[U-Boot] [PATCH v1 1/2] arm: mvebu: Add support for NAND interface on A-38x
From: Chris Packham chris.packham@alliedtelesis.co.nz
The NAND interface on the Armada-38x series is similar to that on the Armada-XP. The key difference is that the NAND ECC clock ratio is provided via the DFX Server registers instead of the Core Clock.
Signed-off-by: Chris Packham chris.packham@alliedtelesis.co.nz Cc: Luka Perkov luka.perkov@sartura.hr Cc: Dirk Eibach eibach@gdsys.de --- I haven't got access to any Armada-375 docs so I wasn't sure if I should include it in the condition. For now it'll fall back to using the same clock control register as the Armada-XP.
arch/arm/mach-mvebu/cpu.c | 9 ++++++++- arch/arm/mach-mvebu/include/mach/soc.h | 2 ++ 2 files changed, 10 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-mvebu/cpu.c b/arch/arm/mach-mvebu/cpu.c index fd66f59..5eb2a39 100644 --- a/arch/arm/mach-mvebu/cpu.c +++ b/arch/arm/mach-mvebu/cpu.c @@ -452,8 +452,15 @@ int arch_cpu_init(void)
u32 mvebu_get_nand_clock(void) { + u32 reg; + + if (mvebu_soc_family() == MVEBU_SOC_A38X) + reg = MVEBU_DFX_DIV_CLK_CTRL(1); + else + reg = MVEBU_CORE_DIV_CLK_CTRL(1); + return CONFIG_SYS_MVEBU_PLL_CLOCK / - ((readl(MVEBU_CORE_DIV_CLK_CTRL(1)) & + ((readl(reg) & NAND_ECC_DIVCKL_RATIO_MASK) >> NAND_ECC_DIVCKL_RATIO_OFFS); }
diff --git a/arch/arm/mach-mvebu/include/mach/soc.h b/arch/arm/mach-mvebu/include/mach/soc.h index 13c9f29..6342cdc 100644 --- a/arch/arm/mach-mvebu/include/mach/soc.h +++ b/arch/arm/mach-mvebu/include/mach/soc.h @@ -73,6 +73,7 @@ #define MVEBU_NAND_BASE (MVEBU_REGISTER(0xd0000)) #define MVEBU_SDIO_BASE (MVEBU_REGISTER(0xd8000)) #define MVEBU_LCD_BASE (MVEBU_REGISTER(0xe0000)) +#define MVEBU_DFX_BASE (MVEBU_REGISTER(0xe4000))
#define SOC_COHERENCY_FABRIC_CTRL_REG (MVEBU_REGISTER(0x20200)) #define MBUS_ERR_PROP_EN (1 << 8) @@ -92,6 +93,7 @@ #define SPI_PUP_EN BIT(5)
#define MVEBU_CORE_DIV_CLK_CTRL(i) (MVEBU_CLOCK_BASE + ((i) * 0x8)) +#define MVEBU_DFX_DIV_CLK_CTRL(i) (MVEBU_DFX_BASE + 0x250 + ((i) * 0x4)) #define NAND_ECC_DIVCKL_RATIO_OFFS 8 #define NAND_ECC_DIVCKL_RATIO_MASK (0x3F << NAND_ECC_DIVCKL_RATIO_OFFS)
Add pin control settings for the NAND flash interface. This interface is multiplexed with the device bus interface to the function is "dev" not "nand" as one might expect.
Signed-off-by: Chris Packham chris.packham@alliedtelesis.co.nz Cc: Luka Perkov luka.perkov@sartura.hr Cc: Dirk Eibach eibach@gdsys.de --- I don't think this is strictly necessary. A quick scan of boards that use this family of processor all seem to set their MPP configurations manually.
Another issue is that technically on the Armada-385 there are 4 possible CE pins. The board I'm looking at happens to use CE#0 (mpp25) but mpp26, mpp27 and mpp6 are all potentially available. I guess if any boards actually use them they can add them to their pin specification. At the very least such boards would need to update the num-cs property anyway.
arch/arm/dts/armada-38x.dtsi | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/arch/arm/dts/armada-38x.dtsi b/arch/arm/dts/armada-38x.dtsi index dc8a1a6..9ecba8a 100644 --- a/arch/arm/dts/armada-38x.dtsi +++ b/arch/arm/dts/armada-38x.dtsi @@ -258,6 +258,14 @@ marvell,function = "i2c0"; };
+ nand_pins: nand-pins { + marvell,pins = "mpp22", "mpp34", "mpp23", "mpp33", + "mpp38", "mpp28", "mpp40", "mpp42", + "mpp35", "mpp36", "mpp25", "mpp30", + "mpp32"; + marvell,function = "dev"; + }; + mdio_pins: mdio-pins { marvell,pins = "mpp4", "mpp5"; marvell,function = "ge";
Hi Chris,
Correct. Unfortunately we don't have a pin-ctrl driver for AXP / A38x in U-Boot yet. Such a driver would be very welcome though. ;)
How is this handled in the kernel? I would very much like to see these changes in the dts in sync with the kernel as much as possible. Does the kernel also use "dev" instead of "nand" here?
Thanks, Stefan
On Tue, Aug 23, 2016 at 6:57 PM, Stefan Roese sr@denx.de wrote:
Hi Chris,
I haven't seen anything in the kernel yet that uses these chip selects.
Yes I based this on https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/arch/ar... I haven't got round to porting the kernel to my board so I imagine a similar change will be required to armada-38x.dtsi in the kernel.
Thanks, Stefan
Hi Stefan,
On Tue, Aug 23, 2016 at 10:54 PM, Chris Packham judge.packham@gmail.com wrote:
Hi Chris,
I've sent a kernel patch for the armada-38x[1] so perhaps we should just drop this one and sync up if/when the kernel patch is accepted.
[1] - http://lists.infradead.org/pipermail/linux-arm-kernel/2016-August/451027.htm...
Hi Chris,
Hi Chris,
Yes, this is better. I'll drop the patch for now and will make sure that we sync with the kernel at some later time. Perhaps we even have a pinctrl driver for A38x at that time... ;)
Thanks, Stefan
Applied to u-boot-marvell/master.
Thanks, Stefan
Chris Packham
Stefan Roese
