[PATCH v3 1/2] imx8mm-evk: Generate a single bootable flash.bin again
After the conversion to binman in commit 8996e6b7c6a1 ("imx8mm_evk: switch to use binman to pack images"), it is necessary to flash both flash.bin and u-boot.itb to get a bootable system. Prior to this commit, only flash.bin was needed.
Such new requirement breaks existing distro mechanisms to generate the final binary because the extra u-boot.itb is now required.
Generate a final flash.bin that can be used again as a single bootable binary to keep the original behavior.
After this change the SPL binary is called spl.bin, which is a more descriptive name for its purpose, and can still be used standalone (for example, for secure boot purposes).
Also update imx8mm_evk.rst to remove the u-boot.itb copy step.
Signed-off-by: Fabio Estevam festevam@denx.de Reviewed-by: Frieder Schrempf frieder.schrempf@kontron.de Reviewed-by: Heiko Schocher hs@denx.de
Signed-off-by: Fabio Estevam festevam@denx.de --- Changes since v2: - Change the LOADER to mkimage.spl.mkimage (Frieder)
arch/arm/dts/imx8mm-evk-u-boot.dtsi | 17 ++++++++++++++++- .../imx8mm_evk/imximage-8mm-lpddr4.cfg | 2 +- doc/board/freescale/imx8mm_evk.rst | 1 - 3 files changed, 17 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/imx8mm-evk-u-boot.dtsi b/arch/arm/dts/imx8mm-evk-u-boot.dtsi index f200afac9f..75cd59e545 100644 --- a/arch/arm/dts/imx8mm-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-evk-u-boot.dtsi @@ -150,7 +150,7 @@ };
- flash { + spl { mkimage { args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x7e1000";
@@ -217,4 +217,19 @@ }; }; }; + + imx-boot { + filename = "flash.bin"; + pad-byte = <0x00>; + + spl: blob-ext@1 { + offset = <0x0>; + filename = "spl.bin"; + }; + + uboot: blob-ext@2 { + offset = <0x57c00>; + filename = "u-boot.itb"; + }; + }; }; diff --git a/board/freescale/imx8mm_evk/imximage-8mm-lpddr4.cfg b/board/freescale/imx8mm_evk/imximage-8mm-lpddr4.cfg index b89092a559..2c15dbc413 100644 --- a/board/freescale/imx8mm_evk/imximage-8mm-lpddr4.cfg +++ b/board/freescale/imx8mm_evk/imximage-8mm-lpddr4.cfg @@ -6,4 +6,4 @@ #define __ASSEMBLY__
BOOT_FROM sd -LOADER mkimage.flash.mkimage 0x7E1000 +LOADER mkimage.spl.mkimage 0x7E1000 diff --git a/doc/board/freescale/imx8mm_evk.rst b/doc/board/freescale/imx8mm_evk.rst index 7fd3d72564..b377c4de27 100644 --- a/doc/board/freescale/imx8mm_evk.rst +++ b/doc/board/freescale/imx8mm_evk.rst @@ -50,7 +50,6 @@ Burn the flash.bin to MicroSD card offset 33KB: .. code-block:: bash
$sudo dd if=flash.bin of=/dev/sd[x] bs=1024 seek=33 conv=notrunc - $sudo dd if=u-boot.itb of=/dev/sdc bs=1024 seek=384 conv=sync
Boot ----
Clean the binaries generated by binman on imx8mm-evk: spl.* mkimage*.mkimage imx-boot.*
Reported-by: Frieder Schrempf frieder.schrempf@kontron.de Signed-off-by: Fabio Estevam festevam@denx.de --- Changes since v2: - None. Newly introducedin this series.
Makefile | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index 3c8437d21a..7096fdf895 100644 --- a/Makefile +++ b/Makefile @@ -2095,7 +2095,8 @@ CLEAN_FILES += include/bmp_logo.h include/bmp_logo_data.h tools/version.h \ boot* u-boot* MLO* SPL System.map fit-dtb.blob* \ u-boot-ivt.img.log u-boot-dtb.imx.log SPL.log u-boot.imx.log \ lpc32xx-* bl31.c bl31.elf bl31_*.bin image.map tispl.bin* \ - idbloader.img flash.bin flash.log defconfig keep-syms-lto.c + idbloader.img flash.bin flash.log defconfig keep-syms-lto.c \ + spl.* mkimage*.mkimage imx-boot.*
# Directories & files removed with 'make mrproper' MRPROPER_DIRS += include/config include/generated spl tpl \
Hi Fabio,
Am Do., 19. Aug. 2021 um 21:28 Uhr schrieb Fabio Estevam festevam@denx.de:
Changes since v2:
it might be useful to use one variable for all BINMAN clean files. Otherwise it is difficult to understand by whom the files were created.
Something like that:
--- a/Makefile +++ b/Makefile @@ -2091,12 +2091,14 @@ CLEAN_DIRS += $(MODVERDIR) \ $(foreach d, spl tpl, $(patsubst %,$d/%, \ $(filter-out include, $(shell ls -1 $d 2>/dev/null))))
+BINMAN_CLEAN_FILES = spl.* mkimage*.mkimage + CLEAN_FILES += include/bmp_logo.h include/bmp_logo_data.h tools/version.h \ boot* u-boot* MLO* SPL System.map fit-dtb.blob* \ u-boot-ivt.img.log u-boot-dtb.imx.log SPL.log u-boot.imx.log \ lpc32xx-* bl31.c bl31.elf bl31_*.bin image.map tispl.bin* \ idbloader.img flash.bin flash.log defconfig keep-syms-lto.c \ - spl.* mkimage*.mkimage imx-boot.* + imx-boot.* $(BINMAN_CLEAN_FILES) +
I had the idea, if binman could create a list with the created files. This could then be used to set the files to be deleted. I think of other users where the output files have a different name. Then the files could be deleted "automatically" with clean.
Am Fr., 20. Aug. 2021 um 07:34 Uhr schrieb Heiko Thiery heiko.thiery@gmail.com:
Hi Fabio,
Changes since v2:
While looking at it a second time, I noticed that itb.fit.fit and itb.fit.itb were also created by binman.
Hi Fabio,
Changes since v2:
flash {
imx-boot {
pad-byte = <0x00>;
spl: blob-ext@1 {
offset = <0x0>;
uboot: blob-ext@2 {
offset = <0x57c00>;
Boot
-- 2.25.1
When building from a clean checkout I see the following warnings. It seems that there are some dependency checks that are looking for the files in mkimage config file.
AR arch/arm/lib/lib.a AS arch/arm/lib/crt0_aarch64_efi.o CC arch/arm/lib/reloc_aarch64_efi.o WARNING 'mkimage.spl.mkimage' not found, resulting binary is not-functional AS arch/arm/mach-imx/imx8m/lowlevel_init.o CC arch/arm/mach-imx/imx8m/clock_slice.o CC arch/arm/mach-imx/imx8m/soc.o : : AS spl/arch/arm/lib/crt0_aarch64_efi.o CC spl/arch/arm/lib/reloc_aarch64_efi.o WARNING 'mkimage.spl.mkimage' not found, resulting binary is not-functional AS spl/arch/arm/mach-imx/imx8m/lowlevel_init.o CC spl/arch/arm/mach-imx/imx8m/clock_slice.o CC spl/arch/arm/mach-imx/imx8m/soc.o : : COPY spl/u-boot-spl.bin SYM spl/u-boot-spl.sym WARNING 'mkimage.spl.mkimage' not found, resulting binary is not-functional make[1]: Nothing to be done for 'SPL'. OBJCOPY u-boot.srec OBJCOPY u-boot-nodtb.bin
Yes, I believe it really requires explicitly setting the filename as I previously suggested.
Hi Heiko and Marcel,
On Fri, Aug 20, 2021 at 4:31 AM Marcel Ziswiler marcel.ziswiler@toradex.com wrote:
Peng Fan has sent a patch fixing this: https://www.mail-archive.com/u-boot@lists.denx.de/msg414966.html
Thanks
Hi Fabio,
Ah ok. Thanks
On Fri, 2021-08-20 at 12:47 +0200, Heiko Thiery wrote:
Hi Fabio,
Ah ok. Thanks
Yes, I can confirm that Peng's patch fixes this. I guess, me explicitly adding the filename did not really change anything but due to me running make again it subsequently picked up the previously generated artifact. Sorry for the noise.
Hi Heiko Thiery and Marcel,
flash {
- spl { mkimage { args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x7e1000";
- imx-boot {
pad-byte = <0x00>;
spl: blob-ext@1 {
offset = <0x0>;
uboot: blob-ext@2 {
offset = <0x57c00>;
Do we have a consensus on the binman format to generate a monolithic flash.bin?
I understand that patch 2/2 still needs to be improved, but what about this one?
Thanks,
Fabio Estevam
Hi Fabio
Yes, I would say so. Remember, I did include this already in our latest verdin-imx8mm specific patch set together with its migration to using binman [1].
Yes, I agree.
Reviewed-by: Marcel Ziswiler marcel.ziswiler@toradex.com
[1] https://marc.info/?l=u-boot&m=162949278629882
Thanks,
Fabio Estevam
Cheers
Marcel
Hi Fabio,
After the conversion to binman in commit 8996e6b7c6a1 ("imx8mm_evk: switch to use binman to pack images"), it is necessary to flash both flash.bin and u-boot.itb to get a bootable system. Prior to this commit, only flash.bin was needed. and if it is not Such new requirement breaks existing distro mechanisms to generate the final binary because the extra u-boot.itb is now required.
Changes since v2:
flash {
imx-boot {
pad-byte = <0x00>;
spl: blob-ext@1 {
offset = <0x0>;
uboot: blob-ext@2 {
offset = <0x57c00>;
I think the "mkimage.spl.mkimage" is a temporarily created file from binman. Isn't it correct to use the output file of the binman image u-boot-spl-ddr ("u-boot-spl-ddr.bin") here?
On Mon, 2021-08-23 at 13:55 +0200, Heiko Thiery wrote:
Hi Fabio,
Changes since v2:
+ uboot: blob-ext@2 { + offset = <0x57c00>; + filename = "u-boot.itb"; + }; + }; }; diff --git a/board/freescale/imx8mm_evk/imximage-8mm-lpddr4.cfg b/board/freescale/imx8mm_evk/imximage-8mm- lpddr4.cfg index b89092a559..2c15dbc413 100644 --- a/board/freescale/imx8mm_evk/imximage-8mm-lpddr4.cfg +++ b/board/freescale/imx8mm_evk/imximage-8mm-lpddr4.cfg @@ -6,4 +6,4 @@ #define __ASSEMBLY__
Yes, looking at it again, that really seems the proper one and I can confirm that this works fine.
Hi Heiko,
I did as you suggested in v4. Please reply with your Reviewed-by if it looks good to you.
Also, I dropped the 2/2 patch (cleaning of the binman files) as it needs improvement.
Could you please take care of the binman files cleanup mechanism?
Thanks,
Fabio Estevam
-- Heiko
Hi Fabio,
Am Mo., 23. Aug. 2021 um 14:16 Uhr schrieb Fabio Estevam festevam@gmail.com:
Hi Heiko,
Yes, I will see what I can do.
-- Heiko
Fabio Estevam
Fabio Estevam
Heiko Thiery
Marcel Ziswiler
