[PATCH v2] arm64: dts: meson: odroidc2: readd PHY reset properties
The sync of the device tree and dt-bindings from Linux v5.6-rc2 11a48a5a18c6 ("Linux 5.6-rc2") causes Ethernet to break on some ODROID-C2. The PHY seems to need proper reset timing to be functional in U-Boot and Linux afterwards. Readd the old PHY reset bindings for dwmac until we support the new bindings in the PHY node.
Fixes: dd5f2351e99a ("arm64: dts: meson: sync dt and bindings from v5.6-rc2") Signed-off-by: Stefan Agner stefan@agner.ch --- arch/arm/dts/meson-gxbb-odroidc2-u-boot.dtsi | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/dts/meson-gxbb-odroidc2-u-boot.dtsi b/arch/arm/dts/meson-gxbb-odroidc2-u-boot.dtsi index 90087b00db..5a2be8171e 100644 --- a/arch/arm/dts/meson-gxbb-odroidc2-u-boot.dtsi +++ b/arch/arm/dts/meson-gxbb-odroidc2-u-boot.dtsi @@ -29,6 +29,12 @@ }; };
+ðmac { + snps,reset-gpio = <&gpio GPIOZ_14 0>; + snps,reset-delays-us = <0 10000 1000000>; + snps,reset-active-low; +}; + &usb0 { status = "disabled"; };
+ðmac {
- snps,reset-gpio = <&gpio GPIOZ_14 0>;
- snps,reset-delays-us = <0 10000 1000000>;
- snps,reset-active-low;
Thanks,
Applied to u-boot-amlogic
Neil Armstrong
Stefan Agner
