/Buffers is on the local Bus (see 28-13) - * - Enable Half Duplex in FSMR - */ -# define CONFIG_SYS_CMXFCR_MASK3 (CMXFCR_FC3|CMXFCR_RF3CS_MSK|CMXFCR_TF3CS_MSK) -# define CONFIG_SYS_CMXFCR_VALUE3 (CMXFCR_RF3CS_CLK15|CMXFCR_TF3CS_CLK16) - -/* system clock rate (CLKIN) - equal to the 60x and local bus speed */ -#define CONFIG_8260_CLKIN 64000000 /* in Hz */ - -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ - -#undef CONFIG_CLOCKS_IN_MHZ /* clocks passsed to Linux in Hz */ - -#define CONFIG_PREBOOT \ - "echo;" \ - "echo Type \"run flash_nfs\" to mount root filesystem over NFS;"\ - "echo" - -#undef CONFIG_BOOTARGS -#define CONFIG_BOOTCOMMAND \ - "bootp;" \ - "setenv bootargs root=/dev/nfs rw " \ - "nfsroot=${serverip}:${rootpath} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off;"\ - "bootm" - -/*----------------------------------------------------------------------- - * Miscellaneous configuration options - */ - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ - - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_EEPROM -#define CONFIG_CMD_PCI -#define CONFIG_CMD_PCMCIA -#define CONFIG_CMD_DATE -#define CONFIG_CMD_IDE - - -#define CONFIG_DOS_PARTITION - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -#define CONFIG_SYS_PIO_MODE 0 /* IDE interface in PIO Mode 0 */ - -#define CONFIG_SYS_RESET_ADDRESS 0xFFF00100 /* "bad" address */ - -#define CONFIG_SYS_ALLOC_DPRAM - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -#define CONFIG_SPI - -#define CONFIG_RTC_DS12887 - -#define RTC_BASE_ADDR 0xF5000000 -#define RTC_PORT_ADDR RTC_BASE_ADDR + 0x800 -#define RTC_PORT_DATA RTC_BASE_ADDR + 0x808 - -#define CONFIG_MISC_INIT_R - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * Flash configuration - */ - -#define CONFIG_SYS_FLASH_BASE 0xFF000000 -#define CONFIG_SYS_FLASH_SIZE 0x00800000 - -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max num of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 128 /* max num of sects on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 240000 /* Flash Erase Timeout (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (in ms) */ - -#define CONFIG_FLASH_16BIT - -/*----------------------------------------------------------------------- - * Hard Reset Configuration Words - * - * if you change bits in the HRCW, you must also change the CONFIG_SYS_* - * defines for the various registers affected by the HRCW e.g. changing - * HRCW_DPPCxx requires you to also change CONFIG_SYS_SIUMCR. - */ -#define CONFIG_SYS_HRCW_MASTER (HRCW_CIP | HRCW_ISB100 | HRCW_BMS | \ - HRCW_BPS10 |\ - HRCW_APPC10) - -/* no slaves so just fill with zeros */ -#define CONFIG_SYS_HRCW_SLAVE1 0 -#define CONFIG_SYS_HRCW_SLAVE2 0 -#define CONFIG_SYS_HRCW_SLAVE3 0 -#define CONFIG_SYS_HRCW_SLAVE4 0 -#define CONFIG_SYS_HRCW_SLAVE5 0 -#define CONFIG_SYS_HRCW_SLAVE6 0 -#define CONFIG_SYS_HRCW_SLAVE7 0 - -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xF0000000 - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - * - * 60x SDRAM is mapped at CONFIG_SYS_SDRAM_BASE. - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_SDRAM_MAX_SIZE 0x08000000 /* max. 128 MB */ -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_MONITOR_LEN (192 << 10) /* Reserve 192 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc()*/ - -#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) -# define CONFIG_SYS_RAMBOOT -#endif - -#define CONFIG_PCI -#define CONFIG_PCI_INDIRECT_BRIDGE -#define CONFIG_PCI_PNP -#define CONFIG_SYS_PCI_MSTR_IO_BUS 0x00000000 /* PCI base */ - -#if 1 -/* environment is in Flash */ -#define CONFIG_ENV_IS_IN_FLASH 1 -# define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE+0x30000) -# define CONFIG_ENV_SIZE 0x10000 -# define CONFIG_ENV_SECT_SIZE 0x10000 -#else -#define CONFIG_ENV_IS_IN_EEPROM 1 -#define CONFIG_ENV_OFFSET 0 -#define CONFIG_ENV_SIZE 2048 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 /* 16-byte page size */ -#endif - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC8260 CPU */ -#if defined(CONFIG_CMD_KGDB) -# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * HIDx - Hardware Implementation-dependent Registers 2-11 - *----------------------------------------------------------------------- - * HID0 also contains cache control - initially enable both caches and - * invalidate contents, then the final state leaves only the instruction - * cache enabled. Note that Power-On and Hard reset invalidate the caches, - * but Soft reset does not. - * - * HID1 has only read-only information - nothing to set. - */ -#define CONFIG_SYS_HID0_INIT (HID0_ICE|HID0_DCE|HID0_ICFI|\ - HID0_DCI|HID0_IFEM|HID0_ABE) -#define CONFIG_SYS_HID0_FINAL (HID0_IFEM|HID0_ABE) -#define CONFIG_SYS_HID2 0 - -/*----------------------------------------------------------------------- - * RMR - Reset Mode Register 5-5 - *----------------------------------------------------------------------- - * turn on Checkstop Reset Enable - */ -#define CONFIG_SYS_RMR RMR_CSRE - -/*----------------------------------------------------------------------- - * BCR - Bus Configuration 4-25 - *----------------------------------------------------------------------- - */ -#define BCR_APD01 0x10000000 -#define CONFIG_SYS_BCR (BCR_APD01|BCR_ETM|BCR_LETM) /* 8260 mode */ - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 4-31 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_SIUMCR (SIUMCR_BBD|SIUMCR_APPC10|\ - SIUMCR_CS10PC00|SIUMCR_BCTLC10) - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 4-35 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Watchdog & Bus Monitor Timer max, 60x Bus Monitor enable - */ -#if defined(CONFIG_WATCHDOG) -#define CONFIG_SYS_SYPCR (SYPCR_SWTC|SYPCR_BMT|SYPCR_PBME|SYPCR_LBME|\ - SYPCR_SWRI|SYPCR_SWP|SYPCR_SWE) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC|SYPCR_BMT|SYPCR_PBME|SYPCR_LBME|\ - SYPCR_SWRI|SYPCR_SWP) -#endif /* CONFIG_WATCHDOG */ - -/*----------------------------------------------------------------------- - * TMCNTSC - Time Counter Status and Control 4-40 - *----------------------------------------------------------------------- - * Clear once per Second and Alarm Interrupt Status, Set 32KHz timersclk, - * and enable Time Counter - */ -#define CONFIG_SYS_TMCNTSC (TMCNTSC_SEC|TMCNTSC_ALR|TMCNTSC_TCF|TMCNTSC_TCE) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 4-42 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Set 32KHz timersclk, and enable - * Periodic timer - */ -#define CONFIG_SYS_PISCR (PISCR_PS|PISCR_PTF|PISCR_PTE) - -/*----------------------------------------------------------------------- - * SCCR - System Clock Control 9-8 - *----------------------------------------------------------------------- - * Ensure DFBRG is Divide by 16 - */ -#define CONFIG_SYS_SCCR SCCR_DFBRG01 - -/*----------------------------------------------------------------------- - * RCCR - RISC Controller Configuration 13-7 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RCCR 0 - -#define CONFIG_SYS_MIN_AM_MASK 0xC0000000 -/*----------------------------------------------------------------------- - * MPTPR - Memory Refresh Timer Prescaler Register 10-18 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_MPTPR 0x1F00 - -/*----------------------------------------------------------------------- - * PSRT - Refresh Timer Register 10-16 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_PSRT 0x0f - -/*----------------------------------------------------------------------- - * PSRT - SDRAM Mode Register 10-10 - *----------------------------------------------------------------------- - */ - - /* SDRAM initialization values for 8-column chips - */ -#define CONFIG_SYS_OR2_8COL (CONFIG_SYS_MIN_AM_MASK |\ - ORxS_BPD_4 |\ - ORxS_ROWST_PBI1_A7 |\ - ORxS_NUMR_12) - -#define CONFIG_SYS_PSDMR_8COL (PSDMR_PBI |\ - PSDMR_SDAM_A15_IS_A5 |\ - PSDMR_BSMA_A15_A17 |\ - PSDMR_SDA10_PBI1_A7 |\ - PSDMR_RFRC_7_CLK |\ - PSDMR_PRETOACT_3W |\ - PSDMR_ACTTORW_2W |\ - PSDMR_LDOTOPRE_1C |\ - PSDMR_WRC_1C |\ - PSDMR_CL_2) - - /* SDRAM initialization values for 9-column chips - */ -#define CONFIG_SYS_OR2_9COL (CONFIG_SYS_MIN_AM_MASK |\ - ORxS_BPD_4 |\ - ORxS_ROWST_PBI1_A6 |\ - ORxS_NUMR_12) - -#define CONFIG_SYS_PSDMR_9COL (PSDMR_PBI |\ - PSDMR_SDAM_A16_IS_A5 |\ - PSDMR_BSMA_A15_A17 |\ - PSDMR_SDA10_PBI1_A6 |\ - PSDMR_RFRC_7_CLK |\ - PSDMR_PRETOACT_3W |\ - PSDMR_ACTTORW_2W |\ - PSDMR_LDOTOPRE_1C |\ - PSDMR_WRC_1C |\ - PSDMR_CL_2) - -/* - * Init Memory Controller: - * - * Bank Bus Machine PortSz Device - * ---- --- ------- ------ ------ - * 0 60x GPCM 8 bit Boot ROM - * 1 60x GPCM 64 bit FLASH - * 2 60x SDRAM 64 bit SDRAM - * - */ - -#define CONFIG_SYS_MRS_OFFS 0x00000000 - -/* Bank 0 - FLASH - */ -#define CONFIG_SYS_BR0_PRELIM ((CONFIG_SYS_FLASH_BASE & BRx_BA_MSK) |\ - BRx_PS_16 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR0_PRELIM (P2SZ_TO_AM(CONFIG_SYS_FLASH_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV1 |\ - ORxG_SCY_3_CLK |\ - ORxU_EHTR_8IDLE) - - -/* Bank 2 - 60x bus SDRAM - */ -#ifndef CONFIG_SYS_RAMBOOT -#define CONFIG_SYS_BR2_PRELIM ((CONFIG_SYS_SDRAM_BASE & BRx_BA_MSK) |\ - BRx_PS_64 |\ - BRx_MS_SDRAM_P |\ - BRx_V) - -#define CONFIG_SYS_OR2_PRELIM CONFIG_SYS_OR2_8COL - -#define CONFIG_SYS_PSDMR CONFIG_SYS_PSDMR_8COL -#endif /* CONFIG_SYS_RAMBOOT */ - -#define CONFIG_SYS_BR4_PRELIM ((RTC_BASE_ADDR & BRx_BA_MSK) |\ - BRx_PS_8 |\ - BRx_MS_UPMA |\ - BRx_V) - -#define CONFIG_SYS_OR4_PRELIM (ORxU_AM_MSK | ORxU_BI) - -/*----------------------------------------------------------------------- - * PCMCIA stuff - *----------------------------------------------------------------------- - * - */ -#define CONFIG_I82365 - -#define CONFIG_SYS_PCMCIA_MEM_ADDR 0x81000000 -#define CONFIG_SYS_PCMCIA_MEM_SIZE 0x1000 - -/*----------------------------------------------------------------------- - * IDE/ATA stuff (Supports IDE harddisk on PCMCIA Adapter) - *----------------------------------------------------------------------- - */ - -#define CONFIG_IDE_PREINIT 1 /* Use preinit IDE hook */ -#define CONFIG_IDE_8xx_PCCARD 1 /* Use IDE with PC Card Adapter */ - -#undef CONFIG_IDE_8xx_DIRECT /* Direct IDE not supported */ -#undef CONFIG_IDE_LED /* LED for ide not supported */ -#undef CONFIG_IDE_RESET /* reset for ide not supported */ - -#define CONFIG_SYS_IDE_MAXBUS 1 /* max. 1 IDE bus */ -#define CONFIG_SYS_IDE_MAXDEVICE 1 /* max. 1 drive per IDE bus */ - -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 - -#define CONFIG_SYS_ATA_BASE_ADDR 0xa0000000 - -/* Offset for data I/O */ -#define CONFIG_SYS_ATA_DATA_OFFSET 0x100 - -/* Offset for normal register accesses */ -#define CONFIG_SYS_ATA_REG_OFFSET 0x100 - -/* Offset for alternate registers */ -#define CONFIG_SYS_ATA_ALT_OFFSET 0x108 - -#endif /* __CONFIG_H */ diff --git a/include/pcmcia.h b/include/pcmcia.h index 8e8831f..c8a730c 100644 --- a/include/pcmcia.h +++ b/include/pcmcia.h @@ -23,8 +23,6 @@
#if defined(CONFIG_TQM8xxL) # define CONFIG_PCMCIA_SLOT_B /* The TQM8xxL use SLOT_B */ -#elif defined(CONFIG_ATC) /* The ATC use SLOT_A */ -# define CONFIG_PCMCIA_SLOT_A #else # error "PCMCIA Slot not configured" #endif
All the MPC824X boards are still non-generic boards: A3000, CPC45, CU824, eXalion, MVBLUE, MUSENKI, Sandpoint824x, utx8245
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Wolfgang Denk wd@denx.de Cc: Josef Wagner Wagner@Microsys.de Cc: Torsten Demke torsten.demke@fci.com Cc: Jim Thompson jim@musenki.com Cc: Greg Allen gallen@arlut.utexas.edu ---
MAKEALL | 6 - README | 5 - arch/powerpc/Kconfig | 4 - arch/powerpc/cpu/mpc824x/Kconfig | 48 -- arch/powerpc/cpu/mpc824x/Makefile | 11 - arch/powerpc/cpu/mpc824x/config.mk | 8 - arch/powerpc/cpu/mpc824x/cpu.c | 262 ------ arch/powerpc/cpu/mpc824x/cpu_init.c | 311 ------- arch/powerpc/cpu/mpc824x/drivers/epic.h | 1 - arch/powerpc/cpu/mpc824x/drivers/epic/README | 102 --- arch/powerpc/cpu/mpc824x/drivers/epic/epic.h | 163 ---- arch/powerpc/cpu/mpc824x/drivers/epic/epic1.c | 517 ------------ arch/powerpc/cpu/mpc824x/drivers/epic/epic2.S | 196 ----- arch/powerpc/cpu/mpc824x/drivers/epic/epicutil.S | 57 -- arch/powerpc/cpu/mpc824x/drivers/errors.h | 212 ----- arch/powerpc/cpu/mpc824x/drivers/i2c/i2c.c | 254 ------ arch/powerpc/cpu/mpc824x/interrupts.c | 77 -- arch/powerpc/cpu/mpc824x/pci.c | 75 -- arch/powerpc/cpu/mpc824x/speed.c | 102 --- arch/powerpc/cpu/mpc824x/start.S | 724 ----------------- arch/powerpc/cpu/mpc824x/traps.c | 194 ----- arch/powerpc/cpu/mpc824x/u-boot.lds | 76 -- arch/powerpc/include/asm/processor.h | 2 - board/a3000/Kconfig | 9 - board/a3000/MAINTAINERS | 6 - board/a3000/Makefile | 8 - board/a3000/README | 17 - board/a3000/a3000.c | 101 --- board/a3000/flash.c | 438 ---------- board/cpc45/Kconfig | 9 - board/cpc45/MAINTAINERS | 7 - board/cpc45/Makefile | 8 - board/cpc45/cpc45.c | 250 ------ board/cpc45/flash.c | 506 ------------ board/cpc45/ide.c | 128 --- board/cpc45/pd67290.c | 797 ------------------ board/cpc45/plx9030.c | 156 ---- board/cu824/Kconfig | 9 - board/cu824/MAINTAINERS | 6 - board/cu824/Makefile | 8 - board/cu824/README | 453 ----------- board/cu824/cu824.c | 83 -- board/cu824/flash.c | 470 ----------- board/eXalion/Kconfig | 9 - board/eXalion/MAINTAINERS | 6 - board/eXalion/Makefile | 8 - board/eXalion/eXalion.c | 283 ------- board/eXalion/eXalion.h | 36 - board/eXalion/piix_pci.h | 156 ---- board/musenki/Kconfig | 9 - board/musenki/MAINTAINERS | 6 - board/musenki/Makefile | 8 - board/musenki/README | 298 ------- board/musenki/flash.c | 496 ------------ board/musenki/musenki.c | 94 --- board/mvblue/Kconfig | 9 - board/mvblue/MAINTAINERS | 6 - board/mvblue/Makefile | 8 - board/mvblue/flash.c | 570 ------------- board/mvblue/mvblue.c | 253 ------ board/mvblue/u-boot.lds | 86 -- board/sandpoint/Kconfig | 19 - board/sandpoint/MAINTAINERS | 12 - board/sandpoint/Makefile | 8 - board/sandpoint/README | 411 ---------- board/sandpoint/dinkdl | 2 - board/sandpoint/flash.c | 748 ----------------- board/sandpoint/sandpoint.c | 91 --- board/sandpoint/u-boot.lds | 84 -- board/utx8245/Kconfig | 9 - board/utx8245/MAINTAINERS | 6 - board/utx8245/Makefile | 13 - board/utx8245/flash.c | 544 ------------- board/utx8245/utx8245.c | 119 --- common/cmd_pcmcia.c | 3 - configs/A3000_defconfig | 3 - configs/CPC45_ROMBOOT_defconfig | 4 - configs/CPC45_defconfig | 3 - configs/CU824_defconfig | 3 - configs/MUSENKI_defconfig | 3 - configs/MVBLUE_defconfig | 3 - configs/Sandpoint8240_defconfig | 3 - configs/Sandpoint8245_defconfig | 3 - configs/eXalion_defconfig | 3 - configs/utx8245_defconfig | 3 - doc/README.scrapyard | 9 + drivers/pcmcia/Makefile | 1 - drivers/pcmcia/i82365.c | 989 ----------------------- include/configs/A3000.h | 293 ------- include/configs/CPC45.h | 489 ----------- include/configs/CU824.h | 286 ------- include/configs/MUSENKI.h | 275 ------- include/configs/MVBLUE.h | 325 -------- include/configs/Sandpoint8240.h | 398 --------- include/configs/Sandpoint8245.h | 376 --------- include/configs/eXalion.h | 433 ---------- include/configs/utx8245.h | 408 ---------- include/mpc824x.h | 523 ------------ include/pci.h | 4 - include/pcmcia/cirrus.h | 180 ----- include/pcmcia/i82365.h | 154 ---- include/pcmcia/ss.h | 133 --- include/pcmcia/ti113x.h | 234 ------ include/ppc_asm.tmpl | 4 +- post/drivers/memory.c | 2 +- 105 files changed, 12 insertions(+), 16821 deletions(-) delete mode 100644 arch/powerpc/cpu/mpc824x/Kconfig delete mode 100644 arch/powerpc/cpu/mpc824x/Makefile delete mode 100644 arch/powerpc/cpu/mpc824x/config.mk delete mode 100644 arch/powerpc/cpu/mpc824x/cpu.c delete mode 100644 arch/powerpc/cpu/mpc824x/cpu_init.c delete mode 100644 arch/powerpc/cpu/mpc824x/drivers/epic.h delete mode 100644 arch/powerpc/cpu/mpc824x/drivers/epic/README delete mode 100644 arch/powerpc/cpu/mpc824x/drivers/epic/epic.h delete mode 100644 arch/powerpc/cpu/mpc824x/drivers/epic/epic1.c delete mode 100644 arch/powerpc/cpu/mpc824x/drivers/epic/epic2.S delete mode 100644 arch/powerpc/cpu/mpc824x/drivers/epic/epicutil.S delete mode 100644 arch/powerpc/cpu/mpc824x/drivers/errors.h delete mode 100644 arch/powerpc/cpu/mpc824x/drivers/i2c/i2c.c delete mode 100644 arch/powerpc/cpu/mpc824x/interrupts.c delete mode 100644 arch/powerpc/cpu/mpc824x/pci.c delete mode 100644 arch/powerpc/cpu/mpc824x/speed.c delete mode 100644 arch/powerpc/cpu/mpc824x/start.S delete mode 100644 arch/powerpc/cpu/mpc824x/traps.c delete mode 100644 arch/powerpc/cpu/mpc824x/u-boot.lds delete mode 100644 board/a3000/Kconfig delete mode 100644 board/a3000/MAINTAINERS delete mode 100644 board/a3000/Makefile delete mode 100644 board/a3000/README delete mode 100644 board/a3000/a3000.c delete mode 100644 board/a3000/flash.c delete mode 100644 board/cpc45/Kconfig delete mode 100644 board/cpc45/MAINTAINERS delete mode 100644 board/cpc45/Makefile delete mode 100644 board/cpc45/cpc45.c delete mode 100644 board/cpc45/flash.c delete mode 100644 board/cpc45/ide.c delete mode 100644 board/cpc45/pd67290.c delete mode 100644 board/cpc45/plx9030.c delete mode 100644 board/cu824/Kconfig delete mode 100644 board/cu824/MAINTAINERS delete mode 100644 board/cu824/Makefile delete mode 100644 board/cu824/README delete mode 100644 board/cu824/cu824.c delete mode 100644 board/cu824/flash.c delete mode 100644 board/eXalion/Kconfig delete mode 100644 board/eXalion/MAINTAINERS delete mode 100644 board/eXalion/Makefile delete mode 100644 board/eXalion/eXalion.c delete mode 100644 board/eXalion/eXalion.h delete mode 100644 board/eXalion/piix_pci.h delete mode 100644 board/musenki/Kconfig delete mode 100644 board/musenki/MAINTAINERS delete mode 100644 board/musenki/Makefile delete mode 100644 board/musenki/README delete mode 100644 board/musenki/flash.c delete mode 100644 board/musenki/musenki.c delete mode 100644 board/mvblue/Kconfig delete mode 100644 board/mvblue/MAINTAINERS delete mode 100644 board/mvblue/Makefile delete mode 100644 board/mvblue/flash.c delete mode 100644 board/mvblue/mvblue.c delete mode 100644 board/mvblue/u-boot.lds delete mode 100644 board/sandpoint/Kconfig delete mode 100644 board/sandpoint/MAINTAINERS delete mode 100644 board/sandpoint/Makefile delete mode 100644 board/sandpoint/README delete mode 100644 board/sandpoint/dinkdl delete mode 100644 board/sandpoint/flash.c delete mode 100644 board/sandpoint/sandpoint.c delete mode 100644 board/sandpoint/u-boot.lds delete mode 100644 board/utx8245/Kconfig delete mode 100644 board/utx8245/MAINTAINERS delete mode 100644 board/utx8245/Makefile delete mode 100644 board/utx8245/flash.c delete mode 100644 board/utx8245/utx8245.c delete mode 100644 configs/A3000_defconfig delete mode 100644 configs/CPC45_ROMBOOT_defconfig delete mode 100644 configs/CPC45_defconfig delete mode 100644 configs/CU824_defconfig delete mode 100644 configs/MUSENKI_defconfig delete mode 100644 configs/MVBLUE_defconfig delete mode 100644 configs/Sandpoint8240_defconfig delete mode 100644 configs/Sandpoint8245_defconfig delete mode 100644 configs/eXalion_defconfig delete mode 100644 configs/utx8245_defconfig delete mode 100644 drivers/pcmcia/i82365.c delete mode 100644 include/configs/A3000.h delete mode 100644 include/configs/CPC45.h delete mode 100644 include/configs/CU824.h delete mode 100644 include/configs/MUSENKI.h delete mode 100644 include/configs/MVBLUE.h delete mode 100644 include/configs/Sandpoint8240.h delete mode 100644 include/configs/Sandpoint8245.h delete mode 100644 include/configs/eXalion.h delete mode 100644 include/configs/utx8245.h delete mode 100644 include/mpc824x.h delete mode 100644 include/pcmcia/cirrus.h delete mode 100644 include/pcmcia/i82365.h delete mode 100644 include/pcmcia/ss.h delete mode 100644 include/pcmcia/ti113x.h
diff --git a/MAKEALL b/MAKEALL index 4822054..208232e 100755 --- a/MAKEALL +++ b/MAKEALL @@ -292,12 +292,6 @@ LIST_8xx="$(targets_by_cpu mpc8xx)" LIST_4xx="$(targets_by_cpu ppc4xx)"
######################################################################### -## MPC824x Systems -######################################################################### - -LIST_824x="$(targets_by_cpu mpc824x)" - -######################################################################### ## MPC8260 Systems (includes 8250, 8255 etc.) #########################################################################
diff --git a/README b/README index 4ca04d0..43aa3af 100644 --- a/README +++ b/README @@ -186,7 +186,6 @@ Directory Hierarchy: /mpc5xx Files specific to Freescale MPC5xx CPUs /mpc5xxx Files specific to Freescale MPC5xxx CPUs /mpc8xx Files specific to Freescale MPC8xx CPUs - /mpc824x Files specific to Freescale MPC824x CPUs /mpc8260 Files specific to Freescale MPC8260 CPUs /mpc85xx Files specific to Freescale MPC85xx CPUs /ppc4xx Files specific to AMCC PowerPC 4xx CPUs @@ -326,10 +325,6 @@ The following options need to be configured: multiple fs option at one time for marvell soc family
-- MPC824X Family Member (if CONFIG_MPC824X is defined) - Define exactly one of - CONFIG_MPC8240, CONFIG_MPC8245 - - 8xx CPU Options: (if using an MPC8xx CPU) CONFIG_8xx_GCLK_FREQ - deprecated: CPU clock if get_gclk_freq() cannot work diff --git a/arch/powerpc/Kconfig b/arch/powerpc/Kconfig index 6f96c7c..7a50301 100644 --- a/arch/powerpc/Kconfig +++ b/arch/powerpc/Kconfig @@ -19,9 +19,6 @@ config 5xx config MPC5xxx bool "MPC5xxx"
-config MPC824X - bool "MPC824X" - config MPC8260 bool "MPC8260"
@@ -46,7 +43,6 @@ source "arch/powerpc/cpu/74xx_7xx/Kconfig" source "arch/powerpc/cpu/mpc512x/Kconfig" source "arch/powerpc/cpu/mpc5xx/Kconfig" source "arch/powerpc/cpu/mpc5xxx/Kconfig" -source "arch/powerpc/cpu/mpc824x/Kconfig" source "arch/powerpc/cpu/mpc8260/Kconfig" source "arch/powerpc/cpu/mpc83xx/Kconfig" source "arch/powerpc/cpu/mpc85xx/Kconfig" diff --git a/arch/powerpc/cpu/mpc824x/Kconfig b/arch/powerpc/cpu/mpc824x/Kconfig deleted file mode 100644 index 4f98423..0000000 --- a/arch/powerpc/cpu/mpc824x/Kconfig +++ /dev/null @@ -1,48 +0,0 @@ -menu "mpc824x CPU" - depends on MPC824X - -config SYS_CPU - default "mpc824x" - -choice - prompt "Target select" - -config TARGET_A3000 - bool "Support A3000" - -config TARGET_CPC45 - bool "Support CPC45" - -config TARGET_CU824 - bool "Support CU824" - -config TARGET_EXALION - bool "Support eXalion" - -config TARGET_MUSENKI - bool "Support MUSENKI" - -config TARGET_MVBLUE - bool "Support MVBLUE" - -config TARGET_SANDPOINT8240 - bool "Support Sandpoint8240" - -config TARGET_SANDPOINT8245 - bool "Support Sandpoint8245" - -config TARGET_UTX8245 - bool "Support utx8245" - -endchoice - -source "board/a3000/Kconfig" -source "board/cpc45/Kconfig" -source "board/cu824/Kconfig" -source "board/eXalion/Kconfig" -source "board/musenki/Kconfig" -source "board/mvblue/Kconfig" -source "board/sandpoint/Kconfig" -source "board/utx8245/Kconfig" - -endmenu diff --git a/arch/powerpc/cpu/mpc824x/Makefile b/arch/powerpc/cpu/mpc824x/Makefile deleted file mode 100644 index 2c8be92..0000000 --- a/arch/powerpc/cpu/mpc824x/Makefile +++ /dev/null @@ -1,11 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -extra-y = start.o -obj-y = traps.o cpu.o cpu_init.o interrupts.o speed.o \ - drivers/epic/epic1.o drivers/i2c/i2c.o pci.o -obj-y += ../mpc8260/bedbug_603e.o diff --git a/arch/powerpc/cpu/mpc824x/config.mk b/arch/powerpc/cpu/mpc824x/config.mk deleted file mode 100644 index ecfb07e..0000000 --- a/arch/powerpc/cpu/mpc824x/config.mk +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2000-2010 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -PLATFORM_CPPFLAGS += -mstring -mcpu=603e -msoft-float diff --git a/arch/powerpc/cpu/mpc824x/cpu.c b/arch/powerpc/cpu/mpc824x/cpu.c deleted file mode 100644 index eaa4e87..0000000 --- a/arch/powerpc/cpu/mpc824x/cpu.c +++ /dev/null @@ -1,262 +0,0 @@ -/* - * (C) Copyright 2000 - 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <config.h> -#include <mpc824x.h> -#include <common.h> -#include <command.h> - -DECLARE_GLOBAL_DATA_PTR; - -int checkcpu (void) -{ - unsigned int pvr = get_pvr (); - unsigned int version = pvr >> 16; - unsigned char revision; - ulong clock = gd->cpu_clk; - char buf[32]; - - puts ("CPU: "); - - switch (version) { - case CPU_TYPE_8240: - puts ("MPC8240"); - break; - - case CPU_TYPE_8245: - puts ("MPC8245"); - break; - - default: - return -1; /*not valid for this source */ - } - - CONFIG_READ_BYTE (REVID, revision); - - if (revision) { - printf (" Revision %d.%d", - (revision & 0xf0) >> 4, - (revision & 0x0f)); - } else { - return -1; /* no valid CPU revision info */ - } - - printf(" at %s MHz: ", strmhz(buf, clock)); - - print_size(checkicache(), " I-Cache "); - print_size(checkdcache(), " D-Cache\n"); - - return 0; -} - -/* ------------------------------------------------------------------------- */ -/* L1 i-cache */ - -int checkicache (void) -{ - /*TODO*/ - return 128 * 4 * 32; -}; - -/* ------------------------------------------------------------------------- */ -/* L1 d-cache */ - -int checkdcache (void) -{ - /*TODO*/ - return 128 * 4 * 32; - -}; - -/*------------------------------------------------------------------- */ - -int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - ulong msr, addr; - - /* Interrupts and MMU off */ - __asm__ ("mtspr 81, 0"); - - /* Interrupts and MMU off */ - __asm__ __volatile__ ("mfmsr %0":"=r" (msr):); - - msr &= ~0x1030; - __asm__ __volatile__ ("mtmsr %0"::"r" (msr)); - - /* - * Trying to execute the next instruction at a non-existing address - * should cause a machine check, resulting in reset - */ -#ifdef CONFIG_SYS_RESET_ADDRESS - addr = CONFIG_SYS_RESET_ADDRESS; -#else - /* - * note: when CONFIG_SYS_MONITOR_BASE points to a RAM address, - * CONFIG_SYS_MONITOR_BASE - sizeof (ulong) is usually a valid - * address. Better pick an address known to be invalid on - * your system and assign it to CONFIG_SYS_RESET_ADDRESS. - * "(ulong)-1" used to be a good choice for many systems... - */ - addr = CONFIG_SYS_MONITOR_BASE - sizeof (ulong); -#endif - ((void (*)(void)) addr) (); - return 1; - -} - -/* ------------------------------------------------------------------------- */ - -/* - * Get timebase clock frequency (like cpu_clk in Hz) - * This is the sys_logic_clk (memory bus) divided by 4 - */ -unsigned long get_tbclk (void) -{ - return ((get_bus_freq (0) + 2L) / 4L); -} - -/* ------------------------------------------------------------------------- */ - -/* - * The MPC824x has an integrated PCI controller known as the MPC107. - * The following are MPC107 Bridge Controller and PCI Support functions - * - */ - -/* - * This procedure reads a 32-bit address MPC107 register, and returns - * a 32 bit value. It swaps the address to little endian before - * writing it to config address, and swaps the value to big endian - * before returning to the caller. - */ -unsigned int mpc824x_mpc107_getreg (unsigned int regNum) -{ - unsigned int temp; - - /* swap the addr. to little endian */ - *(volatile unsigned int *) CHRP_REG_ADDR = PCISWAP (regNum); - temp = *(volatile unsigned int *) CHRP_REG_DATA; - return PCISWAP (temp); /* swap the data upon return */ -} - -/* - * This procedure writes a 32-bit address MPC107 register. It swaps - * the address to little endian before writing it to config address. - */ - -void mpc824x_mpc107_setreg (unsigned int regNum, unsigned int regVal) -{ - /* swap the addr. to little endian */ - *(volatile unsigned int *) CHRP_REG_ADDR = PCISWAP (regNum); - *(volatile unsigned int *) CHRP_REG_DATA = PCISWAP (regVal); - return; -} - - -/* - * Write a byte (8 bits) to a memory location. - */ -void mpc824x_mpc107_write8 (unsigned int addr, unsigned char data) -{ - *(unsigned char *) addr = data; - __asm__ ("sync"); -} - -/* - * Write a word (16 bits) to a memory location after the value - * has been byte swapped (big to little endian or vice versa) - */ - -void mpc824x_mpc107_write16 (unsigned int address, unsigned short data) -{ - *(volatile unsigned short *) address = BYTE_SWAP_16_BIT (data); - __asm__ ("sync"); -} - -/* - * Write a long word (32 bits) to a memory location after the value - * has been byte swapped (big to little endian or vice versa) - */ - -void mpc824x_mpc107_write32 (unsigned int address, unsigned int data) -{ - *(volatile unsigned int *) address = LONGSWAP (data); - __asm__ ("sync"); -} - -/* - * Read a byte (8 bits) from a memory location. - */ -unsigned char mpc824x_mpc107_read8 (unsigned int addr) -{ - return *(volatile unsigned char *) addr; -} - - -/* - * Read a word (16 bits) from a memory location, and byte swap the - * value before returning to the caller. - */ -unsigned short mpc824x_mpc107_read16 (unsigned int address) -{ - unsigned short retVal; - - retVal = BYTE_SWAP_16_BIT (*(unsigned short *) address); - return retVal; -} - - -/* - * Read a long word (32 bits) from a memory location, and byte - * swap the value before returning to the caller. - */ -unsigned int mpc824x_mpc107_read32 (unsigned int address) -{ - unsigned int retVal; - - retVal = LONGSWAP (*(unsigned int *) address); - return (retVal); -} - - -/* - * Read a register in the Embedded Utilities Memory Block address - * space. - * Input: regNum - register number + utility base address. Example, - * the base address of EPIC is 0x40000, the register number - * being passed is 0x40000+the address of the target register. - * (See epic.h for register addresses). - * Output: The 32 bit little endian value of the register. - */ - -unsigned int mpc824x_eummbar_read (unsigned int regNum) -{ - unsigned int temp; - - temp = *(volatile unsigned int *) (EUMBBAR_VAL + regNum); - temp = PCISWAP (temp); - return temp; -} - - -/* - * Write a value to a register in the Embedded Utilities Memory - * Block address space. - * Input: regNum - register number + utility base address. Example, - * the base address of EPIC is 0x40000, the register - * number is 0x40000+the address of the target register. - * (See epic.h for register addresses). - * regVal - value to be written to the register. - */ - -void mpc824x_eummbar_write (unsigned int regNum, unsigned int regVal) -{ - *(volatile unsigned int *) (EUMBBAR_VAL + regNum) = PCISWAP (regVal); - return; -} - -/* ------------------------------------------------------------------------- */ diff --git a/arch/powerpc/cpu/mpc824x/cpu_init.c b/arch/powerpc/cpu/mpc824x/cpu_init.c deleted file mode 100644 index 68d88e9..0000000 --- a/arch/powerpc/cpu/mpc824x/cpu_init.c +++ /dev/null @@ -1,311 +0,0 @@ -/* - * (C) Copyright 2000 - * Rob Taylor. Flying Pig Systems. robt@flyingpig.com. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/processor.h> -#include <mpc824x.h> - -#ifndef CONFIG_SYS_BANK0_ROW -#define CONFIG_SYS_BANK0_ROW 0 -#endif -#ifndef CONFIG_SYS_BANK1_ROW -#define CONFIG_SYS_BANK1_ROW 0 -#endif -#ifndef CONFIG_SYS_BANK2_ROW -#define CONFIG_SYS_BANK2_ROW 0 -#endif -#ifndef CONFIG_SYS_BANK3_ROW -#define CONFIG_SYS_BANK3_ROW 0 -#endif -#ifndef CONFIG_SYS_BANK4_ROW -#define CONFIG_SYS_BANK4_ROW 0 -#endif -#ifndef CONFIG_SYS_BANK5_ROW -#define CONFIG_SYS_BANK5_ROW 0 -#endif -#ifndef CONFIG_SYS_BANK6_ROW -#define CONFIG_SYS_BANK6_ROW 0 -#endif -#ifndef CONFIG_SYS_BANK7_ROW -#define CONFIG_SYS_BANK7_ROW 0 -#endif -#ifndef CONFIG_SYS_DBUS_SIZE2 -#define CONFIG_SYS_DBUS_SIZE2 0 -#endif - -/* - * Breath some life into the CPU... - * - * Set up the memory map, - * initialize a bunch of registers, - */ -void -cpu_init_f (void) -{ - register unsigned long val; - CONFIG_WRITE_HALFWORD(PCICR, 0x06); /* Bus Master, respond to PCI memory space acesses*/ -/* CONFIG_WRITE_HALFWORD(PCISR, 0xffff); */ /*reset PCISR*/ - -#if defined(CONFIG_MUSENKI) -/* Why is this here, you ask? Try, just try setting 0x8000 - * in PCIACR with CONFIG_WRITE_HALFWORD() - * this one was a stumper, and we are annoyed - */ - -#define M_CONFIG_WRITE_HALFWORD( addr, data ) \ - __asm__ __volatile__(" \ - stw %2,0(%0)\n \ - sync\n \ - sth %3,2(%1)\n \ - sync\n \ - " \ - : /* no output */ \ - : "r" (CONFIG_ADDR), "r" (CONFIG_DATA), \ - "r" (PCISWAP(addr & ~3)), "r" (PCISWAP(data << 16)) \ - ); - - M_CONFIG_WRITE_HALFWORD(PCIACR, 0x8000); -#endif - - CONFIG_WRITE_BYTE(PCLSR, 0x8); /* set PCI cache line size */ - CONFIG_WRITE_BYTE (PLTR, 0x40); /* set PCI latency timer */ - /* - * Note that although this bit is cleared after a hard reset, it - * must be explicitly set and then cleared by software during - * initialization in order to guarantee correct operation of the - * DLL and the SDRAM_CLK[0:3] signals (if they are used). - */ - CONFIG_READ_BYTE (AMBOR, val); - CONFIG_WRITE_BYTE(AMBOR, val & 0xDF); - CONFIG_WRITE_BYTE(AMBOR, val | 0x20); - CONFIG_WRITE_BYTE(AMBOR, val & 0xDF); -#ifdef CONFIG_MPC8245 - /* silicon bug 28 MPC8245 */ - CONFIG_READ_BYTE(AMBOR,val); - CONFIG_WRITE_BYTE(AMBOR,val|0x1); - -#if 0 - /* - * The following bug only affects older (XPC8245) processors. - * DMA transfers initiated by external devices get corrupted due - * to a hardware scheduling problem. - * - * The effect is: - * when transferring X words, the first 32 words are transferred - * OK, the next 3 x 32 words are 'old' data (from previous DMA) - * while the rest of the X words is xferred fine. - * - * Disabling 3 of the 4 32 word hardware buffers solves the problem - * with no significant performance loss. - */ - - CONFIG_READ_BYTE(PCMBCR,val); - /* in order not to corrupt data which is being read over the PCI bus - * with the PPC as slave, we need to reduce the number of PCMRBs to 1, - * 4.11 in the processor user manual - * */ - -#if 1 - CONFIG_WRITE_BYTE(PCMBCR,(val|0xC0)); /* 1 PCMRB */ -#else - CONFIG_WRITE_BYTE(PCMBCR,(val|0x80)); /* 2 PCMRBs */ - CONFIG_WRITE_BYTE(PCMBCR,(val|0x40)); /* 3 PCMRBs */ - /* default, 4 PCMRBs are used */ -#endif -#endif -#endif - - CONFIG_READ_WORD(PICR1, val); -#if defined(CONFIG_MPC8240) - CONFIG_WRITE_WORD( PICR1, - (val & (PICR1_ADDRESS_MAP | PICR1_RCS0)) | - PIRC1_MSK | PICR1_PROC_TYPE_603E | - PICR1_FLASH_WR_EN | PICR1_MCP_EN | - PICR1_CF_DPARK | PICR1_EN_PCS | - PICR1_CF_APARK ); -#elif defined(CONFIG_MPC8245) - CONFIG_WRITE_WORD( PICR1, - (val & (PICR1_RCS0)) | - PICR1_PROC_TYPE_603E | - PICR1_FLASH_WR_EN | PICR1_MCP_EN | - PICR1_CF_DPARK | PICR1_NO_BUSW_CK | - PICR1_DEC| PICR1_CF_APARK | 0x10); /* 8245 UM says bit 4 must be set */ -#else -#error Specific type of MPC824x must be defined (i.e. CONFIG_MPC8240) -#endif - - CONFIG_READ_WORD(PICR2, val); - val= val & ~ (PICR2_CF_SNOOP_WS_MASK | PICR2_CF_APHASE_WS_MASK); /*mask off waitstate bits*/ - val |= PICR2_CF_SNOOP_WS_1WS | PICR2_CF_APHASE_WS_1WS; /*1 wait state*/ - CONFIG_WRITE_WORD(PICR2, val); - - CONFIG_WRITE_WORD(EUMBBAR, CONFIG_SYS_EUMB_ADDR); -#ifndef CONFIG_SYS_RAMBOOT - CONFIG_WRITE_WORD(MCCR1, (CONFIG_SYS_ROMNAL << MCCR1_ROMNAL_SHIFT) | - (CONFIG_SYS_BANK0_ROW) | - (CONFIG_SYS_BANK1_ROW << MCCR1_BANK1ROW_SHIFT) | - (CONFIG_SYS_BANK2_ROW << MCCR1_BANK2ROW_SHIFT) | - (CONFIG_SYS_BANK3_ROW << MCCR1_BANK3ROW_SHIFT) | - (CONFIG_SYS_BANK4_ROW << MCCR1_BANK4ROW_SHIFT) | - (CONFIG_SYS_BANK5_ROW << MCCR1_BANK5ROW_SHIFT) | - (CONFIG_SYS_BANK6_ROW << MCCR1_BANK6ROW_SHIFT) | - (CONFIG_SYS_BANK7_ROW << MCCR1_BANK7ROW_SHIFT) | - (CONFIG_SYS_ROMFAL << MCCR1_ROMFAL_SHIFT)); -#endif - -#if defined(CONFIG_SYS_ASRISE) && defined(CONFIG_SYS_ASFALL) - CONFIG_WRITE_WORD(MCCR2, CONFIG_SYS_REFINT << MCCR2_REFINT_SHIFT | - CONFIG_SYS_ASRISE << MCCR2_ASRISE_SHIFT | - CONFIG_SYS_ASFALL << MCCR2_ASFALL_SHIFT); -#else - CONFIG_WRITE_WORD(MCCR2, CONFIG_SYS_REFINT << MCCR2_REFINT_SHIFT); -#endif - -#if defined(CONFIG_MPC8240) - CONFIG_WRITE_WORD(MCCR3, - (((CONFIG_SYS_BSTOPRE & 0x003c) >> 2) << MCCR3_BSTOPRE2TO5_SHIFT) | - (CONFIG_SYS_REFREC << MCCR3_REFREC_SHIFT) | - (CONFIG_SYS_RDLAT << MCCR3_RDLAT_SHIFT)); -#elif defined(CONFIG_MPC8245) - CONFIG_WRITE_WORD(MCCR3, - (((CONFIG_SYS_BSTOPRE & 0x003c) >> 2) << MCCR3_BSTOPRE2TO5_SHIFT) | - (CONFIG_SYS_REFREC << MCCR3_REFREC_SHIFT)); -#else -#error Specific type of MPC824x must be defined (i.e. CONFIG_MPC8240) -#endif - -/* this is gross. We think these should all be the same, and various boards - * should define CONFIG_SYS_ACTORW to 0 if they don't want to set it, or even, if - * its not set, we define it to zero in this file - */ -#if defined(CONFIG_CU824) - CONFIG_WRITE_WORD(MCCR4, - (CONFIG_SYS_PRETOACT << MCCR4_PRETOACT_SHIFT) | - (CONFIG_SYS_ACTTOPRE << MCCR4_ACTTOPRE_SHIFT) | - MCCR4_BIT21 | - (CONFIG_SYS_REGISTERD_TYPE_BUFFER ? MCCR4_REGISTERED: 0) | - ((CONFIG_SYS_BSTOPRE & 0x0003) <<MCCR4_BSTOPRE0TO1_SHIFT ) | - (((CONFIG_SYS_SDMODE_CAS_LAT <<4) | (CONFIG_SYS_SDMODE_WRAP <<3) | - CONFIG_SYS_SDMODE_BURSTLEN) << MCCR4_SDMODE_SHIFT) | - (CONFIG_SYS_ACTORW << MCCR4_ACTTORW_SHIFT) | - (((CONFIG_SYS_BSTOPRE & 0x03c0) >> 6) << MCCR4_BSTOPRE6TO9_SHIFT)); -#elif defined(CONFIG_MPC8240) - CONFIG_WRITE_WORD(MCCR4, - (CONFIG_SYS_PRETOACT << MCCR4_PRETOACT_SHIFT) | - (CONFIG_SYS_ACTTOPRE << MCCR4_ACTTOPRE_SHIFT) | - MCCR4_BIT21 | - (CONFIG_SYS_REGISTERD_TYPE_BUFFER ? MCCR4_REGISTERED: 0) | - ((CONFIG_SYS_BSTOPRE & 0x0003) <<MCCR4_BSTOPRE0TO1_SHIFT ) | - (((CONFIG_SYS_SDMODE_CAS_LAT <<4) | (CONFIG_SYS_SDMODE_WRAP <<3) | - (CONFIG_SYS_SDMODE_BURSTLEN)) <<MCCR4_SDMODE_SHIFT) | - (((CONFIG_SYS_BSTOPRE & 0x03c0) >> 6) <<MCCR4_BSTOPRE6TO9_SHIFT )); -#elif defined(CONFIG_MPC8245) - CONFIG_READ_WORD(MCCR1, val); - val &= MCCR1_DBUS_SIZE0; /* test for 64-bit mem bus */ - - CONFIG_WRITE_WORD(MCCR4, - (CONFIG_SYS_PRETOACT << MCCR4_PRETOACT_SHIFT) | - (CONFIG_SYS_ACTTOPRE << MCCR4_ACTTOPRE_SHIFT) | - (CONFIG_SYS_EXTROM ? MCCR4_EXTROM : 0) | - (CONFIG_SYS_REGDIMM ? MCCR4_REGDIMM : 0) | - (CONFIG_SYS_REGISTERD_TYPE_BUFFER ? MCCR4_REGISTERED: 0) | - ((CONFIG_SYS_BSTOPRE & 0x0003) <<MCCR4_BSTOPRE0TO1_SHIFT ) | - (CONFIG_SYS_DBUS_SIZE2 << MCCR4_DBUS_SIZE2_SHIFT) | - (((CONFIG_SYS_SDMODE_CAS_LAT <<4) | (CONFIG_SYS_SDMODE_WRAP <<3) | - (val ? 2 : 3)) << MCCR4_SDMODE_SHIFT) | - (CONFIG_SYS_ACTORW << MCCR4_ACTTORW_SHIFT) | - (((CONFIG_SYS_BSTOPRE & 0x03c0) >> 6) <<MCCR4_BSTOPRE6TO9_SHIFT )); -#else -#error Specific type of MPC824x must be defined (i.e. CONFIG_MPC8240) -#endif - - CONFIG_WRITE_WORD(MSAR1, - ( (CONFIG_SYS_BANK0_START & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) | - (((CONFIG_SYS_BANK1_START & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 8) | - (((CONFIG_SYS_BANK2_START & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 16) | - (((CONFIG_SYS_BANK3_START & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 24)); - CONFIG_WRITE_WORD(EMSAR1, - ( (CONFIG_SYS_BANK0_START & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) | - (((CONFIG_SYS_BANK1_START & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 8) | - (((CONFIG_SYS_BANK2_START & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 16) | - (((CONFIG_SYS_BANK3_START & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 24)); - CONFIG_WRITE_WORD(MSAR2, - ( (CONFIG_SYS_BANK4_START & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) | - (((CONFIG_SYS_BANK5_START & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 8) | - (((CONFIG_SYS_BANK6_START & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 16) | - (((CONFIG_SYS_BANK7_START & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 24)); - CONFIG_WRITE_WORD(EMSAR2, - ( (CONFIG_SYS_BANK4_START & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) | - (((CONFIG_SYS_BANK5_START & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 8) | - (((CONFIG_SYS_BANK6_START & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 16) | - (((CONFIG_SYS_BANK7_START & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 24)); - CONFIG_WRITE_WORD(MEAR1, - ( (CONFIG_SYS_BANK0_END & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) | - (((CONFIG_SYS_BANK1_END & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 8) | - (((CONFIG_SYS_BANK2_END & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 16) | - (((CONFIG_SYS_BANK3_END & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 24)); - CONFIG_WRITE_WORD(EMEAR1, - ( (CONFIG_SYS_BANK0_END & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) | - (((CONFIG_SYS_BANK1_END & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 8) | - (((CONFIG_SYS_BANK2_END & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 16) | - (((CONFIG_SYS_BANK3_END & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 24)); - CONFIG_WRITE_WORD(MEAR2, - ( (CONFIG_SYS_BANK4_END & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) | - (((CONFIG_SYS_BANK5_END & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 8) | - (((CONFIG_SYS_BANK6_END & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 16) | - (((CONFIG_SYS_BANK7_END & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 24)); - CONFIG_WRITE_WORD(EMEAR2, - ( (CONFIG_SYS_BANK4_END & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) | - (((CONFIG_SYS_BANK5_END & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 8) | - (((CONFIG_SYS_BANK6_END & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 16) | - (((CONFIG_SYS_BANK7_END & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 24)); - - CONFIG_WRITE_BYTE(ODCR, CONFIG_SYS_ODCR); -#ifdef CONFIG_SYS_DLL_MAX_DELAY - CONFIG_WRITE_BYTE(MIOCR1, CONFIG_SYS_DLL_MAX_DELAY); /* needed to make DLL lock */ -#endif -#if defined(CONFIG_SYS_DLL_EXTEND) && defined(CONFIG_SYS_PCI_HOLD_DEL) - CONFIG_WRITE_BYTE(PMCR2, CONFIG_SYS_DLL_EXTEND | CONFIG_SYS_PCI_HOLD_DEL); -#endif -#if defined(MIOCR2) && defined(CONFIG_SYS_SDRAM_DSCD) - CONFIG_WRITE_BYTE(MIOCR2, CONFIG_SYS_SDRAM_DSCD); /* change memory input */ -#endif /* setup & hold time */ - - CONFIG_WRITE_BYTE(MBER, - CONFIG_SYS_BANK0_ENABLE | - (CONFIG_SYS_BANK1_ENABLE << 1) | - (CONFIG_SYS_BANK2_ENABLE << 2) | - (CONFIG_SYS_BANK3_ENABLE << 3) | - (CONFIG_SYS_BANK4_ENABLE << 4) | - (CONFIG_SYS_BANK5_ENABLE << 5) | - (CONFIG_SYS_BANK6_ENABLE << 6) | - (CONFIG_SYS_BANK7_ENABLE << 7)); - -#ifdef CONFIG_SYS_PGMAX - CONFIG_WRITE_BYTE(MPMR, CONFIG_SYS_PGMAX); -#endif - - /* ! Wait 200us before initialize other registers */ - /*FIXME: write a decent udelay wait */ - __asm__ __volatile__( - " mtctr %0 \n \ - 0: bdnz 0b\n" - : - : "r" (0x10000)); - - CONFIG_READ_WORD(MCCR1, val); - CONFIG_WRITE_WORD(MCCR1, val | MCCR1_MEMGO); /* set memory access going */ - __asm__ __volatile__("eieio"); -} - -/* - * initialize higher level parts of CPU like time base and timers - */ -int cpu_init_r (void) -{ - return (0); -} diff --git a/arch/powerpc/cpu/mpc824x/drivers/epic.h b/arch/powerpc/cpu/mpc824x/drivers/epic.h deleted file mode 100644 index 2803f63..0000000 --- a/arch/powerpc/cpu/mpc824x/drivers/epic.h +++ /dev/null @@ -1 +0,0 @@ -#include "epic/epic.h" diff --git a/arch/powerpc/cpu/mpc824x/drivers/epic/README b/arch/powerpc/cpu/mpc824x/drivers/epic/README deleted file mode 100644 index 5798996..0000000 --- a/arch/powerpc/cpu/mpc824x/drivers/epic/README +++ /dev/null @@ -1,102 +0,0 @@ -CONTENT: - - epic.h - epic1.c - epic2.s - -WHAT ARE THESE FILES: - -These files contain MPC8240 (Kahlua) EPIC -driver routines. The driver routines are not -written for any specific operating system. -They serves the purpose of code sample, and -jump-start for using the MPC8240 EPIC unit. - -For the reason of correctness of C language -syntax, these files are compiled by Metaware -C compiler and assembler. - -ENDIAN NOTATION: - -The algorithm is designed for big-endian mode, -software is responsible for byte swapping. - -USAGE: - -1. The host system that is running on MPC8240 - shall link the files listed here. The memory - location of driver routines shall take into - account of that driver routines need to run - in supervisor mode and they process external - interrupts. - - The routine epic_exception shall be called by - exception vector at location 0x500, i.e., - 603e core external exception vector. - -2. The host system is responsible for configuring - the MPC8240 including Embedded Utilities Memory - Block. All EPIC driver functions require the - content of Embedded Utilities Memory Block - Base Address Register, EUMBBAR, as the first - parameter. - -3. Before EPIC unit of MPC8240 can be used, - initialize EPIC unit by calling epicInit - with the corresponding parameters. - - The initialization shall disable the 603e - core External Exception by calling CoreExtIntDisable( ). - Next, call epicInit( ). Last, enable the 603e core - External Exception by calling CoreExtIntEnable( ). - -4. After EPIC unit has been successfully initialized, - epicIntSourceSet( ) shall be used to register each - external interrupt source. Anytime, an external - interrupt source can be disabled or enabled by - calling corresponding function, epicIntDisable( ), - or epicIntEnable( ). - - Global Timers' resource, base count and frequency, - can be changed by calling epicTmFrequencySet( ) - and epicTmBaseSet( ). - - To stop counting a specific global timer, use - the function, epicTmInhibit while epicTmEnable - can be used to start counting a timer. - -5. To mask a set of external interrupts that are - are certain level below, epicIntPrioritySet( ) - can be used. For example, if the processor's - current task priority register is set to 0x7, - only interrupts of priority 0x8 or higher will - be passed to the processor. - - Be careful when using this function. It may - corrupt the current interrupt pending, selector, - and request registers, resulting an invalid vetor. - - After enabling an interrupt, disable it may also - cause an invalid vector. User may consider using - the spurious vector interrupt service routine to - handle this case. - -6. The EPIC driver routines contains a set - of utilities, Set and Get, for host system - to query and modify the desired EPIC source - registers. - -7. Each external interrupt source shall register - its interrupt service routine. The routine - shall contain all interrupt source specific - processes and keep as short as possible. - - Special customized end of interrupt routine - is optional. If it is needed, it shall contain - the external interrupt source specific end of - interrupt process. - - External interrupt exception vector at 0x500 - shall always call the epicEOI just before - rfi instruction. Refer to the routine, - epic_exception, for a code sample. diff --git a/arch/powerpc/cpu/mpc824x/drivers/epic/epic.h b/arch/powerpc/cpu/mpc824x/drivers/epic/epic.h deleted file mode 100644 index 58f81c5..0000000 --- a/arch/powerpc/cpu/mpc824x/drivers/epic/epic.h +++ /dev/null @@ -1,163 +0,0 @@ -/********************************************************************* - * mpc8240epic.h - EPIC module of the MPC8240 micro-controller - * - * Copyrigh 1999 Motorola Inc. - * - * Modification History: - * ===================== - * 01a,04Feb99,My Created. - * 15Nov200, robt -modified to use in U-Boot - * -*/ - -#ifndef __INCEPICh -#define __INCEPICh - -#define ULONG unsigned long -#define MAXVEC 20 -#define MAXIRQ 5 /* IRQs */ -#define EPIC_DIRECT_IRQ 0 /* Direct interrupt type */ - -/* EPIC register addresses */ - -#define EPIC_EUMBBAR 0x40000 /* EUMBBAR of EPIC */ -#define EPIC_FEATURES_REG (EPIC_EUMBBAR + 0x01000)/* Feature reporting */ -#define EPIC_GLOBAL_REG (EPIC_EUMBBAR + 0x01020)/* Global config. */ -#define EPIC_INT_CONF_REG (EPIC_EUMBBAR + 0x01030)/* Interrupt config. */ -#define EPIC_VENDOR_ID_REG (EPIC_EUMBBAR + 0x01080)/* Vendor id */ -#define EPIC_PROC_INIT_REG (EPIC_EUMBBAR + 0x01090)/* Processor init. */ -#define EPIC_SPUR_VEC_REG (EPIC_EUMBBAR + 0x010e0)/* Spurious vector */ -#define EPIC_TM_FREQ_REG (EPIC_EUMBBAR + 0x010f0)/* Timer Frequency */ - -#define EPIC_TM0_CUR_COUNT_REG (EPIC_EUMBBAR + 0x01100)/* Gbl TM0 Cur. Count*/ -#define EPIC_TM0_BASE_COUNT_REG (EPIC_EUMBBAR + 0x01110)/* Gbl TM0 Base Count*/ -#define EPIC_TM0_VEC_REG (EPIC_EUMBBAR + 0x01120)/* Gbl TM0 Vector Pri*/ -#define EPIC_TM0_DES_REG (EPIC_EUMBBAR + 0x01130)/* Gbl TM0 Dest. */ - -#define EPIC_TM1_CUR_COUNT_REG (EPIC_EUMBBAR + 0x01140)/* Gbl TM1 Cur. Count*/ -#define EPIC_TM1_BASE_COUNT_REG (EPIC_EUMBBAR + 0x01150)/* Gbl TM1 Base Count*/ -#define EPIC_TM1_VEC_REG (EPIC_EUMBBAR + 0x01160)/* Gbl TM1 Vector Pri*/ -#define EPIC_TM1_DES_REG (EPIC_EUMBBAR + 0x01170)/* Gbl TM1 Dest. */ - -#define EPIC_TM2_CUR_COUNT_REG (EPIC_EUMBBAR + 0x01180)/* Gbl TM2 Cur. Count*/ -#define EPIC_TM2_BASE_COUNT_REG (EPIC_EUMBBAR + 0x01190)/* Gbl TM2 Base Count*/ -#define EPIC_TM2_VEC_REG (EPIC_EUMBBAR + 0x011a0)/* Gbl TM2 Vector Pri*/ -#define EPIC_TM2_DES_REG (EPIC_EUMBBAR + 0x011b0)/* Gbl TM2 Dest */ - -#define EPIC_TM3_CUR_COUNT_REG (EPIC_EUMBBAR + 0x011c0)/* Gbl TM3 Cur. Count*/ -#define EPIC_TM3_BASE_COUNT_REG (EPIC_EUMBBAR + 0x011d0)/* Gbl TM3 Base Count*/ -#define EPIC_TM3_VEC_REG (EPIC_EUMBBAR + 0x011e0)/* Gbl TM3 Vector Pri*/ -#define EPIC_TM3_DES_REG (EPIC_EUMBBAR + 0x011f0)/* Gbl TM3 Dest. */ - -#define EPIC_EX_INT0_VEC_REG (EPIC_EUMBBAR + 0x10200)/* Ext. Int. Sr0 Des */ -#define EPIC_EX_INT0_DES_REG (EPIC_EUMBBAR + 0x10210)/* Ext. Int. Sr0 Vect*/ -#define EPIC_EX_INT1_VEC_REG (EPIC_EUMBBAR + 0x10220)/* Ext. Int. Sr1 Des */ -#define EPIC_EX_INT1_DES_REG (EPIC_EUMBBAR + 0x10230)/* Ext. Int. Sr1 Vect*/ -#define EPIC_EX_INT2_VEC_REG (EPIC_EUMBBAR + 0x10240)/* Ext. Int. Sr2 Des */ -#define EPIC_EX_INT2_DES_REG (EPIC_EUMBBAR + 0x10250)/* Ext. Int. Sr2 Vect*/ -#define EPIC_EX_INT3_VEC_REG (EPIC_EUMBBAR + 0x10260)/* Ext. Int. Sr3 Des */ -#define EPIC_EX_INT3_DES_REG (EPIC_EUMBBAR + 0x10270)/* Ext. Int. Sr3 Vect*/ -#define EPIC_EX_INT4_VEC_REG (EPIC_EUMBBAR + 0x10280)/* Ext. Int. Sr4 Des */ -#define EPIC_EX_INT4_DES_REG (EPIC_EUMBBAR + 0x10290)/* Ext. Int. Sr4 Vect*/ - -#define EPIC_SR_INT0_VEC_REG (EPIC_EUMBBAR + 0x10200)/* Sr. Int. Sr0 Des */ -#define EPIC_SR_INT0_DES_REG (EPIC_EUMBBAR + 0x10210)/* Sr. Int. Sr0 Vect */ -#define EPIC_SR_INT1_VEC_REG (EPIC_EUMBBAR + 0x10220)/* Sr. Int. Sr1 Des */ -#define EPIC_SR_INT1_DES_REG (EPIC_EUMBBAR + 0x10230)/* Sr. Int. Sr1 Vect.*/ -#define EPIC_SR_INT2_VEC_REG (EPIC_EUMBBAR + 0x10240)/* Sr. Int. Sr2 Des */ -#define EPIC_SR_INT2_DES_REG (EPIC_EUMBBAR + 0x10250)/* Sr. Int. Sr2 Vect.*/ -#define EPIC_SR_INT3_VEC_REG (EPIC_EUMBBAR + 0x10260)/* Sr. Int. Sr3 Des */ -#define EPIC_SR_INT3_DES_REG (EPIC_EUMBBAR + 0x10270)/* Sr. Int. Sr3 Vect.*/ -#define EPIC_SR_INT4_VEC_REG (EPIC_EUMBBAR + 0x10280)/* Sr. Int. Sr4 Des */ -#define EPIC_SR_INT4_DES_REG (EPIC_EUMBBAR + 0x10290)/* Sr. Int. Sr4 Vect.*/ - -#define EPIC_SR_INT5_VEC_REG (EPIC_EUMBBAR + 0x102a0)/* Sr. Int. Sr5 Des */ -#define EPIC_SR_INT5_DES_REG (EPIC_EUMBBAR + 0x102b0)/* Sr. Int. Sr5 Vect.*/ -#define EPIC_SR_INT6_VEC_REG (EPIC_EUMBBAR + 0x102c0)/* Sr. Int. Sr6 Des */ -#define EPIC_SR_INT6_DES_REG (EPIC_EUMBBAR + 0x102d0)/* Sr. Int. Sr6 Vect.*/ -#define EPIC_SR_INT7_VEC_REG (EPIC_EUMBBAR + 0x102e0)/* Sr. Int. Sr7 Des */ -#define EPIC_SR_INT7_DES_REG (EPIC_EUMBBAR + 0x102f0)/* Sr. Int. Sr7 Vect.*/ -#define EPIC_SR_INT8_VEC_REG (EPIC_EUMBBAR + 0x10300)/* Sr. Int. Sr8 Des */ -#define EPIC_SR_INT8_DES_REG (EPIC_EUMBBAR + 0x10310)/* Sr. Int. Sr8 Vect.*/ -#define EPIC_SR_INT9_VEC_REG (EPIC_EUMBBAR + 0x10320)/* Sr. Int. Sr9 Des */ -#define EPIC_SR_INT9_DES_REG (EPIC_EUMBBAR + 0x10330)/* Sr. Int. Sr9 Vect.*/ - -#define EPIC_SR_INT10_VEC_REG (EPIC_EUMBBAR + 0x10340)/* Sr. Int. Sr10 Des */ -#define EPIC_SR_INT10_DES_REG (EPIC_EUMBBAR + 0x10350)/* Sr. Int. Sr10 Vect*/ -#define EPIC_SR_INT11_VEC_REG (EPIC_EUMBBAR + 0x10360)/* Sr. Int. Sr11 Des */ -#define EPIC_SR_INT11_DES_REG (EPIC_EUMBBAR + 0x10370)/* Sr. Int. Sr11 Vect*/ -#define EPIC_SR_INT12_VEC_REG (EPIC_EUMBBAR + 0x10380)/* Sr. Int. Sr12 Des */ -#define EPIC_SR_INT12_DES_REG (EPIC_EUMBBAR + 0x10390)/* Sr. Int. Sr12 Vect*/ -#define EPIC_SR_INT13_VEC_REG (EPIC_EUMBBAR + 0x103a0)/* Sr. Int. Sr13 Des */ -#define EPIC_SR_INT13_DES_REG (EPIC_EUMBBAR + 0x103b0)/* Sr. Int. Sr13 Vect*/ -#define EPIC_SR_INT14_VEC_REG (EPIC_EUMBBAR + 0x103c0)/* Sr. Int. Sr14 Des */ -#define EPIC_SR_INT14_DES_REG (EPIC_EUMBBAR + 0x103d0)/* Sr. Int. Sr14 Vect*/ -#define EPIC_SR_INT15_VEC_REG (EPIC_EUMBBAR + 0x103e0)/* Sr. Int. Sr15 Des */ -#define EPIC_SR_INT15_DES_REG (EPIC_EUMBBAR + 0x103f0)/* Sr. Int. Sr15 Vect*/ - -#define EPIC_I2C_INT_VEC_REG (EPIC_EUMBBAR + 0x11020)/* I2C Int. Vect Pri.*/ -#define EPIC_I2C_INT_DES_REG (EPIC_EUMBBAR + 0x11030)/* I2C Int. Dest */ -#define EPIC_DMA0_INT_VEC_REG (EPIC_EUMBBAR + 0x11040)/* DMA0 Int. Vect Pri*/ -#define EPIC_DMA0_INT_DES_REG (EPIC_EUMBBAR + 0x11050)/* DMA0 Int. Dest */ -#define EPIC_DMA1_INT_VEC_REG (EPIC_EUMBBAR + 0x11060)/* DMA1 Int. Vect Pri*/ -#define EPIC_DMA1_INT_DES_REG (EPIC_EUMBBAR + 0x11070)/* DMA1 Int. Dest */ -#define EPIC_MSG_INT_VEC_REG (EPIC_EUMBBAR + 0x110c0)/* Msg Int. Vect Pri*/ -#define EPIC_MSG_INT_DES_REG (EPIC_EUMBBAR + 0x110d0)/* Msg Int. Dest */ - -#define EPIC_PROC_CTASK_PRI_REG (EPIC_EUMBBAR + 0x20080)/* Proc. current task*/ -#define EPIC_PROC_INT_ACK_REG (EPIC_EUMBBAR + 0x200a0)/* Int. acknowledge */ -#define EPIC_PROC_EOI_REG (EPIC_EUMBBAR + 0x200b0)/* End of interrupt */ - -#define EPIC_VEC_PRI_MASK 0x80000000 /* Mask Interrupt bit in IVPR */ -#define EPIC_VEC_PRI_DFLT_PRI 8 /* Interrupt Priority in IVPR */ - -/* Error code */ - -#define OK 0 -#define ERROR -1 - -/* function prototypes */ - -void epicVendorId( unsigned int *step, - unsigned int *devId, - unsigned int *venId - ); -void epicFeatures( unsigned int *noIRQs, - unsigned int *noCPUs, - unsigned int *VerId ); -extern void epicInit( unsigned int IRQType, unsigned int clkRatio); -ULONG sysEUMBBARRead ( ULONG regNum ); -void sysEUMBBARWrite ( ULONG regNum, ULONG regVal); -extern void epicTmFrequencySet( unsigned int frq ); -extern unsigned int epicTmFrequencyGet(void); -extern unsigned int epicTmBaseSet( ULONG srcAddr, - unsigned int cnt, - unsigned int inhibit ); -extern unsigned int epicTmBaseGet ( ULONG srcAddr, unsigned int *val ); -extern unsigned int epicTmCountGet( ULONG srcAddr, unsigned int *val ); -extern unsigned int epicTmInhibit( unsigned int timer ); -extern unsigned int epicTmEnable( ULONG srcAdr ); -extern void CoreExtIntEnable(void); /* Enable 603e external interrupts */ -extern void CoreExtIntDisable(void); /* Disable 603e external interrupts */ -extern unsigned char epicIntTaskGet(void); -extern void epicIntTaskSet( unsigned char val ); -extern unsigned int epicIntAck(void); -extern void epicSprSet( unsigned int eumbbar, unsigned char ); -extern void epicConfigGet( unsigned int *clkRatio, - unsigned int *serEnable ); -extern void SrcVecTableInit(void); -extern unsigned int epicModeGet(void); -extern void epicIntEnable(int Vect); -extern void epicIntDisable(int Vect); -extern int epicIntSourceConfig(int Vect, int Polarity, int Sense, int Prio); -extern unsigned int epicIntAck(void); -extern void epicEOI(void); -extern int epicCurTaskPrioSet(int Vect); - -struct SrcVecTable - { - ULONG srcAddr; - char srcName[40]; - }; - -#endif /* EPIC_H */ diff --git a/arch/powerpc/cpu/mpc824x/drivers/epic/epic1.c b/arch/powerpc/cpu/mpc824x/drivers/epic/epic1.c deleted file mode 100644 index ecbb42d..0000000 --- a/arch/powerpc/cpu/mpc824x/drivers/epic/epic1.c +++ /dev/null @@ -1,517 +0,0 @@ -/************************************************** - * - * copyright @ motorola, 1999 - * - *************************************************/ -#include <mpc824x.h> -#include <common.h> -#include "epic.h" - - -#define PRINT(format, args...) printf(format , ## args) - -typedef void (*VOIDFUNCPTR) (void); /* ptr to function returning void */ -struct SrcVecTable SrcVecTable[MAXVEC] = /* Addr/Vector cross-reference tbl */ - { - { EPIC_EX_INT0_VEC_REG, "External Direct/Serial Source 0"}, - { EPIC_EX_INT1_VEC_REG, "External Direct/Serial Source 1"}, - { EPIC_EX_INT2_VEC_REG, "External Direct/Serial Source 2"}, - { EPIC_EX_INT3_VEC_REG, "External Direct/Serial Source 3"}, - { EPIC_EX_INT4_VEC_REG, "External Direct/Serial Source 4"}, - - { EPIC_SR_INT5_VEC_REG, "External Serial Source 5"}, - { EPIC_SR_INT6_VEC_REG, "External Serial Source 6"}, - { EPIC_SR_INT7_VEC_REG, "External Serial Source 7"}, - { EPIC_SR_INT8_VEC_REG, "External Serial Source 8"}, - { EPIC_SR_INT9_VEC_REG, "External Serial Source 9"}, - { EPIC_SR_INT10_VEC_REG, "External Serial Source 10"}, - { EPIC_SR_INT11_VEC_REG, "External Serial Source 11"}, - { EPIC_SR_INT12_VEC_REG, "External Serial Source 12"}, - { EPIC_SR_INT13_VEC_REG, "External Serial Source 13"}, - { EPIC_SR_INT14_VEC_REG, "External Serial Source 14"}, - { EPIC_SR_INT15_VEC_REG, "External Serial Source 15"}, - - { EPIC_I2C_INT_VEC_REG, "Internal I2C Source"}, - { EPIC_DMA0_INT_VEC_REG, "Internal DMA0 Source"}, - { EPIC_DMA1_INT_VEC_REG, "Internal DMA1 Source"}, - { EPIC_MSG_INT_VEC_REG, "Internal Message Source"}, - }; - -VOIDFUNCPTR intVecTbl[MAXVEC]; /* Interrupt vector table */ - - -/**************************************************************************** -* epicInit - Initialize the EPIC registers -* -* This routine resets the Global Configuration Register, thus it: -* - Disables all interrupts -* - Sets epic registers to reset values -* - Sets the value of the Processor Current Task Priority to the -* highest priority (0xF). -* epicInit then sets the EPIC operation mode to Mixed Mode (vs. Pass -* Through or 8259 compatible mode). -* -* If IRQType (input) is Direct IRQs: -* - IRQType is written to the SIE bit of the EPIC Interrupt -* Configuration register (ICR). -* - clkRatio is ignored. -* If IRQType is Serial IRQs: -* - both IRQType and clkRatio will be written to the ICR register -*/ - -void epicInit - ( - unsigned int IRQType, /* Direct or Serial */ - unsigned int clkRatio /* Clk Ratio for Serial IRQs */ - ) - { - ULONG tmp; - - tmp = sysEUMBBARRead(EPIC_GLOBAL_REG); - tmp |= 0xa0000000; /* Set the Global Conf. register */ - sysEUMBBARWrite(EPIC_GLOBAL_REG, tmp); - /* - * Wait for EPIC to reset - CLH - */ - while( (sysEUMBBARRead(EPIC_GLOBAL_REG) & 0x80000000) == 1); - sysEUMBBARWrite(EPIC_GLOBAL_REG, 0x20000000); - tmp = sysEUMBBARRead(EPIC_INT_CONF_REG); /* Read interrupt conf. reg */ - - if (IRQType == EPIC_DIRECT_IRQ) /* direct mode */ - sysEUMBBARWrite(EPIC_INT_CONF_REG, tmp & 0xf7ffffff); - else /* Serial mode */ - { - tmp = (clkRatio << 28) | 0x08000000; /* Set clock ratio */ - sysEUMBBARWrite(EPIC_INT_CONF_REG, tmp); - } - - while (epicIntAck() != 0xff) /* Clear all pending interrupts */ - epicEOI(); -} - -/**************************************************************************** - * epicIntEnable - Enable an interrupt source - * - * This routine clears the mask bit of an external, an internal or - * a Timer register to enable the interrupt. - * - * RETURNS: None - */ -void epicIntEnable(int intVec) -{ - ULONG tmp; - ULONG srAddr; - - srAddr = SrcVecTable[intVec].srcAddr; /* Retrieve src Vec/Prio register */ - tmp = sysEUMBBARRead(srAddr); - tmp &= ~EPIC_VEC_PRI_MASK; /* Clear the mask bit */ - tmp |= (EPIC_VEC_PRI_DFLT_PRI << 16); /* Set priority to Default - CLH */ - tmp |= intVec; /* Set Vector number */ - sysEUMBBARWrite(srAddr, tmp); - - return; - } - -/**************************************************************************** - * epicIntDisable - Disable an interrupt source - * - * This routine sets the mask bit of an external, an internal or - * a Timer register to disable the interrupt. - * - * RETURNS: OK or ERROR - * - */ - -void epicIntDisable - ( - int intVec /* Interrupt vector number */ - ) - { - - ULONG tmp, srAddr; - - srAddr = SrcVecTable[intVec].srcAddr; - tmp = sysEUMBBARRead(srAddr); - tmp |= 0x80000000; /* Set the mask bit */ - sysEUMBBARWrite(srAddr, tmp); - return; - } - -/**************************************************************************** - * epicIntSourceConfig - Set properties of an interrupt source - * - * This function sets interrupt properites (Polarity, Sense, Interrupt - * Prority, and Interrupt Vector) of an Interrupt Source. The properties - * can be set when the current source is not in-request or in-service, - * which is determined by the Activity bit. This routine return ERROR - * if the the Activity bit is 1 (in-request or in-service). - * - * This function assumes that the Source Vector/Priority register (input) - * is a valid address. - * - * RETURNS: OK or ERROR - */ - -int epicIntSourceConfig - ( - int Vect, /* interrupt source vector number */ - int Polarity, /* interrupt source polarity */ - int Sense, /* interrupt source Sense */ - int Prio /* interrupt source priority */ - ) - - { - ULONG tmp, newVal; - ULONG actBit, srAddr; - - srAddr = SrcVecTable[Vect].srcAddr; - tmp = sysEUMBBARRead(srAddr); - actBit = (tmp & 40000000) >> 30; /* retrieve activity bit - bit 30 */ - if (actBit == 1) - return ERROR; - - tmp &= 0xff30ff00; /* Erase previously set P,S,Prio,Vector bits */ - newVal = (Polarity << 23) | (Sense << 22) | (Prio << 16) | Vect; - sysEUMBBARWrite(srAddr, tmp | newVal ); - return (OK); - } - -/**************************************************************************** - * epicIntAck - acknowledge an interrupt - * - * This function reads the Interrupt acknowldge register and return - * the vector number of the highest pending interrupt. - * - * RETURNS: Interrupt Vector number. - */ - -unsigned int epicIntAck(void) -{ - return(sysEUMBBARRead( EPIC_PROC_INT_ACK_REG )); -} - -/**************************************************************************** - * epicEOI - signal an end of interrupt - * - * This function writes 0x0 to the EOI register to signal end of interrupt. - * It is usually called after an interrupt routine is served. - * - * RETURNS: None - */ - -void epicEOI(void) - { - sysEUMBBARWrite(EPIC_PROC_EOI_REG, 0x0); - } - -/**************************************************************************** - * epicCurTaskPrioSet - sets the priority of the Processor Current Task - * - * This function should be called after epicInit() to lower the priority - * of the processor current task. - * - * RETURNS: OK or ERROR - */ - -int epicCurTaskPrioSet - ( - int prioNum /* New priority value */ - ) - { - - if ( (prioNum < 0) || (prioNum > 0xF)) - return ERROR; - sysEUMBBARWrite(EPIC_PROC_CTASK_PRI_REG, prioNum); - return OK; - } - - -/************************************************************************ - * function: epicIntTaskGet - * - * description: Get value of processor current interrupt task priority register - * - * note: - ***********************************************************************/ -unsigned char epicIntTaskGet() -{ - /* get the interrupt task priority register */ - ULONG reg; - unsigned char rec; - - reg = sysEUMBBARRead( EPIC_PROC_CTASK_PRI_REG ); - rec = ( reg & 0x0F ); - return rec; -} - - -/************************************************************** - * function: epicISR - * - * description: EPIC service routine called by the core exception - * at 0x500 - * - * note: - **************************************************************/ -unsigned int epicISR(void) -{ - return 0; -} - - -/************************************************************ - * function: epicModeGet - * - * description: query EPIC mode, return 0 if pass through mode - * return 1 if mixed mode - * - * note: - *************************************************************/ -unsigned int epicModeGet(void) -{ - ULONG val; - - val = sysEUMBBARRead( EPIC_GLOBAL_REG ); - return (( val & 0x20000000 ) >> 29); -} - - -/********************************************* - * function: epicConfigGet - * - * description: Get the EPIC interrupt Configuration - * return 0 if not error, otherwise return 1 - * - * note: - ********************************************/ -void epicConfigGet( unsigned int *clkRatio, unsigned int *serEnable) -{ - ULONG val; - - val = sysEUMBBARRead( EPIC_INT_CONF_REG ); - *clkRatio = ( val & 0x70000000 ) >> 28; - *serEnable = ( val & 0x8000000 ) >> 27; -} - - -/******************************************************************* - * sysEUMBBARRead - Read a 32-bit EUMBBAR register - * - * This routine reads the content of a register in the Embedded - * Utilities Memory Block, and swaps to big endian before returning - * the value. - * - * RETURNS: The content of the specified EUMBBAR register. - */ - -ULONG sysEUMBBARRead - ( - ULONG regNum - ) - { - ULONG temp; - - temp = *(ULONG *) (CONFIG_SYS_EUMB_ADDR + regNum); - return ( LONGSWAP(temp)); - } - -/******************************************************************* - * sysEUMBBARWrite - Write a 32-bit EUMBBAR register - * - * This routine swaps the value to little endian then writes it to - * a register in the Embedded Utilities Memory Block address space. - * - * RETURNS: N/A - */ - -void sysEUMBBARWrite - ( - ULONG regNum, /* EUMBBAR register address */ - ULONG regVal /* Value to be written */ - ) - { - - *(ULONG *) (CONFIG_SYS_EUMB_ADDR + regNum) = LONGSWAP(regVal); - return ; - } - - -/******************************************************** - * function: epicVendorId - * - * description: return the EPIC Vendor Identification - * register: - * - * siliccon version, device id, and vendor id - * - * note: - ********************************************************/ -void epicVendorId - ( - unsigned int *step, - unsigned int *devId, - unsigned int *venId - ) - { - ULONG val; - val = sysEUMBBARRead( EPIC_VENDOR_ID_REG ); - *step = ( val & 0x00FF0000 ) >> 16; - *devId = ( val & 0x0000FF00 ) >> 8; - *venId = ( val & 0x000000FF ); - } - -/************************************************** - * function: epicFeatures - * - * description: return the number of IRQ supported, - * number of CPU, and the version of the - * OpenEPIC - * - * note: - *************************************************/ -void epicFeatures - ( - unsigned int *noIRQs, - unsigned int *noCPUs, - unsigned int *verId - ) - { - ULONG val; - - val = sysEUMBBARRead( EPIC_FEATURES_REG ); - *noIRQs = ( val & 0x07FF0000 ) >> 16; - *noCPUs = ( val & 0x00001F00 ) >> 8; - *verId = ( val & 0x000000FF ); -} - - -/********************************************************* - * function: epciTmFrequncySet - * - * description: Set the timer frequency reporting register - ********************************************************/ -void epicTmFrequencySet( unsigned int frq ) -{ - sysEUMBBARWrite(EPIC_TM_FREQ_REG, frq); -} - -/******************************************************* - * function: epicTmFrequncyGet - * - * description: Get the current value of the Timer Frequency - * Reporting register - * - ******************************************************/ -unsigned int epicTmFrequencyGet(void) -{ - return( sysEUMBBARRead(EPIC_TM_FREQ_REG)) ; -} - - -/**************************************************** - * function: epicTmBaseSet - * - * description: Set the #n global timer base count register - * return 0 if no error, otherwise return 1. - * - * note: - ****************************************************/ -unsigned int epicTmBaseSet - ( - ULONG srcAddr, /* Address of the Timer Base register */ - unsigned int cnt, /* Base count */ - unsigned int inhibit /* 1 - count inhibit */ - ) -{ - - unsigned int val = 0x80000000; - /* First inhibit counting the timer */ - sysEUMBBARWrite(srcAddr, val) ; - - /* set the new value */ - val = (cnt & 0x7fffffff) | ((inhibit & 0x1) << 31); - sysEUMBBARWrite(srcAddr, val) ; - return 0; -} - -/*********************************************************************** - * function: epicTmBaseGet - * - * description: Get the current value of the global timer base count register - * return 0 if no error, otherwise return 1. - * - * note: - ***********************************************************************/ -unsigned int epicTmBaseGet( ULONG srcAddr, unsigned int *val ) -{ - *val = sysEUMBBARRead( srcAddr ); - *val = *val & 0x7fffffff; - return 0; -} - -/*********************************************************** - * function: epicTmCountGet - * - * description: Get the value of a given global timer - * current count register - * return 0 if no error, otherwise return 1 - * note: - **********************************************************/ -unsigned int epicTmCountGet( ULONG srcAddr, unsigned int *val ) -{ - *val = sysEUMBBARRead( srcAddr ); - *val = *val & 0x7fffffff; - return 0; -} - - -/*********************************************************** - * function: epicTmInhibit - * - * description: Stop counting of a given global timer - * return 0 if no error, otherwise return 1 - * - * note: - ***********************************************************/ -unsigned int epicTmInhibit( unsigned int srcAddr ) -{ - ULONG val; - - val = sysEUMBBARRead( srcAddr ); - val |= 0x80000000; - sysEUMBBARWrite( srcAddr, val ); - return 0; -} - -/****************************************************************** - * function: epicTmEnable - * - * description: Enable counting of a given global timer - * return 0 if no error, otherwise return 1 - * - * note: - *****************************************************************/ -unsigned int epicTmEnable( ULONG srcAddr ) -{ - ULONG val; - - val = sysEUMBBARRead( srcAddr ); - val &= 0x7fffffff; - sysEUMBBARWrite( srcAddr, val ); - return 0; -} - -void epicSourcePrint(int Vect) - { - ULONG srcVal; - - srcVal = sysEUMBBARRead(SrcVecTable[Vect].srcAddr); - PRINT("%s\n", SrcVecTable[Vect].srcName); - PRINT("Address = 0x%lx\n", SrcVecTable[Vect].srcAddr); - PRINT("Vector = %ld\n", (srcVal & 0x000000FF) ); - PRINT("Mask = %ld\n", srcVal >> 31); - PRINT("Activitiy = %ld\n", (srcVal & 40000000) >> 30); - PRINT("Polarity = %ld\n", (srcVal & 0x00800000) >> 23); - PRINT("Sense = %ld\n", (srcVal & 0x00400000) >> 22); - PRINT("Priority = %ld\n", (srcVal & 0x000F0000) >> 16); - } diff --git a/arch/powerpc/cpu/mpc824x/drivers/epic/epic2.S b/arch/powerpc/cpu/mpc824x/drivers/epic/epic2.S deleted file mode 100644 index 52d19aa..0000000 --- a/arch/powerpc/cpu/mpc824x/drivers/epic/epic2.S +++ /dev/null @@ -1,196 +0,0 @@ -/************************************** - * - * copyright @ Motorola, 1999 - * - **************************************/ - -#include <ppc_asm.tmpl> -#include <ppc_defs.h> -#include <asm/processor.h> - -/********************************************* - * function: CoreExtIntEnable - * - * description: Enable 603e core external interrupt - * - * note: mtmsr is context-synchronization - **********************************************/ - .text - .align 2 - .global CoreExtIntEnable -CoreExtIntEnable: - mfmsr r3 - - ori r3,r3,0x8000 /* enable external interrupt */ - mtmsr r3 - - bclr 20, 0 - -/******************************************* - * function: CoreExtIntDisable - * - * description: Disable 603e core external interrupt - * - * note: - *******************************************/ - .text - .align 2 - .global CoreExtIntDisable -CoreExtIntDisable: - mfmsr r4 - - xor r3,r3,r3 - or r3,r3,r4 - - andis. r4,r4,0xffff - andi. r3,r3,0x7fff /* disable external interrupt */ - - or r3,r3,r4 - mtmsr r3 - - bclr 20, 0 - -/********************************************************* - * function: epicEOI - * - * description: signal the EOI and restore machine status - * Input: r3 - value of eumbbar - * Output: r3 - value of eumbbar - * r4 - ISR vector value - * note: - ********************************************************/ - .text - .align 2 - .global epicEOI -epicEOI: - lis r5,0x0006 /* Build End Of Interrupt Register offset */ - ori r5,r5,0x00b0 - xor r7,r7,r7 /* Clear r7 */ - stwbrx r7,r5,r3 /* Save r7, writing to this register will - * intidate the end of processing the - * highest interrupt. - */ - sync - - /* ---RESTORE MACHINE STATE */ - mfmsr r13 /* Clear Recoverable Interrupt bit in MSR */ - or r7,r7,r13 - - andis. r7,r7,0xffff - andi. r13,r13,0x7ffd /* (and disable interrupts) */ - or r13,r13,r7 - mtmsr r13 - - lwz r13,0x1c(r1) /* pull ctr */ - mtctr r13 - - lwz r13,0x18(r1) /* pull xer */ - mtctr r13 - - lwz r13,0x14(r1) /* pull lr */ - mtctr r13 - - lwz r13,0x10(r1) /* Pull SRR1 from stack */ - mtspr SRR1,r13 /* Restore SRR1 */ - - lwz r13,0xc(r1) /* Pull SRR0 from stack */ - mtspr SRR0,r13 /* Restore SRR0 */ - - lwz r13,0x8(r1) /* Pull User stack pointer from stack */ - mtspr SPRG1,r13 /* Restore SPRG1 */ - - lwz r4,0x4(r1) /* vector value */ - lwz r3,0x0(r1) /* eumbbar */ - sync - - addi r1,r1,0x20 /* Deallocate stack */ - mtspr SPRG0,r1 /* Save updated Supervisor stack pointer */ - mfspr r1,SPRG1 /* Restore User stack pointer */ - - bclr 20,0 - -/*********************************************************** - * function: exception routine called by exception vector - * at 0x500, external interrupt - * - * description: Kahlua EPIC controller - * - * input: r3 - content of eumbbar - * output: r3 - ISR return value - * r4 - Interrupt vector number - * note: - ***********************************************************/ - - .text - .align 2 - .global epic_exception - -epic_exception: - - /*---SAVE MACHINE STATE TO A STACK */ - mtspr SPRG1,r1 /* Save User stack pointer to SPRG1 */ - mfspr r1,SPRG0 /* Load Supervisor stack pointer into r1 */ - - stwu r3,-0x20(r1) /* Push the value of eumbbar onto stack */ - - mfspr r3,SPRG1 /* Push User stack pointer onto stack */ - stw r3,0x8(r1) - mfspr r3,SRR0 /* Push SRR0 onto stack */ - stw r1,0xc(r1) - mfspr r3,SRR1 /* Push SRR1 onto stack */ - stw r3,0x10(r1) - mflr r3 - stw r3,0x14(r1) /* Push LR */ - mfxer r3 - stw r3,0x18(r1) /* Push Xer */ - mfctr r3 - stw r3,0x1c(r1) /* Push CTR */ - - mtspr SPRG0,r1 /* Save updated Supervisor stack pointer - * value to SPRG0 - */ - mfmsr r3 - ori r3,r3,0x0002 /* Set Recoverable Interrupt bit in MSR */ - mtmsr r3 - - /* ---READ IN THE EUMBAR REGISTER */ - lwz r6,0(r1) /* this is eumbbar */ - sync - - /* ---READ EPIC REGISTER: PROCESSOR INTERRUPT ACKNOWLEDGE REGISTER */ - lis r5,0x0006 /* Build Interrupt Acknowledge Register - * offset - */ - ori r5,r5,0x00a0 - lwbrx r7,r5,r6 /* Load interrupt vector into r7 */ - sync - - /* --MASK OFF ALL BITS EXCEPT THE VECTOR */ - xor r3,r3,r3 - xor r4,r4,r4 - or r3, r3, r6 /* eumbbar in r3 */ - andi. r4,r7,0x00ff /* Mask off bits, vector in r4 */ - - stw r4,0x04(r1) /* save the vector value */ - - lis r5,epicISR@ha - ori r5,r5,epicISR@l - mtlr r5 - blrl - - xor r30,r30,r30 - or r30,r30,r3 /* save the r3 which containts the return value from epicISR */ - - /* ---READ IN THE EUMBAR REGISTER */ - lwz r3,0(r1) - sync - - lis r5,epicEOI@ha - ori r5,r5,epicEOI@l - mtlr r5 - blrl - - xor r3,r3,r3 - or r3,r3,r30 /* restore the ISR return value */ - - bclr 20,0 diff --git a/arch/powerpc/cpu/mpc824x/drivers/epic/epicutil.S b/arch/powerpc/cpu/mpc824x/drivers/epic/epicutil.S deleted file mode 100644 index 4877050..0000000 --- a/arch/powerpc/cpu/mpc824x/drivers/epic/epicutil.S +++ /dev/null @@ -1,57 +0,0 @@ -/************************************** - * - * copyright @ Motorola, 1999 - * - * - * This file contains two commonly used - * lower level utility routines. - * - * The utility routines are also in other - * Kahlua device driver libraries. The - * need to be linked in only once. - **************************************/ - -#include <ppc_asm.tmpl> -#include <ppc_defs.h> - -/********************************************************** - * function: load_runtime_reg - * - * input: r3 - value of eumbbar - * r4 - register offset in embedded utility space - * - * output: r3 - register content - **********************************************************/ - .text - .align 2 - .global load_runtime_reg - -load_runtime_reg: - - xor r5,r5,r5 - or r5,r5,r3 /* save eumbbar */ - - lwbrx r3,r4,r5 - sync - - bclr 20, 0 - -/**************************************************************** - * function: store_runtime_reg - * - * input: r3 - value of eumbbar - * r4 - register offset in embedded utility space - * r5 - new value to be stored - * - ****************************************************************/ - .text - .align 2 - .global store_runtime_reg -store_runtime_reg: - - xor r0,r0,r0 - - stwbrx r5, r4, r3 - sync - - bclr 20,0 diff --git a/arch/powerpc/cpu/mpc824x/drivers/errors.h b/arch/powerpc/cpu/mpc824x/drivers/errors.h deleted file mode 100644 index 20794a2..0000000 --- a/arch/powerpc/cpu/mpc824x/drivers/errors.h +++ /dev/null @@ -1,212 +0,0 @@ -/* Copyright Motorola, Inc. 1993, 1994 - ALL RIGHTS RESERVED - - You are hereby granted a copyright license to use, modify, and - distribute the SOFTWARE so long as this entire notice is retained - without alteration in any modified and/or redistributed versions, - and that such modified versions are clearly identified as such. - No licenses are granted by implication, estoppel or otherwise under - any patents or trademarks of Motorola, Inc. - - The SOFTWARE is provided on an "AS IS" basis and without warranty. - To the maximum extent permitted by applicable law, MOTOROLA DISCLAIMS - ALL WARRANTIES WHETHER EXPRESS OR IMPLIED, INCLUDING IMPLIED - WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR - PURPOSE AND ANY WARRANTY AGAINST INFRINGEMENT WITH - REGARD TO THE SOFTWARE (INCLUDING ANY MODIFIED VERSIONS - THEREOF) AND ANY ACCOMPANYING WRITTEN MATERIALS. - - To the maximum extent permitted by applicable law, IN NO EVENT SHALL - MOTOROLA BE LIABLE FOR ANY DAMAGES WHATSOEVER - (INCLUDING WITHOUT LIMITATION, DAMAGES FOR LOSS OF - BUSINESS PROFITS, BUSINESS INTERRUPTION, LOSS OF BUSINESS - INFORMATION, OR OTHER PECUNIARY LOSS) ARISING OF THE USE OR - INABILITY TO USE THE SOFTWARE. Motorola assumes no responsibility - for the maintenance and support of the SOFTWARE. - -*/ - - -#include "config.h" - -/* - 1 2 3 4 5 6 7 8 -01234567890123456789012345678901234567890123456789012345678901234567890123456789 -*/ -/* List define statements here */ - -/* These are for all the toolboxes and functions to use. These will help -to standardize the error handling in the current project */ - - /* this is the "data type" for the error - messages in the system */ -#define STATUS unsigned int - - /* this is a success status code */ -#define SUCCESS 1 - - /* likewise this is failure */ -#define FAILURE 0 - -#define NUM_ERRORS 47 - -/* This first section of "defines" are for error codes ONLY. The called - routine will return one of these error codes to the caller. If the final - returned code is "VALID", then everything is a-okay. However, if one - of the functions returns a non-valid status, that error code should be - propogated back to all the callers. At the end, the last caller will - call an error_processing function, and send in the status which was - returned. It's up to the error_processing function to determine which - error occured (as indicated by the status), and print an appropriate - message back to the user. -*/ -/*----------------------------------------------------------------------*/ -/* these are specifically for the parser routines */ - -#define UNKNOWN_COMMAND 0xfb00 /* "unrecognized command " */ -#define UNKNOWN_REGISTER 0xfb01 /* "unknown register "*/ -#define ILLEGAL_RD_STAGE 0xfb02 /* cannot specify reg. family in range*/ -#define ILLEGAL_REG_FAMILY 0xfb03 /* "cannot specify a range of special - or miscellaneous registers"*/ -#define RANGE_CROSS_FAMILY 0xfb04 /* "cannot specify a range across - register families" */ -#define UNIMPLEMENTED_STAGE 0xfb05 /* invalid rd or rmm parameter format */ -#define REG_NOT_WRITEABLE 0xfb06 /* "unknown operator in arguements"*/ -#define INVALID_FILENAME 0xfb07 /* "invalid download filename" */ -#define INVALID_BAUD_RATE 0xfb08 /* invalid baud rate from sb command */ -#define UNSUPPORTED_REGISTER 0xfb09 /* Special register is not supported */ -#define FOR_BOARD_ONLY 0xfb0a /* "Not available for Unix." */ - - -/*----------------------------------------------------------------------*/ -/* these are for the error checking toolbox */ - -#define INVALID 0xfd00 /* NOT valid */ -#define VALID 0xfd01 /* valid */ - - /* This error is found in the fcn: - is_right_size_input() to indicate - that the input was not 8 characters - long. */ -#define INVALID_SIZE 0xfd02 - - /* This error is found in the fcn: - is_valid_address_range() to indicate - that the address given falls outside - of valid memory defined by MEM_START - to MEM_END. - */ -#define OUT_OF_BOUNDS_ADDRESS 0xfd03 - - /* This error is found in the fcn: - is_valid_hex_input() to indicate that - one of more of the characters entered - are not valid hex characters. Valid - hex characters are 0-9, A-F, a-f. - */ -#define INVALID_HEX_INPUT 0xfd04 - - /* This error is found in the fcn: - is_valid_register_number() to indicate - that a given register does not exist. - */ -#define REG_NOT_READABLE 0xfd05 - - /* This error is found in the fcn: - is_word_aligned_address() to indicate - that the given address is not word- - aligned. A word-aligned address ends - in 0x0,0x4,0x8,0xc. - */ -#define NOT_WORD_ALIGNED 0xfd07 - - /* This error is found in the fcn: - is_valid_address_range() to indicate - that the starting address is greater - than the ending address. - */ -#define REVERSED_ADDRESS 0xfd08 - - /* this error tells us that the address - specified as the destination is within - the source addresses */ -#define RANGE_OVERLAP 0xfd09 - - -#define ERROR 0xfd0a /* An error occured */ -#define INVALID_PARAM 0xfd0b /* "invalid input parameter " */ - - -#define INVALID_FLAG 0xfd0c /* invalid flag */ - -/*----------------------------------------------------------------------*/ -/* these are for the getarg toolbox */ - -#define INVALID_NUMBER_ARGS 0xFE00 /* invalid number of commd arguements */ -#define UNKNOWN_PARAMETER 0xFE01 /* "unknown type of parameter "*/ - - -/*----------------------------------------------------------------------*/ -/* these are for the tokenizer toolbox */ - -#define ILLEGAL_CHARACTER 0xFF00 /* unrecognized char. in input stream*/ -#define TTL_NOT_SORTED 0xFF01 /* token translation list not sorted */ -#define TTL_NOT_DEFINED 0xFF02 /* token translation list not assigned*/ -#define INVALID_STRING 0xFF03 /* unable to extract string from input */ -#define BUFFER_EMPTY 0xFF04 /* "input buffer is empty" */ -#define INVALID_MODE 0xFF05 /* input buf is in an unrecognized mode*/ -#define TOK_INTERNAL_ERROR 0xFF06 /* "internal tokenizer error" */ -#define TOO_MANY_IBS 0xFF07 /* "too many open input buffers" */ -#define NO_OPEN_IBS 0xFF08 /* "no open input buffers" */ - - -/* these are for the read from screen toolbox */ - -#define RESERVED_WORD 0xFC00 /* used a reserved word as an arguement*/ - - -/* these are for the breakpoint routines */ - -#define FULL_BPDS 0xFA00 /* breakpoint data structure is full */ - - -/* THESE are for the downloader */ - -#define NOT_IN_S_RECORD_FORMAT 0xf900 /* "not in S-Record Format" */ -#define UNREC_RECORD_TYPE 0xf901 /* "unrecognized record type" */ -#define CONVERSION_ERROR 0xf902 /* "ascii to int conversion error" */ -#define INVALID_MEMORY 0xf903 /* "bad s-record memory address " */ - - -/* these are for the compression and decompression stuff */ - -#define COMP_UNK_CHARACTER 0xf800 /* "unknown compressed character " */ - -#define COMP_UNKNOWN_STATE 0xf801 /* "unknown binary state" */ - -#define NOT_IN_COMPRESSED_FORMAT 0xf802 /* not in compressed S-Record format */ - - -/* these are for the DUART handling things */ - - /* "unrecognized serial port configuration" */ -#define UNKNOWN_PORT_STATE 0xf700 - - -/* these are for the register toolbox */ - - /* "cannot find register in special - purpose register file " */ -#define SPR_NOT_FOUND 0xf600 - - -/* these are for the duart specific stuff */ - - /* "transparent mode needs access to - two serial ports" */ -#define TM_NEEDS_BOTH_PORTS 0xf500 - - -/*----------------------------------------------------------------------*/ -/* these are specifically for the flash routines */ -#define FLASH_ERROR 0xf100 /* general flash error */ diff --git a/arch/powerpc/cpu/mpc824x/drivers/i2c/i2c.c b/arch/powerpc/cpu/mpc824x/drivers/i2c/i2c.c deleted file mode 100644 index 3638ab0..0000000 --- a/arch/powerpc/cpu/mpc824x/drivers/i2c/i2c.c +++ /dev/null @@ -1,254 +0,0 @@ -/* - * (C) Copyright 2003 - * Gleb Natapov gnatapov@mrv.com - * Some bits are taken from linux driver writen by adrian@humboldt.co.uk - * - * Hardware I2C driver for MPC107 PCI bridge. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> - -#undef I2CDBG - -#ifdef CONFIG_HARD_I2C -#include <i2c.h> - -#define TIMEOUT (CONFIG_SYS_HZ/4) - -#define I2C_Addr ((unsigned *)(CONFIG_SYS_EUMB_ADDR + 0x3000)) - -#define I2CADR &I2C_Addr[0] -#define I2CFDR &I2C_Addr[1] -#define I2CCCR &I2C_Addr[2] -#define I2CCSR &I2C_Addr[3] -#define I2CCDR &I2C_Addr[4] - -#define MPC107_CCR_MEN 0x80 -#define MPC107_CCR_MIEN 0x40 -#define MPC107_CCR_MSTA 0x20 -#define MPC107_CCR_MTX 0x10 -#define MPC107_CCR_TXAK 0x08 -#define MPC107_CCR_RSTA 0x04 - -#define MPC107_CSR_MCF 0x80 -#define MPC107_CSR_MAAS 0x40 -#define MPC107_CSR_MBB 0x20 -#define MPC107_CSR_MAL 0x10 -#define MPC107_CSR_SRW 0x04 -#define MPC107_CSR_MIF 0x02 -#define MPC107_CSR_RXAK 0x01 - -#define I2C_READ 1 -#define I2C_WRITE 0 - -/* taken from linux include/asm-ppc/io.h */ -inline unsigned in_le32 (volatile unsigned *addr) -{ - unsigned ret; - - __asm__ __volatile__ ("lwbrx %0,0,%1;\n" - "twi 0,%0,0;\n" - "isync":"=r" (ret): "r" (addr), "m" (*addr)); - return ret; -} - -inline void out_le32 (volatile unsigned *addr, int val) -{ - __asm__ __volatile__ ("stwbrx %1,0,%2; eieio":"=m" (*addr):"r" (val), - "r" (addr)); -} - -#define writel(val, addr) out_le32(addr, val) -#define readl(addr) in_le32(addr) - -void i2c_init (int speed, int slaveadd) -{ - /* stop I2C controller */ - writel (0x0, I2CCCR); - /* set clock */ - writel (0x1020, I2CFDR); - /* write slave address */ - writel (slaveadd, I2CADR); - /* clear status register */ - writel (0x0, I2CCSR); - /* start I2C controller */ - writel (MPC107_CCR_MEN, I2CCCR); - - return; -} - -static __inline__ int i2c_wait4bus (void) -{ - ulong timeval = get_timer (0); - - while (readl (I2CCSR) & MPC107_CSR_MBB) - if (get_timer (timeval) > TIMEOUT) - return -1; - - return 0; -} - -static __inline__ int i2c_wait (int write) -{ - u32 csr; - ulong timeval = get_timer (0); - - do { - csr = readl (I2CCSR); - - if (!(csr & MPC107_CSR_MIF)) - continue; - - writel (0x0, I2CCSR); - - if (csr & MPC107_CSR_MAL) { -#ifdef I2CDBG - printf ("i2c_wait: MAL\n"); -#endif - return -1; - } - - if (!(csr & MPC107_CSR_MCF)) { -#ifdef I2CDBG - printf ("i2c_wait: unfinished\n"); -#endif - return -1; - } - - if (write == I2C_WRITE && (csr & MPC107_CSR_RXAK)) { -#ifdef I2CDBG - printf ("i2c_wait: No RXACK\n"); -#endif - return -1; - } - - return 0; - } while (get_timer (timeval) < TIMEOUT); - -#ifdef I2CDBG - printf ("i2c_wait: timed out\n"); -#endif - return -1; -} - -static __inline__ int i2c_write_addr (u8 dev, u8 dir, int rsta) -{ - writel (MPC107_CCR_MEN | MPC107_CCR_MSTA | MPC107_CCR_MTX | - (rsta ? MPC107_CCR_RSTA : 0), I2CCCR); - - writel ((dev << 1) | dir, I2CCDR); - - if (i2c_wait (I2C_WRITE) < 0) - return 0; - - return 1; -} - -static __inline__ int __i2c_write (u8 * data, int length) -{ - int i; - - writel (MPC107_CCR_MEN | MPC107_CCR_MSTA | MPC107_CCR_MTX, I2CCCR); - - for (i = 0; i < length; i++) { - writel (data[i], I2CCDR); - - if (i2c_wait (I2C_WRITE) < 0) - break; - } - - return i; -} - -static __inline__ int __i2c_read (u8 * data, int length) -{ - int i; - - writel (MPC107_CCR_MEN | MPC107_CCR_MSTA | - ((length == 1) ? MPC107_CCR_TXAK : 0), I2CCCR); - - /* dummy read */ - readl (I2CCDR); - - for (i = 0; i < length; i++) { - if (i2c_wait (I2C_READ) < 0) - break; - - /* Generate ack on last next to last byte */ - if (i == length - 2) - writel (MPC107_CCR_MEN | MPC107_CCR_MSTA | - MPC107_CCR_TXAK, I2CCCR); - - /* Generate stop on last byte */ - if (i == length - 1) - writel (MPC107_CCR_MEN | MPC107_CCR_TXAK, I2CCCR); - - data[i] = readl (I2CCDR); - } - - return i; -} - -int i2c_read (u8 dev, uint addr, int alen, u8 * data, int length) -{ - int i = 0; - u8 *a = (u8 *) & addr; - - if (i2c_wait4bus () < 0) - goto exit; - - if (i2c_write_addr (dev, I2C_WRITE, 0) == 0) - goto exit; - - if (__i2c_write (&a[4 - alen], alen) != alen) - goto exit; - - if (i2c_write_addr (dev, I2C_READ, 1) == 0) - goto exit; - - i = __i2c_read (data, length); - -exit: - writel (MPC107_CCR_MEN, I2CCCR); - - return !(i == length); -} - -int i2c_write (u8 dev, uint addr, int alen, u8 * data, int length) -{ - int i = 0; - u8 *a = (u8 *) & addr; - - if (i2c_wait4bus () < 0) - goto exit; - - if (i2c_write_addr (dev, I2C_WRITE, 0) == 0) - goto exit; - - if (__i2c_write (&a[4 - alen], alen) != alen) - goto exit; - - i = __i2c_write (data, length); - -exit: - writel (MPC107_CCR_MEN, I2CCCR); - - return !(i == length); -} - -int i2c_probe (uchar chip) -{ - int tmp; - - /* - * Try to read the first location of the chip. The underlying - * driver doesn't appear to support sending just the chip address - * and looking for an <ACK> back. - */ - udelay (10000); - return i2c_read (chip, 0, 1, (uchar *) &tmp, 1); -} - -#endif /* CONFIG_HARD_I2C */ diff --git a/arch/powerpc/cpu/mpc824x/interrupts.c b/arch/powerpc/cpu/mpc824x/interrupts.c deleted file mode 100644 index fad103f..0000000 --- a/arch/powerpc/cpu/mpc824x/interrupts.c +++ /dev/null @@ -1,77 +0,0 @@ -/* - * (C) Copyright 2000-2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * Rob Taylor, Flying Pig Systems. robt@flyingpig.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc824x.h> -#include <asm/processor.h> -#include <asm/pci_io.h> -#include <commproc.h> -#include "drivers/epic.h" - -int interrupt_init_cpu (unsigned *decrementer_count) -{ - *decrementer_count = (get_bus_freq (0) / 4) / CONFIG_SYS_HZ; - - /* - * It's all broken at the moment and I currently don't need - * interrupts. If you want to fix it, have a look at the epic - * drivers in dink32 v12. They do everthing and Motorola said - * I could use the dink source in this project as long as - * copyright notices remain intact. - */ - - epicInit (EPIC_DIRECT_IRQ, 0); - /* EPIC won't generate INT unless Current Task Pri < 15 */ - epicCurTaskPrioSet(0); - - return (0); -} - -/****************************************************************************/ - -/* - * Handle external interrupts - */ -void external_interrupt (struct pt_regs *regs) -{ - register unsigned long temp; - - pci_readl (CONFIG_SYS_EUMB_ADDR + EPIC_PROC_INT_ACK_REG, temp); - sync (); /* i'm not convinced this is needed, but dink source has it */ - temp &= 0xff; /*get vector */ - - /*TODO: handle them -... */ - epicEOI (); -} - -/****************************************************************************/ - -/* - * blank int handlers. - */ - -void -irq_install_handler (int vec, interrupt_handler_t * handler, void *arg) -{ -} - -void irq_free_handler (int vec) -{ - -} - -/*TODO: some handlers for winbond and 87308 interrupts - and what about generic pci inteerupts? - vga? - */ - -void timer_interrupt_cpu (struct pt_regs *regs) -{ - /* nothing to do here */ - return; -} diff --git a/arch/powerpc/cpu/mpc824x/pci.c b/arch/powerpc/cpu/mpc824x/pci.c deleted file mode 100644 index 1257b08..0000000 --- a/arch/powerpc/cpu/mpc824x/pci.c +++ /dev/null @@ -1,75 +0,0 @@ -/* - * arch/powerpc/kernel/mpc10x_common.c - * - * Common routines for the Motorola SPS MPC106, MPC107 and MPC8240 Host bridge, - * Mem ctlr, EPIC, etc. - * - * Author: Mark A. Greer - * mgreer@mvista.com - * - * Copyright 2001 MontaVista Software Inc. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> - -#ifdef CONFIG_PCI - -#include <asm/processor.h> -#include <asm/io.h> -#include <pci.h> -#include <mpc824x.h> - -void pci_mpc824x_init (struct pci_controller *hose) -{ - hose->first_busno = 0; - hose->last_busno = 0xff; - - /* System memory space */ - pci_set_region(hose->regions + 0, - CHRP_PCI_MEMORY_BUS, - CHRP_PCI_MEMORY_PHYS, - CHRP_PCI_MEMORY_SIZE, - PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); - - /* PCI memory space */ - pci_set_region(hose->regions + 1, - CHRP_PCI_MEM_BUS, - CHRP_PCI_MEM_PHYS, - CHRP_PCI_MEM_SIZE, - PCI_REGION_MEM); - - /* ISA/PCI memory space */ - pci_set_region(hose->regions + 2, - CHRP_ISA_MEM_BUS, - CHRP_ISA_MEM_PHYS, - CHRP_ISA_MEM_SIZE, - PCI_REGION_MEM); - - /* PCI I/O space */ - pci_set_region(hose->regions + 3, - CHRP_PCI_IO_BUS, - CHRP_PCI_IO_PHYS, - CHRP_PCI_IO_SIZE, - PCI_REGION_IO); - - /* ISA/PCI I/O space */ - pci_set_region(hose->regions + 4, - CHRP_ISA_IO_BUS, - CHRP_ISA_IO_PHYS, - CHRP_ISA_IO_SIZE, - PCI_REGION_IO); - - hose->region_count = 5; - - pci_setup_indirect(hose, - CHRP_REG_ADDR, - CHRP_REG_DATA); - - pci_register_hose(hose); - - hose->last_busno = pci_hose_scan(hose); -} - -#endif diff --git a/arch/powerpc/cpu/mpc824x/speed.c b/arch/powerpc/cpu/mpc824x/speed.c deleted file mode 100644 index e6064a1..0000000 --- a/arch/powerpc/cpu/mpc824x/speed.c +++ /dev/null @@ -1,102 +0,0 @@ -/* - * (C) Copyright 2001 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * (C) Copyright 2002 - * Gregory E. Allen, gallen@arlut.utexas.edu - * Applied Research Laboratories, The University of Texas at Austin - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc824x.h> -#include <asm/processor.h> - -DECLARE_GLOBAL_DATA_PTR; - -/* ------------------------------------------------------------------------- */ -/* NOTE: This describes the proper use of this file. - * - * CONFIG_SYS_CLK_FREQ should be defined as the input frequency on - * PCI_SYNC_IN . - * - * CONFIG_PLL_PCI_TO_MEM_MULTIPLIER is only required on MPC8240 - * boards. It should be defined as the PCI to Memory Multiplier as - * documented in the MPC8240 Hardware Specs. - * - * Other mpc824x boards don't need CONFIG_PLL_PCI_TO_MEM_MULTIPLIER - * because they can determine it from the PCR. - * - * Gary Milliorn gary.milliorn@motorola.com (who should know since - * he designed the Sandpoint) told us that the PCR is not in all revs - * of the MPC8240 CPU, so it's not guaranteeable and we cannot do - * away with CONFIG_PLL_PCI_TO_MEM_MULTIPLIER altogether. - */ -/* ------------------------------------------------------------------------- */ - -/* This gives the PCI to Memory multiplier times 10 */ -/* The index is the value of PLL_CFG[0:4] */ -/* This is documented in the MPC8240/5 Hardware Specs */ - -short pll_pci_to_mem_multiplier[] = { -#if defined(CONFIG_MPC8240) - 30, 30, 10, 10, 20, 10, 0, 10, - 10, 0, 20, 0, 20, 0, 20, 0, - 30, 0, 15, 0, 20, 0, 20, 0, - 25, 0, 10, 0, 15, 15, 0, 0, -#elif defined(CONFIG_MPC8245) - 30, 30, 10, 10, 20, 10, 10, 10, - 10, 20, 20, 15, 20, 15, 20, 30, - 30, 40, 15, 40, 20, 25, 20, 40, - 25, 20, 10, 20, 15, 15, 15, 0, -#else -#error Specific type of MPC824x must be defined (i.e. CONFIG_MPC8240) -#endif -}; - -#define CU824_PLL_STATE_REG 0xFE80002F -#define PCR 0x800000E2 - -/* ------------------------------------------------------------------------- */ - -/* compute the memory bus clock frequency */ -ulong get_bus_freq (ulong dummy) -{ - unsigned char pll_cfg; -#if defined(CONFIG_MPC8240) && !defined(CONFIG_CU824) - return (CONFIG_SYS_CLK_FREQ) * (CONFIG_PLL_PCI_TO_MEM_MULTIPLIER); -#elif defined(CONFIG_CU824) - pll_cfg = *(volatile unsigned char *) (CU824_PLL_STATE_REG); - pll_cfg &= 0x1f; -#else - CONFIG_READ_BYTE(PCR, pll_cfg); - pll_cfg = (pll_cfg >> 3) & 0x1f; -#endif - return ((CONFIG_SYS_CLK_FREQ) * pll_pci_to_mem_multiplier[pll_cfg] + 5) / 10; -} - - -/* ------------------------------------------------------------------------- */ - -/* This gives the Memory to CPU Core multiplier times 10 */ -/* The index is the value of PLLRATIO in HID1 */ -/* This is documented in the MPC8240 Hardware Specs */ -/* This is not documented for MPC8245 ? FIXME */ -short pllratio_to_factor[] = { - 0, 0, 0, 10, 20, 20, 25, 45, - 30, 0, 0, 0, 0, 0, 0, 0, - 0, 0, 0, 10, 0, 0, 0, 45, - 30, 0, 40, 0, 0, 0, 35, 0, -}; - -/* compute the CPU and memory bus clock frequencies */ -int get_clocks (void) -{ - uint hid1 = mfspr(HID1); - hid1 = (hid1 >> (32-5)) & 0x1f; - gd->cpu_clk = (pllratio_to_factor[hid1] * get_bus_freq(0) + 5) - / 10; - gd->bus_clk = get_bus_freq(0); - return (0); -} diff --git a/arch/powerpc/cpu/mpc824x/start.S b/arch/powerpc/cpu/mpc824x/start.S deleted file mode 100644 index 55238df..0000000 --- a/arch/powerpc/cpu/mpc824x/start.S +++ /dev/null @@ -1,724 +0,0 @@ -/* - * Copyright (C) 1998 Dan Malek dmalek@jlc.net - * Copyright (C) 1999 Magnus Damm <kieraypc01.p.y.kie.era.ericsson.se> - * Copyright (C) 2000,2001,2002 Wolfgang Denk wd@denx.de - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* U-Boot - Startup Code for PowerPC based Embedded Boards - * - * - * The processor starts at 0x00000100 and the code is executed - * from flash. The code is organized to be at an other address - * in memory, but as long we don't jump around before relocating. - * board_init lies at a quite high address and when the cpu has - * jumped there, everything is ok. - * This works because the cpu gives the FLASH (CS0) the whole - * address space at startup, and board_init lies as a echo of - * the flash somewhere up there in the memorymap. - * - * board_init will change CS0 to be positioned at the correct - * address and (s)dram will be positioned at address 0 - */ -#include <asm-offsets.h> -#include <config.h> -#include <mpc824x.h> -#include <version.h> - -#include <ppc_asm.tmpl> -#include <ppc_defs.h> - -#include <asm/cache.h> -#include <asm/mmu.h> -#include <asm/u-boot.h> - -/* We don't want the MMU yet. -*/ -#undef MSR_KERNEL -/* FP, Machine Check and Recoverable Interr. */ -#define MSR_KERNEL ( MSR_FP | MSR_ME | MSR_RI ) - -/* - * Set up GOT: Global Offset Table - * - * Use r12 to access the GOT - */ - START_GOT - GOT_ENTRY(_GOT2_TABLE_) - GOT_ENTRY(_FIXUP_TABLE_) - - GOT_ENTRY(_start) - GOT_ENTRY(_start_of_vectors) - GOT_ENTRY(_end_of_vectors) - GOT_ENTRY(transfer_to_handler) - - GOT_ENTRY(__init_end) - GOT_ENTRY(__bss_end) - GOT_ENTRY(__bss_start) - END_GOT - -/* - * r3 - 1st arg to board_init(): IMMP pointer - * r4 - 2nd arg to board_init(): boot flag - */ - .text - .long 0x27051956 /* U-Boot Magic Number */ - .globl version_string -version_string: - .ascii U_BOOT_VERSION_STRING, "\0" - - . = EXC_OFF_SYS_RESET - .globl _start -_start: - /* Initialize machine status; enable machine check interrupt */ - /*----------------------------------------------------------------------*/ - li r3, MSR_KERNEL /* Set FP, ME, RI flags */ - mtmsr r3 - mtspr SRR1, r3 /* Make SRR1 match MSR */ - - addis r0,0,0x0000 /* lets make sure that r0 is really 0 */ - mtspr HID0, r0 /* disable I and D caches */ - - mfspr r3, ICR /* clear Interrupt Cause Register */ - - mfmsr r3 /* turn off address translation */ - addis r4,0,0xffff - ori r4,r4,0xffcf - and r3,r3,r4 - mtmsr r3 - isync - sync /* the MMU should be off... */ - - -in_flash: - /* - * Setup BATs - cannot be done in C since we don't have a stack yet - */ - bl setup_bats - - /* Enable MMU. - */ - mfmsr r3 - ori r3, r3, (MSR_IR | MSR_DR) - mtmsr r3 - - /* Enable and invalidate data cache. - */ - mfspr r3, HID0 - mr r2, r3 - ori r3, r3, HID0_DCE | HID0_DCI - ori r2, r2, HID0_DCE - sync - mtspr HID0, r3 - mtspr HID0, r2 - sync - - /* Allocate Initial RAM in data cache. - */ - lis r3, CONFIG_SYS_INIT_RAM_ADDR@h - ori r3, r3, CONFIG_SYS_INIT_RAM_ADDR@l - li r2, 128 - mtctr r2 -1: - dcbz r0, r3 - addi r3, r3, 32 - bdnz 1b - - /* Lock way0 in data cache. - */ - mfspr r3, 1011 - lis r2, 0xffff - ori r2, r2, 0xff1f - and r3, r3, r2 - ori r3, r3, 0x0080 - sync - mtspr 1011, r3 - - /* - * Thisk the stack pointer *somewhere* sensible. Doesnt - * matter much where as we'll move it when we relocate - */ - lis r1, (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_GBL_DATA_OFFSET)@h - ori r1, r1, (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_GBL_DATA_OFFSET)@l - - li r0, 0 /* Make room for stack frame header and */ - stwu r0, -4(r1) /* clear final stack frame so that */ - stwu r0, -4(r1) /* stack backtraces terminate cleanly */ - - /* let the C-code set up the rest */ - /* */ - /* Be careful to keep code relocatable ! */ - /*----------------------------------------------------------------------*/ - - GET_GOT /* initialize GOT access */ - - /* r3: IMMR */ - bl cpu_init_f /* run low-level CPU init code (from Flash) */ - - bl board_init_f /* run 1st part of board init code (from Flash) */ - - /* NOTREACHED - board_init_f() does not return */ - - - .globl _start_of_vectors -_start_of_vectors: - -/* Machine check */ - STD_EXCEPTION(EXC_OFF_MACH_CHCK, MachineCheck, MachineCheckException) - -/* Data Storage exception. "Never" generated on the 860. */ - STD_EXCEPTION(EXC_OFF_DATA_STOR, DataStorage, UnknownException) - -/* Instruction Storage exception. "Never" generated on the 860. */ - STD_EXCEPTION(EXC_OFF_INS_STOR, InstStorage, UnknownException) - -/* External Interrupt exception. */ - STD_EXCEPTION(EXC_OFF_EXTERNAL, ExtInterrupt, external_interrupt) - -/* Alignment exception. */ - . = EXC_OFF_ALIGN -Alignment: - EXCEPTION_PROLOG(SRR0, SRR1) - mfspr r4,DAR - stw r4,_DAR(r21) - mfspr r5,DSISR - stw r5,_DSISR(r21) - addi r3,r1,STACK_FRAME_OVERHEAD - EXC_XFER_TEMPLATE(Alignment, AlignmentException, MSR_KERNEL, COPY_EE) - -/* Program check exception */ - . = EXC_OFF_PROGRAM -ProgramCheck: - EXCEPTION_PROLOG(SRR0, SRR1) - addi r3,r1,STACK_FRAME_OVERHEAD - EXC_XFER_TEMPLATE(ProgramCheck, ProgramCheckException, - MSR_KERNEL, COPY_EE) - - /* No FPU on MPC8xx. This exception is not supposed to happen. - */ - STD_EXCEPTION(EXC_OFF_FPUNAVAIL, FPUnavailable, UnknownException) - - /* I guess we could implement decrementer, and may have - * to someday for timekeeping. - */ - STD_EXCEPTION(EXC_OFF_DECR, Decrementer, timer_interrupt) - STD_EXCEPTION(0xa00, Trap_0a, UnknownException) - STD_EXCEPTION(0xb00, Trap_0b, UnknownException) - STD_EXCEPTION(0xc00, SystemCall, UnknownException) - - STD_EXCEPTION(EXC_OFF_TRACE, SingleStep, UnknownException) - - STD_EXCEPTION(EXC_OFF_FPUNASSIST, Trap_0e, UnknownException) - STD_EXCEPTION(EXC_OFF_PMI, Trap_0f, UnknownException) - - STD_EXCEPTION(EXC_OFF_ITME, InstructionTransMiss, UnknownException) - STD_EXCEPTION(EXC_OFF_DLTME, DataLoadTransMiss, UnknownException) - STD_EXCEPTION(EXC_OFF_DSTME, DataStoreTransMiss, UnknownException) - STD_EXCEPTION(EXC_OFF_IABE, InstructionBreakpoint, DebugException) - STD_EXCEPTION(EXC_OFF_SMIE, SysManageInt, UnknownException) - STD_EXCEPTION(0x1500, Reserved5, UnknownException) - STD_EXCEPTION(0x1600, Reserved6, UnknownException) - STD_EXCEPTION(0x1700, Reserved7, UnknownException) - STD_EXCEPTION(0x1800, Reserved8, UnknownException) - STD_EXCEPTION(0x1900, Reserved9, UnknownException) - STD_EXCEPTION(0x1a00, ReservedA, UnknownException) - STD_EXCEPTION(0x1b00, ReservedB, UnknownException) - STD_EXCEPTION(0x1c00, ReservedC, UnknownException) - STD_EXCEPTION(0x1d00, ReservedD, UnknownException) - STD_EXCEPTION(0x1e00, ReservedE, UnknownException) - STD_EXCEPTION(0x1f00, ReservedF, UnknownException) - - STD_EXCEPTION(EXC_OFF_RMTE, RunModeTrace, UnknownException) - - .globl _end_of_vectors -_end_of_vectors: - - - . = 0x3000 - -/* - * This code finishes saving the registers to the exception frame - * and jumps to the appropriate handler for the exception. - * Register r21 is pointer into trap frame, r1 has new stack pointer. - */ - .globl transfer_to_handler -transfer_to_handler: - stw r22,_NIP(r21) - lis r22,MSR_POW@h - andc r23,r23,r22 - stw r23,_MSR(r21) - SAVE_GPR(7, r21) - SAVE_4GPRS(8, r21) - SAVE_8GPRS(12, r21) - SAVE_8GPRS(24, r21) -#if 0 - andi. r23,r23,MSR_PR - mfspr r23,SPRG3 /* if from user, fix up tss.regs */ - beq 2f - addi r24,r1,STACK_FRAME_OVERHEAD - stw r24,PT_REGS(r23) -2: addi r2,r23,-TSS /* set r2 to current */ - tovirt(r2,r2,r23) -#endif - mflr r23 - andi. r24,r23,0x3f00 /* get vector offset */ - stw r24,TRAP(r21) - li r22,0 - stw r22,RESULT(r21) - mtspr SPRG2,r22 /* r1 is now kernel sp */ -#if 0 - addi r24,r2,TASK_STRUCT_SIZE /* check for kernel stack overflow */ - cmplw 0,r1,r2 - cmplw 1,r1,r24 - crand 1,1,4 - bgt stack_ovf /* if r2 < r1 < r2+TASK_STRUCT_SIZE */ -#endif - lwz r24,0(r23) /* virtual address of handler */ - lwz r23,4(r23) /* where to go when done */ - mtspr SRR0,r24 - ori r20,r20,0x30 /* enable IR, DR */ - mtspr SRR1,r20 - mtlr r23 - SYNC - rfi /* jump to handler, enable MMU */ - -int_return: - mfmsr r28 /* Disable interrupts */ - li r4,0 - ori r4,r4,MSR_EE - andc r28,r28,r4 - SYNC /* Some chip revs need this... */ - mtmsr r28 - SYNC - lwz r2,_CTR(r1) - lwz r0,_LINK(r1) - mtctr r2 - mtlr r0 - lwz r2,_XER(r1) - lwz r0,_CCR(r1) - mtspr XER,r2 - mtcrf 0xFF,r0 - REST_10GPRS(3, r1) - REST_10GPRS(13, r1) - REST_8GPRS(23, r1) - REST_GPR(31, r1) - lwz r2,_NIP(r1) /* Restore environment */ - lwz r0,_MSR(r1) - mtspr SRR0,r2 - mtspr SRR1,r0 - lwz r0,GPR0(r1) - lwz r2,GPR2(r1) - lwz r1,GPR1(r1) - SYNC - rfi - -/* Cache functions. -*/ - .globl icache_enable -icache_enable: - mfspr r5,HID0 /* turn on the I cache. */ - ori r5,r5,0x8800 /* Instruction cache only! */ - addis r6,0,0xFFFF - ori r6,r6,0xF7FF - and r6,r5,r6 /* clear the invalidate bit */ - sync - mtspr HID0,r5 - mtspr HID0,r6 - isync - sync - blr - - .globl icache_disable -icache_disable: - mfspr r5,HID0 - addis r6,0,0xFFFF - ori r6,r6,0x7FFF - and r5,r5,r6 - sync - mtspr HID0,r5 - isync - sync - blr - - .globl icache_status -icache_status: - mfspr r3, HID0 - srwi r3, r3, 15 /* >>15 & 1=> select bit 16 */ - andi. r3, r3, 1 - blr - - .globl dcache_enable -dcache_enable: - mfspr r5,HID0 /* turn on the D cache. */ - ori r5,r5,0x4400 /* Data cache only! */ - mfspr r4, PVR /* read PVR */ - srawi r3, r4, 16 /* shift off the least 16 bits */ - cmpi 0, 0, r3, 0xC /* Check for Max pvr */ - bne NotMax - ori r5,r5,0x0040 /* setting the DCFA bit, for Max rev 1 errata */ -NotMax: - addis r6,0,0xFFFF - ori r6,r6,0xFBFF - and r6,r5,r6 /* clear the invalidate bit */ - sync - mtspr HID0,r5 - mtspr HID0,r6 - isync - sync - blr - - .globl dcache_disable -dcache_disable: - mfspr r5,HID0 - addis r6,0,0xFFFF - ori r6,r6,0xBFFF - and r5,r5,r6 - sync - mtspr HID0,r5 - isync - sync - blr - - .globl dcache_status -dcache_status: - mfspr r3, HID0 - srwi r3, r3, 14 /* >>14 & 1=> select bit 17 */ - andi. r3, r3, 1 - blr - - .globl dc_read -dc_read: -/*TODO : who uses this, what should it do? -*/ - blr - - - .globl get_pvr -get_pvr: - mfspr r3, PVR - blr - - -/*------------------------------------------------------------------------------*/ - -/* - * void relocate_code (addr_sp, gd, addr_moni) - * - * This "function" does not return, instead it continues in RAM - * after relocating the monitor code. - * - * r3 = dest - * r4 = src - * r5 = length in bytes - * r6 = cachelinesize - */ - .globl relocate_code -relocate_code: - - mr r1, r3 /* Set new stack pointer */ - mr r9, r4 /* Save copy of Global Data pointer */ - mr r10, r5 /* Save copy of Destination Address */ - - GET_GOT - mr r3, r5 /* Destination Address */ -#ifdef CONFIG_SYS_RAMBOOT - lis r4, CONFIG_SYS_SDRAM_BASE@h /* Source Address */ - ori r4, r4, CONFIG_SYS_SDRAM_BASE@l -#else - lis r4, CONFIG_SYS_MONITOR_BASE@h /* Source Address */ - ori r4, r4, CONFIG_SYS_MONITOR_BASE@l -#endif - lwz r5, GOT(__init_end) - sub r5, r5, r4 - li r6, CONFIG_SYS_CACHELINE_SIZE /* Cache Line Size */ - - /* - * Fix GOT pointer: - * - * New GOT-PTR = (old GOT-PTR - CONFIG_SYS_MONITOR_BASE) + Destination Address - * - * Offset: - */ - sub r15, r10, r4 - - /* First our own GOT */ - add r12, r12, r15 - /* the the one used by the C code */ - add r30, r30, r15 - - /* - * Now relocate code - */ - - cmplw cr1,r3,r4 - addi r0,r5,3 - srwi. r0,r0,2 - beq cr1,4f /* In place copy is not necessary */ - beq 7f /* Protect against 0 count */ - mtctr r0 - bge cr1,2f - - la r8,-4(r4) - la r7,-4(r3) -1: lwzu r0,4(r8) - stwu r0,4(r7) - bdnz 1b - b 4f - -2: slwi r0,r0,2 - add r8,r4,r0 - add r7,r3,r0 -3: lwzu r0,-4(r8) - stwu r0,-4(r7) - bdnz 3b - -4: -/* Unlock the data cache and invalidate locked area */ - xor r0, r0, r0 - mtspr 1011, r0 - lis r4, CONFIG_SYS_INIT_RAM_ADDR@h - ori r4, r4, CONFIG_SYS_INIT_RAM_ADDR@l - li r0, 128 - mtctr r0 -41: - dcbi r0, r4 - addi r4, r4, 32 - bdnz 41b - -/* - * Now flush the cache: note that we must start from a cache aligned - * address. Otherwise we might miss one cache line. - */ - cmpwi r6,0 - add r5,r3,r5 - beq 7f /* Always flush prefetch queue in any case */ - subi r0,r6,1 - andc r3,r3,r0 - mr r4,r3 -5: dcbst 0,r4 - add r4,r4,r6 - cmplw r4,r5 - blt 5b - sync /* Wait for all dcbst to complete on bus */ - mr r4,r3 -6: icbi 0,r4 - add r4,r4,r6 - cmplw r4,r5 - blt 6b -7: sync /* Wait for all icbi to complete on bus */ - isync - -/* - * We are done. Do not return, instead branch to second part of board - * initialization, now running from RAM. - */ - - addi r0, r10, in_ram - _start + EXC_OFF_SYS_RESET - mtlr r0 - blr - -in_ram: - - /* - * Relocation Function, r12 point to got2+0x8000 - * - * Adjust got2 pointers, no need to check for 0, this code - * already puts a few entries in the table. - */ - li r0,__got2_entries@sectoff@l - la r3,GOT(_GOT2_TABLE_) - lwz r11,GOT(_GOT2_TABLE_) - mtctr r0 - sub r11,r3,r11 - addi r3,r3,-4 -1: lwzu r0,4(r3) - cmpwi r0,0 - beq- 2f - add r0,r0,r11 - stw r0,0(r3) -2: bdnz 1b - - /* - * Now adjust the fixups and the pointers to the fixups - * in case we need to move ourselves again. - */ - li r0,__fixup_entries@sectoff@l - lwz r3,GOT(_FIXUP_TABLE_) - cmpwi r0,0 - mtctr r0 - addi r3,r3,-4 - beq 4f -3: lwzu r4,4(r3) - lwzux r0,r4,r11 - cmpwi r0,0 - add r0,r0,r11 - stw r4,0(r3) - beq- 5f - stw r0,0(r4) -5: bdnz 3b -4: -clear_bss: - /* - * Now clear BSS segment - */ - lwz r3,GOT(__bss_start) - lwz r4,GOT(__bss_end) - - cmplw 0, r3, r4 - beq 6f - - li r0, 0 -5: - stw r0, 0(r3) - addi r3, r3, 4 - cmplw 0, r3, r4 - blt 5b -6: - - mr r3, r9 /* Global Data pointer */ - mr r4, r10 /* Destination Address */ - bl board_init_r - - /* - * Copy exception vector code to low memory - * - * r3: dest_addr - * r7: source address, r8: end address, r9: target address - */ - .globl trap_init -trap_init: - mflr r4 /* save link register */ - GET_GOT - lwz r7, GOT(_start) - lwz r8, GOT(_end_of_vectors) - - li r9, 0x100 /* reset vector always at 0x100 */ - - cmplw 0, r7, r8 - bgelr /* return if r7>=r8 - just in case */ -1: - lwz r0, 0(r7) - stw r0, 0(r9) - addi r7, r7, 4 - addi r9, r9, 4 - cmplw 0, r7, r8 - bne 1b - - /* - * relocate `hdlr' and `int_return' entries - */ - li r7, .L_MachineCheck - _start + EXC_OFF_SYS_RESET - li r8, Alignment - _start + EXC_OFF_SYS_RESET -2: - bl trap_reloc - addi r7, r7, 0x100 /* next exception vector */ - cmplw 0, r7, r8 - blt 2b - - li r7, .L_Alignment - _start + EXC_OFF_SYS_RESET - bl trap_reloc - - li r7, .L_ProgramCheck - _start + EXC_OFF_SYS_RESET - bl trap_reloc - - li r7, .L_FPUnavailable - _start + EXC_OFF_SYS_RESET - li r8, SystemCall - _start + EXC_OFF_SYS_RESET -3: - bl trap_reloc - addi r7, r7, 0x100 /* next exception vector */ - cmplw 0, r7, r8 - blt 3b - - li r7, .L_SingleStep - _start + EXC_OFF_SYS_RESET - li r8, _end_of_vectors - _start + EXC_OFF_SYS_RESET -4: - bl trap_reloc - addi r7, r7, 0x100 /* next exception vector */ - cmplw 0, r7, r8 - blt 4b - - mtlr r4 /* restore link register */ - blr - - /* Setup the BAT registers. - */ -setup_bats: - lis r4, CONFIG_SYS_IBAT0L@h - ori r4, r4, CONFIG_SYS_IBAT0L@l - lis r3, CONFIG_SYS_IBAT0U@h - ori r3, r3, CONFIG_SYS_IBAT0U@l - mtspr IBAT0L, r4 - mtspr IBAT0U, r3 - isync - - lis r4, CONFIG_SYS_DBAT0L@h - ori r4, r4, CONFIG_SYS_DBAT0L@l - lis r3, CONFIG_SYS_DBAT0U@h - ori r3, r3, CONFIG_SYS_DBAT0U@l - mtspr DBAT0L, r4 - mtspr DBAT0U, r3 - isync - - lis r4, CONFIG_SYS_IBAT1L@h - ori r4, r4, CONFIG_SYS_IBAT1L@l - lis r3, CONFIG_SYS_IBAT1U@h - ori r3, r3, CONFIG_SYS_IBAT1U@l - mtspr IBAT1L, r4 - mtspr IBAT1U, r3 - isync - - lis r4, CONFIG_SYS_DBAT1L@h - ori r4, r4, CONFIG_SYS_DBAT1L@l - lis r3, CONFIG_SYS_DBAT1U@h - ori r3, r3, CONFIG_SYS_DBAT1U@l - mtspr DBAT1L, r4 - mtspr DBAT1U, r3 - isync - - lis r4, CONFIG_SYS_IBAT2L@h - ori r4, r4, CONFIG_SYS_IBAT2L@l - lis r3, CONFIG_SYS_IBAT2U@h - ori r3, r3, CONFIG_SYS_IBAT2U@l - mtspr IBAT2L, r4 - mtspr IBAT2U, r3 - isync - - lis r4, CONFIG_SYS_DBAT2L@h - ori r4, r4, CONFIG_SYS_DBAT2L@l - lis r3, CONFIG_SYS_DBAT2U@h - ori r3, r3, CONFIG_SYS_DBAT2U@l - mtspr DBAT2L, r4 - mtspr DBAT2U, r3 - isync - - lis r4, CONFIG_SYS_IBAT3L@h - ori r4, r4, CONFIG_SYS_IBAT3L@l - lis r3, CONFIG_SYS_IBAT3U@h - ori r3, r3, CONFIG_SYS_IBAT3U@l - mtspr IBAT3L, r4 - mtspr IBAT3U, r3 - isync - - lis r4, CONFIG_SYS_DBAT3L@h - ori r4, r4, CONFIG_SYS_DBAT3L@l - lis r3, CONFIG_SYS_DBAT3U@h - ori r3, r3, CONFIG_SYS_DBAT3U@l - mtspr DBAT3L, r4 - mtspr DBAT3U, r3 - isync - - /* Invalidate TLBs. - * -> for (val = 0; val < 0x20000; val+=0x1000) - * -> tlbie(val); - */ - lis r3, 0 - lis r5, 2 - -1: - tlbie r3 - addi r3, r3, 0x1000 - cmp 0, 0, r3, r5 - blt 1b - - blr diff --git a/arch/powerpc/cpu/mpc824x/traps.c b/arch/powerpc/cpu/mpc824x/traps.c deleted file mode 100644 index 6abf41d..0000000 --- a/arch/powerpc/cpu/mpc824x/traps.c +++ /dev/null @@ -1,194 +0,0 @@ -/* - * linux/arch/powerpc/kernel/traps.c - * - * Copyright (C) 1995-1996 Gary Thomas (gdt@linuxppc.org) - * - * Modified by Cort Dougan (cort@cs.nmt.edu) - * and Paul Mackerras (paulus@cs.anu.edu.au) - * - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * This file handles the architecture-dependent parts of hardware exceptions - */ - -#include <common.h> -#include <asm/processor.h> - -/* Returns 0 if exception not found and fixup otherwise. */ -extern unsigned long search_exception_table(unsigned long); - -/* THIS NEEDS CHANGING to use the board info structure. -*/ -#define END_OF_MEM 0x00400000 - -/* - * Trap & Exception support - */ - -static void print_backtrace(unsigned long *sp) -{ - int cnt = 0; - unsigned long i; - - printf("Call backtrace: "); - while (sp) { - if ((uint)sp > END_OF_MEM) - break; - - i = sp[1]; - if (cnt++ % 7 == 0) - printf("\n"); - printf("%08lX ", i); - if (cnt > 32) break; - sp = (unsigned long *)*sp; - } - printf("\n"); -} - -void show_regs(struct pt_regs *regs) -{ - int i; - - printf("NIP: %08lX XER: %08lX LR: %08lX REGS: %p TRAP: %04lx DAR: %08lX\n", - regs->nip, regs->xer, regs->link, regs, regs->trap, regs->dar); - printf("MSR: %08lx EE: %01x PR: %01x FP: %01x ME: %01x IR/DR: %01x%01x\n", - regs->msr, regs->msr&MSR_EE ? 1 : 0, regs->msr&MSR_PR ? 1 : 0, - regs->msr & MSR_FP ? 1 : 0,regs->msr&MSR_ME ? 1 : 0, - regs->msr&MSR_IR ? 1 : 0, - regs->msr&MSR_DR ? 1 : 0); - - printf("\n"); - for (i = 0; i < 32; i++) { - if ((i % 8) == 0) - { - printf("GPR%02d: ", i); - } - - printf("%08lX ", regs->gpr[i]); - if ((i % 8) == 7) - { - printf("\n"); - } - } -} - - -static void _exception(int signr, struct pt_regs *regs) -{ - show_regs(regs); - print_backtrace((unsigned long *)regs->gpr[1]); - panic("Exception in kernel pc %lx signal %d",regs->nip,signr); -} - -void MachineCheckException(struct pt_regs *regs) -{ - unsigned long fixup; - - /* Probing PCI using config cycles cause this exception - * when a device is not present. Catch it and return to - * the PCI exception handler. - */ - if ((fixup = search_exception_table(regs->nip)) != 0) { - regs->nip = fixup; - return; - } - - printf("Machine check in kernel mode.\n"); - printf("Caused by (from msr): "); - printf("regs %p ",regs); - switch( regs->msr & 0x000F0000) { - case (0x80000000>>12): - printf("Machine check signal - probably due to mm fault\n" - "with mmu off\n"); - break; - case (0x80000000>>13): - printf("Transfer error ack signal\n"); - break; - case (0x80000000>>14): - printf("Data parity signal\n"); - break; - case (0x80000000>>15): - printf("Address parity signal\n"); - break; - default: - printf("Unknown values in msr\n"); - } - show_regs(regs); - print_backtrace((unsigned long *)regs->gpr[1]); - panic("machine check"); -} - -void AlignmentException(struct pt_regs *regs) -{ - show_regs(regs); - print_backtrace((unsigned long *)regs->gpr[1]); - panic("Alignment Exception"); -} - -void ProgramCheckException(struct pt_regs *regs) -{ - show_regs(regs); - print_backtrace((unsigned long *)regs->gpr[1]); - panic("Program Check Exception"); -} - -void SoftEmuException(struct pt_regs *regs) -{ - show_regs(regs); - print_backtrace((unsigned long *)regs->gpr[1]); - panic("Software Emulation Exception"); -} - - -void UnknownException(struct pt_regs *regs) -{ - printf("Bad trap at PC: %lx, SR: %lx, vector=%lx\n", - regs->nip, regs->msr, regs->trap); - _exception(0, regs); -} - -#if defined(CONFIG_CMD_BEDBUG) -extern void do_bedbug_breakpoint(struct pt_regs *); -#endif - -void DebugException(struct pt_regs *regs) -{ - - printf("Debugger trap at @ %lx\n", regs->nip ); - show_regs(regs); -#if defined(CONFIG_CMD_BEDBUG) - do_bedbug_breakpoint( regs ); -#endif -} - -/* Probe an address by reading. If not present, return -1, otherwise - * return 0. - */ -int addr_probe(uint *addr) -{ -#if 0 - int retval; - - __asm__ __volatile__( \ - "1: lwz %0,0(%1)\n" \ - " eieio\n" \ - " li %0,0\n" \ - "2:\n" \ - ".section .fixup,"ax"\n" \ - "3: li %0,-1\n" \ - " b 2b\n" \ - ".section __ex_table,"a"\n" \ - " .align 2\n" \ - " .long 1b,3b\n" \ - ".text" \ - : "=r" (retval) : "r"(addr)); - - return (retval); -#endif - return 0; -} diff --git a/arch/powerpc/cpu/mpc824x/u-boot.lds b/arch/powerpc/cpu/mpc824x/u-boot.lds deleted file mode 100644 index 04aba84..0000000 --- a/arch/powerpc/cpu/mpc824x/u-boot.lds +++ /dev/null @@ -1,76 +0,0 @@ -/* - * (C) Copyright 2001-2010 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -OUTPUT_ARCH(powerpc) -/* Do we need any of these for elf? - __DYNAMIC = 0; */ -SECTIONS -{ - /* Read-only sections, merged into text segment: */ - .text : - { - arch/powerpc/cpu/mpc824x/start.o (.text*) - *(.text*) - . = ALIGN(16); - *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) - } - - /* Read-write section, merged into data segment: */ - . = (. + 0x0FFF) & 0xFFFFF000; - _erotext = .; - PROVIDE (erotext = .); - .reloc : - { - _GOT2_TABLE_ = .; - KEEP(*(.got2)) - KEEP(*(.got)) - PROVIDE(_GLOBAL_OFFSET_TABLE_ = . + 4); - _FIXUP_TABLE_ = .; - KEEP(*(.fixup)) - } - __got2_entries = ((_GLOBAL_OFFSET_TABLE_ - _GOT2_TABLE_) >> 2) - 1; - __fixup_entries = (. - _FIXUP_TABLE_) >> 2; - - .data : - { - *(.data*) - *(.sdata*) - } - _edata = .; - PROVIDE (edata = .); - - . = .; - - . = ALIGN(4); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); - } - - - . = .; - __start___ex_table = .; - __ex_table : { *(__ex_table) } - __stop___ex_table = .; - - . = ALIGN(4096); - __init_begin = .; - .text.init : { *(.text.init) } - .data.init : { *(.data.init) } - . = ALIGN(4096); - __init_end = .; - - __bss_start = .; - .bss (NOLOAD) : - { - *(.bss*) - *(.sbss*) - *(COMMON) - . = ALIGN(4); - } - __bss_end = . ; - PROVIDE (end = .); -} diff --git a/arch/powerpc/include/asm/processor.h b/arch/powerpc/include/asm/processor.h index 2ed51b1..db8cc8c 100644 --- a/arch/powerpc/include/asm/processor.h +++ b/arch/powerpc/include/asm/processor.h @@ -1360,8 +1360,6 @@ void _nmask_and_or_msr(unsigned long nmask, unsigned long or_val); #elif defined(CONFIG_MPC8260) #define _machine _MACH_8260 #define have_of 0 -#elif defined(CONFIG_SANDPOINT) -#define _machine _MACH_sandpoint #else #error "Machine not defined correctly" #endif diff --git a/board/a3000/Kconfig b/board/a3000/Kconfig deleted file mode 100644 index 21a9e48..0000000 --- a/board/a3000/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_A3000 - -config SYS_BOARD - default "a3000" - -config SYS_CONFIG_NAME - default "A3000" - -endif diff --git a/board/a3000/MAINTAINERS b/board/a3000/MAINTAINERS deleted file mode 100644 index 303e5fd..0000000 --- a/board/a3000/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -A3000 BOARD -#M: - -S: Maintained -F: board/a3000/ -F: include/configs/A3000.h -F: configs/A3000_defconfig diff --git a/board/a3000/Makefile b/board/a3000/Makefile deleted file mode 100644 index 9b9b048..0000000 --- a/board/a3000/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2001-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = a3000.o flash.o diff --git a/board/a3000/README b/board/a3000/README deleted file mode 100644 index f0e92c5..0000000 --- a/board/a3000/README +++ /dev/null @@ -1,17 +0,0 @@ -U-Boot for Artis SBC-A3000 ---------------------------- - -Artis SBC-A3000 has one flash socket that the user uses Intel 28F128J3A (16MB) -or 28F064J3A (8MB) chips. - -In board's notation, bank 0 is the one at the address of 0xFF000000. -bank 1 is the one at the address of 0xFF800000 - -On power-up the processor jumps to the address of 0xFFF00100, the last -megabyte of the bank 0 of flash. - -Thus, U-Boot is configured to reside in flash starting at the address of -0xFFF00000. The environment space is located in flash separately from -U-Boot, at the address of 0xFFFE0000. - -There is a National ns83815 10/100M ethernet controller on-board. diff --git a/board/a3000/a3000.c b/board/a3000/a3000.c deleted file mode 100644 index 3e2f6b0..0000000 --- a/board/a3000/a3000.c +++ /dev/null @@ -1,101 +0,0 @@ -/* - * (C) Copyright 2001 - * Rob Taylor, Flying Pig Systems. robt@flyingpig.com. - * - * Modified during 2003 by - * Ken Chou, kchou@ieee.org - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc824x.h> -#include <pci.h> -#include <netdev.h> - -int checkboard (void) -{ - ulong busfreq = get_bus_freq(0); - char buf[32]; - - printf("Board: A3000 Local Bus at %s MHz\n", strmhz(buf, busfreq)); - return 0; - -} - -phys_size_t initdram (int board_type) -{ - long size; - long new_bank0_end; - long mear1; - long emear1; - - size = get_ram_size(CONFIG_SYS_SDRAM_BASE, CONFIG_SYS_MAX_RAM_SIZE); - - new_bank0_end = size - 1; - mear1 = mpc824x_mpc107_getreg(MEAR1); - emear1 = mpc824x_mpc107_getreg(EMEAR1); - mear1 = (mear1 & 0xFFFFFF00) | - ((new_bank0_end & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT); - emear1 = (emear1 & 0xFFFFFF00) | - ((new_bank0_end & MICR_ADDR_MASK) >> MICR_EADDR_SHIFT); - mpc824x_mpc107_setreg(MEAR1, mear1); - mpc824x_mpc107_setreg(EMEAR1, emear1); - - return (size); -} - -/* - * Initialize PCI Devices - */ -#ifndef CONFIG_PCI_PNP -static struct pci_config_table pci_a3000_config_table[] = { - /* vendor, device, class */ - /* bus, dev, func */ - { PCI_VENDOR_ID_NS, PCI_DEVICE_ID_NS_83815, PCI_ANY_ID, - PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, /* dp83815 eth0 divice */ - pci_cfgfunc_config_device, { PCI_ENET0_IOADDR, - PCI_ENET0_MEMADDR, - PCI_COMMAND_IO | - PCI_COMMAND_MEMORY | - PCI_COMMAND_MASTER }}, - { PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, - PCI_ANY_ID, 0x14, PCI_ANY_ID, /* PCI slot1 */ - pci_cfgfunc_config_device, { PCI_ENET1_IOADDR, - PCI_ENET1_MEMADDR, - PCI_COMMAND_IO | - PCI_COMMAND_MEMORY | - PCI_COMMAND_MASTER }}, - { PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, - PCI_ANY_ID, 0x15, PCI_ANY_ID, /* PCI slot2 */ - pci_cfgfunc_config_device, { PCI_ENET2_IOADDR, - PCI_ENET2_MEMADDR, - PCI_COMMAND_IO | - PCI_COMMAND_MEMORY | - PCI_COMMAND_MASTER }}, - { PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, - PCI_ANY_ID, 0x16, PCI_ANY_ID, /* PCI slot3 */ - pci_cfgfunc_config_device, { PCI_ENET3_IOADDR, - PCI_ENET3_MEMADDR, - PCI_COMMAND_IO | - PCI_COMMAND_MEMORY | - PCI_COMMAND_MASTER }}, - { } -}; -#endif - -struct pci_controller hose = { -#ifndef CONFIG_PCI_PNP - config_table: pci_a3000_config_table, -#endif -}; - -void pci_init_board(void) -{ - pci_mpc824x_init(&hose); -} - -int board_eth_init(bd_t *bis) -{ - return pci_eth_init(bis); -} diff --git a/board/a3000/flash.c b/board/a3000/flash.c deleted file mode 100644 index f2dd3c2..0000000 --- a/board/a3000/flash.c +++ /dev/null @@ -1,438 +0,0 @@ -/* - * (C) Copyright 2001 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - - -#include <common.h> -#include <mpc824x.h> - -#if defined(CONFIG_ENV_IS_IN_FLASH) -# ifndef CONFIG_ENV_ADDR -# define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET) -# endif -# ifndef CONFIG_ENV_SIZE -# define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -# endif -# ifndef CONFIG_ENV_SECT_SIZE -# define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE -# endif -#endif - - -/*---------------------------------------------------------------------*/ -#define DEBUG_FLASH - -#ifdef DEBUG_FLASH -#define DEBUGF(fmt,args...) printf(fmt ,##args) -#else -#define DEBUGF(fmt,args...) -#endif -/*---------------------------------------------------------------------*/ - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH chips */ - -/*----------------------------------------------------------------------- - * Functions - */ -static ulong flash_get_size (vu_char *addr, flash_info_t *info); -static int write_data (flash_info_t *info, uchar *dest, uchar data); -static void flash_get_offsets (ulong base, flash_info_t *info); - -#define BS(b) (b) -#define BYTEME(x) ((x) & 0xFF) - -/*----------------------------------------------------------------------- - */ - -unsigned long flash_init (void) -{ - unsigned long flash_banks[CONFIG_SYS_MAX_FLASH_BANKS] = CONFIG_SYS_FLASH_BANKS; - unsigned long size, size_b[CONFIG_SYS_MAX_FLASH_BANKS]; - - int i; - - /* Init: no FLASHes known */ - for (i=0; i<CONFIG_SYS_MAX_FLASH_BANKS; ++i) - { - flash_info[i].flash_id = FLASH_UNKNOWN; - - DEBUGF("Get flash bank %d @ 0x%08lx\n", i, flash_banks[i]); -/* - size_b[i] = flash_get_size((vu_char *)flash_banks[i], &flash_info[i]); -*/ - size_b[i] = flash_get_size((vu_char *) 0xff800000 , &flash_info[i]); - - if (flash_info[i].flash_id == FLASH_UNKNOWN) - { - printf ("## Unknown FLASH on Bank %d: " - "ID 0x%lx, Size = 0x%08lx = %ld MB\n", - i, flash_info[i].flash_id, - size_b[i], size_b[i]<<20); - } - else - { - DEBUGF("## Flash bank %d at 0x%08lx sizes: 0x%08lx \n", - i, flash_banks[i], size_b[i]); - - flash_get_offsets (flash_banks[i], &flash_info[i]); - flash_info[i].size = size_b[i]; - } - } - - -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE - DEBUGF("protect monitor %x @ %x\n", CONFIG_SYS_MONITOR_BASE, CONFIG_SYS_MONITOR_LEN); - /* monitor protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE+CONFIG_SYS_MONITOR_LEN-1, - &flash_info[0]); -#endif - -#ifdef CONFIG_ENV_IS_IN_FLASH - /* ENV protection ON by default */ - DEBUGF("protect environtment %x @ %x\n", CONFIG_ENV_ADDR, CONFIG_ENV_SECT_SIZE); - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR+CONFIG_ENV_SECT_SIZE-1, - &flash_info[0]); -#endif - - size = 0; - DEBUGF("## Final Flash bank sizes: "); - for (i=0; i<CONFIG_SYS_MAX_FLASH_BANKS; ++i) - { - DEBUGF("%08lx ", size_b[i]); - size += size_b[i]; - } - DEBUGF("\n"); - return (size); -} - -/*----------------------------------------------------------------------- - */ -static void flash_get_offsets (ulong base, flash_info_t *info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_INTEL: - for (i = 0; i < info->sector_count; i++) { - info->start[i] = base; - base += 0x00020000; /* 128k per bank */ - } - return; - - default: - printf ("Don't know sector ofsets for flash type 0x%lx\n", info->flash_id); - return; - } -} - -/*----------------------------------------------------------------------- - */ -void flash_print_info (flash_info_t *info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_AMD: printf ("AMD "); break; - case FLASH_MAN_FUJ: printf ("Fujitsu "); break; - case FLASH_MAN_SST: printf ("SST "); break; - case FLASH_MAN_STM: printf ("STM "); break; - case FLASH_MAN_INTEL: printf ("Intel "); break; - case FLASH_MAN_MT: printf ("MT "); break; - default: printf ("Unknown Vendor "); break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_28F320J3A: - printf ("28F320J3A (32Mbit = 128K x 32)\n"); - break; - case FLASH_28F640J3A: - printf ("28F640J3A (64Mbit = 128K x 64)\n"); - break; - case FLASH_28F128J3A: - printf ("28F128J3A (128Mbit = 128K x 128)\n"); - break; - default: - printf ("Unknown Chip Type\n"); - break; - } - -#if 1 - if (info->size >= (1 << 20)) { - i = 20; - } else { - i = 10; - } - printf (" Size: %ld %cB in %d Sectors\n", - info->size >> i, - (i == 20) ? 'M' : 'k', - info->sector_count); - - printf (" Sector Start Addresses:"); - for (i=0; i<info->sector_count; ++i) { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", - info->start[i], - info->protect[i] ? " (RO)" : " " - ); - } - printf ("\n"); -#endif - return; -} - -/*----------------------------------------------------------------------- - */ - - -/*----------------------------------------------------------------------- - */ - -/* - * The following code cannot be run from FLASH! - */ -static ulong flash_get_size (vu_char *addr, flash_info_t *info) -{ - vu_char manuf, device; - - addr[0] = BS(0x90); - manuf = BS(addr[0]); - DEBUGF("Manuf. ID @ 0x%08lx: 0x%08x\n", (ulong)addr, manuf); - - switch (manuf) { - case BYTEME(AMD_MANUFACT): - info->flash_id = FLASH_MAN_AMD; - break; - case BYTEME(FUJ_MANUFACT): - info->flash_id = FLASH_MAN_FUJ; - break; - case BYTEME(SST_MANUFACT): - info->flash_id = FLASH_MAN_SST; - break; - case BYTEME(STM_MANUFACT): - info->flash_id = FLASH_MAN_STM; - break; - case BYTEME(INTEL_MANUFACT): - info->flash_id = FLASH_MAN_INTEL; - break; - default: - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - addr[0] = BS(0xFF); /* restore read mode, (yes, BS is a NOP) */ - return 0; /* no or unknown flash */ - } - - device = BS(addr[2]); /* device ID */ - - DEBUGF("Device ID @ 0x%08lx: 0x%08x\n", (ulong)(&addr[1]), device); - - switch (device) { - case BYTEME(INTEL_ID_28F320J3A): - info->flash_id += FLASH_28F320J3A; - info->sector_count = 32; - info->size = 0x00400000; - break; /* => 4 MB */ - - case BYTEME(INTEL_ID_28F640J3A): - info->flash_id += FLASH_28F640J3A; - info->sector_count = 64; - info->size = 0x00800000; - break; /* => 8 MB */ - - case BYTEME(INTEL_ID_28F128J3A): - info->flash_id += FLASH_28F128J3A; - info->sector_count = 128; - info->size = 0x01000000; - break; /* => 16 MB */ - - default: - info->flash_id = FLASH_UNKNOWN; - addr[0] = BS(0xFF); /* restore read mode (yes, a NOP) */ - return 0; /* => no or unknown flash */ - - } - - if (info->sector_count > CONFIG_SYS_MAX_FLASH_SECT) { - printf ("** ERROR: sector count %d > max (%d) **\n", - info->sector_count, CONFIG_SYS_MAX_FLASH_SECT); - info->sector_count = CONFIG_SYS_MAX_FLASH_SECT; - } - - addr[0] = BS(0xFF); /* restore read mode */ - - return (info->size); -} - - -/*----------------------------------------------------------------------- - */ - -int flash_erase (flash_info_t *info, int s_first, int s_last) -{ - int flag, prot, sect; - ulong start, now, last; - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - if ((info->flash_id & FLASH_VENDMASK) != FLASH_MAN_INTEL) { - printf ("Can erase only Intel flash types - aborted\n"); - return 1; - } - - prot = 0; - for (sect=s_first; sect<=s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", prot); - } else { - printf ("\n"); - } - - start = get_timer (0); - last = start; - /* Start erase on unprotected sectors */ - for (sect = s_first; sect<=s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - vu_char *addr = (vu_char *)(info->start[sect]); - unsigned long status; - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - *addr = BS(0x50); /* clear status register */ - *addr = BS(0x20); /* erase setup */ - *addr = BS(0xD0); /* erase confirm */ - - /* re-enable interrupts if necessary */ - if (flag) { - enable_interrupts(); - } - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - - while (((status = BS(*addr)) & BYTEME(0x00800080)) != BYTEME(0x00800080)) { - if ((now=get_timer(start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - *addr = BS(0xB0); /* suspend erase */ - *addr = BS(0xFF); /* reset to read mode */ - return 1; - } - - /* show that we're waiting */ - if ((now - last) > 1000) { /* every second */ - putc ('.'); - last = now; - } - } - - *addr = BS(0xFF); /* reset to read mode */ - } - } - printf (" done\n"); - return 0; -} - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - * 4 - Flash not identified - */ - -#define FLASH_WIDTH 1 /* flash bus width in bytes */ - -int write_buff (flash_info_t *info, uchar *src, ulong addr, ulong cnt) -{ - uchar *wp = (uchar *)addr; - int rc; - - if (info->flash_id == FLASH_UNKNOWN) { - return 4; - } - - while (cnt > 0) { - if ((rc = write_data(info, wp, *src)) != 0) { - return rc; - } - wp++; - src++; - cnt--; - } - - return cnt; -} - -/*----------------------------------------------------------------------- - * Write a word to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_data (flash_info_t *info, uchar *dest, uchar data) -{ - vu_char *addr = (vu_char *)dest; - ulong status; - ulong start; - int flag; - - /* Check if Flash is (sufficiently) erased */ - if ((BS(*addr) & data) != data) { - return 2; - } - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - *addr = BS(0x40); /* write setup */ - *addr = data; - - /* re-enable interrupts if necessary */ - if (flag) { - enable_interrupts(); - } - - start = get_timer (0); - - while (((status = BS(*addr)) & BYTEME(0x00800080)) != BYTEME(0x00800080)) { - if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - *addr = BS(0xFF); /* restore read mode */ - return 1; - } - } - - *addr = BS(0xFF); /* restore read mode */ - - return 0; -} - -/*----------------------------------------------------------------------- - */ diff --git a/board/cpc45/Kconfig b/board/cpc45/Kconfig deleted file mode 100644 index c564caf..0000000 --- a/board/cpc45/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_CPC45 - -config SYS_BOARD - default "cpc45" - -config SYS_CONFIG_NAME - default "CPC45" - -endif diff --git a/board/cpc45/MAINTAINERS b/board/cpc45/MAINTAINERS deleted file mode 100644 index 163e09c..0000000 --- a/board/cpc45/MAINTAINERS +++ /dev/null @@ -1,7 +0,0 @@ -CPC45 BOARD -M: Josef Wagner Wagner@Microsys.de -S: Maintained -F: board/cpc45/ -F: include/configs/CPC45.h -F: configs/CPC45_defconfig -F: configs/CPC45_ROMBOOT_defconfig diff --git a/board/cpc45/Makefile b/board/cpc45/Makefile deleted file mode 100644 index 1310f93..0000000 --- a/board/cpc45/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2001-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = cpc45.o flash.o plx9030.o pd67290.o ide.o diff --git a/board/cpc45/cpc45.c b/board/cpc45/cpc45.c deleted file mode 100644 index f182e79..0000000 --- a/board/cpc45/cpc45.c +++ /dev/null @@ -1,250 +0,0 @@ -/* - * (C) Copyright 2001 - * Rob Taylor, Flying Pig Systems. robt@flyingpig.com. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc824x.h> -#include <asm/processor.h> -#include <asm/io.h> -#include <pci.h> -#include <i2c.h> -#include <netdev.h> - -int sysControlDisplay(int digit, uchar ascii_code); -extern void Plx9030Init(void); -extern void SPD67290Init(void); - - /* We have to clear the initial data area here. Couldn't have done it - * earlier because DRAM had not been initialized. - */ -int board_early_init_f(void) -{ - - /* enable DUAL UART Mode on CPC45 */ - *(uchar*)DUART_DCR |= 0x1; /* set DCM bit */ - - return 0; -} - -int checkboard(void) -{ -/* - char revision = BOARD_REV; -*/ - ulong busfreq = get_bus_freq(0); - char buf[32]; - - puts ("CPC45 "); -/* - printf("Revision %d ", revision); -*/ - printf("Local Bus at %s MHz\n", strmhz(buf, busfreq)); - - return 0; -} - -phys_size_t initdram (int board_type) -{ - int m, row, col, bank, i, ref; - unsigned long start, end; - uint32_t mccr1, mccr2; - uint32_t mear1 = 0, emear1 = 0, msar1 = 0, emsar1 = 0; - uint32_t mear2 = 0, emear2 = 0, msar2 = 0, emsar2 = 0; - uint8_t mber = 0; - unsigned int tmp; - - i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); - - if (i2c_reg_read (0x50, 2) != 0x04) - return 0; /* Memory type */ - - m = i2c_reg_read (0x50, 5); /* # of physical banks */ - row = i2c_reg_read (0x50, 3); /* # of rows */ - col = i2c_reg_read (0x50, 4); /* # of columns */ - bank = i2c_reg_read (0x50, 17); /* # of logical banks */ - ref = i2c_reg_read (0x50, 12); /* refresh rate / type */ - - CONFIG_READ_WORD(MCCR1, mccr1); - mccr1 &= 0xffff0000; - - CONFIG_READ_WORD(MCCR2, mccr2); - mccr2 &= 0xffff0000; - - start = CONFIG_SYS_SDRAM_BASE; - end = start + (1 << (col + row + 3) ) * bank - 1; - - for (i = 0; i < m; i++) { - mccr1 |= ((row == 13)? 2 : (bank == 4)? 0 : 3) << i * 2; - if (i < 4) { - msar1 |= ((start >> 20) & 0xff) << i * 8; - emsar1 |= ((start >> 28) & 0xff) << i * 8; - mear1 |= ((end >> 20) & 0xff) << i * 8; - emear1 |= ((end >> 28) & 0xff) << i * 8; - } else { - msar2 |= ((start >> 20) & 0xff) << (i-4) * 8; - emsar2 |= ((start >> 28) & 0xff) << (i-4) * 8; - mear2 |= ((end >> 20) & 0xff) << (i-4) * 8; - emear2 |= ((end >> 28) & 0xff) << (i-4) * 8; - } - mber |= 1 << i; - start += (1 << (col + row + 3) ) * bank; - end += (1 << (col + row + 3) ) * bank; - } - for (; i < 8; i++) { - if (i < 4) { - msar1 |= 0xff << i * 8; - emsar1 |= 0x30 << i * 8; - mear1 |= 0xff << i * 8; - emear1 |= 0x30 << i * 8; - } else { - msar2 |= 0xff << (i-4) * 8; - emsar2 |= 0x30 << (i-4) * 8; - mear2 |= 0xff << (i-4) * 8; - emear2 |= 0x30 << (i-4) * 8; - } - } - - switch(ref) { - case 0x00: - case 0x80: - tmp = get_bus_freq(0) / 1000000 * 15625 / 1000 - 22; - break; - case 0x01: - case 0x81: - tmp = get_bus_freq(0) / 1000000 * 3900 / 1000 - 22; - break; - case 0x02: - case 0x82: - tmp = get_bus_freq(0) / 1000000 * 7800 / 1000 - 22; - break; - case 0x03: - case 0x83: - tmp = get_bus_freq(0) / 1000000 * 31300 / 1000 - 22; - break; - case 0x04: - case 0x84: - tmp = get_bus_freq(0) / 1000000 * 62500 / 1000 - 22; - break; - case 0x05: - case 0x85: - tmp = get_bus_freq(0) / 1000000 * 125000 / 1000 - 22; - break; - default: - tmp = 0x512; - break; - } - - CONFIG_WRITE_WORD(MCCR1, mccr1); - CONFIG_WRITE_WORD(MCCR2, tmp << MCCR2_REFINT_SHIFT); - CONFIG_WRITE_WORD(MSAR1, msar1); - CONFIG_WRITE_WORD(EMSAR1, emsar1); - CONFIG_WRITE_WORD(MEAR1, mear1); - CONFIG_WRITE_WORD(EMEAR1, emear1); - CONFIG_WRITE_WORD(MSAR2, msar2); - CONFIG_WRITE_WORD(EMSAR2, emsar2); - CONFIG_WRITE_WORD(MEAR2, mear2); - CONFIG_WRITE_WORD(EMEAR2, emear2); - CONFIG_WRITE_BYTE(MBER, mber); - - return (1 << (col + row + 3) ) * bank * m; -} - - -/* - * Initialize PCI Devices, report devices found. - */ - -static struct pci_config_table pci_cpc45_config_table[] = { -#ifndef CONFIG_PCI_PNP - { PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, 0x0F, PCI_ANY_ID, - pci_cfgfunc_config_device, { PCI_ENET0_IOADDR, - PCI_ENET0_MEMADDR, - PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER }}, - { PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, 0x0D, PCI_ANY_ID, - pci_cfgfunc_config_device, { PCI_PLX9030_IOADDR, - PCI_PLX9030_MEMADDR, - PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER }}, - { PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, 0x0E, PCI_ANY_ID, - pci_cfgfunc_config_device, { PCMCIA_IO_BASE, - PCMCIA_IO_BASE, - PCI_COMMAND_MEMORY | PCI_COMMAND_IO }}, -#endif /*CONFIG_PCI_PNP*/ - { } -}; - -struct pci_controller hose = { -#ifndef CONFIG_PCI_PNP - config_table: pci_cpc45_config_table, -#endif -}; - -void pci_init_board(void) -{ - pci_mpc824x_init(&hose); - - /* init PCI_to_LOCAL Bus BRIDGE */ - Plx9030Init(); - - /* Clear Display */ - DISP_CWORD = 0x0; - - sysControlDisplay(0,' '); - sysControlDisplay(1,'C'); - sysControlDisplay(2,'P'); - sysControlDisplay(3,'C'); - sysControlDisplay(4,' '); - sysControlDisplay(5,'4'); - sysControlDisplay(6,'5'); - sysControlDisplay(7,' '); - -} - -/************************************************************************** -* -* sysControlDisplay - controls one of the Alphanum. Display digits. -* -* This routine will write an ASCII character to the display digit requested. -* -* SEE ALSO: -* -* RETURNS: NA -*/ - -int sysControlDisplay (int digit, /* number of digit 0..7 */ - uchar ascii_code /* ASCII code */ - ) -{ - if ((digit < 0) || (digit > 7)) - return (-1); - - *((volatile uchar *) (DISP_CHR_RAM + digit)) = ascii_code; - - return (0); -} - -#if defined(CONFIG_CMD_PCMCIA) - -#ifdef CONFIG_SYS_PCMCIA_MEM_ADDR -volatile unsigned char *pcmcia_mem = (unsigned char*)CONFIG_SYS_PCMCIA_MEM_ADDR; -#endif - -int pcmcia_init(void) -{ - u_int rc; - - debug ("Enable PCMCIA " PCMCIA_SLOT_MSG "\n"); - - rc = i82365_init(); - - return rc; -} - -#endif - -int board_eth_init(bd_t *bis) -{ - return pci_eth_init(bis); -} diff --git a/board/cpc45/flash.c b/board/cpc45/flash.c deleted file mode 100644 index 917db34..0000000 --- a/board/cpc45/flash.c +++ /dev/null @@ -1,506 +0,0 @@ -/* - * (C) Copyright 2001-2003 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc824x.h> -#include <asm/processor.h> - -#if defined(CONFIG_ENV_IS_IN_FLASH) -# ifndef CONFIG_ENV_ADDR -# define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET) -# endif -# ifndef CONFIG_ENV_SIZE -# define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -# endif -# ifndef CONFIG_ENV_SECT_SIZE -# define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE -# endif -#endif - -#define FLASH_BANK_SIZE 0x800000 -#define MAIN_SECT_SIZE 0x40000 -#define PARAM_SECT_SIZE 0x8000 - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; - -static int write_data (flash_info_t * info, ulong dest, ulong * data); -static void write_via_fpu (vu_long * addr, ulong * data); -static __inline__ unsigned long get_msr (void); -static __inline__ void set_msr (unsigned long msr); - -/*---------------------------------------------------------------------*/ -#undef DEBUG_FLASH - -/*---------------------------------------------------------------------*/ -#ifdef DEBUG_FLASH -#define DEBUGF(fmt,args...) printf(fmt ,##args) -#else -#define DEBUGF(fmt,args...) -#endif -/*---------------------------------------------------------------------*/ - -/*----------------------------------------------------------------------- - */ - -unsigned long flash_init (void) -{ - int i, j; - ulong size = 0; - uchar tempChar; - vu_long *tmpaddr; - - /* Enable flash writes on CPC45 */ - - tempChar = BOARD_CTRL; - - tempChar |= (B_CTRL_FWPT_1 | B_CTRL_FWRE_1); - - tempChar &= ~(B_CTRL_FWPT_0 | B_CTRL_FWRE_0); - - BOARD_CTRL = tempChar; - - __asm__ volatile ("sync\n eieio"); - - for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; i++) { - vu_long *addr = (vu_long *) (CONFIG_SYS_FLASH_BASE + i * FLASH_BANK_SIZE); - - addr[0] = 0x00900090; - - __asm__ volatile ("sync\n eieio"); - - udelay (100); - - DEBUGF ("Flash bank # %d:\n" - "\tManuf. ID @ 0x%08lX: 0x%08lX\n" - "\tDevice ID @ 0x%08lX: 0x%08lX\n", - i, - (ulong) (&addr[0]), addr[0], - (ulong) (&addr[2]), addr[2]); - - - if ((addr[0] == addr[1]) && (addr[0] == INTEL_MANUFACT) && - (addr[2] == addr[3]) && (addr[2] == INTEL_ID_28F160F3T)) { - - flash_info[i].flash_id = - (FLASH_MAN_INTEL & FLASH_VENDMASK) | - (INTEL_ID_28F160F3T & FLASH_TYPEMASK); - - } else if ((addr[0] == addr[1]) && (addr[0] == INTEL_MANUFACT) - && (addr[2] == addr[3]) - && (addr[2] == INTEL_ID_28F160C3T)) { - - flash_info[i].flash_id = - (FLASH_MAN_INTEL & FLASH_VENDMASK) | - (INTEL_ID_28F160C3T & FLASH_TYPEMASK); - - } else { - flash_info[i].flash_id = FLASH_UNKNOWN; - addr[0] = 0xFFFFFFFF; - goto Done; - } - - DEBUGF ("flash_id = 0x%08lX\n", flash_info[i].flash_id); - - addr[0] = 0xFFFFFFFF; - - flash_info[i].size = FLASH_BANK_SIZE; - flash_info[i].sector_count = CONFIG_SYS_MAX_FLASH_SECT; - memset (flash_info[i].protect, 0, CONFIG_SYS_MAX_FLASH_SECT); - for (j = 0; j < flash_info[i].sector_count; j++) { - if (j > 30) { - flash_info[i].start[j] = CONFIG_SYS_FLASH_BASE + - i * FLASH_BANK_SIZE + - (MAIN_SECT_SIZE * 31) + (j - - 31) * - PARAM_SECT_SIZE; - } else { - flash_info[i].start[j] = CONFIG_SYS_FLASH_BASE + - i * FLASH_BANK_SIZE + - j * MAIN_SECT_SIZE; - } - } - - /* unlock sectors, if 160C3T */ - - for (j = 0; j < flash_info[i].sector_count; j++) { - tmpaddr = (vu_long *) flash_info[i].start[j]; - - if ((flash_info[i].flash_id & FLASH_TYPEMASK) == - (INTEL_ID_28F160C3T & FLASH_TYPEMASK)) { - tmpaddr[0] = 0x00600060; - tmpaddr[0] = 0x00D000D0; - tmpaddr[1] = 0x00600060; - tmpaddr[1] = 0x00D000D0; - } - } - - size += flash_info[i].size; - - addr[0] = 0x00FF00FF; - addr[1] = 0x00FF00FF; - } - - /* Protect monitor and environment sectors - */ -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE + FLASH_BANK_SIZE - flash_protect (FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE + monitor_flash_len - 1, - &flash_info[1]); -#else - flash_protect (FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE + monitor_flash_len - 1, - &flash_info[0]); -#endif - -#if defined(CONFIG_ENV_IS_IN_FLASH) && defined(CONFIG_ENV_ADDR) -#if CONFIG_ENV_ADDR >= CONFIG_SYS_FLASH_BASE + FLASH_BANK_SIZE - flash_protect (FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR + CONFIG_ENV_SIZE - 1, &flash_info[1]); -#else - flash_protect (FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR + CONFIG_ENV_SIZE - 1, &flash_info[0]); -#endif -#endif - -Done: - return size; -} - -/*----------------------------------------------------------------------- - */ -void flash_print_info (flash_info_t * info) -{ - int i; - - switch ((i = info->flash_id & FLASH_VENDMASK)) { - case (FLASH_MAN_INTEL & FLASH_VENDMASK): - printf ("Intel: "); - break; - default: - printf ("Unknown Vendor 0x%04x ", i); - break; - } - - switch ((i = info->flash_id & FLASH_TYPEMASK)) { - case (INTEL_ID_28F160F3T & FLASH_TYPEMASK): - printf ("28F160F3T (16Mbit)\n"); - break; - - case (INTEL_ID_28F160C3T & FLASH_TYPEMASK): - printf ("28F160C3T (16Mbit)\n"); - break; - - default: - printf ("Unknown Chip Type 0x%04x\n", i); - goto Done; - break; - } - - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); - - printf (" Sector Start Addresses:"); - for (i = 0; i < info->sector_count; i++) { - if ((i % 5) == 0) { - printf ("\n "); - } - printf (" %08lX%s", info->start[i], - info->protect[i] ? " (RO)" : " "); - } - printf ("\n"); - -Done: - return; -} - -/*----------------------------------------------------------------------- - */ - -int flash_erase (flash_info_t * info, int s_first, int s_last) -{ - int flag, prot, sect; - ulong start, now, last; - - DEBUGF ("Erase flash bank %d sect %d ... %d\n", - info - &flash_info[0], s_first, s_last); - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - if ((info->flash_id & FLASH_VENDMASK) != - (FLASH_MAN_INTEL & FLASH_VENDMASK)) { - printf ("Can erase only Intel flash types - aborted\n"); - return 1; - } - - prot = 0; - for (sect = s_first; sect <= s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", prot); - } else { - printf ("\n"); - } - - start = get_timer (0); - last = start; - /* Start erase on unprotected sectors */ - for (sect = s_first; sect <= s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - vu_long *addr = (vu_long *) (info->start[sect]); - - DEBUGF ("Erase sect %d @ 0x%08lX\n", - sect, (ulong) addr); - - /* Disable interrupts which might cause a timeout - * here. - */ - flag = disable_interrupts (); - - addr[0] = 0x00500050; /* clear status register */ - addr[0] = 0x00200020; /* erase setup */ - addr[0] = 0x00D000D0; /* erase confirm */ - - addr[1] = 0x00500050; /* clear status register */ - addr[1] = 0x00200020; /* erase setup */ - addr[1] = 0x00D000D0; /* erase confirm */ - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts (); - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - - while (((addr[0] & 0x00800080) != 0x00800080) || - ((addr[1] & 0x00800080) != 0x00800080)) { - if ((now = get_timer (start)) > - CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - addr[0] = 0x00B000B0; /* suspend erase */ - addr[0] = 0x00FF00FF; /* to read mode */ - return 1; - } - - /* show that we're waiting */ - if ((now - last) > 1000) { /* every second */ - putc ('.'); - last = now; - } - } - - addr[0] = 0x00FF00FF; - } - } - printf (" done\n"); - return 0; -} - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - * 4 - Flash not identified - */ - -#define FLASH_WIDTH 8 /* flash bus width in bytes */ - -int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) -{ - ulong wp, cp, msr; - int l, rc, i; - ulong data[2]; - ulong *datah = &data[0]; - ulong *datal = &data[1]; - - DEBUGF ("Flash write_buff: @ 0x%08lx, src 0x%08lx len %ld\n", - addr, (ulong) src, cnt); - - if (info->flash_id == FLASH_UNKNOWN) { - return 4; - } - - msr = get_msr (); - set_msr (msr | MSR_FP); - - wp = (addr & ~(FLASH_WIDTH - 1)); /* get lower aligned address */ - - /* - * handle unaligned start bytes - */ - if ((l = addr - wp) != 0) { - *datah = *datal = 0; - - for (i = 0, cp = wp; i < l; i++, cp++) { - if (i >= 4) { - *datah = (*datah << 8) | - ((*datal & 0xFF000000) >> 24); - } - - *datal = (*datal << 8) | (*(uchar *) cp); - } - for (; i < FLASH_WIDTH && cnt > 0; ++i) { - char tmp = *src++; - - if (i >= 4) { - *datah = (*datah << 8) | - ((*datal & 0xFF000000) >> 24); - } - - *datal = (*datal << 8) | tmp; - --cnt; - ++cp; - } - - for (; cnt == 0 && i < FLASH_WIDTH; ++i, ++cp) { - if (i >= 4) { - *datah = (*datah << 8) | - ((*datal & 0xFF000000) >> 24); - } - - *datal = (*datah << 8) | (*(uchar *) cp); - } - - if ((rc = write_data (info, wp, data)) != 0) { - set_msr (msr); - return (rc); - } - - wp += FLASH_WIDTH; - } - - /* - * handle FLASH_WIDTH aligned part - */ - while (cnt >= FLASH_WIDTH) { - *datah = *(ulong *) src; - *datal = *(ulong *) (src + 4); - if ((rc = write_data (info, wp, data)) != 0) { - set_msr (msr); - return (rc); - } - wp += FLASH_WIDTH; - cnt -= FLASH_WIDTH; - src += FLASH_WIDTH; - } - - if (cnt == 0) { - set_msr (msr); - return (0); - } - - /* - * handle unaligned tail bytes - */ - *datah = *datal = 0; - for (i = 0, cp = wp; i < FLASH_WIDTH && cnt > 0; ++i, ++cp) { - char tmp = *src++; - - if (i >= 4) { - *datah = (*datah << 8) | ((*datal & 0xFF000000) >> - 24); - } - - *datal = (*datal << 8) | tmp; - --cnt; - } - - for (; i < FLASH_WIDTH; ++i, ++cp) { - if (i >= 4) { - *datah = (*datah << 8) | ((*datal & 0xFF000000) >> - 24); - } - - *datal = (*datal << 8) | (*(uchar *) cp); - } - - rc = write_data (info, wp, data); - set_msr (msr); - - return (rc); -} - -/*----------------------------------------------------------------------- - * Write a word to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_data (flash_info_t * info, ulong dest, ulong * data) -{ - vu_long *addr = (vu_long *) dest; - ulong start; - int flag; - - /* Check if Flash is (sufficiently) erased */ - if (((addr[0] & data[0]) != data[0]) || - ((addr[1] & data[1]) != data[1])) { - return (2); - } - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts (); - - addr[0] = 0x00400040; /* write setup */ - write_via_fpu (addr, data); - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts (); - - start = get_timer (0); - - while (((addr[0] & 0x00800080) != 0x00800080) || - ((addr[1] & 0x00800080) != 0x00800080)) { - if (get_timer (start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - addr[0] = 0x00FF00FF; /* restore read mode */ - return (1); - } - } - - addr[0] = 0x00FF00FF; /* restore read mode */ - - return (0); -} - -/*----------------------------------------------------------------------- - */ -static void write_via_fpu (vu_long * addr, ulong * data) -{ - __asm__ __volatile__ ("lfd 1, 0(%0)"::"r" (data)); - __asm__ __volatile__ ("stfd 1, 0(%0)"::"r" (addr)); -} - -/*----------------------------------------------------------------------- - */ -static __inline__ unsigned long get_msr (void) -{ - unsigned long msr; - - __asm__ __volatile__ ("mfmsr %0":"=r" (msr):); - - return msr; -} - -static __inline__ void set_msr (unsigned long msr) -{ - __asm__ __volatile__ ("mtmsr %0"::"r" (msr)); -} diff --git a/board/cpc45/ide.c b/board/cpc45/ide.c deleted file mode 100644 index 1944e36..0000000 --- a/board/cpc45/ide.c +++ /dev/null @@ -1,128 +0,0 @@ -/* - * (C) Copyright 2001 - * Rob Taylor, Flying Pig Systems. robt@flyingpig.com. - * - * (C) Copyright 2000-2011 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <ide.h> -#include <ata.h> -#include <asm/io.h> - -#define EIEIO __asm__ volatile ("eieio") -#define SYNC __asm__ volatile ("sync") - -void ide_input_swap_data(int dev, ulong *sect_buf, int words) -{ - uchar i; - volatile uchar *pbuf_even = - (uchar *) (ATA_CURR_BASE(dev) + ATA_DATA_EVEN); - volatile uchar *pbuf_odd = - (uchar *) (ATA_CURR_BASE(dev) + ATA_DATA_ODD); - ushort *dbuf = (ushort *) sect_buf; - - while (words--) { - for (i = 0; i < 2; i++) { - *(((uchar *) (dbuf)) + 1) = *pbuf_even; - *(uchar *) dbuf = *pbuf_odd; - dbuf += 1; - } - } -} - -void ide_input_data(int dev, ulong *sect_buf, int words) -{ - uchar *dbuf; - volatile uchar *pbuf_even; - volatile uchar *pbuf_odd; - - pbuf_even = (uchar *) (ATA_CURR_BASE(dev) + ATA_DATA_EVEN); - pbuf_odd = (uchar *) (ATA_CURR_BASE(dev) + ATA_DATA_ODD); - dbuf = (uchar *) sect_buf; - while (words--) { - *dbuf++ = *pbuf_even; - EIEIO; - SYNC; - *dbuf++ = *pbuf_odd; - EIEIO; - SYNC; - *dbuf++ = *pbuf_even; - EIEIO; - SYNC; - *dbuf++ = *pbuf_odd; - EIEIO; - SYNC; - } -} - -void ide_input_data_shorts(int dev, ushort *sect_buf, int shorts) -{ - uchar *dbuf; - volatile uchar *pbuf_even; - volatile uchar *pbuf_odd; - - pbuf_even = (uchar *) (ATA_CURR_BASE(dev) + ATA_DATA_EVEN); - pbuf_odd = (uchar *) (ATA_CURR_BASE(dev) + ATA_DATA_ODD); - dbuf = (uchar *) sect_buf; - while (shorts--) { - EIEIO; - *dbuf++ = *pbuf_even; - EIEIO; - *dbuf++ = *pbuf_odd; - } -} - -void ide_output_data(int dev, const ulong *sect_buf, int words) -{ - uchar *dbuf; - volatile uchar *pbuf_even; - volatile uchar *pbuf_odd; - - pbuf_even = (uchar *) (ATA_CURR_BASE(dev) + ATA_DATA_EVEN); - pbuf_odd = (uchar *) (ATA_CURR_BASE(dev) + ATA_DATA_ODD); - dbuf = (uchar *) sect_buf; - while (words--) { - EIEIO; - *pbuf_even = *dbuf++; - EIEIO; - *pbuf_odd = *dbuf++; - EIEIO; - *pbuf_even = *dbuf++; - EIEIO; - *pbuf_odd = *dbuf++; - } -} - -void ide_output_data_shorts(int dev, ushort *sect_buf, int shorts) -{ - uchar *dbuf; - volatile uchar *pbuf_even; - volatile uchar *pbuf_odd; - - pbuf_even = (uchar *) (ATA_CURR_BASE(dev) + ATA_DATA_EVEN); - pbuf_odd = (uchar *) (ATA_CURR_BASE(dev) + ATA_DATA_ODD); - dbuf = (uchar *) sect_buf; - while (shorts--) { - EIEIO; - *pbuf_even = *dbuf++; - EIEIO; - *pbuf_odd = *dbuf++; - } -} - -void ide_led(uchar led, uchar status) -{ - u_char val; - /* We have one PCMCIA slot and use LED H4 for the IDE Interface */ - val = readb(BCSR_BASE + 0x04); - if (status) /* led on */ - val |= B_CTRL_LED0; - else - val &= ~B_CTRL_LED0; - - writeb(val, BCSR_BASE + 0x04); -} diff --git a/board/cpc45/pd67290.c b/board/cpc45/pd67290.c deleted file mode 100644 index 23d87f6..0000000 --- a/board/cpc45/pd67290.c +++ /dev/null @@ -1,797 +0,0 @@ -/* - * (C) Copyright 2003-2005 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - ******************************************************************** - * - * Lots of code copied from: - * - * i82365.c 1.352 - Linux driver for Intel 82365 and compatible - * PC Card controllers, and Yenta-compatible PCI-to-CardBus controllers. - * (C) 1999 David A. Hinds dahinds@users.sourceforge.net - */ - -#include <common.h> - -#ifdef CONFIG_I82365 - -#include <command.h> -#include <pci.h> -#include <pcmcia.h> -#include <asm/io.h> - -#include <pcmcia/ss.h> -#include <pcmcia/i82365.h> -#include <pcmcia/yenta.h> -#include <pcmcia/cirrus.h> - -static struct pci_device_id supported[] = { - {PCI_VENDOR_ID_CIRRUS, PCI_DEVICE_ID_CIRRUS_6729}, - {0, 0} -}; - -#define CYCLE_TIME 120 - -#ifdef DEBUG -static void i82365_dump_regions (pci_dev_t dev); -#endif - -typedef struct socket_info_t { - pci_dev_t dev; - u_short bcr; - u_char pci_lat, cb_lat, sub_bus, cache; - u_int cb_phys; - - socket_cap_t cap; - u_short type; - u_int flags; - cirrus_state_t c_state; -} socket_info_t; - -/* These definitions must match the pcic table! */ -typedef enum pcic_id { - IS_PD6710, IS_PD672X, IS_VT83C469 -} pcic_id; - -typedef struct pcic_t { - char *name; -} pcic_t; - -static pcic_t pcic[] = { - {" Cirrus PD6710: "}, - {" Cirrus PD672x: "}, - {" VIA VT83C469: "}, -}; - -static socket_info_t socket; -static socket_state_t state; -static struct pccard_mem_map mem; -static struct pccard_io_map io; - -/*====================================================================*/ - -/* Some PCI shortcuts */ - -static int pci_readb (socket_info_t * s, int r, u_char * v) -{ - return pci_read_config_byte (s->dev, r, v); -} -static int pci_writeb (socket_info_t * s, int r, u_char v) -{ - return pci_write_config_byte (s->dev, r, v); -} -static int pci_readw (socket_info_t * s, int r, u_short * v) -{ - return pci_read_config_word (s->dev, r, v); -} -static int pci_writew (socket_info_t * s, int r, u_short v) -{ - return pci_write_config_word (s->dev, r, v); -} - -/*====================================================================*/ - -#define cb_readb(s) readb((s)->cb_phys + 1) -#define cb_writeb(s, v) writeb(v, (s)->cb_phys) -#define cb_writeb2(s, v) writeb(v, (s)->cb_phys + 1) -#define cb_readl(s, r) readl((s)->cb_phys + (r)) -#define cb_writel(s, r, v) writel(v, (s)->cb_phys + (r)) - - -static u_char i365_get (socket_info_t * s, u_short reg) -{ - u_char val; -#ifdef CONFIG_PCMCIA_SLOT_A - int slot = 0; -#else - int slot = 1; -#endif - - val = I365_REG (slot, reg); - - cb_writeb (s, val); - val = cb_readb (s); - - debug ("i365_get slot:%x reg: %x val: %x\n", slot, reg, val); - return val; -} - -static void i365_set (socket_info_t * s, u_short reg, u_char data) -{ -#ifdef CONFIG_PCMCIA_SLOT_A - int slot = 0; -#else - int slot = 1; -#endif - u_char val; - - val = I365_REG (slot, reg); - - cb_writeb (s, val); - cb_writeb2 (s, data); - - debug ("i365_set slot:%x reg: %x data:%x\n", slot, reg, data); -} - -static void i365_bset (socket_info_t * s, u_short reg, u_char mask) -{ - i365_set (s, reg, i365_get (s, reg) | mask); -} - -static void i365_bclr (socket_info_t * s, u_short reg, u_char mask) -{ - i365_set (s, reg, i365_get (s, reg) & ~mask); -} - -#if 0 /* not used */ -static void i365_bflip (socket_info_t * s, u_short reg, u_char mask, int b) -{ - u_char d = i365_get (s, reg); - - i365_set (s, reg, (b) ? (d | mask) : (d & ~mask)); -} - -static u_short i365_get_pair (socket_info_t * s, u_short reg) -{ - return (i365_get (s, reg) + (i365_get (s, reg + 1) << 8)); -} -#endif /* not used */ - -static void i365_set_pair (socket_info_t * s, u_short reg, u_short data) -{ - i365_set (s, reg, data & 0xff); - i365_set (s, reg + 1, data >> 8); -} - -/*====================================================================== - - Code to save and restore global state information for Cirrus - PD67xx controllers, and to set and report global configuration - options. - -======================================================================*/ - -#define flip(v,b,f) (v = ((f)<0) ? v : ((f) ? ((v)|(b)) : ((v)&(~b)))) - -static void cirrus_get_state (socket_info_t * s) -{ - int i; - cirrus_state_t *p = &s->c_state; - - p->misc1 = i365_get (s, PD67_MISC_CTL_1); - p->misc1 &= (PD67_MC1_MEDIA_ENA | PD67_MC1_INPACK_ENA); - p->misc2 = i365_get (s, PD67_MISC_CTL_2); - for (i = 0; i < 6; i++) - p->timer[i] = i365_get (s, PD67_TIME_SETUP (0) + i); - -} - -static void cirrus_set_state (socket_info_t * s) -{ - int i; - u_char misc; - cirrus_state_t *p = &s->c_state; - - misc = i365_get (s, PD67_MISC_CTL_2); - i365_set (s, PD67_MISC_CTL_2, p->misc2); - if (misc & PD67_MC2_SUSPEND) - udelay (50000); - misc = i365_get (s, PD67_MISC_CTL_1); - misc &= ~(PD67_MC1_MEDIA_ENA | PD67_MC1_INPACK_ENA); - i365_set (s, PD67_MISC_CTL_1, misc | p->misc1); - for (i = 0; i < 6; i++) - i365_set (s, PD67_TIME_SETUP (0) + i, p->timer[i]); -} - -static u_int cirrus_set_opts (socket_info_t * s) -{ - cirrus_state_t *p = &s->c_state; - u_int mask = 0xffff; - char buf[200] = {0}; - - if (has_ring == -1) - has_ring = 1; - flip (p->misc2, PD67_MC2_IRQ15_RI, has_ring); - flip (p->misc2, PD67_MC2_DYNAMIC_MODE, dynamic_mode); -#if DEBUG - if (p->misc2 & PD67_MC2_IRQ15_RI) - strcat (buf, " [ring]"); - if (p->misc2 & PD67_MC2_DYNAMIC_MODE) - strcat (buf, " [dyn mode]"); - if (p->misc1 & PD67_MC1_INPACK_ENA) - strcat (buf, " [inpack]"); -#endif - - if (p->misc2 & PD67_MC2_IRQ15_RI) - mask &= ~0x8000; - if (has_led > 0) { -#if DEBUG - strcat (buf, " [led]"); -#endif - mask &= ~0x1000; - } - if (has_dma > 0) { -#if DEBUG - strcat (buf, " [dma]"); -#endif - mask &= ~0x0600; - flip (p->misc2, PD67_MC2_FREQ_BYPASS, freq_bypass); -#if DEBUG - if (p->misc2 & PD67_MC2_FREQ_BYPASS) - strcat (buf, " [freq bypass]"); -#endif - } - - if (setup_time >= 0) - p->timer[0] = p->timer[3] = setup_time; - if (cmd_time > 0) { - p->timer[1] = cmd_time; - p->timer[4] = cmd_time * 2 + 4; - } - if (p->timer[1] == 0) { - p->timer[1] = 6; - p->timer[4] = 16; - if (p->timer[0] == 0) - p->timer[0] = p->timer[3] = 1; - } - if (recov_time >= 0) - p->timer[2] = p->timer[5] = recov_time; - - debug ("i82365 Opt: %s [%d/%d/%d] [%d/%d/%d]\n", - buf, - p->timer[0], p->timer[1], p->timer[2], - p->timer[3], p->timer[4], p->timer[5]); - - return mask; -} - -/*====================================================================== - - Routines to handle common CardBus options - -======================================================================*/ - -/* Default settings for PCI command configuration register */ -#define CMD_DFLT (PCI_COMMAND_IO|PCI_COMMAND_MEMORY| \ - PCI_COMMAND_MASTER|PCI_COMMAND_WAIT) - -static void cb_get_state (socket_info_t * s) -{ - pci_readb (s, PCI_CACHE_LINE_SIZE, &s->cache); - pci_readb (s, PCI_LATENCY_TIMER, &s->pci_lat); - pci_readb (s, CB_LATENCY_TIMER, &s->cb_lat); - pci_readb (s, CB_CARDBUS_BUS, &s->cap.cardbus); - pci_readb (s, CB_SUBORD_BUS, &s->sub_bus); - pci_readw (s, CB_BRIDGE_CONTROL, &s->bcr); -} - -static void cb_set_state (socket_info_t * s) -{ - pci_writew (s, PCI_COMMAND, CMD_DFLT); - pci_writeb (s, PCI_CACHE_LINE_SIZE, s->cache); - pci_writeb (s, PCI_LATENCY_TIMER, s->pci_lat); - pci_writeb (s, CB_LATENCY_TIMER, s->cb_lat); - pci_writeb (s, CB_CARDBUS_BUS, s->cap.cardbus); - pci_writeb (s, CB_SUBORD_BUS, s->sub_bus); - pci_writew (s, CB_BRIDGE_CONTROL, s->bcr); -} - -static void cb_set_opts (socket_info_t * s) -{ -} - -/*====================================================================== - - Power control for Cardbus controllers: used both for 16-bit and - Cardbus cards. - -======================================================================*/ - -static int cb_set_power (socket_info_t * s, socket_state_t * state) -{ - u_int reg = 0; - - reg = I365_PWR_NORESET; - if (state->flags & SS_PWR_AUTO) - reg |= I365_PWR_AUTO; - if (state->flags & SS_OUTPUT_ENA) - reg |= I365_PWR_OUT; - if (state->Vpp != 0) { - if (state->Vpp == 120) { - reg |= I365_VPP1_12V; - puts (" 12V card found: "); - } else if (state->Vpp == state->Vcc) { - reg |= I365_VPP1_5V; - } else { - puts (" power not found: "); - return -1; - } - } - if (state->Vcc != 0) { - reg |= I365_VCC_5V; - if (state->Vcc == 33) { - puts (" 3.3V card found: "); - i365_bset (s, PD67_MISC_CTL_1, PD67_MC1_VCC_3V); - } else if (state->Vcc == 50) { - puts (" 5V card found: "); - i365_bclr (s, PD67_MISC_CTL_1, PD67_MC1_VCC_3V); - } else { - puts (" power not found: "); - return -1; - } - } - - if (reg != i365_get (s, I365_POWER)) { - reg = (I365_PWR_OUT | I365_PWR_NORESET | I365_VCC_5V | I365_VPP1_5V); - i365_set (s, I365_POWER, reg); - } - - return 0; -} - -/*====================================================================== - - Generic routines to get and set controller options - -======================================================================*/ - -static void get_bridge_state (socket_info_t * s) -{ - cirrus_get_state (s); - cb_get_state (s); -} - -static void set_bridge_state (socket_info_t * s) -{ - cb_set_state (s); - i365_set (s, I365_GBLCTL, 0x00); - i365_set (s, I365_GENCTL, 0x00); - cirrus_set_state (s); -} - -static void set_bridge_opts (socket_info_t * s) -{ - cirrus_set_opts (s); - cb_set_opts (s); -} - -/*====================================================================*/ -#define PD67_EXT_INDEX 0x2e /* Extension index */ -#define PD67_EXT_DATA 0x2f /* Extension data */ -#define PD67_EXD_VS1(s) (0x01 << ((s)<<1)) - -#define pd67_ext_get(s, r) \ - (i365_set(s, PD67_EXT_INDEX, r), i365_get(s, PD67_EXT_DATA)) - -static int i365_get_status (socket_info_t * s, u_int * value) -{ - u_int status; - u_char val; - u_char power, vcc, vpp; - u_int powerstate; - - status = i365_get (s, I365_IDENT); - status = i365_get (s, I365_STATUS); - *value = ((status & I365_CS_DETECT) == I365_CS_DETECT) ? SS_DETECT : 0; - if (i365_get (s, I365_INTCTL) & I365_PC_IOCARD) { - *value |= (status & I365_CS_STSCHG) ? 0 : SS_STSCHG; - } else { - *value |= (status & I365_CS_BVD1) ? 0 : SS_BATDEAD; - *value |= (status & I365_CS_BVD2) ? 0 : SS_BATWARN; - } - *value |= (status & I365_CS_WRPROT) ? SS_WRPROT : 0; - *value |= (status & I365_CS_READY) ? SS_READY : 0; - *value |= (status & I365_CS_POWERON) ? SS_POWERON : 0; - - /* Check for Cirrus CL-PD67xx chips */ - i365_set (s, PD67_CHIP_INFO, 0); - val = i365_get (s, PD67_CHIP_INFO); - s->type = -1; - if ((val & PD67_INFO_CHIP_ID) == PD67_INFO_CHIP_ID) { - val = i365_get (s, PD67_CHIP_INFO); - if ((val & PD67_INFO_CHIP_ID) == 0) { - s->type = (val & PD67_INFO_SLOTS) ? IS_PD672X : IS_PD6710; - i365_set (s, PD67_EXT_INDEX, 0xe5); - if (i365_get (s, PD67_EXT_INDEX) != 0xe5) - s->type = IS_VT83C469; - } - } else { - printf ("no Cirrus Chip found\n"); - *value = 0; - return -1; - } - - power = i365_get (s, I365_POWER); - state.flags |= (power & I365_PWR_AUTO) ? SS_PWR_AUTO : 0; - state.flags |= (power & I365_PWR_OUT) ? SS_OUTPUT_ENA : 0; - vcc = power & I365_VCC_MASK; - vpp = power & I365_VPP1_MASK; - state.Vcc = state.Vpp = 0; - if((vcc== 0) || (vpp == 0)) { - /* - * On the Cirrus we get the info which card voltage - * we have in EXTERN DATA and write it to MISC_CTL1 - */ - powerstate = pd67_ext_get(s, PD67_EXTERN_DATA); - if (powerstate & PD67_EXD_VS1(0)) { - /* 5V Card */ - i365_bclr (s, PD67_MISC_CTL_1, PD67_MC1_VCC_3V); - } else { - /* 3.3V Card */ - i365_bset (s, PD67_MISC_CTL_1, PD67_MC1_VCC_3V); - } - i365_set (s, I365_POWER, (I365_PWR_OUT | I365_PWR_NORESET | I365_VCC_5V | I365_VPP1_5V)); - power = i365_get (s, I365_POWER); - } - if (power & I365_VCC_5V) { - state.Vcc = (i365_get(s, PD67_MISC_CTL_1) & PD67_MC1_VCC_3V) ? 33 : 50; - } - - if (power == I365_VPP1_12V) - state.Vpp = 120; - - /* IO card, RESET flags, IO interrupt */ - power = i365_get (s, I365_INTCTL); - state.flags |= (power & I365_PC_RESET) ? 0 : SS_RESET; - if (power & I365_PC_IOCARD) - state.flags |= SS_IOCARD; - state.io_irq = power & I365_IRQ_MASK; - - /* Card status change mask */ - power = i365_get (s, I365_CSCINT); - state.csc_mask = (power & I365_CSC_DETECT) ? SS_DETECT : 0; - if (state.flags & SS_IOCARD) - state.csc_mask |= (power & I365_CSC_STSCHG) ? SS_STSCHG : 0; - else { - state.csc_mask |= (power & I365_CSC_BVD1) ? SS_BATDEAD : 0; - state.csc_mask |= (power & I365_CSC_BVD2) ? SS_BATWARN : 0; - state.csc_mask |= (power & I365_CSC_READY) ? SS_READY : 0; - } - debug ("i82365: GetStatus(0) = flags %#3.3x, Vcc %d, Vpp %d, " - "io_irq %d, csc_mask %#2.2x\n", state.flags, - state.Vcc, state.Vpp, state.io_irq, state.csc_mask); - - return 0; -} /* i365_get_status */ - -static int i365_set_socket (socket_info_t * s, socket_state_t * state) -{ - u_char reg; - - set_bridge_state (s); - - /* IO card, RESET flag */ - reg = 0; - reg |= (state->flags & SS_RESET) ? 0 : I365_PC_RESET; - reg |= (state->flags & SS_IOCARD) ? I365_PC_IOCARD : 0; - i365_set (s, I365_INTCTL, reg); - - cb_set_power (s, state); - -#if 0 - /* Card status change interrupt mask */ - reg = s->cs_irq << 4; - if (state->csc_mask & SS_DETECT) - reg |= I365_CSC_DETECT; - if (state->flags & SS_IOCARD) { - if (state->csc_mask & SS_STSCHG) - reg |= I365_CSC_STSCHG; - } else { - if (state->csc_mask & SS_BATDEAD) - reg |= I365_CSC_BVD1; - if (state->csc_mask & SS_BATWARN) - reg |= I365_CSC_BVD2; - if (state->csc_mask & SS_READY) - reg |= I365_CSC_READY; - } - i365_set (s, I365_CSCINT, reg); - i365_get (s, I365_CSC); -#endif /* 0 */ - - return 0; -} /* i365_set_socket */ - -/*====================================================================*/ - -static int i365_set_mem_map (socket_info_t * s, struct pccard_mem_map *mem) -{ - u_short base, i; - u_char map; - - debug ("i82365: SetMemMap(%d, %#2.2x, %d ns, %#5.5lx-%#5.5lx, %#5.5x)\n", - mem->map, mem->flags, mem->speed, - mem->sys_start, mem->sys_stop, mem->card_start); - - map = mem->map; - if ((map > 4) || - (mem->card_start > 0x3ffffff) || - (mem->sys_start > mem->sys_stop) || - (mem->speed > 1000)) { - return -1; - } - - /* Turn off the window before changing anything */ - if (i365_get (s, I365_ADDRWIN) & I365_ENA_MEM (map)) - i365_bclr (s, I365_ADDRWIN, I365_ENA_MEM (map)); - - /* Take care of high byte, for PCI controllers */ - i365_set (s, CB_MEM_PAGE (map), mem->sys_start >> 24); - - base = I365_MEM (map); - i = (mem->sys_start >> 12) & 0x0fff; - if (mem->flags & MAP_16BIT) - i |= I365_MEM_16BIT; - if (mem->flags & MAP_0WS) - i |= I365_MEM_0WS; - i365_set_pair (s, base + I365_W_START, i); - - i = (mem->sys_stop >> 12) & 0x0fff; - switch (mem->speed / CYCLE_TIME) { - case 0: - break; - case 1: - i |= I365_MEM_WS0; - break; - case 2: - i |= I365_MEM_WS1; - break; - default: - i |= I365_MEM_WS1 | I365_MEM_WS0; - break; - } - i365_set_pair (s, base + I365_W_STOP, i); - - i = 0; - if (mem->flags & MAP_WRPROT) - i |= I365_MEM_WRPROT; - if (mem->flags & MAP_ATTRIB) - i |= I365_MEM_REG; - i365_set_pair (s, base + I365_W_OFF, i); - - /* set System Memory map Upper Adress */ - i365_set(s, PD67_EXT_INDEX, PD67_MEM_PAGE(map)); - i365_set(s, PD67_EXT_DATA, ((mem->sys_start >> 24) & 0xff)); - - /* Turn on the window if necessary */ - if (mem->flags & MAP_ACTIVE) - i365_bset (s, I365_ADDRWIN, I365_ENA_MEM (map)); - return 0; -} /* i365_set_mem_map */ - -static int i365_set_io_map (socket_info_t * s, struct pccard_io_map *io) -{ - u_char map, ioctl; - - map = io->map; - /* comment out: comparison is always false due to limited range of data type */ - if ((map > 1) || /* (io->start > 0xffff) || (io->stop > 0xffff) || */ - (io->stop < io->start)) - return -1; - /* Turn off the window before changing anything */ - if (i365_get (s, I365_ADDRWIN) & I365_ENA_IO (map)) - i365_bclr (s, I365_ADDRWIN, I365_ENA_IO (map)); - i365_set_pair (s, I365_IO (map) + I365_W_START, io->start); - i365_set_pair (s, I365_IO (map) + I365_W_STOP, io->stop); - ioctl = i365_get (s, I365_IOCTL) & ~I365_IOCTL_MASK (map); - if (io->speed) - ioctl |= I365_IOCTL_WAIT (map); - if (io->flags & MAP_0WS) - ioctl |= I365_IOCTL_0WS (map); - if (io->flags & MAP_16BIT) - ioctl |= I365_IOCTL_16BIT (map); - if (io->flags & MAP_AUTOSZ) - ioctl |= I365_IOCTL_IOCS16 (map); - i365_set (s, I365_IOCTL, ioctl); - /* Turn on the window if necessary */ - if (io->flags & MAP_ACTIVE) - i365_bset (s, I365_ADDRWIN, I365_ENA_IO (map)); - return 0; -} /* i365_set_io_map */ - -/*====================================================================*/ - -/* - * PCI_ADDR = (HOST_ADDR - 0xfe000000) - * see MPC 8245 Users Manual Adress Map B - */ -#define HOST_TO_PCI(addr) ((addr) - 0xfe000000) -#define PCI_TO_HOST(addr) ((addr) + 0xfe000000) - -static int i82365_init (void) -{ - u_int val; - int i; - - if ((socket.dev = pci_find_devices (supported, 0)) < 0) { - /* Controller not found */ - printf ("No PD67290 device found !!\n"); - return 1; - } - debug ("i82365 Device Found!\n"); - - socket.cb_phys = PCMCIA_IO_BASE; - - /* set base address */ - pci_write_config_dword (socket.dev, PCI_BASE_ADDRESS_0, - HOST_TO_PCI(socket.cb_phys)); - - /* enable mapped memory and IO addresses */ - pci_write_config_dword (socket.dev, - PCI_COMMAND, - PCI_COMMAND_MEMORY | - PCI_COMMAND_IO | PCI_COMMAND_WAIT); - - get_bridge_state (&socket); - set_bridge_opts (&socket); - - i = i365_get_status (&socket, &val); - - if (i > -1) { - puts (pcic[socket.type].name); - } else { - printf ("i82365: Controller not found.\n"); - return 1; - } - if((val & SS_DETECT) != SS_DETECT){ - puts ("No card\n"); - return 1; - } - - state.flags |= SS_OUTPUT_ENA; - - i365_set_socket (&socket, &state); - - for (i = 500; i; i--) { - if ((i365_get (&socket, I365_STATUS) & I365_CS_READY)) - break; - udelay (1000); - } - - if (i == 0) { - /* PC Card not ready for data transfer */ - puts ("i82365 PC Card not ready for data transfer\n"); - return 1; - } - debug (" PC Card ready for data transfer: "); - - mem.map = 0; - mem.flags = MAP_ATTRIB | MAP_ACTIVE; - mem.speed = 300; - mem.sys_start = CONFIG_SYS_PCMCIA_MEM_ADDR; - mem.sys_stop = CONFIG_SYS_PCMCIA_MEM_ADDR + CONFIG_SYS_PCMCIA_MEM_SIZE - 1; - mem.card_start = 0; - i365_set_mem_map (&socket, &mem); - - mem.map = 1; - mem.flags = MAP_ACTIVE; - mem.speed = 300; - mem.sys_start = CONFIG_SYS_PCMCIA_MEM_ADDR + CONFIG_SYS_PCMCIA_MEM_SIZE; - mem.sys_stop = CONFIG_SYS_PCMCIA_MEM_ADDR + (2 * CONFIG_SYS_PCMCIA_MEM_SIZE) - 1; - mem.card_start = 0; - i365_set_mem_map (&socket, &mem); - -#ifdef DEBUG - i82365_dump_regions (socket.dev); -#endif - - return 0; -} - -static void i82365_exit (void) -{ - io.map = 0; - io.flags = 0; - io.speed = 0; - io.start = 0; - io.stop = 0x1; - - i365_set_io_map (&socket, &io); - - mem.map = 0; - mem.flags = 0; - mem.speed = 0; - mem.sys_start = 0; - mem.sys_stop = 0x1000; - mem.card_start = 0; - - i365_set_mem_map (&socket, &mem); - - mem.map = 1; - mem.flags = 0; - mem.speed = 0; - mem.sys_start = 0; - mem.sys_stop = 0x1000; - mem.card_start = 0; - - i365_set_mem_map (&socket, &mem); - - state.Vcc = state.Vpp = 0; - - i365_set_socket (&socket, &state); -} - -int pcmcia_on (void) -{ - u_int rc; - - debug ("Enable PCMCIA " PCMCIA_SLOT_MSG "\n"); - - rc = i82365_init(); - if (rc) - goto exit; - - rc = check_ide_device(0); - if (rc == 0) - goto exit; - - i82365_exit(); - -exit: - return rc; -} - -#if defined(CONFIG_CMD_PCMCIA) -int pcmcia_off (void) -{ - printf ("Disable PCMCIA " PCMCIA_SLOT_MSG "\n"); - - i82365_exit(); - - return 0; -} -#endif - -/*====================================================================== - - Debug stuff - -======================================================================*/ - -#ifdef DEBUG -static void i82365_dump_regions (pci_dev_t dev) -{ - u_int tmp[2]; - u_int *mem = (void *) socket.cb_phys; - u_char *cis = (void *) CONFIG_SYS_PCMCIA_MEM_ADDR; - u_char *ide = (void *) (CONFIG_SYS_ATA_BASE_ADDR + CONFIG_SYS_ATA_REG_OFFSET); - - pci_read_config_dword (dev, 0x00, tmp + 0); - pci_read_config_dword (dev, 0x80, tmp + 1); - - printf ("PCI CONF: %08X ... %08X\n", - tmp[0], tmp[1]); - printf ("PCI MEM: ... %08X ... %08X\n", - mem[0x8 / 4], mem[0x800 / 4]); - printf ("CIS: ...%c%c%c%c%c%c%c%c...\n", - cis[0x38], cis[0x3a], cis[0x3c], cis[0x3e], - cis[0x40], cis[0x42], cis[0x44], cis[0x48]); - printf ("CIS CONF: %02X %02X %02X ...\n", - cis[0x200], cis[0x202], cis[0x204]); - printf ("IDE: %02X %02X %02X %02X %02X %02X %02X %02X\n", - ide[0], ide[1], ide[2], ide[3], - ide[4], ide[5], ide[6], ide[7]); -} -#endif /* DEBUG */ - -#endif /* CONFIG_I82365 */ diff --git a/board/cpc45/plx9030.c b/board/cpc45/plx9030.c deleted file mode 100644 index 06fb8d6..0000000 --- a/board/cpc45/plx9030.c +++ /dev/null @@ -1,156 +0,0 @@ -/* Plx9030.c - system configuration module for PLX9030 PCI to Local Bus Bridge */ -/* - * (C) Copyright 2002-2003 - * Josef Wagner, MicroSys GmbH, wagner@microsys.de. - * - * SPDX-License-Identifier: GPL-2.0+ - * Date Modification by - * ------- ---------------------------------------------- --- - * 30sep02 converted from VxWorks to LINUX wa -*/ - - -/* -DESCRIPTION - -This is the configuration module for the PLX9030 PCI to Local Bus Bridge. -It configures the Chip select lines for SRAM (CS0), ST16C552 (CS1,CS2), Display and local -registers (CS3) on CPC45. -*/ - -/* includes */ - -#include <common.h> -#include <malloc.h> -#include <net.h> -#include <asm/io.h> -#include <pci.h> - -/* imports */ - - -/* defines */ -#define PLX9030_VENDOR_ID 0x10B5 -#define PLX9030_DEVICE_ID 0x9030 - -#undef PLX_DEBUG - -/* PLX9030 register offsets */ -#define P9030_LAS0RR 0x00 -#define P9030_LAS1RR 0x04 -#define P9030_LAS2RR 0x08 -#define P9030_LAS3RR 0x0c -#define P9030_EROMRR 0x10 -#define P9030_LAS0BA 0x14 -#define P9030_LAS1BA 0x18 -#define P9030_LAS2BA 0x1c -#define P9030_LAS3BA 0x20 -#define P9030_EROMBA 0x24 -#define P9030_LAS0BRD 0x28 -#define P9030_LAS1BRD 0x2c -#define P9030_LAS2BRD 0x30 -#define P9030_LAS3BRD 0x34 -#define P9030_EROMBRD 0x38 -#define P9030_CS0BASE 0x3C -#define P9030_CS1BASE 0x40 -#define P9030_CS2BASE 0x44 -#define P9030_CS3BASE 0x48 -#define P9030_INTCSR 0x4c -#define P9030_CNTRL 0x50 -#define P9030_GPIOC 0x54 - -/* typedefs */ - - -/* locals */ - -static struct pci_device_id supported[] = { - { PLX9030_VENDOR_ID, PLX9030_DEVICE_ID }, - { } -}; - -/* forward declarations */ -void sysOutLong(ulong address, ulong value); - - -/*************************************************************************** -* -* Plx9030Init - init CS0..CS3 for CPC45 -* -* -* RETURNS: N/A -*/ - -void Plx9030Init (void) -{ - pci_dev_t devno; - ulong membaseCsr; /* base address of device memory space */ - int idx = 0; /* general index */ - - - /* find plx9030 device */ - - if ((devno = pci_find_devices(supported, idx++)) < 0) - { - printf("No PLX9030 device found !!\n"); - return; - } - - -#ifdef PLX_DEBUG - printf("PLX 9030 device found ! devno = 0x%x\n",devno); -#endif - - membaseCsr = PCI_PLX9030_MEMADDR; - - /* set base address */ - pci_write_config_dword(devno, PCI_BASE_ADDRESS_0, membaseCsr); - - /* enable mapped memory and IO addresses */ - pci_write_config_dword(devno, - PCI_COMMAND, - PCI_COMMAND_MEMORY | - PCI_COMMAND_MASTER); - - - /* configure GBIOC */ - sysOutLong((membaseCsr + P9030_GPIOC), 0x00000FC0); /* CS2/CS3 enable */ - - /* configure CS0 (SRAM) */ - sysOutLong((membaseCsr + P9030_LAS0BA), 0x00000001); /* enable space base */ - sysOutLong((membaseCsr + P9030_LAS0RR), 0x0FE00000); /* 2 MByte */ - sysOutLong((membaseCsr + P9030_LAS0BRD), 0x51928900); /* 4 wait states */ - sysOutLong((membaseCsr + P9030_CS0BASE), 0x00100001); /* enable 2 MByte */ - /* remap CS0 (SRAM) */ - pci_write_config_dword(devno, PCI_BASE_ADDRESS_2, SRAM_BASE); - - /* configure CS1 (ST16552 / CHAN A) */ - sysOutLong((membaseCsr + P9030_LAS1BA), 0x00400001); /* enable space base */ - sysOutLong((membaseCsr + P9030_LAS1RR), 0x0FFFFF00); /* 256 byte */ - sysOutLong((membaseCsr + P9030_LAS1BRD), 0x55122900); /* 4 wait states */ - sysOutLong((membaseCsr + P9030_CS1BASE), 0x00400081); /* enable 256 Byte */ - /* remap CS1 (ST16552 / CHAN A) */ - /* remap CS1 (ST16552 / CHAN A) */ - pci_write_config_dword(devno, PCI_BASE_ADDRESS_3, ST16552_A_BASE); - - /* configure CS2 (ST16552 / CHAN B) */ - sysOutLong((membaseCsr + P9030_LAS2BA), 0x00800001); /* enable space base */ - sysOutLong((membaseCsr + P9030_LAS2RR), 0x0FFFFF00); /* 256 byte */ - sysOutLong((membaseCsr + P9030_LAS2BRD), 0x55122900); /* 4 wait states */ - sysOutLong((membaseCsr + P9030_CS2BASE), 0x00800081); /* enable 256 Byte */ - /* remap CS2 (ST16552 / CHAN B) */ - pci_write_config_dword(devno, PCI_BASE_ADDRESS_4, ST16552_B_BASE); - - /* configure CS3 (BCSR) */ - sysOutLong((membaseCsr + P9030_LAS3BA), 0x00C00001); /* enable space base */ - sysOutLong((membaseCsr + P9030_LAS3RR), 0x0FFFFF00); /* 256 byte */ - sysOutLong((membaseCsr + P9030_LAS3BRD), 0x55357A80); /* 9 wait states */ - sysOutLong((membaseCsr + P9030_CS3BASE), 0x00C00081); /* enable 256 Byte */ - /* remap CS3 (DISPLAY and BCSR) */ - pci_write_config_dword(devno, PCI_BASE_ADDRESS_5, BCSR_BASE); -} - -void sysOutLong(ulong address, ulong value) -{ - *(ulong*)address = cpu_to_le32(value); -} diff --git a/board/cu824/Kconfig b/board/cu824/Kconfig deleted file mode 100644 index 7927b05..0000000 --- a/board/cu824/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_CU824 - -config SYS_BOARD - default "cu824" - -config SYS_CONFIG_NAME - default "CU824" - -endif diff --git a/board/cu824/MAINTAINERS b/board/cu824/MAINTAINERS deleted file mode 100644 index b1b7190..0000000 --- a/board/cu824/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -CU824 BOARD -M: Wolfgang Denk wd@denx.de -S: Maintained -F: board/cu824/ -F: include/configs/CU824.h -F: configs/CU824_defconfig diff --git a/board/cu824/Makefile b/board/cu824/Makefile deleted file mode 100644 index e7bd7ca..0000000 --- a/board/cu824/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2001-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = cu824.o flash.o diff --git a/board/cu824/README b/board/cu824/README deleted file mode 100644 index cc0d207..0000000 --- a/board/cu824/README +++ /dev/null @@ -1,453 +0,0 @@ -ppcboot for a CU824 board ---------------------------- - -CU824 has two banks of flash 8MB each. In board's notation, bank 0 is -the one at the address of 0xFF800000 and bank 1 is the one at the -address of 0xFF000000. On power-up the processor jumps to the address -of 0xFFF00100, the last megabyte of the bank 0 of flash. Thus, -U-Boot is configured to reside in flash starting at the address of -0xFFF00000. The environment space is not embedded in the U-Boot code -and is located in flash separately from U-Boot, at the address of -0xFF008000. - - -U-Boot test results --------------------- - -x.x Operation on all available serial consoles - -x.x.x CONFIG_CONS_INDEX 1 - - -ppcboot 0.9.2 (May 13 2001 - 17:56:46) - -Initializing... - CPU: MPC8240 Revsion 1.1 at 247 MHz: 16 kB I-Cache 16 kB D-Cache - Board: CU824 Revision 1 Local Bus at 99 MHz - DRAM: 64 MB - FLASH: 16 MB - In: serial - Out: serial - Err: serial - -Hit any key to stop autoboot: 0 -=> -=>he -go - start application at address 'addr' -run - run commands in an environment variable -bootm - boot application image from memory -bootp - boot image via network using BootP/TFTP protocol -tftpboot- boot image via network using TFTP protocol - and env variables ipaddr and serverip -rarpboot- boot image via network using RARP/TFTP protocol -bootd - boot default, i.e., run 'bootcmd' -loads - load S-Record file over serial line -loadb - load binary file over serial line (kermit mode) -md - memory display -mm - memory modify (auto-incrementing) -nm - memory modify (constant address) -mw - memory write (fill) -cp - memory copy -cmp - memory compare -crc32 - checksum calculation -base - print or set address offset -printenv- print environment variables -setenv - set environment variables -saveenv - save environment variables to persistent storage -protect - enable or disable FLASH write protection -erase - erase FLASH memory -flinfo - print FLASH memory information -bdinfo - print Board Info structure -iminfo - print header information for application image -coninfo - print console devices and informations -loop - infinite loop on address range -mtest - simple RAM test -icache - enable or disable instruction cache -dcache - enable or disable data cache -reset - Perform RESET of the CPU -echo - echo args to console -version - print monitor version -help - print online help -? - alias for 'help' -=> - - -x.x.x CONFIG_CONS_INDEX 2 - -**** NOT TESTED **** - -x.x Flash Driver Operation - -x.x.x Erase Operation - - -ppcboot 0.9.2 (May 13 2001 - 17:56:46) - -Initializing... - CPU: MPC8240 Revsion 1.1 at 247 MHz: 16 kB I-Cache 16 kB D-Cache - Board: CU824 Revision 1 Local Bus at 99 MHz - DRAM: 64 MB - FLASH: 16 MB - In: serial - Out: serial - Err: serial - -Hit any key to stop autoboot: 0 -=> -=> -=> -=>md ff000000 -ff000000: 27051956 70706362 6f6f7420 302e382e '..Vppcboot 0.8. -ff000010: 3320284d 61792031 31203230 3031202d 3 (May 11 2001 - -ff000020: 2031343a 35373a30 33290000 00000000 14:57:03)...... -ff000030: 00000000 00000000 00000000 00000000 ................ -ff000040: 00000000 00000000 00000000 00000000 ................ -ff000050: 00000000 00000000 00000000 00000000 ................ -ff000060: 00000000 00000000 00000000 00000000 ................ -ff000070: 00000000 00000000 00000000 00000000 ................ -ff000080: 00000000 00000000 00000000 00000000 ................ -ff000090: 00000000 00000000 00000000 00000000 ................ -ff0000a0: 00000000 00000000 00000000 00000000 ................ -ff0000b0: 00000000 00000000 00000000 00000000 ................ -ff0000c0: 00000000 00000000 00000000 00000000 ................ -ff0000d0: 00000000 00000000 00000000 00000000 ................ -ff0000e0: 00000000 00000000 00000000 00000000 ................ -ff0000f0: 00000000 00000000 00000000 00000000 ................ -=>erase ff000000 ff007fff -Erase Flash from 0xff000000 to 0xff007fff - done -Erased 1 sectors -=>md ff000000 -ff000000: ffffffff ffffffff ffffffff ffffffff ................ -ff000010: ffffffff ffffffff ffffffff ffffffff ................ -ff000020: ffffffff ffffffff ffffffff ffffffff ................ -ff000030: ffffffff ffffffff ffffffff ffffffff ................ -ff000040: ffffffff ffffffff ffffffff ffffffff ................ -ff000050: ffffffff ffffffff ffffffff ffffffff ................ -ff000060: ffffffff ffffffff ffffffff ffffffff ................ -ff000070: ffffffff ffffffff ffffffff ffffffff ................ -ff000080: ffffffff ffffffff ffffffff ffffffff ................ -ff000090: ffffffff ffffffff ffffffff ffffffff ................ -ff0000a0: ffffffff ffffffff ffffffff ffffffff ................ -ff0000b0: ffffffff ffffffff ffffffff ffffffff ................ -ff0000c0: ffffffff ffffffff ffffffff ffffffff ................ -ff0000d0: ffffffff ffffffff ffffffff ffffffff ................ -ff0000e0: ffffffff ffffffff ffffffff ffffffff ................ -ff0000f0: ffffffff ffffffff ffffffff ffffffff ................ -=> - -x.x.x Information - - -ppcboot 0.9.2 (May 13 2001 - 17:56:46) - -Initializing... - CPU: MPC8240 Revsion 1.1 at 247 MHz: 16 kB I-Cache 16 kB D-Cache - Board: CU824 Revision 1 Local Bus at 99 MHz - DRAM: 64 MB - FLASH: 16 MB - In: serial - Out: serial - Err: serial - -Hit any key to stop autoboot: 0 -=> -=> -=> -=> -=>flinfo - -Bank # 1: Intel: 28F160F3B (16Mbit) - Size: 8 MB in 39 Sectors - Sector Start Addresses: - FF000000 FF008000 (RO) FF010000 FF018000 FF020000 - FF028000 FF030000 FF038000 FF040000 FF080000 - FF0C0000 FF100000 FF140000 FF180000 FF1C0000 - FF200000 FF240000 FF280000 FF2C0000 FF300000 - FF340000 FF380000 FF3C0000 FF400000 FF440000 - FF480000 FF4C0000 FF500000 FF540000 FF580000 - FF5C0000 FF600000 FF640000 FF680000 FF6C0000 - FF700000 FF740000 FF780000 FF7C0000 - -Bank # 2: Intel: 28F160F3B (16Mbit) - Size: 8 MB in 39 Sectors - Sector Start Addresses: - FF800000 FF808000 FF810000 FF818000 FF820000 - FF828000 FF830000 FF838000 FF840000 FF880000 - FF8C0000 FF900000 FF940000 FF980000 FF9C0000 - FFA00000 FFA40000 FFA80000 FFAC0000 FFB00000 - FFB40000 FFB80000 FFBC0000 FFC00000 FFC40000 - FFC80000 FFCC0000 FFD00000 FFD40000 FFD80000 - FFDC0000 FFE00000 FFE40000 FFE80000 FFEC0000 - FFF00000 (RO) FFF40000 FFF80000 FFFC0000 -=> - -x.x.x Flash Programming - - -ppcboot 0.9.2 (May 13 2001 - 17:56:46) - -Initializing... - CPU: MPC8240 Revsion 1.1 at 247 MHz: 16 kB I-Cache 16 kB D-Cache - Board: CU824 Revision 1 Local Bus at 99 MHz - DRAM: 64 MB - FLASH: 16 MB - In: serial - Out: serial - Err: serial - -Hit any key to stop autoboot: 0 -=> -=> -=> -=> -=>cp 0 ff000000 20 -Copy to Flash... done -=>md 0 -00000000: 0ec08ce0 03f9800c 00000001 040c0000 ................ -00000010: 00000001 03fd1aa0 03fd1ae4 03fd1a00 ................ -00000020: 03fd1a58 03fceb04 03fd34cc 03fd34d0 ...X......4...4. -00000030: 03fcd5bc 03fcdabc 00000000 00000000 ................ -00000040: 00000000 00000000 00000000 00000000 ................ -00000050: 00000000 00000000 00000000 00000000 ................ -00000060: 00000000 00000000 00000000 00000000 ................ -00000070: 00000000 00000000 00000000 00000000 ................ -00000080: 00000000 00000000 00000000 00000000 ................ -00000090: 00000000 00000000 00000000 00000000 ................ -000000a0: 00000000 00000000 00000000 00000000 ................ -000000b0: 00000000 00000000 00000000 00000000 ................ -000000c0: 00000000 00000000 00000000 00000000 ................ -000000d0: 00000000 00000000 00000000 00000000 ................ -000000e0: 00000000 00000000 00000000 00000000 ................ -000000f0: 00000000 00000000 00000000 00000000 ................ -=>md ff000000 -ff000000: 0ec08ce0 03f9800c 00000001 040c0000 ................ -ff000010: 00000001 03fd1aa0 03fd1ae4 03fd1a00 ................ -ff000020: 03fd1a58 03fceb04 03fd34cc 03fd34d0 ...X......4...4. -ff000030: 03fcd5bc 03fcdabc 00000000 00000000 ................ -ff000040: 00000000 00000000 00000000 00000000 ................ -ff000050: 00000000 00000000 00000000 00000000 ................ -ff000060: 00000000 00000000 00000000 00000000 ................ -ff000070: 00000000 00000000 00000000 00000000 ................ -ff000080: ffffffff ffffffff ffffffff ffffffff ................ -ff000090: ffffffff ffffffff ffffffff ffffffff ................ -ff0000a0: ffffffff ffffffff ffffffff ffffffff ................ -ff0000b0: ffffffff ffffffff ffffffff ffffffff ................ -ff0000c0: ffffffff ffffffff ffffffff ffffffff ................ -ff0000d0: ffffffff ffffffff ffffffff ffffffff ................ -ff0000e0: ffffffff ffffffff ffffffff ffffffff ................ -ff0000f0: ffffffff ffffffff ffffffff ffffffff ................ -=> - -x.x.x Storage of environment variables in flash - - -ppcboot 0.9.2 (May 13 2001 - 17:56:46) - -Initializing... - CPU: MPC8240 Revsion 1.1 at 247 MHz: 16 kB I-Cache 16 kB D-Cache - Board: CU824 Revision 1 Local Bus at 99 MHz - DRAM: 64 MB - FLASH: 16 MB - In: serial - Out: serial - Err: serial - -Hit any key to stop autoboot: 0 -=> -=>printenv -bootargs= -bootcmd=bootm FE020000 -bootdelay=5 -baudrate=9600 -ipaddr=192.168.4.2 -serverip=192.168.4.1 -ethaddr=00:40:42:01:00:a0 -stdin=serial -stdout=serial -stderr=serial - -Environment size: 167/32764 bytes -=>setenv myvar 1234 -=>save_env -Un-Protected 1 sectors -Erasing Flash... - done -Erased 1 sectors -Saving Environment to Flash... -Protected 1 sectors -=>reset - - -ppcboot 0.9.2 (May 13 2001 - 17:56:46) - -Initializing... - CPU: MPC8240 Revsion 1.1 at 247 MHz: 16 kB I-Cache 16 kB D-Cache - Board: CU824 Revision 1 Local Bus at 99 MHz - DRAM: 64 MB - FLASH: 16 MB - In: serial - Out: serial - Err: serial - -Hit any key to stop autoboot: 0 -=> -=>printenv -bootargs= -bootcmd=bootm FE020000 -bootdelay=5 -baudrate=9600 -ipaddr=192.168.4.2 -serverip=192.168.4.1 -ethaddr=00:40:42:01:00:a0 -myvar=1234 -stdin=serial -stdout=serial -stderr=serial - -Environment size: 178/32764 bytes -=> - -x.x Image Download and run over serial port - - -ppcboot 0.9.2 (May 13 2001 - 17:56:46) - -Initializing... - CPU: MPC8240 Revsion 1.1 at 247 MHz: 16 kB I-Cache 16 kB D-Cache - Board: CU824 Revision 1 Local Bus at 99 MHz - DRAM: 64 MB - FLASH: 16 MB - In: serial - Out: serial - Err: serial - -Hit any key to stop autoboot: 0 -=> -=> -=>mw 40000 0 10000 -=>md 40000 -00040000: 00000000 00000000 00000000 00000000 ................ -00040010: 00000000 00000000 00000000 00000000 ................ -00040020: 00000000 00000000 00000000 00000000 ................ -00040030: 00000000 00000000 00000000 00000000 ................ -00040040: 00000000 00000000 00000000 00000000 ................ -00040050: 00000000 00000000 00000000 00000000 ................ -00040060: 00000000 00000000 00000000 00000000 ................ -00040070: 00000000 00000000 00000000 00000000 ................ -00040080: 00000000 00000000 00000000 00000000 ................ -00040090: 00000000 00000000 00000000 00000000 ................ -000400a0: 00000000 00000000 00000000 00000000 ................ -000400b0: 00000000 00000000 00000000 00000000 ................ -000400c0: 00000000 00000000 00000000 00000000 ................ -000400d0: 00000000 00000000 00000000 00000000 ................ -000400e0: 00000000 00000000 00000000 00000000 ................ -000400f0: 00000000 00000000 00000000 00000000 ................ -=>loads -## Ready for S-Record download ... - -(Back at xpert.denx.de) -[vlad@xpert vlad]$ cat hello_world.srec >/dev/ttyS0 -[vlad@xpert vlad]$ kermit -l /dev/ttyS0 -b 9600 -c -Connecting to /dev/ttyS0, speed 9600. -The escape character is Ctrl-\ (ASCII 28, FS) -Type the escape character followed by C to get back, -or followed by ? to see other options. -md 40000 -00040000: 00018148 9421ffe0 7c0802a6 bf61000c ...H.!..|....a.. -00040010: 90010024 48000005 7fc802a6 801effe8 ...$H........... -00040020: 7fc0f214 7c7f1b78 813f0038 7c9c2378 ....|..x.?.8|.#x -00040030: 807e8000 7cbd2b78 80090010 3b600000 .~..|.+x....;`.. -00040040: 7c0803a6 4e800021 813f0038 7f84e378 |...N..!.?.8...x -00040050: 807e8004 80090010 7c0803a6 4e800021 .~......|...N..! -00040060: 7c1be000 4181003c 80bd0000 813f0038 |...A..<.....?.8 -00040070: 3bbd0004 2c050000 40820008 80be8008 ;...,...@....... -00040080: 80090010 7f64db78 807e800c 3b7b0001 .....d.x.~..;{.. -00040090: 7c0803a6 4e800021 7c1be000 4081ffcc |...N..!|...@... -000400a0: 813f0038 807e8010 80090010 7c0803a6 .?.8.~......|... -000400b0: 4e800021 813f0038 80090004 7c0803a6 N..!.?.8....|... -000400c0: 4e800021 2c030000 4182ffec 813f0038 N..!,...A....?.8 -000400d0: 80090000 7c0803a6 4e800021 813f0038 ....|...N..!.?.8 -000400e0: 807e8014 80090010 7c0803a6 4e800021 .~......|...N..! -000400f0: 38600000 80010024 7c0803a6 bb61000c 8`.....$|....a.. -=>go 40004 -## Starting application at 0x00040004 ... -Hello World -argc = 1 -argv[0] = "40004" -argv[1] = "<NULL>" -Hit any key to exit ... - -## Application terminated, rc = 0x0 -=> - -x.x Image download and run over ethernet interface - - -ppcboot 0.9.2 (May 13 2001 - 17:56:46) - -Initializing... - CPU: MPC8240 Revsion 1.1 at 247 MHz: 16 kB I-Cache 16 kB D-Cache - Board: CU824 Revision 1 Local Bus at 99 MHz - DRAM: 64 MB - FLASH: 16 MB - In: serial - Out: serial - Err: serial - -Hit any key to stop autoboot: 0 -=> -=> -=>mw 40000 0 10000 -=>md 40000 -00040000: 00000000 00000000 00000000 00000000 ................ -00040010: 00000000 00000000 00000000 00000000 ................ -00040020: 00000000 00000000 00000000 00000000 ................ -00040030: 00000000 00000000 00000000 00000000 ................ -00040040: 00000000 00000000 00000000 00000000 ................ -00040050: 00000000 00000000 00000000 00000000 ................ -00040060: 00000000 00000000 00000000 00000000 ................ -00040070: 00000000 00000000 00000000 00000000 ................ -00040080: 00000000 00000000 00000000 00000000 ................ -00040090: 00000000 00000000 00000000 00000000 ................ -000400a0: 00000000 00000000 00000000 00000000 ................ -000400b0: 00000000 00000000 00000000 00000000 ................ -000400c0: 00000000 00000000 00000000 00000000 ................ -000400d0: 00000000 00000000 00000000 00000000 ................ -000400e0: 00000000 00000000 00000000 00000000 ................ -000400f0: 00000000 00000000 00000000 00000000 ................ -=>tftpboot 40000 hello_world.bin -ARP broadcast 1 -TFTP from server 192.168.4.1; our IP address is 192.168.4.2 -Filename 'hello_world.bin'. -Load address: 0x40000 -Loading: ############# -done -Bytes transferred = 65912 (10178 hex) -=>md 40000 -00040000: 00018148 9421ffe0 7c0802a6 bf61000c ...H.!..|....a.. -00040010: 90010024 48000005 7fc802a6 801effe8 ...$H........... -00040020: 7fc0f214 7c7f1b78 813f0038 7c9c2378 ....|..x.?.8|.#x -00040030: 807e8000 7cbd2b78 80090010 3b600000 .~..|.+x....;`.. -00040040: 7c0803a6 4e800021 813f0038 7f84e378 |...N..!.?.8...x -00040050: 807e8004 80090010 7c0803a6 4e800021 .~......|...N..! -00040060: 7c1be000 4181003c 80bd0000 813f0038 |...A..<.....?.8 -00040070: 3bbd0004 2c050000 40820008 80be8008 ;...,...@....... -00040080: 80090010 7f64db78 807e800c 3b7b0001 .....d.x.~..;{.. -00040090: 7c0803a6 4e800021 7c1be000 4081ffcc |...N..!|...@... -000400a0: 813f0038 807e8010 80090010 7c0803a6 .?.8.~......|... -000400b0: 4e800021 813f0038 80090004 7c0803a6 N..!.?.8....|... -000400c0: 4e800021 2c030000 4182ffec 813f0038 N..!,...A....?.8 -000400d0: 80090000 7c0803a6 4e800021 813f0038 ....|...N..!.?.8 -000400e0: 807e8014 80090010 7c0803a6 4e800021 .~......|...N..! -000400f0: 38600000 80010024 7c0803a6 bb61000c 8`.....$|....a.. -=>go 40004 -## Starting application at 0x00040004 ... -Hello World -argc = 1 -argv[0] = "40004" -argv[1] = "<NULL>" -Hit any key to exit ... - -## Application terminated, rc = 0x0 -=> diff --git a/board/cu824/cu824.c b/board/cu824/cu824.c deleted file mode 100644 index 6b23c53..0000000 --- a/board/cu824/cu824.c +++ /dev/null @@ -1,83 +0,0 @@ -/* - * (C) Copyright 2001 - * Rob Taylor, Flying Pig Systems. robt@flyingpig.com. - * - * (C) Copyright 2001-2006 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de - - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc824x.h> -#include <asm/processor.h> -#include <pci.h> -#include <netdev.h> - -DECLARE_GLOBAL_DATA_PTR; - -#define BOARD_REV_REG 0xFE80002B - -int checkboard (void) -{ - char revision = *(volatile char *)(BOARD_REV_REG); - char buf[32]; - - puts ("Board: CU824 "); - printf("Revision %d ", revision); - printf("Local Bus at %s MHz\n", strmhz(buf, gd->bus_clk)); - - return 0; -} - -phys_size_t initdram(int board_type) -{ - long size; - long new_bank0_end; - long mear1; - long emear1; - - size = get_ram_size(CONFIG_SYS_SDRAM_BASE, CONFIG_SYS_MAX_RAM_SIZE); - - new_bank0_end = size - 1; - mear1 = mpc824x_mpc107_getreg(MEAR1); - emear1 = mpc824x_mpc107_getreg(EMEAR1); - mear1 = (mear1 & 0xFFFFFF00) | - ((new_bank0_end & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT); - emear1 = (emear1 & 0xFFFFFF00) | - ((new_bank0_end & MICR_ADDR_MASK) >> MICR_EADDR_SHIFT); - mpc824x_mpc107_setreg(MEAR1, mear1); - mpc824x_mpc107_setreg(EMEAR1, emear1); - - return (size); -} - -/* - * Initialize PCI Devices, report devices found. - */ -#ifndef CONFIG_PCI_PNP -static struct pci_config_table pci_sandpoint_config_table[] = { - { PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, 0x0f, PCI_ANY_ID, - pci_cfgfunc_config_device, { PCI_ENET0_IOADDR, - PCI_ENET0_MEMADDR, - PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER }}, - - { } -}; -#endif - -struct pci_controller hose = { -#ifndef CONFIG_PCI_PNP - config_table: pci_sandpoint_config_table, -#endif -}; - -void pci_init_board(void) -{ - pci_mpc824x_init(&hose); -} - -int board_eth_init(bd_t *bis) -{ - return pci_eth_init(bis); -} diff --git a/board/cu824/flash.c b/board/cu824/flash.c deleted file mode 100644 index 3a6d954..0000000 --- a/board/cu824/flash.c +++ /dev/null @@ -1,470 +0,0 @@ -/* - * (C) Copyright 2001 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc824x.h> -#include <asm/processor.h> - -#if defined(CONFIG_ENV_IS_IN_FLASH) -# ifndef CONFIG_ENV_ADDR -# define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET) -# endif -# ifndef CONFIG_ENV_SIZE -# define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -# endif -# ifndef CONFIG_ENV_SECT_SIZE -# define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE -# endif -#endif - -#define FLASH_BANK_SIZE 0x800000 -#define MAIN_SECT_SIZE 0x40000 -#define PARAM_SECT_SIZE 0x8000 - -#define BOARD_CTRL_REG 0xFE800013 - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; - -static int write_data (flash_info_t *info, ulong dest, ulong *data); -static void write_via_fpu(vu_long *addr, ulong *data); -static __inline__ unsigned long get_msr(void); -static __inline__ void set_msr(unsigned long msr); - -/*---------------------------------------------------------------------*/ -#undef DEBUG_FLASH - -/*---------------------------------------------------------------------*/ -#ifdef DEBUG_FLASH -#define DEBUGF(fmt,args...) printf(fmt ,##args) -#else -#define DEBUGF(fmt,args...) -#endif -/*---------------------------------------------------------------------*/ - -/*----------------------------------------------------------------------- - */ - -unsigned long flash_init(void) -{ - int i, j; - ulong size = 0; - volatile unsigned char *bcr = (volatile unsigned char *)(BOARD_CTRL_REG); - - DEBUGF("Write protect was: 0x%02X\n", *bcr); - *bcr &= 0x1; /* FWPT must be 0 */ - *bcr |= 0x6; /* FWP0 = FWP1 = 1 */ - DEBUGF("Write protect is: 0x%02X\n", *bcr); - - for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; i++) { - vu_long *addr = (vu_long *)(CONFIG_SYS_FLASH_BASE + i * FLASH_BANK_SIZE); - - addr[0] = 0x00900090; - - DEBUGF ("Flash bank # %d:\n" - "\tManuf. ID @ 0x%08lX: 0x%08lX\n" - "\tDevice ID @ 0x%08lX: 0x%08lX\n", - i, - (ulong)(&addr[0]), addr[0], - (ulong)(&addr[2]), addr[2]); - - if ((addr[0] == addr[1]) && (addr[0] == INTEL_MANUFACT) && - (addr[2] == addr[3]) && (addr[2] == INTEL_ID_28F160F3B)) - { - flash_info[i].flash_id = (FLASH_MAN_INTEL & FLASH_VENDMASK) | - (INTEL_ID_28F160F3B & FLASH_TYPEMASK); - } else { - flash_info[i].flash_id = FLASH_UNKNOWN; - addr[0] = 0xFFFFFFFF; - goto Done; - } - - DEBUGF ("flash_id = 0x%08lX\n", flash_info[i].flash_id); - - addr[0] = 0xFFFFFFFF; - - flash_info[i].size = FLASH_BANK_SIZE; - flash_info[i].sector_count = CONFIG_SYS_MAX_FLASH_SECT; - memset(flash_info[i].protect, 0, CONFIG_SYS_MAX_FLASH_SECT); - for (j = 0; j < flash_info[i].sector_count; j++) { - if (j <= 7) { - flash_info[i].start[j] = CONFIG_SYS_FLASH_BASE + - i * FLASH_BANK_SIZE + - j * PARAM_SECT_SIZE; - } else { - flash_info[i].start[j] = CONFIG_SYS_FLASH_BASE + - i * FLASH_BANK_SIZE + - (j - 7)*MAIN_SECT_SIZE; - } - } - size += flash_info[i].size; - } - - /* Protect monitor and environment sectors - */ -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE + FLASH_BANK_SIZE - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE + monitor_flash_len - 1, - &flash_info[1]); -#else - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE + monitor_flash_len - 1, - &flash_info[0]); -#endif -#endif - -#if defined(CONFIG_ENV_IS_IN_FLASH) && defined(CONFIG_ENV_ADDR) -#if CONFIG_ENV_ADDR >= CONFIG_SYS_FLASH_BASE + FLASH_BANK_SIZE - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR + CONFIG_ENV_SIZE - 1, - &flash_info[1]); -#else - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR + CONFIG_ENV_SIZE - 1, - &flash_info[0]); -#endif -#endif - -Done: - return size; -} - -/*----------------------------------------------------------------------- - */ -void flash_print_info (flash_info_t * info) -{ - int i; - - switch ((i = info->flash_id & FLASH_VENDMASK)) { - case (FLASH_MAN_INTEL & FLASH_VENDMASK): - printf ("Intel: "); - break; - default: - printf ("Unknown Vendor 0x%04x ", i); - break; - } - - switch ((i = info->flash_id & FLASH_TYPEMASK)) { - case (INTEL_ID_28F160F3B & FLASH_TYPEMASK): - printf ("28F160F3B (16Mbit)\n"); - break; - default: - printf ("Unknown Chip Type 0x%04x\n", i); - goto Done; - break; - } - - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); - - printf (" Sector Start Addresses:"); - for (i = 0; i < info->sector_count; i++) { - if ((i % 5) == 0) { - printf ("\n "); - } - printf (" %08lX%s", info->start[i], - info->protect[i] ? " (RO)" : " "); - } - printf ("\n"); - -Done: - return; -} - -/*----------------------------------------------------------------------- - */ - -int flash_erase (flash_info_t *info, int s_first, int s_last) -{ - int flag, prot, sect; - ulong start, now, last; - - DEBUGF ("Erase flash bank %d sect %d ... %d\n", - info - &flash_info[0], s_first, s_last); - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - if ((info->flash_id & FLASH_VENDMASK) != - (FLASH_MAN_INTEL & FLASH_VENDMASK)) { - printf ("Can erase only Intel flash types - aborted\n"); - return 1; - } - - prot = 0; - for (sect=s_first; sect<=s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - printf ("\n"); - } - - start = get_timer (0); - last = start; - /* Start erase on unprotected sectors */ - for (sect = s_first; sect<=s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - vu_long *addr = (vu_long *)(info->start[sect]); - - DEBUGF ("Erase sect %d @ 0x%08lX\n", - sect, (ulong)addr); - - /* Disable interrupts which might cause a timeout - * here. - */ - flag = disable_interrupts(); - - addr[0] = 0x00500050; /* clear status register */ - addr[0] = 0x00200020; /* erase setup */ - addr[0] = 0x00D000D0; /* erase confirm */ - - addr[1] = 0x00500050; /* clear status register */ - addr[1] = 0x00200020; /* erase setup */ - addr[1] = 0x00D000D0; /* erase confirm */ - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - - while (((addr[0] & 0x00800080) != 0x00800080) || - ((addr[1] & 0x00800080) != 0x00800080) ) { - if ((now=get_timer(start)) > - CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - addr[0] = 0x00B000B0; /* suspend erase */ - addr[0] = 0x00FF00FF; /* to read mode */ - return 1; - } - - /* show that we're waiting */ - if ((now - last) > 1000) { /* every second */ - putc ('.'); - last = now; - } - } - - addr[0] = 0x00FF00FF; - } - } - printf (" done\n"); - return 0; -} - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - * 4 - Flash not identified - */ - -#define FLASH_WIDTH 8 /* flash bus width in bytes */ - -int write_buff (flash_info_t *info, uchar *src, ulong addr, ulong cnt) -{ - ulong wp, cp, msr; - int l, rc, i; - ulong data[2]; - ulong *datah = &data[0]; - ulong *datal = &data[1]; - - DEBUGF ("Flash write_buff: @ 0x%08lx, src 0x%08lx len %ld\n", - addr, (ulong)src, cnt); - - if (info->flash_id == FLASH_UNKNOWN) { - return 4; - } - - msr = get_msr(); - set_msr(msr | MSR_FP); - - wp = (addr & ~(FLASH_WIDTH-1)); /* get lower aligned address */ - - /* - * handle unaligned start bytes - */ - if ((l = addr - wp) != 0) { - *datah = *datal = 0; - - for (i = 0, cp = wp; i < l; i++, cp++) { - if (i >= 4) { - *datah = (*datah << 8) | - ((*datal & 0xFF000000) >> 24); - } - - *datal = (*datal << 8) | (*(uchar *)cp); - } - for (; i < FLASH_WIDTH && cnt > 0; ++i) { - char tmp; - - tmp = *src; - - src++; - - if (i >= 4) { - *datah = (*datah << 8) | - ((*datal & 0xFF000000) >> 24); - } - - *datal = (*datal << 8) | tmp; - - --cnt; ++cp; - } - - for (; cnt == 0 && i < FLASH_WIDTH; ++i, ++cp) { - if (i >= 4) { - *datah = (*datah << 8) | - ((*datal & 0xFF000000) >> 24); - } - - *datal = (*datah << 8) | (*(uchar *)cp); - } - - if ((rc = write_data(info, wp, data)) != 0) { - set_msr(msr); - return (rc); - } - - wp += FLASH_WIDTH; - } - - /* - * handle FLASH_WIDTH aligned part - */ - while (cnt >= FLASH_WIDTH) { - *datah = *(ulong *)src; - *datal = *(ulong *)(src + 4); - if ((rc = write_data(info, wp, data)) != 0) { - set_msr(msr); - return (rc); - } - wp += FLASH_WIDTH; - cnt -= FLASH_WIDTH; - src += FLASH_WIDTH; - } - - if (cnt == 0) { - set_msr(msr); - return (0); - } - - /* - * handle unaligned tail bytes - */ - *datah = *datal = 0; - for (i = 0, cp = wp; i < FLASH_WIDTH && cnt > 0; ++i, ++cp) { - char tmp; - - tmp = *src; - - src++; - - if (i >= 4) { - *datah = (*datah << 8) | ((*datal & 0xFF000000) >> 24); - } - - *datal = (*datal << 8) | tmp; - - --cnt; - } - - for (; i < FLASH_WIDTH; ++i, ++cp) { - if (i >= 4) { - *datah = (*datah << 8) | ((*datal & 0xFF000000) >> 24); - } - - *datal = (*datal << 8) | (*(uchar *)cp); - } - - rc = write_data(info, wp, data); - set_msr(msr); - - return (rc); -} - -/*----------------------------------------------------------------------- - * Write a word to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_data (flash_info_t *info, ulong dest, ulong *data) -{ - vu_long *addr = (vu_long *)dest; - ulong start; - int flag; - - /* Check if Flash is (sufficiently) erased */ - if (((addr[0] & data[0]) != data[0]) || - ((addr[1] & data[1]) != data[1]) ) { - return (2); - } - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - addr[0] = 0x00400040; /* write setup */ - write_via_fpu(addr, data); - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - start = get_timer (0); - - while (((addr[0] & 0x00800080) != 0x00800080) || - ((addr[1] & 0x00800080) != 0x00800080) ) { - if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - addr[0] = 0x00FF00FF; /* restore read mode */ - return (1); - } - } - - addr[0] = 0x00FF00FF; /* restore read mode */ - - return (0); -} - -/*----------------------------------------------------------------------- - */ -static void write_via_fpu(vu_long *addr, ulong *data) -{ - __asm__ __volatile__ ("lfd 1, 0(%0)" : : "r" (data)); - __asm__ __volatile__ ("stfd 1, 0(%0)" : : "r" (addr)); -} -/*----------------------------------------------------------------------- - */ -static __inline__ unsigned long get_msr(void) -{ - unsigned long msr; - - __asm__ __volatile__ ("mfmsr %0" : "=r" (msr) :); - return msr; -} - -static __inline__ void set_msr(unsigned long msr) -{ - __asm__ __volatile__ ("mtmsr %0" : : "r" (msr)); -} diff --git a/board/eXalion/Kconfig b/board/eXalion/Kconfig deleted file mode 100644 index a22f58a..0000000 --- a/board/eXalion/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_EXALION - -config SYS_BOARD - default "eXalion" - -config SYS_CONFIG_NAME - default "eXalion" - -endif diff --git a/board/eXalion/MAINTAINERS b/board/eXalion/MAINTAINERS deleted file mode 100644 index 0ea74ca..0000000 --- a/board/eXalion/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -EXALION BOARD -M: Torsten Demke torsten.demke@fci.com -S: Maintained -F: board/eXalion/ -F: include/configs/eXalion.h -F: configs/eXalion_defconfig diff --git a/board/eXalion/Makefile b/board/eXalion/Makefile deleted file mode 100644 index 9192e28..0000000 --- a/board/eXalion/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2001-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = eXalion.o diff --git a/board/eXalion/eXalion.c b/board/eXalion/eXalion.c deleted file mode 100644 index 304ff21..0000000 --- a/board/eXalion/eXalion.c +++ /dev/null @@ -1,283 +0,0 @@ -/* - * (C) Copyright 2000-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * (C) Copyright 2002 - * Torsten Demke, FORCE Computers GmbH. torsten.demke@fci.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc824x.h> -#include <asm/processor.h> -#include <asm/io.h> -#include <pci.h> -#include <ide.h> -#include <netdev.h> -#include <timestamp.h> -#include "piix_pci.h" -#include "eXalion.h" - -int checkboard (void) -{ - ulong busfreq = get_bus_freq (0); - char buf[32]; - - printf ("Board: eXalion MPC824x - CHRP (MAP B)\n"); - printf ("Built: %s at %s\n", U_BOOT_DATE, U_BOOT_TIME); - printf ("Local Bus: %s MHz\n", strmhz (buf, busfreq)); - - return 0; -} - -int checkflash (void) -{ - printf ("checkflash\n"); - flash_init (); - return (0); -} - -phys_size_t initdram (int board_type) -{ - int i, cnt; - volatile uchar *base = CONFIG_SYS_SDRAM_BASE; - volatile ulong *addr; - ulong save[32]; - ulong val, ret = 0; - - for (i = 0, cnt = (CONFIG_SYS_MAX_RAM_SIZE / sizeof (long)) >> 1; cnt > 0; - cnt >>= 1) { - addr = (volatile ulong *) base + cnt; - save[i++] = *addr; - *addr = ~cnt; - } - - addr = (volatile ulong *) base; - save[i] = *addr; - *addr = 0; - - if (*addr != 0) { - *addr = save[i]; - goto Done; - } - - for (cnt = 1; cnt <= CONFIG_SYS_MAX_RAM_SIZE / sizeof (long); cnt <<= 1) { - addr = (volatile ulong *) base + cnt; - val = *addr; - *addr = save[--i]; - if (val != ~cnt) { - ulong new_bank0_end = cnt * sizeof (long) - 1; - ulong mear1 = mpc824x_mpc107_getreg (MEAR1); - ulong emear1 = mpc824x_mpc107_getreg (EMEAR1); - - mear1 = (mear1 & 0xFFFFFF00) | - ((new_bank0_end & MICR_ADDR_MASK) >> - MICR_ADDR_SHIFT); - emear1 = (emear1 & 0xFFFFFF00) | - ((new_bank0_end & MICR_ADDR_MASK) >> - MICR_EADDR_SHIFT); - mpc824x_mpc107_setreg (MEAR1, mear1); - mpc824x_mpc107_setreg (EMEAR1, emear1); - - ret = cnt * sizeof (long); - goto Done; - } - } - - ret = CONFIG_SYS_MAX_RAM_SIZE; - Done: - return ret; -} - -int misc_init_r (void) -{ - pci_dev_t bdf; - u32 val32; - u8 val8; - - puts ("ISA: "); - bdf = pci_find_device (PIIX4_VENDOR_ID, PIIX4_ISA_DEV_ID, 0); - if (bdf == -1) { - puts ("Unable to find PIIX4 ISA bridge !\n"); - hang (); - } - - /* set device for normal ISA instead EIO */ - pci_read_config_dword (bdf, PCI_CFG_PIIX4_GENCFG, &val32); - val32 |= 0x00000001; - pci_write_config_dword (bdf, PCI_CFG_PIIX4_GENCFG, val32); - printf ("PIIX4 ISA bridge (%d,%d,%d)\n", PCI_BUS (bdf), - PCI_DEV (bdf), PCI_FUNC (bdf)); - - puts ("ISA: "); - bdf = pci_find_device (PIIX4_VENDOR_ID, PIIX4_IDE_DEV_ID, 0); - if (bdf == -1) { - puts ("Unable to find PIIX4 IDE controller !\n"); - hang (); - } - - /* Init BMIBA register */ - /* pci_read_config_dword(bdf, PCI_CFG_PIIX4_BMIBA, &val32); */ - /* val32 |= 0x1000; */ - /* pci_write_config_dword(bdf, PCI_CFG_PIIX4_BMIBA, val32); */ - - /* Enable BUS master and IO access */ - val32 = PCI_COMMAND_MASTER | PCI_COMMAND_IO; - pci_write_config_dword (bdf, PCI_COMMAND, val32); - - /* Set latency */ - pci_read_config_byte (bdf, PCI_LATENCY_TIMER, &val8); - val8 = 0x40; - pci_write_config_byte (bdf, PCI_LATENCY_TIMER, val8); - - /* Enable Primary ATA/IDE */ - pci_read_config_dword (bdf, PCI_CFG_PIIX4_IDETIM, &val32); - /* val32 = 0xa307a307; */ - val32 = 0x00008000; - pci_write_config_dword (bdf, PCI_CFG_PIIX4_IDETIM, val32); - - - printf ("PIIX4 IDE controller (%d,%d,%d)\n", PCI_BUS (bdf), - PCI_DEV (bdf), PCI_FUNC (bdf)); - - /* Try to get FAT working... */ - /* fat_register_read(ide_read); */ - - - return (0); -} - -/* - * Show/Init PCI devices on the specified bus number. - */ - -void pci_eXalion_fixup_irq (struct pci_controller *hose, pci_dev_t dev) -{ - unsigned char line; - - switch (PCI_DEV (dev)) { - case 16: - line = PCI_INT_A; - break; - case 17: - line = PCI_INT_B; - break; - case 18: - line = PCI_INT_C; - break; - case 19: - line = PCI_INT_D; - break; -#if defined (CONFIG_MPC8245) - case 20: - line = PCI_INT_A; - break; - case 21: - line = PCI_INT_B; - break; - case 22: - line = PCI_INT_NA; - break; -#endif - default: - line = PCI_INT_A; - break; - } - pci_hose_write_config_byte (hose, dev, PCI_INTERRUPT_LINE, line); -} - - -/* - * Initialize PCI Devices, report devices found. - */ -#ifndef CONFIG_PCI_PNP -#if defined (CONFIG_MPC8240) -static struct pci_config_table pci_eXalion_config_table[] = { - { - /* Intel 82559ER ethernet controller */ - PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, 0x00, 18, 0x00, - pci_cfgfunc_config_device, {PCI_ENET0_IOADDR, - PCI_ENET0_MEMADDR, - PCI_COMMAND_MEMORY | - PCI_COMMAND_MASTER}}, - { - /* Intel 82371AB PIIX4 PCI to ISA bridge */ - PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, 0x00, 20, 0x00, - pci_cfgfunc_config_device, {0, - 0, - PCI_COMMAND_IO | PCI_COMMAND_MASTER}}, - { - /* Intel 82371AB PIIX4 IDE controller */ - PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, 0x00, 20, 0x01, - pci_cfgfunc_config_device, {0, - 0, - PCI_COMMAND_IO | PCI_COMMAND_MASTER}}, - {} -}; -#elif defined (CONFIG_MPC8245) -static struct pci_config_table pci_eXalion_config_table[] = { - { - /* Intel 82559ER ethernet controller */ - PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, 0x00, 17, 0x00, - pci_cfgfunc_config_device, {PCI_ENET0_IOADDR, - PCI_ENET0_MEMADDR, - PCI_COMMAND_MEMORY | - PCI_COMMAND_MASTER}}, - { - /* Intel 82559ER ethernet controller */ - PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, 0x00, 18, 0x00, - pci_cfgfunc_config_device, {PCI_ENET1_IOADDR, - PCI_ENET1_MEMADDR, - PCI_COMMAND_MEMORY | - PCI_COMMAND_MASTER}}, - { - /* Broadcom BCM5690 Gigabit switch */ - PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, 0x00, 20, 0x00, - pci_cfgfunc_config_device, {PCI_ENET2_IOADDR, - PCI_ENET2_MEMADDR, - PCI_COMMAND_MEMORY | - PCI_COMMAND_MASTER}}, - { - /* Broadcom BCM5690 Gigabit switch */ - PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, 0x00, 21, 0x00, - pci_cfgfunc_config_device, {PCI_ENET3_IOADDR, - PCI_ENET3_MEMADDR, - PCI_COMMAND_MEMORY | - PCI_COMMAND_MASTER}}, - { - /* Intel 82371AB PIIX4 PCI to ISA bridge */ - PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, 0x00, 22, 0x00, - pci_cfgfunc_config_device, {0, - 0, - PCI_COMMAND_IO | PCI_COMMAND_MASTER}}, - { - /* Intel 82371AB PIIX4 IDE controller */ - PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, 0x00, 22, 0x01, - pci_cfgfunc_config_device, {0, - 0, - PCI_COMMAND_IO | PCI_COMMAND_MASTER}}, - {} -}; -#else -#error Specific type of MPC824x must be defined (i.e. CONFIG_MPC8240) -#endif - -#endif /* #ifndef CONFIG_PCI_PNP */ - -struct pci_controller hose = { -#ifndef CONFIG_PCI_PNP - config_table:pci_eXalion_config_table, - fixup_irq:pci_eXalion_fixup_irq, -#endif -}; - -void pci_init_board (void) -{ - pci_mpc824x_init (&hose); -} - -int board_eth_init(bd_t *bis) -{ - return pci_eth_init(bis); -} diff --git a/board/eXalion/eXalion.h b/board/eXalion/eXalion.h deleted file mode 100644 index 7804f4f..0000000 --- a/board/eXalion/eXalion.h +++ /dev/null @@ -1,36 +0,0 @@ -/* - * (C) Copyright 2002 - * Torsten Demke, FORCE Computers GmbH. torsten.demke@fci.com - * - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * (C) Copyright 2002 - * James Dougherty (jfd@broadcom.com) - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __EXALION_H -#define __EXALION_H - -/* IRQ settings */ -#define PCI_INT_NA (0xff) /* PCI Intr. not used */ -#define PCI_INT_A (0x09) /* PCI Intr. A Interrupt Request Line Nr. */ -#define PCI_INT_B (0x0a) /* PCI Intr. B Interrupt Request Line Nr. */ -#define PCI_INT_C (0x0b) /* PCI Intr. C Interrupt Request Line Nr. */ -#define PCI_INT_D (0x0c) /* PCI Intr. D Interrupt Request Line Nr. */ -#if defined (CPU_MPC8245) -#define LN_1_INT PCI_INT_B /* ethernet interrupt level */ -#define LN_2_INT PCI_INT_C /* ethernet interrupt level */ -#define BCM_1_INT PCI_INT_A /* BCM5690 interrupt level */ -#define BCM_2_INT PCI_INT_B /* BCM5690 interrupt level */ -#elif defined (CPU_MPC8240) -#define BCM_INT PCI_INT_B /* BCM5600 interrupt level */ -#define LN_INT PCI_INT_C /* ethernet interrupt level */ -#endif - -#ifndef __ASSEMBLY__ -#endif /* !__ASSEMBLY__ */ - -#endif /* __EXALION_H */ diff --git a/board/eXalion/piix_pci.h b/board/eXalion/piix_pci.h deleted file mode 100644 index 21c636f..0000000 --- a/board/eXalion/piix_pci.h +++ /dev/null @@ -1,156 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * (C) Copyright 2002 - * Torsten Demke, FORCE Computers GmbH. torsten.demke@fci.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ -#ifndef _PIIX4_PCI_H -#define _PIIX4_PCI_H - -#include <common.h> -#include <mpc824x.h> -#include <asm/processor.h> -#include <asm/io.h> -#include <pci.h> - -#define PIIX4_VENDOR_ID 0x8086 -#define PIIX4_ISA_DEV_ID 0x7110 -#define PIIX4_IDE_DEV_ID 0x7111 - -/* Function 0 ISA Bridge */ -#define PCI_CFG_PIIX4_IORT 0x4C /* 8 bit ISA Recovery Timer Reg (default 0x4D) */ -#define PCI_CFG_PIIX4_XBCS 0x4E /* 16 bit XBus Chip select reg (default 0x0003) */ -#define PCI_CFG_PIIX4_PIRQC 0x60 /* PCI IRQ Route Register 4 x 8bit (default )*/ -#define PCI_CFG_PIIX4_SERIRQ 0x64 -#define PCI_CFG_PIIX4_TOM 0x69 -#define PCI_CFG_PIIX4_MSTAT 0x6A -#define PCI_CFG_PIIX4_MBDMA 0x76 -#define PCI_CFG_PIIX4_APICBS 0x80 -#define PCI_CFG_PIIX4_DLC 0x82 -#define PCI_CFG_PIIX4_PDMACFG 0x90 -#define PCI_CFG_PIIX4_DDMABS 0x92 -#define PCI_CFG_PIIX4_GENCFG 0xB0 -#define PCI_CFG_PIIX4_RTCCFG 0xCB - -/* IO Addresses */ -#define PIIX4_ISA_DMA1_CH0BA 0x00 -#define PIIX4_ISA_DMA1_CH0CA 0x01 -#define PIIX4_ISA_DMA1_CH1BA 0x02 -#define PIIX4_ISA_DMA1_CH1CA 0x03 -#define PIIX4_ISA_DMA1_CH2BA 0x04 -#define PIIX4_ISA_DMA1_CH2CA 0x05 -#define PIIX4_ISA_DMA1_CH3BA 0x06 -#define PIIX4_ISA_DMA1_CH3CA 0x07 -#define PIIX4_ISA_DMA1_CMDST 0x08 -#define PIIX4_ISA_DMA1_REQ 0x09 -#define PIIX4_ISA_DMA1_WSBM 0x0A -#define PIIX4_ISA_DMA1_CH_MOD 0x0B -#define PIIX4_ISA_DMA1_CLR_PT 0x0C -#define PIIX4_ISA_DMA1_M_CLR 0x0D -#define PIIX4_ISA_DMA1_CLR_M 0x0E -#define PIIX4_ISA_DMA1_RWAMB 0x0F - -#define PIIX4_ISA_DMA2_CH0BA 0xC0 -#define PIIX4_ISA_DMA2_CH0CA 0xC1 -#define PIIX4_ISA_DMA2_CH1BA 0xC2 -#define PIIX4_ISA_DMA2_CH1CA 0xC3 -#define PIIX4_ISA_DMA2_CH2BA 0xC4 -#define PIIX4_ISA_DMA2_CH2CA 0xC5 -#define PIIX4_ISA_DMA2_CH3BA 0xC6 -#define PIIX4_ISA_DMA2_CH3CA 0xC7 -#define PIIX4_ISA_DMA2_CMDST 0xD0 -#define PIIX4_ISA_DMA2_REQ 0xD2 -#define PIIX4_ISA_DMA2_WSBM 0xD4 -#define PIIX4_ISA_DMA2_CH_MOD 0xD6 -#define PIIX4_ISA_DMA2_CLR_PT 0xD8 -#define PIIX4_ISA_DMA2_M_CLR 0xDA -#define PIIX4_ISA_DMA2_CLR_M 0xDC -#define PIIX4_ISA_DMA2_RWAMB 0xDE - -#define PIIX4_ISA_INT1_ICW1 0x20 -#define PIIX4_ISA_INT1_OCW2 0x20 -#define PIIX4_ISA_INT1_OCW3 0x20 -#define PIIX4_ISA_INT1_ICW2 0x21 -#define PIIX4_ISA_INT1_ICW3 0x21 -#define PIIX4_ISA_INT1_ICW4 0x21 -#define PIIX4_ISA_INT1_OCW1 0x21 - -#define PIIX4_ISA_INT1_ELCR 0x4D0 - -#define PIIX4_ISA_INT2_ICW1 0xA0 -#define PIIX4_ISA_INT2_OCW2 0xA0 -#define PIIX4_ISA_INT2_OCW3 0xA0 -#define PIIX4_ISA_INT2_ICW2 0xA1 -#define PIIX4_ISA_INT2_ICW3 0xA1 -#define PIIX4_ISA_INT2_ICW4 0xA1 -#define PIIX4_ISA_INT2_OCW1 0xA1 -#define PIIX4_ISA_INT2_IMR 0xA1 /* read only */ - -#define PIIX4_ISA_INT2_ELCR 0x4D1 - -#define PIIX4_ISA_TMR0_CNT_ST 0x40 -#define PIIX4_ISA_TMR1_CNT_ST 0x41 -#define PIIX4_ISA_TMR2_CNT_ST 0x42 -#define PIIX4_ISA_TMR_TCW 0x43 - -#define PIIX4_ISA_RST_XBUS 0x60 - -#define PIIX4_ISA_NMI_CNT_ST 0x61 -#define PIIX4_ISA_NMI_ENABLE 0x70 - -#define PIIX4_ISA_RTC_INDEX 0x70 -#define PIIX4_ISA_RTC_DATA 0x71 -#define PIIX4_ISA_RTCEXT_IND 0x70 -#define PIIX4_ISA_RTCEXT_DATA 0x71 - -#define PIIX4_ISA_DMA1_CH2LPG 0x81 -#define PIIX4_ISA_DMA1_CH3LPG 0x82 -#define PIIX4_ISA_DMA1_CH1LPG 0x83 -#define PIIX4_ISA_DMA1_CH0LPG 0x87 -#define PIIX4_ISA_DMA2_CH2LPG 0x89 -#define PIIX4_ISA_DMA2_CH3LPG 0x8A -#define PIIX4_ISA_DMA2_CH1LPG 0x8B -#define PIIX4_ISA_DMA2_LPGRFR 0x8F - -#define PIIX4_ISA_PORT_92 0x92 - -#define PIIX4_ISA_APM_CONTRL 0xB2 -#define PIIX4_ISA_APM_STATUS 0xB3 - -#define PIIX4_ISA_COCPU_ERROR 0xF0 - -/* Function 1 IDE Controller */ -#define PCI_CFG_PIIX4_BMIBA 0x20 -#define PCI_CFG_PIIX4_IDETIM 0x40 -#define PCI_CFG_PIIX4_SIDETIM 0x44 -#define PCI_CFG_PIIX4_UDMACTL 0x48 -#define PCI_CFG_PIIX4_UDMATIM 0x4A - -/* Function 2 USB Controller */ -#define PCI_CFG_PIIX4_SBRNUM 0x60 -#define PCI_CFG_PIIX4_LEGSUP 0xC0 - -/* Function 3 Power Management */ -#define PCI_CFG_PIIX4_PMAB 0x40 -#define PCI_CFG_PIIX4_CNTA 0x44 -#define PCI_CFG_PIIX4_CNTB 0x48 -#define PCI_CFG_PIIX4_GPICTL 0x4C -#define PCI_CFG_PIIX4_DEVRESD 0x50 -#define PCI_CFG_PIIX4_DEVACTA 0x54 -#define PCI_CFG_PIIX4_DEVACTB 0x58 -#define PCI_CFG_PIIX4_DEVRESA 0x5C -#define PCI_CFG_PIIX4_DEVRESB 0x60 -#define PCI_CFG_PIIX4_DEVRESC 0x64 -#define PCI_CFG_PIIX4_DEVRESE 0x68 -#define PCI_CFG_PIIX4_DEVRESF 0x6C -#define PCI_CFG_PIIX4_DEVRESG 0x70 -#define PCI_CFG_PIIX4_DEVRESH 0x74 -#define PCI_CFG_PIIX4_DEVRESI 0x78 -#define PCI_CFG_PIIX4_PMMISC 0x80 -#define PCI_CFG_PIIX4_SMBBA 0x90 - - -#endif /* _PIIX4_PCI_H */ diff --git a/board/musenki/Kconfig b/board/musenki/Kconfig deleted file mode 100644 index 26b680f..0000000 --- a/board/musenki/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_MUSENKI - -config SYS_BOARD - default "musenki" - -config SYS_CONFIG_NAME - default "MUSENKI" - -endif diff --git a/board/musenki/MAINTAINERS b/board/musenki/MAINTAINERS deleted file mode 100644 index 4196c80..0000000 --- a/board/musenki/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -MUSENKI BOARD -#M: Jim Thompson jim@musenki.com -S: Orphan (since 2014-04) -F: board/musenki/ -F: include/configs/MUSENKI.h -F: configs/MUSENKI_defconfig diff --git a/board/musenki/Makefile b/board/musenki/Makefile deleted file mode 100644 index d2b79ff..0000000 --- a/board/musenki/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2001-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = musenki.o flash.o diff --git a/board/musenki/README b/board/musenki/README deleted file mode 100644 index 084ab54..0000000 --- a/board/musenki/README +++ /dev/null @@ -1,298 +0,0 @@ -U-Boot for a Musenki M-3/M-1 board ---------------------------- - -Musenki M-1 and M-3 have two banks of flash of 4MB or 8MB each. - -In board's notation, bank 0 is the one at the address of 0xFF800000 -and bank 1 is the one at the address of 0xFF000000. - -On power-up the processor jumps to the address of 0xFFF00100, the last -megabyte of the bank 0 of flash. - -Thus, U-Boot is configured to reside in flash starting at the address of -0xFFF00000. The environment space is located in flash separately from -U-Boot, at the address of 0xFF800000. - -There is a Davicom 9102A on-board, but I don't have it working yet. - -U-Boot test results --------------------- - -x.x Operation on all available serial consoles - -x.x.x CONFIG_CONS_INDEX 1 - - -U-Boot 1.1.1 (Nov 20 2001 - 15:55:32) - -CPU: MPC8245 Revision 16.20 at 250 MHz: 16 kB I-Cache 16 kB D-Cache -Board: MUSENKI Local Bus at 100 MHz -DRAM: 32 MB -FLASH: 4 MB -In: serial -Out: serial -Err: serial -Hit any key to stop autoboot: 0 -=> help -base - print or set address offset -bdinfo - print Board Info structure -bootm - boot application image from memory -bootp - boot image via network using BootP/TFTP protocol -bootd - boot default, i.e., run 'bootcmd' -cmp - memory compare -coninfo - print console devices and informations -cp - memory copy -crc32 - checksum calculation -dcache - enable or disable data cache -echo - echo args to console -erase - erase FLASH memory -flinfo - print FLASH memory information -go - start application at address 'addr' -help - print online help -icache - enable or disable instruction cache -iminfo - print header information for application image -loadb - load binary file over serial line (kermit mode) -loads - load S-Record file over serial line -loop - infinite loop on address range -md - memory display -mm - memory modify (auto-incrementing) -mtest - simple RAM test -mw - memory write (fill) -nm - memory modify (constant address) -printenv- print environment variables -protect - enable or disable FLASH write protection -rarpboot- boot image via network using RARP/TFTP protocol -reset - Perform RESET of the CPU -run - run commands in an environment variable -saveenv - save environment variables to persistent storage -setenv - set environment variables -source - run script from memory -tftpboot- boot image via network using TFTP protocol - and env variables ipaddr and serverip -version - print monitor version -? - alias for 'help' - - -x.x.x CONFIG_CONS_INDEX 2 - -**** NOT TESTED **** - -x.x Flash Driver Operation - - -Boot 1.1.1 (Nov 20 2001 - 15:55:32) - -CPU: MPC8245 Revision 16.20 at 250 MHz: 16 kB I-Cache 16 kB D-Cache -Board: MUSENKI Local Bus at 100 MHz -DRAM: 32 MB -FLASH: 4 MB -*** Warning - bad CRC, using default environment - -In: serial -Out: serial -Err: serial -Hit any key to stop autoboot: 0 -=> -=> md ff800000 -ff800000: 46989bf8 626f6f74 636d643d 626f6f74 F...bootcmd=boot -ff800010: 6d204646 38323030 30300062 6f6f7464 m FF820000.bootd -ff800020: 656c6179 3d350062 61756472 6174653d elay=5.baudrate= -ff800030: 39363030 00636c6f 636b735f 696e5f6d 9600.clocks_in_m -ff800040: 687a3d31 00737464 696e3d73 65726961 hz=1.stdin=seria -ff800050: 6c007374 646f7574 3d736572 69616c00 l.stdout=serial. -ff800060: 73746465 72723d73 65726961 6c006970 stderr=serial.ip -ff800070: 61646472 3d313932 2e313638 2e302e34 addr=192.168.0.4 -ff800080: 32007365 72766572 69703d31 39322e31 2.serverip=192.1 -ff800090: 36382e30 2e380000 00000000 00000000 68.0.8.......... -ff8000a0: 00000000 00000000 00000000 00000000 ................ -ff8000b0: 00000000 00000000 00000000 00000000 ................ -ff8000c0: 00000000 00000000 00000000 00000000 ................ -ff8000d0: 00000000 00000000 00000000 00000000 ................ -ff8000e0: 00000000 00000000 00000000 00000000 ................ -ff8000f0: 00000000 00000000 00000000 00000000 ................ -=> protect off ff800000 ff81ffff -Un-Protected 1 sectors -=> erase ff800000 ff81ffff -Erase Flash from 0xff800000 to 0xff81ffff - done -Erased 1 sectors -=> md ff800000 -ff800000: ffffffff ffffffff ffffffff ffffffff ................ -ff800010: ffffffff ffffffff ffffffff ffffffff ................ -ff800020: ffffffff ffffffff ffffffff ffffffff ................ -ff800030: ffffffff ffffffff ffffffff ffffffff ................ -ff800040: ffffffff ffffffff ffffffff ffffffff ................ -ff800050: ffffffff ffffffff ffffffff ffffffff ................ -ff800060: ffffffff ffffffff ffffffff ffffffff ................ -ff800070: ffffffff ffffffff ffffffff ffffffff ................ -ff800080: ffffffff ffffffff ffffffff ffffffff ................ -ff800090: ffffffff ffffffff ffffffff ffffffff ................ -ff8000a0: ffffffff ffffffff ffffffff ffffffff ................ -ff8000b0: ffffffff ffffffff ffffffff ffffffff ................ -ff8000c0: ffffffff ffffffff ffffffff ffffffff ................ -ff8000d0: ffffffff ffffffff ffffffff ffffffff ................ -ff8000e0: ffffffff ffffffff ffffffff ffffffff ................ -ff8000f0: ffffffff ffffffff ffffffff ffffffff ................ - -x.x.x Information - - -U-Boot 1.1.1 (Nov 20 2001 - 15:55:32) - -CPU: MPC8245 Revision 16.20 at 250 MHz: 16 kB I-Cache 16 kB D-Cache -Board: MUSENKI Local Bus at 100 MHz -DRAM: 32 MB -FLASH: 4 MB -*** Warning - bad CRC, using default environment - -In: serial -Out: serial -Err: serial -Hit any key to stop autoboot: 0 -=> flinfo - -Bank # 1: Intel 28F320J3A (32Mbit = 128K x 32) - Size: 4 MB in 32 Sectors - Sector Start Addresses: - FF800000 (RO) FF820000 FF840000 FF860000 FF880000 - FF8A0000 FF8C0000 FF8E0000 FF900000 FF920000 - FF940000 FF960000 FF980000 FF9A0000 FF9C0000 - FF9E0000 FFA00000 FFA20000 FFA40000 FFA60000 - FFA80000 FFAA0000 FFAC0000 FFAE0000 FFB00000 - FFB20000 FFB40000 FFB60000 FFB80000 FFBA0000 - FFBC0000 FFBE0000 - -Bank # 2: missing or unknown FLASH type -=> - - -x.x.x Flash Programming - - -U-Boot 1.1.1 (Nov 20 2001 - 15:55:32) - -CPU: MPC8245 Revision 16.20 at 250 MHz: 16 kB I-Cache 16 kB D-Cache -Board: MUSENKI Local Bus at 100 MHz -DRAM: 32 MB -FLASH: 4 MB - -In: serial -Out: serial -Err: serial -Hit any key to stop autoboot: 0 -=> -=> -=> -=> protect off ff800000 ff81ffff -Un-Protected 1 sectors -=> cp 0 ff800000 20 -Copy to Flash... done -=> md ff800000 -ff800000: 37ce33ec 33cc334c 33c031cc 33cc35cc 7.3.3.3L3.1.3.5. -ff800010: 33ec13ce 30ccb3ec b3c833c4 31c836cc 3...0.....3.1.6. -ff800020: 33cc3b9d 31ec33ee 13ecf3cc 338833ec 3.;.1.3.....3.3. -ff800030: 234c33ec 32cc22cc 33883bdc 534433cc #L3.2.".3.;.SD3. -ff800040: 33cc30c8 31cc32ec 338c33cc 330c33dc 3.0.1.2.3.3.3.3. -ff800050: 33cc13dc 334c534c b1c433d8 128c13cc 3...3LSL..3..... -ff800060: 37ec36cd 33dc33cc bbc9f7e8 bbcc77cc 7.6.3.3.......w. -ff800070: 314c0adc 139c30ed 33cc334c 33c833ec 1L....0.3.3L3.3. -ff800080: ffffffff ffffffff ffffffff ffffffff ................ -ff800090: ffffffff ffffffff ffffffff ffffffff ................ -ff8000a0: ffffffff ffffffff ffffffff ffffffff ................ -ff8000b0: ffffffff ffffffff ffffffff ffffffff ................ -ff8000c0: ffffffff ffffffff ffffffff ffffffff ................ -ff8000d0: ffffffff ffffffff ffffffff ffffffff ................ -ff8000e0: ffffffff ffffffff ffffffff ffffffff ................ -ff8000f0: ffffffff ffffffff ffffffff ffffffff ................ - - -x.x.x Storage of environment variables in flash - - -U-Boot 1.1.1 (Nov 20 2001 - 15:55:32) - -CPU: MPC8245 Revision 16.20 at 250 MHz: 16 kB I-Cache 16 kB D-Cache -Board: MUSENKI Local Bus at 100 MHz -DRAM: 32 MB -FLASH: 4 MB -In: serial -Out: serial -Err: serial -Hit any key to stop autoboot: 0 -=> printenv -bootcmd=bootm FF820000 -bootdelay=5 -baudrate=9600 -clocks_in_mhz=1 -stdin=serial -stdout=serial -stderr=serial - -Environment size: 106/16380 bytes -=> setenv myvar 1234 -=> saveenv -Un-Protected 1 sectors -Erasing Flash... - done -Erased 1 sectors -Saving Environment to Flash... -Protected 1 sectors -=> reset - - -U-Boot 1.1.1 (Nov 20 2001 - 15:55:32) - -CPU: MPC8245 Revision 16.20 at 250 MHz: 16 kB I-Cache 16 kB D-Cache -Board: MUSENKI Local Bus at 100 MHz -DRAM: 32 MB -FLASH: 4 MB -In: serial -Out: serial -Err: serial -Hit any key to stop autoboot: 0 -=> printenv -bootcmd=bootm FF820000 -bootdelay=5 -baudrate=9600 -clocks_in_mhz=1 -myvar=1234 -stdin=serial -stdout=serial -stderr=serial - -Environment size: 117/16380 bytes - -x.x Image Download and run over serial port - - -U-Boot 1.1.1 (Nov 20 2001 - 15:55:32) - -CPU: MPC8245 Revision 16.20 at 250 MHz: 16 kB I-Cache 16 kB D-Cache -Board: MUSENKI Local Bus at 100 MHz -DRAM: 32 MB -FLASH: 4 MB -In: serial -Out: serial -Err: serial -Hit any key to stop autoboot: 0 -=> loads -## Ready for S-Record download ... - -## First Load Addr = 0x00040000 -## Last Load Addr = 0x00050177 -## Total Size = 0x00010178 = 65912 Bytes -## Start Addr = 0x00040004 -=> go 40004 -## Starting application at 0x00040004 ... -Hello World -argc = 1 -argv[0] = "40004" -argv[1] = "<NULL>" -Hit any key to exit ... - -## Application terminated, rc = 0x0 - - -x.x Image download and run over ethernet interface - -untested (not working yet, actually) diff --git a/board/musenki/flash.c b/board/musenki/flash.c deleted file mode 100644 index 080ec7f..0000000 --- a/board/musenki/flash.c +++ /dev/null @@ -1,496 +0,0 @@ -/* - * (C) Copyright 2001 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc824x.h> - -#if defined(CONFIG_ENV_IS_IN_FLASH) -# ifndef CONFIG_ENV_ADDR -# define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET) -# endif -# ifndef CONFIG_ENV_SIZE -# define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -# endif -# ifndef CONFIG_ENV_SECT_SIZE -# define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE -# endif -#endif - -/*---------------------------------------------------------------------*/ -#undef DEBUG_FLASH - -#ifdef DEBUG_FLASH -#define DEBUGF(fmt,args...) printf(fmt ,##args) -#else -#define DEBUGF(fmt,args...) -#endif -/*---------------------------------------------------------------------*/ - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH chips */ - -/*----------------------------------------------------------------------- - * Functions - */ -static ulong flash_get_size (vu_char *addr, flash_info_t *info); -static int write_data (flash_info_t *info, uchar *dest, uchar data); -static void flash_get_offsets (ulong base, flash_info_t *info); - - -/* - * don't ask. its stupid, but more than one soul has had to live with this mistake - * "swaptab[i]" is the value of "i" with the bits reversed. - */ - -#define MUSENKI_BROKEN_FLASH 1 - -#ifdef MUSENKI_BROKEN_FLASH -unsigned char swaptab[256] = { - 0x00, 0x80, 0x40, 0xc0, 0x20, 0xa0, 0x60, 0xe0, - 0x10, 0x90, 0x50, 0xd0, 0x30, 0xb0, 0x70, 0xf0, - 0x08, 0x88, 0x48, 0xc8, 0x28, 0xa8, 0x68, 0xe8, - 0x18, 0x98, 0x58, 0xd8, 0x38, 0xb8, 0x78, 0xf8, - 0x04, 0x84, 0x44, 0xc4, 0x24, 0xa4, 0x64, 0xe4, - 0x14, 0x94, 0x54, 0xd4, 0x34, 0xb4, 0x74, 0xf4, - 0x0c, 0x8c, 0x4c, 0xcc, 0x2c, 0xac, 0x6c, 0xec, - 0x1c, 0x9c, 0x5c, 0xdc, 0x3c, 0xbc, 0x7c, 0xfc, - 0x02, 0x82, 0x42, 0xc2, 0x22, 0xa2, 0x62, 0xe2, - 0x12, 0x92, 0x52, 0xd2, 0x32, 0xb2, 0x72, 0xf2, - 0x0a, 0x8a, 0x4a, 0xca, 0x2a, 0xaa, 0x6a, 0xea, - 0x1a, 0x9a, 0x5a, 0xda, 0x3a, 0xba, 0x7a, 0xfa, - 0x06, 0x86, 0x46, 0xc6, 0x26, 0xa6, 0x66, 0xe6, - 0x16, 0x96, 0x56, 0xd6, 0x36, 0xb6, 0x76, 0xf6, - 0x0e, 0x8e, 0x4e, 0xce, 0x2e, 0xae, 0x6e, 0xee, - 0x1e, 0x9e, 0x5e, 0xde, 0x3e, 0xbe, 0x7e, 0xfe, - 0x01, 0x81, 0x41, 0xc1, 0x21, 0xa1, 0x61, 0xe1, - 0x11, 0x91, 0x51, 0xd1, 0x31, 0xb1, 0x71, 0xf1, - 0x09, 0x89, 0x49, 0xc9, 0x29, 0xa9, 0x69, 0xe9, - 0x19, 0x99, 0x59, 0xd9, 0x39, 0xb9, 0x79, 0xf9, - 0x05, 0x85, 0x45, 0xc5, 0x25, 0xa5, 0x65, 0xe5, - 0x15, 0x95, 0x55, 0xd5, 0x35, 0xb5, 0x75, 0xf5, - 0x0d, 0x8d, 0x4d, 0xcd, 0x2d, 0xad, 0x6d, 0xed, - 0x1d, 0x9d, 0x5d, 0xdd, 0x3d, 0xbd, 0x7d, 0xfd, - 0x03, 0x83, 0x43, 0xc3, 0x23, 0xa3, 0x63, 0xe3, - 0x13, 0x93, 0x53, 0xd3, 0x33, 0xb3, 0x73, 0xf3, - 0x0b, 0x8b, 0x4b, 0xcb, 0x2b, 0xab, 0x6b, 0xeb, - 0x1b, 0x9b, 0x5b, 0xdb, 0x3b, 0xbb, 0x7b, 0xfb, - 0x07, 0x87, 0x47, 0xc7, 0x27, 0xa7, 0x67, 0xe7, - 0x17, 0x97, 0x57, 0xd7, 0x37, 0xb7, 0x77, 0xf7, - 0x0f, 0x8f, 0x4f, 0xcf, 0x2f, 0xaf, 0x6f, 0xef, - 0x1f, 0x9f, 0x5f, 0xdf, 0x3f, 0xbf, 0x7f, 0xff, -}; - -#define BS(b) (swaptab[b]) - -#else - -#define BS(b) (b) - -#endif - -#define BYTEME(x) ((x) & 0xFF) - -/*----------------------------------------------------------------------- - */ - -unsigned long flash_init (void) -{ - unsigned long size_b0, size_b1; - int i; - - /* Init: no FLASHes known */ - for (i=0; i<CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - } - - /* Static FLASH Bank configuration here - FIXME XXX */ - - DEBUGF("\n## Get flash bank 1 size @ 0x%08x\n",CONFIG_SYS_FLASH_BASE0_PRELIM); - - size_b0 = flash_get_size((vu_char *)CONFIG_SYS_FLASH_BASE0_PRELIM, &flash_info[0]); - - if (flash_info[0].flash_id == FLASH_UNKNOWN) { - printf ("## Unknown FLASH on Bank 0: " - "ID 0x%lx, Size = 0x%08lx = %ld MB\n", - flash_info[0].flash_id, - size_b0, size_b0<<20); - } - - DEBUGF("## Get flash bank 2 size @ 0x%08x\n",CONFIG_SYS_FLASH_BASE1_PRELIM); - size_b1 = flash_get_size((vu_char *)CONFIG_SYS_FLASH_BASE1_PRELIM, &flash_info[1]); - - DEBUGF("## Prelim. Flash bank sizes: %08lx + 0x%08lx\n",size_b0,size_b1); - - flash_get_offsets (CONFIG_SYS_FLASH_BASE, &flash_info[0]); - - flash_info[0].size = size_b0; - -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE - DEBUGF("protect monitor %x @ %x\n", CONFIG_SYS_MONITOR_BASE, monitor_flash_len); - /* monitor protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE+monitor_flash_len-1, - &flash_info[0]); -#endif - -#ifdef CONFIG_ENV_IS_IN_FLASH - /* ENV protection ON by default */ - DEBUGF("protect environtment %x @ %x\n", CONFIG_ENV_ADDR, CONFIG_ENV_SECT_SIZE); - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR+CONFIG_ENV_SECT_SIZE-1, - &flash_info[0]); -#endif - - if (size_b1) { - flash_info[1].size = size_b1; - flash_get_offsets (CONFIG_SYS_FLASH_BASE + size_b0, &flash_info[1]); - -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE - /* monitor protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE+monitor_flash_len-1, - &flash_info[1]); -#endif - -#ifdef CONFIG_ENV_IS_IN_FLASH - /* ENV protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR+CONFIG_ENV_SECT_SIZE-1, - &flash_info[1]); -#endif - } else { - flash_info[1].flash_id = FLASH_UNKNOWN; - flash_info[1].sector_count = -1; - flash_info[1].size = 0; - } - - DEBUGF("## Final Flash bank sizes: %08lx + 0x%08lx\n",size_b0,size_b1); - - return (size_b0 + size_b1); -} - -/*----------------------------------------------------------------------- - */ -static void flash_get_offsets (ulong base, flash_info_t *info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_INTEL: - for (i = 0; i < info->sector_count; i++) { - info->start[i] = base; - base += 0x00020000; /* 128k per bank */ - } - return; - - default: - printf ("Don't know sector ofsets for flash type 0x%lx\n", info->flash_id); - return; - } -} - -/*----------------------------------------------------------------------- - */ -void flash_print_info (flash_info_t *info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_AMD: printf ("AMD "); break; - case FLASH_MAN_FUJ: printf ("Fujitsu "); break; - case FLASH_MAN_SST: printf ("SST "); break; - case FLASH_MAN_STM: printf ("STM "); break; - case FLASH_MAN_INTEL: printf ("Intel "); break; - case FLASH_MAN_MT: printf ("MT "); break; - default: printf ("Unknown Vendor "); break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_28F320J3A: printf ("28F320J3A (32Mbit = 128K x 32)\n"); - break; - case FLASH_28F640J3A: printf ("28F640J3A (64Mbit = 128K x 64)\n"); - break; - case FLASH_28F128J3A: printf ("28F128J3A (128Mbit = 128K x 128)\n"); - break; - default: printf ("Unknown Chip Type\n"); - break; - } - - if (info->size >= (1 << 20)) { - i = 20; - } else { - i = 10; - } - printf (" Size: %ld %cB in %d Sectors\n", - info->size >> i, - (i == 20) ? 'M' : 'k', - info->sector_count); - - printf (" Sector Start Addresses:"); - for (i=0; i<info->sector_count; ++i) { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", - info->start[i], - info->protect[i] ? " (RO)" : " " - ); - } - printf ("\n"); - return; -} - -/*----------------------------------------------------------------------- - */ - - -/*----------------------------------------------------------------------- - */ - -/* - * The following code cannot be run from FLASH! - */ -static ulong flash_get_size (vu_char *addr, flash_info_t *info) -{ - vu_char manuf, device; - - addr[0] = BS(0x90); - manuf = BS(addr[0]); - DEBUGF("Manuf. ID @ 0x%08lx: 0x%08x\n", (vu_char *)addr, manuf); - - switch (manuf) { - case BYTEME(AMD_MANUFACT): - info->flash_id = FLASH_MAN_AMD; - break; - case BYTEME(FUJ_MANUFACT): - info->flash_id = FLASH_MAN_FUJ; - break; - case BYTEME(SST_MANUFACT): - info->flash_id = FLASH_MAN_SST; - break; - case BYTEME(STM_MANUFACT): - info->flash_id = FLASH_MAN_STM; - break; - case BYTEME(INTEL_MANUFACT): - info->flash_id = FLASH_MAN_INTEL; - break; - default: - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - addr[0] = BS(0xFF); /* restore read mode, (yes, BS is a NOP) */ - return 0; /* no or unknown flash */ - } - - device = BS(addr[2]); /* device ID */ - - DEBUGF("Device ID @ 0x%08x: 0x%08x\n", (&addr[1]), device); - - switch (device) { - case BYTEME(INTEL_ID_28F320J3A): - info->flash_id += FLASH_28F320J3A; - info->sector_count = 32; - info->size = 0x00400000; - break; /* => 4 MB */ - - case BYTEME(INTEL_ID_28F640J3A): - info->flash_id += FLASH_28F640J3A; - info->sector_count = 64; - info->size = 0x00800000; - break; /* => 8 MB */ - - case BYTEME(INTEL_ID_28F128J3A): - info->flash_id += FLASH_28F128J3A; - info->sector_count = 128; - info->size = 0x01000000; - break; /* => 16 MB */ - - default: - info->flash_id = FLASH_UNKNOWN; - addr[0] = BS(0xFF); /* restore read mode (yes, a NOP) */ - return 0; /* => no or unknown flash */ - - } - - if (info->sector_count > CONFIG_SYS_MAX_FLASH_SECT) { - printf ("** ERROR: sector count %d > max (%d) **\n", - info->sector_count, CONFIG_SYS_MAX_FLASH_SECT); - info->sector_count = CONFIG_SYS_MAX_FLASH_SECT; - } - - addr[0] = BS(0xFF); /* restore read mode */ - - return (info->size); -} - - -/*----------------------------------------------------------------------- - */ - -int flash_erase (flash_info_t *info, int s_first, int s_last) -{ - int flag, prot, sect; - ulong start, now, last; - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - if ((info->flash_id & FLASH_VENDMASK) != FLASH_MAN_INTEL) { - printf ("Can erase only Intel flash types - aborted\n"); - return 1; - } - - prot = 0; - for (sect=s_first; sect<=s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", prot); - } else { - printf ("\n"); - } - - start = get_timer (0); - last = start; - /* Start erase on unprotected sectors */ - for (sect = s_first; sect<=s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - vu_char *addr = (vu_char *)(info->start[sect]); - unsigned long status; - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - *addr = BS(0x50); /* clear status register */ - *addr = BS(0x20); /* erase setup */ - *addr = BS(0xD0); /* erase confirm */ - - /* re-enable interrupts if necessary */ - if (flag) { - enable_interrupts(); - } - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - - while (((status = BS(*addr)) & BYTEME(0x00800080)) != BYTEME(0x00800080)) { - if ((now=get_timer(start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - *addr = BS(0xB0); /* suspend erase */ - *addr = BS(0xFF); /* reset to read mode */ - return 1; - } - - /* show that we're waiting */ - if ((now - last) > 1000) { /* every second */ - putc ('.'); - last = now; - } - } - - *addr = BS(0xFF); /* reset to read mode */ - } - } - printf (" done\n"); - return 0; -} - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - * 4 - Flash not identified - */ - -#define FLASH_WIDTH 1 /* flash bus width in bytes */ - -int write_buff (flash_info_t *info, uchar *src, ulong addr, ulong cnt) -{ - uchar *wp = (uchar *)addr; - int rc; - - if (info->flash_id == FLASH_UNKNOWN) { - return 4; - } - - while (cnt > 0) { - if ((rc = write_data(info, wp, *src)) != 0) { - return rc; - } - wp++; - src++; - cnt--; - } - - return cnt; -} - -/*----------------------------------------------------------------------- - * Write a word to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_data (flash_info_t *info, uchar *dest, uchar data) -{ - vu_char *addr = (vu_char *)dest; - ulong status; - ulong start; - int flag; - - /* Check if Flash is (sufficiently) erased */ - if ((BS(*addr) & data) != data) { - return 2; - } - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - *addr = BS(0x40); /* write setup */ - *addr = data; - - /* re-enable interrupts if necessary */ - if (flag) { - enable_interrupts(); - } - - start = get_timer (0); - - while (((status = BS(*addr)) & BYTEME(0x00800080)) != BYTEME(0x00800080)) { - if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - *addr = BS(0xFF); /* restore read mode */ - return 1; - } - } - - *addr = BS(0xFF); /* restore read mode */ - - return 0; -} - -/*----------------------------------------------------------------------- - */ diff --git a/board/musenki/musenki.c b/board/musenki/musenki.c deleted file mode 100644 index aa92fc4..0000000 --- a/board/musenki/musenki.c +++ /dev/null @@ -1,94 +0,0 @@ -/* - * (C) Copyright 2001 - * Rob Taylor, Flying Pig Systems. robt@flyingpig.com. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc824x.h> -#include <pci.h> -#include <netdev.h> - -int checkboard (void) -{ - ulong busfreq = get_bus_freq(0); - char buf[32]; - - printf("Board: MUSENKI Local Bus at %s MHz\n", strmhz(buf, busfreq)); - return 0; - -} - -#if 0 /* NOT USED */ -int checkflash (void) -{ - /* TODO: XXX XXX XXX */ - printf ("## Test not implemented yet ##\n"); - - return (0); -} -#endif - -phys_size_t initdram (int board_type) -{ - long size; - long new_bank0_end; - long mear1; - long emear1; - - size = get_ram_size(CONFIG_SYS_SDRAM_BASE, CONFIG_SYS_MAX_RAM_SIZE); - - new_bank0_end = size - 1; - mear1 = mpc824x_mpc107_getreg(MEAR1); - emear1 = mpc824x_mpc107_getreg(EMEAR1); - mear1 = (mear1 & 0xFFFFFF00) | - ((new_bank0_end & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT); - emear1 = (emear1 & 0xFFFFFF00) | - ((new_bank0_end & MICR_ADDR_MASK) >> MICR_EADDR_SHIFT); - mpc824x_mpc107_setreg(MEAR1, mear1); - mpc824x_mpc107_setreg(EMEAR1, emear1); - - return (size); -} - -/* - * Initialize PCI Devices - */ -#ifndef CONFIG_PCI_PNP -static struct pci_config_table pci_sandpoint_config_table[] = { -#if 0 - { PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, - 0x0, 0x0, 0x0, /* unknown eth0 divice */ - pci_cfgfunc_config_device, { PCI_ENET0_IOADDR, - PCI_ENET0_MEMADDR, - PCI_COMMAND_IO | - PCI_COMMAND_MEMORY | - PCI_COMMAND_MASTER }}, - { PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, - 0x0, 0x0, 0x0, /* unknown eth1 device */ - pci_cfgfunc_config_device, { PCI_ENET1_IOADDR, - PCI_ENET1_MEMADDR, - PCI_COMMAND_IO | - PCI_COMMAND_MEMORY | - PCI_COMMAND_MASTER }}, -#endif - { } -}; -#endif - -struct pci_controller hose = { -#ifndef CONFIG_PCI_PNP - config_table: pci_sandpoint_config_table, -#endif -}; - -void pci_init_board(void) -{ - pci_mpc824x_init(&hose); -} - -int board_eth_init(bd_t *bis) -{ - return pci_eth_init(bis); -} diff --git a/board/mvblue/Kconfig b/board/mvblue/Kconfig deleted file mode 100644 index cee206b..0000000 --- a/board/mvblue/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_MVBLUE - -config SYS_BOARD - default "mvblue" - -config SYS_CONFIG_NAME - default "MVBLUE" - -endif diff --git a/board/mvblue/MAINTAINERS b/board/mvblue/MAINTAINERS deleted file mode 100644 index 5955f1a..0000000 --- a/board/mvblue/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -MVBLUE BOARD -#M: - -S: Maintained -F: board/mvblue/ -F: include/configs/MVBLUE.h -F: configs/MVBLUE_defconfig diff --git a/board/mvblue/Makefile b/board/mvblue/Makefile deleted file mode 100644 index 76c10f8..0000000 --- a/board/mvblue/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2001-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = mvblue.o flash.o diff --git a/board/mvblue/flash.c b/board/mvblue/flash.c deleted file mode 100644 index 5dd658f..0000000 --- a/board/mvblue/flash.c +++ /dev/null @@ -1,570 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * (C) Copyright 2001-2003 - * - * Changes for MATRIX Vision mvBLUE devices - * MATRIX Vision GmbH / hg,as info@matrix-vision.de - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc824x.h> - -#if 0 - #define mvdebug(p) printf ##p -#else - #define mvdebug(p) -#endif - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; - -#define FLASH_BUS_WIDTH 8 - -#if (FLASH_BUS_WIDTH==32) - #define FLASH_DATA_MASK 0xffffffff - #define FLASH_SHIFT 1 - #define FDT vu_long -#elif (FLASH_BUS_WIDTH==16) - #define FLASH_DATA_MASK 0xff - #define FLASH_SHIFT 0 - #define FDT vu_short -#elif (FLASH_BUS_WIDTH==8) - #define FLASH_DATA_MASK 0xff - #define FLASH_SHIFT 0 - #define FDT vu_char -#else - #error FLASH_BUS_WIDTH undefined -#endif - -/*----------------------------------------------------------------------- - * Functions - */ -static ulong flash_get_size (vu_long *address, flash_info_t *info); -static int write_word (flash_info_t *info, ulong dest, ulong data); -static void flash_get_offsets (ulong base, flash_info_t *info); - -/*----------------------------------------------------------------------- - */ -unsigned long flash_init (void) -{ - unsigned long size_b0; - int i; - - for (i=0; i<CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - } - - size_b0 = flash_get_size((vu_long *)0xffc00000, &flash_info[0]); - - if (flash_info[0].flash_id == FLASH_UNKNOWN) { - printf ("## Unknown FLASH : Size = 0x%08lx = %ld MB\n", - size_b0, size_b0<<20); - } - - flash_get_offsets (0xffc00000, &flash_info[0]); - flash_info[0].size = size_b0; - - /* monitor protection OFF by default */ - flash_protect ( FLAG_PROTECT_CLEAR, 0xffc00000, 0x2000, flash_info ); - - return size_b0; -} - -/*----------------------------------------------------------------------- - */ -static void flash_get_offsets (ulong base, flash_info_t *info) -{ - int i; - - /* set up sector start address table */ - if (info->flash_id & FLASH_BTYPE) - { /* bottom boot sector types - these are the useful ones! */ - /* set sector offsets for bottom boot block type */ - if ((info->flash_id & FLASH_TYPEMASK) == FLASH_AM320B) - { /* AMDLV320B has 8 x 8k bottom boot sectors */ - for (i = 0; i < 8; i++) /* +8k */ - info->start[i] = base + (i * (0x00002000 << FLASH_SHIFT)); - for (; i < info->sector_count; i++) /* +64k */ - info->start[i] = base + (i * (0x00010000 << FLASH_SHIFT)) - (0x00070000 << FLASH_SHIFT); - } - else - { /* other types have 4 bottom boot sectors (16,8,8,32) */ - i = 0; - info->start[i++] = base + 0x00000000; /* - */ - info->start[i++] = base + (0x00004000 << FLASH_SHIFT); /* +16k */ - info->start[i++] = base + (0x00006000 << FLASH_SHIFT); /* +8k */ - info->start[i++] = base + (0x00008000 << FLASH_SHIFT); /* +8k */ - info->start[i++] = base + (0x00010000 << FLASH_SHIFT); /* +32k */ - for (; i < info->sector_count; i++) /* +64k */ - info->start[i] = base + (i * (0x00010000 << FLASH_SHIFT)) - (0x00030000 << FLASH_SHIFT); - } - } - else - { /* top boot sector types - not so useful */ - /* set sector offsets for top boot block type */ - if ((info->flash_id & FLASH_TYPEMASK) == FLASH_AM320T) - { /* AMDLV320T has 8 x 8k top boot sectors */ - for (i = 0; i < info->sector_count - 8; i++) /* +64k */ - info->start[i] = base + (i * (0x00010000 << FLASH_SHIFT)); - for (; i < info->sector_count; i++) /* +8k */ - info->start[i] = base + (i * (0x00002000 << FLASH_SHIFT)); - } - else - { /* other types have 4 top boot sectors (32,8,8,16) */ - for (i = 0; i < info->sector_count - 4; i++) /* +64k */ - info->start[i] = base + (i * (0x00010000 << FLASH_SHIFT)); - - info->start[i++] = base + info->size - (0x00010000 << FLASH_SHIFT); /* -32k */ - info->start[i++] = base + info->size - (0x00008000 << FLASH_SHIFT); /* -8k */ - info->start[i++] = base + info->size - (0x00006000 << FLASH_SHIFT); /* -8k */ - info->start[i] = base + info->size - (0x00004000 << FLASH_SHIFT); /* -16k */ - } - } -} - -/*----------------------------------------------------------------------- - */ -void flash_print_info (flash_info_t *info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_AMD: printf ("AMD "); break; - case FLASH_MAN_FUJ: printf ("FUJITSU "); break; - case FLASH_MAN_STM: printf ("ST "); break; - default: printf ("Unknown Vendor "); break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_AM160B: printf ("AM29LV160B (16 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM160T: printf ("AM29LV160T (16 Mbit, top boot sector)\n"); - break; - case FLASH_AM320B: printf ("AM29LV320B (32 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM320T: printf ("AM29LV320T (32 Mbit, top boot sector)\n"); - break; - case FLASH_STMW320DB: printf ("M29W320B (32 Mbit, bottom boot sect)\n"); - break; - case FLASH_STMW320DT: printf ("M29W320T (32 Mbit, top boot sector)\n"); - break; - default: printf ("Unknown Chip Type\n"); - break; - } - - printf (" Size: %ld MB in %d Sectors\n", info->size >> 20, info->sector_count); - - printf (" Sector Start Addresses:"); - for (i=0; i<info->sector_count; ++i) { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", info->start[i], info->protect[i] ? " (RO)" : " "); - } - printf ("\n"); -} - -/* - * The following code cannot be run from FLASH! - */ - -#define AMD_ID_LV160T_MVS (AMD_ID_LV160T & FLASH_DATA_MASK) -#define AMD_ID_LV160B_MVS (AMD_ID_LV160B & FLASH_DATA_MASK) -#define AMD_ID_LV320T_MVS (AMD_ID_LV320T & FLASH_DATA_MASK) -#define AMD_ID_LV320B_MVS (AMD_ID_LV320B & FLASH_DATA_MASK) -#define STM_ID_W320DT_MVS (STM_ID_29W320DT & FLASH_DATA_MASK) -#define STM_ID_W320DB_MVS (STM_ID_29W320DB & FLASH_DATA_MASK) -#define AMD_MANUFACT_MVS (AMD_MANUFACT & FLASH_DATA_MASK) -#define FUJ_MANUFACT_MVS (FUJ_MANUFACT & FLASH_DATA_MASK) -#define STM_MANUFACT_MVS (STM_MANUFACT & FLASH_DATA_MASK) - -#if (FLASH_BUS_WIDTH >= 16) - #define AUTOSELECT_ADDR1 0x0555 - #define AUTOSELECT_ADDR2 0x02AA - #define AUTOSELECT_ADDR3 AUTOSELECT_ADDR1 -#else - #define AUTOSELECT_ADDR1 0x0AAA - #define AUTOSELECT_ADDR2 0x0555 - #define AUTOSELECT_ADDR3 AUTOSELECT_ADDR1 -#endif - -#define AUTOSELECT_DATA1 (0x00AA00AA & FLASH_DATA_MASK) -#define AUTOSELECT_DATA2 (0x00550055 & FLASH_DATA_MASK) -#define AUTOSELECT_DATA3 (0x00900090 & FLASH_DATA_MASK) - -#define RESET_BANK_DATA (0x00F000F0 & FLASH_DATA_MASK) - - -static ulong flash_get_size (vu_long *address, flash_info_t *info) -{ - short i; - FDT value; - FDT *addr = (FDT *)address; - - ulong base = (ulong)address; - addr[AUTOSELECT_ADDR1] = AUTOSELECT_DATA1; - addr[AUTOSELECT_ADDR2] = AUTOSELECT_DATA2; - addr[AUTOSELECT_ADDR3] = AUTOSELECT_DATA3; - __asm__ __volatile__("sync"); - - udelay(180); - - value = addr[0]; /* manufacturer ID */ - switch (value) { - case AMD_MANUFACT_MVS: - info->flash_id = FLASH_MAN_AMD; - break; - case FUJ_MANUFACT_MVS: - info->flash_id = FLASH_MAN_FUJ; - break; - case STM_MANUFACT_MVS: - info->flash_id = FLASH_MAN_STM; - break; - default: - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - return (0); /* no or unknown flash */ - } -#if (FLASH_BUS_WIDTH >= 16) - value = addr[1]; /* device ID */ -#else - value = addr[2]; /* device ID */ -#endif - - switch (value) { - case AMD_ID_LV160T_MVS: - info->flash_id += FLASH_AM160T; - info->sector_count = 37; - info->size = (0x00200000 << FLASH_SHIFT); - break; /* => 2 or 4 MB */ - - case AMD_ID_LV160B_MVS: - info->flash_id += FLASH_AM160B; - info->sector_count = 37; - info->size = (0x00200000 << FLASH_SHIFT); - break; /* => 2 or 4 MB */ - - case AMD_ID_LV320T_MVS: - info->flash_id += FLASH_AM320T; - info->sector_count = 71; - info->size = (0x00400000 << FLASH_SHIFT); - break; /* => 4 or 8 MB */ - - case AMD_ID_LV320B_MVS: - info->flash_id += FLASH_AM320B; - info->sector_count = 71; - info->size = (0x00400000 << FLASH_SHIFT); - break; /* => 4 or 8MB */ - - case STM_ID_W320DT_MVS: - info->flash_id += FLASH_STMW320DT; - info->sector_count = 67; - info->size = (0x00400000 << FLASH_SHIFT); - break; /* => 4 or 8 MB */ - - case STM_ID_W320DB_MVS: - info->flash_id += FLASH_STMW320DB; - info->sector_count = 67; - info->size = (0x00400000 << FLASH_SHIFT); - break; /* => 4 or 8MB */ - - default: - info->flash_id = FLASH_UNKNOWN; - return (0); /* => no or unknown flash */ - - } - - /* set up sector start address table */ - flash_get_offsets (base, info); - - /* check for protected sectors */ - for (i = 0; i < info->sector_count; i++) { - /* read sector protection at sector address, (A7 .. A0) = 0x02 */ - /* D0 = 1 if protected */ - addr = (FDT *)(info->start[i]); - info->protect[i] = addr[2] & 1; - } - - /* - * Prevent writes to uninitialized FLASH. - */ - if (info->flash_id != FLASH_UNKNOWN) { - addr = (FDT *)info->start[0]; - *addr = RESET_BANK_DATA; /* reset bank */ - } - return (info->size); -} - - -/*----------------------------------------------------------------------- - */ - -#if (FLASH_BUS_WIDTH >= 16) - #define ERASE_ADDR1 0x0555 - #define ERASE_ADDR2 0x02AA -#else - #define ERASE_ADDR1 0x0AAA - #define ERASE_ADDR2 0x0555 -#endif - -#define ERASE_ADDR3 ERASE_ADDR1 -#define ERASE_ADDR4 ERASE_ADDR1 -#define ERASE_ADDR5 ERASE_ADDR2 - -#define ERASE_DATA1 (0x00AA00AA & FLASH_DATA_MASK) -#define ERASE_DATA2 (0x00550055 & FLASH_DATA_MASK) -#define ERASE_DATA3 (0x00800080 & FLASH_DATA_MASK) -#define ERASE_DATA4 ERASE_DATA1 -#define ERASE_DATA5 ERASE_DATA2 - -#define ERASE_SECTOR_DATA (0x00300030 & FLASH_DATA_MASK) -#define ERASE_CHIP_DATA (0x00100010 & FLASH_DATA_MASK) -#define ERASE_CONFIRM_DATA (0x00800080 & FLASH_DATA_MASK) - -int flash_erase (flash_info_t *info, int s_first, int s_last) -{ - FDT *addr = (FDT *)(info->start[0]); - - int prot, sect, l_sect, flag; - ulong start, now, last; - - __asm__ __volatile__ ("sync"); - addr[0] = 0xf0; - udelay(1000); - - printf("\nflash_erase: first = %d @ 0x%08lx\n", s_first, info->start[s_first] ); - printf(" last = %d @ 0x%08lx\n", s_last , info->start[s_last ] ); - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - if ((info->flash_id == FLASH_UNKNOWN) || (info->flash_id > FLASH_AMD_COMP)) { - printf ("Can't erase unknown flash type %08lx - aborted\n", info->flash_id); - return 1; - } - - prot = 0; - for (sect=s_first; sect<=s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - printf ("\n"); - } - - l_sect = -1; - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - addr[ERASE_ADDR1] = ERASE_DATA1; - addr[ERASE_ADDR2] = ERASE_DATA2; - addr[ERASE_ADDR3] = ERASE_DATA3; - addr[ERASE_ADDR4] = ERASE_DATA4; - addr[ERASE_ADDR5] = ERASE_DATA5; - - for (sect = s_first; sect <= s_last; sect++) { - if (info->protect[sect] == 0) { - addr = (FDT *)(info->start[sect]); - addr[0] = ERASE_SECTOR_DATA; - l_sect = sect; - } - } - - if (flag) - enable_interrupts(); - - /* - * We wait for the last triggered sector - */ - if (l_sect < 0) - goto DONE; - - start = get_timer (0); - last = start; - addr = (FDT *)(info->start[l_sect]); - - while ((addr[0] & ERASE_CONFIRM_DATA) != ERASE_CONFIRM_DATA) { - if ((now = get_timer(start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - return 1; - } - /* show that we're waiting */ - if ((now - last) > 1000) { /* every second */ - putc ('.'); - last = now; - } - } - -DONE: - printf (" done\n"); - return 0; -} - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ - -int write_buff (flash_info_t *info, uchar *src, ulong addr, ulong cnt) -{ -#define BUFF_INC 4 - ulong cp, wp, data; - int i, l, rc; - - mvdebug (("+write_buff %p ==> 0x%08lx, count = 0x%08lx\n", src, addr, cnt)); - - wp = (addr & ~3); /* get lower word aligned address */ - /* - * handle unaligned start bytes - */ - if ((l = addr - wp) != 0) { - mvdebug ((" handle unaligned start bytes (cnt = 0x%08lx)\n", cnt)); - data = 0; - for (i=0, cp=wp; i<l; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - for (; i<BUFF_INC && cnt>0; ++i) { - data = (data << 8) | *src++; - --cnt; - ++cp; - } - for (; cnt==0 && i<BUFF_INC; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - - if ((rc = write_word(info, wp, data)) != 0) { - return (rc); - } - wp += BUFF_INC; - } - - /* - * handle (half)word aligned part - */ - mvdebug ((" handle word aligned part (cnt = 0x%08lx)\n", cnt)); - while (cnt >= BUFF_INC) { - data = 0; - for (i=0; i<BUFF_INC; ++i) { - data = (data << 8) | *src++; - } - if ((rc = write_word(info, wp, data)) != 0) { - return (rc); - } - wp += BUFF_INC; - cnt -= BUFF_INC; - } - - if (cnt == 0) { - return (0); - } - - /* - * handle unaligned tail bytes - */ - mvdebug ((" handle unaligned tail bytes (cnt = 0x%08lx)\n", cnt)); - data = 0; - for (i=0, cp=wp; i<BUFF_INC && cnt>0; ++i, ++cp) { - data = (data << 8) | *src++; - --cnt; - } - for (; i<BUFF_INC; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - - return (write_word(info, wp, data)); -} - -#if (FLASH_BUS_WIDTH >= 16) - #define WRITE_ADDR1 0x0555 - #define WRITE_ADDR2 0x02AA -#else - #define WRITE_ADDR1 0x0AAA - #define WRITE_ADDR2 0x0555 - #define WRITE_ADDR3 WRITE_ADDR1 -#endif - -#define WRITE_DATA1 (0x00AA00AA & FLASH_DATA_MASK) -#define WRITE_DATA2 (0x00550055 & FLASH_DATA_MASK) -#define WRITE_DATA3 (0x00A000A0 & FLASH_DATA_MASK) - -#define WRITE_CONFIRM_DATA ERASE_CONFIRM_DATA - -/*----------------------------------------------------------------------- - * Write a byte to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_char (flash_info_t *info, ulong dest, uchar data) -{ - vu_char *addr = (vu_char *)(info->start[0]); - ulong start; - int flag; - - /* Check if Flash is (sufficiently) erased */ - if ((*((vu_char *)dest) & data) != data) { - printf(" *** ERROR: Flash not erased !\n"); - return (2); - } - flag = disable_interrupts(); - - addr[WRITE_ADDR1] = WRITE_DATA1; - addr[WRITE_ADDR2] = WRITE_DATA2; - addr[WRITE_ADDR3] = WRITE_DATA3; - *((vu_char *)dest) = data; - - if (flag) - enable_interrupts(); - - /* data polling for D7 */ - start = get_timer (0); - addr = (vu_char *)dest; - while (( (*addr) & WRITE_CONFIRM_DATA) != (data & WRITE_CONFIRM_DATA)) { - if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - printf(" *** ERROR: Flash write timeout !"); - return (1); - } - } - mvdebug (("-write_byte\n")); - return (0); -} - -/*----------------------------------------------------------------------- - * Write a word to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_word (flash_info_t *info, ulong dest, ulong data) -{ - int i, - result = 0; - - mvdebug (("+write_word : 0x%08lx @ 0x%08lx\n", data, dest)); - for ( i=0; (i < 4) && (result == 0); i++, dest+=1 ) - result = write_char (info, dest, (data >> (8*(3-i))) & 0xff ); - mvdebug (("-write_word\n")); - return result; -} -/*---------------------------------------------------------------- */ diff --git a/board/mvblue/mvblue.c b/board/mvblue/mvblue.c deleted file mode 100644 index 63503e8..0000000 --- a/board/mvblue/mvblue.c +++ /dev/null @@ -1,253 +0,0 @@ -/* - * GNU General Public License for more details. - * - * MATRIX Vision GmbH / June 2002-Nov 2003 - * Andre Schwarz - */ - -#include <common.h> -#include <mpc824x.h> -#include <asm/io.h> -#include <ns16550.h> -#include <netdev.h> - -#ifdef CONFIG_PCI -#include <pci.h> -#endif - -DECLARE_GLOBAL_DATA_PTR; - -u32 get_BoardType (void); - -#define PCI_CONFIG(b,d,f,r) cpu_to_le32(0x80000000 | ((b&0xff)<<16) \ - | ((d&0x1f)<<11) \ - | ((f&0x7)<<7) \ - | (r&0xfc) ) - -int mv_pci_read (int bus, int dev, int func, int reg) -{ - *(u32 *) (0xfec00cf8) = PCI_CONFIG (bus, dev, func, reg); - asm ("sync"); - return cpu_to_le32 (*(u32 *) (0xfee00cfc)); -} - -u32 get_BoardType () -{ - return (mv_pci_read (0, 0xe, 0, 0) == 0x06801095 ? 0 : 1); -} - -void init_2nd_DUART (void) -{ - NS16550_t console = (NS16550_t) CONFIG_SYS_NS16550_COM2; - int clock_divisor = CONFIG_SYS_NS16550_CLK / 16 / CONFIG_BAUDRATE; - - *(u8 *) (0xfc004511) = 0x1; - NS16550_init (console, clock_divisor); -} -void hw_watchdog_reset (void) -{ - if (get_BoardType () == 0) { - *(u32 *) (0xff000005) = 0; - asm ("sync"); - } -} -int checkboard (void) -{ - ulong busfreq = get_bus_freq (0); - char buf[32]; - u32 BoardType = get_BoardType (); - char *BoardName[2] = { "mvBlueBOX", "mvBlueLYNX" }; - char *p; - - hw_watchdog_reset (); - - printf ("U-Boot (%s) running on mvBLUE device.\n", MV_VERSION); - printf (" Found %s running at %s MHz memory clock.\n", - BoardName[BoardType], strmhz (buf, busfreq)); - - init_2nd_DUART (); - - if ((p = getenv ("console_nr")) != NULL) { - unsigned long con_nr = simple_strtoul (p, NULL, 10) & 3; - - gd->baudrate &= ~3; - gd->baudrate |= con_nr & 3; - } - return 0; -} - -phys_size_t initdram (int board_type) -{ - long size; - long new_bank0_end; - long mear1; - long emear1; - - size = get_ram_size(CONFIG_SYS_SDRAM_BASE, CONFIG_SYS_MAX_RAM_SIZE); - - new_bank0_end = size - 1; - mear1 = mpc824x_mpc107_getreg(MEAR1); - emear1 = mpc824x_mpc107_getreg(EMEAR1); - mear1 = (mear1 & 0xFFFFFF00) | - ((new_bank0_end & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT); - emear1 = (emear1 & 0xFFFFFF00) | - ((new_bank0_end & MICR_ADDR_MASK) >> MICR_EADDR_SHIFT); - mpc824x_mpc107_setreg(MEAR1, mear1); - mpc824x_mpc107_setreg(EMEAR1, emear1); - - return (size); -} - -/* ------------------------------------------------------------------------- */ -u8 *dhcp_vendorex_prep (u8 * e) -{ - char *ptr; - - /* DHCP vendor-class-identifier = 60 */ - if ((ptr = getenv ("dhcp_vendor-class-identifier"))) { - *e++ = 60; - *e++ = strlen (ptr); - while (*ptr) - *e++ = *ptr++; - } - /* my DHCP_CLIENT_IDENTIFIER = 61 */ - if ((ptr = getenv ("dhcp_client_id"))) { - *e++ = 61; - *e++ = strlen (ptr); - while (*ptr) - *e++ = *ptr++; - } - return e; -} - -u8 *dhcp_vendorex_proc (u8 * popt) -{ - return NULL; -} - -/* ------------------------------------------------------------------------- */ - -/* - * Initialize PCI Devices - */ -#ifdef CONFIG_PCI -void pci_mvblue_clear_base (struct pci_controller *hose, pci_dev_t dev) -{ - u32 cnt; - - printf ("clear base @ dev/func 0x%02x/0x%02x ... ", PCI_DEV (dev), - PCI_FUNC (dev)); - for (cnt = 0; cnt < 6; cnt++) - pci_hose_write_config_dword (hose, dev, 0x10 + (4 * cnt), - 0x0); - printf ("done\n"); -} - -void duart_setup (u32 base, u16 divisor) -{ - printf ("duart setup ..."); - out_8 ((u8 *) (CONFIG_SYS_ISA_IO + base + 3), 0x80); - out_8 ((u8 *) (CONFIG_SYS_ISA_IO + base + 0), divisor & 0xff); - out_8 ((u8 *) (CONFIG_SYS_ISA_IO + base + 1), divisor >> 8); - out_8 ((u8 *) (CONFIG_SYS_ISA_IO + base + 3), 0x03); - out_8 ((u8 *) (CONFIG_SYS_ISA_IO + base + 4), 0x03); - out_8 ((u8 *) (CONFIG_SYS_ISA_IO + base + 2), 0x07); - printf ("done\n"); -} - -void pci_mvblue_fixup_irq_behind_bridge (struct pci_controller *hose, - pci_dev_t bridge, unsigned char irq) -{ - pci_dev_t d; - unsigned char bus; - unsigned short vendor, class; - - pci_hose_read_config_byte (hose, bridge, PCI_SECONDARY_BUS, &bus); - for (d = PCI_BDF (bus, 0, 0); - d < PCI_BDF (bus, PCI_MAX_PCI_DEVICES - 1, - PCI_MAX_PCI_FUNCTIONS - 1); - d += PCI_BDF (0, 0, 1)) { - pci_hose_read_config_word (hose, d, PCI_VENDOR_ID, &vendor); - if (vendor != 0xffff && vendor != 0x0000) { - pci_hose_read_config_word (hose, d, PCI_CLASS_DEVICE, - &class); - if (class == PCI_CLASS_BRIDGE_PCI) - pci_mvblue_fixup_irq_behind_bridge (hose, d, - irq); - else - pci_hose_write_config_byte (hose, d, - PCI_INTERRUPT_LINE, - irq); - } - } -} - -#define MV_MAX_PCI_BUSSES 3 -#define SLOT0_IRQ 3 -#define SLOT1_IRQ 4 -void pci_mvblue_fixup_irq (struct pci_controller *hose, pci_dev_t dev) -{ - unsigned char line = 0xff; - unsigned short class; - - if (PCI_BUS (dev) == 0) { - switch (PCI_DEV (dev)) { - case 0xd: - if (get_BoardType () == 0) { - line = 1; - } else - /* mvBL */ - line = 2; - break; - case 0xe: - /* mvBB: IDE */ - line = 2; - pci_hose_write_config_byte (hose, dev, 0x8a, 0x20); - break; - case 0xf: - /* mvBB: Slot0 (Grabber) */ - pci_hose_read_config_word (hose, dev, - PCI_CLASS_DEVICE, &class); - if (class == PCI_CLASS_BRIDGE_PCI) { - pci_mvblue_fixup_irq_behind_bridge (hose, dev, - SLOT0_IRQ); - line = 0xff; - } else - line = SLOT0_IRQ; - break; - case 0x10: - /* mvBB: Slot1 */ - pci_hose_read_config_word (hose, dev, - PCI_CLASS_DEVICE, &class); - if (class == PCI_CLASS_BRIDGE_PCI) { - pci_mvblue_fixup_irq_behind_bridge (hose, dev, - SLOT1_IRQ); - line = 0xff; - } else - line = SLOT1_IRQ; - break; - default: - printf ("***pci_scan: illegal dev = 0x%08x\n", - PCI_DEV (dev)); - line = 0xff; - break; - } - pci_hose_write_config_byte (hose, dev, PCI_INTERRUPT_LINE, - line); - } -} - -struct pci_controller hose = { - fixup_irq:pci_mvblue_fixup_irq -}; - -void pci_init_board (void) -{ - pci_mpc824x_init (&hose); -} - -int board_eth_init(bd_t *bis) -{ - return pci_eth_init(bis); -} -#endif diff --git a/board/mvblue/u-boot.lds b/board/mvblue/u-boot.lds deleted file mode 100644 index 5034a96..0000000 --- a/board/mvblue/u-boot.lds +++ /dev/null @@ -1,86 +0,0 @@ -/* - * (C) Copyright 2001-2007 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -OUTPUT_ARCH(powerpc) -/* Do we need any of these for elf? - __DYNAMIC = 0; */ -SECTIONS -{ - /* Read-only sections, merged into text segment: */ - .text : - { - arch/powerpc/cpu/mpc824x/start.o (.text*) - lib/built-in.o (.text*) - net/built-in.o (.text*) - drivers/pci/built-in.o (.text*) - arch/powerpc/cpu/mpc824x/built-in.o (.text*) - board/mvblue/built-in.o (.text*) - arch/powerpc/lib/built-in.o (.text*) - - . = DEFINED(env_offset) ? env_offset : .; - common/env_embedded.o (.ppcenv*) - - *(.text*) - . = ALIGN(16); - *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) - } - - /* Read-write section, merged into data segment: */ - . = (. + 0x0FFF) & 0xFFFFF000; - _erotext = .; - PROVIDE (erotext = .); - .reloc : - { - _GOT2_TABLE_ = .; - KEEP(*(.got2)) - KEEP(*(.got)) - PROVIDE(_GLOBAL_OFFSET_TABLE_ = . + 4); - _FIXUP_TABLE_ = .; - KEEP(*(.fixup)) - } - __got2_entries = ((_GLOBAL_OFFSET_TABLE_ - _GOT2_TABLE_) >> 2) - 1; - __fixup_entries = (. - _FIXUP_TABLE_) >> 2; - - .data : - { - *(.data*) - *(.sdata*) - } - _edata = .; - PROVIDE (edata = .); - - . = .; - - . = ALIGN(4); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); - } - - - . = .; - __start___ex_table = .; - __ex_table : { *(__ex_table) } - __stop___ex_table = .; - - . = ALIGN(4096); - __init_begin = .; - .text.init : { *(.text.init) } - .data.init : { *(.data.init) } - . = ALIGN(4096); - __init_end = .; - - __bss_start = .; - .bss (NOLOAD) : - { - *(.bss*) - *(.sbss*) - *(COMMON) - . = ALIGN(4); - } - __bss_end = . ; - PROVIDE (end = .); -} diff --git a/board/sandpoint/Kconfig b/board/sandpoint/Kconfig deleted file mode 100644 index c19b63e..0000000 --- a/board/sandpoint/Kconfig +++ /dev/null @@ -1,19 +0,0 @@ -if TARGET_SANDPOINT8240 - -config SYS_BOARD - default "sandpoint" - -config SYS_CONFIG_NAME - default "Sandpoint8240" - -endif - -if TARGET_SANDPOINT8245 - -config SYS_BOARD - default "sandpoint" - -config SYS_CONFIG_NAME - default "Sandpoint8245" - -endif diff --git a/board/sandpoint/MAINTAINERS b/board/sandpoint/MAINTAINERS deleted file mode 100644 index 569cf42..0000000 --- a/board/sandpoint/MAINTAINERS +++ /dev/null @@ -1,12 +0,0 @@ -SANDPOINT BOARD -M: Wolfgang Denk wd@denx.de -S: Maintained -F: board/sandpoint/ -F: include/configs/Sandpoint8240.h -F: configs/Sandpoint8240_defconfig - -SANDPOINT8245 BOARD -#M: Jim Thompson jim@musenki.com -S: Orphan (since 2014-04) -F: include/configs/Sandpoint8245.h -F: configs/Sandpoint8245_defconfig diff --git a/board/sandpoint/Makefile b/board/sandpoint/Makefile deleted file mode 100644 index 58f5a89..0000000 --- a/board/sandpoint/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = sandpoint.o flash.o diff --git a/board/sandpoint/README b/board/sandpoint/README deleted file mode 100644 index c9996a8..0000000 --- a/board/sandpoint/README +++ /dev/null @@ -1,411 +0,0 @@ -This port of U-Boot will run on a Motorola Sandpoint 3 development -system equipped with a Unity X4 PPMC card (MPC8240 CPU) only. It is a -snapshot of work in progress and far from being completed. In order -to run it on the target system, it has to be downloaded using the -DINK32 monitor program that came with your Sandpoint system. Please -note that DINK32 does not accept the S-Record file created by the -U-Boot build process unmodified, because it contains CR/LF line -terminators. You have to strip the CR characters first. There is a -tiny script named 'dinkdl' I created for this purpose. - -The Sandpoint port is based on the work of Rob Taylor, who does not -seem to maintain it any more. I can be reached by mail as -tkoeller@gmx.net. - -Thomas Koeller - - -The port was tested on a Sandpoint 8240 X3 board, with U-Boot -installed in the flash memory of the CPU card. Please use the -following DIP switch settings: - -Motherboard: - -SW1.1: on SW1.2: on SW1.3: on SW1.4: on -SW1.5: on SW1.6: on SW1.7: on SW1.8: on - -SW2.1: on SW2.2: on SW2.3: on SW2.4: on -SW2.5: on SW2.6: on SW2.7: on SW2.8: on - - -CPU Card: - -SW2.1: OFF SW2.2: OFF SW2.3: on SW2.4: on -SW2.5: OFF SW2.6: OFF SW2.7: OFF SW2.8: OFF - -SW3.1: OFF SW3.2: on SW3.3: OFF SW3.4: OFF -SW3.5: on SW3.6: OFF SW3.7: OFF SW3.8: on - - -The followind detailed description of installation and initial steps -with U-Boot and QNX was provided by Jim Sandoz sandoz@lucent.com: - - -Directions for installing U-Boot on Sandpoint+Unity8240 -using the Abatron BDI2000 BDM/JTAG debugger ... - -Background and Reference info: -http://u-boot.sourceforge.net/ -http://www.abatron.ch/ -http://www.abatron.ch/BDI/bdihw.html -http://www.abatron.ch/DataSheets/BDI2000.pdf -http://www.abatron.ch/Manuals/ManGdbCOP-2000C.pdf -http://e-www.motorola.com/collateral/SPX3UM.pdf -http://e-www.motorola.com/collateral/UNITYX4CONFIG.pdf - - -Connection Diagram: - =========== - === ===== |----- | -| | <---------------> | | | | | -|PC | rs232 | BDI |=============[] | | -| | |2000 | BDM probe | | | -| | <---------------> | | |----- | - === ethernet ===== | | - | | - =========== - Sandpoint X3 with - Unity 8240 proc - - -PART 1) - DIP Switch Settings: - -Sandpoint X3 8240 processor board DIP switch settings, with -U-Boot to be installed in the flash memory of the CPU card: - -Motorola Sandpoint X3 Motherboard: -SW1.1: on SW1.2: on SW1.3: on SW1.4: on -SW1.5: on SW1.6: on SW1.7: on SW1.8: on -SW2.1: on SW2.2: on SW2.3: on SW2.4: on -SW2.5: on SW2.6: on SW2.7: on SW2.8: on - -Motorola Unity 8240 CPU Card: -SW2.1: OFF SW2.2: OFF SW2.3: on SW2.4: on -SW2.5: OFF SW2.6: OFF SW2.7: OFF SW2.8: OFF -SW3.1: OFF SW3.2: on SW3.3: OFF SW3.4: OFF -SW3.5: on SW3.6: OFF SW3.7: OFF SW3.8: on - - -PART 2) - Connect the BDI2000 Cable to the Sandpoint/Unity 8240: - -BDM Pin 1 on the Unity 8240 processor board is towards the -PCI PMC connectors, or away from the socketed SDRAM, i.e.: - - ==================== - | ---------------- | - | | SDRAM | | - | | | | - | ---------------- | - | |~| | - | |B| ++++++ | - | |D| + uP + | - | |M| +8240+ | - | ~ 1 ++++++ | - | | - | | - | | - | PMC conn ====== | - | ===== ====== | - | | - ==================== - - -PART 3) - Setting up the BDI2000, and preparing for TCP/IP network comms: - -Connect the BDI2000 to the PC using the supplied serial cable. -Download the BDI2000 software and install it using setup.exe. - -[Note: of course you can also use the Linux command line tool -"bdisetup" to configure your BDI2000 - the sources are included on -the floppy disk that comes with your BDI2000. Just in case you don't -have any Windows PC's - like me :-) -- wd ] - -Power up the BDI2000; then follow directions to assign the IP -address and related network information. Note that U-Boot -will be loaded to the Sandpoint via tftp. You need to either -use the Abatron-provided tftp application or provide a tftp -server (e.g. Linux/Solaris/*BSD) somewhere on your network. -Once the IP address etc are assigned via the RS232 port, -further communication with the BDI2000 will happen via the -ethernet connection. - -PART 4) - Making a TCP/IP network connection to the Abatron BDI2000: - -Telnet to the Abatron BDI2000. Assuming that all of the -networking info was loaded via RS232 correctly, you will see -the following (scrolling): - -- TARGET: waiting for target Vcc -- TARGET: waiting for target Vcc - - -PART 5) - Power up the target Sandpoint: -If the BDM connections are correct, the following will now appear: - -- TARGET: waiting for target Vcc -- TARGET: waiting for target Vcc -- TARGET: processing power-up delay -- TARGET: processing user reset request -- BDI asserts HRESET -- Reset JTAG controller passed -- Bypass check: 0x55 => 0xAA -- Bypass check: 0x55 => 0xAA -- JTAG exists check passed -- Target PVR is 0x00810101 -- COP status is 0x01 -- Check running state passed -- BDI scans COP freeze command -- BDI removes HRESET -- COP status is 0x05 -- Check stopped state passed -- Check LSRL length passed -- BDI sets breakpoint at 0xFFF00100 -- BDI resumes program execution -- Waiting for target stop passed -- TARGET: Target PVR is 0x00810101 -- TARGET: reseting target passed -- TARGET: processing target startup .... -- TARGET: processing target startup passed -BDI> - - -PART 6) - Erase the current contents of the flash memory: - -BDI>era 0xFFF00000 - Erasing flash at 0xfff00000 - Erasing flash passed -BDI>era 0xFFF04000 - Erasing flash at 0xfff04000 - Erasing flash passed -BDI>era 0xFFF06000 - Erasing flash at 0xfff06000 - Erasing flash passed -BDI>era 0xFFF08000 - Erasing flash at 0xfff08000 - Erasing flash passed -BDI>era 0xFFF10000 - Erasing flash at 0xfff10000 - Erasing flash passed -BDI>era 0xFFF20000 - Erasing flash at 0xfff20000 - Erasing flash passed - - -PART 7) - Program the flash memory with the U-Boot image: - -BDI>prog 0xFFF00000 u-boot.bin bin - Programming u-boot.bin , please wait .... - Programming flash passed - - -PART 8) - Connect PC to Sandpoint: -Using a crossover serial cable, attach the PC serial port to the -Sandpoint's COM1. Set communications parameters to 8N1 / 9600 baud. - - -PART 9) - Reset the Unity and begin U-Boot execution: - -BDI>reset -- TARGET: processing user reset request -- TARGET: Target PVR is 0x00810101 -- TARGET: reseting target passed -- TARGET: processing target init list .... -- TARGET: processing target init list passed - -BDI>go - -Now see output from U-Boot running, sent via serial port: - -U-Boot 1.1.4 (Jan 23 2002 - 18:29:19) - -CPU: MPC8240 Revision 1.1 at 264 MHz: 16 kB I-Cache 16 kB D-Cache -Board: Sandpoint 8240 Unity -DRAM: 64 MB -FLASH: 2 MB -PCI: scanning bus0 ... - bus dev fn venID devID class rev MBAR0 MBAR1 IPIN ILINE - 00 00 00 1057 0003 060000 13 00000008 00000000 01 00 - 00 0b 00 10ad 0565 060100 10 00000000 00000000 00 00 - 00 0f 00 8086 1229 020000 08 80000000 80000001 01 00 -In: serial -Out: serial -Err: serial -=> - - -PART 10) - Set and save any required environmental variables, examples of some: - -=> setenv ethaddr 00:03:47:97:D0:79 -=> setenv bootfile your_qnx_image_here -=> setenv hostname sandpointX -=> setenv netmask 255.255.255.0 -=> setenv ipaddr 192.168.0.11 -=> setenv serverip 192.168.0.10 -=> setenv gatewayip=192.168.0.1 -=> saveenv -Saving Environment to Flash... -Un-Protected 1 sectors -Erasing Flash... - done -Erased 1 sectors -Writing to Flash... done -Protected 1 sectors -=> - -**** Example environment: **** - -=> printenv -baudrate=9600 -bootfile=telemetry -hostname=sp1 -ethaddr=00:03:47:97:E4:6B -load=tftp 100000 u-boot.bin -update=protect off all;era FFF00000 FFF3FFFF;cp.b 100000 FFF00000 ${filesize};saveenv -filesize=1f304 -gatewayip=145.17.228.1 -netmask=255.255.255.0 -ipaddr=145.17.228.42 -serverip=145.17.242.46 -stdin=serial -stdout=serial -stderr=serial - -Environment size: 332/8188 bytes -=> - -here's some text useful stuff for cut-n-paste: -setenv hostname sandpoint1 -setenv netmask 255.255.255.0 -setenv ipaddr 145.17.228.81 -setenv serverip 145.17.242.46 -setenv gatewayip 145.17.228.1 -saveenv - -PART 11) - Test U-Boot by tftp'ing new U-Boot, overwriting current: - -=> protect off all -Un-Protect Flash Bank # 1 -=> tftp 100000 u-boot.bin -eth: Intel i82559 PCI EtherExpressPro @0x80000000(bus=0, device=15, func=0) -ARP broadcast 1 -TFTP from server 145.17.242.46; our IP address is 145.17.228.42; sending through - gateway 145.17.228.1 -Filename 'u-boot.bin'. -Load address: 0x100000 -Loading: ######################### -done -Bytes transferred = 127628 (1f28c hex) -=> era all -Erase Flash Bank # 1 - done -Erase Flash Bank # 2 - missing -=> cp.b 0x100000 FFF00000 1f28c -Copy to Flash... done -=> saveenv -Saving Environment to Flash... -Un-Protected 1 sectors -Erasing Flash... - done -Erased 1 sectors -Writing to Flash... done -Protected 1 sectors -=> reset - -You can put these commands into some environment variables; - -=> setenv load tftp 100000 u-boot.bin -=> setenv update protect off all;era FFF00000 FFF3FFFF;cp.b 100000 FFF00000 ${filesize};saveenv -=> saveenv - -Then you just have to type "run load" then "run update" - -=> run load -eth: Intel i82559 PCI EtherExpressPro @0x80000000(bus=0, device=15, func=0) -ARP broadcast 1 -TFTP from server 145.17.242.46; our IP address is 145.17.228.42; sending through - gateway 145.17.228.1 -Filename 'u-boot.bin'. -Load address: 0x100000 -Loading: ######################### -done -Bytes transferred = 127748 (1f304 hex) -=> run update -Un-Protect Flash Bank # 1 -Un-Protect Flash Bank # 2 -Erase Flash from 0xfff00000 to 0xfff3ffff - done -Erased 7 sectors -Copy to Flash... done -Saving Environment to Flash... -Un-Protected 1 sectors -Erasing Flash... - done -Erased 1 sectors -Writing to Flash... done -Protected 1 sectors -=> - - -PART 12) - Load OS image (ELF format) via U-Boot using tftp - - -=> tftp 800000 sandpoint-simple.elf -eth: Intel i82559 PCI EtherExpressPro @0x80000000(bus=0, device=15, func=0) -ARP broadcast 1 -TFTP from server 145.17.242.46; our IP address is 145.17.228.42; sending through - gateway 145.17.228.1 -Filename 'sandpoint-simple.elf'. -Load address: 0x800000 -Loading: ################################################################# - ################################################################# - ################################################################# - ######################## -done -Bytes transferred = 1120284 (11181c hex) -==> - -PART 13) - Begin OS image execution: (note that unless you have the -serial parameters of your OS image set to 9600 (i.e. same as -the U-Boot binary) you will get garbage here until you change -the serial communications speed. - -=> bootelf 800000 -Loading @ 0x001f0100 (1120028 bytes) -## Starting application at 0x001f1d28 ... -Replace init_hwinfo() with a board specific version - -Loading QNX6.... - -Header size=0x0000009c, Total Size=0x000005c0, #Cpu=1, Type=1 -<...loader and kernel messages snipped...> - -Welcome to Neutrino on the Sandpoint -# - - -other information: - -CVS Retrieval Notes: - -U-Boot's SourceForge CVS repository can be checked out -through anonymous (pserver) CVS with the following -instruction set. The module you wish to check out must -be specified as the modulename. When prompted for a -password for anonymous, simply press the Enter key. - -cvs -d:pserver:anonymous@cvs.u-boot.sourceforge.net:/cvsroot/u-boot login - -cvs -z6 -d:pserver:anonymous@cvs.u-boot.sourceforge.net:/cvsroot/u-boot co -P u-boot diff --git a/board/sandpoint/dinkdl b/board/sandpoint/dinkdl deleted file mode 100644 index f281452..0000000 --- a/board/sandpoint/dinkdl +++ /dev/null @@ -1,2 +0,0 @@ -#! /bin/bash -tr -d "\r" <$1 >/dev/tts/1 diff --git a/board/sandpoint/flash.c b/board/sandpoint/flash.c deleted file mode 100644 index 1ab668c..0000000 --- a/board/sandpoint/flash.c +++ /dev/null @@ -1,748 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc824x.h> -#include <asm/processor.h> -#include <asm/pci_io.h> -#include <w83c553f.h> - -#define ROM_CS0_START 0xFF800000 -#define ROM_CS1_START 0xFF000000 - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH chips */ - -#if defined(CONFIG_ENV_IS_IN_FLASH) -# ifndef CONFIG_ENV_ADDR -# define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET) -# endif -# ifndef CONFIG_ENV_SIZE -# define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -# endif -# ifndef CONFIG_ENV_SECT_SIZE -# define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE -# endif -#endif - -/*----------------------------------------------------------------------- - * Functions - */ -static int write_word (flash_info_t *info, ulong dest, ulong data); -#if 0 -static void flash_get_offsets (ulong base, flash_info_t *info); -#endif /* 0 */ - -/*flash command address offsets*/ - -#if 0 -#define ADDR0 (0x555) -#define ADDR1 (0x2AA) -#define ADDR3 (0x001) -#else -#define ADDR0 (0xAAA) -#define ADDR1 (0x555) -#define ADDR3 (0x001) -#endif - -#define FLASH_WORD_SIZE unsigned char - -/*----------------------------------------------------------------------- - */ - -#if 0 -static int byte_parity_odd(unsigned char x) __attribute__ ((const)); -#endif /* 0 */ -static unsigned long flash_id(unsigned char mfct, unsigned char chip) __attribute__ ((const)); - -typedef struct -{ - FLASH_WORD_SIZE extval; - unsigned short intval; -} map_entry; - -#if 0 -static int -byte_parity_odd(unsigned char x) -{ - x ^= x >> 4; - x ^= x >> 2; - x ^= x >> 1; - return (x & 0x1) != 0; -} -#endif /* 0 */ - - -static unsigned long -flash_id(unsigned char mfct, unsigned char chip) -{ - static const map_entry mfct_map[] = - { - {(FLASH_WORD_SIZE) AMD_MANUFACT, (unsigned short) ((unsigned long) FLASH_MAN_AMD >> 16)}, - {(FLASH_WORD_SIZE) FUJ_MANUFACT, (unsigned short) ((unsigned long) FLASH_MAN_FUJ >> 16)}, - {(FLASH_WORD_SIZE) STM_MANUFACT, (unsigned short) ((unsigned long) FLASH_MAN_STM >> 16)}, - {(FLASH_WORD_SIZE) MT_MANUFACT, (unsigned short) ((unsigned long) FLASH_MAN_MT >> 16)}, - {(FLASH_WORD_SIZE) INTEL_MANUFACT,(unsigned short) ((unsigned long) FLASH_MAN_INTEL >> 16)}, - {(FLASH_WORD_SIZE) INTEL_ALT_MANU,(unsigned short) ((unsigned long) FLASH_MAN_INTEL >> 16)} - }; - - static const map_entry chip_map[] = - { - {AMD_ID_F040B, FLASH_AM040}, - {(FLASH_WORD_SIZE) STM_ID_x800AB, FLASH_STM800AB} - }; - - const map_entry *p; - unsigned long result = FLASH_UNKNOWN; - - /* find chip id */ - for(p = &chip_map[0]; p < &chip_map[sizeof chip_map / sizeof chip_map[0]]; p++) - if(p->extval == chip) - { - result = FLASH_VENDMASK | p->intval; - break; - } - - /* find vendor id */ - for(p = &mfct_map[0]; p < &mfct_map[sizeof mfct_map / sizeof mfct_map[0]]; p++) - if(p->extval == mfct) - { - result &= ~FLASH_VENDMASK; - result |= (unsigned long) p->intval << 16; - break; - } - - return result; -} - - -unsigned long -flash_init(void) -{ - unsigned long i; - unsigned char j; - static const ulong flash_banks[] = CONFIG_SYS_FLASH_BANKS; - - /* Init: no FLASHes known */ - for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; i++) - { - flash_info_t * const pflinfo = &flash_info[i]; - pflinfo->flash_id = FLASH_UNKNOWN; - pflinfo->size = 0; - pflinfo->sector_count = 0; - } - - /* Enable writes to Sandpoint flash */ - { - register unsigned char temp; - CONFIG_READ_BYTE(CONFIG_SYS_WINBOND_ISA_CFG_ADDR + WINBOND_CSCR, temp); - temp &= ~0x20; /* clear BIOSWP bit */ - CONFIG_WRITE_BYTE(CONFIG_SYS_WINBOND_ISA_CFG_ADDR + WINBOND_CSCR, temp); - } - - for(i = 0; i < sizeof flash_banks / sizeof flash_banks[0]; i++) - { - flash_info_t * const pflinfo = &flash_info[i]; - const unsigned long base_address = flash_banks[i]; - volatile FLASH_WORD_SIZE * const flash = (FLASH_WORD_SIZE *) base_address; -#if 0 - volatile FLASH_WORD_SIZE * addr2; -#endif -#if 0 - /* write autoselect sequence */ - flash[0x5555] = 0xaa; - flash[0x2aaa] = 0x55; - flash[0x5555] = 0x90; -#else - flash[0xAAA << (3 * i)] = 0xaa; - flash[0x555 << (3 * i)] = 0x55; - flash[0xAAA << (3 * i)] = 0x90; -#endif - __asm__ __volatile__("sync"); - -#if 0 - pflinfo->flash_id = flash_id(flash[0x0], flash[0x1]); -#else - pflinfo->flash_id = flash_id(flash[0x0], flash[0x2 + 14 * i]); -#endif - - switch(pflinfo->flash_id & FLASH_TYPEMASK) - { - case FLASH_AM040: - pflinfo->size = 0x00080000; - pflinfo->sector_count = 8; - for(j = 0; j < 8; j++) - { - pflinfo->start[j] = base_address + 0x00010000 * j; - pflinfo->protect[j] = flash[(j << 16) | 0x2]; - } - break; - case FLASH_STM800AB: - pflinfo->size = 0x00100000; - pflinfo->sector_count = 19; - pflinfo->start[0] = base_address; - pflinfo->start[1] = base_address + 0x4000; - pflinfo->start[2] = base_address + 0x6000; - pflinfo->start[3] = base_address + 0x8000; - for(j = 1; j < 16; j++) - { - pflinfo->start[j+3] = base_address + 0x00010000 * j; - } -#if 0 - /* check for protected sectors */ - for (j = 0; j < pflinfo->sector_count; j++) { - /* read sector protection at sector address, (A7 .. A0) = 0x02 */ - /* D0 = 1 if protected */ - addr2 = (volatile FLASH_WORD_SIZE *)(pflinfo->start[j]); - if (pflinfo->flash_id & FLASH_MAN_SST) - pflinfo->protect[j] = 0; - else - pflinfo->protect[j] = addr2[2] & 1; - } -#endif - break; - } - /* Protect monitor and environment sectors - */ -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE + monitor_flash_len - 1, - &flash_info[0]); -#endif - -#if defined(CONFIG_ENV_IS_IN_FLASH) && defined(CONFIG_ENV_ADDR) - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR + CONFIG_ENV_SIZE - 1, - &flash_info[0]); -#endif - - /* reset device to read mode */ - flash[0x0000] = 0xf0; - __asm__ __volatile__("sync"); - } - - return flash_info[0].size + flash_info[1].size; -} - -#if 0 -static void -flash_get_offsets (ulong base, flash_info_t *info) -{ - int i; - - /* set up sector start address table */ - if (info->flash_id & FLASH_MAN_SST) - { - for (i = 0; i < info->sector_count; i++) - info->start[i] = base + (i * 0x00010000); - } - else - if (info->flash_id & FLASH_BTYPE) { - /* set sector offsets for bottom boot block type */ - info->start[0] = base + 0x00000000; - info->start[1] = base + 0x00004000; - info->start[2] = base + 0x00006000; - info->start[3] = base + 0x00008000; - for (i = 4; i < info->sector_count; i++) { - info->start[i] = base + (i * 0x00010000) - 0x00030000; - } - } else { - /* set sector offsets for top boot block type */ - i = info->sector_count - 1; - info->start[i--] = base + info->size - 0x00004000; - info->start[i--] = base + info->size - 0x00006000; - info->start[i--] = base + info->size - 0x00008000; - for (; i >= 0; i--) { - info->start[i] = base + i * 0x00010000; - } - } - -} -#endif /* 0 */ - -/*----------------------------------------------------------------------- - */ -void -flash_print_info(flash_info_t *info) -{ - static const char unk[] = "Unknown"; - const char *mfct = unk, *type = unk; - unsigned int i; - - if(info->flash_id != FLASH_UNKNOWN) - { - switch(info->flash_id & FLASH_VENDMASK) - { - case FLASH_MAN_AMD: mfct = "AMD"; break; - case FLASH_MAN_FUJ: mfct = "FUJITSU"; break; - case FLASH_MAN_STM: mfct = "STM"; break; - case FLASH_MAN_SST: mfct = "SST"; break; - case FLASH_MAN_BM: mfct = "Bright Microelectonics"; break; - case FLASH_MAN_INTEL: mfct = "Intel"; break; - } - - switch(info->flash_id & FLASH_TYPEMASK) - { - case FLASH_AM040: type = "AM29F040B (512K * 8, uniform sector size)"; break; - case FLASH_AM400B: type = "AM29LV400B (4 Mbit, bottom boot sect)"; break; - case FLASH_AM400T: type = "AM29LV400T (4 Mbit, top boot sector)"; break; - case FLASH_AM800B: type = "AM29LV800B (8 Mbit, bottom boot sect)"; break; - case FLASH_AM800T: type = "AM29LV800T (8 Mbit, top boot sector)"; break; - case FLASH_AM160T: type = "AM29LV160T (16 Mbit, top boot sector)"; break; - case FLASH_AM320B: type = "AM29LV320B (32 Mbit, bottom boot sect)"; break; - case FLASH_AM320T: type = "AM29LV320T (32 Mbit, top boot sector)"; break; - case FLASH_STM800AB: type = "M29W800AB (8 Mbit, bottom boot sect)"; break; - case FLASH_SST800A: type = "SST39LF/VF800 (8 Mbit, uniform sector size)"; break; - case FLASH_SST160A: type = "SST39LF/VF160 (16 Mbit, uniform sector size)"; break; - } - } - - printf( - "\n Brand: %s Type: %s\n" - " Size: %lu KB in %d Sectors\n", - mfct, - type, - info->size >> 10, - info->sector_count - ); - - printf (" Sector Start Addresses:"); - - for (i = 0; i < info->sector_count; i++) - { - unsigned long size; - unsigned int erased; - unsigned long * flash = (unsigned long *) info->start[i]; - - /* - * Check if whole sector is erased - */ - size = - (i != (info->sector_count - 1)) ? - (info->start[i + 1] - info->start[i]) >> 2 : - (info->start[0] + info->size - info->start[i]) >> 2; - - for( - flash = (unsigned long *) info->start[i], erased = 1; - (flash != (unsigned long *) info->start[i] + size) && erased; - flash++ - ) - erased = *flash == ~0x0UL; - - printf( - "%s %08lX %s %s", - (i % 5) ? "" : "\n ", - info->start[i], - erased ? "E" : " ", - info->protect[i] ? "RO" : " " - ); - } - - puts("\n"); - return; -} - -#if 0 - -/* - * The following code cannot be run from FLASH! - */ -ulong -flash_get_size (vu_long *addr, flash_info_t *info) -{ - short i; - FLASH_WORD_SIZE value; - ulong base = (ulong)addr; - volatile FLASH_WORD_SIZE *addr2 = (FLASH_WORD_SIZE *)addr; - - printf("flash_get_size: \n"); - /* Write auto select command: read Manufacturer ID */ - eieio(); - addr2[ADDR0] = (FLASH_WORD_SIZE)0xAA; - addr2[ADDR1] = (FLASH_WORD_SIZE)0x55; - addr2[ADDR0] = (FLASH_WORD_SIZE)0x90; - value = addr2[0]; - - switch (value) { - case (FLASH_WORD_SIZE)AMD_MANUFACT: - info->flash_id = FLASH_MAN_AMD; - break; - case (FLASH_WORD_SIZE)FUJ_MANUFACT: - info->flash_id = FLASH_MAN_FUJ; - break; - case (FLASH_WORD_SIZE)SST_MANUFACT: - info->flash_id = FLASH_MAN_SST; - break; - default: - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - return (0); /* no or unknown flash */ - } - printf("recognised manufacturer"); - - value = addr2[ADDR3]; /* device ID */ - debug ("\ndev_code=%x\n", value); - - switch (value) { - case (FLASH_WORD_SIZE)AMD_ID_LV400T: - info->flash_id += FLASH_AM400T; - info->sector_count = 11; - info->size = 0x00080000; - break; /* => 0.5 MB */ - - case (FLASH_WORD_SIZE)AMD_ID_LV400B: - info->flash_id += FLASH_AM400B; - info->sector_count = 11; - info->size = 0x00080000; - break; /* => 0.5 MB */ - - case (FLASH_WORD_SIZE)AMD_ID_LV800T: - info->flash_id += FLASH_AM800T; - info->sector_count = 19; - info->size = 0x00100000; - break; /* => 1 MB */ - - case (FLASH_WORD_SIZE)AMD_ID_LV800B: - info->flash_id += FLASH_AM800B; - info->sector_count = 19; - info->size = 0x00100000; - break; /* => 1 MB */ - - case (FLASH_WORD_SIZE)AMD_ID_LV160T: - info->flash_id += FLASH_AM160T; - info->sector_count = 35; - info->size = 0x00200000; - break; /* => 2 MB */ - - case (FLASH_WORD_SIZE)AMD_ID_LV160B: - info->flash_id += FLASH_AM160B; - info->sector_count = 35; - info->size = 0x00200000; - break; /* => 2 MB */ - - case (FLASH_WORD_SIZE)SST_ID_xF800A: - info->flash_id += FLASH_SST800A; - info->sector_count = 16; - info->size = 0x00100000; - break; /* => 1 MB */ - - case (FLASH_WORD_SIZE)SST_ID_xF160A: - info->flash_id += FLASH_SST160A; - info->sector_count = 32; - info->size = 0x00200000; - break; /* => 2 MB */ - - case (FLASH_WORD_SIZE)AMD_ID_F040B: - info->flash_id += FLASH_AM040; - info->sector_count = 8; - info->size = 0x00080000; - break; /* => 0.5 MB */ - - default: - info->flash_id = FLASH_UNKNOWN; - return (0); /* => no or unknown flash */ - - } - - printf("flash id %lx; sector count %x, size %lx\n", info->flash_id,info->sector_count,info->size); - /* set up sector start address table */ - if (info->flash_id & FLASH_MAN_SST) - { - for (i = 0; i < info->sector_count; i++) - info->start[i] = base + (i * 0x00010000); - } - else - if (info->flash_id & FLASH_BTYPE) { - /* set sector offsets for bottom boot block type */ - info->start[0] = base + 0x00000000; - info->start[1] = base + 0x00004000; - info->start[2] = base + 0x00006000; - info->start[3] = base + 0x00008000; - for (i = 4; i < info->sector_count; i++) { - info->start[i] = base + (i * 0x00010000) - 0x00030000; - } - } else { - /* set sector offsets for top boot block type */ - i = info->sector_count - 1; - info->start[i--] = base + info->size - 0x00004000; - info->start[i--] = base + info->size - 0x00006000; - info->start[i--] = base + info->size - 0x00008000; - for (; i >= 0; i--) { - info->start[i] = base + i * 0x00010000; - } - } - - /* check for protected sectors */ - for (i = 0; i < info->sector_count; i++) { - /* read sector protection at sector address, (A7 .. A0) = 0x02 */ - /* D0 = 1 if protected */ - addr2 = (volatile FLASH_WORD_SIZE *)(info->start[i]); - if (info->flash_id & FLASH_MAN_SST) - info->protect[i] = 0; - else - info->protect[i] = addr2[2] & 1; - } - - /* - * Prevent writes to uninitialized FLASH. - */ - if (info->flash_id != FLASH_UNKNOWN) { - addr2 = (FLASH_WORD_SIZE *)info->start[0]; - *addr2 = (FLASH_WORD_SIZE)0x00F000F0; /* reset bank */ - } - - return (info->size); -} - -#endif - - -int -flash_erase(flash_info_t *info, int s_first, int s_last) -{ - volatile FLASH_WORD_SIZE *addr = (FLASH_WORD_SIZE *)(info->start[0]); - int flag, prot, sect, l_sect; - ulong start, now, last; - unsigned char sh8b; - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - if ((info->flash_id == FLASH_UNKNOWN) || - (info->flash_id > (FLASH_MAN_STM | FLASH_AMD_COMP))) { - printf ("Can't erase unknown flash type - aborted\n"); - return 1; - } - - prot = 0; - for (sect=s_first; sect<=s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - printf ("\n"); - } - - l_sect = -1; - - /* Check the ROM CS */ - if ((info->start[0] >= ROM_CS1_START) && (info->start[0] < ROM_CS0_START)) - sh8b = 3; - else - sh8b = 0; - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - addr[ADDR0 << sh8b] = (FLASH_WORD_SIZE)0x00AA00AA; - addr[ADDR1 << sh8b] = (FLASH_WORD_SIZE)0x00550055; - addr[ADDR0 << sh8b] = (FLASH_WORD_SIZE)0x00800080; -
