[PATCH] bosch: Add inital board support for ACC
The Bosch ACC (Air Center Control) Board is based on the i.MX6D.
Signed-off-by: Philip Oberfichtner pro@denx.de
This board supports depends on: - "Add pmic bootcount driver", patchwork id 287976 - "crypto/fsl: Fallback to SW sha1/256 is misaligned buffers", patchwork id 270524
--- arch/arm/dts/Makefile | 1 + arch/arm/dts/imx6q-acc-common.dtsi | 885 +++++++++++++++++++++++++++++ arch/arm/dts/imx6q-acc-u-boot.dtsi | 71 +++ arch/arm/dts/imx6q-acc.dts | 281 +++++++++ arch/arm/mach-imx/mx6/Kconfig | 15 + board/bosch/acc/Kconfig | 18 + board/bosch/acc/MAINTAINERS | 10 + board/bosch/acc/Makefile | 6 + board/bosch/acc/acc.c | 737 ++++++++++++++++++++++++ configs/imx6q_acc_defconfig | 107 ++++ include/configs/imx6q-acc.h | 165 ++++++ 11 files changed, 2296 insertions(+) create mode 100644 arch/arm/dts/imx6q-acc-common.dtsi create mode 100644 arch/arm/dts/imx6q-acc-u-boot.dtsi create mode 100644 arch/arm/dts/imx6q-acc.dts create mode 100644 board/bosch/acc/Kconfig create mode 100644 board/bosch/acc/MAINTAINERS create mode 100644 board/bosch/acc/Makefile create mode 100644 board/bosch/acc/acc.c create mode 100644 configs/imx6q_acc_defconfig create mode 100644 include/configs/imx6q-acc.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 960f1a9fd4..45db1e51a9 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -810,6 +810,7 @@ dtb-y += \ imx6q-sabreauto.dtb \ imx6q-sabrelite.dtb \ imx6q-sabresd.dtb \ + imx6q-acc.dtb \ imx6q-tbs2910.dtb \ imx6q-wandboard-revd1.dtb \ imx6qp-sabreauto.dtb \ diff --git a/arch/arm/dts/imx6q-acc-common.dtsi b/arch/arm/dts/imx6q-acc-common.dtsi new file mode 100644 index 0000000000..b70d08ceb8 --- /dev/null +++ b/arch/arm/dts/imx6q-acc-common.dtsi @@ -0,0 +1,885 @@ +// SPDX-License-Identifier: GPL-2.0 + +/* Support for the i.MX6-based Bosch ACC board. + * + * Copyright (c) 2016 Garz & Fricke GmbH + * Copyright (c) 2018 DENX Software Engineering GmbH + * Heiko Schocher hs@denx.de + * Niel Fourie lusus@denx.de + * Copyright (c) 2019,2020 Bosch Thermotechnik GmbH + * + * Based on work from: + * Copyright 2013 Freescale Semiconductor, Inc. + * + * Author: Fabio Estevam fabio.estevam@freescale.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +#include <dt-bindings/gpio/gpio.h> + +/ { + soc { + bus@2000000 { + usbphy_nop1: usbphy_nop1 { + compatible = "usb-nop-xceiv"; + clocks = <&clks IMX6QDL_CLK_USBPHY1>; + clock-names = "main_clk"; + }; + }; + }; + + wdt-reboot { + compatible = "wdt-reboot"; + wdt = <&wdog1>; + }; + + backlight: backlight { + status = "okay"; + + compatible = "pwm-backlight"; + pwms = <&pwm1 0 50000>; + brightness-levels = <0 63 95 159 255 383 543 735 959 1215 1503>; + num-interpolated-steps = <10>; + default-brightness-level = <100>; + power-supply = <®_lcd0_pwr>; + }; + + clk_12mhz_ref:clk_12mhz_ref { + compatible = "fixed-factor-clock"; + + clocks = <&clks 201>; + clock-names = "cko"; + clock-div = <1>; + clock-mult = <1>; + + #clock-cells = <0>; + clock-output-names = "ck12mhzref"; + }; + + leds { + compatible = "pwm-leds"; + + led_red: red { + label = "red"; + max-brightness = <248>; + default-state = "off"; + pwms = <&pwm2 0 500000>; + }; + + led_white: white { + label = "white"; + max-brightness = <248>; + default-state = "off"; + pwms = <&pwm3 0 500000>; + linux,default-trigger = "heartbeat"; + }; + }; + + + /* Third gpio option are the flags, with custom meaning. */ + /* bit 1 act-low */ + /* bit 2 init high */ + + gpio_export_keypad_fixed_in { + compatible = "gpio-export-of"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_export_gpio_fixed_in>; + dir-not-changeable; + dir-input; + + gpios = + <&gpio5 22 0>, /* DIG_IN1 */ + <&gpio5 23 0>, /* DIG_IN2 */ + <&gpio4 10 1>; /* CLEAR_ALL */ + + gpio-names = "DIG_IN1", + "DIG_IN2", + "CLEAR_ALL"; + + status = "okay"; + }; + + reset_gpio_led { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reset_gpio_led>; + + reset { + label = "red_reset"; + gpios = <&gpio5 18 0>; + default-state = "off"; + }; + }; + + gpio_export_keypad_fixed_out { + compatible = "gpio-export-of"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_export_gpio_fixed_out>; + + dir-not-changeable; + dir-output; + + /* Sysfs kp gpios with changeable direction */ + gpios = + <&gpio5 24 0>, /* DIG_OUT_1 */ + <&gpio5 25 0>, /* DIG_OUT_2 */ + <&gpio1 7 0>, /* AN_IN_PWR */ + <&gpio1 8 0>, /* AN_OUT_PWR */ + <&gpio4 16 3>, /* nUART_RESET */ + <&gpio4 17 0>, /* RS485#2_PWR */ + <&gpio4 18 3>, /* nETH1_RESET */ + <&gpio4 19 3>, /* nETH2_RESET */ + <&gpio4 20 0>, /* RS485#1_PWR */ + <&gpio4 21 0>, /* RS485#3_PWR */ + <&gpio4 22 0>, /* RS485#4_PWR */ + <&gpio4 27 3>, /* FEC_RESET_B */ + <&gpio1 0 3>, /* nUSBH1_PWR */ + <&gpio4 5 0>; /* RS485#0_PWR */ + + gpio-names = "DIG_OUT_1", + "DIG_OUT_2", + "AN_IN_PWR", + "AN_OUT_PWR", + "nUART_RESET", + "RS485#2_PWR", + "nETH1_RESET", + "nETH2_RESET", + "RS485#1_PWR", + "RS485#3_PWR", + "RS485#4_PWR", + "FEC_RESET_B", + "nUSBH1_PWR", + "RS485#0_PWR"; + + status = "okay"; + }; + + regulators: regulators { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + supply_5P0: regulator@0 { + compatible = "regulator-fixed"; + reg = <0>; + regulator-name = "5P0"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; + + supply_VIN: regulator@1 { + compatible = "regulator-fixed"; + reg = <1>; + regulator-name = "VIN"; + regulator-min-microvolt = <4500000>; + regulator-max-microvolt = <4500000>; + regulator-always-on; + vin-supply = <&supply_5P0>; + }; + + reg_usb_otg_vbus: regulator@2 { + compatible = "regulator-fixed"; + reg = <2>; + regulator-name = "usb_otg_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + reg_usb_h1_vbus: regulator@3 { + compatible = "regulator-fixed"; + reg = <3>; + regulator-name = "usb_h1_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + vin-supply = <&supply_5P0>; + }; + + supply_VSNVS_3V0: regulator@4 { + compatible = "regulator-fixed"; + reg = <4>; + regulator-name = "VSNVS_3V0"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-always-on; + vin-supply = <&supply_5P0>; + }; + + reg_lcd0_pwr: regulator-lcd0-pwr { + compatible = "regulator-fixed"; + regulator-name = "LCD0 POWER"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lcd_enable>; + gpio = <&gpio3 23 GPIO_ACTIVE_HIGH>; + enable-active-high; + regulator-boot-on; + }; + + reg_usb_h2_vbus: regulator@6 { + compatible = "regulator-fixed"; + reg = <6>; + regulator-name = "usb_h2_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&supply_5P0> ; + regulator-always-on; + }; + + supply_vref_dac: vref_dac { + compatible = "regulator-fixed"; + regulator-name = "vref_dac"; + regulator-min-microvolt = <20000>; + regulator-max-microvolt = <20000>; + vin-supply = <&supply_5P0> ; + regulator-boot-on; + }; + }; +}; + +&anatop { + reg_1p1: regulator-1p1 { + compatible = "fsl,anatop-regulator"; + regulator-name = "vdd1p1"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1375000>; + regulator-always-on; + anatop-reg-offset = <0x110>; + anatop-vol-bit-shift = <8>; + anatop-vol-bit-width = <5>; + anatop-min-bit-val = <4>; + anatop-min-voltage = <800000>; + anatop-max-voltage = <1375000>; + anatop-enable-bit = <0>; + }; + + reg_2p5: regulator-2p5 { + compatible = "fsl,anatop-regulator"; + regulator-name = "vdd2p5"; + regulator-min-microvolt = <2000000>; + regulator-max-microvolt = <2750000>; + regulator-always-on; + anatop-reg-offset = <0x130>; + anatop-vol-bit-shift = <8>; + anatop-vol-bit-width = <5>; + anatop-min-bit-val = <0>; + anatop-min-voltage = <2000000>; + anatop-max-voltage = <2750000>; + anatop-enable-bit = <0>; + }; + + reg_3p0: regulator-3p0 { + compatible = "fsl,anatop-regulator"; + regulator-name = "vdd3p0"; + regulator-min-microvolt = <2625000>; + regulator-max-microvolt = <3400000>; + anatop-reg-offset = <0x120>; + anatop-vol-bit-shift = <8>; + anatop-vol-bit-width = <5>; + anatop-min-bit-val = <0>; + anatop-min-voltage = <2625000>; + anatop-max-voltage = <3400000>; + anatop-enable-bit = <0>; + }; +}; + +&audmux { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_audmux>; + status = "okay"; +}; + +&i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + clock-frequency = <400000>; + status = "okay"; + + lm75: lm75@49 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lm75>; + + compatible = "national,lm75b"; + reg = <0x49>; + + interrupts = <7 0x4>; + interrupt-parent = <&gpio4>; + }; + + eeprom: eeprom@50 { + compatible = "atmel,24c32"; + reg = <0x50>; + pagesize = <32>; + bytelen = <4096>; + bus-id = <0>; + flags = <0x80>; /* AT24_FLAG_ADDR16 */ + }; + + rtc: rtcpcf8563@51 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_rtc>; + + compatible = "nxp,pcf8563"; + reg = <0x51>; + }; +}; + +&i2c2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + clock-frequency = <100000>; + status = "okay"; + + adc101c: ac101c@54 { + compatible = "ti,adc101c"; + reg = <0x54>; + status = "okay"; + vref-supply = <&supply_vref_dac>; + vcc-supply = <&supply_vref_dac>; + }; + + ad5602: ad5602@c { + compatible = "adi,ad5602"; + reg = <0x0c>; + status = "okay"; + vcc-supply = <&supply_vref_dac>; + }; + + eeprom_ext: eeprom_ext@50 { + compatible = "atmel,24c32"; + reg = <0x50>; + pagesize = <32>; + bytelen = <4096>; + bus-id = <1>; + flags = <0x80>; /* AT24_FLAG_ADDR16 */ + }; +}; + +&i2c3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + clock-frequency = <400000>; + status = "okay"; + + usb3503:usb3503@8 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb3503>; + status = "ok"; + + compatible = "smsc,usb3503"; + reg = <0x08>; + refclk-frequency = <12000000>; + connect-gpios = <&gpio1 16 0>; + intn-gpios = <&gpio7 12 1>; + reset-gpios = <&gpio5 5 0>; + initial-mode = <1>; + clocks = <&clks IMX6QDL_CLK_CKO>; + clock-names = "cko"; + }; + + vcnl4035: vcnl4035@60 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_proximity>; + compatible = "vishay,vcnl4035"; + reg = <0x60>; + status = "okay"; + interrupts = <11 IRQ_TYPE_LEVEL_LOW>; + interrupt-parent = <&gpio4>; + }; + +}; + +&ldb { + status = "okay"; + + lvds0: lvds-channel@0 { + fsl,data-mapping = "spwg"; + fsl,data-width = <24>; + status = "okay"; + + display-timings { + native-mode = <&lvds0_timing0>; + + lvds0_timing0: hsd100pxn1 { + clock-frequency = <79479000>; + hactive = <1280>; + vactive = <800>; + hback-porch = <100>; + hfront-porch = <100>; + vback-porch = <5>; + vfront-porch = <5>; + hsync-len = <24>; + vsync-len = <3>; + hsync-active = <0>; + vsync-active = <0>; + de-active = <1>; + pixelclk-active = <1>; + }; + }; + }; +}; + +&pwm1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm1>; + status = "okay"; +}; + +&pwm2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm2>; + status = "okay"; +}; + +&pwm3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm3>; + status = "okay"; + linux,default-trigger = "heartbeat"; +}; + +&pwm4 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm4>; + status = "okay"; +}; + +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog1>; + fsl,ext-reset-output; + status = "okay"; + timeout-sec=<10>; +}; + +&wdog2 { + status = "disabled"; +}; + +&iomuxc { + pinctrl-0 = <&pinctrl_hog &pinctrl_pfid_0_2 &pinctrl_pfid_3_4 &pinctrl_pfid_5_7 &pinctrl_pfid_8_9>; + pinctrl-names = "default"; + + pinctrl_audmux: audmuxgrp { + fsl,pins = < + MX6QDL_PAD_DISP0_DAT20__AUD4_TXC 0x130b0 + MX6QDL_PAD_DISP0_DAT21__AUD4_TXD 0x130b0 + MX6QDL_PAD_DISP0_DAT22__AUD4_TXFS 0x110b0 + MX6QDL_PAD_DISP0_DAT23__AUD4_RXD 0x130b0 + >; + }; + + pinctrl_enet: enetgrp { + fsl,pins = < + MX6QDL_PAD_ENET_MDC__ENET_MDC 0x1b0b0 + MX6QDL_PAD_ENET_MDIO__ENET_MDIO 0x1b0b0 + MX6QDL_PAD_ENET_CRS_DV__ENET_RX_EN 0x1b0b0 + MX6QDL_PAD_ENET_REF_CLK__GPIO1_IO23 0x1b0b0 /* FEC INT */ + MX6QDL_PAD_ENET_RX_ER__ENET_RX_ER 0x1b0b0 + MX6QDL_PAD_ENET_TX_EN__ENET_TX_EN 0x0001B098 + MX6QDL_PAD_ENET_RXD0__ENET_RX_DATA0 0x1b0b0 + MX6QDL_PAD_ENET_RXD1__ENET_RX_DATA1 0x1b0b0 + MX6QDL_PAD_ENET_TXD1__ENET_TX_DATA1 0x0001B098 + MX6QDL_PAD_ENET_TXD0__ENET_TX_DATA0 0x0001B098 + MX6QDL_PAD_GPIO_16__ENET_REF_CLK 0x4001b0a8 + >; + }; + + pinctrl_gpio_export_gpio_fixed_in: pinctrl_gpio_export_gpio_fixed_in_grp { + fsl,pins = < + MX6QDL_PAD_KEY_COL2__GPIO4_IO10 0x80000000 /* CLEAR ALL */ + MX6QDL_PAD_CSI0_DAT4__GPIO5_IO22 0x80000000 /* DIG_IN_1 */ + MX6QDL_PAD_CSI0_DAT5__GPIO5_IO23 0x80000000 /* DIG_IN_2 */ + >; + }; + + pinctrl_reset_gpio_led: pinctrl_reset_gpio_led_pin { + fsl,pins = < + MX6QDL_PAD_CSI0_PIXCLK__GPIO5_IO18 0x0001B0B0 + >; + }; + + pinctrl_gpio_export_gpio_fixed_out: pinctrl_gpio_export_gpio_fixed_out_grp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT6__GPIO5_IO24 0x0001B0B0 /* DIG_OUT_1 */ + MX6QDL_PAD_CSI0_DAT7__GPIO5_IO25 0x0001B0B0 /* DIG_OUT_2 */ + MX6QDL_PAD_DI0_DISP_CLK__GPIO4_IO16 0x0001B0B0 /* nUART_RESET */ + MX6QDL_PAD_DI0_PIN2__GPIO4_IO18 0x0001B0B0 /* nETH1_RESET */ + MX6QDL_PAD_DI0_PIN3__GPIO4_IO19 0x0001B0B0 /* nETH2_RESET */ + MX6QDL_PAD_DI0_PIN4__GPIO4_IO20 0x0001B0B0 /* RS485#1_PWR */ + MX6QDL_PAD_DI0_PIN15__GPIO4_IO17 0x0001B0B0 /* RS485#2_PWR */ + MX6QDL_PAD_DISP0_DAT0__GPIO4_IO21 0x0001B0B0 /* RS485#3_PWR */ + MX6QDL_PAD_DISP0_DAT1__GPIO4_IO22 0x0001B0B0 /* RS485#4_PWR */ + MX6QDL_PAD_DISP0_DAT6__GPIO4_IO27 0x0001B0B0 /* FEC_RESET_B */ + MX6QDL_PAD_GPIO_7__GPIO1_IO07 0x0001B0B0 /* AN_IN_PWR */ + MX6QDL_PAD_GPIO_8__GPIO1_IO08 0x0001B0B0 /* AN_OUT_PWR */ + MX6QDL_PAD_GPIO_0__GPIO1_IO00 0x0001B0B0 /* nUSBH1_PWR */ + >; + }; + + pinctrl_hog: hoggrp { + fsl,pins = < + /* Clock out 12Mhz Ref */ + MX6QDL_PAD_CSI0_MCLK__CCM_CLKO1 0x17059 /* PAD_CTL_PKE | PAD_CTL_PUE | PAD_CTL_PUS_47K_UP | PAD_CTL_SPEED_LOW | PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS */ + /* (1 << 12) | (1 << 13) |(1 << 14) | (1 << 6) | (3 << 3) |(1 << 0) | (1 << 16) */ + /* not used SD2 and SD3 pins */ + MX6QDL_PAD_SD3_CLK__GPIO7_IO03 0x0001B0B0 + MX6QDL_PAD_SD3_CMD__GPIO7_IO02 0x0001B0B0 + MX6QDL_PAD_EIM_CS0__GPIO2_IO23 0x0000B0B1 + MX6QDL_PAD_EIM_D17__GPIO3_IO17 0x0001B0B0 + MX6QDL_PAD_EIM_D18__GPIO3_IO18 0x0001B0B0 + MX6QDL_PAD_EIM_D20__GPIO3_IO20 0x0001B0B0 + MX6QDL_PAD_EIM_OE__GPIO2_IO25 0x0000B0B1 + MX6QDL_PAD_NANDF_CS2__GPIO6_IO15 0x0001B0B0 + MX6QDL_PAD_NANDF_D0__GPIO2_IO00 0x0001B8B1 + MX6QDL_PAD_NANDF_D1__GPIO2_IO01 0x0001B8B1 + MX6QDL_PAD_NANDF_D2__GPIO2_IO02 0x000138B1 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT8__I2C1_SDA 0x4001b8b1 + MX6QDL_PAD_CSI0_DAT9__I2C1_SCL 0x4001b8b1 + >; + }; + + pinctrl_i2c1_gpio: i2c1grp-gpio { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT8__GPIO5_IO26 0x80000000 + MX6QDL_PAD_CSI0_DAT9__GPIO5_IO27 0x80000000 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX6QDL_PAD_KEY_COL3__I2C2_SCL 0x4001b810 + MX6QDL_PAD_KEY_ROW3__I2C2_SDA 0x4001b810 + /* NO SRE | 130 Ohm | SPEED LOW | Open Drain | PKE | PUE | 100k PU | HYS */ + >; + }; + + pinctrl_i2c2_gpio: i2c2grp-gpio { + fsl,pins = < + MX6QDL_PAD_KEY_COL3__GPIO4_IO12 0x80000000 + MX6QDL_PAD_KEY_ROW3__GPIO4_IO13 0x80000000 + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX6QDL_PAD_GPIO_5__I2C3_SCL 0x4001b8b1 + MX6QDL_PAD_GPIO_6__I2C3_SDA 0x4001b8b1 + >; + }; + + pinctrl_i2c3_gpio: i2c3grp-gpio { + fsl,pins = < + MX6QDL_PAD_GPIO_5__GPIO1_IO05 0x80000000 + MX6QDL_PAD_GPIO_6__GPIO1_IO06 0x80000000 + >; + }; + + pinctrl_lcd_enable: lcdenablerp { + fsl,pins = < + MX6QDL_PAD_EIM_D23__GPIO3_IO23 0x80000000 /* lcd enable */ + MX6QDL_PAD_EIM_D16__GPIO3_IO16 0x80000000 /* sel6_8 */ + >; + }; + + pinctrl_lm75: lm75grp { + fsl,pins = < + MX6QDL_PAD_KEY_ROW0__GPIO4_IO07 0x80000000 + >; + }; + + pinctrl_pfid_0_2: pfid_0_2_grp { + fsl,pins = < + MX6QDL_PAD_NANDF_D0__GPIO2_IO00 0x0001B0B0 + MX6QDL_PAD_NANDF_D1__GPIO2_IO01 0x0001B0B0 + MX6QDL_PAD_NANDF_D2__GPIO2_IO02 0x0001B0B0 + >; + }; + + pinctrl_pfid_3_4: pfid_3_4_grp { + fsl,pins = < + MX6QDL_PAD_NANDF_D3__GPIO2_IO03 0x0001B0B0 + MX6QDL_PAD_NANDF_D4__GPIO2_IO04 0x0001B0B0 + >; + }; + + pinctrl_pfid_5_7: pfid_5_7_grp { + fsl,pins = < + MX6QDL_PAD_NANDF_D5__GPIO2_IO05 0x0001B0B0 + MX6QDL_PAD_NANDF_D6__GPIO2_IO06 0x0001B0B0 + MX6QDL_PAD_NANDF_D7__GPIO2_IO07 0x0001B0B0 + >; + }; + + pinctrl_pfid_8_9: pfid_8_9_grp { + fsl,pins = < + MX6QDL_PAD_NANDF_CS3__GPIO6_IO16 0x0001B0B0 + MX6QDL_PAD_NANDF_CS1__GPIO6_IO14 0x0001B0B0 + >; + }; + + pinctrl_proximity: proximitygrp { + fsl,pins = < + /* PROXIMITY_INT */ + MX6QDL_PAD_KEY_ROW2__GPIO4_IO11 0x80000000 + >; + }; + + pinctrl_pwm1: pwm1grp { + fsl,pins = < + MX6QDL_PAD_SD1_DAT3__PWM1_OUT 0x0001B0B0 + >; + }; + + pinctrl_pwm2: pwm2grp { + fsl,pins = < + MX6QDL_PAD_SD1_DAT2__PWM2_OUT 0x0001B0B0 + >; + }; + + pinctrl_pwm3: pwm3grp { + fsl,pins = < + MX6QDL_PAD_SD1_DAT1__PWM3_OUT 0x0001B0B0 + >; + }; + + + pinctrl_pwm4: pwm4grp { + fsl,pins = < + MX6QDL_PAD_SD1_CMD__PWM4_OUT 0x0001B0B0 + >; + }; + + pinctrl_rtc: rtc-grp { + fsl,pins = < + MX6QDL_PAD_KEY_COL1__GPIO4_IO08 0x80000000 /* RTC INT */ + >; + }; + + pinctrl_ctouch: ctouch-grp { + fsl,pins = < + MX6QDL_PAD_KEY_COL0__GPIO4_IO06 0x80000000 /* CTOUCH_INT */ + MX6QDL_PAD_SD1_CLK__GPIO1_IO20 0x0001B0B0 /* CTOUCH_RESET */ + >; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = < + MX6QDL_PAD_SD3_DAT6__UART1_RX_DATA 0x1b0b1 + MX6QDL_PAD_SD3_DAT7__UART1_TX_DATA 0x1b0b1 + MX6QDL_PAD_SD3_RST__GPIO7_IO08 0x0001B0B0 + >; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = < + MX6QDL_PAD_SD3_DAT4__UART2_RX_DATA 0x1b0b1 + MX6QDL_PAD_SD3_DAT5__UART2_TX_DATA 0x1b0b1 + MX6QDL_PAD_EIM_D28__UART2_CTS_B 0x1b0b1 + MX6QDL_PAD_EIM_D29__UART2_RTS_B 0x1b0b1 + >; + }; + + pinctrl_usbh2: usbh2grp { + fsl,pins = < + MX6QDL_PAD_RGMII_TXC__USB_H2_DATA 0x00013018 /* 100K Pull-Down, 76_OHM drive strength */ + MX6QDL_PAD_RGMII_TX_CTL__USB_H2_STROBE 0x00013018 /* 100K Pull-Down, 76_OHM drive strength */ + >; + }; + + pinctrl_usbh2_enabled: usbh2_enabled_grp { + fsl,pins = < + MX6QDL_PAD_RGMII_TXC__USB_H2_DATA 0x00013018 /* 100K Pull-Down, 76_OHM drive strength */ + MX6QDL_PAD_RGMII_TX_CTL__USB_H2_STROBE 0x00017018 /* 47K Pull-Up, 76_OHM drive strength */ + >; + }; + + pinctrl_usb3503: pinctrl_usb3503-grp { + fsl,pins = < + MX6QDL_PAD_GPIO_17__GPIO7_IO12 0x80000000 /* USB INT */ + MX6QDL_PAD_DISP0_DAT11__GPIO5_IO05 0x0001B0B0 /* USB Reset */ + MX6QDL_PAD_SD1_DAT0__GPIO1_IO16 0x00000038 /* USB Connect */ /* Has DSE_120Ohm in Q and no_pad_ctrl in dl on 3.0.35*/ + >; + }; + + pinctrl_usbotg: usbotggrp { + fsl,pins = < + MX6QDL_PAD_GPIO_1__USB_OTG_ID 0x17059 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + /* CMD and DATA0..3 have external pull-up, CLK does not need a pull-up. + CLK signal is half the speed than the others (52 MHz compared to 104 MHz) */ + fsl,pins = < + MX6QDL_PAD_SD2_CMD__SD2_CMD 0x00017069 + MX6QDL_PAD_SD2_CLK__SD2_CLK 0x00010038 + MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x00017069 + MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x00017069 + MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x00017069 + MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x00017069 + MX6QDL_PAD_GPIO_4__SD2_CD_B 0x0001B0B0 + >; + }; + + pinctrl_usdhc4: usdhc4grp { + /* CMD has external pull-up, DATA0..7 within eMMC, CLK does not need a pull-up. + CLK signal is half the speed than the others (52 MHz compared to 104 MHz) */ + fsl,pins = < + MX6QDL_PAD_SD4_CMD__SD4_CMD 0x00017059 + MX6QDL_PAD_SD4_CLK__SD4_CLK 0x00010059 + MX6QDL_PAD_SD4_DAT0__SD4_DATA0 0x00017059 + MX6QDL_PAD_SD4_DAT1__SD4_DATA1 0x00017059 + MX6QDL_PAD_SD4_DAT2__SD4_DATA2 0x00017059 + MX6QDL_PAD_SD4_DAT3__SD4_DATA3 0x00017059 + MX6QDL_PAD_SD4_DAT4__SD4_DATA4 0x00017059 + MX6QDL_PAD_SD4_DAT5__SD4_DATA5 0x00017059 + MX6QDL_PAD_SD4_DAT6__SD4_DATA6 0x00017059 + MX6QDL_PAD_SD4_DAT7__SD4_DATA7 0x00017059 + >; + }; + + pinctrl_wdog1: wdoggrp { + fsl,pins = < + MX6QDL_PAD_GPIO_9__WDOG1_B 0x1b0b0 + >; + }; +}; + +&fec { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_enet>; + status = "okay"; + + clocks = <&clks IMX6QDL_CLK_ENET>, + <&clks IMX6QDL_CLK_ENET>, + <&clks IMX6QDL_CLK_ENET>, + <&clks IMX6QDL_CLK_ENET_REF>; + clock-names = "ipg", "ahb", "ptp", "enet_out"; + phy-mode = "rmii"; + phy-supply = <&supply_sw4_3V3>; + phy-handle = <ðphy>; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + ethphy: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0>; + interrupt-parent = <&gpio1>; + interrupts = <23 IRQ_TYPE_EDGE_FALLING>; + smsc,disable-energy-detect; + }; + }; +}; + +®_1p1 { + vin-supply = <&supply_VSNVS_3V0>; +}; + +®_3p0 { + vin-supply = <®_usb_h1_vbus>; +}; + +®_2p5 { + vin-supply = <&supply_VSNVS_3V0>; +}; + +&sdma { + fsl,sdma-ram-script-name = "imx/sdma/sdma-imx6q.bin"; + iram = <&ocram>; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + status = "okay"; + + rts-gpios = <&gpio7 8 0>; + linux,rs485-enabled-at-boot-time; + rs485-rx-during-tx; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + fsl,uart-has-rtscts; + status = "okay"; +}; + +&usbh1 { + status = "okay"; +}; + +&usbh2 { + pinctrl-names = "default", "enabled"; + pinctrl-0 = <&pinctrl_usbh2>; + pinctrl-1 = <&pinctrl_usbh2_enabled>; + status = "okay"; + + vbus-supply = <®_usb_h2_vbus>; + osc-clkgate-delay = <0x3>; + + phy_type = "hsic"; + fsl,usbphy = <&usbphy_nop1>; + fsl,anatop = <&anatop>; +}; + +&usbotg { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usbotg>; + status = "okay"; + + vbus-supply = <®_usb_otg_vbus>; + disable-over-current; + dr_mode = "otg"; + srp-disable; + hnp-disable; + adp-disable; +}; + +/* sdcard */ +&usdhc2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc2>; + status = "okay"; + + cd-gpios = <&gpio1 4 GPIO_ACTIVE_LOW>; + no-1-8-v; + keep-power-in-suspend; + enable-sdio-wakeup; + voltage-ranges = <3300 3300>; + vmmc-supply = <&supply_sw4_3V3>; +}; + +/* emmc */ +&usdhc4 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc4>; + status = "okay"; + + bus-width = <8>; + non-removable; + no-1-8-v; + keep-power-in-suspend; + voltage-ranges = <3300 3300>; + vmmc-supply = <&supply_sw4_3V3>; +}; + +&clks { + assigned-clocks = <&clks IMX6QDL_CLK_LDB_DI0_SEL>, + <&clks IMX6QDL_CLK_LDB_DI1_SEL>; + assigned-clock-parents = <&clks IMX6QDL_CLK_PLL2_PFD0_352M>, + <&clks IMX6QDL_CLK_PLL2_PFD0_352M>; + assigned-clock-rates = <0>, <0>; +}; diff --git a/arch/arm/dts/imx6q-acc-u-boot.dtsi b/arch/arm/dts/imx6q-acc-u-boot.dtsi new file mode 100644 index 0000000000..b83befb525 --- /dev/null +++ b/arch/arm/dts/imx6q-acc-u-boot.dtsi @@ -0,0 +1,71 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/* Copyright (C) 2022 Denx Software Engineering GmbH + * Philip Oberfichtner pro@denx.de + */ + +/ { + soc { + u-boot,dm-spl; + + bus@2000000 { + u-boot,dm-spl; + + spba-bus@2000000 { + u-boot,dm-spl; + }; + }; + + bus@2100000 { + u-boot,dm-spl; + }; + }; +}; + +&uart1 { + u-boot,dm-spl; +}; + +&uart2 { + u-boot,dm-spl; +}; + +&usdhc2 { + u-boot,dm-spl; +}; + +&usdhc4 { + u-boot,dm-spl; +}; + +&gpio1 { + u-boot,dm-spl; +}; + +&gpio2 { + u-boot,dm-spl; +}; + +&gpio3 { + u-boot,dm-spl; +}; + +&gpio4 { + u-boot,dm-spl; +}; + +&gpio5 { + u-boot,dm-spl; +}; + +&gpio6 { + u-boot,dm-spl; +}; + +&gpio7 { + u-boot,dm-spl; +}; + +&wdog1 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/imx6q-acc.dts b/arch/arm/dts/imx6q-acc.dts new file mode 100644 index 0000000000..f0857e46e1 --- /dev/null +++ b/arch/arm/dts/imx6q-acc.dts @@ -0,0 +1,281 @@ +// SPDX-License-Identifier: GPL-2.0 + +/* Support for the i.MX6-based Bosch ACC board. + * + * Copyright (c) 2016 Garz & Fricke GmbH + * Copyright (c) 2018 DENX Software Engineering GmbH + * Heiko Schocher hs@denx.de + * Niel Fourie lusus@denx.de + * Copyright (c) 2019,2020 Bosch Thermotechnik GmbH + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +/dts-v1/; + +#include "imx6q.dtsi" +#include "imx6q-acc-common.dtsi" + +/ { + model = "i.MX6 Dual Bosch ACC"; + compatible = "bosch,imx6q-acc", "fsl,imx6q"; + + chosen { + stdout-path = &uart2; + }; + + aliases { + serial0 = &uart2; + serial1 = &uart1; + + i2c0 = &i2c1; + i2c1 = &i2c2; + i2c2 = &i2c3; + mmc0 = &usdhc4; + mmc1 = &usdhc2; + }; + + memory { + reg = <0x10000000 0x40000000>; + }; +}; + +®ulators { + supply_sw4_3V3: regulator@8 { + compatible = "regulator-fixed"; + reg = <8>; + regulator-name = "SW4_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + vin-supply = <&supply_5P0>; + }; + + supply_SYS_4V2: regulator@9 { + compatible = "regulator-fixed"; + reg = <9>; + regulator-name = "SYS_4V2"; + regulator-min-microvolt = <4200000>; + regulator-max-microvolt = <4200000>; + regulator-always-on; + vin-supply = <&supply_5P0>; + }; + +}; + +&i2c1 { + pmic: pfuze100@8 { + compatible = "fsl,pfuze100"; + reg = <0x08>; + uboot,bootcounter; + + VGEN1-supply = <&supply_AUX_3V15>; + VGEN2-supply = <&supply_AUX_3V15>; + VGEN3-supply = <&supply_sw4_3V3>; + VGEN4-supply = <&supply_sw4_3V3>; + VGEN5-supply = <&supply_SYS_4V2>; + VGEN6-supply = <&supply_SYS_4V2>; + + VREFDDR-supply = <&supply_DDR_1V5>; + + SW1AB-supply = <&supply_SYS_4V2>; + SW1C-supply = <&supply_SYS_4V2>; + SW2-supply = <&supply_SYS_4V2>; + SW3A-supply = <&supply_SYS_4V2>; + SW3B-supply = <&supply_SYS_4V2>; + SW4-supply = <&supply_SYS_4V2>; + + regulators { + pmic_sw1a_vddcore: sw1ab { + regulator-name = "VDD_SOC (sw1ab)"; + regulator-min-microvolt = <300000>; + regulator-max-microvolt = <1875000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + + default-voltage = <1300000>; + standby-voltage = <900000>; + + }; + + pmic_sw1c_vddsoc: sw1c { + regulator-name = "VDD_SOC (sw1c)"; + regulator-min-microvolt = <300000>; + regulator-max-microvolt = <1875000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + + default-voltage = <1300000>; + standby-voltage = <900000>; + + }; + + sw3a_reg: sw3a { + /* U-Boot sets correct voltage, shall not be touched by the OS */ + compatible = "regulator-fixed"; + regulator-name = "DDR_1V5a"; + regulator-boot-on; + regulator-always-on; + + }; + + supply_DDR_1V5: sw3b { + /* U-Boot sets correct voltage, shall not be touched by the OS */ + compatible = "regulator-fixed"; + regulator-name = "DDR_1V5b"; + regulator-boot-on; + regulator-always-on; + + }; + + supply_AUX_3V15: sw4 { + regulator-name = "AUX 3V15 (sw4)"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <3300000>; + + default-voltage = <3150000>; + + }; + + swbst_reg: swbst { + status = "disabled"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5150000>; + regulator-boot-on; + regulator-always-on; + + }; + + snvs_reg: vsnvs { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <3000000>; + regulator-boot-on; + regulator-always-on; + + default-voltage = <3000000>; + }; + + vref_reg: vrefddr { + regulator-boot-on; + regulator-always-on; + + default-voltage = <750000>; + }; + + vgen1_reg: vgen1 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1550000>; + regulator-always-on; + + default-voltage = <1500000>; + }; + + vgen2_reg: vgen2 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1550000>; + regulator-always-on; + + default-voltage = <1200000>; + }; + + vgen3_reg: vgen3 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + + default-voltage = <2500000>; + }; + + vgen4_reg: vgen4 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + + default-voltage = <1800000>; + }; + + vgen5_reg: vgen5 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + + default-voltage = <2800000>; + }; + + vgen6_reg: vgen6 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + + default-voltage = <2800000>; + }; + + }; + }; +}; + +&i2c3 { + exc3000: exc3000@2a { + compatible = "eeti,exc3000"; + reg = <0x2a>; + + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ctouch>; + + interrupt-parent = <&gpio4>; + interrupts = <6 IRQ_TYPE_LEVEL_LOW>; + + touchscreen-size-x = <4096>; + touchscreen-size-y = <4096>; + + status = "okay"; + }; +}; + +&pmic_sw1a_vddcore { + status="disabled"; /* For acc sw1 ab and c are used both for vddsoc */ +}; + +&pmic_sw1c_vddsoc { + regulator-name = "VDD_SOC (sw1abc)"; +}; + +&pmic +{ + regulators { + pmic_sw2: sw2{ + regulator-name = "VDD_CORE (sw2)"; + + regulator-min-microvolt = <300000>; + regulator-max-microvolt = <1875000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + + default-voltage = <1300000>; + standby-voltage = <900000>; + }; + }; +}; + +®_arm { + vin-supply = <&pmic_sw2>; +}; + +®_soc { + vin-supply = <&pmic_sw1c_vddsoc>; +}; + +®_pu { + vin-supply = <&pmic_sw1c_vddsoc>; +}; + +&usbh2 { + pad-supply = <&vgen2_reg>; +}; diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index 98df4d4e42..995b4b2426 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -345,6 +345,20 @@ config TARGET_MX6Q_ENGICAM select SUPPORT_SPL imply CMD_DM
+config TARGET_MX6Q_ACC + bool "Support for Bosch ACC board" + depends on MX6QDL + select BOARD_LATE_INIT + select OF_CONTROL + select SPL_OF_LIBFDT + select DM + select DM_ETH + select DM_GPIO + select DM_I2C + select DM_MMC + select DM_THERMAL + select SUPPORT_SPL + config TARGET_MX6SABREAUTO bool "mx6sabreauto" depends on MX6QDL @@ -674,6 +688,7 @@ source "board/freescale/mx6sxsabresd/Kconfig" source "board/freescale/mx6sxsabreauto/Kconfig" source "board/freescale/mx6ul_14x14_evk/Kconfig" source "board/freescale/mx6ullevk/Kconfig" +source "board/bosch/acc/Kconfig" source "board/grinn/liteboard/Kconfig" source "board/phytec/pcm058/Kconfig" source "board/phytec/pcl063/Kconfig" diff --git a/board/bosch/acc/Kconfig b/board/bosch/acc/Kconfig new file mode 100644 index 0000000000..88965627b7 --- /dev/null +++ b/board/bosch/acc/Kconfig @@ -0,0 +1,18 @@ +if TARGET_MX6Q_ACC + +config SYS_VENDOR + default "bosch" + +config SYS_BOARD + default "acc" + +config SYS_CONFIG_NAME + default "imx6q-acc" + +config SYS_BOOT_EMMC + bool "Boot from EMMC" + default y + help + Say N here if you want to boot from SD card or microUSB. + +endif diff --git a/board/bosch/acc/MAINTAINERS b/board/bosch/acc/MAINTAINERS new file mode 100644 index 0000000000..29bb26bb93 --- /dev/null +++ b/board/bosch/acc/MAINTAINERS @@ -0,0 +1,10 @@ +MX6Q_ACC +M: Matthias Winker matthias.winker@de.bosch.com +M: Philip Oberfichtner pro@denx.de +S: Maintained +F: board/bosch/acc +F: include/configs/imx6q-acc.h +F: configs/imx6q_acc_defconfig +F: arch/arm/dts/imx6q-acc-common.dtsi +F: arch/arm/dts/imx6q-acc.dts +F: arch/arm/dts/imx6q-acc-u-boot.dts diff --git a/board/bosch/acc/Makefile b/board/bosch/acc/Makefile new file mode 100644 index 0000000000..d425a677bc --- /dev/null +++ b/board/bosch/acc/Makefile @@ -0,0 +1,6 @@ +# Copyright (C) 2017 +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := acc.o diff --git a/board/bosch/acc/acc.c b/board/bosch/acc/acc.c new file mode 100644 index 0000000000..b59436635e --- /dev/null +++ b/board/bosch/acc/acc.c @@ -0,0 +1,737 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2017 DENX Software Engineering GmbH, Heiko Schocher hs@denx.de + * Copyright (c) 2019 Bosch Thermotechnik GmbH + */ + +#include <common.h> +#include <bootstage.h> +#include <dm.h> +#include <dm/platform_data/serial_mxc.h> +#include <dm/device-internal.h> +#include <env.h> +#include <hang.h> +#include <init.h> +#include <linux/delay.h> +#include <mmc.h> + +#include <asm/io.h> +#include <asm/gpio.h> +#include <linux/sizes.h> + +#include <asm/arch/clock.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/iomux.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-imx/iomux-v3.h> +#include <usb.h> +#include <usb/ehci-ci.h> +#include <fuse.h> + +#include <watchdog.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define GPIO_ACC_PLAT_DETECT IMX_GPIO_NR(5, 9) +#define GPIO_ACC_RAM_VOLT_DETECT IMX_GPIO_NR(5, 0) +#define GPIO_BUZZER IMX_GPIO_NR(1, 18) +#define GPIO_LAN1_RESET IMX_GPIO_NR(4, 27) +#define GPIO_LAN2_RESET IMX_GPIO_NR(4, 19) +#define GPIO_LAN3_RESET IMX_GPIO_NR(4, 18) +#define GPIO_USB_HUB_RESET IMX_GPIO_NR(5, 5) +#define GPIO_EXP_RS485_RESET IMX_GPIO_NR(4, 16) +#define GPIO_TOUCH_RESET IMX_GPIO_NR(1, 20) + +#define BOARD_INFO_MAGIC 0x19730517 + +struct board_info { + int magic; + int board; + int rev; +}; + +static struct board_info *detect_board(void); + +#define PFID_BOARD_ACC 0xe + +static const char * const name_board[] = { + [PFID_BOARD_ACC] = "ACC", +}; + +#define PFID_REV_22 0x8 +#define PFID_REV_21 0x9 +#define PFID_REV_20 0xa +#define PFID_REV_14 0xb +#define PFID_REV_13 0xc +#define PFID_REV_12 0xd +#define PFID_REV_11 0xe +#define PFID_REV_10 0xf + +static const char * const name_revision[] = { + [0 ... PFID_REV_10] = "Unknown", + [PFID_REV_10] = "1.0", + [PFID_REV_11] = "1.1", + [PFID_REV_12] = "1.2", + [PFID_REV_13] = "1.3", + [PFID_REV_14] = "1.4", + [PFID_REV_20] = "2.0", + [PFID_REV_21] = "2.1", + [PFID_REV_22] = "2.2", +}; + +/* + * NXP Reset Default: 0x0001B0B0 + * - Schmitt trigger input (PAD_CTL_HYS) + * - 100K Ohm Pull Up (PAD_CTL_PUS_100K_UP) + * - Pull Enabled (PAD_CTL_PUE) + * - Pull/Keeper Enabled (PAD_CTL_PKE) + * - CMOS output (No PAD_CTL_ODE) + * - Medium Speed (PAD_CTL_SPEED_MED) + * - 40 Ohm drive strength (PAD_CTL_DSE_40ohm) + * - Slow (PAD_CTL_SRE_SLOW) + */ + +/* Input, no pull up/down: 0x0x000100B0 */ +#define GPIN_PAD_CTRL (PAD_CTL_HYS \ + | PAD_CTL_SPEED_MED \ + | PAD_CTL_DSE_40ohm \ + | PAD_CTL_SRE_SLOW) + +/* Input, pull up: 0x0x0001B0B0 */ +#define GPIN_PU_PAD_CTRL (PAD_CTL_HYS \ + | PAD_CTL_PUS_100K_UP \ + | PAD_CTL_PUE \ + | PAD_CTL_PKE \ + | PAD_CTL_SPEED_MED \ + | PAD_CTL_DSE_40ohm \ + | PAD_CTL_SRE_SLOW) + +/* Input, pull down: 0x0x000130B0 */ +#define GPIN_PD_PAD_CTRL (PAD_CTL_HYS \ + | PAD_CTL_PUS_100K_DOWN \ + | PAD_CTL_PUE \ + | PAD_CTL_PKE \ + | PAD_CTL_SPEED_MED \ + | PAD_CTL_DSE_40ohm \ + | PAD_CTL_SRE_SLOW) + +static const iomux_v3_cfg_t board_detect_pads[] = { + /* Platform detect */ + IOMUX_PADS(PAD_DISP0_DAT15__GPIO5_IO09 | MUX_PAD_CTRL(GPIN_PAD_CTRL)), + /* RAM Volt detect */ + IOMUX_PADS(PAD_EIM_WAIT__GPIO5_IO00 | MUX_PAD_CTRL(GPIN_PAD_CTRL)), + /* PFID 0..9 */ + IOMUX_PADS(PAD_NANDF_D0__GPIO2_IO00 | MUX_PAD_CTRL(GPIN_PAD_CTRL)), + IOMUX_PADS(PAD_NANDF_D1__GPIO2_IO01 | MUX_PAD_CTRL(GPIN_PAD_CTRL)), + IOMUX_PADS(PAD_NANDF_D2__GPIO2_IO02 | MUX_PAD_CTRL(GPIN_PAD_CTRL)), + IOMUX_PADS(PAD_NANDF_D3__GPIO2_IO03 | MUX_PAD_CTRL(GPIN_PAD_CTRL)), + IOMUX_PADS(PAD_NANDF_D4__GPIO2_IO04 | MUX_PAD_CTRL(GPIN_PAD_CTRL)), + IOMUX_PADS(PAD_NANDF_D5__GPIO2_IO05 | MUX_PAD_CTRL(GPIN_PAD_CTRL)), + IOMUX_PADS(PAD_NANDF_D6__GPIO2_IO06 | MUX_PAD_CTRL(GPIN_PAD_CTRL)), + IOMUX_PADS(PAD_NANDF_D7__GPIO2_IO07 | MUX_PAD_CTRL(GPIN_PAD_CTRL)), + IOMUX_PADS(PAD_NANDF_CS3__GPIO6_IO16 | MUX_PAD_CTRL(GPIN_PAD_CTRL)), + IOMUX_PADS(PAD_NANDF_CS1__GPIO6_IO14 | MUX_PAD_CTRL(GPIN_PAD_CTRL)), + /* Manufacturer */ + IOMUX_PADS(PAD_EIM_A24__GPIO5_IO04 | MUX_PAD_CTRL(GPIN_PAD_CTRL)), + /* Redundant */ + IOMUX_PADS(PAD_NANDF_CS2__GPIO6_IO15 | MUX_PAD_CTRL(GPIN_PU_PAD_CTRL)) +}; + +static int gpio_acc_pfid[] = { + IMX_GPIO_NR(2, 0), + IMX_GPIO_NR(2, 1), + IMX_GPIO_NR(2, 2), + IMX_GPIO_NR(2, 3), + IMX_GPIO_NR(2, 4), + IMX_GPIO_NR(6, 14), + IMX_GPIO_NR(6, 15), + IMX_GPIO_NR(2, 5), + IMX_GPIO_NR(2, 6), + IMX_GPIO_NR(2, 7), + IMX_GPIO_NR(6, 16), + IMX_GPIO_NR(5, 4), +}; + +static int init_gpio(int nr) +{ + int ret; + + ret = gpio_request(nr, ""); + if (ret != 0) { + printf("Could not request gpio nr: %d\n", nr); + hang(); + } + ret = gpio_direction_input(nr); + if (ret != 0) { + printf("Could not set gpio nr: %d to input\n", nr); + hang(); + } + return 0; +} + +/* + * We want to detect the board type only once in SPL, + * so we store the board_info struct at beginning in IRAM. + * + * U-Boot itself can read it also, and do not need again + * to detect board type. + * + */ +static struct board_info *detect_board(void) +{ + struct board_info *binfo = (struct board_info *)IRAM_BASE_ADDR; + int i; + + if (binfo->magic == BOARD_INFO_MAGIC) + return binfo; + + puts("Board: "); + SETUP_IOMUX_PADS(board_detect_pads); + init_gpio(GPIO_ACC_PLAT_DETECT); + if (gpio_get_value(GPIO_ACC_PLAT_DETECT)) { + puts("not supported"); + hang(); + } else { + puts("Bosch "); + } + + for (i = 0; i < sizeof(gpio_acc_pfid) / sizeof(int); i++) + init_gpio(gpio_acc_pfid[i]); + + binfo->board = gpio_get_value(gpio_acc_pfid[0]) << 0 | + gpio_get_value(gpio_acc_pfid[1]) << 1 | + gpio_get_value(gpio_acc_pfid[2]) << 2 | + gpio_get_value(gpio_acc_pfid[11]) << 3; + printf("%s ", name_board[binfo->board]); + + binfo->rev = gpio_get_value(gpio_acc_pfid[7]) << 0 | + gpio_get_value(gpio_acc_pfid[8]) << 1 | + gpio_get_value(gpio_acc_pfid[9]) << 2 | + gpio_get_value(gpio_acc_pfid[10]) << 3; + printf("rev: %s\n", name_revision[binfo->rev]); + + binfo->magic = BOARD_INFO_MAGIC; + + return binfo; +} + +static void unset_early_gpio(void) +{ + init_gpio(GPIO_LAN1_RESET); + init_gpio(GPIO_LAN2_RESET); + init_gpio(GPIO_LAN3_RESET); + init_gpio(GPIO_USB_HUB_RESET); + init_gpio(GPIO_EXP_RS485_RESET); + init_gpio(GPIO_TOUCH_RESET); + + gpio_set_value(GPIO_LAN1_RESET, 1); + gpio_set_value(GPIO_LAN2_RESET, 1); + gpio_set_value(GPIO_LAN3_RESET, 1); + gpio_set_value(GPIO_USB_HUB_RESET, 1); + gpio_set_value(GPIO_EXP_RS485_RESET, 1); + gpio_set_value(GPIO_TOUCH_RESET, 1); +} + +int board_late_init(void) +{ + struct board_info *binfo = detect_board(); + + switch (binfo->board) { + case PFID_BOARD_ACC: + env_set("bootconf", "conf-imx6q-acc.dtb"); + break; + default: + printf("Unknown board %d\n", binfo->board); + break; + } + + unset_early_gpio(); + + return 0; +} + +int board_init(void) +{ + /* Address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + return 0; +} + +int dram_init(void) +{ + gd->ram_size = imx_ddr_size(); + + return 0; +} + +#if IS_ENABLED(CONFIG_SPL_BUILD) +#include <asm/arch/crm_regs.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux.h> +#include <asm/arch/mx6-ddr.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> +#include <spl.h> + +/* Early + * - Buzzer -> GPIO IN, Pull-Down (PWM enabled by Kernel later-on, lacks of an + * external pull-down resistor) + * - Touch clean reset on every boot + * - Ethernet(s), USB Hub, Expansion RS485 -> Clean reset on each u-boot init + */ +static const iomux_v3_cfg_t early_pads[] = { + IOMUX_PADS(PAD_SD1_CMD__GPIO1_IO18 | MUX_PAD_CTRL(GPIN_PD_PAD_CTRL)), /* Buzzer PWM */ + IOMUX_PADS(PAD_DISP0_DAT6__GPIO4_IO27 | MUX_PAD_CTRL(GPIN_PD_PAD_CTRL)), /* #FEC_RESET_B */ + IOMUX_PADS(PAD_DI0_PIN2__GPIO4_IO18 | MUX_PAD_CTRL(GPIN_PD_PAD_CTRL)), /* #ETH1_RESET */ + IOMUX_PADS(PAD_DI0_PIN3__GPIO4_IO19 | MUX_PAD_CTRL(GPIN_PD_PAD_CTRL)), /* #ETH2_RESET */ + IOMUX_PADS(PAD_DISP0_DAT11__GPIO5_IO05 | MUX_PAD_CTRL(GPIN_PD_PAD_CTRL)), /* #USB Reset */ + IOMUX_PADS(PAD_DI0_DISP_CLK__GPIO4_IO16 | MUX_PAD_CTRL(GPIN_PD_PAD_CTRL)), /* #UART_RESET */ + IOMUX_PADS(PAD_SD1_CLK__GPIO1_IO20 | MUX_PAD_CTRL(GPIN_PD_PAD_CTRL)), /* #CTOUCH_RESET */ +}; + +static void setup_iomux_early(void) +{ + SETUP_IOMUX_PADS(early_pads); +} + +static void set_early_gpio(void) +{ + init_gpio(GPIO_BUZZER); + init_gpio(GPIO_LAN1_RESET); + init_gpio(GPIO_LAN2_RESET); + init_gpio(GPIO_LAN3_RESET); + init_gpio(GPIO_USB_HUB_RESET); + init_gpio(GPIO_EXP_RS485_RESET); + init_gpio(GPIO_TOUCH_RESET); + + /* Reset signals are active low */ + gpio_set_value(GPIO_BUZZER, 0); + gpio_set_value(GPIO_LAN1_RESET, 0); + gpio_set_value(GPIO_LAN2_RESET, 0); + gpio_set_value(GPIO_LAN3_RESET, 0); + gpio_set_value(GPIO_USB_HUB_RESET, 0); + gpio_set_value(GPIO_EXP_RS485_RESET, 0); + gpio_set_value(GPIO_TOUCH_RESET, 0); +} + +/* UART */ +#define UART_PAD_CTRL \ + (PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#undef UART_PAD_CTRL +#define UART_PAD_CTRL 0x1b0b1 +static const iomux_v3_cfg_t uart2_pads[] = { + IOMUX_PADS(PAD_SD3_DAT4__UART2_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT5__UART2_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_CMD__UART2_CTS_B | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_CLK__UART2_RTS_B | MUX_PAD_CTRL(UART_PAD_CTRL)), +}; + +static void setup_iomux_uart(void) +{ + SETUP_IOMUX_PADS(uart2_pads); +} + +void spl_board_init(void) +{ +} + +static const struct mx6dq_iomux_ddr_regs acc_mx6d_ddr_ioregs = { + .dram_sdclk_0 = 0x00008038, + .dram_sdclk_1 = 0x00008038, + .dram_cas = 0x00008028, + .dram_ras = 0x00008028, + .dram_reset = 0x00000028, + .dram_sdcke0 = 0x00003000, + .dram_sdcke1 = 0x00003000, + .dram_sdba2 = 0x00008000, + .dram_sdodt0 = 0x00000028, + .dram_sdodt1 = 0x00000028, + .dram_sdqs0 = 0x00008038, + .dram_sdqs1 = 0x00008038, + .dram_sdqs2 = 0x00008038, + .dram_sdqs3 = 0x00008038, + .dram_sdqs4 = 0x00008038, + .dram_sdqs5 = 0x00008038, + .dram_sdqs6 = 0x00008038, + .dram_sdqs7 = 0x00008038, + .dram_dqm0 = 0x00008038, + .dram_dqm1 = 0x00008038, + .dram_dqm2 = 0x00008038, + .dram_dqm3 = 0x00008038, + .dram_dqm4 = 0x00008038, + .dram_dqm5 = 0x00008038, + .dram_dqm6 = 0x00008038, + .dram_dqm7 = 0x00008038, +}; + +static const struct mx6dq_iomux_grp_regs acc_mx6d_grp_ioregs = { + .grp_ddr_type = 0x000C0000, + .grp_ddrmode_ctl = 0x00020000, + .grp_ddrpke = 0x00000000, + .grp_addds = 0x00000030, + .grp_ctlds = 0x00000028, + .grp_ddrmode = 0x00020000, + .grp_b0ds = 0x00000038, + .grp_b1ds = 0x00000038, + .grp_b2ds = 0x00000038, + .grp_b3ds = 0x00000038, + .grp_b4ds = 0x00000038, + .grp_b5ds = 0x00000038, + .grp_b6ds = 0x00000038, + .grp_b7ds = 0x00000038, +}; + +static const struct mx6_mmdc_calibration acc_mx6d_mmdc_calib = { + .p0_mpwldectrl0 = 0x0020001F, + .p0_mpwldectrl1 = 0x00280021, + .p1_mpwldectrl0 = 0x00120028, + .p1_mpwldectrl1 = 0x000D001F, + .p0_mpdgctrl0 = 0x43340342, + .p0_mpdgctrl1 = 0x03300325, + .p1_mpdgctrl0 = 0x4334033E, + .p1_mpdgctrl1 = 0x03280270, + .p0_mprddlctl = 0x46373B3E, + .p1_mprddlctl = 0x3B383544, + .p0_mpwrdlctl = 0x36383E40, + .p1_mpwrdlctl = 0x4030433A, +}; + +/* Micron MT41K128M16JT-125 (standard - 1600,CL=11) + * !!! i.MX6 does NOT support data rates higher than DDR3-1066 !!! + * So this setting is actually invalid! + * +static const struct mx6_ddr3_cfg acc_mx6d_mem_ddr3_1600 = { + .mem_speed = 1600, + .density = 2, + .width = 16, + .banks = 8, + .rowaddr = 14, + .coladdr = 10, + .pagesz = 2, + .trcd = 1375, + .trcmin = 4875, + .trasmin = 3500, + .SRT = 0, +}; + */ + +/* Micron MT41K128M16JT-125 is backward-compatible with 1333,CL=9 (-15E) and 1066,CL=7 (-187E) + * Lowering to 1066 saves on ACC ~0.25 Watt at DC In with negligible performance loss + * width set to 64, as four chips are used on acc (4 * 16 = 64) + */ +static const struct mx6_ddr3_cfg acc_mx6d_mem_ddr3_1066 = { + .mem_speed = 1066, + .density = 2, + .width = 64, + .banks = 8, + .rowaddr = 14, + .coladdr = 10, + .pagesz = 2, + .trcd = 1313, // 13.125ns + .trcmin = 5063, // 50.625ns + .trasmin = 3750, // 37.5ns + .SRT = 0, // Set to 1 for temperatures above 85°C +}; + +static const struct mx6_ddr_sysinfo acc_mx6d_ddr_info = { + .ddr_type = DDR_TYPE_DDR3, + /* width of data bus:0=16,1=32,2=64 */ + .dsize = 2, + .cs_density = 32, /* 32Gb per CS */ + .ncs = 1, /* single chip select */ + .cs1_mirror = 0, + .rtt_wr = 1, /* DDR3_RTT_60_OHM, RTT_Wr = RZQ/4 */ + .rtt_nom = 1, /* DDR3_RTT_60_OHM, RTT_Nom = RZQ/4 */ + .walat = 0, /* Write additional latency */ + .ralat = 5, /* Read additional latency */ + .mif3_mode = 3, /* Command prediction working mode */ + .bi_on = 1, /* Bank interleaving enabled */ + .sde_to_rst = 0x33, /* 14 cycles, 200us (JEDEC default) */ + .rst_to_cke = 0x33, /* 33 cycles, 500us (JEDEC default) */ +}; + +#define ACC_SPREAD_SPECTRUM_STOP 0x0fa +#define ACC_SPREAD_SPECTRUM_STEP 0x001 +#define ACC_SPREAD_SPECTRUM_DENOM 0x190 + +static void ccgr_init(void) +{ + struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + /* Turn clocks on/off */ + writel(0x00C0000F, &ccm->CCGR0); + writel(0x0030FC00, &ccm->CCGR1); + writel(0x03FF0033, &ccm->CCGR2); + writel(0x3FF3300F, &ccm->CCGR3); + writel(0x0003C300, &ccm->CCGR4); + writel(0x0F3000C3, &ccm->CCGR5); + writel(0x00000FFF, &ccm->CCGR6); + + /* Enable spread spectrum */ + writel(BM_ANADIG_PLL_528_SS_ENABLE | + BF_ANADIG_PLL_528_SS_STOP(ACC_SPREAD_SPECTRUM_STOP) | + BF_ANADIG_PLL_528_SS_STEP(ACC_SPREAD_SPECTRUM_STEP), + &ccm->analog_pll_528_ss); + + writel(BF_ANADIG_PLL_528_DENOM_B(ACC_SPREAD_SPECTRUM_DENOM), + &ccm->analog_pll_528_denom); +} + +/* MMC board initialization is needed till adding DM support in SPL */ +#if IS_ENABLED(CONFIG_FSL_ESDHC_IMX) && !IS_ENABLED(CONFIG_DM_MMC) +#include <mmc.h> +#include <fsl_esdhc_imx.h> + +static const iomux_v3_cfg_t usdhc2_pads[] = { + IOMUX_PADS(PAD_SD2_CMD__SD2_CMD | MUX_PAD_CTRL(0x00017069)), + IOMUX_PADS(PAD_SD2_CLK__SD2_CLK | MUX_PAD_CTRL(0x00010038)), + IOMUX_PADS(PAD_SD2_DAT0__SD2_DATA0 | MUX_PAD_CTRL(0x00017069)), + IOMUX_PADS(PAD_SD2_DAT1__SD2_DATA1 | MUX_PAD_CTRL(0x00017069)), + IOMUX_PADS(PAD_SD2_DAT2__SD2_DATA2 | MUX_PAD_CTRL(0x00017069)), + IOMUX_PADS(PAD_SD2_DAT3__SD2_DATA3 | MUX_PAD_CTRL(0x00017069)), + IOMUX_PADS(PAD_GPIO_4__GPIO1_IO04 | MUX_PAD_CTRL(0x0001B0B0)), /* CD */ +}; + +static const iomux_v3_cfg_t usdhc4_pads[] = { + IOMUX_PADS(PAD_SD4_CMD__SD4_CMD | MUX_PAD_CTRL(0x00017059)), + IOMUX_PADS(PAD_SD4_CLK__SD4_CLK | MUX_PAD_CTRL(0x00010059)), + IOMUX_PADS(PAD_SD4_DAT0__SD4_DATA0 | MUX_PAD_CTRL(0x00017059)), + IOMUX_PADS(PAD_SD4_DAT1__SD4_DATA1 | MUX_PAD_CTRL(0x00017059)), + IOMUX_PADS(PAD_SD4_DAT2__SD4_DATA2 | MUX_PAD_CTRL(0x00017059)), + IOMUX_PADS(PAD_SD4_DAT3__SD4_DATA3 | MUX_PAD_CTRL(0x00017059)), + IOMUX_PADS(PAD_SD4_DAT4__SD4_DATA4 | MUX_PAD_CTRL(0x00017059)), + IOMUX_PADS(PAD_SD4_DAT5__SD4_DATA5 | MUX_PAD_CTRL(0x00017059)), + IOMUX_PADS(PAD_SD4_DAT6__SD4_DATA6 | MUX_PAD_CTRL(0x00017059)), + IOMUX_PADS(PAD_SD4_DAT7__SD4_DATA7 | MUX_PAD_CTRL(0x00017059)), +}; + +struct fsl_esdhc_cfg usdhc_cfg[2] = { + {USDHC2_BASE_ADDR, 1, 4}, + {USDHC4_BASE_ADDR, 1, 8}, +}; + +#define USDHC2_CD_GPIO IMX_GPIO_NR(1, 4) + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + detect_board(); + + switch (cfg->esdhc_base) { + case USDHC2_BASE_ADDR: + return !gpio_get_value(USDHC2_CD_GPIO); + case USDHC4_BASE_ADDR: + return 1; /* eMMC always present */ + } + + return ret; +} + +int board_mmc_init(struct bd_info *bis) +{ + int i, ret; + + gpio_direction_input(USDHC2_CD_GPIO); + /* + * According to the board_mmc_init() the following map is done: + * (U-boot device node) (Physical Port) + * mmc0 USDHC2 + * mmc1 USDHC4 + */ + for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { + switch (i) { + case 0: + SETUP_IOMUX_PADS(usdhc2_pads); + usdhc_cfg[i].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); + break; + case 1: + SETUP_IOMUX_PADS(usdhc4_pads); + usdhc_cfg[i].sdhc_clk = mxc_get_clock(MXC_ESDHC4_CLK); + break; + default: + printf("Warning - USDHC%d controller not supporting\n", + i + 1); + return 0; + } + + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + if (ret) { + printf("Warning: failed to initialize mmc dev %d\n", i); + return ret; + } + } + + return 0; +} +#endif // defined(CONFIG_FSL_ESDHC_IMX) && !defined(CONFIG_DM_MMC) + +void board_boot_order(u32 *spl_boot_list) +{ + u32 bmode = imx6_src_get_boot_mode(); + u8 boot_dev = BOOT_DEVICE_MMC1; + + detect_board(); + + switch ((bmode & IMX6_BMODE_MASK) >> IMX6_BMODE_SHIFT) { + case IMX6_BMODE_SD: + case IMX6_BMODE_ESD: + /* SD/eSD - BOOT_DEVICE_MMC1 */ + if (IS_ENABLED(CONFIG_SYS_BOOT_EMMC)) { + /* + * boot from SD is not allowed, if boot from eMMC is + * configured. + */ + puts("SD boot not allowed\n"); + spl_boot_list[0] = BOOT_DEVICE_NONE; + return; + } + + boot_dev = BOOT_DEVICE_MMC1; + break; + + case IMX6_BMODE_MMC: + case IMX6_BMODE_EMMC: + /* MMC/eMMC */ + boot_dev = BOOT_DEVICE_MMC2; + break; + default: + /* Default - BOOT_DEVICE_MMC1 */ + printf("Wrong board boot order\n"); + break; + } + + spl_boot_list[0] = boot_dev; +} + +static void setup_ddr(void) +{ + struct board_info *binfo = detect_board(); + + switch (binfo->rev) { + case PFID_REV_20: + case PFID_REV_21: + case PFID_REV_22: + default: + /* Rev 2 board has i.MX6 Dual with 64-bit RAM */ + mx6dq_dram_iocfg(acc_mx6d_mem_ddr3_1066.width, + &acc_mx6d_ddr_ioregs, + &acc_mx6d_grp_ioregs); + mx6_dram_cfg(&acc_mx6d_ddr_info, &acc_mx6d_mmdc_calib, + &acc_mx6d_mem_ddr3_1066); + /* Perform DDR DRAM calibration */ + udelay(100); + mmdc_do_write_level_calibration(&acc_mx6d_ddr_info); + mmdc_do_dqs_calibration(&acc_mx6d_ddr_info); + break; + } +} + +void board_init_f(ulong dummy) +{ + /* setup AIPS and disable watchdog power-down counter (only enabled after reset) */ + arch_cpu_init(); + + ccgr_init(); + gpr_init(); + + /* setup GP timer */ + timer_init(); + + /* Enable device tree and early DM support*/ + spl_early_init(); + + /* Setup early required pinmuxes */ + setup_iomux_early(); + set_early_gpio(); + + /* Setup UART pinmux */ + setup_iomux_uart(); + + /* UART clocks enabled and gd valid - init serial console */ + preloader_console_init(); + + setup_ddr(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + /* load/boot image from boot device */ + board_init_r(NULL, 0); +} +#endif /* IS_ENABLED(CONFIG_SPL_BUILD) */ + +#if IS_ENABLED(CONFIG_USB_EHCI_MX6) +#define USB_OTHERREGS_OFFSET 0x800 +#define UCTRL_PWR_POL (1 << 9) + +int board_usb_phy_mode(int port) +{ + if (port == 1) + return USB_INIT_HOST; + else + return usb_phy_mode(port); +} + +int board_ehci_hcd_init(int port) +{ + u32 *usbnc_usb_ctrl; + + if (port > 1) + return -EINVAL; + + usbnc_usb_ctrl = (u32 *)(USB_BASE_ADDR + USB_OTHERREGS_OFFSET + + port * 4); + + /* Set Power polarity */ + setbits_le32(usbnc_usb_ctrl, UCTRL_PWR_POL); + + return 0; +} +#endif + +int board_fit_config_name_match(const char *name) +{ + if (!strcmp(name, "imx6q-acc")) + return 0; + return -1; +} + +void reset_cpu(ulong addr) +{ + puts("Hanging CPU for watchdog reset!\n"); + hang(); +} + +#if CONFIG_IS_ENABLED(SHOW_BOOT_PROGRESS) +void show_boot_progress(int val) +{ + u32 fuseval; + int ret; + + if (val < 0) + val *= -1; + + switch (val) { + case BOOTSTAGE_ID_ENTER_CLI_LOOP: + printf("autoboot failed, check fuse\n"); + ret = fuse_read(0, 6, &fuseval); + if (ret == 0 && (fuseval & 0x2) == 0x0) { + printf("Enter cmdline, as device not closed\n"); + return; + } + ret = fuse_read(5, 7, &fuseval); + if (ret == 0 && fuseval == 0x0) { + printf("Enter cmdline, as it is a Development device\n"); + return; + } + panic("do not enter cmdline"); + break; + } +} +#endif diff --git a/configs/imx6q_acc_defconfig b/configs/imx6q_acc_defconfig new file mode 100644 index 0000000000..a8c32a957a --- /dev/null +++ b/configs/imx6q_acc_defconfig @@ -0,0 +1,107 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SYS_TEXT_BASE=0x17780000 +CONFIG_SYS_MALLOC_LEN=0x01000000 +CONFIG_SYS_MALLOC_F_LEN=0x9000 +CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x1fe000 +CONFIG_MX6QDL=y +CONFIG_MX6_DDRCAL=y +CONFIG_MX6_SPREAD_SPECTRUM=y +CONFIG_MX6_SPREAD_SPECTRUM_STOP=0xfa +CONFIG_MX6_SPREAD_SPECTRUM_DENOM=0x190 +CONFIG_TARGET_MX6Q_ACC=y +CONFIG_DEFAULT_DEVICE_TREE="imx6q-acc" +CONFIG_SPL_TEXT_BASE=0x00908000 +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_BOOTCOUNT_BOOTLIMIT=8 +CONFIG_SPL_SIZE_LIMIT=69632 +CONFIG_SPL=y +CONFIG_ENV_OFFSET_REDUND=0x1ff000 +CONFIG_IMX_HAB=y +# CONFIG_CMD_BMODE is not set +# CONFIG_CMD_DEKBLOB is not set +CONFIG_BUILD_TARGET="" +# CONFIG_LOCALVERSION_AUTO is not set +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_FIT_VERBOSE=y +CONFIG_SHOW_BOOT_PROGRESS=y +CONFIG_USE_BOOTCOMMAND=y +CONFIG_BOOTCOMMAND="run mmc_mmc_fit" +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_RAW_IMAGE_SUPPORT=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xaa +# CONFIG_SPL_CRC32 is not set +# CONFIG_SPL_CRYPTO is not set +CONFIG_SPL_WATCHDOG=y +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_FDT is not set +# CONFIG_CMD_GO is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_ENV_EXISTS is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_MEMORY is not set +# CONFIG_CMD_FUSE is not set +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +# CONFIG_CMD_PINMUX is not set +# CONFIG_CMD_ECHO is not set +# CONFIG_CMD_ITEST is not set +# CONFIG_CMD_SOURCE is not set +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_NET is not set +# CONFIG_CMD_BLOCK_CACHE is not set +# CONFIG_CMD_SLEEP is not set +# CONFIG_CMD_MP is not set +# CONFIG_CMD_HASH is not set +CONFIG_CMD_EXT4=y +CONFIG_DOS_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_MULTI_DTB_FIT=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clocks clock-names interrupt-parent" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_SYS_MMC_ENV_PART=1 +CONFIG_ENV_APPEND=y +CONFIG_VERSION_VARIABLE=y +CONFIG_TFTP_BLOCKSIZE=512 +CONFIG_SPL_DM=y +CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTCOUNT_PMIC_PFUZE100=y +CONFIG_SYS_I2C_MXC=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_FSL_USDHC=y +CONFIG_PHYLIB=y +CONFIG_FEC_MXC=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PFUZE100=y +CONFIG_DM_SERIAL=y +CONFIG_MXC_UART=y +CONFIG_WATCHDOG_TIMEOUT_MSECS=60000 +CONFIG_IMX_WATCHDOG=y +CONFIG_WDT=y +CONFIG_EXT4_WRITE=y +CONFIG_FS_FAT=y +CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/imx6q-acc.h b/include/configs/imx6q-acc.h new file mode 100644 index 0000000000..caa11df49f --- /dev/null +++ b/include/configs/imx6q-acc.h @@ -0,0 +1,165 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * Copyright (c) 2017 DENX Software Engineering GmbH, Heiko Schocher hs@denx.de + * Copyright (c) 2019 Bosch Thermotechnik GmbH + */ + +#ifndef __IMX6Q_ACC_H +#define __IMX6Q_ACC_H + +#include <linux/sizes.h> +#include "mx6_common.h" + +/* Environment settings */ +#define CONFIG_ENV_ACCESS_IGNORE_FORCE + +#ifdef CONFIG_SYS_BOOT_EMMC +#define MMC_ROOTFS_DEV 0 +#define MMC_ROOTFS_PART 2 +#endif + +/* Allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +#ifdef CONFIG_SYS_BOOT_EMMC +/* eMMC Boot */ +#define ENV_EXTRA \ + "mmcdev=" __stringify(MMC_ROOTFS_DEV) "\0" \ + "mmcpart=" __stringify(MMC_ROOTFS_PART) "\0" \ + "fitpart=1\0" \ + "optargs=ro quiet systemd.gpt_auto=false\0" \ + "production=1\0" \ + "mmcautodetect=yes\0" \ + "mmcrootfstype=ext4\0" \ + "finduuid=part uuid mmc ${mmcdev}:${mmcpart} uuid\0" \ + "mmcargs=run finduuid; setenv bootargs " \ + "root=PARTUUID=${uuid} ${optargs} rootfstype=${mmcrootfstype}\0" \ + "mmc_mmc_fit=run env_persist; run setbm; run mmcloadfit; " \ + "run auth_fit_or_reset; run mmcargs addcon; " \ + "bootm ${fit_addr}#${bootconf}\0" \ + "bootset=0\0" \ + "setbm=if test ${bootset} -eq 1; " \ + "then setenv mmcpart 4; setenv fitpart 3; " \ + "else; setenv mmcpart 2; setenv fitpart 1; fi\0" \ + "handle_ustate=if test ${ustate} -eq 2; then setenv ustate 3; fi\0" \ + "switch_bootset=if test ${bootset} -eq 1; then setenv bootset 0; " \ + "else; setenv bootset 1;fi\0" \ + "env_persisted=0\0" \ + "env_persist=if test ${env_persisted} != 1; " \ + "then env set env_persisted 1; run save_env; fi;\0" \ + "save_env=env save; env save\0" \ + "altbootcmd=run handle_ustate; run switch_bootset; run save_env; run bootcmd\0" + +#define CONFIG_ENV_FLAGS_LIST_STATIC \ + "addcon:so," \ + "altbootcmd:so," \ + "auth_fit_or_reset:so," \ + "baudrate:do," \ + "bootcmd:so," \ + "bootcount:da," \ + "bootdelay:do," \ + "bootlimit:do," \ + "bootset:ba," \ + "clone_pending:ba," \ + "console:so," \ + "endurance_test:ba," \ + "env_persist:so," \ + "env_persisted:ba," \ + "ethaddr:so," \ + "factory_reset:ba," \ + "fdtcontroladdr:xa," \ + "finduuid:so," \ + "fit_addr:do," \ + "fitpart:da," \ + "handle_ustate:so," \ + "loadaddr:xo," \ + "mmc_mmc_fit:so," \ + "mmcargs:so," \ + "mmcautodetect:so," \ + "mmcdev:do," \ + "mmcfit_name:so," \ + "mmcloadfit:so," \ + "mmcpart:da," \ + "mmcrootfstype:so," \ + "optargs:so," \ + "production:ba," \ + "save_env:so," \ + "setbm:so," \ + "silent:so," \ + "switch_bootset:so," \ + "ustate:da" + +#else //CONFIG_SYS_BOOT_EMMC +/* SD Card boot */ +#define ENV_EXTRA \ + "mmcdev=1\0" \ + "fitpart=1\0" \ + "rootpart=2\0" \ + "optargs=ro systemd.gpt_auto=false\0" \ + "finduuid=part uuid mmc ${mmcdev}:${rootpart} uuid\0" \ + "mmcargs=run finduuid;setenv bootargs root=PARTUUID=${uuid} ${optargs}\0" \ + "mmc_mmc_fit=run mmcloadfit; run auth_fit_or_reset; run mmcargs addcon; " \ + "bootm ${fit_addr}#${bootconf}\0" + +#endif //CONFIG_SYS_BOOT_EMMC + +/* Default environment */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "bootconf=conf-imx6q-acc.dtb\0"\ + "mmcfit_name=fitImage\0" \ + "mmcloadfit=ext4load mmc ${mmcdev}:${fitpart} ${fit_addr} ${mmcfit_name}\0" \ + "auth_fit_or_reset=hab_auth_img ${fit_addr} ${filesize} || reset\0" \ + "console=ttymxc0\0" \ + "addcon=setenv bootargs ${bootargs} console=${console},${baudrate}\0" \ + "fit_addr=19000000\0" \ + ENV_EXTRA + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 5 * SZ_1M) + +/* Physical Memory Map */ +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* Ethernet */ +#ifdef CONFIG_FEC_MXC +#define CONFIG_FEC_MXC_PHYADDR 0 +#define CONFIG_FEC_XCV_TYPE RMII +#define CONFIG_MII +#endif + +/* SPL */ +#ifdef CONFIG_SPL +#include "imx6_spl.h" + +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SYS_FSL_USDHC_NUM 2 + +#ifdef CONFIG_SYS_BOOT_EMMC + +/* Boot from eMMC */ +#define CONFIG_SYS_FSL_ESDHC_ADDR 1 + +#else // CONFIG_SYS_BOOT_EMMC + +/* Boot from SD-card */ +# define CONFIG_SYS_FSL_ESDHC_ADDR 0 + +#endif // CONFIG_SYS_BOOT_EMMC + +#endif // CONFIG_SPL_BUILD +#endif // CONFIG_SPL + +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET +#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) +#define CONFIG_MXC_USB_FLAGS 0 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 /* Enabled USB controller number */ + +#endif /* __IMX6Q_ACC_H */
Hi Philipp,
[snip]
- Copyright (c) 2017 DENX Software Engineering GmbH, Heiko Schocher hs@denx.de
- Copyright (c) 2019 Bosch Thermotechnik GmbH
- "mmcdev=" __stringify(MMC_ROOTFS_DEV) "\0" \
- "mmcpart=" __stringify(MMC_ROOTFS_PART) "\0" \
- "fitpart=1\0" \
- "optargs=ro quiet systemd.gpt_auto=false\0" \
- "production=1\0" \
- "mmcautodetect=yes\0" \
- "mmcrootfstype=ext4\0" \
- "finduuid=part uuid mmc ${mmcdev}:${mmcpart} uuid\0" \
- "mmcargs=run finduuid; setenv bootargs " \
- "mmc_mmc_fit=run env_persist; run setbm; run mmcloadfit; " \
- "bootset=0\0" \
- "setbm=if test ${bootset} -eq 1; " \
- "handle_ustate=if test ${ustate} -eq 2; then setenv ustate 3; fi\0" \
- "switch_bootset=if test ${bootset} -eq 1; then setenv bootset 0; " \
- "env_persisted=0\0" \
- "env_persist=if test ${env_persisted} != 1; " \
- "save_env=env save; env save\0" \
- "altbootcmd=run handle_ustate; run switch_bootset; run save_env; run bootcmd\0"
- "addcon:so," \
- "altbootcmd:so," \
- "auth_fit_or_reset:so," \
- "baudrate:do," \
- "bootcmd:so," \
- "bootcount:da," \
- "bootdelay:do," \
- "bootlimit:do," \
- "bootset:ba," \
- "clone_pending:ba," \
- "console:so," \
- "endurance_test:ba," \
- "env_persist:so," \
- "env_persisted:ba," \
- "ethaddr:so," \
- "factory_reset:ba," \
- "fdtcontroladdr:xa," \
- "finduuid:so," \
- "fit_addr:do," \
- "fitpart:da," \
- "handle_ustate:so," \
- "loadaddr:xo," \
- "mmc_mmc_fit:so," \
- "mmcargs:so," \
- "mmcautodetect:so," \
- "mmcdev:do," \
- "mmcfit_name:so," \
- "mmcloadfit:so," \
- "mmcpart:da," \
- "mmcrootfstype:so," \
- "optargs:so," \
- "production:ba," \
- "save_env:so," \
- "setbm:so," \
- "silent:so," \
- "switch_bootset:so," \
- "ustate:da"
This is the list of the variables that are allowed to be changed. Generally, this list is very short to avoid that an attacker can change a lot. I wonder that on this board the list is very long - sure that this is ok ?
CONFIG_ are not allowed and they are rejected during build. Any CONFIG_ switch should go into Kbuild. It is not useful here, so just rename local defines in this file with something different as CONFIG_ (ENV_FLAG
Rather the CI hits the comments, too, so please drop them. Not only, there are some CONFIG_ that are already defined in Kbuild. Sure that you have to redefine all of them or you can just add them to configs/imx6q_acc_defconfig ?
You can check the error reported here:
https://source.denx.de/u-boot/custodians/u-boot-imx/-/jobs/420785
Best regards, Stefano
- "mmcdev=1\0" \
- "fitpart=1\0" \
- "rootpart=2\0" \
- "optargs=ro systemd.gpt_auto=false\0" \
- "finduuid=part uuid mmc ${mmcdev}:${rootpart} uuid\0" \
- "mmcargs=run finduuid;setenv bootargs root=PARTUUID=${uuid} ${optargs}\0" \
- "mmc_mmc_fit=run mmcloadfit; run auth_fit_or_reset; run mmcargs addcon; " \
- "bootconf=conf-imx6q-acc.dtb\0"\
- "mmcfit_name=fitImage\0" \
- "mmcloadfit=ext4load mmc ${mmcdev}:${fitpart} ${fit_addr} ${mmcfit_name}\0" \
- "auth_fit_or_reset=hab_auth_img ${fit_addr} ${filesize} || reset\0" \
- "console=ttymxc0\0" \
- "addcon=setenv bootargs ${bootargs} console=${console},${baudrate}\0" \
- "fit_addr=19000000\0" \
- ENV_EXTRA
Hi Stefano,
On Mon, 2022-04-11 at 17:45 +0200, Stefano Babic wrote:
Hi Philipp,
The Bosch ACC (Air Center Control) Board is based on the i.MX6D.
[snip]
diff --git a/include/configs/imx6q-acc.h b/include/configs/imx6q- acc.h new file mode 100644 index 0000000000..caa11df49f --- /dev/null +++ b/include/configs/imx6q-acc.h @@ -0,0 +1,165 @@ +/* SPDX-License-Identifier: GPL-2.0+
Schocher hs@denx.de
Thanks for the hint. For V2 I will enable CONFIG_ENV_WRITEABLE_LIST and shorten this list. This will also involve a 'env_get_location' implementation in the board file.
For V2 I will migrate CONFIG_MII and CONFIG_SYS_MEMTEST* to Kconfig, the remainder of CONFIG_* used is whitelisted.
Concerning the CONFIG_SYS_BOOT_EMMC: This is defined in board/bosch/acc/Kconfig and used to discern SD boot from eMMC boot. Is it good practice then to leave it like this?
Thanks for the feedback.
Best regards, Philip
- 5 * SZ_1M)
- CONFIG_SYS_INIT_SP_OFFSET)
Philip Oberfichtner
Stefano Babic
